[GRASS-SVN] r71010 - in grass-addons/grass7/raster: . r.object.activelearning r.object.activelearning/examples
Wed May 3 01:09:28 PDT 2017
Author: mlennert
Date: 2017-05-03 01:09:28 -0700 (Wed, 03 May 2017)
New Revision: 71010
Added:
   grass-addons/grass7/raster/r.object.activelearning/
   grass-addons/grass7/raster/r.object.activelearning/Makefile
   grass-addons/grass7/raster/r.object.activelearning/examples/
   grass-addons/grass7/raster/r.object.activelearning/examples/test_set.csv
   grass-addons/grass7/raster/r.object.activelearning/examples/training_set.csv
   grass-addons/grass7/raster/r.object.activelearning/examples/unlabeled_set.csv
   grass-addons/grass7/raster/r.object.activelearning/examples/update.csv
   grass-addons/grass7/raster/r.object.activelearning/r.object.activelearning.html
   grass-addons/grass7/raster/r.object.activelearning/r.object.activelearning.py
   grass-addons/grass7/raster/r.object.activelearning/report.pdf
   grass-addons/grass7/raster/r.object.activelearning/tests.py
r.object.activelearning: New addon for active learning in OBIA classification
Added: grass-addons/grass7/raster/r.object.activelearning/Makefile
--- grass-addons/grass7/raster/r.object.activelearning/Makefile	                        (rev 0)
+++ grass-addons/grass7/raster/r.object.activelearning/Makefile	2017-05-03 08:09:28 UTC (rev 71010)
@@ -0,0 +1,7 @@
+MODULE_TOPDIR = ../..
+PGM = r.object.activelearning
+include $(MODULE_TOPDIR)/include/Make/Script.make
+default: script
Property changes on: grass-addons/grass7/raster/r.object.activelearning/Makefile
___________________________________________________________________
Added: svn:mime-type
   + text/x-makefile
Added: svn:eol-style
   + native
Added: grass-addons/grass7/raster/r.object.activelearning/examples/test_set.csv
--- grass-addons/grass7/raster/r.object.activelearning/examples/test_set.csv	                        (rev 0)
+++ grass-addons/grass7/raster/r.object.activelearning/examples/test_set.csv	2017-05-03 08:09:28 UTC (rev 71010)
@@ -0,0 +1,586 @@
+cat,Class_num,area,perimeter,compact,opt_blue_min,opt_blue_max,opt_blue_range,opt_blue_mean,opt_blue_stddev,opt_blue_sum,opt_blue_median,opt_green_min,opt_green_max,opt_green_range,opt_green_mean,opt_green_stddev,opt_green_sum,opt_green_median,opt_nir_min,opt_nir_max,opt_nir_range,opt_nir_mean,opt_nir_stddev,opt_nir_sum,opt_nir_median,opt_red_min,opt_red_max,opt_red_range,opt_red_mean,opt_red_stddev,opt_red_sum,opt_red_median,NDVI_min,NDVI_max,NDVI_range,NDVI_mean,NDVI_stddev,NDVI_sum,NDVI_median,Brightness_min,Brightness_max,Brightness_range,Brightness_mean,Brightness_stddev,Brightness_sum,Brightness_median,nDSM_min,nDSM_max,nDSM_range,nDSM_mean,nDSM_stddev,nDSM_sum,nDSM_median
+8284330,14,65.5000000005,79,2.7536041612,211,299,88,274.366412214,9.70260538463,71884,275.0,256,405,149,364.805343511,17.4674257924,95579,366.0,414,573,159,507.900763359,25.1767355844,133070,506.0,253,490,237,416.790076336,30.0336614077,109199,418.0,0.0347071588039,0.244776114821,0.210068956017,0.0992817132101,0.0242767080728,26.011808861,0.0948978,720,1194,474,1055.96183206,55.9704672099,276662,1060.0,-0.0765991210938,2.76522827148,2.84182739258,1.08530571625,0.633532538412,284.350097656,0.872681
+8515666,14,1978.25,1084,6.87517509279,234,497,263,292.083027929,8.65338885726,2311253,292.0,300,711,411,399.708328068,15.1841255026,3162892,400.0,409,875,466,562.920384178,34.2818762881,4454389,563.0,297,839,542,475.466321244,29.29565185,3762365,477.0,-0.019704433158,0.224056601524,0.243761034682,0.0842300451349,0.0154672125107,666.512347153,0.0837344,831,2047,1216,1167.25767724,50.2361233575,9236510,1170.0,-0.186492919922,6.29397583008,6.48046875,0.248186404314,0.415665583189,1963.89901733,0.121216
+8256300,33,167.999999997,141,3.06873608215,228,299,71,257.65625,9.78166361517,173145,256.0,295,423,128,345.980654762,17.5221266797,232499,343.0,480,876,396,651.886904762,59.1760816381,438068,647.0,251,459,208,343.961309524,28.8493365146,231142,338.0,0.107658155262,0.421166300774,0.313508145511,0.308219218394,0.0465597562978,207.123314761,0.315866,774,1175,401,947.598214286,54.7371902532,636786,938.0,-0.0359802246094,1.41625976562,1.45223999023,0.333480244591,0.317511336312,224.098724365,0.305527
+8239293,14,4116.50000059,2017,8.86822914564,223,558,335,281.424571845,8.9061697834,4633937,281.0,260,801,541,372.099356249,15.8255924912,6126988,371.0,301,940,639,475.685351634,32.3561845316,7832635,472.0,194,1071,877,411.357463865,29.4359067852,6773412,408.0,-0.0651417225599,0.216161623597,0.281303346157,0.0725920992167,0.0137671509996,1195.3015057,0.0715152,677,2430,1753,1064.88139196,51.710156865,17534337,1061.0,-0.221130371094,1.72109985352,1.94223022461,0.128343796912,0.228498795397,2113.30895996,0.0
+8234511,14,642.749999989,491,5.46330589194,233,374,141,295.529754959,15.9498493711,759807,293.0,279,541,262,403.04395177,30.7916552659,1036226,397.0,359,862,503,575.865810968,81.4965588915,1480551,558.0,255,688,433,468.769739401,54.7394226278,1205207,456.0,0.00698080286384,0.351102948189,0.344122145325,0.100890440083,0.0406861694589,259.389321454,0.0917226,767,1602,835,1167.34344613,98.4651676503,3001240,1146.0,-0.285858154297,6.58538818359,6.87124633789,0.232936092037,0.425419889849,598.878692627,0.0110474
+8234240,51,6.7499999993,20,2.17156671968,165,270,105,223.777777778,26.046018155,6042,219.0,249,355,106,291.074074074,32.4915099178,7859,279.0,465,679,214,551.0,63.4081429518,14877,548.0,189,353,164,266.37037037,51.0120887257,7192,258.0,0.252571433783,0.485013633966,0.232442200184,0.351696334503,0.0643248610218,9.49580103159,0.36345,603,970,367,781.222222222,103.441281728,21093,756.0,-0.0137023925781,2.7917175293,2.80541992188,2.27642822266,0.954904867082,61.4635620117,2.71484
+8183840,11,117.500000001,114,2.96675023897,287,440,153,349.212765957,30.8786479766,164130,343.0,400,637,237,506.874468085,48.8303095972,238231,505.0,462,893,431,663.927659574,65.3939866522,312046,669.0,442,852,410,627.314893617,62.716644025,294838,633.5,-0.0260869562626,0.122835941613,0.148922897875,0.0284261982167,0.0234602566043,13.3603131619,0.02713,1151,1923,772,1483.40212766,125.107502691,697199,1493.5,-0.0140991210938,3.51824951172,3.53234863281,0.909411750956,0.930856813677,427.423522949,0.499725
+8203600,41,13622.25,1146,2.7698436973,222,332,110,254.589238195,5.4836924361,13872313,254.0,284,466,182,354.905393749,9.29918071478,19338440,354.0,276,600,324,355.183156233,20.6658020619,19353575,350.0,249,548,299,325.560057993,16.3914540206,17739442,323.0,-0.0607407391071,0.219321146607,0.280061885715,0.0433205364114,0.0196030252647,2360.49270852,0.0402385,777,1331,554,935.054689937,29.1166595657,50950195,932.0,-0.716766357422,0.0729675292969,0.789733886719,-1.84682621937e-05,0.00322933339756,-1.00631713867,0.0
+8428393,14,13268.0000015,7629,18.6835737831,198,538,340,311.945036931,11.9635748427,16555547,312.0,247,807,560,440.223620742,18.434079069,23363548,441.0,410,1187,777,677.460129635,38.3294155869,35954164,675.0,227,1201,974,567.598639584,33.2382830009,30123595,567.0,-0.0058626467362,0.341333329678,0.347195976414,0.0883036914292,0.0152950092086,4686.45351153,0.0869183,708,2524,1816,1319.76729726,55.1182298259,70042690,1320.0,-0.198486328125,4.81948852539,5.01797485352,0.175506877008,0.38979291725,9314.50097656,0.0
+8200161,13,11.0,17,1.44593125942,276,339,63,309.5,17.9018790278,13618,310.5,298,374,76,329.886363636,14.2768342383,14515,327.5,211,452,241,294.522727273,56.2637815991,12959,289.0,213,416,203,291.727272727,38.5317835962,12836,291.0,-0.0929368063807,0.0877742916346,0.180711098015,0.000148121873446,0.0495255840338,0.00651736243162,0.00166691,836,1099,263,931.113636364,50.2313809509,40969,929.5,-0.0273742675781,0.642211914062,0.669586181641,0.187499306419,0.246331031403,8.24996948242,0.0964355
+8202143,13,2.75,7,1.19076691953,417,530,113,496.181818182,36.8555366059,5458,511.0,464,589,125,541.818181818,40.2058751515,5960,543.0,251,398,147,316.909090909,48.4682736821,3486,309.0,254,392,138,340.272727273,40.5352616621,3743,358.0,-0.134281203151,0.0459921173751,0.180273320526,-0.037413561632,0.0488853657803,-0.411549177952,-0.0315186,1135,1466,331,1378.27272727,105.119058828,15161,1422.0,2.44213867188,2.70700073242,0.264862060547,2.52004450018,0.114655669584,27.720489502,2.45776
+8204204,14,859.249999963,625,6.01471861876,246,330,84,301.371254001,6.22164279539,1035813,302.0,325,455,130,417.697410532,11.091904627,1435626,418.0,470,714,244,599.868489962,26.7190174583,2061748,600.0,349,599,250,509.802443992,22.109501204,1752191,512.0,0.0335305705667,0.191335737705,0.157805167139,0.0811338874687,0.0114352133961,278.85717123,0.0808356,920,1374,454,1228.87110852,34.5714606167,4223630,1232.0,-0.107421875,4.96087646484,5.06829833984,0.0849719565033,0.279536825919,292.048614502,0.0
+8186401,13,67.5000000042,73,2.50649037749,238,448,210,332.214814815,27.5816324243,89698,336.0,272,562,290,350.966666667,34.8022296008,94761,346.0,167,689,522,284.188888889,75.2488554525,76731,262.0,193,716,523,282.359259259,66.0246349045,76237,265.0,-0.209138840437,0.200828149915,0.409966990352,7.42857788551e-05,0.0676728185075,0.0200571602909,-0.00173616,728,1710,982,965.540740741,114.001251648,260696,946.5,-0.0601806640625,1.94281005859,2.00299072266,0.234210544162,0.570089912767,63.2368469238,0.0
+8213654,11,1081.25000001,465,3.98919219487,282,532,250,365.800231214,23.6910529185,1582086,362.0,417,824,407,568.705202312,40.5857605741,2459650,563.0,556,1102,546,817.009710983,61.2855112905,3533567,809.0,428,1076,648,754.532254335,66.0559663752,3263352,747.0,-0.0223713647574,0.243147656322,0.265519021079,0.040250789097,0.0173868471523,174.084662844,0.0386885,1151,2412,1261,1689.03768786,124.608491028,7305088,1670.0,-0.0203552246094,8.62744140625,8.64779663086,5.94368802638,2.54492197942,25706.4507141,7.07816
+8170911,31,55.0000000009,45,1.71169442833,194,362,168,251.231818182,36.0545784051,55271,240.0,144,465,321,320.85,50.7653268392,70587,321.5,434,1052,618,870.390909091,121.57972285,191486,896.0,59,379,320,271.090909091,56.6986524539,59640,279.5,0.404059052467,0.76953125,0.365472197533,0.528644341501,0.0652692649072,116.30175513,0.530256,510,1085,575,843.172727273,101.635029671,185498,847.5,-0.0164489746094,3.28073120117,3.29718017578,0.175775978782,0.712158856087,38.670715332,0.0
+8169524,13,36.5000000026,43,2.00778447295,361,577,216,445.321917808,33.7851663429,65017,451.0,459,721,262,532.020547945,40.1673671779,77675,523.5,222,609,387,320.595890411,57.6564671333,46807,310.5,252,640,388,330.993150685,68.5642880582,48325,302.5,-0.218884125352,0.113402061164,0.332286186516,-0.0136996178229,0.0722723466858,-2.00014420215,-0.00892887,1155,1938,783,1308.33561644,122.005012102,191017,1266.5,0.215576171875,1.32110595703,1.10552978516,0.471352146096,0.151831228302,68.8174133301,0.497269
+8108343,51,8.5,22,2.12866973727,252,327,75,284.647058824,19.7497317226,9678,281.5,345,500,155,397.794117647,35.5120355835,13525,396.5,542,896,354,669.205882353,89.8507846088,22753,674.5,350,653,303,450.117647059,66.8830255023,15304,445.0,0.124060153961,0.258955985308,0.134895831347,0.196320411914,0.0343526350283,6.67489400506,0.19991,951,1480,529,1132.55882353,117.417853933,38507,1124.0,-0.0187072753906,0.424407958984,0.443115234375,0.0849573471967,0.112552079299,2.88854980469,0.00279236
+8118362,34,4739.49999998,2158,8.84260538812,198,358,160,247.971199494,10.8924294466,4701038,248.0,252,470,218,364.40231037,20.2492754534,6908339,364.0,645,1222,577,961.044150227,56.0257192148,18219475,960.0,138,564,426,325.523578437,31.3606706513,6171276,324.0,0.272964179516,0.685522556305,0.412558376789,0.494190575965,0.036846863609,9368.86493915,0.494418,617,1327,710,937.8970883,59.7721013038,17780653,936.0,-0.299255371094,1.63586425781,1.93511962891,0.063235103713,0.164745612703,1198.81109619,0.0
+8093176,13,7.0,12,1.27946171174,332,439,107,404.285714286,29.0773072329,11320,414.0,389,494,105,434.75,27.9854873104,12173,431.0,276,460,184,340.321428571,51.1482813365,9529,334.0,218,344,126,256.214285714,29.6784639847,7174,249.0,0.0437956191599,0.267062306404,0.223266687244,0.138298970913,0.0514635611845,3.87237118557,0.141212,1016,1220,204,1095.25,47.9021510105,30667,1084.0,3.34997558594,10.4725952148,7.12261962891,7.87665230887,3.00721810182,220.546264648,10.4123
+8200921,34,7382.74999997,3636,11.937403158,90,525,435,258.423554908,15.5369639733,7631506,257.0,83,763,680,368.332972131,26.4168074425,10877241,366.0,396,1442,1046,883.317801632,59.5311119001,26085258,879.0,51,750,699,345.661779147,40.8354475057,10207738,344.0,0.182125926018,0.809345781803,0.627219855785,0.438229395747,0.0446198042732,12941.3522858,0.437202,406,2021,1615,972.418306187,79.8029212265,28716485,968.0,-0.130493164062,4.92196655273,5.0524597168,0.115058823745,0.412192555316,3397.80212402,0.0
+8088130,11,149.250000003,64,1.47780751959,272,452,180,381.323283082,14.4306001856,227650,381.0,461,791,330,591.199329983,28.6188865885,352946,589.0,596,1072,476,767.621440536,51.5187829916,458270,765.0,518,1035,517,752.400335008,53.3562553328,449183,744.0,-0.0310641117394,0.224550902843,0.255615014583,0.0101726416432,0.0202602818247,6.07306706096,0.00557276,1300,2278,978,1724.92294807,89.6608392209,1029779,1716.0,0.314727783203,5.28884887695,4.97412109375,4.18545930949,0.802486355763,2498.71920776,4.16818
+8071409,32,1404.5,577,4.34320180738,185,452,267,270.62246351,25.9932839215,1520357,266.0,247,672,425,394.226771093,46.8645425618,2214766,386.0,487,1275,788,904.155215379,98.740675576,5079544,905.0,150,805,655,390.776076896,73.308807503,2195380,380.0,0.170278638601,0.651778936386,0.481500297785,0.399102205519,0.0645084196716,2242.1561906,0.396848,624,1839,1215,1055.6253115,143.292001771,5930503,1031.0,-0.106140136719,3.97747802734,4.08361816406,0.143951106386,0.426413174013,808.717315674,0.0
+8027910,12,3.5,9,1.35707407896,179,239,60,205.928571429,17.0145495961,2883,206.5,233,332,99,276.714285714,27.9219027479,3874,276.0,620,810,190,706.571428571,50.8523272198,9892,700.0,128,293,165,203.714285714,46.2577075762,2852,204.0,0.468721657991,0.657754004002,0.18903234601,0.557938066976,0.0572202163686,7.81113293767,0.551445,540,864,324,686.357142857,91.096971208,9609,685.0,0.877258300781,0.906402587891,0.0291442871094,0.887656075614,0.00858967353516,12.4271850586,0.88652
+8184384,14,1392.75,823,6.22097304576,229,425,196,313.299407647,16.861236853,1745391,314.0,281,639,358,442.273918507,31.0429086783,2463908,442.0,388,972,584,681.268533477,82.656033018,3795347,665.0,270,806,536,533.433315383,58.7152708669,2971757,526.0,-0.00652376515791,0.312072902918,0.318596668076,0.12100857373,0.0337871229364,674.138764249,0.117037,798,1839,1041,1289.00664154,99.4871707193,7181056,1284.0,-0.353149414062,8.34725952148,8.70040893555,0.326443980485,0.934039608837,1818.61941528,0.0
+8032004,51,220.499999996,219,4.16039806709,216,632,416,339.74829932,43.3461797082,299658,338.0,260,821,561,478.523809524,70.5669621361,422058,478.0,267,1118,851,763.073696145,133.223390938,673031,769.0,106,980,874,589.510204082,124.174546196,519948,598.0,-0.0477272719145,0.468671679497,0.516398951411,0.132768077146,0.0578408243262,117.101444043,0.129192,756,2293,1537,1407.78231293,210.728049602,1241664,1402.0,-0.353149414062,4.26095581055,4.61410522461,0.703008465756,1.2288452508,620.053466797,0.00231934
+8025309,34,126.0,69,1.73403910089,248,313,65,268.44047619,8.54820763327,135294,268.0,324,439,115,355.494047619,13.364248545,179169,354.0,699,851,152,751125,19.836790665,378567,751.0,362,560,198,409.563492063,23.8769983064,206420,408.5,0.204545453191,0.345388799906,0.140843346715,0.294734526633,0.0196433787365,148.546201423,0.294996,948,1312,364,1033.49801587,43.7407586162,520883,1029.0,-0.018798828125,0.902069091797,0.920867919922,0.199416145446,0.169238531812,100.505737305,0.189575
+8022598,13,2.75,7,1.19076691953,348,406,58,378.818181818,20.6697767144,4167,384.0,425,510,85,469.636363636,30.5413958342,5166,480.0,152,207,55,176.727272727,19.3206950237,1944,180.0,264,364,100,315.636363636,36.199630152,3472,308.0,-0.396825402975,-0.168141588569,0.228683814406,-0.28041993488,0.0670913896792,-3.08461928368,-0.282869,1037,1280,243,1164.09090909,86.503236456,12805,1172.0,0.0,0.0,0.0,0.0,0.0,0.0,0.0
+7993005,13,51.4999999998,86,3.38056977893,200,350,150,287.451456311,27.2354899966,59215,292.5,268,484,216,363.242718447,34.270473583,74828,366.0,244,706,462,367.194174757,86.9952635975,75642,343.0,197,512,315,282.067961165,65.0283376819,58106,262.5,0.00959232635796,0.309090912342,0.299498585984,0.129295252689,0.0597607969177,26.6348220538,0.119252,680,1319,639,932.762135922,107.584181189,192149,921.0,-0.066162109375,2.09188842773,2.15805053711,0.072732573574,0.3099288849,14.9829101562,0.0
+7980331,51,10.4999999998,33,2.87285931095,245,354,109,278.857142857,24.4087917695,11712,274.5,293,462,169,357.952380952,41.9954376099,15034,345.0,443,817,374,590.214285714,105.59503409,24789,585.5,252,486,234,339.738095238,63.1615689074,14269,317.0,0.206530615687,0.356345176697,0.149814561009,0.269310280326,0.034743995402,11.3110317737,0.267304,800,1302,502,976.547619048,126.477779411,41015,927.0,0.106994628906,3.19537353516,3.08837890625,1.73024640765,0.896723528292,72.6703491211,2.20653
+7971690,22,1023.0,489,4.31286744348,243,452,209,358.344819159,26.7184848758,1466347,361.0,342,694,352,572.570136852,47.7983322376,2342957,579.0,796,1303,507,1075.62927664,63.6402105281,4401475,1078.0,444,940,496,741.100195503,77.3593810202,3032582,752.0,0.096739128232,0.334140449762,0.23740132153,0.185772849917,0.0381531459135,760.18250186,0.180365,1070,2054,984,1672.01515152,146.713951761,6841886,1693.5,-0.119750976562,0.650573730469,0.770324707031,0.0418365418853,0.0890168522908,171.195129395,0.0
+7952065,21,786.249999984,445,4.47687274499,246,420,174,318.442289348,21.4197639558,1001501,318.0,346,622,276,475.716375199,38.1083594628,1496128,476.0,525,1087,562,871.846104928,66.8281842116,2741956,871.0,337,788,451,606.434976153,63.0087256496,1907238,608.0,0.0682004913688,0.357859522104,0.289659030735,0.180559592899,0.0312451328069,567.859919667,0.175523,980,1773,793,1400.5936407,117.838703957,4404867,1403.0,-0.0765991210938,3.353515625,3.43011474609,0.152016741293,0.559244991369,478.092651367,0.0
+7916244,13,66.7500000021,53,1.8299756146,277,439,162,360.38576779,23.335468007,96223,360.0,241,378,137,324.992509363,19.204398784,86773,328.0,137,526,389,232.580524345,42.2840855448,62099,232.0,157,450,293,230.172284644,24.8856617492,61456,228.0,-0.258666664362,0.257683217525,0.516349881887,0.000194787809953,0.071531496979,0.0520083452575,0.00205339,675,1199,524,915.550561798,51.6354285443,244452,916.0,-3.0517578125e-05,1.13900756836,1.13903808594,0.197348262487,0.317972348365,52.691986084,0.0
+7922381,41,1366.00000001,928,7.08300738375,191,354,163,240.171120059,13.3711176324,1312295,238.0,244,512,268,309.696010249,24.5530250327,1692179,305.0,410,980,570,563.878843338,67.1530421879,3081034,550.5,198,636,438,296.849560761,40.3996287541,1621986,288.0,0.111289031804,0.487889260054,0.37660022825,0.309876529733,0.0603291767567,1693.16535846,0.311414,647,1502,855,846.716691069,75.8953214889,4626460,831.0,-0.305511474609,4.50430297852,4.80981445312,0.229214675255,0.622236720001,1252.4289856,0.0
+7898172,11,13.2500000002,15,1.16246099054,324,419,95,375.603773585,19.3891037506,19907,374.0,453,615,162,547.41509434,32.0468018375,29013,544.0,609,772,163,681.037735849,36.7623485936,36095,680.0,599,717,118,647.698113208,24.3470078016,34328,646.0,-0.0145631069317,0.0831460654736,0.0977091724053,0.0246935212229,0.0242134029992,1.30875662481,0.0212454,1389,1702,313,1570.71698113,59.9582802623,83248,1573.0,0.554260253906,1.08419799805,0.529937744141,0.724161399985,0.168929206792,38.3805541992,0.64035
+7891273,13,7.25,15,1.57151063269,334,562,228,473.310344828,56.1574777459,13726,485.0,333,524,191,449.896551724,44.4121331881,13047,462.0,124,244,120,168.206896552,29.4529189588,4878,166.0,177,308,131,240.482758621,28.5495584719,6974,242.0,-0.347417831421,0.0899742916226,0.437392123044,-0.179301419392,0.0930313193382,-5.19974116236,-0.19598,844,1359,515,1163.68965517,119.90861562,33747,1182.0,5.97183227539,6.29638671875,0.324554443359,6.09763309873,0.0794493505333,176.831359863,6.07367
+7759696,41,3500.99999995,1207,5.7544826198,238,320,82,292.805555556,8.31195856736,4100449,293.0,325,488,163,436.594044559,17.1115456498,6114063,438.0,288,594,306,388.87517852,30.7000300659,5445808,381.0,310,504,194,428.9527992,20.1968317038,6007055,431.0,-0.221621617675,0.250526309013,0.472147926688,-0.0498193922022,0.0509369717617,-697.670768399,-0.0634518,905,1289,384,1158.35239931,41.1473219932,16221567,1161.5,-0.276885986328,4.13702392578,4.41390991211,0.405214023672,0.809606928818,5674.6171875,0.0
+7933150,32,390.499999991,225,3.21193736021,225,385,160,291.149807939,19.9484120995,454776,289.0,314,507,193,410.225992318,30.7483406245,640773,409.0,749,1141,392,935.656209987,53.967531762,1461495,936.0,278,608,330,428.31049936,54.1553960304,669021,425.0,0.233620122075,0.489439845085,0.25581972301,0.373859766952,0.0434762044231,583.968955979,0.376292,834,1461,627,1129.68629962,99.922820046,1764570,1122.5,-0.0556945800781,1.27340698242,1.3291015625,0.217415783988,0.252749830498,339.60345459,0.142242
+7795112,41,647.749999998,624,6.91633382501,194,403,209,248.236974141,18.7388819256,643182,245.0,250,600,350,332.819374759,32.869750249,862335,326.0,291,1032,741,569.829023543,112.63038888,1476427,552.0,184,860,676,335.774218448,57.0643022222,869991,326.0,0.0341463424265,0.453093826771,0.418947484344,0.254449023688,0.0628828726297,659.277420375,0.257944,667,1863,1196,916.830567349,106.025951359,2375508,898.0,-0.571136474609,2.19058227539,2.76171875,0.0507944416972,0.170628321261,131.608398438,0.0
+7810274,21,4773.74999996,2742,11.1952212973,255,440,185,384.214401676,14.738204642,7336574,386.0,380,677,297,595.557475779,24.911684458,11372170,597.0,737,1152,415,1006.22833202,34.7366725767,19213930,1006.0,416,888,472,763.369311338,37.0579990396,14576537,764.0,0.0914893597364,0.278404176235,0.186914816499,0.137514062101,0.0131004816035,2625.83101582,0.135463,1051,1996,945,1743.14118879,74.5833286818,33285281,1746.0,-0.128173828125,1.16549682617,1.2936706543,0.0639032204571,0.115911378846,1220.23199463,0.0
+7775600,32,1574.75,622,4.42160196083,243,414,171,309.188283855,20.0193774019,1947577,309.0,325,607,282,470.200031751,35.1833109457,2961790,471.0,683,1245,562,988.120495317,66.2099610103,6224171,995.0,308,771,463,507.063819654,56.0830671541,3193995,506.0,0.184318318963,0.485193610191,0.300875291228,0.322921670016,0.0382995796473,2034.08359943,0.321764,905,1763,858,1286.45213526,108.931691449,8103362,1286.0,-0.0805053710938,0.838928222656,0.91943359375,0.0627573427841,0.109704929451,395.308502197,0.0
+7775597,31,80.7499999991,84,2.63695724651,195,273,78,238.544891641,14.2485781238,77050,239.0,253,405,152,328.479876161,26.0622391038,106099,329.0,827,1273,446,1081.32817337,84.5531912315,349269,1086.0,172,387,215,282.975232198,41.0816525098,91401,283.0,0.441130310297,0.694444417953,0.253314107656,0.585782990459,0.0474912471353,189.207905918,0.591209,627,1064,437,850.0,79.8067712856,274550,851.0,-0.268005371094,0.960998535156,1.22900390625,0.104676332267,0.215361015237,33.8104553223,0.0
+7758798,12,2.75000000023,8,1.3608764794,161,203,42,175.454545455,12.1158321394,1930,171.0,191,253,62,210.636363636,17.5357957399,2317,207.0,428,555,127,495.454545455,42.4999756927,5450,509.0,137,238,101,190.454545455,27.0667983006,2095,182.0,0.379200011492,0.558064520359,0.178864508867,0.445610956712,0.0531814924022,4.90172052383,0.429967,492,694,202,576.545454545,54.6798344687,6342,569.0,3.73669433594,3.88513183594,0.1484375,3.81043035334,0.0493149792685,41.9147338867,3.81091
+7735553,51,98.9999999991,118,3.34548801202,189,364,175,248.502525253,29.4827889133,98407,246.0,226,614,388,345.939393939,70.2711297792,136992,340.0,436,1264,828,777.537878788,172.950921629,307905,777.5,135,624,489,302.982323232,75.7513688956,119981,297.5,0.221459761262,0.669117629528,0.447657868266,0.437235484144,0.0854479591515,173.145251721,0.444489,566,1558,992,897.424242424,159.976140324,355380,886.0,0.874176025391,4.10272216797,3.22854614258,2.18682537657,1.16668143938,865.982849121,1.99234
+7744494,11,429.249999993,332,4.52041179847,185,495,310,340.170646476,41.6538904934,584073,340.0,221,762,541,498.80314502,76.6209781596,856445,510.0,383,1043,660,687.196272568,90.1558569463,1179916,697.0,200,969,769,621.743156669,110.506267942,1067533,631.0,-0.060734461993,0.32939440012,0.390128862113,0.0541151785075,0.04626494931,92.9157614974,0.0437853,637,2196,1559,1460.71694817,214.886732414,2508051,1505.0,-0.0478210449219,6.87399291992,6.92181396484,3.26894325785,1.93993550456,5612.77557373,3.10822
+7746585,13,11.7499999998,21,1.72820568497,407,514,107,482.255319149,20.6103342031,22666,486.0,513,646,133,598.404255319,25.5589927335,28125,602.0,153,402,249,263.425531915,51.9192272345,12381,272.0,249,421,172,305.744680851,34.6130390418,14370,304.0,-0.251833736897,0.042990654707,0.294824391603,-0.0807326412661,0.0710257378472,-3.79443413951,-0.0632258,1185,1560,375,1386.40425532,63.8597730985,65161,1390.0,1.13903808594,1.17419433594,0.03515625,1.15574353807,0.00824525054869,54.3199462891,1.15466
+7734109,51,10.5000000005,30,2.6116902826,204,302,98,253.404761905,27.69825465,10643,262.0,260,437,177,345.69047619,47.9451512496,14519,361.0,486,723,237,623.904761905,70.3598943947,26204,636.5,280,608,328,422.357142857,86.063880325,17739,445.5,0.0857142880559,0.30607187748,0.220357589424,0.199199403681,0.0500735869452,8.36637495458,0.191507,752,1345,593,1021.45238095,160.937906154,42901,1077.0,-0.0054931640625,0.609100341797,0.614593505859,0.242366972424,0.17915282611,10.1794128418,0.162216
+7733424,51,16.2500000012,44,3.07908063104,230,351,121,275.169230769,26.7757463335,17886,269.0,292,472,180,364.784615385,37.432808443,23711,359.0,402,632,230,538.692307692,51.9555795706,35015,550.0,262,518,256,407.923076923,55.8790748484,26515,409.0,0.0725156664848,0.210843369365,0.13832770288,0.140478744759,0.0302279303275,9.13111840934,0.13986,786,1288,502,1047.87692308,108.554489358,68112,1037.0,-0.00311279296875,3.07482910156,3.07794189453,1.38581636869,1.29821222414,90.0780639648,2.2381
+7725131,31,239.750000007,220,4.0080990076,167,282,115,235.897810219,15.5740347467,226226,237.0,206,404,198,304.788321168,29.0533296493,292292,306.0,436,1015,579,753.382690302,102.543831025,722494,752.0,118,419,301,270.297184567,44.8387250514,259215,269.0,0.332720577717,0.691906034946,0.35918545723,0.471972374741,0.0519543959724,452.621507376,0.471799,521,1071,550,810.983315954,86.0422679858,777733,812.0,-0.139892578125,6.06829833984,6.20819091797,1.26000613788,2.03445760827,1208.34588623,0.0
+7844608,14,4826.24999994,2787,11.3168909073,188,422,234,289.377622378,15.1521389866,5586435,289.0,219,638,419,409.39000259,24.4260770196,7903274,408.0,379,971,592,663.921108521,45.4117236952,12816997,671.0,219,956,737,557.821341621,41.5163122859,10768741,563.0,-0.0182815361768,0.28664496541,0.304926501587,0.0871058732212,0.0177199222952,1681.57888253,0.0851735,638,2016,1378,1256.58896659,70.7415926586,24258450,1257.0,-0.3544921875,4.02841186523,4.38290405273,0.554444257276,0.889812745766,10703.5463867,0.0674133
+7678771,11,102.500000001,64,1.78325359932,627,867,240,789.670731707,38.3211254475,323765,794.0,925,1297,372,1192.54146341,61.9704846174,488942,1202.0,1142,1579,437,1397.06097561,57.1509655854,572795,1401.0,997,1482,485,1324.33414634,62.6916422241,542977,1328.5,-0.0202131569386,0.110359407961,0.1305725649,0.026871840206,0.0159864437647,11.0174544844,0.0281544,2630,3633,1003,3306.54634146,154.453684111,1355684,3330.0,-0.0231323242188,5.4670715332,5.49020385742,4.46155410394,1.33712892666,1829.23718262,4.88478
+7722750,34,1301.0,914,7.1482974446,185,309,124,240.351652575,11.1525519512,1250790,241.0,237,488,251,356.960415065,23.8826631645,1857622,359.0,736,1331,595,1052.90295926,74.7517927137,5479307,1053.0,164,536,372,293.868562644,29.9849247828,1529292,295.0,0.421500384808,0.69415807724,0.272657692432,0.563505362608,0.0352710744147,2932.48190701,0.562248,604,1333,729,891.180630284,61.2736428,4637704,896.0,-0.382843017578,4.63046264648,5.01330566406,0.268720487555,0.933173679654,1398.42141724,0.0
+7665070,41,578.249999989,563,6.6045866465,191,357,166,250.643752702,21.2160815209,579739,248.0,224,526,302,337.065715521,40.2691228241,779633,336.0,332,1187,855,711.389537397,111.763983819,1645444,721.0,161,641,480,336.115002162,64.0097924355,777434,332.0,0.140333667397,0.57238304615,0.432049378753,0.358478062386,0.0673347181016,829.1597583,0.351575,592,1514,922,923.824470385,122.270993024,2136806,916.0,-0.909423828125,4.22009277344,5.12951660156,0.392309596219,0.724429622638,907.412096056,0.0
+7655364,33,24.4999999991,28,1.59576912164,260,374,114,293.142857143,15.9046906186,28728,290.0,380,559,179,422.56122449,25.6161087418,41411,420.0,405,667,262,495.255102041,65.2077232224,48535,483.0,403,734,331,466.897959184,55.1558996041,45756,447.0,-0.0641169846058,0.145315483212,0.209432467818,0.0283057962732,0.0477595879359,2.77396803477,0.0299505,1062,1667,605,1182.60204082,92.7976446521,115895,1158.0,0.0,0.303436279297,0.303436279297,0.0465044294085,0.08879924426,4.55743408203,0.0
+7652115,51,14.7499999995,29,2.13008559663,214,370,156,280.915254237,31.0250244188,16574,281.0,264,523,259,385.559322034,51.3552833208,22748,392.0,516,830,314,693.0,84.014526589,40887,705.0,282,699,417,474.101694915,88.2284582467,27972,489.0,0.0592193827033,0.342713564634,0.283494181931,0.192066649891,0.0550925600123,11.3319323435,0.193338,760,1592,832,1140.57627119,168.968576297,67294,1162.0,0.119506835938,1.10144042969,0.98193359375,0.644338834084,0.333300662364,38.0159912109,0.773865
+7649841,11,66.7500000012,76,2.62411597568,282,417,135,336.344569288,24.1243889232,89804,337.0,402,607,205,495.808988764,39.9074424656,132381,496.0,547,889,342,748.528089888,58.6877262378,199857,750.0,477,842,365,663.097378277,67.1045767838,177047,662.0,-0.021428572014,0.157243818045,0.178672390059,0.0614992963876,0.0246655543524,16.4203121355,0.0572049,1171,1854,683,1495.25093633,126.038193297,399232,1494.0,-0.1591796875,3.02981567383,3.18899536133,2.09228321318,1.04366020898,558.63961792,2.48279
+7653073,11,171.999999999,107,2.30151930575,193,472,279,348.177325581,39.4139179444,239546,342.0,251,710,459,518.034883721,70.5330324518,356408,506.0,394,989,595,787.255813953,88.4000632756,541632,785.0,223,966,743,686.611918605,103.541274928,472389,677.5,-0.0337500013411,0.306376367807,0.340126369148,0.0712254366795,0.0351208337719,49.0031004355,0.0731167,667,2115,1448,1552.82412791,207.418825953,1068343,1523.0,-0.0015869140625,9.87780761719,9.87939453125,3.5683692666,3.40469194509,2455.03805542,1.00777
+7640578,13,18.5000000005,25,1.63964267226,350,523,173,461.216216216,38.2679988637,34130,473.0,432,668,236,566.864864865,51.4679969638,41948,577.5,100,372,272,223.27027027,62.969597404,16522,210.5,206,449,243,310.5,56.6414159428,22977,292.5,-0.459340661764,-0.0284167788923,0.430923882872,-0.173147997139,0.103465217091,-12.8129517883,-0.151605,1124,1619,495,1338.58108108,117.027717525,99055,1331.0,-0.030517578125,0.0,0.030517578125,-0.0011547191723,0.00458879372997,-0.08544921875,0.0
+7650403,14,736.000000015,298,3.09864929003,288,359,71,320.152173913,10.6521364795,942528,320.0,378,514,136,440.563179348,17.2317784259,1297018,440.0,468,643,175,556.279211957,23.2436621195,1637686,557.0,405,583,178,496.705842391,25.4212422643,1462302,498.0,0.0225303284824,0.121475055814,0.0989447273314,0.0567888103093,0.0107934970507,167.18625755,0.0563854,1086,1441,355,1257.42119565,50.919219237,3701848,1257.0,-0.0523376464844,1.09625244141,1.14859008789,0.0576415683912,0.136594590462,169.696777344,0.0
+7625021,34,207.000000007,140,2.74497207666,191,283,92,237.178743961,11.873403574,196384,237.0,249,414,165,346.513285024,24.3963560938,286913,348.0,674,1354,680,1090.71859903,91.8501551808,903115,1102.0,163,429,266,279.93236715,29.8050876846,231784,279.0,0.436069995165,0.696726799011,0.260656803846,0.590876936553,0.0380410497554,489.246103466,0.592289,611,1125,514,863.624396135,63.4217364253,715081,864.0,-0.159576416016,3.10238647461,3.26196289062,0.783169179723,1.06995030432,648.464080811,0.258133
+7596192,13,6.75,12,1.30294003174,246,306,60,282.259259259,18.3799258302,7621,290.0,246,335,89,300.814814815,26.3397137658,8122,310.0,220,351,131,288.703703704,34.9992749288,7795,287.0,190,276,86,241.555555556,22.7324752743,6522,247.0,-0.0434782616794,0.193347200751,0.236825462431,0.0873024083881,0.063609181929,2.35716502648,0.101083,686,896,210,824.62962963,64.3854987976,22265,856.0,2.08685302734,4.17782592773,2.09097290039,2.55789862739,0.856151904842,69.0632629395,2.09592
+7609075,14,10358.7500011,4713,13.0628768269,213,1094,881,299.852491855,15.2236283978,12424388,300.0,259,1783,1524,412.986702063,25.5027487465,17112104,412.0,376,2172,1796,574.128031857,43.4270850058,23788995,571.0,198,2726,2528,494.979847955,45.9185048831,20509490,492.0,-0.147023081779,0.310104519129,0.457127600908,0.0743906522373,0.0162997443614,3082.37667545,0.0730479,713,5603,4890,1207.81904187,82.5186345225,50045982,1204.0,-0.464752197266,4.55847167969,5.02322387695,0.691716538682,0.86516036731,28661.2747803,0.385345
+8053772,14,3428.75000003,2509,12.0872587477,229,411,182,291.061465549,7.77836059294,3991908,291.0,296,583,287,391.684943493,13.3671714159,5371959,392.0,367,757,390,502.012686839,31.1444692551,6885104,501.0,291,783,492,450.282172803,27.7386059167,6175620,449.0,-0.02137767151,0.164835169911,0.186212841421,0.0542970375874,0.0119223491309,744.683870512,0.0538462,827,1768,941,1133.02858184,45.7857082773,15539487,1132.0,-0.299133300781,8.01989746094,8.31903076172,2.3067145236,2.02969508586,31636.5896912,2.34338
+7601964,14,5104.99999862,1977,7.80555636455,200,1027,827,300.792360431,13.3639325006,6142180,301.0,259,1599,1340,421.331341822,21.6562700478,8603586,421.0,452,1939,1487,625.964201763,42.766552392,12782189,625.0,294,2498,2204,537.551762977,39.6773299699,10976807,535.0,-0.125986024737,0.243718594313,0.36970461905,0.0760233348495,0.0173160153921,1552.39649763,0.074199,774,5124,4350,1259.67546523,69.401604298,25722573,1254.0,-0.357055664062,1.60101318359,1.95806884766,0.141139264532,0.197221870251,2882.06378174,0.0115051
+7584792,14,9358.2499993,4164,12.1425099321,207,603,396,301.958218684,10.4715301668,11303202,302.0,259,909,650,419.527342185,17.3282460962,15704167,419.0,375,1047,672,592.074880453,37.0587106912,22163139,587.0,238,1179,941,510.109155024,33.590970081,19094916,506.0,-0.0664605870843,0.249211356044,0.315671943128,0.0744563585044,0.0156958773309,2787.1248679,0.0733032,714,2691,1977,1231.59471589,56.6407387063,46102285,1227.0,-0.233154296875,5.35003662109,5.58319091797,0.996919875262,0.932332497748,37317.7016907,0.839478
+7573622,11,354.500000013,240,3.59582203924,401,889,488,699.81100141,52.6611794641,992332,703.5,550,1343,793,1032.79830748,83.7701550004,1464508,1047.0,585,1481,896,1149.96121298,80.1838370236,1630645,1157.0,440,1530,1090,1133.96050776,95.3404329667,1607956,1143.0,-0.0831275731325,0.158019796014,0.241147369146,0.00767305727953,0.0227692156739,10.8803952224,0.00472103,1391,3651,2260,2866.56981664,205.145054443,4064796,2894.0,-0.00668334960938,8.53890991211,8.54559326172,6.96849718618,1.5559516678,9881.32901001,7.22028
+7537202,31,16.4999999993,18,1.25004486664,211,260,49,236.196969697,10.7057329544,15589,237.0,258,347,89,308.0,20.4480124247,20328,309.5,625,1102,477,948.257575758,116.366233596,62585,975.5,186,349,163,274.181818182,39.0803015911,18096,278.5,0.462882101536,0.647851705551,0.184969604015,0.550573706175,0.0445470263782,36.3378646076,0.555227,655,926,271,818.378787879,64.2232765204,54013,822.5,-0.0015869140625,0.0352783203125,0.036865234375,0.00106210419626,0.00595099227787,0.0700988769531,0.0
+7540178,51,5.25000000047,16,1.96986016975,276,345,69,311.857142857,20.4200781545,6549,305.0,323,403,80,361.761904762,23.0649285649,7597,356.0,369,438,69,402.904761905,17.1406083181,8461,402.0,224,287,63,249.428571429,15.2176946773,5238,247.0,0.199417755008,0.285053938627,0.0856361836195,0.235594235715,0.0217420759372,4.94747895002,0.234104,844,1001,157,923.047619048,41.1911643213,19384,914.0,0.0,0.0732116699219,0.0732116699219,0.00578090122768,0.0182315334372,0.121398925781,0.0
+7544985,14,6358.0000006,3729,13.1925026334,196,980,784,295.614933941,12.0138296634,7518079,296.0,248,1558,1310,402.383414596,20.3101969977,10233415,403.0,261,1863,1602,544.096610569,32.8253823461,13837465,542.0,90,2446,2356,471.291365209,34.5281460061,11985882,470.0,-0.135298207402,0.487179487944,0.622477695346,0.0720057158471,0.0160949379929,1831.24936542,0.0703422,579,4984,4405,1169.28971375,63.1298484692,29737376,1170.0,-0.439880371094,2.17199707031,2.61187744141,0.0942601938599,0.173016829922,2397.22525024,0.0
+7530772,11,9.5,19,1.73894908458,512,699,187,616.473684211,43.3472738426,23426,622.0,852,1143,291,1013.44736842,68.1599115735,38511,1019.5,1308,1619,311,1481.52631579,79.7650288898,56298,1463.0,1126,1407,281,1280.18421053,69.1740197896,48647,1267.5,0.0489853061736,0.101715199649,0.0527298934758,0.0729022871115,0.0135649594456,2.77028691024,0.0735454,2492,3231,739,2910.10526316,168.706189553,110584,2923.0,3.47497558594,4.21063232422,0.735656738281,3.72184994346,0.219877954678,141.430297852,3.74219
+7517599,11,123.249999999,59,1.49917943331,305,384,79,357.732251521,9.49908260765,176362,359.0,443,587,144,544.776876268,17.8458270296,268575,548.0,579,919,340,729.407707911,34.1938469581,359598,727.0,536,752,216,701.894523327,25.2963977429,346034,707.0,-0.0271460022777,0.150031387806,0.177177390084,0.0190066336331,0.0255095273571,9.3702703811,0.0136986,1284,1701,417,1604.40365112,50.190927019,790971,1614.0,-0.0523376464844,3.55029296875,3.60263061523,2.19155945691,1.00538876892,1080.43881226,2.43539
+7498669,13,6.25,19,2.14392041748,447,540,93,497.12,23.6378002361,12428,499.0,497,594,97,548.12,26.3595447609,13703,551.0,187,423,236,262.48,46.2948118043,6562,257.0,267,384,117,309.04,30.1827500404,7726,312.0,-0.207627117634,0.0483271367848,0.255954254419,-0.0857014116831,0.0695759580728,-2.14253529208,-0.0873016,1234,1485,251,1354.28,72.2548379003,33857,1365.0,4.07183837891,4.10699462891,0.03515625,4.08793212891,0.0109553425894,102.198303223,4.08356
+7488343,11,210.250000001,96,1.86766206967,379,579,200,523.737217598,30.4582700255,440463,534.0,514,850,336,779.738406659,45.6881645751,655760,793.0,653,1254,601,890.699167658,65.0830155821,749078,879.0,450,994,544,862.724137931,56.6672075701,725551,872.0,-0.045014243573,0.207456409931,0.252470653504,0.0158398483614,0.0371777733356,13.3213124719,0.00478469,1344,2384,1040,2166.19976219,124.437017291,1821774,2198.0,0.00119018554688,4.51718139648,4.51599121094,3.57675856727,0.443657649895,3008.05395508,3.52493
+7493926,12,3.0,11,1.79154254364,174,282,108,224.0,31.8381322735,2688,217.0,208,375,167,279.833333333,51.5522927607,3358,264.5,447,789,342,660.25,94.6195231792,7923,683.0,185,466,281,296.166666667,86.7562037487,3554,273.0,0.208156332374,0.523353278637,0.315196946263,0.390717420727,0.0795218815994,4.68860904872,0.409406,567,1123,556,800.0,169.606407112,9600,753.0,2.86700439453,2.97817993164,0.111175537109,2.92679595947,0.0322224733017,35.1215515137,2.93204
+7502545,21,279.500000007,270,4.55583436333,235,554,319,301.814847943,24.7417190123,337429,299.0,297,855,558,424.10822898,43.7137368679,474153,418.0,408,1273,865,682.089445438,79.3294181191,762576,678.5,290,1155,865,531.281753131,67.2849270067,593973,527.0,0.017479300499,0.268170416355,0.250691115856,0.124458679155,0.0368666095367,139.144803295,0.122458,840,2550,1710,1257.20483005,131.973157181,1405555,1241.0,-0.061767578125,4.58660888672,4.64837646484,0.971519210897,1.48658391281,1086.15847778,0.0885468
+7511275,21,2355.25000005,1826,10.6139572712,252,456,204,339.407281605,22.0408914984,3197556,340.0,371,695,324,520.821781127,37.1515081518,4906662,523.0,608,1283,675,943.068782507,67.1374149316,8884651,946.0,367,892,525,663.079927821,60.1948740786,6246876,668.0,0.0598958320916,0.354415267706,0.294519435614,0.175015894679,0.0277045852413,1648.82474377,0.171517,990,2035,1045,1523.30899055,114.397910916,14351094,1531.0,-0.238372802734,4.66220092773,4.90057373047,0.0979630907887,0.50683643343,922.91027832,0.0
+7524073,32,393.499999995,230,3.27077399139,229,296,67,252.575603558,8.30564875586,397554,252.0,304,419,115,345.666454892,14.4580602955,544079,344.0,580,824,244,696.48094028,35.4215396193,1096261,698.0,264,501,237,337.778907243,24.7495852355,531664,335.0,0.225656881928,0.432258069515,0.206601187587,0.347197551209,0.0228234073234,546.488945603,0.348554,799,1216,417,936.020965693,46.158119409,1473297,932.0,-0.0789489746094,1.06658935547,1.14553833008,0.0552270341578,0.129907196628,86.9273517644,0.0
+7502725,21,1292.74999999,1092,8.56762467877,218,425,207,321.333397795,19.8171940517,1661615,320.0,287,674,387,483.499903307,33.5500640464,2500178,482.0,498,1163,665,847.278282731,70.2625797998,4381276,852.0,337,997,660,723.447108876,64.1801942053,3740945,726.0,-0.0370844006538,0.215686276555,0.252770677209,0.0790780258471,0.0212720540751,408.912471655,0.0780452,858,2089,1231,1528.28040998,109.446819708,7902738,1531.0,-0.465667724609,6.32836914062,6.79403686523,4.02109080978,1.43998867508,20793.0605774,4.68042
+7446241,31,72.5000000009,52,1.7227783617,192,258,66,233.010344828,12.6369694323,67573,234.0,242,369,127,322.651724138,22.8887733464,93569,326.5,707,1129,422,985.489655172,76.1731346651,285792,1000.5,172,338,166,267.024137931,30.6928516352,77437,271.0,0.5,0.66571700573,0.16571700573,0.574007369527,0.032542908924,166.462137163,0.572621,610,958,348,822.686206897,64.5515149753,238579,833.5,-0.199371337891,0.830505371094,1.02987670898,0.0982184048357,0.224907353474,28.4833374023,0.0
+7415780,22,145.500000001,155,3.62489365065,264,401,137,336.443298969,21.8602885284,195810,338.0,384,606,222,510.525773196,34.2720346609,297126,513.0,768,1116,348,950.750859107,62.5777711949,553337,949.0,478,786,308,677.335051546,52.7539784488,394209,683.5,0.103123158216,0.284431129694,0.181307971478,0.168212256161,0.0325041924282,97.8995330855,0.164718,1155,1791,636,1524.30412371,101.968959381,887145,1527.0,-0.208618164062,1.09091186523,1.2995300293,0.0894682579434,0.173120983437,52.070526123,0.0
+7514849,31,408.249999996,186,2.59683834601,187,307,120,245.738518065,16.0075637972,401291,247.0,232,451,219,351.365584813,34.2469932961,573780,356.0,523,1315,792,1000.25535824,113.548381113,1633417,1005.0,144,470,326,303.535211268,48.2812883831,495673,308.0,0.37207749486,0.721739113331,0.349661618471,0.534014566939,0.0578770949845,872.045787811,0.528105,568,1227,659,900.639314146,96.8895007511,1470744,913.0,-0.118011474609,1.08044433594,1.19845581055,0.0776551451628,0.218601649475,126.810852051,0.0
+7378314,32,209.000000011,205,4.00014547674,214,340,126,280.295454545,17.3641005787,234327,281.0,277,477,200,388.096889952,29.1830379372,324449,388.0,599,1024,425,816.777511962,62.5593365915,682826,817.0,300,616,316,442.752392344,53.5959514425,370141,440.0,0.186781615019,0.458972036839,0.27219042182,0.298094081661,0.0490674349718,249.206652269,0.294115,811,1412,601,1111.14473684,93.4609754477,928917,1106.0,-0.108642578125,1.1233215332,1.23196411133,0.0915597797011,0.13369102288,76.5439758301,0.0124664
+7392776,14,2401.25000001,1098,6.32089708264,244,328,84,286.502654867,5.27772353143,2751858,286.0,319,454,135,388.433628319,9.20182030547,3730905,387.0,430,644,214,527.658198855,21.7335213847,5068157,525.0,329,553,224,450.704528891,19.9587535458,4329017,449.0,0.0360721461475,0.15302491188,0.116952765733,0.0787158958738,0.010592023254,756.066179868,0.0782422,912,1335,423,1125.64081208,32.1913474843,10811780,1122.0,-0.463317871094,1.99862670898,2.46194458008,0.530692162184,0.464979589315,5097.29821777,0.497681
+7425321,21,9087.24999993,8083,23.9194620835,204,557,353,356.778700927,25.664058927,12968549,357.0,262,923,661,539.674846626,43.2130531315,19616641,540.0,442,1401,959,927.626784781,79.7101272893,33718306,931.0,141,1218,1077,761.987867617,73.4652081119,27697497,765.0,-0.0422857142985,0.516295015812,0.55858073011,0.0985332013227,0.0273147573952,3581.58333488,0.0968085,623,2698,2075,1658.44141517,133.858833511,60282687,1662.0,-0.389129638672,3.93872070312,4.3278503418,0.65062962493,0.729410029447,23649.7362366,0.37384
+7339573,11,15.7499999998,19,1.35054291796,399,643,244,536.603174603,60.5783081515,33806,539.0,597,966,369,797.650793651,80.909739781,50252,804.0,855,1258,403,1028.96825397,82.3852676485,64825,1028.0,761,1229,468,977.380952381,101.054822238,61575,987.0,-0.0219780225307,0.0718662962317,0.0938443187624,0.0268130836272,0.0233665404481,1.68922426851,0.028028,1757,2832,1075,2311.63492063,232.16744789,145633,2353.0,3.08190917969,4.23220825195,1.15029907227,3.28235008603,0.316374554179,206.78805542,3.14828
+7333710,11,177.000000002,77,1.63267280912,254,476,222,357.224576271,28.0061356366,252915,357.0,354,739,385,535.155367232,51.4525576773,378890,542.0,511,1046,535,787.426553672,69.3483507964,557498,778.0,391,1068,677,710.100282486,87.2995838739,502751,720.0,-0.0423685535789,0.203665986657,0.246034540236,0.0535669957241,0.0420974023932,37.9254329727,0.0374296,1002,2224,1222,1602.48022599,160.861666029,1134556,1622.5,0.700744628906,4.91702270508,4.21627807617,4.14623208773,0.621929272312,2935.53231812,4.19072
+7533729,21,11143.4999994,8733,23.3371447233,185,718,533,301.516354826,20.7148840276,13439790,298.0,240,1213,973,423.719993718,34.5117084669,18886895,419.0,307,2010,1703,645.389330103,52.5167630372,28767584,649.0,139,1864,1725,551.976668013,52.9782173941,24603808,555.0,-0.0640301331878,0.376681625843,0.440711759031,0.078641674322,0.0223150136865,3505.37399123,0.0784721,564,3795,3231,1277.21301656,99.2098502747,56930493,1275.0,-0.334197998047,7.06103515625,7.3952331543,0.917629441005,1.30037221312,40902.4147034,0.0929108
+7367815,14,2110.49999996,1698,10.4265366863,208,1215,1007,299.211442786,23.6545049551,2525943,297.0,271,1959,1688,406.573916134,37.947619693,3432297,403.0,309,2718,2409,559.899668325,61.8013263205,4726673,551.0,182,3151,2969,482.571783937,63.9474721871,4073871,478.0,-0.073777474463,0.258655816317,0.33243329078,0.0748833523713,0.024577162466,632.165260719,0.0709921,732,6325,5593,1188.35714286,120.024658,10032111,1179.0,-0.221923828125,4.06060791016,4.28253173828,0.585945760207,1.02779248366,4946.55410767,0.0
+7325646,11,184.250000007,150,3.11732856243,193,352,159,268.769335142,22.1984630054,198083,268.0,255,497,242,357.153324288,38.232483052,263222,353.0,331,855,524,565.962008141,89.3778810011,417114,556.0,196,610,414,379.610583446,65.9964560276,279773,380.0,0.0494665391743,0.430985927582,0.381519388407,0.19807486409,0.058900185359,145.981174834,0.186441,666,1447,781,1005.53324288,123.375024992,741078,1001.0,2.09527587891,5.70764160156,3.61236572266,3.11773209591,0.901546654416,2297.76855469,2.65637
+7259752,41,230.499999999,252,4.68230978889,203,313,110,250.003253796,17.7053795959,230503,249.0,249,443,194,333.893709328,32.0244209878,307850,332.0,419,819,400,569.8329718,72.6094676429,525386,563.0,222,538,316,352.249457701,53.0092349087,324774,345.5,0.140369966626,0.413625299931,0.273255333304,0.236860785948,0.0478214029042,218.385644644,0.23028,679,1294,615,936.146420824,100.039846905,863127,924.5,-0.189117431641,1.11172485352,1.30084228516,0.0832457304518,0.186324220646,76.7525634766,0.0
+7302125,13,3.5,8,1.20628807018,355,412,57,381.642857143,16.3384172291,5343,380.0,408,455,47,429.857142857,15.4358448464,6018,426.5,110,282,172,192.571428571,47.0147610342,2696,197.0,211,259,48,230.928571429,15.1018650017,3233,225.0,-0.359580039978,0.0503282286227,0.409908268601,-0.10349260377,0.128052448181,-1.44889645278,-0.0769923,996,1112,116,1042.42857143,30.4037457413,14594,1038.0,3.70959472656,3.74423217773,0.0346374511719,3.73002842494,0.00997673269132,52.2203979492,3.73021
+7258686,34,68.5,44,1.49969332589,205,267,62,241.00729927,9.50642990267,66036,242.0,283,384,101,346.448905109,17.7613729034,94927,347.5,891,1186,295,1047.05839416,60.146447362,286894,1048.0,210,355,145,297.569343066,25.6249751634,81534,298.5,0.483724445105,0.636363625526,0.152639180422,0.55740124009,0.030220278178,152.727939785,0.557066,698,996,298,885.025547445,50.9822790584,242497,887.5,-0.0398864746094,1.13333129883,1.17321777344,0.311778270415,0.359146778093,85.4272460938,0.0463257
+7482341,21,5941.75,4276,15.6486031558,218,762,544,312.286784197,20.3419636331,7422120,310.0,278,1174,896,452.500946691,34.664347976,10754590,451.0,332,1557,1225,722.243741322,61.3217361535,17165567,726.0,172,1655,1483,588.758993563,55.4185114128,13993035,592.0,-0.0305105857551,0.317460328341,0.347970914096,0.102181462389,0.0234707948924,2428.54681661,0.100372,732,3591,2859,1353.54672445,103.395897255,32169745,1354.0,-0.411529541016,8.49758911133,8.90911865234,0.577038525682,1.04053897849,13714.4746399,0.0371704
+7277291,11,151.249999998,86,1.97263088086,260,597,337,381.823140496,46.1057009801,231003,377.0,349,933,584,570.233057851,71.1577474551,344991,569.0,421,1340,919,760.241322314,93.4855163303,459946,758.0,310,1288,978,726.090909091,114.203037982,439285,726.0,-0.185072347522,0.232695132494,0.417767480016,0.0252479918799,0.0472543858549,15.2750350874,0.0141224,940,2811,1871,1678.14710744,201.883920118,1015279,1699.0,3.67730712891,4.68740844727,1.01010131836,4.09820581862,0.162978597343,2479.41452026,4.11066
+7484433,14,3814.99999997,3035,13.8613807242,211,1001,790,299.311009174,19.8543945346,4567486,299.0,263,1590,1327,418.946330275,33.1983820648,6393121,419.0,380,2135,1755,614.365072084,55.3780556011,9375211,613.0,230,2514,2284,525.918348624,56.6711330161,8025514,526.0,-0.081522911787,0.270998418331,0.352521330118,0.078219053635,0.0217322988191,1193.62275847,0.0755627,704,5105,4401,1244.17568807,103.947826281,18986121,1244.0,-0.926574707031,5.81680297852,6.74337768555,0.769292166974,1.28191812007,11739.398468,0.0
+7252739,41,306.999999998,202,3.2522000316,233,295,62,257.850162866,8.22804204348,316640,257.0,303,419,116,341.054560261,15.692778907,418815,338.5,256,639,383,357.712540717,59.516985825,439271,340.0,234,398,164,297.998371336,23.6921075099,365942,296.0,-0.100175745785,0.292537301779,0.392713047564,0.0858820963347,0.076898374854,105.463214299,0.0841223,770,1108,338,896.903094463,46.8583827722,1101397,892.0,0.0,0.0,0.0,0.0,0.0,0.0,0.0
+7273622,13,4.5,11,1.46278836147,317,353,36,337.333333333,9.48097510222,6072,338.0,342,396,54,373.888888889,16.9275872432,6730,377.5,183,241,58,213.5,16.3375844808,3843,216.0,204,264,60,233.0,15.3911951742,4194,234.0,-0.109489053488,0.0163934417069,0.125882495195,-0.0440229239692,0.0346411933897,-0.792412631446,-0.0464055,876,996,120,944.222222222,35.8555056295,16996,958.0,3.38403320312,4.16903686523,0.785003662109,3.5282151964,0.162134307843,63.5078735352,3.4837
+7254759,41,237.999999997,201,3.67538337792,235,281,46,252.478991597,5.13715046981,240360,253.0,305,395,90,341.415966387,8.31656222603,325028,342.0,216,520,304,305.667016807,38.204110226,290995,300.0,245,378,133,298.598739496,12.7164750582,284266,299.0,-0.207339450717,0.248466253281,0.455805703998,0.00843145206956,0.0666166531361,8.02674237022,0.00413299,785,1054,269,892.493697479,24.6312289436,849654,894.0,-0.109405517578,1.28576660156,1.39517211914,0.18190204396,0.289875250749,173.17074585,0.0363922
+7432375,11,13347.2499999,9779,23.8777618625,204,694,490,304.241697728,20.7863638024,16243160,302.0,260,1047,787,431.724718575,35.461643043,23049351,429.0,341,1385,1044,683.536159134,63.7155558469,36493312,691.0,217,1514,1297,563.018280919,59.1540209102,30058983,570.0,-0.0444981046021,0.308474570513,0.352972675115,0.0972602453745,0.0268732411967,5192.6272403,0.0961689,691,3227,2536,1298.98469722,106.499129888,69351494,1303.0,-0.308074951172,7.4453125,7.75338745117,1.18858461756,1.55051017342,63457.3441467,0.215149
+7229810,34,1084.5,672,5.75638142176,212,368,156,262.21230982,18.0858912192,1137477,260.0,280,541,261,362.482710927,31.4321636803,1572450,358.0,557,1098,541,796.802443522,76.7890983666,3456529,791.0,216,593,377,355.050714615,52.0765095785,1540210,346.0,0.196380093694,0.57746475935,0.381084665656,0.384006869304,0.0624439160697,1665.82179904,0.38613,708,1464,756,979.745735362,97.8189897687,4250137,965.0,-0.171905517578,1.16635131836,1.33825683594,0.0868916069653,0.214810743534,376.935791016,0.0
+7215134,41,80.0,52,1.64003613931,236,287,51,246.371875,5.9829828668,78839,246.0,300,387,87,317.803125,10.2811412418,101697,317.0,238,478,240,306.65,34.1789774569,98128,300.5,255,392,137,290.9875,15.7374900715,93116,289.0,-0.120147876441,0.14769230783,0.267840184271,0.0238848527672,0.0566734607077,7.64315288549,0.0197757,796,1066,270,855.1625,31.2576765571,273652,852.0,-0.0609741210938,1.11233520508,1.17330932617,0.0549410820007,0.104073178874,17.5811462402,0.0
+7216142,34,8589.49999998,1406,4.2795336606,180,302,122,238.246172653,12.4828817785,8185662,239.0,208,433,225,308.205250597,25.2540341902,10589316,309.0,476,1207,731,857.487688457,94.4142616638,29461562,860.0,105,474,369,266.058705396,37.5415444404,9141245,267.0,0.292531132698,0.727520406246,0.434989273548,0.525985918502,0.0507887205485,18071.8241879,0.527273,508,1207,699,812.510128645,73.9261194209,27916223,815.0,-0.181274414062,16.2574462891,16.4387207031,6.93609623937,5.01135926115,238310.394592,9.53433
+7189244,33,1610.99999999,866,6.08646585255,210,350,140,269.662942272,15.7207450045,1737708,268.0,305,528,223,393.638268156,27.1575220899,2536605,390.0,723,1112,389,890.823867163,58.1693746458,5740469,883.0,234,637,403,406.342333954,43.8726976125,2618470,402.0,0.219358891249,0.522448956966,0.303090065718,0.37447786324,0.0352358781233,2413.13535072,0.374016,749,1500,751,1069.64354438,84.4417736184,6892783,1060.0,-0.181549072266,5.54486083984,5.72640991211,0.0892991646708,0.472663597686,575.443817139,0.0
+7226962,41,1402.74999999,883,6.65067358028,243,307,64,262.238281946,6.82777433815,1471419,262.0,321,435,114,361.674211371,13.7907863569,2029354,363.0,240,508,268,334.820887542,35.2593744718,1878680,328.0,279,466,187,344.022990554,19.3394391688,1930313,345.0,-0.216981127858,0.225477710366,0.442458838224,-0.0153913268691,0.0633794460959,-86.3607350623,-0.0193548,847,1208,361,967.935483871,38.4576431,5431086,970.0,0.0,0.0,0.0,0.0,0.0,0.0,0.0
+7204163,32,1857.00000001,919,6.01595567153,210,319,109,266.274098008,13.3426929477,1977884,266.0,274,483,209,392.793349488,25.6808678293,2917669,393.0,622,1102,480,898.405761982,61.8292712402,6673358,910.0,260,564,304,402.471593969,40.0028388302,2989559,401.0,0.263586968184,0.506474792957,0.242887824774,0.38170304496,0.0363200755088,2835.29021797,0.384033,784,1350,566,1061.53904146,77.1233893754,7885112,1060.0,-0.187530517578,1.24157714844,1.42910766602,0.0583666635574,0.153884887539,433.547576904,0.0
+7221067,41,1513.75,782,5.66989143125,212,297,85,236.319570603,11.7529245505,1430915,233.0,260,413,153,305.093971924,26.130371008,1847344,295.0,215,553,338,317.240627581,41.0472334835,1920892,305.0,212,461,249,273.464574732,28.6595902652,1655828,267.0,-0.145359024405,0.252808988094,0.3981680125,0.0726578027574,0.0530790659715,439.942995696,0.0746812,693,1162,469,814.878117258,63.216111905,4934087,795.0,0.0,0.0,0.0,0.0,0.0,0.0,0.0
+7141909,34,1007.75,287,2.55035455652,204,390,186,275.871247829,17.8960599006,1112037,273.0,280,551,271,399.433143141,29.8021996997,1610115,395.0,694,1032,338,851.239890846,43.1815900709,3431348,853.0,292,707,415,447.131481022,55.4474912914,1802387,439.0,0.166666671634,0.452542364597,0.285875692964,0.313108473861,0.0509352528749,1262.14025813,0.317263,819,1617,798,1122.43587199,99.0689842985,4524539,1105.0,-0.103149414062,0.482360839844,0.585510253906,0.0328376711346,0.0708647178006,132.368652344,0.0
+7200209,34,821.999999999,859,8.45186055345,186,492,306,257.23296837,17.8213589613,845782,257.0,199,484,285,365.386861314,31.2254668294,1201392,368.5,434,1143,709,869.128345499,103.131367809,2857694,885.0,109,498,389,334.060523114,49.1202684983,1098391,333.0,0.25765055418,0.690780162811,0.433129608631,0.444582485433,0.0557752314203,1461.7872121,0.450345,605,1335,730,956.680352798,93.7415090247,3145565,960.0,-0.0711364746094,4.65536499023,4.72650146484,0.724370673335,1.16820963781,2381.73077393,0.0335541
+7124168,11,76.2500000014,47,1.51835387414,282,411,129,364.885245902,23.5804158535,111290,371.0,373,612,239,551.242622951,41.3024051974,168129,562.0,571,774,203,707.183606557,34.330205504,215691,713.0,497,761,264,685.747540984,39.8594893017,209153,692.0,-0.0292648114264,0.0779220759869,0.107186887413,0.0156623766099,0.0154108995376,4.77702486602,0.0122039,1232,1737,505,1601.87540984,87.8926928754,488572,1626.0,0.00408935546875,4.13623046875,4.13214111328,3.58894163038,0.453564284254,1094.62719727,3.71371
+6761090,41,3353.75000001,1075,5.23646481071,212,250,38,230.845396944,4.33912204442,3096791,231.0,256,311,55,282.544465151,8.4531958927,3790334,282.0,193,384,191,261.217070444,14.5589036863,3504227,262.0,203,283,80,240.237197167,12.0420100733,3222782,240.0,-0.132075473666,0.252173900604,0.38424937427,0.0416490012251,0.0332773027977,558.721351435,0.0466531,684,842,158,753.627059262,23.2472958242,10109907,754.0,-0.546905517578,3.56161499023,4.10852050781,0.557133910996,0.867770685057,7473.95141602,0.0
+7113009,11,56.4999999995,38,1.42611464813,627,1023,396,892.973451327,61.1791884588,201812,904.0,931,1608,677,1407.5619469,89.5604219029,318109,1421.0,1203,2030,827,1728.63716814,105.94075502,390672,1738.5,1243,1940,697,1684.40707965,97.1261507186,380676,1687.5,-0.0814656689763,0.0879310369492,0.169396705925,0.012798529141,0.021280406681,2.89246758586,0.0160902,2880,4326,1446,3984.94247788,209.39269806,900597,4024.5,3.78356933594,5.64761352539,1.86404418945,4.37557375748,0.492964102771,988.879669189,4.34538
+7110287,32,1789.5,676,4.50791701425,220,368,148,300.082704666,17.2949247718,2147992,300.0,303,552,249,458.114138027,29.0591542181,3279181,458.0,811,1149,338,981.381950265,43.4812664166,7024732,983.0,287,654,367,497.041492037,48.6786175462,3557823,496.0,0.208623975515,0.482882887125,0.27425891161,0.32883152052,0.0364263041887,2353.77602388,0.327487,826,1562,736,1255.23833473,92.7537888907,8984996,1254.0,-0.222686767578,0.987030029297,1.20971679688,0.0355534347018,0.0866939361869,254.491485596,0.0
+7082240,32,2439.74999997,1067,6.09378074334,220,410,190,321.730812583,23.4829142893,3139771,321.0,341,624,283,493.39963111,39.8596310493,4815087,492.0,763,1296,533,1020.67004816,62.4084578543,9960719,1021.0,309,815,506,563.500563582,65.0435985691,5499202,561.0,0.1642575562,0.444810539484,0.280552983284,0.290326034052,0.038916183599,2833.29176632,0.289458,892,1831,939,1378.63100728,126.005185281,13454060,1373.0,-0.167236328125,1.2995300293,1.46676635742,0.0513045174847,0.110232119043,500.680786133,0.0
+7060625,13,32.7499999998,46,2.26749974822,272,533,261,444.564885496,45.7213764355,58238,448.0,386,678,292,554.396946565,50.6279166555,72626,565.0,198,551,353,343.717557252,78.4502832605,45027,330.0,221,605,384,360.419847328,63.4680846885,47215,348.0,-0.230769231915,0.140410959721,0.371180191636,-0.0287119645122,0.0802517732791,-3.7612673511,-0.029877,879,1604,725,1359.38167939,111.996827791,178079,1371.0,-0.611755371094,6.95977783203,7.57153320312,0.375632249672,1.34494505652,49.207824707,0.0
+7041888,41,559.250000027,202,2.40959160276,242,343,101,319.172105498,8.40058588818,713988,320.0,356,530,174,495.674117121,15.1122965528,1108823,497.0,368,608,240,469.186857398,21.1602850562,1049571,466.0,350,680,330,578.071077336,20.8534887313,1293145,579.0,-0.227272734046,0.0250696372241,0.25234237127,-0.104038982245,0.029478083968,-232.735203282,-0.110471,948,1546,598,1392.91729996,40.7934366105,3115956,1395.0,-0.219573974609,2.29504394531,2.51461791992,0.250162969597,0.37328551672,559.614562988,0.0757446
+7038870,51,16.2500000002,31,2.16935226284,161,286,125,222.353846154,31.6837404402,14453,217.0,237,463,226,332.461538462,52.7012120494,21610,319.0,341,771,430,514.815384615,97.6165011756,33463,518.0,151,441,290,294.276923077,66.2899244444,19128,301.0,0.139310345054,0.470779210329,0.331468865275,0.275586467981,0.065980282029,17.9131204188,0.267735,604,1134,530,849.092307692,116.695227386,55191,858.0,2.30490112305,5.93301391602,3.62811279297,3.7767578125,1.08245732945,245.489257812,3.66806
+7270620,14,4929.75000047,3978,15.9825988412,228,627,399,291.028906131,9.30126285619,5738799,291.0,274,974,700,394.262335818,15.6447450413,7774459,395.0,391,1334,943,545.62229322,30.6195810279,10759126,546.0,283,1418,1135,474.771692276,28.8566408881,9362023,476.0,-0.0412532649934,0.187948346138,0.229201611131,0.0695483504123,0.0137673717958,1371.42392178,0.0692076,785,3019,2234,1160.06293423,50.4476692822,22875281,1162.0,-0.233642578125,3.91613769531,4.14978027344,0.117880435822,0.436373750647,2324.48431396,0.0
+7039983,41,121.499999996,160,4.09474547528,296,325,29,312.290123457,3.8629006225,151773,312.0,450,506,56,490.835390947,6.6159850188,238546,491.0,365,539,174,409.366255144,18.7768357524,198952,407.0,481,580,99,555.654320988,10.9045546725,270048,557.0,-0.215896889567,0.056862745434,0.272759635001,-0.151882802726,0.0266295507875,-73.8150421246,-0.154959,1227,1402,175,1358.77983539,19.383578939,660367,1360.0,0.0,0.0,0.0,0.0,0.0,0.0,0.0
+7033664,12,6.00000000023,21,2.41845904625,168,284,116,215.333333333,24.7431247465,5168,210.0,202,390,188,278625,40.9062062325,6687,267.0,516,712,196,597.5,60.1428854202,14340,578.0,194,499,305,324.166666667,75.2089681414,7780,301.5,0.175887688994,0.453521132469,0.277633443475,0.304786342507,0.0626968906923,7.31487222016,0.307381,564,1173,609,818125,138.603545079,19635,776.5,2.9059753418,3.779296875,0.873321533203,3.26333872477,0.233283882,78.3201293945,3.15497
+7019085,41,144.499999993,177,4.15369315487,199,292,93,234.351211073,13.1750067564,135455,233.0,230,387,157,278.100346021,25.4599278034,160742,271.0,240,659,419,360.939446367,77.6199917242,208623,341.5,158,422,264,249.605536332,39.3050368389,144272,241.0,-0.042990654707,0.389961391687,0.432952046394,0.176749406199,0.0759023526225,102.161156783,0.173675,587,1089,502,762.057093426,76.069572007,440469,746.0,-0.175811767578,5.32540893555,5.50122070312,0.341703949503,1.21921468397,197.504882812,-3.05176e-05
+7111624,21,4131.99999991,2464,10.8132343429,178,450,272,327.410939013,14.3079228652,5411448,326.0,220,658,438,484.630445305,23.7435689055,8009972,483.0,579,1075,496,864.315585673,42.2098001135,14285408,868.0,305,933,628,685.7392909,37.8219477824,11333899,689.0,0.0465249866247,0.319196432829,0.272671446204,0.115353332513,0.0155741910059,1906.55987978,0.113941,703,2012,1309,1497.78067522,66.170453508,24755319,1500.0,-0.254730224609,3.88989257812,4.14462280273,0.120629625422,0.2737015451,1993.76644897,0.0
+7018499,12,2.5,8,1.42729929292,210,234,24,220.8,6.69029147347,2208,222.0,265,304,39,282.2,11.0797111876,2822,284.0,451,508,57,474.7,16.1248255805,4747,473.0,232,295,63,259.4,18.0344115513,2594,262.5,0.264705896378,0.32064422965,0.0559383332729,0.294010278583,0.0191903015219,2.94010278583,0.292022,707,833,126,762.4,35.7412926459,7624,769.0,-3.0517578125e-05,-3.0517578125e-05,0.0,-3.0517578125e-05,0.0,-0.00030517578125,-3.05176e-05
+7013970,14,364.499999964,394,5.82160216615,220,329,109,286.247599451,9.7852670742,417349,287.0,257,430,173,382.569272977,16.6936305225,557786,384.0,351,606,255,513.525377229,29.8143496748,748720,513.0,286,537,251,444.903978052,26.2989377511,648670,444.0,0.00688073411584,0.167381972075,0.160501237959,0.0716095108466,0.0179507642958,104.406666814,0.0706383,763,1269,506,1113.72085048,47.8703767186,1623805,1115.0,-0.0533142089844,2.82885742188,2.88217163086,0.288003301424,0.697688322806,419.908813477,0.0
+7015130,34,55.25,48,1.82167192084,228,306,78,269.502262443,13.0017835304,59560,270.0,302,444,142,370.502262443,20.9538653837,81881,373.0,765,1052,287,924.610859729,60.4246111921,204339,928.0,263,501,238,383.819004525,33.8709795952,84824,382.0,0.33773958683,0.523118793964,0.185379207134,0.413477158385,0.0341792839598,91.378452003,0.410334,793,1247,454,1023.82352941,64.7941438351,226265,1027.0,-0.00836181640625,1.5182800293,1.5266418457,0.0156643552478,0.144175607794,3.46182250977,-3.05176e-05
+7051770,14,1911.00000069,1370,8.84067227562,204,444,240,294.47396651,11.8163704933,2250959,295.0,254,645,391,403.538069074,18.8108194547,3084645,404.0,345,843,498,566.996729461,36.6576809519,4334123,565.0,218,833,615,486.310308739,34.6825552305,3717356,485.0,-0.0120329326019,0.262267351151,0.274300283752,0.0768419659109,0.0203700756211,587.379987423,0.0747398,678,1888,1210,1184.32234432,60.0335003106,9052960,1184.5,-0.198486328125,15.2716369629,15.470123291,0.471065966388,1.39690538243,3600.82824707,0.0
+7075735,34,4276.25,1868,8.05824368074,149,342,193,249.280210465,16.9780434085,4263938,249.0,230,512,282,342.634142064,32.5233138433,5860757,344.0,435,1208,773,858.734931307,94.7116969288,14688661,861.0,159,566,407,318.883367436,47.5092620506,5454500,316.0,0.154425606132,0.653290510178,0.498864904046,0.457772521281,0.065476832181,7830.19897652,0.459866,604,1382,778,910.797719965,92.7655980895,15579195,910.0,-0.562530517578,3.36819458008,3.93072509766,0.409656634159,0.688894500334,7007.17672729,0.0865784
+6977206,11,25.2500000007,31,1.74030781565,309,432,123,394.425742574,19.5834576254,39837,399.0,400,717,317,590.99009901,45.1763311046,59690,590.0,536,855,319,702.326732673,54.3704034426,70935,695.0,403,814,411,668.396039604,57.9022869652,67508,668.0,-0.0114324139431,0.141640037298,0.153072451241,0.0253069978277,0.0229255863529,2.55600678059,0.0234483,1112,1846,734,1653.81188119,106.959760442,167035,1664.0,0.221069335938,0.449890136719,0.228820800781,0.370305429591,0.0705893476534,37.4008483887,0.402863
+6990542,41,3370.99999998,1750,8.50263899932,298,354,56,312.187926431,3.72600395728,4209542,312.0,458,568,110,486.461139128,6.8927056837,6559442,486.0,327,434,107,354.168051023,6.74636479006,4775602,354.0,511,683,172,552.312666864,10.7822347092,7447384,553.0,-0.233724653721,-0.203520357609,0.0302042961121,-0.218577722862,0.00447613106881,-2947.30201507,-0.218573,1272,1602,330,1350.96173242,20.4368419792,18216368,1351.0,0.0,0.0,0.0,0.0,0.0,0.0,0.0
+6874635,13,12.75,17,1.34303984368,230,275,45,248.392156863,9.26108965632,12668,246.0,272,366,94,304.588235294,20.7470068435,15534,297.0,221,327,106,284.882352941,25.7922674678,14529,286.0,221,297,76,253.980392157,16.0042766295,12953,253.0,-0.00826446246356,0.129370629787,0.137635092251,0.0561456777767,0.0376547927955,2.86342956661,0.0615711,727,877,150,806.960784314,30.6312417628,41155,802.0,-0.0015869140625,1.29754638672,1.29913330078,0.391083362056,0.500878033748,19.9452514648,0.0
+6906408,34,3256.25000002,1998,9.87715073447,194,353,159,259.608982726,16.3192938319,3381407,259.0,228,524,296,355.534587332,30.6887447322,4630838,355.0,479,1196,717,891.447677543,80.7791865176,11611106,893.0,150,644,494,342.786180422,49.680254799,4464790,343.0,0.201826483011,0.695202231407,0.493375748396,0.445472570363,0.0550141501115,5802.28022897,0.444009,599,1521,922,957.92975048,93.2009319773,12477035,957.0,-0.660247802734,1.3740234375,2.03427124023,0.0403549856234,0.212916824081,525.623687744,0.0
+6922043,14,2128.74999973,1608,9.83147732575,238,423,185,285.840281856,7.24718977526,2433930,286.0,309,596,287,375.890193776,12.2996752755,3200705,376.0,384,714,330,470.282795068,22.1808004175,4004458,471.0,311,743,432,413.857897827,19.8952750136,3524000,415.0,-0.0199039112777,0.160949870944,0.180853782222,0.0638264027651,0.0112879626081,543.481819545,0.0637363,860,1762,902,1075.58837346,36.5317938394,9158635,1077.0,-0.165191650391,1.8141784668,1.97937011719,0.201054718322,0.295673921816,1711.98092651,0.0319824
+6827348,41,53.7499999993,75,2.88580576778,280,316,36,300.762790698,4.75487623666,64664,301.0,423,461,38,442.804651163,7.07231594213,95203,442.0,390,487,97,418.395348837,14.9397853957,89955,416.0,430,493,63,465.079069767,12.1982949274,99992,466.0,-0.096997693181,0.0423162579536,0.139313951135,-0.0529547143506,0.0223509014961,-11.3852635854,-0.059752,1141,1266,125,1208.64651163,21.9102964946,259859,1210.0,0.0,0.0,0.0,0.0,0.0,0.0,0.0
+6796938,41,59.2499999991,63,2.30882725294,215,281,66,238.23628692,9.0755776356,56462,238.0,277,370,93,307.037974684,14.9438694129,72768,304.0,540,721,181,609.392405063,30.0429022578,144426,610.0,250,405,155,293.41350211,25.4650813118,69539,291.0,0.235127478838,0.434977591038,0.1998501122,0.350535452366,0.0350935359899,83.0769022107,0.349839,762,1056,294,838.687763713,44.6864790676,198769,834.0,-2.43536376953,-0.731140136719,1.70422363281,-1.93011384473,0.318962725392,-457.436981201,-1.97186
+6902765,32,7036.00000009,3981,13.3882659316,208,424,216,322.315378056,23.8406081854,9071244,322.0,312,653,341,478.51076606,38.9443884284,13467207,479.0,689,1226,537,927.156480955,61.9908834401,26093892,924.0,295,810,515,554.724523877,62.4470273618,15612167,556.0,0.109326742589,0.453177243471,0.343850500882,0.252813315529,0.0432149407692,7115.17795225,0.250864,815,1855,1040,1355.55066799,121.903820079,38150618,1357.0,-0.137390136719,1.46459960938,1.60198974609,0.0448935662162,0.10970365062,1263.48452759,0.0
+6797220,31,82.2499999972,71,2.20843928187,189,294,105,240.638297872,17.1112893507,79170,240.0,247,392,145,316.784194529,27.0579518683,104222,318.0,485,1007,522,821.537993921,119.764812272,270286,839.0,198,423,225,295.112462006,42.6295571829,97092,295.0,0.318811893463,0.642537951469,0.323726058006,0.468161011358,0.0669291472863,154.024972737,0.461088,650,1057,407,852.534954407,77.6654787518,280484,852.0,-0.0084228515625,3.30447387695,3.31289672852,1.9403476889,0.916367924095,638.374389648,1.87729
+6739338,34,274.250000001,173,2.94691665318,238,356,118,266.484958979,10.8578283083,292334,265.0,349,524,175,389.453053783,17.1062376281,427230,387.0,839,1156,317,967.755697356,38.2297727082,1061628,964.0,310,551,241,359.371011851,26.2277730385,394230,356.0,0.342482089996,0.52301889658,0.180536806583,0.458752177662,0.0249214017161,503.251138896,0.458365,910,1431,521,1015.30902461,51.6719566458,1113794,1007.0,-0.0506591796875,1.2184753418,1.26913452148,0.0307597157731,0.0945815207876,33.7434082031,0.0
+7009961,21,6188.74999995,3268,11.7185977274,182,548,366,340.334356696,16.8413720626,8424977,340.0,233,883,650,513.93774995,29.3904128468,12722529,514.0,423,1300,877,884.513391234,51.0303842191,21896129,890.0,234,1312,1078,734.396647142,48.5225096789,18179989,739.0,-0.0255720056593,0.350901514292,0.376473519951,0.092998546082,0.0157538874291,2302.17900826,0.0918567,649,2732,2083,1588.66875379,87.5391251722,39327495,1592.0,-0.496704101562,4.09149169922,4.58819580078,0.162825472344,0.579899458079,4030.74456787,0.00738525
+6758180,11,134.749999996,90,2.18712291344,290,569,279,389.230055659,29.2004610575,209795,387.0,412,946,534,598.730983302,56.3345755448,322716,597.0,519,1463,944,847.037105751,119.498265083,456553,860.0,494,1375,881,792.090909091,96.2125097017,426937,803.0,-0.0790816321969,0.201530605555,0.280612237751,0.0321395222835,0.0396510448384,17.3232025108,0.0275028,1196,2890,1694,1780.05194805,178.400128463,959448,1788.0,1.54022216797,4.23333740234,2.69311523438,3.45639893031,0.485487867553,1862.99902344,3.42172
+6743381,21,3495.25000002,2514,11.9955791078,193,642,449,338.336742722,24.882363409,4730286,339.0,264,988,724,519.014019026,43.5946561594,7256335,521.0,541,1214,673,905.209140977,71.8185554341,12655729,912.0,258,1142,884,690.946570345,64.5755222596,9660124,699.0,0.010398613289,0.354192733765,0.343794120476,0.134782047416,0.0277885336924,1884.38780492,0.130897,731,2606,1875,1548.29733209,123.947045006,21646745,1560.0,-0.871185302734,4.50787353516,5.37905883789,0.271216845787,0.656396419624,3791.88272095,0.0
+6731305,12,4.0,10,1.41047395887,219,316,97,275375,26.2056172413,4406,286.0,276,453,177,380.9375,46.9207693218,6095,395.5,619,734,115,680.4375,34.6517834137,10887,681.0,352,611,259,504.25,70.4977836531,8068,517.0,0.0853293389082,0.274974256754,0.189644917846,0.152684077155,0.0522252477383,2.44294523448,0.138318,847,1380,533,1160.5625,141.9511222,18569,1209.5,0.430541992188,0.841430664062,0.410888671875,0.639795303345,0.151333980694,10.2367248535,0.613144
+6710438,33,24.7500000007,28,1.58768922601,241,296,55,264.393939394,12.2679002853,26175,262.0,315,407,92,363.858585859,19.6628193982,36022,367.0,605,854,249,771.626262626,53.8628234938,76391,787.0,291,470,179,387.454545455,38.5414043994,38358,393.0,0.279693484306,0.395121961832,0.115428477526,0.332395546966,0.0234979494814,32.9071591496,0.331255,847,1168,321,1015.70707071,67.6711078592,100555,1021.0,-0.0563659667969,1.00891113281,1.06527709961,0.122553045099,0.267605833818,12.1327514648,0.000915527
+6706849,13,11.0000000005,20,1.70109559929,310,416,106,373.681818182,24.2353730276,16442,378.0,410,525,115,477.863636364,24.0194910523,21026,478.5,246,410,164,312.181818182,36.867251252,13736,306.5,279,388,109,317.568181818,27.1103785287,13973,310.0,-0.113237641752,0.0504774898291,0.163715131581,-0.0100944220189,0.0404424631029,-0.444154568831,-0.00253986,1029,1290,261,1169.11363636,59.9872016309,51441,1161.5,-0.014892578125,0.563354492188,0.578247070312,0.192828091708,0.20124850328,8.48443603516,0.101059
+6708553,14,659.250000031,567,6.22949809905,222,329,107,310.972317027,6.81142549755,820034,311.0,305,496,191,447.349260523,11.6220556322,1179660,447.0,490,723,233,654.263936291,21.3960105683,1725294,653.0,301,606,305,541.124004551,20.3710969052,1426944,541.0,0.0631844997406,0.238938048482,0.175753548741,0.0947480905105,0.0105642262146,249.850714676,0.0943709,828,1419,591,1299.4455821,36.4708778375,3426638,1300.0,-0.0867614746094,1.04647827148,1.13323974609,0.134280861893,0.195918452395,354.098632812,0.000946045
+6779637,41,3998.5,3128,13.9544672963,300,328,28,313.28973365,3.34185934781,5010756,313.0,464,509,45,485.417031387,5.42801287646,7763760,485.0,345,391,46,369.267475303,5.39687698083,5906064,369.0,497,559,62,528.377266475,7.74871694934,8450866,528.0,-0.189368769526,-0.162790700793,0.0265780687332,-0.17724934788,0.00387550540101,-2834.92606999,-0.177384,1270,1392,122,1327.08403151,14.9290914163,21225382,1327.0,0.0,0.0,0.0,0.0,0.0,0.0,0.0
+6683417,34,760.750000027,336,3.43647639302,181,370,189,254.407492606,17.7098303331,774162,253.0,218,510,292,363.724942491,32.1028824726,1106815,363.0,524,1271,747,1008.86526454,96.2764613104,3069977,1020.0,140,551,411,321.22050608,45.4128432934,977474,316.0,0.292506039143,0.674796760082,0.38229072094,0.516590440338,0.0562344248815,1571.98470995,0.520183,583,1402,819,939.352941176,91.9507021565,2858451,931.0,-0.133728027344,1.59216308594,1.72589111328,0.29173838916,0.417008201135,887.759918213,0.0769958
+6815507,14,1827.75000002,1151,7.59472399206,192,468,276,308.136916974,11.9756166471,2252789,308.0,260,683,423,440.42935303,19.6698063127,3219979,441.0,493,934,441,700.006291889,36.6870630851,5117746,697.0,264,972,708,560.815757078,32.956894012,4100124,560.0,-0.0338680930436,0.305263161659,0.339131254703,0.110558045247,0.0157866034707,808.289868804,0.109299,716,2123,1407,1309.38202708,59.3483534304,9572892,1311.0,-0.0805358886719,2.6946105957,2.77514648438,0.142870460941,0.299961483648,1044.52593994,0.0
+6677865,34,11.4999999998,17,1.4141486693,244,263,19,255.673913043,4.35916998395,11761,256.0,345,381,36,362.543478261,7.8538456981,16677,361.0,997,1109,112,1054.84782609,28.9744770679,48523,1057.0,280,334,54,313.347826087,11.7902269612,14414,312.5,0.51371383667,0.577677249908,0.0639634132385,0.541886634153,0.0155589919647,24.926785171,0.540038,869,978,109,931.565217391,22.7325204459,42852,928.0,-0.03173828125,0.00302124023438,0.0347595214844,-0.00208514669667,0.00750040105065,-0.0959167480469,0.0
+6635781,34,451.250000005,222,2.94808115729,194,349,155,265.772299169,12.553915083,479719,265.0,248,511,263,368.298060942,22.0279304346,664778,368.0,495,1154,659,902.310249307,79.7013895839,1628670,907.0,179,606,427,357.823822715,37.0988794481,645872,357.0,0.237974688411,0.581560254097,0.343585565686,0.43120250285,0.0512525595249,778.320517644,0.434618,621,1466,845,991.894182825,68.4448411639,1790369,991.0,-0.09228515625,2.84457397461,2.93685913086,0.352303020446,0.545377892753,635.906951904,0.0265503
+6632428,51,272.000000011,399,6.82469915494,194,388,194,281.869485294,26.6851444909,306674,284.0,260,555,295,386.966911765,46.423430879,421020,389.0,317,891,574,597.263786765,81.8601484801,649823,606.0,227,739,512,463.115808824,81.111779536,503870,468.5,0.0219653174281,0.332642495632,0.310677178204,0.129602550245,0.0392118059791,141.007574666,0.124592,681,1682,1001,1131.95220588,151.293678412,1231564,1141.0,-0.000823974609375,4.14334106445,4.14416503906,1.54520836998,0.953480552449,1681.18670654,2.0518
+6585161,51,22.5000000014,36,2.14094893932,205,426,221,275.977777778,41.388129747,24838,266.0,297,566,269,366.966666667,53.4127429656,33027,351.5,305,906,601,557.2,124.031555125,50148,535.5,227,537,310,326.233333333,71.5675360916,29361,312.0,0.0244565214962,0.391705065966,0.367248544469,0.259850577534,0.0690376060375,23.3865519781,0.268292,755,1529,774,969.177777778,152.805728352,87226,918.0,-0.0711364746094,1.15975952148,1.23089599609,0.06845703125,0.183408095074,6.1611328125,0.0
+6577463,34,1572.50000001,525,3.73472857334,181,342,161,258.942130366,13.1039195792,1628746,258.0,274,516,242,378.946740859,22.0717400846,2383575,379.0,549,1095,546,861.99745628,53.4518191726,5421964,866.0,208,622,414,378.96772655,38.0119729454,2383707,378.0,0.248366013169,0.547826111317,0.299460098147,0.389892519015,0.0378553656881,2452.42394461,0.390818,680,1478,798,1016.85659777,69.9642114409,6396028,1014.0,-0.214874267578,1.26947021484,1.48434448242,0.0899025096802,0.19195817294,565.486785889,0.0
+6594099,11,614.249999997,399,4.5414588258,194,407,213,281.391941392,17.8298789397,691380,280.0,213,625,412,363.757020757,36.1781416466,893751,358.0,491,933,442,730.426943427,53.6178807989,1794659,742.0,310,752,442,568.2999593,46.2139471289,1396313,572.0,0.0196969695389,0.285396575928,0.265699606389,0.125105947605,0.024631921233,307.385313265,0.122628,717,1760,1043,1213.44892145,82.5774407194,2981444,1212.0,-0.0117492675781,7.04095458984,7.05270385742,5.10202969096,1.2008206026,12535.6869507,5.24435
+6575086,14,724.999999996,537,5.62600806506,261,346,85,302.485517241,9.49984376866,877208,302.0,308,492,184,427.076551724,17.7052788302,1238522,427.0,528,790,262,674.006896552,31.911428404,1954620,676.0,327,687,360,531.564482759,31.6796189334,1541537,533.0,0.0597127750516,0.254275947809,0.194563172758,0.118471253964,0.0157037471506,343.566636495,0.11836,903,1510,607,1261.12655172,55.1506230793,3657267,1263.0,-0.123474121094,1.8134765625,1.93695068359,0.0815273732152,0.176474588985,236.429382324,0.0
+6565162,11,313.749999993,201,3.20110012364,252,487,235,350.152191235,24.8676485699,439441,350.0,369,705,336,531.537051793,43.9169809619,667079,533.0,521,973,452,743.683665339,72.7157288571,933323,739.0,463,946,483,707.956175299,70.6407588046,888485,715.0,-0.0426789224148,0.115558423102,0.158237345517,0.0247891426513,0.0243705004692,31.1103740274,0.0243902,1088,2047,959,1589.64541833,126.907141166,1995005,1593.0,2.36172485352,4.40594482422,2.0442199707,3.37166609441,0.428155138066,4231.44094849,3.3934
+6587584,41,957.750000002,608,5.54207714656,269,296,27,286.81623597,3.04077528112,1098793,287.0,388,445,57,427.201252937,5.25283068673,1636608,427.0,283,359,76,339.763769251,6.17247980654,1301635,340.0,425,526,101,494.973375098,8.87285526175,1896243,495.0,-0.243315503001,-0.154761910439,0.0885535925627,-0.185937220743,0.00428274212511,-712.325492665,-0.185905,1082,1264,182,1208.990864,16.2912563264,4631644,1209.0,0.0,0.0,0.0,0.0,0.0,0.0,0.0
+6713620,14,1758.99999997,1352,9.09366266755,208,478,270,292.630898238,12.2357947636,2058951,293.0,264,670,406,400.694712905,20.24345936,2819288,401.0,373,880,507,548.883172257,43.7819062047,3861942,544.0,216,913,697,479.733797612,40.1089909432,3375407,477.0,-0.0365050882101,0.266553491354,0.303058579564,0.0673917889886,0.0183114491418,474.168627324,0.0660377,726,2036,1310,1173.05940875,68.3505132506,8253646,1170.0,-0.184417724609,3.7919921875,3.97640991211,0.375840933639,0.71964949944,2644.41680908,0.0367889
+6542972,12,8.75000000023,19,1.81194346261,187,281,94,227.228571429,24.7975640673,7953,224.0,226,377,151,288.857142857,43.2085592428,10110,271.0,361,576,215,454.371428571,62.6117678187,15903,447.0,197,406,209,290.342857143,66.3639070826,10162,287.0,0.123348020017,0.389592111111,0.266244091094,0.226791386732,0.067425228202,7.93769853562,0.21148,631,1061,430,806.428571429,132.000494742,28225,780.0,-0.0281677246094,0.312194824219,0.340362548828,0.142663574219,0.0894650735686,4.99322509766,0.164032
+6533891,11,190.750000007,130,2.6552544599,247,473,226,346.964613368,24.7733115539,264734,344.0,320,683,363,526.939711664,42.0374174388,402055,524.0,457,1142,685,782.744429882,67.9009490205,597234,782.0,338,890,552,694.739187418,69.545869136,530086,699.0,-0.0323033705354,0.33220911026,0.364512480795,0.0602545898374,0.0373213424058,45.9742520459,0.0522496,905,2005,1100,1568.64351245,128.732479042,1196875,1565.0,0.496063232422,5.65975952148,5.16369628906,4.25354879837,0.539429362877,3245.45773315,4.17148
+6522034,13,9.5,16,1.46437817648,394,480,86,437.263157895,22.3226156392,16616,436.0,384,434,50,411.736842105,12.5712374522,15646,414.5,175,416,241,280.973684211,53.7423124696,10677,269.5,230,348,118,274.052631579,30.3140990026,10414,268.0,-0.148418486118,0.155555561185,0.303974047303,0.00616088627507,0.0716797497794,0.234113678453,0.00611559,1050,1196,146,1123.05263158,37.2664286403,42676,1129.5,-0.0015869140625,0.376617431641,0.378204345703,0.0277420847039,0.0843390599781,1.05419921875,0.0
+6517742,34,46.4999999995,41,1.69610388243,216,261,45,241.768817204,8.05727452645,44969,243.0,280,355,75,321.903225806,16.014821439,59874,325.0,905,1128,223,1033.41397849,50.5395152361,192215,1035.5,200,335,135,261.639784946,22.3571769997,48665,265.0,0.51902371645,0.647887349129,0.128863632679,0.596184945555,0.024882859028,110.890399873,0.598718,696,949,253,825.311827957,45.175518752,153508,835.5,-0.0320739746094,5.87854003906,5.91061401367,0.899510537424,2.01500586394,167.308959961,0.0
+6516081,41,47.5000000009,107,4.37957573459,249,307,58,275.873684211,9.26026270545,52416,276.0,356,454,98,402.031578947,15.8419513894,76386,403.0,445,848,403,616.678947368,79.6719397143,117169,613.0,308,452,144,374.668421053,25.1461109818,71187,375.0,0.0159817356616,0.408637881279,0.392656145617,0.239782609957,0.0780607054157,45.5586958919,0.239923,917,1213,296,1052.57368421,47.9694238372,199989,1053.5,0.0,0.0,0.0,0.0,0.0,0.0,0.0
+6763780,21,5930.25000006,4457,16.3268048201,205,454,249,308.754858564,10.7038529297,7323974,308.0,266,644,378,457.072045867,18.0401141313,10842206,456.0,586,1107,521,862.73487627,32.8588862435,20464934,864.0,320,1075,755,693.164622065,29.7194051077,16442558,695.0,0.0146654443815,0.293598234653,0.278932790272,0.10907102693,0.0130933775058,2587.27382981,0.107612,791,2173,1382,1458.9915265,50.9308368387,34608738,1458.0,-0.176605224609,4.09176635742,4.26837158203,0.125109466261,0.303897649593,2967.72164917,0.0
+6500105,11,63.7500000014,60,2.11985533195,500,1034,534,643.050980392,51.4171077524,163978,652.0,712,1494,782,906.047058824,61.533585132,231042,912.0,856,1655,799,1046.78431373,69.8433299201,266930,1039.0,787,1820,1033,991.125490196,86.3563975017,252737,985.0,-0.0474820137024,0.0933179706335,0.140799984336,0.027942658966,0.0153409515148,7.12537803632,0.0272142,2031,4348,2317,2540.22352941,177.842078644,647757,2544.0,2.40063476562,7.57150268555,5.17086791992,6.96947165097,0.697772862734,1777.215271,7.05667
+6505574,41,5486.50000002,3736,14.2283403031,214,459,245,318.113278046,27.0743248218,6981314,315.0,301,723,422,476.310079286,48.3074405083,10453101,472.0,418,1256,838,768.114508339,121.612194671,16857041,775.0,255,920,665,555.261687779,78.7046466466,12185773,551.0,-0.0450643785298,0.448605567217,0.493669945747,0.158909419678,0.0492947709304,3487.42612426,0.158559,785,2102,1317,1349.68504511,151.049452715,29620188,1339.0,-1.63128662109,3.48001098633,5.11129760742,0.0966053445326,0.306767994529,2120.10089111,0.0
+6493250,51,10.25,21,1.8503438033,224,444,220,276.414634146,45.5658063977,11333,261.0,266,604,338,347.512195122,66.1381119422,14248,331.0,348,683,335,472.414634146,68.4992346796,19369,467.0,170,557,387,289.634146341,71.374913984,11875,288.0,0.101612903178,0.358139544725,0.256526641548,0.247233844021,0.0586843859014,10.1365876049,0.251656,712,1605,893,913.56097561,164.901308072,37456,855.0,2.66558837891,5.63534545898,2.96975708008,3.08967553115,0.747222720749,126.676696777,2.73199
+6527671,41,6552.25000007,2220,7.73664755103,247,329,82,300.044679309,7.98791649272,7863871,301.0,339,499,160,454.211759319,16.8963763087,11904436,456.0,246,582,336,377.220420466,32.4853577966,9886570,370.0,312,577,265,484.776488992,34.6280347778,12705507,488.0,-0.328263610601,0.179695427418,0.507959038019,-0.124892285094,0.053569079322,-3273.30190002,-0.13486,919,1390,471,1239.03292762,56.7808281339,32473814,1245.0,0.0,0.0,0.0,0.0,0.0,0.0,0.0
+6510339,41,433.000000002,484,6.56139950401,233,365,132,315.147806005,17.9884194474,545836,318.0,331,561,230,474.998267898,33.7218190857,822697,482.0,402,794,392,535.409930716,54.0514410978,927330,529.0,326,623,297,513.734988453,47.9841520201,889789,520.0,-0.177713736892,0.259931892157,0.437645629048,0.0203561439965,0.0717499284856,35.2568414019,0.0166897,894,1484,590,1303.88106236,92.1316381091,2258322,1326.0,-1.15628051758,1.24298095703,2.39926147461,-0.0868091891599,0.286110799879,-150.353515625,-0.0235138
+6419451,33,27.5000000007,34,1.8289744479,266,352,86,304.218181818,18.2848083084,33464,300.5,395,546,151,458.727272727,33.4837570095,50460,453.0,788,1012,224,873.436363636,50.6513083871,96078,867.5,446,709,263,556.145454545,63.5851378238,61176,541.0,0.16604244709,0.282958209515,0.116915762424,0.224037816579,0.0283177476019,24.6441598237,0.228445,1114,1593,479,1319.09090909,114.054735301,145100,1289.0,-0.00888061523438,0.489898681641,0.498779296875,0.0437225341797,0.112120621853,4.80947875977,0.0
+6456365,34,9.49999999977,18,1.64742544857,223,256,33,243.263157895,7.54524671051,9244,244.0,329,379,50,354.131578947,13.0870990164,13457,352.5,1113,1242,129,1182.68421053,28.2638929631,44942,1182.5,208,304,96,266.736842105,22.7430547068,10136,268.0,0.586956501007,0.692643821239,0.105687320232,0.632323327817,0.0250994476458,24.0282864571,0.629604,760,933,173,864.131578947,42.2431377502,32837,866.0,-0.0125122070312,0.0,0.0125122070312,-0.000329268606086,0.0020028627395,-0.0125122070312,0.0
+6399236,41,343.499999989,215,3.27242843129,263,367,104,326.162299854,10.0182078463,448147,327.0,378,565,187,507.410480349,19.3785263792,697182,511.0,379,746,367,495.553129549,49.0382883823,680890,485.0,406,666,260,570.692139738,27.4660141337,784131,576.0,-0.246520876884,0.186330348253,0.432851225138,-0.0719521370822,0.0635892485605,-98.8622363509,-0.0883118,1047,1587,540,1404.26491994,51.5078997145,1929460,1414.0,-0.106658935547,2.3141784668,2.42083740234,0.464227867959,0.639001124023,637.849090576,0.000732422
+6399406,31,37.75,32,1.46921910928,187,282,95,244.655629139,17.374734781,36943,246.0,249,398,149,322.311258278,33.0187956568,48669,326.0,392,1054,662,870.125827815,128.975140304,131389,902.0,165,506,341,302.42384106,53.5438716061,45666,300.0,0.321708798409,0.590111613274,0.268402814865,0.483111518503,0.0623399211989,72.949839294,0.488995,603,1075,472,869.390728477,86.1816942126,131278,877.0,2.44262695312,4.5563659668,2.11373901367,2.96472632806,0.471203806919,447.673675537,2.79651
+6340750,41,162.749999997,157,3.47163630806,265,290,25,283.132104455,2.90786290815,184319,283.0,388,431,43,419.883256528,5.03308981458,273344,420.0,307,404,97,341.533026114,6.80426810331,222338,341.0,426,502,76,476.90015361,8.50882888224,310462,478.0,-0.192166462541,-0.0744559019804,0.11771056056,-0.165407518523,0.00687482630213,-107.680294558,-0.16545,1079,1216,137,1179.91551459,15.5932531642,768125,1181.0,0.0,0.0,0.0,0.0,0.0,0.0,0.0
+6337934,32,960.749999986,657,5.97936742315,208,303,95,258.558157689,5.77237022966,993639,259.0,268,427,159,352.456154046,11.1222871943,1354489,352.0,581,922,341,774.407754359,31.2213274089,2976049,773.0,185,450,265,325.848555816,20.7298514079,1252236,324.0,0.30671197176,0.523076951504,0.216364979744,0.407915565873,0.0238700900431,1567.61951965,0.408727,662,1180,518,936.862867551,36.2862485994,3600364,934.0,0.0,0.0,0.0,0.0,0.0,0.0,0.0
+6422200,22,2614.00000002,1408,7.76863882889,229,554,325,367.889537108,35.7193582405,3846653,368.0,319,826,507,566.50679036,57.939547419,5923395,568.0,576,1344,768,988.678366488,87.331885361,10337621,994.0,305,1003,698,706.418802601,89.5847221514,7386315,717.0,-0.0841020047665,0.389992058277,0.474094063044,0.16834434013,0.0445380131224,1760.20842039,0.15989,856,2359,1503,1640.81513007,175.355329948,17156363,1651.0,-2.42895507812,2.98580932617,5.4147644043,0.152653461389,0.314002028243,1596.14459229,0.00100708
+6334075,41,4640.25000001,4666,19.3227579099,280,350,70,291.368514627,2.96633918248,5408091,291.0,418,537,119,437.231506923,4.98194690727,8115454,437.0,285,402,117,304.87673078,5.00681051187,5658817,305.0,443,636,193,470.039868542,7.81338597831,8724410,470.0,-0.225433528423,-0.203084826469,0.0223487019539,-0.2131333304,0.0029316195679,-3955.96774556,-0.213158,1142,1523,381,1198.63989009,15.1064128126,22247955,1198.0,0.0,0.0,0.0,0.0,0.0,0.0,0.0
+6244643,11,19.5000000009,22,1.40540159835,315,472,157,410.166666667,27.0234545167,31993,408.0,438,685,247,592.858974359,42.035310053,46243,592.0,563,902,339,715.192307692,59.624908255,55785,705.0,455,832,377,645.435897436,64.6290380365,50344,644.5,0.00521512376145,0.119515888393,0.114300764631,0.0520225316107,0.0263122025951,4.05775746563,0.0529074,1208,1984,776,1648.46153846,128.931078021,128580,1633.5,-0.00473022460938,1.15841674805,1.16314697266,0.490996531951,0.150349620463,38.2977294922,0.510864
+6229155,13,33.2499999974,37,1.81009332667,251,401,150,349.984962406,27.9308988795,46548,353.0,313,475,162,393.315789474,24.8878290818,52311,397.0,239,577,338,335.917293233,64.1415311381,44677,326.0,236,487,251,282.308270677,38.9997456038,37547,275.0,-0.0599613152444,0.25663715601,0.316598471254,0.0822982777932,0.0592710938063,10.9456709465,0.0845865,824,1316,492,1025.60902256,68.0733609791,136406,1023.0,0.419494628906,0.689880371094,0.270385742188,0.481543748899,0.0551027092447,64.0453186035,0.46637
+6247631,41,3936.5,1354,6.08777516284,253,281,28,270.936555316,2.96443222642,4266167,271.0,350,404,54,385.574304585,5.03153754856,6071253,386.0,271,364,93,298.433506922,6.61765822173,4699134,298.0,319,398,79,366.011685507,8.77675130743,5763220,366.0,-0.140243902802,0.0282485876232,0.168492490426,-0.101674339251,0.00987183488756,-1600.96414584,-0.101796,922,1079,157,1022.52254541,15.2924671457,16100640,1023.0,0.0,0.0,0.0,0.0,0.0,0.0,0.0
+6200050,41,9.75,20,1.80685272819,317,325,8,320.307692308,2.20900077369,12492,320.0,499,515,16,505.846153846,4.10464690719,19728,506.0,337,354,17,345.076923077,4.46860624967,13458,345.0,570,594,24,580.846153846,6.70452759971,22653,581.0,-0.258205682039,-0.250807315111,0.0073983669281,-0.25463874447,0.00182128290306,-9.93091103435,-0.255026,1386,1434,48,1407.0,12.8681678412,54873,1408.0,0.0,0.0,0.0,0.0,0.0,0.0,0.0
+6341231,41,6784.49999996,4671,15.9972750479,259,289,30,278.363328175,2.80867013178,7554224,278.0,379,426,47,409.789078046,4.09241159467,11120856,410.0,282,361,79,310.942294937,5.08400082679,8438352,311.0,391,470,79,438.176284177,7.23879831635,11891228,438.0,-0.211382120848,-0.0825921222568,0.128789998591,-0.169840351265,0.00431322340866,-4609.12745262,-0.169863,1029,1181,152,1126.3286904,12.9827236031,30566308,1126.0,0.0,0.0,0.0,0.0,0.0,0.0,0.0
+6225862,21,2811.50000001,2212,11.7682299724,260,531,271,367.238840477,16.813542836,4129968,368.0,365,821,456,567.937311044,29.8878049122,6387023,570.0,723,1229,506,988.601547217,49.4024758278,11117813,990.0,473,1245,772,798.614262849,47.0909672009,8981216,803.0,-0.0109622413293,0.290085673332,0.301047914661,0.10652428552,0.0195957851927,1197.97211495,0.103748,1098,2597,1499,1733.79041437,87.3600356685,19498207,1741.0,-0.0414428710938,1.53173828125,1.57318115234,0.184367742103,0.176804086979,2073.39962769,0.142944
+6266301,32,4698.99999998,3014,12.4032527425,215,687,472,298.155139391,21.8550619635,5604124,298.0,280,726,446,453.904500958,36.8166817615,8531589,455.0,551,1195,644,936.558257076,61.1517032921,17603549,941.0,225,991,766,533.551234305,60.9685174696,10028629,535.0,0.0397286824882,0.450074523687,0.410345841199,0.27579090189,0.0374648514322,5183.76579192,0.272842,735,1876,1141,1285.61087465,115.555574799,24164342,1288.5,-0.230499267578,1.12091064453,1.35140991211,0.0487496781334,0.107033794692,916.298950195,0.0
+6848239,14,15677.4999968,9231,20.797226145,205,532,327,308.636644873,10.8102408599,19354604,309.0,261,801,540,439.652304258,17.1937938882,27570596,440.0,449,1142,693,680.407542657,28.762414189,42668357,679.0,263,1193,930,579.150326902,28.3791351673,36318517,578.0,-0.0529567524791,0.269444435835,0.322401188314,0.0805145908844,0.0127665120694,5049.06999436,0.0794431,736,2519,1783,1327.43927603,51.0472139841,83243717,1327.0,-0.639099121094,1.40084838867,2.03994750977,0.108962054976,0.178196267749,6833.01046753,0.0
+6085118,11,3.25,10,1.56478036351,350,396,46,373.846153846,14.1140745567,4860,371.0,513,580,67,553.0,22.4670699195,7189,557.0,825,950,125,886.461538462,43.0109384739,11524,874.0,717,827,110,762.230769231,35.8375691272,9909,762.0,0.0528278425336,0.102657005191,0.0498291626573,0.0752924359762,0.0151594822886,0.97880166769,0.0742414,1584,1772,188,1689.07692308,59.4609911409,21958,1687.0,0.0,0.287567138672,0.287567138672,0.179004375751,0.0703981374611,2.32705688477,0.19043
+6083348,41,179.499999987,197,4.14790754608,266,283,17,275.300835655,2.72485196721,197666,275.0,395,431,36,409.715877437,4.4932693393,294176,409.0,289,332,43,309.194986072,5.13531412707,222002,309.0,419,473,54,439.286908078,7.17925060062,315408,439.0,-0.196105703712,-0.160762935877,0.0353427678347,-0.173806243392,0.00447994384149,-124.792882755,-0.174002,1085,1187,102,1124.30362117,12.9732857394,807250,1124.0,0.0,0.0,0.0,0.0,0.0,0.0,0.0
+6099924,33,1579.50000002,1100,7.80778665762,240,416,176,303.986704653,14.1098709731,1920588,303.0,289,621,332,432.034979424,25.1263261949,2729597,431.0,577,1143,566,832.827793606,57.9691557628,5261806,834.0,307,838,531,512.230610953,41.2234681619,3236273,511.0,0.129952460527,0.41929975152,0.289347290993,0.238427707803,0.0338749600722,1506.3862579,0.236544,862,1875,1013,1248.25229503,78.332955326,7886458,1245.0,-0.332122802734,1.00424194336,1.33636474609,0.124508332738,0.174198235517,786.64364624,0.084198
+6071978,31,40.0000000009,31,1.38269619,197,340,143,249.4,20.5925350552,39904,247.0,249,391,142,323.71875,25.2421205218,51795,323.0,643,973,330,855.58125,67.6714001513,136893,873.0,189,353,164,287.6875,29.7086240636,46030,291.5,0.412478327751,0.58095240593,0.168474078178,0.496806408465,0.0343790569918,79.4890253544,0.501602,651,1024,373,860.80625,62.4964495867,137729,870.0,0.373077392578,4.07583618164,3.70275878906,3.25259113312,0.981876743671,520.414581299,3.5271
+6122761,21,821.500000027,630,6.20057312407,209,383,174,318.747108947,16.8641130886,1047403,319.0,290,588,298,481.506390749,28.6271993858,1582230,483.0,571,989,418,844.222154595,52.0157223386,2774114,850.0,286,764,478,622.897139379,49.3639311363,2046840,629.0,0.0875576063991,0.334883719683,0.247326113284,0.151430186145,0.0246605243243,497.599591672,0.148936,785,1724,939,1423.15063907,90.072146699,4676473,1430.0,-0.131286621094,1.2014465332,1.3327331543,0.0933372975847,0.164829074678,306.706359863,0.0
+6052885,34,998.250000012,752,6.71418416036,186,251,65,219.809416479,7.8946222418,877699,220.0,203,326,123,275.842724768,14.6636317622,1101440,277.0,787,1351,564,1092.7277736,71.6757926791,4363262,1092.0,99,278,179,198.307538192,21.7022075132,791842,200.0,0.60323292017,0.806672394276,0.203439474106,0.692946124593,0.0261212110788,2766.9338755,0.692044,489,851,362,693.959679439,43.2773237263,2770981,697.0,-2.41177368164,4.68127441406,7.0930480957,1.28428992681,2.13947729046,5128.16967773,1.60577
+6035406,41,792.999999988,556,5.56971875561,260,285,25,276.88776797,2.68196803135,878288,277.0,381,422,41,406.923392182,4.51962179602,1290761,407.0,307,365,58,339.64627995,5.89261635635,1077358,339.0,392,465,73,437.226040353,7.66904755326,1386881,437.0,-0.143949046731,-0.0911360830069,0.0528129637241,-0.12560115554,0.00478456323374,-398.406865373,-0.125964,1033,1169,136,1121.0372005,13.8794304963,3555930,1121.0,0.0,0.0,0.0,0.0,0.0,0.0,0.0
+6046937,14,509.999999978,398,4.9715642,207,678,471,287.201470588,19.098406098,585891,285.0,308,973,665,382.748039216,29.1289601545,780806,380.0,303,1186,883,512.568137255,42.9767751286,1045639,514.0,190,1307,1117,422.821568627,46.8549024941,862556,420.0,-0.0486348122358,0.351812362671,0.400447174907,0.096603550529,0.0257082918762,197.071243079,0.0965665,705,2880,2175,1092.77107843,90.6795642867,2229253,1085.0,-1.23831176758,1.34194946289,2.58026123047,0.10837133071,0.236164150699,221.077514648,0.0
+6012173,31,59.7499999981,73,2.66409049654,180,241,61,217.493723849,10.5817678099,51981,219.0,198,307,109,267.384937238,20.0418584743,63905,269.0,684,1109,425,967.334728033,68.452690249,231193,974.0,82,265,183,199.075313808,29.818463598,47579,202.0,0.518312990665,0.805687189102,0.287374198437,0.659622368952,0.0389293862685,157.64974618,0.659819,460,809,349,683.953974895,59.019268314,163465,691.0,2.63772583008,7.76229858398,5.12457275391,5.64269010791,2.348404929,1348.60293579,7.35913
+5981780,31,60.0000000007,74,2.69495279544,187,256,69,225.079166667,12.1163621867,54019,227.0,224,347,123,293.491666667,23.4117121093,70438,295.5,765,1159,394,974.958333333,85.2319282735,233990,982.0,120,311,191,220.045833333,33.4869685993,52811,223.0,0.555078685284,0.75409835577,0.199019670486,0.633062654982,0.034861551529,151.935037196,0.630794,534,914,380,738.616666667,68.4082942502,177268,745.0,-0.881866455078,3.24194335938,4.12380981445,1.95803476969,0.970317254029,469.928344727,2.21164
+6011212,34,1585.50000003,889,6.29816023798,188,265,77,233.9512772,6.5414037401,1483719,234.0,236,408,172,321.839167455,13.3870053699,2041104,322.0,748,1245,497,1066.56764428,57.5650325077,6764172,1066.5,118,369,251,251.969252602,17.0971264248,1597989,252.0,0.498376637697,0.765640497208,0.26726385951,0.617529235613,0.0235751324118,3916.37041226,0.618326,555,1038,483,807.759697256,35.3044107123,5122812,809.0,0.0,0.0,0.0,0.0,0.0,0.0,0.0
