[GRASS-SVN] r69592 - in grass-addons/grass7/raster3d: . r3.count.categories
Tue Sep 27 18:03:12 PDT 2016
Author: wenzeslaus
Date: 2016-09-27 18:03:12 -0700 (Tue, 27 Sep 2016)
New Revision: 69592
Added:
   grass-addons/grass7/raster3d/r3.count.categories/
   grass-addons/grass7/raster3d/r3.count.categories/r3.count.categories.html
   grass-addons/grass7/raster3d/r3.count.categories/r3.count.categories.py
Removed:
   grass-addons/grass7/raster3d/r3.count.categories/r3.count.cats.html
   grass-addons/grass7/raster3d/r3.count.categories/r3.count.cats.py
   grass-addons/grass7/raster3d/r3.count.cats/
   grass-addons/grass7/raster3d/r3.count.categories/Makefile
r3.count.categories: rename from r3.count.cats
New name is not as funny, but on the other hand it follows
r|v.category, r.sample.category and r.category.trim.
Modified: grass-addons/grass7/raster3d/r3.count.categories/Makefile
--- grass-addons/grass7/raster3d/r3.count.cats/Makefile	2016-09-26 02:53:54 UTC (rev 69573)
+++ grass-addons/grass7/raster3d/r3.count.categories/Makefile	2016-09-28 01:03:12 UTC (rev 69592)
@@ -1,6 +1,6 @@
 MODULE_TOPDIR = ../..
-PGM = r3.count.cats
+PGM = r3.count.categories
 include $(MODULE_TOPDIR)/include/Make/Script.make
Copied: grass-addons/grass7/raster3d/r3.count.categories/r3.count.categories.html (from rev 69573, grass-addons/grass7/raster3d/r3.count.cats/r3.count.cats.html)
--- grass-addons/grass7/raster3d/r3.count.categories/r3.count.categories.html	                        (rev 0)
+++ grass-addons/grass7/raster3d/r3.count.categories/r3.count.categories.html	2016-09-28 01:03:12 UTC (rev 69592)
@@ -0,0 +1,30 @@
+<h2>DESCRIPTION</h2>
+<em>r3.count.categories</em> iterates over whole numbers (categories,
+classes) in the 3D raster (considers values to be integers) and for
+each vertical column counts them in the given column.
+<p>
+The 3D raster map is considered to be integer, i.e. all values are
+converted to integer values with truncation. When some conversion
+is appropriate the <b>multiply</b> option can be used to scale
+the value before conversion. For example, if the values are percentages
+with values between 0 and 1, value 100 can be used to obtain percentages
+between 0 and 100. The values will be then preserved with precision 1
+(decimal part is truncated).
+<h2>SEE ALSO</h2>
+<em>
+<a href="r3.to.rast.html">r3.to.rast</a>,
+<a href="r3.to.group.html">r3.to.group</a>,
+<a href="r3.what.html">r3.what</a>
+</em>
+<h2>AUTHORS</h2>
+Vaclav Petras, <a href="http://geospatial.ncsu.edu/osgeorel/">NCSU GeoForAll Lab</a>
+<p><i>Last changed: $Date$</i>
Copied: grass-addons/grass7/raster3d/r3.count.categories/r3.count.categories.py (from rev 69573, grass-addons/grass7/raster3d/r3.count.cats/r3.count.cats.py)
--- grass-addons/grass7/raster3d/r3.count.categories/r3.count.categories.py	                        (rev 0)
+++ grass-addons/grass7/raster3d/r3.count.categories/r3.count.categories.py	2016-09-28 01:03:12 UTC (rev 69592)
@@ -0,0 +1,187 @@
+#!/usr/bin/env python
+# MODULE:        r3.count.categories
+# AUTHOR(S):     Vaclav Petras <wenzeslaus gmail com>
+# PURPOSE:       Count categories in vertical direction
+# COPYRIGHT:     (C) 2016 by Vaclav Petras, and the GRASS Development Team
+#                This program is free software under the GNU General Public
+#                License (>=v2). Read the file COPYING that comes with GRASS
+#                for details.
