[GRASS-SVN] r70237 - grass-addons/tools/addons
Wed Jan 4 04:08:44 PST 2017
Author: martinl
Date: 2017-01-04 04:08:44 -0800 (Wed, 04 Jan 2017)
New Revision: 70237
   grass-addons/tools/addons/build-xml.py
   grass-addons/tools/addons/compile-xml.sh
   grass-addons/tools/addons/compile.sh
broken links to source code and history in add-ons user manuals (see #3224)
Modified: grass-addons/tools/addons/build-xml.py
--- grass-addons/tools/addons/build-xml.py	2017-01-04 11:32:36 UTC (rev 70236)
+++ grass-addons/tools/addons/build-xml.py	2017-01-04 12:08:44 UTC (rev 70237)
@@ -28,7 +28,7 @@
 def start_grass(g7 = True):
     if g7:
-        ver = 'grass70_release'
+        ver = 'grass72_release'
     else:
         ver = 'grass64_release'
     gisbase = os.environ['GISBASE'] = os.path.join(os.getenv('HOME'),
Modified: grass-addons/tools/addons/compile-xml.sh
--- grass-addons/tools/addons/compile-xml.sh	2017-01-04 11:32:36 UTC (rev 70236)
+++ grass-addons/tools/addons/compile-xml.sh	2017-01-04 12:08:44 UTC (rev 70237)
@@ -7,7 +7,7 @@
 DEST="$1"
 compile() {
-    ./compile.sh $1 $2 $3 1
+    ./compile.sh $1 $2 $3 $4 1
 build_xml() {
@@ -20,8 +20,8 @@
 (cd ..; svn up || (svn cleanup && svn up))
 # compile AddOns for GRASS 7 and GRASS 6.5
-compile ../../grass7 ~/src/grass70_release/dist.x86_64-pc-linux-gnu /tmp/.grass7/addons
-compile ../../grass6 ~/src/grass64_release/dist.x86_64-pc-linux-gnu /tmp/.grass6/addons
+compile ../../grass7 ~/src/grass72_release/dist.x86_64-pc-linux-gnu /tmp/.grass7/addons 7
+compile ../../grass6 ~/src/grass64_release/dist.x86_64-pc-linux-gnu /tmp/.grass6/addons 6
 # create XML file for AddOns
 build_xml /tmp/.grass7/addons 7
Modified: grass-addons/tools/addons/compile.sh
--- grass-addons/tools/addons/compile.sh	2017-01-04 11:32:36 UTC (rev 70236)
+++ grass-addons/tools/addons/compile.sh	2017-01-04 12:08:44 UTC (rev 70237)
@@ -11,14 +11,14 @@
 SVN_PATH="$1"
 TOPDIR="$2"
 ADDON_PATH="$3"
-GRASS_VERSION=`echo $ADDON_PATH | cut -d'/' -f7 | sed 's/grass//g'`
+GRASS_VERSION="$4"
 INDEX_FILE="index"
 if [ ! -d "$3" ] ; then
     mkdir -p "$3"
 fi
-if [ -n "$4" ] ; then
+if [ -n "$5" ] ; then
     SEP=1 # useful for collecting files (see build-xml.py)
 else
     SEP=0
@@ -98,7 +98,9 @@
 	    HTMLDIR="$path/docs/html" \
 	    MANDIR="$path/docs/man/man1" \
 	    SCRIPTDIR="$path/scripts" \
-	    ETC="$path/etc" > "$ADDON_PATH/logs/$m.log" 2>&1
+	    ETC="$path/etc" \
+            SOURCE_URL="https://trac.osgeo.org/grass/browser/grass-addons/grass${GRASS_VERSION}/" > \
+            "$ADDON_PATH/logs/$m.log" 2>&1
 	if [ `echo $?` -eq 0 ] ; then
 	    printf "%-30s%s\n" "$c/$m" "SUCCESS" >> "$ADDON_PATH/logs/${INDEX_FILE}.log"
 	    echo " SUCCESS"
