[GRASS-SVN] r68494 - in grass-addons/grass7/raster: . r.out.ntv2
Tue May 24 07:49:10 PDT 2016
Author: msieczka
Date: 2016-05-24 07:49:10 -0700 (Tue, 24 May 2016)
New Revision: 68494
Added:
   grass-addons/grass7/raster/r.out.ntv2/
   grass-addons/grass7/raster/r.out.ntv2/Makefile
   grass-addons/grass7/raster/r.out.ntv2/r.out.ntv2.html
   grass-addons/grass7/raster/r.out.ntv2/r.out.ntv2.py
   grass-addons/grass7/raster/Makefile
Publish r.out.ntv2 GRASS 7 Python addon.
Modified: grass-addons/grass7/raster/Makefile
--- grass-addons/grass7/raster/Makefile	2016-05-24 13:03:13 UTC (rev 68493)
+++ grass-addons/grass7/raster/Makefile	2016-05-24 14:49:10 UTC (rev 68494)
@@ -69,6 +69,7 @@
 	r.northerness.easterness \
 	r.out.arc \
 	r.out.legend \
+	r.out.ntv2 \
 	r.out.tiff \
 	r.popgrowth \
 	r.random.weight \
Added: grass-addons/grass7/raster/r.out.ntv2/Makefile
--- grass-addons/grass7/raster/r.out.ntv2/Makefile	                        (rev 0)
+++ grass-addons/grass7/raster/r.out.ntv2/Makefile	2016-05-24 14:49:10 UTC (rev 68494)
@@ -0,0 +1,7 @@
+MODULE_TOPDIR = ../..
+PGM=r.out.ntv2
+include $(MODULE_TOPDIR)/include/Make/Script.make
+default: script
Added: grass-addons/grass7/raster/r.out.ntv2/r.out.ntv2.html
--- grass-addons/grass7/raster/r.out.ntv2/r.out.ntv2.html	                        (rev 0)
+++ grass-addons/grass7/raster/r.out.ntv2/r.out.ntv2.html	2016-05-24 14:49:10 UTC (rev 68494)
@@ -0,0 +1,16 @@
+<h2>DESCRIPTION</h2>
+<em>r.out.ntv2</em> converts a pair of GRASS raster maps containing longitude and lattitude coordinate offsets into an <a href="http://trac.osgeo.org/proj/wiki/GenParms#nadgrids-GridBasedDatumAdjustments">g NTv2 datum shift</a> file.
+<p>NTv2 format supports only single-precission floating point data. GRASS double-precision DCELL data need to be reduced to FCELL before export, eg. using <a href="r.mapcalc.html">r.mapcalc</a> <code>float()</code> function.
+<p>The user should adjust the region and resolution to match the input raster maps before export, using <a href="g.region.html">g.region</a>.
+<p>PROJ.4 and the software the depend on it, including GDAL, GRASS, QGIS, assume any NTv2 grid's destination coordinate system is WGS84. The values in the grid's header set with <code>majort</code>, <code>minort</code>, <code>systemt</code> parameters are ignored, same as the input coordinate system parameters (<code>majorf</code>, <code>minorf</code>, <code>systemf</code>). They are for documentation purposes only.
+<h2>SEE ALSO</h2>
+<a href="https://github.com/Esri/ntv2-file-routines">NTv2 format description by ESRI</a>
+<h2>AUTHOR</h2>
+Maciej Sieczka
Added: grass-addons/grass7/raster/r.out.ntv2/r.out.ntv2.py
--- grass-addons/grass7/raster/r.out.ntv2/r.out.ntv2.py	                        (rev 0)
+++ grass-addons/grass7/raster/r.out.ntv2/r.out.ntv2.py	2016-05-24 14:49:10 UTC (rev 68494)
@@ -0,0 +1,142 @@
+#!/usr/bin/env python2
+# MODULE:      r.out.ntv2
+# AUTHOR(S):   Maciej Sieczka
+# PURPOSE:     Export NTv2 datum transformation grid.
