[GRASS-SVN] r69790 - in grass/trunk/gui/wxpython: animation core dbmgr gcp gmodeler gui_core iscatt location_wizard mapswipe modules nviz psmap vdigit vnet web_services wxplot
Tue Nov 8 10:37:25 PST 2016
Author: annakrat
Date: 2016-11-08 10:37:25 -0800 (Tue, 08 Nov 2016)
New Revision: 69790
Added:
   grass/trunk/gui/wxpython/gui_core/wrap.py
   grass/trunk/gui/wxpython/animation/dialogs.py
   grass/trunk/gui/wxpython/core/globalvar.py
   grass/trunk/gui/wxpython/dbmgr/base.py
   grass/trunk/gui/wxpython/dbmgr/dialogs.py
   grass/trunk/gui/wxpython/gcp/manager.py
   grass/trunk/gui/wxpython/gcp/statusbar.py
   grass/trunk/gui/wxpython/gmodeler/preferences.py
   grass/trunk/gui/wxpython/gui_core/dialogs.py
   grass/trunk/gui/wxpython/gui_core/forms.py
   grass/trunk/gui/wxpython/gui_core/preferences.py
   grass/trunk/gui/wxpython/iscatt/dialogs.py
   grass/trunk/gui/wxpython/location_wizard/wizard.py
   grass/trunk/gui/wxpython/mapswipe/dialogs.py
   grass/trunk/gui/wxpython/modules/colorrules.py
   grass/trunk/gui/wxpython/modules/vkrige.py
   grass/trunk/gui/wxpython/nviz/preferences.py
   grass/trunk/gui/wxpython/nviz/tools.py
   grass/trunk/gui/wxpython/psmap/dialogs.py
   grass/trunk/gui/wxpython/vdigit/dialogs.py
   grass/trunk/gui/wxpython/vdigit/preferences.py
   grass/trunk/gui/wxpython/vnet/dialogs.py
   grass/trunk/gui/wxpython/web_services/widgets.py
   grass/trunk/gui/wxpython/wxplot/dialogs.py
wxGUI: change size of wx.SpinCtrl for gtk3, see #3201
Modified: grass/trunk/gui/wxpython/animation/dialogs.py
--- grass/trunk/gui/wxpython/animation/dialogs.py	2016-11-08 16:41:07 UTC (rev 69789)
+++ grass/trunk/gui/wxpython/animation/dialogs.py	2016-11-08 18:37:25 UTC (rev 69790)
@@ -36,6 +36,7 @@
 from core.utils import _
 from gui_core.gselect import Select
 from gui_core.widgets import FloatValidator
+from gui_core.wrap import GSpinCtrl as SpinCtrl
 from animation.utils import TemporalMode, getRegisteredMaps, getNameAndLayer, getCpuCount
 from animation.data import AnimationData, AnimLayer
@@ -103,7 +104,7 @@
         labelDuration = wx.StaticText(
             self, id=wx.ID_ANY, label=_("Frame duration:"))
         labelUnits = wx.StaticText(self, id=wx.ID_ANY, label=_("ms"))
-        self.spinDuration = wx.SpinCtrl(
+        self.spinDuration = SpinCtrl(
             self,
             id=wx.ID_ANY,
             min=self.minimumDuration,
@@ -144,7 +145,7 @@
             self, id=wx.ID_ANY, label=_("Duration of time unit:"))
-        self.spinDurationTemp = wx.SpinCtrl(
+        self.spinDurationTemp = SpinCtrl(
             self, id=wx.ID_ANY, min=self.minimumDuration, max=10000,
             initial=self.defaultSpeed)
         self.choiceUnits = wx.Choice(self, id=wx.ID_ANY)
@@ -1115,9 +1116,9 @@
                 "Placement as percentage of"
                 " screen coordinates (X: 0, Y: 0 is top left):"))
         label.Wrap(400)
-        self.spinX = wx.SpinCtrl(
+        self.spinX = SpinCtrl(
             panel, id=wx.ID_ANY, min=0, max=100, initial=10)
-        self.spinY = wx.SpinCtrl(
+        self.spinY = SpinCtrl(
         self.spinX.Bind(
             wx.EVT_SPINCTRL,
@@ -1895,7 +1896,7 @@
                 key='nprocs',
                 subkey='value',
                 value=getCpuCount())
-        nprocs = wx.SpinCtrl(
+        nprocs = SpinCtrl(
             parent=panel,
             initial=UserSettings.Get(
                 group='animation',
Modified: grass/trunk/gui/wxpython/core/globalvar.py
--- grass/trunk/gui/wxpython/core/globalvar.py	2016-11-08 16:41:07 UTC (rev 69789)
+++ grass/trunk/gui/wxpython/core/globalvar.py	2016-11-08 18:37:25 UTC (rev 69790)
@@ -217,6 +217,8 @@
 hasAgw = CheckWxVersion([2, 8, 11, 0])
 wxPython3 = CheckWxVersion([3, 0, 0, 0])
+gtk3 = True if 'gtk3' in wx.PlatformInfo else False
 """@Add GUIDIR/scripts into path"""
 os.environ['PATH'] = os.path.join(
     GUIDIR, 'scripts') + os.pathsep + os.environ['PATH']
Modified: grass/trunk/gui/wxpython/dbmgr/base.py
--- grass/trunk/gui/wxpython/dbmgr/base.py	2016-11-08 16:41:07 UTC (rev 69789)
+++ grass/trunk/gui/wxpython/dbmgr/base.py	2016-11-08 18:37:25 UTC (rev 69790)
@@ -53,6 +53,7 @@
 from core.debug import Debug
 from dbmgr.dialogs import ModifyTableRecord, AddColumnDialog
 from core.settings import UserSettings
 class Log:
@@ -2326,7 +2327,7 @@
                      flag=wx.ALIGN_CENTER_VERTICAL | wx.LEFT | wx.RIGHT,
                      border=5)
-        length = wx.SpinCtrl(parent=panel, id=wx.ID_ANY, size=(65, -1),
+        length = SpinCtrl(parent=panel, id=wx.ID_ANY, size=(65, -1),
                              initial=250,
                              min=1, max=1e6)
         length.Enable(False)
@@ -3055,7 +3056,7 @@
         self.addLayerWidgets = {'layer':
                                 (wx.StaticText(parent=self.addPanel, id=wx.ID_ANY,
                                                label='%s:' % _("Layer")),
-                                 wx.SpinCtrl(parent=self.addPanel, id=wx.ID_ANY, size=(65, -1),
+                                 SpinCtrl(parent=self.addPanel, id=wx.ID_ANY, size=(65, -1),
                                              initial=maxLayer + 1,
                                              min=1, max=1e6)),
                                 'driver':
Modified: grass/trunk/gui/wxpython/dbmgr/dialogs.py
--- grass/trunk/gui/wxpython/dbmgr/dialogs.py	2016-11-08 16:41:07 UTC (rev 69789)
+++ grass/trunk/gui/wxpython/dbmgr/dialogs.py	2016-11-08 18:37:25 UTC (rev 69790)
@@ -30,6 +30,7 @@
 from dbmgr.vinfo import VectorDBInfo, GetUnicodeValue
 from gui_core.widgets import IntegerValidator, FloatValidator
 class DisplayAttributesDialog(wx.Dialog):
@@ -642,7 +643,7 @@
                     cId += 1
                     continue
                 else:
-                    valueWin = wx.SpinCtrl(
+                    valueWin = SpinCtrl(
                         parent=self.dataPanel, id=wx.ID_ANY, value=value,
                         min=-1e9, max=1e9, size=(250, -1))
             else:
@@ -763,7 +764,7 @@
         self.data['addColType'].SetSelection(0)
         self.data['addColType'].Bind(wx.EVT_CHOICE, self.OnTableChangeType)
-        self.data['addColLength'] = wx.SpinCtrl(