+5949003,14,673.750000035,463,5.03183822413,213,837,624,286.305009276,21.6948587257,771592,285.0,275,1315,1040,388.900927644,40.4314419966,1048088,387.0,406,1571,1165,561.631910946,48.1022830128,1513598,557.0,261,1975,1714,475.170315399,61.5720367139,1280584,473.0,-0.113931186497,0.217391297221,0.331322483718,0.0845249555205,0.0213970304292,227.794755128,0.0831601,749,4095,3346,1150.37625232,120.125099418,3100264,1144.0,-0.316711425781,1.85498046875,2.17169189453,0.46241766482,0.349978520581,1246.21560669,0.445496
+5990389,41,5919.99999999,5709,20.9312062743,308,403,95,320.884121622,3.97930685073,7598536,321.0,485,657,172,508.421494932,6.67276274342,12039421,508.0,324,501,177,348.742694257,6.69381406935,8258227,348.0,553,850,297,594.389822635,10.9335959196,14075151,594.0,-0.286180645227,-0.192546591163,0.0936340540648,-0.260462482106,0.00333394027919,-6167.75157626,-0.26045,1346,1910,564,1423.69543919,20.8266752387,33713108,1422.0,0.0,0.0,0.0,0.0,0.0,0.0,0.0
+5910185,41,177.250000011,195,4.13177399026,235,339,104,300.881523272,19.3926849933,213325,305.0,288,512,224,441.499294781,40.0174018855,313023,445.0,359,813,454,589.456981664,71.8068630594,417925,584.0,262,577,315,470.935119887,59.2766340549,333893,478.0,-0.0626151040196,0.322641521692,0.385256625712,0.111399574802,0.0864292980724,78.9822985349,0.112727,785,1406,621,1213.31593794,116.567802203,860241,1226.0,-0.364074707031,1.36294555664,1.72702026367,0.110767229992,0.269915357201,78.5339660645,0.0
+5591492,14,2938.50000004,1927,10.0279909909,205,398,193,273.728347796,10.2501535097,3217403,273.0,233,572,339,353.412710567,19.9697681604,4154013,350.0,310,800,490,481.282882423,39.8105053072,5656999,475.0,172,792,620,383.730644887,34.605709775,4510370,377.0,0.00502512557432,0.295081973076,0.290056847502,0.113048965214,0.0203839298579,1328.77753712,0.111853,610,1762,1152,1010.87170325,62.8742871536,11881786,1000.0,-1.31268310547,9.48904418945,10.8017272949,0.369467613743,0.725010010482,4342.72233193,0.0924835
+5877481,33,283.500000009,218,3.65237221245,213,370,157,253.619929453,11.6518117671,287605,252.0,318,502,184,365.155202822,20.8339086546,414086,360.0,722,1077,355,815.686948854,52.7825383554,924989,804.0,282,533,251,363.168430335,29.427740542,411833,359.0,0.280303031206,0.504347801208,0.224044770002,0.38383498822,0.031786069442,435.268876642,0.381357,824,1346,522,981.94356261,57.0249519012,1113524,970.0,-0.06787109375,0.789489746094,0.857360839844,0.0246927574198,0.104242037478,28.0015869141,0.0
+5850828,14,3324.9999998,1615,7.90081276366,228,769,541,278.523233083,10.9569829452,3704359,278.0,276,1192,916,367.189699248,18.0704477494,4883623,367.0,362,1531,1169,486.705864662,26.3000319371,6473188,486.0,233,1790,1557,389.268571429,29.3838309879,5177272,389.0,-0.0779885575175,0.229530200362,0.30751875788,0.111640179185,0.0130390572137,1484.81438317,0.111623,737,3751,3014,1034.98150376,57.14747276,13765254,1034.0,1.20935058594,3.53012084961,2.32077026367,2.07187897417,0.367582338946,27555.9903564,2.13904
+5821414,14,1427.00000015,742,5.54098515571,187,453,266,288.542747022,10.3907586033,1647002,288.0,240,665,425,386.329187106,18.093497234,2205167,386.0,400,875,475,534.288717589,33.5051748281,3049720,533.0,276,903,627,446.092151367,33.6706333497,2546294,445.0,-0.0157480314374,0.220091328025,0.235839359462,0.0903494794939,0.014595868768,515.714828951,0.0896483,726,2010,1284,1120.96408549,58.8480363911,6398463,1119.0,-0.156372070312,1.86868286133,2.02505493164,0.721540802579,0.451157407091,4118.55490112,0.711411
+5836073,32,2069.5,541,3.35474579908,229,382,153,325.320850447,17.8885904876,2693006,326.0,340,599,259,497.6647741,30.249351801,4119669,499.0,713,1111,398,957.790529113,40.2247472889,7928590,959.0,334,759,425,591.493476685,52.2673831038,4896383,594.0,0.152605459094,0.369811326265,0.217205867171,0.237733351823,0.0269023255419,1967.95668639,0.234908,903,1740,837,1414.47910123,99.0595972301,11709058,1419.0,-0.257843017578,0.514587402344,0.772430419922,0.0341202007108,0.0864327471806,282.447021484,0.0
+5791796,11,53.7499999991,39,1.50061899925,371,700,329,591.934883721,52.8316804346,127266,596.0,527,1036,509,898.246511628,81.9855896267,193123,910.0,756,1440,684,1160.48372093,118.284003775,249504,1179.0,642,1479,837,1124.53488372,115.237943694,241775,1143.0,-0.130816504359,0.0815450623631,0.212361566722,0.0157954609563,0.0352942523602,3.3960241056,0.0258727,1744,3018,1274,2614.71627907,226.48090112,562164,2670.0,2.64605712891,4.32388305664,1.67782592773,3.4862760322,0.407180840871,749.549346924,3.26169
+5770416,41,5868.25000002,1222,4.49999436742,226,306,80,242.418267797,4.01214153736,5690284,242.0,292,443,151,327.065181272,7.19146846057,7677201,327.0,185,504,319,276.797725046,18.4165040741,6497273,274.0,231,484,253,291.903463554,11.4234969644,6851850,292.0,-0.27734375,0.214067280293,0.491411030293,-0.0271785052589,0.0373031564002,-637.961053942,-0.0333919,750,1233,483,861.386912623,21.3857643388,20219335,861.0,-0.230499267578,1.48468017578,1.71517944336,0.0749718358884,0.182975466938,1759.81390381,0.0
+5697267,34,2307.25000001,1100,6.46011762755,149,428,279,237.818723589,13.6681000903,2194829,239.0,186,448,262,336.077689891,26.9819957717,3101661,339.0,577,1281,704,971.202947232,83.699757834,8963232,974.0,116,466,350,285.632571243,35.5262666086,2636103,288.0,0.382268816233,0.739565968513,0.357297152281,0.545320661923,0.0451226515849,5032.76438889,0.542907,568,1228,660,859.528984722,73.4790074466,7932593,866.0,-2.49417114258,2.09478759766,4.58895874023,0.114031289998,0.570681462409,1052.39477539,0.0
+5662191,21,3443.25000001,1447,6.95631630176,228,393,165,322.982937632,13.5974663289,4448444,323.0,310,606,296,476.147825456,27.7517636962,6557984,477.0,498,1077,579,836.97792783,57.7803063792,11527697,838.0,327,788,461,616.219051768,53.0201827136,8487185,619.0,0.0581395365298,0.339943349361,0.281803812832,0.152480516872,0.0288666751501,2100.11415887,0.146305,900,1712,812,1415.34981486,90.2930828935,19493613,1418.0,-0.207855224609,5.31646728516,5.52432250977,0.278803196174,0.612528717256,3839.9564209,0.006073
+5618046,51,7.49999999907,25,2.57516134698,195,272,77,232.1,20.5999190937,6963,231.0,257,369,112,313.033333333,31.271374912,9391,318.0,410,626,216,519.866666667,53.7690947995,15596,508.5,224,444,220,346.2,56.5628853578,10386,355.0,0.0919674038887,0.335311561823,0.243344157934,0.203749698152,0.0663709628953,6.11249094456,0.199788,688,1085,397,891.333333333,105.370246697,26740,907.5,0.395263671875,0.752075195312,0.356811523438,0.457695515951,0.0956087405026,13.7308654785,0.40329
+5660582,12,32.7499999991,55,2.71114100333,175,258,83,221.419847328,19.764628054,29006,226.0,226,355,129,293.969465649,28.8123539373,38510,295.0,451,1040,589,720.282442748,154.109620686,94357,708.0,160,331,171,246.816793893,45.7184883387,32333,252.0,0.338235288858,0.608323156834,0.270087867975,0.485502420718,0.0578530614744,63.6008171141,0.493506,586,936,350,762.20610687,92.1146578548,99849,778.0,-0.0219116210938,4.90365600586,4.92556762695,2.68000595442,2.07539727712,351.080780029,4.02972
+5599318,33,4962.50000003,1952,7.81672118626,195,512,317,263.711738035,19.5481431988,5234678,260.0,248,659,411,376.905390428,34.140359507,7481572,371.0,457,1209,752,761.378539043,75.3357935934,15113364,757.0,186,725,539,380.941108312,63.3226244603,7561681,370.0,0.094004444778,0.609243690968,0.51523924619,0.334959927985,0.0657698063377,6648.95457049,0.335306,676,1678,1002,1021.55823678,111.986076676,20277931,1001.0,-0.169555664062,5.53860473633,5.70816040039,0.0921517060325,0.387293681679,1829.21136475,0.0
+5878796,14,7106.24999918,3838,12.8433937539,203,500,297,307.734248021,10.732019197,8747346,309.0,261,763,502,436.89526825,15.9913578393,12418748,438.0,445,1127,682,660.905540897,30.6162064552,18786240,657.0,265,1185,920,564.349270009,25.9815714728,16041628,562.0,-0.052109181881,0.253521114588,0.305630296469,0.0787794857307,0.0127776418791,2239.3068819,0.078203,768,2447,1679,1308.97878628,43.5310349195,37207722,1309.0,-0.230499267578,1.72268676758,1.95318603516,0.236779104483,0.272133099186,6730.44604492,0.152374
+5573374,32,1860.99999999,2021,13.2156398533,254,436,182,353.492611499,21.5808110828,2631399,353.0,368,663,295,518.884873724,37.5203300378,3862579,519.0,618,1042,424,840.018941429,58.8369320128,6253101,840.0,401,899,498,663.943041376,62.6597301723,4942392,666.0,0.0333333350718,0.26286765933,0.229534324259,0.118030505919,0.0228953824773,878.619086061,0.116022,1023,1971,948,1536.3205266,120.203792799,11436370,1538.0,-0.0961303710938,1.15173339844,1.24786376953,0.295878115679,0.260255612283,2202.51669312,0.219482
+5548160,12,17.7500000005,44,2.94610733775,195,315,120,240.802816901,29.6750569696,17097,235.0,249,449,200,324.267605634,49.5989430108,23023,313.0,452,725,273,560.61971831,69.3127970619,39804,541.0,209,538,329,330.816901408,80.3070357816,23488,331.0,0.124653741717,0.412095636129,0.287441894412,0.266151082977,0.0680037034176,18.8967268914,0.281001,654,1302,648,895.887323944,158.564115907,63608,875.0,0.239135742188,0.72802734375,0.488891601562,0.38608045981,0.152615297655,27.4117126465,0.300751
+5516186,41,124.750000005,141,3.56117981817,244,420,176,326.186372745,20.6204204163,162767,330.0,355,623,268,507.088176353,41.0822070482,253037,515.0,508,933,425,708.424849699,58.8787336334,353504,710.0,381,849,468,639.709418838,71.302860583,319215,652.0,-0.115269459784,0.224032580853,0.339302040637,0.0524536114605,0.0531179126916,26.1743521188,0.0556414,994,1892,898,1472.98396794,130.931301662,735019,1496.0,-0.125030517578,2.3092956543,2.43432617188,0.136851828657,0.280873242547,68.2890625,-3.05176e-05
+5502018,11,27.0,24,1.30294003174,317,485,168,436.611111111,35.6575360414,47154,444.0,458,691,233,617.351851852,52.0201732263,66674,625.5,610,978,368,746.712962963,57.9327597027,80645,737.5,482,794,312,626.703703704,54.1830332982,67684,632.5,0.0304748397321,0.212169736624,0.181694896892,0.0876613110821,0.0421826443439,9.46742159687,0.0729755,1267,1963,696,1680.66666667,134.49810683,181512,1718.5,-0.078369140625,0.128082275391,0.206451416016,0.00139646176939,0.018748991123,0.150817871094,0.0
+5564808,21,4120.24999997,2866,12.5953276638,233,501,268,382.69722711,17.5312131831,6307233,383.0,318,744,426,586.947272617,30.175951043,9673478,587.0,649,1212,563,1003.77495298,46.0732147136,16543215,1005.0,375,966,591,801.743826224,45.8377542742,13213540,803.0,0.0403825715184,0.267578125,0.227195553482,0.112176861241,0.0157807111255,1848.78685012,0.109896,961,2157,1196,1771.38832595,88.5619700659,29194251,1773.0,-0.191436767578,1.29046630859,1.48190307617,0.0777946006007,0.127684058105,1282.1328125,0.0
+5462135,41,116.499999997,198,5.1748443982,190,279,89,224.407725322,17.7303679856,104574,219.0,226,371,145,278.74248927,32.9488190281,129894,268.0,326,901,575,583.680257511,119.997043583,271995,570.5,123,365,242,220.444206009,51.4430192163,102727,204.5,0.179023504257,0.693648815155,0.514625310898,0.449651168172,0.0797385204319,209.537444368,0.446135,541,1005,464,723.594420601,101.310493988,337195,690.0,-0.0914001464844,0.74560546875,0.837005615234,0.0278021030672,0.0823977201113,12.9557800293,0.0
+5453903,11,55.7500000037,53,2.00238923458,287,579,292,468.174887892,47.6824407317,104403,469.0,490,831,341,712.112107623,58.7876850725,158801,716.0,605,1118,513,916.533632287,97.5800349387,204387,938.0,568,1053,485,836.322869955,82.1933832935,186500,843.0,-0.0350467301905,0.116594694555,0.151641424745,0.0452423431042,0.02945318861,10.0890425122,0.0479705,1417,2379,962,2016.60986547,160.139331966,449704,2038.0,-0.0726928710938,0.307800292969,0.380493164062,0.0551459479225,0.110048536241,12.2975463867,0.0
+5411628,31,1242.0,582,4.65861965553,188,320,132,237.97363124,15.5130039063,1182253,238.0,218,428,210,314.745571659,30.49291912,1563656,313.0,458,1372,914,1001.36855878,117.508507049,4974799,1009.0,122,488,366,265.60205314,44.7411373997,1319511,264.0,0.230890467763,0.757630169392,0.526739701629,0.580039677266,0.0597431376503,2881.63711666,0.582665,533,1192,659,818.321256039,87.9316238111,4065420,817.0,-0.345336914062,6.88275146484,7.22808837891,1.12353653839,1.52584950476,5581.72952271,0.268143
+5372846,41,272.999999995,369,6.29999363432,264,393,129,328.445054945,18.765267369,358662,329.0,340,613,273,488.215201465,37.3374183522,533131,490.0,386,818,432,559.987179487,60.8668141634,611506,553.0,364,774,410,558.153846154,55.1760598157,609504,557.0,-0.178133830428,0.145896658301,0.324030488729,0.00132500325066,0.052986547182,1.44690354972,0.00775863,968,1780,812,1374.81410256,107.313818939,1501297,1376.0,-0.0484619140625,3.39532470703,3.44378662109,0.323696318127,0.816148782995,353.476379395,0.0
+5392439,51,4.00000000047,14,1.9746635423,219,291,72,243.5,17.7799043867,3896,243.0,279,396,117,324625,29.7360786756,5194,331.0,478,686,208,552125,46.7812395625,8834,550.5,238,426,188,317.5625,47.7597748503,5081,330.5,0.224137932062,0.335195541382,0.11105760932,0.27292822022,0.0383328786626,4.36685152352,0.26042,736,1113,377,885.6875,94.2488187923,14171,906.5,0.0,0.488525390625,0.488525390625,0.18049621582,0.198710283571,2.88793945312,0.0376892
+5431889,21,4320.49999999,1305,5.60065182693,243,321,78,276.006480731,6.02063762659,4769944,276.0,340,456,116,388.758882074,11.4132490249,6718531,389.0,538,763,225,644.839023261,28.6953338154,11144108,644.0,430,631,201,542.026675153,24.8601698844,9367305,542.0,0.0431244932115,0.145129218698,0.102004725486,0.0866515857146,0.00956231003033,1497.51270432,0.0854353,1025,1403,378,1206.79203796,40.2136627924,20855780,1207.5,-0.142272949219,2.42440795898,2.5666809082,0.102741165082,0.188208578936,1775.57281494,0.0
+5292783,14,2507.24999966,875,4.9295162325,220,517,297,309.154452089,14.2310526343,3100510,307.0,289,751,462,425.897896101,24.9668110452,4271330,422.0,423,915,492,580.366836175,48.8481639973,5820499,574.0,298,1071,773,509.694984545,49.330954995,5111731,500.0,-0.0785498470068,0.217391297221,0.295941144228,0.0653101388719,0.0183402605788,654.995382747,0.0651118,821,2339,1518,1244.74733274,83.6750582881,12483571,1230.0,0.0281677246094,1.46942138672,1.44125366211,0.796486727796,0.203598989441,7987.96539307,0.792572
+5305581,51,542.25000002,670,8.11652424613,98,576,478,250.662056247,35.5805651906,543686,250.0,192,879,687,343.538497003,58.0194282158,745135,339.0,314,1195,881,647.510834486,144.580868292,1404451,636.0,83,1057,974,352.292761641,74.3955978373,764123,347.0,0.02662993595,0.618644058704,0.592014122754,0.291478507056,0.0778643263777,632.216881804,0.294606,579,2512,1933,946.493314892,152.177822013,2052944,938.0,-0.255645751953,4.87448120117,5.13012695312,1.26470910684,1.40785873887,2743.15405273,0.662048
+5261125,11,29.2500000007,30,1.56478036349,331,415,84,376.153846154,14.8269882048,44010,375.0,440,596,156,541.957264957,23.9816144543,63409,544.0,522,773,251,643.803418803,45.6754135954,75325,638.0,482,689,207,604.888888889,35.6403636004,70772,607.0,-0.0243137255311,0.130116954446,0.154430679977,0.0308048305854,0.0309189059617,3.60416517849,0.0273063,1267,1642,375,1523.0,56.5378626633,178191,1530.0,-0.0225524902344,3.29040527344,3.31295776367,0.355548565204,0.715446162346,41.5991821289,0.0
+5190659,14,226.750000024,243,4.55226665705,246,505,259,297.48401323,10.3728994602,269818,298.0,345,754,409,419.448732084,16.1472129907,380440,419.0,503,960,457,595.33076075,22.178855306,539965,593.0,358,1036,678,489.296582139,27.8715200715,443792,487.0,-0.0380761511624,0.176848873496,0.214925024658,0.0980857708209,0.0139981901079,88.9637941346,0.097561,956,2295,1339,1206.22932745,52.6255761754,1094050,1203.0,-0.171905517578,1.0419921875,1.21389770508,0.275296481468,0.268788832514,249.693908691,0.347656
+5304963,22,8903.5,3949,11.805973939,265,456,191,361.98904925,13.9644428576,12891878,362.0,378,698,320,544.093109451,24.6180956443,19377332,544.0,685,1112,427,909.482506879,40.9538914151,32390310,910.0,427,981,554,721.222412534,40.6666996337,25685615,723.0,0.0412698425353,0.259323507547,0.218053665012,0.115721193439,0.0136958775449,4121.29458315,0.11583,1070,2135,1065,1627.30457124,76.6936530499,57954825,1628.0,-0.214477539062,1.4743347168,1.68881225586,0.159912940566,0.180820153336,5695.13946533,0.123413
+5209992,11,161.250000003,67,1.48840119157,277,448,171,404.173643411,15.6115913971,260692,407.0,351,640,289,581.700775194,23.8560037334,375197,585.0,402,922,520,621.83875969,44.2891001168,401086,613.0,335,819,484,616.348837209,35.3915969449,397545,612.0,-0.0454545468092,0.0934579446912,0.1389124915,0.00413602797275,0.0172553817927,2.66773804242,0.000809717,963,1873,910,1602.22325581,64.4285536772,1033434,1605.0,0.269378662109,4.97375488281,4.7043762207,3.71811774202,0.761237803385,2398.1859436,3.94885
+5172098,41,456.249999998,251,3.31487648395,266,370,104,334.056986301,16.5145692992,609654,335.0,380,581,201,514.150684932,39.8491509106,938325,512.0,387,783,396,502.703013699,47.0409616516,917433,496.0,382,706,324,589.675068493,63.5858531506,1076157,591.0,-0.257346391678,0.204166665673,0.461513057351,-0.0783159083889,0.06926142688,-142.92653281,-0.0865562,1036,1642,606,1437.88273973,117.714525602,2624136,1436.0,-0.0728454589844,2.4130859375,2.48593139648,0.0928933506796,0.384107759509,169.53036499,0.0
+5256299,33,2557.0,1600,8.92585210535,188,336,148,260.062866641,13.3166240915,2659923,258.5,246,507,261,362.168459132,25.752694717,3704259,359.0,549,1173,624,849.882283926,74.3517955818,8692596,847.0,172,625,453,363.877199844,42.5973175098,3721736,359.0,0.238482385874,0.574257433414,0.335775047541,0.400514212495,0.0469431500632,4096.4593654,0.400339,606,1446,840,986.108525616,77.5862442504,10085918,976.0,-0.179718017578,1.30844116211,1.48815917969,0.151549394866,0.194901455237,1550.04721069,0.0857849
+5185700,32,343.999999997,177,2.69208713775,224,321,97,267.940406977,13.7751649573,368686,267.0,326,499,173,403.936046512,24.4293650156,555816,402.0,851,1194,343,1023.18023256,49.4246791752,1407896,1020.5,260,540,280,387.422238372,36.4355284331,533093,384.0,0.350571244955,0.556235671043,0.205664426088,0.451503691112,0.0286164652793,621.26907897,0.452617,819,1343,524,1059.29869186,72.7973365419,1457595,1051.5,-0.112762451172,0.480407714844,0.593170166016,0.0425551658453,0.0909521896647,58.5559082031,0.0
+5150788,21,117.499999997,79,2.05590586739,287,702,415,367.887234043,52.013521634,172907,355.0,402,1072,670,539.3,78.282123445,253471,521.0,563,1161,598,788.20212766,96.7060230239,370455,782.5,443,1341,898,671.987234043,78.5193826647,315834,671.0,-0.071942448616,0.187728270888,0.259670719504,0.0788539041657,0.0484601226267,37.0613349579,0.0886108,1193,3115,1922,1579.17446809,194.133063018,742212,1552.0,1.90151977539,3.19052124023,1.28900146484,2.21845209649,0.348186707086,1042.67248535,2.03903
+5155252,33,1508.24999998,793,5.76012075845,210,368,158,279.024200232,18.771451475,1683353,276.0,297,573,276,416.804243328,33.7896443437,2514580,412.0,616,1239,623,901.939333665,81.2948376032,5441400,891.0,303,654,351,430.282943809,52.3268743195,2595897,422.0,0.224652081728,0.492561995983,0.267909914255,0.354773878441,0.0395716410771,2140.35080864,0.352727,848,1585,737,1126.11138737,102.48457869,6793830,1110.0,-0.127960205078,1.17984008789,1.30780029297,0.0429332700907,0.113137706431,259.016418457,0.0
+5143241,32,1039.24999999,265,2.31889415204,234,368,134,302.936733221,12.8638842923,1259308,303.0,318,542,224,429.864084676,22.6052304042,1786945,430.0,570,1001,431,789.640365648,42.8947146205,3282535,786.0,313,660,347,504.272552321,40.129727685,2096261,503.0,0.0831234231591,0.348684221506,0.265560798347,0.221213107467,0.0247283672437,919.582887739,0.221267,865,1556,691,1237.07337022,74.0233054701,5142514,1236.0,-0.202911376953,1.64495849609,1.84786987305,0.208403711454,0.211282567763,866.334228516,0.1987
+5447563,14,6555.24999998,2955,10.2957484606,211,719,508,289.028755578,10.2232438147,7578623,289.0,256,1033,777,387.397925327,17.1882902881,10157961,388.0,303,1231,928,507.966973037,31.4120863937,13319402,507.0,211,1407,1196,443.16101598,29.5988435071,11620125,443.0,-0.0667172074318,0.241007193923,0.307724401355,0.0682777089622,0.0136223782912,1790.3098067,0.0671067,681,3159,2478,1119.58769688,53.8470147273,29356709,1121.0,-0.446868896484,2.81509399414,3.26196289062,0.364219531974,0.509295872207,9550.2003479,0.04245
+5129499,34,301.500000012,225,3.65539175444,211,291,80,246.956053068,9.84012628226,297829,246.0,293,445,152,365.531509121,16.6280722957,440831,365.0,771,1185,414,1033.47512438,35.4368701956,1246371,1032.0,231,458,227,312.925373134,25.276338144,377388,311.0,0.41656050086,0.611438155174,0.194877654314,0.535506782124,0.0277126208195,645.821179241,0.536337,736,1192,456,925.412935323,49.7870952914,1116048,921.0,-0.104736328125,0.503387451172,0.608123779297,0.0336931522806,0.0770625010673,40.6339416504,0.0
+5110018,22,19.5000000016,32,2.04422050665,422,467,45,450.012820513,7.66860664933,35101,450.5,659,736,77,702.91025641,13.6054154918,54827,702.5,1075,1155,80,1106.80769231,15.3372829576,86331,1107.0,882,963,81,917.333333333,17.9783820802,71552,919.0,0.084302328527,0.109100051224,0.0247977226973,0.0936526702001,0.00501609295579,7.3049082756,0.0926115,1967,2158,191,2070.25641026,33.8698246676,161480,2072.0,0.00387573242188,0.470611572266,0.466735839844,0.229312212039,0.110414642631,17.8863525391,0.223831
+5080906,33,687.50000001,512,5.50844069019,232,326,94,269.061090909,13.407321429,739918,267.0,303,498,195,383.649454545,25.9954406784,1055036,380.0,620,1042,422,812.937818182,57.8535403707,2235579,810.0,270,567,297,403.335272727,41.7171117215,1109172,398.0,0.215017065406,0.453201979399,0.238184913993,0.337358145036,0.0395237506302,927.73489885,0.340621,805,1371,566,1056.04581818,77.4854267281,2904126,1045.5,-0.0978393554688,1.16320800781,1.26104736328,0.0607382146662,0.113069394791,167.030090332,0.0
+5074871,12,35.4999999963,84,3.9770420011,195,301,106,240.563380282,21.8088574811,34160,242.0,240,419,179,319.697183099,35.5178965872,45397,322.0,399,686,287,534.007042254,65.3547735768,75829,541.0,216,482,266,310.197183099,47.4073209175,44048,315.0,0.155127078295,0.385749399662,0.230622321367,0.266233015333,0.0482178905193,37.8050881773,0.260562,669,1202,533,870.457746479,100.817267638,123605,876.0,0.215148925781,1.49868774414,1.28353881836,0.727943312954,0.311158842833,103.367950439,0.784058
+5081187,34,323.250000006,131,2.05540352434,195,325,130,239.021655066,14.7053397623,309055,240.0,250,501,251,337.179427688,32.9633180173,435973,345.0,579,1261,682,979.728538283,155.210770841,1266789,1027.0,166,450,284,278.889404486,35.84463321,360604,280.0,0.335793346167,0.67552447319,0.339731127024,0.552280042859,0.0579485264488,714.098095417,0.564655,627,1223,596,855.090487239,78.2856945513,1105632,865.0,-0.0575561523438,1.24349975586,1.3010559082,0.14294952841,0.188370177255,184.833740234,0.100922
+5072758,11,38.9999999995,32,1.44548218256,321,516,195,373.724358974,36.6467149187,58301,363.0,488,771,283,559.538461538,48.0339602908,87288,549.0,1022,1368,346,1241.8974359,54.8888363185,193736,1252.0,853,1364,511,1170.75,78.1603894205,182637,1187.0,-0.00687980558723,0.10150963068,0.108389436267,0.0301666685749,0.0169058333604,4.70600029768,0.0263371,1784,2646,862,2104.01282051,97.771514596,328226,2094.5,4.08825683594,5.02456665039,0.936309814453,4.47838279528,0.19173939541,698.627716064,4.51857
+5020067,12,4.0,13,1.83361614653,223,289,66,250.0,20.3008620507,4000,239.5,259,395,136,318125,41.8820889522,5090,317.0,345,537,192,436375,61.471411038,6982,438.0,199,408,209,298.0,66.2778243457,4768,298.5,0.136507943273,0.26838234067,0.131874397397,0.195242735557,0.0409062224307,3.12388376892,0.203518,681,1086,405,866125,127.004367543,13858,860.5,-3.0517578125e-05,-3.0517578125e-05,0.0,-3.0517578125e-05,0.0,-0.00048828125,-3.05176e-05
+5016351,34,15.25,18,1.30026733143,218,272,54,245.836065574,11.026317739,14996,247.0,291,380,89,341.639344262,20.6945251229,20840,343.0,851,1226,375,1012.91803279,98.5457029832,61788,1011.0,229,352,123,286.262295082,24.7405564957,17462,289.0,0.489891141653,0.63280659914,0.142915457487,0.557815359753,0.0383040093644,34.0267369449,0.556497,739,1004,265,873.737704918,55.28196031,53298,878.0,-3.0517578125e-05,1.35675048828,1.35678100586,0.413322573803,0.407672437429,25.212677002,0.247375
+5076496,21,2790.99999992,2305,12.3079600942,189,654,465,338.21963454,23.0694344261,3775884,336.0,258,994,736,522.579272662,37.9254095993,5834075,522.0,510,1177,667,882.449032605,71.4281954228,9851661,895.0,261,1204,943,697.559118595,63.0400323676,7787550,708.0,-0.0286202486604,0.322957187891,0.351577436551,0.117398325134,0.0249866937223,1310.6349018,0.117157,708,2852,2144,1558.3580258,114.791580477,17397509,1567.0,-0.327392578125,2.57476806641,2.90216064453,0.140046713216,0.346441894437,1563.48150635,0.0
+4976525,21,103.75,197,5.45591055047,291,472,181,331.893975904,15.5308736393,137736,331.0,419,704,285,497.763855422,25.5467847613,206572,497.0,771,1093,322,879.103614458,41.712398682,364828,878.0,537,979,442,676.245783133,42.4324532007,280642,678.0,0.0550193041563,0.178899079561,0.123879775405,0.130771792097,0.0209691601211,54.2702937201,0.128788,1265,2155,890,1505.90361446,76.8008870521,624950,1509.0,-0.109527587891,1.34716796875,1.45669555664,0.271627991458,0.336016213714,112.725616455,0.172638
+5861526,14,9185.99999949,5930,17.4536611749,205,963,758,295.029093185,10.1858677752,10840549,295.0,251,1556,1305,411.757701938,16.7179489346,15129625,413.0,316,2147,1831,599.502122796,28.460656643,22028106,598.0,230,2465,2235,516.884280427,28.1201670306,18992396,517.0,-0.0689505636692,0.22255192697,0.29150249064,0.0741433102006,0.0135542443822,2724.32179001,0.0719697,718,4984,4266,1223.67107555,50.6383162861,44962570,1226.0,-0.548461914062,4.15383911133,4.70230102539,0.272784757375,0.556228500527,10023.203125,0.0104523
+4916536,11,177.500000003,104,2.20206040806,281,550,269,452.345070423,50.7969786412,321165,433.0,415,807,392,630.601408451,76.4815378495,447727,594.0,478,992,514,658.992957746,78.9851025781,467885,634.5,393,898,505,668.311267606,80.9384239073,474501,642.5,-0.0701107010245,0.276344865561,0.346455566585,-0.00683685490332,0.0295474812688,-4.85416698136,-0.0124104,1140,2125,985,1751.25774648,200.670130245,1243393,1640.5,0.846832275391,4.33703613281,3.49020385742,3.55384624642,0.376787000786,2523.23083496,3.6499
+5012524,34,1338.50000002,1363,10.5094922934,171,356,185,262.732723198,17.1666039497,1406671,262.0,238,564,326,366.594322002,31.6517780197,1962746,367.0,271,1161,890,890.508218155,92.1997860563,4767781,901.0,96,568,472,349.512327232,51.658601155,1871289,349.0,0.202807024121,0.652068138123,0.449261114001,0.436691877916,0.057749496672,2338.04831436,0.438115,562,1488,926,978.839372432,98.1928224519,5240706,979.0,-0.429718017578,6.00671386719,6.43643188477,0.85562692385,1.54225684563,4581.02655029,0.00146484
+4947983,51,9.24999999907,25,2.3188049047,213,270,57,243.891891892,13.2864161149,9024,245.0,280,379,99,328.135135135,19.0265279419,12141,328.0,512,685,173,616.0,45.0075068814,22792,625.0,259,427,168,345.054054054,32.5824906933,12767,349.0,0.225955963135,0.331282049417,0.105326086283,0.282433157032,0.0334502901468,10.4500268102,0.296017,759,1064,305,917.081081081,62.1221022505,33932,924.0,1.05776977539,2.86352539062,1.80575561523,1.7145649678,0.431030085642,63.4389038086,1.81693
+4925357,11,21.2499999991,23,1.40748390357,372,567,195,461.847058824,31.9372568281,39257,466.0,484,794,310,658.929411765,43.1829999871,56009,666.0,575,917,342,778.635294118,50.4347795635,66184,773.0,476,960,484,736.258823529,60.612200857,62582,729.0,-0.0229088980705,0.0941960066557,0.117104904726,0.0286555042655,0.0199737784639,2.43571786257,0.0293296,1332,2321,989,1857.03529412,125.894301797,157848,1875.0,-0.000823974609375,2.30743408203,2.30825805664,0.68586102654,0.323985016381,58.2981872559,0.655609
+4911854,11,178.750000004,93,1.96225295289,223,442,219,349.528671329,32.775868708,249913,357.0,294,678,384,522.738461538,61.8184584685,373758,537.0,450,982,532,732.187412587,74.7643653826,523514,732.0,326,931,605,667.444755245,92.900974182,477223,678.0,-0.0769230797887,0.212121218443,0.289044298232,0.0487188309533,0.0472370616882,34.8339641316,0.0400605,881,1959,1078,1539.71188811,172.954760441,1100894,1575.0,-3.0517578125e-05,3.80517578125,3.80520629883,2.48060947231,1.2355668288,1773.63577271,2.9953
+4908853,12,4.00000000023,13,1.83361614648,227,292,65,251375,18.6442853175,4022,245.0,298,415,117,336.3125,33.8003675091,5381,322.0,448,688,240,564.75,60.9030992643,9036,565.0,268,437,169,325.4375,50.1534753905,5207,305.0,0.203036054969,0.342497140169,0.1394610852,0.270684958436,0.0430037872416,4.33095933497,0.265595,793,1144,351,913125,102.247784206,14610,871.0,-0.0289306640625,0.466003417969,0.494934082031,0.166622161865,0.187916705475,2.66595458984,0.0337372
+4941538,34,331.49999999,172,2.66490510347,187,292,105,254.570889894,9.64094603162,337561,254.0,248,437,189,364.026395173,16.7730858034,482699,364.0,621,1287,666,1065.11085973,68.5767655842,1412337,1070.0,129,455,326,320.954751131,29.5740919018,425586,320.0,0.426952153444,0.728706598282,0.301754444838,0.536694956828,0.0365990227695,711.657512754,0.535639,564,1174,610,939.552036199,54.1788969335,1245846,937.5,-0.130493164062,1.10458374023,1.2350769043,0.178182748648,0.226506517527,236.270324707,0.0794373
+4893722,34,24.0,27,1.55472367262,240,284,44,260.583333333,9.692852464,25016,258.0,354,411,57,381.802083333,13.38891005,36653,380.5,932,1163,231,1052375,48.7321014151,101028,1042.0,253,373,120,329.010416667,19.419435492,31585,327.0,0.470332860947,0.572995781898,0.102662920952,0.523547147401,0.0224214952793,50.2605261505,0.523281,882,1057,175,971.395833333,37.9048917156,93254,967.5,-0.134094238281,0.741485595703,0.875579833984,0.380537668864,0.19397380904,36.5316162109,0.416183
+4841308,21,299.750000003,321,5.23022659262,219,323,104,280.721434529,8.09642468549,336585,280.0,318,471,153,405.854045038,12.1524737022,486619,406.0,657,838,181,772.764804003,18.6437492679,926545,774.0,457,704,247,633.663886572,18.0773877684,759763,634.0,0.0553977265954,0.179533213377,0.124135486782,0.098958319269,0.00787337368024,118.651024804,0.0985325,994,1485,491,1320.23936614,34.132869724,1582967,1321.0,-0.243011474609,1.66885375977,1.91186523438,0.12182632459,0.248402435675,146.069763184,0.0
+4854350,12,3.25,10,1.56478036351,191,251,60,218.076923077,17.3757635735,2835,218.0,248,333,85,284.461538462,24.9202277574,3698,273.0,393,541,148,465.230769231,39.4542653366,6048,468.0,231,360,129,290.076923077,38.9288533263,3771,277.0,0.182648405433,0.303988993168,0.121340587735,0.233908974207,0.0411139217483,3.0408166647,0.224299,674,942,268,792.615384615,79.1721964227,10304,757.0,0.637298583984,1.5260925293,0.888793945312,0.965911865234,0.322788110637,12.556854248,0.906494
+4818297,34,422.000000007,459,6.30306125927,190,358,168,241.015995261,13.8076359491,406835,241.0,231,564,333,344.32464455,28.2733786875,581220,344.0,734,1292,558,1011.87736967,80.6439706934,1708049,1007.5,154,412,258,291.537322275,33.3961895893,492115,294.0,0.423347383738,0.730569958687,0.307222574949,0.552830335847,0.0371274330281,933.17760691,0.54967,576,1333,757,876.877962085,71.3953384224,1480170,881.0,-0.0898742675781,1.59466552734,1.68453979492,0.159818495619,0.358244870982,269.773620605,0.0
+4891552,32,2331.24999997,1584,9.25456096408,221,496,275,321.505630027,29.9163354454,2998040,321.0,313,700,387,485.737265416,50.1168632157,4529500,486.0,594,1243,649,935.62616622,85.9475822644,8724714,941.0,336,877,541,601.751849866,87.2380452832,5611336,601.0,0.0735615417361,0.421122997999,0.347561456263,0.219589355895,0.0527160212604,2047.67074372,0.213896,919,1937,1018,1408.99474531,160.016292985,13138876,1410.0,-0.142608642578,3.47064208984,3.61325073242,0.0606051545744,0.170876972495,565.143066406,0.0
+4821110,11,124.750000002,70,1.76796161188,252,492,240,379.266533066,24.0748478459,189254,378.0,428,713,285,580.865731463,40.7071265052,289852,577.0,553,999,446,747.853707415,63.9400132301,373179,743.0,459,877,418,716.370741483,57.0366828632,357469,714.0,-0.0466101691127,0.219035997987,0.265646167099,0.021302541149,0.0302630043356,10.6299680333,0.0164671,1139,1985,846,1676.50300601,109.016910912,836575,1672.0,3.12295532227,4.63711547852,1.51416015625,4.00906592237,0.378183096516,2000.52389526,4.11292
+4779976,22,223.74999999,194,3.65860291389,282,461,179,374.340782123,30.7572049324,335035,377.0,401,724,323,589.517318436,49.3225330848,527618,594.0,814,1294,480,1054.48715084,76.6973126508,943766,1057.0,514,945,431,763.697206704,76.5625821574,683509,768.0,0.0971428602934,0.291073739529,0.193930879235,0.160996198213,0.0309514951242,144.091597401,0.154348,1268,2105,837,1727.55530726,145.485037386,1546162,1740.0,-0.0227355957031,0.319305419922,0.342041015625,0.00859242018375,0.0398718018756,7.69021606445,0.0
+4802943,11,15.2500000002,24,1.73368977522,311,457,146,354.163934426,28.3937076427,21604,350.0,468,726,258,537.68852459,53.0806812388,32799,524.0,643,1043,400,767.786885246,69.2846622144,46835,753.0,561,994,433,677.426229508,86.5050854217,41323,653.0,0.0,0.163307845592,0.163307845592,0.0642192576645,0.0355883235393,3.91737471754,0.0681063,1353,2177,824,1569.27868852,165.912788778,95726,1517.0,0.229644775391,2.79940795898,2.56976318359,1.14844500432,0.979638773132,70.0551452637,0.986298
+4798620,51,41.2499999988,62,2.72317016965,191,311,120,241.036363636,24.0912132628,39771,236.0,234,442,208,310.927272727,42.8509133082,51303,299.0,403,876,473,534.16969697,101.270811508,88138,506.0,201,494,293,302.460606061,62.2609851054,49906,287.0,0.154066979885,0.391715973616,0.237648993731,0.277661400943,0.0499954839015,45.8141311556,0.277497,648,1244,596,854.424242424,121.883508792,140980,821.0,-0.0601806640625,4.87210083008,4.93228149414,0.586743164063,1.47356292414,96.8126220703,0.0
+4780407,32,739.749999997,483,5.00956149105,193,345,152,290.88408246,14.7825427065,860726,292.0,266,518,252,431.199053734,24.3917819317,1275918,432.0,657,1036,379,878.082460291,43.1492371623,2598246,879.0,280,628,348,480.382899628,38.9251896188,1421453,482.0,0.215031310916,0.437185943127,0.222154632211,0.293495373338,0.0279002644519,868.452809706,0.290706,739,1486,747,1202.46603582,74.5748801753,3558097,1206.0,-0.439086914062,1.14627075195,1.58535766602,0.0504015180943,0.126633300672,149.138092041,0.0
+4765532,11,360.5,155,2.30289497231,411,670,259,538.840499307,31.2183633462,777008,538.0,670,1098,428,875.112343967,46.198824071,1261912,876.0,986,1746,760,1410.32801664,87.8395880982,2033693,1414.0,826,1362,536,1135.58945908,63.622570336,1637520,1140.0,-0.00139729853254,0.218038126826,0.219435425359,0.107673619798,0.0214552231322,155.265359749,0.105142,1970,3022,1052,2549.54230236,126.780057672,3676440,2552.0,-4.00723266602,5.03295898438,9.04019165039,0.78689001668,3.57396241391,1134.69540405,2.9377
+4689109,14,5526.49999999,2797,10.6135934272,218,461,243,304.019361259,8.53459469899,6720652,305.0,273,702,429,423.946892246,14.5851894212,9371770,424.0,403,963,560,590.231566091,29.6824196006,13047659,588.0,278,1012,734,523.705690763,27.6649042927,11577038,523.0,-0.0248101260513,0.207977205515,0.232787331566,0.0597962050524,0.0117334978821,1321.85490889,0.0589319,783,2175,1392,1251.67194427,46.5424798545,27669460,1252.0,-0.447692871094,4.06130981445,4.50900268555,0.245993617389,0.589116432229,5437.93490601,0.0
+4709233,14,1372.2500012,994,7.56945885193,210,823,613,302.045363454,18.1325844385,1657927,303.0,255,1205,950,401.926033886,27.3434395333,2206172,402.0,336,1365,1029,531.37985061,41.6809905793,2916744,524.0,192,1667,1475,438.122791037,43.2238034334,2404856,434.0,-0.107641197741,0.351351350546,0.458992548287,0.0965196360102,0.0224992901084,529.79628206,0.0930997,657,3695,3038,1142.09418838,83.5267493365,6268955,1138.0,0.182067871094,2.78030395508,2.59823608398,1.45177622201,0.482181438896,7968.79968262,1.36353
+4710802,12,5.0,13,1.64003613931,194,251,57,218.45,12.6588901567,4369,220.0,242,327,85,279.0,19.7053292284,5580,278.5,493,665,172,572.35,43.9946303542,11447,573.5,161,303,142,225.75,34.3553125441,4515,222.0,0.323489934206,0.580182552338,0.256692618132,0.434840883315,0.0732067853379,8.69681766629,0.434198,597,881,284,723.2,66.3163629883,14464,720.5,0.0,4.0729675293,4.0729675293,2.80065155029,1.83271982667,56.0130310059,3.97134
+4712942,21,9321.49999998,4721,13.7938712003,227,463,236,357.54567398,17.1297929122,13331448,358.0,302,723,421,566.896878185,32.8425986229,21137317,569.0,536,1237,701,997.633374457,57.3550787548,37197758,1002.0,311,1003,692,781.95247546,56.7837824141,29155880,787.0,0.0432537123561,0.321357280016,0.27810356766,0.121661245053,0.0215239316133,4536.26118306,0.11719,840,2186,1346,1706.39502762,102.467633451,63624645,1714.0,-0.709777832031,2.59359741211,3.30337524414,0.0874796354137,0.234133968607,3261.76568604,0.00831604
+4722141,34,1898.99999997,726,4.69968993819,192,346,154,250.479199579,11.3573861569,1902640,251.0,249,520,271,351.933780937,19.8125154321,2673289,352.0,460,1022,562,778.289626119,60.366437226,5911888,774.0,168,633,465,337.806608741,33.0257190461,2565979,338.0,0.23496504128,0.590291261673,0.355326220393,0.394384887313,0.0473347253903,2995.74760403,0.388083,610,1499,889,940.219589258,60.6564902636,7141908,943.0,-0.149261474609,1.45492553711,1.60418701172,0.216301044707,0.294475038806,1643.0227356,0.0945587
+4746900,21,1711.99999998,1301,8.86993596203,210,460,250,344.551693925,16.5143120647,2359490,345.0,260,659,399,526.17859229,28.6430573519,3603271,527.0,458,1064,606,889.170998832,52.7975252651,6089043,895.0,219,846,627,701.887266355,47.2144623713,4806524,707.5,0.027511196211,0.353028059006,0.325516862795,0.117983108047,0.0189973330365,807.948323909,0.116066,689,1874,1185,1572.61755257,85.9949902181,10769285,1581.0,-0.152374267578,4.57916259766,4.73153686523,0.246694872312,0.532873421725,1689.3664856,0.0478973
+4693648,12,4.0,14,1.97466354242,202,252,50,226.0625,16.9169617175,3617,223.0,234,333,99,281.5,32.5883414736,4504,274.5,532,714,182,610.9375,62.9845901293,9775,600.0,155,316,161,241.4375,50.5457326957,3863,236.0,0.36530610919,0.555236756802,0.189930647612,0.438998954371,0.0529808822948,7.02398326993,0.43267,591,901,310,749.0,99.4283661738,11984,731.5,0.532470703125,0.618804931641,0.0863342285156,0.571424484253,0.0291503599715,9.14279174805,0.567703
+4724319,21,382.5,368,5.30795420055,277,366,89,328.101960784,11.34739883,501996,328.0,418,561,143,494.835294118,18.4931800557,757098,495.0,753,965,212,870.153594771,28.1103440272,1331335,871.0,525,730,205,645.91503268,27.3641499434,988250,646.0,0.101488500834,0.197142854333,0.0956543534994,0.14806775571,0.0136090330038,226.543666236,0.147358,1220,1657,437,1468.85228758,53.511544274,2247344,1469.0,-0.0867614746094,2.98208618164,3.06884765625,0.10160965265,0.230307383609,155.462768555,0.00149536
+4653235,11,53.7500000012,73,2.80885094725,261,413,152,346.36744186,30.0074387749,74469,345.0,355,643,288,513.130232558,54.9773041328,110323,518.0,499,824,325,671.753488372,52.4664204852,144427,675.0,444,786,342,633.893023256,45.2102344626,136287,635.0,-0.0320562943816,0.0836065560579,0.11566285044,0.0287475928188,0.0210071769807,6.18073245604,0.0305981,1064,1752,688,1493.39069767,103.490774365,321079,1498.0,0.328857421875,1.37536621094,1.04650878906,0.460572282658,0.0822245055756,99.0230407715,0.469055
+4596562,34,3000.5,535,2.75519305124,169,323,154,248.552324613,13.8159083472,2983125,248.0,234,491,257,360.017497084,27.0206681582,4320930,360.0,533,1287,754,1007.49466756,75.9852182182,12091951,1007.0,132,571,439,320.861689718,45.0525849555,3850982,316.0,0.324260354042,0.763180613518,0.438920259476,0.517324144863,0.0541727695286,6208.92438665,0.51798,551,1385,834,929.431511415,84.0771640931,11155037,924.0,-0.209411621094,1.37469482422,1.58410644531,0.0786458253662,0.161937561672,943.907196045,0.0
+4605269,33,1563.0,1002,7.14962560895,217,310,93,249.914747281,10.6512171207,1562467,248.0,294,456,162,347.133557262,20.3976600643,2170279,344.0,535,994,459,729.348208573,64.6472006247,4559885,717.0,255,503,248,335.880358285,30.9988868085,2099924,331.0,0.227272734046,0.51024210453,0.282969370484,0.368928546819,0.0354565329783,2306.54127471,0.368864,781,1269,488,932.928662828,60.0172109347,5832670,923.0,-0.169219970703,1.33612060547,1.50534057617,0.0871268606155,0.202686275411,544.717132568,0.0
+4577721,31,75.2500000019,53,1.72352538952,197,282,85,243.870431894,17.5307936802,73405,248.0,212,389,177,311.744186047,35.7185055067,93835,320.0,444,1284,840,957.92358804,188.80807498,288335,1008.0,131,382,251,263.870431894,49.1797147376,79425,275.0,0.36031588912,0.702202618122,0.341886729002,0.563924662299,0.0620370695117,169.741323352,0.571802,566,1052,486,819.485049834,100.648811872,246665,845.0,-0.0297241210938,1.18630981445,1.21603393555,0.189093605624,0.208940481751,56.917175293,0.180084
+4671122,21,2357.74999999,1749,10.1609894561,232,451,219,353.433676174,18.8404623728,3333233,352.0,360,752,392,552.879440144,31.7436147943,5214206,554.0,680,1262,582,981.521365709,50.0940494378,9256728,982.0,397,1114,717,740.575866822,55.2960793876,6984371,747.0,0.0345238111913,0.332443267107,0.297919455916,0.140572614585,0.0293018721042,1325.74032816,0.133894,1029,2317,1288,1646.88898314,97.4863642607,15531810,1656.0,-0.181213378906,3.51919555664,3.70040893555,0.089168748804,0.18956103211,840.950469971,0.0
+4536576,41,3.5,10,1.50786008773,240,252,12,244.785714286,3.02793119918,3427,245.0,302,325,23,310.285714286,6.13454587245,4344,309.0,210,282,72,254.785714286,20.4526581277,3567,260.5,264,292,28,277.357142857,9.04439165495,3883,273.5,-0.146341457963,0.0127504551783,0.159091913141,-0.0437298771659,0.0440003479624,-0.612218280323,-0.0307902,812,869,57,832.428571429,17.1035263102,11654,824.0,-0.00335693359375,0.0859069824219,0.0892639160156,0.017582484654,0.0298184957721,0.246154785156,0.0
+4530129,12,4.5,11,1.46278836147,214,262,48,235.5,13.6839321834,4239,233.0,254,358,104,292.222222222,25.1187304075,5260,284.5,399,549,150,461.388888889,37.3007877321,8305,458.5,190,333,143,243.0,39.5797366787,4374,232.5,0.229357793927,0.371874988079,0.142517194152,0.313640665677,0.0422190373916,5.64553198218,0.325805,663,953,290,770.722222222,76.5809706241,13873,762.5,0.0,0.0568237304688,0.0568237304688,0.00315856933594,0.0130157152687,0.0568542480469,0.0
+4514346,12,20.9999999991,36,2.21609269112,196,270,74,226.69047619,18.5683910825,19042,223.0,257,381,124,305.30952381,33.5115389475,25646,297.0,432,914,482,619.25,135.534381071,52017,569.5,182,378,196,261.214285714,46.2454814855,21942,250.5,0.266583234072,0.503250956535,0.236667722464,0.40209774602,0.0548284436001,33.7762106657,0.411001,636,1029,393,793.214285714,97.6979152954,66630,774.0,3.25549316406,4.62341308594,1.36791992188,4.00757271903,0.595875348262,336.636108398,4.4977
+4481619,12,2179.49999999,1110,6.70717457118,179,459,280,256.988300069,23.4472674884,2240424,255.0,228,676,448,365.037279192,44.3249291525,3182395,363.0,405,1494,1089,880.915806378,132.405974465,7679824,902.0,84,762,678,351.842624455,70.8043293094,3067364,345.0,0.132938191295,0.768595039845,0.63565684855,0.429105002836,0.0764653758294,3740.93741472,0.429425,529,1897,1368,973.868203716,134.895386368,8490183,961.0,-0.196136474609,3.67367553711,3.86981201172,0.453832011563,0.74336797038,3956.50747681,0.176987
+4423419,11,1080.75000002,493,4.23037985294,232,534,302,353.196160074,30.2328065176,1526867,362.0,309,847,538,528.459865834,60.1546964551,2284532,551.0,412,1232,820,720.383067314,75.2922252684,3114216,713.0,291,1204,913,663.281517465,75.920524684,2867366,684.0,-0.0495356023312,0.324725627899,0.37426123023,0.0420815616553,0.0450958090167,181.918591036,0.0238824,832,2585,1753,1544.93754337,159.037690745,6678765,1597.0,0.0304260253906,5.62161254883,5.59118652344,3.75160012211,0.959589092578,16218.1673279,4.08691
+4454778,22,2159.75000004,881,5.34772708025,339,694,355,491.61453872,38.2171896429,4247058,489.0,527,1078,551,757.453408959,58.4429154962,6543640,753.0,805,1412,607,1080.92267624,72.6540213852,9338091,1077.0,685,1368,683,963.571941197,75.957810405,8324298,959.0,-0.0612244904041,0.179274618626,0.24049910903,0.0577930773007,0.0173827634374,499.274394801,0.0584984,1618,3090,1472,2212.63988888,164.018936952,19114996,2201.0,-0.123352050781,1.17303466797,1.29638671875,0.063693145812,0.118193590808,550.24508667,0.0
+4359210,34,2866.25000001,516,2.71886557395,201,325,124,249.696293066,10.4320721063,2862768,250.0,264,465,201,346.700828609,18.0992125566,3974925,348.0,678,1140,462,890.022939381,59.610353467,10204113,885.0,193,560,367,315.881290885,29.3807544855,3621579,315.0,0.268178254366,0.659609138966,0.3914308846,0.475659630946,0.0451779476389,5453.4376688,0.47619,676,1340,664,912.27841256,54.0868624338,10459272,913.0,-0.232849121094,1.39205932617,1.62490844727,0.0932857708072,0.200704025031,1069.5213623,0.0
+4471011,33,2234.25,1509,9.00571967706,197,369,172,267.057289918,14.2840502164,2386691,265.0,301,552,251,377.713662303,25.2262588107,3375627,373.0,656,1047,391,827.816828914,51.4113521381,7398199,821.0,260,664,404,389.784939018,42.9294247573,3483508,382.0,0.217391297221,0.503985822201,0.28659452498,0.360916267289,0.0339366811649,3225.50868076,0.362171,788,1585,797,1034.55589124,80.9026481896,9245826,1019.0,-0.053955078125,1.89810180664,1.95205688477,0.484287831799,0.321659531704,4328.08035278,0.424957
+4413490,11,188.249999997,114,2.3438640985,333,615,282,499.735723772,34.82367669,376301,500.0,478,904,426,725.19123506,50.0034854317,546069,726.0,492,940,448,786.131474104,51.9808165665,591957,788.0,438,981,543,789.690571049,62.2738980944,594637,793.0,-0.0589519664645,0.117940202355,0.17689216882,-0.00175264365837,0.0179975461845,-1.31974067475,-0.00184388,1345,2489,1144,2014.61752988,127.444792352,1517007,2021.0,0.0,3.82321166992,3.82321166992,2.8223316451,0.454395498215,2125.21572876,2.82999
+4422404,34,2629.25,823,4.52771374704,176,810,634,263.399448512,20.984953014,2770172,262.0,222,683,461,378.351526101,31.9980617222,3979123,377.0,526,1285,759,910.434249311,89.1680136405,9575037,916.0,173,753,580,370.436721499,52.2268578767,3895883,368.0,0.16678699851,0.609907150269,0.443120151758,0.421563082058,0.0616516564238,4433.578934,0.41875,609,2117,1508,1012.18769611,98.5541648464,10645178,1005.0,-0.221527099609,5.64068603516,5.86221313477,0.328027574148,0.846694930867,3449.86599731,0.0
+4349944,11,206.999999994,145,2.84300679378,225,449,224,365.22826087,34.404665218,302409,372.0,298,727,429,557.933574879,67.3565871976,461969,576.0,372,1033,661,764.596618357,98.7994312808,633086,783.0,253,943,690,690.739130435,99.242673662,571932,704.0,-0.0260492041707,0.193548381329,0.219597585499,0.052105343512,0.0314904753361,43.1432244279,0.0471221,795,2100,1305,1613.90096618,191.291762764,1336310,1666.0,0.283966064453,4.2936706543,4.00970458984,3.17357602327,0.983735836355,2627.72094727,3.52724
+4323566,11,23.7500000009,36,2.08384667705,235,366,131,308.915789474,26.1878489934,29347,306.0,320,479,159,412.663157895,31.8270360167,39203,413.0,465,650,185,573.578947368,37.9036393052,54490,580.0,328,530,202,450.842105263,40.3579551382,42830,457.0,0.0750695094466,0.18325792253,0.108188413084,0.120710630244,0.0237294395745,11.4675098732,0.116054,916,1345,429,1172.42105263,86.2223049598,111380,1182.0,-0.0426330566406,2.44186401367,2.48449707031,0.842477577611,0.549710772168,80.035369873,0.806396
+4405065,33,4468.24999992,1149,4.84893502488,220,374,154,268.33452694,8.60032458191,4795943,268.0,298,534,236,374.023722934,14.6617620288,6684926,373.0,568,911,343,674.429978179,25.5319379069,12054087,671.0,269,671,402,417.73636211,23.6036360854,7466202,417.0,0.139344260097,0.451580017805,0.312235757709,0.235310109745,0.0229798076219,4205.69759147,0.231946,810,1556,746,1060.09461198,45.4013484141,18947071,1058.0,-0.176574707031,1.18588256836,1.36245727539,0.0588104669792,0.117480344514,1051.11947632,0.0
+4284860,31,78.2500000019,46,1.46693451329,195,285,90,244.891373802,18.6931080831,76651,248.0,225,388,163,321.252396166,33.0565910691,100552,329.0,528,1155,627,902.555910543,145.152242117,282500,924.0,128,413,285,283.293929712,58.6078361787,88671,285.0,0.364238411188,0.686673462391,0.322435051203,0.521302596163,0.0735215204391,163.167712599,0.525854,554,1063,509,849.437699681,107.964658682,265874,863.0,-0.320343017578,0.680908203125,1.0012512207,0.0184822448145,0.0806294489798,5.78494262695,0.0
+4318540,34,855.250000009,308,2.97097668093,203,347,144,264.56737796,17.0000061848,905085,264.0,251,510,259,363.199649225,29.8613019061,1242506,362.0,598,1182,584,897.798304589,75.6934555928,3071368,903.0,181,603,422,352.938906752,53.7516679728,1207404,350.0,0.229095846415,0.626535654068,0.397439807653,0.436827332008,0.0605004473126,1494.3863028,0.439873,636,1444,808,980.705933937,98.5320228915,3354995,976.0,0.453094482422,2.6337890625,2.18069458008,1.01282517055,0.363264036642,3464.87490845,0.928864
+4256520,34,114.500000003,89,2.34629346661,233,282,49,255.272925764,7.84106370885,116915,255.0,324,407,83,362.565502183,15.3005219346,166055,362.5,727,1015,288,837.410480349,45.7920787398,383534,833.0,260,399,139,320.323144105,21.3013404806,146708,321.0,0.374608159065,0.557788968086,0.183180809021,0.446514938401,0.0271776917796,204.503841788,0.444092,819,1084,265,938.161572052,42.1489882826,429678,940.0,-0.0656433105469,0.767059326172,0.832702636719,0.0908226446293,0.156440118626,41.5967712402,0.000564575
+4255260,12,7.24999999977,14,1.4667432572,177,230,53,205.310344828,14.1448259049,5954,204.0,212,307,95,251.482758621,26.1700285134,7293,250.0,602,796,194,671.482758621,50.595502519,19473,679.0,133,258,125,193.068965517,34.1628261716,5599,193.0,0.4375,0.694252848625,0.256752848625,0.554639790593,0.0611756318787,16.0845539272,0.533719,525,792,267,649.862068966,73.2269613707,18846,661.0,0.0,0.0,0.0,0.0,0.0,0.0,0.0
+4248906,34,1986.25000002,1183,7.48794865038,201,351,150,252.18464443,14.2726931761,2003607,252.0,248,510,262,337.071491504,26.9988121614,2678033,336.0,563,1100,537,817.466960352,68.3243178337,6494775,816.0,167,600,433,314.723222152,43.0270662332,2500476,312.0,0.274486094713,0.652613818645,0.378127723932,0.445168761966,0.0461969819368,3536.86581382,0.445306,621,1461,840,903.979358087,82.6657958849,7182116,900.0,-0.164093017578,5.61169433594,5.77578735352,2.55984624979,0.826684630619,20337.9784546,2.62015
+4230153,32,249.249999993,143,2.55513306457,233,316,83,277.129388164,12.577475406,276298,276.0,304,471,167,396.382146439,23.4555727683,395193,396.0,669,990,321,821.884653962,52.5624215546,819419,820.0,290,546,256,431.352056169,39.7117677999,430058,430.0,0.219923377037,0.403984069824,0.184060692787,0.312247161207,0.0327365725477,311.310419723,0.310939,834,1332,498,1104.86359077,74.2449215332,1101549,1101.0,-0.288299560547,1.0647277832,1.35302734375,0.0679780124064,0.122787896753,67.7740783691,0.0
+4233818,34,2867.74999999,559,2.94466728677,194,354,160,255.951617121,14.9649873168,2936021,254.0,267,532,265,377.268328829,28.1556815079,4327645,377.0,582,1274,692,992.165024845,77.4109281748,11381125,987.0,193,625,432,347.88701944,48.7723845568,3990612,344.0,0.269703537226,0.654639184475,0.384935647249,0.480995601516,0.0596612348379,5517.500545,0.480258,693,1511,818,981.106965391,88.4528294539,11254278,974.0,-0.165893554688,1.48733520508,1.65322875977,0.146127802733,0.185196847592,1676.23202515,0.052124
+4222387,41,1309.25,211,1.64500124887,289,386,97,352.367576857,5.69331763359,1845349,352.0,489,636,147,593.213481001,11.5520864936,3106659,595.0,526,757,231,584.186939087,19.9594585596,3059387,581.0,641,859,218,813.185793393,19.2632696591,4258654,816.0,-0.226470589638,0.0138181820512,0.240288771689,-0.163920981381,0.0238376854846,-858.454179491,-0.16954,1443,1847,404,1758.76685125,31.220260473,9210662,1763.0,-0.300445556641,1.50323486328,1.80368041992,0.0322530883766,0.140934755316,168.909423828,0.0
+4163059,34,56.2499999988,39,1.46689291724,216,255,39,235.257777778,8.34879868641,52933,235.0,281,347,66,315.715555556,14.4631017966,71036,314.0,814,1271,457,1030.40888889,100.22606408,231842,1016.0,203,332,129,269.115555556,25.8049948271,60551,268.0,0.501126945019,0.697240889072,0.196113944054,0.583997631603,0.0441188218436,131.399467111,0.578565,709,932,223,820.088888889,46.3624475541,184520,817.0,-0.103576660156,0.581115722656,0.684692382812,0.0647511121962,0.173390124991,14.5690002441,0.0
+4199713,51,17.75,32,2.1426235184,154,354,200,237.126760563,40.6766464395,16836,238.0,218,535,317,345.647887324,59.536259183,24541,332.0,387,679,292,503.492957746,62.3456682118,35748,506.0,192,544,352,319.478873239,69.4493146124,22683,312.0,0.110384300351,0.358437925577,0.248053625226,0.229866511595,0.0535381873352,16.3205223233,0.228507,639,1419,780,902.253521127,146.67600765,64060,856.0,0.120269775391,4.91165161133,4.79138183594,0.635741757675,1.20281712872,45.1376647949,0.200958
+4199278,51,8.75,25,2.38413613504,212,296,84,243.8,20.2665100245,8533,238.0,241,393,152,295.857142857,35.0217425178,10355,292.0,385,571,186,464.314285714,51.9641477661,16251,463.0,152,353,201,252.485714286,49.7854662835,8837,243.0,0.163017034531,0.43389198184,0.270874947309,0.300262092693,0.0622825927517,10.5091732442,0.295638,605,1042,437,792.142857143,102.171883987,27725,765.0,0.0,1.81842041016,1.81842041016,0.946465192522,0.602222350297,33.1262817383,1.2652
+4142766,33,2589.00000004,1304,7.22947290122,205,351,146,255.651892623,13.2100789942,2647531,254.0,260,486,226,349.860081112,23.0317811928,3623151,347.0,588,1094,506,779.08198146,42.9836120354,8068173,775.0,241,616,375,371.480204712,41.1581033224,3847049,367.5,0.188940092921,0.516504883766,0.327564790845,0.355604067068,0.0385875255098,3682.63571855,0.354305,706,1442,736,976.992178447,75.2641597277,10117731,970.0,-0.265563964844,1.29043579102,1.55599975586,0.111766651635,0.19986833602,1157.45544434,0.0
+4097083,11,26.2500000009,29,1.59671870162,434,713,279,597.219047619,52.0711931974,62708,611.0,637,1018,381,844.942857143,67.0497794565,88719,857.0,695,1061,366,891.533333333,78.667966091,93611,895.0,610,1086,476,892.771428571,85.1828573345,93741,893.0,-0.0361842103302,0.0658342763782,0.102018486708,-0.000337998582316,0.019851698137,-0.0354898511432,-0.00613497,1729,2788,1059,2334.93333333,178.825920496,245168,2339.0,0.0384826660156,0.686584472656,0.648101806641,0.128646995908,0.0730641303779,13.5079345703,0.119537
+4103055,34,1252.74999998,566,4.51106716649,224,334,110,268.826980643,11.2357494587,1347092,268.0,298,492,194,378.492117342,19.2498224736,1896624,377.0,659,997,338,809.706246258,38.0776748029,4057438,806.0,240,610,370,411.316304131,35.4782915515,2061106,409.0,0.204768583179,0.517102599144,0.312334015965,0.327100584498,0.029245044878,1639.10102892,0.326749,762,1436,674,1058.63540212,64.6790471623,5304822,1054.0,-0.0671997070312,1.06188964844,1.12908935547,0.104756571675,0.15325312006,524.935180664,0.00863647
+4043543,33,396.000000008,288,4.08262943833,243,322,79,272.773358586,12.497515807,432073,271.0,320,462,142,366.901515152,21.5863113127,581172,363.0,564,881,317,672.085858586,48.1753316314,1064584,669.0,343,555,212,427.786616162,33.9159116536,677614,421.0,0.112709835172,0.342245995998,0.229536160827,0.222005952037,0.0375701535938,351.657428026,0.221367,911,1305,394,1067.4614899,65.1046149724,1690859,1055.0,-0.0885314941406,1.38363647461,1.47216796875,0.172959722654,0.281675726785,273.968200684,0.00622559
+4029997,51,10.7500000005,20,1.72076209771,204,312,108,242.930232558,25.3132884937,10446,237.0,269,437,168,344.976744186,34.8167885006,14834,345.0,382,639,257,487.418604651,67.1746188773,20959,477.0,230,489,259,322.674418605,53.3277365461,13875,318.0,0.0767326727509,0.410256415606,0.333523742855,0.204233559412,0.0647107558937,8.7820430547,0.2,707,1222,515,910.581395349,106.288381863,39155,899.0,0.0309753417969,2.95037841797,2.91940307617,2.51399692269,0.441370075276,108.101867676,2.47287
+4017556,11,11.0,16,1.36087647946,320,408,88,370.0,20.5293581355,16280,370.0,447,615,168,566.409090909,36.9381043601,24922,568.0,576,796,220,730.25,41.9908675136,32131,736.5,473,728,255,626.295454545,53.1368642561,27557,629.0,0.0175438597798,0.145348832011,0.127804972231,0.0775407027792,0.0292834751504,3.41179092228,0.0771991,1240,1746,506,1562.70454545,104.813379512,68759,1557.0,0.277313232422,0.830383300781,0.553070068359,0.382083546032,0.104362888525,16.8116760254,0.387085
+4017215,22,652.999999994,334,3.68710023469,238,396,158,311.501914242,22.256242912,813643,310.0,335,619,284,472.523353752,39.5800387811,1234231,472.0,783,1245,462,1002.2737366,77.5564737142,2617939,1013.0,385,789,404,534.204441041,62.546554877,1395342,530.0,0.177100047469,0.405172407627,0.228072360158,0.305878467983,0.0351823056754,798.954558372,0.304684,1017,1799,782,1318.22970904,121.080570948,3443216,1313.0,-125,0.565246582031,0.690246582031,0.0785350711934,0.13130022704,205.133605957,0.0
+4002967,41,3404.99999999,1707,8.25220543454,198,372,174,259.097283407,16.0144898126,3528905,257.0,244,572,328,358.627459618,30.0687217416,4884506,355.0,506,1153,647,816.152643172,80.0548571348,11115999,817.0,146,731,585,354.786123348,55.5639304355,4832187,348.0,0.189406096935,0.674107134342,0.484701037407,0.395223902048,0.0586612197468,5382.94954589,0.396242,592,1675,1083,972.510866373,99.5736341562,13245598,960.0,-0.152374267578,1.79473876953,1.94711303711,0.230259807659,0.321780194627,3136.13858032,0.0968781
+3967770,14,518.499999996,337,4.1749433654,242,336,94,303.512536162,7.66361785331,629485,304.0,311,459,148,422.158630665,14.0622464278,875557,423.0,424,665,241,591.328351013,26.4745414815,1226415,590.0,316,592,276,524.261330762,25.5681474362,1087318,524.0,0.0239693187177,0.146596863866,0.122627545148,0.0602341346198,0.01070410002,124.925595202,0.0596491,871,1355,484,1249.93249759,43.3288125049,2592360,1252.0,-0.351593017578,1.26675415039,1.61834716797,0.105801897775,0.212499986071,219.433135986,0.0
+3985241,21,777.75000001,553,5.59371312109,238,430,192,321.539376406,16.6746518292,1000309,322.0,330,659,329,480.332690453,30.9661560021,1494315,481.0,530,1131,601,834.649630344,62.5758609929,2596595,841.0,338,915,577,633.841851495,55.9624770708,1971882,639.0,0.0443942807615,0.271268069744,0.226873788983,0.13721193483,0.027796931954,426.866329256,0.129094,906,1992,1086,1435.71391835,99.1777759375,4466506,1440.0,-0.129730224609,2.20291137695,2.33264160156,0.243811523673,0.416578529441,758.497650146,0.00811768
+4014784,32,1062.25,491,4.24974811793,258,360,102,313.349964698,13.0619628952,1331424,314.0,359,542,183,458.568604378,24.2837052613,1948458,459.0,684,994,310,838.697340551,46.1021070955,3563625,838.0,447,752,305,610.630501294,44.7745270157,2594569,611.0,0.11155115813,0.27879267931,0.16724152118,0.157870613421,0.0219784550076,670.792236425,0.154557,1064,1647,583,1382.54907037,79.7888039795,5874451,1385.0,-0.0476989746094,1.05065917969,1.0983581543,0.097079332028,0.123860487394,412.490081787,0.058197
+3960846,51,32.2500000007,60,2.98044738101,186,357,171,255.930232558,30.9976708419,33015,256.0,218,521,303,334.496124031,49.7807789611,43150,332.0,290,731,441,521.635658915,106.346438257,67291,522.0,191,569,378,342.620155039,80.0019567395,44198,339.0,-0.0180940888822,0.383812010288,0.40190609917,0.209035042883,0.0750907282952,26.9655205319,0.208054,657,1447,790,933.046511628,153.486906265,120363,925.0,0.0,4.43688964844,4.43688964844,0.550574014353,0.404986267937,71.0240478516,0.644287
+3941858,11,312.750000012,308,4.9130040857,215,475,260,350.238209432,39.5078538326,438148,344.0,318,720,402,520.898481215,59.6697419402,651644,515.0,507,1015,508,778.955235811,91.0431222799,974473,769.0,360,825,465,685.528377298,70.2689918038,857596,694.0,-0.0590979792178,0.221508830786,0.280606810004,0.0631080407374,0.0412534257944,78.9481589625,0.0661157,909,1995,1086,1556.66506795,144.315254276,1947388,1564.0,-0.421142578125,2.87664794922,3.29779052734,0.361713266106,0.326582562911,452.503295898,0.438232
+3911768,41,226.75,139,2.60397146241,216,364,148,308.082690187,26.4240042852,279431,317.0,349,542,193,468.253583241,56.4064990729,424706,483.0,498,835,337,645.558985667,48.7003482401,585522,643.0,352,691,339,557.003307607,97.9212438651,505202,584.0,-0.0798946470022,0.283825039864,0.363719686866,0.0798457910843,0.0852368023788,72.4201325134,0.072381,952,1569,617,1333.33958104,178.022691618,1209339,1385.0,-0.0945739746094,0.919738769531,1.01431274414,0.106575188852,0.176278512426,96.6636962891,0.0
+3928637,41,80.4999999953,101,3.17554668309,250,361,111,288.322981366,16.8545485629,92840,287.0,355,553,198,415.055900621,31.1232270212,133648,408.5,426,820,394,566.48447205,78.8494993497,182408,551.0,352,695,343,458.186335404,54.5827430432,147536,445.0,-0.00467289704829,0.213973805308,0.218646702357,0.103951115129,0.050214507234,33.4722590717,0.107836,965,1606,641,1161.56521739,98.9574714229,374024,1142.5,-0.843780517578,2.11102294922,2.9548034668,0.100561580303,0.317423366201,32.3808288574,-3.05176e-05
+3890761,33,1354.99999999,871,6.67488173625,205,386,181,283.908302583,22.1887384853,1538783,282.0,253,613,360,403.681918819,41.171447913,2187956,399.0,646,1148,502,874.637638376,76.2915778865,4740536,866.0,245,751,506,443.618634686,68.4344660768,2404413,439.0,0.158139541745,0.513704657555,0.355565115809,0.329636649694,0.0483334106724,1786.63064134,0.328491,703,1650,947,1131.20885609,128.246703255,6131152,1120.0,-0.0765991210938,1.16903686523,1.24563598633,0.102889057455,0.148087548308,557.658691406,0.0313568
+3840211,32,781.25,600,6.05551805285,219,382,163,285.40256,18.9460335017,891883,285.0,314,578,264,428.17312,32.6116020684,1338041,427.0,785,1201,416,946.5856,63.0109535925,2958080,944.0,279,711,432,451.66624,50.3721729158,1411457,449.0,0.239130437374,0.498201429844,0.25907099247,0.35515688138,0.0362397412879,1109.86525431,0.355215,812,1671,859,1165.24192,99.5802954139,3641381,1159.0,-0.0780944824219,0.954711914062,1.03280639648,0.0188697460938,0.060941731605,58.967956543,0.0
+3819188,41,1654.24999999,367,2.54542649661,257,338,81,309.0893154,8.56050141429,2045244,310.0,384,549,165,468.496448542,17.9420598158,3100041,472.0,290,534,244,360.484358471,20.9251659687,2385325,356.0,362,567,205,450.252984736,20.3006736289,2979324,452.0,-0.25257730484,0.0714285746217,0.324005879462,-0.11087237642,0.0344446254598,-733.642514773,-0.119593,1022,1454,432,1227.83874868,41.0550943425,8124609,1233.0,-0.0859680175781,1.16534423828,1.25131225586,0.0720620099846,0.18666898579,476.834320068,0.0
+3749095,34,35.9999999981,73,3.4321533,239,315,76,264.8125,15.7933568796,38133,262.0,321,447,126,363.729166667,26.1104009581,52377,357.0,641,853,212,733.979166667,43.5295986067,105693,726.5,312,510,198,394.493055556,40.4801042571,56807,387.5,0.214895263314,0.361423224211,0.146527960896,0.301986790987,0.0344556040556,43.4860979021,0.308612,876,1259,383,1023.03472222,79.0349266318,147317,1011.0,-0.0195617675781,0.492706298828,0.512268066406,0.12788412306,0.16093830083,18.4153137207,0.0358734
+3767381,22,452.749999989,284,3.76516643571,318,381,63,349.918277195,7.54811201852,633702,350.0,480,584,104,533.336278299,13.9043868935,965872,535.0,844,1010,166,939.704583103,33.147587176,1701805,944.0,658,814,156,743.423522916,23.6914194618,1346340,745.0,0.0943396240473,0.151552036405,0.0572124123573,0.116548612899,0.00953130166264,211.06953796,0.115566,1456,1779,323,1626.67807841,43.8349479452,2945914,1630.0,-0.0742492675781,1.14556884766,1.21981811523,0.0770558568406,0.110561704036,139.548156738,0.0440369
+3761910,12,15.5000000009,34,2.43617305786,175,275,100,236.161290323,22.0038072574,14642,240.5,219,378,159,298.112903226,34.8837261432,18483,303.0,481,831,350,660.161290323,98.7653121731,40930,667.0,147,384,237,258.758064516,53.0534379063,16043,260.0,0.322751313448,0.591666638851,0.268915325403,0.439282218775,0.0569275757783,27.2354975641,0.438008,541,1035,494,793.032258065,105.657842135,49168,810.0,-0.0523986816406,0.854187011719,0.906585693359,0.064205538842,0.208461972091,3.9807434082,0.0
+3756349,34,172.750000002,118,2.53260842501,223,356,133,262.348769899,13.5421807908,181283,261.0,305,510,205,366.285094067,22.11117929,253103,365.0,698,966,268,846.672937771,46.9340160021,585051,844.0,243,562,319,353.172214182,33.2879492263,244042,351.0,0.247657299042,0.52141058445,0.273753285408,0.411578734989,0.0418311668046,284.400905877,0.409781,776,1428,652,981.806078148,63.7388396005,678428,976.0,-0.194580078125,0.974182128906,1.16876220703,0.0429515258966,0.150510961054,29.6795043945,0.0
+3753977,11,15.5000000005,17,1.21808652895,397,498,101,460.290322581,26.7933472104,28538,467.0,599,694,95,657.177419355,26.7156618276,40745,663.0,622,818,196,693.548387097,40.3767249384,43000,687.0,633,730,97,685.048387097,20.2264816989,42473,686.0,-0.0246913582087,0.0568475462496,0.0815389044583,0.00554753414209,0.0193148288486,0.343947116809,0.0059209,1680,1902,222,1802.51612903,57.2343067477,111756,1811.5,-0.003173828125,0.00869750976562,0.0118713378906,0.000266782699093,0.00141141668152,0.0165405273438,0.0
+3762439,21,279.999999991,315,5.31039230943,226,460,234,344.878571429,25.2090453883,386264,343.0,297,628,331,509.4375,38.0824249983,570570,511.0,478,1034,556,861.15625,81.5492711289,964495,873.0,262,841,579,653.678571429,68.9804985751,732120,660.0,0.0119521915913,0.341708540916,0.329756349325,0.137492774835,0.0336250263148,153.991907815,0.138283,785,1860,1075,1507.99464286,122.956372808,1688954,1515.5,-0.0140991210938,1.56732177734,1.58142089844,0.493413407462,0.251562842587,552.623016357,0.456223
+3854526,31,28.0,26,1.38608352105,212,418,206,271125,40.1521937223,30366,257.0,284,563,279,371.6875,52.2206908996,41629,358.5,800,1217,417,1022.65178571,93.9602603898,114537,1027.5,226,466,240,302.669642857,50.1254476989,33899,294.5,0.34232211113,0.662011146545,0.319689035416,0.543236569901,0.0625705100253,60.8424958289,0.548995,731,1438,707,945.482142857,130.385827324,105894,918.5,0.129974365234,3.76196289062,3.63198852539,3.03175354004,0.706323900565,339.556396484,3.13411
+3751122,33,1986.00000001,927,5.8679334543,200,359,159,272.920568983,13.6020483721,2168081,272.0,262,535,273,380.531847936,23.2819800916,3022945,379.0,574,1047,473,784.645266868,46.0706558732,6233222,782.0,234,714,480,432.803121853,46.8812163821,3438188,431.0,0.154975533485,0.495145618916,0.34017008543,0.29029305799,0.0442752300697,2306.08805268,0.292643,734,1606,872,1086.25553877,81.2687496813,8629214,1082.0,-0.0711364746094,1.18933105469,1.2604675293,0.152611827562,0.143510050357,1212.34835815,0.130737
+3765972,34,2107.99999999,943,5.79390616678,222,351,129,268.55823055,13.9572801765,2264483,267.0,293,499,206,378.276091082,23.901891851,3189624,376.0,712,1256,544,913.089184061,53.0079754543,7699168,914.0,226,622,396,374.491935484,44.0302173436,3157716,368.0,0.232997477055,0.568290352821,0.335292875767,0.419120884976,0.0492627514902,3534.02730212,0.420245,743,1434,691,1021.32625712,79.2205741426,8611823,1011.0,-0.117218017578,1.11911010742,1.236328125,0.0894543721961,0.152349977907,754.279266357,0.0331573
+3958666,41,2285.24999999,1277,7.53562201886,217,353,136,279.534296029,13.3635822157,2555223,277.0,262,519,257,407.491521715,29.5329589966,3724880,401.0,328,823,495,495.25905262,75.8045369072,4527163,490.0,232,644,412,421.843014987,52.5898959742,3856067,405.0,-0.0748299285769,0.283549785614,0.358379714191,0.0776890233867,0.0574839430253,710.155362778,0.0718114,711,1502,791,1108.86883273,92.8298061273,10136170,1081.0,-0.363311767578,3.10153198242,3.46484375,0.14633934556,0.494712030141,1337.68795776,0.0
+3671515,34,3230.00000004,602,2.9880667719,194,302,108,246.948684211,9.05879905804,3190577,248.0,249,425,176,362.110758514,17.8228349211,4678471,364.0,604,1230,626,965.14876161,65.8321818505,12469722,962.0,155,442,287,314.031811146,27.5919205734,4057291,315.0,0.321336746216,0.677637159824,0.356300413609,0.508371861152,0.0428612914655,6568.16444609,0.506881,598,1164,566,923.09125387,52.000118638,11926339,928.0,-0.207061767578,1.49847412109,1.70553588867,0.140122114246,0.255216241553,1810.37771606,0.0
+3627605,34,1327.00000004,1028,7.96072682491,221,345,124,276.253579503,16.6683408716,1466354,275.0,282,506,224,388.321778448,28.4787775213,2061212,384.0,512,1104,592,829.805764883,60.0795609524,4404609,827.0,180,633,453,414.312170309,52.8427373041,2199169,407.0,0.183795943856,0.479768782854,0.295972838998,0.335443088623,0.0486295029679,1780.53191441,0.336851,691,1477,786,1078.88752826,95.1764729989,5726735,1066.0,-0.100830078125,2.19714355469,2.29797363281,0.121428701693,0.187903415882,644.543548584,0.0531311
+3642843,22,5181.25000001,3687,14.4494371943,248,447,199,370.566996381,14.3543106852,7680001,371.0,396,690,294,583.598069964,23.9727407748,12095070,584.0,772,1251,479,1052.57215923,37.0655373254,21814558,1053.0,467,952,485,787.479951749,39.0936094228,16320522,790.0,0.0752571746707,0.3111500144,0.23589283973,0.144355902871,0.0143125408475,2991.776087,0.141956,1124,2089,965,1741.64501809,73.9496282765,36095593,1744.0,-0.183624267578,1.74261474609,1.92623901367,0.0595284920061,0.129711951386,1233.72799683,0.0
+3588029,41,1384.74999997,449,3.40373485609,221,328,107,282.314316664,8.4484543592,1563739,282.0,325,533,208,443.972016609,16.7995986344,2459161,444.0,267,685,418,357.986640188,42.5073913507,1982888,345.0,323,633,310,427.669254378,52.2574592055,2368860,418.0,-0.214899718761,0.067385442555,0.282285161316,-0.0879219782393,0.0427432986011,-486.999837468,-0.0909091,869,1474,605,1153.95558765,70.9317315369,6391760,1144.0,-0.270050048828,0.463897705078,0.733947753906,0.000537553447359,0.0139162187052,2.97750854492,0.0
+3557525,34,434.000000005,373,5.05078677965,206,325,119,268.275345622,14.4536121327,465726,268.0,268,493,225,387.312788018,25.1771735284,672375,387.0,597,1068,471,910.187788018,52.4704150847,1580086,917.5,201,580,379,384.657834101,37.3679607327,667766,383.0,0.23482850194,0.5,0.26517149806,0.406628948306,0.0323717273663,705.907854259,0.408289,675,1388,713,1040.24596774,73.834710671,1805867,1039.0,-0.364868164062,1.40682983398,1.77169799805,0.0789800547235,0.163748104723,137.109375,0.0
+3543047,51,7.74999999884,15,1.51997160842,207,300,93,248.258064516,25.7142708488,7696,246.0,279,441,162,346.806451613,44.3791722108,10751,334.0,459,655,196,550.774193548,63.075331141,17074,547.0,209,366,157,276.838709677,47.4267494783,8582,288.0,0.238521829247,0.46097561717,0.222453787923,0.332884491451,0.0675995273947,10.319419235,0.344086,722,1089,367,871.903225806,94.3375390813,27029,838.0,0.0,0.830963134766,0.830963134766,0.362872708228,0.254088714233,11.2490539551,0.389008
+3553094,33,1768.50000005,973,6.52687621473,184,330,146,239.860899067,15.1745341406,1696776,239.0,256,527,271,337.782584111,29.3541342663,2389474,335.0,583,1157,574,851.838987843,57.5556836094,6025909,848.0,185,570,385,315.530392988,44.1665633899,2232062,310.0,0.202652916312,0.624746441841,0.422093525529,0.461123205618,0.0439367464536,3261.98555654,0.465925,636,1359,723,893.173876166,85.8290706323,6318312,885.0,-0.361755371094,3.16061401367,3.52236938477,0.399339709876,0.799864879065,2824.92910767,0.0
+3514068,34,42.7500000019,33,1.42377364084,230,280,50,249.035087719,9.21154547411,42585,248.0,326,398,72,357.947368421,14.3275235708,61209,356.0,833,1092,259,979.192982456,62.7944121429,167442,985.0,272,439,167,333.730994152,26.3031834654,57068,333.0,0.352029532194,0.58250194788,0.230472415686,0.490950397581,0.0401184903117,83.9525179863,0.492015,836,1109,273,940.713450292,46.2740981357,160862,934.0,-0.00238037109375,0.356597900391,0.358978271484,0.0501569781387,0.0722512878052,8.57684326172,0.0
+3506399,34,37.5,40,1.84263546385,223,286,63,251.166666667,12.8023001406,37675,251.0,311,424,113,356.846666667,22.785298379,53527,356.0,787,1072,285,928.513333333,63.6299443833,139277,922.5,274,447,173,339.826666667,36.8280231466,50974,336.0,0.353111445904,0.559618413448,0.206506967545,0.464103803039,0.0480075856851,69.6155704558,0.466453,812,1148,336,947.84,69.2405545905,142176,944.5,-0.0357666015625,0.145385742188,0.18115234375,0.0410732014974,0.0456469948567,6.16098022461,0.0295563
+3368173,14,638.749999994,462,5.15669668333,203,353,150,315.233268102,7.78258812794,805421,315.0,280,513,233,456.684931507,12.7720550178,1166830,456.0,507,801,294,692.446966732,29.5140522702,1769202,689.0,302,675,373,549.659882583,24.1476009024,1404381,547.0,0.0636583417654,0.253399252892,0.189740911126,0.114978834313,0.011251013596,293.77092167,0.115171,785,1541,756,1321.57808219,41.0932649912,3376632,1319.0,-0.118011474609,1.26968383789,1.3876953125,0.180706392949,0.284526233757,461.704833984,0.000732422
+3473419,41,389.000000034,247,3.53278510444,268,341,73,303.32840617,9.62407757565,471979,305.0,389,514,125,460.745501285,22.4983749557,716920,467.0,554,772,218,645.748714653,38.8955884936,1004785,648.0,457,658,201,571.942159383,41.0340067942,889942,582.0,-0.0471380464733,0.181746661663,0.228884708136,0.0608847067803,0.048014684641,94.7366037501,0.0551248,1119,1503,384,1336.01606684,70.3230819867,2078841,1360.0,-0.0594177246094,3.23577880859,3.2951965332,0.151385270538,0.471839002411,235.555480957,0.0
+3441175,12,7.50000000023,18,1.85411616968,193,268,75,221.433333333,19.0677447248,6643,218.5,241,371,130,296.866666667,33.0017507953,8906,296.0,419,764,345,568.933333333,97.5417631354,17068,560.0,146,371,225,249.366666667,55.9621796891,7481,248.0,0.255125284195,0.485915482044,0.230790197849,0.393910375237,0.0520192851399,11.8173112571,0.412614,580,997,417,767.666666667,107.431632006,23030,763.5,0.0,0.00149536132812,0.00149536132812,9.86735026042e-05,0.000324949717198,0.00296020507812,0.0
+3412599,21,1177.75000001,835,6.86364775121,206,444,238,322.105922309,19.3998368845,1517441,323.0,307,652,345,473.713012099,33.6473779002,2231662,477.0,522,1068,546,837.64975589,65.6557796742,3946168,847.0,328,899,571,624.876247081,56.5602318639,2943792,631.0,0.0689189210534,0.307366639376,0.238447718322,0.145903896505,0.0296890176593,687.353256434,0.142091,861,1995,1134,1420.69518149,102.365441269,6692895,1433.0,-0.0858764648438,5.70281982422,5.78869628906,0.387474278689,0.827204553304,1825.3913269,0.026001
+3466195,32,1151.25,1341,11.1490798073,213,353,140,282.704017372,18.0157704812,1301852,283.0,317,534,217,417.139413681,28.9403763741,1920927,417.0,706,1090,384,885.352225841,62.1321709296,4077047,884.0,332,693,361,468.000434311,44.4622349461,2155142,466.0,0.163548588753,0.434056758881,0.270508170128,0.308871319385,0.0355902873217,1422.35242577,0.310441,909,1567,658,1167.84386536,88.0675472908,5377921,1166.0,-0.179718017578,0.554260253906,0.733978271484,0.0484439216142,0.0932928309848,223.084259033,0.0
+3402616,51,3.75,9,1.31105811671,204,241,37,217.333333333,9.7479342541,3260,215.0,263,336,73,283.066666667,19.938126514,4246,274.0,483,664,181,542.933333333,45.9673313948,8144,539.0,210,324,114,244.666666667,30.9659311,3670,236.0,0.317269086838,0.453836143017,0.136567056179,0.379626347621,0.0396065978717,5.69439521432,0.37583,677,901,224,745.066666667,60.3594418647,11176,725.0,0.0,0.127868652344,0.127868652344,0.0448018391927,0.0496915485457,0.672027587891,0.015686
+3397938,31,30.0,26,1.33908390035,213,280,67,243225,11.1597957717,29187,244.0,275,383,108,327.291666667,21.8080244533,39275,331.0,641,1067,426,912.416666667,85.9354974514,109490,929.0,233,375,142,299.433333333,30.9264539764,35932,304.5,0.431545227766,0.599674522877,0.168129295111,0.505245796839,0.0343276357145,60.6294956207,0.504624,727,1037,310,869.95,62.4677049896,104394,885.0,-0.0664367675781,0.343688964844,0.410125732422,0.198769378662,0.115776825885,23.8523254395,0.232712
+3368367,12,2.0,7,1.39629798141,186,239,53,215125,17.898585838,1721,213.5,233,325,92,280875,29.9058418206,2247,278.5,600,791,191,672875,50.3026776126,5383,667.5,106,263,157,192375,51.9060148249,1539,191.0,0.463894963264,0.730279922485,0.266384959221,0.560897845775,0.0896770376713,4.4871827662,0.536902,525,827,302,688375,99.5149957293,5507,683.0,0.660491943359,4.07464599609,3.41415405273,1.98397445679,1.61881218177,15.8717956543,0.834335
+3359455,32,179.249999989,196,4.12972903572,222,310,88,260.548117155,12.0372266575,186813,260.0,306,474,168,388.221757322,22.1758453722,278355,389.0,798,1210,412,1010.13389121,58.3753920476,724266,1015.0,260,492,232,357.142259414,31.4939388811,256071,355.0,0.392592579126,0.582870721817,0.190278142691,0.477890058167,0.0292429592632,342.647171706,0.476879,800,1276,476,1005.91213389,63.3697553398,721239,1005.0,-0.0711364746094,0.769836425781,0.840972900391,0.0271875017025,0.113517118251,19.4934387207,0.0
+3275884,41,4959.25000045,2565,10.2748250633,225,364,139,264.305943439,6.79718734279,5243037,264.0,282,471,189,352.194737107,12.0528250569,6986487,351.0,301,789,488,386.717295962,40.6668444376,7671311,376.0,262,582,320,383.574633261,20.6315675519,7608970,384.0,-0.151098906994,0.283783793449,0.434882700443,0.00219097825366,0.0569218502995,43.4624356179,-0.00810811,774,1417,643,1000.07531381,37.4802930734,19838494,999.0,-0.183624267578,2.38153076172,2.5651550293,0.159208008219,0.309017732388,3158.20925903,0.0
+3287435,31,5.25,11,1.35427886676,240,260,20,246.952380952,5.71111022879,5186,246.0,315,359,44,330.619047619,12.487998774,6943,328.0,803,954,151,873.047619048,37.7491421416,18334,876.0,287,348,61,309.285714286,17.8969081053,6495,298.0,0.44406196475,0.505982935429,0.0619209706783,0.476887473038,0.0183677240937,10.0146369338,0.474498,847,965,118,886.857142857,35.1910239019,18624,868.0,3.10461425781,4.69482421875,1.59020996094,3.94045584542,0.533628862298,82.7495727539,4.01929
+3257651,11,8.00000000023,13,1.29656241129,449,574,125,511.0625,29.523229731,16354,510.5,627,843,216,772.34375,40.4749995174,24715,778.0,774,1031,257,921.5625,58.9962591505,29490,917.0,723,988,265,867.96875,55.6548989168,27775,872.0,-0.00854700896889,0.0600667409599,0.0686137499288,0.0299525071168,0.0196340291044,0.958480227739,0.0315771,1799,2405,606,2151375,118.589826187,68844,2145.5,-0.00677490234375,0.607635498047,0.614410400391,0.259282112122,0.2830851815,8.29702758789,0.000701904
+3235133,51,7.25000000047,15,1.57151063264,205,260,55,226.551724138,14.7521739062,6570,223.0,235,329,94,278.551724138,22.7498938336,8078,278.0,611,872,261,726.310344828,73.4166679601,21063,731.0,148,308,160,203.517241379,41.0522129183,5902,194.0,0.468662291765,0.649649620056,0.180987328291,0.564921795294,0.0461671357834,16.3827320635,0.571286,588,897,309,708.620689655,76.4687963376,20550,694.0,0.499908447266,1.50393676758,1.00402832031,0.622434418777,0.249842232466,18.0505981445,0.527466
+3193523,34,272.249999999,193,3.29965423106,196,298,102,257.223140496,8.6163391916,280116,257.0,276,425,149,369.472910927,14.3204648131,402356,370.0,746,1143,397,1016.37557392,41.7766525262,1106833,1015.0,197,420,223,329.346189164,21.2786939462,358658,329.0,0.423476964235,0.608170866966,0.184693902731,0.510562401008,0.0252311056878,556.002454698,0.509346,669,1142,473,956.042240588,42.0132916234,1041130,957.0,-0.147705078125,1.18081665039,1.32852172852,0.120446351387,0.223976502675,131.16607666,0.0
+3198969,51,66.4999999935,83,2.87119267753,200,358,158,275.432330827,25.6968505395,73265,276.0,279,497,218,375.421052632,47.7494574273,99862,383.0,414,1003,589,717.669172932,151.286573745,190900,767.5,237,626,389,415.315789474,89.4344695135,110474,422.0,0.09375,0.40639269352,0.31264269352,0.265861496946,0.0610749707071,70.7191581875,0.265269,741,1468,727,1066.16917293,153.809879069,283601,1085.5,-0.0961303710938,3.19580078125,3.29193115234,0.855750291867,1.0668953583,227.629577637,0.0195465
+3177456,41,334.249999997,193,2.97794497652,240,396,156,266.657442034,13.7794658359,356521,263.0,303,482,179,341.281226627,19.6700201433,456293,337.0,299,611,312,397.30815258,44.0614163155,531201,389.0,371,659,288,440.089005236,26.4689373325,588399,437.0,-0.216251641512,0.118644066155,0.334895707667,-0.0529870305475,0.0542929521197,-70.843659842,-0.0569697,931,1482,551,1048.0276739,53.7196243234,1401213,1036.0,-0.00863647460938,1.75189208984,1.76052856445,0.192403423849,0.387928662391,257.243377686,0.0
+3176687,12,11.5000000005,19,1.58051910094,217,335,118,253.760869565,29.8359170643,11673,239.5,252,467,215,325.0,55.4660099599,14950,310.0,377,689,312,481.913043478,76.2021984411,22168,454.5,230,516,286,317.826086957,76.3642029578,14620,284.5,0.0643699020147,0.308677107096,0.244307205081,0.211306873547,0.0534484410187,9.72011618316,0.219795,699,1318,619,896.586956522,160.389956327,41243,822.5,3.35308837891,3.53436279297,0.181274414062,3.41044616699,0.0415428207241,156.880523682,3.40778
+3177107,34,1892.24999998,1337,8.670361761,176,280,104,228.371911745,13.2732995907,1728547,229.0,230,420,190,316.088651077,23.5600264592,2392475,316.0,781,1273,492,978.06632316,64.0968049931,7402984,973.0,136,398,262,262.120359361,33.7003876139,1983989,263.0,0.459239125252,0.741198837757,0.281959712505,0.578386250186,0.034283245576,4377.80552766,0.57541,542,1077,535,806.580922183,69.4815527929,6105011,809.0,-0.235961914062,3.34368896484,3.57965087891,1.47359664217,1.04043324764,11153.6529846,1.89908
+3131495,34,25.0000000007,28,1.57973083391,236,283,47,252.45,7.47980614722,25245,252.0,312,378,66,341.47,11.7383601921,34147,340.0,821,1075,254,954.2,57.7640026314,95420,959.0,274,404,130,311.31,23.3498158451,31131,310.0,0.383177578449,0.57068836689,0.187510788441,0.507292332053,0.0390975697045,50.7292332053,0.514274,831,1065,234,905.23,40.0841252867,90523,904.0,-0.0892028808594,0.415893554688,0.505096435547,0.17340057373,0.131252492976,17.340057373,0.196121
+3167163,21,5932.75000001,3641,13.3348373536,256,384,128,313.768404197,13.1865241475,7446038,314.0,347,574,227,460.373182757,23.5855534568,10925116,460.0,546,997,451,802.115755763,44.7897240504,19035009,804.0,363,779,416,632.460789684,38.5262143861,15008927,634.0,0.0651041641831,0.220190197229,0.155086033046,0.118382104634,0.0158573522288,2809.32572508,0.116037,976,1704,728,1406.60237664,69.3502712075,33380081,1407.0,-0.148712158203,4.41452026367,4.56323242188,0.0794878540065,0.255257112319,1886.32626343,0.0
+3160408,34,1172.24999997,985,8.11561017151,193,338,145,258.066325443,11.7726415515,1210073,257.0,243,490,247,354.079121348,20.9675517624,1660277,352.0,590,1028,438,830.3017701,47.5411350441,3893285,830.0,204,636,432,366.030283643,37.7903988607,1716316,361.0,0.208333328366,0.53057551384,0.322242185473,0.388740666346,0.0417158583051,1822.8049845,0.391304,641,1463,822,978.175730433,67.7990287217,4586666,970.0,-0.166717529297,1.98724365234,2.15396118164,0.128864095521,0.261506827689,604.243743896,0.0
+3127870,32,1145.75000001,879,7.32552930604,216,352,136,269.674230853,14.154046558,1235917,268.0,318,539,221,402.324896356,24.4481988962,1843855,400.0,788,1218,430,996.392755837,46.5533815476,4566468,998.0,259,604,345,390.622081606,37.3274178267,1790221,387.0,0.334902882576,0.540211200714,0.205308318138,0.437624664428,0.0298623030081,2005.63383707,0.437993,793,1495,702,1062.62120882,74.5365906281,4869993,1056.0,-0.0664367675781,1.22601318359,1.29244995117,0.0253493866493,0.0814745351646,116.176239014,0.0
+3138279,21,997.00000001,687,6.13767977388,268,390,122,317.949097292,13.1766665097,1267981,316.0,342,598,256,469.140170512,20.8095958396,1870931,466.0,689,1079,390,880.460381143,32.620668434,3511276,882.0,436,825,389,699.385406219,29.5690741841,2789149,702.0,0.0556309372187,0.249253734946,0.193622797728,0.114709026103,0.012487069222,457.459596097,0.113238,1068,1789,721,1486.47467402,51.6686807285,5928061,1486.0,-0.0789489746094,1.26638793945,1.34533691406,0.144505040696,0.215956309418,576.286102295,0.0484924
+3080324,12,242.499999993,226,4.09399808964,203,490,287,312.45257732,32.4286420199,303079,312.0,258,773,515,449.734020619,58.5729026519,436242,449.0,412,1161,749,700.610309278,97.2525286391,679592,700.0,220,1081,861,571.292783505,95.6159136212,554154,576.5,0.00246507814154,0.306293696165,0.303828618024,0.104083280412,0.0383271595263,100.960781999,0.102198,681,2344,1663,1333.47938144,184.069580321,1293475,1340.0,-0.0448608398438,3.75769042969,3.80255126953,1.57966034879,1.33877167023,1532.27053833,2.31438
+3104595,34,1658.25000003,937,6.49097080673,207,390,183,281.174430876,19.1033245646,1865030,278.0,265,552,287,390.351273933,32.3207101204,2589200,387.0,520,1114,594,809.472787577,60.0878990025,5369233,808.0,195,707,512,426.904568069,58.9331590088,2831658,419.0,0.144061848521,0.509433984756,0.365372136235,0.311476414369,0.0521739686262,2066.02305651,0.31292,668,1590,922,1098.43027288,105.606430804,7285888,1084.0,-0.232055664062,4.25454711914,4.4866027832,0.181088557273,0.44852355247,1201.16040039,0.0
+3183126,21,18289.75,6625,13.8190142921,205,450,245,336.139600049,20.0934017122,24591637,335.0,308,718,410,532.329187113,37.3135517094,38944671,534.0,631,1311,680,987.369537583,58.0355713161,72234968,987.0,334,994,660,741.189163329,64.584753904,54224658,753.0,0.0396270379424,0.374893248081,0.335266210139,0.1434095177,0.0324172682514,10491.6969054,0.134459,851,2118,1267,1609.65795049,114.783247472,117760966,1625.0,-0.444763183594,2.73883056641,3.18359375,0.155369678476,0.202379504026,11366.6903076,0.106262
+3082390,32,1195.25000001,628,5.12419130909,235,398,163,311.360803179,21.2949359501,1488616,310.0,352,618,266,478.229449906,35.6704550344,2286415,476.0,859,1318,459,1071.9470822,59.7578632447,5124979,1071.0,328,720,392,519.544446768,55.7658620954,2483942,516.0,0.248606473207,0.484615385532,0.236008912325,0.348501252732,0.0329366059205,1666.18448931,0.348186,921,1736,815,1309.13469985,110.627537487,6258973,1302.0,-0.113250732422,0.978637695312,1.09188842773,0.0179435061351,0.0727112093566,85.787902832,0.0
+3090337,34,341.249999981,162,2.47385221893,211,325,114,255.598534799,11.9552277427,348892,255.0,268,470,202,358.920879121,20.3534600733,489927,358.0,635,1208,573,932.798534799,73.2118187234,1273270,932.0,221,503,282,333.421245421,34.7237215461,455120,333.0,0.309719920158,0.617993056774,0.308273136616,0.472844938655,0.0478542422055,645.433341265,0.472637,700,1297,597,947.940659341,62.6918751032,1293939,945.0,-0.0234680175781,4.03485107422,4.0583190918,0.258900334285,0.661381764512,353.398956299,0.0
+3021055,51,34.2500000019,78,3.75975359054,192,330,138,270.744525547,25.5760007252,37092,271.0,221,461,240,374.547445255,40.250487743,51313,379.0,464,869,405,671.540145985,86.8429251222,92001,680.0,222,528,306,381.708029197,56.0335093414,52294,384.0,0.15452362597,0.376777261496,0.222253635526,0.27559202594,0.0513851647451,37.7561075538,0.28103,735,1311,576,1027.0,110.672595333,140699,1038.0,-0.0555114746094,4.91455078125,4.97006225586,2.52112618328,2.0018416203,345.394287109,3.70877
+3029779,12,9.75,19,1.71651009178,195,262,67,223.871794872,18.2899432745,8731,216.0,256,359,103,301.307692308,32.1145017536,11751,291.0,510,719,209,580.897435897,61.8583140658,22655,553.0,195,363,168,268.205128205,51.1349042753,10460,250.0,0.265135705471,0.46822309494,0.203087389469,0.372380538629,0.0495363471788,14.5228410065,0.383033,657,978,321,793.384615385,100.878097388,30942,750.0,-0.0357055664062,0.0835266113281,0.119232177734,0.00201963767027,0.0167800945061,0.0787658691406,0.0
+3029319,12,9.00000000093,19,1.78660034781,201,261,60,230.555555556,12.8332130826,8300,231.5,250,340,90,296.611111111,19.6642339989,10678,296.5,393,569,176,468.305555556,41.4144496016,16859,471.5,215,364,149,274.444444444,34.0591352115,9880,274.5,0.206572771072,0.372262775898,0.165690004826,0.26239153453,0.0340009714688,9.4460952431,0.26102,666,962,296,801.611111111,65.4502685581,28858,807.5,1.90777587891,3.18338012695,1.27560424805,2.39136081272,0.541970700466,86.0889892578,2.08415
+3073288,21,2454.24999997,1271,7.23737737987,283,383,100,353.37740654,8.350139841,3469106,354.0,421,602,181,551.11317103,14.5518615245,5410278,552.0,769,1038,269,954.941631863,23.33078465,9374662,957.0,508,827,319,740.953244372,22.9981941423,7273938,743.0,0.0739081725478,0.208114206791,0.134206034243,0.126263755437,0.0092785610637,1239.53128713,0.125073,1212,1782,570,1645.44382194,42.0770468526,16153322,1649.0,-0.0664367675781,1.2751159668,1.34155273438,0.0772381343727,0.161534252543,758.246765137,0.0
+2999833,34,890.750000012,427,4.03594303227,201,336,135,266.376368229,11.646253491,949099,267.0,315,514,199,373.594442885,19.2483872718,1331117,374.0,701,1182,481,913.372719618,49.2439813218,3254347,912.0,243,556,313,351.495369071,31.7598105558,1252378,353.0,0.304484665394,0.599340498447,0.294855833054,0.444372980967,0.0401393986746,1583.30093119,0.440964,789,1406,617,991.466180185,58.8070064872,3532594,993.0,-0.100433349609,4.005859375,4.10629272461,0.425772470736,0.963958067224,1517.02731323,0.0
+3032357,33,2389.24999999,2218,12.8004669452,213,328,115,258.655017265,10.6433600181,2471966,258.0,253,453,200,340.522548917,19.0845209011,3254374,340.0,457,845,388,661.081720205,40.3484627829,6317958,661.0,226,572,346,380.625300827,29.7251460036,3637636,381.0,0.171568632126,0.399756997824,0.228188365698,0.26963714771,0.0223990197464,2576.92222066,0.269694,692,1350,658,979.802867008,57.0447384693,9363976,978.0,-0.0523681640625,2.67108154297,2.72344970703,0.529680300572,0.495125800517,5062.15463257,0.364014
+3003868,11,34.0000000019,40,1.93515430656,905,1327,422,1080.04411765,77.260908962,146886,1075.5,1389,2023,634,1618.92647059,109.877581102,220174,1600.0,1506,2566,1060,1877.01470588,151.463836943,255274,1857.0,1378,2505,1127,1783.88970588,160.811575563,242609,1768.0,-0.00508788181469,0.0483824796975,0.0534703615122,0.0258145911725,0.0099993734714,3.51078439946,0.0259411,3739,5789,2050,4482.86029412,313.482459702,609669,4457.0,0.0,0.137359619141,0.137359619141,0.00197399363798,0.0133280582117,0.268463134766,0.0
+3004180,34,4191.00000005,1976,8.61039703705,178,322,144,251.000596516,14.9844666132,4207774,251.0,224,484,260,344.366022429,30.3019502567,5772952,346.0,484,1210,726,868.803447864,92.9454121501,14564621,877.0,132,564,432,310.40694345,50.3776727926,5203662,309.0,0.276800006628,0.695049524307,0.418249517679,0.474269044587,0.0583491524247,7950.64626345,0.47163,534,1358,824,905.773562396,93.1341272954,15184388,905.0,-0.148468017578,2.98046875,3.12893676758,0.456601924983,0.46085687167,7654.47467041,0.329651
+3011771,21,794.999999992,385,3.85187542658,275,371,96,328.009748428,14.203160887,1043071,328.0,389,559,170,484.26509434,26.8825978026,1539963,486.0,658,934,276,807.919811321,52.8182136726,2569185,812.0,495,763,268,644.422327044,43.9918153293,2049263,649.0,0.0425824187696,0.19969278574,0.15711036697,0.112649166276,0.0164827123618,358.224348757,0.112278,1169,1686,517,1456.69716981,82.9496084328,4632297,1466.0,-0.156280517578,1.12393188477,1.28021240234,0.0877192851133,0.159258233051,278.94732666,0.0
+2963146,22,5890.00000001,5192,19.0841184914,309,485,176,416.72508489,15.3367053841,9818043,417.0,499,802,303,685.585356537,24.0374428036,16152391,686.0,903,1351,448,1178.32449066,33.5114089161,27761325,1179.0,603,1129,526,954.36893039,35.5190252811,22484932,955.0,0.0626242533326,0.199203193188,0.136578939855,0.10515000454,0.00891422702898,2477.33410696,0.104646,1411,2399,988,2056.67937182,69.4696883902,48455366,2059.0,-0.207061767578,0.833618164062,1.04067993164,0.0383048195183,0.0940910582382,902.461547852,0.0
+2994677,34,3260.25000004,1596,7.88501462539,205,330,125,252.007131355,11.1670583754,3286425,251.0,263,511,248,343.840196304,22.8991363305,4484020,344.0,499,1086,587,785.347289318,76.5685663398,10241714,786.0,197,563,366,331.279733149,34.1262148202,4320219,328.0,0.246511623263,0.58858269453,0.342071071267,0.405852579759,0.0439645207311,5292.72349264,0.405959,676,1360,684,927.127060808,65.4582288952,12090664,922.0,-0.371124267578,3.50521850586,3.87634277344,0.382538866772,0.607159490832,4988.68936157,0.0254211
+2927010,34,1131.25,447,3.74906780453,202,365,163,251.059226519,11.9833044751,1136043,251.0,273,526,253,367.062983425,20.4152312857,1660960,368.0,780,1306,526,1051.50497238,76.1655700673,4758060,1051.0,174,616,442,323.035801105,35.819906192,1461737,321.0,0.287861257792,0.720345616341,0.432484358549,0.529324174046,0.0499825493423,2395.19188756,0.527138,666,1507,841,941.15801105,65.6225638699,4258740,939.0,-0.162536621094,1.88446044922,2.04699707031,0.380559695755,0.349471968739,1722.03262329,0.350861
+2929131,21,3615.25,2309,10.833027198,252,401,149,351.039416361,14.0872137347,5076381,351.0,371,627,256,553.915980914,19.7372284084,8010179,555.0,736,1095,359,952.586888874,28.8922681907,13775359,953.0,454,896,442,759.537998755,30.4893047161,10983679,761.0,0.0733886435628,0.250206440687,0.176817797124,0.112918129661,0.0117911788837,1632.90907302,0.111111,1077,1904,827,1664.49339603,57.7898305906,24070239,1668.0,-0.172454833984,1.13006591797,1.30252075195,0.225526157994,0.183839019958,3261.33377075,0.206635
+2912444,34,397.499999981,375,5.305884223,203,343,140,251.265408805,12.1748270424,399512,251.0,274,513,239,366.780503145,20.9988977788,583181,368.0,742,1220,478,1012.58427673,60.3615324155,1610009,1016.5,189,540,351,322.309433962,32.563085927,512472,322.0,0.384413897991,0.653528869152,0.269114971161,0.517505582267,0.034017177538,822.833875805,0.520275,668,1396,728,940.355345912,63.5637461916,1495165,942.0,-0.157073974609,1.77056884766,1.92764282227,0.166112954961,0.349548598166,264.119598389,0.0
+2873486,22,1005.25000001,749,6.6640745191,285,543,258,425.717980602,30.2067244984,1711812,430.0,390,805,415,649.90350659,50.9780310719,2613262,657.0,756,1357,601,1131.50982343,66.5852374614,4549801,1139.0,373,1001,628,839.598109923,79.8105948381,3376024,855.0,0.046245649457,0.357450485229,0.311204835773,0.149474540604,0.032563946836,601.03712777,0.142272,1049,2228,1179,1915.21959712,154.410938408,7701098,1943.0,-0.102569580078,2.10302734375,2.20559692383,0.109330115405,0.196549242179,439.616394043,0.0
+2866166,32,409.999999998,254,3.53864386118,198,374,176,304.212195122,21.26984233,498908,304.0,313,580,267,464.346341463,34.0487032636,761528,464.0,748,1278,530,1062.51829268,54.397439027,1742530,1064.0,287,720,433,497.819512195,56.3385053072,816424,494.0,0.215273201466,0.507225453854,0.291952252388,0.363432462859,0.0404696783262,596.029239088,0.365442,798,1672,874,1266.37804878,109.029459014,2076860,1264.0,-0.0268859863281,0.412872314453,0.439758300781,0.0664781523914,0.101914259576,109.024169922,0.0
+3155368,14,3257.49998456,3166,15.6481776298,233,478,245,294.626630852,8.9589348769,3838985,294.0,311,667,356,404.581580967,14.4757631601,5271698,403.0,433,827,394,550.963775902,24.8732950371,7179058,547.0,273,816,543,434.897927859,24.9188002025,5666720,432.0,0.00657414179295,0.26181101799,0.255236876197,0.117989777138,0.0171026743774,1537.40679611,0.117296,837,1961,1124,1134.10613968,44.9990229354,14777403,1130.0,-0.276031494141,1.99795532227,2.27398681641,0.515220102236,0.571201462075,6713.31793213,0.289261
+2842784,11,179.75,140,2.94570094546,234,431,197,303.632823366,18.0819901089,218312,306.0,295,625,330,424.07232267,32.4349834149,304908,431.0,398,827,429,587.735744089,53.9305661804,422582,582.0,251,783,532,402.771905424,52.6474430337,289593,390.0,0.0273291934282,0.285412251949,0.258083058521,0.188237550905,0.0376629742456,135.342799101,0.194986,780,1839,1059,1130.47705146,90.3018379388,812813,1128.0,-0.0721130371094,4.93145751953,5.00357055664,3.28864302125,1.38364579828,2364.53433228,3.85471
+2836681,51,4.5,10,1.32980760134,202,248,46,222.222222222,12.8519585864,4000,218.5,276,353,77,302.222222222,22.6974192257,5440,291.5,588,782,194,649.111111111,55.4585820319,11684,631.0,200,316,116,240.833333333,34.1048220768,4335,228.0,0.391480743885,0.513382017612,0.121901273727,0.460599596302,0.0276579958846,8.29079273343,0.463897,678,914,236,765.277777778,68.7118019586,13775,735.5,0.0694885253906,0.992553710938,0.923065185547,0.569695366753,0.285313918406,10.2545166016,0.59108
+2841367,33,728.750000023,315,3.29167036773,241,285,44,258.406861063,6.03515893082,753256,258.0,310,388,78,335.430531732,10.457045729,977780,334.0,521,685,164,574.837049743,22.3332901424,1675650,573.0,307,441,134,352.390737564,17.6258615343,1027219,351.0,0.187134504318,0.298395723104,0.111261218786,0.240077997276,0.0148632641907,699.827362061,0.239957,863,1114,251,946.22813036,32.9421307314,2758255,943.0,-0.0312805175781,1.09094238281,1.12222290039,0.037913144146,0.106575406825,110.516815186,-3.05176e-05
+2826649,34,595.749999987,404,4.66922075792,180,349,169,271.975660932,18.5029127277,648118,271.0,254,530,276,388.983214436,31.4623937312,926947,390.0,473,1036,563,850.929920269,77.3016264962,2027766,863.0,216,566,350,399.222828368,48.9653190197,951348,398.0,0.206922501326,0.538461565971,0.331539064646,0.361812540502,0.0472023449971,862.199284017,0.361741,691,1418,727,1060.18170373,93.9179120378,2526413,1059.0,-0.0953369140625,1.94262695312,2.03796386719,0.222793367796,0.411083956248,530.916595459,0.00149536
+2858662,21,3091.25000003,1844,9.35597214243,240,443,203,385.132228063,16.3790937311,4762160,386.0,386,704,318,599.617064294,28.1354269247,7414265,601.0,664,1277,613,1035.87820461,45.8714571864,12808634,1037.0,441,960,519,801.031945006,45.8849740509,9904760,805.0,0.0862152948976,0.278232395649,0.192017100751,0.128164653066,0.0174442248173,1584.75593516,0.124373,1090,2091,1001,1785.78123736,87.5488505526,22081185,1793.0,-0.121917724609,1.47760009766,1.59951782227,0.0668424724327,0.1340036583,826.507171631,0.0
+2792510,22,3212.74999997,2687,13.3728590848,273,524,251,436.666718543,21.7355938595,5611604,438.0,420,845,425,702.268072524,36.347840001,9024847,705.0,770,1378,608,1160.42354681,48.0128423171,14912603,1165.0,453,1180,727,935.778694265,55.0759329024,12025692,942.0,0.0587138868868,0.279766261578,0.221052374691,0.107623735005,0.0139093714048,1383.07261856,0.105461,1150,2549,1399,2074.71348533,108.009133884,26662143,2087.0,-0.0857849121094,0.692321777344,0.778106689453,0.0314104197304,0.0773240672422,403.655303955,0.0
+2676708,12,7.0,12,1.27946171174,195,291,96,243.642857143,22.9100949142,6822,243.0,305,453,148,374.142857143,32.7061749147,10476,368.5,618,796,178,706.035714286,40.0066799269,19769,709.0,312,514,202,408.678571429,46.2169214307,11443,399.5,0.202202990651,0.354705274105,0.152502283454,0.268636920622,0.0332528356026,7.52183377743,0.262031,832,1258,426,1026.46428571,99.1393255341,28741,1012.5,0.0,0.236022949219,0.236022949219,0.0128653390067,0.0467215944383,0.360229492188,0.0
+2705718,22,5564.24999997,3575,13.5197231019,256,498,242,423.245675518,21.656843135,9420179,424.0,379,800,421,679.284809273,36.9561168931,15118842,681.0,761,1351,590,1131.66522892,51.9479897483,25187473,1135.0,423,1096,673,894.040661365,55.9468125753,19898663,899.0,0.0631726756692,0.305534482002,0.242361806333,0.117773249189,0.0164795882646,2621.2792072,0.115289,1058,2384,1326,1996.57114616,111.237097067,44437684,2004.0,-0.0831604003906,1.07473754883,1.15789794922,0.026788164718,0.0706868417582,596.224182129,0.0
