[GRASS-SVN] r71196 - grass/trunk/lib/python/ctypes/ctypesgencore/parser
Tue Jun 20 14:08:00 PDT 2017
Author: neteler
Date: 2017-06-20 14:08:00 -0700 (Tue, 20 Jun 2017)
New Revision: 71196
   grass/trunk/lib/python/ctypes/ctypesgencore/parser/lextab.py
   grass/trunk/lib/python/ctypes/ctypesgencore/parser/pplexer.py
python ctypesgencore: lexer support added for __FLT64X_EPSILON__ (trac #3331; contributed by glynn)
Modified: grass/trunk/lib/python/ctypes/ctypesgencore/parser/lextab.py
--- grass/trunk/lib/python/ctypes/ctypesgencore/parser/lextab.py	2017-06-20 19:30:17 UTC (rev 71195)
+++ grass/trunk/lib/python/ctypes/ctypesgencore/parser/lextab.py	2017-06-20 21:08:00 UTC (rev 71196)
@@ -1,59 +1,8 @@
 # lextab.py. This file automatically created by PLY (version 2.2). Don't edit!
-_lextokens = {
-    'RIGHT_OP': None,
-    'RIGHT_ASSIGN': None,
-    'DEC_OP': None,
-    'PP_MACRO_PARAM': None,
-    'DIV_ASSIGN': None,
-    'PP_DEFINE': None,
-    'PP_END_DEFINE': None,
-    'PP_DEFINE_MACRO_NAME': None,
-    'HEADER_NAME': None,
-    'NEWLINE': None,
-    'CHARACTER_CONSTANT': None,
-    'PP_STRINGIFY': None,
-    'AND_ASSIGN': None,
-    'PTR_OP': None,
-    'ELLIPSIS': None,
-    'IDENTIFIER': None,
-    'ADD_ASSIGN': None,
-    'PERIOD': None,
-    'AND_OP': None,
-    'OTHER': None,
-    'LPAREN': None,
-    'LEFT_OP': None,
-    'LE_OP': None,
-    'OR_OP': None,
-    'SUB_ASSIGN': None,
-    'MOD_ASSIGN': None,
-    'STRING_LITERAL': None,
-    'PP_IDENTIFIER_PASTE': None,
-    'PP_NUMBER': None,
-    'PP_DEFINE_NAME': None,
-    'XOR_ASSIGN': None,
-    'OR_ASSIGN': None,
-    'GE_OP': None,
-    'MUL_ASSIGN': None,
-    'LEFT_ASSIGN': None,
-    'INC_OP': None,
-    'NE_OP': None,
-    'EQ_OP': None}
-_lexreflags = 0
-_lexliterals = ''
+_lextokens    = {'RIGHT_OP': None, 'RIGHT_ASSIGN': None, 'DEC_OP': None, 'PP_MACRO_PARAM': None, 'DIV_ASSIGN': None, 'PP_DEFINE': None, 'PP_END_DEFINE': None, 'PP_DEFINE_MACRO_NAME': None, 'HEADER_NAME': None, 'NEWLINE': None, 'CHARACTER_CONSTANT': None, 'PP_STRINGIFY': None, 'AND_ASSIGN': None, 'PTR_OP': None, 'ELLIPSIS': None, 'IDENTIFIER': None, 'ADD_ASSIGN': None, 'PERIOD': None, 'AND_OP': None, 'OTHER': None, 'LPAREN': None, 'LEFT_OP': None, 'LE_OP': None, 'OR_OP': None, 'SUB_ASSIGN': None, 'MOD_ASSIGN': None, 'STRING_LITERAL': None, 'PP_IDENTIFIER_PASTE': None, 'PP_NUMBER': None, 'PP_DEFINE_NAME': None, 'XOR_ASSIGN': None, 'OR_ASSIGN': None, 'GE_OP': None, 'MUL_ASSIGN': None, 'LEFT_ASSIGN': None, 'INC_OP': None, 'NE_OP': None, 'EQ_OP': None}
+_lexreflags   = 0
+_lexliterals  = ''
 _lexstateinfo = {'INITIAL': 'inclusive', 'DEFINE': 'exclusive'}
-_lexstatere = {
-    'INITIAL': [
-        ('(?P<t_ANY_directive>\\#\\s+(\\d+)\\s+"([^"]+)"[ \\d]*\\n)|(?P<t_ANY_punctuator>(\\.\\.\\.|\\|\\||\\+\\+|\\*=|\\^=|<<=|>>=|\\|=|\\+=|>=|>>|<<|<=|<:|%=|:>|<%|!=|\\)|\\+|\\*|\\.|\\?|==|&=|&&|\\[|\\^|--|/=|%>|-=|->|\\||!|%|&|-|,|/|;|:|=|>|]|<|{|}|~))', [
