[GRASS-SVN] r71061 - grass/trunk/vector/v.label.sa grass-addons/grass7/vector/v.label.sa
Mon May 8 01:07:13 PDT 2017
Author: mmetz
Date: 2017-05-08 01:07:13 -0700 (Mon, 08 May 2017)
New Revision: 71061
Added:
   grass-addons/grass7/vector/v.label.sa/font.c
   grass/trunk/vector/v.label.sa/font.c
   grass-addons/grass7/vector/v.label.sa/annealing.c
   grass-addons/grass7/vector/v.label.sa/labels.c
   grass-addons/grass7/vector/v.label.sa/labels.h
   grass-addons/grass7/vector/v.label.sa/main.c
   grass/trunk/vector/v.label.sa/annealing.c
   grass/trunk/vector/v.label.sa/labels.c
   grass/trunk/vector/v.label.sa/labels.h
v.label.sa: fix and sync
Modified: grass/trunk/vector/v.label.sa/annealing.c
--- grass/trunk/vector/v.label.sa/annealing.c	2017-05-08 05:10:21 UTC (rev 71060)
+++ grass/trunk/vector/v.label.sa/annealing.c	2017-05-08 08:07:13 UTC (rev 71061)
@@ -101,11 +101,11 @@
 	    /* else apply with probability p=e^(-dE/T) */
 	    else {
-		double p, r;
+		double dp, dr;
-		p = pow(M_E, -dE / T);
-		r = (double)rand() / RAND_MAX;
-		if (r <= p) {
+		dp = pow(M_E, -dE / T);
+		dr = (double)rand() / RAND_MAX;
+		if (dr <= dp) {
 		    do_label_overlap(lp, cc, c);
 		    lp->current_score += lp->candidates[c].score;
 		    lp->current_candidate = c;
Copied: grass/trunk/vector/v.label.sa/font.c (from rev 71060, grass/branches/releasebranch_6_4/vector/v.label.sa/font.c)
--- grass/trunk/vector/v.label.sa/font.c	                        (rev 0)
+++ grass/trunk/vector/v.label.sa/font.c	2017-05-08 08:07:13 UTC (rev 71061)
@@ -0,0 +1,97 @@
+ * from lib/driver/parse_ftcap.c
+ * These functions are copied from the diplay driver lib,
+ * so that we don't need to have an active display driver open,
+ * to run this module.
+#include <stdio.h>
+#include <stdlib.h>
+#include <string.h>
+#include <grass/gis.h>
+#include <grass/glocale.h>
+#include "labels.h"
+static int font_exists(const char *name);
+    FILE *fp;
+    fp = fopen(name, "r");
+    if (!fp)
+	return 0;
+    fclose(fp);
+    return 1;
+void free_freetypecap(struct GFONT_CAP *ftcap)
+    if (ftcap == NULL)
+	return;
+    G_free(ftcap->name);
+    G_free(ftcap->longname);
+    G_free(ftcap->path);
+    G_free(ftcap->encoding);
+    G_free(ftcap);
+    return;
+struct GFONT_CAP *find_font_from_freetypecap(const char *font)
+    char *capfile, file[GPATH_MAX];
+    char buf[GPATH_MAX];
+    FILE *fp;
+    int fonts_count = 0;
+    struct GFONT_CAP *font_cap = NULL;
+    fp = NULL;
+    if ((capfile = getenv("GRASS_FONT_CAP"))) {
+	if ((fp = fopen(capfile, "r")) == NULL)
+	    G_warning(_
+		      ("%s: Unable to read font definition file; use the default"),
+		      capfile);
+    if (fp == NULL) {
+	sprintf(file, "%s/etc/fontcap", G_gisbase());
+	if ((fp = fopen(file, "r")) == NULL)
+	    G_warning(_("%s: No font definition file"), file);
+    if (fp != NULL) {
+	while (fgets(buf, sizeof(buf), fp) && !feof(fp)) {
+	    char name[GNAME_MAX], longname[GNAME_MAX],
+		path[GPATH_MAX], encoding[128];
+	    int type, index;
+	    char *p;
+	    p = strchr(buf, '#');
+	    if (p)
+		*p = 0;
+	    if (sscanf(buf, "%[^|]|%[^|]|%d|%[^|]|%d|%[^|]|",
+		       name, longname, &type, path, &index, encoding)
+		!= 6)
+		continue;
+	    if (strcmp(name, font) != 0 && strcmp(longname, font) != 0)
+		continue;
+	    if (!font_exists(path))
+		continue;
+	    font_cap = (struct GFONT_CAP *)G_malloc(sizeof(struct GFONT_CAP));
+	    font_cap[fonts_count].name = G_store(name);
+	    font_cap[fonts_count].longname = G_store(longname);
+	    font_cap[fonts_count].type = type;
+	    font_cap[fonts_count].path = G_store(path);
+	    font_cap[fonts_count].index = index;
