[GRASS-SVN] r73050 - in grass-addons/grass7/raster: . r.in.pdal
    svn_grass at osgeo.org
    Mon Aug  6 00:25:33 PDT 2018
Author: AnikaBettge
Date: 2018-08-06 00:25:33 -0700 (Mon, 06 Aug 2018)
New Revision: 73050
Added:
   grass-addons/grass7/raster/r.in.pdal/
   grass-addons/grass7/raster/r.in.pdal/Makefile
   grass-addons/grass7/raster/r.in.pdal/r.in.pdal.html
   grass-addons/grass7/raster/r.in.pdal/r.in.pdal.py
   grass-addons/grass7/raster/r.in.pdal/r_in_pdal.png
   grass-addons/grass7/raster/r.in.pdal/r_in_pdal_footprint.jpg
Removed:
r.in.pdal: add files (#3515)
Added: grass-addons/grass7/raster/r.in.pdal/Makefile
--- grass-addons/grass7/raster/r.in.pdal/Makefile	                        (rev 0)
+++ grass-addons/grass7/raster/r.in.pdal/Makefile	2018-08-06 07:25:33 UTC (rev 73050)
@@ -0,0 +1,7 @@
+MODULE_TOPDIR = ../..
+PGM = r.in.pdal
+include $(MODULE_TOPDIR)/include/Make/Script.make
+default: script
Added: grass-addons/grass7/raster/r.in.pdal/r.in.pdal.html
--- grass-addons/grass7/raster/r.in.pdal/r.in.pdal.html	                        (rev 0)
+++ grass-addons/grass7/raster/r.in.pdal/r.in.pdal.html	2018-08-06 07:25:33 UTC (rev 73050)
@@ -0,0 +1,100 @@
+<h2>DESCRIPTION</h2>
+<em>r.in.pdal</em> creates a raster map from LAS LiDAR points using the
+Point Data Abstraction Library (<a href="https://pdal.io/">PDAL</a>) by
+binning the points into a raster map using univariate statistics. The user
+may choose from a variety of statistical methods which will be used for
+binning when creating the new raster map.
+<p>
+The computational region of a LiDAR point file can be determined by scanning
+the file using the <b>-s</b> flag.
+<p>
+Optionally <em>r.in.pdal</em> creates an estimated vector footprint area map
+of the LAS file when using the <em>footprint</em> parameter (the footprint is
+generated by PDAL).
+<p>
+Since a new raster map is created during the binning, the binning of points
+depends on the computational region settings (extent and resolution) which is
+by default set to the extent of the LiDAR input file (see more about binning
+below). The resulting raster resolution can be specified with the parameter
+<em>resolution</em>.
+<p>
+<em>r.in.pdal</em> is designed for processing massive point cloud datasets,
+for example raw LiDAR or sidescan sonar swath data. It has been tested with
+large datasets.
+<p>
+For details concerning raster binning see the manual page of
+<em><a href="r.in.lidar.html">r.in.lidar</a></em>.
+<h2>NOTES</h2>
+<em>r.in.pdal</em> uses <em><a href="g.region.html">g.region</a></em> to set
+the extent and resolution of the resulting raster and internally
+<em><a href="r.in.xyz.html">r.in.xyz</a></em> to import the LiDAR points.
+<h2>EXAMPLES</h2>
+Import of a LAS file using PDAL. The sample LAS file is available
+<a href="https://www.grassbook.org/wp-content/uploads/ncexternal/lidar_raleigh_nc_spm_height_feet.las">here</a>.
