[GRASS-SVN] r69607 - grass/trunk/scripts/r.mask
Thu Sep 29 05:50:55 PDT 2016
Author: annakrat
Date: 2016-09-29 05:50:55 -0700 (Thu, 29 Sep 2016)
New Revision: 69607
   grass/trunk/scripts/r.mask/r.mask.py
r.mask: ignore case when removing mask for Windows
Modified: grass/trunk/scripts/r.mask/r.mask.py
--- grass/trunk/scripts/r.mask/r.mask.py	2016-09-29 06:32:04 UTC (rev 69606)
+++ grass/trunk/scripts/r.mask/r.mask.py	2016-09-29 12:50:55 UTC (rev 69607)
@@ -67,6 +67,7 @@
 #%end
 import os
+import sys
 import atexit
 import grass.script as grass
@@ -101,8 +102,12 @@
     if remove:
         # -> remove
         if exists:
-            grass.run_command('g.remove', flags='f', quiet=True,
-                              type='raster', name='MASK')
+            if sys.platform == 'win32':
+                grass.run_command('g.remove', flags='if', quiet=True,
+                                  type='raster', name='MASK')
+            else:
+                grass.run_command('g.remove', flags='f', quiet=True,
             grass.message(_("Raster MASK removed"))
         else:
             grass.fatal(_("No existing MASK to remove"))
