[GRASS-SVN] r71751 - grass/branches/releasebranch_7_4
svn_grass at osgeo.org
Thu Nov 16 22:48:34 PST 2017
Author: neteler
Date: 2017-11-16 22:48:34 -0800 (Thu, 16 Nov 2017)
New Revision: 71751
grass/branches/releasebranch_7_4/config.guess
grass/branches/releasebranch_7_4/config.sub
config.guess + config.sub: updated from http://git.savannah.gnu.org/cgit/config.git/plain/
Modified: grass/branches/releasebranch_7_4/config.guess
--- grass/branches/releasebranch_7_4/config.guess 2017-11-17 06:38:41 UTC (rev 71750)
+++ grass/branches/releasebranch_7_4/config.guess 2017-11-17 06:48:34 UTC (rev 71751)
@@ -2,7 +2,7 @@
# Attempt to guess a canonical system name.
# Copyright 1992-2017 Free Software Foundation, Inc.
-timestamp='2017-08-08'
+timestamp='2017-11-07'
# This file is free software; you can redistribute it and/or modify it
# under the terms of the GNU General Public License as published by
@@ -15,7 +15,7 @@
# General Public License for more details.
# You should have received a copy of the GNU General Public License
-# along with this program; if not, see <http://www.gnu.org/licenses/>.
+# along with this program; if not, see <https://www.gnu.org/licenses/>.
# As a special exception to the GNU General Public License, if you
# distribute this file as part of a program that contains a
@@ -27,7 +27,7 @@
# Originally written by Per Bothner; maintained since 2000 by Ben Elliston.
# You can get the latest version of this script from:
-# http://git.savannah.gnu.org/gitweb/?p=config.git;a=blob_plain;f=config.guess
+# https://git.savannah.gnu.org/gitweb/?p=config.git;a=blob_plain;f=config.guess
# Please send patches to <config-patches at gnu.org>.
@@ -39,7 +39,7 @@
Output the configuration name of the system \`$me' is run on.
-Operation modes:
+Options:
-h, --help print this help, then exit
-t, --time-stamp print date of last modification, then exit
-v, --version print version number, then exit
@@ -244,6 +244,9 @@
UNAME_MACHINE_ARCH=`arch | sed 's/^.*BSD\.//'`
echo ${UNAME_MACHINE_ARCH}-unknown-libertybsd${UNAME_RELEASE}
exit ;;
+ *:MidnightBSD:*:*)
+ echo ${UNAME_MACHINE}-unknown-midnightbsd${UNAME_RELEASE}
+ exit ;;
*:ekkoBSD:*:*)
echo ${UNAME_MACHINE}-unknown-ekkobsd${UNAME_RELEASE}
exit ;;
@@ -318,15 +321,6 @@
exitcode=$?
trap '' 0
exit $exitcode ;;
- Alpha\ *:Windows_NT*:*)
- # How do we know it's Interix rather than the generic POSIX subsystem?
- # Should we change UNAME_MACHINE based on the output of uname instead
- # of the specific Alpha model?
- echo alpha-pc-interix
- exit ;;
- 21064:Windows_NT:50:3)
- echo alpha-dec-winnt3.5
- exit ;;
Amiga*:UNIX_System_V:4.0:*)
echo m68k-unknown-sysv4
exit ;;
@@ -488,13 +482,13 @@
#endif
#if defined (host_mips) && defined (MIPSEB)
#if defined (SYSTYPE_SYSV)
- printf ("mips-mips-riscos%ssysv\n", argv[1]); exit (0);
+ printf ("mips-mips-riscos%ssysv\\n", argv[1]); exit (0);
#endif
#if defined (SYSTYPE_SVR4)
- printf ("mips-mips-riscos%ssvr4\n", argv[1]); exit (0);
