[GRASS-SVN] r69529 - in grass/branches/releasebranch_7_2: db/drivers/dbf db/drivers/mysql db/drivers/postgres general/g.parser gui/wxpython/gcp gui/wxpython/gmodeler gui/wxpython/mapwin lib/gis lib/init lib/python/gunittest lib/rst/interp_float locale/po ps/ps.map raster/r.out.mat raster/r.reclass raster/r.statistics raster/r.surf.area raster3d/r3.in.v5d raster3d/r3.out.v5d scripts/db.droptable vector/v.out.vtk vector/v.vol.rst
Mon Sep 19 03:21:19 PDT 2016
Author: martinl
Date: 2016-09-19 03:21:19 -0700 (Mon, 19 Sep 2016)
New Revision: 69529
   grass/branches/releasebranch_7_2/db/drivers/dbf/dbfexe.c
   grass/branches/releasebranch_7_2/db/drivers/mysql/execute.c
   grass/branches/releasebranch_7_2/db/drivers/postgres/execute.c
   grass/branches/releasebranch_7_2/general/g.parser/g.parser.html
   grass/branches/releasebranch_7_2/general/g.parser/test.pl
   grass/branches/releasebranch_7_2/general/g.parser/test.py
   grass/branches/releasebranch_7_2/general/g.parser/test.sh
   grass/branches/releasebranch_7_2/gui/wxpython/gcp/g.gui.gcp.html
   grass/branches/releasebranch_7_2/gui/wxpython/gmodeler/g.gui.gmodeler.html
   grass/branches/releasebranch_7_2/gui/wxpython/mapwin/base.py
   grass/branches/releasebranch_7_2/lib/gis/cmprrle.c
   grass/branches/releasebranch_7_2/lib/gis/gislib.dox
   grass/branches/releasebranch_7_2/lib/gis/strings.c
   grass/branches/releasebranch_7_2/lib/init/clean_temp.c
   grass/branches/releasebranch_7_2/lib/init/variables.html
   grass/branches/releasebranch_7_2/lib/python/gunittest/multireport.py
   grass/branches/releasebranch_7_2/lib/rst/interp_float/interp2d.c
   grass/branches/releasebranch_7_2/locale/po/grasslibs_ar.po
   grass/branches/releasebranch_7_2/locale/po/grasslibs_cs.po
   grass/branches/releasebranch_7_2/locale/po/grasslibs_de.po
   grass/branches/releasebranch_7_2/locale/po/grasslibs_el.po
   grass/branches/releasebranch_7_2/locale/po/grasslibs_es.po
   grass/branches/releasebranch_7_2/locale/po/grasslibs_fi.po
   grass/branches/releasebranch_7_2/locale/po/grasslibs_fr.po
   grass/branches/releasebranch_7_2/locale/po/grasslibs_it.po
   grass/branches/releasebranch_7_2/locale/po/grasslibs_ja.po
   grass/branches/releasebranch_7_2/locale/po/grasslibs_ko.po
   grass/branches/releasebranch_7_2/locale/po/grasslibs_lv.po
   grass/branches/releasebranch_7_2/locale/po/grasslibs_ml.po
   grass/branches/releasebranch_7_2/locale/po/grasslibs_pl.po
   grass/branches/releasebranch_7_2/locale/po/grasslibs_pt.po
   grass/branches/releasebranch_7_2/locale/po/grasslibs_pt_br.po
   grass/branches/releasebranch_7_2/locale/po/grasslibs_ro.po
   grass/branches/releasebranch_7_2/locale/po/grasslibs_ru.po
   grass/branches/releasebranch_7_2/locale/po/grasslibs_sl.po
   grass/branches/releasebranch_7_2/locale/po/grasslibs_th.po
   grass/branches/releasebranch_7_2/locale/po/grasslibs_tr.po
   grass/branches/releasebranch_7_2/locale/po/grasslibs_vi.po
   grass/branches/releasebranch_7_2/locale/po/grasslibs_zh.po
   grass/branches/releasebranch_7_2/ps/ps.map/ps.map.html
   grass/branches/releasebranch_7_2/ps/ps.map/vector.h
   grass/branches/releasebranch_7_2/raster/r.out.mat/main.c
   grass/branches/releasebranch_7_2/raster/r.reclass/r.reclass.html
   grass/branches/releasebranch_7_2/raster/r.statistics/r.statistics.html
   grass/branches/releasebranch_7_2/raster/r.surf.area/r.surf.area.html
   grass/branches/releasebranch_7_2/raster3d/r3.in.v5d/v5d.h
   grass/branches/releasebranch_7_2/raster3d/r3.out.v5d/v5d.h
   grass/branches/releasebranch_7_2/scripts/db.droptable/db.droptable.html
   grass/branches/releasebranch_7_2/vector/v.out.vtk/v.out.vtk.html
   grass/branches/releasebranch_7_2/vector/v.vol.rst/user3.c
   grass/branches/releasebranch_7_2/vector/v.vol.rst/v.vol.rst.html
Patch for spelling errors, prepared by sebastic (see #3163) (relbr72: merge r69528 from trunk)
Modified: grass/branches/releasebranch_7_2/db/drivers/dbf/dbfexe.c
--- grass/branches/releasebranch_7_2/db/drivers/dbf/dbfexe.c	2016-09-19 09:37:30 UTC (rev 69528)
+++ grass/branches/releasebranch_7_2/db/drivers/dbf/dbfexe.c	2016-09-19 10:21:19 UTC (rev 69529)
@@ -113,7 +113,7 @@
     ncols = st->nCol;
