[GRASS-SVN] r71104 - grass/trunk/temporal/t.rast.what/testsuite
Mon May 22 02:02:03 PDT 2017
Author: lucadelu
Date: 2017-05-22 02:02:03 -0700 (Mon, 22 May 2017)
New Revision: 71104
   grass/trunk/temporal/t.rast.what/testsuite/test_what.py
t.rast.what testsuite: PEP8 clean up
Modified: grass/trunk/temporal/t.rast.what/testsuite/test_what.py
--- grass/trunk/temporal/t.rast.what/testsuite/test_what.py	2017-05-22 06:18:32 UTC (rev 71103)
+++ grass/trunk/temporal/t.rast.what/testsuite/test_what.py	2017-05-22 09:02:03 UTC (rev 71104)
@@ -18,97 +18,98 @@
         """Initiate the temporal GIS and set the region
         cls.use_temp_region()
-        cls.runModule("g.region",  s=0,  n=80,  w=0,  e=120,  b=0,  t=50,  res=10,  res3=10)
+        cls.runModule("g.region", s=0, n=80, w=0, e=120, b=0, t=50, res=10,
+                      res3=10)
-        cls.runModule("r.mapcalc", expression="a_1 = 100",  overwrite=True)
-        cls.runModule("r.mapcalc", expression="a_2 = 200",  overwrite=True)
-        cls.runModule("r.mapcalc", expression="a_3 = 300",  overwrite=True)
-        cls.runModule("r.mapcalc", expression="a_4 = 400",  overwrite=True)
-        cls.runModule("v.random", output="points", npoints=3, seed=1, overwrite=True)
+        cls.runModule("r.mapcalc", expression="a_1 = 100", overwrite=True)
+        cls.runModule("r.mapcalc", expression="a_2 = 200", overwrite=True)
+        cls.runModule("r.mapcalc", expression="a_3 = 300", overwrite=True)
+        cls.runModule("r.mapcalc", expression="a_4 = 400", overwrite=True)
-        cls.runModule("t.create",  type="strds",  temporaltype="absolute",
-                                 output="A",  title="A test",  description="A test",
-                                 overwrite=True)
-        cls.runModule("t.register",  flags="i",  type="raster",  input="A",
-                                     maps="a_1,a_2,a_3,a_4",  start="2001-01-01",
-                                     increment="3 months",  overwrite=True)
+        cls.runModule("v.random", output="points", npoints=3, seed=1,
+                      overwrite=True)
+        cls.runModule("t.create", type="strds", temporaltype="absolute",
+                      output="A", title="A test", description="A test",
+                      overwrite=True)
+        cls.runModule("t.register", flags="i", type="raster", input="A",
+                      maps="a_1,a_2,a_3,a_4", start="2001-01-01",
+                      increment="3 months", overwrite=True)
     @classmethod
     def tearDownClass(cls):
         """Remove the temporary region
-        cls.runModule("t.remove",  flags="rf",  type="strds",
-                                   inputs="A")
+        cls.runModule("t.remove", flags="rf", type="strds", inputs="A")
         cls.del_temp_region()
     def test_row_output(self):
-        self.assertModule("t.rast.what",  strds="A",  output="out_row.txt",
-                          points="points", flags="n",
-                          layout="row",
-                          nprocs=1,  overwrite=True,  verbose=True)
+        self.assertModule("t.rast.what", strds="A", output="out_row.txt",
+                          points="points", flags="n", layout="row",
+                          nprocs=1, overwrite=True, verbose=True)
-        self.assertFileMd5("out_row.txt", "55209718566d70e1427bd1fecf844d53", text=True)
+        self.assertFileMd5("out_row.txt", "55209718566d70e1427bd1fecf844d53",
+                           text=True)
     def test_row_output_coords(self):
-        self.assertModule("t.rast.what",  strds="A",  output="out_row_coords.txt",
-                          coordinates=(30,30, 45, 45), flags="n",
-                          layout="row",
+        self.assertModule("t.rast.what", strds="A", output="out_row_coords.txt",
+                          coordinates=(30, 30, 45, 45), flags="n", layout="row",
-        self.assertFileMd5("out_row_coords.txt", "cd917ac4848786f1b944512eed1da5bc", text=True)
+        self.assertFileMd5("out_row_coords.txt",
+                           "cd917ac4848786f1b944512eed1da5bc", text=True)
     def test_row_output_coords_stdin(self):
-                          flags="ni",
-                          layout="row", stdin_="30 30\n45 45",
+                          flags="ni", layout="row", stdin_="30 30\n45 45",
     def test_col_output(self):
-        self.assertModule("t.rast.what",  strds="A",  output="out_col.txt",
-                          layout="col",
+        self.assertModule("t.rast.what", strds="A", output="out_col.txt",
+                          points="points", flags="n", layout="col",
-        self.assertFileMd5("out_col.txt", "8720cc237b46ddb18f11440469d0e13f", text=True)
+        self.assertFileMd5("out_col.txt",
