[GRASS-SVN] r73835 - in grass/trunk: gui/wxpython/gui_core gui/wxpython/modules lib/python/ctypes/ctypesgencore/parser lib/raster
Tue Dec 25 12:01:12 PST 2018
Author: martinl
Date: 2018-12-25 12:01:12 -0800 (Tue, 25 Dec 2018)
New Revision: 73835
   grass/trunk/gui/wxpython/gui_core/menu.py
   grass/trunk/gui/wxpython/gui_core/treeview.py
   grass/trunk/gui/wxpython/gui_core/widgets.py
   grass/trunk/gui/wxpython/modules/extensions.py
   grass/trunk/lib/python/ctypes/ctypesgencore/parser/lextab.py
   grass/trunk/lib/raster/gdal.c
libraster: add support for GDAL 2.4 on MS Windows
Modified: grass/trunk/gui/wxpython/gui_core/menu.py
--- grass/trunk/gui/wxpython/gui_core/menu.py	2018-12-25 20:00:12 UTC (rev 73834)
+++ grass/trunk/gui/wxpython/gui_core/menu.py	2018-12-25 20:01:12 UTC (rev 73835)
@@ -152,9 +152,6 @@
         self._tree.SetToolTip(
             _("Double-click or Ctrl-Enter to run selected module"))
-#        self._dataBox = wx.StaticBox(parent = self, id = wx.ID_ANY,
-#                                     label = " %s " % _("Module tree"))
         # search widget
         self._search = SearchModuleWidget(parent=self,
                                           model=model,
Modified: grass/trunk/gui/wxpython/gui_core/treeview.py
--- grass/trunk/gui/wxpython/gui_core/treeview.py	2018-12-25 20:00:12 UTC (rev 73834)
+++ grass/trunk/gui/wxpython/gui_core/treeview.py	2018-12-25 20:01:12 UTC (rev 73835)
@@ -112,16 +112,24 @@
         :param node: node representing item
         :param select: True/False to select/deselect
+        print (node)
         index = self._model.GetIndexOfNode(node)
+        # expand parents
         for i in range(len(index))[1:]:
+            print (index[:i])
             item = self.GetItemByIndex(index[:i])
+            print (item, item.GetText())
             self.Expand(item)
             # needed for wxPython 3:
-            self.EnsureVisible(item)
+            # self.EnsureVisible(item)
+        print (index)
         item = self.GetItemByIndex(index)
+        self.EnsureVisible(item)
         self.SelectItem(item, select)
     def ExpandNode(self, node, recursive=True):
         """Expand items.
Modified: grass/trunk/gui/wxpython/gui_core/widgets.py
--- grass/trunk/gui/wxpython/gui_core/widgets.py	2018-12-25 20:00:12 UTC (rev 73834)
+++ grass/trunk/gui/wxpython/gui_core/widgets.py	2018-12-25 20:01:12 UTC (rev 73835)
@@ -1073,9 +1073,6 @@
         wx.Panel.__init__(self, parent=parent, id=wx.ID_ANY, **kwargs)
-#        self._box = wx.StaticBox(parent = self, id = wx.ID_ANY,
-# label = " %s " % _("Find module - (press Enter for next match)"))
         if sys.platform == 'win32':
             self._search = TextCtrl(
                 parent=self, id=wx.ID_ANY, size=(-1, 25),
Modified: grass/trunk/gui/wxpython/modules/extensions.py
--- grass/trunk/gui/wxpython/modules/extensions.py	2018-12-25 20:00:12 UTC (rev 73834)
+++ grass/trunk/gui/wxpython/modules/extensions.py	2018-12-25 20:01:12 UTC (rev 73835)
@@ -127,9 +127,9 @@
         # self.btnFetch.Bind(wx.EVT_BUTTON, self.OnFetch)
         self.btnInstall.Bind(wx.EVT_BUTTON, self.OnInstall)
         self.btnHelp.Bind(wx.EVT_BUTTON, self.OnHelp)
-        self.tree.selectionChanged.connect(self.OnItemSelected)
-        self.tree.itemActivated.connect(self.OnItemActivated)
-        self.tree.contextMenu.connect(self.OnContextMenu)
+        #self.tree.selectionChanged.connect(self.OnItemSelected)
+        #self.tree.itemActivated.connect(self.OnItemActivated)
+        #self.tree.contextMenu.connect(self.OnContextMenu)
         wx.CallAfter(self._fetch)
Modified: grass/trunk/lib/python/ctypes/ctypesgencore/parser/lextab.py
--- grass/trunk/lib/python/ctypes/ctypesgencore/parser/lextab.py	2018-12-25 20:00:12 UTC (rev 73834)
+++ grass/trunk/lib/python/ctypes/ctypesgencore/parser/lextab.py	2018-12-25 20:01:12 UTC (rev 73835)