+2662982,11,11.7499999995,16,1.31672814094,371,544,173,467.531914894,46.4743585509,21974,484.0,586,783,197,707.404255319,57.5298847684,33248,717.0,764,971,207,883.808510638,47.864453251,41539,888.0,696,920,224,812.787234043,47.0314228006,38201,819.0,-0.0239808149636,0.0930368602276,0.117017675191,0.0419346362233,0.0287622247097,1.9709279025,0.0409496,1695,2216,521,1987.72340426,140.388625066,93423,2010.0,0.0,1.10876464844,1.10876464844,0.268411189952,0.329827605112,12.6153259277,0.102051
+2649948,12,3.75,10,1.45673124079,224,283,59,257.933333333,20.5538858181,3869,262.0,283,386,103,343.066666667,34.3015386762,5146,353.0,431,578,147,513.066666667,47.370126545,7696,536.0,248,424,176,351.266666667,58.6940845022,5269,365.0,0.138211384416,0.269513994455,0.13130261004,0.191913381219,0.0396827114837,2.87870071828,0.189789,755,1092,337,952.266666667,113.39104413,14284,980.0,4.53631591797,4.58526611328,0.0489501953125,4.54831136068,0.0115056826061,68.2246704102,4.54474
+2664523,21,182.250000003,80,1.67167284013,295,434,139,383.208504801,18.825831831,279359,384.0,448,664,216,591.717421125,32.4377168053,431362,593.0,690,1103,413,977.611796982,48.8420811073,712679,982.0,491,892,401,762.530864198,53.5797747035,555885,768.0,0.0532951280475,0.189913317561,0.136618189514,0.124199521614,0.0171093737238,90.5414512567,0.122438,1250,1973,723,1737.45679012,103.204797855,1266606,1745.0,0.921844482422,2.79202270508,1.87017822266,1.40677118498,0.378105255474,1025.53619385,1.31247
+2652603,34,200.250000006,94,1.87385792242,235,285,50,261.390761548,8.14971424294,209374,261.0,322,419,97,368.528089888,15.4154136743,295191,369.0,712,1018,306,900.410736579,44.6246080098,721229,902.0,263,425,162,345.057428215,26.1248170385,276391,345.0,0.384615391493,0.575806438923,0.19119104743,0.446069378829,0.0290798817509,357.301572442,0.443163,829,1127,298,974.97627965,47.8085621346,780956,975.0,-0.034423828125,3.71664428711,3.75106811523,0.552172371511,0.908316507088,442.29006958,0.0124512
+2632744,51,7.25,20,2.09534751026,218,305,87,252.448275862,25.4539289114,7321,248.0,272,424,152,331.689655172,44.654307008,9619,321.0,390,710,320,509.103448276,80.3747021564,14764,507.0,216,495,279,327.689655172,79.9362260669,9503,305.0,0.129135534167,0.345454543829,0.216319009662,0.224127534135,0.0555688917074,6.4996984899,0.216849,708,1214,506,911.827586207,147.345961405,26443,868.0,0.149963378906,0.827239990234,0.677276611328,0.333891769935,0.198662975557,9.68286132812,0.206268
+2654222,51,12.0000000005,20,1.62867503964,205,293,88,241.458333333,20.8596084309,11590,237.0,263,428,165,322.333333333,40.9859393234,15472,309.0,539,896,357,639.541666667,83.0183108149,30698,613.0,213,408,195,273.145833333,42.5132281293,13111,260.5,0.340227514505,0.466183573008,0.125956058502,0.402408340946,0.0323983919626,19.3156003654,0.403333,696,1129,433,836.9375,101.844122366,40173,796.0,-0.0258178710938,0.820770263672,0.846588134766,0.0589841206868,0.154568410613,2.83123779297,0.0
+2621205,31,59.5000000009,40,1.46283915537,205,330,125,249.638655462,19.2483683003,59414,249.0,232,490,258,326.869747899,39.5605568242,77795,328.5,499,995,496,836.647058824,105.050095152,199122,871.0,175,530,355,294.81092437,58.9396676142,70165,290.5,0.253521114588,0.628217339516,0.374696224928,0.480396825852,0.0654113801366,114.334444553,0.481621,615,1350,735,871.319327731,114.754281352,207374,872.5,-0.00628662109375,1.47988891602,1.48617553711,1.16578507624,0.424508376724,277.456848145,1.37177
+2628063,12,9.0,26,2.44482152871,183,259,76,221.916666667,16.8463233707,7989,221.5,230,360,130,286.027777778,23.3112825701,10297,286.0,450,654,204,520.805555556,56.0648530446,18749,506.5,178,405,227,265.0,38.3608596822,9540,261.5,0.235127478838,0.479532152414,0.244404673576,0.326408434245,0.0521891467831,11.7507036328,0.317682,591,1024,433,772.944444444,76.4841829852,27826,769.0,0.319702148438,2.01013183594,1.6904296875,0.861215379503,0.481472083675,31.0037536621,0.790573
+2660364,21,4859.75000004,3017,12.2085311024,213,834,621,318.517310561,18.8265206225,6191658,317.0,291,1002,711,484.049128042,30.8371527604,9409431,483.0,538,1158,620,882.966356294,54.1981918902,17163983,886.0,335,1155,820,680.557281753,51.5410142942,13229353,687.0,0.00129701686092,0.329670339823,0.328373322962,0.129892248863,0.0258236103396,2524.97542564,0.124638,866,2991,2125,1483.12372036,87.8695290831,28830442,1486.0,-0.224243164062,4.84103393555,5.06527709961,0.147104532252,0.581012797212,2859.56500244,0.0
+2647971,34,507.5,451,5.64746550066,187,521,334,276.720197044,26.1666605454,561742,276.0,221,919,698,379.932019704,45.6545748668,771262,378.0,460,1206,746,804.440394089,86.2313884758,1633014,812.0,184,987,803,400.937438424,68.6768224241,813903,400.0,0.0919158384204,0.545275568962,0.453359730542,0.337170989165,0.0623770546252,684.457108006,0.336431,638,2427,1789,1057.58965517,133.400650626,2146907,1053.5,-0.247680664062,4.2008972168,4.44857788086,0.159129776978,0.561752361409,323.033447266,0.0
+2654882,21,4578.49999996,1957,8.15876237417,271,396,125,331.969586109,11.4069588518,6079691,331.0,390,603,213,497.957518838,19.9395380585,9119594,498.0,698,1028,330,860.265534564,26.7238125074,15754903,861.0,506,852,346,684.937206509,26.0828769041,12543940,686.0,0.0642504096031,0.190243899822,0.125993490219,0.113573167155,0.0113719370822,2079.97898328,0.111406,1173,1851,678,1514.86431146,51.0780589066,27743225,1515.0,-0.889678955078,1.75561523438,2.64529418945,0.0970269503442,0.185387832345,1776.9515686,0.0
+2588803,12,111.5,77,2.05706663193,208,335,127,269.890134529,20.9857744147,120371,273.0,282,454,172,382.141255605,32.7690006121,170435,387.0,557,853,296,726.912556054,60.8654619729,324203,734.0,267,562,295,432.603139013,57.7288146765,192941,442.0,0.172870144248,0.371614307165,0.198744162917,0.256281608924,0.0368322768353,114.30159758,0.252445,766,1323,557,1084.63452915,108.754850706,483747,1104.0,-0.0870361328125,1.87774658203,1.96478271484,0.13128778432,0.389236507257,58.5543518066,0.0
+2591518,31,45.2499999995,38,1.59356349634,198,250,52,229.232044199,7.71174541645,41491,229.0,227,336,109,295.591160221,14.4852269679,53502,295.0,899,1312,413,1170.92265193,80.9796003617,211937,1184.0,141,308,167,247.44198895,22.5151441832,44787,248.0,0.56752872467,0.728846132755,0.161317408085,0.650642191178,0.0293039454976,117.766236603,0.652174,566,892,326,772.26519337,43.6663182789,139780,771.0,-0.0140991210938,0.532196044922,0.546295166016,0.392156948701,0.130533874396,70.9804077148,0.428131
+2558462,51,89.7500000002,81,2.41191977493,192,263,71,230.278551532,14.6373187385,82670,231.0,248,382,134,318.442896936,25.2122234242,114321,321.0,629,1177,548,959.253481894,98.7316208791,344372,973.0,153,346,193,262.526462396,37.6293127386,94247,266.0,0.484184920788,0.701171875,0.216986954212,0.570648731129,0.0394563711163,204.862894475,0.571806,593,991,398,811.247910864,76.711936946,291238,817.0,-0.139282226562,0.926696777344,1.06597900391,0.026135712945,0.133704178114,9.38272094727,0.0
+2548546,51,4.74999999953,12,1.5532076083,202,290,88,249.210526316,22.4419225824,4735,252.0,262,391,129,326.157894737,30.7712496674,6197,319.0,438,611,173,510.105263158,48.412585072,9692,498.0,261,436,175,342.947368421,50.1193036498,6516,337.0,0.124497994781,0.277008324862,0.152510330081,0.198486063825,0.0373151036818,3.77123521268,0.197982,725,1117,392,918.315789474,98.4886061439,17448,897.0,0.0,0.556579589844,0.556579589844,0.145857961554,0.190737648615,2.77130126953,0.0322266
+2551432,22,4129.25000004,1727,7.58144199946,240,486,246,411.943573288,26.034563083,6804072,414.0,356,787,431,655.782042744,45.6536599419,10831552,659.0,776,1353,577,1126.6478174,60.1213261201,18608842,1127.0,380,1070,690,860.07465036,71.8972340462,14205853,867.0,0.0597572363913,0.349315077066,0.289557840675,0.13521149017,0.0275760556706,2233.28818314,0.127219,976,2306,1330,1927.80026639,140.834493032,31841477,1940.0,-0.253173828125,0.980407714844,1.23358154297,0.0218289906446,0.0671556322338,360.549438477,0.0
+2566497,33,7042.74999929,5073,17.052528898,178,359,181,236.119200596,10.4127309701,6651714,236.0,237,518,281,332.061162188,18.3027284752,9354495,332.0,600,1129,529,833.393028292,49.5990993254,23477515,831.0,149,628,479,294.119236094,26.0661953547,8285633,295.0,0.278365045786,0.677139759064,0.398774713278,0.478424889663,0.0337900057821,13477.7075667,0.477089,570,1485,915,862.299598878,51.7606346771,24291842,864.0,-0.421081542969,3.99710083008,4.41818237305,0.208906085079,0.463894920294,5885.09332275,0.0
+2470812,34,227.500000002,130,2.43135133512,230,323,93,269.662637363,13.8920259233,245393,268.0,324,477,153,378.63956044,23.9912936549,344562,377.0,607,956,349,807.789010989,50.2340400559,735088,812.0,297,521,224,390.830769231,37.9384976337,355656,388.5,0.221256032586,0.469168901443,0.247912868857,0.348296006581,0.0431213120707,316.949365988,0.347468,881,1273,392,1039.13296703,67.3854984154,945611,1033.0,-0.106292724609,3.38711547852,3.49340820312,1.02055328704,1.32777997247,928.703491211,0.00444031
+2496155,32,336.999999998,198,3.04260313081,236,371,135,296.913204748,19.5430902767,400239,297.0,352,562,210,451.028931751,31.7364877163,607987,451.0,854,1154,300,981.566023739,49.4919524367,1323151,979.0,356,696,340,507.494065282,51.2055333078,684102,506.5,0.234323427081,0.434554964304,0.200231537223,0.319764234413,0.0304219795907,431.042187989,0.318614,949,1623,674,1255.43620178,100.493173784,1692328,1255.0,-0.0337219238281,0.236785888672,0.2705078125,0.0059736574439,0.0259541119388,8.05249023438,0.0
+2458086,32,1027.75,606,5.33241509839,235,357,122,288.032595476,15.3429111149,1184102,288.0,321,530,209,416.361469229,27.2558660152,1711662,416.0,731,1102,371,904.198005351,46.8608046175,3717158,904.0,317,659,342,461.311359766,47.6700975948,1896451,460.0,0.224350199103,0.443478256464,0.219128057361,0.325730601785,0.0325934031992,1339.07850394,0.324108,876,1537,661,1165.70542447,88.5686612304,4792215,1163.0,-0.0406494140625,2.69635009766,2.73699951172,0.189973727713,0.3968154625,780.981994629,0.0865173
+2441348,34,1779.99999997,1039,6.94705303547,193,344,151,272.213904494,13.6148424845,1938163,272.0,254,508,254,381.452808989,26.3748319762,2715944,382.0,473,1087,614,820.060533708,67.6224076431,5838831,818.0,212,604,392,411.455617978,45.2284804738,2929564,408.0,0.198090687394,0.494714587927,0.296623900533,0.33213979582,0.0462438943864,2364.83534624,0.3301,660,1439,779,1065.12233146,81.8434261955,7583671,1062.0,-0.225036621094,4.32717895508,4.55221557617,0.0873916154497,0.252576865337,622.228302002,0.0
+2458119,33,3360.0,2182,10.6189157599,212,367,155,269.652678571,13.9265043204,3624132,269.0,267,543,276,366.689285714,24.4378561616,4928304,365.0,562,993,431,771.524553571,51.6278448839,10369290,769.0,219,669,450,402.638169643,40.6008622605,5411457,401.0,0.164467900991,0.559701502323,0.395233601332,0.314975070321,0.0362573292025,4233.26494512,0.313301,703,1542,839,1038.98013393,75.3737994928,13963893,1034.0,-0.290740966797,1.40539550781,1.69613647461,0.0777233260018,0.173524569855,1044.60150146,0.0
+2473062,34,373.0,207,3.02350713314,240,321,81,261.91689008,6.67724389541,390780,262.0,326,480,154,366.873994638,13.9480631563,547376,365.0,797,1058,261,922.219168901,42.1534867147,1375951,917.5,285,487,202,346.465147453,20.2629693626,516926,346.0,0.321254342794,0.548136651516,0.226882308722,0.453589792226,0.0291341745305,676.755970001,0.450078,859,1210,351,975.256032172,37.0458034342,1455082,973.0,-0.0593872070312,1.06860351562,1.12799072266,0.105985360235,0.209042727033,158.130157471,0.0
+2437417,34,586.749999989,403,4.69324866188,213,372,159,258.011504048,13.7213533854,605553,257.0,303,546,243,374.909671922,24.7329912587,879913,374.0,764,1250,486,929.098849595,58.0621776635,2180595,928.0,252,682,430,356.329356625,36.9589553854,836305,354.0,0.293995857239,0.551695644855,0.257699787617,0.446259764506,0.034005978047,1047.3716673,0.446281,768,1600,832,989.250532595,73.7615161456,2321771,986.0,-0.0926208496094,0.864166259766,0.956787109375,0.0642657156035,0.126285352962,150.831634521,0.0
+2391082,32,1527.49999999,1364,9.84507046395,226,400,174,303.69492635,20.8735548819,1855576,304.0,324,615,291,455.30294599,33.3937728717,2781901,456.0,727,1149,422,915.941243863,53.1315353643,5596401,915.0,331,764,433,523.362520458,53.4643831413,3197745,524.0,0.16228350997,0.423846811056,0.261563301086,0.274074571798,0.0351052561918,1674.59563369,0.273507,924,1760,836,1282.3603928,104.1554378,7835222,1283.0,-0.160186767578,0.637847900391,0.798034667969,0.0156828685205,0.0544516441718,95.8223266602,0.0
+2393917,33,2642.50000002,686,3.76453800304,200,371,171,286.482024598,19.0249527048,3028115,285.0,277,574,297,417.333964049,34.9858075116,4411220,415.0,658,1222,564,936.674929044,63.530916837,9900654,933.0,229,710,481,455.363481552,62.0081765169,4813192,450.0,0.209829866886,0.556529343128,0.346699476242,0.348031274855,0.0443202850293,3678.69057521,0.348568,706,1636,930,1159.1794702,114.094211824,12252527,1150.0,-0.337280273438,8.07806396484,8.41534423828,0.0380092162508,0.240124379053,401.757415771,0.0
+2389868,32,837.499999996,600,5.84862680724,210,337,127,264.181492537,17.3349931016,885008,265.0,296,499,203,392.010149254,33.1319102842,1313234,395.0,768,1197,429,982.56238806,70.5557014227,3291584,996.0,247,557,310,382.117014925,46.0689429175,1280092,383.0,0.32632881403,0.553600013256,0.227271199226,0.441186016869,0.0347845708566,1477.97315651,0.440603,760,1355,595,1038.30865672,94.3511049203,3478334,1044.0,-0.132843017578,1.37619018555,1.50903320312,0.101995321245,0.24468500281,341.684326172,0.0
+2292448,51,10.0,25,2.23015514519,210,290,80,259.15,22.7503296679,10366,267.0,283,427,144,362.9,37.4918657845,14516,373.5,511,760,249,628.5,75.8521588355,25140,617.0,269,479,210,384.4,61.6408144008,15376,400.0,0.173828125,0.321637421846,0.147809296846,0.243619906902,0.0390206041191,9.74479627609,0.233915,785,1191,406,1006.45,115.383480187,40258,1029.0,0.142944335938,0.785888671875,0.642944335938,0.316144561768,0.249603317927,12.6457824707,0.16153
+2277829,22,1750.75,653,4.4024677348,309,476,167,416.426388691,16.0561399225,2916234,417.0,446,750,304,654.892474654,27.7365825462,4586212,655.0,578,1098,520,952.942738826,36.7381836316,6673458,953.0,486,928,442,799.330429816,38.014264489,5597711,800.0,0.0317662023008,0.170573964715,0.138807762414,0.0878489838146,0.0121773406507,615.206433654,0.0860335,1243,2150,907,1870.64929316,78.5913216551,13100157,1871.0,-0.131286621094,1.60284423828,1.73413085938,0.0466954504849,0.14561287785,327.008239746,0.0
+2259041,14,711.249999997,480,5.07721045481,245,316,71,295.523022847,6.93625867163,840763,296.0,311,437,126,399.822144112,11.7540406233,1137494,400.0,458,594,136,529.008435852,21.6871006143,1505029,529.0,322,526,204,461.227768014,22.215088575,1312193,461.0,0.0391061455011,0.174358978868,0.135252833366,0.068602072297,0.0104735435297,195.172895685,0.0675105,878,1270,392,1156.57293497,39.2147443488,3290450,1157.0,-0.378173828125,1.8473815918,2.22555541992,0.157294580765,0.284294254409,447.503082275,0.0
+2248034,32,4358.99999999,3331,14.2323385581,203,392,189,296.624053682,19.9225655598,5171937,296.0,280,610,330,444.885122735,33.7203600323,7757017,443.0,706,1247,541,941.619293416,55.6261336018,16418074,940.0,244,743,499,487.476772195,53.8683787102,8499645,485.0,0.163720220327,0.5234375,0.359717279673,0.319313859144,0.0351545432056,5567.55644804,0.318841,744,1723,979,1228.98594861,105.482384092,21428599,1224.0,-0.390655517578,1.3037109375,1.69436645508,0.0432842733335,0.11014789794,754.704589844,0.0
+2224211,32,4294.74999993,3505,15.0873910206,215,372,157,280.770475581,16.9225833622,4823356,280.0,295,573,278,418.847604634,28.5292866182,7195383,416.0,803,1245,442,985.045753536,53.9677783825,16922101,981.0,261,672,411,437.944525293,45.6862862384,7523449,433.0,0.259174317122,0.531838536263,0.272664219141,0.385645513565,0.0316482288325,6625.00427753,0.386548,786,1596,810,1137.56260551,88.9653397636,19542188,1128.0,-0.150848388672,1.40505981445,1.55590820312,0.0429217487728,0.0912558758558,737.352722168,0.0
+2227782,33,147.750000001,90,2.08868925538,198,297,99,238.532994924,10.7200262172,140973,238.0,265,453,188,323.901861252,16.1155046127,191426,322.0,661,914,253,742.275803723,37.0741709587,438685,738.0,206,525,319,319.840947547,26.8868358919,189026,317.0,0.27032661438,0.559358298779,0.289031684399,0.398213231775,0.0282872430132,235.344019979,0.397849,669,1274,605,882.275803723,49.5825218235,521425,876.0,-0.139099121094,1.18856811523,1.32766723633,0.154832869012,0.316383904661,91.5062255859,0.0
+2180070,11,126.249999999,53,1.33062366848,388,536,148,496.467326733,26.4688013954,250716,505.0,590,877,287,804.853465347,49.6700231615,406451,821.0,832,1189,357,1070.7960396,38.1519627482,540752,1073.0,736,1117,381,1013.79009901,43.2785989802,511964,1022.0,0.00758589897305,0.0901763215661,0.0825904225931,0.0274944582235,0.0154922789042,13.8847014029,0.022409,1714,2503,789,2315.11089109,113.101634747,1169131,2350.0,1.25674438477,4.76950073242,3.51275634766,3.93044796179,0.452570074801,1984.8762207,4.01627
+2149639,11,22.25,25,1.49509940621,279,505,226,366.786516854,31.9653857418,32644,368.0,412,720,308,523.752808989,43.0401643879,46614,522.0,531,969,438,663.651685393,64.5466647888,59065,665.0,445,1064,619,614.06741573,69.5655535566,54652,607.0,-0.0598413832486,0.116640746593,0.176482129842,0.0392539066673,0.0408993820323,3.49359769339,0.0391823,1160,2289,1129,1504.60674157,131.204327996,133910,1492.0,-0.0015869140625,3.05401611328,3.05560302734,2.16868059823,0.913297348137,193.012573242,2.64804
+2148588,21,2351.74999984,1351,7.85877474227,210,487,277,304.176783247,9.22492757533,2861391,304.0,288,812,524,449.706069948,16.2082699121,4230385,449.0,545,1231,686,831.949080472,25.9896304676,7826145,833.0,357,1180,823,679.758052514,24.7439729995,6394484,681.0,0.00589721975848,0.208425715566,0.202528495807,0.100747078795,0.0108409861878,947.727770224,0.0996441,855,2479,1624,1433.64090571,45.1784068178,13486260,1435.0,-0.234405517578,2.0885925293,2.32299804688,0.060323084834,0.136812702512,567.459259033,0.0
+2096876,12,3.25000000023,11,1.7212583998,185,258,73,222.846153846,23.2473196266,2897,227.0,219,340,121,283.076923077,38.4896820109,3680,293.0,405,581,176,504.692307692,52.426336035,6561,510.0,179,400,221,283.153846154,65.6386918656,3681,286.0,0.180555552244,0.407821238041,0.227265685797,0.289740518882,0.0696983144886,3.76662674546,0.288557,585,993,408,789.076923077,124.074085522,10258,779.0,0.292297363281,1.37683105469,1.08453369141,0.409860464243,0.280496353841,5.32818603516,0.327576
+2098407,34,965.500000001,731,6.63645732244,200,292,92,243.033661315,11.4231453924,938596,243.0,262,423,161,337.082858622,18.7455742074,1301814,338.0,579,1043,464,826.765147592,52.0919047737,3192967,825.0,168,464,296,303.895908856,29.574175174,1173646,305.0,0.307979106903,0.648535549641,0.340556442738,0.462883573108,0.0339601505179,1787.65635934,0.461608,633,1175,542,884.012428793,58.3122974156,3414056,887.0,-0.374938964844,0.970458984375,1.34539794922,0.0474559323643,0.132542307817,183.274810791,0.0
+2157440,21,3099.99999996,2014,10.2040760638,203,476,273,304.598709677,13.8773172414,3777024,303.0,258,711,453,444.573790323,22.7861136296,5512715,443.0,544,1079,535,791.350403226,34.4330281453,9812745,792.0,335,1029,694,645.631290323,34.8620371438,8005828,649.0,0.00829383917153,0.254727482796,0.246433643624,0.10166989475,0.015915739648,1260.7066949,0.0994436,815,2216,1401,1394.80379032,62.5643034508,17295567,1396.0,-0.0414428710938,4.48092651367,4.52236938477,0.391780700684,0.562388009396,4858.08068848,0.24791
+2011561,34,1062.25000002,330,2.85624618922,200,387,187,268.597552365,16.5123303062,1141271,266.0,247,583,336,366.048481996,28.1590480483,1555340,362.0,474,1004,530,784.638503177,57.9763562331,3333929,783.0,172,591,419,378.859496352,50.7002625262,1609774,373.0,0.195488721132,0.602272748947,0.406784027815,0.350399056226,0.0532507661248,1488.84558991,0.347506,633,1561,928,1013.50553071,90.5577057729,4306385,1003.0,-0.103942871094,4.21228027344,4.31622314453,0.304897574992,0.617059147709,1295.50979614,0.0
+2009325,34,2756.24999992,767,4.12127057702,182,290,108,228.022312925,11.8522901182,2513946,229.0,225,434,209,314.044535147,24.347799508,3462341,313.0,724,1209,485,977.484807256,55.1748814857,10776770,977.0,148,445,297,266.652970522,30.9748728027,2939849,268.0,0.433696359396,0.706233978271,0.272537618876,0.572114109185,0.0342173705339,6307.55805376,0.571214,562,1168,606,808.719818594,65.8159445008,8916136,809.0,-2.12390136719,15.4390563965,17.5629577637,0.668118046698,1.79282699316,7366.00146484,0.0
+2052013,51,451.500000007,514,6.82384745354,193,373,180,271.748615725,24.8037911887,490778,268.0,258,577,319,385.920265781,43.9395696357,696972,382.0,505,1218,713,854.665005537,105.686723195,1543525,854.0,201,713,512,415.03820598,75.8395694214,749559,400.0,0.170479699969,0.528641581535,0.358161881566,0.348189441535,0.0664227057222,628.830131412,0.346591,701,1660,959,1072.70708749,137.717097413,1937309,1049.0,-0.180633544922,1.45959472656,1.64022827148,0.168986188481,0.303238653589,305.189056396,0.0
+2033070,12,459.500000001,426,5.60611379815,180,360,180,269.891186072,28.8661523874,496060,271.0,242,528,286,377.774211099,48.856462377,694349,383.0,448,1045,597,761.526659412,137.114802605,1399686,791.0,224,631,407,399.053318825,76.676470716,733460,403.0,0.144975289702,0.487336903811,0.342361614108,0.311738013516,0.0593464557706,572.974468842,0.30518,678,1465,787,1046.718716,147.510877444,1923869,1056.0,-0.167236328125,1.14358520508,1.3108215332,0.0765318595546,0.166897767847,140.665557861,0.0
+2150240,22,3572.74999969,2724,12.8558517996,202,497,295,363.39689315,34.2935652791,5193305,364.0,342,775,433,569.290042684,53.8192724208,8135724,569.0,721,1426,705,1048.10943951,75.2028483188,14978532,1050.0,341,1070,729,737.833111749,78.3040383678,10544373,742.0,0.0403489656746,0.388843983412,0.348495017737,0.175068815468,0.0364896262254,2501.90844186,0.168739,924,2327,1403,1670.52004758,154.543583026,23873402,1674.0,-0.263305664062,4.44320678711,4.70651245117,0.0320022900121,0.158747850928,457.344726562,0.0
+2020970,41,870.750000008,445,4.2541062972,227,359,132,268.214757393,12.0219361359,934192,266.0,292,508,216,363.025552684,20.4711846655,1264418,361.0,296,802,506,426.127763422,76.2817513099,1484203,399.0,257,640,383,361.519954063,38.8494350001,1259174,354.0,-0.109774433076,0.33554816246,0.445322595537,0.0772657787236,0.0640993058858,269.116707294,0.0679348,793,1505,712,992.76026414,69.2412734837,3457784,981.0,-0.053955078125,3.00909423828,3.06304931641,0.103715255347,0.297282898069,361.240234375,0.0
+1967507,22,1999.99999998,1617,10.1997632203,233,434,201,376.640375,17.0195782809,3013123,378.0,345,702,357,599.981875,27.415489171,4799855,600.0,741,1225,484,1050.204375,41.0037846529,8401635,1049.0,425,987,562,812.150625,40.1954062936,6497205,812.0,0.0647201910615,0.27101200819,0.206291817129,0.128050238037,0.0134316739445,1024.4019043,0.127116,1003,2118,1115,1788.772875,80.3153708155,14310183,1788.0,-0.0601806640625,0.433044433594,0.493225097656,0.0395089836121,0.079225116804,316.071868896,0.0
+1967043,41,81.5000000009,54,1.68736883435,242,331,89,269.174846626,13.0878384215,87751,266.0,323,479,156,363.435582822,22.7588145965,118480,359.0,329,759,430,409.782208589,67.2140965534,133589,386.5,295,576,281,363.009202454,40.0040248126,118341,355.0,-0.0480225980282,0.168269231915,0.216291829944,0.0574161143141,0.0464584254367,18.7176532664,0.0472226,860,1375,515,995.619631902,75.0995828527,324572,980.0,-0.0445556640625,2.32174682617,2.36630249023,0.138512453419,0.255890871472,45.1550598145,0.0474548
+1940258,34,713.49999999,494,5.21705035061,192,354,162,261.440084093,18.5796006617,746150,260.0,243,508,265,365.70217239,33.2054974643,1043714,363.0,584,1164,580,908.00385424,88.5864642763,2591443,910.0,205,598,393,351.777505256,54.9277276185,1003973,344.0,0.26450741291,0.59925788641,0.334750473499,0.442350316827,0.0585595898492,1262.46780422,0.445848,665,1425,760,978.919761738,100.208427893,2793837,969.0,-0.372436523438,2.00427246094,2.37670898438,0.150717090374,0.339234142266,430.146575928,0.0
+1968252,14,1808.74999982,1048,6.95131675286,216,481,265,295.210089841,9.0761705164,2135845,296.0,276,671,395,399.973600553,14.5832024514,2893809,400.0,417,833,416,564.471596406,32.157776454,4083952,558.0,251,905,654,476.255701451,29.2775318358,3445710,473.0,-0.0414269268513,0.273698270321,0.315125197172,0.0848918200245,0.0166738365271,614.192317877,0.0835792,758,2057,1299,1171.43939185,47.6407864107,8475364,1169.0,-0.236480712891,4.49285888672,4.72933959961,1.20141003865,0.383342110188,8692.20162964,1.17148
+1885583,12,2.25,9,1.69256875064,227,269,42,243.666666667,14.7044966667,2193,235.0,313,383,70,341.777777778,23.971176107,3076,329.0,617,744,127,678.777777778,36.2699072626,6109,679.0,347,450,103,390.888888889,37.435706201,3518,372.0,0.243291586637,0.306403934956,0.0631123483181,0.270410153601,0.0236014571967,2.43369138241,0.280083,887,1102,215,976.333333333,76.0102332292,8787,936.0,0.714233398438,0.894653320312,0.180419921875,0.779713948568,0.0670460240919,7.01742553711,0.757874
+1884838,12,3.5,9,1.35707407896,206,227,21,218.714285714,6.61630638681,3062,220.0,272,307,35,292.642857143,10.8667720457,4097,293.5,571,680,109,622.428571429,27.1680334367,8714,617.0,230,300,70,266.642857143,20.2435426842,3733,273.5,0.365079373121,0.437647044659,0.0725676715374,0.400763607451,0.0227465276379,5.61069050431,0.406287,708,833,125,778.0,36.8413587465,10892,785.0,0.0,0.00100708007812,0.00100708007812,0.000209263392857,0.000395697146862,0.0029296875,0.0
+2063825,22,4430.75000009,2002,8.48438794156,245,616,371,347.623314337,18.5032547549,6160928,347.0,350,931,581,545.156237657,30.2260179934,9661804,547.0,563,1195,632,958.144557919,54.4403220782,16981196,963.0,321,1290,969,745.601591153,50.2996437124,13214297,752.0,-0.0382293760777,0.297529548407,0.335758924484,0.125069009663,0.0195136044607,2216.59805826,0.122689,917,2837,1920,1638.38114315,90.279461164,29037029,1648.0,-0.301605224609,1.54284667969,1.8444519043,0.067538191622,0.138405900224,1196.97937012,0.0
+1872526,31,1968.25,1166,7.41401547796,180,308,128,244.523815572,14.0134200372,1925136,245.0,250,450,200,342.453448495,25.6808252808,2696136,344.0,576,1170,594,913.742410771,73.0470510274,7193894,913.0,173,482,309,312.520640163,37.9135453783,2460475,312.0,0.320169240236,0.646578133106,0.32640889287,0.490622326363,0.0444863034228,3862.66957545,0.492295,624,1225,601,899.49790423,75.3949373136,7081747,901.0,-0.463439941406,1.90603637695,2.36947631836,0.103965562559,0.261468640261,818.520874023,0.0
+1909892,32,2562.0,2044,11.3916437998,215,404,189,313.413446526,23.6250084715,3211861,314.0,282,600,318,462.457747853,41.5157858026,4739267,464.0,637,1253,616,952.984777518,75.7609340501,9766188,952.0,298,775,477,564.460577674,70.6861266482,5784592,567.0,0.147439852357,0.44731977582,0.299879923463,0.257866892087,0.0418791855201,2642.61991011,0.251854,817,1760,943,1340.33177205,131.393873219,13735720,1346.0,-0.114105224609,3.40692138672,3.52102661133,0.28205012754,0.278258421586,2890.44970703,0.226257
+1824210,33,82.249999996,60,1.86628671709,234,265,31,248.477203647,4.7509650363,81749,248.0,296,351,55,318.027355623,8.01153306204,104631,317.0,597,709,112,646.626139818,19.6571692141,212740,646.0,318,403,85,358.203647416,12.4369969234,117849,357.0,0.255319148302,0.327083319426,0.0717641711235,0.287052083794,0.0124979727392,94.4401355684,0.287615,851,1019,168,924.708206687,24.1142158026,304229,922.0,0.928100585938,1.67816162109,0.750061035156,1.07103703739,0.125490665667,352.371185303,1.02576
+1798672,51,6.75,15,1.62867503968,212,282,70,254.814814815,16.7266410633,6880,259.0,268,372,104,323.777777778,26.112765905,8742,327.0,410,598,188,474.888888889,46.18909069,12822,466.0,248,364,116,301.259259259,29.0931996542,8134,296.0,0.14804469049,0.334228187799,0.18618349731,0.223320435043,0.0383288474704,6.02965174615,0.22063,740,1001,261,879.851851852,60.2947720255,23756,885.0,-0.00125122070312,0.151062011719,0.152313232422,0.0253295898438,0.0490112114665,0.683898925781,0.0
+1782531,34,2625.74999999,1805,9.9367779978,181,363,182,253.638674664,13.7540513462,2663967,254.0,238,500,262,366.054079787,25.4799708379,3844666,367.0,611,1238,627,995.907740646,72.2724736307,10460019,1000.0,167,547,380,333.484813863,37.8935244753,3502591,332.0,0.312232673168,0.690454125404,0.378221452236,0.498372976827,0.045048768683,5234.41137561,0.499627,618,1386,768,953.177568314,73.8704060368,10011224,955.0,-0.151611328125,1.45254516602,1.60415649414,0.113126758938,0.243114042187,1188.17034912,0.0
+1730153,32,129.500000003,165,4.0901960784,209,414,205,317.1003861,23.8753511738,164258,316.0,274,543,269,460.073359073,37.7749179403,238318,463.0,482,976,494,800.961389961,97.6188635701,414898,822.5,248,716,468,566.216216216,70.5325821336,293300,572.5,0.0688935294747,0.332436084747,0.263542555273,0.171786145066,0.0411647744828,88.9852231443,0.172459,731,1616,885,1343.38996139,125.761305039,695876,1350.0,-0.0250244140625,2.63354492188,2.65856933594,0.43557533058,0.614715170699,225.62802124,0.228333
+1709727,34,227.250000011,131,2.4514013317,226,332,106,253.711771177,11.1809048702,230624,253.0,310,485,175,364.03520352,20.0609323048,330908,363.0,833,1302,469,1066.49174917,89.3267397456,969441,1057.0,243,522,279,323.334433443,31.5557434067,293911,321.0,0.375999987125,0.653872072697,0.277872085571,0.53340703449,0.0479794397379,484.866994351,0.537335,786,1339,553,941.081408141,58.1111371753,855443,938.0,-0.0498046875,0.85205078125,0.90185546875,0.0653429020881,0.149792969253,59.396697998,0.0
+1720546,34,2970.24999995,1094,5.66260004043,206,345,139,269.349886373,14.3597546,3200146,268.0,273,528,255,384.875936369,25.2047705551,4572711,383.0,629,1147,518,869.53640266,50.146822984,10330962,868.0,219,623,404,406.574867435,44.8518567554,4830516,403.0,0.235494881868,0.555555582047,0.320060700178,0.363972288295,0.0410401118757,4324.35475723,0.362115,708,1488,780,1060.80069018,81.1848656572,12603373,1054.0,-0.183197021484,1.23107910156,1.41427612305,0.147704366622,0.200129306103,1754.87557983,0.0391541
+1680516,11,17.0,19,1.29994269621,349,670,321,561.073529412,68.8428124696,38153,570.0,639,955,316,839.5,71.6495761656,57086,858.5,663,1044,381,878.720588235,71.0486257656,59753,884.5,677,1075,398,893.132352941,64.7674356293,60733,898.0,-0.108280256391,0.0789632275701,0.187243483961,-0.00843321206733,0.0363970505131,-0.573458420578,-0.00585523,1713,2638,925,2293.70588235,175.97368276,155972,2339.5,-0.112823486328,0.535766601562,0.648590087891,0.0927581787109,0.183507170549,6.30755615234,0.0
+1668122,12,5.5,15,1.80428435059,206,277,71,239.5,15.0657649234,5269,239.0,260,366,106,309.136363636,25.2033465573,6801,311.0,401,568,167,479.772727273,47.3573761349,10555,473.0,213,413,200,311.454545455,45.2676156296,6852,315.0,0.153688520193,0.3061889112,0.152500391006,0.2152709033,0.0377181833487,4.7359598726,0.215478,679,1056,377,860.090909091,84.911134879,18922,863.5,0.619506835938,0.848236083984,0.228729248047,0.725630326705,0.0818323766973,15.9638671875,0.719482
+1647495,11,21.7499999986,34,2.05657406352,291,459,168,373.770114943,38.0120069202,32518,376.0,402,673,271,537.632183908,60.1853678599,46774,542.0,459,807,348,665.287356322,65.2299042989,57880,682.0,366,723,357,585.494252874,79.5774579014,50938,601.0,0.0089102126658,0.206933915615,0.198023702949,0.0662851602096,0.0391864764134,5.76680893824,0.0558739,1059,1829,770,1496.89655172,170.088687784,130230,1519.0,-0.00390625,1.48687744141,1.49078369141,0.503467077496,0.454788440105,43.8016357422,0.343719
+1646345,12,5.5,15,1.80428435059,203,259,56,221.227272727,12.6164820705,4867,216.5,248,355,107,276.272727273,25.0511872667,6078,270.0,372,654,282,465.0,61.975068301,10230,465.0,197,367,170,237.227272727,43.6722626953,5219,228.0,0.244919791818,0.400907725096,0.155987933278,0.326539801603,0.0355484761682,7.18387563527,0.325406,651,981,330,734.727272727,80.274065674,16164,718.5,3.33435058594,3.46170043945,0.127349853516,3.43019936301,0.031523700646,75.4643859863,3.4359
+1681662,22,158.500000005,102,2.28549674165,315,452,137,397.09148265,14.4562155214,251756,397.0,531,707,176,647.104100946,23.714293409,410264,649.0,959,1237,278,1121.7807571,34.8631964803,711209,1121.0,693,992,299,889.493690852,39.6683903187,563939,890.0,0.0839260295033,0.170028820634,0.0861027911305,0.115739633021,0.0122844199356,73.3789273351,0.113755,1552,2125,573,1933.68927445,74.770561641,1225959,1936.0,-0.154876708984,0.552856445312,0.707733154297,0.0382341932423,0.0828063026428,24.2404785156,0.0
+1694371,34,4076.99999999,1516,6.69767258925,211,349,138,265.768702477,13.4334119966,4334156,265.0,298,547,249,383.770051508,23.2304756113,6258522,383.0,676,1115,439,876.77747118,44.4187458652,14298487,874.0,238,681,443,379.774589159,38.9521424429,6193364,378.0,0.214079633355,0.564147651196,0.35006801784,0.396455721896,0.0391548596411,6465.39991269,0.394769,777,1577,800,1029.31334314,73.8082757277,16786042,1026.0,-0.307861328125,1.34124755859,1.64910888672,0.0568104702554,0.13019636484,926.465148926,0.0
+1621607,11,55.25,51,1.93552641589,331,574,243,480.63800905,43.5436557724,106221,484.0,451,797,346,684.384615385,64.7158882242,151249,702.0,542,981,439,747.837104072,69.4126664327,165272,748.0,421,886,465,742.212669683,71.807529462,164029,756.0,-0.0409577824175,0.159513130784,0.200470913202,0.00418608644645,0.0287688685794,0.925125104666,-0.00270636,1203,2217,1014,1907.23529412,166.632466902,421499,1947.0,2.55590820312,3.38943481445,0.833526611328,2.75611221521,0.142077819733,609.100799561,2.69199
+1654559,33,3270.25000002,2730,13.4668876781,186,410,224,251.364651021,14.958522821,3288101,250.0,262,592,330,361.862701628,25.801754915,4733526,359.0,651,1253,602,877.024692302,55.1639951204,11472360,872.0,192,694,502,343.915144102,40.2280212526,4498754,340.0,0.261772841215,0.60652589798,0.344753056765,0.437775411297,0.0375004280552,5726.54015517,0.437282,654,1665,1011,957.142496751,78.2948429918,12520381,949.0,-0.337524414062,1.43280029297,1.77032470703,0.0583727431037,0.145436046672,763.573852539,0.0
+1625123,33,518.000000003,355,4.40005941771,211,343,132,266.955598456,12.8765281932,553132,266.0,275,487,212,354.982142857,21.0380279339,735523,354.0,594,985,391,737.127413127,39.044254931,1527328,734.0,244,604,360,381.026544402,36.2327547853,789487,381.0,0.213541671634,0.446768075228,0.233226403594,0.319489754168,0.0309793786128,661.982770637,0.31458,746,1410,664,1002.96428571,66.2634314976,2078142,1002.0,-0.121246337891,0.831848144531,0.953094482422,0.0745458418798,0.127141359478,154.458984375,0.0
+1601731,31,69.2500000014,73,2.47461726862,209,292,83,248.072202166,12.5111583347,68716,249.0,257,410,153,330.74368231,22.2412763448,91616,332.0,713,1064,351,899.288808664,73.136954151,249103,905.0,152,434,282,287.209386282,40.0391440055,79557,291.0,0.364975452423,0.690058469772,0.325083017349,0.516489254654,0.0515263797975,143.067523539,0.517871,623,1131,508,866.025270758,71.4025761527,239889,873.0,-0.0945739746094,1.33120727539,1.42578125,0.0997691240552,0.241766525714,27.6360473633,0.000854492
+1583590,22,2181.74999999,1133,6.84262099421,301,482,181,406.115045262,12.704567608,3544166,406.0,452,757,305,648.241663802,22.7717620962,5657205,649.0,825,1243,418,1071.31328062,38.7764502788,9349351,1073.0,567,963,396,851.888850693,36.6266553341,7434434,854.0,0.0750782042742,0.198551595211,0.123473390937,0.114221868043,0.00983272444894,996.814242408,0.113228,1354,2134,780,1906.24555976,68.4674571267,16635805,1910.0,-0.220336914062,1.27212524414,1.4924621582,0.0387777357122,0.104273100683,338.413299561,0.0
+1555061,51,48.2499999995,65,2.63973156621,174,359,185,252.264248705,33.4925189478,48687,252.0,249,544,295,344.487046632,51.7300795239,66486,337.0,383,856,473,556.984455959,118.774941823,107498,519.0,159,556,397,325.663212435,79.2067900478,62853,305.0,0.106503300369,0.422867506742,0.316364206374,0.264303780088,0.0637441321135,51.0106295571,0.269737,689,1377,688,922.414507772,149.20443324,178026,875.0,-0.00473022460938,3.65637207031,3.66110229492,1.21955816239,1.00123766274,235.374725342,1.32019
+1527845,34,69.9999999991,69,2.32645758315,204,273,69,243175,12.1073214273,68089,242.0,280,411,131,346.389285714,28.1059581798,96989,346.5,792,1089,297,956.396428571,62.6026869696,267791,958.5,191,394,203,296.339285714,32.3050619572,82975,297.5,0.455048412085,0.630824387074,0.175775974989,0.52776335233,0.0271358631332,147.773738652,0.52569,681,1057,376,885.903571429,69.860994544,248053,885.0,-0.073486328125,1.34429931641,1.41778564453,0.324543544224,0.377057377215,90.8721923828,0.120941
+1598251,31,51.5000000009,38,1.49374013486,214,288,74,247.616504854,13.9845101347,51009,245.0,259,407,148,321.665048544,27.9986033242,66263,317.0,682,1172,490,1022.49514563,88.5182087336,210634,1042.5,198,437,239,294.665048544,40.0806158721,60701,287.0,0.393739700317,0.645021617413,0.251281917095,0.551880671851,0.0557764485586,113.687418401,0.566957,671,1102,431,863.946601942,77.8538091249,177973,849.5,-0.0535583496094,3.88250732422,3.93606567383,2.58425044088,0.945370197223,532.35559082,2.70639
+1517684,12,8.74999999953,16,1.52584712647,190,291,101,234.428571429,21.5344053144,8205,236.0,238,349,111,277.771428571,25.6538337032,9722,273.0,393,683,290,471.285714286,65.2461586953,16495,447.0,209,409,200,296.685714286,39.9791169977,10384,285.0,0.118534483016,0.350931674242,0.232397191226,0.226380764799,0.065355577189,7.92332676798,0.227273,659,1049,390,808.885714286,75.1648745582,28311,807.0,0.0,0.0,0.0,0.0,0.0,0.0,0.0
+1444783,12,41.9999999974,62,2.69874662549,197,324,127,248.107142857,27.2438362872,41682,240.5,250,455,205,328.666666667,47.2883337403,55216,313.0,414,711,297,536.386904762,72.1173750278,90113,523.0,195,516,321,313.755952381,75.22707664,52711,286.0,0.126734510064,0.428937256336,0.302202746272,0.268754606534,0.0641056005509,45.1507738978,0.278639,642,1288,646,890.529761905,148.79639835,149609,830.5,-0.000823974609375,0.0128173828125,0.0136413574219,7.57489885603e-05,0.000999687625524,0.0127258300781,0.0
+1525539,14,2106.50000018,2038,12.526176185,241,447,206,288.134702113,9.22498872281,2427823,288.0,320,643,323,393.658438168,15.250518916,3316966,393.0,460,811,351,544.162710657,23.9310464175,4585115,540.0,302,826,524,416.00866366,23.8799870613,3505289,413.0,-0.00916310306638,0.2385661304,0.247729233466,0.133747735076,0.0178309838464,1126.95841575,0.131874,863,1916,1053,1097.80180394,45.4888981437,9250078,1094.0,-0.209381103516,2.29141235352,2.50079345703,0.815260507985,0.676393155568,6869.38504028,0.574234
+1573158,22,4266.49999997,2781,12.0104749529,255,436,181,371.284835345,13.9274720056,6336347,371.0,367,692,325,573.345599437,23.8328214512,9784716,573.0,735,1203,468,978.783780616,43.5827583287,16703924,976.0,402,920,518,736.961326614,38.7456529512,12576982,737.0,0.0962301567197,0.316907405853,0.220677249134,0.141120180519,0.0159413507848,2408.35700073,0.138095,1024,2039,1015,1681.5917614,74.8844904486,28698045,1682.0,-0.145202636719,1.16165161133,1.30685424805,0.0375012932329,0.0861333675425,639.997070312,0.0
+1417137,22,23.5,58,3.37511931566,312,379,67,353.936170213,12.7927909475,33270,356.0,495,587,92,551.946808511,20.0283665968,51883,554.5,788,952,164,893.79787234,32.7516703447,84017,901.5,582,748,166,699.031914894,32.4182940629,65709,709.5,0.0936902463436,0.164393395185,0.0707031488419,0.122472532569,0.0122615174969,11.5124180615,0.122293,1389,1706,317,1604.91489362,61.9199310666,150862,1621.0,-0.099365234375,0.221435546875,0.32080078125,0.0128547181474,0.0449364402464,1.20834350586,0.0
+1406349,21,1362.75000003,1026,7.84032983496,236,456,220,323.419005687,19.2197604345,1762957,323.0,315,681,366,477.904054302,34.5974699066,2605055,478.0,510,1104,594,813.26050266,64.6560180977,4433083,815.0,330,908,578,632.093744267,57.7262136262,3445543,634.0,0.0377224199474,0.284482747316,0.246760327369,0.125788231979,0.0240577820481,685.671652518,0.122736,881,1976,1095,1433.41680426,106.817298435,7813555,1437.0,-0.322692871094,4.14443969727,4.46713256836,0.100337452417,0.332512273231,546.939453125,0.0
+1377296,33,849.500000031,650,6.2911020927,225,407,182,307.220129488,19.1472050953,1043934,305.0,329,611,282,436.966745144,35.1735344912,1484813,435.0,492,1031,539,718.730723955,65.9589930316,2442247,718.0,329,783,454,548.256621542,57.5600365389,1862976,547.0,0.0639534890652,0.246753245592,0.182799756527,0.135092154242,0.0265124826395,459.043140113,0.131322,909,1792,883,1292.44349617,107.930872209,4391723,1288.0,-0.253936767578,4.38943481445,4.64337158203,0.216326457041,0.780210188241,735.077301025,0.0
+1383445,33,3528.24999999,2994,14.2189389286,199,379,180,263.28973287,12.7677760187,3715808,262.0,234,570,336,352.168638844,23.5717337236,4970156,350.0,491,1038,547,737.204634025,50.890042543,10404169,733.0,190,734,544,396.320909799,37.2685912261,5593277,394.0,0.141520470381,0.487870633602,0.346350163221,0.301252239934,0.0310487012493,4251.57286219,0.299914,623,1683,1060,1011.77928151,71.8010408066,14279241,1007.0,-0.266662597656,3.46954345703,3.73620605469,0.721802862785,0.839191872055,10186.8038025,0.353912
+1346710,32,2981.99999999,950,4.90755136354,234,397,163,304.084004024,18.0140087915,3627114,304.0,315,613,298,439.215124078,32.3124288417,5238958,438.0,589,1102,513,862.452297116,50.5233931058,10287331,859.0,329,823,494,523.308685446,55.976420119,6242026,523.0,0.144935071468,0.399638324976,0.254703253508,0.246327106774,0.0348262172205,2938.1897296,0.243225,881,1833,952,1266.60781355,104.582664986,15108098,1265.0,-0.129852294922,1.17889404297,1.30874633789,0.176233766224,0.16087315845,2102.11636353,0.1474
+1388476,34,1933.75000001,675,4.33010749111,200,352,152,258.877310924,14.4353878543,2002416,259.0,234,503,269,352.17970265,24.9781034381,2724110,352.0,561,1113,552,831.662960569,44.8783176171,6432913,833.0,197,601,404,364.892049127,41.8707940585,2822440,365.0,0.21444362402,0.561983466148,0.347539842129,0.391557539396,0.0405463208903,3028.69756722,0.389365,633,1423,790,975.949062702,78.6111324159,7548966,976.0,-0.192230224609,1.54577636719,1.7380065918,0.103077462017,0.217447922856,797.304168701,0.0
+1360853,51,93.7500000107,96,2.79692398216,207,319,112,264.602666667,24.6227968806,99226,262.0,259,451,192,353032,48.3773946108,132387,356.0,406,854,448,635144,122.816852524,238179,645.0,227,551,324,369.549333333,87.3530283746,138581,369.0,0.147864177823,0.428571432829,0.280707255006,0.267889788906,0.0496404915478,100.45867084,0.261566,709,1308,599,987184,157.840614157,370194,994.0,-0.193023681641,2.87313842773,3.06616210938,0.463948323568,0.826169741404,173.980621338,0.0
+1333949,31,99.7500000028,59,1.66644362952,226,298,72,251.654135338,11.748009022,100410,251.0,280,430,150,327.383458647,23.0149962459,130626,324.0,560,933,373,767.92481203,60.073800568,306402,771.0,226,410,184,304.714285714,31.69344977,121581,301.0,0.316098719835,0.529756069183,0.213657349348,0.432084581383,0.0342311688597,172.401747972,0.435847,733,1114,381,883.751879699,62.692559229,352617,876.0,-0.043701171875,1.28240966797,1.32611083984,0.0743646071967,0.203046477281,29.6714782715,0.0
+1336748,12,2.75,10,1.70109559932,218,261,43,237.818181818,11.7614020641,2616,238.0,273,349,76,311.818181818,22.237634692,3430,311.0,521,757,236,615.636363636,64.4773007658,6772,602.0,225,356,131,286.272727273,37.7891059556,3149,289.0,0.295049518347,0.410997211933,0.115947693586,0.366155047308,0.036316848275,4.02770552039,0.384275,716,966,250,835.909090909,71.3906723541,9195,836.0,0.756225585938,3.24099731445,2.48477172852,2.33116288619,1.18393862465,25.642791748,3.21664
+1307417,33,439.250000008,274,3.68799009282,259,362,103,310.82014798,14.0441852287,546111,310.0,362,537,175,447.427433125,25.2052699511,786130,446.0,662,950,288,787.108138873,40.0632500329,1382949,785.0,374,695,321,555.259533295,41.4060892913,975591,555.0,0.0926892980933,0.326126128435,0.233436830342,0.173252208486,0.0321878944741,304.40413031,0.1718,995,1576,581,1313.5071144,78.9123313514,2307832,1310.0,-0.158569335938,1.28228759766,1.44085693359,0.117475428226,0.187714777546,206.404327393,0.0143127
+1291287,12,7.25000000023,29,3.03825388982,186,278,92,237.379310345,24.7057354685,6884,239.0,240,387,147,328.103448276,39.2238006806,9515,333.0,434,644,210,521.724137931,52.4666702424,15130,515.0,214,465,251,352.793103448,63.4526047998,10231,362.0,0.0975369438529,0.349544078112,0.252007134259,0.198313913212,0.0597281603036,5.75110348314,0.185263,640,1119,479,918.275862069,124.081701825,26630,940.0,0.455810546875,0.786346435547,0.330535888672,0.629466089709,0.074755010476,18.2545166016,0.633911
+1273888,34,175.000000003,148,3.15600555559,219,274,55,249.565714286,9.31082144165,174696,250.0,299,403,104,359.511428571,17.1204517869,251658,363.0,799,1206,407,1012.36,60.8952177339,708652,1012.0,230,384,154,311.867142857,25.7922647398,218307,315.0,0.453201979399,0.645881474018,0.192679494619,0.528858934385,0.0310067908086,370.20125407,0.524062,763,1057,294,920.944285714,50.5341020238,644661,928.0,-0.037353515625,1.1598815918,1.19723510742,0.0990510777065,0.210978958258,69.3357543945,0.0
+1255247,11,383.249999993,108,1.55624418515,261,303,42,284.889758643,5.23476070529,436736,285.0,390,469,79,433.090019569,8.60807041417,663927,433.0,747,973,226,914.363992172,23.9196154956,1401720,919.0,251,333,82,290.927592955,11.7751538594,445992,290.0,0.445305764675,0.570707082748,0.125401318073,0.517192621734,0.0181011493963,792.856289119,0.520265,932,1085,153,1008.90737117,22.8446760011,1546655,1008.0,-0.210205078125,6.58364868164,6.79385375977,5.04801577613,1.64008853936,7738.60818481,5.5242
+1223945,33,1298.5,855,6.69329868702,219,321,102,265.810743165,10.3088329634,1380621,265.0,310,461,151,365.979399307,17.616780142,1900897,364.0,668,914,246,758.432036966,31.0929720804,3939296,754.0,334,565,231,422.091451675,26.8962393948,2192343,420.0,0.183823525906,0.361702114344,0.177878588438,0.285330163168,0.0188825029797,1482.00486749,0.287203,886,1343,457,1053.88159415,52.4564476014,5473861,1048.0,-0.230499267578,1.26333618164,1.49383544922,0.0726322060968,0.118096310748,377.251678467,0.0
+1209425,31,107.250000003,61,1.66159911634,175,273,98,239.818181818,12.6238219863,102882,242.0,195,370,175,311.361305361,24.113706829,133574,316.0,543,901,358,763.778554779,70.1357651565,327661,775.0,163,416,253,286.002331002,36.3578753431,122695,290.0,0.315789461136,0.624423980713,0.308634519577,0.455769755832,0.041695615821,195.525225252,0.45571,542,1054,512,837.181818182,69.4758903727,359151,848.0,-0.00784301757812,3.91806030273,3.92590332031,2.59712429091,0.883354411956,1114.1663208,2.93488
+1208901,32,22.5000000002,42,2.4977737626,236,310,74,266.377777778,11.8963839303,23974,266.0,346,457,111,391.688888889,17.8808677669,35252,393.0,882,1054,172,945.222222222,29.8227272685,85070,941.0,318,490,172,392.266666667,28.5745807785,35304,397.0,0.365284979343,0.478331983089,0.113047003746,0.414097983307,0.0220183656596,37.2688184977,0.40959,901,1257,356,1050.33333333,56.7585529531,94530,1055.5,-0.034423828125,0.280364990234,0.314788818359,0.0232432047526,0.0596850399484,2.09188842773,0.0
+1202529,12,3.0,8,1.30294003174,196,234,38,214.333333333,10.5461946797,2572,216.5,240,290,50,269.5,16.7107749671,3234,270.0,541,609,68,579.5,24.9181995069,6954,582.0,184,236,52,213.833333333,18.3794873583,2566,214.0,0.416563659906,0.51530611515,0.0987424552441,0.461595746378,0.0271138151212,5.53914895654,0.454798,620,760,140,697.666666667,44.0933353493,8372,701.5,0.0,0.0814208984375,0.0814208984375,0.00678507486979,0.0225035475176,0.0814208984375,0.0
+1197034,12,8.0000000007,24,2.3936536823,227,320,93,272.5625,24.6854429523,8722,276.5,301,450,149,372.09375,37.3558557784,11907,379.0,442,687,245,580.65625,64.0734975316,18581,594.5,285,515,230,409.25,64.0907559637,13096,420.5,0.0915684476495,0.260240972042,0.168672524393,0.175948669435,0.0420529775498,5.63035742193,0.170899,820,1284,464,1053.90625,124.765620108,33725,1078.5,0.00308227539062,1.34970092773,1.34661865234,0.360600471497,0.280422441291,11.5392150879,0.293701
+1202723,34,189.250000006,137,2.80929723053,187,345,158,263.968295905,22.2486619342,199824,263.0,217,541,324,364.055482166,48.1710359561,275590,366.0,541,1248,707,956.915455746,111.60386274,724385,954.0,149,558,409,346.705416116,69.6680874901,262456,344.0,0.252552747726,0.628762543201,0.376209795475,0.470606672087,0.0675767123615,356.24925077,0.47963,553,1384,831,974.729194188,134.547421255,737870,977.0,-0.118774414062,3.10452270508,3.22329711914,0.896244265759,1.04076618001,678.45690918,0.00271606
+1167664,22,428.99999999,301,4.09951913142,289,454,165,400.135198135,14.6839000133,686632,400.0,418,733,315,629.007575758,26.2714104217,1079377,628.0,778,1146,368,1052.62529138,34.6715193704,1806305,1057.0,496,968,472,839.657925408,34.6594000325,1440853,842.0,0.0832102447748,0.221350073814,0.13813982904,0.112696046869,0.00987273421781,193.386416428,0.112256,1203,2141,938,1868.8006993,71.8415028933,3206862,1871.0,-0.0531616210938,0.490478515625,0.543640136719,0.0830469553843,0.115310698797,142.508575439,0.029129
+1172519,32,319.499999994,425,6.70731289839,247,362,115,292.241001565,14.2094705882,373484,292.0,345,536,191,421.193270736,24.160607337,538285,421.0,761,1095,334,887.064945227,43.0592961028,1133669,883.0,363,685,322,489.064162754,38.6601574845,625024,488.0,0.209964409471,0.375752359629,0.165787950158,0.289947488417,0.02223377714,370.552890196,0.288497,968,1559,591,1202.49843505,74.5077192799,1536793,1200.0,-0.0445556640625,0.941070556641,0.985626220703,0.144777300959,0.132454515051,185.025390625,0.141357
+1130580,34,544.000000007,199,2.40684816883,226,369,143,280.886029412,15.9981004056,611208,279.0,286,561,275,401.012408088,28.2599756673,872603,397.0,515,1105,590,887.230238971,54.2396458093,1930613,888.0,258,687,429,434.305147059,49.4392609672,945048,429.0,0.182501703501,0.477042794228,0.294541090727,0.343994971906,0.0423776049314,748.533058867,0.347151,781,1617,836,1116.20358456,91.4032727948,2428859,1106.0,-0.170349121094,0.866455078125,1.03680419922,0.0603473607232,0.127771609056,131.315856934,0.0
+1099207,11,9.00000000023,13,1.22241076434,381,496,115,442.0,29.6601116354,15912,441.5,565,744,179,652.75,48.0204672799,23499,648.5,765,982,217,872.361111111,57.4244202688,31405,869.5,695,959,264,807.777777778,72.7526674238,29080,798.5,0.000523834489286,0.0849349051714,0.0844110706821,0.0393336600327,0.0191783999849,1.41601176118,0.0415295,1659,2194,535,1902.52777778,143.756446447,68491,1889.5,-0.000823974609375,0.323486328125,0.324310302734,0.211590237088,0.0769838141624,7.61724853516,0.232544
+1096105,12,4.75000000023,12,1.55320760818,201,270,69,238.315789474,26.2759698736,4528,246.0,264,379,115,319.684210526,39.5222157801,6074,328.0,497,775,278,672.684210526,93.8851777055,12781,701.0,194,387,193,285.315789474,66.4862887579,5421,300.0,0.32870772481,0.52450978756,0.19580206275,0.410696942555,0.0511077686767,7.80324190855,0.423077,665,1036,371,843.315789474,132.033908177,16023,874.0,4.47250366211,4.546875,0.0743713378906,4.51248329564,0.0222912044283,85.7371826172,4.50604
+1072356,32,59.2499999963,91,3.33497269876,230,361,131,312.624472574,25.8570867841,74092,318.0,384,574,190,484.814345992,39.9993581818,114901,490.0,839,1080,241,973.443037975,45.601210335,230706,983.0,432,750,318,606.476793249,63.4637715971,143735,622.0,0.154929578304,0.346786260605,0.191856682301,0.234132161812,0.0378130859016,55.4893223494,0.224212,1060,1683,623,1403.91561181,124.95728067,332728,1429.0,-0.0262756347656,0.472534179688,0.498809814453,0.0806049073296,0.128770598411,19.1033630371,0.0
+1061638,32,652.999999979,583,6.4358665774,215,352,137,262.340352221,15.9433869559,685233,260.0,285,542,257,378.463629403,27.9822571819,988547,376.0,729,1204,475,962.443721286,76.2755561245,2513903,961.0,252,561,309,359.717840735,39.831608843,939583,356.0,0.272727280855,0.572948336601,0.300221055746,0.455639228693,0.0479092519563,1190.12966534,0.458014,774,1413,639,1000.52182236,78.1262764211,2613363,990.0,-0.0508422851562,0.671691894531,0.722534179688,0.0467784817332,0.0985035750116,122.185394287,0.0
+1045783,32,911.000000011,766,7.15920253961,245,372,127,307.082052689,18.5644696987,1119007,307.0,344,561,217,451.717343578,31.9297169302,1646058,452.0,791,1167,376,952.935784852,53.5618505739,3472498,951.0,340,718,378,527.629802415,54.6820206453,1922683,527.0,0.195214107633,0.440381556749,0.245167449117,0.288712145006,0.0329784315893,1052.0670564,0.287101,944,1651,707,1286.42919868,103.674489447,4687748,1287.0,-0.0448608398438,0.901000976562,0.945861816406,0.0897637209175,0.113607628422,327.098999023,0.0586548
+1022364,12,3.25,13,2.03421447256,202,280,78,242.923076923,27.7833971962,3158,240.0,250,382,132,321.461538462,47.3848651342,4179,319.0,491,668,177,585.384615385,59.4701456603,7610,594.0,241,460,219,362.692307692,79.4591182892,4715,364.0,0.162790700793,0.360419392586,0.197628691792,0.243465493505,0.0680829015089,3.16505141556,0.209555,693,1115,422,927.076923077,154.404793438,12052,922.0,0.541381835938,0.95361328125,0.412231445312,0.688014103816,0.132530573867,8.94418334961,0.622589
+940309,22,595.250000012,389,4.49774642746,351,471,120,419.779924402,18.387433856,999496,418.0,539,744,205,654.597228055,32.1159487301,1558596,651.0,949,1176,227,1062.55438891,33.4227010466,2529942,1058.0,684,1010,326,874.11549769,38.4444227495,2081269,871.0,0.0742438137531,0.165249094367,0.0910052806139,0.0975279818778,0.00970045741089,232.214124851,0.0957895,1581,2195,614,1948.49265015,86.9432829395,4639361,1941.0,-0.0562744140625,1.11038208008,1.16665649414,0.162453027795,0.1883915735,386.80065918,0.10434
+1014375,31,83.7499999995,85,2.62012243515,191,275,84,245.704477612,11.2079054301,82311,246.0,275,407,132,349.88358209,25.2180023178,117211,354.0,892,1209,317,1096.40895522,44.6492457236,367297,1101.0,206,377,171,300.11641791,30.5649521121,100539,303.0,0.501385033131,0.654558956623,0.153173923492,0.570875366054,0.0310513780375,191.243247628,0.57012,672,1051,379,895.704477612,65.3254023249,300061,903.0,-0.0325927734375,0.713562011719,0.746154785156,0.00509461360191,0.0431272483562,1.70669555664,0.0
+1034876,21,1085.49999993,1023,8.75902544195,203,585,382,336.330953478,26.7282993328,1460349,336.0,338,819,481,510.881621373,43.0980937223,2218248,509.0,645,1176,531,951.406264394,68.004462675,4131006,953.0,354,1028,674,649.80561953,64.6636052082,2821456,652.0,0.0542778298259,0.327421545982,0.273143716156,0.189356271691,0.032293521902,822.184931681,0.18509,914,2432,1518,1497.01819438,124.760329941,6500053,1497.0,-0.151062011719,1.06826782227,1.21932983398,0.0748537082048,0.144859965204,325.014801025,0.0
+1001346,51,9.50000000023,26,2.37961453676,252,382,130,319.578947368,39.6475469334,12144,329.5,328,546,218,444.657894737,69.4217758631,16897,457.0,476,812,336,617.947368421,89.7663479814,23482,629.5,319,630,311,467.578947368,94.2476110486,17768,482.0,0.0827309265733,0.231325298548,0.148594371974,0.143757387604,0.039296688618,5.46278072894,0.127495,899,1499,600,1231.81578947,199.601689591,46809,1278.0,-0.0375366210938,0.638702392578,0.676239013672,0.322443911904,0.271295198336,12.2528686523,0.244461
+999639,31,181.499999992,93,1.9473306607,213,320,107,250.717630854,14.184105989,182021,250.0,277,470,193,344.898071625,26.7272329751,250396,343.0,632,1165,533,909.903581267,103.56756921,660590,912.5,218,526,308,316.061983471,40.3511141295,229461,311.0,0.304777592421,0.578378379345,0.273600786924,0.483761984701,0.0407203285797,351.211200893,0.488949,721,1316,595,911.67768595,79.3676330914,661878,905.5,-0.0476989746094,7.50601196289,7.5537109375,4.91464624326,2.31005567833,3568.03317261,6.46284
+1007957,51,544.999999995,375,4.53135497006,213,321,108,266.369266055,13.8915151456,580685,266.0,270,488,218,378.70412844,24.9172038394,825575,378.0,611,1107,496,879.303669725,54.6947701014,1916882,881.0,250,588,338,403.29266055,43.6303766045,879178,400.0,0.216000005603,0.497017890215,0.281017884612,0.371973515849,0.0423580056927,810.90226455,0.372442,743,1376,633,1048.36605505,78.8331354914,2285438,1044.5,-0.203948974609,1.37106323242,1.57501220703,0.0583917880277,0.143899442182,127.2940979,0.0
+1040284,12,2013.75,890,5.59477077884,143,483,340,265.0761018,17.9136987264,2135188,264.0,208,634,426,377.048417132,28.6996889125,3037125,376.0,587,1232,645,964.763252638,69.6512671073,7771168,971.0,175,570,395,357.954065798,45.4073076539,2883320,356.0,0.255304574966,0.644948065281,0.389643490314,0.459470167273,0.0492220352068,3701.03219739,0.458045,594,1638,1044,1000.07858473,86.193639098,8055633,995.0,-0.102233886719,2.81539916992,2.91763305664,0.18568425146,0.477702325469,1495.68664551,0.0
+1089690,14,1298.25,796,6.23202188949,230,376,146,295.92817254,6.84825213887,1536755,296.0,296,513,217,401.859811284,11.9908491219,2086858,401.0,385,666,281,547.177739264,30.4214283973,2841494,540.0,267,598,331,469.916618525,24.9742748283,2440277,465.0,0.0331447049975,0.180981591344,0.147836886346,0.0759071535794,0.0105466316116,394.185848538,0.0751445,840,1485,645,1167.70460235,40.7385242253,6063890,1163.0,-0.003173828125,2.19122314453,2.19439697266,0.823902731752,0.408269485126,4278.52688599,0.803345
+1025814,21,4258.25,2579,11.1488695155,250,419,169,362.739799213,14.6902913844,6178547,363.0,381,682,301,552.050372806,25.3747035751,9403074,553.0,726,1141,415,951.92461692,39.8472787635,16214132,952.0,410,856,446,712.457288792,38.4519493487,12135285,715.0,0.0714675411582,0.278169006109,0.206701464951,0.144117741046,0.0202942842521,2454.75748323,0.140541,1059,1926,867,1627.24746081,73.7878121581,27716906,1630.0,-0.187530517578,3.65393066406,3.84146118164,0.0670613683216,0.204873407861,1142.25628662,0.0
+975871,21,1468.75000003,810,5.96219460268,264,415,151,324.042382979,17.8237921157,1903749,324.0,371,599,228,486.221787234,30.1126735494,2856553,485.0,655,1122,467,886.154382979,61.7809238267,5206157,887.0,428,817,389,650.71812766,53.7482662274,3822969,652.0,0.0771191865206,0.290272384882,0.213153198361,0.153539995412,0.0293772162456,902.047473043,0.147786,1064,1812,748,1460.98229787,89.6431166766,8583271,1461.0,-0.151580810547,0.984802246094,1.13638305664,0.0581182731466,0.120361023612,341.444854736,0.0
+984173,51,5.25,16,1.96986016984,241,336,95,272.714285714,24.0913793259,5727,267.0,305,453,148,360.857142857,38.5329614181,7578,350.0,416,624,208,519.476190476,60.5125874726,10909,517.0,239,436,197,339.571428571,62.6346712358,7131,330.0,0.113636367023,0.28869047761,0.175054110587,0.213942089961,0.0457138179351,4.49278388917,0.225305,811,1218,407,973.142857143,115.793036107,20436,927.0,0.00042724609375,1.04037475586,1.03994750977,0.118219284784,0.225456758467,2.48260498047,0.0547791
+963807,33,509.999999993,259,3.23526414015,249,371,122,299.512745098,20.3086921001,611006,297.0,333,553,220,429.578921569,36.6437091251,876341,428.0,714,1022,308,851.899019608,46.2068622251,1737874,851.0,393,764,371,561.017156863,64.7390326828,1144475,566.0,0.088874258101,0.341853022575,0.252978764474,0.208095088042,0.0396115959704,424.513979606,0.203017,995,1688,693,1290.10882353,116.148096473,2631822,1293.0,-0.030517578125,0.737518310547,0.768035888672,0.143632791557,0.140921368062,293.010894775,0.124863
+968008,21,3113.99999999,3347,16.9196539447,251,504,253,363.097061657,19.4349979054,4522737,362.0,365,766,401,555.15004817,31.7989461093,6914949,555.0,673,1227,554,958.885597303,55.7765333665,11943879,958.0,471,1051,580,765.843930636,48.2622647075,9539352,768.0,0.0172064770013,0.257824152708,0.240617675707,0.112043405779,0.0204981619205,1395.61266238,0.108491,1087,2241,1154,1684.09104046,91.9043043218,20977038,1683.0,-0.434417724609,2.93383789062,3.36825561523,0.142133020635,0.335044428925,1770.40890503,0.0
+954845,32,1256.25,693,5.51556827887,246,367,121,294.830447761,16.2326710756,1481523,294.0,348,548,200,435.11840796,28.1590032164,2186470,434.0,837,1210,373,1008.52935323,51.1227844374,5067860,1006.0,328,663,335,465.925970149,48.34213156,2341278,463.0,0.271966516972,0.475862056017,0.203895539045,0.369306930541,0.0322648481376,1855.76732597,0.369176,933,1566,633,1195.87482587,91.2181467779,6009271,1190.0,-0.0606384277344,1.07620239258,1.13684082031,0.0232369949569,0.0674909409178,116.765899658,0.0
+967303,34,3221.50000004,1610,8.00187708834,209,330,121,265.789306224,13.3853306999,3424961,265.0,273,490,217,371.109576284,25.0476145644,4782118,369.0,644,1094,450,870.834316312,53.9319629223,11221571,868.0,210,577,367,373.050830359,39.6624862159,4807133,371.0,0.265519827604,0.564870238304,0.2993504107,0.401259902197,0.0320395609813,5170.63509971,0.400157,697,1390,693,1009.94971287,76.7359062151,13014212,1005.0,-0.154724121094,2.22180175781,2.37652587891,0.10903679627,0.187159738403,1405.04815674,0.00630188
+901895,11,103.0,45,1.25080315899,281,424,143,385.126213592,14.51793642,158672,388.0,343,612,269,564.839805825,27.0321377946,232714,571.0,554,840,286,672.339805825,37.244352774,277004,666.0,328,709,381,625.34223301,33.7762751064,257641,628.0,-0.0402525663376,0.264573991299,0.304826557636,0.0363111887647,0.0348587655573,14.9602097711,0.0285037,952,1741,789,1575.30825243,71.891872894,649027,1586.0,-0.0172119140625,5.30361938477,5.32083129883,4.36741971507,0.54757440962,1799.37692261,4.35921
+892191,11,22.75,20,1.18286277094,372,469,97,426.318681319,20.6519451341,38795,430.0,531,647,116,595.571428571,23.5354037065,54197,602.0,612,777,165,671.527472527,39.1470433558,61109,664.0,594,681,87,632.087912088,19.4640544163,57520,630.0,-0.0284810122102,0.115577891469,0.144058903679,0.0296251372713,0.0286060709223,2.69588749169,0.0255591,1516,1773,257,1653.97802198,54.1747230345,150512,1660.0,0.665588378906,1.66912841797,1.00354003906,0.800172910586,0.236679459809,72.8157348633,0.712128
+878993,31,752.499999995,291,2.99250444964,204,318,114,261.318604651,15.724343213,786569,262.0,248,458,210,357.090365449,30.7305913175,1074842,360.0,570,1144,574,878.2910299,78.2211981061,2643656,881.0,160,551,391,344.377740864,51.1808840607,1036577,345.0,0.201449275017,0.620618581772,0.419169306755,0.43744973972,0.0627820753812,1316.72371656,0.434199,613,1325,712,962.786710963,95.0853770376,2897988,968.0,-0.116027832031,2.60800170898,2.72402954102,0.446591926651,0.665968798411,1344.24169922,0.0510559
+858035,51,21.0000000005,32,1.96986016982,205,274,69,233.547619048,12.697398273,19618,233.5,256,371,115,293.726190476,23.5565940573,24673,288.5,359,720,361,521.928571429,81.6996219777,43842,527.0,183,453,270,277.476190476,48.5409685068,23308,269.5,0.182410418987,0.425233632326,0.242823213339,0.305565841319,0.0540024517078,25.6675306708,0.304176,656,1098,442,804.75,80.2254078919,67599,792.5,-0.0711364746094,1.05416870117,1.12530517578,0.0608440580822,0.171810959271,5.11090087891,0.0
+839703,11,100.999999994,142,3.98586628763,233,510,277,370.631188119,47.2104003223,149735,367.0,272,804,532,530.71039604,68.5123230286,214407,533.5,432,1114,682,750.319306931,95.064904996,303129,751.5,307,832,525,583.792079208,82.6866405855,235852,577.0,-0.0279898215085,0.314241498709,0.342231320217,0.125601042435,0.051254802788,50.7428211439,0.124409,812,2055,1243,1485.13366337,171.849856628,599994,1499.0,-0.138305664062,0.601867675781,0.740173339844,0.283301778359,0.148710695945,114.453918457,0.324188
+835972,32,2782.5,1614,8.63139539976,199,353,154,279.77214735,19.5345299035,3113864,280.0,272,542,270,411.938274933,34.0346799968,4584873,412.0,643,1125,482,908.393530997,63.7626088753,10110420,913.0,246,660,414,433.953279425,55.608091244,4829900,431.0,0.180830672383,0.518835604191,0.338004931808,0.355052817161,0.0462256296528,3951.737855,0.355224,717,1536,819,1125.66370171,105.53220713,12528637,1122.0,-0.102386474609,1.0866394043,1.18902587891,0.0493333759976,0.109123788207,549.080474854,0.0
+792809,33,276.99999999,205,3.47463383617,219,290,71,255.303249097,10.6781816547,282876,255.0,267,411,144,335.525270758,19.1926461083,371762,334.0,504,838,334,703.505415162,44.4038222359,779484,703.5,252,492,240,358.781588448,32.9835746291,397530,362.0,0.190391466022,0.479338854551,0.28894738853,0.324850585675,0.0437385253138,359.934448928,0.326373,748,1186,438,949.610108303,59.5065264053,1052168,953.0,-0.114624023438,0.934020996094,1.04864501953,0.0982249566364,0.177879003683,108.833251953,0.0
+807852,34,74.4999999979,43,1.40535287738,237,272,35,256.959731544,5.20825260812,76574,257.0,345,407,62,379.637583893,10.0820225181,113132,380.0,964,1276,312,1138.97315436,58.1433597758,339414,1140.5,270,354,84,313.879194631,16.7954183396,93536,314.0,0.507823586464,0.625503361225,0.117679774761,0.567264090248,0.0287409281721,169.044698894,0.568912,853,1028,175,950.476510067,30.0945008004,283242,951.0,-0.0328369140625,0.428161621094,0.460998535156,0.0725808367633,0.12852701885,21.6290893555,0.0
+799945,34,2465.50000001,1569,8.91385382845,199,329,130,255.587710404,14.4583950225,2520606,254.0,243,478,235,345.435104441,25.9612560314,3406681,344.0,515,1109,594,794.762928412,63.7937190101,7837952,802.0,168,504,336,334.430642872,41.9460958902,3298155,333.0,0.244367420673,0.626187980175,0.381820559502,0.408756603351,0.0414523063053,4031.15762225,0.409892,624,1266,642,935.453457716,79.9304568305,9225442,932.0,-0.186767578125,1.16137695312,1.34814453125,0.0937145715117,0.201415687934,924.213104248,0.0
+774687,32,169.000000007,158,3.42853669995,246,412,166,299.905325444,19.7426467784,202736,300.0,335,555,220,448.695266272,33.6910612882,303318,449.0,770,1127,357,954.079881657,56.1183197207,644958,960.0,336,716,380,490.50887574,46.1428343714,331584,489.0,0.207526281476,0.392405062914,0.184878781438,0.321802884517,0.0287287889084,217.538749933,0.326719,926,1683,757,1239.10946746,94.5657460425,837638,1236.5,-0.050537109375,0.618133544922,0.668670654297,0.0583807138296,0.130271094058,39.4653625488,0.0
+780679,34,6247.74999996,2551,9.10424015138,178,361,183,260.876635589,18.8376010834,6519568,258.0,210,588,378,366.491937097,33.3864583481,9159000,363.0,456,1151,695,852.811252051,80.2210250225,21312606,853.0,118,664,546,366.251970709,56.0364628102,9153003,359.0,0.14091680944,0.674482762814,0.533565953374,0.400363228274,0.057466074728,10005.4774378,0.402715,555,1573,1018,993.620543396,103.96269269,24831571,980.0,-0.296142578125,4.12670898438,4.4228515625,0.104035747547,0.459069034996,2599.95736694,0.0
+753465,32,421.750000008,248,3.40658479131,237,318,81,274.119739182,13.2455674814,462440,273.0,312,487,175,407.893894487,24.793420441,688117,406.0,711,1063,352,920.498518079,54.8120123338,1552881,924.0,308,568,260,425.043864849,44.3794248001,717049,420.0,0.273209542036,0.485057473183,0.211847931147,0.369140699886,0.0374615385264,622.740360707,0.364592,863,1368,505,1107.05749852,80.6631650139,1867606,1098.0,-0.110198974609,0.740417480469,0.850616455078,0.0655327272896,0.103886623781,110.553710938,0.0
+739424,11,10.0,15,1.33809308711,355,508,153,424125,45.8334962118,16965,426.0,477,702,225,598725,67.0540779893,23949,598.5,709,1037,328,866.45,77.9441947806,34658,854.0,435,842,407,655825,103.027396235,26233,695.0,0.0456047579646,0.309119015932,0.263514257967,0.142355370242,0.0660043989223,5.69421480969,0.13741,1288,1976,688,1678675,197.831163811,67147,1703.5,0.008544921875,2.54516601562,2.53662109375,1.48658752441,0.907656441221,59.4635009766,1.20941
+761062,22,3658.25000005,1475,6.87939739585,223,605,382,359.70081323,19.2372849787,5263502,360.0,345,886,541,567.871728285,34.773994005,8309667,569.0,687,1404,717,994.74557507,52.3707625106,14556112,1001.0,432,1277,845,778.82102098,48.5628393396,11396488,782.0,0.0313174948096,0.256431549788,0.225114054978,0.122006459484,0.0148310293937,1785.32052162,0.120709,1000,2768,1768,1706.3935625,98.8200793496,24969657,1713.0,-0.0945739746094,0.86669921875,0.961273193359,0.0399179348476,0.0957013385131,584.119140625,0.0
+701131,33,503.750000009,391,4.91432976878,216,320,104,273.378163772,12.8802046592,550857,273.0,288,487,199,388.524565757,24.8631842792,782877,387.0,551,1111,560,823.732506203,71.1541325649,1659821,813.0,234,570,336,408.656079404,37.8144527297,823442,407.0,0.2261146456,0.555555582047,0.329440936446,0.336608719116,0.0359226236036,678.266569018,0.33098,752,1374,622,1070.55880893,73.9295177088,2157176,1067.0,-0.0904541015625,0.566497802734,0.656951904297,0.0810268657675,0.110762765178,163.269134521,0.0
+703709,34,44.7500000009,36,1.51810233734,238,306,68,262.240223464,11.4024084467,46941,260.0,321,440,119,366.094972067,21.0900417967,65531,363.0,820,1126,306,981.832402235,66.644180326,175748,978.0,253,441,188,335.731843575,35.0178827812,60096,331.0,0.363086223602,0.609531104565,0.246444880962,0.489996231302,0.048717137361,87.709325403,0.490673,816,1181,365,964.067039106,63.6601133434,172568,956.0,-0.131286621094,0.559356689453,0.690643310547,0.159777252368,0.184858558575,28.6001281738,0.110992
+744308,22,7545.25000006,3060,9.93755802412,256,680,424,366.908916206,24.9756838842,11073678,368.0,359,1073,714,548.380007289,43.7435577753,16550657,550.0,662,1646,984,927.476160498,62.1109911856,27992158,932.0,395,1600,1205,719.1978397,67.8798684553,21706110,724.0,0.0141712874174,0.28799328208,0.273821994662,0.127552403396,0.0210852242187,3849.65908689,0.124088,1010,3353,2343,1634.4867632,135.020644592,49330445,1643.0,-0.118011474609,1.62094116211,1.73895263672,0.115452399591,0.16781546063,3484.46887207,0.0441589
+674844,31,63.0000000019,45,1.59932713965,206,272,66,244.599206349,12.2585441278,61639,244.0,257,390,133,331.234126984,23.8639652059,83471,333.0,692,1188,496,973.587301587,91.1238708503,245344,989.5,182,374,192,282.571428571,31.4416639396,71208,284.5,0.441590726376,0.62460565567,0.183014929295,0.549968956127,0.03219583127,138.592176944,0.548198,645,1024,379,858.404761905,65.4595086974,216318,862.0,-0.0558166503906,2.69165039062,2.74746704102,2.1038063897,1.02865511818,530.159210205,2.59998
+662203,34,396.249999996,188,2.66420892993,222,297,75,257.590536278,11.1817578468,408281,257.0,313,445,132,373.295268139,18.7118244724,591673,374.0,830,1139,309,986.851735016,43.2338236391,1564160,987.0,236,440,204,340.10977918,32.7129654153,539074,339.0,0.393274843693,0.612797379494,0.219522535801,0.487820302462,0.0388151198135,773.195179403,0.488266,779,1172,393,970.995583596,60.5184486776,1539028,969.0,-0.125823974609,1.06912231445,1.19494628906,0.0804777416145,0.165896320198,127.557220459,0.0
+646693,22,240.75000001,213,3.87250086572,321,477,156,405.826583593,24.0570462442,390811,405.0,532,817,285,673.998961578,42.9515774466,649061,675.0,920,1373,453,1149.64797508,66.8598421146,1107111,1153.0,679,1091,412,910.51298027,60.7357159662,876824,909.0,0.0691334009171,0.222222223878,0.153088822961,0.116290709095,0.0215037579509,111.987952858,0.113412,1543,2376,833,1990.33852544,118.467129138,1916696,1992.0,-0.678161621094,2.98785400391,3.666015625,0.476086641274,0.701904757459,458.471435547,0.0588379
+630048,33,1707.50000001,801,5.46823572507,196,690,494,267.791654466,22.2396916233,1829017,264.0,256,635,379,380.630161054,36.0800309927,2599704,373.0,488,1121,633,827.562811127,75.4614118506,5652254,824.0,179,883,704,397.364860908,64.0153243534,2714002,385.0,0.102642275393,0.53766232729,0.435020051897,0.353582119,0.054459367231,2414.96587277,0.352034,647,2069,1422,1045.78667643,117.651517951,7142723,1020.0,-0.140441894531,1.71514892578,1.85559082031,0.110833619594,0.242511057995,756.993621826,0.0
+603613,33,617.749999984,458,5.19821417235,193,396,203,283.919870498,21.5850096218,701566,281.0,259,554,295,398.984216916,37.1267333331,985890,395.0,508,1074,566,776.03358964,70.4665960744,1917579,776.0,242,725,483,455.614730878,68.5168517491,1125824,448.0,0.110803321004,0.428571432829,0.317768111825,0.262628304547,0.0512871260922,648.954540536,0.257795,700,1633,933,1138.51881829,123.207610509,2813280,1125.0,-0.057861328125,1.29135131836,1.34921264648,0.0837163736057,0.170422661663,206.86315918,0.0
+612300,21,6562.74999999,4753,16.5508366336,212,397,185,317.014628014,20.0207963788,8321951,317.0,315,637,322,481.100834254,35.2880612993,12629378,481.0,618,1092,474,858.537122395,62.7674980545,22537458,857.0,356,875,519,619.522189631,59.0236608027,16263077,621.0,0.060085836798,0.331574320793,0.271488483995,0.16250543752,0.0312589857875,4265.93024033,0.157354,893,1879,986,1417.6376519,109.399605653,37214406,1420.0,-0.464111328125,3.18496704102,3.64907836914,0.0701754318864,0.172633455022,1842.17526245,0.0
+598069,21,3139.00000004,1508,7.59277886791,230,410,180,334.066422428,13.2108534512,4194538,334.0,350,647,297,524.422507168,22.4794614402,6584649,525.0,687,1139,452,984.036158012,39.2569215852,12355558,985.0,420,870,450,731.387225231,37.6890618081,9183298,733.0,0.0813743248582,0.29103448987,0.209660165012,0.147529442137,0.0144535482163,1852.37967548,0.145171,1023,1835,812,1589.87615483,67.8891578422,19962485,1593.0,-0.103546142578,1.39016723633,1.49371337891,0.0562398496727,0.133617805273,706.14755249,0.0
+552200,34,129.999999997,94,2.32568689373,192,263,71,244.461538462,9.32812442699,127120,246.0,245,383,138,336.45,20.9954528044,174954,341.0,794,1199,405,1090.29230769,77.7805291192,566952,1114.5,137,342,205,281.942307692,27.3368682168,146610,286.0,0.516949176788,0.752707600594,0.235758423805,0.58934145673,0.0250635003723,306.457557499,0.588892,574,978,404,862.853846154,56.4269932048,448684,873.5,-0.186065673828,2.04730224609,2.23336791992,0.207422227126,0.314294880261,107.859558105,0.100159
+563708,31,109.000000003,87,2.35072091639,203,258,55,234.821100917,8.33887297287,102382,235.0,257,364,107,316.777522936,17.0629850285,138115,317.5,844,1173,329,1039.07110092,61.7950666782,453035,1041.5,166,305,139,251.05733945,21.747169304,109461,252.0,0.528582632542,0.684710323811,0.156127691269,0.61088537582,0.0245082643279,266.346023858,0.611139,626,917,291,802.655963303,45.5607869607,349958,806.0,-0.00778198242188,1.03744506836,1.04522705078,0.12501196905,0.252023059126,54.5052185059,0.0
+556987,22,3897.25,2913,13.1630466292,217,453,236,385.436846494,19.5832568774,6008575,386.0,304,718,414,600.536981205,33.863110311,9361771,601.0,545,1349,804,1063.98332157,60.7102274113,16586436,1061.0,294,1023,729,817.521072551,55.6849628079,12744336,820.0,0.0673417747021,0.299165666103,0.231823891401,0.131353051849,0.0206871847838,2047.66272527,0.127233,816,2168,1352,1803.49490025,106.209383069,28114682,1807.0,-0.134643554688,3.6335144043,3.76815795898,0.0712663382684,0.253192760622,1110.97094727,0.0
+531446,33,132.250000003,87,2.1341084247,278,420,142,340.173913043,17.3070786571,179952,339.0,381,568,187,489.502835539,26.4797331549,258947,489.0,560,869,309,743.446124764,44.8386039656,393283,744.0,393,740,347,604.965973535,43.9487454422,320027,606.0,0.0704410821199,0.191391244531,0.120950162411,0.103109475204,0.014024220842,54.544912383,0.102072,1052,1676,624,1434.64272212,82.1571350997,758926,1437.0,-0.0945739746094,0.192810058594,0.287384033203,0.0109953276376,0.0316050780832,5.81652832031,0.0
+535524,11,11.25,20,1.68208834801,470,635,165,570.711111111,47.1921001968,25682,585.0,639,922,283,815.622222222,70.5314079412,36703,846.0,701,957,256,857.4,54.1070543768,38583,860.0,644,1013,369,829.466666667,86.7588227982,37326,819.0,-0.0368474908173,0.126779660583,0.1636271514,0.0182351563048,0.0365187401487,0.820582033717,0.00840336,1779,2501,722,2215.8,172.530396678,99711,2259.0,0.313415527344,0.438232421875,0.124816894531,0.377438693576,0.0324138815486,16.9847412109,0.379639
+553497,21,1797.49999996,1194,7.9444702903,233,388,155,309.796244784,19.2271702263,2227435,310.0,330,625,295,461.770514604,34.3611218774,3320130,462.0,516,1080,564,870.249513213,63.6895770248,6257094,870.0,322,804,482,579.100556328,57.4413267774,4163733,579.0,0.0933333337307,0.343044430017,0.249711096287,0.20173076778,0.0341496390143,1450.44422034,0.198294,910,1785,875,1350.66731572,105.60720003,9711298,1350.0,-0.258544921875,3.33581542969,3.59436035156,0.0619314689795,0.292681496129,445.287261963,0.0
+533949,32,876.499999982,794,7.56553439801,208,398,190,296.73074729,22.1764421848,1040338,296.0,260,598,338,421.947803765,39.5758943212,1479349,422.0,653,1263,610,890.108385625,78.5294513726,3120720,895.0,223,748,525,471.703650884,61.8434185037,1653793,471.0,0.1616294384,0.496614009142,0.334984570742,0.308676365548,0.0466354965356,1082.21933761,0.307943,693,1744,1051,1190.38220194,120.869293669,4173480,1191.0,-0.141448974609,0.508483886719,0.649932861328,0.0795193643347,0.100906603934,278.794891357,0.0317993
+510771,22,552.499999987,460,5.52060606869,304,473,169,393.833936652,18.6166379966,870373,396.0,453,724,271,612.470588235,35.1143097014,1353560,615.0,723,1135,412,988.258371041,61.4051727085,2184051,996.0,510,929,419,810.815837104,51.96449382,1791903,817.0,-0.0449943765998,0.220607668161,0.265602044761,0.0986566314238,0.0212865750018,218.031155447,0.0990592,1267,2076,809,1817.12036199,101.866237338,4015836,1827.0,-0.0265197753906,0.282135009766,0.308654785156,0.00700771970447,0.028194658574,15.4870605469,0.0
+506624,41,1315.99999996,840,6.53200350975,287,312,25,302.892857143,2.55619113396,1594428,303.0,442,488,46,471.320858663,4.71257996229,2481033,471.0,383,460,77,417.52906535,5.97018862063,2197873,418.0,496,574,78,544.297302432,7.54572839686,2865181,544.0,-0.169652268291,-0.0799999982119,0.0896522700787,-0.131798232007,0.00561249432793,-693.785893284,-0.131498,1225,1372,147,1318.51101824,13.8409012456,6940642,1319.0,0.0,0.0,0.0,0.0,0.0,0.0,0.0
+503770,22,4602.49999999,2340,9.73002658353,242,465,223,390.411678436,21.5330738487,7187479,392.0,322,731,409,604.413307985,38.1764394494,11127249,608.0,708,1282,574,1022.06387833,60.8072469876,18816196,1023.0,429,984,555,802.648451928,57.5034811222,14776758,808.0,0.062068965286,0.303174614906,0.24110564962,0.120643950134,0.0200462440626,2221.05512197,0.11651,1020,2180,1160,1797.47343835,114.072467488,33091486,1809.0,-0.181732177734,0.974792480469,1.1565246582,0.067235525816,0.12543331308,1237.80603027,0.0
+499564,41,10675.2500001,8212,22.4210001447,296,319,23,306.843797569,2.60633949155,13102537,307.0,460,505,45,482.781363434,4.83021684829,20615247,483.0,382,429,47,403.954497553,5.0910737647,17249261,404.0,538,606,68,569.548464907,7.50286855188,24320289,569.0,-0.181086525321,-0.158106744289,0.0229797810316,-0.170096199028,0.00284960154171,-7263.27779469,-0.170082,1299,1422,123,1359.17362591,14.1656973204,58038073,1358.0,0.0,0.0,0.0,0.0,0.0,0.0,0.0
+480205,11,22.0,23,1.38328466879,331,403,72,359.590909091,14.3737737529,31644,360.0,502,604,102,545.113636364,18.7340427966,47970,542.0,628,804,176,693.238636364,36.9932408808,61005,686.5,549,684,135,615.613636364,29.2828804385,54174,616.5,0.0278824418783,0.111434817314,0.0835523754358,0.0591494347477,0.0226225198403,5.2051502578,0.0526676,1394,1691,297,1520.31818182,55.2639421846,133788,1521.0,-0.0361938476562,2.95657348633,2.99276733398,1.67177963257,1.08235817039,147.116607666,1.87888
+476390,34,1146.99999997,625,5.20587069043,199,299,100,248.08391456,12.8665327995,1138209,249.0,232,422,190,334.965126417,26.8541640109,1536820,337.0,664,1258,594,1006.21534438,95.7171586695,4616516,1013.5,162,463,301,296.885571055,38.9626856478,1362111,297.0,0.410687029362,0.683309555054,0.272622525692,0.544268326628,0.0447647752706,2497.10308257,0.546131,593,1180,587,879.934612031,76.7474265159,4037140,884.0,-0.243774414062,3.54019165039,3.78396606445,0.421282248593,0.810797970004,1932.84295654,0.0752258
+405213,32,44.2499999991,37,1.56906218022,233,282,49,256.197740113,8.6016944514,45347,256.0,330,423,93,376.288135593,14.9991158091,66603,374.0,889,1037,148,960.774011299,24.9509077824,170057,960.0,283,423,140,352.802259887,22.7347861958,62446,351.0,0.408594310284,0.52674227953,0.118147969246,0.463267460718,0.0206436729499,81.9983405471,0.462866,850,1128,278,985.288135593,44.8126233908,174396,982.0,-0.0742492675781,0.283020019531,0.357269287109,0.0299937792417,0.0746707259751,5.30889892578,0.0
+404346,21,77.2500000019,121,3.88357050688,292,397,105,346.653721683,20.2604360595,107116,347.0,408,606,198,521.731391586,34.4117794943,161215,524.0,838,1191,353,996.122977346,66.5939083597,307802,989.0,458,858,400,710.045307443,60.370414476,219404,708.0,0.109101869166,0.318452388048,0.209350518882,0.168268227148,0.027856537485,51.9948821887,0.16712,1159,1859,700,1578.43042071,111.379809603,487735,1580.0,-0.013427734375,1.31350708008,1.32693481445,0.184760825148,0.190500878178,57.0910949707,0.135468
+393324,34,1315.25,504,3.92031937729,196,299,103,240.568333017,10.3865114768,1265630,241.0,249,425,176,339.457897738,25.5853425935,1785888,336.0,632,1196,564,922.68656149,99.0724921643,4854254,923.0,154,398,244,282.227143129,31.2313036684,1484797,281.0,0.386281579733,0.716651320457,0.330369740725,0.530148366562,0.0451418200816,2789.11055648,0.527301,608,1121,513,862.253373883,64.64946384,4536315,860.0,-0.241455078125,2.27975463867,2.5212097168,0.6243295762,0.62925139602,3284.59790039,0.426819
+388146,34,1363.24999999,881,6.73105630184,202,295,93,243.304969741,8.04514398289,1326742,243.0,253,404,151,327.059416835,14.5769409919,1783455,326.0,634,1154,520,897.130203558,68.4546423745,4892051,889.0,160,447,287,283.747111682,26.9489953923,1547273,281.0,0.323239982128,0.70287835598,0.379638373852,0.518318309153,0.0488846398923,2826.38973981,0.520887,620,1137,517,854.111498258,47.9073281112,4657470,850.0,-0.125946044922,3.89199829102,4.01794433594,0.518997810793,0.727704128212,2830.09506226,0.167542
+397466,41,2413.24999995,1232,7.07464444932,277,314,37,303.610898166,2.79753879326,2930756,304.0,431,491,60,472.611105356,5.24185683112,4562115,473.0,364,472,108,416.84408992,6.97741955493,4023796,417.0,469,581,112,549.561587071,8.76878567685,5304918,550.0,-0.201284796,-0.0574971809983,0.143787615001,-0.137326980475,0.00841561662668,-1325.61734252,-0.138178,1184,1382,198,1325.78359059,15.6757551251,12797789,1326.0,0.0,0.0,0.0,0.0,0.0,0.0,0.0
+377033,34,923.250000001,879,8.16064122459,213,286,73,252.317627945,9.53614729215,931809,253.0,267,419,152,352.526942865,23.3612569513,1301882,351.0,568,949,381,781.451665313,57.9121920978,2885901,786.0,189,383,194,296.960736529,25.2753121542,1096676,298.0,0.354166656733,0.548463344574,0.194296687841,0.449234654538,0.0270115501234,1659.02357921,0.450617,671,1068,397,901.805307338,56.0474321772,3330367,903.0,-0.183135986328,9.76950073242,9.95263671875,2.34725172888,3.22306636885,8668.40063477,0.254272
+370226,32,727.749999995,609,6.36826685264,209,354,145,286.944692546,19.7296228994,835296,287.0,280,541,261,416.335623497,34.398103252,1211953,416.0,696,1094,398,904.052559258,59.2254336864,2631697,905.0,286,715,429,485.989694263,60.8284771979,1414716,484.0,0.192090392113,0.448453605175,0.256363213062,0.30286867911,0.0383277869306,881.650724888,0.300401,838,1584,746,1189.27001031,110.554182801,3461965,1186.0,-0.110961914062,0.378082275391,0.489044189453,0.0147252398969,0.0549055297085,42.8651733398,0.0
+361293,12,6.75000000023,12,1.30294003172,210,279,69,255.185185185,18.1965341369,6890,260.0,290,400,110,362.222222222,28.8062921796,9780,370.0,682,1011,329,872.222222222,91.8829099224,23550,910.0,257,424,167,352.296296296,38.5571387585,9512,360.0,0.36437907815,0.475862056017,0.111482977867,0.424158906495,0.0356362192743,11.4522904754,0.415584,757,1094,337,969.703703704,83.9950681157,26182,979.0,0.209350585938,0.377136230469,0.167785644531,0.353620741102,0.0325775993091,9.54776000977,0.363953
+354115,31,252.500000002,111,1.97054953074,194,327,133,258.581188119,14.0620915368,261167,258.0,274,497,223,354.336633663,25.2296687003,357880,353.0,603,1064,461,918.918811881,68.4961612177,928108,929.5,203,448,245,331.124752475,39.1430516979,334436,327.0,0.332203388214,0.607878267765,0.275674879551,0.469966704657,0.0559206512691,474.666371703,0.482196,702,1222,520,944.042574257,76.0072766794,953483,938.0,-0.053955078125,2.30133056641,2.35528564453,0.936341510433,0.556115323029,945.704925537,1.15182
+358850,31,79.9999999977,49,1.54541866976,199,271,72,244.953125,12.9990741107,78385,248.0,244,372,128,325.74375,22.3241032505,104238,330.0,587,1155,568,952.334375,97.6959444827,304747,975.0,151,360,209,279.18125,35.6057179177,89338,285.0,0.431778937578,0.664444446564,0.232665508986,0.546067064349,0.0464833609673,174.741460592,0.55113,594,1000,406,849.878125,69.536866276,271961,863.0,-0.0953063964844,0.846557617188,0.941864013672,0.497451114655,0.167256254118,159.184356689,0.507446
+339004,31,52.0000000012,37,1.44742183623,198,264,66,241.408653846,13.6832759417,50213,245.0,248,363,115,323.932692308,23.8888710906,67378,329.5,620,1070,450,905.067307692,84.2823510614,188254,927.0,157,341,184,275.721153846,34.6261508364,57350,280.5,0.428301900625,0.657205224037,0.228903323412,0.533473531357,0.0339019079985,110.962494522,0.533353,609,954,345,841.0625,70.8489789942,174941,855.0,-0.0147399902344,1.46536254883,1.48010253906,0.661910423866,0.220476217917,137.677368164,0.665909
+330098,11,7.74999999977,13,1.31730872721,322,404,82,378.774193548,18.6438776207,11742,386.0,520,642,122,591.258064516,25.8081854256,18329,597.0,687,874,187,771.225806452,34.8921931165,23908,767.0,609,777,168,718.516129032,36.4292252118,22274,725.0,0.00741739710793,0.095238097012,0.0878206999041,0.0355212893187,0.0223836440673,1.10115996888,0.033356,1487,1809,322,1688.5483871,69.6525194457,52345,1702.0,-0.0476379394531,0.0316467285156,0.0792846679688,-0.000551285282258,0.0141009661241,-0.01708984375,0.0
+331742,22,1029.74999997,727,6.39092290414,234,445,211,341.955571741,21.0534232409,1408515,343.0,319,660,341,518.518329692,37.1172638548,2135777,520.0,649,1147,498,953.491381403,65.7306137348,3927431,947.0,438,832,394,631.473901432,56.327293623,2601041,632.0,0.0913043469191,0.33044731617,0.239142969251,0.203760468115,0.0291253904342,839.289368168,0.197001,1045,1901,856,1491.94780286,105.758018053,6145333,1496.0,-0.189880371094,1.43005371094,1.61993408203,0.0596438095563,0.151399192486,245.672851562,0.0
+323970,12,4.0,12,1.69256875064,207,302,95,263.5,28.4363323936,4216,267.5,275,449,174,375625,51.7589062384,6010,384.5,506,803,297,670.5625,84.030477172,10729,685.5,252,572,320,433875,94.0743555652,6942,449.5,0.167999997735,0.335092335939,0.167092338204,0.222202926874,0.0498390282375,3.55524682999,0.20835,734,1323,589,1073.0,174.129980187,17168,1101.5,0.184753417969,1.16067504883,0.975921630859,0.54137802124,0.419813067993,8.66204833984,0.239624
+304007,34,804.749999998,553,5.49907580657,212,316,104,260.641192917,12.2448178085,839004,259.0,271,474,203,363.772600186,24.0104276258,1170984,363.0,683,1147,464,910.370922647,53.334324854,2930484,912.0,209,508,299,345.342342342,40.171551738,1111657,343.0,0.292988926172,0.574506282806,0.281517356634,0.450917394108,0.0428389936879,1451.50309163,0.451046,698,1298,600,969.756135446,74.9079824175,3121645,965.0,-0.161743164062,3.35299682617,3.51473999023,0.251491322655,0.546562908255,809.550567627,0.0
+302940,32,693.249999992,420,4.49986432153,249,360,111,283.5943022,13.2681108658,786407,282.0,341,534,193,409.291381176,24.0257897558,1134965,405.0,751,1255,504,909.989902633,56.4741713468,2523402,908.0,325,626,301,432.27082582,40.5270168502,1198687,427.0,0.263723164797,0.479119211435,0.215396046638,0.35656581035,0.0291557106058,988.756992102,0.356725,921,1520,599,1125.1565092,76.6850567937,3120059,1114.0,-0.112548828125,1.72869873047,1.84124755859,0.075329642669,0.15081614213,208.889099121,0.0
+293150,12,8.75000000023,18,1.71657801721,204,277,73,250.542857143,18.888156315,8769,256.0,263,377,114,335.028571429,29.4923580555,11726,343.0,574,843,269,718.542857143,79.3841808125,25149,745.0,205,409,204,332.171428571,47.2243797293,11626,341.0,0.27552986145,0.482976049185,0.207446187735,0.368857984883,0.0494390745672,12.9100294709,0.375808,672,1063,391,917.742857143,93.777957464,32121,946.0,0.132293701172,1.23434448242,1.10205078125,0.26936819894,0.200299192711,9.42788696289,0.149048
+271895,31,336.999999994,187,2.87356962355,199,267,68,240.466617211,8.470996852,324149,242.0,248,375,127,328.06305638,16.6751036061,442229,330.0,840,1195,355,1068.7351632,46.7470500288,1440655,1070.0,155,336,181,266.459198813,22.8781891768,359187,270.0,0.525227487087,0.725906252861,0.200678765774,0.601247182763,0.0239814932384,810.481202364,0.599138,610,975,365,834.988872404,47.0820739376,1125565,842.0,-0.150360107422,2.54809570312,2.69845581055,0.378870819726,0.603217611277,510.71786499,0.000518799
+279736,34,2898.49999999,838,4.39088875555,184,307,123,239.429446265,9.95003381593,2775945,240.0,217,433,216,326.361307573,19.6671796233,3783833,328.0,578,1228,650,983.411160945,81.8087271938,11401669,988.0,109,501,392,269.68112817,30.1063208998,3126683,270.0,0.327065140009,0.743227303028,0.416162163019,0.569049546929,0.0423124598774,6597.5604471,0.571746,511,1238,727,835.471882008,57.9034229915,9686461,838.0,-0.224212646484,6.2057800293,6.42999267578,0.634363292558,1.35686376754,7354.80801392,0.0784454
+296262,33,7336.74999993,2981,9.81759661054,196,341,145,258.693665451,11.9608379105,7591883,257.0,247,484,237,349.402255767,20.9028784905,10253908,346.0,388,978,590,718.408218898,41.3793759358,21083126,715.0,219,603,384,383.372201588,32.7245736689,11250824,380.0,0.149162858725,0.5530179739,0.403855115175,0.304594831538,0.0311469273297,8938.94452116,0.30316,681,1395,714,991.468122806,62.2411956317,29096615,984.0,-0.218017578125,1.33834838867,1.5563659668,0.0522189142107,0.120153493328,1532.46847534,0.0
+254265,11,59.7499999981,38,1.38678683381,282,562,280,512.740585774,38.7065948733,122545,525.0,368,825,457,756.343096234,58.8507034582,180766,775.0,491,1044,553,912.644351464,62.7122928389,218122,911.0,304,954,650,832.845188285,68.7457650873,199050,845.0,0.00732394354418,0.235220119357,0.227896175813,0.0465966058626,0.0239227843137,11.1365888012,0.0387244,954,2298,1344,2101.92887029,157.14808983,502361,2137.0,0.171051025391,4.36962890625,4.19857788086,3.51279605881,0.918865799323,839.558258057,3.95721
+188369,32,829.499999978,601,5.88655687983,228,348,120,283.218505124,16.7583486502,939719,284.0,303,506,203,402.061784207,30.1878204078,1334041,402.0,606,1159,553,880.338758288,57.0930715347,2920964,883.0,281,586,305,428.665762508,45.9661219517,1422313,426.0,0.221225708723,0.46823528409,0.247009575367,0.346096444257,0.0370197582457,1148.34800205,0.346327,835,1433,598,1113.94605184,89.4186052397,3696073,1111.0,-0.100036621094,1.03747558594,1.13751220703,0.108039179935,0.159566425271,358.473999023,0.0101318
+182716,11,40.999999997,38,1.674120584,281,358,77,335.670731707,13.8863460558,55050,339.0,386,541,155,488.707317073,27.1084037932,80148,496.0,493,688,195,619.634146341,31.9435524221,101620,622.0,430,658,228,567.68902439,39.218053664,93101,573.0,0.0108604840934,0.129554659128,0.118694175035,0.0443309577886,0.0195106833304,7.27027707733,0.0409776,1101,1557,456,1392.06707317,78.4525746983,228299,1408.5,-0.0270080566406,3.97634887695,4.00335693359,0.373757339105,1.13849153262,61.2962036133,0.0
+177464,31,54.0000000014,41,1.57391779202,193,256,63,235.175925926,12.1478764367,50798,237.0,230,354,124,311.49537037,21.7800447414,67283,316.0,641,1162,521,1010.74074074,76.3688503459,218320,1024.0,139,340,201,252.259259259,34.1694769496,54488,256.0,0.479326188564,0.693404614925,0.214078426361,0.601543962955,0.0354083795466,129.933495998,0.603837,562,941,379,798.930555556,65.5626629269,172569,809.5,-0.0212707519531,0.676696777344,0.697967529297,0.00804689195421,0.0670373764808,1.73812866211,0.0
+162206,34,110.000000006,146,3.92691572633,248,325,77,284.431818182,12.9165111516,125150,283.5,361,472,111,407.622727273,21.4328429332,179354,406.0,770,1104,334,930.261363636,68.8776079061,409315,933.5,344,550,206,434.002272727,37.839823831,190961,430.0,0.259899199009,0.450274080038,0.190374881029,0.363575653664,0.0382817492017,159.973287612,0.367238,957,1341,384,1126.05681818,70.2208460946,495465,1120.0,-0.0594177246094,0.741638183594,0.801055908203,0.172078288685,0.199613719385,75.7144470215,0.0822754
+130203,33,6172.00000002,2611,9.37538219481,190,343,153,251.735418017,10.1002223176,6214844,250.0,242,487,245,333.481529488,19.4980801287,8232992,331.0,537,1088,551,694.276409592,52.0466607997,17140296,684.0,204,612,408,365.788885288,33.2117863225,9030596,363.0,0.136712744832,0.543498575687,0.406785830855,0.309917536624,0.0384220954665,7651.24414417,0.302852,637,1442,805,951.005832793,60.4407147944,23478432,943.0,-0.172424316406,2.93591308594,3.10833740234,0.119870443585,0.275437856699,2959.36151123,0.0
+119246,31,70.0000000014,50,1.68583882835,185,349,164,236.510714286,23.6218700011,66223,233.5,223,416,193,300.332142857,34.5180134502,84093,297.5,637,1227,590,968.817857143,127.975021429,271269,984.0,143,394,251,260.589285714,50.8110564408,72965,257.5,0.437606841326,0.742640852928,0.305034011602,0.576422270068,0.0580438296046,161.398235619,0.572095,551,1130,579,797.432142857,97.460920936,223281,800.0,-0.0140991210938,0.823394775391,0.837493896484,0.0441264561244,0.134901845554,12.3554077148,0.0
+95477,31,959.250000006,439,3.99846854886,174,295,121,234.549126922,14.0192167675,899965,234.0,207,424,217,307.787333855,26.6469522404,1180980,307.0,516,1137,621,846.434714621,89.1959930427,3247770,842.0,125,476,351,273.418034923,44.9633142443,1049105,271.0,0.307557106018,0.732142865658,0.42458575964,0.511812968516,0.0647336202391,1963.8263602,0.515974,520,1183,663,815.7544957,81.9683519451,3130050,814.0,-0.181274414062,2.0950012207,2.27627563477,0.303169129197,0.589968811901,1163.25994873,0.0
+94286,33,12453.4999999,9276,23.4482316215,185,381,196,269.329967479,20.0771034164,13416403,268.0,238,555,317,369.065142329,34.4469108313,18384611,366.0,476,1106,630,770.803930622,60.1138325417,38396827,764.0,183,708,525,422.254928333,61.7825573056,21034207,418.0,0.107863605022,0.653266310692,0.545402705669,0.294563449073,0.0568183412802,14673.3836521,0.289637,635,1601,966,1060.65003814,111.682428481,52835221,1051.0,-0.229736328125,2.14706420898,2.37680053711,0.042989883916,0.135130269031,2141.49807739,0.0
+84704,11,25.75,25,1.38978128776,344,525,181,436.563106796,43.6296572116,44966,437.0,494,717,223,607.019417476,51.9745980866,62523,611.0,601,809,208,708.13592233,46.1475153785,72938,710.0,571,710,139,638.242718447,30.3671597079,65739,641.0,0.00159489631187,0.10830860585,0.106713709538,0.0513696620474,0.02735613611,5.29107519088,0.0493344,1412,1927,515,1681.82524272,109.046033495,173228,1682.0,0.750427246094,3.02673339844,2.27630615234,2.19235081349,0.341210729621,225.812133789,2.06546
+95338,31,10361.0,3102,8.59678419163,178,369,191,238.377835151,15.806896868,9879331,238.0,224,543,319,320.073448509,27.9303999118,13265124,320.0,544,1280,736,902.04391468,86.9360381219,37384308,904.0,142,678,536,281.267300454,47.0193620175,11656842,277.0,0.213286712766,0.723591566086,0.51030485332,0.52490667143,0.0619440822141,21754.2320907,0.530371,568,1582,1014,839.718584114,87.7047153468,34801297,836.0,-0.417236328125,3.17337036133,3.59060668945,0.249880453183,0.465924660285,10356.0455017,0.0
+64555,11,14.2500000005,17,1.27038851016,337,427,90,385.561403509,21.0854714626,21977,388.0,453,591,138,535.438596491,25.9094357559,30520,539.0,547,744,197,645.701754386,51.8516659335,36805,637.0,451,657,206,574.421052632,44.440753925,32742,575.0,0.0162810627371,0.148253068328,0.131972005591,0.0583218303754,0.0262748023447,3.3243443314,0.0546358,1247,1641,394,1495.42105263,69.1448891614,85239,1511.0,1.75534057617,2.71353149414,0.958190917969,2.24460641961,0.258520679879,127.942565918,2.26028
+28108,22,1731.50000004,772,5.23360715332,194,493,299,355.496967947,41.1110450403,2462172,364.0,273,737,464,537.121715276,75.3643535884,3720105,553.0,629,1291,662,979.790788334,87.1316344552,6786031,988.0,274,908,634,666.275050534,113.732496299,4614621,690.5,0.0760043412447,0.506584703922,0.430580362678,0.195640214344,0.0629398421608,1355.00412454,0.17374,845,2033,1188,1558.89373376,224.23149591,10796898,1607.0,-0.09375,1.0686340332,1.1623840332,0.057977273772,0.102633484951,401.550598145,0.0
+9497,31,137.999999999,82,1.96910727709,179,263,84,230.704710145,14.1091030689,127349,232.0,203,376,173,301.894927536,25.9970701316,166646,305.0,643,1271,628,976.576086957,121.540107923,539070,991.5,86,411,325,246.543478261,41.6777874258,136092,249.0,0.362790703773,0.780612230301,0.417821526527,0.596325437714,0.0602264014322,329.171641618,0.602095,468,1050,582,779.143115942,79.9245986812,430087,789.0,-0.0453186035156,2.60479736328,2.6501159668,0.783526931984,1.046392088,432.506866455,0.191238
+16763576,14,4322.5,2289,9.82139910913,223,569,346,286.65112782,8.56718963096,4956198,287.0,285,870,585,380.99329092,14.1906974754,6587374,381.0,400,1171,771,506.283053788,31.47069357,8753634,502.0,256,1252,996,417.696124928,28.5653567988,7221966,414.0,-0.033429633826,0.227586209774,0.2610158436,0.0960305027755,0.0128022555658,1660.36739299,0.0950454,765,2691,1926,1085.34054367,47.0301657246,18765538,1083.0,0.342163085938,2.72561645508,2.38345336914,1.28995471467,0.390361840931,22303.3170166,1.23785
+16416240,14,2201.74999978,1378,8.28438517986,245,435,190,296.839445895,9.1523507774,2614265,296.0,313,616,303,393.770409901,16.1646735062,3467936,392.0,378,741,363,494.194390825,24.1613346548,4352370,492.0,293,784,491,422.736800273,22.929153932,3723043,421.0,-0.0281967204064,0.159059479833,0.187256200239,0.0780222945187,0.015417216252,687.142347826,0.07828,851,1835,984,1113.34665607,43.9399042763,9805244,1108.0,-0.104217529297,1.72888183594,1.83309936523,0.691117679219,0.395428727553,6086.67340088,0.763489
+15968463,14,3823.99999965,2069,9.43836170806,195,460,265,302.795698222,11.548001503,4631563,302.0,223,668,445,402.057466004,18.9827886827,6149871,401.0,319,891,572,537.791971757,26.19799847,8226066,534.0,117,835,718,429.296286611,29.9337867945,6566516,426.0,-0.0101265823469,0.463302761316,0.473429343663,0.112751030705,0.0193558531576,1724.63976566,0.112008,535,1937,1402,1134.14945084,57.5920858243,17347950,1129.0,0.00152587890625,2.97552490234,2.97399902344,1.38127701053,0.527839483663,21128.0131531,1.36998
+14012066,14,1359.99999966,1063,8.13127929157,242,426,184,296.502941176,9.12732598217,1612976,296.0,317,604,287,399.073529412,15.4673314901,2170960,398.0,420,769,349,538.836029412,27.7755835243,2931268,533.0,304,779,475,440.985110294,26.1299629185,2398959,438.0,-0.0324718356133,0.229647636414,0.262119472027,0.100026548048,0.0145547071905,544.144421382,0.0994264,875,1809,934,1136.56158088,47.7793976537,6182895,1131.0,-0.096923828125,1.26327514648,1.36019897461,0.464184974222,0.324615769465,2525.16625977,0.469086
Added: grass-addons/grass7/raster/r.object.activelearning/examples/training_set.csv
--- grass-addons/grass7/raster/r.object.activelearning/examples/training_set.csv	                        (rev 0)
