[GRASS-SVN] r68412 - grass-addons/grass7/vector/v.in.osm
Mon May 9 06:47:19 PDT 2016
Author: neteler
Date: 2016-05-09 06:47:18 -0700 (Mon, 09 May 2016)
New Revision: 68412
   grass-addons/grass7/vector/v.in.osm/v.in.osm.html
   grass-addons/grass7/vector/v.in.osm/v.in.osm.py
v.in.osm addon: added list layers (-l) support and minor tweaks for OSM .pbf import
Modified: grass-addons/grass7/vector/v.in.osm/v.in.osm.html
--- grass-addons/grass7/vector/v.in.osm/v.in.osm.html	2016-05-09 03:43:12 UTC (rev 68411)
+++ grass-addons/grass7/vector/v.in.osm/v.in.osm.html	2016-05-09 13:47:18 UTC (rev 68412)
@@ -4,13 +4,23 @@
 <h2>EXAMPLES</h2>
+Import from PostgreSQL DB:
 <div class="code"><pre>
-v.in.osm input="PG:host=localhost dbname=gis user=ostepok" table=planet_osm_line output=roads type=point,line where="highway is not null"
+v.in.osm input="PG:host=localhost dbname=gis user=ostepok" table=planet_osm_line \
+         type=point,line output=roads where="highway is not null"
 </pre></div>
+<p>
+Import from OSM PBF file:
+<div class="code"><pre>
+v.in.osm input=saarland-latest.osm.pbf table=lines type=point,line output=roads \
+         where="highway is not null"
+</pre></div>
 <h2>REQUIREMENTS</h2>
-PostgreSQL, PostGIS, osm2pgsql
+PostgreSQL, PostGIS, <a href="http://wiki.openstreetmap.org/wiki/Osm2pgsql">osm2pgsql</a>
 <h2>SEE ALSO</h2>
Modified: grass-addons/grass7/vector/v.in.osm/v.in.osm.py
--- grass-addons/grass7/vector/v.in.osm/v.in.osm.py	2016-05-09 03:43:12 UTC (rev 68411)
+++ grass-addons/grass7/vector/v.in.osm/v.in.osm.py	2016-05-09 13:47:18 UTC (rev 68412)
@@ -7,6 +7,7 @@
 PURPOSE:   Imports OpenStreetMap data into GRASS GIS.
 COPYRIGHT: (C) 2016 Stepan Turek, and by the GRASS Development Team
+            - list layers (-l) support and minor tweaks for OSM .pbf import by Markus Neteler
 This program is free software under the GNU General Public License
 (>=v2). Read the file COPYING that comes with GRASS for details.
@@ -39,7 +40,6 @@
 #%end
 #%option G_OPT_DB_TABLE
-#% required: yes
 #%end
 #%flag
@@ -48,6 +48,11 @@
 #% description: Assume that the dataset has the same projection as the current location
 #%end
+#%flag
+#% key: l
+#% label: List available OGR layers in data source and exit
+#%end
 import os
 import sys
 import atexit
@@ -86,11 +91,29 @@
     def main(self, options, flags):
-        ogr_flags = []
-        if flags['o']:
-            ogr_flags.append('o')
+        # just get the layer names
+        if flags['l']:
+            try:
+                grass.run_command('v.in.ogr',
+                                  quiet=True,
+                                  input=options['input'],
+                                  flags='l'
+                sys.exit()
+            except CalledModuleError:
+                grass.fatal(_('%s failed') % 'v.in.ogr')
+        else:
+            if not options['table']:
+                grass.fatal(_('Required parameter <%s> not set') % 'table')
+            if not options['output']:
+                grass.fatal(_('Required parameter <%s> not set') % 'output')
+        # process
         try:
+            # http://gdal.org/drv_osm.html
+            os.environ['OGR_INTERLEAVED_READING'] = 'YES'
+            grass.debug('Step 1/3: v.in.ogr...', 2)
                              quiet=True,
@@ -98,12 +121,13 @@
                              layer=options['table'],
                              where=options['where'],
                              type=options['type'],
-                             flags=ogr_flags
+                             flags=flags['o']
         try:
+            grass.debug('Step 2/3: v.split...', 2)
             grass.run_command('v.split',
                              quiet=True,
                              input=self.getTmp('ogr'),
@@ -114,8 +138,9 @@
             grass.fatal(_('%s failed') % 'v.split')
         try:
+            grass.debug('Step 3/3: v.build.polylines...', 2)
             grass.run_command('v.build.polylines',
-                             quiet=True, overwrite=grass.overwrite(),
+                             quiet=True,
                              input=self.getNewTmp('split'),
                              output=options['output'],
                              cats='same'