@@ -1,8 +1,8 @@
 # lextab.py. This file automatically created by PLY (version 2.2). Don't edit!
-_lextokens    = {'PP_END_DEFINE': None, 'DIV_ASSIGN': None, 'AND_OP': None, 'PERIOD': None, 'PTR_OP': None, 'PP_MACRO_PARAM': None, 'OTHER': None, 'IDENTIFIER': None, 'PP_STRINGIFY': None, 'XOR_ASSIGN': None, 'PP_DEFINE_NAME': None, 'ELLIPSIS': None, 'INC_OP': None, 'GE_OP': None, 'LEFT_ASSIGN': None, 'MUL_ASSIGN': None, 'RIGHT_ASSIGN': None, 'SUB_ASSIGN': None, 'LPAREN': None, 'PP_IDENTIFIER_PASTE': None, 'PP_DEFINE': None, 'OR_ASSIGN': None, 'ADD_ASSIGN': None, 'HEADER_NAME': None, 'LE_OP': None, 'LEFT_OP': None, 'PP_NUMBER': None, 'DEC_OP': None, 'RIGHT_OP': None, 'MOD_ASSIGN': None, 'STRING_LITERAL': None, 'EQ_OP': None, 'OR_OP': None, 'AND_ASSIGN': None, 'CHARACTER_CONSTANT': None, 'PP_DEFINE_MACRO_NAME': None, 'NE_OP': None, 'NEWLINE': None}
+_lextokens    = {'HEADER_NAME': None, 'IDENTIFIER': None, 'PP_NUMBER': None, 'CHARACTER_CONSTANT': None, 'STRING_LITERAL': None, 'OTHER': None, 'PTR_OP': None, 'INC_OP': None, 'DEC_OP': None, 'LEFT_OP': None, 'RIGHT_OP': None, 'LE_OP': None, 'GE_OP': None, 'EQ_OP': None, 'NE_OP': None, 'AND_OP': None, 'OR_OP': None, 'MUL_ASSIGN': None, 'DIV_ASSIGN': None, 'MOD_ASSIGN': None, 'ADD_ASSIGN': None, 'SUB_ASSIGN': None, 'LEFT_ASSIGN': None, 'RIGHT_ASSIGN': None, 'AND_ASSIGN': None, 'XOR_ASSIGN': None, 'OR_ASSIGN': None, 'PERIOD': None, 'ELLIPSIS': None, 'LPAREN': None, 'NEWLINE': None, 'PP_DEFINE': None, 'PP_DEFINE_NAME': None, 'PP_DEFINE_MACRO_NAME': None, 'PP_MACRO_PARAM': None, 'PP_STRINGIFY': None, 'PP_IDENTIFIER_PASTE': None, 'PP_END_DEFINE': None}
 _lexreflags   = 0
 _lexliterals  = ''
-_lexstateinfo = {'DEFINE': 'exclusive', 'INITIAL': 'inclusive'}
-_lexstatere   = {'DEFINE': [('(?P<t_ANY_directive>\\#\\s+(\\d+)\\s+"([^"]+)"[ \\d]*\\n)|(?P<t_ANY_punctuator>(\\.\\.\\.|\\|\\||\\+\\+|\\*=|\\|=|\\+=|>>=|\\^=|<<=|\\)|-=|<%|<<|%>|\\+|>>|<=|/=|->|!=|&&|\\*|\\[|\\?|--|>=|\\.|:>|&=|==|<:|%=|\\||\\^|/|:|{|~|,|>|-|%|}|;|!|=|&|]|<))', [None, ('t_ANY_directive', 'ANY_directive'), None, None, ('t_ANY_punctuator', 'ANY_punctuator')]), ('(?P<t_DEFINE_identifier>[a-zA-Z_]([a-zA-Z_]|[0-9])*)', [None, ('t_DEFINE_identifier', 'DEFINE_identifier')]), ('(?P<t_ANY_float>(?P<p1>[0-9]+)?(?P<dp>[.]?)(?P<p2>(?(p1)[0-9]*|[0-9]+))(?P<exp>(?:[Ee][+-]?[0-9]+)?)(?P<suf>([FfLl]|d[dfl]|D[DFL]|[fFdD][0-9]+x?)?)(?!\\w))', [None, ('t_ANY_float', 'ANY_float'), None, None, None, None, None]), ('(?P<t_ANY_int>(?P<p1>(?:0x[a-fA-F0-9]+)|(?:[0-9]+))(?P<suf>[uUlL]*))', [None, ('t_ANY_int', 'ANY_int'), None, None]), ('(?P<t_ANY_character_constant>L?\'(\\\\.|[^\\\\\'])+\')|(?P<t_ANY_string_literal>L?"(\\\\.|[^\\\\"])*")|(?P<t_ANY_lparen>\\()|(?P<t_DEFINE_newline>\\n)|(?P<t