+++ grass-addons/grass7/raster/r.object.activelearning/examples/training_set.csv	2017-05-03 08:09:28 UTC (rev 71010)
@@ -0,0 +1,74 @@
+cat,Class_num,area,perimeter,compact,opt_blue_min,opt_blue_max,opt_blue_range,opt_blue_mean,opt_blue_stddev,opt_blue_sum,opt_blue_median,opt_green_min,opt_green_max,opt_green_range,opt_green_mean,opt_green_stddev,opt_green_sum,opt_green_median,opt_nir_min,opt_nir_max,opt_nir_range,opt_nir_mean,opt_nir_stddev,opt_nir_sum,opt_nir_median,opt_red_min,opt_red_max,opt_red_range,opt_red_mean,opt_red_stddev,opt_red_sum,opt_red_median,NDVI_min,NDVI_max,NDVI_range,NDVI_mean,NDVI_stddev,NDVI_sum,NDVI_median,Brightness_min,Brightness_max,Brightness_range,Brightness_mean,Brightness_stddev,Brightness_sum,Brightness_median,nDSM_min,nDSM_max,nDSM_range,nDSM_mean,nDSM_stddev,nDSM_sum,nDSM_median
+17201318.0,12.0,5.25000000093,17.0,2.09297643027,191.0,270.0,79.0,224.380952381,18.2847221953,4712.0,222.0,224.0,353.0,129.0,283.952380952,26.0904583735,5963.0,282.0,583.0,777.0,194.0,658.523809524,47.0051861856,13829.0,647.0,144.0,351.0,207.0,242.333333333,43.6886531344,5089.0,236.0,0.361237496138,0.62790697813,0.266669481993,0.465143154065,0.0627609520191,9.76800623536,0.461187,559.0,974.0,415.0,750.666666667,86.8020919944,15764.0,735.0,0.326812744141,0.364379882812,0.0375671386719,0.356802804129,0.00745807904216,7.49285888672,0.35849
+17155326.0,31.0,71.7499999991,56.0,1.86497125468,213.0,300.0,87.0,243.707317073,13.6230250155,69944.0,241.0,265.0,431.0,166.0,318.331010453,27.3499424486,91361.0,312.0,713.0,1184.0,471.0,914.344947735,82.1283700336,262417.0,910.0,175.0,434.0,259.0,254.975609756,37.963435061,73178.0,247.0,0.372832357883,0.663366317749,0.290533959866,0.564069235989,0.0499202071752,161.887870729,0.569337,653.0,1165.0,512.0,817.013937282,77.7202152693,234483.0,798.0,0.142944335938,2.62054443359,2.47760009766,1.44127407805,0.596709499011,413.6456604,1.68466
+17157734.0,31.0,969.000000006,446.0,4.04173688894,181.0,286.0,105.0,229.575077399,13.5205492084,889833.0,230.0,210.0,422.0,212.0,302.003869969,26.1020509632,1170567.0,302.0,626.0,1407.0,781.0,997.76496388,95.7471931462,3867337.0,999.0,106.0,393.0,287.0,238.949174407,37.1815303479,926167.0,240.0,0.448566615582,0.795379519463,0.346812903881,0.613666220807,0.0485641106071,2378.57027185,0.614742,500.0,1101.0,601.0,770.528121775,74.8195454373,2986567.0,772.0,-16.0390625,335.491790771,351.530853271,4.47072169065,30.3546785733,17328.5172729,0.00149536
+17149081.0,51.0,3.75,11.0,1.60240436487,197.0,251.0,54.0,220.333333333,14.1594099061,3305.0,222.0,241.0,319.0,78.0,267.0,22.4142811618,4005.0,260.0,551.0,683.0,132.0,596.466666667,34.0663405072,8947.0,589.0,140.0,280.0,140.0,191.266666667,38.8698111935,2869.0,182.0,0.418483912945,0.633986949921,0.215503036976,0.518217698733,0.0593920469031,7.773265481,0.525692,578.0,850.0,272.0,678.6,74.9931552432,10179.0,662.0,0.0,0.0,0.0,0.0,0.0,0.0,0.0
+17141973.0,51.0,6.25,12.0,1.35405500051,205.0,242.0,37.0,221.88,9.00364370686,5547.0,219.0,257.0,327.0,70.0,278.48,16.4684425493,6962.0,272.0,573.0,777.0,204.0,635.04,48.7495476902,15876.0,620.0,165.0,280.0,115.0,202.4,27.2161716632,5060.0,192.0,0.409523814917,0.571428596973,0.161904782057,0.517778067589,0.0366377344448,12.9444516897,0.521912,627.0,849.0,222.0,702.76,52.0686316317,17569.0,683.0,0.0687255859375,0.345153808594,0.276428222656,0.178736572266,0.0705368081068,4.46841430664,0.197968
+17120487.0,33.0,615.499999994,254.0,2.88811682108,238.0,330.0,92.0,282.692120227,12.7475428437,695988.0,282.0,315.0,492.0,177.0,392.613322502,23.0108218371,966614.0,390.0,656.0,995.0,339.0,787.275385865,49.3841080233,1938272.0,781.0,294.0,577.0,283.0,421.04752234,38.9476175527,1036619.0,419.0,0.184764996171,0.435314685106,0.250549688935,0.3036496329,0.0385391719862,747.5853962,0.301669,847.0,1399.0,552.0,1096.35296507,72.2540767976,2699221.0,1091.0,-0.116455078125,1.36450195312,1.48095703125,0.151059148372,0.181624136018,371.907623291,0.100632
+17109605.0,33.0,3220.75,1092.0,5.42799199648,224.0,332.0,108.0,251.376697974,11.2453079031,3238486.0,249.0,292.0,469.0,177.0,340.92385314,19.7364500998,4392122.0,337.0,626.0,1082.0,456.0,778.033687806,48.7326181588,10023408.0,771.0,260.0,563.0,303.0,342.516805092,32.0605084505,4412644.0,338.0,0.259210526943,0.519298255444,0.2600877285,0.389231791158,0.0297151254517,5014.47316548,0.389513,784.0,1364.0,580.0,934.817356206,61.6120508202,12043252.0,924.0,-0.220336914062,1.53695678711,1.75729370117,0.087391636659,0.190412119833,1125.86645508,0.0
+16976403.0,32.0,552.250000021,484.0,5.80995230706,230.0,377.0,147.0,274.391127207,16.6975066936,606130.0,273.0,318.0,555.0,237.0,390.437301947,29.1139840635,862476.0,389.0,732.0,1318.0,586.0,954.208691716,70.6596827189,2107847.0,957.0,283.0,639.0,356.0,405.065187868,47.5631176891,894789.0,399.0,0.229729726911,0.544172227383,0.314442500472,0.404813745386,0.0419028548697,894.233563557,0.405318,843.0,1571.0,728.0,1069.89361702,90.5184303781,2363395.0,1061.0,-0.314086914062,1.77087402344,2.0849609375,0.0845640846484,0.219339264685,186.802062988,0.0
+16963689.0,31.0,179.499999998,94.0,1.97920461584,197.0,281.0,84.0,240.378830084,13.3146493043,172592.0,242.0,244.0,387.0,143.0,324.536211699,25.148931278,233017.0,327.0,686.0,1314.0,628.0,996.895543175,100.90232988,715771.0,1004.0,140.0,380.0,240.0,262.179665738,40.089034322,188245.0,263.0,0.417624533176,0.718377113342,0.300752580166,0.584055868821,0.0450137330367,419.352113813,0.586408,581.0,1028.0,447.0,827.094707521,76.7942078673,593854.0,833.5,-0.0523681640625,1.6501159668,1.70248413086,0.442823872261,0.358377586283,317.947540283,0.658157
+16953778.0,32.0,6.25000000023,16.0,1.80540666732,253.0,297.0,44.0,278.52,11.3388535576,6963.0,280.0,366.0,443.0,77.0,411.48,19.8577340097,10287.0,415.0,889.0,1002.0,113.0,949.44,28.5153712934,23736.0,951.0,329.0,450.0,121.0,404.28,32.3709993667,10107.0,406.0,0.374100714922,0.45977011323,0.0856693983078,0.403644894361,0.0235590917238,10.091122359,0.399278,948.0,1190.0,242.0,1094.28,63.1389071809,27357.0,1100.0,-0.0156555175781,0.162811279297,0.178466796875,0.0453735351562,0.0551593978999,1.13433837891,0.0339966
+16922893.0,11.0,13.7500000002,17.0,1.29328023473,461.0,528.0,67.0,500.254545455,17.8399125373,27514.0,500.0,612.0,707.0,95.0,660.290909091,22.2012880276,36316.0,661.0,549.0,800.0,251.0,658.563636364,60.1473232644,36221.0,645.0,576.0,731.0,155.0,636.8,31.3979732988,35024.0,633.0,-0.0445544570684,0.0954415947199,0.139996051788,0.0153418299742,0.0326520089664,0.843800648581,0.0192878,1673.0,1947.0,274.0,1797.34545455,60.8067634342,98854.0,1803.0,0.260772705078,2.19409179688,1.9333190918,0.920502818714,0.609181486038,50.6276550293,1.02728
+16973659.0,22.0,15618.25,10546.0,23.8049158096,247.0,467.0,220.0,375.622204792,18.3199978516,23466246.0,375.0,377.0,765.0,388.0,600.761112801,31.8156668922,37531349.0,600.0,729.0,1312.0,583.0,1039.93619644,48.8202341479,64967934.0,1040.0,419.0,1047.0,628.0,806.409504906,45.3686035952,50378821.0,808.0,0.0262172278017,0.297002732754,0.270785504952,0.126702131274,0.0155267562805,7915.46224705,0.124746,1056.0,2244.0,1188.0,1782.7928225,90.0522411463,111376416.0,1783.0,-0.173858642578,3.05505371094,3.22891235352,0.770785812967,0.572677508439,48153.3020935,0.670898
+16910321.0,32.0,1383.24999998,571.0,4.33092673333,217.0,414.0,197.0,304.961865173,25.2145356738,1687354.0,306.0,296.0,631.0,335.0,460.008313754,43.7870518895,2545226.0,462.0,647.0,1261.0,614.0,1043.68353515,68.3747301106,5774701.0,1044.0,294.0,714.0,420.0,499.970721128,69.7512417328,2766338.0,503.0,0.223570197821,0.516535460949,0.292965263128,0.354760992218,0.0478912530992,1962.89256994,0.35,859.0,1695.0,836.0,1264.94090005,135.458433141,6998918.0,1271.0,-0.120391845703,0.449859619141,0.570251464844,0.0216957311529,0.0582688644826,120.042480469,0.0
+16912689.0,11.0,77.25,54.0,1.73316369731,218.0,360.0,142.0,302.242718447,28.8993788422,93393.0,313.0,241.0,490.0,249.0,412.896440129,50.0181418894,127585.0,433.0,247.0,857.0,610.0,580.317152104,90.5591926626,179318.0,602.0,65.0,506.0,441.0,331.084142395,61.0648711323,102305.0,331.0,0.0810810774565,0.583333313465,0.502252236009,0.275728919311,0.0632082955107,85.2002360672,0.283213,525.0,1318.0,793.0,1046.22330097,125.563011583,323283.0,1074.0,2.35305786133,5.81207275391,3.45901489258,4.13509983692,0.572526470082,1277.74584961,4.06021
+16909519.0,33.0,3334.50000003,1487.0,7.26424821974,200.0,308.0,108.0,249.886489729,11.4847331804,3332986.0,249.0,230.0,425.0,195.0,327.84322987,21.3709554844,4372773.0,327.0,477.0,1053.0,576.0,675.96191333,47.1485313079,9015980.0,677.0,165.0,486.0,321.0,334.842780027,37.8890616785,4466133.0,334.0,0.152691975236,0.545012176037,0.392320200801,0.338391791295,0.0484195736651,4513.46971229,0.334036,605.0,1208.0,603.0,912.572499625,68.7750251039,12171892.0,909.0,-0.542999267578,2.48983764648,3.03283691406,0.698451811092,0.386268498232,9315.95025635,0.709549
+16911105.0,32.0,2543.75000003,1008.0,5.63791321974,228.0,367.0,139.0,292.989090909,20.588018722,2981164.0,292.0,311.0,575.0,264.0,436.229189189,36.9578224717,4438632.0,434.0,756.0,1317.0,561.0,1083.76874693,66.6631481261,11027347.0,1085.0,276.0,745.0,469.0,466.954496314,65.6993643788,4751262.0,464.0,0.191535532475,0.568047344685,0.37651181221,0.399912481822,0.0501360911377,4069.10950254,0.399015,822.0,1679.0,857.0,1196.17277641,120.64658492,12171058.0,1189.0,-0.118804931641,1.12564086914,1.24444580078,0.0363418136709,0.0941741876354,369.777954102,0.0
+16828863.0,22.0,969.249999991,863.0,7.81966159503,306.0,514.0,208.0,437.158885736,20.7247341532,1694865.0,438.0,453.0,802.0,349.0,696.348465308,34.2456051352,2699743.0,698.0,774.0,1360.0,586.0,1166.17539335,59.964146997,4521262.0,1167.0,495.0,1068.0,573.0,891.363425329,52.5806820345,3455816.0,896.0,0.0818345323205,0.276543200016,0.194708667696,0.133748364431,0.0193069385982,518.542408898,0.13052,1254.0,2347.0,1093.0,2024.87077637,101.870646634,7850424.0,2033.0,-0.186248779297,1.130859375,1.3171081543,0.0645651670962,0.14240066558,250.319152832,0.0
+16909220.0,33.0,708.750000012,348.0,3.68746388884,247.0,320.0,73.0,286.907936508,8.93640023618,813384.0,286.0,299.0,462.0,163.0,399.997178131,15.9760400122,1133992.0,399.0,438.0,809.0,371.0,670.133333333,40.1292251233,1899828.0,667.0,304.0,576.0,272.0,474.778483245,26.7266579659,1345997.0,473.0,0.108800001442,0.317789286375,0.208989284933,0.17040373853,0.0270361927733,483.094598733,0.16726,850.0,1352.0,502.0,1161.68359788,50.0128490979,3293373.0,1159.0,-0.148010253906,1.00650024414,1.15451049805,0.0803598340016,0.146522306327,227.820129395,0.0
+16888980.0,12.0,3.25,10.0,1.56478036351,185.0,241.0,56.0,210.153846154,16.6726222101,2732.0,211.0,214.0,312.0,98.0,260.153846154,29.9996055201,3382.0,266.0,460.0,715.0,255.0,556.076923077,63.5978489458,7229.0,542.0,145.0,311.0,166.0,222.615384615,48.4744793467,2894.0,224.0,0.35897436738,0.534246563911,0.175272196531,0.43418019093,0.0572888520707,5.64434248209,0.415144,546.0,864.0,318.0,692.923076923,94.873568937,9008.0,701.0,0.613983154297,0.683135986328,0.0691528320312,0.647568922776,0.0190350390573,8.41839599609,0.645691
+16891856.0,32.0,2030.25,1565.0,9.79793717241,226.0,402.0,176.0,296.75076961,20.2488628314,2409913.0,296.0,278.0,572.0,294.0,431.539465583,35.9686026551,3504532.0,431.0,646.0,1210.0,564.0,942.322374092,71.850281838,7652600.0,943.0,292.0,717.0,425.0,480.427410417,54.7764433293,3901551.0,478.0,0.209979206324,0.476078420877,0.266099214554,0.325752722123,0.0372316717432,2645.43785636,0.324723,803.0,1645.0,842.0,1208.71764561,107.241629477,9815996.0,1206.0,-0.169555664062,2.54284667969,2.71240234375,0.114497146823,0.322215859912,929.831329346,0.0
+16880032.0,34.0,1132.00000001,706.0,5.9193845635,199.0,314.0,115.0,253.590768551,12.9383108742,1148259.0,254.0,249.0,457.0,208.0,351.767667845,26.8016928399,1592804.0,354.0,619.0,1263.0,644.0,978.83635159,71.88889478,4432171.0,980.0,147.0,490.0,343.0,306.538869258,40.4630146717,1388008.0,307.0,0.312046438456,0.69085174799,0.378805309534,0.52396011985,0.0432464200001,2372.49142268,0.523361,595.0,1261.0,666.0,911.897305654,78.3363501575,4129071.0,914.0,-0.185272216797,2.53204345703,2.71731567383,0.285242687266,0.292903368321,1291.57888794,0.207642
+16851176.0,22.0,2705.50000001,998.0,5.41254898851,259.0,454.0,195.0,389.464424321,21.9519472426,4214784.0,392.0,366.0,722.0,356.0,594.947976344,42.0935802505,6438527.0,598.0,674.0,1362.0,688.0,979.04999076,74.6676031897,10595279.0,979.0,343.0,943.0,600.0,729.265939752,66.3377965792,7892116.0,731.0,0.078651688993,0.378623187542,0.299971498549,0.146804982028,0.0234836957547,1588.72351551,0.141789,968.0,2112.0,1144.0,1713.67834042,127.153619673,18545427.0,1720.0,-0.0818786621094,2.5905456543,2.67242431641,1.48992413458,0.41563025495,16123.9589844,1.52429
+16862796.0,21.0,2795.99999996,1688.0,9.00531537299,230.0,438.0,208.0,340.279059371,23.8366821426,3805681.0,338.0,309.0,683.0,374.0,519.691613019,44.7046072688,5812231.0,515.0,550.0,1189.0,639.0,938.506795422,83.9251901591,10496260.0,945.0,332.0,943.0,611.0,700.709942775,69.9183799231,7836740.0,703.0,0.0326004549861,0.339636355639,0.307035900652,0.14542214955,0.0287220390763,1626.40132057,0.139805,897.0,2046.0,1149.0,1560.68061516,133.352185438,17454652.0,1557.0,-0.157836914062,1.64819335938,1.80603027344,0.0555906555001,0.147409259718,621.725891113,0.0
+16865682.0,34.0,1404.99999998,609.0,4.58325687437,182.0,273.0,91.0,234.470284698,8.70390796125,1317723.0,234.0,212.0,413.0,201.0,333.97455516,20.7901879462,1876937.0,333.0,640.0,1266.0,626.0,990.392882562,91.4526796676,5566008.0,974.0,93.0,361.0,268.0,257.508718861,26.0295840886,1447199.0,258.0,0.451012134552,0.804210543633,0.353198409081,0.586283295832,0.0387405574802,3294.91212258,0.586619,487.0,1035.0,548.0,825.953558719,52.8102877373,4641859.0,826.0,-0.156280517578,4.09967041016,4.25595092773,0.370327318945,0.466331231142,2081.23953247,0.288177
+16832957.0,11.0,30.7499999998,27.0,1.37352406234,241.0,433.0,192.0,372.203252033,37.1352087548,45781.0,377.0,288.0,601.0,313.0,448.674796748,41.1168266022,55187.0,454.0,470.0,800.0,330.0,605.81300813,55.70163688,74515.0,595.0,218.0,607.0,389.0,339.479674797,45.9829147475,41756.0,335.0,0.110047847033,0.366279065609,0.256231218576,0.283153634609,0.0432111891869,34.8278970569,0.290323,803.0,1616.0,813.0,1160.35772358,95.8301453056,142724.0,1166.0,0.134338378906,4.20574951172,4.07141113281,0.618104764116,0.40145863878,76.0268859863,0.623108
+16820446.0,34.0,54.7499999984,49.0,1.86809555155,162.0,253.0,91.0,225.96347032,13.9816755097,49486.0,227.0,211.0,370.0,159.0,302.589041096,30.1615902057,66267.0,301.0,850.0,1371.0,521.0,1131.64840183,106.626217936,247831.0,1139.0,62.0,304.0,242.0,226.324200913,35.7909953814,49565.0,228.0,0.591982841492,0.870833337307,0.278850495815,0.667243232466,0.040882945186,146.12626791,0.661859,435.0,927.0,492.0,754.876712329,77.660767739,165318.0,758.0,-0.105133056641,0.537445068359,0.642578125,0.0797198569938,0.140685515725,17.4586486816,0.0
+16818541.0,12.0,10.5,16.0,1.39290148408,277.0,385.0,108.0,319.047619048,21.2254927375,13400.0,319.5,388.0,590.0,202.0,451.238095238,39.2869841065,18952.0,448.5,634.0,947.0,313.0,756.071428571,69.0039311707,31755.0,749.0,411.0,764.0,353.0,561.452380952,66.1456554312,23581.0,571.5,0.0920152068138,0.224528297782,0.132513090968,0.148900636782,0.0316766498444,6.25382674485,0.15315,1077.0,1739.0,662.0,1331.73809524,125.341639705,55933.0,1341.5,1.55465698242,2.72357177734,1.16891479492,2.0122033982,0.341187753484,84.5125427246,1.90965
+16822678.0,22.0,2912.25000005,1865.0,9.74898892805,195.0,464.0,269.0,326.42175294,21.6884085551,3802487.0,326.0,231.0,680.0,449.0,478.752682634,35.9007087328,5576990.0,479.0,360.0,1119.0,759.0,820.674049275,69.3112377246,9560032.0,820.0,150.0,927.0,777.0,614.581337454,59.6559045998,7159258.0,617.0,0.0469798669219,0.445008456707,0.398028589785,0.144119057397,0.0329900300087,1678.84289962,0.1375,576.0,2037.0,1461.0,1419.75577303,108.17032944,16538735.0,1424.0,-0.187530517578,8.53228759766,8.71981811523,0.131173814251,0.58386647537,1528.04376221,0.0
+16793340.0,12.0,80.7500000065,83.0,2.60556489822,193.0,392.0,199.0,279.900928793,31.1114460198,90408.0,281.0,249.0,568.0,319.0,393.777089783,51.9409628687,127190.0,392.0,532.0,1135.0,603.0,881.154798762,94.7950740719,284613.0,898.0,177.0,726.0,549.0,442.334365325,85.065043199,142874.0,439.0,0.140319719911,0.558665215969,0.418345496058,0.335492358765,0.0717103360426,108.364031881,0.326069,624.0,1667.0,1043.0,1116.0123839,158.11027964,360472.0,1105.0,-0.0703735351562,1.6755065918,1.74588012695,0.207947627679,0.318211179945,67.1670837402,0.127655
+16803586.0,31.0,543.249999996,317.0,3.83667014561,192.0,293.0,101.0,232.766682006,11.6268234031,505802.0,233.0,220.0,416.0,196.0,302.679245283,22.0007052763,657722.0,304.0,500.0,1032.0,532.0,762.993097101,88.1310128391,1657984.0,749.0,141.0,424.0,283.0,264.674183157,37.2848596013,575137.0,266.0,0.311601161957,0.675373136997,0.36377197504,0.483481626411,0.0652639435532,1050.60557419,0.478178,565.0,1131.0,566.0,800.120110446,68.7021009183,1738661.0,805.0,-0.0648803710938,1.37704467773,1.44192504883,0.320480845241,0.29862837811,696.404876709,0.254181
+16758859.0,11.0,245.749999993,93.0,1.67352133475,374.0,765.0,391.0,657.530010173,59.6862163304,646352.0,676.0,636.0,1301.0,665.0,1024.91658189,84.361193364,1007493.0,1051.0,772.0,1481.0,709.0,1214.4231943,65.3669814949,1193778.0,1222.0,680.0,1535.0,855.0,1163.25737538,73.2185782951,1143482.0,1170.0,-0.0290456432849,0.0711649954319,0.100210638717,0.0218024174455,0.0120908616918,21.4317763489,0.0231596,1755.0,3240.0,1485.0,2845.70396745,188.21856101,2797327.0,2898.0,-0.0805053710938,6.10388183594,6.18438720703,4.75520453545,1.01808339508,4674.36605835,4.92715
+16751777.0,31.0,20.2499999998,21.0,1.31644236162,227.0,261.0,34.0,245.555555556,8.04002334006,19890.0,247.0,288.0,366.0,78.0,327.259259259,17.8524665639,26508.0,327.0,911.0,1148.0,237.0,1045.82716049,46.8980481111,84712.0,1048.0,207.0,323.0,116.0,264.197530864,25.3169634016,21400.0,264.0,0.528124988079,0.660714268684,0.132589280605,0.597060367649,0.0286969046141,48.3618897796,0.599413,723.0,939.0,216.0,837.012345679,48.370609847,67798.0,842.0,-0.000823974609375,0.356414794922,0.357238769531,0.110636769989,0.136153968504,8.96157836914,0.014801
+16762897.0,21.0,5154.25000001,1313.0,5.15913692441,200.0,435.0,235.0,297.456807489,16.0066554207,6132667.0,296.0,274.0,697.0,423.0,436.209099287,28.9281494663,8993323.0,432.0,477.0,1183.0,706.0,767.436144929,64.5373106841,15822231.0,755.0,278.0,997.0,719.0,615.358248048,54.8969685743,12686841.0,608.0,0.029247911647,0.357865691185,0.328617779538,0.110156742498,0.0247111126147,2271.10156007,0.104408,795.0,2103.0,1308.0,1349.02415482,92.4412168336,27812831.0,1336.0,-0.133605957031,2.60235595703,2.73596191406,0.157660647184,0.326643981678,3250.48956299,0.0
+16765227.0,32.0,3518.24999995,2132.0,10.1395555807,213.0,369.0,156.0,276.213245221,16.0752048635,3887149.0,274.0,279.0,548.0,269.0,381.529737796,31.0596323329,5369268.0,375.0,605.0,1145.0,540.0,798.328430328,72.8454062238,11234876.0,786.0,242.0,664.0,422.0,414.432743551,45.2792535301,5832312.0,407.0,0.157639443874,0.497335702181,0.339696258307,0.316677116937,0.0425325354849,4456.59706666,0.3163,734.0,1571.0,837.0,1072.17572657,89.8104260597,15088729.0,1056.0,-0.198486328125,2.0783996582,2.27688598633,0.338062597288,0.331473993198,4757.55493164,0.27063
+16785797.0,21.0,18368.7499999,7060.0,14.6946743925,218.0,372.0,154.0,298.350064648,14.2537978021,21921271.0,298.0,301.0,558.0,257.0,440.036502212,26.5347371884,32331682.0,440.0,591.0,1035.0,444.0,803.399033685,43.8888781678,59029744.0,802.0,303.0,747.0,444.0,564.08954066,44.5819323138,41446479.0,566.0,0.0962223783135,0.337435901165,0.241213522851,0.175709974295,0.025633024544,12910.2903613,0.170153,833.0,1662.0,829.0,1302.47610752,81.4769354352,95699432.0,1304.0,-0.238311767578,1.66821289062,1.9065246582,0.180206887374,0.198520700383,13240.7010498,0.130249
+16722737.0,12.0,8.0,27.0,2.69286039271,186.0,278.0,92.0,226.875,25.1827694069,7260.0,229.5,225.0,400.0,175.0,300.71875,45.4417445576,9623.0,300.5,463.0,703.0,240.0,562.71875,63.0724951816,18007.0,556.0,218.0,498.0,280.0,333.75,78.6062179474,10680.0,335.5,0.163701072335,0.374316930771,0.210615858436,0.264455392491,0.0634805411796,8.46257255971,0.248818,629.0,1176.0,547.0,861.34375,148.307031478,27563.0,868.5,1.09527587891,1.9794921875,0.884216308594,1.34329509735,0.259891265448,42.9854431152,1.25325
+16741136.0,51.0,4726.74999998,3096.0,12.7032458603,189.0,322.0,133.0,251.723858888,13.7914317433,4759343.0,252.0,222.0,460.0,238.0,341.822235151,25.0524636295,6462833.0,341.0,502.0,1154.0,652.0,837.44930449,73.1119387717,15833654.0,840.0,148.0,548.0,400.0,335.303432591,44.0597510216,6339582.0,334.0,0.271276593208,0.63983052969,0.368553936481,0.428891291466,0.0503561764648,8109.04764774,0.428821,559.0,1317.0,758.0,928.84952663,80.5022437574,17561758.0,927.0,-0.343780517578,2.908203125,3.25198364258,0.089984175731,0.255176889267,1701.33081055,0.0
+16692079.0,11.0,8.25,14.0,1.37497920306,308.0,425.0,117.0,382.454545455,31.7223665565,12621.0,381.0,424.0,571.0,147.0,518.181818182,40.0132209556,17100.0,528.0,590.0,750.0,160.0,661.151515152,43.8379392986,21818.0,660.0,436.0,601.0,165.0,547.151515152,42.335686796,18056.0,553.0,0.0457831323147,0.176581680775,0.13079854846,0.0947320930886,0.0315638608748,3.12615907192,0.0950226,1180.0,1578.0,398.0,1447.78787879,107.861796415,47777.0,1487.0,-0.0844116210938,0.321228027344,0.405639648438,0.225408380682,0.0917382072665,7.4384765625,0.252228
+16691240.0,33.0,1201.74999999,638.0,5.19168914907,222.0,290.0,68.0,242.233825671,5.68446325684,1164418.0,242.0,275.0,408.0,133.0,308.006656959,11.3291230884,1480588.0,307.0,470.0,767.0,297.0,578.851674641,27.7111810959,2782540.0,574.0,219.0,425.0,206.0,322.717495319,18.3316212474,1551303.0,322.0,0.199602782726,0.421520233154,0.221917450428,0.284127422314,0.0255815698843,1365.80051906,0.282424,717.0,1123.0,406.0,872.957977949,32.6608659382,4196309.0,871.0,-0.273986816406,2.09750366211,2.37149047852,0.684763753441,0.40680673009,3291.65936279,0.714569
+16662186.0,34.0,6.5,22.0,2.43422697343,241.0,296.0,55.0,266.884615385,12.3267280676,6939.0,265.0,333.0,418.0,85.0,376.615384615,18.7679696928,9792.0,374.0,788.0,976.0,188.0,859.884615385,48.2384517253,22357.0,842.5,309.0,441.0,132.0,378.192307692,31.0359831248,9833.0,380.5,0.340983599424,0.452127665281,0.111144065857,0.389474867628,0.0283666680267,10.1263465583,0.385577,883.0,1155.0,272.0,1021.69230769,61.122681948,26564.0,1018.0,0.223297119141,0.533935546875,0.310638427734,0.381958007812,0.0868071233677,9.93090820312,0.406479
+16679577.0,33.0,1653.24999999,819.0,5.68211087771,204.0,289.0,85.0,233.107969152,6.98269566253,1541543.0,232.0,237.0,381.0,144.0,295.940420384,13.5705031305,1957054.0,294.0,536.0,846.0,310.0,647.122788447,40.3472607626,4279423.0,642.0,163.0,388.0,225.0,262.191441101,18.5460614231,1733872.0,260.0,0.314866125584,0.557065188885,0.242199063301,0.423183354234,0.0256052588457,2798.51152155,0.422908,614.0,1056.0,442.0,791.239830637,37.7999214081,5232469.0,786.0,-0.0722961425781,2.13735961914,2.20965576172,0.633429912185,0.382958346255,4188.87200928,0.576538
+16647578.0,34.0,291.249999998,128.0,2.11578761505,191.0,400.0,209.0,247.968240343,13.3512412788,288883.0,247.0,234.0,548.0,314.0,328.943347639,18.7644138805,383219.0,330.0,741.0,1332.0,591.0,963.17167382,60.8153870384,1122095.0,968.0,135.0,642.0,507.0,289.788841202,32.1674008595,337604.0,290.0,0.349544078112,0.691780805588,0.342236727476,0.537560406187,0.0408656279333,626.257873207,0.541762,560.0,1590.0,1030.0,866.700429185,61.5348636293,1009706.0,866.0,-0.193786621094,1.07962036133,1.27340698242,0.168324063674,0.280617884972,196.09753418,0.0
+16620545.0,12.0,7.5,18.0,1.85411616971,204.0,297.0,93.0,229.0,19.2388495845,6870.0,225.5,240.0,407.0,167.0,282.333333333,40.2006080662,8470.0,272.0,319.0,525.0,206.0,375.2,47.6426979365,11256.0,359.5,157.0,428.0,271.0,220.433333333,61.7142249044,6613.0,203.5,0.101783841848,0.362763911486,0.260980069637,0.270894002418,0.0664419678326,8.12682007253,0.263987,612.0,1132.0,520.0,731.766666667,120.190871349,21953.0,699.5,5.91793823242,6.17297363281,0.255035400391,6.04638061523,0.0605242401801,181.391418457,6.0421
+16669823.0,22.0,6610.24999997,2816.0,9.77054470181,224.0,331.0,107.0,283.254188571,14.6365943073,7489524.0,284.0,291.0,481.0,190.0,400.434325479,27.2621851474,10587884.0,402.0,555.0,839.0,284.0,708.721644416,34.1437755592,18739309.0,709.0,287.0,598.0,311.0,476.450512462,40.3714605577,12597828.0,479.0,0.130217030644,0.33923304081,0.209016010165,0.197063631513,0.0258509794141,5210.55948085,0.191275,802.0,1399.0,597.0,1160.13902651,79.5812246859,30675236.0,1165.0,-0.152374267578,1.22210693359,1.37448120117,0.0979724481658,0.142377048987,2590.48950195,0.0292969
+16614779.0,11.0,40.9999999986,37.0,1.63006477913,263.0,407.0,144.0,354.006097561,30.3255701797,58057.0,365.5,419.0,630.0,211.0,516.536585366,40.8800133412,84712.0,512.0,456.0,724.0,268.0,575.213414634,61.5517594252,94335.0,568.5,399.0,698.0,299.0,524.006097561,55.4891218686,85937.0,537.0,-0.0365510769188,0.141981616616,0.178532693535,0.0464422530885,0.0451200024982,7.61652950651,0.043005,1105.0,1725.0,620.0,1394.54878049,116.4963783,228706.0,1412.0,-0.0765991210938,0.712158203125,0.788757324219,0.136782390315,0.161596869176,22.4323120117,0.0437012
+16612130.0,22.0,4376.49999996,1005.0,4.28546214665,238.0,462.0,224.0,359.709128299,20.6701597869,6297068.0,360.0,382.0,745.0,363.0,532.702102136,36.3207129394,9325483.0,533.0,690.0,1195.0,505.0,879.592482577,49.5107104765,15398146.0,879.0,393.0,942.0,549.0,653.561293271,46.8962740946,11441244.0,653.0,0.0738498792052,0.346522003412,0.272672124207,0.147871640868,0.0212055609803,2588.64094504,0.142678,1066.0,2139.0,1073.0,1545.97252371,98.8454479762,27063795.0,1546.0,-0.151000976562,1.57513427734,1.72613525391,0.0715607310055,0.139087929517,1252.74215698,0.0
+16614138.0,34.0,4194.99999999,1529.0,6.65942252606,213.0,377.0,164.0,261.519368296,8.43142677178,4388295.0,261.0,273.0,553.0,280.0,361.565315852,14.4008330895,6067066.0,361.0,522.0,1015.0,493.0,786.200238379,39.4248483196,13192440.0,784.0,209.0,598.0,389.0,379.63283671,30.8070013046,6370239.0,378.0,0.157389640808,0.496666669846,0.339277029037,0.348848843527,0.0438866500239,5853.68359439,0.346088,695.0,1515.0,820.0,1002.71752086,51.1269803501,16825600.0,1000.0,-0.266448974609,4.69085693359,4.9573059082,0.189677447386,0.503277446155,3182.78756714,0.0
+16630993.0,21.0,2525.5,2099.0,11.7824015643,236.0,454.0,218.0,338.084240744,21.1915104216,3415327.0,337.0,295.0,684.0,389.0,514.095228668,38.1334603577,5193390.0,513.0,439.0,1178.0,739.0,878.061967927,68.6571375383,8870182.0,878.0,249.0,983.0,734.0,680.439021976,57.7910304554,6873795.0,682.0,0.0298913046718,0.300000011921,0.270108707249,0.127026570868,0.0248274338416,1283.22241891,0.124442,792.0,2083.0,1291.0,1532.61849139,112.436616988,15482512.0,1531.0,-0.131286621094,4.63821411133,4.76950073242,0.219609944992,0.752455583384,2218.49966431,0.0
+16604596.0,51.0,5.5,13.0,1.56371310385,214.0,268.0,54.0,240.818181818,15.5698904172,5298.0,239.5,261.0,345.0,84.0,303.727272727,24.7848594145,6682.0,299.5,565.0,803.0,238.0,675.863636364,71.2794088937,14869.0,671.0,197.0,334.0,137.0,272.045454545,41.8563314128,5985.0,277.0,0.352226734161,0.495518565178,0.143291831017,0.428109797564,0.0383266928612,9.41841554642,0.424816,676.0,947.0,271.0,816.590909091,80.8166606872,17965.0,813.5,0.71484375,1.04846191406,0.333618164062,0.904037475586,0.0837178536553,19.8888244629,0.930649
+16593424.0,22.0,1060.0,366.0,3.1711969912,239.0,503.0,264.0,385.416273585,37.2482058487,1634165.0,386.0,368.0,879.0,511.0,639.397877358,73.0758938986,2711047.0,639.0,576.0,1431.0,855.0,1082.49811321,118.284999193,4589792.0,1088.0,396.0,1239.0,843.0,887.075471698,112.392002512,3761200.0,890.0,-0.0245546456426,0.248135253787,0.27268989943,0.100217276206,0.0270178686152,424.921251112,0.0986051,1007.0,2604.0,1597.0,1911.88962264,219.935330516,8106412.0,1918.0,-0.387542724609,2.93362426758,3.32116699219,0.371331614368,0.517073517934,1574.44604492,0.100006
+16590629.0,11.0,16.2499999995,21.0,1.46956121034,366.0,560.0,194.0,481.184615385,40.9186405924,31277.0,491.0,572.0,775.0,203.0,690.030769231,50.1578950702,44852.0,695.0,623.0,852.0,229.0,731.815384615,47.9544310322,47568.0,733.0,543.0,810.0,267.0,695.030769231,60.5225880861,45177.0,703.0,-0.0452054776251,0.103039287031,0.148244764656,0.0266295011908,0.0341203552376,1.7309175774,0.0383481,1575.0,2109.0,534.0,1866.24615385,130.564576509,121306.0,1872.0,0.0,0.00143432617188,0.00143432617188,5.25841346154e-05,0.000227713407111,0.00341796875,0.0
+16589059.0,31.0,4.0,8.0,1.1283791671,227.0,253.0,26.0,243.1875,5.9709583611,3891.0,243.5,305.0,368.0,63.0,348.0,15.2970585408,5568.0,349.5,1050.0,1373.0,323.0,1260.75,85.3130265552,20172.0,1264.5,212.0,300.0,88.0,264.5,20.1649448301,4232.0,267.5,0.610619485378,0.684605777264,0.0739862918854,0.652978528291,0.0185363560456,10.4476564527,0.655107,744.0,919.0,175.0,855.6875,39.695274829,13691.0,859.0,3.09664916992,3.53942871094,0.442779541016,3.41807746887,0.131930447173,54.689239502,3.45779
+16582614.0,51.0,13.25,19.0,1.47245058803,224.0,304.0,80.0,258.773584906,16.0819147333,13715.0,258.0,290.0,414.0,124.0,337.20754717,28.9256421403,17872.0,337.0,411.0,630.0,219.0,504.943396226,52.6442009185,26762.0,505.0,197.0,365.0,168.0,267.924528302,33.3499733001,14200.0,257.0,0.195979893208,0.394777268171,0.198797374964,0.306878067412,0.0474540594379,16.2645375729,0.302578,748.0,1064.0,316.0,863.905660377,70.1061901153,45787.0,856.0,0.122161865234,2.357421875,2.23526000977,1.96939202075,0.816311225076,104.3777771,2.33533
+16557457.0,34.0,68.499999996,66.0,2.2495399889,222.0,305.0,83.0,262.405109489,11.7355335463,71899.0,262.0,289.0,449.0,160.0,361.397810219,21.1404443985,99023.0,361.0,772.0,1042.0,270.0,915.339416058,49.8623446087,250803.0,915.5,243.0,492.0,249.0,339.364963504,37.6592241902,92986.0,339.5,0.317548751831,0.591596662998,0.274047911167,0.459711808031,0.0437900744327,125.961035401,0.459915,754.0,1246.0,492.0,963.167883212,68.4170411758,263908.0,963.0,-0.100036621094,0.420715332031,0.520751953125,0.0115707286083,0.0491236981188,3.17037963867,0.0
+16563564.0,22.0,247.750000006,205.0,3.67402491805,305.0,432.0,127.0,373.091826438,21.3411254746,369734.0,374.0,434.0,673.0,239.0,560.533804238,42.9085881849,555489.0,561.0,739.0,1117.0,378.0,949.288597376,57.7082108503,940745.0,952.0,506.0,896.0,390.0,726.325933401,63.6765898614,719789.0,729.0,0.0894653275609,0.277142852545,0.187677524984,0.134010669449,0.0229783097863,132.804573424,0.12987,1252.0,1982.0,730.0,1659.95156408,125.371148994,1645012.0,1661.0,-0.065673828125,1.24887084961,1.31454467773,0.257863372895,0.203621800754,255.542602539,0.267761
+16559072.0,34.0,261.750000002,97.0,1.69131093622,234.0,312.0,78.0,258.366762178,11.9323612423,270510.0,256.0,306.0,463.0,157.0,352.345749761,19.2083742529,368906.0,350.0,716.0,1137.0,421.0,924.573065903,75.5143215603,968028.0,924.0,257.0,507.0,250.0,340.015281757,33.2063928019,355996.0,336.0,0.262008726597,0.594317257404,0.332308530807,0.460863676829,0.0571861300603,482.52426964,0.465787,820.0,1252.0,432.0,950.727793696,59.1035015714,995412.0,945.0,-0.0867614746094,1.23934936523,1.32611083984,0.239413752369,0.355193723455,250.66619873,0.0261536
+9401209,13,6.0,11,1.26681188139,467,523,56,494.291666667,13.9178517459,11863,497.0,643,725,82,680.166666667,23.6284903359,16324,680.5,240,371,131,304.166666667,36.4322049231,7300,301.0,304,402,98,357.625,27.0536696525,8583,356.0,-0.182282790542,-0.00145985395648,0.180822936585,-0.0827176983488,0.052930826028,-1.98522476037,-0.0817048,1465,1600,135,1532.08333333,41.2552185251,36770,1541.0,-0.0101928710938,3.47247314453,3.48266601562,0.701395670573,1.2656150128,16.8334960938,0.0443115
+9343268,13,7.5,14,1.44209035422,399,453,54,431.2,14.9496934194,12936,436.0,510,603,93,573.766666667,21.269200476,17213,579.0,176,356,180,247.9,46.8311506016,7437,236.0,278,378,100,323.933333333,23.5654172229,9718,323.0,-0.260504215956,0.0178571436554,0.278361359611,-0.139428562461,0.0718436985404,-4.18285687384,-0.138148,1187,1411,224,1328.9,42.7226325656,39867,1334.5,0.0,0.959320068359,0.959320068359,0.478483072917,0.417315439539,14.3544921875,0.571594
+9323933,13,18.2500000007,24,1.58480150624,300,390,90,351.589041096,20.3737916636,25666,353.0,344,429,85,381.95890411,14.2159840158,27883,384.0,203,526,323,292.698630137,50.6837319369,21367,287.0,251,510,259,317.808219178,35.9316922478,23200,320.0,-0.19603960216,0.102106966078,0.298146568239,-0.0448694821999,0.0627385665311,-3.27547220059,-0.0340557,941,1282,341,1051.35616438,49.6418321892,76749,1053.0,0.691741943359,5.77359008789,5.08184814453,1.65439595262,0.996070753834,120.770904541,1.43317
+9311086,13,14.0,21,1.58325309212,329,433,104,382.017857143,25.0032077024,21393,383.0,388,565,177,482.125,39.3591804956,26999,487.0,249,481,232,347.589285714,52.355507551,19465,342.0,230,498,268,344.125,46.5307358098,19271,336.5,-0.124203823507,0.190140843391,0.314344666898,0.00374114824808,0.0751654028279,0.209504301893,-0.0133542,947,1479,532,1208.26785714,104.358498023,67663,1198.5,-0.0136413574219,0.0,0.0136413574219,-0.000243595668248,0.00180655382632,-0.0136413574219,0.0
+9045300,13,25.7500000009,26,1.44537253925,258,348,90,309.524271845,19.7900851218,31881,312.0,306,423,117,351.058252427,19.2625322931,36159,350.0,198,515,317,290.165048544,53.0874159274,29887,280.0,252,496,244,285.86407767,30.1626814186,29444,282.0,-0.168067231774,0.112804874778,0.280872106552,0.00187141448259,0.0631063236548,0.192755691707,0.0,863,1256,393,946.446601942,50.8742459032,97484,944.0,2.39685058594,2.48278808594,0.0859375,2.44323256409,0.0212890684959,251.652954102,2.44763
+8761449,41,662.999999983,718,7.86615949636,296,366,70,309.23453997,5.67422914342,820090,309.0,456,580,124,474.539969834,9.85977788333,1258480,474.0,375,491,116,392.7413273,9.40805611202,1041550,392.0,504,707,203,539.989441931,15.6351175916,1432052,539.0,-0.183958157897,-0.144408255816,0.0395499020815,-0.15780612832,0.00442231352173,-418.501852304,-0.15778,1262,1653,391,1323.76395173,30.4267673705,3510622,1321.0,0.0,0.0,0.0,0.0,0.0,0.0,0.0
+8662500,41,71.2499999991,88,2.94093418661,240,334,94,309.610526316,11.1512360138,88239,312.0,365,535,170,483.410526316,24.0240353638,137772,487.0,460,688,228,546.954385965,30.1616933199,155882,547.0,411,670,259,576.656140351,36.9783389299,164347,576.0,-0.122591942549,0.0767716541886,0.199363596737,-0.0260900737025,0.0382544162282,-7.43567100522,-0.0251799,1042,1507,465,1369.67719298,68.3985303462,390358,1375.0,-0.0398559570312,0.293151855469,0.3330078125,0.0218779982182,0.0604071797989,6.23522949219,0.0
+8594758,41,1133.0,1031,8.64049808619,176,353,177,253.452780229,17.2515454299,1148648,250.0,211,508,297,342.986540159,33.8000133794,1554415,337.0,350,914,564,601.984333628,96.8439772668,2728193,596.0,249,740,491,386.994042365,70.3351089155,1753857,372.0,0.0641658455133,0.391949146986,0.327783301473,0.217900854824,0.0544921987571,987.526674062,0.21245,737,1589,852,983.433362754,117.151854965,4456920,959.0,-0.712463378906,2.98837280273,3.70083618164,0.050258121339,0.23514523303,227.769805908,0.0
+8734336,41,2906.50000002,2929,15.3260160497,296,391,95,308.372957165,4.87040778457,3585144,308.0,448,619,171,472.057887494,8.16004140534,5488145,471.0,370,533,163,395.927490108,8.07320643552,4603053,395.0,488,770,282,527.764493377,13.0958737028,6135790,526.0,-0.181887954473,-0.0400822199881,0.141805734485,-0.142679911709,0.00495230840487,-1658.79665353,-0.142541,1243,1780,537,1308.19533804,24.9804936585,15209079,1305.0,0.0,0.0,0.0,0.0,0.0,0.0,0.0
+8375273,41,370.500000001,113,1.65607272798,270,325,55,308.70782726,7.29429968056,457505,310.0,385,509,124,475.421727395,16.7452416424,704575,479.0,353,525,172,417.310391363,18.0393410978,618454,415.0,398,556,158,497.4682861,21.0545690568,737248,499.0,-0.169265031815,0.101580135524,0.270845167339,-0.0875660777281,0.0297229553787,-129.772927193,-0.0940356,1065,1363,298,1281.59784076,40.0792763083,1899328,1288.0,-0.142974853516,1.255859375,1.39883422852,0.0380555434748,0.154795780789,56.3983154297,0.0
+8412220,14,1698.99999997,828,5.66668034991,258,384,126,327.849764567,15.4430908111,2228067,327.0,339,566,227,466.668187169,28.6617257089,3171477,465.0,435,945,510,644.909211301,71.1127202356,4382803,633.0,338,768,430,551.57769276,51.4778048057,3748522,543.0,-0.0164233576506,0.206095784903,0.222519142553,0.0771567342769,0.0290421270694,524.357166146,0.0742857,935,1645,710,1346.0956445,89.5934886387,9148066,1337.0,-0.305480957031,1.61074829102,1.91622924805,0.0661431728496,0.163982109743,449.509002686,0.0
+8347158,14,780.750000011,373,3.76571894576,210,383,173,295.087415946,13.8484678785,921558,295.0,273,563,290,405.462696126,23.638991572,1266260,403.0,377,769,392,586.089337176,42.1767626393,1830357,580.0,249,663,414,481.787383926,39.3202033757,1504622,477.0,0.00243309000507,0.262585043907,0.260151953902,0.0980207477284,0.0241804241765,306.118795156,0.0965251,761,1609,848,1182.337496,70.565458399,3692440,1175.0,-0.191192626953,3.81741333008,4.00860595703,0.131163407471,0.50487610381,409.623321533,0.0
+8428620,14,1587.00000005,952,6.74129842498,232,419,187,287.584120983,8.707601205,1825584,288.0,287,595,308,384.366414619,14.0529745319,2439958,384.0,403,852,449,523.424070573,29.8424459775,3322696,518.0,283,815,532,438.423913043,25.8899208978,2783115,435.0,-0.00800000037998,0.20281124115,0.21081124153,0.0884095869312,0.0140906098177,561.224057839,0.0874752,807,1829,1022,1110.37444865,44.3763813573,7048657,1107.0,-0.100006103516,4.10250854492,4.20251464844,0.0955082076709,0.30709019074,606.286102295,0.0
+8258250,14,1447.24999998,884,6.55504313509,204,327,123,294.544999136,7.89991294796,1705121,295.0,240,476,236,403.755743652,14.0047287471,2337342,405.0,362,729,367,572.211608222,28.1431690663,3312533,571.0,199,576,377,479.363966143,24.7116314766,2775038,480.0,-0.0462776646018,0.299826681614,0.346104346216,0.0883643006738,0.01746294689,511.540936601,0.0877193,643,1378,735,1177.66470893,44.009825926,6817501,1180.0,-0.2451171875,9.92211914062,10.1672363281,0.530700588704,1.4399395006,3072.22570801,0.0
+8284330,14,65.5000000005,79,2.7536041612,211,299,88,274.366412214,9.70260538463,71884,275.0,256,405,149,364.805343511,17.4674257924,95579,366.0,414,573,159,507.900763359,25.1767355844,133070,506.0,253,490,237,416.790076336,30.0336614077,109199,418.0,0.0347071588039,0.244776114821,0.210068956017,0.0992817132101,0.0242767080728,26.011808861,0.0948978,720,1194,474,1055.96183206,55.9704672099,276662,1060.0,-0.0765991210938,2.76522827148,2.84182739258,1.08530571625,0.633532538412,284.350097656,0.872681
Added: grass-addons/grass7/raster/r.object.activelearning/examples/unlabeled_set.csv
--- grass-addons/grass7/raster/r.object.activelearning/examples/unlabeled_set.csv	                        (rev 0)
+++ grass-addons/grass7/raster/r.object.activelearning/examples/unlabeled_set.csv	2017-05-03 08:09:28 UTC (rev 71010)
@@ -0,0 +1,772 @@
+cat,area,perimeter,compact,opt_blue_min,opt_blue_max,opt_blue_range,opt_blue_mean,opt_blue_stddev,opt_blue_sum,opt_blue_median,opt_green_min,opt_green_max,opt_green_range,opt_green_mean,opt_green_stddev,opt_green_sum,opt_green_median,opt_nir_min,opt_nir_max,opt_nir_range,opt_nir_mean,opt_nir_stddev,opt_nir_sum,opt_nir_median,opt_red_min,opt_red_max,opt_red_range,opt_red_mean,opt_red_stddev,opt_red_sum,opt_red_median,NDVI_min,NDVI_max,NDVI_range,NDVI_mean,NDVI_stddev,NDVI_sum,NDVI_median,Brightness_min,Brightness_max,Brightness_range,Brightness_mean,Brightness_stddev,Brightness_sum,Brightness_median,nDSM_min,nDSM_max,nDSM_range,nDSM_mean,nDSM_stddev,nDSM_sum,nDSM_median
+16559167.0,97.5000000009,80.0,2.28550800702,256.0,309.0,53.0,281.458974359,9.64243340786,109769.0,281.0,340.0,442.0,102.0,388.925641026,17.8758427156,151681.0,388.0,601.0,850.0,249.0,689.787179487,47.7675282876,269017.0,676.0,392.0,546.0,154.0,464.969230769,25.0170009255,181338.0,464.5,0.120492525399,0.27182045579,0.151327930391,0.194111338812,0.0280813117909,75.7034221366,0.190456,988.0,1283.0,295.0,1135.35384615,50.7184073506,442788.0,1132.5,-0.144561767578,0.320007324219,0.464569091797,0.0312834910857,0.0687417673744,12.2005615234,0.0
+16640518.0,7938.99999803,3380.0,10.7011109615,235.0,463.0,228.0,302.48863207,10.3017163069,9605829.0,302.0,290.0,673.0,383.0,398.0757967,18.8667159655,12641295.0,397.0,350.0,818.0,468.0,521.223075954,38.5260464884,16551960.0,513.0,224.0,877.0,653.0,418.025129109,35.1335000733,13274806.0,412.0,-0.0348082594573,0.27500000596,0.309808265418,0.110229826948,0.018770345307,3500.45838457,0.10872,777.0,2013.0,1236.0,1118.58955788,60.7953701706,35521930.0,1111.0,-0.143035888672,2.28402709961,2.42706298828,0.88424803319,0.645521771788,28080.180542,1.00175
+16542003.0,3.25,12.0,1.87773643621,190.0,282.0,92.0,232.230769231,26.4550528725,3019.0,233.0,244.0,338.0,94.0,282.692307692,26.8138443443,3675.0,271.0,356.0,500.0,144.0,408.692307692,41.850254324,5313.0,381.0,182.0,356.0,174.0,254.307692308,49.12681332,3306.0,231.0,0.168224304914,0.323420077562,0.155195772648,0.238509050929,0.0441661870399,3.10061766207,0.23888,616.0,948.0,332.0,769.230769231,96.7503956232,10000.0,735.0,-0.00714111328125,3.07000732422,3.0771484375,0.436776968149,0.767766943233,5.67810058594,0.288544
+16543666.0,609.749999996,305.0,3.48432777477,219.0,394.0,175.0,311.885608856,22.0442274593,760689.0,311.0,269.0,606.0,337.0,440.487084871,38.7266328025,1074348.0,441.0,435.0,1077.0,642.0,822.52398524,80.8915631983,2006136.0,822.0,242.0,664.0,422.0,512.318573186,60.1284993701,1249545.0,514.0,0.124686188996,0.476894646883,0.352208457887,0.232994003615,0.0482749910989,568.272374816,0.22498,730.0,1591.0,861.0,1264.69126691,115.01470488,3084582.0,1267.0,-0.0758056640625,1.32485961914,1.4006652832,0.0737569698695,0.146581010703,179.893249512,0.0
+16542046.0,1507.49999998,1057.0,7.67964942316,184.0,341.0,157.0,258.744444444,13.565706378,1560229.0,258.0,211.0,523.0,312.0,351.382421227,25.781754436,2118836.0,349.0,426.0,1051.0,625.0,789.545107794,52.1651561949,4760957.0,789.0,123.0,561.0,438.0,365.971310116,36.6755575757,2206807.0,363.0,0.22291021049,0.566775262356,0.343865051866,0.367297616925,0.0351378610893,2214.80463006,0.368421,519.0,1357.0,838.0,976.098175788,71.7138938223,5885872.0,971.0,-0.108642578125,1.62689208984,1.73553466797,0.0824426502335,0.163386989613,497.129180908,0.0
+16565319.0,4538.75000001,3400.0,14.2365859389,264.0,469.0,205.0,364.805342881,20.1202226367,6623041.0,365.0,374.0,692.0,318.0,576.016028642,36.644402663,10457571.0,578.0,617.0,1337.0,720.0,1029.27711374,58.5658787214,18686526.0,1029.0,418.0,952.0,534.0,771.378463233,56.3427664405,14004376.0,776.0,0.0325203239918,0.319399088621,0.286878764629,0.143671025224,0.0279123490052,2608.34746294,0.138058,1057.0,2028.0,971.0,1712.19983476,105.105476917,31084988.0,1720.0,-0.229278564453,1.19604492188,1.42532348633,0.050172258323,0.113208738359,910.877349854,0.0
+16545843.0,2772.50000002,1454.0,7.78975317862,244.0,451.0,207.0,380.816050496,18.0573246668,4223250.0,382.0,374.0,730.0,356.0,607.706853021,34.5742910726,6739469.0,610.0,680.0,1305.0,625.0,1052.24788097,69.4649262299,11669429.0,1054.0,427.0,1017.0,590.0,851.391073039,60.1478213008,9441927.0,856.0,0.0372369140387,0.264610379934,0.227373465896,0.105679291815,0.0187391461145,1171.98334623,0.102885,1053.0,2150.0,1097.0,1839.91397656,109.702258712,20404646.0,1848.0,-0.132843017578,1.23275756836,1.36560058594,0.068923504402,0.13450029622,764.361663818,0.0
+16531195.0,21.25,23.0,1.40748390354,329.0,464.0,135.0,398.788235294,31.880325527,33897.0,404.0,448.0,639.0,191.0,553.717647059,44.2489246834,47066.0,555.0,542.0,774.0,232.0,632.258823529,49.2195926893,53742.0,625.0,457.0,660.0,203.0,575.494117647,45.4272847603,48917.0,585.0,-0.0279329605401,0.119787044823,0.147720005363,0.047038788847,0.0374800884387,3.99829705199,0.0395137,1240.0,1747.0,507.0,1528.0,114.554584985,129880.0,1523.0,-0.163543701172,0.385955810547,0.549499511719,0.0587610581342,0.136007657625,4.99468994141,0.0
+16536496.0,117.500000002,66.0,1.71759224361,233.0,310.0,77.0,263.521276596,12.0782279271,123855.0,262.0,300.0,444.0,144.0,359.163829787,20.897947833,168807.0,357.0,779.0,1183.0,404.0,1041.73829787,68.0314822404,489617.0,1048.0,227.0,464.0,237.0,321.544680851,33.9018157332,151126.0,318.0,0.345557123423,0.649149894714,0.303592771292,0.527797269377,0.0478991311569,248.064716607,0.531399,762.0,1214.0,452.0,944.229787234,63.2962837634,443788.0,938.0,-0.0312805175781,1.09231567383,1.12359619141,0.0873870200299,0.19380178458,41.0718994141,-3.05176e-05
+16526044.0,2936.75000002,1527.0,7.94878254844,237.0,395.0,158.0,299.571890695,14.5616697809,3519071.0,299.0,315.0,548.0,233.0,421.614710139,26.0263635453,4952708.0,421.0,551.0,939.0,388.0,779.876564229,49.2429769313,9161210.0,783.0,304.0,675.0,371.0,491.062739423,43.2542090347,5768514.0,490.0,0.126213595271,0.41272431612,0.286510720849,0.22791574521,0.0305689562118,2677.32625899,0.225908,880.0,1552.0,672.0,1212.24934026,80.8856551204,14240293.0,1211.0,-0.085205078125,1.26910400391,1.35430908203,0.206434706297,0.165516052033,2424.98849487,0.178711
+16509789.0,1028.99999999,542.0,4.76635808954,208.0,336.0,128.0,253.275024295,17.8902188402,1042480.0,252.0,267.0,474.0,207.0,335.379008746,33.8641054093,1380420.0,335.0,545.0,964.0,419.0,701.700437318,68.3322565736,2888199.0,706.0,232.0,613.0,381.0,358.882653061,56.1354920682,1477161.0,355.0,0.165266111493,0.54458874464,0.379322633147,0.325582189679,0.0493634896163,1340.09629272,0.328213,725.0,1417.0,692.0,947.536686103,105.58672376,3900061.0,944.0,-0.131866455078,2.02752685547,2.15939331055,0.236342842539,0.335335110521,972.787139893,0.0582123
+16491503.0,278.500000005,89.0,1.50443169645,353.0,636.0,283.0,540.042190305,47.6810827546,601607.0,560.0,501.0,919.0,418.0,782.867145422,65.3644824297,872114.0,807.0,506.0,1171.0,665.0,859.152603232,61.4543229058,957096.0,853.0,407.0,995.0,588.0,817.179533214,63.3120005965,910338.0,827.5,-0.0289555322379,0.258114367723,0.287069899961,0.0253578098417,0.0308882577792,28.2486001636,0.0139649,1309.0,2539.0,1230.0,2140.08886894,164.939361585,2384059.0,2197.0,-0.135528564453,4.42572021484,4.5612487793,3.1292280543,0.915144765191,3485.96005249,3.36397
+16486506.0,3073.24999999,1566.0,7.96870740265,217.0,387.0,170.0,296.89620109,20.9235855708,3649745.0,296.0,275.0,567.0,292.0,428.186854307,39.1812693747,5263701.0,427.0,595.0,1149.0,554.0,843.010575124,81.7650755938,10363129.0,837.0,224.0,668.0,444.0,468.649475311,52.8802242347,5761108.0,466.0,0.163547605276,0.457627117634,0.294079512358,0.285688702694,0.0393313188216,3511.97122222,0.286166,716.0,1606.0,890.0,1193.73253071,110.851374441,14674554.0,1190.0,-0.125823974609,1.4909362793,1.61676025391,0.111159797953,0.155768439922,1366.48739624,0.0663147
+16485601.0,7534.0,4065.0,13.2112165099,268.0,514.0,246.0,439.177196708,21.4435425395,13235044.0,441.0,377.0,817.0,440.0,665.895307937,34.2996285316,20067421.0,669.0,699.0,1320.0,621.0,1061.43479559,48.853906057,31987399.0,1062.0,382.0,1093.0,711.0,849.568954075,49.8168582176,25602610.0,853.0,0.051323607564,0.333333343267,0.282009735703,0.111223299255,0.0155153786633,3351.82534634,0.108901,1054.0,2418.0,1364.0,1954.64145872,100.268502844,58905075.0,1963.0,-0.150299072266,1.15759277344,1.3078918457,0.106943211,0.120607670871,3222.84060669,0.0775452
+16439195.0,1546.99999999,659.0,4.72645280543,185.0,391.0,206.0,260.940206852,18.2048330515,1614698.0,259.0,234.0,548.0,314.0,367.001939237,32.9463432675,2271008.0,366.0,616.0,1223.0,607.0,942.662249515,79.759338341,5833194.0,950.0,156.0,600.0,444.0,365.273917259,58.1478521262,2260315.0,360.0,0.226581260562,0.667485654354,0.440904393792,0.44282272742,0.0642136269975,2740.18703727,0.442356,581.0,1446.0,865.0,993.216063348,104.881063648,6146021.0,984.0,-0.111724853516,1.28042602539,1.39215087891,0.100483184795,0.169547732388,621.78994751,0.0
+16442477.0,1650.25000003,675.0,4.68731316371,265.0,380.0,115.0,313.249356158,13.3082706666,2067759.0,312.0,368.0,593.0,225.0,461.827298894,24.4801398896,3048522.0,460.0,670.0,976.0,306.0,811.994546281,41.115773897,5359976.0,810.0,491.0,865.0,374.0,665.220118164,41.9476650156,4391118.0,662.0,0.0364145673811,0.154177427292,0.117762859911,0.0996865938839,0.0126931064387,658.031206228,0.100182,1124.0,1822.0,698.0,1440.29677322,77.6609964027,9507399.0,1434.0,-0.143798828125,1.09558105469,1.23937988281,0.194554590561,0.208532757953,1284.25485229,0.148621
+16433574.0,883.750000007,350.0,3.32122576924,228.0,357.0,129.0,271.231683168,14.4157234946,958804.0,270.0,309.0,520.0,211.0,378.222630835,25.5153934154,1337017.0,376.0,698.0,1102.0,404.0,872.163224894,48.8111414556,3083097.0,868.0,274.0,652.0,378.0,388.951343706,46.2384803686,1374943.0,386.0,0.236980691552,0.51499569416,0.278015002608,0.384542994865,0.0440055972334,1359.35948685,0.380331,821.0,1529.0,708.0,1038.40565771,84.4155483624,3670764.0,1031.0,-0.0672302246094,0.726043701172,0.793273925781,0.0393148419543,0.100557681744,138.977966309,0.0
+16446963.0,6350.25,4536.0,16.0573066878,256.0,435.0,179.0,330.774969489,20.5454955197,8402015.0,330.0,364.0,683.0,319.0,488.395378135,36.5152437451,12405731.0,487.0,656.0,1220.0,564.0,909.743947089,64.0226460096,23108406.0,909.0,380.0,826.0,446.0,586.300381875,56.2716203738,14892616.0,586.0,0.113667115569,0.36305731535,0.24939019978,0.216996793743,0.030960276713,5511.93555786,0.215591,1015.0,1887.0,872.0,1405.4707295,110.365514402,35700362.0,1403.0,-0.199584960938,1.20077514648,1.40036010742,0.0622099166095,0.121945141653,1580.1940918,0.0
+16417792.0,99.7499999972,51.0,1.44048517132,306.0,353.0,47.0,341.127819549,6.06408573877,136110.0,342.0,517.0,619.0,102.0,595.546365915,17.9138072951,237623.0,601.0,482.0,708.0,226.0,568.436090226,32.6064141906,226806.0,562.0,683.0,890.0,207.0,835.421052632,29.2862145694,333333.0,843.0,-0.286454468966,-0.0282404050231,0.258214063942,-0.190343456539,0.0404923614544,-75.947039159,-0.202255,1513.0,1835.0,322.0,1772.0952381,50.5685564321,707066.0,1784.0,-0.0492248535156,1.04837036133,1.09759521484,0.11040701424,0.257902002826,44.0523986816,0.0
+16429611.0,13311.2500001,7326.0,17.9123498228,202.0,315.0,113.0,242.62496009,7.31903129784,12918566.0,242.0,231.0,418.0,187.0,304.898657151,12.5129131565,16234329.0,304.0,436.0,763.0,327.0,563.827288947,29.9958521404,30020984.0,560.0,187.0,498.0,311.0,304.38965161,20.2128540404,16207227.0,304.0,0.166666671634,0.47619047761,0.309523805976,0.298845374177,0.031942242099,15912.021948,0.29638,620.0,1231.0,611.0,851.913268852,38.1158603316,45360122.0,850.0,-0.208618164062,4.07507324219,4.28369140625,0.73383141112,0.765929512918,39072.8534851,0.502075
+16419829.0,90.5,69.0,2.04606708582,210.0,351.0,141.0,248.477900552,15.0357146832,89949.0,250.0,261.0,507.0,246.0,328.814917127,28.1967534399,119031.0,331.0,594.0,1271.0,677.0,963.958563536,131.25524855,348953.0,990.0,172.0,563.0,391.0,277.331491713,41.3176691229,100394.0,278.0,0.386041432619,0.680594265461,0.294552832842,0.551618859419,0.0454507308082,199.68602711,0.549506,649.0,1421.0,772.0,854.624309392,82.8498759836,309374.0,860.0,0.0062255859375,2.48541259766,2.47918701172,1.03854951806,0.689464889798,375.954925537,1.42503
+16373059.0,90.25,59.0,1.75195712786,294.0,396.0,102.0,323.418282548,10.1175691702,116754.0,323.0,444.0,643.0,199.0,507.601108033,21.1006399686,183244.0,508.0,304.0,553.0,249.0,375.509695291,32.6327765513,135559.0,369.0,450.0,735.0,285.0,527.736842105,30.9317898491,190513.0,527.0,-0.26293104887,-0.0637450218201,0.19918602705,-0.169144453785,0.0446883253196,-61.0611478165,-0.175966,1188.0,1774.0,586.0,1358.75623269,59.391479016,490511.0,1356.0,-0.0750122070312,1.16198730469,1.23699951172,0.157242624383,0.290265329624,56.7645874023,0.0
+16342979.0,456.749999999,293.0,3.86743844706,253.0,438.0,185.0,367.385878489,20.4926322839,671214.0,371.0,380.0,708.0,328.0,578.715380405,37.0693664612,1057313.0,584.0,704.0,1193.0,489.0,1024.348659,56.3599003833,1871485.0,1025.0,422.0,944.0,522.0,811.731253421,54.8220739756,1483033.0,818.0,0.056994818151,0.250444054604,0.193449236453,0.116185907758,0.0226754644057,212.271653473,0.113696,1055.0,1986.0,931.0,1757.83251232,105.437620499,3211560.0,1776.0,-0.0532836914062,0.655334472656,0.708618164062,0.0179402769493,0.0680158785466,32.7768859863,0.0
+16365885.0,2245.25000001,1140.0,6.78683931225,229.0,362.0,133.0,278.216679657,11.528687134,2498664.0,277.0,321.0,544.0,223.0,393.706157443,21.2817263166,3535875.0,391.0,668.0,1207.0,539.0,820.302304866,54.9137415544,7367135.0,811.0,278.0,664.0,386.0,413.479902015,33.7672819615,3713463.0,411.0,0.214637577534,0.510563373566,0.295925796032,0.329755063725,0.0354258475475,2961.53022732,0.328616,845.0,1558.0,713.0,1085.40273912,64.8687868129,9748002.0,1079.0,-0.0508117675781,1.33197021484,1.38278198242,0.112935739774,0.175446566417,1014.27587891,0.0289612
+16330413.0,6.0,15.0,1.72747074736,220.0,307.0,87.0,277.25,23.2096423928,6654.0,282.0,292.0,425.0,133.0,361.791666667,38.0996272583,8683.0,359.0,330.0,630.0,300.0,436.833333333,84.1648514656,10484.0,452.0,199.0,458.0,259.0,298.916666667,80.3917059708,7174.0,304.0,0.12298387289,0.261595547199,0.138611674309,0.195726366714,0.0426313779497,4.69743280113,0.206438,730.0,1190.0,460.0,937.958333333,133.240221394,22511.0,934.0,-0.0219116210938,0.0471496582031,0.0690612792969,0.000144958496094,0.0110816782668,0.00347900390625,0.0
+16328401.0,5441.25000004,2503.0,9.5720856838,177.0,343.0,166.0,243.224810476,14.8190727192,5293788.0,243.0,192.0,504.0,312.0,332.996186538,30.2341977973,7247662.0,336.0,558.0,1313.0,755.0,998.237399495,92.4691819709,21726637.0,998.0,98.0,549.0,451.0,287.44874799,44.6045843447,6256322.0,291.0,0.363847047091,0.803921580315,0.440074533224,0.553115044242,0.0572884114527,12038.5489379,0.549296,482.0,1396.0,914.0,863.669745003,87.1015583494,18797772.0,872.0,-0.507843017578,2.38186645508,2.88970947266,0.292807701596,0.410959842896,6372.95962524,0.115967
+16350899.0,8559.74999999,4554.0,13.8853731065,230.0,487.0,257.0,376.368381086,23.8718801333,12886477.0,378.0,340.0,767.0,427.0,571.809661497,40.532665904,19578191.0,574.0,690.0,1258.0,568.0,1017.77522708,58.168820975,34847606.0,1020.0,354.0,959.0,605.0,769.055813546,60.9132768816,26331702.0,775.0,0.0589519664645,0.355989813805,0.29703784734,0.139939482584,0.0241566424729,4791.3879442,0.134615,933.0,2174.0,1241.0,1717.23385613,120.386016507,58796370.0,1727.0,-0.146118164062,1.44458007812,1.59069824219,0.114618218333,0.139166655013,3924.41317749,0.0744019
+16328842.0,6.50000000023,11.0,1.21711348669,377.0,458.0,81.0,407.076923077,21.4761461178,10584.0,405.5,496.0,645.0,149.0,542.230769231,37.9932258054,14098.0,538.0,501.0,785.0,284.0,588.961538462,77.9607794734,15313.0,561.5,496.0,719.0,223.0,551.153846154,58.7148862711,14330.0,531.0,-0.00925925932825,0.0746043697,0.0838636290282,0.0317521974391,0.0226870855367,0.825557133416,0.032764,1384.0,1822.0,438.0,1500.46153846,113.491860355,39012.0,1465.5,-0.0054931640625,0.00234985351562,0.00784301757812,-0.000120896559495,0.00116547526674,-0.00314331054688,0.0
+16321090.0,236.499999995,144.0,2.64144752584,272.0,372.0,100.0,312.875264271,13.7604575333,295980.0,313.0,386.0,533.0,147.0,450.391120507,23.3110524062,426070.0,449.0,589.0,839.0,250.0,715.480972516,43.4459660214,676845.0,713.0,495.0,726.0,231.0,588.754756871,39.0594102647,556962.0,584.5,0.0474281907082,0.181102365255,0.133674174547,0.0973074068581,0.0149257638069,92.0528068878,0.0961966,1171.0,1596.0,425.0,1352.02114165,69.41893821,1279012.0,1345.5,-0.067626953125,0.302673339844,0.370300292969,0.0142965175637,0.0525889030382,13.5245056152,0.0
+16310693.0,2604.25000001,1502.0,8.30278255661,249.0,376.0,127.0,321.337429202,12.3590990762,3347372.0,321.0,344.0,562.0,218.0,471.47374484,20.8968977811,4911342.0,471.0,639.0,981.0,342.0,815.032254968,40.7849133196,8490191.0,815.0,419.0,779.0,360.0,655.164346741,36.1972514643,6824847.0,657.0,0.0567936748266,0.227513223886,0.17071954906,0.108859888867,0.016214992543,1133.99346233,0.105965,1012.0,1716.0,704.0,1447.97552078,61.0475092301,15083561.0,1450.0,-0.14892578125,1.01443481445,1.1633605957,0.0864119975114,0.146586405816,900.153778076,0.0
+16286677.0,3.50000000023,9.0,1.35707407891,194.0,282.0,88.0,244.857142857,27.5340234797,3428.0,253.5,221.0,312.0,91.0,250.0,24.1009780477,3500.0,241.5,615.0,722.0,107.0,662.214285714,26.9342548,9271.0,670.0,131.0,208.0,77.0,177.428571429,22.0542003959,2484.0,182.0,0.533957839012,0.657516360283,0.123558521271,0.578837884324,0.0336605473075,8.10373038054,0.569781,557.0,782.0,225.0,672.285714286,59.9647855846,9412.0,684.5,1.92181396484,2.31448364258,0.392669677734,2.06699480329,0.144345997145,28.9379272461,1.99915
+16359374.0,3452.49999963,2140.0,10.2740576363,216.0,776.0,560.0,311.622302679,13.2446044123,4303504.0,312.0,261.0,1126.0,865.0,422.740188269,21.3328162953,5838042.0,423.0,390.0,1292.0,902.0,579.757929037,30.3202503013,8006457.0,578.0,210.0,1555.0,1345.0,467.64974656,34.1830791211,6458243.0,466.0,-0.0923779383302,0.300000011921,0.392377950251,0.107530924364,0.0167108962622,1485.00206546,0.105948,687.0,3457.0,2770.0,1202.01223751,66.4369289423,16599789.0,1200.0,0.206207275391,1.57855224609,1.3723449707,0.762711830885,0.18577626933,10533.0503845,0.739746
+16351232.0,192.749999998,113.0,2.29602344355,271.0,439.0,168.0,400.018158236,16.7876701784,308414.0,402.0,391.0,668.0,277.0,599.189364462,27.3931920118,461975.0,603.0,702.0,1063.0,361.0,940.169909209,35.2473700741,724871.0,942.0,404.0,813.0,409.0,720.044098573,37.8910736701,555154.0,724.0,0.109048724174,0.269439429045,0.16039070487,0.132936653064,0.0171811678703,102.494159512,0.128936,1066.0,1914.0,848.0,1719.25162127,78.7851762828,1325543.0,1730.0,-0.0504150390625,0.385162353516,0.435577392578,0.119337148703,0.102438228235,92.0089416504,0.116394
+16239195.0,4507.00000001,2444.0,10.2695754626,285.0,461.0,176.0,401.740736632,13.2226714184,7242582.0,402.0,444.0,745.0,301.0,649.15348347,23.1276739125,11702939.0,649.0,810.0,1268.0,458.0,1084.50282893,41.072898156,19551417.0,1085.0,464.0,990.0,526.0,841.523297093,35.1240339353,15170982.0,840.0,0.0862581804395,0.293221622705,0.206963442266,0.126223819003,0.0121120933467,2275.56300899,0.124391,1193.0,2181.0,988.0,1892.4175172,68.0352172718,34116503.0,1892.0,-0.095458984375,1.72494506836,1.82040405273,0.268449582307,0.240560529606,4839.60906982,0.236145
+16185790.0,81.5000000065,81.0,2.53105325144,378.0,431.0,53.0,403.803680982,10.3431070647,131640.0,403.0,589.0,670.0,81.0,628.285276074,16.6162450378,204821.0,627.0,938.0,1075.0,137.0,1007.49079755,20.7764520133,328442.0,1005.0,743.0,874.0,131.0,815.960122699,21.700306859,266003.0,815.0,0.0888192281127,0.124708622694,0.0358893945813,0.105104759381,0.00505122086729,34.2641515583,0.104849,1714.0,1975.0,261.0,1848.04907975,45.2638215587,602464.0,1845.0,-0.0910339355469,0.354217529297,0.445251464844,0.0552373780795,0.0889952304926,18.0073852539,3.05176e-05
+16203953.0,1980.5,874.0,5.54011879483,222.0,308.0,86.0,251.877556173,12.6084751949,1995374.0,250.0,296.0,472.0,176.0,354.174703358,28.2765364003,2805772.0,349.0,734.0,1205.0,471.0,922.626356981,66.7674051797,7309046.0,914.0,232.0,485.0,253.0,313.273794496,36.9455803523,2481755.0,308.0,0.315384626389,0.616547346115,0.301162719727,0.493684833413,0.0376005359749,3910.9712503,0.49297,765.0,1262.0,497.0,919.326054027,76.1617990978,7282901.0,908.0,-0.103454589844,1.44311523438,1.54656982422,0.219729929372,0.271272840051,1740.70050049,0.131729
+16175332.0,139.249999998,108.0,2.58179182643,274.0,393.0,119.0,351.921005386,18.3632078999,196020.0,355.0,407.0,617.0,210.0,531.120287253,34.1121010964,295834.0,537.0,727.0,1127.0,400.0,915.752244165,61.544831344,510074.0,917.0,488.0,854.0,366.0,706.082585278,56.7718385614,393288.0,714.0,0.0827629119158,0.226215645671,0.143452733755,0.129734742698,0.0265428770342,72.2622516826,0.121134,1169.0,1851.0,682.0,1589.12387792,106.234053212,885142.0,1610.0,-0.0661926269531,0.16162109375,0.227813720703,0.00541037759832,0.0222382431907,3.01358032227,0.0
+16214164.0,196.000000003,140.0,2.82094791772,279.0,414.0,135.0,376.150510204,13.9984620053,294902.0,377.0,413.0,646.0,233.0,577.343112245,24.6779952074,452637.0,579.0,729.0,1042.0,313.0,950.371173469,37.109239397,745091.0,952.0,475.0,871.0,396.0,763.716836735,35.7258755794,598754.0,767.0,0.078651688993,0.210963457823,0.13231176883,0.109079787926,0.0127699391291,85.5185537338,0.107505,1167.0,1923.0,756.0,1717.21045918,71.3277706086,1346293.0,1723.0,-0.165588378906,0.362457275391,0.528045654297,0.0111951244121,0.0421138270968,8.77697753906,0.0
+16168157.0,394.999999994,169.0,2.39874026267,256.0,374.0,118.0,310.152531646,17.5984075782,490041.0,310.0,332.0,555.0,223.0,442.332278481,29.7305042364,698885.0,441.0,635.0,1042.0,407.0,882.484810127,46.0625375354,1394326.0,883.0,310.0,700.0,390.0,503.835443038,49.2181993662,796060.0,503.0,0.196326062083,0.370583415031,0.174257352948,0.274450138032,0.0301103640187,433.631218091,0.272856,926.0,1625.0,699.0,1256.32025316,94.0164742899,1984986.0,1254.0,-0.0601806640625,1.56332397461,1.62350463867,0.111032374901,0.23477330278,175.431152344,0.0202637
+16153183.0,38.2500000007,32.0,1.45958478169,194.0,271.0,77.0,241.692810458,12.7547407799,36979.0,243.0,241.0,370.0,129.0,322.019607843,26.3747429658,49269.0,323.0,662.0,1035.0,373.0,901.254901961,72.6032759494,137892.0,916.0,148.0,337.0,189.0,264.339869281,38.3443570507,40444.0,266.0,0.452444434166,0.661448121071,0.209003686905,0.547622049751,0.0449624667239,83.7861736119,0.544715,583.0,978.0,395.0,828.052287582,76.9337029632,126692.0,833.0,0.0023193359375,2.0934753418,2.09115600586,1.00027485766,0.41027499476,153.042053223,1.02576
+16182762.0,3939.75000039,2013.0,9.04699834268,237.0,453.0,216.0,306.566533409,10.6509974077,4831182.0,307.0,273.0,603.0,330.0,408.701821182,17.1709579132,6440732.0,408.0,412.0,791.0,379.0,536.385874738,23.6715935806,8452905.0,534.0,185.0,690.0,505.0,430.821625738,26.709120012,6789318.0,429.0,0.0349309518933,0.400881052017,0.365950100124,0.1095752103,0.017286620028,1726.79573913,0.108787,699.0,1746.0,1047.0,1146.08998033,52.4194548972,18061232.0,1144.0,-0.0545654296875,1.24557495117,1.30014038086,0.331243538616,0.177590632266,5220.06692505,0.321838
+16133842.0,164.499999994,130.0,2.85927198545,223.0,336.0,113.0,276.67325228,18.9984301559,182051.0,275.0,275.0,496.0,221.0,386.717325228,34.3366894279,254460.0,381.0,448.0,1005.0,557.0,727.738601824,79.3293607466,478852.0,728.0,252.0,624.0,372.0,420.782674772,58.3453964983,276875.0,409.0,0.109929077327,0.398558199406,0.288629122078,0.268070253184,0.0473600127371,176.390226595,0.273283,783.0,1434.0,651.0,1084.17325228,107.632326482,713386.0,1063.5,-0.03515625,0.718109130859,0.753265380859,0.0372308423816,0.128478309442,24.4978942871,-3.05176e-05
+16137071.0,4209.74999998,1817.0,7.89990452272,221.0,350.0,129.0,275.425262783,15.5075419876,4637886.0,274.0,296.0,525.0,229.0,389.189975652,28.3707995417,6553570.0,387.0,676.0,1203.0,527.0,919.859730388,52.910961518,15489518.0,919.0,241.0,611.0,370.0,384.655086407,46.5108446479,6477207.0,380.0,0.246015250683,0.564637184143,0.31862193346,0.411548239046,0.0452019154613,6930.06079729,0.412315,773.0,1484.0,711.0,1049.27032484,88.6198220463,17668663.0,1040.0,-0.207855224609,2.14266967773,2.35052490234,0.136538000541,0.220048585289,2299.16339111,0.0259399
+16125037.0,24.0000000007,25.0,1.43955895611,196.0,264.0,68.0,241.885416667,11.4381213781,23221.0,243.0,251.0,379.0,128.0,332.3125,21.1696089654,31902.0,334.0,934.0,1362.0,428.0,1170.36458333,83.8754185026,112355.0,1167.0,139.0,321.0,182.0,258.8125,31.5083694239,24846.0,260.5,0.566523611546,0.770057916641,0.203534305096,0.637903378035,0.0374685343403,61.2387242913,0.6309,586.0,959.0,373.0,833.010416667,61.446028959,79969.0,839.5,-0.134368896484,0.276550292969,0.410919189453,0.1165711085,0.102115085678,11.190826416,0.175552
+16121923.0,3415.25000002,1457.0,7.03304457176,207.0,355.0,148.0,267.245882439,19.7372631082,3650846.0,264.0,263.0,538.0,275.0,372.83851841,38.3672396081,5093347.0,367.0,627.0,1242.0,615.0,895.219017641,88.3198666818,12229587.0,888.0,222.0,657.0,435.0,400.989385843,64.0785785664,5477916.0,390.0,0.198352783918,0.625935137272,0.427582353353,0.383100651575,0.0547865197877,5233.53800116,0.382274,703.0,1550.0,847.0,1041.07378669,120.035589854,14222109.0,1020.0,-0.16015625,1.44845581055,1.60861206055,0.0740485161353,0.180461647341,1011.57677892,0.0
+16068696.0,3.00000000023,8.0,1.30294003169,535.0,1042.0,507.0,792.5,135.843353414,9510.0,814.0,1572.0,2214.0,642.0,1964.58333333,200.035187877,23575.0,2063.5,1684.0,2311.0,627.0,1980.08333333,173.432723908,23761.0,1983.5,1819.0,2660.0,841.0,2173.25,225.317969767,26079.0,2164.5,-0.0702072009444,-0.0032240729779,0.0669831279665,-0.0457646953873,0.0167182768108,-0.549176344648,-0.0445253,4190.0,5916.0,1726.0,4930.33333333,499.17888132,59164.0,5045.5,0.0,0.0,0.0,0.0,0.0,0.0,0.0
+16120160.0,1763.50000003,979.0,6.57642736476,235.0,381.0,146.0,314.098242132,15.9065125591,2215649.0,313.0,313.0,575.0,262.0,448.613836121,30.4507394301,3164522.0,445.0,613.0,955.0,342.0,783.258151403,48.4977279395,5525103.0,778.5,363.0,719.0,356.0,555.787212929,45.8908166749,3920523.0,553.0,0.0973006933928,0.286666661501,0.189365968108,0.170502321736,0.0239989402963,1202.72337753,0.166667,956.0,1643.0,687.0,1318.49929118,89.1848456974,9300694.0,1310.0,-0.0784606933594,1.19943237305,1.27789306641,0.188653105002,0.173891809855,1330.75900269,0.154877
+16057856.0,1564.50000003,834.0,5.94803252798,226.0,346.0,120.0,289.46548418,16.1649922427,1811475.0,289.0,276.0,528.0,252.0,414.364014062,31.6836864725,2593090.0,415.0,654.0,1121.0,467.0,886.202301055,62.3337211397,5545854.0,886.0,323.0,627.0,304.0,468.611057846,50.7827596027,2932568.0,467.0,0.18434163928,0.45100864768,0.2666670084,0.309246821622,0.0388754914582,1935.26660971,0.307809,871.0,1500.0,629.0,1172.44055609,96.6090909637,7337133.0,1170.5,-0.16796875,0.942901611328,1.11087036133,0.0807974386535,0.131406746488,505.630371094,0.0
+16043816.0,18.4999999993,19.0,1.24612843096,415.0,494.0,79.0,457.418918919,20.8041100128,33849.0,455.0,567.0,679.0,112.0,616.689189189,26.6832904874,45635.0,612.5,523.0,710.0,187.0,591.0,39.8564993513,43734.0,583.0,554.0,702.0,148.0,595.608108108,31.4710581618,44075.0,591.0,-0.0423509068787,0.0347826071084,0.0771335139871,-0.00429767546499,0.0166669860071,-0.318027984409,-0.00172712,1579.0,1772.0,193.0,1669.71621622,45.5170061092,123559.0,1664.5,-0.0124206542969,0.249298095703,0.26171875,0.0137898213155,0.0559042699551,1.02044677734,0.0
+16042033.0,20.7499999998,23.0,1.42434059904,210.0,251.0,41.0,238.265060241,8.41410797103,19776.0,239.0,259.0,345.0,86.0,314.951807229,17.0059547434,26141.0,316.0,643.0,1047.0,404.0,886.65060241,87.2563642495,73592.0,890.0,153.0,289.0,136.0,244.951807229,27.1017287558,20331.0,250.0,0.495126694441,0.663567185402,0.168440490961,0.566370708756,0.0392024238058,47.0087688267,0.56276,624.0,884.0,260.0,798.168674699,51.8042700192,66248.0,802.0,0.0733947753906,1.38720703125,1.31381225586,0.815577127847,0.370344420739,67.6929016113,0.926208
+16065277.0,1292.0,880.0,6.90631659796,214.0,370.0,156.0,267.327979876,17.5730071233,1381551.0,265.0,269.0,569.0,300.0,380.20626935,33.1333620699,1964906.0,376.0,599.0,1257.0,658.0,915.862422601,74.1780569288,4733177.0,918.0,205.0,695.0,490.0,376.329721362,59.6938042191,1944872.0,367.0,0.207853764296,0.578490912914,0.370637148619,0.419375837489,0.0566027332392,2167.33432814,0.424942,698.0,1631.0,933.0,1023.86397059,107.858739184,5291329.0,1008.0,-0.271881103516,1.30389404297,1.57577514648,0.0800952143713,0.156112285625,413.932067871,0.0
+16042854.0,803.500000008,536.0,5.33417079332,226.0,326.0,100.0,274.874611077,11.263275625,883447.0,275.0,299.0,481.0,182.0,384.755756067,19.8325070262,1236605.0,384.0,640.0,941.0,301.0,812.445239577,31.8487297624,2611199.0,811.0,256.0,523.0,267.0,377.975108899,33.2588797614,1214812.0,379.0,0.265700489283,0.51272726059,0.247026771307,0.365818464244,0.0344354020737,1175.74054408,0.361921,781.0,1330.0,549.0,1037.60547604,63.4011333978,3334864.0,1039.0,-0.143798828125,1.1955871582,1.33938598633,0.140365856956,0.171412093859,451.135864258,0.0839386
+16003739.0,3217.75000003,2333.0,11.6020212691,254.0,396.0,142.0,321.020822003,13.3561460817,4131859.0,321.0,357.0,628.0,271.0,478.972340921,23.2800393592,6164853.0,478.0,629.0,1039.0,410.0,798.610364385,41.3566354781,10278914.0,797.0,437.0,887.0,450.0,663.1968767,38.4726595108,8536007.0,663.0,0.0348387099802,0.205882355571,0.171043645591,0.0927851322421,0.0137319064221,1194.23743709,0.0914411,1052.0,1911.0,859.0,1463.19003962,70.974759265,18832719.0,1462.0,-0.285186767578,2.20910644531,2.49429321289,0.72815656273,0.457648233503,9372.1031189,0.711975
+16079384.0,5741.25000003,5678.0,21.1391357148,197.0,579.0,382.0,351.720226432,28.312820885,8077255.0,352.0,273.0,861.0,588.0,528.223165687,47.2067155621,12130645.0,531.0,506.0,1209.0,703.0,890.613934248,86.7851021651,20452949.0,898.0,253.0,1054.0,801.0,676.955584585,73.4070217515,15546285.0,684.0,-0.0411764718592,0.375308632851,0.41648510471,0.136742238434,0.0354261960527,3140.28550564,0.133615,771.0,2351.0,1580.0,1556.8989767,136.687481535,35754185.0,1568.0,-0.157928466797,3.02252197266,3.18045043945,0.1662073522,0.339887152897,3816.95184326,0.0
+15990927.0,44.7500000005,31.0,1.30725479049,232.0,310.0,78.0,260.843575419,11.8344304316,46691.0,260.0,286.0,461.0,175.0,350.508379888,25.41177502,62741.0,348.0,678.0,958.0,280.0,827.932960894,55.6603424176,148200.0,840.0,244.0,443.0,199.0,328.837988827,30.5211989408,58862.0,330.0,0.32572299242,0.524344563484,0.198621571064,0.431706165468,0.0327252314834,77.2754036188,0.438776,762.0,1185.0,423.0,940.189944134,61.3664486197,168294.0,938.0,0.0805358886719,2.65713500977,2.57659912109,1.78060162933,0.374112416004,318.72769165,1.85229
+15933574.0,2905.25000002,494.0,2.58541498704,284.0,433.0,149.0,361.571121246,15.093918946,4201818.0,360.0,408.0,665.0,257.0,549.490835556,27.3793561516,6385633.0,548.0,723.0,1079.0,356.0,902.53515188,40.1492749544,10488361.0,904.0,503.0,918.0,415.0,737.454694088,35.8228382723,8569961.0,738.0,0.0457516349852,0.200953140855,0.15520150587,0.100742257071,0.0107846373047,1170.72576942,0.100124,1195.0,1987.0,792.0,1648.51665089,74.8841781463,19157412.0,1647.0,-0.150787353516,3.11767578125,3.26846313477,0.104967375157,0.257071525724,1219.8258667,0.0
+15990671.0,3053.50000005,1020.0,5.20710430909,208.0,363.0,155.0,273.630014737,15.5597724954,3342117.0,273.0,263.0,555.0,292.0,382.583756345,27.7956822598,4672878.0,380.0,566.0,1116.0,550.0,854.728508269,44.4923660283,10439654.0,853.0,215.0,684.0,469.0,405.960864582,48.8232319915,4958406.0,403.0,0.215596333146,0.590449929237,0.374853596091,0.357621285006,0.0453833556605,4367.98637506,0.354337,686.0,1600.0,914.0,1062.17463566,90.4052755371,12973401.0,1055.0,-0.178894042969,1.25689697266,1.43579101562,0.0734470555449,0.143228306808,897.082336426,0.0
+15977884.0,76.0,71.0,2.29745292049,195.0,262.0,67.0,232.263157895,13.5545859603,70608.0,234.0,248.0,363.0,115.0,305.286184211,23.2143970453,92807.0,307.0,805.0,1267.0,462.0,1047.84210526,84.7654740774,318544.0,1040.5,167.0,339.0,172.0,254.898026316,36.4391092141,77489.0,257.5,0.514263689518,0.703287899494,0.189024209976,0.609609703092,0.037350689829,185.32134974,0.606721,610.0,952.0,342.0,792.447368421,71.544914994,240904.0,799.0,-0.0391540527344,0.946899414062,0.986053466797,0.034680215936,0.136622479264,10.5427856445,0.0
+15990215.0,3554.99999999,3542.0,16.7580631367,174.0,777.0,603.0,361.360056259,36.6358256486,5138540.0,361.0,259.0,1194.0,935.0,539.412165963,57.8973018322,7670441.0,542.0,442.0,1460.0,1018.0,884.699929677,113.232394427,12580433.0,899.0,246.0,1475.0,1229.0,678.986075949,88.6546330954,9655182.0,687.0,-0.0729411765933,0.439655184746,0.512596361339,0.131519718663,0.0451762466165,1870.21039938,0.132221,693.0,3446.0,2753.0,1579.75829817,163.761627876,22464163.0,1595.0,-0.315673828125,3.13018798828,3.44586181641,0.353232023988,0.643635230194,5022.9593811,0.0166168
+15933590.0,389.250000006,195.0,2.78814508242,197.0,289.0,92.0,242.868978805,12.113710648,378147.0,245.0,230.0,418.0,188.0,332.06807964,27.213218665,517030.0,336.0,681.0,1246.0,565.0,1006.47206166,69.6047195092,1567077.0,1015.0,144.0,414.0,270.0,290.212588311,36.2178046365,451861.0,294.0,0.429646342993,0.748633861542,0.318987518549,0.552801425249,0.0437887597619,860.711819112,0.547566,571.0,1121.0,550.0,865.149646757,72.6999629057,1347038.0,877.0,0.0,0.0,0.0,0.0,0.0,0.0,0.0
+15896170.0,30.2499999995,37.0,1.89772859922,328.0,480.0,152.0,403.157024793,40.5591106771,48782.0,402.0,467.0,707.0,240.0,592.776859504,54.6904871241,71726.0,586.0,601.0,847.0,246.0,722.181818182,49.6701516702,87384.0,717.0,546.0,788.0,242.0,691.41322314,48.0402154917,83661.0,697.0,-0.0296028889716,0.0846905559301,0.114293444902,0.0218362274959,0.0259165470275,2.642183527,0.0229111,1370.0,1923.0,553.0,1687.34710744,115.997272036,204169.0,1713.0,-0.0406494140625,2.23358154297,2.27423095703,1.39284446023,0.731990095228,168.534179688,1.81567
+15884654.0,74.75,76.0,2.47972238075,248.0,313.0,65.0,277.74916388,9.40436589904,83047.0,278.0,348.0,455.0,107.0,391.217391304,16.2788071972,116974.0,392.0,759.0,927.0,168.0,822.919732441,27.893854802,246053.0,825.0,337.0,503.0,166.0,400.508361204,25.4850424423,119752.0,401.0,0.296503484249,0.393177747726,0.0966742634773,0.345795577485,0.0170140783087,103.392877668,0.344743,933.0,1271.0,338.0,1069.47491639,50.3720791786,319773.0,1072.0,-0.0437927246094,0.844207763672,0.888000488281,0.18412581734,0.18830712998,55.0536193848,0.182526
+15879022.0,472.250000003,370.0,4.80298033789,243.0,323.0,80.0,271.286394918,9.20469131285,512460.0,271.0,321.0,456.0,135.0,371.030704076,15.8717434089,700877.0,369.0,593.0,831.0,238.0,691.71201694,34.51045627,1306644.0,687.0,346.0,586.0,240.0,428.073054526,27.7645885277,808630.0,425.0,0.172900497913,0.294949501753,0.122049003839,0.235759966253,0.0174331799158,445.350576252,0.235564,914.0,1365.0,451.0,1070.39015352,52.1625785276,2021967.0,1065.0,-0.000823974609375,1.55447387695,1.55529785156,0.514951076881,0.286462416918,972.742584229,0.509949
+15838185.0,5848.7499994,2872.0,10.5937074245,231.0,384.0,153.0,277.196537722,14.4419249101,6485013.0,275.0,318.0,550.0,232.0,386.575293866,25.2305802708,9043929.0,383.0,534.0,850.0,316.0,658.21688395,41.0576091864,15398984.0,655.0,394.0,669.0,275.0,535.472451378,39.221943971,12527378.0,531.0,0.0397236607969,0.286634474993,0.246910814196,0.103130475151,0.0220294685053,2412.73746616,0.0996564,948.0,1592.0,644.0,1199.24428297,71.7737525176,28056320.0,1190.0,-5.32345581055,335.319793701,340.643249512,3.8578509388,31.9478187519,90254.4227133,3.05176e-05
+15852743.0,2782.49999998,1623.0,8.67952585742,202.0,326.0,124.0,253.959748428,11.3942576579,2826572.0,252.0,288.0,460.0,172.0,345.019407008,19.6795071489,3840066.0,342.0,617.0,1025.0,408.0,773.391823899,46.4865690406,8607851.0,765.0,227.0,501.0,274.0,324.258221024,29.8270424174,3608994.0,320.0,0.252796411514,0.562198638916,0.309402227402,0.409469442323,0.0368679509669,4557.39489305,0.408915,764.0,1275.0,511.0,923.23737646,57.6444588356,10275632.0,915.0,-0.184387207031,1.57113647461,1.75552368164,0.113147104268,0.221908844966,1259.32727051,0.0
+15827617.0,13323.0000005,5852.0,14.3020526176,219.0,329.0,110.0,265.32609022,8.4660059563,14139758.0,265.0,271.0,448.0,177.0,353.505685656,14.6446969408,18839025.0,353.0,513.0,851.0,338.0,668.571342791,35.8652560392,35629504.0,669.0,227.0,533.0,306.0,360.276683179,24.4050405993,19199865.0,359.0,0.161016955972,0.454728364944,0.293711408973,0.299788358005,0.0269443296188,15976.3211748,0.299299,717.0,1292.0,575.0,979.108459056,45.743864169,52178648.0,976.0,-0.264099121094,2.3854675293,2.64956665039,0.271650775742,0.303372652921,14476.8131409,0.192184
+15807367.0,18.25,23.0,1.51876811017,286.0,377.0,91.0,354.01369863,14.0092857177,25843.0,355.0,398.0,588.0,190.0,539.95890411,27.9909174879,39417.0,544.0,1008.0,1210.0,202.0,1079.71232877,45.5864313663,78819.0,1068.0,425.0,761.0,336.0,668.397260274,49.1499633428,48793.0,673.0,0.176981538534,0.406838804483,0.229857265949,0.235956629458,0.034686150939,17.2248339504,0.233766,1109.0,1724.0,615.0,1562.36986301,89.5604956408,114053.0,1569.0,0.00778198242188,0.719604492188,0.711822509766,0.369692867749,0.210039434386,26.9875793457,0.373901
+15769003.0,99.5000000009,74.0,2.09273986499,194.0,294.0,100.0,248.33919598,17.374041208,98839.0,248.0,245.0,443.0,198.0,326.851758794,32.5430620696,130087.0,325.0,489.0,1131.0,642.0,880.590452261,118.108929406,350475.0,885.0,175.0,456.0,281.0,296.364321608,47.5046724326,117953.0,291.0,0.283547252417,0.669187128544,0.385639876127,0.494635299223,0.0661404340561,196.864849091,0.502265,640.0,1183.0,543.0,871.555276382,93.0194538998,346879.0,864.0,0.188232421875,3.0149230957,2.82669067383,2.08808346849,0.597843263046,831.057220459,2.40953
+15769399.0,43.9999999991,34.0,1.44593125944,207.0,266.0,59.0,239.755681818,10.7630719461,42197.0,240.5,265.0,355.0,90.0,317.4375,18.6116582019,55869.0,319.0,735.0,1024.0,289.0,924.017045455,57.378673821,162627.0,929.0,164.0,323.0,159.0,253.857954545,30.423100604,44679.0,256.0,0.427812218666,0.696014821529,0.268202602863,0.56944614107,0.0408929268476,100.222520828,0.573564,640.0,933.0,293.0,811.051136364,58.4887586214,142745.0,817.0,-0.0015869140625,0.7060546875,0.707641601562,0.206020702015,0.237363587036,36.2596435547,0.0761414
+15738641.0,290.749999998,198.0,3.27567191036,188.0,289.0,101.0,237.228718831,12.0822333124,275897.0,237.0,237.0,412.0,175.0,316.604471195,22.9767922232,368211.0,316.0,647.0,1285.0,638.0,1030.93121238,82.4032640967,1198973.0,1035.0,150.0,440.0,290.0,270.487532244,35.2912774515,314577.0,268.0,0.411051213741,0.727520406246,0.316469192505,0.584434426174,0.042459163005,679.697237641,0.583405,587.0,1140.0,553.0,824.32072227,67.3822234212,958685.0,821.0,-0.158630371094,1.39892578125,1.55755615234,0.241652327166,0.339731104209,281.041656494,0.0218506
+15722206.0,49.9999999995,33.0,1.31650952533,277.0,315.0,38.0,293.12,6.08240084177,58624.0,292.5,392.0,496.0,104.0,446.82,11.9204697894,89364.0,446.0,547.0,656.0,109.0,611625.0,17.5566048825,122325.0,612.0,520.0,642.0,122.0,604105.0,19.7604143428,120821.0,608.0,-0.0435510873795,0.0786324813962,0.122183568776,0.00625116984098,0.0202659240604,1.2502339682,0.0,1189.0,1406.0,217.0,1344045.0,28.3353661526,268809.0,1346.0,0.0,0.484283447266,0.484283447266,0.0808856201172,0.137891298509,16.1771240234,0.0
+15712923.0,32.2500000016,27.0,1.34120132144,378.0,416.0,38.0,395.093023256,8.42333585843,50967.0,394.0,569.0,637.0,68.0,598.868217054,13.7256506574,77254.0,598.0,667.0,799.0,132.0,708.325581395,26.8259283318,91374.0,710.0,663.0,775.0,112.0,705.19379845,23.7966441251,90970.0,700.0,-0.0130434781313,0.0216450225562,0.0346885006875,0.00214572401461,0.00843669775022,0.276798397885,0.0,1616.0,1811.0,195.0,1699.15503876,41.0996990902,219191.0,1696.0,3.14059448242,4.13247680664,0.991882324219,3.44533592047,0.24033949817,444.44833374,3.41553
+15659214.0,302.500000001,170.0,2.75728272496,193.0,283.0,90.0,241.290082645,12.7926625726,291961.0,242.0,219.0,384.0,165.0,314.771900826,23.124010716,380874.0,318.0,611.0,1198.0,587.0,959.371900826,84.817804952,1160840.0,963.5,132.0,354.0,222.0,257.419008264,35.1722627711,311477.0,261.0,0.461284995079,0.728115320206,0.266830325127,0.577375813087,0.0415045127255,698.624733835,0.57498,544.0,1021.0,477.0,813.480991736,69.583578753,984312.0,822.0,-0.103942871094,2.15197753906,2.25592041016,0.606262030483,0.570957759226,733.577056885,0.345642
+15667139.0,149.250000001,80.0,1.8472593995,436.0,701.0,265.0,571.420435511,38.8703008209,341138.0,576.0,620.0,1012.0,392.0,826.165829146,61.0208875312,493221.0,831.0,756.0,1183.0,427.0,927.949748744,63.4107147716,553986.0,922.0,654.0,1131.0,477.0,903.621440536,61.4211434299,539462.0,901.0,-0.0513833984733,0.13777191937,0.189155317843,0.0132664377176,0.0248792514414,7.9200633174,0.00813008,1710.0,2818.0,1108.0,2301.20770519,144.212783909,1373821.0,2302.0,0.0074462890625,4.63723754883,4.62979125977,3.52954014662,1.02840009893,2107.13546753,3.96286
+15667837.0,4.75000000023,13.0,1.68264157553,237.0,367.0,130.0,271.842105263,32.3700042403,5165.0,267.0,287.0,482.0,195.0,322.473684211,49.5648096951,6127.0,305.0,350.0,601.0,251.0,456.210526316,67.5196493407,8668.0,436.0,174.0,399.0,225.0,253.578947368,66.9802137237,4818.0,235.0,0.151965990663,0.413290113211,0.261324122548,0.293798005895,0.0702215774716,5.582162112,0.308562,707.0,1248.0,541.0,847.894736842,140.452986979,16110.0,780.0,-0.0853881835938,2.78900146484,2.87438964844,0.401526200144,0.585247750167,7.62899780273,0.264618
+15635236.0,454.000000007,530.0,7.01686322431,263.0,427.0,164.0,347.930066079,24.999759012,631841.0,348.5,360.0,676.0,316.0,522.648127753,46.0039631124,949129.0,524.0,661.0,1337.0,676.0,1014.97742291,79.4865269744,1843199.0,1014.0,398.0,898.0,500.0,653.896475771,78.0836856838,1187476.0,658.0,0.123610205948,0.408886015415,0.285275809467,0.218018270779,0.0408587814928,395.921179734,0.211297,1023.0,2001.0,978.0,1524.4746696,145.160603057,2768446.0,1531.5,-0.0805053710938,0.793487548828,0.873992919922,0.0454106267853,0.0936329118474,82.4656982422,0.0
+15672977.0,1416.24999997,1113.0,8.34296210375,202.0,342.0,140.0,263.21200353,11.6891511606,1491096.0,262.0,266.0,499.0,233.0,355.05772286,20.0815817333,2011402.0,352.0,507.0,1036.0,529.0,746.017475728,53.2391949099,4226189.0,743.0,227.0,575.0,348.0,376.937511033,36.6782914815,2135351.0,373.0,0.198222219944,0.453437775373,0.255215555429,0.328919851667,0.0434319326537,1863.33095969,0.329352,717.0,1416.0,699.0,995.207237423,66.3604358773,5637849.0,987.0,-0.1796875,1.86822509766,2.04791259766,0.450939408089,0.291029098833,2554.57174683,0.431213
+15652234.0,124.999999996,97.0,2.4474385464,367.0,487.0,120.0,437042.0,21.3445130186,218521.0,437.0,573.0,786.0,213.0,700822.0,38.4038841265,350411.0,704.0,942.0,1224.0,282.0,1104684.0,49.2371825352,552342.0,1111.0,742.0,1032.0,290.0,921.41,49.9797348933,460705.0,923.5,0.0664240196347,0.14167098701,0.0752469673753,0.0906919507682,0.00858317900049,45.3459753841,0.0899596,1711.0,2290.0,579.0,2059274.0,106.868400025,1029637.0,2065.5,-0.0531616210938,0.455749511719,0.508911132812,0.128884155273,0.130371151184,64.4420776367,0.11087
+15650351.0,74.2500000016,48.0,1.57140480348,196.0,277.0,81.0,243.067340067,14.7199048908,72191.0,245.0,234.0,391.0,157.0,321.703703704,27.3499534298,95546.0,324.0,716.0,1194.0,478.0,980.292929293,84.7861146427,291147.0,985.0,135.0,373.0,238.0,275.952861953,42.5739736523,81958.0,283.0,0.466776043177,0.725330591202,0.258554548025,0.562334367121,0.0430942549481,167.013307035,0.556962,565.0,1036.0,471.0,840.723905724,84.0756705875,249695.0,853.0,-0.0687866210938,1.1442565918,1.21304321289,0.271488896123,0.212479133013,80.6322021484,0.225983
+15671893.0,286.000000004,134.0,2.23520237273,310.0,485.0,175.0,380.351398601,27.0826037913,435122.0,377.0,457.0,762.0,305.0,577.651223776,48.7728415046,660833.0,572.5,776.0,1182.0,406.0,945.088286713,64.0088914486,1081181.0,938.0,560.0,1019.0,459.0,766.483391608,66.2415035087,876857.0,763.0,0.0652291104198,0.162303671241,0.0970745608211,0.105038197639,0.0148182947064,120.1636981,0.103099,1328.0,2266.0,938.0,1724.48601399,139.947698073,1972812.0,1711.5,-0.0515747070312,0.732788085938,0.784362792969,0.346266046271,0.174089984903,396.128356934,0.356155
+15633436.0,308.250000011,313.0,5.02907211047,216.0,325.0,109.0,262.113544201,11.7434768631,323186.0,262.0,271.0,465.0,194.0,362.00081103,20.680887486,446347.0,363.0,738.0,1107.0,369.0,953.492295215,52.6782470314,1175656.0,957.0,197.0,457.0,260.0,330.875101379,32.2794565251,407969.0,332.0,0.390519201756,0.593814432621,0.203295230865,0.485456413741,0.0298229826029,598.567758143,0.485452,684.0,1247.0,563.0,954.98945661,62.4868314623,1177502.0,956.0,-0.0531616210938,1.29763793945,1.35079956055,0.135695854243,0.201597521814,167.312988281,0.0864868
+15601631.0,821.74999999,572.0,5.62887028202,221.0,375.0,154.0,277.62853666,16.3386678375,912565.0,277.0,287.0,546.0,259.0,389.998783085,28.0947373515,1281926.0,389.0,685.0,1102.0,417.0,865.968360207,55.697930112,2846438.0,862.0,285.0,701.0,416.0,432.35898996,47.2936325128,1421164.0,430.0,0.211058661342,0.468774706125,0.257716044784,0.335042830687,0.0417340093937,1101.28578447,0.337052,798.0,1622.0,824.0,1099.9863097,88.9877845196,3615655.0,1098.0,-0.195343017578,1.71728515625,1.91262817383,0.129231656327,0.220144001085,424.784454346,0.0472107
+15601936.0,183.250000014,163.0,3.39672729205,185.0,281.0,96.0,233.971350614,15.9242064943,171501.0,234.0,225.0,391.0,166.0,300.39154161,32.4893229929,220187.0,300.0,525.0,1089.0,564.0,811.93042292,124.832413998,595145.0,816.0,130.0,395.0,265.0,246.508867667,45.4927125232,180691.0,246.0,0.387423932552,0.669683277607,0.282259345055,0.534374164893,0.0456928419602,391.696262866,0.537159,540.0,1065.0,525.0,780.871759891,92.4184382529,572379.0,779.0,-0.0408630371094,2.15414428711,2.19500732422,1.00021279037,0.567631930341,733.155975342,1.25308
+15610405.0,1868.0,1351.0,8.81783526494,217.0,369.0,152.0,292.934288009,17.7454971194,2188805.0,292.0,283.0,571.0,288.0,415.508163812,31.0795361482,3104677.0,414.0,658.0,1226.0,568.0,911.394673448,66.4233058131,6809941.0,915.0,238.0,675.0,437.0,440.113490364,48.7443948353,3288528.0,437.0,0.194071978331,0.517441868782,0.323369890451,0.349507731336,0.0413261717716,2611.52176854,0.349908,738.0,1615.0,877.0,1148.55594218,94.9185020482,8582010.0,1144.0,-0.107482910156,1.84735107422,1.95483398438,0.12668467487,0.165238283445,946.587890625,0.0774231
+15586981.0,3.75,10.0,1.45673124079,194.0,262.0,68.0,222.866666667,19.5954643278,3343.0,220.0,248.0,326.0,78.0,279.666666667,23.8681563781,4195.0,276.0,702.0,876.0,174.0,742.8,48.0668978265,11142.0,718.0,138.0,299.0,161.0,202.2,45.8725771386,3033.0,197.0,0.45036765933,0.692307710648,0.241940051317,0.575763130188,0.0690432609974,8.63644695282,0.588367,580.0,887.0,307.0,704.733333333,88.3519225723,10571.0,689.0,0.184112548828,0.262268066406,0.0781555175781,0.220576985677,0.0248012807381,3.30865478516,0.217896
+15540617.0,2289.99999998,1557.0,9.17837799552,253.0,387.0,134.0,331.265065502,13.155579042,3034388.0,331.0,377.0,600.0,223.0,492.729912664,23.9949726447,4513406.0,492.0,683.0,1083.0,400.0,833.587445415,42.7199241177,7635661.0,831.0,467.0,872.0,405.0,678.635152838,40.95732506,6216298.0,679.0,0.0399100631475,0.276045620441,0.236135557294,0.102693599428,0.018984186676,940.673370764,0.0988701,1097.0,1858.0,761.0,1502.630131,76.0156419808,13764092.0,1504.0,-0.121124267578,1.32089233398,1.44201660156,0.33117361277,0.22492276914,3033.55029297,0.326599
+15571989.0,4037.24999999,2752.0,12.2180156181,301.0,520.0,219.0,422.058517555,21.6962173399,6815823.0,422.0,443.0,844.0,401.0,659.558300824,39.7456900946,10651207.0,657.0,786.0,1328.0,542.0,1046.27438231,57.5443124769,16896285.0,1042.0,516.0,1176.0,660.0,862.265155737,58.0939462856,13924720.0,858.0,0.027624309063,0.242060691118,0.214436382055,0.0967726394856,0.0154405006078,1562.78135505,0.0958118,1260.0,2534.0,1274.0,1943.88197412,116.620989008,31391750.0,1936.0,-0.166137695312,1.02279663086,1.18893432617,0.100211840634,0.126113843112,1618.3210144,0.0557251
+15602575.0,5133.49999997,2286.0,9.00045595305,206.0,356.0,150.0,269.488068569,15.4759882707,5533668.0,269.0,283.0,499.0,216.0,376.683549235,28.3881266729,7734820.0,376.0,615.0,1077.0,462.0,825.974286549,65.1465462307,16960556.0,825.0,231.0,720.0,489.0,407.805298529,48.5777267717,8373874.0,405.0,0.159303888679,0.517745316029,0.35844142735,0.339627449791,0.0505451363304,6973.91005401,0.338028,720.0,1555.0,835.0,1053.97691633,89.5351117463,21642362.0,1049.0,-0.0797119140625,2.06753540039,2.14724731445,0.396589143002,0.336579368384,8143.5614624,0.354095
+15513522.0,661.499999987,333.0,3.65236672302,210.0,305.0,95.0,265.646636432,13.9216928486,702901.0,265.0,288.0,463.0,175.0,387.795540438,24.7711550745,1026107.0,389.0,783.0,1167.0,384.0,986.575207861,55.5069079534,2610478.0,990.0,185.0,461.0,276.0,339.70143613,37.9533774069,898850.0,340.0,0.391845196486,0.641472876072,0.249627679586,0.488860817025,0.0332019439428,1293.52572185,0.487038,683.0,1228.0,545.0,993.143613001,75.6540976381,2627858.0,995.0,-0.252380371094,3.95309448242,4.20547485352,2.0564600223,1.0983508828,5441.39321899,2.40459
+15523244.0,43.7499999986,49.0,2.08978746254,311.0,599.0,288.0,463.314285714,58.3055848482,81080.0,458.0,396.0,850.0,454.0,637.777142857,81.8773406146,111611.0,634.0,550.0,957.0,407.0,747.954285714,79.2408853447,130892.0,749.0,442.0,869.0,427.0,668.457142857,85.7488501738,116980.0,671.0,-0.0208183769137,0.220028206706,0.24084658362,0.0574144725069,0.0508052737774,10.0475326887,0.0432234,1257.0,2294.0,1037.0,1769.54857143,203.097996574,309671.0,1767.0,0.0559997558594,1.46606445312,1.41006469727,0.38930507115,0.12422977141,68.1283874512,0.376526
+15509934.0,5.5,11.0,1.3231418571,306.0,314.0,8.0,310.272727273,2.19879756772,6826.0,310.0,470.0,496.0,26.0,483.545454545,6.26481714691,10638.0,483.0,346.0,405.0,59.0,377.090909091,15.3768098444,8296.0,379.5,541.0,570.0,29.0,558.090909091,8.81068097105,12278.0,560.5,-0.239560440183,-0.155227035284,0.0843334048986,-0.193786302751,0.0225612753273,-4.26329866052,-0.188537,1319.0,1380.0,61.0,1351.90909091,16.351005226,29742.0,1356.0,0.0,0.0148620605469,0.0148620605469,0.000675548206676,0.00309575079269,0.0148620605469,0.0
+15490750.0,10.0,17.0,1.51650549873,204.0,336.0,132.0,291.65,34.6183116284,11666.0,299.0,267.0,484.0,217.0,416225.0,60.2156489212,16649.0,424.5,472.0,784.0,312.0,679475.0,89.5293213143,27179.0,700.5,238.0,598.0,360.0,485.4,100.794791532,19416.0,510.0,0.113865219057,0.330520391464,0.216655172408,0.17491653394,0.0548720982088,6.99666135758,0.156784,709.0,1414.0,705.0,1193275.0,195.153912016,47731.0,1227.5,-0.000823974609375,1.55834960938,1.55917358398,1.15589752197,0.584943326538,46.2359008789,1.44487
+15467389.0,7.99999999907,17.0,1.6955046918,195.0,377.0,182.0,237.15625,38.6499590677,7589.0,229.5,212.0,465.0,253.0,292625.0,55.86241469,9364.0,288.0,429.0,738.0,309.0,539875.0,70.6809512882,17276.0,534.0,237.0,631.0,394.0,351.25,76.4538259344,11240.0,334.0,0.0781592428684,0.288288295269,0.210129052401,0.216700645862,0.0431585926388,6.93442066759,0.224319,736.0,1473.0,737.0,881.03125,154.736567344,28193.0,838.0,-0.0192260742188,0.677307128906,0.696533203125,0.0563659667969,0.176664936577,1.8037109375,0.0
+15483707.0,1973.50000001,1311.0,8.32490323791,253.0,384.0,131.0,313.2332151,14.2879098985,2472663.0,313.0,342.0,574.0,232.0,454.29364074,25.3635520398,3586194.0,453.0,622.0,1004.0,382.0,785.821763365,46.8347501409,6203277.0,783.0,379.0,810.0,431.0,614.766278186,42.0280978185,4852965.0,614.0,0.0600126348436,0.246357619762,0.186344984919,0.122369099122,0.0215182542394,965.981668472,0.118532,1014.0,1759.0,745.0,1382.29313403,78.7749322618,10911822.0,1380.0,-0.114105224609,1.70309448242,1.81719970703,0.121563965802,0.137376613242,959.625946045,0.0829163
+15453984.0,3876.74999999,2380.0,10.7829633045,215.0,354.0,139.0,274.911136906,14.138358472,4263047.0,274.0,298.0,532.0,234.0,396.915264074,25.6294218355,6154965.0,395.0,623.0,1178.0,555.0,838.148449088,54.7054667632,12997168.0,832.0,267.0,659.0,392.0,431.180305668,41.7824978218,6686313.0,428.0,0.189920097589,0.462978035212,0.273057937622,0.321352430942,0.0330321220039,4983.21214661,0.322449,787.0,1519.0,732.0,1103.00670665,79.9819122933,17104325.0,1097.0,-0.302337646484,1.14413452148,1.44647216797,0.0499661293652,0.118754349972,774.824768066,0.0
+15445003.0,130.499999999,51.0,1.25938926843,284.0,385.0,101.0,338.954022989,13.3152820732,176934.0,342.0,359.0,535.0,176.0,477.727969349,27.4808666162,249374.0,487.0,399.0,672.0,273.0,507.791187739,25.4703734237,265067.0,508.0,323.0,570.0,247.0,402.189655172,24.8618490964,209943.0,399.0,0.0105017507449,0.19957536459,0.189073613845,0.116239766317,0.0227770250455,60.6771580176,0.118377,973.0,1488.0,515.0,1218.87164751,53.6616046799,636251.0,1226.0,-0.081298828125,5.40307617188,5.484375,4.36241488987,0.998447514642,2277.18057251,4.56654
+15424561.0,28.2500000009,52.0,2.75987355779,306.0,345.0,39.0,324.407079646,7.59557063304,36658.0,323.0,460.0,533.0,73.0,489.884955752,14.2895172992,55357.0,489.0,779.0,911.0,132.0,829.300884956,24.8221585834,93711.0,829.0,665.0,791.0,126.0,712.353982301,25.4558164343,80496.0,711.0,0.057704500854,0.0907894745469,0.0330849736929,0.0759479889432,0.00730059088351,8.58212275058,0.0759413,1441.0,1667.0,226.0,1526.6460177,45.294888331,172511.0,1525.0,-0.0328369140625,0.650146484375,0.682983398438,0.0926959282529,0.159687984618,10.4746398926,0.0
+15394478.0,22.5,24.0,1.42729929292,322.0,412.0,90.0,372.933333333,15.7005307766,33564.0,374.5,471.0,596.0,125.0,558.022222222,24.3570559149,50222.0,564.0,643.0,854.0,211.0,719.366666667,34.2800395436,64743.0,714.5,600.0,767.0,167.0,710.9,34.7904999804,63981.0,720.5,-0.0247823167592,0.0810126587749,0.105794975534,0.0059905643148,0.0205738167886,0.539150788332,0.0,1393.0,1769.0,376.0,1641.85555556,69.2248447871,147767.0,1658.5,-0.0556030273438,0.00100708007812,0.0566101074219,-0.0018069797092,0.00830586906344,-0.162628173828,0.0
+15409429.0,3515.74999997,2558.0,12.1698889527,179.0,1053.0,874.0,357.910474294,49.2592142687,5033295.0,353.0,231.0,1638.0,1407.0,524.248097845,73.846735562,7372501.0,523.0,393.0,2572.0,2179.0,835.444499751,127.775407171,11748856.0,837.0,162.0,2829.0,2667.0,640.928820309,102.416894141,9013382.0,651.0,-0.0653643906116,0.453551918268,0.51891630888,0.131957973432,0.0603117998575,1855.72498037,0.135908,623.0,5520.0,4897.0,1523.08739245,200.45471199,21419178.0,1541.0,-0.353149414062,3.49569702148,3.84884643555,0.550229262248,0.868566564161,7737.87411499,0.092926
+15405252.0,7368.49999999,4011.0,13.1812982265,209.0,378.0,169.0,263.627536134,13.922371626,7770158.0,262.0,270.0,549.0,279.0,363.535251408,25.1359996779,10714838.0,361.0,545.0,1248.0,703.0,877.843455249,61.5411202613,25873558.0,879.0,188.0,643.0,455.0,337.085431228,40.6604634477,9935256.0,333.0,0.256843328476,0.63603925705,0.379195928574,0.445745354243,0.0452331621537,13137.898571,0.445969,676.0,1561.0,885.0,964.248218769,77.9348519547,28420252.0,955.0,-0.145355224609,5.08758544922,5.23294067383,0.151454804653,0.342434375671,4463.97891235,0.046051
+15422019.0,1030.25000002,410.0,3.60335966699,228.0,294.0,66.0,258.847852463,8.05738945006,1066712.0,258.0,303.0,424.0,121.0,367.310361563,14.0649518332,1513686.0,367.0,811.0,1151.0,340.0,939.593545256,44.4567035741,3872065.0,936.0,240.0,450.0,210.0,341.132977433,26.3213261949,1405809.0,341.0,0.366762191057,0.594594597816,0.227832406759,0.467225258905,0.0358100653225,1925.43529195,0.462735,781.0,1156.0,375.0,967.291191458,46.1221450244,3986207.0,966.0,-0.168792724609,1.9387512207,2.10754394531,0.405531559486,0.407655819936,1671.19555664,0.317139
+15413318.0,49.5,40.0,1.60380831164,337.0,456.0,119.0,399.595959596,21.7048238328,79120.0,397.5,516.0,720.0,204.0,623.661616162,41.5459055029,123485.0,625.0,890.0,1170.0,280.0,1055.80808081,53.8465227801,209050.0,1061.5,583.0,918.0,335.0,790.858585859,66.1173597066,156590.0,800.5,0.0669772848487,0.224885851145,0.157908566296,0.144400046856,0.0354605618305,28.5912092775,0.137452,1436.0,2088.0,652.0,1814.11616162,125.632869185,359195.0,1828.5,-0.0180969238281,0.723815917969,0.741912841797,0.0743856719046,0.170045830305,14.7283630371,0.0
+15371066.0,78.499999996,70.0,2.22873421159,304.0,320.0,16.0,312.261146497,3.21153672131,98050.0,312.0,475.0,503.0,28.0,489.665605096,5.32267368971,153755.0,490.0,378.0,411.0,33.0,395.455414013,5.4917064848,124173.0,396.0,531.0,572.0,41.0,551.952229299,8.96033073482,173313.0,552.0,-0.178053826094,-0.151003167033,0.0270506590605,-0.165160612411,0.00623670308638,-51.860432297,-0.166052,1311.0,1390.0,79.0,1353.87898089,16.0853021959,425118.0,1352.0,0.0,0.0,0.0,0.0,0.0,0.0,0.0
+15373982.0,2565.25000002,1689.0,9.40718899754,201.0,339.0,138.0,273.443913849,16.0076453704,2805808.0,273.0,271.0,509.0,238.0,392.215086249,28.5467493664,4024519.0,394.0,671.0,1206.0,535.0,928.788909463,61.2913568436,9530303.0,929.0,179.0,622.0,443.0,403.426664068,47.9517917944,4139561.0,402.0,0.199121519923,0.634815514088,0.435693994164,0.395518570932,0.0444313079356,4058.41605633,0.394312,651.0,1466.0,815.0,1069.08566417,89.6331116189,10969888.0,1068.0,-0.153167724609,2.28256225586,2.43572998047,0.128092036495,0.245431802996,1314.35238647,3.05176e-05
+15345574.0,1901.49999996,702.0,4.54133997356,244.0,364.0,120.0,304.005653432,15.8616684666,2312267.0,304.0,330.0,545.0,215.0,434.30909808,28.1844305136,3303355.0,435.0,607.0,1055.0,448.0,830.961346306,49.5148944725,6320292.0,830.0,311.0,681.0,370.0,511.161714436,49.6868223679,3887896.0,513.0,0.118219748139,0.452006995678,0.333787247539,0.239293696859,0.0403558254941,1820.06785831,0.237953,903.0,1581.0,678.0,1249.47646595,91.2302289752,9503518.0,1252.0,-0.139984130859,3.03561401367,3.17559814453,0.0794757779824,0.195400015562,604.492767334,0.0
+15321846.0,24.5000000005,29.0,1.65276087593,199.0,271.0,72.0,248.265306122,11.7877063428,24330.0,251.0,260.0,377.0,117.0,341.418367347,20.984407948,33459.0,344.0,758.0,1077.0,319.0,967.102040816,61.7285846193,94776.0,971.5,175.0,356.0,181.0,307.224489796,31.9612426683,30108.0,314.0,0.472307682037,0.629629611969,0.157321929932,0.518774635025,0.0298159477519,50.8399142325,0.513811,634.0,1004.0,370.0,896.908163265,63.4067025902,87897.0,908.0,0.0976257324219,3.45983886719,3.36221313477,0.558564789441,0.734035750512,54.7393493652,0.36467
+15336388.0,3112.99999998,1896.0,9.58614161863,206.0,318.0,112.0,245.478316736,9.40589494641,3056696.0,246.0,248.0,438.0,190.0,328.264294892,17.5858483663,4087547.0,329.0,573.0,1097.0,524.0,854.693703823,61.4984726764,10642646.0,855.0,148.0,442.0,294.0,268.62921619,25.5383366881,3344971.0,269.0,0.344687759876,0.686311781406,0.34162402153,0.521522089726,0.0358528509067,6493.99306127,0.520958,613.0,1198.0,585.0,842.371827819,50.7672378087,10489214.0,844.0,-0.218780517578,2.46112060547,2.67990112305,0.631724962038,0.506553520728,7866.23922729,0.562256
+15295290.0,1953.0,797.0,5.08747476147,233.0,363.0,130.0,288.368535586,16.6392785184,2252735.0,287.0,317.0,547.0,230.0,416.896441372,29.3118533041,3256795.0,414.0,746.0,1176.0,430.0,947.16077829,55.3343050255,7399220.0,944.0,291.0,681.0,390.0,445.769457245,52.6037508866,3482351.0,442.0,0.22126929462,0.52192980051,0.300660505891,0.36142432465,0.0427107635685,2823.44682416,0.359676,841.0,1569.0,728.0,1151.0344342,97.1702570241,8991881.0,1143.0,-0.121124267578,1.42095947266,1.54208374023,0.108614545081,0.136147037321,848.496826172,0.0731354
