[GRASS-SVN] r68468 - grass/trunk/imagery/i.segment
Thu May 19 13:26:05 PDT 2016
Author: mmetz
Date: 2016-05-19 13:26:04 -0700 (Thu, 19 May 2016)
New Revision: 68468
Added:
   grass/trunk/imagery/i.segment/mean_shift.c
   grass/trunk/imagery/i.segment/region_growing.c
   grass/trunk/imagery/i.segment/watershed.c
   grass/trunk/imagery/i.segment/create_isegs.c
   grass/trunk/imagery/i.segment/iseg.h
   grass/trunk/imagery/i.segment/parse_args.c
i.segment: prepare for different algorithms
Modified: grass/trunk/imagery/i.segment/create_isegs.c
--- grass/trunk/imagery/i.segment/create_isegs.c	2016-05-19 19:17:13 UTC (rev 68467)
+++ grass/trunk/imagery/i.segment/create_isegs.c	2016-05-19 20:26:04 UTC (rev 68468)
@@ -14,105 +14,6 @@
 #include <grass/rbtree.h>	/* Red Black Tree library functions */
 #include "iseg.h"
-#define EPSILON 1.0e-8
-#ifdef MAX
-#undef MAX
-#endif
-#define MAX(a,b) ( ((a) > (b)) ? (a) : (b) )
-#ifdef MIN
-#undef MIN
-#endif
-#define MIN(a,b) ( ((a) < (b)) ? (a) : (b) )
-/* internal functions */
-static int merge_regions(struct ngbr_stats *, struct reg_stats *, /* Ri */
-                         struct ngbr_stats *, struct reg_stats *, /* Rk */
-			 int,
-			 struct globals *);
-static int search_neighbors(struct ngbr_stats *,    /* Ri */
-			    struct reg_stats *,
-                            struct NB_TREE *,       /* Ri's neighbors */
-			    double *,               /* highest similarity */
-			    struct ngbr_stats *,    /* Ri's best neighbor */
-static int set_candidate_flag(struct ngbr_stats *, int , struct globals *);
-static int find_best_neighbor(struct ngbr_stats *, struct reg_stats *,
-			      struct NB_TREE *, struct ngbr_stats *,
-			      struct reg_stats *, double *, int,
-static int calculate_reg_stats(int, int, struct reg_stats *,
-/* function used by binary tree to compare items */
-static int compare_rc(const void *first, const void *second)
-    struct rc *a = (struct rc *)first, *b = (struct rc *)second;
-    if (a->row < b->row)
-	return -1;
-    if (a->row > b->row)
-	return 1;
-    /* same row */
-    if (a->col < b->col)
-	return -1;
-    if (a->col > b->col)
-	return 1;
-    /* same row and col */
-    return 0;
-static int compare_ints(const void *first, const void *second)
-    int a = *(int *)first, b = *(int *)second;
-    return (a < b ? -1 : (a > b));
-static int compare_double(double first, double second)
-    /* standard comparison, gives good results */
-    if (first < second)
-	return -1;
-    return (first > second);
-    /* fuzzy comparison,
-     * can give weird results if EPSILON is too large or
-     * if the formula is changed because this is operating at the
-     * limit of double fp precision */
-    if (first < second && first + first * EPSILON < second)
-	    return -1;
-    if (first > second && first > second + second * EPSILON)
-	    return 1;
-    return 0;
-static int dump_Ri(struct ngbr_stats *Ri, struct reg_stats *Ri_rs, double *Ri_sim,
-                   double *Rk_sim, int *Ri_nn, int *Rk_nn, struct globals *globals)
-    int i;
-    G_debug(0, "Ri, Ri_rs ID: %d, %d", Ri->id, Ri_rs->id);
-    G_debug(0, "Ri, Ri_rs count: %d, %d", Ri->count, Ri_rs->count);
-    for (i = 0; i < globals->nbands; i++) {
-	G_debug(0, "Ri, Ri_rs mean %d: %g, %g", i, Ri->mean[i], Ri_rs->mean[i]);
-	G_debug(0, "Ri_rs sum %d: %g", i, Ri_rs->sum[i]);
-    G_debug(0, "Ri nn: %d", *Ri_nn);
-    if (Rk_nn)
-	G_debug(0, "Rk nn: %d", *Rk_nn);
-    G_debug(0, "Ri similarity: %g", *Ri_sim);
-    if (Rk_sim)
-	G_debug(0, "Rk similarity: %g", *Rk_sim);
-    return 1;
 int create_isegs(struct globals *globals)
     int row, col;
@@ -120,11 +21,9 @@
     int have_bound, rid;
     CELL current_bound, bounds_val;
-    G_debug(1, "segmentation method: %d", globals->method);
     if (globals->bounds_map == NULL) {
 	/* just one time through loop */
-	successflag = region_growing(globals);
+	successflag = globals->method(globals);
     else {
 	/* outer processing loop for polygon constraints */
@@ -171,7 +70,7 @@
 	    globals->col_max++;
 	    if (have_bound)
 	}    /* end outer loop for processing polygons */
 	/* restore NULL flag */
@@ -188,1457 +87,3 @@
     return successflag;
-int region_growing(struct globals *globals)
-    int row, col, t;
-    double threshold, adjthresh, Ri_similarity, Rk_similarity;
-    double alpha2, divisor;		/* threshold parameters */
-    int n_merges, do_merge;		/* number of merges on that iteration */
-    int pathflag;		/* =1 if we didn't find mutually best neighbors, continue with Rk */
-    int candidates_only;
-    struct ngbr_stats Ri,
-                      Rk,
-	              Rk_bestn,         /* Rk's best neighbor */
-		      *next;
-    int Ri_nn, Rk_nn; /* number of neighbors for Ri/Rk */
-    struct NB_TREE *Ri_ngbrs, *Rk_ngbrs;
-    struct NB_TRAV travngbr;
-    /* not all regions are in the tree, but we always need reg_stats for Ri and Rk */
-    struct reg_stats Ri_rs, Rk_rs, Rk_bestn_rs;
-    double *dp;
-    struct NB_TREE *tmpnbtree;
-    G_verbose_message("Running region growing algorithm");
-    /* init neighbor stats */
-    Ri.mean = G_malloc(globals->datasize);
-    Rk.mean = G_malloc(globals->datasize);
-    Rk_bestn.mean = G_malloc(globals->datasize);
-    Ri_ngbrs = nbtree_create(globals->nbands, globals->datasize);
-    Rk_ngbrs = nbtree_create(globals->nbands, globals->datasize);
-    /* init region stats */
-    Ri_rs.mean = G_malloc(globals->datasize);
-    Ri_rs.sum = G_malloc(globals->datasize);
-    Rk_rs.mean = G_malloc(globals->datasize);
-    Rk_rs.sum = G_malloc(globals->datasize);
-    Rk_bestn_rs.mean = G_malloc(globals->datasize);
-    Rk_bestn_rs.sum = G_malloc(globals->datasize);
-    t = 0;
-    n_merges = 2;
-    /* threshold calculation */
-    alpha2 = globals->alpha * globals->alpha;
-    threshold = alpha2;
-    G_debug(1, "Squared threshold: %g", threshold);
-    /* make the divisor a constant ? */
-    divisor = globals->nrows + globals->ncols;
-    while (t < globals->end_t && n_merges > 1) {
-	G_message(_("Processing pass %d..."), ++t);
-	n_merges = 0;
-	globals->candidate_count = 0;
-	flag_clear_all(globals->candidate_flag);
-	/* Set candidate flag to true/1 for all non-NULL cells */
-	for (row = globals->row_min; row < globals->row_max; row++) {
-	    for (col = globals->col_min; col < globals->col_max; col++) {
-		if (!(FLAG_GET(globals->null_flag, row, col))) {
-		    FLAG_SET(globals->candidate_flag, row, col);
-		    globals->candidate_count++;
-	G_debug(4, "Starting to process %ld candidate cells",
-		globals->candidate_count);
-	/*process candidate cells */
-	G_percent_reset();
-	    G_percent(row - globals->row_min,
-	              globals->row_max - globals->row_min, 4);
-		if (!(FLAG_GET(globals->candidate_flag, row, col)))
-		    continue;
-		pathflag = TRUE;
-		candidates_only = TRUE;
-		nbtree_clear(Ri_ngbrs);
-		nbtree_clear(Rk_ngbrs);
-		G_debug(4, "Next starting cell: row, %d, col, %d",
-			row, col);
-		/* First cell in Ri is current row/col */
-		Ri.row = row;
-		Ri.col = col;
-		/* get Ri's segment ID */
-		Segment_get(&globals->rid_seg, (void *)&Ri.id, Ri.row, Ri.col);
-		if (Ri.id < 0)
-		    continue;
-		if (Ri.id == 0)
-		    G_fatal_error("Zero segment id at row %d, col %d", Ri.row, Ri.col);
-		/* find segment neighbors */
-		/* find Ri's best neighbor, clear candidate flag */
-		Ri_similarity = 2;
-		Ri_rs.id = Ri.id;
-		fetch_reg_stats(Ri.row, Ri.col, &Ri_rs, globals);
-		memcpy(Ri.mean, Ri_rs.mean, globals->datasize);
-		Ri.count = Ri_rs.count;
-		/* Ri is now complete */
-		G_debug(4, "Ri is now complete");
-		/* find best neighbor, get region stats for Rk */
-		Ri_nn = find_best_neighbor(&Ri, &Ri_rs, Ri_ngbrs,
-					   &Rk, &Rk_rs, &Ri_similarity,
-					   1, globals);
-		/* Rk is now complete */
-		G_debug(4, "Rk is now complete");
-		if (Rk.id == 0) {
-		    /* this can only happen if the segment is surrounded by NULL data */
-		    G_debug(4, "Segment had no valid neighbors");
-		    continue;
-		if (/* !(t & 1) && */ Ri_nn == 1 &&
-		    !(FLAG_GET(globals->candidate_flag, Rk.row, Rk.col)) &&
-		    compare_double(Ri_similarity, threshold) == -1) {
-		    /* this is slow ??? */
-		    int smaller = Rk.count;
-		    if (Ri.count < Rk.count)
-			smaller = Ri.count;
-		    /* TODO: better */
-		    adjthresh = pow(alpha2, 1. + (double) smaller / divisor);