+#%module
+#% description: Count categories in vertical direction
+#% keyword: raster3d
+#% keyword: conversion
+#% keyword: raster
+#% keyword: categories
+#% keyword: voxel
+#%end
+#%option G_OPT_R3_INPUT
+#%end
+#%option G_OPT_R_BASENAME_OUTPUT
+#% required: yes
+#%end
+#% key: slices
+# TODO: required: no
+#% required: yes
+#% label: Basename for horizontal slices of the 3D raster
+#%end
+#%option
+#% key: multiply
+#% type: double
+#% required: no
+#% label: Value to multiply the raster values with
+#% description: Coefficient a in the equation y = ax + b
+#%end
+#%option
+#% key: add
+#% type: double
+#% required: no
+#% label: Value to add to the raster values
+#% description: Coefficient b in the equation y = ax + b
+#%end
+#%option
+#% key: size
+#% type: integer
+#% required: no
+#% label: Moving window size
+#% description: By default, only the given cell is considered
+#%end
+import grass.script as gs
+from grass.exceptions import CalledModuleError
+def check_raster3d_exists(name):
+    """Check if the raster map exists, call GRASS fatal otherwise"""
+    file_info = gs.find_file(name, element='grid3')
+    if not file_info['fullname']:
+        gs.fatal(_("3D Raster map <%s> not found") % name)
+def remove(maps):
+    """Remove raster maps"""
+    if maps:
+        gs.run_command('g.remove', flags='f', quiet=True,
+                       type='rast', name=maps)
+def list_in_current_mapset(pattern):
+    """List names of raster maps in the current mapset"""
+    maps = gs.list_pairs(type='rast', mapset=".", pattern=pattern, flag='e')
+    maps = [name for name, mapset in maps]
+    return maps
+def basename_in_use_message(basename, rasters):
+    if len(rasters) > 3:
+        formatted = "%s,..." % ", ".join(rasters[:3])
+    else:
+        formatted = ", ".join(rasters)
+    gs.fatal(_("There are rasters with basename <%s> (%s), use"
+               " different name or overwrite") % (basename, formatted))
+# TODO: create name for slices if not provided
+def create_tmp_map_name(name):
+    return '{mod}_{pid}_{map_}_tmp'.format(mod='r3_reduce',
+                                           pid=os.getpid(),
+                                           map_=name)
+def main():
+    options, flags = gs.parser()
+    input_ = options['input']
+    output_basename = options['output']
+    slices_basename = options['slices']
+    check_raster3d_exists(input_)
+    size = None
+    if options['size']:
+        size = int(options['size'])
+        if size % 2 == 0:
+            gs.fatal(_("Please provide an odd number for the moving"
+                       " window size, not %d") % size)
+    # options to be passed to r3.to.rast
+    additional_options = {}
+    for option in ['multiply', 'add']:
+        if options[option]:
+            additional_options[option] = options[option]
+    additional_options['type'] = 'CELL'
+    basename_sep = "_"
+    output_pattern = "%s%s[0-9]+" % (output_basename, basename_sep)
+    slices_pattern = "%s%s[0-9]+" % (slices_basename, basename_sep)
+    overwrite = gs.overwrite()
+    rasters = list_in_current_mapset(output_pattern)
+    if not overwrite and rasters:
+        basename_in_use_message(output_basename, rasters)
+    rasters = list_in_current_mapset(slices_pattern)
+        basename_in_use_message(slices_basename, rasters)
+    # TODO: list of categories would be better
+    info = gs.parse_command('r3.info', map=input_, flags='r')
+    map_min = int(float(info['min']))
+    map_max = int(float(info['max']))
+    gs.verbose(_("Categories from %d to %d") % (map_min, map_max))
+    rasters = []
+    try:
+        # TODO: we should switch to 3D region for the following computations?
+        # or should we require resolutions to be the same?
