[GRASS-SVN] r71377 - grass/branches/releasebranch_7_2
Thu Aug 10 13:36:11 PDT 2017
Author: neteler
Date: 2017-08-10 13:36:11 -0700 (Thu, 10 Aug 2017)
New Revision: 71377
   grass/branches/releasebranch_7_2/config.guess
   grass/branches/releasebranch_7_2/config.sub
   grass/branches/releasebranch_7_2/configure
config.guess + config.sub: updated from http://git.savannah.gnu.org/cgit/config.git/plain/
Modified: grass/branches/releasebranch_7_2/config.guess
--- grass/branches/releasebranch_7_2/config.guess	2017-08-10 20:33:54 UTC (rev 71376)
+++ grass/branches/releasebranch_7_2/config.guess	2017-08-10 20:36:11 UTC (rev 71377)
@@ -1,8 +1,8 @@
 #! /bin/sh
 # Attempt to guess a canonical system name.
-#   Copyright 1992-2016 Free Software Foundation, Inc.
+#   Copyright 1992-2017 Free Software Foundation, Inc.
-timestamp='2016-10-02'
+timestamp='2017-08-08'
 # This file is free software; you can redistribute it and/or modify it
 # under the terms of the GNU General Public License as published by
@@ -50,7 +50,7 @@
 GNU config.guess ($timestamp)
 Originally written by Per Bothner.
-Copyright 1992-2016 Free Software Foundation, Inc.
+Copyright 1992-2017 Free Software Foundation, Inc.
 This is free software; see the source for copying conditions.  There is NO
 warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE."
@@ -259,6 +259,9 @@
     *:Sortix:*:*)
 	echo ${UNAME_MACHINE}-unknown-sortix
 	exit ;;
+    *:Redox:*:*)
+	echo ${UNAME_MACHINE}-unknown-redox
+	exit ;;
     alpha:OSF1:*:*)
 	case $UNAME_RELEASE in
 	*4.0)
@@ -837,10 +840,11 @@
 	UNAME_PROCESSOR=`/usr/bin/uname -p`
 	case ${UNAME_PROCESSOR} in
 	    amd64)
-		echo x86_64-unknown-freebsd`echo ${UNAME_RELEASE}|sed -e 's/[-(].*//'` ;;
-		echo ${UNAME_PROCESSOR}-unknown-freebsd`echo ${UNAME_RELEASE}|sed -e 's/[-(].*//'` ;;
+		UNAME_PROCESSOR=x86_64 ;;
+	    i386)
+		UNAME_PROCESSOR=i586 ;;
 	esac
+	echo ${UNAME_PROCESSOR}-unknown-freebsd`echo ${UNAME_RELEASE}|sed -e 's/[-(].*//'`
 	exit ;;
     i*:CYGWIN*:*)
 	echo ${UNAME_MACHINE}-pc-cygwin
@@ -1303,14 +1307,21 @@
 	if test `echo "$UNAME_RELEASE" | sed -e 's/\..*//'` -le 10 ; then
 	    if [ "$CC_FOR_BUILD" != no_compiler_found ]; then
 		if (echo '#ifdef __LP64__'; echo IS_64BIT_ARCH; echo '#endif') | \
-		    (CCOPTS="" $CC_FOR_BUILD -E - 2>/dev/null) | \
-		    grep IS_64BIT_ARCH >/dev/null
+		       (CCOPTS="" $CC_FOR_BUILD -E - 2>/dev/null) | \
+		       grep IS_64BIT_ARCH >/dev/null
 		then
 		    case $UNAME_PROCESSOR in
