[GRASS-SVN] r72041 - grass/branches/releasebranch_7_4/locale/po
Sat Jan 6 10:27:45 PST 2018
Author: marisn
Date: 2018-01-06 10:27:45 -0800 (Sat, 06 Jan 2018)
New Revision: 72041
   grass/branches/releasebranch_7_4/locale/po/grasslibs_lv.po
   grass/branches/releasebranch_7_4/locale/po/grassmods_lv.po
   grass/branches/releasebranch_7_4/locale/po/grasswxpy_lv.po
Translations: LV translation update
Modified: grass/branches/releasebranch_7_4/locale/po/grasslibs_lv.po
--- grass/branches/releasebranch_7_4/locale/po/grasslibs_lv.po	2018-01-06 17:58:15 UTC (rev 72040)
+++ grass/branches/releasebranch_7_4/locale/po/grasslibs_lv.po	2018-01-06 18:27:45 UTC (rev 72041)
@@ -7,7 +7,7 @@
 msgstr ""
 "Project-Id-Version: grasslibs_lv\n"
 "Report-Msgid-Bugs-To: \n"
-"POT-Creation-Date: 2017-04-01 16:10+0300\n"
+"POT-Creation-Date: 2018-01-06 20:09+0200\n"
 "PO-Revision-Date: 2017-04-01 17:03+0200\n"
 "Last-Translator: Maris Nartiss <maris.kde at gmail.com>\n"
 "Language-Team: Latvian <grass-translations at lists.osgeo.org>\n"
@@ -19,4299 +19,2407 @@
 "X-Poedit-Language: Latvian\n"
 "X-Poedit-Country: LATVIA\n"
 "X-Poedit-SourceCharset: utf-8\n"
-"Plural-Forms:  nplurals=3; plural=(n%10==1 && n%100!=11 ? 0 : n != 0 ? 1 : 2);\n"
+"Plural-Forms:  nplurals=3; plural=(n%10==1 && n%100!=11 ? 0 : n != 0 ? 1 : "
+"2);\n"
-#: ../lib/cairodriver/text.c:46
-#, c-format
-msgid "Unable to convert from <%s> to UTF-8"
-msgstr ""
+#: ../lib/vector/neta/spanningtree.c:101 ../lib/vector/neta/flow.c:66
+#: ../lib/vector/neta/flow.c:190 ../lib/vector/neta/timetables.c:69
+#: ../lib/vector/neta/timetables.c:168 ../lib/vector/neta/timetables.c:178
+#: ../lib/vector/neta/timetables.c:191 ../lib/vector/neta/timetables.c:278
+#: ../lib/vector/neta/timetables.c:413 ../lib/vector/neta/timetables.c:425
+#: ../lib/vector/neta/centrality.c:63 ../lib/vector/neta/centrality.c:145
+#: ../lib/vector/neta/path.c:262 ../lib/vector/neta/articulation_point.c:60
+#: ../lib/vector/neta/components.c:71 ../lib/vector/neta/components.c:176
+#: ../lib/vector/neta/bridge.c:58 ../lib/vector/Vlib/map.c:48
+#: ../lib/vector/Vlib/line.c:50 ../lib/vector/Vlib/line.c:154
+#: ../lib/vector/diglib/struct_alloc.c:491
+#: ../lib/rst/interp_float/interp2d.c:139
+#: ../lib/rst/interp_float/interp2d.c:145
+#: ../lib/rst/interp_float/segmen2d_parallel.c:78
+#: ../lib/rst/interp_float/segmen2d_parallel.c:85
+#: ../lib/rst/interp_float/segmen2d_parallel.c:92
+#: ../lib/rst/interp_float/segmen2d_parallel.c:101
+#: ../lib/rst/interp_float/segmen2d_parallel.c:263
+#: ../lib/rst/interp_float/segmen2d.c:197
+#: ../lib/rst/interp_float/segmen2d.c:203
+#: ../lib/rst/interp_float/segmen2d.c:209
+#: ../lib/rst/interp_float/segmen2d.c:219 ../lib/segment/open.c:98
+#: ../lib/rowio/setup.c:61 ../lib/rowio/setup.c:67
+msgid "Out of memory"
+msgstr "Nepietiek atmiņas"
-#: ../lib/cairodriver/text.c:56
-msgid "Some characters could not be converted to UTF-8"
+#: ../lib/vector/neta/spanningtree.c:106
+msgid "Computing minimum spanning tree..."
 msgstr ""
-#: ../lib/cairodriver/raster.c:109
-msgid "Failed to create cairo surface"
+#: ../lib/vector/neta/flow.c:331 ../lib/vector/Vlib/graph.c:105
+#: ../lib/vector/Vlib/net_build.c:661 ../lib/vector/Vlib/net_build.c:1067
+msgid "GngFlatten error"
 msgstr ""
-#: ../lib/cairodriver/read_ppm.c:28 ../lib/cairodriver/read_bmp.c:88
+#: ../lib/vector/neta/timetables.c:46 ../lib/vector/neta/timetables.c:203
+#: ../lib/vector/neta/timetables.c:244 ../lib/vector/neta/timetables.c:286
 #, c-format
-msgid "Cairo: unable to open input file <%s>"
+msgid "Unable to open select cursor: %s"
 msgstr ""
-#: ../lib/cairodriver/read_ppm.c:32 ../lib/cairodriver/read_bmp.c:92
+#: ../lib/vector/neta/timetables.c:133 ../lib/vector/neta/utils.c:119
+#: ../lib/vector/Vlib/write_pg.c:2915 ../lib/vector/Vlib/ascii.c:410
+#: ../lib/vector/Vlib/close_nat.c:160 ../lib/vector/Vlib/net_build.c:165
+#: ../lib/vector/Vlib/net_build.c:211 ../lib/vector/Vlib/net_build.c:496
+#: ../lib/vector/Vlib/net_build.c:797 ../lib/vector/Vlib/net_build.c:976
+#: ../lib/vector/Vlib/cats.c:597 ../lib/vector/Vlib/array.c:282
+#: ../lib/vector/Vlib/write_ogr.c:197 ../lib/vector/Vlib/map.c:341
+#: ../lib/rst/interp_float/vinput2d.c:109 ../lib/db/dbmi_client/db.c:46
+#: ../lib/db/dbmi_client/copy_tab.c:112 ../lib/db/dbmi_client/copy_tab.c:133
+#: ../lib/ogsf/gv3.c:350 ../lib/ogsf/gp3.c:208
 #, c-format
-msgid "Cairo: invalid input file <%s>"
-msgstr ""
+msgid "Unable to open database <%s> by driver <%s>"
+msgstr "Nav iespējams atvērt datu bāzi <%s> izmantojot <%s> dzinēju"
-#: ../lib/cairodriver/read_ppm.c:38
+#: ../lib/vector/neta/utils.c:200
 #, c-format
-msgid "Cairo: input file has incorrect dimensions: expected: %dx%d got: %dx%d"
+msgid "Point %d is not connected!"
 msgstr ""
-#: ../lib/cairodriver/read_ppm.c:46
+#: ../lib/vector/neta/utils.c:235
 #, c-format
-msgid "Cairo: unable to open input mask file <%s>"
+msgid "'%s' must be > 0"
 msgstr ""
-#: ../lib/cairodriver/read_ppm.c:50
-#, c-format
-msgid "Cairo: invalid input mask file <%s>"
+#: ../lib/vector/neta/utils.c:244
+msgid "'where' and 'cats' parameters were supplied, cat will be ignored"
 msgstr ""
-#: ../lib/cairodriver/read_ppm.c:56
-#, c-format
-msgid "Cairo: input mask file has incorrect dimensions: expected: %dx%d got: %dx%d"
+#: ../lib/vector/neta/utils.c:247
+msgid "Unable to load data from database"
 msgstr ""
-#: ../lib/cairodriver/read_xid.c:14
-#, c-format
-msgid "Unable to open input file <%s>"
+#: ../lib/vector/neta/utils.c:254
+msgid "Problem loading category values"
 msgstr ""
-#: ../lib/cairodriver/read_xid.c:17
-#, c-format
-msgid "Unable to read input file <%s>"
+#: ../lib/vector/Vlib/read_pg.c:91 ../lib/vector/Vlib/read_pg.c:214
+#: ../lib/vector/Vlib/read_pg.c:298 ../lib/vector/Vlib/read_pg.c:416
+#: ../lib/vector/Vlib/write_pg.c:123 ../lib/vector/Vlib/write_pg.c:157
+#: ../lib/vector/Vlib/write_pg.c:196 ../lib/vector/Vlib/write_pg.c:294
+#: ../lib/vector/Vlib/write_pg.c:354 ../lib/vector/Vlib/write_pg.c:476
+#: ../lib/vector/Vlib/build_sfa.c:721 ../lib/vector/Vlib/open_pg.c:143
+#: ../lib/vector/Vlib/open_pg.c:200 ../lib/vector/Vlib/open_pg.c:299
+#: ../lib/vector/Vlib/open_pg.c:349 ../lib/vector/Vlib/close.c:275
+#: ../lib/vector/Vlib/close_pg.c:99 ../lib/vector/Vlib/close_pg.c:146
+#: ../lib/vector/Vlib/area.c:94 ../lib/vector/Vlib/area.c:499
+#: ../lib/vector/Vlib/write_sfa.c:306 ../lib/vector/Vlib/build_pg.c:117
+#: ../lib/vector/Vlib/simple_features.c:336
+#: ../lib/vector/Vlib/header_finfo.c:47 ../lib/vector/Vlib/header_finfo.c:86
+#: ../lib/vector/Vlib/header_finfo.c:123 ../lib/vector/Vlib/header_finfo.c:171
+#: ../lib/vector/Vlib/copy.c:428 ../lib/vector/Vlib/rewind_pg.c:56
+#: ../lib/vector/Vlib/rewind_pg.c:81
+msgid "GRASS is not compiled with PostgreSQL support"
 msgstr ""
-#: ../lib/cairodriver/read_xid.c:20
+#: ../lib/vector/Vlib/read_pg.c:192 ../lib/vector/Vlib/read_sfa.c:117
 #, c-format
-msgid "Unable to parse input file <%s>"
+msgid "Unexpected feature type (%d) - should be (%d)"
 msgstr ""
-#: ../lib/cairodriver/write_xid.c:14 ../lib/pngdriver/read_png.c:71
+#: ../lib/vector/Vlib/read_pg.c:272 ../lib/vector/Vlib/read_pg.c:471
 #, c-format
-msgid "Unable to open output file <%s>"
+msgid "Feature %ld without geometry skipped"
 msgstr ""
-#: ../lib/cairodriver/write_xid.c:19
+#: ../lib/vector/Vlib/read_pg.c:331 ../lib/vector/Vlib/write_pg.c:236
+#: ../lib/vector/Vlib/write_pg.c:381 ../lib/vector/Vlib/write_pg.c:396
+#: ../lib/vector/Vlib/box.c:249 ../lib/vector/Vlib/read_sfa.c:50
+#: ../lib/vector/Vlib/write_sfa.c:158 ../lib/vector/Vlib/write_sfa.c:207
+#: ../lib/vector/Vlib/write_nat.c:182 ../lib/vector/Vlib/write_nat.c:295
+#: ../lib/vector/Vlib/write_nat.c:651 ../lib/vector/Vlib/read.c:173
+#: ../lib/vector/Vlib/read_nat.c:144
 #, c-format
-msgid "Unable to write output file <%s>"
+msgid "Attempt to access feature with invalid id (%d)"
 msgstr ""
-#: ../lib/cairodriver/draw_bitmap.c:47
-msgid "Cairo_Bitmap: Failed to create source"
+#: ../lib/vector/Vlib/read_pg.c:337 ../lib/vector/Vlib/write_pg.c:242
+#: ../lib/vector/Vlib/write_pg.c:402 ../lib/vector/Vlib/write_pg.c:2592
+#: ../lib/vector/Vlib/write_pg.c:2689 ../lib/vector/Vlib/read_sfa.c:56
+#: ../lib/vector/Vlib/write_nat.c:301 ../lib/vector/Vlib/write_nat.c:657
+#: ../lib/vector/Vlib/read_nat.c:150
+#, c-format
+msgid "Attempt to access dead feature %d"
 msgstr ""
-#: ../lib/cairodriver/write_bmp.c:72 ../lib/cairodriver/write_ppm.c:27
+#: ../lib/vector/Vlib/read_pg.c:365
 #, c-format
-msgid "Cairo: unable to open output file <%s>"
+msgid ""
+"Requesting invalid feature from cache (%d). Number of features in cache: %d"
 msgstr ""
-#: ../lib/cairodriver/write_ppm.c:34
+#: ../lib/vector/Vlib/read_pg.c:368
 #, c-format
-msgid "Cairo: unable to open mask file <%s>"
+msgid "Feature %d: unexpected type (%d) - should be %d"
 msgstr ""
-#: ../lib/cairodriver/graph.c:67
-msgid "Unable to open display"
-msgstr "Nav iespējams atvērt ekrānu"
-#: ../lib/cairodriver/graph.c:85
-msgid "Unable to obtain visual"
+#: ../lib/vector/Vlib/read_pg.c:378 ../lib/vector/Vlib/build_sfa.c:354
+#: ../lib/vector/Vlib/build_sfa.c:364
+#, c-format
+msgid "Feature %d without geometry skipped"
 msgstr ""
-#: ../lib/cairodriver/graph.c:160
-#, c-format
-msgid "Unknown file extension: %s"
+#: ../lib/vector/Vlib/read_pg.c:482 ../lib/vector/Vlib/read_ogr.c:382
+msgid "Feature without geometry. Skipped."
 msgstr ""
-#: ../lib/cairodriver/graph.c:190
-#, c-format
-msgid "cairo: collecting to file '%s'"
+#: ../lib/vector/Vlib/read_pg.c:575
+msgid "No geometry or topo geometry column defined"
 msgstr ""
-#: ../lib/cairodriver/graph.c:192
-#, c-format
-msgid "cairo: image size %dx%d"
+#: ../lib/vector/Vlib/read_pg.c:585
+msgid "Random access not supported. Primary key not defined."
 msgstr ""
-#: ../lib/cairodriver/graph.c:371
-msgid "Unknown Cairo surface type"
+#: ../lib/vector/Vlib/read_pg.c:652
+msgid "Inconsistency in topology: detected centroid (should be point)"
 msgstr ""
-#: ../lib/cairodriver/graph.c:376
-msgid "Failed to initialize Cairo surface"
+#: ../lib/vector/Vlib/read_pg.c:662
+msgid "Inconsistency in topology: detected boundary (should be line)"
 msgstr ""
-#: ../lib/cairodriver/read_bmp.c:96
+#: ../lib/vector/Vlib/read_pg.c:787
 #, c-format
-msgid "Cairo: Invalid BMP header for <%s>"
+msgid "Invalid WKB content: %d bytes"
 msgstr ""
-#: ../lib/psdriver/graph_set.c:199
-#, c-format
-msgid "ps: truecolor status %s"
+#: ../lib/vector/Vlib/read_pg.c:803
+msgid "Reading EWKB with 4-dimensional coordinates (XYZM) is not supported"
 msgstr ""
-#: ../lib/psdriver/graph_set.c:200 ../lib/pngdriver/graph_set.c:102
-msgid "enabled"
+#: ../lib/vector/Vlib/read_pg.c:884 ../lib/vector/Vlib/read_pg.c:1192
+#: ../lib/vector/Vlib/read_pg.c:1362 ../lib/vector/Vlib/read_pg.c:1455
+#: ../lib/vector/Vlib/write_pg.c:737 ../lib/vector/Vlib/write_pg.c:1176
+#: ../lib/vector/Vlib/write_pg.c:1285 ../lib/vector/Vlib/write_pg.c:1798
+#: ../lib/vector/Vlib/write_pg.c:1975 ../lib/vector/Vlib/write_pg.c:2333
+#, c-format
+msgid "Unsupported feature type %d"
 msgstr ""
-msgid "disabled"
+#: ../lib/vector/Vlib/read_pg.c:996 ../lib/vector/Vlib/read_pg.c:1066
+#: ../lib/vector/Vlib/read_pg.c:1137
+msgid "Length of input WKB is too small"
 msgstr ""
-#: ../lib/psdriver/graph_set.c:214
+#: ../lib/vector/Vlib/read_pg.c:1077
 #, c-format
-msgid "ps: collecting to file '%s'"
+msgid "Invalid cache index %d (max: %d)"
 msgstr ""
-#: ../lib/psdriver/graph_set.c:215
+#: ../lib/vector/Vlib/read_pg.c:1215
 #, c-format
-msgid "ps: image size %dx%d"
+msgid "Corrupted data. %s."
 msgstr ""
-#: ../lib/python/exceptions/__init__.py:68
-#, python-format
-msgid "Module run %s %s ended with error"
+#: ../lib/vector/Vlib/read_pg.c:1217
+msgid "Corrupted data"
 msgstr ""
-#: ../lib/python/exceptions/__init__.py:69
-#, python-format
-msgid ""
-"\n"
-"Process ended with non-zero return code %s"
-msgstr ""
+#: ../lib/vector/Vlib/read_pg.c:1252
+#, fuzzy, c-format
+msgid "Unable to parse '%s'"
+msgstr "Neiespējami atvērt failu %s iekš %s"
-#: ../lib/python/exceptions/__init__.py:71
-#, python-format
-msgid ""
-". See the following errors:\n"
-"%s"
-msgstr ""
+#: ../lib/vector/Vlib/read_pg.c:1420 ../lib/vector/Vlib/close_pg.c:66
+#, c-format
+msgid "Unable to close cursor %s"
+msgstr "Nevar aizvērt kursoru %s"
-#: ../lib/python/exceptions/__init__.py:75
-msgid ". See errors in the (error) output."
-msgstr ""
-#: ../lib/python/pygrass/raster/abstract.py:275
-#, python-brace-format
-msgid "Mode type: {0} not supported ('r', 'w')"
-msgstr ""
-#: ../lib/python/pygrass/raster/abstract.py:286
-msgid "Overwrite type: {0} not supported (True/False)"
-msgstr ""
-#: ../lib/python/pygrass/raster/abstract.py:299
-#: ../lib/python/pygrass/vector/abstract.py:97
-msgid "Map name {0} not valid"
-msgstr ""
-#: ../lib/python/pygrass/raster/category.py:69
-msgid "Raster type: {0} not supported"
-msgstr ""
-#: ../lib/python/pygrass/raster/category.py:156
-msgid "Error executing: Rast_get_ith_cat"
-msgstr ""
-#: ../lib/python/pygrass/raster/category.py:184
-msgid "Null value detected"
-msgstr "Konstatēta NULL vērtība"
-#: ../lib/python/pygrass/raster/category.py:186
-msgid "Error executing: Rast_set_cat"
-msgstr ""
-#: ../lib/python/pygrass/raster/__init__.py:209
-msgid "The map does not exist, I can't open in 'r' mode"
-msgstr ""
-#: ../lib/python/pygrass/raster/__init__.py:214
-msgid "Raster map <{0}> already exists and will be not overwritten"
-msgstr ""
-#: ../lib/python/pygrass/raster/__init__.py:218
-msgid "Raster type not defined"
-msgstr ""
-#: ../lib/python/pygrass/raster/__init__.py:321
-msgid "Mode type: {0} not supported ('r', 'w','rw')"
-msgstr ""
-#: ../lib/python/pygrass/raster/__init__.py:341
-#, python-format
-msgid "Index out of range: %r."
-msgstr ""
-#: ../lib/python/pygrass/raster/__init__.py:530
-msgid "Raster map <{0}> already exists. Use overwrite."
-msgstr ""
-#: ../lib/python/pygrass/raster/__init__.py:561
-msgid "Raster map <{0}> does not exist"
-msgstr ""
-#: ../lib/python/pygrass/utils.py:277
-msgid "Vector doesn't contain points"
-msgstr ""
-#: ../lib/python/pygrass/vector/__init__.py:806
-#, python-format
-msgid "Unable to read line of feature %i"
-msgstr ""
-#: ../lib/python/pygrass/vector/__init__.py:895
-#, python-format
-msgid "Unable to read area with id %i"
-msgstr ""
-#: ../lib/python/pygrass/vector/table.py:1035
-#, python-format
-msgid "Deleting table <%s> which is attached to following map(s):"
-msgstr ""
-#: ../lib/python/pygrass/vector/table.py:1039
-msgid "You must use the force flag to actually remove it. Exiting."
-msgstr ""
-#: ../lib/python/pygrass/modules/grid/grid.py:553
-msgid "Execution of subprocesses was not successful"
-msgstr ""
-#: ../lib/python/pygrass/errors.py:17
-msgid "The map is close!"
-msgstr ""
-#: ../lib/python/pygrass/errors.py:28
-msgid "The self.c_mapinfo pointer must be correctly initiated"
-msgstr ""
-#: ../lib/python/gunittest/gmodules.py:103
-msgid "input='-' must be used when stdin is specified"
-msgstr ""
-#: ../lib/python/gunittest/gmodules.py:105
-msgid "stdin must be string or buffer, not PIPE"
-msgstr ""
-#: ../lib/python/gunittest/gmodules.py:108
-msgid "stdin must be used when input='-'"
-msgstr ""
-#: ../lib/python/gunittest/gmodules.py:110
-msgid "You cannot merge stdout and stderr and not capture them"
-msgstr ""
-#: ../lib/python/gunittest/gmodules.py:112
-msgid "stdout argument not allowed, it could be overridden"
-msgstr ""
-#: ../lib/python/gunittest/gmodules.py:114
-msgid "stderr argument not allowed, it could be overridden"
-msgstr ""
-#: ../lib/python/temporal/datetime_math.py:256
-#: ../lib/python/temporal/datetime_math.py:273
-#, python-format
-msgid "Wrong increment format: %s"
-msgstr ""
-#: ../lib/python/temporal/datetime_math.py:451
-#: ../lib/python/temporal/abstract_space_time_dataset.py:1616
-#, python-format
-msgid "Wrong granularity format: %s"
-msgstr ""
-#: ../lib/python/temporal/datetime_math.py:729
-msgid "Time string seems to specify relative time"
-msgstr ""
-#: ../lib/python/temporal/datetime_math.py:741
-msgid "Dates Before Christ (BC) are not supported"
-msgstr ""
-#: ../lib/python/temporal/datetime_math.py:745
-msgid "Time zones are not supported"
-msgstr ""
-#: ../lib/python/temporal/datetime_math.py:755
-#, python-format
-msgid "Unable to parse time string: %s"
-msgstr ""
-#: ../lib/python/temporal/core.py:604
-msgid "Unable to initialize the temporal DBMI interface. Please use t.connect to specify the driver and the database string"
-msgstr ""
-#: ../lib/python/temporal/core.py:667
-#, python-format
+#: ../lib/vector/Vlib/read_pg.c:1530
+#, c-format
 msgid ""
-"Unable to receive temporal database metadata.\n"
-"Current temporal database info:%(info)s"
+"Execution failed: %s (...)\n"
+"Reason: %s"
 msgstr ""
-#: ../lib/python/temporal/core.py:672
-#, python-format
+#: ../lib/vector/Vlib/read_pg.c:1561
+#, c-format
 msgid ""
-"Unsupported temporal database: version mismatch.\n"
-" %(backup)s Supported temporal API version is: %(api)i.\n"
-"Please update your GRASS GIS installation.\n"
+"Execution failed: %s\n"
+"Reason: %s"
 msgstr ""
-#: ../lib/python/temporal/core.py:680
-#, python-format
+#: ../lib/vector/Vlib/read_pg.c:1693
+#, c-format
 msgid ""
-" %(backup)sSupported temporal database version is: %(tdb)i\n"
+"Unable to read features. Reason:\n"
+"%s"
 msgstr ""
-#: ../lib/python/temporal/core.py:768
-#, python-format
-msgid "Creating temporal database: %s"
+#: ../lib/vector/Vlib/constraint.c:150
+msgid "Layer constraint ignored for non-native vector formats"
 msgstr ""
-#: ../lib/python/temporal/core.py:777
-#, python-format
-msgid ""
-"Unable to create SQLite temporal database\n"
-"Exception: %s\n"
-"Please use t.connect to set a read- and writable temporal database path"
-msgstr ""
+#: ../lib/vector/Vlib/net_analyze.c:201 ../lib/vector/Vlib/graph.c:226
+#, c-format
+msgid "dglShortestPath error: %s"
+msgstr "dglShortestPath kļūda: %s"
-#: ../lib/python/temporal/core.py:942
-msgid "Unable to mogrify sql statement. "
+#: ../lib/vector/Vlib/net_analyze.c:291 ../lib/vector/Vlib/net_analyze.c:332
+#, c-format
+msgid "Unable to find point with defined unique category for node <%d>."
 msgstr ""
-#: ../lib/python/temporal/core.py:964
-msgid "Unable to check table. "
-msgstr ""
-#: ../lib/python/temporal/core.py:980
-msgid "Unable to execute sql statement. "
-msgstr ""
-#: ../lib/python/temporal/core.py:990
-msgid "Unable to fetch one. "
-msgstr ""
-#: ../lib/python/temporal/core.py:1000
-msgid "Unable to fetch all. "
-msgstr ""
-#: ../lib/python/temporal/core.py:1017
-msgid "Unable to execute transaction. "
-msgstr ""
-#: ../lib/python/temporal/core.py:1120
-#, python-format
+#: ../lib/vector/Vlib/net_analyze.c:295 ../lib/vector/Vlib/net_analyze.c:336
+#, c-format
 msgid ""
-"Unable to connect to %(db)s database: %(string)s\n"
-"Exception: \"%(ex)s\"\n"
-"Please use t.connect to set a read- and writable temporal database backend"
+"There exists more than one point on node <%d> with unique category in field  "
+"<%d>.\n"
+"The unique category layer may not be valid."
 msgstr ""
-#: ../lib/python/temporal/core.py:1277
-#, python-format
-msgid ""
-"Unable to execute :\n"
-" %(sql)s"
+#: ../lib/vector/Vlib/net_analyze.c:452
+msgid "Wrong line direction in Vect_net_get_line_cost()"
 msgstr ""
+"Nebija iespējams izveidot jaunu novietojumu. Novietojums <%s> jau eksistē."
-#: ../lib/python/temporal/core.py:1321
-#, python-format
-msgid ""
-"Unable to execute transaction:\n"
-" %(sql)s"
+#: ../lib/vector/Vlib/write_pg.c:187 ../lib/vector/Vlib/write_pg.c:255
+#: ../lib/vector/Vlib/write_sfa.c:164 ../lib/vector/Vlib/write_ogr.c:96
+msgid "Unable to rewrite feature (incompatible feature types)"
 msgstr ""
-#: ../lib/python/temporal/temporal_vector_algebra.py:386
-#, python-format
-msgid "Error vector maps with basename %s exist. Use --o flag to overwrite existing file"
+#: ../lib/vector/Vlib/write_pg.c:285
+#, c-format
+msgid "Unable to rewrite feature %d"
 msgstr ""
-#: ../lib/python/temporal/temporal_vector_algebra.py:419
-#, python-format
-msgid ""
-"Error starting %s : \n"
-"%s"
+#: ../lib/vector/Vlib/write_pg.c:321 ../lib/vector/Vlib/write_pg.c:811
+#: ../lib/vector/Vlib/write_pg.c:1213 ../lib/vector/Vlib/write_pg.c:1371
+#: ../lib/vector/Vlib/simple_features.c:324
+msgid "No connection defined"
 msgstr ""
-#: ../lib/python/temporal/temporal_vector_algebra.py:492
-#, python-format
-msgid ""
-"Error vector map %s exist in temporal database. Use overwrite flag.  : \n"
-"%s"
+#: ../lib/vector/Vlib/write_pg.c:326 ../lib/vector/Vlib/write_ogr.c:134
+#, c-format
+msgid "Invalid offset (%ld)"
 msgstr ""
-#: ../lib/python/temporal/extract.py:60
-msgid "You need to specify the base name of new created maps"
+#: ../lib/vector/Vlib/write_pg.c:347 ../lib/vector/Vlib/write_ogr.c:140
+msgid "Unable to delete feature"
 msgstr ""
-#: ../lib/python/temporal/extract.py:131
-#: ../lib/python/temporal/open_stds.py:211
-#: ../lib/python/temporal/mapcalc.py:239
-#, python-format
-msgid "Map <%s> is already in temporal database, use overwrite flag to overwrite"
+#: ../lib/vector/Vlib/write_pg.c:452
+#, c-format
+msgid "Unable to delete feature (%s) %d"
 msgstr ""
-#: ../lib/python/temporal/extract.py:138
-#, python-format
-msgid "Applying r.mapcalc expression: \"%s\""
-msgstr ""
+#: ../lib/vector/Vlib/write_pg.c:554 ../lib/vector/Vlib/write_pg.c:1301
+#: ../lib/vector/Vlib/write_sfa.c:349
+msgid "Boundary is not closed. Skipping."
+msgstr "Robeža nav noslēgta. Izlaižam."
-#: ../lib/python/temporal/extract.py:143
-#, python-format
-msgid "Applying r3.mapcalc expression: \"%s\""
+#: ../lib/vector/Vlib/write_pg.c:612 ../lib/vector/Vlib/write_pg.c:880
+#: ../lib/vector/Vlib/build_pg.c:411 ../lib/vector/Vlib/open.c:1355
+msgid "Unable to open PG file"
 msgstr ""
-#: ../lib/python/temporal/extract.py:148
-#, python-format
-msgid "Applying v.extract where statement: \"%s\""
-msgstr ""
-#: ../lib/python/temporal/extract.py:176
-msgid "Error in computation process"
-msgstr ""
-#: ../lib/python/temporal/factory.py:51
-#, python-format
-msgid "Unknown dataset type: %s"
-msgstr ""
-#: ../lib/python/temporal/temporal_algebra.py:810
-msgid "Spatio-temporal topological operators are not supported in granularity algebra mode"
-msgstr ""
-#: ../lib/python/temporal/temporal_algebra.py:848
-msgid "All input space time datasets must have a valid temporal topology."
-msgstr ""
-#: ../lib/python/temporal/temporal_algebra.py:857
-msgid "All input space time datasets must have the same temporal type."
-msgstr ""
-#: ../lib/python/temporal/temporal_algebra.py:1105
-#, python-format
-msgid "Removing un-needed or empty %s maps"
-msgstr ""
-#: ../lib/python/temporal/temporal_algebra.py:1160
-#, python-format
-msgid "Space time %s dataset <%s> not found"
-msgstr ""
-#: ../lib/python/temporal/temporal_algebra.py:1188
-#: ../lib/python/temporal/temporal_algebra.py:1192
-#, python-format
-msgid "Wrong temporal type of space time dataset <%s>                                       <%s> time is required"
-msgstr ""
-#: ../lib/python/temporal/temporal_algebra.py:1212
-msgid "Wrong type of input "
-msgstr ""
-#: ../lib/python/temporal/temporal_algebra.py:2104
-#, python-format
-msgid "The resulting space time dataset type <%(a)s> is different from the requested type <%(b)s>"
-msgstr ""
-#: ../lib/python/temporal/temporal_algebra.py:2110
-msgid "Maps that should be registered in the resulting space time dataset have different types."
-msgstr ""
-#: ../lib/python/temporal/temporal_algebra.py:2313
-#: ../lib/python/temporal/temporal_raster_base_algebra.py:717
-#, python-format
-msgid "%s map <%s> not found in GRASS spatial database"
-msgstr ""
-#: ../lib/python/temporal/temporal_algebra.py:2319
-msgid "Wrong map type. TMAP only supports single maps that are registered in the temporal GRASS database"
-msgstr ""
-#: ../lib/python/temporal/temporal_algebra.py:2347
-msgid "Merging empty map lists"
-msgstr ""
-#: ../lib/python/temporal/temporal_algebra.py:2350
-msgid "First Map list is empty, can't merge it. Return only last map list"
-msgstr ""
-#: ../lib/python/temporal/temporal_algebra.py:2353
-msgid "Second Map list is empty, can't merge it. Return only first map list"
-msgstr ""
-#: ../lib/python/temporal/temporal_algebra.py:2361
-msgid "Space time datasets to merge must have the same temporal type"
-msgstr ""
-#: ../lib/python/temporal/abstract_dataset.py:386
-#, python-format
-msgid "Unable to insert dataset <%(ds)s> of type %(type)s in the temporal database. The mapset of the dataset does not match the current mapset"
-msgstr ""
-#: ../lib/python/temporal/abstract_dataset.py:426
-#: ../lib/python/temporal/abstract_dataset.py:469
-#: ../lib/python/temporal/abstract_space_time_dataset.py:2285
-#: ../lib/python/temporal/abstract_map_dataset.py:424
-#: ../lib/python/temporal/abstract_map_dataset.py:520
-#, python-format
-msgid "Unable to update dataset <%(ds)s> of type %(type)s in the temporal database. The mapset of the dataset does not match the current mapset"
-msgstr ""
-#: ../lib/python/temporal/stds_export.py:104
-#, python-format
-msgid "Unable to export raster map <%s>"
-msgstr ""
-#: ../lib/python/temporal/stds_export.py:115
-#, python-format
-msgid "Unable to export color rules for raster map <%s> r.out.gdal"
-msgstr ""
-#: ../lib/python/temporal/stds_export.py:139
-#, python-format
-msgid "Unable to export raster map <%s> with r.pack"
-msgstr ""
-#: ../lib/python/temporal/stds_export.py:167
-#, python-format
-msgid "Unable to export vector map <%s> as GML with v.out.ogr"
-msgstr ""
-#: ../lib/python/temporal/stds_export.py:200
-#, python-format
-msgid "Unable to export vector map <%s> with v.pack"
-msgstr ""
-#: ../lib/python/temporal/stds_export.py:226
-#, python-format
-msgid "Unable to export raster map <%s> with r3.pack"
-msgstr ""
-#: ../lib/python/temporal/base.py:380
-#, fuzzy
-msgid "Object not found in the temporal database"
-msgstr "neiespējami atvērt rastra karti [%s iekš %s]"
-#: ../lib/python/temporal/base.py:462 ../lib/python/temporal/base.py:513
-msgid "Missing identifier"
-msgstr ""
-#: ../lib/python/temporal/base.py:621
-msgid "Wrong identifier, the mapset is missing"
-msgstr ""
-#: ../lib/python/temporal/c_libraries_interface.py:596
-#: ../lib/python/temporal/c_libraries_interface.py:613
-msgid "Unable to read range file"
-msgstr ""
-#: ../lib/python/temporal/c_libraries_interface.py:676
-#: ../lib/gpde/n_arrays_io.c:281 ../lib/ogsf/gvl_file.c:436
+#: ../lib/vector/Vlib/write_pg.c:666 ../lib/vector/Vlib/ascii.c:428
+#: ../lib/db/dbmi_client/column.c:136 ../lib/python/script/db.py:45
 #, c-format, python-format
-msgid "Unable to open 3D raster map <%s>"
+msgid "Unable to describe table <%s>"
 msgstr ""
-#: ../lib/python/temporal/c_libraries_interface.py:691
-#, python-format
-msgid "Unable to load range of 3D raster map <%s>"
+#: ../lib/vector/Vlib/write_pg.c:773
+#, c-format
+msgid "Building spatial index on <%s>..."
 msgstr ""
-#: ../lib/python/temporal/c_libraries_interface.py:706
-#: ../lib/raster3d/close.c:120 ../lib/raster3d/close.c:130
-#: ../lib/raster3d/close.c:159 ../lib/ogsf/gvl_file.c:470
-#, c-format, python-format
-msgid "Unable to close 3D raster map <%s>"
+#: ../lib/vector/Vlib/write_pg.c:841
+#, c-format
+msgid "Schema <%s> doesn't exist, created"
 msgstr ""
-#: ../lib/python/temporal/c_libraries_interface.py:747
-#: ../lib/vector/Vlib/map.c:192 ../lib/vector/Vlib/map.c:202
-#: ../lib/vector/Vlib/map.c:274 ../lib/vector/Vlib/open.c:301
-#: ../lib/vector/Vlib/open.c:437 ../lib/ogsf/gp3.c:62 ../lib/ogsf/gp3.c:196
-#: ../lib/ogsf/gv3.c:66 ../lib/ogsf/gv3.c:338
-msgid "Unable to open vector map <%s>"
-msgstr "Nav iespējams atvērt vektoru karti <%s>"
-#: ../lib/python/temporal/abstract_space_time_dataset.py:167
-#: ../lib/python/temporal/abstract_space_time_dataset.py:301
-#, python-format
-msgid "Unknown temporal type \"%s\""
+#: ../lib/vector/Vlib/write_pg.c:920
+#, c-format
+msgid "Creating topology schema <%s>..."
 msgstr ""
-#: ../lib/python/temporal/abstract_space_time_dataset.py:294
-#: ../lib/python/temporal/abstract_space_time_dataset.py:1062
-#, python-format
-msgid "Wrong granularity: \"%s\""
+#: ../lib/vector/Vlib/write_pg.c:934
+#, c-format
+msgid "Adding new topology column <%s>..."
 msgstr ""
-#: ../lib/python/temporal/abstract_space_time_dataset.py:322
-#, python-format
-msgid "Unsupported temporal unit: %s"
+#: ../lib/vector/Vlib/write_pg.c:1072 ../lib/vector/Vlib/open_pg.c:85
+#: ../lib/vector/Vlib/open_pg.c:232
+msgid "Connection string not defined"
 msgstr ""
-#: ../lib/python/temporal/abstract_space_time_dataset.py:372
-#, python-format
-msgid "Created register table <%s> for space time %s  dataset <%s>"
+#: ../lib/vector/Vlib/write_pg.c:1077 ../lib/vector/Vlib/write_pg.c:1217
+#: ../lib/vector/Vlib/write_pg.c:1375 ../lib/vector/Vlib/open_pg.c:90
+#: ../lib/vector/Vlib/open_pg.c:237
+msgid "PostGIS feature table not defined"
 msgstr ""
-#: ../lib/python/temporal/abstract_space_time_dataset.py:690
-#: ../lib/python/temporal/abstract_space_time_dataset.py:932
-msgid "The space time datasets must be of the same temporal type"
-msgstr ""
+#: ../lib/vector/Vlib/write_pg.c:1105 ../lib/vector/Vlib/write_ogr.c:304
+#, c-format
+msgid "Unsupported geometry type (%d)"
+msgstr "Neatbalstīts ģeometrijas tips (%d)"
-#: ../lib/python/temporal/abstract_space_time_dataset.py:695
-#: ../lib/python/temporal/abstract_space_time_dataset.py:937
-msgid "The temporal map type of the sample dataset must be interval"
+#: ../lib/vector/Vlib/write_pg.c:1118 ../lib/vector/Vlib/write_ogr.c:338
+#, c-format
+msgid "More layers defined, using driver <%s> and database <%s>"
 msgstr ""
-#: ../lib/python/temporal/abstract_space_time_dataset.py:1499
-#, python-format
-msgid "Unable to get map ids from register table <%s>"
+#: ../lib/vector/Vlib/write_pg.c:1123 ../lib/vector/Vlib/write_ogr.c:344
+msgid "Database connection not defined. Unable to write attributes."
 msgstr ""
-#: ../lib/python/temporal/abstract_space_time_dataset.py:1609
-#, python-format
-msgid "Unable to shift dataset <%(ds)s> of type %(type)s in the temporal database. The mapset of the dataset does not match the current mapset"
+#: ../lib/vector/Vlib/write_pg.c:1130
+msgid "Unable to create new PostGIS feature table"
 msgstr ""
-#: ../lib/python/temporal/abstract_space_time_dataset.py:1778
-#, python-format
-msgid "Unable to snap dataset <%(ds)s> of type %(type)s in the temporal database. The mapset of the dataset does not match the current mapset"
+#: ../lib/vector/Vlib/write_pg.c:1144
+msgid "Unable to create new PostGIS topology schema"
 msgstr ""
-#: ../lib/python/temporal/abstract_space_time_dataset.py:1880
-#, python-format
-msgid "Unable to rename dataset <%(ds)s> of type %(type)s in the temporal database. The mapset of the dataset does not match the current mapset"
+#: ../lib/vector/Vlib/write_pg.c:1238 ../lib/vector/Vlib/write_pg.c:1403
+#: ../lib/vector/Vlib/write_ogr.c:408
+#, c-format
+msgid "No category defined for layer %d"
 msgstr ""
-#: ../lib/python/temporal/abstract_space_time_dataset.py:1889
-msgid "Renaming of space time datasets is not supported for PostgreSQL."
+#: ../lib/vector/Vlib/write_pg.c:1240 ../lib/vector/Vlib/write_pg.c:1405
+#: ../lib/vector/Vlib/write_ogr.c:410
+#, c-format
+msgid "Feature has more categories, using category %d (from layer %d)"
 msgstr ""
-#: ../lib/python/temporal/abstract_space_time_dataset.py:1954
-#, python-format
-msgid "Delete space time %s  dataset <%s> from temporal database"
+#: ../lib/vector/Vlib/write_pg.c:1251
+#, c-format
+msgid "Point skipped (output feature type: %s)"
 msgstr ""
-#: ../lib/python/temporal/abstract_space_time_dataset.py:1960
-#: ../lib/python/temporal/abstract_map_dataset.py:841
-#, python-format
-msgid "Unable to delete dataset <%(ds)s> of type %(type)s from the temporal database. The mapset of the dataset does not match the current mapset"
+#: ../lib/vector/Vlib/write_pg.c:1258
+#, c-format
+msgid "Line skipped (output feature type: %s)"
 msgstr ""
-#: ../lib/python/temporal/abstract_space_time_dataset.py:1973
-#, python-format
-msgid "Drop map register table: %s"
+#: ../lib/vector/Vlib/write_pg.c:1265
+#, c-format
+msgid "Centroid skipped (output feature type: %s)"
 msgstr ""
-#: ../lib/python/temporal/abstract_space_time_dataset.py:2028
-msgid "Error in register table request"
+#: ../lib/vector/Vlib/write_pg.c:1272
+#, c-format
+msgid "Boundary skipped (output feature type: %s)"
 msgstr ""
-#: ../lib/python/temporal/abstract_space_time_dataset.py:2057
-#, python-format
-msgid "Unable to register map in dataset <%(ds)s> of type %(type)s. The mapset of the dataset does not match the current mapset"
+#: ../lib/vector/Vlib/write_pg.c:1279
+#, c-format
+msgid "Face skipped (output feature type: %s)"
 msgstr ""
-#: ../lib/python/temporal/abstract_space_time_dataset.py:2066
-msgid "Only a map that was inserted in the temporal database can be registered in a space time dataset"
+#: ../lib/vector/Vlib/write_pg.c:1365
+#, c-format
+msgid "Invalid feature type (%d) for nodes"
 msgstr ""
-#: ../lib/python/temporal/abstract_space_time_dataset.py:2089
-#, python-format
-msgid "Map <%(id)s> with layer %(l)s has invalid time"
+#: ../lib/vector/Vlib/write_pg.c:1379
+msgid "PostGIS topology schema not defined"
 msgstr ""
-#: ../lib/python/temporal/abstract_space_time_dataset.py:2093
-#, python-format
-msgid "Map <%s> has invalid time"
+#: ../lib/vector/Vlib/write_pg.c:1880
+msgid "Trying to insert 3D data into feature table which store 2D data only"
 msgstr ""
-#: ../lib/python/temporal/abstract_space_time_dataset.py:2111
-#, python-format
-msgid "Temporal type of space time dataset <%(id)s> and map <%(map)s> with layer %(l)s are different"
+#: ../lib/vector/Vlib/write_pg.c:1885
+msgid "Trying to insert 2D data into feature table which store 3D data only"
 msgstr ""
-#: ../lib/python/temporal/abstract_space_time_dataset.py:2117
-#, python-format
-msgid "Temporal type of space time dataset <%(id)s> and map <%(map)s> are different"
+#: ../lib/vector/Vlib/write_pg.c:1910
+msgid "Unable to insert topological element into PostGIS Topology schema"
 msgstr ""
-#: ../lib/python/temporal/abstract_space_time_dataset.py:2132
-#, python-format
-msgid "Set temporal unit for space time %s dataset <%s> to %s"
+#: ../lib/vector/Vlib/write_pg.c:2013 ../lib/vector/Vlib/write_ogr.c:579
+#, c-format
+msgid "Unable to select attributes for category %d"
 msgstr ""
-#: ../lib/python/temporal/abstract_space_time_dataset.py:2142
-#, python-format
-msgid "Relative time units of space time dataset <%(id)s> and map <%(map)s> with layer %(l)s are different"
+#: ../lib/vector/Vlib/write_pg.c:2017 ../lib/vector/Vlib/write_ogr.c:585
+#: ../lib/db/dbmi_client/copy_tab.c:338
+#, c-format
+msgid "Unable to fetch data from table <%s>"
 msgstr ""
-#: ../lib/python/temporal/abstract_space_time_dataset.py:2148
-#, python-format
-msgid "Relative time units of space time dataset <%(id)s> and map <%(map)s> are different"
+#: ../lib/vector/Vlib/write_pg.c:2022 ../lib/vector/Vlib/write_ogr.c:591
+#, c-format
+msgid "No database record for category %d, no attributes will be written"
 msgstr ""
-#: ../lib/python/temporal/abstract_space_time_dataset.py:2154
-msgid "Only maps from the same mapset can be registered"
+#: ../lib/vector/Vlib/write_pg.c:2048
+#, c-format
+msgid "FID column must be integer, column <%s> ignored!"
 msgstr ""
-#: ../lib/python/temporal/abstract_space_time_dataset.py:2159
-#, python-format
-msgid "Map <%(map)s> with layer %(l)s is already registered."
-msgstr ""
+#: ../lib/vector/Vlib/write_pg.c:2082 ../lib/vector/Vlib/write_ogr.c:653
+#, c-format
+msgid "Unsupported column type %d"
+msgstr "Neatbalstīts kolonas tips %d"
-#: ../lib/python/temporal/abstract_space_time_dataset.py:2163
-#, python-format
-msgid "Map <%s> is already registered."
+#: ../lib/vector/Vlib/write_pg.c:2089
+msgid "Invalid value for FID column: NULL"
 msgstr ""
-#: ../lib/python/temporal/abstract_space_time_dataset.py:2211
-#, python-format
-msgid "Unable to unregister map from dataset <%(ds)s> of type %(type)s in the temporal database. The mapset of the dataset does not match the current mapset"
+#: ../lib/vector/Vlib/write_pg.c:2181
+#, c-format
+msgid "Invalid feature %d (max: %d)"
 msgstr ""
-#: ../lib/python/temporal/abstract_space_time_dataset.py:2224
-#, python-format
-msgid "Map <%(map)s> with layer %(l)s is not registered in space time dataset <%(base)s>"
+#: ../lib/vector/Vlib/write_pg.c:2195
+#, c-format
+msgid "Invalid feature type (%d) for node"
 msgstr ""
-#: ../lib/python/temporal/abstract_space_time_dataset.py:2230
-#, python-format
-msgid "Map <%(map)s> is not registered in space time dataset <%(base)s>"
+#: ../lib/vector/Vlib/write_pg.c:2199
+#, c-format
+msgid "Invalid node %d (%d)"
 msgstr ""
-#: ../lib/python/temporal/abstract_space_time_dataset.py:2291
-#, python-format
-msgid "Update metadata, spatial and temporal extent from all registered maps of <%s>"
+#: ../lib/vector/Vlib/write_pg.c:2277
+#, c-format
+msgid "Unable to determine next left/right edge for edge %d"
 msgstr ""
-#: ../lib/python/temporal/univar_statistics.py:62
-#: ../lib/python/temporal/univar_statistics.py:178
-#, python-format
-msgid "Space time %(sp)s dataset <%(i)s> is empty"
+#: ../lib/vector/Vlib/write_pg.c:2282
+msgid "Unable to insert new edge. Topology not available."
 msgstr ""
-#: ../lib/python/temporal/univar_statistics.py:101
-#, python-format
-msgid "Unable to get statistics for raster map <%s>"
-msgstr ""
+#: ../lib/vector/Vlib/write_pg.c:2381 ../lib/vector/Vlib/write_pg.c:2388
+msgid "Invalid topology"
+msgstr "Nederīga topoloģija"
-#: ../lib/python/temporal/univar_statistics.py:104
-#, python-format
-msgid "Unable to get statistics for 3d raster map <%s>"
+#: ../lib/vector/Vlib/write_pg.c:2587 ../lib/vector/Vlib/write_pg.c:2684
+#, c-format
+msgid "Attempt to access non-existing feature %d"
 msgstr ""
-#: ../lib/python/temporal/univar_statistics.py:168
-#, python-format
-msgid "Space time %(sp)s dataset <%(i)s> not found"
+#: ../lib/vector/Vlib/write_pg.c:2618
+msgid "Unable to determine next left/right edge"
 msgstr ""
-#: ../lib/python/temporal/univar_statistics.py:222
-#, python-format
-msgid "Unable to get statistics for vector map <%s>"
+#: ../lib/vector/Vlib/write_pg.c:2704
+msgid "Unable to create new face"
 msgstr ""
-#: ../lib/python/temporal/spatial_extent.py:123
-msgid "Projections are different. Unable to compute overlapping_2d for spatial extents"
+#: ../lib/vector/Vlib/write_pg.c:2842 ../lib/vector/Vlib/write_pg.c:2854
+#, c-format
+msgid "Unable to delete node %d"
 msgstr ""
-#: ../lib/python/temporal/spatial_extent.py:529
-msgid "Projections are different. Unable to compute is_in_2d for spatial extents"
+#: ../lib/vector/Vlib/write_pg.c:2910 ../lib/vector/Vlib/ascii.c:404
+#: ../lib/vector/Vlib/write_ogr.c:192 ../lib/db/dbmi_client/db.c:41
+#: ../lib/db/dbmi_client/copy_tab.c:107 ../lib/db/dbmi_client/copy_tab.c:127
+#, c-format
+msgid "Unable to start driver <%s>"
 msgstr ""
-#: ../lib/python/temporal/spatial_extent.py:661
-msgid "Projections are different. Unable to compute equivalent_2d for spatial extents"
-msgstr ""
-#: ../lib/python/temporal/spatial_extent.py:766
-msgid "Projections are different. Unable to compute cover_2d for spatial extents"
-msgstr ""
-#: ../lib/python/temporal/spatial_extent.py:838
-msgid "Projections are different. Unable to compute cover for spatial extents"
-msgstr ""
-#: ../lib/python/temporal/spatial_extent.py:1690
-msgid "Volume computation is not supported for LL projections"
-msgstr ""
-#: ../lib/python/temporal/spatial_extent.py:1708
-msgid "Area computation is not supported for LL projections"
-msgstr "Objekta id"
-#: ../lib/python/temporal/stds_import.py:85
-#, python-format
-msgid "Unable to import/link raster map <%s> from file %s."
-msgstr ""
-#: ../lib/python/temporal/stds_import.py:96
-#, python-format
-msgid "Unable to set the color rules for raster map <%s>."
-msgstr ""
-#: ../lib/python/temporal/stds_import.py:120
-#, python-format
-msgid "Unable to unpack raster map <%s> from file %s."
-msgstr ""
-#: ../lib/python/temporal/stds_import.py:144
-#, python-format
-msgid "Unable to import vector map <%s> from file %s."
-msgstr ""
-#: ../lib/python/temporal/stds_import.py:168
-#, python-format
-msgid "Unable to unpack vector map <%s> from file %s."
-msgstr ""
-#: ../lib/python/temporal/stds_import.py:207
-#, python-format
-msgid "Space time raster dataset archive <%s> not found"
-msgstr ""
-#: ../lib/python/temporal/stds_import.py:210
-#, python-format
-msgid "Extraction directory <%s> not found"
-msgstr ""
-#: ../lib/python/temporal/stds_import.py:216
-#, python-format
-msgid "Checking validity of input file (size: %0.1f MB). Make take a while..."
-msgstr ""
-#: ../lib/python/temporal/stds_import.py:223
-#, python-format
-msgid "Unable to find init file <%s>"
-msgstr ""
-#: ../lib/python/temporal/stds_import.py:225
-#, python-format
-msgid "Unable to find list file <%s>"
-msgstr ""
-#: ../lib/python/temporal/stds_import.py:227
-#, python-format
-msgid "Unable to find projection file <%s>"
-msgstr ""
-#: ../lib/python/temporal/stds_import.py:229
-msgid "Extracting data..."
-msgstr ""
-#: ../lib/python/temporal/stds_import.py:269
-msgid "Projection information does not match. Proceeding..."
-msgstr ""
-#: ../lib/python/temporal/stds_import.py:273
+#: ../lib/vector/Vlib/dgraph.c:432
 msgid ""
-"Difference between PROJ_INFO file of imported map and of current location:\n"
-"{diff}"
+"Trying to add more edges to the planar_graph than the initial allocation "
+"size allows"
 msgstr ""
-#: ../lib/python/temporal/stds_import.py:276
-msgid "Projection information does not match. Aborting."
+#: ../lib/vector/Vlib/bridges.c:213
+#, c-format
+msgid "Removed lines: %d"
 msgstr ""
-#: ../lib/python/temporal/stds_import.py:293
-#, python-format
-msgid "Unable to create location %(l)s. Reason: %(e)s"
+#: ../lib/vector/Vlib/bridges.c:214
+#, c-format
+msgid "Removed bridges: %d"
 msgstr ""
-#: ../lib/python/temporal/stds_import.py:301
-#, python-format
-msgid "Unable to switch to location %s"
+#: ../lib/vector/Vlib/intersect.c:127
+msgid "3D not supported by Vect_segment_intersection()"
 msgstr ""
-#: ../lib/python/temporal/stds_import.py:306
-#, python-format
-msgid "Unable to create default temporal database in new location %s"
+#: ../lib/vector/Vlib/intersect.c:353
+msgid "Vect_segment_intersection() ERROR (collinear vertical segments)"
 msgstr ""
-#: ../lib/python/temporal/stds_import.py:380
-#, python-format
-msgid "Key words %(t)s, %(s)s or %(n)s not found in init file."
+#: ../lib/vector/Vlib/intersect.c:447
+msgid "Vect_segment_intersection() ERROR (collinear non vertical segments)"
 msgstr ""
-#: ../lib/python/temporal/stds_import.py:386
-msgid "Number of maps mismatch in init and list file."
+#: ../lib/vector/Vlib/intersect.c:1194 ../lib/vector/Vlib/intersect.c:1200
+#: ../lib/vector/Vlib/intersect.c:1202 ../lib/vector/Vlib/intersect.c:1257
+#: ../lib/vector/Vlib/intersect.c:1266 ../lib/vector/Vlib/intersect.c:1287
+#: ../lib/vector/Vlib/intersect.c:1304 ../lib/vector/Vlib/intersect2.c:1202
+#: ../lib/vector/Vlib/intersect2.c:1208 ../lib/vector/Vlib/intersect2.c:1210
+#: ../lib/vector/Vlib/intersect2.c:1262 ../lib/vector/Vlib/intersect2.c:1271
+#: ../lib/vector/Vlib/intersect2.c:1292 ../lib/vector/Vlib/intersect2.c:1309
+msgid "Error while adding point to array. Out of memory"
 msgstr ""
-#: ../lib/python/temporal/stds_import.py:397
-msgid "The archive file is of wrong space time dataset type"
+#: ../lib/vector/Vlib/clean_nodes.c:248
+#, c-format
+msgid "Modifications: %d"
 msgstr ""
-#: ../lib/python/temporal/stds_import.py:405
-#, python-format
-msgid "Unable to find GeoTIFF raster file <%s> in archive."
+#: ../lib/vector/Vlib/legal_vname.c:43
+#, c-format
+msgid "Illegal vector map name <%s>. May not contain '.' or 'NULL'."
 msgstr ""
-#: ../lib/python/temporal/stds_import.py:411
-#, python-format
-msgid "Unable to find AAIGrid raster file <%s> in archive."
+#: ../lib/vector/Vlib/legal_vname.c:50
+#, c-format
+msgid "Illegal vector map name <%s>. Must start with a letter."
 msgstr ""
-#: ../lib/python/temporal/stds_import.py:417
-#, python-format
-msgid "Unable to find GML vector file <%s> in archive."
+#: ../lib/vector/Vlib/legal_vname.c:58
+#, c-format
+msgid "Illegal vector map name <%s>. Character '%c' not allowed."
 msgstr ""
-#: ../lib/python/temporal/stds_import.py:426
-#, python-format
-msgid "Unable to find GRASS package file <%s> in archive."
-msgstr ""
-#: ../lib/python/temporal/stds_import.py:429
-msgid "Unsupported input format"
-msgstr "Ievades objektu tips"
-#: ../lib/python/temporal/stds_import.py:435
-#, python-format
-msgid "Space time %(t)s dataset <%(sp)s> is already in the database. Use the overwrite flag."
-msgstr ""
-#: ../lib/python/temporal/stds_import.py:456
-#, python-format
-msgid "Overwrite space time %(sp)s dataset <%(id)s> and unregister all maps."
-msgstr ""
-#: ../lib/python/temporal/stds_import.py:468
-#, python-format
-msgid "Key word %s not found in init file."
-msgstr ""
-#: ../lib/python/temporal/stds_import.py:473
-#, python-format
-msgid "Create space time %s dataset."
-msgstr ""
-#: ../lib/python/temporal/stds_import.py:502
-msgid "Switching to original location failed"
-msgstr ""
-#: ../lib/python/temporal/aggregation.py:127
-#, python-format
-msgid "Aggregating %s raster maps"
-msgstr ""
-#: ../lib/python/temporal/aggregation.py:141
-#, python-format
-msgid "Raster map <%(name)s> is already in temporal database, use overwrite flag to overwrite"
-msgstr ""
-#: ../lib/python/temporal/aggregation.py:146
-#, python-format
-msgid "Computing aggregation of maps between %(st)s - %(end)s"
-msgstr ""
-#: ../lib/python/temporal/aggregation.py:171
-msgid "Error occurred in r.series computation"
-msgstr ""
-#: ../lib/python/temporal/aggregation.py:280
-#, python-format
-msgid "Aggregating %(len)i raster maps from %(start)s to %(end)s"
-msgstr ""
-#: ../lib/python/temporal/aggregation.py:301
-#, python-format
-msgid "Unable to perform aggregation. Output raster map <%(name)s> exists and overwrite flag was not set"
-msgstr ""
-#: ../lib/python/temporal/aggregation.py:319
-#, python-format
-msgid "The limit of open files (%i) was reached (%i). The module r.series will be run with flag z, to avoid open files limit exceeding."
-msgstr ""
-#: ../lib/python/temporal/open_stds.py:63
-#: ../lib/python/temporal/open_stds.py:119
-#, python-format
-msgid "Unknown type: %s"
-msgstr ""
-#: ../lib/python/temporal/open_stds.py:69
-#, python-format
-msgid "Space time %(sp)s dataset <%(name)s> not found"
-msgstr ""
-#: ../lib/python/temporal/open_stds.py:108
-msgid "Space time datasets can only be created in the current mapset"
-msgstr ""
-#: ../lib/python/temporal/open_stds.py:125
-#, python-format
-msgid "Space time %(sp)s dataset <%(name)s> is already in the database. Use the overwrite flag."
-msgstr ""
-#: ../lib/python/temporal/open_stds.py:160
-#, python-format
-msgid "Overwriting space time %(sp)s dataset <%(name)s> and unregistering all maps"
-msgstr ""
-#: ../lib/python/temporal/open_stds.py:168
-#, python-format
-msgid "Creating a new space time %s dataset"
-msgstr ""
-#: ../lib/python/temporal/gui_support.py:58 ../lib/python/script/core.py:1290
-#, python-format
-msgid "Invalid element '%s'"
-msgstr ""
-#: ../lib/python/temporal/abstract_map_dataset.py:350
-#, python-format
-msgid "Start time must be of type datetime for %(type)s map <%(id)s> with layer: %(l)s"
-msgstr ""
-#: ../lib/python/temporal/abstract_map_dataset.py:357
-#, python-format
-msgid "Start time must be of type datetime for %(type)s map <%(id)s>"
-msgstr ""
-#: ../lib/python/temporal/abstract_map_dataset.py:365
-#, python-format
-msgid "End time must be of type datetime for %(type)s map <%(id)s> with layer: %(l)s"
-msgstr ""
-#: ../lib/python/temporal/abstract_map_dataset.py:372
-#, python-format
-msgid "End time must be of type datetime for %(type)s map <%(id)s>"
-msgstr ""
-#: ../lib/python/temporal/abstract_map_dataset.py:381
-#, python-format
-msgid "End time must be greater than start time for %(type)s map <%(id)s> with layer: %(l)s"
-msgstr ""
-#: ../lib/python/temporal/abstract_map_dataset.py:389
-#: ../lib/python/temporal/abstract_map_dataset.py:482
-#, python-format
-msgid "End time must be greater than start time for %(type)s map <%(id)s>"
-msgstr ""
-#: ../lib/python/temporal/abstract_map_dataset.py:460
-#, python-format
-msgid "Unsupported relative time unit type for %(type)s map <%(id)s> with layer %(l)s: %(u)s"
-msgstr ""
-#: ../lib/python/temporal/abstract_map_dataset.py:467
-#, python-format
-msgid "Unsupported relative time unit type for %(type)s map <%(id)s>: %(u)s"
-msgstr ""
-#: ../lib/python/temporal/abstract_map_dataset.py:476
-#, python-format
-msgid "End time must be greater than start time for %(typ)s map <%(id)s> with layer %(l)s"
-msgstr ""
-#: ../lib/python/temporal/abstract_map_dataset.py:800
-#, python-format
-msgid "Map <%(id)s> with layer %(layer)s has incorrect time interval, start time is greater than end time"
-msgstr ""
-#: ../lib/python/temporal/abstract_map_dataset.py:806
-#, python-format
-msgid "Map <%s> has incorrect time interval, start time is greater than end time"
-msgstr ""
-#: ../lib/python/temporal/abstract_map_dataset.py:812
-#, python-format
-msgid "Map <%s> has incorrect start time"
-msgstr ""
-#: ../lib/python/temporal/abstract_map_dataset.py:859
-#, python-format
-msgid "Delete %s dataset <%s> from temporal database"
-msgstr ""
-#: ../lib/python/temporal/abstract_map_dataset.py:909
-#, python-format
-msgid "Unable to unregister dataset <%(ds)s> of type %(type)s from the temporal database. The mapset of the dataset does not match the current mapset"
-msgstr ""
-#: ../lib/python/temporal/sampling.py:95 ../lib/python/temporal/sampling.py:100
-#, python-format
-msgid "Dataset <%s> not found in temporal database"
-msgstr ""
-#: ../lib/python/temporal/temporal_raster_base_algebra.py:630
-#, python-format
-msgid "Error computing map <%s>"
-msgstr ""
-#: ../lib/python/temporal/register.py:82 ../lib/python/temporal/register.py:85
-#, python-format
-msgid "%s= and %s= are mutually exclusive"
-msgstr ""
-#: ../lib/python/temporal/register.py:89
-#, python-format
-msgid "%s= and the %s flag are mutually exclusive"
-msgstr ""
-#: ../lib/python/temporal/register.py:93
-msgid "The increment option requires the start option"
-msgstr ""
-#: ../lib/python/temporal/register.py:96
-msgid "The interval flag requires the start option"
-msgstr ""
-#: ../lib/python/temporal/register.py:99
-#, python-format
-msgid "Please specify %s= and %s="
-msgstr ""
-#: ../lib/python/temporal/register.py:103
-#, python-format
-msgid "Please specify %s= or %s="
-msgstr ""
-#: ../lib/python/temporal/register.py:114
-#, python-format
-msgid "Space time %(sp)s dataset <%(name)s> with relative time found, but no relative unit set for %(sp)s maps"
-msgstr ""
-#: ../lib/python/temporal/register.py:175
-msgid "The increment option will be ignored because of time stamps in input file"
-msgstr ""
-#: ../lib/python/temporal/register.py:179
-msgid "The interval flag will be ignored because of time stamps in input file"
-msgstr ""
-#: ../lib/python/temporal/register.py:187
-msgid "Gathering map information..."
-msgstr ""
-#: ../lib/python/temporal/register.py:197
-#, python-format
-msgid "Unable to update %(t)s map <%(id)s>. The map does not exist."
-msgstr ""
-#: ../lib/python/temporal/register.py:215
-#, python-format
-msgid "Unable to register %(t)s map <%(id)s> with layer %(l)s. The map has timestamp and the start time is not set."
-msgstr ""
-#: ../lib/python/temporal/register.py:221
-#, python-format
-msgid "Unable to register %(t)s map <%(id)s>. The map has no timestamp and the start time is not set."
-msgstr ""
-#: ../lib/python/temporal/register.py:229
-#, python-format
-msgid "%(u)s= can only be set for relative time"
-msgstr ""
-#: ../lib/python/temporal/register.py:232
-#, python-format
-msgid "%(u)s= must be set in case of relative time stamps"
-msgstr ""
-#: ../lib/python/temporal/register.py:245
-#, python-format
-msgid "Map is already registered in temporal database. Unable to update %(t)s map <%(id)s> with layer %(l)s. Overwrite flag is not set."
-msgstr ""
-#: ../lib/python/temporal/register.py:252
-#, python-format
-msgid "Map is already registered in temporal database. Unable to update %(t)s map <%(id)s>. Overwrite flag is not set."
-msgstr ""
-#: ../lib/python/temporal/register.py:276
-#, python-format
-msgid "Unable to update %(t)s map <%(id)s> with layer %(l)s. The temporal types are different."
-msgstr ""
-#: ../lib/python/temporal/register.py:282
-#, python-format
-msgid "Unable to update %(t)s map <%(id)s>. The temporal types are different."
-msgstr ""
-#: ../lib/python/temporal/register.py:330
-msgid "Registering maps in the temporal database..."
-msgstr ""
-#: ../lib/python/temporal/register.py:337
-msgid "Registering maps in the space time dataset..."
-msgstr ""
-#: ../lib/python/temporal/register.py:346
-msgid "Updating space time dataset..."
-msgstr ""
-#: ../lib/python/temporal/register.py:399
-#: ../lib/python/temporal/register.py:406
-#, python-format
-msgid "Unable to convert string \"%s\"into a datetime object"
-msgstr ""
-#: ../lib/python/temporal/register.py:414
-#: ../lib/python/temporal/register.py:419
-msgid "Error occurred in increment computation"
-msgstr ""
-#: ../lib/python/temporal/register.py:422
-#, python-format
-msgid "Set absolute valid time for map <%(id)s> with layer %(layer)s to %(start)s - %(end)s"
-msgstr ""
-#: ../lib/python/temporal/register.py:427
-#, python-format
-msgid "Set absolute valid time for map <%s> to %s - %s"
-msgstr ""
-#: ../lib/python/temporal/register.py:444
-#, python-format
-msgid "Set relative valid time for map <%s> with layer %s to %i - %s with unit %s"
-msgstr ""
-#: ../lib/python/temporal/register.py:449
-#, python-format
-msgid "Set relative valid time for map <%s> to %i - %s with unit %s"
-msgstr ""
-#: ../lib/python/temporal/list_stds.py:208
-msgid "Empty map list"
-msgstr "Lauku atdalītājs"
-#: ../lib/python/temporal/list_stds.py:219
-msgid "Empty entry in map list, this should not happen"
-msgstr ""
-#: ../lib/python/temporal/space_time_datasets.py:250
-#, python-format
-msgid "Unable to read timestamp file for raster map <%s>"
-msgstr ""
-#: ../lib/python/temporal/space_time_datasets.py:274
-#, python-format
-msgid "Unable to create timestamp file for raster map <%s>"
-msgstr ""
-#: ../lib/python/temporal/space_time_datasets.py:279
-#, python-format
-msgid "Invalid datetime in timestamp for raster map <%s>"
-msgstr ""
-#: ../lib/python/temporal/space_time_datasets.py:284
-#: ../lib/python/temporal/space_time_datasets.py:632
-msgid "Internal error"
-msgstr "Iekšēja kļūda"
-#: ../lib/python/temporal/space_time_datasets.py:301
-#: ../lib/python/temporal/space_time_datasets.py:646
-#, python-format
-msgid "Unable to remove timestamp for raster map <%s>"
-msgstr ""
-#: ../lib/python/temporal/space_time_datasets.py:598
-#, python-format
-msgid "Unable to read timestamp file for 3D raster map <%s>"
-msgstr ""
-#: ../lib/python/temporal/space_time_datasets.py:622
-#, python-format
-msgid "Unable to create timestamp file for 3D raster map <%s>"
-msgstr ""
-#: ../lib/python/temporal/space_time_datasets.py:627
-#, python-format
-msgid "Invalid datetime in timestamp for 3D raster map <%s>"
-msgstr ""
-#: ../lib/python/temporal/space_time_datasets.py:906
-#, python-format
-msgid "Unable to read timestamp file for vector map <%s>"
-msgstr ""
-#: ../lib/python/temporal/space_time_datasets.py:929
-#, python-format
-msgid "Unable to create timestamp file for vector map <%s>"
-msgstr ""
-#: ../lib/python/temporal/space_time_datasets.py:934
-#, python-format
-msgid "Invalid datetime in timestamp for vector map <%s>"
-msgstr ""
-#: ../lib/python/temporal/space_time_datasets.py:950
-#, python-format
-msgid "Unable to remove timestamp for vector map <%s>"
-msgstr ""
-#: ../lib/python/temporal/mapcalc.py:109
-msgid "Starting spatio-temporal sampling..."
-msgstr ""
-#: ../lib/python/temporal/mapcalc.py:111
-msgid "Starting temporal sampling..."
-msgstr ""
-#: ../lib/python/temporal/mapcalc.py:128
-msgid "No samples found for map calculation"
-msgstr ""
-#: ../lib/python/temporal/mapcalc.py:155
-msgid "Found more than a single map in a sample granule. Only the first map is used for computation. Use t.rast.aggregate.ds to create synchronous raster datasets."
-msgstr ""
-#: ../lib/python/temporal/mapcalc.py:173
-msgid "No maps registered in input dataset"
-msgstr ""
-#: ../lib/python/temporal/mapcalc.py:189
-msgid "Starting mapcalc computation..."
-msgstr ""
-#: ../lib/python/temporal/mapcalc.py:259
-#, python-format
-msgid "Apply mapcalc expression: \"%s\""
-msgstr ""
-#: ../lib/python/temporal/mapcalc.py:278
-msgid "Error while mapcalc computation"
-msgstr ""
-#: ../lib/python/temporal/mapcalc.py:284
-msgid "Starting map registration in temporal database..."
-msgstr ""
-#: ../lib/python/temporal/mapcalc.py:438 ../lib/python/temporal/mapcalc.py:444
-#: ../lib/python/temporal/mapcalc.py:450 ../lib/python/temporal/mapcalc.py:456
-#: ../lib/python/temporal/mapcalc.py:462 ../lib/python/temporal/mapcalc.py:468
-#: ../lib/python/temporal/mapcalc.py:474 ../lib/python/temporal/mapcalc.py:480
-#: ../lib/python/temporal/mapcalc.py:486 ../lib/python/temporal/mapcalc.py:521
-#: ../lib/python/temporal/mapcalc.py:530 ../lib/python/temporal/mapcalc.py:539
-#: ../lib/python/temporal/mapcalc.py:548 ../lib/python/temporal/mapcalc.py:557
-#: ../lib/python/temporal/mapcalc.py:566 ../lib/python/temporal/mapcalc.py:575
-#: ../lib/python/temporal/mapcalc.py:584 ../lib/python/temporal/mapcalc.py:593
-#, python-format
-msgid "The temporal operators <%s> support only absolute time."
-msgstr ""
-#: ../lib/python/script/raster.py:54
-#, python-format
-msgid "Unable to write history for <%(map)s>. Raster map <%(map)s> not found in current mapset."
-msgstr ""
-#: ../lib/python/script/raster.py:113
-#, python-format
-msgid "An error occurred while running r.mapcalc with expression: %s"
-msgstr ""
-#: ../lib/python/script/raster.py:192
-msgid "No data"
-msgstr ""
-#: ../lib/python/script/raster.py:200
-msgid "value"
-msgstr "vērtība"
-msgid "label"
-msgstr "nosaukums"
-msgid "color"
-msgstr "krāsa"
-#: ../lib/python/script/vector.py:88
-#, python-format
-msgid "Database connection not defined for layer %s"
-msgstr ""
-#: ../lib/python/script/vector.py:228
-#, python-format
-msgid "Missing layer %(layer)d in vector map <%(map)s>"
-msgstr ""
-#: ../lib/python/script/vector.py:243
-msgid "vector_db_select() failed"
-msgstr ""
-#: ../lib/python/script/vector.py:351
-msgid "Number of given vector maps ({m}) differs from number of layers ({l})"
-msgstr ""
-#: ../lib/python/script/vector.py:413
+#: ../lib/vector/Vlib/legal_vname.c:65
+#, c-format
 msgid ""
-"v.what output is not valid JSON format:\n"
-" {ret}"
+"Illegal vector map name <%s>. SQL keyword cannot be used as vector map name."
 msgstr ""
-#: ../lib/python/script/core.py:67
-msgid "Cannot find the executable {0}"
+#: ../lib/vector/Vlib/legal_vname.c:100 ../lib/vector/Vlib/legal_vname.c:104
+#, c-format
+msgid "Output vector map name <%s> is not in the current mapset (%s)"
 msgstr ""
-#: ../lib/python/script/core.py:305
-#, python-format
-msgid "To run the module <%s> add underscore at the end of the option <%s> to avoid conflict with Python keywords. Underscore at the beginning is depreciated in GRASS GIS 7.0 and will be removed in version 7.1."
+#: ../lib/vector/Vlib/legal_vname.c:117 ../lib/vector/Vlib/legal_vname.c:121
+#, c-format
+msgid "Output vector map name <%s> is not SQL compliant"
 msgstr ""
-#: ../lib/python/script/core.py:985
-msgid "Mixing value types. Will try to compare after integer conversion"
-msgstr ""
+#: ../lib/vector/Vlib/legal_vname.c:141 ../lib/vector/Vlib/legal_vname.c:144
+#: ../lib/vector/Vlib/open.c:235 ../lib/vector/Vlib/map.c:263
+#: ../lib/ogsf/gv3.c:60 ../lib/ogsf/gv3.c:333 ../lib/ogsf/gp3.c:56
+#: ../lib/ogsf/gp3.c:191 ../lib/manage/do_rename.c:54
+#: ../lib/manage/do_remove.c:57
+#, c-format
+msgid "Vector map <%s> not found"
+msgstr "Vektorkarte <%s> nav atrasta"
-#: ../lib/python/script/core.py:1180
-#, python-format
-msgid "Element type should be \"cell\" and not \"%s\""
+#: ../lib/vector/Vlib/legal_vname.c:159 ../lib/vector/Vlib/legal_vname.c:163
+#, c-format
+msgid "Output vector map <%s> is used as input"
 msgstr ""
-#: ../lib/python/script/core.py:1209 ../lib/python/script/core.py:1274
-#, python-format
-msgid "Element type should be \"raster\" and not \"%s\""
+#: ../lib/vector/Vlib/build_sfa.c:279 ../lib/vector/Vlib/build_sfa.c:546
+#, c-format
+msgid "Unable to calculate centroid for area %d"
 msgstr ""
-#: ../lib/python/script/core.py:1429
-msgid "Unable to list mapsets"
-msgstr ""
+#: ../lib/vector/Vlib/build_sfa.c:305
+#, c-format
+msgid "Feature type %d not supported"
+msgstr "Objekta tips %d nav atbalstīts"
-#: ../lib/python/script/core.py:1468
-#, python-format
-msgid "Location <%s> already exists. Operation canceled."
-msgstr ""
+#: ../lib/vector/Vlib/build_sfa.c:339 ../lib/vector/Vlib/build_sfa.c:632
+#: ../lib/vector/Vlib/build_nat.c:74
+msgid "Registering primitives..."
+msgstr "Reģistrē primitīvus..."
-#: ../lib/python/script/core.py:1471
-#, python-format
-msgid "Location <%s> already exists and will be overwritten"
-msgstr ""
-#: ../lib/python/script/core.py:1595
-msgid "Debug level {0}"
-msgstr ""
-#: ../lib/python/script/core.py:1598
-msgid "WARNING: Ignoring unsupported debug level (must be >=0 and <=5). {0}\n"
-msgstr ""
-#: ../lib/python/script/core.py:1614
-#, python-format
-msgid "Illegal filename <%s>. Cannot be 'NULL' or start with '.'."
-msgstr ""
-#: ../lib/python/script/core.py:1623
-#, python-format
-msgid "Illegal filename <%(s)s>. <%(il)s> not allowed.\n"
-msgstr ""
-#: ../lib/python/script/raster3d.py:92
-#, python-format
-msgid "An error occurred while running r3.mapcalc with expression: %s"
-msgstr ""
-#: ../lib/python/script/task.py:62
-msgid "unknown"
-msgstr ""
-#: ../lib/python/script/task.py:173
-#, python-format
-msgid "Parameter element '%(element)s' not found: '%(value)s'"
-msgstr ""
-#: ../lib/python/script/task.py:188
-#, python-format
-msgid "Flag not found: %s"
-msgstr ""
-#: ../lib/python/script/task.py:207
-#, python-format
-msgid "Parameter '%(name)s' (%(desc)s) is missing."
-msgstr ""
-#: ../lib/python/script/task.py:240
-msgid "<required>"
-msgstr ""
-#: ../lib/python/script/task.py:500 ../lib/python/script/task.py:504
-#, python-format
-msgid ""
-"Unable to fetch interface description for command '%(cmd)s'.\n"
-"\n"
-"Details: %(det)s"
-msgstr ""
-#: ../lib/python/script/task.py:527
-msgid "Cannot parse interface description of<{name}> module: {error}"
-msgstr ""
-#: ../lib/python/script/array.py:157 ../lib/python/script/array.py:207
-#: ../lib/python/script/array.py:254 ../lib/python/script/array.py:305
-#: ../lib/python/script/array.py:356 ../lib/python/script/array.py:398
-#, python-format
-msgid "Invalid kind <%s>"
-msgstr ""
-#: ../lib/python/script/array.py:160 ../lib/python/script/array.py:210
-#: ../lib/python/script/array.py:308 ../lib/python/script/array.py:359
-#, python-format
-msgid "Invalid size <%d>"
-msgstr ""
-#: ../lib/python/script/array.py:197
-msgid "grass.script.array.read is deprecated and does not work on MS Windows, pass raster name in the constructor"
-msgstr ""
-#: ../lib/python/script/array.py:247 ../lib/python/script/array.py:392
-#, python-format
-msgid "Invalid FP size <%d>"
-msgstr ""
-#: ../lib/python/script/array.py:251 ../lib/python/script/array.py:395
-#, python-format
-msgid "Invalid integer size <%d>"
-msgstr ""
-#: ../lib/python/script/array.py:346
-msgid "grass.script.array3d.read is deprecated and does not work on MS Windows, pass 3D raster name in the constructor"
-msgstr ""
-#: ../lib/python/script/db.py:45 ../lib/vector/Vlib/write_pg.c:666
-#: ../lib/vector/Vlib/ascii.c:428 ../lib/db/dbmi_client/column.c:136
-msgid "Unable to describe table <%s>"
-msgstr ""
-#: ../lib/python/script/db.py:153
-#, python-format
-msgid "Programmer error: '%(sql)s', '%(filename)s', or '%(table)s' must be provided"
-msgstr ""
-#: ../lib/python/script/db.py:163
-msgid "Fetching data failed"
-msgstr ""
-#: ../lib/rowio/setup.c:61 ../lib/rowio/setup.c:67 ../lib/segment/open.c:98
-#: ../lib/rst/interp_float/interp2d.c:139
-#: ../lib/rst/interp_float/interp2d.c:145
-#: ../lib/rst/interp_float/segmen2d_parallel.c:78
-#: ../lib/rst/interp_float/segmen2d_parallel.c:85
-#: ../lib/rst/interp_float/segmen2d_parallel.c:92
-#: ../lib/rst/interp_float/segmen2d_parallel.c:101
-#: ../lib/rst/interp_float/segmen2d_parallel.c:263
-#: ../lib/rst/interp_float/segmen2d.c:197
-#: ../lib/rst/interp_float/segmen2d.c:203
-#: ../lib/rst/interp_float/segmen2d.c:209
-#: ../lib/rst/interp_float/segmen2d.c:219
-#: ../lib/vector/diglib/struct_alloc.c:491 ../lib/vector/Vlib/line.c:50
-#: ../lib/vector/Vlib/line.c:154 ../lib/vector/Vlib/map.c:48
-#: ../lib/vector/neta/components.c:71 ../lib/vector/neta/components.c:176
-#: ../lib/vector/neta/centrality.c:63 ../lib/vector/neta/centrality.c:145
-#: ../lib/vector/neta/flow.c:66 ../lib/vector/neta/flow.c:190
-#: ../lib/vector/neta/articulation_point.c:60
-#: ../lib/vector/neta/timetables.c:69 ../lib/vector/neta/timetables.c:168
-#: ../lib/vector/neta/timetables.c:178 ../lib/vector/neta/timetables.c:191
-#: ../lib/vector/neta/timetables.c:278 ../lib/vector/neta/timetables.c:413
-#: ../lib/vector/neta/timetables.c:425 ../lib/vector/neta/bridge.c:58
-#: ../lib/vector/neta/spanningtree.c:101 ../lib/vector/neta/path.c:262
-msgid "Out of memory"
-msgstr "Nepietiek atmiņas"
-#: ../lib/proj/get_proj.c:148
+#: ../lib/vector/Vlib/build_sfa.c:385 ../lib/vector/Vlib/build_sfa.c:664
+#: ../lib/vector/Vlib/build_nat.c:117
 #, c-format
-msgid "Invalid zone %s specified"
-msgstr ""
+msgid "One primitive registered"
+msgid_plural "%d primitives registered"
+msgstr[0] "Ir reģistrēts %d primitīvs"
+msgstr[1] "Ir reģistrēti %d primitīvi"
+msgstr[2] "Ir reģistrēts %d primitīvu"
-#: ../lib/proj/get_proj.c:228
-msgid "Unable to initialise PROJ.4 with the following parameter list:"
-msgstr ""
-#: ../lib/proj/get_proj.c:236
+#: ../lib/vector/Vlib/build_sfa.c:386 ../lib/vector/Vlib/build_sfa.c:665
+#: ../lib/vector/Vlib/build_nat.c:118
 #, c-format
-msgid "The error message: %s"
-msgstr "Kļūdas paziņojums: %s"
+msgid "One vertex registered"
+msgid_plural "%d vertices registered"
+msgstr[0] "Reģistrēta %d virsotne"
+msgstr[1] "Reģistrētas %d virsotnes"
+msgstr[2] "Reģistrēts %d virsotņu"
-#: ../lib/proj/get_proj.c:294
-msgid "Option input overflowed option table"
-msgstr ""
-#: ../lib/proj/get_proj.c:325
+#: ../lib/vector/Vlib/build_sfa.c:603 ../lib/vector/Vlib/read_ogr.c:344
+#: ../lib/vector/Vlib/read_ogr.c:578
 #, c-format
-msgid "Unable to initialize pj cause: %s"
+msgid "OGR feature type %d not supported"
 msgstr ""
-#: ../lib/proj/get_proj.c:401
-msgid "Input Projection Parameters"
-msgstr ""
-#: ../lib/proj/get_proj.c:404
-msgid "Input Unit Factor"
-msgstr ""
-#: ../lib/proj/get_proj.c:414
-msgid "Output Projection Parameters"
-msgstr ""
-#: ../lib/proj/get_proj.c:417
-msgid "Output Unit Factor"
-msgstr ""
-#: ../lib/proj/datum.c:195
-msgid "Failed to detect nadgrids path, GRASS_PROJSHARE not defined"
-msgstr ""
-#: ../lib/proj/datum.c:278 ../lib/proj/datum.c:358
+#: ../lib/vector/Vlib/build_sfa.c:668
 #, c-format
-msgid "Unable to open datum table file <%s>"
-msgstr "Nav iespējams atvērt datumu tabulas failu <%s>"
+msgid "One feature without geometry skipped"
+msgid_plural "%d features without geometry skipped"
+msgstr[0] "Ir izlaists %d objekts bez ģeometrijas"
+msgstr[1] "Ir izlaisti %d objekti bez ģeometrijas"
+msgstr[2] "Ir izlaists %d objektu bez ģeometrijas"
-#: ../lib/proj/datum.c:291 ../lib/proj/datum.c:372
-#, c-format
-msgid "Error in datum table file <%s>, line %d"
-msgstr "Kļūda datumu tabulas failā <%s> līnijā %d"
-#: ../lib/proj/convert.c:82 ../lib/vector/Vlib/build_sfa.c:714
-#: ../lib/vector/Vlib/simple_features.c:310 ../lib/vector/Vlib/close.c:284
-#: ../lib/vector/Vlib/header_finfo.c:41 ../lib/vector/Vlib/header_finfo.c:80
-#: ../lib/vector/Vlib/header_finfo.c:113 ../lib/vector/Vlib/header_finfo.c:153
-#: ../lib/vector/Vlib/header_finfo.c:254 ../lib/vector/Vlib/write_sfa.c:298
-#: ../lib/vector/Vlib/close_ogr.c:77 ../lib/vector/Vlib/close_ogr.c:111
-#: ../lib/vector/Vlib/write_ogr.c:69 ../lib/vector/Vlib/write_ogr.c:105
-#: ../lib/vector/Vlib/write_ogr.c:145 ../lib/vector/Vlib/build_ogr.c:101
-#: ../lib/vector/Vlib/build_ogr.c:176 ../lib/vector/Vlib/rewind_ogr.c:47
-#: ../lib/vector/Vlib/rewind_ogr.c:71 ../lib/vector/Vlib/open_ogr.c:121
-#: ../lib/vector/Vlib/open_ogr.c:154 ../lib/vector/Vlib/open_ogr.c:231
+#: ../lib/vector/Vlib/build_sfa.c:714 ../lib/vector/Vlib/close_ogr.c:77
+#: ../lib/vector/Vlib/close_ogr.c:111 ../lib/vector/Vlib/close.c:284
+#: ../lib/vector/Vlib/write_sfa.c:298 ../lib/vector/Vlib/write_ogr.c:69
+#: ../lib/vector/Vlib/write_ogr.c:105 ../lib/vector/Vlib/write_ogr.c:145
+#: ../lib/vector/Vlib/open_ogr.c:121 ../lib/vector/Vlib/open_ogr.c:154
+#: ../lib/vector/Vlib/open_ogr.c:231 ../lib/vector/Vlib/simple_features.c:310
+#: ../lib/vector/Vlib/field.c:675 ../lib/vector/Vlib/header_finfo.c:41
+#: ../lib/vector/Vlib/header_finfo.c:80 ../lib/vector/Vlib/header_finfo.c:113
+#: ../lib/vector/Vlib/header_finfo.c:153 ../lib/vector/Vlib/header_finfo.c:254
+#: ../lib/vector/Vlib/rewind_ogr.c:47 ../lib/vector/Vlib/rewind_ogr.c:71
 #: ../lib/vector/Vlib/read_ogr.c:56 ../lib/vector/Vlib/read_ogr.c:157
-#: ../lib/vector/Vlib/read_ogr.c:242 ../lib/vector/Vlib/field.c:675
+#: ../lib/vector/Vlib/read_ogr.c:242 ../lib/vector/Vlib/build_ogr.c:101
+#: ../lib/vector/Vlib/build_ogr.c:176 ../lib/proj/convert.c:64
 msgid "GRASS is not compiled with OGR support"
 msgstr "GRASS nav kompilēts ar OGR atbalstu"
-#: ../lib/proj/convert.c:120
-msgid "Unable parse GRASS PROJ_INFO file"
-msgstr "Nebija iespējams parsēt GRASS PROJ_INFO failu"
-#: ../lib/proj/convert.c:125
-msgid "Unable get PROJ.4-style parameter string"
-msgstr ""
-#: ../lib/proj/convert.c:139
+#: ../lib/vector/Vlib/build_sfa.c:725
 #, c-format
-msgid "OGR can't parse PROJ.4-style parameter string: %s (OGR Error code was %d)"
+msgid "%s: Native format unsupported"
 msgstr ""
-#: ../lib/proj/convert.c:152
-#, c-format
-msgid "OGR can't get WKT-style parameter string (OGR Error code was %d)"
+#: ../lib/vector/Vlib/build_sfa.c:751
+msgid "Feature index is built only for non-native formats. Nothing to dump."
 msgstr ""
-#: ../lib/proj/convert.c:394
-msgid "No projection name! Projection parameters likely to be meaningless."
-msgstr ""
+#: ../lib/vector/Vlib/rewind.c:29 ../lib/vector/Vlib/close.c:38
+#: ../lib/vector/Vlib/read.c:32 ../lib/vector/Vlib/open.c:59
+#: ../lib/vector/Vlib/write.c:56 ../lib/vector/Vlib/write.c:62
+#: ../lib/vector/Vlib/build.c:37
+msgid "Requested format is not compiled in this version"
+msgstr "Pieprasītais formāts nav pieejams/iekļauts šijā versijā"
-#: ../lib/proj/convert.c:457
+#: ../lib/vector/Vlib/ascii.c:84
 #, c-format
-msgid "Datum <%s> not recognised by GRASS and no parameters found"
-msgstr "Datums <%s> nav atpazīts un parametri nav atrasti"
+msgid "Error reading ASCII file: (bad type) [%s]"
+msgstr ""
-#: ../lib/proj/convert.c:473
+#: ../lib/vector/Vlib/ascii.c:123
 #, c-format
-msgid "Datum <%s> apparently recognised by GRASS but no parameters found. You may want to look into this."
+msgid "Error reading ASCII file: (unknown type) [%s]"
 msgstr ""
-#: ../lib/proj/convert.c:477
-#, c-format
-msgid "Invalid transformation number %d; valid range is 1 to %d. Leaving datum transform parameters unspecified."
+#: ../lib/vector/Vlib/ascii.c:143
+msgid "End of ASCII file reached before end of coordinates"
 msgstr ""
-#: ../lib/proj/ellipse.c:97
+#: ../lib/vector/Vlib/ascii.c:155
 #, c-format
-msgid "Invalid ellipsoid <%s> in file"
-msgstr "Nederīgs elipsoīds failā <%s>"
-#: ../lib/proj/ellipse.c:124
-msgid "No secondary ellipsoid descriptor (rf, es or b) in file"
+msgid "Error reading ASCII file: (bad point) [%s]"
 msgstr ""
-#: ../lib/proj/ellipse.c:128
-msgid "Invalid ellipsoid descriptors (a, rf, es or b) in file"
-msgstr ""
-#: ../lib/proj/ellipse.c:141
-msgid "No ellipsoid info given in file"
-msgstr "Failā nav sniegta elipsoīda informācija"
-#: ../lib/proj/ellipse.c:243 ../lib/gis/get_ellipse.c:263
+#: ../lib/vector/Vlib/ascii.c:160
 #, c-format
-msgid "Unable to open ellipsoid table file <%s>"
-msgstr "Nav iespējams atvērt elipsoīda tabulas failu <%s>"
-#: ../lib/proj/do_proj.c:106 ../lib/proj/do_proj.c:180
-#, c-format
-msgid "pj_transform() failed: %s"
+msgid "Unparsable longitude value: [%s]"
 msgstr ""
-#: ../lib/arraystats/class.c:19
+#: ../lib/vector/Vlib/ascii.c:165
 #, c-format
-msgid "Unknown algorithm '%s'"
+msgid "Unparsable latitude value: [%s]"
 msgstr ""
-#: ../lib/arraystats/class.c:42
-msgid "Discont algorithm currently not available because of bugs"
+#: ../lib/vector/Vlib/ascii.c:201
+msgid "End of ASCII file reached before end of categories"
 msgstr ""
-#: ../lib/arraystats/class.c:49
-msgid "Classification algorithm failed"
+#: ../lib/vector/Vlib/ascii.c:212
+#, c-format
+msgid "Error reading categories: [%s]"
 msgstr ""
-#: ../lib/arraystats/class.c:227
-msgid "Equiprobable classbreaks currently limited to 10 classes"
+#: ../lib/vector/Vlib/ascii.c:225
+msgid "Unable to copy points"
 msgstr ""
-#: ../lib/arraystats/class.c:242
+#: ../lib/vector/Vlib/ascii.c:238
 #, c-format
-msgid "There are classbreaks outside the range min-max. Number of classes reduced to %i, but using probabilities for %i classes."
+msgid "Vector map <%s> is 2D. %d 3D features (faces or kernels) skipped."
 msgstr ""
-#: ../lib/manage/option.c:47
+#: ../lib/vector/Vlib/ascii.c:270
 #, c-format
-msgid "%s to be %s"
+msgid ""
+"Unexpected data in vector header:\n"
+"[%s]"
 msgstr ""
-#: ../lib/manage/option.c:51
-msgid "Raster"
-msgstr "Rastrs"
-#: ../lib/manage/option.c:53
-msgid "Vector"
-msgstr "Vektors"
-#: ../lib/manage/option.c:55
-msgid "Region"
-msgstr "Reģions"
-#: ../lib/manage/option.c:57
-msgid "Group"
-msgstr "Grupa"
-#: ../lib/manage/do_list.c:30
+#: ../lib/vector/Vlib/ascii.c:306
 #, c-format
-msgid "%s: invalid index %d"
+msgid "Unknown keyword <%s> in vector head"
 msgstr ""
-#: ../lib/manage/read_list.c:73
+#: ../lib/vector/Vlib/ascii.c:398 ../lib/vector/Vlib/net_build.c:159
+#: ../lib/vector/Vlib/net_build.c:206 ../lib/vector/Vlib/net_build.c:490
+#: ../lib/vector/Vlib/net_build.c:791 ../lib/vector/Vlib/net_build.c:971
+#: ../lib/vector/Vlib/cats.c:589 ../lib/vector/Vlib/array.c:276
+#: ../lib/vector/Vlib/map.c:300 ../lib/vector/Vlib/map.c:436
+#: ../lib/vector/Vlib/copy.c:620 ../lib/vector/Vlib/copy.c:730
+#: ../lib/rst/interp_float/vinput2d.c:100 ../lib/ogsf/gv3.c:344
+#: ../lib/ogsf/gp3.c:202
 #, c-format
-msgid "Unable to open data base element list '%s'"
-msgstr ""
+msgid "Database connection not defined for layer %d"
+msgstr "Slānim %d nav definēts savienojums ar datu bāzi"
-#: ../lib/manage/read_list.c:134
+#: ../lib/vector/Vlib/ascii.c:465
 #, c-format
-msgid "Format error: file ('%s') line (%d) - %s"
+msgid "Column <%s> does not exist"
 msgstr ""
-#: ../lib/manage/do_rename.c:42
-#, c-format
-msgid "Rename %s <%s> to <%s>"
+#: ../lib/vector/Vlib/ascii.c:467
+msgid "Available columns:"
 msgstr ""
-#: ../lib/manage/do_rename.c:54 ../lib/manage/do_remove.c:57
-#: ../lib/vector/Vlib/legal_vname.c:141 ../lib/vector/Vlib/legal_vname.c:144
-#: ../lib/vector/Vlib/map.c:263 ../lib/vector/Vlib/open.c:235
-#: ../lib/ogsf/gp3.c:56 ../lib/ogsf/gp3.c:191 ../lib/ogsf/gv3.c:60
-#: ../lib/ogsf/gv3.c:333
-#, c-format
-msgid "Vector map <%s> not found"
-msgstr "Vektorkarte <%s> nav atrasta"
+#: ../lib/vector/Vlib/ascii.c:472
+msgid "Export cancelled"
+msgstr ""
-#: ../lib/manage/do_rename.c:62
+#: ../lib/vector/Vlib/ascii.c:505
 #, c-format
-msgid "Unable to rename vector map <%s> to <%s>"
+msgid "Unknown type of column <%s>, export cancelled"
 msgstr ""
-#: ../lib/manage/do_rename.c:71 ../lib/manage/do_remove.c:73
-#: ../lib/rst/interp_float/resout2d.c:205
-#: ../lib/rst/interp_float/resout2d.c:253
-#: ../lib/rst/interp_float/resout2d.c:296
-#: ../lib/rst/interp_float/resout2d.c:327
-#: ../lib/rst/interp_float/resout2d.c:377
-#: ../lib/rst/interp_float/resout2d.c:395
-#: ../lib/rst/interp_float/resout2d.c:410
-#: ../lib/rst/interp_float/resout2d.c:426
-#: ../lib/rst/interp_float/output2d.c:247
-#: ../lib/rst/interp_float/output2d.c:328
-#: ../lib/rst/interp_float/output2d.c:397
-#: ../lib/rst/interp_float/output2d.c:447
-#: ../lib/rst/interp_float/output2d.c:461
-#: ../lib/rst/interp_float/output2d.c:475
-#: ../lib/rst/interp_float/output2d.c:491 ../lib/raster/open.c:178
-#: ../lib/raster/open.c:845 ../lib/raster/open.c:882 ../lib/raster/open.c:934
-#: ../lib/gis/legal_name.c:94 ../lib/gis/legal_name.c:97 ../lib/ogsf/gs3.c:125
-#: ../lib/ogsf/gs3.c:189 ../lib/ogsf/gs3.c:264 ../lib/ogsf/gs3.c:336
-#: ../lib/ogsf/gs3.c:442 ../lib/ogsf/gs3.c:529 ../lib/ogsf/gs3.c:588
-#: ../lib/ogsf/gs3.c:645 ../lib/ogsf/gs3.c:716 ../lib/ogsf/gs3.c:786
-#: ../lib/ogsf/gsd_legend.c:239
+#: ../lib/vector/Vlib/ascii.c:539
 #, c-format
-msgid "Raster map <%s> not found"
-msgstr "Rastra karte <%s> nav atrasta"
+msgid "Unable to select record from table <%s> (key %s, column %s)"
+msgstr ""
-#: ../lib/manage/do_rename.c:76 ../lib/manage/do_remove.c:78
-#: ../lib/gpde/n_arrays_io.c:273 ../lib/ogsf/gvl_file.c:427
-#: ../lib/ogsf/gvl3.c:40
+#: ../lib/vector/Vlib/ascii.c:661
 #, c-format
-msgid "3D raster map <%s> not found"
-msgstr "3D rastra karte <%s> nav atrasta"
-#: ../lib/manage/do_rename.c:83 ../lib/manage/do_rename.c:103
-#, c-format
-msgid "Unable to rename %s"
-msgstr "Nevar pārsaukt %s"
-#: ../lib/manage/do_rename.c:87 ../lib/manage/do_rename.c:107
-#: ../lib/manage/do_copy.c:61 ../lib/manage/do_remove.c:89
-#: ../lib/manage/do_remove.c:109
-#, c-format
-msgid "%s is missing"
+msgid "Unknown feature type %d"
 msgstr ""
-#: ../lib/manage/do_rename.c:90 ../lib/manage/do_rename.c:110
+#: ../lib/vector/Vlib/ascii.c:701
 #, c-format
-msgid "%s renamed"
+msgid "Feature has more categories. Only one category (%d) is exported."
 msgstr ""
-#: ../lib/manage/do_rename.c:119
+#: ../lib/vector/Vlib/ascii.c:718
 #, c-format
-msgid "<%s> nothing renamed"
+msgid "Cannot select attributes for cat = %d"
 msgstr ""
-#: ../lib/manage/do_copy.c:43
-#, c-format
-msgid "Copy %s <%s> to current mapset as <%s>"
+#: ../lib/vector/Vlib/ascii.c:724
+msgid "Unable to fetch data from table"
 msgstr ""
-#: ../lib/manage/do_copy.c:50 ../lib/manage/do_copy.c:67
+#: ../lib/vector/Vlib/ascii.c:756 ../lib/vector/Vlib/net_build.c:216
+#: ../lib/vector/Vlib/net_build.c:501 ../lib/vector/Vlib/net_build.c:519
+#: ../lib/vector/Vlib/net_build.c:802 ../lib/vector/Vlib/net_build.c:820
+#: ../lib/vector/Vlib/net_build.c:981
 #, c-format
-msgid "Unable to copy <%s> to current mapset as <%s>"
+msgid "Column <%s> not found in table <%s>"
 msgstr ""
-#: ../lib/manage/do_copy.c:72
+#: ../lib/vector/Vlib/ascii.c:758
 #, c-format
-msgid "%s copied"
+msgid "Column <%s>: unsupported data type"
 msgstr ""
-#: ../lib/manage/do_remove.c:42
-#, c-format
-msgid "Removing %s <%s>"
+#: ../lib/vector/Vlib/ascii.c:840
+msgid "Unknown format"
 msgstr ""
-#: ../lib/manage/do_remove.c:65
-msgid "Unable to delete vector map"
+#: ../lib/vector/Vlib/ascii.c:850
+msgid "Topology not available, unable to process areas"
 msgstr ""
-#: ../lib/manage/do_remove.c:85
+#: ../lib/vector/Vlib/ascii.c:863
 #, c-format
-msgid "Unable to remove %s element"
+msgid "Unable to get boundary of area id %d"
 msgstr ""
-#: ../lib/manage/do_remove.c:92 ../lib/manage/do_remove.c:112
+#: ../lib/vector/Vlib/ascii.c:875
 #, c-format
-msgid "%s removed"
+msgid "Unable to get boundary of isle id %d (area id %d)"
 msgstr ""
-#: ../lib/manage/do_remove.c:105
+#: ../lib/vector/Vlib/ascii.c:889
 #, c-format
-msgid "Unable to remove %s"
-msgstr "Nevar aizvākt %s"
-#: ../lib/manage/do_remove.c:121
-#, c-format
-msgid "<%s> nothing removed"
+msgid ""
+"%d features without category skipped. To export also features without "
+"category use '%s=-1'."
 msgstr ""
-#: ../lib/nviz/position.c:56
-msgid "Unable to set focus"
+#: ../lib/vector/Vlib/cindex.c:32
+msgid "Category index is not up to date"
 msgstr ""
-#: ../lib/nviz/map_obj.c:59
-msgid "Maximum surfaces loaded!"
-msgstr ""
+#: ../lib/vector/Vlib/cindex.c:38
+msgid "Layer index out of range"
+msgstr "Slāņa indekss ārpus robežām"
-#: ../lib/nviz/map_obj.c:88
-msgid "Maximum vector line maps loaded!"
+#: ../lib/vector/Vlib/cindex.c:268
+msgid "Category index out of range"
 msgstr ""
-#: ../lib/nviz/map_obj.c:97 ../lib/nviz/map_obj.c:128
+#: ../lib/vector/Vlib/cindex.c:488
 #, c-format
-msgid "Error loading vector map <%s>"
+msgid "Unable to create category index file for vector map <%s>"
 msgstr ""
-#: ../lib/nviz/map_obj.c:116
-msgid "Maximum vector point maps loaded!"
+#: ../lib/vector/Vlib/cindex.c:497
+msgid "Error writing out category index file"
 msgstr ""
-#: ../lib/nviz/map_obj.c:143
-msgid "Maximum volumes loaded!"
+#: ../lib/vector/Vlib/cindex.c:539 ../lib/vector/Vlib/open.c:393
+#, c-format
+msgid "Unable to open category index file for vector map <%s>"
 msgstr ""
-#: ../lib/nviz/map_obj.c:152
+#: ../lib/vector/Vlib/close_ogr.c:104 ../lib/vector/Vlib/close_pg.c:139
 #, c-format
-msgid "Error loading 3d raster map <%s>"
+msgid "Unable to save feature index file for vector map <%s>"
 msgstr ""
-#: ../lib/nviz/map_obj.c:160
-msgid "Nviz_new_map_obj(): unsupported data type"
+#: ../lib/vector/Vlib/close_nat.c:74
+#, c-format
+msgid "Unable to create '%s': %s"
 msgstr ""
-#: ../lib/nviz/lights.c:171
-msgid "Unable to define new light"
+#: ../lib/vector/Vlib/close_nat.c:81
+#, c-format
+msgid "Unable to copy '%s': %s"
 msgstr ""
-#: ../lib/nviz/nviz.c:128
+#: ../lib/vector/Vlib/close_nat.c:102 ../lib/vector/Vlib/map.c:317
+#: ../lib/vector/Vlib/copy.c:764
 #, c-format
-msgid "Invalid color (%s), using \"white\" as default"
+msgid "Unable to copy table <%s>"
 msgstr ""
-#: ../lib/nviz/render.c:106
-msgid "Bad server connection"
-msgstr ""
-#: ../lib/nviz/render.c:112
-msgid "Unable to get visual info"
-msgstr ""
-#: ../lib/nviz/render.c:119
-msgid "Unable to create rendering context"
-msgstr ""
-#: ../lib/lidar/zones.c:473 ../lib/lidar/zones.c:510
+#: ../lib/vector/Vlib/close_nat.c:167
 #, c-format
-msgid "<%s> created in database."
-msgstr "Datubāzē ir izveidots <%s>."
-#: ../lib/lidar/zones.c:477 ../lib/lidar/zones.c:514
-#, c-format
-msgid "<%s> has not been created in database."
-msgstr "<%s> nav izveidots datubāzē."
-#: ../lib/lidar/raster.c:74 ../lib/lidar/raster.c:89 ../lib/lidar/raster.c:102
-#: ../lib/lidar/raster.c:119 ../lib/lidar/raster.c:134
-#: ../lib/lidar/raster.c:147 ../lib/lidar/raster.c:162
-#: ../lib/lidar/raster.c:175
-#, c-format
-msgid "Unable to access table <%s>"
-msgstr "Nav iespējams piekļūt tabulai <%s>"
-#: ../lib/segment/open.c:53
-msgid "Segment file name is NULL"
+msgid "Unable to drop table <%s>"
 msgstr ""
-#: ../lib/segment/open.c:58
-msgid "Segment file exists already"
-msgstr "Segmentu fails jau eksistē"
-#: ../lib/segment/open.c:66
-msgid "Unable to create segment file"
+#: ../lib/vector/Vlib/snap.c:223 ../lib/vector/Vlib/snap.c:582
+msgid "Snap vertices Pass 1: select points"
 msgstr ""
-#: ../lib/segment/open.c:74
-msgid "Could not write segment file"
+#: ../lib/vector/Vlib/snap.c:270 ../lib/vector/Vlib/snap.c:636
+msgid "Snap vertices Pass 2: assign anchor vertices"
 msgstr ""
-#: ../lib/segment/open.c:78
-msgid "Illegal segment configuration parameter(s)"
+#: ../lib/vector/Vlib/snap.c:339 ../lib/vector/Vlib/snap.c:705
+msgid "Snap vertices Pass 3: snap to assigned points"
 msgstr ""
-#: ../lib/segment/open.c:87
-msgid "Unable to re-open segment file"
+#: ../lib/vector/Vlib/snap.c:525 ../lib/vector/Vlib/snap.c:888
+#, c-format
+msgid "Snapped vertices: %d"
 msgstr ""
-#: ../lib/segment/open.c:94
-msgid "Could not read segment file"
+#: ../lib/vector/Vlib/snap.c:526 ../lib/vector/Vlib/snap.c:889
+#, c-format
+msgid "New vertices: %d"
 msgstr ""
-#: ../lib/segment/format.c:143
-msgid "Segment format: file size too large"
+#: ../lib/vector/Vlib/snap.c:916
+msgid "Reading features..."
 msgstr ""
-#: ../lib/segment/format.c:144
-msgid "Please recompile with Large File Support (LFS)"
+#: ../lib/vector/Vlib/box.c:264
+#, c-format
+msgid "Unable to determine bbox for feature %d"
 msgstr ""
-#: ../lib/gpde/test/test_main.c:88
-msgid "Performs unit and integration tests for gpde library"
+#: ../lib/vector/Vlib/box.c:313 ../lib/vector/Vlib/box.c:359
+#, c-format
+msgid "Attempt to access area with invalid id (%d)"
 msgstr ""
-#: ../lib/gpde/n_gwflow.c:436 ../lib/gpde/n_gwflow.c:715
+#: ../lib/vector/Vlib/box.c:325
 #, c-format
-msgid "The total sum of the water budget: %g\n"
+msgid "Unable to determine bbox for area %d"
 msgstr ""
-#: ../lib/gpde/n_gwflow.c:438 ../lib/gpde/n_gwflow.c:717
+#: ../lib/vector/Vlib/box.c:371
 #, c-format
-msgid "The total sum of the water budget is significantly larger then 0: %g\n"
+msgid "Unable to determine bbox for isle %d"
 msgstr ""
-#: ../lib/gpde/n_parse_options.c:106
-msgid "The calculation time in seconds"
-msgstr ""
-#: ../lib/gpde/n_arrays_io.c:93
+#: ../lib/vector/Vlib/box.c:429
 #, c-format
-msgid "Reading raster map <%s> into memory"
+msgid "Topology not available for vector map <%s>. Registering primitives..."
 msgstr ""
-#: ../lib/gpde/n_arrays_io.c:183
-msgid "N_array_2d * array is empty"
-msgstr ""
+#: ../lib/vector/Vlib/box.c:436 ../lib/vector/Vlib/build_nat.c:84
+msgid "Unable to read vector map"
+msgstr "Nav iespējams nolasīt vektoru karti"
-#: ../lib/gpde/n_arrays_io.c:202
-#, c-format
-msgid "Write 2d array to raster map <%s>"
+#: ../lib/vector/Vlib/open_pg.c:109 ../lib/vector/Vlib/open_pg.c:267
+msgid "No feature tables found in database."
 msgstr ""
-#: ../lib/gpde/n_arrays_io.c:309
+#: ../lib/vector/Vlib/open_pg.c:133
 #, c-format
-msgid "Read g3d map <%s> into the memory"
+msgid "Feature table <%s> not found in 'geometry_columns'"
 msgstr ""
-#: ../lib/gpde/n_arrays_io.c:364 ../lib/gpde/n_arrays_io.c:464
-msgid "Error closing g3d file"
+#: ../lib/vector/Vlib/open_pg.c:181
+msgid "Topology schema not found."
 msgstr ""
-#: ../lib/gpde/n_arrays_io.c:420
+#: ../lib/vector/Vlib/open_pg.c:193 ../lib/vector/Vlib/open_ogr.c:145
 #, c-format
-msgid "Error opening g3d map <%s>"
+msgid "Unable to open feature index file for vector map <%s>"
 msgstr ""
-#: ../lib/gpde/n_arrays_io.c:422
+#: ../lib/vector/Vlib/open_pg.c:273
 #, c-format
-msgid "Write 3d array to g3d map <%s>"
+msgid "PostGIS layer <%s.%s> already exists and will be overwritten"
 msgstr ""
-#: ../lib/driver/parse_ftcap.c:84
+#: ../lib/vector/Vlib/open_pg.c:276
 #, c-format
-msgid "%s: Unable to read font definition file; use the default"
+msgid "Unable to delete PostGIS layer <%s>"
 msgstr ""
-#: ../lib/driver/parse_ftcap.c:90
+#: ../lib/vector/Vlib/open_pg.c:282
 #, c-format
-msgid "%s: No font definition file"
+msgid "PostGIS layer <%s.%s> already exists in database '%s'"
 msgstr ""
-#: ../lib/symbol/read.c:211
-#, c-format
-msgid "Cannot read symbol line coordinates: %s"
+#: ../lib/vector/Vlib/open_pg.c:390
+msgid "No key column detected."
 msgstr ""
-#: ../lib/symbol/read.c:260
+#: ../lib/vector/Vlib/open_pg.c:462 ../lib/vector/Vlib/open_pg.c:474
 #, c-format
-msgid "Incorrect symbol name: '%s' (should be: group/name or group/name at mapset)"
+msgid "Execution failed: %s"
 msgstr ""
-#: ../lib/symbol/read.c:284
+#: ../lib/vector/Vlib/open_pg.c:476
 #, c-format
-msgid "Cannot find/open symbol: '%s'"
-msgstr "Nevar atrast/atvērt simbolu: '%s'"
-#: ../lib/symbol/read.c:393 ../lib/symbol/read.c:411 ../lib/symbol/read.c:421
-#: ../lib/symbol/read.c:439
-#, c-format
-msgid "Incorrect symbol color: '%s', using default."
-msgstr "Nederīga simbola krāsa: '%s', tiek izmantota noklusējuma."
-#: ../lib/gmath/del2g.c:50
-msgid "    taking FFT of image..."
+msgid "PostGIS topology schema <%s> dropped"
 msgstr ""
-#: ../lib/gmath/del2g.c:56
-msgid "    computing del**2 g..."
-msgstr ""
-#: ../lib/gmath/del2g.c:59
-msgid "    taking FFT of del**2 g..."
-msgstr ""
-#: ../lib/gmath/del2g.c:63
-msgid "    multiplying transforms..."
-msgstr ""
-#: ../lib/gmath/del2g.c:66
-msgid "    taking inverse FFT..."
-msgstr ""
-#: ../lib/gmath/test/test_matrix_conversion.c:37
+#: ../lib/vector/Vlib/open_pg.c:559
 msgid ""
-"\n"
-"++ Running matrix conversion unit tests ++"
+"Connection to PostgreSQL database failed. Try to set up username/password by "
+"db.login."
 msgstr ""
-#: ../lib/gmath/test/test_matrix_conversion.c:42
-msgid ""
-"\n"
-"-- Matrix conversion unit tests failure --"
+#: ../lib/vector/Vlib/open_pg.c:566
+msgid "Unable to get database name"
 msgstr ""
-#: ../lib/gmath/test/test_matrix_conversion.c:44
-msgid ""
-"\n"
-"-- Matrix conversion unit tests finished successfully --"
+#: ../lib/vector/Vlib/open_pg.c:571
+#, c-format
+msgid "<%s> is not PostGIS database. DB table 'spatial_ref_sys' not found."
 msgstr ""
-#: ../lib/gmath/test/bench_blas2.c:35
-msgid ""
-"\n"
-"++ Running blas level 2 benchmark ++"
-msgstr ""
-#: ../lib/gmath/test/test_ccmath_wrapper.c:37
-msgid ""
-"\n"
-"++ Running ccmath wrapper unit tests ++"
-msgstr ""
-#: ../lib/gmath/test/test_ccmath_wrapper.c:42
-msgid ""
-"\n"
-"-- ccmath wrapper unit tests failure --"
-msgstr ""
-#: ../lib/gmath/test/test_ccmath_wrapper.c:44
-msgid ""
-"\n"
-"-- ccmath wrapper unit tests finished successfully --"
-msgstr ""
-#: ../lib/gmath/test/test_main.c:47
-#: ../lib/vector/rtree/test_suite/test_main.c:44
-#: ../lib/db/dbmi_base/test/test_main.c:47
-msgid "Choose the unit tests to run"
-msgstr ""
-#: ../lib/gmath/test/test_main.c:54 ../lib/db/dbmi_base/test/test_main.c:54
-msgid "Choose the integration tests to run"
-msgstr ""
-#: ../lib/gmath/test/test_main.c:61
-msgid "The size of the matrices and vectors for benchmarking"
-msgstr ""
-#: ../lib/gmath/test/test_main.c:68
-msgid "Choose solver benchmark"
-msgstr ""
-#: ../lib/gmath/test/test_main.c:75
-msgid "Choose blas benchmark"
-msgstr ""
-#: ../lib/gmath/test/test_main.c:79 ../lib/db/dbmi_base/test/test_main.c:58
-msgid "Run all unit tests"
-msgstr ""
-#: ../lib/gmath/test/test_main.c:83 ../lib/db/dbmi_base/test/test_main.c:62
-msgid "Run all integration tests"
-msgstr ""
-#: ../lib/gmath/test/test_main.c:87 ../lib/db/dbmi_base/test/test_main.c:66
-msgid "Run all unit and integration tests"
-msgstr ""
-#: ../lib/gmath/test/test_main.c:106
-msgid "Performs benchmarks, unit and integration tests for the gmath library"
-msgstr ""
-#: ../lib/gmath/test/bench_solver_krylov.c:34
-msgid ""
-"\n"
-"++ Running krylov solver benchmark ++"
-msgstr ""
-#: ../lib/gmath/test/test_blas3.c:38
-msgid ""
-"\n"
-"++ Running blas level 3 unit tests ++"
-msgstr ""
-#: ../lib/gmath/test/test_blas3.c:44
-msgid ""
-"\n"
-"-- blas level 3 unit tests failure --"
-msgstr ""
-#: ../lib/gmath/test/test_blas3.c:46
-msgid ""
-"\n"
-"-- blas level 3 unit tests finished successfully --"
-msgstr ""
-#: ../lib/gmath/test/bench_solver_direct.c:34
-msgid ""
-"\n"
-"++ Running direct solver benchmark ++"
-msgstr ""
-#: ../lib/gmath/test/test_blas1.c:40
-msgid ""
-"\n"
-"++ Running blas level 1 unit tests ++"
-msgstr ""
-#: ../lib/gmath/test/test_blas1.c:47
-msgid ""
-"\n"
-"-- blas level 1 unit tests failure --"
-msgstr ""
-#: ../lib/gmath/test/test_blas1.c:49
-msgid ""
-"\n"
-"-- blas level 1 unit tests finished successfully --"
-msgstr ""
-#: ../lib/gmath/test/test_blas2.c:38
-msgid ""
-"\n"
-"++ Running blas level 2 unit tests ++"
-msgstr ""
-#: ../lib/gmath/test/test_blas2.c:44
-msgid ""
-"\n"
-"-- blas level 2 unit tests failure --"
-msgstr ""
-#: ../lib/gmath/test/test_blas2.c:46
-msgid ""
-"\n"
-"-- blas level 2 unit tests finished successfully --"
-msgstr ""
-#: ../lib/gmath/test/test_solvers.c:37
-msgid ""
-"\n"
-"++ Running solver unit tests ++"
-msgstr ""
-#: ../lib/gmath/test/test_solvers.c:42
-msgid ""
-"\n"
-"-- Solver unit tests failure --"
-msgstr ""
-#: ../lib/gmath/test/test_solvers.c:44
-msgid ""
-"\n"
-"-- Solver unit tests finished successfully --"
-msgstr ""
-#: ../lib/gmath/test/bench_blas3.c:34
-msgid ""
-"\n"
-"++ Running blas level 3 benchmark ++"
-msgstr ""
-#: ../lib/gmath/solvers_direct_cholesky_band.c:33
+#: ../lib/vector/Vlib/open_pg.c:580
 #, c-format
-msgid "Decomposition failed at row %i and col %i"
+msgid "PostGIS Topology extension not found in the database <%s>"
 msgstr ""
-#: ../lib/gmath/la.c:61 ../lib/gmath/la.c:117
-msgid "Matrix dimensions out of range"
+#: ../lib/vector/Vlib/open_pg.c:667
+msgid "Empty bounding box"
 msgstr ""
-#: ../lib/gmath/la.c:150
-msgid "Matrix is not initialised fully."
-msgstr ""
-#: ../lib/gmath/la.c:155
-msgid "Unable to allocate space for matrix copy"
-msgstr ""
-#: ../lib/gmath/la.c:220
-msgid "Input matrix is uninitialized"
-msgstr ""
-#: ../lib/gmath/la.c:285
-msgid "First scalar multiplier must be non-zero"
-msgstr ""
-#: ../lib/gmath/la.c:291 ../lib/gmath/la.c:299 ../lib/gmath/la.c:364
-msgid "One or both input matrices uninitialised"
-msgstr ""
-#: ../lib/gmath/la.c:304 ../lib/gmath/la.c:369
-msgid "Matrix order does not match"
-msgstr ""
-#: ../lib/gmath/la.c:310
-msgid "Unable to allocate space for matrix sum"
-msgstr ""
-#: ../lib/gmath/la.c:374
-msgid "Unable to allocate space for matrix product"
-msgstr ""
-#: ../lib/gmath/la.c:486
-msgid "Input: one or both data matrices uninitialised"
-msgstr ""
-#: ../lib/gmath/la.c:491
-msgid "Principal matrix is not properly dimensioned"
-msgstr ""
-#: ../lib/gmath/la.c:496
-msgid "Input: you must have at least one array to solve"
-msgstr ""
-#: ../lib/gmath/la.c:502
-msgid "Could not allocate space for solution matrix"
-msgstr ""
-#: ../lib/gmath/la.c:508 ../lib/gmath/la.c:516
-msgid "Could not allocate space for working matrix"
-msgstr ""
-#: ../lib/gmath/la.c:569
-msgid "Matrix (or submatrix is singular). Solution undetermined"
-msgstr ""
-#: ../lib/gmath/la.c:573
-msgid "Problem in LA routine."
-msgstr ""
-#: ../lib/gmath/la.c:580
-msgid "Procedure not yet available for selected matrix type"
-msgstr ""
-#: ../lib/gmath/la.c:614
-msgid "Matrix is not square. Cannot determine inverse"
-msgstr ""
-#: ../lib/gmath/la.c:619
-msgid "Unable to allocate space for matrix"
-msgstr ""
-#: ../lib/gmath/la.c:636
-msgid "Matrix is singular"
-msgstr ""
-#: ../lib/gmath/la.c:641
-msgid "Problem in LA procedure."
-msgstr ""
-#: ../lib/gmath/la.c:729
-msgid "Element array has not been allocated"
-msgstr ""
-#: ../lib/gmath/la.c:734
-msgid "Specified element is outside array bounds"
-msgstr ""
-#: ../lib/gmath/la.c:788
-msgid "Specified matrix column index is outside range"
-msgstr ""
-#: ../lib/gmath/la.c:793 ../lib/gmath/la.c:834 ../lib/gmath/la.c:1198
-#: ../lib/gmath/la.c:1250 ../lib/gmath/la.c:1325
-msgid "Matrix is not initialised"
-msgstr ""
-#: ../lib/gmath/la.c:798 ../lib/gmath/la.c:839
-msgid "Could not allocate space for vector structure"
-msgstr ""
-#: ../lib/gmath/la.c:829
-msgid "Specified matrix row index is outside range"
-msgstr ""
-#: ../lib/gmath/la.c:869
-msgid "Specified row index is outside range"
-msgstr ""
-#: ../lib/gmath/la.c:874
-msgid "Specified column index is outside range"
-msgstr ""
-#: ../lib/gmath/la.c:894
-msgid "Unknown vector type."
-msgstr ""
-#: ../lib/gmath/la.c:949
-msgid "Input matrix and vector have differing dimensions1"
-msgstr ""
-#: ../lib/gmath/la.c:955 ../lib/gmath/la.c:1071 ../lib/gmath/la.c:1361
-msgid "Output vector is uninitialized"
-msgstr ""
-#: ../lib/gmath/la.c:1076 ../lib/gmath/la.c:1366
-msgid "Vectors are not of the same type"
-msgstr ""
-#: ../lib/gmath/la.c:1081
-msgid "Output vector is of incorrect type"
-msgstr ""
-#: ../lib/gmath/la.c:1086 ../lib/gmath/la.c:1376
-msgid "Matrices not allowed"
-msgstr ""
-#: ../lib/gmath/la.c:1092 ../lib/gmath/la.c:1383
-msgid "Vectors have differing dimensions"
-msgstr ""
-#: ../lib/gmath/la.c:1098 ../lib/gmath/la.c:1390
-msgid "Output vector has incorrect dimension"
-msgstr ""
-#: ../lib/gmath/la.c:1143
-msgid "Vector dimensions out of range"
-msgstr ""
-#: ../lib/gmath/la.c:1148
-msgid "Row/column out of range"
-msgstr ""
-#: ../lib/gmath/la.c:1371
-msgid "Output vector is not the same type as others"
-msgstr ""
-#: ../lib/gmath/la.c:1437
-msgid "Vector structure is not initialised"
-msgstr ""
-#: ../lib/gmath/la.c:1558 ../lib/gmath/la.c:1566 ../lib/gmath/la.c:1571
-msgid "Input format error"
-msgstr ""
-#: ../lib/gmath/solvers_classic_iter.c:84
+#: ../lib/vector/Vlib/open_pg.c:768
 #, c-format
-msgid "sparse Jacobi -- iteration %5i error %g\n"
+msgid "Inconsistency in topology: unable to read node %d"
 msgstr ""
-#: ../lib/gmath/solvers_classic_iter.c:156
+#: ../lib/vector/Vlib/open_pg.c:834
 #, c-format
-msgid "sparse SOR -- iteration %5i error %g\n"
+msgid "Inconsistency in topology: node %d - unexpected feature type %d"
 msgstr ""
-#: ../lib/gmath/solvers_classic_iter.c:218
+#: ../lib/vector/Vlib/open_pg.c:1003
 #, c-format
-msgid "Jacobi -- iteration %5i error %g\n"
+msgid "Area %d without boundary detected"
 msgstr ""
-#: ../lib/gmath/solvers_classic_iter.c:275
+#: ../lib/vector/Vlib/open_pg.c:1061
 #, c-format
-msgid "SOR -- iteration %5i error %g\n"
+msgid "Isle %d without boundary detected"
 msgstr ""
-#: ../lib/gmath/solvers_direct.c:45
-msgid "Starting direct gauss elimination solver"
+#: ../lib/vector/Vlib/open_pg.c:1128
+msgid "Unable to get map bounding box from topology"
 msgstr ""
-#: ../lib/gmath/solvers_direct.c:73
-msgid "Starting direct lu decomposition solver"
+#: ../lib/vector/Vlib/open_pg.c:1135
+#, c-format
+msgid ""
+"Unable to parse map bounding box:\n"
+"%s"
 msgstr ""
-#: ../lib/gmath/solvers_direct.c:131
-msgid "Starting cholesky decomposition solver"
+#: ../lib/vector/Vlib/open_pg.c:1159
+#, c-format
+msgid "Different number of nodes detected (%d, %d)"
 msgstr ""
-#: ../lib/gmath/solvers_direct.c:134 ../lib/gmath/solvers_krylov.c:254
-#: ../lib/gmath/solvers_krylov.c:482 ../lib/gmath/solvers_krylov.c:646
-msgid "Unable to solve the linear equation system"
-msgstr ""
-#: ../lib/gmath/solvers_krylov.c:262
+#: ../lib/vector/Vlib/open_pg.c:1187 ../lib/vector/Vlib/open_pg.c:1209
 #, c-format
-msgid "Sparse PCG -- iteration %i error  %g\n"
+msgid "Different number of areas detected (%d, %d)"
 msgstr ""
-#: ../lib/gmath/solvers_krylov.c:264
-#, c-format
-msgid "PCG -- iteration %i error  %g\n"
+#: ../lib/vector/Vlib/open_pg.c:1380
+msgid "To be implemented: isles not attached in Topo-Geo-only mode"
 msgstr ""
-#: ../lib/gmath/solvers_krylov.c:490
+#: ../lib/vector/Vlib/open_pg.c:1485 ../lib/vector/Vlib/build_pg.c:212
 #, c-format
-msgid "Sparse CG -- iteration %i error  %g\n"
+msgid "Inconsistency in topology: number of nodes %d (should be %d)"
 msgstr ""
-#: ../lib/gmath/solvers_krylov.c:492
+#: ../lib/vector/Vlib/open_pg.c:1569
 #, c-format
-msgid "CG -- iteration %i error  %g\n"
+msgid "Inconsistency in topology: number of points %d (should be %d)"
 msgstr ""
-#: ../lib/gmath/solvers_krylov.c:695
+#: ../lib/vector/Vlib/open_pg.c:1614
 #, c-format
-msgid "Sparse BiCGStab -- iteration %i error  %g\n"
+msgid "Inconsistency in topology: number of lines %d (should be %d)"
 msgstr ""
-#: ../lib/gmath/solvers_krylov.c:698
+#: ../lib/vector/Vlib/open_pg.c:1668
 #, c-format
-msgid "BiCGStab -- iteration %i error  %g\n"
+msgid "Inconsistency in topology: number of centroids %d (should be %d)"
 msgstr ""
-#: ../lib/rst/interp_float/interp2d.c:232
+#: ../lib/vector/Vlib/remove_duplicates.c:199
 #, c-format
-msgid "Overshoot - increase in tension suggested. Overshoot occurs at (%d,%d) cell. Z-value %f, zmin %f, zmax %f."
+msgid "Removed duplicates: %d"
 msgstr ""
-#: ../lib/rst/interp_float/segmen2d_parallel.c:109
-msgid "Starting parallel work"
+#: ../lib/vector/Vlib/buffer2.c:361
+msgid "Line is not looped"
 msgstr ""
-#: ../lib/rst/interp_float/segmen2d_parallel.c:188
-#: ../lib/rst/interp_float/segmen2d.c:133
-msgid "Taking too long to find points for interpolation - please change the region to area where your points are. Continuing calculations..."
-msgstr ""
-#: ../lib/rst/interp_float/input2d.c:58
+#: ../lib/vector/Vlib/buffer2.c:443
 #, c-format
-msgid "Mask raster map <%s> not found"
+msgid "Unexpected result of line_intersection() res = %d"
 msgstr ""
-#: ../lib/rst/interp_float/input2d.c:81
-msgid "Bitmap mask created"
+#: ../lib/vector/Vlib/buffer2.c:589
+msgid ""
+"Next edge was visited (right) but it is not the first one !!! breaking loop"
 msgstr ""
-#: ../lib/rst/interp_float/resout2d.c:77
-msgid "Temporarily changing the region to desired resolution..."
+#: ../lib/vector/Vlib/buffer2.c:600
+msgid ""
+"Next edge was visited (left) but it is not the first one !!! breaking loop"
 msgstr ""
-#: ../lib/rst/interp_float/resout2d.c:103
-#, c-format
-msgid "First change your rows number(%d) to %d"
+#: ../lib/vector/Vlib/buffer2.c:648
+msgid "side != 0 feature not implemented"
 msgstr ""
-#: ../lib/rst/interp_float/resout2d.c:110
-#, c-format
-msgid "First change your columns number(%d) to %d"
+#: ../lib/vector/Vlib/buffer2.c:890 ../lib/vector/Vlib/buffer2.c:937
+msgid "zero area size"
 msgstr ""
-#: ../lib/rst/interp_float/resout2d.c:264
-msgid "No color table for input raster map -- will not create color table"
-msgstr ""
+#: ../lib/vector/Vlib/buffer2.c:896 ../lib/vector/Vlib/buffer2.c:943
+msgid "Line was not closed"
+msgstr "Līnija netika noslēgta"
-#: ../lib/rst/interp_float/resout2d.c:458
-msgid "Changing the region back to initial..."
+#: ../lib/vector/Vlib/buffer2.c:909 ../lib/vector/Vlib/buffer2.c:960
+msgid "Vect_get_point_in_poly() failed"
 msgstr ""
-#: ../lib/rst/interp_float/write2d.c:53 ../lib/rst/interp_float/write2d.c:64
-#: ../lib/rst/interp_float/write2d.c:79 ../lib/rst/interp_float/write2d.c:88
-#: ../lib/rst/interp_float/write2d.c:96 ../lib/rst/interp_float/write2d.c:104
-msgid "Cannot write files"
-msgstr ""
-#: ../lib/rst/interp_float/vinput2d.c:94
+#: ../lib/vector/Vlib/close.c:91
 #, c-format
-msgid "Vector map <%s> is not 3D"
+msgid "Unable to create vector map <%s>"
 msgstr ""
-#: ../lib/rst/interp_float/vinput2d.c:97
-msgid "Loading data from attribute table ..."
+#: ../lib/vector/Vlib/close.c:108
+msgid "Copying features failed"
 msgstr ""
-#: ../lib/rst/interp_float/vinput2d.c:100 ../lib/vector/Vlib/array.c:276
-#: ../lib/vector/Vlib/copy.c:622 ../lib/vector/Vlib/copy.c:732
-#: ../lib/vector/Vlib/map.c:300 ../lib/vector/Vlib/map.c:436
-#: ../lib/vector/Vlib/net_build.c:159 ../lib/vector/Vlib/net_build.c:206
-#: ../lib/vector/Vlib/net_build.c:490 ../lib/vector/Vlib/net_build.c:791
-#: ../lib/vector/Vlib/net_build.c:971 ../lib/vector/Vlib/cats.c:589
-#: ../lib/vector/Vlib/ascii.c:398 ../lib/ogsf/gp3.c:202 ../lib/ogsf/gv3.c:344
+#: ../lib/vector/Vlib/close.c:141
 #, c-format
-msgid "Database connection not defined for layer %d"
-msgstr "Slānim %d nav definēts savienojums ar datu bāzi"
-#: ../lib/rst/interp_float/vinput2d.c:109 ../lib/vector/Vlib/array.c:282
-#: ../lib/vector/Vlib/close_nat.c:160 ../lib/vector/Vlib/write_pg.c:2915
-#: ../lib/vector/Vlib/map.c:341 ../lib/vector/Vlib/net_build.c:165
-#: ../lib/vector/Vlib/net_build.c:211 ../lib/vector/Vlib/net_build.c:496
-#: ../lib/vector/Vlib/net_build.c:797 ../lib/vector/Vlib/net_build.c:976
-#: ../lib/vector/Vlib/cats.c:597 ../lib/vector/Vlib/ascii.c:410
-#: ../lib/vector/Vlib/write_ogr.c:197 ../lib/vector/neta/timetables.c:133
-#: ../lib/vector/neta/utils.c:119 ../lib/db/dbmi_client/db.c:46
-#: ../lib/db/dbmi_client/copy_tab.c:112 ../lib/db/dbmi_client/copy_tab.c:133
-#: ../lib/ogsf/gp3.c:208 ../lib/ogsf/gv3.c:350
-#, c-format
-msgid "Unable to open database <%s> by driver <%s>"
-msgstr "Nav iespējams atvērt datu bāzi <%s> izmantojot <%s> dzinēju"
-#: ../lib/rst/interp_float/vinput2d.c:115
-#: ../lib/rst/interp_float/vinput2d.c:129 ../lib/db/dbmi_client/copy_tab.c:291
-#, c-format
-msgid "Column <%s> not found"
+msgid "Unable to open %s file"
 msgstr ""
-#: ../lib/rst/interp_float/vinput2d.c:118
-#: ../lib/rst/interp_float/vinput2d.c:131
+#: ../lib/vector/Vlib/close.c:226
 #, c-format
-msgid "Data type of column <%s> must be numeric"
+msgid "Unable to close vector <%s>"
 msgstr ""
-#: ../lib/rst/interp_float/vinput2d.c:142
-msgid "Reading features from vector map ..."
-msgstr ""
-#: ../lib/rst/interp_float/vinput2d.c:174
+#: ../lib/vector/Vlib/close.c:257
 #, c-format
-msgid "Database record for cat %d not found"
+msgid "Invalid request for writing frmt file - map format is %d"
 msgstr ""
-#: ../lib/rst/interp_float/vinput2d.c:192
-msgid "Negative value of smoothing detected: sm must be >= 0"
-msgstr ""
-#: ../lib/rst/interp_float/vinput2d.c:256
-msgid "Strip exists with insufficient data"
-msgstr ""
-#: ../lib/rst/interp_float/vinput2d.c:270
+#: ../lib/vector/Vlib/close.c:289
 #, c-format
-msgid "There are points outside specified 2D/3D region - %d points ignored"
+msgid "Link to vector map <%s> created"
 msgstr ""
-#: ../lib/rst/interp_float/vinput2d.c:273
-#, c-format
-msgid "Ignoring %d points (too dense)"
+#: ../lib/vector/Vlib/graph.c:138
+msgid "Unable to add network arc"
 msgstr ""
-#: ../lib/rst/interp_float/vinput2d.c:277
+#: ../lib/vector/Vlib/level_two.c:23
 #, c-format
-msgid "%d points given for interpolation (after thinning) is less than given NPMIN=%d"
+msgid "Vector map <%s> is not open at topological level"
 msgstr ""
-#: ../lib/rst/interp_float/vinput2d.c:282
-msgid "Zero points in the given region"
-msgstr ""
-#: ../lib/rst/interp_float/vinput2d.c:287
+#: ../lib/vector/Vlib/level_two.c:284
 #, c-format
-msgid "Segmentation parameters set to invalid values: npmin= %d, segmax= %d for smooth connection of segments, npmin > segmax (see manual)"
-msgstr ""
+msgid "Invalid node id: %d"
+msgstr "Nederīgs mezgla ID: %d"
-#: ../lib/rst/interp_float/vinput2d.c:293
+#: ../lib/vector/Vlib/level_two.c:316
 #, c-format
-msgid "There are less than %d points for interpolation. No segmentation is necessary, to run the program faster set segmax=%d (see manual)"
-msgstr ""
+msgid "Nodes not available for line %d"
+msgstr "%d līnijas mezgli nav pieejami"
-#: ../lib/rst/interp_float/vinput2d.c:297
+#: ../lib/vector/Vlib/level_two.c:357
 #, c-format
-msgid "Number of points from vector map %d"
+msgid "Areas not available for line %d"
 msgstr ""
-#: ../lib/rst/interp_float/vinput2d.c:298
+#: ../lib/vector/Vlib/level_two.c:362
 #, c-format
-msgid "Number of points outside of 2D/3D region %d"
-msgstr ""
+msgid "Line %d is not a boundary"
+msgstr "%d līnija nav robeža"
-#: ../lib/rst/interp_float/vinput2d.c:300
+#: ../lib/vector/Vlib/level_two.c:445
 #, c-format
-msgid "Number of points being used %d"
+msgid "Topology info not available for feature %d"
 msgstr ""
-#: ../lib/rst/interp_float/vinput2d.c:333
-msgid "Some points outside of region (ignored)"
+#: ../lib/vector/Vlib/area.c:50
+msgid "Attempt to read points of nonexistent area"
 msgstr ""
-#: ../lib/rst/interp_float/vinput2d.c:339
-msgid "Unable to allocate memory"
+#: ../lib/vector/Vlib/area.c:81
+msgid "Attempt to read points of nonexistent isle"
 msgstr ""
-#: ../lib/rst/interp_float/vinput2d.c:347
+#: ../lib/vector/Vlib/area.c:121 ../lib/vector/Vlib/area.c:153
+#: ../lib/vector/Vlib/area.c:219 ../lib/vector/Vlib/area.c:248
 #, c-format
-msgid "Unable to insert %f,%f,%f a = %d"
+msgid "Attempt to read topo for dead area (%d)"
 msgstr ""
-#: ../lib/rst/interp_float/output2d.c:117
+#: ../lib/vector/Vlib/area.c:189 ../lib/vector/Vlib/area.c:275
 #, c-format
-msgid "First change your rows number to nsizr! %d %d"
+msgid "Attempt to read topo for dead isle (%d)"
 msgstr ""
-#: ../lib/rst/interp_float/output2d.c:124
+#: ../lib/vector/Vlib/open_nat.c:56
 #, c-format
-msgid "First change your cols number to nsizc %d %d"
+msgid "Unable to open coor file for vector map <%s>"
 msgstr ""
-#: ../lib/htmldriver/graph_set.c:97
+#: ../lib/vector/Vlib/open_nat.c:152
 #, c-format
-msgid "html: collecting to file '%s'"
-msgstr "html: apvieno failā '%s'"
+msgid ""
+"Coor file of vector map <%s@%s> is larger than it should be (%ld bytes "
+"excess)"
+msgstr ""
-#: ../lib/htmldriver/graph_set.c:98
+#: ../lib/vector/Vlib/open_nat.c:156
 #, c-format
-msgid "html: image size %dx%d"
-msgstr "html: attēla izmērs %dx%d"
-#: ../lib/htmldriver/graph_set.c:111 ../lib/htmldriver/graph_set.c:115
-#: ../lib/htmldriver/graph_set.c:119
-#, c-format
-msgid "html: type '%s'"
-msgstr "html: tips '%s'"
-#: ../lib/pngdriver/graph_set.c:101
-#, c-format
-msgid "png: truecolor status %s"
+msgid ""
+"Coor file of vector <%s@%s> is shorter than it should be (%ld bytes missing)."
 msgstr ""
-#: ../lib/pngdriver/graph_set.c:149
+#: ../lib/vector/Vlib/read_sfa.c:90
 #, c-format
-msgid "png: collecting to file '%s'"
+msgid "Unable to construct centroid for area %d. Skipped."
 msgstr ""
-#: ../lib/pngdriver/graph_set.c:150
+#: ../lib/vector/Vlib/read_sfa.c:95
 #, c-format
-msgid "png: image size %dx%d"
+msgid "Centroid %d: invalid area %d"
 msgstr ""
-#: ../lib/pngdriver/read_png.c:42
-msgid "Unable to read PNG"
-msgstr "Nevar nolasīt PNG"
-#: ../lib/pngdriver/read_png.c:60
-msgid "Unable allocate PNG structure"
+#: ../lib/vector/Vlib/read_sfa.c:124 ../lib/vector/Vlib/write_sfa.c:131
+#: ../lib/vector/Vlib/write_sfa.c:173 ../lib/vector/Vlib/write_sfa.c:273
+msgid "GRASS is not compiled with OGR/PostgreSQL support"
 msgstr ""
-#: ../lib/pngdriver/read_png.c:64 ../lib/pngdriver/write_png.c:71
-#: ../lib/pngdriver/write_png.c:75
-msgid "Unable to allocate PNG structure"
+#: ../lib/vector/Vlib/break_polygons.c:102
+msgid "Break polygons: Bug in binary tree!"
 msgstr ""
-#: ../lib/pngdriver/read_png.c:67
-msgid "Unable to read PNG file"
+#: ../lib/vector/Vlib/break_polygons.c:156
+#: ../lib/vector/Vlib/break_polygons.c:435
+msgid "Breaking polygons (pass 1: select break points)..."
 msgstr ""
-#: ../lib/pngdriver/read_png.c:81
-msgid "Input PNG file is not 8-bit"
+#: ../lib/vector/Vlib/break_polygons.c:286
+#: ../lib/vector/Vlib/break_polygons.c:552
+msgid "Breaking polygons (pass 2: break at selected points)..."
 msgstr ""
-#: ../lib/pngdriver/read_png.c:85
+#: ../lib/vector/Vlib/break_polygons.c:398
+#: ../lib/vector/Vlib/break_polygons.c:650
 #, c-format
-msgid "Input PNG file has incorrect dimensions: expected: %dx%d got: %lux%lu"
+msgid "Breaks: %d"
 msgstr ""
-#: ../lib/pngdriver/read_png.c:90
-msgid "Input PNG file is not RGBA"
+#: ../lib/vector/Vlib/break_polygons.c:592
+msgid "Point not in search tree!"
 msgstr ""
-#: ../lib/pngdriver/read_png.c:94
-msgid "Input PNG file is not indexed color"
-msgstr ""
+#: ../lib/vector/Vlib/net_build.c:101 ../lib/vector/Vlib/net_build.c:727
+msgid "Building graph..."
+msgstr "Tiek veidots grafs..."
-#: ../lib/pngdriver/read_png.c:104
-msgid "Input PNG file has invalid palette"
-msgstr ""
+#: ../lib/vector/Vlib/net_build.c:143 ../lib/vector/Vlib/net_build.c:775
+msgid "Unable to build network graph"
+msgstr "Nav iespējams izveidot tīkla grafu"
-#: ../lib/pngdriver/write_png.c:39
-msgid "Unable to write PNG"
+#: ../lib/vector/Vlib/net_build.c:149 ../lib/vector/Vlib/net_build.c:781
+msgid "Forward costs column not specified"
 msgstr ""
-#: ../lib/pngdriver/write_png.c:78
-msgid "Unable to write PNG file"
+#: ../lib/vector/Vlib/net_build.c:156
+msgid "Turntable field < 1"
 msgstr ""
-#: ../lib/pngdriver/write_png.c:82
+#: ../lib/vector/Vlib/net_build.c:172
 #, c-format
-msgid "Unable to open output PNG file <%s>"
+msgid "Turntable column <%s> not found in table <%s>"
 msgstr ""
-#: ../lib/temporal/lib/default_name.c:69
-msgid "Programmer error - only SQLite driver is currently supported"
-msgstr ""
-#: ../lib/temporal/lib/connect.c:110
+#: ../lib/vector/Vlib/net_build.c:182 ../lib/vector/Vlib/net_build.c:223
+#: ../lib/vector/Vlib/net_build.c:508 ../lib/vector/Vlib/net_build.c:526
+#: ../lib/vector/Vlib/net_build.c:809 ../lib/vector/Vlib/net_build.c:827
+#: ../lib/vector/Vlib/net_build.c:988
 #, c-format
-msgid "Mapset <%s> does not exist."
+msgid "Data type of column <%s> not supported (must be numeric)"
 msgstr ""
-#: ../lib/raster3d/test/test_main.c:96
-msgid "raster3d"
+#: ../lib/vector/Vlib/net_build.c:202 ../lib/vector/Vlib/net_build.c:967
+msgid "Setting node costs..."
 msgstr ""
-#: ../lib/raster3d/test/test_main.c:97
-#, fuzzy
-msgid "unit test"
-msgstr "vienības"
-#: ../lib/raster3d/close.c:47
+#: ../lib/vector/Vlib/net_build.c:277 ../lib/vector/Vlib/net_build.c:1032
 #, c-format
-msgid "Unable to write history for 3D raster map <%s>"
+msgid "Database record for node %d (cat = %d) not found (cost set to 0)"
 msgstr ""
-#: ../lib/raster3d/close.c:62
-#, c-format
-msgid "Unable to move temp raster map <%s> to 3D raster map <%s>"
+#: ../lib/vector/Vlib/net_build.c:332 ../lib/vector/Vlib/net_build.c:352
+msgid "Cannot add network arc for virtual node connection."
 msgstr ""
-#: ../lib/raster3d/close.c:79
-msgid "Unable to flush all tiles"
+#: ../lib/vector/Vlib/net_build.c:364
+#, c-format
+msgid ""
+"There exists more than one point of node <%d> with unique category field  <"
+"%d>.\n"
+"The unique categories layer is not valid therefore you will probably get "
+"incorrect results."
 msgstr ""
-#: ../lib/raster3d/close.c:84
-msgid "Unable to flush index"
-msgstr ""
-#: ../lib/raster3d/close.c:94
-msgid "Unable to position file"
-msgstr ""
-#: ../lib/raster3d/close.c:99 ../lib/raster3d/close.c:105
-#: ../lib/raster3d/close.c:191 ../lib/raster3d/header.c:217
+#: ../lib/vector/Vlib/net_build.c:393
 #, c-format
-msgid "Unable to write header for 3D raster map <%s>"
+msgid ""
+"Unable to find point representing intersection <%d> in unique categories "
+"field <%d>.\n"
+"Cost for the intersection was set to 0.\n"
 msgstr ""
-#: ../lib/raster3d/close.c:110 ../lib/raster3d/close.c:153
+#: ../lib/vector/Vlib/net_build.c:407
 #, c-format
-msgid "Unable to create 3D raster map <%s>"
+msgid ""
+"Unable to find node for point representing intersection <%d> in unique "
+"categories field <%d>.\n"
 msgstr ""
-#: ../lib/raster3d/close.c:169
-msgid "Error in cache"
-msgstr ""
-#: ../lib/raster3d/history.c:43
+#: ../lib/vector/Vlib/net_build.c:432
 #, c-format
-msgid "can't get history information for [%s] in mapset [%s]"
-msgstr "nevar iegūt vēstures informāciju priekš [%s] no karšu kopas [%s]"
-#: ../lib/raster3d/open.c:20
-msgid "Rast3d_open_cell_old_no_header: error in Rast3d_mask_open_old"
-msgstr "Nav iespējams izveidot vektoru karti <%s>. Nosaukums nav SQL savietojams"
-#: ../lib/raster3d/open.c:26
-msgid "Rast3d_open_cell_old_no_header: error in Rast3d_malloc"
+msgid ""
+"Database record for turn with cat = %d in not found. (The turn was skipped."
 msgstr ""
-#: ../lib/raster3d/open.c:37
-msgid "Rast3d_open_cell_old_no_header: error in G_open_old"
+#: ../lib/vector/Vlib/net_build.c:465
+msgid "Cannot add network arc representing turn."
 msgstr ""
-#: ../lib/raster3d/open.c:93
-msgid "Rast3d_open_cell_old: error in Rast3d_open_cell_old_no_header"
+#: ../lib/vector/Vlib/net_build.c:487 ../lib/vector/Vlib/net_build.c:788
+msgid "Arc field < 1"
 msgstr ""
-#: ../lib/raster3d/open.c:98
-msgid "Rast3d_open_cell_old: can't rewind file"
+#: ../lib/vector/Vlib/net_build.c:539 ../lib/vector/Vlib/net_build.c:840
+msgid "Registering arcs..."
 msgstr ""
-#: ../lib/raster3d/open.c:111
-msgid "Rast3d_open_cell_old: error in Rast3d_read_header"
+#: ../lib/vector/Vlib/net_build.c:558
+#, c-format
+msgid ""
+"Line with id <%d> has more unique categories defined in field <%d>.\n"
 msgstr ""
-#: ../lib/raster3d/open.c:119
-msgid "Rast3d_open_cell_old: projection does not match window projection"
+#: ../lib/vector/Vlib/net_build.c:579
+#, c-format
+msgid ""
+"Database record for line %d (cat = %d, forward/both direction(s)) not found "
+"(cost was set to 0)"
 msgstr ""
-#: ../lib/raster3d/open.c:123
-msgid "Rast3d_open_cell_old: zone does not match window zone"
+#: ../lib/vector/Vlib/net_build.c:596
+#, c-format
+msgid ""
+"Database record for line %d (cat = %d, backword direction) not found(cost "
+"was set to 0)"
 msgstr ""
-#: ../lib/raster3d/open.c:135 ../lib/raster3d/open.c:152
-msgid "Rast3d_open_cell_old: can't read header"
+#: ../lib/vector/Vlib/net_build.c:658 ../lib/vector/Vlib/net_build.c:1064
+msgid "Flattening the graph..."
 msgstr ""
-#: ../lib/raster3d/open.c:141
-msgid "Rast3d_open_cell_old: index does not fit into long"
-msgstr ""
+#: ../lib/vector/Vlib/net_build.c:667 ../lib/vector/Vlib/net_build.c:1073
+msgid "Graph was built"
+msgstr "Grafs ir izveidots"
-#: ../lib/raster3d/open.c:145
-msgid "Rast3d_open_cell_old: error in Rast3d_malloc"
-msgstr ""
-#: ../lib/raster3d/open.c:172
-msgid "Rast3d_open_cell_old: error in Rast3d_fill_header"
-msgstr ""
-#: ../lib/raster3d/open.c:219
-msgid "Rast3d_open_cell_new: error in Rast3d_mask_open_old"
-msgstr ""
-#: ../lib/raster3d/open.c:228
-msgid "Rast3d_open_cell_new: error in Rast3d_malloc"
-msgstr ""
-#: ../lib/raster3d/open.c:233
+#: ../lib/vector/Vlib/net_build.c:869
 #, c-format
-msgid "map <%s> is not in the current mapset"
-msgstr "karte <%s> neatrodas šī brīža karšu kopā"
-#: ../lib/raster3d/open.c:243
-msgid "Rast3d_open_cell_new: could not open file"
+msgid ""
+"(forward/both direction(s) of line skipped)"
 msgstr ""
-#: ../lib/raster3d/open.c:287 ../lib/raster3d/open.c:292
-msgid "Rast3d_open_cell_new: can't write header"
-msgstr ""
-#: ../lib/raster3d/open.c:314
-msgid "Rast3d_open_cell_new: error in Rast3d_fill_header"
-msgstr ""
-#: ../lib/raster3d/color.c:354
+#: ../lib/vector/Vlib/net_build.c:888
 #, c-format
-msgid "mapset <%s> is not the current mapset"
-msgstr "karšu kopa <%s> nav aktīvā karšu kopa"
-#: ../lib/raster3d/maskfn.c:77
-#, c-format
-msgid "Adding rule: %lf - %lf"
+msgid ""
+"Database record for line %d (cat = %d, backword direction) not "
+"found(direction of line skipped)"
 msgstr ""
-#: ../lib/raster3d/maskfn.c:95
-#, c-format
-msgid "%s: illegal value spec"
+#: ../lib/vector/Vlib/net_build.c:937
+msgid "Cannot add network arc"
 msgstr ""
-#: ../lib/raster3d/range.c:73
-#, c-format
-msgid "Unable to open range file for [%s in %s]"
-msgstr "Neiespējami atvērt failu %s iekš %s"
+#: ../lib/vector/Vlib/build_nat.c:129
+msgid "Building areas..."
+msgstr "Veido poligonus..."
-#: ../lib/raster3d/range.c:88
+#: ../lib/vector/Vlib/build_nat.c:153
 #, c-format
-msgid "Error reading range file for [%s in %s]"
-msgstr "Nederīgs diapazona fails priekš [%s iekš %s]"
+msgid "One area built"
+msgid_plural "%d areas built"
+msgstr[0] "Izveidots %d laukums"
+msgstr[1] "Izveidoti %d laukumi"
+msgstr[2] "Izveidots %d laukumu"
-#: ../lib/raster3d/range.c:150
+#: ../lib/vector/Vlib/build_nat.c:154
 #, c-format
-msgid "Unable to open range file for <%s>"
-msgstr "Nevar atvērt diapazona failu priekš <%s>"
+msgid "One isle built"
+msgid_plural "%d isles built"
+msgstr[0] "Izveidota %d sala"
+msgstr[1] "Izveidotas %d salas"
+msgstr[2] "Izveidots %d salu"
-#: ../lib/raster3d/param.c:84
-msgid "Rast3d_get_standard3d_params: precision value invalid"
-msgstr ""
+#: ../lib/vector/Vlib/build_nat.c:163
+msgid "Attaching islands..."
+msgstr "Pievieno salas..."
-#: ../lib/raster3d/param.c:105
-msgid "Rast3d_get_standard3d_params: tile dimension value invalid"
-msgstr ""
+#: ../lib/vector/Vlib/build_nat.c:180
+msgid "Attaching centroids..."
+msgstr "Pievieno centroīdus..."
