[GRASS-SVN] r73791 - in grass/trunk/scripts: . r.mapcalc.simple r.mapcalc.simple/testsuite
Mon Dec 10 22:28:51 PST 2018
Author: neteler
Date: 2018-12-10 22:28:51 -0800 (Mon, 10 Dec 2018)
New Revision: 73791
Added:
   grass/trunk/scripts/r.mapcalc.simple/
   grass/trunk/scripts/r.mapcalc.simple/r.mapcalc.simple.html
   grass/trunk/scripts/r.mapcalc.simple/r.mapcalc.simple.py
   grass/trunk/scripts/r.mapcalc.simple/testsuite/test_rmapcalcsimple.py
Removed:
   grass/trunk/scripts/r.mapcalc.simple/r.mapcalculator.html
   grass/trunk/scripts/r.mapcalc.simple/r.mapcalculator.py
   grass/trunk/scripts/r.mapcalc.simple/testsuite/test_rmapcalculator.py
   grass/trunk/scripts/Makefile
   grass/trunk/scripts/r.mapcalc.simple/Makefile
r.mapcalc.simple: added from https://svn.osgeo.org/grass/sandbox/wenzeslaus/r.mapcalculator as r.mapcalc.simple (trac #3431)
Modified: grass/trunk/scripts/Makefile
--- grass/trunk/scripts/Makefile	2018-12-11 02:56:25 UTC (rev 73790)
+++ grass/trunk/scripts/Makefile	2018-12-11 06:28:51 UTC (rev 73791)
@@ -40,6 +40,7 @@
 	r.in.aster \
 	r.in.srtm \
 	r.in.wms \
+	r.mapcalc.simple \
 	r.mask \
 	r.out.xyz \
 	r.pack \
Modified: grass/trunk/scripts/r.mapcalc.simple/Makefile
--- sandbox/wenzeslaus/r.mapcalculator/Makefile	2018-12-11 02:56:25 UTC (rev 73790)
+++ grass/trunk/scripts/r.mapcalc.simple/Makefile	2018-12-11 06:28:51 UTC (rev 73791)
@@ -1,6 +1,6 @@
 MODULE_TOPDIR = ../..
-PGM = r.mapcalculator
+PGM = r.mapcalc.simple
 include $(MODULE_TOPDIR)/include/Make/Script.make
Copied: grass/trunk/scripts/r.mapcalc.simple/r.mapcalc.simple.html (from rev 73790, sandbox/wenzeslaus/r.mapcalculator/r.mapcalculator.html)
--- grass/trunk/scripts/r.mapcalc.simple/r.mapcalc.simple.html	                        (rev 0)
+++ grass/trunk/scripts/r.mapcalc.simple/r.mapcalc.simple.html	2018-12-11 06:28:51 UTC (rev 73791)
@@ -0,0 +1,121 @@
+<h2>DESCRIPTION</h2>
+<em>r.mapcalc.simple</em> provides a wrapper to <em>r.mapcalc</em>.
+Up to 6 maps can be combined using simple expressions.
+<p>
+The general syntax for the <b>expression</b> follows
+<em><a href="r.mapcalc.html">r.mapcalc</a></em> expression format,
+for example, <tt>A + B</tt> or <tt>exp(A + B)</tt> are valid.
+The variables A, B, ..., F represent raster maps which are provided
+as options <b>a</b>, <b>b</b>, ..., <b>f</b>.
+<p>
+The result name, i.e. the output raster map, is provided using the
+option <b>output</b> and, unlike <em>r.mapcalc</em> it is not part
+of the expression.
+<p>
+This module is meant for convenience (for users and programmers) while
+the <em>r.mapcalc</em> module is a better choice for more complex
+expressions and advanced usage.
+<h2>NOTES</h2>
+Differences to <em>r.mapcalc</em> module:
+<ul>
+    <li>The input raster map names and the output map raster name are
+        separate from the expression (formula) which uses generic
+        variable names (A, B, C, ...).