+<div class="code"><pre>
+# check metadata
+pdal info --summary lidar_raleigh_nc_spm_height_feet.las
+# scan extent and exit
+r.in.pdal input=lidar_raleigh_nc_spm_height_feet.las output=lidar_raleigh -s
+# scan extent (g.region style) and exit
+r.in.pdal input=lidar_raleigh_nc_spm_height_feet.las output=lidar_raleigh -s -g
+# import while aligning pixel geometry to existing "elevation" 10m res. raster map
+r.in.pdal input=lidar_raleigh_nc_spm_height_feet.las raster_reference=elevation \
+          resolution=10 output=lidar_raleigh method=mean
+# optionally: footprint=lidar_raleigh_footprint
+# visualize
+d.mon wx0
+g.list vector
+d.rast lidar_raleigh
+d.vect streets_wake
+# analyse differences between DEM and rasterized point cloud
+# LAS files come with height in US feet units
+r.mapcalc "diff = elevation - lidar_raleigh * 0.3048006096012192"
+r.univar -e diff
+</pre></div>
+<div align="center" style="margin: 10px">
+<a href="r_in_pdal.png">
+<img src="r_in_pdal.png" width="600" height="697" alt="Figure: View showing the difference of the elevation and the LiDAR point data binned to raster map with r.in.pdal" border="0">
+</a><br>
+<i>Figure: View showing the difference of the elevation map and LiDAR point data binned to raster map with r.in.pdal</i>
+</div>
+<a href="r_in_pdal_footprint.jpg">
+<img src="r_in_pdal_footprint.jpg" width="600" height="497" alt="Figure: LiDAR cloud footprint" border="0">
+</a><br>
+<i>Figure: LiDAR cloud footprint</i>
+</div>
+<h2>SEE ALSO</h2>
+<em>
+<a href="r.in.xyz.html">r.in.xyz</a>,
+<a href="r.in.lidar.html">r.in.lidar</a>,
+<a href="v.in.lidar.html">v.in.lidar</a>
+</em>
+<h2>AUTHORS</h2>
+Anika Bettge, mundialis GmbH & Co. KG
+<p>
+Documentation: Markus Neteler, mundialis GmbH & Co. KG
+<p>
+<i>Last changed: $Date: 2018-05-23 12:28:54 +0200 (Mi, 23. Mai 2018) $</i>
Added: grass-addons/grass7/raster/r.in.pdal/r.in.pdal.py
--- grass-addons/grass7/raster/r.in.pdal/r.in.pdal.py	                        (rev 0)
+++ grass-addons/grass7/raster/r.in.pdal/r.in.pdal.py	2018-08-06 07:25:33 UTC (rev 73050)
@@ -0,0 +1,358 @@
+#!/usr/bin/env python
+# MODULE:	    r.in.pdal
+# AUTHOR(S):    Anika Bettge <bettge at mundialis.de>
+#               Thanks to Markus Neteler <neteler at mundialis.de> for help
+# PURPOSE:      Creates a raster map from LAS LiDAR points using univariate statistics and r.in.xyz.
+# COPYRIGHT:	(C) 2018 by mundialis and the GRASS Development Team
+#		This program is free software under the GNU General Public
+#		License (>=v2). Read the file COPYING that comes with GRASS
+#		for details.
+#%Module
+#% description:  Creates a raster map from LAS LiDAR points using univariate statistics and r.in.xyz.
+#% keyword: raster
+#% keyword: import
+#% keyword: LIDAR
+#% keyword: statistics
+#% keyword: conversion
+#% overwrite: yes
+#%End
+#%option G_OPT_R_INPUT
+#% key: input
+#% description: LAS input file
+#% required: yes
+#%end
+#%option G_OPT_R_OUTPUT
+#% key: output
+#% description: Name for output raster map
+#% required: yes
+#%end
+#%option
+#% key: resolution
+#% type: double
+#% description: 2D grid resolution (north-south and east-west)
+#% answer: 1.0
+#% required: no
+#%end
+#%option
+#% key: raster_reference
+#% label: Raster map to be used as pixel geometry reference
+#% description: Raster map to align to, e.g. an orthophoto of the same region
+#% required: no
+#%end
+#%option
+#% key: raster_file
+#% label: External raster map to be used as pixel geometry reference
+#% description: External raster map to align to, e.g. an orthophoto of the same region
+#% required: no
+#%end
+#%option
+#% key: method
+#% type: string
+#% description: Statistic to use for raster values