     if (st->command == SQLP_INSERT || st->command == SQLP_SELECT
 	|| st->command == SQLP_UPDATE || st->command == SQLP_DROP_COLUMN) {
-	if (ncols > 0) {	/* colums were specified */
+	if (ncols > 0) {	/* columns were specified */
 	    cols = (int *)G_malloc(ncols * sizeof(int));
 	    for (i = 0; i < ncols; i++) {
 		cols[i] = find_column(tab, st->Col[i].s);
Modified: grass/branches/releasebranch_7_2/db/drivers/mysql/execute.c
--- grass/branches/releasebranch_7_2/db/drivers/mysql/execute.c	2016-09-19 09:37:30 UTC (rev 69528)
+++ grass/branches/releasebranch_7_2/db/drivers/mysql/execute.c	2016-09-19 10:21:19 UTC (rev 69529)
@@ -30,7 +30,7 @@
      * escape ' by another ' and the string passed to the driver is \''
      * MySQL converts \' to ' but second ' remains not escaped and
      * result is error.
-     * Because of this, all occurencies of \ in sql must be
+     * Because of this, all occurrences of \ in sql must be
      * escaped by \ */
     str = G_str_replace(db_get_string(sql), "\\", "\\\\");
Modified: grass/branches/releasebranch_7_2/db/drivers/postgres/execute.c
--- grass/branches/releasebranch_7_2/db/drivers/postgres/execute.c	2016-09-19 09:37:30 UTC (rev 69528)
+++ grass/branches/releasebranch_7_2/db/drivers/postgres/execute.c	2016-09-19 10:21:19 UTC (rev 69529)
@@ -30,7 +30,7 @@
      * text contains string \' GRASS modules escape ' by another ' and
      * string passed to driver is \'' postgres takes \' as ' but
      * second ' remains not escaped, result is error.  Because of
-     * this, all occurencies of \ in sql are escaped by \ */
+     * this, all occurrences of \ in sql are escaped by \ */
     G_debug(3, "db__driver_execute_immediate(): Escaped SQL: '%s'", str);
Modified: grass/branches/releasebranch_7_2/general/g.parser/g.parser.html
--- grass/branches/releasebranch_7_2/general/g.parser/g.parser.html	2016-09-19 09:37:30 UTC (rev 69528)
+++ grass/branches/releasebranch_7_2/general/g.parser/g.parser.html	2016-09-19 10:21:19 UTC (rev 69529)
@@ -338,7 +338,7 @@
 <div class="code"><pre>
 #!/usr/bin/env python
-# g.parser demo script for python programing
+# g.parser demo script for python programming
 #%module
 #% description: g.parser test script (python)
@@ -402,7 +402,7 @@
 #!/bin/sh
-# g.parser demo script for shell programing
+# g.parser demo script for shell programming
 #%module
 #% description: g.parser test script (shell)
Modified: grass/branches/releasebranch_7_2/general/g.parser/test.pl
--- grass/branches/releasebranch_7_2/general/g.parser/test.pl	2016-09-19 09:37:30 UTC (rev 69528)
+++ grass/branches/releasebranch_7_2/general/g.parser/test.pl	2016-09-19 10:21:19 UTC (rev 69529)
@@ -1,6 +1,6 @@
 #!/usr/bin/perl -w
 use strict;
-# g.parser demo script for perl programing
+# g.parser demo script for perl programming
 #%module
 #% description: g.parser test script (perl)
Modified: grass/branches/releasebranch_7_2/general/g.parser/test.py
--- grass/branches/releasebranch_7_2/general/g.parser/test.py	2016-09-19 09:37:30 UTC (rev 69528)
+++ grass/branches/releasebranch_7_2/general/g.parser/test.py	2016-09-19 10:21:19 UTC (rev 69529)
@@ -1,6 +1,6 @@
 #%module
Modified: grass/branches/releasebranch_7_2/general/g.parser/test.sh
--- grass/branches/releasebranch_7_2/general/g.parser/test.sh	2016-09-19 09:37:30 UTC (rev 69528)
+++ grass/branches/releasebranch_7_2/general/g.parser/test.sh	2016-09-19 10:21:19 UTC (rev 69529)
@@ -1,6 +1,6 @@
 #!/bin/sh
 #%module
Modified: grass/branches/releasebranch_7_2/gui/wxpython/gcp/g.gui.gcp.html
--- grass/branches/releasebranch_7_2/gui/wxpython/gcp/g.gui.gcp.html	2016-09-19 09:37:30 UTC (rev 69528)
+++ grass/branches/releasebranch_7_2/gui/wxpython/gcp/g.gui.gcp.html	2016-09-19 10:21:19 UTC (rev 69529)
@@ -11,7 +11,7 @@
 The <b>GCP Manager</b> provides an interactive graphical interface to
 manage and analyze Ground Control Points. A backup copy of the initial
 POINTS file is always maintained and updated only on request (Save GCPs
-to POINTS file). This guarantees that accidential changes are not
+to POINTS file). This guarantees that accidental changes are not
 permanent and can be undone by reloading the Ground Control Points.