+15298244.0,8720.74999996,4376.0,13.218904438,340.0,450.0,110.0,354.776682051,3.98880536956,12375675.0,355.0,577.0,765.0,188.0,600.871083336,6.75309232809,20960186.0,601.0,458.0,614.0,156.0,479.090244532,6.19110072932,16712105.0,479.0,640.0,925.0,285.0,676.597311011,9.89512188609,23601744.0,676.0,-0.20207926631,-0.145597204566,0.0564820617437,-0.170886220963,0.00402815840653,-5961.02404587,-0.170994,1564.0,2136.0,572.0,1632.2450764,19.3836971148,56937605.0,1631.0,-0.457427978516,4.82794189453,5.28536987305,0.458396249137,0.718449174723,15990.2363586,0.00100708
+15265259.0,95.7500000037,83.0,2.39278550429,264.0,354.0,90.0,306.362924282,18.4876328379,117337.0,305.0,340.0,497.0,157.0,418.997389034,30.1807867483,160476.0,419.0,561.0,841.0,280.0,694.088772846,57.3704234561,265836.0,690.0,378.0,680.0,302.0,516.924281984,55.6812732295,197982.0,514.0,0.0633363053203,0.244444444776,0.181108139455,0.147345209324,0.0283740333433,56.4332151711,0.146119,994.0,1497.0,503.0,1242.2845953,101.09721789,475795.0,1241.0,-0.003173828125,2.34683227539,2.35000610352,0.950575865902,0.691481164977,364.070556641,1.31339
+15257903.0,703.000000012,325.0,3.45780713775,242.0,418.0,176.0,338.677809388,23.1244399056,952362.0,338.0,306.0,643.0,337.0,508.804765292,43.3116161547,1430759.0,509.0,711.0,1198.0,487.0,919.007112376,66.8001037516,2584248.0,911.0,402.0,886.0,484.0,680.713015647,58.3858365065,1914165.0,682.0,0.0955120846629,0.311842113733,0.21633002907,0.149406970681,0.0273772977208,420.132401556,0.141515,950.0,1947.0,997.0,1528.19559033,119.713195114,4297286.0,1531.0,-0.121124267578,1.09216308594,1.21328735352,0.0637455447809,0.115616472886,179.252471924,0.0
+15245099.0,6.99999999907,18.0,1.91919256773,310.0,320.0,10.0,314.214285714,2.85803557482,8798.0,314.0,487.0,504.0,17.0,497.321428571,4.14947132113,13925.0,497.5,368.0,386.0,18.0,377.285714286,4.32482157235,10564.0,377.0,563.0,591.0,28.0,578.0,6.81385143869,16184.0,577.5,-0.213552355766,-0.205366358161,0.00818599760532,-0.210106318018,0.00215833286091,-5.88297690451,-0.209929,1360.0,1413.0,53.0,1389.53571429,12.6927486128,38907.0,1389.0,0.0,0.0,0.0,0.0,0.0,0.0,0.0
+15233444.0,239.999999998,134.0,2.44002482833,211.0,317.0,106.0,251.840625,15.3340788641,241767.0,249.5,251.0,462.0,211.0,332.770833333,33.8956976027,319460.0,329.0,544.0,1059.0,515.0,830.53125,84.6708889767,797310.0,844.5,171.0,491.0,320.0,296.364583333,50.0867829771,284510.0,290.0,0.344151467085,0.584541082382,0.240389615297,0.476190863084,0.042620145792,457.143228561,0.475482,633.0,1270.0,637.0,880.976041667,97.9256970071,845737.0,870.0,-0.0922241210938,2.67739868164,2.76962280273,1.16310377121,1.01377042835,1116.57962036,0.555008
+15208133.0,828.499999996,356.0,3.48898264831,225.0,345.0,120.0,270.051901026,15.3753585807,894952.0,268.0,311.0,522.0,211.0,388.110742305,26.4666832478,1286199.0,385.0,771.0,1240.0,469.0,993.070307785,79.935294854,3291035.0,1001.0,232.0,612.0,380.0,383.023234762,48.0947854965,1269339.0,377.0,0.327079415321,0.57037037611,0.243290960789,0.444299623388,0.0369905676814,1472.40895191,0.444624,774.0,1478.0,704.0,1041.18587809,88.3626072602,3450490.0,1028.0,-0.0742492675781,1.14181518555,1.21606445312,0.085732790959,0.152232471263,284.118469238,0.0205383
+15207820.0,77.4999999998,37.0,1.18562115772,334.0,412.0,78.0,373.5,12.9137960737,115785.0,374.0,473.0,619.0,146.0,553.425806452,28.5833130627,171562.0,551.0,572.0,812.0,240.0,680.503225806,52.4766460122,210956.0,677.0,576.0,779.0,203.0,670.548387097,46.6048860166,207870.0,663.5,-0.0263157896698,0.063523247838,0.0898390375078,0.0070898440152,0.0157448876741,2.19785164471,0.00403285,1399.0,1797.0,398.0,1597.47419355,85.0898821465,495217.0,1591.5,-0.00955200195312,4.97402954102,4.98358154297,3.98832673104,1.23404695865,1236.38128662,4.32712
+15272351.0,7523.24999999,4677.0,15.2110674107,258.0,456.0,198.0,354.590170472,17.2684702723,10670682.0,353.0,386.0,713.0,327.0,542.214867245,29.0925007083,16316872.0,542.0,695.0,1160.0,465.0,901.834945004,43.6855777914,27138919.0,900.0,443.0,985.0,542.0,734.397301698,45.0208279542,22100218.0,734.0,0.0380859375,0.272849470377,0.234763532877,0.102661501215,0.0171966582496,3089.39255606,0.101317,1087.0,2136.0,1049.0,1631.20233941,81.6662478188,49087772.0,1631.0,-0.222808837891,1.00866699219,1.23147583008,0.149721660987,0.159690861072,4505.57394409,0.107788
+15172508.0,2724.24999998,1003.0,5.42091404679,186.0,289.0,103.0,240.387537854,11.103980288,2619503.0,242.0,226.0,416.0,190.0,339.755161971,26.8965825233,3702312.0,346.0,743.0,1329.0,586.0,1064.80315683,88.1995403721,11603160.0,1069.0,118.0,388.0,270.0,270.949343856,30.9521236391,2952535.0,276.0,0.473601251841,0.770551025867,0.296949774027,0.59439868985,0.0348031089896,6477.1625233,0.592463,543.0,1090.0,547.0,851.092043682,66.6755608855,9274350.0,865.0,-0.142974853516,6.5895690918,6.73254394531,0.513263050915,1.18366146339,5593.02746582,0.0630493
+15161378.0,22.4999999993,32.0,1.90306572393,227.0,285.0,58.0,251.255555556,10.4865640079,22613.0,252.0,303.0,407.0,104.0,344.877777778,20.1013143726,31039.0,346.5,858.0,1191.0,333.0,1038.05555556,65.763779479,93425.0,1034.0,213.0,372.0,159.0,287.677777778,29.4376281418,25891.0,288.5,0.501769304276,0.64735096693,0.145581662655,0.566319462988,0.0306309203935,50.9687516689,0.566492,743.0,1064.0,321.0,883.811111111,58.8039859655,79543.0,886.5,-0.0562744140625,0.673095703125,0.729370117188,0.112118530273,0.164385290724,10.0906677246,0.0312042
+15135734.0,3.0,8.0,1.30294003174,183.0,265.0,82.0,205.833333333,20.448444657,2470.0,199.5,259.0,358.0,99.0,280.916666667,24.6625841216,3371.0,276.0,352.0,525.0,173.0,407.0,40.8411557133,4884.0,402.0,200.0,397.0,197.0,251.416666667,47.2995037559,3017.0,238.5,0.138828635216,0.275362312794,0.136533677578,0.240607053041,0.0342541975665,2.8872846365,0.244243,642.0,1020.0,378.0,738.166666667,91.4401747349,8858.0,710.0,2.45913696289,4.0461730957,1.58703613281,3.89885203044,0.434184182612,46.7862243652,4.02979
+15129623.0,27.2500000009,29.0,1.56714727759,295.0,369.0,74.0,331.844036697,17.9761178529,36171.0,332.0,427.0,591.0,164.0,514.23853211,38.4604882636,56052.0,511.0,843.0,1092.0,249.0,994.688073394,60.0539050282,108421.0,1007.0,720.0,930.0,210.0,834.311926606,50.5762567581,90940.0,840.0,0.0590809620917,0.117287382483,0.0582064203918,0.087670425312,0.0117435940684,9.556076359,0.0868516,1508.0,1881.0,373.0,1680.39449541,97.7861379595,183163.0,1674.0,-3.0517578125e-05,-3.0517578125e-05,0.0,-3.0517578125e-05,0.0,-0.00332641601562,-3.05176e-05
+15159705.0,4732.74999998,2138.0,8.76689866767,205.0,344.0,139.0,269.787649886,13.0001327741,5107350.0,268.0,282.0,517.0,235.0,379.730283662,23.0871746637,7188674.0,377.0,521.0,940.0,419.0,670.953515398,43.2826553831,12701821.0,667.0,291.0,704.0,413.0,456.857799377,40.1070375987,8648775.0,451.0,0.0812286660075,0.364628821611,0.283400155604,0.190409861329,0.0347440842242,3604.64908481,0.189802,784.0,1550.0,766.0,1106.37573292,74.1592512721,20944799.0,1096.0,-0.331573486328,1.85025024414,2.18182373047,0.0737972943632,0.151917421738,1397.05657959,0.0
+15136726.0,1577.75000004,863.0,6.12895975007,238.0,375.0,137.0,310.716843606,16.137437562,1960934.0,312.0,308.0,563.0,255.0,446.534780542,28.3718660253,2818081.0,448.0,577.0,1101.0,524.0,876.563777531,63.4247065826,5531994.0,878.0,298.0,700.0,402.0,544.98051022,49.0530202555,3439372.0,548.0,0.119631901383,0.396449714899,0.276817813516,0.233590183217,0.0388710372481,1474.18764628,0.230435,859.0,1587.0,728.0,1302.23213437,89.6955615435,8218387.0,1308.0,-0.121520996094,2.25173950195,2.37326049805,0.174838275695,0.247764817582,1103.40435791,0.0888977
+15047215.0,2732.74999998,1174.0,6.33524206211,206.0,409.0,203.0,293.909340408,20.1757740067,3212723.0,300.0,254.0,634.0,380.0,392.593358339,23.5943353591,4291438.0,397.0,368.0,1033.0,665.0,604.355777148,78.023419273,6606213.0,600.0,207.0,832.0,625.0,442.313603513,43.1162919819,4834930.0,433.0,0.0185792353004,0.430088490248,0.411509254947,0.152724079951,0.0478897360117,1669.42691795,0.142572,667.0,1875.0,1208.0,1128.81630226,59.5017530525,12339091.0,1126.0,-0.176605224609,5.86901855469,6.0456237793,0.285530469239,0.465452136069,3121.13355925,0.0402222
+15108728.0,3.5,15.0,2.2617901316,235.0,267.0,32.0,244.357142857,10.2162835209,3421.0,240.5,248.0,295.0,47.0,269.071428571,11.5044357018,3767.0,268.5,308.0,613.0,305.0,399.642857143,81.2127779732,5595.0,387.0,117.0,230.0,113.0,148.785714286,31.1039238945,2083.0,146.5,0.428571432829,0.496981889009,0.0684104561806,0.457514839513,0.0195128325573,6.40520775318,0.452318,600.0,787.0,187.0,662.214285714,50.7249988684,9271.0,658.0,4.88513183594,4.92175292969,0.03662109375,4.90646580287,0.0110211409021,68.6905212402,4.9104
+15071180.0,241.249999995,180.0,3.26914295507,226.0,273.0,47.0,242.849740933,6.02113827698,234350.0,242.0,281.0,377.0,96.0,315.006217617,11.3126992099,303981.0,314.0,563.0,758.0,195.0,665.534715026,27.8908696232,642241.0,666.0,258.0,419.0,161.0,324.615544041,19.5405349082,313254.0,324.0,0.272556394339,0.437295526266,0.164739131927,0.344494754416,0.02386491762,332.437438011,0.344229,774.0,1061.0,287.0,882.471502591,33.8474552096,851585.0,880.0,-0.313537597656,1.55172729492,1.86526489258,0.124689701061,0.249422464509,120.325561523,0.0
+15068091.0,3.00000000023,8.0,1.30294003169,209.0,310.0,101.0,255.0,32.7210431782,3060.0,252.5,226.0,325.0,99.0,277.0,30.3836578882,3324.0,270.5,502.0,779.0,277.0,622.416666667,93.1624551821,7469.0,626.5,214.0,332.0,118.0,268.75,37.4168522638,3225.0,267.0,0.32868757844,0.426048576832,0.0973609983921,0.39601992319,0.02576238479,4.75223907828,0.401658,704.0,947.0,243.0,800.75,84.2764547981,9609.0,783.5,4.42700195312,5.22225952148,0.795257568359,4.62714894613,0.229957148259,55.5257873535,4.55061
+15055624.0,999.000000011,328.0,2.9274276304,203.0,375.0,172.0,263.332082082,14.0001459226,1052275.0,262.0,281.0,529.0,248.0,387.913163163,22.0900812265,1550101.0,387.0,579.0,1159.0,580.0,990.551801802,53.6971083831,3958245.0,991.0,182.0,512.0,330.0,362.956706707,35.6168771723,1450375.0,361.0,0.321621626616,0.593195259571,0.271573632956,0.463957347669,0.0416026591292,1853.97356129,0.463673,683.0,1361.0,678.0,1014.20195195,67.5330453809,4052751.0,1010.0,-0.263488769531,1.25759887695,1.52108764648,0.0432077050806,0.128088909759,172.657989502,0.0
+15070698.0,633.499999996,253.0,2.83558244873,171.0,282.0,111.0,231.111286504,14.7702026402,585636.0,232.0,224.0,402.0,178.0,317.035911602,30.7111047382,803369.0,319.0,571.0,1292.0,721.0,949.597868982,130.921744746,2406281.0,965.0,137.0,403.0,266.0,262.858326756,38.8130124647,666083.0,265.0,0.392889708281,0.734827280045,0.341937571764,0.564522263083,0.0527671428942,1430.49941465,0.566142,548.0,1085.0,537.0,811.005524862,82.3455333801,2055088.0,816.0,-0.161224365234,1.96246337891,2.12368774414,0.553518438302,0.490448787734,1402.61572266,0.585648
+15083018.0,3573.49999995,2251.0,10.6224249108,199.0,360.0,161.0,263.303553939,14.9681530294,3763661.0,261.0,263.0,516.0,253.0,353.706730097,29.0869457599,5055884.0,351.0,491.0,1049.0,558.0,737.729606828,65.5758852096,10545107.0,734.0,199.0,625.0,426.0,368.099342381,45.1341895931,5261612.0,364.0,0.157654225826,0.515279233456,0.357625007629,0.335086351472,0.0429127708192,4789.72430794,0.333333,663.0,1487.0,824.0,985.109626417,87.5388375362,14081157.0,975.0,-0.251586914062,4.30307006836,4.55465698242,0.187913533039,0.295302081694,2686.03604126,0.0844879
+15059066.0,114.499999998,74.0,1.95085074756,283.0,388.0,105.0,355.598253275,11.3339616598,162864.0,357.0,483.0,613.0,130.0,550.379912664,19.5375517498,252074.0,551.0,900.0,1121.0,221.0,1005.50218341,36.6076953342,460520.0,1002.0,610.0,891.0,281.0,764.76419214,36.2405395802,350262.0,763.0,0.108659677207,0.205211728811,0.0965520516038,0.136202159342,0.0120861713816,62.3805889785,0.13556,1393.0,1892.0,499.0,1670.74235808,62.0083386112,765200.0,1669.5,-0.0516052246094,0.24560546875,0.297210693359,0.0271856316312,0.0568551149028,12.4510192871,0.0
+15074696.0,3810.99999999,2851.0,13.0278518409,204.0,339.0,135.0,255.604303332,15.6226560198,3896432.0,253.0,240.0,494.0,254.0,349.04218053,28.5679433347,5320799.0,345.0,650.0,1087.0,437.0,855.665179743,55.0937960481,13043760.0,856.0,162.0,535.0,373.0,319.424691682,41.9537538138,4869310.0,313.0,0.291460841894,0.684824883938,0.393364042044,0.457670540462,0.0445743070418,6976.7297188,0.458537,620.0,1342.0,722.0,924.071175544,83.9819174719,14086541.0,911.0,-0.157836914062,2.38928222656,2.54711914062,0.364547865624,0.480696676608,5557.16766357,0.205627
+15015326.0,1848.99999999,1072.0,7.03268876238,205.0,390.0,185.0,267.758518118,28.7035554106,1980342.0,259.0,263.0,585.0,322.0,367.068280151,46.1950395799,2714837.0,355.0,375.0,1064.0,689.0,657.662520281,87.3310589204,4864072.0,647.0,234.0,830.0,596.0,414.710113575,67.0324184015,3067196.0,410.0,0.0262172278017,0.4532520473,0.427034819499,0.227641020923,0.0551134592404,1683.63299074,0.224909,735.0,1792.0,1057.0,1049.53691184,136.117001676,7762375.0,1026.0,-0.520446777344,3.22235107422,3.74279785156,0.244698210366,0.536326209935,1809.78796387,0.0
+15009352.0,223.749999998,91.0,1.71614878947,227.0,285.0,58.0,256.165363128,7.24676974903,229268.0,256.0,297.0,430.0,133.0,359.157541899,15.8815020676,321446.0,359.0,831.0,1251.0,420.0,1021.31620112,65.305705818,914078.0,1011.0,236.0,438.0,202.0,329.69273743,26.2482881122,295075.0,328.0,0.399503707886,0.625099301338,0.225595593452,0.511300579296,0.0382766136398,457.61401847,0.507891,760.0,1131.0,371.0,945.015642458,45.9389171929,845789.0,942.0,-0.0649108886719,4.26055908203,4.3254699707,0.699248244643,1.29831102802,625.827178955,0.0
+15013261.0,23.2500000009,22.0,1.28708215855,498.0,762.0,264.0,671.075268817,67.6811367376,62410.0,690.0,736.0,1144.0,408.0,1012.74193548,98.8516759231,94185.0,1045.0,949.0,1323.0,374.0,1172.76344086,94.0059936146,109067.0,1197.0,855.0,1380.0,525.0,1144.35483871,122.044557804,106425.0,1164.0,-0.0252600293607,0.0532089956105,0.0784690249711,0.0135650971838,0.0182353201145,1.26155403809,0.0131796,2174.0,3254.0,1080.0,2828.17204301,275.527046217,263020.0,2926.0,2.60699462891,4.20324707031,1.59625244141,3.36923217773,0.277753222897,313.338592529,3.28036
+15000295.0,196.499999999,110.0,2.21363735961,336.0,478.0,142.0,415.933842239,16.7782483609,326924.0,415.0,491.0,726.0,235.0,635.148854962,29.8694271255,499227.0,634.0,750.0,1059.0,309.0,943.255725191,36.6366103836,741399.0,944.0,574.0,924.0,350.0,796.698473282,40.8164067036,626205.0,795.0,0.0396196506917,0.148788928986,0.109169278294,0.0844942993999,0.0129016562617,66.4125193283,0.0835038,1401.0,2125.0,724.0,1847.78117048,85.4049205825,1452356.0,1846.0,-0.043701171875,0.397491455078,0.441192626953,0.0409524932162,0.0858611470718,32.188659668,0.0
+15157927.0,3324.25000001,2276.0,11.1357760161,220.0,440.0,220.0,323.192449425,21.8128401206,4297490.0,323.0,258.0,631.0,373.0,475.656163044,37.5481601227,6324800.0,476.0,524.0,1140.0,616.0,880.424381439,72.8046834925,11707003.0,885.0,242.0,871.0,629.0,647.822516357,58.4143829872,8614096.0,653.0,0.0467185750604,0.368146210909,0.321427635849,0.152384876817,0.0328260355941,2026.26170704,0.149343,732.0,1910.0,1178.0,1446.67112883,109.726267891,19236386.0,1453.0,-0.176605224609,5.52728271484,5.70388793945,0.128683506335,0.334551745886,1711.10458374,0.00778198
+14950730.0,2544.5,915.0,5.11699431478,259.0,450.0,191.0,367.434368245,18.0389707661,3739747.0,368.0,364.0,725.0,361.0,578.4869326,32.1353475506,5887840.0,578.0,769.0,1183.0,414.0,980.621143643,49.9958016806,9980762.0,977.0,475.0,997.0,522.0,772.055413637,52.2958529303,7857980.0,772.0,0.0497109815478,0.264413505793,0.214702524245,0.119449565673,0.0209189774673,1215.75767942,0.11464,1153.0,2153.0,1000.0,1717.97671448,98.1328444822,17485567.0,1718.0,-0.177368164062,1.27941894531,1.45678710938,0.116715712874,0.185487102546,1187.93252563,0.00100708
+14972533.0,441.499999995,213.0,2.85962652948,210.0,301.0,91.0,256.674971687,11.8470680019,453288.0,257.0,276.0,454.0,178.0,370.617780294,28.696551595,654511.0,374.0,742.0,1272.0,530.0,1007.36353341,99.9448392926,1779004.0,1011.0,190.0,442.0,252.0,322.370328426,31.3266663659,569306.0,323.0,0.397239267826,0.621103107929,0.223863840103,0.513779116463,0.042637918162,907.333919674,0.512216,676.0,1197.0,521.0,949.663080408,68.9908759082,1677105.0,954.0,-0.114868164062,1.79135131836,1.90621948242,0.40812363414,0.394561952649,720.746337891,0.344742
+14953226.0,105.0,139.0,3.8266189574,210.0,346.0,136.0,254.904761905,20.7644493853,107060.0,256.0,255.0,493.0,238.0,335.580952381,36.3726823061,140944.0,336.5,378.0,731.0,353.0,521.554761905,58.5103112703,219053.0,518.0,216.0,606.0,390.0,342.995238095,60.814863285,144058.0,344.0,0.0934928953648,0.34957370162,0.256080806255,0.210459432095,0.0443061344441,88.3929614797,0.209621,698.0,1445.0,747.0,933.480952381,116.189181199,392062.0,938.0,-0.00238037109375,1.09149169922,1.09387207031,0.0723765781948,0.169904363286,30.3981628418,0.0
+15017494.0,3780.0,2354.0,10.8007925968,264.0,461.0,197.0,366.04755291,20.3720695453,5534639.0,367.0,362.0,704.0,342.0,552.548677249,35.3771424404,8354536.0,554.0,689.0,1229.0,540.0,949.962103175,50.5465690285,14363427.0,952.0,428.0,881.0,453.0,725.174470899,49.4254340209,10964638.0,730.0,0.0696629211307,0.271695047617,0.202032126486,0.134623624165,0.0194610545628,2035.50919738,0.131104,1078.0,2018.0,940.0,1643.77070106,100.984724348,24853813.0,1652.0,-0.022705078125,1.20257568359,1.22528076172,0.208578267173,0.15144017635,3153.70339966,0.193924
+14945969.0,2446.25,1313.0,7.48875072677,182.0,299.0,117.0,251.652427184,12.1391645419,2462419.0,252.0,254.0,436.0,182.0,359.414307614,21.7048732414,3516869.0,360.0,655.0,1085.0,430.0,887.309453245,49.923275805,8682323.0,890.0,194.0,476.0,282.0,338.451711804,34.4861534703,3311750.0,337.0,0.326894491911,0.608080804348,0.281186312437,0.448372289884,0.0388952016922,4387.32285652,0.448052,638.0,1204.0,566.0,949.518446602,66.7654325699,9291038.0,950.0,-0.253936767578,1.32739257812,1.5813293457,0.0673546059618,0.165788127408,659.064819336,0.0
+14920793.0,54.9999999995,48.0,1.82580739024,287.0,454.0,167.0,400.663636364,33.7963896062,88146.0,410.0,380.0,676.0,296.0,588.781818182,60.2265241806,129532.0,599.0,497.0,963.0,466.0,745.613636364,67.4416973491,164035.0,756.0,341.0,828.0,487.0,688.045454545,82.8708619001,151370.0,712.0,-0.00196206662804,0.245575219393,0.247537286021,0.0420856996037,0.0331152350817,9.25885391282,0.0353677,1008.0,1941.0,933.0,1677.49090909,169.456041254,369048.0,1736.0,0.121826171875,2.14831542969,2.02648925781,0.426543773304,0.403447416319,93.839630127,0.283768
+14959212.0,2092.75000002,1230.0,7.58475407785,235.0,425.0,190.0,328.306653924,24.4105465793,2748255.0,328.0,333.0,628.0,295.0,496.960100346,41.8923147409,4160053.0,498.0,672.0,1275.0,603.0,1009.69322662,67.3142765485,8452142.0,1014.0,304.0,810.0,506.0,582.516067375,70.5960396269,4876242.0,584.0,0.14989733696,0.460035532713,0.310138195753,0.27025644118,0.0413105635039,2262.31666912,0.269655,895.0,1826.0,931.0,1407.78282165,133.121353838,11784550.0,1411.0,-0.125518798828,1.27114868164,1.39666748047,0.0332558335348,0.0869103275403,278.38458252,0.0
+14918403.0,88.2499999995,56.0,1.68161176822,298.0,582.0,284.0,370.036827195,31.1945608522,130623.0,363.0,497.0,925.0,428.0,568.073654391,48.2587479773,200530.0,559.0,641.0,1277.0,636.0,769.101983003,61.0804125308,271493.0,760.0,539.0,1282.0,743.0,719.487252125,64.2265861623,253979.0,709.0,-0.0260747000575,0.0902953594923,0.11637005955,0.0336304992218,0.0124266559043,11.8715662253,0.0324826,1358.0,2789.0,1431.0,1657.59773371,134.931195122,585132.0,1633.0,3.16088867188,4.9348449707,1.77395629883,4.1048443932,0.494630901219,1449.0100708,4.25592
+14901064.0,2008.74999999,499.0,3.14074493975,186.0,309.0,123.0,234.475046671,12.615691116,1884007.0,236.0,208.0,436.0,228.0,299.473802116,24.1602800731,2406272.0,301.0,567.0,1238.0,671.0,972.931798382,100.993007839,7817507.0,983.0,100.0,473.0,373.0,237.135656503,35.5965292953,1905385.0,240.0,0.388098329306,0.794822633266,0.406724303961,0.607876890193,0.0477110533091,4884.2908127,0.611563,494.0,1218.0,724.0,771.084505289,71.1728009452,6195664.0,777.0,0.0116882324219,5.69049072266,5.67880249023,2.5478434498,1.30241508654,20471.9221191,2.46933
+14882420.0,449.499999955,317.0,4.21783398882,233.0,308.0,75.0,262.043937709,7.4436529585,471155.0,262.0,307.0,421.0,114.0,357.631256952,15.2888125209,643021.0,359.0,187.0,639.0,452.0,313.622358176,64.3311985285,563893.0,296.0,261.0,487.0,226.0,338.932703003,22.0264889709,609401.0,337.0,-0.30324909091,0.299620747566,0.602869838476,-0.0467439858726,0.0958715935423,-84.0456865989,-0.0646425,830.0,1199.0,369.0,958.607897664,39.3280360606,1723577.0,959.0,-0.168792724609,1.83508300781,2.00387573242,0.165805532351,0.340412967204,298.118347168,0.0
+14884725.0,169.499999997,156.0,3.38014098567,220.0,427.0,207.0,321.283185841,29.0802883172,217830.0,321.0,295.0,631.0,336.0,457.073746313,43.5373625305,309896.0,456.0,625.0,1224.0,599.0,881.800884956,87.3939316615,597861.0,873.0,279.0,821.0,542.0,528.898230088,71.2233594337,358593.0,523.5,0.133291214705,0.403122127056,0.269830912352,0.251702744283,0.0392761375603,170.654460624,0.252025,794.0,1878.0,1084.0,1307.25516224,139.596990827,886319.0,1301.5,-0.125152587891,0.536987304688,0.662139892578,0.2262447661,0.176994628166,153.393951416,0.215408
+14954255.0,7921.00000001,2954.0,9.36301140337,226.0,352.0,126.0,298.436340109,11.4523027891,9455657.0,299.0,288.0,526.0,238.0,415.715660901,20.1433266942,13171535.0,416.0,530.0,928.0,398.0,721.352575432,36.2861121293,22855335.0,721.0,258.0,644.0,386.0,483.467396793,32.9842102799,15318181.0,484.0,0.123397432268,0.345177650452,0.221780218184,0.197891004668,0.0198914480828,6269.97859191,0.196213,799.0,1494.0,695.0,1197.6193978,62.8240849675,37945373.0,1199.0,-0.110626220703,1.8127746582,1.92340087891,0.194501425338,0.189953778478,6162.5831604,0.151169
+14883087.0,28.75,30.0,1.57832849825,214.0,273.0,59.0,244.330434783,11.5357453834,28098.0,246.0,249.0,387.0,138.0,337.530434783,25.4737108268,38816.0,339.0,698.0,1109.0,411.0,974.608695652,75.1957093656,112080.0,986.0,187.0,352.0,165.0,282.469565217,34.4215103979,32484.0,284.0,0.484570473433,0.640599012375,0.156028538942,0.551222437361,0.0352049928707,63.3905802965,0.551251,650.0,1006.0,356.0,864.330434783,69.3967449104,99398.0,868.0,0.0616760253906,0.320373535156,0.258697509766,0.185185706097,0.0422051167852,21.2963562012,0.183838
+14900735.0,613.499999996,450.0,5.12507586175,251.0,337.0,86.0,291.076202119,9.64299049941,714301.0,291.0,344.0,475.0,131.0,414.855338223,16.6575807965,1018055.0,415.0,655.0,960.0,305.0,854.39405053,34.2760020522,2096683.0,855.0,371.0,619.0,248.0,468.784433578,29.1301701943,1150397.0,469.0,0.184453234077,0.374367624521,0.189914390445,0.291775424188,0.0226524679614,716.016890958,0.291064,993.0,1426.0,433.0,1174.71597392,53.5389591249,2882753.0,1174.0,-0.205535888672,0.798889160156,1.00442504883,0.0772385601115,0.135913346946,189.543426514,0.0634766
+14860298.0,9018.49999999,3782.0,11.2343884848,202.0,506.0,304.0,299.604230193,17.850295476,10807923.0,300.0,253.0,811.0,558.0,406.830348728,29.6863460374,14675998.0,402.0,349.0,1104.0,755.0,572.538005212,65.3981236386,20653736.0,553.0,155.0,1093.0,938.0,450.471308976,47.9823844767,16250302.0,438.0,-0.0379146933556,0.473684221506,0.511598914862,0.118760506422,0.0314696461302,4284.16650866,0.112073,646.0,2410.0,1764.0,1156.9058879,81.9739831998,41734223.0,1141.0,-0.335968017578,11.3096313477,11.6455993652,0.3980484123,1.25993000752,14359.1984253,0.00376892
+14864917.0,5.75000000023,17.0,1.99990822728,174.0,217.0,43.0,199.086956522,11.2825877523,4579.0,198.0,213.0,249.0,36.0,231.739130435,11.2914642302,5330.0,234.0,486.0,720.0,234.0,552.869565217,73.1830963779,12716.0,526.0,97.0,199.0,102.0,157.52173913,23.7667461606,3623.0,160.0,0.439655184746,0.758104741573,0.318449556828,0.551698591398,0.0810465932659,12.6890676022,0.525862,484.0,658.0,174.0,588.347826087,44.1849951864,13532.0,591.0,-0.00173950195312,4.36889648438,4.37063598633,1.82743636422,2.08433733063,42.031036377,0.000518799
+14843213.0,1056.99999998,648.0,5.6225403421,227.0,529.0,302.0,367.156811731,38.5477840371,1552339.0,370.0,310.0,768.0,458.0,557.906811731,67.1558772242,2358830.0,562.0,597.0,1302.0,705.0,971.420056764,105.880450581,4107164.0,971.0,277.0,1010.0,733.0,682.691106906,107.526253186,2886418.0,690.0,0.0367483310401,0.430689394474,0.393941063434,0.17754389291,0.0500967030876,750.655579224,0.166068,814.0,2239.0,1425.0,1607.75473037,207.727451484,6797587.0,1624.0,-0.0906677246094,1.39849853516,1.48916625977,0.400170448036,0.388633027714,1691.9206543,0.329224
+14893202.0,2922.25000001,1221.0,6.37165200484,217.0,352.0,135.0,286.740011977,14.0208859288,3351704.0,287.0,283.0,538.0,255.0,414.135768671,25.6726957546,4840833.0,415.0,564.0,1136.0,572.0,874.725382839,48.0535002831,10224665.0,874.0,227.0,640.0,413.0,443.06441954,43.3512696119,5178980.0,443.0,0.209944754839,0.498699039221,0.288754284382,0.328508715624,0.0380449960434,3839.93837693,0.326211,727.0,1530.0,803.0,1143.94020019,80.9130996476,13371517.0,1145.0,-0.202514648438,1.82608032227,2.0285949707,0.143847686535,0.199529229271,1681.43560791,0.0987244
+14798286.0,235.500000001,268.0,4.92645370843,255.0,377.0,122.0,307.470276008,16.9308782009,289637.0,308.0,360.0,558.0,198.0,455.029723992,30.1369339063,428638.0,456.0,839.0,1148.0,309.0,978.097664544,52.0590981223,921368.0,977.0,366.0,699.0,333.0,511.703821656,53.8433913511,482025.0,512.0,0.229857817292,0.426356583834,0.196498766541,0.314432748437,0.0376779249341,296.195649028,0.314519,989.0,1634.0,645.0,1274.20382166,99.6725576775,1200300.0,1277.0,-0.0354919433594,0.882720947266,0.918212890625,0.293908153623,0.212373402487,276.861480713,0.317566
+14803987.0,3582.5,1957.0,9.22343717878,238.0,418.0,180.0,336.512770412,24.2333160181,4822228.0,337.0,327.0,641.0,314.0,494.079064899,43.9656509803,7080153.0,496.0,483.0,1247.0,764.0,912.604535939,63.1234901667,13077623.0,915.0,324.0,841.0,517.0,605.375296581,73.3512221459,8675028.0,608.0,0.0666666701436,0.401154398918,0.334487728775,0.204551651833,0.0398783120969,2931.22517076,0.201538,901.0,1871.0,970.0,1435.96713189,139.38560668,20577409.0,1441.0,-0.057861328125,4.23266601562,4.29052734375,0.252145208983,0.218556838144,3613.24084473,0.213654
+14759824.0,2867.25000003,820.0,4.31992433107,216.0,269.0,53.0,237.485831372,5.51268124527,2723725.0,237.0,285.0,372.0,87.0,322.866596913,10.2532323015,3702957.0,322.0,908.0,1496.0,588.0,1204.95640422,84.1678878328,13819645.0,1208.0,173.0,331.0,158.0,244.647397332,15.7472186545,2805861.0,243.0,0.517295598984,0.750447750092,0.233152151108,0.661226712464,0.0311570880708,7583.60916525,0.663173,687.0,960.0,273.0,804.999825617,29.0645716334,9232543.0,803.0,-0.231292724609,1.31878662109,1.5500793457,0.173852706165,0.22761366697,1993.91668701,0.0797424
+14765145.0,37.5000000035,85.0,3.91560036049,259.0,501.0,242.0,366.266666667,27.1302209517,54940.0,361.0,371.0,792.0,421.0,554.7,39.9071839815,83205.0,552.0,768.0,1242.0,474.0,912.986666667,55.6522520259,136948.0,907.0,461.0,1060.0,599.0,694.42,49.8334920845,104163.0,692.0,0.0790616869926,0.252230346203,0.17316865921,0.136250130286,0.0225111489771,20.4375195429,0.13155,1091.0,2353.0,1262.0,1615.38666667,110.751300168,242308.0,1603.5,-0.114105224609,0.481170654297,0.595275878906,0.113189086914,0.149351546582,16.9783630371,0.00964355
+14810163.0,16111.7499999,8123.0,18.0526168181,221.0,399.0,178.0,296.716542275,16.2474693309,19122491.0,297.0,285.0,545.0,260.0,412.844911322,28.6367694224,26606616.0,412.0,514.0,1005.0,491.0,747.456437072,54.6638727987,48171325.0,744.0,252.0,702.0,450.0,465.790789331,47.7618334584,30018819.0,463.0,0.0573770478368,0.447600394487,0.390223346651,0.233047799236,0.0360254549536,15019.2315174,0.232013,758.0,1591.0,833.0,1175.35224293,89.9972585784,75747926.0,1172.0,-0.194030761719,2.17556762695,2.36959838867,0.16876829994,0.176252220761,10876.6106262,0.132355
+14746929.0,73.7500000021,39.0,1.28108711366,257.0,455.0,198.0,368.569491525,24.1541887039,108728.0,370.0,333.0,583.0,250.0,454.454237288,29.0544277208,134064.0,457.0,168.0,519.0,351.0,287.206779661,75.7904422766,84726.0,258.0,132.0,430.0,298.0,258.322033898,40.8705441475,76205.0,252.0,-0.132231399417,0.278048783541,0.410280182958,0.0431773115403,0.08478213321,12.7373069044,0.0219619,809.0,1359.0,550.0,1081.34576271,70.5802760224,318997.0,1084.0,0.167938232422,1.14828491211,0.980346679688,0.663578253277,0.222834069837,195.755584717,0.647766
+14758040.0,342.249999993,231.0,3.52237280543,190.0,295.0,105.0,244.438276114,10.9476152992,334636.0,245.0,270.0,438.0,168.0,355.227903579,19.7141533123,486307.0,356.0,699.0,1124.0,425.0,982.970781592,60.2902816812,1345687.0,995.0,189.0,469.0,280.0,316.287070855,32.0884708941,432997.0,314.0,0.376329779625,0.632768332958,0.256438553333,0.513399218821,0.0366618557911,702.843530566,0.514409,660.0,1202.0,542.0,915.953250548,60.5028176878,1253940.0,915.0,-0.201568603516,0.91796875,1.11953735352,0.0610507605631,0.140635086804,83.5784912109,0.0
+14753571.0,1692.99999999,726.0,4.97740763499,213.0,341.0,128.0,262.768901359,11.406955129,1779471.0,261.0,277.0,499.0,222.0,368.71234495,19.7130839163,2496920.0,368.0,683.0,1238.0,555.0,910.848198464,52.4138309921,6168264.0,909.0,198.0,603.0,405.0,366.3248671,37.1111047418,2480752.0,366.0,0.267023712397,0.590834677219,0.323810964823,0.426583868768,0.0471431421432,2888.8259593,0.423341,691.0,1432.0,741.0,997.806113408,64.0474370432,6757143.0,996.0,-0.0827331542969,1.14828491211,1.23101806641,0.0904965656999,0.175491588061,612.84274292,0.0
+14736985.0,3.75,8.0,1.16538499263,249.0,307.0,58.0,276.066666667,15.0707958943,4141.0,276.0,341.0,457.0,116.0,394.2,30.6511554975,5913.0,398.0,283.0,579.0,296.0,391.466666667,76.4424547545,5872.0,403.0,302.0,445.0,143.0,370.0,36.4636805603,5550.0,369.0,-0.158989593387,0.2063074857,0.365297079086,0.0211057101066,0.114951418203,0.316585651599,-0.00431655,892.0,1209.0,317.0,1040.26666667,81.7764975745,15604.0,1039.0,0.0698547363281,0.62744140625,0.557586669922,0.308451334635,0.170759380866,4.62677001953,0.30835
+14729677.0,589.500000005,335.0,3.89222529114,241.0,333.0,92.0,289.918150975,12.7315734089,683627.0,290.0,330.0,485.0,155.0,414.754028838,21.9093797978,977990.0,415.0,611.0,936.0,325.0,795.558524173,46.5001820551,1875927.0,797.0,317.0,581.0,264.0,465.156064461,38.2416458986,1096838.0,464.0,0.177142858505,0.350909084082,0.173766225576,0.262639456123,0.0274738449343,619.303837538,0.262958,888.0,1394.0,506.0,1169.82824427,71.3231944441,2758455.0,1169.0,-0.355499267578,1.18603515625,1.54153442383,0.0656116022914,0.162868659686,154.712158203,0.0
+14783719.0,4805.25000001,2729.0,11.1055637628,207.0,321.0,114.0,246.843296395,11.974923091,4744575.0,244.0,271.0,477.0,206.0,331.71645596,23.5512018047,6375922.0,327.0,599.0,1134.0,535.0,815.527547994,75.7446485925,15675255.0,815.0,223.0,543.0,320.0,326.013162687,34.7066366932,6266299.0,321.0,0.253499209881,0.56286919117,0.309369981289,0.428587834378,0.0362788755493,8237.88676459,0.431176,705.0,1319.0,614.0,904.572915041,68.3408442907,17386796.0,892.0,-0.218780517578,2.23443603516,2.45321655273,0.813141342281,0.502700697832,15629.38974,0.919312
+14823220.0,2470.49999999,1051.0,5.96493004707,239.0,444.0,205.0,295.523274641,8.42118325094,2920361.0,296.0,306.0,641.0,335.0,402.405788302,14.4366266812,3976574.0,403.0,407.0,881.0,474.0,545.818255414,27.5036337073,5393776.0,543.5,316.0,885.0,569.0,473.773021656,26.2423047723,4681825.0,473.0,-0.0022650056053,0.171232879162,0.173497884767,0.0707943776142,0.0121860407037,699.590039584,0.0699399,862.0,1970.0,1108.0,1171.7020846,47.0994299119,11578760.0,1173.0,-0.48828125,1.92233276367,2.41061401367,0.382387125355,0.412285883032,3778.74957275,0.268494
+14692146.0,41.0,55.0,2.42306926623,206.0,308.0,102.0,261.12195122,15.1668687733,42824.0,261.5,259.0,440.0,181.0,358.524390244,25.1663856382,58798.0,357.0,546.0,915.0,369.0,781.323170732,50.3276988148,128137.0,782.5,196.0,538.0,342.0,411.408536585,53.3549794262,67471.0,413.0,0.219804957509,0.474530845881,0.254725888371,0.312638400441,0.0470513482771,51.2726976722,0.312921,661.0,1286.0,625.0,1031.05487805,88.0816038661,169093.0,1019.0,-0.0516052246094,0.395324707031,0.446929931641,0.0688621707079,0.115756288941,11.2933959961,0.0
+14894094.0,5742.49999989,3200.0,11.912270437,216.0,649.0,433.0,309.529734436,14.5221734465,7109898.0,310.0,286.0,985.0,699.0,448.18075751,22.9101113911,10294712.0,448.0,462.0,1289.0,827.0,704.530605137,35.9435118811,16183068.0,704.0,263.0,1365.0,1102.0,588.662646931,33.0598268069,13521581.0,588.0,-0.0309859160334,0.274482756853,0.305468672886,0.0897102443557,0.0141546868855,2060.64431285,0.0887397,769.0,2999.0,2230.0,1346.37313888,61.4231959785,30926191.0,1346.0,-0.180267333984,1.71371459961,1.89398193359,0.234105878007,0.261291934059,5377.41201782,0.156433
+14709163.0,4813.49999999,3633.0,14.771682954,196.0,699.0,503.0,346.012932378,25.2199401611,6662133.0,346.0,257.0,1463.0,1206.0,524.074841591,43.723138575,10090537.0,524.0,501.0,1708.0,1207.0,909.768307884,73.5573283623,17516679.0,918.0,271.0,1658.0,1387.0,712.266957515,65.9420494987,13713988.0,719.0,-0.0698254331946,0.366420269012,0.436245702207,0.122220468731,0.0306142131776,2353.23290495,0.119324,742.0,3804.0,3062.0,1582.35473148,119.942517911,30466658.0,1587.0,-0.192993164062,2.65258789062,2.84558105469,0.160044017779,0.289446468961,3081.48751831,0.0
+14653202.0,3078.24999994,1732.0,8.80625002331,239.0,390.0,151.0,295.116787136,11.7852410984,3633773.0,294.0,361.0,571.0,210.0,422.4083489,21.1290635895,5201114.0,421.0,565.0,857.0,292.0,692.173231544,38.0920605337,8522729.0,690.0,423.0,789.0,366.0,555.527978559,36.0871854235,6840216.0,554.0,0.0385487526655,0.21850900352,0.179960250854,0.109778520312,0.0168084146618,1351.7029206,0.106591,1071.0,1750.0,679.0,1273.05311459,65.5655362258,15675103.0,1269.0,-0.144317626953,0.755615234375,0.899932861328,0.112287102653,0.162709449473,1382.59109497,0.00387573
+14650346.0,110.500000001,65.0,1.74432451959,211.0,289.0,78.0,249.21719457,11.4161461155,110154.0,249.0,285.0,406.0,121.0,343.339366516,20.3941420379,151756.0,343.0,795.0,1208.0,413.0,977.875565611,80.6255261459,432221.0,980.5,192.0,430.0,238.0,302.699095023,34.5854237742,133793.0,302.0,0.356287419796,0.679012358189,0.322724938393,0.526438290919,0.0517097301069,232.685724586,0.527234,694.0,1094.0,400.0,895.255656109,63.331314959,395703.0,891.5,-0.0054931640625,1.59741210938,1.60290527344,0.54449870252,0.404202643393,240.668426514,0.501755
+14647394.0,59.9999999998,43.0,1.56598608385,276.0,325.0,49.0,297.3,9.24310553872,71352.0,295.0,374.0,484.0,110.0,431.120833333,21.0718508752,103469.0,432.0,309.0,523.0,214.0,356.820833333,24.5505682074,85637.0,353.0,389.0,554.0,165.0,427.129166667,19.1440804421,102511.0,426.0,-0.184696570039,-0.00714285718277,0.177553712856,-0.0901681382733,0.0359124079804,-21.6403531856,-0.0913738,1054.0,1363.0,309.0,1155.55,40.3327513732,277332.0,1156.5,-0.00238037109375,0.3310546875,0.333435058594,0.0164452870687,0.0530513346296,3.94686889648,0.0
+14642656.0,25.0000000007,27.0,1.52331187556,301.0,404.0,103.0,367.72,19.7803336676,36772.0,371.5,422.0,592.0,170.0,526.61,33.3481318817,52661.0,532.5,482.0,780.0,298.0,626.97,57.3843977053,62697.0,625.5,437.0,701.0,264.0,584.99,51.4300486097,58499.0,589.0,-0.0116175152361,0.123370110989,0.134987626225,0.0345008751843,0.0294989713626,3.45008751843,0.0299853,1160.0,1696.0,536.0,1479.32,99.332761967,147932.0,1491.0,-0.113128662109,0.615173339844,0.728302001953,0.308889465332,0.286689524814,30.8889465332,0.428726
+14646211.0,3059.24999999,2234.0,11.3938566832,221.0,422.0,201.0,307.750919343,14.60215444,3765948.0,305.0,285.0,577.0,292.0,457.106888943,23.9300487447,5593617.0,454.0,518.0,1011.0,493.0,830.764566479,44.8652916558,10166066.0,835.0,363.0,842.0,479.0,662.207894092,38.3394420281,8103438.0,665.0,0.0376633368433,0.231746032834,0.194082695991,0.112992538835,0.0155255236244,1382.68969773,0.111111,876.0,1764.0,888.0,1427.06570238,64.3112967719,17463003.0,1427.0,-0.197326660156,3.10815429688,3.30548095703,0.113233125647,0.251444481844,1385.63375854,0.0
+14609754.0,3.75,9.0,1.31105811671,525.0,665.0,140.0,611.4,42.5171338012,9171.0,626.0,657.0,777.0,120.0,717.466666667,39.9480774117,10762.0,713.0,712.0,1058.0,346.0,854.0,96.874489246,12810.0,820.0,707.0,867.0,160.0,804.6,44.5283430338,12069.0,797.0,-0.0541033446789,0.166482910514,0.220586255193,0.0272756118095,0.0677767962927,0.409134177142,0.00352361,1895.0,2301.0,406.0,2133.46666667,121.910276661,32002.0,2142.0,0.0164184570312,0.494293212891,0.477874755859,0.356294759115,0.13284163598,5.34442138672,0.415009
+14572365.0,23.25,25.0,1.46259336202,310.0,404.0,94.0,367.720430108,16.9238430722,34198.0,368.0,439.0,590.0,151.0,541.053763441,32.6079235675,50318.0,548.0,600.0,824.0,224.0,708.344086022,45.4145764634,65876.0,713.0,463.0,725.0,262.0,654.35483871,45.7648607185,60855.0,661.0,-0.0301624126732,0.154929578304,0.185091990978,0.0398618682057,0.0355924220705,3.70715374313,0.0393071,1212.0,1710.0,498.0,1563.12903226,88.2457743125,145371.0,1578.0,2.49029541016,3.38967895508,0.899383544922,3.04657048051,0.183401306491,283.331054688,3.00455
+14541422.0,234.750000001,116.0,2.13574922157,248.0,303.0,55.0,282.345047923,6.40039639288,265122.0,283.0,330.0,458.0,128.0,410.165069223,16.0314325922,385145.0,412.0,328.0,495.0,167.0,408.2342918,21.0751597799,383332.0,402.0,330.0,533.0,203.0,441.063897764,23.4010769105,414159.0,442.0,-0.0856481492519,0.0276497695595,0.113297918811,-0.0385638363601,0.0295336890112,-36.2114423421,-0.0455635,910.0,1292.0,382.0,1133.57401491,44.6357832685,1064426.0,1136.0,-0.0093994140625,1.09744262695,1.10684204102,0.111806688725,0.251470408247,104.986480713,0.0
+14551185.0,1605.74999996,1085.0,7.63810880889,229.0,427.0,198.0,320.135450724,22.8465157436,2056230.0,318.0,332.0,684.0,352.0,484.766152888,39.1359040814,3113653.0,483.0,619.0,1259.0,640.0,899.601432352,73.0319529228,5778140.0,893.0,410.0,1016.0,606.0,646.255799471,67.1816093266,4150901.0,644.0,0.0624561421573,0.33115825057,0.268702108413,0.164717784988,0.0358133293979,1057.98233298,0.16116,975.0,2127.0,1152.0,1451.15740308,123.787991723,9320784.0,1444.0,-0.178680419922,2.00335693359,2.18203735352,0.0570645974504,0.198462189732,366.525909424,0.0
+14500139.0,206.499999998,103.0,2.02195862616,228.0,447.0,219.0,349.863196126,23.2919033507,288987.0,348.0,280.0,614.0,334.0,502.0968523,29.9689963245,414732.0,500.0,527.0,886.0,359.0,639.945520581,50.7743971394,528595.0,634.0,392.0,793.0,401.0,575.489104116,43.9669477709,475354.0,571.0,-0.00683371303603,0.159029647708,0.165863360744,0.052930104204,0.0226457394955,43.7202660725,0.0471739,984.0,1750.0,766.0,1427.44915254,82.2050849155,1179073.0,1421.0,0.205444335938,5.2509765625,5.04553222656,3.91099370998,0.792643059757,3230.48080444,4.14839
+14619529.0,6403.75,2900.0,10.222941638,247.0,470.0,223.0,302.428967402,12.1837075273,7746718.0,301.0,305.0,703.0,398.0,406.819168456,20.799075405,10420673.0,404.0,389.0,948.0,559.0,535.027288698,39.000664131,13704724.0,526.0,290.0,957.0,667.0,455.291430802,33.7107244127,11662290.0,450.0,-0.0101910829544,0.188081935048,0.198273018003,0.0804696122654,0.0183055560554,2061.22911818,0.0774125,843.0,2130.0,1287.0,1164.53956666,63.7941600195,29829681.0,1155.0,-0.218017578125,2.22207641602,2.44009399414,0.576338552326,0.410646024421,14762.9120178,0.58963
+14474070.0,226.000000003,203.0,3.80922728379,270.0,374.0,104.0,309.542035398,14.5743593286,279826.0,309.0,389.0,548.0,159.0,449.088495575,25.7289935012,405976.0,447.0,620.0,949.0,329.0,766.091814159,47.8303530862,692547.0,764.0,476.0,745.0,269.0,613.434734513,47.3348567207,554545.0,616.0,0.0611439831555,0.20000000298,0.138856019825,0.111138378826,0.0230302634401,100.469094459,0.108625,1147.0,1661.0,514.0,1372.06526549,80.0054419425,1240347.0,1371.0,-0.141448974609,0.628997802734,0.770446777344,0.0672622275563,0.126852212564,60.8050537109,0.0
+14527896.0,5816.74999998,2346.0,8.67726531344,219.0,357.0,138.0,282.810633085,16.7950970438,6580155.0,282.0,266.0,523.0,257.0,389.359908884,31.5790315105,9059237.0,387.0,514.0,990.0,476.0,742.470064899,64.1280469703,17275051.0,735.0,228.0,676.0,448.0,456.875445911,52.4350570752,10630121.0,453.0,0.0735294148326,0.457788348198,0.384258933365,0.239023976623,0.0419826829611,5561.37086408,0.237217,721.0,1531.0,810.0,1129.04598788,98.4199714084,26269513.0,1122.0,0.651519775391,3.7087097168,3.05718994141,2.23288046631,0.478178018668,51952.4298096,2.28281
+14455492.0,1659.50000001,1267.0,8.77370553644,191.0,306.0,115.0,249.992316963,10.5815859899,1659449.0,249.0,247.0,435.0,188.0,350.264085568,19.7165208858,2325053.0,351.0,626.0,1200.0,574.0,920.971527569,57.4507919426,6113409.0,921.0,157.0,505.0,348.0,322.286532088,31.8560737216,2139338.0,322.0,0.300595223904,0.644268751144,0.343673527241,0.481764735937,0.0381567455102,3197.95431715,0.481743,595.0,1246.0,651.0,922.542934619,60.1425359079,6123840.0,922.0,-0.0782775878906,1.99310302734,2.07138061523,0.489755683938,0.440297565772,3250.99822998,0.407089
+14422498.0,95.2500000033,124.0,3.58413418743,214.0,303.0,89.0,255.590551181,16.7517089647,97380.0,255.0,261.0,404.0,143.0,334.034120735,29.8071912808,127267.0,334.0,546.0,1011.0,465.0,765.564304462,94.8594716185,291680.0,776.0,176.0,475.0,299.0,322.708661417,50.1074609366,122952.0,325.0,0.275362312794,0.552662730217,0.277300417423,0.407875755015,0.0455342554592,155.400662661,0.402202,669.0,1182.0,513.0,912.333333333,93.3405790213,347599.0,911.0,0.12353515625,1.63290405273,1.50936889648,0.425034170076,0.246391015389,161.938018799,0.359283
+14412897.0,30.5000000005,54.0,2.7582835422,272.0,303.0,31.0,288.0,6.72772584771,35136.0,289.0,368.0,430.0,62.0,397.549180328,15.624225861,48501.0,398.0,614.0,748.0,134.0,662.336065574,28.2072571338,80805.0,662.0,437.0,535.0,98.0,476.918032787,22.8450196043,58184.0,475.5,0.130074560642,0.192242830992,0.0621682703495,0.162846635111,0.0120446141944,19.8672894835,0.16482,1083.0,1264.0,181.0,1162.46721311,41.0573737764,141821.0,1163.5,-0.000823974609375,1.26849365234,1.26931762695,0.331241044842,0.172311696186,40.4114074707,0.338226
+14397690.0,1528.00000003,1241.0,8.95581620784,271.0,429.0,158.0,391.018979058,11.8403137563,2389908.0,392.0,395.0,699.0,304.0,619.687827225,20.4221336526,3787532.0,622.0,747.0,1140.0,393.0,1017.88530759,26.4424217679,6221315.0,1021.0,467.0,935.0,468.0,813.070189791,27.7317191583,4969485.0,816.0,0.0563535913825,0.24307204783,0.186718456447,0.111990754271,0.0103362334691,684.487490103,0.110872,1134.0,2018.0,884.0,1823.77699607,56.6244416857,11146925.0,1830.0,-0.0117492675781,1.35452270508,1.36627197266,0.258197065423,0.18519737075,1578.10046387,0.230225
+14386771.0,119.000000002,114.0,2.94799293666,206.0,449.0,243.0,295.039915966,21.5740975252,140439.0,292.0,243.0,582.0,339.0,387.153361345,46.1115245767,184285.0,374.0,428.0,975.0,547.0,725.43487395,59.5883106574,345307.0,739.0,232.0,877.0,645.0,543.071428571,57.1413471439,258502.0,553.0,0.0529157668352,0.31707316637,0.264157399535,0.144854828457,0.0236523220072,68.9508983456,0.145624,687.0,1908.0,1221.0,1225.26470588,101.907424696,583226.0,1214.0,-0.228149414062,5.45123291016,5.67938232422,2.848275962,2.28228758486,1355.77935791,4.20447
+14359505.0,7.50000000047,13.0,1.33908390031,194.0,269.0,75.0,214.866666667,17.1322956884,6446.0,209.0,221.0,333.0,112.0,254.033333333,24.7716011235,7621.0,248.5,400.0,571.0,171.0,510.333333333,38.8890158728,15310.0,520.0,222.0,320.0,98.0,261.866666667,24.1339778919,7856.0,260.0,0.203804343939,0.4056224823,0.201818138361,0.321368676921,0.0497498794138,9.64106030762,0.328352,651.0,922.0,271.0,730.766666667,58.1731228509,21923.0,711.5,2.93362426758,3.63330078125,0.699676513672,3.07260843913,0.192237138974,92.1782531738,3.0079
+14353579.0,37.5000000007,40.0,1.84263546383,176.0,242.0,66.0,223.393333333,12.6743292612,33509.0,226.0,217.0,345.0,128.0,306.14,24.9212171987,45921.0,310.5,760.0,1177.0,417.0,997.273333333,81.251206897,149591.0,993.5,140.0,304.0,164.0,247.973333333,33.8360649144,37196.0,253.0,0.519999980927,0.708333313465,0.188333332539,0.602290885846,0.0403623596422,90.3436328769,0.60155,533.0,891.0,358.0,777.506666667,70.6848165371,116626.0,791.0,0.151489257812,1.61557006836,1.46408081055,0.576214192708,0.265443036588,86.4321289062,0.601578
+14275616.0,490.749999996,134.0,1.70635626846,196.0,312.0,116.0,248.27050433,12.1021160774,487355.0,248.0,256.0,431.0,175.0,350.777381559,19.9829998526,688576.0,351.0,799.0,1282.0,483.0,1148.7845135,69.9811554913,2255064.0,1164.0,172.0,431.0,259.0,291.450331126,28.352952529,572117.0,291.0,0.39061370492,0.6949685812,0.30435487628,0.595012148621,0.0362690913899,1168.00884774,0.60161,624.0,1139.0,515.0,890.498217015,56.7059100646,1748048.0,890.0,-0.166442871094,1.42428588867,1.59072875977,0.199394346559,0.355351808765,391.411102295,0.0
+14304631.0,1052.24999999,644.0,5.60043122253,200.0,464.0,264.0,281.102874792,26.091958907,1183162.0,276.0,281.0,662.0,381.0,411.817058684,41.8376784306,1733338.0,405.0,582.0,1337.0,755.0,1002.45949157,96.1710918761,4219352.0,1005.0,199.0,782.0,583.0,421.979805179,75.4406447,1776113.0,411.0,0.163043484092,0.701672255993,0.538628771901,0.408912345894,0.0767488073687,1721.11206387,0.411111,703.0,1896.0,1193.0,1114.89973866,136.221738381,4692613.0,1090.0,-0.232025146484,3.42071533203,3.65274047852,0.136427321267,0.492469220652,574.222595215,0.0
+14293528.0,38.4999999981,42.0,1.90947507449,226.0,297.0,71.0,258.623376623,13.6866974577,39828.0,260.0,292.0,421.0,129.0,350.292207792,23.8776440909,53945.0,353.0,654.0,866.0,212.0,747.779220779,44.3607183718,115158.0,745.5,280.0,475.0,195.0,368.512987013,35.8809787566,56751.0,375.0,0.269992083311,0.423589736223,0.153597652912,0.340822972454,0.0282981034387,52.4867377579,0.340827,801.0,1193.0,392.0,977.428571429,72.6528712657,150524.0,987.5,0.0757446289062,1.85235595703,1.77661132812,1.11089691558,0.752483998592,171.078125,1.69762
+14281250.0,111.999999998,81.0,2.15909163857,310.0,433.0,123.0,384.517857143,16.2385850802,172264.0,387.0,446.0,689.0,243.0,606.904017857,29.9472330871,271893.0,613.0,822.0,1105.0,283.0,1036.16964286,37.3788252684,464204.0,1040.0,522.0,892.0,370.0,810.011160714,50.2058918043,362885.0,822.0,0.0881104022264,0.248677253723,0.160566851497,0.123176511793,0.0190932624532,55.1830772832,0.119705,1305.0,1978.0,673.0,1801.43303571,93.3895450408,807042.0,1823.0,0.016357421875,0.372131347656,0.355773925781,0.161972658975,0.0632832323513,72.5637512207,0.166565
+14272391.0,306.249999976,312.0,5.02934714497,174.0,545.0,371.0,299.358367347,36.5060316709,366714.0,297.0,255.0,793.0,538.0,425.675102041,56.0937603617,521452.0,422.0,437.0,1326.0,889.0,758.137142857,93.2067833215,928718.0,770.0,148.0,1082.0,934.0,481.248163265,88.6420941989,589529.0,479.0,0.0379589311779,0.494017094374,0.456058163196,0.227168303771,0.0613848839469,278.281172119,0.22546,687.0,2420.0,1733.0,1206.28163265,169.312684619,1477695.0,1196.0,-0.114868164062,0.5810546875,0.695922851562,0.0825319375797,0.13050569967,101.101623535,0.0
+14260970.0,488.749999986,276.0,3.52176817734,286.0,376.0,90.0,331.669565217,8.72309276469,648414.0,333.0,472.0,606.0,134.0,561.44398977,15.7947612941,1097623.0,565.0,529.0,808.0,279.0,665.945780051,29.1930364528,1301924.0,662.0,687.0,946.0,259.0,877.276214834,38.4530726325,1715075.0,886.0,-0.206632658839,0.0511049740016,0.257737632841,-0.136795899117,0.0302554134576,-267.435982774,-0.141753,1456.0,1875.0,419.0,1770.38976982,58.8527009308,3461112.0,1786.0,-0.132843017578,0.995788574219,1.1286315918,0.0534519361413,0.124342128762,104.498535156,0.0
+14254774.0,2.49999999977,8.0,1.42729929299,211.0,248.0,37.0,230.1,11.4494541355,2301.0,231.5,245.0,316.0,71.0,292.4,21.397196078,2924.0,296.0,418.0,544.0,126.0,465.2,42.0233268555,4652.0,455.5,278.0,388.0,110.0,326.2,37.7088848947,3262.0,314.5,0.13984169066,0.227091640234,0.0872499495745,0.176729536057,0.0274596866284,1.76729536057,0.166215,747.0,942.0,195.0,848.7,62.5172776119,8487.0,847.5,0.0,0.0,0.0,0.0,0.0,0.0,0.0
+14246112.0,8.25,20.0,1.96425600437,241.0,347.0,106.0,281.848484848,24.2451134872,9301.0,282.0,269.0,424.0,155.0,332.636363636,30.612750544,10977.0,330.0,396.0,664.0,268.0,508.121212121,61.9837503514,16768.0,496.0,201.0,376.0,175.0,296.787878788,44.0844627173,9794.0,294.0,0.199079394341,0.368916809559,0.169837415218,0.264219901327,0.0403897141037,8.71925674379,0.261111,721.0,1119.0,398.0,911.272727273,87.3808358184,30072.0,915.0,-0.0115356445312,0.248748779297,0.260284423828,0.0215518835819,0.0684228745664,0.711212158203,0.0
+14250305.0,28.5,38.0,2.00796544417,335.0,383.0,48.0,357.254385965,9.7655062512,40727.0,357.0,384.0,470.0,86.0,417.570175439,14.9372778106,47603.0,416.0,188.0,417.0,229.0,256.587719298,34.7274630702,29251.0,253.5,238.0,437.0,199.0,269.929824561,35.5339519625,30772.0,259.0,-0.123543120921,0.0407766997814,0.164319820702,-0.0258498620038,0.038933038127,-2.94688426843,-0.0190726,977.0,1259.0,282.0,1044.75438596,49.9065023017,119102.0,1033.5,0.129638671875,1.20581054688,1.076171875,0.733800519977,0.244951302531,83.6532592773,0.7267
+14236616.0,34.2500000005,30.0,1.44605907331,319.0,447.0,128.0,391.664233577,22.1953100104,53658.0,397.0,466.0,685.0,219.0,560.919708029,35.5151984314,76846.0,565.0,571.0,985.0,414.0,718.160583942,74.5984123015,98388.0,709.0,543.0,901.0,358.0,654.649635036,54.1008238588,89687.0,647.0,-0.0259541980922,0.165930598974,0.191884797066,0.0452314596037,0.0370303977067,6.1967099657,0.0397767,1334.0,2033.0,699.0,1607.23357664,102.875182168,220191.0,1611.0,0.123077392578,2.45010375977,2.32702636719,1.29028186659,0.656516397129,176.768615723,1.01514
+14221939.0,235.750000001,130.0,2.38843028635,214.0,318.0,104.0,258.924708378,12.1820606896,244166.0,258.0,260.0,468.0,208.0,358.335100742,25.7072619555,337910.0,358.0,674.0,1182.0,508.0,909.208907741,97.1493141065,857384.0,898.0,204.0,545.0,341.0,348.274655355,36.8218874272,328423.0,348.0,0.337304532528,0.614369511604,0.277064979076,0.444816696998,0.0470279948774,419.462145269,0.440129,679.0,1322.0,643.0,965.534464475,70.6448155032,910499.0,963.0,-0.105499267578,1.93118286133,2.03668212891,0.628388357314,0.457097104679,592.570220947,0.706177
+14310353.0,5958.24999999,3820.0,13.960438831,284.0,473.0,189.0,408.67318424,14.1341574415,9739908.0,409.0,435.0,766.0,331.0,657.883942433,25.6250400912,15679348.0,659.0,754.0,1313.0,559.0,1098.52125205,38.2322805366,26181057.0,1099.0,510.0,1050.0,540.0,893.58444174,39.8077051941,21296798.0,897.0,0.0485639683902,0.230317279696,0.181753311306,0.103062914124,0.0115485940158,2456.29843232,0.101435,1229.0,2274.0,1045.0,1960.14156841,75.4374468653,46716054.0,1964.0,-0.207061767578,1.38067626953,1.58773803711,0.11213885821,0.1499838717,2672.60540771,0.0604248
+14228024.0,942.999999982,593.0,5.44745830701,207.0,323.0,116.0,240.936373277,11.3613725963,908812.0,240.0,266.0,494.0,228.0,322.054082715,21.7450824948,1214788.0,320.0,528.0,931.0,403.0,695.913573701,60.6141330413,2624986.0,690.0,241.0,452.0,211.0,338.40747614,31.7047232682,1276473.0,335.0,0.238267153502,0.481973439455,0.243706285954,0.345453030196,0.034105957672,1303.0488299,0.342105,717.0,1197.0,480.0,901.397932131,61.755379173,3400073.0,895.0,-0.0901794433594,2.03982543945,2.13000488281,0.581299273106,0.449445319252,2192.66085815,0.549057
+14201376.0,120.750000004,108.0,2.7725236138,198.0,321.0,123.0,239.960662526,20.4592334436,115901.0,235.0,249.0,438.0,189.0,304.608695652,32.9589443927,147126.0,296.0,442.0,1152.0,710.0,700.438923395,151.287195849,338312.0,669.0,177.0,480.0,303.0,268.300207039,51.6860539992,129589.0,259.0,0.229116946459,0.62714779377,0.398030847311,0.440699375688,0.0744285997877,212.857798457,0.444003,629.0,1227.0,598.0,812.869565217,102.578100151,392616.0,789.0,-0.114074707031,1.15142822266,1.26550292969,0.357833704346,0.285217390933,172.833679199,0.331848
+14151464.0,1218.00000001,572.0,4.62346370438,235.0,310.0,75.0,261.795361248,6.07768157221,1275467.0,262.0,300.0,448.0,148.0,363.508210181,12.4414859638,1771012.0,365.0,223.0,587.0,364.0,323.36001642,35.4127913398,1575410.0,315.0,241.0,443.0,202.0,314.624589491,16.9872112996,1532851.0,315.0,-0.199312716722,0.274809151888,0.47412186861,0.011574019195,0.0610307754958,56.3886215178,-0.00465116,785.0,1201.0,416.0,939.92816092,33.9269682424,4579330.0,942.0,-0.0760192871094,1.71716308594,1.79318237305,0.29057055193,0.381491788776,1415.659729,0.144394
+14205570.0,2807.75000003,2322.0,12.361696178,245.0,403.0,158.0,316.614459977,16.4987395382,3555897.0,315.0,360.0,620.0,260.0,478.966432197,30.5660723399,5379272.0,477.0,631.0,1044.0,413.0,794.582851037,50.9307901804,8923960.0,790.0,456.0,883.0,427.0,656.509037486,47.879708247,7373253.0,653.0,0.00342231336981,0.240485832095,0.237063518725,0.095405620102,0.0203862016254,1071.50051937,0.092707,1113.0,1882.0,769.0,1452.08992966,91.1106936925,16308422.0,1444.0,-0.340057373047,1.44482421875,1.7848815918,0.134601988719,0.217936080073,1511.7149353,0.0
+14179869.0,4.74999999977,15.0,1.94150951032,211.0,264.0,53.0,236.473684211,18.3399719367,4493.0,231.0,269.0,376.0,107.0,320.315789474,35.6666623519,6086.0,319.0,388.0,552.0,164.0,460.263157895,41.7622873255,8745.0,458.0,131.0,313.0,182.0,230.421052632,49.0953055849,4378.0,234.0,0.24304716289,0.495183050632,0.252135887742,0.34001434712,0.0671627096889,6.46027259529,0.331429,612.0,927.0,315.0,787.210526316,97.2823232428,14957.0,787.0,0.259307861328,0.944671630859,0.685363769531,0.439453125,0.18369919391,8.349609375,0.372009
+14197974.0,15527.2500001,4050.0,9.16859561593,175.0,324.0,149.0,251.861759165,10.4265614034,15642882.0,251.0,204.0,479.0,275.0,356.581477725,21.2636882624,22146919.0,358.0,578.0,1237.0,659.0,942.414046273,62.8336978582,58532394.0,941.0,132.0,519.0,387.0,323.242959957,33.1597027722,20076297.0,322.0,0.303523033857,0.698285698891,0.394762665033,0.48910646931,0.0440081192414,30377.9137024,0.48871,548.0,1317.0,769.0,931.686196847,61.7347384278,57866098.0,931.0,-0.314849853516,5.4352722168,5.75012207031,0.282749188494,0.598169353718,17561.2693481,0.0
+14143479.0,75.2499999998,77.0,2.50398971689,426.0,466.0,40.0,442.631229236,7.77509151011,133232.0,442.0,698.0,766.0,68.0,729.61461794,13.718248835,219614.0,730.0,1139.0,1252.0,113.0,1192.15614618,20.9028492494,358839.0,1193.0,938.0,1056.0,118.0,996.617940199,20.7653448144,299982.0,995.0,0.0785484611988,0.101154737175,0.0226062759757,0.0893662258042,0.00457710771634,26.8992339671,0.08901,2064.0,2281.0,217.0,2168.86378738,38.0149216761,652828.0,2166.0,-0.0408020019531,0.464538574219,0.505340576172,0.0669216016598,0.0862340391339,20.1434020996,0.0284424
+14139891.0,2.5,10.0,1.78412411615,233.0,293.0,60.0,257.7,16.7514178504,2577.0,255.5,286.0,358.0,72.0,315.1,24.9857959649,3151.0,309.5,392.0,551.0,159.0,477.6,47.5798276584,4776.0,485.0,203.0,320.0,117.0,248.4,38.8077311885,2484.0,233.5,0.222963958979,0.387696713209,0.16473275423,0.317799842358,0.0500894837812,3.17799842358,0.313831,737.0,947.0,210.0,821.2,76.4562620065,8212.0,800.5,0.0128173828125,0.642700195312,0.6298828125,0.151849365234,0.241064769381,1.51849365234,0.034317
+14126662.0,31.0000000019,74.0,3.74926330037,260.0,448.0,188.0,337.822580645,41.0632966142,41890.0,334.0,296.0,515.0,219.0,382.161290323,41.3611917016,47388.0,377.0,271.0,1071.0,800.0,481.048387097,138.472883967,59650.0,461.5,208.0,603.0,395.0,335.540322581,74.0725885472,41607.0,316.5,0.0322580635548,0.340118736029,0.307860672474,0.170471552189,0.069019474378,21.1384724714,0.166225,836.0,1497.0,661.0,1055.52419355,130.087158357,130885.0,1033.0,0.00543212890625,2.77221679688,2.76678466797,1.68040983139,0.583255444925,208.370819092,1.59001
+14119579.0,580.749999979,242.0,2.83279941942,206.0,359.0,153.0,264.266465777,13.6058541515,613891.0,263.0,253.0,475.0,222.0,357.262160999,24.7004206617,829920.0,354.0,407.0,871.0,464.0,638.86698235,60.9295122745,1484088.0,637.0,206.0,584.0,378.0,373.001291433,38.2974570961,866482.0,368.0,0.148496240377,0.435897439718,0.287401199341,0.262593787643,0.0372972082629,610.005368695,0.260618,665.0,1404.0,739.0,994.529918209,72.79244363,2310293.0,986.0,-0.163330078125,1.75955200195,1.92288208008,0.229752316025,0.270638353441,533.714630127,0.151581
+14176665.0,3802.24999999,1320.0,6.0387724481,338.0,512.0,174.0,438.172595174,17.8233600563,6664167.0,437.0,501.0,804.0,303.0,685.466763101,30.8906702692,10425264.0,686.0,846.0,1306.0,460.0,1083.19034782,46.4278033722,16474242.0,1083.0,590.0,1011.0,421.0,867.095009534,43.2452509909,13187648.0,867.0,0.0736368745565,0.251028805971,0.177391931415,0.110954811586,0.0119665973833,1687.5117294,0.109034,1454.0,2295.0,841.0,1990.73436781,88.1245595002,30277079.0,1990.0,-0.168792724609,1.18246459961,1.35125732422,0.115905115611,0.151198098796,1762.80090332,0.0671997
+14209167.0,4456.74999999,2780.0,11.7471016642,193.0,347.0,154.0,254.096314579,12.3934073656,4529775.0,253.0,242.0,523.0,281.0,359.088517417,22.8633170882,6401471.0,356.0,500.0,1107.0,607.0,796.384024233,56.0426092266,14197138.0,794.0,175.0,667.0,492.0,369.014248051,40.7286940682,6578417.0,364.0,0.209141269326,0.667272746563,0.458131477237,0.367314032579,0.0450595586927,6548.10725878,0.367867,619.0,1533.0,914.0,982.199080047,73.3706500168,17509663.0,973.0,-0.316436767578,2.26022338867,2.57666015625,0.214426924083,0.353982913422,3822.58877563,0.00436401
+14116193.0,3.5,8.0,1.20628807018,331.0,405.0,74.0,367.571428571,24.067507099,5146.0,364.5,364.0,437.0,73.0,392.714285714,23.1776634205,5498.0,382.5,265.0,397.0,132.0,329.0,35.5065386332,4606.0,331.5,219.0,335.0,116.0,270.285714286,28.1562694653,3784.0,269.5,0.0454545468092,0.14649681747,0.10104227066,0.0976658862616,0.0264705074544,1.36732240766,0.102764,965.0,1177.0,212.0,1030.57142857,63.7166879752,14428.0,1005.0,0.731658935547,8.13946533203,7.40780639648,1.79190063477,1.80855385947,25.0866088867,1.12885
+14108501.0,19.9999999998,23.0,1.45080120017,307.0,427.0,120.0,375.0625,24.6796189952,30005.0,376.0,326.0,478.0,152.0,392.8875,29.7018491638,31431.0,392.5,178.0,458.0,280.0,271.45,46.0450594527,21716.0,273.5,205.0,475.0,270.0,273.8375,39.4893795058,21907.0,271.0,-0.174013927579,0.10019646585,0.274210393429,-0.00654992286582,0.0544386824426,-0.523993829265,0.00178764,853.0,1367.0,514.0,1041.7875,80.1022305791,83343.0,1041.0,0.939666748047,3.56201171875,2.6223449707,1.78821678162,0.493049001826,143.057342529,1.68042
+14088217.0,3297.75000003,2135.0,10.4877924167,252.0,433.0,181.0,323.810855887,18.5853351638,4271389.0,321.0,357.0,650.0,293.0,486.358881055,33.5127689462,6415560.0,481.0,627.0,1102.0,475.0,873.567508149,51.9683163872,11523229.0,872.0,447.0,915.0,468.0,697.482677583,46.6510244249,9200494.0,697.0,0.025559104979,0.260292172432,0.234733067453,0.112276129148,0.0201590004623,1481.0344196,0.108389,1074.0,1993.0,919.0,1507.65241453,89.3594330775,19887443.0,1499.0,-0.225036621094,4.39141845703,4.61645507812,0.161361406303,0.424004503303,2128.51831055,0.0
+14060849.0,323.000000001,176.0,2.76252663918,250.0,499.0,249.0,394.868421053,33.319352956,510170.0,402.0,414.0,729.0,315.0,587.890866873,46.3594417814,759555.0,600.0,512.0,1032.0,520.0,715.879256966,57.1800640479,924916.0,704.0,475.0,962.0,487.0,691.523219814,53.411672286,893448.0,691.0,-0.0379562042654,0.171648159623,0.209604363889,0.0172394583574,0.0287693500144,22.2733801977,0.0081117,1180.0,2060.0,880.0,1674.28250774,121.531837503,2163173.0,1696.5,-0.0203247070312,4.31533813477,4.3356628418,3.23800782006,0.715666329072,4183.50610352,3.5137
+14058809.0,115.999999999,82.0,2.14773119802,216.0,306.0,90.0,261.573275862,10.5900804087,121370.0,261.0,296.0,437.0,141.0,370.056034483,18.7807531192,171706.0,371.0,771.0,1106.0,335.0,963.560344828,57.3012364904,447092.0,966.0,213.0,484.0,271.0,348.515086207,33.7663719676,161711.0,349.0,0.375886529684,0.629565238953,0.253678709269,0.468875042645,0.0407760469697,217.558019787,0.468318,725.0,1227.0,502.0,980.144396552,59.3731501605,454787.0,982.0,-0.0472106933594,1.60217285156,1.64938354492,0.1121337496,0.312489778989,52.0300598145,0.0
+14049606.0,96.9999999981,59.0,1.6899008037,228.0,271.0,43.0,247.412371134,6.93712941214,95996.0,248.0,316.0,394.0,78.0,349.886597938,12.8182185814,135756.0,350.0,855.0,1143.0,288.0,975.659793814,42.3360723572,378556.0,970.0,258.0,387.0,129.0,313.152061856,20.5614510418,121503.0,313.0,0.449275374413,0.615499258041,0.166223883629,0.513925562123,0.0279152270297,199.403118104,0.510331,808.0,1050.0,242.0,910.451030928,38.3569127625,353255.0,911.0,-0.0883178710938,0.974548339844,1.06286621094,0.113027985563,0.246370933158,43.8548583984,0.0
+14048983.0,149.250000002,79.0,1.824168657,376.0,475.0,99.0,434.5360134,16.2230307429,259418.0,436.0,508.0,629.0,121.0,573.167504188,20.6041599279,342181.0,575.0,146.0,376.0,230.0,242.693467337,36.4331126775,144888.0,243.0,339.0,503.0,164.0,404.793969849,26.1958113665,241662.0,407.0,-0.459459453821,-0.111764706671,0.34769474715,-0.254010691727,0.0526394634117,-151.644382961,-0.251534,1262.0,1562.0,300.0,1412.49748744,48.808023859,843261.0,1414.0,-0.0478210449219,1.57278442383,1.62060546875,0.197288730436,0.319577052763,117.78137207,0.00415039
+14040153.0,194.000000007,114.0,2.3088677327,189.0,458.0,269.0,316.243556701,28.263737828,245405.0,323.0,234.0,671.0,437.0,463.62242268,55.7198715438,359771.0,479.0,366.0,1008.0,642.0,595.06314433,96.0104557365,461769.0,604.0,126.0,801.0,675.0,374.384020619,72.8374440093,290522.0,381.5,0.0761245638132,0.607476651669,0.531352087855,0.229732951965,0.0506391473035,178.272770725,0.230218,549.0,1930.0,1381.0,1154.25,146.086312486,895698.0,1189.0,0.0624694824219,5.6257019043,5.56323242188,4.44875512664,1.64954864333,3452.23397827,5.13083
+14048074.0,4.75000000047,15.0,1.94150951018,191.0,244.0,53.0,214.947368421,12.0981672566,4084.0,215.0,212.0,313.0,101.0,258.789473684,23.825194421,4917.0,260.0,456.0,706.0,250.0,579.894736842,56.490236452,11018.0,571.0,123.0,288.0,165.0,194.631578947,37.4449919725,3698.0,198.0,0.327102810144,0.651063859463,0.323961049318,0.498395091609,0.0792119746055,9.46950674057,0.482625,526.0,845.0,319.0,668.368421053,73.1510409512,12699.0,672.0,0.885406494141,1.50674438477,0.621337890625,1.18022075452,0.24340861119,22.4241943359,1.30084
+14043846.0,30.4999999993,43.0,2.19641096883,198.0,262.0,64.0,239.483606557,13.3079746871,29217.0,242.5,244.0,351.0,107.0,308.31147541,22.746674038,37614.0,308.0,752.0,1032.0,280.0,918.516393443,63.7329512538,112059.0,929.0,153.0,332.0,179.0,257.745901639,37.0720524569,31445.0,260.5,0.500763356686,0.665024638176,0.16426128149,0.563692154943,0.0357987637481,68.770442903,0.560365,595.0,945.0,350.0,805.540983607,72.7820852058,98276.0,811.0,-0.00238037109375,0.882263183594,0.884643554688,0.171010502049,0.131020896712,20.86328125,0.138062
+14019849.0,2226.0,900.0,5.38114875128,219.0,647.0,428.0,294.062219227,11.7238149024,2618330.0,294.0,286.0,947.0,661.0,402.434636119,20.2375047642,3583278.0,402.0,280.0,1127.0,847.0,568.038185085,42.8673739509,5057812.0,565.0,85.0,1215.0,1130.0,492.833557951,39.9358556511,4388190.0,491.0,-0.0435261726379,0.534246563911,0.577772736549,0.0710873053377,0.015830968946,632.961366727,0.0699734,668.0,2694.0,2026.0,1189.3304133,67.1316527169,10589798.0,1188.0,-0.290618896484,1.71054077148,2.00115966797,0.312024814849,0.375876966529,2778.26895142,0.18042
+13970212.0,104.499999999,61.0,1.68332028818,204.0,262.0,58.0,235.897129187,8.39009677035,98605.0,236.0,247.0,368.0,121.0,314.899521531,19.0847881447,131628.0,311.0,841.0,1292.0,451.0,1133.27990431,80.3913313187,473711.0,1143.5,146.0,327.0,181.0,252.019138756,25.3239228619,105344.0,251.0,0.54852938652,0.734786570072,0.186257183552,0.6356422673,0.0345911026303,265.698467731,0.636873,597.0,948.0,351.0,802.815789474,50.6757403477,335577.0,800.0,-0.0117492675781,4.52667236328,4.53842163086,1.57144551984,1.63177036868,656.864227295,1.96481
+14026848.0,2.5,9.0,1.60571170454,188.0,268.0,80.0,219.5,22.3886131772,2195.0,217.5,236.0,376.0,140.0,282.3,41.9524731095,2823.0,275.5,355.0,629.0,274.0,457.6,82.2425680533,4576.0,450.0,200.0,480.0,280.0,298.0,82.646234034,2980.0,286.0,0.134355276823,0.301492542028,0.167137265205,0.220376847684,0.0509462668499,2.20376847684,0.215035,634.0,1124.0,490.0,799.8,146.086823499,7998.0,779.0,2.14779663086,3.90133666992,1.75354003906,2.95727539062,0.777437002972,29.5727539062,2.53029
+14018652.0,78.4999999984,115.0,3.66149191899,239.0,348.0,109.0,288.261146497,17.2507348673,90514.0,287.0,352.0,514.0,162.0,415.920382166,29.3970734686,130599.0,413.0,766.0,1055.0,289.0,869.831210191,52.1101251253,273127.0,869.0,345.0,638.0,293.0,461.515923567,55.5874940222,144916.0,454.0,0.193548381329,0.44801223278,0.254463851452,0.308248174466,0.05096031474,96.7899267823,0.308532,957.0,1500.0,543.0,1165.69745223,98.5552684991,366029.0,1153.5,-0.0654907226562,1.19934082031,1.26483154297,0.170189535542,0.235147291957,53.4395141602,0.0286255
+13986255.0,97.0000000009,72.0,2.06225182822,230.0,290.0,60.0,247.518041237,8.15299478709,96037.0,246.0,299.0,413.0,114.0,332.520618557,13.7577377527,129018.0,331.0,692.0,893.0,201.0,772.613402062,34.6901606088,299774.0,772.5,299.0,516.0,217.0,363.634020619,28.3798802937,141090.0,359.0,0.24074074626,0.443462908268,0.202722162008,0.360218718648,0.0363192625215,139.764862835,0.363724,828.0,1219.0,391.0,943.672680412,47.4980040387,366145.0,939.0,-0.0289001464844,1.07388305664,1.10278320312,0.210186043965,0.236394030113,81.5521850586,0.162476
+13982768.0,219.749999997,96.0,1.82684566578,269.0,378.0,109.0,329.390216155,19.5772486379,289534.0,326.0,283.0,338.0,55.0,310.791808874,11.4286081486,273186.0,310.0,193.0,394.0,201.0,244.491467577,26.3147502728,214908.0,238.0,187.0,379.0,192.0,221.369738339,24.7722007172,194584.0,215.0,-0.0512820519507,0.138833001256,0.190115053207,0.0497776013088,0.0414215559506,43.7545115504,0.0567686,784.0,1010.0,226.0,861.551763367,45.8240860846,757304.0,850.0,-0.00393676757812,1.00650024414,1.01043701172,0.233434683634,0.173805752674,205.189086914,0.215576
+13971666.0,655.499999996,199.0,2.19261204921,223.0,532.0,309.0,321.760488177,25.9762373557,843656.0,322.0,288.0,832.0,544.0,469.112509535,44.8017491149,1230013.0,467.0,596.0,1365.0,769.0,919.771929825,100.655736422,2411642.0,936.0,411.0,1252.0,841.0,736.506102212,92.9567031797,1931119.0,754.0,-0.0302325580269,0.29788684845,0.328119406477,0.111623167884,0.0349667497273,292.675946191,0.10826,963.0,2597.0,1634.0,1527.37909992,144.303742994,4004788.0,1546.0,-0.0258178710938,5.27322387695,5.29904174805,3.42727280536,1.11797144442,8986.30929565,3.83304
+13961666.0,105.499999998,80.0,2.19714553704,242.0,402.0,160.0,294.767772512,19.4385190537,124392.0,292.0,324.0,527.0,203.0,362.492890995,24.8488072069,152972.0,357.0,185.0,649.0,464.0,273.760663507,49.0760804811,115527.0,265.0,188.0,601.0,413.0,258.082938389,39.1802886278,108911.0,249.0,-0.200863927603,0.180327862501,0.381191790104,0.0277443830298,0.054096827024,11.7081296386,0.0378397,820.0,1509.0,689.0,915.343601896,76.6872638716,386275.0,896.0,-0.0625305175781,0.350769042969,0.413299560547,0.0452036925402,0.0808363134225,19.075958252,0.0
+13988597.0,1298.00000001,785.0,6.14649281803,191.0,393.0,202.0,273.703197227,16.4024502738,1421067.0,273.0,236.0,569.0,333.0,381.144260401,28.1056604419,1978901.0,380.0,426.0,1097.0,671.0,880.025616333,67.5832357785,4569093.0,882.0,138.0,665.0,527.0,385.641371341,47.3019149122,2002250.0,385.0,0.212312549353,0.63826996088,0.425957411528,0.3914524034,0.0495763487378,2032.42087846,0.390687,569.0,1606.0,1037.0,1040.48882897,88.2498306961,5402218.0,1038.0,-0.209411621094,1.4206237793,1.63003540039,0.150264933958,0.220410217135,780.175537109,0.048172
+13887113.0,26.7499999998,55.0,2.99982461437,225.0,425.0,200.0,305.317757009,45.5987370974,32669.0,304.0,257.0,508.0,251.0,350.046728972,46.2549584465,37455.0,348.0,280.0,827.0,547.0,506.112149533,136.230517057,54154.0,495.0,129.0,449.0,320.0,257.925233645,62.2448738173,27598.0,250.0,0.162790700793,0.511363625526,0.348572924733,0.318893671871,0.0788546345643,34.1216228902,0.318027,649.0,1382.0,733.0,913.289719626,118.178702744,97722.0,894.0,-3.0517578125e-05,4.31002807617,4.31005859375,2.11116469909,1.7838529575,225.894622803,3.47833
+13876779.0,735.249999997,208.0,2.16391843284,183.0,372.0,189.0,243.56749405,10.7420665305,716332.0,243.0,157.0,554.0,397.0,330.914654879,20.0752712968,973220.0,333.0,608.0,1315.0,707.0,942.603196192,105.815750787,2772196.0,951.0,47.0,691.0,644.0,283.973818429,33.9719216421,835167.0,282.0,0.27757447958,0.887425124645,0.609850645065,0.534562502526,0.0596582311323,1572.14831993,0.544601,388.0,1617.0,1229.0,858.455967358,61.8809650981,2524719.0,860.0,-0.143768310547,4.16696166992,4.31072998047,0.384984311827,0.813367922422,1132.23886108,0.0
+13864478.0,47.5000000014,75.0,3.06979607563,310.0,559.0,249.0,466.863157895,50.3220388103,88704.0,479.0,402.0,621.0,219.0,548.021052632,52.0464324977,104124.0,562.5,200.0,646.0,446.0,341.868421053,94.2162046216,64955.0,328.5,168.0,505.0,337.0,306.894736842,49.1858930748,58310.0,301.0,-0.132075473666,0.227467805147,0.359543278813,0.0419740777775,0.0905030718746,7.97507477773,0.0311681,961.0,1575.0,614.0,1321.77894737,107.581810138,251138.0,1340.0,-0.026611328125,1.44274902344,1.46936035156,0.119230732165,0.321238999215,22.6538391113,0.0
+13861974.0,302.499999999,243.0,3.94129236569,267.0,443.0,176.0,357.666115702,28.6000218278,432776.0,357.0,388.0,701.0,313.0,553.125619835,46.3452628994,669282.0,554.0,766.0,1193.0,427.0,979.266115702,67.6220433933,1184912.0,975.0,513.0,966.0,453.0,741.203305785,73.8097509,896856.0,745.0,0.0718346238136,0.252498328686,0.180663704872,0.139577741902,0.0303063131639,168.889067702,0.135101,1197.0,2106.0,909.0,1651.99504132,143.021792162,1998914.0,1659.0,-0.0598449707031,0.584625244141,0.644470214844,0.0713235650181,0.137689535076,86.3015136719,0.0
+13858576.0,21.2499999995,24.0,1.46867885588,188.0,301.0,113.0,234.694117647,26.2459065848,19949.0,237.0,224.0,412.0,188.0,301.658823529,42.3927166167,25641.0,301.0,605.0,1030.0,425.0,808.317647059,114.361882972,68707.0,788.0,110.0,407.0,297.0,236.376470588,67.1020252996,20092.0,242.0,0.428771942854,0.719745218754,0.2909732759,0.554829476861,0.0696772502262,47.1605055332,0.54792,522.0,1120.0,598.0,772.729411765,135.3757636,65682.0,770.0,-0.000823974609375,1.73355102539,1.734375,0.867146929573,0.427976346471,73.7074890137,0.646057
+13855733.0,50.25,54.0,2.14892270605,242.0,455.0,213.0,336.800995025,36.0632418391,67697.0,342.0,281.0,513.0,232.0,357.218905473,33.3319179918,71801.0,352.0,207.0,592.0,385.0,313.114427861,73.9821939099,62936.0,290.0,220.0,495.0,275.0,287.572139303,68.9970510575,57802.0,256.0,-0.0793650820851,0.155080214143,0.234445296228,0.0423800856638,0.0499081550129,8.51839721843,0.045045,760.0,1458.0,698.0,981.592039801,109.624064687,197300.0,958.0,0.0991821289062,2.12054443359,2.02136230469,0.82091222355,0.394912640655,165.003356934,0.835175
+13854898.0,9.75000000093,21.0,1.89719536451,241.0,362.0,121.0,284.435897436,26.3358923182,11093.0,285.0,257.0,501.0,244.0,354.179487179,55.8982004182,13813.0,351.0,378.0,566.0,188.0,438.025641026,47.7077036082,17083.0,414.0,204.0,365.0,161.0,260.282051282,39.7130403681,10151.0,247.0,0.184019371867,0.302564114332,0.118544742465,0.25683518098,0.0304909868234,10.0165720582,0.262195,753.0,1183.0,430.0,898.897435897,97.8087602578,35057.0,880.0,0.289703369141,0.429809570312,0.140106201172,0.32900766226,0.0372478847342,12.8312988281,0.308685
+13850614.0,20.0,22.0,1.38772288711,303.0,433.0,130.0,387.5875,30.5608793026,31007.0,392.0,496.0,635.0,139.0,584.1875,32.7254082289,46735.0,586.0,623.0,894.0,271.0,747.3625,69.5608086048,59789.0,744.0,539.0,735.0,196.0,677.1625,37.0308802724,54173.0,682.0,-0.0257611237466,0.121311478317,0.147072602063,0.047831231392,0.042065441036,3.82649851136,0.0502779,1369.0,1788.0,419.0,1648.9375,85.5656683124,131915.0,1667.0,-0.11572265625,2.49011230469,2.60583496094,1.70032310486,0.89733582042,136.025848389,2.09724
+13851654.0,10.75,15.0,1.29057157331,412.0,480.0,68.0,450.046511628,14.5633395869,19352.0,452.0,482.0,638.0,156.0,556.558139535,42.6572616167,23932.0,549.0,204.0,414.0,210.0,280.581395349,42.02503825,12065.0,275.0,233.0,445.0,212.0,310.744186047,47.9462358894,13362.0,298.0,-0.21387283504,0.052096568048,0.265969403088,-0.0502492419477,0.0672295132815,-2.16071740375,-0.0293542,1175.0,1517.0,342.0,1317.34883721,88.572893045,56646.0,1290.0,1.89526367188,1.91479492188,0.01953125,1.90643736374,0.00480867742289,81.9768066406,1.90698
+13856492.0,4914.25,1499.0,6.03209368066,240.0,430.0,190.0,328.05514575,24.3152258716,6448580.0,328.0,307.0,680.0,373.0,488.283054383,41.9539309674,9598180.0,489.0,596.0,1240.0,644.0,967.982601618,59.9497890878,19027634.0,966.0,298.0,850.0,552.0,574.899170779,74.8470901113,11300793.0,575.0,0.142064377666,0.483870953321,0.341806575656,0.257343626075,0.0458138323464,5058.60365775,0.252207,849.0,1842.0,993.0,1391.23737091,137.458032171,27347553.0,1393.0,-0.317993164062,3.44689941406,3.76489257812,0.178044633681,0.198422212047,3499.82336426,0.160889
+13839344.0,84.9999999995,65.0,1.98883595066,232.0,281.0,49.0,253.923529412,8.39993203136,86334.0,253.0,315.0,395.0,80.0,349.273529412,13.8455303644,118753.0,348.0,778.0,1026.0,248.0,913.514705882,46.0457230073,310595.0,913.5,260.0,399.0,139.0,319.555882353,25.9755506218,108649.0,318.0,0.395604401827,0.564853549004,0.169249147177,0.481699255021,0.0346193028667,163.777746707,0.479534,824.0,1070.0,246.0,922.752941176,46.001510431,313736.0,917.5,-0.114868164062,0.340759277344,0.455627441406,0.039262749167,0.0779906521543,13.3493347168,0.0
+13824049.0,49.0000000009,74.0,2.98214494158,187.0,326.0,139.0,259.071428571,28.5434684619,50778.0,258.0,219.0,461.0,242.0,344.459183673,51.3891055649,67514.0,341.0,488.0,954.0,466.0,747.658163265,114.46686752,146541.0,768.0,199.0,585.0,386.0,393.545918367,83.2362198785,77135.0,396.0,0.193659543991,0.464508086443,0.270848542452,0.314417152456,0.0548762686294,61.6257618815,0.31209,671.0,1346.0,675.0,997.076530612,155.303584398,195427.0,998.0,-0.0117492675781,1.40509033203,1.41683959961,0.264410836356,0.213634146944,51.8245239258,0.223663
+13786173.0,671.249999994,193.0,2.10140725665,191.0,313.0,122.0,251.401862197,14.6888192787,675014.0,251.0,242.0,448.0,206.0,351.926256983,29.8354231796,944922.0,356.0,620.0,1413.0,793.0,1063.98435754,100.411691365,2856798.0,1076.0,127.0,492.0,365.0,309.516201117,42.6714726631,831051.0,308.0,0.386253625154,0.744209468365,0.35795584321,0.548521101353,0.0574183175622,1472.77915713,0.557333,588.0,1252.0,664.0,912.844320298,83.8934256216,2450987.0,915.0,-0.12109375,1.24566650391,1.36676025391,0.153875039099,0.232590148289,413.15447998,0.00622559
+13825943.0,2.75,7.0,1.19076691953,434.0,502.0,68.0,478.545454545,21.4194628418,5264.0,480.0,482.0,528.0,46.0,508.454545455,14.6744281993,5593.0,510.0,176.0,235.0,59.0,205.454545455,17.0846216675,2260.0,213.0,270.0,309.0,39.0,288.363636364,12.6582544199,3172.0,285.0,-0.23847694695,-0.106463879347,0.132013067603,-0.168741474097,0.0463954268056,-1.85615621507,-0.146497,1212.0,1334.0,122.0,1275.36363636,35.4946160508,14029.0,1283.0,0.0,0.0,0.0,0.0,0.0,0.0,0.0
+13819657.0,22.4999999998,37.0,2.20041974327,224.0,370.0,146.0,295.944444444,30.1206319511,26635.0,298.0,235.0,526.0,291.0,350.755555556,54.3830674447,31568.0,345.5,198.0,789.0,591.0,377.611111111,109.602179058,33985.0,360.0,102.0,459.0,357.0,256.933333333,68.6706794944,23124.0,244.0,0.00361010828055,0.659432411194,0.655822302913,0.184308583737,0.116337668412,16.5877725363,0.167755,599.0,1314.0,715.0,903.633333333,133.660220127,81327.0,893.5,0.386962890625,1.09515380859,0.708190917969,0.769233873155,0.19207376267,69.231048584,0.868866
+13812482.0,121.999999997,84.0,2.14533164398,193.0,261.0,68.0,235.430327869,9.70630511106,114890.0,235.0,236.0,361.0,125.0,303.461065574,22.1694877936,148089.0,300.0,749.0,1348.0,599.0,1043.58401639,91.7955961135,509269.0,1039.0,177.0,337.0,160.0,264.049180328,26.9472321213,128856.0,264.0,0.482334882021,0.676862716675,0.194527834654,0.595710053918,0.031538097006,290.706506312,0.597951,606.0,955.0,349.0,802.94057377,56.5183358583,391835.0,802.0,-0.026611328125,6.91168212891,6.93829345703,4.1398517421,2.30448376375,2020.24765015,5.76727
+13815053.0,27.999999997,60.0,3.19865427952,236.0,348.0,112.0,302.973214286,26.4130851708,33933.0,307.5,306.0,524.0,218.0,434.258928571,46.5216434914,48637.0,440.0,413.0,967.0,554.0,716.607142857,120.245979822,80260.0,743.5,269.0,624.0,355.0,501.428571429,75.5238508077,56160.0,510.0,0.0557692311704,0.258547008038,0.202777776867,0.1752933781,0.0425650008259,19.6328583471,0.174888,823.0,1460.0,637.0,1238.66071429,138.640693983,138730.0,1259.5,-0.0498657226562,0.986999511719,1.03686523438,0.537563051496,0.265813621628,60.2070617676,0.653793
+13809147.0,418.499999998,215.0,2.96473442863,358.0,577.0,219.0,498.396654719,36.0238589236,834316.0,503.0,400.0,653.0,253.0,539.412783751,40.5459292825,902977.0,543.5,147.0,574.0,427.0,256.689964158,72.8546452723,429699.0,238.0,130.0,512.0,382.0,243.194145759,58.361365014,407107.0,237.0,-0.10000000149,0.198198199272,0.298198200762,0.0231010894534,0.0600722561866,38.671223745,0.0202041,1009.0,1671.0,662.0,1281.00358423,94.7101974052,2144400.0,1284.0,-0.410186767578,2.36688232422,2.7770690918,0.547371083833,0.697061468788,916.299194336,0.215942
+13806220.0,32.5,49.0,2.42465229343,287.0,423.0,136.0,353.953846154,31.1111806611,46014.0,351.0,308.0,486.0,178.0,379.815384615,30.4463676286,49376.0,383.0,190.0,581.0,391.0,314.569230769,73.0067371455,40894.0,294.0,180.0,483.0,303.0,265.784615385,54.8212458275,34552.0,248.5,-0.0887290164828,0.262222230434,0.350951246917,0.0808289286519,0.0779603890466,10.5077607248,0.0708206,799.0,1355.0,556.0,999.553846154,86.1591605504,129942.0,1006.0,2.36950683594,3.93402099609,1.56451416016,3.2372443566,0.661881789621,420.841766357,3.35934
+13877510.0,6475.25000017,3536.0,12.3959282572,241.0,411.0,170.0,304.802864754,9.15870273223,7894699.0,304.0,279.0,593.0,314.0,407.144473186,14.9951118521,10545449.0,406.0,374.0,849.0,475.0,527.796996255,24.9095445577,13670470.0,527.0,254.0,726.0,472.0,441.241573684,22.4746243562,11428598.0,440.0,0.0222222227603,0.214076250792,0.191854028031,0.0893877851638,0.0134389066991,2315.23302353,0.0890891,811.0,1730.0,919.0,1153.18891163,43.7249558914,29868746.0,1151.0,-0.544250488281,6.06665039062,6.61090087891,0.168516663605,0.296749734459,4364.75010404,3.05176e-05
+13790035.0,11.75,24.0,1.97509221138,419.0,522.0,103.0,466.595744681,22.7817205321,21930.0,463.0,491.0,620.0,129.0,549.361702128,33.5657028172,25820.0,548.0,103.0,306.0,203.0,195.765957447,47.303552458,9201.0,186.0,219.0,383.0,164.0,278.872340426,44.6850048728,13107.0,268.0,-0.446236550808,-0.0373001769185,0.408936373889,-0.182099517197,0.0853722409515,-8.55867730826,-0.169451,1137.0,1483.0,346.0,1294.82978723,93.6488050494,60857.0,1271.0,-0.00628662109375,1.2453918457,1.2516784668,0.56847105635,0.457817208666,26.7181396484,0.392578
+13893069.0,7049.50000193,3471.0,11.6619325214,227.0,371.0,144.0,301.281757571,6.45274066744,8495543.0,301.0,291.0,528.0,237.0,407.792503014,10.4496959938,11498933.0,407.0,426.0,704.0,278.0,544.875913185,23.7358316078,15364411.0,544.0,305.0,678.0,373.0,470.450812114,20.5894512062,13265772.0,470.0,-0.00106269924436,0.195250660181,0.196313359425,0.0732996460852,0.0108350711701,2066.90342031,0.071908,852.0,1577.0,725.0,1179.5250727,32.2401068572,33260248.0,1179.0,-0.246032714844,1.8180847168,2.06411743164,0.263561283237,0.301059524712,7431.90106472,0.165222
+13774834.0,11.0,15.0,1.27582169949,438.0,563.0,125.0,507.0,30.6393982851,22308.0,504.5,628.0,825.0,197.0,733.136363636,48.4001272111,32258.0,734.5,653.0,952.0,299.0,790.659090909,52.0532695601,34789.0,787.0,690.0,1009.0,319.0,807.681818182,62.1726966994,35538.0,798.5,-0.0638297870755,0.04814305529,0.111972842366,-0.0102670264803,0.0286015526742,-0.451749165135,-0.0146359,1781.0,2392.0,611.0,2047.81818182,136.521771945,90104.0,2044.5,0.106201171875,1.43356323242,1.32736206055,0.206603310325,0.277252973487,9.0905456543,0.121826
+13767630.0,89.5000000037,64.0,1.90837414623,255.0,472.0,217.0,362.287709497,31.792684145,129699.0,358.5,300.0,640.0,340.0,443.351955307,58.8659032311,158720.0,425.0,115.0,738.0,623.0,272.212290503,75.6322672471,97452.0,259.0,140.0,609.0,469.0,262.536312849,75.76339655,93988.0,234.5,-0.344729334116,0.321663022041,0.666392356157,0.0187621015041,0.0888675997821,6.71683233848,0.0369632,710.0,1649.0,939.0,1068.17597765,151.408691748,382407.0,1017.5,-0.0870056152344,0.339447021484,0.426452636719,0.0258272480032,0.0651041671546,9.24615478516,0.0
+13743889.0,6.5,16.0,1.77034688977,243.0,310.0,67.0,281.0,18.0788869637,7306.0,281.5,314.0,411.0,97.0,352.230769231,22.8613003404,9158.0,350.0,224.0,412.0,188.0,286.423076923,46.2677600636,7447.0,277.0,212.0,389.0,177.0,263.538461538,43.0457991958,6852.0,249.5,-0.0458333343267,0.131868138909,0.177701473236,0.0413856892847,0.0400476721692,1.0760279214,0.045164,782.0,1108.0,326.0,896.769230769,72.8904909343,23316.0,878.5,0.479309082031,3.9267578125,3.44744873047,3.2090641902,1.32427109172,83.4356689453,3.84064
+13746441.0,127.750000002,59.0,1.47253838759,206.0,279.0,73.0,246.755381605,10.4511184151,126092.0,246.0,243.0,382.0,139.0,324.772994129,18.3467187444,165959.0,326.0,654.0,999.0,345.0,868.909980431,52.8512637914,444013.0,874.0,178.0,434.0,256.0,304.363992172,35.0319478864,155530.0,304.0,0.291739881039,0.602421820164,0.310681939125,0.481777224522,0.0449584002844,246.188161731,0.485246,627.0,1087.0,460.0,875.892367906,62.0290488138,447581.0,878.0,-0.0062255859375,5.2658996582,5.27212524414,3.82997420996,1.00480053033,1957.11682129,4.22519
+13706846.0,873.999999993,644.0,6.14504714325,240.0,580.0,340.0,308.807208238,19.9076246156,1079590.0,307.0,301.0,869.0,568.0,424.868993135,30.3627477802,1485342.0,424.0,320.0,1139.0,819.0,575.889588101,46.5486058463,2013310.0,574.0,141.0,1162.0,1021.0,488.516590389,47.1689991889,1707854.0,487.0,-0.0353728495538,0.388286322355,0.423659171909,0.0825872155928,0.0271956745199,288.724905712,0.0817491,688.0,2611.0,1923.0,1222.19279176,91.7573597057,4272786.0,1219.0,-0.131286621094,4.18206787109,4.31335449219,0.219230346331,0.371228136614,766.429290771,0.0
+13750149.0,334.249999997,172.0,2.65391987544,205.0,356.0,151.0,261.994764398,12.8610014299,350287.0,262.0,272.0,532.0,260.0,381.641735228,22.6569055943,510255.0,382.0,606.0,1218.0,612.0,979.713537771,72.4052383308,1309877.0,978.0,206.0,602.0,396.0,351.433059088,34.2858791624,469866.0,353.0,0.33846154809,0.595505595207,0.257044047117,0.471683176177,0.0419481537682,630.640406549,0.469449,683.0,1490.0,807.0,995.069558714,66.6153322549,1330408.0,998.0,-0.213317871094,2.97387695312,3.18719482422,0.872736106992,1.02141154912,1166.84817505,0.0938416
+13738152.0,61.7499999998,95.0,3.4103597367,303.0,400.0,97.0,348.048582996,16.8899051138,85968.0,346.0,422.0,588.0,166.0,519.372469636,27.9707577778,128285.0,519.0,696.0,1030.0,334.0,902.850202429,62.7015763928,223004.0,907.0,567.0,849.0,282.0,726.87854251,51.0941163918,179539.0,728.0,0.0316742099822,0.192746803164,0.161072593182,0.107929045131,0.0236903779181,26.6584741473,0.109662,1292.0,1819.0,527.0,1594.29959514,89.5916925633,393792.0,1597.0,-0.00143432617188,1.41412353516,1.41555786133,0.294471400952,0.22220295182,72.7344360352,0.223969
+13731120.0,14.7500000002,29.0,2.13008559658,240.0,328.0,88.0,290.86440678,21.2279457856,17161.0,294.0,268.0,384.0,116.0,324.169491525,31.2465062684,19126.0,315.0,188.0,394.0,206.0,244.406779661,37.9415780361,14420.0,237.0,190.0,354.0,164.0,251.677966102,34.5711943764,14849.0,254.0,-0.153191491961,0.0693739429116,0.222565434873,-0.0154546762351,0.0616192430149,-0.911825897871,-0.0021978,768.0,1038.0,270.0,866.711864407,54.3260872652,51136.0,856.0,0.0,0.0,0.0,0.0,0.0,0.0,0.0
+13727479.0,35.9999999981,39.0,1.83361614658,299.0,451.0,152.0,393.666666667,25.3388151964,56688.0,397.5,319.0,472.0,153.0,411.361111111,21.0335747183,59236.0,412.0,199.0,485.0,286.0,252.673611111,34.7999899946,36385.0,246.0,186.0,462.0,276.0,255.527777778,33.4732364992,36796.0,248.5,-0.106145247817,0.17149220407,0.277637451887,-0.00607004883043,0.0508942687716,-0.874087031581,-0.00591446,804.0,1302.0,498.0,1060.55555556,63.0669593212,152720.0,1054.0,0.552642822266,1.40438842773,0.851745605469,0.88565741645,0.191150703866,127.534667969,0.799561
+13725593.0,42.2499999974,56.0,2.4303551292,203.0,367.0,164.0,284.059171598,34.1503297119,48006.0,291.0,267.0,480.0,213.0,352.24260355,31.5423124529,59529.0,356.0,245.0,654.0,409.0,350.952662722,81.8785946879,59311.0,328.0,180.0,464.0,284.0,273.443786982,58.1367351697,46212.0,250.0,-0.159999996424,0.298482298851,0.458482295275,0.121392026779,0.074310114215,20.5152525257,0.124105,681.0,1311.0,630.0,909.74556213,86.533164254,153747.0,907.0,-0.0062255859375,0.0754699707031,0.0816955566406,0.00174455811991,0.00893698693791,0.294830322266,0.0
+13720269.0,7.25,13.0,1.36197588167,255.0,288.0,33.0,272.310344828,7.50679438576,7897.0,273.0,367.0,410.0,43.0,390.24137931,10.9565133279,11317.0,393.0,428.0,539.0,111.0,473.517241379,30.168058799,13732.0,469.0,330.0,397.0,67.0,367.620689655,14.4423080425,10661.0,367.0,0.0536352805793,0.230769231915,0.177133951336,0.125041889348,0.0437728617177,3.62621479109,0.118149,960.0,1095.0,135.0,1030.17241379,30.4993713508,29875.0,1032.0,-0.000823974609375,0.945831298828,0.946655273438,0.0689507846175,0.239096857653,1.99957275391,0.0
+13712258.0,37.2499999991,28.0,1.294165925,311.0,400.0,89.0,356.046979866,17.9216548442,53051.0,354.0,376.0,448.0,72.0,403.134228188,16.7490990314,60067.0,401.0,132.0,403.0,271.0,249.845637584,42.6346622747,37227.0,249.0,214.0,343.0,129.0,260.718120805,27.5357194592,38847.0,262.0,-0.292225211859,0.178362578154,0.470587790012,-0.0254377750156,0.0859411824092,-3.79022847733,-0.0122951,929.0,1163.0,234.0,1019.89932886,54.44148943,151965.0,1016.0,0.309692382812,1.14657592773,0.836883544922,0.550899838441,0.169550266786,82.0840759277,0.562012
+13717696.0,543.249999987,358.0,4.33289562189,207.0,346.0,139.0,273.137597791,17.7252885127,593528.0,270.0,263.0,507.0,244.0,387.352968247,30.7381072101,841718.0,382.0,502.0,1192.0,690.0,941.216290842,83.1325223048,2045263.0,947.0,200.0,604.0,404.0,372.548090198,54.9769236808,809547.0,366.0,0.261639356613,0.593342959881,0.331703603268,0.433276339289,0.0641682202244,941.509485275,0.430625,672.0,1452.0,780.0,1033.03865624,100.78354043,2244793.0,1015.0,-0.13037109375,2.98095703125,3.111328125,0.259689380209,0.400780092896,564.305023193,0.17337
+13692788.0,111.249999998,120.0,3.20941814921,235.0,393.0,158.0,272.829213483,16.2690179275,121409.0,272.0,309.0,583.0,274.0,377.892134831,30.5017524813,168162.0,375.0,422.0,961.0,539.0,577.997752809,79.4570762188,257209.0,567.0,227.0,679.0,452.0,362.148314607,46.7884603855,161156.0,359.0,0.0643127337098,0.394295305014,0.329982571304,0.227811341356,0.067077973191,101.376046903,0.222482,772.0,1655.0,883.0,1012.86966292,90.0398967805,450727.0,1008.0,-0.0664367675781,1.42102050781,1.48745727539,0.0938736476255,0.277269653416,41.7737731934,0.0
+13690465.0,101.999999998,95.0,2.65349691716,234.0,434.0,200.0,339.137254902,36.7874230468,138368.0,341.0,294.0,575.0,281.0,414.463235294,48.3305471272,169101.0,405.0,211.0,647.0,436.0,365.448529412,96.4415260094,149103.0,328.0,233.0,626.0,393.0,347.985294118,83.9398698148,141978.0,320.0,-0.129082426429,0.215859025717,0.344941452146,0.0215436637384,0.0634541222704,8.78981480526,0.0204348,795.0,1609.0,814.0,1101.58578431,148.685111053,449447.0,1055.5,-0.148803710938,6.37942504883,6.52822875977,0.143273521872,0.560519689684,58.4555969238,0.00231934
+13693184.0,2481.00000002,1222.0,6.92074570316,200.0,287.0,87.0,240.992543329,7.90780618442,2391610.0,241.0,258.0,432.0,174.0,335.354897219,15.1989031112,3328062.0,335.0,680.0,1106.0,426.0,902.461003628,52.9621307566,8956023.0,901.0,193.0,408.0,215.0,286.319125353,20.0296543808,2841431.0,285.0,0.384615391493,0.62613427639,0.241518884897,0.518048769669,0.0269997864373,5141.11599019,0.519328,651.0,1099.0,448.0,862.666565901,41.0563013157,8561103.0,861.0,-0.0984802246094,2.39709472656,2.49557495117,0.884419786791,0.528450037733,8776.98196411,0.993332
+13662988.0,30.5000000007,32.0,1.63453839537,324.0,448.0,124.0,390.672131148,23.5655495367,47662.0,393.0,370.0,513.0,143.0,418.68852459,24.2774542806,51080.0,416.0,177.0,438.0,261.0,255.942622951,54.7675114866,31225.0,243.0,231.0,536.0,305.0,288.803278689,50.1281373401,35234.0,277.5,-0.191780820489,0.0620031803846,0.253784000874,-0.0639339813497,0.0550582161042,-7.79994572466,-0.0710995,953.0,1492.0,539.0,1098.16393443,80.3731421431,133976.0,1077.0,-0.0664367675781,0.428100585938,0.494537353516,0.0105840964395,0.0463069844361,1.29125976562,-3.05176e-05
+13652268.0,10.75,27.0,2.32302883196,202.0,310.0,108.0,234.23255814,24.7450603098,10072.0,223.0,250.0,407.0,157.0,297.790697674,40.6485550757,12805.0,283.0,357.0,646.0,289.0,436.790697674,67.1155054831,18782.0,413.0,189.0,463.0,274.0,277.069767442,60.8159233084,11914.0,259.0,0.081349208951,0.378340363503,0.296991154552,0.227870771878,0.0704584255072,9.79844319075,0.228018,641.0,1176.0,535.0,809.093023256,124.425715945,34791.0,762.0,1.82824707031,4.52789306641,2.69964599609,3.20014918128,0.657054204118,137.606414795,3.01083
+13694615.0,714.499999997,551.0,5.81494418217,242.0,330.0,88.0,297.730930721,10.5104514235,850915.0,298.0,284.0,457.0,173.0,403.8310007,15.3840202887,1154149.0,404.0,393.0,676.0,283.0,568.487053884,29.4927255622,1624736.0,565.0,273.0,581.0,308.0,468.236529041,26.7941254696,1338220.0,468.0,0.032692309469,0.276150614023,0.243458304554,0.0968306589418,0.0182322002234,276.742023256,0.0963623,799.0,1368.0,569.0,1169.79846046,43.4406519582,3343284.0,1168.0,-0.205505371094,3.30145263672,3.50695800781,0.266783685597,0.39617032859,762.467773438,0.13353
+13646119.0,40.2499999986,52.0,2.31214714585,213.0,321.0,108.0,251.677018634,23.745441533,40520.0,247.0,249.0,443.0,194.0,309.161490683,32.1181631671,49775.0,304.0,479.0,926.0,447.0,713.385093168,88.5615946733,114855.0,713.0,168.0,492.0,324.0,284.459627329,47.1304511537,45798.0,277.0,0.24137930572,0.54354351759,0.302164211869,0.429504668398,0.0691050792792,69.1502516121,0.444444,668.0,1254.0,586.0,845.298136646,96.0569089034,136093.0,830.0,5.31402587891,8.13623046875,2.82220458984,6.9426034489,0.763389341992,1117.75915527,6.76828
+13648123.0,2.5,7.0,1.24888688131,362.0,402.0,40.0,378.4,11.5082579047,3784.0,375.0,394.0,444.0,50.0,408.8,17.7583783043,4088.0,400.0,134.0,222.0,88.0,178.9,26.0171097549,1789.0,180.0,242.0,319.0,77.0,268.0,27.5390631649,2680.0,256.5,-0.287234038115,-0.0961968675256,0.191037170589,-0.20161056146,0.053495915813,-2.0161056146,-0.207478,1001.0,1165.0,164.0,1055.2,55.6611174879,10552.0,1030.5,1.23669433594,1.27185058594,0.03515625,1.25427246094,0.011219848919,12.5427246094,1.25427
+13650179.0,520.250000012,265.0,3.27744111433,235.0,275.0,40.0,251.299855839,5.02750196901,522955.0,251.0,311.0,393.0,82.0,348.281595387,10.3491889173,724774.0,349.0,676.0,905.0,229.0,785.994233542,38.2215017492,1635654.0,785.0,248.0,352.0,104.0,298.188851514,14.3288551207,620531.0,298.0,0.351403683424,0.521461188793,0.170057505369,0.449602586211,0.0237284296048,935.622981906,0.451208,795.0,1020.0,225.0,897.770302739,28.0335506816,1868260.0,898.0,-0.003173828125,1.99276733398,1.99594116211,0.785981588442,0.355228058616,1635.62768555,0.752228
+13642174.0,2001.99999998,1455.0,9.17330904047,187.0,288.0,101.0,242.119755245,12.9901991542,1938895.0,243.0,220.0,414.0,194.0,331.509865135,26.577519411,2654731.0,333.0,546.0,1244.0,698.0,940.577172827,92.7213098328,7532142.0,946.0,116.0,435.0,319.0,273.295829171,38.9279640644,2188553.0,276.0,0.381651371717,0.756833195686,0.375181823969,0.549986068293,0.046547804333,4404.28843489,0.549917,531.0,1137.0,606.0,846.92544955,77.0567733256,6782179.0,852.0,-0.335968017578,9.57504272461,9.91101074219,1.60876691591,2.51454328063,12883.0054626,0.67894
+13639766.0,35.5000000028,51.0,2.4146326433,214.0,391.0,177.0,297.021126761,34.5949333402,42177.0,302.0,263.0,475.0,212.0,339.345070423,33.4790339636,48187.0,340.0,217.0,647.0,430.0,360.978873239,100.910116769,51259.0,327.0,158.0,495.0,337.0,257.964788732,65.1199772437,36631.0,233.0,-0.00204498972744,0.333333343267,0.335378332995,0.161070693278,0.0734404505895,22.8720384454,0.16646,690.0,1361.0,671.0,894.330985915,101.939620477,126995.0,884.5,-0.0203552246094,0.101531982422,0.121887207031,0.00247106417804,0.0129282555667,0.350891113281,0.0
+13643055.0,93.0000000028,119.0,3.48097220156,237.0,521.0,284.0,309.545698925,37.3322132771,115151.0,301.0,311.0,830.0,519.0,452.806451613,67.8724702397,168444.0,437.0,549.0,1151.0,602.0,790.239247312,86.8383386633,293969.0,786.0,417.0,1102.0,685.0,604.35483871,92.6867072583,224820.0,585.5,-0.0260521043092,0.256514191628,0.282566295937,0.134955248982,0.0462953886715,50.2033526214,0.141146,1026.0,2453.0,1427.0,1366.70698925,192.368185996,508415.0,1323.0,-0.175048828125,3.82598876953,4.00103759766,0.833274020944,1.28654397397,309.977935791,0.0187531
+13637105.0,5.0,10.0,1.26156626101,336.0,420.0,84.0,370.4,19.8957281847,7408.0,368.5,448.0,569.0,121.0,483.95,25.8968627444,9679.0,479.5,178.0,487.0,309.0,253.45,69.4020712947,5069.0,243.5,279.0,519.0,240.0,313.55,51.2800887285,6271.0,301.0,-0.253668755293,-0.0165016502142,0.237167105079,-0.115465636179,0.0713006730111,-2.30931272358,-0.108219,1074.0,1508.0,434.0,1167.9,87.3406549094,23358.0,1148.5,0.376281738281,0.521301269531,0.14501953125,0.447734069824,0.0488311597596,8.95468139648,0.453171
+13748687.0,1598.50000001,879.0,6.20194089069,239.0,373.0,134.0,300.653268689,11.6588611079,1922377.0,301.0,293.0,553.0,260.0,408.654989052,19.8002888808,2612940.0,410.0,346.0,708.0,362.0,569.163121677,37.3763143526,3639229.0,573.0,222.0,564.0,342.0,465.483891148,33.9516133478,2976304.0,469.0,0.0344202890992,0.23359580338,0.199175514281,0.100449888583,0.0174551038927,642.276587598,0.0999001,762.0,1416.0,654.0,1174.79214889,61.1845441785,7511621.0,1182.0,0.0133361816406,1.12463378906,1.11129760742,0.449205715357,0.167615715936,2872.22134399,0.443375
+13619757.0,437.499999995,341.0,4.5989683238,284.0,393.0,109.0,315.730285714,7.72249755518,552528.0,315.0,375.0,565.0,190.0,428.213714286,13.6222941399,749374.0,428.0,470.0,789.0,319.0,548.289142857,21.2133070597,959506.0,546.0,376.0,686.0,310.0,472.526285714,22.0232123109,826921.0,471.0,0.0248681232333,0.111111111939,0.0862429887056,0.0743616403735,0.0088799318799,130.132870654,0.0750128,1035.0,1644.0,609.0,1216.47028571,41.7326590496,2128823.0,1213.0,-0.152374267578,1.98364257812,2.1360168457,0.52871332659,0.434895510288,925.248321533,0.45282
+13622480.0,48.0000000005,68.0,2.76874756744,208.0,366.0,158.0,296.145833333,34.6719684948,56860.0,300.5,230.0,463.0,233.0,352.6875,39.4663127711,67716.0,357.0,214.0,627.0,413.0,354.885416667,81.2431881493,68138.0,337.0,197.0,468.0,271.0,269625.0,50.1149200172,51768.0,257.0,-0.022964509204,0.360501557589,0.383466066793,0.130578662354,0.0818071476993,25.0711031719,0.129556,671.0,1293.0,622.0,918.458333333,97.7534011201,176344.0,917.5,-0.0445556640625,1.24905395508,1.29360961914,0.404578208923,0.249884965992,77.6790161133,0.382599
+13616281.0,26.0,34.0,1.88099357038,289.0,457.0,168.0,382.173076923,35.6139672006,39746.0,385.5,370.0,584.0,214.0,460.326923077,44.7760328893,47874.0,461.5,212.0,560.0,348.0,307.269230769,73.0800707824,31956.0,296.0,162.0,505.0,343.0,260.932692308,61.2762132954,27137.0,246.0,-0.183600708842,0.244755238295,0.428355947137,0.0807047396576,0.0821852462611,8.39329292439,0.0732415,866.0,1546.0,680.0,1103.43269231,122.835863313,114757.0,1105.5,0.0,1.54995727539,1.54995727539,0.57445027278,0.313032321002,59.7428283691,0.55542
+13651826.0,1893.25,1199.0,7.77338661763,194.0,302.0,108.0,236.308068137,8.1239268774,1789561.0,237.0,261.0,447.0,186.0,336.059553678,14.7539265814,2544979.0,337.0,733.0,1208.0,475.0,993.175491879,48.6483076094,7521318.0,992.0,174.0,437.0,263.0,282.156741054,20.4632309261,2136773.0,283.0,0.437601298094,0.685714304447,0.248113006353,0.557494107462,0.0254562675279,4221.90287581,0.557288,629.0,1186.0,557.0,854.524362868,41.4517242706,6471313.0,856.0,-0.385192871094,1.51132202148,1.89651489258,0.127807234358,0.267285324735,967.884185791,0.0
+13614159.0,5.25,16.0,1.96986016984,206.0,266.0,60.0,222.380952381,16.5341671942,4670.0,217.0,260.0,380.0,120.0,295.19047619,30.4562434722,6199.0,283.0,409.0,598.0,189.0,480.428571429,46.7073680621,10089.0,467.0,225.0,438.0,213.0,287.380952381,52.9343494479,6035.0,266.0,0.154440149665,0.339207053185,0.18476690352,0.255833676174,0.0435953979282,5.37250719965,0.264398,692.0,1084.0,392.0,804.952380952,99.3140646974,16904.0,767.0,0.435211181641,1.28219604492,0.846984863281,0.777743384952,0.315185725137,16.332611084,0.978882
+13612882.0,22.75,24.0,1.41943532513,444.0,668.0,224.0,596.483516484,39.0872123316,54280.0,604.0,569.0,879.0,310.0,776.89010989,60.3443325724,70697.0,789.0,147.0,336.0,189.0,225.164835165,41.8420010175,20490.0,225.0,286.0,440.0,154.0,385.384615385,38.514951922,35070.0,395.0,-0.41296929121,-0.114139690995,0.298829600215,-0.266402708878,0.0664919416171,-24.2426465079,-0.268366,1340.0,1938.0,598.0,1758.75824176,125.995930569,160047.0,1795.0,0.610107421875,1.63778686523,1.02767944336,0.976926028073,0.47232615759,88.9002685547,0.641357
+13574136.0,866.749999998,921.0,8.82485895706,211.0,550.0,339.0,293.894433228,13.5364708631,1018932.0,293.0,268.0,767.0,499.0,429.137006057,20.5158870539,1487818.0,428.0,583.0,1318.0,735.0,822.494663975,41.1334039776,2851589.0,822.0,347.0,1258.0,911.0,653.970868186,40.4251563669,2267317.0,654.0,0.0232919249684,0.259338319302,0.236046394333,0.114434326389,0.0176943437716,396.74380959,0.11254,827.0,2575.0,1748.0,1377.00230747,68.8459024717,4774067.0,1374.0,-0.158233642578,1.77001953125,1.92825317383,0.216968370234,0.276180244525,752.2293396,0.114288
+13611257.0,32.5000000009,35.0,1.73189449529,237.0,427.0,190.0,344.553846154,39.2002868001,44792.0,350.0,277.0,501.0,224.0,400.530769231,39.748089158,52069.0,406.0,222.0,644.0,422.0,325.192307692,89.0320682204,42275.0,291.5,173.0,524.0,351.0,256.907692308,60.5860413162,33398.0,236.5,-0.0411522649229,0.2854578197,0.326610084623,0.111755437736,0.0713852366536,14.5282069057,0.102826,751.0,1358.0,607.0,1001.99230769,95.8342717045,130259.0,1010.0,0.424194335938,0.673553466797,0.249359130859,0.510506497897,0.0792314625713,66.3658447266,0.482788