+	    font_cap[fonts_count].encoding = G_store(encoding);
+	fclose(fp);
+    return font_cap;
Modified: grass/trunk/vector/v.label.sa/labels.c
--- grass/trunk/vector/v.label.sa/labels.c	2017-05-08 05:10:21 UTC (rev 71060)
+++ grass/trunk/vector/v.label.sa/labels.c	2017-05-08 08:07:13 UTC (rev 71061)
@@ -97,7 +97,7 @@
     else if (error)
 	G_fatal_error(_("Font file can not be loaded"));
     p->font->answer = G_store(font_cap->name);
-    free_fontcap(font_cap);
+    free_freetypecap(font_cap);
     font_size = atof(p->size->answer);
     buffer = atof(p->isize->answer);
@@ -1158,7 +1158,6 @@
 		for (l = 0; l < labels[k].n_candidates; l++) {
 		    int overlap = 0;
-		    struct line_pnts *a = NULL, *b = NULL;
 		    if ((labels[i].candidates[j].rotation == 0) &&
 			(labels[k].candidates[l].rotation == 0)) {
@@ -1184,6 +1183,8 @@
 			overlap = box_overlap(&a, &b);
 		    else {
+			struct line_pnts *a = NULL, *b = NULL;
 			a = box_trans_rot(&labels[i].bb,
 					  &labels[i].candidates[j].point,
 					  labels[i].candidates[j].rotation);
Modified: grass/trunk/vector/v.label.sa/labels.h
--- grass/trunk/vector/v.label.sa/labels.h	2017-05-08 05:10:21 UTC (rev 71060)
+++ grass/trunk/vector/v.label.sa/labels.h	2017-05-08 08:07:13 UTC (rev 71061)
@@ -179,4 +179,7 @@
 struct line_pnts *skyline_trans_rot(struct line_pnts *skyline,
 				    label_point_t * p, double angle);
+struct GFONT_CAP *find_font_from_freetypecap(const char *font);
+void free_freetypecap(struct GFONT_CAP *ftcap);
 #endif /* _LABELS_H */
Modified: grass-addons/grass7/vector/v.label.sa/annealing.c
--- grass-addons/grass7/vector/v.label.sa/annealing.c	2017-05-08 05:10:21 UTC (rev 71060)
+++ grass-addons/grass7/vector/v.label.sa/annealing.c	2017-05-08 08:07:13 UTC (rev 71061)
 	    else {
-		double p, r;
+		double dp, dr;
-		if (r <= p) {
+		if (dr <= dp) {
Copied: grass-addons/grass7/vector/v.label.sa/font.c (from rev 71060, grass/branches/releasebranch_6_4/vector/v.label.sa/font.c)
--- grass-addons/grass7/vector/v.label.sa/font.c	                        (rev 0)
+++ grass-addons/grass7/vector/v.label.sa/font.c	2017-05-08 08:07:13 UTC (rev 71061)
@@ -0,0 +1,97 @@
+#include <stdio.h>
+    FILE *fp;
+    if (!fp)
+	return 0;
+    fclose(fp);
+    return 1;
+	return;
+    G_free(ftcap);
+    return;
+    FILE *fp;
+    fp = NULL;
+	    G_warning(_
+		      capfile);
+    if (fp == NULL) {
+    if (fp != NULL) {
+	    int type, index;
+	    char *p;
+	    if (p)
+		*p = 0;
+		!= 6)
+		continue;
+		continue;
+		continue;
+	fclose(fp);
+    return font_cap;
Modified: grass-addons/grass7/vector/v.label.sa/labels.c
--- grass-addons/grass7/vector/v.label.sa/labels.c	2017-05-08 05:10:21 UTC (rev 71060)
+++ grass-addons/grass7/vector/v.label.sa/labels.c	2017-05-08 08:07:13 UTC (rev 71061)
@@ -97,7 +97,7 @@
     else if (error)
 		    int overlap = 0;
 		    else {
Modified: grass-addons/grass7/vector/v.label.sa/labels.h
--- grass-addons/grass7/vector/v.label.sa/labels.h	2017-05-08 05:10:21 UTC (rev 71060)
+++ grass-addons/grass7/vector/v.label.sa/labels.h	2017-05-08 08:07:13 UTC (rev 71061)
@@ -179,4 +179,7 @@
Modified: grass-addons/grass7/vector/v.label.sa/main.c
--- grass-addons/grass7/vector/v.label.sa/main.c	2017-05-08 05:10:21 UTC (rev 71060)
+++ grass-addons/grass7/vector/v.label.sa/main.c	2017-05-08 08:07:13 UTC (rev 71061)
@@ -168,7 +168,7 @@
     label_candidate_overlap(labels, n_labels);
     /*   3. position selection */
     simulate_annealing(labels, n_labels, &p);
-    /* write lables to file */
+    /* write labels to file */
     fprintf(stderr, "Writing labels to file: ...");
     labelf = G_fopen_new("paint/labels", p.labels->answer);
     for (i = 0; i < n_labels; i++) {
