[GRASS-SVN] r72640 - in grass-addons/grass7/vector: v.gsflow.export v.gsflow.gravres v.gsflow.grid v.gsflow.hruparams v.gsflow.mapdata v.gsflow.reaches v.gsflow.segments
Sun Apr 22 09:09:06 PDT 2018
Author: awickert
Date: 2018-04-22 09:09:06 -0700 (Sun, 22 Apr 2018)
New Revision: 72640
   grass-addons/grass7/vector/v.gsflow.export/v.gsflow.export.html
   grass-addons/grass7/vector/v.gsflow.export/v.gsflow.export.py
   grass-addons/grass7/vector/v.gsflow.gravres/v.gsflow.gravres.html
   grass-addons/grass7/vector/v.gsflow.grid/v.gsflow.grid.html
   grass-addons/grass7/vector/v.gsflow.hruparams/v.gsflow.hruparams.html
   grass-addons/grass7/vector/v.gsflow.mapdata/v.gsflow.mapdata.html
   grass-addons/grass7/vector/v.gsflow.reaches/v.gsflow.reaches.html
   grass-addons/grass7/vector/v.gsflow.segments/v.gsflow.segments.html
r.gsflow and v.gsflow HTML help file formatting
Modified: grass-addons/grass7/vector/v.gsflow.export/v.gsflow.export.html
--- grass-addons/grass7/vector/v.gsflow.export/v.gsflow.export.html	2018-04-22 15:56:18 UTC (rev 72639)
+++ grass-addons/grass7/vector/v.gsflow.export/v.gsflow.export.html	2018-04-22 16:09:06 UTC (rev 72640)
@@ -13,13 +13,14 @@
 <h2>SEE ALSO</h2>
 <em>
-  <a href="v.gsflow.gravres">v.gsflow.gravres</a>,
-  <a href="v.gsflow.grid">v.gsflow.grid</a>,
-  <a href="v.gsflow.hruparams">v.gsflow.hruparams</a>,
-  <a href="v.gsflow.reaches">v.gsflow.reaches</a>,
-  <a href="v.gsflow.segments">v.gsflow.segments</a>,
-  <a href="v.stream.inbasin">v.stream.inbasin</a>,
-  <a href="v.stream.network">v.stream.network</a>,
+  <a href="v.gsflow.gravres">v.gsflow.gravres</a><br>
+  <a href="v.gsflow.grid">v.gsflow.grid</a><br>
+  <a href="v.gsflow.hruparams">v.gsflow.hruparams</a><br>
+  <a href="v.gsflow.reaches">v.gsflow.reaches</a><br>
+  <a href="v.gsflow.segments">v.gsflow.segments</a><br>
+  <a href="v.gsflow.mapdata">v.gsflow.mapdata</a><br>
+  <a href="v.stream.inbasin">v.stream.inbasin</a><br>
+  <a href="v.stream.network">v.stream.network</a>
 </em>
 <h2>AUTHOR</h2>
@@ -26,5 +27,4 @@
 Andrew D. Wickert<br>
-<p>
-<i>Last changed: $Date 2016-09-27$</i>
+<p><i>Last changed: $Date 2018-04-22$</i>
Modified: grass-addons/grass7/vector/v.gsflow.export/v.gsflow.export.py
--- grass-addons/grass7/vector/v.gsflow.export/v.gsflow.export.py	2018-04-22 15:56:18 UTC (rev 72639)
+++ grass-addons/grass7/vector/v.gsflow.export/v.gsflow.export.py	2018-04-22 16:09:06 UTC (rev 72640)
@@ -186,7 +186,7 @@
         outtable = np.vstack((columns_in_order, outarray))
         np.savetxt(out_reaches+'.txt', outtable, fmt='%s', delimiter=',')
     elif (len(reaches) > 0) or (len(out_reaches) > 0):
-        grass.fatal(_("You must inlcude both input and output reaches"))
+        gscript.fatal(_("You must inlcude both input and output reaches"))
     # Segments
@@ -217,7 +217,7 @@
         np.savetxt(out_segments+'_4C_DOWNSTREAM.txt', outtable, fmt='%s',
                    delimiter=',')
     elif (len(segments) > 0) or (len(out_segments) > 0):
-        grass.fatal(_("You must inlcude both input and output segments"))
+        gscript.fatal(_("You must inlcude both input and output segments"))
     # Gravity reservoirs
@@ -230,7 +230,7 @@
         np.savetxt(out_gravity_reservoirs+'.txt', outtable, fmt='%s',
                    delimiter=',')
     elif (len(gravity_reservoirs) > 0) or (len(out_gravity_reservoirs) > 0):
-        grass.fatal(_("You must inlcude both input and output \
+        gscript.fatal(_("You must inlcude both input and output \
                       gravity reservoirs"))
     # HRUs
@@ -243,7 +243,7 @@
         np.savetxt(HRUs+'.txt', outtable, fmt='%s', delimiter=',')
     elif (len(HRUs) > 0) or (len(out_HRUs) > 0):
-        grass.fatal(_("You must inlcude both input and output HRUs"))
+        gscript.fatal(_("You must inlcude both input and output HRUs"))
     # Pour Point and Boundary Condition Cell (downstream from pour point)
@@ -275,7 +275,7 @@
                 outfile.write(outstr)
             outfile.close()
     if (len(pour_point) == 0) and (len(bc_cell) == 0):
-        grass.fatal(_("You must inlcude input and output pp's and/or bc's"))
+        gscript.fatal(_("You must inlcude input and output pp's and/or bc's"))
 if __name__ == "__main__":
     main()
Modified: grass-addons/grass7/vector/v.gsflow.gravres/v.gsflow.gravres.html
--- grass-addons/grass7/vector/v.gsflow.gravres/v.gsflow.gravres.html	2018-04-22 15:56:18 UTC (rev 72639)
+++ grass-addons/grass7/vector/v.gsflow.gravres/v.gsflow.gravres.html	2018-04-22 16:09:06 UTC (rev 72640)
@@ -10,12 +10,13 @@
 Francisco, CA.