-		    if (compare_double(Ri_similarity, adjthresh) == -1) {
-			G_debug(4, "Ri nn == 1");
-			if (Rk.count < 2)
-			    G_fatal_error("Rk count too low");
-			if (Rk.count < Ri.count)
-			    G_debug(4, "Rk count lower than Ri count");
-			merge_regions(&Ri, &Ri_rs, &Rk, &Rk_rs, 1, globals);
-			n_merges++;
-		    pathflag = FALSE;
-		if (/* t & */ 1) {
-		    if ((globals->nn < 8 && Rk.count <= 8) ||
-		        (globals->nn >= 8 && Rk.count <= globals->nn))
-		    candidates_only = FALSE;
-		while (pathflag) {
-		    pathflag = FALSE;
-		    /* optional check if Rk is candidate
-		     * to prevent backwards merging */
-		    if (candidates_only &&
-		        !(FLAG_GET(globals->candidate_flag, Rk.row, Rk.col))) {
-		    if (compare_double(Ri_similarity, threshold) == -1) {
-			do_merge = 1;
-			/* we'll have the neighbor pixel to start with. */
-			G_debug(4, "Working with Rk");
-			/* find Rk's best neighbor, do not clear candidate flag */
-			Rk_similarity = Ri_similarity;
-			Rk_bestn_rs.count = 0;
-			/* Rk_rs is already complete */
-			Rk_nn = find_best_neighbor(&Rk, &Rk_rs, Rk_ngbrs,
-						   &Rk_bestn,
-						   &Rk_bestn_rs,
-						   &Rk_similarity, 0,
-						   globals);
-			/* not mutually best neighbors */
-			if (Rk_similarity != Ri_similarity) {
-				do_merge = 0;
-			/* Ri has only one neighbor, merge */
-			if (Ri_nn == 1 && Rk_nn > 1)
-			    do_merge = 1;
-			/* adjust threshold */
-			if (do_merge) {
-			    do_merge = 0;
-				do_merge = 1;
-			if (do_merge) {
-			    G_debug(4, "merge neighbor trees");
-			    Ri_nn -= Ri_ngbrs->count;
-			    Ri_nn += (Rk_nn - Rk_ngbrs->count);
-			    globals->ns.id = Rk.id;
-			    nbtree_remove(Ri_ngbrs, &(globals->ns));
-			    nbtree_init_trav(&travngbr, Rk_ngbrs);
-			    while ((next = nbtree_traverse(&travngbr))) {
-				if (!nbtree_find(Ri_ngbrs, next) && next->id != Ri.id)
-				    nbtree_insert(Ri_ngbrs, next);
-			    Ri_nn += Ri_ngbrs->count;
-			    /* Ri is now updated, Rk no longer usable */
-			    /* made a merge, need another iteration */
-			    n_merges++;
-			    Rk_similarity = 2;
-			    /* we have checked the neighbors of Ri, Rk already
-			     * use faster version of finding the best neighbor
-			    /* use neighbor tree to find Ri's new best neighbor */
-			    search_neighbors(&Ri, &Ri_rs, Ri_ngbrs, &Ri_similarity,
-					     &Rk, &Rk_rs, globals);
-			    if (Rk.id != 0 && Ri_nn > 0 &&
-				pathflag = TRUE;
-				/* candidates_only:
-				 * FALSE: less passes, takes a bit longer, but less memory
-				 * TRUE: more passes, is a bit faster */
-			    /* else end of Ri -> Rk chain since we merged Ri and Rk
-			     * go to next row, col */
-			else {
-			    if (compare_double(Rk_similarity, threshold) == -1) {
-				pathflag = TRUE;
-			    /* test this: can it cause an infinite loop ? */
-			    if (!(FLAG_GET(globals->candidate_flag, Rk.row, Rk.col)))
-				pathflag = FALSE;
-			    if (Rk_nn < 2)
-				pathflag = FALSE;
-			    if (Rk.id < 1)
-				pathflag = FALSE;
-			    if (Rk_bestn.id == 0) {
-				G_debug(4, "Rk's best neighour is zero");
-				pathflag = FALSE;
-			    if (pathflag) {
-				/* clear candidate flag for Rk */
-				if (FLAG_GET(globals->candidate_flag, Rk.row, Rk.col)) {
-				    set_candidate_flag(&Rk, FALSE, globals);
-				/* Use Rk as next Ri:
-				 * this is the eCognition technique. */
-				G_debug(4, "do ecog");
-				Ri_nn = Rk_nn;
-				Ri_similarity = Rk_similarity;
-				dp = Ri.mean;
-				Ri = Rk;
-				Rk = Rk_bestn;
-				Rk_bestn.mean = dp;
-				Ri_rs.id = Rk_rs.id;
-				Rk_rs.id = Rk_bestn_rs.id;
-				Rk_bestn_rs.id = 0;
-				Ri_rs.count = Rk_rs.count;
-				Rk_rs.count = Rk_bestn_rs.count;
-				dp = Ri_rs.mean;
-				Ri_rs.mean = Rk_rs.mean;
-				Rk_rs.mean = Rk_bestn_rs.mean;
-				Rk_bestn_rs.mean = dp;
-				dp = Ri_rs.sum;
-				Ri_rs.sum = Rk_rs.sum;
-				Rk_rs.sum = Rk_bestn_rs.sum;
-				Rk_bestn_rs.sum = dp;
-				tmpnbtree = Ri_ngbrs;
-				Ri_ngbrs = Rk_ngbrs;
-				Rk_ngbrs = tmpnbtree;
-		    }    /* end if < threshold */
-		}    /* end pathflag */
-	    }    /* next col */
-	}    /* next row */
-        G_percent(1, 1, 1);
-	/* finished one pass for processing candidate pixels */
-	G_verbose_message("%d merges", n_merges);
-	G_debug(4, "Finished pass %d", t);
-    /*end t loop *//*TODO, should there be a max t that it can iterate for?  Include t in G_message? */
-    if (n_merges > 1)
-	G_message(_("Segmentation processes stopped at %d due to reaching max iteration limit, more merges may be possible"), t);
-    else
-	G_message(_("Segmentation converged after %d iterations"), t);
-    /* final pass, ignore threshold and force a merge for small segments with their best neighbor */
-    if (globals->min_segment_size > 1) {
-	G_message(_("Merging segments smaller than %d cells..."), globals->min_segment_size);
-	threshold = globals->alpha * globals->alpha;
-	n_merges = 0;
-	/* process candidate cells */
-		int do_merge = 1;
-		    continue;
-		Ri.row = row;
-		Ri.col = col;
-		/* get segment id */
-		Segment_get(&globals->rid_seg, (void *) &Ri.id, row, col);
-		if (Ri.id < 0)
-		    continue;
-		Ri_rs.id = Ri.id;
-		/* get segment size */
-		if (Ri.count >= globals->min_segment_size) {
-		    set_candidate_flag(&Ri, FALSE, globals);
-		    do_merge = 0;
-		while (do_merge) {
-		    do_merge = 0;
-		    /* merge all smaller than min size */
-		    if (Ri.count < globals->min_segment_size)
-			do_merge = 1;
-		    Ri_nn = 0;
-		    Rk.id = 0;
-		    if (do_merge) {
-						   &Rk, &Rk_rs,
-						   &Ri_similarity, 1,
-						   globals);
-		    do_merge = 0;
-		    if (Rk.id != 0) {
-			/* merge Ri with Rk */
-			/* do not clear candidate flag for Rk */
-			merge_regions(&Ri, &Ri_rs, &Rk, &Rk_rs, 0, globals);
-			n_merges++;
-			    do_merge = 1;
-    /* free neighbor stats */
-    G_free(Ri.mean);
-    G_free(Rk.mean);
-    G_free(Rk_bestn.mean);
-    free(Ri_ngbrs);
-    free(Rk_ngbrs);
-    /* free region stats */
-    G_free(Ri_rs.mean);
-    G_free(Ri_rs.sum);
-    G_free(Rk_rs.mean);
-    G_free(Rk_rs.sum);
-    G_free(Rk_bestn_rs.mean);
-    G_free(Rk_bestn_rs.sum);
-    return TRUE;
-static int find_best_neighbor(struct ngbr_stats *Ri,
-			      struct reg_stats *Ri_rs,
-			      struct ngbr_stats *Rk,
-			      struct reg_stats *Rk_rs,
-			      double *sim, int clear_cand,
-			      struct globals *globals)
-    int n, n_ngbrs, no_check, cmp;
-    struct rc ngbr_rc, next;
-    struct rclist rilist;
-    double tempsim;
-    int neighbors[8][2];
-    struct RB_TREE *no_check_tree;	/* cells already checked */
-    struct reg_stats *rs_found;
-    G_debug(4, "find_best_neighbor()");
-    if (Ri->id != Ri_rs->id)
-	G_fatal_error("Ri = %d but Ri_rs = %d", Ri->id, Ri_rs->id);
-    if (Ri->id <= 0)
-	G_fatal_error("Ri is %d", Ri->id);
-    if (Ri_rs->id <= 0)
-	G_fatal_error("Ri_rs is %d", Ri_rs->id);
-    /* dynamics of the region growing algorithm
-     * some regions are growing fast, often surrounded by many small regions
-     * not all regions are equally growing, some will only grow at a later stage ? */
-    /* *** initialize data *** */
-    no_check_tree = rbtree_create(compare_rc, sizeof(struct rc));
-    ngbr_rc.row = Ri->row;
-    ngbr_rc.col = Ri->col;
-    rbtree_insert(no_check_tree, &ngbr_rc);
-    n_ngbrs = 0;
-    /* TODO: add size of largest region to reg_tree, use this as min */
-    Rk->count = globals->ncells + 1;
-    Rk->id = Rk_rs->id = 0;
-    /* go through segment, spreading outwards from head */
-    rclist_init(&rilist);
-    /* check neighbors of start cell */
-    next.row = Ri->row;
-    next.col = Ri->col;
-    do {
-	/* remove from candidates */
-	if (clear_cand)
-	    FLAG_UNSET(globals->candidate_flag, next.row, next.col);
-	G_debug(5, "find_pixel_neighbors for row: %d , col %d",
-		next.row, next.col);
-	globals->find_neighbors(next.row, next.col, neighbors);
-	n = globals->nn - 1;
-	do {
-	    globals->ns.row = ngbr_rc.row = neighbors[n][0];
-	    globals->ns.col = ngbr_rc.col = neighbors[n][1];
-	    no_check = (ngbr_rc.row < globals->row_min ||
-	                ngbr_rc.row >= globals->row_max ||
-		        ngbr_rc.col < globals->col_min ||
-			ngbr_rc.col >= globals->col_max);
-	    n_ngbrs += no_check;
-	    if (!no_check) {
-		no_check = ((FLAG_GET(globals->null_flag, ngbr_rc.row,
-							  ngbr_rc.col)) != 0);
-		if (!no_check) {
-		    if (!rbtree_find(no_check_tree, &ngbr_rc)) {