-            None, ('t_ANY_directive', 'ANY_directive'), None, None, ('t_ANY_punctuator', 'ANY_punctuator')]), ('(?P<t_INITIAL_identifier>[a-zA-Z_]([a-zA-Z_]|[0-9])*)', [
-                None, ('t_INITIAL_identifier', 'INITIAL_identifier')]), ('(?P<t_ANY_float>(?P<p1>[0-9]+)?(?P<dp>[.]?)(?P<p2>(?(p1)[0-9]*|[0-9]+))(?P<exp>(?:[Ee][+-]?[0-9]+)?)(?P<suf>[FflL]?)(?!\\w))', [
-                    None, ('t_ANY_float', 'ANY_float'), None, None, None, None, None]), ('(?P<t_ANY_int>(?P<p1>(?:0x[a-fA-F0-9]+)|(?:[0-9]+))(?P<suf>[uUlL]*))', [
-                        None, ('t_ANY_int', 'ANY_int'), None, None]), ('(?P<t_ANY_character_constant>L?\'(\\\\.|[^\\\\\'])+\')|(?P<t_ANY_string_literal>L?"(\\\\.|[^\\\\"])*")|(?P<t_ANY_lparen>\\()|(?P<t_INITIAL_newline>\\n)|(?P<t_INITIAL_pp_define>\\#define)', [
-                            None, ('t_ANY_character_constant', 'ANY_character_constant'), None, ('t_ANY_string_literal', 'ANY_string_literal'), None, ('t_ANY_lparen', 'ANY_lparen'), ('t_INITIAL_newline', 'INITIAL_newline'), ('t_INITIAL_pp_define', 'INITIAL_pp_define')])], 'DEFINE': [
-                                    None, ('t_ANY_directive', 'ANY_directive'), None, None, ('t_ANY_punctuator', 'ANY_punctuator')]), ('(?P<t_DEFINE_identifier>[a-zA-Z_]([a-zA-Z_]|[0-9])*)', [
-                                        None, ('t_DEFINE_identifier', 'DEFINE_identifier')]), ('(?P<t_ANY_float>(?P<p1>[0-9]+)?(?P<dp>[.]?)(?P<p2>(?(p1)[0-9]*|[0-9]+))(?P<exp>(?:[Ee][+-]?[0-9]+)?)(?P<suf>[FflL]?)(?!\\w))', [
-                                                None, ('t_ANY_int', 'ANY_int'), None, None]), ('(?P<t_ANY_character_constant>L?\'(\\\\.|[^\\\\\'])+\')|(?P<t_ANY_string_literal>L?"(\\\\.|[^\\\\"])*")|(?P<t_ANY_lparen>\\()|(?P<t_DEFINE_newline>\\n)|(?P<t_DEFINE_pp_param_op>(\\#\\#)|(\\#))', [
-                                                    None, ('t_ANY_character_constant', 'ANY_character_constant'), None, ('t_ANY_string_literal', 'ANY_string_literal'), None, ('t_ANY_lparen', 'ANY_lparen'), ('t_DEFINE_newline', 'DEFINE_newline'), ('t_DEFINE_pp_param_op', 'DEFINE_pp_param_op')])]}
+_lexstatere   = {'INITIAL': [('(?P<t_ANY_directive>\\#\\s+(\\d+)\\s+"([^"]+)"[ \\d]*\\n)|(?P<t_ANY_punctuator>(\\.\\.\\.|\\|\\||\\+\\+|>>=|\\|=|\\^=|<<=|\\*=|\\+=|>=|>>|%=|:>|%>|!=|\\*|\\.|==|\\^|--|-=|->|\\||<<|<=|<:|<%|\\)|\\+|\\?|&=|&&|\\[|/=|&|,|:|<|>|~|!|%|-|/|;|=|]|{|}))', [None, ('t_ANY_directive', 'ANY_directive'), None, None, ('t_ANY_punctuator', 'ANY_punctuator')]), ('(?P<t_INITIAL_identifier>[a-zA-Z_]([a-zA-Z_]|[0-9])*)', [None, ('t_INITIAL_identifier', 'INITIAL_identifier')]), ('(?P<t_ANY_float>(?P<p1>[0-9]+)?(?P<dp>[.]?)(?P<p2>(?(p1)[0-9]*|[0-9]+))(?P<exp>(?:[Ee][+-]?[0-9]+)?)(?P<suf>([FfLl]|d[dfl]|D[DFL]|[fFdD][0-9]+x?)?)(?!\\w))', [None, ('t_ANY_float', 'ANY_float'), None, None, None, None, None]), ('(?P<t_ANY_int>(?P<p1>(?:0x[a-fA-F0-9]+)|(?:0[0-7]+)|(?:[1-9][0-9]+))(?P<suf>[uUlL]*))', [None, ('t_ANY_int', 'ANY_int'), None, None]), ('(?P<t_ANY_character_constant>L?\'(\\\\.|[^\\\\\'])+\')|(?P<t_ANY_string_literal>L?"(\\\\.|[^\\\\"])*")|(?P<t_ANY_lparen>\\()|(?P<t_INIT
