[GRASS-SVN] r69610 - in grass/trunk: raster/r.in.gdal vector/v.out.postgis
Fri Sep 30 12:12:19 PDT 2016
Author: martinl
Date: 2016-09-30 12:12:19 -0700 (Fri, 30 Sep 2016)
New Revision: 69610
   grass/trunk/raster/r.in.gdal/main.c
   grass/trunk/vector/v.out.postgis/create.c
v.out.postgis: fix epsg vs. srid check
Modified: grass/trunk/raster/r.in.gdal/main.c
--- grass/trunk/raster/r.in.gdal/main.c	2016-09-29 13:19:25 UTC (rev 69609)
+++ grass/trunk/raster/r.in.gdal/main.c	2016-09-30 19:12:19 UTC (rev 69610)
@@ -38,7 +38,7 @@
 #define MAX(a,b)      ((a) > (b) ? (a) : (b))
 static void ImportBand(GDALRasterBandH hBand, const char *output,
-		       struct Ref *group_ref);
+		       struct Ref *group_ref, const struct Cell_head*);
 static void SetupReprojector(const char *pszSrcWKT, const char *pszDstLoc,
 			     struct pj_info *iproj, struct pj_info *oproj);
 static int dump_rat(GDALRasterBandH hBand, char *outrat, int nBand);
@@ -79,7 +79,7 @@
 	              *rat;
     } parm;
     struct Flag *flag_o, *flag_e, *flag_k, *flag_f, *flag_l, *flag_c, *flag_p,
-        *flag_j;
+        *flag_j, *flag_r;
     /*      Initialize.                                                     */
@@ -214,6 +214,10 @@
 	_("Create the location specified by the \"location\" parameter and exit."
           " Do not import the raster file.");
+    flag_r = G_define_flag();
+    flag_r->key = 'r';
+    flag_r->description = _("Limit import to the current region");
     flag_p = G_define_flag();
     flag_p->key = 'p';
     flag_p->description = _("Print number of bands and exit");
@@ -358,30 +362,64 @@
     G_debug(3, "GDAL size: row = %d, col = %d", GDALGetRasterYSize(hDS),
 	    GDALGetRasterXSize(hDS));
-    cellhd.rows = GDALGetRasterYSize(hDS);
-    cellhd.rows3 = GDALGetRasterYSize(hDS);
-    cellhd.cols = GDALGetRasterXSize(hDS);
-    cellhd.cols3 = GDALGetRasterXSize(hDS);
+    if (flag_r->answer) {
+        G_get_set_window(&cellhd);
+    else {
+        cellhd.rows = GDALGetRasterYSize(hDS);
+        cellhd.rows3 = GDALGetRasterYSize(hDS);
+        cellhd.cols = GDALGetRasterXSize(hDS);
+        cellhd.cols3 = GDALGetRasterXSize(hDS);
     if (GDALGetGeoTransform(hDS, adfGeoTransform) == CE_None) {
 	if (adfGeoTransform[2] != 0.0 || adfGeoTransform[4] != 0.0 ||
 	    adfGeoTransform[1] <= 0.0 || adfGeoTransform[5] >= 0.0)
 	    G_fatal_error(_("Input raster map is flipped or rotated - cannot import. "
 			    "You may use 'gdalwarp' to transform the map to North-up."));
-	cellhd.north = adfGeoTransform[3];
-	cellhd.ns_res = fabs(adfGeoTransform[5]);
+        cellhd.ns_res = fabs(adfGeoTransform[5]);
 	cellhd.ns_res3 = fabs(adfGeoTransform[5]);
-	cellhd.south = cellhd.north - cellhd.ns_res * cellhd.rows;
-	cellhd.west = adfGeoTransform[0];
 	cellhd.ew_res = fabs(adfGeoTransform[1]);
 	cellhd.ew_res3 = fabs(adfGeoTransform[1]);
-	cellhd.east = cellhd.west + cellhd.cols * cellhd.ew_res;
+            int pixel_start, pixel_end, line_start, line_end;
+            /* get pixel coordinates defined by current region */
+            pixel_start = (int) (cellhd.west - adfGeoTransform[0]) / adfGeoTransform[1];
+            line_start = (int) (cellhd.north - adfGeoTransform[3]) / adfGeoTransform[5];
+            pixel_end = (int) (cellhd.east - adfGeoTransform[0]) / adfGeoTransform[1];
+            line_end = (int) (cellhd.south - adfGeoTransform[3]) / adfGeoTransform[5];
+            /* align region extent to input raster */
+            cellhd.west = adfGeoTransform[0] + pixel_start * adfGeoTransform[1] +
+                line_start * adfGeoTransform[2];
+            cellhd.north = adfGeoTransform[3] + pixel_start * adfGeoTransform[4] +
+                line_start * adfGeoTransform[5];
+            cellhd.east = adfGeoTransform[0] + pixel_end * adfGeoTransform[1] +
+                line_end * adfGeoTransform[2] + adfGeoTransform[1];
+            cellhd.south = adfGeoTransform[3] + pixel_end * adfGeoTransform[4] +
+                line_end * adfGeoTransform[5] + adfGeoTransform[5];
+            cellhd.rows = cellhd.rows3 = line_end - line_start + 1;
+            cellhd.cols = cellhd.cols3 = pixel_end - pixel_start + 1;
+        else {
+            cellhd.north = adfGeoTransform[3];
+            cellhd.south = cellhd.north - cellhd.ns_res * cellhd.rows;
+            cellhd.west = adfGeoTransform[0];
+            cellhd.east = cellhd.west + cellhd.cols * cellhd.ew_res;
 	cellhd.top = 1.;
 	cellhd.bottom = 0.;
 	cellhd.tb_res = 1.;
 	cellhd.depths = 1;
     else {
+            G_fatal_error(_("Unable to fetch the affine transformation coefficients. "
+                            "Flag -%c cannot be used in this case."), flag_r->key);
 	cellhd.north = cellhd.rows;
 	cellhd.south = 0.0;
 	cellhd.ns_res = 1.0;
@@ -609,7 +647,7 @@
 	    G_fatal_error(_("Selected band (%d) does not exist"), nBand);
-	ImportBand(hBand, output, NULL);
+	ImportBand(hBand, output, NULL, flag_r->answer ? &cellhd : NULL);
 	if (parm.rat->answer)
 	    dump_rat(hBand, parm.rat->answer, nBand);
@@ -697,7 +735,7 @@
-	    ImportBand(hBand, szBandName, &ref);
+	    ImportBand(hBand, szBandName, &ref, flag_r->answer ? &cellhd : NULL);
 	    if(map_names_file)
 	        fprintf(map_names_file, "%s\n", szBandName);
@@ -962,13 +1000,13 @@
+		       struct Ref *group_ref, const struct Cell_head *cellhd)
     RASTER_MAP_TYPE data_type;
     GDALDataType eGDT, eRawGDT;
     int row, nrows, ncols, complex;
     int cf, cfR, cfI, bNoDataEnabled;
-    int indx;
+    int indx, row_offset, col_offset;
     void *cell, *cellReal, *cellImg;
     void *bufComplex;
     double dfNoData;
@@ -1023,11 +1061,24 @@
-    /*      Create the new raster(s)                                          */
+    /*      Create the new raster(s)                                        */
-    ncols = GDALGetRasterBandXSize(hBand);
-    nrows = GDALGetRasterBandYSize(hBand);
+    row_offset = col_offset = 0;
+    if (cellhd) {
+        double adfGeoTransform[6];
+        ncols = cellhd->cols;
+        nrows = cellhd->rows;
+        if (GDALGetGeoTransform(GDALGetBandDataset(hBand), adfGeoTransform) == CE_None) {
+            col_offset = (int) (cellhd->west - adfGeoTransform[0]) / adfGeoTransform[1];
+            row_offset = (int) (cellhd->north - adfGeoTransform[3]) / adfGeoTransform[5];
+    else {
+        ncols = GDALGetRasterBandXSize(hBand);
+        nrows = GDALGetRasterBandYSize(hBand);
     if (complex) {
 	sprintf(outputReal, "%s.real", output);
 	cfR = Rast_open_new(outputReal, data_type);
@@ -1073,7 +1124,7 @@
     if (!l1bdriver) {		/* no AVHRR */
 	for (row = 1; row <= nrows; row++) {
 	    if (complex) {	/* CEOS SAR et al.: import flipped to match GRASS coordinates */
-		GDALRasterIO(hBand, GF_Read, 0, row - 1, ncols, 1,
+		GDALRasterIO(hBand, GF_Read, col_offset, row_offset + row - 1, ncols, 1,
 			     bufComplex, ncols, 1, eGDT, 0, 0);
 		for (indx = ncols - 1; indx >= 0; indx--) {	/* CEOS: flip east-west during import - MN */
@@ -1100,7 +1151,7 @@
 		Rast_put_row(cfI, cellImg, data_type);
 	    }			/* end of complex */
 	    else {		/* single band */
 			     cell, ncols, 1, eGDT, 0, 0);
 		if (nullFlags != NULL) {
Modified: grass/trunk/vector/v.out.postgis/create.c
--- grass/trunk/vector/v.out.postgis/create.c	2016-09-29 13:19:25 UTC (rev 69609)
+++ grass/trunk/vector/v.out.postgis/create.c	2016-09-30 19:12:19 UTC (rev 69610)
@@ -69,11 +69,14 @@
 	    G_debug(1, "option: %s=%s", tokens[0], tokens[1]);
             /* force lower case */
             G_str_to_lower(tokens[0]);
-            if (strcmp(tokens[0], "srid") && epsg)
-                G_warning(_("EPSG code (%s) defined for current location will be ignored"),
-                          epsg);
+            /* strip whitespace for key/value */
+            G_strip(tokens[0]);
+            G_strip(tokens[1]);
+            if (strcmp(tokens[0], "srid") == 0 && (epsg && strcmp(tokens[1], epsg) != 0))
+                G_warning(_("EPSG code defined for current location (%s) is overridden by %s"),
+                          epsg, tokens[1]);
 	    G_set_key_value(tokens[0], tokens[1], key_val);
 	    if (strcmp(tokens[0], "fid") == 0)