 			i386) UNAME_PROCESSOR=x86_64 ;;
 			powerpc) UNAME_PROCESSOR=powerpc64 ;;
 		    esac
 		fi
+		# On 10.4-10.6 one might compile for PowerPC via gcc -arch ppc
+		if (echo '#ifdef __POWERPC__'; echo IS_PPC; echo '#endif') | \
+		       grep IS_PPC >/dev/null
+		then
+		    UNAME_PROCESSOR=powerpc
+		fi
 	    fi
 	elif test "$UNAME_PROCESSOR" = i386 ; then
 	    # Avoid executing cc on OS X 10.9, as it ships with a stub
@@ -1334,15 +1345,18 @@
     *:QNX:*:4*)
 	echo i386-pc-qnx
 	exit ;;
-    NEO-?:NONSTOP_KERNEL:*:*)
+    NEO-*:NONSTOP_KERNEL:*:*)
 	echo neo-tandem-nsk${UNAME_RELEASE}
 	exit ;;
     NSE-*:NONSTOP_KERNEL:*:*)
 	echo nse-tandem-nsk${UNAME_RELEASE}
 	exit ;;
-    NSR-?:NONSTOP_KERNEL:*:*)
+    NSR-*:NONSTOP_KERNEL:*:*)
 	echo nsr-tandem-nsk${UNAME_RELEASE}
 	exit ;;
+    NSX-*:NONSTOP_KERNEL:*:*)
+	echo nsx-tandem-nsk${UNAME_RELEASE}
+	exit ;;
     *:NonStop-UX:*:*)
 	echo mips-compaq-nonstopux
 	exit ;;
@@ -1418,8 +1432,8 @@
 $0: unable to guess system type
 This script (version $timestamp), has failed to recognize the
-operating system you are using. If your script is old, overwrite
-config.guess and config.sub with the latest versions from:
+operating system you are using. If your script is old, overwrite *all*
+copies of config.guess and config.sub with the latest versions from:
   http://git.savannah.gnu.org/gitweb/?p=config.git;a=blob_plain;f=config.guess
 and
Modified: grass/branches/releasebranch_7_2/config.sub
--- grass/branches/releasebranch_7_2/config.sub	2017-08-10 20:33:54 UTC (rev 71376)
+++ grass/branches/releasebranch_7_2/config.sub	2017-08-10 20:36:11 UTC (rev 71377)
@@ -1,8 +1,8 @@
 #! /bin/sh
 # Configuration validation subroutine script.
-timestamp='2016-09-05'
+timestamp='2017-04-02'
@@ -67,7 +67,7 @@
 version="\
 GNU config.sub ($timestamp)
@@ -263,7 +263,7 @@
 	| fido | fr30 | frv | ft32 \
 	| h8300 | h8500 | hppa | hppa1.[01] | hppa2.0 | hppa2.0[nw] | hppa64 \
 	| hexagon \
-	| i370 | i860 | i960 | ia64 \
+	| i370 | i860 | i960 | ia16 | ia64 \
 	| ip2k | iq2000 \
 	| k1om \
 	| le32 | le64 \
@@ -301,6 +301,7 @@
 	| open8 | or1k | or1knd | or32 \
 	| pdp10 | pdp11 | pj | pjl \
 	| powerpc | powerpc64 | powerpc64le | powerpcle \
+	| pru \
 	| pyramid \
 	| riscv32 | riscv64 \
 	| rl78 | rx \
@@ -314,6 +315,7 @@
 	| ubicom32 \
 	| v850 | v850e | v850e1 | v850e2 | v850es | v850e2v3 \
 	| visium \
+	| wasm32 \
 	| we32k \
 	| x86 | xc16x | xstormy16 | xtensa \
 	| z8k | z80)
@@ -387,7 +389,7 @@