 <h2>SEE ALSO</h2>
-<a href="v.gsflow.export">v.gsflow.export</a>
-<a href="v.gsflow.grid">v.gsflow.grid</a>
-<a href="v.gsflow.hruparams">v.gsflow.hruparams</a>
-<a href="v.gsflow.reaches">v.gsflow.reaches</a>
-<a href="v.gsflow.segments">v.gsflow.segments</a>
-<a href="v.stream.inbasin">v.stream.inbasin</a>
+<a href="v.gsflow.export">v.gsflow.export</a><br>
+<a href="v.gsflow.grid">v.gsflow.grid</a><br>
+<a href="v.gsflow.hruparams">v.gsflow.hruparams</a><br>
+<a href="v.gsflow.reaches">v.gsflow.reaches</a><br>
+<a href="v.gsflow.segments">v.gsflow.segments</a><br>
+<a href="v.gsflow.mapdata">v.gsflow.mapdata</a><br>
+<a href="v.stream.inbasin">v.stream.inbasin</a><br>
 <h2>AUTHORS</h2>
@@ -22,4 +23,4 @@
-<p><i>Last changed: $Date 2016-09-27$</i>
Modified: grass-addons/grass7/vector/v.gsflow.grid/v.gsflow.grid.html
--- grass-addons/grass7/vector/v.gsflow.grid/v.gsflow.grid.html	2018-04-22 15:56:18 UTC (rev 72639)
+++ grass-addons/grass7/vector/v.gsflow.grid/v.gsflow.grid.html	2018-04-22 16:09:06 UTC (rev 72640)
@@ -19,8 +19,9 @@
+<a href="v.gsflow.mapdata">v.gsflow.mapdata</a>,
 <a href="r.gsflow.hydrodem">r.gsflow.hydrodem</a>,
Modified: grass-addons/grass7/vector/v.gsflow.hruparams/v.gsflow.hruparams.html
--- grass-addons/grass7/vector/v.gsflow.hruparams/v.gsflow.hruparams.html	2018-04-22 15:56:18 UTC (rev 72639)
+++ grass-addons/grass7/vector/v.gsflow.hruparams/v.gsflow.hruparams.html	2018-04-22 16:09:06 UTC (rev 72640)
@@ -10,12 +10,13 @@
 Francisco, CA.
 <h2>SEE ALSO</h2>
-<a href="v.gsflow.gravres">v.gsflow.gravres</a>
+<a href="v.gsflow.gravres">v.gsflow.gravres</a><br>
 <h2>AUTHORS</h2>
@@ -22,4 +23,4 @@
Modified: grass-addons/grass7/vector/v.gsflow.mapdata/v.gsflow.mapdata.html
--- grass-addons/grass7/vector/v.gsflow.mapdata/v.gsflow.mapdata.html	2018-04-22 15:56:18 UTC (rev 72639)
+++ grass-addons/grass7/vector/v.gsflow.mapdata/v.gsflow.mapdata.html	2018-04-22 16:09:06 UTC (rev 72640)
@@ -15,15 +15,14 @@
 <h2>SEE ALSO</h2>
-<a href="v.gsflow.export">v.gsflow.export</a>,
-<a href="v.gsflow.gravres">v.gsflow.gravres</a>,
-<a href="v.gsflow.grid">v.gsflow.grid</a>,
-<a href="v.gsflow.hruparams">v.gsflow.hruparams</a>,
-<a href="v.gsflow.reaches">v.gsflow.reaches</a>,
-<a href="v.gsflow.segments">v.gsflow.segments</a>,
-<a href="v.gsflow.mapdata">v.gsflow.mapdata</a>
-<a href="r.gsflow.hydrodem">r.gsflow.hydrodem</a>,
-<a href="v.stream.inbasin">v.stream.inbasin</a>,
-<a href="v.stream.network">v.stream.network</a>,
+<a href="r.gsflow.hydrodem">r.gsflow.hydrodem</a><br>
+<a href="v.stream.network">v.stream.network</a>
Modified: grass-addons/grass7/vector/v.gsflow.reaches/v.gsflow.reaches.html
--- grass-addons/grass7/vector/v.gsflow.reaches/v.gsflow.reaches.html	2018-04-22 15:56:18 UTC (rev 72639)
+++ grass-addons/grass7/vector/v.gsflow.reaches/v.gsflow.reaches.html	2018-04-22 16:09:06 UTC (rev 72640)
@@ -10,12 +10,13 @@
 Francisco, CA.
 <h2>SEE ALSO</h2>
 <h2>AUTHORS</h2>
@@ -22,4 +23,4 @@
Modified: grass-addons/grass7/vector/v.gsflow.segments/v.gsflow.segments.html
--- grass-addons/grass7/vector/v.gsflow.segments/v.gsflow.segments.html	2018-04-22 15:56:18 UTC (rev 72639)
+++ grass-addons/grass7/vector/v.gsflow.segments/v.gsflow.segments.html	2018-04-22 16:09:06 UTC (rev 72640)
@@ -10,14 +10,13 @@
 Francisco, CA.
 <h2>SEE ALSO</h2>
 <h2>AUTHORS</h2>