-			/* not yet checked, don't check it again */
-			/* get neighbor ID */
-				    (void *) &(globals->ns.id),
-				    ngbr_rc.row, ngbr_rc.col);
-			if (globals->ns.id == Ri->id) {
-			    /* want to check this neighbor's neighbors */
-			    rclist_add(&rilist, ngbr_rc.row, ngbr_rc.col);
-			else {
-			    /* new neighbor ? */
-			    if (nbtree_find(Ri_ngbrs, &globals->ns) == NULL) {
-				/* get values for Rk */
-				globals->rs.id = globals->ns.id;
-				rs_found = rgtree_find(globals->reg_tree,
-						       &(globals->rs));
-				if (!rs_found) {
-				    /* region stats are not in search tree */
-				    rs_found = &(globals->rs);
-				    calculate_reg_stats(ngbr_rc.row, ngbr_rc.col,
-							rs_found, globals);
-				globals->ns.mean = rs_found->mean;
-				globals->ns.count = rs_found->count;
-				/* globals->ns is now complete */
-				tempsim = (globals->calculate_similarity)(Ri, &globals->ns, globals);
-				cmp = compare_double(tempsim, *sim);
-				if (cmp == -1) {
-				    *sim = tempsim;
-				    /* copy temp Rk to Rk */
-				    Rk->row = ngbr_rc.row;
-				    Rk->col = ngbr_rc.col;
-				    Rk->id = rs_found->id;
-				    Rk->count = rs_found->count;
-				    memcpy(Rk->mean, rs_found->mean,
-				           globals->datasize);
-				    Rk_rs->id = Rk->id;
-				    Rk_rs->count = Rk->count;
-				    memcpy(Rk_rs->mean, rs_found->mean,
-				    memcpy(Rk_rs->sum, rs_found->sum,
-				else if (cmp == 0) {
-				    /* resolve ties: prefer smaller regions */
-				    if (Rk->count > globals->ns.count) {
-				n_ngbrs++;
-				nbtree_insert(Ri_ngbrs, &globals->ns);
-	} while (n--);    /* end do loop - next neighbor */
-    } while (rclist_drop(&rilist, &next));   /* while there are cells to check */
-    /* clean up */
-    rbtree_destroy(no_check_tree);
-    return n_ngbrs;
-void find_four_neighbors(int p_row, int p_col,
-			        int neighbors[8][2])
-    /* north */
-    neighbors[0][0] = p_row - 1;
-    neighbors[0][1] = p_col;
-    /* east */
-    neighbors[1][0] = p_row;
-    neighbors[1][1] = p_col + 1;
-    /* south */
-    neighbors[2][0] = p_row + 1;
-    neighbors[2][1] = p_col;
-    /* west */
-    neighbors[3][0] = p_row;
-    neighbors[3][1] = p_col - 1;
-    return;
-void find_eight_neighbors(int p_row, int p_col,
-    /* get the 4 orthogonal neighbors */
-    find_four_neighbors(p_row, p_col, neighbors);
-    /* get the 4 diagonal neighbors */
-    /* north-west */
-    neighbors[4][0] = p_row - 1;
-    neighbors[4][1] = p_col - 1;
-    /* north-east */
-    neighbors[5][0] = p_row - 1;
-    neighbors[5][1] = p_col + 1;
-    /* south-west */
-    neighbors[6][0] = p_row + 1;
-    neighbors[6][1] = p_col - 1;
-    /* south-east */
-    neighbors[7][0] = p_row + 1;
-    neighbors[7][1] = p_col + 1;
-    return;
-/* similarity / distance between two points based on their input raster values */
-/* assumes first point values already saved in files->bands_seg - only run Segment_get once for that value... */
-/* TODO: Segment_get already happened for a[] values in the main function.  Could remove a[] from these parameters */
-double calculate_euclidean_similarity(struct ngbr_stats *Ri,
-    double val = 0., diff;
-    int n = globals->nbands - 1;
-    /* squared euclidean distance, sum the square differences for each dimension */
-    do {
-	diff = Ri->mean[n] - Rk->mean[n];
-	val += diff * diff;
-    } while (n--);
-    /* the return value should always be in the range 0 - 1 */
-    if (val <= 0)
-	return 0.;
-    val /= globals->max_diff;
-#ifdef _OR_SHAPE_
-    if (globals->shape_weight < 1)
-	val = val * globals->shape_weight + (1 - globals->shape_weight) *
-	      calculate_shape(rsi, rsk, nshared, globals);
-#endif
-    return val;
-double calculate_manhattan_similarity(struct ngbr_stats *Ri,
-    double val = 0.;
-    /* squared manhattan distance, sum the differences for each dimension */
-    do {
-	val += Ri->mean[n] - Rk->mean[n];
-    } while (n--);
-    if (val <= 0)
-	return 0.;
-#ifdef _OR_SHAPE_
-#endif
-    return val;
-double calculate_shape(struct reg_stats *rsi, struct reg_stats *rsk,
-                       int nshared, struct globals *globals)
-     In the eCognition literature, we find that the key factor in the
-     multi-scale segmentation algorithm used by Definiens is the scale
-     factor f:
-     f = W.Hcolor + (1 - W).Hshape
-     Hcolor = sum(b = 1:nbands)(Wb.SigmaB)
-     Hshape = Ws.Hcompact + (1 - Ws).Hsmooth
-     Hcompact = PL/sqrt(Npx)
-     Hsmooth = PL/Pbbox
-     Where
-     W is a user-defined weight of importance of object radiometry vs
-     shape (usually .9 vs .1)
-     Wb is the weigh given to band B
-     SigmaB is the std dev of the object for band b
-     Ws is a user-defined weight giving the importance of compactedness vs smoothness
-     PL is the perimeter length of the object
-     Npx the number of pixels within the object
-     Pbbox the perimeter of the bounding box of the object.
-     /* here we calculate a shape index for the new object to be created
-      * the radiometric index ranges from 0 to 1, 0 = identical
-      * with the shape index we want to favour compact and smooth opjects
-      * thus the shape index should range from 0 to 1,
-      * 0 = maximum compactness and smoothness */
-    double smooth, compact;
-    int pl, pbbox, count;
-    double bboxdiag;
-    int pl1, pl2, count1, count2;
-    int e1, n1, s1, w1, e2, n2, s2, w2, ns_extent, ew_extent;
-    pl = pl1 + pl2 - nshared;
-    ns_extent = MAX(n1, n2) - MIN(s1, s2);
-    ew_extent = MAX(e1, e2) - MIN(w1, w2);
-    pbbox = 2 * (ns_extent + ew_extent);
-    /* Smoothness Hsmooth = PL / Pbbox
-     * the smallest possible value would be
-     * the diagonal divided by the bbox perimeter
-     * invert such that the largest possible value would be
-     * the bbox perimeter divided by the diagonal
-    bboxdiag = sqrt(ns_extent * ns_extent + ew_extent * ew_extent);
-    smooth = 1. - (double)bboxdiag / pl; /* smaller -> smoother */
-    count = count1 + count2;
-    /* compactness Hcompact = PL / sqrt(Npx)
-     * a circle is the most compact form
-     * Npx = M_PI * r * r;
-     * r = sqrt(Npx / M_pi)
-     * pl_circle = 2 * sqrt(count * M_PI);
-     * compact = 1 - pl_circle / (pl * sqrt(count);
-    /* compact = 1 - 2 * sqrt(M_PI) / pl; */
-    /* PL max = Npx */
-    /* Hcompact max = Npx / sqrt(Npx) = sqrt(Npx)
-     * Hcompact / Hcompact max = (PL / sqrt(Npx)) / sqrt(Npx)
-     *                         = PL / Npx
-    compact = (double)pl / count; /* smaller -> more compact */
-    return globals->smooth_weight * smooth + (1 - globals->smooth_weight) * compact;
-static int search_neighbors(struct ngbr_stats *Ri,
-			    double *sim,
-    double tempsim, *dp;
-    struct ngbr_stats *next;
-    int cmp;
-    G_debug(4, "search_neighbors");
-    if (Ri->id <= 0)
-    nbtree_init_trav(&travngbr, Ri_ngbrs);
-	tempsim = (globals->calculate_similarity)(Ri, next, globals);
-	if (cmp == -1) {
-	    *sim = tempsim;
-	    dp = Rk->mean;
-	    *Rk = *next;
-	    Rk->mean = dp;
-	    memcpy(Rk->mean, next->mean, globals->datasize);
-	    /* resolve ties, prefer smaller regions */
-	    G_debug(4, "resolve ties");
-	    if (Rk->count > next->count) {
-		dp = Rk->mean;
-		*Rk = *next;
-		Rk->mean = dp;
-    if (Rk->id != 0) {
-	fetch_reg_stats(Rk->row, Rk->col, Rk_rs, globals);
-    return 1;
-int update_band_vals(int row, int col, struct reg_stats *rs,
-                     struct globals *globals) {
-    struct rc next, ngbr_rc;
-    int rid, count, n;
-    /* update band values with sum */
-    /* rs->id must be set */
-    G_debug(4, "update_band_vals()");
-    if (rs->count >= globals->min_reg_size) {
-	G_fatal_error(_("Region stats should go in tree, %d >= %d"),
-	              rs->count, globals->min_reg_size);
-    Segment_get(&globals->rid_seg, (void *) &rid, row, col);
-    if (rid != rs->id) {
-	G_fatal_error(_("Region ids are different"));
-    if (rs->count == 1) {
-	G_warning(_("Region consists of only one cell, nothing to update"));
-	return rs->count;
-    /* update region stats */
-    Segment_put(&globals->bands_seg, (void *)rs->sum, row, col);
-    count = 1;
-    /* fast version for rs->count == 2 */
-    if (rs->count == 2) {
-	globals->find_neighbors(row, col, neighbors);
-	do {
-	    ngbr_rc.row = neighbors[n][0];
-	    ngbr_rc.col = neighbors[n][1];
