[GRASS-SVN] r68105 - grass/trunk/locale/po
Tue Mar 22 03:35:40 PDT 2016
Author: neteler
Date: 2016-03-22 03:35:40 -0700 (Tue, 22 Mar 2016)
New Revision: 68105
   grass/trunk/locale/po/grassmods_ar.po
   grass/trunk/locale/po/grassmods_cs.po
   grass/trunk/locale/po/grassmods_de.po
   grass/trunk/locale/po/grassmods_el.po
   grass/trunk/locale/po/grassmods_es.po
   grass/trunk/locale/po/grassmods_fi.po
   grass/trunk/locale/po/grassmods_fr.po
   grass/trunk/locale/po/grassmods_it.po
   grass/trunk/locale/po/grassmods_ja.po
   grass/trunk/locale/po/grassmods_ko.po
   grass/trunk/locale/po/grassmods_lv.po
   grass/trunk/locale/po/grassmods_pl.po
   grass/trunk/locale/po/grassmods_pt.po
   grass/trunk/locale/po/grassmods_pt_br.po
   grass/trunk/locale/po/grassmods_ro.po
   grass/trunk/locale/po/grassmods_ru.po
   grass/trunk/locale/po/grassmods_sl.po
   grass/trunk/locale/po/grassmods_th.po
   grass/trunk/locale/po/grassmods_tr.po
   grass/trunk/locale/po/grassmods_vi.po
   grass/trunk/locale/po/grassmods_zh.po
i.target: Fix a message (complete r68090)
Modified: grass/trunk/locale/po/grassmods_ar.po
--- grass/trunk/locale/po/grassmods_ar.po	2016-03-22 02:27:50 UTC (rev 68104)
+++ grass/trunk/locale/po/grassmods_ar.po	2016-03-22 10:35:40 UTC (rev 68105)
@@ -15472,7 +15472,7 @@
 msgstr "اسم الخريطة الناتجة"
 #: ../imagery/i.target/main.c:68
-msgid "Set current location and mapset as target for of imagery group"
+msgid "Set current location and mapset as target for imagery group"
 msgstr ""
 #: ../imagery/i.target/main.c:90 ../imagery/i.target/main.c:107
Modified: grass/trunk/locale/po/grassmods_cs.po
--- grass/trunk/locale/po/grassmods_cs.po	2016-03-22 02:27:50 UTC (rev 68104)
+++ grass/trunk/locale/po/grassmods_cs.po	2016-03-22 10:35:40 UTC (rev 68105)
@@ -15583,7 +15583,7 @@
 msgstr "Název cílového mapsetu"
 msgstr "Nastaví aktuální lokaci a mapset jako cíl pro obrazovou skupinu"
Modified: grass/trunk/locale/po/grassmods_de.po
--- grass/trunk/locale/po/grassmods_de.po	2016-03-22 02:27:50 UTC (rev 68104)
+++ grass/trunk/locale/po/grassmods_de.po	2016-03-22 10:35:40 UTC (rev 68105)
@@ -15551,7 +15551,7 @@
 msgstr "Name des Zielmapsets."
 msgstr "Setzt aktuelle Location und Mapset als Ziel für die Bildgruppe."
Modified: grass/trunk/locale/po/grassmods_el.po
--- grass/trunk/locale/po/grassmods_el.po	2016-03-22 02:27:50 UTC (rev 68104)
+++ grass/trunk/locale/po/grassmods_el.po	2016-03-22 10:35:40 UTC (rev 68105)
@@ -14926,7 +14926,7 @@
 msgstr ""
 msgstr ""
Modified: grass/trunk/locale/po/grassmods_es.po
--- grass/trunk/locale/po/grassmods_es.po	2016-03-22 02:27:50 UTC (rev 68104)
+++ grass/trunk/locale/po/grassmods_es.po	2016-03-22 10:35:40 UTC (rev 68105)
@@ -15574,7 +15574,7 @@
 msgstr "Nombre de destino del conjunto de mapas"
 msgstr ""
 "Asignar la localización y el conjunto de mapas activo como destino del grupo "
 "de imágenes"
Modified: grass/trunk/locale/po/grassmods_fi.po
--- grass/trunk/locale/po/grassmods_fi.po	2016-03-22 02:27:50 UTC (rev 68104)
+++ grass/trunk/locale/po/grassmods_fi.po	2016-03-22 10:35:40 UTC (rev 68105)
@@ -14270,7 +14270,7 @@
 msgstr ""
 msgstr ""
Modified: grass/trunk/locale/po/grassmods_fr.po
--- grass/trunk/locale/po/grassmods_fr.po	2016-03-22 02:27:50 UTC (rev 68104)
+++ grass/trunk/locale/po/grassmods_fr.po	2016-03-22 10:35:40 UTC (rev 68105)
@@ -16248,7 +16248,7 @@
 msgstr "Nom du jeu de données en sortie"
 msgstr ""
 "Règle le Secteur courant et le jeu de donnée comme cible du groupe d'images"
Modified: grass/trunk/locale/po/grassmods_it.po
--- grass/trunk/locale/po/grassmods_it.po	2016-03-22 02:27:50 UTC (rev 68104)
+++ grass/trunk/locale/po/grassmods_it.po	2016-03-22 10:35:40 UTC (rev 68105)
@@ -15336,7 +15336,7 @@
 msgstr "Nome del mapset di destinazione"
 msgstr ""
 "Imposta location e mapset correnti come destinazione del gruppo di immagini"