+        self.data['addColLength'] = SpinCtrl(
             parent=self, id=wx.ID_ANY, size=(
                 65, -1), initial=250, min=1, max=1e6)
         self.data['addColLength'].Enable(False)
Modified: grass/trunk/gui/wxpython/gcp/manager.py
--- grass/trunk/gui/wxpython/gcp/manager.py	2016-11-08 16:41:07 UTC (rev 69789)
+++ grass/trunk/gui/wxpython/gcp/manager.py	2016-11-08 18:37:25 UTC (rev 69790)
@@ -49,6 +49,7 @@
 from gcp.mapdisplay import MapFrame
 from core.giface import Notification
 from location_wizard.wizard import TitledPage as TitledPage
@@ -2793,7 +2794,7 @@
                 group='gcpman',
                 key='symbol',
                 subkey='size'))
-        sizeWin = wx.SpinCtrl(parent=panel, id=wx.ID_ANY,
+        sizeWin = SpinCtrl(parent=panel, id=wx.ID_ANY,
                               min=1, max=20)
         sizeWin.SetValue(symsize)
         self.symbol['size'] = sizeWin.GetId()
@@ -2815,7 +2816,7 @@
                 group='gcpman',
                 key='symbol',
                 subkey='width'))
-        widWin = wx.SpinCtrl(parent=panel, id=wx.ID_ANY,
+        widWin = SpinCtrl(parent=panel, id=wx.ID_ANY,
                              min=1, max=10)
         widWin.SetValue(width)
         self.symbol['width'] = widWin.GetId()
Modified: grass/trunk/gui/wxpython/gcp/statusbar.py
--- grass/trunk/gui/wxpython/gcp/statusbar.py	2016-11-08 16:41:07 UTC (rev 69789)
+++ grass/trunk/gui/wxpython/gcp/statusbar.py	2016-11-08 18:37:25 UTC (rev 69790)
@@ -22,6 +22,7 @@
 from core.gcmd import GMessage
 from mapdisp.statusbar import SbItem, SbTextItem
 class SbGoToGCP(SbItem):
@@ -36,7 +37,7 @@
         self.name = 'gotoGCP'
         self.label = _("Go to GCP No.")
-        self.widget = wx.SpinCtrl(parent=self.statusbar, id=wx.ID_ANY,
+        self.widget = SpinCtrl(parent=self.statusbar, id=wx.ID_ANY,
                                   value="", min=0)
         self.widget.Hide()
Modified: grass/trunk/gui/wxpython/gmodeler/preferences.py
--- grass/trunk/gui/wxpython/gmodeler/preferences.py	2016-11-08 16:41:07 UTC (rev 69789)
+++ grass/trunk/gui/wxpython/gmodeler/preferences.py	2016-11-08 18:37:25 UTC (rev 69790)
@@ -22,6 +22,7 @@
 from gui_core.preferences import PreferencesBaseDialog
 class PreferencesDialog(PreferencesBaseDialog):
@@ -185,7 +186,7 @@
                       wx.ALIGN_CENTER_VERTICAL,
                       pos=(row, 0))
-        width = wx.SpinCtrl(
+        width = SpinCtrl(
             parent=panel,
             id=wx.ID_ANY,
             min=0,
@@ -211,7 +212,7 @@
                       pos=(row, 0))
-        height = wx.SpinCtrl(
+        height = SpinCtrl(
             parent=panel,
             id=wx.ID_ANY,
             min=0,
@@ -351,7 +352,7 @@
                       pos=(row, 0))
+        width = SpinCtrl(
             parent=panel,
             id=wx.ID_ANY,
             min=0,
@@ -377,7 +378,7 @@
                       pos=(row, 0))
             parent=panel,
             id=wx.ID_ANY,
             min=0,
@@ -463,7 +464,7 @@
                       pos=(row, 0))
+        width = SpinCtrl(
             parent=panel,
             id=wx.ID_ANY,
             min=0,
@@ -489,7 +490,7 @@
                       pos=(row, 0))
             parent=panel,
             id=wx.ID_ANY,
             min=0,
@@ -579,7 +580,7 @@
                       pos=(row, 0))
+        width = SpinCtrl(
             parent=panel,
             id=wx.ID_ANY,
             min=0,
@@ -605,7 +606,7 @@
                       pos=(row, 0))
             parent=panel,
             id=wx.ID_ANY,
             min=0,
Modified: grass/trunk/gui/wxpython/gui_core/dialogs.py
--- grass/trunk/gui/wxpython/gui_core/dialogs.py	2016-11-08 16:41:07 UTC (rev 69789)
+++ grass/trunk/gui/wxpython/gui_core/dialogs.py	2016-11-08 18:37:25 UTC (rev 69790)
@@ -47,6 +47,7 @@
 class SimpleDialog(wx.Dialog):
@@ -1893,12 +1894,12 @@
                                 label=' % s' % _("Image size"))
         size = self.parent.GetWindow().GetClientSize()
-        self.width = wx.SpinCtrl(parent=self.panel, id=wx.ID_ANY,
+        self.width = SpinCtrl(parent=self.panel, id=wx.ID_ANY,
                                  style=wx.SP_ARROW_KEYS)
         self.width.SetRange(20, 1e6)
         self.width.SetValue(size.width)
         wx.CallAfter(self.width.SetFocus)
-        self.height = wx.SpinCtrl(parent=self.panel, id=wx.ID_ANY,
+        self.height = SpinCtrl(parent=self.panel, id=wx.ID_ANY,
         self.height.SetRange(20, 1e6)
         self.height.SetValue(size.height)
@@ -2472,7 +2473,7 @@
                           flag=wx.ALIGN_CENTER_VERTICAL,
                           pos=(2, 0))
-            self.spin = wx.SpinCtrl(parent=panel, id=wx.ID_ANY)
+            self.spin = SpinCtrl(parent=panel, id=wx.ID_ANY)
             if self.fontsize:
                 self.spin.SetValue(int(self.fontsize))
             self.spin.Bind(wx.EVT_SPINCTRL, self.OnSizeSpin)
Modified: grass/trunk/gui/wxpython/gui_core/forms.py
--- grass/trunk/gui/wxpython/gui_core/forms.py	2016-11-08 16:41:07 UTC (rev 69789)
+++ grass/trunk/gui/wxpython/gui_core/forms.py	2016-11-08 18:37:25 UTC (rev 69790)
@@ -98,6 +98,7 @@
 from gui_core.widgets import FloatValidator, GNotebook, FormNotebook, FormListbook
 from gui_core.widgets import LayersList
 wxUpdateDialog, EVT_DIALOG_UPDATE = NewEvent()
@@ -1200,7 +1201,7 @@
                             except ValueError:
                                 minValue = -1e6
                                 maxValue = 1e6
-                            txt2 = wx.SpinCtrl(
+                            txt2 = SpinCtrl(
                                 parent=which_panel,
                                 id=wx.ID_ANY,
                                 size=globalvar.DIALOG_SPIN_SIZE,
@@ -1216,7 +1217,7 @@
                         value = self._getValue(p)
                         # parameter previously set
                         if value:
-                            if isinstance(txt2, wx.SpinCtrl):
+                            if isinstance(txt2, SpinCtrl):
                                 txt2.SetValue(int(value))
                             else:
                                 txt2.SetValue(value)
@@ -1317,7 +1318,7 @@
                     maxValue = 1e9
