[GRASS-SVN] r70406 - grass/trunk/vector/v.db.select
svn_grass at osgeo.org
Sat Jan 21 13:19:05 PST 2017
Author: mmetz
Date: 2017-01-21 13:19:05 -0800 (Sat, 21 Jan 2017)
New Revision: 70406
grass/trunk/vector/v.db.select/main.c
v.db.select: fix #3236
Modified: grass/trunk/vector/v.db.select/main.c
--- grass/trunk/vector/v.db.select/main.c 2017-01-21 18:40:39 UTC (rev 70405)
+++ grass/trunk/vector/v.db.select/main.c 2017-01-21 21:19:05 UTC (rev 70406)
@@ -247,7 +247,7 @@
continue;
if (f_flag->answer) {
- Vect_cidx_find_all(&Map, field_number, -1, cat, list_lines);
+ Vect_cidx_find_all(&Map, field_number, ~GV_AREA, cat, list_lines);
/* if no features are found for this category, don't print
* anything. */
if (list_lines->n_values == 0)
@@ -276,7 +276,7 @@
if (r_flag->answer) {
/* get minimal region extent */
for (i = 0; i < list_lines->n_values; i++) {
line = list_lines->value[i];
if (Vect_get_line_type(&Map, line) == GV_CENTROID) {
