[GRASS-SVN] r71552 - grass/trunk/vector/v.out.ogr
Thu Oct 12 13:18:46 PDT 2017
Author: mmetz
Date: 2017-10-12 13:18:46 -0700 (Thu, 12 Oct 2017)
New Revision: 71552
   grass/trunk/vector/v.out.ogr/args.c
   grass/trunk/vector/v.out.ogr/list.c
   grass/trunk/vector/v.out.ogr/local_proto.h
   grass/trunk/vector/v.out.ogr/main.c
   grass/trunk/vector/v.out.ogr/v.out.ogr.html
v.out.ogr: +-l flag to list supported formats (sync to r.out.gdal)
Modified: grass/trunk/vector/v.out.ogr/args.c
--- grass/trunk/vector/v.out.ogr/args.c	2017-10-12 18:47:34 UTC (rev 71551)
+++ grass/trunk/vector/v.out.ogr/args.c	2017-10-12 20:18:46 UTC (rev 71552)
@@ -116,7 +116,7 @@
     flags->multi = G_define_flag();
     flags->multi->key = 'm';
-    flags->multi->description =
+    flags->multi->description =
 	_("Export vector data as multi-features");
     flags->multi->guisection = _("Creation");
@@ -127,6 +127,12 @@
 	  "and exit. Nothing is read from input.");
     flags->new->guisection = _("Creation");
+    flags->list = G_define_flag();
+    flags->list->key = 'l';
+    flags->list->description =
+	_("List supported output formats and exit");
+    flags->list->suppress_required = YES;
     G_option_requires(flags->append, options->layer, NULL);
     if (G_parser(argc, argv))
Modified: grass/trunk/vector/v.out.ogr/list.c
--- grass/trunk/vector/v.out.ogr/list.c	2017-10-12 18:47:34 UTC (rev 71551)
+++ grass/trunk/vector/v.out.ogr/list.c	2017-10-12 20:18:46 UTC (rev 71552)
@@ -1,3 +1,5 @@
+#include "gdal.h"
+#include <grass/glocale.h>
 #include "local_proto.h"
 static int cmp(const void *, const void *);
@@ -62,3 +64,46 @@
     return (strcmp(*(char **)a, *(char **)b));
+void list_formats(void)
+    int iDriver;
+    G_message(_("Supported formats:"));
+#if GDAL_VERSION_NUM >= 2000000
+    for (iDriver = 0; iDriver < GDALGetDriverCount(); iDriver++) {
+	GDALDriverH hDriver = GDALGetDriver(iDriver);
+	const char *pszRWFlag;
+	if (!GDALGetMetadataItem(hDriver, GDAL_DCAP_VECTOR, NULL))
+	    continue;
+	if (GDALGetMetadataItem(hDriver, GDAL_DCAP_CREATE, NULL))
+	    pszRWFlag = "rw+";
+	else if (GDALGetMetadataItem(hDriver, GDAL_DCAP_CREATECOPY, NULL))
+	    pszRWFlag = "rw";
+	else
+	    continue;
+	fprintf(stdout, " %s (%s): %s\n",
+		GDALGetDriverShortName(hDriver),
+		pszRWFlag, GDALGetDriverLongName(hDriver));
+#else
+    for (iDriver = 0; iDriver < OGRGetDriverCount(); iDriver++) {
+	OGRSFDriverH poDriver = OGRGetDriver(iDriver);
+	if (OGR_Dr_TestCapability(poDriver, ODrCCreateDataSource))
+	    pszRWFlag = "rw";
+	else
+	    continue;
+		OGR_Dr_GetName(poDriver),
+		pszRWFlag, OGR_Dr_GetName(poDriver));
+#endif
Modified: grass/trunk/vector/v.out.ogr/local_proto.h
--- grass/trunk/vector/v.out.ogr/local_proto.h	2017-10-12 18:47:34 UTC (rev 71551)
+++ grass/trunk/vector/v.out.ogr/local_proto.h	2017-10-12 20:18:46 UTC (rev 71552)
@@ -16,7 +16,8 @@
 struct Flags {
-    struct Flag *cat, *esristyle, *update, *nocat, *new, *append, *force2d, *multi;
+    struct Flag *cat, *esristyle, *update, *nocat, *new, *append,
+                *force2d, *multi, *list;
 /* args.c */
@@ -33,6 +34,7 @@
 /* list.c */
 char *OGR_list_write_drivers();
+void list_formats(void);
 /* create.c */
 void create_ogr_layer(const char *, const char *, const char *,
Modified: grass/trunk/vector/v.out.ogr/main.c
--- grass/trunk/vector/v.out.ogr/main.c	2017-10-12 18:47:34 UTC (rev 71551)
+++ grass/trunk/vector/v.out.ogr/main.c	2017-10-12 20:18:46 UTC (rev 71552)
@@ -90,7 +90,12 @@
     /* parse & read options */
     parse_args(argc, argv, &options, &flags);
+    if (flags.list->answer) {
+	list_formats();
+	exit(EXIT_SUCCESS);
     /* check for weird options */
     if (G_strncasecmp(options.dsn->answer, "PG:", 3) == 0 &&
         strcmp(options.format->answer, "PostgreSQL") != 0)
Modified: grass/trunk/vector/v.out.ogr/v.out.ogr.html
--- grass/trunk/vector/v.out.ogr/v.out.ogr.html	2017-10-12 18:47:34 UTC (rev 71551)
+++ grass/trunk/vector/v.out.ogr/v.out.ogr.html	2017-10-12 20:18:46 UTC (rev 71552)
@@ -24,6 +24,8 @@
   <li>... and many others</li>
 </ul>
+The list of supported formats is printed with the <em>-l</em> flag.
 <p>
 For further available other supported formats go
 <a href="http://www.gdal.org/ogr_formats.html">here</a>.
