[GRASS-SVN] r71632 - in grass/trunk/raster: . r.geomorphon r.param.scale
Fri Nov 3 09:43:03 PDT 2017
Author: neteler
Date: 2017-11-03 09:43:02 -0700 (Fri, 03 Nov 2017)
New Revision: 71632
Added:
   grass/trunk/raster/r.geomorphon/
Removed:
   grass/trunk/raster/r.geomorphon/test_rgeomorphon_NC.sh
   grass/trunk/raster/Makefile
   grass/trunk/raster/r.geomorphon/main.c
   grass/trunk/raster/r.geomorphon/multires.c
   grass/trunk/raster/r.geomorphon/pattern.c
   grass/trunk/raster/r.param.scale/r.param.scale.html
r.geomorphon: moved to trunk from Addons
Modified: grass/trunk/raster/Makefile
--- grass/trunk/raster/Makefile	2017-11-03 08:19:17 UTC (rev 71631)
+++ grass/trunk/raster/Makefile	2017-11-03 16:43:02 UTC (rev 71632)
@@ -23,6 +23,7 @@
 	r.external.out \
 	r.fill.dir \
 	r.flow \
+	r.geomorphon \
 	r.grow.distance \
 	r.gwflow \
 	r.his \
Modified: grass/trunk/raster/r.geomorphon/main.c
--- grass-addons/grass7/raster/r.geomorphon/main.c	2017-11-03 08:19:17 UTC (rev 71631)
+++ grass/trunk/raster/r.geomorphon/main.c	2017-11-03 16:43:02 UTC (rev 71632)
@@ -434,7 +434,7 @@
 		    ((FCELL *) rasters[o_variance].buffer)[col] =
 			variance(pattern->elevation, pattern_size);
-		//                       used only for next four shape functions
+		/*                       used only for next four shape functions */
 		if (opt_output[o_elongation]->answer ||
 		    opt_output[o_azimuth]->answer ||
 		    opt_output[o_extend]->answer ||
Modified: grass/trunk/raster/r.geomorphon/multires.c
--- grass-addons/grass7/raster/r.geomorphon/multires.c	2017-11-03 08:19:17 UTC (rev 71631)
+++ grass/trunk/raster/r.geomorphon/multires.c	2017-11-03 16:43:02 UTC (rev 71632)
@@ -1,8 +1,5 @@
 #include "local_proto.h"
 int pattern_matching(int *pattern)
     int n, i;
Modified: grass/trunk/raster/r.geomorphon/pattern.c
--- grass-addons/grass7/raster/r.geomorphon/pattern.c	2017-11-03 08:19:17 UTC (rev 71631)
+++ grass/trunk/raster/r.geomorphon/pattern.c	2017-11-03 16:43:02 UTC (rev 71632)
@@ -1,4 +1,5 @@
 /*directions
  * 3|2|1
  * 4|0|8
@@ -74,7 +75,7 @@
 		nadir_distance = cur_distance;
 	    j += cell_step;
-	    //              j++; /* go to next cell */
+	    /*             j++; */ /* go to next cell */
 	    target_northing =
 		Rast_row_to_northing(row + j * nextr[i] + 0.5, &window);
 	    target_easting =
@@ -124,13 +125,13 @@
 	    fabs(nadir_angle) > nadir_threshold) {
 	    if (fabs(nadir_angle) < fabs(zenith_angle)) {
 		pattern->pattern[i] = 1;
-		pattern->elevation[i] = zenith_height;	//ZMIANA!
+		pattern->elevation[i] = zenith_height;	/* ZMIANA! */
 		pattern->distance[i] = zenith_distance;
 		pattern->num_positives++;
 	    if (fabs(nadir_angle) > fabs(zenith_angle)) {
 		pattern->pattern[i] = -1;
-		pattern->elevation[i] = nadir_height;	//ZMIANA!
+		pattern->elevation[i] = nadir_height;	/* ZMIANA! */
 		pattern->distance[i] = nadir_distance;
 		pattern->num_negatives++;
Deleted: grass/trunk/raster/r.geomorphon/test_rgeomorphon_NC.sh
--- grass-addons/grass7/raster/r.geomorphon/test_rgeomorphon_NC.sh	2017-11-03 08:19:17 UTC (rev 71631)
+++ grass/trunk/raster/r.geomorphon/test_rgeomorphon_NC.sh	2017-11-03 16:43:02 UTC (rev 71632)
@@ -1,36 +0,0 @@
-#!/bin/sh
-# 2017, Markus Neteler
-# synthetic test case for r.geomorphon
-GRASSDATA=$HOME/grassdata
-grass72 $GRASSDATA/nc_spm_08_grass7/user1/
-# computational region of NC
-g.region raster=elevation -p
-# generate a synthetic, non-symmetric DEM
-r.mapcalc "synthetic_dem = sin(x() / 5.0) + (sin(x() / 5.0) * 100.0 + 200)"
-# d.mon wx0
-# d.rast synthetic_dem
-# calculate geomorphon forms
-r.geomorphon elevation=synthetic_dem forms=synthetic_dem_geomorph search=10
-# expected result:
-r.category synthetic_dem_geomorph
-#1	flat
-#3	ridge
-#4	shoulder
-#6	slope
-#8	footslope
-#9	valley
-# further visual inspection
-# d.rast synthetic_dem_geomorph
-# r.relief synthetic_dem out=synthetic_dem_shaded
-# d.shade shade=synthetic_dem_shaded color=synthetic_dem_geomorph
Modified: grass/trunk/raster/r.param.scale/r.param.scale.html
--- grass/trunk/raster/r.param.scale/r.param.scale.html	2017-11-03 08:19:17 UTC (rev 71631)
+++ grass/trunk/raster/r.param.scale/r.param.scale.html	2017-11-03 16:43:02 UTC (rev 71632)
@@ -104,11 +104,9 @@
 </ul>
 <h2>SEE ALSO</h2>
-<!-- not ported to GRASS 6 due to non-GPLness of numerical recipes.
-<i><a href="d.param.scale.html">d.param.scale</a></i>
 <em>
+  <a href="r.geomorphon.html">r.geomorphon</a>,
   <a href="r.slope.aspect.html">r.slope.aspect</a>
 </em>
