[GRASS-SVN] r71654 - in grass-addons/grass7/raster/r.object.geometry: . testsuite testsuite/data
Fri Nov 10 07:19:57 PST 2017
Author: mlennert
Date: 2017-11-10 07:19:57 -0800 (Fri, 10 Nov 2017)
New Revision: 71654
Added:
   grass-addons/grass7/raster/r.object.geometry/testsuite/
   grass-addons/grass7/raster/r.object.geometry/testsuite/data/
   grass-addons/grass7/raster/r.object.geometry/testsuite/data/file_meter.csv
   grass-addons/grass7/raster/r.object.geometry/testsuite/data/file_pixel.csv
   grass-addons/grass7/raster/r.object.geometry/testsuite/r_object_geometry_test.py
   grass-addons/grass7/raster/r.object.geometry/testsuite/test_keyvalue_result.txt
r.object.geometry: add first tests
Added: grass-addons/grass7/raster/r.object.geometry/testsuite/data/file_meter.csv
--- grass-addons/grass7/raster/r.object.geometry/testsuite/data/file_meter.csv	                        (rev 0)
+++ grass-addons/grass7/raster/r.object.geometry/testsuite/data/file_meter.csv	2017-11-10 15:19:57 UTC (rev 71654)
@@ -0,0 +1,4 @@
+cat|area|perimeter|compact_square|compact_circle|fd
+1|750000000.000000|110000.000000|0.995859|1.133071|1.136081
+2|1500000000.000000|160000.000000|0.968246|1.165385|1.134278
+3|750000000.000000|110000.000000|0.995859|1.133071|1.136081
Added: grass-addons/grass7/raster/r.object.geometry/testsuite/data/file_pixel.csv
--- grass-addons/grass7/raster/r.object.geometry/testsuite/data/file_pixel.csv	                        (rev 0)
+++ grass-addons/grass7/raster/r.object.geometry/testsuite/data/file_pixel.csv	2017-11-10 15:19:57 UTC (rev 71654)
@@ -0,0 +1,4 @@
+1|4.000000|8.000000|1.000000|1.128379|2.999459
+2|8.000000|12.000000|0.942809|1.196827|2.389831
+3|4.000000|8.000000|1.000000|1.128379|2.999459
Added: grass-addons/grass7/raster/r.object.geometry/testsuite/r_object_geometry_test.py
--- grass-addons/grass7/raster/r.object.geometry/testsuite/r_object_geometry_test.py	                        (rev 0)
+++ grass-addons/grass7/raster/r.object.geometry/testsuite/r_object_geometry_test.py	2017-11-10 15:19:57 UTC (rev 71654)
@@ -0,0 +1,112 @@
+Name:      r_object_geometry_test
+Purpose:   This script is to demonstrate a unit test for r.object.geometry
+           module.
+import os
+from grass.gunittest.case import TestCase
+from grass.gunittest.main import test
+testraster1 = """\
+north:   250000
+south:   200000
+east:    670000
+west:    610000
+rows:    4
+cols:    4
+1 1 2 2
+1 1 2 2
+3 3 2 2
+3 3 2 2
+class TestObjectGeometryPixel(TestCase):
+    """Test case for object geometry module"""
+    # Setup variables to be used for outputs
+    test_objects1 = 'test_objects1'
+    output_file_pixel = 'output_file_pixel.csv'
+    @classmethod
+    def setUpClass(cls):
+        """Imports test raster(s), ensures expected computational region and setup"""
+        cls.runModule('r.in.ascii', input='-', stdin_=testraster1,
+                output=cls.test_objects1)
+        cls.use_temp_region()
+        cls.runModule('g.region', raster=cls.test_objects1)
+    @classmethod
+    def tearDownClass(cls):
+        """Remove the temporary region"""
+        cls.del_temp_region()
+    def tearDown(self):
+        """Remove the outputs created from the object geometry module
+        This is executed after each test run.
+        if os.path.isfile(self.output_file_pixel):
+            os.remove(self.output_file_pixel)
+        self.runModule('g.remove', flags='f', type='raster',
+                       name=self.test_objects1)
+    def test_object_geometry_pixel(self):
+        """Test to see if the outputs are created and are correct in pixel units"""
+        # run the object geometry module
+        self.assertModule('r.object.geometry', input=self.test_objects1,
+                          output=self.output_file_pixel)
+        # check to see if output file exists
+        self.assertFileExists(self.output_file_pixel,
+                               msg='Output file does not exist')
+        # check if the output file is equal to the reference file
+        self.assertFilesEqualMd5(self.output_file_pixel, 'data/file_pixel.csv',
+                               msg='Output file is not equal to reference file')
+class TestObjectGeometryMeter(TestCase):
+    output_file_meter = 'output_file_meter.csv'
+    @classmethod
+    @classmethod
+        if os.path.isfile(self.output_file_meter):
+            os.remove(self.output_file_meter)
+    def test_object_geometry_meter(self):
+        """Test to see if the outputs are created and are correct in meter units"""
+                          output=self.output_file_meter, flags='m')
+        self.assertFileExists(self.output_file_meter,
+        self.assertFilesEqualMd5(self.output_file_meter, 'data/file_meter.csv',
+if __name__ == '__main__':
+    test()
Added: grass-addons/grass7/raster/r.object.geometry/testsuite/test_keyvalue_result.txt
--- grass-addons/grass7/raster/r.object.geometry/testsuite/test_keyvalue_result.txt	                        (rev 0)
+++ grass-addons/grass7/raster/r.object.geometry/testsuite/test_keyvalue_result.txt	2017-11-10 15:19:57 UTC (rev 71654)
@@ -0,0 +1,12 @@
+time=0.571s
+status=succeeded
+total=2
+failures=0
+errors=0
+successes=2
+skipped=0
+expected_failures=0
+unexpected_successes=0
+tested_modules=r.object.geometry,r.object.geometry
+supplementary_files=
+test_type=not-specified
