[GRASS-SVN] r68398 - grass/trunk/gui/wxpython/core
Sat May 7 19:13:17 PDT 2016
Author: wenzeslaus
Date: 2016-05-07 19:13:17 -0700 (Sat, 07 May 2016)
New Revision: 68398
   grass/trunk/gui/wxpython/core/gconsole.py
   grass/trunk/gui/wxpython/core/giface.py
wxGUI: add environment paramater to GConsole
Modified: grass/trunk/gui/wxpython/core/gconsole.py
--- grass/trunk/gui/wxpython/core/gconsole.py	2016-05-07 21:32:41 UTC (rev 68397)
+++ grass/trunk/gui/wxpython/core/gconsole.py	2016-05-08 02:13:17 UTC (rev 68398)
@@ -431,7 +431,7 @@
         """Write message in error style"""
         self.writeError.emit(text=text)
-    def RunCmd(self, command, compReg=True, skipInterface=False,
+    def RunCmd(self, command, compReg=True, env=None, skipInterface=False,
                onDone=None, onPrepare=None, userData=None, addLayer=None,
                notification=Notification.MAKE_VISIBLE):
         """Run command typed into console command prompt (GPrompt).
@@ -542,12 +542,14 @@
                         return
+                if env:
+                    env = env.copy()
+                else:
+                    env = os.environ.copy()
                 # activate computational region (set with g.region)
                 # for all non-display commands.
-                if compReg:
-                    tmpreg = os.getenv("GRASS_REGION")
-                    if "GRASS_REGION" in os.environ:
-                        del os.environ["GRASS_REGION"]
+                if compReg and "GRASS_REGION" in env:
+                    del env["GRASS_REGION"]
                 # process GRASS command with argument
                 self.cmdThread.RunCmd(command,
@@ -555,14 +557,12 @@
                                       stderr=self.cmdStdErr,
                                       onDone=onDone, onPrepare=onPrepare,
                                       userData=userData, addLayer=addLayer,
-                                      env=os.environ.copy(),
+                                      env=env,
                                       notification=notification)
                 self.cmdOutputTimer.Start(50)
-                # deactivate computational region and return to display
-                # settings
-                if compReg and tmpreg:
-                    os.environ["GRASS_REGION"] = tmpreg
+                # we don't need to change computational region settings
+                # because we work on a copy
         else:
             # Send any other command to the shell. Send output to
             # console output window
@@ -609,6 +609,7 @@
+                                      env=env,
Modified: grass/trunk/gui/wxpython/core/giface.py
--- grass/trunk/gui/wxpython/core/giface.py	2016-05-07 21:32:41 UTC (rev 68397)
+++ grass/trunk/gui/wxpython/core/giface.py	2016-05-08 02:13:17 UTC (rev 68398)
@@ -246,13 +246,13 @@
         grass.percent(event.value, 100, 1)
         event.Skip()
-    def RunCmd(
-            self, command, compReg=True, skipInterface=False, onDone=None,
-            onPrepare=None, userData=None,
-            notification=Notification.MAKE_VISIBLE):
+               onDone=None, onPrepare=None, userData=None,
+               notification=Notification.MAKE_VISIBLE):
         self._gconsole.RunCmd(
             command=command,
             compReg=compReg,
+            env=env,
             skipInterface=skipInterface,
             onDone=onDone,