-#: ../lib/raster3d/param.c:129
-msgid "Window replacing the default"
-msgstr "Logs aizvieto noklusēto"
-#: ../lib/raster/put_cellhd.c:34
+#: ../lib/vector/Vlib/header.c:86
 #, c-format
-msgid "Unable to create header file for <%s>"
+msgid "Unable to create header file for vector map <%s>"
 msgstr ""
-#: ../lib/raster/quant_rw.c:88
+#: ../lib/vector/Vlib/header.c:129
 #, c-format
-msgid "Unable to read fp range for raster map <%s>"
+msgid "Unable to open header file of vector <%s>"
 msgstr ""
-#: ../lib/raster/quant_rw.c:92
+#: ../lib/vector/Vlib/header.c:137
 #, c-format
-msgid "Raster map <%s> is empty"
+msgid "Corrupted row in head: %s"
 msgstr ""
-#: ../lib/raster/quant_rw.c:157
+#: ../lib/vector/Vlib/header.c:175
 #, c-format
-msgid "Unable to write quant rules: raster map <%s> is integer"
+msgid "Unknown keyword '%s' in vector head"
 msgstr ""
-#: ../lib/raster/quant_rw.c:166
-#, c-format
-msgid "Unable to write quant rules for raster map <%s>"
-msgstr ""
+#: ../lib/vector/Vlib/header.c:552 ../lib/gis/proj3.c:121
+msgid "Unknown projection"
+msgstr "Nezināma projekcija"
-#: ../lib/raster/reclass.c:168
-#, c-format
-msgid "Too many reclass categories for <%s@%s>"
-msgstr "Pārāk daudz pārklasificēšanas kategorijas priekš <%s@%s>"
-#: ../lib/raster/reclass.c:171
-#, c-format
-msgid "Illegal reclass format in header file for <%s@%s>"
+#: ../lib/vector/Vlib/write_sfa.c:117
+msgid "Unable to calculate centroid for area"
 msgstr ""
-#: ../lib/raster/reclass.c:273
-msgid "Illegal reclass request"
-msgstr "Netļauts pārklasificēšanas pieprasījums"
+#: ../lib/vector/Vlib/write_sfa.c:219
+msgid "Attempt to delete dead feature"
+msgstr "Mēģinājums dzēst mirušu objektu"
-#: ../lib/raster/reclass.c:278
-msgid "Illegal reclass type"
-msgstr "Netļauts klases tips"
-#: ../lib/raster/reclass.c:284
+#: ../lib/vector/Vlib/write_sfa.c:311
 #, c-format
-msgid "Unable to create header file for <%s@%s>"
-msgstr ""
+msgid "Unsupported vector map format (%d)"
+msgstr "Neatbalstīts vektoru kartes formāts (%d)"
-#: ../lib/raster/reclass.c:332
+#: ../lib/vector/Vlib/color_write.c:71 ../lib/raster/color_write.c:81
 #, c-format
-msgid "Unable to create dependency file in <%s@%s>"
-msgstr "Niespējami izveidot atkarību failu <%s@%s>"
-#: ../lib/raster/close.c:77 ../lib/raster/close.c:110
-#, c-format
-msgid "Invalid descriptor: %d"
-msgstr "Nepareizs deskriptors: %d"
-#: ../lib/raster/close.c:391 ../lib/raster/close.c:519
-#, c-format
-msgid "Unable to rename null file '%s' to '%s': %s"
+msgid "Qualified name <%s> doesn't match mapset <%s>"
 msgstr ""
-#: ../lib/raster/close.c:461
+#: ../lib/vector/Vlib/color_write.c:91 ../lib/raster/color_write.c:96
 #, c-format
-msgid "Unable to rename cell file '%s' to '%s': %s"
+msgid "Unable to create <%s> file for map <%s>"
 msgstr ""
-#: ../lib/raster/close.c:541
-msgid "unable to write f_format file for CELL maps"
+#: ../lib/vector/Vlib/build_pg.c:88
+msgid "No DB connection"
 msgstr ""
-#: ../lib/raster/color_write.c:81 ../lib/vector/Vlib/color_write.c:71
+#: ../lib/vector/Vlib/build_pg.c:93 ../lib/vector/Vlib/build_ogr.c:87
 #, c-format
-msgid "Qualified name <%s> doesn't match mapset <%s>"
+msgid "Feature table <%s> has no primary key defined"
 msgstr ""
-#: ../lib/raster/color_write.c:96 ../lib/vector/Vlib/color_write.c:91
-#, c-format
-msgid "Unable to create <%s> file for map <%s>"
+#: ../lib/vector/Vlib/build_pg.c:95
+msgid "Random read is not supported for this layer. Unable to build topology."
 msgstr ""
-#: ../lib/raster/color_rand.c:33
+#: ../lib/vector/Vlib/build_pg.c:101 ../lib/vector/Vlib/build_ogr.c:95
 #, c-format
-msgid "Rast_make_random_colors: min (%d) > max (%d)"
+msgid "Using external data format '%s' (feature type '%s')"
 msgstr ""
-#: ../lib/raster/histogram.c:55
-#, c-format
-msgid "Histogram for [%s in %s] missing (run r.support)"
-msgstr "Histogramma preikš [%s iekš %s] pietrūkst (palaist r.support)"
-#: ../lib/raster/histogram.c:62
-#, c-format
-msgid "Can't read histogram for [%s in %s]"
-msgstr "Nevar nolasīt histogrammu priekš [%s no %s]"
-#: ../lib/raster/histogram.c:66 ../lib/raster/histogram.c:73
-#, c-format
-msgid "Invalid histogram file for [%s in %s]"
-msgstr "Nederīgs histogrammas fails priekš [%s iekš %s]"
-#: ../lib/raster/histogram.c:331
-#, c-format
-msgid "Unable to create histogram file for <%s>"
+#: ../lib/vector/Vlib/build_pg.c:105
+msgid "Building pseudo-topology over simple features..."
 msgstr ""
-#: ../lib/raster/alloc_cell.c:151
+#: ../lib/vector/Vlib/build_pg.c:107
 #, c-format
-msgid "Rast__null_bitstream_size: cols (%d) is negative"
+msgid "Building topology from PostGIS topology schema <%s>..."
 msgstr ""
-#: ../lib/raster/history.c:115 ../lib/raster/history.c:123
-#, c-format
-msgid "Unable to get history information for <%s@%s>"
+#: ../lib/vector/Vlib/build_pg.c:237
+msgid "Cleaning-up topology schema..."
 msgstr ""
-#: ../lib/raster/history.c:162
-#, c-format
-msgid "Unable to write history information for <%s>"
+#: ../lib/vector/Vlib/build_pg.c:282
+msgid "Updating faces..."
 msgstr ""
-#: ../lib/raster/history.c:235
-#, c-format
-msgid "generated by %s"
-msgstr "ģenerēts ar %s"
-#: ../lib/raster/interp.c:211
-#, c-format
-msgid "Unknown interpolation method: %s"
-msgstr "Nezināma interpolācijas metode: %s"
-#: ../lib/raster/color_read.c:103
-msgid "missing"
-msgstr "iztrūkst"
-#: ../lib/raster/color_read.c:106
-msgid "invalid"
-msgstr "nederīgs"
-#: ../lib/raster/color_read.c:112
-#, c-format
-msgid "Color support for <%s@%s> %s"
-msgstr "Krāsu atbalsts priekš <%s@%s> %s"
-#: ../lib/raster/window.c:31
-msgid "Internal error: Rast_get_window() called with split window. Use Rast_get_input_window() or Rast_get_output_window() instead."
+#: ../lib/vector/Vlib/build_pg.c:314
+msgid "Updating edges..."
 msgstr ""
-#: ../lib/raster/window.c:90
-msgid "Internal error: Rast_window_rows() called with split window. Use Rast_input_window_rows() or Rast_output_window_rows() instead."
+#: ../lib/vector/Vlib/build_pg.c:323
+msgid "Inconsistency in topology detected. Dead line found."
 msgstr ""
-#: ../lib/raster/window.c:125
-msgid "Internal error: Rast_window_cols() called with split window. Use Rast_input_window_cols() or Rast_output_window_cols() instead."
+#: ../lib/vector/Vlib/build_pg.c:377
+msgid "Updating TopoGeometry data..."
 msgstr ""
-#: ../lib/raster/gdal.c:88
+#: ../lib/vector/Vlib/build_pg.c:462
 #, c-format
-msgid "Unable to locate symbol <%s>"
-msgstr "Nevar atrast simbolu <%s>"
-#: ../lib/raster/gdal.c:143
-msgid "Unable to load GDAL library"
-msgstr "Nevar ielādēt GDAL bibliotēku"
-#: ../lib/raster/gdal.c:373
-msgid "Unable to open GDAL file"
-msgstr "Nevar atvērt GDAL failu"
-#: ../lib/raster/gdal.c:477 ../lib/raster/open.c:599
-#, c-format
-msgid "Invalid map type <%d>"
-msgstr "Nederīgs kartes tips <%d>"
-#: ../lib/raster/gdal.c:483
-#, c-format
-msgid "Unable to get <%s> driver"
-msgstr "Nav iespējams saņemt <%s> dzinēju"
-#: ../lib/raster/gdal.c:492
-#, c-format
-msgid "Unable to create <%s> dataset using <%s> driver"
+msgid "Unsupported topo geometry type %d"
 msgstr ""
-#: ../lib/raster/gdal.c:500
+#: ../lib/vector/Vlib/build_pg.c:491
 #, c-format
-msgid "Driver <%s> does not support direct writing. Using MEM driver for intermediate dataset."
+msgid "Unable to create <%s.%s>"
 msgstr ""
-#: ../lib/raster/gdal.c:506
-msgid "Unable to get in-memory raster driver"
+#: ../lib/vector/Vlib/build_pg.c:642
+msgid "Unable to write nodes, offset array mismatch"
 msgstr ""
-#: ../lib/raster/gdal.c:513
-#, c-format
-msgid "Unable to create <%s> dataset using memory driver"
-msgstr ""
+#: ../lib/vector/Vlib/build_pg.c:671
+msgid "Unable to write nodes"
+msgstr "Nevar ierakstīt mezglus"
-#: ../lib/raster/gdal.c:517
+#: ../lib/vector/Vlib/build_pg.c:716
 #, c-format
-msgid "Driver <%s> does not support creating rasters"
+msgid "Inconsistency in topology: number of boundaries %d (should be %d)"
 msgstr ""
-#: ../lib/raster/gdal.c:533
-msgid "Unable to set geo transform"
+#: ../lib/vector/Vlib/build_pg.c:739
+msgid "Unable to write lines"
 msgstr ""
-#: ../lib/raster/gdal.c:537
-msgid "Unable to set projection"
-msgstr ""
-#: ../lib/raster/gdal.c:541
+#: ../lib/vector/Vlib/build_pg.c:790
 #, c-format
-msgid "Unable to create cell_misc/%s/gdal file"
+msgid "Topology for centroid %d not available. Area %d skipped"
 msgstr ""
-#: ../lib/raster/gdal.c:557
-#, c-format
-msgid "Error writing cell_misc/%s/gdal file"
+#: ../lib/vector/Vlib/build_pg.c:1000
+msgid "Create simple features topology from topogeometry data..."
 msgstr ""
-#: ../lib/raster/gdal.c:605
+#: ../lib/vector/Vlib/build_pg.c:1018
 #, c-format
-msgid "Unable to create output file <%s> using driver <%s>"
+msgid ""
+"Unable to build simple features from topogeometry data. Unsupported type %d."
 msgstr ""
-#: ../lib/raster/open.c:193
-#, c-format
-msgid "Unable to open raster map <%s@%s> since it is a reclass of raster map <%s@%s> which does not exist"
+#: ../lib/vector/Vlib/cats.c:45
+msgid "Vect_new_cats_struct(): Out of memory"
 msgstr ""
-#: ../lib/raster/open.c:198
+#: ../lib/vector/Vlib/cats.c:127
 #, c-format
-msgid "Error reading reclass file for raster map <%s>"
+msgid "Too many categories (%d), unable to set cat %d (layer %d)"
 msgstr ""
-#: ../lib/raster/open.c:209
+#: ../lib/vector/Vlib/cats.c:419
 #, c-format
-msgid "Error reading map type for raster map <%s>"
+msgid "Unable to convert category string '%s' (from '%s') to category range"
 msgstr ""
-#: ../lib/raster/open.c:217
-#, c-format
-msgid "Raster map <%s@%s>: format field in header file invalid"
+#: ../lib/vector/Vlib/cats.c:572 ../lib/vector/Vlib/cats.c:668
+msgid "Layer number must be > 0 for category constraints"
 msgstr ""
-#: ../lib/raster/open.c:236
+#: ../lib/vector/Vlib/cats.c:585
 #, c-format
-msgid "Compression with %s is not supported"
+msgid "'%s' and '%s' parameters were supplied, cats will be ignored"
 msgstr ""
-#: ../lib/raster/open.c:240
+#: ../lib/vector/Vlib/cats.c:593
 #, c-format
-msgid "Raster map <%s> is in different projection than current region. Found <%s>, should be <%s>."
-msgstr ""
+msgid "Loading categories from table <%s>..."
+msgstr "Ielādē kategorijas no tabulas <%s>..."
-#: ../lib/raster/open.c:247
+#: ../lib/vector/Vlib/cats.c:603 ../lib/db/dbmi_client/select.c:317
 #, c-format
-msgid "Raster map <%s> is in different zone (%d) than current region (%d)"
+msgid "Unable select records from table <%s>"
 msgstr ""
-#: ../lib/raster/open.c:252
+#: ../lib/vector/Vlib/cats.c:605
 #, c-format
-msgid "Raster map <%s>: bytes per cell (%d) too large"
-msgstr ""
+msgid "One category loaded"
+msgid_plural "%d categories loaded"
+msgstr[0] "Ielādēta %d kategorija"
+msgstr[1] "Ielādētas %d kategorijas"
+msgstr[2] "Ielādēts %d kategoriju"
-#: ../lib/raster/open.c:277
+#: ../lib/vector/Vlib/cats.c:627
 #, c-format
-msgid "Raster map <%s@%s> is a GDAL link but GRASS is compiled without GDAL support"
+msgid "No categories selected with '%s' option"
 msgstr ""
-#: ../lib/raster/open.c:285
+#: ../lib/vector/Vlib/cats.c:637
 #, c-format
-msgid "Unable to open %s file for raster map <%s@%s>"
+msgid "%d errors in '%s' option"
 msgstr ""
-#: ../lib/raster/open.c:322
-#, c-format
-msgid "Error reading format for <%s@%s>"
+#: ../lib/vector/Vlib/level.c:34
+msgid "Map structure was never initialized"
 msgstr ""
-#: ../lib/raster/open.c:527
-msgid "Unable to create GDAL link"
+#: ../lib/vector/Vlib/level.c:36
+msgid "Map structure has been closed"
 msgstr ""
-#: ../lib/raster/open.c:604 ../lib/raster/open.c:759
-#, c-format
-msgid "Raster map <%s> is not in the current mapset (%s)"
+#: ../lib/vector/Vlib/remove_areas.c:107 ../lib/vector/Vlib/remove_areas.c:268
+msgid "Area is composed of dead boundary"
 msgstr ""
-#: ../lib/raster/open.c:611
+#: ../lib/vector/Vlib/remove_areas.c:194 ../lib/vector/Vlib/remove_areas.c:602
 #, c-format
-msgid "<%s> is an illegal file name"
+msgid "%d areas of total size %g removed"
 msgstr ""
-#: ../lib/raster/open.c:626 ../lib/raster/open.c:706 ../lib/raster/open.c:782
-#, c-format
-msgid "No temp files available: %s"
+#: ../lib/vector/Vlib/remove_areas.c:395
+msgid "Could not delete line from coor"
 msgstr ""
-#: ../lib/raster/open.c:755
-#, c-format
-msgid "Raster map <%s> does not exist in the current mapset (%s)"
+#: ../lib/vector/Vlib/remove_areas.c:458
+msgid "dissolve_neighbour > 0, failed to build new area"
 msgstr ""
-#: ../lib/raster/open.c:821
-msgid "Rast_set_fp_type(): can only be called with FCELL_TYPE or DCELL_TYPE"
+#: ../lib/vector/Vlib/remove_areas.c:463 ../lib/vector/Vlib/remove_areas.c:501
+msgid "Dissolve with neighbour area: corrupt topology"
 msgstr ""
-#: ../lib/raster/open.c:879
-#, c-format
-msgid "Raster map <%s> not found in mapset <%s>"
-msgstr ""
+#: ../lib/vector/Vlib/remove_areas.c:497
+msgid "Failed to build new area"
+msgstr "Neizdevās izveidot jaunu laukumu"
-#: ../lib/raster/open.c:940
-#, c-format
-msgid "Unable to find '%s'"
-msgstr ""
+#: ../lib/vector/Vlib/remove_areas.c:544 ../lib/vector/Vlib/remove_areas.c:571
+msgid "Failed to build new isle"
+msgstr "Neizdevās izveidot jaunu salu"
-#: ../lib/raster/open.c:951
-#, c-format
-msgid "Invalid type: field '%s' in file '%s'"
+#: ../lib/vector/Vlib/remove_areas.c:549 ../lib/vector/Vlib/remove_areas.c:576
+msgid "Dissolve with outer isle: corrupt topology"
 msgstr ""
-#: ../lib/raster/open.c:956
-#, c-format
-msgid "Missing type: field in file '%s'"
-msgstr ""
+#: ../lib/vector/Vlib/remove_areas.c:581
+msgid "Area merging failed"
+msgstr "Laukumu apvienošana bija nesekmīga"
-#: ../lib/raster/open.c:961
+#: ../lib/vector/Vlib/array.c:96
 #, c-format
-msgid "Raster map <%s> is not xdr: byte_order: %s"
+msgid "%d errors in category string"
 msgstr ""
-#: ../lib/raster/open.c:1030
-msgid "Rast_set_quant_rules() can be called only for raster maps opened for reading"
+#: ../lib/vector/Vlib/array.c:142 ../lib/vector/Vlib/array.c:267
+msgid "Mixed area and other type requested for vector array"
 msgstr ""
-#: ../lib/raster/set_window.c:48
-msgid "Rast_set_window() called while window split"
+#: ../lib/vector/Vlib/array.c:152 ../lib/vector/Vlib/array.c:175
+#: ../lib/vector/Vlib/array.c:304 ../lib/vector/Vlib/array.c:336
+msgid "Not enough space in vector array"
 msgstr ""
-#: ../lib/raster/set_window.c:131
-msgid "Rast_set_read_window(): projection/zone differs from that of currently open raster maps"
+#: ../lib/vector/Vlib/array.c:292
+#, c-format
+msgid "Unable to select record from table <%s> (key %s, where %s)"
 msgstr ""
-#: ../lib/raster/set_window.c:158
+#: ../lib/vector/Vlib/write_ogr.c:129 ../lib/vector/Vlib/open_ogr.c:65
+msgid "OGR layer not defined"
+msgstr "OGR slānis nav definēts"
+#: ../lib/vector/Vlib/write_ogr.c:210 ../lib/db/dbmi_client/table.c:110
+#: ../lib/db/dbmi_client/copy_tab.c:242 ../lib/db/dbmi_client/copy_tab.c:319
 #, c-format
-msgid "Input window changed while maps are open for read. Map name <%s>"
+msgid "Unable to open select cursor: '%s'"
 msgstr ""
-#: ../lib/raster/set_window.c:174
+#: ../lib/vector/Vlib/write_ogr.c:239
 #, c-format
-msgid "Output window changed while maps are open for write. Map name <%s>"
+msgid "Creating field <%s> failed"
 msgstr ""
-#: ../lib/raster/cats.c:109
+#: ../lib/vector/Vlib/write_ogr.c:326
 #, c-format
-msgid "Category support for <%s@%s> missing"
+msgid "Unable to create OGR layer <%s> in '%s'"
 msgstr ""
-#: ../lib/raster/cats.c:112
-#, c-format
-msgid "Category support for <%s@%s> invalid"
+#: ../lib/vector/Vlib/write_ogr.c:424
+msgid "Feature is not a point. Skipping."
 msgstr ""
-#: ../lib/raster/cats.c:145
-#, c-format
-msgid "Category support for vector map <%s@%s> missing"
+#: ../lib/vector/Vlib/write_ogr.c:432
+msgid "Feature is not a line. Skipping."
 msgstr ""
-#: ../lib/raster/cats.c:149
-#, c-format
-msgid "Category support for vector map <%s@%s> invalid"
+#: ../lib/vector/Vlib/write_ogr.c:439
+msgid "Feature is not a polygon. Skipping."
 msgstr ""
-#: ../lib/raster/cats.c:968
-#, c-format
-msgid "Unable to open %s file for map <%s>"
+#: ../lib/vector/Vlib/write_ogr.c:446
+msgid "Feature is not a face. Skipping."
 msgstr ""
-#: ../lib/raster/format.c:162
+#: ../lib/vector/Vlib/write_ogr.c:452
 #, c-format
-msgid "Fail of initial read of compressed file [%s in %s]"
-msgstr "Izgāzusies arhivētā faila lasīšanas inicializācija [%s iekš %s]"
+msgid "Unsupported feature type (%d)"
+msgstr "Neatbalstīts objekta tips (%d)"
-#: ../lib/raster/format.c:176
-#, c-format
-msgid "Fail of initial read of compressed null file [%s in %s]"
+#: ../lib/vector/Vlib/write_ogr.c:471
+msgid "Boundary is not closed. Feature skipped."
 msgstr ""
-#: ../lib/raster/get_row.c:36 ../lib/raster/get_row.c:898
-#, c-format
-msgid "Reading raster map <%s@%s> request for row %d is outside region"
+#: ../lib/vector/Vlib/write_ogr.c:500
+msgid "Unable to writes feature attributes"
 msgstr ""
-#: ../lib/raster/get_row.c:95 ../lib/raster/get_row.c:137
-#: ../lib/raster/get_row.c:144 ../lib/raster/get_row.c:187
-#: ../lib/raster/get_row.c:191
+#: ../lib/vector/Vlib/write_ogr.c:565
 #, c-format
-msgid "Error reading raster data for row %d of <%s>"
+msgid "Feature without category of layer %d"
 msgstr ""
-#: ../lib/raster/get_row.c:102 ../lib/raster/get_row.c:168
+#: ../lib/vector/Vlib/write_ogr.c:624
 #, c-format
-msgid "Error uncompressing raster data for row %d of <%s>"
+msgid "Unable to create field <%s>"
 msgstr ""
-#: ../lib/raster/get_row.c:227
-#, c-format
-msgid "Error reading raster data via GDAL for row %d of <%s>"
+#: ../lib/vector/Vlib/write_nat.c:398
+msgid "Attempt to access feature with invalid id (%"
 msgstr ""
-#: ../lib/raster/get_row.c:827 ../lib/raster/get_row.c:832
-#: ../lib/raster/get_row.c:842
+#: ../lib/vector/Vlib/write_nat.c:404
 #, c-format
-msgid "Error reading null data for row %d of <%s>"
+msgid "Attempt to access alive feature %d"
 msgstr ""
-#: ../lib/raster/get_row.c:848
+#: ../lib/vector/Vlib/write_nat.c:566 ../lib/vector/Vlib/write_nat.c:602
 #, c-format
-msgid "Error uncompressing null data for row %d of <%s>"
+msgid "%s: Area %d does not exist"
 msgstr ""
-#: ../lib/raster/get_row.c:882 ../lib/raster/get_row.c:885
+#: ../lib/vector/Vlib/write_nat.c:756
 #, c-format
-msgid "Error reading null row %d for <%s>"
+msgid "Attempt to access dead area %d"
 msgstr ""
-#: ../lib/raster/color_rules.c:120
-msgid "syntax error in the color rule"
+#: ../lib/vector/Vlib/read.c:25 ../lib/vector/Vlib/write.c:30
+#: ../lib/vector/Vlib/write.c:36 ../lib/vector/Vlib/write.c:42
+#: ../lib/vector/Vlib/write.c:49
+msgid "for this format/level not supported"
 msgstr ""
-#: ../lib/raster/color_rules.c:122
-msgid "syntax error in the color format"
+#: ../lib/vector/Vlib/read.c:93 ../lib/vector/Vlib/read.c:129
+#: ../lib/vector/Vlib/read.c:168
+msgid "Vector map is not open for reading"
 msgstr ""
-#: ../lib/raster/color_rules.c:130
-msgid "percentage not in range 0-100"
-msgstr "procenti nav diapazonā 0 - 100"
-#: ../lib/raster/color_rules.c:132
-msgid "invalid value"
-msgstr "nederīga vērtība"
-#: ../lib/raster/color_rules.c:134
-msgid "unknown error"
-msgstr "nezināma kļūda"
-#: ../lib/raster/color_rules.c:180
+#: ../lib/vector/Vlib/read.c:136 ../lib/vector/Vlib/read.c:180
 #, c-format
-msgid "bad rule (%s): [%s]"
+msgid "Unable to read feature %d from vector map <%s>"
 msgstr ""
-#: ../lib/raster/color_rules.c:327
-#, c-format
-msgid "Unable to load color rules <%s>"
-msgstr "Nav iespējams ielādēt krāsu noteikumus <%s>"
-#: ../lib/raster/raster_metadata.c:109
-#, c-format
-msgid "Unable to read <%s> for raster map <%s@%s>"
+#: ../lib/vector/Vlib/read.c:200
+msgid "Line index is out of range"
 msgstr ""
-#: ../lib/raster/raster_metadata.c:119 ../lib/raster/raster_metadata.c:148
-#, c-format
-msgid "Error closing <%s> metadata file for raster map <%s@%s>"
+#: ../lib/vector/Vlib/read.c:224
+msgid "Node index is out of range"
 msgstr ""
-#: ../lib/raster/raster_metadata.c:142
-#, c-format
-msgid "Unable to create <%s> metadata file for raster map <%s@%s>"
+#: ../lib/vector/Vlib/read.c:248
+msgid "Area index is out of range"
 msgstr ""
-#: ../lib/raster/put_row.c:121
-#, c-format
-msgid "Error writing uncompressed FP data for row %d of <%s>: %s"
+#: ../lib/vector/Vlib/read.c:272
+msgid "Isle index is out of range"
 msgstr ""
-#: ../lib/raster/put_row.c:131
+#: ../lib/vector/Vlib/select.c:116
 #, c-format
-msgid "Error writing compressed FP data for row %d of <%s>: %s"
+msgid "Unable to delete item %d from spatial index"
 msgstr ""
-#: ../lib/raster/put_row.c:387 ../lib/raster/put_row.c:393
+#: ../lib/vector/Vlib/open.c:138
 #, c-format
-msgid "Error writing compressed data for row %d of <%s>"
+msgid "Programmer requested unknown access level %d"
 msgstr ""
-#: ../lib/raster/put_row.c:403
+#: ../lib/vector/Vlib/open.c:232
 #, c-format
-msgid "Error writing uncompressed data for row %d of <%s>"
-msgstr ""
+msgid "Vector map <%s> not found in current mapset"
+msgstr "Vektoru karte <%s> pašreizējā karšu kopā nav atrasta"
-#: ../lib/raster/put_row.c:462
-#, c-format
-msgid "Error writing data via GDAL for row %d of <%s>"
+#: ../lib/vector/Vlib/open.c:252
+msgid "Temporary vector maps can be accessed only in the current mapset"
 msgstr ""
-#: ../lib/raster/put_row.c:486
-msgid "GDAL output doesn't support writing null rows separately"
+#: ../lib/vector/Vlib/open.c:277
+msgid ""
+"Vector map which is not in the current mapset cannot be opened for update"
 msgstr ""
-#: ../lib/raster/put_row.c:489
+#: ../lib/vector/Vlib/open.c:301 ../lib/vector/Vlib/open.c:437
+#: ../lib/vector/Vlib/map.c:192 ../lib/vector/Vlib/map.c:202
+#: ../lib/vector/Vlib/map.c:274 ../lib/ogsf/gv3.c:66 ../lib/ogsf/gv3.c:338
+#: ../lib/ogsf/gp3.c:62 ../lib/ogsf/gp3.c:196
+#: ../lib/python/temporal/c_libraries_interface.py:747
+#, c-format, python-format
+msgid "Unable to open vector map <%s>"
+msgstr "Nav iespējams atvērt vektoru karti <%s>"
+#: ../lib/vector/Vlib/open.c:311
 #, c-format
-msgid "No null file for <%s>"
+msgid "Unable to read header file of vector map <%s>"
 msgstr ""
-#: ../lib/raster/put_row.c:513 ../lib/raster/put_row.c:518
+#: ../lib/vector/Vlib/open.c:352
 #, c-format
-msgid "Error writing compressed null data for row %d of <%s>"
+msgid "Unable to open topology file for vector map <%s>"
 msgstr ""
-#: ../lib/raster/put_row.c:552 ../lib/raster/put_row.c:555
+#: ../lib/vector/Vlib/open.c:367 ../lib/vector/Vlib/open.c:871
+#: ../lib/vector/Vlib/build.c:865
 #, c-format
-msgid "Error writing null row %d of <%s>"
+msgid "Unable to open spatial index file for vector map <%s>"
 msgstr ""
-#: ../lib/raster/put_row.c:680
+#: ../lib/vector/Vlib/open.c:419
 #, c-format
-msgid "put_raster_row: raster map <%s> not open for write - request ignored"
+msgid ""
+"Unable to open vector map <%s> on level %d. Try to rebuild vector topology "
+"with v.build."
 msgstr ""
-#: ../lib/raster/put_row.c:687
-msgid "put_raster_row: unopened file descriptor - request ignored"
+#: ../lib/vector/Vlib/open.c:445
+#, c-format
+msgid "Building topology for OGR layer <%s> from datasource '%s'..."
 msgstr ""
-#: ../lib/raster/mask_info.c:43
+#: ../lib/vector/Vlib/open.c:453
 #, c-format
-msgid "<%s> in mapset <%s>"
-msgstr "<%s>karšu kopā <%s>"
-#: ../lib/raster/mask_info.c:46
-msgid "none"
-msgstr "neviens"
-#: ../lib/raster/mask_info.c:49
-msgid "not known"
-msgstr "nav zināms"
-#: ../lib/raster/sample.c:70
-msgid "Unknown interpolation type"
+msgid "Unable to open vector map <%s> on level %d"
 msgstr ""
-#: ../lib/raster/sample.c:327
-msgid "\"no data\" label found; setting to zero"
-msgstr ""
-#: ../lib/raster/get_cellhd.c:66
+#: ../lib/vector/Vlib/open.c:507
 #, c-format
-msgid "Unable to read header file for raster map <%s@%s>. It is a reclass of raster map <%s@%s> %s"
+msgid "Unable to open history file for vector map <%s>"
 msgstr ""
-#: ../lib/raster/get_cellhd.c:70
-msgid "which is missing."
-msgstr ""
-#: ../lib/raster/get_cellhd.c:71
-msgid "whose header file can't be opened."
-msgstr ""
-#: ../lib/raster/get_cellhd.c:76
+#: ../lib/vector/Vlib/open.c:777
 #, c-format
-msgid "Unable to open header file for raster map <%s@%s>"
+msgid "Unable to create vector map: <%s> is not in the current mapset (%s)"
 msgstr ""
-#: ../lib/raster/range.c:102
+#: ../lib/vector/Vlib/open.c:786
 #, c-format
-msgid "Unable to read fp range file for <%s>"
+msgid "Unable to create vector map: <%s> is not SQL compliant"
 msgstr ""
-#: ../lib/raster/range.c:169
+#: ../lib/vector/Vlib/open.c:813 ../lib/vector/Vlib/open.c:826
+#: ../lib/vector/Vlib/map.c:159
 #, c-format
-msgid "Unable to read quant rules for raster map <%s>"
+msgid "Unable to delete vector map <%s>"
 msgstr ""
-#: ../lib/raster/range.c:206 ../lib/raster/range.c:226
+#: ../lib/vector/Vlib/open.c:821 ../lib/vector/Vlib/map.c:155
+#: ../lib/vector/Vlib/map.c:249
 #, c-format
-msgid "Unable to read range file for <%s>"
+msgid "Vector map <%s> already exists and will be overwritten"
 msgstr ""
-#: ../lib/raster/range.c:264 ../lib/raster/range.c:270
-#: ../lib/raster/range.c:300 ../lib/raster/range.c:314
+#: ../lib/vector/Vlib/open.c:846
 #, c-format
-msgid "Unable to write range file for <%s>"
+msgid "Unable to open history file of vector map <%s>"
 msgstr ""
-#: ../lib/raster/auto_mask.c:69
-msgid "Unable to open automatic MASK file"
-msgstr "Neiespējami atvērt automātisku MASK failu"
-#: ../lib/raster/put_title.c:28
+#: ../lib/vector/Vlib/open.c:887
 #, c-format
-msgid "category information for [%s] in [%s] missing or invalid"
-msgstr "kategorijas informācija priekš [%s] iekš [%s] trūkst vai ir nederīga"
-#: ../lib/raster/put_title.c:37
-msgid "G_put_title - can't create a temp file"
-msgstr "G_put_title - nevar izveidot pagaidu failu"
-#: ../lib/raster/put_title.c:53
-#, c-format
-msgid "category information for [%s] in [%s] invalid"
-msgstr "kategorijas informācija priekš [%s] iekš [%s] ir nederīga"
-#: ../lib/raster/put_title.c:60
-msgid "G_put_title - can't reopen temp file"
+msgid "Using OGR/%s format"
 msgstr ""
-#: ../lib/raster/put_title.c:67
-#, c-format
-msgid "can't write category information for [%s] in [%s]"
-msgstr "nevar ierakstīt kategorijas informāciju priekš [%s] iekš [%s]"
-#: ../lib/raster/init.c:61
-msgid "Raster library not initialized. Programmer forgot to call Rast_init()."
+#: ../lib/vector/Vlib/open.c:891
+msgid "Using PostGIS Topology format"
 msgstr ""
-#: ../lib/raster/init.c:109
-#, c-format
-msgid "Unknown compression method <%s>, using default ZLIB"
+#: ../lib/vector/Vlib/open.c:893
+msgid "Using PostGIS format"
 msgstr ""
-#: ../lib/raster/init.c:113
-msgid "No compression is not supported for GRASS raster maps, using default ZLIB"
+#: ../lib/vector/Vlib/open.c:896
+msgid "Using native format"
 msgstr ""
-#: ../lib/raster/init.c:118
+#: ../lib/vector/Vlib/open.c:985
 #, c-format
-msgid "This GRASS version does not support %s compression, using default ZLIB"
+msgid "Unable to stat file <%s>"
 msgstr ""
-#: ../lib/raster/quant_io.c:43
+#: ../lib/vector/Vlib/open.c:1049
 #, c-format
-msgid "Floating data range for raster map <%s> is empty"
+msgid "unknown %d (update Vect_maptype_info)"
 msgstr ""
-#: ../lib/raster/quant_io.c:52
-#, c-format
-msgid "Integer data range for raster map <%s> is empty"
+#: ../lib/vector/Vlib/open.c:1138
+msgid "Size of 'coor' file differs from value saved in topology file"
 msgstr ""
-#: ../lib/raster/quant_io.c:105
+#: ../lib/vector/Vlib/open.c:1149 ../lib/vector/Vlib/open.c:1248
 #, c-format
-msgid "Attempt to open quantization table for CELL raster map <%s>"
+msgid "Please rebuild topology for vector map <%s@%s>"
 msgstr ""
-#: ../lib/raster/quant_io.c:135
-#, c-format
-msgid "Quantization file for raster map <%s> is missing"
+#: ../lib/vector/Vlib/open.c:1237
+msgid "Size of 'coor' file differs from value saved in sidx file"
 msgstr ""
-#: ../lib/raster/quant_io.c:145
-#, c-format
-msgid "Quantization file for raster map <%s> is empty"
+#: ../lib/vector/Vlib/open.c:1317
+msgid "Unable to open OGR file"
 msgstr ""
-#: ../lib/raster/null_val.c:64
-msgid "EmbedGivenNulls: wrong data type"
+#: ../lib/vector/Vlib/open.c:1343
+msgid "OGR output also detected, using OGR"
 msgstr ""
-#: ../lib/raster/null_val.c:114
-msgid "Rast_set_null_value: wrong data type!"
+#: ../lib/vector/Vlib/open_ogr.c:60
+msgid "OGR datasource not defined"
 msgstr ""
-#: ../lib/display/tran_colr.c:107 ../lib/display/tran_colr.c:109
+#: ../lib/vector/Vlib/open_ogr.c:77 ../lib/vector/Vlib/field.c:690
 #, c-format
-msgid "[%s]: No such color"
+msgid "Unable to open OGR data source '%s'"
 msgstr ""
-#: ../lib/display/r_raster.c:98
+#: ../lib/vector/Vlib/open_ogr.c:97
 #, c-format
-msgid "Both %s and %s are defined. %s will be ignored."
+msgid "OGR layer <%s> not found"
 msgstr ""
-#: ../lib/display/r_raster.c:131
+#: ../lib/vector/Vlib/open_ogr.c:191
 #, c-format
-msgid "Neither %s (managed by d.mon command) nor %s (used for direct rendering) defined"
+msgid "Unable to get OGR driver <%s>"
 msgstr ""
-#: ../lib/display/r_raster.c:150
+#: ../lib/vector/Vlib/open_ogr.c:199
 #, c-format
-msgid "Unknown display driver <%s>"
+msgid "Unable to create OGR data source '%s'"
 msgstr ""
-#: ../lib/display/r_raster.c:151
+#: ../lib/vector/Vlib/open_ogr.c:211
 #, c-format
-msgid "Using display driver <%s>..."
+msgid "OGR layer <%s> already exists and will be overwritten"
 msgstr ""
-#: ../lib/display/icon.c:80
+#: ../lib/vector/Vlib/open_ogr.c:215
 #, c-format
-msgid "Unsupported icon %d"
+msgid "Unable to delete OGR layer <%s>"
 msgstr ""
-#: ../lib/vector/diglib/port_init.c:158
+#: ../lib/vector/Vlib/open_ogr.c:221
 #, c-format
-msgid "Unable to find '%x' in %s"
+msgid "OGR layer <%s> already exists in datasource '%s'"
 msgstr ""
-#: ../lib/vector/diglib/plus_area.c:215 ../lib/vector/diglib/plus_area.c:711
+#: ../lib/vector/Vlib/open_ogr.c:279
 #, c-format
-msgid "Line %d already has area/isle %d to left"
+msgid ""
+"Feature index format version %d.%d is not supported by this release. Try to "
+"rebuild topology or upgrade GRASS."
 msgstr ""
-#: ../lib/vector/diglib/plus_area.c:225 ../lib/vector/diglib/plus_area.c:719
+#: ../lib/vector/Vlib/open_ogr.c:284
 #, c-format
-msgid "Line %d already has area/isle %d to right"
+msgid ""
+"Your GRASS version does not fully support feature index format %d.%d of the "
+"vector. Consider to rebuild topology or upgrade GRASS."
 msgstr ""
-#: ../lib/vector/diglib/plus_area.c:279
-msgid "Isle already registered in area"
-msgstr ""
+#: ../lib/vector/Vlib/break_lines.c:572
+#, c-format
+msgid "Intersections: %d"
+msgstr "Krustojumi: %d"
-#: ../lib/vector/diglib/plus_area.c:313
-msgid "Attempt to delete isle from dead area"
-msgstr ""
-#: ../lib/vector/diglib/plus_area.c:330
+#: ../lib/vector/Vlib/simple_features.c:225
 #, c-format
-msgid "Attempt to delete not registered isle %d from area %d"
+msgid "Unknown Simple Features type (%d)"
 msgstr ""
-#: ../lib/vector/diglib/plus_area.c:369
-msgid "Attempt to delete dead area"
+#: ../lib/vector/Vlib/simple_features.c:332
+msgid "Unable to get number of simple features"
 msgstr ""
-#: ../lib/vector/diglib/plus_area.c:408
+#: ../lib/vector/Vlib/simple_features.c:341
 #, c-format
-msgid "Dead centroid %d registered for area (bug in the vector library)"
+msgid "Unable to report simple features for vector map <%s>"
 msgstr ""
-#: ../lib/vector/diglib/plus_area.c:431
+#: ../lib/vector/Vlib/merge_lines.c:240
 #, c-format
-msgid "Attempt to delete area %d info from dead isle %d"
+msgid "%d boundaries merged"
 msgstr ""
-#: ../lib/vector/diglib/plus_area.c:777
+#: ../lib/vector/Vlib/merge_lines.c:241
 #, c-format
-msgid "Attempt to delete isle %d info from dead area %d"
+msgid "%d new boundaries"
 msgstr ""
-#: ../lib/vector/diglib/file.c:159
-msgid "Writing to file loaded to memory not supported"
+#: ../lib/vector/Vlib/map.c:139 ../lib/vector/Vlib/map.c:245
+msgid "Vector map name is not SQL compliant"
 msgstr ""
-#: ../lib/vector/diglib/file.c:197
-msgid "Unable to load file to memory, file not open"
+#: ../lib/vector/Vlib/map.c:143
+#, c-format
+msgid "Unable to find vector map <%s> in <%s>"
 msgstr ""
-#: ../lib/vector/diglib/file.c:212
-msgid "Vector memory mode not supported, using 'AUTO'"
-msgstr ""
-#: ../lib/vector/diglib/portable.c:208 ../lib/vector/diglib/portable.c:241
-#: ../lib/vector/diglib/portable.c:683 ../lib/vector/diglib/plus_struct.c:563
-msgid "Vector exceeds supported file size limit"
-msgstr ""
-#: ../lib/vector/diglib/plus.c:222
-msgid "Unable read topology for nodes"
-msgstr ""
-#: ../lib/vector/diglib/plus.c:227
+#: ../lib/vector/Vlib/map.c:179 ../lib/vector/Vlib/map.c:267
 #, c-format
-msgid "Unable to read topology for node %d"
+msgid "Unable to copy vector map <%s> to <%s>"
 msgstr ""
-#: ../lib/vector/diglib/plus.c:232
-msgid "Unable read topology for lines"
-msgstr ""
-#: ../lib/vector/diglib/plus.c:237
+#: ../lib/vector/Vlib/map.c:331 ../lib/vector/Vlib/map.c:462
 #, c-format
-msgid "Unable to read topology for line %d"
+msgid "Unable to delete table <%s>"
 msgstr ""
-#: ../lib/vector/diglib/plus.c:242
-msgid "Unable to read topo for areas"
-msgstr ""
-#: ../lib/vector/diglib/plus.c:247
+#: ../lib/vector/Vlib/map.c:346
 #, c-format
-msgid "Unable read topology for area %d"
+msgid "Unable to create index for table <%s>, key <%s>"
 msgstr ""
-#: ../lib/vector/diglib/plus.c:252
-msgid "Unable to read topology for isles"
-msgstr ""
-#: ../lib/vector/diglib/plus.c:257
+#: ../lib/vector/Vlib/map.c:402
 #, c-format
-msgid "Unable to read topology for isle %d"
+msgid "Ignoring invalid mapset: %s"
 msgstr ""
-#: ../lib/vector/diglib/plus.c:279 ../lib/vector/diglib/plus.c:305
-msgid "Unable to write head to plus file"
-msgstr ""
-#: ../lib/vector/diglib/plus.c:284
-msgid "Unable to write nodes to plus file"
-msgstr ""
-#: ../lib/vector/diglib/plus.c:289
-msgid "Unable to write lines to plus file"
-msgstr ""
-#: ../lib/vector/diglib/plus.c:294
-msgid "Unable to write areas to plus file"
-msgstr ""
-#: ../lib/vector/diglib/plus.c:299
-msgid "Unable to write isles to plus file"
-msgstr ""
-#: ../lib/vector/diglib/cindex_rw.c:156
+#: ../lib/vector/Vlib/map.c:407
 #, c-format
-msgid "This version of GRASS (%d.%d) is too old to read this category index format. Try to rebuild topology or upgrade GRASS to at least version %d."
+msgid "Invalid vector map name <%s>"
 msgstr ""
-#: ../lib/vector/diglib/test.c:58
-msgid "Unable to open test.tmp file"
-msgstr ""
-#: ../lib/vector/diglib/test.c:75
+#: ../lib/vector/Vlib/map.c:417
 #, c-format
-msgid "Error in read/write portable double, byte_order = %d Written: %.16e3E Read: %.16e3E"
+msgid "Unable to open header file for vector map <%s>"
 msgstr ""
-#: ../lib/vector/diglib/test.c:89
+#: ../lib/vector/Vlib/map.c:449
 #, c-format
-msgid "Error in read/write portable float, byte_order = %d Written: %.8e3E Read: %.8e3E"
+msgid "Unable to find table <%s> linked to vector map <%s>"
 msgstr ""
-#: ../lib/vector/diglib/test.c:104
+#: ../lib/vector/Vlib/map.c:472
 #, c-format
-msgid "Error in read/write portable off_t, byte_order = %d Written: %lu Read: %lu"
+msgid "Table <%s> linked to vector map <%s> does not exist"
 msgstr ""
-#: ../lib/vector/diglib/test.c:119
+#: ../lib/vector/Vlib/map.c:485
 #, c-format
-msgid "Error in read/write portable long, byte_order = %d Written: %lu Read: %lu"
+msgid "Unable to open directory '%s'"
 msgstr ""
-#: ../lib/vector/diglib/test.c:134
+#: ../lib/vector/Vlib/map.c:499
 #, c-format
-msgid "Error in read/write portable int, byte_order = %d Written: %d Read: %d"
+msgid "Unable to delete file '%s'"
 msgstr ""
-#: ../lib/vector/diglib/test.c:150
+#: ../lib/vector/Vlib/map.c:519
 #, c-format
-msgid "Error in read/write portable short, byte_order = %d Written: %d Read: %d"
+msgid "Unable to rename directory '%s' to '%s'"
 msgstr ""
-#: ../lib/vector/diglib/test.c:165
+#: ../lib/vector/Vlib/map.c:528
 #, c-format
-msgid "Error in read/write portable char, byte_order = %d Written: %d Read: %d"
+msgid "Unable to remove directory '%s': %s"
 msgstr ""
-#: ../lib/vector/diglib/spindex_rw.c:98 ../lib/vector/diglib/spindex_rw.c:106
-msgid "Topology file must be written before spatial index file"
-msgstr ""
+#: ../lib/vector/Vlib/field.c:91
+msgid "Layer number must be 1 or greater"
+msgstr "Slāņa numuram ir jābūt 1 vai lielākam"
-#: ../lib/vector/diglib/spindex_rw.c:302
-#, c-format
-msgid "This version of GRASS (%d.%d) is too old to read this spatial index format. Try to rebuild topology or upgrade GRASS to at least version %d."
+#: ../lib/vector/Vlib/field.c:96
+msgid "Unable to add attribute link, vector map is not opened in WRITE mode"
 msgstr ""
-#: ../lib/vector/diglib/spindex_rw.c:308
-#, c-format
-msgid "Your GRASS version does not fully support spatial index format %d.%d of the vector. Consider to rebuild topology or upgrade GRASS."
-msgstr ""
+#: ../lib/vector/Vlib/field.c:103
+msgid "Unable to add attribute link"
+msgstr "Nevar pievienot atribūtu saiti"
-#: ../lib/vector/diglib/spindex_rw.c:317
-#, c-format
-msgid "Spatial index format version %d.%d is not supported by this release. Please rebuild topology."
-msgstr ""
+#: ../lib/vector/Vlib/field.c:109
+msgid "Unable to write attribute links"
+msgstr "Nevar ierakstīt atribūtu saiti"
-#: ../lib/vector/diglib/frmt.c:45 ../lib/vector/diglib/frmt.c:70
-#, c-format
-msgid "Vector format not recognized: %s"
-msgstr ""
+#: ../lib/vector/Vlib/field.c:154
+msgid "Unable to write database links"
+msgstr "Nevar ierakstīt datubāzes saites"
-#: ../lib/vector/diglib/frmt.c:79 ../lib/vector/diglib/frmt.c:88
-#, c-format
-msgid "Vector format '%s' not supported"
+#: ../lib/vector/Vlib/field.c:178
+msgid "Database connection not defined. Skipping."
 msgstr ""
-#: ../lib/vector/diglib/frmt.c:97
-#, c-format
-msgid "Format definition is not correct: %s"
+#: ../lib/vector/Vlib/field.c:185
+msgid ""
+"More DB links defined for input vector map. Using only first DB link for "
+"output."
 msgstr ""
-#: ../lib/vector/diglib/spindex.c:450
+#: ../lib/vector/Vlib/field.c:261
 #, c-format
-msgid "Unable to delete node %d from spatial index"
+msgid "Layer number %d or name <%s> already exists"
 msgstr ""
-#: ../lib/vector/diglib/spindex.c:493
+#: ../lib/vector/Vlib/field.c:345
 #, c-format
-msgid "Unable to delete line %d from spatial index"
+msgid ""
+"Default driver / database set to:\n"
+"driver: %s\n"
+"database: %s"
 msgstr ""
-#: ../lib/vector/diglib/spindex.c:529
-msgid "Attempt to delete sidx for dead area"
-msgstr ""
+#: ../lib/vector/Vlib/field.c:352
+msgid "Default driver is not set"
+msgstr "Noklusējuma dzinējs nav iestatīts"
-#: ../lib/vector/diglib/spindex.c:546
-#, c-format
-msgid "Unable to delete area %d from spatial index"
-msgstr ""
+#: ../lib/vector/Vlib/field.c:355
+msgid "Default database is not set"
+msgstr "Noklusējuma datubāze nav iestatīta"
-#: ../lib/vector/diglib/spindex.c:595
+#: ../lib/vector/Vlib/field.c:428
 #, c-format
-msgid "Unable to delete isle %d from spatial index"
-msgstr ""
+msgid "Requested dblink %d, maximum link number %d"
+msgstr "Pieprasītā dbsaite %d, maksimāli iespējamo saišu skaits %d"
-#: ../lib/vector/diglib/plus_node.c:214
+#: ../lib/vector/Vlib/field.c:614 ../lib/vector/Vlib/field.c:622
 #, c-format
-msgid "Attempt to read line angle for the line which is not connected to the node: node %d, line %d"
+msgid "Error in rule on row %d in <%s>"
 msgstr ""
-#: ../lib/vector/diglib/plus_struct.c:523
+#: ../lib/vector/Vlib/field.c:707
 #, c-format
-msgid "This version of GRASS (%d.%d) is too old to read this topology format. Try to rebuild topology or upgrade GRASS to at least version %d."
+msgid "Unable to open OGR layer <%s>"
 msgstr ""
-#: ../lib/vector/diglib/plus_struct.c:529
-#, c-format
-msgid "Your GRASS version does not fully support topology format %d.%d of the vector. Consider to rebuild topology or upgrade GRASS."
+#: ../lib/vector/Vlib/field.c:734
+msgid "Unable to open OGR DBMI driver"
+msgstr "Nevar atvērt OGR DBMI dzinēju"
+#: ../lib/vector/Vlib/field.c:773
+msgid ""
+"All FID tests failed. Neither 'FID' nor 'ogc_fid' nor 'ogr_fid' nor 'gid' "
+"available in OGR DB table"
 msgstr ""
-#: ../lib/vector/diglib/plus_struct.c:539
+#: ../lib/vector/Vlib/field.c:840
 #, c-format
-msgid "Old topology format version %d.%d is not supported by this release. Try to rebuild topology using v.build or v.build.all module."
+msgid ""
+"Feature table <%s> has no primary key defined. Unable to define DB links."
 msgstr ""
-#: ../lib/vector/Vlib/intersect.c:127
-msgid "3D not supported by Vect_segment_intersection()"
-msgstr ""
+#: ../lib/vector/Vlib/field.c:860
+msgid "GRASS not compiled with PostgreSQL support"
+msgstr "GRASS nav kompilēts ar PostgreSQL atbalstu"
-#: ../lib/vector/Vlib/intersect.c:353
-msgid "Vect_segment_intersection() ERROR (collinear vertical segments)"
-msgstr ""
+#: ../lib/vector/Vlib/field.c:892
+msgid "Unknown vector map format"
+msgstr "Nezināms vektordatu kartes formāts"
-#: ../lib/vector/Vlib/intersect.c:447
-msgid "Vect_segment_intersection() ERROR (collinear non vertical segments)"
+#: ../lib/vector/Vlib/field.c:925
+#, c-format
+msgid "Unable to create database definition file for vector map <%s>"
 msgstr ""
-#: ../lib/vector/Vlib/intersect.c:1194 ../lib/vector/Vlib/intersect.c:1200
-#: ../lib/vector/Vlib/intersect.c:1202 ../lib/vector/Vlib/intersect.c:1257
-#: ../lib/vector/Vlib/intersect.c:1266 ../lib/vector/Vlib/intersect.c:1287
-#: ../lib/vector/Vlib/intersect.c:1304 ../lib/vector/Vlib/intersect2.c:1202
-#: ../lib/vector/Vlib/intersect2.c:1208 ../lib/vector/Vlib/intersect2.c:1210
-#: ../lib/vector/Vlib/intersect2.c:1262 ../lib/vector/Vlib/intersect2.c:1271
-#: ../lib/vector/Vlib/intersect2.c:1292 ../lib/vector/Vlib/intersect2.c:1309
-msgid "Error while adding point to array. Out of memory"
+#: ../lib/vector/Vlib/field.c:1020
+msgid "Bug: attempt to update map which is not in current mapset"
 msgstr ""
-#: ../lib/vector/Vlib/read.c:25 ../lib/vector/Vlib/write.c:30
-#: ../lib/vector/Vlib/write.c:36 ../lib/vector/Vlib/write.c:42
-#: ../lib/vector/Vlib/write.c:49
-msgid "for this format/level not supported"
-msgstr ""
+#: ../lib/vector/Vlib/dangles.c:148
+msgid "Changed"
+msgstr "Mainīts"
-#: ../lib/vector/Vlib/read.c:32 ../lib/vector/Vlib/rewind.c:29
-#: ../lib/vector/Vlib/close.c:38 ../lib/vector/Vlib/build.c:37
-#: ../lib/vector/Vlib/open.c:59 ../lib/vector/Vlib/write.c:56
-#: ../lib/vector/Vlib/write.c:62
-msgid "Requested format is not compiled in this version"
-msgstr "Pieprasītais formāts nav pieejams/iekļauts šijā versijā"
+#: ../lib/vector/Vlib/dangles.c:151
+msgid "Removed"
+msgstr "Noņemts"
-#: ../lib/vector/Vlib/read.c:93 ../lib/vector/Vlib/read.c:129
-#: ../lib/vector/Vlib/read.c:168
-msgid "Vector map is not open for reading"
-msgstr ""
+#: ../lib/vector/Vlib/dangles.c:154
+msgid "Selected"
+msgstr "Izvēlēts"
-#: ../lib/vector/Vlib/read.c:136 ../lib/vector/Vlib/read.c:180
+#: ../lib/vector/Vlib/dangles.c:262
 #, c-format
-msgid "Unable to read feature %d from vector map <%s>"
-msgstr ""
+msgid "%s lines: %d"
+msgstr "%s līnijas: %d"
-#: ../lib/vector/Vlib/read.c:173 ../lib/vector/Vlib/box.c:276
-#: ../lib/vector/Vlib/write_pg.c:236 ../lib/vector/Vlib/write_pg.c:381
-#: ../lib/vector/Vlib/write_pg.c:396 ../lib/vector/Vlib/write_sfa.c:158
-#: ../lib/vector/Vlib/write_sfa.c:207 ../lib/vector/Vlib/write_nat.c:182
-#: ../lib/vector/Vlib/write_nat.c:295 ../lib/vector/Vlib/write_nat.c:651
-#: ../lib/vector/Vlib/read_sfa.c:50 ../lib/vector/Vlib/read_nat.c:144
-#: ../lib/vector/Vlib/read_pg.c:331
+#: ../lib/vector/Vlib/dangles.c:263
 #, c-format
-msgid "Attempt to access feature with invalid id (%d)"
+msgid "%s dangles: %d"
 msgstr ""
-#: ../lib/vector/Vlib/read.c:200
-msgid "Line index is out of range"
+#: ../lib/vector/Vlib/overlay.c:72
+msgid "unknown operator"
 msgstr ""
-#: ../lib/vector/Vlib/read.c:224
-msgid "Node index is out of range"
+#: ../lib/vector/Vlib/overlay.c:124
+msgid "Overlay: line/boundary types not supported by AND operator"
 msgstr ""
-#: ../lib/vector/Vlib/read.c:248
-msgid "Area index is out of range"
+#: ../lib/vector/Vlib/overlay.c:127
+msgid "Overlay: area x area types not supported by AND operator"
 msgstr ""
-#: ../lib/vector/Vlib/read.c:272
-msgid "Isle index is out of range"
+#: ../lib/vector/Vlib/line.c:184 ../lib/vector/Vlib/line.c:217
+#: ../lib/vector/Vlib/line.c:250
+msgid "Index out of range in"
 msgstr ""
-#: ../lib/vector/Vlib/remove_areas.c:107 ../lib/vector/Vlib/remove_areas.c:268
-msgid "Area is composed of dead boundary"
+#: ../lib/vector/Vlib/line.c:550
+msgid "Segment outside line, no segment created"
 msgstr ""
-#: ../lib/vector/Vlib/remove_areas.c:194 ../lib/vector/Vlib/remove_areas.c:602
-#, c-format
-msgid "%d areas of total size %g removed"
+#: ../lib/vector/Vlib/geos.c:52
+msgid "vector map is not opened"
 msgstr ""
-#: ../lib/vector/Vlib/remove_areas.c:395
-msgid "Could not delete line from coor"
+#: ../lib/vector/Vlib/geos.c:55
+#, c-format
+msgid ""
+"Vect_read_line_geos(): feature id %d is not reasonable (max features in "
+"vector map <%s>: %d)"
 msgstr ""
-#: ../lib/vector/Vlib/remove_areas.c:458
-msgid "dissolve_neighbour > 0, failed to build new area"
+#: ../lib/vector/Vlib/geos.c:60
+msgid "only native format supported"
 msgstr ""
-#: ../lib/vector/Vlib/remove_areas.c:463 ../lib/vector/Vlib/remove_areas.c:501
-msgid "Dissolve with neighbour area: corrupt topology"
+#: ../lib/vector/Vlib/geos.c:65 ../lib/vector/Vlib/geos.c:258
+msgid "Attempt to read dead line"
 msgstr ""
-#: ../lib/vector/Vlib/remove_areas.c:497
-msgid "Failed to build new area"
-msgstr "Neizdevās izveidot jaunu laukumu"
-#: ../lib/vector/Vlib/remove_areas.c:544 ../lib/vector/Vlib/remove_areas.c:571
-msgid "Failed to build new isle"
-msgstr "Neizdevās izveidot jaunu salu"
-#: ../lib/vector/Vlib/remove_areas.c:549 ../lib/vector/Vlib/remove_areas.c:576
-msgid "Dissolve with outer isle: corrupt topology"
+#: ../lib/vector/Vlib/geos.c:90
+#, c-format
+msgid "Vect_read_area_geos(): unable to read area id %d"
 msgstr ""
-#: ../lib/vector/Vlib/remove_areas.c:581
-msgid "Area merging failed"
-msgstr "Laukumu apvienošana bija nesekmīga"
-#: ../lib/vector/Vlib/dgraph.c:432
-msgid "Trying to add more edges to the planar_graph than the initial allocation size allows"
+#: ../lib/vector/Vlib/geos.c:104
+#, c-format
+msgid "Vect_read_area_geos(): unable to read isle id %d of area id %d"
 msgstr ""
-#: ../lib/vector/Vlib/array.c:96
+#: ../lib/vector/Vlib/geos.c:205
 #, c-format
-msgid "%d errors in category string"
+msgid "Unable to read line offset %ld"
 msgstr ""
-#: ../lib/vector/Vlib/array.c:142 ../lib/vector/Vlib/array.c:267
-msgid "Mixed area and other type requested for vector array"
-msgstr ""
-#: ../lib/vector/Vlib/array.c:152 ../lib/vector/Vlib/array.c:175
-#: ../lib/vector/Vlib/array.c:304 ../lib/vector/Vlib/array.c:336
-msgid "Not enough space in vector array"
-msgstr ""
-#: ../lib/vector/Vlib/array.c:292
+#: ../lib/vector/Vlib/geos.c:412
 #, c-format
-msgid "Unable to select record from table <%s> (key %s, where %s)"
+msgid "Attempt to read points of nonexistent area id %d"
 msgstr ""
-#: ../lib/vector/Vlib/build_sfa.c:279 ../lib/vector/Vlib/build_sfa.c:546
+#: ../lib/vector/Vlib/geos.c:472
 #, c-format
-msgid "Unable to calculate centroid for area %d"
+msgid "Unable to read feature id %d"
 msgstr ""
-#: ../lib/vector/Vlib/build_sfa.c:305
+#: ../lib/vector/Vlib/copy.c:81
 #, c-format
-msgid "Feature type %d not supported"
-msgstr "Objekta tips %d nav atbalstīts"
-#: ../lib/vector/Vlib/build_sfa.c:339 ../lib/vector/Vlib/build_sfa.c:632
-#: ../lib/vector/Vlib/build_nat.c:74
-msgid "Registering primitives..."
-msgstr "Reģistrē primitīvus..."
-#: ../lib/vector/Vlib/build_sfa.c:354 ../lib/vector/Vlib/build_sfa.c:364
-#: ../lib/vector/Vlib/read_pg.c:378
-#, c-format
-msgid "Feature %d without geometry skipped"
+msgid "Unable to copy features. Input vector map <%s> is not open"
 msgstr ""
-#: ../lib/vector/Vlib/build_sfa.c:385 ../lib/vector/Vlib/build_sfa.c:664
-#: ../lib/vector/Vlib/build_nat.c:117
+#: ../lib/vector/Vlib/copy.c:102
 #, c-format
-msgid "One primitive registered"
-msgid_plural "%d primitives registered"
-msgstr[0] "Ir reģistrēts %d primitīvs"
-msgstr[1] "Ir reģistrēti %d primitīvi"
-msgstr[2] "Ir reģistrēts %d primitīvu"
-#: ../lib/vector/Vlib/build_sfa.c:386 ../lib/vector/Vlib/build_sfa.c:665
-#: ../lib/vector/Vlib/build_nat.c:118
-#, c-format
-msgid "One vertex registered"
-msgid_plural "%d vertices registered"
-msgstr[0] "Reģistrēta %d virsotne"
-msgstr[1] "Reģistrētas %d virsotnes"
-msgstr[2] "Reģistrēts %d virsotņu"
-#: ../lib/vector/Vlib/build_sfa.c:603 ../lib/vector/Vlib/read_ogr.c:344
-#: ../lib/vector/Vlib/read_ogr.c:578
-#, c-format
-msgid "OGR feature type %d not supported"
+msgid "Unable to create PostGIS layer <%s>"
 msgstr ""
-#: ../lib/vector/Vlib/build_sfa.c:668
+#: ../lib/vector/Vlib/copy.c:134
 #, c-format
-msgid "One feature without geometry skipped"
-msgid_plural "%d features without geometry skipped"
-msgstr[0] "Ir izlaists %d objekts bez ģeometrijas"
-msgstr[1] "Ir izlaisti %d objekti bez ģeometrijas"
-msgstr[2] "Ir izlaists %d objektu bez ģeometrijas"
-#: ../lib/vector/Vlib/build_sfa.c:721 ../lib/vector/Vlib/simple_features.c:336
-#: ../lib/vector/Vlib/close.c:275 ../lib/vector/Vlib/build_pg.c:117
-#: ../lib/vector/Vlib/rewind_pg.c:56 ../lib/vector/Vlib/rewind_pg.c:81
-#: ../lib/vector/Vlib/header_finfo.c:47 ../lib/vector/Vlib/header_finfo.c:86
-#: ../lib/vector/Vlib/header_finfo.c:123 ../lib/vector/Vlib/header_finfo.c:171
-#: ../lib/vector/Vlib/copy.c:430 ../lib/vector/Vlib/close_pg.c:99
-#: ../lib/vector/Vlib/close_pg.c:146 ../lib/vector/Vlib/area.c:94
-#: ../lib/vector/Vlib/area.c:499 ../lib/vector/Vlib/write_pg.c:123
-#: ../lib/vector/Vlib/write_pg.c:157 ../lib/vector/Vlib/write_pg.c:196
-#: ../lib/vector/Vlib/write_pg.c:294 ../lib/vector/Vlib/write_pg.c:354
-#: ../lib/vector/Vlib/write_pg.c:476 ../lib/vector/Vlib/open_pg.c:143
-#: ../lib/vector/Vlib/open_pg.c:200 ../lib/vector/Vlib/open_pg.c:299
-#: ../lib/vector/Vlib/open_pg.c:349 ../lib/vector/Vlib/write_sfa.c:306
-#: ../lib/vector/Vlib/read_pg.c:91 ../lib/vector/Vlib/read_pg.c:214
-#: ../lib/vector/Vlib/read_pg.c:298 ../lib/vector/Vlib/read_pg.c:416
-msgid "GRASS is not compiled with PostgreSQL support"
+msgid "Vector map <%s> not open on topological level. Areas will be skipped!"
 msgstr ""
-#: ../lib/vector/Vlib/build_sfa.c:725
+#: ../lib/vector/Vlib/copy.c:169 ../lib/vector/Vlib/copy.c:246
+#: ../lib/ogsf/gp3.c:92
 #, c-format
-msgid "%s: Native format unsupported"
-msgstr ""
+msgid "Unable to read vector map <%s>"
+msgstr "Nav iespējams nolasīt vektoru karti <%s>"
-#: ../lib/vector/Vlib/build_sfa.c:751
-msgid "Feature index is built only for non-native formats. Nothing to dump."
-msgstr ""
+#: ../lib/vector/Vlib/copy.c:230 ../lib/vector/Vlib/copy.c:235
+msgid "Copying features..."
+msgstr "Kopē objektus..."
-#: ../lib/vector/Vlib/clean_nodes.c:248
+#: ../lib/vector/Vlib/copy.c:232
 #, c-format
-msgid "Modifications: %d"
+msgid "Copying features (%s)..."
 msgstr ""
-#: ../lib/vector/Vlib/line.c:184 ../lib/vector/Vlib/line.c:217
-#: ../lib/vector/Vlib/line.c:250
-msgid "Index out of range in"
+#: ../lib/vector/Vlib/copy.c:358
+msgid "Writing new feature failed"
 msgstr ""
-#: ../lib/vector/Vlib/line.c:550
-msgid "Segment outside line, no segment created"
-msgstr ""
-#: ../lib/vector/Vlib/simple_features.c:225
+#: ../lib/vector/Vlib/copy.c:364
 #, c-format
-msgid "Unknown Simple Features type (%d)"
+msgid "%d features without category or from different layer skipped"
 msgstr ""
-#: ../lib/vector/Vlib/simple_features.c:324 ../lib/vector/Vlib/write_pg.c:321
-#: ../lib/vector/Vlib/write_pg.c:811 ../lib/vector/Vlib/write_pg.c:1213
-#: ../lib/vector/Vlib/write_pg.c:1371
-msgid "No connection defined"
-msgstr ""
+#: ../lib/vector/Vlib/copy.c:396
+msgid "Exporting nodes..."
+msgstr "Eksportē mezglus..."
-#: ../lib/vector/Vlib/simple_features.c:332
-msgid "Unable to get number of simple features"
-msgstr ""
-#: ../lib/vector/Vlib/simple_features.c:341
+#: ../lib/vector/Vlib/copy.c:424
 #, c-format
-msgid "Unable to report simple features for vector map <%s>"
+msgid "Writing node %d failed"
 msgstr ""
-#: ../lib/vector/Vlib/level.c:34
-msgid "Map structure was never initialized"
-msgstr ""
+#: ../lib/vector/Vlib/copy.c:502
+msgid "Exporting areas..."
+msgstr "Eksportē laukumus..."
-#: ../lib/vector/Vlib/level.c:36
-msgid "Map structure has been closed"
-msgstr ""
-#: ../lib/vector/Vlib/close.c:91
+#: ../lib/vector/Vlib/copy.c:560 ../lib/vector/Vlib/copy.c:568
 #, c-format
-msgid "Unable to create vector map <%s>"
+msgid "Writing area %d failed"
 msgstr ""
-#: ../lib/vector/Vlib/close.c:108
-msgid "Copying features failed"
-msgstr ""
-#: ../lib/vector/Vlib/close.c:141
+#: ../lib/vector/Vlib/copy.c:576
 #, c-format
-msgid "Unable to open %s file"
+msgid "%d areas without category or from different layer skipped"
 msgstr ""
-#: ../lib/vector/Vlib/close.c:226
+#: ../lib/vector/Vlib/copy.c:630
 #, c-format
-msgid "Unable to close vector <%s>"
+msgid "Unable to copy table <%s> for layer %d from <%s> to <%s>"
 msgstr ""
-#: ../lib/vector/Vlib/close.c:257
+#: ../lib/vector/Vlib/copy.c:749
 #, c-format
-msgid "Invalid request for writing frmt file - map format is %d"
+msgid "Unable to add database link for vector map <%s>"
 msgstr ""
-#: ../lib/vector/Vlib/close.c:289
+#: ../lib/vector/Vlib/copy.c:773
 #, c-format
-msgid "Link to vector map <%s> created"
+msgid "Unable to open database <%s> with driver <%s>"
 msgstr ""
-#: ../lib/vector/Vlib/build_pg.c:88
-msgid "No DB connection"
+#: ../lib/vector/Vlib/copy.c:780
+msgid "Unable to create index"
 msgstr ""
-#: ../lib/vector/Vlib/build_pg.c:93 ../lib/vector/Vlib/build_ogr.c:87
+#: ../lib/vector/Vlib/copy.c:786
 #, c-format
-msgid "Feature table <%s> has no primary key defined"
+msgid "Unable to grant privileges on table <%s>"
 msgstr ""
-#: ../lib/vector/Vlib/build_pg.c:95
-msgid "Random read is not supported for this layer. Unable to build topology."
-msgstr ""
-#: ../lib/vector/Vlib/build_pg.c:101 ../lib/vector/Vlib/build_ogr.c:95
+#: ../lib/vector/Vlib/read_ogr.c:215 ../lib/vector/Vlib/read_ogr.c:224
 #, c-format
-msgid "Using external data format '%s' (feature type '%s')"
+msgid "Unable to get feature geometry, fid %ld"
 msgstr ""
-#: ../lib/vector/Vlib/build_pg.c:105
-msgid "Building pseudo-topology over simple features..."
+#: ../lib/vector/Vlib/read_ogr.c:390
+msgid "OGR feature without ID"
 msgstr ""
-#: ../lib/vector/Vlib/build_pg.c:107
+#: ../lib/vector/Vlib/read_ogr.c:514
 #, c-format
-msgid "Building topology from PostGIS topology schema <%s>..."
+msgid "OGR feature type '%s' not supported"
 msgstr ""
-#: ../lib/vector/Vlib/build_pg.c:212 ../lib/vector/Vlib/open_pg.c:1485
-#, c-format
-msgid "Inconsistency in topology: number of nodes %d (should be %d)"
+#: ../lib/vector/Vlib/build_ogr.c:72
+msgid "Empty OGR layer, nothing to build"
 msgstr ""
-#: ../lib/vector/Vlib/build_pg.c:237
-msgid "Cleaning-up topology schema..."
+#: ../lib/vector/Vlib/build_ogr.c:89
+msgid ""
+"Random read is not supported by OGR for this layer. Unable to build topology."
 msgstr ""
-#: ../lib/vector/Vlib/build_pg.c:282
-msgid "Updating faces..."
+#: ../lib/vector/Vlib/build_ogr.c:139
+#, c-format
+msgid "Unable to open fidx file for write <%s>"
 msgstr ""
-#: ../lib/vector/Vlib/build_pg.c:314
-msgid "Updating edges..."
+#: ../lib/vector/Vlib/write.c:194
+#, c-format
+msgid "Unable to write feature in vector map <%s>"
 msgstr ""
-#: ../lib/vector/Vlib/build_pg.c:323
-msgid "Inconsistency in topology detected. Dead line found."
-msgstr ""
-#: ../lib/vector/Vlib/build_pg.c:377
-msgid "Updating TopoGeometry data..."
-msgstr ""
-#: ../lib/vector/Vlib/build_pg.c:411 ../lib/vector/Vlib/write_pg.c:612
-#: ../lib/vector/Vlib/write_pg.c:880 ../lib/vector/Vlib/open.c:1355
-msgid "Unable to open PG file"
-msgstr ""
-#: ../lib/vector/Vlib/build_pg.c:462
+#: ../lib/vector/Vlib/write.c:234
 #, c-format
-msgid "Unsupported topo geometry type %d"
+msgid "Unable to rewrite feature/offset %lu in vector map <%s>"
 msgstr ""
-#: ../lib/vector/Vlib/build_pg.c:491
+#: ../lib/vector/Vlib/write.c:266
 #, c-format
-msgid "Unable to create <%s.%s>"
+msgid "Unable to delete feature/offset %lu from vector map <%s>"
 msgstr ""
-#: ../lib/vector/Vlib/build_pg.c:642
-msgid "Unable to write nodes, offset array mismatch"
+#: ../lib/vector/Vlib/write.c:299
+msgid "Unable to restore feature/offset %"
 msgstr ""
-#: ../lib/vector/Vlib/build_pg.c:671
-msgid "Unable to write nodes"
-msgstr "Nevar ierakstīt mezglus"
-#: ../lib/vector/Vlib/build_pg.c:716
+#: ../lib/vector/Vlib/write.c:308
 #, c-format
-msgid "Inconsistency in topology: number of boundaries %d (should be %d)"
-msgstr ""
+msgid "Vector map <%s> is not opened"
+msgstr "Vektoru karte <%s> nav atvērta"
-#: ../lib/vector/Vlib/build_pg.c:739
-msgid "Unable to write lines"
-msgstr ""
-#: ../lib/vector/Vlib/build_pg.c:790
+#: ../lib/vector/Vlib/write.c:313
 #, c-format
-msgid "Topology for centroid %d not available. Area %d skipped"
+msgid "Vector map <%s> is not opened in write mode"
 msgstr ""
-#: ../lib/vector/Vlib/build_pg.c:1000
-msgid "Create simple features topology from topogeometry data..."
+#: ../lib/vector/Vlib/poly.c:268
+msgid "Unable to find point in polygon"
 msgstr ""
-#: ../lib/vector/Vlib/build_pg.c:1018
-#, c-format
-msgid "Unable to build simple features from topogeometry data. Unsupported type %d."
+#: ../lib/vector/Vlib/poly.c:810
+msgid "conditions failed"
 msgstr ""
-#: ../lib/vector/Vlib/select.c:116
-#, c-format
-msgid "Unable to delete item %d from spatial index"
-msgstr ""
 #: ../lib/vector/Vlib/build.c:115
 msgid "Area of size = 0.0 (less than 4 vertices) ignored"
 msgstr ""
@@ -4364,12 +2472,6 @@
 msgid "Number of redundant holes: %d"
 msgstr ""
-#: ../lib/vector/Vlib/build.c:865 ../lib/vector/Vlib/open.c:367
-#: ../lib/vector/Vlib/open.c:871
-#, c-format
-msgid "Unable to open spatial index file for vector map <%s>"
-msgstr ""
 #: ../lib/vector/Vlib/build.c:871
 #, c-format
 msgid "Building topology for vector map <%s>..."
@@ -4472,7 +2574,9 @@
 msgstr ""
 #: ../lib/vector/Vlib/build.c:1210
-msgid "Unable to build spatial index from topology, vector map is not opened at topology level 2"
+msgid ""
+"Unable to build spatial index from topology, vector map is not opened at "
+"topology level 2"
 msgstr ""
 #: ../lib/vector/Vlib/build.c:1233
@@ -4493,2453 +2597,2197 @@
 msgid "Error writing out spatial index file"
 msgstr ""
-#: ../lib/vector/Vlib/bridges.c:213
+#: ../lib/vector/diglib/plus_node.c:214
 #, c-format
-msgid "Removed lines: %d"
+msgid ""
+"Attempt to read line angle for the line which is not connected to the node: "
+"node %d, line %d"
 msgstr ""
-#: ../lib/vector/Vlib/bridges.c:214
+#: ../lib/vector/diglib/plus_area.c:215 ../lib/vector/diglib/plus_area.c:716
 #, c-format
-msgid "Removed bridges: %d"
+msgid "Line %d already has area/isle %d to left"
 msgstr ""
-#: ../lib/vector/Vlib/legal_vname.c:43
+#: ../lib/vector/diglib/plus_area.c:225 ../lib/vector/diglib/plus_area.c:724
 #, c-format
-msgid "Illegal vector map name <%s>. May not contain '.' or 'NULL'."
+msgid "Line %d already has area/isle %d to right"
 msgstr ""
-#: ../lib/vector/Vlib/legal_vname.c:50
-#, c-format
-msgid "Illegal vector map name <%s>. Must start with a letter."
+#: ../lib/vector/diglib/plus_area.c:279
+msgid "Isle already registered in area"
 msgstr ""
-#: ../lib/vector/Vlib/legal_vname.c:58
-#, c-format
-msgid "Illegal vector map name <%s>. Character '%c' not allowed."
+#: ../lib/vector/diglib/plus_area.c:313
+msgid "Attempt to delete isle from dead area"
 msgstr ""
-#: ../lib/vector/Vlib/legal_vname.c:65
+#: ../lib/vector/diglib/plus_area.c:330
 #, c-format
-msgid "Illegal vector map name <%s>. SQL keyword cannot be used as vector map name."
+msgid "Attempt to delete not registered isle %d from area %d"
 msgstr ""
-#: ../lib/vector/Vlib/legal_vname.c:100 ../lib/vector/Vlib/legal_vname.c:104
-#, c-format
-msgid "Output vector map name <%s> is not in the current mapset (%s)"
+#: ../lib/vector/diglib/plus_area.c:369
+msgid "Attempt to delete dead area"
 msgstr ""
-#: ../lib/vector/Vlib/legal_vname.c:117 ../lib/vector/Vlib/legal_vname.c:121
+#: ../lib/vector/diglib/plus_area.c:408
 #, c-format
-msgid "Output vector map name <%s> is not SQL compliant"
+msgid "Dead centroid %d registered for area (bug in the vector library)"
 msgstr ""
-#: ../lib/vector/Vlib/legal_vname.c:159 ../lib/vector/Vlib/legal_vname.c:163
+#: ../lib/vector/diglib/plus_area.c:431
 #, c-format
-msgid "Output vector map <%s> is used as input"
+msgid "Attempt to delete area %d info from dead isle %d"
 msgstr ""
-#: ../lib/vector/Vlib/copy.c:81
+#: ../lib/vector/diglib/plus_area.c:782
 #, c-format
-msgid "Unable to copy features. Input vector map <%s> is not open"
+msgid "Attempt to delete isle %d info from dead area %d"
 msgstr ""
-#: ../lib/vector/Vlib/copy.c:100 ../lib/vector/Vlib/write_pg.c:737
-#: ../lib/vector/Vlib/write_pg.c:1176 ../lib/vector/Vlib/write_pg.c:1285
-#: ../lib/vector/Vlib/write_pg.c:1798 ../lib/vector/Vlib/write_pg.c:1975
-#: ../lib/vector/Vlib/write_pg.c:2333 ../lib/vector/Vlib/read_pg.c:884
-#: ../lib/vector/Vlib/read_pg.c:1192 ../lib/vector/Vlib/read_pg.c:1362
-#: ../lib/vector/Vlib/read_pg.c:1455
-#, c-format
-msgid "Unsupported feature type %d"
+#: ../lib/vector/diglib/file.c:159
+msgid "Writing to file loaded to memory not supported"
 msgstr ""
-#: ../lib/vector/Vlib/copy.c:104
-#, c-format
-msgid "Unable to create PostGIS layer <%s>"
+#: ../lib/vector/diglib/file.c:197
+msgid "Unable to load file to memory, file not open"
 msgstr ""
-#: ../lib/vector/Vlib/copy.c:136
+#: ../lib/vector/diglib/file.c:212
+msgid "Vector memory mode not supported, using 'AUTO'"
+msgstr ""
+#: ../lib/vector/diglib/spindex_rw.c:98 ../lib/vector/diglib/spindex_rw.c:106
+msgid "Topology file must be written before spatial index file"
+msgstr ""
+#: ../lib/vector/diglib/spindex_rw.c:302
 #, c-format
-msgid "Vector map <%s> not open on topological level. Areas will be skipped!"
+msgid ""
+"This version of GRASS (%d.%d) is too old to read this spatial index format. "
+"Try to rebuild topology or upgrade GRASS to at least version %d."
 msgstr ""
-#: ../lib/vector/Vlib/copy.c:171 ../lib/vector/Vlib/copy.c:248
-#: ../lib/ogsf/gp3.c:92
+#: ../lib/vector/diglib/spindex_rw.c:308
 #, c-format
-msgid "Unable to read vector map <%s>"
-msgstr "Nav iespējams nolasīt vektoru karti <%s>"
+msgid ""
+"Your GRASS version does not fully support spatial index format %d.%d of the "
+msgstr ""
-#: ../lib/vector/Vlib/copy.c:232 ../lib/vector/Vlib/copy.c:237
-msgid "Copying features..."
-msgstr "Kopē objektus..."
-#: ../lib/vector/Vlib/copy.c:234
+#: ../lib/vector/diglib/spindex_rw.c:317
 #, c-format
-msgid "Copying features (%s)..."
+msgid ""
+"Spatial index format version %d.%d is not supported by this release. Please "
+"rebuild topology."
 msgstr ""
-#: ../lib/vector/Vlib/copy.c:360
-msgid "Writing new feature failed"
+#: ../lib/vector/diglib/test.c:58
+msgid "Unable to open test.tmp file"
 msgstr ""
-#: ../lib/vector/Vlib/copy.c:366
+#: ../lib/vector/diglib/test.c:75
 #, c-format
-msgid "%d features without category or from different layer skipped"
+msgid ""
+"Error in read/write portable double, byte_order = %d Written: %.16e3E Read: "
+"%.16e3E"
 msgstr ""
-#: ../lib/vector/Vlib/copy.c:398
-msgid "Exporting nodes..."
-msgstr "Eksportē mezglus..."
-#: ../lib/vector/Vlib/copy.c:426
+#: ../lib/vector/diglib/test.c:89
 #, c-format
-msgid "Writing node %d failed"
+msgid ""
+"Error in read/write portable float, byte_order = %d Written: %.8e3E Read: "
+"%.8e3E"
 msgstr ""
-#: ../lib/vector/Vlib/copy.c:504
-msgid "Exporting areas..."
-msgstr "Eksportē laukumus..."
-#: ../lib/vector/Vlib/copy.c:562 ../lib/vector/Vlib/copy.c:570
+#: ../lib/vector/diglib/test.c:104
 #, c-format
-msgid "Writing area %d failed"
+msgid ""
+"Error in read/write portable off_t, byte_order = %d Written: %lu Read: %lu"
 msgstr ""
-#: ../lib/vector/Vlib/copy.c:578
+#: ../lib/vector/diglib/test.c:119
 #, c-format
-msgid "%d areas without category or from different layer skipped"
+msgid ""
+"Error in read/write portable long, byte_order = %d Written: %lu Read: %lu"
 msgstr ""
-#: ../lib/vector/Vlib/copy.c:632
+#: ../lib/vector/diglib/test.c:134
 #, c-format
-msgid "Unable to copy table <%s> for layer %d from <%s> to <%s>"
+msgid "Error in read/write portable int, byte_order = %d Written: %d Read: %d"
 msgstr ""
-#: ../lib/vector/Vlib/copy.c:751
+#: ../lib/vector/diglib/test.c:150
 #, c-format
-msgid "Unable to add database link for vector map <%s>"
+msgid ""
+"Error in read/write portable short, byte_order = %d Written: %d Read: %d"
 msgstr ""
-#: ../lib/vector/Vlib/copy.c:766 ../lib/vector/Vlib/close_nat.c:102
-#: ../lib/vector/Vlib/map.c:317
+#: ../lib/vector/diglib/test.c:165
 #, c-format
-msgid "Unable to copy table <%s>"
+msgid "Error in read/write portable char, byte_order = %d Written: %d Read: %d"
 msgstr ""
-#: ../lib/vector/Vlib/copy.c:775
+#: ../lib/vector/diglib/port_init.c:158
 #, c-format
-msgid "Unable to open database <%s> with driver <%s>"
+msgid "Unable to find '%x' in %s"
 msgstr ""
-#: ../lib/vector/Vlib/copy.c:782
-msgid "Unable to create index"
+#: ../lib/vector/diglib/plus.c:222
+msgid "Unable read topology for nodes"
 msgstr ""
-#: ../lib/vector/Vlib/copy.c:788
+#: ../lib/vector/diglib/plus.c:227
 #, c-format
-msgid "Unable to grant privileges on table <%s>"
+msgid "Unable to read topology for node %d"
 msgstr ""
-#: ../lib/vector/Vlib/geos.c:52
-msgid "vector map is not opened"
+#: ../lib/vector/diglib/plus.c:232
+msgid "Unable read topology for lines"
 msgstr ""
-#: ../lib/vector/Vlib/geos.c:55
+#: ../lib/vector/diglib/plus.c:237
 #, c-format
-msgid "Vect_read_line_geos(): feature id %d is not reasonable (max features in vector map <%s>: %d)"
+msgid "Unable to read topology for line %d"
 msgstr ""
-#: ../lib/vector/Vlib/geos.c:60
-msgid "only native format supported"
+#: ../lib/vector/diglib/plus.c:242
+msgid "Unable to read topo for areas"
 msgstr ""
-#: ../lib/vector/Vlib/geos.c:65 ../lib/vector/Vlib/geos.c:258
-msgid "Attempt to read dead line"
-msgstr ""
-#: ../lib/vector/Vlib/geos.c:90
+#: ../lib/vector/diglib/plus.c:247
 #, c-format
-msgid "Vect_read_area_geos(): unable to read area id %d"
+msgid "Unable read topology for area %d"
 msgstr ""
-#: ../lib/vector/Vlib/geos.c:104
-#, c-format
-msgid "Vect_read_area_geos(): unable to read isle id %d of area id %d"
+#: ../lib/vector/diglib/plus.c:252
+msgid "Unable to read topology for isles"
 msgstr ""
-#: ../lib/vector/Vlib/geos.c:205
+#: ../lib/vector/diglib/plus.c:257
 #, c-format
-msgid "Unable to read line offset %ld"
+msgid "Unable to read topology for isle %d"
 msgstr ""
-#: ../lib/vector/Vlib/geos.c:412
-#, c-format
-msgid "Attempt to read points of nonexistent area id %d"
+#: ../lib/vector/diglib/plus.c:279 ../lib/vector/diglib/plus.c:305
+msgid "Unable to write head to plus file"
 msgstr ""
-#: ../lib/vector/Vlib/geos.c:472
-#, c-format
-msgid "Unable to read feature id %d"
+#: ../lib/vector/diglib/plus.c:284
+msgid "Unable to write nodes to plus file"
 msgstr ""
-#: ../lib/vector/Vlib/buffer2.c:361
-msgid "Line is not looped"
+#: ../lib/vector/diglib/plus.c:289
+msgid "Unable to write lines to plus file"
 msgstr ""
-#: ../lib/vector/Vlib/buffer2.c:443
-#, c-format
-msgid "Unexpected result of line_intersection() res = %d"
+#: ../lib/vector/diglib/plus.c:294
+msgid "Unable to write areas to plus file"
 msgstr ""
-#: ../lib/vector/Vlib/buffer2.c:589
-msgid "Next edge was visited (right) but it is not the first one !!! breaking loop"
+#: ../lib/vector/diglib/plus.c:299
+msgid "Unable to write isles to plus file"
 msgstr ""
-#: ../lib/vector/Vlib/buffer2.c:600
-msgid "Next edge was visited (left) but it is not the first one !!! breaking loop"
+#: ../lib/vector/diglib/plus_struct.c:523
+#, c-format
+msgid ""
+"This version of GRASS (%d.%d) is too old to read this topology format. Try "
+"to rebuild topology or upgrade GRASS to at least version %d."
 msgstr ""
-#: ../lib/vector/Vlib/buffer2.c:648
-msgid "side != 0 feature not implemented"
+#: ../lib/vector/diglib/plus_struct.c:529
+#, c-format
+msgid ""
+"Your GRASS version does not fully support topology format %d.%d of the "
 msgstr ""
-#: ../lib/vector/Vlib/buffer2.c:890 ../lib/vector/Vlib/buffer2.c:937
-msgid "zero area size"
+#: ../lib/vector/diglib/plus_struct.c:539
+#, c-format
+msgid ""
+"Old topology format version %d.%d is not supported by this release. Try to "
+"rebuild topology using v.build or v.build.all module."
 msgstr ""
-#: ../lib/vector/Vlib/buffer2.c:896 ../lib/vector/Vlib/buffer2.c:943
-msgid "Line was not closed"
-msgstr "Līnija netika noslēgta"
-#: ../lib/vector/Vlib/buffer2.c:909 ../lib/vector/Vlib/buffer2.c:960
-msgid "Vect_get_point_in_poly() failed"
+#: ../lib/vector/diglib/plus_struct.c:563 ../lib/vector/diglib/portable.c:208
+#: ../lib/vector/diglib/portable.c:241 ../lib/vector/diglib/portable.c:683
+msgid "Vector exceeds supported file size limit"
 msgstr ""
-#: ../lib/vector/Vlib/close_pg.c:66 ../lib/vector/Vlib/read_pg.c:1420
+#: ../lib/vector/diglib/cindex_rw.c:156
 #, c-format
-msgid "Unable to close cursor %s"
-msgstr "Nevar aizvērt kursoru %s"
+msgid ""
+"This version of GRASS (%d.%d) is too old to read this category index format. "
+msgstr ""
-#: ../lib/vector/Vlib/close_pg.c:139 ../lib/vector/Vlib/close_ogr.c:104
+#: ../lib/vector/diglib/frmt.c:45 ../lib/vector/diglib/frmt.c:70
 #, c-format
-msgid "Unable to save feature index file for vector map <%s>"
+msgid "Vector format not recognized: %s"
 msgstr ""
-#: ../lib/vector/Vlib/box.c:291
+#: ../lib/vector/diglib/frmt.c:79 ../lib/vector/diglib/frmt.c:88
 #, c-format
-msgid "Unable to determine bbox for feature %d"
+msgid "Vector format '%s' not supported"
 msgstr ""
-#: ../lib/vector/Vlib/box.c:340 ../lib/vector/Vlib/box.c:386
+#: ../lib/vector/diglib/frmt.c:97
 #, c-format
-msgid "Attempt to access area with invalid id (%d)"
+msgid "Format definition is not correct: %s"
 msgstr ""
-#: ../lib/vector/Vlib/box.c:352
+#: ../lib/vector/diglib/spindex.c:450
 #, c-format
-msgid "Unable to determine bbox for area %d"
+msgid "Unable to delete node %d from spatial index"
 msgstr ""
-#: ../lib/vector/Vlib/box.c:398
+#: ../lib/vector/diglib/spindex.c:493
 #, c-format
-msgid "Unable to determine bbox for isle %d"
+msgid "Unable to delete line %d from spatial index"
 msgstr ""
-#: ../lib/vector/Vlib/box.c:456
+#: ../lib/vector/diglib/spindex.c:529
+msgid "Attempt to delete sidx for dead area"
+msgstr ""
+#: ../lib/vector/diglib/spindex.c:546
 #, c-format
-msgid "Topology not available for vector map <%s>. Registering primitives..."
+msgid "Unable to delete area %d from spatial index"
 msgstr ""
-#: ../lib/vector/Vlib/box.c:463 ../lib/vector/Vlib/build_nat.c:84
-msgid "Unable to read vector map"
-msgstr "Nav iespējams nolasīt vektoru karti"
-#: ../lib/vector/Vlib/close_nat.c:74
+#: ../lib/vector/diglib/spindex.c:595
 #, c-format
-msgid "Unable to create '%s': %s"
+msgid "Unable to delete isle %d from spatial index"
 msgstr ""
-#: ../lib/vector/Vlib/close_nat.c:81
+#: ../lib/vector/vedit/delete.c:40
 #, c-format
-msgid "Unable to copy '%s': %s"
+msgid "Attempt to delete dead feature (%d)"
 msgstr ""
-#: ../lib/vector/Vlib/close_nat.c:167
+#: ../lib/vector/vedit/delete.c:72
 #, c-format
-msgid "Unable to drop table <%s>"
+msgid "No area found for centroid %d"
 msgstr ""
-#: ../lib/vector/Vlib/area.c:50
-msgid "Attempt to read points of nonexistent area"
+#: ../lib/vector/vedit/delete.c:76
+#, c-format
+msgid "Duplicate centroid %d, unable to delete area"
 msgstr ""
-#: ../lib/vector/Vlib/area.c:81
-msgid "Attempt to read points of nonexistent isle"
+#: ../lib/vector/vedit/delete.c:105
+#, c-format
+msgid "Area %d without centroid"
 msgstr ""
-#: ../lib/vector/Vlib/area.c:121 ../lib/vector/Vlib/area.c:153
-#: ../lib/vector/Vlib/area.c:219 ../lib/vector/Vlib/area.c:248
+#: ../lib/vector/vedit/delete.c:121
 #, c-format
-msgid "Attempt to read topo for dead area (%d)"
+msgid "Area %d has no boundaries"
 msgstr ""
-#: ../lib/vector/Vlib/area.c:189 ../lib/vector/Vlib/area.c:275
+#: ../lib/vector/vedit/cats.c:63
 #, c-format
-msgid "Attempt to read topo for dead isle (%d)"
+msgid "Unable to set category %d for (feature id %d)"
 msgstr ""
-#: ../lib/vector/Vlib/write_pg.c:187 ../lib/vector/Vlib/write_pg.c:255
-#: ../lib/vector/Vlib/write_sfa.c:164 ../lib/vector/Vlib/write_ogr.c:96
-msgid "Unable to rewrite feature (incompatible feature types)"
+#: ../lib/vector/vedit/select.c:231
+msgid "Unknown query tool"
 msgstr ""
-#: ../lib/vector/Vlib/write_pg.c:242 ../lib/vector/Vlib/write_pg.c:402
-#: ../lib/vector/Vlib/write_pg.c:2592 ../lib/vector/Vlib/write_pg.c:2689
-#: ../lib/vector/Vlib/write_nat.c:301 ../lib/vector/Vlib/write_nat.c:657
-#: ../lib/vector/Vlib/read_sfa.c:56 ../lib/vector/Vlib/read_nat.c:150
-#: ../lib/vector/Vlib/read_pg.c:337
-#, c-format
-msgid "Attempt to access dead feature %d"
+#: ../lib/vector/rtree/test_suite/test_basics.c:40
+msgid ""
+"\n"
+"++ Running basic unit tests ++"
 msgstr ""
-#: ../lib/vector/Vlib/write_pg.c:285
-#, c-format
-msgid "Unable to rewrite feature %d"
+#: ../lib/vector/rtree/test_suite/test_basics.c:48
+msgid ""
+"\n"
+"-- Basic rtree unit tests failure --"
 msgstr ""
-#: ../lib/vector/Vlib/write_pg.c:326 ../lib/vector/Vlib/write_ogr.c:134
-#, c-format
-msgid "Invalid offset (%ld)"
+#: ../lib/vector/rtree/test_suite/test_basics.c:50
+msgid ""
+"\n"
+"-- Basic rtree unit tests finished successfully --"
 msgstr ""
-#: ../lib/vector/Vlib/write_pg.c:347 ../lib/vector/Vlib/write_ogr.c:140
-msgid "Unable to delete feature"
+#: ../lib/vector/rtree/test_suite/test_main.c:44
+#: ../lib/db/dbmi_base/test/test_main.c:47 ../lib/gmath/test/test_main.c:47
+msgid "Choose the unit tests to run"
 msgstr ""
-#: ../lib/vector/Vlib/write_pg.c:452
-#, c-format
-msgid "Unable to delete feature (%s) %d"
+#: ../lib/vector/rtree/test_suite/test_main.c:61
+msgid "Unit tests for the vector rtree library"
 msgstr ""
-#: ../lib/vector/Vlib/write_pg.c:554 ../lib/vector/Vlib/write_pg.c:1301
-#: ../lib/vector/Vlib/write_sfa.c:349
-msgid "Boundary is not closed. Skipping."
-msgstr "Robeža nav noslēgta. Izlaižam."
-#: ../lib/vector/Vlib/write_pg.c:773
+#: ../lib/cairodriver/write_xid.c:14 ../lib/pngdriver/read_png.c:71
 #, c-format
-msgid "Building spatial index on <%s>..."
+msgid "Unable to open output file <%s>"
 msgstr ""
-#: ../lib/vector/Vlib/write_pg.c:841
+#: ../lib/cairodriver/write_xid.c:19
 #, c-format
-msgid "Schema <%s> doesn't exist, created"
+msgid "Unable to write output file <%s>"
 msgstr ""
-#: ../lib/vector/Vlib/write_pg.c:920
+#: ../lib/cairodriver/write_ppm.c:27 ../lib/cairodriver/write_bmp.c:72
 #, c-format
-msgid "Creating topology schema <%s>..."
+msgid "Cairo: unable to open output file <%s>"
 msgstr ""
-#: ../lib/vector/Vlib/write_pg.c:934
+#: ../lib/cairodriver/write_ppm.c:34
 #, c-format
-msgid "Adding new topology column <%s>..."
+msgid "Cairo: unable to open mask file <%s>"
 msgstr ""
-#: ../lib/vector/Vlib/write_pg.c:1072 ../lib/vector/Vlib/open_pg.c:85
-#: ../lib/vector/Vlib/open_pg.c:232
-msgid "Connection string not defined"
+#: ../lib/cairodriver/raster.c:109
+msgid "Failed to create cairo surface"
 msgstr ""
-#: ../lib/vector/Vlib/write_pg.c:1077 ../lib/vector/Vlib/write_pg.c:1217
-#: ../lib/vector/Vlib/write_pg.c:1375 ../lib/vector/Vlib/open_pg.c:90
-#: ../lib/vector/Vlib/open_pg.c:237
-msgid "PostGIS feature table not defined"
+#: ../lib/cairodriver/graph.c:67
+msgid "Unable to open display"
+msgstr "Nav iespējams atvērt ekrānu"
+#: ../lib/cairodriver/graph.c:85
+msgid "Unable to obtain visual"
 msgstr ""
-#: ../lib/vector/Vlib/write_pg.c:1105 ../lib/vector/Vlib/write_ogr.c:304
+#: ../lib/cairodriver/graph.c:160
 #, c-format
-msgid "Unsupported geometry type (%d)"
-msgstr "Neatbalstīts ģeometrijas tips (%d)"
+msgid "Unknown file extension: %s"
+msgstr ""
-#: ../lib/vector/Vlib/write_pg.c:1118 ../lib/vector/Vlib/write_ogr.c:338
+#: ../lib/cairodriver/graph.c:190
 #, c-format
-msgid "More layers defined, using driver <%s> and database <%s>"
+msgid "cairo: collecting to file '%s'"
 msgstr ""
-#: ../lib/vector/Vlib/write_pg.c:1123 ../lib/vector/Vlib/write_ogr.c:344
-msgid "Database connection not defined. Unable to write attributes."
+#: ../lib/cairodriver/graph.c:192
+#, c-format
+msgid "cairo: image size %dx%d"
 msgstr ""
-#: ../lib/vector/Vlib/write_pg.c:1130
-msgid "Unable to create new PostGIS feature table"
+#: ../lib/cairodriver/graph.c:371
+msgid "Unknown Cairo surface type"
 msgstr ""
-#: ../lib/vector/Vlib/write_pg.c:1144
-msgid "Unable to create new PostGIS topology schema"
+#: ../lib/cairodriver/graph.c:376
+msgid "Failed to initialize Cairo surface"
 msgstr ""
-#: ../lib/vector/Vlib/write_pg.c:1238 ../lib/vector/Vlib/write_pg.c:1403
-#: ../lib/vector/Vlib/write_ogr.c:408
-#, c-format
-msgid "No category defined for layer %d"
+#: ../lib/cairodriver/draw_bitmap.c:47
+msgid "Cairo_Bitmap: Failed to create source"
 msgstr ""
-#: ../lib/vector/Vlib/write_pg.c:1240 ../lib/vector/Vlib/write_pg.c:1405
-#: ../lib/vector/Vlib/write_ogr.c:410
+#: ../lib/cairodriver/text.c:46
 #, c-format
-msgid "Feature has more categories, using category %d (from layer %d)"
+msgid "Unable to convert from <%s> to UTF-8"
 msgstr ""
-#: ../lib/vector/Vlib/write_pg.c:1251
+#: ../lib/cairodriver/text.c:56
+msgid "Some characters could not be converted to UTF-8"
+msgstr ""
+#: ../lib/cairodriver/read_bmp.c:88 ../lib/cairodriver/read_ppm.c:28
 #, c-format
-msgid "Point skipped (output feature type: %s)"
+msgid "Cairo: unable to open input file <%s>"
 msgstr ""
-#: ../lib/vector/Vlib/write_pg.c:1258
+#: ../lib/cairodriver/read_bmp.c:92 ../lib/cairodriver/read_ppm.c:32
 #, c-format
-msgid "Line skipped (output feature type: %s)"
+msgid "Cairo: invalid input file <%s>"
 msgstr ""
-#: ../lib/vector/Vlib/write_pg.c:1265
+#: ../lib/cairodriver/read_bmp.c:96
 #, c-format
-msgid "Centroid skipped (output feature type: %s)"
+msgid "Cairo: Invalid BMP header for <%s>"
 msgstr ""
-#: ../lib/vector/Vlib/write_pg.c:1272
+#: ../lib/cairodriver/read_ppm.c:38
 #, c-format
-msgid "Boundary skipped (output feature type: %s)"
+msgid "Cairo: input file has incorrect dimensions: expected: %dx%d got: %dx%d"
 msgstr ""
-#: ../lib/vector/Vlib/write_pg.c:1279
+#: ../lib/cairodriver/read_ppm.c:46
 #, c-format
-msgid "Face skipped (output feature type: %s)"
+msgid "Cairo: unable to open input mask file <%s>"
 msgstr ""
-#: ../lib/vector/Vlib/write_pg.c:1365
+#: ../lib/cairodriver/read_ppm.c:50
 #, c-format
-msgid "Invalid feature type (%d) for nodes"
+msgid "Cairo: invalid input mask file <%s>"
 msgstr ""
-#: ../lib/vector/Vlib/write_pg.c:1379
-msgid "PostGIS topology schema not defined"
+#: ../lib/cairodriver/read_ppm.c:56
+#, c-format
+msgid ""
+"Cairo: input mask file has incorrect dimensions: expected: %dx%d got: %dx%d"
 msgstr ""
-#: ../lib/vector/Vlib/write_pg.c:1880
-msgid "Trying to insert 3D data into feature table which store 2D data only"
+#: ../lib/cairodriver/read_xid.c:14
+#, c-format
+msgid "Unable to open input file <%s>"
 msgstr ""
-#: ../lib/vector/Vlib/write_pg.c:1885
-msgid "Trying to insert 2D data into feature table which store 3D data only"
+#: ../lib/cairodriver/read_xid.c:17
+#, c-format
+msgid "Unable to read input file <%s>"
 msgstr ""
-#: ../lib/vector/Vlib/write_pg.c:1910
-msgid "Unable to insert topological element into PostGIS Topology schema"
+#: ../lib/cairodriver/read_xid.c:20
+#, c-format
+msgid "Unable to parse input file <%s>"
 msgstr ""
-#: ../lib/vector/Vlib/write_pg.c:2013 ../lib/vector/Vlib/write_ogr.c:579
+#: ../lib/driver/parse_ftcap.c:84
 #, c-format
-msgid "Unable to select attributes for category %d"
+msgid "%s: Unable to read font definition file; use the default"
 msgstr ""
-#: ../lib/vector/Vlib/write_pg.c:2017 ../lib/vector/Vlib/write_ogr.c:585
-#: ../lib/db/dbmi_client/copy_tab.c:338
+#: ../lib/driver/parse_ftcap.c:90
 #, c-format
-msgid "Unable to fetch data from table <%s>"
+msgid "%s: No font definition file"
 msgstr ""
-#: ../lib/vector/Vlib/write_pg.c:2022 ../lib/vector/Vlib/write_ogr.c:591
+#: ../lib/rst/interp_float/output2d.c:117
 #, c-format
-msgid "No database record for category %d, no attributes will be written"
+msgid "First change your rows number to nsizr! %d %d"
 msgstr ""
-#: ../lib/vector/Vlib/write_pg.c:2048
+#: ../lib/rst/interp_float/output2d.c:124
 #, c-format
-msgid "FID column must be integer, column <%s> ignored!"
+msgid "First change your cols number to nsizc %d %d"
 msgstr ""
-#: ../lib/vector/Vlib/write_pg.c:2082 ../lib/vector/Vlib/write_ogr.c:653
+#: ../lib/rst/interp_float/output2d.c:247
+#: ../lib/rst/interp_float/output2d.c:328
+#: ../lib/rst/interp_float/output2d.c:397
+#: ../lib/rst/interp_float/output2d.c:447
+#: ../lib/rst/interp_float/output2d.c:461
+#: ../lib/rst/interp_float/output2d.c:475
+#: ../lib/rst/interp_float/output2d.c:491
+#: ../lib/rst/interp_float/resout2d.c:205
+#: ../lib/rst/interp_float/resout2d.c:253
+#: ../lib/rst/interp_float/resout2d.c:296
+#: ../lib/rst/interp_float/resout2d.c:327
+#: ../lib/rst/interp_float/resout2d.c:377
+#: ../lib/rst/interp_float/resout2d.c:395
+#: ../lib/rst/interp_float/resout2d.c:410
+#: ../lib/rst/interp_float/resout2d.c:426 ../lib/raster/open.c:176
+#: ../lib/raster/open.c:843 ../lib/raster/open.c:880 ../lib/raster/open.c:932
+#: ../lib/ogsf/gsd_legend.c:239 ../lib/ogsf/gs3.c:125 ../lib/ogsf/gs3.c:189
+#: ../lib/ogsf/gs3.c:264 ../lib/ogsf/gs3.c:336 ../lib/ogsf/gs3.c:442
+#: ../lib/ogsf/gs3.c:529 ../lib/ogsf/gs3.c:588 ../lib/ogsf/gs3.c:645
+#: ../lib/ogsf/gs3.c:716 ../lib/ogsf/gs3.c:786 ../lib/gis/legal_name.c:94
+#: ../lib/gis/legal_name.c:97 ../lib/manage/do_rename.c:71
+#: ../lib/manage/do_remove.c:73
 #, c-format
-msgid "Unsupported column type %d"
-msgstr "Neatbalstīts kolonas tips %d"
+msgid "Raster map <%s> not found"
+msgstr "Rastra karte <%s> nav atrasta"
-#: ../lib/vector/Vlib/write_pg.c:2089
-msgid "Invalid value for FID column: NULL"
+#: ../lib/rst/interp_float/resout2d.c:77
+msgid "Temporarily changing the region to desired resolution..."
 msgstr ""
-#: ../lib/vector/Vlib/write_pg.c:2181
+#: ../lib/rst/interp_float/resout2d.c:103
 #, c-format
-msgid "Invalid feature %d (max: %d)"
+msgid "First change your rows number(%d) to %d"
 msgstr ""
-#: ../lib/vector/Vlib/write_pg.c:2195
+#: ../lib/rst/interp_float/resout2d.c:110
 #, c-format
-msgid "Invalid feature type (%d) for node"
+msgid "First change your columns number(%d) to %d"
 msgstr ""
-#: ../lib/vector/Vlib/write_pg.c:2199
-#, c-format
-msgid "Invalid node %d (%d)"
+#: ../lib/rst/interp_float/resout2d.c:264
+msgid "No color table for input raster map -- will not create color table"
 msgstr ""
-#: ../lib/vector/Vlib/write_pg.c:2277
+#: ../lib/rst/interp_float/resout2d.c:458
+msgid "Changing the region back to initial..."
+msgstr ""
+#: ../lib/rst/interp_float/input2d.c:58
 #, c-format
-msgid "Unable to determine next left/right edge for edge %d"
+msgid "Mask raster map <%s> not found"
 msgstr ""
-#: ../lib/vector/Vlib/write_pg.c:2282
-msgid "Unable to insert new edge. Topology not available."
+#: ../lib/rst/interp_float/input2d.c:81
+msgid "Bitmap mask created"
 msgstr ""
-#: ../lib/vector/Vlib/write_pg.c:2381 ../lib/vector/Vlib/write_pg.c:2388
-msgid "Invalid topology"
-msgstr "Nederīga topoloģija"
-#: ../lib/vector/Vlib/write_pg.c:2587 ../lib/vector/Vlib/write_pg.c:2684
+#: ../lib/rst/interp_float/interp2d.c:232
 #, c-format
-msgid "Attempt to access non-existing feature %d"
+msgid ""
+"Overshoot - increase in tension suggested. Overshoot occurs at (%d,%d) cell. "
+"Z-value %f, zmin %f, zmax %f."
 msgstr ""
-#: ../lib/vector/Vlib/write_pg.c:2618
-msgid "Unable to determine next left/right edge"
+#: ../lib/rst/interp_float/write2d.c:53 ../lib/rst/interp_float/write2d.c:64
+#: ../lib/rst/interp_float/write2d.c:79 ../lib/rst/interp_float/write2d.c:88
+#: ../lib/rst/interp_float/write2d.c:96 ../lib/rst/interp_float/write2d.c:104
+msgid "Cannot write files"
 msgstr ""
-#: ../lib/vector/Vlib/write_pg.c:2704
-msgid "Unable to create new face"
+#: ../lib/rst/interp_float/segmen2d_parallel.c:109
+msgid "Starting parallel work"
 msgstr ""
-#: ../lib/vector/Vlib/write_pg.c:2842 ../lib/vector/Vlib/write_pg.c:2854
-#, c-format
-msgid "Unable to delete node %d"
+#: ../lib/rst/interp_float/segmen2d_parallel.c:188
+#: ../lib/rst/interp_float/segmen2d.c:133
+msgid ""
+"Taking too long to find points for interpolation - please change the region "
+"to area where your points are. Continuing calculations..."
 msgstr ""
-#: ../lib/vector/Vlib/write_pg.c:2910 ../lib/vector/Vlib/ascii.c:404
-#: ../lib/vector/Vlib/write_ogr.c:192 ../lib/db/dbmi_client/db.c:41
-#: ../lib/db/dbmi_client/copy_tab.c:107 ../lib/db/dbmi_client/copy_tab.c:127
+#: ../lib/rst/interp_float/vinput2d.c:94
 #, c-format
-msgid "Unable to start driver <%s>"
+msgid "Vector map <%s> is not 3D"
 msgstr ""
-#: ../lib/vector/Vlib/net_analyze.c:201 ../lib/vector/Vlib/graph.c:226
-#, c-format
-msgid "dglShortestPath error: %s"
-msgstr "dglShortestPath kļūda: %s"
+#: ../lib/rst/interp_float/vinput2d.c:97
+msgid "Loading data from attribute table ..."
+msgstr ""
-#: ../lib/vector/Vlib/net_analyze.c:291 ../lib/vector/Vlib/net_analyze.c:332
+#: ../lib/rst/interp_float/vinput2d.c:115
+#: ../lib/rst/interp_float/vinput2d.c:129 ../lib/db/dbmi_client/copy_tab.c:291
 #, c-format
-msgid "Unable to find point with defined unique category for node <%d>."
+msgid "Column <%s> not found"
 msgstr ""
-#: ../lib/vector/Vlib/net_analyze.c:295 ../lib/vector/Vlib/net_analyze.c:336
+#: ../lib/rst/interp_float/vinput2d.c:118
+#: ../lib/rst/interp_float/vinput2d.c:131
 #, c-format
-msgid ""
-"There exists more than one point on node <%d> with unique category in field  <%d>.\n"
-"The unique category layer may not be valid."
+msgid "Data type of column <%s> must be numeric"
 msgstr ""
-#: ../lib/vector/Vlib/net_analyze.c:452
-msgid "Wrong line direction in Vect_net_get_line_cost()"
-msgstr "Nebija iespējams izveidot jaunu novietojumu. Novietojums <%s> jau eksistē."
-#: ../lib/vector/Vlib/map.c:139 ../lib/vector/Vlib/map.c:245
-msgid "Vector map name is not SQL compliant"
+#: ../lib/rst/interp_float/vinput2d.c:142
+msgid "Reading features from vector map ..."
 msgstr ""
-#: ../lib/vector/Vlib/map.c:143
+#: ../lib/rst/interp_float/vinput2d.c:174
 #, c-format
-msgid "Unable to find vector map <%s> in <%s>"
+msgid "Database record for cat %d not found"
 msgstr ""
-#: ../lib/vector/Vlib/map.c:155 ../lib/vector/Vlib/map.c:249
-#: ../lib/vector/Vlib/open.c:821
-#, c-format
-msgid "Vector map <%s> already exists and will be overwritten"
+#: ../lib/rst/interp_float/vinput2d.c:192
+msgid "Negative value of smoothing detected: sm must be >= 0"
 msgstr ""
-#: ../lib/vector/Vlib/map.c:159 ../lib/vector/Vlib/open.c:813
-#: ../lib/vector/Vlib/open.c:826
-#, c-format
-msgid "Unable to delete vector map <%s>"
+#: ../lib/rst/interp_float/vinput2d.c:256
+msgid "Strip exists with insufficient data"
 msgstr ""
-#: ../lib/vector/Vlib/map.c:179 ../lib/vector/Vlib/map.c:267
+#: ../lib/rst/interp_float/vinput2d.c:270
 #, c-format
-msgid "Unable to copy vector map <%s> to <%s>"
+msgid "There are points outside specified 2D/3D region - %d points ignored"
 msgstr ""
-#: ../lib/vector/Vlib/map.c:331 ../lib/vector/Vlib/map.c:462
+#: ../lib/rst/interp_float/vinput2d.c:273
 #, c-format
-msgid "Unable to delete table <%s>"
+msgid "Ignoring %d points (too dense)"
 msgstr ""
-#: ../lib/vector/Vlib/map.c:346
+#: ../lib/rst/interp_float/vinput2d.c:277
 #, c-format
-msgid "Unable to create index for table <%s>, key <%s>"
+msgid ""
+"%d points given for interpolation (after thinning) is less than given NPMIN="
+"%d"
 msgstr ""
-#: ../lib/vector/Vlib/map.c:402
-#, c-format
-msgid "Ignoring invalid mapset: %s"
+#: ../lib/rst/interp_float/vinput2d.c:282
+msgid "Zero points in the given region"
 msgstr ""
-#: ../lib/vector/Vlib/map.c:407
+#: ../lib/rst/interp_float/vinput2d.c:287
 #, c-format
-msgid "Invalid vector map name <%s>"
+msgid ""
+"Segmentation parameters set to invalid values: npmin= %d, segmax= %d for "
+"smooth connection of segments, npmin > segmax (see manual)"
 msgstr ""
-#: ../lib/vector/Vlib/map.c:417
+#: ../lib/rst/interp_float/vinput2d.c:293
 #, c-format
-msgid "Unable to open header file for vector map <%s>"
+msgid ""
+"There are less than %d points for interpolation. No segmentation is "
+"necessary, to run the program faster set segmax=%d (see manual)"
 msgstr ""
-#: ../lib/vector/Vlib/map.c:449
+#: ../lib/rst/interp_float/vinput2d.c:297
 #, c-format
-msgid "Unable to find table <%s> linked to vector map <%s>"
+msgid "Number of points from vector map %d"
 msgstr ""
-#: ../lib/vector/Vlib/map.c:472
+#: ../lib/rst/interp_float/vinput2d.c:298
 #, c-format
-msgid "Table <%s> linked to vector map <%s> does not exist"
+msgid "Number of points outside of 2D/3D region %d"
 msgstr ""
-#: ../lib/vector/Vlib/map.c:485
+#: ../lib/rst/interp_float/vinput2d.c:300
 #, c-format
-msgid "Unable to open directory '%s'"
+msgid "Number of points being used %d"
 msgstr ""
-#: ../lib/vector/Vlib/map.c:499
-#, c-format
-msgid "Unable to delete file '%s'"
+#: ../lib/rst/interp_float/vinput2d.c:333
+msgid "Some points outside of region (ignored)"
 msgstr ""
-#: ../lib/vector/Vlib/map.c:519
-#, c-format
-msgid "Unable to rename directory '%s' to '%s'"
+#: ../lib/rst/interp_float/vinput2d.c:339
+msgid "Unable to allocate memory"
 msgstr ""
-#: ../lib/vector/Vlib/map.c:528
+#: ../lib/rst/interp_float/vinput2d.c:347
 #, c-format
-msgid "Unable to remove directory '%s': %s"
+msgid "Unable to insert %f,%f,%f a = %d"
 msgstr ""
-#: ../lib/vector/Vlib/dangles.c:148
-msgid "Changed"
-msgstr "Mainīts"
-#: ../lib/vector/Vlib/dangles.c:151
-msgid "Removed"
-msgstr "Noņemts"
-#: ../lib/vector/Vlib/dangles.c:154
-msgid "Selected"
-msgstr "Izvēlēts"
-#: ../lib/vector/Vlib/dangles.c:262
+#: ../lib/raster/get_row.c:34 ../lib/raster/get_row.c:898
 #, c-format
-msgid "%s lines: %d"
-msgstr "%s līnijas: %d"
+msgid "Reading raster map <%s@%s> request for row %d is outside region"
+msgstr ""
-#: ../lib/vector/Vlib/dangles.c:263
+#: ../lib/raster/get_row.c:93 ../lib/raster/get_row.c:135
+#: ../lib/raster/get_row.c:142 ../lib/raster/get_row.c:185
+#: ../lib/raster/get_row.c:189
 #, c-format
-msgid "%s dangles: %d"
+msgid "Error reading raster data for row %d of <%s>"
 msgstr ""
-#: ../lib/vector/Vlib/net_build.c:101 ../lib/vector/Vlib/net_build.c:727
-msgid "Building graph..."
-msgstr "Tiek veidots grafs..."
-#: ../lib/vector/Vlib/net_build.c:143 ../lib/vector/Vlib/net_build.c:775
-msgid "Unable to build network graph"
-msgstr "Nav iespējams izveidot tīkla grafu"
-#: ../lib/vector/Vlib/net_build.c:149 ../lib/vector/Vlib/net_build.c:781
-msgid "Forward costs column not specified"
+#: ../lib/raster/get_row.c:100 ../lib/raster/get_row.c:166
+#, c-format
+msgid "Error uncompressing raster data for row %d of <%s>"
 msgstr ""
-#: ../lib/vector/Vlib/net_build.c:156
-msgid "Turntable field < 1"
-msgstr ""
-#: ../lib/vector/Vlib/net_build.c:172
+#: ../lib/raster/get_row.c:225
 #, c-format
-msgid "Turntable column <%s> not found in table <%s>"
+msgid "Error reading raster data via GDAL for row %d of <%s>"
 msgstr ""
-#: ../lib/vector/Vlib/net_build.c:182 ../lib/vector/Vlib/net_build.c:223
-#: ../lib/vector/Vlib/net_build.c:508 ../lib/vector/Vlib/net_build.c:526
-#: ../lib/vector/Vlib/net_build.c:809 ../lib/vector/Vlib/net_build.c:827
-#: ../lib/vector/Vlib/net_build.c:988
+#: ../lib/raster/get_row.c:827 ../lib/raster/get_row.c:832
+#: ../lib/raster/get_row.c:842
 #, c-format
-msgid "Data type of column <%s> not supported (must be numeric)"
+msgid "Error reading null data for row %d of <%s>"
 msgstr ""
-#: ../lib/vector/Vlib/net_build.c:202 ../lib/vector/Vlib/net_build.c:967
-msgid "Setting node costs..."
-msgstr ""
-#: ../lib/vector/Vlib/net_build.c:216 ../lib/vector/Vlib/net_build.c:501
-#: ../lib/vector/Vlib/net_build.c:519 ../lib/vector/Vlib/net_build.c:802
-#: ../lib/vector/Vlib/net_build.c:820 ../lib/vector/Vlib/net_build.c:981
-#: ../lib/vector/Vlib/ascii.c:756
+#: ../lib/raster/get_row.c:848
 #, c-format
-msgid "Column <%s> not found in table <%s>"
+msgid "Error uncompressing null data for row %d of <%s>"
 msgstr ""
-#: ../lib/vector/Vlib/net_build.c:277 ../lib/vector/Vlib/net_build.c:1032
+#: ../lib/raster/get_row.c:882 ../lib/raster/get_row.c:885
 #, c-format
-msgid "Database record for node %d (cat = %d) not found (cost set to 0)"
+msgid "Error reading null row %d for <%s>"
 msgstr ""
-#: ../lib/vector/Vlib/net_build.c:332 ../lib/vector/Vlib/net_build.c:352
-msgid "Cannot add network arc for virtual node connection."
-msgstr ""
+#: ../lib/raster/auto_mask.c:69
+msgid "Unable to open automatic MASK file"
+msgstr "Neiespējami atvērt automātisku MASK failu"
-#: ../lib/vector/Vlib/net_build.c:364
+#: ../lib/raster/quant_rw.c:88
 #, c-format
-msgid ""
-"There exists more than one point of node <%d> with unique category field  <%d>.\n"
-"The unique categories layer is not valid therefore you will probably get incorrect results."
+msgid "Unable to read fp range for raster map <%s>"
 msgstr ""
-#: ../lib/vector/Vlib/net_build.c:393
+#: ../lib/raster/quant_rw.c:92
 #, c-format
-msgid ""
-"Unable to find point representing intersection <%d> in unique categories field <%d>.\n"
-"Cost for the intersection was set to 0.\n"
+msgid "Raster map <%s> is empty"
 msgstr ""
-#: ../lib/vector/Vlib/net_build.c:407
+#: ../lib/raster/quant_rw.c:157
 #, c-format
-msgid ""
-"Unable to find node for point representing intersection <%d> in unique categories field <%d>.\n"
+msgid "Unable to write quant rules: raster map <%s> is integer"
 msgstr ""
-#: ../lib/vector/Vlib/net_build.c:432
+#: ../lib/raster/quant_rw.c:166
 #, c-format
-msgid "Database record for turn with cat = %d in not found. (The turn was skipped."
+msgid "Unable to write quant rules for raster map <%s>"
 msgstr ""
-#: ../lib/vector/Vlib/net_build.c:465
-msgid "Cannot add network arc representing turn."
+#: ../lib/raster/init.c:61
+msgid "Raster library not initialized. Programmer forgot to call Rast_init()."
 msgstr ""
-#: ../lib/vector/Vlib/net_build.c:487 ../lib/vector/Vlib/net_build.c:788
-msgid "Arc field < 1"
+#: ../lib/raster/init.c:109
+#, c-format
+msgid "Unknown compression method <%s>, using default ZLIB"
 msgstr ""
-#: ../lib/vector/Vlib/net_build.c:539 ../lib/vector/Vlib/net_build.c:840
-msgid "Registering arcs..."
+#: ../lib/raster/init.c:113
+msgid ""
+"No compression is not supported for GRASS raster maps, using default ZLIB"
 msgstr ""
-#: ../lib/vector/Vlib/net_build.c:558
+#: ../lib/raster/init.c:118
 #, c-format
-msgid ""
-"Line with id <%d> has more unique categories defined in field <%d>.\n"
+msgid "This GRASS version does not support %s compression, using default ZLIB"
 msgstr ""
-#: ../lib/vector/Vlib/net_build.c:579
+#: ../lib/raster/alloc_cell.c:151
 #, c-format
-msgid "Database record for line %d (cat = %d, forward/both direction(s)) not found (cost was set to 0)"
+msgid "Rast__null_bitstream_size: cols (%d) is negative"
 msgstr ""
-#: ../lib/vector/Vlib/net_build.c:596
+#: ../lib/raster/gdal.c:88
 #, c-format
-msgid "Database record for line %d (cat = %d, backword direction) not found(cost was set to 0)"
-msgstr ""
+msgid "Unable to locate symbol <%s>"
+msgstr "Nevar atrast simbolu <%s>"
-#: ../lib/vector/Vlib/net_build.c:658 ../lib/vector/Vlib/net_build.c:1064
-msgid "Flattening the graph..."
-msgstr ""
+#: ../lib/raster/gdal.c:144
+msgid "Unable to load GDAL library"
+msgstr "Nevar ielādēt GDAL bibliotēku"
-#: ../lib/vector/Vlib/net_build.c:661 ../lib/vector/Vlib/net_build.c:1067
-#: ../lib/vector/Vlib/graph.c:105 ../lib/vector/neta/flow.c:331
-msgid "GngFlatten error"
-msgstr ""
+#: ../lib/raster/gdal.c:374
+msgid "Unable to open GDAL file"
+msgstr "Nevar atvērt GDAL failu"
-#: ../lib/vector/Vlib/net_build.c:667 ../lib/vector/Vlib/net_build.c:1073
-msgid "Graph was built"
-msgstr "Grafs ir izveidots"
+#: ../lib/raster/gdal.c:478 ../lib/raster/open.c:597
+#, c-format
+msgid "Invalid map type <%d>"
+msgstr "Nederīgs kartes tips <%d>"
-#: ../lib/vector/Vlib/net_build.c:869
+#: ../lib/raster/gdal.c:484
 #, c-format
-msgid "Database record for line %d (cat = %d, forward/both direction(s)) not found (forward/both direction(s) of line skipped)"
+msgid "Unable to get <%s> driver"
+msgstr "Nav iespējams saņemt <%s> dzinēju"
+#: ../lib/raster/gdal.c:493
+#, c-format
+msgid "Unable to create <%s> dataset using <%s> driver"
 msgstr ""
-#: ../lib/vector/Vlib/net_build.c:888
+#: ../lib/raster/gdal.c:501
 #, c-format
-msgid "Database record for line %d (cat = %d, backword direction) not found(direction of line skipped)"
+msgid ""
+"Driver <%s> does not support direct writing. Using MEM driver for "
+"intermediate dataset."
 msgstr ""
-#: ../lib/vector/Vlib/net_build.c:937
-msgid "Cannot add network arc"
+#: ../lib/raster/gdal.c:507
+msgid "Unable to get in-memory raster driver"
 msgstr ""
-#: ../lib/vector/Vlib/open.c:138
+#: ../lib/raster/gdal.c:514
 #, c-format
-msgid "Programmer requested unknown access level %d"
+msgid "Unable to create <%s> dataset using memory driver"
 msgstr ""
-#: ../lib/vector/Vlib/open.c:232
+#: ../lib/raster/gdal.c:518
 #, c-format
-msgid "Vector map <%s> not found in current mapset"
-msgstr "Vektoru karte <%s> pašreizējā karšu kopā nav atrasta"
+msgid "Driver <%s> does not support creating rasters"
+msgstr ""
-#: ../lib/vector/Vlib/open.c:252
-msgid "Temporary vector maps can be accessed only in the current mapset"
+#: ../lib/raster/gdal.c:534
+msgid "Unable to set geo transform"
 msgstr ""
-#: ../lib/vector/Vlib/open.c:277
-msgid "Vector map which is not in the current mapset cannot be opened for update"
+#: ../lib/raster/gdal.c:538
+msgid "Unable to set projection"
 msgstr ""
-#: ../lib/vector/Vlib/open.c:311
+#: ../lib/raster/gdal.c:542
 #, c-format
-msgid "Unable to read header file of vector map <%s>"
+msgid "Unable to create cell_misc/%s/gdal file"
 msgstr ""
-#: ../lib/vector/Vlib/open.c:352
+#: ../lib/raster/gdal.c:558
 #, c-format
-msgid "Unable to open topology file for vector map <%s>"
+msgid "Error writing cell_misc/%s/gdal file"
 msgstr ""
-#: ../lib/vector/Vlib/open.c:393 ../lib/vector/Vlib/cindex.c:539
+#: ../lib/raster/gdal.c:606
 #, c-format
-msgid "Unable to open category index file for vector map <%s>"
+msgid "Unable to create output file <%s> using driver <%s>"
 msgstr ""
-#: ../lib/vector/Vlib/open.c:419
-#, c-format
-msgid "Unable to open vector map <%s> on level %d. Try to rebuild vector topology with v.build."
+#: ../lib/raster/set_window.c:48
+msgid "Rast_set_window() called while window split"
 msgstr ""
-#: ../lib/vector/Vlib/open.c:445
-#, c-format
-msgid "Building topology for OGR layer <%s> from datasource '%s'..."
+#: ../lib/raster/set_window.c:131
+msgid ""
+"Rast_set_read_window(): projection/zone differs from that of currently open "
+"raster maps"
 msgstr ""
-#: ../lib/vector/Vlib/open.c:453
+#: ../lib/raster/set_window.c:158
 #, c-format
-msgid "Unable to open vector map <%s> on level %d"
+msgid "Input window changed while maps are open for read. Map name <%s>"
 msgstr ""
-#: ../lib/vector/Vlib/open.c:507
+#: ../lib/raster/set_window.c:174
 #, c-format
-msgid "Unable to open history file for vector map <%s>"
+msgid "Output window changed while maps are open for write. Map name <%s>"
 msgstr ""
-#: ../lib/vector/Vlib/open.c:777
+#: ../lib/raster/put_title.c:28
 #, c-format
-msgid "Unable to create vector map: <%s> is not in the current mapset (%s)"
-msgstr ""
+msgid "category information for [%s] in [%s] missing or invalid"
+msgstr "kategorijas informācija priekš [%s] iekš [%s] trūkst vai ir nederīga"
-#: ../lib/vector/Vlib/open.c:786
+#: ../lib/raster/put_title.c:37
+msgid "G_put_title - can't create a temp file"
+msgstr "G_put_title - nevar izveidot pagaidu failu"
+#: ../lib/raster/put_title.c:53
 #, c-format
-msgid "Unable to create vector map: <%s> is not SQL compliant"
+msgid "category information for [%s] in [%s] invalid"
+msgstr "kategorijas informācija priekš [%s] iekš [%s] ir nederīga"
+#: ../lib/raster/put_title.c:60
+msgid "G_put_title - can't reopen temp file"
 msgstr ""
-#: ../lib/vector/Vlib/open.c:846
+#: ../lib/raster/put_title.c:67
 #, c-format
-msgid "Unable to open history file of vector map <%s>"
-msgstr ""
+msgid "can't write category information for [%s] in [%s]"
+msgstr "nevar ierakstīt kategorijas informāciju priekš [%s] iekš [%s]"
-#: ../lib/vector/Vlib/open.c:887
+#: ../lib/raster/mask_info.c:43
 #, c-format
-msgid "Using OGR/%s format"
-msgstr ""
+msgid "<%s> in mapset <%s>"
+msgstr "<%s>karšu kopā <%s>"
-#: ../lib/vector/Vlib/open.c:891
-msgid "Using PostGIS Topology format"
-msgstr ""
+#: ../lib/raster/mask_info.c:46
+msgid "none"
+msgstr "neviens"
-#: ../lib/vector/Vlib/open.c:893
-msgid "Using PostGIS format"
-msgstr ""
+#: ../lib/raster/mask_info.c:49
+msgid "not known"
+msgstr "nav zināms"
-#: ../lib/vector/Vlib/open.c:896
-msgid "Using native format"
+#: ../lib/raster/range.c:101
+#, c-format
+msgid "Unable to read fp range file for <%s>"
 msgstr ""
-#: ../lib/vector/Vlib/open.c:985
+#: ../lib/raster/range.c:168
 #, c-format
-msgid "Unable to stat file <%s>"
+msgid "Unable to read quant rules for raster map <%s>"
 msgstr ""
-#: ../lib/vector/Vlib/open.c:1049
+#: ../lib/raster/range.c:205 ../lib/raster/range.c:225
 #, c-format
-msgid "unknown %d (update Vect_maptype_info)"
+msgid "Unable to read range file for <%s>"
 msgstr ""
-#: ../lib/vector/Vlib/open.c:1138
-msgid "Size of 'coor' file differs from value saved in topology file"
+#: ../lib/raster/range.c:263 ../lib/raster/range.c:269
+#: ../lib/raster/range.c:299 ../lib/raster/range.c:313
+#, c-format
+msgid "Unable to write range file for <%s>"
 msgstr ""
-#: ../lib/vector/Vlib/open.c:1149 ../lib/vector/Vlib/open.c:1248
+#: ../lib/raster/color_rand.c:33
 #, c-format
-msgid "Please rebuild topology for vector map <%s@%s>"
+msgid "Rast_make_random_colors: min (%d) > max (%d)"
 msgstr ""
-#: ../lib/vector/Vlib/open.c:1237
-msgid "Size of 'coor' file differs from value saved in sidx file"
-msgstr ""
+#: ../lib/raster/close.c:77 ../lib/raster/close.c:110
+#, c-format
+msgid "Invalid descriptor: %d"
+msgstr "Nepareizs deskriptors: %d"
-#: ../lib/vector/Vlib/open.c:1317
-msgid "Unable to open OGR file"
+#: ../lib/raster/close.c:392 ../lib/raster/close.c:520
+#, c-format
+msgid "Unable to rename null file '%s' to '%s': %s"
 msgstr ""
-#: ../lib/vector/Vlib/open.c:1343
-msgid "OGR output also detected, using OGR"
+#: ../lib/raster/close.c:462
+#, c-format
+msgid "Unable to rename cell file '%s' to '%s': %s"
 msgstr ""
-#: ../lib/vector/Vlib/open_pg.c:109 ../lib/vector/Vlib/open_pg.c:267
-msgid "No feature tables found in database."
+#: ../lib/raster/close.c:542
+msgid "unable to write f_format file for CELL maps"
 msgstr ""
-#: ../lib/vector/Vlib/open_pg.c:133
+#: ../lib/raster/raster_metadata.c:109
 #, c-format
-msgid "Feature table <%s> not found in 'geometry_columns'"
+msgid "Unable to read <%s> for raster map <%s@%s>"
 msgstr ""
-#: ../lib/vector/Vlib/open_pg.c:181
-msgid "Topology schema not found."
-msgstr ""
-#: ../lib/vector/Vlib/open_pg.c:193 ../lib/vector/Vlib/open_ogr.c:145
+#: ../lib/raster/raster_metadata.c:119 ../lib/raster/raster_metadata.c:148
 #, c-format
-msgid "Unable to open feature index file for vector map <%s>"
+msgid "Error closing <%s> metadata file for raster map <%s@%s>"
 msgstr ""
-#: ../lib/vector/Vlib/open_pg.c:273
+#: ../lib/raster/raster_metadata.c:142
 #, c-format
-msgid "PostGIS layer <%s.%s> already exists and will be overwritten"
+msgid "Unable to create <%s> metadata file for raster map <%s@%s>"
 msgstr ""
-#: ../lib/vector/Vlib/open_pg.c:276
+#: ../lib/raster/get_cellhd.c:66
 #, c-format
-msgid "Unable to delete PostGIS layer <%s>"
+msgid ""
+"Unable to read header file for raster map <%s@%s>. It is a reclass of raster "
+"map <%s@%s> %s"
 msgstr ""
-#: ../lib/vector/Vlib/open_pg.c:282
-#, c-format
-msgid "PostGIS layer <%s.%s> already exists in database '%s'"
+#: ../lib/raster/get_cellhd.c:70
+msgid "which is missing."
 msgstr ""
-#: ../lib/vector/Vlib/open_pg.c:390
-msgid "No key column detected."
+#: ../lib/raster/get_cellhd.c:71
+msgid "whose header file can't be opened."
 msgstr ""
-#: ../lib/vector/Vlib/open_pg.c:462 ../lib/vector/Vlib/open_pg.c:474
+#: ../lib/raster/get_cellhd.c:76
 #, c-format
-msgid "Execution failed: %s"
+msgid "Unable to open header file for raster map <%s@%s>"
 msgstr ""
-#: ../lib/vector/Vlib/open_pg.c:476
+#: ../lib/raster/interp.c:211
 #, c-format
-msgid "PostGIS topology schema <%s> dropped"
-msgstr ""
+msgid "Unknown interpolation method: %s"
+msgstr "Nezināma interpolācijas metode: %s"
-#: ../lib/vector/Vlib/open_pg.c:559
-msgid "Connection to PostgreSQL database failed. Try to set up username/password by db.login."
+#: ../lib/raster/cats.c:109
+#, c-format
+msgid "Category support for <%s@%s> missing"
 msgstr ""
-#: ../lib/vector/Vlib/open_pg.c:566
-msgid "Unable to get database name"
-msgstr ""
-#: ../lib/vector/Vlib/open_pg.c:571
+#: ../lib/raster/cats.c:112
 #, c-format
-msgid "<%s> is not PostGIS database. DB table 'spatial_ref_sys' not found."
+msgid "Category support for <%s@%s> invalid"
 msgstr ""
-#: ../lib/vector/Vlib/open_pg.c:580
+#: ../lib/raster/cats.c:145
 #, c-format
-msgid "PostGIS Topology extension not found in the database <%s>"
+msgid "Category support for vector map <%s@%s> missing"
 msgstr ""
-#: ../lib/vector/Vlib/open_pg.c:667
-msgid "Empty bounding box"
-msgstr ""
-#: ../lib/vector/Vlib/open_pg.c:768
+#: ../lib/raster/cats.c:149
 #, c-format
-msgid "Inconsistency in topology: unable to read node %d"
+msgid "Category support for vector map <%s@%s> invalid"
 msgstr ""
-#: ../lib/vector/Vlib/open_pg.c:834
+#: ../lib/raster/cats.c:971
 #, c-format
-msgid "Inconsistency in topology: node %d - unexpected feature type %d"
+msgid "Unable to open %s file for map <%s>"
 msgstr ""
-#: ../lib/vector/Vlib/open_pg.c:1003
+#: ../lib/raster/format.c:162
 #, c-format
-msgid "Area %d without boundary detected"
-msgstr ""
+msgid "Fail of initial read of compressed file [%s in %s]"
+msgstr "Izgāzusies arhivētā faila lasīšanas inicializācija [%s iekš %s]"
-#: ../lib/vector/Vlib/open_pg.c:1061
+#: ../lib/raster/format.c:176
 #, c-format
-msgid "Isle %d without boundary detected"
+msgid "Fail of initial read of compressed null file [%s in %s]"
 msgstr ""
-#: ../lib/vector/Vlib/open_pg.c:1128
-msgid "Unable to get map bounding box from topology"
+#: ../lib/raster/color_rules.c:120
+msgid "syntax error in the color rule"
 msgstr ""
-#: ../lib/vector/Vlib/open_pg.c:1135
-#, c-format
-msgid ""
-"Unable to parse map bounding box:\n"
-"%s"
+#: ../lib/raster/color_rules.c:122
+msgid "syntax error in the color format"
 msgstr ""
-#: ../lib/vector/Vlib/open_pg.c:1159
-#, c-format
-msgid "Different number of nodes detected (%d, %d)"
-msgstr ""
+#: ../lib/raster/color_rules.c:130
+msgid "percentage not in range 0-100"
+msgstr "procenti nav diapazonā 0 - 100"
-#: ../lib/vector/Vlib/open_pg.c:1187 ../lib/vector/Vlib/open_pg.c:1209
-#, c-format
-msgid "Different number of areas detected (%d, %d)"
-msgstr ""
+#: ../lib/raster/color_rules.c:132
+msgid "invalid value"
+msgstr "nederīga vērtība"
-#: ../lib/vector/Vlib/open_pg.c:1380
-msgid "To be implemented: isles not attached in Topo-Geo-only mode"
-msgstr ""
+#: ../lib/raster/color_rules.c:134
+msgid "unknown error"
+msgstr "nezināma kļūda"
-#: ../lib/vector/Vlib/open_pg.c:1569
+#: ../lib/raster/color_rules.c:180
 #, c-format
-msgid "Inconsistency in topology: number of points %d (should be %d)"
+msgid "bad rule (%s): [%s]"
 msgstr ""
-#: ../lib/vector/Vlib/open_pg.c:1614
-#, c-format
-msgid "Inconsistency in topology: number of lines %d (should be %d)"
+#: ../lib/raster/color_rules.c:232
+msgid "Unknown error reading color rule"
 msgstr ""
-#: ../lib/vector/Vlib/open_pg.c:1668
+#: ../lib/raster/color_rules.c:330
 #, c-format
-msgid "Inconsistency in topology: number of centroids %d (should be %d)"
+msgid "Unable to load color rules <%s>"
+msgstr "Nav iespējams ielādēt krāsu noteikumus <%s>"
+#: ../lib/raster/null_val.c:64
+msgid "EmbedGivenNulls: wrong data type"
 msgstr ""
-#: ../lib/vector/Vlib/cats.c:45
-msgid "Vect_new_cats_struct(): Out of memory"
+#: ../lib/raster/null_val.c:114
+msgid "Rast_set_null_value: wrong data type!"
 msgstr ""
-#: ../lib/vector/Vlib/cats.c:127
-#, c-format
-msgid "Too many categories (%d), unable to set cat %d (layer %d)"
+#: ../lib/raster/window.c:31
+msgid ""
+"Internal error: Rast_get_window() called with split window. Use "
+"Rast_get_input_window() or Rast_get_output_window() instead."
 msgstr ""
-#: ../lib/vector/Vlib/cats.c:419
-#, c-format
-msgid "Unable to convert category string '%s' (from '%s') to category range"
+#: ../lib/raster/window.c:90
+msgid ""
+"Internal error: Rast_window_rows() called with split window. Use "
+"Rast_input_window_rows() or Rast_output_window_rows() instead."
 msgstr ""
-#: ../lib/vector/Vlib/cats.c:572 ../lib/vector/Vlib/cats.c:668
-msgid "Layer number must be > 0 for category constraints"
+#: ../lib/raster/window.c:125
+msgid ""
+"Internal error: Rast_window_cols() called with split window. Use "
+"Rast_input_window_cols() or Rast_output_window_cols() instead."
 msgstr ""
-#: ../lib/vector/Vlib/cats.c:585
+#: ../lib/raster/open.c:191
 #, c-format
-msgid "'%s' and '%s' parameters were supplied, cats will be ignored"
+msgid ""
+"Unable to open raster map <%s@%s> since it is a reclass of raster map <%s@"
+"%s> which does not exist"
 msgstr ""
-#: ../lib/vector/Vlib/cats.c:593
+#: ../lib/raster/open.c:196
 #, c-format
-msgid "Loading categories from table <%s>..."
-msgstr "Ielādē kategorijas no tabulas <%s>..."
+msgid "Error reading reclass file for raster map <%s>"
+msgstr ""
-#: ../lib/vector/Vlib/cats.c:603 ../lib/db/dbmi_client/select.c:317
+#: ../lib/raster/open.c:207
 #, c-format
-msgid "Unable select records from table <%s>"
+msgid "Error reading map type for raster map <%s>"
 msgstr ""
-#: ../lib/vector/Vlib/cats.c:605
+#: ../lib/raster/open.c:215
 #, c-format
-msgid "One category loaded"
-msgid_plural "%d categories loaded"
-msgstr[0] "Ielādēta %d kategorija"
-msgstr[1] "Ielādētas %d kategorijas"
-msgstr[2] "Ielādēts %d kategoriju"
+msgid "Raster map <%s@%s>: format field in header file invalid"
+msgstr ""
-#: ../lib/vector/Vlib/cats.c:627
+#: ../lib/raster/open.c:234
 #, c-format
-msgid "No categories selected with '%s' option"
+msgid "Compression with %s is not supported"
 msgstr ""
-#: ../lib/vector/Vlib/cats.c:637
+#: ../lib/raster/open.c:238
 #, c-format
-msgid "%d errors in '%s' option"
+msgid ""
+"Raster map <%s> is in different projection than current region. Found <%s>, "
+"should be <%s>."
 msgstr ""
-#: ../lib/vector/Vlib/header.c:86
+#: ../lib/raster/open.c:245
 #, c-format
-msgid "Unable to create header file for vector map <%s>"
+msgid "Raster map <%s> is in different zone (%d) than current region (%d)"
 msgstr ""
-#: ../lib/vector/Vlib/header.c:129
+#: ../lib/raster/open.c:250
 #, c-format
-msgid "Unable to open header file of vector <%s>"
+msgid "Raster map <%s>: bytes per cell (%d) too large"
 msgstr ""
-#: ../lib/vector/Vlib/header.c:137
+#: ../lib/raster/open.c:275
 #, c-format
-msgid "Corrupted row in head: %s"
+msgid ""
+"Raster map <%s@%s> is a GDAL link but GRASS is compiled without GDAL support"
 msgstr ""
-#: ../lib/vector/Vlib/header.c:175
+#: ../lib/raster/open.c:283
 #, c-format
-msgid "Unknown keyword '%s' in vector head"
+msgid "Unable to open %s file for raster map <%s@%s>"
 msgstr ""
-#: ../lib/vector/Vlib/header.c:552 ../lib/gis/proj3.c:121
-msgid "Unknown projection"
-msgstr "Nezināma projekcija"
-#: ../lib/vector/Vlib/level_two.c:23
+#: ../lib/raster/open.c:320
 #, c-format
-msgid "Vector map <%s> is not open at topological level"
+msgid "Error reading format for <%s@%s>"
 msgstr ""
-#: ../lib/vector/Vlib/level_two.c:284
-#, c-format
-msgid "Invalid node id: %d"
-msgstr "Nederīgs mezgla ID: %d"
+#: ../lib/raster/open.c:525
+msgid "Unable to create GDAL link"
+msgstr ""
-#: ../lib/vector/Vlib/level_two.c:316
+#: ../lib/raster/open.c:602 ../lib/raster/open.c:757
 #, c-format
-msgid "Nodes not available for line %d"
-msgstr "%d līnijas mezgli nav pieejami"
+msgid "Raster map <%s> is not in the current mapset (%s)"
+msgstr ""
-#: ../lib/vector/Vlib/level_two.c:357
+#: ../lib/raster/open.c:609
 #, c-format
-msgid "Areas not available for line %d"
+msgid "<%s> is an illegal file name"
 msgstr ""
-#: ../lib/vector/Vlib/level_two.c:362
+#: ../lib/raster/open.c:624 ../lib/raster/open.c:704 ../lib/raster/open.c:780
 #, c-format
-msgid "Line %d is not a boundary"
-msgstr "%d līnija nav robeža"
+msgid "No temp files available: %s"
+msgstr ""
-#: ../lib/vector/Vlib/level_two.c:445
+#: ../lib/raster/open.c:753
 #, c-format
-msgid "Topology info not available for feature %d"
+msgid "Raster map <%s> does not exist in the current mapset (%s)"
 msgstr ""
-#: ../lib/vector/Vlib/write_sfa.c:117
-msgid "Unable to calculate centroid for area"
+#: ../lib/raster/open.c:819
+msgid "Rast_set_fp_type(): can only be called with FCELL_TYPE or DCELL_TYPE"
 msgstr ""
-#: ../lib/vector/Vlib/write_sfa.c:131 ../lib/vector/Vlib/write_sfa.c:173
-#: ../lib/vector/Vlib/write_sfa.c:273 ../lib/vector/Vlib/read_sfa.c:124
-msgid "GRASS is not compiled with OGR/PostgreSQL support"
+#: ../lib/raster/open.c:877
+#, c-format
+msgid "Raster map <%s> not found in mapset <%s>"
 msgstr ""
-#: ../lib/vector/Vlib/write_sfa.c:219
-msgid "Attempt to delete dead feature"
-msgstr "Mēģinājums dzēst mirušu objektu"
-#: ../lib/vector/Vlib/write_sfa.c:311
+#: ../lib/raster/open.c:938
 #, c-format
-msgid "Unsupported vector map format (%d)"
-msgstr "Neatbalstīts vektoru kartes formāts (%d)"
+msgid "Unable to find '%s'"
+msgstr ""
-#: ../lib/vector/Vlib/write.c:194
+#: ../lib/raster/open.c:949
 #, c-format
-msgid "Unable to write feature in vector map <%s>"
+msgid "Invalid type: field '%s' in file '%s'"
 msgstr ""
-#: ../lib/vector/Vlib/write.c:234
+#: ../lib/raster/open.c:954
 #, c-format
-msgid "Unable to rewrite feature/offset %lu in vector map <%s>"
+msgid "Missing type: field in file '%s'"
 msgstr ""
-#: ../lib/vector/Vlib/write.c:266
+#: ../lib/raster/open.c:959
 #, c-format
-msgid "Unable to delete feature/offset %lu from vector map <%s>"
+msgid "Raster map <%s> is not xdr: byte_order: %s"
 msgstr ""
-#: ../lib/vector/Vlib/write.c:299
-msgid "Unable to restore feature/offset %"
+#: ../lib/raster/open.c:1028
+msgid ""
+"Rast_set_quant_rules() can be called only for raster maps opened for reading"
 msgstr ""
-#: ../lib/vector/Vlib/write.c:308
+#: ../lib/raster/put_row.c:121
 #, c-format
-msgid "Vector map <%s> is not opened"
-msgstr "Vektoru karte <%s> nav atvērta"
+msgid "Error writing uncompressed FP data for row %d of <%s>: %s"
+msgstr ""
-#: ../lib/vector/Vlib/write.c:313
+#: ../lib/raster/put_row.c:131
 #, c-format
-msgid "Vector map <%s> is not opened in write mode"
+msgid "Error writing compressed FP data for row %d of <%s>: %s"
 msgstr ""
-#: ../lib/vector/Vlib/ascii.c:84
+#: ../lib/raster/put_row.c:386 ../lib/raster/put_row.c:392
 #, c-format
-msgid "Error reading ASCII file: (bad type) [%s]"
+msgid "Error writing compressed data for row %d of <%s>"
 msgstr ""
-#: ../lib/vector/Vlib/ascii.c:123
+#: ../lib/raster/put_row.c:402
 #, c-format
-msgid "Error reading ASCII file: (unknown type) [%s]"
+msgid "Error writing uncompressed data for row %d of <%s>"
 msgstr ""
-#: ../lib/vector/Vlib/ascii.c:143
-msgid "End of ASCII file reached before end of coordinates"
+#: ../lib/raster/put_row.c:462
+#, c-format
+msgid "Error writing data via GDAL for row %d of <%s>"
 msgstr ""
-#: ../lib/vector/Vlib/ascii.c:155
-#, c-format
-msgid "Error reading ASCII file: (bad point) [%s]"
+#: ../lib/raster/put_row.c:486
+msgid "GDAL output doesn't support writing null rows separately"
 msgstr ""
-#: ../lib/vector/Vlib/ascii.c:160
+#: ../lib/raster/put_row.c:489
 #, c-format
-msgid "Unparsable longitude value: [%s]"
+msgid "No null file for <%s>"
 msgstr ""
-#: ../lib/vector/Vlib/ascii.c:165
+#: ../lib/raster/put_row.c:513 ../lib/raster/put_row.c:518
 #, c-format
-msgid "Unparsable latitude value: [%s]"
+msgid "Error writing compressed null data for row %d of <%s>"
 msgstr ""
-#: ../lib/vector/Vlib/ascii.c:201
-msgid "End of ASCII file reached before end of categories"
+#: ../lib/raster/put_row.c:552 ../lib/raster/put_row.c:555
+#, c-format
+msgid "Error writing null row %d of <%s>"
 msgstr ""
-#: ../lib/vector/Vlib/ascii.c:212
+#: ../lib/raster/put_row.c:680
 #, c-format
-msgid "Error reading categories: [%s]"
+msgid "put_raster_row: raster map <%s> not open for write - request ignored"
 msgstr ""
-#: ../lib/vector/Vlib/ascii.c:225
-msgid "Unable to copy points"
+#: ../lib/raster/put_row.c:687
+msgid "put_raster_row: unopened file descriptor - request ignored"
 msgstr ""
-#: ../lib/vector/Vlib/ascii.c:238
-#, c-format
-msgid "Vector map <%s> is 2D. %d 3D features (faces or kernels) skipped."
+#: ../lib/raster/sample.c:70
+msgid "Unknown interpolation type"
 msgstr ""
-#: ../lib/vector/Vlib/ascii.c:270
-#, c-format
-msgid ""
-"Unexpected data in vector header:\n"
-"[%s]"
+#: ../lib/raster/sample.c:327
+msgid "\"no data\" label found; setting to zero"
 msgstr ""
-#: ../lib/vector/Vlib/ascii.c:306
+#: ../lib/raster/reclass.c:168
 #, c-format
-msgid "Unknown keyword <%s> in vector head"
-msgstr ""
+msgid "Too many reclass categories for <%s@%s>"
+msgstr "Pārāk daudz pārklasificēšanas kategorijas priekš <%s@%s>"
-#: ../lib/vector/Vlib/ascii.c:465
+#: ../lib/raster/reclass.c:171
 #, c-format
-msgid "Column <%s> does not exist"
+msgid "Illegal reclass format in header file for <%s@%s>"
 msgstr ""
-#: ../lib/vector/Vlib/ascii.c:467
-msgid "Available columns:"
-msgstr ""
+#: ../lib/raster/reclass.c:273
+msgid "Illegal reclass request"
+msgstr "Netļauts pārklasificēšanas pieprasījums"
-#: ../lib/vector/Vlib/ascii.c:472
-msgid "Export cancelled"
-msgstr ""
+#: ../lib/raster/reclass.c:278
+msgid "Illegal reclass type"
+msgstr "Netļauts klases tips"
-#: ../lib/vector/Vlib/ascii.c:505
+#: ../lib/raster/reclass.c:284
 #, c-format
-msgid "Unknown type of column <%s>, export cancelled"
+msgid "Unable to create header file for <%s@%s>"
 msgstr ""
-#: ../lib/vector/Vlib/ascii.c:539
+#: ../lib/raster/reclass.c:332
 #, c-format
-msgid "Unable to select record from table <%s> (key %s, column %s)"
-msgstr ""
+msgid "Unable to create dependency file in <%s@%s>"
+msgstr "Niespējami izveidot atkarību failu <%s@%s>"
-#: ../lib/vector/Vlib/ascii.c:661
+#: ../lib/raster/put_cellhd.c:34
 #, c-format
-msgid "Unknown feature type %d"
+msgid "Unable to create header file for <%s>"
 msgstr ""
-#: ../lib/vector/Vlib/ascii.c:701
+#: ../lib/raster/history.c:115 ../lib/raster/history.c:123
 #, c-format
-msgid "Feature has more categories. Only one category (%d) is exported."
