[GRASS-SVN] r70391 - grass/branches/releasebranch_7_2/raster/r.compress
Tue Jan 17 13:51:25 PST 2017
Author: mmetz
Date: 2017-01-17 13:51:25 -0800 (Tue, 17 Jan 2017)
New Revision: 70391
   grass/branches/releasebranch_7_2/raster/r.compress/main.c
   grass/branches/releasebranch_7_2/raster/r.compress/r.compress.html
r.compress: backport trunk r70337
Modified: grass/branches/releasebranch_7_2/raster/r.compress/main.c
--- grass/branches/releasebranch_7_2/raster/r.compress/main.c	2017-01-17 21:42:37 UTC (rev 70390)
+++ grass/branches/releasebranch_7_2/raster/r.compress/main.c	2017-01-17 21:51:25 UTC (rev 70391)
@@ -37,6 +37,7 @@
 #include <stdlib.h>
+#include <stdio.h>
 #include <limits.h>
 #include <string.h>
 #include <sys/types.h>
@@ -46,9 +47,12 @@
 #include <grass/glocale.h>
 static int process(char *, int);
-static int pprint(char *);
+static int pprint(char *, int);
 static int doit(char *, int, RASTER_MAP_TYPE);
+/* compressed null file, see lib/raster/open.c */
+#define NULLC_FILE "nullcmpr"
 int main(int argc, char *argv[])
     int stat;
@@ -56,7 +60,7 @@
     char *name;
     struct GModule *module;
     struct Option *map;
-    struct Flag *uncompress, *pflag;
+    struct Flag *uncompress, *pflag, *gflag;
     G_gisinit(argv[0]);
@@ -77,12 +81,16 @@
     pflag->key = 'p';
     pflag->description = _("Print compression information and data type of input map(s)");
+    gflag = G_define_flag();
+    gflag->key = 'g';
+    gflag->description = _("Print compression information in shell script style");
     if (G_parser(argc, argv))
 	exit(EXIT_FAILURE);
-    if (pflag->answer) {
+    if (pflag->answer || gflag->answer) {
         for (n = 0; (name = map->answers[n]); n++)
-            pprint(name);
+            pprint(name, gflag->answer);
         exit(EXIT_SUCCESS);
@@ -284,7 +292,7 @@
-static int pprint(char *name)
+static int pprint(char *name, int shell_style)
     struct Cell_head cellhd;
     char rname[GNAME_MAX], rmapset[GMAPSET_MAX];
@@ -323,19 +331,41 @@
     if (cellhd.compressed == 1 && map_type != CELL_TYPE)
 	cellhd.compressed = 2;
-    if (cellhd.compressed == 0) {
-        G_message(_("<%s> is uncompressed (method %i: %s). Data type: %s"), name, cellhd.compressed,
-                    "NONE",
-                     (map_type == CELL_TYPE ? "CELL" :
-                       (map_type == DCELL_TYPE ? "DCELL" :
-                         (map_type == FCELL_TYPE ? "FCELL" : "??"))));
+    if (!shell_style) {
+	if (cellhd.compressed == 0) {
+	    G_message(_("<%s> is uncompressed (method %i: %s). Data type: %s"), name, cellhd.compressed,
+			"NONE",
+			 (map_type == CELL_TYPE ? "CELL" :
+			   (map_type == DCELL_TYPE ? "DCELL" :
+			     (map_type == FCELL_TYPE ? "FCELL" : "??"))));
+	else if (cellhd.compressed > 0) {
+	    G_message(_("<%s> is compressed (method %i: %s). Data type: %s"), name, cellhd.compressed,
+			G_compressor_name(cellhd.compressed),
+	if (G_find_file2_misc("cell_misc", NULLC_FILE, name, G_mapset())) {
+	    G_message(_("<%s> has a compressed NULL file"), name);
+	} else {
+	    G_message(_("<%s> has an uncompressed NULL file"), name);
-    else if (cellhd.compressed > 0) {
-        G_message(_("<%s> is compressed (method %i: %s). Data type: %s"), name, cellhd.compressed,
-                    G_compressor_name(cellhd.compressed),
+    else {
+	fprintf(stdout, "%s|%s", name,
+	    fprintf(stdout, "|NONE");
+	else
+	    fprintf(stdout, "|%s", G_compressor_name(cellhd.compressed));
+	    fprintf(stdout, "|YES\n");
+	else
+	    fprintf(stdout, "|NO\n");
     return 0;
Modified: grass/branches/releasebranch_7_2/raster/r.compress/r.compress.html
--- grass/branches/releasebranch_7_2/raster/r.compress/r.compress.html	2017-01-17 21:42:37 UTC (rev 70390)
+++ grass/branches/releasebranch_7_2/raster/r.compress/r.compress.html	2017-01-17 21:51:25 UTC (rev 70391)
@@ -47,6 +47,14 @@
 module simply informs the user that the map is already decompressed and
 exits.
+<p>
+Information about the compression method and data type of the input
+raster map(s) can be printed in shell style with the <b>-g</b> flag. In
+this case, the module prints to <tt>stdout</tt> one line per input map
+with the fields "input map name", "data type",
+"name of data compression method", "NULL file
+compression" separated by the pipe character. NULL file
+compression is indicated with "YES" or "NO".
 <h3>TERMINOLOGY</h3>