-                    win = wx.SpinCtrl(
+                    win = SpinCtrl(
                         parent=which_panel,
                         value=p.get(
                             'default',
@@ -1620,7 +1621,7 @@
                                 win.SetValue(
                                     str(value))    # default or previously set value
                             else:
+                                win = SpinCtrl(
                                     parent=which_panel, id=wx.ID_ANY, min=1,
                                     max=100, initial=int(p['default']))
                                 win.Bind(wx.EVT_SPINCTRL, self.OnSetValue)
@@ -2600,7 +2601,7 @@
             if pLayer:
                 pLayer['value'] = ''
         else:
-            if isinstance(me, wx.SpinCtrl):
+            if isinstance(me, SpinCtrl):
                 porf['value'] = str(me.GetValue())
             elif isinstance(me, wx.ComboBox):
                 porf['value'] = me.GetValue()
Modified: grass/trunk/gui/wxpython/gui_core/preferences.py
--- grass/trunk/gui/wxpython/gui_core/preferences.py	2016-11-08 16:41:07 UTC (rev 69789)
+++ grass/trunk/gui/wxpython/gui_core/preferences.py	2016-11-08 18:37:25 UTC (rev 69790)
@@ -50,6 +50,7 @@
 from gui_core.dialogs import SymbolDialog, DefaultFontDialog
 from gui_core.widgets import IntegerValidator, ColorTablesComboBox
 class PreferencesBaseDialog(wx.Dialog):
@@ -647,7 +648,7 @@
             key='gSelectPopupHeight',
             subkey='value')
-        popupHeightSpin = wx.SpinCtrl(
+        popupHeightSpin = SpinCtrl(
             parent=panel, id=wx.ID_ANY, size=(100, -1))
         popupHeightSpin.SetRange(min, max)
         popupHeightSpin.SetValue(value)
@@ -1362,7 +1363,7 @@
         gridSizer.Add(item=wx.StaticText(parent=panel, id=wx.ID_ANY,
                                          label=_("Line width:")),
                       flag=wx.ALIGN_CENTER_VERTICAL, pos=(row, col))
-        hlWidth = wx.SpinCtrl(
+        hlWidth = SpinCtrl(
             parent=panel, id=wx.ID_ANY, size=(50, -1),
             initial=self.settings.Get(
                 group='vectorLayer', key='line', subkey='width'),
@@ -1379,7 +1380,7 @@
                                          label=_("Symbol size:")),
-        ptSize = wx.SpinCtrl(
+        ptSize = SpinCtrl(
                 group='vectorLayer', key='point', subkey='size'),
@@ -1473,7 +1474,7 @@
             parent=panel,
             id=wx.ID_ANY,
             label=_("Line width (in pixels):"))
                 group='atm', key='highlight', subkey='width'),
@@ -1757,7 +1758,7 @@
             ll.SetSelection(1)
         # precision
-        precision = wx.SpinCtrl(parent=panel, id=wx.ID_ANY,
+        precision = SpinCtrl(parent=panel, id=wx.ID_ANY,
                                 min=0, max=12,
                                 name="GetValue")
         precision.SetValue(int(self.settings.Get(
Added: grass/trunk/gui/wxpython/gui_core/wrap.py
--- grass/trunk/gui/wxpython/gui_core/wrap.py	                        (rev 0)
+++ grass/trunk/gui/wxpython/gui_core/wrap.py	2016-11-08 18:37:25 UTC (rev 69790)
@@ -0,0 +1,36 @@
+ at package gui_core.wrap
+ at brief Core wrapped wxpython widgets
+Classes:
+ - wrap::GSpinCtrl
+(C) 2016 by the GRASS Development Team
+This program is free software under the GNU General Public License
+(>=v2). Read the file COPYING that comes with GRASS for details.
+ at author Anna Petrasova <kratochanna gmail.com>
+import wx
+from core.globalvar import gtk3
+class GSpinCtrl(wx.SpinCtrl):
+    """Wrapper around wx.SpinCtrl to have more control
+    over the widget on different platforms"""
+    gtk3MinSize = 130
+    def __init__(self, *args, **kwargs):
+        if gtk3:
+            if 'size' in kwargs:
+                kwargs['size'] = wx.Size(max(self.gtk3MinSize, kwargs['size'][0]), kwargs['size'][1])
+            else:
+                kwargs['size'] = wx.Size(self.gtk3MinSize, -1)
+        wx.SpinCtrl.__init__(self, *args, **kwargs)
\ No newline at end of file
Modified: grass/trunk/gui/wxpython/iscatt/dialogs.py
--- grass/trunk/gui/wxpython/iscatt/dialogs.py	2016-11-08 16:41:07 UTC (rev 69789)
+++ grass/trunk/gui/wxpython/iscatt/dialogs.py	2016-11-08 18:37:25 UTC (rev 69790)
@@ -31,6 +31,7 @@
 from gui_core.dialogs import SimpleDialog
 class AddScattPlotDialog(wx.Dialog):
@@ -375,7 +376,7 @@
         for settKey, sett in self.sizeSetts.iteritems():
             settsLabels[settKey] = wx.StaticText(
                 parent=self, id=wx.ID_ANY, label=sett[1])
-            self.settings[settKey] = wx.SpinCtrl(
+            self.settings[settKey] = SpinCtrl(
                 parent=self, id=wx.ID_ANY, min=0, max=100)
             size = int(
                 UserSettings.Get(
Modified: grass/trunk/gui/wxpython/location_wizard/wizard.py
--- grass/trunk/gui/wxpython/location_wizard/wizard.py	2016-11-08 16:41:07 UTC (rev 69789)
+++ grass/trunk/gui/wxpython/location_wizard/wizard.py	2016-11-08 18:37:25 UTC (rev 69790)
@@ -46,6 +46,7 @@
 from core.gcmd import RunCommand, GError, GMessage, GWarning
 from gui_core.widgets import GenericValidator
 from location_wizard.base import BaseClass
 from location_wizard.dialogs import SelectTransformDialog
@@ -860,7 +861,7 @@
                     win.SetSelection(param['value'])
                     win.Bind(wx.EVT_CHOICE, self.OnParamEntry)
                 elif param['type'] == 'zone':
-                    win = wx.SpinCtrl(parent=self.panel, id=id,
+                    win = SpinCtrl(parent=self.panel, id=id,
                                       size=(100, -1),
                                       style=wx.SP_ARROW_KEYS | wx.SP_WRAP,
                                       min=1, max=60)
Modified: grass/trunk/gui/wxpython/mapswipe/dialogs.py
--- grass/trunk/gui/wxpython/mapswipe/dialogs.py	2016-11-08 16:41:07 UTC (rev 69789)
+++ grass/trunk/gui/wxpython/mapswipe/dialogs.py	2016-11-08 18:37:25 UTC (rev 69790)
@@ -27,6 +27,7 @@
 from core.layerlist import LayerList
 from gui_core.simplelmgr import SimpleLayerManager, SIMPLE_LMGR_RASTER, \
     SIMPLE_LMGR_VECTOR, SIMPLE_LMGR_RGB, SIMPLE_LMGR_TB_LEFT, SIMPLE_LMGR_TB_RIGHT
@@ -328,7 +329,7 @@
             pos=(