+msgid "Unable to get history information for <%s@%s>"
 msgstr ""
-#: ../lib/vector/Vlib/ascii.c:718
+#: ../lib/raster/history.c:162
 #, c-format
-msgid "Cannot select attributes for cat = %d"
+msgid "Unable to write history information for <%s>"
 msgstr ""
-#: ../lib/vector/Vlib/ascii.c:724
-msgid "Unable to fetch data from table"
-msgstr ""
+#: ../lib/raster/history.c:235
+#, c-format
+msgid "generated by %s"
+msgstr "ģenerēts ar %s"
-#: ../lib/vector/Vlib/ascii.c:758
+#: ../lib/raster/color_read.c:103
+msgid "missing"
+msgstr "iztrūkst"
+#: ../lib/raster/color_read.c:106
+msgid "invalid"
+msgstr "nederīgs"
+#: ../lib/raster/color_read.c:112
 #, c-format
-msgid "Column <%s>: unsupported data type"
-msgstr ""
+msgid "Color support for <%s@%s> %s"
+msgstr "Krāsu atbalsts priekš <%s@%s> %s"
-#: ../lib/vector/Vlib/ascii.c:840
-msgid "Unknown format"
+#: ../lib/raster/quant_io.c:43
+#, c-format
+msgid "Floating data range for raster map <%s> is empty"
 msgstr ""
-#: ../lib/vector/Vlib/ascii.c:850
-msgid "Topology not available, unable to process areas"
+#: ../lib/raster/quant_io.c:52
+#, c-format
+msgid "Integer data range for raster map <%s> is empty"
 msgstr ""
-#: ../lib/vector/Vlib/ascii.c:863
+#: ../lib/raster/quant_io.c:105
 #, c-format
-msgid "Unable to get boundary of area id %d"
+msgid "Attempt to open quantization table for CELL raster map <%s>"
 msgstr ""
-#: ../lib/vector/Vlib/ascii.c:875
+#: ../lib/raster/quant_io.c:135
 #, c-format
-msgid "Unable to get boundary of isle id %d (area id %d)"
+msgid "Quantization file for raster map <%s> is missing"
 msgstr ""
-#: ../lib/vector/Vlib/ascii.c:889
+#: ../lib/raster/quant_io.c:145
 #, c-format
-msgid "%d features without category skipped. To export also features without category use '%s=-1'."
+msgid "Quantization file for raster map <%s> is empty"
 msgstr ""
-#: ../lib/vector/Vlib/write_ogr.c:129 ../lib/vector/Vlib/open_ogr.c:65
-msgid "OGR layer not defined"
-msgstr "OGR slānis nav definēts"
+#: ../lib/raster/histogram.c:55
+#, c-format
+msgid "Histogram for [%s in %s] missing (run r.support)"
+msgstr "Histogramma preikš [%s iekš %s] pietrūkst (palaist r.support)"
-#: ../lib/vector/Vlib/write_ogr.c:210 ../lib/db/dbmi_client/copy_tab.c:242
-#: ../lib/db/dbmi_client/copy_tab.c:319 ../lib/db/dbmi_client/table.c:110
+#: ../lib/raster/histogram.c:62
 #, c-format
-msgid "Unable to open select cursor: '%s'"
-msgstr ""
+msgid "Can't read histogram for [%s in %s]"
+msgstr "Nevar nolasīt histogrammu priekš [%s no %s]"
-#: ../lib/vector/Vlib/write_ogr.c:239
+#: ../lib/raster/histogram.c:66 ../lib/raster/histogram.c:73
 #, c-format
-msgid "Creating field <%s> failed"
-msgstr ""
+msgid "Invalid histogram file for [%s in %s]"
+msgstr "Nederīgs histogrammas fails priekš [%s iekš %s]"
-#: ../lib/vector/Vlib/write_ogr.c:326
+#: ../lib/raster/histogram.c:331
 #, c-format
-msgid "Unable to create OGR layer <%s> in '%s'"
+msgid "Unable to create histogram file for <%s>"
 msgstr ""
-#: ../lib/vector/Vlib/write_ogr.c:424
-msgid "Feature is not a point. Skipping."
+#: ../lib/nviz/nviz.c:128
+#, c-format
+msgid "Invalid color (%s), using \"white\" as default"
 msgstr ""
-#: ../lib/vector/Vlib/write_ogr.c:432
-msgid "Feature is not a line. Skipping."
+#: ../lib/nviz/map_obj.c:59
+msgid "Maximum surfaces loaded!"
 msgstr ""
-#: ../lib/vector/Vlib/write_ogr.c:439
-msgid "Feature is not a polygon. Skipping."
+#: ../lib/nviz/map_obj.c:88
+msgid "Maximum vector line maps loaded!"
 msgstr ""
-#: ../lib/vector/Vlib/write_ogr.c:446
-msgid "Feature is not a face. Skipping."
-msgstr ""
-#: ../lib/vector/Vlib/write_ogr.c:452
+#: ../lib/nviz/map_obj.c:97 ../lib/nviz/map_obj.c:128
 #, c-format
-msgid "Unsupported feature type (%d)"
-msgstr "Neatbalstīts objekta tips (%d)"
-#: ../lib/vector/Vlib/write_ogr.c:471
-msgid "Boundary is not closed. Feature skipped."
+msgid "Error loading vector map <%s>"
 msgstr ""
-#: ../lib/vector/Vlib/write_ogr.c:500
-msgid "Unable to writes feature attributes"
+#: ../lib/nviz/map_obj.c:116
+msgid "Maximum vector point maps loaded!"
 msgstr ""
-#: ../lib/vector/Vlib/write_ogr.c:565
-#, c-format
-msgid "Feature without category of layer %d"
+#: ../lib/nviz/map_obj.c:143
+msgid "Maximum volumes loaded!"
 msgstr ""
-#: ../lib/vector/Vlib/write_ogr.c:624
+#: ../lib/nviz/map_obj.c:152
 #, c-format
-msgid "Unable to create field <%s>"
+msgid "Error loading 3d raster map <%s>"
 msgstr ""
-#: ../lib/vector/Vlib/constraint.c:150
-msgid "Layer constraint ignored for non-native vector formats"
+#: ../lib/nviz/map_obj.c:160
+msgid "Nviz_new_map_obj(): unsupported data type"
 msgstr ""
-#: ../lib/vector/Vlib/snap.c:223 ../lib/vector/Vlib/snap.c:582
-msgid "Snap vertices Pass 1: select points"
+#: ../lib/nviz/position.c:56
+msgid "Unable to set focus"
 msgstr ""
-#: ../lib/vector/Vlib/snap.c:270 ../lib/vector/Vlib/snap.c:636
-msgid "Snap vertices Pass 2: assign anchor vertices"
+#: ../lib/nviz/lights.c:171
+msgid "Unable to define new light"
 msgstr ""
-#: ../lib/vector/Vlib/snap.c:339 ../lib/vector/Vlib/snap.c:705
-msgid "Snap vertices Pass 3: snap to assigned points"
+#: ../lib/nviz/render.c:106
+msgid "Bad server connection"
 msgstr ""
-#: ../lib/vector/Vlib/snap.c:525 ../lib/vector/Vlib/snap.c:888
-#, c-format
-msgid "Snapped vertices: %d"
+#: ../lib/nviz/render.c:112
+msgid "Unable to get visual info"
 msgstr ""
-#: ../lib/vector/Vlib/snap.c:526 ../lib/vector/Vlib/snap.c:889
-#, c-format
-msgid "New vertices: %d"
+#: ../lib/nviz/render.c:119
+msgid "Unable to create rendering context"
 msgstr ""
-#: ../lib/vector/Vlib/snap.c:916
-msgid "Reading features..."
+#: ../lib/segment/format.c:144
+msgid "Segment format: file size too large"
 msgstr ""
-#: ../lib/vector/Vlib/build_nat.c:129
-msgid "Building areas..."
-msgstr "Veido poligonus..."
-#: ../lib/vector/Vlib/build_nat.c:153
-#, c-format
-msgid "One area built"
-msgid_plural "%d areas built"
-msgstr[0] "Izveidots %d laukums"
-msgstr[1] "Izveidoti %d laukumi"
-msgstr[2] "Izveidots %d laukumu"
-#: ../lib/vector/Vlib/build_nat.c:154
-#, c-format
-msgid "One isle built"
-msgid_plural "%d isles built"
-msgstr[0] "Izveidota %d sala"
-msgstr[1] "Izveidotas %d salas"
-msgstr[2] "Izveidots %d salu"
-#: ../lib/vector/Vlib/build_nat.c:163
-msgid "Attaching islands..."
-msgstr "Pievieno salas..."
-#: ../lib/vector/Vlib/build_nat.c:180
-msgid "Attaching centroids..."
-msgstr "Pievieno centroīdus..."
-#: ../lib/vector/Vlib/write_nat.c:398
-msgid "Attempt to access feature with invalid id (%"
+#: ../lib/segment/format.c:145
+msgid "Please recompile with Large File Support (LFS)"
 msgstr ""
-#: ../lib/vector/Vlib/write_nat.c:404
-#, c-format
-msgid "Attempt to access alive feature %d"
+#: ../lib/segment/open.c:53
+msgid "Segment file name is NULL"
 msgstr ""
-#: ../lib/vector/Vlib/write_nat.c:566 ../lib/vector/Vlib/write_nat.c:602
-#, c-format
-msgid "%s: Area %d does not exist"
-msgstr ""
+#: ../lib/segment/open.c:58
+msgid "Segment file exists already"
+msgstr "Segmentu fails jau eksistē"
-#: ../lib/vector/Vlib/write_nat.c:756
-#, c-format
-msgid "Attempt to access dead area %d"
+#: ../lib/segment/open.c:66
+msgid "Unable to create segment file"
 msgstr ""
-#: ../lib/vector/Vlib/build_ogr.c:72
-msgid "Empty OGR layer, nothing to build"
+#: ../lib/segment/open.c:74
+msgid "Could not write segment file"
 msgstr ""
-#: ../lib/vector/Vlib/build_ogr.c:89
-msgid "Random read is not supported by OGR for this layer. Unable to build topology."
+#: ../lib/segment/open.c:78
+msgid "Illegal segment configuration parameter(s)"
 msgstr ""
-#: ../lib/vector/Vlib/build_ogr.c:139
-#, c-format
-msgid "Unable to open fidx file for write <%s>"
+#: ../lib/segment/open.c:87
+msgid "Unable to re-open segment file"
 msgstr ""
-#: ../lib/vector/Vlib/graph.c:138
-msgid "Unable to add network arc"
+#: ../lib/segment/open.c:94
+msgid "Could not read segment file"
 msgstr ""
-#: ../lib/vector/Vlib/remove_duplicates.c:199
+#: ../lib/temporal/lib/connect.c:110
 #, c-format
-msgid "Removed duplicates: %d"
+msgid "Mapset <%s> does not exist."
 msgstr ""
-#: ../lib/vector/Vlib/poly.c:268
-msgid "Unable to find point in polygon"
+#: ../lib/temporal/lib/default_name.c:69
+msgid "Programmer error - only SQLite driver is currently supported"
 msgstr ""
-#: ../lib/vector/Vlib/poly.c:810
-msgid "conditions failed"
+#: ../lib/gpde/n_parse_options.c:106
+msgid "The calculation time in seconds"
 msgstr ""
-#: ../lib/vector/Vlib/cindex.c:32
-msgid "Category index is not up to date"
+#: ../lib/gpde/test/test_main.c:88
+msgid "Performs unit and integration tests for gpde library"
 msgstr ""
-#: ../lib/vector/Vlib/cindex.c:38
-msgid "Layer index out of range"
-msgstr "Slāņa indekss ārpus robežām"
-#: ../lib/vector/Vlib/cindex.c:268
-msgid "Category index out of range"
-msgstr ""
-#: ../lib/vector/Vlib/cindex.c:488
+#: ../lib/gpde/n_arrays_io.c:93
 #, c-format
-msgid "Unable to create category index file for vector map <%s>"
+msgid "Reading raster map <%s> into memory"
 msgstr ""
-#: ../lib/vector/Vlib/cindex.c:497
-msgid "Error writing out category index file"
+#: ../lib/gpde/n_arrays_io.c:183
+msgid "N_array_2d * array is empty"
 msgstr ""
-#: ../lib/vector/Vlib/open_ogr.c:60
-msgid "OGR datasource not defined"
+#: ../lib/gpde/n_arrays_io.c:202
+#, c-format
+msgid "Write 2d array to raster map <%s>"
 msgstr ""
-#: ../lib/vector/Vlib/open_ogr.c:77 ../lib/vector/Vlib/field.c:690
+#: ../lib/gpde/n_arrays_io.c:273 ../lib/ogsf/gvl3.c:40
+#: ../lib/ogsf/gvl_file.c:427 ../lib/manage/do_rename.c:76
+#: ../lib/manage/do_remove.c:78
 #, c-format
-msgid "Unable to open OGR data source '%s'"
-msgstr ""
+msgid "3D raster map <%s> not found"
+msgstr "3D rastra karte <%s> nav atrasta"
-#: ../lib/vector/Vlib/open_ogr.c:97
-#, c-format
-msgid "OGR layer <%s> not found"
+#: ../lib/gpde/n_arrays_io.c:281 ../lib/ogsf/gvl_file.c:436
+#: ../lib/python/temporal/c_libraries_interface.py:676
+#, c-format, python-format
+msgid "Unable to open 3D raster map <%s>"
 msgstr ""
-#: ../lib/vector/Vlib/open_ogr.c:191
+#: ../lib/gpde/n_arrays_io.c:309
 #, c-format
-msgid "Unable to get OGR driver <%s>"
+msgid "Read g3d map <%s> into the memory"
 msgstr ""
-#: ../lib/vector/Vlib/open_ogr.c:199
-#, c-format
-msgid "Unable to create OGR data source '%s'"
+#: ../lib/gpde/n_arrays_io.c:364 ../lib/gpde/n_arrays_io.c:464
+msgid "Error closing g3d file"
 msgstr ""
-#: ../lib/vector/Vlib/open_ogr.c:211
+#: ../lib/gpde/n_arrays_io.c:420
 #, c-format
-msgid "OGR layer <%s> already exists and will be overwritten"
+msgid "Error opening g3d map <%s>"
 msgstr ""
-#: ../lib/vector/Vlib/open_ogr.c:215
+#: ../lib/gpde/n_arrays_io.c:422
 #, c-format
-msgid "Unable to delete OGR layer <%s>"
+msgid "Write 3d array to g3d map <%s>"
 msgstr ""
-#: ../lib/vector/Vlib/open_ogr.c:221
+#: ../lib/gpde/n_gwflow.c:436 ../lib/gpde/n_gwflow.c:715
 #, c-format
-msgid "OGR layer <%s> already exists in datasource '%s'"
+msgid "The total sum of the water budget: %g\n"
 msgstr ""
-#: ../lib/vector/Vlib/open_ogr.c:279
+#: ../lib/gpde/n_gwflow.c:438 ../lib/gpde/n_gwflow.c:717
 #, c-format
-msgid "Feature index format version %d.%d is not supported by this release. Try to rebuild topology or upgrade GRASS."
+msgid "The total sum of the water budget is significantly larger then 0: %g\n"
 msgstr ""
-#: ../lib/vector/Vlib/open_ogr.c:284
+#: ../lib/raster3d/range.c:73
 #, c-format
-msgid "Your GRASS version does not fully support feature index format %d.%d of the vector. Consider to rebuild topology or upgrade GRASS."
-msgstr ""
+msgid "Unable to open range file for [%s in %s]"
+msgstr "Neiespējami atvērt failu %s iekš %s"
-#: ../lib/vector/Vlib/break_lines.c:572
+#: ../lib/raster3d/range.c:88
 #, c-format
-msgid "Intersections: %d"
-msgstr "Krustojumi: %d"
+msgid "Error reading range file for [%s in %s]"
+msgstr "Nederīgs diapazona fails priekš [%s iekš %s]"
-#: ../lib/vector/Vlib/merge_lines.c:240
+#: ../lib/raster3d/range.c:150
 #, c-format
-msgid "%d boundaries merged"
-msgstr ""
+msgid "Unable to open range file for <%s>"
+msgstr "Nevar atvērt diapazona failu priekš <%s>"
-#: ../lib/vector/Vlib/merge_lines.c:241
+#: ../lib/raster3d/close.c:47
 #, c-format
-msgid "%d new boundaries"
+msgid "Unable to write history for 3D raster map <%s>"
 msgstr ""
-#: ../lib/vector/Vlib/read_ogr.c:215 ../lib/vector/Vlib/read_ogr.c:224
+#: ../lib/raster3d/close.c:62
 #, c-format
-msgid "Unable to get feature geometry, fid %ld"
+msgid "Unable to move temp raster map <%s> to 3D raster map <%s>"
 msgstr ""
-#: ../lib/vector/Vlib/read_ogr.c:382 ../lib/vector/Vlib/read_pg.c:482
-msgid "Feature without geometry. Skipped."
+#: ../lib/raster3d/close.c:79
+msgid "Unable to flush all tiles"
 msgstr ""
-#: ../lib/vector/Vlib/read_ogr.c:390
-msgid "OGR feature without ID"
+#: ../lib/raster3d/close.c:84
+msgid "Unable to flush index"
 msgstr ""
-#: ../lib/vector/Vlib/read_ogr.c:514
-#, c-format
-msgid "OGR feature type '%s' not supported"
+#: ../lib/raster3d/close.c:94
+msgid "Unable to position file"
 msgstr ""
-#: ../lib/vector/Vlib/read_sfa.c:90
+#: ../lib/raster3d/close.c:99 ../lib/raster3d/close.c:105
+#: ../lib/raster3d/close.c:191 ../lib/raster3d/header.c:217
 #, c-format
-msgid "Unable to construct centroid for area %d. Skipped."
+msgid "Unable to write header for 3D raster map <%s>"
 msgstr ""
-#: ../lib/vector/Vlib/read_sfa.c:95
+#: ../lib/raster3d/close.c:110 ../lib/raster3d/close.c:153
 #, c-format
-msgid "Centroid %d: invalid area %d"
+msgid "Unable to create 3D raster map <%s>"
 msgstr ""
-#: ../lib/vector/Vlib/read_sfa.c:117 ../lib/vector/Vlib/read_pg.c:192
-#, c-format
-msgid "Unexpected feature type (%d) - should be (%d)"
+#: ../lib/raster3d/close.c:120 ../lib/raster3d/close.c:130
+#: ../lib/raster3d/close.c:159 ../lib/ogsf/gvl_file.c:470
+#: ../lib/python/temporal/c_libraries_interface.py:706
+msgid "Unable to close 3D raster map <%s>"
 msgstr ""
-#: ../lib/vector/Vlib/break_polygons.c:102
-msgid "Break polygons: Bug in binary tree!"
+#: ../lib/raster3d/close.c:169
+msgid "Error in cache"
 msgstr ""
-#: ../lib/vector/Vlib/break_polygons.c:156
-#: ../lib/vector/Vlib/break_polygons.c:435
-msgid "Breaking polygons (pass 1: select break points)..."
+#: ../lib/raster3d/test/test_main.c:96
+msgid "raster3d"
 msgstr ""
-#: ../lib/vector/Vlib/break_polygons.c:286
-#: ../lib/vector/Vlib/break_polygons.c:552
-msgid "Breaking polygons (pass 2: break at selected points)..."
-msgstr ""
+#: ../lib/raster3d/test/test_main.c:97
+#, fuzzy
+msgid "unit test"
+msgstr "vienības"
-#: ../lib/vector/Vlib/break_polygons.c:398
-#: ../lib/vector/Vlib/break_polygons.c:650
-#, c-format
-msgid "Breaks: %d"
+#: ../lib/raster3d/param.c:84
+msgid "Rast3d_get_standard3d_params: precision value invalid"
 msgstr ""
-#: ../lib/vector/Vlib/break_polygons.c:592
-msgid "Point not in search tree!"
+#: ../lib/raster3d/param.c:105
+msgid "Rast3d_get_standard3d_params: tile dimension value invalid"
 msgstr ""
-#: ../lib/vector/Vlib/overlay.c:72
-msgid "unknown operator"
+#: ../lib/raster3d/param.c:129
+msgid "Window replacing the default"
+msgstr "Logs aizvieto noklusēto"
+#: ../lib/raster3d/maskfn.c:77
+#, c-format
+msgid "Adding rule: %lf - %lf"
 msgstr ""
-#: ../lib/vector/Vlib/overlay.c:124
-msgid "Overlay: line/boundary types not supported by AND operator"
+#: ../lib/raster3d/maskfn.c:95
+#, c-format
+msgid "%s: illegal value spec"
 msgstr ""
-#: ../lib/vector/Vlib/overlay.c:127
-msgid "Overlay: area x area types not supported by AND operator"
+#: ../lib/raster3d/open.c:20
+msgid "Rast3d_open_cell_old_no_header: error in Rast3d_mask_open_old"
 msgstr ""
+"Nav iespējams izveidot vektoru karti <%s>. Nosaukums nav SQL savietojams"
-#: ../lib/vector/Vlib/open_nat.c:56
-#, c-format
-msgid "Unable to open coor file for vector map <%s>"
+#: ../lib/raster3d/open.c:26
+msgid "Rast3d_open_cell_old_no_header: error in Rast3d_malloc"
 msgstr ""
-#: ../lib/vector/Vlib/open_nat.c:152
-#, c-format
-msgid "Coor file of vector map <%s@%s> is larger than it should be (%ld bytes excess)"
+#: ../lib/raster3d/open.c:37
+msgid "Rast3d_open_cell_old_no_header: error in G_open_old"
 msgstr ""
-#: ../lib/vector/Vlib/open_nat.c:156
-#, c-format
-msgid "Coor file of vector <%s@%s> is shorter than it should be (%ld bytes missing)."
+#: ../lib/raster3d/open.c:93
+msgid "Rast3d_open_cell_old: error in Rast3d_open_cell_old_no_header"
 msgstr ""
-#: ../lib/vector/Vlib/read_pg.c:272 ../lib/vector/Vlib/read_pg.c:471
-#, c-format
-msgid "Feature %ld without geometry skipped"
+#: ../lib/raster3d/open.c:98
+msgid "Rast3d_open_cell_old: can't rewind file"
 msgstr ""
-#: ../lib/vector/Vlib/read_pg.c:365
-#, c-format
-msgid "Requesting invalid feature from cache (%d). Number of features in cache: %d"
+#: ../lib/raster3d/open.c:111
+msgid "Rast3d_open_cell_old: error in Rast3d_read_header"
 msgstr ""
-#: ../lib/vector/Vlib/read_pg.c:368
-#, c-format
-msgid "Feature %d: unexpected type (%d) - should be %d"
+#: ../lib/raster3d/open.c:119
+msgid "Rast3d_open_cell_old: projection does not match window projection"
 msgstr ""
-#: ../lib/vector/Vlib/read_pg.c:575
-msgid "No geometry or topo geometry column defined"
+#: ../lib/raster3d/open.c:123
+msgid "Rast3d_open_cell_old: zone does not match window zone"
 msgstr ""
-#: ../lib/vector/Vlib/read_pg.c:585
-msgid "Random access not supported. Primary key not defined."
+#: ../lib/raster3d/open.c:135 ../lib/raster3d/open.c:152
+msgid "Rast3d_open_cell_old: can't read header"
 msgstr ""
-#: ../lib/vector/Vlib/read_pg.c:652
-msgid "Inconsistency in topology: detected centroid (should be point)"
+#: ../lib/raster3d/open.c:141
+msgid "Rast3d_open_cell_old: index does not fit into long"
 msgstr ""
-#: ../lib/vector/Vlib/read_pg.c:662
-msgid "Inconsistency in topology: detected boundary (should be line)"
+#: ../lib/raster3d/open.c:145
+msgid "Rast3d_open_cell_old: error in Rast3d_malloc"
 msgstr ""
-#: ../lib/vector/Vlib/read_pg.c:787
-#, c-format
-msgid "Invalid WKB content: %d bytes"
+#: ../lib/raster3d/open.c:172
+msgid "Rast3d_open_cell_old: error in Rast3d_fill_header"
 msgstr ""
-#: ../lib/vector/Vlib/read_pg.c:803
-msgid "Reading EWKB with 4-dimensional coordinates (XYZM) is not supported"
+#: ../lib/raster3d/open.c:219
+msgid "Rast3d_open_cell_new: error in Rast3d_mask_open_old"
 msgstr ""
-#: ../lib/vector/Vlib/read_pg.c:996 ../lib/vector/Vlib/read_pg.c:1066
-#: ../lib/vector/Vlib/read_pg.c:1137
-msgid "Length of input WKB is too small"
+#: ../lib/raster3d/open.c:228
+msgid "Rast3d_open_cell_new: error in Rast3d_malloc"
 msgstr ""
-#: ../lib/vector/Vlib/read_pg.c:1077
+#: ../lib/raster3d/open.c:233
 #, c-format
-msgid "Invalid cache index %d (max: %d)"
+msgid "map <%s> is not in the current mapset"
+msgstr "karte <%s> neatrodas šī brīža karšu kopā"
+#: ../lib/raster3d/open.c:243
+msgid "Rast3d_open_cell_new: could not open file"
 msgstr ""
-#: ../lib/vector/Vlib/read_pg.c:1215
-#, c-format
-msgid "Corrupted data. %s."
+#: ../lib/raster3d/open.c:287 ../lib/raster3d/open.c:292
+msgid "Rast3d_open_cell_new: can't write header"
 msgstr ""
-#: ../lib/vector/Vlib/read_pg.c:1217
-msgid "Corrupted data"
+#: ../lib/raster3d/open.c:314
+msgid "Rast3d_open_cell_new: error in Rast3d_fill_header"
 msgstr ""
-#: ../lib/vector/Vlib/read_pg.c:1252
-#, fuzzy, c-format
-msgid "Unable to parse '%s'"
-msgstr "Neiespējami atvērt failu %s iekš %s"
+#: ../lib/raster3d/color.c:354
+#, c-format
+msgid "mapset <%s> is not the current mapset"
+msgstr "karšu kopa <%s> nav aktīvā karšu kopa"
-#: ../lib/vector/Vlib/read_pg.c:1530
+#: ../lib/raster3d/history.c:43
 #, c-format
-msgid ""
-"Execution failed: %s (...)\n"
-"Reason: %s"
-msgstr ""
+msgid "can't get history information for [%s] in mapset [%s]"
+msgstr "nevar iegūt vēstures informāciju priekš [%s] no karšu kopas [%s]"
-#: ../lib/vector/Vlib/read_pg.c:1561
+#: ../lib/db/dbmi_client/delete_tab.c:40 ../lib/db/dbmi_client/table.c:46
 #, c-format
-msgid ""
-"Execution failed: %s\n"
-"Reason: %s"
+msgid "Unable open database <%s> by driver <%s>"
 msgstr ""
-#: ../lib/vector/Vlib/read_pg.c:1693
+#: ../lib/db/dbmi_client/delete_tab.c:53
 #, c-format
-msgid ""
-"Unable to read features. Reason:\n"
-"%s"
+msgid "Unable to drop table: '%s'"
 msgstr ""
-#: ../lib/vector/Vlib/field.c:91
-msgid "Layer number must be 1 or greater"
-msgstr "Slāņa numuram ir jābūt 1 vai lielākam"
-#: ../lib/vector/Vlib/field.c:96
-msgid "Unable to add attribute link, vector map is not opened in WRITE mode"
+#: ../lib/db/dbmi_client/select.c:119 ../lib/db/dbmi_client/select.c:221
+#: ../lib/db/dbmi_client/select.c:288
+msgid "Missing column name"
 msgstr ""
-#: ../lib/vector/Vlib/field.c:103
-msgid "Unable to add attribute link"
-msgstr "Nevar pievienot atribūtu saiti"
-#: ../lib/vector/Vlib/field.c:109
-msgid "Unable to write attribute links"
-msgstr "Nevar ierakstīt atribūtu saiti"
-#: ../lib/vector/Vlib/field.c:154
-msgid "Unable to write database links"
-msgstr "Nevar ierakstīt datubāzes saites"
-#: ../lib/vector/Vlib/field.c:178
-msgid "Database connection not defined. Skipping."
+#: ../lib/db/dbmi_client/select.c:216 ../lib/db/dbmi_client/select.c:283
+msgid "Missing key column name"
 msgstr ""
-#: ../lib/vector/Vlib/field.c:185
-msgid "More DB links defined for input vector map. Using only first DB link for output."
+#: ../lib/db/dbmi_client/select.c:333
+msgid "Key column type is not integer"
 msgstr ""
-#: ../lib/vector/Vlib/field.c:261
+#: ../lib/db/dbmi_client/copy_tab.c:91
 #, c-format
-msgid "Layer number %d or name <%s> already exists"
+msgid "Array of values to select from column <%s> is empty"
 msgstr ""
-#: ../lib/vector/Vlib/field.c:345
+#: ../lib/db/dbmi_client/copy_tab.c:151
 #, c-format
-msgid ""
-"Default driver / database set to:\n"
-"driver: %s\n"
-"database: %s"
+msgid "Unable to get list tables in database <%s>"
 msgstr ""
-#: ../lib/vector/Vlib/field.c:352
-msgid "Default driver is not set"
-msgstr "Noklusējuma dzinējs nav iestatīts"
-#: ../lib/vector/Vlib/field.c:355
-msgid "Default database is not set"
-msgstr "Noklusējuma datubāze nav iestatīta"
-#: ../lib/vector/Vlib/field.c:428
+#: ../lib/db/dbmi_client/copy_tab.c:189
 #, c-format
-msgid "Requested dblink %d, maximum link number %d"
-msgstr "Pieprasītā dbsaite %d, maksimāli iespējamo saišu skaits %d"
+msgid "Table <%s> already exists in database and will be overwritten"
+msgstr ""
-#: ../lib/vector/Vlib/field.c:614 ../lib/vector/Vlib/field.c:622
+#: ../lib/db/dbmi_client/copy_tab.c:194
 #, c-format
-msgid "Error in rule on row %d in <%s>"
+msgid "Table <%s> already exists in database <%s>"
 msgstr ""
-#: ../lib/vector/Vlib/field.c:707
+#: ../lib/db/dbmi_client/copy_tab.c:274
 #, c-format
-msgid "Unable to open OGR layer <%s>"
+msgid "Column <%s> is not integer"
 msgstr ""
-#: ../lib/vector/Vlib/field.c:734
-msgid "Unable to open OGR DBMI driver"
-msgstr "Nevar atvērt OGR DBMI dzinēju"
-#: ../lib/vector/Vlib/field.c:773
-msgid "All FID tests failed. Neither 'FID' nor 'ogc_fid' nor 'ogr_fid' nor 'gid' available in OGR DB table"
+#: ../lib/db/dbmi_client/copy_tab.c:294
+#, c-format
+msgid "Unable to create table <%s>"
 msgstr ""
-#: ../lib/vector/Vlib/field.c:840
+#: ../lib/db/dbmi_client/copy_tab.c:394
 #, c-format
-msgid "Feature table <%s> has no primary key defined. Unable to define DB links."
+msgid "Unknown column type (column <%s>)"
 msgstr ""
-#: ../lib/vector/Vlib/field.c:860
-msgid "GRASS not compiled with PostgreSQL support"
-msgstr "GRASS nav kompilēts ar PostgreSQL atbalstu"
-#: ../lib/vector/Vlib/field.c:892
-msgid "Unknown vector map format"
-msgstr "Nezināms vektordatu kartes formāts"
-#: ../lib/vector/Vlib/field.c:925
+#: ../lib/db/dbmi_driver/d_error.c:35
 #, c-format
-msgid "Unable to create database definition file for vector map <%s>"
+msgid "DBMI-%s driver error:"
 msgstr ""
-#: ../lib/vector/Vlib/field.c:1020
-msgid "Bug: attempt to update map which is not in current mapset"
+#: ../lib/db/dbmi_base/login.c:115
+#, c-format
+msgid "Unable to read file '%s'"
 msgstr ""
-#: ../lib/vector/vedit/select.c:231
-msgid "Unknown query tool"
+#: ../lib/db/dbmi_base/login.c:126
+#, c-format
+msgid "Login file (%s) corrupted (line: %s)"
 msgstr ""
-#: ../lib/vector/vedit/cats.c:63
+#: ../lib/db/dbmi_base/login.c:164
 #, c-format
-msgid "Unable to set category %d for (feature id %d)"
+msgid "Unable to write file '%s'"
 msgstr ""
-#: ../lib/vector/vedit/delete.c:40
+#: ../lib/db/dbmi_base/login.c:229
 #, c-format
-msgid "Attempt to delete dead feature (%d)"
+msgid "DB connection <%s/%s> already exists and will be overwritten"
 msgstr ""
-#: ../lib/vector/vedit/delete.c:72
+#: ../lib/db/dbmi_base/login.c:232
 #, c-format
-msgid "No area found for centroid %d"
+msgid ""
+"DB connection <%s/%s> already exists. Re-run '%s' with '--%s' flag to "
+"overwrite existing settings."
 msgstr ""
-#: ../lib/vector/vedit/delete.c:76
-#, c-format
-msgid "Duplicate centroid %d, unable to delete area"
+#: ../lib/db/dbmi_base/xdrvalue.c:82
+msgid "send data: invalid C-type"
 msgstr ""
-#: ../lib/vector/vedit/delete.c:105
-#, c-format
-msgid "Area %d without centroid"
+#: ../lib/db/dbmi_base/default_name.c:136
+msgid "Programmer error"
+msgstr "Programmētāja kļūda"
+#: ../lib/db/dbmi_base/test/test_table.c:38
+msgid ""
+"\n"
+"++ Running table unit tests ++"
 msgstr ""
-#: ../lib/vector/vedit/delete.c:121
-#, c-format
-msgid "Area %d has no boundaries"
+#: ../lib/db/dbmi_base/test/test_table.c:43
+msgid ""
+"\n"
+"-- Table unit tests failure --"
 msgstr ""
-#: ../lib/vector/rtree/test_suite/test_basics.c:40
+#: ../lib/db/dbmi_base/test/test_table.c:45
 msgid ""
 "\n"
-"++ Running basic unit tests ++"
+"-- Table unit tests finished successfully --"
 msgstr ""
-#: ../lib/vector/rtree/test_suite/test_basics.c:48
+#: ../lib/db/dbmi_base/test/test_columns.c:37
 msgid ""
 "\n"
-"-- Basic rtree unit tests failure --"
+"++ Running column unit tests ++"
 msgstr ""
-#: ../lib/vector/rtree/test_suite/test_basics.c:50
+#: ../lib/db/dbmi_base/test/test_columns.c:42
 msgid ""
 "\n"
-"-- Basic rtree unit tests finished successfully --"
+"-- column unit tests failure --"
 msgstr ""
-#: ../lib/vector/rtree/test_suite/test_main.c:61
-msgid "Unit tests for the vector rtree library"
+#: ../lib/db/dbmi_base/test/test_columns.c:44
+msgid ""
+"\n"
+"-- column unit tests finished successfully --"
 msgstr ""
-#: ../lib/vector/neta/timetables.c:46 ../lib/vector/neta/timetables.c:203
-#: ../lib/vector/neta/timetables.c:244 ../lib/vector/neta/timetables.c:286
-#, c-format
-msgid "Unable to open select cursor: %s"
+#: ../lib/db/dbmi_base/test/test_columns.c:57
+msgid ""
+"\n"
+"++ Run test copy column ++"
 msgstr ""
-#: ../lib/vector/neta/utils.c:200
-#, c-format
-msgid "Point %d is not connected!"
+#: ../lib/db/dbmi_base/test/test_columns.c:150
+msgid ""
+"\n"
+"++ Test copy column finished ++"
 msgstr ""
-#: ../lib/vector/neta/utils.c:235
-#, c-format
-msgid "'%s' must be > 0"
+#: ../lib/db/dbmi_base/test/test_main.c:54 ../lib/gmath/test/test_main.c:54
+msgid "Choose the integration tests to run"
 msgstr ""
-#: ../lib/vector/neta/utils.c:244
-msgid "'where' and 'cats' parameters were supplied, cat will be ignored"
+#: ../lib/db/dbmi_base/test/test_main.c:58 ../lib/gmath/test/test_main.c:79
+msgid "Run all unit tests"
 msgstr ""
-#: ../lib/vector/neta/utils.c:247
-msgid "Unable to load data from database"
+#: ../lib/db/dbmi_base/test/test_main.c:62 ../lib/gmath/test/test_main.c:83
+msgid "Run all integration tests"
 msgstr ""
-#: ../lib/vector/neta/utils.c:254
-msgid "Problem loading category values"
+#: ../lib/db/dbmi_base/test/test_main.c:66 ../lib/gmath/test/test_main.c:87
+msgid "Run all unit and integration tests"
 msgstr ""
-#: ../lib/vector/neta/spanningtree.c:106
-msgid "Computing minimum spanning tree..."
+#: ../lib/db/dbmi_base/test/test_main.c:83
+msgid "Performs unit and integration tests for the dbmi base library"
 msgstr ""
-#: ../lib/init/lock.c:38
+#: ../lib/db/dbmi_base/legal_dbname.c:38
 #, c-format
-msgid "Usage: %s file pid"
+msgid "Illegal table map name <%s>. May not contain '.' or 'NULL'."
 msgstr ""
-#: ../lib/init/lock.c:42
-msgid "Concurrent mapset locking is not supported on Windows"
+#: ../lib/db/dbmi_base/legal_dbname.c:45
+#, c-format
+msgid "Illegal table map name <%s>. Must start with a letter."
 msgstr ""
-#: ../lib/init/lock.c:60
+#: ../lib/db/dbmi_base/legal_dbname.c:54
 #, c-format
-msgid "Unable to write lockfile %s (%s)"
+msgid "Illegal table map name <%s>. Character <%c> not allowed."
 msgstr ""
-#: ../lib/init/grass.py:123
-msgid "WARNING"
-msgstr "BRĪDINĀJUMS"
-#: ../lib/init/grass.py:187 ../lib/gis/parser.c:621
-msgid "ERROR"
-msgstr "KĻŪDA"
-#: ../lib/init/grass.py:188
-msgid "Exiting..."
-msgstr "Iziet..."
-#: ../lib/init/grass.py:332
-msgid "Usage"
-msgstr "Lietojums"
-#: ../lib/init/grass.py:333 ../lib/gis/parser_html.c:141
-#: ../lib/gis/parser_rest.c:146
-msgid "Flags"
-msgstr "Karogi"
-#: ../lib/init/grass.py:334
-msgid "print this help message"
-msgstr "izdrukā šo palīdzības paziņojumu"
-#: ../lib/init/grass.py:335
-msgid "show version information and exit"
-msgstr "parāda versijas informāciju un iziet"
-#: ../lib/init/grass.py:336
-msgid "create given database, location or mapset if it doesn't exist"
+#: ../lib/db/dbmi_base/error.c:72
+msgid "<NULL error message>"
 msgstr ""
-#: ../lib/init/grass.py:337
-msgid "exit after creation of location or mapset. Only with -c flag"
-msgstr ""
+#: ../lib/db/dbmi_base/error.c:91
+msgid "dbmi: Protocol error"
+msgstr "dbmi: protokola kļūda"
-#: ../lib/init/grass.py:338
-msgid "force removal of .gislock if exists (use with care!). Only with -text flag"
+#: ../lib/db/dbmi_base/error.c:136
+msgid "dbmi: Out of Memory"
 msgstr ""
-#: ../lib/init/grass.py:339
-msgid "use text based interface (skip welcome screen)"
+#: ../lib/db/dbmi_base/error.c:149
+#, c-format
+msgid "dbmi: %s() not implemented"
 msgstr ""
-#: ../lib/init/grass.py:340 ../lib/init/grass.py:342 ../lib/init/grass.py:344
-msgid "and set as default"
+#: ../lib/db/dbmi_base/error.c:163
+#, c-format
+msgid "dbmi: Invalid procedure %d"
 msgstr ""
-#: ../lib/init/grass.py:341
-msgid "use text based interface (show welcome screen)"
+#: ../lib/db/dbmi_base/xdrtable.c:109
+msgid "fetch: table has wrong number of columns"
 msgstr ""
-#: ../lib/init/grass.py:343
-msgid "use $DEFAULT_GUI graphical user interface"
+#: ../lib/db/dbmi_base/index.c:180
+msgid "db_set_index_column_name(): invalid column number"
 msgstr ""
-#: ../lib/init/grass.py:345
-msgid "print GRASS configuration parameters"
-msgstr "izdrukā GRASS konfigurācijas parametrus"
-#: ../lib/init/grass.py:346
-msgid "options: arch,build,compiler,path,revision"
+#: ../lib/db/dbmi_base/index.c:197
+msgid "db_get_index_column_name(): invalid column number"
 msgstr ""
-#: ../lib/init/grass.py:347 ../lib/gis/parser_html.c:189
-#: ../lib/gis/parser_rest.c:179
-msgid "Parameters"
-msgstr "Parametri"
-#: ../lib/init/grass.py:348
-msgid "initial GRASS GIS database directory"
+#: ../lib/db/dbmi_base/valuefmt.c:52
+msgid "db_convert_Cstring_to_value(): unrecognized sqltype"
 msgstr ""
-#: ../lib/init/grass.py:349
-msgid "directory containing Locations"
+#: ../lib/db/dbmi_base/valuefmt.c:91
+msgid "db_convert_value_into_string(): unrecongized sqltype-type"
 msgstr ""
-#: ../lib/init/grass.py:350
-msgid "initial GRASS Location"
+#: ../lib/pngdriver/graph_set.c:101
+#, c-format
+msgid "png: truecolor status %s"
 msgstr ""
-#: ../lib/init/grass.py:351
-msgid "directory containing Mapsets with one common coordinate system (projection)"
+#: ../lib/pngdriver/graph_set.c:102 ../lib/psdriver/graph_set.c:200
+msgid "enabled"
 msgstr ""
-#: ../lib/init/grass.py:352
-msgid "initial GRASS Mapset"
+msgid "disabled"
 msgstr ""
-#: ../lib/init/grass.py:353
-msgid "fully qualified initial Mapset directory"
+#: ../lib/pngdriver/graph_set.c:149
+#, c-format
+msgid "png: collecting to file '%s'"
 msgstr ""
-#: ../lib/init/grass.py:354
-msgid "Environment variables relevant for startup"
+#: ../lib/pngdriver/graph_set.c:150
+#, c-format
+msgid "png: image size %dx%d"
 msgstr ""
-#: ../lib/init/grass.py:355
-msgid "select GUI (text, gui, gtext)"
+#: ../lib/pngdriver/write_png.c:39
+msgid "Unable to write PNG"
 msgstr ""
-#: ../lib/init/grass.py:356
-msgid "set html web browser for help pages"
+#: ../lib/pngdriver/write_png.c:71 ../lib/pngdriver/write_png.c:75
+#: ../lib/pngdriver/read_png.c:64
+msgid "Unable to allocate PNG structure"
 msgstr ""
-#: ../lib/init/grass.py:357
-msgid "set additional path(s) to local GRASS modules or user scripts"
+#: ../lib/pngdriver/write_png.c:78
+msgid "Unable to write PNG file"
 msgstr ""
-#: ../lib/init/grass.py:358
-msgid "set additional GISBASE for locally installed GRASS Addons"
+#: ../lib/pngdriver/write_png.c:82
+#, c-format
+msgid "Unable to open output PNG file <%s>"
 msgstr ""
-#: ../lib/init/grass.py:359
-msgid "shell script to be processed as batch job"
-msgstr ""
+#: ../lib/pngdriver/read_png.c:42
+msgid "Unable to read PNG"
+msgstr "Nevar nolasīt PNG"
-#: ../lib/init/grass.py:360
-msgid "set Python interpreter name to override 'python'"
+#: ../lib/pngdriver/read_png.c:60
+msgid "Unable allocate PNG structure"
 msgstr ""
-#: ../lib/init/grass.py:361
-msgid "execute GRASS module or script"
+#: ../lib/pngdriver/read_png.c:67
+msgid "Unable to read PNG file"
 msgstr ""
-#: ../lib/init/grass.py:362
-msgid "provided executable will be executed in GRASS session"
+#: ../lib/pngdriver/read_png.c:81
+msgid "Input PNG file is not 8-bit"
 msgstr ""
-#: ../lib/init/grass.py:363
-msgid "GRASS module, script or any other executable"
+#: ../lib/pngdriver/read_png.c:85
+#, c-format
+msgid "Input PNG file has incorrect dimensions: expected: %dx%d got: %lux%lu"
 msgstr ""
-#: ../lib/init/grass.py:364
-msgid "parameters of the executable"
+#: ../lib/pngdriver/read_png.c:90
+msgid "Input PNG file is not RGBA"
 msgstr ""
-#: ../lib/init/grass.py:365
-msgid "standard flags"
+#: ../lib/pngdriver/read_png.c:94
+msgid "Input PNG file is not indexed color"
 msgstr ""
-#: ../lib/init/grass.py:390
-msgid "The APPDATA variable is not set, ask your operating system support"
+#: ../lib/pngdriver/read_png.c:104
+msgid "Input PNG file has invalid palette"
 msgstr ""
-#: ../lib/init/grass.py:393
-msgid "The APPDATA variable points to directory which does not exist, ask your operating system support"
+#: ../lib/ogsf/gv3.c:269
+#, c-format
+msgid "No features from vector map <%s> fall within current region"
 msgstr ""
-#: ../lib/init/grass.py:440
-#, python-format
-msgid "Unable to create temporary directory <grass7-%(user)s-%(lock)s>! Exiting."
+#: ../lib/ogsf/gv3.c:274
+#, c-format
+msgid "Vector map <%s> loaded (%d features)"
 msgstr ""
-#: ../lib/init/grass.py:493
-#, python-brace-format
-msgid "Invalid line in RC file ({file}): '{line}' ({error})\n"
+#: ../lib/ogsf/gv3.c:353
+#, c-format
+msgid "Loading thematic vector layer <%s>..."
 msgstr ""
-#: ../lib/init/grass.py:547
-#, python-format
-msgid "GUI <%s> not supported in this version"
+#: ../lib/ogsf/gv3.c:377 ../lib/ogsf/gp3.c:235
+#, c-format
+msgid "No color rule defined for category %d"
 msgstr ""
-#: ../lib/init/grass.py:704
-msgid "Searched for a web browser, but none found"
+#: ../lib/ogsf/gv3.c:392 ../lib/ogsf/gp3.c:249
+#, c-format
+msgid "Invalid color definition (%s)"
 msgstr ""
-#: ../lib/init/grass.py:742
+#: ../lib/ogsf/gv3.c:414
+#, c-format
 msgid ""
-"The python command does not work as expected!\n"
-"Please check your GRASS_PYTHON environment variable.\n"
-"Use the -help option for details.\n"
-"Switching to text based interface mode.\n"
-"\n"
-"Hit RETURN to continue.\n"
+"%d features without category. Unable to determine color rules for features "
+"without category."
 msgstr ""
-#: ../lib/init/grass.py:754
-msgid ""
-"It appears that the X Windows system is not active.\n"
-"A graphical based user interface is not supported.\n"
-"(DISPLAY variable is not set.)\n"
-"\n"
-msgstr ""
+#: ../lib/ogsf/gsd_legend.c:246
+#, c-format
+msgid "Unable to read color file of raster map <%s>"
+msgstr "Nav iespējams nolasīt rastra kartes <%s> krāsu failu"
-#: ../lib/init/grass.py:841 ../lib/gis/make_mapset.c:66
-#, c-format, python-format
-msgid "Location <%s> doesn't exist"
-msgstr "Novietojums <%s> neeksistē"
-#: ../lib/init/grass.py:843
-#, python-format
-msgid "<%s> is not a valid GRASS Location because PERMANENT Mapset is missing"
+#: ../lib/ogsf/gsd_legend.c:252
+#, c-format
+msgid "Unable to read category file of raster map <%s>"
 msgstr ""
-#: ../lib/init/grass.py:846
-#, python-format
-msgid "<%s> is not a valid GRASS Location because PERMANENT is not a directory"
+#: ../lib/ogsf/gsd_legend.c:269
+#, c-format
+msgid "Unable to read fp range of raster map <%s>"
 msgstr ""
-#: ../lib/init/grass.py:850
-#, python-format
-msgid "<%s> is not a valid GRASS Location because PERMANENT Mapset does not have a DEFAULT_WIND file (default computational region)"
+#: ../lib/ogsf/gsd_legend.c:281
+#, c-format
+msgid "Unable to read range of raster map <%s>"
 msgstr ""
-#: ../lib/init/grass.py:854
-msgid "Mapset <{mapset}> doesn't exist in GRASS Location <{loc}>. A new mapset can be created by '-c' switch."
+#: ../lib/ogsf/gsd_legend.c:295
+msgid "Range request error for legend"
 msgstr ""
-#: ../lib/init/grass.py:858
-#, python-format
-msgid "<%s> is not a GRASS Mapset because it is not a directory"
+#: ../lib/ogsf/gsd_legend.c:385
+msgid "Unable to show discrete FP range (use list)"
 msgstr ""
-#: ../lib/init/grass.py:861
-msgid "Mapset <{mapset}> is invalid for an unknown reason"
+#: ../lib/ogsf/gsd_legend.c:501
+msgid "Too many categories to show as discrete!"
 msgstr ""
-#: ../lib/init/grass.py:923
-#, python-format
-msgid "Failed to create new location. The location <%s> already exists."
-msgstr "Nebija iespējams izveidot jaunu novietojumu. Novietojums <%s> jau eksistē."
-#: ../lib/init/grass.py:934
-msgid "Missing WIND file fixed"
+#: ../lib/ogsf/gsd_legend.c:503
+msgid "Try using smaller font!"
 msgstr ""
-#: ../lib/init/grass.py:946
-msgid ""
-"GISDBASE, LOCATION_NAME and MAPSET variables not set properly.\n"
-"Interactive startup needed."
-msgstr ""
+#: ../lib/ogsf/gk2.c:216 ../lib/ogsf/gsd_img_ppm.c:52
+#: ../lib/ogsf/gsd_img_ppm.c:95 ../lib/ogsf/gsd_img_tif.c:66
+#, c-format
+msgid "Unable to open file <%s> for writing"
+msgstr "Nav iespējams atvērt failu <%s> rakstīšanai"
-#: ../lib/init/grass.py:970
-#, python-format
-msgid "Invalid user interface specified - <%s>. Use the --help option to see valid interface names."
+#: ../lib/ogsf/gk2.c:272 ../lib/ogsf/gk2.c:285
+msgid "Check no. of frames requested and keyframes marked"
 msgstr ""
-#: ../lib/init/grass.py:989
-msgid ""
-"Error in GUI startup. See messages above (if any) and if necessary, please report this error to the GRASS developers.\n"
-"On systems with package manager, make sure you have the right GUI package, probably named grass-gui, installed.\n"
-"To run GRASS GIS in text mode use the -text flag.\n"
-"Use '--help' for further options\n"
-"     {cmd_name} --help\n"
-"See also: https://grass.osgeo.org/{cmd_name}/manuals/helptext.html"
+#: ../lib/ogsf/gk.c:320
+msgid "Need at least 3 keyframes for spline"
 msgstr ""
-#: ../lib/init/grass.py:1001
-msgid ""
-"Exit was requested in GUI.\n"
-"GRASS GIS will not start. Bye."
+#: ../lib/ogsf/gk.c:622
+msgid "Need at least 2 keyframes for interpolation"
 msgstr ""
-"Grafiskajā vidē bija pieprasīta iziešana.\n"
-"GRASS GIS netiks startēts."
-#: ../lib/init/grass.py:1004
-msgid ""
-"Invalid return code from GUI startup script.\n"
-"Please advise GRASS developers of this error."
+#: ../lib/ogsf/gsd_surf.c:1742
+msgid "Cut-plane points mis-match between surfaces. Check resolution(s)."
 msgstr ""
-#: ../lib/init/grass.py:1051
-msgid ""
-"Error reading data path information from g.gisenv.\n"
-"GISDBASE={gisbase}\n"
-"LOCATION_NAME={location}\n"
-"MAPSET={mapset}\n"
-"\n"
-"Check the <{file}> file."
+#: ../lib/ogsf/gp2.c:705
+msgid "Unknown icon marker, using \"sphere\""
 msgstr ""
-#: ../lib/init/grass.py:1132 ../lib/init/grass.py:1136
-msgid "Default locale settings are missing. GRASS running with C locale."
+#: ../lib/ogsf/gsds.c:109
+msgid "Maximum number of datasets exceeded"
 msgstr ""
-#: ../lib/init/grass.py:1214
-#, python-format
-msgid "Path '%s' doesn't exist"
-msgstr "Ceļš '%s' neeksitē"
-#: ../lib/init/grass.py:1216
-#, python-format
-msgid "Path '%s' not accessible."
-msgstr "Ceļš '%s' nav pieejams."
-#. GTC %s is mapset's folder path
-#: ../lib/init/grass.py:1221
-#, python-format
-msgid "You are not the owner of '%s'."
-msgstr "Jūs neesat '%s' īpašnieks."
-#: ../lib/init/grass.py:1229
-#, python-format
-msgid ""
-"%(user)s is currently running GRASS in selected mapset (file %(file)s found). Concurrent use not allowed.\n"
-"You can force launching GRASS using -f flag (note that you need permission for this operation). Have another look in the processor manager just to be sure..."
+#: ../lib/ogsf/gsdrape.c:207
+msgid "Unable to process vector map - out of memory"
 msgstr ""
-#: ../lib/init/grass.py:1236
-#, python-format
-msgid "%(user)s is currently running GRASS in selected mapset (file %(file)s found). Forcing to launch GRASS..."
+#: ../lib/ogsf/gvl_file.c:103
+msgid "Maximum number of datafiles exceeded"
 msgstr ""
-#: ../lib/init/grass.py:1240
-#, python-format
-msgid ""
-"Unable to properly access '%s'.\n"
-"Please notify system personnel."
+#: ../lib/ogsf/gvl_file.c:442
+#, c-format
+msgid "Unable to read range of 3D raster map <%s>"
 msgstr ""
-#: ../lib/init/grass.py:1261
-msgid "Building user fontcap..."
+#: ../lib/ogsf/gp3.c:148
+#, c-format
+msgid "No points from vector map <%s> fall within current region"
 msgstr ""
-#: ../lib/init/grass.py:1320
-msgid "The SHELL variable is not set"
+#: ../lib/ogsf/gp3.c:153
+#, c-format
+msgid "Vector map <%s> loaded (%d points)"
 msgstr ""
-#: ../lib/init/grass.py:1336
-msgid "Unsupported shell <{sh}>: {env_file}"
+#: ../lib/ogsf/gp3.c:211
+#, c-format
+msgid "Loading thematic points layer <%s>..."
 msgstr ""
-#: ../lib/init/grass.py:1352
-#, python-format
+#: ../lib/ogsf/gp3.c:288
+#, c-format
 msgid ""
-"Job file <%s> has been defined in the 'GRASS_BATCH_JOB' variable but not found. Exiting.\n"
-"\n"
-"Use 'unset GRASS_BATCH_JOB' to disable batch job processing."
+"%d points without category. Unable to determine color rules for features "
 msgstr ""
-#: ../lib/init/grass.py:1359
-#, python-format
-msgid "Change file permission to 'executable' for <%s>"
+#: ../lib/ogsf/gs_bm.c:124
+msgid "Bitmap mismatch"
 msgstr ""
-#: ../lib/init/grass.py:1374
-#, python-format
-msgid "Executing <%s> ..."
-msgstr "Izpilda <%s>...."
-#: ../lib/init/grass.py:1381
-msgid ""
-"Execution of <{cmd}> failed:\n"
-"{error}"
+#: ../lib/ogsf/gvl2.c:267
+#, c-format
+msgid "Loading 3d raster map <%s>..."
 msgstr ""
-#: ../lib/init/grass.py:1384
-#, python-format
-msgid "Execution of <%s> finished."
+#: ../lib/ogsf/trans.c:180
+msgid "Out of matrix stack space"
 msgstr ""
-#: ../lib/init/grass.py:1415
-msgid "Unable to close GUI. {0}"
+#: ../lib/ogsf/trans.c:200
+msgid "Tried to pop an empty stack"
 msgstr ""
-#: ../lib/init/grass.py:1442
-#, python-format
-msgid "Welcome to GRASS GIS %s"
+#: ../lib/ogsf/gsd_prim.c:146
+#, c-format
+msgid "Color Material: %d"
 msgstr ""
-#: ../lib/init/grass.py:1464
-msgid "GRASS GIS homepage:"
-msgstr "GRASS GIS mājas lapa:"
-#. GTC Running through: SHELL NAME
-#: ../lib/init/grass.py:1466
-msgid "This version running through:"
-msgstr "Šo versiju darbina:"
-#: ../lib/init/grass.py:1468
-msgid "Help is available with the command:"
-msgstr "Palīdzība ir pieejama ar komandu:"
-#: ../lib/init/grass.py:1469
-msgid "See the licence terms with:"
-msgstr "Licences informācija ir pieejama:"
-#: ../lib/init/grass.py:1470
-msgid "See citation options with:"
+#: ../lib/ogsf/gsd_prim.c:630
+#, c-format
+msgid ""
+"gsd_rot(): %c is an invalid axis specification. Rotation ignored. Please "
+"advise GRASS developers of this error"
 msgstr ""
-#: ../lib/init/grass.py:1473
-msgid "If required, restart the GUI with:"
-msgstr "Ja nepieciešams, grafisko vidi var pārstartēt ar:"
-#: ../lib/init/grass.py:1475
-msgid "Start the GUI with:"
-msgstr "Grafiskās vides startēšana: "
-#: ../lib/init/grass.py:1477
-msgid "When ready to quit enter:"
-msgstr "Lai izietu, izpildiet:"
-#: ../lib/init/grass.py:1565
-msgid "2D and 3D raster MASKs present"
+#: ../lib/ogsf/gsd_label.c:58
+msgid "Max. number of labels reached!"
 msgstr ""
-#: ../lib/init/grass.py:1566
-msgid "Raster MASK present"
+#: ../lib/ogsf/gs3.c:132 ../lib/ogsf/gs3.c:196 ../lib/ogsf/gs3.c:348
+#: ../lib/ogsf/gs3.c:454 ../lib/ogsf/gs3.c:540
+#, c-format
+msgid "Loading raster map <%s>..."
 msgstr ""
-#: ../lib/init/grass.py:1567
-msgid "3D raster MASK present"
+#: ../lib/ogsf/gs3.c:596
+#, c-format
+msgid "Color table range doesn't match data (mincol=%d, maxcol=%d"
 msgstr ""
-#: ../lib/init/grass.py:1607
-msgid "Done."
-msgstr "Pabeigts."
-#: ../lib/init/grass.py:1609
-msgid "Goodbye from GRASS GIS"
-msgstr "Uz redzēšanos"
-#: ../lib/init/grass.py:1614
-msgid "Cleaning up temporary files..."
-msgstr "Satīra pagaidu failus..."
-#: ../lib/init/grass.py:1634
-msgid "Please install the GRASS GIS development package"
+#: ../lib/ogsf/gs3.c:658 ../lib/ogsf/gs3.c:730
+#, c-format
+msgid "Translating colors from raster map <%s>..."
 msgstr ""
-#: ../lib/init/grass.py:1666
-#, python-format
-msgid "Parameter <%s> not supported"
-msgstr "Parametrs <%s> nav atbalstīts"
-#: ../lib/init/grass.py:1810
-msgid "Flag -e requires also flag -c"
+#: ../lib/ogsf/gs3.c:967
+msgid "View not saved by this program,there may be some inconsistancies"
 msgstr ""
-#: ../lib/init/grass.py:1857
-msgid ""
-"Unable to start GRASS GIS. You have the choice to:\n"
-" - Launch the graphical user interface with the '-gui' switch\n"
-"     {cmd_name} -gui\n"
-" - Launch with path to the location/mapset as an argument\n"
-"     {cmd_name} /path/to/location/mapset`\n"
-" - Create a location with '-c' and launch in its PERMANENT mapset\n"
-"     {cmd_name} -c EPSG:number /path/to/location\n"
-"     {cmd_name} -c geofile /path/to/location\n"
-" - Create manually the GISRC file ({gisrcrc})\n"
-" - Use '--help' for further options\n"
-msgstr ""
+#: ../lib/ogsf/gs2.c:1211
+#, c-format
+msgid "no category info"
+msgstr "nav kategoriju informācijas"
-#: ../lib/init/grass.py:1880
-msgid "Creating new GRASS GIS location/mapset..."
-msgstr ""
+#: ../lib/ogsf/gs2.c:1230
+#, c-format
+msgid "no data"
+msgstr "nav datu"
-#: ../lib/init/grass.py:1882
-msgid "Starting GRASS GIS..."
-msgstr "Startē GRASS GIS..."
+#: ../lib/ogsf/gs2.c:1655
+#, c-format
+msgid "Raster map <%s> is outside of current region. Load failed."
+msgstr "Rastra karte <%s> atrodas ārpus reģiona. Ielāde nav veikta."
-#: ../lib/init/grass.py:1903
-msgid "<{0}> requested, but not available. Run GRASS in text mode (-text) or install missing package (usually 'grass-gui')."
+#: ../lib/ogsf/gs2.c:1733 ../lib/ogsf/gs2.c:1739 ../lib/ogsf/gs2.c:1747
+#: ../lib/ogsf/gs2.c:1756 ../lib/ogsf/gs2.c:1764 ../lib/ogsf/gs2.c:1774
+#: ../lib/ogsf/gs2.c:1822
+msgid "GS_load_att_map(): Out of memory. Unable to load map"
 msgstr ""
-#: ../lib/init/grass.py:1957
-#, python-format
-msgid "Launching <%s> GUI in the background, please wait..."
-msgstr "Startē <%s> grafisko vidi fona režīmā. Lūdzu uzgaidiet..."
+#: ../lib/ogsf/gs2.c:1850
+msgid "Loading failed"
+msgstr "Nesekmīga ielāde"
-#: ../lib/init/grass.py:1979
-#, python-format
-msgid "Failed to start shell '%s'"
+#: ../lib/ogsf/gs2.c:1854
+msgid "Error finding range"
 msgstr ""
-#: ../lib/gis/debug.c:80
+#: ../lib/psdriver/graph_set.c:199
 #, c-format
-msgid "Cannot open debug file '%s'"
+msgid "ps: truecolor status %s"
 msgstr ""
-#: ../lib/gis/gisinit.c:53 ../lib/gis/gisinit.c:87
+#: ../lib/psdriver/graph_set.c:214
 #, c-format
-msgid "Module built against version %s but trying to use version %s. You need to rebuild GRASS GIS or untangle multiple installations."
+msgid "ps: collecting to file '%s'"
 msgstr ""
-#: ../lib/gis/gisinit.c:65
+#: ../lib/psdriver/graph_set.c:215
 #, c-format
-msgid "MAPSET %s - permission denied"
-msgstr "Karšu kopa %s - piekļuve ir liegta"
-#: ../lib/gis/gisinit.c:68
-#, c-format
-msgid "MAPSET %s not found at %s"
+msgid "ps: image size %dx%d"
 msgstr ""
-#: ../lib/gis/gisinit.c:102
-msgid "System not initialized. Programmer forgot to call G_gisinit()."
-msgstr "Sistēma nav inicializēta. Programmētājs aizmirsis izsaukt G_gisinit()."
-#: ../lib/gis/distance.c:154
-#, c-format
-msgid "%s: shouldn't happen: code=%d P=(%f,%f) S=(%f,%f)(%f,%f)"
-msgstr ""
-#: ../lib/gis/mkstemp.c:132
-msgid "Attempt to create read-only temporary file"
-msgstr ""
-#: ../lib/gis/mkstemp.c:138
-#, c-format
-msgid "Unrecognised access mode: %o"
-msgstr ""
 #: ../lib/gis/parser_html.c:57 ../lib/gis/parser_rest.c:60
 msgid "NAME"
 msgstr "NOSAUKUMS"
@@ -6952,6 +4800,11 @@
 msgid "SYNOPSIS"
 msgstr "KOPSAVILKUMS"
+#: ../lib/gis/parser_html.c:141 ../lib/gis/parser_rest.c:146
+#: ../lib/init/grass.py:333
+msgid "Flags"
+msgstr "Karogi"
 #: ../lib/gis/parser_html.c:167 ../lib/gis/parser_interface.c:329
 #: ../lib/gis/parser_help.c:215 ../lib/gis/parser_rest.c:164
 msgid "Allow output files to overwrite existing files"
@@ -6976,6 +4829,11 @@
 msgid "Force launching GUI dialog"
 msgstr ""
+#: ../lib/gis/parser_html.c:189 ../lib/gis/parser_rest.c:179
+#: ../lib/init/grass.py:347
+msgid "Parameters"
+msgstr "Parametri"
 #: ../lib/gis/parser_html.c:233 ../lib/gis/parser_rest.c:223
 msgid "Options"
 msgstr ""
@@ -6984,68 +4842,91 @@
 msgid "Default"
 msgstr ""
-#: ../lib/gis/spawn.c:386
+#: ../lib/gis/mapset_msc.c:90
 #, c-format
-msgid "CreateProcess() failed: error = %d"
+msgid "Unable to make mapset element %s (%s): %s"
 msgstr ""
-#: ../lib/gis/spawn.c:421
+#: ../lib/gis/mapset_msc.c:94
 #, c-format
-msgid "G_spawn: unable to redirect descriptor %d"
+msgid "Unable to access mapset element %s (%s): %s"
 msgstr ""
-#: ../lib/gis/spawn.c:429 ../lib/gis/spawn.c:619
+#: ../lib/gis/mapset.c:38
+msgid "MAPSET is not set"
+msgstr "KARŠU KOPA nav noteikta"
+#: ../lib/gis/mapset.c:80
 #, c-format
-msgid "G_spawn: unable to open file %s"
-msgstr "G_spawn: neispējami atvērt failu %s"
-#: ../lib/gis/spawn.c:503
-msgid "G_spawn: unable to execute command"
+msgid "MAPSET <%s> not available"
 msgstr ""
-#: ../lib/gis/spawn.c:528 ../lib/gis/spawn.c:536
+#: ../lib/gis/view.c:176
 #, c-format
-msgid "G_spawn: unable to restore signal %d"
-msgstr "G_spawn: neiespējami atjaunot signālu %d"
+msgid "Unable to open %s for writing"
+msgstr "Neiespējami atvērt %s priekš rakstīšanas"
-#: ../lib/gis/spawn.c:567
+#: ../lib/gis/view.c:262 ../lib/gis/view.c:479
 #, c-format
-msgid "G_spawn: unable to reset signal %d"
-msgstr "G_spawn: neiespējami pārlikt signālu %d"
+msgid "Unable to open %s for reading"
+msgstr "Neiespējami atvērt %s priekš lasīšanas"
-#: ../lib/gis/spawn.c:576
+#: ../lib/gis/view.c:465
 #, c-format
-msgid "G_spawn: unable to ignore signal %d"
-msgstr "G_spawn: neiespējami ignorēt signālu %d"
+msgid "GRASS window when view was saved:\n"
+msgstr "GRASS logs kad skats tika saglabāts:\n"
-#: ../lib/gis/spawn.c:587
+#: ../lib/gis/view.c:545
 #, c-format
-msgid "G_spawn: unable to block signal %d"
-msgstr "G_spawn: neiespējami bloķēt signālu %d"
+msgid " Window saved in \"%s\" is completely outside of current GRASS window."
+msgstr " Logs saglabāts \"%s\" un ir pilnībā ārpus tekošā GRASS loga."
-#: ../lib/gis/spawn.c:595
+#: ../lib/gis/view.c:549
 #, c-format
-msgid "G_spawn: unable to unblock signal %d"
-msgstr "G_spawn: neiespējami atbloķēt signālu %d"
+msgid ""
+" Only %d%% of window saved in \"%s\" overlaps with current GRASS window."
+msgstr ""
+" Tikai %d%% no loga ir saglabāts \"%s\" pārklājuma ar tekošo GRASS logu."
-#: ../lib/gis/spawn.c:624 ../lib/gis/spawn.c:633
+#: ../lib/gis/get_window.c:118
 #, c-format
-msgid "G_spawn: unable to duplicate descriptor %d to %d"
-msgstr "G_spawn: neiespējami dubultot deskriptoru %d to %d"
+msgid "Unable to open element file <%s> for <%s@%s>"
+msgstr ""
-#: ../lib/gis/spawn.c:666
-msgid "Unable to create a new process"
+#: ../lib/gis/get_window.c:123
+#, c-format
+msgid "Region file %s/%s/%s is empty"
 msgstr ""
-#: ../lib/gis/spawn.c:681
+#: ../lib/gis/open_misc.c:49
 #, c-format
-msgid "Unable to change directory to %s"
+msgid "G__open_misc(read): mapset <%s> doesn't match xmapset <%s>"
 msgstr ""
-#: ../lib/gis/spawn.c:689
-msgid "Unable to execute command"
+#: ../lib/gis/open_misc.c:74
+#, c-format
+msgid "G__open_misc(write): xmapset <%s> != G_mapset() <%s>"
 msgstr ""
+#: ../lib/gis/env.c:311
+msgid "GISRC - variable not set"
+msgstr "GISRC - mainīgais nav norādīts"
+#: ../lib/gis/env.c:343 ../lib/gis/env.c:369
+#, c-format
+msgid "Variable '%s' not set"
+msgstr "Mainīgais '%s' nav iestatīts"
+#: ../lib/gis/debug.c:80
+#, c-format
+msgid "Cannot open debug file '%s'"
+msgstr ""
+#: ../lib/gis/compress.c:131 ../lib/gis/compress.c:193
+#: ../lib/gis/compress.c:209
+msgid "Request for unsupported compressor"
+msgstr ""
 #: ../lib/gis/proj2.c:63
 msgid "Latitude-Longitude"
 msgstr "Platums-Garums"
@@ -7054,6 +4935,125 @@
 msgid "Other Projection"
 msgstr "Cita Projekcija"
+#: ../lib/gis/list.c:83
+#, c-format
+msgid "no %s files available in current mapset\n"
+msgstr ""
+#: ../lib/gis/list.c:86
+#, c-format
+msgid "no %s files available in mapset <%s>\n"
+msgstr ""
+#: ../lib/gis/list.c:132
+#, c-format
+msgid "%s files available in mapset <%s>:\n"
+msgstr ""
+#: ../lib/gis/list.c:204
+msgid "G_list: Unknown element type"
+msgstr "G_list: nezināms elementa tips"
+#: ../lib/gis/alloc.c:44 ../lib/gis/alloc.c:86 ../lib/gis/alloc.c:132
+#, c-format
+msgid "Current region rows: %d, cols: %d"
+msgstr ""
+#: ../lib/gis/alloc.c:47
+#, c-format
+msgid "G_malloc: unable to allocate %lu bytes of memory at %s:%d"
+msgstr ""
+#: ../lib/gis/alloc.c:89
+#, c-format
+msgid "G_calloc: unable to allocate %lu * %lu bytes of memory at %s:%d"
+msgstr ""
+#: ../lib/gis/alloc.c:135
+#, c-format
+msgid "G_realloc: unable to allocate %lu bytes of memory at %s:%d"
+msgstr ""
+#: ../lib/gis/find_file.c:114
+#, c-format
+msgid "Data element '%s/%s' was found in more mapsets (also found in <%s>)"
+msgstr ""
+#: ../lib/gis/find_file.c:127
+#, c-format
+msgid "Using <%s@%s>..."
+msgstr ""
+#: ../lib/gis/done_msg.c:38
+#, c-format
+msgid "%s complete. %s"
+msgstr "%s izpildīts. %s"
+#: ../lib/gis/make_mapset.c:66 ../lib/init/grass.py:845
+msgid "Location <%s> doesn't exist"
+msgstr "Novietojums <%s> neeksistē"
+#: ../lib/gis/get_projinfo.c:37 ../lib/gis/get_projinfo.c:66
+#, c-format
+msgid "<%s> file not found for location <%s>"
+msgstr ""
+#: ../lib/gis/parser_wps.c:490
+msgid "Multiple outputs are not supported by WPS 1.0.0"
+msgstr ""
+#: ../lib/gis/worker.c:84
+msgid "Task already has a worker"
+msgstr ""
+#: ../lib/gis/parser_help.c:84
+msgid "Description:"
+msgstr "Apraksts:"
+#: ../lib/gis/parser_help.c:103
+msgid "Keywords:"
+msgstr "Atslēgvārdi:"
+#: ../lib/gis/parser_help.c:111
+msgid "Usage:"
+msgstr "Pieleitojums:"
+#: ../lib/gis/parser_help.c:141
+msgid "ERROR: Option key not defined"
+msgstr ""
+#: ../lib/gis/parser_help.c:191
+msgid "Flags:"
+msgstr "Karogi:"
+#: ../lib/gis/parser_help.c:220
+msgid "Super quiet module output"
+msgstr ""
+#: ../lib/gis/parser_help.c:230
+msgid "Parameters:"
+msgstr "Parametri:"
+#: ../lib/gis/parser_help.c:253
+#, c-format
+msgid "  %*s   default: %s\n"
+msgstr "  %*s   noklusētais: %s\n"
+#: ../lib/gis/parser_help.c:279
+#, c-format
+msgid "  %*s   options: "
+msgstr "  %*s   opcijas: "
+#: ../lib/gis/mkstemp.c:132
+msgid "Attempt to create read-only temporary file"
+msgstr ""
+#: ../lib/gis/mkstemp.c:138
+#, c-format
+msgid "Unrecognised access mode: %o"
+msgstr ""
 #: ../lib/gis/units.c:208
 msgid "square units"
 msgstr ""
@@ -7230,50 +5230,6 @@
 msgid "second"
 msgstr "sekunde"
-#: ../lib/gis/parser_wps.c:490
-msgid "Multiple outputs are not supported by WPS 1.0.0"
-msgstr ""
-#: ../lib/gis/ls.c:103
-#, c-format
-msgid "Unable to open directory %s"
-msgstr "Nevar atvērt mapi %s"
-#: ../lib/gis/open_misc.c:49
-#, c-format
-msgid "G__open_misc(read): mapset <%s> doesn't match xmapset <%s>"
-msgstr ""
-#: ../lib/gis/open_misc.c:74
-#, c-format
-msgid "G__open_misc(write): xmapset <%s> != G_mapset() <%s>"
-msgstr ""
-#: ../lib/gis/get_projinfo.c:37 ../lib/gis/get_projinfo.c:66
-#, c-format
-msgid "<%s> file not found for location <%s>"
-msgstr ""
-#: ../lib/gis/datum.c:160
-#, c-format
-msgid "unable to open datum table file: %s"
-msgstr "neispējami atvērt datumu tabulas failu: %s"
-#: ../lib/gis/datum.c:182
-#, c-format
-msgid "error in datum table file, line %d"
-msgstr "kļūda datumu tabulas failā, līnija  %d"
-#: ../lib/gis/get_window.c:118
-#, c-format
-msgid "Unable to open element file <%s> for <%s@%s>"
-msgstr ""
-#: ../lib/gis/get_window.c:123
-#, c-format
-msgid "Region file %s/%s/%s is empty"
-msgstr ""
 #: ../lib/gis/parser_standard_options.c:147
 msgid "SQL SELECT statement"
 msgstr "SQL SELECT izteikums"
@@ -7307,7 +5263,8 @@
 msgstr ""
 #: ../lib/gis/parser_standard_options.c:193
-msgid "Do not use this option if schemas are not supported by driver/database server"
+msgid ""
+"Do not use this option if schemas are not supported by driver/database server"
 msgstr ""
 #: ../lib/gis/parser_standard_options.c:202
@@ -7443,7 +5400,9 @@
 msgstr ""
 #: ../lib/gis/parser_standard_options.c:433
-msgid "Number of digits used as mantissa in the internal map storage, 0 -23 for float, 0 - 52 for double, max or default"
+msgid ""
+"Number of digits used as mantissa in the internal map storage, 0 -23 for "
+"float, 0 - 52 for double, max or default"
 msgstr ""
 #: ../lib/gis/parser_standard_options.c:443
@@ -7451,7 +5410,9 @@
 msgstr ""
 #: ../lib/gis/parser_standard_options.c:453
-msgid "The dimensions of the tiles used in the output raster3d map (XxYxZ or default: 16x16x8)"
+msgid ""
+"The dimensions of the tiles used in the output raster3d map (XxYxZ or "
+"default: 16x16x8)"
 msgstr ""
 #: ../lib/gis/parser_standard_options.c:463
@@ -7493,7 +5454,10 @@
 msgstr "Slāņa numurs vai nosaukums"
 #: ../lib/gis/parser_standard_options.c:527
-msgid "Vector features can have category values in different layers. This number determines which layer to use. When used with direct OGR access this is the layer name."
+msgid ""
+"Vector features can have category values in different layers. This number "
+"determines which layer to use. When used with direct OGR access this is the "
+"layer name."
 msgstr ""
 #: ../lib/gis/parser_standard_options.c:537
@@ -7501,7 +5465,10 @@
 msgstr "Slāņa numurs vai nosaukums ('-1' priekš visiem slāņiem)"
 #: ../lib/gis/parser_standard_options.c:539
-msgid "A single vector map can be connected to multiple database tables. This number determines which table to use. When used with direct OGR access this is the layer name."
+msgid ""
+"A single vector map can be connected to multiple database tables. This "
+"number determines which table to use. When used with direct OGR access this "
+"is the layer name."
 msgstr ""
 #: ../lib/gis/parser_standard_options.c:548
@@ -7676,7 +5643,9 @@
 msgstr ""
 #: ../lib/gis/parser_standard_options.c:887
-msgid "WHERE conditions of SQL statement without 'where' keyword used in the temporal GIS framework"
+msgid ""
+"WHERE conditions of SQL statement without 'where' keyword used in the "
+"temporal GIS framework"
 msgstr ""
 #: ../lib/gis/parser_standard_options.c:888
@@ -7699,104 +5668,318 @@
 msgid "Advantageous when handling a large number of points"
 msgstr ""
-#: ../lib/gis/token.c:169
-msgid "parse error"
+#: ../lib/gis/location.c:61
+#, c-format
+msgid "LOCATION <%s> not available"
 msgstr ""
-#: ../lib/gis/worker.c:84
-msgid "Task already has a worker"
+#: ../lib/gis/adj_cellhd.c:57
+#, c-format
+msgid "Illegal n-s resolution value <%lf>"
 msgstr ""
-#: ../lib/gis/home.c:39
-msgid "Unable to determine user's home directory"
+#: ../lib/gis/adj_cellhd.c:61 ../lib/gis/adj_cellhd.c:163
+msgid "Illegal row value"
+msgstr "Neatļauta rindas vērtība"
+#: ../lib/gis/adj_cellhd.c:65 ../lib/gis/adj_cellhd.c:169
+msgid "Illegal e-w resolution value"
+msgstr "Neatļauta e-w izšķirtspējas vērtība"
+#: ../lib/gis/adj_cellhd.c:69 ../lib/gis/adj_cellhd.c:175
+msgid "Illegal col value"
+msgstr "Neatļauta kolonas vērtība"
+#: ../lib/gis/adj_cellhd.c:75 ../lib/gis/adj_cellhd.c:191
+msgid "North must be north of South"
+msgstr "Ziemeļiem ir jāatrodas uz ziemeļiem no dienvidiem"
+#: ../lib/gis/adj_cellhd.c:77 ../lib/gis/adj_cellhd.c:193
+msgid "North must be larger than South"
+msgstr "Ziemeļiem ir jābūt lielākiem nekā Dienvidiem"
+#: ../lib/gis/adj_cellhd.c:83 ../lib/gis/adj_cellhd.c:199
+msgid "East must be larger than West"
+msgstr "Austrumiem ir jābūt lielākiem nekā Rietumiem"
+#: ../lib/gis/adj_cellhd.c:102 ../lib/gis/adj_cellhd.c:242
+msgid "Invalid coordinates"
+msgstr "Nederīgas koordinātes"
+#: ../lib/gis/adj_cellhd.c:109 ../lib/gis/adj_cellhd.c:249
+msgid "NS resolution has been changed"
 msgstr ""
-#: ../lib/gis/home.c:120
+#: ../lib/gis/adj_cellhd.c:114 ../lib/gis/adj_cellhd.c:254
+msgid "EW resolution has been changed"
+msgstr ""
+#: ../lib/gis/adj_cellhd.c:117 ../lib/gis/adj_cellhd.c:257
+msgid "NS and EW resolutions are different"
+msgstr ""
+#: ../lib/gis/adj_cellhd.c:157
+msgid "Illegal n-s resolution value"
+msgstr "Neatļauta n-s izšķirtspējas vērtība"
+#: ../lib/gis/adj_cellhd.c:159
+msgid "Illegal n-s3 resolution value"
+msgstr "Nederīga n-s3 izšķirtspējas vērtība"
+#: ../lib/gis/adj_cellhd.c:165
+msgid "Illegal row3 value"
+msgstr "Neatļauta row3 vērtība"
+#: ../lib/gis/adj_cellhd.c:171
+msgid "Illegal e-w3 resolution value"
+msgstr "Neatļauta e-w3 izšķirtspējas vērtība"
+#: ../lib/gis/adj_cellhd.c:177
+msgid "Illegal col3 value"
+msgstr "Neatļauta col3 vērtība"
+#: ../lib/gis/adj_cellhd.c:181
+msgid "Illegal t-b3 resolution value"
+msgstr "Neatļauta t-b3 izšķirtspējas vērtība"
+#: ../lib/gis/adj_cellhd.c:185
+msgid "Illegal depths value"
+msgstr "Neatļauta dziļuma vērtība"
+#: ../lib/gis/adj_cellhd.c:202
+msgid "Top must be larger than Bottom"
+msgstr "Augšai ir jābūt lielākai par Apakšu"
+#: ../lib/gis/adj_cellhd.c:276
+#, fuzzy, c-format
+msgid "East (%.15g) is not larger than West (%.15g)"
+#: ../lib/gis/adj_cellhd.c:311
+#, fuzzy, c-format
+msgid "Illegal latitude for North: %g"
+msgstr "Neatļauta platuma vērtība Ziemeļiem"
+#: ../lib/gis/adj_cellhd.c:313
+#, fuzzy, c-format
+msgid "Illegal latitude for South: %g"
+msgstr "Neatļauta platuma vērtība Dienvidiem"
+#: ../lib/gis/adj_cellhd.c:319
+#, fuzzy, c-format
+msgid "Illegal longitude for West: %g"
+#: ../lib/gis/adj_cellhd.c:323
+#, fuzzy, c-format
+msgid "Illegal longitude for East: %g"
+#: ../lib/gis/adj_cellhd.c:351
 #, c-format
-msgid "Failed to create directory [%s]"
+msgid "NS extent does not match NS resolution: %g cells difference"
 msgstr ""
-#: ../lib/gis/myname.c:46
-msgid "This location has no description."
+#: ../lib/gis/adj_cellhd.c:360
+#, c-format
+msgid "%g cells missing to reach 90 degree north"
 msgstr ""
-#: ../lib/gis/lrand48.c:84
+#: ../lib/gis/adj_cellhd.c:363 ../lib/gis/adj_cellhd.c:377
+#: ../lib/gis/adj_cellhd.c:391
 #, c-format
-msgid "gettimeofday failed: %s"
+msgid "Subtle input data rounding error of north boundary (%g)"
 msgstr ""
-#: ../lib/gis/lrand48.c:114
-msgid "Pseudo-random number generator not seeded"
+#: ../lib/gis/adj_cellhd.c:373
+#, c-format
+msgid "90 degree north is exceeded by %g cells"
 msgstr ""
-#: ../lib/gis/error.c:361
-msgid "WARNING: "
-msgstr "BRĪDINĀJUMS:"
+#: ../lib/gis/adj_cellhd.c:402
+msgid "Illegal latitude for North"
-#: ../lib/gis/error.c:362 ../lib/gis/parser.c:1592
+#: ../lib/gis/adj_cellhd.c:410
 #, c-format
-msgid "ERROR: "
-msgstr "KĻŪDA: "
+msgid "%g cells missing to reach 90 degree south"
+msgstr ""
-#: ../lib/gis/cmprbzip.c:82 ../lib/gis/cmprbzip.c:142
-msgid "GRASS needs to be compiled with BZIP2 for BZIP2 compression"
+#: ../lib/gis/adj_cellhd.c:413 ../lib/gis/adj_cellhd.c:427
+#: ../lib/gis/adj_cellhd.c:441
+#, c-format
+msgid "Subtle input data rounding error of south boundary (%g)"
 msgstr ""
-#: ../lib/gis/key_value3.c:33
+#: ../lib/gis/adj_cellhd.c:423
 #, c-format
-msgid "Unable to open output file <%s>: %s"
+msgid "90 degree south is exceeded by %g cells"
 msgstr ""
-#: ../lib/gis/key_value3.c:36
+#: ../lib/gis/adj_cellhd.c:452
+msgid "Illegal latitude for South"
+#: ../lib/gis/adj_cellhd.c:481
 #, c-format
-msgid "Error writing file <%s>: %s"
+msgid "EW extent does not match EW resolution: %g cells difference"
 msgstr ""
-#: ../lib/gis/key_value3.c:39
+#: ../lib/gis/adj_cellhd.c:487
 #, c-format
-msgid "Error closing output file <%s>: %s"
+msgid "360 degree EW extent is exceeded by %g cells"
 msgstr ""
-#: ../lib/gis/key_value3.c:60
+#: ../lib/gis/adj_cellhd.c:493
 #, c-format
-msgid "Unable to open input file <%s>: %s"
+msgid "%g cells missing to cover 360 degree EW extent"
 msgstr ""
-#: ../lib/gis/key_value3.c:64
+#: ../lib/gis/adj_cellhd.c:528
+msgid "Invalid NS resolution"
+msgstr "Nederīga ZD izšķirtspēja"
+#: ../lib/gis/adj_cellhd.c:533
+msgid "Invalid EW resolution"
+msgstr "Nederīga AR izšķirtspēja"
+#: ../lib/gis/adj_cellhd.c:538
+msgid "Invalid North"
+msgstr "Nederīgi ziemeļi"
+#: ../lib/gis/adj_cellhd.c:543
+msgid "Invalid South"
+msgstr "Nederīgi dienvidi"
+#: ../lib/gis/adj_cellhd.c:548
+msgid "Invalid West"
+msgstr "Nederīgi rietumi"
+#: ../lib/gis/adj_cellhd.c:553
+msgid "Invalid East"
+msgstr "Nederīgi austrumi"
+#: ../lib/gis/adj_cellhd.c:606
 #, c-format
-msgid "Error reading file <%s>: %s"
+msgid "NS resolution rounded from %s to %s"
 msgstr ""
-#: ../lib/gis/key_value3.c:67
+#: ../lib/gis/adj_cellhd.c:639 ../lib/gis/adj_cellhd.c:694
 #, c-format
-msgid "Error closing input file <%s>: %s"
+msgid "North rounded from %s to %s"
 msgstr ""
-#: ../lib/gis/done_msg.c:38
+#: ../lib/gis/adj_cellhd.c:651
 #, c-format
-msgid "%s complete. %s"
-msgstr "%s izpildīts. %s"
+msgid "South adjusted from %s to %s"
+msgstr ""
-#: ../lib/gis/open.c:68
+#: ../lib/gis/adj_cellhd.c:666 ../lib/gis/adj_cellhd.c:709
 #, c-format
-msgid "G__open(read): mapset <%s> doesn't match xmapset <%s>"
+msgid "South rounded from %s to %s"
 msgstr ""
-#: ../lib/gis/open.c:89
+#: ../lib/gis/adj_cellhd.c:678
 #, c-format
-msgid "G__open(read): Unable to open '%s': %s"
+msgid "North adjusted from %s to %s"
 msgstr ""
-#: ../lib/gis/open.c:98
+#: ../lib/gis/adj_cellhd.c:732
 #, c-format
-msgid "G__open(write): xmapset <%s> != G_mapset() <%s>"
+msgid "EW resolution rounded from %s to %s"
 msgstr ""
-#: ../lib/gis/open.c:122
+#: ../lib/gis/adj_cellhd.c:765 ../lib/gis/adj_cellhd.c:820
 #, c-format
-msgid "G__open(write): Unable to open '%s': %s"
+msgid "West rounded from %s to %s"
 msgstr ""
+#: ../lib/gis/adj_cellhd.c:777
+#, c-format
+msgid "East adjusted from %s to %s"
+msgstr ""
+#: ../lib/gis/adj_cellhd.c:792 ../lib/gis/adj_cellhd.c:835
+#, c-format
+msgid "East rounded from %s to %s"
+msgstr ""
+#: ../lib/gis/adj_cellhd.c:804
+#, c-format
+msgid "West adjusted from %s to %s"
+msgstr ""
+#: ../lib/gis/myname.c:46
+msgid "This location has no description."
+msgstr ""
+#: ../lib/gis/color_rules.c:88
+msgid "no description"
+msgstr "nav apraksta"
+#: ../lib/gis/error.c:361
+msgid "WARNING: "
+msgstr "BRĪDINĀJUMS:"
+#: ../lib/gis/error.c:362 ../lib/gis/parser.c:1588
+#, c-format
+msgid "ERROR: "
+msgstr "KĻŪDA: "
+#: ../lib/gis/timestamp.c:292
+#, c-format
+msgid "Unable to create timestamp file for %s map <%s@%s>"
+msgstr ""
+#: ../lib/gis/timestamp.c:301
+#, c-format
+msgid "Invalid timestamp specified for %s map <%s@%s>"
+msgstr ""
+#: ../lib/gis/timestamp.c:331
+#, c-format
+msgid "Unable to open timestamp file for %s map <%s@%s>"
+msgstr ""
+#: ../lib/gis/timestamp.c:340
+#, c-format
+msgid "Invalid timestamp file for %s map <%s@%s>"
+msgstr ""
+#: ../lib/gis/timestamp.c:479
+#, c-format
+msgid "Unable to open timestamp file for vector map <%s@%s>"
+msgstr ""
+#: ../lib/gis/timestamp.c:488
+#, c-format
+msgid "Invalid timestamp file for vector map <%s@%s>"
+msgstr ""
+#: ../lib/gis/timestamp.c:524
+#, c-format
+msgid "Unable to create timestamp file for vector map <%s@%s>"
+msgstr ""
+#: ../lib/gis/timestamp.c:533
+#, c-format
+msgid "Invalid timestamp specified for vector map <%s@%s>"
+msgstr ""
+#: ../lib/gis/cmprbzip.c:82 ../lib/gis/cmprbzip.c:142
+msgid "GRASS needs to be compiled with BZIP2 for BZIP2 compression"
+msgstr ""
+#: ../lib/gis/datum.c:160
+#, c-format
+msgid "unable to open datum table file: %s"
+msgstr "neispējami atvērt datumu tabulas failu: %s"
+#: ../lib/gis/datum.c:182
+#, c-format
+msgid "error in datum table file, line %d"
+msgstr "kļūda datumu tabulas failā, līnija  %d"
 #: ../lib/gis/rd_cellhd.c:141 ../lib/gis/rd_cellhd.c:180
 #: ../lib/gis/rd_cellhd.c:357
 #, c-format
@@ -7993,6 +6176,49 @@
 msgid "Invalid compressed field: %s"
 msgstr ""
+#: ../lib/gis/open.c:68
+#, c-format
+msgid "G__open(read): mapset <%s> doesn't match xmapset <%s>"
+msgstr ""
+#: ../lib/gis/open.c:89
+#, c-format
+msgid "G__open(read): Unable to open '%s': %s"
+msgstr ""
+#: ../lib/gis/open.c:98
+#, c-format
+msgid "G__open(write): xmapset <%s> != G_mapset() <%s>"
+msgstr ""
+#: ../lib/gis/open.c:122
+#, c-format
+msgid "G__open(write): Unable to open '%s': %s"
+msgstr ""
+#: ../lib/gis/home.c:39
+msgid "Unable to determine user's home directory"
+msgstr ""
+#: ../lib/gis/home.c:120
+#, c-format
+msgid "Failed to create directory [%s]"
+msgstr ""
+#: ../lib/gis/paths.c:201
+#, c-format
+msgid "Unable to open file <%s> for reading"
+msgstr ""
+#: ../lib/gis/paths.c:217
+#, c-format
+msgid "Unable to fetch security info for <%s>"
+msgstr ""
+#: ../lib/gis/token.c:169
+msgid "parse error"
+msgstr ""
 #: ../lib/gis/parser_dependencies.c:122
 msgid "Internal error: option or flag not found"
 msgstr ""
@@ -8047,669 +6273,1134 @@
 msgid "Internal error: invalid rule type: %d"
 msgstr ""
-#: ../lib/gis/color_rules.c:88
-msgid "no description"
-msgstr "nav apraksta"
+#: ../lib/gis/spawn.c:386
+#, c-format
+msgid "CreateProcess() failed: error = %d"
+msgstr ""
-#: ../lib/gis/env.c:311
-msgid "GISRC - variable not set"
-msgstr "GISRC - mainīgais nav norādīts"
+#: ../lib/gis/spawn.c:421
+#, c-format
+msgid "G_spawn: unable to redirect descriptor %d"
+msgstr ""
-#: ../lib/gis/env.c:343 ../lib/gis/env.c:369
+#: ../lib/gis/spawn.c:429 ../lib/gis/spawn.c:619
 #, c-format
-msgid "Variable '%s' not set"
-msgstr "Mainīgais '%s' nav iestatīts"
+msgid "G_spawn: unable to open file %s"
+msgstr "G_spawn: neispējami atvērt failu %s"
-#: ../lib/gis/parser_help.c:84
-msgid "Description:"
-msgstr "Apraksts:"
+#: ../lib/gis/spawn.c:503
+msgid "G_spawn: unable to execute command"
+msgstr ""
-#: ../lib/gis/parser_help.c:103
-msgid "Keywords:"
-msgstr "Atslēgvārdi:"
+#: ../lib/gis/spawn.c:528 ../lib/gis/spawn.c:536
+#, c-format
+msgid "G_spawn: unable to restore signal %d"
+msgstr "G_spawn: neiespējami atjaunot signālu %d"
-#: ../lib/gis/parser_help.c:111
-msgid "Usage:"
-msgstr "Pieleitojums:"
+#: ../lib/gis/spawn.c:567
+#, c-format
+msgid "G_spawn: unable to reset signal %d"
+msgstr "G_spawn: neiespējami pārlikt signālu %d"
-#: ../lib/gis/parser_help.c:141
-msgid "ERROR: Option key not defined"
+#: ../lib/gis/spawn.c:576
+#, c-format
+msgid "G_spawn: unable to ignore signal %d"
+msgstr "G_spawn: neiespējami ignorēt signālu %d"
+#: ../lib/gis/spawn.c:587
+#, c-format
+msgid "G_spawn: unable to block signal %d"
+msgstr "G_spawn: neiespējami bloķēt signālu %d"
+#: ../lib/gis/spawn.c:595
+#, c-format
+msgid "G_spawn: unable to unblock signal %d"
+msgstr "G_spawn: neiespējami atbloķēt signālu %d"
+#: ../lib/gis/spawn.c:624 ../lib/gis/spawn.c:633
+#, c-format
+msgid "G_spawn: unable to duplicate descriptor %d to %d"
+msgstr "G_spawn: neiespējami dubultot deskriptoru %d to %d"
+#: ../lib/gis/spawn.c:666
+#, fuzzy, c-format
+msgid "Unable to create a new process: %s"
+msgstr "Nevar ierakstīt mezglus"
+#: ../lib/gis/spawn.c:681
+#, c-format
+msgid "Unable to change directory to %s"
 msgstr ""
-#: ../lib/gis/parser_help.c:191
-msgid "Flags:"
-msgstr "Karogi:"
+#: ../lib/gis/spawn.c:689
+msgid "Unable to execute command"
+msgstr ""
-#: ../lib/gis/parser_help.c:220
-msgid "Super quiet module output"
+#: ../lib/gis/seek.c:52 ../lib/gis/seek.c:58
+msgid "Unable to seek"
 msgstr ""
-#: ../lib/gis/parser_help.c:230
-msgid "Parameters:"
-msgstr "Parametri:"
+#: ../lib/gis/seek.c:56
+msgid "Seek offset out of range"
+msgstr ""
-#: ../lib/gis/parser_help.c:253
+#: ../lib/gis/gisinit.c:53 ../lib/gis/gisinit.c:87
 #, c-format
-msgid "  %*s   default: %s\n"
-msgstr "  %*s   noklusētais: %s\n"
+msgid ""
+"Module built against version %s but trying to use version %s. You need to "
+"rebuild GRASS GIS or untangle multiple installations."
+msgstr ""
-#: ../lib/gis/parser_help.c:279
+#: ../lib/gis/gisinit.c:65
 #, c-format
-msgid "  %*s   options: "
-msgstr "  %*s   opcijas: "
+msgid "MAPSET %s - permission denied"
+msgstr "Karšu kopa %s - piekļuve ir liegta"
-#: ../lib/gis/adj_cellhd.c:57
+#: ../lib/gis/gisinit.c:68
 #, c-format
-msgid "Illegal n-s resolution value <%lf>"
+msgid "MAPSET %s not found at %s"
 msgstr ""
-#: ../lib/gis/adj_cellhd.c:61 ../lib/gis/adj_cellhd.c:163
-msgid "Illegal row value"
-msgstr "Neatļauta rindas vērtība"
+#: ../lib/gis/gisinit.c:102
+msgid "System not initialized. Programmer forgot to call G_gisinit()."
+msgstr "Sistēma nav inicializēta. Programmētājs aizmirsis izsaukt G_gisinit()."
-#: ../lib/gis/adj_cellhd.c:65 ../lib/gis/adj_cellhd.c:169
-msgid "Illegal e-w resolution value"
-msgstr "Neatļauta e-w izšķirtspējas vērtība"
+#: ../lib/gis/key_value3.c:33
+#, c-format
+msgid "Unable to open output file <%s>: %s"
+msgstr ""
-#: ../lib/gis/adj_cellhd.c:69 ../lib/gis/adj_cellhd.c:175
-msgid "Illegal col value"
-msgstr "Neatļauta kolonas vērtība"
+#: ../lib/gis/key_value3.c:36
+#, c-format
+msgid "Error writing file <%s>: %s"
+msgstr ""
-#: ../lib/gis/adj_cellhd.c:75 ../lib/gis/adj_cellhd.c:191
-msgid "North must be north of South"
-msgstr "Ziemeļiem ir jāatrodas uz ziemeļiem no dienvidiem"
+#: ../lib/gis/key_value3.c:39
+#, c-format
+msgid "Error closing output file <%s>: %s"
+msgstr ""
-#: ../lib/gis/adj_cellhd.c:77 ../lib/gis/adj_cellhd.c:193
-msgid "North must be larger than South"
-msgstr "Ziemeļiem ir jābūt lielākiem nekā Dienvidiem"
+#: ../lib/gis/key_value3.c:60
+#, c-format
+msgid "Unable to open input file <%s>: %s"
+msgstr ""
-#: ../lib/gis/adj_cellhd.c:83 ../lib/gis/adj_cellhd.c:199
-msgid "East must be larger than West"
-msgstr "Austrumiem ir jābūt lielākiem nekā Rietumiem"
+#: ../lib/gis/key_value3.c:64
+#, c-format
+msgid "Error reading file <%s>: %s"
+msgstr ""
-#: ../lib/gis/adj_cellhd.c:102 ../lib/gis/adj_cellhd.c:242
-msgid "Invalid coordinates"
-msgstr "Nederīgas koordinātes"
+#: ../lib/gis/key_value3.c:67
+#, c-format
+msgid "Error closing input file <%s>: %s"
+msgstr ""
-#: ../lib/gis/adj_cellhd.c:109 ../lib/gis/adj_cellhd.c:249
-msgid "NS resolution has been changed"
+#: ../lib/gis/lrand48.c:84
+#, c-format
+msgid "gettimeofday failed: %s"
 msgstr ""
-#: ../lib/gis/adj_cellhd.c:114 ../lib/gis/adj_cellhd.c:254
-msgid "EW resolution has been changed"
+#: ../lib/gis/lrand48.c:114
+msgid "Pseudo-random number generator not seeded"
 msgstr ""
-#: ../lib/gis/adj_cellhd.c:117 ../lib/gis/adj_cellhd.c:257
-msgid "NS and EW resolutions are different"
+#: ../lib/gis/parser.c:355
+#, c-format
+msgid "BUG in option name, '%s' is not valid"
 msgstr ""
-#: ../lib/gis/adj_cellhd.c:157
-msgid "Illegal n-s resolution value"
-msgstr "Neatļauta n-s izšķirtspējas vērtība"
+#: ../lib/gis/parser.c:407
+#, c-format
+msgid "BUG in descriptions, option '%s' in <%s> does not exist"
+msgstr ""
-#: ../lib/gis/adj_cellhd.c:159
-msgid "Illegal n-s3 resolution value"
-msgstr "Nederīga n-s3 izšķirtspējas vērtība"
+#: ../lib/gis/parser.c:525
+msgid "Use either --quiet or --verbose flag, not both. Assuming --verbose."
+msgstr ""
-#: ../lib/gis/adj_cellhd.c:165
-msgid "Illegal row3 value"
-msgstr "Neatļauta row3 vērtība"
+#: ../lib/gis/parser.c:539
+msgid "Use either --quiet or --verbose flag, not both. Assuming --quiet."
+msgstr ""
-#: ../lib/gis/adj_cellhd.c:171
-msgid "Illegal e-w3 resolution value"
-msgstr "Neatļauta e-w3 izšķirtspējas vērtība"
+#: ../lib/gis/parser.c:554
+msgid "Use either --qq or --verbose flag, not both. Assuming --qq."
+msgstr ""
-#: ../lib/gis/adj_cellhd.c:177
-msgid "Illegal col3 value"
-msgstr "Neatļauta col3 vērtība"
+#: ../lib/gis/parser.c:585
+#, c-format
+msgid "Sorry <%s> is not a valid option"
+msgstr "Atvainojiet, <%s> nav derīgs parametrs"
-#: ../lib/gis/adj_cellhd.c:181
-msgid "Illegal t-b3 resolution value"
-msgstr "Neatļauta t-b3 izšķirtspējas vērtība"
+#: ../lib/gis/parser.c:598
+msgid "Your installation doesn't include GUI, exiting."
+msgstr ""
-#: ../lib/gis/adj_cellhd.c:185
-msgid "Illegal depths value"
-msgstr "Neatļauta dziļuma vērtība"
+#: ../lib/gis/parser.c:621 ../lib/init/grass.py:187
+msgid "ERROR"
+msgstr "KĻŪDA"
-#: ../lib/gis/adj_cellhd.c:202
-msgid "Top must be larger than Bottom"
-msgstr "Augšai ir jābūt lielākai par Apakšu"
+#: ../lib/gis/parser.c:943
+msgid "Unable to determine program name"
+msgstr "Nav iespējams noteikt programmas nosaukumu"
-#: ../lib/gis/adj_cellhd.c:276
-#, fuzzy, c-format
-msgid "East (%.15g) is not larger than West (%.15g)"
+#: ../lib/gis/parser.c:965 ../lib/gis/parser.c:984
+#, c-format
+msgid "%s: Sorry, <%c> is not a valid flag"
+msgstr ""
-#: ../lib/gis/adj_cellhd.c:311
-#, fuzzy, c-format
-msgid "Illegal latitude for North: %g"
-msgstr "Neatļauta platuma vērtība Ziemeļiem"
+#: ../lib/gis/parser.c:1114
+#, c-format
+msgid "%s: Sorry, <%s=> is ambiguous"
+msgstr ""
-#: ../lib/gis/adj_cellhd.c:313
-#, fuzzy, c-format
-msgid "Illegal latitude for South: %g"
-msgstr "Neatļauta platuma vērtība Dienvidiem"
+#: ../lib/gis/parser.c:1117
+#, c-format
+msgid "Option <%s=> matches"
+msgstr ""
-#: ../lib/gis/adj_cellhd.c:319
-#, fuzzy, c-format
-msgid "Illegal longitude for West: %g"
+#: ../lib/gis/parser.c:1135
+#, c-format
+msgid "Please update the usage of <%s>: option <%s> has been renamed to <%s>"
+msgstr ""
-#: ../lib/gis/adj_cellhd.c:323
-#, fuzzy, c-format
-msgid "Illegal longitude for East: %g"
+#: ../lib/gis/parser.c:1148
+#, c-format
+msgid "%s: Sorry, <%s> is not a valid parameter"
+msgstr ""
-#: ../lib/gis/adj_cellhd.c:351
+#: ../lib/gis/parser.c:1154 ../lib/gis/parser.c:1400
 #, c-format
-msgid "NS extent does not match NS resolution: %g cells difference"
+msgid "<%s> is an abbreviation for <%s>"
 msgstr ""
-#: ../lib/gis/adj_cellhd.c:360
+#: ../lib/gis/parser.c:1159
 #, c-format
-msgid "%g cells missing to reach 90 degree north"
+msgid "Option <%s> does not accept multiple answers"
+msgstr "<%s> opcija nepieņem vairākus parametrus"
+#: ../lib/gis/parser.c:1231
+#, c-format
+msgid ""
+"Illegal range syntax for parameter <%s>\n"
+"\tPresented as: %s"
 msgstr ""
-#: ../lib/gis/adj_cellhd.c:363 ../lib/gis/adj_cellhd.c:377
-#: ../lib/gis/adj_cellhd.c:391
+#: ../lib/gis/parser.c:1237
 #, c-format
-msgid "Subtle input data rounding error of north boundary (%g)"
+msgid ""
+"Value <%s> out of range for parameter <%s>\n"
+"\tLegal range: %s"
 msgstr ""
-#: ../lib/gis/adj_cellhd.c:373
+#: ../lib/gis/parser.c:1243
 #, c-format
-msgid "90 degree north is exceeded by %g cells"
+msgid "Missing value for parameter <%s>"
 msgstr ""
-#: ../lib/gis/adj_cellhd.c:402
-msgid "Illegal latitude for North"
+#: ../lib/gis/parser.c:1249
+#, c-format
+msgid ""
+"Value <%s> ambiguous for parameter <%s>\n"
+"\tValid options: %s"
+msgstr ""
-#: ../lib/gis/adj_cellhd.c:410
+#: ../lib/gis/parser.c:1422
 #, c-format
-msgid "%g cells missing to reach 90 degree south"
+msgid ""
+"Required parameter <%s> not set:\n"
+"\t(%s)"
 msgstr ""
-#: ../lib/gis/adj_cellhd.c:413 ../lib/gis/adj_cellhd.c:427
-#: ../lib/gis/adj_cellhd.c:441
+#: ../lib/gis/parser.c:1514
 #, c-format
-msgid "Subtle input data rounding error of south boundary (%g)"
+msgid ""
+"Option <%s> must be provided in multiples of %d\n"
+"\tYou provided %d item(s): %s"
 msgstr ""
-#: ../lib/gis/adj_cellhd.c:423
+#: ../lib/gis/parser.c:1590 ../lib/gis/parser.c:1597
 #, c-format
-msgid "90 degree south is exceeded by %g cells"
+msgid "option <%s>: <%s> exists. To overwrite, use the --overwrite flag"
 msgstr ""
-#: ../lib/gis/adj_cellhd.c:452
-msgid "Illegal latitude for South"
+#: ../lib/gis/parser.c:1707
+#, c-format
+msgid "%s= is not a separator option"
+msgstr ""
-#: ../lib/gis/adj_cellhd.c:481
+#: ../lib/gis/parser.c:1710
 #, c-format
-msgid "EW extent does not match EW resolution: %g cells difference"
+msgid "No separator given for %s="
 msgstr ""
-#: ../lib/gis/adj_cellhd.c:487
+#: ../lib/gis/parser.c:1772 ../lib/gis/parser.c:1789
 #, c-format
-msgid "360 degree EW extent is exceeded by %g cells"
+msgid "%s= is not a file option"
 msgstr ""
-#: ../lib/gis/adj_cellhd.c:493
+#: ../lib/gis/parser.c:1774
 #, c-format
-msgid "%g cells missing to cover 360 degree EW extent"
+msgid "Opening multiple files not supported for %s="
 msgstr ""
-#: ../lib/gis/adj_cellhd.c:528
-msgid "Invalid NS resolution"
-msgstr "Nederīga ZD izšķirtspēja"
+#: ../lib/gis/parser.c:1780
+#, c-format
+msgid "Unable to open %s file <%s>"
+msgstr ""
-#: ../lib/gis/adj_cellhd.c:533
-msgid "Invalid EW resolution"
-msgstr "Nederīga AR izšķirtspēja"
+#: ../lib/gis/parser.c:1786
+#, c-format
+msgid "Unable to create %s file <%s>"
+msgstr ""
-#: ../lib/gis/adj_cellhd.c:538
-msgid "Invalid North"
-msgstr "Nederīgi ziemeļi"
+#: ../lib/gis/get_ellipse.c:263 ../lib/proj/ellipse.c:243
+#, c-format
+msgid "Unable to open ellipsoid table file <%s>"
+msgstr "Nav iespējams atvērt elipsoīda tabulas failu <%s>"
-#: ../lib/gis/adj_cellhd.c:543
-msgid "Invalid South"
-msgstr "Nederīgi dienvidi"
+#: ../lib/gis/get_ellipse.c:344 ../lib/gis/get_ellipse.c:367
+#, c-format
+msgid "Invalid a: field '%s' in file %s in <%s>"
+msgstr ""
-#: ../lib/gis/adj_cellhd.c:548
-msgid "Invalid West"
-msgstr "Nederīgi rietumi"
+#: ../lib/gis/get_ellipse.c:356
+#, c-format
+msgid "Invalid ellipsoid '%s' in file %s in <%s>"
+msgstr ""
-#: ../lib/gis/adj_cellhd.c:553
-msgid "Invalid East"
-msgstr "Nederīgi austrumi"
-#: ../lib/gis/adj_cellhd.c:606
+#: ../lib/gis/get_ellipse.c:370
 #, c-format
-msgid "NS resolution rounded from %s to %s"
+msgid "Invalid es: field '%s' in file %s in <%s>"
 msgstr ""
-#: ../lib/gis/adj_cellhd.c:639 ../lib/gis/adj_cellhd.c:694
+#: ../lib/gis/get_ellipse.c:383
 #, c-format
-msgid "North rounded from %s to %s"
+msgid "No ellipsoid info given in file %s in <%s>"
 msgstr ""
-#: ../lib/gis/adj_cellhd.c:651
+#: ../lib/gis/legal_name.c:39
 #, c-format
-msgid "South adjusted from %s to %s"
+msgid "Illegal filename <%s>. Cannot start with '.' or be 'NULL'."
 msgstr ""
-#: ../lib/gis/adj_cellhd.c:666 ../lib/gis/adj_cellhd.c:709
+#: ../lib/gis/legal_name.c:46
 #, c-format
-msgid "South rounded from %s to %s"
+msgid "Illegal filename <%s>. Character <%c> not allowed.\n"
+msgstr "Neatļauts faila nosaukums <%s>. Rakstzīme <%c> nav atļauta.\n"
+#: ../lib/gis/legal_name.c:77 ../lib/gis/legal_name.c:81
+#, c-format
+msgid "Output raster map name <%s> is not valid map name"
 msgstr ""
-#: ../lib/gis/adj_cellhd.c:678
+#: ../lib/gis/legal_name.c:118 ../lib/gis/legal_name.c:122
 #, c-format
-msgid "North adjusted from %s to %s"
+msgid "Output raster map <%s> is used as input"
 msgstr ""
-#: ../lib/gis/adj_cellhd.c:732
+#: ../lib/gis/distance.c:154
 #, c-format
-msgid "EW resolution rounded from %s to %s"
+msgid "%s: shouldn't happen: code=%d P=(%f,%f) S=(%f,%f)(%f,%f)"
 msgstr ""
-#: ../lib/gis/adj_cellhd.c:765 ../lib/gis/adj_cellhd.c:820
+#: ../lib/gis/ls.c:103
 #, c-format
-msgid "West rounded from %s to %s"
+msgid "Unable to open directory %s"
+msgstr "Nevar atvērt mapi %s"
+#: ../lib/cluster/c_exec.c:44
+#, c-format
+msgid "Not enough data points (%d) in cluster"
 msgstr ""
-#: ../lib/gis/adj_cellhd.c:777
+#: ../lib/cluster/c_begin.c:57
 #, c-format
-msgid "East adjusted from %s to %s"
+msgid "produced by i.cluster"
 msgstr ""
-#: ../lib/gis/adj_cellhd.c:792 ../lib/gis/adj_cellhd.c:835
+#: ../lib/display/tran_colr.c:107 ../lib/display/tran_colr.c:109
 #, c-format
-msgid "East rounded from %s to %s"
+msgid "[%s]: No such color"
 msgstr ""
-#: ../lib/gis/adj_cellhd.c:804
+#: ../lib/display/r_raster.c:98
 #, c-format
-msgid "West adjusted from %s to %s"
+msgid "Both %s and %s are defined. %s will be ignored."
 msgstr ""
-#: ../lib/gis/compress.c:131 ../lib/gis/compress.c:193
-#: ../lib/gis/compress.c:209
-msgid "Request for unsupported compressor"
+#: ../lib/display/r_raster.c:131
+#, c-format
+msgid ""
+"Neither %s (managed by d.mon command) nor %s (used for direct rendering) "
+"defined"
 msgstr ""
-#: ../lib/gis/location.c:61
+#: ../lib/display/r_raster.c:150
 #, c-format
-msgid "LOCATION <%s> not available"
+msgid "Unknown display driver <%s>"
 msgstr ""
-#: ../lib/gis/view.c:176
+#: ../lib/display/r_raster.c:151
 #, c-format
-msgid "Unable to open %s for writing"
-msgstr "Neiespējami atvērt %s priekš rakstīšanas"
+msgid "Using display driver <%s>..."
+msgstr ""
-#: ../lib/gis/view.c:262 ../lib/gis/view.c:479
+#: ../lib/display/icon.c:80
 #, c-format
-msgid "Unable to open %s for reading"
-msgstr "Neiespējami atvērt %s priekš lasīšanas"
+msgid "Unsupported icon %d"
+msgstr ""
-#: ../lib/gis/view.c:465
+#: ../lib/htmldriver/graph_set.c:97
 #, c-format
-msgid "GRASS window when view was saved:\n"
-msgstr "GRASS logs kad skats tika saglabāts:\n"
+msgid "html: collecting to file '%s'"
+msgstr "html: apvieno failā '%s'"
-#: ../lib/gis/view.c:545
+#: ../lib/htmldriver/graph_set.c:98
 #, c-format
-msgid " Window saved in \"%s\" is completely outside of current GRASS window."
-msgstr " Logs saglabāts \"%s\" un ir pilnībā ārpus tekošā GRASS loga."
+msgid "html: image size %dx%d"
+msgstr "html: attēla izmērs %dx%d"
-#: ../lib/gis/view.c:549
+#: ../lib/htmldriver/graph_set.c:111 ../lib/htmldriver/graph_set.c:115
+#: ../lib/htmldriver/graph_set.c:119
 #, c-format
-msgid " Only %d%% of window saved in \"%s\" overlaps with current GRASS window."
-msgstr " Tikai %d%% no loga ir saglabāts \"%s\" pārklājuma ar tekošo GRASS logu."
+msgid "html: type '%s'"
+msgstr "html: tips '%s'"
-#: ../lib/gis/get_ellipse.c:344 ../lib/gis/get_ellipse.c:367
+#: ../lib/manage/read_list.c:73
 #, c-format
-msgid "Invalid a: field '%s' in file %s in <%s>"
+msgid "Unable to open data base element list '%s'"
 msgstr ""
-#: ../lib/gis/get_ellipse.c:356
+#: ../lib/manage/read_list.c:134
 #, c-format
-msgid "Invalid ellipsoid '%s' in file %s in <%s>"
+msgid "Format error: file ('%s') line (%d) - %s"
 msgstr ""
-#: ../lib/gis/get_ellipse.c:370
+#: ../lib/manage/do_rename.c:42
 #, c-format
-msgid "Invalid es: field '%s' in file %s in <%s>"
+msgid "Rename %s <%s> to <%s>"
 msgstr ""
-#: ../lib/gis/get_ellipse.c:383
+#: ../lib/manage/do_rename.c:62
 #, c-format
-msgid "No ellipsoid info given in file %s in <%s>"
+msgid "Unable to rename vector map <%s> to <%s>"
 msgstr ""
-#: ../lib/gis/alloc.c:44 ../lib/gis/alloc.c:86 ../lib/gis/alloc.c:132
+#: ../lib/manage/do_rename.c:83 ../lib/manage/do_rename.c:103
 #, c-format
-msgid "Current region rows: %d, cols: %d"
+msgid "Unable to rename %s"
+msgstr "Nevar pārsaukt %s"
+#: ../lib/manage/do_rename.c:87 ../lib/manage/do_rename.c:107
+#: ../lib/manage/do_copy.c:61 ../lib/manage/do_remove.c:89
+#: ../lib/manage/do_remove.c:109
+#, c-format
+msgid "%s is missing"
 msgstr ""
-#: ../lib/gis/alloc.c:47
+#: ../lib/manage/do_rename.c:90 ../lib/manage/do_rename.c:110
 #, c-format
-msgid "G_malloc: unable to allocate %lu bytes of memory at %s:%d"
+msgid "%s renamed"
 msgstr ""
-#: ../lib/gis/alloc.c:89
+#: ../lib/manage/do_rename.c:119
 #, c-format
-msgid "G_calloc: unable to allocate %lu * %lu bytes of memory at %s:%d"
+msgid "<%s> nothing renamed"
 msgstr ""
-#: ../lib/gis/alloc.c:135
+#: ../lib/manage/do_copy.c:43
 #, c-format
-msgid "G_realloc: unable to allocate %lu bytes of memory at %s:%d"
+msgid "Copy %s <%s> to current mapset as <%s>"
 msgstr ""
-#: ../lib/gis/mapset.c:38
-msgid "MAPSET is not set"
-msgstr "KARŠU KOPA nav noteikta"
-#: ../lib/gis/mapset.c:80
+#: ../lib/manage/do_copy.c:50 ../lib/manage/do_copy.c:67
 #, c-format
-msgid "MAPSET <%s> not available"
+msgid "Unable to copy <%s> to current mapset as <%s>"
 msgstr ""
-#: ../lib/gis/parser.c:355
+#: ../lib/manage/do_copy.c:72
 #, c-format
-msgid "BUG in option name, '%s' is not valid"
+msgid "%s copied"
 msgstr ""
-#: ../lib/gis/parser.c:407
+#: ../lib/manage/do_remove.c:42
 #, c-format
-msgid "BUG in descriptions, option '%s' in <%s> does not exist"
+msgid "Removing %s <%s>"
 msgstr ""
-#: ../lib/gis/parser.c:525
-msgid "Use either --quiet or --verbose flag, not both. Assuming --verbose."
+#: ../lib/manage/do_remove.c:65
+msgid "Unable to delete vector map"
 msgstr ""
-#: ../lib/gis/parser.c:539
-msgid "Use either --quiet or --verbose flag, not both. Assuming --quiet."
+#: ../lib/manage/do_remove.c:85
+#, c-format
+msgid "Unable to remove %s element"
 msgstr ""
-#: ../lib/gis/parser.c:554
-msgid "Use either --qq or --verbose flag, not both. Assuming --qq."
+#: ../lib/manage/do_remove.c:92 ../lib/manage/do_remove.c:112
+#, c-format
+msgid "%s removed"
 msgstr ""
-#: ../lib/gis/parser.c:585
+#: ../lib/manage/do_remove.c:105
 #, c-format
-msgid "Sorry <%s> is not a valid option"
-msgstr "Atvainojiet, <%s> nav derīgs parametrs"
+msgid "Unable to remove %s"
+msgstr "Nevar aizvākt %s"
-#: ../lib/gis/parser.c:598
-msgid "Your installation doesn't include GUI, exiting."
+#: ../lib/manage/do_remove.c:121
+#, c-format
+msgid "<%s> nothing removed"
 msgstr ""
-#: ../lib/gis/parser.c:947
-msgid "Unable to determine program name"
-msgstr "Nav iespējams noteikt programmas nosaukumu"
+#: ../lib/manage/do_list.c:30
+#, c-format
+msgid "%s: invalid index %d"
+msgstr ""
-#: ../lib/gis/parser.c:969 ../lib/gis/parser.c:988
+#: ../lib/manage/option.c:47
 #, c-format
-msgid "%s: Sorry, <%c> is not a valid flag"
+msgid "%s to be %s"
 msgstr ""
-#: ../lib/gis/parser.c:1118
+#: ../lib/manage/option.c:51
+msgid "Raster"
+msgstr "Rastrs"
+#: ../lib/manage/option.c:53
+msgid "Vector"
+msgstr "Vektors"
+#: ../lib/manage/option.c:55
+msgid "Region"
+msgstr "Reģions"
+#: ../lib/manage/option.c:57
+msgid "Group"
+msgstr "Grupa"
+#: ../lib/proj/ellipse.c:97
 #, c-format
-msgid "%s: Sorry, <%s=> is ambiguous"
+msgid "Invalid ellipsoid <%s> in file"
+msgstr "Nederīgs elipsoīds failā <%s>"
+#: ../lib/proj/ellipse.c:124
+msgid "No secondary ellipsoid descriptor (rf, es or b) in file"
 msgstr ""
-#: ../lib/gis/parser.c:1121
+#: ../lib/proj/ellipse.c:128
+msgid "Invalid ellipsoid descriptors (a, rf, es or b) in file"
+msgstr ""
+#: ../lib/proj/ellipse.c:141
+msgid "No ellipsoid info given in file"
+msgstr "Failā nav sniegta elipsoīda informācija"
+#: ../lib/proj/get_proj.c:148
 #, c-format
-msgid "Option <%s=> matches"
+msgid "Invalid zone %s specified"
 msgstr ""
-#: ../lib/gis/parser.c:1139
+#: ../lib/proj/get_proj.c:228
+msgid "Unable to initialise PROJ.4 with the following parameter list:"
+msgstr ""
+#: ../lib/proj/get_proj.c:236
 #, c-format
-msgid "Please update the usage of <%s>: option <%s> has been renamed to <%s>"
+msgid "The error message: %s"
+msgstr "Kļūdas paziņojums: %s"
+#: ../lib/proj/get_proj.c:294
+msgid "Option input overflowed option table"
 msgstr ""
-#: ../lib/gis/parser.c:1152
+#: ../lib/proj/get_proj.c:325
 #, c-format
-msgid "%s: Sorry, <%s> is not a valid parameter"
+msgid "Unable to initialize pj cause: %s"
 msgstr ""
-#: ../lib/gis/parser.c:1158 ../lib/gis/parser.c:1404
+#: ../lib/proj/get_proj.c:401
+msgid "Input Projection Parameters"
+msgstr ""
+#: ../lib/proj/get_proj.c:404
+msgid "Input Unit Factor"
+msgstr ""
+#: ../lib/proj/get_proj.c:414
+msgid "Output Projection Parameters"
+msgstr ""
+#: ../lib/proj/get_proj.c:417
+msgid "Output Unit Factor"
+msgstr ""
+#: ../lib/proj/do_proj.c:106 ../lib/proj/do_proj.c:180
 #, c-format
-msgid "<%s> is an abbreviation for <%s>"
+msgid "pj_transform() failed: %s"
 msgstr ""
-#: ../lib/gis/parser.c:1163
+#: ../lib/proj/datum.c:195
+msgid "Failed to detect nadgrids path, GRASS_PROJSHARE not defined"
+msgstr ""
+#: ../lib/proj/datum.c:278 ../lib/proj/datum.c:358
 #, c-format
-msgid "Option <%s> does not accept multiple answers"
-msgstr "<%s> opcija nepieņem vairākus parametrus"
+msgid "Unable to open datum table file <%s>"
+msgstr "Nav iespējams atvērt datumu tabulas failu <%s>"
-#: ../lib/gis/parser.c:1235
+#: ../lib/proj/datum.c:291 ../lib/proj/datum.c:372
 #, c-format
-msgid ""
-"Illegal range syntax for parameter <%s>\n"
-"\tPresented as: %s"
+msgid "Error in datum table file <%s>, line %d"
+msgstr "Kļūda datumu tabulas failā <%s> līnijā %d"
+#: ../lib/proj/convert.c:159
+msgid "Unable parse GRASS PROJ_INFO file"
+msgstr "Nebija iespējams parsēt GRASS PROJ_INFO failu"
+#: ../lib/proj/convert.c:164
+msgid "Unable get PROJ.4-style parameter string"
 msgstr ""
-#: ../lib/gis/parser.c:1241
+#: ../lib/proj/convert.c:178
 #, c-format
 msgid ""
-"Value <%s> out of range for parameter <%s>\n"
-"\tLegal range: %s"
+"OGR can't parse PROJ.4-style parameter string: %s (OGR Error code was %d)"
 msgstr ""
-#: ../lib/gis/parser.c:1247
+#: ../lib/proj/convert.c:191
 #, c-format
-msgid "Missing value for parameter <%s>"
+msgid "OGR can't get WKT-style parameter string (OGR Error code was %d)"
 msgstr ""
-#: ../lib/gis/parser.c:1253
+#: ../lib/proj/convert.c:427
 #, c-format
 msgid ""
-"Value <%s> ambiguous for parameter <%s>\n"
-"\tValid options: %s"
+"Updating spatial reference with embedded proj4 definition failed. Proj4 "
+"definition: <%s>"
 msgstr ""
-#: ../lib/gis/parser.c:1426
+#: ../lib/proj/convert.c:434
+msgid "Updating spatial reference with embedded proj4 definition"
+msgstr ""
+#: ../lib/proj/convert.c:564
+msgid "No projection name! Projection parameters likely to be meaningless."
+msgstr ""
+#: ../lib/proj/convert.c:626
 #, c-format
+msgid "Datum <%s> not recognised by GRASS and no parameters found"
+msgstr "Datums <%s> nav atpazīts un parametri nav atrasti"
+#: ../lib/proj/convert.c:642
+#, c-format
 msgid ""
-"Required parameter <%s> not set:\n"
-"\t(%s)"
+"Datum <%s> apparently recognised by GRASS but no parameters found. You may "
+"want to look into this."
 msgstr ""
-#: ../lib/gis/parser.c:1518
+#: ../lib/proj/convert.c:646
 #, c-format
 msgid ""
-"Option <%s> must be provided in multiples of %d\n"
-"\tYou provided %d item(s): %s"
+"Invalid transformation number %d; valid range is 1 to %d. Leaving datum "
+"transform parameters unspecified."
 msgstr ""
-#: ../lib/gis/parser.c:1594 ../lib/gis/parser.c:1601
-#, c-format
-msgid "option <%s>: <%s> exists. To overwrite, use the --overwrite flag"
+#: ../lib/gmath/la.c:61 ../lib/gmath/la.c:117
+msgid "Matrix dimensions out of range"
 msgstr ""
-#: ../lib/gis/parser.c:1711
-#, c-format
-msgid "%s= is not a separator option"
+#: ../lib/gmath/la.c:150
+msgid "Matrix is not initialised fully."
 msgstr ""
-#: ../lib/gis/parser.c:1714
-#, c-format
-msgid "No separator given for %s="
+#: ../lib/gmath/la.c:155
+msgid "Unable to allocate space for matrix copy"
 msgstr ""
-#: ../lib/gis/parser.c:1776 ../lib/gis/parser.c:1793
-#, c-format
-msgid "%s= is not a file option"
+#: ../lib/gmath/la.c:220
+msgid "Input matrix is uninitialized"
 msgstr ""
-#: ../lib/gis/parser.c:1778
-#, c-format
-msgid "Opening multiple files not supported for %s="
+#: ../lib/gmath/la.c:285
+msgid "First scalar multiplier must be non-zero"
 msgstr ""
-#: ../lib/gis/parser.c:1784
-#, c-format
-msgid "Unable to open %s file <%s>"
+#: ../lib/gmath/la.c:291 ../lib/gmath/la.c:299 ../lib/gmath/la.c:364
+msgid "One or both input matrices uninitialised"
 msgstr ""
-#: ../lib/gis/parser.c:1790
-#, c-format
-msgid "Unable to create %s file <%s>"
+#: ../lib/gmath/la.c:304 ../lib/gmath/la.c:369
+msgid "Matrix order does not match"
 msgstr ""
-#: ../lib/gis/seek.c:52 ../lib/gis/seek.c:58
-msgid "Unable to seek"
+#: ../lib/gmath/la.c:310
+msgid "Unable to allocate space for matrix sum"
 msgstr ""
-#: ../lib/gis/seek.c:56
-msgid "Seek offset out of range"
+#: ../lib/gmath/la.c:374
+msgid "Unable to allocate space for matrix product"
 msgstr ""
-#: ../lib/gis/list.c:83
-#, c-format
-msgid "no %s files available in current mapset\n"
+#: ../lib/gmath/la.c:486
+msgid "Input: one or both data matrices uninitialised"
 msgstr ""
-#: ../lib/gis/list.c:86
-#, c-format
-msgid "no %s files available in mapset <%s>\n"
+#: ../lib/gmath/la.c:491
+msgid "Principal matrix is not properly dimensioned"
 msgstr ""
-#: ../lib/gis/list.c:132
-#, c-format
-msgid "%s files available in mapset <%s>:\n"
+#: ../lib/gmath/la.c:496
+msgid "Input: you must have at least one array to solve"
 msgstr ""
-#: ../lib/gis/list.c:204
-msgid "G_list: Unknown element type"
-msgstr "G_list: nezināms elementa tips"
+#: ../lib/gmath/la.c:502
+msgid "Could not allocate space for solution matrix"
+msgstr ""
-#: ../lib/gis/find_file.c:114
+#: ../lib/gmath/la.c:508 ../lib/gmath/la.c:516
+msgid "Could not allocate space for working matrix"
+msgstr ""
+#: ../lib/gmath/la.c:569
+msgid "Matrix (or submatrix is singular). Solution undetermined"
+msgstr ""
+#: ../lib/gmath/la.c:573
+msgid "Problem in LA routine."
+msgstr ""
+#: ../lib/gmath/la.c:580
+msgid "Procedure not yet available for selected matrix type"
+msgstr ""
+#: ../lib/gmath/la.c:614
+msgid "Matrix is not square. Cannot determine inverse"
+msgstr ""
+#: ../lib/gmath/la.c:619
+msgid "Unable to allocate space for matrix"
+msgstr ""
+#: ../lib/gmath/la.c:636
+msgid "Matrix is singular"
+msgstr ""
+#: ../lib/gmath/la.c:641
+msgid "Problem in LA procedure."
+msgstr ""
+#: ../lib/gmath/la.c:729
+msgid "Element array has not been allocated"
+msgstr ""
+#: ../lib/gmath/la.c:734
+msgid "Specified element is outside array bounds"
+msgstr ""
+#: ../lib/gmath/la.c:788
+msgid "Specified matrix column index is outside range"
+msgstr ""
+#: ../lib/gmath/la.c:793 ../lib/gmath/la.c:834 ../lib/gmath/la.c:1198
+#: ../lib/gmath/la.c:1250 ../lib/gmath/la.c:1325
+msgid "Matrix is not initialised"
+msgstr ""
+#: ../lib/gmath/la.c:798 ../lib/gmath/la.c:839
+msgid "Could not allocate space for vector structure"
+msgstr ""
+#: ../lib/gmath/la.c:829
+msgid "Specified matrix row index is outside range"
+msgstr ""
+#: ../lib/gmath/la.c:869
+msgid "Specified row index is outside range"
+msgstr ""
+#: ../lib/gmath/la.c:874
+msgid "Specified column index is outside range"
+msgstr ""
+#: ../lib/gmath/la.c:894
+msgid "Unknown vector type."
+msgstr ""
+#: ../lib/gmath/la.c:949
+msgid "Input matrix and vector have differing dimensions1"
+msgstr ""
+#: ../lib/gmath/la.c:955 ../lib/gmath/la.c:1071 ../lib/gmath/la.c:1361
+msgid "Output vector is uninitialized"
+msgstr ""
+#: ../lib/gmath/la.c:1076 ../lib/gmath/la.c:1366
+msgid "Vectors are not of the same type"
+msgstr ""
+#: ../lib/gmath/la.c:1081
+msgid "Output vector is of incorrect type"
+msgstr ""
+#: ../lib/gmath/la.c:1086 ../lib/gmath/la.c:1376
+msgid "Matrices not allowed"
+msgstr ""
+#: ../lib/gmath/la.c:1092 ../lib/gmath/la.c:1383
+msgid "Vectors have differing dimensions"
+msgstr ""
+#: ../lib/gmath/la.c:1098 ../lib/gmath/la.c:1390
+msgid "Output vector has incorrect dimension"
+msgstr ""
+#: ../lib/gmath/la.c:1143
+msgid "Vector dimensions out of range"
+msgstr ""
+#: ../lib/gmath/la.c:1148
+msgid "Row/column out of range"
+msgstr ""
+#: ../lib/gmath/la.c:1371
+msgid "Output vector is not the same type as others"
+msgstr ""
+#: ../lib/gmath/la.c:1437
+msgid "Vector structure is not initialised"
+msgstr ""
+#: ../lib/gmath/la.c:1558 ../lib/gmath/la.c:1566 ../lib/gmath/la.c:1571
+msgid "Input format error"
+msgstr ""
+#: ../lib/gmath/test/bench_blas2.c:35
+msgid ""
+"\n"
+"++ Running blas level 2 benchmark ++"
+msgstr ""
+#: ../lib/gmath/test/bench_blas3.c:34
+msgid ""
+"\n"
+"++ Running blas level 3 benchmark ++"
+msgstr ""
+#: ../lib/gmath/test/test_blas3.c:38
+msgid ""
+"\n"
+"++ Running blas level 3 unit tests ++"
+msgstr ""
+#: ../lib/gmath/test/test_blas3.c:44
+msgid ""
+"\n"
+"-- blas level 3 unit tests failure --"
+msgstr ""
+#: ../lib/gmath/test/test_blas3.c:46
+msgid ""
+"\n"
+"-- blas level 3 unit tests finished successfully --"
+msgstr ""
+#: ../lib/gmath/test/test_solvers.c:37
+msgid ""
+"\n"
+"++ Running solver unit tests ++"
+msgstr ""
+#: ../lib/gmath/test/test_solvers.c:42
+msgid ""
+"\n"
+"-- Solver unit tests failure --"
+msgstr ""
+#: ../lib/gmath/test/test_solvers.c:44
+msgid ""
+"\n"
+"-- Solver unit tests finished successfully --"
+msgstr ""
+#: ../lib/gmath/test/bench_solver_krylov.c:34
+msgid ""
+"\n"
+"++ Running krylov solver benchmark ++"
+msgstr ""
+#: ../lib/gmath/test/bench_solver_direct.c:34
+msgid ""
+"\n"
+"++ Running direct solver benchmark ++"
+msgstr ""
+#: ../lib/gmath/test/test_blas2.c:38
+msgid ""
+"\n"
+"++ Running blas level 2 unit tests ++"
+msgstr ""
+#: ../lib/gmath/test/test_blas2.c:44
+msgid ""
+"\n"
+"-- blas level 2 unit tests failure --"
+msgstr ""
+#: ../lib/gmath/test/test_blas2.c:46
+msgid ""
+"\n"
+"-- blas level 2 unit tests finished successfully --"
+msgstr ""
+#: ../lib/gmath/test/test_main.c:61
+msgid "The size of the matrices and vectors for benchmarking"
+msgstr ""
+#: ../lib/gmath/test/test_main.c:68
+msgid "Choose solver benchmark"
+msgstr ""
+#: ../lib/gmath/test/test_main.c:75
+msgid "Choose blas benchmark"
+msgstr ""
+#: ../lib/gmath/test/test_main.c:106
+msgid "Performs benchmarks, unit and integration tests for the gmath library"
+msgstr ""
+#: ../lib/gmath/test/test_blas1.c:40
+msgid ""
+"\n"
+"++ Running blas level 1 unit tests ++"
+msgstr ""
+#: ../lib/gmath/test/test_blas1.c:47
+msgid ""
+"\n"
+"-- blas level 1 unit tests failure --"
+msgstr ""
+#: ../lib/gmath/test/test_blas1.c:49
+msgid ""
+"\n"
+"-- blas level 1 unit tests finished successfully --"
+msgstr ""
+#: ../lib/gmath/test/test_ccmath_wrapper.c:37
+msgid ""
+"\n"
+"++ Running ccmath wrapper unit tests ++"
+msgstr ""
+#: ../lib/gmath/test/test_ccmath_wrapper.c:42
+msgid ""
+"\n"
+"-- ccmath wrapper unit tests failure --"
+msgstr ""
+#: ../lib/gmath/test/test_ccmath_wrapper.c:44
+msgid ""
+"\n"
+"-- ccmath wrapper unit tests finished successfully --"
+msgstr ""
+#: ../lib/gmath/test/test_matrix_conversion.c:37
+msgid ""
+"\n"
+"++ Running matrix conversion unit tests ++"
+msgstr ""
+#: ../lib/gmath/test/test_matrix_conversion.c:42
+msgid ""
+"\n"
+"-- Matrix conversion unit tests failure --"
+msgstr ""
+#: ../lib/gmath/test/test_matrix_conversion.c:44
+msgid ""
+"\n"
+"-- Matrix conversion unit tests finished successfully --"
+msgstr ""
+#: ../lib/gmath/solvers_direct.c:45
+msgid "Starting direct gauss elimination solver"
+msgstr ""
+#: ../lib/gmath/solvers_direct.c:73
+msgid "Starting direct lu decomposition solver"
+msgstr ""
+#: ../lib/gmath/solvers_direct.c:131
+msgid "Starting cholesky decomposition solver"
+msgstr ""
+#: ../lib/gmath/solvers_direct.c:134 ../lib/gmath/solvers_krylov.c:254
+#: ../lib/gmath/solvers_krylov.c:482 ../lib/gmath/solvers_krylov.c:646
+msgid "Unable to solve the linear equation system"
+msgstr ""
+#: ../lib/gmath/solvers_classic_iter.c:84
 #, c-format
-msgid "Data element '%s/%s' was found in more mapsets (also found in <%s>)"
+msgid "sparse Jacobi -- iteration %5i error %g\n"
 msgstr ""
-#: ../lib/gis/find_file.c:127
+#: ../lib/gmath/solvers_classic_iter.c:156
 #, c-format
-msgid "Using <%s@%s>..."
+msgid "sparse SOR -- iteration %5i error %g\n"
 msgstr ""
-#: ../lib/gis/mapset_msc.c:90
+#: ../lib/gmath/solvers_classic_iter.c:218
 #, c-format
-msgid "Unable to make mapset element %s (%s): %s"
+msgid "Jacobi -- iteration %5i error %g\n"
 msgstr ""
-#: ../lib/gis/mapset_msc.c:94
+#: ../lib/gmath/solvers_classic_iter.c:275
 #, c-format
-msgid "Unable to access mapset element %s (%s): %s"
+msgid "SOR -- iteration %5i error %g\n"
 msgstr ""
-#: ../lib/gis/paths.c:201
+#: ../lib/gmath/solvers_direct_cholesky_band.c:33
 #, c-format
-msgid "Unable to open file <%s> for reading"
+msgid "Decomposition failed at row %i and col %i"
 msgstr ""
-#: ../lib/gis/paths.c:217
+#: ../lib/gmath/solvers_krylov.c:262
 #, c-format
-msgid "Unable to fetch security info for <%s>"
+msgid "Sparse PCG -- iteration %i error  %g\n"
 msgstr ""
-#: ../lib/gis/timestamp.c:292
+#: ../lib/gmath/solvers_krylov.c:264
 #, c-format
-msgid "Unable to create timestamp file for %s map <%s@%s>"
+msgid "PCG -- iteration %i error  %g\n"
 msgstr ""
-#: ../lib/gis/timestamp.c:301
+#: ../lib/gmath/solvers_krylov.c:490
 #, c-format
-msgid "Invalid timestamp specified for %s map <%s@%s>"
+msgid "Sparse CG -- iteration %i error  %g\n"
 msgstr ""
-#: ../lib/gis/timestamp.c:331
+#: ../lib/gmath/solvers_krylov.c:492
 #, c-format
-msgid "Unable to open timestamp file for %s map <%s@%s>"
+msgid "CG -- iteration %i error  %g\n"
 msgstr ""
-#: ../lib/gis/timestamp.c:340
+#: ../lib/gmath/solvers_krylov.c:695
 #, c-format
-msgid "Invalid timestamp file for %s map <%s@%s>"
+msgid "Sparse BiCGStab -- iteration %i error  %g\n"
 msgstr ""
-#: ../lib/gis/timestamp.c:479
+#: ../lib/gmath/solvers_krylov.c:698
 #, c-format
-msgid "Unable to open timestamp file for vector map <%s@%s>"
+msgid "BiCGStab -- iteration %i error  %g\n"
 msgstr ""
-#: ../lib/gis/timestamp.c:488
+#: ../lib/gmath/del2g.c:50
+msgid "    taking FFT of image..."
+msgstr ""
+#: ../lib/gmath/del2g.c:56
+msgid "    computing del**2 g..."
+msgstr ""
+#: ../lib/gmath/del2g.c:59
+msgid "    taking FFT of del**2 g..."
+msgstr ""
+#: ../lib/gmath/del2g.c:63
+msgid "    multiplying transforms..."
+msgstr ""
+#: ../lib/gmath/del2g.c:66
+msgid "    taking inverse FFT..."
+msgstr ""
+#: ../lib/arraystats/class.c:19
 #, c-format
-msgid "Invalid timestamp file for vector map <%s@%s>"
+msgid "Unknown algorithm '%s'"
 msgstr ""
-#: ../lib/gis/timestamp.c:524
+#: ../lib/arraystats/class.c:42
+msgid "Discont algorithm currently not available because of bugs"
+msgstr ""
+#: ../lib/arraystats/class.c:49
+msgid "Classification algorithm failed"
+msgstr ""
+#: ../lib/arraystats/class.c:227
+msgid "Equiprobable classbreaks currently limited to 10 classes"
+msgstr ""
+#: ../lib/arraystats/class.c:242
 #, c-format
-msgid "Unable to create timestamp file for vector map <%s@%s>"
+msgid ""
+"There are classbreaks outside the range min-max. Number of classes reduced "
+"to %i, but using probabilities for %i classes."
 msgstr ""
-#: ../lib/gis/timestamp.c:533
+#: ../lib/symbol/read.c:211
 #, c-format
-msgid "Invalid timestamp specified for vector map <%s@%s>"
+msgid "Cannot read symbol line coordinates: %s"
 msgstr ""
-#: ../lib/gis/legal_name.c:39
+#: ../lib/symbol/read.c:260
 #, c-format
-msgid "Illegal filename <%s>. Cannot start with '.' or be 'NULL'."
+msgid ""
+"Incorrect symbol name: '%s' (should be: group/name or group/name at mapset)"
 msgstr ""
-#: ../lib/gis/legal_name.c:46
+#: ../lib/symbol/read.c:284
 #, c-format
-msgid "Illegal filename <%s>. Character <%c> not allowed.\n"
-msgstr "Neatļauts faila nosaukums <%s>. Rakstzīme <%c> nav atļauta.\n"
+msgid "Cannot find/open symbol: '%s'"
+msgstr "Nevar atrast/atvērt simbolu: '%s'"
-#: ../lib/gis/legal_name.c:77 ../lib/gis/legal_name.c:81
+#: ../lib/symbol/read.c:393 ../lib/symbol/read.c:411 ../lib/symbol/read.c:421
+#: ../lib/symbol/read.c:439
 #, c-format
-msgid "Output raster map name <%s> is not valid map name"
-msgstr ""
+msgid "Incorrect symbol color: '%s', using default."
+msgstr "Nederīga simbola krāsa: '%s', tiek izmantota noklusējuma."
-#: ../lib/gis/legal_name.c:118 ../lib/gis/legal_name.c:122
+#: ../lib/lidar/raster.c:74 ../lib/lidar/raster.c:89 ../lib/lidar/raster.c:102
+#: ../lib/lidar/raster.c:119 ../lib/lidar/raster.c:134
+#: ../lib/lidar/raster.c:147 ../lib/lidar/raster.c:162
+#: ../lib/lidar/raster.c:175
 #, c-format
-msgid "Output raster map <%s> is used as input"
-msgstr ""
+msgid "Unable to access table <%s>"
+msgstr "Nav iespējams piekļūt tabulai <%s>"
+#: ../lib/lidar/zones.c:476 ../lib/lidar/zones.c:513
+#, c-format
+msgid "<%s> created in database."
+msgstr "Datubāzē ir izveidots <%s>."
+#: ../lib/lidar/zones.c:480 ../lib/lidar/zones.c:517
+#, c-format
+msgid "<%s> has not been created in database."
+msgstr "<%s> nav izveidots datubāzē."
 #: ../lib/imagery/target.c:38
 #, c-format
 msgid "Unable to read target file for group [%s]"
 msgstr ""
-#: ../lib/imagery/sigsetfile.c:41
+#: ../lib/imagery/iclass_perimeter.c:109
 #, c-format
-msgid "Unable to create signature file <%s> for subgroup <%s> of group <%s> - <%s> is not current mapset"
+msgid "Get area %d failed"
 msgstr ""
-#: ../lib/imagery/sigsetfile.c:57
-#, c-format
-msgid "Unable to create signature file <%s> for subgroup <%s> of group <%s>"
+#: ../lib/imagery/iclass_perimeter.c:116
+msgid "Perimeter computation failed"
 msgstr ""
-#: ../lib/imagery/points.c:124
-#, c-format
-msgid "Unable to open control point file for group [%s in %s]"
+#: ../lib/imagery/iclass_perimeter.c:208
+msgid "Absurd polygon."
 msgstr ""
-#: ../lib/imagery/points.c:132
-#, c-format
-msgid "Bad format in control point file for group [%s in %s]"
+#: ../lib/imagery/iclass_perimeter.c:253
+msgid "Outlined area is too large."
 msgstr ""
-#: ../lib/imagery/points.c:159
-#, c-format
-msgid "Unable to create control point file for group [%s in %s]"
-msgstr ""
 #: ../lib/imagery/iclass.c:83
 #, c-format
 msgid "No areas in category %d"
@@ -8735,36 +7426,107 @@
 msgid "Group <%s> does not have enough files (it has %d files)"
 msgstr ""
-#: ../lib/imagery/fopen.c:23
+#: ../lib/imagery/iclass_statistics.c:218
+msgid "prepare_signature: outline has odd number of points."
+msgstr ""
+#: ../lib/imagery/iclass_statistics.c:227 ../lib/imagery/iscatt_core.c:972
 #, c-format
-msgid "Unable to create file [%s] of group [%s in %s]"
+msgid "prepare_signature: scan line %d has odd number of points."
 msgstr ""
-#: ../lib/imagery/fopen.c:36 ../lib/imagery/fopen.c:57
+#: ../lib/imagery/iclass_statistics.c:237 ../lib/imagery/iscatt_core.c:981
+msgid "signature: perimeter points out of order."
+msgstr ""
+#: ../lib/imagery/iclass_statistics.c:248
 #, c-format
-msgid "Unable to open file [%s] of group [%s in %s]"
+msgid "Data error preparing signatures: value (%d) > num of cats (%d)"
 msgstr ""
-#: ../lib/imagery/fopen.c:49
+#: ../lib/imagery/iclass_statistics.c:561
+#: ../lib/imagery/iclass_statistics.c:584
+#: ../lib/imagery/iclass_statistics.c:607
+#: ../lib/imagery/iclass_statistics.c:630
+#: ../lib/imagery/iclass_statistics.c:653
+#: ../lib/imagery/iclass_statistics.c:680
+#: ../lib/imagery/iclass_statistics.c:712
+#: ../lib/imagery/iclass_statistics.c:735
+#: ../lib/imagery/iclass_statistics.c:758
+msgid "Band index out of range"
+msgstr ""
+#: ../lib/imagery/iclass_statistics.c:684
+msgid "Cell category value out of range"
+msgstr ""
+#: ../lib/imagery/list_subgp.c:72
 #, c-format
-msgid "Unable to find file [%s] of group [%s in %s]"
+msgid "subgroup <%s> of group <%s> is empty\n"
 msgstr ""
-#: ../lib/imagery/fopen.c:79
+#: ../lib/imagery/list_subgp.c:85
 #, c-format
-msgid "Unable to create file [%s] for subgroup [%s] of group [%s in %s]"
+msgid "subgroup <%s> of group <%s> references the following raster maps\n"
 msgstr ""
-#: ../lib/imagery/fopen.c:101 ../lib/imagery/fopen.c:127
+#: ../lib/imagery/georef_tps.c:219
+msgid "Calculating forward transformation coefficients"
+msgstr ""
+#: ../lib/imagery/georef_tps.c:236
+msgid "Calculating backward transformation coefficients"
+msgstr ""
+#: ../lib/imagery/georef_tps.c:279 ../lib/imagery/georef_tps.c:282
+#: ../lib/imagery/georef_tps.c:285 ../lib/imagery/georef_tps.c:290
+#: ../lib/imagery/georef_tps.c:293
 #, c-format
-msgid "Unable to open file [%s] for subgroup [%s] of group [%s in %s]"
+msgid "%s: out of memory"
 msgstr ""
-#: ../lib/imagery/fopen.c:116
+#: ../lib/imagery/sigsetfile.c:41
 #, c-format
-msgid "Unable to find file [%s] for subgroup [%s] of group [%s in %s]"
+msgid ""
+"Unable to create signature file <%s> for subgroup <%s> of group <%s> - <%s> "
+"is not current mapset"
 msgstr ""
+#: ../lib/imagery/sigsetfile.c:57
+#, c-format
+msgid "Unable to create signature file <%s> for subgroup <%s> of group <%s>"
+msgstr ""
+#: ../lib/imagery/iclass_signatures.c:120
+#, c-format
+msgid "Unable to open output signature file '%s'"
+msgstr ""
+#: ../lib/imagery/points.c:124
+#, c-format
+msgid "Unable to open control point file for group [%s in %s]"
+msgstr ""
+#: ../lib/imagery/points.c:132
+#, c-format
+msgid "Bad format in control point file for group [%s in %s]"
+msgstr ""
+#: ../lib/imagery/points.c:159
+#, c-format
+msgid "Unable to create control point file for group [%s in %s]"
+msgstr ""
+#: ../lib/imagery/list_gp.c:34
+#, c-format
+msgid "group <%s> is empty\n"
+msgstr ""
+#: ../lib/imagery/list_gp.c:44
+#, c-format
+msgid "group <%s> references the following raster maps\n"
+msgstr ""
 #: ../lib/imagery/iscatt_core.c:81
 #, c-format
 msgid "Unable to write header into category raster condition file <%s>."
@@ -8809,7 +7571,9 @@
 msgstr ""
 #: ../lib/imagery/iscatt_core.c:579
-msgid "Data inconsistent. Value computed for scatter plot is out of initialized range."
+msgid ""
+"Data inconsistent. Value computed for scatter plot is out of initialized "
+"range."
 msgstr ""
 #: ../lib/imagery/iscatt_core.c:745
@@ -8841,659 +7605,2223 @@
 msgid "Corrupted category raster conditions file (fseek failed)"
 msgstr ""
-#: ../lib/imagery/iscatt_core.c:972 ../lib/imagery/iclass_statistics.c:227
+#: ../lib/imagery/fopen.c:23
 #, c-format
-msgid "prepare_signature: scan line %d has odd number of points."
+msgid "Unable to create file [%s] of group [%s in %s]"
 msgstr ""
-#: ../lib/imagery/iscatt_core.c:981 ../lib/imagery/iclass_statistics.c:237
-msgid "signature: perimeter points out of order."
+#: ../lib/imagery/fopen.c:36 ../lib/imagery/fopen.c:57
+#, c-format
+msgid "Unable to open file [%s] of group [%s in %s]"
 msgstr ""
-#: ../lib/imagery/list_subgp.c:72
+#: ../lib/imagery/fopen.c:49
 #, c-format
-msgid "subgroup <%s> of group <%s> is empty\n"
+msgid "Unable to find file [%s] of group [%s in %s]"
 msgstr ""
-#: ../lib/imagery/list_subgp.c:85
+#: ../lib/imagery/fopen.c:79
 #, c-format
-msgid "subgroup <%s> of group <%s> references the following raster maps\n"
+msgid "Unable to create file [%s] for subgroup [%s] of group [%s in %s]"
 msgstr ""
-#: ../lib/imagery/list_gp.c:34
+#: ../lib/imagery/fopen.c:101 ../lib/imagery/fopen.c:127
 #, c-format
-msgid "group <%s> is empty\n"
+msgid "Unable to open file [%s] for subgroup [%s] of group [%s in %s]"
 msgstr ""
-#: ../lib/imagery/list_gp.c:44
+#: ../lib/imagery/fopen.c:116
 #, c-format
-msgid "group <%s> references the following raster maps\n"
+msgid "Unable to find file [%s] for subgroup [%s] of group [%s in %s]"
 msgstr ""
-#: ../lib/imagery/iclass_statistics.c:218
-msgid "prepare_signature: outline has odd number of points."
+#: ../lib/init/grass.py:123
+msgid "WARNING"
+msgstr "BRĪDINĀJUMS"
+#: ../lib/init/grass.py:188
+msgid "Exiting..."
+msgstr "Iziet..."
