[GRASS-SVN] r68422 - in grass-addons/grass7/imagery: . i.landsat8.qc
Wed May 11 03:16:37 PDT 2016
Author: sbl
Date: 2016-05-11 03:16:37 -0700 (Wed, 11 May 2016)
New Revision: 68422
Added:
   grass-addons/grass7/imagery/i.landsat8.qc/
   grass-addons/grass7/imagery/i.landsat8.qc/Makefile
   grass-addons/grass7/imagery/i.landsat8.qc/i.landsat8.qc.html
   grass-addons/grass7/imagery/i.landsat8.qc/i.landsat8.qc.py
i.landsat8.qc: added
Added: grass-addons/grass7/imagery/i.landsat8.qc/Makefile
--- grass-addons/grass7/imagery/i.landsat8.qc/Makefile	                        (rev 0)
+++ grass-addons/grass7/imagery/i.landsat8.qc/Makefile	2016-05-11 10:16:37 UTC (rev 68422)
@@ -0,0 +1,7 @@
+MODULE_TOPDIR = ../..
+PGM = i.landsat8.qc
+include $(MODULE_TOPDIR)/include/Make/Script.make
+default: script
Property changes on: grass-addons/grass7/imagery/i.landsat8.qc/Makefile
___________________________________________________________________
Added: svn:mime-type
   + text/x-makefile
Added: svn:eol-style
   + native
Added: grass-addons/grass7/imagery/i.landsat8.qc/i.landsat8.qc.html
--- grass-addons/grass7/imagery/i.landsat8.qc/i.landsat8.qc.html	                        (rev 0)
+++ grass-addons/grass7/imagery/i.landsat8.qc/i.landsat8.qc.html	2016-05-11 10:16:37 UTC (rev 68422)
@@ -0,0 +1,177 @@
+<h2>DESCRIPTION</h2>
+<p>Removing unreliable pixels is a fundamental and one of the first steps in
+remote sensing. Landsat8 provides a Quality Assessment (QA) band which can be
+used for this purpose.</p>
+<p>The <em>i.landsat8.qc</em> module filters (reclasifies) the QA band according
+to pixel quality characteristics the user defines as unacceptable.</p>
+<p>Values defined as unacceptable for a given condition will be set to NULL
+in the output raster map. All other values will be set to 1. The <em>i</em>-
+flag inverts this behavior.</p>
+<p>The Quality Assessment (QA) band from Landsat8 contains 16bit integer
+values that represent "bit-packed combinations of surface, atmosphere, and
+sensor conditions that can affect the overall usefulness of a given pixel".
+<br>
+The QA band is currently only available for Landsat 8 OLI/TIRS data.</p>
+<p>The following quality relevant conditions are represented as "single bits"
+in the Landsat8 QA band:</p>
+<table border="1" padding="0" spacing="1" style="width:300px;">
+  <tr>
+    <td>Condition</td>
+    <td>QA Bit Position</td>
+  </tr>
+  <tr>
+    <td>Designated Fill</td>
+    <td>0</td>
+  </tr>
+  <tr>
+    <td>Dropped Frame</td>
+    <td>1</td>
+  </tr>
+  <tr>
+    <td>Terrain Occlusion</td>
+    <td>2</td>
+  </tr>
+  <tr>
+    <td>Reserved (not currently used)</td>
+    <td>3</td>
+  </tr>
+</table>
+<p>Possible choices for the "single bits" are:</p>
+  <tr>
+    <td>Value</td>
+	<td>Description</td>
+	<td>Bit representation</td>
+  </tr>
+  <tr>
+    <td>No</td>
+	<td>This condition does not exist</td>
+	<td>0</td>
+  </tr>
+  <tr>
+    <td>Yes</td>
+	<td>This condition exists</td>
+	<td>1</td>
+  </tr>
+</table>
+<p>The following quality relevant conditions are represented as "double bits"
+<table>
+  <tr>
+    <td>QA Bit</td>
+    <td>Description Confidence</td>
+  </tr>
+  <tr>
+    <td>4-5</td>
+    <td>Water Confidence</td>
+  </tr>
+  <tr>
+    <td>6-7</td>
+  </tr>
+  <tr>
+    <td>8-9</td>
+    <td>Vegetation Confidence</td>
+  </tr>