-	    if (ngbr_rc.row < globals->row_min || ngbr_rc.row >= globals->row_max ||
-		ngbr_rc.col < globals->col_min || ngbr_rc.col >= globals->col_max) {
-		continue;
-	    if ((FLAG_GET(globals->null_flag, ngbr_rc.row, ngbr_rc.col)) == 0) {
-		if (rid == rs->id) {
-				(void *)rs->sum,
-		    count++;
-		    /* only one other neighbor can have the same ID
-		     * deactivate for debugging */
-		    break;
-	} while (n--);
-	if (count > 2)
-	    G_fatal_error(_("Region size is larger than 2: %d"), count);
-    else if (rs->count > 2) {
-	struct RB_TREE *rc_check_tree;	/* cells already checked */
-	struct rclist rlist;
-	int no_check;
-	/* go through region, spreading outwards from head */
-	rclist_init(&rlist);
-	rc_check_tree = rbtree_create(compare_rc, sizeof(struct rc));
-	ngbr_rc.row = row;
-	ngbr_rc.col = col;
-	rbtree_insert(rc_check_tree, &ngbr_rc);
-	next.row = row;
-	next.col = col;
-	do {
-	    do {
-		no_check = (ngbr_rc.row < 0 || ngbr_rc.row >= globals->nrows ||
-		    ngbr_rc.col < 0 || ngbr_rc.col >= globals->ncols);
-		if (!no_check) {
-			/* already checked ? */
-			if (!rbtree_find(rc_check_tree, &ngbr_rc)) {
-				rclist_add(&rlist, ngbr_rc.row, ngbr_rc.col);
-					    (void *)rs->sum,
-				count++;
-	    } while (n--);
-	} while (rclist_drop(&rlist, &next));
-	/* clean up */
-	rbtree_destroy(rc_check_tree);
-	rclist_destroy(&rlist);
-    if (count != rs->count) {
-	G_fatal_error(_("Region size is %d, should be %d"),
-	              count, rs->count);
-    return count;
-static int merge_regions(struct ngbr_stats *Ri, struct reg_stats *Ri_rs,
-		         struct ngbr_stats *Rk, struct reg_stats *Rk_rs,
-		         int do_cand, struct globals *globals)
-    int n;
-    int R_id;
-    struct reg_stats *new_rs;
-    G_debug(4, "merge_regions");
-    /* Ri ID must always be positive */
-    if (Ri_rs->id < 1)
-	G_fatal_error("Ri id is not positive: %d", Ri_rs->id);
-    /* if Rk ID is negative (no seed), Rk count must be 1  */
-    if (Rk_rs->id < 1 && Rk_rs->count > 1)
-	G_fatal_error("Rk id is not positive: %d, but count is > 1: %d",
-	              Rk_rs->id, Rk_rs->count);
-    /* update segment id and clear candidate flag */
-    /* cases
-     * Ri, Rk are not in the tree
-     * Ri, Rk are both in the tree
-     * Ri is in the tree, Rk is not
-     * Rk is in the tree, Ri is not
-    /* Ri_rs, Rk_rs must always be set */
-    /* add Rk */
-    Ri_rs->count += Rk_rs->count;
-    n = globals->nbands - 1;
-    do {
-	Ri_rs->sum[n] += Rk_rs->sum[n];
-	Ri_rs->mean[n] = Ri_rs->sum[n] / Ri_rs->count;
-    } while (n--);
-    if (Ri->count >= Rk->count) {
-	if (Rk->count >= globals->min_reg_size) {
-	    if (rgtree_find(globals->reg_tree, Rk_rs) == NULL)
-		G_fatal_error("merge regions: Rk should be in tree");
-	    /* remove from tree */
-	    rgtree_remove(globals->reg_tree, Rk_rs);
-    else {
-	if (Ri->count >= globals->min_reg_size) {
-	    if (rgtree_find(globals->reg_tree, Ri_rs) == NULL)
-		G_fatal_error("merge regions: Ri should be in tree");
-	    rgtree_remove(globals->reg_tree, Ri_rs);
-	/* magic switch */
-	Ri_rs->id = Rk->id;
-    if ((new_rs = rgtree_find(globals->reg_tree, Ri_rs)) != NULL) {
-	/* update stats for tree item */
-	new_rs->count = Ri_rs->count;
-	memcpy(new_rs->mean, Ri_rs->mean, globals->datasize);
-	memcpy(new_rs->sum, Ri_rs->sum, globals->datasize);
-    else if (Ri_rs->count >= globals->min_reg_size) {
-	/* add to tree */
-	rgtree_insert(globals->reg_tree, Ri_rs);
-    Ri->count = Ri_rs->count;
-    memcpy(Ri->mean, Ri_rs->mean, globals->datasize);
-    if (Ri->id == Ri_rs->id) {
-	/* Ri is already updated, including candidate flags
-	 * need to clear candidate flag for Rk and set new id */
-	/* the actual merge: change region id */
-	Segment_put(&globals->rid_seg, (void *) &Ri->id, Rk->row, Rk->col);
-	if (do_cand) {
-	    do_cand = 0;
-	    if (FLAG_GET(globals->candidate_flag, Rk->row, Rk->col)) {
-		/* clear candidate flag */
-		FLAG_UNSET(globals->candidate_flag, Rk->row, Rk->col);
-		globals->candidate_count--;
-		do_cand = 1;
-	rclist_add(&rlist, Rk->row, Rk->col);
-	while (rclist_drop(&rlist, &next)) {
-	    if (do_cand) {
-	    do {
-		if (ngbr_rc.row >= globals->row_min &&
-		    ngbr_rc.row < globals->row_max &&
-		    ngbr_rc.col >= globals->col_min &&
-		    ngbr_rc.col < globals->col_max) {
-		    if (!(FLAG_GET(globals->null_flag, ngbr_rc.row, ngbr_rc.col))) {
-			Segment_get(&globals->rid_seg, (void *) &R_id,
-			if (R_id == Rk->id) {
-			    Segment_put(&globals->rid_seg, (void *) &Ri->id, ngbr_rc.row, ngbr_rc.col);
-	    } while (n--);
-    else {
-	/* Rk was larger than Ri */
-	if (do_cand && FLAG_GET(globals->candidate_flag, Rk->row, Rk->col)) {
-	    set_candidate_flag(Rk, FALSE, globals);
-	/* update region id for Ri */
-	Segment_put(&globals->rid_seg, (void *) &Rk->id, Ri->row, Ri->col);
-	rclist_add(&rlist, Ri->row, Ri->col);
-	    do {
-			Segment_get(&globals->rid_seg, (void *) &R_id, ngbr_rc.row, ngbr_rc.col);
-			if (R_id == Ri->id) {
-			    Segment_put(&globals->rid_seg, (void *) &Rk->id, ngbr_rc.row, ngbr_rc.col);
-	    } while (n--);
-	Ri->id = Ri_rs->id;   /* == Rk->id */
-	if (Ri->id != Rk->id)
-	    G_fatal_error("Ri ID should be set to Rk ID");
-    if (Rk->id > 0)
-	globals->n_regions--;
-    /* disable Rk */
-    Rk->count = Rk_rs->count = 0;
-    /* update Ri */
-    if (Ri_rs->count < globals->min_reg_size) {
-	update_band_vals(Ri->row, Ri->col, Ri_rs, globals);
-    return TRUE;
-static int set_candidate_flag(struct ngbr_stats *head, int value, struct globals *globals)
-    int n, R_id;
-    G_debug(4, "set_candidate_flag");
-    if (!(FLAG_GET(globals->candidate_flag, head->row, head->col)) != value) {
-	G_warning(_("Candidate flag is already %s"), value ? _("set") : _("unset"));
-	return FALSE;
-    rclist_add(&rlist, head->row, head->col);
-    /* (un)set candidate flag */
-    if (value == TRUE) {
-	FLAG_SET(globals->candidate_flag, head->row, head->col);
-    else {
-	FLAG_UNSET(globals->candidate_flag, head->row, head->col);
-	do {
-		    if (!(FLAG_GET(globals->candidate_flag, ngbr_rc.row, ngbr_rc.col)) == value) {
-			if (R_id == head->id) {
-				FLAG_SET(globals->candidate_flag, ngbr_rc.row, ngbr_rc.col);
-			    else {
-				FLAG_UNSET(globals->candidate_flag, ngbr_rc.row, ngbr_rc.col);
-	} while (n--);
-    return TRUE;
-int fetch_reg_stats(int row, int col, struct reg_stats *rs,
-    if (rs->id <= 0)
-	G_fatal_error("fetch_reg_stats(): invalid region id %d", rs->id);
-    if ((rs_found = rgtree_find(globals->reg_tree, rs)) != NULL) {
-	memcpy(rs->mean, rs_found->mean, globals->datasize);
-	memcpy(rs->sum, rs_found->sum, globals->datasize);
-	rs->count = rs_found->count;
-	return 1;
-    calculate_reg_stats(row, col, rs, globals);
-    return 2;
-static int calculate_reg_stats(int row, int col, struct reg_stats *rs,
-    int ret = 0;
-    G_debug(4, "calculate_reg_stats()");
-    if (rs->id <= 0)
-	G_fatal_error("Invalid region id %d", rs->id);
-    Segment_get(&globals->bands_seg, (void *)globals->bands_val,
-		row, col);
-    rs->count = 1;
-    memcpy(rs->sum, globals->bands_val, globals->datasize);
-    if (globals->min_reg_size < 3)
-	ret = 1;
-    else if (globals->min_reg_size == 3) {
-	int n, rid;
-	struct rc ngbr_rc;
-	do {
-		continue;
-		    rs->count++;
-		    break;
-	} while (n--);
-	if (rs->count > 2)
-	    G_fatal_error(_("Region size is larger than 2: %d"), rs->count);
-	ret = 2;
-    else if (globals->min_reg_size > 3) {
-	int n, rid;
-	int no_check;
-	next.row = row;
-	next.col = col;
-	do {
-	    do {
-		if (!no_check) {
-				rs->count++;
-	    } while (n--);
-	/* clean up */
-	rclist_destroy(&rilist);
-	ret = 3;
-    /* band mean */
-	memcpy(rs->mean, rs->sum, globals->datasize);
-    else {
-	int i = globals->nbands - 1;
-	do {
-	    rs->mean[i] = rs->sum[i] / rs->count;
-	} while (i--);
-	G_fatal_error(_("Region of size %d should be in search tree"),
-		      rs->count);
-    return ret;
Modified: grass/trunk/imagery/i.segment/iseg.h
--- grass/trunk/imagery/i.segment/iseg.h	2016-05-19 19:17:13 UTC (rev 68467)
+++ grass/trunk/imagery/i.segment/iseg.h	2016-05-19 20:26:04 UTC (rev 68468)
@@ -33,6 +33,7 @@
     struct rc *tail, *head;
 /* input and output files, as well as some other processing info */
 struct globals
@@ -40,7 +41,7 @@
     char *image_group;
     int weighted;		/* 0 if false/not selected, so we should scale input.