 	| h8300-* | h8500-* \
 	| hppa-* | hppa1.[01]-* | hppa2.0-* | hppa2.0[nw]-* | hppa64-* \
 	| hexagon-* \
-	| i*86-* | i860-* | i960-* | ia64-* \
+	| i*86-* | i860-* | i960-* | ia16-* | ia64-* \
 	| ip2k-* | iq2000-* \
 	| k1om-* \
 	| le32-* | le64-* \
@@ -428,6 +430,7 @@
 	| orion-* \
 	| pdp10-* | pdp11-* | pj-* | pjl-* | pn-* | power-* \
 	| powerpc-* | powerpc64-* | powerpc64le-* | powerpcle-* \
+	| pru-* \
 	| pyramid-* \
 	| riscv32-* | riscv64-* \
 	| rl78-* | romp-* | rs6000-* | rx-* \
@@ -444,6 +447,7 @@
 	| v850-* | v850e-* | v850e1-* | v850es-* | v850e2-* | v850e2v3-* \
 	| vax-* \
 	| visium-* \
+	| wasm32-* \
 	| we32k-* \
 	| x86-* | x86_64-* | xc16x-* | xps100-* \
 	| xstormy16-* | xtensa*-* \
@@ -946,6 +950,9 @@
 	nsr-tandem)
 		basic_machine=nsr-tandem
+	nsx-tandem)
+		basic_machine=nsx-tandem
 	op50n-* | op60c-*)
 		basic_machine=hppa1.1-oki
 		os=-proelf
@@ -1241,6 +1248,9 @@
 		basic_machine=a29k-wrs
 		os=-vxworks
+	wasm32)
+		basic_machine=wasm32-unknown
 	w65*)
 		basic_machine=w65-wdc
 		os=-none
@@ -1395,7 +1405,7 @@
 	      | -bosx* | -nextstep* | -cxux* | -aout* | -elf* | -oabi* \
 	      | -ptx* | -coff* | -ecoff* | -winnt* | -domain* | -vsta* \
 	      | -udi* | -eabi* | -lites* | -ieee* | -go32* | -aux* \
-	      | -chorusos* | -chorusrdb* | -cegcc* \
+	      | -chorusos* | -chorusrdb* | -cegcc* | -glidix* \
 	      | -cygwin* | -msys* | -pe* | -psos* | -moss* | -proelf* | -rtems* \
 	      | -midipix* | -mingw32* | -mingw64* | -linux-gnu* | -linux-android* \
 	      | -linux-newlib* | -linux-musl* | -linux-uclibc* \
@@ -1407,7 +1417,7 @@
 	      | -morphos* | -superux* | -rtmk* | -rtmk-nova* | -windiss* \
 	      | -powermax* | -dnix* | -nx6 | -nx7 | -sei* | -dragonfly* \
 	      | -skyos* | -haiku* | -rdos* | -toppers* | -drops* | -es* \
-	      | -onefs* | -tirtos* | -phoenix*)
+	      | -onefs* | -tirtos* | -phoenix* | -fuchsia* | -redox*)
 	# Remember, each alternative MUST END IN *, to match a version number.
 	-qnx*)
@@ -1636,6 +1646,9 @@
 	sparc-* | *-sun)
 		os=-sunos4.1.1
+	pru-*)
+		os=-elf
 	*-be)
 		os=-beos
Modified: grass/branches/releasebranch_7_2/configure
--- grass/branches/releasebranch_7_2/configure	2017-08-10 20:33:54 UTC (rev 71376)
+++ grass/branches/releasebranch_7_2/configure	2017-08-10 20:36:11 UTC (rev 71377)
@@ -8490,7 +8490,7 @@
 LDFLAGS=${ac_save_ldflags}
-  # Check for libmysqld (for embeded version of the driver)
+  # Check for libmysqld (for embedded version of the driver)