+#: ../lib/init/grass.py:332
+msgid "Usage"
+msgstr "Lietojums"
+#: ../lib/init/grass.py:334
+msgid "print this help message"
+msgstr "izdrukā šo palīdzības paziņojumu"
+#: ../lib/init/grass.py:335
+msgid "show version information and exit"
+msgstr "parāda versijas informāciju un iziet"
+#: ../lib/init/grass.py:336
+msgid "create given database, location or mapset if it doesn't exist"
 msgstr ""
-#: ../lib/imagery/iclass_statistics.c:248
-#, c-format
-msgid "Data error preparing signatures: value (%d) > num of cats (%d)"
+#: ../lib/init/grass.py:337
+msgid "exit after creation of location or mapset. Only with -c flag"
 msgstr ""
-#: ../lib/imagery/iclass_statistics.c:561
-#: ../lib/imagery/iclass_statistics.c:584
-#: ../lib/imagery/iclass_statistics.c:607
-#: ../lib/imagery/iclass_statistics.c:630
-#: ../lib/imagery/iclass_statistics.c:653
-#: ../lib/imagery/iclass_statistics.c:680
-#: ../lib/imagery/iclass_statistics.c:712
-#: ../lib/imagery/iclass_statistics.c:735
-#: ../lib/imagery/iclass_statistics.c:758
-msgid "Band index out of range"
+#: ../lib/init/grass.py:338
+msgid ""
+"force removal of .gislock if exists (use with care!). Only with -text flag"
 msgstr ""
-#: ../lib/imagery/iclass_statistics.c:684
-msgid "Cell category value out of range"
+#: ../lib/init/grass.py:339
+msgid "use text based interface (skip welcome screen)"
 msgstr ""
-#: ../lib/imagery/georef_tps.c:219
-msgid "Calculating forward transformation coefficients"
+#: ../lib/init/grass.py:340 ../lib/init/grass.py:342 ../lib/init/grass.py:344
+msgid "and set as default"
 msgstr ""
-#: ../lib/imagery/georef_tps.c:236
-msgid "Calculating backward transformation coefficients"
+#: ../lib/init/grass.py:341
+msgid "use text based interface (show welcome screen)"
 msgstr ""
-#: ../lib/imagery/georef_tps.c:279 ../lib/imagery/georef_tps.c:282
-#: ../lib/imagery/georef_tps.c:285 ../lib/imagery/georef_tps.c:290
-#: ../lib/imagery/georef_tps.c:293
-#, c-format
-msgid "%s: out of memory"
+#: ../lib/init/grass.py:343
+msgid "use $DEFAULT_GUI graphical user interface"
 msgstr ""
-#: ../lib/imagery/iclass_perimeter.c:109
-#, c-format
-msgid "Get area %d failed"
+#: ../lib/init/grass.py:345
+msgid "print GRASS configuration parameters"
+msgstr "izdrukā GRASS konfigurācijas parametrus"
+#: ../lib/init/grass.py:346
+msgid "options: arch,build,compiler,path,revision,version"
 msgstr ""
-#: ../lib/imagery/iclass_perimeter.c:116
-msgid "Perimeter computation failed"
+#: ../lib/init/grass.py:348
+msgid "initial GRASS GIS database directory"
 msgstr ""
-#: ../lib/imagery/iclass_perimeter.c:208
-msgid "Absurd polygon."
+#: ../lib/init/grass.py:349
+msgid "directory containing Locations"
 msgstr ""
-#: ../lib/imagery/iclass_perimeter.c:253
-msgid "Outlined area is too large."
+#: ../lib/init/grass.py:350
+msgid "initial GRASS Location"
 msgstr ""
-#: ../lib/imagery/iclass_signatures.c:120
-#, c-format
-msgid "Unable to open output signature file '%s'"
+#: ../lib/init/grass.py:351
+msgid ""
+"directory containing Mapsets with one common coordinate system (projection)"
 msgstr ""
-#: ../lib/cluster/c_exec.c:44
-#, c-format
-msgid "Not enough data points (%d) in cluster"
+#: ../lib/init/grass.py:352
+msgid "initial GRASS Mapset"
 msgstr ""
-#: ../lib/cluster/c_begin.c:57
-#, c-format
-msgid "produced by i.cluster"
+#: ../lib/init/grass.py:353
+msgid "fully qualified initial Mapset directory"
 msgstr ""
-#: ../lib/db/dbmi_driver/d_error.c:35
-#, c-format
-msgid "DBMI-%s driver error:"
+#: ../lib/init/grass.py:354
+msgid "Environment variables relevant for startup"
 msgstr ""
-#: ../lib/db/dbmi_client/select.c:119 ../lib/db/dbmi_client/select.c:221
-#: ../lib/db/dbmi_client/select.c:288
-msgid "Missing column name"
+#: ../lib/init/grass.py:355
+msgid "select GUI (text, gui, gtext)"
 msgstr ""
-#: ../lib/db/dbmi_client/select.c:216 ../lib/db/dbmi_client/select.c:283
-msgid "Missing key column name"
+#: ../lib/init/grass.py:356
+msgid "set html web browser for help pages"
 msgstr ""
-#: ../lib/db/dbmi_client/select.c:333
-msgid "Key column type is not integer"
+#: ../lib/init/grass.py:357
+msgid "set additional path(s) to local GRASS modules or user scripts"
 msgstr ""
-#: ../lib/db/dbmi_client/copy_tab.c:91
-#, c-format
-msgid "Array of values to select from column <%s> is empty"
+#: ../lib/init/grass.py:358
+msgid "set additional GISBASE for locally installed GRASS Addons"
 msgstr ""
-#: ../lib/db/dbmi_client/copy_tab.c:151
-#, c-format
-msgid "Unable to get list tables in database <%s>"
+#: ../lib/init/grass.py:359
+msgid "shell script to be processed as batch job"
 msgstr ""
-#: ../lib/db/dbmi_client/copy_tab.c:189
-#, c-format
-msgid "Table <%s> already exists in database and will be overwritten"
+#: ../lib/init/grass.py:360
+msgid "set Python interpreter name to override 'python'"
 msgstr ""
-#: ../lib/db/dbmi_client/copy_tab.c:194
-#, c-format
-msgid "Table <%s> already exists in database <%s>"
+#: ../lib/init/grass.py:361
+msgid "execute GRASS module or script"
 msgstr ""
-#: ../lib/db/dbmi_client/copy_tab.c:274
-#, c-format
-msgid "Column <%s> is not integer"
+#: ../lib/init/grass.py:362
+msgid "provided executable will be executed in GRASS session"
 msgstr ""
-#: ../lib/db/dbmi_client/copy_tab.c:294
-#, c-format
-msgid "Unable to create table <%s>"
+#: ../lib/init/grass.py:363
+msgid "GRASS module, script or any other executable"
 msgstr ""
-#: ../lib/db/dbmi_client/copy_tab.c:394
-#, c-format
-msgid "Unknown column type (column <%s>)"
+#: ../lib/init/grass.py:364
+msgid "parameters of the executable"
 msgstr ""
-#: ../lib/db/dbmi_client/table.c:46 ../lib/db/dbmi_client/delete_tab.c:40
-#, c-format
-msgid "Unable open database <%s> by driver <%s>"
+#: ../lib/init/grass.py:365
+msgid "standard flags"
 msgstr ""
-#: ../lib/db/dbmi_client/delete_tab.c:53
-#, c-format
-msgid "Unable to drop table: '%s'"
+#: ../lib/init/grass.py:390
+msgid "The APPDATA variable is not set, ask your operating system support"
 msgstr ""
-#: ../lib/db/dbmi_base/test/test_main.c:83
-msgid "Performs unit and integration tests for the dbmi base library"
+#: ../lib/init/grass.py:393
+msgid ""
+"The APPDATA variable points to directory which does not exist, ask your "
+"operating system support"
 msgstr ""
-#: ../lib/db/dbmi_base/test/test_columns.c:37
+#: ../lib/init/grass.py:440
+#, python-format
 msgid ""
-"\n"
-"++ Running column unit tests ++"
+"Unable to create temporary directory <grass7-%(user)s-%(lock)s>! Exiting."
 msgstr ""
-#: ../lib/db/dbmi_base/test/test_columns.c:42
+#: ../lib/init/grass.py:493
+#, python-brace-format
+msgid "Invalid line in RC file ({file}): '{line}' ({error})\n"
+msgstr ""
+#: ../lib/init/grass.py:547
+#, python-format
+msgid "GUI <%s> not supported in this version"
+msgstr ""
+#: ../lib/init/grass.py:704
+msgid "Searched for a web browser, but none found"
+msgstr ""
+#: ../lib/init/grass.py:743
 msgid ""
-"\n"
-"-- column unit tests failure --"
+"The python command does not work as expected!\n"
+"Please check your GRASS_PYTHON environment variable.\n"
+"Use the -help option for details.\n"
 msgstr ""
-#: ../lib/db/dbmi_base/test/test_columns.c:44
+#: ../lib/init/grass.py:747
+msgid "GRASS GUI not found. Please check your installation."
+msgstr ""
+#: ../lib/init/grass.py:749
 msgid ""
+"{}\n"
+"Switching to text based interface mode.\n"
 "\n"
-"-- column unit tests finished successfully --"
+"Hit RETURN to continue.\n"
 msgstr ""
-#: ../lib/db/dbmi_base/test/test_columns.c:57
+#: ../lib/init/grass.py:758
 msgid ""
+"It appears that the X Windows system is not active.\n"
+"A graphical based user interface is not supported.\n"
+"(DISPLAY variable is not set.)\n"
 "\n"
-"++ Run test copy column ++"
 msgstr ""
-#: ../lib/db/dbmi_base/test/test_columns.c:150
+#: ../lib/init/grass.py:847
+#, python-format
+msgid "<%s> is not a valid GRASS Location because PERMANENT Mapset is missing"
+msgstr ""
+#: ../lib/init/grass.py:850
+#, python-format
+msgid "<%s> is not a valid GRASS Location because PERMANENT is not a directory"
+msgstr ""
+#: ../lib/init/grass.py:854
+#, python-format
 msgid ""
-"\n"
-"++ Test copy column finished ++"
+"<%s> is not a valid GRASS Location because PERMANENT Mapset does not have a "
+"DEFAULT_WIND file (default computational region)"
 msgstr ""
-#: ../lib/db/dbmi_base/test/test_table.c:38
+#: ../lib/init/grass.py:858
 msgid ""
-"\n"
-"++ Running table unit tests ++"
+"Mapset <{mapset}> doesn't exist in GRASS Location <{loc}>. A new mapset can "
+"be created by '-c' switch."
 msgstr ""
-#: ../lib/db/dbmi_base/test/test_table.c:43
+#: ../lib/init/grass.py:862
+#, python-format
+msgid "<%s> is not a GRASS Mapset because it is not a directory"
+msgstr ""
+#: ../lib/init/grass.py:865
+msgid "Mapset <{mapset}> is invalid for an unknown reason"
+msgstr ""
+#: ../lib/init/grass.py:927
+#, python-format
+msgid "Failed to create new location. The location <%s> already exists."
+msgstr ""
+"Nebija iespējams izveidot jaunu novietojumu. Novietojums <%s> jau eksistē."
+#: ../lib/init/grass.py:938
+msgid "Missing WIND file fixed"
+msgstr ""
+#: ../lib/init/grass.py:950
 msgid ""
+"GISDBASE, LOCATION_NAME and MAPSET variables not set properly.\n"
+"Interactive startup needed."
+msgstr ""
+#: ../lib/init/grass.py:974
+#, python-format
+msgid ""
+"Invalid user interface specified - <%s>. Use the --help option to see valid "
+"interface names."
+msgstr ""
+#: ../lib/init/grass.py:993
+msgid ""
+"Error in GUI startup. See messages above (if any) and if necessary, please "
+"report this error to the GRASS developers.\n"
+"On systems with package manager, make sure you have the right GUI package, "
+"probably named grass-gui, installed.\n"
+"To run GRASS GIS in text mode use the -text flag.\n"
+"Use '--help' for further options\n"
+"     {cmd_name} --help\n"
+"See also: https://grass.osgeo.org/{cmd_name}/manuals/helptext.html"
+msgstr ""
+#: ../lib/init/grass.py:1005
+msgid ""
+"Exit was requested in GUI.\n"
+"GRASS GIS will not start. Bye."
+msgstr ""
+"Grafiskajā vidē bija pieprasīta iziešana.\n"
+"GRASS GIS netiks startēts."
+#: ../lib/init/grass.py:1008
+msgid ""
+"Invalid return code from GUI startup script.\n"
+"Please advise GRASS developers of this error."
+msgstr ""
+#: ../lib/init/grass.py:1055
+msgid ""
+"Error reading data path information from g.gisenv.\n"
+"GISDBASE={gisbase}\n"
+"LOCATION_NAME={location}\n"
+"MAPSET={mapset}\n"
 "\n"
-"-- Table unit tests failure --"
+"Check the <{file}> file."
 msgstr ""
-#: ../lib/db/dbmi_base/test/test_table.c:45
+#: ../lib/init/grass.py:1136 ../lib/init/grass.py:1140
+msgid "Default locale settings are missing. GRASS running with C locale."
+msgstr ""
+#: ../lib/init/grass.py:1218
+#, python-format
+msgid "Path '%s' doesn't exist"
+msgstr "Ceļš '%s' neeksitē"
+#: ../lib/init/grass.py:1220
+#, python-format
+msgid "Path '%s' not accessible."
+msgstr "Ceļš '%s' nav pieejams."
+#. GTC %s is mapset's folder path
+#: ../lib/init/grass.py:1225
+#, python-format
+msgid "You are not the owner of '%s'."
+msgstr "Jūs neesat '%s' īpašnieks."
+#: ../lib/init/grass.py:1233
+#, python-format
 msgid ""
+"%(user)s is currently running GRASS in selected mapset (file %(file)s "
+"found). Concurrent use not allowed.\n"
+"You can force launching GRASS using -f flag (note that you need permission "
+"for this operation). Have another look in the processor manager just to be "
+"sure..."
+msgstr ""
+#: ../lib/init/grass.py:1240
+#, python-format
+msgid ""
+"found). Forcing to launch GRASS..."
+msgstr ""
+#: ../lib/init/grass.py:1244
+#, python-format
+msgid ""
+"Unable to properly access '%s'.\n"
+"Please notify system personnel."
+msgstr ""
+#: ../lib/init/grass.py:1265
+msgid "Building user fontcap..."
+msgstr ""
+#: ../lib/init/grass.py:1324
+msgid "The SHELL variable is not set"
+msgstr ""
+#: ../lib/init/grass.py:1340
+msgid "Unsupported shell <{sh}>: {env_file}"
+msgstr ""
+#: ../lib/init/grass.py:1356
+#, python-format
+msgid ""
+"Job file <%s> has been defined in the 'GRASS_BATCH_JOB' variable but not "
+"found. Exiting.\n"
 "\n"
-"-- Table unit tests finished successfully --"
+"Use 'unset GRASS_BATCH_JOB' to disable batch job processing."
 msgstr ""
-#: ../lib/db/dbmi_base/valuefmt.c:52
-msgid "db_convert_Cstring_to_value(): unrecognized sqltype"
+#: ../lib/init/grass.py:1363
+#, python-format
+msgid "Change file permission to 'executable' for <%s>"
 msgstr ""
-#: ../lib/db/dbmi_base/valuefmt.c:91
-msgid "db_convert_value_into_string(): unrecongized sqltype-type"
+#: ../lib/init/grass.py:1378
+#, python-format
+msgid "Executing <%s> ..."
+msgstr "Izpilda <%s>...."
+#: ../lib/init/grass.py:1385
+msgid ""
+"Execution of <{cmd}> failed:\n"
+"{error}"
 msgstr ""
-#: ../lib/db/dbmi_base/index.c:180
-msgid "db_set_index_column_name(): invalid column number"
+#: ../lib/init/grass.py:1388
+#, python-format
+msgid "Execution of <%s> finished."
 msgstr ""
-#: ../lib/db/dbmi_base/index.c:197
-msgid "db_get_index_column_name(): invalid column number"
+#: ../lib/init/grass.py:1419
+msgid "Unable to close GUI. {0}"
 msgstr ""
-#: ../lib/db/dbmi_base/login.c:115
-#, c-format
-msgid "Unable to read file '%s'"
+#: ../lib/init/grass.py:1446
+#, python-format
+msgid "Welcome to GRASS GIS %s"
 msgstr ""
-#: ../lib/db/dbmi_base/login.c:126
-#, c-format
-msgid "Login file (%s) corrupted (line: %s)"
+#: ../lib/init/grass.py:1468
+msgid "GRASS GIS homepage:"
+msgstr "GRASS GIS mājas lapa:"
+#. GTC Running through: SHELL NAME
+#: ../lib/init/grass.py:1470
+msgid "This version running through:"
+msgstr "Šo versiju darbina:"
+#: ../lib/init/grass.py:1472
+msgid "Help is available with the command:"
+msgstr "Palīdzība ir pieejama ar komandu:"
+#: ../lib/init/grass.py:1473
+msgid "See the licence terms with:"
+msgstr "Licences informācija ir pieejama:"
+#: ../lib/init/grass.py:1474
+msgid "See citation options with:"
 msgstr ""
-#: ../lib/db/dbmi_base/login.c:164
-#, c-format
-msgid "Unable to write file '%s'"
+#: ../lib/init/grass.py:1477
+msgid "If required, restart the GUI with:"
+msgstr "Ja nepieciešams, grafisko vidi var pārstartēt ar:"
+#: ../lib/init/grass.py:1479
+msgid "Start the GUI with:"
+msgstr "Grafiskās vides startēšana: "
+#: ../lib/init/grass.py:1481
+msgid "When ready to quit enter:"
+msgstr "Lai izietu, izpildiet:"
+#: ../lib/init/grass.py:1569
+msgid "2D and 3D raster MASKs present"
 msgstr ""
-#: ../lib/db/dbmi_base/login.c:229
-#, c-format
-msgid "DB connection <%s/%s> already exists and will be overwritten"
+#: ../lib/init/grass.py:1570
+msgid "Raster MASK present"
 msgstr ""
-#: ../lib/db/dbmi_base/login.c:232
-#, c-format
-msgid "DB connection <%s/%s> already exists. Re-run '%s' with '--%s' flag to overwrite existing settings."
+#: ../lib/init/grass.py:1571
+msgid "3D raster MASK present"
 msgstr ""
-#: ../lib/db/dbmi_base/default_name.c:136
-msgid "Programmer error"
-msgstr "Programmētāja kļūda"
+#: ../lib/init/grass.py:1612
+msgid "Done."
+msgstr "Pabeigts."
-#: ../lib/db/dbmi_base/xdrvalue.c:82
-msgid "send data: invalid C-type"
+#: ../lib/init/grass.py:1614
+msgid "Goodbye from GRASS GIS"
+msgstr "Uz redzēšanos"
+#: ../lib/init/grass.py:1619
+msgid "Cleaning up temporary files..."
+msgstr "Satīra pagaidu failus..."
+#: ../lib/init/grass.py:1639
+msgid "Please install the GRASS GIS development package"
 msgstr ""
-#: ../lib/db/dbmi_base/error.c:72
-msgid "<NULL error message>"
+#: ../lib/init/grass.py:1673
+#, python-format
+msgid "Parameter <%s> not supported"
+msgstr "Parametrs <%s> nav atbalstīts"
+#: ../lib/init/grass.py:1817
+msgid "Flag -e requires also flag -c"
 msgstr ""
-#: ../lib/db/dbmi_base/error.c:91
-msgid "dbmi: Protocol error"
-msgstr "dbmi: protokola kļūda"
+#: ../lib/init/grass.py:1864
+msgid ""
+"Unable to start GRASS GIS. You have the choice to:\n"
+" - Launch the graphical user interface with the '-gui' switch\n"
+"     {cmd_name} -gui\n"
+" - Launch with path to the location/mapset as an argument\n"
+"     {cmd_name} /path/to/location/mapset`\n"
+" - Create a location with '-c' and launch in its PERMANENT mapset\n"
+"     {cmd_name} -c EPSG:number /path/to/location\n"
+"     {cmd_name} -c geofile /path/to/location\n"
+" - Create manually the GISRC file ({gisrcrc})\n"
+" - Use '--help' for further options\n"
+msgstr ""
-#: ../lib/db/dbmi_base/error.c:136
-msgid "dbmi: Out of Memory"
+#: ../lib/init/grass.py:1887
+msgid "Creating new GRASS GIS location/mapset..."
 msgstr ""
-#: ../lib/db/dbmi_base/error.c:149
-#, c-format
-msgid "dbmi: %s() not implemented"
+#: ../lib/init/grass.py:1889
+msgid "Starting GRASS GIS..."
+msgstr "Startē GRASS GIS..."
+#: ../lib/init/grass.py:1910
+msgid ""
+"<{0}> requested, but not available. Run GRASS in text mode (-text) or "
+"install missing package (usually 'grass-gui')."
 msgstr ""
-#: ../lib/db/dbmi_base/error.c:163
-#, c-format
-msgid "dbmi: Invalid procedure %d"
+#: ../lib/init/grass.py:1964
+#, python-format
+msgid "Launching <%s> GUI in the background, please wait..."
+msgstr "Startē <%s> grafisko vidi fona režīmā. Lūdzu uzgaidiet..."
+#: ../lib/init/grass.py:1986
+#, python-format
+msgid "Failed to start shell '%s'"
 msgstr ""
-#: ../lib/db/dbmi_base/legal_dbname.c:38
+#: ../lib/init/lock.c:38
 #, c-format
-msgid "Illegal table map name <%s>. May not contain '.' or 'NULL'."
+msgid "Usage: %s file pid"
 msgstr ""
-#: ../lib/db/dbmi_base/legal_dbname.c:45
-#, c-format
-msgid "Illegal table map name <%s>. Must start with a letter."
+#: ../lib/init/lock.c:42
+msgid "Concurrent mapset locking is not supported on Windows"
 msgstr ""
-#: ../lib/db/dbmi_base/legal_dbname.c:54
+#: ../lib/init/lock.c:60
 #, c-format
-msgid "Illegal table map name <%s>. Character <%c> not allowed."
+msgid "Unable to write lockfile %s (%s)"
 msgstr ""
-#: ../lib/db/dbmi_base/xdrtable.c:109
-msgid "fetch: table has wrong number of columns"
+#: ../lib/python/gunittest/gmodules.py:103
+msgid "input='-' must be used when stdin is specified"
 msgstr ""
-#: ../lib/ogsf/trans.c:180
-msgid "Out of matrix stack space"
+#: ../lib/python/gunittest/gmodules.py:105
+msgid "stdin must be string or buffer, not PIPE"
 msgstr ""
-#: ../lib/ogsf/trans.c:200
-msgid "Tried to pop an empty stack"
+#: ../lib/python/gunittest/gmodules.py:108
+msgid "stdin must be used when input='-'"
 msgstr ""
-#: ../lib/ogsf/gs3.c:132 ../lib/ogsf/gs3.c:196 ../lib/ogsf/gs3.c:348
-#: ../lib/ogsf/gs3.c:454 ../lib/ogsf/gs3.c:540
-#, c-format
-msgid "Loading raster map <%s>..."
+#: ../lib/python/gunittest/gmodules.py:110
+msgid "You cannot merge stdout and stderr and not capture them"
 msgstr ""
-#: ../lib/ogsf/gs3.c:596
-#, c-format
-msgid "Color table range doesn't match data (mincol=%d, maxcol=%d"
+#: ../lib/python/gunittest/gmodules.py:112
+msgid "stdout argument not allowed, it could be overridden"
 msgstr ""
-#: ../lib/ogsf/gs3.c:658 ../lib/ogsf/gs3.c:730
-#, c-format
-msgid "Translating colors from raster map <%s>..."
+#: ../lib/python/gunittest/gmodules.py:114
+msgid "stderr argument not allowed, it could be overridden"
 msgstr ""
-#: ../lib/ogsf/gs3.c:967
-msgid "View not saved by this program,there may be some inconsistancies"
+#: ../lib/python/temporal/temporal_vector_algebra.py:386
+#, python-format
+msgid ""
+"Error vector maps with basename %s exist. Use --o flag to overwrite existing "
+"file"
 msgstr ""
-#: ../lib/ogsf/gp3.c:148
-#, c-format
-msgid "No points from vector map <%s> fall within current region"
+#: ../lib/python/temporal/temporal_vector_algebra.py:419
+#, python-format
+msgid ""
+"Error starting %s : \n"
+"%s"
 msgstr ""
-#: ../lib/ogsf/gp3.c:153
-#, c-format
-msgid "Vector map <%s> loaded (%d points)"
+#: ../lib/python/temporal/temporal_vector_algebra.py:492
+#, python-format
+msgid ""
+"Error vector map %s exist in temporal database. Use overwrite flag.  : \n"
+"%s"
 msgstr ""
-#: ../lib/ogsf/gp3.c:211
-#, c-format
-msgid "Loading thematic points layer <%s>..."
+#: ../lib/python/temporal/datetime_math.py:256
+#: ../lib/python/temporal/datetime_math.py:273
+#, python-format
+msgid "Wrong increment format: %s"
 msgstr ""
-#: ../lib/ogsf/gp3.c:235 ../lib/ogsf/gv3.c:377
-#, c-format
-msgid "No color rule defined for category %d"
+#: ../lib/python/temporal/datetime_math.py:451
+#: ../lib/python/temporal/abstract_space_time_dataset.py:1616
+#, python-format
+msgid "Wrong granularity format: %s"
 msgstr ""
-#: ../lib/ogsf/gp3.c:249 ../lib/ogsf/gv3.c:392
-#, c-format
-msgid "Invalid color definition (%s)"
+#: ../lib/python/temporal/datetime_math.py:771
+msgid "Time string seems to specify relative time"
 msgstr ""
-#: ../lib/ogsf/gp3.c:288
-#, c-format
-msgid "%d points without category. Unable to determine color rules for features without category."
+#: ../lib/python/temporal/datetime_math.py:783
+msgid "Dates Before Christ (BC) are not supported"
 msgstr ""
-#: ../lib/ogsf/gs_bm.c:124
-msgid "Bitmap mismatch"
+#: ../lib/python/temporal/datetime_math.py:787
+msgid "Time zones are not supported"
 msgstr ""
-#: ../lib/ogsf/gsd_legend.c:246
-#, c-format
-msgid "Unable to read color file of raster map <%s>"
-msgstr "Nav iespējams nolasīt rastra kartes <%s> krāsu failu"
+#: ../lib/python/temporal/datetime_math.py:807
+#, python-format
+msgid "Unable to parse time string: %s"
+msgstr ""
-#: ../lib/ogsf/gsd_legend.c:252
-#, c-format
-msgid "Unable to read category file of raster map <%s>"
+#: ../lib/python/temporal/abstract_space_time_dataset.py:167
+#: ../lib/python/temporal/abstract_space_time_dataset.py:301
+#, python-format
+msgid "Unknown temporal type \"%s\""
 msgstr ""
-#: ../lib/ogsf/gsd_legend.c:269
-#, c-format
-msgid "Unable to read fp range of raster map <%s>"
+#: ../lib/python/temporal/abstract_space_time_dataset.py:294
+#: ../lib/python/temporal/abstract_space_time_dataset.py:1062
+#, python-format
+msgid "Wrong granularity: \"%s\""
 msgstr ""
-#: ../lib/ogsf/gsd_legend.c:281
-#, c-format
-msgid "Unable to read range of raster map <%s>"
+#: ../lib/python/temporal/abstract_space_time_dataset.py:322
+#, python-format
+msgid "Unsupported temporal unit: %s"
 msgstr ""
-#: ../lib/ogsf/gsd_legend.c:295
-msgid "Range request error for legend"
+#: ../lib/python/temporal/abstract_space_time_dataset.py:372
+#, python-format
+msgid "Created register table <%s> for space time %s  dataset <%s>"
 msgstr ""
-#: ../lib/ogsf/gsd_legend.c:385
-msgid "Unable to show discrete FP range (use list)"
+#: ../lib/python/temporal/abstract_space_time_dataset.py:690
+#: ../lib/python/temporal/abstract_space_time_dataset.py:932
+msgid "The space time datasets must be of the same temporal type"
 msgstr ""
-#: ../lib/ogsf/gsd_legend.c:501
-msgid "Too many categories to show as discrete!"
+#: ../lib/python/temporal/abstract_space_time_dataset.py:695
+#: ../lib/python/temporal/abstract_space_time_dataset.py:937
+msgid "The temporal map type of the sample dataset must be interval"
 msgstr ""
-#: ../lib/ogsf/gsd_legend.c:503
-msgid "Try using smaller font!"
+#: ../lib/python/temporal/abstract_space_time_dataset.py:1499
+#, python-format
+msgid "Unable to get map ids from register table <%s>"
 msgstr ""
-#: ../lib/ogsf/gs2.c:1211
-#, c-format
-msgid "no category info"
-msgstr "nav kategoriju informācijas"
+#: ../lib/python/temporal/abstract_space_time_dataset.py:1609
+#, python-format
+msgid ""
+"Unable to shift dataset <%(ds)s> of type %(type)s in the temporal database. "
+"The mapset of the dataset does not match the current mapset"
+msgstr ""
-#: ../lib/ogsf/gs2.c:1230
-#, c-format
-msgid "no data"
-msgstr "nav datu"
+#: ../lib/python/temporal/abstract_space_time_dataset.py:1778
+#, python-format
+msgid ""
+"Unable to snap dataset <%(ds)s> of type %(type)s in the temporal database. "
+msgstr ""
-#: ../lib/ogsf/gs2.c:1655
-#, c-format
-msgid "Raster map <%s> is outside of current region. Load failed."
-msgstr "Rastra karte <%s> atrodas ārpus reģiona. Ielāde nav veikta."
+#: ../lib/python/temporal/abstract_space_time_dataset.py:1880
+#, python-format
+msgid ""
+"Unable to rename dataset <%(ds)s> of type %(type)s in the temporal database. "
+msgstr ""
-#: ../lib/ogsf/gs2.c:1733 ../lib/ogsf/gs2.c:1739 ../lib/ogsf/gs2.c:1747
-#: ../lib/ogsf/gs2.c:1756 ../lib/ogsf/gs2.c:1764 ../lib/ogsf/gs2.c:1774
-#: ../lib/ogsf/gs2.c:1822
-msgid "GS_load_att_map(): Out of memory. Unable to load map"
+#: ../lib/python/temporal/abstract_space_time_dataset.py:1889
+msgid "Renaming of space time datasets is not supported for PostgreSQL."
 msgstr ""
-#: ../lib/ogsf/gs2.c:1850
-msgid "Loading failed"
-msgstr "Nesekmīga ielāde"
+#: ../lib/python/temporal/abstract_space_time_dataset.py:1954
+#, python-format
+msgid "Delete space time %s  dataset <%s> from temporal database"
+msgstr ""
-#: ../lib/ogsf/gs2.c:1854
-msgid "Error finding range"
+#: ../lib/python/temporal/abstract_space_time_dataset.py:1960
+#: ../lib/python/temporal/abstract_map_dataset.py:841
+#, python-format
+msgid ""
+"Unable to delete dataset <%(ds)s> of type %(type)s from the temporal "
+"database. The mapset of the dataset does not match the current mapset"
 msgstr ""
-#: ../lib/ogsf/gsd_prim.c:146
-#, c-format
-msgid "Color Material: %d"
+#: ../lib/python/temporal/abstract_space_time_dataset.py:1973
+#, python-format
+msgid "Drop map register table: %s"
 msgstr ""
-#: ../lib/ogsf/gsd_prim.c:630
-#, c-format
-msgid "gsd_rot(): %c is an invalid axis specification. Rotation ignored. Please advise GRASS developers of this error"
+#: ../lib/python/temporal/abstract_space_time_dataset.py:2028
+msgid "Error in register table request"
 msgstr ""
-#: ../lib/ogsf/gk.c:320
-msgid "Need at least 3 keyframes for spline"
+#: ../lib/python/temporal/abstract_space_time_dataset.py:2057
+#, python-format
+msgid ""
+"Unable to register map in dataset <%(ds)s> of type %(type)s. The mapset of "
+"the dataset does not match the current mapset"
 msgstr ""
-#: ../lib/ogsf/gk.c:622
-msgid "Need at least 2 keyframes for interpolation"
+#: ../lib/python/temporal/abstract_space_time_dataset.py:2066
+msgid ""
+"Only a map that was inserted in the temporal database can be registered in a "
+"space time dataset"
 msgstr ""
-#: ../lib/ogsf/gvl_file.c:103
-msgid "Maximum number of datafiles exceeded"
+#: ../lib/python/temporal/abstract_space_time_dataset.py:2089
+#, python-format
+msgid "Map <%(id)s> with layer %(l)s has invalid time"
 msgstr ""
-#: ../lib/ogsf/gvl_file.c:442
-#, c-format
-msgid "Unable to read range of 3D raster map <%s>"
+#: ../lib/python/temporal/abstract_space_time_dataset.py:2093
+#, python-format
+msgid "Map <%s> has invalid time"
 msgstr ""
-#: ../lib/ogsf/gsds.c:109
-msgid "Maximum number of datasets exceeded"
+#: ../lib/python/temporal/abstract_space_time_dataset.py:2111
+#, python-format
+msgid ""
+"Temporal type of space time dataset <%(id)s> and map <%(map)s> with layer "
+"%(l)s are different"
 msgstr ""
-#: ../lib/ogsf/gvl2.c:267
-#, c-format
-msgid "Loading 3d raster map <%s>..."
+#: ../lib/python/temporal/abstract_space_time_dataset.py:2117
+#, python-format
+msgid ""
+"Temporal type of space time dataset <%(id)s> and map <%(map)s> are different"
 msgstr ""
-#: ../lib/ogsf/gsd_label.c:58
-msgid "Max. number of labels reached!"
+#: ../lib/python/temporal/abstract_space_time_dataset.py:2132
+#, python-format
+msgid "Set temporal unit for space time %s dataset <%s> to %s"
 msgstr ""
-#: ../lib/ogsf/gsd_img_tif.c:66 ../lib/ogsf/gk2.c:216
-#: ../lib/ogsf/gsd_img_ppm.c:52 ../lib/ogsf/gsd_img_ppm.c:95
-#, c-format
-msgid "Unable to open file <%s> for writing"
-msgstr "Nav iespējams atvērt failu <%s> rakstīšanai"
+#: ../lib/python/temporal/abstract_space_time_dataset.py:2142
+#, python-format
+msgid ""
+"Relative time units of space time dataset <%(id)s> and map <%(map)s> with "
+"layer %(l)s are different"
+msgstr ""
-#: ../lib/ogsf/gv3.c:269
-#, c-format
-msgid "No features from vector map <%s> fall within current region"
+#: ../lib/python/temporal/abstract_space_time_dataset.py:2148
+#, python-format
+msgid ""
+"Relative time units of space time dataset <%(id)s> and map <%(map)s> are "
+"different"
 msgstr ""
-#: ../lib/ogsf/gv3.c:274
-#, c-format
-msgid "Vector map <%s> loaded (%d features)"
+#: ../lib/python/temporal/abstract_space_time_dataset.py:2154
+msgid "Only maps from the same mapset can be registered"
 msgstr ""
-#: ../lib/ogsf/gv3.c:353
-#, c-format
-msgid "Loading thematic vector layer <%s>..."
+#: ../lib/python/temporal/abstract_space_time_dataset.py:2159
+#, python-format
+msgid "Map <%(map)s> with layer %(l)s is already registered."
 msgstr ""
-#: ../lib/ogsf/gv3.c:414
-#, c-format
-msgid "%d features without category. Unable to determine color rules for features without category."
+#: ../lib/python/temporal/abstract_space_time_dataset.py:2163
+#, python-format
+msgid "Map <%s> is already registered."
 msgstr ""
-#: ../lib/ogsf/gp2.c:705
-msgid "Unknown icon marker, using \"sphere\""
+#: ../lib/python/temporal/abstract_space_time_dataset.py:2211
+#, python-format
+msgid ""
+"Unable to unregister map from dataset <%(ds)s> of type %(type)s in the "
+"temporal database. The mapset of the dataset does not match the current "
+"mapset"
 msgstr ""
-#: ../lib/ogsf/gk2.c:272 ../lib/ogsf/gk2.c:285
-msgid "Check no. of frames requested and keyframes marked"
+#: ../lib/python/temporal/abstract_space_time_dataset.py:2224
+#, python-format
+msgid ""
+"Map <%(map)s> with layer %(l)s is not registered in space time dataset <"
+"%(base)s>"
 msgstr ""
-#: ../lib/ogsf/gsd_surf.c:1742
-msgid "Cut-plane points mis-match between surfaces. Check resolution(s)."
+#: ../lib/python/temporal/abstract_space_time_dataset.py:2230
+#, python-format
+msgid "Map <%(map)s> is not registered in space time dataset <%(base)s>"
 msgstr ""
-#: ../lib/ogsf/gsdrape.c:207
-msgid "Unable to process vector map - out of memory"
+#: ../lib/python/temporal/abstract_space_time_dataset.py:2285
+#: ../lib/python/temporal/abstract_dataset.py:426
+#: ../lib/python/temporal/abstract_dataset.py:469
+#: ../lib/python/temporal/abstract_map_dataset.py:424
+#: ../lib/python/temporal/abstract_map_dataset.py:520
+#, python-format
+msgid ""
+"Unable to update dataset <%(ds)s> of type %(type)s in the temporal database. "
 msgstr ""
+#: ../lib/python/temporal/abstract_space_time_dataset.py:2291
+#, python-format
 msgid ""
-"Path '%s' not accessible\n"
-"and you are not the owner of it."
+"Update metadata, spatial and temporal extent from all registered maps of <%s>"
 msgstr ""
-"Ceļš '%s' nav pieejams\n"
-"un jūs neesat tā īpašnieks."
+#: ../lib/python/temporal/mapcalc.py:109
+msgid "Starting spatio-temporal sampling..."
+msgstr ""
+#: ../lib/python/temporal/mapcalc.py:111
+msgid "Starting temporal sampling..."
+msgstr ""
+#: ../lib/python/temporal/mapcalc.py:128
+msgid "No samples found for map calculation"
+msgstr ""
+#: ../lib/python/temporal/mapcalc.py:155
+msgid ""
+"Found more than a single map in a sample granule. Only the first map is used "
+"for computation. Use t.rast.aggregate.ds to create synchronous raster "
+"datasets."
+msgstr ""
+#: ../lib/python/temporal/mapcalc.py:173
+msgid "No maps registered in input dataset"
+msgstr ""
+#: ../lib/python/temporal/mapcalc.py:189
+msgid "Starting mapcalc computation..."
+msgstr ""
+#: ../lib/python/temporal/mapcalc.py:239
+#: ../lib/python/temporal/open_stds.py:211
+#: ../lib/python/temporal/extract.py:131
+#, python-format
+msgid ""
+"Map <%s> is already in temporal database, use overwrite flag to overwrite"
+msgstr ""
+#: ../lib/python/temporal/mapcalc.py:259
+#, python-format
+msgid "Apply mapcalc expression: \"%s\""
+msgstr ""
+#: ../lib/python/temporal/mapcalc.py:278
+msgid "Error while mapcalc computation"
+msgstr ""
+#: ../lib/python/temporal/mapcalc.py:284
+msgid "Starting map registration in temporal database..."
+msgstr ""
+#: ../lib/python/temporal/mapcalc.py:323
+msgid "Removing {}/{} ({}%) maps because empty..."
+msgstr ""
+#: ../lib/python/temporal/mapcalc.py:441 ../lib/python/temporal/mapcalc.py:447
+#: ../lib/python/temporal/mapcalc.py:453 ../lib/python/temporal/mapcalc.py:459
+#: ../lib/python/temporal/mapcalc.py:465 ../lib/python/temporal/mapcalc.py:471
+#: ../lib/python/temporal/mapcalc.py:477 ../lib/python/temporal/mapcalc.py:483
+#: ../lib/python/temporal/mapcalc.py:489 ../lib/python/temporal/mapcalc.py:524
+#: ../lib/python/temporal/mapcalc.py:533 ../lib/python/temporal/mapcalc.py:542
+#: ../lib/python/temporal/mapcalc.py:551 ../lib/python/temporal/mapcalc.py:560
+#: ../lib/python/temporal/mapcalc.py:569 ../lib/python/temporal/mapcalc.py:578
+#: ../lib/python/temporal/mapcalc.py:587 ../lib/python/temporal/mapcalc.py:596
+#, python-format
+msgid "The temporal operators <%s> support only absolute time."
+msgstr ""
+#: ../lib/python/temporal/gui_support.py:58 ../lib/python/script/core.py:1298
+#, python-format
+msgid "Invalid element '%s'"
+msgstr ""
+#: ../lib/python/temporal/temporal_granularity.py:1054
+#: ../lib/python/temporal/temporal_granularity.py:1096
+msgid ""
+"Output granularity seems not to be valid. Please use one of the following "
+"values : {gr}"
+msgstr ""
+#: ../lib/python/temporal/temporal_granularity.py:1058
+#: ../lib/python/temporal/temporal_granularity.py:1099
+#: ../lib/python/temporal/temporal_granularity.py:1172
+msgid "Invalid absolute granularity"
+msgstr ""
+#: ../lib/python/temporal/temporal_granularity.py:1169
+msgid "Probably you need to invert 'from_gran' and 'to_gran'"
+msgstr ""
+#: ../lib/python/temporal/spatial_extent.py:123
+msgid ""
+"Projections are different. Unable to compute overlapping_2d for spatial "
+"extents"
+msgstr ""
+#: ../lib/python/temporal/spatial_extent.py:529
+msgid ""
+"Projections are different. Unable to compute is_in_2d for spatial extents"
+msgstr ""
+#: ../lib/python/temporal/spatial_extent.py:661
+msgid ""
+"Projections are different. Unable to compute equivalent_2d for spatial "
+"extents"
+msgstr ""
+#: ../lib/python/temporal/spatial_extent.py:766
+msgid ""
+"Projections are different. Unable to compute cover_2d for spatial extents"
+msgstr ""
+#: ../lib/python/temporal/spatial_extent.py:838
+msgid "Projections are different. Unable to compute cover for spatial extents"
+msgstr ""
+#: ../lib/python/temporal/spatial_extent.py:1690
+msgid "Volume computation is not supported for LL projections"
+msgstr ""
+#: ../lib/python/temporal/spatial_extent.py:1708
+msgid "Area computation is not supported for LL projections"
+msgstr "Objekta id"
+#: ../lib/python/temporal/stds_import.py:85
+#, python-format
+msgid "Unable to import/link raster map <%s> from file %s."
+msgstr ""
+#: ../lib/python/temporal/stds_import.py:96
+#, python-format
+msgid "Unable to set the color rules for raster map <%s>."
+msgstr ""
+#: ../lib/python/temporal/stds_import.py:120
+#, python-format
+msgid "Unable to unpack raster map <%s> from file %s."
+msgstr ""
+#: ../lib/python/temporal/stds_import.py:144
+#, python-format
+msgid "Unable to import vector map <%s> from file %s."
+msgstr ""
+#: ../lib/python/temporal/stds_import.py:168
+#, python-format
+msgid "Unable to unpack vector map <%s> from file %s."
+msgstr ""
+#: ../lib/python/temporal/stds_import.py:207
+#, python-format
+msgid "Space time raster dataset archive <%s> not found"
+msgstr ""
+#: ../lib/python/temporal/stds_import.py:210
+#, python-format
+msgid "Extraction directory <%s> not found"
+msgstr ""
+#: ../lib/python/temporal/stds_import.py:216
+#, python-format
+msgid "Checking validity of input file (size: %0.1f MB). Make take a while..."
+msgstr ""
+#: ../lib/python/temporal/stds_import.py:223
+#, python-format
+msgid "Unable to find init file <%s>"
+msgstr ""
+#: ../lib/python/temporal/stds_import.py:225
+#, python-format
+msgid "Unable to find list file <%s>"
+msgstr ""
+#: ../lib/python/temporal/stds_import.py:227
+#, python-format
+msgid "Unable to find projection file <%s>"
+msgstr ""
+#: ../lib/python/temporal/stds_import.py:229
+msgid "Extracting data..."
+msgstr ""
+#: ../lib/python/temporal/stds_import.py:269
+msgid "Projection information does not match. Proceeding..."
+msgstr ""
+#: ../lib/python/temporal/stds_import.py:273
+msgid ""
+"Difference between PROJ_INFO file of imported map and of current location:\n"
+"{diff}"
+msgstr ""
+#: ../lib/python/temporal/stds_import.py:276
+msgid "Projection information does not match. Aborting."
+msgstr ""
+#: ../lib/python/temporal/stds_import.py:293
+#, python-format
+msgid "Unable to create location %(l)s. Reason: %(e)s"
+msgstr ""
+#: ../lib/python/temporal/stds_import.py:301
+#, python-format
+msgid "Unable to switch to location %s"
+msgstr ""
+#: ../lib/python/temporal/stds_import.py:306
+#, python-format
+msgid "Unable to create default temporal database in new location %s"
+msgstr ""
+#: ../lib/python/temporal/stds_import.py:380
+#, python-format
+msgid "Key words %(t)s, %(s)s or %(n)s not found in init file."
+msgstr ""
+#: ../lib/python/temporal/stds_import.py:386
+msgid "Number of maps mismatch in init and list file."
+msgstr ""
+#: ../lib/python/temporal/stds_import.py:397
+msgid "The archive file is of wrong space time dataset type"
+msgstr ""
+#: ../lib/python/temporal/stds_import.py:405
+#, python-format
+msgid "Unable to find GeoTIFF raster file <%s> in archive."
+msgstr ""
+#: ../lib/python/temporal/stds_import.py:411
+#, python-format
+msgid "Unable to find AAIGrid raster file <%s> in archive."
+msgstr ""
+#: ../lib/python/temporal/stds_import.py:417
+#, python-format
+msgid "Unable to find GML vector file <%s> in archive."
+msgstr ""
+#: ../lib/python/temporal/stds_import.py:426
+#, python-format
+msgid "Unable to find GRASS package file <%s> in archive."
+msgstr ""
+#: ../lib/python/temporal/stds_import.py:429
+msgid "Unsupported input format"
+msgstr "Ievades objektu tips"
+#: ../lib/python/temporal/stds_import.py:435
+#, python-format
+msgid ""
+"Space time %(t)s dataset <%(sp)s> is already in the database. Use the "
+"overwrite flag."
+msgstr ""
+#: ../lib/python/temporal/stds_import.py:456
+#, python-format
+msgid "Overwrite space time %(sp)s dataset <%(id)s> and unregister all maps."
+msgstr ""
+#: ../lib/python/temporal/stds_import.py:468
+#, python-format
+msgid "Key word %s not found in init file."
+msgstr ""
+#: ../lib/python/temporal/stds_import.py:473
+#, python-format
+msgid "Create space time %s dataset."
+msgstr ""
+#: ../lib/python/temporal/stds_import.py:502
+msgid "Switching to original location failed"
+msgstr ""
+#: ../lib/python/temporal/sampling.py:95 ../lib/python/temporal/sampling.py:100
+#, python-format
+msgid "Dataset <%s> not found in temporal database"
+msgstr ""
+#: ../lib/python/temporal/c_libraries_interface.py:596
+#: ../lib/python/temporal/c_libraries_interface.py:613
+msgid "Unable to read range file"
+msgstr ""
+#: ../lib/python/temporal/c_libraries_interface.py:691
+#, python-format
+msgid "Unable to load range of 3D raster map <%s>"
+msgstr ""
+#: ../lib/python/temporal/core.py:603
+msgid ""
+"Unable to initialize the temporal DBMI interface. Please use t.connect to "
+"specify the driver and the database string"
+msgstr ""
+#: ../lib/python/temporal/core.py:672
+#, python-format
+msgid ""
+"Unable to receive temporal database metadata.\n"
+"Current temporal database info:%(info)s"
+msgstr ""
+#: ../lib/python/temporal/core.py:677
+#, python-format
+msgid ""
+"Unsupported temporal database: version mismatch.\n"
+" %(backup)s Supported temporal API version is: %(api)i.\n"
+"Please update your GRASS GIS installation.\n"
+msgstr ""
+#: ../lib/python/temporal/core.py:685
+#, python-format
+msgid ""
+" %(backup)sSupported temporal database version is: %(tdb)i\n"
+msgstr ""
+#: ../lib/python/temporal/core.py:773
+#, python-format
+msgid "Creating temporal database: %s"
+msgstr ""
+#: ../lib/python/temporal/core.py:782
+#, python-format
+msgid ""
+"Unable to create SQLite temporal database\n"
+"Exception: %s\n"
+"Please use t.connect to set a read- and writable temporal database path"
+msgstr ""
+#: ../lib/python/temporal/core.py:947
+msgid "Unable to mogrify sql statement. "
+msgstr ""
+#: ../lib/python/temporal/core.py:969
+msgid "Unable to check table. "
+msgstr ""
+#: ../lib/python/temporal/core.py:985
+msgid "Unable to execute sql statement. "
+msgstr ""
+#: ../lib/python/temporal/core.py:995
+msgid "Unable to fetch one. "
+msgstr ""
+#: ../lib/python/temporal/core.py:1005
+msgid "Unable to fetch all. "
+msgstr ""
+#: ../lib/python/temporal/core.py:1022
+msgid "Unable to execute transaction. "
+msgstr ""
+#: ../lib/python/temporal/core.py:1126
+#, python-format
+msgid ""
+"Unable to connect to %(db)s database: %(string)s\n"
+"Exception: \"%(ex)s\"\n"
+"Please use t.connect to set a read- and writable temporal database backend"
+msgstr ""
+#: ../lib/python/temporal/core.py:1286
+#, python-format
+msgid ""
+"Unable to execute :\n"
+" %(sql)s"
+msgstr ""
+#: ../lib/python/temporal/core.py:1330
+#, python-format
+msgid ""
+"Unable to execute transaction:\n"
+" %(sql)s"
+msgstr ""
+#: ../lib/python/temporal/abstract_dataset.py:386
+#, python-format
+msgid ""
+"Unable to insert dataset <%(ds)s> of type %(type)s in the temporal database. "
+msgstr ""
+#: ../lib/python/temporal/space_time_datasets.py:251
+#, python-format
+msgid "Unable to read timestamp file for raster map <%s>"
+msgstr ""
+#: ../lib/python/temporal/space_time_datasets.py:275
+#, python-format
+msgid "Unable to create timestamp file for raster map <%s>"
+msgstr ""
+#: ../lib/python/temporal/space_time_datasets.py:280
+#, python-format
+msgid "Invalid datetime in timestamp for raster map <%s>"
+msgstr ""
+#: ../lib/python/temporal/space_time_datasets.py:285
+#: ../lib/python/temporal/space_time_datasets.py:633
+msgid "Internal error"
+msgstr "Iekšēja kļūda"
+#: ../lib/python/temporal/space_time_datasets.py:302
+#: ../lib/python/temporal/space_time_datasets.py:647
+#, python-format
+msgid "Unable to remove timestamp for raster map <%s>"
+msgstr ""
+#: ../lib/python/temporal/space_time_datasets.py:599
+#, python-format
+msgid "Unable to read timestamp file for 3D raster map <%s>"
+msgstr ""
+#: ../lib/python/temporal/space_time_datasets.py:623
+#, python-format
+msgid "Unable to create timestamp file for 3D raster map <%s>"
+msgstr ""
+#: ../lib/python/temporal/space_time_datasets.py:628
+#, python-format
+msgid "Invalid datetime in timestamp for 3D raster map <%s>"
+msgstr ""
+#: ../lib/python/temporal/space_time_datasets.py:907
+#, python-format
+msgid "Unable to read timestamp file for vector map <%s>"
+msgstr ""
+#: ../lib/python/temporal/space_time_datasets.py:930
+#, python-format
+msgid "Unable to create timestamp file for vector map <%s>"
+msgstr ""
+#: ../lib/python/temporal/space_time_datasets.py:935
+#, python-format
+msgid "Invalid datetime in timestamp for vector map <%s>"
+msgstr ""
+#: ../lib/python/temporal/space_time_datasets.py:951
+#, python-format
+msgid "Unable to remove timestamp for vector map <%s>"
+msgstr ""
+#: ../lib/python/temporal/univar_statistics.py:62
+#: ../lib/python/temporal/univar_statistics.py:178
+#, python-format
+msgid "Space time %(sp)s dataset <%(i)s> is empty"
+msgstr ""
+#: ../lib/python/temporal/univar_statistics.py:101
+#, python-format
+msgid "Unable to get statistics for raster map <%s>"
+msgstr ""
+#: ../lib/python/temporal/univar_statistics.py:104
+#, python-format
+msgid "Unable to get statistics for 3d raster map <%s>"
+msgstr ""
+#: ../lib/python/temporal/univar_statistics.py:168
+#, python-format
+msgid "Space time %(sp)s dataset <%(i)s> not found"
+msgstr ""
+#: ../lib/python/temporal/univar_statistics.py:222
+#, python-format
+msgid "Unable to get statistics for vector map <%s>"
+msgstr ""
+#: ../lib/python/temporal/list_stds.py:208
+msgid "Empty map list"
+msgstr "Lauku atdalītājs"
+#: ../lib/python/temporal/list_stds.py:219
+msgid "Empty entry in map list, this should not happen"
+msgstr ""
+#: ../lib/python/temporal/abstract_map_dataset.py:350
+#, python-format
+msgid ""
+"Start time must be of type datetime for %(type)s map <%(id)s> with layer: "
+"%(l)s"
+msgstr ""
+#: ../lib/python/temporal/abstract_map_dataset.py:357
+#, python-format
+msgid "Start time must be of type datetime for %(type)s map <%(id)s>"
+msgstr ""
+#: ../lib/python/temporal/abstract_map_dataset.py:365
+#, python-format
+msgid ""
+"End time must be of type datetime for %(type)s map <%(id)s> with layer: %(l)s"
+msgstr ""
+#: ../lib/python/temporal/abstract_map_dataset.py:372
+#, python-format
+msgid "End time must be of type datetime for %(type)s map <%(id)s>"
+msgstr ""
+#: ../lib/python/temporal/abstract_map_dataset.py:381
+#, python-format
+msgid ""
+"End time must be greater than start time for %(type)s map <%(id)s> with "
+"layer: %(l)s"
+msgstr ""
+#: ../lib/python/temporal/abstract_map_dataset.py:389
+#: ../lib/python/temporal/abstract_map_dataset.py:482
+#, python-format
+msgid "End time must be greater than start time for %(type)s map <%(id)s>"
+msgstr ""
+#: ../lib/python/temporal/abstract_map_dataset.py:460
+#, python-format
+msgid ""
+"Unsupported relative time unit type for %(type)s map <%(id)s> with layer "
+"%(l)s: %(u)s"
+msgstr ""
+#: ../lib/python/temporal/abstract_map_dataset.py:467
+#, python-format
+msgid "Unsupported relative time unit type for %(type)s map <%(id)s>: %(u)s"
+msgstr ""
+#: ../lib/python/temporal/abstract_map_dataset.py:476
+#, python-format
+msgid ""
+"End time must be greater than start time for %(typ)s map <%(id)s> with layer "
+"%(l)s"
+msgstr ""
+#: ../lib/python/temporal/abstract_map_dataset.py:800
+#, python-format
+msgid ""
+"Map <%(id)s> with layer %(layer)s has incorrect time interval, start time is "
+"greater than end time"
+msgstr ""
+#: ../lib/python/temporal/abstract_map_dataset.py:806
+#, python-format
+msgid ""
+"Map <%s> has incorrect time interval, start time is greater than end time"
+msgstr ""
+#: ../lib/python/temporal/abstract_map_dataset.py:812
+#, python-format
+msgid "Map <%s> has incorrect start time"
+msgstr ""
+#: ../lib/python/temporal/abstract_map_dataset.py:859
+#, python-format
+msgid "Delete %s dataset <%s> from temporal database"
+msgstr ""
+#: ../lib/python/temporal/abstract_map_dataset.py:909
+#, python-format
+msgid ""
+"Unable to unregister dataset <%(ds)s> of type %(type)s from the temporal "
+msgstr ""
+#: ../lib/python/temporal/register.py:82 ../lib/python/temporal/register.py:85
+#, python-format
+msgid "%s= and %s= are mutually exclusive"
+msgstr ""
+#: ../lib/python/temporal/register.py:89
+#, python-format
+msgid "%s= and the %s flag are mutually exclusive"
+msgstr ""
+#: ../lib/python/temporal/register.py:93
+msgid "The increment option requires the start option"
+msgstr ""
+#: ../lib/python/temporal/register.py:96
+msgid "The interval flag requires the start option"
+msgstr ""
+#: ../lib/python/temporal/register.py:99
+#, python-format
+msgid "Please specify %s= and %s="
+msgstr ""
+#: ../lib/python/temporal/register.py:103
+#, python-format
+msgid "Please specify %s= or %s="
+msgstr ""
+#: ../lib/python/temporal/register.py:114
+#, python-format
+msgid ""
+"Space time %(sp)s dataset <%(name)s> with relative time found, but no "
+"relative unit set for %(sp)s maps"
+msgstr ""
+#: ../lib/python/temporal/register.py:175
+msgid ""
+"The increment option will be ignored because of time stamps in input file"
+msgstr ""
+#: ../lib/python/temporal/register.py:179
+msgid "The interval flag will be ignored because of time stamps in input file"
+msgstr ""
+#: ../lib/python/temporal/register.py:187
+msgid "Gathering map information..."
+msgstr ""
+#: ../lib/python/temporal/register.py:197
+#, python-format
+msgid "Unable to update %(t)s map <%(id)s>. The map does not exist."
+msgstr ""
+#: ../lib/python/temporal/register.py:215
+#, python-format
+msgid ""
+"Unable to register %(t)s map <%(id)s> with layer %(l)s. The map has "
+"timestamp and the start time is not set."
+msgstr ""
+#: ../lib/python/temporal/register.py:221
+#, python-format
+msgid ""
+"Unable to register %(t)s map <%(id)s>. The map has no timestamp and the "
+"start time is not set."
+msgstr ""
+#: ../lib/python/temporal/register.py:229
+#, python-format
+msgid "%(u)s= can only be set for relative time"
+msgstr ""
+#: ../lib/python/temporal/register.py:232
+#, python-format
+msgid "%(u)s= must be set in case of relative time stamps"
+msgstr ""
+#: ../lib/python/temporal/register.py:245
+#, python-format
+msgid ""
+"Map is already registered in temporal database. Unable to update %(t)s map <"
+"%(id)s> with layer %(l)s. Overwrite flag is not set."
+msgstr ""
+#: ../lib/python/temporal/register.py:252
+#, python-format
+msgid ""
+"%(id)s>. Overwrite flag is not set."
+msgstr ""
+#: ../lib/python/temporal/register.py:276
+#, python-format
+msgid ""
+"Unable to update %(t)s map <%(id)s> with layer %(l)s. The temporal types are "
+"different."
+msgstr ""
+#: ../lib/python/temporal/register.py:282
+#, python-format
+msgid "Unable to update %(t)s map <%(id)s>. The temporal types are different."
+msgstr ""
+#: ../lib/python/temporal/register.py:330
+msgid "Registering maps in the temporal database..."
+msgstr ""
+#: ../lib/python/temporal/register.py:337
+msgid "Registering maps in the space time dataset..."
+msgstr ""
+#: ../lib/python/temporal/register.py:346
+msgid "Updating space time dataset..."
+msgstr ""
+#: ../lib/python/temporal/register.py:399
+#: ../lib/python/temporal/register.py:406
+#, python-format
+msgid "Unable to convert string \"%s\"into a datetime object"
+msgstr ""
+#: ../lib/python/temporal/register.py:414
+#: ../lib/python/temporal/register.py:419
+msgid "Error occurred in increment computation"
+msgstr ""
+#: ../lib/python/temporal/register.py:422
+#, python-format
+msgid ""
+"Set absolute valid time for map <%(id)s> with layer %(layer)s to %(start)s - "
+"%(end)s"
+msgstr ""
+#: ../lib/python/temporal/register.py:427
+#, python-format
+msgid "Set absolute valid time for map <%s> to %s - %s"
+msgstr ""
+#: ../lib/python/temporal/register.py:444
+#, python-format
+msgid ""
+"Set relative valid time for map <%s> with layer %s to %i - %s with unit %s"
+msgstr ""
+#: ../lib/python/temporal/register.py:449
+#, python-format
+msgid "Set relative valid time for map <%s> to %i - %s with unit %s"
+msgstr ""
+#: ../lib/python/temporal/temporal_algebra.py:815
+msgid ""
+"Spatio-temporal topological operators are not supported in granularity "
+"algebra mode"
+msgstr ""
+#: ../lib/python/temporal/temporal_algebra.py:853
+msgid "All input space time datasets must have a valid temporal topology."
+msgstr ""
+#: ../lib/python/temporal/temporal_algebra.py:862
+msgid "All input space time datasets must have the same temporal type."
+msgstr ""
+#: ../lib/python/temporal/temporal_algebra.py:1113
+#, python-format
+msgid "Removing un-needed or empty %s maps"
+msgstr ""
+#: ../lib/python/temporal/temporal_algebra.py:1168
+#, python-format
+msgid "Space time %s dataset <%s> not found"
+msgstr ""
+#: ../lib/python/temporal/temporal_algebra.py:1196
+#: ../lib/python/temporal/temporal_algebra.py:1200
+#, python-format
+msgid ""
+"Wrong temporal type of space time dataset <"
+"%s>                                       <%s> time is required"
+msgstr ""
+#: ../lib/python/temporal/temporal_algebra.py:1220
+msgid "Wrong type of input "
+msgstr ""
+#: ../lib/python/temporal/temporal_algebra.py:2186
+#, python-format
+msgid ""
+"The resulting space time dataset type <%(a)s> is different from the "
+"requested type <%(b)s>"
+msgstr ""
+#: ../lib/python/temporal/temporal_algebra.py:2192
+msgid ""
+"Maps that should be registered in the resulting space time dataset have "
+"different types."
+msgstr ""
+#: ../lib/python/temporal/temporal_algebra.py:2395
+#: ../lib/python/temporal/temporal_raster_base_algebra.py:777
+#, python-format
+msgid "%s map <%s> not found in GRASS spatial database"
+msgstr ""
+#: ../lib/python/temporal/temporal_algebra.py:2401
+msgid ""
+"Wrong map type. TMAP only supports single maps that are registered in the "
+"temporal GRASS database"
+msgstr ""
+#: ../lib/python/temporal/temporal_algebra.py:2429
+msgid "Merging empty map lists"
+msgstr ""
+#: ../lib/python/temporal/temporal_algebra.py:2432
+msgid "First Map list is empty, can't merge it. Return only last map list"
+msgstr ""
+#: ../lib/python/temporal/temporal_algebra.py:2435
+msgid "Second Map list is empty, can't merge it. Return only first map list"
+msgstr ""
+#: ../lib/python/temporal/temporal_algebra.py:2443
+msgid "Space time datasets to merge must have the same temporal type"
+msgstr ""
+#: ../lib/python/temporal/open_stds.py:63
+#: ../lib/python/temporal/open_stds.py:119
+#, python-format
+msgid "Unknown type: %s"
+msgstr ""
+#: ../lib/python/temporal/open_stds.py:69
+#, python-format
+msgid "Space time %(sp)s dataset <%(name)s> not found"
+msgstr ""
+#: ../lib/python/temporal/open_stds.py:108
+msgid "Space time datasets can only be created in the current mapset"
+msgstr ""
+#: ../lib/python/temporal/open_stds.py:125
+#, python-format
+msgid ""
+"Space time %(sp)s dataset <%(name)s> is already in the database. Use the "
+"overwrite flag."
+msgstr ""
+#: ../lib/python/temporal/open_stds.py:160
+#, python-format
+msgid ""
+"Overwriting space time %(sp)s dataset <%(name)s> and unregistering all maps"
+msgstr ""
+#: ../lib/python/temporal/open_stds.py:168
+#, python-format
+msgid "Creating a new space time %s dataset"
+msgstr ""
+#: ../lib/python/temporal/factory.py:51
+#, python-format
+msgid "Unknown dataset type: %s"
+msgstr ""
+#: ../lib/python/temporal/stds_export.py:107
+#, python-format
+msgid "Unable to export raster map <%s>"
+msgstr ""
+#: ../lib/python/temporal/stds_export.py:118
+#, python-format
+msgid "Unable to export color rules for raster map <%s> r.out.gdal"
+msgstr ""
+#: ../lib/python/temporal/stds_export.py:142
+#, python-format
+msgid "Unable to export raster map <%s> with r.pack"
+msgstr ""
+#: ../lib/python/temporal/stds_export.py:170
+#, python-format
+msgid "Unable to export vector map <%s> as GML with v.out.ogr"
+msgstr ""
+#: ../lib/python/temporal/stds_export.py:203
+#, python-format
+msgid "Unable to export vector map <%s> with v.pack"
+msgstr ""
+#: ../lib/python/temporal/stds_export.py:229
+#, python-format
+msgid "Unable to export raster map <%s> with r3.pack"
+msgstr ""
+#: ../lib/python/temporal/extract.py:60
+msgid "You need to specify the base name of new created maps"
+msgstr ""
+#: ../lib/python/temporal/extract.py:138
+#, python-format
+msgid "Applying r.mapcalc expression: \"%s\""
+msgstr ""
+#: ../lib/python/temporal/extract.py:143
+#, python-format
+msgid "Applying r3.mapcalc expression: \"%s\""
+msgstr ""
+#: ../lib/python/temporal/extract.py:148
+#, python-format
+msgid "Applying v.extract where statement: \"%s\""
+msgstr ""
+#: ../lib/python/temporal/extract.py:176
+msgid "Error in computation process"
+msgstr ""
+#: ../lib/python/temporal/temporal_raster_base_algebra.py:690
+#, python-format
+msgid "Error computing map <%s>"
+msgstr ""
+#: ../lib/python/temporal/aggregation.py:127
+#, python-format
+msgid "Aggregating %s raster maps"
+msgstr ""
+#: ../lib/python/temporal/aggregation.py:141
+#, python-format
+msgid ""
+"Raster map <%(name)s> is already in temporal database, use overwrite flag to "
+"overwrite"
+msgstr ""
+#: ../lib/python/temporal/aggregation.py:146
+#, python-format
+msgid "Computing aggregation of maps between %(st)s - %(end)s"
+msgstr ""
+#: ../lib/python/temporal/aggregation.py:171
+msgid "Error occurred in r.series computation"
+msgstr ""
+#: ../lib/python/temporal/aggregation.py:280
+#, python-format
+msgid "Aggregating %(len)i raster maps from %(start)s to %(end)s"
+msgstr ""
+#: ../lib/python/temporal/aggregation.py:301
+#, python-format
+msgid ""
+"Unable to perform aggregation. Output raster map <%(name)s> exists and "
+"overwrite flag was not set"
+msgstr ""
+#: ../lib/python/temporal/aggregation.py:319
+#, python-format
+msgid ""
+"The limit of open files (%i) was reached (%i). The module r.series will be "
+"run with flag z, to avoid open files limit exceeding."
+msgstr ""
+#: ../lib/python/temporal/base.py:380
 #, fuzzy
-msgid "Out of memmory"
-msgstr "Neiespējami piešķirt atmiņu\n"
+msgid "Object not found in the temporal database"
+msgstr "neiespējami atvērt rastra karti [%s iekš %s]"
+#: ../lib/python/temporal/base.py:462 ../lib/python/temporal/base.py:513
+msgid "Missing identifier"
+msgstr ""
+#: ../lib/python/temporal/base.py:621
+msgid "Wrong identifier, the mapset is missing"
+msgstr ""
+#: ../lib/python/exceptions/__init__.py:68
+#, python-format
+msgid "Module run %s %s ended with error"
+msgstr ""
+#: ../lib/python/exceptions/__init__.py:69
+#, python-format
+msgid ""
+"\n"
+"Process ended with non-zero return code %s"
+msgstr ""
+#: ../lib/python/exceptions/__init__.py:71
+#, python-format
+msgid ""
+". See the following errors:\n"
+"%s"
+msgstr ""
+#: ../lib/python/exceptions/__init__.py:75
+msgid ". See errors in the (error) output."
+msgstr ""
+#: ../lib/python/pygrass/vector/__init__.py:806
+#, python-format
+msgid "Unable to read line of feature %i"
+msgstr ""
+#: ../lib/python/pygrass/vector/__init__.py:895
+#, python-format
+msgid "Unable to read area with id %i"
+msgstr ""
+#: ../lib/python/pygrass/vector/abstract.py:97
+#: ../lib/python/pygrass/raster/abstract.py:299
+msgid "Map name {0} not valid"
+msgstr ""
+#: ../lib/python/pygrass/vector/table.py:1033
+#, python-format
+msgid "Deleting table <%s> which is attached to following map(s):"
+msgstr ""
+#: ../lib/python/pygrass/vector/table.py:1037
+msgid "You must use the force flag to actually remove it. Exiting."
+msgstr ""
+#: ../lib/python/pygrass/raster/__init__.py:209
+msgid "The map does not exist, I can't open in 'r' mode"
+msgstr ""
+#: ../lib/python/pygrass/raster/__init__.py:214
+msgid "Raster map <{0}> already exists and will be not overwritten"
+msgstr ""
+#: ../lib/python/pygrass/raster/__init__.py:218
+msgid "Raster type not defined"
+msgstr ""
+#: ../lib/python/pygrass/raster/__init__.py:321
+msgid "Mode type: {0} not supported ('r', 'w','rw')"
+msgstr ""
+#: ../lib/python/pygrass/raster/__init__.py:341
+#, python-format
+msgid "Index out of range: %r."
+msgstr ""
+#: ../lib/python/pygrass/raster/__init__.py:530
+msgid "Raster map <{0}> already exists. Use overwrite."
+msgstr ""
+#: ../lib/python/pygrass/raster/__init__.py:561
+msgid "Raster map <{0}> does not exist"
+msgstr ""
+#: ../lib/python/pygrass/raster/abstract.py:275
+msgid "Mode type: {0} not supported ('r', 'w')"
+msgstr ""
+#: ../lib/python/pygrass/raster/abstract.py:286
+msgid "Overwrite type: {0} not supported (True/False)"
+msgstr ""
+#: ../lib/python/pygrass/raster/category.py:69
+msgid "Raster type: {0} not supported"
+msgstr ""
+#: ../lib/python/pygrass/raster/category.py:156
+msgid "Error executing: Rast_get_ith_cat"
+msgstr ""
+#: ../lib/python/pygrass/raster/category.py:184
+msgid "Null value detected"
+msgstr "Konstatēta NULL vērtība"
+#: ../lib/python/pygrass/raster/category.py:186
+msgid "Error executing: Rast_set_cat"
+msgstr ""
+#: ../lib/python/pygrass/modules/grid/grid.py:553
+msgid "Execution of subprocesses was not successful"
+msgstr ""
+#: ../lib/python/pygrass/utils.py:277
+msgid "Vector doesn't contain points"
+msgstr ""
+#: ../lib/python/pygrass/errors.py:17
+msgid "The map is close!"
+msgstr ""
+#: ../lib/python/pygrass/errors.py:28
+msgid "The self.c_mapinfo pointer must be correctly initiated"
+msgstr ""
+#: ../lib/python/script/task.py:58
+msgid "unknown"
+msgstr ""
+#: ../lib/python/script/task.py:169
+#, python-format
+msgid "Parameter element '%(element)s' not found: '%(value)s'"
+msgstr ""
+#: ../lib/python/script/task.py:184
+#, python-format
+msgid "Flag not found: %s"
+msgstr ""
+#: ../lib/python/script/task.py:203
+#, python-format
+msgid "Parameter '%(name)s' (%(desc)s) is missing."
+msgstr ""
+#: ../lib/python/script/task.py:236
+msgid "<required>"
+msgstr ""
+#: ../lib/python/script/task.py:496 ../lib/python/script/task.py:500
+#, python-format
+msgid ""
+"Unable to fetch interface description for command '%(cmd)s'.\n"
+"\n"
+"Details: %(det)s"
+msgstr ""
+#: ../lib/python/script/task.py:523
+msgid "Cannot parse interface description of<{name}> module: {error}"
+msgstr ""
+#: ../lib/python/script/db.py:153
+#, python-format
+msgid ""
+"Programmer error: '%(sql)s', '%(filename)s', or '%(table)s' must be provided"
+msgstr ""
+#: ../lib/python/script/db.py:163
+msgid "Fetching data failed"
+msgstr ""
+#: ../lib/python/script/core.py:67
+msgid "Cannot find the executable {0}"
+msgstr ""
+#: ../lib/python/script/core.py:307
+#, python-format
+msgid ""
+"To run the module <%s> add underscore at the end of the option <%s> to avoid "
+"conflict with Python keywords. Underscore at the beginning is depreciated in "
+"GRASS GIS 7.0 and will be removed in version 7.1."
+msgstr ""
+#: ../lib/python/script/core.py:987
+msgid "Mixing value types. Will try to compare after integer conversion"
+msgstr ""
+#: ../lib/python/script/core.py:1188
+#, python-format
+msgid "Element type should be \"cell\" and not \"%s\""
+msgstr ""
+#: ../lib/python/script/core.py:1217 ../lib/python/script/core.py:1282
+#, python-format
+msgid "Element type should be \"raster\" and not \"%s\""
+msgstr ""
+#: ../lib/python/script/core.py:1437
+msgid "Unable to list mapsets"
+msgstr ""
+#: ../lib/python/script/core.py:1476
+#, python-format
+msgid "Location <%s> already exists. Operation canceled."
+msgstr ""
+#: ../lib/python/script/core.py:1479
+#, python-format
+msgid "Location <%s> already exists and will be overwritten"
+msgstr ""
+#: ../lib/python/script/core.py:1603
+msgid "Debug level {0}"
+msgstr ""
+#: ../lib/python/script/core.py:1606
+msgid "WARNING: Ignoring unsupported debug level (must be >=0 and <=5). {0}\n"
+msgstr ""
+#: ../lib/python/script/core.py:1622
+#, python-format
+msgid "Illegal filename <%s>. Cannot be 'NULL' or start with '.'."
+msgstr ""
+#: ../lib/python/script/core.py:1631
+#, python-format
+msgid "Illegal filename <%(s)s>. <%(il)s> not allowed.\n"
+msgstr ""
+#: ../lib/python/script/array.py:157 ../lib/python/script/array.py:207
+#: ../lib/python/script/array.py:254 ../lib/python/script/array.py:305
+#: ../lib/python/script/array.py:356 ../lib/python/script/array.py:398
+#, python-format
+msgid "Invalid kind <%s>"
+msgstr ""
+#: ../lib/python/script/array.py:160 ../lib/python/script/array.py:210
+#: ../lib/python/script/array.py:308 ../lib/python/script/array.py:359
+#, python-format
+msgid "Invalid size <%d>"
+msgstr ""
+#: ../lib/python/script/array.py:197
+msgid ""
+"grass.script.array.read is deprecated and does not work on MS Windows, pass "
+"raster name in the constructor"
+msgstr ""
+#: ../lib/python/script/array.py:247 ../lib/python/script/array.py:392
+#, python-format
+msgid "Invalid FP size <%d>"
+msgstr ""
+#: ../lib/python/script/array.py:251 ../lib/python/script/array.py:395
+#, python-format
+msgid "Invalid integer size <%d>"
+msgstr ""
+#: ../lib/python/script/array.py:346
+msgid ""
+"grass.script.array3d.read is deprecated and does not work on MS Windows, "
+"pass 3D raster name in the constructor"
+msgstr ""
+#: ../lib/python/script/vector.py:88
+#, python-format
+msgid "Database connection not defined for layer %s"
+msgstr ""
+#: ../lib/python/script/vector.py:230
+#, python-format
+msgid "Missing layer %(layer)d in vector map <%(map)s>"
+msgstr ""
+#: ../lib/python/script/vector.py:245
+msgid "vector_db_select() failed"
+msgstr ""
+#: ../lib/python/script/vector.py:353
+msgid "Number of given vector maps ({m}) differs from number of layers ({l})"
+msgstr ""
+#: ../lib/python/script/vector.py:415
+msgid ""
+"v.what output is not valid JSON format:\n"
+" {ret}"
+msgstr ""
+#: ../lib/python/script/raster.py:51
+#, python-format
+msgid ""
+"Unable to write history for <%(map)s>. Raster map <%(map)s> not found in "
+"current mapset."
+msgstr ""
+#: ../lib/python/script/raster.py:110
+#, python-format
+msgid "An error occurred while running r.mapcalc with expression: %s"
+msgstr ""
+#: ../lib/python/script/raster.py:189
+msgid "No data"
+msgstr ""
+#: ../lib/python/script/raster.py:197
+msgid "value"
+msgstr "vērtība"
+msgid "label"
+msgstr "nosaukums"
+msgid "color"
+msgstr "krāsa"
+#: ../lib/python/script/raster3d.py:92
+#, python-format
+msgid "An error occurred while running r3.mapcalc with expression: %s"
+msgstr ""
+#~ msgid ""
+#~ "Path '%s' not accessible\n"
+#~ "and you are not the owner of it."
+#~ msgstr ""
+#~ "Ceļš '%s' nav pieejams\n"
+#~ "un jūs neesat tā īpašnieks."
 #, fuzzy
-msgid "Unable to mogrify sql statement. There is no temporal database connection defined for mapset <%(mapset)s>"
-msgstr "neispējami atvērt datumu tabulas failu: %s"
+#~ msgid "Out of memmory"
+#~ msgstr "Neiespējami piešķirt atmiņu\n"
 #, fuzzy
-msgid "Unable to check table. There is no temporal database connection defined for mapset <%(mapset)s>"
+#~ msgid ""
+#~ "Unable to mogrify sql statement. There is no temporal database connection "
+#~ "defined for mapset <%(mapset)s>"
+#~ msgstr "neispējami atvērt datumu tabulas failu: %s"
 #, fuzzy
-msgid "Unable to execute sql statement. There is no temporal database connection defined for mapset <%(mapset)s>"
+#~ msgid ""
+#~ "Unable to check table. There is no temporal database connection defined "
+#~ "for mapset <%(mapset)s>"
 #, fuzzy
-msgid "Unable to fetch one. There is no temporal database connection defined for mapset <%(mapset)s>"
-msgstr "Nevar atvērt vēsturi vektoram '%s'"
+#~ msgid ""
+#~ "Unable to execute sql statement. There is no temporal database connection "
 #, fuzzy
-msgid "Unable to fetch all. There is no temporal database connection defined for mapset <%(mapset)s>"
+#~ msgid ""
+#~ "Unable to fetch one. There is no temporal database connection defined for "
+#~ "mapset <%(mapset)s>"
+#~ msgstr "Nevar atvērt vēsturi vektoram '%s'"
 #, fuzzy
-msgid "Unable to execute transaction. There is no temporal database connection defined for mapset <%(mapset)s>"
+#~ msgid ""
+#~ "Unable to fetch all. There is no temporal database connection defined for "
 #, fuzzy
-msgid "Error writing uncompressed FP data for row %d of <%s>"
-msgstr "kļūda nolasot %smap [%s] karšu biblotēkā [%s], līnija %d"
+#~ msgid ""
+#~ "Unable to execute transaction. There is no temporal database connection "
 #, fuzzy
-msgid "Error writing compressed FP data for row %d of <%s>"
+#~ msgid "Error writing uncompressed FP data for row %d of <%s>"
+#~ msgstr "kļūda nolasot %smap [%s] karšu biblotēkā [%s], līnija %d"
 #, fuzzy
-msgid "Unable to find a temporary null file <%s>"
-msgstr "neispējami atrast pagaidu null failu: %s"
+#~ msgid "Error writing compressed FP data for row %d of <%s>"
 #, fuzzy
-msgid "Unable to open null file <%s>"
-msgstr "G_spawn: neispējami atvērt failu %s"
+#~ msgid "Unable to find a temporary null file <%s>"
+#~ msgstr "neispējami atrast pagaidu null failu: %s"
 #, fuzzy
-msgid "Unable to restore feature/offset %lu in vector map <%s>"
+#~ msgid "Unable to open null file <%s>"
+#~ msgstr "G_spawn: neispējami atvērt failu %s"
 #, fuzzy
-msgid "Invalid offset (%d)"
-msgstr "Nederīgs mezgla ID: %d"
+#~ msgid "Unable to restore feature/offset %lu in vector map <%s>"
 #, fuzzy
-msgid "ERROR: <%s> is not a valid GRASS location"
-msgstr "Atvainojiet, <%s> nav derīgs parametrs"
+#~ msgid "Invalid offset (%d)"
+#~ msgstr "Nederīgs mezgla ID: %d"
 #, fuzzy
-msgid "ERROR: option <%s>: <%s> exists.\n"
-msgstr "Kļūda: opcija/pazīme <%s>: <%s> jau eksistē.\n"
+#~ msgid "ERROR: <%s> is not a valid GRASS location"
+#~ msgstr "Atvainojiet, <%s> nav derīgs parametrs"
 #, fuzzy
-msgid "Unable to allocate stream"
+#~ msgid "ERROR: option <%s>: <%s> exists.\n"
+#~ msgstr "Kļūda: opcija/pazīme <%s>: <%s> jau eksistē.\n"
 #, fuzzy
-msgid "Video codec not found"
-msgstr "Vektorkarte <%s> nav atrasta"
+#~ msgid "Unable to allocate stream"
 #, fuzzy
-msgid "Unable to open codec"
-msgstr "Nevar atvērt mapi %s"
+#~ msgid "Video codec not found"
+#~ msgstr "Vektorkarte <%s> nav atrasta"
 #, fuzzy
-msgid "Unable to allocate temporary picture"
+#~ msgid "Unable to open codec"
+#~ msgstr "Nevar atvērt mapi %s"
 #, fuzzy
-msgid "Error while writing video frame"
-msgstr "Kļūdu raskrīšana ārpus topo faila.\n"
+#~ msgid "Unable to allocate temporary picture"
 #, fuzzy
-msgid "Unable to find suitable output format"
+#~ msgid "Error while writing video frame"
+#~ msgstr "Kļūdu raskrīšana ārpus topo faila.\n"
 #, fuzzy
-msgid "Invalid output format parameters"
-msgstr ""
-"\n"
-"Kļūda: Trūkst vērtība parametram <%s>\n"
+#~ msgid "Unable to find suitable output format"
 #, fuzzy
-msgid "Unable to open <%s>"
-msgstr "Neiespējami atvērt failu %s iekš %s"
+#~ msgid "Invalid output format parameters"
+#~ msgstr ""
+#~ "\n"
+#~ "Kļūda: Trūkst vērtība parametram <%s>\n"
 #, fuzzy
-msgid "Unable to open file '%s'"
+#~ msgid "Unable to open <%s>"
+#~ msgstr "Neiespējami atvērt failu %s iekš %s"
-msgid "Hit RETURN to continue"
-msgstr "Spied ENTER, lai turpinātu"
+#, fuzzy
+#~ msgid "Unable to open file '%s'"
+#~ msgid "Hit RETURN to continue"
+#~ msgstr "Spied ENTER, lai turpinātu"
 #, fuzzy
-msgid "Vector map <%s> is not opened on topology level"
-msgstr "Vektoru karte <%s> nav atvērta"
+#~ msgid "Vector map <%s> is not opened on topology level"
+#~ msgstr "Vektoru karte <%s> nav atvērta"
 #, fuzzy
-msgid "Removing empty 3D raster maps"
-msgstr "Ievades rastra faila nosaukums"
+#~ msgid "Removing empty 3D raster maps"
+#~ msgstr "Ievades rastra faila nosaukums"
 #, fuzzy
-msgid "Mode type: {0} not supported."
-msgstr "Ieejas vektors '%s' nav atrasts"
+#~ msgid "Mode type: {0} not supported."
+#~ msgstr "Ieejas vektors '%s' nav atrasts"
 #, fuzzy
-msgid "Invalid type {0}"
-msgstr "neispējami mainīt direktoriju uz %s"
+#~ msgid "Invalid type {0}"
+#~ msgstr "neispējami mainīt direktoriju uz %s"
-msgid "Attributes for category %d not found"
-msgstr "Kategorijai %d atribūti nav atrasti"
+#~ msgid "Attributes for category %d not found"
+#~ msgstr "Kategorijai %d atribūti nav atrasti"
-msgid "Category must be integer"
-msgstr "Kategorijai ir jābūt veselam skaitlim"
+#~ msgid "Category must be integer"
+#~ msgstr "Kategorijai ir jābūt veselam skaitlim"
-msgid "Memory error in writing timestamp"
-msgstr "Laika zīmoga rakstīšanas atmiņas kļūda"
+#~ msgid "Memory error in writing timestamp"
+#~ msgstr "Laika zīmoga rakstīšanas atmiņas kļūda"
-msgid "Illegal TimeStamp string"
-msgstr "Nederīgs laika zīmoga teksts"
+#~ msgid "Illegal TimeStamp string"
+#~ msgstr "Nederīgs laika zīmoga teksts"
-msgid "Cannot fetch row"
-msgstr "Nevar saņemt rindu"
+#~ msgid "Cannot fetch row"
+#~ msgstr "Nevar saņemt rindu"
 #~ msgid "syntax error"
 #~ msgstr "sintakses kļūda"
Modified: grass/branches/releasebranch_7_4/locale/po/grassmods_lv.po
--- grass/branches/releasebranch_7_4/locale/po/grassmods_lv.po	2018-01-06 17:58:15 UTC (rev 72040)
+++ grass/branches/releasebranch_7_4/locale/po/grassmods_lv.po	2018-01-06 18:27:45 UTC (rev 72041)
@@ -9,7 +9,7 @@
 msgstr ""
 "Project-Id-Version: grassmods_lv\n"
 "Report-Msgid-Bugs-To: \n"
-"POT-Creation-Date: 2017-04-01 16:10+0300\n"
+"POT-Creation-Date: 2018-01-06 20:09+0200\n"
 "PO-Revision-Date: 2017-04-01 16:41+0200\n"
 "Last-Translator: Maris Nartiss <maris.kde at gmail.com>\n"
 "Language-Team: Latvian <grass-translations at lists.osgeo.org>\n"
@@ -18,15492 +18,16531 @@
 "Content-Type: text/plain; charset=UTF-8\n"
 "Content-Transfer-Encoding: 8bit\n"
 "X-Generator: Lokalize 2.0\n"
-"Plural-Forms:  nplurals=3; plural=(n%10==1 && n%100!=11 ? 0 : n != 0 ? 1 : 2);\n"
+"Plural-Forms:  nplurals=3; plural=(n%10==1 && n%100!=11 ? 0 : n != 0 ? 1 : "
+"2);\n"
-#: ../misc/m.nviz.script/main.c:69 ../misc/m.transform/main.c:316
-#: ../misc/m.measure/main.c:46 ../misc/m.cogo/main.c:225
-#: ../misc/m.nviz.image/main.c:50
-#: ../locale/scriptstrings/m.proj_to_translate.c:2
-msgid "miscellaneous"
-msgstr ""
-#: ../misc/m.nviz.script/main.c:70 ../misc/m.nviz.image/main.c:52
-#: ../visualization/ximgview/main.c:291
-#: ../locale/scriptstrings/d.redraw_to_translate.c:3
-#: ../locale/scriptstrings/d.frame_to_translate.c:3
-#: ../locale/scriptstrings/wxpyimgview_to_translate.c:3
-#: ../display/d.his/main.c:63 ../display/d.mon/main.c:39
-#: ../display/d.rast/main.c:54 ../display/d.vect/main.c:74
-#: ../display/d.info/main.c:35 ../display/d.erase/main.c:30
-#: ../display/d.rgb/main.c:54
-msgid "graphics"
-msgstr ""
-#: ../misc/m.nviz.script/main.c:71 ../misc/m.nviz.image/main.c:53
-#: ../visualization/ximgview/main.c:292
-#: ../locale/scriptstrings/r.pack_to_translate.c:2
-#: ../locale/scriptstrings/t.rast.colors_to_translate.c:4
-#: ../locale/scriptstrings/r.blend_to_translate.c:2
-#: ../locale/scriptstrings/t.rast.mapcalc_to_translate.c:4
-#: ../locale/scriptstrings/i.spectral_to_translate.c:4
-#: ../locale/scriptstrings/t.rast.out.vtk_to_translate.c:4
-#: ../locale/scriptstrings/v.rast.stats_to_translate.c:4
-#: ../locale/scriptstrings/r.in.srtm_to_translate.c:2
-#: ../locale/scriptstrings/t.rast.contour_to_translate.c:4
-#: ../locale/scriptstrings/r.import_to_translate.c:2
-#: ../locale/scriptstrings/r.reclass.area_to_translate.c:2
-#: ../locale/scriptstrings/t.rast.gapfill_to_translate.c:4
-#: ../locale/scriptstrings/t.rast.to.rast3_to_translate.c:4
-#: ../locale/scriptstrings/t.rast.aggregate_to_translate.c:4
-#: ../locale/scriptstrings/r.in.aster_to_translate.c:2
-#: ../locale/scriptstrings/t.rast.aggregate.ds_to_translate.c:4
-#: ../locale/scriptstrings/t.rast.accdetect_to_translate.c:4
-#: ../locale/scriptstrings/t.rast.univar_to_translate.c:4
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:2
-#: ../locale/scriptstrings/r.fillnulls_to_translate.c:2
-#: ../locale/scriptstrings/r.rgb_to_translate.c:2
-#: ../locale/scriptstrings/d.correlate_to_translate.c:4
-#: ../locale/scriptstrings/t.rast.neighbors_to_translate.c:4
-#: ../locale/scriptstrings/r.colors.stddev_to_translate.c:2
-#: ../locale/scriptstrings/t.rast.list_to_translate.c:4
-#: ../locale/scriptstrings/r.tileset_to_translate.c:2
-#: ../locale/scriptstrings/t.rast.what_to_translate.c:4
-#: ../locale/scriptstrings/t.rast.algebra_to_translate.c:4
-#: ../locale/scriptstrings/t.rast.extract_to_translate.c:4
-#: ../locale/scriptstrings/t.rast.export_to_translate.c:4
-#: ../locale/scriptstrings/t.rast.import_to_translate.c:4
-#: ../locale/scriptstrings/r.plane_to_translate.c:2
-#: ../locale/scriptstrings/r.grow_to_translate.c:2
-#: ../locale/scriptstrings/d.to.rast_to_translate.c:4
-#: ../locale/scriptstrings/t.rast.to.vect_to_translate.c:4
-#: ../locale/scriptstrings/wxpyimgview_to_translate.c:4
-#: ../locale/scriptstrings/r.unpack_to_translate.c:2
-#: ../locale/scriptstrings/t.rast.series_to_translate.c:5
-#: ../locale/scriptstrings/r.mask_to_translate.c:2
-#: ../locale/scriptstrings/r.out.xyz_to_translate.c:2
-#: ../locale/scriptstrings/r.buffer.lowmem_to_translate.c:3
-#: ../locale/scriptstrings/d.rast.edit_to_translate.c:4
-#: ../locale/scriptstrings/r.shade_to_translate.c:2
-#: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:4
-#: ../raster3d/r3.cross.rast/main.c:230 ../raster3d/r3.to.rast/main.c:261
-#: ../raster/r.mode/main.c:55 ../raster/r.thin/main.c:57
-#: ../raster/r.reclass/main.c:50 ../raster/r.in.bin/main.c:257
-#: ../raster/r.out.png/main.c:112 ../raster/r.in.xyz/main.c:158
-#: ../raster/r.univar/r.univar_main.c:104 ../raster/r.surf.area/main.c:76
-#: ../raster/r.in.png/main.c:519 ../raster/r.in.poly/main.c:34
-#: ../raster/r.texture/main.c:102 ../raster/r.external.out/main.c:235
-#: ../raster/r.uslek/main.c:53 ../raster/r.flow/main.c:421
-#: ../raster/r.buffer/main.c:66 ../raster/r.resamp.interp/main.c:76
-#: ../raster/r.clump/main.c:58 ../raster/r.to.vect/main.c:76
-#: ../raster/r.resamp.bspline/main.c:80 ../raster/r.relief/main.c:107
-#: ../raster/r.series.interp/main.c:64 ../raster/r.quantile/main.c:262
-#: ../raster/r.series.accumulate/main.c:80 ../raster/r.topidx/main.c:39
-#: ../raster/r.neighbors/main.c:167 ../raster/r.stats.zonal/main.c:101
-#: ../raster/r.series/main.c:137 ../raster/r.slope.aspect/main.c:151
-#: ../raster/r.report/main.c:67 ../raster/r.his/main.c:67
-#: ../raster/r.category/main.c:52 ../raster/r.composite/main.c:72
-#: ../raster/r.spreadpath/main.c:88 ../raster/r.describe/main.c:54
-#: ../raster/r.surf.contour/main.c:60 ../raster/r.in.mat/main.c:91
-#: ../raster/r.sunhours/main.c:72 ../raster/r.what.color/main.c:88
-#: ../raster/r.resamp.rst/main.c:148 ../raster/r.out.ascii/main.c:59
-#: ../raster/r.distance/main.c:39 ../raster/r.random/main.c:51
-#: ../raster/r.volume/main.c:76 ../raster/r.random.cells/main.c:47
-#: ../raster/r.cross/main.c:69 ../raster/r.li/r.li.cwed/cwed.c:54
-#: ../raster/r.li/r.li.padrange/padrange.c:53
-#: ../raster/r.li/r.li.renyi/renyi.c:47
-#: ../raster/r.li/r.li.dominance/dominance.c:46
-#: ../raster/r.li/r.li.shannon/shannon.c:46
-#: ../raster/r.li/r.li.padcv/padcv.c:53 ../raster/r.li/r.li.mps/mps.c:52
-#: ../raster/r.li/r.li.patchdensity/main.c:51
-#: ../raster/r.li/r.li.shape/main.c:49 ../raster/r.li/r.li.mpa/mpa.c:44
-#: ../raster/r.li/r.li.padsd/padsd.c:53
-#: ../raster/r.li/r.li.simpson/simpson.c:46
-#: ../raster/r.li/r.li.richness/richness.c:43
-#: ../raster/r.li/r.li.edgedensity/edgedensity.c:48
-#: ../raster/r.li/r.li.patchnum/main.c:50
-#: ../raster/r.li/r.li.pielou/pielou.c:46 ../raster/r.drain/main.c:109
-#: ../raster/r.tile/main.c:43 ../raster/r.sun/main.c:239
-#: ../raster/r.out.pov/main.c:121 ../raster/r.resamp.filter/main.c:389
-#: ../raster/r.surf.fractal/main.c:38 ../raster/r.spread/main.c:105
-#: ../raster/r.walk/main.c:178 ../raster/r.cost/main.c:140
-#: ../raster/r.lake/main.c:150 ../raster/r.sim/r.sim.sediment/main.c:113
-#: ../raster/r.sim/r.sim.water/main.c:113 ../raster/r.out.mpeg/main.c:102
-#: ../raster/r.support.stats/main.c:38 ../raster/r.grow.distance/main.c:150
-#: ../raster/r.transect/main.c:103 ../raster/r.fill.dir/main.c:86
-#: ../raster/r.stream.extract/main.c:76 ../raster/r.stats.quantile/main.c:516
-#: ../raster/r.resample/main.c:54 ../raster/r.out.gridatb/main.c:67
-#: ../raster/r.horizon/main.c:180 ../raster/r.sunmask/main.c:116
-#: ../raster/r.info/main.c:70 ../raster/r.recode/main.c:48
-#: ../raster/r.null/main.c:60 ../raster/r.param.scale/interface.c:54
-#: ../raster/r.surf.random/main.c:36 ../raster/r.out.ppm3/main.c:57
-#: ../raster/r.surf.idw/main.c:104 ../raster/r.surf.gauss/main.c:38
-#: ../raster/r.contour/main.c:87 ../raster/r.out.mat/main.c:62
-#: ../raster/r.profile/main.c:53 ../raster/r.in.gridatb/main.c:45
-#: ../raster/r.regression.line/main.c:46 ../raster/r.quant/main.c:47
-#: ../raster/r.timestamp/main.c:35 ../raster/r.statistics/main.c:55
-#: ../raster/r.proj/main.c:144 ../raster/r.kappa/main.c:68
-#: ../raster/r.out.bin/main.c:279 ../raster/r.rescale.eq/main.c:52
-#: ../raster/r.ros/main.c:212 ../raster/r.covar/main.c:51
-#: ../raster/r.external/main.c:57 ../raster/r.out.vrml/main.c:47
-#: ../raster/r.what/main.c:98 ../raster/r.out.gdal/main.c:136
-#: ../raster/r.in.gdal/main.c:90 ../raster/r.colors/edit_colors.c:63
-#: ../raster/r.to.rast3/main.c:197 ../raster/r.mfilter/main.c:56
-#: ../raster/r.in.ascii/main.c:69 ../raster/r.mapcalc/main.c:69
-#: ../raster/r.basins.fill/main.c:54 ../raster/r.in.lidar/main.c:108
-#: ../raster/r.to.rast3elev/main.c:361 ../raster/r.circle/main.c:51
-#: ../raster/r.solute.transport/main.c:229 ../raster/r.stats/main.c:106
-#: ../raster/r.compress/main.c:68 ../raster/r.colors.out/raster_main.c:45
-#: ../raster/r.regression.multi/main.c:128 ../raster/r.random.surface/main.c:57
-#: ../raster/r.latlong/main.c:56 ../raster/r.coin/main.c:66
-#: ../raster/r.out.ppm/main.c:54 ../raster/r.support/main.c:54
-#: ../raster/r.region/main.c:51 ../raster/r.carve/main.c:74
-#: ../raster/r.rescale/main.c:48 ../raster/r.gwflow/main.c:208
-#: ../raster/r.topmodel/main.c:51 ../raster/r.out.vtk/main.c:59
-#: ../raster/r.water.outlet/main.c:57 ../raster/r.resamp.stats/main.c:261
-#: ../raster/r.patch/main.c:58 ../raster/r.watershed/front/main.c:73
-#: ../raster/r.usler/main.c:52 ../display/d.colortable/main.c:61
-#: ../display/d.rast.arrow/main.c:99 ../display/d.rast/main.c:55
-#: ../display/d.rast.num/main.c:79 ../display/d.profile/main.c:193
-#: ../display/d.rgb/main.c:55 ../vector/v.what.rast3/main.c:66
-#: ../vector/v.sample/main.c:77 ../vector/v.kriging/main.c:56
-#: ../vector/v.neighbors/main.c:53 ../vector/v.to.rast/main.c:46
-#: ../vector/v.what.rast/main.c:73 ../doc/raster/r.example/main.c:83
-msgid "raster"
-msgstr "rastrs"
-#: ../misc/m.nviz.script/main.c:72 ../misc/m.nviz.image/main.c:55
-#: ../locale/scriptstrings/t.rast3d.list_to_translate.c:5
-#: ../locale/scriptstrings/t.rast3d.algebra_to_translate.c:4
-#: ../locale/scriptstrings/t.rast3d.extract_to_translate.c:4
-#: ../locale/scriptstrings/t.rast3d.mapcalc_to_translate.c:4
-#: ../locale/scriptstrings/t.rast.to.rast3_to_translate.c:5
-#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:2
-#: ../locale/scriptstrings/t.rast3d.univar_to_translate.c:4
-#: ../raster3d/r3.mkdspf/main.c:79 ../raster3d/r3.gwflow/main.c:159
-#: ../raster3d/r3.gradient/main.c:43 ../raster3d/r3.out.v5d/main.c:284
-#: ../raster3d/r3.in.bin/main.c:252 ../raster3d/r3.out.bin/main.c:205
-#: ../raster3d/r3.neighbors/main.c:208 ../raster3d/r3.out.ascii/main.c:302
-#: ../raster3d/r3.info/main.c:75 ../raster3d/r3.null/main.c:186
-#: ../raster3d/r3.cross.rast/main.c:228 ../raster3d/r3.in.v5d/main.c:178
-#: ../raster3d/r3.stats/main.c:48 ../raster3d/r3.out.netcdf/main.c:586
-#: ../raster3d/r3.flow/test_main.c:43 ../raster3d/r3.flow/main.c:179
-#: ../raster3d/r3.in.ascii/main.c:354 ../raster3d/r3.support/main.c:49
-#: ../raster3d/r3.mask/main.c:133 ../raster3d/r3.to.rast/main.c:259
-#: ../raster3d/r3.timestamp/main.c:43 ../raster3d/r3.retile/main.c:96
-#: ../raster3d/r3.in.lidar/main.c:162 ../raster3d/r3.out.vtk/main.c:376
-#: ../raster/r.univar/r3.univar_main.c:98 ../raster/r.colors/edit_colors.c:59
-#: ../raster/r.to.rast3elev/main.c:363
-#: ../raster/r.colors.out/raster3d_main.c:46
-msgid "raster3d"
-msgstr "rastrs_3d"
-#: ../misc/m.nviz.script/main.c:73 ../misc/m.nviz.image/main.c:54
-#: ../visualization/ximgview/main.c:293
-#: ../locale/scriptstrings/t.vect.export_to_translate.c:4
+#: ../vector/v.segment/main.c:60 ../vector/v.clean/main.c:51
+#: ../vector/v.clean/test/topocheck.c:42 ../vector/v.to.3d/main.c:36
+#: ../vector/v.select/main.c:48 ../vector/v.surf.rst/main.c:147
+#: ../vector/v.lidar.correction/main.c:71 ../vector/v.sample/main.c:75
+#: ../vector/v.in.ascii/main.c:70 ../vector/v.univar/main.c:92
+#: ../vector/v.profile/main.c:153 ../vector/v.to.db/main.c:36
+#: ../vector/v.surf.idw/main.c:87 ../vector/v.db.connect/main.c:52
+#: ../vector/v.net.allpairs/main.c:61 ../vector/v.voronoi/main.c:123
+#: ../vector/v.class/main.c:45 ../vector/v.external.out/main.c:43
+#: ../vector/v.cluster/main.c:90 ../vector/v.in.dwg/main.c:82
+#: ../vector/v.build/main.c:36 ../vector/v.kcv/main.c:55
+#: ../vector/v.lidar.growing/main.c:75 ../vector/v.in.ogr/main.c:169
+#: ../vector/v.label/main.c:59 ../vector/v.reclass/main.c:67
+#: ../vector/v.category/main.c:75 ../vector/v.net.steiner/main.c:346
+#: ../vector/v.normal/main.c:72 ../vector/v.extract/main.c:77
+#: ../vector/v.out.ogr/main.c:82 ../vector/v.patch/main.c:69
+#: ../vector/v.out.vtk/main.c:47 ../vector/v.vol.rst/main.c:235
+#: ../vector/v.in.lidar/main.c:136 ../vector/v.vect.stats/main.c:130
+#: ../vector/v.qcount/main.c:60 ../vector/v.to.points/main.c:53
+#: ../vector/v.buffer/main.c:221 ../vector/v.build.polylines/main.c:110
+#: ../vector/v.external/main.c:52 ../vector/v.net/main.c:47
+#: ../vector/v.kernel/main.c:108 ../vector/v.outlier/main.c:69
+#: ../vector/v.hull/main.c:52 ../vector/v.what/main.c:62
+#: ../vector/v.generalize/main.c:76 ../vector/v.out.lidar/main.c:471
+#: ../vector/v.out.svg/main.c:77 ../vector/v.neighbors/main.c:50
+#: ../vector/v.in.db/main.c:52 ../vector/v.net.alloc/main.c:64
+#: ../vector/v.out.pov/main.c:46 ../vector/v.net.components/main.c:72
+#: ../vector/v.net.iso/main.c:76 ../vector/v.out.postgis/main.c:44
+#: ../vector/v.distance/main.c:121 ../vector/v.net.bridge/main.c:47
+#: ../vector/v.edit/main.c:54 ../vector/v.parallel/main.c:49
+#: ../vector/v.timestamp/main.c:35 ../vector/v.perturb/main.c:62
+#: ../vector/v.out.ascii/main.c:47 ../vector/v.type/main.c:38
+#: ../vector/v.net.flow/main.c:58 ../vector/v.overlay/main.c:63
+#: ../vector/v.db.select/main.c:54 ../vector/v.surf.bspline/main.c:91
+#: ../vector/v.lidar.edgedetection/main.c:75 ../vector/v.what.rast/main.c:71
+#: ../vector/v.net.path/main.c:42 ../vector/v.net.visibility/main.c:45
+#: ../vector/v.mkgrid/main.c:70 ../vector/v.net.connectivity/main.c:52
+#: ../vector/v.lrs/v.lrs.label/main.c:102 ../vector/v.lrs/v.lrs.where/main.c:57
+#: ../vector/v.lrs/v.lrs.create/main.c:121
+#: ../vector/v.lrs/v.lrs.segment/main.c:71 ../vector/v.net.timetable/main.c:260
+#: ../vector/v.rectify/main.c:70 ../vector/v.proj/main.c:68
+#: ../vector/v.split/main.c:54 ../vector/v.to.rast/main.c:44
+#: ../vector/v.net.distance/main.c:66 ../vector/v.net.spanningtree/main.c:46
+#: ../vector/v.transform/main.c:70 ../vector/v.support/main.c:39
+#: ../vector/v.random/main.c:97 ../vector/v.what.rast3/main.c:64
+#: ../vector/v.colors/main.c:55 ../vector/v.out.dxf/main.c:56
+#: ../vector/v.net.salesman/main.c:127 ../vector/v.in.dxf/main.c:64
+#: ../vector/v.info/main.c:37 ../vector/v.info/print.c:436
+#: ../vector/v.label.sa/main.c:38 ../vector/v.in.region/main.c:41
+#: ../vector/v.to.rast3/main.c:48 ../vector/v.colors.out/main.c:49
+#: ../vector/v.delaunay/main.c:85 ../vector/v.net.centrality/main.c:96
+#: ../vector/v.drape/main.c:56 ../vector/v.decimate/main.c:123
+#: ../vector/v.extrude/main.c:67 ../raster/r.contour/main.c:90
+#: ../raster/r.random/main.c:53
+#: ../locale/scriptstrings/t.vect.list_to_translate.c:4
+#: ../locale/scriptstrings/d.what.vect_to_translate.c:3
+#: ../locale/scriptstrings/v.db.univar_to_translate.c:2
+#: ../locale/scriptstrings/v.in.mapgen_to_translate.c:2
+#: ../locale/scriptstrings/v.in.wfs_to_translate.c:2
+#: ../locale/scriptstrings/t.vect.extract_to_translate.c:4
 #: ../locale/scriptstrings/v.to.lines_to_translate.c:2
+#: ../locale/scriptstrings/v.in.lines_to_translate.c:2
+#: ../locale/scriptstrings/v.in.geonames_to_translate.c:2
+#: ../locale/scriptstrings/t.rast.to.vect_to_translate.c:5
+#: ../locale/scriptstrings/v.db.droprow_to_translate.c:2
+#: ../locale/scriptstrings/v.in.e00_to_translate.c:2
+#: ../locale/scriptstrings/v.clip_to_translate.c:2
+#: ../locale/scriptstrings/v.what.vect_to_translate.c:2
 #: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:2
-#: ../locale/scriptstrings/v.rast.stats_to_translate.c:2
+#: ../locale/scriptstrings/t.vect.observe.strds_to_translate.c:4
+#: ../locale/scriptstrings/t.vect.export_to_translate.c:4
+#: ../locale/scriptstrings/v.db.addcolumn_to_translate.c:2
+#: ../locale/scriptstrings/v.db.addtable_to_translate.c:2
+#: ../locale/scriptstrings/v.build.all_to_translate.c:2
+#: ../locale/scriptstrings/v.import_to_translate.c:2
+#: ../locale/scriptstrings/t.vect.what.strds_to_translate.c:4
+#: ../locale/scriptstrings/v.centroids_to_translate.c:2
+#: ../locale/scriptstrings/v.db.update_to_translate.c:2
 #: ../locale/scriptstrings/t.rast.contour_to_translate.c:5
-#: ../locale/scriptstrings/v.unpack_to_translate.c:2
-#: ../locale/scriptstrings/t.vect.db.select_to_translate.c:4
-#: ../locale/scriptstrings/v.db.update_to_translate.c:2
-#: ../locale/scriptstrings/t.vect.algebra_to_translate.c:4
-#: ../locale/scriptstrings/v.dissolve_to_translate.c:2
-#: ../locale/scriptstrings/v.import_to_translate.c:2
-#: ../locale/scriptstrings/t.vect.observe.strds_to_translate.c:4
-#: ../locale/scriptstrings/v.what.vect_to_translate.c:2
-#: ../locale/scriptstrings/d.what.vect_to_translate.c:3
 #: ../locale/scriptstrings/v.db.renamecolumn_to_translate.c:2
-#: ../locale/scriptstrings/v.build.all_to_translate.c:2
-#: ../locale/scriptstrings/v.db.addtable_to_translate.c:2
-#: ../locale/scriptstrings/v.pack_to_translate.c:2
 #: ../locale/scriptstrings/v.db.join_to_translate.c:2
-#: ../locale/scriptstrings/v.db.droptable_to_translate.c:2
-#: ../locale/scriptstrings/v.centroids_to_translate.c:2
-#: ../locale/scriptstrings/t.vect.list_to_translate.c:4
-#: ../locale/scriptstrings/v.report_to_translate.c:2
-#: ../locale/scriptstrings/v.db.univar_to_translate.c:2
-#: ../locale/scriptstrings/t.rast.to.vect_to_translate.c:5
-#: ../locale/scriptstrings/t.vect.univar_to_translate.c:4
-#: ../locale/scriptstrings/v.db.addcolumn_to_translate.c:2
-#: ../locale/scriptstrings/v.in.mapgen_to_translate.c:2
-#: ../locale/scriptstrings/v.db.droprow_to_translate.c:2
-#: ../locale/scriptstrings/v.in.geonames_to_translate.c:2
+#: ../locale/scriptstrings/v.dissolve_to_translate.c:2
 #: ../locale/scriptstrings/v.what.strds_to_translate.c:2
-#: ../locale/scriptstrings/v.in.lines_to_translate.c:2
+#: ../locale/scriptstrings/v.rast.stats_to_translate.c:2
+#: ../locale/scriptstrings/v.pack_to_translate.c:2
 #: ../locale/scriptstrings/v.db.dropcolumn_to_translate.c:2
-#: ../locale/scriptstrings/v.in.wfs_to_translate.c:2
-#: ../locale/scriptstrings/v.in.e00_to_translate.c:2
-#: ../locale/scriptstrings/t.vect.what.strds_to_translate.c:4
-#: ../locale/scriptstrings/t.vect.extract_to_translate.c:4
+#: ../locale/scriptstrings/v.unpack_to_translate.c:2
+#: ../locale/scriptstrings/t.vect.import_to_translate.c:4
+#: ../locale/scriptstrings/t.vect.db.select_to_translate.c:4
 #: ../locale/scriptstrings/d.what.rast_to_translate.c:3
-#: ../locale/scriptstrings/t.vect.import_to_translate.c:4
-#: ../raster/r.random/main.c:53 ../raster/r.contour/main.c:90
-#: ../display/d.vect/main.c:75 ../display/d.extract/main.c:50
-#: ../display/d.legend.vect/main.c:52 ../vector/v.net.spanningtree/main.c:46
-#: ../vector/v.surf.rst/main.c:147 ../vector/v.what.rast3/main.c:64
-#: ../vector/v.category/main.c:75 ../vector/v.extrude/main.c:67
-#: ../vector/v.extract/main.c:77 ../vector/v.lidar.correction/main.c:71
-#: ../vector/v.net.components/main.c:72 ../vector/v.net.distance/main.c:66
-#: ../vector/v.out.pov/main.c:46 ../vector/v.surf.idw/main.c:87
-#: ../vector/v.timestamp/main.c:35 ../vector/v.segment/main.c:60
-#: ../vector/v.out.vtk/main.c:47 ../vector/v.net.flow/main.c:58
-#: ../vector/v.split/main.c:54 ../vector/v.edit/main.c:54
-#: ../vector/v.random/main.c:97 ../vector/v.profile/main.c:98
-#: ../vector/v.voronoi/main.c:123 ../vector/v.lrs/v.lrs.segment/main.c:71
-#: ../vector/v.lrs/v.lrs.label/main.c:102
-#: ../vector/v.lrs/v.lrs.create/main.c:121
-#: ../vector/v.lrs/v.lrs.where/main.c:57 ../vector/v.in.region/main.c:41
-#: ../vector/v.kernel/main.c:109 ../vector/v.to.rast3/main.c:48
-#: ../vector/v.out.ogr/main.c:81 ../vector/v.type/main.c:38
-#: ../vector/v.net.timetable/main.c:260 ../vector/v.label.sa/main.c:38
-#: ../vector/v.in.db/main.c:52 ../vector/v.in.dxf/main.c:64
-#: ../vector/v.sample/main.c:75 ../vector/v.build.polylines/main.c:110
-#: ../vector/v.class/main.c:45 ../vector/v.net.alloc/main.c:57
-#: ../vector/v.external/main.c:50 ../vector/v.in.ascii/main.c:70
-#: ../vector/v.to.3d/main.c:36 ../vector/v.univar/main.c:92
-#: ../vector/v.out.postgis/main.c:44 ../vector/v.qcount/main.c:60
-#: ../vector/v.out.lidar/main.c:471 ../vector/v.mkgrid/main.c:70
-#: ../vector/v.out.ascii/main.c:47 ../vector/v.lidar.growing/main.c:75
-#: ../vector/v.overlay/main.c:63 ../vector/v.in.ogr/main.c:135
-#: ../vector/v.net.allpairs/main.c:61 ../vector/v.decimate/main.c:123
-#: ../vector/v.parallel/main.c:49 ../vector/v.rectify/main.c:70
-#: ../vector/v.to.db/main.c:36 ../vector/v.build/main.c:36
-#: ../vector/v.kcv/main.c:55 ../vector/v.net.connectivity/main.c:52
-#: ../vector/v.vol.rst/main.c:235 ../vector/v.select/main.c:48
-#: ../vector/v.db.select/main.c:54 ../vector/v.to.points/main.c:53
-#: ../vector/v.clean/test/topocheck.c:42 ../vector/v.clean/main.c:51
-#: ../vector/v.lidar.edgedetection/main.c:75 ../vector/v.surf.bspline/main.c:91
-#: ../vector/v.external.out/main.c:43 ../vector/v.outlier/main.c:69
-#: ../vector/v.net.bridge/main.c:47 ../vector/v.net.path/main.c:42
-#: ../vector/v.drape/main.c:56 ../vector/v.perturb/main.c:62
-#: ../vector/v.info/main.c:37 ../vector/v.info/print.c:436
-#: ../vector/v.patch/main.c:69 ../vector/v.proj/main.c:68
-#: ../vector/v.net.steiner/main.c:346 ../vector/v.in.dwg/main.c:82
-#: ../vector/v.cluster/main.c:90 ../vector/v.delaunay/main.c:85
-#: ../vector/v.reclass/main.c:67 ../vector/v.neighbors/main.c:50
-#: ../vector/v.in.lidar/main.c:136 ../vector/v.net.centrality/main.c:96
-#: ../vector/v.out.svg/main.c:77 ../vector/v.net.visibility/main.c:45
-#: ../vector/v.generalize/main.c:76 ../vector/v.net.iso/main.c:72
-#: ../vector/v.support/main.c:39 ../vector/v.net/main.c:47
-#: ../vector/v.out.dxf/main.c:56 ../vector/v.to.rast/main.c:44
-#: ../vector/v.what.rast/main.c:71 ../vector/v.net.salesman/main.c:127
-#: ../vector/v.vect.stats/main.c:124 ../vector/v.transform/main.c:70
-#: ../vector/v.normal/main.c:72 ../vector/v.distance/main.c:121
-#: ../vector/v.hull/main.c:52 ../vector/v.db.connect/main.c:52
-#: ../vector/v.label/main.c:59 ../vector/v.colors/main.c:55
-#: ../vector/v.colors.out/main.c:49 ../vector/v.what/main.c:62
-#: ../vector/v.buffer/main.c:221 ../doc/vector/v.example/main.c:50
+#: ../locale/scriptstrings/t.vect.univar_to_translate.c:4
+#: ../locale/scriptstrings/v.report_to_translate.c:2
+#: ../locale/scriptstrings/t.vect.algebra_to_translate.c:4
+#: ../locale/scriptstrings/v.db.droptable_to_translate.c:2
+#: ../misc/m.nviz.script/main.c:73 ../misc/m.nviz.image/main.c:54
+#: ../doc/vector/v.example/main.c:50 ../visualization/ximgview/main.c:293
+#: ../display/d.extract/main.c:50 ../display/d.vect/main.c:75
+#: ../display/d.legend.vect/main.c:52
 msgid "vector"
 msgstr "vektors"
-#: ../misc/m.nviz.script/main.c:74 ../misc/m.nviz.image/main.c:51
-#: ../visualization/ximgview/main.c:294
-#: ../locale/scriptstrings/d.shade_to_translate.c:6
-#: ../locale/scriptstrings/r.shade_to_translate.c:6
-msgid "visualization"
-msgstr "vizualizācija"
+#: ../vector/v.segment/main.c:61 ../vector/v.clean/main.c:53
+#: ../vector/v.to.3d/main.c:37 ../vector/v.select/main.c:49
+#: ../vector/v.univar/main.c:96 ../vector/v.voronoi/main.c:124
+#: ../vector/v.build/main.c:38 ../vector/v.in.ogr/main.c:173
+#: ../vector/v.patch/main.c:70 ../vector/v.to.points/main.c:54
+#: ../vector/v.buffer/main.c:225 ../vector/v.build.polylines/main.c:112
+#: ../vector/v.hull/main.c:53 ../vector/v.edit/main.c:55
+#: ../vector/v.parallel/main.c:50 ../vector/v.perturb/main.c:63
+#: ../vector/v.type/main.c:39 ../vector/v.overlay/main.c:64
+#: ../vector/v.mkgrid/main.c:71 ../vector/v.split/main.c:55
+#: ../vector/v.transform/main.c:72 ../vector/v.in.region/main.c:42
+#: ../vector/v.delaunay/main.c:86 ../vector/v.drape/main.c:57
+#: ../vector/v.extrude/main.c:68 ../raster/r.patch/main.c:59
+#: ../raster/r.to.vect/main.c:78 ../raster/r.circle/main.c:53
+#: ../raster/r.thin/main.c:58
+#: ../locale/scriptstrings/v.to.lines_to_translate.c:3
+#: ../locale/scriptstrings/i.image.mosaic_to_translate.c:3
+#: ../locale/scriptstrings/v.report_to_translate.c:3
+msgid "geometry"
+msgstr ""
-#: ../misc/m.nviz.script/main.c:75
-msgid "Creates fly-through script to run in NVIZ."
+#: ../vector/v.segment/main.c:62 ../vector/v.to.points/main.c:57
+#: ../vector/v.build.polylines/main.c:114 ../vector/v.edit/main.c:58
+#: ../vector/v.split/main.c:57
+msgid "node"
+msgstr "mezgls"
+#: ../vector/v.segment/main.c:63 ../vector/v.category/main.c:679
+#: ../vector/v.to.points/main.c:59 ../vector/v.edit/main.c:59
+#: ../vector/v.type/main.c:43
+#: ../locale/scriptstrings/v.to.lines_to_translate.c:6
+#: ../locale/scriptstrings/v.in.lines_to_translate.c:5
+msgid "point"
+msgstr "punkts"
+#: ../vector/v.segment/main.c:64 ../vector/v.split/main.c:58
+msgid "segment"
 msgstr ""
-#: ../misc/m.nviz.script/main.c:80
-msgid "Name of output script"
-msgstr "Izvades skripta nosaukums"
+#: ../vector/v.segment/main.c:65 ../vector/v.to.points/main.c:58
+#: ../vector/v.build.polylines/main.c:115 ../vector/v.edit/main.c:60
+#: ../vector/v.split/main.c:59
+msgid "vertex"
+msgstr ""
-#: ../misc/m.nviz.script/main.c:86
-msgid "Prefix of output images (default = NVIZ)"
+#: ../vector/v.segment/main.c:67
+msgid "Creates points/segments from input vector lines and positions."
 msgstr ""
-#: ../misc/m.nviz.script/main.c:94
-msgid "Route coordinates (east,north)"
+#: ../vector/v.segment/main.c:70
+msgid "Name of input vector lines map"
 msgstr ""
-#: ../misc/m.nviz.script/main.c:100
-msgid "Camera layback distance (in map units)"
+#: ../vector/v.segment/main.c:79
+msgid "Name of file containing segment rules"
 msgstr ""
-#: ../misc/m.nviz.script/main.c:106
-msgid "Camera height above terrain"
-msgstr "Kameras augstums virs reljefa"
+#: ../vector/v.segment/main.c:80 ../vector/v.what/main.c:78
+#: ../vector/v.edit/args.c:95 ../raster/r.recode/main.c:61
+#: ../raster/r.reclass/main.c:66 ../raster/r.in.ascii/main.c:79
+#: ../locale/scriptstrings/m.proj_to_translate.c:8 ../general/g.proj/main.c:141
+#: ../general/g.proj/main.c:150 ../raster3d/r3.in.ascii/main.c:87
+#: ../db/db.select/main.c:208 ../db/db.execute/main.c:139
+msgid "'-' for standard input"
+msgstr ""
-#: ../misc/m.nviz.script/main.c:112
-msgid "Number of frames"
-msgstr "Kadru skaits"
+#: ../vector/v.segment/main.c:98 ../vector/v.net.path/path.c:49
+#: ../vector/v.lrs/v.lrs.segment/main.c:133 ../raster/r.in.mat/main.c:125
+#: ../raster/r.mapcalc/main.c:49 ../raster/r.in.xyz/main.c:582
+#: ../raster/r.support/main.c:176 ../raster/r.series/main.c:223
+#: ../raster/r.topmodel/file_io.c:28 ../raster/r.topmodel/file_io.c:136
+#: ../raster/r.topmodel/file_io.c:161 ../raster/r.series.accumulate/main.c:221
+#: ../general/g.cairocomp/main.c:46 ../raster3d/r3.support/main.c:167
+#: ../display/d.where/main.c:163 ../display/d.linegraph/main.c:415
+#: ../display/d.linegraph/main.c:432 ../display/d.linegraph/main.c:730
+#: ../display/d.legend.vect/main.c:259 ../display/d.legend.vect/main.c:273
+#: ../display/d.legend.vect/draw.c:72 ../display/d.text/main.c:380
+#, c-format
+msgid "Unable to open input file <%s>"
+msgstr ""
-#: ../misc/m.nviz.script/main.c:118
-msgid "Start frame number (default=0)"
+#: ../vector/v.segment/main.c:108 ../vector/v.clean/main.c:283
+#: ../vector/v.clean/test/topocheck.c:67 ../vector/v.clean/test/topocheck.c:87
+#: ../vector/v.to.3d/main.c:72 ../vector/v.select/main.c:108
+#: ../vector/v.surf.rst/main.c:561 ../vector/v.surf.rst/main.c:665
+#: ../vector/v.lidar.correction/main.c:161 ../vector/v.sample/main.c:124
+#: ../vector/v.univar/main.c:158 ../vector/v.profile/main.c:370
+#: ../vector/v.profile/main.c:394 ../vector/v.to.db/main.c:59
+#: ../vector/v.surf.idw/read_sites.c:29 ../vector/v.db.connect/main.c:154
+#: ../vector/v.net.allpairs/main.c:130 ../vector/v.voronoi/main.c:196
+#: ../vector/v.class/main.c:102 ../vector/v.cluster/main.c:149
+#: ../vector/v.build/main.c:118 ../vector/v.build/main.c:128
+#: ../vector/v.lidar.growing/main.c:138 ../vector/v.lidar.growing/main.c:142
+#: ../vector/v.label/main.c:268 ../vector/v.reclass/main.c:113
+#: ../vector/v.net.steiner/main.c:432 ../vector/v.normal/main.c:110
+#: ../vector/v.extract/main.c:191 ../vector/v.out.ogr/main.c:135
+#: ../vector/v.patch/main.c:129 ../vector/v.patch/main.c:147
+#: ../vector/v.patch/main.c:177 ../vector/v.patch/main.c:274
+#: ../vector/v.patch/main.c:355 ../vector/v.vol.rst/main.c:560
+#: ../vector/v.vect.stats/main.c:267 ../vector/v.vect.stats/main.c:278
+#: ../vector/v.qcount/main.c:101 ../vector/v.to.points/main.c:130
+#: ../vector/v.buffer/main.c:337 ../vector/v.build.polylines/main.c:151
+#: ../vector/v.external/main.c:228 ../vector/v.net/main.c:68
+#: ../vector/v.net/main.c:92 ../vector/v.kernel/main.c:318
+#: ../vector/v.kernel/main.c:331 ../vector/v.hull/main.c:87
+#: ../vector/v.generalize/main.c:325 ../vector/v.out.lidar/main.c:609
+#: ../vector/v.out.svg/main.c:139 ../vector/v.neighbors/main.c:88
+#: ../vector/v.net.alloc/main.c:185 ../vector/v.out.pov/main.c:97
+#: ../vector/v.net.components/main.c:148 ../vector/v.net.iso/main.c:243
+#: ../vector/v.out.postgis/main.c:100 ../vector/v.distance/main.c:364
+#: ../vector/v.distance/main.c:386 ../vector/v.net.bridge/main.c:118
+#: ../vector/v.edit/main.c:170 ../vector/v.edit/main.c:243
+#: ../vector/v.parallel/main.c:148 ../vector/v.perturb/main.c:148
+#: ../vector/v.perturb/main.c:173 ../vector/v.out.ascii/main.c:87
+#: ../vector/v.out.ascii/main.c:94 ../vector/v.type/main.c:131
+#: ../vector/v.net.flow/main.c:143 ../vector/v.overlay/main.c:188
+#: ../vector/v.db.select/main.c:164 ../vector/v.lidar.edgedetection/main.c:186
+#: ../vector/v.what.rast/main.c:131 ../vector/v.net.path/main.c:158
+#: ../vector/v.net.visibility/main.c:73 ../vector/v.net.visibility/main.c:82
+#: ../vector/v.net.connectivity/main.c:130
+#: ../vector/v.lrs/v.lrs.label/main.c:272
+#: ../vector/v.lrs/v.lrs.where/main.c:131
+#: ../vector/v.lrs/v.lrs.where/main.c:140
+#: ../vector/v.lrs/v.lrs.create/main.c:254
+#: ../vector/v.lrs/v.lrs.create/main.c:263
+#: ../vector/v.lrs/v.lrs.segment/main.c:144
+#: ../vector/v.net.timetable/main.c:353 ../vector/v.rectify/main.c:150
+#: ../vector/v.proj/main.c:237 ../vector/v.split/main.c:172
+#: ../vector/v.to.rast/vect2rast.c:39 ../vector/v.to.rast/support.c:100
+#: ../vector/v.to.rast/support.c:272 ../vector/v.to.rast/support.c:510
+#: ../vector/v.net.distance/main.c:192 ../vector/v.net.spanningtree/main.c:101
+#: ../vector/v.transform/main.c:197 ../vector/v.support/main.c:134
+#: ../vector/v.random/main.c:201 ../vector/v.what.rast3/main.c:114
+#: ../vector/v.colors/main.c:262 ../vector/v.out.dxf/main.c:80
+#: ../vector/v.net.salesman/main.c:250 ../vector/v.info/main.c:61
+#: ../vector/v.label.sa/labels.c:58 ../vector/v.to.rast3/main.c:73
+#: ../vector/v.colors.out/make_colors.c:23
+#: ../vector/v.colors.out/scan_cats.c:20 ../vector/v.delaunay/main.c:120
+#: ../vector/v.net.centrality/main.c:209 ../vector/v.drape/main.c:143
+#: ../vector/v.decimate/main.c:272 ../vector/v.extrude/main.c:190
+#: ../raster/r.region/main.c:176 ../raster/r.walk/main.c:673
+#: ../raster/r.walk/main.c:742 ../raster/r.what/main.c:250
+#: ../raster/r.drain/main.c:271 ../raster/r.random/support.c:67
+#: ../raster/r.cost/main.c:533 ../raster/r.cost/main.c:606
+#: ../raster/r.sim/simlib/observation_points.c:41 ../raster/r.carve/main.c:162
+#: ../general/g.region/main.c:489 ../general/manage/lister/vector.c:32
+#: ../misc/m.nviz.image/vector.c:280 ../raster3d/r3.flow/main.c:411
+#: ../doc/vector/v.example/main.c:87 ../display/d.vect.chart/main.c:246
+#: ../display/d.extract/main.c:103 ../display/d.path/main.c:185
+#, c-format
+msgid "Unable to open vector map <%s>"
 msgstr ""
-#: ../misc/m.nviz.script/main.c:123
-msgid "Full render -- Save images"
+#: ../vector/v.segment/main.c:114 ../vector/v.clean/main.c:288
+#: ../vector/v.clean/main.c:295 ../vector/v.to.3d/main.c:87
+#: ../vector/v.select/main.c:125 ../vector/v.surf.rst/main.c:600
+#: ../vector/v.surf.rst/main.c:603 ../vector/v.surf.rst/main.c:769
+#: ../vector/v.lidar.correction/main.c:215
+#: ../vector/v.lidar.correction/main.c:221 ../vector/v.sample/main.c:162
+#: ../vector/v.in.ascii/main.c:251 ../vector/v.profile/main.c:537
+#: ../vector/v.net.allpairs/main.c:136 ../vector/v.voronoi/main.c:215
+#: ../vector/v.cluster/main.c:209 ../vector/v.in.dwg/main.c:200
+#: ../vector/v.build/main.c:154 ../vector/v.in.ogr/main.c:818
+#: ../vector/v.reclass/main.c:117 ../vector/v.net.steiner/main.c:607
+#: ../vector/v.extract/main.c:346 ../vector/v.patch/main.c:283
+#: ../vector/v.patch/main.c:288 ../vector/v.vol.rst/main.c:580
+#: ../vector/v.vol.rst/main.c:583 ../vector/v.in.lidar/main.c:555
+#: ../vector/v.qcount/main.c:127 ../vector/v.to.points/main.c:138
+#: ../vector/v.buffer/main.c:405 ../vector/v.build.polylines/main.c:156
+#: ../vector/v.external/main.c:180 ../vector/v.kernel/main.c:337
+#: ../vector/v.outlier/main.c:229 ../vector/v.outlier/main.c:234
+#: ../vector/v.outlier/main.c:240 ../vector/v.hull/main.c:121
+#: ../vector/v.generalize/main.c:336 ../vector/v.in.db/main.c:151
+#: ../vector/v.net.alloc/main.c:298 ../vector/v.net.components/main.c:154
+#: ../vector/v.net.iso/main.c:356 ../vector/v.distance/main.c:410
+#: ../vector/v.net.bridge/main.c:124 ../vector/v.edit/main.c:107
+#: ../vector/v.edit/main.c:122 ../vector/v.parallel/main.c:153
+#: ../vector/v.perturb/main.c:154 ../vector/v.net.flow/main.c:149
+#: ../vector/v.net.flow/main.c:155 ../vector/v.overlay/main.c:220
+#: ../vector/v.surf.bspline/main.c:353
+#: ../vector/v.lidar.edgedetection/main.c:251 ../vector/v.net.path/main.c:167
+#: ../vector/v.net.visibility/main.c:77 ../vector/v.mkgrid/main.c:264
+#: ../vector/v.net.connectivity/main.c:136
+#: ../vector/v.lrs/v.lrs.label/main.c:276
+#: ../vector/v.lrs/v.lrs.create/main.c:267
+#: ../vector/v.lrs/v.lrs.create/main.c:273
+#: ../vector/v.lrs/v.lrs.segment/main.c:148
+#: ../vector/v.net.timetable/main.c:359 ../vector/v.rectify/main.c:216
+#: ../vector/v.proj/main.c:380 ../vector/v.split/main.c:177
+#: ../vector/v.net.distance/main.c:198 ../vector/v.net.spanningtree/main.c:107
+#: ../vector/v.transform/main.c:265 ../vector/v.random/main.c:229
+#: ../vector/v.net.salesman/main.c:551 ../vector/v.in.dxf/main.c:146
+#: ../vector/v.in.region/main.c:75 ../vector/v.delaunay/main.c:126
+#: ../vector/v.net.centrality/main.c:215 ../vector/v.drape/main.c:158
+#: ../vector/v.decimate/main.c:391 ../vector/v.extrude/main.c:196
+#: ../raster/r.stream.extract/close.c:38 ../raster/r.volume/main.c:155
+#: ../raster/r.to.vect/main.c:157 ../raster/r.drain/main.c:200
+#: ../raster/r.resamp.bspline/main.c:495 ../raster/r.contour/main.c:156
+#: ../raster/r.random/random.c:63 ../raster/r.flow/io.c:178
+#: ../raster/r.sim/simlib/output.c:38 ../raster/r.sim/simlib/output.c:44
+#: ../raster/r.carve/vect.c:32 ../raster3d/r3.flow/main.c:396
+#: ../doc/vector/v.example/main.c:98 ../display/d.extract/main.c:106
+#: ../scripts/v.what.strds/v.what.strds.py:217
+#, c-format, python-format
+msgid "Unable to create vector map <%s>"
 msgstr ""
-#: ../misc/m.nviz.script/main.c:127
-msgid "Fly at constant elevation (ht)"
+#: ../vector/v.segment/main.c:146 ../vector/v.segment/main.c:190
+#, c-format
+msgid "Unable to read input: %s"
 msgstr ""
-#: ../misc/m.nviz.script/main.c:132
-msgid "Include command in the script to output a KeyFrame file"
+#: ../vector/v.segment/main.c:157 ../vector/v.segment/main.c:201
+#, c-format
+msgid "Unable to find line of cat %d"
 msgstr ""
-#: ../misc/m.nviz.script/main.c:136
-msgid "Render images off-screen"
+#: ../vector/v.segment/main.c:172
+#, c-format
+msgid ""
+"Unable to get point on line: cat = %d offset = %f (line length = %.15g)\n"
+"%s"
 msgstr ""
-#: ../misc/m.nviz.script/main.c:140
-msgid "Enable vector and sites drawing"
+#: ../vector/v.segment/main.c:226
+msgid "End of segment > line length -> cut"
 msgstr ""
-#: ../misc/m.nviz.script/main.c:148
-msgid "Either -i flag and/or route parameter must be used"
+#: ../vector/v.segment/main.c:232
+#, c-format
+msgid ""
+"Unable to make line segment: cat = %d : %f - %f (line length = %.15g)\n"
+"%s"
 msgstr ""
-#: ../misc/m.nviz.script/main.c:172
-msgid "Off-screen only available with full render mode"
+#: ../vector/v.segment/main.c:256 ../vector/v.lrs/v.lrs.segment/main.c:337
+#, c-format
+msgid "Incorrect segment type: %s"
 msgstr ""
-#: ../misc/m.nviz.script/main.c:202 ../misc/m.transform/main.c:276
-#: ../general/g.pnmcomp/main.c:242 ../general/g.pnmcomp/main.c:259
-#: ../raster/r.category/main.c:173 ../raster/r.out.ascii/main.c:157
-#: ../raster/r.horizon/main.c:385 ../raster/r.recode/main.c:90
-#: ../raster/r.out.ppm3/main.c:133 ../raster/r.profile/main.c:175
-#: ../raster/r.in.lidar/main.c:644 ../display/d.mon/stop.c:66
-#: ../vector/v.out.vtk/main.c:173 ../vector/v.edit/main.c:79
-#: ../vector/v.profile/main.c:254 ../vector/v.out.ascii/main.c:125
-#: ../vector/v.net/main.c:100
-#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:348
+#: ../vector/v.segment/main.c:263
 #, c-format
-msgid "Unable to open file <%s>"
-msgstr "Nebija iespējams atvērt failu <%s>"
+msgid "%d point read from input"
+msgid_plural "%d points read from input"
+msgstr[0] ""
+msgstr[1] ""
+msgstr[2] ""
-#: ../misc/m.nviz.script/main.c:250
+#. GTC Number of lost points
+#. GTC Number of lost lines
+#: ../vector/v.segment/main.c:267 ../vector/v.segment/main.c:278
+#: ../vector/v.lrs/v.lrs.segment/main.c:360
+#: ../vector/v.lrs/v.lrs.segment/main.c:372
 #, c-format
-msgid "You must provide at least four points %d"
-msgstr "Ir jāievada kā minimums četri punkti %d"
+msgid "%d lost"
+msgid_plural "%d lost"
+msgstr[0] ""
+msgstr[1] ""
+msgstr[2] ""
-#: ../misc/m.nviz.script/main.c:324
+#. GTC %s is replaced with message indicating number of lost points.
+#: ../vector/v.segment/main.c:269
 #, c-format
-msgid "Created NVIZ script <%s>."
-msgstr ""
+msgid "%d point written to output map (%s)"
+msgid_plural "%d points written to output map (%s)"
+msgstr[0] ""
+msgstr[1] ""
+msgstr[2] ""
-#: ../misc/m.nviz.script/main.c:439
-msgid "Skipping this point, selected point is outside region. Perhaps the camera setback distance puts it beyond the edge?"
-msgstr ""
+#: ../vector/v.segment/main.c:274
+#, c-format
+msgid "%d line read from input"
+msgid_plural "%d lines read from input"
+msgstr[0] ""
+msgstr[1] ""
+msgstr[2] ""
-#: ../misc/m.transform/main.c:92
+#. GTC %s is replaced with message indicating number of lost lines.
+#: ../vector/v.segment/main.c:280
 #, c-format
-msgid "Not enough points, %d are required"
-msgstr ""
+msgid "%d line written to output map (%s)"
+msgid_plural "%d lines written to output map (%s)"
+msgstr[0] ""
+msgstr[1] ""
+msgstr[2] ""
-#: ../misc/m.transform/main.c:96
-#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:93
-#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:136
+#: ../vector/v.clean/rmdac.c:60
 #, c-format
-msgid "Error conducting transform (%d)"
+msgid "Duplicate area centroids: %d"
 msgstr ""
-#: ../misc/m.transform/main.c:194
-msgid "Poorly placed control points"
+#: ../vector/v.clean/main.c:52 ../vector/v.build/main.c:37
+#: ../vector/v.in.ogr/main.c:172 ../vector/v.build.polylines/main.c:111
+#: ../vector/v.out.postgis/main.c:48 ../vector/v.info/main.c:39
+#: ../locale/scriptstrings/v.build.all_to_translate.c:3
+#: ../locale/scriptstrings/t.topology_to_translate.c:3
+msgid "topology"
 msgstr ""
-#: ../misc/m.transform/main.c:196
-#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:255
-msgid "Insufficient memory"
+#: ../vector/v.clean/main.c:54 ../vector/v.in.ogr/main.c:174
+#: ../locale/scriptstrings/t.snap_to_translate.c:4
+msgid "snapping"
 msgstr ""
-#: ../misc/m.transform/main.c:198
-#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:257
-msgid "Parameter error"
+#: ../vector/v.clean/main.c:55
+msgid "Toolset for cleaning topology of vector map."
 msgstr ""
-#: ../misc/m.transform/main.c:200
-#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:259
-msgid "No active control points"
-msgstr ""
+#: ../vector/v.clean/main.c:61 ../vector/v.clean/main.c:64
+#: ../vector/v.to.3d/args.c:19 ../vector/v.to.3d/args.c:25
+#: ../vector/v.select/args.c:18 ../vector/v.select/args.c:24
+#: ../vector/v.select/args.c:33 ../vector/v.select/args.c:39
+#: ../vector/v.select/args.c:106 ../vector/v.surf.rst/main.c:178
+#: ../vector/v.surf.rst/main.c:190 ../vector/v.profile/main.c:165
+#: ../vector/v.profile/main.c:168 ../vector/v.profile/main.c:173
+#: ../vector/v.to.db/parse.c:45 ../vector/v.net.allpairs/main.c:75
+#: ../vector/v.net.allpairs/main.c:81 ../vector/v.net.allpairs/main.c:84
+#: ../vector/v.net.allpairs/main.c:87 ../vector/v.in.ogr/main.c:212
+#: ../vector/v.in.ogr/main.c:217 ../vector/v.in.ogr/main.c:226
+#: ../vector/v.in.ogr/main.c:242 ../vector/v.in.ogr/main.c:290
+#: ../vector/v.in.ogr/main.c:335 ../vector/v.reclass/main.c:77
+#: ../vector/v.reclass/main.c:82 ../vector/v.category/main.c:85
+#: ../vector/v.category/main.c:89 ../vector/v.category/main.c:93
+#: ../vector/v.extract/main.c:98 ../vector/v.extract/main.c:103
+#: ../vector/v.extract/main.c:109 ../vector/v.extract/main.c:112
+#: ../vector/v.extract/main.c:115 ../vector/v.extract/main.c:125
+#: ../vector/v.extract/main.c:135 ../vector/v.out.ogr/args.c:12
+#: ../vector/v.out.ogr/args.c:22 ../vector/v.out.ogr/args.c:102
+#: ../vector/v.in.lidar/main.c:187 ../vector/v.in.lidar/main.c:197
+#: ../vector/v.in.lidar/main.c:206 ../vector/v.in.lidar/main.c:216
+#: ../vector/v.in.lidar/main.c:223 ../vector/v.in.lidar/main.c:228
+#: ../vector/v.in.lidar/main.c:283 ../vector/v.in.lidar/main.c:289
+#: ../vector/v.in.lidar/main.c:297 ../vector/v.vect.stats/main.c:157
+#: ../vector/v.vect.stats/main.c:162 ../vector/v.vect.stats/main.c:167
+#: ../vector/v.vect.stats/main.c:172 ../vector/v.vect.stats/main.c:177
+#: ../vector/v.vect.stats/main.c:182 ../vector/v.to.points/main.c:67
+#: ../vector/v.to.points/main.c:71 ../vector/v.buffer/main.c:235
+#: ../vector/v.buffer/main.c:238 ../vector/v.buffer/main.c:241
+#: ../vector/v.buffer/main.c:246 ../vector/v.generalize/main.c:92
+#: ../vector/v.generalize/main.c:231 ../vector/v.generalize/main.c:234
+#: ../vector/v.out.lidar/main.c:487 ../vector/v.out.lidar/main.c:491
+#: ../vector/v.out.lidar/main.c:588 ../vector/v.in.db/main.c:94
+#: ../vector/v.out.postgis/args.c:15 ../vector/v.out.postgis/args.c:19
+#: ../vector/v.edit/args.c:24 ../vector/v.edit/args.c:29
+#: ../vector/v.edit/args.c:118 ../vector/v.edit/args.c:122
+#: ../vector/v.edit/args.c:131 ../vector/v.edit/args.c:140
+#: ../vector/v.edit/args.c:149 ../vector/v.edit/args.c:152
+#: ../vector/v.edit/args.c:170 ../vector/v.edit/args.c:205
+#: ../vector/v.out.ascii/args.c:24 ../vector/v.out.ascii/args.c:28
+#: ../vector/v.out.ascii/args.c:43 ../vector/v.out.ascii/args.c:46
+#: ../vector/v.db.select/main.c:64 ../vector/v.db.select/main.c:67
+#: ../vector/v.db.select/main.c:70 ../vector/v.db.select/main.c:76
+#: ../vector/v.db.select/main.c:116 ../vector/v.to.rast/main.c:57
+#: ../vector/v.to.rast/main.c:60 ../vector/v.to.rast/main.c:63
+#: ../vector/v.random/main.c:119 ../vector/v.random/main.c:122
+#: ../vector/v.random/main.c:125 ../vector/v.random/main.c:128
+#: ../vector/v.net.centrality/main.c:121 ../vector/v.net.centrality/main.c:123
+#: ../vector/v.drape/main.c:67 ../vector/v.drape/main.c:70
+#: ../vector/v.drape/main.c:73 ../vector/v.drape/main.c:78
+#: ../vector/v.decimate/main.c:149 ../vector/v.decimate/main.c:152
+#: ../vector/v.extrude/main.c:84 ../vector/v.extrude/main.c:87
+#: ../vector/v.extrude/main.c:90 ../vector/v.extrude/main.c:95
+#: ../raster/r.in.lidar/main.c:193 ../raster/r.in.lidar/main.c:209
+#: ../raster/r.in.lidar/main.c:262 ../raster/r.in.lidar/main.c:272
+#: ../raster/r.in.lidar/main.c:341 ../raster/r.category/main.c:62
+#: ../raster/r.category/main.c:71
+#: ../locale/scriptstrings/t.vect.list_to_translate.c:10
+#: ../locale/scriptstrings/t.vect.list_to_translate.c:11
+#: ../locale/scriptstrings/t.rast3d.univar_to_translate.c:7
+#: ../locale/scriptstrings/t.rast3d.list_to_translate.c:10
+#: ../locale/scriptstrings/t.rast3d.list_to_translate.c:11
+#: ../locale/scriptstrings/t.rast.univar_to_translate.c:6
+#: ../locale/scriptstrings/t.rast.list_to_translate.c:10
+#: ../locale/scriptstrings/t.rast.list_to_translate.c:11
+#: ../locale/scriptstrings/t.list_to_translate.c:7
+#: ../locale/scriptstrings/t.list_to_translate.c:8
+#: ../locale/scriptstrings/t.list_to_translate.c:14
+#: ../locale/scriptstrings/t.list_to_translate.c:15
+#: ../locale/scriptstrings/t.vect.univar_to_translate.c:6
+#: ../locale/scriptstrings/t.vect.univar_to_translate.c:7
+#: ../locale/scriptstrings/v.report_to_translate.c:5
+#: ../raster3d/r3.in.lidar/main.c:232 ../raster3d/r3.in.lidar/main.c:242
+#: ../raster3d/r3.in.lidar/main.c:272 ../raster3d/r3.in.lidar/main.c:288
+#: ../display/d.vect.chart/main.c:74 ../display/d.vect.chart/main.c:77
+#: ../display/d.vect.thematic/main.c:98 ../display/d.vect.thematic/main.c:148
+#: ../display/d.vect/main.c:84 ../display/d.vect/main.c:109
+#: ../display/d.vect/main.c:112 ../display/d.vect/main.c:115
+#: ../display/d.vect/main.c:317 ../display/d.rast/main.c:70
+#: ../display/d.rast/main.c:87
+msgid "Selection"
+msgstr "Izvēle"
-#: ../misc/m.transform/main.c:295
-#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:367
-#, c-format
-msgid "Invalid coordinates: [%s]"
+#: ../vector/v.clean/main.c:70
+msgid "Name of output map where errors are written"
 msgstr ""
-#: ../misc/m.transform/main.c:317
-#: ../locale/scriptstrings/i.tasscap_to_translate.c:3
-#: ../locale/scriptstrings/m.proj_to_translate.c:4 ../raster/r.proj/main.c:146
-#: ../vector/v.proj/main.c:70 ../vector/v.transform/main.c:71
-#: ../imagery/i.pca/main.c:73
-#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:390
-#: ../imagery/i.ifft/main.c:78 ../imagery/i.fft/main.c:79
-msgid "transformation"
-msgstr ""
+#: ../vector/v.clean/main.c:81
+msgid "Cleaning tool"
+msgstr "Tīrīšanas rīks"
-#: ../misc/m.transform/main.c:320
-#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:393
-msgid "Computes a coordinate transformation based on the control points."
+#: ../vector/v.clean/main.c:97
+msgid "break lines at each intersection"
 msgstr ""
-#: ../misc/m.transform/main.c:330
-msgid "Rectification polynomial order"
+#: ../vector/v.clean/main.c:98
+msgid "remove duplicate geometry features (pay attention to categories!)"
 msgstr ""
-#: ../misc/m.transform/main.c:341
-#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:406
-msgid "point index"
+#: ../vector/v.clean/main.c:99
+msgid "remove dangles, threshold ignored if < 0"
 msgstr ""
-#: ../misc/m.transform/main.c:342
-#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:407
-msgid "source coordinates"
+#: ../vector/v.clean/main.c:100
+msgid ""
+"change the type of boundary dangle to line, threshold ignored if < 0, input "
+"line type is ignored"
 msgstr ""
-#: ../misc/m.transform/main.c:343
-#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:408
-msgid "destination coordinates"
+#: ../vector/v.clean/main.c:102
+msgid "remove bridges connecting area and island or 2 islands"
 msgstr ""
-#: ../misc/m.transform/main.c:344
-#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:409
-msgid "forward coordinates (destination)"
+#: ../vector/v.clean/main.c:103
+msgid ""
+"change the type of bridges connecting area and island or 2 islands from "
+"boundary to line"
 msgstr ""
-#: ../misc/m.transform/main.c:345
-#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:410
-msgid "reverse coordinates (source)"
+#: ../vector/v.clean/main.c:105
+msgid "snap lines to vertex in threshold"
 msgstr ""
-#: ../misc/m.transform/main.c:346
-#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:411
-msgid "forward coordinates difference (destination)"
+#: ../vector/v.clean/main.c:106
+msgid "remove duplicate area centroids ('type' option ignored)"
 msgstr ""
-#: ../misc/m.transform/main.c:347
-#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:412
-msgid "reverse coordinates difference (source)"
+#: ../vector/v.clean/main.c:107
+msgid ""
+"break (topologically clean) polygons (imported from non topological format, "
+"like ShapeFile). Boundaries are broken on each point shared between 2 and "
+"more polygons where angles of segments are different"
 msgstr ""
-#: ../misc/m.transform/main.c:348
-#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:413
-msgid "forward error (destination)"
+#: ../vector/v.clean/main.c:110
+msgid ""
+"remove vertices in threshold from lines and boundaries, boundary is pruned "
+"only if topology is not damaged (new intersection, changed attachment of "
+"centroid), first and last segment of the boundary is never changed"
 msgstr ""
-#: ../misc/m.transform/main.c:349
-#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:414
-msgid "reverse error (source)"
+#: ../vector/v.clean/main.c:114
+msgid "remove small areas, the longest boundary with adjacent area is removed"
 msgstr ""
-#: ../misc/m.transform/main.c:352 ../vector/v.out.ascii/args.c:55
-#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:417
-msgid "Output format"
+#: ../vector/v.clean/main.c:115
+msgid "remove all lines or boundaries of zero length, threshold is ignored"
 msgstr ""
-#: ../misc/m.transform/main.c:356
-#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:421
-msgid "Display summary information"
+#: ../vector/v.clean/main.c:116
+msgid "remove small angles between lines at nodes"
 msgstr ""
-#: ../misc/m.transform/main.c:361
-#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:427
-msgid "File containing coordinates to transform (\"-\" to read from stdin)"
+#: ../vector/v.clean/main.c:124
+msgid "Threshold in map units, one value for each tool"
 msgstr ""
-#: ../misc/m.transform/main.c:362
-#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:428
-msgid "Local x,y coordinates to target east,north"
+#: ../vector/v.clean/main.c:125
+msgid "Default: 0.0[,0.0,...])"
 msgstr ""
-#: ../misc/m.transform/main.c:366
-#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:432
-msgid "Reverse transform of coords file or coeff. dump"
+#: ../vector/v.clean/main.c:130
+msgid "Do not build topology for the output vector"
 msgstr ""
-#: ../misc/m.transform/main.c:367
-#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:433
-msgid "Target east,north coordinates to local x,y"
+#: ../vector/v.clean/main.c:135
+msgid "Combine tools with recommended follow-up tools"
 msgstr ""
-#: ../misc/m.transform/main.c:371
-#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:437
-msgid "Display transform matrix coefficients"
-msgstr ""
+#: ../vector/v.clean/main.c:156
+msgid "You must select at least one tool"
+msgstr "Jums ir jāizvēlas vismaz viens rīks"
-#: ../misc/m.measure/main.c:45
-msgid "Measures the lengths and areas of features."
+#: ../vector/v.clean/main.c:191
+msgid "Tool doesn't exist"
+msgstr "Rīks neeksistē"
+#: ../vector/v.clean/main.c:202
+msgid ""
+"Note: In latitude-longitude coordinate system specify threshold in degree "
+"unit"
 msgstr ""
-#: ../misc/m.measure/main.c:47
-msgid "measurement"
+#: ../vector/v.clean/main.c:215
+#, c-format
+msgid "Threshold for tool %d may not be > 0, set to 0"
 msgstr ""
-#: ../misc/m.measure/main.c:48 ../misc/m.cogo/main.c:226
-#: ../locale/scriptstrings/r.grow_to_translate.c:3
-#: ../raster/r.distance/main.c:40 ../raster/r.grow.distance/main.c:151
-#: ../display/d.geodesic/main.c:47 ../display/d.rhumbline/main.c:45
-#: ../vector/v.distance/main.c:122
-msgid "distance"
-msgstr "attālums"
+#: ../vector/v.clean/main.c:224
+msgid "Tool: Threshold"
+msgstr "Rīks: pielaide"
-#: ../misc/m.measure/main.c:49
-#: ../locale/scriptstrings/v.to.lines_to_translate.c:4
-#: ../locale/scriptstrings/v.dissolve_to_translate.c:4
-#: ../locale/scriptstrings/v.centroids_to_translate.c:4
-#: ../vector/v.category/main.c:695 ../vector/v.type/main.c:41
-#: ../vector/v.buffer/main.c:223
-msgid "area"
+#: ../vector/v.clean/main.c:229
+msgid "Break"
 msgstr ""
-#: ../misc/m.measure/main.c:56
-msgid "Units"
-msgstr "Vienības"
+#: ../vector/v.clean/main.c:232
+msgid "Remove duplicates"
+msgstr ""
-#: ../misc/m.measure/main.c:57
-msgid "Default: location map units"
+#: ../vector/v.clean/main.c:235
+msgid "Remove dangles"
 msgstr ""
-#: ../misc/m.measure/main.c:61
-msgid "Shell script style"
+#: ../vector/v.clean/main.c:238
+msgid "Change type of boundary dangles"
 msgstr ""
-#: ../misc/m.measure/main.c:104
-msgid "Length:"
-msgstr "Garums:"
+#: ../vector/v.clean/main.c:242
+msgid "Remove bridges"
+msgstr ""
-#: ../misc/m.measure/main.c:115
-msgid "Area:"
-msgstr "Platība:"
+#: ../vector/v.clean/main.c:245
+msgid "Change type of boundary bridges"
+msgstr ""
-#: ../misc/m.cogo/main.c:227
-msgid "polar"
+#: ../vector/v.clean/main.c:249
+msgid "Snap vertices"
 msgstr ""
-#: ../misc/m.cogo/main.c:228
-msgid "A simple utility for converting bearing and distance measurements to coordinates and vice versa."
