[GRASS-SVN] r72278 - grass/branches/releasebranch_7_4/lib/init
Sun Feb 25 07:28:44 PST 2018
Author: mmetz
Date: 2018-02-25 07:28:44 -0800 (Sun, 25 Feb 2018)
New Revision: 72278
   grass/branches/releasebranch_7_4/lib/init/grass.py
grass startup script: fix confusing message about missing WIND file fixed (backport trunk r72277)
Modified: grass/branches/releasebranch_7_4/lib/init/grass.py
--- grass/branches/releasebranch_7_4/lib/init/grass.py	2018-02-25 15:21:46 UTC (rev 72277)
+++ grass/branches/releasebranch_7_4/lib/init/grass.py	2018-02-25 15:28:44 UTC (rev 72278)
@@ -930,12 +930,14 @@
                 else:
                     # 'location_name' is a valid GRASS location,
                     # create new mapset
-                    os.mkdir(location)
+                    if os.path.exists(location):
+                        warning(_("Missing WIND file"))
+                    else:
+                        os.mkdir(location)
                     # copy PERMANENT/DEFAULT_WIND to <mapset>/WIND
                     s = readfile(os.path.join(gisdbase, location_name,
                                               "PERMANENT", "DEFAULT_WIND"))
                     writefile(os.path.join(location, "WIND"), s)
-                    message(_("Missing WIND file fixed"))
         if os.access(gisrc, os.R_OK):
             kv = read_gisrc(gisrc)