+# COPYRIGHT:   (C) 2016 by the GRASS Development Team
+#              This program is free software under the GNU General Public
+#              License (>=v2). Read the file COPYING that comes with GRASS
+#              for details.
+#%Module
+#% description: Exports NTv2 datum transformation grid
+#%End
+#%option
+#% key: latshift
+#% type: string
+#% gisprompt: old,cell,raster
+#% description: Input raster map of lattitude datum shift values
+#% required : yes
+#%end
+#%option
+#% key: lonshift
+#% type: string
+#% description: Input raster map of longitude datum shift values
+#% required : yes
+#%end
+#%option
+#% key: output
+#% type: string
+#% description: Output NTv2 datum transformation grid file
+#% gisprompt: new_file,file,output
+#% required: yes
+#%end
+#%option
+#% key: systemt
+#% type: string
+#% description: Transformation grid's destination coordinate system name
+#% required : no
+#% answer: WGS84
+#%end
+#%option
+#% key: majort
+#% type: string
+#% description: Major ellipsoid axis of the transformation grid's destination coordinate system
+#% required : no
+#% answer: 6378137
+#%end
+#%option
+#% key: minort
+#% type: string
+#% description: Minor ellipsoid axis of the transformation grid's destination coordinate system
+#% required : no
+#% answer: 6356752.314245
+#%end
+#%option
+#% key: systemf
+#% type: string
+#% description: Transformation grid's input coordinate system name
+#% required : no
+#% answer: UNKNOWN
+#%end
+#%option
+#% key: majorf
+#% type: string
+#% description: Major ellipsoid axis of the transformation grid's input coordinate system
+#% required : no
+#% answer: UNKNOWN
+#%end
+#%option
+#% key: minorf
+#% type: string
+#% description: Minor ellipsoid axis of the transformation grid's input coordinate system
+#% required : no
+#% answer: UNKNOWN
+#%end
+SYSTEM_F, SYSTEM_T, MAJOR_F, MINOR_F, MAJOR_T, MINOR_T are not used for
+anything in GDAL or PROJ.4. They will always assume the *_T system is WGS84 and
+the *_F system's parameters are simply ignored. It makes sense setting these
+for documentation's sake only.
+More about NTv2 format on https://github.com/Esri/ntv2-file-routines.
+import atexit, sys, uuid, time
+from grass.script import core as grass
+tmp_group = str(uuid.uuid4())
+def cleanup():
+  grass.run_command("g.remove",
+                    type = "group",
+                    name = tmp_group,
+                    flags = "f",
+                    quiet = True)
+def main():
+  grass.run_command("i.group",
+                    input = (options["latshift"], options["lonshift"]),
+                    group = tmp_group,
+                    quiet = True)
+  grass.run_command("r.out.gdal",
+                    input = tmp_group,
+                    output = options["output"],
+                    format = "NTv2",
+                    type = "Float32",
+                    quiet = True,
+                    metaopt = ("CREATED="+time.strftime("%Y%m%d"),
+                              "GS_TYPE=SECONDS",
+                              "SYSTEM_T="+options["systemt"],
+                              "MAJOR_T="+options["majort"],
+                              "MINOR_T="+options["minort"],
+                              "SYSTEM_F="+options["systemf"],
+                              "MAJOR_F="+options["majorf"],
+                              "MINOR_F="+options["minorf"],
+                              "PARENT=NONE",
+                              "SUB_NAME=NONE",
+                              "UPDATED="+time.strftime("%H%M%S"),
+                              "VERSION=NTv2.0"))
+if __name__ == "__main__":
+  options, flags = grass.parser()
+  atexit.register(cleanup)
+  sys.exit(main())
Property changes on: grass-addons/grass7/raster/r.out.ntv2/r.out.ntv2.py
___________________________________________________________________
Added: svn:executable