 				 * 1 if the scaling should be skipped */
-    int method;			/* Segmentation method */
+    int (*method)();		/* Segmentation method function */
     int nn;			/* number of neighbors, 4 or 8 */
     double max_diff;		/* max possible difference */
     double alpha;		/* similarity threshold */
@@ -104,7 +105,6 @@
 /* create_isegs.c */
 int create_isegs(struct globals *);
-int region_growing(struct globals *);
 void find_four_neighbors(int, int, int[][2]);
 void find_eight_neighbors(int, int, int[8][2]);
 double calculate_euclidean_similarity(struct ngbr_stats *,
@@ -122,7 +122,15 @@
 /* void calculate_reg_stats(int, int, struct reg_stats *,
                          struct globals *); */
+/* region_growing.c */
+int region_growing(struct globals *);
+/* mean_shift.c */
+int mean_shift(struct globals *);
+/* watershed.c */
+int watershed(struct globals *);
 /* rclist.c */
 void rclist_init(struct rclist *);
 void rclist_add(struct rclist *, int, int);
Added: grass/trunk/imagery/i.segment/mean_shift.c
--- grass/trunk/imagery/i.segment/mean_shift.c	                        (rev 0)
+++ grass/trunk/imagery/i.segment/mean_shift.c	2016-05-19 20:26:04 UTC (rev 68468)
@@ -0,0 +1,22 @@
+/* PURPOSE:      Develop the image segments */
+#include <stdlib.h>
+#include <string.h>
+#include <float.h>
+#include <math.h>
+#include <time.h>
+#include <grass/gis.h>
+#include <grass/glocale.h>
+#include <grass/raster.h>
+#include <grass/segment.h>	/* segmentation library */
+#include <grass/rbtree.h>	/* Red Black Tree library functions */
+#include "iseg.h"
+int mean_shift(struct globals *globals)
+    G_fatal_error(_("Mean shift is not yet implemented"));
+    return FALSE;
Property changes on: grass/trunk/imagery/i.segment/mean_shift.c
___________________________________________________________________
Added: svn:mime-type
   + text/x-csrc
Added: svn:eol-style
   + native
Modified: grass/trunk/imagery/i.segment/parse_args.c
--- grass/trunk/imagery/i.segment/parse_args.c	2016-05-19 19:17:13 UTC (rev 68467)
+++ grass/trunk/imagery/i.segment/parse_args.c	2016-05-19 20:26:04 UTC (rev 68468)
@@ -37,7 +37,7 @@
     method->type = TYPE_STRING;
     method->required = NO;
     method->answer = "region_growing";
-    method->options = "region_growing";
+    method->options = "region_growing,mean_shift,watershed";
     method->description = _("Segmentation method");
     method->guisection = _("Settings");
@@ -154,11 +154,15 @@
     /* segmentation methods:  1 = region growing */
     if (strcmp(method->answer, "region_growing") == 0)
-	globals->method = 1;
+	globals->method = region_growing;
+    if (strcmp(method->answer, "mean_shift") == 0)
+	globals->method = mean_shift;
+    if (strcmp(method->answer, "watershed") == 0)
+	globals->method = watershed;
     else
 	G_fatal_error(_("Unable to assign segmentation method"));
+    G_debug(1, "segmentation method: %s", method->answer);
     /* distance methods for similarity measurement */
     if (strcmp(similarity->answer, "euclidean") == 0)
Added: grass/trunk/imagery/i.segment/region_growing.c
--- grass/trunk/imagery/i.segment/region_growing.c	                        (rev 0)
+++ grass/trunk/imagery/i.segment/region_growing.c	2016-05-19 20:26:04 UTC (rev 68468)
@@ -0,0 +1,1567 @@
+/* Currently only region growing is implemented */
+#include <float.h>
+#include <math.h>
+#include <time.h>
+#include "iseg.h"
+#define EPSILON 1.0e-8
+#ifdef MAX
+#undef MAX
+#endif
+#define MAX(a,b) ( ((a) > (b)) ? (a) : (b) )
+#ifdef MIN
+#undef MIN
+#endif
+#define MIN(a,b) ( ((a) < (b)) ? (a) : (b) )
+/* internal functions */
+static int merge_regions(struct ngbr_stats *, struct reg_stats *, /* Ri */
+                         struct ngbr_stats *, struct reg_stats *, /* Rk */
+			 int,
+			 struct globals *);
+static int search_neighbors(struct ngbr_stats *,    /* Ri */
+			    struct reg_stats *,
+                            struct NB_TREE *,       /* Ri's neighbors */
+			    double *,               /* highest similarity */
+			    struct ngbr_stats *,    /* Ri's best neighbor */
+static int set_candidate_flag(struct ngbr_stats *, int , struct globals *);
+static int find_best_neighbor(struct ngbr_stats *, struct reg_stats *,
+			      struct NB_TREE *, struct ngbr_stats *,
+			      struct reg_stats *, double *, int,
+static int calculate_reg_stats(int, int, struct reg_stats *,
+/* function used by binary tree to compare items */
+static int compare_rc(const void *first, const void *second)
+    struct rc *a = (struct rc *)first, *b = (struct rc *)second;
+    if (a->row < b->row)
+	return -1;
+    if (a->row > b->row)
+	return 1;
+    /* same row */
+    if (a->col < b->col)
+	return -1;
+    if (a->col > b->col)
+	return 1;
+    /* same row and col */
+    return 0;
+static int compare_ints(const void *first, const void *second)
+    int a = *(int *)first, b = *(int *)second;
+    return (a < b ? -1 : (a > b));
+static int compare_double(double first, double second)
+    /* standard comparison, gives good results */
+    if (first < second)
+	return -1;
+    return (first > second);
+    /* fuzzy comparison,
+     * can give weird results if EPSILON is too large or
+     * if the formula is changed because this is operating at the
+     * limit of double fp precision */
+    if (first < second && first + first * EPSILON < second)
+	    return -1;
+    if (first > second && first > second + second * EPSILON)
+	    return 1;
+    return 0;
+static int dump_Ri(struct ngbr_stats *Ri, struct reg_stats *Ri_rs, double *Ri_sim,
+                   double *Rk_sim, int *Ri_nn, int *Rk_nn, struct globals *globals)
+    int i;
+    G_debug(0, "Ri, Ri_rs ID: %d, %d", Ri->id, Ri_rs->id);
+    G_debug(0, "Ri, Ri_rs count: %d, %d", Ri->count, Ri_rs->count);
+    for (i = 0; i < globals->nbands; i++) {
+	G_debug(0, "Ri, Ri_rs mean %d: %g, %g", i, Ri->mean[i], Ri_rs->mean[i]);
+	G_debug(0, "Ri_rs sum %d: %g", i, Ri_rs->sum[i]);
+    G_debug(0, "Ri nn: %d", *Ri_nn);
+    if (Rk_nn)
+	G_debug(0, "Rk nn: %d", *Rk_nn);
+    G_debug(0, "Ri similarity: %g", *Ri_sim);
+    if (Rk_sim)
+	G_debug(0, "Rk similarity: %g", *Rk_sim);
+    return 1;
+int region_growing(struct globals *globals)
+    int row, col, t;
+    double threshold, adjthresh, Ri_similarity, Rk_similarity;
+    double alpha2, divisor;		/* threshold parameters */
+    int n_merges, do_merge;		/* number of merges on that iteration */
+    int pathflag;		/* =1 if we didn't find mutually best neighbors, continue with Rk */
+    int candidates_only;
+    struct ngbr_stats Ri,
+                      Rk,
+	              Rk_bestn,         /* Rk's best neighbor */
+		      *next;
+    int Ri_nn, Rk_nn; /* number of neighbors for Ri/Rk */
+    struct NB_TREE *Ri_ngbrs, *Rk_ngbrs;
+    struct NB_TRAV travngbr;
+    /* not all regions are in the tree, but we always need reg_stats for Ri and Rk */
+    struct reg_stats Ri_rs, Rk_rs, Rk_bestn_rs;
+    double *dp;
+    struct NB_TREE *tmpnbtree;
+    G_verbose_message("Running region growing algorithm");
+    /* init neighbor stats */
+    Ri.mean = G_malloc(globals->datasize);
+    Rk.mean = G_malloc(globals->datasize);
+    Rk_bestn.mean = G_malloc(globals->datasize);
+    Ri_ngbrs = nbtree_create(globals->nbands, globals->datasize);
+    Rk_ngbrs = nbtree_create(globals->nbands, globals->datasize);
+    /* init region stats */
+    Ri_rs.mean = G_malloc(globals->datasize);
+    Ri_rs.sum = G_malloc(globals->datasize);
+    Rk_rs.mean = G_malloc(globals->datasize);
+    Rk_rs.sum = G_malloc(globals->datasize);
+    Rk_bestn_rs.mean = G_malloc(globals->datasize);
+    Rk_bestn_rs.sum = G_malloc(globals->datasize);
+    t = 0;
+    n_merges = 2;
+    /* threshold calculation */
+    alpha2 = globals->alpha * globals->alpha;
+    threshold = alpha2;
+    G_debug(1, "Squared threshold: %g", threshold);
+    /* make the divisor a constant ? */
+    divisor = globals->nrows + globals->ncols;
+    while (t < globals->end_t && n_merges > 1) {
+	G_message(_("Processing pass %d..."), ++t);
+	n_merges = 0;
+	globals->candidate_count = 0;
+	flag_clear_all(globals->candidate_flag);
+	/* Set candidate flag to true/1 for all non-NULL cells */
+	for (row = globals->row_min; row < globals->row_max; row++) {
+	    for (col = globals->col_min; col < globals->col_max; col++) {
+		if (!(FLAG_GET(globals->null_flag, row, col))) {
+		    FLAG_SET(globals->candidate_flag, row, col);
+		    globals->candidate_count++;
+	G_debug(4, "Starting to process %ld candidate cells",
+		globals->candidate_count);
+	/*process candidate cells */
+	G_percent_reset();
+	    G_percent(row - globals->row_min,
+	              globals->row_max - globals->row_min, 4);
+		if (!(FLAG_GET(globals->candidate_flag, row, col)))
+		    continue;
+		pathflag = TRUE;
+		candidates_only = TRUE;
+		nbtree_clear(Ri_ngbrs);
+		nbtree_clear(Rk_ngbrs);
+		G_debug(4, "Next starting cell: row, %d, col, %d",
+			row, col);
