[GRASS-SVN] r70511 - grass/trunk/scripts/v.report
Thu Feb 9 01:34:18 PST 2017
Author: hcho
Date: 2017-02-09 01:34:18 -0800 (Thu, 09 Feb 2017)
New Revision: 70511
   grass/trunk/scripts/v.report/v.report.py
v.report: Add spaces
Modified: grass/trunk/scripts/v.report/v.report.py
--- grass/trunk/scripts/v.report/v.report.py	2017-02-09 07:25:08 UTC (rev 70510)
+++ grass/trunk/scripts/v.report/v.report.py	2017-02-09 09:34:18 UTC (rev 70511)
@@ -108,8 +108,8 @@
         if len(records1) == 0:
             try:
                 f = grass.vector_db(map=mapname)[int(layer)]
-                grass.fatal(_("There is a table connected to input vector map '%s', but"
-                              "there are no categories present in the key column '%s'. Consider using"
+                grass.fatal(_("There is a table connected to input vector map '%s', but "
+                              "there are no categories present in the key column '%s'. Consider using "
                               "v.to.db to correct this.") % (mapname, f['key']))
             except KeyError:
                 pass