 IAL_newline>\\n)|(?P<t_INITIAL_pp_define>\\#define)', [None, ('t_ANY_character_constant', 'ANY_character_constant'), None, ('t_ANY_string_literal', 'ANY_string_literal'), None, ('t_ANY_lparen', 'ANY_lparen'), ('t_INITIAL_newline', 'INITIAL_newline'), ('t_INITIAL_pp_define', 'INITIAL_pp_define')])], 'DEFINE': [('(?P<t_ANY_directive>\\#\\s+(\\d+)\\s+"([^"]+)"[ \\d]*\\n)|(?P<t_ANY_punctuator>(\\.\\.\\.|\\|\\||\\+\\+|>>=|\\|=|\\^=|<<=|\\*=|\\+=|>=|>>|%=|:>|%>|!=|\\*|\\.|==|\\^|--|-=|->|\\||<<|<=|<:|<%|\\)|\\+|\\?|&=|&&|\\[|/=|&|,|:|<|>|~|!|%|-|/|;|=|]|{|}))', [None, ('t_ANY_directive', 'ANY_directive'), None, None, ('t_ANY_punctuator', 'ANY_punctuator')]), ('(?P<t_DEFINE_identifier>[a-zA-Z_]([a-zA-Z_]|[0-9])*)', [None, ('t_DEFINE_identifier', 'DEFINE_identifier')]), ('(?P<t_ANY_float>(?P<p1>[0-9]+)?(?P<dp>[.]?)(?P<p2>(?(p1)[0-9]*|[0-9]+))(?P<exp>(?:[Ee][+-]?[0-9]+)?)(?P<suf>([FfLl]|d[dfl]|D[DFL]|[fFdD][0-9]+x?)?)(?!\\w))', [None, ('t_ANY_float', 'ANY_float'), None, None, None, None, Non
 e]), ('(?P<t_ANY_int>(?P<p1>(?:0x[a-fA-F0-9]+)|(?:0[0-7]+)|(?:[1-9][0-9]+))(?P<suf>[uUlL]*))', [None, ('t_ANY_int', 'ANY_int'), None, None]), ('(?P<t_ANY_character_constant>L?\'(\\\\.|[^\\\\\'])+\')|(?P<t_ANY_string_literal>L?"(\\\\.|[^\\\\"])*")|(?P<t_ANY_lparen>\\()|(?P<t_DEFINE_newline>\\n)|(?P<t_DEFINE_pp_param_op>(\\#\\#)|(\\#))', [None, ('t_ANY_character_constant', 'ANY_character_constant'), None, ('t_ANY_string_literal', 'ANY_string_literal'), None, ('t_ANY_lparen', 'ANY_lparen'), ('t_DEFINE_newline', 'DEFINE_newline'), ('t_DEFINE_pp_param_op', 'DEFINE_pp_param_op')])]}
 _lexstateignore = {'INITIAL': ' \t\x0b\x0c\r', 'DEFINE': ' \t\x0b\x0c\r'}
 _lexstateerrorf = {'INITIAL': 't_INITIAL_error', 'DEFINE': 't_DEFINE_error'}
Modified: grass/trunk/lib/python/ctypes/ctypesgencore/parser/pplexer.py
--- grass/trunk/lib/python/ctypes/ctypesgencore/parser/pplexer.py	2017-06-20 19:30:17 UTC (rev 71195)
+++ grass/trunk/lib/python/ctypes/ctypesgencore/parser/pplexer.py	2017-06-20 21:08:00 UTC (rev 71196)
@@ -52,7 +52,7 @@
     'L': '[a-zA-Z_]',
     'H': '[a-fA-F0-9]',
     'E': '[Ee][+-]?\s*{D}+',
-    'FS': '[FflL]',
+    'FS': '([FfLl]|d[dfl]|D[DFL]|[fFdD][0-9]+x?)',
     'IS': '[uUlL]*',
 # Helper: substitute {foo} with subs[foo] in string (makes regexes more lexy)
@@ -226,10 +226,10 @@
     exp = m.group("exp")
     suf = m.group("suf")
-    if dp or exp or (suf and suf in ("Ff")):
+    if dp or exp or (suf and suf not in ("Ll")):
         s = m.group(0)
         if suf:
-            s = s[:-1]
+            s = s[:-len(suf)]
         # Attach a prefix so the parser can figure out if should become an
         # integer, float, or long
         t.value = "f" + s
@@ -240,7 +240,7 @@
     return t
-INT_LITERAL = sub(r"(?P<p1>(?:0x{H}+)|(?:{D}+))(?P<suf>{IS})")
+INT_LITERAL = sub(r"(?P<p1>(?:0x{H}+)|(?:0[0-7]+)|(?:[1-9]{D}+))(?P<suf>{IS})")
 @TOKEN(INT_LITERAL)