   # Extract the first word of "mysql_config", so it can be a program name with args.
 set dummy mysql_config; ac_word=$2
 echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
@@ -12193,7 +12193,58 @@
   fi
 fi
+for ac_declaration in \
+   '#include <stdlib.h>' \
+   'extern "C" void std::exit (int) throw (); using std::exit;' \
+   'extern "C" void std::exit (int); using std::exit;' \
+   'extern "C" void exit (int) throw ();' \
+   'extern "C" void exit (int);' \
+   'void exit (int);'
+do
+  cat > conftest.$ac_ext <<EOF
+#line 12207 "configure"
+#include "confdefs.h"
+#include <stdlib.h>
+$ac_declaration
+int main() {
+exit (42);
+; return 0; }
+EOF
+if { (eval echo configure:12215: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
+  echo "configure: failed program was:" >&5
+  cat conftest.$ac_ext >&5
+  rm -rf conftest*
+  continue
+fi
+rm -f conftest*
+#line 12225 "configure"
+$ac_declaration
+int main() {
+exit (42);
+; return 0; }
+EOF
+if { (eval echo configure:12232: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+  rm -rf conftest*
+  break
+else
+fi
+rm -f conftest*
+done
+if test -n "$ac_declaration"; then
+  echo '#ifdef __cplusplus' >>confdefs.h
+  echo $ac_declaration      >>confdefs.h
+  echo '#endif'             >>confdefs.h
+fi
+else
 	CXX=
 	CXXFLAGS=
@@ -12206,7 +12257,7 @@
 echo $ac_n "checking whether to use openDWG""... $ac_c" 1>&6
-echo "configure:12210: checking whether to use openDWG" >&5
+echo "configure:12261: checking whether to use openDWG" >&5
 echo "$ac_t"""$with_opendwg"" 1>&6
 case "$with_opendwg" in
 	"no")	USE_OPENDWG=	;;
@@ -12226,7 +12277,7 @@
 echo $ac_n "checking for location of openDGW includes""... $ac_c" 1>&6
-echo "configure:12230: checking for location of openDGW includes" >&5
+echo "configure:12281: checking for location of openDGW includes" >&5
 case "$with_opendwg_includes" in
 y | ye | yes | n | no)
 	{ echo "configure: error: *** You must supply a directory to --with-opendwg-includes." 1>&2; exit 1; }
@@ -12252,15 +12303,15 @@
 do
 ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
 echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:12256: checking for $ac_hdr" >&5
+echo "configure:12307: checking for $ac_hdr" >&5
-#line 12259 "configure"
+#line 12310 "configure"
 #include <$ac_hdr>
 EOF
 ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:12264: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12315: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
 ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
 if test -z "$ac_err"; then
   rm -rf conftest*
@@ -12294,7 +12345,7 @@
 echo $ac_n "checking for location of openDWG library""... $ac_c" 1>&6
-echo "configure:12298: checking for location of openDWG library" >&5
+echo "configure:12349: checking for location of openDWG library" >&5
 case "$with_opendwg_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-opendwg-libs." 1>&2; exit 1; }
@@ -12335,7 +12386,7 @@
 echo $ac_n "checking whether to use POSIX threads""... $ac_c" 1>&6
-echo "configure:12339: checking whether to use POSIX threads" >&5
+echo "configure:12390: checking whether to use POSIX threads" >&5
 echo "$ac_t"""$with_pthread"" 1>&6
 case "$with_pthread" in
 	"no")	USE_PTHREAD=	;;
@@ -12355,7 +12406,7 @@
 echo $ac_n "checking for location of POSIX threads includes""... $ac_c" 1>&6
-echo "configure:12359: checking for location of POSIX threads includes" >&5
+echo "configure:12410: checking for location of POSIX threads includes" >&5
 case "$with_pthread_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-pthread-includes." 1>&2; exit 1; }
@@ -12381,15 +12432,15 @@
 do
-echo "configure:12385: checking for $ac_hdr" >&5
+echo "configure:12436: checking for $ac_hdr" >&5
-#line 12388 "configure"
+#line 12439 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:12393: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12444: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -12423,7 +12474,7 @@