+ printf ("mips-mips-riscos%ssvr4\\n", argv[1]); exit (0);
#endif
#if defined (SYSTYPE_BSD43) || defined(SYSTYPE_BSD)
- printf ("mips-mips-riscos%sbsd\n", argv[1]); exit (0);
+ printf ("mips-mips-riscos%sbsd\\n", argv[1]); exit (0);
#endif
#endif
exit (-1);
@@ -617,7 +611,7 @@
*:AIX:*:*)
echo rs6000-ibm-aix
exit ;;
- ibmrt:4.4BSD:*|romp-ibm:BSD:*)
+ ibmrt:4.4BSD:*|romp-ibm:4.4BSD:*)
echo romp-ibm-bsd4.4
exit ;;
ibmrt:*BSD:*|romp-ibm:BSD:*) # covers RT/PC BSD and
@@ -638,8 +632,8 @@
9000/[34678]??:HP-UX:*:*)
HPUX_REV=`echo ${UNAME_RELEASE}|sed -e 's/[^.]*.[0B]*//'`
case "${UNAME_MACHINE}" in
- 9000/31? ) HP_ARCH=m68000 ;;
- 9000/[34]?? ) HP_ARCH=m68k ;;
+ 9000/31?) HP_ARCH=m68000 ;;
+ 9000/[34]??) HP_ARCH=m68k ;;
9000/[678][0-9][0-9])
if [ -x /usr/bin/getconf ]; then
sc_cpu_version=`/usr/bin/getconf SC_CPU_VERSION 2>/dev/null`
@@ -752,7 +746,7 @@
{ echo "$SYSTEM_NAME"; exit; }
echo unknown-hitachi-hiuxwe2
exit ;;
- 9000/7??:4.3bsd:*:* | 9000/8?[79]:4.3bsd:*:* )
+ 9000/7??:4.3bsd:*:* | 9000/8?[79]:4.3bsd:*:*)
echo hppa1.1-hp-bsd
exit ;;
9000/8??:4.3bsd:*:*)
@@ -761,7 +755,7 @@
*9??*:MPE/iX:*:* | *3000*:MPE/iX:*:*)
echo hppa1.0-hp-mpeix
exit ;;
- hp7??:OSF1:*:* | hp8?[79]:OSF1:*:* )
+ hp7??:OSF1:*:* | hp8?[79]:OSF1:*:*)
echo hppa1.1-hp-osf
exit ;;
hp8??:OSF1:*:*)
@@ -858,10 +852,6 @@
*:MSYS*:*)
echo ${UNAME_MACHINE}-pc-msys
exit ;;
- i*:windows32*:*)
- # uname -m includes "-pc" on this system.
- echo ${UNAME_MACHINE}-mingw32
- exit ;;
i*:PW*:*)
echo ${UNAME_MACHINE}-pc-pw32
exit ;;
@@ -877,27 +867,12 @@
echo ia64-unknown-interix${UNAME_RELEASE}
exit ;;
esac ;;
- [345]86:Windows_95:* | [345]86:Windows_98:* | [345]86:Windows_NT:*)
- echo i${UNAME_MACHINE}-pc-mks
- exit ;;
- 8664:Windows_NT:*)
- echo x86_64-pc-mks
- exit ;;
- i*:Windows_NT*:* | Pentium*:Windows_NT*:*)
- # It also conflicts with pre-2.0 versions of AT&T UWIN. Should we
- # UNAME_MACHINE based on the output of uname instead of i386?
- echo i586-pc-interix
- exit ;;
i*:UWIN*:*)
echo ${UNAME_MACHINE}-pc-uwin
exit ;;
amd64:CYGWIN*:*:* | x86_64:CYGWIN*:*:*)
echo x86_64-unknown-cygwin
exit ;;
- p*:CYGWIN*:*)
- echo powerpcle-unknown-cygwin
- exit ;;
prep*:SunOS:5.*:*)
echo powerpcle-unknown-solaris2`echo ${UNAME_RELEASE}|sed -e 's/[^.]*//'`
exit ;;
@@ -1100,7 +1075,7 @@
i*86:*DOS:*:*)
echo ${UNAME_MACHINE}-pc-msdosdjgpp
exit ;;
- i*86:*:4.*:* | i*86:SYSTEM_V:4.*:*)
+ i*86:*:4.*:*)
UNAME_REL=`echo ${UNAME_RELEASE} | sed 's/\/MP$//'`
if grep Novell /usr/include/link.h >/dev/null 2>/dev/null; then
echo ${UNAME_MACHINE}-univel-sysv${UNAME_REL}
@@ -1428,16 +1403,28 @@
exit ;;
esac
+echo "$0: unable to guess system type" >&2
+case "${UNAME_MACHINE}:${UNAME_SYSTEM}" in
+ mips:Linux | mips64:Linux)
+ # If we got here on MIPS GNU/Linux, output extra information.
+ cat >&2 <<EOF
+NOTE: MIPS GNU/Linux systems require a C compiler to fully recognize
+the system type. Please install a C compiler and try again.
