[GRASS-SVN] r70433 - grass-addons/grass7/raster/r.category.trim
Wed Jan 25 05:03:18 PST 2017
Author: pvanbosgeo
Date: 2017-01-25 05:03:18 -0800 (Wed, 25 Jan 2017)
New Revision: 70433
   grass-addons/grass7/raster/r.category.trim/r.category.trim.html
   grass-addons/grass7/raster/r.category.trim/r.category.trim.py
r.category.trim addon: bug fix and small change help file
Modified: grass-addons/grass7/raster/r.category.trim/r.category.trim.html
--- grass-addons/grass7/raster/r.category.trim/r.category.trim.html	2017-01-25 09:38:32 UTC (rev 70432)
+++ grass-addons/grass7/raster/r.category.trim/r.category.trim.html	2017-01-25 13:03:18 UTC (rev 70433)
@@ -55,9 +55,14 @@
 <h2>NOTE</h2>
-The file is only useful for categorical maps.
-Therefore only integer maps are accepted as input.
+The file is only useful for categorical maps. Therefore only integer maps are
+accepted as input. To export color maps for continuous raster layers (or as an
+alternative to this plugin), have a look at the r.colors.out_sld plugin. To
+get QGIS color files, you need a two step approach: (1) create a sld file using
+the r.colors.out_sld plugin, and (2) in QGIS, use the SLD4raster plugin to
+convert this to a qml file.
 <p>When you use the option to recode the map, you need to set an
 output map as well. It uses the <em><a href="r.recode">r.recode </a></em>
 function, with the 'a' flag set, i.e., the region is
@@ -71,6 +76,8 @@
 <a href="r.category.html">r.category</a>,
 <a href="r.colors.html">r.colors</a>,
 <a href="r.recode.html">r.recode</a>
+<a href="https://grass.osgeo.org/grass70/manuals/addons/r.colors.out_sld.html">
+r.colors.out_sld</a>
 </em>
 <h2>AUTHOR</h2>
Modified: grass-addons/grass7/raster/r.category.trim/r.category.trim.py
--- grass-addons/grass7/raster/r.category.trim/r.category.trim.py	2017-01-25 09:38:32 UTC (rev 70432)
+++ grass-addons/grass7/raster/r.category.trim/r.category.trim.py	2017-01-25 13:03:18 UTC (rev 70433)
@@ -135,7 +135,7 @@
         RIDN = range(1, len(RID) + 1)
         RLAB = [z.split('\t')[1] for z in RCAT]
         for j in xrange(len(RID)):
-            RECO = '{0}{1}:{1}:{2}\n'.format(RECO, RID[j], RIDN[J])
+            RECO = '{0}{1}:{1}:{2}\n'.format(RECO, RID[j], RIDN[j])
             A = map(int, [i for i, x in enumerate(CCAT) if x == RIDI[j]])
             CV.append(RCOL[A[0]].split(' ')[1])
             CR = '{}{} {}\n'.format(CR, RIDN[j], CV[j])