+#% options: n, min, max, range, sum, mean, stddev, variance, coeff_var, median, percentile, skewness, trimmean
+#% answer: mean
+#% descriptions: n;Number of points in cell;min;Minimum value of point values in cell;max;Maximum value of point values in cell;range;Range of point values in cell;sum;Sum of point values in cell;mean;Mean (average) value of point values in cell;stddev;Standard deviation of point values in cell;variance;Variance of point values in cell;coeff_var;Coefficient of variance of point values in cell;median;Median value of point values in cell;percentile;Pth (nth) percentile of point values in cell;skewness;Skewness of point values in cell
+#% required: no
+#%end
+#%option
+#% key: zrange
+#% type: double
+#% key_desc: min,max
+#% description: Filter range for z data (min,max)
+#% required: no
+#%end
+#%option
+#% key: zscale
+#% type: double
+#% description: Scale to apply to z data
+#% answer: 1.0
+#% required: no
+#%end
+#%option
+#% key: type
+#% type: string
+#% description: Type of raster map to be created / Storage type for resultant raster map
+#% options: CELL, FCELL, DCELL
+#% answer: FCELL
+#% required: no
+#% descriptions: CELL;Integer;FCELL;Single precision floating point;DCELL;Double precision floating point
+#%end
+#%option
+#% key: percent
+#% type: integer
+#% description: Percent of map to keep in memory
+#% options: 1-100
+#% answer: 100
+#% required: no
+#%end
+#%option
+#% key: pth
+#% type: integer
+#% description: Pth percentile of the values
+#% options: 1-100
+#% required: no
+#%end
+#%option
+#% key: trim
+#% type: double
+#% description: Discard <trim> percent of the smallest and <trim> percent of the largest observations
+#% options: 1-50
+#% required: no
+#%end
+#%option
+#% key: footprint
+#% type: string
+#% description: Footprint of the data as vector map
+#% required: no
+#%end
+#%flag
+#% key: s
+#% description: Scan data file for extent then exit
+#%end
+#%flag
+#% key: g
+#% description: In scan mode, print using shell script style
+#%end
+import os
+import sys
+import grass.script as grass
+import tempfile
+import json
+# i18N
+import gettext
+gettext.install('grassmods', os.path.join(os.getenv("GISBASE"), 'locale'))
+def footprintToVectormap(infile, footprint):
+    if not grass.find_program('pdal', 'info --boundary'):
+        grass.fatal(_("pdal info --boundary is not in the path and executable"))
+    command_fp = ['pdal','info','--boundary',infile]
+    tmp_fp = os.path.join(tempfile.gettempdir(), 'fp.txt')
+    fh = open(tmp_fp, 'wb')
+    p = grass.call(command_fp, stdout=fh)
+    fh.close()
+    if p != 0:
+        # check to see if gdalwarp executed properly
+        os.remove(tmp_fp)
+        grass.fatal(_("pdal info broken..."))
+    str1 = u'boundary'
+    str2 = u'boundary_json'
+    str3 = u'coordinates'
+    data = json.load(open(tmp_fp))
+    coord = data[str1][str2][str3][0][0]
+    xy_in = ''
+    for xy in coord:
+        xy_in += str(xy[0]) + ',' + str(xy[1]) + '\n'
+    tmp_xy = os.path.join(tempfile.gettempdir(), 'xy.txt')
+    f = open(tmp_xy,'w')
+    f.write(xy_in[:-1])
+    f.close()
+    grass.run_command('v.in.lines',input=tmp_xy,output='footprint_line',separator='comma')
+    grass.run_command('g.region',vector='footprint_line')
+    grass.run_command('v.type',input='footprint_line', out='footprint_boundary', from_type='line', to_type='boundary')
+    grass.run_command('v.centroids',input='footprint_boundary', out=footprint)
+    grass.run_command('v.db.addtable',map=footprint,columns='name varchar(50)')
+    grass.run_command('v.db.update',map=footprint,column='name', value=infile)
+    # Cleaning up
+    grass.message(_("Cleaning up..."))