+EOF
+esac
cat >&2 <<EOF
-$0: unable to guess system type
This script (version $timestamp), has failed to recognize the
operating system you are using. If your script is old, overwrite *all*
copies of config.guess and config.sub with the latest versions from:
- http://git.savannah.gnu.org/gitweb/?p=config.git;a=blob_plain;f=config.guess
+ https://git.savannah.gnu.org/gitweb/?p=config.git;a=blob_plain;f=config.guess
and
- http://git.savannah.gnu.org/gitweb/?p=config.git;a=blob_plain;f=config.sub
+ https://git.savannah.gnu.org/gitweb/?p=config.git;a=blob_plain;f=config.sub
If $0 has already been updated, send the following data and any
information you think might be pertinent to config-patches at gnu.org to
@@ -1469,7 +1456,7 @@
exit 1
# Local variables:
-# eval: (add-hook 'write-file-hooks 'time-stamp)
+# eval: (add-hook 'write-file-functions 'time-stamp)
# time-stamp-start: "timestamp='"
# time-stamp-format: "%:y-%02m-%02d"
# time-stamp-end: "'"
Modified: grass/branches/releasebranch_7_4/config.sub
--- grass/branches/releasebranch_7_4/config.sub 2017-11-17 06:38:41 UTC (rev 71750)
+++ grass/branches/releasebranch_7_4/config.sub 2017-11-17 06:48:34 UTC (rev 71751)
@@ -2,7 +2,7 @@
# Configuration validation subroutine script.
-timestamp='2017-04-02'
+timestamp='2017-11-04'
@@ -15,7 +15,7 @@
@@ -33,7 +33,7 @@
# Otherwise, we print the canonical config type on stdout and succeed.
-# http://git.savannah.gnu.org/gitweb/?p=config.git;a=blob_plain;f=config.sub
+# https://git.savannah.gnu.org/gitweb/?p=config.git;a=blob_plain;f=config.sub
# This file is supposed to be the same for all GNU packages
# and recognize all the CPU types, system types and aliases
@@ -57,7 +57,7 @@
Canonicalize a configuration name.
-Operation modes:
+Options:
@@ -229,9 +229,6 @@
-ptx*)
basic_machine=`echo $1 | sed -e 's/86-.*/86-sequent/'`
- -windowsnt*)
- os=`echo $os | sed -e 's/windowsnt/winnt/'`
-psos*)
os=-psos
@@ -316,7 +313,6 @@
| v850 | v850e | v850e1 | v850e2 | v850es | v850e2v3 \
| visium \
| wasm32 \
- | we32k \
| x86 | xc16x | xstormy16 | xtensa \
| z8k | z80)
basic_machine=$basic_machine-unknown
@@ -643,7 +639,7 @@
basic_machine=rs6000-bull
os=-bosx
- dpx2* | dpx2*-bull)
+ dpx2*)
basic_machine=m68k-bull
os=-sysv3
@@ -905,7 +901,7 @@
basic_machine=v70-nec
os=-sysv
- next | m*-next )
+ next | m*-next)
basic_machine=m68k-next
case $os in
-nextstep* )
@@ -1259,6 +1255,9 @@
basic_machine=hppa1.1-winbond
os=-proelf
+ x64)
+ basic_machine=x86_64-pc
xbox)
basic_machine=i686-pc
os=-mingw32
@@ -1366,8 +1365,8 @@
if [ x"$os" != x"" ]
then
case $os in
- # First match some system type aliases
- # that might get confused with valid system types.
+ # First match some system type aliases that might get confused
+ # with valid system types.
# -solaris* is a basic system type, with this one exception.
-auroraux)
os=-auroraux
@@ -1387,9 +1386,9 @@
-gnu/linux*)
os=`echo $os | sed -e 's|gnu/linux|linux-gnu|'`
- # First accept the basic system types.
+ # Now accept the basic system types.
# The portable systems comes first.
- # Each alternative MUST END IN A *, to match a version number.
+ # Each alternative MUST end in a * to match a version number.
# -sysv* is not here because it comes later, after sysvr4.
-gnu* | -bsd* | -mach* | -minix* | -genix* | -ultrix* | -irix* \
| -*vms* | -sco* | -esix* | -isc* | -aix* | -cnk* | -sunos | -sunos[34]*\
@@ -1492,7 +1491,7 @@
-nova*)
os=-rtmk-nova
- -ns2 )
+ -ns2)
os=-nextstep2
-nsk*)
@@ -1694,7 +1693,7 @@
m88k-omron*)
os=-luna
- *-next )
+ *-next)
os=-nextstep
*-sequent)
@@ -1829,7 +1828,7 @@
exit
# Local variables:
