[GRASS-SVN] r69612 - grass/branches/releasebranch_7_2/vector/v.out.postgis
Fri Sep 30 12:23:18 PDT 2016
Author: martinl
Date: 2016-09-30 12:23:18 -0700 (Fri, 30 Sep 2016)
New Revision: 69612
   grass/branches/releasebranch_7_2/vector/v.out.postgis/create.c
v.out.postgis: fix epsg vs. srid check
Modified: grass/branches/releasebranch_7_2/vector/v.out.postgis/create.c
--- grass/branches/releasebranch_7_2/vector/v.out.postgis/create.c	2016-09-30 19:16:01 UTC (rev 69611)
+++ grass/branches/releasebranch_7_2/vector/v.out.postgis/create.c	2016-09-30 19:23:18 UTC (rev 69612)
@@ -69,11 +69,14 @@
 	    G_debug(1, "option: %s=%s", tokens[0], tokens[1]);
             /* force lower case */
             G_str_to_lower(tokens[0]);
-            if (strcmp(tokens[0], "srid") && epsg)
-                G_warning(_("EPSG code (%s) defined for current location will be ignored"),
-                          epsg);
+            /* strip whitespace for key/value */
+            G_strip(tokens[0]);
+            G_strip(tokens[1]);
+            if (strcmp(tokens[0], "srid") == 0 && (epsg && strcmp(tokens[1], epsg) != 0))
+                G_warning(_("EPSG code defined for current location (%s) is overridden by %s"),
+                          epsg, tokens[1]);
 	    G_set_key_value(tokens[0], tokens[1], key_val);
 	    if (strcmp(tokens[0], "fid") == 0)
