[GRASS-SVN] r71788 - in grass/branches/releasebranch_7_4/vector/v.profile: . testsuite
Mon Nov 20 12:18:25 PST 2017
Author: marisn
Date: 2017-11-20 12:18:25 -0800 (Mon, 20 Nov 2017)
New Revision: 71788
   grass/branches/releasebranch_7_4/vector/v.profile/Makefile
   grass/branches/releasebranch_7_4/vector/v.profile/main.c
   grass/branches/releasebranch_7_4/vector/v.profile/testsuite/test_v_profile.py
   grass/branches/releasebranch_7_4/vector/v.profile/v.profile.html
v.profile: Generate buffers with GEOS. Backport of r71769
Modified: grass/branches/releasebranch_7_4/vector/v.profile/Makefile
--- grass/branches/releasebranch_7_4/vector/v.profile/Makefile	2017-11-20 19:46:24 UTC (rev 71787)
+++ grass/branches/releasebranch_7_4/vector/v.profile/Makefile	2017-11-20 20:18:25 UTC (rev 71788)
@@ -3,10 +3,10 @@
 PGM = v.profile
-LIBES = $(VECTORLIB) $(DBMILIB) $(GISLIB)
+LIBES = $(VECTORLIB) $(DBMILIB) $(GISLIB) $(GEOSLIBS)
 DEPENDENCIES = $(VECTORDEP) $(DBMIDEP) $(GISDEP)
 EXTRA_INC = $(VECT_INC)
-EXTRA_CFLAGS = $(VECT_CFLAGS)
+EXTRA_CFLAGS = $(VECT_CFLAGS) $(GEOSCFLAGS)
 include $(MODULE_TOPDIR)/include/Make/Module.make
Modified: grass/branches/releasebranch_7_4/vector/v.profile/main.c
--- grass/branches/releasebranch_7_4/vector/v.profile/main.c	2017-11-20 19:46:24 UTC (rev 71787)
+++ grass/branches/releasebranch_7_4/vector/v.profile/main.c	2017-11-20 20:18:25 UTC (rev 71788)
@@ -37,6 +37,78 @@
 #include "local_proto.h"
+#if HAVE_GEOS
+#include <float.h>
+/* A copy of ring2pts from v.buffer geos.c
+ * It is a terrible approach to copy/pasta functions around,
+ * but all this GEOS stuff is just a temporary solution before native
+ * buffers are fixed. (Will happen at some point after next ten years
+ * or so as there's nothing more permanent than a temporary solution.)
+ * 2017-11-19
+static int ring2pts(const GEOSGeometry *geom, struct line_pnts *Points)
+    int i, ncoords;
+    double x, y, z;
+    const GEOSCoordSequence *seq = NULL;
+    G_debug(3, "ring2pts()");
+    Vect_reset_line(Points);
+    if (!geom) {
+	G_warning(_("Invalid GEOS geometry!"));
+	return 0;
+    z = 0.0;
+    ncoords = GEOSGetNumCoordinates(geom);
+    if (!ncoords) {
+	G_warning(_("No coordinates in GEOS geometry (can be ok for negative distance)!"));
+	return 0;
+    seq = GEOSGeom_getCoordSeq(geom);
+    for (i = 0; i < ncoords; i++) {
+	GEOSCoordSeq_getX(seq, i, &x);
+	GEOSCoordSeq_getY(seq, i, &y);
+	if (x != x || x > DBL_MAX || x < -DBL_MAX)
+	    G_fatal_error(_("Invalid x coordinate %f"), x);
+	if (y != y || y > DBL_MAX || y < -DBL_MAX)
+	    G_fatal_error(_("Invalid y coordinate %f"), y);
+	Vect_append_point(Points, x, y, z);
+    return 1;
+/* Helper for converting multipoligons to GRASS poligons */
+static int add_poly(const GEOSGeometry *OGeom, struct line_pnts *Buffer) {
+    const GEOSGeometry *geom2;
+    static struct line_pnts *gPoints;
+    int i, nrings;
+    gPoints = Vect_new_line_struct();
+    geom2 = GEOSGetExteriorRing(OGeom);
+    if (!ring2pts(geom2, gPoints)) {
+        G_fatal_error(_("Corrupt GEOS geometry"));
+    Vect_append_points(Buffer, gPoints, GV_FORWARD);
+    Vect_reset_line(gPoints);
+    nrings = GEOSGetNumInteriorRings(OGeom);
+    for (i = 0; i < nrings; i++) {
+        geom2 = GEOSGetInteriorRingN(OGeom, i);
+#endif
 static int compdist(const void *, const void *);
 Result *resultset;
@@ -197,6 +269,16 @@
     if (G_parser(argc, argv))
         exit(EXIT_FAILURE);
+#if HAVE_GEOS
+#if (GEOS_VERSION_MAJOR < 3 || (GEOS_VERSION_MAJOR >= 3 && GEOS_VERSION_MINOR < 3))
+    G_fatal_error("This module requires GEOS >= 3.3");
+#endif
+    initGEOS(G_message, G_fatal_error);
+#else
+    G_fatal_error("GRASS native buffering functions are known to return incorrect results.\n"
+        "Till those errors are fixed, this module requires GRASS to be compiled with GEOS support.");
+#endif
     /* Start with simple input validation and then move to more complex ones */
     otype = Vect_option_to_types(type_opt);
@@ -404,8 +486,47 @@
     /* Create a buffer around profile line for point sampling
        Tolerance is calculated in such way that buffer will have flat end and no cap. */
+    /* Native buffering is known to fail.