+    os.remove(tmp_fp)
+    os.remove(tmp_xy)
+    grass.run_command('g.remove', flags='f', type='vector', name='footprint_line', quiet=True)
+    grass.run_command('g.remove', flags='f', type='vector', name='footprint_boundary', quiet=True)
+    grass.message(_("Generating output vactor map <%s>...") % footprint)
+def main():
+    # parameters
+    infile = options['input']
+    raster_reference = options['raster_reference']
+    raster_file = options['raster_file']
+    outfile = options['output']
+    resolution = options['resolution']
+    method = options['method']
+    zrange = options['zrange']
+    zscale = options['zscale']
+    output_type = options['type']
+    percent = options['percent']
+    pth = options['pth']
+    trim = options['trim']
+    footprint = options['footprint']
+    # flags
+    scan = flags['s']
+    shell_script_style = flags['g']
+    # overwrite auf true setzen
+    os.environ['GRASS_OVERWRITE'] = '1'
+    # to hide non-error messages from subprocesses
+    if grass.verbosity() <= 2:
+        outdev = open(os.devnull, 'w')
+    else:
+        outdev = sys.stdout
+    # scan -s or shell_script_style -g:
+    if scan: # or shell_script_style:
+        if not grass.find_program('pdal', 'info --summary'):
+            grass.fatal(_("The pdal program is not in the path and executable. Please install first"))
+        command_scan = ['pdal','info','--summary', infile]
+        tmp_scan = os.path.join(tempfile.gettempdir(), 'scan.txt')
+        fh = open(tmp_scan, 'wb')
+        p = grass.call(command_scan, stdout=fh)
+        fh.close()
+        summary = True
+        if p != 0:
+            command_scan = ['pdal','info',infile]
+            fh.close()
+            summary = False
+        if p != 0:
+            # check to see if pdal executed properly
+            os.remove(tmp_scan)
+            grass.fatal(_("pdal cannot determine metadata for unsupported format of <%s>") %infile )
+        data = json.load(open(tmp_scan))
+        if summary:
+            str1 = u'summary'
+            str2 = u'bounds'
+            y_str = u'Y'
+            x_str = u'X'
+            z_str = u'Z'
+            min_str =  u'min'
+            max_str = u'max'
+            n = str(data[str1][str2][y_str][max_str])
+            s = str(data[str1][str2][y_str][min_str])
+            w = str(data[str1][str2][x_str][min_str])
+            e = str(data[str1][str2][x_str][max_str])
+            t = str(data[str1][str2][z_str][max_str])
+            b = str(data[str1][str2][z_str][min_str])
+        else:
+            str1 = u'stats'
+            str2 = u'bbox'
+            str3 = u'native'
+            str4 = u'bbox'
+            n = str(data[str1][str2][str3][str4][u'maxy'])
+            s = str(data[str1][str2][str3][str4][u'miny'])
+            w = str(data[str1][str2][str3][str4][u'minx'])
+            e = str(data[str1][str2][str3][str4][u'maxx'])
+            t = str(data[str1][str2][str3][str4][u'maxz'])
+            b = str(data[str1][str2][str3][str4][u'minz'])
+        if not shell_script_style:
+            print('north: ' + n + '\n' + 'south: ' + s + '\n' +
+            'west:   ' + w + '\n' + 'east:   ' + e + '\n' +
+            'top:     ' + t + '\n' + 'bottom:  ' + b)
+        else:
+            print('n=' + n + ' ' + 's=' + s + ' ' + 'w=' + w + ' ' +
+            'e=' + e + ' ' + 't=' + t + ' ' + 'b=' + b)
+    elif footprint:
+        print 'footprint'
+        footprintToVectormap(infile, footprint)
+    else:
+        # get region with pdal
+        footprintToVectormap(infile, 'tiles')
+        if raster_file:
+            raster_reference = 'img.1'
+            grass.run_command('r.external', input=raster_file, flags="o", output='img', overwrite=True)
