[GRASS-SVN] r72623 - grass/branches/releasebranch_7_4/scripts/db.droptable
Tue Apr 17 06:01:00 PDT 2018
Author: neteler
Date: 2018-04-17 06:01:00 -0700 (Tue, 17 Apr 2018)
New Revision: 72623
   grass/branches/releasebranch_7_4/scripts/db.droptable/db.droptable.py
db.droptable: fatal -> warning if table not found, as for g.remove (trunk, r72438)
Modified: grass/branches/releasebranch_7_4/scripts/db.droptable/db.droptable.py
--- grass/branches/releasebranch_7_4/scripts/db.droptable/db.droptable.py	2018-04-17 09:27:49 UTC (rev 72622)
+++ grass/branches/releasebranch_7_4/scripts/db.droptable/db.droptable.py	2018-04-17 13:01:00 UTC (rev 72623)
@@ -75,8 +75,9 @@
     # check if table exists
     if not grass.db_table_exist(table):
-        grass.fatal(_("Table <%s> not found in database <%s>") %
-                    (table, database))
+        grass.warning(_("Table <%s> not found in database <%s>") %
+                       (table, database))
+        sys.exit(0)
     # check if table is used somewhere (connected to vector map)
     used = grass.db.db_table_in_vector(table)