+13609933.0,37.9999999991,58.0,2.65418544491,236.0,280.0,44.0,248125.0,6.02223129221,37715.0,247.0,309.0,383.0,74.0,327.315789474,11.2550696487,49752.0,325.5,312.0,659.0,347.0,397.671052632,47.9054408947,60446.0,387.5,253.0,380.0,127.0,279.789473684,19.7442968378,42528.0,276.5,0.021276595071,0.271428585052,0.250151989982,0.171562359105,0.0496432509484,26.0774785839,0.17474,806.0,1027.0,221.0,855.230263158,35.4776561252,129995.0,848.5,-0.0586242675781,0.101531982422,0.16015625,-0.000255383943257,0.0403078458152,-0.038818359375,-0.00784302
+13608151.0,32.9999999993,46.0,2.25889440505,331.0,494.0,163.0,377.045454545,24.079371165,49770.0,374.0,373.0,655.0,282.0,429.151515152,43.0634635352,56648.0,420.0,200.0,621.0,421.0,300.136363636,80.5086832064,39618.0,278.5,222.0,678.0,456.0,298.340909091,80.7211651815,39381.0,276.0,-0.102564103901,0.119999997318,0.222564101219,0.00254842171897,0.0559553781015,0.336391666904,0.00560269,954.0,1827.0,873.0,1104.53787879,140.862677881,145799.0,1067.5,-0.0117492675781,0.871124267578,0.882873535156,0.0507930408825,0.152812902768,6.70468139648,0.0
+13607340.0,12.0,23.0,1.87297629563,374.0,439.0,65.0,406375.0,16.0177310607,19506.0,408.0,582.0,671.0,89.0,629.708333333,20.2164931979,30226.0,629.0,1095.0,1220.0,125.0,1148.95833333,26.4267528064,55150.0,1150.5,776.0,938.0,162.0,869.791666667,35.5210960401,41750.0,877.0,0.113636367023,0.177476122975,0.0638397559524,0.138522913369,0.0181479973974,6.64909984171,0.132068,1750.0,2028.0,278.0,1905875.0,61.4873377886,91482.0,1910.5,-0.00372314453125,0.0896606445312,0.0933837890625,0.0109208424886,0.0223033541011,0.524200439453,0.0
+13604592.0,7.25000000023,13.0,1.36197588165,194.0,292.0,98.0,244.275862069,25.5719357914,7084.0,251.0,244.0,417.0,173.0,333.75862069,43.9016574759,9679.0,339.0,444.0,918.0,474.0,701.586206897,143.310253559,20346.0,745.0,180.0,475.0,295.0,327.172413793,70.694129379,9488.0,349.0,0.242262542248,0.473684221506,0.231421679258,0.364209229576,0.0566185175271,10.5620676577,0.374798,618.0,1184.0,566.0,905.206896552,139.640024721,26251.0,941.0,3.03271484375,3.80685424805,0.774139404297,3.59995874865,0.238516382716,104.398803711,3.69598
+13595483.0,1181.49999999,509.0,4.17730309095,238.0,402.0,164.0,312.323317816,11.8760523767,1476040.0,314.0,302.0,561.0,259.0,437.487727465,22.4976642799,2067567.0,443.0,381.0,867.0,486.0,576.745662294,36.6140103878,2725700.0,572.0,238.0,786.0,548.0,457.169064748,29.3679717545,2160581.0,454.0,0.0151878492907,0.254013210535,0.238825361244,0.115635412575,0.0219086554883,546.492959828,0.117031,788.0,1719.0,931.0,1206.98011003,51.7121417583,5704188.0,1208.0,-0.121124267578,18.6790161133,18.8001403809,10.2407997638,8.77931660107,48398.0196838,17.6921
+13577780.0,950.250000008,814.0,7.44904389995,181.0,383.0,202.0,271.502762431,22.6653718137,1031982.0,270.0,243.0,562.0,319.0,381.014996054,37.7730387793,1448238.0,377.0,438.0,1267.0,829.0,904.575901079,83.998603665,3438293.0,899.0,172.0,703.0,531.0,390.533543804,65.3509779713,1484418.0,384.0,0.183033123612,0.596923053265,0.413889929652,0.398629604002,0.0684880110633,1515.19112481,0.396131,608.0,1641.0,1033.0,1043.05130229,120.862352425,3964638.0,1029.0,-0.0203552246094,1.37805175781,1.39840698242,0.281410022586,0.206539685575,1069.63949585,0.25766
+13570030.0,6.25,17.0,1.91824458406,222.0,284.0,62.0,252.32,15.7676123747,6308.0,249.0,282.0,406.0,124.0,345.2,30.8583862183,8630.0,340.0,485.0,617.0,132.0,557.32,38.317327673,13933.0,561.0,333.0,497.0,164.0,419.24,46.4562417765,10481.0,416.0,0.10028116405,0.196662694216,0.0963815301657,0.143179810941,0.0275469053613,3.57949527353,0.146968,841.0,1170.0,329.0,1016.76,90.0743159841,25419.0,1003.0,0.48095703125,1.20349121094,0.722534179688,0.895334472656,0.206309892296,22.3833618164,0.938538
+13607921.0,3257.50000001,2525.0,12.4799900258,260.0,511.0,251.0,342.993169609,15.2833367797,4469201.0,343.0,369.0,771.0,402.0,510.547198772,25.103378694,6652430.0,510.0,599.0,1122.0,523.0,851.456331543,39.8709551705,11094476.0,850.0,422.0,924.0,502.0,660.381811205,35.3799977844,8604775.0,660.0,0.0600203461945,0.214596003294,0.154575657099,0.126531815925,0.0138576517673,1648.7095615,0.125668,1083.0,2195.0,1112.0,1513.92217959,69.3272070253,19726406.0,1513.0,-0.205505371094,3.56271362305,3.76821899414,0.0862840489983,0.180239757135,1124.28115845,0.0
+13549655.0,2.75,7.0,1.19076691953,273.0,294.0,21.0,282.454545455,5.91398398811,3107.0,282.0,380.0,420.0,40.0,402.0,11.8398402938,4422.0,402.0,349.0,450.0,101.0,385.272727273,26.1849745572,4238.0,384.0,357.0,432.0,75.0,397.545454545,21.5464134808,4373.0,396.0,-0.100515462458,0.115241639316,0.215757101774,-0.0160322280135,0.0572410541246,-0.176354508149,-0.0128535,1010.0,1146.0,136.0,1082.0,38.8165850214,11902.0,1080.0,0.670288085938,0.724273681641,0.0539855957031,0.696735728871,0.0171971717172,7.66409301758,0.699463
+13545493.0,33.4999999998,39.0,1.90080371235,239.0,374.0,135.0,308.291044776,25.0062155339,41311.0,313.0,292.0,497.0,205.0,362.246268657,29.0569272875,48541.0,360.0,203.0,585.0,382.0,303.649253731,69.9154347897,40689.0,285.0,184.0,526.0,342.0,247.813432836,52.3990383742,33207.0,232.5,-0.0520446114242,0.259557336569,0.311601947993,0.0980745405827,0.0663103996313,13.1419884381,0.0935512,730.0,1332.0,602.0,918.350746269,85.0703183643,123059.0,907.0,-0.014892578125,0.646575927734,0.661468505859,0.196890304338,0.210545868954,26.3833007812,0.11293
+13539150.0,4.0,12.0,1.69256875064,196.0,248.0,52.0,227125.0,11.4938842434,3634.0,228.5,235.0,319.0,84.0,283.9375,18.9653260913,4543.0,287.5,389.0,553.0,164.0,452625.0,46.7237560027,7242.0,443.5,139.0,285.0,146.0,221375.0,32.2681634897,3542.0,226.0,0.278481006622,0.48613679409,0.207655787468,0.3448497504,0.0540323077095,5.51759600639,0.337785,570.0,852.0,282.0,732.4375,61.9808123031,11719.0,740.5,0.0,0.00518798828125,0.00518798828125,0.000387191772461,0.00126319914284,0.00619506835938,0.0
+13521317.0,1111.99999996,741.0,6.26846033837,212.0,294.0,82.0,256.332508993,9.47048162989,1140167.0,256.0,292.0,450.0,158.0,372.508318345,19.3135669842,1656917.0,373.0,862.0,1267.0,405.0,1067.44694245,53.3958246623,4748004.0,1069.0,187.0,425.0,238.0,310.050134892,26.4559232835,1379103.0,310.0,0.421375095844,0.668439745903,0.247064650059,0.550016355212,0.0292477428651,2446.47274798,0.551982,696.0,1157.0,461.0,938.89096223,52.151748603,4176187.0,940.0,-0.44189453125,1.93264770508,2.37454223633,0.264475458818,0.422356872491,1176.38684082,0.0680389
+13518316.0,40.0000000012,38.0,1.69491791032,208.0,318.0,110.0,239.04375,15.4427761733,38247.0,240.0,237.0,424.0,187.0,290.5375,25.9922795028,46486.0,293.0,219.0,570.0,351.0,322.44375,57.8121685801,51591.0,312.0,160.0,456.0,296.0,259.1125,43.4175925605,41458.0,256.5,-0.00796812772751,0.259130448103,0.26709857583,0.107680361045,0.0575565539761,17.2288577672,0.104509,610.0,1198.0,588.0,788.69375,81.3444064514,126191.0,786.0,0.108764648438,3.49371337891,3.38494873047,0.834029006958,0.706131347961,133.444641113,0.295212
+13576242.0,592.999999986,525.0,6.08172844698,270.0,421.0,151.0,369.659780776,23.1791945573,876833.0,373.0,390.0,655.0,265.0,555.646711636,37.154115614,1317994.0,561.0,768.0,1189.0,421.0,986.284569983,51.4610025865,2339467.0,985.0,430.0,845.0,415.0,684.939713322,57.9353465135,1624677.0,693.0,0.104571074247,0.343009918928,0.238438844681,0.181256531856,0.0316182447489,429.940493561,0.176116,1091.0,1904.0,813.0,1610.24620573,110.921861913,3819504.0,1630.0,-0.0309753417969,0.719360351562,0.750335693359,0.198395508739,0.131859238262,470.594146729,0.180923
+13478613.0,230.250000012,123.0,2.2866534983,210.0,325.0,115.0,269.149837134,12.7582262524,247887.0,269.0,255.0,453.0,198.0,368.758957655,20.2806714302,339627.0,370.0,522.0,1065.0,543.0,876.980456026,74.425075808,807699.0,880.0,215.0,475.0,260.0,350.365906623,32.7168899105,322687.0,351.0,0.277637124062,0.547811985016,0.270174860954,0.428288315361,0.0451210924611,394.453538448,0.428127,696.0,1235.0,539.0,988.274701412,60.4517332482,910201.0,991.0,-0.194580078125,2.12280273438,2.3173828125,0.428696291713,0.595532884287,394.829284668,0.147705
+13492201.0,23.2499999998,24.0,1.40408962755,314.0,437.0,123.0,358.290322581,22.8786328663,33321.0,356.0,388.0,576.0,188.0,440.311827957,30.5589430427,40949.0,440.0,171.0,512.0,341.0,292.451612903,71.2204688665,27198.0,291.0,224.0,525.0,301.0,276.064516129,52.5256325448,25674.0,259.0,-0.185714289546,0.178378373384,0.36409266293,0.0215993136598,0.0846743635562,2.00873617036,0.0208333,942.0,1538.0,596.0,1074.66666667,93.8400988795,99944.0,1057.0,0.187469482422,0.931091308594,0.743621826172,0.407310896022,0.200267975019,37.8799133301,0.340942
+13492764.0,10.4999999998,19.0,1.65407051237,319.0,385.0,66.0,354.023809524,18.8053792902,14869.0,355.0,466.0,559.0,93.0,520.428571429,25.1084721588,21858.0,526.5,530.0,675.0,145.0,606.571428571,35.5059638566,25476.0,607.0,543.0,671.0,128.0,614.952380952,31.3649428054,25828.0,618.5,-0.063694268465,0.0509059540927,0.114600222558,-0.00705444581746,0.0301715176669,-0.296286724333,-0.00735084,1328.0,1592.0,264.0,1489.4047619,64.2621341233,62555.0,1506.5,0.0,0.0,0.0,0.0,0.0,0.0,0.0
+13469363.0,6.25,15.0,1.69256875064,387.0,463.0,76.0,436.32,17.326788508,10908.0,438.0,552.0,650.0,98.0,609.92,26.3619726121,15248.0,615.0,673.0,876.0,203.0,746.12,57.3343317743,18653.0,754.0,613.0,797.0,184.0,695.68,52.7232168973,17392.0,705.0,0.0073480294086,0.0879689529538,0.0806209235452,0.0349691257067,0.0175698320099,0.874228142668,0.035206,1603.0,1910.0,307.0,1741.92,88.4637417251,43548.0,1765.0,0.127319335938,0.445861816406,0.318542480469,0.407420654297,0.0818030821186,10.1855163574,0.431244
+13765010.0,3779.49999999,1957.0,8.97984248529,232.0,698.0,466.0,302.834964942,7.80410388243,4578259.0,303.0,292.0,1057.0,765.0,419.774573356,12.8300061759,6346152.0,420.0,432.0,1385.0,953.0,578.708162455,19.9149641039,8748910.0,579.0,308.0,1601.0,1293.0,513.853618203,21.4772329317,7768439.0,514.0,-0.0723375752568,0.176470592618,0.248808167875,0.0594601205526,0.00943231539682,898.918102515,0.059246,833.0,3356.0,2523.0,1236.4631565,40.2822583432,18692850.0,1237.0,-0.311767578125,2.16024780273,2.47201538086,0.253485435247,0.386868716757,3832.19281006,0.0
+13447745.0,135.249999997,72.0,1.74646114328,294.0,401.0,107.0,339.861367837,21.3540960235,183865.0,333.0,368.0,509.0,141.0,436.85767098,28.8899384037,236340.0,430.0,196.0,697.0,501.0,288.709796673,46.6307601999,156192.0,280.0,210.0,560.0,350.0,263.01663586,34.3252586755,142292.0,255.0,-0.178197070956,0.237749546766,0.415946617723,0.0446851282841,0.0648177955721,24.1746544017,0.043956,916.0,1386.0,470.0,1039.73567468,73.4101384794,562497.0,1020.0,-0.0328369140625,1.06869506836,1.10153198242,0.176660505989,0.242593808557,95.5733337402,0.0
+13462073.0,388.499999999,239.0,3.42056192641,182.0,360.0,178.0,253.059202059,17.6101891029,393254.0,255.0,227.0,533.0,306.0,341.390604891,32.5705837116,530521.0,348.0,491.0,1252.0,761.0,842.109395109,104.968529337,1308638.0,847.0,153.0,627.0,474.0,321.636422136,53.9999617386,499823.0,332.0,0.254988908768,0.635280072689,0.380291163921,0.447874555237,0.0617217899662,695.997058839,0.446305,573.0,1520.0,947.0,916.086229086,101.597391146,1423598.0,933.0,-0.0726928710938,4.49829101562,4.57098388672,1.16285617195,1.37733477982,1807.07849121,0.471466
+13402173.0,6.0,14.0,1.61230603087,340.0,385.0,45.0,356.916666667,10.4798086284,8566.0,355.5,349.0,400.0,51.0,366375.0,14.3289116242,8793.0,360.0,120.0,189.0,69.0,166.291666667,18.0611903601,3991.0,171.5,216.0,263.0,47.0,239.166666667,12.7399197625,5740.0,236.5,-0.320113301277,-0.11627907306,0.203834228218,-0.181482823566,0.0565462962835,-4.35558776557,-0.16405,912.0,1041.0,129.0,962.458333333,30.0416088765,23099.0,961.5,0.333557128906,0.471557617188,0.138000488281,0.379782358805,0.0345826907626,9.11477661133,0.376526
+13383838.0,83.4999999991,59.0,1.8213937496,220.0,285.0,65.0,253.520958084,12.9452269998,84676.0,254.0,286.0,399.0,113.0,339.715568862,20.9661817119,113465.0,339.0,708.0,1047.0,339.0,920.508982036,57.4069273568,307450.0,923.5,248.0,409.0,161.0,326.661676647,32.3747133463,109105.0,329.0,0.392171919346,0.566552877426,0.17438095808,0.476421490044,0.0377888942689,159.124777675,0.477326,759.0,1082.0,323.0,919.898203593,62.3314623154,307246.0,921.0,0.047607421875,1.79406738281,1.74645996094,1.12490442699,0.377233514589,375.718078613,1.23819
+13382031.0,11.5,17.0,1.41414866929,279.0,381.0,102.0,291.173913043,16.9247751868,13394.0,286.5,393.0,548.0,155.0,415.97826087,25.8948451563,19135.0,410.0,298.0,577.0,279.0,359.695652174,45.0038015618,16546.0,348.0,343.0,558.0,215.0,384.52173913,32.0792084436,17688.0,381.0,-0.129927009344,0.0276008490473,0.157527858391,-0.0351296565597,0.0378282275912,-1.61596420174,-0.0312163,1040.0,1487.0,447.0,1091.67391304,73.2093645554,50217.0,1076.5,0.0,0.0,0.0,0.0,0.0,0.0,0.0
+13377489.0,32.7500000002,36.0,1.77456502033,275.0,431.0,156.0,358.870229008,33.3920493683,47012.0,361.0,317.0,519.0,202.0,405.694656489,34.3779827308,53146.0,404.0,147.0,516.0,369.0,297.702290076,59.9574524277,38999.0,296.0,179.0,428.0,249.0,262.709923664,43.0766206315,34415.0,265.0,-0.139344260097,0.237191647291,0.376535907388,0.0586856166772,0.0738137917141,7.68781578471,0.0688935,818.0,1286.0,468.0,1027.27480916,78.8860472415,134573.0,1021.0,-0.0125427246094,7.79107666016,7.80361938477,0.129611648676,0.953664200624,16.9791259766,0.0
+13369759.0,3261.25000014,1855.0,9.16319514948,248.0,471.0,223.0,309.341050211,9.62044610897,4035354.0,309.0,320.0,666.0,346.0,414.860866232,16.132140409,5411860.0,413.0,414.0,877.0,463.0,545.606899195,24.9833523399,7117442.0,543.0,276.0,909.0,633.0,455.871521656,25.1587869115,5946844.0,453.0,-0.0179171338677,0.211186110973,0.229103244841,0.0897954596035,0.0122275621813,1171.38177053,0.0903553,844.0,2046.0,1202.0,1180.0734381,49.1393007814,15394058.0,1175.0,-0.169189453125,1.55911254883,1.72830200195,0.197887886332,0.272709875863,2581.4474772,0.0685425
+13373400.0,52.4999999995,34.0,1.32371452186,227.0,399.0,172.0,334.204761905,40.8208744008,70183.0,347.5,269.0,471.0,202.0,396.280952381,51.0837045963,83219.0,413.0,192.0,474.0,282.0,294.90952381,60.0482853707,61931.0,275.0,172.0,402.0,230.0,273.30952381,31.9136394898,57395.0,274.0,-0.0805084779859,0.195007801056,0.275516279042,0.031602621283,0.0678085390573,6.63655046944,0.0185833,756.0,1169.0,413.0,1003.7952381,99.2715898369,210797.0,1039.0,0.566375732422,3.76513671875,3.19876098633,1.04933980306,1.02597879902,220.361358643,0.578094
+13418840.0,4002.24999984,2492.0,11.1119684421,257.0,380.0,123.0,322.701105628,8.22509088608,5166122.0,322.0,322.0,537.0,215.0,446.875507527,14.3242805696,7154030.0,446.0,445.0,730.0,285.0,598.191392342,25.3386403956,9576446.0,596.0,309.0,643.0,334.0,508.508838778,23.0239468816,8140718.0,508.0,0.0171017106622,0.180555552244,0.163453841582,0.0810923748829,0.0116501609217,1298.2078295,0.0813226,888.0,1560.0,672.0,1278.08545193,42.7092352372,20460870.0,1277.0,-0.201599121094,2.12887573242,2.33047485352,0.115068073357,0.214090333633,1842.12478638,0.0
+13317822.0,417.75,170.0,2.34631199088,195.0,325.0,130.0,253.49551167,16.6005579917,423591.0,255.0,236.0,452.0,216.0,343.327348893,31.2358064969,573700.0,348.0,430.0,1100.0,670.0,817.203470975,112.898870186,1365547.0,818.0,159.0,551.0,392.0,351.13165769,61.1916818218,586741.0,353.0,0.187935039401,0.633397340775,0.445462301373,0.397448455722,0.0885414382459,664.136369511,0.387755,597.0,1328.0,731.0,947.954518253,106.112714435,1584032.0,957.0,-0.112213134766,2.37130737305,2.48352050781,0.325874716703,0.484928270502,544.536651611,0.113068
+13353504.0,226.250000008,128.0,2.40054993125,181.0,433.0,252.0,278.325966851,32.4291124882,251885.0,276.0,231.0,636.0,405.0,403.503867403,50.3700147194,365171.0,401.0,317.0,1204.0,887.0,854.09281768,120.038696354,772954.0,877.0,172.0,677.0,505.0,401.144751381,74.3948554448,363036.0,399.0,0.143617019057,0.56809335947,0.424476340413,0.36171148342,0.0683147250381,327.348892495,0.367421,643.0,1582.0,939.0,1082.97458564,141.248256882,980092.0,1075.0,-0.0597534179688,0.562805175781,0.62255859375,0.0353144693111,0.0935074786562,31.9595947266,0.0
+13347337.0,4.5,10.0,1.32980760134,371.0,419.0,48.0,392.0,13.7679176187,7056.0,389.0,471.0,559.0,88.0,523.333333333,22.6495033058,9420.0,524.5,486.0,695.0,209.0,597.722222222,51.3222991989,10759.0,602.0,455.0,611.0,156.0,560.555555556,40.6300685347,10090.0,567.0,-0.0180505421013,0.0647737383842,0.0828242804855,0.0315941314523,0.0239753678757,0.568694366142,0.0351387,1331.0,1546.0,215.0,1475.88888889,64.0146588151,26566.0,1489.5,0.936676025391,0.971832275391,0.03515625,0.953169080946,0.0100484695337,17.157043457,0.952301
+13472528.0,8634.50000012,6102.0,18.5245929749,229.0,613.0,384.0,315.080259424,10.8170466621,10882242.0,315.0,296.0,823.0,527.0,437.664601309,16.5814798151,15116060.0,437.0,441.0,1153.0,712.0,606.452400255,34.2603539478,20945653.0,605.0,271.0,1146.0,875.0,502.878684348,31.0062868212,17368424.0,502.0,-0.0770676657557,0.371229708195,0.44829737395,0.0934901715876,0.0133185670853,3228.96354629,0.0929368,796.0,2545.0,1749.0,1255.62354508,50.6114564539,43366726.0,1254.0,-0.224243164062,3.65985107422,3.88409423828,0.12346876828,0.228571159778,4264.36431885,0.00149536
+13353229.0,162.5,153.0,3.38578842669,276.0,342.0,66.0,314.335384615,9.75049396412,204318.0,315.0,391.0,509.0,118.0,458.969230769,17.7515929779,298330.0,460.0,613.0,873.0,260.0,752.249230769,36.708448506,488962.0,754.0,490.0,713.0,223.0,615.830769231,30.9601576376,400290.0,617.0,0.0590778104961,0.154668569565,0.0955907590687,0.0997277781482,0.0153237694963,64.8230557963,0.0992521,1161.0,1562.0,401.0,1389.13538462,57.0688664436,902938.0,1392.0,-0.0437622070312,3.57647705078,3.62023925781,0.2461329064,0.625362463467,159.98638916,0.000457764
+13332517.0,1528.24999997,950.0,6.85522117089,268.0,384.0,116.0,313.563225912,7.20342872793,1916812.0,313.0,363.0,551.0,188.0,428.718468837,11.6779994997,2620756.0,428.0,487.0,781.0,294.0,579.680844103,21.9283305599,3543589.0,578.0,388.0,686.0,298.0,486.957467692,20.4361847686,2976771.0,484.0,0.0188370179385,0.145593866706,0.126756848767,0.0869978519774,0.0108013339208,531.817869138,0.0871694,1024.0,1621.0,597.0,1229.23916244,35.3733108152,7514339.0,1227.0,-0.184417724609,0.988098144531,1.17251586914,0.0850614063794,0.144921036526,519.980377197,0.0
+13324487.0,45.2500000005,43.0,1.80324290374,271.0,389.0,118.0,339.541436464,27.3846086572,61457.0,348.0,289.0,454.0,165.0,346.187845304,27.536576706,62660.0,341.0,219.0,611.0,392.0,305.143646409,85.0403955098,55231.0,269.0,170.0,480.0,310.0,255.690607735,58.8760601966,46280.0,234.0,-0.0173160172999,0.311258286238,0.328574303538,0.082668322801,0.0587731238094,14.962966427,0.0747664,764.0,1277.0,513.0,941.419889503,86.2370524639,170397.0,926.0,-0.0264282226562,0.763732910156,0.790161132812,0.194324640938,0.153547658314,35.1727600098,0.239655
+13303125.0,49.75,53.0,2.11969997674,207.0,284.0,77.0,241.844221106,15.7368707109,48127.0,244.0,257.0,385.0,128.0,325.894472362,31.3510504035,64853.0,336.0,419.0,961.0,542.0,720.170854271,123.766236759,143314.0,770.0,186.0,394.0,208.0,299.472361809,48.1121803647,59595.0,313.0,0.269794732332,0.533502995968,0.263708263636,0.410478907165,0.0445909800319,81.6853025258,0.410468,650.0,1055.0,405.0,867.211055276,94.2982314823,172575.0,893.0,-0.0828552246094,1.16580200195,1.24865722656,0.183355283498,0.230403327133,36.487701416,0.0714111
+13444720.0,9995.74999959,6345.0,17.9027192706,215.0,829.0,614.0,316.321861791,10.8660390257,12647497.0,316.0,273.0,1211.0,938.0,447.662631618,15.7686629905,17898895.0,447.0,370.0,1502.0,1132.0,644.346422229,35.9316104135,25762903.0,638.0,244.0,1518.0,1274.0,548.217292349,31.3211068465,21919372.0,544.0,-0.0636195167899,0.246913582087,0.310533098876,0.0806234797316,0.0130429052572,3223.56859011,0.079932,732.0,3558.0,2826.0,1312.20178576,47.6446797282,52465764.0,1311.0,-0.303161621094,2.48205566406,2.78521728516,0.133473079666,0.267793998574,5336.65414429,0.0
+13298606.0,10.7499999998,20.0,1.72076209777,295.0,392.0,97.0,351.465116279,21.959104524,15113.0,354.0,333.0,467.0,134.0,398.465116279,28.7000112124,17134.0,396.0,245.0,498.0,253.0,318.813953488,48.70234979,13709.0,315.0,220.0,467.0,247.0,310.627906977,46.4302543987,13357.0,304.0,-0.0692771077156,0.137254908681,0.206532016397,0.0129523187074,0.040415863379,0.55694970442,0.0148048,862.0,1319.0,457.0,1060.55813953,88.1830290917,45604.0,1053.0,0.207763671875,1.50344848633,1.29568481445,0.657363536746,0.259271716486,28.2666320801,0.619934
+13282497.0,1660.74999994,1208.0,8.36199438761,273.0,478.0,205.0,377.914496462,18.1143582971,2510486.0,378.0,352.0,740.0,388.0,566.421345778,32.8912413541,3762737.0,567.0,567.0,1142.0,575.0,921.703146169,58.9893284478,6122874.0,927.0,372.0,954.0,582.0,719.125545687,47.913174921,4777151.0,723.0,0.00421940907836,0.253429591656,0.249210182577,0.123509157588,0.0197298884831,820.471333858,0.122242,997.0,2172.0,1175.0,1663.46138793,96.0163463663,11050374.0,1669.0,-0.176605224609,2.61770629883,2.79431152344,0.119671708038,0.262668790526,794.979156494,0.0
+13267997.0,217.000000003,160.0,3.06397476222,211.0,292.0,81.0,249.32718894,9.42586146982,216416.0,250.0,257.0,422.0,165.0,347.766129032,18.6945963075,301861.0,350.0,835.0,1180.0,345.0,1035.39861751,42.1125067396,898726.0,1039.0,194.0,427.0,233.0,293.0,23.7912871788,254324.0,292.0,0.453964203596,0.645865857601,0.191901654005,0.559260508775,0.0236181052931,485.438121617,0.560797,662.0,1141.0,479.0,890.093317972,47.6204202564,772601.0,891.5,-0.135314941406,4.66543579102,4.80075073242,0.790952726443,1.46326908438,686.546966553,0.14183
+13260965.0,17.2500000005,20.0,1.35840888633,294.0,473.0,179.0,371.028985507,40.5198004968,25601.0,371.0,358.0,620.0,262.0,427.753623188,57.4469902586,29515.0,415.0,230.0,581.0,351.0,358.260869565,86.4626336606,24720.0,329.0,246.0,613.0,367.0,352.492753623,83.3217307613,24322.0,336.0,-0.133226320148,0.140722289681,0.273948609829,0.00570857535838,0.0719570135517,0.393891699729,-0.00423131,990.0,1698.0,708.0,1151.27536232,165.247980896,79438.0,1109.0,0.051513671875,6.78356933594,6.73205566406,1.27715799083,1.86079050778,88.1239013672,0.712463
+13109424.0,969.499999996,777.0,7.03950594573,231.0,427.0,196.0,294.974213512,7.83818790418,1143910.0,295.0,302.0,619.0,317.0,405.876998453,12.6020366432,1573991.0,407.0,390.0,829.0,439.0,564.796802476,22.0548912031,2190282.0,564.0,320.0,859.0,539.0,506.395564724,23.2463609296,1963802.0,507.0,-0.0177725125104,0.170163169503,0.187935682014,0.0546721975952,0.0131154170311,212.018782274,0.0527298,877.0,1905.0,1028.0,1207.24677669,41.0725556914,4681703.0,1209.0,-0.161743164062,2.14685058594,2.30859375,0.596407405859,0.47234831402,2312.86791992,0.574081
+13249257.0,1860.99999993,1228.0,8.03008695703,274.0,362.0,88.0,300.177324019,5.00893790465,2234520.0,300.0,356.0,472.0,116.0,398.288420204,7.0852997517,2964859.0,398.0,439.0,613.0,174.0,500.476894143,12.0535759151,3725550.0,499.0,362.0,554.0,192.0,435.673293928,11.7000705599,3243152.0,435.0,0.0289219990373,0.110878661275,0.0819566622376,0.0692548174924,0.00758330226369,515.532861413,0.0689289,1009.0,1358.0,349.0,1134.13903815,21.087064903,8442531.0,1133.0,-0.393798828125,2.29632568359,2.69012451172,0.867661362883,0.451413259633,6458.8711853,0.936951
+13480880.0,6292.50000009,3825.0,13.6023797529,242.0,377.0,135.0,297.99753675,6.93785871025,7500598.0,298.0,299.0,530.0,231.0,404.009296782,12.6647173885,10168914.0,404.0,366.0,692.0,326.0,535.19749702,26.5292974849,13470921.0,534.0,278.0,669.0,391.0,455.385538339,23.0583105792,11462054.0,454.0,0.0168993379921,0.189261749387,0.172362411395,0.0805897678539,0.0113810254062,2028.44445688,0.0805501,820.0,1576.0,756.0,1157.39237187,40.8852444722,29131566.0,1156.0,-0.261535644531,16.7142028809,16.9757385254,0.310516237388,1.31902907954,7815.69369507,0.000915527
+13243324.0,19.5,23.0,1.46928348922,364.0,489.0,125.0,413.41025641,25.7823413517,32246.0,410.0,364.0,528.0,164.0,418.153846154,36.9632793955,32616.0,410.5,205.0,549.0,344.0,296.564102564,62.4552331456,23132.0,294.0,238.0,552.0,314.0,336.012820513,61.791106652,26209.0,324.5,-0.189189195633,0.0730411708355,0.262230366468,-0.0642017988303,0.067982619742,-5.00774030876,-0.0827822,1006.0,1444.0,438.0,1167.57692308,110.220934215,91071.0,1134.0,0.343719482422,0.641845703125,0.298126220703,0.42058974046,0.0951069377759,32.8059997559,0.374969
+13210950.0,459.500000004,176.0,2.3161409119,212.0,289.0,77.0,252.326441785,8.40960818081,463776.0,253.0,260.0,418.0,158.0,351.852013058,20.0698961921,646704.0,352.0,684.0,1209.0,525.0,969.761153428,74.3497606798,1782421.0,969.0,197.0,411.0,214.0,305.127312296,26.706849803,560824.0,306.0,0.396258503199,0.628053605556,0.231795102358,0.520556736936,0.0400061794414,956.783282489,0.520257,669.0,1105.0,436.0,909.305767138,52.3629469648,1671304.0,912.0,-0.149261474609,3.53668212891,3.68594360352,0.22119532472,0.327800097956,406.557006836,0.120407
+13232124.0,275.999999999,298.0,5.06007310166,249.0,409.0,160.0,349.485507246,23.4723042184,385832.0,352.0,383.0,629.0,246.0,532.78442029,38.3287256056,588194.0,537.0,812.0,1182.0,370.0,998.552536232,52.1216956074,1102402.0,999.0,443.0,813.0,370.0,661.505434783,62.3864328155,730302.0,666.0,0.114149823785,0.352812260389,0.238662436605,0.204293795726,0.0364031340392,225.540350482,0.196865,1085.0,1833.0,748.0,1543.77536232,115.169126934,1704328.0,1555.5,-0.0492553710938,0.7568359375,0.806091308594,0.0368957795959,0.0945491121702,40.7329406738,0.0
+13210616.0,19.5,22.0,1.40540159838,303.0,378.0,75.0,342.358974359,20.2939768499,26704.0,343.0,380.0,452.0,72.0,423.153846154,19.3258674288,33006.0,429.0,230.0,323.0,93.0,275.756410256,24.728881639,21509.0,281.0,264.0,340.0,76.0,299.807692308,16.4395221812,23385.0,301.5,-0.11313868314,0.0237659960985,0.136904679239,-0.0430076499186,0.034643442443,-3.35459669365,-0.040073,951.0,1161.0,210.0,1065.32051282,51.3563452225,83095.0,1077.0,0.367156982422,1.60806274414,1.24090576172,0.75064830291,0.307710930083,58.550567627,0.745102
+13178381.0,8.75000000023,13.0,1.23975079021,217.0,296.0,79.0,243.628571429,19.0953782206,8527.0,235.0,274.0,408.0,134.0,312.828571429,35.028548124,10949.0,298.0,304.0,513.0,209.0,384.0,59.0263863515,13440.0,371.0,223.0,453.0,230.0,290.885714286,60.0065574648,10181.0,261.0,0.0536130517721,0.323217004538,0.269603952765,0.141155482616,0.0553296638391,4.94044189155,0.143813,714.0,1157.0,443.0,847.342857143,113.698333411,29657.0,793.0,0.403076171875,1.20849609375,0.805419921875,0.657577950614,0.28632168977,23.0152282715,0.535889
+13157456.0,418.499999998,427.0,5.88810046989,200.0,332.0,132.0,262.280764636,15.284049686,439058.0,261.0,244.0,485.0,241.0,367.074074074,28.7202218629,614482.0,367.0,607.0,1277.0,670.0,978.911589008,94.9949030739,1638698.0,985.5,186.0,543.0,357.0,348.619474313,43.9981712253,583589.0,346.0,0.205052003264,0.608832836151,0.403780832887,0.474309698085,0.0521003648735,793.994434595,0.476686,640.0,1353.0,713.0,977.974313023,84.1433389563,1637129.0,972.0,-0.0436096191406,3.45416259766,3.4977722168,0.130668029421,0.299586509548,218.73828125,0.0
+13157915.0,260.749999998,205.0,3.58126757408,318.0,415.0,97.0,390.788111218,10.5204076245,407592.0,392.0,459.0,628.0,169.0,583.670182167,18.0807431255,608768.0,585.0,772.0,1069.0,297.0,967.803451582,28.7667697987,1009419.0,970.0,525.0,814.0,289.0,725.450623202,28.5236980261,756645.0,727.0,0.105949006975,0.191576093435,0.0856270864606,0.143276132086,0.0127902912716,149.437005766,0.143349,1302.0,1851.0,549.0,1699.90891659,55.9282887914,1773005.0,1705.0,-0.0448608398438,0.646942138672,0.691802978516,0.119229924759,0.16527657739,124.356811523,0.026947
+13327616.0,6939.74999992,4354.0,14.7438729522,221.0,947.0,726.0,306.422817825,11.3890147804,8505991.0,306.0,282.0,1545.0,1263.0,429.594798084,19.973733868,11925122.0,428.0,403.0,2143.0,1740.0,608.884361829,44.1946759164,16902021.0,601.0,306.0,2516.0,2210.0,516.159551857,38.3295947684,14328073.0,511.0,-0.0800601020455,0.25855961442,0.338619716465,0.0823359631032,0.0174377113578,2285.56399978,0.0804795,818.0,5008.0,4190.0,1252.17716777,65.9431554798,34759186.0,1245.0,-0.228149414062,5.11254882812,5.34069824219,0.200333588714,0.518261613433,5561.06008911,0.0
+13176883.0,2985.75000006,1966.0,10.1496685719,241.0,428.0,187.0,340.964581763,14.7765800486,4072140.0,341.0,329.0,612.0,283.0,512.024868124,26.9162205449,6115113.0,512.0,575.0,1060.0,485.0,876.081805242,54.0621261024,10463045.0,879.0,379.0,879.0,500.0,712.864858076,47.5415072955,8513745.0,715.0,0.0232249498367,0.240137219429,0.216912269592,0.10285022501,0.0204436749029,1228.34023729,0.0988336,949.0,1882.0,933.0,1565.85430796,84.0678209401,18700998.0,1569.0,-0.223175048828,3.13882446289,3.36199951172,0.133262766513,0.368447534418,1591.55722046,0.0
+13254773.0,1580.75000003,1121.0,7.95369778813,175.0,1445.0,1270.0,302.410406453,19.0027091939,1912141.0,302.0,208.0,2330.0,2122.0,413.883915863,31.6875382156,2616988.0,413.0,330.0,2736.0,2406.0,574.535979756,40.3959028614,3632791.0,572.0,123.0,3661.0,3538.0,468.044124624,52.6190729076,2959443.0,466.0,-0.144599035382,0.456953644753,0.601552680135,0.102733934075,0.0159126896577,649.586665157,0.101964,506.0,7436.0,6930.0,1184.33844694,101.875882878,7488572.0,1181.0,-0.141571044922,1.99606323242,2.13763427734,1.20660846354,0.457109873576,7629.38531494,1.34232
+13106576.0,169.749999999,84.0,1.81873515943,197.0,287.0,90.0,242.533136966,12.2377650372,164680.0,243.0,262.0,407.0,145.0,334.706921944,22.0329341606,227266.0,334.0,805.0,1249.0,444.0,986.011782032,86.3382216691,669502.0,979.0,180.0,390.0,210.0,288.075110457,30.5270629919,195603.0,290.0,0.41397446394,0.689629077911,0.275654613972,0.54697594029,0.0434662873331,371.396663457,0.547325,646.0,1062.0,416.0,865.315169367,61.3095738806,587549.0,865.0,-0.0561828613281,1.43859863281,1.49478149414,0.336488299588,0.367646378526,228.47555542,0.284332
+13071596.0,97.249999997,75.0,2.14541605545,200.0,275.0,75.0,237.100257069,11.1388860047,92232.0,239.0,265.0,398.0,133.0,339.362467866,20.1494347922,132012.0,342.0,737.0,1219.0,482.0,1038.74550129,73.9599315656,404072.0,1037.0,186.0,373.0,187.0,270.699228792,27.0991614175,105302.0,273.0,0.513176143169,0.670608103275,0.157431960106,0.586602878754,0.0294261921325,228.188519835,0.586351,654.0,1046.0,392.0,847.161953728,57.0718393841,329546.0,855.0,-0.0726318359375,1.15130615234,1.22393798828,0.336476147022,0.446642941777,130.889221191,0.0
+13065699.0,6.75,13.0,1.41151836772,627.0,938.0,311.0,767.777777778,75.2188576303,20730.0,752.0,984.0,1445.0,461.0,1172.77777778,107.266830099,31665.0,1162.0,1371.0,2251.0,880.0,1758.07407407,230.383404419,47468.0,1793.0,1206.0,1848.0,642.0,1442.51851852,165.09870681,38948.0,1409.0,0.00430107535794,0.191502466798,0.18720139144,0.097095112644,0.048578135079,2.62156804139,0.0983167,2892.0,4231.0,1339.0,3383.07407407,334.498732315,91343.0,3328.0,-0.018798828125,0.012451171875,0.03125,-0.00131451642072,0.00573435152568,-0.0354919433594,0.0
+13054331.0,47.0000000019,38.0,1.56361466731,210.0,296.0,86.0,252.015957447,14.589225135,47379.0,253.0,281.0,422.0,141.0,351.957446809,22.7948365251,66168.0,353.0,773.0,1045.0,272.0,911.414893617,52.641887208,171346.0,913.5,229.0,454.0,225.0,352.771276596,40.1303172982,66321.0,356.5,0.34769231081,0.542914152145,0.195221841335,0.442956845177,0.0420847877542,83.2758868933,0.446704,720.0,1167.0,447.0,956.744680851,75.3074458993,179868.0,963.0,-0.0892333984375,1.11755371094,1.20678710938,0.0437899650411,0.141181433891,8.23251342773,0.0
+13047195.0,4.75,15.0,1.94150951028,191.0,260.0,69.0,228.578947368,19.5402844064,4343.0,232.0,241.0,342.0,101.0,295.263157895,29.0187636308,5610.0,292.0,391.0,633.0,242.0,506.105263158,69.1039603838,9616.0,524.0,154.0,311.0,157.0,235.0,46.8828326789,4465.0,227.0,0.260752677917,0.515723288059,0.254970610142,0.36823468773,0.0772685058301,6.99645906687,0.373676,586.0,913.0,327.0,758.842105263,94.4882410717,14418.0,738.0,0.626861572266,1.13970947266,0.512847900391,1.08128116005,0.155475914813,20.544342041,1.13425
+13060909.0,274.999999999,311.0,5.2904073139,237.0,482.0,245.0,286.863636364,16.1611640404,315550.0,286.0,299.0,701.0,402.0,381.935454545,25.6024220671,420129.0,383.0,391.0,996.0,605.0,502.138181818,44.3739173631,552352.0,502.0,293.0,995.0,702.0,438.478181818,45.2255205143,482326.0,440.0,-0.0115089509636,0.161749750376,0.173258701339,0.0681790904136,0.0168722141708,74.9969994549,0.066124,831.0,2178.0,1347.0,1107.27727273,83.8327470829,1218005.0,1111.0,-0.0453491210938,2.8544921875,2.89984130859,0.727090565075,0.802508329932,799.799621582,0.322754
+13026919.0,926.749998957,906.0,8.39541112645,240.0,459.0,219.0,302.619099002,9.61977674431,1121809.0,303.0,315.0,676.0,361.0,425.702724575,16.3551460359,1578080.0,426.0,482.0,956.0,474.0,635.072565417,38.9683508218,2354214.0,635.0,339.0,934.0,595.0,543.466684651,32.6781339096,2014631.0,543.0,-0.00569259980693,0.174458384514,0.180150984321,0.0776581732207,0.0135217111916,287.878848129,0.0769231,899.0,2056.0,1157.0,1271.78850823,54.2615189002,4714520.0,1273.0,-0.24609375,3.50537109375,3.75146484375,0.118974116088,0.416914809453,441.03704834,0.0
+13021336.0,292.999999998,124.0,2.043539059,289.0,480.0,191.0,400.296075085,23.6649007447,469147.0,405.0,368.0,663.0,295.0,581.914675768,40.6267605822,682004.0,590.5,499.0,999.0,500.0,727.779863481,47.6300376012,852958.0,726.0,282.0,703.0,421.0,613.497440273,45.5496296887,719019.0,620.0,-0.00239425385371,0.290845900774,0.293240154628,0.0855650960924,0.0318192437477,100.28229262,0.0770428,939.0,1765.0,826.0,1595.70819113,101.736921497,1870170.0,1615.0,0.0,4.1242980957,4.1242980957,3.11818728919,0.748208842928,3654.51550293,3.26338
+12987874.0,54.0000000065,73.0,2.80234143443,284.0,311.0,27.0,296.217592593,5.18311590655,63983.0,296.0,395.0,443.0,48.0,411.722222222,7.16774324386,88932.0,411.0,540.0,622.0,82.0,566.101851852,12.8477118692,122278.0,566.0,479.0,559.0,80.0,504.87962963,11.2852063049,109054.0,504.0,0.042990654707,0.0714285746217,0.0284379199147,0.0571589773107,0.00621826612911,12.3463390991,0.0569731,1162.0,1307.0,145.0,1212.81944444,20.9585082093,261969.0,1213.0,-0.0476989746094,0.520111083984,0.567810058594,0.184820810954,0.125153611603,39.921295166,0.176331
+13007577.0,431.749999985,247.0,3.35332655506,246.0,316.0,70.0,294.11059641,7.22826098404,507929.0,294.0,307.0,434.0,127.0,390.286624204,12.650234898,674025.0,390.0,402.0,630.0,228.0,517.315576144,32.3602425638,893404.0,511.0,293.0,519.0,226.0,429.839027215,27.0878094483,742332.0,428.0,0.0561797767878,0.164804473519,0.108624696732,0.0923773050718,0.0126776705687,159.535605859,0.091858,846.0,1262.0,416.0,1114.23624783,44.368825885,1924286.0,1112.0,0.140441894531,0.735443115234,0.595001220703,0.380920586865,0.104010028292,657.849853516,0.365845
+12960503.0,1845.50000004,550.0,3.61160905084,213.0,333.0,120.0,280.220265511,18.4909558841,2068586.0,280.0,268.0,492.0,224.0,380.044296938,36.5664674936,2805487.0,379.0,397.0,989.0,592.0,634.411677052,90.8939988921,4683227.0,624.0,239.0,572.0,333.0,413.638715795,59.0187754602,3053481.0,409.0,-0.0479616299272,0.403100788593,0.45106241852,0.210391960961,0.0367779714235,1553.11345582,0.207599,720.0,1368.0,648.0,1073.90327824,112.995387479,7927554.0,1069.0,-0.062255859375,1.44104003906,1.50329589844,0.101282091329,0.162299656251,747.664398193,0.00149536
+12997349.0,211.499999997,77.0,1.49358728338,229.0,307.0,78.0,267.482269504,11.3312072496,226290.0,268.0,300.0,459.0,159.0,365.326241135,19.1005166667,309066.0,364.0,678.0,1000.0,322.0,838.856973995,44.533034115,709673.0,834.0,253.0,512.0,259.0,358.722222222,31.8944351072,303479.0,357.0,0.256821841002,0.51970666647,0.262884825468,0.401172069758,0.0412816091266,339.391571015,0.404695,800.0,1245.0,445.0,991.530732861,58.0322187857,838835.0,989.0,-0.0570678710938,1.01098632812,1.06805419922,0.0503997802734,0.153755253123,42.6382141113,0.0
+12981066.0,20.9999999998,20.0,1.23116260616,270.0,414.0,144.0,306.30952381,29.4557683697,25730.0,296.5,327.0,610.0,283.0,398.154761905,53.1862168969,33445.0,389.0,785.0,1236.0,451.0,973.285714286,70.7770764996,81756.0,976.0,686.0,1052.0,366.0,765.5,63.6954248189,64302.0,745.5,0.0269340965897,0.163990825415,0.137056728825,0.119626918298,0.0304867532585,10.048661137,0.127627,1304.0,1998.0,694.0,1469.96428571,132.934771548,123477.0,1425.5,2.73065185547,3.03115844727,0.300506591797,2.87393915086,0.0895894734746,241.410888672,2.85878
+12970089.0,23.9999999991,26.0,1.4971413144,1069.0,1420.0,351.0,1228.01041667,80.89402723,117889.0,1230.5,1730.0,2218.0,488.0,1832.72916667,80.5851618846,175942.0,1823.5,1866.0,2254.0,388.0,1995.82291667,84.4061355876,191599.0,1980.5,1820.0,2346.0,526.0,1957.4375,100.093166236,187914.0,1943.0,-0.03361742571,0.0598626099527,0.0934800356627,0.00989582439979,0.0176379726399,0.94999914238,0.010213,4833.0,5867.0,1034.0,5018.17708333,149.106155892,481745.0,4987.0,0.272125244141,4.30969238281,4.03756713867,2.77058792114,1.43093665783,265.97644043,3.42238
+12972815.0,235.499999993,92.0,1.69117067606,307.0,534.0,227.0,452.83014862,33.818624873,426566.0,460.0,429.0,729.0,300.0,645.693205945,46.0418476745,608243.0,658.5,595.0,1104.0,509.0,820.785562633,73.4743386003,773180.0,823.5,417.0,966.0,549.0,733.747346072,66.449842748,691190.0,740.0,-0.0138696255162,0.251764714718,0.265634340234,0.0561604634157,0.0365364915194,52.9031565376,0.0471271,1213.0,2160.0,947.0,1832.27070064,126.407313423,1725999.0,1862.0,0.321044921875,5.83401489258,5.5129699707,4.14858007735,0.765227166969,3907.96243286,4.19148
+12959759.0,26.25,22.0,1.21130384263,295.0,553.0,258.0,473.00952381,56.9416568976,49666.0,485.0,560.0,882.0,322.0,718.247619048,75.6020635839,75416.0,716.0,642.0,1032.0,390.0,859.59047619,81.5427080899,90257.0,848.0,619.0,1048.0,429.0,823.247619048,76.6221130524,86441.0,818.0,-0.0433051250875,0.0683229789138,0.111628104001,0.0214572556661,0.0249757609281,2.25301184494,0.0210396,1523.0,2322.0,799.0,2014.5047619,141.882991619,211523.0,2027.0,-0.0008544921875,0.918273925781,0.919128417969,0.059514218285,0.153840592135,6.24899291992,0.00283813
+12947385.0,17.25,30.0,2.03761332953,241.0,329.0,88.0,282.014492754,21.6958506376,19459.0,276.0,311.0,495.0,184.0,405.188405797,43.7039696941,27958.0,397.0,770.0,1169.0,399.0,917.405797101,101.486105116,63301.0,878.0,330.0,631.0,301.0,459.15942029,82.7135134655,31682.0,425.0,0.229548230767,0.416129022837,0.186580792069,0.336438780462,0.0426055819031,23.2142758518,0.340764,882.0,1434.0,552.0,1146.36231884,144.480275071,79099.0,1112.0,-0.0180053710938,1.05856323242,1.07656860352,0.0828052465466,0.23390274683,5.71356201172,0.0
+12942081.0,60.7499999974,115.0,4.16216954593,216.0,263.0,47.0,227.604938272,5.54891235184,55308.0,227.0,250.0,332.0,82.0,274.452674897,8.90327672637,66692.0,273.0,221.0,526.0,305.0,298.847736626,38.941940864,72620.0,295.0,194.0,330.0,136.0,227.724279835,14.4718439204,55337.0,227.0,-0.0289256200194,0.300840348005,0.329765968025,0.13168671543,0.0627105634956,31.9998718495,0.137331,660.0,925.0,265.0,729.781893004,27.8821328935,177337.0,728.0,-0.0093994140625,1.48641967773,1.4958190918,0.441214479046,0.318043574619,107.215118408,0.333984
+12935433.0,75.2500000019,56.0,1.82108343044,210.0,289.0,79.0,235.063122924,13.3077302073,70754.0,231.0,249.0,400.0,151.0,287.813953488,25.0927569194,86632.0,279.0,320.0,656.0,336.0,419.425249169,65.0095205935,126247.0,404.0,179.0,401.0,222.0,236.710963455,35.7187171785,71250.0,226.0,0.157342657447,0.415032684803,0.257690027356,0.277078212595,0.0524139339567,83.400541991,0.278891,643.0,1090.0,447.0,759.588039867,72.4375528273,228636.0,735.0,-0.00238037109375,1.09005737305,1.09243774414,0.170893570909,0.196487640076,51.4389648438,0.120239
+12908685.0,195.750000005,146.0,2.94372365942,212.0,286.0,74.0,225.224776501,6.28042422121,176351.0,224.0,242.0,374.0,132.0,265.697318008,10.5024028369,208041.0,265.0,187.0,514.0,327.0,277.091954023,30.3598969897,216963.0,276.0,185.0,387.0,202.0,218.446998723,16.325455542,171044.0,216.0,-0.107398569584,0.284467726946,0.39186629653,0.116454487894,0.0559099636887,91.1838640212,0.123506,645.0,1047.0,402.0,709.369093231,31.5725023039,555436.0,706.0,-0.0191650390625,2.74261474609,2.76177978516,0.692443224053,0.641733391552,542.183044434,0.611481
+12904004.0,59.2500000014,50.0,1.83240258166,201.0,268.0,67.0,238.53164557,10.9534906018,56532.0,240.0,266.0,425.0,159.0,347.185654008,24.0517928509,82283.0,347.0,1058.0,1436.0,378.0,1288.85654008,59.6342269391,305459.0,1295.0,144.0,342.0,198.0,255.603375527,31.7304521238,60578.0,258.0,0.613508462906,0.769784152508,0.156275689602,0.669889495091,0.0290178823744,158.763810337,0.669046,611.0,1033.0,422.0,841.320675105,64.8927589432,199393.0,845.0,0.0150146484375,1.25677490234,1.24176025391,0.451833217959,0.198841035959,107.084472656,0.495544
+12892421.0,1470.75000001,1122.0,8.25312639658,256.0,386.0,130.0,315.91126976,14.4670032736,1858506.0,316.0,362.0,613.0,251.0,472.288288288,27.5002049443,2778472.0,472.0,702.0,1069.0,367.0,856.358660547,49.0930444614,5037958.0,857.0,411.0,850.0,439.0,628.6945436,48.0121062678,3698610.0,631.0,0.0912343487144,0.307046979666,0.215812630951,0.153890728265,0.0204196127036,905.339154385,0.150803,1047.0,1849.0,802.0,1416.89410165,85.5579253889,8335588.0,1420.0,-0.0725402832031,2.17352294922,2.24606323242,0.322343301392,0.311290422895,1896.34564209,0.233551
+12883190.0,794.250000017,512.0,5.12491205547,186.0,404.0,218.0,268.260623229,15.8728640658,852264.0,267.0,245.0,608.0,363.0,370.252439408,28.7241531314,1176292.0,369.0,498.0,1167.0,669.0,795.677683349,83.9694399117,2527868.0,801.0,204.0,747.0,543.0,393.618193264,51.590369412,1250525.0,389.0,0.143795147538,0.494656503201,0.350861355662,0.338228202031,0.0521611552999,1074.55099785,0.339623,644.0,1759.0,1115.0,1032.1312559,94.2065222154,3279081.0,1023.0,-0.149688720703,2.87509155273,3.02478027344,0.107772726288,0.253238430611,342.393951416,0.0
+12863943.0,4.0,14.0,1.97466354242,190.0,284.0,94.0,240.3125,29.7504595553,3845.0,246.0,221.0,376.0,155.0,305875.0,51.2614316519,4894.0,310.5,322.0,543.0,221.0,443375.0,71.1827533536,7094.0,449.0,136.0,416.0,280.0,296125.0,88.5860281026,4738.0,312.0,0.113006398082,0.406113535166,0.293107137084,0.216330632567,0.0846580482123,3.46129012108,0.180792,548.0,1070.0,522.0,842.3125,169.205023104,13477.0,868.5,0.000213623046875,0.241363525391,0.241149902344,0.157348632812,0.0785256921129,2.517578125,0.180817
+12863679.0,1252.0,530.0,4.22540919595,166.0,297.0,131.0,225.750199681,12.4761313633,1130557.0,226.0,180.0,406.0,226.0,280.684105431,25.6347698386,1405666.0,280.0,538.0,1390.0,852.0,1027.47943291,115.379336756,5145617.0,1024.0,60.0,445.0,385.0,223.556110224,36.1382082353,1119569.0,224.0,0.448574960232,0.863791167736,0.415216207504,0.642398755438,0.0466650193457,3217.13296723,0.643909,411.0,1148.0,737.0,729.990415335,71.9620139911,3655792.0,731.0,-0.030517578125,10.7811584473,10.8116760254,6.21453598437,2.9781536283,31122.3962097,6.65961
+12846582.0,19.7499999995,19.0,1.20604946114,345.0,425.0,80.0,387.329113924,17.9533301583,30599.0,387.0,482.0,641.0,159.0,583.759493671,38.8014142995,46117.0,592.0,587.0,912.0,325.0,755.17721519,65.2366208202,59659.0,756.0,585.0,837.0,252.0,731.594936709,53.267778036,57796.0,748.0,-0.044959127903,0.1218855232,0.166844651103,0.0153098797361,0.0387767550368,1.20948049915,0.00884956,1424.0,1836.0,412.0,1702.6835443,96.2154155263,134512.0,1730.0,0.444732666016,0.494995117188,0.0502624511719,0.472077961209,0.013955135115,37.2941589355,0.473053
+12926138.0,3366.50000003,2105.0,10.2342932927,218.0,545.0,327.0,359.317763256,25.3462422943,4838573.0,360.0,298.0,801.0,503.0,556.08020199,45.6255556126,7488176.0,561.0,609.0,1252.0,643.0,966.06067132,77.3194986654,13008973.0,979.0,338.0,1001.0,663.0,723.231991683,74.8069098442,9739042.0,736.0,0.00128205132205,0.386383742094,0.385101690772,0.144738353203,0.031309263638,1949.04666423,0.139223,891.0,2207.0,1316.0,1638.62995693,133.452521907,22065791.0,1658.0,-0.276611328125,6.79995727539,7.07656860352,0.128692067185,0.330138668816,1732.96737671,0.0
+12835495.0,46.2499999977,38.0,1.57624163958,255.0,291.0,36.0,270.459459459,7.62497530202,50035.0,269.0,358.0,435.0,77.0,394.043243243,17.8170361921,72898.0,393.0,331.0,518.0,187.0,418.254054054,32.4349710718,77377.0,417.0,369.0,469.0,100.0,413.92972973,23.5411183098,76577.0,412.0,-0.160963237286,0.122426867485,0.283390104771,0.00449072691247,0.0584377605778,0.830784478807,0.00985222,984.0,1192.0,208.0,1078.43243243,47.439600598,199510.0,1072.0,-0.0445251464844,0.630340576172,0.674865722656,0.0682000237542,0.141809303682,12.6170043945,0.0
+12836804.0,39.2499999991,37.0,1.66600753586,187.0,292.0,105.0,247.630573248,20.7822457987,38878.0,250.0,229.0,412.0,183.0,329.872611465,38.7478745856,51790.0,338.0,442.0,1069.0,627.0,845.394904459,127.538567064,132727.0,867.0,121.0,421.0,300.0,284.987261146,57.2354603973,44743.0,292.0,0.358231693506,0.706666648388,0.348434954882,0.497159636135,0.0623336066779,78.0540628731,0.494845,537.0,1125.0,588.0,862.49044586,115.576462563,135411.0,874.0,2.03903198242,3.68383789062,1.6448059082,2.18081878856,0.194536894143,342.388549805,2.13895
+12834826.0,3613.74999996,2906.0,13.6367734519,221.0,468.0,247.0,324.842338291,18.5913465344,4695596.0,324.0,281.0,733.0,452.0,475.370529229,30.9597002595,6871481.0,475.0,416.0,1120.0,704.0,765.95814597,59.9881388474,11071925.0,768.0,259.0,1022.0,763.0,632.595641646,54.2905958844,9144170.0,634.0,0.00784313771874,0.254237294197,0.246394156478,0.0956750212286,0.0222075789035,1382.98243186,0.0945559,761.0,2223.0,1462.0,1432.80850917,98.2500301069,20711247.0,1434.0,-0.166015625,3.68041992188,3.84643554688,0.605408253203,0.792064699771,8751.17630005,0.301117
+12856689.0,1142.5,432.0,3.60537722039,260.0,419.0,159.0,342.885776805,16.3354092813,1566988.0,344.0,417.0,675.0,258.0,541.110940919,28.5779932201,2472877.0,542.0,778.0,1138.0,360.0,943.577461707,44.3963180767,4312149.0,943.0,494.0,874.0,380.0,695.333479212,44.4034560567,3177674.0,696.0,0.0772486776114,0.244444444776,0.167195767164,0.151880250733,0.0175262157407,694.092745848,0.149936,1181.0,1958.0,777.0,1579.33019694,86.2003349956,7217539.0,1581.0,-0.980499267578,2.40780639648,3.38830566406,0.137113348295,0.348188017387,626.608001709,0.0
+12813200.0,617.999999972,394.0,4.4709215787,210.0,419.0,209.0,338.566343042,27.0487777044,836936.0,341.0,334.0,637.0,303.0,512.030744337,47.848042164,1265740.0,516.0,634.0,1146.0,512.0,895.791666667,72.9182492893,2214397.0,897.0,341.0,819.0,478.0,620.510517799,72.2894826849,1533902.0,624.0,0.0567201003432,0.340720236301,0.284000135958,0.182994306642,0.0401323724054,452.361926019,0.173384,885.0,1799.0,914.0,1471.10760518,138.454050211,3636578.0,1476.0,-0.211120605469,0.962768554688,1.17388916016,0.101775283567,0.137249058293,251.588500977,0.0407562
+12777832.0,129.750000006,69.0,1.70879701009,284.0,501.0,217.0,418.447013487,21.9789833433,217174.0,420.0,394.0,750.0,356.0,610.820809249,34.9611492401,317016.0,617.0,519.0,1045.0,526.0,704.909441233,43.6368518964,365848.0,702.0,397.0,1006.0,609.0,682.429672447,46.899621894,354181.0,685.0,-0.0613973177969,0.157157152891,0.218554470688,0.0165455721779,0.0226225232221,8.58715196035,0.0130246,1160.0,2256.0,1096.0,1711.69749518,95.8232306654,888371.0,1721.0,2.41564941406,5.3830871582,2.96743774414,4.30209432907,0.477983810639,2232.78695679,4.20819
+12798906.0,364.749999992,199.0,2.9393445301,199.0,265.0,66.0,243.629883482,7.95033146766,355456.0,244.0,256.0,389.0,133.0,348.674434544,16.8410371459,508716.0,350.0,949.0,1341.0,392.0,1175.33653187,53.1606367412,1714816.0,1178.0,143.0,323.0,180.0,259.492117889,21.1178464875,378599.0,260.0,0.561439216137,0.738095223904,0.176656007767,0.638513290858,0.0213909105887,931.590891361,0.6375,598.0,963.0,365.0,851.796435915,44.1550211805,1242771.0,853.0,-0.168792724609,6.98291015625,7.15170288086,0.461886954357,1.3740171905,673.893066406,0.0
+12772722.0,122.249999994,146.0,3.72497609391,271.0,372.0,101.0,326.235173824,15.3862309977,159529.0,328.0,368.0,559.0,191.0,507.924335378,30.7518666336,248375.0,514.0,359.0,705.0,346.0,504.020449898,57.3862134655,246466.0,504.0,376.0,668.0,292.0,545.341513292,35.0821987521,266672.0,549.0,-0.254901975393,0.170902714133,0.425804689527,-0.0412883062619,0.0731590980777,-20.1899817621,-0.0430528,1015.0,1599.0,584.0,1379.50102249,73.5048132126,674576.0,1393.0,-0.123474121094,0.393707275391,0.517181396484,0.00626028486069,0.0377778742446,3.06127929688,0.0
+12737943.0,351.749999999,157.0,2.36144408864,202.0,272.0,70.0,230.495380242,10.2535628343,324307.0,229.0,260.0,379.0,119.0,311.931769723,20.4687334133,438888.0,310.0,642.0,1207.0,565.0,977.507462687,83.7252574984,1375353.0,974.0,181.0,351.0,170.0,244.855721393,25.8423643995,344512.0,241.0,0.454710155725,0.709363281727,0.254653126001,0.598173141607,0.0434233412228,841.62961024,0.60221,648.0,978.0,330.0,787.282871357,54.5548465715,1107707.0,779.0,-0.132080078125,1.51138305664,1.64346313477,0.286386887063,0.280923908012,402.946350098,0.249176
+12719850.0,12.0,32.0,2.60588006348,268.0,440.0,172.0,334.729166667,29.2494583877,16067.0,339.5,328.0,611.0,283.0,403.416666667,48.4943438855,19364.0,394.0,256.0,628.0,372.0,377.208333333,79.6735418059,18106.0,353.0,176.0,533.0,357.0,260.833333333,67.9780397547,12520.0,242.5,-0.00187617260963,0.380281686783,0.382157859392,0.18439106164,0.082647324969,8.8507709587,0.191512,798.0,1584.0,786.0,998.979166667,132.942733533,47951.0,972.0,0.279663085938,1.76910400391,1.48944091797,0.775421778361,0.407192359361,37.2202453613,0.8311
+12835703.0,1702.25000004,1627.0,11.1242553562,243.0,415.0,172.0,346.510353943,16.0034854482,2359389.0,347.0,354.0,636.0,282.0,532.860185049,25.4627286475,3628245.0,534.0,669.0,1098.0,429.0,951.768541636,40.0550312105,6480592.0,953.0,394.0,884.0,490.0,717.683947716,38.2192926077,4886710.0,719.0,0.0851063802838,0.272391498089,0.187285117805,0.140466188649,0.0160016643031,956.434278511,0.139272,1004.0,1924.0,920.0,1597.05448671,74.8934709099,10874344.0,1601.0,-0.0679931640625,1.37426757812,1.44226074219,0.165418477254,0.157817780854,1126.33441162,0.125732
+12713906.0,5616.24999953,3460.0,13.0241068644,206.0,487.0,281.0,324.558869352,16.1610280948,7291215.0,324.0,279.0,754.0,475.0,476.849187625,29.2264930226,10712417.0,477.0,567.0,1067.0,500.0,848.713064767,54.5192192411,19066339.0,851.0,286.0,1015.0,729.0,634.91671489,49.664956772,14263404.0,638.0,0.0249759852886,0.334109425545,0.309133440256,0.14452337257,0.0256364379692,3246.71756479,0.140471,796.0,2256.0,1460.0,1436.32477187,90.3301865271,32267036.0,1442.0,-0.290802001953,8.26229858398,8.55310058594,0.094285630023,0.226554733343,2118.12667847,0.0
+12644268.0,17.5000000002,18.0,1.21380395641,336.0,402.0,66.0,367.3,10.9301026005,25711.0,367.0,480.0,589.0,109.0,547.114285714,19.6567275704,38298.0,550.5,576.0,703.0,127.0,641.971428571,29.9528064168,44938.0,640.5,563.0,719.0,156.0,646.757142857,30.6400464911,45273.0,649.0,-0.0410534478724,0.043330501765,0.0843839496374,-0.00368851299364,0.0191317839768,-0.258195909555,-0.00813869,1379.0,1677.0,298.0,1561.17142857,58.1026115539,109282.0,1567.5,2.66714477539,3.47134399414,0.80419921875,3.21156136649,0.245398178892,224.809295654,3.32202
+12682182.0,1637.0,1326.0,9.24515618391,216.0,458.0,242.0,347.32666463,15.4047423873,2274295.0,347.0,301.0,723.0,422.0,531.579718998,26.2066041408,3480784.0,532.5,599.0,1073.0,474.0,945.643708002,43.3023842648,6192075.0,949.5,419.0,930.0,511.0,750.641722663,42.1205680675,4915202.0,754.0,0.0436385981739,0.241628959775,0.197990361601,0.115200285669,0.0178045936147,754.33147056,0.113463,936.0,2111.0,1175.0,1629.54810629,73.9964583413,10670281.0,1634.0,-0.236755371094,1.68585205078,1.92260742188,0.160133403762,0.266269262371,1048.55352783,3.05176e-05
+12629325.0,17.0,31.0,2.12095913591,207.0,273.0,66.0,230.75,16.48205352,15691.0,227.0,242.0,366.0,124.0,289.176470588,34.0505425268,19664.0,276.5,299.0,582.0,283.0,411.720588235,84.8760074164,27997.0,385.0,187.0,404.0,217.0,272.691176471,57.1008543649,18543.0,252.5,0.104212857783,0.292906165123,0.18869330734,0.203396310153,0.0389770169757,13.8309490904,0.198308,640.0,1043.0,403.0,792.617647059,106.017344504,53898.0,754.0,2.85153198242,3.8948059082,1.04327392578,3.17101287842,0.220504136511,215.628875732,3.14273
+12596476.0,10.2500000002,15.0,1.3216741452,283.0,379.0,96.0,334.902439024,23.6238871237,13731.0,339.0,308.0,391.0,83.0,361.317073171,16.3415362212,14814.0,363.0,171.0,329.0,158.0,230.073170732,40.5765703415,9433.0,218.0,183.0,306.0,123.0,264.195121951,26.7866179842,10832.0,269.0,-0.226244345307,0.0769230797887,0.303167425096,-0.0731931552859,0.0668498641675,-3.00091936672,-0.0738255,818.0,1076.0,258.0,960.414634146,51.7856631491,39377.0,956.0,2.99526977539,3.04736328125,0.0520935058594,3.01260152677,0.0201302014873,123.516662598,2.99918
+12654292.0,1249.49999998,889.0,7.09461281006,212.0,377.0,165.0,295.163865546,14.2064664255,1475229.0,295.0,265.0,554.0,289.0,414.085234094,25.2999915787,2069598.0,413.0,457.0,987.0,530.0,769.649259704,47.465562488,3846707.0,771.0,202.0,741.0,539.0,497.510804322,43.3797660777,2486559.0,497.0,0.0835913345218,0.396113604307,0.312522269785,0.215443766853,0.032926020967,1076.78794673,0.214798,684.0,1666.0,982.0,1206.75990396,80.6997804134,6031386.0,1204.0,-0.184417724609,1.22909545898,1.41351318359,0.0642433731305,0.165724559095,321.088378906,0.0
+12575797.0,1105.49999996,477.0,4.04700809959,197.0,302.0,105.0,253.107869742,8.80518773803,1119243.0,253.0,239.0,450.0,211.0,364.788331072,15.755552085,1613094.0,365.0,723.0,1195.0,472.0,1017.1840796,49.5718442558,4497988.0,1021.0,139.0,455.0,316.0,318.955676165,24.4303684371,1410422.0,318.0,0.396551728249,0.695509314537,0.298957586288,0.522522245763,0.0310778054878,2310.59337077,0.524053,576.0,1197.0,621.0,936.851876979,46.4157318936,4142759.0,937.0,-0.0797119140625,3.27233886719,3.35205078125,0.129758354335,0.313293193373,573.791442871,0.0
+12554670.0,548.749999968,354.0,4.26295809364,199.0,374.0,175.0,275.072437358,22.3421466785,603784.0,274.0,233.0,538.0,305.0,380.752164009,42.3635807466,835751.0,382.0,550.0,1106.0,556.0,851.887015945,89.1850268339,1869892.0,870.0,191.0,657.0,466.0,415.6,66.4752845982,912242.0,408.0,0.222222223878,0.529556632042,0.307334408164,0.346686021091,0.0421749941573,760.975816295,0.348579,623.0,1550.0,927.0,1071.42460137,128.506072238,2351777.0,1066.0,-0.156280517578,1.19384765625,1.35012817383,0.0526076888169,0.159775694531,115.473876953,0.0
+12541165.0,21.2500000005,30.0,1.83584856981,283.0,484.0,201.0,349.588235294,32.1380456661,29715.0,347.0,336.0,661.0,325.0,418.352941176,47.454673329,35560.0,417.0,202.0,629.0,427.0,344.635294118,84.3636173406,29294.0,317.0,124.0,615.0,491.0,278.858823529,72.1767687802,23703.0,267.0,-0.0294627379626,0.291028439999,0.320491177961,0.106660535571,0.0707254026095,9.06614552357,0.104796,826.0,1760.0,934.0,1046.8,137.80581393,88978.0,1018.0,0.525573730469,1.31860351562,0.793029785156,0.759758085363,0.17810142377,64.5794372559,0.666382
+12527959.0,2.75,9.0,1.53098603939,214.0,249.0,35.0,231.090909091,11.2124488077,2542.0,228.0,272.0,327.0,55.0,298.181818182,18.8043427374,3280.0,296.0,410.0,536.0,126.0,467.818181818,37.64382886,5146.0,463.0,221.0,318.0,97.0,266.363636364,32.0943855959,2930.0,262.0,0.199481859803,0.331334322691,0.131852462888,0.275769584558,0.0390770184886,3.03346543014,0.277778,709.0,888.0,179.0,795.636363636,61.6253677507,8752.0,788.0,3.46545410156,3.47952270508,0.0140686035156,3.47283935547,0.00399308783669,38.2012329102,3.47278
+12606445.0,2721.24999996,1554.0,8.40353206313,213.0,394.0,181.0,333.098208544,15.0437793677,3625774.0,334.0,279.0,610.0,331.0,491.008911346,27.4822498954,5344632.0,492.0,480.0,1035.0,555.0,846.800551217,47.3820892228,9217424.0,849.0,231.0,814.0,583.0,640.815525953,47.6667284682,6975277.0,645.0,0.0618618614972,0.367123275995,0.305261414498,0.13904191933,0.0201460662241,1513.4712919,0.135691,723.0,1810.0,1087.0,1464.92264584,88.0300919798,15945683.0,1471.0,-0.165649414062,1.02734375,1.19299316406,0.052809100311,0.111072253223,574.827056885,0.0
+12517603.0,27.4999999991,26.0,1.39862751903,320.0,398.0,78.0,372.854545455,15.9070232423,41014.0,375.5,459.0,605.0,146.0,556.890909091,30.898468763,61258.0,567.0,557.0,731.0,174.0,663.718181818,31.2422010103,73009.0,666.0,522.0,726.0,204.0,651.418181818,39.3352448525,71656.0,661.0,-0.0515151508152,0.0805316641927,0.132046815008,0.00974063110982,0.0207612445228,1.07146942208,0.00706629,1319.0,1725.0,406.0,1581.16363636,82.2242529221,173928.0,1603.0,2.11480712891,2.99475097656,0.879943847656,2.36485290527,0.209315718935,260.13381958,2.33492
+12499479.0,11.0,14.0,1.19076691953,334.0,437.0,103.0,371.181818182,23.2997002783,16332.0,371.5,608.0,832.0,224.0,755.272727273,53.5071633422,33232.0,765.0,942.0,1281.0,339.0,1142.43181818,82.4895028383,50267.0,1156.5,826.0,1179.0,353.0,1031.90909091,83.4189367486,45404.0,1040.0,0.035849057138,0.0682178735733,0.0323688164353,0.0511724963276,0.00784677078133,2.25158983842,0.0500711,1778.0,2441.0,663.0,2158.36363636,153.773459542,94968.0,2173.5,-3.0517578125e-05,0.00100708007812,0.00103759765625,2.35817649148e-05,0.000150191988307,0.00103759765625,0.0
+12480252.0,423.749999999,242.0,3.31631349637,216.0,297.0,81.0,244.912684366,9.83195312406,415127.0,244.0,286.0,425.0,139.0,342.064896755,16.7185774712,579800.0,342.0,736.0,1134.0,398.0,890.312094395,45.3527758633,1509079.0,888.0,230.0,464.0,234.0,314.293215339,27.4487376541,532727.0,313.0,0.354793548584,0.575809180737,0.221015632153,0.478626104829,0.0283325964405,811.271247685,0.478469,736.0,1186.0,450.0,901.27079646,52.7576342079,1527654.0,900.0,-0.165802001953,3.90179443359,4.06759643555,0.0825264269623,0.307923816241,139.882293701,0.0
+12397246.0,2133.00000002,868.0,5.30175146964,244.0,326.0,82.0,297.401781528,7.32542321213,2537432.0,298.0,327.0,487.0,160.0,451.890881388,13.7276238702,3855533.0,454.0,305.0,682.0,377.0,428.774144398,34.1022011577,3658301.0,424.0,308.0,526.0,218.0,468.29899203,20.7079525892,3995527.0,471.0,-0.212841853499,0.231046929955,0.443888783455,-0.0449936451164,0.0494427949026,-383.885780134,-0.0536692,917.0,1319.0,402.0,1217.59165495,38.077830278,10388492.0,1222.0,-0.238311767578,3.72125244141,3.95956420898,0.246921337215,0.500829535701,2106.73284912,0.0
+12465448.0,60.2500000005,34.0,1.23564995988,343.0,408.0,65.0,370.360995851,13.4370506176,89257.0,369.0,483.0,599.0,116.0,541.746887967,25.4719404782,130561.0,546.0,549.0,822.0,273.0,645.452282158,55.2876934842,155554.0,636.0,552.0,765.0,213.0,626.809128631,44.6780655716,151061.0,628.0,-0.0354302227497,0.0700280144811,0.105458237231,0.014116024376,0.0232079445973,3.40196187462,0.00834725,1397.0,1737.0,340.0,1538.91701245,77.5900585092,370879.0,1551.0,-0.0406494140625,1.31646728516,1.35711669922,0.368549647668,0.169158949035,88.8204650879,0.322266
+12462992.0,18.2499999998,19.0,1.2546345258,276.0,401.0,125.0,352.589041096,34.4482282251,25739.0,363.0,305.0,432.0,127.0,390.589041096,29.5003299802,28513.0,395.0,206.0,423.0,217.0,279.232876712,42.3580693895,20384.0,272.0,175.0,362.0,187.0,252.780821918,39.9634238853,18453.0,247.0,-0.0700854733586,0.164241164923,0.234326638281,0.0503378710741,0.054051723821,3.67466458841,0.0519031,757.0,1111.0,354.0,995.95890411,83.9000446318,72705.0,1014.0,-0.069580078125,0.436737060547,0.506317138672,0.108818158711,0.122376708205,7.94372558594,0.0985718
+12449246.0,747.749999991,400.0,4.1264524829,197.0,364.0,167.0,261.59779338,20.6677004851,782439.0,258.0,273.0,558.0,285.0,375.808759612,35.0456578084,1124044.0,371.0,541.0,1231.0,690.0,941.151454363,86.6371906601,2814984.0,932.0,189.0,699.0,510.0,368.454697426,68.1392059782,1102048.0,357.0,0.207569479942,0.686307072639,0.478737592697,0.438302016635,0.0818011192169,1310.96133175,0.441331,675.0,1602.0,927.0,1005.86125042,117.459866623,3008531.0,986.0,-0.089111328125,1.47473144531,1.56384277344,0.0992622643321,0.187644508758,296.893432617,0.0
+12422461.0,554.499999958,419.0,5.0194752335,244.0,357.0,113.0,283.860234445,9.75485527252,629602.0,284.0,334.0,503.0,169.0,378.416140667,15.5469982108,839327.0,378.0,423.0,634.0,211.0,510.576645627,25.6471115887,1132459.0,507.0,319.0,561.0,242.0,392.370153291,26.9700858243,870277.0,390.0,0.0610878653824,0.199563801289,0.138475935906,0.131418860906,0.0162708718927,291.48703349,0.131281,936.0,1421.0,485.0,1054.6465284,49.5527830096,2339206.0,1054.0,-0.152374267578,2.15194702148,2.30432128906,0.214487060327,0.327220218573,475.732299805,0.00149536
+12410882.0,106.25,136.0,3.72194119334,234.0,415.0,181.0,292.985882353,24.1812720579,124519.0,289.0,326.0,640.0,314.0,418.016470588,37.0644870369,177657.0,412.0,593.0,1196.0,603.0,864.432941176,69.2694370908,367384.0,854.0,353.0,816.0,463.0,472.675294118,51.753105973,200887.0,465.0,0.165021151304,0.420722126961,0.255700975657,0.293729116741,0.0316191115514,124.834874615,0.296233,929.0,1871.0,942.0,1183.67764706,109.086849778,503063.0,1165.0,-0.0273132324219,1.12380981445,1.15112304688,0.141070556641,0.238577725378,59.9549865723,0.000518799
+12437529.0,122.750000003,61.0,1.55315268786,194.0,474.0,280.0,274.676171079,22.8579921002,134866.0,271.0,244.0,742.0,498.0,367.189409369,41.9414630608,180290.0,358.0,582.0,1176.0,594.0,1074.99389002,85.9907751135,527822.0,1110.0,406.0,917.0,511.0,793.894093686,74.2492155783,389802.0,814.0,0.00542299356312,0.319805204868,0.314382211305,0.151011356153,0.0365484668243,74.1465758709,0.154286,850.0,2021.0,1171.0,1435.75967413,106.125522666,704958.0,1449.0,4.16714477539,6.63824462891,2.47109985352,5.39474866444,0.618838347761,2648.82159424,5.43481
+12453555.0,2404.24999997,1585.0,9.11873347454,206.0,305.0,99.0,244.038785484,8.53366211565,2346921.0,244.0,265.0,432.0,167.0,342.885827181,16.4731455751,3297533.0,344.0,770.0,1202.0,432.0,986.900696683,62.2061031453,9491024.0,982.0,173.0,445.0,272.0,281.119787876,24.4668086905,2703529.0,281.0,0.425503343344,0.701754391193,0.27625104785,0.55624874214,0.0347341465306,5349.44415316,0.555386,644.0,1182.0,538.0,868.044400541,47.0079208556,8347983.0,869.0,-0.0508117675781,1.73748779297,1.78829956055,0.381402766864,0.296466073225,3667.95040894,0.348602
+12422261.0,19.5,22.0,1.40540159838,392.0,581.0,189.0,493.307692308,32.6116652451,38478.0,494.0,498.0,681.0,183.0,576.205128205,43.6390671169,44944.0,568.5,214.0,454.0,240.0,300.884615385,55.4635432975,23469.0,288.5,239.0,479.0,240.0,334.564102564,63.1188520222,26096.0,326.0,-0.185074627399,0.0538573525846,0.238931979984,-0.0522607778115,0.0570208722993,-4.0763406693,-0.0510131,1205.0,1691.0,486.0,1404.07692308,117.713338158,109518.0,1373.5,-0.0054931640625,2.67105102539,2.67654418945,0.120589036208,0.519826661933,9.40594482422,0.0
+12370009.0,238.75,141.0,2.57420121239,205.0,284.0,79.0,249.908900524,10.7959210033,238663.0,250.0,251.0,402.0,151.0,350.937172775,22.2385032446,335145.0,355.0,691.0,1218.0,527.0,1015.6104712,72.348495574,969908.0,1016.0,173.0,405.0,232.0,306.969633508,31.5811946061,293156.0,310.0,0.370139956474,0.692044496536,0.321904540062,0.535768296144,0.0385028701103,511.658722818,0.533719,632.0,1081.0,449.0,907.815706806,62.2410914957,866964.0,916.0,-0.032958984375,1.36834716797,1.40130615234,0.271273276444,0.273518816538,259.065979004,0.28714
+12377913.0,716.499999997,463.0,4.87941729986,167.0,343.0,176.0,259.606769016,20.7337811801,744033.0,259.0,238.0,475.0,237.0,365.732030705,35.6719282044,1048188.0,368.0,397.0,1076.0,679.0,817.814724355,92.1382396477,2343857.0,834.0,192.0,579.0,387.0,370.175157013,61.6582098904,1060922.0,369.0,0.208271786571,0.540653824806,0.332382038236,0.378512333426,0.0564306466708,1084.8163476,0.38152,629.0,1365.0,736.0,995.513956734,114.31807578,2853143.0,997.0,-0.162536621094,3.00534057617,3.16787719727,0.220394573757,0.553879701119,631.650848389,0.0
+12358591.0,2.5,7.0,1.24888688131,188.0,223.0,35.0,203.8,10.9068785635,2038.0,201.5,234.0,291.0,57.0,259.3,18.385048273,2593.0,258.0,647.0,829.0,182.0,767.6,53.3651571721,7676.0,774.5,154.0,228.0,74.0,179.3,27.3570831779,1793.0,169.5,0.561959683895,0.678278684616,0.116319000721,0.622270941734,0.0396929725953,6.22270941734,0.640847,576.0,742.0,166.0,642.4,55.9110007065,6424.0,627.0,-0.0015869140625,0.0,0.0015869140625,-0.00015869140625,0.00047607421875,-0.0015869140625,0.0
+12363974.0,690.000000031,639.0,6.86232655415,207.0,327.0,120.0,269.14384058,14.2441940281,742837.0,268.0,249.0,483.0,234.0,375.834057971,25.9107582054,1037302.0,375.0,498.0,1138.0,640.0,826.239492754,71.0402791831,2280421.0,829.0,205.0,557.0,352.0,393.591304348,46.4343037211,1086312.0,390.0,0.198594018817,0.520532727242,0.321938708425,0.355043646445,0.050965270165,979.920464188,0.353596,677.0,1350.0,673.0,1038.5692029,83.8921209923,2866451.0,1032.0,-0.240661621094,1.46530151367,1.70596313477,0.073066501341,0.168381021853,201.663543701,0.0
+12354864.0,604.999999978,492.0,5.64264182208,253.0,408.0,155.0,346.263636364,15.6298057072,837958.0,346.0,360.0,617.0,257.0,530.618595041,27.8925251637,1284097.0,530.0,682.0,1030.0,348.0,883.397107438,47.3336206573,2137821.0,887.0,380.0,759.0,379.0,632.241322314,41.8761903384,1530024.0,632.0,0.0928419530392,0.284369111061,0.191527158022,0.166013302023,0.0205749791391,401.752190895,0.165829,993.0,1774.0,781.0,1509.12355372,83.2658345139,3652079.0,1507.0,-0.0910034179688,0.855926513672,0.946929931641,0.0577546048755,0.108378760643,139.766143799,0.0
+12341192.0,8.00000000047,14.0,1.39629798136,173.0,259.0,86.0,219375.0,26.9950805704,7020.0,225.5,218.0,359.0,141.0,296.34375,39.5202553881,9483.0,313.0,547.0,936.0,389.0,756.3125,103.606357642,24202.0,768.0,160.0,335.0,175.0,253.0,52.9274267275,8096.0,262.5,0.385729044676,0.610451281071,0.224722236395,0.501669283025,0.0574511375848,16.0534170568,0.490948,560.0,951.0,391.0,768.71875,118.341728264,24599.0,801.5,-0.00238037109375,3.88339233398,3.88577270508,2.70080852509,1.69128013227,86.4258728027,3.69482
+12355361.0,12853.9999994,7720.0,19.2084897656,192.0,729.0,537.0,311.110471449,19.9779589738,15996056.0,310.0,239.0,1045.0,806.0,457.406391007,33.6817440945,23518007.0,456.0,454.0,1502.0,1048.0,794.784736269,65.8108036485,40864652.0,797.0,288.0,1753.0,1465.0,632.222498833,56.8981936318,32506352.0,637.0,-0.0771121382713,0.31225296855,0.389365106821,0.114192233439,0.0254528426104,5871.30787451,0.111567,728.0,3527.0,2799.0,1400.73936129,100.433707863,72020415.0,1404.0,-0.371887207031,6.56369018555,6.93557739258,0.336154467065,0.808655306133,17283.7180786,0.0
+12330232.0,5.99999999977,19.0,2.18812961336,479.0,574.0,95.0,527375.0,24.5455571336,12657.0,526.0,515.0,584.0,69.0,551.583333333,20.7904558766,13238.0,555.5,188.0,311.0,123.0,240.083333333,33.4339107627,5762.0,228.0,214.0,345.0,131.0,290.416666667,34.7106091691,6970.0,296.5,-0.188640967011,0.0,0.188640967011,-0.0955486897534,0.0497788805907,-2.29316855408,-0.0861489,1237.0,1451.0,214.0,1369375.0,61.0872412347,32865.0,1390.0,0.514312744141,0.679473876953,0.165161132812,0.603346506755,0.0502782224276,14.4803161621,0.597015
+12354075.0,1525.50000002,607.0,4.38407174844,191.0,290.0,99.0,239.983775811,8.50541495444,1464381.0,240.0,234.0,415.0,181.0,333.640773517,15.6135135455,2035876.0,333.0,710.0,1219.0,509.0,899.47181252,56.1085165221,5488577.0,897.0,154.0,409.0,255.0,279.243854474,21.3570999946,1703946.0,279.0,0.380909889936,0.673091769218,0.292181879282,0.525702661044,0.034595427773,3207.83763769,0.528427,583.0,1110.0,527.0,852.868403802,43.1769307589,5204203.0,852.0,-0.124267578125,2.03311157227,2.15737915039,0.567184073149,0.430485855944,3460.95721436,0.567139
+12297816.0,402.250000003,326.0,4.58526712637,224.0,362.0,138.0,301.144810441,10.4510239942,484542.0,302.0,316.0,514.0,198.0,435.619018024,14.3470146413,700911.0,437.0,576.0,826.0,250.0,702.755748912,38.240001389,1130734.0,697.0,391.0,721.0,330.0,550.341827222,34.7313582177,885500.0,551.0,0.0678733065724,0.228070169687,0.160196863115,0.121855229093,0.0183303333351,196.065063611,0.118644,931.0,1584.0,653.0,1287.10565569,49.3065148262,2070953.0,1288.0,-0.0609741210938,2.53591918945,2.59689331055,0.675196977785,0.467017156386,1086.39193726,0.562927
+12308311.0,6.49999999977,18.0,1.99164025103,185.0,253.0,68.0,223.846153846,16.7186959091,5820.0,226.5,257.0,315.0,58.0,280.576923077,15.7386664398,7295.0,275.0,373.0,614.0,241.0,467.423076923,68.9035965774,12153.0,450.0,214.0,291.0,77.0,239.692307692,20.5328427924,6232.0,232.5,0.203225806355,0.443914085627,0.240688279271,0.317635615858,0.0598095424533,8.2585260123,0.307095,667.0,859.0,192.0,744.115384615,45.6418557257,19347.0,735.5,0.0,0.0,0.0,0.0,0.0,0.0,0.0
+12317409.0,764.000000003,416.0,4.24562585434,185.0,336.0,151.0,244.005890052,14.1728287669,745682.0,246.0,202.0,495.0,293.0,324.090314136,27.3988326729,990420.0,328.0,525.0,1252.0,727.0,950.301701571,99.1097642193,2904122.0,958.0,128.0,550.0,422.0,278.196335079,39.512002778,850168.0,281.0,0.348484843969,0.694552540779,0.34606769681,0.546783645584,0.0522695348788,1670.9708209,0.548285,521.0,1381.0,860.0,846.292539267,78.077623792,2586270.0,855.0,-0.290649414062,2.23391723633,2.52456665039,0.605102559035,0.553376719269,1849.19342041,0.525574
+12295263.0,39.75,36.0,1.61075319796,213.0,298.0,85.0,256.955974843,24.2957008677,40856.0,258.0,275.0,443.0,168.0,345.540880503,46.8159439242,54941.0,343.0,451.0,760.0,309.0,606.874213836,80.3988283449,96493.0,603.0,256.0,571.0,315.0,386.993710692,87.0745720203,61532.0,370.0,0.132567048073,0.354758948088,0.222191900015,0.228320967757,0.0526921185577,36.3030338734,0.225653,760.0,1301.0,541.0,989.490566038,156.495458488,157329.0,971.0,-3.0517578125e-05,0.428985595703,0.429016113281,0.119203771435,0.109516170143,18.9533996582,0.0830994
+12324206.0,663.250000014,625.0,6.84599308297,260.0,501.0,241.0,354.402563136,23.6852878784,940230.0,354.0,388.0,742.0,354.0,566.340746325,40.2755116141,1502502.0,569.0,674.0,1192.0,518.0,1016.20731248,71.5284269405,2695998.0,1027.0,458.0,918.0,460.0,757.97663023,61.151066244,2010912.0,765.0,-0.0577149577439,0.284375011921,0.342089969665,0.145866032475,0.0265099582745,386.982584155,0.144557,1140.0,2117.0,977.0,1678.71993969,113.493500091,4453644.0,1692.0,-0.415008544922,5.36636352539,5.78137207031,0.102455860976,0.271464102773,271.81539917,0.0
+12278448.0,207.499999997,115.0,2.25208022842,279.0,492.0,213.0,372.904819277,26.1403874549,309511.0,370.0,393.0,775.0,382.0,575.419277108,48.0175682153,477598.0,570.0,557.0,1154.0,597.0,821.912048193,94.1983333155,682187.0,816.0,454.0,1037.0,583.0,737.544578313,80.5091018622,612162.0,733.0,-0.0467432960868,0.212121218443,0.25886451453,0.053765954362,0.0307034193513,44.6257421205,0.0548615,1146.0,2285.0,1139.0,1685.8686747,146.655742643,1399271.0,1673.0,0.0737915039062,5.26947021484,5.19567871094,3.92007402167,1.23710092213,3253.66143799,4.47429
+12228314.0,445.5,275.0,3.6753940475,220.0,326.0,106.0,257.128507295,10.4907519486,458203.0,256.0,299.0,484.0,185.0,349.580808081,18.1572484102,622953.0,348.0,685.0,1041.0,356.0,808.164421998,48.1444750083,1440149.0,807.0,256.0,570.0,314.0,338.960718294,32.2500511165,604028.0,337.5,0.248908296227,0.54121863842,0.292310342193,0.409213693714,0.0429200910403,729.218802199,0.410845,801.0,1380.0,579.0,945.67003367,58.1380472355,1685184.0,942.0,-0.254730224609,1.23303222656,1.48776245117,0.0745264774755,0.194624358073,132.806182861,0.0
+12238927.0,42.0,50.0,2.17640856888,191.0,273.0,82.0,226.988095238,16.9526610129,38134.0,229.0,209.0,380.0,171.0,267.279761905,30.7648387726,44903.0,267.0,471.0,698.0,227.0,562.678571429,44.2432832444,94530.0,556.0,206.0,393.0,187.0,281.636904762,36.0531065954,47315.0,280.0,0.224256291986,0.445623338223,0.221367046237,0.334286847994,0.0477170792618,56.1601904631,0.325078,666.0,1010.0,344.0,775.904761905,66.6707651801,130352.0,762.5,-0.00473022460938,1.10595703125,1.11068725586,0.594605218797,0.448431581858,99.8936767578,0.699188
+12216439.0,136.749999999,169.0,4.07678778525,206.0,335.0,129.0,277.296160878,18.5331375699,151681.0,279.0,258.0,475.0,217.0,389.811700183,31.3204702358,213227.0,394.0,468.0,1055.0,587.0,836.742230347,92.8209600778,457698.0,856.0,213.0,575.0,362.0,419.956124314,51.766932105,229716.0,421.0,0.189720332623,0.44777327776,0.258052945137,0.331465899863,0.0472054550284,181.311847225,0.337991,684.0,1352.0,668.0,1087.06398537,93.7089972298,594624.0,1093.0,-0.0242614746094,4.91528320312,4.93954467773,0.375903532318,0.900830323869,205.619232178,0.0
+12188293.0,746.000000003,454.0,4.68901375917,226.0,384.0,158.0,299.616957105,21.8444812539,894057.0,299.0,290.0,600.0,310.0,441.61963807,40.8121279598,1317793.0,442.0,604.0,1197.0,593.0,916.154825737,70.6973036032,2733806.0,917.0,267.0,747.0,480.0,497.995978552,73.1223586901,1486020.0,495.0,0.161609902978,0.490122288466,0.328512385488,0.298512902056,0.0494889347707,890.762499735,0.301753,783.0,1731.0,948.0,1239.23257373,134.072189792,3697870.0,1238.0,-0.0640869140625,3.16146850586,3.22555541992,0.346329625107,0.294093190034,1033.44760132,0.344559
+12102627.0,8.5,18.0,1.74163887595,769.0,1364.0,595.0,994.264705882,137.839486536,33805.0,971.0,661.0,1757.0,1096.0,1362.47058824,223.974162808,46324.0,1393.0,934.0,1866.0,932.0,1454.58823529,187.721652148,49456.0,1446.5,802.0,2123.0,1321.0,1452.88235294,253.333396315,49398.0,1423.0,-0.12171253562,0.0918665900826,0.213579125702,0.00399704687366,0.0500277648284,0.135899593704,0.00769849,2317.0,5112.0,2795.0,3809.61764706,519.615695927,129527.0,3798.5,2.83044433594,3.00537109375,0.174926757812,2.92974225213,0.0325890734833,99.6112365723,2.9326
+12097410.0,45.0000000007,43.0,1.8082449741,189.0,264.0,75.0,231.85,13.9882788235,41733.0,233.0,245.0,388.0,143.0,325.927777778,25.9433208179,58667.0,328.5,718.0,1269.0,551.0,1062.79444444,111.636000626,191303.0,1061.5,163.0,358.0,195.0,269.283333333,35.6154265889,48471.0,272.0,0.502581775188,0.691143095493,0.188561320305,0.595723199513,0.0346019023225,107.230175912,0.596993,597.0,1006.0,409.0,827.061111111,74.5467909652,148871.0,832.0,-0.0566101074219,0.294006347656,0.350616455078,0.00886484781901,0.0414823809729,1.59567260742,0.0
+12081821.0,11.7499999998,15.0,1.23443263212,263.0,285.0,22.0,276.063829787,4.81312149485,12975.0,276.0,363.0,398.0,35.0,381.85106383,7.98929795708,17947.0,381.0,300.0,424.0,124.0,370.723404255,31.1371039031,17424.0,368.0,320.0,373.0,53.0,350.489361702,12.5238025978,16473.0,352.0,-0.104477614164,0.114799447358,0.219277061522,0.0265275475846,0.0537809336737,1.24679473648,0.02526,951.0,1056.0,105.0,1008.40425532,24.4520021148,47395.0,1010.0,-0.065673828125,0.693572998047,0.759246826172,0.037654146235,0.142239675769,1.76974487305,0.0
+12078479.0,456.749999988,348.0,4.59340812148,182.0,546.0,364.0,316.489326765,32.7012194684,578226.0,317.0,218.0,862.0,644.0,459.596606459,60.8500525823,839683.0,461.0,334.0,1269.0,935.0,706.431308155,95.8718074527,1290650.0,711.0,190.0,1264.0,1074.0,581.893267652,100.496676217,1063119.0,586.0,-0.016344724223,0.327342748642,0.343687472865,0.0995663112113,0.0555785350545,181.907650583,0.101871,590.0,2672.0,2082.0,1357.97920088,189.202389456,2481028.0,1362.0,-2.27752685547,3.38400268555,5.66152954102,0.651361274406,0.765494955119,1190.03704834,0.513245
+12163423.0,4279.00000001,2582.0,11.1347421053,246.0,301.0,55.0,276.691984108,4.89810965189,4735860.0,277.0,354.0,437.0,83.0,406.136013087,9.19333309021,6951424.0,407.0,255.0,481.0,226.0,321.60639168,13.5669022079,5504615.0,321.0,325.0,455.0,130.0,409.420542183,15.2434381221,7007642.0,410.0,-0.221910119057,0.0944254845381,0.316335603595,-0.120135188397,0.0253446639697,-2056.23388461,-0.120666,932.0,1174.0,242.0,1092.24853938,27.6305043704,18694926.0,1093.0,-0.160186767578,1.53720092773,1.69738769531,0.176444076606,0.245672300171,3020.01681519,0.0882568
+12015535.0,291.000000004,172.0,2.84431060393,294.0,506.0,212.0,394.363402062,32.0207364209,459039.0,398.5,389.0,870.0,481.0,601.846219931,57.6200634546,700549.0,605.0,456.0,1100.0,644.0,766.569587629,76.0004824738,892287.0,755.5,343.0,1098.0,755.0,716.414948454,76.7369126483,833907.0,714.0,-0.0731707289815,0.160826593637,0.233997322619,0.0342574754047,0.030368833965,39.875701371,0.0298201,1030.0,2389.0,1359.0,1712.62457045,156.322654414,1993495.0,1719.5,-0.0406494140625,8.01113891602,8.05178833008,2.16781015822,1.52472169852,2523.33102417,1.78583
+12020804.0,501.750000006,231.0,2.90913152957,215.0,368.0,153.0,269.157448929,14.5912288452,540199.0,269.0,284.0,545.0,261.0,381.073741903,26.3071911088,764815.0,380.0,688.0,1201.0,513.0,913.624813154,51.3760255969,1833645.0,914.0,224.0,601.0,377.0,363.603886398,40.1000373983,729753.0,362.0,0.278944224119,0.591985404491,0.313041180372,0.431553626141,0.0411700467794,866.128127664,0.432473,729.0,1505.0,776.0,1013.83507723,77.8519234082,2034767.0,1011.0,-0.164886474609,3.04046630859,3.2053527832,0.0813107188804,0.245240111305,163.190612793,0.0
+12008554.0,20.0000000009,38.0,2.39697589586,337.0,475.0,138.0,379.6375,28.1887582868,30371.0,372.0,392.0,637.0,245.0,455.2375,45.9976205227,36419.0,446.5,186.0,683.0,497.0,313625.0,101.699972345,25090.0,274.0,225.0,667.0,442.0,317.7625,81.1289473231,25421.0,290.5,-0.196998119354,0.146456688643,0.343454807997,-0.0146519981732,0.0746733921863,-1.17215985386,-0.00173073,956.0,1779.0,823.0,1152.6375,149.324080756,92211.0,1117.5,0.448394775391,1.25875854492,0.810363769531,0.689532089233,0.211374398649,55.1625671387,0.626999
+12017608.0,2444.0,1620.0,9.243990314,204.0,591.0,387.0,349.105871522,17.698163235,3412859.0,348.0,279.0,894.0,615.0,531.81945581,30.5637168485,5199067.0,532.0,587.0,1075.0,488.0,936.02547054,46.2674621543,9150585.0,940.0,332.0,1085.0,753.0,745.276288871,40.549118978,7285821.0,749.0,-0.0119729312137,0.286788403988,0.298761335202,0.113575076722,0.0147268856088,1110.30995004,0.112287,815.0,2516.0,1701.0,1626.2016162,83.6172498815,15897747.0,1628.0,-0.160186767578,3.84140014648,4.00158691406,0.0909202875365,0.269694588496,888.836730957,0.0
+12004283.0,292.249999994,97.0,1.60062480293,195.0,286.0,91.0,241.680068435,13.9549668484,282524.0,243.0,248.0,407.0,159.0,337.99572284,26.2376286154,395117.0,341.0,620.0,1273.0,653.0,1057.81351583,91.2147999602,1236584.0,1061.0,168.0,422.0,254.0,284.582549187,36.5278323406,332677.0,289.0,0.352472096682,0.704489767551,0.35201767087,0.57597153535,0.0440579783417,673.310724825,0.575017,611.0,1104.0,493.0,864.258340462,74.1808299742,1010318.0,876.0,-0.026611328125,1.48324584961,1.50985717773,0.373572174151,0.346206348459,436.705871582,0.333954
+11996168.0,72.7499999993,38.0,1.2567884064,342.0,503.0,161.0,405.659793814,24.229240208,118047.0,400.0,493.0,789.0,296.0,635.103092784,44.2416399471,184815.0,633.0,616.0,1048.0,432.0,853.034364261,42.297086101,248233.0,847.0,539.0,1033.0,494.0,810.756013746,49.074446461,235930.0,809.0,-0.00517063075677,0.0666666701436,0.0718373009004,0.0257125703315,0.00934405066407,7.48235796648,0.0258303,1374.0,2308.0,934.0,1851.51890034,113.631293879,538792.0,1841.0,0.000732421875,4.66925048828,4.66851806641,3.81625806671,0.474446048785,1110.53109741,3.59979
+11979193.0,355.999999999,301.0,4.50024921269,248.0,352.0,104.0,300.701544944,9.38772195241,428199.0,301.0,344.0,475.0,131.0,430.916432584,13.6895005972,613625.0,432.0,522.0,822.0,300.0,681.481741573,34.3119316768,970430.0,677.0,370.0,619.0,249.0,517.584269663,26.1906885799,737040.0,517.0,0.0648918449879,0.230268508196,0.165376663208,0.136668925425,0.017015734379,194.616549805,0.135044,962.0,1428.0,466.0,1249.20224719,43.0978908672,1778864.0,1251.0,-0.026611328125,2.31033325195,2.33694458008,0.619403539079,0.41866131713,882.030639648,0.489441
+11986586.0,2.5,9.0,1.60571170454,189.0,217.0,28.0,200.9,9.26768579528,2009.0,199.5,240.0,298.0,58.0,263.8,16.296011782,2638.0,261.5,450.0,519.0,69.0,491.2,23.0555850067,4912.0,496.0,186.0,254.0,68.0,213.3,22.8431609021,2133.0,212.0,0.342820167542,0.438700139523,0.095879971981,0.39591383636,0.0313622407136,3.9591383636,0.394195,615.0,769.0,154.0,678.0,47.6675990585,6780.0,676.0,0.00555419921875,2.04574584961,2.04019165039,1.58585510254,0.580350296,15.8585510254,1.8513
+12040018.0,1989.50000003,1566.0,9.90409628897,246.0,447.0,201.0,318.239381754,13.9466769756,2532549.0,317.0,336.0,652.0,316.0,471.194395577,23.9736500603,3749765.0,470.0,592.0,1047.0,455.0,836.476250314,48.5934623222,6656678.0,837.0,449.0,927.0,478.0,692.961422468,45.1350534852,5514587.0,693.0,0.0236794166267,0.236734688282,0.213055271655,0.0940350136987,0.0164105049256,748.330639014,0.0928382,1031.0,2026.0,995.0,1482.3951998,74.646732811,11796901.0,1481.0,-1.00784301758,3.67999267578,4.68783569336,0.420004350691,0.310560887178,3342.3946228,0.403061
+11911097.0,15.5000000019,32.0,2.29286876027,200.0,254.0,54.0,223.0,13.0062019945,13826.0,222.5,219.0,327.0,108.0,260.096774194,26.4786643737,16126.0,256.5,434.0,795.0,361.0,549.838709677,72.0002673715,34090.0,527.0,163.0,319.0,156.0,214.677419355,38.7209929698,13310.0,208.0,0.326259940863,0.546061396599,0.219801455736,0.439694261359,0.0512532064912,27.2610442042,0.437644,600.0,900.0,300.0,697.774193548,73.0034067598,43262.0,680.5,0.109283447266,0.884368896484,0.775085449219,0.409005441973,0.235632687317,25.3583374023,0.364151
+11906741.0,26.5000000002,24.0,1.31517447885,318.0,491.0,173.0,446.641509434,37.1278232341,47344.0,455.0,423.0,738.0,315.0,661.047169811,64.3911077412,70071.0,676.0,507.0,936.0,429.0,783.886792453,76.5419259578,83092.0,787.0,417.0,846.0,429.0,753.990566038,78.6786508507,79923.0,779.5,-0.0275464449078,0.169836953282,0.19738339819,0.0199991908327,0.0434101189593,2.11991422827,0.00318091,1158.0,2047.0,889.0,1861.67924528,175.65470777,197338.0,1912.0,-0.0430908203125,3.69900512695,3.74209594727,2.76209158268,0.795334711242,292.781707764,3.0143
+11906579.0,58.0,58.0,2.1483699285,150.0,405.0,255.0,265.49137931,40.7397111381,61594.0,264.5,206.0,551.0,345.0,340.422413793,55.6072512733,78978.0,330.5,353.0,769.0,416.0,478.823275862,77.0563988009,111087.0,464.5,97.0,493.0,396.0,294.021551724,61.2114372709,68213.0,294.0,0.0799999982119,0.713864326477,0.633864328265,0.241504617742,0.0925272102311,56.0290713161,0.222151,498.0,1414.0,916.0,899.935344828,129.616443956,208785.0,884.5,-0.0758056640625,4.23147583008,4.30728149414,0.311174195388,0.874705421492,72.1924133301,0.0
+11901191.0,32.75,32.0,1.57739112919,257.0,292.0,35.0,267.06870229,5.7693462655,34986.0,267.0,346.0,407.0,61.0,361.854961832,8.33654892023,47403.0,361.0,308.0,405.0,97.0,366.183206107,21.8079058172,47970.0,371.0,307.0,379.0,72.0,329.358778626,13.0466390058,43146.0,329.0,-0.0614692643285,0.124824687839,0.186293952167,0.0523551655285,0.0394455341699,6.85852668423,0.0638889,918.0,1078.0,160.0,958.282442748,25.08741201,125535.0,958.0,-0.0437927246094,1.06295776367,1.10675048828,0.185167152463,0.226719831606,24.2568969727,0.0779114
+11918268.0,2860.24999995,1389.0,7.32647912604,193.0,340.0,147.0,259.567345512,13.4834415321,2969710.0,259.0,232.0,526.0,294.0,363.976750284,26.7089899441,4164258.0,366.0,503.0,1326.0,823.0,1001.59854908,72.3217163517,11459289.0,1006.0,135.0,571.0,436.0,316.406782624,38.8619829914,3620010.0,315.0,0.277108430862,0.705882370472,0.42877393961,0.520128147019,0.0463668618924,5950.78613004,0.521036,572.0,1437.0,865.0,939.95087842,76.3242387676,10753978.0,940.0,-0.268798828125,2.63229370117,2.9010925293,0.31383928983,0.455255017724,3590.63531494,0.0680542
+11862117.0,99.0000000014,56.0,1.58768922602,275.0,394.0,119.0,360.313131313,18.9764055865,142684.0,365.0,391.0,614.0,223.0,554.737373737,40.6369951015,219676.0,563.0,571.0,874.0,303.0,755.297979798,65.6032388333,299098.0,768.0,517.0,844.0,327.0,726.820707071,63.161534736,287821.0,746.0,-0.0257425736636,0.0952716991305,0.121014272794,0.0192171711214,0.0198570361739,7.60999976407,0.0208423,1224.0,1851.0,627.0,1641.87121212,114.965194907,650181.0,1671.5,-0.0015869140625,4.04498291016,4.04656982422,1.49839374273,1.35939774717,593.363922119,2.44952
+12371124.0,11702.250001,6133.0,15.9931255551,172.0,771.0,599.0,295.536456664,11.8898736945,13833766.0,296.0,244.0,1209.0,965.0,415.43440364,19.6576006075,19446069.0,416.0,363.0,1715.0,1352.0,600.845029802,35.9532608846,28124955.0,602.0,239.0,1989.0,1750.0,531.599030101,34.1777768403,24883619.0,533.0,-0.0739740803838,0.20772947371,0.281703554094,0.0612252464266,0.0136471185335,2865.89255998,0.0603589,680.0,3955.0,3275.0,1242.56989041,60.3529882376,58163454.0,1245.0,-0.345733642578,3.31033325195,3.65606689453,0.200056465962,0.375937381079,9364.44311523,0.0249634
+11871398.0,1370.00000002,907.0,6.91261025778,204.0,330.0,126.0,253.081021898,9.70228382209,1386884.0,253.0,277.0,483.0,206.0,362.191058394,17.9879469066,1984807.0,361.0,744.0,1303.0,559.0,989.174452555,69.1758380766,5420676.0,988.0,185.0,539.0,354.0,319.809489051,30.8122496335,1752556.0,316.0,0.277177840471,0.673433363438,0.396255522966,0.510827782021,0.0435629293696,2799.33624548,0.514744,666.0,1352.0,686.0,935.081569343,55.0600941416,5124247.0,932.0,-0.355499267578,2.24826049805,2.60375976562,0.332577681715,0.434205581366,1822.5256958,0.176743
+11848667.0,711.500000039,256.0,2.70736980571,209.0,312.0,103.0,261.613492621,13.8087891222,744552.0,262.0,273.0,463.0,190.0,365.216092762,24.5541558939,1039405.0,366.0,707.0,1198.0,491.0,1024.45783556,60.8504683147,2915607.0,1029.0,176.0,493.0,317.0,323.944834856,41.2064644474,921947.0,323.0,0.367904692888,0.679417133331,0.311512440443,0.520414027482,0.0452599456326,1481.09832221,0.522455,671.0,1268.0,597.0,950.774420239,76.7669103879,2705904.0,951.0,-0.195343017578,1.09457397461,1.28991699219,0.0563893321527,0.111046644886,160.484039307,0.0
+11795779.0,3007.00000005,1365.0,7.02200291333,218.0,520.0,302.0,296.120884603,8.97390368079,3561742.0,296.0,269.0,776.0,507.0,394.540073163,16.3609408703,4745528.0,394.0,324.0,997.0,673.0,496.293398736,34.1354229955,5969417.0,493.0,205.0,1101.0,896.0,443.761722647,30.9197001886,5337566.0,444.0,-0.049571018666,0.224952742457,0.274523761123,0.0558766980241,0.0143733877074,672.084923833,0.0536278,692.0,2397.0,1705.0,1134.42268041,53.1824037213,13644836.0,1133.0,-3.2024230957,3.97760009766,7.18002319336,0.356613770648,0.730438406787,4289.35043335,0.0814209
+11788781.0,195.250000001,177.0,3.57332742931,271.0,306.0,35.0,287.956466069,5.56747917707,224894.0,288.0,344.0,401.0,57.0,373.991037132,10.4762970838,292087.0,373.0,408.0,516.0,108.0,456.043533931,18.7019386537,356170.0,455.0,358.0,456.0,98.0,405.355953905,18.0523865939,316583.0,405.0,0.0293159615248,0.0931076183915,0.0637916568667,0.0589123012214,0.0103580641356,46.0105072539,0.0580046,976.0,1156.0,180.0,1067.30345711,32.3578162474,833564.0,1066.0,-0.555541992188,1.15795898438,1.71350097656,0.0581189105514,0.278484309256,45.3908691406,0.054657
+11765112.0,311.750000007,139.0,2.22078562264,244.0,351.0,107.0,275.769847634,10.397201611,343885.0,275.0,321.0,507.0,186.0,376.760224539,18.287188322,469820.0,374.0,473.0,793.0,320.0,623.433039294,33.207231978,777421.0,619.0,361.0,691.0,330.0,492.72574178,28.5360842162,614429.0,493.0,0.0191625263542,0.195615515113,0.176452988759,0.11718974914,0.0196817260059,146.135617178,0.115848,943.0,1549.0,606.0,1145.25581395,53.6007501185,1428134.0,1142.0,-0.0625305175781,4.7529296875,4.81546020508,3.37897719664,1.42061150177,4213.58456421,4.01007
+11759108.0,41.7499999991,36.0,1.57169882631,446.0,764.0,318.0,643.532934132,63.7265663805,107470.0,652.0,645.0,1174.0,529.0,979.119760479,106.812376909,163513.0,994.0,742.0,1299.0,557.0,1134.89221557,89.0101945275,189527.0,1145.0,627.0,1397.0,770.0,1122.20958084,104.498908818,187409.0,1130.0,-0.0398213602602,0.0840029194951,0.123824279755,0.00635558066727,0.0137137283578,1.06138197143,0.00695048,1802.0,3179.0,1377.0,2744.86227545,243.389609454,458392.0,2774.0,3.2707824707,4.19229125977,0.921508789062,3.80503598516,0.219047486955,635.441009521,3.78162
+11732522.0,5344.00000001,2798.0,10.7971604054,208.0,379.0,171.0,291.308897829,19.0086517929,6227019.0,291.0,304.0,590.0,286.0,440.532045284,33.6751457334,9416813.0,440.0,608.0,1195.0,587.0,949.935909431,61.3702055047,20305830.0,952.0,282.0,738.0,456.0,494.861526946,56.578858264,10578160.0,493.0,0.121887288988,0.490792632103,0.368905343115,0.316360633271,0.0418776716617,6762.52489679,0.315126,794.0,1696.0,902.0,1226.70247006,106.307523551,26221992.0,1225.0,-0.367218017578,2.77215576172,3.1393737793,0.0593106746674,0.231270757087,1267.82498169,0.0
+11715164.0,4.5,17.0,2.26067292227,202.0,236.0,34.0,218.166666667,10.0678255404,3927.0,217.0,240.0,313.0,73.0,274.388888889,22.4997256499,4939.0,274.5,549.0,864.0,315.0,693.777777778,88.9997225686,12488.0,707.0,163.0,250.0,87.0,204.611111111,27.4694555398,3683.0,198.5,0.492638736963,0.601307213306,0.108668476343,0.543853627311,0.0335338024322,9.7893652916,0.538509,606.0,794.0,188.0,697.166666667,58.9823419904,12549.0,687.5,0.0,0.0723571777344,0.0723571777344,0.014172024197,0.0256446357958,0.255096435547,0.0
+11735025.0,1146.00000001,574.0,4.78315716955,265.0,355.0,90.0,290.673647469,4.20949481011,1332448.0,291.0,382.0,559.0,177.0,438.572643979,8.01522615102,2010417.0,439.0,283.0,429.0,146.0,336.819808028,10.5943484208,1543982.0,335.0,357.0,644.0,287.0,449.984075044,13.3548678424,2062727.0,451.0,-0.218232050538,0.0124481329694,0.230680183508,-0.143794310257,0.0197330820943,-659.15311822,-0.146154,1005.0,1558.0,553.0,1179.23036649,23.9321445362,5405592.0,1180.0,-0.117279052734,1.2643737793,1.38165283203,0.126235808794,0.193833584156,578.66494751,0.0853271
+11683699.0,30.7500000009,55.0,2.7979193862,210.0,342.0,132.0,255.617886179,18.1884982531,31441.0,255.0,285.0,502.0,217.0,348.390243902,28.9554280816,42852.0,347.0,538.0,954.0,416.0,761.276422764,79.503776135,93637.0,766.0,226.0,467.0,241.0,331.097560976,44.9979971793,40725.0,327.0,0.248106062412,0.523091435432,0.27498537302,0.393736443384,0.058674593773,48.4295825362,0.4,722.0,1311.0,589.0,935.105691057,86.2880233621,115018.0,932.0,0.0,4.71481323242,4.71481323242,2.88030608883,1.29538299203,354.277648926,3.4187
+11667865.0,20.5000000009,39.0,2.42986835151,207.0,272.0,65.0,229.341463415,13.0741035342,18806.0,227.0,257.0,395.0,138.0,300.182926829,26.9991544803,24615.0,294.5,472.0,851.0,379.0,574.804878049,66.2685664779,47134.0,560.0,211.0,423.0,212.0,272.963414634,39.4240378332,22383.0,263.5,0.271005928516,0.436686396599,0.165680468082,0.356762970003,0.0391909197401,29.2545635402,0.354727,675.0,1089.0,414.0,802.487804878,77.4422277041,65804.0,781.5,-0.0421752929688,0.883056640625,0.925231933594,0.181993810142,0.237215028528,14.9234924316,0.108658
+11782445.0,4805.00000001,2339.0,9.51872091774,246.0,340.0,94.0,272.409677419,8.41274057333,5235714.0,272.0,333.0,510.0,177.0,374.562539022,15.3041482139,7199092.0,373.0,273.0,682.0,409.0,370.370811655,34.8313076256,7118527.0,363.0,276.0,523.0,247.0,346.249687825,19.6974445277,6654919.0,345.0,-0.160796329379,0.292307704687,0.453104034066,0.0323580167466,0.0442392758666,621.92108187,0.0244604,860.0,1363.0,503.0,993.221904266,42.0041823015,19089725.0,989.0,-0.203948974609,1.24829101562,1.45223999023,0.0965127744486,0.185980856541,1854.9755249,0.0
+11653810.0,1600.75000012,1051.0,7.41030406706,235.0,402.0,167.0,288.50242074,9.46163424797,1847281.0,288.0,295.0,557.0,262.0,374.2200531,15.0246345954,2396131.0,375.0,351.0,651.0,300.0,445.600655943,23.9486079638,2853181.0,447.0,277.0,695.0,418.0,402.886771826,24.5784795496,2579684.0,403.0,-0.032689448446,0.127629727125,0.160319175571,0.0505310624321,0.0152098536075,323.550392753,0.049711,809.0,1654.0,845.0,1065.60924567,46.4361177344,6823096.0,1066.0,-0.285064697266,1.35983276367,1.64489746094,0.0673044429018,0.165108977753,430.9503479,0.0
+11636605.0,1980.25000002,1246.0,7.89865416963,255.0,488.0,233.0,371.254008332,24.7142562546,2940703.0,374.0,369.0,727.0,358.0,557.736144426,42.164361999,4417828.0,563.0,699.0,1218.0,519.0,958.275344022,63.7709321378,7590499.0,962.0,413.0,895.0,482.0,707.878298195,67.1643540742,5607104.0,714.0,0.0283073373139,0.315543681383,0.287236344069,0.15132364115,0.0320809518433,1198.63456155,0.145676,1038.0,2008.0,970.0,1636.86845095,129.459525849,12965635.0,1652.0,-0.515258789062,1.79510498047,2.31036376953,0.208833131717,0.302095153217,1654.16723633,0.170044
+11575761.0,338.999999993,371.0,5.6841970973,262.0,346.0,84.0,289.850294985,10.2945774985,393037.0,290.0,347.0,513.0,166.0,415.955014749,18.9469110795,564035.0,416.0,313.0,807.0,494.0,489.025073746,70.6998367956,663118.0,479.0,312.0,515.0,203.0,388.286135693,26.126126168,526516.0,389.0,-0.143638849258,0.333333343267,0.476972192526,0.110201631037,0.0809898397842,149.433411686,0.108832,927.0,1363.0,436.0,1094.09144543,53.3587973464,1483588.0,1094.0,-0.061767578125,1.01797485352,1.07974243164,0.0902996682136,0.158977600387,122.446350098,0.0
+11582183.0,1841.49999944,1611.0,10.5902142621,210.0,816.0,606.0,299.309122998,15.6490977713,2204711.0,300.0,264.0,1255.0,991.0,423.41053489,25.7268873323,3118842.0,425.0,397.0,1908.0,1511.0,627.272875373,37.2530433267,4620492.0,629.0,243.0,1916.0,1673.0,527.293782243,41.06134404,3884046.0,530.0,-0.0580204762518,0.279907077551,0.337927553803,0.0871455789423,0.0183769238704,641.914334489,0.0852321,762.0,3987.0,3225.0,1250.01344013,77.5955470413,9207599.0,1256.0,-0.219573974609,9.33502197266,9.55459594727,0.269321417828,0.721007789095,1983.82156372,0.0831909
+11480146.0,798.999999997,462.0,4.61066590592,257.0,318.0,61.0,299.404255319,5.83024627519,956896.0,300.0,377.0,479.0,102.0,442.408010013,10.0228455396,1413936.0,443.0,304.0,584.0,280.0,398.198998748,32.924779808,1272644.0,390.0,335.0,489.0,154.0,431.500625782,16.7893989471,1379076.0,432.0,-0.207301169634,0.153301879764,0.360603049397,-0.0412923366703,0.0510426835588,-131.970307998,-0.0504305,978.0,1271.0,293.0,1173.31289111,30.0071284235,3749908.0,1175.0,-0.156280517578,1.20431518555,1.36059570312,0.120604160581,0.227982499234,385.450897217,0.0
+11500851.0,106.000000006,96.0,2.63034895763,176.0,382.0,206.0,260.952830189,27.1596023797,110644.0,261.0,208.0,565.0,357.0,352.474056604,51.677148033,149449.0,350.5,428.0,1070.0,642.0,791.893867925,138.232663999,335763.0,814.5,100.0,526.0,426.0,322.523584906,64.1760506847,136750.0,321.0,0.203180208802,0.681528687477,0.478348478675,0.419991823651,0.0772842583627,178.076533228,0.425545,632.0,1285.0,653.0,935.950471698,124.420031527,396843.0,932.5,0.463256835938,4.48599243164,4.0227355957,3.32030602221,0.579330002597,1407.80975342,3.34335
+11480798.0,1400.75,302.0,2.27625910185,288.0,948.0,660.0,418.583437444,32.9995693377,2345323.0,421.0,393.0,1565.0,1172.0,640.968052829,58.1899124231,3591344.0,639.0,503.0,2384.0,1881.0,741.378368731,90.1069444703,4153943.0,761.0,436.0,2629.0,2193.0,750.830447974,86.5015043168,4206903.0,755.0,-0.118346899748,0.131953433156,0.250300332904,-0.00680194195706,0.021691221622,-38.1112807854,-0.00832178,1226.0,5142.0,3916.0,1810.38193825,168.851283036,10143570.0,1827.0,-0.0117492675781,9.85800170898,9.86975097656,8.1815487727,0.92790548087,45841.2177734,8.22479
+11490183.0,119.249999997,131.0,3.38405310586,178.0,346.0,168.0,255.635220126,32.8833312869,121938.0,252.0,238.0,537.0,299.0,354.018867925,57.6368816487,168867.0,355.0,373.0,974.0,601.0,640.664570231,162.622276725,305597.0,628.0,221.0,629.0,408.0,368.251572327,93.5652981252,175656.0,364.0,0.0361445769668,0.458797335625,0.422652758658,0.268307178572,0.0690169631761,127.982524179,0.27414,683.0,1512.0,829.0,977.905660377,180.156784471,466461.0,969.0,-0.0140991210938,1.92846679688,1.94256591797,0.683736037408,0.432946034921,326.142089844,0.70163
+11469821.0,7.25,18.0,1.88581275923,261.0,329.0,68.0,294.344827586,21.0570257946,8536.0,294.0,306.0,404.0,98.0,361.724137931,29.8304363797,10490.0,370.0,80.0,218.0,138.0,173.75862069,40.0229720005,5039.0,189.0,227.0,300.0,73.0,264.655172414,19.8690121964,7675.0,269.0,-0.551820755005,-0.0782241001725,0.473596654832,-0.216300641668,0.138035281654,-6.27271860838,-0.17094,800.0,1030.0,230.0,920.724137931,68.7293023649,26701.0,937.0,3.59292602539,3.77136230469,0.178436279297,3.68085663894,0.0566790526957,106.744842529,3.6676
+11469923.0,154.750000001,188.0,4.26321846634,219.0,372.0,153.0,328.552504039,17.6833137679,203374.0,330.0,304.0,557.0,253.0,490.252019386,28.6032603454,303466.0,491.0,628.0,1006.0,378.0,882.444264943,44.2960160624,546233.0,883.0,389.0,824.0,435.0,704.802907916,44.8390039572,436273.0,711.0,0.0630508437753,0.235004916787,0.171954073012,0.112334672356,0.0194171965226,69.5351621881,0.108564,912.0,1703.0,791.0,1523.60743134,83.7876538055,943113.0,1528.0,-0.00762939453125,1.19580078125,1.20343017578,0.158395893547,0.18531184215,98.0470581055,0.0862732
+11457687.0,193.75000001,170.0,3.44526897873,254.0,360.0,106.0,291.932903226,11.1066682073,226248.0,292.0,340.0,512.0,172.0,391.263225806,17.0114307655,303229.0,390.0,411.0,621.0,210.0,476.201290323,26.1300123751,369056.0,472.0,351.0,625.0,274.0,429.939354839,27.4483009563,333203.0,427.0,-0.00563153671101,0.108265422285,0.113896958996,0.0512829292112,0.017216433023,39.7442701387,0.049505,954.0,1497.0,543.0,1113.13548387,51.9612855163,862680.0,1109.0,-0.0588989257812,0.519226074219,0.578125,0.0152481965096,0.0447922945883,11.8173522949,0.0
+11511763.0,4629.49999889,2347.0,9.7306334567,209.0,1119.0,910.0,303.200021601,15.045075952,5614658.0,304.0,271.0,1816.0,1545.0,428.930122043,24.5523872599,7942928.0,429.0,414.0,2250.0,1836.0,631.988119667,44.8042323291,11703156.0,628.0,289.0,2663.0,2374.0,554.478993412,43.4765631307,10267842.0,551.0,-0.0840626880527,0.223118275404,0.307180963457,0.0653603650212,0.0137163176271,1210.34323946,0.0647011,802.0,5598.0,4796.0,1286.60913706,76.4847677396,23825428.0,1283.0,-0.305511474609,2.47729492188,2.78280639648,0.178389444917,0.250301240639,3303.41574097,0.0465546
+11413531.0,90.2500000002,69.0,2.04889901393,199.0,263.0,64.0,241.313019391,8.68941292479,87114.0,241.0,263.0,387.0,124.0,351.487534626,17.6486322797,126887.0,354.0,941.0,1325.0,384.0,1201.07756233,54.5428705883,433589.0,1206.0,167.0,328.0,161.0,277.648199446,22.1782205392,100231.0,279.0,0.570576548576,0.69855594635,0.127979397774,0.62485152549,0.0179666522771,225.571400702,0.624196,629.0,969.0,340.0,870.448753463,47.268822247,314232.0,873.0,-0.00863647460938,1.47985839844,1.48849487305,0.422271052226,0.327769236369,152.439849854,0.358368
+11332343.0,7152.49999937,4243.0,14.1526956225,180.0,1086.0,906.0,298.005627403,15.0308108287,8525941.0,298.0,224.0,1874.0,1650.0,413.060188745,25.9247009773,11817652.0,412.0,381.0,2974.0,2593.0,602.76186648,42.6644789361,17245017.0,601.0,134.0,2973.0,2839.0,522.585948969,42.5439580435,14951184.0,521.0,-0.0597243495286,0.47961166501,0.539336014539,0.071392728332,0.0135842458788,2042.54595758,0.0707324,538.0,5914.0,5376.0,1233.65176512,80.1184232583,35294777.0,1230.0,-0.365661621094,6.77035522461,7.1360168457,0.267671842018,0.729409880789,7658.09140015,0.0
