[GRASS-SVN] r69519 - grass-addons/grass7/vector/v.in.pygbif
Sun Sep 18 14:16:32 PDT 2016
Author: sbl
Date: 2016-09-18 14:16:32 -0700 (Sun, 18 Sep 2016)
New Revision: 69519
   grass-addons/grass7/vector/v.in.pygbif/v.in.pygbif.py
fix manual build and column order
Modified: grass-addons/grass7/vector/v.in.pygbif/v.in.pygbif.py
--- grass-addons/grass7/vector/v.in.pygbif/v.in.pygbif.py	2016-09-18 21:15:32 UTC (rev 69518)
+++ grass-addons/grass7/vector/v.in.pygbif/v.in.pygbif.py	2016-09-18 21:16:32 UTC (rev 69519)
@@ -188,16 +188,6 @@
     grass.message("You must be in GRASS GIS to run this program.")
     sys.exit(1)
-try:
-    from pygbif import occurrences
-    from pygbif import species
-except ImportError:
-    grass.fatal(_("Cannot import pygbif (https://github.com/sckott/pygbif)"
-                  " library."
-                  " Please install it (pip install pygbif)"
-                  " or ensure that it is on path"
-                  " (use PYTHONPATH variable)."))
 def set_output_encoding(encoding='utf-8'):
     import sys
     import codecs
@@ -215,6 +205,16 @@
 def main():
+    try:
+        from pygbif import occurrences
+        from pygbif import species
+    except ImportError:
+        grass.fatal(_("Cannot import pygbif (https://github.com/sckott/pygbif)"
+                      " library."
+                      " Please install it (pip install pygbif)"
+                      " or ensure that it is on path"
+                      " (use PYTHONPATH variable)."))
     # Parse input options
     output = options['output']
     mask = options['mask']
@@ -575,8 +575,8 @@
                         res.update({k: None})
                 new.write(point, attrs=(
+                          u'{}'.format(s),
                           res['key'],
-                          u'{}'.format(s),
                           res['taxonRank'],
                           res['taxonKey'],
                           res['taxonID'],