+		/* First cell in Ri is current row/col */
+		Ri.row = row;
+		Ri.col = col;
+		/* get Ri's segment ID */
+		Segment_get(&globals->rid_seg, (void *)&Ri.id, Ri.row, Ri.col);
+		if (Ri.id < 0)
+		    continue;
+		if (Ri.id == 0)
+		    G_fatal_error("Zero segment id at row %d, col %d", Ri.row, Ri.col);
+		/* find segment neighbors */
+		/* find Ri's best neighbor, clear candidate flag */
+		Ri_similarity = 2;
+		Ri_rs.id = Ri.id;
+		fetch_reg_stats(Ri.row, Ri.col, &Ri_rs, globals);
+		memcpy(Ri.mean, Ri_rs.mean, globals->datasize);
+		Ri.count = Ri_rs.count;
+		/* Ri is now complete */
+		G_debug(4, "Ri is now complete");
+		/* find best neighbor, get region stats for Rk */
+		Ri_nn = find_best_neighbor(&Ri, &Ri_rs, Ri_ngbrs,
+					   &Rk, &Rk_rs, &Ri_similarity,
+					   1, globals);
+		/* Rk is now complete */
+		G_debug(4, "Rk is now complete");
+		if (Rk.id == 0) {
+		    /* this can only happen if the segment is surrounded by NULL data */
+		    G_debug(4, "Segment had no valid neighbors");
+		    continue;
+		if (/* !(t & 1) && */ Ri_nn == 1 &&
+		    !(FLAG_GET(globals->candidate_flag, Rk.row, Rk.col)) &&
+		    compare_double(Ri_similarity, threshold) == -1) {
+		    /* this is slow ??? */
+		    int smaller = Rk.count;
+		    if (Ri.count < Rk.count)
+			smaller = Ri.count;
+		    /* TODO: better */
+		    adjthresh = pow(alpha2, 1. + (double) smaller / divisor);
+		    if (compare_double(Ri_similarity, adjthresh) == -1) {
+			G_debug(4, "Ri nn == 1");
+			if (Rk.count < 2)
+			    G_fatal_error("Rk count too low");
+			if (Rk.count < Ri.count)
+			    G_debug(4, "Rk count lower than Ri count");
+			merge_regions(&Ri, &Ri_rs, &Rk, &Rk_rs, 1, globals);
+			n_merges++;
+		    pathflag = FALSE;
+		if (/* t & */ 1) {
+		    if ((globals->nn < 8 && Rk.count <= 8) ||
+		        (globals->nn >= 8 && Rk.count <= globals->nn))
+		    candidates_only = FALSE;
+		while (pathflag) {
+		    pathflag = FALSE;
+		    /* optional check if Rk is candidate
+		     * to prevent backwards merging */
+		    if (candidates_only &&
+		        !(FLAG_GET(globals->candidate_flag, Rk.row, Rk.col))) {
+		    if (compare_double(Ri_similarity, threshold) == -1) {
+			do_merge = 1;
+			/* we'll have the neighbor pixel to start with. */
+			G_debug(4, "Working with Rk");
+			/* find Rk's best neighbor, do not clear candidate flag */
+			Rk_similarity = Ri_similarity;
+			Rk_bestn_rs.count = 0;
+			/* Rk_rs is already complete */
+			Rk_nn = find_best_neighbor(&Rk, &Rk_rs, Rk_ngbrs,
+						   &Rk_bestn,
+						   &Rk_bestn_rs,
+						   &Rk_similarity, 0,
+						   globals);
+			/* not mutually best neighbors */
+			if (Rk_similarity != Ri_similarity) {
+				do_merge = 0;
+			/* Ri has only one neighbor, merge */
+			if (Ri_nn == 1 && Rk_nn > 1)
+			    do_merge = 1;
+			/* adjust threshold */
+			if (do_merge) {
+			    do_merge = 0;
+				do_merge = 1;
+			if (do_merge) {
+			    G_debug(4, "merge neighbor trees");
+			    Ri_nn -= Ri_ngbrs->count;
+			    Ri_nn += (Rk_nn - Rk_ngbrs->count);
+			    globals->ns.id = Rk.id;
+			    nbtree_remove(Ri_ngbrs, &(globals->ns));
+			    nbtree_init_trav(&travngbr, Rk_ngbrs);
+			    while ((next = nbtree_traverse(&travngbr))) {
+				if (!nbtree_find(Ri_ngbrs, next) && next->id != Ri.id)
+				    nbtree_insert(Ri_ngbrs, next);
+			    Ri_nn += Ri_ngbrs->count;
+			    /* Ri is now updated, Rk no longer usable */
+			    /* made a merge, need another iteration */
+			    n_merges++;
+			    Rk_similarity = 2;
+			    /* we have checked the neighbors of Ri, Rk already
+			     * use faster version of finding the best neighbor
+			    /* use neighbor tree to find Ri's new best neighbor */
+			    search_neighbors(&Ri, &Ri_rs, Ri_ngbrs, &Ri_similarity,
+					     &Rk, &Rk_rs, globals);
+			    if (Rk.id != 0 && Ri_nn > 0 &&
+				pathflag = TRUE;
+				/* candidates_only:
+				 * FALSE: less passes, takes a bit longer, but less memory
+				 * TRUE: more passes, is a bit faster */
+			    /* else end of Ri -> Rk chain since we merged Ri and Rk
+			     * go to next row, col */
+			else {
+			    if (compare_double(Rk_similarity, threshold) == -1) {
+				pathflag = TRUE;
+			    /* test this: can it cause an infinite loop ? */
+			    if (!(FLAG_GET(globals->candidate_flag, Rk.row, Rk.col)))
+				pathflag = FALSE;
+			    if (Rk_nn < 2)
+				pathflag = FALSE;
+			    if (Rk.id < 1)
+				pathflag = FALSE;
+			    if (Rk_bestn.id == 0) {
+				G_debug(4, "Rk's best neighour is zero");
+				pathflag = FALSE;
+			    if (pathflag) {
+				/* clear candidate flag for Rk */
+				if (FLAG_GET(globals->candidate_flag, Rk.row, Rk.col)) {
+				    set_candidate_flag(&Rk, FALSE, globals);
+				/* Use Rk as next Ri:
+				 * this is the eCognition technique. */
+				G_debug(4, "do ecog");
+				Ri_nn = Rk_nn;
+				Ri_similarity = Rk_similarity;
+				dp = Ri.mean;
+				Ri = Rk;
+				Rk = Rk_bestn;
+				Rk_bestn.mean = dp;
+				Ri_rs.id = Rk_rs.id;
+				Rk_rs.id = Rk_bestn_rs.id;
+				Rk_bestn_rs.id = 0;
+				Ri_rs.count = Rk_rs.count;
+				Rk_rs.count = Rk_bestn_rs.count;
+				dp = Ri_rs.mean;
+				Ri_rs.mean = Rk_rs.mean;
+				Rk_rs.mean = Rk_bestn_rs.mean;
+				Rk_bestn_rs.mean = dp;
+				dp = Ri_rs.sum;
+				Ri_rs.sum = Rk_rs.sum;
+				Rk_rs.sum = Rk_bestn_rs.sum;
+				Rk_bestn_rs.sum = dp;
+				tmpnbtree = Ri_ngbrs;
+				Ri_ngbrs = Rk_ngbrs;
+				Rk_ngbrs = tmpnbtree;
+		    }    /* end if < threshold */
+		}    /* end pathflag */
+	    }    /* next col */
+	}    /* next row */
+        G_percent(1, 1, 1);
+	/* finished one pass for processing candidate pixels */
+	G_verbose_message("%d merges", n_merges);
+	G_debug(4, "Finished pass %d", t);
+    /*end t loop *//*TODO, should there be a max t that it can iterate for?  Include t in G_message? */
+    if (n_merges > 1)
+	G_message(_("Segmentation processes stopped at %d due to reaching max iteration limit, more merges may be possible"), t);
+    else
+	G_message(_("Segmentation converged after %d iterations"), t);
+    /* final pass, ignore threshold and force a merge for small segments with their best neighbor */
+    if (globals->min_segment_size > 1) {
+	G_message(_("Merging segments smaller than %d cells..."), globals->min_segment_size);
+	threshold = globals->alpha * globals->alpha;
+	n_merges = 0;
+	/* process candidate cells */
+		int do_merge = 1;
+		    continue;
+		Ri.row = row;
+		Ri.col = col;
+		/* get segment id */
+		Segment_get(&globals->rid_seg, (void *) &Ri.id, row, col);
+		if (Ri.id < 0)
+		    continue;
+		Ri_rs.id = Ri.id;
+		/* get segment size */
+		if (Ri.count >= globals->min_segment_size) {
+		    set_candidate_flag(&Ri, FALSE, globals);
+		    do_merge = 0;
+		while (do_merge) {
+		    do_merge = 0;
+		    /* merge all smaller than min size */
+		    if (Ri.count < globals->min_segment_size)
+			do_merge = 1;
+		    Ri_nn = 0;
+		    Rk.id = 0;
+		    if (do_merge) {
+						   &Rk, &Rk_rs,
+						   &Ri_similarity, 1,
+						   globals);
+		    do_merge = 0;
+		    if (Rk.id != 0) {
+			/* merge Ri with Rk */
+			/* do not clear candidate flag for Rk */
+			merge_regions(&Ri, &Ri_rs, &Rk, &Rk_rs, 0, globals);
+			n_merges++;
+			    do_merge = 1;
+    /* free neighbor stats */
+    G_free(Ri.mean);
+    G_free(Rk.mean);
+    G_free(Rk_bestn.mean);
+    free(Ri_ngbrs);
+    free(Rk_ngbrs);
+    /* free region stats */
+    G_free(Ri_rs.mean);
+    G_free(Ri_rs.sum);
+    G_free(Rk_rs.mean);
+    G_free(Rk_rs.sum);
+    G_free(Rk_bestn_rs.mean);
+    G_free(Rk_bestn_rs.sum);
+    return TRUE;
+static int find_best_neighbor(struct ngbr_stats *Ri,
+			      struct reg_stats *Ri_rs,
+			      struct ngbr_stats *Rk,
+			      struct reg_stats *Rk_rs,
+			      double *sim, int clear_cand,
+			      struct globals *globals)
+    int n, n_ngbrs, no_check, cmp;
+    struct rc ngbr_rc, next;
+    struct rclist rilist;
+    double tempsim;
+    int neighbors[8][2];
+    struct RB_TREE *no_check_tree;	/* cells already checked */
+    struct reg_stats *rs_found;
+    G_debug(4, "find_best_neighbor()");
+    if (Ri->id != Ri_rs->id)
+	G_fatal_error("Ri = %d but Ri_rs = %d", Ri->id, Ri_rs->id);
+    if (Ri->id <= 0)
+	G_fatal_error("Ri is %d", Ri->id);
+    if (Ri_rs->id <= 0)
+	G_fatal_error("Ri_rs is %d", Ri_rs->id);
+    /* dynamics of the region growing algorithm
+     * some regions are growing fast, often surrounded by many small regions
+     * not all regions are equally growing, some will only grow at a later stage ? */
+    /* *** initialize data *** */
+    no_check_tree = rbtree_create(compare_rc, sizeof(struct rc));
+    ngbr_rc.row = Ri->row;
+    ngbr_rc.col = Ri->col;
+    rbtree_insert(no_check_tree, &ngbr_rc);
+    n_ngbrs = 0;
+    /* TODO: add size of largest region to reg_tree, use this as min */
+    Rk->count = globals->ncells + 1;
+    Rk->id = Rk_rs->id = 0;
+    /* go through segment, spreading outwards from head */
+    rclist_init(&rilist);
