[GRASS-SVN] r71872 - grass/trunk/lib/vector/Vlib
svn_grass at osgeo.org
Wed Nov 29 12:53:00 PST 2017
Author: mmetz
Date: 2017-11-29 12:53:00 -0800 (Wed, 29 Nov 2017)
New Revision: 71872
grass/trunk/lib/vector/Vlib/intersect2.c
Vlib: use dynamic floating point representation error
Modified: grass/trunk/lib/vector/Vlib/intersect2.c
--- grass/trunk/lib/vector/Vlib/intersect2.c 2017-11-29 19:32:24 UTC (rev 71871)
+++ grass/trunk/lib/vector/Vlib/intersect2.c 2017-11-29 20:53:00 UTC (rev 71872)
@@ -107,7 +107,28 @@
static double rethresh = 0.000001; /* TODO */
+static double d_ulp(double a, double b)
+ double fa = fabs(a);
+ double fb = fabs(b);
+ double dmax, result;
+ int exp;
+ dmax = fa;
+ if (dmax < fb)
+ dmax = fb;
+ /* unit in the last place (ULP):
+ * smallest representable difference
+ * shift of the exponent
+ * float: 23, double: 52, middle: 37 */
+ result = frexp(dmax, &exp);
+ exp -= 23;
+ result = ldexp(result, exp);
+ return result;
static void add_cross(int asegment, double adistance, int bsegment,
double bdistance, double x, double y)
@@ -495,12 +516,12 @@
box.T = z1;
box.B = z2;
- box.W -= rethresh;
- box.S -= rethresh;
- box.B -= rethresh;
- box.E += rethresh;
- box.N += rethresh;
- box.T += rethresh;
+ box.W -= d_ulp(box.W, box.W);
+ box.S -= d_ulp(box.S, box.S);
+ box.B -= d_ulp(box.B, box.B);
+ box.E += d_ulp(box.E, box.E);
+ box.N += d_ulp(box.N, box.N);
+ box.T += d_ulp(box.T, box.T);
if (!Vect_box_overlap(abbox, &box))
continue;
@@ -633,7 +654,7 @@
* for example: equator length is 40.075,695 km (8 digits), units are m (+3)
* and we want precision in mm (+ 3) = 14 -> minimum rethresh may be around 0.001
* ?Maybe all nonsense?
- * Use rounding error of the unit in the least place ?
+ * Use rounding error of the unit in the last place ?
* max of fabs(x), fabs(y)
* rethresh = pow(2, log2(max) - 53) */
@@ -702,12 +723,12 @@
abbox.B = BBox->B;
- abbox.N += rethresh;
- abbox.S -= rethresh;
- abbox.E += rethresh;
- abbox.W -= rethresh;
- abbox.T += rethresh;
- abbox.B -= rethresh;
+ abbox.N += d_ulp(abbox.N, abbox.N);
+ abbox.S -= d_ulp(abbox.S, abbox.S);
+ abbox.E += d_ulp(abbox.E, abbox.E);
+ abbox.W -= d_ulp(abbox.W, abbox.W);
+ abbox.T += d_ulp(abbox.T, abbox.T);
+ abbox.B -= d_ulp(abbox.B, abbox.B);
if (APnts->n_points < 2 || BPnts->n_points < 2) {
G_fatal_error("Intersection with points is not yet supported");
@@ -831,7 +852,15 @@
x = BPnts->x[seg + 1];
y = BPnts->y[seg + 1];
- if (curdist < rethresh * rethresh) {
+ /* the threshold should not be too small, otherwise we get
+ * too many tiny new segments
+ * the threshold should not be too large, otherwise we might
+ * introduce new crossings
+ * the smallest difference representable with
+ * single precision floating point works well with pathological input
+ * regular input is not affected */
+ if (curdist < d_ulp(x, y)) { /* was rethresh * rethresh */
cross[i].x = x;
cross[i].y = y;
@@ -1285,7 +1314,7 @@
APoints->z[0], with_z, NULL, NULL, NULL, &dist,
NULL, NULL);
- if (dist <= rethresh) {
+ if (dist <= d_ulp(APoints->x[0], APoints->y[0])) {
if (0 >
Vect_copy_xyz_to_pnts(IPnts, &APoints->x[0], &APoints->y[0],
&APoints->z[0], 1))
@@ -1302,7 +1331,7 @@
BPoints->z[0], with_z, NULL, NULL, NULL, &dist,
NULL, NULL);
+ if (dist <= d_ulp(BPoints->x[0], BPoints->y[0])) {
if (0 >
Vect_copy_xyz_to_pnts(IPnts, &BPoints->x[0], &BPoints->y[0],
&BPoints->z[0], 1))
@@ -1337,12 +1366,12 @@
if (abbox.B < ABox.B)
abbox.B = ABox.B;
/* initialize queue */
bo_queue.count = 0;