 <p>
Modified: grass/branches/releasebranch_7_2/gui/wxpython/gmodeler/g.gui.gmodeler.html
--- grass/branches/releasebranch_7_2/gui/wxpython/gmodeler/g.gui.gmodeler.html	2016-09-19 09:37:30 UTC (rev 69528)
+++ grass/branches/releasebranch_7_2/gui/wxpython/gmodeler/g.gui.gmodeler.html	2016-09-19 10:21:19 UTC (rev 69529)
@@ -325,7 +325,7 @@
 For example, this model can later be used to calculate the average precipitation
 for every administrative region in Slovakia using the <tt>precip</tt> raster data from
 <a href="https://grass.osgeo.org/uploads/grass/sampledata/slovakia3d_grass7.tar.gz">
-Slovakia precipitation dataset</a> and administration boudaries of Slovakia from
+Slovakia precipitation dataset</a> and administration boundaries of Slovakia from
 <a href="https://www.geoportal.sk/sk/zbgis_smd/na-stiahnutie/">Slovak Geoportal</a>
 (only with a few clicks).
Modified: grass/branches/releasebranch_7_2/gui/wxpython/mapwin/base.py
--- grass/branches/releasebranch_7_2/gui/wxpython/mapwin/base.py	2016-09-19 09:37:30 UTC (rev 69528)
+++ grass/branches/releasebranch_7_2/gui/wxpython/mapwin/base.py	2016-09-19 10:21:19 UTC (rev 69529)
@@ -217,7 +217,7 @@
         Call event.Skip() in handler to allow default processing in MapWindow.
-        If any error occures inside of handler, the handler is removed.
+        If any error occurs inside of handler, the handler is removed.
         Before handler is unregistered it is called with
         string value "unregistered" of event parameter.
Modified: grass/branches/releasebranch_7_2/lib/gis/cmprrle.c
--- grass/branches/releasebranch_7_2/lib/gis/cmprrle.c	2016-09-19 09:37:30 UTC (rev 69528)
+++ grass/branches/releasebranch_7_2/lib/gis/cmprrle.c	2016-09-19 10:21:19 UTC (rev 69529)
@@ -82,8 +82,8 @@
     /* modified RLE:
      * unit is 1 byte, only sequences longer than 1 are encoded
-     * single occurences don't have a following count
-     * multiple occurences are twice in dst, followed by the count
+     * single occurrences don't have a following count
+     * multiple occurrences are twice in dst, followed by the count
      * example:
      * ABBCCC
      * is encoded as
@@ -152,8 +152,8 @@
     nbytes = 0;
     i = 1;
     while (i < src_sz) {
-	/* single occurences don't have a following count
-	 * multiple occurences are twice in src, followed by the count */
+	/* single occurrences don't have a following count
+	 * multiple occurrences are twice in src, followed by the count */
 	if (cnt == 2) {
 	    if (i >= src_sz)
 		return -1;
Modified: grass/branches/releasebranch_7_2/lib/gis/gislib.dox
--- grass/branches/releasebranch_7_2/lib/gis/gislib.dox	2016-09-19 09:37:30 UTC (rev 69528)
+++ grass/branches/releasebranch_7_2/lib/gis/gislib.dox	2016-09-19 10:21:19 UTC (rev 69529)
@@ -1177,7 +1177,7 @@
  - G_strchg()
-Replace all occurencies of character in string with new.
+Replace all occurrences of character in string with new.
 This next routine copies a string to allocated memory.