                 row,
                 0))
+        width = SpinCtrl(
             parent=panel,
             min=1,
             max=10,
@@ -351,7 +352,7 @@
             pos=(
                 row,
                 0))
-        size = wx.SpinCtrl(
+        size = SpinCtrl(
             parent=panel,
             min=4,
             max=50,
Modified: grass/trunk/gui/wxpython/modules/colorrules.py
--- grass/trunk/gui/wxpython/modules/colorrules.py	2016-11-08 16:41:07 UTC (rev 69789)
+++ grass/trunk/gui/wxpython/modules/colorrules.py	2016-11-08 18:37:25 UTC (rev 69790)
@@ -45,6 +45,7 @@
 from core.debug import Debug as Debug
 from gui_core.widgets import ColorTablesComboBox
 class RulesPanel:
@@ -80,7 +81,7 @@
         # clear button
         self.clearAll = wx.Button(parent, id=wx.ID_ANY, label=_("Clear all"))
         #  determines how many rules should be added
-        self.numRules = wx.SpinCtrl(parent, id=wx.ID_ANY,
+        self.numRules = SpinCtrl(parent, id=wx.ID_ANY,
                                     min=1, max=1e6, initial=1)
         # add rules
         self.btnAdd = wx.Button(parent, id=wx.ID_ADD)
@@ -154,7 +155,7 @@
                 init = 2
                 if self.attributeType == 'size':
                     init = 100
-                columnCtrl = wx.SpinCtrl(self.mainPanel, id=2000 + num,
+                columnCtrl = SpinCtrl(self.mainPanel, id=2000 + num,
                                          size=(50, -1), min=1, max=1e4,
                                          initial=init)
                 columnCtrl.Bind(wx.EVT_SPINCTRL, self.OnRuleSize)
Modified: grass/trunk/gui/wxpython/modules/vkrige.py
--- grass/trunk/gui/wxpython/modules/vkrige.py	2016-11-08 16:41:07 UTC (rev 69789)
+++ grass/trunk/gui/wxpython/modules/vkrige.py	2016-11-08 18:37:25 UTC (rev 69790)
@@ -39,6 +39,7 @@
 from gui_core.widgets import GNotebook
 #import help
 import wx
@@ -502,7 +503,7 @@
                 setattr(
                     self,
                     n + "Ctrl",
-                    (wx.SpinCtrl(
+                    (SpinCtrl(
                         self,
                         id=wx.ID_ANY,
                         min=MinValues[
@@ -550,7 +551,7 @@
         # block kriging parameters. Size.
         BlockSizer = wx.BoxSizer(wx.HORIZONTAL)
         BlockLabel = wx.StaticText(self, id=wx.ID_ANY, label=_("Block size:"))
-        self.BlockSpinBox = wx.SpinCtrl(self, id=wx.ID_ANY, min=1, max=maxint)
+        self.BlockSpinBox = SpinCtrl(self, id=wx.ID_ANY, min=1, max=maxint)
         # default choice is Ordinary kriging so block param is disabled
         self.BlockSpinBox.Enable(False)
         BlockSizer.Add(
Modified: grass/trunk/gui/wxpython/nviz/preferences.py
--- grass/trunk/gui/wxpython/nviz/preferences.py	2016-11-08 16:41:07 UTC (rev 69789)
+++ grass/trunk/gui/wxpython/nviz/preferences.py	2016-11-08 18:37:25 UTC (rev 69790)
@@ -26,6 +26,7 @@
 class NvizPreferencesDialog(PreferencesBaseDialog):
@@ -89,7 +90,7 @@
                 parent=panel, id=wx.ID_ANY, label=_("value:")), pos=(
                 row, 1), flag=wx.ALIGN_CENTER_VERTICAL | wx.ALIGN_RIGHT)
-        pval = wx.SpinCtrl(parent=panel, id=wx.ID_ANY, size=(65, -1),
+        pval = SpinCtrl(parent=panel, id=wx.ID_ANY, size=(65, -1),
                            initial=pvals['value'],
                            min=ipvals['min'],
                            max=ipvals['max'])
@@ -102,7 +103,7 @@
                 parent=panel, id=wx.ID_ANY, label=_("step:")), pos=(
                 row, 3), flag=wx.ALIGN_CENTER_VERTICAL | wx.ALIGN_RIGHT)
-        pstep = wx.SpinCtrl(parent=panel, id=wx.ID_ANY, size=(65, -1),
+        pstep = SpinCtrl(parent=panel, id=wx.ID_ANY, size=(65, -1),
                             initial=pvals['step'],
                             min=ipvals['min'],
                             max=ipvals['max'] - 1)
@@ -121,7 +122,7 @@
                 parent=panel, id=wx.ID_ANY, label=_("x:")), pos=(
-        px = wx.SpinCtrl(parent=panel, id=wx.ID_ANY, size=(65, -1),
+        px = SpinCtrl(parent=panel, id=wx.ID_ANY, size=(65, -1),
                          initial=posvals['x'] * 100,
                          min=0,
                          max=100)
@@ -134,7 +135,7 @@
                 parent=panel, id=wx.ID_ANY, label="y:"), pos=(
-        py = wx.SpinCtrl(parent=panel, id=wx.ID_ANY, size=(65, -1),
+        py = SpinCtrl(parent=panel, id=wx.ID_ANY, size=(65, -1),
                          initial=posvals['y'] * 100,
                          min=0,
                          max=100)
@@ -160,7 +161,7 @@
-        tval = wx.SpinCtrl(parent=panel, id=wx.ID_ANY, size=(65, -1),
+        tval = SpinCtrl(parent=panel, id=wx.ID_ANY, size=(65, -1),
                            initial=tvals['value'],
                            min=itvals['min'],
                            max=itvals['max'])
@@ -179,7 +180,7 @@
-        zval = wx.SpinCtrl(parent=panel, id=wx.ID_ANY, size=(65, -1),
+        zval = SpinCtrl(parent=panel, id=wx.ID_ANY, size=(65, -1),
                            initial=zvals['value'],
                            min=-1e6,
                            max=1e6)
@@ -246,7 +247,7 @@
                                          label=_("Move exag:")),
                       pos=(0, 0), flag=wx.ALIGN_CENTER_VERTICAL)
-        moveExag = wx.SpinCtrl(
+        moveExag = SpinCtrl(
             panel, id=wx.ID_ANY, min=1, max=20, initial=UserSettings.Get(
                 group='nviz', key='fly', subkey=[
                     'exag', 'move']), size=(
@@ -259,7 +260,7 @@
                                          label=_("Turn exag:")),
                       pos=(1, 0), flag=wx.ALIGN_CENTER_VERTICAL)
-        turnExag = wx.SpinCtrl(
+        turnExag = SpinCtrl(
                     'exag', 'turn']), size=(
@@ -303,7 +304,7 @@
                 0, 1), flag=wx.ALIGN_CENTER_VERTICAL | wx.ALIGN_RIGHT)
                          min=-100,
                          max=100)
@@ -316,7 +317,7 @@
                 0, 3), flag=wx.ALIGN_CENTER_VERTICAL | wx.ALIGN_RIGHT)
                          min=-100,
                          max=100)
@@ -329,7 +330,7 @@
                 parent=panel, id=wx.ID_ANY, label=_("z:")), pos=(