 _DEFINE_pp_param_op>(\\#\\#)|(\\#))', [None, ('t_ANY_character_constant', 'ANY_character_constant'), None, ('t_ANY_string_literal', 'ANY_string_literal'), None, ('t_ANY_lparen', 'ANY_lparen'), ('t_DEFINE_newline', 'DEFINE_newline'), ('t_DEFINE_pp_param_op', 'DEFINE_pp_param_op')])], 'INITIAL': [('(?P<t_ANY_directive>\\#\\s+(\\d+)\\s+"([^"]+)"[ \\d]*\\n)|(?P<t_ANY_punctuator>(\\.\\.\\.|\\|\\||\\+\\+|\\*=|\\|=|\\+=|>>=|\\^=|<<=|\\)|-=|<%|<<|%>|\\+|>>|<=|/=|->|!=|&&|\\*|\\[|\\?|--|>=|\\.|:>|&=|==|<:|%=|\\||\\^|/|:|{|~|,|>|-|%|}|;|!|=|&|]|<))', [None, ('t_ANY_directive', 'ANY_directive'), None, None, ('t_ANY_punctuator', 'ANY_punctuator')]), ('(?P<t_INITIAL_identifier>[a-zA-Z_]([a-zA-Z_]|[0-9])*)', [None, ('t_INITIAL_identifier', 'INITIAL_identifier')]), ('(?P<t_ANY_float>(?P<p1>[0-9]+)?(?P<dp>[.]?)(?P<p2>(?(p1)[0-9]*|[0-9]+))(?P<exp>(?:[Ee][+-]?[0-9]+)?)(?P<suf>([FfLl]|d[dfl]|D[DFL]|[fFdD][0-9]+x?)?)(?!\\w))', [None, ('t_ANY_float', 'ANY_float'), None, None, None, None, None]), ('(?P<t
 _ANY_int>(?P<p1>(?:0x[a-fA-F0-9]+)|(?:[0-9]+))(?P<suf>[uUlL]*))', [None, ('t_ANY_int', 'ANY_int'), None, None]), ('(?P<t_ANY_character_constant>L?\'(\\\\.|[^\\\\\'])+\')|(?P<t_ANY_string_literal>L?"(\\\\.|[^\\\\"])*")|(?P<t_ANY_lparen>\\()|(?P<t_INITIAL_newline>\\n)|(?P<t_INITIAL_pp_define>\\#define)', [None, ('t_ANY_character_constant', 'ANY_character_constant'), None, ('t_ANY_string_literal', 'ANY_string_literal'), None, ('t_ANY_lparen', 'ANY_lparen'), ('t_INITIAL_newline', 'INITIAL_newline'), ('t_INITIAL_pp_define', 'INITIAL_pp_define')])]}
-_lexstateignore = {'DEFINE': ' \t\x0b\x0c\r', 'INITIAL': ' \t\x0b\x0c\r'}
-_lexstateerrorf = {'DEFINE': 't_DEFINE_error', 'INITIAL': 't_INITIAL_error'}
+_lexstateinfo = {'INITIAL': 'inclusive', 'DEFINE': 'exclusive'}
+_lexstatere   = {'INITIAL': [('(?P<t_ANY_directive>\\#\\s+(\\d+)\\s+"([^"]+)"[ \\d]*\\n)|(?P<t_ANY_punctuator>(\\.\\.\\.|\\+\\+|\\|\\||>>=|<<=|\\+=|\\*=|\\^=|\\|=|-=|/=|%=|&=|>>|<<|--|->|&&|<=|>=|==|!=|<:|:>|<%|%>|\\)|\\[|\\.|\\+|\\*|\\^|\\||\\?|;|{|}|,|:|=|]|&|!|~|-|/|%|<|>))', [None, ('t_ANY_directive', 'ANY_directive'), None, None, ('t_ANY_punctuator', 'ANY_punctuator')]), ('(?P<t_INITIAL_identifier>[a-zA-Z_]([a-zA-Z_]|[0-9])*)', [None, ('t_INITIAL_identifier', 'INITIAL_identifier')]), ('(?P<t_ANY_float>(?P<p1>[0-9]+)?