Modified: grass/branches/releasebranch_7_2/lib/gis/strings.c
--- grass/branches/releasebranch_7_2/lib/gis/strings.c	2016-09-19 09:37:30 UTC (rev 69528)
+++ grass/branches/releasebranch_7_2/lib/gis/strings.c	2016-09-19 10:21:19 UTC (rev 69529)
@@ -148,7 +148,7 @@
-  \brief Replace all occurencies of character in string bug with new
+  \brief Replace all occurrences of character in string bug with new
   \param[in,out] bug base string
   \param character character to replace
@@ -169,7 +169,7 @@
-  \brief Replace all occurencies of old_str in buffer with new_str
+  \brief Replace all occurrences of old_str in buffer with new_str
   Code example:
   \code
Modified: grass/branches/releasebranch_7_2/lib/init/clean_temp.c
--- grass/branches/releasebranch_7_2/lib/init/clean_temp.c	2016-09-19 09:37:30 UTC (rev 69528)
+++ grass/branches/releasebranch_7_2/lib/init/clean_temp.c	2016-09-19 10:21:19 UTC (rev 69529)
@@ -61,7 +61,7 @@
 	     G_snprintf(buf, BUF_MAX, "%s/%s", pathname,
 			cur_entry->d_name)) >= BUF_MAX)
 	    G_fatal_error
-		("clean_temp: exceeded maximum pathname length %d, got %d, should'nt happen",
+		("clean_temp: exceeded maximum pathname length %d, got %d, shouldn't happen",
 		 BUF_MAX, pathlen);
 	if (stat(buf, &info) != 0) {
Modified: grass/branches/releasebranch_7_2/lib/init/variables.html
--- grass/branches/releasebranch_7_2/lib/init/variables.html	2016-09-19 09:37:30 UTC (rev 69528)
+++ grass/branches/releasebranch_7_2/lib/init/variables.html	2016-09-19 10:21:19 UTC (rev 69529)
@@ -243,7 +243,7 @@
     path to bourne shell interpreter used to run shell scripts.</dd>
   <dt>GRASS_SIGSEGV_ON_ERROR</dt>
-  <dd>Raise SIGSEGV if an error occures]<br>
+  <dd>Raise SIGSEGV if an error occurs]<br>
   This variable can be set for debugging purpose. The call
   of G_fatal_error() will end in a segmentation violation. GDB can be used
   to trace the source of the error.</dd>
Modified: grass/branches/releasebranch_7_2/lib/python/gunittest/multireport.py
--- grass/branches/releasebranch_7_2/lib/python/gunittest/multireport.py	2016-09-19 09:37:30 UTC (rev 69528)
+++ grass/branches/releasebranch_7_2/lib/python/gunittest/multireport.py	2016-09-19 10:21:19 UTC (rev 69529)
@@ -118,7 +118,7 @@
     graph.plot(x, successes, color=color,
                linestyle=style.linestyle, linewidth=style.linewidth)
-    # rotates the xlables
+    # rotates the xlabels
     fig.autofmt_xdate()
     graph.set_xticks(xticks)
     graph.set_xticklabels(xlabels)
Modified: grass/branches/releasebranch_7_2/lib/rst/interp_float/interp2d.c
--- grass/branches/releasebranch_7_2/lib/rst/interp_float/interp2d.c	2016-09-19 09:37:30 UTC (rev 69528)
+++ grass/branches/releasebranch_7_2/lib/rst/interp_float/interp2d.c	2016-09-19 10:21:19 UTC (rev 69529)
@@ -230,7 +230,7 @@
 		    if (!once) {
 			once = 1;
 			G_warning(_("Overshoot - increase in tension suggested. "
-				    "Overshoot occures at (%d,%d) cell. "
+				    "Overshoot occurs at (%d,%d) cell. "
 				    "Z-value %f, zmin %f, zmax %f."),
 				  l, k, zz, zmin, zmax);
Modified: grass/branches/releasebranch_7_2/locale/po/grasslibs_ar.po
--- grass/branches/releasebranch_7_2/locale/po/grasslibs_ar.po	2016-09-19 09:37:30 UTC (rev 69528)
+++ grass/branches/releasebranch_7_2/locale/po/grasslibs_ar.po	2016-09-19 10:21:19 UTC (rev 69529)
@@ -7579,7 +7579,7 @@
 #: ../lib/rst/interp_float/interp2d.c:232
 #, c-format
 msgid ""
-"Overshoot - increase in tension suggested. Overshoot occures at (%d,%d) "
+"Overshoot - increase in tension suggested. Overshoot occurs at (%d,%d) "
 "cell. Z-value %f, zmin %f, zmax %f."