+#: ../vector/v.clean/main.c:252
+msgid "Remove duplicate area centroids"
 msgstr ""
-#: ../misc/m.cogo/main.c:230
-msgid "It assumes a cartesian coordinate system"
+#: ../vector/v.clean/main.c:256
+msgid "Break polygons"
 msgstr ""
-#: ../misc/m.cogo/main.c:234
-msgid "Lines are labelled"
+#: ../vector/v.clean/main.c:259
+msgid "Prune"
 msgstr ""
-#: ../misc/m.cogo/main.c:239
-msgid "Convert from coordinates to bearing and distance"
+#: ../vector/v.clean/main.c:262
+msgid "Remove small areas"
 msgstr ""
-#: ../misc/m.cogo/main.c:244
-msgid "Repeat the starting coordinate at the end to close a loop"
+#: ../vector/v.clean/main.c:265
+msgid "Remove small angles at nodes"
 msgstr ""
-#: ../misc/m.cogo/main.c:255
-msgid "Starting coordinate pair"
+#: ../vector/v.clean/main.c:270
+msgid "Remove all lines or boundaries of zero length"
 msgstr ""
-#: ../misc/m.cogo/main.c:265
-#, c-format
-msgid "Couldn't open COGO file <%s>"
+#: ../vector/v.clean/main.c:314
+msgid "Topological cleaning works best with native GRASS vector format"
 msgstr ""
-#: ../misc/m.cogo/main.c:274
-#, c-format
-msgid "Couldn't open output file <%s>"
+#: ../vector/v.clean/main.c:325
+msgid "Failed to copy attribute table to output vector map"
 msgstr ""
-#: ../misc/m.cogo/main.c:301 ../misc/m.cogo/main.c:304
-msgid "Converting starting coordinate pair"
+#: ../vector/v.clean/main.c:340 ../vector/v.clean/main.c:351
+msgid "Rebuilding parts of topology..."
 msgstr ""
-#: ../misc/m.cogo/main.c:319
-#, c-format
-msgid "Input parse error on line %lu"
+#: ../vector/v.clean/main.c:360 ../vector/v.clean/main.c:405
+#: ../vector/v.clean/main.c:456
+msgid "Tool: Split lines"
+msgstr "Rīks: sadalīt līnijas"
+#: ../vector/v.clean/main.c:363 ../vector/v.clean/main.c:409
+#: ../vector/v.clean/main.c:462
+msgid "Tool: Break lines at intersections"
 msgstr ""
-#: ../misc/m.nviz.image/surface.c:50 ../misc/m.nviz.image/surface.c:107
-#: ../general/g.region/main.c:428 ../general/g.region/main.c:765
-#: ../general/g.region/main.c:773 ../raster/r.reclass/main.c:79
-#: ../raster/r.univar/r.univar_main.c:234 ../raster/r.flow/io.c:65
-#: ../raster/r.flow/io.c:242 ../raster/r.buffer/main.c:112
-#: ../raster/r.report/parse.c:273 ../raster/r.category/main.c:119
-#: ../raster/r.category/main.c:140 ../raster/r.distance/parse.c:72
-#: ../raster/r.distance/parse.c:81 ../raster/r.cross/main.c:106
-#: ../raster/r.tile/main.c:86 ../raster/r.spread/main.c:439
-#: ../raster/r.spread/main.c:442 ../raster/r.spread/main.c:445
-#: ../raster/r.spread/main.c:449 ../raster/r.spread/main.c:452
-#: ../raster/r.spread/main.c:455 ../raster/r.walk/main.c:435
-#: ../raster/r.walk/main.c:440 ../raster/r.walk/main.c:801
-#: ../raster/r.cost/main.c:350 ../raster/r.cost/main.c:665
-#: ../raster/r.sim/simlib/output.c:363 ../raster/r.sim/simlib/output.c:372
-#: ../raster/r.sim/simlib/output.c:403 ../raster/r.sim/simlib/output.c:412
-#: ../raster/r.sim/simlib/output.c:458 ../raster/r.sim/simlib/output.c:475
-#: ../raster/r.sim/simlib/output.c:497 ../raster/r.sim/simlib/output.c:541
-#: ../raster/r.sim/simlib/output.c:583 ../raster/r.sim/simlib/output.c:755
-#: ../raster/r.stream.extract/main.c:174 ../raster/r.stream.extract/main.c:178
-#: ../raster/r.stream.extract/main.c:183 ../raster/r.info/main.c:104
-#: ../raster/r.null/main.c:128 ../raster/r.kappa/stats.c:33
-#: ../raster/r.kappa/stats.c:38 ../raster/r.kappa/main.c:150
-#: ../raster/r.ros/main.c:368 ../raster/r.ros/main.c:379
-#: ../raster/r.ros/main.c:384 ../raster/r.ros/main.c:389
-#: ../raster/r.ros/main.c:394 ../raster/r.ros/main.c:408
-#: ../raster/r.ros/main.c:412 ../raster/r.ros/main.c:427
-#: ../raster/r.ros/main.c:431 ../raster/r.ros/main.c:442
-#: ../raster/r.colors/edit_colors.c:393 ../raster/r.mapcalc/map.c:517
-#: ../raster/r.compress/main.c:124 ../raster/r.compress/main.c:304
-#: ../raster/r.coin/main.c:121 ../raster/r.coin/main.c:123
-#: ../raster/r.carve/main.c:165 ../vector/v.vol.rst/main.c:615
-#: ../vector/v.colors/main.c:312 ../imagery/i.pca/main.c:139
-#: ../imagery/i.ortho.photo/i.ortho.elev/main.c:155
-#: ../imagery/i.gensigset/parse.c:44 ../imagery/i.gensig/parse.c:38
-#: ../doc/raster/r.example/main.c:105 ../scripts/d.correlate/d.correlate.py:50
-#: ../scripts/r.fillnulls/r.fillnulls.py:149
-#: ../scripts/v.rast.stats/v.rast.stats.py:123 ../scripts/d.polar/d.polar.py:62
-#: ../scripts/r.rgb/r.rgb.py:60 ../scripts/d.rast.leg/d.rast.leg.py:99
-#: ../scripts/d.rast.leg/d.rast.leg.py:103 ../scripts/r.pack/r.pack.py:74
-#: ../scripts/r.mask/r.mask.py:131
-#: ../scripts/r.reclass.area/r.reclass.area.py:103
-#: ../scripts/r.reclass.area/r.reclass.area.py:213
-#: ../scripts/r.grow/r.grow.py:123
-#: ../scripts/r.buffer.lowmem/r.buffer.lowmem.py:87
-#, c-format, python-format
-msgid "Raster map <%s> not found"
+#: ../vector/v.clean/main.c:366 ../vector/v.clean/main.c:375
+#: ../vector/v.clean/main.c:411 ../vector/v.clean/main.c:427
+#: ../vector/v.clean/main.c:464
+msgid "Tool: Remove duplicates"
 msgstr ""
-#: ../misc/m.nviz.image/surface.c:67
-#, c-format
-msgid "Missing topography attribute for surface %d"
+#: ../vector/v.clean/main.c:369 ../vector/v.clean/main.c:418
+#: ../vector/v.clean/main.c:469
+msgid "Tool: Merge lines"
 msgstr ""
-#: ../misc/m.nviz.image/surface.c:131 ../misc/m.nviz.image/volume.c:159
-#, c-format
-msgid "Color attribute not defined, using default <%s>"
+#: ../vector/v.clean/main.c:379
+msgid "Tool: Remove dangles"
 msgstr ""
-#: ../misc/m.nviz.image/surface.c:137
-#, c-format
-msgid "Missing color attribute for surface %d"
+#: ../vector/v.clean/main.c:383
+msgid "Tool: Change type of boundary dangles"
 msgstr ""
-#: ../misc/m.nviz.image/surface.c:217
-#, c-format
-msgid "Surface id %d doesn't exist"
+#: ../vector/v.clean/main.c:387
+msgid "Tool: Remove bridges"
 msgstr ""
-#: ../misc/m.nviz.image/surface.c:264 ../misc/m.nviz.image/surface.c:271
-#, c-format
-msgid "Unable to set draw mode for surface id %d"
+#: ../vector/v.clean/main.c:391
+msgid "Tool: Change type of boundary bridges"
 msgstr ""
-#: ../misc/m.nviz.image/args.c:51
-msgid "Use draw mode for all loaded surfaces"
+#: ../vector/v.clean/main.c:395
+msgid "Tool: Remove duplicate area centroids"
 msgstr ""
-#: ../misc/m.nviz.image/args.c:52 ../misc/m.nviz.image/args.c:133
-#: ../misc/m.nviz.image/args.c:143 ../misc/m.nviz.image/args.c:150
-#: ../misc/m.nviz.image/args.c:156 ../misc/m.nviz.image/args.c:164
-#: ../misc/m.nviz.image/args.c:173 ../misc/m.nviz.image/args.c:183
-#: ../misc/m.nviz.image/args.c:191 ../misc/m.nviz.image/args.c:201
-#: ../misc/m.nviz.image/args.c:209 ../misc/m.nviz.image/args.c:219
-msgid "Surfaces"
+#: ../vector/v.clean/main.c:399
+msgid "Tool: Snap line to vertex in threshold"
 msgstr ""
-#: ../misc/m.nviz.image/args.c:70 ../general/g.pnmcomp/main.c:325
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:32
-#: ../display/d.mon/main.c:90 ../display/d.legend/main.c:246
-#: ../display/d.grid/main.c:113 ../display/d.legend.vect/main.c:101
-#: ../display/d.path/main.c:115 ../display/d.histogram/main.c:108
-#: ../display/d.erase/main.c:37 ../vector/v.lrs/v.lrs.label/main.c:218
-#: ../vector/v.label.sa/main.c:124 ../vector/v.label/main.c:187
-msgid "Background color"
-msgstr "Fona krāsa"
-#: ../misc/m.nviz.image/args.c:92
-msgid "Name for output image file (without extension)"
+#: ../vector/v.clean/main.c:413 ../vector/v.clean/main.c:447
+#: ../vector/v.clean/main.c:466
+msgid "Tool: Remove small angles at nodes"
 msgstr ""
-#: ../misc/m.nviz.image/args.c:93 ../misc/m.nviz.image/args.c:107
-#: ../misc/m.nviz.image/args.c:117
-msgid "Image"
-msgstr "Attēls"
+#: ../vector/v.clean/main.c:424
+msgid "Tool: Break polygons"
+msgstr "Rīks: sadalīt poligonus"
-#: ../misc/m.nviz.image/args.c:105
-#: ../locale/scriptstrings/d.out.file_to_translate.c:5
-msgid "Graphics file format"
+#: ../vector/v.clean/main.c:432
+msgid "Tool: Prune lines/boundaries"
 msgstr ""
-#: ../misc/m.nviz.image/args.c:115
-msgid "Size (width, height) of output image"
+#: ../vector/v.clean/main.c:436
+msgid "Tool: Remove small areas"
 msgstr ""
-#: ../misc/m.nviz.image/args.c:132
-msgid "Name of raster map(s) for elevation"
+#: ../vector/v.clean/main.c:442
+msgid "Tool: Merge boundaries"
 msgstr ""
-#: ../misc/m.nviz.image/args.c:142
-msgid "Constant elevation value(s) to use instead of a raster DEM"
+#: ../vector/v.clean/main.c:475
+msgid "Tool: Remove all lines and boundaries of zero length"
 msgstr ""
-#: ../misc/m.nviz.image/args.c:149
-msgid "Name of raster map(s) for color"
+#: ../vector/v.clean/main.c:484
+msgid "Rebuilding topology for output vector map..."
 msgstr ""
-#: ../misc/m.nviz.image/args.c:155
-msgid "Color value(s)"
+#: ../vector/v.clean/main.c:495
+msgid "Building topology for error vector map..."
 msgstr ""
-#: ../misc/m.nviz.image/args.c:163
-msgid "Name of raster map(s) for mask"
+#: ../vector/v.clean/test/topocheck.c:63
+#: ../vector/v.lidar.correction/main.c:157 ../vector/v.profile/main.c:359
+#: ../vector/v.profile/main.c:363 ../vector/v.lidar.growing/main.c:126
+#: ../vector/v.vect.stats/main.c:263 ../vector/v.vect.stats/main.c:271
+#: ../vector/v.outlier/main.c:176 ../vector/v.edit/main.c:155
+#: ../vector/v.surf.bspline/main.c:263 ../vector/v.surf.bspline/main.c:332
+#: ../vector/v.lidar.edgedetection/main.c:180
+#: ../vector/v.lrs/v.lrs.label/main.c:268
+#: ../vector/v.lrs/v.lrs.where/main.c:127
+#: ../vector/v.lrs/v.lrs.where/main.c:136
+#: ../vector/v.lrs/v.lrs.create/main.c:251
+#: ../vector/v.lrs/v.lrs.create/main.c:260
+#: ../vector/v.lrs/v.lrs.segment/main.c:140 ../vector/v.colors/main.c:238
+#: ../raster/r.walk/main.c:410 ../raster/r.cost/main.c:325
+#: ../raster/r.carve/main.c:158 ../general/g.region/main.c:479
+#: ../misc/m.nviz.image/vector.c:84 ../doc/vector/v.example/main.c:75
+#: ../display/d.extract/main.c:98 ../scripts/v.report/v.report.py:74
+#: ../scripts/r.mask/r.mask.py:150 ../scripts/v.db.univar/v.db.univar.py:75
+#: ../scripts/v.dissolve/v.dissolve.py:68 ../scripts/v.pack/v.pack.py:65
+msgid "Vector map <%s> not found"
 msgstr ""
-#: ../misc/m.nviz.image/args.c:172
-msgid "Name of raster map(s) for transparency"
+#: ../vector/v.clean/split.c:85
+#, c-format
+msgid "Line splits: %d"
 msgstr ""
-#: ../misc/m.nviz.image/args.c:182
-msgid "Transparency value(s)"
+#: ../vector/v.clean/prune.c:216
+#, c-format
+msgid ""
+"%d vertices from input %d (vertices of given type) removed, i.e. %.2f %%"
 msgstr ""
-#: ../misc/m.nviz.image/args.c:190
-msgid "Name of raster map(s) for shininess"
+#: ../vector/v.clean/prune.c:220
+#, c-format
+msgid "%d boundaries not pruned because pruning would damage topology"
 msgstr ""
-#: ../misc/m.nviz.image/args.c:200
-msgid "Shininess value(s)"
+#: ../vector/v.clean/rmline.c:64
+#, c-format
+msgid "Lines / boundaries removed: %d"
 msgstr ""
-#: ../misc/m.nviz.image/args.c:208
-msgid "Name of raster map(s) for emission"
+#: ../vector/v.to.3d/main.c:38 ../vector/v.surf.rst/main.c:150
+#: ../vector/v.hull/main.c:54 ../vector/v.out.postgis/main.c:49
+#: ../vector/v.drape/main.c:59 ../vector/v.extrude/main.c:70
+msgid "3D"
+msgstr "3D"
+#: ../vector/v.to.3d/main.c:40
+msgid "Performs transformation of 2D vector features to 3D."
 msgstr ""
-#: ../misc/m.nviz.image/args.c:218
-msgid "Emission value(s)"
+#: ../vector/v.to.3d/main.c:52
+#, c-format
+msgid "Either '%s' or '%s' parameter have to be used"
 msgstr ""
-#: ../misc/m.nviz.image/args.c:230
-msgid "Draw mode"
+#: ../vector/v.to.3d/main.c:58
+#, c-format
+msgid "Parameters '%s' ignored"
 msgstr ""
-#: ../misc/m.nviz.image/args.c:233 ../misc/m.nviz.image/args.c:244
-#: ../misc/m.nviz.image/args.c:255 ../misc/m.nviz.image/args.c:267
-#: ../misc/m.nviz.image/args.c:279 ../misc/m.nviz.image/args.c:288
-#: ../misc/m.nviz.image/args.c:298 ../misc/m.nviz.image/args.c:608
-#: ../misc/m.nviz.image/args.c:620 ../display/d.grid/main.c:133
-#: ../display/d.grid/main.c:139 ../display/d.grid/main.c:144
-#: ../display/d.grid/main.c:149 ../display/d.grid/main.c:154
-msgid "Draw"
-msgstr "Zīmēt"
+#: ../vector/v.to.3d/main.c:63
+msgid "Attribute table required"
+msgstr ""
-#: ../misc/m.nviz.image/args.c:242
-msgid "Fine resolution"
+#: ../vector/v.to.3d/main.c:76
+#, c-format
+msgid "Vector map <%s> is 2D"
 msgstr ""
-#: ../misc/m.nviz.image/args.c:253
-msgid "Coarse resolution"
+#: ../vector/v.to.3d/main.c:80
+#, c-format
+msgid "Vector map <%s> is 3D"
 msgstr ""
-#: ../misc/m.nviz.image/args.c:264
-msgid "Draw style"
-msgstr "Zīmēšanas stils"
+#: ../vector/v.to.3d/main.c:96 ../vector/v.to.3d/main.c:117
+#: ../vector/v.net/main.c:156 ../vector/v.in.db/main.c:282
+#: ../vector/v.transform/main.c:302
+msgid "Copying attributes..."
+msgstr ""
-#: ../misc/m.nviz.image/args.c:276
-msgid "Shading"
+#: ../vector/v.to.3d/main.c:98 ../vector/v.to.3d/main.c:119
+msgid "Unable to copy attributes"
 msgstr ""
-#: ../misc/m.nviz.image/args.c:285
-msgid "Wire color"
+#: ../vector/v.to.3d/main.c:128
+#, c-format
+msgid "Vertical extent of vector map <%s>: B: %f T: %f"
 msgstr ""
-#: ../misc/m.nviz.image/args.c:297
-msgid "Surface position"
+#: ../vector/v.to.3d/trans3.c:45 ../vector/v.to.3d/trans2.c:43
+#, c-format
+msgid "Invalid layer number %d, assuming 1"
 msgstr ""
-#: ../misc/m.nviz.image/args.c:309
-msgid "Name of line vector overlay map(s)"
+#: ../vector/v.to.3d/trans3.c:51 ../vector/v.to.3d/trans2.c:49
+#: ../vector/v.db.connect/main.c:213 ../vector/v.extract/main.c:255
+#: ../vector/v.distance/main.c:515 ../vector/v.distance/main.c:596
+#: ../vector/v.db.select/main.c:171 ../vector/v.to.rast/vect2rast.c:55
+#: ../vector/v.info/print.c:138 ../vector/v.to.rast3/main.c:80
+#: ../vector/v.colors.out/make_colors.c:31
+#, c-format
+msgid "Database connection not defined for layer <%s>"
 msgstr ""
-#: ../misc/m.nviz.image/args.c:310 ../misc/m.nviz.image/args.c:318
-#: ../misc/m.nviz.image/args.c:330 ../misc/m.nviz.image/args.c:339
-#: ../misc/m.nviz.image/args.c:348 ../misc/m.nviz.image/args.c:355
-#: ../misc/m.nviz.image/args.c:369 ../misc/m.nviz.image/args.c:379
-#: ../misc/m.nviz.image/args.c:391
-msgid "Vector lines"
+#: ../vector/v.to.3d/trans3.c:57 ../vector/v.to.3d/trans2.c:55
+#: ../vector/v.select/copy_tabs.c:82 ../vector/v.surf.rst/main.c:620
+#: ../vector/v.sample/main.c:179 ../vector/v.in.ascii/main.c:348
+#: ../vector/v.profile/main.c:426 ../vector/v.profile/main.c:580
+#: ../vector/v.to.db/query.c:89 ../vector/v.to.db/update.c:46
+#: ../vector/v.surf.idw/read_sites.c:55 ../vector/v.db.connect/main.c:223
+#: ../vector/v.db.connect/main.c:331 ../vector/v.net.allpairs/main.c:166
+#: ../vector/v.class/main.c:117 ../vector/v.in.dwg/main.c:213
+#: ../vector/v.kcv/main.c:126 ../vector/v.in.ogr/main.c:1052
+#: ../vector/v.in.ogr/main.c:1096 ../vector/v.label/main.c:278
+#: ../vector/v.reclass/main.c:133 ../vector/v.normal/main.c:122
+#: ../vector/v.extract/main.c:263 ../vector/v.out.ogr/main.c:641
+#: ../vector/v.patch/main.c:156 ../vector/v.patch/main.c:188
+#: ../vector/v.patch/main.c:309 ../vector/v.patch/main.c:391
+#: ../vector/v.out.vtk/writeVTK.c:649 ../vector/v.vol.rst/main.c:600
+#: ../vector/v.vol.rst/user1.c:99 ../vector/v.to.points/main.c:177
+#: ../vector/v.buffer/main.c:431 ../vector/v.out.svg/main.c:159
+#: ../vector/v.in.db/main.c:164 ../vector/v.in.db/main.c:302
+#: ../vector/v.net.alloc/main.c:316 ../vector/v.net.components/main.c:180
+#: ../vector/v.net.iso/main.c:376 ../vector/v.out.postgis/table.c:34
+#: ../vector/v.distance/main.c:520 ../vector/v.distance/main.c:555
+#: ../vector/v.distance/main.c:601 ../vector/v.distance/main.c:1340
+#: ../vector/v.distance/main.c:1359 ../vector/v.edit/select.c:516
+#: ../vector/v.net.flow/main.c:169 ../vector/v.overlay/main.c:246
+#: ../vector/v.overlay/main.c:413 ../vector/v.db.select/main.c:177
+#: ../vector/v.surf.bspline/main.c:384 ../vector/v.surf.bspline/crosscorr.c:123
+#: ../vector/v.what.rast/main.c:144 ../vector/v.net.path/path.c:96
+#: ../vector/v.mkgrid/main.c:278 ../vector/v.lrs/v.lrs.create/main.c:296
+#: ../vector/v.lrs/v.lrs.create/main.c:305 ../vector/v.net.timetable/main.c:93
+#: ../vector/v.to.rast/vect2rast.c:60 ../vector/v.to.rast/support.c:109
+#: ../vector/v.to.rast/support.c:284 ../vector/v.to.rast/support.c:523
+#: ../vector/v.net.distance/main.c:279 ../vector/v.transform/trans_digit.c:41
+#: ../vector/v.random/main.c:240 ../vector/v.what.rast3/main.c:126
+#: ../vector/v.colors/write_rgb.c:25 ../vector/v.colors/scan_attr.c:29
+#: ../vector/v.colors/read_rgb.c:28 ../vector/v.in.dxf/write_vect.c:211
+#: ../vector/v.info/print.c:147 ../vector/v.label.sa/labels.c:78
+#: ../vector/v.to.rast3/main.c:84 ../vector/v.colors.out/make_colors.c:36
+#: ../vector/v.net.centrality/main.c:246 ../vector/v.extrude/main.c:229
+#: ../raster/r.volume/main.c:243 ../raster/r.to.vect/main.c:188
+#: ../raster/r.contour/main.c:172 ../raster/r.random/random.c:73
+#: ../misc/m.nviz.image/vector.c:293 ../ps/ps.map/catval.c:53
+#: ../ps/ps.map/catval.c:115 ../ps/ps.map/catval.c:181
+#: ../raster3d/r3.flow/main.c:46 ../doc/vector/v.example/main.c:131
+#: ../display/d.vect.chart/plot.c:44 ../display/d.vect.thematic/plot1.c:111
+#: ../display/d.vect/attr.c:43 ../display/d.vect/shape.c:44
+#, c-format
+msgid "Unable to open database <%s> by driver <%s>"
 msgstr ""
-#: ../misc/m.nviz.image/args.c:317 ../misc/m.nviz.image/args.c:410
-msgid "Layer number or name for thematic mapping"
+#: ../vector/v.to.3d/trans3.c:65 ../vector/v.to.3d/trans2.c:63
+#: ../vector/v.univar/main.c:355 ../vector/v.db.connect/main.c:289
+#: ../vector/v.reclass/main.c:145 ../vector/v.vect.stats/main.c:428
+#: ../vector/v.out.lidar/main.c:118 ../vector/v.out.lidar/main.c:155
+#: ../vector/v.in.db/main.c:187 ../vector/v.distance/main.c:533
+#: ../vector/v.distance/main.c:574 ../vector/v.transform/trans_digit.c:116
+#: ../vector/v.colors/scan_attr.c:35 ../vector/v.colors.out/make_colors.c:42
+#: ../db/drivers/ogr/execute.c:69 ../scripts/db.univar/db.univar.py:120
+#: ../scripts/v.db.renamecolumn/v.db.renamecolumn.py:96
+#: ../scripts/v.db.join/v.db.join.py:98 ../scripts/v.db.join/v.db.join.py:106
+#: ../scripts/v.db.join/v.db.join.py:123
+msgid "Column <%s> not found in table <%s>"
 msgstr ""
-#: ../misc/m.nviz.image/args.c:329
-msgid "Vector line width"
+#: ../vector/v.to.3d/trans3.c:69 ../vector/v.to.3d/trans2.c:67
+msgid "Column must be numeric"
 msgstr ""
-#: ../misc/m.nviz.image/args.c:337 ../misc/m.nviz.image/args.c:449
-msgid "Name of width definition column"
+#: ../vector/v.to.3d/trans3.c:75
+msgid "Reading categories..."
 msgstr ""
-#: ../misc/m.nviz.image/args.c:345
-msgid "Vector line color"
+#: ../vector/v.to.3d/trans3.c:80 ../vector/v.to.3d/trans2.c:79
+#: ../vector/v.transform/main.c:296
+msgid "Transforming features..."
 msgstr ""
-#: ../misc/m.nviz.image/args.c:353 ../misc/m.nviz.image/args.c:465
-msgid "Name of color definition column"
+#: ../vector/v.to.3d/trans3.c:85 ../vector/v.to.3d/trans2.c:84
+#: ../vector/v.label/main.c:293 ../vector/v.vol.rst/user1.c:140
+#: ../vector/v.out.lidar/main.c:732 ../vector/v.perturb/main.c:182
+#: ../vector/v.what.rast/main.c:213 ../vector/v.colors/scan_cats.c:24
+#: ../vector/v.colors/scan_z.c:36 ../vector/v.info/level1.c:38
+#: ../vector/v.label.sa/labels.c:141 ../vector/v.colors.out/scan_cats.c:32
+#: ../vector/v.decimate/main.c:406 ../raster/r.walk/main.c:688
+#: ../raster/r.walk/main.c:754 ../raster/r.to.vect/main.c:289
+#: ../raster/r.drain/main.c:286 ../raster/r.cost/main.c:548
+#: ../raster/r.cost/main.c:618 ../display/d.vect.thematic/display.c:75
+#: ../display/d.vect/zcoor.c:38 ../display/d.vect/attr.c:51
+#: ../display/d.vect/lines.c:143 ../display/d.vect/vert.c:27
+#: ../display/d.vect/dir.c:30 ../display/d.vect/label.c:44
+#: ../display/d.vect/topo.c:52
+msgid "Unable to read vector map"
 msgstr ""
-#: ../misc/m.nviz.image/args.c:364
-msgid "Vector line display mode"
+#: ../vector/v.to.3d/trans3.c:101
+#, c-format
+msgid "Feature id %d has no category - skipping"
 msgstr ""
-#: ../misc/m.nviz.image/args.c:366
-msgid "surface;drape on raster surface;flat;draw at constant elevation"
+#: ../vector/v.to.3d/trans3.c:104
+#, c-format
+msgid "Feature id %d has more categories. Using category %d."
 msgstr ""
-#: ../misc/m.nviz.image/args.c:378
-msgid "Vector line height"
+#: ../vector/v.to.3d/trans3.c:130 ../vector/v.to.db/update.c:231
+#, c-format
+msgid "Record (cat %d) does not exist (not updated)"
 msgstr ""
-#: ../misc/m.nviz.image/args.c:390
-msgid "Vector lines position"
+#: ../vector/v.to.3d/trans2.c:70
+#, c-format
+msgid "Fetching height from <%s> column..."
 msgstr ""
-#: ../misc/m.nviz.image/args.c:402
-msgid "Name of point vector overlay map(s)"
+#: ../vector/v.to.3d/trans2.c:101
+msgid "Skipping feature without category"
 msgstr ""
-#: ../misc/m.nviz.image/args.c:403 ../misc/m.nviz.image/args.c:411
-#: ../misc/m.nviz.image/args.c:423 ../misc/m.nviz.image/args.c:432
-#: ../misc/m.nviz.image/args.c:442 ../misc/m.nviz.image/args.c:451
-#: ../misc/m.nviz.image/args.c:460 ../misc/m.nviz.image/args.c:467
-#: ../misc/m.nviz.image/args.c:480 ../misc/m.nviz.image/args.c:488
-#: ../misc/m.nviz.image/args.c:503 ../misc/m.nviz.image/args.c:513
-msgid "Vector points"
+#: ../vector/v.to.3d/trans2.c:116
+#, c-format
+msgid "Unable to get height for feature category %d"
 msgstr ""
-#: ../misc/m.nviz.image/args.c:422
-msgid "Icon size (map units)"
+#: ../vector/v.to.3d/args.c:11
+msgid "Reverse transformation; 3D vector features to 2D"
 msgstr ""
-#: ../misc/m.nviz.image/args.c:430
-msgid "Name of size definition column"
+#: ../vector/v.to.3d/args.c:14
+msgid "Do not copy attribute table"
 msgstr ""
-#: ../misc/m.nviz.image/args.c:441
-msgid "Icon width"
+#: ../vector/v.to.3d/args.c:30
+msgid "Name of attribute column used for height"
 msgstr ""
-#: ../misc/m.nviz.image/args.c:457
-msgid "Icon color"
+#: ../vector/v.to.3d/args.c:32
+msgid "Can be used for reverse transformation, to store height of points"
 msgstr ""
-#: ../misc/m.nviz.image/args.c:476
-msgid "Icon marker"
+#: ../vector/v.to.3d/args.c:33 ../vector/v.to.3d/args.c:41
+#: ../vector/v.extrude/main.c:105 ../vector/v.extrude/main.c:113
+#: ../vector/v.extrude/main.c:119
+msgid "Height"
 msgstr ""
-#: ../misc/m.nviz.image/args.c:486
-msgid "Name of marker definition column"
+#: ../vector/v.to.3d/args.c:40 ../vector/v.extrude/main.c:112
+msgid "Fixed height for 3D vector features"
 msgstr ""
-#: ../misc/m.nviz.image/args.c:497
-msgid "3D vector point display mode"
+#: ../vector/v.select/main.c:50 ../vector/v.overlay/main.c:65
+msgid "spatial query"
 msgstr ""
-#: ../misc/m.nviz.image/args.c:499
-msgid "surface;drape on raster surface;3D;place at 3D point's z-elevation"
+#: ../vector/v.select/main.c:52
+msgid ""
+"Selects features from vector map (A) by features from other vector map (B)."
 msgstr ""
-#: ../misc/m.nviz.image/args.c:512
-msgid "Vector points position"
+#: ../vector/v.select/main.c:85 ../vector/v.overlay/main.c:178
+#, c-format
+msgid "Unknown operator '%s'"
 msgstr ""
-#: ../misc/m.nviz.image/args.c:529
-msgid "Viewpoint position (x,y model coordinates)"
+#: ../vector/v.select/main.c:89 ../vector/v.in.ogr/main.c:419
+#: ../vector/v.external/main.c:110 ../vector/v.net/args.c:152
+#: ../vector/v.net/args.c:159 ../vector/v.net/args.c:165
+#: ../vector/v.net/args.c:169 ../vector/v.net/args.c:179
+#: ../vector/v.edit/main.c:89 ../vector/v.what.rast/main.c:121
+#: ../vector/v.proj/main.c:206 ../raster/r.proj/main.c:300
+#: ../scripts/d.frame/d.frame.py:288
+msgid "Required parameter <%s> not set"
 msgstr ""
-#: ../misc/m.nviz.image/args.c:530 ../misc/m.nviz.image/args.c:542
-#: ../misc/m.nviz.image/args.c:552 ../misc/m.nviz.image/args.c:564
-#: ../misc/m.nviz.image/args.c:586
-msgid "Viewpoint"
-msgstr "Skatu punkts"
+#: ../vector/v.select/main.c:94
+msgid "Operator can only be 'overlap'"
+msgstr ""
-#: ../misc/m.nviz.image/args.c:541
-msgid "Viewpoint height (in map units)"
+#: ../vector/v.select/main.c:128
+msgid "Output from v.select"
 msgstr ""
-#: ../misc/m.nviz.image/args.c:551
-msgid "Viewpoint field of view (in degrees)"
+#: ../vector/v.select/main.c:181
+#, c-format
+msgid "%d features from <%s> without category skipped"
 msgstr ""
-#: ../misc/m.nviz.image/args.c:563
-msgid "Viewpoint twist angle (in degrees)"
+#: ../vector/v.select/main.c:190
+#, c-format
+msgid "%d features written to output."
 msgstr ""
-#: ../misc/m.nviz.image/args.c:575 ../raster/r.out.vrml/main.c:65
-msgid "Vertical exaggeration"
+#: ../vector/v.select/main.c:192
+#, fuzzy
+msgid "No features found !"
+msgstr "Rastra karte kura tiks pārkodēta"
+#: ../vector/v.select/args.c:12
+msgid "Input vector map from which to select features (A)"
 msgstr ""
-#: ../misc/m.nviz.image/args.c:585
-msgid "Focus to point on surface (from SW corner in map units)"
+#: ../vector/v.select/args.c:16
+msgid "Layer number (vector map A)"
 msgstr ""
-#: ../misc/m.nviz.image/args.c:595 ../misc/m.nviz.image/args.c:630
-#: ../misc/m.nviz.image/args.c:642 ../misc/m.nviz.image/args.c:652
-#: ../misc/m.nviz.image/args.c:661 ../misc/m.nviz.image/args.c:669
-#: ../misc/m.nviz.image/args.c:678 ../misc/m.nviz.image/args.c:689
-#: ../misc/m.nviz.image/args.c:698 ../misc/m.nviz.image/args.c:709
-#: ../misc/m.nviz.image/args.c:716 ../misc/m.nviz.image/args.c:722
-#: ../misc/m.nviz.image/args.c:734 ../misc/m.nviz.image/args.c:744
-#: ../misc/m.nviz.image/args.c:755
-msgid "Volumes"
-msgstr "Tilpumi"
+#: ../vector/v.select/args.c:21 ../vector/v.overlay/main.c:81
+msgid "Feature type (vector map A)"
+msgstr ""
-#: ../misc/m.nviz.image/args.c:605
-msgid "Volume draw mode"
+#: ../vector/v.select/args.c:27
+msgid "Query vector map (B)"
 msgstr ""
-#: ../misc/m.nviz.image/args.c:617
-msgid "Volume shading"
+#: ../vector/v.select/args.c:31
+msgid "Layer number (vector map B)"
 msgstr ""
-#: ../misc/m.nviz.image/args.c:629
-msgid "Volume position"
+#: ../vector/v.select/args.c:36 ../vector/v.overlay/main.c:95
+msgid "Feature type (vector map B)"
 msgstr ""
-#: ../misc/m.nviz.image/args.c:640
-msgid "Volume resolution"
+#: ../vector/v.select/args.c:49
+msgid "Operator defines required relation between features"
 msgstr ""
-#: ../misc/m.nviz.image/args.c:651
-msgid "Isosurface level"
+#: ../vector/v.select/args.c:51
+msgid ""
+"A feature is written to output if the result of operation 'ainput operator "
+"binput' is true. An input feature is considered to be true, if category of "
+"given layer is defined."
 msgstr ""
-#: ../misc/m.nviz.image/args.c:660
-msgid "Name of volume for isosurface color"
+#: ../vector/v.select/args.c:59 ../vector/v.select/args.c:75
+msgid "features partially or completely overlap"
 msgstr ""
-#: ../misc/m.nviz.image/args.c:668
-msgid "Isosurface color"
+#: ../vector/v.select/args.c:76
+msgid "features are spatially equals (using GEOS)"
 msgstr ""
-#: ../misc/m.nviz.image/args.c:677
-msgid "Name of 3D raster map(s) for isosurface transparency"
+#: ../vector/v.select/args.c:77
+msgid "features do not spatially intersect (using GEOS)"
 msgstr ""
-#: ../misc/m.nviz.image/args.c:688
-msgid "Transparency value(s)for isosurfaces"
+#: ../vector/v.select/args.c:78
+msgid "features spatially intersect (using GEOS)"
 msgstr ""
-#: ../misc/m.nviz.image/args.c:697
-msgid "Name of 3D raster map(s) for shininess"
+#: ../vector/v.select/args.c:79
+msgid "features spatially touches (using GEOS)"
 msgstr ""
-#: ../misc/m.nviz.image/args.c:708
-msgid "Shininess value(s) for isosurfaces"
+#: ../vector/v.select/args.c:80
+msgid "features spatially crosses (using GEOS)"
 msgstr ""
-#: ../misc/m.nviz.image/args.c:715
-msgid "Toggles normal direction of all isosurfaces (changes light effect)"
+#: ../vector/v.select/args.c:81
+msgid "feature A is completely inside feature B (using GEOS)"
 msgstr ""
-#: ../misc/m.nviz.image/args.c:721
-msgid "Draw volume box"
+#: ../vector/v.select/args.c:82
+msgid "feature B is completely inside feature A (using GEOS)"
 msgstr ""
-#: ../misc/m.nviz.image/args.c:733
-msgid "Volume slice parallel to given axis (x, y, z)"
+#: ../vector/v.select/args.c:83
+msgid "features spatially overlap (using GEOS)"
 msgstr ""
-#: ../misc/m.nviz.image/args.c:743
-msgid "Volume slice position"
+#: ../vector/v.select/args.c:84
+msgid ""
+"feature A is spatially related to feature B (using GEOS, requires 'relate' "
+"option)"
 msgstr ""
-#: ../misc/m.nviz.image/args.c:754
-msgid "Volume slice transparency"
+#: ../vector/v.select/args.c:94
+msgid "Intersection Matrix Pattern used for 'relate' operator"
 msgstr ""
-#: ../misc/m.nviz.image/args.c:771
-msgid "Light position (x,y,z model coordinates)"
+#: ../vector/v.select/args.c:101
+msgid "Do not skip features without category"
 msgstr ""
-#: ../misc/m.nviz.image/args.c:772 ../misc/m.nviz.image/args.c:778
-#: ../misc/m.nviz.image/args.c:787 ../misc/m.nviz.image/args.c:797
-msgid "Lighting"
+#: ../vector/v.select/args.c:105 ../vector/v.extract/main.c:97
+#: ../vector/v.edit/args.c:204
+msgid "Reverse selection"
 msgstr ""
-#: ../misc/m.nviz.image/args.c:777
-msgid "Light color"
+#: ../vector/v.select/select.c:41 ../vector/v.category/main.c:332
+#: ../vector/v.drape/main.c:177
+msgid "Processing features..."
 msgstr ""
-#: ../misc/m.nviz.image/args.c:786
-msgid "Light brightness"
+#: ../vector/v.select/select.c:65
+#, c-format
+msgid "Unable to read line id %d from vector map <%s>"
 msgstr ""
-#: ../misc/m.nviz.image/args.c:796
-msgid "Light ambient"
+#: ../vector/v.select/select.c:171 ../vector/v.out.pov/main.c:175
+msgid "Processing areas..."
 msgstr ""
-#: ../misc/m.nviz.image/args.c:810
-msgid "Cutting plane index (0-5)"
+#: ../vector/v.select/select.c:195
+#, c-format
+msgid "Unable to read area id %d from vector map <%s>"
 msgstr ""
-#: ../misc/m.nviz.image/args.c:811 ../misc/m.nviz.image/args.c:820
-#: ../misc/m.nviz.image/args.c:829 ../misc/m.nviz.image/args.c:841
-#: ../misc/m.nviz.image/args.c:852
-msgid "Cutting planes"
+#: ../vector/v.select/copy_tabs.c:17 ../vector/v.voronoi/main.c:384
+#: ../vector/v.extract/copy_tab.c:57 ../vector/v.generalize/misc.c:134
+#: ../raster/r.contour/main.c:203
+msgid "Writing attributes..."
 msgstr ""
-#: ../misc/m.nviz.image/args.c:819
-msgid "Cutting plane x,y,z coordinates"
+#: ../vector/v.select/copy_tabs.c:51 ../scripts/v.to.lines/v.to.lines.py:157
+msgid "No table for layer %d"
 msgstr ""
-#: ../misc/m.nviz.image/args.c:831
-msgid "Cutting plane rotation along the vertical axis"
+#: ../vector/v.select/copy_tabs.c:71
+#, c-format
+msgid "Unable to copy table for layer %d"
 msgstr ""
-#: ../misc/m.nviz.image/args.c:842
-msgid "Cutting plane tilt"
+#: ../vector/v.select/copy_tabs.c:87 ../vector/v.extract/copy_tab.c:124
+#: ../vector/v.patch/main.c:328 ../vector/v.overlay/main.c:592
+#: ../vector/v.mkgrid/main.c:346 ../vector/v.mkgrid/main.c:404
+#: ../vector/v.random/main.c:260 ../raster/r.to.vect/main.c:233
+#: ../raster/r.random/random.c:258 ../db/drivers/postgres/index.c:59
+msgid "Unable to create index"
 msgstr ""
-#: ../misc/m.nviz.image/args.c:854
-msgid "Cutting plane color (between two surfaces)"
+#: ../vector/v.select/copy_tabs.c:90 ../vector/v.sample/main.c:197
+#: ../vector/v.in.ascii/main.c:423 ../vector/v.in.dwg/main.c:249
+#: ../vector/v.in.ogr/main.c:1066 ../vector/v.reclass/main.c:327
+#: ../vector/v.extract/copy_tab.c:129 ../vector/v.patch/main.c:333
+#: ../vector/v.in.lidar/attributes.c:144 ../vector/v.to.points/main.c:202
+#: ../vector/v.distance/main.c:1424 ../vector/v.overlay/main.c:597
+#: ../vector/v.mkgrid/main.c:350 ../vector/v.mkgrid/main.c:408
+#: ../vector/v.random/main.c:266 ../vector/v.in.dxf/write_vect.c:238
+#: ../raster/r.stream.extract/close.c:202 ../raster/r.to.vect/main.c:238
+#: ../raster/r.contour/main.c:193 ../raster/r.random/random.c:262
+#: ../raster3d/r3.flow/main.c:72
+#, c-format
+msgid "Unable to grant privileges on table <%s>"
 msgstr ""
-#: ../misc/m.nviz.image/args.c:870
-msgid "North-West edge"
+#: ../vector/v.select/write.c:27
+msgid "Writing selected features..."
 msgstr ""
-#: ../misc/m.nviz.image/args.c:871
-msgid "North-East edge"
+#: ../vector/v.surf.rst/main.c:148 ../vector/v.surf.idw/main.c:88
+#: ../vector/v.vol.rst/main.c:237 ../vector/v.surf.bspline/main.c:92
+#: ../raster/r.surf.area/main.c:77 ../raster/r.surf.fractal/main.c:39
+#: ../raster/r.resamp.bspline/main.c:80 ../raster/r.surf.random/main.c:37
+#: ../raster/r.contour/main.c:88 ../raster/r.surf.gauss/main.c:39
+#: ../raster/r.surf.contour/main.c:61 ../raster/r.random.surface/main.c:58
+#: ../raster/r.surf.idw/main.c:105 ../raster/r.fill.stats/main.c:776
+msgid "surface"
 msgstr ""
-#: ../misc/m.nviz.image/args.c:872
-msgid "South-West edge"
+#: ../vector/v.surf.rst/main.c:149 ../vector/v.surf.idw/main.c:89
+#: ../vector/v.vol.rst/main.c:238 ../vector/v.surf.bspline/main.c:93
+#: ../raster/r.series.interp/main.c:66 ../raster/r.resamp.bspline/main.c:82
+#: ../raster/r.surf.contour/main.c:62 ../raster/r.surf.idw/main.c:106
+#: ../raster/r.resamp.interp/main.c:78 ../raster/r.fill.stats/main.c:777
+#: ../locale/scriptstrings/r.fillnulls_to_translate.c:4
+#: ../locale/scriptstrings/t.rast.gapfill_to_translate.c:3
+msgid "interpolation"
 msgstr ""
-msgid "South-East edge"
+#: ../vector/v.surf.rst/main.c:151
+msgid "Performs surface interpolation from vector points map by splines."
 msgstr ""
-#: ../misc/m.nviz.image/args.c:874
-msgid "Fringe edges"
+#: ../vector/v.surf.rst/main.c:153
+msgid ""
+"Spatial approximation and topographic analysis from given point or isoline "
+"data in vector format to floating point raster format using regularized "
+"spline with tension."
 msgstr ""
-#: ../misc/m.nviz.image/args.c:875 ../misc/m.nviz.image/args.c:881
-#: ../misc/m.nviz.image/args.c:890
-msgid "Fringe"
+#: ../vector/v.surf.rst/main.c:160
+msgid "Perform cross-validation procedure without raster approximation"
 msgstr ""
-#: ../misc/m.nviz.image/args.c:880
-msgid "Fringe color"
+#: ../vector/v.surf.rst/main.c:161 ../vector/v.surf.rst/main.c:166
+#: ../vector/v.surf.rst/main.c:187 ../vector/v.surf.rst/main.c:262
+#: ../vector/v.surf.rst/main.c:268 ../vector/v.surf.rst/main.c:276
+#: ../vector/v.surf.rst/main.c:283 ../vector/v.surf.rst/main.c:291
+#: ../vector/v.surf.rst/main.c:299 ../vector/v.surf.rst/main.c:308
+#: ../vector/v.surf.rst/main.c:316 ../vector/v.surf.rst/main.c:324
+#: ../vector/v.surf.rst/main.c:333 ../vector/v.surf.rst/main.c:341
+#: ../vector/v.surf.rst/main.c:348 ../raster/r.sim/r.sim.sediment/main.c:227
+#: ../raster/r.sim/r.sim.sediment/main.c:235
+#: ../raster/r.sim/r.sim.sediment/main.c:244
+#: ../raster/r.sim/r.sim.sediment/main.c:262
+#: ../raster/r.sim/r.sim.sediment/main.c:289
+#: ../raster/r.sim/r.sim.water/main.c:231
+#: ../raster/r.sim/r.sim.water/main.c:239
+#: ../raster/r.sim/r.sim.water/main.c:248
+#: ../raster/r.sim/r.sim.water/main.c:266
+#: ../raster/r.sim/r.sim.water/main.c:276
+#: ../raster/r.sim/r.sim.water/main.c:284
+#: ../raster/r.sim/r.sim.water/main.c:293
+#: ../raster/r.sim/r.sim.water/main.c:324 ../imagery/i.eb.hsebal01/main.c:141
+#: ../imagery/i.eb.hsebal01/main.c:150 ../imagery/i.eb.hsebal01/main.c:157
+#: ../imagery/i.eb.hsebal01/main.c:164 ../imagery/i.eb.hsebal01/main.c:171
+#: ../imagery/i.eb.hsebal01/main.c:178
+msgid "Parameters"
 msgstr ""
-#: ../misc/m.nviz.image/args.c:889
-msgid "Fringe elevation"
+#: ../vector/v.surf.rst/main.c:165
+msgid "Use scale dependent tension"
 msgstr ""
-#: ../misc/m.nviz.image/args.c:903
-msgid "Place north arrow at given position \t(in screen coordinates from bottom left corner)"
+#: ../vector/v.surf.rst/main.c:171 ../raster/r.resamp.rst/main.c:263
+msgid "Output partial derivatives instead of topographic parameters"
 msgstr ""
-#: ../misc/m.nviz.image/args.c:905 ../misc/m.nviz.image/args.c:915
-#: ../misc/m.nviz.image/args.c:922
-msgid "Decoration"
+#: ../vector/v.surf.rst/main.c:172 ../vector/v.surf.rst/main.c:196
+#: ../vector/v.surf.rst/main.c:202 ../vector/v.surf.rst/main.c:208
+#: ../vector/v.surf.rst/main.c:214 ../vector/v.surf.rst/main.c:220
+#: ../vector/v.surf.rst/main.c:226 ../vector/v.surf.rst/main.c:232
+#: ../vector/v.surf.rst/main.c:239 ../vector/v.surf.rst/main.c:246
+#: ../vector/v.surf.rst/main.c:253 ../vector/v.vol.rst/main.c:291
+#: ../vector/v.vol.rst/main.c:297 ../vector/v.vol.rst/main.c:360
+#: ../vector/v.vol.rst/main.c:366 ../vector/v.vol.rst/main.c:372
+#: ../vector/v.vol.rst/main.c:379 ../vector/v.vol.rst/main.c:385
+#: ../vector/v.vol.rst/main.c:391 ../vector/v.vol.rst/main.c:397
+#: ../vector/v.vol.rst/main.c:403 ../vector/v.surf.bspline/main.c:130
+#: ../vector/v.surf.bspline/main.c:135 ../raster/r.slope.aspect/main.c:166
+#: ../raster/r.slope.aspect/main.c:172 ../raster/r.slope.aspect/main.c:196
+#: ../raster/r.slope.aspect/main.c:203 ../raster/r.slope.aspect/main.c:210
+#: ../raster/r.slope.aspect/main.c:217 ../raster/r.slope.aspect/main.c:224
+#: ../raster/r.slope.aspect/main.c:231 ../raster/r.slope.aspect/main.c:238
+#: ../raster/r.watershed/front/main.c:139
+#: ../raster/r.watershed/front/main.c:146
+#: ../raster/r.watershed/front/main.c:153
+#: ../raster/r.watershed/front/main.c:160
+#: ../raster/r.watershed/front/main.c:166
+#: ../raster/r.watershed/front/main.c:172
+#: ../raster/r.watershed/front/main.c:180
+#: ../raster/r.watershed/front/main.c:188
+#: ../raster/r.watershed/front/main.c:195
+msgid "Outputs"
+msgstr "Izvades"
+#: ../vector/v.surf.rst/main.c:184 ../vector/v.surf.bspline/main.c:118
+msgid "Name of the attribute column with values to be used for approximation"
 msgstr ""
-#: ../misc/m.nviz.image/args.c:914
-msgid "North arrow size (in map units)"
+#: ../vector/v.surf.rst/main.c:185 ../vector/v.surf.idw/main.c:102
+msgid ""
+"If not given and input is 2D vector map then category values are used. If "
+"input is 3D vector map then z-coordinates are used."
 msgstr ""
-#: ../misc/m.nviz.image/args.c:921
-msgid "North arrow color"
+#: ../vector/v.surf.rst/main.c:195
+msgid "Name for output surface elevation raster map"
 msgstr ""
-#: ../misc/m.nviz.image/args.c:973
-#, c-format
-msgid "At least one <%s> or <%s> required"
+#: ../vector/v.surf.rst/main.c:201 ../raster/r.slope.aspect/main.c:165
+msgid "Name for output slope raster map"
 msgstr ""
-#: ../misc/m.nviz.image/args.c:987 ../misc/m.nviz.image/args.c:1017
-#: ../misc/m.nviz.image/args.c:1023 ../misc/m.nviz.image/args.c:1029
-#: ../misc/m.nviz.image/args.c:1035 ../misc/m.nviz.image/args.c:1041
-#: ../misc/m.nviz.image/args.c:1047
-#, c-format
-msgid "Inconsistent number of attributes (<%s/%s>: %d vs. <%s>: %d)"
+#: ../vector/v.surf.rst/main.c:207 ../raster/r.slope.aspect/main.c:171
+msgid "Name for output aspect raster map"
 msgstr ""
-#: ../misc/m.nviz.image/args.c:1058
-#, c-format
-msgid "Inconsistent number of attributes (<%s>: %d vs. <%s>: %d x 3)"
+#: ../vector/v.surf.rst/main.c:213 ../raster/r.slope.aspect/main.c:195
+msgid "Name for output profile curvature raster map"
 msgstr ""
-#: ../misc/m.nviz.image/args.c:1064 ../misc/m.nviz.image/args.c:1070
-#: ../misc/m.nviz.image/args.c:1082 ../misc/m.nviz.image/args.c:1089
-#: ../misc/m.nviz.image/args.c:1096 ../misc/m.nviz.image/args.c:1103
-#: ../misc/m.nviz.image/args.c:1110 ../misc/m.nviz.image/args.c:1122
-#: ../misc/m.nviz.image/args.c:1127 ../misc/m.nviz.image/args.c:1164
-#, c-format
-msgid "Inconsistent number of attributes (<%s>: %d vs. <%s>: %d)"
+#: ../vector/v.surf.rst/main.c:219 ../raster/r.slope.aspect/main.c:202
+msgid "Name for output tangential curvature raster map"
 msgstr ""
-#: ../misc/m.nviz.image/args.c:1146 ../misc/m.nviz.image/args.c:1156
-#, c-format
-msgid "Inconsistent number of attributes (<%s>: %d vs. <%s>: %d, <%s>: %d)"
+#: ../vector/v.surf.rst/main.c:225
+msgid "Name for output mean curvature raster map"
 msgstr ""
-#: ../misc/m.nviz.image/args.c:1171
-#, c-format
-msgid "Inconsistent number of attributes (<%s>: %d vs. <%s>: %d x 6)"
+#: ../vector/v.surf.rst/main.c:231 ../vector/v.vol.rst/main.c:290
+msgid "Name for output deviations vector point map"
 msgstr ""
-#: ../misc/m.nviz.image/args.c:1183
-#, c-format
-msgid "Inconsistent number of attributes (<%s/%s>: %d vs. <%s>: %d, <%s>: %d)"
+#: ../vector/v.surf.rst/main.c:238 ../vector/v.vol.rst/main.c:296
+msgid "Name for output cross-validation errors vector point map"
 msgstr ""
-#: ../misc/m.nviz.image/vector.c:84 ../general/g.region/main.c:478
-#: ../raster/r.walk/main.c:410 ../raster/r.cost/main.c:325
-#: ../raster/r.carve/main.c:158 ../display/d.extract/main.c:98
-#: ../vector/v.lidar.correction/main.c:152 ../vector/v.edit/main.c:153
-#: ../vector/v.profile/main.c:283 ../vector/v.profile/main.c:287
-#: ../vector/v.lrs/v.lrs.segment/main.c:140
-#: ../vector/v.lrs/v.lrs.label/main.c:268
-#: ../vector/v.lrs/v.lrs.create/main.c:251
-#: ../vector/v.lrs/v.lrs.create/main.c:260
-#: ../vector/v.lrs/v.lrs.where/main.c:127
-#: ../vector/v.lrs/v.lrs.where/main.c:136 ../vector/v.lidar.growing/main.c:126
-#: ../vector/v.clean/test/topocheck.c:63
-#: ../vector/v.lidar.edgedetection/main.c:174
-#: ../vector/v.surf.bspline/main.c:258 ../vector/v.surf.bspline/main.c:326
-#: ../vector/v.outlier/main.c:171 ../vector/v.vect.stats/main.c:238
-#: ../vector/v.vect.stats/main.c:246 ../vector/v.colors/main.c:238
-#: ../doc/vector/v.example/main.c:75 ../scripts/v.report/v.report.py:74
-#: ../scripts/v.dissolve/v.dissolve.py:68 ../scripts/v.pack/v.pack.py:65
-#: ../scripts/r.mask/r.mask.py:150 ../scripts/v.db.univar/v.db.univar.py:75
-msgid "Vector map <%s> not found"
+#: ../vector/v.surf.rst/main.c:245
+msgid "Name for output vector map showing quadtree segmentation"
 msgstr ""
-#: ../misc/m.nviz.image/vector.c:280 ../general/manage/lister/vector.c:32
-#: ../general/g.region/main.c:488 ../raster3d/r3.flow/main.c:411
-#: ../raster/r.random/support.c:63 ../raster/r.drain/main.c:268
-#: ../raster/r.walk/main.c:673 ../raster/r.walk/main.c:742
-#: ../raster/r.cost/main.c:533 ../raster/r.cost/main.c:606
-#: ../raster/r.sim/simlib/observation_points.c:41 ../raster/r.what/main.c:237
-#: ../raster/r.region/main.c:176 ../raster/r.carve/main.c:162
-#: ../display/d.extract/main.c:103 ../display/d.path/main.c:185
-#: ../display/d.vect.chart/main.c:246 ../vector/v.net.spanningtree/main.c:101
-#: ../vector/v.surf.rst/main.c:561 ../vector/v.surf.rst/main.c:665
-#: ../vector/v.what.rast3/main.c:114 ../vector/v.extrude/main.c:190
-#: ../vector/v.extract/main.c:191 ../vector/v.lidar.correction/main.c:156
-#: ../vector/v.net.components/main.c:148 ../vector/v.net.distance/main.c:192
-#: ../vector/v.out.pov/main.c:97 ../vector/v.surf.idw/read_sites.c:29
-#: ../vector/v.segment/main.c:108 ../vector/v.net.flow/main.c:143
-#: ../vector/v.split/main.c:172 ../vector/v.edit/main.c:168
-#: ../vector/v.edit/main.c:241 ../vector/v.random/main.c:199
-#: ../vector/v.profile/main.c:294 ../vector/v.profile/main.c:323
-#: ../vector/v.voronoi/main.c:196 ../vector/v.lrs/v.lrs.segment/main.c:144
-#: ../vector/v.lrs/v.lrs.label/main.c:272
-#: ../vector/v.lrs/v.lrs.create/main.c:254
-#: ../vector/v.lrs/v.lrs.create/main.c:263
-#: ../vector/v.lrs/v.lrs.where/main.c:131
-#: ../vector/v.lrs/v.lrs.where/main.c:140 ../vector/v.kernel/main.c:319
-#: ../vector/v.kernel/main.c:332 ../vector/v.to.rast3/main.c:73
-#: ../vector/v.out.ogr/main.c:129 ../vector/v.type/main.c:131
-#: ../vector/v.net.timetable/main.c:353 ../vector/v.label.sa/labels.c:58
-#: ../vector/v.sample/main.c:124 ../vector/v.build.polylines/main.c:151
-#: ../vector/v.class/main.c:102 ../vector/v.net.alloc/main.c:174
-#: ../vector/v.external/main.c:205 ../vector/v.to.3d/main.c:72
-#: ../vector/v.univar/main.c:158 ../vector/v.out.postgis/main.c:100
-#: ../vector/v.qcount/main.c:101 ../vector/v.out.lidar/main.c:609
-#: ../vector/v.out.ascii/main.c:87 ../vector/v.out.ascii/main.c:94
-#: ../vector/v.lidar.growing/main.c:138 ../vector/v.lidar.growing/main.c:142
-#: ../vector/v.overlay/main.c:188 ../vector/v.net.allpairs/main.c:130
-#: ../vector/v.decimate/main.c:270 ../vector/v.parallel/main.c:148
-#: ../vector/v.rectify/main.c:148 ../vector/v.to.db/main.c:59
-#: ../vector/v.build/main.c:118 ../vector/v.build/main.c:128
-#: ../vector/v.net.connectivity/main.c:130 ../vector/v.vol.rst/main.c:560
-#: ../vector/v.select/main.c:108 ../vector/v.db.select/main.c:164
-#: ../vector/v.to.points/main.c:130 ../vector/v.clean/test/topocheck.c:67
-#: ../vector/v.clean/test/topocheck.c:87 ../vector/v.clean/main.c:283
-#: ../vector/v.lidar.edgedetection/main.c:180 ../vector/v.kriging/main.c:387
-#: ../vector/v.net.bridge/main.c:118 ../vector/v.net.path/main.c:158
-#: ../vector/v.drape/main.c:143 ../vector/v.perturb/main.c:147
-#: ../vector/v.perturb/main.c:172 ../vector/v.info/main.c:60
-#: ../vector/v.patch/main.c:127 ../vector/v.patch/main.c:145
-#: ../vector/v.patch/main.c:175 ../vector/v.patch/main.c:272
-#: ../vector/v.patch/main.c:353 ../vector/v.proj/main.c:237
-#: ../vector/v.net.steiner/main.c:432 ../vector/v.cluster/main.c:147
-#: ../vector/v.delaunay/main.c:120 ../vector/v.reclass/main.c:113
-#: ../vector/v.neighbors/main.c:88 ../vector/v.net.centrality/main.c:209
-#: ../vector/v.out.svg/main.c:139 ../vector/v.net.visibility/main.c:73
-#: ../vector/v.net.visibility/main.c:82 ../vector/v.generalize/main.c:325
-#: ../vector/v.net.iso/main.c:211 ../vector/v.support/main.c:134
-#: ../vector/v.net/main.c:68 ../vector/v.net/main.c:92
-#: ../vector/v.out.dxf/main.c:80 ../vector/v.to.rast/support.c:100
-#: ../vector/v.to.rast/support.c:272 ../vector/v.to.rast/support.c:510
-#: ../vector/v.to.rast/vect2rast.c:39 ../vector/v.what.rast/main.c:131
-#: ../vector/v.net.salesman/main.c:250 ../vector/v.vect.stats/main.c:242
-#: ../vector/v.vect.stats/main.c:253 ../vector/v.transform/main.c:197
-#: ../vector/v.normal/main.c:110 ../vector/v.distance/main.c:364
-#: ../vector/v.distance/main.c:386 ../vector/v.hull/main.c:87
-#: ../vector/v.db.connect/main.c:154 ../vector/v.label/main.c:268
-#: ../vector/v.colors/main.c:262 ../vector/v.colors.out/make_colors.c:23
-#: ../vector/v.colors.out/scan_cats.c:20 ../vector/v.buffer/main.c:338
-#: ../doc/vector/v.example/main.c:87
-#, c-format
-msgid "Unable to open vector map <%s>"
+#: ../vector/v.surf.rst/main.c:252
+msgid "Name for output vector map showing overlapping windows"
 msgstr ""
-#: ../misc/m.nviz.image/vector.c:293 ../raster3d/r3.flow/main.c:46
-#: ../raster/r.to.vect/main.c:188 ../raster/r.random/random.c:73
-#: ../raster/r.volume/main.c:243 ../raster/r.contour/main.c:172
-#: ../display/d.vect/shape.c:44 ../display/d.vect/attr.c:43
-#: ../display/d.vect.thematic/plot1.c:111 ../display/d.vect.chart/plot.c:44
-#: ../vector/v.surf.rst/main.c:620 ../vector/v.what.rast3/main.c:126
-#: ../vector/v.extrude/main.c:229 ../vector/v.extract/main.c:263
-#: ../vector/v.net.components/main.c:180 ../vector/v.net.distance/main.c:279
-#: ../vector/v.surf.idw/read_sites.c:55 ../vector/v.out.vtk/writeVTK.c:649
-#: ../vector/v.net.flow/main.c:169 ../vector/v.edit/select.c:516
-#: ../vector/v.random/main.c:238 ../vector/v.profile/main.c:355
-#: ../vector/v.profile/main.c:462 ../vector/v.lrs/v.lrs.create/main.c:296
-#: ../vector/v.lrs/v.lrs.create/main.c:305 ../vector/v.to.rast3/main.c:84
-#: ../vector/v.out.ogr/main.c:631 ../vector/v.net.timetable/main.c:93
-#: ../vector/v.label.sa/labels.c:78 ../vector/v.in.db/main.c:164
-#: ../vector/v.in.db/main.c:302 ../vector/v.in.dxf/write_vect.c:211
-#: ../vector/v.sample/main.c:179 ../vector/v.class/main.c:117
-#: ../vector/v.in.ascii/main.c:346 ../vector/v.to.3d/trans3.c:57
-#: ../vector/v.to.3d/trans2.c:55 ../vector/v.out.postgis/table.c:34
-#: ../vector/v.mkgrid/main.c:278 ../vector/v.overlay/main.c:246
-#: ../vector/v.overlay/main.c:413 ../vector/v.in.ogr/main.c:1143
-#: ../vector/v.net.allpairs/main.c:166 ../vector/v.to.db/update.c:46
-#: ../vector/v.to.db/query.c:89 ../vector/v.kcv/main.c:126
-#: ../vector/v.vol.rst/user1.c:99 ../vector/v.vol.rst/main.c:600
-#: ../vector/v.select/copy_tabs.c:82 ../vector/v.db.select/main.c:177
-#: ../vector/v.to.points/main.c:177 ../vector/v.kriging/getval.c:54
-#: ../vector/v.surf.bspline/main.c:378 ../vector/v.surf.bspline/crosscorr.c:123
-#: ../vector/v.net.path/path.c:96 ../vector/v.info/print.c:147
-#: ../vector/v.patch/main.c:154 ../vector/v.patch/main.c:186
-#: ../vector/v.patch/main.c:307 ../vector/v.patch/main.c:389
-#: ../vector/v.in.dwg/main.c:213 ../vector/v.reclass/main.c:133
-#: ../vector/v.net.centrality/main.c:246 ../vector/v.out.svg/main.c:159
-#: ../vector/v.to.rast/support.c:109 ../vector/v.to.rast/support.c:284
-#: ../vector/v.to.rast/support.c:523 ../vector/v.to.rast/vect2rast.c:60
-#: ../vector/v.what.rast/main.c:144 ../vector/v.transform/trans_digit.c:41
-#: ../vector/v.normal/main.c:122 ../vector/v.distance/main.c:520
-#: ../vector/v.distance/main.c:555 ../vector/v.distance/main.c:601
-#: ../vector/v.distance/main.c:1340 ../vector/v.distance/main.c:1359
-#: ../vector/v.db.connect/main.c:223 ../vector/v.db.connect/main.c:331
-#: ../vector/v.label/main.c:278 ../vector/v.colors/scan_attr.c:29
-#: ../vector/v.colors/read_rgb.c:28 ../vector/v.colors/write_rgb.c:25
-#: ../vector/v.colors.out/make_colors.c:36 ../vector/v.buffer/main.c:417
-#: ../doc/vector/v.example/main.c:131 ../ps/ps.map/catval.c:53
-#: ../ps/ps.map/catval.c:115 ../ps/ps.map/catval.c:181
-#, c-format
-msgid "Unable to open database <%s> by driver <%s>"
+#: ../vector/v.surf.rst/main.c:261
+#, fuzzy
+msgid "Number of threads for parallel computing"
+msgstr "Drukājamo kopiju sakits"
+#: ../vector/v.surf.rst/main.c:267
+msgid "Name of raster map used as mask"
 msgstr ""
-#: ../misc/m.nviz.image/vector.c:300 ../misc/m.nviz.image/vector.c:309
-#: ../misc/m.nviz.image/vector.c:319 ../misc/m.nviz.image/vector.c:329
-#, c-format
-msgid "Column <%s> in table <%s> not found"
+#: ../vector/v.surf.rst/main.c:275 ../vector/v.vol.rst/main.c:267
+msgid "Tension parameter"
 msgstr ""
-#: ../misc/m.nviz.image/vector.c:304
-msgid "Data type of color column must be character"
+#: ../vector/v.surf.rst/main.c:282 ../vector/v.vol.rst/main.c:275
+msgid "Smoothing parameter"
 msgstr ""
-#: ../misc/m.nviz.image/vector.c:314
-msgid "Data type of size column must be numeric"
+#: ../vector/v.surf.rst/main.c:290
+msgid "Name of the attribute column with smoothing parameters"
 msgstr ""
-#: ../misc/m.nviz.image/vector.c:324
-msgid "Data type of width column must be numeric"
+#: ../vector/v.surf.rst/main.c:298 ../vector/v.vol.rst/main.c:310
+#: ../locale/scriptstrings/r.fillnulls_to_translate.c:14
+msgid "Maximum number of points in a segment"
+msgstr "Maksimālais punktu skaits vienā segmentā"
+#: ../vector/v.surf.rst/main.c:307 ../vector/v.vol.rst/main.c:319
+#: ../locale/scriptstrings/r.fillnulls_to_translate.c:12
+msgid "Minimum number of points for approximation in a segment (>segmax)"
 msgstr ""
-#: ../misc/m.nviz.image/vector.c:335
-msgid "Data type of marker column must be character"
+#: ../vector/v.surf.rst/main.c:315 ../vector/v.vol.rst/main.c:336
+msgid "Minimum distance between points (to remove almost identical points)"
 msgstr ""
-#: ../misc/m.nviz.image/main.c:56
-msgid "Creates a 3D rendering of GIS data."
+#: ../vector/v.surf.rst/main.c:323
+msgid ""
+"Maximum distance between points on isoline (to insert additional points)"
 msgstr ""
-#: ../misc/m.nviz.image/main.c:57
-msgid "Renders surfaces (raster data), 2D/3D vector data, and volumes (3D raster data) in 3D."
+#: ../vector/v.surf.rst/main.c:332
+msgid "Conversion factor for values used for approximation"
 msgstr ""
-#: ../misc/m.nviz.image/main.c:83
-msgid "Unable to render data"
+#: ../vector/v.surf.rst/main.c:340 ../raster/r.resamp.rst/main.c:246
+msgid "Anisotropy angle (in degrees counterclockwise from East)"
 msgstr ""
-#: ../misc/m.nviz.image/main.c:142
-#, c-format
-msgid "Vertical exaggeration not given, using calculated value %.0f"
+#: ../vector/v.surf.rst/main.c:347 ../raster/r.resamp.rst/main.c:253
+msgid "Anisotropy scaling factor"
 msgstr ""
-#: ../misc/m.nviz.image/main.c:154
+#: ../vector/v.surf.rst/main.c:404 ../raster/r.sim/r.sim.sediment/main.c:374
+#: ../raster/r.sim/r.sim.water/main.c:402
 #, c-format
-msgid "Viewpoint height not given, using calculated value %.0f"
+msgid ""
+"<%d> is not valid number of threads. Number of threads will be set on <%d>"
 msgstr ""
-#: ../misc/m.nviz.image/main.c:240
-msgid "Unsupported output format"
+#: ../vector/v.surf.rst/main.c:409
+msgid "Parallel computation disabled when deviation output is required"
 msgstr ""
-#: ../misc/m.nviz.image/main.c:242 ../imagery/i.cluster/main.c:354
-#, c-format
-msgid "File <%s> created."
+#: ../vector/v.surf.rst/main.c:416
+msgid ""
+"GRASS GIS is not compiled with OpenMP support, parallel computation is "
+"disabled."
 msgstr ""
-#: ../misc/m.nviz.image/volume.c:42 ../misc/m.nviz.image/volume.c:133
+#: ../vector/v.surf.rst/main.c:421 ../vector/v.surf.rst/main.c:426
+#: ../vector/v.surf.rst/main.c:431 ../vector/v.surf.rst/main.c:436
 #, c-format
-msgid "3d raster map <%s> not found"
+msgid "Output vector map name <%s> is not valid map name"
 msgstr ""
-#: ../misc/m.nviz.image/volume.c:96 ../misc/m.nviz.image/volume.c:256
-#, c-format
-msgid "Error tokenize '%s'"
+#: ../vector/v.surf.rst/main.c:449
+msgid "You are not outputting any raster or vector maps"
 msgstr ""
-#: ../misc/m.nviz.image/volume.c:103 ../misc/m.nviz.image/volume.c:271
-#, c-format
-msgid "Volume set number %d is not available"
+#: ../vector/v.surf.rst/main.c:458
+msgid ""
+"Both cross-validation options (-c flag and cvdev vector output) must be "
+"specified"
 msgstr ""
-#: ../misc/m.nviz.image/volume.c:108
-#, c-format
-msgid "Unable to add isosurface (volume set %d)"
+#: ../vector/v.surf.rst/main.c:461
+msgid ""
+"The cross-validation cannot be computed simultaneously with output raster or "
+"devi file"
 msgstr ""
-#: ../misc/m.nviz.image/volume.c:119 ../misc/m.nviz.image/volume.c:140
-#: ../misc/m.nviz.image/volume.c:153 ../misc/m.nviz.image/volume.c:172
-#: ../misc/m.nviz.image/volume.c:182 ../misc/m.nviz.image/volume.c:195
-#: ../misc/m.nviz.image/volume.c:205
-#, c-format
-msgid "Unable to set isosurface (%d) attribute (%d) of volume %d"
+#: ../vector/v.surf.rst/main.c:479
+msgid "Using anisotropy - both theta and scalex have to be specified"
 msgstr ""
-#: ../misc/m.nviz.image/volume.c:267
-#, c-format
-msgid "Wrong name for axis: %s"
+#: ../vector/v.surf.rst/main.c:487
+msgid "Both smatt and smooth options specified - using constant"
 msgstr ""
-#: ../misc/m.nviz.image/volume.c:276
-#, c-format
-msgid "Unable to add slice (volume set %d)"
+#: ../vector/v.surf.rst/main.c:497
+msgid "The computation will last too long - lower npmin is suggested"
 msgstr ""
-#: ../misc/m.nviz.image/volume.c:288
+#: ../vector/v.surf.rst/main.c:515 ../vector/v.surf.rst/main.c:520
+#: ../vector/v.surf.rst/main.c:524 ../vector/v.surf.rst/main.c:529
+#: ../vector/v.surf.rst/main.c:533 ../vector/v.surf.rst/main.c:537
+#: ../vector/v.vol.rst/user3.c:273 ../vector/v.vol.rst/user3.c:279
+#: ../vector/v.vol.rst/user3.c:285 ../vector/v.vol.rst/main.c:507
+#: ../vector/v.vol.rst/main.c:510 ../vector/v.vol.rst/main.c:513
+#: ../vector/v.vol.rst/main.c:516 ../vector/v.vol.rst/main.c:519
+#: ../vector/v.vol.rst/main.c:522 ../vector/v.vol.rst/main.c:525
+#: ../vector/v.vol.rst/main.c:528 ../vector/v.vol.rst/main.c:531
+#: ../vector/v.vol.rst/main.c:534 ../vector/v.vol.rst/main.c:621
+#: ../vector/v.vol.rst/main.c:652 ../vector/v.vol.rst/main.c:674
+#: ../vector/v.vol.rst/main.c:696 ../vector/v.vol.rst/main.c:718
+#: ../vector/v.vol.rst/main.c:740 ../vector/v.vol.rst/main.c:762
+#: ../vector/v.vol.rst/main.c:784 ../vector/v.vol.rst/user2.c:122
+#: ../vector/v.vol.rst/user2.c:232
 #, c-format
-msgid "Unable to set slice (%d) position of volume %d"
+msgid "Not enough memory for %s"
 msgstr ""
-#: ../misc/m.nviz.image/volume.c:294
+#: ../vector/v.surf.rst/main.c:544 ../vector/v.surf.rst/main.c:550
+#: ../vector/v.surf.rst/main.c:553 ../vector/v.surf.rst/main.c:557
+#: ../vector/v.vol.rst/main.c:539 ../vector/v.vol.rst/main.c:544
+#: ../vector/v.vol.rst/main.c:546
 #, c-format
-msgid "Unable to set slice (%d) transparency of volume %d"
+msgid "Unable to create %s"
 msgstr ""
-#: ../misc/m.nviz.image/cplane.c:40
+#: ../vector/v.surf.rst/main.c:570 ../vector/v.out.ascii/main.c:104
+#: ../vector/v.colors/main.c:270 ../vector/v.colors.out/make_colors.c:27
+#: ../vector/v.colors.out/scan_cats.c:24
 #, c-format
-msgid "Cutting plane number <%d> not found"
+msgid "Layer <%s> not found"
 msgstr ""
-#: ../visualization/ximgview/main.c:64 ../general/g.cairocomp/main.c:89
-#: ../general/g.cairocomp/main.c:256
-msgid "Unable to open display"
+#: ../vector/v.surf.rst/main.c:574 ../vector/v.surf.bspline/main.c:277
+msgid ""
+"Input is 3D: using attribute values instead of z-coordinates for "
+"approximation"
 msgstr ""
-#: ../visualization/ximgview/main.c:84
-msgid "Unable to get window attributes"
+#: ../vector/v.surf.rst/main.c:576 ../vector/v.surf.bspline/main.c:279
+msgid "Input is 3D: using z-coordinates for approximation"
 msgstr ""
-#: ../visualization/ximgview/main.c:258
-msgid "Unable to open image file"
+#: ../vector/v.surf.rst/main.c:580
+msgid "Input is 2D: using attribute values for approximation"
 msgstr ""
-#: ../visualization/ximgview/main.c:261
-msgid "Unable to read BMP header"
+#: ../vector/v.surf.rst/main.c:582
+msgid "Input is 2D: using category values for approximation"
 msgstr ""
-#: ../visualization/ximgview/main.c:264
-msgid "Invalid BMP header"
+#: ../vector/v.surf.rst/main.c:625 ../vector/v.vol.rst/main.c:605
+#, c-format
+msgid "Unable to create table '%s'"
 msgstr ""
-#: ../visualization/ximgview/main.c:270
-msgid "Unable to map image file"
+#: ../vector/v.surf.rst/main.c:656 ../vector/v.surf.rst/main.c:711
+#: ../vector/v.vol.rst/main.c:914 ../raster/r.sim/r.sim.sediment/main.c:422
+#: ../raster/r.sim/r.sim.water/main.c:530
+msgid "Input failed"
 msgstr ""
-#: ../visualization/ximgview/main.c:290 ../general/g.cairocomp/main.c:197
-#: ../general/g.pnmcomp/main.c:283 ../general/g.ppmtopng/main.c:118
-#: ../locale/scriptstrings/d.shade_to_translate.c:2
-#: ../locale/scriptstrings/d.redraw_to_translate.c:2
-#: ../locale/scriptstrings/d.frame_to_translate.c:2
-#: ../locale/scriptstrings/d.out.file_to_translate.c:2
-#: ../locale/scriptstrings/d.correlate_to_translate.c:2
-#: ../locale/scriptstrings/d.what.vect_to_translate.c:2
-#: ../locale/scriptstrings/d.rast.leg_to_translate.c:2
-#: ../locale/scriptstrings/d.to.rast_to_translate.c:2
-#: ../locale/scriptstrings/d.polar_to_translate.c:2
-#: ../locale/scriptstrings/wxpyimgview_to_translate.c:2
-#: ../locale/scriptstrings/d.rast.edit_to_translate.c:2
-#: ../locale/scriptstrings/d.what.rast_to_translate.c:2
-#: ../raster3d/r3.mkdspf/main.c:80 ../display/d.his/main.c:62
-#: ../display/d.colortable/main.c:60 ../display/d.labels/main.c:43
-#: ../display/d.rast.arrow/main.c:97 ../display/d.geodesic/main.c:46
-#: ../display/d.mon/main.c:38 ../display/d.rast/main.c:53
-#: ../display/d.font/main.c:45 ../display/d.vect/main.c:73
-#: ../display/d.graph/main.c:58 ../display/d.extract/main.c:49
-#: ../display/d.rast.num/main.c:77 ../display/d.legend/main.c:78
-#: ../display/d.barscale/main.c:63 ../display/d.colorlist/main.c:35
-#: ../display/d.vect.thematic/main.c:85 ../display/d.rhumbline/main.c:44
-#: ../display/d.grid/main.c:53 ../display/d.legend.vect/main.c:50
-#: ../display/d.profile/main.c:191 ../display/d.path/main.c:48
-#: ../display/d.vect.chart/main.c:63 ../display/d.info/main.c:34
-#: ../display/d.histogram/main.c:83 ../display/d.text/main.c:138
-#: ../display/d.fontlist/main.c:45 ../display/d.erase/main.c:29
-#: ../display/d.where/main.c:43 ../display/d.title/main.c:49
-#: ../display/d.northarrow/main.c:46 ../display/d.linegraph/main.c:231
-#: ../display/d.rgb/main.c:53
-msgid "display"
+#: ../vector/v.surf.rst/main.c:695
+#, c-format
+msgid ""
+"Processing all selected output files will require %d bytes of disk space for "
+"temp files"
 msgstr ""
-#: ../visualization/ximgview/main.c:295
-msgid "View BMP images from the PNG driver."
-msgstr ""
+#: ../vector/v.surf.rst/main.c:716
+#, fuzzy
+msgid "Processing segments in parallel..."
+msgstr "Izveidot punktus visā garumā ilīniju garumā"
-#: ../visualization/ximgview/main.c:301
-msgid "Image file"
+#: ../vector/v.surf.rst/main.c:722 ../vector/v.surf.rst/main.c:731
+msgid "Interp_segmets failed"
 msgstr ""
-#: ../visualization/ximgview/main.c:308
-#: ../locale/scriptstrings/wxpyimgview_to_translate.c:6
-msgid "Percentage of CPU time to use"
+#: ../vector/v.surf.rst/main.c:725
+msgid "Processing segments..."
 msgstr ""
-#: ../visualization/ximgview/color.c:90 ../visualization/ximgview/color.c:288
-#, c-format
-msgid "Unknown visual class [%d]."
+#: ../vector/v.surf.rst/main.c:749
+msgid "Unable to write raster maps - try to increase resolution"
 msgstr ""
-#: ../visualization/ximgview/color.c:239
-msgid "Unable to get sufficient gray shades."
+#: ../vector/v.surf.rst/main.c:843 ../vector/v.profile/processors.c:31
+#: ../vector/v.net.allpairs/main.c:201 ../vector/v.kcv/main.c:208
+#: ../vector/v.vol.rst/user1.c:423 ../vector/v.generalize/simplification.c:33
+#: ../vector/v.generalize/simplification.c:40
+#: ../vector/v.generalize/simplification.c:306
+#: ../vector/v.generalize/simplification.c:314
+#: ../vector/v.generalize/simplification.c:338
+#: ../vector/v.generalize/smoothing.c:144
+#: ../vector/v.generalize/smoothing.c:231
+#: ../vector/v.generalize/smoothing.c:374
+#: ../vector/v.generalize/smoothing.c:528
+#: ../vector/v.generalize/smoothing.c:574
+#: ../vector/v.generalize/smoothing.c:578
+#: ../vector/v.generalize/smoothing.c:582
+#: ../vector/v.generalize/smoothing.c:586
+#: ../vector/v.generalize/smoothing.c:590
+#: ../vector/v.generalize/smoothing.c:594
+#: ../vector/v.generalize/smoothing.c:598 ../vector/v.generalize/network.c:96
+#: ../vector/v.generalize/network.c:131 ../vector/v.generalize/matrix.c:144
+#: ../vector/v.net.components/main.c:170 ../vector/v.net.flow/main.c:232
+#: ../vector/v.mkgrid/write_grid.c:28 ../vector/v.net.connectivity/main.c:186
+#: ../vector/v.net.connectivity/main.c:202 ../vector/v.net.timetable/main.c:389
+#: ../vector/v.net.timetable/main.c:399 ../vector/v.net.distance/main.c:228
+#: ../vector/v.net.centrality/main.c:293 ../vector/v.net.centrality/main.c:298
+#: ../vector/v.net.centrality/main.c:304 ../vector/v.net.centrality/main.c:310
+#: ../vector/v.net.centrality/main.c:316 ../raster/r.stream.extract/seg.c:56
+#: ../raster/r.stream.extract/dseg.c:51 ../raster/r.stream.extract/cseg.c:51
+#: ../raster/r.stream.extract/bseg.c:50 ../raster/r.li/r.li.daemon/list.c:49
+#: ../raster/r.to.rast3/main.c:244 ../raster/r.sun/main.c:854
+#: ../raster/r.sun/main.c:865 ../raster/r.sun/main.c:878
+#: ../raster/r.sun/main.c:890 ../raster/r.sun/main.c:901
+#: ../raster/r.sun/main.c:912 ../raster/r.sun/main.c:923
+#: ../raster/r.sun/main.c:935 ../raster/r.sun/main.c:946
+#: ../raster3d/r3.to.rast/main.c:360 ../db/drivers/postgres/listtab.c:92
+#: ../db/drivers/postgres/listdb.c:88 ../db/drivers/sqlite/listdb.c:134
+#: ../imagery/i.smap/multialloc.c:115
+msgid "Out of memory"
 msgstr ""
-#: ../visualization/ximgview/color.c:256
-msgid "Unable to get sufficient colors."
+#: ../vector/v.surf.rst/main.c:864 ../vector/v.in.ascii/main.c:275
+#: ../raster/r.resamp.rst/main.c:542 ../raster/r.in.ascii/main.c:120
+#: ../raster/r.in.ascii/main.c:150 ../general/g.setproj/get_stp.c:162
+#: ../general/g.setproj/get_stp.c:165 ../general/g.setproj/get_stp.c:282
+#: ../general/g.setproj/get_stp.c:286 ../raster3d/r3.in.ascii/main.c:169
+#: ../display/d.title/main.c:117
+#, c-format
+msgid "Unable to open temporary file <%s>"
 msgstr ""
-#: ../visualization/ximgview/color.c:269
-msgid "Using private colormap for DirectColor visual."
+#: ../vector/v.surf.rst/main.c:869 ../raster/r.resamp.rst/main.c:547
+#: ../raster/r.thin/io.c:131 ../raster/r.thin/io.c:138
+#: ../raster/r.thin/io.c:147
+#, c-format
+msgid "Error writing temporary file <%s>"
 msgstr ""
-#: ../general/g.findfile/element.c:7
-msgid "List of available elements:"
+#: ../vector/v.lidar.correction/main.c:72 ../vector/v.lidar.growing/main.c:76
+#: ../vector/v.in.lidar/main.c:138 ../vector/v.outlier/main.c:74
+#: ../vector/v.out.lidar/main.c:473 ../vector/v.surf.bspline/main.c:94
+#: ../vector/v.lidar.edgedetection/main.c:76 ../vector/v.decimate/main.c:124
+#: ../raster/r.in.lidar/main.c:110 ../raster/r.in.xyz/main.c:165
+#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:5
+#: ../raster3d/r3.in.lidar/main.c:164
+msgid "LIDAR"
 msgstr ""
-#: ../general/g.findfile/main.c:38 ../general/g.cairocomp/main.c:196
-#: ../general/g.gui/main.c:39 ../general/g.dirseps/main.c:34
-#: ../general/g.version/main.c:65 ../general/g.remove/main.c:69
-#: ../general/g.mapset/main.c:49 ../general/g.pnmcomp/main.c:282
-#: ../general/g.list/main.c:65 ../general/g.setproj/main.c:78
-#: ../general/g.mapsets/main.c:63 ../general/g.rename/main.c:45
-#: ../general/g.region/main.c:64 ../general/g.proj/main.c:64
-#: ../general/g.mkfontcap/main.c:71 ../general/g.findetc/main.c:28
-#: ../general/g.ppmtopng/main.c:117 ../general/g.filename/main.c:39
-#: ../general/g.tempfile/main.c:38 ../general/g.copy/main.c:41
-#: ../general/g.message/main.c:33 ../general/g.access/main.c:37
-#: ../general/g.gisenv/main.c:43
-#: ../locale/scriptstrings/g.search.modules_to_translate.c:2
-#: ../locale/scriptstrings/g.extension.all_to_translate.c:3
-#: ../locale/scriptstrings/g.extension_to_translate.c:3
-#: ../locale/scriptstrings/g.manual_to_translate.c:2
-msgid "general"
+#: ../vector/v.lidar.correction/main.c:74
+msgid ""
+"Corrects the v.lidar.growing output. It is the last of the three algorithms "
+"for LIDAR filtering."
 msgstr ""
-#: ../general/g.findfile/main.c:39 ../general/g.dirseps/main.c:35
-#: ../general/g.remove/main.c:70 ../general/g.list/main.c:66
-#: ../general/g.rename/main.c:46 ../general/g.findetc/main.c:29
-#: ../general/g.filename/main.c:40 ../general/g.copy/main.c:42
-#: ../general/g.access/main.c:38
-#: ../locale/scriptstrings/t.rename_to_translate.c:3
-#: ../locale/scriptstrings/t.rast3d.list_to_translate.c:3
-#: ../locale/scriptstrings/t.list_to_translate.c:3
-#: ../locale/scriptstrings/t.rast.list_to_translate.c:3
-#: ../locale/scriptstrings/t.create_to_translate.c:3
-#: ../locale/scriptstrings/t.unregister_to_translate.c:3
-#: ../locale/scriptstrings/t.vect.list_to_translate.c:3
-#: ../locale/scriptstrings/t.remove_to_translate.c:3
-#: ../locale/scriptstrings/t.register_to_translate.c:3
-#: ../raster/r.compress/main.c:69 ../imagery/i.target/main.c:46
-#: ../imagery/i.group/main.c:53
-msgid "map management"
+#: ../vector/v.lidar.correction/main.c:78
+#: ../vector/v.lidar.edgedetection/main.c:83
+msgid "Estimate point density and distance and quit"
 msgstr ""
-#: ../general/g.findfile/main.c:40 ../general/g.dirseps/main.c:36
-#: ../general/g.findetc/main.c:30 ../general/g.filename/main.c:41
-#: ../general/g.tempfile/main.c:40 ../general/g.message/main.c:35
-#: ../general/g.gisenv/main.c:46
-msgid "scripts"
+#: ../vector/v.lidar.correction/main.c:80 ../vector/v.surf.bspline/main.c:107
+#: ../vector/v.lidar.edgedetection/main.c:85
+msgid ""
+"Estimate point density and distance in map units for the input vector points "
+"within the current region extents and quit"
 msgstr ""
-#: ../general/g.findfile/main.c:42
-msgid "Searches for GRASS data base files and sets variables for the shell."
+#: ../vector/v.lidar.correction/main.c:85
+msgid "Input observation vector map name (v.lidar.growing output)"
 msgstr ""
-#: ../general/g.findfile/main.c:53 ../general/g.filename/main.c:50
-msgid "Name of an element"
-msgstr "Elementa nosaukums"
-#: ../general/g.findfile/main.c:59
-msgid "Name of an existing map"
+#: ../vector/v.lidar.correction/main.c:88
+msgid "Output classified vector map name"
 msgstr ""
-#: ../general/g.findfile/main.c:65
-msgid "Name of a mapset (default: search path)"
+#: ../vector/v.lidar.correction/main.c:93
+msgid "Name for output only 'terrain' points vector map"
 msgstr ""
-#: ../general/g.findfile/main.c:66
-msgid "'.' for current mapset"
+#: ../vector/v.lidar.correction/main.c:100 ../vector/v.outlier/main.c:102
+#: ../vector/v.surf.bspline/main.c:148
+#: ../vector/v.lidar.edgedetection/main.c:97
+msgid "Length of each spline step in the east-west direction"
 msgstr ""
-#: ../general/g.findfile/main.c:70
-msgid "Do not add quotes"
+#: ../vector/v.lidar.correction/main.c:101
+#, fuzzy
+msgid "Default: 25 * east-west resolution"
+msgstr "Vēlamā austrumi-rietumi izšķirtspēja"
+#: ../vector/v.lidar.correction/main.c:102
+#: ../vector/v.lidar.correction/main.c:111 ../vector/v.surf.idw/main.c:115
+#: ../vector/v.surf.idw/main.c:124 ../vector/v.surf.idw/main.c:132
+#: ../vector/v.db.connect/main.c:66 ../vector/v.db.connect/main.c:72
+#: ../vector/v.external.out/args.c:20 ../vector/v.external.out/args.c:35
+#: ../vector/v.external.out/args.c:47 ../vector/v.external.out/args.c:53
+#: ../vector/v.vol.rst/main.c:268 ../vector/v.vol.rst/main.c:276
+#: ../vector/v.vol.rst/main.c:283 ../vector/v.vol.rst/main.c:311
+#: ../vector/v.vol.rst/main.c:320 ../vector/v.vol.rst/main.c:329
+#: ../vector/v.vol.rst/main.c:337 ../vector/v.vol.rst/main.c:346
+#: ../vector/v.vol.rst/main.c:354 ../vector/v.outlier/main.c:104
+#: ../vector/v.outlier/main.c:113 ../vector/v.outlier/main.c:121
+#: ../vector/v.surf.bspline/main.c:113 ../vector/v.surf.bspline/main.c:120
+#: ../vector/v.surf.bspline/main.c:150 ../vector/v.surf.bspline/main.c:159
+#: ../vector/v.surf.bspline/main.c:167 ../vector/v.surf.bspline/main.c:179
+#: ../vector/v.lidar.edgedetection/main.c:99
+#: ../vector/v.lidar.edgedetection/main.c:108
+#: ../vector/v.lidar.edgedetection/main.c:117
+#: ../vector/v.lidar.edgedetection/main.c:126
+#: ../vector/v.lidar.edgedetection/main.c:135
+#: ../vector/v.lidar.edgedetection/main.c:143
+#: ../vector/v.lidar.edgedetection/main.c:152 ../vector/v.colors.out/main.c:68
+#: ../vector/v.colors.out/main.c:73 ../raster/r.walk/main.c:274
+#: ../raster/r.walk/main.c:284 ../raster/r.walk/main.c:294
+#: ../raster/r.slope.aspect/main.c:181 ../raster/r.slope.aspect/main.c:189
+#: ../raster/r.slope.aspect/main.c:247 ../raster/r.slope.aspect/main.c:256
+#: ../raster/r.slope.aspect/main.c:262 ../raster/r.resamp.bspline/main.c:107
+#: ../raster/r.resamp.bspline/main.c:115 ../raster/r.resamp.bspline/main.c:121
+#: ../raster/r.resamp.bspline/main.c:133 ../raster/r.resamp.bspline/main.c:138
+#: ../raster/r.resamp.rst/main.c:210 ../raster/r.resamp.rst/main.c:216
+#: ../raster/r.resamp.rst/main.c:224 ../raster/r.resamp.rst/main.c:232
+#: ../raster/r.resamp.rst/main.c:240 ../raster/r.in.bin/main.c:275
+#: ../raster/r.in.bin/main.c:280 ../raster/r.in.bin/main.c:306
+#: ../raster/r.in.bin/main.c:314 ../raster/r.in.bin/main.c:323
+#: ../raster/r.in.bin/main.c:384 ../raster/r.in.bin/main.c:398
+#: ../raster/r.out.mpeg/main.c:132 ../general/g.access/main.c:50
+#: ../general/g.access/main.c:58 ../db/db.login/main.c:60
+#: ../db/db.login/main.c:68 ../db/db.login/main.c:77 ../db/db.login/main.c:86
+#: ../display/d.mon/main.c:82 ../display/d.mon/main.c:90
+#: ../display/d.mon/main.c:98 ../display/d.mon/main.c:104
+#: ../display/d.mon/main.c:110 ../display/d.mon/main.c:145
+#: ../display/d.mon/main.c:151 ../display/d.mon/main.c:157
+#: ../imagery/i.landsat.toar/main.c:159 ../imagery/i.landsat.toar/main.c:168
+#: ../imagery/i.landsat.toar/main.c:178 ../imagery/i.landsat.toar/main.c:187
+#: ../imagery/i.landsat.toar/main.c:208 ../imagery/i.cluster/main.c:103
+#: ../imagery/i.cluster/main.c:120 ../imagery/i.cluster/main.c:128
+#: ../imagery/i.cluster/main.c:137 ../imagery/i.cluster/main.c:145
+#: ../imagery/i.cluster/main.c:153 ../imagery/i.segment/parse_args.c:68
+#: ../imagery/i.segment/parse_args.c:77 ../imagery/i.segment/parse_args.c:88
+#: ../imagery/i.segment/parse_args.c:99 ../imagery/i.segment/parse_args.c:109
+#: ../imagery/i.segment/parse_args.c:127 ../imagery/i.segment/parse_args.c:135
+#: ../imagery/i.segment/parse_args.c:144 ../imagery/i.segment/parse_args.c:151
+#: ../imagery/i.segment/parse_args.c:157 ../imagery/i.segment/parse_args.c:163
+#: ../imagery/i.segment/parse_args.c:169 ../imagery/i.segment/parse_args.c:176
+msgid "Settings"
 msgstr ""
-#: ../general/g.findfile/main.c:74
-msgid "List available elements and exit"
+#: ../vector/v.lidar.correction/main.c:109 ../vector/v.outlier/main.c:111
+#: ../vector/v.surf.bspline/main.c:157
+#: ../vector/v.lidar.edgedetection/main.c:106
+msgid "Length of each spline step in the north-south direction"
 msgstr ""
-#: ../general/g.findfile/main.c:97
-#, c-format
-msgid "Parameter 'file' contains reference to <%s> mapset, but mapset parameter <%s> does not correspond"
+#: ../vector/v.lidar.correction/main.c:110
+#, fuzzy
+msgid "Default: 25 * north-south resolution"
+msgstr "Vēlamā ziemeļi-dienvidi izšķirtspēja"
+#: ../vector/v.lidar.correction/main.c:118
+msgid "Regularization weight in reclassification evaluation"
 msgstr ""
-#: ../general/g.cairocomp/main.c:46 ../raster3d/r3.support/main.c:167
-#: ../raster/r.in.xyz/main.c:582 ../raster/r.series.accumulate/main.c:221
-#: ../raster/r.series/main.c:223 ../raster/r.in.mat/main.c:125
-#: ../raster/r.mapcalc/main.c:48 ../raster/r.support/main.c:176
-#: ../raster/r.topmodel/file_io.c:28 ../raster/r.topmodel/file_io.c:136
-#: ../raster/r.topmodel/file_io.c:161 ../display/d.legend.vect/main.c:259
-#: ../display/d.legend.vect/main.c:273 ../display/d.legend.vect/draw.c:72
-#: ../display/d.text/main.c:382 ../display/d.where/main.c:163
-#: ../display/d.linegraph/main.c:415 ../display/d.linegraph/main.c:432
-#: ../display/d.linegraph/main.c:730 ../vector/v.segment/main.c:98
-#: ../vector/v.lrs/v.lrs.segment/main.c:133 ../vector/v.net.path/path.c:49
-#, c-format
-msgid "Unable to open input file <%s>"
+#: ../vector/v.lidar.correction/main.c:126
+msgid "High threshold for object to terrain reclassification"
 msgstr ""
-#: ../general/g.cairocomp/main.c:49 ../scripts/r3.in.xyz/r3.in.xyz.py:212
-#: ../scripts/v.in.lines/v.in.lines.py:75
-#, c-format, python-format
-msgid "Unable to read input file <%s>"
+#: ../vector/v.lidar.correction/main.c:134
+msgid "Low threshold for terrain to object reclassification"
 msgstr ""
-#: ../general/g.cairocomp/main.c:52
+#: ../vector/v.lidar.correction/main.c:165 ../vector/v.outlier/main.c:210
+#: ../vector/v.lidar.edgedetection/main.c:190
 #, c-format
-msgid "Unable to parse input file <%s>"
+msgid "Input vector map <%s> is not 3D!"
 msgstr ""
-#: ../general/g.cairocomp/main.c:66 ../raster3d/r3.support/main.c:153
-#: ../raster/r.out.png/main.c:205 ../raster/r.out.pov/main.c:173
-#: ../raster/r.out.mat/main.c:91 ../raster/r.out.vrml/main.c:131
-#: ../raster/r.colors.out/raster3d_main.c:80
-#: ../raster/r.colors.out/raster_main.c:79 ../raster/r.support/main.c:162
-#: ../vector/v.colors.out/main.c:103
+#: ../vector/v.lidar.correction/main.c:171
+#: ../vector/v.lidar.edgedetection/main.c:196
 #, c-format
-msgid "Unable to open output file <%s>"
+msgid "Estimated point density: %.4g\n"
 msgstr ""
-#: ../general/g.cairocomp/main.c:71
+#: ../vector/v.lidar.correction/main.c:172
+#: ../vector/v.lidar.edgedetection/main.c:197
 #, c-format
-msgid "Unable to write output file <%s>"
+msgid "Estimated mean distance between points: %.4g\n"
 msgstr ""
-#: ../general/g.cairocomp/main.c:113
-msgid "Unable to obtain visual"
+#: ../vector/v.lidar.correction/main.c:175 ../vector/v.outlier/main.c:220
+#: ../vector/v.lidar.edgedetection/main.c:200
+msgid "No points in current region!"
 msgstr ""
-#: ../general/g.cairocomp/main.c:129
-msgid "Failed to initialize output surface"
+#: ../vector/v.lidar.correction/main.c:182 ../vector/v.outlier/main.c:146
+#: ../vector/v.lidar.edgedetection/main.c:207
+msgid "Unable to read name of database"
 msgstr ""
-#: ../general/g.cairocomp/main.c:150 ../general/g.pnmcomp/main.c:38
-#, c-format
-msgid "Invalid color: %s"
+#: ../vector/v.lidar.correction/main.c:185 ../vector/v.outlier/main.c:149
+#: ../vector/v.lidar.edgedetection/main.c:210
+msgid "Unable to read name of driver"
 msgstr ""
-#: ../general/g.cairocomp/main.c:171
-msgid "Failed to initialize input surface"
+#: ../vector/v.lidar.correction/main.c:199
+#: ../vector/v.lidar.correction/main.c:235 ../vector/v.lidar.growing/main.c:163
+#: ../vector/v.outlier/main.c:193 ../vector/v.outlier/main.c:261
+#: ../vector/v.surf.bspline/main.c:252 ../vector/v.surf.bspline/main.c:412
+#: ../vector/v.lidar.edgedetection/main.c:227
+#: ../vector/v.lidar.edgedetection/main.c:239
+#: ../vector/v.lidar.edgedetection/main.c:261
+#, c-format
+msgid "No database connection for driver <%s> is defined. Run db.connect."
 msgstr ""
-#: ../general/g.cairocomp/main.c:198
-msgid "Overlays multiple X Pixmaps."
+#: ../vector/v.lidar.correction/main.c:204 ../vector/v.outlier/main.c:198
+#: ../vector/v.surf.bspline/main.c:257
+#: ../vector/v.lidar.edgedetection/main.c:230
+#: ../vector/v.lidar.edgedetection/main.c:242
+msgid "Old auxiliary table could not be dropped"
 msgstr ""
-#: ../general/g.cairocomp/main.c:203 ../general/g.pnmcomp/main.c:290
-msgid "Name of input file(s)"
-msgstr ""
+#: ../vector/v.lidar.correction/main.c:278
+#, c-format
+msgid "Adjusted EW spline %d"
+msgid_plural "Adjusted EW splines %d"
+msgstr[0] ""
+msgstr[1] ""
+msgstr[2] ""
-#: ../general/g.cairocomp/main.c:212
-msgid "Output Visual XID"
-msgstr ""
+#: ../vector/v.lidar.correction/main.c:281
+#, c-format
+msgid "Adjusted NS spline %d"
+msgid_plural "Adjusted NS splines %d"
+msgstr[0] ""
+msgstr[1] ""
+msgstr[2] ""
-#: ../general/g.cairocomp/main.c:218
-msgid "Output screen"
+#: ../vector/v.lidar.correction/main.c:338
+#: ../vector/v.lidar.edgedetection/main.c:360
+#, c-format
+msgid "Subregion %d of %d"
 msgstr ""
-#: ../general/g.cairocomp/main.c:224 ../general/g.pnmcomp/main.c:302
-msgid "Layer opacities"
+#: ../vector/v.lidar.correction/main.c:376
+msgid "Performing mean calculation..."
 msgstr ""
-#: ../general/g.cairocomp/main.c:230 ../general/g.pnmcomp/main.c:315
-msgid "Image width"
+#: ../vector/v.lidar.correction/main.c:407 ../vector/v.outlier/main.c:418
+#: ../vector/v.surf.bspline/main.c:170 ../raster/r.resamp.bspline/main.c:124
+msgid "Bilinear interpolation"
 msgstr ""
-#: ../general/g.cairocomp/main.c:236 ../general/g.pnmcomp/main.c:321
-msgid "Image height"
+#: ../vector/v.lidar.correction/main.c:420
+msgid "Correction and creation of terrain vector..."
 msgstr ""
-#: ../general/g.cairocomp/main.c:240
-msgid "Background color (R:G:B:A)"
+#: ../vector/v.lidar.correction/main.c:433
+#: ../vector/v.lidar.edgedetection/main.c:466
+msgid "No data within this subregion. Consider changing the spline step."
 msgstr ""
-#: ../general/g.cairocomp/main.c:245
-msgid "Do not composite; just delete input Pixmaps"
+#: ../vector/v.lidar.correction/main.c:444 ../vector/v.outlier/main.c:460
+#: ../vector/v.surf.bspline/main.c:946
+#: ../vector/v.lidar.edgedetection/main.c:476
+msgid "Auxiliary table could not be dropped"
 msgstr ""
-#: ../general/g.cairocomp/main.c:277
-msgid "input= and opacity= must have the same number of values"
+#: ../vector/v.lidar.correction/correction.c:93
+#: ../vector/v.lidar.correction/correction.c:127
+#: ../vector/v.lidar.correction/correction.c:151
+#: ../vector/v.lidar.correction/correction.c:163
+#: ../vector/v.lidar.correction/correction.c:187
+#: ../vector/v.outlier/outlier.c:86 ../vector/v.outlier/outlier.c:123
+#: ../vector/v.outlier/outlier.c:148 ../vector/v.outlier/outlier.c:161
+#: ../vector/v.outlier/outlier.c:185
+msgid "Impossible to read the database"
 msgstr ""
-#: ../general/g.gui/main.c:40
-msgid "GUI"
+#: ../vector/v.lidar.correction/correction.c:97
+#: ../vector/v.lidar.correction/correction.c:155
+#: ../vector/v.outlier/outlier.c:90 ../vector/v.outlier/outlier.c:152
+msgid "Impossible to update the database"
 msgstr ""
-#: ../general/g.gui/main.c:41
-msgid "user interface"
+#: ../vector/v.lidar.correction/correction.c:107
+#: ../vector/v.lidar.correction/correction.c:115
+#: ../vector/v.lidar.correction/correction.c:210
+#: ../vector/v.outlier/outlier.c:101 ../vector/v.outlier/outlier.c:110
+#: ../vector/v.outlier/outlier.c:207
+msgid "Impossible to write in the database"
 msgstr ""
-#: ../general/g.gui/main.c:44
-msgid "Launches a GRASS graphical user interface (GUI) session."
+#: ../vector/v.sample/main.c:76 ../vector/v.what.rast/main.c:72
+#: ../vector/v.random/main.c:98 ../vector/v.what.rast3/main.c:65
+#: ../vector/v.drape/main.c:58 ../vector/v.extrude/main.c:69
+#: ../raster/r.random.cells/main.c:48 ../raster/r.random/main.c:52
+#: ../locale/scriptstrings/t.sample_to_translate.c:3
+#: ../locale/scriptstrings/v.what.vect_to_translate.c:3
+#: ../locale/scriptstrings/t.vect.observe.strds_to_translate.c:3
+#: ../locale/scriptstrings/t.vect.what.strds_to_translate.c:3
+#: ../locale/scriptstrings/v.what.strds_to_translate.c:4
+#: ../locale/scriptstrings/v.rast.stats_to_translate.c:7
+#: ../locale/scriptstrings/t.rast.what_to_translate.c:3
+#: ../display/d.where/main.c:44
+msgid "sampling"
 msgstr ""
-#: ../general/g.gui/main.c:45
-msgid "Optionally updates default user interface settings."
+#: ../vector/v.sample/main.c:77 ../vector/v.neighbors/main.c:53
+#: ../vector/v.what.rast/main.c:73 ../vector/v.to.rast/main.c:46
+#: ../vector/v.what.rast3/main.c:66 ../raster/r.geomorphon/main.c:104
+#: ../raster/r.covar/main.c:51 ../raster/r.stream.extract/main.c:76
+#: ../raster/r.gwflow/main.c:208 ../raster/r.in.mat/main.c:91
+#: ../raster/r.param.scale/interface.c:54 ../raster/r.resamp.filter/main.c:389
+#: ../raster/r.out.vtk/main.c:59 ../raster/r.series.interp/main.c:64
+#: ../raster/r.relief/main.c:107 ../raster/r.stats.quantile/main.c:516
+#: ../raster/r.horizon/main.c:180 ../raster/r.region/main.c:51
+#: ../raster/r.buffer/main.c:66 ../raster/r.quant/main.c:47
+#: ../raster/r.kappa/main.c:68 ../raster/r.null/main.c:60
+#: ../raster/r.patch/main.c:58 ../raster/r.walk/main.c:178
+#: ../raster/r.out.ppm/main.c:54 ../raster/r.out.vrml/main.c:47
+#: ../raster/r.out.pov/main.c:121 ../raster/r.sunmask/main.c:116
+#: ../raster/r.distance/main.c:39 ../raster/r.volume/main.c:76
+#: ../raster/r.external/main.c:57 ../raster/r.surf.area/main.c:76
+#: ../raster/r.compress/main.c:68 ../raster/r.stats.zonal/main.c:101
+#: ../raster/r.in.poly/main.c:34 ../raster/r.ros/main.c:212
+#: ../raster/r.li/r.li.mps/mps.c:52 ../raster/r.li/r.li.renyi/renyi.c:47
+#: ../raster/r.li/r.li.simpson/simpson.c:46
+#: ../raster/r.li/r.li.shannon/shannon.c:46
+#: ../raster/r.li/r.li.patchnum/main.c:50 ../raster/r.li/r.li.padsd/padsd.c:53
+#: ../raster/r.li/r.li.pielou/pielou.c:46 ../raster/r.li/r.li.shape/main.c:49
+#: ../raster/r.li/r.li.richness/richness.c:43
+#: ../raster/r.li/r.li.patchdensity/main.c:51
+#: ../raster/r.li/r.li.edgedensity/edgedensity.c:48
+#: ../raster/r.li/r.li.dominance/dominance.c:46
+#: ../raster/r.li/r.li.mpa/mpa.c:44 ../raster/r.li/r.li.cwed/cwed.c:54
+#: ../raster/r.li/r.li.padcv/padcv.c:53
+#: ../raster/r.li/r.li.padrange/padrange.c:53
+#: ../raster/r.surf.fractal/main.c:38 ../raster/r.random.cells/main.c:47
+#: ../raster/r.to.vect/main.c:76 ../raster/r.out.bin/main.c:279
+#: ../raster/r.timestamp/main.c:35 ../raster/r.slope.aspect/main.c:151
+#: ../raster/r.out.ppm3/main.c:57 ../raster/r.support.stats/main.c:38
+#: ../raster/r.out.ascii/main.c:59 ../raster/r.external.out/main.c:235
+#: ../raster/r.univar/r.univar_main.c:104 ../raster/r.out.gridatb/main.c:67
+#: ../raster/r.uslek/main.c:53 ../raster/r.grow.distance/main.c:150
+#: ../raster/r.what/main.c:100 ../raster/r.report/main.c:67
+#: ../raster/r.drain/main.c:109 ../raster/r.info/main.c:70
+#: ../raster/r.resamp.bspline/main.c:79 ../raster/r.coin/main.c:66
+#: ../raster/r.to.rast3elev/main.c:361 ../raster/r.out.gdal/main.c:139
+#: ../raster/r.describe/main.c:54 ../raster/r.quantile/main.c:265
+#: ../raster/r.neighbors/main.c:167 ../raster/r.mapcalc/main.c:70
+#: ../raster/r.in.lidar/main.c:108 ../raster/r.rescale/main.c:48
+#: ../raster/r.surf.random/main.c:36 ../raster/r.to.rast3/main.c:197
+#: ../raster/r.contour/main.c:87 ../raster/r.tile/main.c:43
+#: ../raster/r.surf.gauss/main.c:38 ../raster/r.spreadpath/main.c:88
+#: ../raster/r.out.mat/main.c:62 ../raster/r.what.color/main.c:88
+#: ../raster/r.in.gridatb/main.c:45 ../raster/r.resamp.stats/main.c:261
+#: ../raster/r.water.outlet/main.c:57 ../raster/r.surf.contour/main.c:60
+#: ../raster/r.resamp.rst/main.c:148 ../raster/r.composite/main.c:72
+#: ../raster/r.in.xyz/main.c:158 ../raster/r.cross/main.c:69
+#: ../raster/r.support/main.c:54 ../raster/r.sunhours/main.c:72
+#: ../raster/r.clump/main.c:58 ../raster/r.mode/main.c:55
+#: ../raster/r.recode/main.c:48 ../raster/r.circle/main.c:51
+#: ../raster/r.regression.line/main.c:46 ../raster/r.statistics/main.c:55
+#: ../raster/r.solute.transport/main.c:229 ../raster/r.series/main.c:137
+#: ../raster/r.random/main.c:51 ../raster/r.random.surface/main.c:57
+#: ../raster/r.colors.out/raster_main.c:45 ../raster/r.cost/main.c:140
+#: ../raster/r.topidx/main.c:39 ../raster/r.resample/main.c:54
+#: ../raster/r.proj/main.c:144 ../raster/r.profile/main.c:53
+#: ../raster/r.surf.idw/main.c:104 ../raster/r.in.bin/main.c:257
+#: ../raster/r.stats/main.c:106 ../raster/r.topmodel/main.c:51
+#: ../raster/r.resamp.interp/main.c:76 ../raster/r.rescale.eq/main.c:52
+#: ../raster/r.his/main.c:67 ../raster/r.usler/main.c:52
+#: ../raster/r.watershed/front/main.c:73 ../raster/r.out.png/main.c:112
+#: ../raster/r.out.mpeg/main.c:102 ../raster/r.reclass/main.c:50
+#: ../raster/r.regression.multi/main.c:129 ../raster/r.spread/main.c:105
+#: ../raster/r.fill.dir/main.c:86 ../raster/r.in.ascii/main.c:69
+#: ../raster/r.basins.fill/main.c:54 ../raster/r.transect/main.c:103
+#: ../raster/r.flow/main.c:421 ../raster/r.texture/main.c:102
+#: ../raster/r.in.gdal/main.c:92 ../raster/r.fill.stats/main.c:775
+#: ../raster/r.colors/edit_colors.c:63
+#: ../raster/r.sim/r.sim.sediment/main.c:114
+#: ../raster/r.sim/r.sim.water/main.c:113 ../raster/r.carve/main.c:74
+#: ../raster/r.in.png/main.c:519 ../raster/r.category/main.c:52
+#: ../raster/r.mfilter/main.c:56 ../raster/r.sun/main.c:251
+#: ../raster/r.latlong/main.c:56 ../raster/r.series.accumulate/main.c:80
+#: ../raster/r.lake/main.c:150 ../raster/r.thin/main.c:57
+#: ../locale/scriptstrings/r.buffer.lowmem_to_translate.c:3
+#: ../locale/scriptstrings/t.rast.to.rast3_to_translate.c:4
+#: ../locale/scriptstrings/t.rast.export_to_translate.c:4
+#: ../locale/scriptstrings/t.rast.accdetect_to_translate.c:4
+#: ../locale/scriptstrings/r.fillnulls_to_translate.c:2
+#: ../locale/scriptstrings/d.correlate_to_translate.c:4
+#: ../locale/scriptstrings/r.shade_to_translate.c:2
+#: ../locale/scriptstrings/t.rast.aggregate_to_translate.c:4
+#: ../locale/scriptstrings/t.rast.to.vect_to_translate.c:4
+#: ../locale/scriptstrings/r.reclass.area_to_translate.c:2
+#: ../locale/scriptstrings/t.rast.series_to_translate.c:5
+#: ../locale/scriptstrings/t.rast.aggregate.ds_to_translate.c:4
+#: ../locale/scriptstrings/i.spectral_to_translate.c:4
+#: ../locale/scriptstrings/d.rast.edit_to_translate.c:4
+#: ../locale/scriptstrings/t.rast.univar_to_translate.c:4
+#: ../locale/scriptstrings/t.rast.gapfill_to_translate.c:4
+#: ../locale/scriptstrings/t.rast.mapcalc_to_translate.c:4
+#: ../locale/scriptstrings/r.grow_to_translate.c:2
+#: ../locale/scriptstrings/r.mask_to_translate.c:2
+#: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:4
+#: ../locale/scriptstrings/wxpyimgview_to_translate.c:4
+#: ../locale/scriptstrings/r.pack_to_translate.c:2
+#: ../locale/scriptstrings/r.in.srtm_to_translate.c:2
+#: ../locale/scriptstrings/t.rast.list_to_translate.c:4
+#: ../locale/scriptstrings/t.rast.contour_to_translate.c:4
+#: ../locale/scriptstrings/r.tileset_to_translate.c:2
+#: ../locale/scriptstrings/t.rast.colors_to_translate.c:4
+#: ../locale/scriptstrings/t.rast.algebra_to_translate.c:4
+#: ../locale/scriptstrings/r.blend_to_translate.c:2
+#: ../locale/scriptstrings/r.import_to_translate.c:2
+#: ../locale/scriptstrings/d.to.rast_to_translate.c:4
+#: ../locale/scriptstrings/v.rast.stats_to_translate.c:4
+#: ../locale/scriptstrings/r.rgb_to_translate.c:2
+#: ../locale/scriptstrings/r.colors.stddev_to_translate.c:2
+#: ../locale/scriptstrings/t.rast.what_to_translate.c:4
+#: ../locale/scriptstrings/t.rast.extract_to_translate.c:4
+#: ../locale/scriptstrings/t.rast.import_to_translate.c:4
+#: ../locale/scriptstrings/r.plane_to_translate.c:2
+#: ../locale/scriptstrings/r.unpack_to_translate.c:2
+#: ../locale/scriptstrings/r.out.xyz_to_translate.c:2
+#: ../locale/scriptstrings/r.in.wms_to_translate.c:2
+#: ../locale/scriptstrings/t.rast.out.vtk_to_translate.c:4
+#: ../locale/scriptstrings/t.rast.neighbors_to_translate.c:4
+#: ../locale/scriptstrings/r.in.aster_to_translate.c:2
+#: ../misc/m.nviz.script/main.c:71 ../misc/m.nviz.image/main.c:53
+#: ../raster3d/r3.cross.rast/main.c:230 ../raster3d/r3.to.rast/main.c:261
+#: ../doc/raster/r.example/main.c:83 ../visualization/ximgview/main.c:292
+#: ../display/d.rgb/main.c:55 ../display/d.profile/main.c:193
+#: ../display/d.colortable/main.c:61 ../display/d.rast.num/main.c:79
+#: ../display/d.rast.arrow/main.c:99 ../display/d.rast/main.c:55
+msgid "raster"
+msgstr "rastrs"
+#: ../vector/v.sample/main.c:79
+msgid "Samples a raster map at vector point locations."
 msgstr ""
-#: ../general/g.gui/main.c:50
-msgid "User interface"
+#: ../vector/v.sample/main.c:82 ../vector/v.surf.bspline/main.c:110
+msgid "Name of input vector point map"
 msgstr ""
-#: ../general/g.gui/main.c:54
-msgid "wxPython based GUI (wxGUI)"
+#: ../vector/v.sample/main.c:89
+msgid "Name of attribute column to use for comparison"
 msgstr ""
-#: ../general/g.gui/main.c:55
-msgid "command line interface only"
+#: ../vector/v.sample/main.c:92
+msgid "Name for output vector map to store differences"
 msgstr ""
-#: ../general/g.gui/main.c:56
-msgid "command line interface with GUI startup screen"
+#: ../vector/v.sample/main.c:96
+msgid "Name of raster map to be sampled"
 msgstr ""
-#: ../general/g.gui/main.c:60 ../general/g.message/main.c:43
-#: ../general/g.message/main.c:48 ../general/g.message/main.c:53
-#: ../general/g.message/main.c:58
-msgid "Type"
+#: ../vector/v.sample/main.c:107
+msgid "Scaling factor for values read from raster map"
 msgstr ""
-#: ../general/g.gui/main.c:66
-msgid "Name of workspace file to load on start-up"
+#: ../vector/v.sample/main.c:109
+msgid "Sampled values will be multiplied by this factor"
 msgstr ""
-#: ../general/g.gui/main.c:67
-msgid "This is valid only for wxGUI (wxpython)"
+#: ../vector/v.sample/main.c:133 ../vector/v.surf.idw/read_sites.c:50
+#: ../vector/v.reclass/main.c:128
+#, c-format
+msgid "Database connection not defined for layer %s"
 msgstr ""
-#: ../general/g.gui/main.c:71
-msgid "Start GUI in the foreground"
+#: ../vector/v.sample/main.c:148
+#, c-format
+msgid "Column type <%s> not supported (must be integer or double precision)"
 msgstr ""
-#: ../general/g.gui/main.c:72
-msgid "By default the GUI starts in the background and control is immediately returned to the caller. When GUI runs in foregreound, it blocks the command line"
+#: ../vector/v.sample/main.c:152 ../vector/v.univar/main.c:366
+#: ../vector/v.surf.idw/read_sites.c:68 ../vector/v.class/main.c:132
+#: ../vector/v.normal/main.c:134 ../vector/v.vol.rst/user1.c:112
+#: ../vector/v.out.lidar/main.c:132 ../vector/v.out.lidar/main.c:167
+#: ../vector/v.surf.bspline/main.c:398 ../vector/v.to.rast3/main.c:95
+#: ../ps/ps.map/catval.c:66 ../ps/ps.map/catval.c:131 ../ps/ps.map/catval.c:198
+msgid "Unable to select data from table"
 msgstr ""
-#: ../general/g.gui/main.c:78
-msgid "Update default user interface settings"
+#: ../vector/v.sample/main.c:154
+#, c-format
+msgid "%d record selected from table"
+msgid_plural "%d records selected from table"
+msgstr[0] ""
+msgstr[1] ""
+msgstr[2] ""
+#: ../vector/v.sample/main.c:190 ../vector/v.patch/main.c:322
+#: ../scripts/v.db.addtable/v.db.addtable.py:137
+#, c-format, python-format
+msgid "Unable to create table <%s>"
 msgstr ""
-#: ../general/g.gui/main.c:79 ../general/g.gui/main.c:85
-msgid "Default"
-msgstr "Noklusējuma"
+#: ../vector/v.sample/main.c:193 ../vector/v.db.connect/main.c:336
+#: ../vector/v.net.allpairs/main.c:183 ../vector/v.kcv/main.c:175
+#: ../vector/v.net.alloc/main.c:333 ../vector/v.net.components/main.c:194
+#: ../vector/v.net.iso/main.c:394 ../vector/v.net.flow/main.c:185
+#: ../vector/v.net.path/path.c:113 ../vector/v.net.timetable/main.c:107
+#: ../vector/v.net.distance/main.c:295 ../vector/v.net.centrality/main.c:270
+msgid "Cannot create index"
+msgstr "Nevar izveidot indeksu"
-#: ../general/g.gui/main.c:84
-msgid "Do not launch GUI after updating the default user interface settings"
+#: ../vector/v.sample/main.c:200 ../raster3d/r3.in.lidar/main.c:574
+msgid "Reading points..."
 msgstr ""
-#: ../general/g.gui/main.c:95
+#: ../vector/v.sample/main.c:226 ../vector/v.sample/main.c:234
+#: ../vector/v.label/main.c:325 ../vector/v.vol.rst/user1.c:172
+#: ../vector/v.buffer/main.c:540 ../vector/v.buffer/main.c:642
+#: ../vector/v.what.rast/main.c:623 ../vector/v.what.rast3/main.c:272
+#: ../vector/v.label.sa/labels.c:166
 #, c-format
-msgid "<%s> is now the default GUI"
+msgid "No record for category %d in table <%s>"
 msgstr ""
-#: ../general/g.gui/main.c:101
+#: ../vector/v.sample/main.c:240 ../vector/v.surf.idw/read_sites.c:65
+#: ../vector/v.class/main.c:129 ../vector/v.buffer/main.c:448
+#: ../vector/v.surf.bspline/main.c:395 ../vector/v.surf.bspline/crosscorr.c:133
+#: ../vector/v.what.rast/main.c:183 ../vector/v.to.rast3/main.c:99
+msgid "Column type not supported"
+msgstr "Kolonas tips nav atbalstīts"
+#: ../vector/v.sample/main.c:263 ../vector/v.kcv/main.c:284
 #, c-format
-msgid "Nothing to do. For setting up <%s> as default UI use -%c flag."
+msgid "Unable to insert row: %s"
 msgstr ""
-#: ../general/g.gui/main.c:108
-msgid "Your installation doesn't include GUI, exiting."
+#: ../vector/v.in.ascii/main.c:71 ../vector/v.in.dwg/main.c:83
+#: ../vector/v.in.ogr/main.c:170 ../vector/v.in.lidar/main.c:137
+#: ../vector/v.external/main.c:53 ../vector/v.in.db/main.c:53
+#: ../vector/v.proj/main.c:71 ../vector/v.in.dxf/main.c:65
+#: ../raster/r.in.mat/main.c:92 ../raster/r.external/main.c:58
+#: ../raster/r.in.poly/main.c:35 ../raster/r.in.lidar/main.c:109
+#: ../raster/r.in.gridatb/main.c:46 ../raster/r.in.xyz/main.c:159
+#: ../raster/r.proj/main.c:147 ../raster/r.in.bin/main.c:258
+#: ../raster/r.in.ascii/main.c:70 ../raster/r.in.gdal/main.c:93
+#: ../raster/r.in.png/main.c:520
+#: ../locale/scriptstrings/v.in.mapgen_to_translate.c:3
+#: ../locale/scriptstrings/v.in.wfs_to_translate.c:3
+#: ../locale/scriptstrings/v.in.lines_to_translate.c:3
+#: ../locale/scriptstrings/v.in.geonames_to_translate.c:3
+#: ../locale/scriptstrings/v.in.e00_to_translate.c:3
+#: ../locale/scriptstrings/i.in.spotvgt_to_translate.c:3
+#: ../locale/scriptstrings/r.in.srtm_to_translate.c:3
+#: ../locale/scriptstrings/v.import_to_translate.c:3
+#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:3
+#: ../locale/scriptstrings/r.import_to_translate.c:3
+#: ../locale/scriptstrings/db.in.ogr_to_translate.c:3
+#: ../locale/scriptstrings/v.unpack_to_translate.c:3
+#: ../locale/scriptstrings/t.rast.import_to_translate.c:3
+#: ../locale/scriptstrings/t.vect.import_to_translate.c:3
+#: ../locale/scriptstrings/r.unpack_to_translate.c:3
+#: ../locale/scriptstrings/r.in.wms_to_translate.c:3
+#: ../locale/scriptstrings/r.in.aster_to_translate.c:3
+#: ../raster3d/r3.in.lidar/main.c:163 ../raster3d/r3.in.v5d/main.c:179
+#: ../raster3d/r3.in.bin/main.c:253 ../raster3d/r3.in.ascii/main.c:355
+msgid "import"
+msgstr "importēt"
+#: ../vector/v.in.ascii/main.c:73 ../vector/v.cluster/main.c:94
+#: ../vector/v.patch/main.c:71 ../vector/v.in.lidar/main.c:139
+#: ../vector/v.external/main.c:57 ../vector/v.edit/main.c:61
+#: ../vector/v.perturb/main.c:67 ../vector/v.rectify/main.c:72
+#: ../vector/v.random/main.c:103 ../vector/v.in.dxf/main.c:67
+#: ../vector/v.info/main.c:43 ../vector/v.decimate/main.c:130
+#: ../raster/r.random/main.c:55 ../general/g.region/main.c:69
+#: ../display/d.vect/main.c:76
+msgid "level1"
 msgstr ""
-#: ../general/g.gui/main.c:111
-#, c-format
-msgid "Launching <%s> GUI, please wait..."
+#: ../vector/v.in.ascii/main.c:76
+msgid "Creates a vector map from an ASCII points file or ASCII vector file."
 msgstr ""
-#: ../general/g.gui/main.c:122
-#, c-format
-msgid "Launching <%s> GUI in the background, please wait..."
+#: ../vector/v.in.ascii/main.c:80 ../raster/r.in.ascii/main.c:78
+#: ../raster3d/r3.in.ascii/main.c:86
+msgid "Name of input file to be imported"
 msgstr ""
-#: ../general/g.dirseps/main.c:38
-msgid "Internal GRASS utility for converting directory separator characters."
+#: ../vector/v.in.ascii/main.c:94
+msgid "simple x,y[,z] list"
 msgstr ""
-#: ../general/g.version/main.c:66 ../general/g.tempfile/main.c:39
-#: ../general/g.message/main.c:34
-msgid "support"
+#: ../vector/v.in.ascii/main.c:95
+msgid "GRASS vector ASCII format"
 msgstr ""
-#: ../general/g.version/main.c:67
-msgid "citing"
+#: ../vector/v.in.ascii/main.c:98
+msgid "Input file format"
 msgstr ""
-#: ../general/g.version/main.c:68
-msgid "copyright"
+#: ../vector/v.in.ascii/main.c:99 ../vector/v.in.ascii/main.c:102
+#: ../vector/v.in.ascii/main.c:109 ../vector/v.in.ascii/main.c:187
+msgid "Input format"
 msgstr ""
-#: ../general/g.version/main.c:69
-msgid "version"
+#: ../vector/v.in.ascii/main.c:108
+msgid "Special characters: doublequote, singlequote, none"
 msgstr ""
-#: ../general/g.version/main.c:70
-msgid "license"
+#: ../vector/v.in.ascii/main.c:118
+msgid "Number of header lines to skip at top of input file (points mode)"
 msgstr ""
-#: ../general/g.version/main.c:71
-msgid "Displays GRASS GIS version info."
+#: ../vector/v.in.ascii/main.c:119 ../vector/v.in.ascii/main.c:126
+#: ../vector/v.in.ascii/main.c:138 ../vector/v.in.ascii/main.c:148
+#: ../vector/v.in.ascii/main.c:158 ../vector/v.in.ascii/main.c:168
+#: ../vector/v.in.ascii/main.c:192 ../vector/v.in.ascii/main.c:196
+#: ../vector/v.in.ascii/main.c:202 ../vector/v.in.ascii/main.c:207
+#: ../vector/v.out.ascii/args.c:40 ../vector/v.out.ascii/args.c:66
+#: ../vector/v.out.ascii/args.c:76 ../vector/v.out.ascii/args.c:86
+#: ../vector/v.out.ascii/args.c:92 ../raster/r.random/main.c:99
+#: ../display/d.linegraph/main.c:353 ../display/d.linegraph/main.c:362
+#: ../display/d.linegraph/main.c:371 ../display/d.linegraph/main.c:386
+msgid "Points"
+msgstr "Punkti"
+#: ../vector/v.in.ascii/main.c:127
+msgid "Column definition in SQL style (points mode)"
 msgstr ""
-#: ../general/g.version/main.c:72
-msgid "Optionally also prints build or copyright information."
+#: ../vector/v.in.ascii/main.c:128
+msgid ""
+"For example: 'x double precision, y double precision, cat int, name "
+"varchar(10)'"
 msgstr ""
-#: ../general/g.version/main.c:76
-msgid "Print also the copyright message"
+#: ../vector/v.in.ascii/main.c:140 ../vector/v.in.ascii/main.c:150
+msgid "First column is 1"
 msgstr ""
-#: ../general/g.version/main.c:77 ../general/g.version/main.c:82
-#: ../general/g.version/main.c:87 ../general/g.version/main.c:93
-#: ../general/g.version/main.c:99
-msgid "Additional info"
+#: ../vector/v.in.ascii/main.c:149
+msgid "Number of column used as y coordinate (points mode)"
 msgstr ""
-#: ../general/g.version/main.c:81
-msgid "Print also the citation options"
+#: ../vector/v.in.ascii/main.c:159
+msgid "Number of column used as z coordinate (points mode)"
 msgstr ""
-#: ../general/g.version/main.c:86
-msgid "Print also the build information"
+#: ../vector/v.in.ascii/main.c:160
+msgid "First column is 1. If 0, z coordinate is not used"
 msgstr ""
-#: ../general/g.version/main.c:92
-msgid "Print also the GIS library revision number and date"
+#: ../vector/v.in.ascii/main.c:170
+msgid "Number of column used as category (points mode)"
 msgstr ""
-#: ../general/g.version/main.c:97
-msgid "Print also extended info for additional libraries"
+#: ../vector/v.in.ascii/main.c:172
+msgid ""
+"First column is 1. If 0, unique category is assigned to each row and written "
+"to new column 'cat'"
 msgstr ""
-#: ../general/g.version/main.c:98
-msgid "GDAL/OGR, PROJ.4, GEOS"
+#: ../vector/v.in.ascii/main.c:176 ../vector/v.in.dwg/main.c:106
+msgid "Create 3D vector map"
 msgstr ""
-#: ../general/g.version/main.c:103
-msgid "Print info in shell script style (including SVN revision number)"
+#: ../vector/v.in.ascii/main.c:181
+msgid "Create a new empty vector map and exit. Nothing is read from input."
 msgstr ""
-#: ../general/g.version/main.c:104
-msgid "Shell"
+#: ../vector/v.in.ascii/main.c:186
+msgid "Do not expect a header when reading in standard format"
 msgstr ""
-#: ../general/g.version/main.c:172
-#, c-format
-msgid "Cannot determine GRASS libgis version and date number. The GRASS build might be broken. Report this to developers or packagers.\n"
+#: ../vector/v.in.ascii/main.c:191
+msgid "Do not create table in points mode"
 msgstr ""
-#: ../general/g.version/main.c:179
-msgid "GRASS GIS libgis version and date number don't have the expected format. Trying to print the original strings..."
+#: ../vector/v.in.ascii/main.c:195 ../raster/r.random/main.c:98
+msgid "Do not build topology in points mode"
 msgstr ""
-#: ../general/g.version/main.c:181
-#, c-format
-msgid "GIS_H_VERSION=\"%s\""
+#: ../vector/v.in.ascii/main.c:201
+msgid "Only import points falling within current region (points mode)"
 msgstr ""
-#: ../general/g.version/main.c:182
-#, c-format
-msgid "GIS_H_DATE=\"%s\""
+#: ../vector/v.in.ascii/main.c:206
+msgid "Ignore broken line(s) in points mode"
 msgstr ""
-#: ../general/g.version/main.c:212
-msgid "GRASS not compiled with GDAL/OGR support"
+#: ../vector/v.in.ascii/main.c:220 ../raster/r.in.xyz/main.c:378
+msgid "Please specify reasonable number of lines to skip"
 msgstr ""
-#: ../general/g.version/main.c:223
-msgid "GRASS not compiled with GEOS support"
+#: ../vector/v.in.ascii/main.c:223
+msgid "Please specify z column"
 msgstr ""
-#: ../general/g.version/main.c:234
-msgid "GRASS not compiled with SQLite support"
+#: ../vector/v.in.ascii/main.c:234
+msgid "Please specify reasonable z column"
 msgstr ""
-#: ../general/g.remove/check_reclass.c:16
-#, c-format
-msgid "Raster map <%s@%s> is a base map for <%s>. Remove forced."
+#: ../vector/v.in.ascii/main.c:239
+msgid "Column numbers must not be negative"
 msgstr ""
-#: ../general/g.remove/check_reclass.c:19
+#: ../vector/v.in.ascii/main.c:283
 #, c-format
-msgid "Raster map <%s@%s> is a base map. Remove reclassed map <%s> first."
+msgid "Maximum input row length: %d"
 msgstr ""
-#: ../general/g.remove/check_reclass.c:41
-#: ../general/g.remove/check_reclass.c:54
+#: ../vector/v.in.ascii/main.c:285
 #, c-format
-msgid "Removing information about reclassed map from <%s@%s> failed"
+msgid "Maximum number of columns: %d"
 msgstr ""
-#: ../general/g.remove/main.c:71
-#: ../locale/scriptstrings/t.remove_to_translate.c:4
-msgid "remove"
+#: ../vector/v.in.ascii/main.c:286
+#, c-format
+msgid "Minimum number of columns: %d"
 msgstr ""
-#: ../general/g.remove/main.c:73
-msgid "Removes data base element files from the user's current mapset using the search pattern."
+#: ../vector/v.in.ascii/main.c:289
+#, c-format
+msgid "Number of columns: %d"
 msgstr ""
-#: ../general/g.remove/main.c:83 ../general/g.remove/main.c:91
-#: ../general/g.remove/main.c:133
-msgid "Basic"
+#: ../vector/v.in.ascii/main.c:292
+#, c-format
+msgid "Number of rows: %d"
 msgstr ""
-#: ../general/g.remove/main.c:90
-msgid "Name of file(s) to remove"
+#: ../vector/v.in.ascii/main.c:296 ../vector/v.in.ascii/main.c:300
+#: ../vector/v.in.ascii/main.c:305 ../vector/v.in.ascii/main.c:310
+#, c-format
+msgid ""
+"'%s' column number > minimum last column number (incorrect field separator "
+"or format?)"
 msgstr ""
-#: ../general/g.remove/main.c:99
-msgid "Name of file(s) to ignore (default: none)"
+#: ../vector/v.in.ascii/main.c:315 ../vector/v.in.ascii/main.c:318
+#: ../vector/v.in.ascii/main.c:321 ../vector/v.in.ascii/main.c:324
+#, c-format
+msgid "'%s' column is not of number type"
 msgstr ""
-#: ../general/g.remove/main.c:100 ../general/g.remove/main.c:106
-#: ../general/g.remove/main.c:112 ../general/g.remove/main.c:117
-#: ../general/g.remove/main.c:123 ../general/g.remove/main.c:129
-#: ../general/g.list/main.c:87 ../general/g.list/main.c:95
-#: ../general/g.list/main.c:121 ../general/g.list/main.c:127
-#: ../general/g.list/main.c:133
-msgid "Pattern"
-msgstr "Šablons"
-#: ../general/g.remove/main.c:105
-msgid "File name search pattern"
+#: ../vector/v.in.ascii/main.c:366
+msgid "Category column is not of integer type"
 msgstr ""
-#: ../general/g.remove/main.c:111
-msgid "File name exclusion pattern (default: none)"
+#: ../vector/v.in.ascii/main.c:415 ../vector/v.mkgrid/main.c:342
+#: ../vector/v.mkgrid/main.c:400 ../vector/v.lrs/v.lrs.create/main.c:338
+#: ../vector/v.random/main.c:254 ../vector/v.in.dxf/write_vect.c:233
+#: ../raster/r.volume/main.c:260 ../raster/r.to.vect/main.c:229
+#: ../raster3d/r3.flow/main.c:64
+#, c-format
+msgid "Unable to create table: %s"
 msgstr ""
-#: ../general/g.remove/main.c:116 ../general/g.list/main.c:120
-msgid "Ignore case"
+#: ../vector/v.in.ascii/main.c:435 ../vector/v.profile/main.c:433
+#: ../vector/v.profile/main.c:586 ../vector/v.db.connect/main.c:228
+#: ../vector/v.reclass/main.c:193 ../vector/v.out.ogr/main.c:646
+#: ../vector/v.patch/main.c:164 ../vector/v.patch/main.c:204
+#: ../vector/v.out.vtk/writeVTK.c:655 ../vector/v.out.svg/main.c:165
+#: ../vector/v.out.postgis/table.c:41 ../vector/v.random/main.c:273
+#: ../vector/v.info/print.c:152 ../db/db.describe/main.c:67
+#: ../db/db.columns/main.c:62 ../doc/vector/v.example/main.c:137
+#: ../scripts/db.univar/db.univar.py:112
+msgid "Unable to describe table <%s>"
 msgstr ""
-#: ../general/g.remove/main.c:122 ../general/g.list/main.c:126
-msgid "Use basic regular expressions instead of wildcards"
+#: ../vector/v.in.ascii/main.c:443
+#, c-format
+msgid ""
+"Number of columns defined (%d) does not match number of columns (%d) in input"
 msgstr ""
-#: ../general/g.remove/main.c:128 ../general/g.list/main.c:132
-msgid "Use extended regular expressions instead of wildcards"
+#: ../vector/v.in.ascii/main.c:471
+#, c-format
+msgid "Column number %d <%s> defined as double has only integer values"
 msgstr ""
-#: ../general/g.remove/main.c:135
-#: ../locale/scriptstrings/db.dropcolumn_to_translate.c:4
-#: ../locale/scriptstrings/db.droptable_to_translate.c:4
-msgid "Force removal (required for actual deletion of files)"
+#: ../vector/v.in.ascii/main.c:476
+#, c-format
+msgid "Column number %d <%s> defined as string has only integer values"
 msgstr ""
-#: ../general/g.remove/main.c:139
-msgid "Remove base raster maps"
+#: ../vector/v.in.ascii/main.c:483
+#, c-format
+msgid "Column number %d <%s> defined as integer has double values"
 msgstr ""
-#: ../general/g.remove/main.c:178 ../general/g.remove/main.c:202
-#: ../general/g.list/main.c:185 ../general/g.list/main.c:212
+#: ../vector/v.in.ascii/main.c:488
 #, c-format
-msgid "Unable to compile pattern <%s>"
+msgid "Column number %d <%s> defined as string has double values"
 msgstr ""
-#: ../general/g.remove/main.c:208
-msgid "The following data base element files would be deleted:"
+#: ../vector/v.in.ascii/main.c:495
+#, c-format
+msgid "Column number %d <%s> defined as integer has string values"
 msgstr ""
-#: ../general/g.remove/main.c:259
-msgid "No data base element files found"
+#: ../vector/v.in.ascii/main.c:500
+#, c-format
+msgid "Column number %d <%s> defined as double has string values"
 msgstr ""
-#: ../general/g.remove/main.c:267
+#: ../vector/v.in.ascii/main.c:505
 #, c-format
-msgid "Nothing removed. You must use the force flag (-%c) to actually remove them. Exiting."
+msgid "Length of column %d <%s> (%d) is less than maximum value length (%d)"
 msgstr ""
-#: ../general/g.remove/construct_pattern.c:37
+#: ../vector/v.in.ascii/main.c:523 ../vector/v.in.dwg/main.c:244
+#: ../vector/v.in.ogr/main.c:1279 ../vector/v.reclass/main.c:322
+#: ../vector/v.in.lidar/attributes.c:139 ../vector/v.to.points/main.c:197
+#: ../vector/v.in.dxf/write_vect.c:241 ../raster/r.contour/main.c:188
+#: ../raster3d/r3.flow/main.c:67
 #, c-format
-msgid "%s: Cannot remove or exclude files not in the current mapset."
+msgid "Unable to create index for table <%s>, key <%s>"
 msgstr ""
-#: ../general/g.remove/construct_pattern.c:57
-msgid "Illegal filenames not allowed in the name or ignore option."
+#: ../vector/v.in.ascii/main.c:541
+msgid "Populating table..."
 msgstr ""
-#: ../general/g.mapset/main.c:50 ../general/g.mapsets/main.c:64
-#: ../general/g.region/main.c:65 ../general/g.gisenv/main.c:44
-#: ../temporal/t.connect/main.c:35 ../display/d.font/main.c:46
-#: ../display/d.colorlist/main.c:36 ../display/d.fontlist/main.c:46
-msgid "settings"
+#: ../vector/v.in.ascii/main.c:544
+msgid ""
+"Unable to close attribute table. The DBMI driver did not accept all "
+"attributes"
 msgstr ""
-#: ../general/g.mapset/main.c:51
-msgid "Changes/reports current mapset."
+#: ../vector/v.in.ascii/main.c:552 ../vector/v.in.ascii/main.c:555
+#: ../vector/v.in.ogr/main.c:1762
+msgid "Import failed"
 msgstr ""
-#: ../general/g.mapset/main.c:52
-msgid "Optionally create new mapset or list available mapsets in given location."
+#: ../vector/v.in.ascii/points.c:82
+msgid "Scanning input for column types..."
 msgstr ""
-#: ../general/g.mapset/main.c:56
-msgid "Name of mapset where to switch"
+#: ../vector/v.in.ascii/points.c:130
+#, c-format
+msgid "Row %d: '%s' can not be imported into the attribute table"
 msgstr ""
-#: ../general/g.mapset/main.c:57 ../general/g.mapset/main.c:61
-#: ../general/g.mapset/main.c:64
-msgid "Mapset"
+#: ../vector/v.in.ascii/points.c:134 ../vector/v.in.ascii/points.c:144
+#, c-format
+msgid "Broken row %d: '%s'"
 msgstr ""
-#: ../general/g.mapset/main.c:68
-msgid "Create mapset if it doesn't exist"
+#: ../vector/v.in.ascii/points.c:188 ../vector/v.in.ascii/points.c:207
+#, c-format
+msgid ""
+"Current row %d:\n"
+"%s\n"
 msgstr ""
-#: ../general/g.mapset/main.c:70 ../general/g.proj/main.c:201
-#: ../locale/scriptstrings/r.mask_to_translate.c:18
-msgid "Create"
-msgstr "Izveidot"
+#: ../vector/v.in.ascii/points.c:189 ../vector/v.in.ascii/points.c:217
+#, c-format
+msgid "Unparsable longitude value in column %d: %s"
+msgstr ""
-#: ../general/g.mapset/main.c:75
-msgid "List available mapsets and exit"
+#: ../vector/v.in.ascii/points.c:208 ../vector/v.in.ascii/points.c:221
+#, c-format
+msgid "Unparsable latitude value in column %d: %s"
 msgstr ""
-#: ../general/g.mapset/main.c:76 ../general/g.mapset/main.c:82
-#: ../general/g.list/main.c:105 ../general/g.list/main.c:116
-#: ../general/g.list/main.c:138 ../general/g.list/main.c:143
-#: ../general/g.list/main.c:148 ../general/g.list/main.c:153
-#: ../general/g.mapsets/main.c:87 ../general/g.mapsets/main.c:92
-#: ../general/g.mapsets/main.c:98 ../general/g.region/main.c:88
-#: ../general/g.region/main.c:94 ../general/g.region/main.c:99
-#: ../general/g.region/main.c:105 ../general/g.region/main.c:111
-#: ../general/g.region/main.c:117 ../general/g.region/main.c:123
-#: ../general/g.region/main.c:131 ../general/g.region/main.c:136
-#: ../general/g.region/main.c:142 ../general/g.region/main.c:147
-#: ../general/g.region/main.c:152 ../general/g.proj/main.c:80
-#: ../general/g.proj/main.c:86 ../general/g.proj/main.c:92
-#: ../general/g.proj/main.c:98 ../general/g.proj/main.c:104
-#: ../general/g.proj/main.c:115 ../general/g.proj/main.c:120
-#: ../locale/scriptstrings/t.rast.colors_to_translate.c:18
-#: ../locale/scriptstrings/g.extension_to_translate.c:16
-#: ../locale/scriptstrings/g.extension_to_translate.c:18
-#: ../locale/scriptstrings/g.extension_to_translate.c:20
-#: ../locale/scriptstrings/g.extension_to_translate.c:22
-#: ../temporal/t.connect/main.c:43 ../raster/r.external.out/main.c:272
-#: ../raster/r.external.out/main.c:283 ../raster/r.sunmask/main.c:232
-#: ../raster/r.sunmask/main.c:238 ../raster/r.proj/main.c:204
-#: ../raster/r.proj/main.c:214 ../raster/r.proj/main.c:220
-#: ../raster/r.external/main.c:96 ../raster/r.external/main.c:129
-#: ../raster/r.what/main.c:120 ../raster/r.what/main.c:128
-#: ../raster/r.what/main.c:142 ../raster/r.what/main.c:147
-#: ../raster/r.what/main.c:152 ../raster/r.what/main.c:157
-#: ../raster/r.out.gdal/main.c:142 ../raster/r.in.gdal/main.c:203
-#: ../raster/r.in.gdal/main.c:231 ../raster/r.colors/edit_colors.c:128
-#: ../display/d.mon/main.c:103 ../display/d.mon/main.c:108
-#: ../display/d.mon/main.c:113 ../vector/v.external/args.c:52
-#: ../vector/v.external/args.c:58 ../vector/v.external/args.c:66
-#: ../vector/v.in.ogr/main.c:257 ../vector/v.in.ogr/main.c:263
-#: ../vector/v.to.db/parse.c:118 ../vector/v.to.db/parse.c:123
-#: ../vector/v.to.db/parse.c:129 ../vector/v.to.db/parse.c:135
-#: ../vector/v.external.out/args.c:63 ../vector/v.external.out/args.c:75
-#: ../vector/v.external.out/args.c:81 ../vector/v.info/parse.c:25
-#: ../vector/v.info/parse.c:31 ../vector/v.info/parse.c:36
-#: ../vector/v.info/parse.c:41 ../vector/v.info/parse.c:46
-#: ../vector/v.db.connect/main.c:84 ../vector/v.db.connect/main.c:89
-#: ../vector/v.db.connect/main.c:96 ../vector/v.db.connect/main.c:103
-#: ../vector/v.colors/main.c:133 ../vector/v.what/main.c:91
-#: ../vector/v.what/main.c:96 ../vector/v.what/main.c:101
-#: ../vector/v.what/main.c:106 ../vector/v.what/main.c:111
-#: ../imagery/i.group/main.c:79 ../imagery/i.group/main.c:84
-#: ../imagery/i.group/main.c:89 ../db/db.connect/main.c:53
-#: ../db/db.connect/main.c:58 ../db/db.login/main.c:91
-msgid "Print"
-msgstr "Drukāt"
+#: ../vector/v.in.ascii/points.c:298
+#, c-format
+msgid "Skipping %d of %d row falling outside of current region"
+msgid_plural "Skipping %d of %d rows falling outside of current region"
+msgstr[0] ""
+msgstr[1] ""
+msgstr[2] ""
-#: ../general/g.mapset/main.c:81
-msgid "Print current mapset and exit"
+#: ../vector/v.in.ascii/points.c:328
+msgid "Importing points..."
 msgstr ""
-#: ../general/g.mapset/main.c:136
+#: ../vector/v.in.ascii/points.c:452 ../vector/v.mkgrid/main.c:365
+#: ../vector/v.mkgrid/main.c:463 ../vector/v.in.dxf/write_vect.c:70
 #, c-format
-msgid "<%s> is already the current mapset"
+msgid "Unable to insert new record: %s"
 msgstr ""
-#: ../general/g.mapset/main.c:145
-#, c-format
-msgid "You don't have permission to use the mapset <%s>"
+#: ../vector/v.univar/main.c:93 ../vector/v.class/main.c:48
+#: ../vector/v.kcv/main.c:56 ../vector/v.normal/main.c:73
+#: ../vector/v.qcount/main.c:61 ../vector/v.outlier/main.c:70
+#: ../vector/v.neighbors/main.c:52 ../vector/v.perturb/main.c:64
+#: ../vector/v.random/main.c:99 ../raster/r.covar/main.c:52
+#: ../raster/r.stats.quantile/main.c:517 ../raster/r.quant/main.c:48
+#: ../raster/r.kappa/main.c:69 ../raster/r.surf.area/main.c:78
+#: ../raster/r.stats.zonal/main.c:102 ../raster/r.support.stats/main.c:39
+#: ../raster/r.univar/r.univar_main.c:105
+#: ../raster/r.univar/r3.univar_main.c:99 ../raster/r.report/main.c:68
+#: ../raster/r.coin/main.c:67 ../raster/r.quantile/main.c:267
+#: ../raster/r.neighbors/main.c:169 ../raster/r.in.lidar/main.c:111
+#: ../raster/r.in.xyz/main.c:160 ../raster/r.cross/main.c:70
+#: ../raster/r.clump/main.c:59 ../raster/r.mode/main.c:56
+#: ../raster/r.regression.line/main.c:47 ../raster/r.statistics/main.c:56
+#: ../raster/r.stats/main.c:107 ../raster/r.regression.multi/main.c:130
+#: ../raster/r.texture/main.c:104 ../raster/r.mfilter/main.c:58
+#: ../locale/scriptstrings/t.rast3d.univar_to_translate.c:3
+#: ../locale/scriptstrings/v.db.univar_to_translate.c:3
+#: ../locale/scriptstrings/d.correlate_to_translate.c:3
+#: ../locale/scriptstrings/r.reclass.area_to_translate.c:3
+#: ../locale/scriptstrings/t.rast.univar_to_translate.c:3
+#: ../locale/scriptstrings/db.univar_to_translate.c:3
+#: ../locale/scriptstrings/i.oif_to_translate.c:4
+#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:6
+#: ../locale/scriptstrings/v.rast.stats_to_translate.c:3
+#: ../locale/scriptstrings/t.vect.univar_to_translate.c:3
+#: ../locale/scriptstrings/v.report_to_translate.c:4
+#: ../raster3d/r3.in.lidar/main.c:165 ../raster3d/r3.stats/main.c:49
+#: ../raster3d/r3.neighbors/main.c:211 ../display/d.histogram/main.c:85
+#: ../imagery/i.cca/main.c:85
+msgid "statistics"
 msgstr ""
-#: ../general/g.mapset/main.c:153
-#, c-format
-msgid "Unable to create new mapset <%s>"
+#: ../vector/v.univar/main.c:94 ../vector/v.vect.stats/main.c:133
+#: ../raster/r.univar/r.univar_main.c:106
+#: ../raster/r.univar/r3.univar_main.c:100
+#: ../locale/scriptstrings/v.rast.stats_to_translate.c:5
+msgid "univariate statistics"
 msgstr ""
-#: ../general/g.mapset/main.c:156
-#, c-format
-msgid "Mapset <%s> does not exist. Use -c flag to create it."
+#: ../vector/v.univar/main.c:95 ../vector/v.to.db/main.c:37
+#: ../vector/v.db.connect/main.c:53 ../vector/v.class/main.c:47
+#: ../vector/v.vect.stats/main.c:131 ../vector/v.distance/main.c:124
+#: ../vector/v.db.select/main.c:55 ../vector/v.what.rast/main.c:76
+#: ../vector/v.what.rast3/main.c:69
+#: ../locale/scriptstrings/db.out.ogr_to_translate.c:4
+#: ../locale/scriptstrings/v.db.univar_to_translate.c:4
+#: ../locale/scriptstrings/db.droptable_to_translate.c:3
+#: ../locale/scriptstrings/v.db.droprow_to_translate.c:3
+#: ../locale/scriptstrings/v.what.vect_to_translate.c:7
+#: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:3
+#: ../locale/scriptstrings/db.univar_to_translate.c:4
+#: ../locale/scriptstrings/v.db.addcolumn_to_translate.c:3
+#: ../locale/scriptstrings/v.db.addtable_to_translate.c:3
+#: ../locale/scriptstrings/v.db.update_to_translate.c:3
+#: ../locale/scriptstrings/v.db.renamecolumn_to_translate.c:3
+#: ../locale/scriptstrings/v.db.join_to_translate.c:3
+#: ../locale/scriptstrings/v.what.strds_to_translate.c:7
+#: ../locale/scriptstrings/db.in.ogr_to_translate.c:4
+#: ../locale/scriptstrings/v.db.dropcolumn_to_translate.c:3
+#: ../locale/scriptstrings/t.vect.db.select_to_translate.c:3
+#: ../locale/scriptstrings/v.db.droptable_to_translate.c:3
+#: ../locale/scriptstrings/db.test_to_translate.c:3
+#: ../locale/scriptstrings/db.dropcolumn_to_translate.c:3
+#: ../db/db.select/main.c:266 ../db/db.connect/main.c:44
+#: ../db/db.tables/main.c:98 ../db/db.createdb/main.c:72
+#: ../db/db.copy/main.c:36 ../db/db.dropdb/main.c:72
+#: ../db/db.databases/main.c:96 ../db/db.describe/main.c:130
+#: ../db/db.columns/main.c:100 ../db/db.execute/main.c:126
+msgid "attribute table"
 msgstr ""
-#: ../general/g.mapset/main.c:166
-msgid "Unable to read GIS_LOCK environment variable"
+#: ../vector/v.univar/main.c:98
+msgid "Calculates univariate statistics of vector map features."
 msgstr ""
-#: ../general/g.mapset/main.c:182
-#, c-format
-msgid "Lock file of mapset <%s> cannot be checked"
+#: ../vector/v.univar/main.c:99
+msgid ""
+"Variance and standard deviation is calculated only for points if specified."
 msgstr ""
-#: ../general/g.mapset/main.c:185
-#, c-format
-msgid "There appears to be an active GRASS session in selected mapset <%s>"
+#: ../vector/v.univar/main.c:122 ../raster/r.univar/r.univar_main.c:52
+#: ../raster/r.univar/r3.univar_main.c:52
+#: ../locale/scriptstrings/v.db.univar_to_translate.c:6
+#: ../locale/scriptstrings/db.univar_to_translate.c:6
+msgid "Percentile to calculate (requires extended statistics flag)"
 msgstr ""
-#: ../general/g.mapset/main.c:191
-msgid "Cleaning up temporary files..."
