[GRASS-SVN] r71774 - in grass/trunk: raster/r.in.gdal temporal/t.rast.import temporal/t.vect.import vector/v.in.ogr
Sun Nov 19 09:45:28 PST 2017
Author: neteler
Date: 2017-11-19 09:45:28 -0800 (Sun, 19 Nov 2017)
New Revision: 71774
   grass/trunk/raster/r.in.gdal/main.c
   grass/trunk/temporal/t.rast.import/t.rast.import.py
   grass/trunk/temporal/t.vect.import/t.vect.import.py
   grass/trunk/vector/v.in.ogr/main.c
various commands: keywords added
Modified: grass/trunk/raster/r.in.gdal/main.c
--- grass/trunk/raster/r.in.gdal/main.c	2017-11-19 17:44:41 UTC (rev 71773)
+++ grass/trunk/raster/r.in.gdal/main.c	2017-11-19 17:45:28 UTC (rev 71774)
@@ -92,6 +92,7 @@
     module = G_define_module();
     G_add_keyword(_("raster"));
     G_add_keyword(_("import"));
+    G_add_keyword(_("create location"));
     module->description =
 	_("Imports raster data into a GRASS raster map using GDAL library.");
Modified: grass/trunk/temporal/t.rast.import/t.rast.import.py
--- grass/trunk/temporal/t.rast.import/t.rast.import.py	2017-11-19 17:44:41 UTC (rev 71773)
+++ grass/trunk/temporal/t.rast.import/t.rast.import.py	2017-11-19 17:45:28 UTC (rev 71774)
@@ -20,6 +20,7 @@
 #% keyword: import
 #% keyword: raster
 #% keyword: time
+#% keyword: create location
 #%end
 #%option G_OPT_F_INPUT
Modified: grass/trunk/temporal/t.vect.import/t.vect.import.py
--- grass/trunk/temporal/t.vect.import/t.vect.import.py	2017-11-19 17:44:41 UTC (rev 71773)
+++ grass/trunk/temporal/t.vect.import/t.vect.import.py	2017-11-19 17:45:28 UTC (rev 71774)
@@ -20,6 +20,7 @@
 #% keyword: import
 #% keyword: vector
 #% keyword: time
 #%end
Modified: grass/trunk/vector/v.in.ogr/main.c
--- grass/trunk/vector/v.in.ogr/main.c	2017-11-19 17:44:41 UTC (rev 71773)
+++ grass/trunk/vector/v.in.ogr/main.c	2017-11-19 17:45:28 UTC (rev 71774)
@@ -169,6 +169,10 @@
     G_add_keyword(_("vector"));
     G_add_keyword("OGR");
+    G_add_keyword(_("topology"));
+    G_add_keyword(_("geometry"));
+    G_add_keyword(_("snapping"));
     module->description = _("Imports vector data into a GRASS vector map using OGR library.");
     param.dsn = G_define_option();
