[GRASS-SVN] r68363 - grass/trunk/scripts/r.fillnulls
Mon May 2 09:09:16 PDT 2016
Author: zarch
Date: 2016-05-02 09:09:16 -0700 (Mon, 02 May 2016)
New Revision: 68363
   grass/trunk/scripts/r.fillnulls/r.fillnulls.py
Fix conflicting during rebasing
Modified: grass/trunk/scripts/r.fillnulls/r.fillnulls.py
--- grass/trunk/scripts/r.fillnulls/r.fillnulls.py	2016-05-02 16:09:11 UTC (rev 68362)
+++ grass/trunk/scripts/r.fillnulls/r.fillnulls.py	2016-05-02 16:09:16 UTC (rev 68363)
@@ -131,8 +131,8 @@
     segmax = int(options['segmax'])
     npmin = int(options['npmin'])
     lambda_ = float(options['lambda'])
-    quiet = True # FIXME
+    quiet = True # FIXME
     mapset = grass.gisenv()['MAPSET']
     unique = str(os.getpid()) # Shouldn't we use temp name?
     prefix = 'r_fillnulls_%s_' % unique
@@ -144,7 +144,7 @@
     # save original region
     reg_org = grass.region()
     # check if a MASK is already present
     # and remove it to not interfere with NULL lookup part
     # as we don't fill MASKed parts!
@@ -158,16 +158,16 @@
         # idea: filter all NULLS and grow that area(s) by 3 pixel, then
         # interpolate from these surrounding 3 pixel edge
         filling = prefix + 'filled'
         grass.use_temp_region()
         grass.run_command('g.region', align = input, quiet = quiet)
         region = grass.region()
         ns_res = region['nsres']
         ew_res = region['ewres']
         grass.message(_("Using RST interpolation..."))
         grass.message(_("Locating and isolating NULL areas..."))
         # creating binary (0/1) map
         if usermask:
             grass.message(_("Skipping masked raster parts"))
@@ -177,7 +177,7 @@
             grass.mapcalc("$tmp1 = if(isnull($input),1,null())",
                 tmp1 = prefix + 'nulls', input = input)
         tmp_rmaps.append(prefix + 'nulls')
         # restoring user's mask, if present
         # to ignore MASKed original values
         if usermask:
@@ -187,7 +187,7 @@
             except CalledModuleError:
                 grass.warning(_("Failed to restore user MASK!"))
             usermask = None
         # grow identified holes by X pixels
         grass.message(_("Growing NULL areas"))
         tmp_rmaps.append(prefix + 'grown')
@@ -210,7 +210,7 @@
         grass.mapcalc("$out = if(isnull($inp), null(), $clumped)",
                         out = prefix + 'holes', inp = prefix + 'nulls', clumped = prefix + 'clumped')
         tmp_rmaps.append(prefix + 'holes')
         # use new IDs to identify holes
         try:
             grass.run_command('r.to.vect', flags='v',
@@ -219,7 +219,7 @@
         except:
             grass.fatal(_("abandoned. Removing temporary maps, restoring user mask if needed:"))
         tmp_vmaps.append(prefix + 'holes')
         # get a list of unique hole cat's
         cats_file_name = grass.tempfile(False)
         grass.run_command('v.db.select', flags = 'c', map = prefix + 'holes', columns = 'cat', file = cats_file_name, quiet = quiet)
@@ -229,10 +229,10 @@
             cat_list.append(line.rstrip('\n'))
         cats_file.close()
         os.remove(cats_file_name)
         if len(cat_list) < 1:
             grass.fatal(_("Input map has no holes. Check region settings."))