+    <li>The output raster name is not included in the expression.
+    <li>The expression is expected to be a single short one liner
+        without the function <tt>eval()</tt>.
+</ul>
+Differences to <em>r.mapcalc.simple</em> module in GRASS GIS 5 and 6:
+<ul>
+    <li>The primary purpose is not being a GUI front end to
+        <em>r.mapcalc</em>, but a wrapper which allows easy building of
+        interfaces to <em>r.mapcalc</em> (including GUIs).
+    <li>Whitespace (most notably spaces) are allowed
+        (in the same way as for <em>r.mapcalc</em>).
+    <li>The variable names are case-insensitive to allow the original
+        uppercase as well as lowercase as in option names
+        (unless the <b>-c</b> flag is used).
+    <li>Option names for each map are just one letter (not amap, etc.).
+    <li>Output option name is <b>output</b> as for other modules
+        (not outfile).
+    <li>Raster map names can be optionally quoted (the <b>-q</b> flag).
+    <li>There is no expert mode
+        (which was just running <em>r.mapcalc</em>).
+    <li>The <b>expression</b> option is first, so it is possible to
+        omit its name in the command line
+        (just like with <em>r.mapcalc</em>).
+    <li>Overwriting of outputs is done in the same way as with other
+        modules, so there is no flag to not overwrite outputs.
+</ul>
+<h2>EXAMPLES</h2>
+<h3>Basic examples</h3>
+<div class="code"><pre>
+r.mapcalc.simple expression="0" output=zeros
+r.mapcalc.simple expression="1" output=ones
+r.mapcalc.simple expression="2" output=twos
+</pre></div>
+r.mapcalc.simple expression="A + B + C" a=zeros b=ones c=twos output=result1
+</pre></div>
+r.mapcalc.simple expression="(A * B) / 2 + 3 * C" a=zeros b=ones c=twos output=result2
+</pre></div>
+<h3>Example expressions</h3>
+Addition:
+A + B
+</pre></div>
+No spaces around operators are not recommended for readability,
+but allowed in the expression:
+A+B
+</pre></div>
+More complex expression with a function:
+<p>
+exp(A+C)+(B-2)*7
+</pre></div>
+<h2>SEE ALSO</h2>
+<em>
+<a href="r.mapcalc.html">r.mapcalc</a>,
+<a href="r3.mapcalc.html">r3.mapcalc</a>,
+<a href="t.rast.mapcalc.html">t.rast.mapcalc</a>,
+<a href="g.region.html">g.region</a>
+</em>
+<h2>AUTHORS</h2>
+Vaclav Petras, <a href="https://geospatial.ncsu.edu/geoforall/">NCSU GeoForAll Lab</a><br>
+Michael Barton, Arizona State University (updated to GRASS 5.7)<br>
+R. Brunzema (original 5.0 Bash version)
+<p><i>Last changed: $Date$</i>
Copied: grass/trunk/scripts/r.mapcalc.simple/r.mapcalc.simple.py (from rev 73790, sandbox/wenzeslaus/r.mapcalculator/r.mapcalculator.py)
--- grass/trunk/scripts/r.mapcalc.simple/r.mapcalc.simple.py	                        (rev 0)
+++ grass/trunk/scripts/r.mapcalc.simple/r.mapcalc.simple.py	2018-12-11 06:28:51 UTC (rev 73791)
@@ -0,0 +1,143 @@
+#!/usr/bin/env python
+MODULE:    r.mapcalc.simple
+AUTHOR(S): Vaclav Petras <wenzeslaus gmail com>
+           R. Brunzema <r.brunzema web de> (original 5.0 version)
+           Michael Barton <michael.barton asu edu> (update to GRASS 5.7)
+           Huidae Cho <grass4u gmail com> (removed bashism)
+PURPOSE:   Provides wrapper friendly wrapper to r.mapcalc
+COPYRIGHT: (C) 2018 by Vaclav Petras and the GRASS Development Team
+This program is free software under the GNU General Public
+License (>=v2). Read the file COPYING that comes with GRASS
+for details.