+11451214.0,3008.74999997,2281.0,11.7307911165,279.0,319.0,40.0,291.852014956,3.68296405527,3512439.0,292.0,389.0,457.0,68.0,419.407644371,6.24887590535,5047571.0,419.0,342.0,461.0,119.0,369.410386373,6.32820725309,4445854.0,369.0,382.0,462.0,80.0,411.406564188,7.98443480289,4951278.0,411.0,-0.0948717966676,0.0671296268702,0.162001423538,-0.0537612306088,0.00657448979472,-647.016410377,-0.0539523,1062.0,1238.0,176.0,1122.66622351,16.3131186866,13511288.0,1122.0,-0.851593017578,2.02297973633,2.87457275391,0.0825547145817,0.287687087245,993.54598999,0.0
+11342180.0,31.0000000012,30.0,1.51997160827,215.0,305.0,90.0,252.5,16.2170260986,31310.0,252.5,247.0,427.0,180.0,335.540322581,29.2347007669,41607.0,335.0,532.0,1003.0,471.0,838.5,89.7877874446,103974.0,862.0,173.0,436.0,263.0,309.032258065,47.3284568773,38320.0,312.5,0.297794103622,0.5625,0.264705896378,0.462194867192,0.0549947387691,57.3121635318,0.46364,635.0,1168.0,533.0,897.072580645,90.1306554654,111237.0,899.5,0.108947753906,3.29626464844,3.18731689453,2.70659317509,0.585862141452,335.617553711,2.8779
+11375209.0,5240.49999997,1906.0,7.42731086908,177.0,317.0,140.0,242.823203893,13.3751025659,5090060.0,243.0,190.0,458.0,268.0,325.664869764,27.3470233238,6826587.0,328.0,533.0,1206.0,673.0,883.98711955,95.6848475201,18530138.0,882.0,100.0,538.0,438.0,286.587491652,40.9882081197,6007447.0,289.0,0.298108279705,0.772123873234,0.474015593529,0.510096376329,0.0536427034519,10692.6402406,0.509065,467.0,1302.0,835.0,855.075565309,79.9946247075,17924094.0,860.0,-0.484588623047,8.7353515625,9.21994018555,0.538402866378,1.27208144289,11286.000885,0.0700836
+11309665.0,19.2500000002,31.0,1.99315647537,307.0,407.0,100.0,359.025974026,21.2920166894,27645.0,358.0,443.0,646.0,203.0,546.519480519,40.7455233425,42082.0,543.0,645.0,910.0,265.0,770.480519481,61.2348280471,59327.0,764.0,539.0,836.0,297.0,708.584415584,63.8582746216,54561.0,712.0,-0.00239808158949,0.173312887549,0.175710969139,0.0423033905288,0.0295339196097,3.25736107072,0.0352201,1295.0,1883.0,588.0,1614.12987013,121.836845412,124288.0,1614.0,2.81481933594,3.41931152344,0.6044921875,2.92734596946,0.153996607238,225.405639648,2.84216
+11309573.0,43.75,40.0,1.70594894898,293.0,522.0,229.0,409.531428571,56.0179347374,71668.0,401.0,355.0,706.0,351.0,552.034285714,65.6952181032,96606.0,549.0,376.0,766.0,390.0,635.131428571,73.1522864458,111148.0,621.0,288.0,742.0,454.0,595.142857143,77.3169886551,104150.0,593.0,-0.0354131534696,0.132530122995,0.167943276465,0.0338008614207,0.0309191401685,5.91515074862,0.0303479,953.0,1891.0,938.0,1556.70857143,169.529131709,272424.0,1547.0,-0.007080078125,3.82934570312,3.83642578125,2.19025129046,1.64860423693,383.29397583,2.92538
+11311449.0,472.75000002,519.0,6.7335898119,224.0,808.0,584.0,336.142781597,34.5839473998,635646.0,333.0,304.0,1264.0,960.0,488.898995241,53.7288849384,924508.0,489.0,469.0,1792.0,1323.0,767.679534638,86.9610007534,1451682.0,777.0,328.0,1876.0,1548.0,650.679005817,86.822131849,1230434.0,664.0,-0.0377733595669,0.287625432014,0.325398791581,0.0834963415601,0.0356532240682,157.89158189,0.0839206,860.0,3948.0,3088.0,1475.72078265,163.352027904,2790588.0,1491.0,-0.170104980469,4.02230834961,4.19241333008,1.64956279333,1.36612817511,3119.32324219,2.50787
+11266477.0,26.2500000012,57.0,3.13837813765,194.0,427.0,233.0,276.085714286,43.8206549006,28989.0,267.0,279.0,499.0,220.0,367.438095238,53.4069593841,38581.0,367.0,359.0,688.0,329.0,511.038095238,65.6082056148,53659.0,509.0,216.0,525.0,309.0,351.333333333,67.0102574475,36890.0,343.0,0.0591397844255,0.327102810144,0.267963025719,0.189358495069,0.0523131004383,19.8826419823,0.190372,768.0,1434.0,666.0,994.857142857,148.405585094,104460.0,989.0,-0.0724792480469,0.810760498047,0.883239746094,0.0658938453311,0.193333466291,6.91885375977,0.0
+11248597.0,78.7499999991,60.0,1.90730890805,296.0,405.0,109.0,361.187301587,15.0958786772,113774.0,363.0,414.0,611.0,197.0,560.053968254,29.5532923281,176417.0,567.0,578.0,897.0,319.0,790.834920635,45.2459738057,249113.0,796.0,508.0,823.0,315.0,748.641269841,51.2666995941,235822.0,765.0,-0.0211442783475,0.1116951406,0.132839418948,0.027811537511,0.0256836019795,8.76063431596,0.0185778,1224.0,1830.0,606.0,1669.88253968,91.4843841991,526013.0,1693.0,0.413238525391,3.92886352539,3.515625,2.79649144733,1.04053972225,880.894805908,3.14059
+11189478.0,1679.25,596.0,4.10283119804,208.0,278.0,70.0,247.218549948,7.20929759507,1660567.0,247.0,270.0,407.0,137.0,336.996426976,13.5717805856,2263605.0,336.0,766.0,1314.0,548.0,988.45883579,78.6326119897,6639478.0,982.0,181.0,396.0,215.0,287.60979604,20.603454773,1931875.0,288.0,0.390774577856,0.677666902542,0.286892324686,0.547955745993,0.0372342719036,3680.61874583,0.547475,666.0,1057.0,391.0,871.824772964,39.9723455799,5856047.0,872.0,-0.359405517578,1.52136230469,1.88076782227,0.2229575276,0.274181547209,1497.60571289,0.120148
+11101135.0,5031.50000003,2551.0,10.145110649,181.0,652.0,471.0,294.869074829,17.8302110789,5934535.0,293.0,248.0,941.0,693.0,396.274818643,31.5103564366,7975427.0,391.0,363.0,1271.0,908.0,520.37791911,57.458700932,10473126.0,507.0,192.0,1191.0,999.0,446.604541389,57.3526617694,8988363.0,436.0,-0.0797824114561,0.308108121157,0.387890532613,0.0769859805332,0.0226978895499,1549.41984421,0.0750552,621.0,2784.0,2163.0,1137.74843486,103.579377462,22898325.0,1120.0,-0.126586914062,3.17343139648,3.30001831055,0.164956180118,0.246110400847,3319.90808105,0.0602722
+11174584.0,45.0000000002,40.0,1.68208834801,233.0,307.0,74.0,254.977777778,11.5863691732,45896.0,253.5,338.0,428.0,90.0,372.433333333,16.2552897373,67038.0,371.0,997.0,1285.0,288.0,1124.2,56.8673309848,202356.0,1117.0,250.0,415.0,165.0,324.861111111,28.3466172563,58475.0,323.0,0.440751433372,0.660095155239,0.219343721867,0.551283295453,0.0387140106538,99.2309931815,0.54704,832.0,1119.0,287.0,952.272222222,51.8919636848,171409.0,950.0,-0.007080078125,1.03070068359,1.03778076172,0.0255174424913,0.124188164821,4.59313964844,0.0
+11335131.0,4179.24999957,2530.0,11.0399323874,222.0,764.0,542.0,305.173476102,13.4521031345,5101585.0,305.0,288.0,1156.0,868.0,434.636776934,23.3720727396,7265823.0,436.0,421.0,1623.0,1202.0,643.868935814,47.0998818016,10763557.0,647.0,289.0,1763.0,1474.0,551.295806664,42.7139294057,9216012.0,556.0,-0.0413467213511,0.224161073565,0.265507794917,0.0775941367528,0.0170436976497,1297.1411841,0.0758065,807.0,3683.0,2876.0,1291.1060597,75.2520110334,21583420.0,1297.0,-0.148468017578,3.58013916016,3.72860717773,0.290021152112,0.536821386943,4848.28359985,0.0638428
+11175989.0,23.9999999991,73.0,4.20351215198,199.0,301.0,102.0,251.28125,24.2206450871,24123.0,250.0,245.0,413.0,168.0,327.604166667,42.6769549363,31450.0,326.0,326.0,610.0,284.0,469.0,60.2270011429,45024.0,465.5,225.0,523.0,298.0,360.489583333,71.5680030332,34607.0,359.5,0.0467289723456,0.256997466087,0.210268493742,0.13624279298,0.0496836626034,13.0793081261,0.125557,669.0,1233.0,564.0,939375.0,136.128405222,90180.0,932.5,0.788513183594,3.25289916992,2.46438598633,1.09893512726,0.478006648701,105.497772217,0.877823
+11222696.0,11001.4999999,6496.0,17.4708941577,187.0,615.0,428.0,316.098077535,15.8182686327,13910212.0,315.0,280.0,940.0,660.0,464.161727946,27.0472392572,20425901.0,463.0,386.0,1490.0,1104.0,761.13327728,50.9195480695,33494431.0,763.0,210.0,1551.0,1341.0,634.928396128,46.2542830017,27940659.0,637.0,-0.0200591906905,0.349246233702,0.369305424392,0.0906170794557,0.0180101206663,3987.69519853,0.0887324,757.0,3001.0,2244.0,1415.18820161,83.1692718807,62276772.0,1415.0,-0.264099121094,4.10961914062,4.37371826172,0.32829672119,0.743133865218,14447.0255127,0.0
+11164444.0,47.5,41.0,1.67815518804,296.0,450.0,154.0,385.521052632,23.7082503727,73249.0,385.0,406.0,662.0,256.0,590.378947368,38.6613308637,112172.0,600.0,578.0,833.0,255.0,763.984210526,50.6155245912,145157.0,784.0,488.0,820.0,332.0,747.968421053,64.8092671462,142114.0,771.5,-0.0158328060061,0.0844277665019,0.100260572508,0.0114959035816,0.0161048472933,2.18422168051,0.00745854,1190.0,1877.0,687.0,1723.86842105,114.911904713,327535.0,1760.5,2.59848022461,4.15759277344,1.55911254883,3.44285567434,0.292289181982,654.142578125,3.37738
+11152221.0,66.9999999979,85.0,2.92938593723,244.0,399.0,155.0,332.843283582,20.5411325523,89202.0,334.0,342.0,630.0,288.0,499.828358209,37.3999214061,133954.0,503.0,659.0,966.0,307.0,803.660447761,47.2200351461,215381.0,805.0,550.0,921.0,371.0,725.48880597,49.297791662,194431.0,731.0,0.00647249212489,0.124565064907,0.118092572782,0.0514142596139,0.0192993352487,13.7790215765,0.0492643,1212.0,1950.0,738.0,1558.16044776,95.4289628105,417587.0,1564.0,-0.00985717773438,3.76431274414,3.77416992188,2.75128401571,0.953687011442,737.344116211,3.07263
+11224236.0,3519.74999992,1836.0,8.72995160263,205.0,508.0,303.0,355.902478869,22.954942948,5010751.0,356.0,285.0,706.0,421.0,551.055401662,39.4358836432,7758309.0,552.0,513.0,1270.0,757.0,981.029760636,70.7094046873,13811918.0,986.0,205.0,1044.0,839.0,735.13260885,68.1304966422,10349932.0,739.0,0.0170889813453,0.428969353437,0.411880372092,0.144040360659,0.0301864086318,2027.94423771,0.138965,717.0,2144.0,1427.0,1642.09048938,122.012862544,23118992.0,1646.0,-0.0942993164062,4.73956298828,4.83386230469,0.191419810478,0.525745708364,2694.99951172,0.0
+11122481.0,11.2500000002,34.0,2.85955019159,208.0,303.0,95.0,247.8,23.0734094191,11151.0,242.0,259.0,419.0,160.0,326.022222222,39.4954224571,14671.0,320.0,377.0,706.0,329.0,520.177777778,71.4489060297,23408.0,517.0,200.0,535.0,335.0,347.133333333,78.6871724687,15621.0,342.0,0.11840967834,0.308724820614,0.190315142274,0.206880203552,0.0491154138177,9.30960915983,0.20297,705.0,1257.0,552.0,920.955555556,132.689102886,41443.0,896.0,-0.0054931640625,0.560760498047,0.566253662109,0.127124023438,0.174087050757,5.72058105469,0.0179443
+11120801.0,54.0000000014,42.0,1.61230603085,293.0,402.0,109.0,350.453703704,20.2156816007,75698.0,351.0,411.0,617.0,206.0,519.412037037,39.3732335702,112193.0,517.0,579.0,862.0,283.0,709.138888889,49.0511747761,153174.0,701.5,534.0,852.0,318.0,682.092592593,54.5637644374,147332.0,677.0,-0.0464807450771,0.0825958698988,0.129076614976,0.0198294062055,0.0190523992528,4.28315174038,0.0211609,1266.0,1845.0,579.0,1551.95833333,108.668682348,335223.0,1537.5,0.401519775391,3.5810546875,3.17953491211,2.83112250434,0.416465339337,611.522460938,2.88721
+11100739.0,107.250000002,57.0,1.55264179725,261.0,494.0,233.0,342.51048951,18.7652162219,146937.0,341.0,352.0,786.0,434.0,524.48018648,36.111426934,225002.0,525.0,618.0,1431.0,813.0,755.466200466,57.9999750805,324095.0,747.0,516.0,1078.0,562.0,696.750582751,44.5070464643,298906.0,697.0,-0.0677083358169,0.207299277186,0.275007613003,0.0401489798384,0.0322465696293,17.2239123507,0.0333797,1161.0,2358.0,1197.0,1563.74125874,92.0098844356,670845.0,1559.0,1.37448120117,5.49426269531,4.11978149414,4.64246900154,0.390065751161,1991.61920166,4.72543
+11110826.0,5950.0000003,3474.0,12.7047580642,220.0,564.0,344.0,297.231176471,14.2051713673,7074102.0,297.0,286.0,837.0,551.0,400.953655462,22.7204401014,9542697.0,399.0,340.0,984.0,644.0,527.882815126,44.097322739,12563611.0,524.0,256.0,1118.0,862.0,465.758277311,39.5502426818,11085047.0,462.0,-0.0637488141656,0.18544600904,0.249194823205,0.0625052795024,0.0213909114762,1487.62565216,0.0612245,811.0,2519.0,1708.0,1163.94310924,68.9302256426,27701846.0,1158.0,-0.166442871094,3.20889282227,3.37533569336,0.0949142109847,0.202504070171,2258.95822144,0.0
+11041168.0,68.0000000019,62.0,2.12095913588,296.0,413.0,117.0,353.672794118,21.3420909959,96199.0,357.0,418.0,606.0,188.0,515.286764706,35.9898695077,140158.0,522.5,520.0,777.0,257.0,630.724264706,48.1196547778,171557.0,620.5,457.0,792.0,335.0,604.621323529,56.5121016557,164457.0,606.0,-0.0243902429938,0.145833328366,0.17022357136,0.0218360959527,0.0265218572095,5.93941809912,0.0191276,1190.0,1790.0,600.0,1473.58088235,102.781146356,400814.0,1484.5,0.408569335938,3.24783325195,2.83926391602,2.20207909977,0.957969644312,598.965515137,2.70496
+11039989.0,72.7500000005,44.0,1.45522868109,246.0,298.0,52.0,261.948453608,7.46405517141,76227.0,262.0,323.0,414.0,91.0,359.329896907,14.1817279829,104565.0,361.0,273.0,532.0,259.0,325.5395189,40.1805331271,94732.0,311.0,300.0,489.0,189.0,339.274914089,25.7604619172,98729.0,333.0,-0.130708664656,0.0805134177208,0.211222082376,-0.0227756168612,0.0390586224888,-6.62770450662,-0.0333333,879.0,1198.0,319.0,960.553264605,40.0786994013,279521.0,954.0,-0.0401000976562,0.354217529297,0.394317626953,0.0059100278874,0.0363975318062,1.71981811523,0.0
+11017749.0,201.000000005,106.0,2.1091278411,243.0,291.0,48.0,257.266169154,5.41890001425,206842.0,257.0,326.0,401.0,75.0,355.86318408,10.2832369902,286114.0,355.0,638.0,787.0,149.0,697.57960199,29.0063448513,560854.0,693.0,339.0,473.0,134.0,384.919154229,16.149170343,309475.0,384.0,0.212323069572,0.33841753006,0.126094460487,0.288734884682,0.0183298186831,232.142847285,0.288208,914.0,1165.0,251.0,998.048507463,30.4918859652,802431.0,997.0,-0.0805969238281,0.645904541016,0.726501464844,0.0746796261612,0.130062416686,60.0424194336,0.0
+11025110.0,23.4999999991,50.0,2.909585617,172.0,663.0,491.0,287.191489362,83.4657882004,26996.0,270.5,214.0,748.0,534.0,364.787234043,88.107269285,34290.0,345.5,255.0,1266.0,1011.0,570.70212766,200.033286049,53646.0,523.5,87.0,973.0,886.0,375.85106383,143.036593848,35330.0,350.5,0.0407331958413,0.491228073835,0.450494877994,0.208124654962,0.0721484155694,19.5637175664,0.206673,576.0,2384.0,1808.0,1027.82978723,306.119175732,96616.0,960.5,0.949951171875,7.5924987793,6.64254760742,3.02842257885,2.22324863698,284.671722412,2.08507
+11021049.0,29.9999999991,30.0,1.54509680812,306.0,420.0,114.0,366.1,25.7786733561,43932.0,370.0,446.0,629.0,183.0,555.433333333,46.3640905107,66652.0,569.5,637.0,867.0,230.0,758.658333333,43.1824609136,91039.0,758.5,529.0,820.0,291.0,708725.0,63.7530342415,85047.0,720.0,-0.0320000015199,0.169491529465,0.201491530985,0.0352790855647,0.036676951948,4.23349026777,0.0309578,1282.0,1838.0,556.0,1630.25833333,124.347262122,195631.0,1671.0,0.381225585938,2.59579467773,2.2145690918,1.28442993164,0.794056926159,154.131591797,0.918701
+10983457.0,95.5000000019,71.0,2.04951797182,253.0,401.0,148.0,358.30104712,21.5159979188,136871.0,364.0,357.0,611.0,254.0,541.115183246,42.8303279768,206706.0,560.0,427.0,812.0,385.0,686.303664921,55.858196839,262168.0,701.0,381.0,796.0,415.0,686.240837696,68.3174726972,262144.0,712.0,-0.0380434766412,0.16003537178,0.198078848422,0.00106851226213,0.0262620998013,0.408171684132,-0.00746582,994.0,1804.0,810.0,1585.65706806,130.17382736,605721.0,1638.0,2.90386962891,5.75466918945,2.85079956055,4.63022289975,0.762227900178,1768.74514771,4.84814
+10983410.0,26.75,44.0,2.39985969148,308.0,442.0,134.0,379.08411215,26.5020265476,40562.0,376.0,418.0,603.0,185.0,539.953271028,31.5091985316,57775.0,541.0,514.0,736.0,222.0,637.91588785,40.6625321798,68257.0,639.0,445.0,728.0,283.0,610.635514019,44.3904495335,65338.0,613.0,-0.0315627418458,0.0719499513507,0.103512693197,0.0221765517131,0.0227144674429,2.3728910333,0.0215827,1171.0,1726.0,555.0,1529.6728972,86.0988104058,163675.0,1527.0,0.61181640625,3.0553894043,2.44357299805,2.49650388343,0.576689491774,267.125915527,2.66724
+11035674.0,3178.25000116,2288.0,11.4487233265,213.0,527.0,314.0,302.101942893,11.5126798929,3840622.0,302.0,282.0,771.0,489.0,416.934319201,17.9741420773,5300486.0,416.0,392.0,959.0,567.0,570.771179108,29.5360322537,7256214.0,568.0,268.0,1044.0,776.0,481.407063636,29.4670941798,6120128.0,479.0,-0.0424363464117,0.233190268278,0.27562661469,0.0851664949528,0.0153427005439,1082.72165033,0.0852995,764.0,2342.0,1578.0,1200.44332573,52.5179022536,15261236.0,1196.0,-1.29299926758,2.25238037109,3.54537963867,0.127703701869,0.296516543821,1623.49716187,0.0
+11015593.0,553.000000011,540.0,6.47778101202,231.0,368.0,137.0,316.550180832,9.35973422386,700209.0,317.0,310.0,542.0,232.0,455.144213382,17.3402159844,1006779.0,455.0,484.0,774.0,290.0,661.627486438,36.2006104823,1463520.0,666.0,312.0,693.0,381.0,579.28119349,35.7894883497,1281370.0,584.0,0.00352112669498,0.216080397367,0.212559270672,0.0665861469016,0.0145591724285,147.288556946,0.0663665,853.0,1566.0,713.0,1350.9755877,58.3256070555,2988358.0,1357.0,-0.0093994140625,1.06231689453,1.07171630859,0.258726744281,0.155632741797,572.30355835,0.242157
+10980079.0,349.750000007,208.0,3.13746970751,215.0,502.0,287.0,326.275911365,27.5282881111,456460.0,322.0,305.0,759.0,454.0,480.839885633,42.749633796,672695.0,480.0,404.0,947.0,543.0,677.30378842,68.456389492,947548.0,683.0,334.0,972.0,638.0,623.370979271,70.4897118189,872096.0,634.0,-0.0301109347492,0.183383986354,0.213494921103,0.0422878097896,0.030013215742,59.1606458956,0.0386343,887.0,2233.0,1346.0,1430.48677627,124.912107786,2001251.0,1440.0,-0.063232421875,4.39370727539,4.45693969727,2.26054176183,1.64848299984,3162.4979248,3.32437
+10968136.0,874.000000005,367.0,3.50191351174,169.0,282.0,113.0,234.291475973,15.2524333691,819083.0,235.0,207.0,398.0,191.0,310.268306636,34.1814310881,1084698.0,305.0,477.0,1256.0,779.0,916.815503432,106.596353637,3205187.0,927.0,107.0,421.0,314.0,261.207093822,48.5245227586,913180.0,259.0,0.371257483959,0.757030367851,0.385772883892,0.557026302531,0.0636024873746,1947.36395365,0.566497,489.0,1094.0,605.0,805.76687643,96.102367541,2816961.0,800.0,-0.089111328125,3.79052734375,3.87963867188,0.90527002435,1.06979491691,3164.82400513,0.431213
+10947619.0,59.2499999984,58.0,2.12558699478,215.0,261.0,46.0,241.274261603,9.42014472099,57182.0,242.0,268.0,357.0,89.0,316.46835443,18.2364929102,75003.0,317.0,721.0,1141.0,420.0,929.873417722,84.3945476505,220380.0,918.0,204.0,342.0,138.0,274.607594937,23.7652466122,65082.0,277.0,0.46140652895,0.619047641754,0.157641112804,0.543262282379,0.0298076128643,128.753160924,0.547967,689.0,960.0,271.0,832.35021097,50.135004762,197267.0,837.0,-0.121673583984,0.588775634766,0.71044921875,0.00837186016614,0.0604741605074,1.98413085938,0.0
+10935151.0,17.0,46.0,3.14722968555,181.0,322.0,141.0,244.897058824,35.2708593709,16653.0,236.0,256.0,461.0,205.0,332.294117647,55.1993869381,22596.0,317.5,453.0,760.0,307.0,585.308823529,83.1646590228,39801.0,573.5,223.0,560.0,337.0,368.941176471,93.1227656428,25088.0,350.0,0.0737018436193,0.401342272758,0.327640429139,0.235521330772,0.07080978249,16.0154504925,0.237947,689.0,1335.0,646.0,946.132352941,181.723117149,64337.0,899.5,2.49188232422,3.88830566406,1.39642333984,3.33253748277,0.311932977887,226.612548828,3.42773
+10929336.0,1685.49999997,1225.0,8.41718317221,205.0,348.0,143.0,269.229457134,16.3425309993,1815145.0,268.0,272.0,505.0,233.0,385.527439929,27.1492365952,2599226.0,384.0,548.0,1165.0,617.0,908.808513794,72.5305465486,6127187.0,913.0,209.0,606.0,397.0,381.863097004,48.4236756563,2574521.0,377.0,0.209655165672,0.619047641754,0.409392476082,0.408581810093,0.0570140414663,2754.65856364,0.409885,686.0,1422.0,736.0,1036.61999407,87.9399440653,6988892.0,1029.0,-0.314849853516,2.70922851562,3.02407836914,0.136600893847,0.394165573561,920.963226318,0.0
+10917509.0,71.5000000009,71.0,2.36864729051,312.0,383.0,71.0,349.548951049,12.8118191015,99971.0,350.0,467.0,591.0,124.0,526.979020979,22.2826623723,150716.0,530.0,804.0,985.0,181.0,896.468531469,32.8424516763,256390.0,903.0,621.0,833.0,212.0,725.20979021,37.451666408,207410.0,733.0,0.0823927745223,0.137146800756,0.0547540262341,0.105925146777,0.0114295056442,30.2945919782,0.105934,1400.0,1807.0,407.0,1601.73776224,71.8584791209,458097.0,1615.0,-0.00238037109375,0.186340332031,0.188720703125,0.0500554438238,0.0514063228358,14.3158569336,0.0369873
+11053745.0,5399.74999931,2590.0,9.94278401734,248.0,386.0,138.0,303.025093754,6.48446308154,6545039.0,303.0,316.0,561.0,245.0,412.285800269,11.3468414306,8904961.0,412.0,434.0,816.0,382.0,563.538034168,26.3723181927,12171858.0,564.0,330.0,796.0,466.0,494.287513311,22.3541302935,10676116.0,495.0,-0.00200668885373,0.15318416059,0.155190849444,0.0654182222934,0.010830014347,1412.96818332,0.0651558,898.0,1741.0,843.0,1209.59840733,37.2037176444,26126116.0,1210.0,-0.263336181641,2.19104003906,2.4543762207,0.175606818424,0.274553951284,3792.93167114,0.00408936
+10900786.0,10.25,16.0,1.4097857549,383.0,455.0,72.0,417.512195122,18.6784367017,17118.0,417.0,528.0,618.0,90.0,572.512195122,22.9889920118,23473.0,577.0,525.0,662.0,137.0,609.43902439,30.3307368695,24987.0,609.0,509.0,671.0,162.0,603.707317073,36.1421609774,24752.0,603.0,-0.0172955971211,0.0274193547666,0.0447149518877,0.00500130528874,0.0119288672337,0.205053516838,0.00727567,1451.0,1734.0,283.0,1593.73170732,64.5358755929,65343.0,1594.0,3.08801269531,3.54098510742,0.452972412109,3.31470098728,0.129180812141,135.902740479,3.3176
+10895995.0,36.4999999988,30.0,1.40077986492,320.0,407.0,87.0,372.746575342,14.6679277579,54421.0,376.5,480.0,631.0,151.0,571.226027397,25.9603941091,83399.0,575.0,601.0,814.0,213.0,718.636986301,30.8666775455,104921.0,719.0,513.0,758.0,245.0,703.965753425,36.1788582749,102779.0,712.0,-0.034289713949,0.0789946168661,0.113284330815,0.0105607953925,0.0207335194174,1.5418761273,0.00633368,1340.0,1779.0,439.0,1647.93835616,69.8831924256,240599.0,1663.0,3.21716308594,3.93218994141,0.715026855469,3.43988747793,0.168311199019,502.223571777,3.44514
+10889216.0,177.75,75.0,1.5869071857,287.0,541.0,254.0,360.302390999,22.5430978374,256175.0,357.0,409.0,853.0,444.0,546.680731364,36.8667827578,388690.0,545.0,523.0,1091.0,568.0,703.399437412,48.9800694243,500117.0,703.0,434.0,1159.0,725.0,680.182841069,60.0161046209,483610.0,685.0,-0.030222222209,0.102439023554,0.132661245763,0.017541112622,0.0154433786099,12.4717310742,0.014556,1144.0,2526.0,1382.0,1587.16596343,116.076278429,1128475.0,1587.0,0.00534057617188,4.63342285156,4.62808227539,3.51850648604,0.524235596099,2501.65811157,3.62308
+10905358.0,3892.99999998,2866.0,12.9577337557,176.0,334.0,158.0,237.78576933,12.3243511197,3702800.0,239.0,223.0,491.0,268.0,332.498073465,26.2122956402,5177660.0,336.0,599.0,1274.0,675.0,976.104931929,82.0448221858,15199906.0,981.0,114.0,548.0,434.0,277.659517082,33.632129521,4323714.0,280.0,0.344889432192,0.77864074707,0.433751314878,0.557018204067,0.0413652754289,8673.88747373,0.555228,513.0,1373.0,860.0,847.943359877,69.8873906356,13204174.0,855.0,-0.248474121094,6.50863647461,6.7571105957,0.530065203828,1.18206070602,8254.175354,0.0
+10883801.0,11.2500000009,28.0,2.35492368712,206.0,311.0,105.0,254.155555556,28.0039327044,11437.0,246.0,243.0,440.0,197.0,334.2,52.5697843083,15039.0,318.0,493.0,741.0,248.0,601.066666667,73.6865433215,27048.0,604.0,229.0,544.0,315.0,371.555555556,86.1841840493,16720.0,352.0,0.123993560672,0.367403328419,0.243409767747,0.244224485755,0.0573409903489,10.990101859,0.251637,678.0,1295.0,617.0,959.911111111,165.38867652,43196.0,921.0,0.317932128906,1.10452270508,0.786590576172,0.704477945964,0.253235527065,31.7015075684,0.690063
+10949228.0,8697.50000001,6296.0,19.0441927599,208.0,528.0,320.0,319.490428284,15.0702849963,11115072.0,319.0,251.0,788.0,537.0,465.841391204,25.4088764621,16206622.0,465.0,385.0,1181.0,796.0,758.484708249,47.5785981887,26387683.0,759.0,228.0,1159.0,931.0,627.951566542,43.4263433287,21846435.0,629.0,-0.0106707317755,0.258728742599,0.269399474375,0.0943694881348,0.0159776191848,3283.11449221,0.0929204,752.0,2470.0,1718.0,1413.28338603,76.5122077775,49168129.0,1414.0,-0.395355224609,4.80502319336,5.20037841797,0.362030802982,0.749170744888,12595.0516357,0.0
+10850197.0,2669.25000003,1769.0,9.65891346486,246.0,469.0,223.0,331.94239955,19.4676446815,3544149.0,331.0,337.0,707.0,370.0,469.591083638,29.2295316644,5013824.0,468.0,404.0,1113.0,709.0,722.574599607,45.1412649864,7714929.0,724.0,285.0,1035.0,750.0,595.719022197,42.3840678036,6360492.0,597.0,0.0263345204294,0.230493277311,0.204158756882,0.0964793347025,0.0175227377932,1030.10985662,0.0956389,868.0,2208.0,1340.0,1397.25250539,80.8415760847,14918465.0,1395.0,-6.36779785156,7.76965332031,14.1374511719,1.96625486143,2.81774269777,20993.7031555,2.7088
+10834415.0,237.249999998,148.0,2.71052659507,174.0,274.0,100.0,230.831401475,14.697405355,219059.0,232.0,199.0,385.0,186.0,303.582718651,28.724166138,288100.0,304.0,600.0,1284.0,684.0,953.347734457,122.704916661,904727.0,950.0,132.0,388.0,256.0,263.286617492,37.1569739967,249859.0,264.0,0.401854723692,0.764075040817,0.362220317125,0.566079631087,0.0448648969512,537.209569901,0.567831,544.0,1027.0,483.0,797.700737619,76.9104073461,757018.0,800.0,0.0,7.12551879883,7.12551879883,4.37702969229,2.15156584219,4153.80117798,6.09662
+10827738.0,67.7500000009,52.0,1.78214797658,332.0,530.0,198.0,402.933579336,34.2000196601,109195.0,394.0,471.0,769.0,298.0,602.073800738,47.3279569901,163162.0,600.0,588.0,902.0,314.0,710.343173432,46.2495670617,192503.0,703.0,557.0,927.0,370.0,706.597785978,51.1160014472,191488.0,708.0,-0.0232281126082,0.0532081387937,0.0764362514019,0.00292615262758,0.0151672135686,0.792987362074,-0.00147493,1360.0,2160.0,800.0,1711.60516605,127.147918519,463845.0,1699.0,3.42391967773,4.64895629883,1.22503662109,4.02778935169,0.300248408348,1091.53091431,3.91049
+10852705.0,2477.50000001,1353.0,7.6680693681,221.0,639.0,418.0,285.467507568,10.6595656952,2828983.0,284.0,255.0,954.0,699.0,374.666700303,17.3889792833,3712947.0,372.0,346.0,1219.0,873.0,482.124924319,24.7901410689,4777858.0,479.0,220.0,1367.0,1147.0,413.984056509,28.5738469701,4102582.0,410.0,-0.0572312436998,0.22671353817,0.28394478187,0.0764500147074,0.0153302700657,757.61964575,0.0760928,696.0,2960.0,2264.0,1074.11826438,54.8246736698,10644512.0,1066.0,-0.237548828125,1.94808959961,2.18563842773,0.202201158079,0.298646015141,2003.81347656,0.0265198
+10842850.0,5955.00000016,3536.0,12.9260681528,189.0,1267.0,1078.0,305.843534845,21.0864697053,7285193.0,305.0,241.0,2144.0,1903.0,442.92527288,36.4177350582,10550480.0,442.0,446.0,2809.0,2363.0,756.209445844,63.202272832,18012909.0,764.0,199.0,3239.0,3040.0,614.422586062,60.1711476786,14635546.0,619.0,-0.072870194912,0.394216120243,0.467086315155,0.103895687641,0.0249197651651,2474.7952796,0.101855,657.0,6650.0,5993.0,1363.19139379,109.534916822,32471219.0,1369.0,-0.36083984375,5.796875,6.15771484375,0.277468308354,0.771605056379,6609.29510498,0.0
+10811176.0,5.74999999907,16.0,1.88226656704,227.0,323.0,96.0,256.086956522,28.3562937473,5890.0,242.0,259.0,359.0,100.0,296.260869565,24.0329798607,6814.0,292.0,397.0,531.0,134.0,448.217391304,35.950396408,10309.0,442.0,206.0,358.0,152.0,262.869565217,38.8948463646,6046.0,253.0,0.187878787518,0.316749572754,0.128870785236,0.263605415173,0.0352174865095,6.06292454898,0.267525,725.0,1024.0,299.0,815.217391304,85.9635698986,18750.0,784.0,0.0,0.4873046875,0.4873046875,0.203931725543,0.171085380008,4.6904296875,0.184692
+10802224.0,185.999999995,161.0,3.33015518382,203.0,346.0,143.0,256.143817204,15.433851722,190571.0,256.0,272.0,474.0,202.0,360.165322581,23.04223172,267963.0,360.0,633.0,1158.0,525.0,954.044354839,76.7667842343,709809.0,958.0,219.0,563.0,344.0,322.959677419,38.1701550911,240282.0,320.5,0.302786380053,0.605592370033,0.302805989981,0.493529770964,0.0548100777481,367.186149597,0.497781,699.0,1383.0,684.0,939.268817204,72.2460163407,698816.0,936.0,-0.0797119140625,0.68798828125,0.767700195312,0.0568947330598,0.129892664475,42.3296813965,0.0
+10810660.0,372.999999998,289.0,4.22122493468,325.0,369.0,44.0,351.123324397,3.73549996573,523876.0,351.0,539.0,613.0,74.0,588.04691689,6.33846061656,877366.0,588.0,537.0,661.0,124.0,586.922252011,8.9428098499,875688.0,587.0,738.0,851.0,113.0,817.03150134,9.85856819801,1219011.0,817.0,-0.195652171969,-0.0882557332516,0.107396438718,-0.163912108822,0.00751154337961,-244.556866363,-0.164286,1602.0,1821.0,219.0,1756.20174263,18.273801466,2620253.0,1756.0,0.0,0.0,0.0,0.0,0.0,0.0,0.0
+10777019.0,2764.25,1451.0,7.78527255297,255.0,422.0,167.0,305.399294565,6.34802162396,3376800.0,305.0,332.0,590.0,258.0,412.515148775,10.3837279591,4561180.0,412.0,424.0,749.0,325.0,535.362394863,18.6190390649,5919502.0,536.0,336.0,765.0,429.0,478.853486479,16.7448996934,5294683.0,479.0,-0.0211027916521,0.174334138632,0.195436930284,0.0557107453421,0.00891544891728,615.993711248,0.055336,928.0,1763.0,835.0,1196.76792982,30.7925847937,13232663.0,1196.0,-0.212524414062,1.75003051758,1.96255493164,0.343955197524,0.340446807633,3803.11261902,0.286743
+10743041.0,20.5,24.0,1.49530360096,210.0,246.0,36.0,230.097560976,8.30017595479,18868.0,231.0,263.0,331.0,68.0,302.195121951,15.060397935,24780.0,304.0,849.0,1116.0,267.0,1004.90243902,54.7380925365,82402.0,1000.5,177.0,280.0,103.0,238.268292683,21.455597246,19538.0,239.0,0.572424471378,0.702521026134,0.130096554756,0.617096895125,0.0201348305334,50.6019454002,0.613673,651.0,855.0,204.0,770.56097561,43.4971536946,63186.0,774.5,0.608062744141,3.21221923828,2.60415649414,2.05587135873,0.698325157632,168.581451416,1.95805
+10744439.0,217.999999999,159.0,3.03783334952,235.0,300.0,65.0,262.012614679,10.1349190421,228475.0,261.0,312.0,448.0,136.0,366.577981651,20.3435712533,319656.0,366.0,842.0,1207.0,365.0,1034.1456422,72.9275789397,901775.0,1042.0,246.0,471.0,225.0,327.061926606,31.1975919436,285198.0,328.0,0.407547175884,0.627272725105,0.219725549221,0.518937826157,0.0414432047301,452.513784409,0.514848,794.0,1216.0,422.0,955.652522936,59.5243735681,833329.0,955.0,-0.007080078125,1.29748535156,1.30456542969,0.342398582249,0.351819337893,298.571563721,0.206329
+10720664.0,19.5,24.0,1.53316538005,285.0,400.0,115.0,340.717948718,21.9573581125,26576.0,336.5,417.0,621.0,204.0,519.948717949,37.6167916119,40556.0,513.0,629.0,1013.0,384.0,808.871794872,63.3179520407,63092.0,800.0,556.0,861.0,305.0,732.91025641,62.2369718418,57167.0,735.0,0.00933333300054,0.121454544365,0.112121211365,0.0495622891407,0.0256786026669,3.86585855298,0.0444805,1258.0,1881.0,623.0,1593.57692308,117.329201475,124299.0,1576.5,0.639801025391,2.27264404297,1.63284301758,1.67437392015,0.614040624043,130.601165771,2.04124
+10737549.0,147.249999997,76.0,1.76677403672,241.0,347.0,106.0,286.327674024,17.099417623,168647.0,283.0,369.0,522.0,153.0,416.405772496,27.6175684216,245263.0,410.0,846.0,1177.0,331.0,981.916808149,55.1641311392,578349.0,977.0,316.0,621.0,305.0,431.146010187,52.250335181,253945.0,424.0,0.243781089783,0.535294115543,0.291513025761,0.390814658109,0.0523370145662,230.189833626,0.39076,973.0,1481.0,508.0,1133.87945671,92.7623837158,667855.0,1115.0,0.281219482422,0.820404052734,0.539184570312,0.484882037385,0.138535918392,285.59552002,0.459351
+10705007.0,290.999999999,126.0,2.08362288429,267.0,484.0,217.0,407.343642612,30.5314403744,474148.0,409.0,412.0,733.0,321.0,616.731099656,51.8393536425,717875.0,619.0,522.0,1127.0,605.0,860.464776632,74.9395721963,1001581.0,870.0,382.0,969.0,587.0,756.890893471,80.9697832118,881021.0,764.0,-0.06894287467,0.20452567935,0.27346855402,0.0650558935855,0.0318803822016,75.7250601335,0.0620785,1088.0,2165.0,1077.0,1780.96563574,158.819908777,2073044.0,1792.0,3.53707885742,8.3264465332,4.78936767578,7.69512210597,0.806503553551,8957.12213135,7.81302
+10717241.0,506.999999999,373.0,4.67304453692,234.0,381.0,147.0,299.724358974,18.8459565226,607841.0,299.0,331.0,568.0,237.0,454.294378698,30.5748125051,921309.0,454.0,751.0,1211.0,460.0,1004.14151874,53.6867438163,2036399.0,1004.0,323.0,689.0,366.0,492.65433925,50.3775914649,999103.0,490.0,0.245041593909,0.461666673422,0.216625079513,0.343023963486,0.030920894577,695.652597949,0.342113,893.0,1638.0,745.0,1246.67307692,98.1199459433,2528253.0,1243.0,-0.0908508300781,1.03695678711,1.12780761719,0.0413124189809,0.0896042991389,83.7815856934,0.0
+10706161.0,767.999999993,425.0,4.32616807416,118.0,348.0,230.0,257.900390625,13.802686931,792270.0,258.0,263.0,529.0,266.0,378.111328125,22.1422655516,1161558.0,378.0,561.0,1216.0,655.0,987.728190104,60.6786329525,3034301.0,991.0,168.0,489.0,321.0,341.6015625,32.8919292225,1049400.0,340.0,0.342995166779,0.661048710346,0.318053543568,0.486130661525,0.0386080007665,1493.39339221,0.485801,648.0,1204.0,556.0,977.61328125,63.2229144135,3003228.0,976.0,-0.12939453125,1.18041992188,1.30981445312,0.0541089375814,0.162094296587,166.22265625,0.0
+10706375.0,14.0,32.0,2.41257614037,330.0,384.0,54.0,356.267857143,12.6822303573,19951.0,357.5,488.0,578.0,90.0,537.196428571,22.3857573046,30083.0,541.5,585.0,844.0,259.0,738.553571429,62.4033308529,41359.0,748.0,636.0,774.0,138.0,709125.0,34.3230776696,39711.0,713.0,-0.0738161578774,0.0866449475288,0.160461105406,0.0190557274556,0.0374905363293,1.06712073751,0.0261229,1463.0,1725.0,262.0,1602.58928571,66.2750698619,89745.0,1613.0,0.252563476562,3.39251708984,3.13995361328,2.28150558472,0.981472825899,127.764312744,2.65948
+10702580.0,26.2500000002,29.0,1.59671870164,244.0,349.0,105.0,302.342857143,25.6789068791,31746.0,303.0,332.0,524.0,192.0,435.504761905,48.6306044751,45728.0,434.0,525.0,990.0,465.0,707.047619048,86.2073227419,74240.0,694.0,249.0,529.0,280.0,382.076190476,60.3341007957,40118.0,378.0,0.17984496057,0.444816052914,0.264971092343,0.299176278143,0.0674722608275,31.413509205,0.291866,848.0,1385.0,537.0,1119.92380952,119.014900647,117592.0,1145.0,-0.0054931640625,1.07968139648,1.08517456055,0.244877406529,0.263799855238,25.7121276855,0.235718
+10703044.0,17.7500000007,22.0,1.47305366887,325.0,441.0,116.0,383.169014085,25.8740099711,27205.0,375.0,463.0,643.0,180.0,557.281690141,40.5699476296,39567.0,552.0,566.0,768.0,202.0,671.605633803,42.2122333491,47684.0,662.0,525.0,776.0,251.0,654.887323944,60.6422316695,46497.0,634.0,-0.0305444896221,0.0611246936023,0.0916691832244,0.0137167725037,0.0219942978502,0.973890847759,0.0192926,1349.0,1860.0,511.0,1595.33802817,122.467350482,113269.0,1559.0,-0.0195007324219,2.96325683594,2.98275756836,1.95501966879,1.26002601782,138.806396484,2.77759
+10850814.0,8148.74999999,6081.0,19.0031052784,324.0,418.0,94.0,351.722350054,3.94209221816,11464390.0,352.0,552.0,724.0,172.0,594.382758092,6.47277970657,19373906.0,594.0,529.0,697.0,168.0,574.802975917,5.96676563226,18735703.0,575.0,760.0,1043.0,283.0,833.044086516,9.62610675229,27153072.0,833.0,-0.198850572109,-0.169122800231,0.0297277718782,-0.183422190508,0.00282312700994,-5978.64629962,-0.183415,1636.0,2185.0,549.0,1779.14919466,18.4853697836,57991368.0,1779.0,0.0,0.0,0.0,0.0,0.0,0.0,0.0
+10646546.0,10219.5,7106.0,19.8292115972,195.0,595.0,400.0,341.070869416,21.9450650983,13942295.0,339.0,251.0,869.0,618.0,503.709256813,35.678138049,20590627.0,501.0,462.0,1191.0,729.0,886.960908068,66.9372264705,36257188.0,887.0,234.0,1024.0,790.0,709.848965214,59.7423192667,29017206.0,711.0,0.00470114173368,0.388535022736,0.383833881002,0.111257481888,0.02308621718,4547.9833446,0.10828,694.0,2413.0,1719.0,1554.62909144,106.352431914,63550128.0,1552.0,-0.0929260253906,4.20254516602,4.29547119141,0.342805957332,0.32581128071,14013.2219238,0.26944
+10644072.0,34.0,31.0,1.49974458762,226.0,294.0,68.0,259.794117647,12.5546555971,35332.0,259.5,294.0,427.0,133.0,360.845588235,22.64361963,49075.0,362.0,566.0,935.0,369.0,787.117647059,67.3794194036,107048.0,798.0,229.0,442.0,213.0,338.419117647,37.8915936562,46025.0,337.5,0.31918656826,0.503503501415,0.184316933155,0.398692396415,0.0453723944229,54.2221659124,0.395886,749.0,1163.0,414.0,959.058823529,72.0031417519,130432.0,956.5,0.137664794922,0.832427978516,0.694763183594,0.202189501594,0.165485015063,27.4977722168,0.14566
+10640220.0,23.7500000005,23.0,1.33134648813,222.0,278.0,56.0,250.221052632,12.1474961227,23771.0,250.0,286.0,386.0,100.0,341.336842105,21.1065520016,32427.0,339.0,754.0,1073.0,319.0,952.410526316,71.4531123018,90479.0,959.0,231.0,374.0,143.0,300.978947368,34.230174115,28593.0,300.0,0.403539836407,0.602067172527,0.198527336121,0.519498704609,0.0465243071257,49.3523769379,0.520161,746.0,1038.0,292.0,892.536842105,65.9431670019,84791.0,892.0,-0.0390930175781,1.78338623047,1.82247924805,0.649905556127,0.47166776193,61.741027832,0.799713
+10653650.0,180.500000001,179.0,3.75845622061,207.0,387.0,180.0,287.207756233,20.9449494955,207364.0,284.0,275.0,594.0,319.0,413.404432133,34.6534066913,298478.0,410.0,444.0,857.0,413.0,581.975069252,74.1157621081,420186.0,568.0,230.0,736.0,506.0,436.472299169,58.5319472156,315133.0,426.0,-0.0363901033998,0.331395357847,0.367785461247,0.142795084687,0.0559952212589,103.098051144,0.144397,712.0,1706.0,994.0,1137.08448753,109.608974135,820975.0,1117.5,-0.120361328125,1.19259643555,1.31295776367,0.0894739040047,0.184666813708,64.6001586914,0.0
+10630660.0,54.2500000016,50.0,1.91498422637,284.0,391.0,107.0,358.534562212,15.1432470058,77802.0,360.0,439.0,631.0,192.0,550.99078341,29.5262112381,119565.0,555.0,640.0,1014.0,374.0,817.262672811,64.5401324669,177346.0,811.0,520.0,897.0,377.0,757.594470046,64.1434277558,164398.0,756.0,-0.0252659581602,0.167327523232,0.192593481392,0.0381521799286,0.0326957753642,8.27902304451,0.0318803,1248.0,1905.0,657.0,1667.11981567,105.106197882,361765.0,1676.0,-0.0172119140625,3.35342407227,3.37063598633,2.13438731954,1.41775038329,463.16204834,3.00436
+10629222.0,5423.24999997,1748.0,6.69586492084,275.0,428.0,153.0,379.739916102,12.5778571143,8237698.0,380.0,404.0,675.0,271.0,588.748536394,22.7809465082,12771722.0,589.0,725.0,1172.0,447.0,994.655787581,38.4686152564,21577068.0,992.0,501.0,934.0,433.0,785.029871387,36.1852850069,17029653.0,784.0,0.0460142567754,0.234188035131,0.188173778355,0.117933035646,0.0129991971321,2558.32134227,0.116757,1238.0,2019.0,781.0,1753.51832388,68.9635366661,38039073.0,1752.0,-0.0312805175781,1.97268676758,2.00396728516,0.211122769118,0.200196245895,4579.88623047,0.168152
+10626501.0,47.0000000009,55.0,2.26312649218,280.0,431.0,151.0,359.111702128,23.2914757322,67513.0,359.5,402.0,653.0,251.0,540.356382979,39.9532387804,101587.0,544.5,549.0,928.0,379.0,770.45212766,74.4354843153,144845.0,772.0,480.0,910.0,430.0,718.228723404,74.425500552,135027.0,723.0,-0.0267449449748,0.122736416757,0.149481361732,0.0354518841917,0.0242504532311,6.66495422804,0.0334383,1162.0,1977.0,815.0,1617.69680851,130.935539567,304127.0,1631.5,0.0995483398438,3.39776611328,3.29821777344,2.98529296226,0.438261789695,561.235076904,3.01073
+10574578.0,1298.49999999,997.0,7.80493425846,217.0,419.0,202.0,287.530419715,9.91383452919,1493433.0,288.0,269.0,619.0,350.0,383.834616866,17.1222412869,1993637.0,384.0,374.0,796.0,422.0,512.628417405,31.3012885874,2662592.0,511.0,254.0,800.0,546.0,441.534462842,29.1419002907,2293330.0,442.0,-0.0319888740778,0.191082805395,0.223071679473,0.0746433280515,0.017988840837,387.697445899,0.0736393,740.0,1834.0,1094.0,1112.89949942,52.3747999017,5780400.0,1114.0,-0.164093017578,2.08862304688,2.25271606445,0.883093580173,0.351086253644,4586.78805542,0.851166
+10692453.0,263.750000001,207.0,3.59558184826,248.0,431.0,183.0,360.392417062,24.0512001127,380214.0,361.0,365.0,689.0,324.0,552.487203791,43.1912486446,582874.0,555.0,752.0,1162.0,410.0,983.530805687,65.0537564719,1037625.0,982.0,484.0,865.0,381.0,702.323222749,61.8869691361,740951.0,704.0,0.073863632977,0.299565851688,0.225702218711,0.167496206686,0.0325255725577,176.708498053,0.161446,1100.0,1959.0,859.0,1615.2028436,123.375597269,1704039.0,1622.0,-0.0184936523438,0.843017578125,0.861511230469,0.0689132618113,0.141326101949,72.7034912109,0.0
+10566965.0,88.7499999981,90.0,2.69496665852,296.0,559.0,263.0,370.822535211,30.926893339,131642.0,371.0,440.0,824.0,384.0,552.985915493,45.2348777806,196310.0,559.0,493.0,1007.0,514.0,669.16056338,62.3246350562,237552.0,672.0,493.0,1125.0,632.0,672.270422535,66.2693190421,238656.0,680.0,-0.0777604952455,0.0978184342384,0.175578929484,-0.00207932333373,0.0317933597119,-0.738159783476,-0.00430416,1243.0,2508.0,1265.0,1596.07887324,128.712736071,566608.0,1619.0,0.0,3.859375,3.859375,3.16592097753,0.569042231128,1123.90194702,3.2774
+10595079.0,349.750000009,324.0,4.88721242899,195.0,330.0,135.0,260.735525375,19.5705893107,364769.0,260.0,251.0,487.0,236.0,357.438170122,37.3524296945,500056.0,360.0,542.0,1312.0,770.0,931.673338099,128.579882068,1303411.0,955.0,165.0,567.0,402.0,334.923516798,60.7531407796,468558.0,330.0,0.287753582001,0.667003035545,0.379249453545,0.47111936739,0.0639541620643,659.095994979,0.475763,611.0,1365.0,754.0,953.097212294,114.793112778,1333383.0,950.0,-0.0547180175781,0.853942871094,0.908660888672,0.195195970406,0.243746927202,273.079162598,0.0704651
+10561081.0,215.249999997,118.0,2.26884848926,208.0,292.0,84.0,250.113821138,12.0441910629,215348.0,251.0,267.0,449.0,182.0,349.894308943,26.0781320031,301259.0,350.0,742.0,1266.0,524.0,994.457607433,83.2395037568,856228.0,994.0,193.0,471.0,278.0,305.341463415,36.6874232732,262899.0,304.0,0.393041223288,0.640839993954,0.247798770666,0.530449518413,0.037629949336,456.717035353,0.532822,668.0,1212.0,544.0,905.349593496,73.2522709954,779506.0,907.0,-0.0203552246094,4.24722290039,4.267578125,2.36476558814,1.42937011544,2036.06317139,3.32828
+10544845.0,66.5000000009,48.0,1.66044877727,240.0,431.0,191.0,366.755639098,29.4824477247,97557.0,373.0,306.0,618.0,312.0,535.958646617,48.858878612,142565.0,548.5,402.0,833.0,431.0,684.721804511,57.8684473071,182136.0,688.0,292.0,807.0,515.0,642.060150376,69.013048717,170788.0,651.0,-0.0234948601574,0.167567566037,0.191062426195,0.0335490023116,0.0344672127889,8.92403461487,0.0269134,838.0,1826.0,988.0,1544.77443609,138.746001313,410910.0,1584.0,-0.00390625,3.21197509766,3.21588134766,1.39613273449,1.15804207902,371.371307373,2.11993
+10550355.0,454.50000001,242.0,3.20216340632,202.0,281.0,79.0,250.328382838,10.696815773,455097.0,252.0,263.0,419.0,156.0,357.408140814,24.2349287375,649768.0,363.0,704.0,1277.0,573.0,1039.09075908,88.9646721171,1889067.0,1045.0,174.0,372.0,198.0,290.381738174,27.1665509899,527914.0,294.0,0.45684877038,0.674715936184,0.217867165804,0.562689651931,0.0297499882961,1022.96978721,0.560164,642.0,1062.0,420.0,898.118261826,60.4158561398,1632779.0,909.5,-0.00900268554688,1.94235229492,1.95135498047,0.583414025301,0.517916939561,1060.646698,0.614258
+10529009.0,36.9999999991,39.0,1.8086678256,336.0,448.0,112.0,386.743243243,18.1354221188,57238.0,388.0,450.0,655.0,205.0,555.101351351,27.521426509,82155.0,557.0,499.0,812.0,313.0,640.905405405,56.067808589,94854.0,631.0,444.0,777.0,333.0,621.972972973,43.8393791178,92052.0,615.5,-0.0280373822898,0.0727580338717,0.100795416161,0.0144017389118,0.0236353446041,2.13145735895,0.0105044,1238.0,1880.0,642.0,1563.81756757,79.9247143357,231445.0,1567.5,0.393707275391,3.65640258789,3.2626953125,2.28447908969,0.626578720933,338.102905273,2.32697
+10536434.0,608.500000027,552.0,6.31253580432,197.0,755.0,558.0,297.108052588,53.6469582616,723161.0,288.0,236.0,1213.0,977.0,403.621199671,91.8617507087,982414.0,391.0,259.0,1658.0,1399.0,637.176663928,158.503073586,1550888.0,624.0,155.0,1598.0,1443.0,440.389071487,141.239902889,1071907.0,418.0,-0.0282258056104,0.38351982832,0.41174563393,0.187272208765,0.066134554976,455.820556134,0.186705,637.0,3566.0,2929.0,1141.11832375,281.483085045,2777482.0,1096.0,-0.0458374023438,4.84613037109,4.89196777344,1.06152912977,0.770587268773,2583.76190186,1.05545
+10525898.0,2883.74999999,973.0,5.1112733138,212.0,376.0,164.0,296.979193758,20.112356715,3425655.0,297.0,306.0,583.0,277.0,449.76142176,35.9809315109,5187998.0,450.0,781.0,1313.0,532.0,1060.70047681,65.0843446948,12235180.0,1062.0,240.0,685.0,445.0,471.513914174,60.758338392,5438913.0,470.0,0.255681812763,0.572953760624,0.317271947861,0.386497737117,0.0412212378698,4458.25139764,0.383721,758.0,1643.0,885.0,1218.25452969,115.677565084,14052566.0,1216.0,-0.139892578125,0.824249267578,0.964141845703,0.0453326704392,0.102463625057,522.912353516,0.0
+10507334.0,5.5,11.0,1.3231418571,225.0,308.0,83.0,264.863636364,20.9008382923,5827.0,261.0,286.0,371.0,85.0,344.545454545,22.7550739052,7580.0,350.5,599.0,915.0,316.0,826.181818182,81.0155071372,18176.0,849.0,221.0,375.0,154.0,322.454545455,44.0626901262,7094.0,335.5,0.393277317286,0.495618313551,0.102340996265,0.440110282464,0.031420444976,9.68242621422,0.438571,732.0,1034.0,302.0,931.863636364,81.2293584715,20501.0,958.0,0.31689453125,1.55853271484,1.24163818359,1.2000246915,0.382191126035,26.4005432129,1.37122
+10499551.0,65.25,50.0,1.74612292521,316.0,427.0,111.0,376.455938697,20.4617897607,98255.0,380.0,459.0,636.0,177.0,558.042145594,40.1170001705,145649.0,562.0,544.0,831.0,287.0,699.026819923,62.5627902908,182446.0,709.0,526.0,832.0,306.0,680.831417625,68.0225504184,177697.0,694.0,-0.0412371121347,0.0660592243075,0.107296336442,0.0136963213616,0.0205156994736,3.57473987539,0.0134847,1314.0,1853.0,539.0,1615.32950192,120.360213873,421601.0,1629.0,-0.0203552246094,2.67358398438,2.69393920898,2.20400860666,0.319432931302,575.246246338,2.27832
+10522867.0,404.750000014,223.0,3.1268460716,214.0,317.0,103.0,275.846201359,13.1921398383,446595.0,276.0,301.0,487.0,186.0,396.894379246,22.3849876188,642572.0,397.0,571.0,1066.0,495.0,817.869054972,49.8457053513,1324130.0,816.0,250.0,559.0,309.0,427.861642989,39.5023162395,692708.0,429.0,0.220233470201,0.478079319,0.257845848799,0.313679435293,0.0400594948796,507.84700574,0.310638,765.0,1340.0,575.0,1100.60222359,73.5923861773,1781875.0,1104.0,-0.0906677246094,1.18197631836,1.27264404297,0.0463437227057,0.147236545134,75.0304870605,0.0
+10469069.0,16.0000000009,26.0,1.83361614648,234.0,254.0,20.0,244.078125,4.96331758851,15621.0,243.5,285.0,320.0,35.0,301.90625,7.8575575682,19322.0,301.0,306.0,401.0,95.0,350.984375,20.6711545604,22463.0,347.5,259.0,311.0,52.0,280375.0,11.9615268674,17944.0,279.0,0.0402576476336,0.177679881454,0.13742223382,0.111291322624,0.0356014312668,7.12264464796,0.118071,784.0,884.0,100.0,826.359375,23.5155315613,52887.0,824.0,-0.132568359375,1.39282226562,1.525390625,0.216037750244,0.399422883872,13.8264160156,0.0
+10514944.0,1508.00000002,1411.0,10.2499420722,206.0,380.0,174.0,276.528514589,21.7002315422,1668020.0,274.0,273.0,574.0,301.0,397.453083554,38.8277343918,2397437.0,393.0,580.0,1158.0,578.0,853.796584881,85.5371964183,5150101.0,856.0,240.0,705.0,465.0,413.080238727,62.5022932795,2491700.0,407.0,0.186282157898,0.52277225256,0.336490094662,0.349727390712,0.048521272032,2109.55562077,0.343773,735.0,1659.0,924.0,1087.06183687,121.008518957,6557157.0,1074.0,-0.215667724609,1.23876953125,1.45443725586,0.0540928372654,0.149161721624,326.287994385,0.0
+10460082.0,2095.50000002,934.0,5.75569949878,210.0,385.0,175.0,257.852779766,15.9249175231,2161322.0,255.0,277.0,557.0,280.0,356.635289907,30.2913634592,2989317.0,350.0,505.0,1157.0,652.0,723.89453591,83.3048599195,6067684.0,707.0,215.0,666.0,451.0,351.787162968,48.7669728895,2948680.0,343.0,0.175355449319,0.537717580795,0.362362131476,0.346133426242,0.0491723295144,2901.29037876,0.348548,702.0,1598.0,896.0,966.275232641,93.4427580833,8099319.0,948.0,-0.271118164062,1.35089111328,1.62200927734,0.0715677292755,0.19478698034,599.880706787,0.0
+10475571.0,12250.0,8036.0,20.4817448534,183.0,362.0,179.0,270.87455102,17.266865677,13272853.0,269.0,255.0,564.0,309.0,400.737122449,31.1030790766,19636119.0,399.0,699.0,1355.0,656.0,986.389204082,64.6668366714,48333071.0,984.0,142.0,647.0,505.0,382.189653061,47.0975038452,18727293.0,378.0,0.269129276276,0.695278942585,0.426149666309,0.442873470334,0.0365690085928,21700.8000464,0.443953,580.0,1550.0,970.0,1053.80132653,93.9487375325,51636265.0,1045.0,-0.211242675781,1.63681030273,1.84805297852,0.0447080439353,0.119351537431,2190.69415283,0.0
+10418480.0,134.499999993,117.0,2.8459009955,231.0,376.0,145.0,284.436802974,14.2860026707,153027.0,284.0,298.0,537.0,239.0,412.698884758,24.9739350864,222032.0,414.0,338.0,791.0,453.0,455.18401487,58.3206235804,244889.0,451.0,281.0,664.0,383.0,420.767657993,38.9653825309,226373.0,419.0,-0.0923787504435,0.196635127068,0.289013877511,0.0375010880629,0.0579877018977,20.1755853778,0.0394663,810.0,1563.0,753.0,1117.90334572,74.9576457109,601432.0,1116.0,-0.0845947265625,0.893157958984,0.977752685547,0.0225473283392,0.099409083924,12.1304626465,0.0
+10421563.0,98.7499999944,134.0,3.80391946987,161.0,368.0,207.0,240.729113924,31.213759348,95088.0,241.0,159.0,518.0,359.0,298.93164557,50.0374329354,118078.0,293.0,250.0,737.0,487.0,400.126582278,88.7099336679,158050.0,382.0,154.0,636.0,482.0,299.341772152,82.156239865,118240.0,280.0,-0.0176817290485,0.408829182386,0.426510911435,0.147774808173,0.0740908133372,58.3710492284,0.141831,550.0,1479.0,929.0,839.002531646,144.817711672,331406.0,803.0,-0.0297241210938,11.6111755371,11.6408996582,3.50341279235,3.56161484564,1383.84805298,2.66135
+10411423.0,71.2499999965,73.0,2.43963858666,257.0,523.0,266.0,408.810526316,38.1486367474,116511.0,412.0,405.0,769.0,364.0,639.603508772,60.8019562385,182287.0,655.0,589.0,1023.0,434.0,843.792982456,92.105179883,240481.0,851.0,357.0,896.0,539.0,685.431578947,71.1588762519,195348.0,688.0,0.00123609392904,0.271428585052,0.270192491123,0.103174097624,0.0466673888679,29.404617823,0.100606,1131.0,2180.0,1049.0,1733.84561404,152.05238256,494146.0,1751.0,2.99792480469,5.19555664062,2.19763183594,4.24361679345,0.241513664757,1209.43078613,4.24771
+10423694.0,1136.74999997,591.0,4.9448152212,228.0,368.0,140.0,284.718715637,14.4546128977,1294616.0,284.0,288.0,563.0,275.0,404.749505168,25.4404771364,1840396.0,404.0,556.0,1122.0,566.0,830.803606774,52.4974967113,3777664.0,834.0,253.0,697.0,444.0,445.617330108,47.4947247528,2026222.0,445.0,0.168983176351,0.503759384155,0.334776207805,0.302748720479,0.0455203325768,1376.59843202,0.301455,769.0,1605.0,836.0,1135.08555091,84.8859280887,5161234.0,1133.0,-0.314422607422,1.60018920898,1.91461181641,0.105443165437,0.164586603212,479.450073242,0.0732422
+10399718.0,10.75,16.0,1.3766096782,269.0,496.0,227.0,424.209302326,51.7222268534,18241.0,440.0,350.0,677.0,327.0,575.604651163,74.8350556876,24751.0,586.0,468.0,789.0,321.0,663.604651163,63.0511566148,28535.0,654.0,287.0,702.0,415.0,596.139534884,80.3740040686,25634.0,616.0,-0.0206349212676,0.239735096693,0.260370017961,0.0568424005191,0.0592448322135,2.44422322232,0.0445151,919.0,1816.0,897.0,1595.95348837,199.003208282,68626.0,1668.0,0.012451171875,0.207794189453,0.195343017578,0.0463398778161,0.0438943717242,1.99261474609,0.0325623
+10370814.0,5.25,12.0,1.47739512738,224.0,305.0,81.0,248.857142857,23.3182652999,5226.0,242.0,276.0,376.0,100.0,306.80952381,31.4954555265,6443.0,293.0,555.0,844.0,289.0,653.238095238,89.4096536611,13718.0,623.0,226.0,395.0,169.0,277.19047619,54.6378719585,5821.0,260.0,0.323630124331,0.469575196505,0.145945072174,0.406983139969,0.0386800510289,8.54664593935,0.416965,732.0,1072.0,340.0,832.857142857,108.529691226,17490.0,802.0,0.0170593261719,0.463470458984,0.446411132812,0.184552873884,0.121964062753,3.87561035156,0.163788
+10363177.0,22.5000000014,53.0,3.15195260511,190.0,293.0,103.0,234.677777778,24.820165537,21121.0,228.0,238.0,414.0,176.0,313.8,43.4509173922,28242.0,305.5,339.0,639.0,300.0,460.433333333,68.1622329446,41439.0,446.5,178.0,498.0,320.0,306.988888889,73.6754888299,27629.0,291.0,0.103965699673,0.335820883512,0.23185518384,0.207076190826,0.0599747709093,18.6368571743,0.203904,613.0,1195.0,582.0,855.466666667,140.140342356,76992.0,815.5,1.17514038086,1.96383666992,0.788696289062,1.30785624186,0.211187322034,117.707061768,1.20863
+10394070.0,3311.24999998,1727.0,8.46625645827,204.0,374.0,170.0,291.425821065,18.8131869633,3859935.0,291.0,291.0,559.0,268.0,432.424235561,32.5716369011,5727459.0,431.0,725.0,1199.0,474.0,964.716798792,73.1150583417,12777674.0,965.0,237.0,701.0,464.0,462.510305776,52.2322656668,6125949.0,460.0,0.208237990737,0.527888417244,0.319650426507,0.35273533452,0.0406301646632,4671.97950572,0.353764,749.0,1620.0,871.0,1186.3603624,101.102191252,15713343.0,1181.0,-0.151611328125,1.24566650391,1.39727783203,0.0338851312369,0.08960637298,448.808563232,0.0
+10354952.0,47.75,60.0,2.44939953135,163.0,373.0,210.0,256.397905759,33.8108194804,48972.0,255.0,228.0,614.0,386.0,342.141361257,53.740952398,65349.0,334.0,487.0,1148.0,661.0,755.722513089,144.914928884,144343.0,759.0,148.0,741.0,593.0,318.392670157,70.40219348,60813.0,313.0,0.146804839373,0.568539321423,0.42173448205,0.407191632618,0.0649032493907,77.77360183,0.404943,598.0,1728.0,1130.0,916.931937173,147.739797358,175134.0,910.0,2.16247558594,4.91171264648,2.74923706055,3.26953859978,0.718076236861,624.481872559,3.16248
+10426589.0,573.750000017,317.0,3.73330077902,217.0,306.0,89.0,248.152069717,7.64643330837,569509.0,248.0,304.0,466.0,162.0,366.593028322,14.0450549288,841331.0,367.0,851.0,1204.0,353.0,1018.91023965,53.7568458806,2338399.0,1022.0,220.0,458.0,238.0,301.044008715,20.839657133,690896.0,300.0,0.448856800795,0.617346942425,0.16849014163,0.543630939345,0.0270946800656,1247.6330058,0.544765,748.0,1230.0,482.0,915.789106754,40.8157127657,2101736.0,915.0,-0.218933105469,1.17956542969,1.39849853516,0.135650554981,0.255965974388,311.318023682,0.0
+10387135.0,5819.00000011,2487.0,9.19701033799,229.0,361.0,132.0,291.782565733,14.2020026549,6791531.0,292.0,290.0,553.0,263.0,424.300824884,26.3285140552,9876026.0,425.0,658.0,1074.0,416.0,875.130005156,46.6656967959,20369526.0,876.0,267.0,662.0,395.0,454.521223578,44.4908134874,10579436.0,454.0,0.204530313611,0.504057705402,0.299527391791,0.317376417245,0.0369566468265,7387.2534878,0.314725,786.0,1576.0,790.0,1170.60461419,83.0483402609,27246993.0,1171.0,-0.156280517578,1.33697509766,1.49325561523,0.164718208372,0.190640882882,3833.98101807,0.101074
+10566083.0,2780.74999999,2000.0,10.6990222504,209.0,616.0,407.0,298.829812101,11.7762747419,3323884.0,299.0,291.0,932.0,641.0,409.54634541,20.2155712541,4555384.0,408.0,396.0,1192.0,796.0,571.369414726,47.9641422177,6355342.0,570.0,270.0,1312.0,1042.0,493.398183943,41.4805162979,5488068.0,491.0,-0.047923322767,0.300518125296,0.348441448063,0.0731865983467,0.0164429458669,814.05453341,0.0723404,810.0,2860.0,2050.0,1201.77434145,68.8574272267,13367336.0,1196.0,-0.242218017578,2.08151245117,2.32373046875,0.12215855091,0.207055915068,1358.76956177,0.0108948
+10345568.0,457.249999987,365.0,4.81516391129,237.0,379.0,142.0,306.38600328,13.0078724887,560380.0,306.0,311.0,543.0,232.0,436.962274467,21.7595638863,799204.0,437.0,453.0,839.0,386.0,684.610716238,48.1372356437,1252153.0,686.0,337.0,729.0,392.0,570.024056862,42.0927465476,1042574.0,571.0,0.0211433041841,0.239757210016,0.218613905832,0.0914371367106,0.0224934439776,167.238523044,0.0893142,885.0,1645.0,760.0,1313.37233461,69.7096981209,2402158.0,1314.0,-0.119567871094,3.35726928711,3.4768371582,0.354093823816,0.787360849412,647.63760376,0.0
+10307339.0,970.50000001,443.0,4.01144668367,226.0,323.0,97.0,267.721535291,9.76738703399,1039295.0,267.0,298.0,471.0,173.0,384.594796497,16.1452035558,1492997.0,384.0,612.0,1064.0,452.0,850.080370943,39.010734874,3300012.0,849.0,257.0,527.0,270.0,379.819938176,24.3185811506,1474461.0,379.0,0.297134250402,0.489583343267,0.192449092865,0.382494149228,0.0256380760211,1484.8422873,0.383081,797.0,1316.0,519.0,1032.13626996,48.7505952174,4006753.0,1030.0,-0.0941467285156,1.20431518555,1.29846191406,0.0574359923279,0.148134209549,222.966522217,0.0
+10264690.0,87.7500000037,47.0,1.41536797039,237.0,411.0,174.0,309.062678063,21.5310430553,108481.0,303.0,344.0,572.0,228.0,459.051282051,27.1322117475,161127.0,454.0,507.0,869.0,362.0,803.381766382,41.1079062035,281987.0,813.0,438.0,868.0,430.0,723.717948718,45.6802050218,254025.0,729.0,-0.0181818176061,0.0962850674987,0.114466885105,0.0525238819615,0.0128635649121,18.4358825685,0.0537217,1063.0,1851.0,788.0,1491.83190883,78.0432176754,523633.0,1490.0,3.29370117188,4.82260131836,1.52890014648,4.18922037413,0.320554591915,1470.41635132,4.13095
+10255452.0,25.75,52.0,2.89074507855,228.0,411.0,183.0,341.834951456,42.3533671676,35209.0,348.0,324.0,605.0,281.0,495.475728155,62.9698409335,51034.0,508.0,447.0,844.0,397.0,697.174757282,82.6618362283,71809.0,697.0,335.0,736.0,401.0,597.203883495,87.0302212016,61512.0,614.0,-0.00465838517994,0.231854841113,0.236513226293,0.0795763741763,0.0486459492779,8.19636654016,0.0703518,933.0,1694.0,761.0,1434.51456311,180.900008001,147755.0,1498.0,0.0531311035156,1.27465820312,1.22152709961,0.337116722922,0.32010300185,34.7230224609,0.210846
+10251991.0,35.5000000002,81.0,3.83500478656,181.0,336.0,155.0,251.352112676,33.5223694881,35692.0,252.0,222.0,479.0,257.0,338.507042254,56.8295879193,48068.0,339.0,364.0,840.0,476.0,527.978873239,94.6545586285,74973.0,519.5,161.0,619.0,458.0,359.887323944,103.769320183,51104.0,348.0,0.0270270276815,0.423368752003,0.396341724321,0.201134433721,0.0796900470201,28.5610895883,0.191131,567.0,1409.0,842.0,949.746478873,192.526107124,134864.0,945.5,-0.0110168457031,1.86752319336,1.87854003906,0.658834108165,0.607997328591,93.5544433594,0.762451
+10304617.0,24005.4999995,16930.0,30.824543107,181.0,828.0,647.0,339.043167191,20.7397371871,32555603.0,337.0,227.0,1460.0,1233.0,512.16266064,35.0911405403,49178883.0,510.0,339.0,1916.0,1577.0,864.739580513,61.9085894631,83034024.0,866.0,175.0,2209.0,2034.0,727.963091791,56.997690833,69900472.0,730.0,-0.0948587954044,0.453125,0.547983795404,0.0861422083864,0.0211374418496,8271.54713368,0.0854534,652.0,4497.0,3845.0,1579.16891962,104.716141991,151634958.0,1577.0,-0.164794921875,8.48098754883,8.6457824707,0.247329725898,0.432237221826,23749.0949402,0.122162
+10252756.0,249.000000008,180.0,3.21786558884,213.0,419.0,206.0,300.587349398,21.2756672438,299385.0,303.0,303.0,685.0,382.0,476.876506024,54.4668925106,474969.0,479.0,637.0,1308.0,671.0,1015.22991968,107.596385987,1011169.0,1022.0,242.0,745.0,503.0,427.009036145,57.6951283038,425301.0,432.5,0.245187431574,0.600547194481,0.355359762907,0.407898339521,0.0544161217321,406.266746163,0.402641,771.0,1849.0,1078.0,1204.47289157,129.153469729,1199655.0,1211.0,-0.105499267578,0.533630371094,0.639129638672,0.0187923017755,0.0641707354691,18.7171325684,-3.05176e-05
+10231195.0,1551.75000001,754.0,5.39952475774,206.0,285.0,79.0,249.874496536,7.32375466816,1550971.0,250.0,269.0,396.0,127.0,338.257612373,13.8222570299,2099565.0,339.0,625.0,1119.0,494.0,865.010149831,39.9259511966,5369118.0,862.0,217.0,416.0,199.0,315.577090382,21.8404029261,1958787.0,315.0,0.368905246258,0.587076425552,0.218171179295,0.465474398677,0.0273335320557,2889.19959259,0.464195,713.0,1093.0,380.0,903.709199291,40.6703655969,5609323.0,904.0,-0.110961914062,6.35250854492,6.46347045898,0.416062957483,1.29748534077,2582.5027771,0.0
+10234248.0,6.74999999977,13.0,1.41151836774,205.0,276.0,71.0,228.777777778,15.0882179527,6177.0,227.0,260.0,371.0,111.0,293.296296296,24.9767518791,7919.0,288.0,506.0,639.0,133.0,569.0,35.291379705,15363.0,571.0,195.0,383.0,188.0,265.925925926,39.5239504754,7180.0,258.0,0.223910838366,0.506329119205,0.28241828084,0.364945956954,0.0622879905116,9.85354083776,0.36143,660.0,1030.0,370.0,788.0,77.4218841682,21276.0,773.0,-0.00393676757812,0.286804199219,0.290740966797,0.21075213397,0.113460260157,5.69030761719,0.266846
+10354385.0,5279.49999993,3713.0,14.4152978456,248.0,429.0,181.0,370.456766739,16.7350370624,7823306.0,373.0,357.0,704.0,347.0,585.190974524,26.1368874955,12358063.0,588.0,775.0,1199.0,424.0,1031.85775168,35.5036021017,21790772.0,1032.0,447.0,968.0,521.0,814.858272564,35.5862851686,17208177.0,815.0,0.061560831964,0.268412441015,0.206851609051,0.11767788574,0.0120166758759,2485.12159106,0.117223,1101.0,2101.0,1000.0,1770.50601383,69.1264362503,37389546.0,1775.0,-0.0394897460938,1.66305541992,1.70254516602,0.269671358025,0.223851771874,5694.91973877,0.223175
+10257171.0,3200.25000006,2894.0,14.4311732867,258.0,552.0,294.0,350.903288806,19.2651464877,4491913.0,352.0,372.0,892.0,520.0,542.142254511,34.4355649937,6939963.0,544.0,625.0,1396.0,771.0,969.434419186,62.597591767,12409730.0,977.0,429.0,1234.0,805.0,716.916725256,57.6763495913,9177251.0,723.0,-0.0163415912539,0.332402229309,0.348743820563,0.15022806985,0.0244723659589,1923.06952215,0.145928,1089.0,2663.0,1574.0,1609.96226857,106.244101662,20609127.0,1620.0,-0.204711914062,4.85934448242,5.06405639648,0.0736848461508,0.27966968488,943.239715576,0.0
+10192311.0,1980.75000001,991.0,6.28136297344,220.0,380.0,160.0,300.897765998,18.8678859732,2384013.0,301.0,332.0,605.0,273.0,456.61592831,32.4679518875,3617768.0,458.0,839.0,1395.0,556.0,1092.82506626,61.4649626285,8658453.0,1099.0,260.0,708.0,448.0,484.749463587,53.4696089079,3840670.0,485.0,0.276934206486,0.5536480546,0.276713848114,0.386715728549,0.0379241074025,3063.9487173,0.38294,812.0,1683.0,871.0,1242.26315789,102.895893267,9842451.0,1243.0,-0.0897521972656,1.12576293945,1.21551513672,0.028936799933,0.0811642938081,229.266265869,0.0
+10141735.0,192.500000004,172.0,3.4971007793,418.0,503.0,85.0,460.746753247,14.7532790493,354775.0,459.0,666.0,825.0,159.0,748.450649351,23.0903539953,576307.0,746.5,1096.0,1301.0,205.0,1199.1,30.527809336,923307.0,1197.0,888.0,1128.0,240.0,1010.11688312,34.71560674,777790.0,1007.0,0.063386157155,0.111215390265,0.04782923311,0.0856706079821,0.00708275476185,65.9663681462,0.0857015,1974.0,2454.0,480.0,2219.31428571,69.9716263725,1708872.0,2214.0,-0.0406494140625,1.02435302734,1.06500244141,0.403445355304,0.290493548616,310.652923584,0.367294
+10141085.0,393.249999983,394.0,5.6047587567,236.0,515.0,279.0,340.820089002,27.233632646,536110.0,338.0,349.0,721.0,372.0,519.531468531,40.9581034468,817223.0,519.0,602.0,1157.0,555.0,915.012714558,81.8793933641,1439315.0,922.0,447.0,912.0,465.0,713.73553719,65.9051505139,1122706.0,723.0,0.0417163297534,0.22507122159,0.183354891837,0.123675558991,0.0266886268274,194.541654292,0.121893,1064.0,2116.0,1052.0,1574.08709472,121.458855991,2476039.0,1580.0,-0.134979248047,1.0256652832,1.16064453125,0.0493394544908,0.117662665594,77.6109619141,0.0
+10155457.0,1658.49999999,1118.0,7.74424588416,194.0,496.0,302.0,321.738317757,27.1031196638,2134412.0,321.0,251.0,754.0,503.0,463.48688574,45.8946595012,3074772.0,465.0,413.0,1141.0,728.0,731.061802834,78.8401647631,4849864.0,743.0,227.0,1011.0,784.0,606.136719928,75.7044407201,4021111.0,620.0,-0.0723270475864,0.377229094505,0.449556142092,0.0945561447495,0.037541701698,627.285464268,0.0916937,691.0,2261.0,1570.0,1391.36192342,140.15199124,9230295.0,1407.0,-0.209411621094,4.15014648438,4.35955810547,0.57291606711,0.987559425527,3800.72518921,0.0401306
+10119531.0,23.7500000009,27.0,1.56288500779,228.0,339.0,111.0,258.242105263,24.7499987409,24533.0,252.0,267.0,441.0,174.0,323.957894737,34.1242052661,30776.0,313.0,547.0,1028.0,481.0,824.789473684,113.66033375,78355.0,836.0,226.0,417.0,191.0,294.842105263,35.2406212352,28010.0,289.0,0.309121608734,0.598726093769,0.289604485035,0.469491651497,0.0644279583004,44.6017068923,0.470492,724.0,1188.0,464.0,877.042105263,90.7659704132,83319.0,855.0,1.03042602539,3.74459838867,2.71417236328,2.72739611174,0.676411083762,259.102630615,2.60745
+10108793.0,404.999999989,435.0,6.09757026163,206.0,260.0,54.0,238.864197531,6.22708755501,386960.0,239.0,264.0,361.0,97.0,316.735185185,13.0113766565,513111.0,318.0,737.0,1043.0,306.0,911.403703704,38.3465353899,1476474.0,911.0,170.0,320.0,150.0,258.993209877,16.8137386011,419569.0,260.0,0.486639678478,0.653061211109,0.166421532631,0.5575965649,0.0182311817074,903.306435138,0.556382,642.0,936.0,294.0,814.592592593,34.8798565016,1319640.0,818.0,-0.02734375,2.97943115234,3.00677490234,0.683799461082,0.51090263008,1107.75512695,0.75589
+10097924.0,463.750000018,270.0,3.53685186757,221.0,445.0,224.0,277.587061995,12.4880037204,514924.0,276.0,262.0,663.0,401.0,360.950404313,24.2654395476,669563.0,356.0,324.0,863.0,539.0,472.518598383,44.4706336269,876522.0,461.0,225.0,794.0,569.0,385.109433962,39.8574737394,714378.0,376.0,-0.025559104979,0.270108044147,0.295667149127,0.102221299686,0.02580857213,189.620510917,0.101517,708.0,1902.0,1194.0,1023.64690027,75.3876584081,1898865.0,1008.0,-9.70739746094,8.60498046875,18.3123779297,-0.0407993697092,2.38123726664,-75.6828308105,0.212585
+10099167.0,83.7500000019,53.0,1.63372340072,295.0,433.0,138.0,372.689552239,19.0979965686,124851.0,374.0,408.0,617.0,209.0,559.441791045,28.4114027416,187413.0,565.0,517.0,899.0,382.0,711.211940299,46.0673728631,238256.0,710.0,462.0,793.0,331.0,705.232835821,48.1558365461,236253.0,712.0,-0.0429958403111,0.176470592618,0.219466432929,0.00444743997807,0.0252371314641,1.48989239265,-0.000712758,1173.0,1786.0,613.0,1637.3641791,84.7603746153,548517.0,1651.0,2.97418212891,4.63739013672,1.66320800781,4.06675415039,0.341566353713,1362.36264038,4.05176
+10074563.0,102.499999999,60.0,1.67180024938,205.0,301.0,96.0,256.817073171,16.0273607894,105295.0,257.0,252.0,438.0,186.0,343.317073171,28.0530325515,140760.0,345.0,658.0,1155.0,497.0,948.080487805,90.5800864335,388713.0,952.0,188.0,557.0,369.0,313.57804878,43.0920173254,128567.0,317.0,0.311069875956,0.63603925705,0.324969381094,0.503175285386,0.0488531060017,206.301867008,0.504593,651.0,1296.0,645.0,913.712195122,84.7080789049,374622.0,918.0,-0.00238037109375,2.75894165039,2.76132202148,1.70034745379,0.50720538015,697.142456055,1.75153
+10044137.0,243.749999995,155.0,2.80062172873,246.0,540.0,294.0,375.354871795,37.6089353044,365971.0,370.0,328.0,793.0,465.0,530.988717949,59.8597238499,517714.0,526.0,371.0,990.0,619.0,631.529230769,88.8622957564,615741.0,635.0,273.0,1027.0,754.0,588.859487179,89.7966349078,574138.0,596.0,-0.0302066765726,0.190123453736,0.220330130309,0.0357951387776,0.0331089769156,34.9002603082,0.0281457,874.0,2347.0,1473.0,1495.20307692,173.85494629,1457823.0,1496.0,-0.00421142578125,3.85452270508,3.85873413086,1.84090184921,1.34180383924,1794.87930298,2.7197
+10050142.0,10310.75,6542.0,18.1744166202,209.0,371.0,162.0,282.723056034,15.1246313472,11660347.0,281.0,290.0,551.0,261.0,413.643672866,25.1704098825,17059906.0,411.0,651.0,1144.0,493.0,883.631719322,47.9469240742,36443623.0,880.0,226.0,648.0,422.0,433.527653178,37.4611370563,17879981.0,429.0,0.227138638496,0.545728623867,0.318589985371,0.342308473269,0.0316338640229,14117.828363,0.341299,725.0,1563.0,838.0,1129.89438208,75.4720334514,46600234.0,1122.0,-0.118774414062,1.16885375977,1.28762817383,0.0312927644185,0.080869907137,1290.60748291,0.0
+10055972.0,1325.49999999,1226.0,9.49938899431,211.0,688.0,477.0,340.667483968,32.8378179637,1806219.0,339.0,305.0,1025.0,720.0,511.510939268,52.3285670163,2712031.0,512.0,503.0,1484.0,981.0,922.383062995,85.2136872853,4890475.0,930.0,239.0,1486.0,1247.0,629.436250472,82.8654952113,3337271.0,632.0,-0.00541271967813,0.384180784225,0.389593503904,0.190396995819,0.0440566057894,1009.48487183,0.188078,776.0,3199.0,2423.0,1481.61467371,158.154305002,7855521.0,1484.0,-0.356475830078,1.27737426758,1.63385009766,0.084073159165,0.186217064272,445.755889893,0.0
+10026696.0,4.99999999977,15.0,1.89234939156,204.0,229.0,25.0,215.6,7.00999286733,4312.0,217.5,255.0,290.0,35.0,273.75,11.536355577,5475.0,274.5,533.0,722.0,189.0,609.95,52.2890762971,12199.0,602.5,196.0,255.0,59.0,218.55,16.9807979789,4371.0,222.5,0.380829006433,0.52320677042,0.142377763987,0.471116419137,0.0432948796067,9.42232838273,0.483655,660.0,763.0,103.0,707.9,30.4103600768,14158.0,714.0,0.378082275391,0.884094238281,0.506011962891,0.50224609375,0.15818405578,10.044921875,0.425781
+9985489.0,510.25,343.0,4.2834892502,288.0,371.0,83.0,307.337089662,6.13948922417,627275.0,307.0,345.0,526.0,181.0,421.470357668,10.3658802386,860221.0,421.0,505.0,741.0,236.0,577.159725625,24.444599137,1177983.0,572.0,369.0,678.0,309.0,501.556099951,19.2658217977,1023676.0,499.0,0.019172552973,0.265671640635,0.246499087662,0.0700041725073,0.0122456268701,142.878516087,0.0692308,1006.0,1575.0,569.0,1230.36354728,30.7207575205,2511172.0,1230.0,-0.150817871094,1.37759399414,1.52841186523,0.151015001789,0.242566114671,308.221618652,0.0
+9983856.0,9.75,17.0,1.53582481896,317.0,381.0,64.0,353.333333333,15.6538409038,13780.0,357.0,447.0,573.0,126.0,526.564102564,28.0958021062,20536.0,533.0,648.0,807.0,159.0,748.666666667,36.3489733452,29198.0,751.0,555.0,753.0,198.0,681.025641026,47.0632347006,26560.0,689.0,0.015121630393,0.0998415201902,0.0847198897973,0.0479451489324,0.0188168898437,1.86986080837,0.0470588,1336.0,1697.0,361.0,1560.92307692,86.6787125599,60876.0,1580.0,2.13497924805,2.8117980957,0.676818847656,2.47986544096,0.153634621779,96.7147521973,2.44034
+9984762.0,2.5,11.0,1.96253652777,300.0,311.0,11.0,305.7,4.2201895692,3057.0,306.0,416.0,444.0,28.0,432.0,7.37563556583,4320.0,433.0,604.0,684.0,80.0,636.6,22.1187703094,6366.0,633.0,471.0,517.0,46.0,500.4,12.2898331966,5004.0,501.0,0.0949820801616,0.149579837918,0.0545977577567,0.11960683316,0.0179370464628,1.1960683316,0.124305,1187.0,1271.0,84.0,1238.1,22.3,12381.0,1238.5,0.276519775391,0.588409423828,0.311889648438,0.372808837891,0.0839646214165,3.72808837891,0.364166
+9980274.0,33.250000003,54.0,2.6417578279,217.0,314.0,97.0,250.413533835,17.7882819499,33305.0,248.0,264.0,439.0,175.0,321.571428571,30.9467856905,42769.0,315.0,450.0,766.0,316.0,582.789473684,66.8711085025,77511.0,562.0,240.0,522.0,282.0,316.812030075,55.9015179123,42136.0,304.0,0.163670763373,0.388076484203,0.22440572083,0.298452222258,0.05040314375,39.6941455603,0.307602,740.0,1275.0,535.0,888.796992481,100.907294564,118210.0,868.0,0.722351074219,1.96771240234,1.24536132812,1.0234436953,0.299711279754,136.118011475,0.974091
+9993498.0,1852.25,1738.0,11.3918704739,208.0,486.0,278.0,339.43609124,19.8532746858,2514882.0,340.0,289.0,718.0,429.0,519.985693076,32.1238755047,3852574.0,520.0,583.0,1216.0,633.0,913.267107572,55.8188826246,6766396.0,912.0,381.0,976.0,595.0,699.556485356,49.8364345973,5183014.0,699.0,0.0483558997512,0.282485872507,0.234129972756,0.132795797581,0.0202894221814,983.884064276,0.131336,887.0,2097.0,1210.0,1558.97826967,96.8338576715,11550470.0,1558.0,-0.199249267578,1.0270690918,1.22631835938,0.0403681737174,0.0935867620087,299.087799072,0.0
+9800254.0,9300.75000598,6387.0,18.6824142925,228.0,912.0,684.0,297.818186705,10.0778415591,11079730.0,298.0,285.0,1386.0,1101.0,405.569658361,16.799215603,15088408.0,406.0,327.0,1699.0,1372.0,543.590006182,30.8642629914,20223179.0,541.0,217.0,2049.0,1832.0,474.299465097,28.9058529319,17645363.0,474.0,-0.093383140862,0.261669009924,0.355052150786,0.0681189964184,0.015157783535,2534.23102375,0.0675182,753.0,4347.0,3594.0,1177.68731016,53.1186090955,43813501.0,1179.0,-0.276611328125,3.4231262207,3.69973754883,0.171359096007,0.290409486164,6375.07244873,0.0132446
+9947049.0,1722.00000001,706.0,4.79935854013,233.0,991.0,758.0,345.156068525,20.6787454856,2377435.0,346.0,341.0,1519.0,1178.0,505.142131243,32.5521556256,3479419.0,504.0,393.0,2087.0,1694.0,747.541521487,49.6253795874,5149066.0,741.0,278.0,2148.0,1870.0,577.022357724,49.1915839097,3974530.0,575.0,-0.0843233838677,0.281501352787,0.365824736655,0.129063686989,0.0277079750744,888.990675979,0.124307,897.0,4658.0,3761.0,1427.32055749,98.9544060599,9831384.0,1424.0,-0.192993164062,5.40884399414,5.6018371582,0.511382715489,1.09332263076,3522.40414429,0.0
+9928011.0,1038.25000001,477.0,4.1760191076,214.0,1143.0,929.0,353.881290633,42.0611346779,1469669.0,351.0,267.0,1795.0,1528.0,525.994943414,74.2298849737,2184457.0,524.0,340.0,2482.0,2142.0,756.984830243,117.606773824,3143758.0,749.0,187.0,2708.0,2521.0,665.432699254,116.228812583,2763542.0,665.0,-0.0571827068925,0.302452325821,0.359635032713,0.0657257933926,0.0458500353826,272.95921996,0.0605144,668.0,5646.0,4978.0,1545.3089333,224.163782869,6417668.0,1534.0,0.00152587890625,5.39456176758,5.39303588867,3.23046786085,1.11106139751,13416.1330261,3.50232
+9989445.0,10898.2500001,9060.0,24.4818866354,206.0,529.0,323.0,357.853783864,21.8536306299,15599920.0,359.0,257.0,799.0,542.0,540.551120593,36.9084442367,23564245.0,543.0,494.0,1256.0,762.0,935.747803546,66.7903868891,40792054.0,941.0,270.0,1049.0,779.0,751.451723901,61.4052695687,32758035.0,758.0,-0.0403726696968,0.329207926989,0.369580596685,0.109617540391,0.0249715097221,4778.55743826,0.107219,736.0,2323.0,1587.0,1649.85662836,112.8521198,71922200.0,1659.0,-0.0992736816406,4.22979736328,4.32907104492,0.311184075143,0.342781133147,13565.4473877,0.228699
+10040873.0,1370.99999997,482.0,3.67217507793,190.0,328.0,138.0,252.808533917,12.5188039499,1386402.0,253.0,233.0,475.0,242.0,345.157549234,23.1026231356,1892844.0,347.0,535.0,1254.0,719.0,934.241247265,100.376255897,5123379.0,929.0,154.0,543.0,389.0,312.297775346,36.7394098052,1712641.0,312.0,0.265938073397,0.670822918415,0.404884845018,0.497348618423,0.0556756449876,2727.45982343,0.498759,587.0,1346.0,759.0,910.263858497,69.8521899857,4991887.0,912.0,-0.203948974609,3.58453369141,3.78848266602,0.40871734953,0.73294885614,2241.40594482,0.0755005
+10002097.0,6035.99999998,2686.0,9.75273583057,206.0,360.0,154.0,276.059766402,13.2022686997,6665187.0,275.0,288.0,546.0,258.0,397.833043406,23.6846044297,9605281.0,396.0,681.0,1107.0,426.0,857.808316766,52.4904859354,20710924.0,850.0,233.0,617.0,384.0,433.562582836,38.9552339025,10467935.0,432.0,0.21702721715,0.516095519066,0.299068301916,0.329153378247,0.0308045727274,7947.0791644,0.327347,727.0,1462.0,735.0,1107.45539264,74.1950563934,26738403.0,1104.0,-0.160278320312,1.12561035156,1.28588867188,0.0250976504357,0.0767309898552,605.957672119,0.0
+9951360.0,2998.75000002,1781.0,9.17463629905,222.0,347.0,125.0,274.348228429,15.123960352,3290807.0,273.0,288.0,493.0,205.0,377.292288454,26.2775058641,4525621.0,373.0,552.0,1104.0,552.0,800.041433931,57.5084867198,9596497.0,796.0,224.0,649.0,425.0,410.818340975,49.9745589006,4927766.0,404.0,0.156595185399,0.501364886761,0.344769701362,0.322478340613,0.0535947436683,3868.12769565,0.323427,734.0,1481.0,747.0,1062.45885786,88.7376246191,12744194.0,1048.0,-0.0133056640625,1.89312744141,1.90643310547,0.490811669881,0.272508653543,5887.28598022,0.522614
+9951298.0,3583.24999994,2454.0,11.5646121362,215.0,515.0,300.0,354.376473871,21.5911382652,5079278.0,353.0,284.0,717.0,433.0,543.040047443,37.255032117,7783393.0,543.0,512.0,1293.0,781.0,977.165352683,67.1386974587,14005711.0,981.0,247.0,976.0,729.0,729.626316891,63.2302267505,10457734.0,734.0,0.0181219112128,0.353333324194,0.335211412981,0.145696320152,0.0263763069091,2088.26535674,0.141463,760.0,2208.0,1448.0,1627.04283821,116.194056622,23320405.0,1632.0,-0.0797119140625,2.41372680664,2.4934387207,0.509542267329,0.307584365986,7303.26931763,0.481995
+9886807.0,1301.75,477.0,3.72949177635,264.0,397.0,133.0,312.879969272,7.48813773896,1629166.0,313.0,410.0,631.0,221.0,485.467447667,15.8399683142,2527829.0,486.0,311.0,557.0,246.0,375.641636259,17.5412777924,1955966.0,374.0,385.0,735.0,350.0,493.27597465,24.6286747476,2568488.0,492.0,-0.2496984303,0.0300751887262,0.279773619026,-0.135149166501,0.0318652732062,-703.721709973,-0.143177,1082.0,1763.0,681.0,1291.62339159,46.1433011249,6725483.0,1291.0,-0.0859680175781,1.17077636719,1.25674438477,0.00911208464679,0.0600207718183,47.4466247559,0.0
+9901124.0,1465.49999999,1239.0,9.13005645522,208.0,391.0,183.0,273.451552371,17.7507850143,1602973.0,271.0,279.0,590.0,311.0,394.417775503,32.5010769782,2312077.0,389.0,584.0,1200.0,616.0,804.180484476,83.5060118612,4714106.0,794.0,223.0,704.0,481.0,410.712043671,48.0492148076,2407594.0,403.0,0.162724018097,0.479128867388,0.316404849291,0.323794674541,0.0424738418933,1898.08438216,0.322508,710.0,1683.0,973.0,1078.58137155,95.4657125172,6322644.0,1063.0,-0.178100585938,0.999938964844,1.17803955078,0.0386343897101,0.0950764097732,226.47479248,0.0
+9968641.0,7557.25,5575.0,18.0908113591,183.0,631.0,448.0,353.696020378,22.7149443463,10691877.0,353.0,235.0,943.0,708.0,534.961758576,39.024051156,16171359.0,536.0,426.0,1270.0,844.0,882.141916703,67.7667756013,26666268.0,891.0,222.0,1247.0,1025.0,743.919183565,64.4265501333,22487933.0,751.0,-0.040347609669,0.363171368837,0.403518978506,0.0854481646622,0.0219603824567,2583.01256957,0.0856778,667.0,2695.0,2028.0,1632.57696252,118.602074835,49351169.0,1640.0,-0.151947021484,5.0446472168,5.19659423828,0.333171590203,0.406373325122,10071.4440002,0.224304
+9886882.0,20.5000000005,39.0,2.42986835153,195.0,286.0,91.0,244.06097561,21.6007833874,20013.0,243.5,256.0,405.0,149.0,330.792682927,35.1136613692,27125.0,332.5,461.0,742.0,281.0,579.219512195,73.628935257,47496.0,566.0,179.0,432.0,253.0,313.743902439,56.2576414269,25727.0,316.5,0.168888881803,0.545108020306,0.376219138503,0.299417045422,0.0723752449417,24.5521977246,0.294789,633.0,1123.0,490.0,888.597560976,112.244925982,72865.0,891.0,-0.061767578125,4.43460083008,4.4963684082,1.02082973573,1.86130370177,83.7080383301,0.0
+9875936.0,117.5,61.0,1.58747161911,246.0,450.0,204.0,361.970212766,33.0915423719,170126.0,367.0,303.0,681.0,378.0,515.793617021,56.7928108436,242423.0,527.5,449.0,924.0,475.0,600.376595745,87.6344237055,282177.0,572.0,225.0,727.0,502.0,470.806382979,84.3982376146,221279.0,441.0,0.00720720738173,0.332344204187,0.325136996806,0.123293291334,0.0444834523486,57.9478469272,0.118481,818.0,1806.0,988.0,1348.57021277,156.331094244,633828.0,1346.5,-0.010986328125,4.13079833984,4.14178466797,1.58390360081,1.43744968295,744.434692383,1.16077
+9873202.0,19.5000000009,37.0,2.36362996086,210.0,336.0,126.0,271.884615385,32.4388895954,21207.0,275.5,272.0,483.0,211.0,366.512820513,51.9515907779,28588.0,365.5,314.0,736.0,422.0,475.076923077,97.1831167714,37056.0,460.0,213.0,571.0,358.0,380.192307692,93.1166979011,29655.0,387.5,0.0299999993294,0.203199997544,0.173199998215,0.115789417536,0.0445323143954,9.03157456778,0.117072,717.0,1376.0,659.0,1018.58974359,173.782979596,79450.0,1025.5,2.99163818359,4.27264404297,1.28100585938,3.81194090232,0.300816647697,297.331390381,3.83278
+9920599.0,674.250000007,248.0,2.69423994823,203.0,325.0,122.0,246.857248795,11.138192865,665774.0,247.0,257.0,462.0,205.0,329.057471264,21.2925322306,887468.0,329.0,713.0,1288.0,575.0,999.833518725,84.5318067005,2696551.0,1010.0,151.0,476.0,325.0,281.450129774,35.9025250137,759071.0,278.0,0.355397939682,0.714801430702,0.35940349102,0.559806063379,0.055082897825,1509.79695293,0.571661,617.0,1263.0,646.0,857.364849833,64.3758401143,2312313.0,855.0,-0.784393310547,1.32934570312,2.11373901367,0.0653294785004,0.360668064123,176.193603516,0.0
+9847272.0,223.500000004,110.0,2.07562546105,261.0,316.0,55.0,295.195749441,8.0382714209,263905.0,296.0,347.0,486.0,139.0,444.845637584,17.227023994,397692.0,449.0,313.0,445.0,132.0,367.413870246,17.5531429593,328468.0,364.0,361.0,486.0,125.0,437.795302013,20.4110867214,391389.0,441.0,-0.187270507216,0.063670411706,0.250940918922,-0.0873040782122,0.0360365189868,-78.0498459217,-0.0966952,982.0,1278.0,296.0,1177.83668904,43.6917225355,1052986.0,1186.0,-0.267211914062,1.40844726562,1.67565917969,0.119332810643,0.253777774089,106.683532715,0.00100708
+9877083.0,62.2500000014,61.0,2.180997788,332.0,453.0,121.0,416.148594378,14.7140757144,103621.0,416.0,487.0,717.0,230.0,653.012048193,31.5795015015,162600.0,656.0,884.0,1308.0,424.0,1128.1124498,56.222694449,280900.0,1126.0,566.0,964.0,398.0,858.317269076,48.9448478955,213721.0,859.0,0.0954879298806,0.258297264576,0.162809334695,0.136005456758,0.018744048365,33.8653587326,0.133906,1385.0,2134.0,749.0,1927.47791165,93.4797215841,479942.0,1932.0,0.008544921875,1.34085083008,1.3323059082,0.240321638115,0.336415025256,59.8400878906,0.136444
+9830138.0,44.9999999998,32.0,1.34567067841,203.0,266.0,63.0,240.288888889,12.2811910791,43252.0,241.0,251.0,357.0,106.0,308.488888889,21.9538629577,55528.0,309.0,601.0,1156.0,555.0,972.133333333,86.0418115414,174984.0,980.5,173.0,376.0,203.0,269.805555556,38.4531601392,48565.0,271.0,0.414785981178,0.680517077446,0.265731096268,0.565597829388,0.0497810778196,101.80760929,0.570204,627.0,996.0,369.0,818.583333333,71.127575134,147345.0,820.0,0.586181640625,3.16329956055,2.57711791992,1.83046502007,0.48705531324,329.483703613,1.63338
+9836948.0,6.00000000023,13.0,1.49714131435,318.0,351.0,33.0,335.541666667,8.49008817517,8053.0,337.5,463.0,517.0,54.0,491.541666667,13.7628096897,11797.0,493.0,640.0,829.0,189.0,758625.0,48.6276777326,18207.0,777.0,630.0,728.0,98.0,686625.0,27.321866243,16479.0,688.0,0.0078740157187,0.08548707515,0.0776130594313,0.0491231216195,0.0231797425869,1.17895491887,0.0559212,1411.0,1596.0,185.0,1513.70833333,48.9153002365,36329.0,1524.0,-0.0244445800781,0.0444030761719,0.06884765625,0.00366973876953,0.0141140286514,0.0880737304688,0.0
+9832182.0,21.2499999998,32.0,1.9582384745,443.0,714.0,271.0,555.152941176,48.428602604,47188.0,559.0,633.0,1052.0,419.0,781.682352941,78.2033866823,66443.0,774.0,630.0,1100.0,470.0,825.035294118,94.8383698794,70128.0,813.0,601.0,1258.0,657.0,858.341176471,119.67598933,72959.0,847.0,-0.0670059397817,0.0551989711821,0.122204910964,-0.0183556082754,0.0225378520655,-1.56022670341,-0.019883,1730.0,2979.0,1249.0,2195.17647059,230.204981623,186590.0,2158.0,0.207336425781,1.05484008789,0.847503662109,0.423662971048,0.323532434877,36.0113525391,0.248413
+9822885.0,252.500000004,275.0,4.88199208065,211.0,337.0,126.0,270.912871287,18.8613579688,273622.0,271.0,275.0,471.0,196.0,375.843564356,35.9187653756,379602.0,379.0,309.0,791.0,482.0,575.668316832,80.431201067,581425.0,582.5,240.0,655.0,415.0,442.854455446,71.7528045124,447283.0,446.0,-0.00189753319137,0.278651684523,0.280549217714,0.131696861602,0.0497890431522,133.013830218,0.125925,731.0,1463.0,732.0,1089.61089109,124.570883556,1100507.0,1096.0,-0.57421875,1.30715942383,1.88137817383,-0.0244195617071,0.190456052567,-24.6637573242,-3.05176e-05
+9844847.0,842.00000001,581.0,5.6482661742,219.0,314.0,95.0,257.582244656,10.1855880997,867537.0,256.0,264.0,434.0,170.0,342.233669834,17.5800941287,1152643.0,340.0,517.0,993.0,476.0,692.021971496,44.6186146822,2330730.0,687.0,237.0,528.0,291.0,356.760391924,32.4049571197,1201569.0,351.0,0.202416911721,0.445048958063,0.242632046342,0.320229703282,0.0306342412258,1078.53364065,0.320494,720.0,1276.0,556.0,956.576306413,58.6242523699,3221749.0,947.0,-0.154541015625,2.05520629883,2.20974731445,0.32141320779,0.401292102924,1082.51968384,0.261688
+9820631.0,10.2499999998,15.0,1.32167414523,204.0,284.0,80.0,252.317073171,23.1173454299,10345.0,262.0,258.0,370.0,112.0,325.414634146,36.0338429067,13342.0,342.0,646.0,848.0,202.0,747.634146341,46.2895215965,30653.0,750.0,179.0,377.0,198.0,301.170731707,58.8047212469,12348.0,329.0,0.330372989178,0.600443959236,0.270070970058,0.430698152722,0.0724400999713,17.6586242616,0.411546,643.0,1028.0,385.0,878.902439024,117.468585293,36035.0,934.0,0.185913085938,1.1526184082,0.966705322266,0.327957525486,0.194440735119,13.4462585449,0.281982
+9857283.0,2780.00000003,1113.0,5.9548089764,218.0,418.0,200.0,266.668615108,13.9924113769,2965355.0,264.0,264.0,534.0,270.0,383.298561151,23.1737276373,4262280.0,382.0,610.0,1278.0,668.0,985.163758993,57.4302178961,10955021.0,987.0,178.0,550.0,372.0,343.81205036,39.1530192902,3823190.0,338.0,0.294287770987,0.611570239067,0.317282468081,0.483371028711,0.0390258831893,5375.08583927,0.483469,675.0,1444.0,769.0,993.779226619,73.7733544301,11050825.0,983.0,-0.0562744140625,1.55801391602,1.61428833008,0.219694519043,0.212684263907,2443.00305176,0.177307
+9836739.0,1938.00000001,686.0,4.39584425894,228.0,391.0,163.0,304.255417957,20.0890569859,2358588.0,303.0,334.0,612.0,278.0,461.816821465,34.3123136305,3580004.0,460.0,770.0,1251.0,481.0,996.071723426,51.8767692721,7721548.0,995.0,300.0,763.0,463.0,519.726135191,58.8846425926,4028917.0,515.0,0.198237881064,0.468085110188,0.269847229123,0.316013347629,0.0385015380023,2449.73547082,0.316522,870.0,1766.0,896.0,1285.79837461,112.365379758,9967509.0,1278.0,-0.110961914062,0.3701171875,0.481079101562,0.0168911960472,0.0503488240515,130.940551758,0.0
+9796329.0,2863.5,1617.0,8.52425620068,186.0,271.0,85.0,232.412694255,11.0706345047,2662055.0,233.0,238.0,430.0,192.0,324.130609394,21.1657601284,3712592.0,324.0,681.0,1281.0,600.0,1005.20394622,84.9944428496,11513606.0,1004.0,139.0,372.0,233.0,257.773878121,28.6461287714,2952542.0,259.0,0.468354433775,0.728536367416,0.260181933641,0.591520551944,0.0358575145007,6775.27640197,0.590612,566.0,1056.0,490.0,814.317181771,59.5204225021,9327189.0,817.0,-0.214111328125,3.6926574707,3.90676879883,1.65340859074,0.828148092872,18938.1419983,1.77769
+9771704.0,45.0,30.0,1.26156626101,349.0,405.0,56.0,377.572222222,9.71026407442,67963.0,377.0,520.0,632.0,112.0,586.622222222,19.0485215395,105592.0,587.0,719.0,858.0,139.0,792.8,26.7997512426,142704.0,794.0,670.0,848.0,178.0,776.155555556,30.2171441812,139708.0,780.0,-0.0130030959845,0.0380473807454,0.0510504767299,0.0107047954429,0.00938923087338,1.92686317972,0.0100129,1545.0,1877.0,332.0,1740.35,53.3859610135,313263.0,1745.0,2.57022094727,3.61474609375,1.04452514648,3.06463572184,0.236310320186,551.634429932,3.0399
+9773160.0,253.500000007,223.0,3.951035658,234.0,317.0,83.0,278.918145957,10.0938498526,282823.0,279.0,342.0,466.0,124.0,403.120315582,16.0678210493,408764.0,402.0,684.0,881.0,197.0,769.716962525,30.9437003598,780493.0,770.0,371.0,580.0,209.0,466.25739645,32.15970103,472785.0,461.5,0.17761194706,0.320547938347,0.142935991287,0.246061678748,0.02648702755,249.506542251,0.247932,947.0,1362.0,415.0,1148.29585799,55.3253711145,1164372.0,1143.0,-0.050048828125,0.515563964844,0.565612792969,0.0615632247172,0.104901810168,62.4251098633,0.0
+9772828.0,23.2500000005,24.0,1.40408962753,473.0,745.0,272.0,593.193548387,42.6756353304,55167.0,597.0,676.0,1019.0,343.0,838.225806452,52.2099008104,77955.0,845.0,644.0,1033.0,389.0,868.698924731,64.5768334482,80789.0,869.0,652.0,1170.0,518.0,892.032258065,68.266153961,82959.0,894.0,-0.0621879249811,0.0251903925091,0.0873783174902,-0.0131872657615,0.0190140646586,-1.22641571582,-0.0110145,1848.0,2934.0,1086.0,2323.4516129,144.659371215,216081.0,2338.0,-0.0679626464844,0.467071533203,0.535034179688,0.0529949229251,0.103085481171,4.92852783203,0.0
+9741483.0,204.999999988,133.0,2.62041319983,207.0,339.0,132.0,247.995121951,15.3070197705,203356.0,245.0,263.0,522.0,259.0,318.709756098,33.7058459493,261342.0,309.0,313.0,750.0,437.0,408.391463415,63.1497961707,334881.0,385.0,204.0,612.0,408.0,284.973170732,46.389725126,233678.0,271.0,0.0624380558729,0.326186835766,0.263748779893,0.178233075296,0.0335967695311,146.151121743,0.172527,712.0,1473.0,761.0,851.67804878,90.4558981943,698376.0,825.0,-0.275024414062,17.8942260742,18.1692504883,0.584950702946,2.98690272549,479.659576416,0.0
+9740379.0,7.5,13.0,1.33908390035,194.0,277.0,83.0,219.266666667,19.3785677719,6578.0,214.5,266.0,402.0,136.0,338.366666667,31.2265734414,10151.0,342.5,446.0,652.0,206.0,508.833333333,47.8553956089,15265.0,490.0,229.0,490.0,261.0,336.4,54.7354851384,10092.0,330.5,0.141856387258,0.321481496096,0.179625108838,0.207784271737,0.0410636876795,6.23352815211,0.195604,706.0,1169.0,463.0,894.033333333,97.6724059747,26821.0,887.0,-0.0832214355469,0.00653076171875,0.0897521972656,-0.0171813964844,0.0270194819363,-0.515441894531,0.0
+9725645.0,265.000000005,124.0,2.14878921806,220.0,313.0,93.0,251.616981132,8.05420869353,266714.0,252.0,319.0,487.0,168.0,372.400943396,13.802467617,394745.0,373.0,986.0,1293.0,307.0,1112.3490566,40.1996532541,1179090.0,1111.0,228.0,481.0,253.0,313.816037736,21.7426875011,332645.0,314.0,0.44839450717,0.655580163002,0.207185655832,0.559995345378,0.024910764826,593.5950661,0.558953,771.0,1281.0,510.0,937.833962264,42.5775516343,994104.0,938.0,-0.100830078125,1.08209228516,1.18292236328,0.106009141454,0.195468194708,112.369689941,0.0
+9713827.0,216.000000003,94.0,1.804247225,301.0,465.0,164.0,400.086805556,16.3294528264,345675.0,400.0,470.0,749.0,279.0,603.131944444,30.154213174,521106.0,605.0,529.0,916.0,387.0,733.930555556,37.8408863198,634116.0,731.0,498.0,890.0,392.0,711.005787037,41.471612489,614309.0,711.0,-0.0344379469752,0.0822179764509,0.116655923426,0.0160573311769,0.01408176415,13.8735341369,0.0145133,1280.0,2003.0,723.0,1714.22453704,81.0051041474,1481090.0,1716.0,-0.0195617675781,5.71575927734,5.73532104492,4.04163328807,1.79463236784,3491.97116089,4.73488
+9722667.0,168.500000003,68.0,1.47776041236,290.0,429.0,139.0,382.620178042,16.0818919482,257886.0,384.0,356.0,653.0,297.0,563.341246291,33.0603600787,379692.0,571.0,461.0,776.0,315.0,665.62462908,28.7768976527,448631.0,668.0,459.0,791.0,332.0,660.192878338,36.4422824379,444970.0,666.0,-0.0793131664395,0.138936534524,0.218249700963,0.00441857881327,0.0237179409424,2.97812212014,-0.000732601,1165.0,1730.0,565.0,1606.15430267,70.3556876039,1082548.0,1619.0,3.39370727539,5.66229248047,2.26858520508,4.48441335073,0.566073680157,3022.49459839,4.34425
+9789705.0,2915.99999994,1294.0,6.75982704739,192.0,304.0,112.0,248.95781893,12.2883705454,2903844.0,249.0,245.0,455.0,210.0,357.339849108,24.9873473437,4168012.0,358.0,617.0,1237.0,620.0,976.353737997,67.8871224317,11388190.0,980.0,151.0,488.0,337.0,317.009773663,35.9284731889,3697602.0,317.0,0.389999985695,0.685884714127,0.295884728432,0.510267000957,0.0383980640987,5951.75429916,0.507741,588.0,1247.0,659.0,923.307441701,72.0667471308,10769458.0,924.0,-0.259399414062,2.96243286133,3.22183227539,0.395942496992,0.74320180485,4618.27328491,0.0
+9711617.0,36.2499999998,45.0,2.10840276125,288.0,381.0,93.0,339.006896552,19.0655842859,49156.0,339.0,408.0,607.0,199.0,515.855172414,42.035121491,74799.0,517.0,644.0,878.0,234.0,790.731034483,43.8664517437,114656.0,798.0,577.0,842.0,265.0,742.786206897,53.8377109478,107704.0,755.0,0.00472813239321,0.0909090936184,0.0861809612252,0.0318286806152,0.0167836200631,4.61515868921,0.0285714,1275.0,1804.0,529.0,1597.64827586,98.7621685936,231659.0,1615.0,0.289703369141,3.50381469727,3.21411132812,2.68768773572,0.626005095743,389.71472168,2.92154
+9837685.0,7661.49999997,6215.0,20.0299238416,213.0,507.0,294.0,302.144292893,13.811049454,9259514.0,301.0,279.0,757.0,478.0,431.544606148,22.6273135449,13225116.0,430.0,391.0,1109.0,718.0,700.885792599,39.1549832759,21479346.0,704.0,254.0,1061.0,807.0,586.82682895,37.086654693,17983895.0,590.0,-0.0148148145527,0.240287765861,0.255102580413,0.0887983548615,0.0158039374956,2721.31438309,0.0878477,784.0,2304.0,1520.0,1320.51572799,65.9576940856,40468525.0,1323.0,-0.267517089844,15.382598877,15.6501159668,0.634674531334,1.0806613757,19450.2356873,0.0
+9680274.0,135.749999994,151.0,3.65596556194,286.0,519.0,233.0,418.64825046,42.1623586376,227326.0,416.0,401.0,725.0,324.0,583.241252302,56.3965079302,316700.0,583.0,463.0,983.0,520.0,738.390423573,103.318538983,400946.0,734.0,392.0,955.0,563.0,677.82320442,90.5395635835,368058.0,667.0,-0.125915080309,0.163318783045,0.289233863354,0.0422116358612,0.0494354954777,22.9209182726,0.0412698,1166.0,2116.0,950.0,1679.71270718,162.141738135,912084.0,1689.0,0.118713378906,1.61557006836,1.49685668945,0.527285019118,0.348586088493,286.315765381,0.448395
+9683966.0,29.2499999991,33.0,1.72125839989,283.0,425.0,142.0,365.871794872,27.4850506256,42807.0,369.0,403.0,597.0,194.0,516.367521368,36.7364367181,60415.0,522.0,560.0,754.0,194.0,656.196581197,37.3244584956,76775.0,653.0,480.0,717.0,237.0,608.068376068,42.6654099366,71144.0,615.0,-0.0138990487903,0.141361251473,0.155260300264,0.0384953042222,0.0279468916078,4.50395059399,0.0352,1182.0,1739.0,557.0,1490.30769231,98.3529716625,174366.0,1503.0,0.182006835938,0.861236572266,0.679229736328,0.406653771034,0.203415026083,47.5784912109,0.301514
+9892568.0,3495.75000001,2132.0,10.1721342945,222.0,492.0,270.0,281.941786455,11.7865792712,3942392.0,281.0,272.0,715.0,443.0,375.472073232,20.2309006285,5250226.0,375.0,346.0,885.0,539.0,508.31280841,45.6694557682,7107738.0,503.0,232.0,959.0,727.0,426.212972896,38.7456177761,5959736.0,423.0,-0.0401301532984,0.232796490192,0.272926643491,0.0878438377717,0.0192548066411,1228.32038356,0.0868687,730.0,2164.0,1434.0,1083.62683258,66.6807834652,15152354.0,1081.0,-0.241455078125,2.67092895508,2.9123840332,0.132072686075,0.274239155323,1846.77236938,0.0
+9659603.0,173.500000011,112.0,2.39863049664,260.0,412.0,152.0,338.025936599,23.9130730389,234590.0,337.0,362.0,628.0,266.0,511.19740634,40.3204018575,354771.0,514.0,528.0,908.0,380.0,745.008645533,61.8494028138,517036.0,749.0,400.0,858.0,458.0,701.463976945,66.4023909267,486816.0,711.0,-0.0233488995582,0.137931033969,0.161279933527,0.0307310581375,0.017304405175,21.3273543474,0.027696,1028.0,1809.0,781.0,1550.68731988,115.086417527,1076177.0,1576.0,-0.00204467773438,3.89205932617,3.89410400391,2.95313502595,0.482367783233,2049.47570801,3.00888
+9688651.0,978.500000007,477.0,4.3016297993,233.0,375.0,142.0,292.572560041,20.8751054814,1145129.0,290.0,321.0,556.0,235.0,418.824987225,38.4815423913,1639281.0,415.0,694.0,1158.0,464.0,922.73888605,64.8413990956,3611600.0,928.0,279.0,654.0,375.0,442.44149208,62.093997806,1731716.0,432.0,0.217016026378,0.514310479164,0.297294452786,0.35416342486,0.0430535193444,1386.1956449,0.358362,848.0,1563.0,715.0,1153.83903935,119.900259387,4516126.0,1134.0,-0.0297241210938,1.44720458984,1.47692871094,0.236438390608,0.212063184402,925.41986084,0.170227
+9652131.0,47.749999996,54.0,2.20445957831,233.0,300.0,67.0,268.130890052,12.2781310183,51213.0,268.0,287.0,423.0,136.0,364.172774869,26.1761350114,69557.0,365.0,708.0,1011.0,303.0,847.188481675,56.1410534084,161813.0,847.0,276.0,530.0,254.0,383.706806283,38.1790752394,73288.0,384.0,0.25088340044,0.501805067062,0.250921666622,0.376649871547,0.0500181537675,71.9401254654,0.376432,831.0,1234.0,403.0,1016.0104712,67.8178951757,194058.0,1022.0,-0.0747375488281,1.06860351562,1.14334106445,0.0881582529757,0.202422226484,16.8382263184,0.0
+9650359.0,10.0000000002,16.0,1.42729929291,370.0,473.0,103.0,420.2,25.1109537852,16808.0,423.0,532.0,676.0,144.0,583975.0,31.4821278665,23359.0,582.5,590.0,805.0,215.0,664825.0,49.7468026611,26593.0,659.0,560.0,828.0,268.0,652725.0,52.1382716917,26109.0,645.0,-0.0272660274059,0.0377833768725,0.0650494042784,0.00935778309649,0.0157984076115,0.37431132386,0.0100083,1518.0,1977.0,459.0,1656.9,92.7221117102,66276.0,1649.0,2.91983032227,3.4133605957,0.493530273438,3.27709197998,0.125931905207,131.083679199,3.32999
+9630882.0,101.000000001,59.0,1.65609937297,281.0,514.0,233.0,390.660891089,47.5562861426,157827.0,383.0,419.0,721.0,302.0,574.925742574,57.825826142,232270.0,581.5,487.0,959.0,472.0,751.485148515,98.6242357559,303600.0,742.0,483.0,954.0,471.0,725.809405941,90.4298908495,293227.0,710.5,-0.081212118268,0.114576272666,0.195788390934,0.0168928475703,0.0306190292499,6.82471041841,0.0202573,1199.0,2009.0,810.0,1691.3960396,152.327053643,683324.0,1728.0,-0.00634765625,4.1643371582,4.17068481445,3.22244874558,0.513578757155,1301.86929321,3.19475
+9782539.0,12341.5000011,7636.0,19.3899644982,156.0,1335.0,1179.0,299.334501479,18.7602784841,14776947.0,299.0,224.0,2186.0,1962.0,409.948345015,30.7561119913,20237510.0,409.0,329.0,2476.0,2147.0,562.525564153,47.229036011,27769637.0,556.0,138.0,3343.0,3205.0,482.980512904,51.8496644263,23842816.0,479.0,-0.15918366611,0.461240321398,0.620423987508,0.0767653841656,0.0228292401713,3789.59995472,0.0746004,563.0,6864.0,6301.0,1192.2633594,96.4866297124,58857273.0,1188.0,-0.285186767578,6.06838989258,6.35357666016,0.192466624875,0.46643778355,9501.30740356,0.0
+9626035.0,108.750000003,58.0,1.56894756225,293.0,422.0,129.0,380.544827586,15.2571728646,165537.0,383.0,409.0,602.0,193.0,552.951724138,30.6111686555,240534.0,564.0,580.0,860.0,280.0,677.901149425,35.038525576,294887.0,670.0,481.0,725.0,244.0,641.170114943,27.4998604592,278909.0,644.0,-0.0332326292992,0.151824817061,0.185057446361,0.0276650580109,0.0268484059925,12.0343002348,0.0203762,1238.0,1706.0,468.0,1574.66666667,62.048306481,684980.0,1589.0,3.67495727539,5.38446044922,1.70950317383,4.41213210533,0.359177027412,1919.27746582,4.33255
+9641573.0,54.75,41.0,1.56310035944,198.0,274.0,76.0,233.643835616,16.6536322334,51168.0,236.0,249.0,376.0,127.0,315.894977169,29.3587932636,69181.0,320.0,660.0,1215.0,555.0,1013.40639269,149.222227571,221936.0,1067.0,169.0,362.0,193.0,265.493150685,41.5237589318,58143.0,269.0,0.446945339441,0.711849927902,0.264904588461,0.583136996314,0.0473694637899,127.707002193,0.587492,626.0,977.0,351.0,815.03196347,84.9151275511,178492.0,828.0,-0.0281677246094,2.71536254883,2.74353027344,1.72145770347,0.548824390772,376.999237061,1.87857
+9619862.0,64.7499999977,90.0,3.15513314564,151.0,423.0,272.0,238.77992278,43.5507273387,61844.0,235.0,147.0,545.0,398.0,293.297297297,64.0792857136,75964.0,284.0,253.0,838.0,585.0,375.55984556,86.2185832748,97270.0,357.0,171.0,594.0,423.0,276.305019305,71.7952070188,71563.0,256.0,-0.00657894741744,0.307577997446,0.314156944863,0.153692410554,0.0779242590195,39.8063343336,0.149466,516.0,1531.0,1015.0,808.382239382,168.350447573,209371.0,771.0,0.0,20.6221923828,20.6221923828,4.26291412,7.16732057533,1104.09475708,0.0
+9620629.0,237.499999998,234.0,4.28330616623,162.0,527.0,365.0,340.877894737,35.9352610265,323834.0,344.0,296.0,779.0,483.0,492.197894737,61.0451152905,467588.0,499.0,380.0,978.0,598.0,646.592631579,77.1601297946,614263.0,645.0,238.0,962.0,724.0,583.709473684,92.4419579761,554524.0,591.5,-0.00986193306744,0.279661029577,0.289522962645,0.0542942566167,0.0394098815012,51.5795437858,0.0464879,786.0,2268.0,1482.0,1416.78526316,182.817608831,1345946.0,1436.0,2.38122558594,3.63171386719,1.25048828125,2.7013139263,0.25080177437,2566.24822998,2.60258
+9612396.0,18.0,22.0,1.46278836147,307.0,397.0,90.0,352.888888889,16.0291016207,25408.0,351.0,469.0,612.0,143.0,547.972222222,26.4175721308,39454.0,553.0,758.0,1026.0,268.0,934.236111111,45.4121536154,67265.0,935.0,621.0,909.0,288.0,813.486111111,57.1848836513,58571.0,826.5,0.0193905811757,0.163406208158,0.144015626982,0.0696771348982,0.0357582723938,5.01675371267,0.0626092,1397.0,1890.0,493.0,1714.34722222,93.1750383422,123433.0,1740.0,2.88668823242,3.43975830078,0.553070068359,3.1386150784,0.169034257215,225.980285645,3.1544
+9643763.0,3074.00000001,1373.0,6.98576020162,221.0,329.0,108.0,278.040988939,12.7691432748,3418792.0,277.0,290.0,485.0,195.0,396.771226415,23.0012684226,4878699.0,396.0,625.0,1075.0,450.0,857.019193234,51.725739908,10537908.0,853.0,285.0,613.0,328.0,457.608897202,42.8796338022,5626759.0,457.0,0.199722602963,0.44774851203,0.248025909066,0.304606389841,0.0344374577024,3745.44016948,0.304556,796.0,1416.0,620.0,1132.42111256,77.4573347202,13924250.0,1130.0,-0.223602294922,1.68200683594,1.90560913086,0.0460493476188,0.108661821833,566.22277832,0.0
+9608050.0,8.25,20.0,1.96425600437,214.0,384.0,170.0,271.96969697,36.3171925631,8975.0,264.0,290.0,565.0,275.0,376.757575758,62.9569503242,12433.0,362.0,456.0,803.0,347.0,589.303030303,100.392105463,19447.0,547.0,288.0,562.0,274.0,389.878787879,71.4616903411,12866.0,380.0,0.0904007479548,0.333917617798,0.243516869843,0.204070402592,0.0527818760011,6.73432328552,0.198661,792.0,1443.0,651.0,1038.60606061,164.721608929,34274.0,993.0,0.648559570312,1.4533996582,0.804840087891,0.850013501716,0.253027310208,28.0504455566,0.733551