+#: ../vector/v.univar/main.c:126 ../vector/v.what/main.c:100
+#: ../raster/r.univar/r.univar_main.c:61 ../raster/r.univar/r3.univar_main.c:59
+msgid "Print the stats in shell script style"
+msgstr "Drukāt statistiku komandrindas skripta stilā"
+#: ../vector/v.univar/main.c:130 ../raster/r.univar/r.univar_main.c:66
+#: ../raster/r.univar/r3.univar_main.c:63
+#: ../locale/scriptstrings/t.rast3d.univar_to_translate.c:10
+#: ../locale/scriptstrings/t.rast.univar_to_translate.c:9
+#: ../locale/scriptstrings/t.vect.univar_to_translate.c:10
+msgid "Calculate extended statistics"
 msgstr ""
-#: ../general/g.mapset/main.c:205
-msgid "Mapset switched. Your shell continues to use the history for the old mapset"
+#: ../vector/v.univar/main.c:134
+msgid "Weigh by line length or area size"
 msgstr ""
-#: ../general/g.mapset/main.c:210
-#, c-format
-msgid ""
-"You can switch the history by commands:\n"
-"history -w; history -r %s/.bash_history; HISTFILE=%s/.bash_history"
+#: ../vector/v.univar/main.c:138
+msgid "Calculate geometric distances instead of attribute statistics"
 msgstr ""
-#: ../general/g.mapset/main.c:215
+#: ../vector/v.univar/main.c:147 ../vector/v.to.db/parse.c:143
+#: ../vector/v.to.db/parse.c:146 ../ps/ps.map/main.c:213
+#: ../ps/ps.map/main.c:232
 #, c-format
 msgid ""
-"history -S; history -L %s/.history; setenv histfile=%s/.history"
+"Required parameter <%s> not set:\n"
+"\t(%s)"
 msgstr ""
-#: ../general/g.mapset/main.c:221
+#: ../vector/v.univar/main.c:192
 #, c-format
-msgid "Your current mapset is <%s>"
+msgid "Geometry distances are not supported for areas. Use '%s' instead."
 msgstr ""
-#: ../general/g.pnmcomp/main.c:54
-msgid "Error reading PPM file"
+#: ../vector/v.univar/main.c:195
+msgid ""
+"Incompatible vector type(s) specified, only number of features, minimum, "
+"maximum and range can be calculated"
 msgstr ""
-#: ../general/g.pnmcomp/main.c:69 ../general/g.pnmcomp/main.c:74
-#: ../general/g.pnmcomp/main.c:83 ../general/g.pnmcomp/main.c:134
-#: ../general/g.pnmcomp/main.c:147
-msgid "Invalid PPM file"
+#: ../vector/v.univar/main.c:200
+msgid "Extended statistics is currently supported only for points/centroids"
 msgstr ""
-#: ../general/g.pnmcomp/main.c:96 ../scripts/v.unpack/v.unpack.py:70
-#: ../scripts/v.db.update/v.db.update.py:92
-#: ../scripts/v.in.geonames/v.in.geonames.py:57
-msgid "File <%s> not found"
+#: ../vector/v.univar/main.c:225
+msgid "'layer' must be > 0 for 'where'."
 msgstr ""
-#: ../general/g.pnmcomp/main.c:104
-msgid "Expecting PPM but got PGM"
+#: ../vector/v.univar/main.c:229 ../vector/v.vect.stats/main.c:330
+#: ../vector/v.vect.stats/main.c:404 ../vector/v.buffer/main.c:426
+#: ../vector/v.generalize/misc.c:170 ../vector/v.distance/main.c:549
+#: ../vector/v.edit/select.c:502 ../vector/v.overlay/main.c:398
+#: ../vector/v.surf.bspline/crosscorr.c:114 ../vector/v.what.rast/main.c:138
+#: ../vector/v.to.rast/support.c:104 ../vector/v.to.rast/support.c:276
+#: ../vector/v.to.rast/support.c:515 ../vector/v.what.rast3/main.c:120
+#: ../vector/v.colors/write_rgb.c:20 ../vector/v.colors/scan_attr.c:24
+#: ../vector/v.colors/read_rgb.c:23 ../vector/v.extrude/main.c:224
+#: ../doc/vector/v.example/main.c:105 ../display/d.vect.chart/plot.c:38
+#: ../display/d.vect.thematic/plot1.c:105 ../display/d.vect/shape.c:38
+#, c-format
+msgid "Database connection not defined for layer %d"
 msgstr ""
-#: ../general/g.pnmcomp/main.c:109
-msgid "Expecting PGM but got PPM"
+#: ../vector/v.univar/main.c:242
+#, c-format
+msgid "Unable select categories from table <%s>"
 msgstr ""
-#: ../general/g.pnmcomp/main.c:112
+#: ../vector/v.univar/main.c:253
 #, c-format
-msgid "Invalid magic number: 'P%c'"
+msgid "Calculating geometric distances between %d primitives..."
 msgstr ""
-#: ../general/g.pnmcomp/main.c:125 ../general/g.pnmcomp/main.c:142
-msgid "Invalid PGM file"
+#: ../vector/v.univar/main.c:343
+#, c-format
+msgid " Database connection not defined for layer <%s>"
 msgstr ""
-#: ../general/g.pnmcomp/main.c:247
-msgid "Error writing PPM file"
+#: ../vector/v.univar/main.c:358 ../vector/v.out.lidar/main.c:121
+#: ../vector/v.out.lidar/main.c:158
+msgid "Only numeric column type is supported"
 msgstr ""
-#: ../general/g.pnmcomp/main.c:264
-msgid "Error writing PGM file"
+#: ../vector/v.univar/main.c:652
+msgid "Cannot sort the key/value array"
 msgstr ""
-#: ../general/g.pnmcomp/main.c:285
-msgid "Overlays multiple PPM image files."
+#: ../vector/v.profile/main.c:60 ../vector/v.buffer/geos.c:19
+msgid "Invalid GEOS geometry!"
 msgstr ""
-#: ../general/g.pnmcomp/main.c:296
-msgid "Name of input mask file(s)"
+#: ../vector/v.profile/main.c:66 ../vector/v.buffer/geos.c:25
+msgid "No coordinates in GEOS geometry (can be ok for negative distance)!"
 msgstr ""
-#: ../general/g.pnmcomp/main.c:309
-msgid "Name for output mask file"
+#: ../vector/v.profile/main.c:74 ../vector/v.buffer/geos.c:33
+#, c-format
+msgid "Invalid x coordinate %f"
 msgstr ""
-#: ../general/g.list/main.c:67
-#: ../locale/scriptstrings/t.rast3d.list_to_translate.c:4
-#: ../locale/scriptstrings/t.list_to_translate.c:4
-#: ../locale/scriptstrings/t.rast.list_to_translate.c:5
-#: ../locale/scriptstrings/t.vect.list_to_translate.c:5
-msgid "list"
-msgstr "saraksts"
-#: ../general/g.list/main.c:68
-#: ../locale/scriptstrings/g.search.modules_to_translate.c:4
-msgid "search"
+#: ../vector/v.profile/main.c:76 ../vector/v.buffer/geos.c:35
+#, c-format
+msgid "Invalid y coordinate %f"
 msgstr ""
-#: ../general/g.list/main.c:70
-msgid "Lists available GRASS data base files of the user-specified data type optionally using the search pattern."
+#: ../vector/v.profile/main.c:93 ../vector/v.profile/main.c:104
+#: ../vector/v.buffer/geos.c:107
+msgid "Corrupt GEOS geometry"
 msgstr ""
-#: ../general/g.list/main.c:86
-msgid "Map name search pattern (default: all)"
-msgstr ""
+#: ../vector/v.profile/main.c:154 ../raster/r.profile/main.c:54
+#: ../raster/r.transect/main.c:104 ../raster3d/r3.cross.rast/main.c:229
+#: ../display/d.profile/main.c:192
+msgid "profile"
+msgstr "profils"
-#: ../general/g.list/main.c:94
-msgid "Map name exclusion pattern (default: none)"
+#: ../vector/v.profile/main.c:155 ../raster/r.profile/main.c:55
+#: ../raster/r.transect/main.c:105
+msgid "transect"
 msgstr ""
-#: ../general/g.list/main.c:100
-msgid "Name of mapset to list (default: current search path)"
+#: ../vector/v.profile/main.c:156
+#, fuzzy
+msgid "Vector map profiling tool"
+msgstr "vektora karte <%s> nav atrasta"
+#: ../vector/v.profile/main.c:172
+#, fuzzy
+msgid "Use features only from specified layer"
+msgstr "Drukāt saules pozīcijas apraskstu komandrindas skripta stilā"
+#: ../vector/v.profile/main.c:183
+msgid "Path to output text file or - for stdout"
 msgstr ""
-#: ../general/g.list/main.c:102
-msgid "'.' for current mapset; '*' for all mapsets in location"
+#: ../vector/v.profile/main.c:184 ../vector/v.profile/main.c:187
+#: ../vector/v.profile/main.c:196 ../vector/v.db.select/main.c:85
+#: ../vector/v.db.select/main.c:88 ../vector/v.db.select/main.c:106
+#: ../vector/v.db.select/main.c:111 ../general/g.gisenv/main.c:93
+#: ../general/g.gisenv/main.c:98 ../db/db.select/main.c:227
+#: ../db/db.select/main.c:233 ../db/db.select/main.c:236
+#: ../db/db.select/main.c:246 ../db/db.select/main.c:256
+msgid "Format"
 msgstr ""
-#: ../general/g.list/main.c:108
-msgid "Name of saved region for map search (default: not restricted)"
+#: ../vector/v.profile/main.c:195
+#, fuzzy
+msgid "Number of significant digits"
 msgstr ""
+"\n"
+"\n"
+"  Punktu skaits: %d\n"
-#: ../general/g.list/main.c:110
-msgid "'.' for current region; '*' for default region"
+#: ../vector/v.profile/main.c:204
+#, fuzzy
+msgid "Buffer (tolerance) for points in map units"
+msgstr "Bufera izmērs kartes vienībās"
+#: ../vector/v.profile/main.c:205
+msgid "How far points can be from sampling line"
 msgstr ""
-#: ../general/g.list/main.c:114
-#: ../locale/scriptstrings/d.out.file_to_translate.c:4
-#: ../raster/r.topmodel/main.c:72
-msgid "Name for output file"
+#: ../vector/v.profile/main.c:215
+#, fuzzy
+msgid "Name for profile line and buffer output map"
+msgstr "Izejas rastra kartes nosaukums"
+#: ../vector/v.profile/main.c:217
+#, fuzzy
+msgid "Profile line and buffer around it will be written"
+msgstr "Izejas karte kurā tiks ierakstīti punkti"
+#: ../vector/v.profile/main.c:218 ../vector/v.profile/main.c:223
+#: ../vector/v.profile/main.c:229 ../vector/v.in.ogr/main.c:203
+#: ../vector/v.in.ogr/main.c:258 ../vector/v.in.ogr/main.c:308
+#: ../vector/v.in.ogr/main.c:314 ../vector/v.in.ogr/main.c:356
+#: ../vector/v.out.ascii/args.c:35 ../vector/v.out.ascii/args.c:81
+#: ../raster/r.grow.distance/main.c:162 ../raster/r.grow.distance/main.c:168
+#: ../raster/r.in.lidar/main.c:126 ../raster/r.in.lidar/main.c:253
+#: ../raster/r.in.lidar/main.c:286 ../raster/r.in.lidar/main.c:295
+#: ../raster/r.resamp.rst/main.c:174 ../raster/r.resamp.rst/main.c:180
+#: ../raster/r.resamp.rst/main.c:186 ../raster/r.resamp.rst/main.c:192
+#: ../raster/r.resamp.rst/main.c:198 ../raster/r.resamp.rst/main.c:204
+#: ../raster/r.resamp.rst/main.c:264 ../raster/r.in.xyz/main.c:297
+#: ../raster/r.spread/main.c:277 ../raster/r.spread/main.c:289
+#: ../raster/r.spread/main.c:301 ../raster/r.sim/r.sim.sediment/main.c:179
+#: ../raster/r.sim/r.sim.sediment/main.c:186
+#: ../raster/r.sim/r.sim.sediment/main.c:193
+#: ../raster/r.sim/r.sim.sediment/main.c:199
+#: ../raster/r.sim/r.sim.sediment/main.c:206
+#: ../raster/r.sim/r.sim.sediment/main.c:213
+#: ../raster/r.sim/r.sim.sediment/main.c:220
+#: ../raster/r.sim/r.sim.water/main.c:197
+#: ../raster/r.sim/r.sim.water/main.c:203
+#: ../raster/r.sim/r.sim.water/main.c:209
+#: ../raster/r.sim/r.sim.water/main.c:216
+#: ../raster/r.sim/r.sim.water/main.c:223
+#: ../raster/r.sim/r.sim.water/main.c:298 ../raster/r.sun/main.c:403
+#: ../raster/r.sun/main.c:412 ../raster/r.sun/main.c:421
+#: ../raster/r.sun/main.c:430 ../raster/r.sun/main.c:439
+#: ../raster/r.sun/main.c:448 ../raster/r.lake/main.c:167
+#: ../raster/r.lake/main.c:195 ../locale/scriptstrings/m.proj_to_translate.c:11
+#: ../locale/scriptstrings/m.proj_to_translate.c:23
+#: ../locale/scriptstrings/m.proj_to_translate.c:25
+#: ../locale/scriptstrings/m.proj_to_translate.c:27
+#: ../locale/scriptstrings/i.spectral_to_translate.c:10
+#: ../locale/scriptstrings/i.spectral_to_translate.c:12
+#: ../locale/scriptstrings/v.import_to_translate.c:10
+#: ../locale/scriptstrings/v.import_to_translate.c:13
+#: ../locale/scriptstrings/v.import_to_translate.c:16
+#: ../locale/scriptstrings/v.import_to_translate.c:19
+#: ../locale/scriptstrings/r.import_to_translate.c:12
+#: ../locale/scriptstrings/r.import_to_translate.c:15
+#: ../locale/scriptstrings/r.import_to_translate.c:18
+#: ../locale/scriptstrings/r.import_to_translate.c:21
+#: ../locale/scriptstrings/r.import_to_translate.c:23
+#: ../locale/scriptstrings/g.search.modules_to_translate.c:7
+#: ../locale/scriptstrings/g.search.modules_to_translate.c:9
+#: ../locale/scriptstrings/g.search.modules_to_translate.c:11
+#: ../locale/scriptstrings/g.search.modules_to_translate.c:14
+#: ../locale/scriptstrings/g.search.modules_to_translate.c:16
+#: ../locale/scriptstrings/g.search.modules_to_translate.c:18
+#: ../locale/scriptstrings/g.search.modules_to_translate.c:20
+#: ../locale/scriptstrings/db.in.ogr_to_translate.c:8
+#: ../locale/scriptstrings/db.in.ogr_to_translate.c:10
+#: ../locale/scriptstrings/db.in.ogr_to_translate.c:13
+#: ../raster3d/r3.in.lidar/main.c:190 ../raster3d/r3.in.lidar/main.c:196
+#: ../raster3d/r3.in.lidar/main.c:202 ../raster3d/r3.flow/main.c:211
+#: ../raster3d/r3.flow/main.c:218
+msgid "Output"
+msgstr "Izvade"
+#: ../vector/v.profile/main.c:222
+#, fuzzy
+msgid "Do not print column names"
+msgstr "Atslēga (id) kolonas nosaukums"
+#: ../vector/v.profile/main.c:227
+#, fuzzy
+msgid "Do not print 3D vector data (z values)"
+msgstr "Nevajag taisīt atribūtu tabulu"
+#: ../vector/v.profile/main.c:228
+msgid "Only affects 3D vectors"
 msgstr ""
-#: ../general/g.list/main.c:115 ../vector/v.out.ascii/args.c:33
-msgid "If not given or '-' then standard output"
+#: ../vector/v.profile/main.c:235
+#, fuzzy
+msgid "Coordinates for profiling line nodes"
+msgstr "Vienu koordinātu pāri uz līniju, lūdzu"
+#: ../vector/v.profile/main.c:236
+msgid "Specify profiling line vertexes and nodes"
 msgstr ""
-#: ../general/g.list/main.c:137
-msgid "Print data types"
+#: ../vector/v.profile/main.c:237 ../vector/v.profile/main.c:249
+#: ../vector/v.profile/main.c:260 ../vector/v.profile/main.c:268
+#, fuzzy
+msgid "Profiling line"
+msgstr "Izveidot punktus visā garumā ilīniju garumā"
+#: ../vector/v.profile/main.c:247
+#, fuzzy
+msgid "Profiling line map"
+#: ../vector/v.profile/main.c:248
+#, fuzzy
+msgid "Vector map containing profiling line"
+msgstr "Ieejošā karte satur līnijas"
+#: ../vector/v.profile/main.c:257
+msgid "WHERE conditions for input profile line map"
 msgstr ""
-#: ../general/g.list/main.c:142
-msgid "Print fully-qualified map names (including mapsets)"
+#: ../vector/v.profile/main.c:259
+msgid "Use to select only one line from profiling line map"
 msgstr ""
-#: ../general/g.list/main.c:147
-msgid "Pretty printing in human readable format"
+#: ../vector/v.profile/main.c:267
+#, fuzzy
+msgid "Profiling line map layer"
+#: ../vector/v.profile/main.c:288
+#, fuzzy
+msgid "Layer 0 not supported"
+#: ../vector/v.profile/main.c:293
+msgid "Failed to interpreter 'dp' parameter as an integer"
 msgstr ""
-#: ../general/g.list/main.c:152
-msgid "Verbose listing (also list map titles)"
+#: ../vector/v.profile/main.c:299
+#, fuzzy
+msgid "Tolerance value must be greater than 0"
+msgstr "2 līmeņiem jābūt norādītiem"
+#: ../vector/v.profile/main.c:304
+#, fuzzy, c-format
+msgid "<%s> is not a valid vector map name"
+msgstr "izejas līmeņa nosaukums"
+#: ../vector/v.profile/main.c:309
+msgid ""
+"No input profile map name provided, but WHERE conditions for it have been set"
 msgstr ""
-#: ../general/g.list/main.c:269
-#, c-format
-msgid "Mapset <%s> does not exist"
+#: ../vector/v.profile/main.c:313
+msgid ""
+"Profile input coordinates and vector map are provided. Please provide only "
+"one of them"
 msgstr ""
-#: ../general/g.list/list.c:123 ../general/g.region/main.c:457
-#, c-format
-msgid "Unable to read header of 3D raster map <%s@%s>"
+#: ../vector/v.profile/main.c:317
+msgid ""
+"No profile input coordinates nor vector map are provided. Please provide one "
+"of them"
 msgstr ""
-#: ../general/g.list/list.c:131
+#: ../vector/v.profile/main.c:330 ../vector/v.out.vtk/main.c:173
+#: ../vector/v.net/main.c:100 ../vector/v.edit/main.c:81
+#: ../vector/v.out.ascii/main.c:125 ../raster/r.horizon/main.c:385
+#: ../raster/r.out.ppm3/main.c:133 ../raster/r.out.ascii/main.c:157
+#: ../raster/r.in.lidar/main.c:646 ../raster/r.recode/main.c:90
+#: ../raster/r.profile/main.c:176 ../raster/r.category/main.c:173
+#: ../general/g.pnmcomp/main.c:242 ../general/g.pnmcomp/main.c:259
+#: ../misc/m.nviz.script/main.c:202 ../misc/m.transform/main.c:276
+#: ../display/d.mon/stop.c:66
+#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:348
 #, c-format
-msgid "Unable to open vector map <%s@%s> on topological level"
-msgstr ""
+msgid "Unable to open file <%s>"
+msgstr "Nebija iespējams atvērt failu <%s>"
-#: ../general/g.setproj/main.c:79 ../general/g.proj/main.c:65
-#: ../locale/scriptstrings/r.import_to_translate.c:4
-#: ../locale/scriptstrings/v.import_to_translate.c:4
-#: ../locale/scriptstrings/m.proj_to_translate.c:3 ../raster/r.proj/main.c:145
-#: ../raster/r.latlong/main.c:59 ../vector/v.proj/main.c:69
-msgid "projection"
-msgstr ""
+#: ../vector/v.profile/main.c:354
+#, fuzzy
+msgid "At least profile start and end coordinates are required!"
+msgstr "Vaicājuma koordinātes"
-#: ../general/g.setproj/main.c:81
-msgid "Interactively reset the location's projection settings."
+#: ../vector/v.profile/main.c:366 ../vector/v.cluster/main.c:146
+#: ../doc/vector/v.example/main.c:81
+msgid "Unable to set predetermined vector open level"
 msgstr ""
-#: ../general/g.setproj/main.c:88
-msgid "You must be in the PERMANENT mapset to run g.setproj"
-msgstr ""
+#: ../vector/v.profile/main.c:385 ../vector/v.profile/main.c:401
+#, fuzzy, c-format
+msgid ""
+"No database connection defined for map <%s> layer %d, but WHERE condition is "
+"provided"
+msgstr "Datubāzes konekcija nav definēta"
-#: ../general/g.setproj/main.c:101
-msgid "PERMANENT: permission denied"
+#: ../vector/v.profile/main.c:420 ../vector/v.profile/main.c:575
+#: ../vector/v.db.connect/main.c:217 ../vector/v.db.connect/main.c:283
+#: ../vector/v.out.vtk/writeVTK.c:644 ../vector/v.out.svg/main.c:152
+#: ../vector/v.edit/select.c:509 ../raster/r.stream.extract/close.c:178
+#: ../db/db.select/main.c:75 ../db/db.tables/main.c:45
+#: ../db/db.createdb/main.c:42 ../db/db.dropdb/main.c:42
+#: ../db/db.databases/main.c:48 ../db/db.describe/main.c:56
+#: ../db/db.columns/main.c:51 ../db/db.execute/main.c:70
+#: ../doc/vector/v.example/main.c:126 ../display/d.vect.thematic/main.c:294
+#: ../display/d.vect/opt.c:147
+#, c-format
+msgid "Unable to start driver <%s>"
 msgstr ""
-#: ../general/g.setproj/main.c:105
-msgid "Current region cannot be set"
-msgstr ""
+#: ../vector/v.profile/main.c:444 ../vector/v.profile/main.c:596
+#, fuzzy
+msgid "No features match Your query"
+msgstr "Vektorkartes nosaukums"
-#: ../general/g.setproj/main.c:108
-msgid "Retrieving and setting region failed"
+#: ../vector/v.profile/main.c:449 ../vector/v.profile/main.c:462
+msgid ""
+"Your query matches more than one record in input profiling map. Currently "
+"it's not supported. Enhance WHERE conditions to get only one line."
 msgstr ""
-#: ../general/g.setproj/main.c:135
-msgid "Would you still like to change some of the parameters?"
+#: ../vector/v.profile/main.c:455
+msgid "Error while initialising line list"
 msgstr ""
-#: ../general/g.setproj/main.c:137
-msgid "The projection information will not be updated"
+#: ../vector/v.profile/main.c:467
+msgid "Error while reading vector feature from profile line map"
 msgstr ""
-#: ../general/g.setproj/main.c:148
-#, c-format
+#: ../vector/v.profile/main.c:481
 msgid ""
-"Zone in default geographic region definition: %d\n"
-" is different from zone in PROJ_INFO file: %d"
+"Your input profile map contains more than one line. Currently it's not "
+"supported. Provide WHERE conditions to get only one line."
 msgstr ""
-#: ../general/g.setproj/main.c:158
-msgid "XY-location cannot be projected"
+#: ../vector/v.profile/main.c:501
+msgid "Failed to convert GRASS line to GEOS line"
 msgstr ""
-#: ../general/g.setproj/main.c:192
-msgid "Unknown projection"
-msgstr ""
+#: ../vector/v.profile/main.c:509
+#, fuzzy
+msgid "Buffering failed"
+msgstr "Lasam dig failu... \n"
-#: ../general/g.setproj/main.c:198
+#: ../vector/v.profile/main.c:556
 #, c-format
-msgid "Projection %s is not specified in the file 'proj-parms.table'"
+msgid "Vector map <%s> does not have cat's defined on layer %d"
 msgstr ""
-#: ../general/g.setproj/main.c:205
-msgid "Do you wish to specify a geodetic datum for this location?"
-msgstr ""
+#: ../vector/v.profile/main.c:683
+#, fuzzy, c-format
+msgid "Unabale to get attribute data for cat %d"
+msgstr "Nevar iatlasīt datus no tabulas"
-#: ../general/g.setproj/main.c:214
+#: ../vector/v.profile/main.c:692
 #, c-format
-msgid "The current datum is %s (%s)"
+msgid "Error while retreiving database record for cat %d"
 msgstr ""
-#: ../general/g.setproj/main.c:217
-msgid "Do you wish to change the datum (or datum transformation parameters)?"
+#: ../vector/v.profile/main.c:730
+msgid "Can not write data portion to provided output"
 msgstr ""
-#: ../general/g.setproj/main.c:225
-msgid "The datum information has not been changed"
+#: ../vector/v.to.db/parse.c:36
+msgid "Layer number or name (write to)"
 msgstr ""
-#: ../general/g.setproj/main.c:288
-#, c-format
-msgid "The current ellipsoid is %s"
-msgstr ""
+#: ../vector/v.to.db/parse.c:41 ../vector/v.vect.stats/main.c:151
+#: ../vector/v.net.bridge/main.c:101
+msgid "Feature type"
+msgstr "Objektu tips"
-#: ../general/g.setproj/main.c:290
-msgid "Do you want to change ellipsoid parameter?"
+#: ../vector/v.to.db/parse.c:43
+msgid "For coor valid point/centroid, for length valid line/boundary"
 msgstr ""
-#: ../general/g.setproj/main.c:294
-msgid "The ellipse information has not been changed"
+#: ../vector/v.to.db/parse.c:54
+msgid "Value to upload"
 msgstr ""
-#: ../general/g.setproj/main.c:311
-#, c-format
-msgid "The radius is currently %f"
+#: ../vector/v.to.db/parse.c:73
+msgid "insert new row for each category if doesn't exist yet"
 msgstr ""
-#: ../general/g.setproj/main.c:312
-msgid "Do you want to change the radius?"
+#: ../vector/v.to.db/parse.c:74
+msgid "area size"
 msgstr ""
-#: ../general/g.setproj/main.c:314 ../general/g.setproj/main.c:320
-msgid "Enter radius for the sphere in meters"
+#: ../vector/v.to.db/parse.c:75
+msgid ""
+"compactness of an area, calculated as \n"
+"              compactness = perimeter / (2 * sqrt(PI * area))"
 msgstr ""
-#: ../general/g.setproj/main.c:336
-msgid "Invalid input ellipsoid"
+#: ../vector/v.to.db/parse.c:77
+msgid ""
+"fractal dimension of boundary defining a polygon, calculated as \n"
+"              fd = 2 * (log(perimeter) / log(area))"
 msgstr ""
-#: ../general/g.setproj/main.c:447
-#, c-format
-msgid "The UTM zone is now set to %d"
+#: ../vector/v.to.db/parse.c:79
+msgid "perimeter length of an area"
 msgstr ""
-#: ../general/g.setproj/main.c:450
-msgid "Do you want to change the UTM zone?"
+#: ../vector/v.to.db/parse.c:80
+msgid "line length"
 msgstr ""
-#: ../general/g.setproj/main.c:451
-msgid "UTM zone information has not been updated"
+#: ../vector/v.to.db/parse.c:81
+msgid "number of features for each category"
 msgstr ""
-#: ../general/g.setproj/main.c:456
-msgid "But if you change zone, all the existing data will be interpreted by projection software. GRASS will not automatically re-project or even change the headers for existing maps."
+#: ../vector/v.to.db/parse.c:82
+msgid "point coordinates, X,Y or X,Y,Z"
 msgstr ""
-#: ../general/g.setproj/main.c:461
-msgid "Would you still like to change the UTM zone?"
+#: ../vector/v.to.db/parse.c:83
+msgid "line/boundary starting point coordinates, X,Y or X,Y,Z"
 msgstr ""
-#: ../general/g.setproj/main.c:497
-#, c-format
-msgid "Error writing PROJ_INFO file <%s>"
+#: ../vector/v.to.db/parse.c:84
+msgid "line/boundary end point coordinates, X,Y or X,Y,Z"
 msgstr ""
-#: ../general/g.setproj/main.c:571
-#, c-format
-msgid "Enter plural form of units [meters]: "
+#: ../vector/v.to.db/parse.c:85
+msgid ""
+"categories of areas on the left and right side of the boundary, "
+"'query_layer' is used for area category"
 msgstr ""
-#: ../general/g.setproj/main.c:603
-#, c-format
-msgid "Enter singular for unit: "
+#: ../vector/v.to.db/parse.c:87
+msgid ""
+"result of a database query for all records of the geometry(or geometries) "
+"from table specified by 'query_layer' option"
 msgstr ""
-#: ../general/g.setproj/main.c:611
-#, c-format
-msgid "Enter conversion factor from %s to meters: "
+#: ../vector/v.to.db/parse.c:89
+msgid "slope steepness of vector line or boundary"
 msgstr ""
-#: ../general/g.setproj/main.c:636
-#, c-format
-msgid "Error writing into UNITS output file <%s>"
+#: ../vector/v.to.db/parse.c:90
+msgid ""
+"line sinuousity, calculated as line length / distance between end points"
 msgstr ""
-#: ../general/g.setproj/main.c:643
-msgid "Unable to write to DEFAULT_WIND region file"
+#: ../vector/v.to.db/parse.c:91
+msgid ""
+"line azimuth, calculated as angle between North direction and endnode "
+"direction at startnode"
 msgstr ""
-#: ../general/g.setproj/main.c:645
-#, c-format
-msgid ""
-"\n"
-"Projection information has been recorded for this location\n"
-"\n"
+#: ../vector/v.to.db/parse.c:92
+#, fuzzy
+msgid "bounding box of area, N,S,E,W"
+msgstr "Nevar atrast vektoru karti [%s]"
+#: ../vector/v.to.db/parse.c:96
+msgid "Name of attribute column(s) to populate"
 msgstr ""
-#: ../general/g.setproj/main.c:647
-msgid "The geographic region information in WIND is now obsolete"
+#: ../vector/v.to.db/parse.c:105
+msgid "Query layer number or name (read from)"
 msgstr ""
-#: ../general/g.setproj/main.c:648
-msgid "Run g.region -d to update it"
+#: ../vector/v.to.db/parse.c:106 ../vector/v.to.db/parse.c:114
+#: ../raster/r.what/main.c:112 ../raster/r.what/main.c:118
+#: ../db/db.select/main.c:203 ../db/db.select/main.c:209
+#: ../db/db.select/main.c:213 ../db/db.select/main.c:251
+#: ../db/db.select/main.c:261
+msgid "Query"
 msgstr ""
-#: ../general/g.setproj/get_stp.c:43
-msgid "This should not happen. See your system admin."
+#: ../vector/v.to.db/parse.c:111
+msgid "Name of attribute column used for 'query' option"
 msgstr ""
-#: ../general/g.setproj/get_stp.c:99
-msgid "Unable to open FIPS code file"
+#: ../vector/v.to.db/parse.c:112
+msgid "E.g. 'cat', 'count(*)', 'sum(val)'"
 msgstr ""
-#: ../general/g.setproj/get_stp.c:125
-#, c-format
-msgid "No match of FIPS state %d county %d"
+#: ../vector/v.to.db/parse.c:117
+msgid "Field separator for print mode"
 msgstr ""
-#: ../general/g.setproj/get_stp.c:162 ../general/g.setproj/get_stp.c:165
-#: ../general/g.setproj/get_stp.c:282 ../general/g.setproj/get_stp.c:286
-#: ../raster3d/r3.in.ascii/main.c:169 ../raster/r.resamp.rst/main.c:542
-#: ../raster/r.in.ascii/main.c:120 ../raster/r.in.ascii/main.c:150
-#: ../display/d.title/main.c:117 ../vector/v.surf.rst/main.c:864
-#: ../vector/v.in.ascii/main.c:273
-#, c-format
-msgid "Unable to open temporary file <%s>"
+#: ../vector/v.to.db/parse.c:118 ../vector/v.to.db/parse.c:123
+#: ../vector/v.to.db/parse.c:129 ../vector/v.to.db/parse.c:135
+#: ../vector/v.db.connect/main.c:84 ../vector/v.db.connect/main.c:89
+#: ../vector/v.db.connect/main.c:96 ../vector/v.db.connect/main.c:103
+#: ../vector/v.external.out/args.c:63 ../vector/v.external.out/args.c:75
+#: ../vector/v.external.out/args.c:81 ../vector/v.in.ogr/main.c:295
+#: ../vector/v.in.ogr/main.c:301 ../vector/v.external/args.c:57
+#: ../vector/v.external/args.c:63 ../vector/v.external/args.c:71
+#: ../vector/v.what/main.c:91 ../vector/v.what/main.c:96
+#: ../vector/v.what/main.c:101 ../vector/v.what/main.c:106
+#: ../vector/v.what/main.c:111 ../vector/v.colors/main.c:133
+#: ../vector/v.info/parse.c:25 ../vector/v.info/parse.c:31
+#: ../vector/v.info/parse.c:36 ../vector/v.info/parse.c:41
+#: ../vector/v.info/parse.c:46 ../raster/r.sunmask/main.c:232
+#: ../raster/r.sunmask/main.c:238 ../raster/r.external/main.c:96
+#: ../raster/r.external/main.c:135 ../raster/r.external.out/main.c:272
+#: ../raster/r.external.out/main.c:283 ../raster/r.what/main.c:122
+#: ../raster/r.what/main.c:130 ../raster/r.what/main.c:144
+#: ../raster/r.what/main.c:149 ../raster/r.what/main.c:154
+#: ../raster/r.what/main.c:159 ../raster/r.what/main.c:169
+#: ../raster/r.out.gdal/main.c:145 ../raster/r.proj/main.c:204
+#: ../raster/r.proj/main.c:214 ../raster/r.proj/main.c:220
+#: ../raster/r.in.gdal/main.c:208 ../raster/r.in.gdal/main.c:241
+#: ../raster/r.colors/edit_colors.c:128
+#: ../locale/scriptstrings/t.rast.colors_to_translate.c:18
+#: ../locale/scriptstrings/g.extension_to_translate.c:16
+#: ../locale/scriptstrings/g.extension_to_translate.c:18
+#: ../locale/scriptstrings/g.extension_to_translate.c:20
+#: ../locale/scriptstrings/g.extension_to_translate.c:22
+#: ../locale/scriptstrings/v.unpack_to_translate.c:13
+#: ../locale/scriptstrings/r.unpack_to_translate.c:12
+#: ../general/g.mapset/main.c:76 ../general/g.mapset/main.c:82
+#: ../general/g.mapsets/main.c:87 ../general/g.mapsets/main.c:92
+#: ../general/g.mapsets/main.c:98 ../general/g.region/main.c:89
+#: ../general/g.region/main.c:95 ../general/g.region/main.c:100
+#: ../general/g.region/main.c:106 ../general/g.region/main.c:112
+#: ../general/g.region/main.c:118 ../general/g.region/main.c:124
+#: ../general/g.region/main.c:132 ../general/g.region/main.c:137
+#: ../general/g.region/main.c:143 ../general/g.region/main.c:148
+#: ../general/g.region/main.c:153 ../general/g.list/main.c:105
+#: ../general/g.list/main.c:116 ../general/g.list/main.c:138
+#: ../general/g.list/main.c:143 ../general/g.list/main.c:148
+#: ../general/g.list/main.c:153 ../general/g.proj/main.c:80
+#: ../general/g.proj/main.c:86 ../general/g.proj/main.c:92
+#: ../general/g.proj/main.c:98 ../general/g.proj/main.c:104
+#: ../general/g.proj/main.c:115 ../general/g.proj/main.c:120
+#: ../temporal/t.connect/main.c:43 ../db/db.connect/main.c:53
+#: ../db/db.connect/main.c:58 ../db/db.login/main.c:91
+#: ../display/d.mon/main.c:115 ../display/d.mon/main.c:120
+#: ../display/d.mon/main.c:125 ../imagery/i.group/main.c:79
+#: ../imagery/i.group/main.c:84 ../imagery/i.group/main.c:89
+msgid "Print"
+msgstr "Drukāt"
+#: ../vector/v.to.db/parse.c:122
+msgid "Print only"
 msgstr ""
-#: ../general/g.setproj/get_stp.c:179
-msgid "Reading sf key_value temp file"
+#: ../vector/v.to.db/parse.c:128
+msgid "Only print SQL statements"
 msgstr ""
-#: ../general/g.setproj/get_stp.c:212
-msgid "Invalid State FIPS code"
+#: ../vector/v.to.db/parse.c:134
+msgid "Print also totals for option length, area, or count"
 msgstr ""
-#: ../general/g.setproj/get_stp.c:302
-msgid "Reading cf key_value temp file"
+#: ../vector/v.to.db/parse.c:181
+msgid "This option requires one column"
 msgstr ""
-#: ../general/g.setproj/get_stp.c:336
-msgid "Invalid County FIPS code"
+#: ../vector/v.to.db/parse.c:186
+msgid "This option requires two columns"
 msgstr ""
-#: ../general/g.setproj/proj.c:168
-#, c-format
-msgid "Unrecognized 'ask' value in parms.table: %s"
+#: ../vector/v.to.db/parse.c:191
+msgid "This option requires at least two columns"
 msgstr ""
-#: ../general/g.setproj/proj.c:178
-#, c-format
-msgid "Unrecognized default value in parms.table: %s"
+#: ../vector/v.to.db/parse.c:196
+msgid "This option requires four columns"
 msgstr ""
-#: ../general/g.parser/main.c:74
-msgid "Usage"
-msgstr "Lietošana"
-#: ../general/g.parser/main.c:84
-msgid "Unable to open script file"
+#: ../vector/v.to.db/parse.c:203
+msgid "Parameter 'qcolumn' must be specified for 'option=query'"
 msgstr ""
-#: ../general/g.parser/main.c:99
-#, c-format
-msgid "Line too long or missing newline at line %d\n"
+#: ../vector/v.to.db/parse.c:208
+msgid "The 'sides' option makes sense only for boundaries"
 msgstr ""
-#: ../general/g.parser/main.c:139
-msgid "Error closing script file"
+#: ../vector/v.to.db/parse.c:211
+msgid "The 'sinuous' option makes sense only for lines"
 msgstr ""
-#: ../general/g.parser/rules.c:14
-#, c-format
-msgid "Unknown flag \"-%c\" in rule\n"
+#: ../vector/v.to.db/parse.c:214
+msgid "The 'azimuth' option makes sense only for lines"
 msgstr ""
-#: ../general/g.parser/rules.c:26
-#, c-format
-msgid "Unknown option \"%s\" in rule\n"
+#: ../vector/v.to.db/query.c:23 ../vector/v.to.db/lines.c:75
+#: ../vector/v.voronoi/main.c:208 ../vector/v.to.rast/do_lines.c:36
+#: ../vector/v.colors/scan_cats.c:19 ../vector/v.colors/scan_z.c:31
+#: ../vector/v.colors.out/scan_cats.c:28
+msgid "Reading features..."
 msgstr ""
-#: ../general/g.parser/rules.c:94
+#: ../vector/v.to.db/query.c:83 ../vector/v.to.db/main.c:65
+#: ../vector/v.to.db/update.c:28 ../vector/v.to.db/update.c:32
 #, c-format
-msgid "Unknown rule type \"%s\" at line %d\n"
+msgid "Database connection not defined for layer %d. Use v.db.connect first."
 msgstr ""
-#: ../general/g.parser/revoke.c:63
-msgid "G_spawn() failed"
+#: ../vector/v.to.db/query.c:93
+msgid "Querying database... "
 msgstr ""
-#: ../general/g.parser/revoke.c:71
-msgid "execl() failed"
+#: ../vector/v.to.db/query.c:109
+#, c-format
+msgid ""
+"Query for category '0' (no category) was not executed because of too many "
+"(%d) query categories. All later reported values for cat 0 are not valid."
 msgstr ""
-#: ../general/g.parser/parse.c:22
+#: ../vector/v.to.db/query.c:146
 #, c-format
-msgid "Unknown boolean value \"%s\" at line %d\n"
+msgid "Multiple query results, output value set to NULL (category [%d])"
 msgstr ""
-#: ../general/g.parser/parse.c:70
-#, c-format
-msgid "Unknown command \"%s\" at line %d\n"
+#: ../vector/v.to.db/query.c:153
+msgid "Unable to fetch record"
 msgstr ""
-#: ../general/g.parser/parse.c:103
-#, c-format
-msgid "Unknown module parameter \"%s\" at line %d\n"
+#: ../vector/v.to.db/main.c:38 ../vector/v.db.connect/main.c:54
+#: ../vector/v.vect.stats/main.c:132 ../vector/v.in.db/main.c:54
+#: ../vector/v.distance/main.c:123 ../vector/v.db.select/main.c:56
+#: ../locale/scriptstrings/db.out.ogr_to_translate.c:2
+#: ../locale/scriptstrings/db.droptable_to_translate.c:2
+#: ../locale/scriptstrings/v.db.droprow_to_translate.c:4
+#: ../locale/scriptstrings/v.what.vect_to_translate.c:4
+#: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:4
+#: ../locale/scriptstrings/db.univar_to_translate.c:2
+#: ../locale/scriptstrings/v.db.addcolumn_to_translate.c:4
+#: ../locale/scriptstrings/v.db.addtable_to_translate.c:4
+#: ../locale/scriptstrings/v.db.update_to_translate.c:4
+#: ../locale/scriptstrings/v.db.renamecolumn_to_translate.c:4
+#: ../locale/scriptstrings/v.db.join_to_translate.c:4
+#: ../locale/scriptstrings/db.in.ogr_to_translate.c:2
+#: ../locale/scriptstrings/v.db.dropcolumn_to_translate.c:4
+#: ../locale/scriptstrings/t.vect.db.select_to_translate.c:5
+#: ../locale/scriptstrings/v.db.droptable_to_translate.c:4
+#: ../locale/scriptstrings/db.test_to_translate.c:2
+#: ../locale/scriptstrings/db.dropcolumn_to_translate.c:2
+#: ../db/db.drivers/main.c:71 ../db/db.select/main.c:265
+#: ../db/db.connect/main.c:43 ../db/db.tables/main.c:97
+#: ../db/db.createdb/main.c:71 ../db/db.copy/main.c:35
+#: ../db/db.dropdb/main.c:71 ../db/db.login/main.c:40
+#: ../db/db.databases/main.c:95 ../db/db.describe/main.c:129
+#: ../db/db.columns/main.c:99 ../db/db.execute/main.c:125
+msgid "database"
 msgstr ""
-#: ../general/g.parser/parse.c:140
-#, c-format
-msgid "Unknown flag parameter \"%s\" at line %d\n"
+#: ../vector/v.to.db/main.c:39
+msgid "Populates attribute values from vector features."
 msgstr ""
-#: ../general/g.parser/parse.c:155
+#: ../vector/v.to.db/main.c:48
 #, c-format
-msgid "Unknown type \"%s\" at line %d\n"
+msgid ""
+"Vector map <%s> not found in the current mapset. Unable to modify vector "
+"maps from different mapsets."
 msgstr ""
-#: ../general/g.parser/parse.c:233
+#: ../vector/v.to.db/main.c:114
 #, c-format
-msgid "Unknown option parameter \"%s\" at line %d\n"
+msgid "Category index for vector map <%s> is not sorted"
 msgstr ""
-#: ../general/g.mapsets/main.c:65
-msgid "search path"
+#: ../vector/v.to.db/update.c:84
+msgid "Updating database..."
 msgstr ""
-#: ../general/g.mapsets/main.c:66
-msgid "Modifies/prints the user's current mapset search path."
+#: ../vector/v.to.db/update.c:125
+#, c-format
+msgid "More elements of category %d, nothing loaded to database"
 msgstr ""
-#: ../general/g.mapsets/main.c:67
-msgid "Affects the user's access to data existing under the other mapsets in the current location."
+#: ../vector/v.to.db/update.c:223
+#, c-format
+msgid "Record (cat %d) already exists (not inserted)"
 msgstr ""
-#: ../general/g.mapsets/main.c:73
-msgid "Name(s) of existing mapset(s) to add/remove or set"
+#: ../vector/v.to.db/report.c:13
+msgid "No totals for selected option"
 msgstr ""
-#: ../general/g.mapsets/main.c:81
-#: ../locale/scriptstrings/g.extension.all_to_translate.c:6
-#: ../locale/scriptstrings/g.extension_to_translate.c:10
-#: ../vector/v.net/args.c:36
-msgid "Operation to be performed"
+#: ../vector/v.to.db/report.c:211
+#, c-format
+msgid "%d categories read from vector map (layer %d)"
 msgstr ""
-#: ../general/g.mapsets/main.c:85
-msgid "Field separator for printing (-l and -p flags)"
+#: ../vector/v.to.db/report.c:215
+#, c-format
+msgid "%d records selected from table (layer %d)"
 msgstr ""
-#: ../general/g.mapsets/main.c:91
-msgid "List all available mapsets in alphabetical order"
+#: ../vector/v.to.db/report.c:218
+#, c-format
+msgid "%d categories read from vector map exist in selection from table"
 msgstr ""
-#: ../general/g.mapsets/main.c:97
-msgid "Print mapsets in current search path"
+#: ../vector/v.to.db/report.c:221
+#, c-format
+msgid "%d categories read from vector map don't exist in selection from table"
 msgstr ""
-#: ../general/g.mapsets/main.c:103
-msgid "Launch mapset selection GUI dialog"
+#: ../vector/v.to.db/report.c:223
+#, c-format
+msgid "%d records updated/inserted (layer %d)"
 msgstr ""
-#: ../general/g.mapsets/main.c:126
+#: ../vector/v.to.db/report.c:226
 #, c-format
-msgid "Unknown operation '%s'"
+msgid "%d update/insert errors (layer %d)"
 msgstr ""
-#: ../general/g.mapsets/main.c:136 ../general/g.mapsets/main.c:138
-#: ../general/g.mapsets/main.c:148 ../display/d.mon/main.c:157
+#: ../vector/v.to.db/report.c:229
 #, c-format
-msgid "Flag -%c ignored"
+msgid "%d categories with more points (coordinates not loaded)"
 msgstr ""
-#: ../general/g.mapsets/main.c:140 ../general/g.mapsets/main.c:150
-#: ../general/g.mapsets/main.c:158 ../display/d.mon/main.c:202
-#, c-format
-msgid "Option <%s> ignored"
+#: ../vector/v.to.db/areas.c:28 ../vector/v.to.rast/do_areas.c:34
+msgid "Reading areas..."
 msgstr ""
-#: ../general/g.mapsets/main.c:174 ../general/g.mapsets/main.c:208
+#: ../vector/v.surf.idw/read_sites.c:37
 #, c-format
-msgid "Mapset <%s> not found"
+msgid "Input vector map <%s> is 2D - using categories to interpolate"
 msgstr ""
-#: ../general/g.mapsets/main.c:181 ../general/g.mapsets/main.c:240
+#: ../vector/v.surf.idw/read_sites.c:40
 #, c-format
-msgid "Current mapset (<%s>) must always included in the search path"
+msgid "Input vector map <%s> is 3D - using z-coordinates to interpolate"
 msgstr ""
-#: ../general/g.mapsets/main.c:203
+#: ../vector/v.surf.idw/read_sites.c:70
 #, c-format
-msgid "Mapset <%s> already in the path"
-msgstr ""
+msgid "One record selected from table"
+msgid_plural "%d records selected from table"
+msgstr[0] ""
+msgstr[1] ""
+msgstr[2] ""
-#: ../general/g.mapsets/main.c:210
+#: ../vector/v.surf.idw/read_sites.c:107
+#: ../vector/v.surf.bspline/crosscorr.c:220
 #, c-format
-msgid "Mapset <%s> added to search path"
+msgid "No record for point (cat = %d)"
 msgstr ""
-#: ../general/g.mapsets/main.c:243
+#: ../vector/v.surf.idw/read_sites.c:123
 #, c-format
-msgid "Mapset <%s> removed from search path"
+msgid "%ld point loaded"
+msgid_plural "%ld points loaded"
+msgstr[0] ""
+msgstr[1] ""
+msgstr[2] ""
+#: ../vector/v.surf.idw/main.c:90 ../raster/r.surf.idw/main.c:107
+#: ../raster/r.fill.stats/main.c:778
+msgid "IDW"
 msgstr ""
-#: ../general/g.mapsets/main.c:255
-msgid "Search path not modified"
+#: ../vector/v.surf.idw/main.c:92
+msgid ""
+"Provides surface interpolation from vector point data by Inverse Distance "
+"Squared Weighting."
 msgstr ""
-#: ../general/g.mapsets/main.c:273
-msgid "Unable to open SEARCH_PATH for write"
+#: ../vector/v.surf.idw/main.c:101
+msgid "Name of attribute column with values to interpolate"
 msgstr ""
-#: ../general/g.mapsets/list.c:10
-msgid "Available mapsets:"
+#: ../vector/v.surf.idw/main.c:104
+msgid "Values"
 msgstr ""
-#: ../general/g.mapsets/list.c:35
-msgid "Accessible mapsets:"
+#: ../vector/v.surf.idw/main.c:113 ../raster/r.surf.idw/main.c:119
+msgid "Number of interpolation points"
 msgstr ""
-#: ../general/g.rename/main.c:47
-#: ../locale/scriptstrings/t.rename_to_translate.c:4
-msgid "rename"
-msgstr "pārdēvēt"
-#: ../general/g.rename/main.c:49
-msgid "Renames data base element files in the user's current mapset."
-msgstr "Pārsauc datubāzes elementu failus lietotāja pašreizējā karšu kopā."
-#: ../general/g.rename/main.c:55
-msgid "renamed"
+#: ../vector/v.surf.idw/main.c:121
+msgid "Power parameter"
 msgstr ""
-#: ../general/g.rename/main.c:76
-#, c-format
-msgid "%s <%s> not found"
+#: ../vector/v.surf.idw/main.c:123
+msgid "Greater values assign greater influence to closer points"
 msgstr ""
-#: ../general/g.rename/main.c:80
-#, c-format
-msgid "<%s> already exists in mapset <%s>"
+#: ../vector/v.surf.idw/main.c:128
+msgid "Don't index points by raster cell"
 msgstr ""
-#: ../general/g.rename/main.c:85 ../general/g.copy/main.c:80
-#: ../raster/r.watershed/shed/com_line.c:231
-#: ../raster/r.watershed/shed/com_line.c:266
-#: ../imagery/i.landsat.toar/main.c:564
-#: ../imagery/i.ortho.photo/i.ortho.camera/main.c:114
-#: ../imagery/i.landsat.acca/main.c:188
-#, c-format
-msgid "<%s> is an illegal file name"
+#: ../vector/v.surf.idw/main.c:129
+msgid ""
+"Slower but uses less memory and includes points from outside region in the "
+"interpolation"
 msgstr ""
-#: ../general/g.rename/main.c:90
+#: ../vector/v.surf.idw/main.c:139
 #, c-format
-msgid "%s=%s,%s: files could be the same, no rename possible"
+msgid "Illegal number (%s) of interpolation points"
 msgstr ""
-#: ../general/g.rename/main.c:116
-msgid "Updating reclass maps"
+#: ../vector/v.surf.idw/main.c:176 ../vector/v.normal/main.c:195
+#: ../vector/v.neighbors/main.c:175
+msgid "No points found"
 msgstr ""
-#: ../general/g.rename/main.c:184
+#. GTC Count of window rows
+#. GTC Count of raster rows
+#: ../vector/v.surf.idw/main.c:259 ../vector/v.kernel/main.c:302
+#: ../raster/r.thin/io.c:105 ../raster/r.thin/io.c:172
+#: ../raster/r.thin/io.c:181 ../display/d.rast.num/main.c:199
 #, c-format
-msgid "Unable to find reclass information for <%s> in base map <%s@%s>"
-msgstr ""
+msgid "%d row"
+msgid_plural "%d rows"
+msgstr[0] ""
+msgstr[1] ""
+msgstr[2] ""
-#: ../general/g.rename/main.c:188
+#. GTC Count of window columns
+#. GTC Count of raster columns
+#: ../vector/v.surf.idw/main.c:261 ../vector/v.kernel/main.c:303
+#: ../raster/r.thin/io.c:107 ../raster/r.thin/io.c:174
+#: ../raster/r.thin/io.c:183
 #, c-format
-msgid "Updating base map <%s@%s>"
-msgstr ""
+msgid "%d column"
+msgid_plural "%d columns"
+msgstr[0] ""
+msgstr[1] ""
+msgstr[2] ""
-#: ../general/g.rename/main.c:194
+#. GTC First argument is map name, second - message about number of rows, third - columns.
+#: ../vector/v.surf.idw/main.c:263
 #, c-format
-msgid "Unable to update dependency file in <%s@%s>"
+msgid "Interpolating raster map <%s> (%s, %s)..."
 msgstr ""
-#: ../general/g.region/printwindow.c:251 ../general/g.region/printwindow.c:475
-#: ../general/g.region/printwindow.c:542 ../raster/r.sun/main.c:745
-#: ../raster/r.horizon/main.c:531 ../display/d.where/main.c:107
-msgid "Can't get projection info of current location"
-msgstr ""
+#: ../vector/v.db.connect/main.c:55 ../vector/v.category/main.c:77
+msgid "layer"
+msgstr "slānis"
-#: ../general/g.region/printwindow.c:254 ../general/g.region/printwindow.c:478
-#: ../general/g.region/printwindow.c:547 ../raster/r.sun/main.c:749
-#: ../raster/r.horizon/main.c:534 ../display/d.where/main.c:110
-msgid "Can't get projection units of current location"
+#: ../vector/v.db.connect/main.c:57
+msgid "Prints/sets DB connection for a vector map to attribute table."
 msgstr ""
-#: ../general/g.region/printwindow.c:257 ../general/g.region/printwindow.c:481
-#: ../general/g.region/printwindow.c:550 ../raster/r.sun/main.c:753
-#: ../raster/r.horizon/main.c:538 ../display/d.grid/plot.c:554
-#: ../display/d.where/main.c:113 ../ps/ps.map/do_geogrid.c:272
-msgid "Can't get projection key values of current location"
+#: ../vector/v.db.connect/main.c:79
+msgid "Format: layer number[/layer name]"
 msgstr ""
-#: ../general/g.region/printwindow.c:267 ../general/g.region/printwindow.c:488
-#: ../general/g.region/printwindow.c:569 ../raster/r.sunhours/main.c:232
-msgid "Unable to update lat/long projection parameters"
+#: ../vector/v.db.connect/main.c:83
+msgid "Field separator for shell script style output"
 msgstr ""
-#: ../general/g.region/printwindow.c:285 ../general/g.region/printwindow.c:293
-#: ../general/g.region/printwindow.c:301 ../general/g.region/printwindow.c:309
-#: ../general/g.region/printwindow.c:319 ../general/g.region/printwindow.c:503
-#: ../general/g.region/printwindow.c:596 ../general/g.region/printwindow.c:608
-#: ../general/g.region/printwindow.c:625 ../general/g.region/printwindow.c:643
-#: ../general/g.region/printwindow.c:658 ../raster/r.sunhours/main.c:296
-#: ../raster/r.sunhours/main.c:391 ../raster/r.sunmask/g_solposition.c:127
-msgid "Error in pj_do_proj (projection of input coordinate pair)"
+#: ../vector/v.db.connect/main.c:88
+msgid "Print all map connection parameters and exit"
 msgstr ""
-#: ../general/g.region/printwindow.c:383
-msgid "You are already in Lat/Long. Use the -p flag instead."
+#: ../vector/v.db.connect/main.c:93
+msgid "Print all map connection parameters in shell script style and exit"
 msgstr ""
-#: ../general/g.region/printwindow.c:385
-msgid "You are in a simple XY location, projection to Lat/Lon is not possible. Use the -p flag instead."
+#: ../vector/v.db.connect/main.c:95
+msgid "Format: layer[/layer name] table key database driver"
 msgstr ""
-#: ../general/g.region/printwindow.c:559
-msgid "WGS84 output not possible as this location does not contain datum transformation parameters. Try running g.setproj."
+#: ../vector/v.db.connect/main.c:101
+msgid "Print types/names of table columns for specified layer and exit"
 msgstr ""
-#: ../general/g.region/printwindow.c:711
-msgid "Lat/Long calculations are not possible from a simple XY system"
+#: ../vector/v.db.connect/main.c:108
+msgid "Overwrite connection parameter for certain layer"
 msgstr ""
-#: ../general/g.region/main.c:66
-msgid "computational region"
+#: ../vector/v.db.connect/main.c:113
+msgid "Delete connection for certain layer (not the table)"
 msgstr ""
-#: ../general/g.region/main.c:67
-#: ../locale/scriptstrings/t.info_to_translate.c:4
-#: ../raster3d/r3.info/main.c:78 ../raster/r.info/main.c:72
-#: ../vector/v.info/main.c:40
-msgid "extent"
+#: ../vector/v.db.connect/main.c:149
+msgid "Please choose only one print style"
 msgstr ""
-#: ../general/g.region/main.c:68
-msgid "resolution"
+#: ../vector/v.db.connect/main.c:158 ../vector/v.kcv/main.c:168
+msgid "Unable to modify vector map stored in other mapset"
 msgstr ""
-#: ../general/g.region/main.c:70
-msgid "Manages the boundary definitions for the geographic region."
+#: ../vector/v.db.connect/main.c:166
+#, c-format
+msgid "Map <%s> is not connected to a database"
 msgstr ""
-#: ../general/g.region/main.c:76 ../raster/r.region/main.c:65
-msgid "Set from default region"
+#: ../vector/v.db.connect/main.c:175
+#, c-format
+msgid "Vector map <%s> is connected by:\n"
 msgstr ""
-#: ../general/g.region/main.c:77 ../general/g.region/main.c:83
-#: ../general/g.region/main.c:170 ../general/g.region/main.c:177
-#: ../general/g.region/main.c:186 ../general/g.region/main.c:194
-#: ../raster/r.region/main.c:61 ../raster/r.region/main.c:66
-#: ../raster/r.region/main.c:72 ../raster/r.region/main.c:87
-#: ../raster/r.region/main.c:94 ../raster/r.region/main.c:101
-#: ../raster/r.region/main.c:144
-msgid "Existing"
-msgstr "Eksistējošs"
+#: ../vector/v.db.connect/main.c:180 ../display/d.vect.thematic/main.c:290
+#: ../display/d.vect/opt.c:143
+msgid "Database connection not defined"
+msgstr "Nav definēts datubāzes savienojums"
-#: ../general/g.region/main.c:81
-msgid "Save as default region"
+#: ../vector/v.db.connect/main.c:197
+#, c-format
+msgid ""
+"layer <%d/%s> table <%s> in database <%s> through driver <%s> with key <%s>\n"
 msgstr ""
-#: ../general/g.region/main.c:82
-msgid "Only possible from the PERMANENT mapset"
+#: ../vector/v.db.connect/main.c:203
+#, c-format
+msgid ""
+"layer <%d> table <%s> in database <%s> through driver <%s> with key <%s>\n"
 msgstr ""
-#: ../general/g.region/main.c:87
-msgid "Print the current region"
+#: ../vector/v.db.connect/main.c:266
+#, c-format
+msgid "Use -o to overwrite existing link for layer <%d>"
 msgstr ""
-#: ../general/g.region/main.c:92
-msgid "Print the current region in lat/long using the current ellipsoid/datum"
+#: ../vector/v.db.connect/main.c:274 ../vector/v.db.connect/main.c:314
+#, c-format
+msgid "Table <%s> does not exist in database <%s>"
 msgstr ""
-#: ../general/g.region/main.c:98
-msgid "Print the current region extent"
+#: ../vector/v.db.connect/main.c:295 ../vector/v.in.db/main.c:190
+msgid "Data type of key column must be integer"
 msgstr ""
-#: ../general/g.region/main.c:104
-msgid "Print the current region map center coordinates"
+#: ../vector/v.db.connect/main.c:302 ../vector/v.db.connect/main.c:320
+#, c-format
+msgid ""
+"The table <%s> is now part of vector map <%s> and may be deleted or "
+"overwritten by GRASS modules"
 msgstr ""
-#: ../general/g.region/main.c:110
-msgid "Print the current region in GMT style"
-msgstr ""
+#: ../vector/v.db.connect/main.c:341 ../vector/v.kcv/main.c:179
+#, c-format
+msgid "Cannot grant privileges on table %s"
+msgstr "Nevar piešķirt privilēģijas tabulai %s"
-#: ../general/g.region/main.c:116
-msgid "Print the current region in WMS style"
+#: ../vector/v.db.connect/main.c:344 ../vector/v.kcv/main.c:182
+msgid "Select privileges were granted on the table"
 msgstr ""
-#: ../general/g.region/main.c:122
-msgid "Print region resolution in meters (geodesic)"
+#: ../vector/v.db.connect/main.c:351
+msgid ""
+"For defining a new connection you have to specify these parameters: driver, "
+"database, table [, key [, layer]]"
 msgstr ""
-#: ../general/g.region/main.c:127
-msgid "Print the convergence angle (degrees CCW)"
-msgstr ""
+#: ../vector/v.net.allpairs/main.c:62 ../vector/v.net.steiner/main.c:347
+#: ../vector/v.net/main.c:48 ../vector/v.net.alloc/main.c:65
+#: ../vector/v.net.components/main.c:73 ../vector/v.net.iso/main.c:77
+#: ../vector/v.net.bridge/main.c:48 ../vector/v.net.flow/main.c:59
+#: ../vector/v.net.path/main.c:43 ../vector/v.net.visibility/main.c:46
+#: ../vector/v.net.connectivity/main.c:53
+#: ../vector/v.lrs/v.lrs.label/main.c:104 ../vector/v.lrs/v.lrs.where/main.c:59
+#: ../vector/v.lrs/v.lrs.create/main.c:123
+#: ../vector/v.lrs/v.lrs.segment/main.c:73 ../vector/v.net.timetable/main.c:261
+#: ../vector/v.net.distance/main.c:67 ../vector/v.net.spanningtree/main.c:47
+#: ../vector/v.net.salesman/main.c:128 ../vector/v.net.centrality/main.c:97
+#: ../display/d.path/main.c:49
+msgid "network"
+msgstr "tīkls"
-#: ../general/g.region/main.c:129
-msgid "The difference between the projection's grid north and true north, measured at the center coordinates of the current region."
+#: ../vector/v.net.allpairs/main.c:63 ../vector/v.net.path/main.c:44
+#: ../vector/v.net.visibility/main.c:47 ../vector/v.net.timetable/main.c:262
+#: ../vector/v.net.distance/main.c:68 ../display/d.geodesic/main.c:49
+#: ../display/d.path/main.c:50
+msgid "shortest path"
+msgstr "īsākais ceļš"
+#: ../vector/v.net.allpairs/main.c:65
+msgid "Computes the shortest path between all pairs of nodes in the network."
 msgstr ""
-#: ../general/g.region/main.c:135
-msgid "Print also 3D settings"
+#: ../vector/v.net.allpairs/main.c:74 ../vector/v.net.steiner/main.c:368
+#: ../vector/v.net/args.c:56 ../vector/v.net.alloc/main.c:96
+#: ../vector/v.net.components/main.c:84 ../vector/v.net.iso/main.c:117
+#: ../vector/v.net.bridge/main.c:60 ../vector/v.net.flow/main.c:70
+#: ../vector/v.net.path/main.c:54 ../vector/v.net.connectivity/main.c:64
+#: ../vector/v.net.timetable/main.c:274 ../vector/v.net.distance/main.c:82
+#: ../vector/v.net.spanningtree/main.c:59 ../vector/v.net.salesman/main.c:149
+#: ../vector/v.net.centrality/main.c:109 ../display/d.path/main.c:70
+msgid "Arc layer"
 msgstr ""
-#: ../general/g.region/main.c:141
-msgid "Print the maximum bounding box in lat/long on WGS84"
+#: ../vector/v.net.allpairs/main.c:80 ../vector/v.net/args.c:70
+#: ../vector/v.net.alloc/main.c:109 ../vector/v.net.components/main.c:90
+#: ../vector/v.net.iso/main.c:130 ../vector/v.net.bridge/main.c:66
+#: ../vector/v.net.flow/main.c:76 ../vector/v.net.path/main.c:67
+#: ../vector/v.net.connectivity/main.c:70 ../vector/v.net.timetable/main.c:280
+#: ../vector/v.net.distance/main.c:95 ../vector/v.net.spanningtree/main.c:65
+#: ../vector/v.net.centrality/main.c:115 ../display/d.path/main.c:75
+msgid "Node layer"
 msgstr ""
-#: ../general/g.region/main.c:146
-#: ../locale/scriptstrings/t.info_to_translate.c:9
-#: ../locale/scriptstrings/i.oif_to_translate.c:6
-#: ../raster/r.regression.line/main.c:69
-#: ../raster/r.regression.multi/main.c:161 ../imagery/i.group/main.c:88
-msgid "Print in shell script style"
+#: ../vector/v.net.allpairs/main.c:93 ../vector/v.net.alloc/main.c:114
+#: ../vector/v.net.components/main.c:97 ../vector/v.net.iso/main.c:135
+#: ../vector/v.net.bridge/main.c:73 ../vector/v.net.flow/main.c:90
+#: ../vector/v.net.path/main.c:79 ../vector/v.net.connectivity/main.c:77
+#: ../vector/v.net.timetable/main.c:288 ../vector/v.net.distance/main.c:141
+#: ../vector/v.net.spanningtree/main.c:72 ../vector/v.net.salesman/main.c:168
+#: ../vector/v.net.centrality/main.c:129 ../display/d.path/main.c:81
+msgid "Arc forward/both direction(s) cost column (number)"
 msgstr ""
-#: ../general/g.region/main.c:151
-#, fuzzy
-msgid "Print in shell script style, but in one line (flat)"
-msgstr "Drukāt statistiku komandrindas skripta stilā"
+#: ../vector/v.net.allpairs/main.c:94 ../vector/v.net.allpairs/main.c:100
+#: ../vector/v.net.allpairs/main.c:107 ../vector/v.net.alloc/main.c:82
+#: ../vector/v.net.alloc/main.c:115 ../vector/v.net.alloc/main.c:120
+#: ../vector/v.net.alloc/main.c:125 ../vector/v.net.components/main.c:85
+#: ../vector/v.net.components/main.c:91 ../vector/v.net.components/main.c:98
+#: ../vector/v.net.components/main.c:104 ../vector/v.net.components/main.c:111
+#: ../vector/v.net.iso/main.c:96 ../vector/v.net.iso/main.c:136
+#: ../vector/v.net.iso/main.c:141 ../vector/v.net.iso/main.c:146
+#: ../vector/v.net.bridge/main.c:61 ../vector/v.net.bridge/main.c:67
+#: ../vector/v.net.bridge/main.c:74 ../vector/v.net.bridge/main.c:80
+#: ../vector/v.net.bridge/main.c:87 ../vector/v.net.flow/main.c:71
+#: ../vector/v.net.flow/main.c:77 ../vector/v.net.flow/main.c:91
+#: ../vector/v.net.flow/main.c:97 ../vector/v.net.flow/main.c:103
+#: ../vector/v.net.path/main.c:80 ../vector/v.net.path/main.c:87
+#: ../vector/v.net.path/main.c:94 ../vector/v.net.connectivity/main.c:65
+#: ../vector/v.net.connectivity/main.c:71
+#: ../vector/v.net.connectivity/main.c:78
+#: ../vector/v.net.connectivity/main.c:84
+#: ../vector/v.net.connectivity/main.c:92 ../vector/v.net.timetable/main.c:275
+#: ../vector/v.net.timetable/main.c:281 ../vector/v.net.timetable/main.c:289
+#: ../vector/v.net.timetable/main.c:296 ../vector/v.net.timetable/main.c:303
+#: ../vector/v.net.distance/main.c:83 ../vector/v.net.distance/main.c:90
+#: ../vector/v.net.distance/main.c:96 ../vector/v.net.distance/main.c:142
+#: ../vector/v.net.distance/main.c:148 ../vector/v.net.distance/main.c:154
+#: ../vector/v.net.spanningtree/main.c:60
+#: ../vector/v.net.spanningtree/main.c:66
+#: ../vector/v.net.spanningtree/main.c:73
+#: ../vector/v.net.spanningtree/main.c:79 ../vector/v.net.salesman/main.c:169
+#: ../vector/v.net.salesman/main.c:177 ../vector/v.net.centrality/main.c:110
+#: ../vector/v.net.centrality/main.c:116 ../vector/v.net.centrality/main.c:130
+#: ../vector/v.net.centrality/main.c:136 ../vector/v.net.centrality/main.c:143
+msgid "Cost"
+msgstr "Izmaksas"
-#: ../general/g.region/main.c:157
-msgid "Align region to resolution (default = align to bounds, works only for 2D resolution)"
+#: ../vector/v.net.allpairs/main.c:99 ../vector/v.net.alloc/main.c:119
+#: ../vector/v.net.components/main.c:103 ../vector/v.net.iso/main.c:140
+#: ../vector/v.net.bridge/main.c:79 ../vector/v.net.flow/main.c:96
+#: ../vector/v.net.path/main.c:86 ../vector/v.net.connectivity/main.c:83
+#: ../vector/v.net.timetable/main.c:295 ../vector/v.net.distance/main.c:147
+#: ../vector/v.net.centrality/main.c:135 ../display/d.path/main.c:87
+msgid "Arc backward direction cost column (number)"
 msgstr ""
-#: ../general/g.region/main.c:159 ../general/g.region/main.c:203
-#: ../general/g.region/main.c:212 ../general/g.region/main.c:221
-#: ../general/g.region/main.c:230 ../general/g.region/main.c:239
-#: ../general/g.region/main.c:248 ../general/g.region/main.c:324
-#: ../general/g.region/main.c:335 ../raster3d/r3.in.bin/main.c:284
-#: ../raster3d/r3.in.bin/main.c:292 ../raster3d/r3.in.bin/main.c:300
-#: ../raster3d/r3.in.bin/main.c:308 ../raster3d/r3.in.bin/main.c:316
-#: ../raster3d/r3.in.bin/main.c:323 ../raster3d/r3.in.bin/main.c:330
-#: ../raster3d/r3.in.bin/main.c:337 ../raster3d/r3.in.bin/main.c:344
-#: ../raster/r.in.bin/main.c:285 ../raster/r.in.bin/main.c:339
-#: ../raster/r.in.bin/main.c:347 ../raster/r.in.bin/main.c:355
-#: ../raster/r.in.bin/main.c:363 ../raster/r.in.bin/main.c:370
-#: ../raster/r.in.bin/main.c:377 ../raster/r.region/main.c:110
-#: ../raster/r.region/main.c:119 ../raster/r.region/main.c:128
-#: ../raster/r.region/main.c:137
-msgid "Bounds"
-msgstr "Robežas"
+#: ../vector/v.net.allpairs/main.c:106 ../vector/v.net.alloc/main.c:124
+#: ../vector/v.net.components/main.c:110 ../vector/v.net.iso/main.c:145
+#: ../vector/v.net.bridge/main.c:86 ../vector/v.net.flow/main.c:102
+#: ../vector/v.net.path/main.c:93 ../vector/v.net.connectivity/main.c:91
+#: ../vector/v.net.timetable/main.c:302 ../vector/v.net.distance/main.c:153
+#: ../vector/v.net.spanningtree/main.c:78 ../vector/v.net.centrality/main.c:142
+msgid "Node cost column (number)"
+msgstr ""
-#: ../general/g.region/main.c:163
-msgid "Do not update the current region"
+#: ../vector/v.net.allpairs/main.c:112 ../vector/v.net.steiner/main.c:398
+#: ../vector/v.net.alloc/main.c:151 ../vector/v.net.iso/main.c:172
+#: ../vector/v.net.path/main.c:132 ../vector/v.net.distance/main.c:159
+#: ../vector/v.net.spanningtree/main.c:84 ../vector/v.net.salesman/main.c:208
+#: ../vector/v.net.centrality/main.c:188 ../display/d.path/main.c:122
+msgid "Use geodesic calculation for longitude-latitude locations"
 msgstr ""
-#: ../general/g.region/main.c:164 ../general/g.region/main.c:346
-#: ../vector/v.label/main.c:90 ../vector/v.label/main.c:95
-#: ../vector/v.label/main.c:170 ../vector/v.label/main.c:183
-msgid "Effects"
+#: ../vector/v.net.allpairs/main.c:142 ../vector/v.net.path/main.c:148
+#: ../vector/v.net.distance/main.c:205 ../vector/v.net.spanningtree/main.c:113
+#: ../vector/v.net.centrality/main.c:222 ../display/d.path/main.c:178
+msgid "The current projection is not longitude-latitude"
 msgstr ""
-#: ../general/g.region/main.c:169
-msgid "Set current region from named region"
+#: ../vector/v.net.allpairs/main.c:179 ../vector/v.in.dwg/main.c:240
+#: ../vector/v.in.ogr/main.c:1059 ../vector/v.in.lidar/attributes.c:135
+#: ../vector/v.to.points/main.c:192 ../vector/v.net.alloc/main.c:329
+#: ../vector/v.net.components/main.c:190 ../vector/v.net.iso/main.c:390
+#: ../vector/v.distance/main.c:1419 ../vector/v.net.flow/main.c:181
+#: ../vector/v.overlay/main.c:587 ../vector/v.net.path/path.c:109
+#: ../vector/v.net.timetable/main.c:103 ../vector/v.net.distance/main.c:291
+#: ../vector/v.net.centrality/main.c:266 ../raster/r.stream.extract/close.c:194
+#: ../raster/r.contour/main.c:183
+#, c-format
+msgid "Unable to create table: '%s'"
 msgstr ""
-#: ../general/g.region/main.c:176
-msgid "Set region to match raster map(s)"
+#: ../vector/v.net.allpairs/main.c:187 ../vector/v.net.alloc/main.c:337
+#: ../vector/v.net.components/main.c:198 ../vector/v.net.iso/main.c:398
+#: ../vector/v.net.flow/main.c:189 ../vector/v.net.path/path.c:117
+#: ../vector/v.net.timetable/main.c:112 ../vector/v.net.distance/main.c:299
+#: ../vector/v.net.centrality/main.c:274
+#, c-format
+msgid "Cannot grant privileges on table <%s>"
 msgstr ""
-#: ../general/g.region/main.c:184
-msgid "Set region to match 3D raster map(s) (both 2D and 3D values)"
+#: ../vector/v.net.allpairs/main.c:208
+msgid "Writing node points..."
 msgstr ""
-#: ../general/g.region/main.c:192
-msgid "Set region to match vector map(s)"
+#: ../vector/v.net.allpairs/main.c:242
+msgid "Collecting shortest paths..."
 msgstr ""
-#: ../general/g.region/main.c:202 ../raster/r.region/main.c:109
-msgid "Value for the northern edge"
-msgstr "Ziemeļu šķautnes vērtība"
-#: ../general/g.region/main.c:211 ../raster/r.region/main.c:118
-msgid "Value for the southern edge"
-msgstr "Dienvidu šķautnes vērtība"
-#: ../general/g.region/main.c:220 ../raster/r.region/main.c:127
-msgid "Value for the eastern edge"
-msgstr "Austrumu šķautnes vērtība"
-#: ../general/g.region/main.c:229 ../raster/r.region/main.c:136
-msgid "Value for the western edge"
-msgstr "Rietumu šķautnes vērtība"
-#: ../general/g.region/main.c:238
-msgid "Value for the top edge"
+#: ../vector/v.net.allpairs/main.c:271 ../vector/v.net.alloc/main.c:432
+#: ../vector/v.net.alloc/main.c:464 ../vector/v.net.alloc/main.c:495
+#: ../vector/v.net.alloc/main.c:533 ../vector/v.net.alloc/main.c:561
+#: ../vector/v.net.alloc/main.c:612 ../vector/v.net.alloc/main.c:648
+#: ../vector/v.net.alloc/main.c:679 ../vector/v.net.components/main.c:39
+#: ../vector/v.net.iso/main.c:724 ../vector/v.net.iso/main.c:754
+#: ../vector/v.net.flow/main.c:262 ../vector/v.net.path/path.c:350
+#: ../vector/v.net.timetable/main.c:134 ../vector/v.net.timetable/main.c:156
+#: ../vector/v.net.distance/main.c:363 ../vector/v.net.centrality/main.c:69
+#: ../raster/r.random/random.c:190
+#, c-format
+msgid "Cannot insert new record: %s"
 msgstr ""
-#: ../general/g.region/main.c:247
-msgid "Value for the bottom edge"
+#: ../vector/v.net.allpairs/main.c:296
+msgid "Writing shortest paths..."
 msgstr ""
-#: ../general/g.region/main.c:256
-msgid "Number of rows in the new region"
-msgstr "Jaunā reģiona rindu skaits"
+#: ../vector/v.voronoi/sw_main.c:188
+#, c-format
+msgid ""
+"Found %d point/centroid in <%s>, but at least 2 are needed. Are the current "
+"region extents covering at least parts of the input map?"
+msgid_plural ""
+"Found %d points/centroids in <%s>, but at least 2 are needed. Are the "
+"current region extents covering at least parts of the input map?"
+msgstr[0] ""
+msgstr[1] ""
+msgstr[2] ""
-#: ../general/g.region/main.c:257 ../general/g.region/main.c:266
-#: ../general/g.region/main.c:276 ../general/g.region/main.c:286
-#: ../general/g.region/main.c:295 ../general/g.region/main.c:304
-#: ../general/g.region/main.c:313
-msgid "Resolution"
-msgstr "Izšķirtspēja"
+#: ../vector/v.voronoi/sw_main.c:412 ../vector/v.voronoi/sw_main.c:438
+msgid "All boundaries in the list should be valid"
+msgstr ""
-#: ../general/g.region/main.c:265
-msgid "Number of columns in the new region"
-msgstr "Jaunā reģiona kolonu skaits"
-#: ../general/g.region/main.c:275
-msgid "2D grid resolution (north-south and east-west)"
+#: ../vector/v.voronoi/sw_main.c:418 ../vector/v.voronoi/sw_main.c:444
+msgid "Boundary is degenerate"
 msgstr ""
-#: ../general/g.region/main.c:285
-msgid "3D grid resolution (north-south, east-west and top-bottom)"
-msgstr "3D izšķirtspēja (abas ziemļi-dienvidi, austrumi-rietumi un augša-apakša)"
+#: ../vector/v.voronoi/sw_main.c:470
+#, c-format
+msgid "Found %d vertex in <%s>, but at least 2 are needed"
+msgid_plural "Found %d vertices in <%s>, but at least 2 are needed"
+msgstr[0] ""
+msgstr[1] ""
+msgstr[2] ""
-#: ../general/g.region/main.c:294
-msgid "North-south 2D grid resolution"
+#: ../vector/v.voronoi/clean_topo.c:20
+msgid "Searching for topology errors..."
 msgstr ""
-#: ../general/g.region/main.c:303
-msgid "East-west 2D grid resolution"
+#: ../vector/v.voronoi/clean_topo.c:78
+msgid "Cleaning output topology"
 msgstr ""
-#: ../general/g.region/main.c:312
-msgid "Top-bottom 3D grid resolution"
+#: ../vector/v.voronoi/clean_topo.c:87 ../vector/v.in.ogr/main.c:1380
+#: ../vector/v.buffer/main.c:773
+msgid "Removing dangles..."
 msgstr ""
-#: ../general/g.region/main.c:322
-msgid "Shrink region until it meets non-NULL data from this raster map"
+#: ../vector/v.voronoi/clean_topo.c:89 ../vector/v.in.ogr/main.c:1395
+#: ../vector/v.buffer/main.c:776
+msgid "Removing bridges..."
 msgstr ""
-#: ../general/g.region/main.c:333
-msgid "Adjust region cells to cleanly align with this raster map"
+#: ../vector/v.voronoi/clean_topo.c:115
+msgid "Removing incorrect boundaries from output"
 msgstr ""
-#: ../general/g.region/main.c:344
-msgid "Save current region settings in named region file"
+#: ../vector/v.voronoi/main.c:125 ../vector/v.delaunay/main.c:87
+msgid "triangulation"
 msgstr ""
-#: ../general/g.region/main.c:413 ../scripts/r.in.wms/r.in.wms.py:196
-#, c-format, python-format
-msgid "Region <%s> not found"
+#: ../vector/v.voronoi/main.c:126
+msgid "skeleton"
 msgstr ""
-#: ../general/g.region/main.c:454 ../raster3d/r3.out.v5d/main.c:307
-#: ../raster3d/r3.out.bin/main.c:299 ../raster3d/r3.neighbors/main.c:229
-#: ../raster3d/r3.out.ascii/main.c:326 ../raster3d/r3.null/main.c:103
-#: ../raster3d/r3.cross.rast/main.c:245 ../raster3d/r3.stats/main.c:96
-#: ../raster3d/r3.out.netcdf/main.c:600 ../raster3d/r3.flow/main.c:87
-#: ../raster3d/r3.support/main.c:135 ../raster3d/r3.mask/main.c:58
-#: ../raster3d/r3.to.rast/main.c:275 ../raster3d/r3.timestamp/main.c:73
-#: ../raster3d/r3.retile/main.c:113 ../raster3d/r3.out.vtk/main.c:142
-#: ../raster/r.univar/r3.univar_main.c:144
-#: ../raster/r.univar/r3.univar_main.c:182 ../raster/r.colors/edit_colors.c:400
-#: ../vector/v.colors/main.c:319
-#, c-format
-msgid "3D raster map <%s> not found"
+#: ../vector/v.voronoi/main.c:127
+msgid ""
+"Creates a Voronoi diagram constrained to the extents of the current region "
+"from an input vector map containing points or centroids."
 msgstr ""
-#: ../general/g.region/main.c:498
+#: ../vector/v.voronoi/main.c:131
 #, fuzzy
-msgid "Unable to get map bounding box"
-msgstr "Nevar atrast vektoru karti [%s]"
+msgid "Name of input vector map"
-#: ../general/g.region/main.c:783
-#, c-format
-msgid "Unable to set region <%s>"
+#: ../vector/v.voronoi/main.c:141
+msgid "Factor for output smoothness"
 msgstr ""
-#: ../general/g.region/main.c:789
-msgid "Unable to update current region"
+#: ../vector/v.voronoi/main.c:142
+msgid ""
+"Applies to input areas only. Smaller values produce smoother output but can "
+"cause numerical instability."
 msgstr ""
-#: ../general/g.region/main.c:797
-msgid "Unable to change default region. The current mapset is not <PERMANENT>."
+#: ../vector/v.voronoi/main.c:149
+msgid "Maximum dangle length of skeletons"
 msgstr ""
-#: ../general/g.region/main.c:814 ../raster/r.in.lidar/main.c:523
-#, c-format
-msgid "Invalid input <%s=%s>"
+#: ../vector/v.voronoi/main.c:150
+msgid ""
+"Applies only to skeleton extraction. Default = -1 will extract the center "
+"line."
 msgstr ""
-#: ../general/g.proj/main.c:66
-msgid "create location"
+#: ../vector/v.voronoi/main.c:156
+msgid "Create Voronoi diagram for input areas"
 msgstr ""
-#: ../general/g.proj/main.c:69
-msgid "Prints or modifies GRASS projection information files (in various co-ordinate system descriptions)."
+#: ../vector/v.voronoi/main.c:161
+msgid "Extract skeletons for input areas"
 msgstr ""
-#: ../general/g.proj/main.c:72
-msgid "Can also be used to create new GRASS locations."
+#: ../vector/v.voronoi/main.c:166
+msgid "Output tessellation as a graph (lines), not areas"
 msgstr ""
-#: ../general/g.proj/main.c:75
-msgid "Prints and manipulates GRASS projection information files."
+#: ../vector/v.voronoi/main.c:182
+#, c-format
+msgid "Option '%s' is too small, set to %g"
 msgstr ""
-#: ../general/g.proj/main.c:82
-msgid "Print projection information in conventional GRASS format"
+#: ../vector/v.voronoi/main.c:226
+#, c-format
+msgid "Voronoi triangulation for %d point..."
+msgid_plural "Voronoi triangulation for %d points..."
+msgstr[0] ""
+msgstr[1] ""
+msgstr[2] ""
+#: ../vector/v.voronoi/main.c:230 ../vector/v.delaunay/in_out.c:93
+msgid "Writing edges..."
 msgstr ""
-#: ../general/g.proj/main.c:88
-msgid "Print projection information in shell script style"
+#: ../vector/v.voronoi/main.c:239
+msgid "Thin skeletons ..."
 msgstr ""
-#: ../general/g.proj/main.c:94
-msgid "Verify datum information and print transformation parameters"
+#: ../vector/v.voronoi/main.c:322 ../vector/v.in.db/main.c:235
+msgid "Writing features..."
 msgstr ""
-#: ../general/g.proj/main.c:100
-msgid "Print projection information in PROJ.4 format"
+#: ../vector/v.voronoi/main.c:396
+msgid "No table"
 msgstr ""
-#: ../general/g.proj/main.c:106
-msgid "Print 'flat' output with no linebreaks (applies to WKT and PROJ.4 output)"
+#: ../vector/v.voronoi/main.c:411
+msgid "Cannot copy table"
+msgstr "Nevar nokopēt tabulu"
+#: ../vector/v.voronoi/skeleton.c:293 ../vector/v.voronoi/skeleton.c:400
+#, c-format
+msgid "Pass %d"
 msgstr ""
-#: ../general/g.proj/main.c:116
-msgid "Print projection information in WKT format"
+#: ../vector/v.voronoi/skeleton.c:509
+msgid "Node is outside any input area"
 msgstr ""
-#: ../general/g.proj/main.c:122
-msgid "Use ESRI-style format (applies to WKT output only)"
+#: ../vector/v.class/main.c:46 ../raster/r.kappa/main.c:70
+#: ../imagery/i.smap/main.c:39 ../imagery/i.cluster/main.c:76
+#: ../imagery/i.gensigset/main.c:41 ../imagery/i.maxlik/main.c:62
+#: ../imagery/i.segment/main.c:38 ../imagery/i.gensig/main.c:40
+msgid "classification"
 msgstr ""
-#: ../general/g.proj/main.c:129 ../general/g.proj/main.c:138
-#: ../general/g.proj/main.c:148 ../general/g.proj/main.c:158
-msgid "Specification"
+#: ../vector/v.class/main.c:50
+msgid "Classifies attribute data, e.g. for thematic mapping"
 msgstr ""
-#: ../general/g.proj/main.c:130
-msgid "Name of georeferenced data file to read projection information from"
+#: ../vector/v.class/main.c:58
+msgid "Column name or expression"
 msgstr ""
-#: ../general/g.proj/main.c:139
-msgid "Name of ASCII file containing a WKT projection description"
+#: ../vector/v.class/main.c:68 ../display/d.vect.thematic/main.c:119
+msgid "Algorithm to use for classification"
 msgstr ""
-#: ../general/g.proj/main.c:141 ../general/g.proj/main.c:150
-#: ../locale/scriptstrings/m.proj_to_translate.c:8
-#: ../raster3d/r3.in.ascii/main.c:87 ../raster/r.reclass/main.c:66
-#: ../raster/r.recode/main.c:61 ../raster/r.in.ascii/main.c:79
-#: ../vector/v.segment/main.c:80 ../vector/v.edit/args.c:95
-#: ../vector/v.what/main.c:78 ../db/db.execute/main.c:139
-#: ../db/db.select/main.c:208
-msgid "'-' for standard input"
+#: ../vector/v.class/main.c:76 ../display/d.vect.thematic/main.c:123
+msgid "simple intervals"
 msgstr ""
-#: ../general/g.proj/main.c:149
-msgid "PROJ.4 projection description"
+#: ../vector/v.class/main.c:77 ../display/d.vect.thematic/main.c:124
+msgid "standard deviations"
 msgstr ""
-#: ../general/g.proj/main.c:159
-#: ../locale/scriptstrings/v.import_to_translate.c:21
-msgid "EPSG projection code"
+#: ../vector/v.class/main.c:78 ../display/d.vect.thematic/main.c:125
+msgid "quantiles"
 msgstr ""
-#: ../general/g.proj/main.c:167 ../general/g.proj/main.c:180
-#: ../general/g.proj/main.c:186
-msgid "Datum"
-msgstr "Datums"
+#: ../vector/v.class/main.c:79 ../display/d.vect.thematic/main.c:126
+msgid "equiprobable (normal distribution)"
+msgstr ""
-#: ../general/g.proj/main.c:169
-msgid "Datum (overrides any datum specified in input co-ordinate system)"
+#: ../vector/v.class/main.c:88 ../display/d.vect.thematic/main.c:136
+msgid "Number of classes to define"
 msgstr ""
-#: ../general/g.proj/main.c:171
-msgid "Accepts standard GRASS datum codes, or \"list\" to list and exit"
+#: ../vector/v.class/main.c:93
+msgid "Print only class breaks (without min and max)"
 msgstr ""
-#: ../general/g.proj/main.c:181
-#: ../locale/scriptstrings/v.import_to_translate.c:23
-msgid "Index number of datum transform parameters"
+#: ../vector/v.class/main.c:111 ../vector/v.label/main.c:274
+#: ../vector/v.vol.rst/user1.c:95 ../vector/v.label.sa/labels.c:75
+#: ../ps/ps.map/catval.c:48 ../ps/ps.map/catval.c:110 ../ps/ps.map/catval.c:176
+msgid "Unable to get layer info for vector map"
 msgstr ""
-#: ../general/g.proj/main.c:182
-msgid "\"0\" for unspecified or \"-1\" to list and exit"
+#: ../vector/v.class/main.c:138
+msgid "Unable to sort array of values"
 msgstr ""
-#: ../general/g.proj/main.c:188
-msgid "Force override of datum transformation information in input co-ordinate system"
+#: ../vector/v.class/main.c:173
+msgid ""
+"The discontinuities algorithm indicates that some class breaks are not "
+"statistically significant at alpha=0.05. You are advised to reduce the "
+"number of classes."
 msgstr ""
-#: ../general/g.proj/main.c:193 ../raster/r.null/main.c:74
-#: ../raster/r.null/main.c:82
-msgid "Modify"
+#: ../vector/v.class/main.c:201
+#, c-format
+msgid ""
+"\n"
+"Classification of %s into %i classes\n"
 msgstr ""
-#: ../general/g.proj/main.c:194
-msgid "Modify current location projection files"
+#: ../vector/v.class/main.c:203 ../display/d.vect.thematic/main.c:527
+#, c-format
+msgid "Using algorithm: *** %s ***\n"
 msgstr ""
-#: ../general/g.proj/main.c:202
-msgid "Name of new location to create"
-msgstr "Jaunā novietojuma nosaukums"
+#: ../vector/v.class/main.c:204 ../display/d.vect.thematic/main.c:529
+#, c-format
+msgid "Mean: %f\tStandard deviation = %f\n"
+msgstr ""
-#: ../general/g.proj/main.c:218
+#: ../vector/v.class/main.c:208
 #, c-format
-msgid "Only one of '%s', '%s', '%s' or '%s' options may be specified"
+msgid "Lowest chi2 = %f\n"
 msgstr ""
-#: ../general/g.proj/main.c:263
-msgid "Projection files missing"
-msgstr "Trūkst projekcijas failu"
-#: ../general/g.proj/main.c:283
+#: ../vector/v.class/main.c:211 ../display/d.vect.thematic/main.c:535
 #, c-format
-msgid "Only one of -%c, -%c, -%c, -%c, -%c or -%c flags may be specified"
+msgid "Stdev multiplied by %.4f to define step\n"
 msgstr ""
-#: ../general/g.proj/main.c:310
+#: ../vector/v.class/main.c:214
 #, c-format
-msgid "No output format specified, define one of flags -%c, -%c, -%c, or -%c"
+msgid ""
+"%15s%15s%15s\n"
+"\n"
 msgstr ""
-#: ../general/g.proj/main.c:314
+#: ../vector/v.class/main.c:226
 #, c-format
-msgid "No output format specified, define one of flags -%c, -%c, or -%c"
+msgid ""
+"\n"
+"Note: Minimum of first class is including\n"
+"\n"
 msgstr ""
-#: ../general/g.proj/output.c:146
-msgid "Unable to convert projection information to PROJ.4 format"
+#: ../vector/v.external.out/list.c:102 ../vector/v.in.ogr/main.c:378
+#: ../vector/v.out.ogr/list.c:116 ../vector/v.external/list.c:94
+#: ../raster/r.external/list.c:23 ../raster/r.in.gdal/main.c:272
+msgid "Supported formats:"
 msgstr ""
-#: ../general/g.proj/output.c:190
+#: ../vector/v.external.out/status.c:25
 #, c-format
-msgid "%s: Unable to convert to WKT"
+msgid "format: native\n"
 msgstr ""
-#: ../general/g.proj/input.c:91
-msgid "Error reading WKT projection description"
+#: ../vector/v.external.out/status.c:80
+msgid "No settings defined"
 msgstr ""
-#: ../general/g.proj/input.c:98
-#, c-format
-msgid "Unable to open file '%s' for reading"
+#: ../vector/v.external.out/status.c:109 ../vector/v.external.out/status.c:149
+msgid "Format not defined"
 msgstr ""
-#: ../general/g.proj/input.c:143
-msgid "Can't parse PROJ.4-style parameter string"
+#: ../vector/v.external.out/status.c:116
+msgid "OGR datasource (dsn) not defined"
 msgstr ""
-#: ../general/g.proj/input.c:181
-msgid "Unable to translate EPSG code"
+#: ../vector/v.external.out/status.c:124
+msgid "PG connection info (conninfo) not defined"
 msgstr ""
-#: ../general/g.proj/input.c:218
-msgid "Trying to open with OGR..."
+#: ../vector/v.external.out/status.c:158 ../vector/v.external.out/link.c:88
+msgid "Unable to create settings file"
 msgstr ""
-#: ../general/g.proj/input.c:226 ../general/g.proj/input.c:245
-msgid "...succeeded."
+#: ../vector/v.external.out/status.c:160 ../vector/v.external.out/link.c:91
+msgid "Error writing settings file"
 msgstr ""
-#: ../general/g.proj/input.c:239
-msgid "Trying to open with GDAL..."
+#: ../vector/v.external.out/main.c:44 ../vector/v.out.ogr/main.c:83
+#: ../vector/v.out.vtk/main.c:48 ../vector/v.out.lidar/main.c:472
+#: ../vector/v.out.svg/main.c:78 ../vector/v.out.pov/main.c:47
+#: ../vector/v.out.postgis/main.c:45 ../vector/v.out.ascii/main.c:48
+#: ../vector/v.out.dxf/main.c:57 ../vector/v.colors.out/main.c:51
+#: ../raster/r.out.vtk/main.c:60 ../raster/r.out.ppm/main.c:55
+#: ../raster/r.out.vrml/main.c:48 ../raster/r.out.pov/main.c:122
+#: ../raster/r.out.bin/main.c:280 ../raster/r.out.ppm3/main.c:58
+#: ../raster/r.out.ascii/main.c:60 ../raster/r.external.out/main.c:236
+#: ../raster/r.out.gridatb/main.c:68 ../raster/r.out.gdal/main.c:140
+#: ../raster/r.out.mat/main.c:63 ../raster/r.colors.out/raster_main.c:47
+#: ../raster/r.colors.out/raster3d_main.c:48 ../raster/r.out.png/main.c:113
+#: ../raster/r.out.mpeg/main.c:103
+#: ../locale/scriptstrings/t.rast.export_to_translate.c:3
+#: ../locale/scriptstrings/db.out.ogr_to_translate.c:3
+#: ../locale/scriptstrings/d.out.file_to_translate.c:3
+#: ../locale/scriptstrings/t.vect.export_to_translate.c:3
+#: ../locale/scriptstrings/r.pack_to_translate.c:3
+#: ../locale/scriptstrings/d.to.rast_to_translate.c:3
+#: ../locale/scriptstrings/v.pack_to_translate.c:3
+#: ../locale/scriptstrings/r.out.xyz_to_translate.c:3
+#: ../locale/scriptstrings/t.rast.out.vtk_to_translate.c:3
+#: ../raster3d/r3.out.bin/main.c:206 ../raster3d/r3.out.v5d/main.c:285
+#: ../raster3d/r3.out.netcdf/main.c:587 ../raster3d/r3.out.ascii/main.c:303
+#: ../raster3d/r3.out.vtk/main.c:377
+msgid "export"
 msgstr ""
-#: ../general/g.proj/input.c:254
-#, c-format
-msgid "Could not read georeferenced file %s using either OGR nor GDAL"
+#: ../vector/v.external.out/main.c:45 ../raster/r.external.out/main.c:237
+msgid "output"
+msgstr "izvade"
+#: ../vector/v.external.out/main.c:46 ../vector/v.external/main.c:54
+#: ../raster/r.external/main.c:59 ../raster/r.external.out/main.c:238
+msgid "external"
 msgstr ""
-#: ../general/g.proj/input.c:259
-#, c-format
-msgid "Read of file %s was successful, but it did not contain projection information. 'XY (unprojected)' will be used"
+#: ../vector/v.external.out/main.c:49
+msgid "Defines vector output format."
 msgstr ""
-#: ../general/g.proj/datumtrans.c:47
-#, c-format
-msgid "Invalid datum code <%s>"
+#: ../vector/v.external.out/main.c:63
+msgid "Switched from OGR to native format"
 msgstr ""
-#: ../general/g.proj/datumtrans.c:77
-#, c-format
-msgid "Datum set to <%s>"
+#: ../vector/v.external.out/main.c:67
+msgid "Switched from PostGIS to native format"
 msgstr ""
-#: ../general/g.proj/datumtrans.c:79
+#: ../vector/v.external.out/main.c:69 ../vector/v.external.out/main.c:96
 #, c-format
-msgid "Ellipsoid set to <%s>"
+msgid "Current output format for vectors: %s"
 msgstr ""
-#: ../general/g.proj/create.c:15 ../raster/r.in.gdal/main.c:453
-#: ../raster/r.in.gdal/main.c:868 ../vector/v.in.ogr/main.c:584
-#: ../vector/v.in.lidar/main.c:514
-#, c-format
-msgid "Location <%s> created"
+#: ../vector/v.external.out/format.c:22 ../vector/v.external/main.c:78
+msgid ""
+"Environment variable GRASS_VECTOR_OGR defined, but GRASS is compiled with "
+"OGR support. Using GRASS-PostGIS data driver instead."
 msgstr ""
-#: ../general/g.proj/create.c:17
-#, c-format
-msgid "Unable to create location <%s>: %s"
+#: ../vector/v.external.out/format.c:27 ../vector/v.external/main.c:83
+msgid ""
+"GRASS is not compiled with PostgreSQL support. Using OGR-PostgreSQL driver "
+"instead of native GRASS-PostGIS data driver."
 msgstr ""
-#: ../general/g.proj/create.c:20
+#: ../vector/v.external.out/format.c:49 ../raster/r.external.out/main.c:156
 #, c-format
-msgid "Unable to create projection files: %s"
+msgid "Format <%s> not supported"
 msgstr ""
-#: ../general/g.proj/create.c:24
+#: ../vector/v.external.out/format.c:52 ../raster/r.external.out/main.c:166
 #, c-format
-msgid "Unable to create location <%s>"
+msgid "Format <%s> does not support writing"
 msgstr ""
-#: ../general/g.proj/create.c:30
-#, c-format
+#: ../vector/v.external.out/args.c:14
+msgid "Name of output directory or OGR or PostGIS data source"
+msgstr ""
+#: ../vector/v.external.out/args.c:15 ../vector/v.external/args.c:15
 msgid ""
-"You can switch to the new location by\n"
-"`%s=%s`"
+"Examples:\n"
+"\t\tESRI Shapefile: directory containing a shapefile\n"
+"\t\tMapInfo File: directory containing a mapinfo file\n"
+"\t\tPostGIS database: connection string, eg. 'PG:dbname=db user=grass'"
 msgstr ""
-#: ../general/g.proj/create.c:40
-#, c-format
-msgid "You must select the PERMANENT mapset before updating the current location's projection (current mapset is <%s>)"
+#: ../vector/v.external.out/args.c:24
+msgid "Format for output vector data"
 msgstr ""
-#: ../general/g.proj/create.c:66
-msgid "Default region was updated to the new projection, but if you have multiple mapsets `g.region -d` should be run in each to update the region from the default"
+#: ../vector/v.external.out/args.c:39 ../vector/v.out.postgis/args.c:52
+#: ../raster/r.external.out/main.c:264
+msgid "Creation options"
 msgstr ""
-#: ../general/g.proj/create.c:70
-msgid "Projection information updated"
+#: ../vector/v.external.out/args.c:40
+msgid ""
+"Examples:\n"
+"\t\t'SHPT=POINTZ': create 3D point Shapefile data\n"
+"\t\t'GEOM_TYPE=geography': use geography PostGIS data\n"
+"\t\t'SCHEMA=grass': create new PostGIS tables in 'grass' schema"
 msgstr ""
-#: ../general/g.proj/create.c:91
-#, c-format
-msgid "Unable to create PROJ_EPSG file: %s"
+#: ../vector/v.external.out/args.c:52
+msgid "Name of input file to read settings from"
 msgstr ""
-#: ../general/g.mkfontcap/freetype_fonts.c:55
-msgid "Unable to initialise Freetype"
+#: ../vector/v.external.out/args.c:58
+msgid "Name for output file where to save current settings"
 msgstr ""
-#: ../general/g.mkfontcap/main.c:73
-msgid "Generates the font configuration file by scanning various directories for fonts."
+#: ../vector/v.external.out/args.c:62 ../vector/v.external/args.c:56
+#: ../raster/r.external/main.c:95 ../raster/r.external.out/main.c:271
+#: ../raster/r.in.gdal/main.c:207
+msgid "List supported formats and exit"
 msgstr ""
-#: ../general/g.mkfontcap/main.c:79
-msgid "Overwrite font configuration file if already existing"
+#: ../vector/v.external.out/args.c:68
+msgid "Cease using OGR/PostGIS, revert to native output and exit"
 msgstr ""
-#: ../general/g.mkfontcap/main.c:84
-msgid "Write font configuration file to standard output instead of $GISBASE/etc"
+#: ../vector/v.external.out/args.c:70
+msgid "Native"
 msgstr ""
-#: ../general/g.mkfontcap/main.c:91
-msgid "List of extra directories to scan"
+#: ../vector/v.external.out/args.c:74 ../raster/r.external.out/main.c:282
+msgid "Print current status"
 msgstr ""
-#: ../general/g.mkfontcap/main.c:93
-msgid "Comma-separated list of extra directories to scan for Freetype-compatible fonts as well as the defaults (see documentation)"
+#: ../vector/v.external.out/args.c:80
+msgid "Print current status in shell script style"
 msgstr ""
-#: ../general/g.mkfontcap/main.c:110
+#: ../vector/v.external.out/args.c:90 ../raster/r.resamp.filter/main.c:438
 #, c-format
-msgid "Fontcap file %s already exists; use -%c flag if you wish to overwrite it"
+msgid "%s= and %s=/%s= are mutually exclusive"
 msgstr ""
-#: ../general/g.mkfontcap/main.c:122
-msgid "This GRASS installation was compiled without Freetype support, extradirs parameter ignored"
+#: ../vector/v.external.out/args.c:98
+#, c-format
+msgid "%s= or %s= must be specified"
 msgstr ""
-#: ../general/g.mkfontcap/main.c:149
+#: ../vector/v.external.out/args.c:101
 #, c-format
-msgid "Cannot open %s for writing: %s"
+msgid "%s= must be specified"
 msgstr ""
-#: ../general/g.ppmtopng/main.c:34
+#: ../vector/v.external.out/link.c:26 ../vector/v.out.ogr/main.c:102
 #, c-format
-msgid "Unable to open input file %s"
+msgid ""
+"Data source starts with \"PG:\" prefix, expecting \"PostgreSQL\" format (\"%s"
+"\" given)"
 msgstr ""
-#: ../general/g.ppmtopng/main.c:37
+#: ../vector/v.external.out/link.c:96
 #, c-format
-msgid "Invalid input file %s"
+msgid "Switched to OGR format (%s)"
 msgstr ""
-#: ../general/g.ppmtopng/main.c:70 ../general/g.ppmtopng/main.c:74
-#: ../raster/r.in.png/main.c:307 ../raster/r.in.png/main.c:311
-msgid "Unable to allocate PNG structure"
+#: ../vector/v.external.out/link.c:99
+msgid "Switched to PostGIS format"
 msgstr ""
-#: ../general/g.ppmtopng/main.c:77
-msgid "Error writing PNG file"
+#: ../vector/v.external.out/link.c:110
+#, c-format
+msgid "Unable to parse option '%s'"
 msgstr ""
-#: ../general/g.ppmtopng/main.c:81
-#, c-format
-msgid "Unable to open output file %s"
+#: ../vector/v.cluster/main.c:91
+msgid "point cloud"
 msgstr ""
-#: ../general/g.ppmtopng/main.c:119
-msgid "Converts between PPM/PGM and PNG image formats."
+#: ../vector/v.cluster/main.c:92
+msgid "cluster"
 msgstr ""
-#: ../general/g.filename/main.c:42
-msgid "Prints GRASS data base file names."
+#: ../vector/v.cluster/main.c:93
+msgid "clump"
 msgstr ""
-#: ../general/g.filename/main.c:56
-msgid "Name of a database file"
-msgstr "Datubāzes faila nosaukums"
+#: ../vector/v.cluster/main.c:96
+msgid "Performs cluster identification."
+msgstr ""
-#: ../general/g.filename/main.c:62
-msgid "Name of a mapset (default: current)"
+#: ../vector/v.cluster/main.c:104
+msgid "Layer number or name for cluster ids"
 msgstr ""
-#: ../general/g.tempfile/main.c:41
-msgid "Creates a temporary file and prints it's file name."
+#: ../vector/v.cluster/main.c:111
+msgid "Maximum distance to neighbors"
 msgstr ""
-#: ../general/g.tempfile/main.c:47
-msgid "Process id to use when naming the tempfile"
+#: ../vector/v.cluster/main.c:117
+msgid "Minimum number of points to create a cluster"
 msgstr ""
-#: ../general/g.tempfile/main.c:51
-msgid "Dry run - don't create a file, just prints it's file name"
+#: ../vector/v.cluster/main.c:125
+msgid "Clustering method"
 msgstr ""
-#: ../general/g.copy/main.c:44
-msgid "Copies available data files in the current mapset search path to the user's current mapset."
+#: ../vector/v.cluster/main.c:129
+msgid "Force 2D clustering"
 msgstr ""
-#: ../general/g.copy/main.c:51
-msgid "copied"
+#: ../vector/v.cluster/main.c:167
+msgid "Minimum number of points must be at least 2"
 msgstr ""
-#: ../general/g.copy/main.c:66
+#: ../vector/v.cluster/main.c:175 ../vector/v.to.points/main.c:113
 #, c-format
-msgid "<%s> not found"
+msgid "Option %s must be positive"
 msgstr ""
-#: ../general/g.copy/main.c:71
-#, c-format
-msgid "%s=%s,%s: files are the same, no copy required"
+#: ../vector/v.cluster/main.c:188
+msgid "Counting input points ..."
 msgstr ""
-#: ../general/g.copy/main.c:76
+#: ../vector/v.cluster/main.c:194
 #, c-format
-msgid "<%s> already exists. File not copied."
+msgid "Layer %d is not empty, choose another layer"
 msgstr ""
-#: ../general/g.message/main.c:37
-msgid "Prints a message, warning, progress info, or fatal error in the GRASS way."
+#: ../vector/v.cluster/main.c:201
+msgid "Not enough points in input, nothing to do"
 msgstr ""
-#: ../general/g.message/main.c:39
-msgid "This module should be used in scripts for messages served to user."
+#: ../vector/v.cluster/main.c:218
+msgid "Creating search index ..."
 msgstr ""
-#: ../general/g.message/main.c:44
-msgid "Print message as warning"
+#: ../vector/v.cluster/main.c:253 ../vector/v.cluster/main.c:458
+#: ../vector/v.cluster/main.c:708
+#, c-format
+msgid "Option %s must be a positive number"
 msgstr ""
-#: ../general/g.message/main.c:49
-msgid "Print message as fatal error"
+#: ../vector/v.cluster/main.c:262 ../vector/v.cluster/main.c:467
+msgid "Estimating maximum distance ..."
 msgstr ""
-#: ../general/g.message/main.c:54
-msgid "Print message as debug message"
+#: ../vector/v.cluster/main.c:293 ../vector/v.cluster/main.c:498
+msgid "No neighbors found"
 msgstr ""
-#: ../general/g.message/main.c:59
-msgid "Print message as progress info"
+#: ../vector/v.cluster/main.c:303 ../vector/v.cluster/main.c:508
+#, c-format
+msgid "Distance to the %d nearest neighbor:"
 msgstr ""
-#: ../general/g.message/main.c:63 ../general/g.message/main.c:69
-#: ../general/g.message/main.c:85
-msgid "Level"
+#: ../vector/v.cluster/main.c:304 ../vector/v.cluster/main.c:509
+#, c-format
+msgid "Min: %g, max: %g"
 msgstr ""
-#: ../general/g.message/main.c:64
-msgid "Print message in all modes except of quiet mode"
+#: ../vector/v.cluster/main.c:305 ../vector/v.cluster/main.c:510
+#, c-format
+msgid "Mean: %g"
 msgstr ""
-#: ../general/g.message/main.c:65
-msgid "Message is printed on GRASS_VERBOSE>=1"
+#: ../vector/v.cluster/main.c:306 ../vector/v.cluster/main.c:511
+#, c-format
+msgid "Standard deviation: %g"
 msgstr ""
-#: ../general/g.message/main.c:70
-msgid "Print message only in verbose mode"
+#: ../vector/v.cluster/main.c:308 ../vector/v.cluster/main.c:513
+#, c-format
+msgid "Estimated maximum distance: %g"
 msgstr ""
-#: ../general/g.message/main.c:71
-msgid "Message is printed only on GRASS_VERBOSE>=3"
+#: ../vector/v.cluster/main.c:312 ../vector/v.cluster/main.c:517
+#: ../vector/v.cluster/main.c:930 ../vector/v.cluster/main.c:1091
+msgid "Building clusters ..."
 msgstr ""
-#: ../general/g.message/main.c:78
-msgid "Text of the message to be printed"
+#: ../vector/v.cluster/main.c:354 ../vector/v.cluster/main.c:562
+#, c-format
+msgid "nlines: %d, nclusters: %d"
 msgstr ""
-#: ../general/g.message/main.c:79
-msgid "Message is printed on GRASS_VERBOSE>=2"
+#: ../vector/v.cluster/main.c:398 ../vector/v.cluster/main.c:607
+#, c-format
+msgid "No clusters found, adjust option %s"
 msgstr ""
-#: ../general/g.message/main.c:88
-msgid "Level to use for debug messages"
+#: ../vector/v.cluster/main.c:406 ../vector/v.cluster/main.c:615
+#: ../vector/v.cluster/main.c:972 ../raster/r.clump/clump.c:53
+#: ../imagery/i.segment/cluster.c:386
+msgid "Generating renumbering scheme..."
 msgstr ""
-#: ../general/g.message/main.c:95
-msgid "Select only one message level"
+#: ../vector/v.cluster/main.c:434 ../vector/v.cluster/main.c:649
+#: ../vector/v.cluster/main.c:828 ../vector/v.cluster/main.c:1000
+#: ../vector/v.cluster/main.c:1154
+msgid "Write out cluster ids ..."
 msgstr ""
-#: ../general/g.message/main.c:108
-msgid "Unable to parse input message"
+#: ../vector/v.cluster/main.c:712
+msgid "Loading points ..."
 msgstr ""
-#: ../general/g.access/main.c:39
-msgid "permission"
+#: ../vector/v.cluster/main.c:736 ../vector/v.cluster/main.c:880
+msgid "Reachability network ..."
 msgstr ""
-#: ../general/g.access/main.c:41
-msgid "Controls access to the current mapset for other users on the system."
+#: ../vector/v.cluster/main.c:748 ../vector/v.cluster/main.c:781
+#: ../vector/v.cluster/main.c:890 ../vector/v.cluster/main.c:1068
+#: ../vector/v.cluster/main.c:1102 ../vector/v.cluster/main.c:1139
+msgid "Not enough points found"
 msgstr ""
-#: ../general/g.access/main.c:42
-msgid "If no option given, prints current status."
+#: ../vector/v.cluster/main.c:809
+msgid "Set cluster ids ..."
 msgstr ""
-#: ../general/g.access/main.c:49
-msgid "Access for group"
+#: ../vector/v.cluster/main.c:911
+msgid "Neighbor point's core dist is -1"
 msgstr ""
-#: ../general/g.access/main.c:50 ../general/g.access/main.c:58
-#: ../raster/r.in.bin/main.c:275 ../raster/r.in.bin/main.c:280
-#: ../raster/r.in.bin/main.c:306 ../raster/r.in.bin/main.c:314
-#: ../raster/r.in.bin/main.c:323 ../raster/r.in.bin/main.c:384
-#: ../raster/r.in.bin/main.c:398 ../raster/r.resamp.bspline/main.c:108
-#: ../raster/r.resamp.bspline/main.c:116 ../raster/r.resamp.bspline/main.c:122
-#: ../raster/r.resamp.bspline/main.c:134 ../raster/r.resamp.bspline/main.c:139
-#: ../raster/r.slope.aspect/main.c:181 ../raster/r.slope.aspect/main.c:189
-#: ../raster/r.slope.aspect/main.c:247 ../raster/r.slope.aspect/main.c:256
-#: ../raster/r.slope.aspect/main.c:262 ../raster/r.resamp.rst/main.c:210
-#: ../raster/r.resamp.rst/main.c:216 ../raster/r.resamp.rst/main.c:224
-#: ../raster/r.resamp.rst/main.c:232 ../raster/r.resamp.rst/main.c:240
-#: ../raster/r.walk/main.c:274 ../raster/r.walk/main.c:284
-#: ../raster/r.walk/main.c:294 ../raster/r.out.mpeg/main.c:132
-#: ../display/d.mon/main.c:70 ../display/d.mon/main.c:78
-#: ../display/d.mon/main.c:86 ../display/d.mon/main.c:92
-#: ../display/d.mon/main.c:98 ../display/d.mon/main.c:133
-#: ../display/d.mon/main.c:139 ../display/d.mon/main.c:145
-#: ../vector/v.lidar.correction/main.c:102
-#: ../vector/v.lidar.correction/main.c:111 ../vector/v.surf.idw/main.c:115
-#: ../vector/v.surf.idw/main.c:124 ../vector/v.surf.idw/main.c:132
-#: ../vector/v.vol.rst/main.c:268 ../vector/v.vol.rst/main.c:276
-#: ../vector/v.vol.rst/main.c:283 ../vector/v.vol.rst/main.c:311
-#: ../vector/v.vol.rst/main.c:320 ../vector/v.vol.rst/main.c:329
-#: ../vector/v.vol.rst/main.c:337 ../vector/v.vol.rst/main.c:346
-#: ../vector/v.vol.rst/main.c:354 ../vector/v.lidar.edgedetection/main.c:99
-#: ../vector/v.lidar.edgedetection/main.c:108
-#: ../vector/v.lidar.edgedetection/main.c:117
-#: ../vector/v.lidar.edgedetection/main.c:126
-#: ../vector/v.lidar.edgedetection/main.c:135
-#: ../vector/v.lidar.edgedetection/main.c:143
-#: ../vector/v.lidar.edgedetection/main.c:152
-#: ../vector/v.surf.bspline/main.c:113 ../vector/v.surf.bspline/main.c:120
-#: ../vector/v.surf.bspline/main.c:150 ../vector/v.surf.bspline/main.c:159
-#: ../vector/v.surf.bspline/main.c:167 ../vector/v.surf.bspline/main.c:179
-#: ../vector/v.external.out/args.c:20 ../vector/v.external.out/args.c:35
-#: ../vector/v.external.out/args.c:47 ../vector/v.external.out/args.c:53
-#: ../vector/v.outlier/main.c:104 ../vector/v.outlier/main.c:113
-#: ../vector/v.outlier/main.c:121 ../vector/v.db.connect/main.c:66
-#: ../vector/v.db.connect/main.c:72 ../vector/v.colors.out/main.c:68
-#: ../vector/v.colors.out/main.c:73 ../imagery/i.segment/parse_args.c:68
-#: ../imagery/i.segment/parse_args.c:77 ../imagery/i.segment/parse_args.c:88
-#: ../imagery/i.segment/parse_args.c:99 ../imagery/i.segment/parse_args.c:109
-#: ../imagery/i.segment/parse_args.c:127 ../imagery/i.segment/parse_args.c:135
-#: ../imagery/i.segment/parse_args.c:144 ../imagery/i.segment/parse_args.c:151
-#: ../imagery/i.segment/parse_args.c:157 ../imagery/i.segment/parse_args.c:163
-#: ../imagery/i.segment/parse_args.c:169 ../imagery/i.segment/parse_args.c:176
-#: ../imagery/i.landsat.toar/main.c:160 ../imagery/i.landsat.toar/main.c:169
-#: ../imagery/i.landsat.toar/main.c:179 ../imagery/i.landsat.toar/main.c:188
-#: ../imagery/i.landsat.toar/main.c:209 ../imagery/i.cluster/main.c:103
-#: ../imagery/i.cluster/main.c:120 ../imagery/i.cluster/main.c:128
-#: ../imagery/i.cluster/main.c:137 ../imagery/i.cluster/main.c:145
-#: ../imagery/i.cluster/main.c:153 ../db/db.login/main.c:60
-#: ../db/db.login/main.c:68 ../db/db.login/main.c:77 ../db/db.login/main.c:86
-msgid "Settings"
+#: ../vector/v.cluster/main.c:1056
+msgid "Core density ..."
 msgstr ""
-#: ../general/g.access/main.c:57
-msgid "Access for others"
+#: ../vector/v.cluster/main.c:1180
+#, c-format
+msgid "%d clusters found"
 msgstr ""
-#: ../general/g.access/main.c:64
-msgid "UNIX filesystem access controls are not supported by MS-Windows"
+#: ../vector/v.cluster/main.c:1181
+#, c-format
+msgid "%d outliers found"
 msgstr ""
-#: ../general/g.access/main.c:72
-msgid "Access to the PERMANENT mapset must be open, nothing changed"
+#: ../vector/v.in.dwg/main.c:84
+msgid "Converts DWG/DXF to GRASS vector map"
 msgstr ""
-#: ../general/g.access/main.c:76
-msgid "Unable to determine mapset permissions"
+#: ../vector/v.in.dwg/main.c:87
+msgid "Name of DWG or DXF file"
 msgstr ""
-#: ../general/g.access/set_perms.c:26
-msgid "Unable to change mapset permissions"
+#: ../vector/v.in.dwg/main.c:97
+msgid "List of layers to import"
 msgstr ""
-#: ../general/g.access/exp_perms.c:11 ../general/g.access/exp_perms.c:29
-msgid "have"
+#: ../vector/v.in.dwg/main.c:102
+msgid "Invert selection by layers (don't import layers in list)"
 msgstr ""
-#: ../general/g.access/exp_perms.c:12
-msgid "read "
+#: ../vector/v.in.dwg/main.c:110
+msgid "Write circles as points (centre)"
 msgstr ""
-#: ../general/g.access/exp_perms.c:15
-msgid "Everyone"
+#: ../vector/v.in.dwg/main.c:114
+msgid "List available layers and exit"
 msgstr ""
-#: ../general/g.access/exp_perms.c:16
-msgid "has"
+#: ../vector/v.in.dwg/main.c:118
+msgid "Use numeric type for attribute \"layer\""
 msgstr ""
-#: ../general/g.access/exp_perms.c:19
-msgid "Only users in your group"
+#: ../vector/v.in.dwg/main.c:138
+#, c-format
+msgid "Unable to initialize OpenDWG Toolkit, error: %d: %s."
 msgstr ""
-#: ../general/g.access/exp_perms.c:22
-msgid "Only users outside your group"
+#: ../vector/v.in.dwg/main.c:141
+#, c-format
+msgid "%s Cannot open %s"
 msgstr ""
-#: ../general/g.access/exp_perms.c:25
-msgid "Only you"
+#: ../vector/v.in.dwg/main.c:149
+#, c-format
+msgid "Unable to open input file <%s>. Error %d: %s"
 msgstr ""
-#: ../general/g.access/exp_perms.c:31
+#: ../vector/v.in.dwg/main.c:287
 #, c-format
-msgid "%s %s %s %saccess to mapset %s"
+msgid "%d elements skipped (layer name was not in list)"
 msgstr ""
-#: ../general/g.access/exp_perms.c:32
-msgid "will"
+#: ../vector/v.in.dwg/main.c:290
+#, c-format
+msgid "%d elements processed"
 msgstr ""
-msgid "now"
-msgstr "tagad"
-#: ../general/g.gisenv/main.c:45
-msgid "variables"
+#: ../vector/v.build/main.c:39
+msgid "Creates topology for vector map."
 msgstr ""
-#: ../general/g.gisenv/main.c:48
-msgid "Outputs and modifies the user's current GRASS variable settings."
+#: ../vector/v.build/main.c:40
+msgid "Optionally also checks for topological errors."
 msgstr ""
-#: ../general/g.gisenv/main.c:49
-msgid "Prints all defined GRASS variables if no option is given."
+#: ../vector/v.build/main.c:44
+msgid "Name of vector map"
 msgstr ""
-#: ../general/g.gisenv/main.c:54
-msgid "GRASS variable to get"
+#: ../vector/v.build/main.c:49
+msgid ""
+"Name for output vector map where erroneous vector features are written to"
 msgstr ""
-#: ../general/g.gisenv/main.c:57
-msgid "Get"
-msgstr ""
+#: ../vector/v.build/main.c:51 ../vector/v.build/main.c:77
+#: ../db/db.execute/main.c:161
+msgid "Errors"
+msgstr "Kļūdas"
-#: ../general/g.gisenv/main.c:63
-msgid "GRASS variable to set"
+#: ../vector/v.build/main.c:61
+msgid "Build topology or dump topology or indices to standard output"
 msgstr ""
-#: ../general/g.gisenv/main.c:66 ../general/g.gisenv/main.c:74
-#: ../general/g.gisenv/main.c:84 ../temporal/t.connect/main.c:49
-#: ../temporal/t.connect/main.c:55 ../temporal/t.connect/main.c:60
-#: ../temporal/t.connect/main.c:65 ../temporal/t.connect/main.c:69
-#: ../db/db.connect/main.c:64 ../db/db.connect/main.c:70
-#: ../db/db.connect/main.c:75 ../db/db.connect/main.c:79
-#: ../db/db.connect/main.c:83 ../db/db.connect/main.c:93
-msgid "Set"
-msgstr "Iestatīt"
+#: ../vector/v.build/main.c:65
+msgid "build topology"
+msgstr "būvēt topoloģiju"
-#: ../general/g.gisenv/main.c:71
-msgid "GRASS variable to unset"
+#: ../vector/v.build/main.c:66
+msgid "write topology to stdout"
 msgstr ""
-#: ../general/g.gisenv/main.c:82
-msgid "Where GRASS variable is stored"
+#: ../vector/v.build/main.c:67
+msgid "write spatial index to stdout"
 msgstr ""
-#: ../general/g.gisenv/main.c:87
-msgid "Separator for multiple GRASS variables"
+#: ../vector/v.build/main.c:68
+msgid "write category index to stdout"
 msgstr ""
-#: ../general/g.gisenv/main.c:92
-msgid "Use shell syntax (for \"eval\")"
+#: ../vector/v.build/main.c:69
+msgid "write feature index to stdout (OGR simple-feature-based formats only)"
 msgstr ""
-#: ../general/g.gisenv/main.c:93 ../general/g.gisenv/main.c:98
-#: ../vector/v.db.select/main.c:85 ../vector/v.db.select/main.c:88
-#: ../vector/v.db.select/main.c:106 ../vector/v.db.select/main.c:111
-#: ../db/db.select/main.c:227 ../db/db.select/main.c:233
-#: ../db/db.select/main.c:236 ../db/db.select/main.c:246
-#: ../db/db.select/main.c:256
-msgid "Format"
+#: ../vector/v.build/main.c:75
+msgid "Extensive checks for topological errors"
 msgstr ""
-#: ../general/g.gisenv/main.c:97
-msgid "Do not use shell syntax"
+#: ../vector/v.build/main.c:76
+msgid "Perform in-depth checks for topological errors when building topology"
 msgstr ""
-#: ../general/g.gisenv/main.c:171
+#: ../vector/v.build/main.c:106
 #, c-format
-msgid "Variable <%s> is mandatory. No operation performed."
+msgid ""
+"Direct read access to OGR layers is not supported by this module. Run %s to "
+"create a link as GRASS vector map in the current mapset."
 msgstr ""
-#: ../general/g.gisenv/main.c:177
+#: ../vector/v.build/main.c:111
 #, c-format
-msgid "Value '%s' ignored when unsetting the GRASS variable"
+msgid "Vector map <%s> is not in current mapset"
 msgstr ""
-#: ../general/g.gisenv/main.c:216
-msgid "GRASS variable not defined"
+#: ../vector/v.kcv/main.c:57 ../vector/v.normal/main.c:74
+#: ../vector/v.out.lidar/main.c:474 ../vector/v.in.db/main.c:55
+#: ../vector/v.decimate/main.c:129
+msgid "points"
 msgstr ""
-#: ../general/g.gisenv/main.c:222
-#, c-format
-msgid "GRASS variable must be uppercase. Using '%s'."
+#: ../vector/v.kcv/main.c:58 ../vector/v.normal/main.c:75
+#: ../vector/v.qcount/main.c:62 ../vector/v.perturb/main.c:66
+#: ../vector/v.mkgrid/main.c:73 ../vector/v.random/main.c:101
+msgid "point pattern"
 msgstr ""
-#: ../locale/scriptstrings/r.pack_to_translate.c:1
-msgid "Exports a raster map as GRASS GIS specific archive file"
+#: ../vector/v.kcv/main.c:60
+msgid "Randomly partition points into test/train sets."
 msgstr ""
-#: ../locale/scriptstrings/r.pack_to_translate.c:3
-#: ../locale/scriptstrings/t.vect.export_to_translate.c:3
-#: ../locale/scriptstrings/t.rast.out.vtk_to_translate.c:3
-#: ../locale/scriptstrings/db.out.ogr_to_translate.c:3
-#: ../locale/scriptstrings/d.out.file_to_translate.c:3
-#: ../locale/scriptstrings/v.pack_to_translate.c:3
-#: ../locale/scriptstrings/t.rast.export_to_translate.c:3
-#: ../locale/scriptstrings/d.to.rast_to_translate.c:3
-#: ../locale/scriptstrings/r.out.xyz_to_translate.c:3
-#: ../raster3d/r3.out.v5d/main.c:285 ../raster3d/r3.out.bin/main.c:206
-#: ../raster3d/r3.out.ascii/main.c:303 ../raster3d/r3.out.netcdf/main.c:587
-#: ../raster3d/r3.out.vtk/main.c:377 ../raster/r.out.png/main.c:113
-#: ../raster/r.external.out/main.c:236 ../raster/r.out.ascii/main.c:60
-#: ../raster/r.out.pov/main.c:122 ../raster/r.out.mpeg/main.c:103
-#: ../raster/r.out.gridatb/main.c:68 ../raster/r.out.ppm3/main.c:58
-#: ../raster/r.out.mat/main.c:63 ../raster/r.out.bin/main.c:280
-#: ../raster/r.out.vrml/main.c:48 ../raster/r.out.gdal/main.c:137
-#: ../raster/r.colors.out/raster3d_main.c:48
-#: ../raster/r.colors.out/raster_main.c:47 ../raster/r.out.ppm/main.c:55
-#: ../raster/r.out.vtk/main.c:60 ../vector/v.out.pov/main.c:47
-#: ../vector/v.out.vtk/main.c:48 ../vector/v.out.ogr/main.c:82
-#: ../vector/v.out.postgis/main.c:45 ../vector/v.out.lidar/main.c:472
-#: ../vector/v.out.ascii/main.c:48 ../vector/v.external.out/main.c:44
-#: ../vector/v.out.svg/main.c:78 ../vector/v.out.dxf/main.c:57
-#: ../vector/v.colors.out/main.c:51
-msgid "export"
+#: ../vector/v.kcv/main.c:70
+msgid "Number of partitions"
 msgstr ""
-#: ../locale/scriptstrings/r.pack_to_translate.c:4
-#: ../locale/scriptstrings/v.unpack_to_translate.c:4
-#: ../locale/scriptstrings/v.pack_to_translate.c:4
-#: ../locale/scriptstrings/r.unpack_to_translate.c:4
-msgid "copying"
+#: ../vector/v.kcv/main.c:71
+msgid "Must be > 1"
 msgstr ""
-#: ../locale/scriptstrings/r.pack_to_translate.c:5
-msgid "Name of raster map to pack up"
+#: ../vector/v.kcv/main.c:76
+msgid "Name for new column to which partition number is written"
 msgstr ""
-#: ../locale/scriptstrings/r.pack_to_translate.c:6
-#: ../locale/scriptstrings/v.pack_to_translate.c:6
-msgid "Name for output file (default is <input>.pack)"
+#: ../vector/v.kcv/main.c:85
+#, c-format
+msgid "'%s' must be > 1"
 msgstr ""
-#: ../locale/scriptstrings/r.pack_to_translate.c:7
-#: ../locale/scriptstrings/v.pack_to_translate.c:7
-msgid "Switch the compression off"
+#: ../vector/v.kcv/main.c:96 ../vector/v.kcv/main.c:186
+#: ../vector/v.category/main.c:186 ../vector/v.category/main.c:250
+#: ../vector/v.category/main.c:258
+#, c-format
+msgid "Unable to open vector map <%s> at topological level %d"
 msgstr ""
-#: ../locale/scriptstrings/db.test_to_translate.c:1
-msgid "Test database driver, database must exist and set by db.connect."
+#: ../vector/v.kcv/main.c:102
+msgid "Layer number must be positive"
 msgstr ""
-#: ../locale/scriptstrings/db.test_to_translate.c:2
-#: ../locale/scriptstrings/db.in.ogr_to_translate.c:2
-#: ../locale/scriptstrings/db.univar_to_translate.c:2
-#: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:4
-#: ../locale/scriptstrings/t.vect.db.select_to_translate.c:5
-#: ../locale/scriptstrings/v.db.update_to_translate.c:4
-#: ../locale/scriptstrings/db.dropcolumn_to_translate.c:2
-#: ../locale/scriptstrings/db.out.ogr_to_translate.c:2
-#: ../locale/scriptstrings/v.what.vect_to_translate.c:4
-#: ../locale/scriptstrings/v.db.renamecolumn_to_translate.c:4
-#: ../locale/scriptstrings/db.droptable_to_translate.c:2
-#: ../locale/scriptstrings/v.db.addtable_to_translate.c:4
-#: ../locale/scriptstrings/v.db.join_to_translate.c:4
-#: ../locale/scriptstrings/v.db.droptable_to_translate.c:4
-#: ../locale/scriptstrings/v.db.addcolumn_to_translate.c:4
-#: ../locale/scriptstrings/v.db.droprow_to_translate.c:4
-#: ../locale/scriptstrings/v.db.dropcolumn_to_translate.c:4
-#: ../vector/v.in.db/main.c:54 ../vector/v.to.db/main.c:38
-#: ../vector/v.db.select/main.c:56 ../vector/v.vect.stats/main.c:126
-#: ../vector/v.distance/main.c:123 ../vector/v.db.connect/main.c:54
-#: ../db/db.createdb/main.c:71 ../db/db.describe/main.c:129
-#: ../db/db.drivers/main.c:71 ../db/db.copy/main.c:35
-#: ../db/db.databases/main.c:95 ../db/db.execute/main.c:125
-#: ../db/db.dropdb/main.c:71 ../db/db.tables/main.c:97
-#: ../db/db.select/main.c:265 ../db/db.connect/main.c:43
-#: ../db/db.columns/main.c:99 ../db/db.login/main.c:40
-msgid "database"
+#: ../vector/v.kcv/main.c:107
+#, c-format
+msgid "More partitions than points (%d)"
 msgstr ""
-#: ../locale/scriptstrings/db.test_to_translate.c:3
-#: ../locale/scriptstrings/db.in.ogr_to_translate.c:4
-#: ../locale/scriptstrings/db.univar_to_translate.c:4
-#: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:3
-#: ../locale/scriptstrings/t.vect.db.select_to_translate.c:3
-#: ../locale/scriptstrings/v.db.update_to_translate.c:3
-#: ../locale/scriptstrings/db.dropcolumn_to_translate.c:3
-#: ../locale/scriptstrings/db.out.ogr_to_translate.c:4
-#: ../locale/scriptstrings/v.what.vect_to_translate.c:7
-#: ../locale/scriptstrings/v.db.renamecolumn_to_translate.c:3
-#: ../locale/scriptstrings/db.droptable_to_translate.c:3
-#: ../locale/scriptstrings/v.db.addtable_to_translate.c:3
-#: ../locale/scriptstrings/v.db.join_to_translate.c:3
-#: ../locale/scriptstrings/v.db.droptable_to_translate.c:3
-#: ../locale/scriptstrings/v.db.univar_to_translate.c:4
-#: ../locale/scriptstrings/v.db.addcolumn_to_translate.c:3
-#: ../locale/scriptstrings/v.db.droprow_to_translate.c:3
-#: ../locale/scriptstrings/v.what.strds_to_translate.c:7
-#: ../locale/scriptstrings/v.db.dropcolumn_to_translate.c:3
-#: ../vector/v.what.rast3/main.c:69 ../vector/v.class/main.c:47
-#: ../vector/v.univar/main.c:95 ../vector/v.to.db/main.c:37
-#: ../vector/v.db.select/main.c:55 ../vector/v.what.rast/main.c:76
-#: ../vector/v.vect.stats/main.c:125 ../vector/v.distance/main.c:124
-#: ../vector/v.db.connect/main.c:53 ../db/db.createdb/main.c:72
-#: ../db/db.describe/main.c:130 ../db/db.copy/main.c:36
-#: ../db/db.databases/main.c:96 ../db/db.execute/main.c:126
-#: ../db/db.dropdb/main.c:72 ../db/db.tables/main.c:98
-#: ../db/db.select/main.c:266 ../db/db.connect/main.c:44
-#: ../db/db.columns/main.c:100
-msgid "attribute table"
+#: ../vector/v.kcv/main.c:120
+#, c-format
+msgid "Unable to get layer info for vector map <%s>"
 msgstr ""
-#: ../locale/scriptstrings/db.test_to_translate.c:4
-msgid "Test name"
+#: ../vector/v.kcv/main.c:145
+#, c-format
+msgid "Column <%s> already exists but is not numeric"
 msgstr ""
-#: ../locale/scriptstrings/t.rename_to_translate.c:1
-msgid "Renames a space time dataset"
+#: ../vector/v.kcv/main.c:160
+#, c-format
+msgid "Unable to alter table: %s"
 msgstr ""
-#: ../locale/scriptstrings/t.rename_to_translate.c:2
-#: ../locale/scriptstrings/t.vect.export_to_translate.c:2
-#: ../locale/scriptstrings/t.rast3d.list_to_translate.c:2
-#: ../locale/scriptstrings/t.rast.colors_to_translate.c:2
-#: ../locale/scriptstrings/t.rast.mapcalc_to_translate.c:2
-#: ../locale/scriptstrings/t.sample_to_translate.c:2
-#: ../locale/scriptstrings/t.rast.out.vtk_to_translate.c:2
-#: ../locale/scriptstrings/t.list_to_translate.c:2
-#: ../locale/scriptstrings/t.rast3d.algebra_to_translate.c:2
-#: ../locale/scriptstrings/t.rast3d.extract_to_translate.c:2
-#: ../locale/scriptstrings/t.snap_to_translate.c:2
-#: ../locale/scriptstrings/t.rast.contour_to_translate.c:2
-#: ../locale/scriptstrings/t.rast3d.mapcalc_to_translate.c:2
-#: ../locale/scriptstrings/t.vect.db.select_to_translate.c:2
-#: ../locale/scriptstrings/t.vect.algebra_to_translate.c:2
-#: ../locale/scriptstrings/t.rast.gapfill_to_translate.c:2
-#: ../locale/scriptstrings/t.rast.to.rast3_to_translate.c:2
-#: ../locale/scriptstrings/t.rast.aggregate_to_translate.c:2
-#: ../locale/scriptstrings/t.rast.aggregate.ds_to_translate.c:2
-#: ../locale/scriptstrings/t.rast.accdetect_to_translate.c:2
-#: ../locale/scriptstrings/t.info_to_translate.c:2
-#: ../locale/scriptstrings/t.vect.observe.strds_to_translate.c:2
-#: ../locale/scriptstrings/t.select_to_translate.c:2
-#: ../locale/scriptstrings/t.rast.univar_to_translate.c:2
-#: ../locale/scriptstrings/t.rast.neighbors_to_translate.c:2
-#: ../locale/scriptstrings/t.support_to_translate.c:2
-#: ../locale/scriptstrings/t.rast.list_to_translate.c:2
-#: ../locale/scriptstrings/t.rast.what_to_translate.c:2
-#: ../locale/scriptstrings/t.rast.algebra_to_translate.c:2
-#: ../locale/scriptstrings/t.shift_to_translate.c:2
-#: ../locale/scriptstrings/t.rast.extract_to_translate.c:2
-#: ../locale/scriptstrings/t.create_to_translate.c:2
-#: ../locale/scriptstrings/t.rast.export_to_translate.c:2
-#: ../locale/scriptstrings/t.unregister_to_translate.c:2
-#: ../locale/scriptstrings/t.rast.import_to_translate.c:2
-#: ../locale/scriptstrings/t.topology_to_translate.c:2
-#: ../locale/scriptstrings/t.vect.list_to_translate.c:2
-#: ../locale/scriptstrings/t.remove_to_translate.c:2
-#: ../locale/scriptstrings/t.rast.to.vect_to_translate.c:2
-#: ../locale/scriptstrings/t.register_to_translate.c:2
-#: ../locale/scriptstrings/t.rast3d.univar_to_translate.c:2
-#: ../locale/scriptstrings/t.merge_to_translate.c:2
-#: ../locale/scriptstrings/t.rast.series_to_translate.c:2
-#: ../locale/scriptstrings/t.vect.univar_to_translate.c:2
-#: ../locale/scriptstrings/v.what.strds_to_translate.c:3
-#: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:2
-#: ../locale/scriptstrings/t.vect.what.strds_to_translate.c:2
-#: ../locale/scriptstrings/t.vect.extract_to_translate.c:2
-#: ../locale/scriptstrings/t.vect.import_to_translate.c:2
-#: ../temporal/t.connect/main.c:34
-msgid "temporal"
+#: ../vector/v.kcv/main.c:267
+#, c-format
+msgid "No category for line %d in layer %d"
 msgstr ""
-#: ../locale/scriptstrings/t.rename_to_translate.c:5
-#: ../locale/scriptstrings/t.vect.export_to_translate.c:5
-#: ../locale/scriptstrings/t.rast3d.list_to_translate.c:7
-#: ../locale/scriptstrings/t.rast.colors_to_translate.c:5
-#: ../locale/scriptstrings/t.rast.mapcalc_to_translate.c:5
-#: ../locale/scriptstrings/t.sample_to_translate.c:4
-#: ../locale/scriptstrings/t.rast.out.vtk_to_translate.c:6
-#: ../locale/scriptstrings/t.list_to_translate.c:5
-#: ../locale/scriptstrings/t.rast3d.algebra_to_translate.c:6
-#: ../locale/scriptstrings/t.rast3d.extract_to_translate.c:6
-#: ../locale/scriptstrings/t.snap_to_translate.c:5
-#: ../locale/scriptstrings/t.rast.contour_to_translate.c:6
-#: ../locale/scriptstrings/t.rast3d.mapcalc_to_translate.c:6
-#: ../locale/scriptstrings/t.vect.db.select_to_translate.c:7
-#: ../locale/scriptstrings/t.vect.algebra_to_translate.c:5
-#: ../locale/scriptstrings/t.rast.gapfill_to_translate.c:5
-#: ../locale/scriptstrings/t.rast.to.rast3_to_translate.c:7
-#: ../locale/scriptstrings/t.rast.aggregate_to_translate.c:5
-#: ../locale/scriptstrings/t.rast.aggregate.ds_to_translate.c:5
-#: ../locale/scriptstrings/t.rast.accdetect_to_translate.c:5
-#: ../locale/scriptstrings/t.info_to_translate.c:5
-#: ../locale/scriptstrings/t.vect.observe.strds_to_translate.c:5
-#: ../locale/scriptstrings/t.select_to_translate.c:4
-#: ../locale/scriptstrings/t.rast.univar_to_translate.c:5
-#: ../locale/scriptstrings/t.rast.neighbors_to_translate.c:5
-#: ../locale/scriptstrings/t.support_to_translate.c:4
-#: ../locale/scriptstrings/t.rast.list_to_translate.c:6
-#: ../locale/scriptstrings/t.rast.what_to_translate.c:5
-#: ../locale/scriptstrings/t.rast.algebra_to_translate.c:5
-#: ../locale/scriptstrings/t.shift_to_translate.c:5
-#: ../locale/scriptstrings/t.rast.extract_to_translate.c:5
-#: ../locale/scriptstrings/t.create_to_translate.c:5
-#: ../locale/scriptstrings/t.rast.export_to_translate.c:5
-#: ../locale/scriptstrings/t.unregister_to_translate.c:5
-#: ../locale/scriptstrings/t.rast.import_to_translate.c:5
-#: ../locale/scriptstrings/t.topology_to_translate.c:4
-#: ../locale/scriptstrings/t.vect.list_to_translate.c:6
-#: ../locale/scriptstrings/t.remove_to_translate.c:5
-#: ../locale/scriptstrings/t.rast.to.vect_to_translate.c:6
-#: ../locale/scriptstrings/t.register_to_translate.c:5
-#: ../locale/scriptstrings/t.rast3d.univar_to_translate.c:6
-#: ../locale/scriptstrings/t.merge_to_translate.c:5
-#: ../locale/scriptstrings/t.rast.series_to_translate.c:6
-#: ../locale/scriptstrings/t.vect.univar_to_translate.c:5
-#: ../locale/scriptstrings/v.what.strds_to_translate.c:8
-#: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:5
-#: ../locale/scriptstrings/t.vect.what.strds_to_translate.c:5
-#: ../locale/scriptstrings/t.vect.extract_to_translate.c:5
-#: ../locale/scriptstrings/t.vect.import_to_translate.c:5
-#: ../raster3d/r3.timestamp/main.c:46 ../raster/r.timestamp/main.c:38
-#: ../vector/v.timestamp/main.c:38
-msgid "time"
+#: ../vector/v.kcv/main.c:300
+msgid "internal error"
 msgstr ""
-#: ../locale/scriptstrings/t.rename_to_translate.c:6
-#: ../locale/scriptstrings/t.snap_to_translate.c:7
-#: ../locale/scriptstrings/t.info_to_translate.c:7
-#: ../locale/scriptstrings/t.select_to_translate.c:5
-#: ../locale/scriptstrings/t.support_to_translate.c:6
-#: ../locale/scriptstrings/t.shift_to_translate.c:7
-#: ../locale/scriptstrings/t.topology_to_translate.c:5
-msgid "input"
+#: ../vector/v.lidar.growing/main.c:78
+msgid ""
+"Building contour determination and Region Growing algorithm for determining "
+"the building inside"
 msgstr ""
-#: ../locale/scriptstrings/t.rename_to_translate.c:7
-#: ../locale/scriptstrings/t.sample_to_translate.c:6
-#: ../locale/scriptstrings/t.sample_to_translate.c:7
-#: ../locale/scriptstrings/t.snap_to_translate.c:8
-#: ../locale/scriptstrings/t.info_to_translate.c:8
-#: ../locale/scriptstrings/t.select_to_translate.c:6
-#: ../locale/scriptstrings/t.support_to_translate.c:7
-#: ../locale/scriptstrings/t.shift_to_translate.c:8
-#: ../locale/scriptstrings/t.topology_to_translate.c:6
-#: ../locale/scriptstrings/t.merge_to_translate.c:7
-#: ../vector/v.profile/main.c:104 ../vector/v.profile/main.c:123
-msgid "Required"
+#: ../vector/v.lidar.growing/main.c:83
+msgid "Input vector (v.lidar.edgedetection output)"
 msgstr ""
-#: ../locale/scriptstrings/d.shade_to_translate.c:1
-#: ../locale/scriptstrings/r.shade_to_translate.c:1
-msgid "Drapes a color raster over an shaded relief or aspect map."
+#: ../vector/v.lidar.growing/main.c:93
+msgid "Name of the first pulse vector map"
 msgstr ""
-#: ../locale/scriptstrings/d.shade_to_translate.c:3
-#: ../locale/scriptstrings/r.in.aster_to_translate.c:6
-#: ../locale/scriptstrings/r.fillnulls_to_translate.c:3
-#: ../locale/scriptstrings/r.plane_to_translate.c:3
-#: ../locale/scriptstrings/r.shade_to_translate.c:3
-#: ../raster/r.relief/main.c:108 ../raster/r.param.scale/interface.c:57
-msgid "elevation"
+#: ../vector/v.lidar.growing/main.c:100
+msgid "Threshold for cell object frequency in region growing"
 msgstr ""
-#: ../locale/scriptstrings/d.shade_to_translate.c:4
-#: ../locale/scriptstrings/r.shade_to_translate.c:4
-#: ../raster/r.relief/main.c:109
-msgid "relief"
+#: ../vector/v.lidar.growing/main.c:108
+msgid "Threshold for double pulse in region growing"
 msgstr ""
-#: ../locale/scriptstrings/d.shade_to_translate.c:5
-#: ../locale/scriptstrings/r.shade_to_translate.c:5
-#: ../raster/r.relief/main.c:111
-msgid "hillshade"
+#: ../vector/v.lidar.growing/main.c:176
+#, c-format
+msgid "Unable to open table <%s>"
 msgstr ""
-#: ../locale/scriptstrings/d.shade_to_translate.c:7
-#: ../locale/scriptstrings/r.shade_to_translate.c:7
-msgid "Name of shaded relief or aspect raster map"
+#: ../vector/v.lidar.growing/main.c:201
+msgid "Setting regions and boxes"
 msgstr ""
-#: ../locale/scriptstrings/d.shade_to_translate.c:8
-#: ../locale/scriptstrings/r.shade_to_translate.c:8
-msgid "Name of raster to drape over relief raster map"
+#: ../vector/v.lidar.growing/main.c:246 ../raster/r.resamp.bspline/main.c:556
+#, c-format
+msgid "subregion %d of %d"
 msgstr ""
-#: ../locale/scriptstrings/d.shade_to_translate.c:9
-#: ../locale/scriptstrings/r.shade_to_translate.c:9
-msgid "Typically, this raster is elevation or other colorful raster"
+#: ../vector/v.lidar.growing/main.c:267
+#, c-format
+msgid "Rows = %d"
 msgstr ""
-#: ../locale/scriptstrings/d.shade_to_translate.c:10
-#: ../locale/scriptstrings/r.shade_to_translate.c:11
-msgid "Percent to brighten"
+#: ../vector/v.lidar.growing/main.c:268
+#, c-format
+msgid "Columns = %d"
 msgstr ""
-#: ../locale/scriptstrings/t.vect.export_to_translate.c:1
-msgid "Exports a space time vector dataset as GRASS GIS specific archive file."
+#: ../vector/v.lidar.growing/main.c:288
+msgid "read points in input vector"
 msgstr ""
-#: ../locale/scriptstrings/t.vect.export_to_translate.c:6
-msgid "Name of a space time vector dataset archive"
+#: ../vector/v.lidar.growing/main.c:446
+msgid "Region Growing"
 msgstr ""
-#: ../locale/scriptstrings/t.vect.export_to_translate.c:7
-#: ../locale/scriptstrings/t.rast.export_to_translate.c:7
-msgid "Path to the work directory, default is /tmp"
+#: ../vector/v.lidar.growing/ConvexHull.c:269
+msgid "...now exiting to system..."
 msgstr ""
-#: ../locale/scriptstrings/t.vect.export_to_translate.c:8
-#: ../locale/scriptstrings/t.rast.export_to_translate.c:8
-msgid "Compression method of the tar archive"
+#: ../vector/v.in.ogr/proj.c:33 ../vector/v.external/proj.c:33
+#, fuzzy, c-format
+msgid "Geometry column <%s> not found in input layer <%s>"
+msgstr "reģions <%s> nav atrasts"
+#: ../vector/v.in.ogr/proj.c:51 ../vector/v.external/proj.c:51
+msgid ""
+"Unable to convert input layer projection information to GRASS format for "
+"checking"
 msgstr ""
-#: ../locale/scriptstrings/t.vect.export_to_translate.c:9
-msgid "The export format of a single vector map"
+#: ../vector/v.in.ogr/proj.c:57 ../vector/v.in.ogr/proj.c:85
+#: ../vector/v.external/proj.c:57 ../vector/v.external/proj.c:85
+msgid "Can't get WKT parameter string"
 msgstr ""
-#: ../locale/scriptstrings/t.vect.export_to_translate.c:10
-msgid "Supported are GML via v.out.ogr and the GRASS package format of v.pack"
+#: ../vector/v.in.ogr/proj.c:60 ../vector/v.in.ogr/proj.c:88
+#: ../vector/v.external/proj.c:60 ../vector/v.external/proj.c:88
+#, c-format
+msgid ""
+"WKT definition:\n"
+"%s"
 msgstr ""
-#: ../locale/scriptstrings/t.rast3d.list_to_translate.c:1
-msgid "Lists registered maps of a space time raster3d dataset."