 msgstr ""
Modified: grass/branches/releasebranch_7_2/locale/po/grasslibs_cs.po
--- grass/branches/releasebranch_7_2/locale/po/grasslibs_cs.po	2016-09-19 09:37:30 UTC (rev 69528)
+++ grass/branches/releasebranch_7_2/locale/po/grasslibs_cs.po	2016-09-19 10:21:19 UTC (rev 69529)
@@ -7655,7 +7655,7 @@
 #, c-format
 msgid ""
 msgstr ""
Modified: grass/branches/releasebranch_7_2/locale/po/grasslibs_de.po
--- grass/branches/releasebranch_7_2/locale/po/grasslibs_de.po	2016-09-19 09:37:30 UTC (rev 69528)
+++ grass/branches/releasebranch_7_2/locale/po/grasslibs_de.po	2016-09-19 10:21:19 UTC (rev 69529)
@@ -7641,7 +7641,7 @@
 #, c-format
 msgid ""
 msgstr ""
 "Overshoot - Erhöhung der Spannung empfohlen. Overshoot bei Zelle (%d,%d). Z-"
Modified: grass/branches/releasebranch_7_2/locale/po/grasslibs_el.po
--- grass/branches/releasebranch_7_2/locale/po/grasslibs_el.po	2016-09-19 09:37:30 UTC (rev 69528)
+++ grass/branches/releasebranch_7_2/locale/po/grasslibs_el.po	2016-09-19 10:21:19 UTC (rev 69529)
@@ -7693,7 +7693,7 @@
 #, c-format
 msgid ""
 msgstr ""
Modified: grass/branches/releasebranch_7_2/locale/po/grasslibs_es.po
--- grass/branches/releasebranch_7_2/locale/po/grasslibs_es.po	2016-09-19 09:37:30 UTC (rev 69528)
+++ grass/branches/releasebranch_7_2/locale/po/grasslibs_es.po	2016-09-19 10:21:19 UTC (rev 69529)
@@ -7190,7 +7190,7 @@
 #, c-format
-msgid "Overshoot - increase in tension suggested. Overshoot occures at (%d,%d) cell. Z-value %f, zmin %f, zmax %f."
+msgid "Overshoot - increase in tension suggested. Overshoot occurs at (%d,%d) cell. Z-value %f, zmin %f, zmax %f."
 msgstr "Sobrepico o rebasamiento- Se sugiere un aumento en la tensión. El sobrepico ocurre en las celdas (%d,%d). Valor-Z %f, zmin %f, zmax %f."
 #: ../lib/rst/interp_float/resout2d.c:77
Modified: grass/branches/releasebranch_7_2/locale/po/grasslibs_fi.po
--- grass/branches/releasebranch_7_2/locale/po/grasslibs_fi.po	2016-09-19 09:37:30 UTC (rev 69528)
+++ grass/branches/releasebranch_7_2/locale/po/grasslibs_fi.po	2016-09-19 10:21:19 UTC (rev 69529)
@@ -7264,7 +7264,7 @@
 #, c-format
 msgid ""
 msgstr ""
Modified: grass/branches/releasebranch_7_2/locale/po/grasslibs_fr.po
--- grass/branches/releasebranch_7_2/locale/po/grasslibs_fr.po	2016-09-19 09:37:30 UTC (rev 69528)
+++ grass/branches/releasebranch_7_2/locale/po/grasslibs_fr.po	2016-09-19 10:21:19 UTC (rev 69529)
@@ -7875,7 +7875,7 @@
 #, c-format
 msgid ""
 msgstr ""
 "Dépassement - augmentation de la tension suggérée. Le dépassement se produit "
Modified: grass/branches/releasebranch_7_2/locale/po/grasslibs_it.po
--- grass/branches/releasebranch_7_2/locale/po/grasslibs_it.po	2016-09-19 09:37:30 UTC (rev 69528)
+++ grass/branches/releasebranch_7_2/locale/po/grasslibs_it.po	2016-09-19 10:21:19 UTC (rev 69529)
@@ -7766,7 +7766,7 @@
 #, c-format
 msgid ""
 msgstr ""
 "Overshoot - si suggerisce un aumento della tensione. L'overshoot avviene "
Modified: grass/branches/releasebranch_7_2/locale/po/grasslibs_ja.po
--- grass/branches/releasebranch_7_2/locale/po/grasslibs_ja.po	2016-09-19 09:37:30 UTC (rev 69528)
+++ grass/branches/releasebranch_7_2/locale/po/grasslibs_ja.po	2016-09-19 10:21:19 UTC (rev 69529)
@@ -7653,7 +7653,7 @@
 #, c-format
 msgid ""
 msgstr ""
 "オーバーシュート - 張力が増加しています.オーバーシュートは次のところで起こっ"
Modified: grass/branches/releasebranch_7_2/locale/po/grasslibs_ko.po
--- grass/branches/releasebranch_7_2/locale/po/grasslibs_ko.po	2016-09-19 09:37:30 UTC (rev 69528)
+++ grass/branches/releasebranch_7_2/locale/po/grasslibs_ko.po	2016-09-19 10:21:19 UTC (rev 69529)
@@ -7454,7 +7454,7 @@
 #, c-format
 msgid ""
 msgstr ""
Modified: grass/branches/releasebranch_7_2/locale/po/grasslibs_lv.po
--- grass/branches/releasebranch_7_2/locale/po/grasslibs_lv.po	2016-09-19 09:37:30 UTC (rev 69528)
+++ grass/branches/releasebranch_7_2/locale/po/grasslibs_lv.po	2016-09-19 10:21:19 UTC (rev 69529)
@@ -7540,7 +7540,7 @@
 #, c-format
 msgid ""
 msgstr ""
Modified: grass/branches/releasebranch_7_2/locale/po/grasslibs_ml.po