         # GTC Hole is NULL area in a raster map
         grass.message(_("Processing %d map holes") % len(cat_list))
         first = True
@@ -250,19 +250,20 @@
             tmp_vmaps.append(holename + '_pol')
             # zoom to specific hole with a buffer of two cells around the hole to remove rest of data
             try:
-                                  vector=holename + '_pol', align=input,
+                                  vector=holename + '_pol', align=input,
                                   w = 'w-%d' % (edge * 2 * ew_res),
-                                  e = 'e+%d' % (edge * 2 * ew_res),
+                                  e = 'e+%d' % (edge * 2 * ew_res),
                                   n = 'n+%d' % (edge * 2 * ns_res),
                                   s = 's-%d' % (edge * 2 * ns_res),
                                   quiet=quiet)
-                grass.fatal(_("abandoned. Removing temporary maps, restoring user mask if needed:"))
+                grass.fatal(_("abandoned. Removing temporary maps, restoring "
+                              "user mask if needed:"))
             # remove temporary map to not overfill disk
             try:
                 grass.run_command('g.remove', flags='fb', type='vector',
@@ -270,16 +271,16 @@
             tmp_vmaps.remove(holename + '_pol')
             # copy only data around hole
             grass.mapcalc("$out = if($inp == $catn, $inp, null())",
                             out = holename, inp = prefix + 'holes', catn = cat)
             tmp_rmaps.append(holename)
-            # If here loop is split into two, next part of loop can be run in parallel
+            # If here loop is split into two, next part of loop can be run in parallel
             # (except final result patching)
             # Downside - on large maps such approach causes large disk usage
             # grow hole border to get it's edge area
             tmp_rmaps.append(holename + '_grown')
             try:
@@ -287,12 +288,12 @@
                              old=-1, out=holename + '_grown', quiet=quiet)
                 grass.fatal(_("abandoned. Removing temporary map, restoring user mask if needed:"))
             # no idea why r.grow old=-1 doesn't replace existing values with NULL
-            grass.mapcalc("$out = if($inp == -1, null(), $dem)",
+            grass.mapcalc("$out = if($inp == -1, null(), $dem)",
                             out = holename + '_edges', inp = holename + '_grown', dem = input)
             tmp_rmaps.append(holename + '_edges')
             # convert to points for interpolation
             tmp_vmaps.append(holename)
             try:
@@ -301,7 +302,7 @@
                                   type='point', flags='z', quiet=quiet)
             # count number of points to control segmax parameter for interpolation:
             pointsnumber = grass.vector_info_topo(map = holename)['points']
             grass.verbose(_("Interpolating %d points") % pointsnumber)
@@ -310,23 +311,23 @@
                 grass.verbose(_("No points to interpolate"))
                 failed_list.append(holename)
                 continue
             # Avoid v.surf.rst warnings
             if pointsnumber < segmax:
                 npmin = pointsnumber + 1
                 segmax = pointsnumber
             # launch v.surf.rst
             tmp_rmaps.append(holename + '_dem')
             try:
                 grass.run_command('v.surf.rst', quiet=quiet,
                                   input=holename, elev=holename + '_dem',
-                                  tension=tension, smooth=smooth,
+                                  tension=tension, smooth=smooth,
                                   segmax=segmax, npmin=npmin)
                 grass.fatal(_("Failed to fill hole %s") % cat)
             # v.surf.rst sometimes fails with exit code 0
             # related bug #1813
             if not grass.find_file(holename + '_dem')['file']:
@@ -341,18 +342,18 @@
                 grass.warning(_("Filling has failed silently. Leaving temporary maps with prefix <%s> for debugging.") % holename)
                 continue
             # append hole result to interpolated version later used to patch into original DEM
             if first:
                 tmp_rmaps.append(filling)
                 grass.run_command('g.region', align = input, raster = holename + '_dem', quiet = quiet)
-                grass.mapcalc("$out = if(isnull($inp), null(), $dem)",
+                grass.mapcalc("$out = if(isnull($inp), null(), $dem)",
                                 out = filling, inp = holename, dem = holename + '_dem')
                 first = False
             else:
                 tmp_rmaps.append(filling + '_tmp')
                 grass.run_command('g.region', align = input, raster = (filling, holename + '_dem'), quiet = quiet)
-                grass.mapcalc("$out = if(isnull($inp), if(isnull($fill), null(), $fill), $dem)",
+                grass.mapcalc("$out = if(isnull($inp), if(isnull($fill), null(), $fill), $dem)",
                                 out = filling + '_tmp', inp = holename, dem = holename + '_dem', fill = filling)
                 try:
                     grass.run_command('g.rename',
@@ -361,7 +362,7 @@
                 tmp_rmaps.remove(filling + '_tmp') # this map has been removed. No need for later cleanup.
             # remove temporary maps to not overfill disk
             try:
                 tmp_rmaps.remove(holename)
@@ -388,7 +389,7 @@
                                   type='vector', name=holename)
     #check if method is different from rst to use r.resamp.bspline
     if method != 'rst':
         grass.message(_("Using %s bspline interpolation") % method)
@@ -402,13 +403,13 @@
         tmp_rmaps.append(prefix + 'filled')
         if usermask:
             grass.run_command('r.resamp.bspline', input = input, mask = usermask,
-                output = prefix + 'filled', method = method,
-                ew_step = 3 * reg['ewres'], ns_step = 3 * reg['nsres'],
+                output = prefix + 'filled', method = method,
+                ew_step = 3 * reg['ewres'], ns_step = 3 * reg['nsres'],
                 lambda_=lambda_, flags='n')
         else:
     # restoring user's mask, if present:
@@ -421,7 +422,7 @@
         usermask = None
     # set region to original extents, align to input
-    grass.run_command('g.region', n = reg_org['n'], s = reg_org['s'],
+    grass.run_command('g.region', n = reg_org['n'], s = reg_org['s'],
                     e = reg_org['e'], w = reg_org['w'], align = input)
     # patch orig and fill map
@@ -436,7 +437,7 @@
     # write cmd history:
     grass.raster_history(output)
     if len(failed_list) > 0:
         grass.warning(_("Following holes where not filled. Temporary maps with are left in place to allow examination of unfilled holes"))
         outlist = failed_list[0]