+    /* check neighbors of start cell */
+    next.row = Ri->row;
+    next.col = Ri->col;
+    do {
+	/* remove from candidates */
+	if (clear_cand)
+	    FLAG_UNSET(globals->candidate_flag, next.row, next.col);
+	G_debug(5, "find_pixel_neighbors for row: %d , col %d",
+		next.row, next.col);
+	globals->find_neighbors(next.row, next.col, neighbors);
+	n = globals->nn - 1;
+	do {
+	    globals->ns.row = ngbr_rc.row = neighbors[n][0];
+	    globals->ns.col = ngbr_rc.col = neighbors[n][1];
+	    no_check = (ngbr_rc.row < globals->row_min ||
+	                ngbr_rc.row >= globals->row_max ||
+		        ngbr_rc.col < globals->col_min ||
+			ngbr_rc.col >= globals->col_max);
+	    n_ngbrs += no_check;
+	    if (!no_check) {
+		no_check = ((FLAG_GET(globals->null_flag, ngbr_rc.row,
+							  ngbr_rc.col)) != 0);
+		if (!no_check) {
+		    if (!rbtree_find(no_check_tree, &ngbr_rc)) {
+			/* not yet checked, don't check it again */
+			/* get neighbor ID */
+				    (void *) &(globals->ns.id),
+				    ngbr_rc.row, ngbr_rc.col);
+			if (globals->ns.id == Ri->id) {
+			    /* want to check this neighbor's neighbors */
+			    rclist_add(&rilist, ngbr_rc.row, ngbr_rc.col);
+			else {
+			    /* new neighbor ? */
+			    if (nbtree_find(Ri_ngbrs, &globals->ns) == NULL) {
+				/* get values for Rk */
+				globals->rs.id = globals->ns.id;
+				rs_found = rgtree_find(globals->reg_tree,
+						       &(globals->rs));
+				if (!rs_found) {
+				    /* region stats are not in search tree */
+				    rs_found = &(globals->rs);
+				    calculate_reg_stats(ngbr_rc.row, ngbr_rc.col,
+							rs_found, globals);
+				globals->ns.mean = rs_found->mean;
+				globals->ns.count = rs_found->count;
+				/* globals->ns is now complete */
+				tempsim = (globals->calculate_similarity)(Ri, &globals->ns, globals);
+				cmp = compare_double(tempsim, *sim);
+				if (cmp == -1) {
+				    *sim = tempsim;
+				    /* copy temp Rk to Rk */
+				    Rk->row = ngbr_rc.row;
+				    Rk->col = ngbr_rc.col;
+				    Rk->id = rs_found->id;
+				    Rk->count = rs_found->count;
+				    memcpy(Rk->mean, rs_found->mean,
+				           globals->datasize);
+				    Rk_rs->id = Rk->id;
+				    Rk_rs->count = Rk->count;
+				    memcpy(Rk_rs->mean, rs_found->mean,
+				    memcpy(Rk_rs->sum, rs_found->sum,
+				else if (cmp == 0) {
+				    /* resolve ties: prefer smaller regions */
+				    if (Rk->count > globals->ns.count) {
+				n_ngbrs++;
+				nbtree_insert(Ri_ngbrs, &globals->ns);
+	} while (n--);    /* end do loop - next neighbor */
+    } while (rclist_drop(&rilist, &next));   /* while there are cells to check */
+    /* clean up */
+    rbtree_destroy(no_check_tree);
+    return n_ngbrs;
+void find_four_neighbors(int p_row, int p_col,
+			        int neighbors[8][2])
+    /* north */
+    neighbors[0][0] = p_row - 1;
+    neighbors[0][1] = p_col;
+    /* east */
+    neighbors[1][0] = p_row;
+    neighbors[1][1] = p_col + 1;
+    /* south */
+    neighbors[2][0] = p_row + 1;
+    neighbors[2][1] = p_col;
+    /* west */
+    neighbors[3][0] = p_row;
+    neighbors[3][1] = p_col - 1;
+    return;
+void find_eight_neighbors(int p_row, int p_col,
+    /* get the 4 orthogonal neighbors */
+    find_four_neighbors(p_row, p_col, neighbors);
+    /* get the 4 diagonal neighbors */
+    /* north-west */
+    neighbors[4][0] = p_row - 1;
+    neighbors[4][1] = p_col - 1;
+    /* north-east */
+    neighbors[5][0] = p_row - 1;
+    neighbors[5][1] = p_col + 1;
+    /* south-west */
+    neighbors[6][0] = p_row + 1;
+    neighbors[6][1] = p_col - 1;
+    /* south-east */
+    neighbors[7][0] = p_row + 1;
+    neighbors[7][1] = p_col + 1;
+    return;
+/* similarity / distance between two points based on their input raster values */
+/* assumes first point values already saved in files->bands_seg - only run Segment_get once for that value... */
+/* TODO: Segment_get already happened for a[] values in the main function.  Could remove a[] from these parameters */
+double calculate_euclidean_similarity(struct ngbr_stats *Ri,
+    double val = 0., diff;
+    int n = globals->nbands - 1;
+    /* squared euclidean distance, sum the square differences for each dimension */
+    do {
+	diff = Ri->mean[n] - Rk->mean[n];
+	val += diff * diff;
+    } while (n--);
+    /* the return value should always be in the range 0 - 1 */
+    if (val <= 0)
+	return 0.;
+    val /= globals->max_diff;
+#ifdef _OR_SHAPE_
+    if (globals->shape_weight < 1)
+	val = val * globals->shape_weight + (1 - globals->shape_weight) *
+	      calculate_shape(rsi, rsk, nshared, globals);
+#endif
+    return val;
+double calculate_manhattan_similarity(struct ngbr_stats *Ri,
+    double val = 0.;
+    /* squared manhattan distance, sum the differences for each dimension */
+    do {
+	val += Ri->mean[n] - Rk->mean[n];
+    } while (n--);
+    if (val <= 0)
+	return 0.;
+#ifdef _OR_SHAPE_
+#endif
+    return val;
+double calculate_shape(struct reg_stats *rsi, struct reg_stats *rsk,
+                       int nshared, struct globals *globals)
+     In the eCognition literature, we find that the key factor in the
+     multi-scale segmentation algorithm used by Definiens is the scale
+     factor f:
+     f = W.Hcolor + (1 - W).Hshape
+     Hcolor = sum(b = 1:nbands)(Wb.SigmaB)
+     Hshape = Ws.Hcompact + (1 - Ws).Hsmooth
+     Hcompact = PL/sqrt(Npx)
+     Hsmooth = PL/Pbbox
+     Where
+     W is a user-defined weight of importance of object radiometry vs
+     shape (usually .9 vs .1)
+     Wb is the weigh given to band B
+     SigmaB is the std dev of the object for band b
+     Ws is a user-defined weight giving the importance of compactedness vs smoothness
+     PL is the perimeter length of the object
+     Npx the number of pixels within the object
+     Pbbox the perimeter of the bounding box of the object.
+     /* here we calculate a shape index for the new object to be created
+      * the radiometric index ranges from 0 to 1, 0 = identical
+      * with the shape index we want to favour compact and smooth opjects
+      * thus the shape index should range from 0 to 1,
+      * 0 = maximum compactness and smoothness */
+    double smooth, compact;
+    int pl, pbbox, count;
+    double bboxdiag;
+    int pl1, pl2, count1, count2;
+    int e1, n1, s1, w1, e2, n2, s2, w2, ns_extent, ew_extent;
+    pl = pl1 + pl2 - nshared;
+    ns_extent = MAX(n1, n2) - MIN(s1, s2);
+    ew_extent = MAX(e1, e2) - MIN(w1, w2);
+    pbbox = 2 * (ns_extent + ew_extent);
+    /* Smoothness Hsmooth = PL / Pbbox
+     * the smallest possible value would be
+     * the diagonal divided by the bbox perimeter
+     * invert such that the largest possible value would be
+     * the bbox perimeter divided by the diagonal
+    bboxdiag = sqrt(ns_extent * ns_extent + ew_extent * ew_extent);
+    smooth = 1. - (double)bboxdiag / pl; /* smaller -> smoother */
+    count = count1 + count2;
+    /* compactness Hcompact = PL / sqrt(Npx)
+     * a circle is the most compact form
+     * Npx = M_PI * r * r;
+     * r = sqrt(Npx / M_pi)
+     * pl_circle = 2 * sqrt(count * M_PI);
+     * compact = 1 - pl_circle / (pl * sqrt(count);
+    /* compact = 1 - 2 * sqrt(M_PI) / pl; */
+    /* PL max = Npx */
+    /* Hcompact max = Npx / sqrt(Npx) = sqrt(Npx)
+     * Hcompact / Hcompact max = (PL / sqrt(Npx)) / sqrt(Npx)
+     *                         = PL / Npx
+    compact = (double)pl / count; /* smaller -> more compact */
+    return globals->smooth_weight * smooth + (1 - globals->smooth_weight) * compact;
+static int search_neighbors(struct ngbr_stats *Ri,
+			    double *sim,
+    double tempsim, *dp;
+    struct ngbr_stats *next;
+    int cmp;
+    G_debug(4, "search_neighbors");
+    if (Ri->id <= 0)
+    nbtree_init_trav(&travngbr, Ri_ngbrs);
+	tempsim = (globals->calculate_similarity)(Ri, next, globals);
+	if (cmp == -1) {
+	    *sim = tempsim;
+	    dp = Rk->mean;
+	    *Rk = *next;
+	    Rk->mean = dp;
+	    memcpy(Rk->mean, next->mean, globals->datasize);
+	    /* resolve ties, prefer smaller regions */
+	    G_debug(4, "resolve ties");
+	    if (Rk->count > next->count) {
+		dp = Rk->mean;
+		*Rk = *next;
+		Rk->mean = dp;
+    if (Rk->id != 0) {
+	fetch_reg_stats(Rk->row, Rk->col, Rk_rs, globals);
+    return 1;
+int update_band_vals(int row, int col, struct reg_stats *rs,
+                     struct globals *globals) {
+    struct rc next, ngbr_rc;
+    int rid, count, n;
+    /* update band values with sum */
+    /* rs->id must be set */
+    G_debug(4, "update_band_vals()");
+    if (rs->count >= globals->min_reg_size) {
+	G_fatal_error(_("Region stats should go in tree, %d >= %d"),
+	              rs->count, globals->min_reg_size);
+    Segment_get(&globals->rid_seg, (void *) &rid, row, col);
+    if (rid != rs->id) {
+	G_fatal_error(_("Region ids are different"));
+    if (rs->count == 1) {
+	G_warning(_("Region consists of only one cell, nothing to update"));