+  <tr>
+    <td>10-11</td>
+    <td>Snow/Ice Confidence</td>
+  </tr>
+  <tr>
+    <td>12-13</td>
+    <td>Cirrus Confidence</td>
+  </tr>
+  <tr>
+    <td>14-15</td>
+    <td>Cloud Confidence</td>
+  </tr>
+</table>
+<p>Possible choices for the "double bits" are:</p>
+  <tr>
+    <td>Value</td>
+  </tr>
+  <tr>
+    <td>Not Determined</td>
+	<td>Algorithm did not determine the status of this condition</td>
+	<td>00</td>
+  </tr>
+  <tr>
+    <td>No</td>
+	<td>Algorithm has low to no confidence that this condition exists
+	(0-33 percent confidence)</td>
+	<td>01</td>
+  </tr>
+  <tr>
+    <td>Maybe</td>
+	<td>Algorithm has medium confidence that this condition exists
+	(34-66 percent confidence)</td>
+	<td>10</td>
+  </tr>
+  <tr>
+    <td>Yes</td>
+	<td>Algorithm has high confidence that this condition exists
+	(67-100 percent confidence)</td>
+	<td>11</td>
+  </tr>
+</table>
+<h2>NOTES</h2>
+<p>The Landsat Quality Assessment band is an artificial band which represents
+an analysis based on <a href=https://landsat.usgs.gov/documents/LDCM_CVT_ADD.pdf>
+defined algorithms</a>. The USGS provides the users with the following note on
+how the QA band should be used:</p>
+<p>"Rigorous science applications seeking to optimize the value of pixels used
+in a study will find QA bits useful as a first level indicator of certain
+conditions. Otherwise, users are advised that this file contains information
+that can be easily misinterpreted and it is not recommended for general use."</p>
+<h2>EXAMPLE</h2>
+<div class="code"><pre>
+#Create a cloud mask:
+i.landsat8.qc --overwrite --verbose input=LC81980182015183LGN00_BQA \
+    cloud="Not Determined,Maybe,Yes" output=LC81980182015183LGN00_Cloud_Mask
+#Create a water mask:
+    water="Not Determined,Maybe,Yes" output=LC81980182015183LGN00_Water_Mask
+</pre></div>
+<h2>SEE ALSO</h2>
+<em>
+<a href="i.modis.qc.html">i.landsat8.swlst.html</a>,
+<a href="r.bitpattern.html">r.bitpattern.html</a>,
+<a href="i.landsat8.swlst.html">i.landsat8.swlst.html</a>,
+</em>
+<h2>REFERENCES</h2>
+<em><a href=http://landsat.usgs.gov/qualityband.php>http://landsat.usgs.gov/qualityband.php</a>
+<a href=https://landsat.usgs.gov/documents/LDCM_CVT_ADD.pdf>https://landsat.usgs.gov/documents/LDCM_CVT_ADD.pdf</a></em>
+<h2>AUTHOR</h2>
+<p>Stefan Blumentrath, Norwegian Institute for Nature Research, Oslo (Norway)</p>
+<p><i>Last changed: $Date$</i></p>
Property changes on: grass-addons/grass7/imagery/i.landsat8.qc/i.landsat8.qc.html
   + text/html
Added: svn:keywords
   + Author Date Id
   + native
Added: grass-addons/grass7/imagery/i.landsat8.qc/i.landsat8.qc.py
--- grass-addons/grass7/imagery/i.landsat8.qc/i.landsat8.qc.py	                        (rev 0)
+++ grass-addons/grass7/imagery/i.landsat8.qc/i.landsat8.qc.py	2016-05-11 10:16:37 UTC (rev 68422)
@@ -0,0 +1,325 @@
+#!/usr/bin/env python
+# -*- coding: utf-8 -*-
+ MODULE:       i.landsat8.qc
+ AUTHOR(S):    Stefan Blumentrath <stefan.blumentrath at nina.no>
+ PURPOSE:      Reclass Landsat8 QA band according to acceptable pixel quality
+               as defined by the user
+ COPYRIGHT:    (C) 2016 by the GRASS Development Team
+               This program is free software under the GNU General Public
+               License (>=v2). Read the file COPYING that comes with GRASS
+               for details.
