[GRASS-SVN] r70381 - grass/trunk/vector/v.what.rast
svn_grass at osgeo.org
Tue Jan 17 04:47:33 PST 2017
Author: martinl
Date: 2017-01-17 04:47:33 -0800 (Tue, 17 Jan 2017)
New Revision: 70381
grass/trunk/vector/v.what.rast/main.c
v.what.rast: segfault with map without topology (see #3249)
Modified: grass/trunk/vector/v.what.rast/main.c
--- grass/trunk/vector/v.what.rast/main.c 2017-01-16 14:46:53 UTC (rev 70380)
+++ grass/trunk/vector/v.what.rast/main.c 2017-01-17 12:47:33 UTC (rev 70381)
@@ -28,7 +28,7 @@
int main(int argc, char *argv[])
- int i, j, type, field, cat, vtype;
+ int i, j, type, field, cat, vtype, open_level;
int fd;
/* struct Categories RCats; */ /* TODO */
@@ -124,10 +124,10 @@
Vect_region_box(&window, &box); /* T and B set to +/- PORT_DOUBLE_MAX */
/* Open vector */
- Vect_set_open_level(2);
- if (Vect_open_old2(&Map, opt.vect->answer,
- print_flag->answer ? "" : G_mapset(),
- opt.field->answer) < 0)
+ open_level = Vect_open_old2(&Map, opt.vect->answer,
+ print_flag->answer ? "" : G_mapset(),
+ opt.field->answer);
+ if (open_level < 0)
G_fatal_error(_("Unable to open vector map <%s>"), opt.vect->answer);
field = Vect_get_field_number(&Map, opt.field->answer);
@@ -192,9 +192,13 @@
vtype = Vect_option_to_types(opt.type);
/* Read vector points to cache */
- Cache_size = Vect_get_num_primitives(&Map, vtype);
- /* Note: Some space may be wasted (outside region or no category) */
+ if (open_level > 1) {
+ Cache_size = Vect_get_num_primitives(&Map, vtype);
+ /* Note: Some space may be wasted (outside region or no category) */
+ else {
+ Cache_size = 1000;
cache = (struct order *)G_calloc(Cache_size, sizeof(struct order));
point_cnt = outside_cnt = nocat_cnt = 0;
@@ -230,6 +234,14 @@
G_debug(4, " cat = %d", cat);
+ /* Resize cache on level 1 if needed */
+ if (open_level < 2) {
+ if (point_cnt >= Cache_size) {
+ Cache_size += 1000;
+ cache = (struct order *)G_realloc(cache, Cache_size * sizeof(struct order));
/* Add point to cache */
row = Rast_northing_to_row(Points->y[0], &window);
col = Rast_easting_to_col(Points->x[0], &window);