+        gs.run_command('r3.to.rast', input=input_, output=slices_basename,
+                       **additional_options)
+        # it's clear we created just the ones in the current mapset
+        # and we need to make the command line as short as possible
+        if size:
+            base_expr = "int({m}[{a},{b}] == $num)"
+            size = int((size - 1) / 2)  # window size to max index
+            expr_list = []
+            for raster in rasters:
+                for j in range(-size, size + 1):
+                    for i in range(-size, size + 1):
+                        expr_list.append(base_expr.format(
+                            m=raster, a=i, b=j))
+            expr = " + ".join(expr_list)
+            expr = "{out}{sep}$num = {inp}".format(
+                out=output_basename, sep=basename_sep,
+                inp=expr)
+        else:
+            expr = "{out}{sep}$num = int({inp} == $num)".format(
+                inp=" == $num) + int(".join(rasters))
+        # TODO: define behavior when the map is empty or has just one class
+        try:
+            # TODO: this uses uncommitted experimental code for trunk
+            from grass.script.parallel import ModuleCallList, execute_by_module
+            call = ModuleCallList()
+            parallel = True
+        except ImportError:
+            call = gs  # fall back to grass.script
+            parallel = False
+        for i in range(map_min, map_max + 1):
+            call.mapcalc(expr, num=i)
+        if parallel:
+            execute_by_module(call, nprocs=4)
+    except CalledModuleError as error:
+        remove(rasters)
+        gs.fatal(_("Module %s failed. Check the above error messages.") %
+                 error.cmd)
+if __name__ == "__main__":
+    main()
Deleted: grass-addons/grass7/raster3d/r3.count.categories/r3.count.cats.html
--- grass-addons/grass7/raster3d/r3.count.cats/r3.count.cats.html	2016-09-26 02:53:54 UTC (rev 69573)
+++ grass-addons/grass7/raster3d/r3.count.categories/r3.count.cats.html	2016-09-28 01:03:12 UTC (rev 69592)
@@ -1,30 +0,0 @@
-<h2>DESCRIPTION</h2>
-<em>r3.count.cats</em> iterates over whole numbers (categories, classes)
-in the 3D raster (considers values to be integers) and for each vertical
-column counts them in the given column.
-<p>
-The 3D raster map is considered to be integer, i.e. all values are
-converted to integer values with truncation. When some conversion
-is appropriate the <b>multiply</b> option can be used to scale
-the value before conversion. For example, if the values are percentages
-with values between 0 and 1, value 100 can be used to obtain percentages
-between 0 and 100. The values will be then preserved with precision 1
-(decimal part is truncated).
-<h2>SEE ALSO</h2>
-<em>
-<a href="r3.to.rast.html">r3.to.rast</a>,
-<a href="r3.to.group.html">r3.to.group</a>,
-<a href="r3.what.html">r3.what</a>
-</em>
-<h2>AUTHORS</h2>
-Vaclav Petras, <a href="http://geospatial.ncsu.edu/osgeorel/">NCSU GeoForAll Lab</a>
-<p><i>Last changed: $Date$</i>
Deleted: grass-addons/grass7/raster3d/r3.count.categories/r3.count.cats.py
--- grass-addons/grass7/raster3d/r3.count.cats/r3.count.cats.py	2016-09-26 02:53:54 UTC (rev 69573)
+++ grass-addons/grass7/raster3d/r3.count.categories/r3.count.cats.py	2016-09-28 01:03:12 UTC (rev 69592)
@@ -1,188 +0,0 @@
-#!/usr/bin/env python
-# MODULE:        r3.count.cats
-# AUTHOR(S):     Vaclav Petras <wenzeslaus gmail com>
-# PURPOSE:       Count categories in vertical direction
-# COPYRIGHT:     (C) 2016 by Vaclav Petras, and the GRASS Development Team
-#                This program is free software under the GNU General Public
-#                License (>=v2). Read the file COPYING that comes with GRASS
-#                for details.
