[GRASS-SVN] r68509 - grass-addons/grass7/raster/r.out.ntv2
Wed May 25 02:29:11 PDT 2016
Author: msieczka
Date: 2016-05-25 02:29:11 -0700 (Wed, 25 May 2016)
New Revision: 68509
   grass-addons/grass7/raster/r.out.ntv2/r.out.ntv2.html
r.out.ntv2 doc last touches
Modified: grass-addons/grass7/raster/r.out.ntv2/r.out.ntv2.html
--- grass-addons/grass7/raster/r.out.ntv2/r.out.ntv2.html	2016-05-25 09:18:46 UTC (rev 68508)
+++ grass-addons/grass7/raster/r.out.ntv2/r.out.ntv2.html	2016-05-25 09:29:11 UTC (rev 68509)
@@ -1,6 +1,6 @@
 <h2>DESCRIPTION</h2>
-<em>r.out.ntv2</em> converts a pair of GRASS raster maps containing longitude and lattitude coordinate offsets into an <a href="http://trac.osgeo.org/proj/wiki/GenParms#nadgrids-GridBasedDatumAdjustments">NTv2 grid datum shift</a> file (if this document dissapeared it might have been moved to the <a href="https://github.com/OSGeo/proj.4/wiki">new PROJ.4 wiki</a>.
+<em>r.out.ntv2</em> converts a pair of GRASS raster maps containing longitude and lattitude coordinate offsets into an <a href="http://trac.osgeo.org/proj/wiki/GenParms#nadgrids-GridBasedDatumAdjustments">NTv2 grid datum shift</a> file (if this document dissapeared it might have been moved to the <a href="https://github.com/OSGeo/proj.4/wiki">new PROJ.4 wiki</a>).
 <h2>NOTES</h2>
@@ -8,7 +8,7 @@
 <p>The user should adjust the region and resolution to match the input raster maps before export, using <a href="g.region.html">g.region</a>.
-<p>PROJ.4 and the software the depend on it, including GDAL, GRASS, QGIS, assume any NTv2 grid's destination coordinate system is WGS84. The metadata values in the grid's header set with <code>majort</code>, <code>minort</code>, <code>systemt</code> parameters are ignored, same as the input coordinate system parameters (<code>majorf</code>, <code>minorf</code>, <code>systemf</code>). They are for documentation purposes only.
+<p>PROJ.4 and the software that depend on it, including GDAL, GRASS, QGIS, assume the NTv2 grid's destination coordinate system to be WGS84. The metadata values in the grid's header set with <code>majort</code>, <code>minort</code>, <code>systemt</code> parameters are ignored, same as the input coordinate system parameters (<code>majorf</code>, <code>minorf</code>, <code>systemf</code>). They are for documentation purposes only.
 <p>The <code>CREATED</code> and <code>UPDATED</code> output grid's metadata fields are set to, respectively, current date and time, in YYYYMMDD and HHMMSS format.
