[GRASS-SVN] r70367 - grass-addons/grass7/raster/r.resamp.tps
svn_grass at osgeo.org
Fri Jan 13 15:04:14 PST 2017
Author: mmetz
Date: 2017-01-13 15:04:14 -0800 (Fri, 13 Jan 2017)
New Revision: 70367
grass-addons/grass7/raster/r.resamp.tps/main.c
grass-addons/grass7/raster/r.resamp.tps/tps.c
grass-addons/grass7/raster/r.resamp.tps/tps.h
r.resamp.tps: more safety checks
Modified: grass-addons/grass7/raster/r.resamp.tps/main.c
--- grass-addons/grass7/raster/r.resamp.tps/main.c 2017-01-13 20:12:55 UTC (rev 70366)
+++ grass-addons/grass7/raster/r.resamp.tps/main.c 2017-01-13 23:04:14 UTC (rev 70367)
@@ -36,7 +36,7 @@
struct GModule *module;
struct Option *in_opt, *ivar_opt, *ovar_opt, *out_opt, *minpnts_opt,
*maxpnts_opt, *radius_opt, *reg_opt, *ov_opt,
- *lm_opt, *mask_opt, *mem_opt;
+ *lm_opt, *ep_opt, *mask_opt, *mem_opt;
struct Flag *c_flag;
struct Cell_head cellhd, src, dst;
@@ -46,7 +46,7 @@
int r, c, nrows, ncols;
DCELL **dbuf, *dval;
- double regularization, overlap, lm_thresh;
+ double regularization, overlap, lm_thresh, ep_thresh;
SEGMENT in_seg, var_seg, out_seg;
int insize, varsize;
double segsize;
@@ -134,9 +134,20 @@
lm_opt->label =
_("Threshold to avoid interpolation outliers when using covariables");
lm_opt->description =
- _("Disabled when set to zero");
+ _("Disabled when set to zero, larger values will cause more outliers");
lm_opt->guisection = _("Settings");
+ ep_opt = G_define_option();
+ ep_opt->key = "epfilter";
+ ep_opt->type = TYPE_DOUBLE;
+ ep_opt->required = NO;
+ ep_opt->answer = "0";
+ ep_opt->label =
+ _("Threshold to avoid extrapolation when using covariables");
+ ep_opt->description =
+ _("Disabled when set to zero, smaller values will cause more outliers");
+ ep_opt->guisection = _("Settings");
out_opt = G_define_standard_option(G_OPT_R_OUTPUT);
out_opt->key = "output";
out_opt->required = YES;
@@ -231,7 +242,6 @@
src.west =
cellhd.west + floor((src.west - cellhd.west) / cellhd.ew_res) * cellhd.ew_res;
/* open segment structures for input and output */
/* set input window */
@@ -408,6 +418,13 @@
lm_thresh = 0;
+ ep_thresh = 0;
+ if (ep_opt->answer) {
+ ep_thresh = atof(ep_opt->answer);
+ if (ep_thresh < 0)
+ ep_thresh = 0;
if (radius) {
if (tps_window(&in_seg, &var_seg, n_vars, &out_seg, out_fd,
mask_opt->answer, &src, &dst, n_points,
@@ -420,7 +437,7 @@
if (tps_nn(&in_seg, &var_seg, n_vars, &out_seg, out_fd,
min_points, max_points, regularization, overlap,
- c_flag->answer, lm_thresh) != 1) {
+ c_flag->answer, lm_thresh, ep_thresh) != 1) {
G_fatal_error(_("TPS interpolation failed"));
Modified: grass-addons/grass7/raster/r.resamp.tps/tps.c
--- grass-addons/grass7/raster/r.resamp.tps/tps.c 2017-01-13 20:12:55 UTC (rev 70366)
+++ grass-addons/grass7/raster/r.resamp.tps/tps.c 2017-01-13 23:04:14 UTC (rev 70367)
@@ -108,8 +108,11 @@
static int load_tps_pnts(SEGMENT *in_seg, DCELL *dval, int n_vars,
struct tps_pnt *pnts, int n_points,
struct Cell_head *src, struct Cell_head *dst,
- double regularization, double **m, double *a,
- double **mvars, double *avars)
+ double **m, double *a,
+ double **mvars, double *avars,
+ double **mpnts, double *apnts,
+ double *vmin, double *vmax)
int i, j, k;
double dx, dy, dist, dist2, distsum, reg;
@@ -122,7 +125,7 @@
- if (n_vars) {
+ if (n_vars && mvars) {
for (i = 0; i <= n_vars; i++) {
avars[i] = 0.0;
mvars[i][i] = 0.0;