                 0, 5), flag=wx.ALIGN_CENTER_VERTICAL | wx.ALIGN_RIGHT)
-        pz = wx.SpinCtrl(parent=panel, id=wx.ID_ANY, size=(65, -1),
+        pz = SpinCtrl(parent=panel, id=wx.ID_ANY, size=(65, -1),
                          initial=posvals['z'],
                          min=0,
                          max=100)
@@ -344,7 +345,7 @@
                                          label=_("Brightness:")),
-        bright = wx.SpinCtrl(parent=panel, id=wx.ID_ANY, size=(65, -1),
+        bright = SpinCtrl(parent=panel, id=wx.ID_ANY, size=(65, -1),
                              initial=brightval,
                              min=0,
                              max=100)
@@ -358,7 +359,7 @@
                                          label=_("Ambient:")),
                       pos=(2, 0), flag=wx.ALIGN_CENTER_VERTICAL)
-        amb = wx.SpinCtrl(parent=panel, id=wx.ID_ANY, size=(65, -1),
+        amb = SpinCtrl(parent=panel, id=wx.ID_ANY, size=(65, -1),
                           initial=ambval,
                           min=0,
                           max=100)
@@ -448,7 +449,7 @@
             pos=(
                 1,
                 1))
-        fine = wx.SpinCtrl(parent=panel, id=wx.ID_ANY, size=(65, -1),
+        fine = SpinCtrl(parent=panel, id=wx.ID_ANY, size=(65, -1),
                            initial=res,
                            min=1,
                            max=100)
@@ -479,7 +480,7 @@
             pos=(
                 2,
                 1))
-        coarse = wx.SpinCtrl(parent=panel, id=wx.ID_ANY, size=(65, -1),
+        coarse = SpinCtrl(parent=panel, id=wx.ID_ANY, size=(65, -1),
                              initial=res,
                              min=1,
                              max=100)
@@ -558,7 +559,7 @@
                                          label=_("Width:")),
                       pos=(row, 0), flag=wx.ALIGN_CENTER_VERTICAL)
-        iwidth = wx.SpinCtrl(parent=panel, id=wx.ID_ANY, size=(65, -1),
+        iwidth = SpinCtrl(parent=panel, id=wx.ID_ANY, size=(65, -1),
                              initial=12,
                              min=1,
                              max=100)
@@ -606,7 +607,7 @@
                                          label=_("Size:")),
-        isize = wx.SpinCtrl(parent=panel, id=wx.ID_ANY, size=(65, -1),
+        isize = SpinCtrl(parent=panel, id=wx.ID_ANY, size=(65, -1),
                             initial=100,
                             min=1,
                             max=1e6)
Modified: grass/trunk/gui/wxpython/nviz/tools.py
--- grass/trunk/gui/wxpython/nviz/tools.py	2016-11-08 16:41:07 UTC (rev 69789)
+++ grass/trunk/gui/wxpython/nviz/tools.py	2016-11-08 18:37:25 UTC (rev 69790)
@@ -53,6 +53,7 @@
 from gui_core.widgets import ScrolledPanel, NumTextCtrl, FloatSlider, SymbolButton
 try:
     from nviz.mapwindow import wxUpdateProperties, wxUpdateView,\
@@ -548,7 +549,7 @@
             parent=panel,
             id=wx.ID_ANY,
             label=_("Frame rate (FPS):"))
-        fps = wx.SpinCtrl(
+        fps = SpinCtrl(
                 group='nviz', key='animation', subkey='fps'),
@@ -897,7 +898,7 @@
                                          label=_("resolution:")),
                       pos=(2, 1), flag=wx.ALIGN_CENTER_VERTICAL)
-        resC = wx.SpinCtrl(parent=panel, id=wx.ID_ANY, size=(65, -1),
+        resC = SpinCtrl(parent=panel, id=wx.ID_ANY, size=(65, -1),
                            initial=6,
                            min=1,
                            max=100)
@@ -943,7 +944,7 @@
                       pos=(1, 1), flag=wx.ALIGN_CENTER_VERTICAL)
-        resF = wx.SpinCtrl(parent=panel, id=wx.ID_ANY, size=(65, -1),
+        resF = SpinCtrl(parent=panel, id=wx.ID_ANY, size=(65, -1),
                            initial=3,
                            min=1,
                            max=100)
@@ -1018,7 +1019,7 @@
             elif code == 'mask':
                 value = None
             else:
-                value = wx.SpinCtrl(parent=panel, id=wx.ID_ANY, size=(65, -1),
+                value = SpinCtrl(parent=panel, id=wx.ID_ANY, size=(65, -1),
                                     initial=0)
                 value.SetRange(minVal=0, maxVal=100)
                 value.Bind(wx.EVT_TEXT, self.OnSurfaceMap)
@@ -1383,7 +1384,7 @@
                                          label=_("Fine resolution:")),
                            initial=3,
                            min=1,
                            max=100)
@@ -1398,7 +1399,7 @@
                                          label=_("Value:")), pos=(1, 0),
-        value = wx.SpinCtrl(panel, id=wx.ID_ANY,
+        value = SpinCtrl(panel, id=wx.ID_ANY,
                             min=-1e9, max=1e9,
                             size=(65, -1))
         self.win['constant']['value'] = value.GetId()
@@ -1410,7 +1411,7 @@
                                          label=_("Transparency:")), pos=(2, 0),
-        transp = wx.SpinCtrl(panel, id=wx.ID_ANY,
+        transp = SpinCtrl(panel, id=wx.ID_ANY,
                              min=0, max=100,
                              size=(65, -1))
         self.win['constant']['transp'] = transp.GetId()
@@ -1496,7 +1497,7 @@
                       pos=(0, 1), flag=wx.ALIGN_CENTER_VERTICAL |
                       wx.ALIGN_RIGHT)
-        width = wx.SpinCtrl(parent=panel, id=wx.ID_ANY, size=(65, -1),
+        width = SpinCtrl(parent=panel, id=wx.ID_ANY, size=(65, -1),
                             initial=1,
                             min=1,
                             max=100)
@@ -1667,7 +1668,7 @@
             isize.SetDigits(1)
             isize.Bind(fs.EVT_FLOATSPIN, self.OnVectorPoints)
         else:
                                 initial=1,
                                 min=1,
                                 max=1e6)
@@ -1921,7 +1922,7 @@
                                          label=_("Resolution:")),
                       pos=(0, 4), flag=wx.ALIGN_CENTER_VERTICAL)
-        resol = wx.SpinCtrl(parent=panel, id=wx.ID_ANY, size=(65, -1),
+        resol = SpinCtrl(parent=panel, id=wx.ID_ANY, size=(65, -1),
                             initial=1,
                             min=1,
                             max=100)
@@ -2279,7 +2280,7 @@