--- grass/branches/releasebranch_7_2/locale/po/grasslibs_ml.po	2016-09-19 09:37:30 UTC (rev 69528)
+++ grass/branches/releasebranch_7_2/locale/po/grasslibs_ml.po	2016-09-19 10:21:19 UTC (rev 69529)
@@ -7406,7 +7406,7 @@
 #, c-format
 msgid ""
 msgstr ""
Modified: grass/branches/releasebranch_7_2/locale/po/grasslibs_pl.po
--- grass/branches/releasebranch_7_2/locale/po/grasslibs_pl.po	2016-09-19 09:37:30 UTC (rev 69528)
+++ grass/branches/releasebranch_7_2/locale/po/grasslibs_pl.po	2016-09-19 10:21:19 UTC (rev 69529)
@@ -7608,7 +7608,7 @@
 #, c-format
 msgid ""
 msgstr ""
 "Przestrzelenie - zwiększenie parametru 'tension' może pomóc. Przestrzelenie "
Modified: grass/branches/releasebranch_7_2/locale/po/grasslibs_pt.po
--- grass/branches/releasebranch_7_2/locale/po/grasslibs_pt.po	2016-09-19 09:37:30 UTC (rev 69528)
+++ grass/branches/releasebranch_7_2/locale/po/grasslibs_pt.po	2016-09-19 10:21:19 UTC (rev 69529)
@@ -7669,7 +7669,7 @@
 #, c-format
 msgid ""
 msgstr ""
 "Estimativa por excesso - aumento na tensão sugerida. Estimativa por excesso "
Modified: grass/branches/releasebranch_7_2/locale/po/grasslibs_pt_br.po
--- grass/branches/releasebranch_7_2/locale/po/grasslibs_pt_br.po	2016-09-19 09:37:30 UTC (rev 69528)
+++ grass/branches/releasebranch_7_2/locale/po/grasslibs_pt_br.po	2016-09-19 10:21:19 UTC (rev 69529)
@@ -7645,7 +7645,7 @@
 #, c-format
 msgid ""
 msgstr ""
Modified: grass/branches/releasebranch_7_2/locale/po/grasslibs_ro.po
--- grass/branches/releasebranch_7_2/locale/po/grasslibs_ro.po	2016-09-19 09:37:30 UTC (rev 69528)
+++ grass/branches/releasebranch_7_2/locale/po/grasslibs_ro.po	2016-09-19 10:21:19 UTC (rev 69529)
@@ -7395,7 +7395,7 @@
 #, c-format
 msgid ""
 msgstr ""
Modified: grass/branches/releasebranch_7_2/locale/po/grasslibs_ru.po
--- grass/branches/releasebranch_7_2/locale/po/grasslibs_ru.po	2016-09-19 09:37:30 UTC (rev 69528)
+++ grass/branches/releasebranch_7_2/locale/po/grasslibs_ru.po	2016-09-19 10:21:19 UTC (rev 69529)
@@ -7673,7 +7673,7 @@
 #, c-format
 msgid ""
 msgstr ""
Modified: grass/branches/releasebranch_7_2/locale/po/grasslibs_sl.po
--- grass/branches/releasebranch_7_2/locale/po/grasslibs_sl.po	2016-09-19 09:37:30 UTC (rev 69528)
+++ grass/branches/releasebranch_7_2/locale/po/grasslibs_sl.po	2016-09-19 10:21:19 UTC (rev 69529)
@@ -7633,7 +7633,7 @@
 #, c-format
 msgid ""
 msgstr ""
Modified: grass/branches/releasebranch_7_2/locale/po/grasslibs_th.po
--- grass/branches/releasebranch_7_2/locale/po/grasslibs_th.po	2016-09-19 09:37:30 UTC (rev 69528)
+++ grass/branches/releasebranch_7_2/locale/po/grasslibs_th.po	2016-09-19 10:21:19 UTC (rev 69529)
 #, c-format
 msgid ""
 msgstr ""
Modified: grass/branches/releasebranch_7_2/locale/po/grasslibs_tr.po
--- grass/branches/releasebranch_7_2/locale/po/grasslibs_tr.po	2016-09-19 09:37:30 UTC (rev 69528)
+++ grass/branches/releasebranch_7_2/locale/po/grasslibs_tr.po	2016-09-19 10:21:19 UTC (rev 69529)
@@ -7581,7 +7581,7 @@
 #, c-format
 msgid ""
 msgstr ""
Modified: grass/branches/releasebranch_7_2/locale/po/grasslibs_vi.po
--- grass/branches/releasebranch_7_2/locale/po/grasslibs_vi.po	2016-09-19 09:37:30 UTC (rev 69528)
+++ grass/branches/releasebranch_7_2/locale/po/grasslibs_vi.po	2016-09-19 10:21:19 UTC (rev 69529)
@@ -7687,7 +7687,7 @@
 #, c-format
 msgid ""
 msgstr ""
Modified: grass/branches/releasebranch_7_2/locale/po/grasslibs_zh.po
--- grass/branches/releasebranch_7_2/locale/po/grasslibs_zh.po	2016-09-19 09:37:30 UTC (rev 69528)
+++ grass/branches/releasebranch_7_2/locale/po/grasslibs_zh.po	2016-09-19 10:21:19 UTC (rev 69529)
 #, c-format
 msgid ""
 msgstr ""
Modified: grass/branches/releasebranch_7_2/ps/ps.map/ps.map.html
--- grass/branches/releasebranch_7_2/ps/ps.map/ps.map.html	2016-09-19 09:37:30 UTC (rev 69528)
+++ grass/branches/releasebranch_7_2/ps/ps.map/ps.map.html	2016-09-19 10:21:19 UTC (rev 69529)
@@ -1440,7 +1440,7 @@
 <p><em>width</em> is the width in inches of the color symbol (for lines)
 in front of the legend text. The default is 1/24 * fontsize inches.
