[GRASS-SVN] r68406 - grass/trunk/gui/wxpython/gui_core
Sat May 7 20:25:12 PDT 2016
Author: wenzeslaus
Date: 2016-05-07 20:25:11 -0700 (Sat, 07 May 2016)
New Revision: 68406
   grass/trunk/gui/wxpython/gui_core/pyedit.py
pyedit: add Submitting/Python, refactor URL, remove prints
Modified: grass/trunk/gui/wxpython/gui_core/pyedit.py
--- grass/trunk/gui/wxpython/gui_core/pyedit.py	2016-05-08 03:01:53 UTC (rev 68405)
+++ grass/trunk/gui/wxpython/gui_core/pyedit.py	2016-05-08 03:25:11 UTC (rev 68406)
@@ -248,6 +248,11 @@
+def open_url(url):
+    import webbrowser
+    webbrowser.open(url)
 class PyEditController(object):
     # using the naming GUI convention, change for controller?
     # pylint: disable=invalid-name
@@ -290,12 +295,8 @@
         # run in console as other modules, avoid Python shell which
         # carries variables over to the next execution
         env = os.environ.copy()
-        if not self.overwrite:
-            print "overwrite not active"
         if self.overwrite:
-            print "overwrite active"
             env['GRASS_OVERWRITE'] = '1'
-        print self.giface
         self.giface.RunCmd([fd.name], env=env)
     def SaveAs(self):
@@ -437,38 +438,31 @@
         return True
     def OnHelp(self, event):
-        import webbrowser
         # inspired by g.manual but simple not using GRASS_HTML_BROWSER
         # not using g.manual because it does not show
         entry = 'libpython/script_intro.html'
         major, minor, patch = gscript.version()['version'].split('.')
         url = 'http://grass.osgeo.org/grass%s%s/manuals/%s' % (
             major, minor, entry)
-        webbrowser.open(url)
+        open_url(url)
     def OnPythonHelp(self, event):
-        import webbrowser
         url = 'https://docs.python.org/%s/tutorial/' % sys.version_info[0]
+        open_url(url)
     def OnModulesHelp(self, event):
         self.giface.Help('full_index')
+    def OnSubmittingHelp(self, event):
+        open_url('https://trac.osgeo.org/grass/wiki/Submitting/Python')
     def OnAddonsHelp(self, event):
-        import webbrowser
+        open_url('https://grass.osgeo.org/development/code-submission/')
-        url = 'https://grass.osgeo.org/development/code-submission/'
     def OnSupport(self, event):
-        import webbrowser
+        open_url('https://grass.osgeo.org/support/')
-        url = 'https://grass.osgeo.org/support/'
 class PyEditToolbar(BaseToolbar):
     # GUI class
     # pylint: disable=too-many-ancestors
@@ -522,14 +516,12 @@
                                      self.icons['overwriteFalse'].GetBitmap())
             self.SetToolShortHelp(self.overwrite,
                                   self.icons['overwriteFalse'].GetLabel())
-            print "setting overwrite true"
             self.parent.overwrite = True
         else:
             self.SetToolNormalBitmap(self.overwrite,
                                      self.icons['overwriteTrue'].GetBitmap())
                                   self.icons['overwriteTrue'].GetLabel())
-            print "setting overwrite false"
             self.parent.overwrite = False
@@ -617,6 +609,9 @@
     def OnModulesHelp(self, *args, **kwargs):
         self.controller.OnModulesHelp(*args, **kwargs)
+    def OnSubmittingHelp(self, *args, **kwargs):
+        self.controller.OnSubmittingHelp(*args, **kwargs)
     def OnAddonsHelp(self, *args, **kwargs):
         self.controller.OnAddonsHelp(*args, **kwargs)
