[GRASS-SVN] r71437 - in grass/trunk/temporal/t.rast.series: . testsuite
Fri Aug 25 13:39:57 PDT 2017
Author: huhabla
Date: 2017-08-25 13:39:57 -0700 (Fri, 25 Aug 2017)
New Revision: 71437
   grass/trunk/temporal/t.rast.series/t.rast.series.py
   grass/trunk/temporal/t.rast.series/testsuite/test_series.py
temporal modules: Added quantile option to t.rast.series with test
Modified: grass/trunk/temporal/t.rast.series/t.rast.series.py
--- grass/trunk/temporal/t.rast.series/t.rast.series.py	2017-08-25 15:14:33 UTC (rev 71436)
+++ grass/trunk/temporal/t.rast.series/t.rast.series.py	2017-08-25 20:39:57 UTC (rev 71437)
@@ -38,6 +38,15 @@
 #%end
 #%option
+#% key: quantile
+#% type: double
+#% description: Quantile to calculate for method=quantile
+#% required: no
+#% multiple: no
+#% options: 0.0-1.0
+#%end
+#%option
 #% key: order
 #% type: string
 #% description: Sort the maps by category
@@ -78,6 +87,7 @@
     input = options["input"]
     output = options["output"]
     method = options["method"]
+    quantile = options["quantile"]
     order = options["order"]
     where = options["where"]
     add_time = flags["t"]
@@ -111,7 +121,7 @@
         try:
             grass.run_command("r.series", flags=flag, file=filename,
                               output=output, overwrite=grass.overwrite(),
-                              method=method)
+                              method=method, quantile=quantile)
         except CalledModuleError:
             grass.fatal(_("%s failed. Check above error messages.") % 'r.series')
Modified: grass/trunk/temporal/t.rast.series/testsuite/test_series.py
--- grass/trunk/temporal/t.rast.series/testsuite/test_series.py	2017-08-25 15:14:33 UTC (rev 71436)
+++ grass/trunk/temporal/t.rast.series/testsuite/test_series.py	2017-08-25 20:39:57 UTC (rev 71437)
@@ -23,64 +23,71 @@
         os.putenv("GRASS_OVERWRITE",  "1")
         tgis.init()
         cls.use_temp_region()
-        cls.runModule("g.region",  s=0,  n=80,  w=0,  e=120,  b=0,
+        cls.runModule("g.region",  s=0,  n=80,  w=0,  e=120,  b=0,
                       t=50,  res=10,  res3=10)
         cls.runModule("r.mapcalc", expression="a1 = 100",  overwrite=True)
         cls.runModule("r.mapcalc", expression="a2 = 200",  overwrite=True)
         cls.runModule("r.mapcalc", expression="a3 = 300",  overwrite=True)
         cls.runModule("r.mapcalc", expression="a4 = 400",  overwrite=True)
-        cls.runModule("t.create",  type="strds",  temporaltype="absolute",
-                                    output="A",  title="A test",
+        cls.runModule("t.create",  type="strds",  temporaltype="absolute",
+                                    output="A",  title="A test",
                                     description="A test",  overwrite=True)
-        cls.runModule("t.register", type="raster",  input="A",
+        cls.runModule("t.register", type="raster",  input="A",
                                      maps="a1,a2,a3,a4",
-                                     start="2001-01-01",
-                                     increment="1 month",
+                                     start="2001-01-01",
+                                     increment="1 month",
                                      overwrite=True)
     @classmethod
     def tearDownClass(cls):
         """Remove the temporary region
-        cls.del_temp_region()
+        cls.del_temp_region()
         cls.runModule("t.remove", flags="rf", type="strds", inputs="A")
         cls.runModule("g.remove", flags="f", type="raster", name="series_average")
         cls.runModule("g.remove", flags="f", type="raster", name="series_maximum")
         cls.runModule("g.remove", flags="f", type="raster", name="series_minimum")
         cls.runModule("g.remove", flags="f", type="raster", name="series_minimum_2")
+        cls.runModule("g.remove", flags="f", type="raster", name="series_quantile")
     def test_average(self):
-        self.assertModule("t.rast.series", input="A", method="average",
+        self.assertModule("t.rast.series", input="A", method="average",
                           output="series_average")
         self.assertRasterMinMax(map="series_average", refmin=250, refmax=250,
                                 msg="Average must be 250")
     def test_maximum(self):
-        self.assertModule("t.rast.series", input="A", method="maximum",
+        self.assertModule("t.rast.series", input="A", method="maximum",
                           output="series_maximum")
         self.assertRasterMinMax(map="series_maximum", refmin=400, refmax=400,
                                 msg="Maximum must be 400")
     def test_minimum(self):
-        self.assertModule("t.rast.series", input="A", method="minimum",
+        self.assertModule("t.rast.series", input="A", method="minimum",
                           output="series_minimum")
         self.assertRasterMinMax(map="series_minimum", refmin=100, refmax=100,
                                 msg="Minimum must be 100")
     def test_minimum_where(self):
-                          output="series_minimum_2",
+                          output="series_minimum_2",
                           where="start_time >= '2001-03-01'")
         self.assertRasterMinMax(map="series_minimum_2", refmin=300, refmax=300,
                                 msg="Minimum must be 300")
+    def test_quantile(self):
+        self.assertModule("t.rast.series", input="A", method="quantile", quantile=0.5,
+                          output="series_quantile")
+        self.assertRasterMinMax(map="series_quantile", refmin=300, refmax=300,
+                                msg="Minimum must be 300")
 class TestSnapRelativeSTRDS(TestCase):
     @classmethod
@@ -90,64 +97,64 @@
         tgis.init()
-        cls.runModule("t.create",  type="strds",  temporaltype="relative",
+        cls.runModule("t.create",  type="strds",  temporaltype="relative",
                                      maps="a1,a2,a3,a4",
-                                     start="0",
-                                     increment="14", unit="days",
+                                     start="0",
+                                     increment="14", unit="days",
                                      overwrite=True)
     @classmethod
                           where="start_time >= 28")
 if __name__ == '__main__':
     from grass.gunittest.main import test
     test()