+#%module
+#% description: Calculate new raster map from a r.mapcalc expression
+#% keyword: raster
+#% keyword: algebra
+#%end
+#%option
+#% key: expression
+#% type: string
+#% description: Formula (e.g. A-B or A*C+B)
+#% required : yes
+#%end
+#%option G_OPT_R_INPUT
+#% key: a
+#% description: A
+#% required : no
+#%end
+#% key: b
+#% description: B
+#% required : no
+#%end
+#% key: c
+#% description: C
+#% required : no
+#%end
+#% key: d
+#% description: D
+#% required : no
+#%end
+#% key: e
+#% description: E
+#% required : no
+#%end
+#% key: f
+#% description: F
+#% required : no
+#%end
+#%option
+#% key: output
+#% description: Name for output raster map
+#% required : yes
+#%end
+#%option
+#% key: seed
+#% type: integer
+#% required: no
+#% multiple: no
+#% description: Seed for rand() function
+#%end
+#%flag
+#% key: s
+#% description: Generate random seed (result is non-deterministic)
+#%end
+#%flag
+#% key: q
+#% description: Quote the map names
+#%end
+#%flag
+#% key: c
+#% description: Case sensitive variable names
+#%end
+import sys
+import re
+import grass.script as gs
+def name_quote(name):
+    return '"{}"'.format(name)
+def main():
+    options, flags = gs.parser()
+    expr = options['expression']
+    if not expr:
+        gs.fatal(_("The expression is an empty string"))
+    output = options['output']
+    quote = flags['q']
+    re_flags = 0
+    if flags['c']:
+        re_flags = re.IGNORECASE
+    if quote:
+        output = name_quote(output)
+    seed = None
+    if options['seed']:
+        seed = options['seed']
+    elif flags['s']:
+        seed = 'auto'
+    variables = []
+    for key in "ABCDEF":
+        name = options[key.lower()]
+        if name:
+            if quote:
+                name = name_quote(name)
+            variables.append((key, name))
+    for key, name in variables:
+        find = r'([^a-zA-Z0-9]|^){key}([^a-zA-Z0-9]|$)'.format(key=key)
+        replace = r'\1{}\2'.format(name)
+        # we need to do the substitution twice because we are matching
+        # also the char before and after which fails when there is only
+        # one char between the two usages of the same var (e.g. A*A)
+        expr = re.sub(find, replace, expr, flags=re_flags)
+    expr = '{lhs} = {rhs}'.format(lhs=output, rhs=expr)
+    gs.verbose(_("Expression: {}").format(expr))
+    gs.mapcalc(expr, seed=seed)
+    # g.message -e "Calculating $GIS_OPT_OUTFILE. Try expert mode."
+    return 0
+if __name__ == "__main__":
+    sys.exit(main())
Deleted: grass/trunk/scripts/r.mapcalc.simple/r.mapcalculator.html
--- sandbox/wenzeslaus/r.mapcalculator/r.mapcalculator.html	2018-12-11 02:56:25 UTC (rev 73790)
+++ grass/trunk/scripts/r.mapcalc.simple/r.mapcalculator.html	2018-12-11 06:28:51 UTC (rev 73791)
@@ -1,121 +0,0 @@
-<h2>DESCRIPTION</h2>
-<em>r.mapcalculator</em> provides a wrapper to <em>r.mapcalc</em>.
-Up to 6 maps can be combined using simple expressions.
-<p>
-The general syntax for the <b>expression</b> follows
-<em><a href="r.mapcalc.html">r.mapcalc</a></em> expression format,
-for example, <tt>A + B</tt> or <tt>exp(A + B)</tt> are valid.