(?P<dp>[.]?)(?P<p2>(?(p1)[0-9]*|[0-9]+))(?P<exp>(?:[Ee][+-]?[0-9]+)?)(?P<suf>([FfLl]|d[dfl]|D[DFL]|[fFdD][0-9]+x?)?)(?!\\w))', [None, ('t_ANY_float', 'ANY_float'), None, None, None, None, None]), ('(?P<t_ANY_int>(?P<p1>(?:0x[a-fA-F0-9]+)|(?:[0-9]+))(?P<suf>[uUlL]*))', [None, ('t_ANY_int', 'ANY_int'), None, None]), ('(?P<t_ANY_character_constant>L?\'(\\\\.|[^\\\\\'])+\')|(?P<t_ANY_string_literal>L?"(\\\\.|[^\\\\"])*")|(?P<t_ANY_lparen>\\()|(?P<t_INITIAL_newline>\\n)|
 (?P<t_INITIAL_pp_define>\\#define)', [None, ('t_ANY_character_constant', 'ANY_character_constant'), None, ('t_ANY_string_literal', 'ANY_string_literal'), None, ('t_ANY_lparen', 'ANY_lparen'), ('t_INITIAL_newline', 'INITIAL_newline'), ('t_INITIAL_pp_define', 'INITIAL_pp_define')])], 'DEFINE': [('(?P<t_ANY_directive>\\#\\s+(\\d+)\\s+"([^"]+)"[ \\d]*\\n)|(?P<t_ANY_punctuator>(\\.\\.\\.|\\+\\+|\\|\\||>>=|<<=|\\+=|\\*=|\\^=|\\|=|-=|/=|%=|&=|>>|<<|--|->|&&|<=|>=|==|!=|<:|:>|<%|%>|\\)|\\[|\\.|\\+|\\*|\\^|\\||\\?|;|{|}|,|:|=|]|&|!|~|-|/|%|<|>))', [None, ('t_ANY_directive', 'ANY_directive'), None, None, ('t_ANY_punctuator', 'ANY_punctuator')]), ('(?P<t_DEFINE_identifier>[a-zA-Z_]([a-zA-Z_]|[0-9])*)', [None, ('t_DEFINE_identifier', 'DEFINE_identifier')]), ('(?P<t_ANY_float>(?P<p1>[0-9]+)?(?P<dp>[.]?)(?P<p2>(?(p1)[0-9]*|[0-9]+))(?P<exp>(?:[Ee][+-]?[0-9]+)?)(?P<suf>([FfLl]|d[dfl]|D[DFL]|[fFdD][0-9]+x?)?)(?!\\w))', [None, ('t_ANY_float', 'ANY_float'), None, None, None, None, None]), ('(?P<t_ANY_
 int>(?P<p1>(?:0x[a-fA-F0-9]+)|(?:[0-9]+))(?P<suf>[uUlL]*))', [None, ('t_ANY_int', 'ANY_int'), None, None]), ('(?P<t_ANY_character_constant>L?\'(\\\\.|[^\\\\\'])+\')|(?P<t_ANY_string_literal>L?"(\\\\.|[^\\\\"])*")|(?P<t_ANY_lparen>\\()|(?P<t_DEFINE_newline>\\n)|(?P<t_DEFINE_pp_param_op>(\\#\\#)|(\\#))', [None, ('t_ANY_character_constant', 'ANY_character_constant'), None, ('t_ANY_string_literal', 'ANY_string_literal'), None, ('t_ANY_lparen', 'ANY_lparen'), ('t_DEFINE_newline', 'DEFINE_newline'), ('t_DEFINE_pp_param_op', 'DEFINE_pp_param_op')])]}
+_lexstateignore = {'INITIAL': ' \t\x0b\x0c\r', 'DEFINE': ' \t\x0b\x0c\r'}
+_lexstateerrorf = {'INITIAL': 't_INITIAL_error', 'DEFINE': 't_DEFINE_error'}
Modified: grass/trunk/lib/raster/gdal.c
--- grass/trunk/lib/raster/gdal.c	2018-12-25 20:00:12 UTC (rev 73834)
+++ grass/trunk/lib/raster/gdal.c	2018-12-25 20:01:12 UTC (rev 73835)
@@ -115,6 +115,7 @@
 	"libgdal1.7.0.so",
 # endif
 # ifdef _WIN32
+	"gdal204.dll",
 	"gdal203.dll",
 	"gdal202.dll",
 	"gdal201.dll",