+                           "8720cc237b46ddb18f11440469d0e13f", text=True)
     def test_col_output_coords(self):
-        self.assertModule("t.rast.what",  strds="A",  output="out_col_coords.txt",
-                          layout="col",
+        self.assertModule("t.rast.what", strds="A", output="out_col_coords.txt",
+                          coordinates=(30, 30, 45, 45), flags="n", layout="col",
-        self.assertFileMd5("out_col_coords.txt", "ac44ebc5aa040d4ce2a5787e95f208ec", text=True)
+        self.assertFileMd5("out_col_coords.txt",
+                           "ac44ebc5aa040d4ce2a5787e95f208ec", text=True)
     def test_timerow_output(self):
-        self.assertModule("t.rast.what",  strds="A",  output="out_timerow.txt",
-                          layout="timerow",
+        self.assertModule("t.rast.what", strds="A", output="out_timerow.txt",
+                          points="points", flags="n", layout="timerow",
-        self.assertFileMd5("out_timerow.txt", "129fe0b63019e505232efa20ad42c03a", text=True)
+        self.assertFileMd5("out_timerow.txt",
+                           "129fe0b63019e505232efa20ad42c03a", text=True)
     def test_timerow_output_coords(self):
-        self.assertModule("t.rast.what",  strds="A",  output="out_timerow_coords.txt",
-                          layout="timerow",
+        self.assertModule("t.rast.what", strds="A", output="out_timerow_coords.txt",
+                          coordinates=(30, 30, 45, 45), flags="n", layout="timerow",
-        self.assertFileMd5("out_timerow_coords.txt", "ca4ee0e7e4aaca170d6034e0d57d292d", text=True)
+        self.assertFileMd5("out_timerow_coords.txt",
+                           "ca4ee0e7e4aaca170d6034e0d57d292d", text=True)
     def test_row_stdout_where_parallel(self):
-        t_rast_what = SimpleModule("t.rast.what",  strds="A",  output="-",
-                                                      where="start_time > '2001-03-01'",
-                                                      nprocs=4,  overwrite=True,  verbose=True)
+        t_rast_what = SimpleModule("t.rast.what", strds="A", output="-",
+                                   where="start_time > '2001-03-01'",
+                                   nprocs=4, overwrite=True, verbose=True)
         self.assertModule(t_rast_what)
-        text="""x|y|start|end|value
+        text = """x|y|start|end|value
 115.0043586274|36.3593955783|2001-04-01 00:00:00|2001-07-01 00:00:00|200
 79.6816763826|45.2391522853|2001-04-01 00:00:00|2001-07-01 00:00:00|200
 97.4892579600|79.2347263950|2001-04-01 00:00:00|2001-07-01 00:00:00|200
@@ -119,18 +120,17 @@
 79.6816763826|45.2391522853|2001-10-01 00:00:00|2002-01-01 00:00:00|400
 97.4892579600|79.2347263950|2001-10-01 00:00:00|2002-01-01 00:00:00|400
-        self.assertLooksLike(text,  t_rast_what.outputs.stdout)
+        self.assertLooksLike(text, t_rast_what.outputs.stdout)
     def test_row_stdout_where_parallel2(self):
         """Here without output definition, the default is used then"""
+        t_rast_what = SimpleModule("t.rast.what", strds="A", points="points",
+                                   flags="n", where="start_time > '2001-03-01'",
@@ -141,32 +141,34 @@
     def test_row_output_where_parallel(self):
-        self.assertModule("t.rast.what",  strds="A",  output="out_where.txt",
+        self.assertModule("t.rast.what", strds="A", output="out_where.txt",
-        self.assertFileMd5("out_where.txt", "af731bec01fedc262f4ac162fe420707", text=True)
+        self.assertFileMd5("out_where.txt",
+                           "af731bec01fedc262f4ac162fe420707", text=True)
     def test_empty_strds(self):
-        self.assertModuleFail("t.rast.what",  strds="A",  output="out_error.txt",
-                          where="start_time > '2002-03-01'",
+        self.assertModuleFail("t.rast.what", strds="A", output="out_error.txt",
+                              where="start_time > '2002-03-01'",
 class TestRasterWhatFails(TestCase):
     def test_error_handling(self):
         # No vector map, no strds, no coordinates
-        self.assertModuleFail("t.rast.what",  output="out.txt")
+        self.assertModuleFail("t.rast.what", output="out.txt")
         # No vector map, no coordinates
-        self.assertModuleFail("t.rast.what",  strds="A",  output="out.txt")
+        self.assertModuleFail("t.rast.what", strds="A", output="out.txt")
         # Points and coordinates are mutually exclusive
-        self.assertModuleFail("t.rast.what",  points="points", coordinates=(30, 30, 45, 45),  output="out.txt",  strds="A")
+        self.assertModuleFail("t.rast.what", points="points", strds="A",
+                              coordinates=(30, 30, 45, 45), output="out.txt")
 if __name__ == '__main__':
     from grass.gunittest.main import test