-The variables A, B, ..., F represent raster maps which are provided
-as options <b>a</b>, <b>b</b>, ..., <b>f</b>.
-<p>
-The result name, i.e. the output raster map, is provided using the
-option <b>output</b> and, unlike <em>r.mapcalc</em> it is not part
-of the expression.
-<p>
-This module is meant for convenience (for users and programmers) while
-the <em>r.mapcalc</em> module is a better choice for more complex
-expressions and advanced usage.
-<h2>NOTES</h2>
-Differences to <em>r.mapcalc</em> module:
-<ul>
-    <li>The input raster map names and the output map raster name are
-        separate from the expression (formula) which uses generic
-        variable names (A, B, C, ...).
-    <li>The output raster name is not included in the expression.
-    <li>The expression is expected to be a single short one liner
-        without the function <tt>eval()</tt>.
-</ul>
-Differences to <em>r.mapcalculator</em> module in GRASS GIS 5 and 6:
-<ul>
-    <li>The primary purpose is not being a GUI front end to
-        <em>r.mapcalc</em>, but a wrapper which allows easy building of
-        interfaces to <em>r.mapcalc</em> (including GUIs).
-    <li>Whitespace (most notably spaces) are allowed
-        (in the same way as for <em>r.mapcalc</em>).
-    <li>The variable names are case-insensitive to allow the original
-        uppercase as well as lowercase as in option names
-        (unless the <b>-c</b> flag is used).
-    <li>Option names for each map are just one letter (not amap, etc.).
-    <li>Output option name is <b>output</b> as for other modules
-        (not outfile).
-    <li>Raster map names can be optionally quoted (the <b>-q</b> flag).
-    <li>There is no expert mode
-        (which was just running <em>r.mapcalc</em>).
-    <li>The <b>expression</b> option is first, so it is possible to
-        omit its name in the command line
-        (just like with <em>r.mapcalc</em>).
-    <li>Overwriting of outputs is done in the same way as with other
-        modules, so there is no flag to not overwrite outputs.
-</ul>
-<h2>EXAMPLES</h2>
-<h3>Basic examples</h3>
-<div class="code"><pre>
-r.mapcalculator expression="0" output=zeros
-r.mapcalculator expression="1" output=ones
-r.mapcalculator expression="2" output=twos
-</pre></div>
-r.mapcalculator expression="A + B + C" a=zeros b=ones c=twos output=result1
-</pre></div>
-r.mapcalculator expression="(A * B) / 2 + 3 * C" a=zeros b=ones c=twos output=result2
-</pre></div>
-<h3>Example expressions</h3>
-Addition:
-A + B
-</pre></div>
-No spaces around operators are not recommended for readability,
-but allowed in the expression:
-A+B
-</pre></div>
-More complex expression with a function:
-<p>
-exp(A+C)+(B-2)*7
-</pre></div>
-<h2>SEE ALSO</h2>
-<em>
-<a href="r.mapcalc.html">r.mapcalc</a>,
-<a href="r3.mapcalc.html">r3.mapcalc</a>,
-<a href="t.rast.mapcalc.html">t.rast.mapcalc</a>,
-<a href="g.region.html">g.region</a>
-</em>
-<h2>AUTHORS</h2>
-Vaclav Petras, <a href="https://geospatial.ncsu.edu/geoforall/">NCSU GeoForAll Lab</a><br>
-R. Brunzema (original 5.0 Bash version)<br>
-Michael Barton, Arizona State University (updated to GRASS 5.7)
-<p><i>Last changed: $Date$</i>
Deleted: grass/trunk/scripts/r.mapcalc.simple/r.mapcalculator.py
--- sandbox/wenzeslaus/r.mapcalculator/r.mapcalculator.py	2018-12-11 02:56:25 UTC (rev 73790)
+++ grass/trunk/scripts/r.mapcalc.simple/r.mapcalculator.py	2018-12-11 06:28:51 UTC (rev 73791)
@@ -1,143 +0,0 @@
-#!/usr/bin/env python
-MODULE:    r.mapcalculator
-AUTHOR(S): Vaclav Petras <wenzeslaus gmail com>
-           R. Brunzema <r.brunzema web de> (original 5.0 version)
-           Michael Barton <michael.barton asu edu> (update to GRASS 5.7)
-           Huidae Cho <grass4u gmail com> (removed bashism)
-PURPOSE:   Provides wrapper friendly wrapper to r.mapcalc
-COPYRIGHT: (C) 2018 by Vaclav Petras and the GRASS Development Team
-This program is free software under the GNU General Public
-License (>=v2). Read the file COPYING that comes with GRASS
-for details.