 <p><em>cols</em> is the number of columns to split the legend into. The
-default is one column. The maximum number of colums is 10, or equal
+default is one column. The maximum number of columns is 10, or equal
 to the number of legend entries if there are less than 10 entries.
 <p><em>span</em> is the column separation distance between the left edges of
 two columns in a multicolumn legend. It is given in inches.
Modified: grass/branches/releasebranch_7_2/ps/ps.map/vector.h
--- grass/branches/releasebranch_7_2/ps/ps.map/vector.h	2016-09-19 09:37:30 UTC (rev 69528)
+++ grass/branches/releasebranch_7_2/ps/ps.map/vector.h	2016-09-19 10:21:19 UTC (rev 69529)
@@ -102,7 +102,7 @@
     int fontsize;		/* legend font size */
     char *font;			/* legend font */
     double width;		/* width of legend symbols */
-    int cols;			/* number of colums  */
+    int cols;			/* number of columns  */
     PSCOLOR border;		/* border color */
     double span;		/* column separation in inches */
     LAYER *layer;
Modified: grass/branches/releasebranch_7_2/raster/r.out.mat/main.c
--- grass/branches/releasebranch_7_2/raster/r.out.mat/main.c	2016-09-19 09:37:30 UTC (rev 69528)
+++ grass/branches/releasebranch_7_2/raster/r.out.mat/main.c	2016-09-19 10:21:19 UTC (rev 69529)
@@ -216,7 +216,7 @@
 	fwrite(&format_block, sizeof(int), 1, fp1);
 	/* fprintf(stderr, "bounds data format is [%04ld]\n", format_block); */
-	/* 4 byte number of rows , 4 byte number of colums */
+	/* 4 byte number of rows , 4 byte number of columns */
 	fwrite(&mrows, sizeof(int), 1, fp1);
 	fwrite(&ncols, sizeof(int), 1, fp1);
Modified: grass/branches/releasebranch_7_2/raster/r.reclass/r.reclass.html
--- grass/branches/releasebranch_7_2/raster/r.reclass/r.reclass.html	2016-09-19 09:37:30 UTC (rev 69528)
+++ grass/branches/releasebranch_7_2/raster/r.reclass/r.reclass.html	2016-09-19 10:21:19 UTC (rev 69529)
@@ -31,7 +31,7 @@
 <p><em>r.reclass</em> only works on an <i>integer</i> input raster map; if the
 input map is instead floating point data, you must multiply the input data by some
-factor to acheive whole number input data, otherwise <em>r.reclass</em> will round
+factor to achieve whole number input data, otherwise <em>r.reclass</em> will round
 the raster values down to the next integer.
 <p>Also note that although the user can generate a <em>r.reclass</em> map
Modified: grass/branches/releasebranch_7_2/raster/r.statistics/r.statistics.html
--- grass/branches/releasebranch_7_2/raster/r.statistics/r.statistics.html	2016-09-19 09:37:30 UTC (rev 69528)
+++ grass/branches/releasebranch_7_2/raster/r.statistics/r.statistics.html	2016-09-19 10:21:19 UTC (rev 69529)
@@ -29,7 +29,7 @@
 The calculations will be performed on each area of data of the
 cover layers which fall within each unique value, or category, of the base layer.
-<p>Setting the <em>-c</em> flag the category lables of the covering raster
+<p>Setting the <em>-c</em> flag the category labels of the covering raster
 layer will be used.  This is nice to avoid the GRASS limitation to integer
 in raster maps because using category values floating point numbers can be
 stored.
Modified: grass/branches/releasebranch_7_2/raster/r.surf.area/r.surf.area.html
--- grass/branches/releasebranch_7_2/raster/r.surf.area/r.surf.area.html	2016-09-19 09:37:30 UTC (rev 69528)
+++ grass/branches/releasebranch_7_2/raster/r.surf.area/r.surf.area.html	2016-09-19 10:21:19 UTC (rev 69529)
@@ -36,7 +36,7 @@
 <p><em>r.surf.area</em> works best when the surface being evaluated
 extends to the edges of the current region and the cell resolution is
 small. Surfaces which are especially long and thin and have highly
-irregular boudaries will tend to have underestimated surface areas.
