[GRASS-SVN] r70385 - grass/trunk/lib/vector/Vlib
svn_grass at osgeo.org
Tue Jan 17 08:16:52 PST 2017
Author: martinl
Date: 2017-01-17 08:16:52 -0800 (Tue, 17 Jan 2017)
New Revision: 70385
grass/trunk/lib/vector/Vlib/open.c
v.external.out: SRID lost when not exactly defined (see #3262)
Modified: grass/trunk/lib/vector/Vlib/open.c
--- grass/trunk/lib/vector/Vlib/open.c 2017-01-17 15:05:44 UTC (rev 70384)
+++ grass/trunk/lib/vector/Vlib/open.c 2017-01-17 16:16:52 UTC (rev 70385)
@@ -1395,8 +1395,16 @@
/* srid (default: 0) */
p = G_find_key_value("srid", key_val);
- if (p)
+ if (p) {
pg_info->srid = atoi(p);
+ else {
+ /* not defined by v.external.out, so try if EPSG code
+ * is defined */
+ p = G_database_epsg_code();
+ if (p)
+ pg_info->srid = atoi(p);
G_debug(1, "PG: srid = %d", pg_info->srid);
/* table name */