-#%module
-#% description: Calculate new raster map from a r.mapcalc expression
-#% keyword: raster
-#% keyword: algebra
-#%end
-#%option
-#% key: expression
-#% type: string
-#% description: Formula (e.g. A-B or A*C+B)
-#% required : yes
-#%end
-#%option G_OPT_R_INPUT
-#% key: a
-#% description: A
-#% required : no
-#%end
-#% key: b
-#% description: B
-#% required : no
-#%end
-#% key: c
-#% description: C
-#% required : no
-#%end
-#% key: d
-#% description: D
-#% required : no
-#%end
-#% key: e
-#% description: E
-#% required : no
-#%end
-#% key: f
-#% description: F
-#% required : no
-#%end
-#%option
-#% key: output
-#% description: Name for output raster map
-#% required : yes
-#%end
-#%option
-#% key: seed
-#% type: integer
-#% required: no
-#% multiple: no
-#% description: Seed for rand() function
-#%end
-#%flag
-#% key: s
-#% description: Generate random seed (result is non-deterministic)
-#%end
-#%flag
-#% key: q
-#% description: Quote the map names
-#%end
-#%flag
-#% key: c
-#% description: Case sensitive variable names
-#%end
-import sys
-import re
-import grass.script as gs
-def name_quote(name):
-    return '"{}"'.format(name)
-def main():
-    options, flags = gs.parser()
-    expr = options['expression']
-    if not expr:
-        gs.fatal(_("The expression is an empty string"))
-    output = options['output']
-    quote = flags['q']
-    re_flags = 0
-    if flags['c']:
-        re_flags = re.IGNORECASE
-    if quote:
-        output = name_quote(output)
-    seed = None
-    if options['seed']:
-        seed = options['seed']
-    elif flags['s']:
-        seed = 'auto'
-    variables = []
-    for key in "ABCDEF":
-        name = options[key.lower()]
-        if name:
-            if quote:
-                name = name_quote(name)
-            variables.append((key, name))
-    for key, name in variables:
-        find = r'([^a-zA-Z0-9]|^){key}([^a-zA-Z0-9]|$)'.format(key=key)
-        replace = r'\1{}\2'.format(name)
-        # we need to do the substitution twice because we are matching
-        # also the char before and after which fails when there is only
-        # one char between the two usages of the same var (e.g. A*A)
-        expr = re.sub(find, replace, expr, flags=re_flags)
-    expr = '{lhs} = {rhs}'.format(lhs=output, rhs=expr)
-    gs.verbose(_("Expression: {}").format(expr))
-    gs.mapcalc(expr, seed=seed)
-    # g.message -e "Calculating $GIS_OPT_OUTFILE. Try expert mode."
-    return 0
-if __name__ == "__main__":
-    sys.exit(main())
Copied: grass/trunk/scripts/r.mapcalc.simple/testsuite/test_rmapcalcsimple.py (from rev 73790, sandbox/wenzeslaus/r.mapcalculator/testsuite/test_rmapcalculator.py)
--- grass/trunk/scripts/r.mapcalc.simple/testsuite/test_rmapcalcsimple.py	                        (rev 0)
+++ grass/trunk/scripts/r.mapcalc.simple/testsuite/test_rmapcalcsimple.py	2018-12-11 06:28:51 UTC (rev 73791)
@@ -0,0 +1,49 @@
+Name:       r.mapcalc.simple test
+Purpose:    Tests r.mapcalc.simple and its flags/options.