-#%module
-#% description: Count categories in vertical direction
-#% keyword: raster3d
-#% keyword: conversion
-#% keyword: raster
-#% keyword: categories
-#% keyword: voxel
-#%end
-#%option G_OPT_R3_INPUT
-#%end
-#%option G_OPT_R_BASENAME_OUTPUT
-#% required: yes
-#%end
-#% key: slices
-# TODO: required: no
-#% required: yes
-#% label: Basename for horizontal slices of the 3D raster
-#%end
-#%option
-#% key: multiply
-#% type: double
-#% required: no
-#% label: Value to multiply the raster values with
-#% description: Coefficient a in the equation y = ax + b
-#%end
-#%option
-#% key: add
-#% type: double
-#% required: no
-#% label: Value to add to the raster values
-#% description: Coefficient b in the equation y = ax + b
-#%end
-#%option
-#% key: size
-#% type: integer
-#% required: no
-#% label: Moving window size
-#% description: By default, only the given cell is considered
-#%end
-import grass.script as gs
-from grass.exceptions import CalledModuleError
-def check_raster3d_exists(name):
-    """Check if the raster map exists, call GRASS fatal otherwise"""
-    file_info = gs.find_file(name, element='grid3')
-    if not file_info['fullname']:
-        gs.fatal(_("3D Raster map <%s> not found") % name)
-def remove(maps):
-    """Remove raster maps"""
-    if maps:
-        gs.run_command('g.remove', flags='f', quiet=True,
-                       type='rast', name=maps)
-def list_in_current_mapset(pattern):
-    """List names of raster maps in the current mapset"""
-    maps = gs.list_pairs(type='rast', mapset=".", pattern=pattern, flag='e')
-    maps = [name for name, mapset in maps]
-    return maps
-def basename_in_use_message(basename, rasters):
-    if len(rasters) > 3:
-        formatted = "%s,..." % ", ".join(rasters[:3])
-    else:
-        formatted = ", ".join(rasters)
-    gs.fatal(_("There are rasters with basename <%s> (%s), use"
-               " different name or overwrite") % (basename, formatted))
-# TODO: create name for slices if not provided
-def create_tmp_map_name(name):
-    return '{mod}_{pid}_{map_}_tmp'.format(mod='r3_reduce',
-                                           pid=os.getpid(),
-                                           map_=name)
-def main():
-    options, flags = gs.parser()
-    input_ = options['input']
-    output_basename = options['output']
-    slices_basename = options['slices']
-    check_raster3d_exists(input_)
-    size = None
-    if options['size']:
-        size = int(options['size'])
-        if size % 2 == 0:
-            gs.fatal(_("Please provide an odd number for the moving"
-                       " window size, not %d") % size)
-    # options to be passed to r3.to.rast
-    additional_options = {}
-    for option in ['multiply', 'add']:
-        if options[option]:
-            additional_options[option] = options[option]
-    additional_options['type'] = 'CELL'
-    basename_sep = "_"
-    output_pattern = "%s%s[0-9]+" % (output_basename, basename_sep)
-    slices_pattern = "%s%s[0-9]+" % (slices_basename, basename_sep)
-    overwrite = gs.overwrite()
-    rasters = list_in_current_mapset(output_pattern)
-    if not overwrite and rasters:
-        basename_in_use_message(output_basename, rasters)
-    rasters = list_in_current_mapset(slices_pattern)
-        basename_in_use_message(slices_basename, rasters)
-    # TODO: list of categories would be better
-    info = gs.parse_command('r3.info', map=input_, flags='r')
-    map_min = int(float(info['min']))
-    map_max = int(float(info['max']))
-    gs.verbose(_("Categories from %d to %d") % (map_min, map_max))
-    rasters = []
-    try:
-        # TODO: we should switch to 3D region for the following computations?
-        # or should we require resolutions to be the same?
-        gs.run_command('r3.to.rast', input=input_, output=slices_basename,
-                       **additional_options)
-        # it's clear we created just the ones in the current mapset
-        # and we need to make the command line as short as possible
-        if size:
-            base_expr = "int({m}[{a},{b}] == $num)"
-            size = int((size - 1) / 2)  # window size to max index
-            expr_list = []
-            for raster in rasters:
-                for j in range(-size, size + 1):
-                    for i in range(-size, size + 1):
-                        expr_list.append(base_expr.format(
-                            m=raster, a=i, b=j))
-            expr = " + ".join(expr_list)
-            expr = "{out}{sep}$num = {inp}".format(
-                out=output_basename, sep=basename_sep,
-                inp=expr)
-        else:
-            expr = "{out}{sep}$num = int({inp} == $num)".format(
-                inp=" == $num) + int(".join(rasters))
-        # TODO: define behavior when the map is empty or has just one class
-        try:
-            # TODO: this uses uncommitted experimental code for trunk
-            from grass.script.parallel import ModuleCallList, execute_by_module
-            call = ModuleCallList()
-            parallel = True
-        except ImportError:
-            call = gs  # fall back to grass.script
-            parallel = False
-        for i in range(map_min, map_max + 1):
-            # TODO: parallelize here
-            call.mapcalc(expr, num=i)
-        if parallel:
-            execute_by_module(call, nprocs=4)
-    except CalledModuleError as error:
-        remove(rasters)
-        gs.fatal(_("Module %s failed. Check the above error messages.") %
-                 error.cmd)
-if __name__ == "__main__":
-    main()