 echo $ac_n "checking for location of POSIX threads library""... $ac_c" 1>&6
-echo "configure:12427: checking for location of POSIX threads library" >&5
+echo "configure:12478: checking for location of POSIX threads library" >&5
 case "$with_pthread_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-pthread-libs." 1>&2; exit 1; }
@@ -12448,10 +12499,10 @@
 LIBS="  $LIBS"
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for pthread_create""... $ac_c" 1>&6
-echo "configure:12452: checking for pthread_create" >&5
+echo "configure:12503: checking for pthread_create" >&5
-#line 12455 "configure"
+#line 12506 "configure"
 /* System header to define __stub macros and hopefully few prototypes,
     which can conflict with char pthread_create(); below.  */
@@ -12474,7 +12525,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:12478: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12529: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_pthread_create=yes"
 else
@@ -12501,13 +12552,13 @@
 echo $ac_n "checking for pthread_create in -lpthread""... $ac_c" 1>&6
-echo "configure:12505: checking for pthread_create in -lpthread" >&5
+echo "configure:12556: checking for pthread_create in -lpthread" >&5
 ac_lib_var=`echo pthread'_'pthread_create | sed 'y%./+-%__p_%'`
 ac_save_LIBS="$LIBS"
 LIBS="-lpthread  $LIBS"
-#line 12511 "configure"
+#line 12562 "configure"
 /* Override any gcc2 internal prototype to avoid an error.  */
 /* We use char because int might match the return type of a gcc2
@@ -12518,7 +12569,7 @@
 pthread_create()
 ; return 0; }
 EOF
-if { (eval echo configure:12522: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12573: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_lib_$ac_lib_var=yes"
 else
@@ -12568,7 +12619,7 @@
 echo $ac_n "checking whether to use OpenMP""... $ac_c" 1>&6
-echo "configure:12572: checking whether to use OpenMP" >&5
+echo "configure:12623: checking whether to use OpenMP" >&5
 echo "$ac_t"""$with_openmp"" 1>&6
 case "$with_openmp" in
 	"no")	USE_OPENMP=	;;
@@ -12589,7 +12640,7 @@
 echo $ac_n "checking for location of OpenMP includes""... $ac_c" 1>&6
-echo "configure:12593: checking for location of OpenMP includes" >&5
+echo "configure:12644: checking for location of OpenMP includes" >&5
 case "$with_openmp_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-openmp-includes." 1>&2; exit 1; }
@@ -12615,15 +12666,15 @@
 do
-echo "configure:12619: checking for $ac_hdr" >&5
+echo "configure:12670: checking for $ac_hdr" >&5
-#line 12622 "configure"
+#line 12673 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:12627: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12678: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -12661,7 +12712,7 @@
 echo $ac_n "checking for location of OpenMP library""... $ac_c" 1>&6
-echo "configure:12665: checking for location of OpenMP library" >&5
+echo "configure:12716: checking for location of OpenMP library" >&5
 case "$with_openmp_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-openmp-libs." 1>&2; exit 1; }
@@ -12686,10 +12737,10 @@
 LIBS="  $LIBS"
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for GOMP_parallel_start""... $ac_c" 1>&6
-echo "configure:12690: checking for GOMP_parallel_start" >&5
+echo "configure:12741: checking for GOMP_parallel_start" >&5
-#line 12693 "configure"
+#line 12744 "configure"
     which can conflict with char GOMP_parallel_start(); below.  */
@@ -12712,7 +12763,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:12716: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12767: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_GOMP_parallel_start=yes"
 else
@@ -12739,13 +12790,13 @@
 echo $ac_n "checking for GOMP_parallel_start in -lgomp""... $ac_c" 1>&6
-echo "configure:12743: checking for GOMP_parallel_start in -lgomp" >&5