     Vect_line_buffer(Profil, bufsize, 1 - (bufsize * cos((2 * M_PI) / 2)),
                      Buffer);
+#ifdef HAVE_GEOS
+    /* Code lifted from v.buffer geos.c (with modifications) */
+    GEOSGeometry *IGeom;
+    GEOSGeometry *OGeom = NULL;
+    const GEOSGeometry *geom2 = NULL;
+    IGeom = Vect_line_to_geos(Profil, GV_LINE, 0);
+    if (!IGeom) {
+        G_fatal_error(_("Failed to convert GRASS line to GEOS line"));
+    GEOSBufferParams* geos_params = GEOSBufferParams_create();
+    GEOSBufferParams_setEndCapStyle(geos_params, GEOSBUF_CAP_FLAT);
+    OGeom = GEOSBufferWithParams(IGeom, geos_params, bufsize);
+    GEOSBufferParams_destroy(geos_params);
+    if (!OGeom) {
+        G_fatal_error(_("Buffering failed"));
+    if (GEOSGeomTypeId(OGeom) == GEOS_MULTIPOLYGON) {
+        int ngeoms = GEOSGetNumGeometries(OGeom);
+        for (i = 0; i < ngeoms; i++) {
+            geom2 = GEOSGetGeometryN(OGeom, i);
+            add_poly(geom2, Buffer);
+    else {
+        add_poly(OGeom, Buffer);
+    if (IGeom)
+        GEOSGeom_destroy(IGeom);
+    if (OGeom)
+        GEOSGeom_destroy(OGeom);
+    finishGEOS();
+#endif
     Vect_cat_set(Cats, 1, 1);
     /* Should we store used buffer for later examination? */
Modified: grass/branches/releasebranch_7_4/vector/v.profile/testsuite/test_v_profile.py
--- grass/branches/releasebranch_7_4/vector/v.profile/testsuite/test_v_profile.py	2017-11-20 19:46:24 UTC (rev 71787)
+++ grass/branches/releasebranch_7_4/vector/v.profile/testsuite/test_v_profile.py	2017-11-20 20:18:25 UTC (rev 71788)
@@ -36,13 +36,40 @@
 2|24.34|1029|999647|"Greshams Lake Dam"|"Dam"|"NC"|37|"Wake"|183|"078:34:31W"|"35:52:43N"|35.878484|-78.57528|""|""|""|""|77|"Wake Forest"
+buf_points = """\
+626382.68026139|228917.44816672|1
+626643.91393428|228738.2879083|2
+626907.14939778|228529.10079092|3
+buf_output = """\
+Number,Distance,cat,dbl_1,dbl_2,int_1
+1,2102.114,3,626907.14939778,228529.10079092,3
+2,2854.300,2,626643.91393428,228738.2879083,2
+3,2960.822,1,626382.68026139,228917.44816672,1
 class TestProfiling(TestCase):
+    to_remove = []
+    points = 'test_v_profile_points'
     in_points = 'points_of_interest'
     in_map = 'roadsmajor'
     where = "cat='354'"
     prof_ponts = (647952, 236176, 647950, 236217)
     outfile = 'test_out.csv'
+    @classmethod
+    def setUpClass(cls):
+        """Create vector map with points for sampling"""
+        cls.runModule('v.in.ascii', input='-', output=cls.points,
+                      stdin=buf_points)
+        cls.to_remove.append(cls.points)
+    @classmethod
+    def tearDownClass(cls):
+        """Remove vector maps"""
+        if cls.to_remove:
+            cls.runModule('g.remove', flags='f', type='vector',
+                          name=','.join(cls.to_remove), verbose=True)
     def testParsing(self):
         """Test input parameter parsing"""
@@ -99,6 +126,13 @@
         vpro = SimpleModule('v.profile', input=self.in_points, coordinates=self.prof_ponts, buffer=200)
         vpro.run()
         self.assertLooksLike(reference=output_coords, actual=vpro.outputs.stdout)
+    def testBuffering(self):
+        """Test against errors in buffering implementation"""
+        vpro = SimpleModule('v.profile', input=self.points, separator='comma', dp=3,
+            buffer=500, profile_map='roadsmajor at PERMANENT', profile_where='cat=193')
+        vpro.run()
 if __name__ == '__main__':
Modified: grass/branches/releasebranch_7_4/vector/v.profile/v.profile.html
--- grass/branches/releasebranch_7_4/vector/v.profile/v.profile.html	2017-11-20 19:46:24 UTC (rev 71787)
+++ grass/branches/releasebranch_7_4/vector/v.profile/v.profile.html	2017-11-20 20:18:25 UTC (rev 71788)
@@ -18,10 +18,18 @@
 <h2>NOTES</h2>
+<p>
 Currently the module can profile only points and lines (including 3D ones).
 Areas and other complex features are not supported. If in future users can
 provide reasonable examples how area sampling should work and why it is
 important, area (or any other feature type) sampling can be added.
+</p>
+<p>
+Due to bugs in GRASS native buffering algorithms, this module for now
+depends on GEOS and will not function if GRASS is compiled without GEOS.
+This restriction will be removed as soon as GRASS native buffer generation
+is fixed.
+</p>
 <h2>EXAMPLES</h2>