+#%Module
+#% description: Reclass Landsat8 QA band according to acceptable pixel quality as defined by the user
+#% keywords: imagery
+#% keywords: qc
+#% keywords: bitpattern
+#% keywords: mask
+#% keywords: landsat8
+#%End
+#%flag
+#% key: i
+#% description: Invert filter (default is set unacceptable pixels to NULL)
+#%end
+#%flag
+#% key: p
+#% guisection: Main
+#% description: Print effect of bitpattern filter in number of pixels filtered and exit
+#%end
+#%option G_OPT_R_INPUT
+#% description: Landsat8 QA band
+#% required : yes
+#%end
+#%option
+#% key: designated_fill
+#% multiple: No
+#% description: Unacceptable conditions for Designated Fill (bit 0)
+#% guisection: QA bit filter
+#% options: No, Yes
+#% required : no
+#%end
+#%option
+#% key: dropped_frame
+#% multiple: No
+#% description: Unacceptable conditions for Dropped Frame (bit 1)
+#% required : no
+#%end
+#%option
+#% key: terrain_occlusion
+#% multiple: No
+#% description: Unacceptable conditions for Terrain Occlusion (bit 2)
+#% required : no
+#%end
+##%option
+##% key: reserved
+##% multiple: No
+##% description: Unacceptable conditions for Reserved (not currently used) (bit 3)
+##% guisection: QA bit filter
+##% options: No, Yes
+##% required : no
+##%end
+#%option
+#% key: water
+#% multiple: yes
+#% description: Unacceptable conditions for Water Confidence (bit 4-5)
+#% options: Not Determined, No, Maybe, Yes
+#% required : no
+#%end
+#%option
+#% key: cloud_shaddow
+#% multiple: yes
+#% description: Unacceptable conditions for Cloud Shaddow Confidence (bit 6-7)
+#% required : no
+#%end
+#%option
+#% key: vegetation
+#% multiple: yes
+#% description: Unacceptable conditions for Vegetation Confidence (bit 8-9)
+#% required : no
+#%end
+#%option
+#% key: snow_ice
+#% multiple: yes
+#% description: Unacceptable conditions for Snow/Ice Confidence (bit 10-11)
+#% required : no
+#%end
+#%option
+#% key: cirrus
+#% multiple: yes
+#% description: Unacceptable conditions for Cirrus Confidence (bit 12-13)
+#% required : no
+#%end
+#%option
+#% key: cloud
+#% multiple: yes
+#% description: Unacceptable conditions for Cloud Confidence (bit 14-15)
+#% required : no
+#%end
+#%option G_OPT_R_OUTPUT
+#% description: Name for output QA band filter
+#% required: no
+#%end
+#%rules
+#% required: designated_fill,dropped_frame,terrain_occlusion,water,cloud_shaddow,vegetation,snow_ice,cirrus,cloud
+#%end
+import os
+import sys
+import grass.script as grass
+if "GISBASE" not in os.environ:
+    print "You must be in GRASS GIS to run this program."
+    sys.exit(1)
+def main():
+    Main program
+    # flags
+    invert = flags['i']
+    print_effect = flags['p']
+    # Parse options
+    input = options['input']
+    output = options['output']
+    # Define bitpattern filter (bf)
+    bf = {'designated_fill': options['designated_fill'],
+          'dropped_frame': options['dropped_frame'],
+          'terrain_occlusion': options['terrain_occlusion'],
+          # 'reserved': options[''],
+          'water': options['water'],
+          'cloud_shaddow': options['cloud_shaddow'],
+          'vegetation': options['vegetation'],
+          'snow_ice': options['snow_ice'],
+          'cirrus': options['cirrus'],
+          'cloud': options['cloud']}
+    # Check if propper input is provided:
+    if print_effect and output:
+        grass.fatal("output option and p-flag are mutually exclusive")
+    if print_effect and invert:
+        grass.fatal("i-flag and p-flag are mutually exclusive")
+    for o in ['water', 'cloud_shaddow', 'vegetation',
+              'snow_ice', 'cirrus', 'cloud']:
+        if len(bf[o].split(',')) >= 4 and not invert:
+            grass.fatal("""All conditions for {} specified as
+            unacceptable, this will result in an empty map.""".format(o))
+        if not bf[o] and invert:
+            grass.fatal("""No conditions for {} selected for an
+            invers filter, this will result in an empty map.""".format(o))
+    # Define bitpattern characteristics according to
+    # http://landsat.usgs.gov/qualityband.php
+    Currently populated bits:
+    0     Designated Fill
+    1     Dropped Frame
+    2     Terrain Occlusion
+    3     Reserved (not currently used)
+    4-5     Water Confidence
+    6-7     Reserved for cloud shaddow
+    8-9     Vegetation confidence
+    10-11     Snow/Ice confidence
+    12-13     Cirrus confidence
+    14-15     Cloud confidence
+    # Define bit length (single or double bits)
+    bl = {'designated_fill': 1,
+          'dropped_frame': 1,
+          'terrain_occlusion': 1,
+          # 'reserved': 1,
+          'water': 2,
+          'cloud_shaddow': 2,
+          'vegetation': 2,
+          'snow_ice': 2,
+          'cirrus': 2,
+          'cloud': 2}
+    # Define bit position start
+    bps = {
+        'designated_fill': 0,
+        'terrain_occlusion': 2,
+        # 'reserved': 3,
+        'water': 4,
+        'cloud_shaddow': 6,
+        'vegetation': 8,
+        'snow_ice': 10,
+        'cirrus': 12,
+        'cloud': 14}
+    For the single bits (0, 1, 2, and 3):
+        0 = No, this condition does not exist
+        1 = Yes, this condition exists.