+Author:     Markus Neteler
+Copyright:  (C) 2018 by Markus Neteler and the GRASS Development Team
+Licence:    This program is free software under the GNU General Public
+            License (>=v2). Read the file COPYING that comes with GRASS
+            for details.
+from grass.gunittest.case import TestCase
+class TestReport(TestCase):
+    @classmethod
+    def setUpClass(cls):
+        """Use temporary region settings"""
+        map_input = 'elevation'
+        cls.runModule("g.region", raster=map_input)
+        cls.use_temp_region()
+    @classmethod
+    def tearDownClass(cls):
+        map_output1 = 'test1'
+        map_output2 = 'test2'
+        cls.runModule("g.remove", flags='f', type='raster', name=map_output1)
+        cls.runModule("g.remove", flags='f', type='raster', name=map_output2)
+        cls.del_temp_region()
+    def test_rmapcalcsimple(self):
+        """Testing r.mapcalc.simple"""
+        # test 1
+        self.assertModule('r.mapcalc.simple', expression='0', output=map_output1)
+        self.assertRasterMinMax(map=map_output1, refmin=0, refmax=0,
+                                msg="Result must be 0 for all pixels")
+        # test 2
+        formula='if(%s > 2000, 1, 0)' % map_input # expected to be 0
+        self.assertModule('r.mapcalc.simple', expression=formula, output=map_output2)
+        self.assertRasterMinMax(map=map_output2, refmin=0, refmax=0,
+if __name__ == '__main__':
+    from grass.gunittest.main import test
+    test()
Deleted: grass/trunk/scripts/r.mapcalc.simple/testsuite/test_rmapcalculator.py
--- sandbox/wenzeslaus/r.mapcalculator/testsuite/test_rmapcalculator.py	2018-12-11 02:56:25 UTC (rev 73790)
+++ grass/trunk/scripts/r.mapcalc.simple/testsuite/test_rmapcalculator.py	2018-12-11 06:28:51 UTC (rev 73791)
@@ -1,49 +0,0 @@
-Name:       r.mapcalculator test
-Purpose:    Tests r.mapcalculator and its flags/options.
-Author:     Markus Neteler
-Copyright:  (C) 2018 by Markus Neteler and the GRASS Development Team
-Licence:    This program is free software under the GNU General Public
-            License (>=v2). Read the file COPYING that comes with GRASS
-            for details.
-from grass.gunittest.case import TestCase
-class TestReport(TestCase):
-    @classmethod
-    def setUpClass(cls):
-        """Use temporary region settings"""
-        map_input = 'elevation'
-        cls.runModule("g.region", raster=map_input)
-        cls.use_temp_region()
-    @classmethod
-    def tearDownClass(cls):
-        map_output1 = 'test1'
-        map_output2 = 'test2'
-        cls.runModule("g.remove", flags='f', type='raster', name=map_output1)
-        cls.runModule("g.remove", flags='f', type='raster', name=map_output2)
-        cls.del_temp_region()
-    def test_rmapcalculator(self):
-        """Testing r.mapcalculator"""
-        # test 1
-        self.assertModule('r.mapcalculator', expression='0', output=map_output1)
-        self.assertRasterMinMax(map=map_output1, refmin=0, refmax=0,
-                                msg="Result must be 0 for all pixels")
-        # test 2
-        formula='if(%s > 2000, 1, 0)' % map_input # expected to be 0
-        self.assertModule('r.mapcalculator', expression=formula, output=map_output2)
-        self.assertRasterMinMax(map=map_output2, refmin=0, refmax=0,
-if __name__ == '__main__':
-    from grass.gunittest.main import test
-    test()
