[GRASS-SVN] r70449 - in grass/trunk/gui/wxpython: docs lmgr xml
Sat Jan 28 18:57:21 PST 2017
Author: wenzeslaus
Date: 2017-01-28 18:57:21 -0800 (Sat, 28 Jan 2017)
New Revision: 70449
   grass/trunk/gui/wxpython/docs/wxGUI.html
   grass/trunk/gui/wxpython/lmgr/frame.py
   grass/trunk/gui/wxpython/xml/toolboxes.xml
   grass/trunk/gui/wxpython/xml/wxgui_items.xml
wxGUI: menu item and shortcut to re-render all map displays
Modified: grass/trunk/gui/wxpython/docs/wxGUI.html
--- grass/trunk/gui/wxpython/docs/wxGUI.html	2017-01-29 02:35:13 UTC (rev 70448)
+++ grass/trunk/gui/wxpython/docs/wxGUI.html	2017-01-29 02:57:21 UTC (rev 70449)
@@ -573,6 +573,8 @@
   <dd>Switch 'Layers' and 'Console' tab</dd>
   <dt>Ctrl+Q</dt>
   <dd>Quit</dd>
+  <dt>Ctrl+R</dt>
+  <dd>Render map in all map displays</dd>
 </dl>
 <b>Workspace</b>
Modified: grass/trunk/gui/wxpython/lmgr/frame.py
--- grass/trunk/gui/wxpython/lmgr/frame.py	2017-01-29 02:35:13 UTC (rev 70448)
+++ grass/trunk/gui/wxpython/lmgr/frame.py	2017-01-29 02:57:21 UTC (rev 70449)
@@ -840,6 +840,10 @@
             return mlist
+    def GetAllMapDisplays(self):
+        """Get all (open) map displays"""
+        return self.GetMapDisplay(onlyCurrent=False)
     def GetLogWindow(self):
         """Gets console for command output and messages"""
         return self._gconsole
@@ -1686,6 +1690,10 @@
         for display in self.GetMapDisplay(onlyCurrent=False):
             display.OnCloseWindow(event)
+    def OnRenderAllMapDisplays(self, event=None):
+        for display in self.GetAllMapDisplays():
+            display.OnRender(None)
     def OnRenameDisplay(self, event):
         """Change Map Display name"""
         name = self.notebookLayers.GetPageText(self.currentPageNum)
Modified: grass/trunk/gui/wxpython/xml/toolboxes.xml
--- grass/trunk/gui/wxpython/xml/toolboxes.xml	2017-01-29 02:35:13 UTC (rev 70448)
+++ grass/trunk/gui/wxpython/xml/toolboxes.xml	2017-01-29 02:57:21 UTC (rev 70449)
@@ -228,6 +228,7 @@
       <wxgui-item name="AddWebServiceLayer"/>
       <separator/>
       <wxgui-item name="NewMapDisplayWindow"/>
+      <wxgui-item name="RenderAllMapDisplays"/>
       <wxgui-item name="CloseCurrentMapDisplayWindow"/>
       <wxgui-item name="CloseAllOpenMapDisplayWindows"/>
     </items>
Modified: grass/trunk/gui/wxpython/xml/wxgui_items.xml
--- grass/trunk/gui/wxpython/xml/wxgui_items.xml	2017-01-29 02:35:13 UTC (rev 70448)
+++ grass/trunk/gui/wxpython/xml/wxgui_items.xml	2017-01-29 02:57:21 UTC (rev 70449)
@@ -194,6 +194,12 @@
     <handler>OnNewDisplay</handler>
     <description>Open new map display window</description>
   </wxgui-item>
+  <wxgui-item name="RenderAllMapDisplays">
+    <label>Render all map displays</label>
+    <handler>OnRenderAllMapDisplays</handler>
+    <description>Re-render maps in all open map display windows</description>
+    <shortcut>Ctrl+R</shortcut>
+  </wxgui-item>
   <wxgui-item name="CloseCurrentMapDisplayWindow">
     <label>Close current map display window</label>
     <handler>OnDisplayClose</handler>