@@ -143,9 +146,21 @@
for (j = 0; j < n_vars; j++) {
m[j + 1][i + 1 + n_vars] = m[i + 1 + n_vars][j + 1] = dval[j + 1];
+ if (vmin) {
+ if (i == 0) {
+ vmin[j] = vmax[j] = dval[j + 1];
+ else {
+ if (vmin[j] > dval[j + 1])
+ vmin[j] = dval[j + 1];
+ if (vmax[j] < dval[j + 1])
+ vmax[j] = dval[j + 1];
- if (n_vars) {
avars[0] += dval[0];
mvars[0][0] += 1;
for (j = 1; j <= n_vars; j++) {
@@ -196,6 +211,22 @@
m[i + 1 + n_vars][i + 1 + n_vars] = reg;
+ if (n_vars && mpnts) {
+ mpnts[0][0] = m[0][0];
+ apnts[0] = a[0];
+ for (i = 0; i < n_points; i++) {
+ mpnts[0][i + 1] = m[0][i + 1 + n_vars];
+ mpnts[i + 1][0] = m[i + 1 + n_vars][0];
+ mpnts[i + 1][i + 1] = m[i + 1 + n_vars][i + 1 + n_vars];
+ for (j = 0; j < i; j++) {
+ mpnts[i + 1][j + 1] = m[i + 1 + n_vars][j + 1 + n_vars];
+ mpnts[j + 1][i + 1] = m[j + 1 + n_vars][i + 1 + n_vars];
+ apnts[i + 1] = a[i + 1 + n_vars];
return 1;
@@ -574,18 +605,22 @@
off_t n_points, int min_points, int max_points,
double regularization, double overlap, int clustered,
- double lm_thresh)
+ double lm_thresh, double efac)
int ridx, cidx, row, col, nrows, ncols, src_row, src_col;
double **m, *a, *B;
+ double **mfull, *afull, *Bfull;
+ double **mpnts, *apnts, *Bpnts;
double **mvars, *avars, *Bvars;
+ double *Bc;
int i, j;
int kdalloc, palloc, n_cur_points;
struct tps_pnt *cur_pnts;
double dx, dy, dist, dist2, mfactor;
DCELL *dval, result, *outbuf, *varbuf;
CELL *maskbuf;
- int solved, solved_tps_lm, solved_tps, solved_lm, n_vars_i;
+ int solved, solved_tps_lm, solved_tps, solved_lm;
+ int n_vars_i, n_vars_ic;
double rsqr;
int kdfound, bfsfound, pfound;
double distmax, mindist;
@@ -598,8 +633,9 @@
double wmin, wmax;
int rmin, rmax, cmin, cmax, rminp, rmaxp, cminp, cmaxp;
int irow, irow1, irow2, icol, icol1, icol2;
- unsigned int cnt_wa, cnt_tps_lm, cnt_tps;
+ unsigned int cnt_wa, cnt_tps_lm, cnt_tps, cnt_efac;
double i_n, i_e;
+ double *vmin, *vmax;
nrows = Rast_window_rows();
ncols = Rast_window_cols();
@@ -611,12 +647,25 @@
for (i = 0; i < (palloc + 1 + n_vars); i++)
m[i] = G_malloc((palloc + 1 + n_vars) * sizeof(double));
cur_pnts = G_malloc(palloc * 5 * sizeof(struct tps_pnt));
+ afull = a;
+ Bfull = B;
+ mfull = m;
pvar = NULL;
varbuf = NULL;
mvars = NULL;
avars = NULL;
Bvars = NULL;
+ mpnts = NULL;
+ apnts = NULL;
+ Bpnts = NULL;
+ Bc = NULL;
+ vmin = NULL;
+ vmax = NULL;
if (n_vars) {
pvar = G_malloc(palloc * 5 * n_vars * sizeof(double));
cur_pnts[0].vars = pvar;
@@ -630,6 +679,15 @@
mvars = G_malloc((1 + n_vars) * sizeof(double *));
for (i = 0; i < (1 + n_vars); i++)
mvars[i] = G_malloc((1 + n_vars) * sizeof(double));
+ apnts = G_malloc((palloc + 1) * sizeof(double));
+ Bpnts = G_malloc((palloc + 1) * sizeof(double));
+ mpnts = G_malloc((palloc + 1) * sizeof(double *));
+ for (i = 0; i < (palloc + 1); i++)
+ mpnts[i] = G_malloc((palloc + 1) * sizeof(double));
+ vmin = G_malloc(n_vars * sizeof(double));
+ vmax = G_malloc(n_vars * sizeof(double));
dval = G_malloc((1 + n_vars) * sizeof(DCELL));
@@ -706,6 +764,7 @@
cnt_wa = 0;
cnt_tps_lm = 0;
cnt_tps = 0;
+ cnt_efac = 0;
if (overlap > 1.0)
overlap = 1.0;
@@ -876,6 +935,10 @@
pfound += bfsfound;
+ m = mfull;
+ a = afull;
+ B = Bfull;
if (palloc < pfound) {
G_free(a);
@@ -890,6 +953,22 @@
m = G_malloc((palloc + 1 + n_vars) * sizeof(double *));
+ mfull = m;
+ afull = a;
+ Bfull = B;
+ G_free(apnts);
+ G_free(Bpnts);