+#: ../vector/v.in.ogr/proj.c:70 ../vector/v.external/proj.c:70
+#, c-format
+msgid "No OGR projection available for layer <%s>"
 msgstr ""
-#: ../locale/scriptstrings/t.rast3d.list_to_translate.c:6
-#: ../locale/scriptstrings/t.rast3d.algebra_to_translate.c:5
-#: ../locale/scriptstrings/t.rast3d.extract_to_translate.c:5
-#: ../locale/scriptstrings/t.rast3d.mapcalc_to_translate.c:5
-#: ../locale/scriptstrings/t.rast.to.rast3_to_translate.c:6
-#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:4
-#: ../locale/scriptstrings/t.rast3d.univar_to_translate.c:5
-#: ../raster3d/r3.mkdspf/main.c:81 ../raster3d/r3.gwflow/main.c:161
-#: ../raster3d/r3.gradient/main.c:45 ../raster3d/r3.out.v5d/main.c:286
-#: ../raster3d/r3.in.bin/main.c:254 ../raster3d/r3.out.bin/main.c:207
-#: ../raster3d/r3.neighbors/main.c:210 ../raster3d/r3.out.ascii/main.c:304
-#: ../raster3d/r3.info/main.c:77 ../raster3d/r3.null/main.c:188
-#: ../raster3d/r3.cross.rast/main.c:231 ../raster3d/r3.in.v5d/main.c:180
-#: ../raster3d/r3.stats/main.c:50 ../raster3d/r3.out.netcdf/main.c:589
-#: ../raster3d/r3.flow/main.c:181 ../raster3d/r3.in.ascii/main.c:356
-#: ../raster3d/r3.support/main.c:51 ../raster3d/r3.mask/main.c:135
-#: ../raster3d/r3.to.rast/main.c:262 ../raster3d/r3.timestamp/main.c:47
-#: ../raster3d/r3.retile/main.c:98 ../raster3d/r3.out.vtk/main.c:378
-#: ../raster/r.to.rast3/main.c:199 ../raster/r.to.rast3elev/main.c:364
-#: ../vector/v.to.rast3/main.c:50 ../vector/v.vol.rst/main.c:236
-msgid "voxel"
+#: ../vector/v.in.ogr/proj.c:78 ../vector/v.external/proj.c:78
+#, c-format
+msgid "OGR projection for layer <%s> does not contain a valid SRS"
 msgstr ""
-#: ../locale/scriptstrings/t.rast3d.list_to_translate.c:8
-msgid "Order the space time dataset by category"
+#: ../vector/v.in.ogr/proj.c:96 ../vector/v.external/proj.c:96
+#, c-format
+msgid "OGR projection for layer <%s> can not be converted to proj4"
 msgstr ""
-#: ../locale/scriptstrings/t.rast3d.list_to_translate.c:9
-#: ../locale/scriptstrings/t.list_to_translate.c:13
-#: ../locale/scriptstrings/t.rast.list_to_translate.c:9
-#: ../locale/scriptstrings/t.vect.list_to_translate.c:9
-msgid "Columns to be printed to stdout"
+#: ../vector/v.in.ogr/proj.c:103 ../vector/v.external/proj.c:103
+msgid "Can't get WKT-style parameter string"
 msgstr ""
-#: ../locale/scriptstrings/t.rast3d.list_to_translate.c:10
-#: ../locale/scriptstrings/t.rast3d.list_to_translate.c:11
-#: ../locale/scriptstrings/t.list_to_translate.c:7
-#: ../locale/scriptstrings/t.list_to_translate.c:8
-#: ../locale/scriptstrings/t.list_to_translate.c:14
-#: ../locale/scriptstrings/t.list_to_translate.c:15
-#: ../locale/scriptstrings/t.rast.univar_to_translate.c:6
-#: ../locale/scriptstrings/t.rast.list_to_translate.c:10
-#: ../locale/scriptstrings/t.rast.list_to_translate.c:11
-#: ../locale/scriptstrings/t.vect.list_to_translate.c:10
-#: ../locale/scriptstrings/t.vect.list_to_translate.c:11
-#: ../locale/scriptstrings/v.report_to_translate.c:5
-#: ../locale/scriptstrings/t.rast3d.univar_to_translate.c:7
-#: ../locale/scriptstrings/t.vect.univar_to_translate.c:6
-#: ../locale/scriptstrings/t.vect.univar_to_translate.c:7
-#: ../raster3d/r3.in.lidar/main.c:232 ../raster3d/r3.in.lidar/main.c:242
-#: ../raster3d/r3.in.lidar/main.c:272 ../raster3d/r3.in.lidar/main.c:288
-#: ../raster/r.category/main.c:62 ../raster/r.category/main.c:71
-#: ../raster/r.in.lidar/main.c:192 ../raster/r.in.lidar/main.c:208
-#: ../raster/r.in.lidar/main.c:261 ../raster/r.in.lidar/main.c:271
-#: ../raster/r.in.lidar/main.c:339 ../display/d.rast/main.c:70
-#: ../display/d.rast/main.c:87 ../display/d.vect/main.c:83
-#: ../display/d.vect/main.c:108 ../display/d.vect/main.c:111
-#: ../display/d.vect/main.c:114 ../display/d.vect/main.c:316
-#: ../display/d.vect.thematic/main.c:98 ../display/d.vect.thematic/main.c:148
-#: ../display/d.vect.chart/main.c:74 ../display/d.vect.chart/main.c:77
-#: ../vector/v.surf.rst/main.c:178 ../vector/v.surf.rst/main.c:190
-#: ../vector/v.category/main.c:85 ../vector/v.category/main.c:89
-#: ../vector/v.category/main.c:93 ../vector/v.extrude/main.c:84
-#: ../vector/v.extrude/main.c:87 ../vector/v.extrude/main.c:90
-#: ../vector/v.extrude/main.c:95 ../vector/v.extract/main.c:98
-#: ../vector/v.extract/main.c:103 ../vector/v.extract/main.c:109
-#: ../vector/v.extract/main.c:112 ../vector/v.extract/main.c:115
-#: ../vector/v.extract/main.c:125 ../vector/v.extract/main.c:135
-#: ../vector/v.edit/args.c:24 ../vector/v.edit/args.c:29
-#: ../vector/v.edit/args.c:118 ../vector/v.edit/args.c:122
-#: ../vector/v.edit/args.c:131 ../vector/v.edit/args.c:140
-#: ../vector/v.edit/args.c:149 ../vector/v.edit/args.c:152
-#: ../vector/v.edit/args.c:170 ../vector/v.edit/args.c:205
-#: ../vector/v.random/main.c:117 ../vector/v.random/main.c:120
-#: ../vector/v.random/main.c:123 ../vector/v.random/main.c:126
-#: ../vector/v.out.ogr/args.c:12 ../vector/v.out.ogr/args.c:22
-#: ../vector/v.out.ogr/args.c:102 ../vector/v.in.db/main.c:94
-#: ../vector/v.to.3d/args.c:19 ../vector/v.to.3d/args.c:25
-#: ../vector/v.out.postgis/args.c:15 ../vector/v.out.postgis/args.c:19
-#: ../vector/v.out.lidar/main.c:487 ../vector/v.out.lidar/main.c:491
-#: ../vector/v.out.lidar/main.c:588 ../vector/v.out.ascii/args.c:24
-#: ../vector/v.out.ascii/args.c:28 ../vector/v.out.ascii/args.c:43
-#: ../vector/v.out.ascii/args.c:46 ../vector/v.in.ogr/main.c:174
-#: ../vector/v.in.ogr/main.c:179 ../vector/v.in.ogr/main.c:188
-#: ../vector/v.in.ogr/main.c:204 ../vector/v.in.ogr/main.c:252
-#: ../vector/v.in.ogr/main.c:297 ../vector/v.net.allpairs/main.c:75
-#: ../vector/v.net.allpairs/main.c:81 ../vector/v.net.allpairs/main.c:84
-#: ../vector/v.net.allpairs/main.c:87 ../vector/v.decimate/main.c:147
-#: ../vector/v.decimate/main.c:150 ../vector/v.to.db/parse.c:45
-#: ../vector/v.select/args.c:18 ../vector/v.select/args.c:24
-#: ../vector/v.select/args.c:33 ../vector/v.select/args.c:39
-#: ../vector/v.select/args.c:106 ../vector/v.db.select/main.c:64
-#: ../vector/v.db.select/main.c:67 ../vector/v.db.select/main.c:70
-#: ../vector/v.db.select/main.c:76 ../vector/v.db.select/main.c:116
-#: ../vector/v.to.points/main.c:67 ../vector/v.to.points/main.c:71
-#: ../vector/v.clean/main.c:61 ../vector/v.clean/main.c:64
-#: ../vector/v.drape/main.c:67 ../vector/v.drape/main.c:70
-#: ../vector/v.drape/main.c:73 ../vector/v.drape/main.c:78
-#: ../vector/v.reclass/main.c:77 ../vector/v.reclass/main.c:82
-#: ../vector/v.in.lidar/main.c:185 ../vector/v.in.lidar/main.c:195
-#: ../vector/v.in.lidar/main.c:204 ../vector/v.in.lidar/main.c:214
-#: ../vector/v.in.lidar/main.c:221 ../vector/v.in.lidar/main.c:226
-#: ../vector/v.in.lidar/main.c:281 ../vector/v.in.lidar/main.c:287
-#: ../vector/v.in.lidar/main.c:295 ../vector/v.net.centrality/main.c:121
-#: ../vector/v.net.centrality/main.c:123 ../vector/v.generalize/main.c:92
-#: ../vector/v.generalize/main.c:231 ../vector/v.generalize/main.c:234
-#: ../vector/v.to.rast/main.c:57 ../vector/v.to.rast/main.c:60
-#: ../vector/v.to.rast/main.c:63 ../vector/v.buffer/main.c:235
-#: ../vector/v.buffer/main.c:238 ../vector/v.buffer/main.c:241
-#: ../vector/v.buffer/main.c:246
-msgid "Selection"
-msgstr "Izvēle"
+#: ../vector/v.in.ogr/proj.c:106 ../vector/v.external/proj.c:106
+#, c-format
+msgid ""
+"WKT-style definition:\n"
+"%s"
+msgstr ""
-#: ../locale/scriptstrings/t.rast3d.list_to_translate.c:12
-#: ../locale/scriptstrings/t.rast.list_to_translate.c:12
-#: ../locale/scriptstrings/t.vect.list_to_translate.c:12
-msgid "Method used for data listing"
+#: ../vector/v.in.ogr/proj.c:151
+msgid "Layer projections are unreadable"
 msgstr ""
-#: ../locale/scriptstrings/t.rast3d.list_to_translate.c:13
-#: ../locale/scriptstrings/t.list_to_translate.c:16
-#: ../locale/scriptstrings/t.vect.db.select_to_translate.c:8
-#: ../locale/scriptstrings/t.rast.univar_to_translate.c:7
-#: ../locale/scriptstrings/t.rast.list_to_translate.c:14
-#: ../locale/scriptstrings/t.vect.list_to_translate.c:13
-#: ../locale/scriptstrings/t.rast3d.univar_to_translate.c:8
-#: ../locale/scriptstrings/t.vect.univar_to_translate.c:8
-msgid "Field separator character between the output columns"
+#: ../vector/v.in.ogr/proj.c:162
+#, fuzzy, c-format
+msgid "Projection for layer <%s> is unreadable"
+msgstr "Trūkst projekcijas failu"
+#: ../vector/v.in.ogr/proj.c:196
+#, c-format
+msgid "Projection of layer <%s> is different from projection of layer <%s>"
 msgstr ""
-#: ../locale/scriptstrings/t.rast3d.list_to_translate.c:14
-#: ../locale/scriptstrings/t.rast3d.list_to_translate.c:16
-#: ../locale/scriptstrings/t.list_to_translate.c:11
-#: ../locale/scriptstrings/t.list_to_translate.c:17
-#: ../locale/scriptstrings/t.list_to_translate.c:19
-#: ../locale/scriptstrings/t.rast.univar_to_translate.c:8
-#: ../locale/scriptstrings/t.rast.univar_to_translate.c:12
-#: ../locale/scriptstrings/t.rast.list_to_translate.c:8
-#: ../locale/scriptstrings/t.rast.list_to_translate.c:15
-#: ../locale/scriptstrings/t.rast.list_to_translate.c:17
-#: ../locale/scriptstrings/t.vect.list_to_translate.c:8
-#: ../locale/scriptstrings/t.vect.list_to_translate.c:14
-#: ../locale/scriptstrings/t.vect.list_to_translate.c:16
-#: ../locale/scriptstrings/t.rast3d.univar_to_translate.c:9
-#: ../locale/scriptstrings/t.rast3d.univar_to_translate.c:12
-#: ../locale/scriptstrings/t.vect.univar_to_translate.c:9
-#: ../locale/scriptstrings/t.vect.univar_to_translate.c:12
-#: ../raster/r.univar/r.univar_main.c:56 ../raster/r.univar/r.univar_main.c:62
-#: ../raster/r.univar/r.univar_main.c:72 ../raster/r.report/parse.c:69
-#: ../raster/r.report/parse.c:77 ../raster/r.report/parse.c:85
-#: ../raster/r.report/parse.c:109 ../raster/r.report/parse.c:114
-#: ../raster/r.report/parse.c:119 ../raster/r.report/parse.c:124
-#: ../raster/r.stats.quantile/main.c:559 ../raster/r.kappa/main.c:104
-#: ../raster/r.kappa/main.c:109 ../raster/r.stats/main.c:123
-#: ../raster/r.stats/main.c:127 ../raster/r.stats/main.c:151
-msgid "Formatting"
+#: ../vector/v.in.ogr/proj.c:253 ../vector/v.in.lidar/main.c:507
+#: ../vector/v.external/proj.c:154 ../raster/r.external/proj.c:62
+#: ../raster/r.in.gdal/proj.c:62 ../raster/r.in.gdal/main.c:808
+msgid ""
+"Unable to convert input map projection to GRASS format; cannot create new "
+"location."
 msgstr ""
-#: ../locale/scriptstrings/t.rast3d.list_to_translate.c:15
-#: ../locale/scriptstrings/t.rast.univar_to_translate.c:11
-#: ../locale/scriptstrings/t.rast.list_to_translate.c:16
-#: ../locale/scriptstrings/t.vect.list_to_translate.c:15
-#: ../locale/scriptstrings/t.rast3d.univar_to_translate.c:11
-#: ../locale/scriptstrings/t.vect.univar_to_translate.c:11
-msgid "Suppress printing of column names"
+#: ../vector/v.in.ogr/proj.c:259 ../vector/v.in.lidar/main.c:513
+#: ../vector/v.external/proj.c:160 ../raster/r.external/proj.c:68
+#: ../raster/r.in.gdal/proj.c:68 ../raster/r.in.gdal/main.c:832
+#, c-format
+msgid "Unable to create new location <%s>"
 msgstr ""
-#: ../locale/scriptstrings/i.in.spotvgt_to_translate.c:1
-msgid "Imports SPOT VGT NDVI data into a raster map."
+#: ../vector/v.in.ogr/proj.c:262 ../vector/v.in.lidar/main.c:516
+#: ../vector/v.external/proj.c:163 ../raster/r.external/proj.c:71
+#: ../raster/r.in.gdal/proj.c:71 ../raster/r.in.gdal/main.c:838
+#: ../general/g.proj/create.c:15
+#, c-format
+msgid "Location <%s> created"
 msgstr ""
-#: ../locale/scriptstrings/i.in.spotvgt_to_translate.c:2
-#: ../locale/scriptstrings/i.spectral_to_translate.c:2
-#: ../locale/scriptstrings/r.in.aster_to_translate.c:4
-#: ../locale/scriptstrings/i.colors.enhance_to_translate.c:2
-#: ../locale/scriptstrings/i.oif_to_translate.c:2
-#: ../locale/scriptstrings/i.image.mosaic_to_translate.c:2
-#: ../locale/scriptstrings/i.tasscap_to_translate.c:2
-#: ../locale/scriptstrings/i.pansharpen_to_translate.c:2
-#: ../imagery/i.segment/main.c:36 ../imagery/i.biomass/main.c:50
-#: ../imagery/i.pca/main.c:72 ../imagery/i.modis.qc/main.c:168
-#: ../imagery/i.landsat.toar/main.c:70 ../imagery/i.eb.hsebal01/main.c:104
-#: ../imagery/i.maxlik/main.c:61 ../imagery/i.albedo/main.c:95
-#: ../imagery/i.eb.netrad/main.c:56 ../imagery/i.eb.evapfr/main.c:47
-#: ../imagery/i.smap/main.c:38 ../imagery/i.aster.toar/main.c:97
-#: ../imagery/i.ortho.photo/i.ortho.init/main.c:47
-#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:388
-#: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:88
-#: ../imagery/i.ortho.photo/i.ortho.photo/menu.c:46
-#: ../imagery/i.ortho.photo/i.ortho.target/main.c:47
-#: ../imagery/i.ortho.photo/i.ortho.camera/main.c:56
-#: ../imagery/i.ortho.photo/i.ortho.elev/main.c:63
-#: ../imagery/i.landsat.acca/main.c:105 ../imagery/i.evapo.time/main.c:77
-#: ../imagery/i.zc/main.c:52 ../imagery/i.his.rgb/main.c:46
-#: ../imagery/i.target/main.c:45 ../imagery/i.evapo.pm/main.c:58
-#: ../imagery/i.ifft/main.c:77 ../imagery/i.fft/main.c:78
-#: ../imagery/i.rectify/main.c:99 ../imagery/i.gensigset/main.c:40
-#: ../imagery/i.eb.soilheatflux/main.c:49 ../imagery/i.vi/main.c:89
-#: ../imagery/i.group/main.c:52 ../imagery/i.eb.eta/main.c:42
-#: ../imagery/i.evapo.pt/main.c:66 ../imagery/i.gensig/main.c:39
-#: ../imagery/i.topo.corr/main.c:47 ../imagery/i.evapo.mh/main.c:69
-#: ../imagery/i.cluster/main.c:75 ../imagery/i.emissivity/main.c:44
-#: ../imagery/i.cca/main.c:84 ../imagery/i.rgb.his/main.c:46
-msgid "imagery"
-msgstr "attēli"
+#: ../vector/v.in.ogr/proj.c:284 ../vector/v.external/proj.c:185
+#: ../raster/r.external/proj.c:93 ../raster/r.in.gdal/proj.c:93
+msgid "Unable to convert input map projection information to GRASS format."
+msgstr ""
-#: ../locale/scriptstrings/i.in.spotvgt_to_translate.c:3
-#: ../locale/scriptstrings/db.in.ogr_to_translate.c:3
-#: ../locale/scriptstrings/r.in.srtm_to_translate.c:3
-#: ../locale/scriptstrings/v.unpack_to_translate.c:3
-#: ../locale/scriptstrings/r.import_to_translate.c:3
-#: ../locale/scriptstrings/r.in.aster_to_translate.c:3
-#: ../locale/scriptstrings/v.import_to_translate.c:3
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:3
-#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:3
-#: ../locale/scriptstrings/t.rast.import_to_translate.c:3
-#: ../locale/scriptstrings/r.unpack_to_translate.c:3
-#: ../locale/scriptstrings/v.in.mapgen_to_translate.c:3
-#: ../locale/scriptstrings/v.in.geonames_to_translate.c:3
-#: ../locale/scriptstrings/v.in.lines_to_translate.c:3
-#: ../locale/scriptstrings/v.in.wfs_to_translate.c:3
-#: ../locale/scriptstrings/v.in.e00_to_translate.c:3
-#: ../locale/scriptstrings/t.vect.import_to_translate.c:3
-#: ../raster3d/r3.in.bin/main.c:253 ../raster3d/r3.in.v5d/main.c:179
-#: ../raster3d/r3.in.ascii/main.c:355 ../raster3d/r3.in.lidar/main.c:163
-#: ../raster/r.in.bin/main.c:258 ../raster/r.in.xyz/main.c:159
-#: ../raster/r.in.png/main.c:520 ../raster/r.in.poly/main.c:35
-#: ../raster/r.in.mat/main.c:92 ../raster/r.in.gridatb/main.c:46
-#: ../raster/r.proj/main.c:147 ../raster/r.external/main.c:58
-#: ../raster/r.in.gdal/main.c:91 ../raster/r.in.ascii/main.c:70
-#: ../raster/r.in.lidar/main.c:109 ../vector/v.in.db/main.c:53
-#: ../vector/v.in.dxf/main.c:65 ../vector/v.external/main.c:51
-#: ../vector/v.in.ascii/main.c:71 ../vector/v.in.ogr/main.c:136
-#: ../vector/v.proj/main.c:71 ../vector/v.in.dwg/main.c:83
-#: ../vector/v.in.lidar/main.c:137
-msgid "import"
-msgstr "importēt"
-#: ../locale/scriptstrings/i.in.spotvgt_to_translate.c:4
-msgid "NDVI"
+#: ../vector/v.in.ogr/proj.c:313 ../vector/v.in.lidar/projection.c:126
+#: ../vector/v.external/proj.c:214 ../raster/r.external/proj.c:121
+#: ../raster/r.in.lidar/projection.c:128 ../raster/r.in.gdal/proj.c:121
+#: ../raster3d/r3.in.lidar/projection.c:130
+msgid "Over-riding projection check"
 msgstr ""
-#: ../locale/scriptstrings/i.in.spotvgt_to_translate.c:5
-msgid "SPOT"
+#: ../vector/v.in.ogr/proj.c:322 ../vector/v.in.pdal/projection.c:31
+#: ../vector/v.in.lidar/projection.c:32 ../vector/v.external/proj.c:223
+#: ../raster/r.external/proj.c:130 ../raster/r.in.lidar/projection.c:34
+#: ../raster/r.in.gdal/proj.c:130 ../raster3d/r3.in.lidar/projection.c:36
+msgid ""
+"Projection of dataset does not appear to match current location.\n"
+"\n"
 msgstr ""
-#: ../locale/scriptstrings/i.in.spotvgt_to_translate.c:6
-msgid "Also import quality map (SM status map layer) and filter NDVI map"
+#: ../vector/v.in.ogr/proj.c:329 ../vector/v.external/proj.c:230
+#: ../raster/r.external/proj.c:137 ../raster/r.in.gdal/proj.c:137
+msgid "Location PROJ_INFO is:\n"
 msgstr ""
-#: ../locale/scriptstrings/i.in.spotvgt_to_translate.c:7
-msgid "Name of input SPOT VGT NDVI HDF file"
+#: ../vector/v.in.ogr/proj.c:339 ../vector/v.in.ogr/proj.c:346
+#: ../vector/v.external/proj.c:240 ../vector/v.external/proj.c:247
+#: ../raster/r.external/proj.c:147 ../raster/r.external/proj.c:154
+#: ../raster/r.in.gdal/proj.c:147 ../raster/r.in.gdal/proj.c:154
+msgid "Dataset PROJ_INFO is:\n"
 msgstr ""
-#: ../locale/scriptstrings/t.rast.colors_to_translate.c:1
-msgid "Creates/modifies the color table associated with each raster map of the space time raster dataset."
+#: ../vector/v.in.ogr/proj.c:427 ../vector/v.in.pdal/projection.c:88
+#: ../vector/v.in.lidar/projection.c:89 ../vector/v.external/proj.c:328
+#: ../raster/r.external/proj.c:235 ../raster/r.in.lidar/projection.c:91
+#: ../raster/r.in.gdal/proj.c:235 ../raster3d/r3.in.lidar/projection.c:93
+#, c-format
+msgid ""
+"\n"
+"In case of no significant differences in the projection definitions, use the "
+"-o flag to ignore them and use current location definition.\n"
 msgstr ""
-#: ../locale/scriptstrings/t.rast.colors_to_translate.c:3
-#: ../locale/scriptstrings/r.colors.stddev_to_translate.c:3
-#: ../raster/r.what.color/main.c:90 ../raster/r.colors/edit_colors.c:67
-#: ../raster/r.colors.out/raster3d_main.c:47
-#: ../raster/r.colors.out/raster_main.c:46 ../display/d.colortable/main.c:62
-#: ../vector/v.colors/main.c:56 ../vector/v.colors.out/main.c:50
-msgid "color table"
+#: ../vector/v.in.ogr/proj.c:431 ../vector/v.external/proj.c:332
+#: ../raster/r.external/proj.c:239 ../raster/r.in.gdal/proj.c:239
+msgid ""
+"Consider generating a new location from the input dataset using the "
+"'location' parameter.\n"
 msgstr ""
-#: ../locale/scriptstrings/t.rast.colors_to_translate.c:6
-msgid "Name of color table (see r.color help)"
+#: ../vector/v.in.ogr/proj.c:449 ../vector/v.in.pdal/projection.c:137
+#: ../vector/v.in.lidar/projection.c:137 ../vector/v.external/proj.c:350
+#: ../raster/r.external/proj.c:257 ../raster/r.in.lidar/projection.c:139
+#: ../raster/r.in.gdal/proj.c:257 ../raster3d/r3.in.lidar/projection.c:141
+msgid "Projection of input dataset and current location appear to match"
 msgstr ""
-#: ../locale/scriptstrings/t.rast.colors_to_translate.c:7
-#: ../locale/scriptstrings/t.rast.colors_to_translate.c:9
-#: ../locale/scriptstrings/t.rast.colors_to_translate.c:11
-#: ../locale/scriptstrings/t.rast.colors_to_translate.c:13
-#: ../locale/scriptstrings/t.rast.colors_to_translate.c:20
-#: ../locale/scriptstrings/t.rast.colors_to_translate.c:22
-#: ../locale/scriptstrings/t.rast.colors_to_translate.c:24
-#: ../locale/scriptstrings/t.rast.colors_to_translate.c:26
-#: ../raster/r.category/main.c:81 ../raster/r.category/main.c:88
-#: ../raster/r.colors/edit_colors.c:90 ../raster/r.colors/edit_colors.c:97
-#: ../raster/r.colors/edit_colors.c:104 ../raster/r.colors/edit_colors.c:111
-#: ../raster/r.colors/edit_colors.c:122 ../raster/r.colors/edit_colors.c:133
-#: ../raster/r.colors/edit_colors.c:138 ../raster/r.colors/edit_colors.c:143
-#: ../raster/r.colors/edit_colors.c:148 ../display/d.linegraph/main.c:270
-#: ../vector/v.colors/main.c:81 ../vector/v.colors/main.c:92
-#: ../vector/v.colors/main.c:99 ../vector/v.colors/main.c:106
-#: ../vector/v.colors/main.c:112 ../vector/v.colors/main.c:138
-#: ../vector/v.colors/main.c:143 ../vector/v.colors/main.c:148
-msgid "Define"
-msgstr "Definēt"
-#: ../locale/scriptstrings/t.rast.colors_to_translate.c:8
-#: ../raster/r.colors/edit_colors.c:96 ../vector/v.colors/main.c:98
-msgid "Raster map from which to copy color table"
+#: ../vector/v.in.ogr/main.c:175 ../raster/r.in.gdal/main.c:94
+#: ../locale/scriptstrings/t.rast.import_to_translate.c:6
+#: ../locale/scriptstrings/t.vect.import_to_translate.c:6
+#: ../general/g.proj/main.c:66
+msgid "create location"
 msgstr ""
-#: ../locale/scriptstrings/t.rast.colors_to_translate.c:10
-#: ../raster/r.colors/edit_colors.c:103 ../vector/v.colors/main.c:105
-msgid "3D raster map from which to copy color table"
+#: ../vector/v.in.ogr/main.c:176
+msgid "Imports vector data into a GRASS vector map using OGR library."
 msgstr ""
-#: ../locale/scriptstrings/t.rast.colors_to_translate.c:12
-#: ../raster/r.colors/edit_colors.c:109 ../vector/v.colors/main.c:111
-msgid "Path to rules file"
+#: ../vector/v.in.ogr/main.c:182
+#: ../locale/scriptstrings/v.import_to_translate.c:5
+msgid "Name of OGR datasource to be imported"
 msgstr ""
-#: ../locale/scriptstrings/t.rast.colors_to_translate.c:14
-#: ../raster/r.colors/edit_colors.c:115 ../vector/v.colors/main.c:121
-msgid "Remove existing color table"
+#: ../vector/v.in.ogr/main.c:183
+msgid ""
+"Examples:\n"
+"\t\tESRI Shapefile: directory containing shapefiles\n"
+"\t\tMapInfo File: directory containing mapinfo files"
 msgstr ""
-#: ../locale/scriptstrings/t.rast.colors_to_translate.c:15
-#: ../locale/scriptstrings/g.extension_to_translate.c:30
-#: ../locale/scriptstrings/r.mask_to_translate.c:20 ../raster/r.null/main.c:108
-#: ../raster/r.colors/edit_colors.c:116 ../vector/v.colors/main.c:122
-msgid "Remove"
+#: ../vector/v.in.ogr/main.c:194
+#: ../locale/scriptstrings/v.import_to_translate.c:7
+msgid "OGR layer name. If not given, all available layers are imported"
 msgstr ""
-#: ../locale/scriptstrings/t.rast.colors_to_translate.c:16
-#: ../raster/r.colors/edit_colors.c:121 ../vector/v.colors/main.c:127
-msgid "Only write new color table if it does not already exist"
+#: ../vector/v.in.ogr/main.c:196
+msgid ""
+"Examples:\n"
+"\t\tESRI Shapefile: shapefile name\n"
+"\t\tMapInfo File: mapinfo file name"
 msgstr ""
-#: ../locale/scriptstrings/t.rast.colors_to_translate.c:17
-#: ../raster/r.colors/edit_colors.c:126 ../vector/v.colors/main.c:131
-msgid "List available rules then exit"
+#: ../vector/v.in.ogr/main.c:198 ../vector/v.edit/args.c:96
+#: ../vector/v.edit/args.c:215 ../raster/r.horizon/main.c:195
+#: ../raster/r.horizon/main.c:204 ../raster/r.horizon/main.c:212
+#: ../raster/r.external/main.c:66 ../raster/r.external/main.c:74
+#: ../raster/r.external/main.c:83 ../raster/r.in.lidar/main.c:122
+#: ../raster/r.in.lidar/main.c:133 ../raster/r.in.xyz/main.c:213
+#: ../raster/r.in.xyz/main.c:222 ../raster/r.in.xyz/main.c:230
+#: ../raster/r.in.xyz/main.c:241 ../raster/r.in.xyz/main.c:251
+#: ../raster/r.spread/main.c:125 ../raster/r.spread/main.c:139
+#: ../raster/r.spread/main.c:151 ../raster/r.spread/main.c:164
+#: ../raster/r.spread/main.c:177 ../raster/r.spread/main.c:189
+#: ../raster/r.spread/main.c:201 ../raster/r.sim/r.sim.sediment/main.c:158
+#: ../raster/r.sim/r.sim.sediment/main.c:166
+#: ../raster/r.sim/r.sim.sediment/main.c:173
+#: ../raster/r.sim/r.sim.water/main.c:138
+#: ../raster/r.sim/r.sim.water/main.c:147
+#: ../raster/r.sim/r.sim.water/main.c:154
+#: ../raster/r.sim/r.sim.water/main.c:163
+#: ../raster/r.sim/r.sim.water/main.c:169
+#: ../raster/r.sim/r.sim.water/main.c:177
+#: ../raster/r.sim/r.sim.water/main.c:184
+#: ../raster/r.sim/r.sim.water/main.c:191 ../raster/r.sun/main.c:272
+#: ../raster/r.sun/main.c:281 ../raster/r.sun/main.c:290
+#: ../raster/r.sun/main.c:299 ../raster/r.sun/main.c:307
+#: ../raster/r.sun/main.c:316 ../raster/r.sun/main.c:325
+#: ../raster/r.sun/main.c:334 ../raster/r.sun/main.c:343
+#: ../raster/r.sun/main.c:352 ../raster/r.sun/main.c:361
+#: ../raster/r.sun/main.c:370 ../raster/r.sun/main.c:379
+#: ../raster/r.sun/main.c:386 ../raster/r.sun/main.c:394
+#: ../locale/scriptstrings/i.spectral_to_translate.c:6
+#: ../locale/scriptstrings/i.spectral_to_translate.c:7
+#: ../locale/scriptstrings/i.spectral_to_translate.c:8
+#: ../locale/scriptstrings/t.register_to_translate.c:6
+#: ../locale/scriptstrings/t.register_to_translate.c:7
+#: ../locale/scriptstrings/t.register_to_translate.c:9
+#: ../locale/scriptstrings/t.register_to_translate.c:12
+#: ../locale/scriptstrings/t.register_to_translate.c:26
+#: ../locale/scriptstrings/v.import_to_translate.c:6
+#: ../locale/scriptstrings/v.import_to_translate.c:8
+#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:18
+#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:20
+#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:22
+#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:24
+#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:27
+#: ../locale/scriptstrings/r.import_to_translate.c:6
+#: ../locale/scriptstrings/r.import_to_translate.c:8
+#: ../locale/scriptstrings/t.remove_to_translate.c:6
+#: ../locale/scriptstrings/t.remove_to_translate.c:9
+#: ../locale/scriptstrings/t.remove_to_translate.c:11
+#: ../raster3d/r3.in.lidar/main.c:177 ../raster3d/r3.in.lidar/main.c:184
+#: ../raster3d/r3.flow/main.c:188 ../raster3d/r3.flow/main.c:195
+#: ../raster3d/r3.flow/main.c:205 ../display/d.legend/main.c:88
+#: ../display/d.legend/main.c:93 ../display/d.text/main.c:149
+#: ../display/d.text/main.c:154
+msgid "Input"
 msgstr ""
-#: ../locale/scriptstrings/t.rast.colors_to_translate.c:19
-#: ../raster/r.colors/edit_colors.c:132 ../vector/v.colors/main.c:137
-msgid "Invert colors"
-msgstr "Pretējas krāsas"
-#: ../locale/scriptstrings/t.rast.colors_to_translate.c:21
-#: ../raster/r.colors/edit_colors.c:137 ../vector/v.colors/main.c:142
-msgid "Logarithmic scaling"
+#: ../vector/v.in.ogr/main.c:211 ../vector/v.in.lidar/main.c:186
+msgid "Import subregion only"
 msgstr ""
-#: ../locale/scriptstrings/t.rast.colors_to_translate.c:23
-#: ../raster/r.colors/edit_colors.c:142 ../vector/v.colors/main.c:147
-msgid "Logarithmic-absolute scaling"
+#: ../vector/v.in.ogr/main.c:214 ../vector/v.in.lidar/main.c:189
+msgid "Format: xmin,ymin,xmax,ymax - usually W,S,E,N"
 msgstr ""
-#: ../locale/scriptstrings/t.rast.colors_to_translate.c:25
-#: ../raster/r.colors/edit_colors.c:147
-msgid "Histogram equalization"
+#: ../vector/v.in.ogr/main.c:225
+msgid "Minimum size of area to be imported (square meters)"
 msgstr ""
-#: ../locale/scriptstrings/v.to.lines_to_translate.c:1
-msgid "Converts vector polygons or points to lines."
+#: ../vector/v.in.ogr/main.c:227
+msgid "Smaller areas and islands are ignored. Should be greater than snap^2"
 msgstr ""
-#: ../locale/scriptstrings/v.to.lines_to_translate.c:3
-#: ../locale/scriptstrings/i.image.mosaic_to_translate.c:3
-#: ../locale/scriptstrings/v.report_to_translate.c:3 ../raster/r.thin/main.c:58
-#: ../raster/r.to.vect/main.c:78 ../raster/r.circle/main.c:53
-#: ../raster/r.patch/main.c:59 ../vector/v.extrude/main.c:68
-#: ../vector/v.segment/main.c:61 ../vector/v.split/main.c:55
-#: ../vector/v.edit/main.c:55 ../vector/v.voronoi/main.c:124
-#: ../vector/v.in.region/main.c:42 ../vector/v.type/main.c:39
-#: ../vector/v.build.polylines/main.c:112 ../vector/v.to.3d/main.c:37
-#: ../vector/v.univar/main.c:96 ../vector/v.mkgrid/main.c:71
-#: ../vector/v.overlay/main.c:64 ../vector/v.parallel/main.c:50
-#: ../vector/v.build/main.c:38 ../vector/v.select/main.c:49
-#: ../vector/v.to.points/main.c:54 ../vector/v.clean/main.c:53
-#: ../vector/v.drape/main.c:57 ../vector/v.perturb/main.c:63
-#: ../vector/v.patch/main.c:70 ../vector/v.delaunay/main.c:86
-#: ../vector/v.transform/main.c:72 ../vector/v.hull/main.c:53
-#: ../vector/v.buffer/main.c:225
-msgid "geometry"
+#: ../vector/v.in.ogr/main.c:233
+msgid "Optionally change default input type"
 msgstr ""
-#: ../locale/scriptstrings/v.to.lines_to_translate.c:5
-#: ../locale/scriptstrings/v.dissolve_to_translate.c:5
-#: ../locale/scriptstrings/v.in.lines_to_translate.c:4
-#: ../vector/v.category/main.c:683 ../vector/v.edit/main.c:57
-#: ../vector/v.type/main.c:42 ../vector/v.build.polylines/main.c:113
-#: ../vector/v.parallel/main.c:52 ../vector/v.to.points/main.c:56
-#: ../vector/v.buffer/main.c:226
-msgid "line"
-msgstr "līnija"
-#: ../locale/scriptstrings/v.to.lines_to_translate.c:6
-#: ../locale/scriptstrings/v.in.lines_to_translate.c:5
-#: ../vector/v.category/main.c:679 ../vector/v.segment/main.c:63
-#: ../vector/v.edit/main.c:59 ../vector/v.type/main.c:43
-#: ../vector/v.to.points/main.c:59
-msgid "point"
-msgstr "punkts"
-#: ../locale/scriptstrings/v.to.lines_to_translate.c:7
-msgid "Method used for point interpolation"
+#: ../vector/v.in.ogr/main.c:237
+msgid "import area centroids as points"
 msgstr ""
-#: ../locale/scriptstrings/v.to.lines_to_translate.c:8
-#: ../locale/scriptstrings/r.reclass.area_to_translate.c:6
-#: ../locale/scriptstrings/r.reclass.area_to_translate.c:8
-#: ../locale/scriptstrings/r.reclass.area_to_translate.c:10
-msgid "Area"
+#: ../vector/v.in.ogr/main.c:238
+msgid "import area boundaries as lines"
 msgstr ""
-#: ../locale/scriptstrings/db.in.ogr_to_translate.c:1
-msgid "Imports attribute tables in various formats."
+#: ../vector/v.in.ogr/main.c:239
+msgid "import lines as area boundaries"
 msgstr ""
-#: ../locale/scriptstrings/db.in.ogr_to_translate.c:5
-msgid "Table file to be imported or DB connection string"
+#: ../vector/v.in.ogr/main.c:240
+msgid "import points as centroids"
 msgstr ""
-#: ../locale/scriptstrings/db.in.ogr_to_translate.c:6
-msgid "Name of table from given DB to be imported"
+#: ../vector/v.in.ogr/main.c:249
+#: ../locale/scriptstrings/v.import_to_translate.c:17
+msgid "Snapping threshold for boundaries (map units)"
 msgstr ""
-#: ../locale/scriptstrings/db.in.ogr_to_translate.c:7
-msgid "Name for output table"
+#: ../vector/v.in.ogr/main.c:250
+msgid "'-1' for no snap"
 msgstr ""
-#: ../locale/scriptstrings/db.in.ogr_to_translate.c:8
-#: ../locale/scriptstrings/db.in.ogr_to_translate.c:10
-#: ../locale/scriptstrings/db.in.ogr_to_translate.c:13
-#: ../locale/scriptstrings/i.spectral_to_translate.c:10
-#: ../locale/scriptstrings/i.spectral_to_translate.c:12
-#: ../locale/scriptstrings/r.import_to_translate.c:12
-#: ../locale/scriptstrings/r.import_to_translate.c:15
-#: ../locale/scriptstrings/r.import_to_translate.c:18
-#: ../locale/scriptstrings/r.import_to_translate.c:21
-#: ../locale/scriptstrings/r.import_to_translate.c:23
-#: ../locale/scriptstrings/v.import_to_translate.c:10
-#: ../locale/scriptstrings/v.import_to_translate.c:13
-#: ../locale/scriptstrings/v.import_to_translate.c:16
-#: ../locale/scriptstrings/v.import_to_translate.c:19
-#: ../locale/scriptstrings/g.search.modules_to_translate.c:7
-#: ../locale/scriptstrings/g.search.modules_to_translate.c:9
-#: ../locale/scriptstrings/g.search.modules_to_translate.c:11
-#: ../locale/scriptstrings/g.search.modules_to_translate.c:14
-#: ../locale/scriptstrings/g.search.modules_to_translate.c:16
-#: ../locale/scriptstrings/g.search.modules_to_translate.c:18
-#: ../locale/scriptstrings/g.search.modules_to_translate.c:20
-#: ../locale/scriptstrings/m.proj_to_translate.c:11
-#: ../locale/scriptstrings/m.proj_to_translate.c:23
-#: ../locale/scriptstrings/m.proj_to_translate.c:25
-#: ../locale/scriptstrings/m.proj_to_translate.c:27
-#: ../raster3d/r3.flow/main.c:211 ../raster3d/r3.flow/main.c:218
-#: ../raster3d/r3.in.lidar/main.c:190 ../raster3d/r3.in.lidar/main.c:196
-#: ../raster3d/r3.in.lidar/main.c:202 ../raster/r.in.xyz/main.c:297
-#: ../raster/r.resamp.rst/main.c:174 ../raster/r.resamp.rst/main.c:180
-#: ../raster/r.resamp.rst/main.c:186 ../raster/r.resamp.rst/main.c:192
-#: ../raster/r.resamp.rst/main.c:198 ../raster/r.resamp.rst/main.c:204
-#: ../raster/r.resamp.rst/main.c:264 ../raster/r.sun/main.c:391
-#: ../raster/r.sun/main.c:400 ../raster/r.sun/main.c:409
-#: ../raster/r.sun/main.c:418 ../raster/r.sun/main.c:427
-#: ../raster/r.sun/main.c:436 ../raster/r.spread/main.c:277
-#: ../raster/r.spread/main.c:289 ../raster/r.spread/main.c:301
-#: ../raster/r.lake/main.c:167 ../raster/r.lake/main.c:195
-#: ../raster/r.sim/r.sim.sediment/main.c:178
-#: ../raster/r.sim/r.sim.sediment/main.c:185
-#: ../raster/r.sim/r.sim.sediment/main.c:192
-#: ../raster/r.sim/r.sim.sediment/main.c:198
-#: ../raster/r.sim/r.sim.sediment/main.c:205
-#: ../raster/r.sim/r.sim.sediment/main.c:212
-#: ../raster/r.sim/r.sim.sediment/main.c:219
-#: ../raster/r.sim/r.sim.water/main.c:197
-#: ../raster/r.sim/r.sim.water/main.c:203
-#: ../raster/r.sim/r.sim.water/main.c:209
-#: ../raster/r.sim/r.sim.water/main.c:216
-#: ../raster/r.sim/r.sim.water/main.c:223
-#: ../raster/r.sim/r.sim.water/main.c:298 ../raster/r.grow.distance/main.c:162
-#: ../raster/r.grow.distance/main.c:168 ../raster/r.in.lidar/main.c:126
-#: ../raster/r.in.lidar/main.c:252 ../raster/r.in.lidar/main.c:285
-#: ../raster/r.in.lidar/main.c:294 ../vector/v.out.ascii/args.c:35
-#: ../vector/v.out.ascii/args.c:81 ../vector/v.in.ogr/main.c:165
-#: ../vector/v.in.ogr/main.c:220 ../vector/v.in.ogr/main.c:270
-#: ../vector/v.in.ogr/main.c:276 ../vector/v.in.ogr/main.c:318
-msgid "Output"
-msgstr "Izvade"
+#: ../vector/v.in.ogr/main.c:256 ../vector/v.in.lidar/main.c:272
+#: ../raster/r.in.gdal/main.c:171
+msgid "Name for new location to create"
+msgstr "Janveidojamā novietojuma nosaukums"
-#: ../locale/scriptstrings/db.in.ogr_to_translate.c:9
-msgid "Name for auto-generated unique key column"
+#: ../vector/v.in.ogr/main.c:262
+msgid ""
+"List of column names to be used instead of original names, first is used for "
+"category column"
 msgstr ""
+#: ../vector/v.in.ogr/main.c:264 ../vector/v.in.ogr/main.c:274
+#: ../vector/v.in.ogr/main.c:284 ../vector/v.in.ogr/main.c:317
+#: ../vector/v.in.ogr/main.c:349 ../vector/v.extract/main.c:93
+#: ../vector/v.extract/main.c:145 ../vector/v.buffer/main.c:306
+#: ../vector/v.generalize/main.c:243 ../vector/v.overlay/main.c:135
+#: ../vector/v.overlay/main.c:145 ../vector/v.to.rast/main.c:88
+#: ../vector/v.to.rast/main.c:94 ../vector/v.to.rast/main.c:100
+#: ../raster/r.to.vect/main.c:106 ../raster/r.to.vect/main.c:113
+msgid "Attributes"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:271
+#: ../locale/scriptstrings/v.import_to_translate.c:14
 #: ../locale/scriptstrings/db.in.ogr_to_translate.c:11
-#: ../locale/scriptstrings/v.import_to_translate.c:14
-#: ../vector/v.in.ogr/main.c:233
 msgid "Encoding value for attribute data"
 msgstr ""
-#: ../locale/scriptstrings/db.in.ogr_to_translate.c:12
-msgid "Overrides encoding interpretation, useful when importing DBF tables"
+#: ../vector/v.in.ogr/main.c:273
+#: ../locale/scriptstrings/v.import_to_translate.c:15
+msgid "Overrides encoding interpretation, useful when importing ESRI Shapefile"
 msgstr ""
-#: ../locale/scriptstrings/r.blend_to_translate.c:1
-msgid "Blends color components of two raster maps by a given ratio."
+#: ../vector/v.in.ogr/main.c:281
+msgid "Name of column used for categories"
 msgstr ""
-#: ../locale/scriptstrings/r.blend_to_translate.c:3
-#: ../raster/r.composite/main.c:73
-msgid "composite"
+#: ../vector/v.in.ogr/main.c:283
+msgid ""
+"If not given, categories are generated as unique values and stored in 'cat' "
+"column"
 msgstr ""
-#: ../locale/scriptstrings/r.blend_to_translate.c:4
-msgid "Name of first raster map for blending"
+#: ../vector/v.in.ogr/main.c:288
+msgid "Name of geometry column"
 msgstr ""
-#: ../locale/scriptstrings/r.blend_to_translate.c:5
-msgid "Name of second raster map for blending"
+#: ../vector/v.in.ogr/main.c:289
+msgid "If not given, all geometry columns from the input are used"
 msgstr ""
-#: ../locale/scriptstrings/r.blend_to_translate.c:6
-msgid "Basename for red, green and blue output raster maps"
+#: ../vector/v.in.ogr/main.c:294
+#: ../locale/scriptstrings/v.import_to_translate.c:25
+msgid "List supported OGR formats and exit"
 msgstr ""
-#: ../locale/scriptstrings/r.blend_to_translate.c:7
-msgid "Percentage weight of first map for color blending"
+#: ../vector/v.in.ogr/main.c:300
+#: ../locale/scriptstrings/v.import_to_translate.c:26
+msgid "List available OGR layers in data source and exit"
 msgstr ""
-#: ../locale/scriptstrings/r.blend_to_translate.c:8
-msgid "Combine resulting R,G,B layers into single output map"
+#: ../vector/v.in.ogr/main.c:307
+msgid "Do not clean polygons (not recommended)"
 msgstr ""
-#: ../locale/scriptstrings/db.univar_to_translate.c:1
-msgid "Calculates univariate statistics on selected table column."
+#: ../vector/v.in.ogr/main.c:312
+msgid "Force 2D output even if input is 3D"
 msgstr ""
-#: ../locale/scriptstrings/db.univar_to_translate.c:3
-#: ../locale/scriptstrings/v.rast.stats_to_translate.c:3
-#: ../locale/scriptstrings/r.reclass.area_to_translate.c:3
-#: ../locale/scriptstrings/t.rast.univar_to_translate.c:3
-#: ../locale/scriptstrings/d.correlate_to_translate.c:3
-#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:6
-#: ../locale/scriptstrings/i.oif_to_translate.c:4
-#: ../locale/scriptstrings/v.report_to_translate.c:4
-#: ../locale/scriptstrings/v.db.univar_to_translate.c:3
-#: ../locale/scriptstrings/t.rast3d.univar_to_translate.c:3
-#: ../locale/scriptstrings/t.vect.univar_to_translate.c:3
-#: ../raster3d/r3.neighbors/main.c:211 ../raster3d/r3.stats/main.c:49
-#: ../raster3d/r3.in.lidar/main.c:165 ../raster/r.mode/main.c:56
-#: ../raster/r.in.xyz/main.c:160 ../raster/r.univar/r3.univar_main.c:99
-#: ../raster/r.univar/r.univar_main.c:105 ../raster/r.surf.area/main.c:78
-#: ../raster/r.texture/main.c:104 ../raster/r.clump/main.c:59
-#: ../raster/r.quantile/main.c:264 ../raster/r.neighbors/main.c:169
-#: ../raster/r.stats.zonal/main.c:102 ../raster/r.report/main.c:68
-#: ../raster/r.cross/main.c:70 ../raster/r.support.stats/main.c:39
-#: ../raster/r.stats.quantile/main.c:517 ../raster/r.regression.line/main.c:47
-#: ../raster/r.quant/main.c:48 ../raster/r.statistics/main.c:56
-#: ../raster/r.kappa/main.c:69 ../raster/r.covar/main.c:52
-#: ../raster/r.mfilter/main.c:58 ../raster/r.in.lidar/main.c:111
-#: ../raster/r.stats/main.c:107 ../raster/r.regression.multi/main.c:129
-#: ../raster/r.coin/main.c:67 ../display/d.histogram/main.c:85
-#: ../vector/v.random/main.c:99 ../vector/v.class/main.c:48
-#: ../vector/v.univar/main.c:93 ../vector/v.qcount/main.c:61
-#: ../vector/v.kcv/main.c:56 ../vector/v.outlier/main.c:70
-#: ../vector/v.perturb/main.c:64 ../vector/v.neighbors/main.c:52
-#: ../vector/v.normal/main.c:73 ../imagery/i.cca/main.c:85
-msgid "statistics"
+#: ../vector/v.in.ogr/main.c:313 ../vector/v.out.ogr/args.c:114
+#: ../vector/v.out.postgis/args.c:78
+msgid "Useful if input is 3D but all z coordinates are identical"
 msgstr ""
-#: ../locale/scriptstrings/db.univar_to_translate.c:5
-#: ../locale/scriptstrings/v.db.univar_to_translate.c:5
-msgid "Name of attribute column on which to calculate statistics (must be numeric)"
+#: ../vector/v.in.ogr/main.c:322 ../vector/v.in.lidar/main.c:321
+#: ../vector/v.external/args.c:45 ../raster/r.external/main.c:102
+#: ../raster/r.in.lidar/main.c:300 ../raster/r.in.gdal/main.c:185
+#: ../locale/scriptstrings/v.import_to_translate.c:27
+#: ../locale/scriptstrings/r.import_to_translate.c:31
+#: ../locale/scriptstrings/v.unpack_to_translate.c:9
+#: ../locale/scriptstrings/t.rast.import_to_translate.c:18
+#: ../locale/scriptstrings/t.vect.import_to_translate.c:14
+#: ../locale/scriptstrings/r.unpack_to_translate.c:8
+#: ../raster3d/r3.in.lidar/main.c:293
+msgid "Override projection check (use current location's projection)"
 msgstr ""
-#: ../locale/scriptstrings/db.univar_to_translate.c:6
-#: ../locale/scriptstrings/v.db.univar_to_translate.c:6
-#: ../raster/r.univar/r3.univar_main.c:52 ../raster/r.univar/r.univar_main.c:52
-#: ../vector/v.univar/main.c:122
-msgid "Percentile to calculate (requires extended statistics flag)"
+#: ../vector/v.in.ogr/main.c:324 ../vector/v.external/args.c:47
+#: ../locale/scriptstrings/v.import_to_translate.c:28
+#: ../locale/scriptstrings/r.import_to_translate.c:32
+msgid "Assume that the dataset has the same projection as the current location"
 msgstr ""
-#: ../locale/scriptstrings/db.univar_to_translate.c:7
-#: ../locale/scriptstrings/v.db.univar_to_translate.c:7
-msgid "Extended statistics (quartiles and 90th percentile)"
+#: ../vector/v.in.ogr/main.c:329 ../vector/v.external/args.c:52
+#: ../raster/r.external/main.c:109 ../raster/r.in.gdal/main.c:193
+msgid "Perform projection check only and exit"
 msgstr ""
-#: ../locale/scriptstrings/db.univar_to_translate.c:8
-#: ../locale/scriptstrings/v.db.univar_to_translate.c:8
-msgid "Print stats in shell script style"
+#: ../vector/v.in.ogr/main.c:336 ../vector/v.in.lidar/main.c:284
+#: ../raster/r.in.gdal/main.c:235
+msgid "Limit import to the current region"
 msgstr ""
-#: ../locale/scriptstrings/t.rast.mapcalc_to_translate.c:1
-msgid "Performs spatio-temporal mapcalc expressions on temporally sampled maps of space time raster datasets."
+#: ../vector/v.in.ogr/main.c:341 ../vector/v.in.lidar/main.c:302
+#: ../raster/r.external/main.c:114 ../raster/r.in.gdal/main.c:200
+msgid "Extend region extents based on new dataset"
 msgstr ""
-#: ../locale/scriptstrings/t.rast.mapcalc_to_translate.c:3
-#: ../locale/scriptstrings/t.rast3d.algebra_to_translate.c:3
-#: ../locale/scriptstrings/t.rast3d.mapcalc_to_translate.c:3
-#: ../locale/scriptstrings/t.vect.algebra_to_translate.c:3
-#: ../locale/scriptstrings/t.rast.algebra_to_translate.c:3
-#: ../raster3d/r3.neighbors/main.c:209 ../raster/r.mode/main.c:57
-#: ../raster/r.texture/main.c:103 ../raster/r.quantile/main.c:263
-#: ../raster/r.neighbors/main.c:168 ../raster/r.mfilter/main.c:57
-#: ../raster/r.mapcalc/main.c:70 ../vector/v.neighbors/main.c:51
-msgid "algebra"
+#: ../vector/v.in.ogr/main.c:343 ../raster/r.external/main.c:115
+#: ../raster/r.in.gdal/main.c:202
+msgid "Also updates the default region if in the PERMANENT mapset"
 msgstr ""
-#: ../locale/scriptstrings/t.rast.mapcalc_to_translate.c:6
-#: ../locale/scriptstrings/t.vect.algebra_to_translate.c:6
-msgid "Spatio-temporal mapcalc expression"
+#: ../vector/v.in.ogr/main.c:348
+msgid "Change column names to lowercase characters"
 msgstr ""
-#: ../locale/scriptstrings/t.rast.mapcalc_to_translate.c:7
-msgid "Basename for output raster maps"
+#: ../vector/v.in.ogr/main.c:354 ../vector/v.in.lidar/main.c:328
+msgid ""
+"Create the location specified by the \"location\" parameter and exit. Do not "
+"import the vector data."
 msgstr ""
-#: ../locale/scriptstrings/t.rast.mapcalc_to_translate.c:8
-#: ../locale/scriptstrings/t.rast3d.algebra_to_translate.c:9
-#: ../locale/scriptstrings/t.rast.contour_to_translate.c:8
-#: ../locale/scriptstrings/t.rast3d.mapcalc_to_translate.c:9
-#: ../locale/scriptstrings/t.vect.algebra_to_translate.c:8
-#: ../locale/scriptstrings/t.rast.gapfill_to_translate.c:7
-#: ../locale/scriptstrings/t.rast.aggregate.ds_to_translate.c:9
-#: ../locale/scriptstrings/t.rast.accdetect_to_translate.c:15
-#: ../locale/scriptstrings/t.rast.neighbors_to_translate.c:9
-#: ../locale/scriptstrings/t.rast.algebra_to_translate.c:8
-#: ../locale/scriptstrings/t.rast.extract_to_translate.c:8
-#: ../locale/scriptstrings/t.rast.import_to_translate.c:7
-#: ../locale/scriptstrings/t.rast.to.vect_to_translate.c:9
-#: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:14
-#: ../locale/scriptstrings/t.vect.extract_to_translate.c:7
-#: ../locale/scriptstrings/t.vect.import_to_translate.c:7
-msgid "A numerical suffix separated by an underscore will be attached to create a unique identifier"
+#: ../vector/v.in.ogr/main.c:479 ../vector/v.external/main.c:151
+#, c-format
+msgid "Unable to open data source <%s>"
 msgstr ""
-#: ../locale/scriptstrings/t.rast.mapcalc_to_translate.c:9
-#: ../locale/scriptstrings/t.rast.aggregate.ds_to_translate.c:13
-#: ../locale/scriptstrings/t.rast.algebra_to_translate.c:9
-#: ../locale/scriptstrings/t.rast.extract_to_translate.c:10
-msgid "Number of r.mapcalc processes to run in parallel"
+#: ../vector/v.in.ogr/main.c:484
+#, c-format
+msgid "Using OGR driver '%s/%s'"
 msgstr ""
-#: ../locale/scriptstrings/t.rast.mapcalc_to_translate.c:10
-#: ../locale/scriptstrings/t.rast3d.algebra_to_translate.c:12
-#: ../locale/scriptstrings/t.rast3d.extract_to_translate.c:11
-#: ../locale/scriptstrings/t.rast3d.mapcalc_to_translate.c:11
-#: ../locale/scriptstrings/t.rast.aggregate_to_translate.c:14
-#: ../locale/scriptstrings/t.rast.aggregate.ds_to_translate.c:14
-#: ../locale/scriptstrings/t.rast.neighbors_to_translate.c:12
-#: ../locale/scriptstrings/t.rast.algebra_to_translate.c:11
-#: ../locale/scriptstrings/t.rast.extract_to_translate.c:11
-msgid "Register Null maps"
+#: ../vector/v.in.ogr/main.c:488
+#, c-format
+msgid "Using OGR driver '%s'"
 msgstr ""
-#: ../locale/scriptstrings/t.rast.mapcalc_to_translate.c:11
-#: ../locale/scriptstrings/t.rast3d.algebra_to_translate.c:11
-#: ../locale/scriptstrings/t.rast3d.mapcalc_to_translate.c:12
-#: ../locale/scriptstrings/t.vect.algebra_to_translate.c:9
-#: ../locale/scriptstrings/t.rast.algebra_to_translate.c:10
-msgid "Check the spatial topology of temporally related maps and process only spatially related maps"
+#: ../vector/v.in.ogr/main.c:506
+msgid "Using interleaved reading mode"
 msgstr ""
-#: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:1
-msgid "Reconnects attribute tables for all vector maps from the current mapset to a new database."
+#: ../vector/v.in.ogr/main.c:512 ../vector/v.in.ogr/main.c:516
+#, c-format
+msgid ""
+"Option <%s> will be ignored. OGR doesn't support it for selected format (%s)."
 msgstr ""
-#: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:5
-msgid "Copy attribute tables to the target database if not exist"
+#: ../vector/v.in.ogr/main.c:522
+#, c-format
+msgid ""
+"Option <%s> will be ignored. Multiple geometry fields are supported by GDAL "
+">= 1.11"
 msgstr ""
-#: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:6
-msgid "Delete attribute tables from the source database"
+#: ../vector/v.in.ogr/main.c:532
+#, c-format
+msgid "Encoding value not supported by OGR driver <%s>"
 msgstr ""
-#: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:7
-msgid "Name of source database"
+#: ../vector/v.in.ogr/main.c:542
+msgid "No OGR layers available"
 msgstr ""
-#: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:8
-msgid "Name of source database schema"
+#: ../vector/v.in.ogr/main.c:549
+#, c-format
+msgid "Data source <%s> (format '%s') contains %d layers:"
 msgstr ""
-#: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:9
-msgid "Name for target driver"
+#: ../vector/v.in.ogr/main.c:588 ../vector/v.external/main.c:124
+#, c-format
+msgid "Layer <%s> not available"
 msgstr ""
-#: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:10
-msgid "Name for target database"
+#: ../vector/v.in.ogr/main.c:602
+msgid ""
+"Detected different projections of input layers. Input layers must be "
+"imported separately."
 msgstr ""
-#: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:11
-msgid "Name for target database schema"
-msgstr ""
+#: ../vector/v.in.ogr/main.c:642
+#, fuzzy, c-format
+msgid "Illegal output name <%s>"
+msgstr "Nederīga x koordināta <%s>"
-msgid "Displays spectral response at user specified locations in group or images."
+#: ../vector/v.in.ogr/main.c:648 ../vector/v.in.lidar/main.c:545
+#: ../vector/v.edit/main.c:99 ../scripts/v.unpack/v.unpack.py:117
+#, c-format, python-format
+msgid "Vector map <%s> already exists"
 msgstr ""
-#: ../locale/scriptstrings/i.spectral_to_translate.c:3
-#: ../locale/scriptstrings/v.rast.stats_to_translate.c:8
-#: ../locale/scriptstrings/v.what.vect_to_translate.c:6
-#: ../locale/scriptstrings/v.what.strds_to_translate.c:6
-#: ../raster/r.what.color/main.c:89 ../raster/r.what/main.c:99
-#: ../display/d.where/main.c:46 ../vector/v.what.rast3/main.c:68
-#: ../vector/v.what.rast/main.c:75 ../vector/v.what/main.c:63
-msgid "querying"
+#: ../vector/v.in.ogr/main.c:663
+#, c-format
+msgid "All available OGR layers will be imported into vector map <%s>"
 msgstr ""
-#: ../locale/scriptstrings/i.spectral_to_translate.c:5
-#: ../locale/scriptstrings/i.oif_to_translate.c:3
-msgid "multispectral"
+#: ../vector/v.in.ogr/main.c:672
+msgid ""
+"When creating a new location, the current region can not be used as spatial "
+"filter, disabling"
 msgstr ""
-#: ../locale/scriptstrings/i.spectral_to_translate.c:6
-#: ../locale/scriptstrings/i.spectral_to_translate.c:7
-#: ../locale/scriptstrings/i.spectral_to_translate.c:8
-#: ../locale/scriptstrings/r.import_to_translate.c:6
-#: ../locale/scriptstrings/r.import_to_translate.c:8
-#: ../locale/scriptstrings/v.import_to_translate.c:6
-#: ../locale/scriptstrings/v.import_to_translate.c:8
-#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:18
-#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:20
-#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:22
-#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:24
-#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:27
-#: ../locale/scriptstrings/t.remove_to_translate.c:6
-#: ../locale/scriptstrings/t.remove_to_translate.c:9
-#: ../locale/scriptstrings/t.remove_to_translate.c:11
-#: ../locale/scriptstrings/t.register_to_translate.c:6
-#: ../locale/scriptstrings/t.register_to_translate.c:7
-#: ../locale/scriptstrings/t.register_to_translate.c:9
-#: ../locale/scriptstrings/t.register_to_translate.c:12
-#: ../locale/scriptstrings/t.register_to_translate.c:26
-#: ../raster3d/r3.flow/main.c:188 ../raster3d/r3.flow/main.c:195
-#: ../raster3d/r3.flow/main.c:205 ../raster3d/r3.in.lidar/main.c:177
-#: ../raster3d/r3.in.lidar/main.c:184 ../raster/r.in.xyz/main.c:213
-#: ../raster/r.in.xyz/main.c:222 ../raster/r.in.xyz/main.c:230
-#: ../raster/r.in.xyz/main.c:241 ../raster/r.in.xyz/main.c:251
-#: ../raster/r.sun/main.c:260 ../raster/r.sun/main.c:269
-#: ../raster/r.sun/main.c:278 ../raster/r.sun/main.c:287
-#: ../raster/r.sun/main.c:295 ../raster/r.sun/main.c:304
-#: ../raster/r.sun/main.c:313 ../raster/r.sun/main.c:322
-#: ../raster/r.sun/main.c:331 ../raster/r.sun/main.c:340
-#: ../raster/r.sun/main.c:349 ../raster/r.sun/main.c:358
-#: ../raster/r.sun/main.c:367 ../raster/r.sun/main.c:374
-#: ../raster/r.sun/main.c:382 ../raster/r.spread/main.c:125
-#: ../raster/r.spread/main.c:139 ../raster/r.spread/main.c:151
-#: ../raster/r.spread/main.c:164 ../raster/r.spread/main.c:177
-#: ../raster/r.spread/main.c:189 ../raster/r.spread/main.c:201
-#: ../raster/r.sim/r.sim.sediment/main.c:157
-#: ../raster/r.sim/r.sim.sediment/main.c:165
-#: ../raster/r.sim/r.sim.sediment/main.c:172
-#: ../raster/r.sim/r.sim.water/main.c:138
-#: ../raster/r.sim/r.sim.water/main.c:147
-#: ../raster/r.sim/r.sim.water/main.c:154
-#: ../raster/r.sim/r.sim.water/main.c:163
-#: ../raster/r.sim/r.sim.water/main.c:169
-#: ../raster/r.sim/r.sim.water/main.c:177
-#: ../raster/r.sim/r.sim.water/main.c:184
-#: ../raster/r.sim/r.sim.water/main.c:191 ../raster/r.horizon/main.c:195
-#: ../raster/r.horizon/main.c:204 ../raster/r.horizon/main.c:212
-#: ../raster/r.external/main.c:66 ../raster/r.external/main.c:74
-#: ../raster/r.external/main.c:83 ../raster/r.in.lidar/main.c:122
-#: ../raster/r.in.lidar/main.c:133 ../display/d.legend/main.c:88
-#: ../display/d.legend/main.c:93 ../display/d.text/main.c:148
-#: ../display/d.text/main.c:153 ../vector/v.edit/args.c:96
-#: ../vector/v.edit/args.c:215 ../vector/v.in.ogr/main.c:160
-msgid "Input"
+#: ../vector/v.in.ogr/main.c:677 ../vector/v.in.ogr/main.c:2015
+#: ../vector/v.in.lidar/main.c:450
+msgid "Select either the current region flag or the spatial option, not both"
 msgstr ""
-#: ../locale/scriptstrings/i.spectral_to_translate.c:9
-msgid "Name for output image (or text file for -t)"
-msgstr ""
+#: ../vector/v.in.ogr/main.c:690 ../vector/v.in.ogr/main.c:1881
+#, fuzzy, c-format
+msgid "Error setting attribute filter '%s'"
+msgstr "Kļūda rakstot krāsu failu priekš <%s@%s>!"
-#: ../locale/scriptstrings/i.spectral_to_translate.c:11
-msgid "Graphics format for output file"
+#: ../vector/v.in.ogr/main.c:730
+#, c-format
+msgid "Geometry column <%s> not found in OGR layer <%s>"
 msgstr ""
-#: ../locale/scriptstrings/i.spectral_to_translate.c:13
-msgid "Show sampling coordinates instead of numbering in the legend"
+#: ../vector/v.in.ogr/main.c:743
+#, c-format
+msgid "Check if OGR layer <%s> contains polygons..."
 msgstr ""
-#: ../locale/scriptstrings/i.spectral_to_translate.c:14
-msgid "Use gnuplot for display"
+#: ../vector/v.in.ogr/main.c:801
+#, c-format
+msgid "Boundary splitting distance in map units: %G"
 msgstr ""
-#: ../locale/scriptstrings/i.spectral_to_translate.c:15
-msgid "output to text file"
+#: ../vector/v.in.ogr/main.c:829 ../vector/v.buffer/main.c:414
+#: ../vector/v.overlay/main.c:227
+msgid "Unable to create temporary vector map"
 msgstr ""
-#: ../locale/scriptstrings/t.sample_to_translate.c:1
-msgid "Samples the input space time dataset(s) with a sample space time dataset and print the result to stdout."
+#: ../vector/v.in.ogr/main.c:831
+#, c-format
+msgid "Using temporary vector <%s>"
 msgstr ""
-#: ../locale/scriptstrings/t.sample_to_translate.c:3
-#: ../locale/scriptstrings/v.rast.stats_to_translate.c:7
-#: ../locale/scriptstrings/t.vect.observe.strds_to_translate.c:3
-#: ../locale/scriptstrings/v.what.vect_to_translate.c:3
-#: ../locale/scriptstrings/t.rast.what_to_translate.c:3
-#: ../locale/scriptstrings/v.what.strds_to_translate.c:4
-#: ../locale/scriptstrings/t.vect.what.strds_to_translate.c:3
-#: ../raster/r.random/main.c:52 ../raster/r.random.cells/main.c:48
-#: ../display/d.where/main.c:44 ../vector/v.what.rast3/main.c:65
-#: ../vector/v.extrude/main.c:69 ../vector/v.random/main.c:98
-#: ../vector/v.sample/main.c:76 ../vector/v.drape/main.c:58
-#: ../vector/v.what.rast/main.c:72
-msgid "sampling"
-msgstr ""
+#: ../vector/v.in.ogr/main.c:873
+#, fuzzy, c-format
+msgid "Key column '%s' not found in input layer <%s>"
-#: ../locale/scriptstrings/t.sample_to_translate.c:5
-msgid "Name of the sample space time dataset"
+#: ../vector/v.in.ogr/main.c:886
+#, c-format
+msgid "Key column '%s' in input layer <%s> is not integer"
 msgstr ""
-#: ../locale/scriptstrings/t.sample_to_translate.c:8
-msgid "Type of the sample space time dataset"
-msgstr ""
+#: ../vector/v.in.ogr/main.c:895
+#, fuzzy, c-format
+msgid "Creating attribute table for layer <%s>..."
+msgstr "Draiveris %s nav atrasts"
-#: ../locale/scriptstrings/t.sample_to_translate.c:9
-msgid "Field separator between output columns, default is tabular \" | \""
+#: ../vector/v.in.ogr/main.c:955
+#, c-format
+msgid "Column name <%s> renamed to <%s>"
 msgstr ""
-#: ../locale/scriptstrings/t.sample_to_translate.c:10
-msgid "Do not use \",\" as this char is reserved to list several map ids in a sample granule"
+#: ../vector/v.in.ogr/main.c:985
+#, c-format
+msgid "Writing column <%s> with integer 64 as integer 32"
 msgstr ""
-#: ../locale/scriptstrings/t.sample_to_translate.c:11
-#: ../locale/scriptstrings/t.list_to_translate.c:18
-msgid "Print the column names as first row"
+#: ../vector/v.in.ogr/main.c:998
+#, c-format
+msgid "Writing column <%s> with fixed length %d chars (may be truncated)"
 msgstr ""
-#: ../locale/scriptstrings/t.sample_to_translate.c:12
-msgid "Check for spatial topological overlap"
+#: ../vector/v.in.ogr/main.c:1021
+#, c-format
+msgid ""
+"Width for column %s set to 255 (was not specified by OGR), some strings may "
+"be truncated!"
 msgstr ""
-#: ../locale/scriptstrings/t.rast.out.vtk_to_translate.c:1
-msgid "Exports space time raster dataset as VTK time series."
+#: ../vector/v.in.ogr/main.c:1033
+#, c-format
+msgid "Writing column %s with fixed length %d chars (may be truncated)"
 msgstr ""
-#: ../locale/scriptstrings/t.rast.out.vtk_to_translate.c:5
-msgid "VTK"
+#: ../vector/v.in.ogr/main.c:1037
+#, c-format
+msgid "Column type (Ogr_ftype: %d) not supported (Ogr_fieldname: %s)"
 msgstr ""
-#: ../locale/scriptstrings/t.rast.out.vtk_to_translate.c:7
-msgid "Path to the export directory"
-msgstr ""
+#: ../vector/v.in.ogr/main.c:1082
+#, fuzzy, c-format
+msgid "Importing %lld features (OGR layer <%s>)..."
+msgstr "Eksistējošas rastra kartes nosaukums"
-#: ../locale/scriptstrings/t.rast.out.vtk_to_translate.c:8
-#: ../raster/r.out.vtk/parameters.c:45
-msgid "Value to represent no data cell"
-msgstr ""
+#: ../vector/v.in.ogr/main.c:1245
+#, fuzzy, c-format
+msgid "Cannot insert new row for input layer <%s>: %s"
+msgstr "Nevar izveidot jaunu rindu: %s"
-#: ../locale/scriptstrings/t.rast.out.vtk_to_translate.c:9
-#: ../raster/r.out.vtk/parameters.c:59
-msgid "Create VTK point data instead of VTK cell data (if no elevation map is given)"
+#: ../vector/v.in.ogr/main.c:1261
+#, c-format
+msgid "%d %s without geometry in input layer <%s> skipped"
 msgstr ""
-#: ../locale/scriptstrings/t.rast.out.vtk_to_translate.c:10
-#: ../vector/v.out.vtk/main.c:84
-msgid "Correct the coordinates to fit the VTK-OpenGL precision"
-msgstr ""
+#: ../vector/v.in.ogr/main.c:1262
+#, fuzzy
+msgid "feature"
+msgstr "Objektu tips"
-#: ../locale/scriptstrings/t.rast.out.vtk_to_translate.c:11
-msgid "Export files using the space time dataset granularity for equidistant time between maps, where statement will be ignored"
-msgstr ""
+#, fuzzy
+msgid "features"
-#: ../locale/scriptstrings/v.rast.stats_to_translate.c:1
-msgid "Calculates univariate statistics from a raster map based on a vector map and uploads statistics to new attribute columns."
+#: ../vector/v.in.ogr/main.c:1286
+#, c-format
+msgid "Unable to drop table: '%s'"
 msgstr ""
-#: ../locale/scriptstrings/v.rast.stats_to_translate.c:5
-#: ../raster/r.univar/r3.univar_main.c:100
-#: ../raster/r.univar/r.univar_main.c:106 ../vector/v.univar/main.c:94
-#: ../vector/v.vect.stats/main.c:127
-msgid "univariate statistics"
+#: ../vector/v.in.ogr/main.c:1321
+msgid "Cleaning polygons"
 msgstr ""
-#: ../locale/scriptstrings/v.rast.stats_to_translate.c:6
-#: ../raster/r.univar/r.univar_main.c:107 ../raster/r.stats.zonal/main.c:103
-#: ../raster/r.statistics/main.c:57 ../vector/v.vect.stats/main.c:128
-msgid "zonal statistics"
+#: ../vector/v.in.ogr/main.c:1325
+#, c-format
+msgid "Snapping boundaries (threshold = %.3e)..."
 msgstr ""
-#: ../locale/scriptstrings/v.rast.stats_to_translate.c:9
-msgid "Continue if upload column(s) already exist"
+#: ../vector/v.in.ogr/main.c:1341 ../vector/v.buffer/main.c:752
+msgid "Breaking polygons..."
 msgstr ""
-#: ../locale/scriptstrings/v.rast.stats_to_translate.c:10
-msgid "Name of input raster map to calculate statistics from"
+#: ../vector/v.in.ogr/main.c:1346 ../vector/v.in.ogr/main.c:1360
+#: ../vector/v.buffer/main.c:755 ../vector/v.buffer/main.c:762
+#: ../vector/v.overlay/area_area.c:113 ../vector/v.delaunay/main.c:144
+msgid "Removing duplicates..."
 msgstr ""
-#: ../locale/scriptstrings/v.rast.stats_to_translate.c:11
-msgid "Column prefix for new attribute columns"
+#: ../vector/v.in.ogr/main.c:1356 ../vector/v.buffer/main.c:759
+msgid "Breaking boundaries..."
 msgstr ""
-#: ../locale/scriptstrings/v.rast.stats_to_translate.c:12
-msgid "The methods to use"
+#: ../vector/v.in.ogr/main.c:1364 ../vector/v.overlay/area_area.c:116
+msgid "Cleaning boundaries at nodes..."
 msgstr ""
-#: ../locale/scriptstrings/v.rast.stats_to_translate.c:13
-msgid "Percentile to calculate"
+#: ../vector/v.in.ogr/main.c:1371
+msgid "Merging boundaries..."
 msgstr ""
-msgid "Lists space time datasets and maps registered in the temporal database."
+#: ../vector/v.in.ogr/main.c:1376
+msgid "Changing boundary dangles to lines..."
 msgstr ""
-#: ../locale/scriptstrings/t.list_to_translate.c:6
-msgid "Type of the space time dataset or map, default is strds"
+#: ../vector/v.in.ogr/main.c:1389
+msgid "Changing boundary bridges to lines..."
 msgstr ""
-#: ../locale/scriptstrings/t.list_to_translate.c:9
-#: ../locale/scriptstrings/t.list_to_translate.c:12
-msgid "Columns number_of_maps and granularity only available for space time datasets"
+#: ../vector/v.in.ogr/main.c:1418 ../vector/v.category/main.c:364
+#: ../vector/v.delaunay/main.c:172
+msgid "Unable to calculate area centroid"
 msgstr ""
-#: ../locale/scriptstrings/t.list_to_translate.c:10
-#: ../locale/scriptstrings/t.rast.list_to_translate.c:7
-#: ../locale/scriptstrings/t.vect.list_to_translate.c:7
-msgid "Sort the space time dataset by category"
+#: ../vector/v.in.ogr/main.c:1435
+#, c-format
+msgid "Finding centroids for OGR layer <%s>..."
 msgstr ""
-msgid "Apply temporal and spatial operations on space time 3D raster datasets using temporal 3D raster algebra."
+#: ../vector/v.in.ogr/main.c:1492 ../vector/v.overlay/area_area.c:218
+msgid "Writing centroids..."
 msgstr ""
-#: ../locale/scriptstrings/t.rast3d.algebra_to_translate.c:7
-msgid "Algebraic expression for temporal and spatial analysis of space time 3D raster datasets"
+#: ../vector/v.in.ogr/main.c:1535
+#, c-format
+msgid ""
+"%d areas represent more (overlapping) features, because polygons overlap in "
+"input layer(s). Such areas are linked to more than 1 row in attribute table. "
+"The number of features for those areas is stored as category in layer %d"
 msgstr ""
-#: ../locale/scriptstrings/t.rast3d.algebra_to_translate.c:8
-#: ../locale/scriptstrings/t.rast.contour_to_translate.c:7
-#: ../locale/scriptstrings/t.rast3d.mapcalc_to_translate.c:8
-#: ../locale/scriptstrings/t.vect.algebra_to_translate.c:7
-#: ../locale/scriptstrings/t.rast.gapfill_to_translate.c:6
-#: ../locale/scriptstrings/t.rast.aggregate_to_translate.c:6
-#: ../locale/scriptstrings/t.rast.aggregate.ds_to_translate.c:8
-#: ../locale/scriptstrings/t.rast.accdetect_to_translate.c:14
-#: ../locale/scriptstrings/t.rast.neighbors_to_translate.c:8
-#: ../locale/scriptstrings/t.rast.algebra_to_translate.c:7
-#: ../locale/scriptstrings/t.rast.extract_to_translate.c:7
-#: ../locale/scriptstrings/t.rast.import_to_translate.c:6
-#: ../locale/scriptstrings/t.rast.to.vect_to_translate.c:8
-#: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:13
-#: ../locale/scriptstrings/t.vect.extract_to_translate.c:6
-#: ../locale/scriptstrings/t.vect.import_to_translate.c:6
-msgid "Basename of the new generated output maps"
+#: ../vector/v.in.ogr/main.c:1545
+#, c-format
+msgid "%d input polygons\n"
 msgstr ""
-#: ../locale/scriptstrings/t.rast3d.algebra_to_translate.c:10
-#: ../locale/scriptstrings/t.rast3d.extract_to_translate.c:10
-#: ../locale/scriptstrings/t.rast3d.mapcalc_to_translate.c:10
-msgid "Number of r3.mapcalc processes to run in parallel"
+#: ../vector/v.in.ogr/main.c:1546
+#, c-format
+msgid "%d input polygons"
 msgstr ""
-#: ../locale/scriptstrings/t.rast3d.algebra_to_translate.c:13
-#: ../locale/scriptstrings/t.rast.algebra_to_translate.c:12
-msgid "Use granularity sampling instead of the temporal topology approach"
+#: ../vector/v.in.ogr/main.c:1549
+#, c-format
+msgid "Total area: %G (%d areas)\n"
 msgstr ""
-#: ../locale/scriptstrings/r.in.srtm_to_translate.c:1
-msgid "Imports SRTM HGT files into raster map."
+#: ../vector/v.in.ogr/main.c:1550
+#, c-format
+msgid "Total area: %G (%d areas)"
 msgstr ""
-#: ../locale/scriptstrings/r.in.srtm_to_translate.c:4
-msgid "Name of SRTM input tile (file without .hgt.zip extension)"
+#: ../vector/v.in.ogr/main.c:1553
+#, c-format
+msgid "Overlapping area: %G (%d areas)\n"
 msgstr ""
-#: ../locale/scriptstrings/r.in.srtm_to_translate.c:5
-msgid "Name for output raster map (default: input tile)"
+#: ../vector/v.in.ogr/main.c:1556
+#, c-format
+msgid "Overlapping area: %G (%d areas)"
 msgstr ""
-#: ../locale/scriptstrings/r.in.srtm_to_translate.c:6
-msgid "Input is a 1-arcsec tile (default: 3-arcsec)"
+#: ../vector/v.in.ogr/main.c:1561
+#, c-format
+msgid "Area without category: %G (%d areas)\n"
 msgstr ""
-#: ../locale/scriptstrings/d.redraw_to_translate.c:1
-msgid "Redraws the content of currently selected monitor."
+#: ../vector/v.in.ogr/main.c:1564
+#, c-format
+msgid "Area without category: %G (%d areas)"
 msgstr ""
-#: ../locale/scriptstrings/d.redraw_to_translate.c:4
-#: ../locale/scriptstrings/d.frame_to_translate.c:4 ../display/d.mon/main.c:40
-#: ../display/d.info/main.c:36 ../display/d.erase/main.c:31
-msgid "monitors"
+#: ../vector/v.in.ogr/main.c:1686
+msgid "The output contains topological errors:"
 msgstr ""
-msgid "Extracts a subset of a space time 3D raster dataset."
-msgstr ""
+#: ../vector/v.in.ogr/main.c:1688
+#, fuzzy, c-format
+msgid "Unable to calculate a centroid for %d areas"
+msgstr "Nevar noteikt poligona centroīdu"
-#: ../locale/scriptstrings/t.rast3d.extract_to_translate.c:3
-#: ../locale/scriptstrings/t.rast.extract_to_translate.c:3
-#: ../locale/scriptstrings/t.vect.extract_to_translate.c:3
-#: ../vector/v.extract/main.c:78 ../vector/v.decimate/main.c:127
-#: ../vector/v.outlier/main.c:71
-msgid "extract"
-msgstr ""
+#: ../vector/v.in.ogr/main.c:1690
+#, fuzzy, c-format
+msgid "Number of incorrect boundaries: %d"
+msgstr "Punktu skaits: %d"
-#: ../locale/scriptstrings/t.rast3d.extract_to_translate.c:7
-msgid "The r3.mapcalc expression assigned to all extracted 3D raster maps"
-msgstr ""
+#: ../vector/v.in.ogr/main.c:1693
+#, fuzzy, c-format
+msgid "Number of centroids outside area: %d"
-#: ../locale/scriptstrings/t.rast3d.extract_to_translate.c:8
-msgid "Basename of the new generated 3D raster maps"
-msgstr ""
+#: ../vector/v.in.ogr/main.c:1696
+#, fuzzy, c-format
+msgid "Number of duplicate centroids: %d"
-#: ../locale/scriptstrings/t.rast3d.extract_to_translate.c:9
-#: ../locale/scriptstrings/t.rast.contour_to_translate.c:9
-#: ../locale/scriptstrings/t.rast.gapfill_to_translate.c:8
-#: ../locale/scriptstrings/t.rast.aggregate_to_translate.c:8
-#: ../locale/scriptstrings/t.rast.aggregate.ds_to_translate.c:10
-#: ../locale/scriptstrings/t.rast.neighbors_to_translate.c:10
-#: ../locale/scriptstrings/t.rast.extract_to_translate.c:9
-#: ../locale/scriptstrings/t.rast.to.vect_to_translate.c:10
-#: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:15
-#: ../locale/scriptstrings/t.vect.extract_to_translate.c:8
-msgid "Suffix to add at basename: set 'gran' for granularity, 'time' for the full time format, 'num' for numerical suffix with a specific number of digits (default %05)"
+#: ../vector/v.in.ogr/main.c:1699 ../vector/v.in.ogr/main.c:1721
+#: ../vector/v.in.ogr/main.c:1754
+msgid "The input could be cleaned by snapping vertices to each other."
 msgstr ""
-#: ../locale/scriptstrings/t.snap_to_translate.c:1
-msgid "Snaps temporally the maps of a space time dataset."
+#: ../vector/v.in.ogr/main.c:1702 ../vector/v.in.ogr/main.c:1725
+#: ../vector/v.in.ogr/main.c:1749 ../vector/v.in.ogr/main.c:1755
+#, c-format
+msgid "Estimated range of snapping threshold: [%g, %g]"
 msgstr ""
-#: ../locale/scriptstrings/t.snap_to_translate.c:3
-#: ../locale/scriptstrings/t.shift_to_translate.c:3
-#: ../locale/scriptstrings/t.merge_to_translate.c:3
-msgid "time management"
+#: ../vector/v.in.ogr/main.c:1706 ../vector/v.in.ogr/main.c:1729
+#, c-format
+msgid "Try to import again, snapping with at least %g: 'snap=%g'"
 msgstr ""
-#: ../locale/scriptstrings/t.snap_to_translate.c:4 ../vector/v.clean/main.c:54
-msgid "snapping"
+#: ../vector/v.in.ogr/main.c:1710 ../vector/v.in.ogr/main.c:1733
+#, c-format
+msgid "Try to import again, snapping with %g: 'snap=%g'"
 msgstr ""
-#: ../locale/scriptstrings/t.snap_to_translate.c:6
-#: ../locale/scriptstrings/t.shift_to_translate.c:6
-msgid "Name of an existing space time dataset"
+#: ../vector/v.in.ogr/main.c:1714 ../vector/v.in.ogr/main.c:1737
+msgid "Manual cleaning may be needed."
 msgstr ""
-#: ../locale/scriptstrings/t.rast.contour_to_translate.c:1
-msgid "Produces a space time vector dataset of specified contours from a space time raster dataset."
+#: ../vector/v.in.ogr/main.c:1719
+msgid "Some input polygons are overlapping each other."
 msgstr ""
-#: ../locale/scriptstrings/t.rast.contour_to_translate.c:3
-msgid "contour"
+#: ../vector/v.in.ogr/main.c:1720
+msgid "If overlapping is not desired, the data need to be cleaned."
 msgstr ""
-#: ../locale/scriptstrings/t.rast.contour_to_translate.c:10
-#: ../raster/r.contour/main.c:101
-msgid "Increment between contour levels"
+#: ../vector/v.in.ogr/main.c:1742
+#, c-format
+msgid "%d input polygons got lost during import."
 msgstr ""
-#: ../locale/scriptstrings/t.rast.contour_to_translate.c:11
-#: ../raster/r.contour/main.c:109
-msgid "List of contour levels"
+#: ../vector/v.in.ogr/main.c:1745
+#, c-format
+msgid "%d additional areas where created during import."
 msgstr ""
-#: ../locale/scriptstrings/t.rast.contour_to_translate.c:12
-#: ../raster/r.contour/main.c:116
-msgid "Minimum contour level"
+#: ../vector/v.in.ogr/main.c:1748
+#, c-format
+msgid "The snapping threshold %g might be too large."
 msgstr ""
-#: ../locale/scriptstrings/t.rast.contour_to_translate.c:13
-#: ../raster/r.contour/main.c:123
-msgid "Maximum contour level"
+#: ../vector/v.in.ogr/main.c:1751
+msgid "Try to reduce the snapping threshold or clean the output manually."
 msgstr ""
-#: ../locale/scriptstrings/t.rast.contour_to_translate.c:14
-#: ../raster/r.contour/main.c:132
-msgid "Minimum number of points for a contour line (0 -> no limit)"
+#: ../vector/v.in.ogr/main.c:1790 ../raster/r.external/window.c:93
+#: ../raster/r.in.gdal/main.c:881
+msgid "Default region for this location updated"
 msgstr ""
-#: ../locale/scriptstrings/t.rast.contour_to_translate.c:15
-msgid "Number of r.contour processes to run in parallel, more than 1 process works only in conjunction with flag -t"
+#: ../vector/v.in.ogr/main.c:1793 ../raster/r.external/window.c:96
+#: ../raster/r.in.gdal/main.c:884
+msgid "Region for the current mapset updated"
 msgstr ""
-#: ../locale/scriptstrings/t.rast.contour_to_translate.c:16
-#: ../locale/scriptstrings/t.rast.to.vect_to_translate.c:13
-msgid "Register empty vector maps"
+#: ../vector/v.in.ogr/main.c:1797
+msgid ""
+"Input data contains 3D features. Created vector is 2D only, disable -2 flag "
+"to import 3D vector."
 msgstr ""
-#: ../locale/scriptstrings/t.rast.contour_to_translate.c:17
-#: ../locale/scriptstrings/t.rast.to.vect_to_translate.c:14
-msgid "Do not create attribute tables"
+#: ../vector/v.in.ogr/main.c:1819
+#, c-format
+msgid "Using GDAL 2.2+ style interleaved reading for GDAL version %d"
 msgstr ""
-#: ../locale/scriptstrings/v.unpack_to_translate.c:1
-msgid "Imports a vector map as GRASS GIS specific archive file (packed with v.pack)"
+#: ../vector/v.in.ogr/main.c:1822
+#, c-format
+msgid "Using GDAL 1.x style interleaved reading for GDAL version %d"
 msgstr ""
-#: ../locale/scriptstrings/v.unpack_to_translate.c:5
-#: ../locale/scriptstrings/r.unpack_to_translate.c:5
-msgid "Name of input pack file"
-msgstr ""
+#: ../vector/v.in.ogr/main.c:1872
+#, fuzzy, c-format
+msgid "Unable to re-open data source <%s>"
+msgstr "neiespējami atvērt <%s>"
-#: ../locale/scriptstrings/v.unpack_to_translate.c:6
-msgid "Name for output vector map"
+#: ../vector/v.in.ogr/main.c:2042 ../vector/v.in.lidar/main.c:478
+msgid "4 parameters required for 'spatial' parameter"
 msgstr ""
-#: ../locale/scriptstrings/v.unpack_to_translate.c:7
-msgid "Default: taken from input file internals"
+#: ../vector/v.in.ogr/main.c:2044
+msgid "xmin is larger than xmax in 'spatial' parameters"
 msgstr ""
-#: ../locale/scriptstrings/v.unpack_to_translate.c:8
-#: ../locale/scriptstrings/v.unpack_to_translate.c:11
-#: ../locale/scriptstrings/r.unpack_to_translate.c:7
-#: ../locale/scriptstrings/r.unpack_to_translate.c:10
-#: ../raster/r.univar/r.univar_main.c:42 ../raster/r.kappa/main.c:90
-#: ../raster/r.kappa/main.c:98 ../ps/ps.map/main.c:100 ../ps/ps.map/main.c:113
-#: ../ps/ps.map/main.c:135
-msgid "Output settings"
-msgstr "Izvades iestatījumi"
-#: ../locale/scriptstrings/v.unpack_to_translate.c:9
-#: ../locale/scriptstrings/r.import_to_translate.c:31
-#: ../locale/scriptstrings/v.import_to_translate.c:27
-#: ../locale/scriptstrings/t.rast.import_to_translate.c:17
-#: ../locale/scriptstrings/r.unpack_to_translate.c:8
-#: ../locale/scriptstrings/t.vect.import_to_translate.c:13
-#: ../raster3d/r3.in.lidar/main.c:293 ../raster/r.external/main.c:102
-#: ../raster/r.in.gdal/main.c:180 ../raster/r.in.lidar/main.c:299
-#: ../vector/v.external/args.c:45 ../vector/v.in.ogr/main.c:284
-#: ../vector/v.in.lidar/main.c:319
-msgid "Override projection check (use current location's projection)"
+#: ../vector/v.in.ogr/main.c:2046
+msgid "ymin is larger than ymax in 'spatial' parameters"
 msgstr ""
-#: ../locale/scriptstrings/v.unpack_to_translate.c:10
-#: ../locale/scriptstrings/t.rast.import_to_translate.c:18
-#: ../locale/scriptstrings/r.unpack_to_translate.c:9
-#: ../locale/scriptstrings/t.vect.import_to_translate.c:14
-#: ../raster3d/r3.in.lidar/main.c:295 ../raster/r.external/main.c:104
-#: ../raster/r.in.gdal/main.c:182 ../raster/r.in.lidar/main.c:301
-#: ../vector/v.in.lidar/main.c:321
-msgid "Assume that the dataset has same projection as the current location"
+#: ../vector/v.in.ogr/main.c:2063
+#, c-format
+msgid ""
+"The spatial filter does not overlap with OGR layer <%s>. Nothing to import."
 msgstr ""
-msgid "Performs r3.mapcalc expressions on maps of sampled space time 3D raster datasets."
+#: ../vector/v.in.ogr/geom.c:76 ../vector/v.in.ogr/geom.c:261
+#: ../vector/v.in.ogr/geom.c:275 ../vector/v.in.ogr/geom.c:304
+#: ../vector/v.in.ogr/geom.c:352
+#, c-format
+msgid "Skipping empty geometry feature %d"
 msgstr ""
-#: ../locale/scriptstrings/t.rast3d.mapcalc_to_translate.c:7
-msgid "r3.mapcalc expression applied to each time step of the sampled data"
+#: ../vector/v.in.ogr/geom.c:199 ../vector/v.in.ogr/geom.c:220
+msgid "Unable to read part of geometry"
 msgstr ""
-#: ../locale/scriptstrings/t.vect.db.select_to_translate.c:1
-msgid "Prints attributes of vector maps registered in a space time vector dataset."
+#: ../vector/v.in.ogr/geom.c:320
+#, c-format
+msgid "Feature (cat %d): degenerated polygon (%d vertices)"
 msgstr ""
-#: ../locale/scriptstrings/t.vect.db.select_to_translate.c:6
-#: ../vector/v.extract/main.c:79 ../vector/v.decimate/main.c:128
-#: ../vector/v.outlier/main.c:72
-msgid "select"
+#: ../vector/v.in.ogr/geom.c:366
+#, c-format
+msgid "Degenerate island (%d vertices)"
 msgstr ""
-#: ../locale/scriptstrings/v.db.update_to_translate.c:1
-msgid "Updates a column in the attribute table connected to a vector map."
+#: ../vector/v.in.ogr/geom.c:400
+msgid "Unable calculate centroid"
 msgstr ""
-#: ../locale/scriptstrings/v.db.update_to_translate.c:5
-msgid "Name of attribute column to update"
+#: ../vector/v.in.ogr/geom.c:431
+msgid "No centroid written for polygon with 0 vertices"
 msgstr ""
-#: ../locale/scriptstrings/v.db.update_to_translate.c:6
-msgid "Literal value to update the column with"
+#: ../vector/v.in.ogr/geom.c:452
+msgid "Unable to write part of geometry"
 msgstr ""
-#: ../locale/scriptstrings/v.db.update_to_translate.c:7
-msgid "Name of other attribute column to query, can be combination of columns (e.g. co1+col2)"
+#: ../vector/v.in.ogr/geom.c:458
+#, c-format
+msgid "Skipping unsupported geometry type '%s'"
 msgstr ""
-#: ../locale/scriptstrings/v.db.update_to_translate.c:8
-msgid "Name of SQLite extension file for extra functions (SQLite backend only)"
+#: ../vector/v.in.ogr/dsn.c:26 ../vector/v.out.ogr/dsn.c:21
+#: ../vector/v.external/dsn.c:21
+msgid "Invalid connection string (dbname missing)"
 msgstr ""
-msgid "Imports raster data into a GRASS raster map using GDAL library and reprojects on the fly."
+#: ../vector/v.label/main.c:60 ../vector/v.label.sa/main.c:39
+#: ../display/d.labels/main.c:44
+msgid "paint labels"
 msgstr ""
-#: ../locale/scriptstrings/r.import_to_translate.c:5
-msgid "Name of GDAL dataset to be imported"
+#: ../vector/v.label/main.c:62
+msgid "Creates paint labels for a vector map from attached attributes."
 msgstr ""
-#: ../locale/scriptstrings/r.import_to_translate.c:7
-msgid "Input band(s) to select (default is all bands)"
+#: ../vector/v.label/main.c:67 ../vector/v.label.sa/main.c:61
+msgid "Name for new paint-label file"
 msgstr ""
-#: ../locale/scriptstrings/r.import_to_translate.c:9
-#: ../locale/scriptstrings/t.rast.import_to_translate.c:13
-#: ../raster/r.resamp.bspline/main.c:151 ../raster/r.stream.extract/main.c:141
-#: ../raster/r.proj/main.c:191 ../raster/r.in.gdal/main.c:117
-#: ../vector/v.surf.bspline/main.c:194 ../vector/v.to.rast/main.c:116
-msgid "Maximum memory to be used (in MB)"
+#: ../vector/v.label/main.c:69
+msgid "If not given the name of the input map is used"
 msgstr ""
-#: ../locale/scriptstrings/r.import_to_translate.c:10
-#: ../locale/scriptstrings/t.rast.import_to_translate.c:12
-#: ../raster/r.resamp.bspline/main.c:152 ../raster/r.stream.extract/main.c:142
-#: ../raster/r.proj/main.c:192 ../raster/r.in.gdal/main.c:118
-#: ../vector/v.surf.bspline/main.c:195 ../vector/v.to.rast/main.c:117
-msgid "Cache size for raster rows"
+#: ../vector/v.label/main.c:78 ../vector/v.label.sa/main.c:57
+msgid "Name of attribute column to be used for labels"
 msgstr ""
-#: ../locale/scriptstrings/r.import_to_translate.c:11
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:6
-#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:14
-#: ../imagery/i.ifft/main.c:93
-msgid "Name for output raster map"
+#: ../vector/v.label/main.c:89
+msgid "Rotate labels to align with lines"
 msgstr ""
-#: ../locale/scriptstrings/r.import_to_translate.c:13
-msgid "Resampling method to use for reprojection"
+#: ../vector/v.label/main.c:90 ../vector/v.label/main.c:95
+#: ../vector/v.label/main.c:170 ../vector/v.label/main.c:183
+#: ../general/g.region/main.c:165 ../general/g.region/main.c:347
+msgid "Effects"
 msgstr ""
-#: ../locale/scriptstrings/r.import_to_translate.c:14
-msgid "nearest;nearest neighbor;bilinear;bilinear interpolation;bicubic;bicubic interpolation;lanczos;lanczos filter;bilinear_f;bilinear interpolation with fallback;bicubic_f;bicubic interpolation with fallback;lanczos_f;lanczos filter with fallback"
+#: ../vector/v.label/main.c:94
+msgid "Curl labels along lines"
 msgstr ""
-#: ../locale/scriptstrings/r.import_to_translate.c:16
-msgid "Output raster map extent"
+#: ../vector/v.label/main.c:99
+msgid "Offset label in x-direction"
 msgstr ""
-#: ../locale/scriptstrings/r.import_to_translate.c:17
-msgid "region;extent of current region;input;extent of input map"
+#: ../vector/v.label/main.c:102 ../vector/v.label/main.c:109
+#: ../vector/v.label/main.c:118 ../vector/v.label/main.c:162
+msgid "Placement"
 msgstr ""
-#: ../locale/scriptstrings/r.import_to_translate.c:19
-msgid "Resolution of output raster map (default: estimated)"
+#: ../vector/v.label/main.c:106
+msgid "Offset label in y-direction"
 msgstr ""
-#: ../locale/scriptstrings/r.import_to_translate.c:20
-msgid "estimated;estimated resolution;value;user-specified resolution;region;current region resolution"
+#: ../vector/v.label/main.c:113 ../vector/v.lrs/v.lrs.label/main.c:174
+msgid "Reference position"
 msgstr ""
-#: ../locale/scriptstrings/r.import_to_translate.c:22
-msgid "Resolution of output raster map (use with option resolution=value)"
-msgstr ""
+#: ../vector/v.label/main.c:122 ../display/d.legend/main.c:210
+#: ../display/d.rast.num/main.c:119 ../display/d.vect/main.c:266
+#: ../display/d.legend.vect/main.c:115 ../display/d.text/main.c:223
+msgid "Font name"
+msgstr "Fonta nosaukums"
-#: ../locale/scriptstrings/r.import_to_translate.c:24
-#: ../raster/r.in.bin/main.c:298 ../raster/r.in.poly/main.c:50
-#: ../raster/r.external/main.c:90 ../raster/r.in.gdal/main.c:135
-#: ../raster/r.in.ascii/main.c:92 ../raster/r.support/main.c:66
-msgid "Title for resultant raster map"
+#: ../vector/v.label/main.c:125 ../vector/v.label/main.c:132
+#: ../vector/v.label/main.c:140 ../vector/v.label/main.c:148
+#: ../vector/v.lrs/v.lrs.label/main.c:181 ../vector/v.label.sa/main.c:72
+#: ../vector/v.label.sa/main.c:80
+msgid "Font"
 msgstr ""
-#: ../locale/scriptstrings/r.import_to_translate.c:25
-#: ../raster/r.external/main.c:91 ../raster/r.in.gdal/main.c:136
-#: ../raster/r.in.gdal/main.c:145 ../raster/r.in.gdal/main.c:154
-#: ../raster/r.in.gdal/main.c:160 ../imagery/i.landsat.toar/main.c:94
-#: ../imagery/i.landsat.toar/main.c:116 ../imagery/i.landsat.toar/main.c:126
-#: ../imagery/i.landsat.toar/main.c:135 ../imagery/i.landsat.toar/main.c:143
-#: ../imagery/i.landsat.toar/main.c:152
-msgid "Metadata"
+#: ../vector/v.label/main.c:129 ../vector/v.lrs/v.lrs.label/main.c:187
+#: ../vector/v.label.sa/main.c:77
+msgid "Label size (in map-units)"
 msgstr ""
-#: ../locale/scriptstrings/r.import_to_translate.c:26
-msgid "Estimate resolution only"
+#: ../vector/v.label/main.c:137
+msgid "Space between letters for curled labels (in map-units)"
 msgstr ""
-#: ../locale/scriptstrings/r.import_to_translate.c:27
-#: ../locale/scriptstrings/r.import_to_translate.c:29
-#: ../raster/r.horizon/main.c:278 ../raster/r.horizon/main.c:297
-msgid "Optional"
+#: ../vector/v.label/main.c:144
+msgid "Label size (in points)"
 msgstr ""
-#: ../locale/scriptstrings/r.import_to_translate.c:28
-#: ../raster/r.proj/main.c:208
-msgid "Do not perform region cropping optimization"
-msgstr ""
+#: ../vector/v.label/main.c:151 ../vector/v.lrs/v.lrs.label/main.c:193
+#: ../vector/v.label.sa/main.c:98 ../display/d.geodesic/main.c:66
+#: ../display/d.legend/main.c:203 ../display/d.rhumbline/main.c:62
+#: ../display/d.rast.num/main.c:88 ../display/d.northarrow/main.c:113
+#: ../display/d.grid/main.c:107
+msgid "Text color"
+msgstr "Teksta krāsa"
-#: ../locale/scriptstrings/r.import_to_translate.c:30
-#: ../raster/r.in.gdal/main.c:209
-msgid "Force Lat/Lon maps to fit into geographic coordinates (90N,S; 180E,W)"
+#: ../vector/v.label/main.c:152 ../vector/v.label/main.c:176
+#: ../vector/v.label/main.c:189 ../vector/v.label/main.c:195
+#: ../vector/v.label/main.c:205 ../vector/v.label.sa/main.c:103
+#: ../vector/v.label.sa/main.c:113 ../vector/v.label.sa/main.c:120
+#: ../vector/v.label.sa/main.c:130 ../vector/v.label.sa/main.c:140
+#: ../vector/v.label.sa/main.c:150 ../vector/v.label.sa/main.c:157
+#: ../locale/scriptstrings/i.colors.enhance_to_translate.c:11
+#: ../locale/scriptstrings/i.colors.enhance_to_translate.c:13
+#: ../locale/scriptstrings/i.colors.enhance_to_translate.c:15
+#: ../display/d.rast.num/main.c:89 ../display/d.rast.num/main.c:95
+#: ../display/d.rast.num/main.c:113 ../display/d.barscale/main.c:153
+#: ../display/d.barscale/main.c:159 ../display/d.northarrow/main.c:104
+#: ../display/d.northarrow/main.c:109 ../display/d.northarrow/main.c:115
+#: ../display/d.vect/main.c:121 ../display/d.vect/main.c:127
+#: ../display/d.vect/main.c:131 ../display/d.vect/main.c:138
+#: ../display/d.vect/main.c:309 ../display/d.rast.arrow/main.c:119
+#: ../display/d.rast.arrow/main.c:125 ../display/d.rast.arrow/main.c:131
+#: ../display/d.rast.arrow/main.c:137
+msgid "Colors"
+msgstr "Krāsas"
+#: ../vector/v.label/main.c:156 ../display/d.northarrow/main.c:92
+#: ../display/d.text/main.c:181
+msgid "Rotation angle in degrees (counter-clockwise)"
 msgstr ""
-#: ../locale/scriptstrings/r.import_to_translate.c:32
-#: ../locale/scriptstrings/v.import_to_translate.c:28
-#: ../vector/v.external/args.c:47 ../vector/v.in.ogr/main.c:286
-msgid "Assume that the dataset has the same projection as the current location"
+#: ../vector/v.label/main.c:166
+msgid "Border width"
 msgstr ""
-#: ../locale/scriptstrings/t.vect.algebra_to_translate.c:1
-msgid "Apply temporal and spatial operations on space time vector datasets using temporal vector algebra."
+#: ../vector/v.label/main.c:174 ../vector/v.lrs/v.lrs.label/main.c:205
+#: ../vector/v.label.sa/main.c:107
+msgid "Highlight color for text"
 msgstr ""
-#: ../locale/scriptstrings/d.frame_to_translate.c:1
-msgid "Manages display frames on the user's graphics monitor."
+#: ../vector/v.label/main.c:180 ../vector/v.label.sa/main.c:117
+msgid "Width of highlight coloring"
 msgstr ""
-#: ../locale/scriptstrings/d.frame_to_translate.c:5
-msgid "frame"
-msgstr "rāmis"
+#: ../vector/v.label/main.c:187 ../vector/v.lrs/v.lrs.label/main.c:218
+#: ../vector/v.label.sa/main.c:124
+#: ../locale/scriptstrings/r.in.wms_to_translate.c:32
+#: ../general/g.pnmcomp/main.c:325 ../misc/m.nviz.image/args.c:70
+#: ../display/d.erase/main.c:37 ../display/d.legend/main.c:246
+#: ../display/d.mon/main.c:102 ../display/d.histogram/main.c:108
+#: ../display/d.legend.vect/main.c:101 ../display/d.path/main.c:115
+#: ../display/d.grid/main.c:113
+msgid "Background color"
+msgstr "Fona krāsa"
-#: ../locale/scriptstrings/d.frame_to_translate.c:6
-msgid "Create a new frame if doesn't exist and select"
-msgstr ""
+#: ../vector/v.label/main.c:193 ../vector/v.lrs/v.lrs.label/main.c:223
+#: ../vector/v.label.sa/main.c:144 ../display/d.legend/main.c:240
+#: ../display/d.legend.vect/main.c:95 ../display/d.grid/main.c:101
+msgid "Border color"
+msgstr "Malu krāsa"
-#: ../locale/scriptstrings/d.frame_to_translate.c:7
-msgid "Remove all frames, erase the screen and exit"
+#: ../vector/v.label/main.c:200 ../vector/v.label.sa/main.c:135
+msgid "Opaque to vector (only relevant if background color is selected)"
 msgstr ""
-#: ../locale/scriptstrings/d.frame_to_translate.c:8
-msgid "Print name of current frame and exit"
-msgstr ""
+#: ../vector/v.label/main.c:233 ../display/d.extract/main.c:79
+msgid "No graphics device selected"
+msgstr "Nav izvēlēta grafiskā iekārta"
-#: ../locale/scriptstrings/d.frame_to_translate.c:9
-msgid "Print names of all frames including 'at' position and exit"
+#: ../vector/v.label/main.c:251
+msgid ""
+"size and space options vary significantly which may lead to crummy output"
 msgstr ""
-#: ../locale/scriptstrings/d.frame_to_translate.c:10
-msgid "Frame to be selected or created (if -c flag is given)"
+#: ../vector/v.label/main.c:259
+msgid "Too many parameters for <reference>"
 msgstr ""
-#: ../locale/scriptstrings/d.frame_to_translate.c:11
-msgid "Screen coordinates in percent where to place the frame (0,0 is lower-left)"
+#: ../vector/v.label/main.c:319 ../vector/v.overlay/main.c:423
+#: ../vector/v.label.sa/labels.c:162
+msgid "Unable to select attributes"
 msgstr ""
-#: ../locale/scriptstrings/d.frame_to_translate.c:12
-msgid "Implies only when -c or --overwrite flag is given"
+#: ../vector/v.label/main.c:438
+#, c-format
+msgid "Labeled %d lines."
 msgstr ""
-msgid "Reclasses a raster map greater or less than user specified area size (in hectares)."
+#: ../vector/v.reclass/main.c:68 ../raster/r.recode/main.c:50
+#: ../raster/r.reclass/main.c:51
+msgid "reclassification"
 msgstr ""
-#: ../locale/scriptstrings/r.reclass.area_to_translate.c:4
-#: ../locale/scriptstrings/t.rast.aggregate_to_translate.c:3
-#: ../locale/scriptstrings/t.rast.aggregate.ds_to_translate.c:3
-#: ../locale/scriptstrings/t.rast.neighbors_to_translate.c:3
-#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:8
-#: ../locale/scriptstrings/t.rast.series_to_translate.c:3
-#: ../raster3d/r3.neighbors/main.c:212 ../raster3d/r3.in.lidar/main.c:167
-#: ../raster/r.in.xyz/main.c:162 ../raster/r.neighbors/main.c:170
-#: ../raster/r.series/main.c:138 ../raster/r.in.lidar/main.c:113
-#: ../vector/v.neighbors/main.c:54
-msgid "aggregation"
+#: ../vector/v.reclass/main.c:69
+msgid "attributes"
 msgstr ""
-#: ../locale/scriptstrings/r.reclass.area_to_translate.c:5
-msgid "Value option that sets the area size limit (in hectares)"
+#: ../vector/v.reclass/main.c:71
+msgid ""
+"Changes vector category values for an existing vector map according to "
+"results of SQL queries or a value in attribute table column."
 msgstr ""
-#: ../locale/scriptstrings/r.reclass.area_to_translate.c:7
-msgid "Lesser or greater than specified value"
+#: ../vector/v.reclass/main.c:88
+msgid "The name of the column whose values are to be used as new categories"
 msgstr ""
-#: ../locale/scriptstrings/r.reclass.area_to_translate.c:9
-msgid "Method used for reclassification"
+#: ../vector/v.reclass/main.c:89
+msgid "The source for the new key column must be type integer or string"
 msgstr ""
-#: ../locale/scriptstrings/r.reclass.area_to_translate.c:11
-msgid "Input map is clumped"
+#: ../vector/v.reclass/main.c:94
+msgid "Full path to the reclass rule file"
 msgstr ""
-#: ../locale/scriptstrings/r.reclass.area_to_translate.c:12
-msgid "Clumps including diagonal neighbors"
+#: ../vector/v.reclass/main.c:104
+#, c-format
+msgid "Either '%s' or '%s' must be specified"
 msgstr ""
-#: ../locale/scriptstrings/t.rast.gapfill_to_translate.c:1
-msgid "Replaces gaps in a space time raster dataset with interpolated raster maps."
+#: ../vector/v.reclass/main.c:241 ../vector/v.to.rast/vect2rast.c:78
+#: ../vector/v.to.rast/support.c:123 ../vector/v.to.rast/support.c:295
+#: ../vector/v.to.rast/support.c:534
+#, c-format
+msgid "No records selected from table <%s>"
 msgstr ""
-#: ../locale/scriptstrings/t.rast.gapfill_to_translate.c:3
-#: ../locale/scriptstrings/r.fillnulls_to_translate.c:4
-#: ../raster/r.resamp.interp/main.c:78 ../raster/r.resamp.bspline/main.c:83
-#: ../raster/r.series.interp/main.c:66 ../raster/r.surf.contour/main.c:62
-#: ../raster/r.surf.idw/main.c:106 ../vector/v.surf.rst/main.c:149
-#: ../vector/v.surf.idw/main.c:89 ../vector/v.vol.rst/main.c:238
-#: ../vector/v.surf.bspline/main.c:93
-msgid "interpolation"
+#: ../vector/v.reclass/main.c:254
+msgid "Key column type is not integer"
 msgstr ""
-#: ../locale/scriptstrings/t.rast.gapfill_to_translate.c:9
-msgid "Number of interpolation processes to run in parallel"
+#: ../vector/v.reclass/main.c:267 ../vector/v.db.select/main.c:229
+#, c-format
+msgid "Unable to fetch data from table <%s>"
 msgstr ""
-#: ../locale/scriptstrings/t.rast.gapfill_to_translate.c:10
-msgid "Assign the space time raster dataset start and end time to the output map"
+#: ../vector/v.reclass/main.c:298
+#, c-format
+msgid "Cannot insert data: [%s]"
 msgstr ""
-#: ../locale/scriptstrings/t.rast.to.rast3_to_translate.c:1
-msgid "Converts a space time raster dataset into a 3D raster map."
+#: ../vector/v.reclass/main.c:336
+msgid "Column type must be integer or string"
 msgstr ""
-#: ../locale/scriptstrings/t.rast.to.rast3_to_translate.c:3
-#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:7
-#: ../locale/scriptstrings/t.rast.to.vect_to_translate.c:3
-#: ../locale/scriptstrings/r.out.xyz_to_translate.c:5
-#: ../raster3d/r3.out.ascii/main.c:305 ../raster3d/r3.in.ascii/main.c:357
-#: ../raster3d/r3.to.rast/main.c:260 ../raster3d/r3.in.lidar/main.c:166
-#: ../raster/r.in.xyz/main.c:161 ../raster/r.to.vect/main.c:77
-#: ../raster/r.to.rast3/main.c:198 ../raster/r.in.ascii/main.c:71
-#: ../raster/r.in.lidar/main.c:112 ../raster/r.to.rast3elev/main.c:362
-#: ../vector/v.to.rast3/main.c:49 ../vector/v.to.rast/main.c:45
-msgid "conversion"
+#: ../vector/v.reclass/main.c:348
+#, c-format
+msgid "Unable to open rule file <%s>"
 msgstr ""
-#: ../locale/scriptstrings/v.dissolve_to_translate.c:1
-msgid "Dissolves boundaries between adjacent areas sharing a common category number or attribute."
+#: ../vector/v.reclass/main.c:364
+#, c-format
+msgid "Category %d overwritten by '%s'"
 msgstr ""
-#: ../locale/scriptstrings/v.dissolve_to_translate.c:3
-#: ../vector/v.extract/main.c:80
-msgid "dissolve"
+#: ../vector/v.reclass/main.c:368
+#, c-format
+msgid "Category '%s' invalid"
 msgstr ""
-#: ../locale/scriptstrings/v.dissolve_to_translate.c:6
-msgid "Layer number or name."
-msgstr "Slāņa numurs vai nosaukums."
-#: ../locale/scriptstrings/v.dissolve_to_translate.c:7
-msgid "Name of attribute column used to dissolve common boundaries"
+#: ../vector/v.reclass/main.c:372
+#, c-format
+msgid "Label '%s' overwritten by '%s'"
 msgstr ""
-msgid "Aggregates temporally the maps of a space time raster dataset by a user defined granularity."
+#: ../vector/v.reclass/main.c:378
+#, c-format
+msgid "Condition '%s' overwritten by '%s'"
 msgstr ""
-#: ../locale/scriptstrings/t.rast.aggregate_to_translate.c:7
-msgid "Either a numerical suffix or the start time (s-flag) separated by an underscore will be attached to create a unique identifier"
+#: ../vector/v.reclass/main.c:383
+#, c-format
+msgid "Unknown rule option: '%s'"
 msgstr ""
-#: ../locale/scriptstrings/t.rast.aggregate_to_translate.c:9
-msgid "Aggregation granularity, format absolute time \"x years, x months, x weeks, x days, x hours, x minutes, x seconds\" or an integer value for relative time"
+#: ../vector/v.reclass/main.c:397
+msgid "Cannot select values from database"
 msgstr ""
-#: ../locale/scriptstrings/t.rast.aggregate_to_translate.c:10
-#: ../locale/scriptstrings/t.rast.aggregate.ds_to_translate.c:11
-#: ../locale/scriptstrings/t.rast.neighbors_to_translate.c:7
-#: ../locale/scriptstrings/t.rast.series_to_translate.c:7
-#: ../locale/scriptstrings/t.vect.what.strds_to_translate.c:8
-msgid "Aggregate operation to be performed on the raster maps"
+#: ../vector/v.reclass/main.c:413
+#, c-format
+msgid "%d previously set categories overwritten by new category %d"
 msgstr ""
-#: ../locale/scriptstrings/t.rast.aggregate_to_translate.c:11
-#: ../locale/scriptstrings/t.rast.aggregate.ds_to_translate.c:12
-msgid "Offset that is used to create the output map ids, output map id is generated as: basename_ (count + offset)"
+#: ../vector/v.reclass/main.c:439
+msgid "Incomplete rule"
 msgstr ""
-#: ../locale/scriptstrings/t.rast.aggregate_to_translate.c:12
-msgid "Number of r.series processes to run in parallel"
+#: ../vector/v.reclass/main.c:475
+#, c-format
+msgid "%d features reclassed."
 msgstr ""
-#: ../locale/scriptstrings/t.rast.aggregate_to_translate.c:13
-msgid "The maximum number of open files allowed for each r.series process"
+#: ../vector/v.category/main.c:76 ../raster/r.category/main.c:53
+msgid "category"
 msgstr ""
-#: ../locale/scriptstrings/r.in.aster_to_translate.c:1
-msgid "Georeference, rectify, and import Terra-ASTER imagery and relative DEMs using gdalwarp."
+#: ../vector/v.category/main.c:79
+msgid "Attaches, deletes or reports vector categories to map geometry."
 msgstr ""
-#: ../locale/scriptstrings/r.in.aster_to_translate.c:5
-#: ../imagery/i.albedo/main.c:100 ../imagery/i.aster.toar/main.c:103
-msgid "ASTER"
+#: ../vector/v.category/main.c:92
+msgid "Feature ids (by default all features are processed)"
 msgstr ""
-#: ../locale/scriptstrings/r.in.aster_to_translate.c:7
-msgid "Name of input ASTER image"
+#: ../vector/v.category/main.c:104
+msgid "Action to be done"
 msgstr ""
-#: ../locale/scriptstrings/r.in.aster_to_translate.c:8
-msgid "ASTER imagery processing type (Level 1A, Level 1B, or relative DEM)"
+#: ../vector/v.category/main.c:115
+msgid "add a category to features without category in the given layer"
 msgstr ""
-#: ../locale/scriptstrings/r.in.aster_to_translate.c:9
-msgid "List L1A or L1B band to translate (1,2,3n,...), or enter 'all' to translate all bands"
+#: ../vector/v.category/main.c:116
+msgid "delete category (cat=-1 to delete all categories of given layer)"
 msgstr ""
-#: ../locale/scriptstrings/r.in.aster_to_translate.c:10
-msgid "Base name for output raster map (band number will be appended to base name)"
+#: ../vector/v.category/main.c:117
+msgid "change layer number (e.g. layer=3,1 changes layer 3 to layer 1)"
 msgstr ""
-#: ../locale/scriptstrings/db.dropcolumn_to_translate.c:1
-msgid "Drops a column from selected attribute table."
+#: ../vector/v.category/main.c:118
+msgid "add the value specified by cat option to the current category value"
 msgstr ""
-#: ../locale/scriptstrings/v.import_to_translate.c:1
-msgid "Imports vector data into a GRASS vector map using OGR library and reprojects on the fly."
+#: ../vector/v.category/main.c:119
+msgid ""
+"copy values from one layer to another (e.g. layer=1,2,3 copies values from "
+"layer 1 to layer 2 and 3)"
 msgstr ""
-#: ../locale/scriptstrings/v.import_to_translate.c:5
-#: ../vector/v.in.ogr/main.c:144
-msgid "Name of OGR datasource to be imported"
+#: ../vector/v.category/main.c:120
+msgid "print report (statistics), in shell style: layer type count min max"
 msgstr ""
-#: ../locale/scriptstrings/v.import_to_translate.c:7
-#: ../vector/v.in.ogr/main.c:156
-msgid "OGR layer name. If not given, all available layers are imported"
+#: ../vector/v.category/main.c:121
+msgid ""
+"print category values, layers are separated by '|', more cats in the same "
+"layer are separated by '/'"
 msgstr ""
-#: ../locale/scriptstrings/v.import_to_translate.c:9
-#: ../vector/v.proj/main.c:106
-msgid "Name for output vector map (default: input)"
+#: ../vector/v.category/main.c:122
+msgid "print only layer numbers"
 msgstr ""
-#: ../locale/scriptstrings/v.import_to_translate.c:11
-msgid "Output vector map extent"
+#: ../vector/v.category/main.c:134
+#: ../locale/scriptstrings/v.centroids_to_translate.c:7
+msgid "Category increment"
 msgstr ""
-#: ../locale/scriptstrings/v.import_to_translate.c:12
-msgid "input;extent of input map;region;extent of current region"
+#: ../vector/v.category/main.c:138
+msgid "Shell script style, currently only for report"
 msgstr ""
-#: ../locale/scriptstrings/v.import_to_translate.c:15
-#: ../vector/v.in.ogr/main.c:235
-msgid "Overrides encoding interpretation, useful when importing ESRI Shapefile"
+#: ../vector/v.category/main.c:139
+msgid "Format: layer type count min max"
 msgstr ""
-#: ../locale/scriptstrings/v.import_to_translate.c:17
-#: ../vector/v.in.ogr/main.c:211
-msgid "Snapping threshold for boundaries (map units)"
+#: ../vector/v.category/main.c:142
+msgid "Do not copy attribute table(s)"
 msgstr ""
-#: ../locale/scriptstrings/v.import_to_translate.c:18
-#: ../vector/v.in.ogr/main.c:212
-msgid "'-1' for no snap"
+#: ../vector/v.category/main.c:160
+msgid ""
+"Database connection and attribute tables for concerned layers are not changed"
 msgstr ""
-#: ../locale/scriptstrings/v.import_to_translate.c:20
-#: ../locale/scriptstrings/v.import_to_translate.c:22
-msgid "Input SRS"
+#: ../vector/v.category/main.c:208
+msgid ""
+"Invalid category number (must be equal to or greater than 0). Normally "
+"category number starts at 1."
 msgstr ""
-#: ../locale/scriptstrings/v.import_to_translate.c:24
-msgid "-1 to list available datum transform parameters"
-msgstr ""
+#: ../vector/v.category/main.c:217
+#, c-format
+msgid "%d error in id option"
+msgid_plural "%d errors in id option"
+msgstr[0] ""
+msgstr[1] ""
+msgstr[2] ""
-#: ../locale/scriptstrings/v.import_to_translate.c:25
-#: ../vector/v.in.ogr/main.c:256
-msgid "List supported OGR formats and exit"
+#: ../vector/v.category/main.c:228
+msgid "Output vector wasn't entered"
 msgstr ""
-#: ../locale/scriptstrings/v.import_to_translate.c:26
-#: ../vector/v.in.ogr/main.c:262
-msgid "List available OGR layers in data source and exit"
-msgstr ""
+#: ../vector/v.category/main.c:275
+msgid "Too many layers for this operation"
+msgstr "Pārāk daudz līmeņu šai operācijai"
-msgid "Aggregates data of an existing space time raster dataset using the time intervals of a second space time dataset."
-msgstr ""
+#: ../vector/v.category/main.c:278 ../vector/v.category/main.c:281
+msgid "2 layers must be specified"
+msgstr "Jābūt norādītiem 2 līmeņiem"
-#: ../locale/scriptstrings/t.rast.aggregate.ds_to_translate.c:6
-msgid "Time intervals from this space time dataset (raster, vector or raster3d) are used for aggregation computation"
+#: ../vector/v.category/main.c:289
+#, c-format
+msgid "Categories already exist in layer %d"
 msgstr ""
-#: ../locale/scriptstrings/t.rast.aggregate.ds_to_translate.c:7
-msgid "Type of the space time dataset from which aggregation will be copied"
-msgstr ""
+#: ../vector/v.category/main.c:378
+#, c-format
+msgid "%d new centroid placed in output map"
+msgid_plural "%d new centroids placed in output map"
+msgstr[0] ""
+msgstr[1] ""
+msgstr[2] ""
-msgid "Detects accumulation patterns in temporally accumulated space time raster datasets created by t.rast.accumulate."
+#: ../vector/v.category/main.c:672
+msgid "Layer/table"
 msgstr ""
-#: ../locale/scriptstrings/t.rast.accdetect_to_translate.c:3
-#: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:3
-#: ../raster/r.series.accumulate/main.c:82
-msgid "accumulation"
+#: ../vector/v.category/main.c:676
+msgid "Layer"
 msgstr ""
-#: ../locale/scriptstrings/t.rast.accdetect_to_translate.c:6
-msgid "Input space time raster dataset that specifies the minimum values to detect the accumulation pattern"
+#: ../vector/v.category/main.c:678
+#, c-format
+msgid "type       count        min        max\n"
 msgstr ""
-#: ../locale/scriptstrings/t.rast.accdetect_to_translate.c:7
-msgid "Input space time raster dataset that specifies the maximum values to detect the accumulation pattern"
-msgstr ""
+#: ../vector/v.category/main.c:683 ../vector/v.to.points/main.c:56
+#: ../vector/v.buffer/main.c:226 ../vector/v.build.polylines/main.c:113
+#: ../vector/v.edit/main.c:57 ../vector/v.parallel/main.c:52
+#: ../vector/v.type/main.c:42
+#: ../locale/scriptstrings/v.to.lines_to_translate.c:5
+#: ../locale/scriptstrings/v.in.lines_to_translate.c:4
+#: ../locale/scriptstrings/v.dissolve_to_translate.c:5
+msgid "line"
+msgstr "līnija"
-#: ../locale/scriptstrings/t.rast.accdetect_to_translate.c:8
-msgid "The output space time raster dataset that stores the occurrence of the the accumulation pattern using the provided data range"
+#: ../vector/v.category/main.c:687
+msgid "boundary"
 msgstr ""
-#: ../locale/scriptstrings/t.rast.accdetect_to_translate.c:9
-msgid "The output space time raster dataset that stores the indication of the start, intermediate and end of the specified data range"
+#: ../vector/v.category/main.c:691
+#: ../locale/scriptstrings/v.centroids_to_translate.c:3
+msgid "centroid"
 msgstr ""
-#: ../locale/scriptstrings/t.rast.accdetect_to_translate.c:10
-#: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:8
-msgid "The temporal starting point to begin the accumulation, eg '2001-01-01'"
+#: ../vector/v.category/main.c:695 ../vector/v.buffer/main.c:223
+#: ../vector/v.type/main.c:41
+#: ../locale/scriptstrings/v.to.lines_to_translate.c:4
+#: ../locale/scriptstrings/v.clip_to_translate.c:4
+#: ../locale/scriptstrings/v.centroids_to_translate.c:4
+#: ../locale/scriptstrings/v.dissolve_to_translate.c:4
+#: ../misc/m.measure/main.c:49
+msgid "area"
 msgstr ""
-#: ../locale/scriptstrings/t.rast.accdetect_to_translate.c:11
-#: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:9
-msgid "The temporal date to stop the accumulation, eg '2009-01-01'"
+#: ../vector/v.category/main.c:699
+msgid "face"
 msgstr ""
-#: ../locale/scriptstrings/t.rast.accdetect_to_translate.c:12
-#: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:10
-msgid "The temporal cycle to restart the accumulation, eg '12 months'"
+#: ../vector/v.category/main.c:703
+msgid "kernel"
 msgstr ""
-#: ../locale/scriptstrings/t.rast.accdetect_to_translate.c:13
-#: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:11
-msgid "The temporal offset to the begin of the next cycle, eg '6 months'"
+#: ../vector/v.category/main.c:707
+msgid "all"
 msgstr ""
-#: ../locale/scriptstrings/t.rast.accdetect_to_translate.c:16
-msgid "Suffix to add at basename: set 'gran' for granularity, 'time' for the full time format, 'count' for numerical suffix with a specific number of digits (default %05)"
+#: ../vector/v.category/main.c:761 ../vector/v.rectify/main.c:276
+msgid "Copying attribute table(s)..."
 msgstr ""
-#: ../locale/scriptstrings/t.rast.accdetect_to_translate.c:17
-msgid "The minimum and maximum value of the occurrence of accumulated values, these values will be used if the min/max space time raster datasets are not specified"
+#: ../vector/v.category/main.c:763 ../vector/v.build.polylines/main.c:241
+#: ../vector/v.net/main.c:158 ../vector/v.type/main.c:155
+#: ../vector/v.rectify/main.c:278 ../vector/v.proj/main.c:503
+#: ../vector/v.transform/main.c:304
+msgid "Failed to copy attribute table to output map"
 msgstr ""
-#: ../locale/scriptstrings/t.rast.accdetect_to_translate.c:18
-msgid "The user defined values that indicate start, intermediate and end status in the indicator output space time raster dataset"
+#: ../vector/v.category/main.c:771
+#, c-format
+msgid "Categories copied from layer %d to layer %d"
 msgstr ""
-#: ../locale/scriptstrings/t.rast.accdetect_to_translate.c:19
-#: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:21
-msgid "Register empty maps in the output space time raster dataset, otherwise they will be deleted"
+#: ../vector/v.category/main.c:775
+#, c-format
+msgid "%d feature modified."
+msgid_plural "%d features modified."
+msgstr[0] ""
+msgstr[1] ""
+msgstr[2] ""
+#: ../vector/v.net.steiner/main.c:58
+#, c-format
+msgid "Init costs from node %d"
 msgstr ""
-#: ../locale/scriptstrings/t.rast.accdetect_to_translate.c:20
-#: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:22
-msgid "Reverse time direction in cyclic accumulation"
+#: ../vector/v.net.steiner/main.c:348
+msgid "steiner tree"
 msgstr ""
-#: ../locale/scriptstrings/t.info_to_translate.c:1
-msgid "Lists information about space time datasets and maps."
+#: ../vector/v.net.steiner/main.c:350
+msgid "Creates Steiner tree for the network and given terminals."
 msgstr ""
-#: ../locale/scriptstrings/t.info_to_translate.c:3
-#: ../locale/scriptstrings/t.select_to_translate.c:3
-#: ../locale/scriptstrings/t.support_to_translate.c:3
-#: ../temporal/t.connect/main.c:36 ../raster3d/r3.info/main.c:76
-#: ../raster3d/r3.support/main.c:50 ../raster3d/r3.timestamp/main.c:44
-#: ../raster/r.describe/main.c:55 ../raster/r.info/main.c:71
-#: ../raster/r.timestamp/main.c:36 ../raster/r.support/main.c:55
-#: ../raster/r.region/main.c:52 ../vector/v.timestamp/main.c:36
-#: ../vector/v.info/main.c:38 ../vector/v.support/main.c:40
-msgid "metadata"
+#: ../vector/v.net.steiner/main.c:352
+msgid ""
+"Note that 'Minimum Steiner Tree' problem is NP-hard and heuristic algorithm "
+"is used in this module so the result may be sub optimal."
 msgstr ""
-#: ../locale/scriptstrings/t.info_to_translate.c:6
-msgid "Name of an existing space time dataset or map"
+#: ../vector/v.net.steiner/main.c:363 ../vector/v.net/args.c:63
+#: ../vector/v.net.alloc/main.c:103 ../vector/v.net.iso/main.c:124
+#: ../vector/v.net.path/main.c:61 ../vector/v.net.distance/main.c:89
+#: ../vector/v.net.salesman/main.c:156 ../display/d.path/main.c:60
+msgid "Arc type"
 msgstr ""
-#: ../locale/scriptstrings/t.info_to_translate.c:10
-msgid "Print history information in human readable shell style for space time datasets"
+#: ../vector/v.net.steiner/main.c:373
+msgid "Node layer (used for terminals)"
 msgstr ""
-#: ../locale/scriptstrings/t.info_to_translate.c:11
-msgid "Print information about the temporal DBMI interface and exit"
+#: ../vector/v.net.steiner/main.c:379
+msgid "Arcs' cost column (for both directions)"
 msgstr ""
-#: ../locale/scriptstrings/t.vect.observe.strds_to_translate.c:1
-msgid "Observes specific locations in a space time raster dataset over a period of time using vector points."
+#: ../vector/v.net.steiner/main.c:385
+msgid "Categories of points on terminals (layer is specified by nlayer)"
 msgstr ""
-#: ../locale/scriptstrings/t.vect.observe.strds_to_translate.c:6
-msgid "Name of the new created vector map that stores the sampled values in different layers"
+#: ../vector/v.net.steiner/main.c:393
+msgid "Number of Steiner points (-1 for all possible)"
 msgstr ""
-#: ../locale/scriptstrings/t.vect.observe.strds_to_translate.c:7
-msgid "Names of the vector columns to be created and to store sampled raster values, one name for each STRDS"
+#: ../vector/v.net.steiner/main.c:448
+#, c-format
+msgid "Point is not connected to the network (cat=%d)"
 msgstr ""
-#: ../locale/scriptstrings/t.select_to_translate.c:1
-msgid "Select maps from space time datasets by topological relationships to other space time datasets using temporal algebra."
+#. GTC Terminal refers to an Steiner tree endpoint
+#: ../vector/v.net.steiner/main.c:458
+#, c-format
+msgid "Number of terminals: %d\n"
 msgstr ""
-#: ../locale/scriptstrings/t.select_to_translate.c:7
-msgid "The temporal mapcalc expression"
+#: ../vector/v.net.steiner/main.c:462
+msgid "Not enough terminals (< 2)"
 msgstr ""
-#: ../locale/scriptstrings/t.select_to_translate.c:8
-msgid "Check the spatial topology of temporally related maps and select only spatially related maps"
+#: ../vector/v.net.steiner/main.c:469
+msgid "Requested number of Steiner points > than possible"
 msgstr ""
-#: ../locale/scriptstrings/t.select_to_translate.c:9
-#: ../locale/scriptstrings/t.rast.algebra_to_translate.c:13
-msgid "Perform a dry run, compute all dependencies and module calls but don't run them"
+#: ../vector/v.net.steiner/main.c:475
+#, c-format
+msgid "Number of Steiner points set to %d\n"
 msgstr ""
-#: ../locale/scriptstrings/t.rast.univar_to_translate.c:1
-msgid "Calculates univariate statistics from the non-null cells for each registered raster map of a space time raster dataset."
+#: ../vector/v.net.steiner/main.c:522
+#, c-format
+msgid "Terminal at node [%d] cannot be connected to terminal at node [%d]"
 msgstr ""
-#: ../locale/scriptstrings/t.rast.univar_to_translate.c:9
-#: ../locale/scriptstrings/t.rast3d.univar_to_translate.c:10
-#: ../locale/scriptstrings/t.vect.univar_to_translate.c:10
-#: ../raster/r.univar/r3.univar_main.c:63 ../raster/r.univar/r.univar_main.c:66
-#: ../vector/v.univar/main.c:130
-msgid "Calculate extended statistics"
+#: ../vector/v.net.steiner/main.c:538
+#, c-format
+msgid ""
+"[%d] (not reachable) nodes removed from list of Steiner point candidates"
 msgstr ""
-#: ../locale/scriptstrings/t.rast.univar_to_translate.c:10
-msgid "Ignore the current region settings and use the raster map regions for univar statistical calculation"
+#: ../vector/v.net.steiner/main.c:543
+#, c-format
+msgid "MST costs = %f"
 msgstr ""
-#: ../locale/scriptstrings/db.out.ogr_to_translate.c:1
-msgid "Exports attribute tables into various formats."
+#: ../vector/v.net.steiner/main.c:549
+#, c-format
+msgid "Search for [%d]. Steiner point"
 msgstr ""
-#: ../locale/scriptstrings/db.out.ogr_to_translate.c:5
-msgid "GRASS table name"
+#: ../vector/v.net.steiner/main.c:570
+#, c-format
+msgid "Steiner point at node [%d] was added to terminals (MST costs = %f)"
 msgstr ""
-#: ../locale/scriptstrings/db.out.ogr_to_translate.c:6
-msgid "Output table file name or DB connection string"
+#: ../vector/v.net.steiner/main.c:582
+msgid "No Steiner point found -> leaving cycle"
 msgstr ""
-#: ../locale/scriptstrings/db.out.ogr_to_translate.c:7
-msgid "Table format"
+#: ../vector/v.net.steiner/main.c:587
+#, c-format
+msgid "Number of added Steiner points: %d (theoretic max is %d).\n"
 msgstr ""
-#: ../locale/scriptstrings/db.out.ogr_to_translate.c:8
-msgid "Name for output table (default: input name)"
+#: ../vector/v.net.steiner/main.c:598
+#, c-format
+msgid ""
+"Spanning tree costs on complete graph = %f\n"
+"(may be higher than resulting Steiner tree costs!!!)"
 msgstr ""
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:1
-msgid "Downloads and imports data from WMS/WMTS/NASA OnEarth server."
+#: ../vector/v.net.steiner/main.c:603
+#, c-format
+msgid "Steiner tree costs = %f"
 msgstr ""
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:4
-#: ../locale/scriptstrings/v.in.wfs_to_translate.c:4
-msgid "OGC web services"
+#: ../vector/v.net.steiner/main.c:656
+#, c-format
+msgid "A Steiner tree with %d arc has been built"
+msgid_plural "A Steiner tree with %d arcs has been built"
+msgstr[0] ""
+msgstr[1] ""
+msgstr[2] ""
+#: ../vector/v.normal/main.c:76
+msgid "Tests for normality for vector points."
 msgstr ""
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:5
-msgid "Typically starts with \"http://\""
+#: ../vector/v.normal/main.c:88
+msgid "Lists of tests (1-15)"
 msgstr ""
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:7
-msgid "Layer(s) to request from the map server"
+#: ../vector/v.normal/main.c:89
+msgid "E.g. 1,3-8,13"
 msgstr ""
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:8
-msgid "Layer style(s) to request from the map server"
+#: ../vector/v.normal/main.c:96 ../vector/v.delaunay/main.c:98
+msgid "Use only points in current region"
 msgstr ""
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:9
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:34
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:40
-msgid "Map style"
+#: ../vector/v.normal/main.c:100
+msgid "Lognormality instead of normality"
 msgstr ""
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:10
-msgid "Image format requested from the server"
+#: ../vector/v.normal/main.c:131
+msgid "Only numeric column type supported"
 msgstr ""
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:11
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:13
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:18
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:20
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:22
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:24
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:31
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:38
-msgid "Request"
+#: ../vector/v.normal/main.c:135 ../vector/v.surf.bspline/main.c:400
+#, c-format
+msgid "%d records selected from table"
+msgstr "No tabulas atlasīti %d ieraksti"
+#: ../vector/v.normal/main.c:174 ../vector/v.normal/main.c:182
+#, c-format
+msgid "No record for cat %d"
 msgstr ""
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:12
-msgid "EPSG code of requested source projection"
+#: ../vector/v.normal/main.c:192
+#, c-format
+msgid "Number of points: %d"
+#: ../vector/v.normal/main.c:198
+msgid "Too small sample"
 msgstr ""
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:14
-msgid "Driver used to communication with server"
+#: ../vector/v.normal/main.c:206
+msgid "Negative or very small point values set to -10.0"
 msgstr ""
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:15
-msgid "WMS_GDAL;Download data using GDAL WMS driver;WMS_GRASS;Download data using native GRASS-WMS driver;WMTS_GRASS;Download data using native GRASS-WMTS driver;OnEarth_GRASS;Download data using native GRASS-OnEarth driver;"
+#: ../vector/v.normal/main.c:223
+#, c-format
+msgid "Moments \\sqrt{b_1} and b_2: "
 msgstr ""
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:16
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:26
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:28
-#: ../locale/scriptstrings/db.droptable_to_translate.c:7
-#: ../locale/scriptstrings/db.droptable_to_translate.c:10
-#: ../db/db.databases/main.c:80 ../db/db.databases/main.c:91
-#: ../db/db.execute/main.c:144 ../db/db.execute/main.c:149
-#: ../db/db.execute/main.c:154 ../db/db.select/main.c:219
-#: ../db/db.select/main.c:224
-msgid "Connection"
+#: ../vector/v.normal/main.c:228
+#, c-format
+msgid "Geary's a-statistic & an approx. normal: "
 msgstr ""
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:17
-msgid "WMS standard version"
+#: ../vector/v.normal/main.c:233
+#, c-format
+msgid "Extreme normal deviates: "
 msgstr ""
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:19
-msgid "Maximum columns to request at a time"
+#: ../vector/v.normal/main.c:238
+#, c-format
+msgid "D'Agostino's D & an approx. normal: "
 msgstr ""
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:21
-msgid "Maximum rows to request at a time"
+#: ../vector/v.normal/main.c:244
+#, c-format
+msgid "Kuiper's V (regular & modified for normality): "
 msgstr ""
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:23
-msgid "Additional query parameters to pass to the server"
+#: ../vector/v.normal/main.c:250
+#, c-format
+msgid "Watson's U^2 (regular & modified for normality): "
 msgstr ""
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:25
-msgid "Username for server connection"
+#: ../vector/v.normal/main.c:256
+#, c-format
+msgid "Durbin's Exact Test (modified Kolmogorov): "
 msgstr ""
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:27
-msgid "Password for server connection"
+#: ../vector/v.normal/main.c:262
+#, c-format
+msgid "Anderson-Darling's A^2 (regular & modified for normality): "
 msgstr ""
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:29
-msgid "Interpolation method to use in reprojection"
+#: ../vector/v.normal/main.c:268
+#, c-format
+msgid "Cramer-Von Mises W^2(regular & modified for normality): "
 msgstr ""
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:30
-msgid "Request data for this named region instead of the current region bounds"
+#: ../vector/v.normal/main.c:274
+#, c-format
+msgid "Kolmogorov-Smirnov's D (regular & modified for normality): "
 msgstr ""
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:33
-msgid "Format: 0xRRGGBB"
+#: ../vector/v.normal/main.c:280
+#, c-format
+msgid "Chi-Square stat (equal probability classes) and d.f.: "
 msgstr ""
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:35
-msgid "Capabilities file to parse (input). It is relevant for WMTS_GRASS and OnEarth_GRASS drivers"
+#: ../vector/v.normal/main.c:286
+msgid "Shapiro-Wilk's W cannot be used for n > 50"
 msgstr ""
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:36
-msgid "File where the server capabilities will be saved ('c' flag)"
+#: ../vector/v.normal/main.c:288
+msgid "Use Weisberg-Binghams's W''"
 msgstr ""
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:37
-msgid "Get the server capabilities then exit"
+#: ../vector/v.normal/main.c:291
+#, c-format
+msgid "Shapiro-Wilk W: "
 msgstr ""
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:39
-msgid "Do not request transparent data"
+#: ../vector/v.normal/main.c:298
+msgid "Weisberg-Bingham's W'' cannot be used for n < 50 or n > 99"
 msgstr ""
-#: ../locale/scriptstrings/v.what.vect_to_translate.c:1
-msgid "Uploads vector values at positions of vector points to the table."
+#: ../vector/v.normal/main.c:300
+#, c-format
+msgid "Weisberg-Bingham's W'': "
 msgstr ""
-#: ../locale/scriptstrings/v.what.vect_to_translate.c:5
-#: ../locale/scriptstrings/v.what.strds_to_translate.c:5
-#: ../raster/r.what/main.c:100 ../display/d.where/main.c:45
-#: ../vector/v.what.rast3/main.c:67 ../vector/v.what.rast/main.c:74
-#: ../vector/v.what/main.c:64
-msgid "position"
+#: ../vector/v.normal/main.c:307
+msgid "Royston only extended Shapiro-Wilk's W up to n = 2000"
 msgstr ""
-#: ../locale/scriptstrings/v.what.vect_to_translate.c:8
-#: ../vector/v.what.rast3/main.c:76 ../vector/v.what.rast/main.c:83
-msgid "Name of vector points map for which to edit attributes"
+#: ../vector/v.normal/main.c:309
+#, c-format
+msgid "Shapiro-Wilk W'': "
 msgstr ""
-#: ../locale/scriptstrings/v.what.vect_to_translate.c:9
-#: ../locale/scriptstrings/v.db.join_to_translate.c:6
-msgid "layer,column"
+#: ../vector/v.normal/main.c:315
+#, c-format
+msgid "Kotz' T'_f (Lognormality vs. Normality): "
 msgstr ""
-#: ../locale/scriptstrings/v.what.vect_to_translate.c:10
-#: ../locale/scriptstrings/v.db.join_to_translate.c:8
-msgid "column"
+#: ../vector/v.extract/main.c:78 ../vector/v.outlier/main.c:71
+#: ../vector/v.decimate/main.c:127
+#: ../locale/scriptstrings/t.vect.extract_to_translate.c:3
+#: ../locale/scriptstrings/t.rast3d.extract_to_translate.c:3
+#: ../locale/scriptstrings/t.rast.extract_to_translate.c:3
+msgid "extract"
 msgstr ""
-#: ../locale/scriptstrings/v.what.vect_to_translate.c:11
-#: ../vector/v.what.rast3/main.c:87 ../vector/v.what.rast/main.c:98
-msgid "Name of attribute column to be updated with the query result"
+#: ../vector/v.extract/main.c:79 ../vector/v.outlier/main.c:72
+#: ../vector/v.decimate/main.c:128
+#: ../locale/scriptstrings/t.vect.db.select_to_translate.c:6
+msgid "select"
 msgstr ""
-#: ../locale/scriptstrings/v.what.vect_to_translate.c:12
-msgid "Name of vector map to be queried"
+#: ../vector/v.extract/main.c:80
+#: ../locale/scriptstrings/v.dissolve_to_translate.c:3
+msgid "dissolve"
 msgstr ""
-#: ../locale/scriptstrings/v.what.vect_to_translate.c:13
-msgid "query_layer,query_column"
+#: ../vector/v.extract/main.c:81 ../vector/v.perturb/main.c:65
+#: ../vector/v.random/main.c:100 ../raster/r.random.cells/main.c:49
+#: ../raster/r.surf.random/main.c:38 ../raster/r.surf.gauss/main.c:40
+#: ../raster/r.random/main.c:54 ../raster/r.random.surface/main.c:59
+msgid "random"
 msgstr ""
-#: ../locale/scriptstrings/v.what.vect_to_translate.c:14
-msgid "query_column"
+#: ../vector/v.extract/main.c:83
+msgid ""
+"Selects vector features from an existing vector map and creates a new vector "
+"map containing only the selected features."
 msgstr ""
-#: ../locale/scriptstrings/v.what.vect_to_translate.c:15
-msgid "Name of attribute column to be queried"
+#: ../vector/v.extract/main.c:88
+msgid "Dissolve common boundaries (default is no)"
 msgstr ""
-#: ../locale/scriptstrings/v.what.vect_to_translate.c:16
-msgid "Maximum query distance in map units"
+#: ../vector/v.extract/main.c:92
+msgid "Do not copy attributes (see also 'new' parameter)"
 msgstr ""
-#: ../locale/scriptstrings/r.fillnulls_to_translate.c:1
-msgid "Fills no-data areas in raster maps using spline interpolation."
+#: ../vector/v.extract/main.c:108
+msgid "Types to be extracted"
 msgstr ""
-#: ../locale/scriptstrings/r.fillnulls_to_translate.c:5
-#: ../raster/r.proj/main.c:182
-#: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:127
-#: ../imagery/i.rectify/main.c:148
-msgid "Interpolation method to use"
+#: ../vector/v.extract/main.c:123
+msgid "Input text file with category numbers/number ranges to be extracted"
 msgstr ""
-#: ../locale/scriptstrings/r.fillnulls_to_translate.c:6
-msgid "Spline tension parameter"
+#: ../vector/v.extract/main.c:124
+msgid "If '-' given reads from standard input"
 msgstr ""
-#: ../locale/scriptstrings/r.fillnulls_to_translate.c:7
-#: ../locale/scriptstrings/r.fillnulls_to_translate.c:9
-#: ../locale/scriptstrings/r.fillnulls_to_translate.c:11
-#: ../locale/scriptstrings/r.fillnulls_to_translate.c:13
-#: ../locale/scriptstrings/r.fillnulls_to_translate.c:15
-msgid "RST options"
+#: ../vector/v.extract/main.c:132
+msgid "Number of random categories matching vector objects to extract"
 msgstr ""
-#: ../locale/scriptstrings/r.fillnulls_to_translate.c:8
-msgid "Spline smoothing parameter"
+#: ../vector/v.extract/main.c:134
+msgid "Number must be smaller than unique cat count in layer"
 msgstr ""
-#: ../locale/scriptstrings/r.fillnulls_to_translate.c:10
-msgid "Width of hole edge used for interpolation (in cells)"
+#: ../vector/v.extract/main.c:142
+msgid "Desired new category value (enter -1 to keep original categories)"
 msgstr ""
-#: ../locale/scriptstrings/r.fillnulls_to_translate.c:12
-#: ../vector/v.surf.rst/main.c:307 ../vector/v.vol.rst/main.c:319
-msgid "Minimum number of points for approximation in a segment (>segmax)"
+#: ../vector/v.extract/main.c:144
+msgid "If new >= 0, attributes is not copied"
 msgstr ""
-#: ../locale/scriptstrings/r.fillnulls_to_translate.c:14
-#: ../vector/v.surf.rst/main.c:298 ../vector/v.vol.rst/main.c:310
-msgid "Maximum number of points in a segment"
-msgstr "Maksimālais punktu skaits vienā segmentā"
-#: ../locale/scriptstrings/r.fillnulls_to_translate.c:16
-#: ../raster/r.resamp.bspline/main.c:132 ../vector/v.surf.bspline/main.c:177
-msgid "Tykhonov regularization parameter (affects smoothing)"
+#: ../vector/v.extract/main.c:161
+#, c-format
+msgid ""
+"Options <%s>, <%s>, <%s> and <%s> options are exclusive. Please specify only "
+"one of them."
 msgstr ""
-#: ../locale/scriptstrings/r.fillnulls_to_translate.c:17
-msgid "Used in bilinear and bicubic spline interpolation"
+#: ../vector/v.extract/main.c:208
+#, c-format
+msgid "Category value in '%s' not valid"
 msgstr ""
-#: ../locale/scriptstrings/r.fillnulls_to_translate.c:18
-msgid "Spline options"
+#: ../vector/v.extract/main.c:224
+#, c-format
+msgid "Process file <%s> for category numbers..."
 msgstr ""
-#: ../locale/scriptstrings/r.rgb_to_translate.c:1
-msgid "Splits a raster map into red, green and blue maps."
+#: ../vector/v.extract/main.c:229
+#, c-format
+msgid "Unable to open specified file <%s>"
 msgstr ""
-#: ../locale/scriptstrings/r.rgb_to_translate.c:3
-#: ../locale/scriptstrings/i.colors.enhance_to_translate.c:3
-msgid "RGB"
+#: ../vector/v.extract/main.c:240
+#, c-format
+msgid "Ignored text entry: %s"
 msgstr ""
-#: ../locale/scriptstrings/r.rgb_to_translate.c:4
-msgid "separate"
+#: ../vector/v.extract/main.c:259
+#, c-format
+msgid "Loading categories from table <%s>..."
 msgstr ""
-#: ../locale/scriptstrings/r.rgb_to_translate.c:5
-msgid "split"
+#: ../vector/v.extract/main.c:269
+#, c-format
+msgid "Unable select records from table <%s>"
 msgstr ""
-#: ../locale/scriptstrings/r.rgb_to_translate.c:6
-msgid "Red channel raster map name"
+#: ../vector/v.extract/main.c:271
+#, c-format
+msgid "%d category loaded"
+msgid_plural "%d categories loaded"
+msgstr[0] ""
+msgstr[1] ""
+msgstr[2] ""
+#: ../vector/v.extract/main.c:286
+msgid ""
+"This map has no categories attached. Use v.category to attach categories to "
+"this vector map."
 msgstr ""
-#: ../locale/scriptstrings/r.rgb_to_translate.c:7
-msgid "Green channel raster map name"
+#: ../vector/v.extract/main.c:293
+msgid "Please specify random number larger than 0"
 msgstr ""
-#: ../locale/scriptstrings/r.rgb_to_translate.c:8
-msgid "Blue channel raster map name"
+#: ../vector/v.extract/main.c:297
+#, c-format
+msgid ""
+"Random category count must be smaller than feature count. There are only %d "
+"features of type(s): %s"
 msgstr ""
-#: ../locale/scriptstrings/d.out.file_to_translate.c:1
-msgid "Saves the contents of the active display monitor to a graphics file."
+#: ../vector/v.extract/main.c:320
+#, c-format
+msgid ""
+"Random category count is larger or equal to uniq <%s> feature category count "
+"%d"
 msgstr ""
-#: ../locale/scriptstrings/d.out.file_to_translate.c:6
-msgid "Width and height of output image"
+#: ../vector/v.extract/main.c:354
+msgid "Extracting features..."
 msgstr ""
-#: ../locale/scriptstrings/d.out.file_to_translate.c:7
-msgid "Images"
+#: ../vector/v.extract/main.c:378
+msgid "Removing duplicate centroids..."
 msgstr ""
-#: ../locale/scriptstrings/d.correlate_to_translate.c:1
-msgid "Prints a graph of the correlation between raster maps (in pairs)."
+#: ../vector/v.extract/extract.c:171
+#, c-format
+msgid "No category found for area %d. Skipping."
 msgstr ""
-#: ../locale/scriptstrings/d.correlate_to_translate.c:5
-#: ../locale/scriptstrings/d.polar_to_translate.c:3
-msgid "diagram"
+#: ../vector/v.extract/extract.c:175
+#, c-format
+msgid "More categories (%d) found for area %d. Using first found category %d"
 msgstr ""
-#: ../locale/scriptstrings/d.correlate_to_translate.c:6
-msgid "correlation"
+#: ../vector/v.extract/extract.c:228
+msgid ""
+"Topology level required for extracting areas for OGR layers. Areas will be "
+"not processed."
 msgstr ""
-#: ../locale/scriptstrings/d.what.vect_to_translate.c:1
-msgid "Allows the user to interactively query vector map layers at user-selected locations."
+#: ../vector/v.extract/copy_tab.c:90
+#, c-format
+msgid "Writing attributes for layer %d"
 msgstr ""
-#: ../locale/scriptstrings/g.search.modules_to_translate.c:1
-msgid "Search in GRASS modules using keywords"
+#: ../vector/v.extract/copy_tab.c:95
+#, c-format
+msgid "No attribute table for layer %d"
 msgstr ""
-#: ../locale/scriptstrings/g.search.modules_to_translate.c:3
-msgid "modules"
+#: ../vector/v.extract/copy_tab.c:108 ../vector/v.to.points/main.c:165
+#: ../vector/v.generalize/misc.c:184
+#: ../scripts/v.db.reconnect.all/v.db.reconnect.all.py:128
+#, c-format, python-format
+msgid "Unable to copy table <%s>"
 msgstr ""
-#: ../locale/scriptstrings/g.search.modules_to_translate.c:5
-msgid "Keyword to be searched"
+#: ../vector/v.extract/copy_tab.c:117 ../vector/v.vect.stats/main.c:335
+#: ../vector/v.vect.stats/main.c:417
+#, c-format
+msgid "Unable to open database <%s> with driver <%s>"
 msgstr ""
-#: ../locale/scriptstrings/g.search.modules_to_translate.c:6
-msgid "Display only modules where all keywords are available (AND), default: OR"
+#: ../vector/v.out.ogr/export_lines.c:178
+#: ../vector/v.out.ogr/export_areas.c:143
+#, c-format
+msgid "Unable to export multi-features. No category index for layer %d."
 msgstr ""
-#: ../locale/scriptstrings/g.search.modules_to_translate.c:8
-msgid "Invert selection (logical NOT)"
+#: ../vector/v.out.ogr/export_lines.c:212
+#: ../vector/v.out.ogr/export_areas.c:176
+#, c-format
+msgid ""
+"Unable to create multi-feature. Category %d not found in line %d, field %d"
 msgstr ""
-#: ../locale/scriptstrings/g.search.modules_to_translate.c:10
-msgid "Search in manual pages too (can be slow)"
+#: ../vector/v.out.ogr/attrb.c:48 ../vector/v.out.vtk/writeVTK.c:585
+#, c-format
+msgid "Cannot select attributes for cat = %d"
 msgstr ""
-#: ../locale/scriptstrings/g.search.modules_to_translate.c:12
-msgid "Search only for the exact keyword in module keyword list"
+#: ../vector/v.out.ogr/attrb.c:53 ../vector/v.out.vtk/writeVTK.c:589
+#: ../vector/v.out.svg/main.c:400 ../vector/v.overlay/main.c:487
+#: ../vector/v.lrs/v.lrs.label/main.c:331
+msgid "Unable to fetch data from table"
 msgstr ""
-#: ../locale/scriptstrings/g.search.modules_to_translate.c:13
-msgid "Instead of full text search, search only in actual keywords"
+#: ../vector/v.out.ogr/attrb.c:65
+#, c-format
+msgid "No database record for cat = %d and export of 'cat' disabled"
 msgstr ""
-#: ../locale/scriptstrings/g.search.modules_to_translate.c:15
-msgid "Use colorized (more readable) output to terminal"
+#: ../vector/v.out.ogr/main.c:87
+msgid "Exports a vector map layer to any of the supported OGR vector formats."
 msgstr ""
-#: ../locale/scriptstrings/g.search.modules_to_translate.c:17
-msgid "Shell script format"
+#: ../vector/v.out.ogr/main.c:88
+msgid "By default a vector map layer is exported to OGC GeoPackage format."
 msgstr ""
-#: ../locale/scriptstrings/g.search.modules_to_translate.c:19
-msgid "JSON format"
+#: ../vector/v.out.ogr/main.c:170
+msgid "Volumes will be exported as sets of faces"
 msgstr ""
-#: ../locale/scriptstrings/v.db.renamecolumn_to_translate.c:1
-msgid "Renames a column in the attribute table connected to a given vector map."