                 label=_("Elevation of fringe from bottom:")),
             pos=(0, 0),
-        spin = wx.SpinCtrl(parent=panel, id=wx.ID_ANY,
+        spin = SpinCtrl(parent=panel, id=wx.ID_ANY,
                            size=(65, -1), min=-1e6, max=1e6)
         spin.SetValue(
             UserSettings.Get(
@@ -2886,7 +2887,7 @@
 ##                value.Bind(wx.EVT_TEXT, self.OnVolumeIsosurfMap)
             else:
                 size = (65, -1)
-                value = wx.SpinCtrl(parent=panel, id=wx.ID_ANY, size=size,
+                value = SpinCtrl(parent=panel, id=wx.ID_ANY, size=size,
                                     initial=0)
                 if code == 'topo':
                     value.SetRange(minVal=-1e9, maxVal=1e9)
@@ -3029,7 +3030,7 @@
         hSizer.Add(item=wx.StaticText(parent=panel, id=wx.ID_ANY,
                                       label=_("Transparency:")), proportion=0,
                    flag=wx.ALIGN_CENTER_VERTICAL | wx.RIGHT | wx.TOP, border=7)
-        spin = wx.SpinCtrl(parent=panel, id=wx.ID_ANY, size=(65, -1),
+        spin = SpinCtrl(parent=panel, id=wx.ID_ANY, size=(65, -1),
                            min=0, max=100, initial=0)
         spin.Bind(wx.EVT_SPINCTRL, self.OnSliceTransparency)
         self.win['volume']['slice']['transp'] = spin.GetId()
Modified: grass/trunk/gui/wxpython/psmap/dialogs.py
--- grass/trunk/gui/wxpython/psmap/dialogs.py	2016-11-08 16:41:07 UTC (rev 69789)
+++ grass/trunk/gui/wxpython/psmap/dialogs.py	2016-11-08 18:37:25 UTC (rev 69790)
@@ -57,6 +57,7 @@
 from psmap.utils import *
 from psmap.instructions import *
@@ -401,7 +402,7 @@
             parent.font['fontCtrl'].SetStringSelection(dialogDict['font'])
         else:
             parent.font['fontCtrl'].SetStringSelection('Helvetica')
-        parent.font['fontSizeCtrl'] = wx.SpinCtrl(
+        parent.font['fontSizeCtrl'] = SpinCtrl(
             parent, id=wx.ID_ANY, min=4, max=50, initial=10)
         parent.font['fontSizeCtrl'].SetValue(dialogDict['fontsize'])
@@ -1046,7 +1047,7 @@
         resolutionText = wx.StaticText(
             self, id=wx.ID_ANY, label=_("Map max resolution (dpi):"))
-        self.resolutionSpin = wx.SpinCtrl(
+        self.resolutionSpin = SpinCtrl(
             self, id=wx.ID_ANY, min=1, max=1000, initial=300)
         flexSizer.Add(
@@ -1099,7 +1100,7 @@
         self.borderWidthText = wx.StaticText(
             self, id=wx.ID_ANY, label=_("border width (pts):"))
         self.borderColourPicker = wx.ColourPickerCtrl(self, id=wx.ID_ANY)
-        self.borderWidthCtrl = wx.SpinCtrl(
+        self.borderWidthCtrl = SpinCtrl(
             self, id=wx.ID_ANY, min=1, max=100, initial=1)
         if self.mapFrameDict['border'] == 'y':
@@ -2346,7 +2347,7 @@
             self.widthSpin.SetFormat("%f")
             self.widthSpin.SetDigits(2)
         else:
-            self.widthSpin = wx.SpinCtrl(
+            self.widthSpin = SpinCtrl(
                 panel, id=wx.ID_ANY, min=1, max=25, initial=1,
                 size=self.spinCtrlSize)
@@ -2510,7 +2511,7 @@
             self.outWidthSpin.SetFormat("%f")
             self.outWidthSpin.SetDigits(1)
         else:
-            self.outWidthSpin = wx.SpinCtrl(
+            self.outWidthSpin = SpinCtrl(
                 panel, id=wx.ID_ANY, min=1, max=30, initial=1,
@@ -2720,13 +2721,13 @@
         self.sizeRadio = wx.RadioButton(
             panel, id=wx.ID_ANY, label=_("size:"),
             style=wx.RB_GROUP)
-        self.sizeSpin = wx.SpinCtrl(
+        self.sizeSpin = SpinCtrl(
             panel, id=wx.ID_ANY, min=1, max=50, initial=1)
         self.sizecolumnRadio = wx.RadioButton(
             panel, id=wx.ID_ANY, label=_("size from map table column:"))
         self.sizeColChoice = self.getColsChoice(panel)
         self.scaleText = wx.StaticText(panel, id=wx.ID_ANY, label=_("scale:"))
-        self.scaleSpin = wx.SpinCtrl(
+        self.scaleSpin = SpinCtrl(
             panel, id=wx.ID_ANY, min=1, max=25, initial=1)
         self.sizeRadio.SetValue(self.vPropertiesDict['size'] is not None)
@@ -2798,7 +2799,7 @@
             panel, id=wx.ID_ANY, label=_("rotate symbols:"))
         self.rotateRadio = wx.RadioButton(panel, id=wx.ID_ANY, label=_(
             "counterclockwise in degrees:"), style=wx.RB_GROUP)
-        self.rotateSpin = wx.SpinCtrl(
+        self.rotateSpin = SpinCtrl(
             panel, id=wx.ID_ANY, min=0, max=360, initial=0)
         self.rotatecolumnRadio = wx.RadioButton(
             panel, id=wx.ID_ANY, label=_("from map table column:"))
@@ -2889,7 +2890,7 @@
             self.widthSpin.SetDigits(1)
         else:
                 panel, id=wx.ID_ANY, min=1, max=30, initial=1)
         self.cwidthCheck = wx.CheckBox(
@@ -3012,11 +3013,11 @@
             fileMode=wx.FD_OPEN)
         self.patWidthText = wx.StaticText(
             panel, id=wx.ID_ANY, label=_("pattern line width (pts):"))
-        self.patWidthSpin = wx.SpinCtrl(
+        self.patWidthSpin = SpinCtrl(
         self.patScaleText = wx.StaticText(
             panel, id=wx.ID_ANY, label=_("pattern scale factor:"))
-        self.patScaleSpin = wx.SpinCtrl(
+        self.patScaleSpin = SpinCtrl(
         self.patternCheck.SetValue(bool(self.vPropertiesDict['pat']))
@@ -3872,7 +3873,7 @@
                 minVect = 1
                 maxVect = min(10, len(self.instruction[self.vectorId]['list']))
             cols = wx.StaticText(panel, id=wx.ID_ANY, label=_("Columns:"))
-            panel.colsCtrl = wx.SpinCtrl(
+            panel.colsCtrl = SpinCtrl(
                 panel,
                 id=wx.ID_ANY,
                 value="",
@@ -4037,7 +4038,7 @@
         self.panelRaster.heightOrColumnsCtrl.Destroy()
         if self.discrete.GetValue():
             self.panelRaster.heightOrColumnsLabel.SetLabel(_("Columns:"))
-            self.panelRaster.heightOrColumnsCtrl = wx.SpinCtrl(
+            self.panelRaster.heightOrColumnsCtrl = SpinCtrl(
                 self.panelRaster, id=wx.ID_ANY, value="", min=1, max=10,
                 initial=self.rLegendDict['cols'])
             self.panelRaster.heightOrColumnsCtrl.Enable(enabledSize)
@@ -4949,21 +4950,21 @@
         sbSegmentsText = wx.StaticText(