+    # Define single bits dictionary
+    single_bits = {'No': '0',
+                   'Yes': '1'}
+The double bits (4-5, 6-7, 8-9, 10-11, 12-13, and 14-15), read from left to
+right, represent levels of confidence that a condition exists:
+00 = 'Not Determined' = Algorithm did not determine the status
+                        of this condition
+01 = 'No' = Algorithm has low to no confidence that this condition exists
+10 = 'Maybe' = Algorithm has medium confidence that this condition exists
+11 = 'Yes' = Algorithm has high confidence that this condition exists
+             (67-100 percent confidence).
+    # Define double bits dictionary
+    double_bits = {'Not Determined': '00',
+                   'No': '01',
+                   'Maybe': '10',
+                   'Yes': '11'}
+    # Get categories and number of pixels from QA band raster
+    qa_cats = grass.parse_command('r.stats', flags='cn', input=input).keys()
+    # Initialise string for reclass rules
+    rc = ''
+    # Initialise dictionary for printing the effect of the different bitpattern
+    if print_effect:
+        pe = {}
+    # Loop over category values present in the QA band (qa_cats)
+    for line in qa_cats:
+        cat, pixels = line.split(' ')
+        # Convert integer categories into bitpattern
+        bin_cat = '{0:016b}'.format(int(cat))
+        # Loop over the bitpattern filter (bf) elements defined by the user
+        for k in bf.keys():
+            # Only work on bits included in the user`s bitpattern filter (bf)
+            if bf[k]:
+                # Calculate bit positions end (bpe)
+                bpe = bps[k] + bl[k]
+                # Extract unnacceptable bitpatterns (bp) form bitpattern filter
+                for bp in bf[k].split(','):
+                    if bl[k] == 1:
+                        bits = single_bits[bp]
+                    else:
+                        bits = double_bits[bp]
+                    # Check if bitpattern of the category should be filtered
+                    if bits == bin_cat[len(bin_cat) -
+                                       bpe:len(bin_cat) - bps[k]]:
+                        # Add category to recassification rule
+                        rc = rc + ' {}'.format(cat)
+                        # Calculate nuber of pixels which are filtered using
+                        # the current bitpattern
+                        if print_effect:
+                            pe_key = '{} = {}'.format(k, bp)
+                            if pe_key not in pe.keys():
+                                pe[pe_key] = int(pixels)
+                            else:
+                                pe[pe_key] = pe[pe_key] + int(pixels)
+    # Construct rules for reclassification
+    if invert:
+        rc = rc + ' = 1\n * = NULL'
+    else:
+        rc = rc + ' = NULL\n * = 1'
+    # Print filterstistics if requested, else reclassify
+    if print_effect:
+        for k in pe.keys():
+            sys.stdout.write('{} {}\n'.format(k, pe[k]))
+    else:
+        grass.write_command('r.reclass', flags='', input=input, output=output,
+                            rules='-', stdin=rc)
+if __name__ == "__main__":
+    options, flags = grass.parser()
+    sys.exit(main())
Property changes on: grass-addons/grass7/imagery/i.landsat8.qc/i.landsat8.qc.py
Added: svn:executable
   + text/x-python
   + native
