[GRASS-SVN] r71863 - grass/trunk/raster/r.fill.stats/testsuite
Tue Nov 28 06:40:43 PST 2017
Author: annakrat
Date: 2017-11-28 06:40:43 -0800 (Tue, 28 Nov 2017)
New Revision: 71863
   grass/trunk/raster/r.fill.stats/testsuite/test_r_fill_stats.py
r.fill.stats: fix test
Modified: grass/trunk/raster/r.fill.stats/testsuite/test_r_fill_stats.py
--- grass/trunk/raster/r.fill.stats/testsuite/test_r_fill_stats.py	2017-11-28 14:28:49 UTC (rev 71862)
+++ grass/trunk/raster/r.fill.stats/testsuite/test_r_fill_stats.py	2017-11-28 14:40:43 UTC (rev 71863)
@@ -30,13 +30,13 @@
     def test_stats(self):
         """Test if results match verified rasters"""
-        self.assertModule('r.fill.gaps', input=self.ascii, output=self.stats, distance=1, mode='wmean', power=2, cells=2, overwrite=True)
+        self.assertModule('r.fill.stats', input=self.ascii, output=self.stats, distance=1, mode='wmean', power=2, cells=2, overwrite=True)
         self.assertRastersNoDifference(self.stats, self.wmean, precision=1e-6)
-        self.assertModule('r.fill.gaps', input=self.ascii, output=self.stats, distance=1, mode='mean', power=2, cells=2, overwrite=True)
+        self.assertModule('r.fill.stats', input=self.ascii, output=self.stats, distance=1, mode='mean', power=2, cells=2, overwrite=True)
         self.assertRastersNoDifference(self.stats, self.mean, precision=1e-6)
-        self.assertModule('r.fill.gaps', input=self.ascii, output=self.stats, distance=1, mode='median', power=2, cells=2, overwrite=True)
+        self.assertModule('r.fill.stats', input=self.ascii, output=self.stats, distance=1, mode='median', power=2, cells=2, overwrite=True)
         self.assertRastersNoDifference(self.stats, self.median, precision=1e-6)
-        self.assertModule('r.fill.gaps', input=self.ascii, output=self.stats, distance=1, mode='mode', power=2, cells=2, overwrite=True)
+        self.assertModule('r.fill.stats', input=self.ascii, output=self.stats, distance=1, mode='mode', power=2, cells=2, overwrite=True)
         self.assertRastersNoDifference(self.stats, self.mode, precision=1e-6)
 if __name__ == '__main__':