+irregular boundaries will tend to have underestimated surface areas.
 Setting a high cell resolution (small area) will greatly reduce this
 impact, but will cause longer processing times.
Modified: grass/branches/releasebranch_7_2/raster3d/r3.in.v5d/v5d.h
--- grass/branches/releasebranch_7_2/raster3d/r3.in.v5d/v5d.h	2016-09-19 09:37:30 UTC (rev 69528)
+++ grass/branches/releasebranch_7_2/raster3d/r3.in.v5d/v5d.h	2016-09-19 10:21:19 UTC (rev 69529)
@@ -186,7 +186,7 @@
        ProjArgs[0] = North bound, Y coordinate of grid row 0
        ProjArgs[1] = West bound, X coordiante of grid column 0
        ProjArgs[2] = Increment between rows
-       ProjArgs[3] = Increment between colums
+       ProjArgs[3] = Increment between columns
        NOTES: X coordinates increase to the right, Y increase upward.
        NOTES: Coordinate system is right-handed.
        ELSE IF Projection==1 THEN
Modified: grass/branches/releasebranch_7_2/raster3d/r3.out.v5d/v5d.h
--- grass/branches/releasebranch_7_2/raster3d/r3.out.v5d/v5d.h	2016-09-19 09:37:30 UTC (rev 69528)
+++ grass/branches/releasebranch_7_2/raster3d/r3.out.v5d/v5d.h	2016-09-19 10:21:19 UTC (rev 69529)
@@ -186,7 +186,7 @@
Modified: grass/branches/releasebranch_7_2/scripts/db.droptable/db.droptable.html
--- grass/branches/releasebranch_7_2/scripts/db.droptable/db.droptable.html	2016-09-19 09:37:30 UTC (rev 69528)
+++ grass/branches/releasebranch_7_2/scripts/db.droptable/db.droptable.html	2016-09-19 10:21:19 UTC (rev 69529)
@@ -9,7 +9,7 @@
 <em>db.droptable</em> is a front-end
 to <em><a href="db.execute.html">db.execute</a></em> to allow easier
 usage. To some extent it is verified if the table is connected to a
-vector map to avoid accidential table removal.
+vector map to avoid accidental table removal.
 <h2>EXAMPLES</h2>
Modified: grass/branches/releasebranch_7_2/vector/v.out.vtk/v.out.vtk.html
--- grass/branches/releasebranch_7_2/vector/v.out.vtk/v.out.vtk.html	2016-09-19 09:37:30 UTC (rev 69528)
+++ grass/branches/releasebranch_7_2/vector/v.out.vtk/v.out.vtk.html	2016-09-19 10:21:19 UTC (rev 69529)
@@ -29,7 +29,7 @@
 Note that you can easily convert your 2d vectors into 3d vectors with v.drape.
 <br>
 <br>
-Because of the 32bit limits of OpenGL which is used by VTK, visualisation errors may occure if
+Because of the 32bit limits of OpenGL which is used by VTK, visualisation errors may occur if
 the grass region contains coordinates greater than 1.000.000 and vector coordinates
 with 0.01 - 0.001 meters precisison. For this reason, the flag "-c" was added. The coordinates are
 transformed to smaller coordinates (by decreasing the coordinates with the region center).
Modified: grass/branches/releasebranch_7_2/vector/v.vol.rst/user3.c
--- grass/branches/releasebranch_7_2/vector/v.vol.rst/user3.c	2016-09-19 09:37:30 UTC (rev 69528)
+++ grass/branches/releasebranch_7_2/vector/v.vol.rst/user3.c	2016-09-19 10:21:19 UTC (rev 69529)
@@ -520,7 +520,7 @@
 				fprintf(stderr,
 					"Overshoot -- increase in tension suggested.\n");
 				fprintf(stderr,
-					"Overshoot occures at (%d,%d,%d) cell\n",
+					"Overshoot occurs at (%d,%d,%d) cell\n",
 					l, k, i);
 				fprintf(stderr,
 					"The w-value is %lf, wmin is %lf,wmax is %lf\n",
Modified: grass/branches/releasebranch_7_2/vector/v.vol.rst/v.vol.rst.html
--- grass/branches/releasebranch_7_2/vector/v.vol.rst/v.vol.rst.html	2016-09-19 09:37:30 UTC (rev 69528)
+++ grass/branches/releasebranch_7_2/vector/v.vol.rst/v.vol.rst.html	2016-09-19 10:21:19 UTC (rev 69529)
@@ -117,7 +117,7 @@
 The module <a href="v.in.db.html">v.in.db</a> can be used to generate
 a 3D vector map from a table containing x,y,z columns.
-Also, the input data should be in a projected coodinate system, such as
+Also, the input data should be in a projected coordinate system, such as
 Univeral Transverse Mercator. The module does not appear to have support for
 geographic (Lat/Long) coordinates as of May 2009.