+echo "configure:12794: checking for GOMP_parallel_start in -lgomp" >&5
 ac_lib_var=`echo gomp'_'GOMP_parallel_start | sed 'y%./+-%__p_%'`
 LIBS="-lgomp  $LIBS"
-#line 12749 "configure"
+#line 12800 "configure"
@@ -12756,7 +12807,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:12760: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12811: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12829,7 +12880,7 @@
 echo $ac_n "checking whether to use OpenCL""... $ac_c" 1>&6
-echo "configure:12833: checking whether to use OpenCL" >&5
+echo "configure:12884: checking whether to use OpenCL" >&5
 echo "$ac_t"""$with_opencl"" 1>&6
 case "$with_opencl" in
 	"no")	USE_OPENCL=	;;
@@ -12849,7 +12900,7 @@
 echo $ac_n "checking for location of OpenCL includes""... $ac_c" 1>&6
-echo "configure:12853: checking for location of OpenCL includes" >&5
+echo "configure:12904: checking for location of OpenCL includes" >&5
 case "$with_opencl_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-opencl-includes." 1>&2; exit 1; }
@@ -12876,15 +12927,15 @@
 do
-echo "configure:12880: checking for $ac_hdr" >&5
+echo "configure:12931: checking for $ac_hdr" >&5
-#line 12883 "configure"
+#line 12934 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:12888: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12939: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -12924,10 +12975,10 @@
 LIBS="-framework OpenCL  $LIBS"
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for clGetPlatformInfo""... $ac_c" 1>&6
-echo "configure:12928: checking for clGetPlatformInfo" >&5
+echo "configure:12979: checking for clGetPlatformInfo" >&5
-#line 12931 "configure"
+#line 12982 "configure"
     which can conflict with char clGetPlatformInfo(); below.  */
@@ -12950,7 +13001,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:12954: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13005: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_clGetPlatformInfo=yes"
 else
@@ -12989,15 +13040,15 @@
 do
-echo "configure:12993: checking for $ac_hdr" >&5
+echo "configure:13044: checking for $ac_hdr" >&5
-#line 12996 "configure"
+#line 13047 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:13001: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13052: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -13030,7 +13081,7 @@
     # With OpenCL library directory
 echo $ac_n "checking for location of OpenCL library""... $ac_c" 1>&6
-echo "configure:13034: checking for location of OpenCL library" >&5
+echo "configure:13085: checking for location of OpenCL library" >&5
 case "$with_opencl_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-opencl-libs." 1>&2; exit 1; }
@@ -13054,13 +13105,13 @@
 echo $ac_n "checking for clGetPlatformInfo in -lOpenCL""... $ac_c" 1>&6
-echo "configure:13058: checking for clGetPlatformInfo in -lOpenCL" >&5
+echo "configure:13109: checking for clGetPlatformInfo in -lOpenCL" >&5
 ac_lib_var=`echo OpenCL'_'clGetPlatformInfo | sed 'y%./+-%__p_%'`
 LIBS="-lOpenCL  $LIBS"
-#line 13064 "configure"
+#line 13115 "configure"
@@ -13071,7 +13122,7 @@
 clGetPlatformInfo()
 ; return 0; }
 EOF
-if { (eval echo configure:13075: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13126: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13131,7 +13182,7 @@
      fi
      echo $ac_n "checking for special C compiler options needed for large files""... $ac_c" 1>&6
-echo "configure:13135: checking for special C compiler options needed for large files" >&5
+echo "configure:13186: checking for special C compiler options needed for large files" >&5
 ac_cv_sys_largefile_CC=no
         largefile_cc_opt=""
@@ -13139,7 +13190,7 @@
 	  # IRIX 6.2 and later do not support large files by default,
 	  # so use the C compiler's -n32 option if that helps.
-#line 13143 "configure"
+#line 13194 "configure"
 #include <sys/types.h>
     /* Check that off_t can represent 2**63 - 1 correctly.