+9659056.0,1675.49999998,1079.0,7.43608416358,226.0,376.0,150.0,303.322739481,18.8785913341,2032869.0,302.0,289.0,564.0,275.0,441.909877648,33.6989399917,2961680.0,440.0,658.0,1169.0,511.0,933.046254849,60.2870380453,6253276.0,929.0,278.0,686.0,408.0,481.26022083,58.3851347455,3225406.0,477.0,0.181571811438,0.502572894096,0.321001082659,0.321022820238,0.0460819633333,2151.49494123,0.321033,830.0,1609.0,779.0,1226.49283796,108.979602397,8219955.0,1218.0,-0.0289611816406,1.28723144531,1.31619262695,0.19680656358,0.188536015869,1318.99758911,0.152924
+9676052.0,6196.75000001,5405.0,19.3690704395,222.0,511.0,289.0,370.826521967,18.8119413466,9191677.0,371.0,301.0,722.0,421.0,569.610198895,31.6179319264,14118928.0,571.0,548.0,1190.0,642.0,976.984427321,53.1747917512,24216513.0,980.0,324.0,1013.0,689.0,777.422035745,51.2945560816,19269960.0,781.0,0.00808314047754,0.28802588582,0.279942745343,0.114078949561,0.0211692897722,2827.67492276,0.111868,848.0,2175.0,1327.0,1717.85875661,95.4616458497,42580565.0,1723.0,-0.0508117675781,3.38589477539,3.43670654297,0.218228700619,0.266533053817,5409.23480225,0.151947
+9586175.0,180.250000006,99.0,2.08014029,283.0,440.0,157.0,353.274618585,19.9209820985,254711.0,355.0,379.0,656.0,277.0,533.821081831,37.8187134834,384885.0,542.0,496.0,966.0,470.0,747.611650485,64.1130163512,539028.0,765.0,363.0,907.0,544.0,672.791955617,74.7238540206,485083.0,691.0,-0.0192592591047,0.241776317358,0.261035576463,0.0539964144684,0.0369505259027,38.9314148317,0.0435365,1026.0,1991.0,965.0,1559.88765603,127.784112215,1124679.0,1593.0,1.61010742188,6.95425415039,5.34414672852,3.68492725388,0.775570736139,2656.83255005,3.50497
+9582265.0,8.0,15.0,1.49603355151,197.0,304.0,107.0,252.15625,28.4770844002,8069.0,259.0,244.0,414.0,170.0,337.21875,45.4654637988,10791.0,348.0,536.0,946.0,410.0,789.5,108.260103455,25264.0,797.5,154.0,451.0,297.0,303.03125,75.33155231,9697.0,316.0,0.284581512213,0.620689630508,0.336108118296,0.452112249099,0.0719826016406,14.4675919712,0.444107,595.0,1169.0,574.0,892.40625,148.470295719,28557.0,925.0,-0.00238037109375,0.824127197266,0.826507568359,0.470445632935,0.286455704366,15.0542602539,0.463898
+9573356.0,16.0,26.0,1.83361614653,284.0,407.0,123.0,317.265625,16.8525240946,20305.0,315.0,329.0,524.0,195.0,397.34375,30.9405774984,25430.0,389.5,271.0,772.0,501.0,344.703125,94.2661921912,22061.0,328.0,242.0,573.0,331.0,291.015625,56.6106472394,18625.0,277.5,-0.0127504551783,0.200622081757,0.213372536935,0.0781623172297,0.0494525894848,5.0023883027,0.0775698,893.0,1504.0,611.0,1005625.0,96.2567367772,64360.0,981.0,1.06872558594,6.83889770508,5.77017211914,2.27413749695,2.25176497839,145.544799805,1.15271
+9566316.0,11.7500000009,28.0,2.30427424652,233.0,363.0,130.0,273.170212766,26.8536769137,12839.0,268.0,263.0,427.0,164.0,309.872340426,36.3473883409,14564.0,308.0,297.0,613.0,316.0,412.893617021,71.8175092864,19406.0,401.0,135.0,413.0,278.0,228.936170213,64.381312293,10760.0,213.0,0.11627907306,0.425531923771,0.309252850711,0.295575449917,0.0684863730645,13.8920461461,0.311432,666.0,1132.0,466.0,811.978723404,108.875976555,38163.0,788.0,0.319183349609,0.464782714844,0.145599365234,0.409525769822,0.0324601356378,19.2477111816,0.412842
+9566663.0,7.0,18.0,1.91919256761,154.0,309.0,155.0,244.464285714,42.4343881294,6845.0,245.5,327.0,544.0,217.0,415.0,55.4842319943,11620.0,398.5,438.0,791.0,353.0,590.321428571,84.1075219888,16529.0,593.0,276.0,576.0,300.0,412.107142857,82.2762503858,11539.0,413.5,0.0950510576367,0.325654447079,0.230603389442,0.181765891878,0.0584712154367,5.08944497257,0.182564,813.0,1374.0,561.0,1071.57142857,151.453535678,30004.0,1062.0,0.412475585938,0.718566894531,0.306091308594,0.494293212891,0.0830103280784,13.8402099609,0.456192
+9554854.0,2.0,8.0,1.59576912161,278.0,342.0,64.0,309.25,23.4507462568,2474.0,305.0,386.0,497.0,111.0,438625.0,42.3022975144,3509.0,430.0,673.0,1017.0,344.0,843875.0,105.919117137,6751.0,863.5,403.0,579.0,176.0,482.75,65.9540559784,3862.0,458.5,0.231075704098,0.328928053379,0.0978523492813,0.27234262228,0.035792191187,2.17874097824,0.264605,1067.0,1418.0,351.0,1230625.0,131.424824044,9845.0,1193.5,0.0,0.00527954101562,0.00527954101562,0.00104141235352,0.00188780499395,0.00833129882812,0.0
+9553141.0,170.000000001,119.0,2.57464626303,282.0,675.0,393.0,350.502941176,33.0103369309,238342.0,350.0,396.0,1036.0,640.0,536.591176471,54.4617289676,364882.0,540.0,569.0,1596.0,1027.0,789.958823529,84.6200752069,537172.0,785.0,470.0,1614.0,1144.0,741.679411765,92.490270647,504342.0,749.0,-0.0227882042527,0.176843777299,0.199631981552,0.0323685116846,0.0291299667738,22.0105879455,0.0242636,1152.0,3325.0,2173.0,1628.77352941,177.699345904,1107566.0,1641.0,0.0,6.93197631836,6.93197631836,4.55252492568,1.60883328306,3095.71694946,4.04227
+9563394.0,3356.50000003,1855.0,9.03224389453,249.0,444.0,195.0,362.533517056,21.3432982097,4867375.0,364.0,378.0,704.0,326.0,567.039550127,38.5909617235,7613073.0,570.0,745.0,1265.0,520.0,992.244674512,65.4633619182,13321877.0,997.0,463.0,971.0,508.0,757.072918218,58.5770716355,10164461.0,762.0,0.0417827293277,0.277053833008,0.23527110368,0.134795433272,0.0222824130006,1809.76348712,0.130633,1090.0,2094.0,1004.0,1686.6459854,114.081943067,22644909.0,1696.0,-0.224243164062,0.919921875,1.14416503906,0.0337132931679,0.0831400902554,452.634674072,0.0
+9519475.0,10.25,17.0,1.49789736458,335.0,410.0,75.0,379.487804878,18.5092224227,15559.0,381.0,396.0,467.0,71.0,428.487804878,18.0758860407,17568.0,427.0,216.0,367.0,151.0,268.292682927,28.6852081389,11000.0,265.0,233.0,337.0,104.0,270.87804878,21.145483427,11106.0,269.0,-0.076320938766,0.0656934306026,0.142014369369,-0.00606772680653,0.0333320671523,-0.248776799068,-0.00390625,998.0,1214.0,216.0,1078.85365854,50.718525492,44233.0,1074.0,0.0,0.435485839844,0.435485839844,0.164529195646,0.131725767713,6.74569702148,0.182281
+9529926.0,4990.75000008,3837.0,15.3215943345,188.0,562.0,374.0,354.763412313,21.1822887131,7082142.0,355.0,333.0,835.0,502.0,556.497370135,36.0748556718,11109357.0,558.0,581.0,1166.0,585.0,951.332715524,63.6185967938,18991455.0,957.0,405.0,973.0,568.0,750.796423383,55.718063166,14988149.0,756.0,0.00913562905043,0.311475396156,0.302339767106,0.118037026565,0.0221980016639,2356.37316131,0.116511,977.0,2370.0,1393.0,1662.05720583,102.28660592,33179648.0,1671.0,-0.163330078125,3.7356262207,3.89895629883,0.189360222417,0.441627330066,3780.19812012,0.0
+9697847.0,26207.7499985,17518.0,30.5256360103,182.0,723.0,541.0,310.158102088,19.0314583704,32514184.0,309.0,212.0,1258.0,1046.0,447.237114976,32.2076202072,46884314.0,446.0,297.0,1598.0,1301.0,728.960116759,59.5320700794,76417618.0,734.0,143.0,1785.0,1642.0,599.932605813,54.8476841747,62891535.0,605.0,-0.0725959688425,0.478399991989,0.550995960832,0.0975284367813,0.0236284051475,10224.0035562,0.0963855,577.0,3644.0,3067.0,1357.32782288,96.9473156975,142290033.0,1360.0,-1.28674316406,7.13491821289,8.42166137695,0.412292433891,0.87849662167,43221.0281372,3.05176e-05
+9506068.0,4.75,12.0,1.55320760822,640.0,859.0,219.0,726.631578947,60.8537595831,13806.0,716.0,986.0,1373.0,387.0,1174.10526316,102.933240878,22308.0,1172.0,1290.0,1740.0,450.0,1473.10526316,132.925738958,27989.0,1423.0,1206.0,1808.0,602.0,1462.31578947,171.156146816,27784.0,1422.0,-0.0202205888927,0.056947607547,0.0771681964397,0.00504672440308,0.0210677760333,0.0958877636585,0.00317237,2875.0,4040.0,1165.0,3363.05263158,332.133846464,63898.0,3317.0,2.26324462891,2.83966064453,0.576416015625,2.5168762207,0.155069719808,47.8206481934,2.48465
+9508674.0,1072.49999999,625.0,5.38364525193,209.0,309.0,100.0,253.383682984,8.86093621642,1087016.0,253.0,275.0,445.0,170.0,356.082750583,15.1567999121,1527595.0,355.0,672.0,953.0,281.0,775.146620047,37.0689421833,3325379.0,773.0,233.0,521.0,288.0,367.506060606,25.0498912077,1576601.0,366.0,0.247524753213,0.489035099745,0.241510346532,0.356862088138,0.0304454064299,1530.93835811,0.354015,718.0,1275.0,557.0,976.972494172,46.0416066885,4191212.0,973.0,-0.117218017578,1.00396728516,1.12118530273,0.0612628643329,0.144370336047,262.817687988,0.0
+9482540.0,43.2500000016,37.0,1.58709796997,310.0,496.0,186.0,370.283236994,19.3503030383,64059.0,371.0,417.0,720.0,303.0,542.144508671,32.1601292742,93791.0,547.0,482.0,866.0,384.0,666.849710983,55.754835581,115365.0,654.0,458.0,925.0,467.0,644.531791908,55.6404162969,111504.0,633.0,-0.0329424887896,0.0758122727275,0.108754761517,0.0170853470877,0.0181074851837,2.95576504618,0.0156986,1185.0,2141.0,956.0,1556.95953757,96.563636712,269354.0,1550.0,-0.00784301757812,3.29052734375,3.29837036133,2.53647838438,0.867886014275,438.810760498,2.69589
+9449861.0,19.7500000007,32.0,2.03124119765,203.0,262.0,59.0,228.848101266,14.2323295794,18079.0,226.0,250.0,360.0,110.0,303.582278481,31.3310650204,23983.0,296.0,503.0,1048.0,545.0,851.025316456,143.228946113,67231.0,873.0,170.0,324.0,154.0,239.949367089,41.123432211,18956.0,235.0,0.308192461729,0.66568338871,0.357490926981,0.557102621356,0.0594822454516,44.0111070871,0.564374,635.0,939.0,304.0,772.379746835,81.850945696,61018.0,758.0,1.93939208984,2.68975830078,0.750366210938,2.62212864357,0.134168051363,207.148162842,2.65573
+9450413.0,787.250000001,378.0,3.80041070876,247.0,351.0,104.0,295.650682756,11.6012087366,931004.0,295.0,300.0,508.0,208.0,415.133058114,20.5101439452,1307254.0,414.0,499.0,955.0,456.0,745.767545252,47.5366978732,2348422.0,742.0,299.0,638.0,339.0,481.163543982,35.610961909,1515184.0,479.0,0.12018853426,0.311361670494,0.191173136234,0.215881457368,0.0231690679355,679.810709253,0.216641,846.0,1496.0,650.0,1191.94728485,66.0832141126,3753442.0,1186.0,-0.00473022460938,1.86267089844,1.86740112305,0.162186817352,0.166908192255,510.726287842,0.139709
+9424596.0,31.2499999981,30.0,1.51387951326,329.0,861.0,532.0,731528.0,88.9508247067,91441.0,763.0,719.0,1288.0,569.0,1112216.0,102.028433998,139027.0,1140.0,751.0,1630.0,879.0,1324.92,106.638424595,165615.0,1327.0,648.0,1684.0,1036.0,1315888.0,131.134997068,164486.0,1322.0,-0.0416849479079,0.0736240148544,0.115308962762,0.00444204662554,0.0162177187651,0.555255828192,0.00218978,1696.0,3588.0,1892.0,3159632.0,270.006534321,394954.0,3207.0,0.867919921875,4.17828369141,3.31036376953,3.02704785156,0.786180355433,378.380981445,3.08746
+9501125.0,40817.0000015,33277.0,46.4642245981,190.0,1129.0,939.0,365.491596639,28.1569913883,59673082.0,366.0,235.0,1859.0,1624.0,549.634704902,46.4320729017,89737759.0,551.0,342.0,2467.0,2125.0,944.521688267,83.0451772905,154210167.0,948.0,120.0,2782.0,2662.0,765.905952177,76.618668065,125047933.0,770.0,-0.0629820078611,0.480519473553,0.543501481414,0.104990085737,0.0276115932423,17141.5213182,0.101604,570.0,5770.0,5200.0,1681.03225372,141.451725639,274458774.0,1685.0,-0.0906677246094,4.62164306641,4.71231079102,0.287758042508,0.393805767117,46981.6800842,0.196136
+9420685.0,2175.24999998,1014.0,6.13307724135,212.0,413.0,201.0,299.042293989,15.7125308811,2601967.0,298.0,273.0,595.0,322.0,432.348235835,28.6348812469,3761862.0,430.0,404.0,1076.0,672.0,726.307091139,53.1658680187,6319598.0,725.0,278.0,832.0,554.0,597.02873233,42.8918569363,5194747.0,597.0,0.0153846153989,0.241007193923,0.225622578524,0.0976319736597,0.0183235967882,849.495802813,0.0956938,778.0,1789.0,1011.0,1328.41926215,81.9074117789,11558576.0,1325.0,-0.133636474609,11.5651855469,11.6988220215,0.287753804116,0.862831462168,2503.74584961,0.00149536
+9502250.0,1007.50000001,837.0,7.43871634799,170.0,366.0,196.0,233.294292804,17.4996842845,940176.0,231.0,214.0,501.0,287.0,290.130769231,34.6606236229,1169227.0,281.0,390.0,886.0,496.0,557.018114144,80.8854559978,2244783.0,548.0,176.0,530.0,354.0,280.109181141,53.6921746434,1128840.0,263.0,0.145454540849,0.582443654537,0.436989113688,0.332171400091,0.0621661790919,1338.65074237,0.332476,592.0,1327.0,735.0,803.534243176,99.3119915025,3238243.0,772.0,-1.54397583008,2.14978027344,3.69375610352,0.0368277878678,0.283676922287,148.415985107,0.0
+9360491.0,289.750000008,175.0,2.90015623394,335.0,451.0,116.0,407.706643658,15.1617183696,472532.0,409.0,522.0,729.0,207.0,654.187230371,24.7705670728,758203.0,654.0,972.0,1206.0,234.0,1118.91716997,35.1564241257,1296825.0,1118.0,688.0,977.0,289.0,880.979292494,36.5678008339,1021055.0,882.0,0.0922545641661,0.176541000605,0.0842864364386,0.119149351038,0.0113150800264,138.094097853,0.117675,1549.0,2157.0,608.0,1942.87316652,72.4518247932,2251790.0,1944.0,-0.137542724609,0.590606689453,0.728149414062,0.0431698131808,0.107471529896,50.0338134766,0.0
+9347153.0,352.500000004,240.0,3.60600852439,229.0,521.0,292.0,394.604964539,31.3616851349,556393.0,396.0,328.0,832.0,504.0,611.362411348,55.5000466922,862021.0,612.5,477.0,1152.0,675.0,841.264539007,78.666268452,1186183.0,844.0,319.0,1109.0,790.0,781.070212766,83.7207704849,1101309.0,785.0,-0.0690811499953,0.198492467403,0.267573617399,0.0379344862449,0.0217794273427,53.4876256053,0.0375213,876.0,2424.0,1548.0,1787.03758865,160.918853185,2519723.0,1793.0,-0.0297241210938,11.3561401367,11.3858642578,9.08839314779,3.29128117042,12814.6343384,10.2921
+9386752.0,2890.00000001,2070.0,10.862167413,211.0,361.0,150.0,284.329065744,17.7638445299,3286844.0,284.0,317.0,553.0,236.0,422.983217993,30.8293757706,4889686.0,423.0,761.0,1181.0,420.0,973.15233564,57.0674741297,11249641.0,974.0,271.0,657.0,386.0,464.020588235,50.1241789274,5364078.0,463.0,0.2436619699,0.501838207245,0.258176237345,0.355478094994,0.0374505330957,4109.32677813,0.353104,820.0,1556.0,736.0,1171.33287197,95.9518473836,13540608.0,1170.0,-0.082275390625,0.994049072266,1.07632446289,0.0343530674707,0.079108528603,397.121459961,0.0
+9351708.0,439.750000001,337.0,4.53337917003,210.0,290.0,80.0,253.802160318,11.946801537,446438.0,254.0,298.0,426.0,128.0,359.993746447,19.3411803436,633229.0,361.0,744.0,1083.0,339.0,916.637862422,47.7670484158,1612366.0,915.0,224.0,427.0,203.0,327.030699261,29.3968392356,575247.0,328.0,0.376451075077,0.596396386623,0.219945311546,0.474646647353,0.0286202476731,834.903452694,0.471698,753.0,1133.0,380.0,940.826606026,59.1142701766,1654914.0,943.0,-0.211761474609,0.970336914062,1.18209838867,0.0543874769878,0.141706217592,95.6675720215,0.0
+9321017.0,115.499999999,107.0,2.80858682053,290.0,585.0,295.0,391.448051948,48.0314708621,180849.0,393.0,411.0,852.0,441.0,576.108225108,66.9860841778,266162.0,581.5,569.0,913.0,344.0,734.54978355,57.5913419979,339362.0,732.0,463.0,952.0,489.0,688.547619048,68.8982632303,318109.0,698.5,-0.0744525566697,0.131200000644,0.205652557313,0.0332867377748,0.0390994783713,15.3784728519,0.0322339,1223.0,2389.0,1166.0,1656.1038961,166.380054511,765120.0,1673.0,0.119506835938,3.11071777344,2.9912109375,1.60645403181,0.859642641458,742.181762695,0.988449
+9310203.0,227.749999997,174.0,3.25248366033,240.0,342.0,102.0,297.030735456,13.8825692621,270595.0,297.0,318.0,513.0,195.0,432.749725576,25.5375777753,394235.0,433.0,651.0,1030.0,379.0,883.424807903,47.901524939,804800.0,883.0,346.0,634.0,288.0,507.48518112,40.227557303,462319.0,506.0,0.197513818741,0.423220962286,0.225707143545,0.270780386912,0.0315832317109,246.680932477,0.271739,943.0,1454.0,511.0,1237.26564215,75.1763365345,1127149.0,1237.0,-0.0395812988281,1.72311401367,1.7626953125,0.182892348188,0.237191123159,166.614929199,0.125336
+9360466.0,1888.00000006,1027.0,6.66752290957,227.0,412.0,185.0,312.444915254,18.9938907884,2359584.0,312.0,317.0,644.0,327.0,482.538400424,30.0467169444,3644130.0,482.0,740.0,1107.0,367.0,929.009401483,51.8078546614,7015879.0,930.0,420.0,812.0,392.0,654.696636653,48.5182180021,4944269.0,655.0,0.0964109748602,0.307994753122,0.211583778262,0.173708373557,0.022849081662,1311.84563711,0.169713,1015.0,1760.0,745.0,1449.67995233,89.8279763749,10947983.0,1449.5,-0.180908203125,1.72756958008,1.9084777832,0.0670352386216,0.229778130724,506.25012207,0.0
+9257285.0,25.2499999995,51.0,2.86308705162,235.0,400.0,165.0,313.891089109,28.222209143,31703.0,314.0,311.0,604.0,293.0,447.98019802,46.4214401213,45246.0,447.0,519.0,1038.0,519.0,774.178217822,85.0786934549,78192.0,778.0,338.0,808.0,470.0,578.138613861,80.955192313,58392.0,590.0,0.0808510631323,0.222094357014,0.141243293881,0.146858385736,0.0348549219359,14.8326969594,0.143065,884.0,1812.0,928.0,1340.00990099,147.929438294,135341.0,1347.0,0.100738525391,1.7477722168,1.64703369141,0.698491464747,0.45516433861,70.5476379395,0.704742
+9296527.0,513.250000002,356.0,4.43282500481,203.0,502.0,299.0,362.75888943,36.4558307256,744744.0,365.0,268.0,719.0,451.0,532.899659036,57.3648110253,1094043.0,541.0,414.0,995.0,581.0,693.027764247,85.2548210893,1422786.0,693.0,226.0,905.0,679.0,643.452995616,85.2879558815,1321009.0,642.0,-0.137785285711,0.300309598446,0.438094884157,0.0379464406756,0.045579352014,77.904042707,0.0247678,697.0,2074.0,1377.0,1539.11154408,161.426265187,3159796.0,1570.0,-0.0679931640625,3.69970703125,3.76770019531,1.60508171338,0.971383198995,3295.23275757,1.71771
+9333368.0,5025.25,3214.0,12.7897514384,191.0,796.0,605.0,311.000198995,23.1383816891,6251415.0,309.0,244.0,1189.0,945.0,449.358638874,38.4184162395,9032558.0,447.0,392.0,1625.0,1233.0,723.862593901,71.3542731106,14550362.0,723.0,186.0,1835.0,1649.0,599.759862693,65.4643916998,12055773.0,601.0,-0.070972584188,0.370558381081,0.441530965269,0.0942607214736,0.0272773409802,1894.73476234,0.091358,643.0,3780.0,3137.0,1360.11870056,118.7968097,27339746.0,1358.0,-0.333618164062,4.6926574707,5.02627563477,0.587639491491,1.09713305825,11812.1414185,0.000946045
+9199502.0,4824.99999997,967.0,3.92710834542,215.0,310.0,95.0,244.32880829,7.46214412571,4715546.0,244.0,272.0,425.0,153.0,318.495025907,14.1761905815,6146954.0,318.0,551.0,998.0,447.0,717.441658031,57.3029479149,13846624.0,709.0,202.0,505.0,303.0,300.937150259,24.3178720214,5808087.0,298.0,0.228041902184,0.566724419594,0.338682517409,0.408093643928,0.042821918069,7876.20732781,0.408644,689.0,1220.0,531.0,863.760984456,43.0347783331,16670587.0,860.0,-0.235198974609,2.76324462891,2.99844360352,0.165464623011,0.341541111536,3193.46722412,0.0
+9386191.0,8736.75000012,6753.0,20.380595213,201.0,729.0,528.0,382.985578161,20.5061770527,13384197.0,383.0,267.0,1159.0,892.0,590.960168255,36.1945342767,20652285.0,592.0,549.0,1386.0,837.0,992.551091653,59.0348925415,34686683.0,999.0,298.0,1462.0,1164.0,803.971270781,57.4316024928,28096384.0,809.0,-0.0401992164552,0.308443427086,0.348642643541,0.10534192417,0.0204000703974,3681.38422396,0.103814,766.0,3350.0,2584.0,1777.9170172,107.448356268,62132866.0,1784.0,-0.0586242675781,3.09039306641,3.14901733398,0.220884272635,0.219361199131,7719.24267578,0.171173
+9261165.0,3.25,12.0,1.87773643621,213.0,276.0,63.0,236.307692308,18.6150667487,3072.0,231.0,280.0,400.0,120.0,328.384615385,34.0102664625,4269.0,324.0,535.0,666.0,131.0,589.538461538,38.5578793397,7664.0,571.0,172.0,291.0,119.0,228.384615385,47.1993130027,2969.0,241.0,0.358708202839,0.532432436943,0.173724234104,0.447107484707,0.0648310729659,5.8123973012,0.408389,665.0,959.0,294.0,793.076923077,95.6375059502,10310.0,809.0,0.0023193359375,0.0413818359375,0.0390625,0.0239539513221,0.0117303012596,0.311401367188,0.0257568
+9261332.0,182.0,149.0,3.11562831738,245.0,621.0,376.0,386.042582418,35.4381848432,281039.0,378.0,338.0,904.0,566.0,551.46978022,48.1379276224,401470.0,550.0,473.0,1116.0,643.0,669.092032967,90.2847208316,487099.0,680.0,316.0,1215.0,899.0,641.998626374,91.1436720467,467375.0,643.5,-0.0494296588004,0.198986053467,0.248415712267,0.0209431626573,0.0289480416298,15.2466224145,0.015445,899.0,2740.0,1841.0,1579.51098901,151.033817951,1149884.0,1560.0,2.69448852539,5.2509765625,2.55648803711,3.77168340997,0.701452278811,2745.78552246,3.9752
+9231992.0,14.0,18.0,1.35707407896,219.0,273.0,54.0,247.589285714,10.599489182,13865.0,246.0,284.0,403.0,119.0,353.178571429,22.0349617839,19778.0,355.0,906.0,1314.0,408.0,1141.5,73.6221045999,63924.0,1145.0,207.0,348.0,141.0,290.017857143,29.0482917321,16241.0,292.5,0.547758281231,0.670571029186,0.122812747955,0.595151189182,0.0262492021671,33.3284665942,0.592494,710.0,1023.0,313.0,890.785714286,59.7296630918,49884.0,893.0,-0.0477600097656,0.981781005859,1.02954101562,0.523919241769,0.358482185012,29.3394775391,0.508606
+9218252.0,240.750000005,126.0,2.29077516003,201.0,333.0,132.0,237.231568017,15.0197986448,228454.0,237.0,226.0,366.0,140.0,303.238836968,22.3493704335,292019.0,304.0,548.0,1308.0,760.0,962.399792316,119.948020414,926791.0,950.0,128.0,359.0,231.0,259.358255452,34.6671669307,249762.0,261.0,0.452695816755,0.705413997173,0.252718180418,0.574331966021,0.0431380573606,553.081683278,0.575529,580.0,1036.0,456.0,799.828660436,68.5641245739,770235.0,802.0,0.997161865234,3.9817199707,2.98455810547,1.83298128788,0.750218887328,1765.16098022,1.48108
+9257463.0,2229.99999999,752.0,4.4922144144,240.0,379.0,139.0,313.28632287,18.8019019509,2794514.0,314.0,351.0,590.0,239.0,479.285089686,32.3074912819,4275223.0,480.0,787.0,1307.0,520.0,1044.0588565,50.427722219,9313005.0,1043.0,331.0,720.0,389.0,521.29293722,55.8420654434,4649933.0,523.0,0.184597954154,0.5,0.315402045846,0.335426042115,0.0396440596997,2992.00029567,0.332438,942.0,1682.0,740.0,1313.86434978,105.221253045,11719670.0,1317.0,-0.0793762207031,0.938354492188,1.01773071289,0.0429494951873,0.0981082312107,383.10949707,0.0
+9195983.0,3132.75,744.0,3.74977435183,237.0,520.0,283.0,343.066554944,15.3285995402,4298967.0,341.0,301.0,727.0,426.0,517.834570266,27.8452494601,6488985.0,514.0,546.0,1125.0,579.0,923.347218897,52.6077192167,11570464.0,919.0,379.0,908.0,529.0,718.612880057,45.1117509382,9004938.0,716.0,0.0391459092498,0.247813418508,0.208667509258,0.124834314459,0.0157737000161,1564.29879448,0.122653,951.0,2054.0,1103.0,1579.51400527,84.1040821347,19792890.0,1570.0,-0.135192871094,8.59390258789,8.72909545898,0.235330939816,0.355836155746,2948.93200684,0.15976
+9215680.0,1288.25,1172.0,9.21133557245,201.0,354.0,153.0,258.553075878,12.7911293199,1332324.0,259.0,270.0,527.0,257.0,372.231903745,22.6025398118,1918111.0,372.0,649.0,1251.0,602.0,896.952843004,52.4031113036,4621998.0,898.0,193.0,566.0,373.0,341.543760916,33.6667218869,1759975.0,341.0,0.282968848944,0.581798493862,0.298829644918,0.449255346506,0.0283245525384,2315.01280054,0.450443,676.0,1437.0,761.0,972.328740539,66.476496671,5010410.0,971.0,-0.390655517578,3.62844848633,4.01910400391,0.726286710639,0.992790045132,3742.55541992,0.0788574
+9250466.0,4481.25,2245.0,9.46045069889,202.0,1054.0,852.0,299.019079498,17.3324237635,5359917.0,300.0,261.0,1593.0,1332.0,426.576122734,28.4556503697,7646377.0,428.0,457.0,2150.0,1693.0,697.312914923,41.3176880411,12499334.0,701.0,306.0,2492.0,2186.0,592.848312413,41.7047379061,10626806.0,595.0,-0.0736751407385,0.197903007269,0.271578148007,0.0811935313441,0.0127941196543,1455.39404934,0.0804954,769.0,5139.0,4370.0,1318.44351464,82.6744842859,23633100.0,1321.0,-0.223480224609,2.70501708984,2.92849731445,0.136488086482,0.31108828054,2446.5489502,0.0
+9172079.0,610.25,476.0,5.43560796885,205.0,311.0,106.0,239.616960262,12.1672904511,584905.0,238.0,249.0,421.0,172.0,305.883244572,22.3419454274,746661.0,301.0,428.0,843.0,415.0,564.193363376,52.8362420017,1377196.0,560.0,192.0,482.0,290.0,284.610405571,39.9144337552,694734.0,275.0,0.182468697429,0.460701316595,0.278232619166,0.330558756247,0.0498735670052,806.893923998,0.334096,649.0,1202.0,553.0,830.110610406,72.4844306135,2026300.0,813.0,-0.417999267578,2.48348999023,2.90148925781,0.0655216403009,0.256485980642,159.938323975,0.0
+9163187.0,44.4999999984,73.0,3.08700919179,128.0,401.0,273.0,226.241573034,47.2081580004,40271.0,219.0,178.0,581.0,403.0,350.820224719,90.1610371761,62446.0,348.5,438.0,961.0,523.0,548.460674157,82.8908252035,97626.0,524.0,233.0,596.0,363.0,362.297752809,78.3130142262,64489.0,348.5,0.0928381979465,0.372353672981,0.279515475035,0.209454227825,0.0586891878367,37.2828525528,0.200219,644.0,1379.0,735.0,939.359550562,161.88001849,167206.0,887.0,-0.0421447753906,0.984619140625,1.02676391602,0.235614219408,0.261941988693,41.9393310547,0.186966
+9058340.0,9618.25,4974.0,14.3071397183,197.0,1228.0,1031.0,300.186364463,17.2447568324,11549070.0,300.0,216.0,1976.0,1760.0,410.405089283,28.531167932,15789515.0,410.0,328.0,2228.0,1900.0,559.272190887,43.9310403817,21516879.0,554.0,210.0,3102.0,2892.0,480.047695787,49.1279139793,18468875.0,477.0,-0.163977488875,0.300940424204,0.464917913079,0.0766965357485,0.0195676162935,2950.74581985,0.0745614,641.0,6306.0,5665.0,1190.63914953,91.5198600549,45807460.0,1188.0,-0.496124267578,4.07135009766,4.56747436523,0.292469117762,0.472073475189,11252.1643677,0.0620117
+9127257.0,124.749999999,74.0,1.86898798972,191.0,270.0,79.0,235.436873747,14.5532510897,117483.0,238.0,228.0,376.0,148.0,303.529058116,25.0731326578,151461.0,307.0,476.0,941.0,465.0,789.899799599,98.9269177224,394160.0,815.0,149.0,356.0,207.0,258.328657315,36.8776914768,128906.0,262.0,0.372677594423,0.662514150143,0.289836555719,0.506263991217,0.0487829017373,252.625731617,0.510698,581.0,1002.0,421.0,797.294589178,75.0554330268,397850.0,808.0,-0.0828857421875,2.99755859375,3.08044433594,1.89257775806,0.515957238348,944.39630127,1.98495
+9126547.0,5.00000000023,19.0,2.39697589586,196.0,248.0,52.0,220.45,13.7930235989,4409.0,220.0,255.0,334.0,79.0,290.1,23.449733474,5802.0,292.5,551.0,759.0,208.0,653.7,62.3378697102,13074.0,656.5,155.0,301.0,146.0,216.8,39.8454514343,4336.0,214.5,0.337733775377,0.618226587772,0.280492812395,0.503160010278,0.0706050373549,10.0632002056,0.516253,606.0,883.0,277.0,727.35,76.2392779347,14547.0,732.0,0.240081787109,0.891143798828,0.651062011719,0.557342529297,0.220965642639,11.1468505859,0.576065
+9146820.0,1133.50000002,1260.0,10.5573483284,228.0,279.0,51.0,250.50264667,5.70432837462,1135779.0,250.0,298.0,383.0,85.0,338.114689016,10.4192693474,1533012.0,338.0,720.0,943.0,223.0,827.569916189,29.841343949,3752202.0,826.0,234.0,368.0,134.0,305.143802382,15.142830064,1383522.0,305.0,0.380514711142,0.528301894665,0.147787183523,0.46127570992,0.0170498400645,2091.42406878,0.461538,760.0,1022.0,262.0,893.761138068,29.3723277512,4052313.0,893.0,-0.423431396484,1.57928466797,2.00271606445,0.186785670593,0.2767436423,846.886230469,0.00100708
+9122731.0,2160.5,587.0,3.5625095228,207.0,440.0,233.0,332.954177274,14.7367466776,2877390.0,332.0,269.0,690.0,421.0,496.826776209,27.4182669266,4293577.0,497.0,436.0,1024.0,588.0,834.381393196,57.0976266068,7210724.0,842.0,294.0,871.0,577.0,690.185952326,46.1764651189,5964587.0,695.0,0.0139082055539,0.254685789347,0.240777583793,0.0945206836801,0.0207776872982,816.847748363,0.0926289,775.0,1903.0,1128.0,1519.96690581,81.7595470187,13135554.0,1527.0,-0.010986328125,4.25830078125,4.26928710938,0.547571526112,0.938671118326,4732.11312866,0.206696
+9113771.0,175.249999999,82.0,1.747350011,353.0,629.0,276.0,533.041369472,45.603197705,373662.0,546.0,542.0,990.0,448.0,855.569186876,73.7712458281,599754.0,876.0,749.0,1393.0,644.0,1257.19686163,87.3671874305,881295.0,1279.0,592.0,1308.0,716.0,1108.89015692,86.2449696032,777332.0,1130.0,0.00644641416147,0.122312821448,0.115866407286,0.0629934102288,0.0139622327052,44.1583805704,0.0627615,1495.0,2912.0,1417.0,2497.50071327,200.741141927,1750748.0,2554.0,6.71362304688,11.908416748,5.19479370117,10.6837512137,1.10396628885,7489.30960083,11.0588
+9127021.0,482.250000018,484.0,6.21733561536,229.0,347.0,118.0,289.763608087,15.7268381996,558954.0,290.0,326.0,540.0,214.0,439.048729912,25.8819689943,846925.0,439.0,710.0,1125.0,415.0,959.370139969,42.7881790145,1850625.0,960.0,288.0,646.0,358.0,472.273716952,41.5777328391,911016.0,472.0,0.257844477892,0.457627117634,0.199782639742,0.34125355572,0.0266621346351,658.278108984,0.340845,843.0,1528.0,685.0,1201.08605495,81.2763071895,2316895.0,1200.0,-0.0601501464844,0.542114257812,0.602264404297,0.0419344904511,0.0880247007997,80.8916320801,0.0
+9111203.0,31.7500000009,36.0,1.80229427819,219.0,313.0,94.0,284.11023622,19.6381551912,36082.0,289.0,292.0,450.0,158.0,376.897637795,32.2873014812,47866.0,382.0,390.0,744.0,354.0,563.763779528,56.4903248204,71598.0,575.0,270.0,522.0,252.0,424.125984252,49.3719599285,53864.0,433.0,0.0885311886668,0.277139216661,0.188608027995,0.142299328439,0.0239565302364,18.0720147118,0.138584,800.0,1272.0,472.0,1085.13385827,99.7365318364,137812.0,1103.0,1.93121337891,2.94515991211,1.0139465332,2.02967365896,0.270205488701,257.768554688,1.94684
+9158469.0,1933.00000002,971.0,6.2301481038,182.0,440.0,258.0,284.28569581,18.872485419,2198097.0,283.0,218.0,618.0,400.0,404.021598551,33.3129072908,3123895.0,402.0,474.0,1173.0,699.0,907.84881014,71.262103608,7019487.0,910.0,140.0,729.0,589.0,413.255690636,63.3342199928,3195293.0,406.0,0.157071784139,0.652605473995,0.495533689857,0.376240490352,0.064095308224,2909.0914714,0.378442,555.0,1725.0,1170.0,1101.562985,112.923522691,8517285.0,1090.0,-0.0156555175781,9.07723999023,9.09289550781,0.250926085352,0.507691383898,1940.16049194,0.171082
+9103716.0,12.9999999977,30.0,2.34717054548,191.0,312.0,121.0,249.096153846,25.1734442002,12953.0,249.5,268.0,386.0,118.0,332.807692308,27.6829845417,17306.0,329.5,424.0,685.0,261.0,522.25,62.5231880062,27157.0,513.0,246.0,444.0,198.0,341.807692308,47.824212753,17774.0,336.5,0.13972055912,0.294243067503,0.154522508383,0.209827972433,0.0414936269343,10.9110545665,0.211969,705.0,1119.0,414.0,923.711538462,94.5963766867,48033.0,906.5,3.06558227539,3.98065185547,0.915069580078,3.6808988131,0.286310800459,191.406738281,3.77211
+9048674.0,167.499999999,71.0,1.54755470873,296.0,391.0,95.0,337.214925373,11.0102429072,225934.0,338.0,433.0,593.0,160.0,507.549253731,17.8011350731,340058.0,509.0,634.0,927.0,293.0,857.728358209,32.8281495788,574678.0,863.0,533.0,827.0,294.0,722.605970149,32.8588563704,484146.0,726.0,0.0401437990367,0.153958946466,0.11381514743,0.0856401101867,0.013726259424,57.3788738251,0.0855699,1286.0,1811.0,525.0,1567.37014925,56.5702337607,1050138.0,1573.5,-0.0390930175781,1.58670043945,1.62579345703,0.232816326084,0.285433779749,155.986938477,0.140564
+9049227.0,770.500000024,771.0,7.83543522185,188.0,730.0,542.0,341.864373783,41.5008944504,1053626.0,340.0,255.0,1159.0,904.0,508.423101882,65.3287455503,1566960.0,505.0,484.0,1644.0,1160.0,905.451979234,111.377061823,2790603.0,907.0,65.0,1644.0,1579.0,611.681051265,99.7078364622,1885201.0,611.0,0.0,0.763205826283,0.763205826283,0.19603236614,0.0521293731781,604.171752444,0.192204,669.0,3497.0,2828.0,1461.96852693,193.906715688,4505787.0,1459.0,-0.125579833984,1.71838378906,1.84396362305,0.0997234842052,0.208641253501,307.34777832,0.0
+8994929.0,164.000000001,112.0,2.46712507106,275.0,480.0,205.0,359.407012195,31.2913221369,235771.0,360.0,361.0,764.0,403.0,541.282012195,56.848198962,355081.0,541.0,520.0,962.0,442.0,764.467987805,83.3150548548,501491.0,770.0,380.0,920.0,540.0,691.832317073,89.5938460403,453842.0,688.5,-0.02620456554,0.201061710715,0.227266276255,0.0510167910825,0.042530808104,33.4670149501,0.044204,1016.0,2065.0,1049.0,1592.52134146,165.625402444,1044694.0,1588.5,0.499176025391,4.4850769043,3.98590087891,3.18183945446,0.473502823363,2087.28668213,3.11031
+8983240.0,24.7500000019,27.0,1.53098603933,344.0,436.0,92.0,387.717171717,22.3390044378,38384.0,387.0,498.0,681.0,183.0,586.636363636,43.8259769251,58077.0,582.0,659.0,877.0,218.0,757.151515152,54.321222602,74958.0,759.0,573.0,843.0,270.0,727.434343434,63.7121306205,72016.0,728.0,-0.0381011851132,0.108624093235,0.146725278348,0.0206527433039,0.033156070552,2.04462158709,0.0155844,1418.0,1933.0,515.0,1701.78787879,126.127422561,168477.0,1692.0,0.00308227539062,0.169494628906,0.166412353516,0.120361944642,0.0419053956567,11.9158325195,0.130432
+8969795.0,182.750000001,69.0,1.43984408266,319.0,524.0,205.0,482.785225718,26.2418844321,352916.0,490.0,455.0,809.0,354.0,748.945280438,47.2779395926,547479.0,763.0,565.0,1067.0,502.0,905.291381669,51.5883810674,661768.0,913.0,406.0,970.0,564.0,872.868673051,60.4599039852,638067.0,884.0,-0.0212290510535,0.163748711348,0.184977762401,0.0187969963442,0.0203850903047,13.7406043276,0.0159428,1180.0,2295.0,1115.0,2104.59917921,129.716820689,1538462.0,2135.0,1.00784301758,4.2907409668,3.28289794922,3.26172839372,0.456233600276,2384.32345581,3.27731
+8939523.0,162.250000004,124.0,2.74615091599,210.0,293.0,83.0,254.117103236,10.5998154005,164922.0,254.0,289.0,432.0,143.0,365.941448382,17.8013250246,237496.0,366.0,641.0,1131.0,490.0,963.500770416,58.8239682816,625312.0,963.0,217.0,425.0,208.0,331.508474576,29.0482888805,215149.0,331.0,0.374113470316,0.612321555614,0.238208085299,0.487850370089,0.0376514912959,316.614890188,0.485212,716.0,1150.0,434.0,951.567026194,56.0058236896,617567.0,952.0,-0.0825805664062,3.06350708008,3.14608764648,0.459367796159,0.909670038387,298.129699707,0.0
+8928853.0,141.500000004,136.0,3.22519335567,197.0,366.0,169.0,286.959363958,31.4593816691,162419.0,292.0,248.0,538.0,290.0,405.911660777,56.2054783844,229746.0,414.0,412.0,856.0,444.0,654.955830389,102.598069053,370705.0,668.0,205.0,661.0,456.0,468.765017668,100.025100625,265321.0,471.5,0.0523255802691,0.398826986551,0.346501406282,0.171587988254,0.0578074836138,97.1188013516,0.166023,659.0,1565.0,906.0,1161.6360424,184.390913219,657486.0,1180.5,-0.0289306640625,0.909454345703,0.938385009766,0.259952720399,0.302356347207,147.133239746,0.0704651
+8903756.0,345.000000007,151.0,2.29330843137,187.0,272.0,85.0,237.921014493,12.9975022846,328331.0,239.0,222.0,376.0,154.0,315.957971014,24.9458771,436022.0,318.0,587.0,1156.0,569.0,955.172463768,83.6721039588,1318138.0,969.0,111.0,361.0,250.0,262.193478261,37.430141126,361827.0,265.0,0.448154658079,0.725247502327,0.277092844248,0.570248946677,0.0398224710069,786.943546414,0.570408,520.0,997.0,477.0,816.072463768,74.1580605019,1126180.0,824.0,-0.0163879394531,14.1855163574,14.2019042969,6.32641833761,5.82165533885,8730.45730591,8.27371
+8932149.0,538.499999992,297.0,3.61042779115,191.0,703.0,512.0,384.230733519,52.9317473906,827633.0,377.0,210.0,1096.0,886.0,550.628133705,83.8050450632,1186053.0,553.0,315.0,1227.0,912.0,665.020427112,86.884476768,1432454.0,660.0,158.0,1423.0,1265.0,632.263231198,106.001606801,1361895.0,638.0,-0.164035692811,0.331923902035,0.495959594846,0.0283607745725,0.0455580872164,61.0891084293,0.0161757,639.0,3222.0,2583.0,1567.12209842,235.501890898,3375581.0,1574.0,0.617767333984,5.09396362305,4.47619628906,3.34070944897,0.826899796694,7195.88815308,3.17719
+8893240.0,49.4999999995,40.0,1.60380831164,263.0,1322.0,1059.0,391.323232323,110.313312134,77482.0,377.0,364.0,2190.0,1826.0,599.257575758,189.165229785,118653.0,582.5,534.0,2759.0,2225.0,809.590909091,233.78501589,160299.0,769.0,451.0,3191.0,2740.0,783.813131313,283.340963229,155195.0,759.5,-0.0726050436497,0.132450327277,0.205055370927,0.0210433131318,0.0427579307481,4.16657600011,0.00689478,1086.0,6703.0,5617.0,1774.39393939,581.445096606,351330.0,1717.5,0.107788085938,3.89825439453,3.79046630859,3.08845227174,0.771457410335,611.513549805,3.25832
+8888268.0,414.00000001,330.0,4.57518687117,215.0,576.0,361.0,323.003019324,33.9576407852,534893.0,316.0,281.0,865.0,584.0,459.567028986,57.5689072503,761043.0,449.0,426.0,1149.0,723.0,677.237318841,77.6911921441,1121505.0,670.0,276.0,1177.0,901.0,575.900362319,84.5072623576,953691.0,569.0,-0.0120378332213,0.220571428537,0.232609261759,0.0829420660418,0.0294575928985,137.352061365,0.0793778,772.0,2618.0,1846.0,1358.47041063,166.93138859,2249627.0,1333.0,-0.184417724609,3.93048095703,4.11489868164,1.07985738856,1.3319368118,1788.24383545,0.130829
+8912848.0,541.000000001,482.0,5.84579354895,187.0,349.0,162.0,257.67883549,13.7251168001,557617.0,257.0,219.0,508.0,289.0,351.219963031,24.223440947,760040.0,351.0,438.0,979.0,541.0,774.249075786,64.9677822478,1675475.0,776.0,148.0,579.0,431.0,339.530961183,40.3264459032,734745.0,338.0,0.160120844841,0.587044537067,0.426923692226,0.391145465066,0.0394976253948,846.438786402,0.393235,568.0,1436.0,868.0,948.429759704,76.5169460514,2052402.0,947.0,-0.270141601562,4.83474731445,5.10488891602,0.517438186956,1.26447051283,1119.73623657,0.0428772
+8862240.0,242.499999994,235.0,4.25703341178,197.0,318.0,121.0,243.301030928,12.9885000272,236002.0,244.0,265.0,443.0,178.0,347.844329897,22.3673061716,337409.0,349.0,827.0,1200.0,373.0,994.394845361,53.443232955,964563.0,994.0,193.0,413.0,220.0,299.089690722,29.4046983571,290117.0,303.0,0.464083939791,0.660510122776,0.196426182985,0.538225237365,0.0271836488119,522.078480244,0.537394,679.0,1154.0,475.0,890.235051546,62.5807223722,863528.0,896.0,-0.213317871094,1.09417724609,1.30749511719,0.0692233056137,0.163442907944,67.1466064453,0.0
+9076008.0,5490.24999976,3322.0,12.6473237472,216.0,734.0,518.0,307.722417012,15.8011870629,6757892.0,307.0,263.0,1150.0,887.0,443.869495925,25.40818357,9747818.0,444.0,415.0,1503.0,1088.0,741.067164519,41.910957853,16274576.0,744.0,239.0,1645.0,1406.0,596.774190611,40.0815452272,13105758.0,600.0,-0.0451080054045,0.28832629323,0.333434298635,0.108119085638,0.0165835244598,2374.4032397,0.108014,781.0,3529.0,2748.0,1348.36610355,74.0869091804,29611468.0,1350.0,-0.246124267578,6.31072998047,6.55685424805,0.269338763166,0.605286717943,5914.94857788,0.0
+8863547.0,7.75000000023,17.0,1.72263448938,183.0,311.0,128.0,217.064516129,35.08509056,6729.0,205.0,255.0,458.0,203.0,305.774193548,57.0781635425,9479.0,286.0,503.0,849.0,346.0,628.580645161,81.1894535474,19486.0,600.0,174.0,469.0,295.0,264.612903226,78.9318519538,8203.0,225.0,0.286407768726,0.533512055874,0.247104287148,0.417960240956,0.06743424027,12.9567674696,0.429306,625.0,1238.0,613.0,787.451612903,170.038674673,24411.0,710.0,0.110626220703,1.19641113281,1.08578491211,0.667689169607,0.346557393539,20.6983642578,0.723816
+8860691.0,995.749999986,676.0,6.04319497543,215.0,851.0,636.0,296.506151142,21.7897169515,1180984.0,295.0,262.0,1047.0,785.0,403.559628421,31.108516377,1607378.0,400.0,295.0,1218.0,923.0,561.604067286,51.4586740292,2236869.0,552.0,202.0,1306.0,1104.0,474.773537535,50.6058244469,1891023.0,466.0,-0.0439276471734,0.251798570156,0.29572621733,0.0842721390661,0.0211198960822,335.6559299,0.0825688,737.0,3204.0,2467.0,1174.8393171,97.7058731641,4679385.0,1161.0,-0.289093017578,8.17385864258,8.46295166016,0.419784672321,1.13763289106,1672.00234985,0.0
+8863492.0,876.500000008,754.0,7.18439916374,196.0,442.0,246.0,312.372789504,29.4803431862,1095179.0,315.0,257.0,699.0,442.0,443.141186537,54.8307126406,1553653.0,448.0,398.0,1275.0,877.0,774.193382772,110.176010309,2714322.0,786.5,193.0,893.0,700.0,521.889047347,93.6441112815,1829743.0,528.0,0.0290302652866,0.488859772682,0.459829507396,0.197471804217,0.0554335622322,692.336145585,0.192133,650.0,2034.0,1384.0,1277.40302339,175.421560155,4478575.0,1292.0,-0.0101928710938,3.43939208984,3.44958496094,0.39390711069,0.462459643992,1381.03833008,0.254639
+8863221.0,1793.50000001,1010.0,6.72768658471,202.0,415.0,213.0,303.799553945,18.2532740248,2179458.0,303.0,253.0,578.0,325.0,434.57499303,30.53184628,3117641.0,435.0,370.0,922.0,552.0,696.713409534,63.4857027494,4998222.0,709.0,203.0,746.0,543.0,560.598829105,55.8176037011,4021736.0,570.0,0.00964066572487,0.304207116365,0.294566450641,0.108756768215,0.0233321700396,780.221055177,0.104972,666.0,1690.0,1024.0,1298.97337608,94.485295861,9318835.0,1310.0,-0.222015380859,4.83441162109,5.05642700195,0.628188793394,1.16776161139,4506.62640381,0.023941
+8847687.0,9.25,14.0,1.29853074657,496.0,659.0,163.0,589.054054054,37.1104603495,21795.0,593.0,713.0,1006.0,293.0,885.459459459,61.5764058863,32762.0,892.0,979.0,1397.0,418.0,1204.72972973,98.4316606527,44575.0,1214.0,785.0,1322.0,537.0,1126.78378378,117.652979226,41691.0,1147.0,-0.0425867512822,0.109977327287,0.152564078569,0.0346631647365,0.0380322171637,1.28253709525,0.0471204,2048.0,2987.0,939.0,2601.2972973,206.874275028,96248.0,2629.0,1.39721679688,1.78210449219,0.384887695312,1.65041206978,0.104686857284,61.065246582,1.68494
+8805455.0,13.0,32.0,2.50364858162,222.0,353.0,131.0,293.057692308,32.4021684113,15239.0,300.0,258.0,517.0,259.0,402.346153846,60.1568093899,20922.0,420.5,498.0,773.0,275.0,635.461538462,80.9107916969,33044.0,644.0,227.0,654.0,427.0,457.230769231,103.093985385,23776.0,484.5,0.0618705041707,0.404980331659,0.343109827489,0.171776348653,0.0697848487641,8.93237012997,0.15426,721.0,1524.0,803.0,1152.63461538,191.331370708,59937.0,1208.0,0.0101318359375,0.520355224609,0.510223388672,0.0984051044171,0.130598675244,5.11706542969,0.02771
+8797357.0,119.0,59.0,1.52571564267,268.0,433.0,165.0,357.783613445,26.2345877998,170305.0,362.0,358.0,651.0,293.0,534.93487395,46.4901494286,254629.0,545.5,477.0,832.0,355.0,701.384453782,56.7944592249,333859.0,711.0,397.0,762.0,365.0,664.968487395,64.7533868442,316525.0,682.0,-0.0451977401972,0.187406301498,0.232604041696,0.0275113853083,0.0302046738402,13.0954194068,0.0250259,1023.0,1815.0,792.0,1557.68697479,130.926324455,741459.0,1595.0,1.84216308594,4.78909301758,2.94692993164,4.0008223718,0.465340381671,1904.39144897,4.04118
+8766383.0,14.5,19.0,1.40755271177,356.0,473.0,117.0,401.793103448,26.4436672692,23304.0,399.0,411.0,566.0,155.0,478.75862069,34.2154987793,27768.0,472.0,142.0,482.0,340.0,266.120689655,65.8752943031,15435.0,261.0,248.0,451.0,203.0,327.24137931,44.5731906221,18980.0,314.0,-0.378555804491,0.0519125685096,0.430468373001,-0.111934182617,0.103106242603,-6.49218259181,-0.110153,1016.0,1467.0,451.0,1207.79310345,99.604521193,70052.0,1186.5,0.304382324219,0.936157226562,0.631774902344,0.697910177297,0.129340215025,40.4787902832,0.716675
+8780363.0,2363.99999996,1237.0,7.17696835816,217.0,334.0,117.0,263.210025381,14.9718958716,2488914.0,259.0,298.0,504.0,206.0,375.030456853,27.815299895,3546288.0,367.0,610.0,1020.0,410.0,776.137373096,63.8311397244,7339155.0,770.0,223.0,526.0,303.0,362.372779188,37.9539541931,3426597.0,353.0,0.254163652658,0.525050103664,0.270886451006,0.363842131312,0.0304248854044,3440.49119368,0.364818,738.0,1364.0,626.0,1000.61326142,79.5641978508,9461799.0,979.0,-0.0703125,1.27725219727,1.34756469727,0.0969591544163,0.165055378577,916.84576416,0.0
+8743251.0,164.249999995,81.0,1.78290169458,312.0,450.0,138.0,397.503805175,21.2249759718,261160.0,402.0,427.0,619.0,192.0,553.00456621,29.0626517456,363324.0,559.0,452.0,787.0,335.0,622.474885845,39.9839358081,408966.0,617.0,387.0,728.0,341.0,577.97108067,35.9527944042,379727.0,577.0,-0.0647249221802,0.16336633265,0.22809125483,0.0370161901627,0.0315099570796,24.3196369369,0.0321517,1173.0,1762.0,589.0,1528.47945205,76.7759393258,1004211.0,1539.0,0.0938720703125,5.32641601562,5.23254394531,3.91086628303,0.529286738115,2569.43914795,3.96637
+8764086.0,3050.00000001,2282.0,11.6563019321,277.0,439.0,162.0,371.671967213,17.7658523366,4534398.0,373.0,438.0,697.0,259.0,582.522213115,28.6615781833,7106771.0,584.0,792.0,1205.0,413.0,1006.6847541,41.8755255061,12281554.0,1008.0,533.0,947.0,414.0,783.894344262,43.6868296259,9563511.0,786.0,0.0603955090046,0.251225501299,0.190829992294,0.124746119496,0.014702922838,1521.90265786,0.124058,1248.0,2061.0,813.0,1738.08852459,85.5512828628,21204680.0,1742.0,-0.142669677734,0.758880615234,0.901550292969,0.0497640891153,0.0985325532439,607.121887207,0.0
+8780060.0,1280.49999999,1017.0,8.01726482744,226.0,869.0,643.0,295.127489262,15.43090398,1511643.0,295.0,289.0,1399.0,1110.0,401.661460367,27.6778088643,2057310.0,401.0,356.0,1906.0,1550.0,571.590589613,56.1553433101,2927687.0,566.0,276.0,2166.0,1890.0,474.83814916,51.3066266541,2432121.0,472.0,-0.0638506859541,0.252723306417,0.316573992372,0.0924093553286,0.0249236874486,473.320717993,0.0912512,828.0,4434.0,3606.0,1171.62709879,92.0512689246,6001074.0,1167.0,-0.224426269531,8.04528808594,8.26971435547,0.172222031694,0.381308565675,882.121246338,0.0
+8827956.0,17855.5,6549.0,13.8256019927,232.0,374.0,142.0,287.077735152,15.4439907198,20503666.0,285.0,314.0,574.0,260.0,413.907731511,29.1139339914,29562118.0,410.0,532.0,994.0,462.0,703.293340987,63.0359980518,50230617.0,696.0,350.0,783.0,433.0,544.355954748,51.8481132033,38878991.0,539.0,0.0464904271066,0.354112565517,0.307622138411,0.127535775013,0.0277260340584,9108.86012296,0.122278,896.0,1690.0,794.0,1245.34142141,94.8201731898,88944775.0,1233.0,-0.137481689453,1.2451171875,1.38259887695,0.181722807365,0.170054416911,12979.0063477,0.148407
+8711432.0,63.4999999991,56.0,1.98242256463,236.0,420.0,184.0,339.559055118,38.7640050472,86248.0,343.5,292.0,527.0,235.0,402.385826772,49.8842040617,102206.0,400.5,205.0,872.0,667.0,406.917322835,155.332907209,103357.0,350.0,183.0,679.0,496.0,323.279527559,104.983297388,82113.0,283.0,-0.0171428564936,0.284815818071,0.301958674565,0.104667362821,0.0677534852043,26.5855101565,0.106335,753.0,1575.0,822.0,1065.22440945,158.32459691,270567.0,1035.5,2.09350585938,3.67858886719,1.58508300781,2.92012240192,0.402657719898,741.711090088,3.0253
+8782491.0,6070.75,2990.0,10.8254281541,181.0,311.0,130.0,238.65654985,10.0449789947,5795297.0,239.0,220.0,469.0,249.0,342.118766215,20.4614632197,8307670.0,344.0,554.0,1201.0,647.0,890.398591607,73.2531035098,21621549.0,884.0,131.0,465.0,334.0,286.420994111,26.9970761206,6955161.0,288.0,0.345951616764,0.720807731152,0.374856114388,0.512666863387,0.0381717249916,12449.0894436,0.509077,536.0,1235.0,699.0,867.196310176,55.836271493,21058128.0,871.0,-0.281280517578,5.91888427734,6.20016479492,0.334896754193,0.648912309829,8132.29788208,0.056366
+8762829.0,5111.74999996,2350.0,9.2721004391,203.0,344.0,141.0,249.032131853,7.11062283333,5091960.0,249.0,265.0,499.0,234.0,351.042108867,11.999809963,7177758.0,350.0,614.0,1050.0,436.0,778.951924488,39.3995015072,15927230.0,775.0,187.0,558.0,371.0,322.895143542,20.1463821767,6602237.0,322.0,0.277856141329,0.558758318424,0.280902177095,0.413743361865,0.0291431702083,8459.81052005,0.414503,655.0,1395.0,740.0,922.969384262,37.9635847495,18871955.0,921.0,-0.196868896484,1.50765991211,1.70452880859,0.157822191835,0.237863317347,3226.99035645,0.0231323
+8692373.0,1195.00000002,245.0,1.99929647239,252.0,385.0,133.0,324.965062762,16.3081413395,1553333.0,329.0,323.0,553.0,230.0,460.090167364,26.0024787114,2199231.0,464.0,420.0,885.0,465.0,666.391631799,48.1928762277,3185352.0,657.0,339.0,693.0,354.0,551.380753138,35.5758516345,2635600.0,550.0,-0.00854700896889,0.232227489352,0.240774498321,0.0941686431368,0.0213807798306,450.126114194,0.0887967,914.0,1618.0,704.0,1336.43598326,65.8780180779,6388164.0,1342.0,-0.126586914062,1.61346435547,1.74005126953,0.0675158704175,0.16837828972,322.725860596,0.0
+8705457.0,20.2500000007,25.0,1.56719328761,362.0,431.0,69.0,393.765432099,16.4198551932,31895.0,394.0,513.0,667.0,154.0,588.703703704,34.5348077922,47685.0,587.0,595.0,830.0,235.0,702.185185185,52.9409433636,56877.0,708.0,582.0,804.0,222.0,704.617283951,56.0666640026,57074.0,711.0,-0.0286475680768,0.0396419428289,0.0682895109057,-0.00153231903635,0.0139239880628,-0.124117841944,0.0,1479.0,1880.0,401.0,1687.08641975,98.1617709313,136654.0,1687.0,0.000732421875,0.914672851562,0.913940429688,0.433447567033,0.260531751966,35.1092529297,0.367493
+8675250.0,760.999999917,559.0,5.71629387127,235.0,773.0,538.0,300.305190539,19.9862919349,914129.0,300.0,292.0,1234.0,942.0,411.067017083,33.480643046,1251288.0,410.0,372.0,1704.0,1332.0,559.968791064,48.1144060482,1704545.0,556.0,275.0,1914.0,1639.0,488.24868594,56.8424545003,1486229.0,486.0,-0.0580431185663,0.166281759739,0.224324878305,0.0691938923541,0.0163804311363,210.626208326,0.0674264,802.0,3921.0,3119.0,1199.62089356,108.359164109,3651646.0,1197.0,-0.539581298828,5.30816650391,5.84774780273,0.09851007048,0.359948780413,299.864654541,0.0
+8699660.0,42.4999999998,35.0,1.51449780179,348.0,473.0,125.0,412.670588235,29.3896293175,70154.0,409.5,491.0,635.0,144.0,553.911764706,34.2688056118,94165.0,548.0,165.0,629.0,464.0,305.441176471,90.9962478788,51925.0,276.5,268.0,551.0,283.0,384.0,72.4142494915,65280.0,392.0,-0.345955252647,0.107927411795,0.453882664442,-0.122998198905,0.0939235994607,-20.9096938139,-0.126731,1179.0,1558.0,379.0,1350.58235294,101.089457967,229599.0,1360.0,-3.0517578125e-05,1.88507080078,1.88510131836,0.509046846278,0.773428755089,86.5379638672,-3.05176e-05
+8706325.0,11.5,29.0,2.41237125937,212.0,309.0,97.0,251.934782609,28.5332774249,11589.0,248.5,250.0,436.0,186.0,324.913043478,51.3397998366,14946.0,325.0,409.0,754.0,345.0,547.434782609,89.0153020978,25182.0,562.5,243.0,592.0,349.0,379.02173913,91.7466950312,17435.0,375.5,0.0731292515993,0.276169270277,0.203040018678,0.189031535355,0.0536431543374,8.69545062631,0.19171,705.0,1337.0,632.0,955.869565217,169.522681398,43970.0,949.5,0.0210571289062,1.38827514648,1.36721801758,0.377102395763,0.465603121944,17.3467102051,0.0757446
+8664073.0,174.750000005,96.0,2.04860254926,271.0,468.0,197.0,346.811158798,21.2815808571,242421.0,346.0,380.0,653.0,273.0,543.6981402,34.2027805423,380045.0,548.0,564.0,928.0,364.0,824.344778255,53.666056765,576217.0,838.0,479.0,908.0,429.0,791.719599428,63.7158283572,553412.0,808.0,-0.0332155488431,0.114195585251,0.147411134094,0.0208220621663,0.020066855701,14.5546214543,0.0185963,1164.0,1896.0,732.0,1682.22889843,107.093259375,1175878.0,1706.0,2.94683837891,4.03421020508,1.08737182617,3.39350618245,0.22288909348,2372.06082153,3.36163
+8725500.0,2147.50000004,1482.0,9.02145704033,212.0,550.0,338.0,324.303376019,14.0412389552,2785766.0,323.0,327.0,841.0,514.0,483.205937136,23.5667696268,4150739.0,482.0,564.0,1339.0,775.0,882.985681024,37.2437792991,7584847.0,884.0,363.0,1258.0,895.0,728.575436554,35.1333607901,6258463.0,730.0,0.0109780440107,0.251546382904,0.240568338893,0.0959478591352,0.0121834548878,824.192109971,0.0953846,902.0,2649.0,1747.0,1536.08474971,65.7654776926,13194968.0,1535.0,-0.280517578125,1.79357910156,2.07409667969,0.10494387963,0.22257241713,901.467926025,0.0
+8654694.0,1390.25000002,1094.0,8.27686626588,211.0,607.0,396.0,310.100521489,29.8866311086,1724469.0,304.0,272.0,950.0,678.0,424.823233231,48.8682326344,2362442.0,414.0,343.0,1204.0,861.0,584.732781874,74.2298380506,3251699.0,572.0,194.0,1328.0,1134.0,497.945693221,68.5523747828,2769076.0,486.0,-0.0489731431007,0.340136051178,0.389109194279,0.0807702236323,0.0347620371962,449.163213619,0.0800386,682.0,2885.0,2203.0,1232.86944794,138.045153932,6855987.0,1204.0,-0.126434326172,4.2712097168,4.39764404297,1.14799041556,1.33221404499,6383.97470093,0.230347
+8617130.0,837.499999989,371.0,3.61640090916,200.0,339.0,139.0,253.444776119,15.2076501132,849040.0,251.0,276.0,484.0,208.0,353.686567164,25.606639155,1184850.0,350.0,692.0,1149.0,457.0,920.046268657,74.0165931948,3082155.0,919.0,204.0,569.0,365.0,317.349552239,43.4368083622,1063121.0,309.0,0.235494881868,0.653815865517,0.418320983648,0.48656117171,0.0636620101756,1629.97992523,0.490816,695.0,1341.0,646.0,924.480895522,79.8936873402,3097011.0,911.0,-0.145355224609,1.33575439453,1.48110961914,0.0769381395027,0.189660522832,257.742767334,0.0
+8627831.0,240.75,175.0,3.18163216674,248.0,541.0,293.0,361.508826584,33.4617258608,348133.0,367.0,356.0,749.0,393.0,532.787123572,55.6973478634,513074.0,544.0,536.0,1047.0,511.0,729.338525441,67.0595869676,702353.0,743.0,381.0,1043.0,662.0,681.442367601,79.9027547031,656229.0,685.0,-0.0788690447807,0.17887930572,0.257748350501,0.035291262641,0.0422111762489,33.9854859232,0.0233766,1080.0,2327.0,1247.0,1575.73831776,156.135215969,1517436.0,1591.0,-0.0508117675781,4.61199951172,4.6628112793,3.20762436214,0.76063673032,3088.94226074,3.44199
+8610544.0,801.749999995,341.0,3.39726920708,243.0,550.0,307.0,365.618023075,30.473639118,1172537.0,361.0,308.0,848.0,540.0,542.49703773,49.4061450873,1739788.0,544.0,458.0,1180.0,722.0,733.208917992,73.4694530511,2351401.0,736.0,265.0,1021.0,756.0,666.685063923,75.3561213907,2138059.0,687.0,-0.0940819457173,0.298941791058,0.393023736775,0.048444661829,0.0407515827011,155.362030486,0.038681,831.0,2243.0,1412.0,1574.80012473,141.252050745,5050384.0,1595.0,-0.406463623047,10.7777099609,11.184173584,3.59600079271,2.7928797968,11532.3745422,5.03113
+8588117.0,36.0000000014,63.0,2.96199531357,192.0,369.0,177.0,261.576388889,28.6563886277,37667.0,256.5,240.0,508.0,268.0,316.138888889,48.4006156858,45524.0,304.5,309.0,1028.0,719.0,543.361111111,182.680945728,78244.0,487.0,155.0,622.0,467.0,280.694444444,86.3224154758,40420.0,250.5,0.148606806993,0.532467544079,0.383860737085,0.309096808649,0.0932586103078,44.5099404454,0.32255,599.0,1499.0,900.0,858.409722222,160.239552147,123611.0,813.0,3.79684448242,7.44592285156,3.64907836914,4.8753083547,1.0859771821,702.044403076,4.21037
+8585908.0,6.0,14.0,1.61230603087,265.0,294.0,29.0,277375.0,8.23515077781,6657.0,276.5,336.0,379.0,43.0,352375.0,12.3180507792,8457.0,353.0,486.0,568.0,82.0,525.0,27.3053718769,12600.0,529.5,340.0,424.0,84.0,373125.0,22.7363741246,8955.0,374.5,0.138211384416,0.193370163441,0.0551587790251,0.169304326798,0.013702798286,4.06330384314,0.171992,946.0,1097.0,151.0,1002875.0,42.2367459487,24069.0,1002.5,-0.00628662109375,0.221893310547,0.228179931641,0.0532353719076,0.0756856327996,1.27764892578,0.0
+8583359.0,450.249999992,417.0,5.54375797868,211.0,512.0,301.0,303.992226541,17.9405194545,547490.0,303.0,293.0,755.0,462.0,416.443642421,29.5756638867,750015.0,414.0,331.0,968.0,637.0,576.148250972,50.0934796172,1037643.0,570.0,200.0,976.0,776.0,485.776235425,49.1622816855,874883.0,482.0,-0.00411522621289,0.277580082417,0.281695308629,0.0858496465019,0.026572830662,154.61521335,0.0793951,771.0,2243.0,1472.0,1206.21210439,92.4177890776,2172388.0,1200.0,-0.112548828125,7.64239501953,7.75494384766,1.4319147918,1.31264475799,2578.87854004,1.87497
+8691475.0,2742.50000033,1586.0,8.54328575451,201.0,535.0,334.0,300.474020055,15.0962185818,3296200.0,298.0,246.0,868.0,622.0,421.956973564,25.9845611751,4628868.0,418.0,409.0,1218.0,809.0,650.842570647,54.7589040054,7139743.0,651.0,240.0,1271.0,1031.0,549.987784868,46.8676080656,6033366.0,549.0,-0.0212936922908,0.27953889966,0.300832591951,0.0840065686883,0.0193783760616,921.552058511,0.0821291,690.0,2674.0,1984.0,1272.41877849,80.842963191,13958434.0,1266.0,-0.279724121094,4.98913574219,5.26885986328,0.246119638476,0.560757886338,2699.93243408,0.0
+8557468.0,358.249999995,457.0,6.81111430182,203.0,505.0,302.0,290.427773901,36.5407244882,416183.0,292.0,252.0,711.0,459.0,404.411723657,63.0447236719,579522.0,410.0,353.0,1011.0,658.0,699.988834613,141.858828771,1003084.0,714.0,149.0,833.0,684.0,451.055826936,110.256845143,646363.0,459.0,-0.0440165065229,0.542277336121,0.586293842643,0.220002958199,0.0783410704512,315.264239099,0.220285,632.0,2049.0,1417.0,1145.89532449,205.480571798,1642068.0,1163.0,-0.014892578125,4.91101074219,4.92590332031,1.53290088811,1.29328973107,2196.64697266,1.21039
+8553725.0,952.249999995,657.0,6.00599473131,197.0,286.0,89.0,242.001050144,8.7938974371,921782.0,241.0,256.0,437.0,181.0,341.604095563,17.0229330908,1301170.0,340.0,661.0,1019.0,358.0,817.627986348,55.7284179315,3114345.0,811.0,177.0,471.0,294.0,315.839327908,24.3259872185,1203032.0,314.0,0.330014228821,0.596810936928,0.266796708107,0.442563732267,0.0273173008129,1685.7252562,0.441984,630.0,1176.0,546.0,899.444473615,48.228128217,3425984.0,895.0,-0.283630371094,1.28753662109,1.57116699219,0.120933078036,0.232968219164,460.634094238,0.0
+8505487.0,10.7500000005,30.0,2.58114314657,204.0,263.0,59.0,230.348837209,14.8384850366,9905.0,225.0,249.0,351.0,102.0,290.534883721,25.8009814463,12493.0,280.0,391.0,640.0,249.0,492.255813953,52.1692652204,21167.0,487.0,198.0,390.0,192.0,281.441860465,48.7887245483,12102.0,262.0,0.17285259068,0.411589890718,0.238737300038,0.275508753782,0.0617617422971,11.8468764126,0.267423,651.0,1002.0,351.0,802.325581395,87.590676187,34500.0,779.0,-0.0508117675781,2.9274597168,2.97827148438,0.34895644077,0.806952113893,15.0051269531,-3.05176e-05
+8459634.0,64.7499999993,56.0,1.96319395726,374.0,528.0,154.0,443.023166023,31.1355152961,114743.0,445.0,536.0,747.0,211.0,650.768339768,43.5619693682,168549.0,658.0,609.0,934.0,325.0,775.223938224,69.8000733364,200783.0,777.0,535.0,835.0,300.0,723.915057915,60.0794882501,187494.0,742.0,-0.0410256423056,0.111395649612,0.152421291918,0.0339831689617,0.0316208483703,8.80164076108,0.0340909,1451.0,2106.0,655.0,1817.70656371,125.875615796,470786.0,1844.0,0.0,3.91806030273,3.91806030273,2.61487393766,1.15919694118,677.252349854,3.12546
+8458064.0,30.5000000028,36.0,1.83885569473,262.0,421.0,159.0,372.844262295,28.8935356352,45487.0,375.5,345.0,623.0,278.0,553.213114754,49.5572577451,67492.0,561.0,645.0,931.0,286.0,745.213114754,48.5037144949,90916.0,735.5,492.0,847.0,355.0,710.196721311,54.2082564857,86644.0,717.0,-0.0416666679084,0.213429257274,0.255095925182,0.0245018926755,0.0416422600956,2.98923090642,0.0198533,1165.0,1864.0,699.0,1636.25409836,114.520208073,199623.0,1658.5,0.928100585938,2.14398193359,1.21588134766,1.36844847632,0.396820560092,166.950714111,1.0939
+8449826.0,116.999999994,139.0,3.62507450889,204.0,438.0,234.0,351.35042735,20.6893243206,164432.0,352.5,285.0,618.0,333.0,538.301282051,33.2885763378,251925.0,543.5,639.0,1161.0,522.0,986.467948718,62.4015895184,461667.0,993.0,357.0,935.0,578.0,801.972222222,62.498728857,375323.0,811.5,0.0399556048214,0.283132523298,0.243176918477,0.103798147386,0.0261552614044,48.5775329769,0.0987868,846.0,1927.0,1081.0,1691.62393162,110.549673756,791680.0,1707.5,-0.0133056640625,1.11145019531,1.12475585938,0.350522228795,0.239202348959,164.044403076,0.347626
+8500377.0,569.749999993,269.0,3.17910726169,243.0,456.0,213.0,357.084686266,19.5768605468,813796.0,357.0,329.0,714.0,385.0,556.089074155,41.6572704114,1267327.0,563.0,501.0,1043.0,542.0,824.31548925,52.3025179554,1878615.0,824.0,349.0,1007.0,658.0,766.397103993,61.8086532667,1746619.0,778.0,-0.0678098201752,0.178823530674,0.246633350849,0.0371012950977,0.0253685016793,84.5538515277,0.0287141,921.0,2132.0,1211.0,1679.57086441,116.197352028,3827742.0,1698.0,-0.222686767578,12.3995361328,12.6222229004,9.941764239,2.59977019033,22657.2807007,10.6457
+8447527.0,1192.50000002,925.0,7.55627242136,275.0,447.0,172.0,379.106289308,16.7910148137,1808337.0,380.0,402.0,704.0,302.0,584.40230608,29.4289784831,2787599.0,587.0,798.0,1181.0,383.0,1006.70314465,44.0309012246,4801974.0,1009.0,510.0,903.0,393.0,773.880503145,44.4837800199,3691410.0,779.0,0.0758540853858,0.251533746719,0.175679661334,0.131069903877,0.0202261506545,625.203441493,0.126904,1200.0,1994.0,794.0,1737.38909853,86.2543601221,8287346.0,1745.0,-0.174072265625,1.82385253906,1.99792480469,0.0786246181784,0.14947392349,375.039428711,0.0
+8447406.0,49.5000000007,42.0,1.68399872721,287.0,468.0,181.0,400.767676768,31.5273901385,79352.0,410.0,407.0,700.0,293.0,587.075757576,48.2669274037,116241.0,599.5,475.0,875.0,400.0,732.585858586,69.2492949461,145052.0,743.5,442.0,817.0,375.0,699.944444444,75.7179237981,138589.0,718.0,-0.0293367356062,0.109615385532,0.138952121139,0.0236128732504,0.0228486577913,4.67534890358,0.0216068,1136.0,1906.0,770.0,1687.78787879,143.610955431,334182.0,1728.0,-9.1552734375e-05,4.17138671875,4.17147827148,2.85749323681,1.35824473304,565.783660889,3.50703
+8441476.0,2.5,7.0,1.24888688131,204.0,226.0,22.0,211.9,6.96347614342,2119.0,210.5,266.0,323.0,57.0,290.5,19.0905735901,2905.0,288.0,463.0,647.0,184.0,544.4,52.5551139281,5444.0,544.0,210.0,279.0,69.0,237.9,24.1513974751,2379.0,233.0,0.341288775206,0.428201824427,0.086913049221,0.391644090414,0.0263200197214,3.91644090414,0.392949,682.0,828.0,146.0,740.3,49.9180328138,7403.0,731.5,4.00024414062,4.13162231445,0.131378173828,4.03378295898,0.0427579520774,40.3378295898,4.01205
+8428940.0,62.7500000007,56.0,1.99423452155,184.0,289.0,105.0,251.585657371,12.3451215209,63148.0,253.0,258.0,426.0,168.0,362.832669323,20.1495377851,91071.0,366.0,655.0,1130.0,475.0,998.709163347,65.7450032617,250676.0,1010.0,205.0,413.0,208.0,326.199203187,30.9430810087,81876.0,330.0,0.423574149609,0.603007495403,0.179433345795,0.507577997161,0.0364216456852,127.402077287,0.508853,647.0,1123.0,476.0,940.61752988,60.6381496313,236095.0,949.0,0.00823974609375,2.59887695312,2.59063720703,1.51865511586,0.397495383723,381.182434082,1.58578
+8469126.0,5533.75,2300.0,8.72194083878,212.0,391.0,179.0,266.078427829,10.4281764783,5889646.0,265.0,286.0,558.0,272.0,344.241698667,18.8322914887,7619790.0,342.0,496.0,903.0,407.0,642.186130562,38.2088426985,14214790.0,639.0,276.0,742.0,466.0,382.692297267,31.3989069752,8470894.0,380.0,0.0978723391891,0.378403753042,0.280531413853,0.2537260395,0.0262670335365,5616.22588433,0.255489,794.0,1691.0,897.0,993.012423763,58.9728768763,21980330.0,986.0,-0.0406494140625,1.82153320312,1.86218261719,0.493913507214,0.315543915584,10932.7754822,0.464844
+8381375.0,20.7499999981,34.0,2.10554697258,282.0,419.0,137.0,335.084337349,27.3183837741,27812.0,332.0,411.0,570.0,159.0,480.204819277,26.9800278815,39857.0,481.0,847.0,1079.0,232.0,944.43373494,52.5540898116,78388.0,943.0,560.0,773.0,213.0,700.831325301,45.3372421388,58169.0,712.0,0.0901126414537,0.261237770319,0.171125128865,0.148141210787,0.0405814051011,12.2957204953,0.138686,1260.0,1761.0,501.0,1516.12048193,89.1151140738,125838.0,1522.0,2.38146972656,3.46615600586,1.0846862793,3.13483769061,0.18732927475,260.19152832,3.15921
+8372575.0,6.0,14.0,1.61230603087,273.0,336.0,63.0,305.291666667,14.6015957081,7327.0,306.0,292.0,353.0,61.0,321.083333333,16.906400826,7706.0,321.5,271.0,378.0,107.0,320.791666667,28.1291354984,7699.0,325.0,182.0,269.0,87.0,226.166666667,17.8784476085,5428.0,229.0,0.118908382952,0.262103497982,0.14319511503,0.17239559597,0.0403364406663,4.13749430329,0.162076,767.0,926.0,159.0,852.541666667,38.145531812,20461.0,859.5,2.68292236328,3.33905029297,0.656127929688,2.96352513631,0.240369237798,71.1246032715,2.82921
+8363040.0,549.249999996,391.0,4.70637786258,224.0,391.0,167.0,274.948111061,15.7743545531,604061.0,273.0,264.0,559.0,295.0,363.792444242,28.9541988749,799252.0,359.0,467.0,973.0,506.0,710.553026855,54.4109979795,1561085.0,711.0,254.0,730.0,476.0,397.463359126,44.5429441511,873227.0,395.0,0.137962132692,0.43153527379,0.293573141098,0.283398724926,0.0457668091071,622.626998663,0.280855,773.0,1680.0,907.0,1036.20391443,84.6167311521,2276540.0,1024.0,-0.0508117675781,2.31539916992,2.3662109375,0.315048321953,0.231926257401,692.16116333,0.275757
+8366927.0,18.25,29.0,1.91496848674,291.0,466.0,175.0,388.315068493,33.0242238665,28347.0,387.0,384.0,595.0,211.0,468.602739726,39.0748280134,34208.0,463.0,274.0,707.0,433.0,445.315068493,107.475499178,32508.0,431.0,228.0,477.0,249.0,296.97260274,53.9149438208,21679.0,282.0,0.0170542635024,0.37305700779,0.356002744287,0.191727093663,0.0842617822175,13.9960778374,0.194257,917.0,1521.0,604.0,1153.89041096,112.025628384,84234.0,1131.0,2.20230102539,4.11251831055,1.91021728516,2.45995508481,0.443200419787,179.576721191,2.2702
+8361848.0,20.4999999995,39.0,2.42986835159,274.0,396.0,122.0,356.024390244,22.7081029965,29194.0,359.0,333.0,488.0,155.0,428.158536585,27.8267591481,35109.0,429.0,179.0,314.0,135.0,241.341463415,30.759182453,19790.0,240.0,196.0,329.0,133.0,262.12195122,31.7068855505,21494.0,270.0,-0.14688128233,0.0459965914488,0.192877873778,-0.0414574532287,0.0395881885352,-3.39951116475,-0.0402015,883.0,1172.0,289.0,1046.30487805,58.1391705044,85797.0,1047.0,-0.109680175781,0.962615966797,1.07229614258,0.355177344345,0.331876335242,29.1245422363,0.439636
+8337285.0,441.499999986,477.0,6.40395236891,200.0,488.0,288.0,315.848810872,27.8837644861,557789.0,315.0,230.0,745.0,515.0,447.990373726,47.2418108835,791151.0,447.0,346.0,1174.0,828.0,731.859569649,92.6502366405,1292464.0,727.0,193.0,1046.0,853.0,575.759343148,83.3904524846,1016791.0,579.0,-0.0175619833171,0.344881892204,0.362443875521,0.12056578893,0.0463313452951,212.91918325,0.11851,623.0,2259.0,1636.0,1339.59852775,151.397776486,2365731.0,1343.0,-0.0172119140625,5.42791748047,5.44512939453,0.806231921013,1.21682599235,1423.80557251,0.31192
+8329686.0,12.25,19.0,1.53137172677,291.0,400.0,109.0,364.918367347,17.3685579568,17881.0,367.0,359.0,488.0,129.0,422.857142857,26.2149669043,20720.0,417.0,152.0,333.0,181.0,217.06122449,38.6778469333,10636.0,208.0,247.0,440.0,193.0,311.918367347,48.8854707912,15284.0,306.0,-0.288389503956,-0.032928943634,0.255460560322,-0.180453903517,0.0527280650564,-8.84224127233,-0.177778,948.0,1307.0,359.0,1099.69387755,83.0451571483,53885.0,1090.0,1.06167602539,5.23764038086,4.17596435547,1.55576558016,1.20225661446,76.2325134277,1.12027
+8307622.0,47.25,31.0,1.27220135969,206.0,292.0,86.0,249.592592593,13.9218585752,47173.0,250.0,249.0,383.0,134.0,328.005291005,21.0136003716,61993.0,329.0,597.0,1112.0,515.0,912.17989418,109.509775447,172402.0,924.0,167.0,365.0,198.0,283.64021164,33.6701659655,53608.0,282.0,0.374642521143,0.634586453438,0.259943932295,0.523591208395,0.0513372788827,98.9587383866,0.534351,622.0,1019.0,397.0,861.238095238,63.3330110984,162774.0,861.0,2.63632202148,4.8678894043,2.23156738281,3.55604464415,0.601615207836,672.092437744,3.44482
+8307114.0,22.0000000002,28.0,1.68399872721,241.0,379.0,138.0,307.170454545,21.7418854199,27031.0,309.0,268.0,532.0,264.0,378.738636364,34.1755143335,33329.0,382.0,227.0,667.0,440.0,311.931818182,65.8839881663,27450.0,299.0,154.0,578.0,424.0,298.409090909,53.3301544335,26260.0,293.5,-0.133587792516,0.214285716414,0.34787350893,0.020105828928,0.0704512993326,1.76931294566,0.0241271,663.0,1489.0,826.0,984.318181818,104.747591148,86620.0,985.0,-0.000823974609375,0.41064453125,0.411468505859,0.00913932106712,0.0606875093751,0.804260253906,0.0
Added: grass-addons/grass7/raster/r.object.activelearning/examples/update.csv
--- grass-addons/grass7/raster/r.object.activelearning/examples/update.csv	                        (rev 0)
+++ grass-addons/grass7/raster/r.object.activelearning/examples/update.csv	2017-05-03 08:09:28 UTC (rev 71010)
@@ -0,0 +1,6 @@
+cat,Class_num
+8441476,12
+12377913,34
+9984762,14
+9951298,21
+15321846,34
\ No newline at end of file
Added: grass-addons/grass7/raster/r.object.activelearning/r.object.activelearning.html
--- grass-addons/grass7/raster/r.object.activelearning/r.object.activelearning.html	                        (rev 0)
+++ grass-addons/grass7/raster/r.object.activelearning/r.object.activelearning.html	2017-05-03 08:09:28 UTC (rev 71010)
@@ -0,0 +1,189 @@
+<h2>DESCRIPTION</h2>
+This module uses SVM from the <em> scikit-learn </em> python package to perform
+classification on regions of raster maps. These regions can be the output of
+<em><a href="i.segment.html">i.segment</a></em>
+or
+<em><a href="r.clump.html">r.clump</a></em>.
+<p>
+The module enables learning with only a small initial labeled data set via
+<em>active learning</em>. This semi-supervised learning algorithm interactively
+query the user to label the regions that are most useful to improve the overall
+classification score.  With this technique, the number of examples to learn the
+classification is often much lower than the number of examples needed in normal
+supervised algorithms. You should start the classification with a small training
+set and run the module multiple times to label new informative samples to
+improve the classification score. The score metric is the number of correctly
+predicted labels over the total number of samples in the test set.
+<p>
+The samples that are chosen to be labeled are the ones where the class
+prediction is the most uncertain [2].  Moreover, from the more uncertain
+samples, only the most different samples are kept [1]. This diversity heuristic
+takes into account for each uncertain sample the distance to its closest
+neighbour and the average distance to all other samples. This ensures that newly
+labeled samples are not redundant with each other.
+<p>
+The learning data should be composed of features extracted from the regions, for
+example with the
+<em><a href="i.segment.stats.html">i.segment.stats</a></em> module.
+The features of the training set, the test set and the unlabeled set should be
+in three different files in csv format. The first line of each file must be a
+header containing the features' name. Every regions should be uniquely
+identified by the first attribute. The classes for the training and test
+examples should be the second attribute.
+<p>
+Example of a training and test files :
+	<div class="code">
+		<pre>
+			cat,Class_num,attr1,attr2,attr3
+			167485,4,3.546,456.76,6.76
+			183234,6,5.76,1285.54,9.45
+			173457,2,5.65,468.76,6.78
+		</pre>
+	</div>
+<p>
+Example of an unlabeled file :
+		<pre>
+			cat,attr1,attr2,attr3
+			167485,3.546,456.76,6.76
+			183234,5.76,1285.54,9.45
+			173457,5.65,468.76,6.78
+		</pre>
+	</div>
+<p>
+The training set can be easily updated once you have labeled new samples. Create
+a file to specify what label you give to which sample.
+This file in csv format should have a header and two attributes per line : the
+ID of the sample you have labeled and the label itself.  The module will
+transfer the newly labeled samples from the unlabeled set to the training set,
+adding the class you have provided. This is done internally and does not modify
+your original files.
+<p>
+If the user wants to save the changes in new files according to the updates, new
+files can be created with the new labeled samples added to the training file and
+removed from the unlabeled file. Just specify the path of those output files in
+the parameters (training_updated, unlabeled_updated).
+<p>
+Example of an update file :
+		<pre>
+			cat,Class_num
+			194762,2
+			153659,6
+			178350,2
+		</pre>
+	</div>
+<p>
+Here are more details on a few parameters :
+<ul>
+	<li><b>learning_steps</b> : This is the number of samples that
+		the module will ask to label at each run.</li>
+	<li><b>nbr_uncertainty</b> : Number of uncertain samples to
+		choose before applying the diversity filter. This number should
+		be higher than <em>learning_steps</em></li>
+	<li><b>diversity_lambda</b> : Parameter used in the diversity
+		heuristic. If close to 0 only take into account the average
+		distance to all other samples. If close to 1 only take into
+		account the distance to the closest neighbour</li>
+	<li><b>c_SVM</b> : Penalty parameter C of the error term. If
+		it is too large there is a risk of overfitting the training
+		data. If it is too small you may have underfitting.</li>
+	<li><b>gamma_SVM</b> : Kernel coefficient. 1/#features is
+		often a good value to start with.</li>
+		If C or gamma is left empty (or both), a good value based on the
+		data distibution is found by cross-validation (at least 3
+		samples per class in the training set is needed, more is
+		better). This automatic parameter tuning requires more
+		computation time as the training set grows.
+	<li><b>search_iter</b>  :Number of parameter settings that are
+		sampled in the automatic parameter search (C, gamma).
+		search_iter trades off runtime vs quality of the solution.</li>
+</ul>
+<h2>EXAMPLES</h2>
+The following examples are based on the data files found in this module
+repository.
+<h3>Simple run without an update file</h3>
+<div class="code">
+	<pre>
+		r.object.activelearning training_set=/path/to/training_set.csv \
+					test_set=/path/to/test_set.csv \
+					unlabeled_set=/path/to/unlabeled_set.csv
+		Parameters used : C=146.398423284, gamma=0.0645567086567, lambda=0.25
+		12527959
+		9892568
+		13731120
+		15445003
+		13767630
+		Class predictions written to predictions.csv
+		Training set : 70
+		Test set : 585
+		Unlabeled set : 792
+		Score : 0.321367521368
+	</pre>
+</div>
+<h3>With an update file</h3>
+The five samples output at the previous example have been labeled and added to
+the update file.
+<div class="code">
+	<pre>
+					unlabeled_set=/path/to/unlabeled_set.csv \
+					update=/path/to/update.csv
+		Parameters used : C=101.580687073, gamma=0.00075388337475, lambda=0.25
+		Training set : 75
+		Test set : 585
+		Unlabeled set : 787
+		Score : 0.454700854701
+		8691475
+		9321017
+		14254774
+		14954255
+		15838185
+	</pre>
+</div>
+<h2>NOTES</h2>
+This module requires the <em> scikit-learn </em> python package. This module
+needs to be installed in your GRASS GIS Python environment. Please refer to <a
+     href="r.learn.ml.html"><em>r.learn.ml</em></a>'s notes on how to install
+this package.
+<p>
+The memory usage for ~1450 samples of 52 features each is around ~650 kb.  This
+number can vary due to the unpredictablity of the garbage collector's behaviour.
+Everything is computed in memory; therefore the size of the data is limited by
+the amount of RAM available.
+<h2>REFERENCES</h2>
+[1] Bruzzone, L. and Persello, C. (2009). Active learning for classification of
+remote sensing images. 2009 IEEE International Geoscience and Remote Sensing
+Symposium. doi:10.1109/igarss.2009.5417857<br>
+[2] Tuia, D. et al (2011). A Survey of Active Learning Algorithms for Supervised Remote Sensing Image Classification. IEEE Journal of Selected Topics in Signal Processing, 5(3), 606-617. doi:10.1109/jstsp.2011.2139193
+<h2>AUTHOR</h2>
+Lucas Lefèvre (ULB, Brussels, Belgium)
+<p><i>Last changed: $Date$</i>
Property changes on: grass-addons/grass7/raster/r.object.activelearning/r.object.activelearning.html
___________________________________________________________________
Added: svn:mime-type
   + text/html
Added: svn:keywords
   + Author Date Id
Added: svn:eol-style
   + native
Added: grass-addons/grass7/raster/r.object.activelearning/r.object.activelearning.py
--- grass-addons/grass7/raster/r.object.activelearning/r.object.activelearning.py	                        (rev 0)
+++ grass-addons/grass7/raster/r.object.activelearning/r.object.activelearning.py	2017-05-03 08:09:28 UTC (rev 71010)
@@ -0,0 +1,579 @@
+#!/usr/bin/env python
+# encoding: utf-8
+#* MODULE:	r.object.activelearning
+#* AUTHOR(S)	Lucas Lefèvre
+#* PURPOSE:	Active learning for classifying raster objects
+#* COPYRIGHT:	(C) 2017 Lucas Lefèvre, and the GRASS Development Team
+#               This program is free software under the GNU General Public
+#               License (>=v2). Read the file COPYING that comes with GRASS
+#               for details.
+#%module
+#% description: Active learning for classifying raster objects
+#%end
+#%option G_OPT_F_INPUT
+#% key: training_set
+#% description: Training set (csv format)
+#% required: yes
+#%end
+#% key: test_set
+#% description: Test set (csv format)
+#% required: yes
+#%end
+#% key: unlabeled_set
+#% description: Unlabeled samples (csv format)
+#% required: yes
+#%end
+#%option
+#% key: learning_steps
+#% type: integer
+#% description: Number of samples to label at each iteration
+#% answer: 5
+#% required: no
+#%end
+#%option
+#% key: nbr_uncertainty
+#% type: integer
+#% description: Number of samples to select (based on uncertainty criterion) before applying the diversity criterion.
+#% answer: 15
+#% required: no
+#%end
+#%option
+#% key: diversity_lambda
+#% type: double
+#% description: Lambda parameter used in the diversity heuristic
+#% answer: 0.25
+#% required: no
+#%end
+#%option
+#% key: c_svm
+#% type: double
+#% description: Penalty parameter C of the error term
+#% required: no
+#%end
+#%option
+#% key: gamma_parameter
+#% type: double
+#% description: Kernel coefficient
+#% required: no
+#%end
+#%option
+#% key: search_iter
+#% type: integer
+#% description: Number of parameter settings that are sampled in the automatic parameter search (C, gamma).
+#% answer: 15
+#% required: no
+#%end
+#% key: update
+#% description: Training set update file
+#% required: no
+#%end
+#%option G_OPT_F_OUTPUT
+#% key: predictions
+#% description: Output file for class predictions
+#% required: no
+#%end
+#% key: training_updated
+#% description: Output file for the updated training file
+#% required: no
+#%end
+#% key: unlabeled_updated
+#% description: Output file for the updated unlabeled file
+#% required: no
+#%end
+try :
+	from sklearn import svm
+	from sklearn import preprocessing
+	from sklearn.model_selection import train_test_split
+	from sklearn.model_selection import RandomizedSearchCV
+	from sklearn.model_selection import StratifiedKFold
+	from sklearn.metrics.pairwise import rbf_kernel
+except ImportError :
+	gcore.fatal("This module requires the scikit-learn python package. Please install it.")
+try : # You can run the tests outside of grass where those imports are not available
+	import grass as grass
+	import grass.script as gcore
+	pass
+import numpy as np
+import scipy
+import os.path
+import sys
+import matplotlib.pyplot as plt
+def load_data(file_path, labeled=False, skip_header=1, scale=True) :
+		Load the data from a csv file
+		:param file_path: Path to the csv data file
+		:param labeled: True if the data is labeled (default=False)
+		:param skip_header: Header size (in line) (default=1)
+		:param scale: True if the data should be normalize (default=True)
+		:type file_path: string
+		:type labeled: boolean
+		:type skip_header: int
+		:type scale: boolean
+		:return: Return 4 arrays, the features X, the IDs, the labels y and the header
+		:rtype: ndarray
+	data = np.genfromtxt(file_path, delimiter=',', skip_header=0, dtype=None)
+	header = np.array([])
+	if skip_header != 0 :
+		header = data[0:skip_header,:]
+	data = data[skip_header:, :] #Remove header
+	data = data.astype(np.float)
+	ID = data[:,0] #get only row 0s
+	if labeled :
+		y = data[:,1] #get only row 1
+		X = data[:,2:] #remove ID and label
+	else :
+		y = []
+		X = data[:,1:] #remove ID
+	if scale :
+		X = preprocessing.scale(X)
+	return X, ID, y, header
+def write_result_file(ID, X_unlabeled, predictions, header, filename) :
+		Write all samples with their ID and their class prediction in csv file. Also add the header to this csv file.
+		:param ID: Samples'IDs
+		:X_unlabeled: Samples'features
+		:predictions: Class predictin for each sample
+		:header: Header of the csv file
+		:filename: Name of the csv file
+	data = np.copy(X_unlabeled)
+	data = np.insert(data, 0, map(str, ID), axis=1)
+	data = np.insert(data, 1, map(str, predictions), axis=1)
+	if header.size != 0 :
+		header = np.insert(header, 1, ['Class'])
+		data = np.insert(data.astype(str), 0, header , axis=0)
+	np.savetxt(filename, data, delimiter=",",fmt="%s")
+	return True
+def update(update_file, X_train, ID_train, y_train, X_unlabeled, ID_unlabeled) :
+		Transfer features and labels from the unlabeled arrays to the training arrays based on the update file.
+		:param update_file: Path to the update file
+		:param X_train: Features for the training samples
+		:param ID_train: IDs of the training samples
+		:param y_train: Labels of the training samples
+		:param X_unlabeled: Features for the training samples
+		:param ID_unlabeled: IDs of the unlabeled samples
+	update = np.genfromtxt(update_file, delimiter=',', skip_header=1)
+	if update.size == 0 :
+		return X_train, ID_train, y_train
+	elif update.ndim == 1 :
+		update = [update]
+	for index_update, row in enumerate(update) :
+		index = np.where(ID_unlabeled == row[0]) # Find in 'unlabeled' the line corresping to the ID
+		if index[0].size != 0 : # Check if row exists
+			features = X_unlabeled[index[0][0]] # Features
+			ID = ID_unlabeled[index[0][0]]
+			label = row[1]
+			X_train = np.append(X_train, [features], axis=0)
+			ID_train = np.append(ID_train, [ID], axis=0)
+			y_train = np.append(y_train, [label], axis=0)
+		else :
+			gcore.warning("The following sample could not be found :{}".format(row[0]))
+def write_update(update_file, training_file, unlabeled_file, new_training_filename, new_unlabeled_filename) :
+		Transfer samples from the unlabeled set to the training set based on an update file
+		with IDs of samples to transfer and their classes.
+		:param training_file: Path to the training file
+		:param unlabeled_file: Path to the unlabeled file
+		:param new_training_filename: Path to the new training file that will be created
+		:param new_unlabeled_filename: Path to the new unlabeled file that will be created
+		:type update_file: string
+		:type training_file: string
+		:type unlabeled_file: string
+		:type new_training_filename: string
+		:type new_unlabeled_filename: string
+	training = np.genfromtxt(training_file, delimiter=',', skip_header=0, dtype=None)
+	unlabeled = np.genfromtxt(unlabeled_file, delimiter=',', skip_header=0, dtype=None)
+	successful_updates = []
+		return
+		update = [update]
+		index = np.where(unlabeled == str(row[0])) # Find in 'unlabeled' the line corresping to the ID
+			data = unlabeled[index[0][0]][1:] # Features
+			data = np.insert(data, 0, row[0], axis=0) # ID
+			data = np.insert(data, 1, row[1], axis=0) # Class
+			training = np.append(training, [data], axis=0)
+			unlabeled = np.delete(unlabeled, index[0][0], axis=0)
+			successful_updates.append(index_update)
+		else :
+			gcore.warning("Unable to update completely: the following sample could not be found in the unlabeled set:{}".format(row[0]))
+	with open(update_file) as f:
+   		header = f.readline()
+		header = header.split(',')
+	update = np.delete(update, successful_updates, axis=0)
+	update = np.insert(update.astype(str), 0, header, axis=0)
+	# Save files
+	if new_training_filename != '' :
+		write_updated_file(new_training_filename, training)
+		gcore.message("New training file written to {}".format(new_training_filename))
+	if new_unlabeled_filename != '':
+		write_updated_file(new_unlabeled_filename, unlabeled)
+		gcore.message("New unlabeled file written to {}".format(new_unlabeled_filename))
+def write_updated_file(file_path, data) :
+		Write to disk some csv data. Add '_updated' at the end of the filename
+		:param filename: location where the file will be saved
+		:param data: data to save
+		:type data: ndarray
+	np.savetxt(file_path, data, delimiter=",",fmt="%s")
+def linear_scale(data) :
+		Linearly scale values : 5th percentile to 0 and 95th percentile to 1
+		:param data: Features
+		:type data: ndarray(#samples x #features)
+		:return: Linearly scaled data
+		:rtype: ndarray(#samples x #features)
+	p5 = np.percentile(data, 5, axis=0, interpolation='nearest')[np.newaxis] 	# 5th percentiles as a 2D array (-> newaxis)
+	p95 = np.percentile(data, 95, axis=0, interpolation='nearest')[np.newaxis]	# 95th percentiles as a 2D array (-> newaxis)
+	return (data-p5)/(p95-p5)
+def train(X, y, c_svm, gamma_parameter) :
+		Train a SVM classifier.
+		:param c: Penalty parameter C of the error term.
+		:param gamma: Kernel coefficient
+		:param X: Features of the training samples
+		:param y: Labels of the training samples
+		:return: Returns the trained classifier
+		:rtype: sklearn.svm.SVC
+	classifier = svm.SVC(kernel='rbf', C=c_svm, gamma=gamma_parameter, probability=False,decision_function_shape='ovr', random_state=1938475632)
+	classifier.fit(X, y)
+	return classifier
+def active_diversity_sample_selection(X_unlabled, nbr, classifier) :
+		Select a number of samples to label based on uncertainety and diversity
+		:param X_unlabeled: Pool of unlabeled samples
+		:param nbr: Number of samples to select from the pool
+		:param classifier: Used to predict the class of each sample
+		:type X_unlabeled: ndarray(#samples x #features)
+		:type nbr: int
+		:type classifier: sklearn.svm.SVC
+		:return: Indexes of selected samples
+		:rtype: ndarray
+	batch_size = nbr_uncertainty	# Number of samples to select with the uncertainty criterion
+	uncertain_samples_index = uncertainty_filter(X_unlabled, batch_size, classifier)	# Take twice as many samples as needed
+	uncertain_samples = X_unlabled[uncertain_samples_index]
+	return diversity_filter(uncertain_samples, uncertain_samples_index, nbr, diversity_lambda)
+def uncertainty_filter(samples, nbr, classifier) :
+		Keep only a few samples based on an uncertainty criterion
+		Return the indexes of samples to keep
+		:param samples: Pool of unlabeled samples to select from
+		:param nbr: number of samples to select from the pool
+		:type nbr: int
+		:rtype: ndarray
+	NBR_NEW_SAMPLE = nbr
+	decision_function = np.absolute(classifier.decision_function(samples))
+	# Check if the number of samples to return is not
+	# bigger than the total number of samples
+	if (nbr >= samples.shape[0]) :
+		NBR_NEW_SAMPLE = samples.shape[0] - 1
+	# Get the max distance to each class hyperplane for each example
+	max_index = np.argmax(decision_function[:,:], axis=1)
+	max_values = decision_function[np.arange(len(decision_function)), max_index]
+	# Make the max values very small.
+	# The max value is now the second best
+	decision_function[np.arange(len(decision_function)), max_index] = np.NINF
+	# Get the second max distance to each class to hyperplane for each example
+	second_max_index = np.argmax(decision_function[:,:], axis=1)
+	second_max_values = decision_function[np.arange(len(decision_function)), second_max_index]
+	# "Functionnal margin" for multiclass classifiers for each sample
+	f_MC = max_values - second_max_values
+	selected_sample_index = np.argpartition(f_MC, NBR_NEW_SAMPLE)[:NBR_NEW_SAMPLE]
+	return selected_sample_index
+def diversity_filter(samples, uncertain_samples_index, nbr, diversity_lambda=0.25) :
+		Keep only 'nbr' samples based on a diversity criterion (bruzzone2009 : Active Learning For Classification Of Remote Sensing Images)
+		:param uncertain_samples: Indexes of uncertain samples in the arry of samples
+		:param diversity_lambda: Heuristic parameter, between 0 and 1. Weight between the average distance to other samples and the distance to the closest sample. (default=0.25)
+		:type uncertain_samples_index: ndarray(#uncertain_samples)
+		:type nbr: int
+		:type diversity_lambda: float
+		:rtype: ndarray
+	L = diversity_lambda
+	m = samples.shape[0]	# Number of samples
+	samples_cpy = np.empty(samples.shape)
+	samples_cpy[:] = samples
+	selected_sample_index = uncertain_samples_index	# At the begining, take all samples
+	while (selected_sample_index.shape[0] > nbr) :
+		dist_to_closest = distance_to_closest(samples_cpy)
+		average_dist = average_distance(samples_cpy)
+		discard = np.argmax(L*dist_to_closest + (1-L) * (1./m) * average_dist)
+		selected_sample_index = np.delete(selected_sample_index, discard)	# Remove the sample to discard
+		samples_cpy = np.delete(samples_cpy, discard, axis=0)
+def distance_to_closest(samples) :
+		For each sample, computes the distance to its closest neighbour
+		:param samples: Samples to consider
+		:type samples: ndarray(#samples x #features)
+		:return: For each sample, the distance to its closest neighbour
+		:rtype: ndarray(#samples)
+	dist_with_samples = rbf_kernel(samples, samples) # Distance between each samples (symetric matrix)
+	np.fill_diagonal(dist_with_samples, np.NINF) # Do not take into acount the distance between a sample and itself (values on the diagonal)
+	dist_with_closest = dist_with_samples.max(axis=0) # For each sample, the distance to the closest other sample
+	return dist_with_closest
+def average_distance(samples) :
+		For each sample, computes the average distance to all other samples
+		:return: For each sample, the average distance to all other samples
+	samples = np.asarray(samples)
+	nbr_samples = samples.shape[0]
+	average_dist = (dist_with_samples.sum(axis=1) - 1)/(nbr_samples-1)	# Remove dist to itself (=1)
+	return average_dist
+def learning(X_train, y_train, X_test, y_test, X_unlabeled, ID_unlabeled, steps, sample_selection) :
+		Train a SVM classifier with the training data, compute the score of the classifier based on testing data and
+		make a class prediction for each sample in the unlabeled data.
+		Find the best samples to label that would increase the most the classification score
+		:param X_train: Features of training samples
+		:param y_train: Labels of training samples
+		:param X_test: Features of test samples
+		:param y_test: Labels of test samples
+		:param X_unlabeled: Features of unlabeled samples
+		:param ID_unlabeled: IDs of unlabeled samples
+		:param steps: Number of samples to label
+		:param sample_selection: Function used to select the samples to label (different heuristics)
+		:type X_train: ndarray(#samples x #features)
+		:type y_train: ndarray(#samples)
+		:type X_test: ndarray(#samples x #features)
+		:type y_test: ndarray(#samples)
+		:type ID_unlabeled: ndarray(#samples)
+		:type steps: int
+		:type samples_selection: callable
+		:return: The IDs of samples to label, the score of the classifier and the prediction for all unlabeled samples
+		:rtype indexes: ndarray(#steps)
+		:rtype score: float
+		:rtype predictions: ndarray(#unlabeled_samples)
+	if(X_unlabeled.size == 0) :
+		raise Exception("Pool of unlabeled samples empty")
+	c_svm, gamma_parameter = SVM_parameters(options['c_svm'], options['gamma_parameter'], X_train, y_train, search_iter)
+	gcore.message('Parameters used : C={}, gamma={}, lambda={}'.format(c_svm, gamma_parameter, diversity_lambda))
+	classifier = train(X_train, y_train, c_svm, gamma_parameter)
+	score = classifier.score(X_test, y_test)
+	predictions = classifier.predict(X_unlabeled)
+	samples_to_label = sample_selection(X_unlabeled, steps, classifier)
+	return ID_unlabeled[samples_to_label], score, predictions
+def SVM_parameters(c, gamma, X_train, y_train, n_iter) :
+		Determine the parameters (C and gamma) for the SVM classifier.
+		If a parameter is specified in the parameters, keep this value.
+		If it is not specified, compute the 'best' value by grid search (cross validation set)
+		:param X_train: Features of the training samples
+		:param n_iter: Number of parameter settings that are sampled. n_iter trades off runtime vs quality of the solution.
+		:type c: string
+		:type gamma: string
+		:type Y_train: ndarray
+		:type n_iter: int
+		:return: The c and gamma parameters
+		:rtype: floats
+	parameters = {}
+	if c == '' or gamma == '':
+		parameters = {'C': scipy.stats.expon(scale=100), 'gamma': scipy.stats.expon(scale=.1),
+  						'kernel': ['rbf'], 'class_weight':['balanced', None]}
+	if parameters != {} :
+		svr = svm.SVC()
+		clf = RandomizedSearchCV(svr, parameters, n_iter=n_iter, n_jobs=-1, verbose=0)
+		clf.fit(X_train, y_train)
+	if c == '' :
+		c = clf.best_params_['C']
+	if gamma == '' :
+		gamma = clf.best_params_['gamma']
+	return float(c), float(gamma)
+def main() :
+	global learning_steps
+	global diversity_lambda
+	global nbr_uncertainty
+	global search_iter
+	learning_steps = int(options['learning_steps']) if options['learning_steps'] != '0' else 5
+	search_iter = int(options['search_iter']) if options['search_iter'] != '0' else 10					# Number of samples to label at each iteration
+	diversity_lambda = float(options['diversity_lambda']) if options['diversity_lambda'] != '' else 0.25		# Lambda parameter used in the diversity heuristic
+	nbr_uncertainty = int(options['nbr_uncertainty']) if options['nbr_uncertainty'] != '0' else 15 	# Number of samples to select (based on uncertainty criterion) before applying the diversity criterion. Must be at least greater or equal to [LEARNING][steps]
+	X_train, ID_train, y_train, header_train = load_data(options['training_set'], labeled = True)
+	X_test, ID_test, y_test, header_test = load_data(options['test_set'], labeled = True)
+	X_unlabeled, ID_unlabeled, y_unlabeled, header_unlabeled = load_data(options['unlabeled_set'])
+	nbr_train = ID_train.shape[0]
+	if (options['update'] !='') : # If an update file has been specified, transfer samples
+		X_train, ID_train, y_train = update(options['update'], X_train, ID_train, y_train, X_unlabeled, ID_unlabeled)
+		if (options['training_updated'] != '' or options['unlabeled_updated'] != '') :
+			write_update(options['update'], options['training_set'], options['unlabeled_set'], options['training_updated'], options['unlabeled_updated'])
+	elif (options['update'] =='' and (options['training_updated'] != '' or options['unlabeled_updated'] != '')) :
+		gcore.warning('No update file specified : could not write the updated files.')
+	nbr_new_train = ID_train.shape[0]
+	samples_to_label_IDs, score, predictions = learning(X_train, y_train, X_test, y_test, X_unlabeled, ID_unlabeled, learning_steps, active_diversity_sample_selection)
+	X_unlabeled, ID_unlabeled, y_unlabeled, header_unlabeled = load_data(options['unlabeled_set'], scale=False) # Load unscaled data
+	predictions_file = options['predictions']
+	if (predictions_file != '') : # Write the class prediction only if an output file has been specified by the user
+		write_result_file(ID_unlabeled, X_unlabeled, predictions, header_unlabeled,  predictions_file)
+		gcore.message("Class predictions written to {}".format(predictions_file))
+	gcore.message('Training set : {}'.format(X_train.shape[0]))
+	gcore.message('Test set : {}'.format(X_test.shape[0]))
+	gcore.message('Unlabeled set : {}'.format(X_unlabeled.shape[0] - (nbr_new_train - nbr_train)))
+	gcore.message('Score : {}'.format(score))
+	for ID in samples_to_label_IDs :
+		print(int(ID))
+if __name__ == '__main__' :
+	options, flags = grass.script.parser()
+	main()
Property changes on: grass-addons/grass7/raster/r.object.activelearning/r.object.activelearning.py
Added: svn:executable
   + text/x-python
   + native
Added: grass-addons/grass7/raster/r.object.activelearning/report.pdf
(Binary files differ)
Property changes on: grass-addons/grass7/raster/r.object.activelearning/report.pdf
   + application/pdf
Added: grass-addons/grass7/raster/r.object.activelearning/tests.py
--- grass-addons/grass7/raster/r.object.activelearning/tests.py	                        (rev 0)
+++ grass-addons/grass7/raster/r.object.activelearning/tests.py	2017-05-03 08:09:28 UTC (rev 71010)
@@ -0,0 +1,188 @@
+# encoding: utf-8
+import unittest
+import os
+import numpy as np
+from sklearn.metrics.pairwise import rbf_kernel
+#from r.objects.activelearning import * --> doesn't work because of the dots in the file name
+import imp
+open_file, file_name, description = imp.find_module('r.objects.activelearning')
+al = imp.load_source('al', file_name, open_file)
+def silent_remove(filename) :
+		Remove the file if it exists or do nothing if it does not exists
+	try :
+		os.remove(filename)
+	except OSerror as e :
+		if e.errno != errno.ENOENT :
+			raise
+class Test (unittest.TestCase) :
+	def test_linear_scale(self) :
+		X = np.random.randint(0,100, (10,5))
+		#print(X)
+		X = al.linear_scale(X)
+		#print(X)
+		p1 = np.percentile(X, 1, interpolation='nearest', axis=0)
+		p5 = np.percentile(X, 5, interpolation='nearest', axis=0)
+		p95 = np.percentile(X, 95, interpolation='nearest', axis=0)
+		p99 = np.percentile(X, 99, interpolation='nearest', axis=0)
+		self.assertTrue((p1 <= 0).all())
+		self.assertTrue((p5 == 0).all())
+		self.assertTrue((p95 == 1).all())
+		self.assertTrue((p99 >= 0).all())
+		X = np.random.rand(100,100)/2
+	def test_dist_to_closest(self) :
+		# 5 samples
+		a = [1, 	3]
+		b = [0, 	4]
+		c = [2, 	5]
+		d = [-1, 	2]
+		e = [-1, 	2]
+		samples = np.array([a, b, c, d, e])
+		dist = al.distance_to_closest(samples)
+		self.assertEqual(dist[0], rbf_kernel([a], [b])[0][0]) # closest to a
+		self.assertEqual(dist[1], rbf_kernel([b], [a])[0][0]) # closest to b
+		self.assertEqual(dist[2], rbf_kernel([c], [b])[0][0]) # closest to c
+		self.assertEqual(dist[3], rbf_kernel([d], [e])[0][0]) # closest to d
+		self.assertEqual(dist[4], rbf_kernel([d], [e])[0][0]) # closest to e
+	def test_average_dist(self) :
+		# 3 samples
+		a = [1, 	3]
+		b = [0, 	4]
+		c = [2, 	5]
+		samples = np.array([a, b, c])
+		dist = al.average_distance(samples)
+		avg_a = (rbf_kernel([a], [b])[0][0] + rbf_kernel([a], [c])[0][0])/2
+		avg_b = (rbf_kernel([b], [a])[0][0] + rbf_kernel([b], [c])[0][0])/2
+		avg_c = (rbf_kernel([c], [a])[0][0] + rbf_kernel([c], [b])[0][0])/2
+		self.assertAlmostEqual(dist[0],avg_a)
+		self.assertAlmostEqual(dist[1],avg_b)
+		self.assertAlmostEqual(dist[2],avg_c)
+	def test_diversity_criterion(self) :
+		# 9 samples -> plot them for a better visualization (e.g. with GeoGebra)
+		a = [2, 	4]
+		b = [4, 	1]
+		b_bis = [4, 	1]
+		c = [-2, 	1]
+		d = [-1, 	5]
+		e = [1.6, 	3.6]
+		f = [3, 	1]
+		g = [1, 	2]
+		h = [9, 	5]
+		i = [49, 	4] # This sample is not sent to the diversity filter
+		samples = np.array([a, b, b_bis, c, d, e, f, g, h, i])
+		selected_samples = al.diversity_filter(samples, np.arange(9), 4)
+		self.assertTrue(0 not in selected_samples)
+		self.assertTrue((1 in selected_samples) ^ (2 in selected_samples))	# Either b or b_bis is kept
+		self.assertTrue(3 in selected_samples)
+		self.assertTrue(4 in selected_samples)
+		self.assertTrue(5 not in selected_samples)
+		self.assertTrue(6 not in selected_samples)
+		self.assertTrue(7 not in selected_samples)
+		self.assertTrue(8 in selected_samples)
+		self.assertTrue((samples == np.array([a, b, b_bis, c, d, e, f, g, h, i])).all())	# Check that the original array was not modified
+	def test_write_result_file(self) :
+		X = np.array([
+			[11., 3.5, 4.7],
+			[22., 4.5, 6.7]
+		header = np.array(['ID', 'attr1','attr2', 'attr3'])
+		ID = np.array([1., 2.])
+		predictions = np.array([0,1])
+		filename = 'unittest_prediction.csv'
+		#ID, X_unlabeled, predictions, header, filename
+		al.write_result_file(ID, X, predictions, header, filename)
+		result = np.genfromtxt(filename, delimiter=',', dtype=str)
+		data = np.array([
+			['ID', 'Class', 'attr1','attr2', 'attr3'],
+			[1., 0., 11., 3.5, 4.7],
+			[2., 1., 22., 4.5, 6.7]
+		self.assertTrue((data == result).all())
+		silent_remove(filename)
+	def test_update(self) :
+		#Create a fake update file
+		update_file = 'update.csv'
+		update_data = np.array([
+			['cat', 'Class'],
+			[123, 1],
+			[456, 2]
+		np.savetxt(update_file, update_data, delimiter=",",fmt="%s")
+		X_train = np.array([
+			[1,2,3],
+			[4,5,6]
+		ID_train = np.array([111,222])
+		y_train = np.array([1,2])
+		X_unlabeled = np.array([
+			[11,22,33],
+			[44,55,66],
+			[77,88,99]
+		ID_unlabeled = np.array([123,456, 789])
+		X_train, ID_train, y_train = al.update(update_file, X_train, ID_train, y_train, X_unlabeled, ID_unlabeled)
+		X_train_should_be = np.array([
+			[1,2,3],
+			[4,5,6],
+			[11,22,33],
+			[44,55,66]
+		ID_train_should_be = np.array([111,222,123,456])
+		y_train_should_be = np.array([1,2,1,2])
+		self.assertTrue((X_train == X_train_should_be).all())
+		self.assertTrue((ID_train_should_be == ID_train).all())
+		self.assertTrue((y_train_should_be == y_train).all())
+		silent_remove(update_file)
+	unittest.main()
Property changes on: grass-addons/grass7/raster/r.object.activelearning/tests.py
   + text/x-python
   + native