             panel, id=wx.ID_ANY, label=_("Number of segments:"))
-        self.sbSegmentsCtrl = wx.SpinCtrl(
+        self.sbSegmentsCtrl = SpinCtrl(
             panel, id=wx.ID_ANY, min=1, max=30, initial=4)
         self.sbSegmentsCtrl.SetValue(self.scalebarDict['segment'])
         sbLabelsText1 = wx.StaticText(
             panel, id=wx.ID_ANY, label=_("Label every "))
         sbLabelsText2 = wx.StaticText(panel, id=wx.ID_ANY, label=_("segments"))
-        self.sbLabelsCtrl = wx.SpinCtrl(
+        self.sbLabelsCtrl = SpinCtrl(
         self.sbLabelsCtrl.SetValue(self.scalebarDict['numbers'])
         # font
         fontsizeText = wx.StaticText(
             panel, id=wx.ID_ANY, label=_("Font size:"))
-        self.fontsizeCtrl = wx.SpinCtrl(
+        self.fontsizeCtrl = SpinCtrl(
             panel, id=wx.ID_ANY, min=4, max=30, initial=10)
         self.fontsizeCtrl.SetValue(self.scalebarDict['fontsize'])
@@ -5265,7 +5266,7 @@
             panel, id=wx.ID_ANY, label=_("highlight"))
         self.effect['highlightColor'] = wx.ColourPickerCtrl(
-        self.effect['highlightWidth'] = wx.SpinCtrl(
+        self.effect['highlightWidth'] = SpinCtrl(
             panel, id=wx.ID_ANY, size=self.spinCtrlSize, min=0, max=5, initial=1)
         self.effect['highlightWidthLabel'] = wx.StaticText(
             panel, id=wx.ID_ANY, label=_("Width (pts):"))
@@ -5273,7 +5274,7 @@
         self.effect['borderCtrl'] = wx.CheckBox(
             panel, id=wx.ID_ANY, label=_("text border"))
         self.effect['borderColor'] = wx.ColourPickerCtrl(panel, id=wx.ID_ANY)
-        self.effect['borderWidth'] = wx.SpinCtrl(
+        self.effect['borderWidth'] = SpinCtrl(
             panel, id=wx.ID_ANY, size=self.spinCtrlSize, min=1, max=25, initial=1)
         self.effect['borderWidthLabel'] = wx.StaticText(
@@ -5387,10 +5388,10 @@
             panel, id=wx.ID_ANY, label=_("horizontal (pts):"))
         self.yoffLabel = wx.StaticText(
             panel, id=wx.ID_ANY, label=_("vertical (pts):"))
-        self.xoffCtrl = wx.SpinCtrl(
+        self.xoffCtrl = SpinCtrl(
             min=-50, max=50, initial=0)
-        self.yoffCtrl = wx.SpinCtrl(
+        self.yoffCtrl = SpinCtrl(
         self.xoffCtrl.SetValue(self.textDict['xoffset'])
@@ -5486,7 +5487,7 @@
             panel,
             id=wx.ID_ANY,
             label=_("rotate text (counterclockwise)"))
-        self.rotValue = wx.SpinCtrl(
+        self.rotValue = SpinCtrl(
             panel, wx.ID_ANY, size=(50, -1),
         if self.textDict['rotate']:
@@ -5886,7 +5887,7 @@
             panel.image['rotate'].SetFormat("%f")
             panel.image['rotate'].SetDigits(1)
         else:
-            panel.image['rotate'] = wx.SpinCtrl(
+            panel.image['rotate'] = SpinCtrl(
                 parent=panel,
                 id=wx.ID_ANY,
@@ -6444,7 +6445,7 @@
             parent=panel,
             id=wx.ID_ANY,
             label=_("Size (pt):"))
-        self.sizeCtrl = wx.SpinCtrl(
+        self.sizeCtrl = SpinCtrl(
             panel, id=wx.ID_ANY, size=self.spinCtrlSize)
         self.sizeCtrl.SetToolTipString(_("Symbol size in points"))
         self.sizeCtrl.SetValue(self.pointDict['size'])
@@ -6474,7 +6475,7 @@
             self.rotCtrl.SetFormat("%f")
             self.rotCtrl.SetDigits(1)
         else:
-            self.rotCtrl = wx.SpinCtrl(
+            self.rotCtrl = SpinCtrl(
                 parent=panel,
                 id=wx.ID_ANY,
@@ -6810,7 +6811,7 @@
             self.widthCtrl.SetFormat("%f")
             self.widthCtrl.SetDigits(1)
         else:
-            self.widthCtrl = wx.SpinCtrl(
+            self.widthCtrl = SpinCtrl(
                 parent=panel,
                 id=wx.ID_ANY,
Modified: grass/trunk/gui/wxpython/vdigit/dialogs.py
--- grass/trunk/gui/wxpython/vdigit/dialogs.py	2016-11-08 16:41:07 UTC (rev 69789)
+++ grass/trunk/gui/wxpython/vdigit/dialogs.py	2016-11-08 18:37:25 UTC (rev 69790)
@@ -28,6 +28,7 @@
 class VDigitCategoryDialog(wx.Dialog, listmix.ColumnSorterMixin):
@@ -125,7 +126,7 @@
             newCat = max(self.cats[self.fid][1]) + 1
         except KeyError:
             newCat = 1
-        self.catNew = wx.SpinCtrl(parent=self, id=wx.ID_ANY, size=(75, -1),
+        self.catNew = SpinCtrl(parent=self, id=wx.ID_ANY, size=(75, -1),
                                   initial=newCat, min=0, max=1e9)
         btnAddCat = wx.Button(self, wx.ID_ADD)
         flexSizer.Add(item=layerNewTxt, proportion=0,
@@ -634,7 +635,7 @@
         # starting value
         txt = wx.StaticText(parent=self,
                             label=_("Starting value"))
-        self.value = wx.SpinCtrl(parent=self, id=wx.ID_ANY, size=(150, -1),
+        self.value = SpinCtrl(parent=self, id=wx.ID_ANY, size=(150, -1),
                                  initial=0,
                                  min=-1e6, max=1e6)
         flexSizer.Add(txt, proportion=0, flag=wx.ALIGN_CENTER_VERTICAL)
@@ -646,7 +647,7 @@
         # step
                             label=_("Step"))
-        self.step = wx.SpinCtrl(parent=self, id=wx.ID_ANY, size=(150, -1),
+        self.step = SpinCtrl(parent=self, id=wx.ID_ANY, size=(150, -1),
                                 initial=0,
                                 min=0, max=1e6)
Modified: grass/trunk/gui/wxpython/vdigit/preferences.py
--- grass/trunk/gui/wxpython/vdigit/preferences.py	2016-11-08 16:41:07 UTC (rev 69789)
+++ grass/trunk/gui/wxpython/vdigit/preferences.py	2016-11-08 18:37:25 UTC (rev 69790)
@@ -25,6 +25,7 @@
 from core.units import Units
 class VDigitSettingsDialog(wx.Dialog):
@@ -163,7 +164,7 @@
         flexSizer.AddGrowableCol(0)
         # line width
         text = wx.StaticText(parent=panel, id=wx.ID_ANY, label=_("Line width"))
-        self.lineWidthValue = wx.SpinCtrl(
+        self.lineWidthValue = SpinCtrl(
             parent=panel, id=wx.ID_ANY, size=(75, -1),
                 group='vdigit', key="lineWidth", subkey='value'),
@@ -208,7 +209,7 @@
             parent=panel,
             id=wx.ID_ANY,
             label=_("Snapping threshold"))
-        self.snappingValue = wx.SpinCtrl(
+        self.snappingValue = SpinCtrl(
                 group='vdigit', key="snapping", subkey='value'),
@@ -285,7 +286,7 @@