@@ -13155,7 +13206,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:13159: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13210: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
@@ -13164,7 +13215,7 @@
   ac_save_CC="${CC-cc}"
 	     CC="$CC -n32"
-#line 13168 "configure"
+#line 13219 "configure"
@@ -13180,7 +13231,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:13184: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13235: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_largefile_CC=' -n32'
 else
@@ -13207,11 +13258,11 @@
      fi
      echo $ac_n "checking for _FILE_OFFSET_BITS value needed for large files""... $ac_c" 1>&6
-echo "configure:13211: checking for _FILE_OFFSET_BITS value needed for large files" >&5
+echo "configure:13262: checking for _FILE_OFFSET_BITS value needed for large files" >&5
 ac_cv_sys_file_offset_bits=no
-#line 13215 "configure"
+#line 13266 "configure"
@@ -13227,14 +13278,14 @@
 ; return 0; }
 EOF
-if { (eval echo configure:13231: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13282: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   rm -rf conftest*
-#line 13238 "configure"
+#line 13289 "configure"
 #define _FILE_OFFSET_BITS 64
@@ -13252,7 +13303,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:13256: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13307: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_file_offset_bits=64
 else
@@ -13278,11 +13329,11 @@
    fi
      echo $ac_n "checking for _LARGE_FILES value needed for large files""... $ac_c" 1>&6
-echo "configure:13282: checking for _LARGE_FILES value needed for large files" >&5
+echo "configure:13333: checking for _LARGE_FILES value needed for large files" >&5
 ac_cv_sys_large_files=no
-#line 13286 "configure"
+#line 13337 "configure"
@@ -13298,14 +13349,14 @@
 ; return 0; }
 EOF
-if { (eval echo configure:13302: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13353: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   rm -rf conftest*
-#line 13309 "configure"
+#line 13360 "configure"
 #define _LARGE_FILES 1
@@ -13323,7 +13374,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:13327: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13378: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_large_files=1
 else
@@ -13349,25 +13400,25 @@
    fi
      echo $ac_n "checking for _LARGEFILE_SOURCE value needed for large files""... $ac_c" 1>&6
-echo "configure:13353: checking for _LARGEFILE_SOURCE value needed for large files" >&5
+echo "configure:13404: checking for _LARGEFILE_SOURCE value needed for large files" >&5
 ac_cv_sys_largefile_source=no
-#line 13357 "configure"
+#line 13408 "configure"
 #include <stdio.h>
 int main() {
 return !fseeko;
 ; return 0; }
 EOF
-if { (eval echo configure:13364: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13415: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   rm -rf conftest*
-#line 13371 "configure"
+#line 13422 "configure"
 #define _LARGEFILE_SOURCE 1
 #include <stdio.h>
@@ -13376,7 +13427,7 @@
 return !fseeko;
 ; return 0; }
 EOF
-if { (eval echo configure:13380: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13431: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_largefile_source=1
 else
@@ -13408,25 +13459,25 @@
 ac_save_cflags=${CFLAGS}
 CFLAGS="$LFS_CFLAGS ${ac_save_cflags}"
-echo "configure:13412: checking for _LARGEFILE_SOURCE value needed for large files" >&5
+echo "configure:13463: checking for _LARGEFILE_SOURCE value needed for large files" >&5
-#line 13416 "configure"
+#line 13467 "configure"
 #include <stdio.h>
 int main() {
 return !fseeko;
 ; return 0; }
 EOF
-if { (eval echo configure:13423: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13474: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   rm -rf conftest*
-#line 13430 "configure"
+#line 13481 "configure"
 #include <stdio.h>
@@ -13435,7 +13486,7 @@
 return !fseeko;
 ; return 0; }
 EOF
-if { (eval echo configure:13439: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13490: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
 else
@@ -13465,18 +13516,18 @@
    # If you want fseeko and ftello with glibc, upgrade to a fixed glibc.
    echo $ac_n "checking for fseeko""... $ac_c" 1>&6
-echo "configure:13469: checking for fseeko" >&5
+echo "configure:13520: checking for fseeko" >&5
 ac_cv_func_fseeko=no
-#line 13473 "configure"
+#line 13524 "configure"
 #include <stdio.h>
 int main() {
 return fseeko && fseeko (stdin, 0, 0);
 ; return 0; }
 EOF
-if { (eval echo configure:13480: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13531: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   ac_cv_func_fseeko=yes
 else
@@ -13493,10 +13544,10 @@
    fi
 echo $ac_n "checking if system supports Large Files at all""... $ac_c" 1>&6
-echo "configure:13497: checking if system supports Large Files at all" >&5
+echo "configure:13548: checking if system supports Large Files at all" >&5
-#line 13500 "configure"
+#line 13551 "configure"
 #include <stdio.h>
@@ -13528,7 +13579,7 @@
 #endif
 ; return 0; }
 EOF
-if { (eval echo configure:13532: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13583: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_largefiles=yes
 else