+ G_free(mpnts[i]);
+ G_free(mpnts);
/* sort points */
@@ -898,7 +977,8 @@
qsort(cur_pnts, pfound, sizeof(struct tps_pnt), cmp_pnts);
load_tps_pnts(in_seg, dval, n_vars, cur_pnts, pfound,
- src, dst, regularization, m, a, mvars, avars);
+ src, dst, regularization, m, a,
+ mvars, avars, mpnts, apnts, vmin, vmax);
/* solve */
/* it can happen that a simple linear model with the
@@ -907,6 +987,9 @@
solved_tps_lm = solved_tps = 0;
n_vars_i = n_vars;
+ m = mfull;
+ a = afull;
+ B = Bfull;
if (n_vars) {
solved_tps_lm = solvemat(m, a, B, pfound + 1 + n_vars);
@@ -938,22 +1021,32 @@
+ if (efac) {
+ for (i = 0; i < n_vars; i++) {
+ double diff;
+ diff = efac * (vmax[i] - vmin[i]);
+ vmin[i] -= diff;
+ vmax[i] += diff;
+ solved_tps = solvemat(mpnts, apnts, Bpnts, pfound + 1);
if (!solved_tps_lm) {
n_vars_i = 0;
- for (i = 0; i < pfound; i++) {
- cur_pnts[i].r = (int)((src->north - cur_pnts[i].r) / src->ns_res);
- cur_pnts[i].c = (int)((cur_pnts[i].c - src->west) / src->ew_res);
- load_tps_pnts(in_seg, dval, 0, cur_pnts, pfound,
- src, dst, regularization, m, a, NULL, NULL);
+ m = mpnts;
+ a = apnts;
+ B = Bpnts;
+ if (efac == 0)
+ solved_tps = solvemat(m, a, B, pfound + 1);
- if (!solved_tps_lm) {
+ else {
- solved = (solved_tps_lm || solved_tps);
+ solved = (solved_tps_lm | solved_tps);
if (!solved && n_cur_points == n_points)
G_fatal_error(_("Matrix is unsolvable"));
@@ -1076,6 +1169,9 @@
if ((FLAG_GET(mask_flag, irow, icol))) {
continue;
+ n_vars_ic = n_vars_i;
+ Bc = B;
if (n_vars_i) {
@@ -1084,28 +1180,26 @@
continue;
- /* TODO: check current vars against range
- * of observed vars
- use_tps = 0;
- for (i = 0; i < n_vars_i; i++) {
- if (varbuf[i] < min[i] - factor * (max[i] - min[i]) ||
- varbuf[i] > max[i] + factor * (max[i] - min[i]))
- use_tps = 1;
+ if (efac && solved_tps) {
+ for (i = 0; i < n_vars_i; i++) {
+ if (varbuf[i] < vmin[i] || varbuf[i] > vmax[i]) {
+ n_vars_ic = 0;
+ cnt_efac++;
+ Bc = Bpnts;
+ break;
i_e = dst->west + (icol + 0.5) * dst->ew_res;
Segment_get(out_seg, (void *)&tps_out, irow, icol);
- result = B[0];
- if (n_vars_i) {
- for (j = 0; j < n_vars_i; j++) {
- result += varbuf[j] * B[j + 1];
+ result = Bc[0];
+ if (n_vars_ic) {
+ for (j = 0; j < n_vars_ic; j++) {
+ result += varbuf[j] * Bc[j + 1];
@@ -1117,7 +1211,7 @@
dist = 0;
if (dist2 > 0) {
dist = dist2 * log(dist2) * 0.5;
- result += B[1 + n_vars_i + i] * dist;
+ result += Bc[1 + n_vars_i + i] * dist;
@@ -1160,6 +1254,10 @@
G_verbose_message(_("Percentage of TPS interpolations without covariables: %.2f"),
perc_no_vars);
+ if (cnt_efac) {
+ G_verbose_message(_("Number of TPS interpolations avoiding extrapolation: %u"),
+ cnt_efac);
flag_destroy(pnt_flag);
@@ -1388,7 +1486,8 @@
+ src, dst, regularization, m, a, mvars, avars,
+ NULL, NULL, NULL, NULL);
n_vars_i = n_vars;
if (pfound > 2) {
@@ -1430,7 +1529,8 @@
+ NULL, NULL, NULL, NULL, NULL, NULL);
Modified: grass-addons/grass7/raster/r.resamp.tps/tps.h
--- grass-addons/grass7/raster/r.resamp.tps/tps.h 2017-01-13 20:12:55 UTC (rev 70366)
+++ grass-addons/grass7/raster/r.resamp.tps/tps.h 2017-01-13 23:04:14 UTC (rev 70367)
@@ -17,7 +17,7 @@
double regularization, double overlap, int do_bfs,
- double lm_thresh);
+ double lm_thresh, double ep_thresh);
int tps_window(SEGMENT *in_seg, SEGMENT *var_seg, int n_vars,
SEGMENT *out_seg, int out_fd, char *mask_name,