+        # first pass: set region to extent of tiles while aligning pixel geometry to raster_reference
+        grass.run_command('g.region',vector='tiles', flags='p')
+        if raster_reference:
+            grass.run_command('g.region',vector='tiles', flags='ap', align=raster_reference)
+        # second pass: change raster resolution to final resolution while best effort aligning to pixel geometry
+        grass.run_command('g.region',vector='tiles', flags='ap', res=resolution)
+        # . pdal pipline laz2json (STDOUT) | r.in.xyz
+        bn=os.path.basename(infile)
+        infile_format = bn.split('.')[-1]
+        formatReader = '' # from https://pdal.io/stages/readers.html
+        if infile_format.lower() == 'laz' or infile_format.lower() == 'las':
+            formatReader = 'readers.las'
+        elif infile_format.lower() == 'pts': # nicht getestet
+            formatReader = 'readers.pts'
+        else:
+            grass.run_command('g.remove', flags='f', type='vector', name='tiles', quiet=True)
+            grass.fatal(_("Format .%s is not supported.." % infile_format))
+        tmp_file_json = os.path.join(tempfile.gettempdir(), 'las2txt.json')
+        data = {}
+        data['pipeline'] = []
+        data['pipeline'].append({'type': formatReader,'filename': infile})
+            'type': 'writers.text',
+            'format': 'csv',
+            'order': 'X,Y,Z',
+            'keep_unspecified':'false',
+            'filename':'STDOUT',
+            'quote_header':'false'})
+        with open(tmp_file_json, 'w') as f:
+            json.dump(data, f)
+        tmp_xyz = os.path.join(tempfile.gettempdir(), 'tmp_xyz.txt')
+        command_pdal1 = ['pdal','pipeline','--input',tmp_file_json]
+        command_pdal2 = ['r.in.xyz','input=' + tmp_xyz,'output=' + outfile,
+            'skip=1','separator=comma', 'method=' + method]
+        if zrange:
+            command_pdal2.append('zrange=' + zrange)
+        if zscale:
+            command_pdal2.append('zscale=' + zscale)
+        if output_type:
+            command_pdal2.append('type=' + output_type)
+        if percent:
+            command_pdal2.append('percent=' + percent)
+        if pth:
+            command_pdal2.append('pth=' + pth)
+        if trim:
+            command_pdal2.append('trim=' + trim)
+        fh = open(tmp_xyz, 'wb')
+        p2 = grass.call(command_pdal1,stdout=fh)
+        fh.close()
+        if p2 != 0:
+            grass.fatal(_("pdal pipeline is broken..."))
+        p3 = grass.call(command_pdal2,stdout=outdev)
+        if p3 != 0:
+            os.remove(tmp_xyz)
+            grass.fatal(_("r.in.xyz is broken..."))
+        # Cleanup
+        os.remove(tmp_file_json)
+        grass.message(_("Generating output raster map <%s>...") % outfile)
+if __name__ == "__main__":
+    options, flags = grass.parser()
+    main()
Added: grass-addons/grass7/raster/r.in.pdal/r_in_pdal.png
(Binary files differ)
Index: grass-addons/grass7/raster/r.in.pdal/r_in_pdal.png
--- grass-addons/grass7/raster/r.in.pdal/r_in_pdal.png	2018-08-04 09:16:27 UTC (rev 73049)
+++ grass-addons/grass7/raster/r.in.pdal/r_in_pdal.png	2018-08-06 07:25:33 UTC (rev 73050)
Property changes on: grass-addons/grass7/raster/r.in.pdal/r_in_pdal.png
___________________________________________________________________
Added: svn:mime-type
## -0,0 +1 ##
+application/octet-stream
\ No newline at end of property
Added: grass-addons/grass7/raster/r.in.pdal/r_in_pdal_footprint.jpg
Index: grass-addons/grass7/raster/r.in.pdal/r_in_pdal_footprint.jpg
--- grass-addons/grass7/raster/r.in.pdal/r_in_pdal_footprint.jpg	2018-08-04 09:16:27 UTC (rev 73049)
+++ grass-addons/grass7/raster/r.in.pdal/r_in_pdal_footprint.jpg	2018-08-06 07:25:33 UTC (rev 73050)
Property changes on: grass-addons/grass7/raster/r.in.pdal/r_in_pdal_footprint.jpg
## -0,0 +1 ##