             parent=panel,
             id=wx.ID_ANY,
             label=_("Select threshold"))
-        self.selectThreshValue = wx.SpinCtrl(
+        self.selectThreshValue = SpinCtrl(
                 group='vdigit', key="selectThresh", subkey='value'),
@@ -477,7 +478,7 @@
                 group='vdigit',
                 key="queryLength",
                 subkey='than-selection'))
-        self.queryLengthValue = wx.SpinCtrl(
+        self.queryLengthValue = SpinCtrl(
                 100, -1), initial=1, min=0, max=1e6)
         self.queryLengthValue.SetValue(
@@ -531,7 +532,7 @@
                 group='vdigit',
                 key="queryDangle",
-        self.queryDangleValue = wx.SpinCtrl(
+        self.queryDangleValue = SpinCtrl(
         self.queryDangleValue.SetValue(
@@ -612,7 +613,7 @@
                     (_("Mode"), _("Next to use")))
         # layer
         text = wx.StaticText(parent=panel, id=wx.ID_ANY, label=_("Layer"))
-        self.layer = wx.SpinCtrl(parent=panel, id=wx.ID_ANY, size=(125, -1),
+        self.layer = SpinCtrl(parent=panel, id=wx.ID_ANY, size=(125, -1),
                                  min=1, max=1e3)
         self.layer.SetValue(int(UserSettings.Get(
             group='vdigit', key="layer", subkey='value')))
@@ -624,7 +625,7 @@
             parent=panel,
             id=wx.ID_ANY,
             label=_("Category number"))
-        self.category = wx.SpinCtrl(
+        self.category = SpinCtrl(
                 group='vdigit', key="category", subkey='value'),
Modified: grass/trunk/gui/wxpython/vnet/dialogs.py
--- grass/trunk/gui/wxpython/vnet/dialogs.py	2016-11-08 16:41:07 UTC (rev 69789)
+++ grass/trunk/gui/wxpython/vnet/dialogs.py	2016-11-08 18:37:25 UTC (rev 69790)
@@ -49,6 +49,7 @@
 from gui_core.goutput import GConsoleWindow
 from gui_core.gselect import Select, LayerSelect, ColumnSelect
 from vnet.widgets import PointsList
 from vnet.toolbars import MainToolbar, PointListToolbar, AnalysisToolbar
@@ -245,7 +246,7 @@
         maxDistLabel = wx.StaticText(
             parent=maxDistPanel, id=wx.ID_ANY,
             label=_("Maximum distance of point to the network:"))
-        self.anSettings["max_dist"] = wx.SpinCtrl(
+        self.anSettings["max_dist"] = SpinCtrl(
             parent=maxDistPanel, id=wx.ID_ANY, min=0, max=maxValue)
         self.anSettings["max_dist"].Bind(
             wx.EVT_SPINCTRL, lambda event: self.MaxDist())
@@ -1285,7 +1286,7 @@
                 parent=self, id=wx.ID_ANY, min=1, max=50)
             size = int(
                 UserSettings.Get(
Modified: grass/trunk/gui/wxpython/web_services/widgets.py
--- grass/trunk/gui/wxpython/web_services/widgets.py	2016-11-08 16:41:07 UTC (rev 69789)
+++ grass/trunk/gui/wxpython/web_services/widgets.py	2016-11-08 18:37:25 UTC (rev 69790)
@@ -43,6 +43,7 @@
 from gui_core.widgets import ManageSettingsWidget
 import grass.script as grass
@@ -274,13 +275,13 @@
         labels['maxcols'] = wx.StaticText(
             parent=adv_setts_panel, id=wx.ID_ANY,
             label=_("Maximum columns to request from server at time:"))
-        self.params['maxcols'] = wx.SpinCtrl(
+        self.params['maxcols'] = SpinCtrl(
             parent=adv_setts_panel, id=wx.ID_ANY, size=(100, -1))
         labels['maxrows'] = wx.StaticText(
             label=_("Maximum rows to request from server at time:"))
-        self.params['maxrows'] = wx.SpinCtrl(
+        self.params['maxrows'] = SpinCtrl(
         min = 100
Modified: grass/trunk/gui/wxpython/wxplot/dialogs.py
--- grass/trunk/gui/wxpython/wxplot/dialogs.py	2016-11-08 16:41:07 UTC (rev 69789)
+++ grass/trunk/gui/wxpython/wxplot/dialogs.py	2016-11-08 18:37:25 UTC (rev 69790)
@@ -30,6 +30,7 @@
 from core.globalvar import ICONDIR
 from grass.script import core as grass
@@ -194,7 +195,7 @@
                               label=_("Number of bins (for FP maps)"))
         box.Add(item=label,
                 flag=wx.ALIGN_CENTER_VERTICAL, pos=(1, 0))
-        self.spinbins = wx.SpinCtrl(
+        self.spinbins = SpinCtrl(
             parent=self, id=wx.ID_ANY, value="", pos=(
                 30, 50), size=(
                 100, -1), style=wx.SP_ARROW_KEYS)
@@ -501,7 +502,7 @@
         box.Add(item=label,
                 flag=wx.ALIGN_CENTER_VERTICAL, pos=(3, 0))
                 30, 50), size=(
@@ -686,7 +687,7 @@
             id=wx.ID_ANY,
             label=_("Title font size (pts):"))
         gridSizer.Add(item=tlabel, flag=wx.ALIGN_CENTER_VERTICAL, pos=(1, 0))
-        self.ptitlesize = wx.SpinCtrl(
+        self.ptitlesize = SpinCtrl(
                 30, 50), size=(
                 50, -1), style=wx.SP_ARROW_KEYS)
@@ -731,7 +732,7 @@
             id=wx.ID_ANY,
             label=_("Label font size (pts):"))
         gridSizer.Add(item=llabel, flag=wx.ALIGN_CENTER_VERTICAL, pos=(4, 0))
-        self.axislabelsize = wx.SpinCtrl(
+        self.axislabelsize = SpinCtrl(
                 30, 50), size=(
@@ -1057,7 +1058,7 @@
                 pos=(
                     row,
                     0))
-            width = wx.SpinCtrl(parent=self, id=wx.ID_ANY, value="",
+            width = SpinCtrl(parent=self, id=wx.ID_ANY, value="",
                                 size=(50, -1), style=wx.SP_ARROW_KEYS)
             width.SetRange(1, 10)
             width.SetValue(self.raster[self.map]['pwidth'])
@@ -1126,7 +1127,7 @@
                 pos=(
                     1,
                     0))
-            ptsize = wx.SpinCtrl(parent=self, id=wx.ID_ANY, value="",
+            ptsize = SpinCtrl(parent=self, id=wx.ID_ANY, value="",
             ptsize.SetRange(1, 10)
             ptsize.SetValue(self.properties['marker']['size'])
@@ -1207,7 +1208,7 @@
                 pos=(
                     1,
                     0))
             ptsize.SetValue(self.raster[self.map]['psize'])
@@ -1381,7 +1382,7 @@
             id=wx.ID_ANY,
             label=_("Legend font size"))
         gridSizer.Add(item=label, flag=wx.ALIGN_CENTER_VERTICAL, pos=(row, 0))
-        legendfontsize = wx.SpinCtrl(parent=self, id=wx.ID_ANY, value="",
+        legendfontsize = SpinCtrl(parent=self, id=wx.ID_ANY, value="",
         legendfontsize.SetRange(5, 100)
         legendfontsize.SetValue(