Modified: grass/trunk/locale/po/grassmods_ja.po
--- grass/trunk/locale/po/grassmods_ja.po	2016-03-22 02:27:50 UTC (rev 68104)
+++ grass/trunk/locale/po/grassmods_ja.po	2016-03-22 10:35:40 UTC (rev 68105)
@@ -15419,7 +15419,7 @@
 msgstr "ターゲットマップセット名"
 msgstr ""
 "画像グループのターゲットとして現在のロケーションとマップセットを設定する。"
Modified: grass/trunk/locale/po/grassmods_ko.po
--- grass/trunk/locale/po/grassmods_ko.po	2016-03-22 02:27:50 UTC (rev 68104)
+++ grass/trunk/locale/po/grassmods_ko.po	2016-03-22 10:35:40 UTC (rev 68105)
@@ -15003,7 +15003,7 @@
 msgstr ""
 msgstr ""
Modified: grass/trunk/locale/po/grassmods_lv.po
--- grass/trunk/locale/po/grassmods_lv.po	2016-03-22 02:27:50 UTC (rev 68104)
+++ grass/trunk/locale/po/grassmods_lv.po	2016-03-22 10:35:40 UTC (rev 68105)
@@ -15410,7 +15410,7 @@
 msgstr "Rastra kartes nosaukums"
 msgstr ""
Modified: grass/trunk/locale/po/grassmods_pl.po
--- grass/trunk/locale/po/grassmods_pl.po	2016-03-22 02:27:50 UTC (rev 68104)
+++ grass/trunk/locale/po/grassmods_pl.po	2016-03-22 10:35:40 UTC (rev 68105)
@@ -15489,7 +15489,7 @@
 msgstr "Nazwa docelowego mapsetu"
 msgstr "Ustaw bieżącą lokację i mapset jako docelowe dla grupy obrazów"
Modified: grass/trunk/locale/po/grassmods_pt.po
--- grass/trunk/locale/po/grassmods_pt.po	2016-03-22 02:27:50 UTC (rev 68104)
+++ grass/trunk/locale/po/grassmods_pt.po	2016-03-22 10:35:40 UTC (rev 68105)
@@ -15865,7 +15865,7 @@
 msgstr "Nome do mapset de destino"
 msgstr "Definir locação e mapset atuais como destino para um grupo de imagens"
Modified: grass/trunk/locale/po/grassmods_pt_br.po
--- grass/trunk/locale/po/grassmods_pt_br.po	2016-03-22 02:27:50 UTC (rev 68104)
+++ grass/trunk/locale/po/grassmods_pt_br.po	2016-03-22 10:35:40 UTC (rev 68105)
Modified: grass/trunk/locale/po/grassmods_ro.po
--- grass/trunk/locale/po/grassmods_ro.po	2016-03-22 02:27:50 UTC (rev 68104)
+++ grass/trunk/locale/po/grassmods_ro.po	2016-03-22 10:35:40 UTC (rev 68105)
@@ -14466,7 +14466,7 @@
 msgstr ""
 msgstr ""
Modified: grass/trunk/locale/po/grassmods_ru.po
--- grass/trunk/locale/po/grassmods_ru.po	2016-03-22 02:27:50 UTC (rev 68104)
+++ grass/trunk/locale/po/grassmods_ru.po	2016-03-22 10:35:40 UTC (rev 68105)
@@ -15591,7 +15591,7 @@
 msgstr "Имя целевого набора"
 msgstr "Установить текущую область и набор как целевые для группы изображений"
Modified: grass/trunk/locale/po/grassmods_sl.po
--- grass/trunk/locale/po/grassmods_sl.po	2016-03-22 02:27:50 UTC (rev 68104)
+++ grass/trunk/locale/po/grassmods_sl.po	2016-03-22 10:35:40 UTC (rev 68105)
@@ -15563,7 +15563,7 @@
 msgstr "Ime izhodnega rastrskega sloja"
 msgstr ""
Modified: grass/trunk/locale/po/grassmods_th.po
--- grass/trunk/locale/po/grassmods_th.po	2016-03-22 02:27:50 UTC (rev 68104)
+++ grass/trunk/locale/po/grassmods_th.po	2016-03-22 10:35:40 UTC (rev 68105)
@@ -15537,7 +15537,7 @@
 msgstr "ชื่อของ ชุดแผนที่เป้าหมาย"
 msgstr "กำหนด ตำแหน่งและชุดแผนที่ ปัจจุบัน เป็นเป้าหมายสำหรับ กลุ่มภาพ"
Modified: grass/trunk/locale/po/grassmods_tr.po
--- grass/trunk/locale/po/grassmods_tr.po	2016-03-22 02:27:50 UTC (rev 68104)
+++ grass/trunk/locale/po/grassmods_tr.po	2016-03-22 10:35:40 UTC (rev 68105)
@@ -15357,7 +15357,7 @@
 msgstr "Hedef harita takımının adı"
 msgstr ""
Modified: grass/trunk/locale/po/grassmods_vi.po
--- grass/trunk/locale/po/grassmods_vi.po	2016-03-22 02:27:50 UTC (rev 68104)
+++ grass/trunk/locale/po/grassmods_vi.po	2016-03-22 10:35:40 UTC (rev 68105)
@@ -15623,7 +15623,7 @@
 msgstr "Tên của bộ bản đồ đích"
 msgstr "Thiết lập vị trí và bộ bản đồ hiện tại làm đích cho nhóm ảnh"
Modified: grass/trunk/locale/po/grassmods_zh.po
--- grass/trunk/locale/po/grassmods_zh.po	2016-03-22 02:27:50 UTC (rev 68104)
+++ grass/trunk/locale/po/grassmods_zh.po	2016-03-22 10:35:40 UTC (rev 68105)
@@ -15485,7 +15485,7 @@
 msgstr ""
 msgstr ""