+	return rs->count;
+    /* update region stats */
+    Segment_put(&globals->bands_seg, (void *)rs->sum, row, col);
+    count = 1;
+    /* fast version for rs->count == 2 */
+    if (rs->count == 2) {
+	globals->find_neighbors(row, col, neighbors);
+	do {
+	    ngbr_rc.row = neighbors[n][0];
+	    ngbr_rc.col = neighbors[n][1];
+	    if (ngbr_rc.row < globals->row_min || ngbr_rc.row >= globals->row_max ||
+		ngbr_rc.col < globals->col_min || ngbr_rc.col >= globals->col_max) {
+		continue;
+	    if ((FLAG_GET(globals->null_flag, ngbr_rc.row, ngbr_rc.col)) == 0) {
+		if (rid == rs->id) {
+				(void *)rs->sum,
+		    count++;
+		    /* only one other neighbor can have the same ID
+		     * deactivate for debugging */
+		    break;
+	} while (n--);
+	if (count > 2)
+	    G_fatal_error(_("Region size is larger than 2: %d"), count);
+    else if (rs->count > 2) {
+	struct RB_TREE *rc_check_tree;	/* cells already checked */
+	struct rclist rlist;
+	int no_check;
+	/* go through region, spreading outwards from head */
+	rclist_init(&rlist);
+	rc_check_tree = rbtree_create(compare_rc, sizeof(struct rc));
+	ngbr_rc.row = row;
+	ngbr_rc.col = col;
+	rbtree_insert(rc_check_tree, &ngbr_rc);
+	next.row = row;
+	next.col = col;
+	do {
+	    do {
+		no_check = (ngbr_rc.row < 0 || ngbr_rc.row >= globals->nrows ||
+		    ngbr_rc.col < 0 || ngbr_rc.col >= globals->ncols);
+		if (!no_check) {
+			/* already checked ? */
+			if (!rbtree_find(rc_check_tree, &ngbr_rc)) {
+				rclist_add(&rlist, ngbr_rc.row, ngbr_rc.col);
+					    (void *)rs->sum,
+				count++;
+	    } while (n--);
+	} while (rclist_drop(&rlist, &next));
+	/* clean up */
+	rbtree_destroy(rc_check_tree);
+	rclist_destroy(&rlist);
+    if (count != rs->count) {
+	G_fatal_error(_("Region size is %d, should be %d"),
+	              count, rs->count);
+    return count;
+static int merge_regions(struct ngbr_stats *Ri, struct reg_stats *Ri_rs,
+		         struct ngbr_stats *Rk, struct reg_stats *Rk_rs,
+		         int do_cand, struct globals *globals)
+    int n;
+    int R_id;
+    struct reg_stats *new_rs;
+    G_debug(4, "merge_regions");
+    /* Ri ID must always be positive */
+    if (Ri_rs->id < 1)
+	G_fatal_error("Ri id is not positive: %d", Ri_rs->id);
+    /* if Rk ID is negative (no seed), Rk count must be 1  */
+    if (Rk_rs->id < 1 && Rk_rs->count > 1)
+	G_fatal_error("Rk id is not positive: %d, but count is > 1: %d",
+	              Rk_rs->id, Rk_rs->count);
+    /* update segment id and clear candidate flag */
+    /* cases
+     * Ri, Rk are not in the tree
+     * Ri, Rk are both in the tree
+     * Ri is in the tree, Rk is not
+     * Rk is in the tree, Ri is not
+    /* Ri_rs, Rk_rs must always be set */
+    /* add Rk */
+    Ri_rs->count += Rk_rs->count;
+    n = globals->nbands - 1;
+    do {
+	Ri_rs->sum[n] += Rk_rs->sum[n];
+	Ri_rs->mean[n] = Ri_rs->sum[n] / Ri_rs->count;
+    } while (n--);
+    if (Ri->count >= Rk->count) {
+	if (Rk->count >= globals->min_reg_size) {
+	    if (rgtree_find(globals->reg_tree, Rk_rs) == NULL)
+		G_fatal_error("merge regions: Rk should be in tree");
+	    /* remove from tree */
+	    rgtree_remove(globals->reg_tree, Rk_rs);
+    else {
+	if (Ri->count >= globals->min_reg_size) {
+	    if (rgtree_find(globals->reg_tree, Ri_rs) == NULL)
+		G_fatal_error("merge regions: Ri should be in tree");
+	    rgtree_remove(globals->reg_tree, Ri_rs);
+	/* magic switch */
+	Ri_rs->id = Rk->id;
+    if ((new_rs = rgtree_find(globals->reg_tree, Ri_rs)) != NULL) {
+	/* update stats for tree item */
+	new_rs->count = Ri_rs->count;
+	memcpy(new_rs->mean, Ri_rs->mean, globals->datasize);
+	memcpy(new_rs->sum, Ri_rs->sum, globals->datasize);
+    else if (Ri_rs->count >= globals->min_reg_size) {
+	/* add to tree */
+	rgtree_insert(globals->reg_tree, Ri_rs);
+    Ri->count = Ri_rs->count;
+    memcpy(Ri->mean, Ri_rs->mean, globals->datasize);
+    if (Ri->id == Ri_rs->id) {
+	/* Ri is already updated, including candidate flags
+	 * need to clear candidate flag for Rk and set new id */
+	/* the actual merge: change region id */
+	Segment_put(&globals->rid_seg, (void *) &Ri->id, Rk->row, Rk->col);
+	if (do_cand) {
+	    do_cand = 0;
+	    if (FLAG_GET(globals->candidate_flag, Rk->row, Rk->col)) {
+		/* clear candidate flag */
+		FLAG_UNSET(globals->candidate_flag, Rk->row, Rk->col);
+		globals->candidate_count--;
+		do_cand = 1;
+	rclist_add(&rlist, Rk->row, Rk->col);
+	while (rclist_drop(&rlist, &next)) {
+	    if (do_cand) {
+	    do {
+		if (ngbr_rc.row >= globals->row_min &&
+		    ngbr_rc.row < globals->row_max &&
+		    ngbr_rc.col >= globals->col_min &&
+		    ngbr_rc.col < globals->col_max) {
+		    if (!(FLAG_GET(globals->null_flag, ngbr_rc.row, ngbr_rc.col))) {
+			Segment_get(&globals->rid_seg, (void *) &R_id,
+			if (R_id == Rk->id) {
+			    Segment_put(&globals->rid_seg, (void *) &Ri->id, ngbr_rc.row, ngbr_rc.col);
+	    } while (n--);
+    else {
+	/* Rk was larger than Ri */
+	if (do_cand && FLAG_GET(globals->candidate_flag, Rk->row, Rk->col)) {
+	    set_candidate_flag(Rk, FALSE, globals);
+	/* update region id for Ri */
+	Segment_put(&globals->rid_seg, (void *) &Rk->id, Ri->row, Ri->col);
+	rclist_add(&rlist, Ri->row, Ri->col);
+	    do {
+			Segment_get(&globals->rid_seg, (void *) &R_id, ngbr_rc.row, ngbr_rc.col);
+			if (R_id == Ri->id) {
+			    Segment_put(&globals->rid_seg, (void *) &Rk->id, ngbr_rc.row, ngbr_rc.col);
+	    } while (n--);
+	Ri->id = Ri_rs->id;   /* == Rk->id */
+	if (Ri->id != Rk->id)
+	    G_fatal_error("Ri ID should be set to Rk ID");
+    if (Rk->id > 0)
+	globals->n_regions--;
+    /* disable Rk */
+    Rk->count = Rk_rs->count = 0;
+    /* update Ri */
+    if (Ri_rs->count < globals->min_reg_size) {
+	update_band_vals(Ri->row, Ri->col, Ri_rs, globals);
+    return TRUE;
+static int set_candidate_flag(struct ngbr_stats *head, int value, struct globals *globals)
+    int n, R_id;
+    G_debug(4, "set_candidate_flag");
+    if (!(FLAG_GET(globals->candidate_flag, head->row, head->col)) != value) {
+	G_warning(_("Candidate flag is already %s"), value ? _("set") : _("unset"));
+	return FALSE;
+    rclist_add(&rlist, head->row, head->col);
+    /* (un)set candidate flag */
+    if (value == TRUE) {
+	FLAG_SET(globals->candidate_flag, head->row, head->col);
+    else {
+	FLAG_UNSET(globals->candidate_flag, head->row, head->col);
+	do {
+		    if (!(FLAG_GET(globals->candidate_flag, ngbr_rc.row, ngbr_rc.col)) == value) {
+			if (R_id == head->id) {
+				FLAG_SET(globals->candidate_flag, ngbr_rc.row, ngbr_rc.col);
+			    else {
+				FLAG_UNSET(globals->candidate_flag, ngbr_rc.row, ngbr_rc.col);
+	} while (n--);
+    return TRUE;
+int fetch_reg_stats(int row, int col, struct reg_stats *rs,
+    if (rs->id <= 0)
+	G_fatal_error("fetch_reg_stats(): invalid region id %d", rs->id);
+    if ((rs_found = rgtree_find(globals->reg_tree, rs)) != NULL) {
+	memcpy(rs->mean, rs_found->mean, globals->datasize);
+	memcpy(rs->sum, rs_found->sum, globals->datasize);
+	rs->count = rs_found->count;
+	return 1;
+    calculate_reg_stats(row, col, rs, globals);
+    return 2;
+static int calculate_reg_stats(int row, int col, struct reg_stats *rs,
+    int ret = 0;
+    G_debug(4, "calculate_reg_stats()");
+    if (rs->id <= 0)
+	G_fatal_error("Invalid region id %d", rs->id);
+    Segment_get(&globals->bands_seg, (void *)globals->bands_val,
+		row, col);
+    rs->count = 1;
+    memcpy(rs->sum, globals->bands_val, globals->datasize);
+    if (globals->min_reg_size < 3)
+	ret = 1;
+    else if (globals->min_reg_size == 3) {
+	int n, rid;
+	struct rc ngbr_rc;
+	do {
+		continue;
+		    rs->count++;
+		    break;
+	} while (n--);
+	if (rs->count > 2)
+	    G_fatal_error(_("Region size is larger than 2: %d"), rs->count);
+	ret = 2;
+    else if (globals->min_reg_size > 3) {
+	int n, rid;
+	int no_check;
+	next.row = row;
+	next.col = col;
+	do {
+	    do {
+		if (!no_check) {
+				rs->count++;
+	    } while (n--);
+	/* clean up */
+	rclist_destroy(&rilist);
+	ret = 3;
+    /* band mean */
+	memcpy(rs->mean, rs->sum, globals->datasize);
+    else {
+	int i = globals->nbands - 1;
+	do {
+	    rs->mean[i] = rs->sum[i] / rs->count;
+	} while (i--);
+	G_fatal_error(_("Region of size %d should be in search tree"),
+		      rs->count);
+    return ret;
Property changes on: grass/trunk/imagery/i.segment/region_growing.c
   + text/x-csrc
   + native
Added: grass/trunk/imagery/i.segment/watershed.c
--- grass/trunk/imagery/i.segment/watershed.c	                        (rev 0)
+++ grass/trunk/imagery/i.segment/watershed.c	2016-05-19 20:26:04 UTC (rev 68468)
@@ -0,0 +1,23 @@
+#include <float.h>
+#include <math.h>
+#include <time.h>
+#include "iseg.h"
+int watershed(struct globals *globals)
+    G_fatal_error(_("Watershed is not yet implemented"));
+    return FALSE;
Property changes on: grass/trunk/imagery/i.segment/watershed.c
   + text/x-csrc
   + native
