[GRASS-SVN] r72649 - grass/trunk/imagery/i.maxlik
Thu Apr 26 03:20:18 PDT 2018
Author: marisn
Date: 2018-04-26 03:20:18 -0700 (Thu, 26 Apr 2018)
New Revision: 72649
   grass/trunk/imagery/i.maxlik/global.h
   grass/trunk/imagery/i.maxlik/main.c
i.maxlik: Correctly handle fully qualified output raster map names.
Modified: grass/trunk/imagery/i.maxlik/global.h
--- grass/trunk/imagery/i.maxlik/global.h	2018-04-26 07:27:47 UTC (rev 72648)
+++ grass/trunk/imagery/i.maxlik/global.h	2018-04-26 10:20:18 UTC (rev 72649)
@@ -9,6 +9,7 @@
 extern int *cellfd;
 extern CELL *class_cell, *reject_cell;
 extern int class_fd, reject_fd;
-extern char *class_name, *reject_name;
+extern char *reject_name;
+extern char class_name[GNAME_MAX];
 extern double *B;
 extern double *P;
Modified: grass/trunk/imagery/i.maxlik/main.c
--- grass/trunk/imagery/i.maxlik/main.c	2018-04-26 07:27:47 UTC (rev 72648)
+++ grass/trunk/imagery/i.maxlik/main.c	2018-04-26 10:20:18 UTC (rev 72649)
@@ -35,7 +35,8 @@
 int *cellfd;
-char *class_name, *reject_name;
+char *reject_name;
+char class_name[GNAME_MAX];
 double *B;
 double *P;
 CELL cat;
@@ -54,6 +55,7 @@
 	struct Option *group, *subgroup, *sigfile, *class, *reject;
     } parm;
+    char xmapset[GMAPSET_MAX];
     G_gisinit(argv[0]);
@@ -95,11 +97,16 @@
 	exit(EXIT_FAILURE);
-    class_name = parm.class->answer;
     reject_name = parm.reject->answer;
     group = parm.group->answer;
     subgroup = parm.subgroup->answer;
     sigfile = parm.sigfile->answer;
+    if (G_unqualified_name(parm.class->answer, G_mapset(), class_name, xmapset) < 0)
+        G_fatal_error(_("<%s> does not match the current mapset"), xmapset);
+    if (G_legal_filename(class_name) < 0)
+        G_fatal_error(_("<%s> is an illegal file name"), class_name);
     open_files();
