[GRASS-SVN] r70425 - grass/branches/releasebranch_7_2/vector/v.what.rast
Tue Jan 24 07:37:10 PST 2017
Author: martinl
Date: 2017-01-24 07:37:10 -0800 (Tue, 24 Jan 2017)
New Revision: 70425
   grass/branches/releasebranch_7_2/vector/v.what.rast/main.c
v.what.rast: segfault with map without topology (fix #3249)
             (merge r70331, r70332, r70366, r70381 from trunk)
Modified: grass/branches/releasebranch_7_2/vector/v.what.rast/main.c
--- grass/branches/releasebranch_7_2/vector/v.what.rast/main.c	2017-01-24 15:14:07 UTC (rev 70424)
+++ grass/branches/releasebranch_7_2/vector/v.what.rast/main.c	2017-01-24 15:37:10 UTC (rev 70425)
@@ -28,7 +28,7 @@
 int main(int argc, char *argv[])
-    int i, j, nlines, type, field, cat, vtype;
+    int i, j, type, field, cat, vtype, open_level;
     int fd;
     /* struct Categories RCats; */ /* TODO */
@@ -124,10 +124,10 @@
     Vect_region_box(&window, &box);	/* T and B set to +/- PORT_DOUBLE_MAX */
     /* Open vector */
-    Vect_set_open_level(2);
-    if (Vect_open_old2(&Map, opt.vect->answer,
-		   print_flag->answer ? "" : G_mapset(),
-		   opt.field->answer) < 0)
+    open_level = Vect_open_old2(&Map, opt.vect->answer,
+                                print_flag->answer ? "" : G_mapset(),
+                                opt.field->answer);
+    if (open_level < 0)
 	G_fatal_error(_("Unable to open vector map <%s>"), opt.vect->answer);
     field = Vect_get_field_number(&Map, opt.field->answer);
@@ -192,28 +192,33 @@
     vtype = Vect_option_to_types(opt.type);
     /* Read vector points to cache */
-    Cache_size = Vect_get_num_primitives(&Map, vtype);
-    /* Note: Some space may be wasted (outside region or no category) */
+    if (open_level > 1) {
+        Cache_size = Vect_get_num_primitives(&Map, vtype);
+        /* Note: Some space may be wasted (outside region or no category) */
+    else {
+        Cache_size = 1000;
     cache = (struct order *)G_calloc(Cache_size, sizeof(struct order));
     point_cnt = outside_cnt = nocat_cnt = 0;
-    nlines = Vect_get_num_lines(&Map);
-    G_debug(1, "Reading %d vector features fom map", nlines);
     G_important_message(_("Reading features from vector map..."));
-    for (i = 1; i <= nlines; i++) {
-	type = Vect_read_line(&Map, Points, Cats, i);
-	G_debug(4, "line = %d type = %d", i, type);
+    Vect_set_constraint_type(&Map, vtype);
+    i = 0;
+    while (TRUE) {
+        /* register line */
+        type = Vect_read_next_line(&Map, Points, Cats);
+        if (type == -1) {
+            G_fatal_error(_("Unable to read vector map"));
+        else if (type == -2) {
+            break;
-	G_percent(i, nlines, 2);
+        G_progress(++i, 1e4);
-	/* check type */
-	if (!(type & vtype))
-	    continue;		/* Points or centroids only */
-        G_debug(1, "line = %d type = %d", i, type);
+        G_debug(4, "line = %d type = %d", i, type);
 	/* check region */
 	if (!Vect_point_in_box(Points->x[0], Points->y[0], 0.0, &box)) {
@@ -229,6 +234,14 @@
 	G_debug(4, "    cat = %d", cat);
+        /* Resize cache on level 1 if needed */
+        if (open_level < 2) {
+            if (point_cnt >= Cache_size) {
+                Cache_size += 1000;
+                cache = (struct order *)G_realloc(cache, Cache_size * sizeof(struct order));
 	/* Add point to cache */
 	row = Rast_northing_to_row(Points->y[0], &window);
 	col = Rast_easting_to_col(Points->x[0], &window);
@@ -245,7 +258,8 @@
 	cache[point_cnt].count = 1;
 	point_cnt++;
+    G_progress(1, 1);
     if (!print_flag->answer) {
 	Vect_set_db_updated(&Map);
 	Vect_hist_command(&Map);
