[GRASS-SVN] r68492 - grass/trunk/raster/r.in.gdal
Mon May 23 12:10:50 PDT 2016
Author: neteler
Date: 2016-05-23 12:10:50 -0700 (Mon, 23 May 2016)
New Revision: 68492
   grass/trunk/raster/r.in.gdal/main.c
r.in.gdal: re-phrase num_digits description further
Modified: grass/trunk/raster/r.in.gdal/main.c
--- grass/trunk/raster/r.in.gdal/main.c	2016-05-23 17:50:49 UTC (rev 68491)
+++ grass/trunk/raster/r.in.gdal/main.c	2016-05-23 19:10:50 UTC (rev 68492)
@@ -147,7 +147,7 @@
     parm.num_digits->type = TYPE_INTEGER;
     parm.num_digits->required = NO;
     parm.num_digits->answer = "0";
-    parm.num_digits->label = _("Zero-padding of band number by adding given number of leading zeros");
+    parm.num_digits->label = _("Zero-padding of band number by filling with leading zeros up to given number");
     parm.num_digits->description = _("If 0, length will be adjusted to 'offset' number without leading zeros");
     parm.num_digits->guisection = _("Metadata");
