[GRASS-SVN] r72589 - grass-addons/grass7/vector/v.surf.nnbathy
Tue Apr 3 03:43:37 PDT 2018
Author: robertomarzocchi
Date: 2018-04-03 03:43:37 -0700 (Tue, 03 Apr 2018)
New Revision: 72589
   grass-addons/grass7/vector/v.surf.nnbathy/nnbathy.py
   grass-addons/grass7/vector/v.surf.nnbathy/v.surf.nnbathy.html
Corrected problem GUI input (mapset name)
Modified: grass-addons/grass7/vector/v.surf.nnbathy/nnbathy.py
--- grass-addons/grass7/vector/v.surf.nnbathy/nnbathy.py	2018-03-31 01:21:50 UTC (rev 72588)
+++ grass-addons/grass7/vector/v.surf.nnbathy/nnbathy.py	2018-04-03 10:43:37 UTC (rev 72589)
@@ -140,7 +140,7 @@
                 grass.message('Name of z column required for 2D vector maps.')
         # convert vector to ASCII
         grass.run_command("v.out.ascii", overwrite=1,
-                          input=options['input'], output=self._tmpcat,
+                          input=options['input'].split('@')[0], output=self._tmpcat,
                           format="point", separator="space", precision=15,
                           where=options['where'], layer=_layer,
                           columns=_column)
@@ -157,7 +157,7 @@
                 for line in fin:
                     parts = line.split(" ")
                     from grass.pygrass.vector import VectorTopo
-                    pnt = VectorTopo(options['input'])
+                    pnt = VectorTopo(options['input'].split('@')[0])
                     pnt.open(mode='r')
                     check=pnt.read(1)
                     if check.is2D==True:
Modified: grass-addons/grass7/vector/v.surf.nnbathy/v.surf.nnbathy.html
--- grass-addons/grass7/vector/v.surf.nnbathy/v.surf.nnbathy.html	2018-03-31 01:21:50 UTC (rev 72588)
+++ grass-addons/grass7/vector/v.surf.nnbathy/v.surf.nnbathy.html	2018-04-03 10:43:37 UTC (rev 72589)
@@ -61,7 +61,7 @@
 <h2>REQUIREMENTS</h2>
 <ul>
-  <li><a href="https://code.google.com/p/nn-c/">nnbathy</a> library by Pavel Sakov</li>
+  <li><a href="https://github.com/sakov/nn-c">nnbathy</a> library by Pavel Sakov</li>
 </ul>
 <h2>SEE ALSO</h2>
@@ -73,7 +73,9 @@
 <h2>AUTHOR</h2>
 Adam Laza, OSGeoREL, Czech Technical University in Prague (mentor: Martin Landa)
+Corrected by Roberto Marzocchi, <a href="mailto:roberto.marzocchi at gter.it">roberto.marzocchi at gter.it</a>
 <p>
 Based on v.surf.nnbathy from GRASS 6 by:<br>
 Hamish Bowman, Otago University, New Zealand<br>