+#: ../vector/v.out.ogr/main.c:188
+msgid "Unable to determine input map's vector feature type(s)."
 msgstr ""
-#: ../locale/scriptstrings/v.db.renamecolumn_to_translate.c:5
-msgid "Old and new name of the column (old,new)"
+#: ../vector/v.out.ogr/main.c:254
+msgid "The combination of types is not supported by all formats."
 msgstr ""
-#: ../locale/scriptstrings/v.build.all_to_translate.c:1
-msgid "Rebuilds topology on all vector maps in the current mapset."
+#: ../vector/v.out.ogr/main.c:278
+#, c-format
+msgid "Unknown EPSG code %s"
 msgstr ""
-#: ../locale/scriptstrings/v.build.all_to_translate.c:3
-#: ../locale/scriptstrings/t.topology_to_translate.c:3
-#: ../vector/v.build.polylines/main.c:111 ../vector/v.out.postgis/main.c:48
-#: ../vector/v.build/main.c:37 ../vector/v.clean/main.c:52
-#: ../vector/v.info/main.c:39
-msgid "topology"
+#: ../vector/v.out.ogr/main.c:300
+#, c-format
+msgid "OGR layer <%s> created in datasource <%s> (format '%s')"
 msgstr ""
-#: ../locale/scriptstrings/t.rast.neighbors_to_translate.c:1
-msgid "Performs a neighborhood analysis for each map in a space time raster dataset."
+#: ../vector/v.out.ogr/main.c:312
+msgid ""
+"The map contains islands. With the -c flag, islands will appear as filled "
+"areas, not holes in the output map."
 msgstr ""
-#: ../locale/scriptstrings/t.rast.neighbors_to_translate.c:6
-#: ../raster/r.neighbors/main.c:212
-msgid "Neighborhood size"
-msgstr "Apkārtnes izmērs šūnās"
+#: ../vector/v.out.ogr/main.c:318
+#, c-format
+msgid ""
+"%d point found, but not requested to be exported. Verify 'type' parameter."
+msgid_plural ""
+"%d points found, but not requested to be exported. Verify 'type' parameter."
+msgstr[0] ""
+msgstr[1] ""
+msgstr[2] ""
-#: ../locale/scriptstrings/t.rast.neighbors_to_translate.c:11
-msgid "Number of r.neighbor processes to run in parallel"
-msgstr ""
+#: ../vector/v.out.ogr/main.c:326
+#, c-format
+msgid ""
+"%d line found, but not requested to be exported. Verify 'type' parameter."
+msgid_plural ""
+"%d line(s) found, but not requested to be exported. Verify 'type' parameter."
+msgstr[0] ""
+msgstr[1] ""
+msgstr[2] ""
-#: ../locale/scriptstrings/t.rast.neighbors_to_translate.c:13
-msgid "Ignore the current region settings and use the raster map regions"
-msgstr ""
+#: ../vector/v.out.ogr/main.c:335
+#, c-format
+msgid ""
+"%d boundary found, but not requested to be exported. Verify 'type' parameter."
+msgid_plural ""
+"%d boundaries found, but not requested to be exported. Verify 'type' "
+"parameter."
+msgstr[0] ""
+msgstr[1] ""
+msgstr[2] ""
-#: ../locale/scriptstrings/d.rast.leg_to_translate.c:1
-msgid "Displays a raster map and its legend on a graphics window"
-msgstr ""
+#: ../vector/v.out.ogr/main.c:344
+#, c-format
+msgid ""
+"%d centroid found, but not requested to be exported. Verify 'type' parameter."
+msgid_plural ""
+"%d centroids found, but not requested to be exported. Verify 'type' "
+"parameter."
+msgstr[0] ""
+msgstr[1] ""
+msgstr[2] ""
-#: ../locale/scriptstrings/d.rast.leg_to_translate.c:3
-#: ../display/d.graph/main.c:59 ../display/d.legend/main.c:79
-#: ../display/d.barscale/main.c:64 ../display/d.vect.thematic/main.c:86
-#: ../display/d.grid/main.c:54 ../display/d.legend.vect/main.c:51
-#: ../display/d.vect.chart/main.c:64 ../display/d.text/main.c:139
-#: ../display/d.title/main.c:50 ../display/d.northarrow/main.c:47
-#: ../display/d.linegraph/main.c:232
-msgid "cartography"
-msgstr ""
+#: ../vector/v.out.ogr/main.c:352
+#, c-format
+msgid ""
+"%d area found, but not requested to be exported. Verify 'type' parameter."
+msgid_plural ""
+"%d areas found, but not requested to be exported. Verify 'type' parameter."
+msgstr[0] ""
+msgstr[1] ""
+msgstr[2] ""
-#: ../locale/scriptstrings/d.rast.leg_to_translate.c:4
-#: ../display/d.legend/main.c:80 ../display/d.vect.thematic/main.c:88
-#: ../display/d.legend.vect/main.c:53
-msgid "legend"
-msgstr "leģenda"
+#: ../vector/v.out.ogr/main.c:360
+#, c-format
+msgid ""
+"%d face found, but not requested to be exported. Verify 'type' parameter."
+msgid_plural ""
+"%d faces found, but not requested to be exported. Verify 'type' parameter."
+msgstr[0] ""
+msgstr[1] ""
+msgstr[2] ""
-#: ../locale/scriptstrings/d.rast.leg_to_translate.c:5
-#: ../display/d.legend/main.c:277
-msgid "Flip legend"
-msgstr ""
+#: ../vector/v.out.ogr/main.c:368
+#, c-format
+msgid ""
+"%d volume found, but not requested to be exported. Verify 'type' parameter."
+msgid_plural ""
+"%d volumes found, but not requested to be exported. Verify 'type' parameter."
+msgstr[0] ""
+msgstr[1] ""
+msgstr[2] ""
-#: ../locale/scriptstrings/d.rast.leg_to_translate.c:6
-msgid "Omit entries with missing label"
+#: ../vector/v.out.ogr/main.c:378
+msgid ""
+"No points found, but requested to be exported. Will skip this feature type."
 msgstr ""
-#: ../locale/scriptstrings/d.rast.leg_to_translate.c:7
-msgid "Name of raster map to display"
+#: ../vector/v.out.ogr/main.c:387
+msgid ""
+"No lines found, but requested to be exported. Will skip this feature type."
 msgstr ""
-#: ../locale/scriptstrings/d.rast.leg_to_translate.c:8
-#: ../display/d.legend/main.c:272
-msgid "Draw smooth gradient"
+#: ../vector/v.out.ogr/main.c:397
+msgid ""
+"No boundaries found, but requested to be exported. Will skip this feature "
+"type."
 msgstr ""
-#: ../locale/scriptstrings/d.rast.leg_to_translate.c:9
-msgid "Number of lines to appear in the legend"
+#: ../vector/v.out.ogr/main.c:406
+msgid ""
+"No areas found, but requested to be exported. Will skip this feature type."
 msgstr ""
-#: ../locale/scriptstrings/d.rast.leg_to_translate.c:10
-msgid "Name of input raster map to generate legend from"
+#: ../vector/v.out.ogr/main.c:416
+msgid ""
+"No centroids found, but requested to be exported. Will skip this feature "
+"type."
 msgstr ""
-msgid "Drops an attribute table."
+#: ../vector/v.out.ogr/main.c:425
+msgid ""
+"No faces found, but requested to be exported. Will skip this feature type."
 msgstr ""
-#: ../locale/scriptstrings/db.droptable_to_translate.c:5
-msgid "Name of database driver"
+#: ../vector/v.out.ogr/main.c:434
+msgid ""
+"No kernels found, but requested to be exported. Will skip this feature type."
 msgstr ""
-#: ../locale/scriptstrings/db.droptable_to_translate.c:6
-msgid "If not given then default driver is used"
+#: ../vector/v.out.ogr/main.c:443
+msgid ""
+"No volumes found, but requested to be exported. Will skip this feature type."
 msgstr ""
-#: ../locale/scriptstrings/db.droptable_to_translate.c:8
-msgid "Name of database"
+#: ../vector/v.out.ogr/main.c:468
+#, c-format
+msgid "OGR driver <%s> not found"
 msgstr ""
-#: ../locale/scriptstrings/db.droptable_to_translate.c:9
-msgid "If not given then default database is used"
+#: ../vector/v.out.ogr/main.c:495
+#, c-format
+msgid "Unable to open OGR data source '%s'"
 msgstr ""
-#: ../locale/scriptstrings/db.droptable_to_translate.c:11
-msgid "Name of table to drop"
+#: ../vector/v.out.ogr/main.c:509
+#, c-format
+msgid "Layer <%s> already exists in OGR data source '%s'"
 msgstr ""
-#: ../locale/scriptstrings/t.support_to_translate.c:1
-msgid "Modifies the metadata of a space time dataset."
+#: ../vector/v.out.ogr/main.c:513
+#, c-format
+msgid "OGR layer <%s> already exists and will be overwritten"
 msgstr ""
-#: ../locale/scriptstrings/t.support_to_translate.c:5
-#: ../locale/scriptstrings/t.create_to_translate.c:7
-msgid "Semantic type of the space time dataset"
+#: ../vector/v.out.ogr/main.c:520
+#, c-format
+msgid "OGR layer <%s> doesn't exists, creating new OGR layer instead"
 msgstr ""
-#: ../locale/scriptstrings/t.support_to_translate.c:8
-msgid "Title of the space time dataset"
+#: ../vector/v.out.ogr/main.c:548
+msgid "Overriding existing user-defined 'SHPT=' LCO."
 msgstr ""
-#: ../locale/scriptstrings/t.support_to_translate.c:9
-msgid "Description of the space time dataset"
+#: ../vector/v.out.ogr/main.c:563
+#, c-format
+msgid ""
+"Vector map <%s> is 3D. Use format specific layer creation options SHPT "
+"(parameter 'lco') or '-z' flag to export in 3D rather than 2D (default)"
 msgstr ""
-#: ../locale/scriptstrings/t.support_to_translate.c:10
-msgid "Aggregation type of the space time raster or 3D raster dataset"
+#: ../vector/v.out.ogr/main.c:575
+#, c-format
+msgid ""
+"Vector map <%s> is 3D. Use format specific layer creation options DIM "
+"(parameter 'lco') to export in 3D rather than 2D (default)."
 msgstr ""
-#: ../locale/scriptstrings/t.support_to_translate.c:11
-msgid "Update the metadata information and spatial extent of registered maps from the GRASS spatial database"
+#: ../vector/v.out.ogr/main.c:582
+#, c-format
+msgid ""
+"Vector map <%s> is 3D. Use format specific layer creation options (parameter "
+"'lco') to export <in 3D rather than 2D (default)."
 msgstr ""
-#: ../locale/scriptstrings/t.support_to_translate.c:12
-msgid "Check for removed maps and delete them from the temporal database and all effected space time datasets"
+#: ../vector/v.out.ogr/main.c:599 ../db/drivers/ogr/execute.c:56
+#, c-format
+msgid "OGR layer <%s> not found"
 msgstr ""
-#: ../locale/scriptstrings/t.support_to_translate.c:13
-msgid "Update metadata information, temporal and spatial extent from registered maps based on database entries."
+#: ../vector/v.out.ogr/main.c:601
+msgid "Unable to create OGR layer"
 msgstr ""
-#: ../locale/scriptstrings/r.colors.stddev_to_translate.c:1
-msgid "Sets color rules based on stddev from a raster map's mean value."
+#: ../vector/v.out.ogr/main.c:613
+msgid "No attribute table found -> using only category numbers as attributes"
 msgstr ""
+"Atribūtu tabula nav atrasta -> tiek izmantoti kategoriju numuri kā atribūti"
-#: ../locale/scriptstrings/r.colors.stddev_to_translate.c:4
-msgid "Color using standard deviation bands"
+#: ../vector/v.out.ogr/main.c:617
+msgid "Exporting 'cat' anyway, as it is the only attribute table field"
 msgstr ""
-#: ../locale/scriptstrings/r.colors.stddev_to_translate.c:5
-msgid "Force center at zero"
+#: ../vector/v.out.ogr/main.c:626 ../vector/v.out.ogr/main.c:698
+#, c-format
+msgid "New attribute column <%s> added to the table"
 msgstr ""
-#: ../locale/scriptstrings/g.extension.all_to_translate.c:1
-msgid "Rebuilds or removes all locally installed GRASS Addons extensions."
+#: ../vector/v.out.ogr/main.c:710
+#, c-format
+msgid "Key column <%s> not found"
 msgstr ""
-#: ../locale/scriptstrings/g.extension.all_to_translate.c:2
-msgid "By default only extensions built against different GIS Library are rebuilt."
-msgstr ""
+#: ../vector/v.out.ogr/main.c:723
+#, c-format
+msgid "Exporting %d feature..."
+msgid_plural "Exporting %d features..."
+msgstr[0] ""
+msgstr[1] ""
+msgstr[2] ""
-#: ../locale/scriptstrings/g.extension.all_to_translate.c:4
-#: ../locale/scriptstrings/g.extension_to_translate.c:4
-msgid "installation"
-msgstr ""
+#: ../vector/v.out.ogr/main.c:738
+#, c-format
+msgid "Exporting %d area (may take some time)..."
+msgid_plural "Exporting %d areas (may take some time)..."
+msgstr[0] ""
+msgstr[1] ""
+msgstr[2] ""
-#: ../locale/scriptstrings/g.extension.all_to_translate.c:5
-#: ../locale/scriptstrings/g.extension_to_translate.c:5
-msgid "extensions"
-msgstr ""
+#: ../vector/v.out.ogr/main.c:757
+#, c-format
+msgid "Exporting %d volume..."
+msgid_plural "Exporting %d volumes..."
+msgstr[0] ""
+msgstr[1] ""
+msgstr[2] ""
-#: ../locale/scriptstrings/g.extension.all_to_translate.c:7
-msgid "Force operation (required for removal)"
+#: ../vector/v.out.ogr/main.c:761
+msgid "Export of volumes not implemented yet. Skipping."
 msgstr ""
-#: ../locale/scriptstrings/t.rast.list_to_translate.c:1
-msgid "Lists registered maps of a space time raster dataset."
-msgstr ""
+#: ../vector/v.out.ogr/main.c:778
+#, c-format
+msgid "%d feature without attributes was written"
+msgid_plural "%d features without attributes were written"
+msgstr[0] ""
+msgstr[1] ""
+msgstr[2] ""
-#: ../locale/scriptstrings/t.rast.list_to_translate.c:13
-msgid "The granule to be used for listing. The granule must be specified as string eg.: absolute time \"1 months\" or relative time \"1\""
-msgstr ""
+#: ../vector/v.out.ogr/main.c:784
+#, c-format
+msgid "%d feature without category was written"
+msgid_plural "%d features without category were written"
+msgstr[0] ""
+msgstr[1] ""
+msgstr[2] ""
-#: ../locale/scriptstrings/r.tileset_to_translate.c:1
-msgid "Produces tilings of the source projection for use in the destination region and projection."
-msgstr ""
+#: ../vector/v.out.ogr/main.c:788
+#, c-format
+msgid ""
+"%d feature without category was skipped. Features without category are "
+"written only when -%c flag is given."
+msgid_plural ""
+"%d features without category were skipped. Features without category are "
+msgstr[0] ""
+msgstr[1] ""
+msgstr[2] ""
-#: ../locale/scriptstrings/r.tileset_to_translate.c:3
-#: ../raster3d/r3.retile/main.c:97 ../raster/r.tile/main.c:44
-msgid "tiling"
+#: ../vector/v.out.ogr/main.c:804
+msgid "Output layer is empty, no features written"
 msgstr ""
-#: ../locale/scriptstrings/r.tileset_to_translate.c:4
-msgid "Produces shell script output"
+#: ../vector/v.out.ogr/main.c:805
+#, c-format
+msgid "%d feature (%s type) written to <%s> (%s format)."
+msgid_plural "%d features (%s type) written to <%s> (%s format)."
+msgstr[0] ""
+msgstr[1] ""
+msgstr[2] ""
+#: ../vector/v.out.ogr/export_areas.c:154
+msgid "Exporting features with category..."
 msgstr ""
-#: ../locale/scriptstrings/r.tileset_to_translate.c:5
-msgid "Produces web map server query string output"
+#: ../vector/v.out.ogr/export_areas.c:214
+msgid "Exporting features without category..."
 msgstr ""
-#: ../locale/scriptstrings/r.tileset_to_translate.c:6
-msgid "Name of region to use instead of current region for bounds and resolution"
+#: ../vector/v.out.ogr/args.c:9
+msgid "Name of input vector map to export"
 msgstr ""
-#: ../locale/scriptstrings/r.tileset_to_translate.c:7
-msgid "Source projection"
+#: ../vector/v.out.ogr/args.c:18
+msgid "Feature type(s)"
 msgstr ""
-#: ../locale/scriptstrings/r.tileset_to_translate.c:8
-#: ../locale/scriptstrings/r.tileset_to_translate.c:10
-msgid "Conversion factor from units to meters in source projection"
+#: ../vector/v.out.ogr/args.c:20
+msgid ""
+"Combination of types is not supported by all output formats. Default is to "
+"use first type found in input vector map."
 msgstr ""
-#: ../locale/scriptstrings/r.tileset_to_translate.c:9
-msgid "Destination projection, defaults to this location's projection"
+#: ../vector/v.out.ogr/args.c:25
+msgid "Name of output OGR datasource"
 msgstr ""
-#: ../locale/scriptstrings/r.tileset_to_translate.c:11
-msgid "Maximum number of columns for a tile in the source projection"
+#: ../vector/v.out.ogr/args.c:27
+msgid ""
+"For example: ESRI Shapefile: filename or directory for storage\n"
+"\t\t\tPostGIS database: connection string"
 msgstr ""
-#: ../locale/scriptstrings/r.tileset_to_translate.c:12
-msgid "Maximum number of rows for a tile in the source projection"
+#: ../vector/v.out.ogr/args.c:37
+msgid "Data format to write"
 msgstr ""
-#: ../locale/scriptstrings/r.tileset_to_translate.c:13
-msgid "Number of cells tiles should overlap in each direction"
+#: ../vector/v.out.ogr/args.c:44
+msgid "Name for output OGR layer. If not specified, input name is used"
 msgstr ""
-#: ../locale/scriptstrings/r.tileset_to_translate.c:14
-msgid "Output field separator"
-msgstr "Izvades lauku atdalītājs"
-#: ../locale/scriptstrings/v.db.addtable_to_translate.c:1
-msgid "Creates and connects a new attribute table to a given layer of an existing vector map."
+#: ../vector/v.out.ogr/args.c:46
+msgid ""
+"For example: ESRI Shapefile: shapefile name\n"
+"\t\t\tPostGIS database: table name"
 msgstr ""
-#: ../locale/scriptstrings/v.db.addtable_to_translate.c:5
-msgid "Name of new attribute table (default: vector map name)"
+#: ../vector/v.out.ogr/args.c:48 ../vector/v.out.ogr/args.c:59
+#: ../vector/v.out.ogr/args.c:69 ../vector/v.out.ogr/args.c:79
+#: ../vector/v.out.ogr/args.c:95 ../vector/v.out.ogr/args.c:108
+#: ../vector/v.out.ogr/args.c:115 ../vector/v.out.ogr/args.c:121
+#: ../vector/v.out.ogr/args.c:128 ../vector/v.out.postgis/args.c:38
+#: ../vector/v.out.postgis/args.c:48 ../vector/v.out.postgis/args.c:61
+#: ../vector/v.out.postgis/args.c:67 ../vector/v.out.postgis/args.c:73
+#: ../vector/v.out.postgis/args.c:79 ../raster/r.out.gdal/main.c:152
+#: ../raster/r.out.gdal/main.c:158 ../raster/r.out.gdal/main.c:205
+#: ../raster/r.out.gdal/main.c:216 ../raster/r.out.gdal/main.c:227
+#: ../raster/r.out.gdal/main.c:240 ../raster/r.out.gdal/main.c:251
+msgid "Creation"
 msgstr ""
-#: ../locale/scriptstrings/v.db.addtable_to_translate.c:6
-#: ../locale/scriptstrings/v.db.addtable_to_translate.c:8
-#: ../locale/scriptstrings/v.db.addtable_to_translate.c:9
-#: ../locale/scriptstrings/v.db.addtable_to_translate.c:12
-msgid "Definition"
+#: ../vector/v.out.ogr/args.c:54
+msgid "Optionally change default output type"
 msgstr ""
-#: ../locale/scriptstrings/v.db.addtable_to_translate.c:7
-msgid "Layer number where to add new attribute table"
+#: ../vector/v.out.ogr/args.c:57
+msgid "export area boundaries as linestrings"
 msgstr ""
-#: ../locale/scriptstrings/v.db.addtable_to_translate.c:10
-#: ../locale/scriptstrings/v.db.addcolumn_to_translate.c:6
-msgid "Name and type of the new column(s) ('name type [,name type, ...]')"
+#: ../vector/v.out.ogr/args.c:58
+msgid "export lines as polygons"
 msgstr ""
-#: ../locale/scriptstrings/v.db.addtable_to_translate.c:11
-#: ../locale/scriptstrings/v.db.addcolumn_to_translate.c:7
-msgid "Types depend on database backend, but all support VARCHAR(), INT, DOUBLE PRECISION and DATE. Example: 'label varchar(250), value integer'"
+#: ../vector/v.out.ogr/args.c:68
+msgid "OGR dataset creation option (format specific, NAME=VALUE)"
 msgstr ""
-#: ../locale/scriptstrings/t.rast.what_to_translate.c:1
-msgid "Sample a space time raster dataset at specific vector point coordinates and write the output to stdout using different layouts"
+#: ../vector/v.out.ogr/args.c:78
+msgid "OGR layer creation option (format specific, NAME=VALUE)"
 msgstr ""
-#: ../locale/scriptstrings/t.rast.what_to_translate.c:6
-msgid "Comma separated list of coordinates"
+#: ../vector/v.out.ogr/args.c:83
+msgid "Open an existing OGR datasource for update"
 msgstr ""
-#: ../locale/scriptstrings/t.rast.what_to_translate.c:7
-msgid "Name for the output file or \"-\" in case stdout should be used"
+#: ../vector/v.out.ogr/args.c:87
+msgid "Append to existing layer"
 msgstr ""
-#: ../locale/scriptstrings/t.rast.what_to_translate.c:8
-#: ../locale/scriptstrings/t.rast.series_to_translate.c:8
-msgid "Sort the maps by category"
+#: ../vector/v.out.ogr/args.c:88
+msgid "A new OGR layer is created if it does not exist"
 msgstr ""
-#: ../locale/scriptstrings/t.rast.what_to_translate.c:9
-msgid "The layout of the output. One point per row (row), one point per column (col), all timsteps in one row (timerow)"
+#: ../vector/v.out.ogr/args.c:94
+msgid "Skip export of GRASS category ID ('cat') attribute"
 msgstr ""
-#: ../locale/scriptstrings/t.rast.what_to_translate.c:10
-msgid "Number of r.what processes to run in parallel"
+#: ../vector/v.out.ogr/args.c:100
+msgid ""
+"Also export features without category (not labeled). Otherwise only features "
+"with category are exported."
 msgstr ""
-#: ../locale/scriptstrings/t.rast.what_to_translate.c:11
-#: ../raster/r.what/main.c:141
-msgid "Output header row"
+#: ../vector/v.out.ogr/args.c:106
+msgid "Use ESRI-style .prj file format (applies to Shapefile output only)"
 msgstr ""
-#: ../locale/scriptstrings/t.rast.what_to_translate.c:12
-msgid "Use stdin as input and ignore coordinates and point option"
+#: ../vector/v.out.ogr/args.c:112
+msgid "Force 2D output even if input is 3D (applies to Shapefile output only)"
 msgstr ""
-#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:1
-msgid "Create a 3D raster map from an assemblage of many coordinates using univariate statistics"
+#: ../vector/v.out.ogr/args.c:120
+msgid "Export vector data as multi-features"
 msgstr ""
-#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:5
-#: ../raster3d/r3.in.lidar/main.c:164 ../raster/r.in.xyz/main.c:165
-#: ../raster/r.in.lidar/main.c:110 ../vector/v.lidar.correction/main.c:72
-#: ../vector/v.out.lidar/main.c:473 ../vector/v.lidar.growing/main.c:76
-#: ../vector/v.decimate/main.c:124 ../vector/v.lidar.edgedetection/main.c:76
-#: ../vector/v.surf.bspline/main.c:94 ../vector/v.outlier/main.c:74
-#: ../vector/v.in.lidar/main.c:138
-msgid "LIDAR"
+#: ../vector/v.out.ogr/args.c:126
+msgid ""
+"Create a new empty layer in defined OGR datasource and exit. Nothing is read "
+"from input."
 msgstr ""
-#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:9
-#: ../raster3d/r3.in.lidar/main.c:168 ../raster/r.in.xyz/main.c:163
-#: ../raster/r.in.lidar/main.c:114
-msgid "binning"
+#: ../vector/v.out.ogr/args.c:133
+#, fuzzy
+msgid "List supported output formats and exit"
+msgstr "Izvadīt atbalstītos formātus un tad iziet"
+#: ../vector/v.out.ogr/create.c:20
+#, c-format
+msgid "OGR driver <%s> not available"
 msgstr ""
-#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:10
-#: ../raster3d/r3.in.lidar/main.c:303 ../raster/r.in.xyz/main.c:328
-#: ../raster/r.in.lidar/main.c:305
-msgid "Scan data file for extent then exit"
+#: ../vector/v.out.ogr/create.c:26
+#, c-format
+msgid "Creation of output OGR datasource <%s> failed"
 msgstr ""
-#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:11
-#: ../raster3d/r3.in.lidar/main.c:307 ../raster/r.in.xyz/main.c:335
-#: ../raster/r.in.lidar/main.c:310
-msgid "In scan mode, print using shell script style"
+#: ../vector/v.out.ogr/create.c:36
+#, c-format
+msgid "Creation of OGR layer <%s> failed"
 msgstr ""
-#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:12
-#: ../raster/r.in.xyz/main.c:341
-msgid "Ignore broken lines"
+#: ../vector/v.patch/main.c:73
+msgid "Creates a new vector map by combining other vector maps."
 msgstr ""
-#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:13
-msgid "ASCII file containing input data"
+#: ../vector/v.patch/main.c:84
+msgid ""
+"Name for output vector map where bounding boxes of input vector maps are "
+"written to"
 msgstr ""
-#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:15
-#: ../raster/r.in.xyz/main.c:179 ../raster/r.in.lidar/main.c:139
-msgid "Statistic to use for raster values"
+#: ../vector/v.patch/main.c:88
+msgid "Do not expect input with topology"
 msgstr ""
-#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:16
-#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:32
-#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:34
-#: ../raster/r.in.xyz/main.c:183 ../raster/r.in.xyz/main.c:315
-#: ../raster/r.in.xyz/main.c:324 ../raster/r.in.lidar/main.c:143
-#: ../raster/r.in.lidar/main.c:234 ../raster/r.in.lidar/main.c:244
-msgid "Statistic"
+#: ../vector/v.patch/main.c:90
+msgid "Applicable when input is points without topology"
 msgstr ""
-#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:17
-msgid "Storage type for resultant raster map"
+#: ../vector/v.patch/main.c:94
+msgid "Expect z coordinate even when not using topology"
 msgstr ""
-#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:19
-#: ../raster/r.in.xyz/main.c:221
-msgid "Column number of x coordinates in input file (first column is 1)"
+#: ../vector/v.patch/main.c:96
+msgid "Applicable when input is points with z coordinate but without topology"
 msgstr ""
-#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:21
-#: ../raster/r.in.xyz/main.c:229
-msgid "Column number of y coordinates in input file"
+#: ../vector/v.patch/main.c:100
+msgid "Copy also attribute table"
 msgstr ""
-#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:23
-msgid "Column number of z coordinates in input file"
+#: ../vector/v.patch/main.c:102
+msgid "Only the table of layer 1 is currently supported"
 msgstr ""
-#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:25
-#: ../raster/r.in.xyz/main.c:237
-msgid "Column number of data values in input file"
+#: ../vector/v.patch/main.c:106
+msgid ""
+"Append files to existing file (overwriting existing files must be activated)"
 msgstr ""
-#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:26
-msgid "If not given or set to 0, the data points' z-values are used"
+#: ../vector/v.patch/main.c:216
+msgid "Missing table"
 msgstr ""
-#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:28
-msgid "Filter range for value column data (min,max)"
+#: ../vector/v.patch/main.c:220
+msgid "Key columns differ"
 msgstr ""
-#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:29
-msgid "Scaling factor to apply to value column data"
+#: ../vector/v.patch/main.c:226
+msgid "Number of columns differ"
 msgstr ""
-#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:30
-#: ../raster/r.in.xyz/main.c:305 ../raster/r.in.lidar/main.c:224
-msgid "Percent of map to keep in memory"
+#: ../vector/v.patch/main.c:238
+msgid "Column names differ"
 msgstr ""
-#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:31
-#: ../raster/r.in.lidar/main.c:233
-msgid "pth percentile of the values"
+#: ../vector/v.patch/main.c:246
+msgid "Column types differ"
 msgstr ""
-#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:33
-#: ../raster/r.in.xyz/main.c:323 ../raster/r.in.lidar/main.c:243
-msgid "Discard <trim> percent of the smallest and <trim> percent of the largest observations"
+#: ../vector/v.patch/main.c:251
+msgid "Length of string columns differ"
 msgstr ""
-#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:35
-msgid "Number of parallel processes to launch"
+#: ../vector/v.patch/main.c:265
+msgid "Key column not found"
 msgstr ""
-msgid "Apply temporal and spatial operations on space time raster datasets using temporal raster algebra."
+#: ../vector/v.patch/main.c:277
+msgid "The output map is not 3D"
 msgstr ""
-#: ../locale/scriptstrings/t.rast.algebra_to_translate.c:6
-msgid "r.mapcalc expression for temporal and spatial analysis of space time raster datasets"
+#: ../vector/v.patch/main.c:349
+#, c-format
+msgid "Patching vector map <%s>..."
 msgstr ""
-#: ../locale/scriptstrings/v.pack_to_translate.c:1
-msgid "Exports a vector map as GRASS GIS specific archive file"
+#: ../vector/v.patch/main.c:373
+#, c-format
+msgid "Error reading vector map <%s> - some data may not be correct"
 msgstr ""
-#: ../locale/scriptstrings/v.pack_to_translate.c:5
-msgid "Name of vector map to pack up"
+#: ../vector/v.patch/main.c:429
+#, c-format
+msgid "Building topology for vector map <%s>..."
 msgstr ""
-#: ../locale/scriptstrings/t.shift_to_translate.c:1
-msgid "Shifts temporally the maps of a space time dataset."
+#: ../vector/v.patch/main.c:435
+msgid "Intersections at borders will have to be snapped"
 msgstr ""
-#: ../locale/scriptstrings/t.shift_to_translate.c:4
-msgid "shift"
+#: ../vector/v.patch/main.c:436
+msgid "Lines common between files will have to be edited"
 msgstr ""
-#: ../locale/scriptstrings/t.shift_to_translate.c:9
-msgid "Shift granularity"
+#: ../vector/v.patch/main.c:437
+msgid "The header information also may have to be edited"
 msgstr ""
-#: ../locale/scriptstrings/t.shift_to_translate.c:10
-msgid "Format absolute time: \"x years, x months, x weeks, x days, x hours, x minutes, x seconds\", relative time is of type integer"
+#: ../vector/v.patch/main.c:439
+#, c-format
+msgid "%d vector maps patched"
 msgstr ""
-#: ../locale/scriptstrings/g.extension_to_translate.c:1
-msgid "Maintains GRASS Addons extensions in local GRASS installation."
+#: ../vector/v.patch/main.c:462
+#, c-format
+msgid "Cannot open select cursor: '%s'"
 msgstr ""
-#: ../locale/scriptstrings/g.extension_to_translate.c:2
-msgid "Downloads and installs extensions from GRASS Addons repository or other source into the local GRASS installation or removes installed extensions."
+#: ../vector/v.patch/main.c:474
+msgid "Cannot fetch row"
 msgstr ""
-#: ../locale/scriptstrings/g.extension_to_translate.c:6
-msgid "addons"
+#: ../vector/v.patch/main.c:524
+msgid "Unknown column type"
 msgstr ""
-#: ../locale/scriptstrings/g.extension_to_translate.c:7
-msgid "download"
+#: ../vector/v.patch/main.c:532
+#, c-format
+msgid "Cannot insert new record: '%s'"
 msgstr ""
-#: ../locale/scriptstrings/g.extension_to_translate.c:8
-msgid "Name of extension to install or remove"
+#: ../vector/v.out.vtk/writeVTK.c:196
+msgid ""
+"No coordinates to generate the output! Maybe an empty vector type chosen?"
 msgstr ""
-#: ../locale/scriptstrings/g.extension_to_translate.c:9
-msgid "Name of toolbox (set of extensions) when -t flag is given"
+#: ../vector/v.out.vtk/writeVTK.c:632
+msgid "Cannot export attribute table fields for layer < 1. Skipping export"
 msgstr ""
-#: ../locale/scriptstrings/g.extension_to_translate.c:11
-msgid "URL or directory to get the extension from (supported only on Linux and Mac)"
+#: ../vector/v.out.vtk/writeVTK.c:640
+msgid "No attribute table found"
 msgstr ""
-#: ../locale/scriptstrings/g.extension_to_translate.c:12
-msgid "The official repository is used by default. User can specify a ZIP file, directory or a repository on common hosting services. If not identified, Subversion repository is assumed. See manual for all options."
+#: ../vector/v.out.vtk/writeVTK.c:673
+msgid "No numerical attributes found. Skipping export"
 msgstr ""
-#: ../locale/scriptstrings/g.extension_to_translate.c:13
-msgid "Prefix where to install extension (ignored when flag -s is given)"
+#: ../vector/v.out.vtk/writeVTK.c:732 ../vector/v.out.vtk/writeVTK.c:763
+#: ../vector/v.out.vtk/writeVTK.c:794 ../vector/v.out.vtk/writeVTK.c:823
+#, c-format
+msgid "Error reading value of attribute '%s'"
 msgstr ""
-#: ../locale/scriptstrings/g.extension_to_translate.c:14
-msgid "Set the proxy with: \"http=<value>,ftp=<value>\""
+#: ../vector/v.out.vtk/main.c:51
+msgid "Converts a vector map to VTK ASCII output."
 msgstr ""
-#: ../locale/scriptstrings/g.extension_to_translate.c:15
-msgid "List available extensions in the official GRASS GIS Addons repository"
+#: ../vector/v.out.vtk/main.c:59
+msgid "Name for output VTK file"
 msgstr ""
-#: ../locale/scriptstrings/g.extension_to_translate.c:17
-msgid "List available extensions in the official GRASS GIS Addons repository including module description"
+#: ../vector/v.out.vtk/main.c:70 ../vector/v.out.ascii/args.c:75
+#: ../raster/r.out.vtk/parameters.c:98 ../raster/r.out.ascii/main.c:79
+#: ../raster3d/r3.out.vtk/parameters.c:107 ../display/d.rast.num/main.c:104
+msgid "Number of significant digits (floating point only)"
 msgstr ""
-#: ../locale/scriptstrings/g.extension_to_translate.c:19
-msgid "List available extensions in the official GRASS GIS Addons repository (shell script style)"
+#: ../vector/v.out.vtk/main.c:76 ../raster/r.out.vtk/parameters.c:85
+#: ../raster3d/r3.out.vtk/parameters.c:94
+msgid "Scale factor for elevation"
 msgstr ""
-#: ../locale/scriptstrings/g.extension_to_translate.c:21
-msgid "List locally installed extensions"
+#: ../vector/v.out.vtk/main.c:84
+#: ../locale/scriptstrings/t.rast.out.vtk_to_translate.c:10
+msgid "Correct the coordinates to fit the VTK-OpenGL precision"
 msgstr ""
-#: ../locale/scriptstrings/g.extension_to_translate.c:23
-msgid "Install system-wide (may need system administrator rights)"
+#: ../vector/v.out.vtk/main.c:89
+msgid "Export numeric attribute table fields as VTK scalar variables"
 msgstr ""
-#: ../locale/scriptstrings/g.extension_to_translate.c:24
-#: ../locale/scriptstrings/g.extension_to_translate.c:26
-#: ../locale/scriptstrings/g.extension_to_translate.c:28
-msgid "Install"
+#: ../vector/v.out.vtk/main.c:153 ../vector/v.out.ascii/args.c:109
+msgid "Failed to interpret 'dp' parameter as an integer"
 msgstr ""
-#: ../locale/scriptstrings/g.extension_to_translate.c:25
-msgid "Download source code and exit"
+#: ../vector/v.out.vtk/main.c:155
+msgid "dp has to be from 0 to 8"
 msgstr ""
-#: ../locale/scriptstrings/g.extension_to_translate.c:27
-msgid "Do not install new extension, just compile it"
+#: ../vector/v.out.vtk/main.c:164
+msgid "Failed to interpret 'layer' parameter as an integer"
 msgstr ""
-#: ../locale/scriptstrings/g.extension_to_translate.c:29
-msgid "Force removal when uninstalling extension (operation=remove)"
+#: ../vector/v.out.vtk/main.c:183
+#, c-format
+msgid ""
+"Export of areas requires topology. Please adjust '%s' option or rebuild "
+"topology."
 msgstr ""
-#: ../locale/scriptstrings/g.extension_to_translate.c:31
-msgid "Operate on toolboxes instead of single modules (experimental)"
+#: ../vector/v.out.vtk/head.c:27
+msgid "writeVTKHeader: Writing VTK-Header"
 msgstr ""
-#: ../locale/scriptstrings/t.rast.extract_to_translate.c:1
-msgid "Extracts a subset of a space time raster datasets."
+#: ../vector/v.in.pdal/filters.c:46
+#, c-format
+msgid "4 values required for '%s' option"
 msgstr ""
-#: ../locale/scriptstrings/t.rast.extract_to_translate.c:6
-msgid "r.mapcalc expression assigned to all extracted raster maps"
+#: ../vector/v.in.pdal/filters.c:68 ../vector/v.in.lidar/main.c:435
+#: ../vector/v.decimate/main.c:294
+#, c-format
+msgid "Invalid zrange <%s>"
 msgstr ""
-#: ../locale/scriptstrings/v.db.join_to_translate.c:1
-msgid "Joins a database table to a vector map table."
+#: ../vector/v.in.pdal/filters.c:95 ../vector/v.in.lidar/filters.c:36
+#: ../raster3d/r3.in.lidar/filters.c:54
+#, c-format
+msgid "Unknown return filter value <%s>"
 msgstr ""
-#: ../locale/scriptstrings/v.db.join_to_translate.c:5
-msgid "Vector map to which to join other table"
+#: ../vector/v.in.pdal/projection.c:37 ../vector/v.in.lidar/projection.c:38
+#: ../raster/r.in.lidar/projection.c:40 ../raster3d/r3.in.lidar/projection.c:42
+msgid "GRASS LOCATION PROJ_INFO is:\n"
 msgstr ""
-#: ../locale/scriptstrings/v.db.join_to_translate.c:7
-msgid "Layer where to join"
+#: ../vector/v.in.pdal/projection.c:46 ../vector/v.in.pdal/projection.c:52
+#: ../vector/v.in.lidar/projection.c:47 ../vector/v.in.lidar/projection.c:53
+#: ../raster/r.in.lidar/projection.c:49 ../raster/r.in.lidar/projection.c:55
+#: ../raster3d/r3.in.lidar/projection.c:51
+#: ../raster3d/r3.in.lidar/projection.c:57
+msgid "Import dataset PROJ_INFO is:\n"
 msgstr ""
-#: ../locale/scriptstrings/v.db.join_to_translate.c:9
-msgid "Identifier column (e.g.: cat) in the vector table to be used for join"
+#: ../vector/v.in.pdal/projection.c:92 ../vector/v.in.lidar/projection.c:93
+#: ../raster/r.in.lidar/projection.c:95 ../raster3d/r3.in.lidar/projection.c:97
+msgid ""
+"Consider generating a new location with 'location' parameter from input data "
+"set.\n"
 msgstr ""
-#: ../locale/scriptstrings/v.db.join_to_translate.c:10
-msgid "Other table name"
+#: ../vector/v.in.pdal/projection.c:110 ../vector/v.in.pdal/projection.c:156
+#: ../vector/v.in.pdal/projection.c:189 ../vector/v.in.lidar/projection.c:111
+#: ../raster/r.in.lidar/projection.c:113
+#: ../raster3d/r3.in.lidar/projection.c:115
+msgid ""
+"Unable to convert input map projection information to GRASS format for "
+"checking"
 msgstr ""
-#: ../locale/scriptstrings/v.db.join_to_translate.c:11
-msgid "ocolumn,scolumns"
+#: ../vector/v.in.pdal/projection.c:125
+msgid "Overriding projection check"
 msgstr ""
-#: ../locale/scriptstrings/v.db.join_to_translate.c:12
-msgid "Identifier column (e.g.: id) in the other table used for join"
+#: ../vector/v.vol.rst/user3.c:548
+msgid "Secpar_loop failed"
 msgstr ""
-#: ../locale/scriptstrings/v.db.join_to_translate.c:13
-msgid "Subset of columns from the other table"
+#: ../vector/v.vol.rst/user3.c:588 ../vector/v.vol.rst/user3.c:599
+#: ../vector/v.vol.rst/user3.c:610 ../vector/v.vol.rst/user3.c:621
+#: ../vector/v.vol.rst/user3.c:632 ../vector/v.vol.rst/user3.c:643
+#: ../vector/v.vol.rst/user3.c:654 ../vector/v.vol.rst/user3.c:665
+msgid "Not enough disk space--cannot write files"
 msgstr ""
-#: ../locale/scriptstrings/v.db.droptable_to_translate.c:1
-msgid "Removes existing attribute table of a vector map."
+#: ../vector/v.vol.rst/vector.c:80 ../vector/v.in.lidar/attributes.c:240
+#: ../vector/v.random/main.c:471 ../vector/v.random/main.c:591
+#: ../raster/r.volume/main.c:296 ../raster/r.to.vect/util.c:157
+#: ../raster/r.to.vect/areas_io.c:359
+#, c-format
+msgid "Cannot insert new row: %s"
+msgstr "Nevar izveidot jaunu rindu: %s"
+#: ../vector/v.vol.rst/main.c:236 ../vector/v.to.rast3/main.c:50
+#: ../raster/r.to.rast3elev/main.c:364 ../raster/r.to.rast3/main.c:199
+#: ../locale/scriptstrings/t.rast3d.univar_to_translate.c:5
+#: ../locale/scriptstrings/t.rast.to.rast3_to_translate.c:6
+#: ../locale/scriptstrings/t.rast3d.mapcalc_to_translate.c:5
+#: ../locale/scriptstrings/t.rast3d.list_to_translate.c:6
+#: ../locale/scriptstrings/t.rast3d.extract_to_translate.c:5
+#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:4
+#: ../locale/scriptstrings/t.rast3d.algebra_to_translate.c:5
+#: ../raster3d/r3.out.bin/main.c:207 ../raster3d/r3.out.v5d/main.c:286
+#: ../raster3d/r3.mkdspf/main.c:81 ../raster3d/r3.in.v5d/main.c:180
+#: ../raster3d/r3.in.bin/main.c:254 ../raster3d/r3.out.netcdf/main.c:589
+#: ../raster3d/r3.in.ascii/main.c:356 ../raster3d/r3.gwflow/main.c:161
+#: ../raster3d/r3.retile/main.c:98 ../raster3d/r3.stats/main.c:50
+#: ../raster3d/r3.gradient/main.c:45 ../raster3d/r3.cross.rast/main.c:231
+#: ../raster3d/r3.neighbors/main.c:210 ../raster3d/r3.to.rast/main.c:262
+#: ../raster3d/r3.info/main.c:77 ../raster3d/r3.null/main.c:182
+#: ../raster3d/r3.timestamp/main.c:47 ../raster3d/r3.mask/main.c:135
+#: ../raster3d/r3.out.ascii/main.c:304 ../raster3d/r3.out.vtk/main.c:378
+#: ../raster3d/r3.flow/main.c:181 ../raster3d/r3.support/main.c:51
+msgid "voxel"
 msgstr ""
-#: ../locale/scriptstrings/v.db.droptable_to_translate.c:5
-msgid "Force removal (required for actual deletion of table)"
+#: ../vector/v.vol.rst/main.c:239
+msgid "RST"
 msgstr ""
-#: ../locale/scriptstrings/v.db.droptable_to_translate.c:6
-msgid "Table name (default: vector map name)"
+#: ../vector/v.vol.rst/main.c:241
+msgid ""
+"Interpolates point data to a 3D raster map using regularized spline with "
+"tension (RST) algorithm."
 msgstr ""
-#: ../locale/scriptstrings/t.create_to_translate.c:1
-msgid "Creates a space time dataset."
+#: ../vector/v.vol.rst/main.c:246
+msgid "Name of input 3D vector points map"
 msgstr ""
-#: ../locale/scriptstrings/t.create_to_translate.c:4
-msgid "create"
+#: ../vector/v.vol.rst/main.c:253
+msgid "Name of input surface raster map for cross-section"
 msgstr ""
-#: ../locale/scriptstrings/t.create_to_translate.c:6
-msgid "Type of the output space time dataset"
+#: ../vector/v.vol.rst/main.c:254 ../vector/v.vol.rst/main.c:303
+#: ../imagery/i.vi/main.c:142 ../imagery/i.vi/main.c:150
+#: ../imagery/i.vi/main.c:158 ../imagery/i.vi/main.c:166
+#: ../imagery/i.vi/main.c:174
+msgid "Optional inputs"
 msgstr ""
-#: ../locale/scriptstrings/t.create_to_translate.c:8
-#: ../locale/scriptstrings/t.rast.import_to_translate.c:9
-#: ../locale/scriptstrings/t.vect.import_to_translate.c:9
-msgid "Title of the new space time dataset"
+#: ../vector/v.vol.rst/main.c:260
+msgid "Name of column containing w-values attribute to interpolate"
 msgstr ""
-#: ../locale/scriptstrings/t.create_to_translate.c:9
-#: ../locale/scriptstrings/t.rast.import_to_translate.c:10
-#: ../locale/scriptstrings/t.vect.import_to_translate.c:10
-msgid "Description of the new space time dataset"
+#: ../vector/v.vol.rst/main.c:282
+msgid "Name of column with smoothing parameters"
 msgstr ""
-#: ../locale/scriptstrings/t.rast.export_to_translate.c:1
-msgid "Exports space time raster dataset."
+#: ../vector/v.vol.rst/main.c:302
+msgid "Name of input raster map used as mask"
 msgstr ""
-#: ../locale/scriptstrings/t.rast.export_to_translate.c:6
-msgid "Name of a space time raster dataset archive"
+#: ../vector/v.vol.rst/main.c:328
+msgid "Maximum number of points for approximation in a segment (>npmin)"
 msgstr ""
-#: ../locale/scriptstrings/t.rast.export_to_translate.c:9
-msgid "The export format of a single raster map"
+#: ../vector/v.vol.rst/main.c:345
+msgid "Conversion factor for w-values used for interpolation"
 msgstr ""
-#: ../locale/scriptstrings/t.rast.export_to_translate.c:10
-msgid "Supported are GTiff, AAIGrid via r.out.gdal and the GRASS package format of r.pack"
+#: ../vector/v.vol.rst/main.c:353
+msgid "Conversion factor for z-values"
 msgstr ""
-#: ../locale/scriptstrings/t.rast.export_to_translate.c:11
-#: ../raster/r.out.gdal/main.c:198
-msgid "Data type"
-msgstr "Datu tips"
-#: ../locale/scriptstrings/t.rast.export_to_translate.c:12
-msgid "Supported only for GTiff"
+#: ../vector/v.vol.rst/main.c:359
+msgid "Name for output cross-section raster map"
 msgstr ""
-#: ../locale/scriptstrings/t.unregister_to_translate.c:1
-msgid "Unregisters raster, vector and raster3d maps from the temporal database or a specific space time dataset."
+#: ../vector/v.vol.rst/main.c:365
+msgid "Name for output elevation 3D raster map"
 msgstr ""
-#: ../locale/scriptstrings/t.unregister_to_translate.c:4
-msgid "unregister"
+#: ../vector/v.vol.rst/main.c:371
+msgid "Name for output gradient magnitude 3D raster map"
 msgstr ""
-#: ../locale/scriptstrings/t.unregister_to_translate.c:6
-#: ../locale/scriptstrings/t.register_to_translate.c:10
-msgid "Input file with map names, one per line"
+#: ../vector/v.vol.rst/main.c:378
+msgid "Name for output gradient horizontal angle 3D raster map"
 msgstr ""
-#: ../locale/scriptstrings/t.unregister_to_translate.c:7
-#: ../locale/scriptstrings/t.register_to_translate.c:8
-msgid "input,maps"
+#: ../vector/v.vol.rst/main.c:384
+msgid "Name for output gradient vertical angle 3D raster map"
 msgstr ""
-#: ../locale/scriptstrings/t.unregister_to_translate.c:8
-msgid "Name(s) of existing raster, vector or raster3d map(s) to unregister"
+#: ../vector/v.vol.rst/main.c:390
+msgid "Name for output change of gradient 3D raster map"
 msgstr ""
-#: ../locale/scriptstrings/i.colors.enhance_to_translate.c:1
-msgid "Performs auto-balancing of colors for RGB images."
+#: ../vector/v.vol.rst/main.c:396
+msgid "Name for output Gaussian curvature 3D raster map"
 msgstr ""
-#: ../locale/scriptstrings/i.colors.enhance_to_translate.c:4
-#: ../imagery/i.modis.qc/main.c:173 ../imagery/i.landsat.toar/main.c:76
-#: ../imagery/i.albedo/main.c:98 ../imagery/i.aster.toar/main.c:102
-#: ../imagery/i.landsat.acca/main.c:108
-msgid "satellite"
+#: ../vector/v.vol.rst/main.c:402
+msgid "Name for output mean curvature 3D raster map"
 msgstr ""
-#: ../locale/scriptstrings/i.colors.enhance_to_translate.c:5
-#: ../display/d.colorlist/main.c:37
-msgid "colors"
-msgstr "krāsas"
-#: ../locale/scriptstrings/i.colors.enhance_to_translate.c:6
-msgid "Name of red channel"
+#: ../vector/v.vol.rst/main.c:408
+msgid "Perform a cross-validation procedure without volume interpolation"
 msgstr ""
-#: ../locale/scriptstrings/i.colors.enhance_to_translate.c:7
-msgid "Name of green channel"
+#: ../vector/v.vol.rst/main.c:471
+msgid "Smoothing must be a positive value"
 msgstr ""
-#: ../locale/scriptstrings/i.colors.enhance_to_translate.c:8
-msgid "Name of blue channel"
+#: ../vector/v.vol.rst/main.c:477
+#, c-format
+msgid "Both crossvalidation options (-%c, %s) must be specified"
 msgstr ""
-#: ../locale/scriptstrings/i.colors.enhance_to_translate.c:9
-msgid "Cropping intensity (upper brightness level)"
+#: ../vector/v.vol.rst/main.c:480
+msgid "Both crossvalidation and deviations must be specified"
 msgstr ""
-#: ../locale/scriptstrings/i.colors.enhance_to_translate.c:10
-msgid "Extend colors to full range of data on each channel"
+#: ../vector/v.vol.rst/main.c:491
+msgid ""
+"Crossvalidation cannot be computed simultanuously with output grids or devi "
+"file"
 msgstr ""
-#: ../locale/scriptstrings/i.colors.enhance_to_translate.c:11
-#: ../locale/scriptstrings/i.colors.enhance_to_translate.c:13
-#: ../locale/scriptstrings/i.colors.enhance_to_translate.c:15
-#: ../display/d.rast.arrow/main.c:119 ../display/d.rast.arrow/main.c:125
-#: ../display/d.rast.arrow/main.c:131 ../display/d.rast.arrow/main.c:137
-#: ../display/d.vect/main.c:120 ../display/d.vect/main.c:126
-#: ../display/d.vect/main.c:130 ../display/d.vect/main.c:137
-#: ../display/d.vect/main.c:308 ../display/d.rast.num/main.c:89
-#: ../display/d.rast.num/main.c:95 ../display/d.rast.num/main.c:113
-#: ../display/d.barscale/main.c:153 ../display/d.barscale/main.c:159
-#: ../display/d.northarrow/main.c:104 ../display/d.northarrow/main.c:109
-#: ../display/d.northarrow/main.c:115 ../vector/v.label.sa/main.c:103
-#: ../vector/v.label.sa/main.c:113 ../vector/v.label.sa/main.c:120
-#: ../vector/v.label.sa/main.c:130 ../vector/v.label.sa/main.c:140
-#: ../vector/v.label.sa/main.c:150 ../vector/v.label.sa/main.c:157
-#: ../vector/v.label/main.c:152 ../vector/v.label/main.c:176
-#: ../vector/v.label/main.c:189 ../vector/v.label/main.c:195
-#: ../vector/v.label/main.c:205
-msgid "Colors"
-msgstr "Krāsas"
-#: ../locale/scriptstrings/i.colors.enhance_to_translate.c:12
-msgid "Preserve relative colors, adjust brightness only"
+#: ../vector/v.vol.rst/main.c:555
+#, c-format
+msgid "Unable to open %s"
 msgstr ""
-#: ../locale/scriptstrings/i.colors.enhance_to_translate.c:14
-msgid "Reset to standard color range"
+#: ../vector/v.vol.rst/main.c:563
+msgid "Vector is not 3D"
 msgstr ""
-#: ../locale/scriptstrings/i.colors.enhance_to_translate.c:16
-#: ../locale/scriptstrings/i.oif_to_translate.c:7
-msgid "Process bands serially (default: run in parallel)"
+#: ../vector/v.vol.rst/main.c:615 ../vector/v.colors/main.c:312
+#: ../raster/r.geomorphon/memory.c:14 ../raster/r.stream.extract/main.c:173
+#: ../raster/r.stream.extract/main.c:177 ../raster/r.stream.extract/main.c:182
+#: ../raster/r.buffer/main.c:112 ../raster/r.kappa/main.c:150
+#: ../raster/r.kappa/stats.c:33 ../raster/r.kappa/stats.c:38
+#: ../raster/r.null/main.c:128 ../raster/r.walk/main.c:435
+#: ../raster/r.walk/main.c:440 ../raster/r.walk/main.c:801
+#: ../raster/r.distance/parse.c:72 ../raster/r.distance/parse.c:81
+#: ../raster/r.compress/main.c:124 ../raster/r.compress/main.c:304
+#: ../raster/r.ros/main.c:368 ../raster/r.ros/main.c:379
+#: ../raster/r.ros/main.c:384 ../raster/r.ros/main.c:389
+#: ../raster/r.ros/main.c:394 ../raster/r.ros/main.c:408
+#: ../raster/r.ros/main.c:412 ../raster/r.ros/main.c:427
+#: ../raster/r.ros/main.c:431 ../raster/r.ros/main.c:442
+#: ../raster/r.univar/r.univar_main.c:234 ../raster/r.report/parse.c:273
+#: ../raster/r.info/main.c:104 ../raster/r.coin/main.c:121
+#: ../raster/r.coin/main.c:123 ../raster/r.mapcalc/map3.c:710
+#: ../raster/r.mapcalc/map.c:519 ../raster/r.mapcalc/map.c:813
+#: ../raster/r.tile/main.c:86 ../raster/r.cross/main.c:106
+#: ../raster/r.cost/main.c:350 ../raster/r.cost/main.c:665
+#: ../raster/r.reclass/main.c:79 ../raster/r.spread/main.c:439
+#: ../raster/r.spread/main.c:442 ../raster/r.spread/main.c:445
+#: ../raster/r.spread/main.c:449 ../raster/r.spread/main.c:452
+#: ../raster/r.spread/main.c:455 ../raster/r.flow/io.c:65
+#: ../raster/r.flow/io.c:242 ../raster/r.fill.stats/main.c:1028
+#: ../raster/r.colors/edit_colors.c:393 ../raster/r.sim/simlib/output.c:363
+#: ../raster/r.sim/simlib/output.c:372 ../raster/r.sim/simlib/output.c:403
+#: ../raster/r.sim/simlib/output.c:412 ../raster/r.sim/simlib/output.c:458
+#: ../raster/r.sim/simlib/output.c:475 ../raster/r.sim/simlib/output.c:497
+#: ../raster/r.sim/simlib/output.c:541 ../raster/r.sim/simlib/output.c:583
+#: ../raster/r.sim/simlib/output.c:755 ../raster/r.carve/main.c:165
+#: ../raster/r.category/main.c:119 ../raster/r.category/main.c:140
+#: ../general/g.region/main.c:429 ../general/g.region/main.c:766
+#: ../general/g.region/main.c:774 ../misc/m.nviz.image/surface.c:50
+#: ../misc/m.nviz.image/surface.c:107 ../doc/raster/r.example/main.c:105
+#: ../imagery/i.ortho.photo/i.ortho.elev/main.c:197
+#: ../imagery/i.gensigset/parse.c:44 ../imagery/i.gensig/parse.c:38
+#: ../imagery/i.pca/main.c:139 ../scripts/d.correlate/d.correlate.py:50
+#: ../scripts/r.grow/r.grow.py:123 ../scripts/r.mask/r.mask.py:131
+#: ../scripts/r.fillnulls/r.fillnulls.py:149
+#: ../scripts/r.buffer.lowmem/r.buffer.lowmem.py:87
+#: ../scripts/r.pack/r.pack.py:74 ../scripts/v.rast.stats/v.rast.stats.py:128
+#: ../scripts/d.polar/d.polar.py:62
+#: ../scripts/r.reclass.area/r.reclass.area.py:103
+#: ../scripts/r.reclass.area/r.reclass.area.py:213
+#: ../scripts/d.rast.leg/d.rast.leg.py:99
+#: ../scripts/d.rast.leg/d.rast.leg.py:103 ../scripts/r.rgb/r.rgb.py:60
+msgid "Raster map <%s> not found"
 msgstr ""
-#: ../locale/scriptstrings/v.centroids_to_translate.c:1
-msgid "Adds missing centroids to closed boundaries."
+#: ../vector/v.vol.rst/main.c:628 ../vector/v.vol.rst/main.c:659
+#: ../vector/v.vol.rst/main.c:681 ../vector/v.vol.rst/main.c:703
+#: ../vector/v.vol.rst/main.c:725 ../vector/v.vol.rst/main.c:747
+#: ../vector/v.vol.rst/main.c:769 ../vector/v.vol.rst/main.c:791
+#, c-format
+msgid "Unable to open temp file '%s'"
 msgstr ""
-#: ../locale/scriptstrings/v.centroids_to_translate.c:3
-#: ../vector/v.category/main.c:691
-msgid "centroid"
+#: ../vector/v.vol.rst/main.c:636 ../vector/v.vol.rst/main.c:665
+#: ../vector/v.vol.rst/main.c:687 ../vector/v.vol.rst/main.c:709
+#: ../vector/v.vol.rst/main.c:731 ../vector/v.vol.rst/main.c:753
+#: ../vector/v.vol.rst/main.c:775 ../vector/v.vol.rst/main.c:797
+msgid "Not enough disk space - cannot write temp files"
 msgstr ""
-#: ../locale/scriptstrings/v.centroids_to_translate.c:5
-msgid "Action to be taken"
+#: ../vector/v.vol.rst/main.c:640
+#, c-format
+msgid ""
+"Unable to create <%s> raster map without cross_input raster map being "
+"specified"
 msgstr ""
-#: ../locale/scriptstrings/v.centroids_to_translate.c:6
-msgid "Category number starting value"
+#: ../vector/v.vol.rst/main.c:818
+msgid "Finished interpolating"
 msgstr ""
-#: ../locale/scriptstrings/v.centroids_to_translate.c:7
-#: ../vector/v.category/main.c:134
-msgid "Category increment"
+#: ../vector/v.vol.rst/main.c:853
+#, c-format
+msgid "Raster map <%s> created"
 msgstr ""
-msgid "Imports space time raster dataset."
+#: ../vector/v.vol.rst/main.c:893
+#, c-format
+msgid "Vector map <%s> created"
 msgstr ""
-#: ../locale/scriptstrings/t.rast.import_to_translate.c:8
-#: ../locale/scriptstrings/t.vect.import_to_translate.c:8
-msgid "Path to the extraction directory"
+#: ../vector/v.vol.rst/main.c:909
+msgid "Interpolation failed"
 msgstr ""
-#: ../locale/scriptstrings/t.rast.import_to_translate.c:11
-#: ../locale/scriptstrings/t.vect.import_to_translate.c:11
-msgid "Create a new location and import the data into it. Do not run this module in parallel or interrupt it when a new location should be created"
+#: ../vector/v.vol.rst/user2.c:213
+msgid "Cannot allocate A"
 msgstr ""
-#: ../locale/scriptstrings/t.rast.import_to_translate.c:14
-msgid "Set the current region from the last map that was imported"
+#: ../vector/v.vol.rst/user2.c:217
+msgid "Cannot allocate b"
 msgstr ""
-#: ../locale/scriptstrings/t.rast.import_to_translate.c:15
-msgid "Link the raster files using r.external"
+#: ../vector/v.vol.rst/user2.c:221
+msgid "Cannot allocate w"
 msgstr ""
-#: ../locale/scriptstrings/t.rast.import_to_translate.c:16
-#: ../locale/scriptstrings/t.vect.import_to_translate.c:12
-msgid "Extend location extents based on new dataset"
-msgstr "Paplašināt novietojuma apjomu pamatojoties uz jauno datu kopu"
-#: ../locale/scriptstrings/t.rast.import_to_translate.c:19
-msgid "Create the location specified by the \"location\" parameter and exit. Do not import the space time raster datasets."
+#: ../vector/v.vol.rst/user1.c:109
+msgid "Column type of wcolumn is not supported (must be integer or double)"
 msgstr ""
-#: ../locale/scriptstrings/r.plane_to_translate.c:1
-msgid "Creates raster plane map given dip (inclination), aspect (azimuth) and one point."
+#: ../vector/v.vol.rst/user1.c:123
+msgid "Cannot read column type of smooth column"
 msgstr ""
-#: ../locale/scriptstrings/r.plane_to_translate.c:4
-msgid "Dip of plane in degrees"
+#: ../vector/v.vol.rst/user1.c:126
+msgid "Column type of smooth column (datetime) is not supported"
 msgstr ""
-#: ../locale/scriptstrings/r.plane_to_translate.c:5
-msgid "Azimuth of the plane in degrees"
+#: ../vector/v.vol.rst/user1.c:128
+msgid ""
+"Column type of smooth column is not supported (must be integer or double)"
 msgstr ""
-#: ../locale/scriptstrings/r.plane_to_translate.c:6
-msgid "Easting coordinate of a point on the plane"
+#: ../vector/v.vol.rst/user1.c:150
+msgid "Point without category"
 msgstr ""
-#: ../locale/scriptstrings/r.plane_to_translate.c:7
-msgid "Northing coordinate of a point on the plane"
+#: ../vector/v.vol.rst/user1.c:208
+msgid "Some points outside of region -- will ignore..."
 msgstr ""
-#: ../locale/scriptstrings/r.plane_to_translate.c:8
-msgid "Elevation coordinate of a point on the plane"
+#: ../vector/v.vol.rst/user1.c:215
+msgid "Cannot allocate memory for point"
 msgstr ""
-#: ../locale/scriptstrings/t.topology_to_translate.c:1
-msgid "Lists temporal topology of a space time dataset."
+#: ../vector/v.vol.rst/user1.c:223
+#, c-format
+msgid "Can't insert %lf,%lf,%lf,%lf,%lf a=%d"
 msgstr ""
-#: ../locale/scriptstrings/t.topology_to_translate.c:7
-msgid "Print temporal topological relationships and exit"
+#: ../vector/v.vol.rst/user1.c:270
+msgid "Strip exists with insufficient data"
 msgstr ""
-#: ../locale/scriptstrings/t.topology_to_translate.c:8
-msgid "Print spatio-temporal topological relationships and exit"
+#: ../vector/v.vol.rst/user1.c:280
+msgid "Zero segments!"
 msgstr ""
-#: ../locale/scriptstrings/i.oif_to_translate.c:1
-msgid "Calculates Optimum-Index-Factor table for spectral bands"
+#: ../vector/v.vol.rst/user1.c:311
+#, c-format
+msgid ""
+"There are points outside specified 2D/3D region--ignored %d points (total "
+"points: %d)"
 msgstr ""
-#: ../locale/scriptstrings/i.oif_to_translate.c:5
-#: ../locale/scriptstrings/r.out.xyz_to_translate.c:6
-#: ../raster/r.univar/r3.univar_main.c:42 ../raster/r.univar/r.univar_main.c:41
-#: ../raster/r.quantile/main.c:296 ../raster/r.stats.quantile/main.c:555
-#: ../raster/r.what/main.c:125 ../raster/r.stats/main.c:119
-#: ../vector/v.db.select/main.c:95 ../db/db.select/main.c:241
-msgid "Name for output file (if omitted or \"-\" output to stdout)"
+#: ../vector/v.vol.rst/user1.c:315
+#, c-format
+msgid ""
+"Points are more dense than specified 'DMIN'--ignored %d points (remain %d)"
 msgstr ""
-#: ../locale/scriptstrings/t.vect.list_to_translate.c:1
-msgid "Lists registered maps of a space time vector dataset."
+#: ../vector/v.vol.rst/user1.c:321
+#, c-format
+msgid ""
+"%d points given for interpolation (after thinning) is less than given NPMIN="
+"%d"
 msgstr ""
-#: ../locale/scriptstrings/r.grow_to_translate.c:1
-msgid "Generates a raster map layer with contiguous areas grown by one cell."
-msgstr "Ģenerē rastra karti, kur vienlaidus apgabali ir palielināti par vienu šūnu."
-#: ../locale/scriptstrings/r.grow_to_translate.c:4
-#: ../raster/r.grow.distance/main.c:152
-msgid "proximity"
+#: ../vector/v.vol.rst/user1.c:341
+#, c-format
+msgid ""
+"There is less than %d points for interpolation, no segmentation is "
+"necessary, to run the program faster, set segmax=%d (see manual)"
 msgstr ""
-#: ../locale/scriptstrings/r.grow_to_translate.c:5
-msgid "Radius is in map units rather than cells"
+#: ../vector/v.vol.rst/user1.c:368
+#, c-format
+msgid "Mask raster map [%s] not found"
 msgstr ""
-#: ../locale/scriptstrings/r.grow_to_translate.c:6
-msgid "Radius of buffer in raster cells"
-msgstr "Bufera zonas rādiuss rastra šūnās"
-#: ../locale/scriptstrings/r.grow_to_translate.c:7
-#: ../raster/r.grow.distance/main.c:174
-msgid "Metric"
-msgstr "Metriskā"
-#: ../locale/scriptstrings/r.grow_to_translate.c:8
-msgid "Value to write for input cells which are non-NULL (-1 => NULL)"
+#: ../vector/v.vol.rst/user1.c:383
+msgid "Bitmap mask created"
 msgstr ""
-#: ../locale/scriptstrings/r.grow_to_translate.c:9
-msgid "Value to write for \"grown\" cells"
-msgstr "Vērtība \"pieaudzētajām\" šūnām"
-#: ../locale/scriptstrings/i.image.mosaic_to_translate.c:1
-msgid "Mosaics several images and extends colormap."
+#: ../vector/v.vol.rst/user1.c:432 ../vector/v.vol.rst/user1.c:485
+#: ../vector/v.vol.rst/user1.c:538 ../vector/v.vol.rst/user1.c:591
+#: ../vector/v.vol.rst/user1.c:644 ../vector/v.vol.rst/user1.c:697
+#: ../vector/v.vol.rst/user1.c:750
+#, c-format
+msgid "Unable to open %s for writing"
 msgstr ""
-#: ../locale/scriptstrings/i.image.mosaic_to_translate.c:4
-#: ../raster/r.patch/main.c:60
-msgid "mosaicking"
+#: ../vector/v.vol.rst/user1.c:443 ../vector/v.vol.rst/user1.c:496
+#: ../vector/v.vol.rst/user1.c:549 ../vector/v.vol.rst/user1.c:602
+#: ../vector/v.vol.rst/user1.c:655 ../vector/v.vol.rst/user1.c:708
+#: ../vector/v.vol.rst/user1.c:761
+msgid "Unable to read data from temp file"
 msgstr ""
-#: ../locale/scriptstrings/v.report_to_translate.c:1
-msgid "Reports geometry statistics for vector maps."
+#: ../vector/v.vol.rst/user1.c:461 ../vector/v.vol.rst/user1.c:514
+#: ../vector/v.vol.rst/user1.c:567 ../vector/v.vol.rst/user1.c:620
+#: ../vector/v.vol.rst/user1.c:673 ../vector/v.vol.rst/user1.c:726
+#: ../vector/v.vol.rst/user1.c:779
+#, c-format
+msgid "Error writing cell (%d,%d,%d) with value %f"
 msgstr ""
-#: ../locale/scriptstrings/v.report_to_translate.c:6
-msgid "Value to calculate"
+#: ../vector/v.vol.rst/user1.c:474 ../vector/v.vol.rst/user1.c:527
+#: ../vector/v.vol.rst/user1.c:580 ../vector/v.vol.rst/user1.c:633
+#: ../vector/v.vol.rst/user1.c:686 ../vector/v.vol.rst/user1.c:739
+#: ../vector/v.vol.rst/user1.c:792
+#, c-format
+msgid "Error closing output file %s"
 msgstr ""
-#: ../locale/scriptstrings/v.report_to_translate.c:7
-msgid "Sort the result"
+#: ../vector/v.vol.rst/user1.c:476 ../vector/v.vol.rst/user1.c:529
+#: ../vector/v.vol.rst/user1.c:582 ../vector/v.vol.rst/user1.c:635
+#: ../vector/v.vol.rst/user1.c:688 ../vector/v.vol.rst/user1.c:741
+#: ../vector/v.vol.rst/user1.c:794
+#, c-format
+msgid "3D raster map <%s> created"
 msgstr ""
-#: ../locale/scriptstrings/v.report_to_translate.c:8
-msgid "asc;Sort in ascending order;desc;Sort in descending order"
+#: ../vector/v.vol.rst/dataoct.c:196
+msgid "Points are too concentrated -- please increase DMIN"
 msgstr ""
-#: ../locale/scriptstrings/t.remove_to_translate.c:1
-msgid "Removes space time datasets from temporal database."
+#: ../vector/v.vol.rst/dataoct.c:245
+msgid "Point out of range"
 msgstr ""
-#: ../locale/scriptstrings/t.remove_to_translate.c:7
-msgid "Type of the space time dataset, default is strds"
+#: ../vector/v.in.lidar/main.c:48
+#, c-format
+msgid ""
+"Values of %s and %s are the same. All categories would be stored only in "
+"layer number <%d>"
 msgstr ""
-#: ../locale/scriptstrings/t.remove_to_translate.c:8
-#: ../locale/scriptstrings/t.merge_to_translate.c:6
-msgid "inputs"
+#: ../vector/v.in.lidar/main.c:141
+msgid "Converts LAS LiDAR point clouds to a GRASS vector map with libLAS."
 msgstr ""
-#: ../locale/scriptstrings/t.remove_to_translate.c:10
-msgid "Input file with dataset names, one per line"
+#: ../vector/v.in.lidar/main.c:144 ../raster/r.in.lidar/main.c:120
+#: ../raster3d/r3.in.lidar/main.c:174
+msgid "LAS input file"
 msgstr ""
-#: ../locale/scriptstrings/t.remove_to_translate.c:12
-msgid "Remove all registered maps from the temporal and also from the spatial database"
+#: ../vector/v.in.lidar/main.c:145 ../raster/r.in.lidar/main.c:121
+#: ../raster/r.in.lidar/main.c:131 ../raster3d/r3.in.lidar/main.c:182
+msgid "LiDAR input files in LAS format (*.las or *.laz)"
 msgstr ""
-#: ../locale/scriptstrings/t.remove_to_translate.c:13
-msgid "Force recursive removing"
+#: ../vector/v.in.lidar/main.c:151 ../vector/v.out.lidar/main.c:496
+msgid "Layer number to store generated point ID as category"
 msgstr ""
-#: ../locale/scriptstrings/d.to.rast_to_translate.c:1
-msgid "Saves the contents of the active display monitor to a raster map."
+#: ../vector/v.in.lidar/main.c:152
+msgid "Set to 1 by default, use -c to not store it"
 msgstr ""
-#: ../locale/scriptstrings/v.db.univar_to_translate.c:1
-msgid "Calculates univariate statistics on selected table column for a GRASS vector map."
+#: ../vector/v.in.lidar/main.c:154 ../vector/v.in.lidar/main.c:162
+#: ../vector/v.in.lidar/main.c:170 ../vector/v.in.lidar/main.c:178
+#: ../vector/v.out.lidar/main.c:498 ../vector/v.out.lidar/main.c:505
+#: ../vector/v.out.lidar/main.c:512 ../vector/v.out.lidar/main.c:519
+msgid "Categories"
+msgstr "Kategorijas"
+#: ../vector/v.in.lidar/main.c:159
+msgid "Layer number to store return information as category"
 msgstr ""
-#: ../locale/scriptstrings/d.polar_to_translate.c:1
-msgid "Draws polar diagram of angle map such as aspect or flow directions"
+#: ../vector/v.in.lidar/main.c:160 ../vector/v.in.lidar/main.c:168
+#: ../vector/v.in.lidar/main.c:176
+msgid "Leave empty to not store it"
 msgstr ""
-#: ../locale/scriptstrings/d.polar_to_translate.c:4
-msgid "Name of raster angle map"
+#: ../vector/v.in.lidar/main.c:167 ../vector/v.out.lidar/main.c:510
+msgid "Layer number to store class number as category"
 msgstr ""
-#: ../locale/scriptstrings/d.polar_to_translate.c:5
-msgid "Pixel value to be interpreted as undefined (different from NULL)"
+#: ../vector/v.in.lidar/main.c:175
+msgid "Layer number where RBG colors are stored as category"
 msgstr ""
-#: ../locale/scriptstrings/d.polar_to_translate.c:6
-msgid "Name for optional EPS output file"
+#: ../vector/v.in.lidar/main.c:196 ../vector/v.decimate/main.c:148
+#: ../raster/r.in.xyz/main.c:258
+msgid "Filter range for z data (min,max)"
 msgstr ""
-#: ../locale/scriptstrings/d.polar_to_translate.c:7
-msgid "Plot using Xgraph"
+#: ../vector/v.in.lidar/main.c:203 ../raster/r.in.lidar/main.c:259
+#: ../raster3d/r3.in.lidar/main.c:229
+msgid "Only import points of selected return type"
 msgstr ""
-#: ../locale/scriptstrings/t.rast.to.vect_to_translate.c:1
-msgid "Converts a space time raster dataset into a space time vector dataset"
+#: ../vector/v.in.lidar/main.c:204 ../raster/r.in.lidar/main.c:260
+#: ../raster3d/r3.in.lidar/main.c:230
+msgid "If not specified, all points are imported"
 msgstr ""
-#: ../locale/scriptstrings/t.rast.to.vect_to_translate.c:7
-#: ../raster/r.to.vect/main.c:87 ../vector/v.mkgrid/main.c:136
-msgid "Output feature type"
-msgstr "Izvades objektu tips"
-#: ../locale/scriptstrings/t.rast.to.vect_to_translate.c:11
-#: ../raster/r.to.vect/main.c:94
-msgid "Name of attribute column to store value"
+#: ../vector/v.in.lidar/main.c:213 ../raster/r.in.lidar/main.c:269
+#: ../raster3d/r3.in.lidar/main.c:239
+msgid "Only import points of selected class(es)"
 msgstr ""
-#: ../locale/scriptstrings/t.rast.to.vect_to_translate.c:12
-msgid "Number of r.to.vect processes to run in parallel, more than 1 process works only in conjunction with flag -t"
+#: ../vector/v.in.lidar/main.c:214 ../raster/r.in.lidar/main.c:270
+#: ../raster3d/r3.in.lidar/main.c:240
+msgid ""
+"Input is comma separated integers. If not specified, all points are imported."
 msgstr ""
-#: ../locale/scriptstrings/t.rast.to.vect_to_translate.c:15
-#: ../raster/r.to.vect/main.c:100
-msgid "Smooth corners of area features"
+#: ../vector/v.in.lidar/main.c:221
+msgid "Areas where to import points"
 msgstr ""
-#: ../locale/scriptstrings/t.rast.to.vect_to_translate.c:16
-#: ../raster/r.to.vect/main.c:110
-msgid "Write raster values as z coordinate"
+#: ../vector/v.in.lidar/main.c:222
+msgid "Name of vector map with areas where the points should be imported"
 msgstr ""
-#: ../locale/scriptstrings/t.rast.to.vect_to_translate.c:17
-#: ../raster/r.to.vect/main.c:111
-msgid "Table is not created. Currently supported only for points."
+#: ../vector/v.in.lidar/main.c:227
+msgid "Layer number or name for mask option"
 msgstr ""
-#: ../locale/scriptstrings/t.rast.to.vect_to_translate.c:18
-#: ../raster/r.to.vect/main.c:117 ../vector/v.proj/main.c:130
-msgid "Do not build vector topology"
+#: ../vector/v.in.lidar/main.c:235
+msgid "Do not import every n-th point"
 msgstr ""
-#: ../locale/scriptstrings/t.rast.to.vect_to_translate.c:19
-#: ../raster/r.to.vect/main.c:95
-msgid "Name must be SQL compliant"
+#: ../vector/v.in.lidar/main.c:236
+msgid ""
+"For example, 5 will import 80 percent of points. If not specified, all "
+"points are imported"
 msgstr ""
-#: ../locale/scriptstrings/t.rast.to.vect_to_translate.c:20
-#: ../raster/r.to.vect/main.c:105
-msgid "Use raster values as categories instead of unique sequence (CELL only)"
+#: ../vector/v.in.lidar/main.c:238 ../vector/v.in.lidar/main.c:248
+#: ../vector/v.in.lidar/main.c:257 ../vector/v.in.lidar/main.c:266
+msgid "Decimation"
 msgstr ""
-#: ../locale/scriptstrings/g.manual_to_translate.c:1
-msgid "Displays the manual pages of GRASS modules."
+#: ../vector/v.in.lidar/main.c:245
+msgid "Import only every n-th point"
 msgstr ""
-#: ../locale/scriptstrings/g.manual_to_translate.c:3
-msgid "manual"
+#: ../vector/v.in.lidar/main.c:246
+msgid ""
+"For example, 4 will import 25 percent of points. If not specified, all "
 msgstr ""
-#: ../locale/scriptstrings/g.manual_to_translate.c:4
-msgid "help"
+#: ../vector/v.in.lidar/main.c:255 ../vector/v.decimate/main.c:183
+msgid "Skip first n points"
 msgstr ""
-#: ../locale/scriptstrings/g.manual_to_translate.c:5
-msgid "Display index"
+#: ../vector/v.in.lidar/main.c:256 ../vector/v.decimate/main.c:185
+msgid "Skips the given number of points at the beginning."
 msgstr ""
-#: ../locale/scriptstrings/g.manual_to_translate.c:6
-msgid "Display topics"
+#: ../vector/v.in.lidar/main.c:264
+msgid "Import only n points"
 msgstr ""
-#: ../locale/scriptstrings/g.manual_to_translate.c:7
-msgid "Display as MAN text page instead of HTML page in browser"
+#: ../vector/v.in.lidar/main.c:265
+msgid "Imports only the given number of points"
 msgstr ""
-#: ../locale/scriptstrings/g.manual_to_translate.c:8
-msgid "Display online manuals instead of locally installed"
+#: ../vector/v.in.lidar/main.c:278 ../raster/r.in.lidar/main.c:277
+#: ../raster3d/r3.in.lidar/main.c:299
+msgid "Print LAS file info and exit"
 msgstr ""
-#: ../locale/scriptstrings/g.manual_to_translate.c:9
-msgid "Use online manuals available at http://grass.osgeo.org website. This flag has no effect when displaying MAN text pages."
+#: ../vector/v.in.lidar/main.c:288
+msgid "Invert mask when selecting points"
 msgstr ""
-#: ../locale/scriptstrings/g.manual_to_translate.c:10
-msgid "Manual entry to be displayed"
+#: ../vector/v.in.lidar/main.c:293 ../raster/r.in.lidar/main.c:337
+#: ../raster3d/r3.in.lidar/main.c:284
+msgid "Use only valid points"
 msgstr ""
-#, fuzzy
-msgid "Registers raster, vector and raster3d maps in a space time dataset."
-msgstr "Eksistējošas rastra kartes nosaukums"
-#: ../locale/scriptstrings/t.register_to_translate.c:4
-msgid "register"
+#: ../vector/v.in.lidar/main.c:295 ../raster/r.in.lidar/main.c:339
+#: ../raster3d/r3.in.lidar/main.c:286
+msgid ""
+"Points invalid according to APSRS LAS specification will be filtered out"
 msgstr ""
-#: ../locale/scriptstrings/t.register_to_translate.c:11
-msgid "Additionally the start time and the end time can be specified per line"
+#: ../vector/v.in.lidar/main.c:305 ../vector/v.in.lidar/main.c:313
+#: ../vector/v.in.lidar/main.c:316 ../vector/v.decimate/main.c:243
+#: ../vector/v.decimate/main.c:246
+msgid "Speed"
 msgstr ""
-#: ../locale/scriptstrings/t.register_to_translate.c:13
-msgid "Valid start date and time of the first map"
+#: ../vector/v.in.lidar/main.c:310
+msgid "Do not automatically add unique ID as category to each point"
 msgstr ""
-#: ../locale/scriptstrings/t.register_to_translate.c:14
-#: ../locale/scriptstrings/t.register_to_translate.c:17
-msgid "Format for absolute time: \"yyyy-mm-dd HH:MM:SS +HHMM\", relative time is of type integer."
+#: ../vector/v.in.lidar/main.c:312
+msgid "Create only requested layers and categories"
 msgstr ""
-#: ../locale/scriptstrings/t.register_to_translate.c:15
-#: ../locale/scriptstrings/t.register_to_translate.c:18
-#: ../locale/scriptstrings/t.register_to_translate.c:21
-#: ../locale/scriptstrings/t.register_to_translate.c:24
-#: ../locale/scriptstrings/t.register_to_translate.c:28
-msgid "Time & Date"
+#: ../vector/v.in.lidar/main.c:323 ../raster/r.external/main.c:104
+#: ../raster/r.in.lidar/main.c:302 ../raster/r.in.gdal/main.c:187
+#: ../locale/scriptstrings/v.unpack_to_translate.c:10
+#: ../locale/scriptstrings/t.rast.import_to_translate.c:19
+#: ../locale/scriptstrings/t.vect.import_to_translate.c:15
+#: ../locale/scriptstrings/r.unpack_to_translate.c:9
+#: ../raster3d/r3.in.lidar/main.c:295
+msgid "Assume that the dataset has same projection as the current location"
 msgstr ""
-#: ../locale/scriptstrings/t.register_to_translate.c:16
-msgid "Valid end date and time of all map"
+#: ../vector/v.in.lidar/main.c:349 ../raster/r.in.lidar/main.c:399
+#: ../raster3d/r3.in.lidar/main.c:374
+#, c-format
+msgid "Input file <%s> does not exist"
 msgstr ""
-#: ../locale/scriptstrings/t.register_to_translate.c:19
-msgid "Time stamp unit"
+#: ../vector/v.in.lidar/main.c:354
+#, c-format
+msgid "Unable to open file <%s> as a LiDAR point cloud. %s"
 msgstr ""
-#: ../locale/scriptstrings/t.register_to_translate.c:20
-msgid "Unit must be set in case of relative timestamps"
+#: ../vector/v.in.lidar/main.c:358 ../raster/r.in.lidar/main.c:407
+#: ../raster3d/r3.in.lidar/main.c:382
+#, c-format
+msgid "Unable to read LAS header of <%s>"
 msgstr ""
-#: ../locale/scriptstrings/t.register_to_translate.c:22
-msgid "Time increment, works only in conjunction with start option"
+#: ../vector/v.in.lidar/main.c:415
+#, c-format
+msgid "-%c flag is not set but ID layer is not specified"
 msgstr ""
-#: ../locale/scriptstrings/t.register_to_translate.c:23
-msgid "Time increment between maps for creation of valid time intervals (format for absolute time: NNN seconds, minutes, hours, days, weeks, months, years; format for relative time is of type integer: 5)"
+#: ../vector/v.in.lidar/main.c:416
+msgid "ID layer is required to store attribute table"
 msgstr ""
-#: ../locale/scriptstrings/t.register_to_translate.c:25
-msgid "Field separator character of the input file"
+#: ../vector/v.in.lidar/main.c:425
+#, c-format
+msgid ""
+"Storing generated point IDs as categories in the layer <%d>, consequently no "
+"more than %d points can be imported"
 msgstr ""
-#: ../locale/scriptstrings/t.register_to_translate.c:27
-msgid "Create an interval (start and end time) in case an increment and the start time are provided"
+#: ../vector/v.in.lidar/main.c:542 ../scripts/v.unpack/v.unpack.py:119
+#, c-format, python-format
+msgid "Vector map <%s> already exists and will be overwritten"
 msgstr ""
-#: ../locale/scriptstrings/t.rast3d.univar_to_translate.c:1
-msgid "Calculates univariate statistics from the non-null cells for each registered 3D raster map of a space time 3D raster dataset."
+#: ../vector/v.in.lidar/main.c:605 ../vector/v.decimate/main.c:344
+msgid "Settings for count-based decimation are not valid"
 msgstr ""
-#: ../locale/scriptstrings/wxpyimgview_to_translate.c:1
-msgid "Views BMP images from the PNG driver."
+#: ../vector/v.in.lidar/main.c:609
+#, c-format
+msgid "Scanning %llu points..."
 msgstr ""
-#: ../locale/scriptstrings/wxpyimgview_to_translate.c:5
-msgid "Name of input image file"
+#: ../vector/v.in.lidar/main.c:611
+#, c-format
+msgid "Scanning %lu points..."
 msgstr ""
-#: ../locale/scriptstrings/r.unpack_to_translate.c:1
-msgid "Imports a raster map as GRASS GIS specific archive file (packed with r.pack)"
+#: ../vector/v.in.lidar/main.c:746
+msgid ""
+"The underlying libLAS library is at its limits. Previously reported counts "
+"might have been distorted. However, the import itself should be unaffected."
 msgstr ""
-#: ../locale/scriptstrings/r.unpack_to_translate.c:6
-msgid "Name for output raster map (default: taken from input file internals)"
+#: ../vector/v.in.lidar/main.c:752
+#, c-format
+msgid "%llu points imported (limit was %llu)"
 msgstr ""
-#: ../locale/scriptstrings/t.merge_to_translate.c:1
-msgid "Merges several space time datasets into a single space time dataset."
+#: ../vector/v.in.lidar/main.c:757
+#, c-format
+msgid "%llu points imported"
 msgstr ""
-#: ../locale/scriptstrings/t.merge_to_translate.c:4 ../raster/r.patch/main.c:61
-msgid "merge"
+#: ../vector/v.in.lidar/main.c:760
+#, c-format
+msgid "%llu input points were not valid and filtered out"
 msgstr ""
-#: ../locale/scriptstrings/t.rast.series_to_translate.c:1
-msgid "Performs different aggregation algorithms from r.series on all or a subset of raster maps in a space time raster dataset."
+#: ../vector/v.in.lidar/main.c:762
+#, c-format
+msgid "%llu input points were outside of the selected area"
 msgstr ""
-#: ../locale/scriptstrings/t.rast.series_to_translate.c:4
-#: ../raster/r.series.interp/main.c:65 ../raster/r.series.accumulate/main.c:81
-#: ../raster/r.series/main.c:139
-msgid "series"
+#: ../vector/v.in.lidar/main.c:764
+#, c-format
+msgid "%llu input points were outside of the area specified by mask"
 msgstr ""
-#: ../locale/scriptstrings/t.rast.series_to_translate.c:9
-msgid "Do not assign the space time raster dataset start and end time to the output map"
+#: ../vector/v.in.lidar/main.c:766
+#, c-format
+msgid "%llu input points were filtered out by return number"
 msgstr ""
-#: ../locale/scriptstrings/t.rast.series_to_translate.c:10
-#: ../raster/r.series.accumulate/main.c:159 ../raster/r.series/main.c:187
-#: ../raster/r.resamp.filter/main.c:431 ../raster/r.resamp.stats/main.c:288
-msgid "Propagate NULLs"
+#: ../vector/v.in.lidar/main.c:768
+#, c-format
+msgid "%llu input points were filtered out by class number"
 msgstr ""
-#: ../locale/scriptstrings/r.mask_to_translate.c:1
-msgid "Creates a MASK for limiting raster operation."
+#: ../vector/v.in.lidar/main.c:770
+#, c-format
+msgid "%llu input points were filtered outsite the range for z coordinate"
 msgstr ""
-#: ../locale/scriptstrings/r.mask_to_translate.c:3
-#: ../raster3d/r3.mask/main.c:134
-msgid "mask"
-msgstr "maska"
-#: ../locale/scriptstrings/r.mask_to_translate.c:4
-msgid "Name of raster map to use as mask"
+#: ../vector/v.in.lidar/main.c:772
+#, c-format
+msgid "%llu input points were skipped at the begging using offset"
 msgstr ""
-#: ../locale/scriptstrings/r.mask_to_translate.c:5
-#: ../locale/scriptstrings/r.mask_to_translate.c:8
-msgid "Raster"
-msgstr "Rastrs"
-#: ../locale/scriptstrings/r.mask_to_translate.c:6
-msgid "Raster values to use for mask"
+#: ../vector/v.in.lidar/main.c:775
+#, c-format
+msgid "%llu input points were skipped by count-based decimation"
 msgstr ""
-#: ../locale/scriptstrings/r.mask_to_translate.c:7
-msgid "Format: 1 2 3 thru 7 *"
+#: ../vector/v.in.lidar/main.c:779
+#, c-format
+msgid "%lu points imported (limit was %d)"
 msgstr ""
-#: ../locale/scriptstrings/r.mask_to_translate.c:9
-msgid "Name of vector map to use as mask"
+#: ../vector/v.in.lidar/main.c:783
+#, c-format
+msgid "%lu points imported"
 msgstr ""
-#: ../locale/scriptstrings/r.mask_to_translate.c:10
-#: ../locale/scriptstrings/r.mask_to_translate.c:12
-#: ../locale/scriptstrings/r.mask_to_translate.c:14
-#: ../locale/scriptstrings/r.mask_to_translate.c:16
-msgid "Vector"
-msgstr "Vektors"
-#: ../locale/scriptstrings/r.mask_to_translate.c:11
-msgid "Layer number or name (vector)"
-msgstr "Slāņa numurs vai nosaukums"
-#: ../locale/scriptstrings/r.mask_to_translate.c:13
-msgid "Category values (vector)"
+#: ../vector/v.in.lidar/main.c:785 ../raster3d/r3.in.lidar/main.c:707
+#, c-format
+msgid "%lu input points were not valid and filtered out"
 msgstr ""
-#: ../locale/scriptstrings/r.mask_to_translate.c:15
-msgid "WHERE conditions of SQL statement without 'where' keyword (vector)"
+#: ../vector/v.in.lidar/main.c:787
+#, c-format
+msgid "%lu input points were outside of the selected area"
 msgstr ""
-#: ../locale/scriptstrings/r.mask_to_translate.c:17
-msgid "Create inverse mask"
+#: ../vector/v.in.lidar/main.c:789
+#, c-format
+msgid "%lu input points were outside of the area specified by mask"
 msgstr ""
-#: ../locale/scriptstrings/r.mask_to_translate.c:19
-msgid "Remove existing mask (overrides other options)"
+#: ../vector/v.in.lidar/main.c:791 ../raster3d/r3.in.lidar/main.c:710
+#, c-format
+msgid "%lu input points were filtered out by return number"
 msgstr ""
-#: ../locale/scriptstrings/t.vect.univar_to_translate.c:1
-msgid "Calculates univariate statistics of attributes for each registered vector map of a space time vector dataset"
+#: ../vector/v.in.lidar/main.c:793 ../raster3d/r3.in.lidar/main.c:712
+#, c-format
+msgid "%lu input points were filtered out by class number"
 msgstr ""
-#: ../locale/scriptstrings/r.out.xyz_to_translate.c:1
-msgid "Exports a raster map to a text file as x,y,z values based on cell centers."
+#: ../vector/v.in.lidar/main.c:795
+#, c-format
+msgid "%lu input points were filtered outsite the range for z coordinate"
 msgstr ""
-#: ../locale/scriptstrings/r.out.xyz_to_translate.c:4
-msgid "ASCII"
+#: ../vector/v.in.lidar/main.c:797
+#, c-format
+msgid "%lu input points were skipped at the begging using offset"
 msgstr ""
-#: ../locale/scriptstrings/r.out.xyz_to_translate.c:7
-msgid "Include no data values"
+#: ../vector/v.in.lidar/main.c:800
+#, c-format
+msgid "%lu input points were skipped by count-based decimation"
 msgstr ""
-#: ../locale/scriptstrings/v.db.addcolumn_to_translate.c:1
-msgid "Adds one or more columns to the attribute table connected to a given vector map."
+#: ../vector/v.in.lidar/main.c:802
+msgid ""
+"Accuracy of the printed point counts might be limited by your computer "
+"architecture."
 msgstr ""
-#: ../locale/scriptstrings/v.db.addcolumn_to_translate.c:5
-msgid "Layer number where to add column(s)"
+#: ../vector/v.in.lidar/main.c:805
+msgid "The rest of points was ignored"
 msgstr ""
-#: ../locale/scriptstrings/v.in.mapgen_to_translate.c:1
-msgid "Imports Mapgen or Matlab-ASCII vector maps into GRASS."
+#: ../vector/v.in.lidar/main.c:809
+#, c-format
+msgid "%llu input points were not valid, use -%c flag to filter them out"
 msgstr ""
-#: ../locale/scriptstrings/v.in.mapgen_to_translate.c:4
-msgid "Input map is in Matlab format"
+#: ../vector/v.in.lidar/main.c:813 ../raster3d/r3.in.lidar/main.c:716
+#, c-format
+msgid "%lu input points were not valid, use -%c flag to filter them out"
 msgstr ""
-#: ../locale/scriptstrings/v.in.mapgen_to_translate.c:5
-msgid "Create a 3D vector points map from 3 column Matlab data"
+#: ../vector/v.in.lidar/main.c:818
+#, c-format
+msgid ""
+"Maximum number of categories reached (%d). Import ended prematurely. Try to "
+"import without using category as an ID."
 msgstr ""
-#: ../locale/scriptstrings/v.in.mapgen_to_translate.c:6
-msgid "Name of input file in Mapgen/Matlab format"
+#: ../vector/v.in.lidar/attributes.c:129
+#, c-format
+msgid "Unable open database <%s> by driver <%s>"
 msgstr ""
-#: ../locale/scriptstrings/v.in.mapgen_to_translate.c:7
-msgid "Name for output vector map (omit for display to stdout)"
+#: ../vector/v.in.lidar/vector_mask.c:20
+#, c-format
+msgid "Failed to open vector <%s>"
 msgstr ""
-#: ../locale/scriptstrings/r.buffer.lowmem_to_translate.c:1
-#: ../raster/r.buffer/main.c:69
-msgid "Creates a raster map showing buffer zones surrounding cells that contain non-NULL category values."
+#: ../vector/v.vect.stats/main.c:134 ../raster/r.stats.zonal/main.c:103
+#: ../raster/r.univar/r.univar_main.c:107 ../raster/r.statistics/main.c:57
+#: ../locale/scriptstrings/v.rast.stats_to_translate.c:6
+msgid "zonal statistics"
 msgstr ""
-#: ../locale/scriptstrings/r.buffer.lowmem_to_translate.c:2
-msgid "This is the low-memory alternative to the classic r.buffer module."
+#: ../vector/v.vect.stats/main.c:135
+msgid "Count points in areas, calculate statistics from point attributes."
 msgstr ""
-#: ../locale/scriptstrings/r.buffer.lowmem_to_translate.c:4
-#: ../raster/r.buffer/main.c:67 ../raster/r.circle/main.c:52
-#: ../vector/v.parallel/main.c:51 ../vector/v.buffer/main.c:222
-msgid "buffer"
+#: ../vector/v.vect.stats/main.c:139
+msgid "Name of existing vector map with points"
 msgstr ""
-#: ../locale/scriptstrings/r.buffer.lowmem_to_translate.c:5
-#: ../raster/r.buffer/main.c:94
-msgid "Ignore zero (0) data cells instead of NULL cells"
+#: ../vector/v.vect.stats/main.c:144
+msgid "Name of existing vector map with areas"
 msgstr ""
-#: ../locale/scriptstrings/r.buffer.lowmem_to_translate.c:6
-#: ../raster/r.buffer/main.c:81
-msgid "Distance zone(s)"
+#: ../vector/v.vect.stats/main.c:156
+msgid "Layer number for points map"
 msgstr ""
-#: ../locale/scriptstrings/r.buffer.lowmem_to_translate.c:7
-#: ../raster/r.buffer/main.c:88
-msgid "Units of distance"
-msgstr "Attāluma vienības"
+#: ../vector/v.vect.stats/main.c:161
+#, fuzzy
+msgid "Category values for points map"
+msgstr "Vektorkartes nosaukums"
-#: ../locale/scriptstrings/i.tasscap_to_translate.c:1
-msgid "Performs Tasseled Cap (Kauth Thomas) transformation."
+#: ../vector/v.vect.stats/main.c:166
+msgid ""
+"WHERE conditions of SQL statement without 'where' keyword for points map"
 msgstr ""
-#: ../locale/scriptstrings/i.tasscap_to_translate.c:4
-#: ../imagery/i.landsat.toar/main.c:77 ../imagery/i.albedo/main.c:99
-#: ../imagery/i.landsat.acca/main.c:109
-msgid "Landsat"
+#: ../vector/v.vect.stats/main.c:171
+msgid "Layer number for area map"
 msgstr ""
-#: ../locale/scriptstrings/i.tasscap_to_translate.c:5
-#: ../imagery/i.modis.qc/main.c:174 ../imagery/i.albedo/main.c:102
-msgid "MODIS"
+#: ../vector/v.vect.stats/main.c:176
+#, fuzzy
+msgid "Category values for area map"
+msgstr "Izmantot negatīvas vērtības ezera rastra kartei"
+#: ../vector/v.vect.stats/main.c:181
+msgid "WHERE conditions of SQL statement without 'where' keyword for area map"
 msgstr ""
-#: ../locale/scriptstrings/i.tasscap_to_translate.c:6
-msgid "Tasseled Cap transformation"
+#: ../vector/v.vect.stats/main.c:198
+msgid "Method for aggregate statistics"
 msgstr ""
-#: ../locale/scriptstrings/i.tasscap_to_translate.c:7
-msgid "For Landsat4-7: bands 1, 2, 3, 4, 5, 7; for Landsat8: bands 2, 3, 4, 5, 6, 7; for MODIS: bands 1, 2, 3, 4, 5, 6, 7"
+#: ../vector/v.vect.stats/main.c:205
+msgid "Column name of points map to use for statistics"
 msgstr ""
-#: ../locale/scriptstrings/i.tasscap_to_translate.c:8
-#: ../imagery/i.pca/main.c:85
-msgid "Name for output basename raster map(s)"
+#: ../vector/v.vect.stats/main.c:206
+msgid "Column of points map must be numeric"
 msgstr ""
-#: ../locale/scriptstrings/i.tasscap_to_translate.c:9
-msgid "Satellite sensor"
+#: ../vector/v.vect.stats/main.c:213
+msgid "Column name to upload points count"
 msgstr ""
-#: ../locale/scriptstrings/i.tasscap_to_translate.c:10
-msgid "landsat4_tm;Use transformation rules for Landsat 4 TM;landsat5_tm;Use transformation rules for Landsat 5 TM;landsat7_etm;Use transformation rules for Landsat 7 ETM;landsat8_oli;Use transformation rules for Landsat 8 OLI;modis;Use transformation rules for MODIS"
+#: ../vector/v.vect.stats/main.c:215
+msgid ""
+"Column to hold points count, must be of type integer, will be created if not "
+"existing"
 msgstr ""
-#: ../locale/scriptstrings/v.db.droprow_to_translate.c:1
-msgid "Removes a vector feature from a vector map through attribute selection."
+#: ../vector/v.vect.stats/main.c:222
+msgid "Column name to upload statistics"
 msgstr ""
-#: ../locale/scriptstrings/i.pansharpen_to_translate.c:1
-msgid "Image fusion algorithms to sharpen multispectral with high-res panchromatic channels"
+#: ../vector/v.vect.stats/main.c:224
+msgid ""
+"Column to hold statistics, must be of type double, will be created if not "
+"existing"
 msgstr ""
-#: ../locale/scriptstrings/i.pansharpen_to_translate.c:3
-msgid "fusion"
+#: ../vector/v.vect.stats/main.c:231
+msgid "Print output to stdout, do not update attribute table"
 msgstr ""
-#: ../locale/scriptstrings/i.pansharpen_to_translate.c:4
-msgid "sharpen"
-msgstr "asināt"
+#: ../vector/v.vect.stats/main.c:232
+msgid "First column is always area category"
+msgstr ""
-#: ../locale/scriptstrings/i.pansharpen_to_translate.c:5
-msgid "Brovey"
+#: ../vector/v.vect.stats/main.c:273
+#, c-format
+msgid "Vector map <%s> is not in user mapset and cannot be updated"
 msgstr ""
-#: ../locale/scriptstrings/i.pansharpen_to_translate.c:6
-msgid "IHS"
+#: ../vector/v.vect.stats/main.c:302 ../raster/r.stats.zonal/main.c:165
+#: ../raster/r.statistics/main.c:118 ../raster/r.proj/main.c:237
+#: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:151
+#: ../imagery/i.rectify/main.c:156
+#, c-format
+msgid "<%s=%s> unknown %s"
 msgstr ""
-#: ../locale/scriptstrings/i.pansharpen_to_translate.c:7
-msgid "HIS"
+#: ../vector/v.vect.stats/main.c:339
+msgid "count_column is required to upload point counts"
 msgstr ""
-#: ../locale/scriptstrings/i.pansharpen_to_translate.c:8
-#: ../imagery/i.pca/main.c:74
-msgid "PCA"
+#: ../vector/v.vect.stats/main.c:348
+msgid "count_column must be of type integer"
 msgstr ""
-#: ../locale/scriptstrings/i.pansharpen_to_translate.c:9
-msgid "Name of raster map to be used for <red>"
+#: ../vector/v.vect.stats/main.c:361 ../vector/v.vect.stats/main.c:391
+#, c-format
+msgid "Unable to add column <%s>"
 msgstr ""
-#: ../locale/scriptstrings/i.pansharpen_to_translate.c:10
-msgid "Name of raster map to be used for <green>"
+#: ../vector/v.vect.stats/main.c:367
+msgid "stats_column is required to upload point stats"
 msgstr ""
-#: ../locale/scriptstrings/i.pansharpen_to_translate.c:11
-msgid "Name of raster map to be used for <blue>"
+#: ../vector/v.vect.stats/main.c:378
+msgid "stats_column must be of type double precision"
 msgstr ""
-#: ../locale/scriptstrings/i.pansharpen_to_translate.c:12
-msgid "Name of raster map to be used for high resolution panchromatic channel"
+#: ../vector/v.vect.stats/main.c:400
+msgid "collecting attributes from points vector..."
 msgstr ""
-#: ../locale/scriptstrings/i.pansharpen_to_translate.c:13
-msgid "Method for pan sharpening"
+#: ../vector/v.vect.stats/main.c:437
+msgid "column for points vector must be numeric"
 msgstr ""
-#: ../locale/scriptstrings/i.pansharpen_to_translate.c:14
-msgid "Serial processing rather than parallel processing"
+#: ../vector/v.vect.stats/main.c:498
+#, c-format
+msgid "No area categories in vector <%s>, layer <%s>"
 msgstr ""
-#: ../locale/scriptstrings/i.pansharpen_to_translate.c:15
-msgid "Rebalance blue channel for LANDSAT"
+#: ../vector/v.vect.stats/main.c:523
+msgid "Selecting points for each area..."
 msgstr ""
-#: ../locale/scriptstrings/v.in.geonames_to_translate.c:1
-msgid "Imports geonames.org country files into a vector points map."
+#: ../vector/v.vect.stats/main.c:628
+#, c-format
+msgid "could not find area category %d"
 msgstr ""
-#: ../locale/scriptstrings/v.in.geonames_to_translate.c:4
-msgid "gazetteer"
+#: ../vector/v.vect.stats/main.c:754
+#, c-format
+msgid "%d records updated"
 msgstr ""
-#: ../locale/scriptstrings/v.in.geonames_to_translate.c:5
-msgid "Name of uncompressed geonames file (with .txt extension)"
+#: ../vector/v.vect.stats/main.c:756 ../vector/v.distance/main.c:1736
+#: ../vector/v.what.rast/main.c:688
+#, c-format
+msgid "%d update errors"
 msgstr ""
-#: ../locale/scriptstrings/v.what.strds_to_translate.c:1
-msgid "Uploads space time raster dataset values at positions of vector points to the table."
+#: ../vector/v.qcount/main.c:63
+msgid "Indices for quadrat counts of vector point lists."
 msgstr ""
-#: ../locale/scriptstrings/v.what.strds_to_translate.c:9
-msgid "Update attribute table of input vector map"
+#: ../vector/v.qcount/main.c:72
+msgid ""
+"Name for output quadrat centers map (number of points is written as category)"
 msgstr ""
-#: ../locale/scriptstrings/v.what.strds_to_translate.c:10
-msgid "Instead of creating a new vector map update the attribute table with value(s)"
+#: ../vector/v.qcount/main.c:78
+msgid "Number of quadrats"
 msgstr ""
-#: ../locale/scriptstrings/d.rast.edit_to_translate.c:1
-msgid "Edits cell values in a raster map."
+#: ../vector/v.qcount/main.c:84
+msgid "Quadrat radius"
 msgstr ""
-#: ../locale/scriptstrings/d.rast.edit_to_translate.c:3
-#: ../vector/v.edit/main.c:56 ../vector/v.type/main.c:40
-msgid "editing"
+#: ../vector/v.qcount/main.c:88
+msgid "Print results in shell script style"
 msgstr ""
-#: ../locale/scriptstrings/d.rast.edit_to_translate.c:5
-#: ../raster/r.flow/main.c:434
-msgid "Name of input aspect raster map"
+#: ../vector/v.qcount/main.c:104
+msgid "Finding quadrats..."
 msgstr ""
-#: ../locale/scriptstrings/d.rast.edit_to_translate.c:6
-msgid "Width of display canvas"
+#: ../vector/v.qcount/main.c:109
+msgid "Counting points quadrats..."
 msgstr ""
-#: ../locale/scriptstrings/d.rast.edit_to_translate.c:7
-msgid "Height of display canvas"
+#: ../vector/v.to.points/main.c:61
+msgid "Creates points along input lines in new vector map with 2 layers."
 msgstr ""
-#: ../locale/scriptstrings/d.rast.edit_to_translate.c:8
-msgid "Minimum size of each cell"
+#: ../vector/v.to.points/main.c:79
+msgid "Use line nodes or vertices only"
 msgstr ""
-#: ../locale/scriptstrings/d.rast.edit_to_translate.c:9
-msgid "Maximum number of rows to load"
+#: ../vector/v.to.points/main.c:87
+#, fuzzy
+msgid "Maximum distance between points in map units or percentage with -p"
+msgstr "Maksimālā distance starp punktiem kartes vienībās"
+#: ../vector/v.to.points/main.c:91
+msgid "Interpolate points between line vertices (only for use=vertex)"
 msgstr ""
-#: ../locale/scriptstrings/d.rast.edit_to_translate.c:10
-msgid "Maximum number of columns to load"
+#: ../vector/v.to.points/main.c:95
+msgid "Use dmax as percentage of line length"
 msgstr ""
-#: ../locale/scriptstrings/v.in.lines_to_translate.c:1
-msgid "Imports ASCII x,y[,z] coordinates as a series of lines."
+#: ../vector/v.to.points/main.c:99
+msgid "Start from the end node"
 msgstr ""
-#: ../locale/scriptstrings/v.in.lines_to_translate.c:6
-msgid "Create a 3D line from 3 column data"
+#: ../vector/v.to.points/main.c:246
+#, c-format
+msgid ""
+"%d features without category in layer <%d> skipped. Note that features "
+"without category (usually boundaries) are not skipped when '%s=-1' is given."
 msgstr ""
-#: ../locale/scriptstrings/v.in.lines_to_translate.c:7
-msgid "Name of input file (or \"-\" to read from stdin)"
+#: ../vector/v.to.points/main.c:310
+#, c-format
+msgid "%d points written to output vector map."
 msgstr ""
-#: ../locale/scriptstrings/r.shade_to_translate.c:10
-msgid "Name of shaded raster map"
+#: ../vector/v.to.points/write.c:57 ../vector/v.overlay/line_area.c:443
+#: ../vector/v.overlay/area_area.c:345 ../raster/r.contour/main.c:216
+#: ../raster3d/r3.flow/flowline.c:60
+#, c-format
+msgid "Unable to insert new record: '%s'"
 msgstr ""
-#: ../locale/scriptstrings/r.shade_to_translate.c:12 ../raster/r.his/main.c:121
-msgid "Color to use instead of NULL values"
+#: ../vector/v.buffer/main.c:222 ../vector/v.parallel/main.c:51
+#: ../raster/r.buffer/main.c:67 ../raster/r.circle/main.c:52
+#: ../locale/scriptstrings/r.buffer.lowmem_to_translate.c:4
+msgid "buffer"
 msgstr ""
-#: ../locale/scriptstrings/r.shade_to_translate.c:13
-msgid "Either a standard color name, R:G:B triplet, or \"none\""
+#: ../vector/v.buffer/main.c:224 ../raster/r.circle/main.c:54
+msgid "circle"
 msgstr ""
-#: ../locale/scriptstrings/r.shade_to_translate.c:14 ../raster/r.his/main.c:126
-msgid "Use colors from color tables for NULL values"
+#: ../vector/v.buffer/main.c:227
+msgid "grow"
 msgstr ""
-#: ../locale/scriptstrings/v.db.dropcolumn_to_translate.c:1
-msgid "Drops a column from the attribute table connected to a given vector map."
+#: ../vector/v.buffer/main.c:228
+msgid "shrink"
 msgstr ""
-#: ../locale/scriptstrings/v.db.dropcolumn_to_translate.c:5
-msgid "Name of attribute column(s) to drop"
+#: ../vector/v.buffer/main.c:230
+msgid "Creates a buffer around vector features of given type."
 msgstr ""
-#: ../locale/scriptstrings/m.proj_to_translate.c:1
-msgid "Converts coordinates from one projection to another (cs2cs frontend)."
+#: ../vector/v.buffer/main.c:255
+msgid "Buffer distance along major axis in map units"
 msgstr ""
-#: ../locale/scriptstrings/m.proj_to_translate.c:5
-msgid "Input coordinates to reproject"
+#: ../vector/v.buffer/main.c:256 ../vector/v.buffer/main.c:264
+#: ../vector/v.buffer/main.c:272 ../vector/v.buffer/main.c:277
+#: ../vector/v.buffer/main.c:285 ../vector/v.buffer/main.c:293
+msgid "Distance"
+msgstr "Attālums"
+#: ../vector/v.buffer/main.c:263
+msgid "Buffer distance along minor axis in map units"
 msgstr ""
-#: ../locale/scriptstrings/m.proj_to_translate.c:6
-#: ../locale/scriptstrings/m.proj_to_translate.c:9
-#: ../locale/scriptstrings/m.proj_to_translate.c:13
-msgid "Input coordinates"
+#: ../vector/v.buffer/main.c:271 ../vector/v.parallel/main.c:84
+msgid "Angle of major axis in degrees"
 msgstr ""
-#: ../locale/scriptstrings/m.proj_to_translate.c:7
-msgid "Name of input coordinate file"
+#: ../vector/v.buffer/main.c:276
+msgid "Name of column to use for buffer distances"
 msgstr ""
-#: ../locale/scriptstrings/m.proj_to_translate.c:10
-msgid "Name for output coordinate file (omit to send to stdout)"
+#: ../vector/v.buffer/main.c:284
+msgid "Scaling factor for attribute column values"
 msgstr ""
-#: ../locale/scriptstrings/m.proj_to_translate.c:12
-msgid "Field separator (format: input[,output])"
+#: ../vector/v.buffer/main.c:292
+msgid ""
+"Maximum distance between theoretical arc and polygon segments as multiple of "
+"buffer (default 0.01)"
 msgstr ""
-#: ../locale/scriptstrings/m.proj_to_translate.c:14
-msgid "Input projection parameters (PROJ.4 style)"
+#: ../vector/v.buffer/main.c:297
+msgid "Make outside corners straight"
 msgstr ""
-#: ../locale/scriptstrings/m.proj_to_translate.c:15
-#: ../locale/scriptstrings/m.proj_to_translate.c:17
-#: ../locale/scriptstrings/m.proj_to_translate.c:19
-#: ../locale/scriptstrings/m.proj_to_translate.c:21
-msgid "Projections"
+#: ../vector/v.buffer/main.c:301
+msgid "Do not make caps at the ends of polylines"
 msgstr ""
-#: ../locale/scriptstrings/m.proj_to_translate.c:16
-msgid "Output projection parameters (PROJ.4 style)"
+#: ../vector/v.buffer/main.c:305
+msgid "Transfer categories and attributes"
 msgstr ""
-#: ../locale/scriptstrings/m.proj_to_translate.c:18
-msgid "Use LL WGS84 as input and current location as output projection"
+#: ../vector/v.buffer/main.c:325
+msgid ""
+"Note: In latitude-longitude coordinate system specify distances in degree "
+"unit"
 msgstr ""
-#: ../locale/scriptstrings/m.proj_to_translate.c:20
-msgid "Use current location as input and LL WGS84 as output projection"
+#: ../vector/v.buffer/main.c:329
+msgid "Select a buffer distance/minordistance/angle or column, but not both."
 msgstr ""
-#: ../locale/scriptstrings/m.proj_to_translate.c:22
-msgid "Output long/lat in decimal degrees, or other projections with many decimal places"
+#: ../vector/v.buffer/main.c:347 ../vector/v.random/main.c:208
+#: ../vector/v.drape/main.c:150
+#, c-format
+msgid ""
+"Invalid layer number (%d). Parameter '%s' or '%s' specified, assuming layer "
+"'1'."
 msgstr ""
-#: ../locale/scriptstrings/m.proj_to_translate.c:24
-msgid "Include input coordinates in output file"
+#: ../vector/v.buffer/main.c:358
+msgid "The bufcol option requires a valid layer."
 msgstr ""
-#: ../locale/scriptstrings/m.proj_to_translate.c:26
-msgid "Include column names in output file"
+#: ../vector/v.buffer/main.c:364
+msgid "The tolerance must be > 0."
 msgstr ""
-#: ../locale/scriptstrings/v.in.wfs_to_translate.c:1
-msgid "Imports GetFeature from a WFS server."
+#: ../vector/v.buffer/main.c:368
+#, c-format
+msgid "The tolerance was reset to %g"
 msgstr ""
-#: ../locale/scriptstrings/v.in.wfs_to_translate.c:5
-msgid "Base URL starting with 'http' and ending in '?'"
+#: ../vector/v.buffer/main.c:372
+msgid "Illegal scale value"
 msgstr ""
-#: ../locale/scriptstrings/v.in.wfs_to_translate.c:6
-msgid "Comma separated names of data layers to download"
+#: ../vector/v.buffer/main.c:389
+#, c-format
+msgid "The tolerance in map units = %g"
 msgstr ""
-#: ../locale/scriptstrings/v.in.wfs_to_translate.c:7
-msgid "Specify alternate spatial reference system (example: EPSG:4326)"
+#: ../vector/v.buffer/main.c:393 ../vector/v.buffer/main.c:396
+#: ../vector/v.buffer/main.c:399
+#, fuzzy, c-format
+msgid "Option '%s' is not available with GEOS buffering"
+msgstr "rastra karte <%s> nav atrasta"
+#: ../vector/v.buffer/main.c:442
+#, c-format
+msgid "Unable to select data from table <%s>"
 msgstr ""
-#: ../locale/scriptstrings/v.in.wfs_to_translate.c:8
-msgid "The given code must be supported by the server, consult the capabilities file"
+#: ../vector/v.buffer/main.c:478
+msgid ""
+"No features available for buffering. Check type option and features "
+"available in the input vector."
 msgstr ""
-#: ../locale/scriptstrings/v.in.wfs_to_translate.c:9
-msgid "Maximum number of features to download"
+#: ../vector/v.buffer/main.c:495
+#, c-format
+msgid "Flags -%c/%c ignored by this version, GEOS >= 3.3 is required"
 msgstr ""
-#: ../locale/scriptstrings/v.in.wfs_to_translate.c:10
-msgid "(default: unlimited)"
+#: ../vector/v.buffer/main.c:500
+msgid ""
+"Negative distances for internal buffers are not supported and converted to "
+"positive values."
 msgstr ""
-#: ../locale/scriptstrings/v.in.wfs_to_translate.c:11
-msgid "Skip earlier feature IDs and start downloading at this one"
+#: ../vector/v.buffer/main.c:510
+msgid "Buffering areas..."
 msgstr ""
-#: ../locale/scriptstrings/v.in.wfs_to_translate.c:12
-msgid "(default: start with the first feature)"
+#: ../vector/v.buffer/main.c:546 ../vector/v.buffer/main.c:648
+#, c-format
+msgid "Attribute is of invalid size (%.3f) for category %d"
 msgstr ""
-#: ../locale/scriptstrings/v.in.wfs_to_translate.c:13
-msgid "Download server capabilities to 'wms_capabilities.xml' in the current directory and exit"
+#: ../vector/v.buffer/main.c:560 ../vector/v.buffer/main.c:666
+#, c-format
+msgid "The tolerance in map units: %g"
 msgstr ""
-#: ../locale/scriptstrings/v.in.wfs_to_translate.c:14
-msgid "Restrict fetch to features which touch the current region"
+#: ../vector/v.buffer/main.c:606
+msgid "Buffering features..."
 msgstr ""
-#: ../locale/scriptstrings/v.in.e00_to_translate.c:1
-msgid "Imports E00 file into a vector map."
+#: ../vector/v.buffer/main.c:609 ../vector/v.buffer/main.c:658
+msgid "Negative distances are only supported for areas"
 msgstr ""
-#: ../locale/scriptstrings/v.in.e00_to_translate.c:4
-msgid "E00"
+#: ../vector/v.buffer/main.c:732
+msgid "Cleaning buffers..."
 msgstr ""
-#: ../locale/scriptstrings/v.in.e00_to_translate.c:5
-msgid "Name of input E00 file"
+#: ../vector/v.buffer/main.c:735
+msgid "Building parts of topology..."
 msgstr ""
-#: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:1
-msgid "Computes cyclic accumulations of a space time raster dataset."
+#: ../vector/v.buffer/main.c:749
+msgid "Snapping boundaries..."
 msgstr ""
-#: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:6
-msgid "Input space time raster dataset that defines the lower threshold, values lower this threshold are excluded from accumulation"
+#: ../vector/v.buffer/main.c:765
+msgid "Cleaning boundaries at nodes"
 msgstr ""
-#: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:7
-msgid "Input space time raster dataset that defines the upper threshold, values upper this threshold are excluded from accumulation"
+#: ../vector/v.buffer/main.c:779 ../vector/v.overlay/area_area.c:158
+msgid "Attaching islands..."
 msgstr ""
-#: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:12
-msgid "The granularity for accumulation '1 day'"
+#: ../vector/v.buffer/main.c:786
+msgid "Calculating centroids for all areas..."
 msgstr ""
-#: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:16
-msgid "Use these limits in case lower and/or upper input  space time raster datasets are not defined or contain NULL values"
+#: ../vector/v.buffer/main.c:800 ../vector/v.overlay/area_area.c:171
+msgid "Cannot calculate area centroid"
+msgstr "Nevar noteikt poligona centroīdu"
+#: ../vector/v.buffer/main.c:817
+msgid "Generating list of boundaries to be deleted..."
 msgstr ""
-#: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:17
-msgid "Scale factor for input space time raster dataset"
+#: ../vector/v.buffer/main.c:850
+msgid "Deleting boundaries..."
 msgstr ""
-#: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:18
-msgid "Shift factor for input space time raster dataset"
+#: ../vector/v.buffer/main.c:882
+msgid "Calculating centroids for areas..."
 msgstr ""
-#: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:19
-msgid "This method will be applied to compute the accumulative values from the input maps in a single granule"
+#: ../vector/v.buffer/main.c:895
+#, c-format
+msgid "Unable to calculate centroid for area %d"
 msgstr ""
-#: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:20
-msgid "Growing Degree Days or Winkler indices; Mean: sum(input maps)/(number of input maps); Biologically Effective Degree Days; Huglin Heliothermal index"
+#: ../vector/v.buffer/geos.c:135
+msgid "Unknown GEOS geometry type"
 msgstr ""
-#: ../locale/scriptstrings/t.vect.what.strds_to_translate.c:1
-msgid "Stores raster map values at spatial and temporal positions of vector points as vector attributes."
+#: ../vector/v.buffer/geos.c:178
+#, c-format
+msgid "Buffering failed (feature %d)"
 msgstr ""
-#: ../locale/scriptstrings/t.vect.what.strds_to_translate.c:6
-msgid "Name of the vector column to be created and to store sampled raster values"
+#: ../vector/v.build.polylines/main.c:116
+msgid "Builds polylines from lines or boundaries."
 msgstr ""
-#: ../locale/scriptstrings/t.vect.what.strds_to_translate.c:7
-msgid "The use of a column name forces t.vect.what.rast to sample only values from the first map found in an interval. Otherwise the raster map names are used as column names"
+#: ../vector/v.build.polylines/main.c:126
+msgid "Category number mode"
 msgstr ""
-#: ../locale/scriptstrings/t.vect.extract_to_translate.c:1
-msgid "Extracts a subset of a space time vector dataset."
+#: ../vector/v.build.polylines/main.c:131
+msgid "Do not assign any category number to polyline"
 msgstr ""
-#: ../locale/scriptstrings/t.vect.extract_to_translate.c:9
-msgid "The number of v.extract processes to run in parallel. Use only if database backend is used which supports concurrent writing"
+#: ../vector/v.build.polylines/main.c:132
+msgid "Assign category number of first line to polyline"
 msgstr ""
-#: ../locale/scriptstrings/t.vect.extract_to_translate.c:10
-msgid "Register empty maps"
+#: ../vector/v.build.polylines/main.c:133
+msgid "Assign multiple category numbers to polyline"
 msgstr ""
-#: ../locale/scriptstrings/d.what.rast_to_translate.c:1
-msgid "Allows the user to interactively query raster map layers at user-selected locations."
+#: ../vector/v.build.polylines/main.c:134
+msgid "Create polyline from lines with same categories"
 msgstr ""
-msgid "Imports a space time vector dataset from a GRASS GIS specific archive file."
+#: ../vector/v.build.polylines/main.c:231
+#, c-format
+msgid "%d line or boundaries found in input vector map"
+msgid_plural "%d lines or boundaries found in input vector map"
+msgstr[0] ""
+msgstr[1] ""
+msgstr[2] ""
+#: ../vector/v.build.polylines/main.c:234
+#, c-format
+msgid "%d polyline stored in output vector map"
+msgid_plural "%d polylines stored in output vector map"
+msgstr[0] ""
+msgstr[1] ""
+msgstr[2] ""
+#: ../vector/v.external/list.c:111
+msgid "GRASS is not compiled with PostgreSQL support"
 msgstr ""
-#: ../locale/scriptstrings/t.vect.import_to_translate.c:15
-msgid "Create the location specified by the \"location\" parameter and exit. Do not import the space time vector datasets."
+#: ../vector/v.external/list.c:117
+msgid "GRASS is not compiled with OGR support"
 msgstr ""
-#: ../temporal/t.connect/main.c:38
-msgid "Prints/sets general temporal GIS database connection for current mapset."
+#: ../vector/v.external/list.c:158
+msgid "Connection to PostgreSQL database failed."
 msgstr ""
-#: ../temporal/t.connect/main.c:42 ../db/db.connect/main.c:51
-msgid "Print current connection parameters and exit"
+#: ../vector/v.external/list.c:168
+msgid "No feature tables found in database."
 msgstr ""
-#: ../temporal/t.connect/main.c:48 ../db/db.connect/main.c:63
-msgid "Check connection parameters, set if uninitialized, and exit"
+#: ../vector/v.external/list.c:179
+#, c-format
+msgid "PostGIS database <%s> contains %d feature table:"
+msgid_plural "PostGIS database <%s> contains %d feature tables:"
+msgstr[0] ""
+msgstr[1] ""
+msgstr[2] ""
+#: ../vector/v.external/list.c:260
+#, c-format
+msgid "Unable to open data source '%s'"
 msgstr ""
-#: ../temporal/t.connect/main.c:53 ../db/db.connect/main.c:68
-msgid "Set from default settings and exit"
+#: ../vector/v.external/list.c:267
+#, c-format
+msgid "Data source <%s> (format '%s') contains %d layer:"
+msgid_plural "Data source <%s> (format '%s') contains %d layers:"
+msgstr[0] ""
+msgstr[1] ""
+msgstr[2] ""
+#: ../vector/v.external/list.c:310
+#, c-format
+msgid ""
+"Unable to convert input map projection to GRASS format. Projection check "
+"cannot be provided for OGR layer <%s>"
 msgstr ""
-#: ../temporal/t.connect/main.c:54
-msgid "Overwrite current settings if initialized"
+#: ../vector/v.external/list.c:326
+#, c-format
+msgid "Invalid geometry column %d"
 msgstr ""
-#: ../temporal/t.connect/main.c:59
-msgid "Print current connection parameter in shell style and exit"
+#: ../vector/v.external/main.c:59
+msgid ""
+"Creates a new pseudo-vector map as a link to an OGR-supported layer or a "
+"PostGIS feature table."
 msgstr ""
-#: ../temporal/t.connect/main.c:83 ../temporal/t.connect/main.c:95
-msgid "Temporal GIS database connection not defined. Run t.connect."
+#: ../vector/v.external/main.c:126
+msgid "No layer defined"
 msgstr ""
-#: ../temporal/t.connect/main.c:111
+#: ../vector/v.external/main.c:137 ../vector/v.proj/main.c:150
+#: ../raster/r.proj/main.c:245 ../display/d.mon/start.c:52
+#: ../imagery/i.cluster/main.c:179 ../imagery/i.gensigset/parse.c:57
+#: ../imagery/i.gensig/parse.c:50
 #, c-format
-msgid ""
-"Default TGIS driver / database set to:\n"
-"driver: %s\n"
-"database: %s"
+msgid "option <%s>: <%s> exists. To overwrite, use the --overwrite flag"
 msgstr ""
-#: ../temporal/t.connect/main.c:118
-msgid "Default TGIS driver is not set"
+#: ../vector/v.external/main.c:192
+#, c-format
+msgid "Unable to delete '%s'"
 msgstr ""
-#: ../temporal/t.connect/main.c:121
-msgid "Default TGIS database is not set"
+#: ../vector/v.external/main.c:199
+#, c-format
+msgid "Unable to create file '%s/%s'"
 msgstr ""
-#: ../temporal/t.connect/main.c:133 ../db/db.connect/main.c:161
-#: ../db/db.connect/main.c:188
+#: ../vector/v.external/main.c:233
 #, c-format
-msgid ""
-"Default driver / database set to:\n"
-"driver: %s\n"
-"database: %s"
+msgid "Link to vector map <%s> created."
 msgstr ""
-#: ../raster3d/r3.mkdspf/main.c:83
-msgid "Creates a display file from an existing 3D raster map according to specified threshold levels."
+#: ../vector/v.external/args.c:14
+msgid "Name of input OGR or PostGIS data source"
 msgstr ""
-#: ../raster3d/r3.mkdspf/main.c:91
-msgid "Name of an existing 3D raster map"
+#: ../vector/v.external/args.c:27
+msgid "Name of OGR layer or PostGIS feature table to be linked"
 msgstr ""
-#: ../raster3d/r3.mkdspf/main.c:96
-msgid "Name for output display file"
+#: ../vector/v.external/args.c:28
+msgid ""
+"Examples:\n"
+"\t\tESRI Shapefile: shapefile name\n"
+"\t\tMapInfo File: mapinfo file name\n"
+"\t\tPostGIS database: table name"
 msgstr ""
-#: ../raster3d/r3.mkdspf/main.c:103
-msgid "List of thresholds for isosurfaces"
+#: ../vector/v.external/args.c:40
+msgid "Name for output GRASS vector map (default: input layer)"
 msgstr ""
-#: ../raster3d/r3.mkdspf/main.c:109
-msgid "Minimum isosurface level"
+#: ../vector/v.external/args.c:62
+msgid "List available layers in data source and exit"
 msgstr ""
-#: ../raster3d/r3.mkdspf/main.c:115
-msgid "Maximum isosurface level"
+#: ../vector/v.external/args.c:68
+msgid "List available layers including feature type in data source and exit"
 msgstr ""
-#: ../raster3d/r3.mkdspf/main.c:121
-msgid "Positive increment between isosurface levels"
+#: ../vector/v.external/args.c:70
+msgid "Format: layer name,type,projection check,geometry"
 msgstr ""
-#: ../raster3d/r3.mkdspf/main.c:128
-msgid "Number of isosurface threshold levels"
+#: ../vector/v.net/connect.c:78
+msgid "Failed to find intersection segment"
 msgstr ""
-#: ../raster3d/r3.mkdspf/main.c:132
-msgid "Suppress progress report & min/max information"
+#: ../vector/v.net/main.c:49
+msgid "network maintenance"
 msgstr ""
-#: ../raster3d/r3.mkdspf/main.c:136
-msgid "Use flat shading rather than gradient"
+#: ../vector/v.net/main.c:50
+msgid "Performs network maintenance."
 msgstr ""
-#: ../raster3d/r3.mkdspf/main.c:144
+#: ../vector/v.net/main.c:122
 #, c-format
-msgid "Region from getWindow: %d %d %d"
+msgid "Unable to open vector map <%s> at topology level %d"
 msgstr ""
-#: ../raster3d/r3.mkdspf/main.c:156
+#: ../vector/v.net/main.c:139
 #, c-format
-msgid "Not able to find grid3 file for [%s]"
+msgid "%d new points (nodes) written to output."
 msgstr ""
-#: ../raster3d/r3.mkdspf/main.c:168 ../raster3d/r3.gradient/main.c:113
-#: ../raster3d/r3.gradient/main.c:122 ../raster3d/r3.out.v5d/main.c:312
-#: ../raster3d/r3.out.bin/main.c:314 ../raster3d/r3.neighbors/main.c:266
-#: ../raster3d/r3.neighbors/main.c:275 ../raster3d/r3.out.ascii/main.c:339
-#: ../raster3d/r3.info/main.c:110 ../raster3d/r3.null/main.c:110
-#: ../raster3d/r3.cross.rast/main.c:279 ../raster3d/r3.stats/main.c:103
-#: ../raster3d/r3.out.netcdf/main.c:617 ../raster3d/r3.flow/test_main.c:82
-#: ../raster3d/r3.flow/main.c:118 ../raster3d/r3.flow/main.c:132
-#: ../raster3d/r3.flow/main.c:373 ../raster3d/r3.flow/main.c:385
-#: ../raster3d/r3.mask/main.c:64 ../raster3d/r3.to.rast/main.c:298
-#: ../raster3d/r3.to.rast/main.c:322 ../raster3d/r3.retile/main.c:127
-#: ../raster3d/r3.out.vtk/main.c:207 ../raster3d/r3.out.vtk/main.c:292
-#: ../raster3d/r3.out.vtk/main.c:513 ../raster/r.univar/r3.univar_main.c:151
-#: ../raster/r.univar/r3.univar_main.c:189
+#: ../vector/v.net/main.c:151
 #, c-format
-msgid "Unable to open 3D raster map <%s>"
+msgid "%d lines (network arcs) written to output."
 msgstr ""
-#: ../raster3d/r3.mkdspf/main.c:171 ../raster3d/r3.info/main.c:328
-#: ../raster3d/r3.info/main.c:448
+#: ../vector/v.net/turntable.c:326 ../vector/v.net/turntable.c:346
+#: ../vector/v.net/turntable.c:366 ../vector/v.net/turntable.c:487
+#: ../vector/v.net/turntable.c:554
 #, c-format
-msgid "Unable to read range of 3D raster map <%s>"
+msgid "Unable to read line from <%s>."
 msgstr ""
-#: ../raster3d/r3.mkdspf/main.c:200
-#, c-format
-msgid "Unable to open display file <%s>"
+#: ../vector/v.net/turntable.c:448 ../vector/v.net/turntable.c:523
+msgid "Unable to insert data into turntable."
 msgstr ""
-#: ../raster3d/r3.mkdspf/main.c:221
+#: ../vector/v.net/turntable.c:637
 #, c-format
-msgid "Writing %s from %s..."
+msgid "Unable to open vector map <%s>."
 msgstr ""
-#: ../raster3d/r3.gwflow/main.c:54
-msgid "Input 3D raster map with initial piezometric heads in [m]"
+#: ../vector/v.net/turntable.c:642
+#, c-format
+msgid "Unable to create vector map <%s>."
 msgstr ""
-#: ../raster3d/r3.gwflow/main.c:60
-msgid "Input 3D raster map providing the status for each cell, = 0 - inactive, 1 - active, 2 - dirichlet"
+#: ../vector/v.net/turntable.c:655
+#, c-format
+msgid "Arc layer <%s> does not exist in map <%s>."
 msgstr ""
-#: ../raster3d/r3.gwflow/main.c:65
-msgid "Input 3D raster map with the x-part of the hydraulic conductivity tensor in [m/s]"
+#: ../vector/v.net/turntable.c:660
+#, c-format
+msgid ""
+"Layer <%s> already exist in map <%s>.\n"
+"It will be overwritten by tlayer data."
 msgstr ""
-#: ../raster3d/r3.gwflow/main.c:70
-msgid "Input 3D raster map with the y-part of the hydraulic conductivity tensor in [m/s]"
+#: ../vector/v.net/turntable.c:665
+#, c-format
+msgid ""
+"It will be overwritten by tuclayer data."
 msgstr ""
-#: ../raster3d/r3.gwflow/main.c:75
-msgid "Input 3D raster map with the z-part of the hydraulic conductivity tensor in [m/s]"
+#: ../vector/v.net/turntable.c:700
+#, c-format
+msgid "Unable to open database <%s> using driver <%s>"
 msgstr ""
-#: ../raster3d/r3.gwflow/main.c:80
-msgid "Input 3D raster map with sources and sinks in [m^3/s]"
+#: ../vector/v.net/turntable.c:715
+#, c-format
+msgid "Unable to create turntable <%s>."
 msgstr ""
-#: ../raster3d/r3.gwflow/main.c:84
-msgid "Specific yield [1/m] input 3D raster map"
+#: ../vector/v.net/turntable.c:722
+#, c-format
+msgid "Unable to connect table <%s> to vector map <%s>."
 msgstr ""
-#: ../raster3d/r3.gwflow/main.c:89
-msgid "Recharge input 3D raster map in m^3/s"
+#: ../vector/v.net/turntable.c:727
+#, c-format
+msgid "Unable to create index for column <%s> in table <%s>."
 msgstr ""
-#: ../raster3d/r3.gwflow/main.c:93
-msgid "Output 3D raster map storing the piezometric head result of the numerical calculation"
+#: ../vector/v.net/report.c:37
+#, c-format
+msgid "Line %d has no category"
 msgstr ""
-#: ../raster3d/r3.gwflow/main.c:99
-msgid "Output 3D raster map storing the groundwater filter velocity vector part in x direction [m/s]"
+#: ../vector/v.net/report.c:67
+#, c-format
+msgid "%d points found: %g %g %g line category: %d"
 msgstr ""
-#: ../raster3d/r3.gwflow/main.c:105
-msgid "Output 3D raster map storing the groundwater filter velocity vector part in y direction [m/s]"
+#: ../vector/v.net/report.c:94
+#, c-format
+msgid "Duplicate nodes at x=%g y=%g z=%g "
 msgstr ""
-#: ../raster3d/r3.gwflow/main.c:111
-msgid "Output 3D raster map storing the groundwater filter velocity vector part in z direction [m/s]"
+#: ../vector/v.net/arcs.c:42
+#, c-format
+msgid "Error reading file: '%s'"
 msgstr ""
-#: ../raster3d/r3.gwflow/main.c:117
-msgid "Output 3D raster map storing the groundwater budget for each cell [m^3/s]"
+#: ../vector/v.net/arcs.c:48
+#, c-format
+msgid "Skipping arc %d"
 msgstr ""
-#: ../raster3d/r3.gwflow/main.c:127
-msgid "Use 3D raster mask (if exists)"
+#: ../vector/v.net/arcs.c:85
+#, c-format
+msgid "No point with category %d found"
 msgstr ""
-#: ../raster3d/r3.gwflow/main.c:131 ../raster/r.solute.transport/main.c:192
-msgid "Use a full filled quadratic linear equation system, default is a sparse linear equation system."
+#: ../vector/v.net/arcs.c:89
+#, c-format
+msgid "More points with category %d found"
 msgstr ""
-#: ../raster3d/r3.gwflow/main.c:160 ../raster/r.gwflow/main.c:209
-msgid "groundwater flow"
+#: ../vector/v.net/args.c:14
+msgid "Name of input vector line map (arcs)"
 msgstr ""
-#: ../raster3d/r3.gwflow/main.c:162 ../raster3d/r3.flow/main.c:180
-#: ../raster/r.uslek/main.c:54 ../raster/r.flow/main.c:422
-#: ../raster/r.topidx/main.c:40 ../raster/r.drain/main.c:110
-#: ../raster/r.lake/main.c:151 ../raster/r.sim/r.sim.sediment/main.c:114
-#: ../raster/r.sim/r.sim.water/main.c:114 ../raster/r.fill.dir/main.c:87
-#: ../raster/r.stream.extract/main.c:77 ../raster/r.basins.fill/main.c:55
-#: ../raster/r.solute.transport/main.c:230 ../raster/r.carve/main.c:75
-#: ../raster/r.gwflow/main.c:210 ../raster/r.topmodel/main.c:52
-#: ../raster/r.water.outlet/main.c:58 ../raster/r.watershed/front/main.c:74
-#: ../raster/r.usler/main.c:53
-msgid "hydrology"
-msgstr "hidroloģija"
-#: ../raster3d/r3.gwflow/main.c:163
-msgid "Numerical calculation program for transient, confined groundwater flow in three dimensions."
+#: ../vector/v.net/args.c:15
+msgid "Required for operation 'nodes', 'connect', 'report' and 'nreport'"
 msgstr ""
-#: ../raster3d/r3.gwflow/main.c:180
-msgid ""
-"The cholesky solver does not work with sparse matrices.\n"
-"Consider to choose a full filled quadratic matrix with flag -f "
+#: ../vector/v.net/args.c:17 ../vector/v.net/args.c:57
+msgid "Arcs"
 msgstr ""
-#: ../raster3d/r3.gwflow/main.c:279 ../raster/r.gwflow/main.c:546
-msgid "Unable to create and solve the linear equation system"
+#: ../vector/v.net/args.c:21
+msgid "Name of input vector point map (nodes)"
 msgstr ""
-#: ../raster3d/r3.gwflow/main.c:365 ../raster3d/r3.in.lidar/main.c:484
-#: ../raster3d/r3.in.lidar/main.c:493 ../raster3d/r3.in.lidar/main.c:501
-#: ../raster3d/r3.in.lidar/main.c:509 ../raster3d/r3.in.lidar/main.c:517
-#: ../raster3d/r3.in.lidar/main.c:527 ../raster3d/r3.in.lidar/main.c:536
-#, c-format
-msgid "Unable to create 3D raster map <%s>"
+#: ../vector/v.net/args.c:23
+msgid "Required for operation 'connect' and 'arcs'"
 msgstr ""
-#: ../raster3d/r3.gwflow/main.c:412 ../raster3d/r3.out.v5d/main.c:55
-#: ../raster3d/r3.out.v5d/main.c:326 ../raster3d/r3.in.bin/main.c:471
-#: ../raster3d/r3.out.ascii/main.c:63 ../raster3d/r3.out.ascii/main.c:367
-#: ../raster3d/r3.cross.rast/main.c:55 ../raster3d/r3.in.v5d/main.c:206
-#: ../raster3d/r3.out.netcdf/main.c:649 ../raster3d/r3.in.ascii/main.c:393
-#: ../raster3d/r3.to.rast/main.c:75 ../raster3d/r3.to.rast/main.c:445
-#: ../raster3d/r3.out.vtk/main.c:252 ../raster3d/r3.out.vtk/main.c:338
-msgid "Unable to close 3D raster map"
+#: ../vector/v.net/args.c:25 ../vector/v.net/args.c:71
+#: ../vector/v.net/args.c:93 ../vector/v.net/args.c:100
+msgid "Nodes"
 msgstr ""
-#: ../raster3d/r3.gradient/main.c:44
-msgid "gradient"
+#: ../vector/v.net/args.c:36
+#: ../locale/scriptstrings/g.extension_to_translate.c:10
+#: ../locale/scriptstrings/g.extension.all_to_translate.c:6
+#: ../general/g.mapsets/main.c:81
+msgid "Operation to be performed"
 msgstr ""
-#: ../raster3d/r3.gradient/main.c:47
-msgid "Computes gradient of a 3D raster map and outputs gradient components as three 3D raster maps."
+#: ../vector/v.net/args.c:40
+msgid "new point is placed on each node (line end) if doesn't exist"
 msgstr ""
-#: ../raster3d/r3.gradient/main.c:56
-msgid "Name for output 3D raster map(s)"
+#: ../vector/v.net/args.c:42
+msgid ""
+"connect still unconnected points to vector network by inserting new line(s)"
 msgstr ""
-#: ../raster3d/r3.gradient/main.c:63
-msgid "Size of blocks"
+#: ../vector/v.net/args.c:44
+msgid "new line is created from start point to end point"
 msgstr ""
-#: ../raster3d/r3.gradient/main.c:130
-msgid "Failed to allocate memory for blocks"
+#: ../vector/v.net/args.c:46
+msgid ""
+"print to standard output {line_category start_point_category "
+"end_point_category}"
 msgstr ""
-#: ../raster3d/r3.gradient/main.c:292
-msgid "Writing gradient 3D raster maps..."
+#: ../vector/v.net/args.c:48
+msgid ""
+"print to standard output {point_category line_category[,line_category...]}"
 msgstr ""
-#: ../raster3d/r3.out.v5d/main.c:73
-msgid "3D raster map to be converted to Vis5D (V5D) file"
+#: ../vector/v.net/args.c:50
+msgid "create turntable on vector network"
 msgstr ""
-#: ../raster3d/r3.out.v5d/main.c:77
-msgid "Name for V5D output file"
+#: ../vector/v.net/args.c:64 ../vector/v.net/args.c:111
+#: ../vector/v.net/args.c:123 ../vector/v.net.alloc/main.c:130
+#: ../vector/v.net.alloc/main.c:138 ../vector/v.net.alloc/main.c:146
+#: ../vector/v.net.iso/main.c:151 ../vector/v.net.iso/main.c:159
+#: ../vector/v.net.iso/main.c:167 ../vector/v.net.path/main.c:111
+#: ../vector/v.net.path/main.c:119 ../vector/v.net.path/main.c:127
+#: ../vector/v.net.salesman/main.c:182 ../vector/v.net.salesman/main.c:189
+#: ../vector/v.net.salesman/main.c:196
+msgid "Turntable"
 msgstr ""
-#: ../raster3d/r3.out.v5d/main.c:147
-#, c-format
-msgid "Vis5D allows %d columns, %d columns found"
+#: ../vector/v.net/args.c:80
+msgid "Required for operation 'connect'. Connect points in given threshold."
 msgstr ""
-#: ../raster3d/r3.out.v5d/main.c:150
-#, c-format
-msgid "Vis5D allows %d rows, %d rows found"
+#: ../vector/v.net/args.c:84
+msgid "Name of input file"
 msgstr ""
-#: ../raster3d/r3.out.v5d/main.c:257
-#, c-format
-msgid "Unable to create V5D file <%s>"
+#: ../vector/v.net/args.c:86
+msgid "Required for operation 'arcs' ('-' for standard input)"
 msgstr ""
-#: ../raster3d/r3.out.v5d/main.c:262
-msgid "Failed writing V5D file"
+#: ../vector/v.net/args.c:91
+msgid "Assign unique categories to new points"
 msgstr ""
-#: ../raster3d/r3.out.v5d/main.c:288
-msgid "Exports GRASS 3D raster map to 3-dimensional Vis5D file."
+#: ../vector/v.net/args.c:92
+msgid "For operation 'nodes'"
 msgstr ""
-#: ../raster3d/r3.out.v5d/main.c:295
-msgid "Use map coordinates instead of xyz coordinates"
+#: ../vector/v.net/args.c:97
+msgid "Snap points to network"
 msgstr ""
-#: ../raster3d/r3.in.bin/main.c:73
-msgid "Error reading binary data"
+#: ../vector/v.net/args.c:99
+msgid ""
+"For operation 'connect'. By default, a new line from the point to the "
+"network is created."
 msgstr ""
-#: ../raster3d/r3.in.bin/main.c:154
-#, c-format
-msgid "Loading %s data with %i  bytes ...  (%dx%dx%d)"
+#: ../vector/v.net/args.c:103
+msgid "Turntable layer"
 msgstr ""
-#: ../raster3d/r3.in.bin/main.c:202 ../raster3d/r3.neighbors/main.c:311
-msgid "Error flushing tiles"
+#: ../vector/v.net/args.c:106
+msgid ""
+"Layer where turntable will be attached. Format: layer number[/layer name]."
+"Required for operation 'turntable'."
 msgstr ""
-#: ../raster3d/r3.in.bin/main.c:256
-msgid "Imports a binary raster file into a GRASS 3D raster map."
+#: ../vector/v.net/args.c:114 ../vector/v.net.alloc/main.c:143
+#: ../vector/v.net.iso/main.c:164 ../vector/v.net.path/main.c:124
+#: ../vector/v.net.salesman/main.c:194
+msgid "Layer with unique categories used in turntable"
 msgstr ""
-#: ../raster3d/r3.in.bin/main.c:259
-msgid "Name of binary 3D raster file to be imported"
+#: ../vector/v.net/args.c:117
+msgid ""
+"Layer with unique categories for every line in arc_layer and point on every "
+"node.  The categories are used in turntable. Format: layer number[/layer "
+"name]. Required for operation 'turntable'."
 msgstr ""
-#: ../raster3d/r3.in.bin/main.c:268 ../raster3d/r3.out.bin/main.c:228
-msgid "Number of bytes per cell in binary file"
+#: ../vector/v.net/args.c:146
+msgid "Unknown operation"
 msgstr ""
-#: ../raster3d/r3.in.bin/main.c:275
-msgid "Byte order in binary file"
+#: ../vector/v.net/args.c:175
+msgid "Threshold value must be >= 0"
 msgstr ""
-#: ../raster3d/r3.in.bin/main.c:283 ../raster/r.in.bin/main.c:338
-msgid "Northern limit of geographic region (outer edge)"
+#: ../vector/v.kernel/main.c:68
+#, c-format
+msgid "\tScore Value=%f\tsmoothing parameter (standard deviation)=%f"
 msgstr ""
-#: ../raster3d/r3.in.bin/main.c:291 ../raster/r.in.bin/main.c:346
-msgid "Southern limit of geographic region (outer edge)"
+#: ../vector/v.kernel/main.c:109
+msgid "kernel density"
 msgstr ""
-#: ../raster3d/r3.in.bin/main.c:299 ../raster/r.in.bin/main.c:354
-msgid "Eastern limit of geographic region (outer edge)"
+#: ../vector/v.kernel/main.c:110
+msgid "point density"
 msgstr ""
-#: ../raster3d/r3.in.bin/main.c:307 ../raster/r.in.bin/main.c:362
-msgid "Western limit of geographic region (outer edge)"
+#: ../vector/v.kernel/main.c:111
+msgid "heatmap"
 msgstr ""
-#: ../raster3d/r3.in.bin/main.c:315
-msgid "Bottom limit of geographic region (outer edge)"
+#: ../vector/v.kernel/main.c:112
+msgid "hotspot"
 msgstr ""
-#: ../raster3d/r3.in.bin/main.c:322
-msgid "Top limit of geographic region (outer edge)"
+#: ../vector/v.kernel/main.c:114
+msgid "Generates a raster density map from vector points map."
 msgstr ""
-#: ../raster3d/r3.in.bin/main.c:329 ../raster/r.in.bin/main.c:369
-msgid "Number of rows"
-msgstr "Rindu skaits"
-#: ../raster3d/r3.in.bin/main.c:336 ../raster/r.in.bin/main.c:376
-msgid "Number of columns"
-msgstr "Kolonu skaits"
-#: ../raster3d/r3.in.bin/main.c:343
-msgid "Number of depths"
+#: ../vector/v.kernel/main.c:115
+msgid ""
+"Density is computed using a moving kernel. Optionally generates a vector "
+"density map on a vector network."
 msgstr ""
-#: ../raster3d/r3.in.bin/main.c:350 ../raster/r.in.bin/main.c:383
-msgid "Set Value to NULL"
+#: ../vector/v.kernel/main.c:119
+msgid "Name of input vector map with training points"
 msgstr ""
-#: ../raster3d/r3.in.bin/main.c:354 ../raster3d/r3.out.bin/main.c:240
-#: ../raster3d/r3.out.ascii/main.c:106
-msgid "Switch the row order in output from north->south to south->north"
+#: ../vector/v.kernel/main.c:121 ../vector/v.kernel/main.c:135
+#: ../vector/v.kernel/main.c:149 ../general/g.remove/main.c:83
+#: ../general/g.remove/main.c:91 ../general/g.remove/main.c:133
+msgid "Basic"
 msgstr ""
-#: ../raster3d/r3.in.bin/main.c:359 ../raster3d/r3.out.bin/main.c:245
-#: ../raster3d/r3.out.ascii/main.c:110
-msgid "Switch the depth order in output from bottom->top to top->bottom"
+#: ../vector/v.kernel/main.c:125
+msgid "Name of input network vector map"
 msgstr ""
-#: ../raster3d/r3.in.bin/main.c:365
-msgid "Binary data is of type integer"
-msgstr ""
+#: ../vector/v.kernel/main.c:128 ../vector/v.kernel/main.c:142
+#: ../vector/v.kernel/main.c:164 ../vector/v.kernel/main.c:172
+#: ../vector/v.kernel/main.c:194 ../vector/v.kernel/main.c:219
+#: ../vector/v.kernel/main.c:225
+msgid "Network"
+msgstr "Tīkls"
-#: ../raster3d/r3.in.bin/main.c:369 ../raster/r.in.bin/main.c:274
-msgid "Signed data (two's complement)"
+#: ../vector/v.kernel/main.c:133
+#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:14
+#: ../locale/scriptstrings/r.import_to_translate.c:11
+#: ../locale/scriptstrings/r.in.wms_to_translate.c:6
+#: ../imagery/i.ifft/main.c:93
+msgid "Name for output raster map"
 msgstr ""
-#: ../raster3d/r3.in.bin/main.c:399
-#, c-format
-msgid "bytes=%d; must be 4 or 8 in case of floating point input"
-msgstr ""
+#: ../vector/v.kernel/main.c:140
+#, fuzzy
+msgid "Name for output vector density map"
+msgstr "Izejas rastra kartes nosaukums"
-#: ../raster3d/r3.in.bin/main.c:409
-msgid "Integer input doesn't support size=8 in this build"
+#: ../vector/v.kernel/main.c:141
+#, fuzzy
+msgid "Outputs vector map if network map is given"
+msgstr "2 līmeņiem jābūt norādītiem"
+#: ../vector/v.kernel/main.c:148
+msgid "Kernel radius in map units"
 msgstr ""
-#: ../raster3d/r3.in.bin/main.c:413
-msgid "bytes= must be 1, 2, 4 or 8"
+#: ../vector/v.kernel/main.c:155
+msgid "Discretization error in map units"
 msgstr ""
-#: ../raster3d/r3.in.bin/main.c:424 ../raster/r.in.bin/main.c:521
-#: ../display/d.grid/main.c:266
-#, c-format
-msgid "Illegal north coordinate <%s>"
+#: ../vector/v.kernel/main.c:162
+msgid "Maximum length of segment on network"
 msgstr ""
-#: ../raster3d/r3.in.bin/main.c:426 ../raster/r.in.bin/main.c:523
-#, c-format
-msgid "Illegal south coordinate <%s>"
+#: ../vector/v.kernel/main.c:170
+msgid "Maximum distance from point to network"
 msgstr ""
-#: ../raster3d/r3.in.bin/main.c:428 ../raster/r.in.bin/main.c:525
-#: ../display/d.grid/main.c:259
-#, c-format
-msgid "Illegal east coordinate <%s>"
+#: ../vector/v.kernel/main.c:178
+msgid "Multiply the density result by this number"
 msgstr ""
-#: ../raster3d/r3.in.bin/main.c:430 ../raster/r.in.bin/main.c:527
-#, c-format
-msgid "Illegal west coordinate <%s>"
+#: ../vector/v.kernel/main.c:185
+msgid "Node method"
 msgstr ""
-#: ../raster3d/r3.in.bin/main.c:438 ../raster/r.in.bin/main.c:533
-#, c-format
-msgid "Unable to open <%s>"
+#: ../vector/v.kernel/main.c:191
+msgid "No method applied at nodes with more than 2 arcs"
 msgstr ""
-#: ../raster3d/r3.in.bin/main.c:446
-#, c-format
-msgid "File Size %lld ... Total Bytes %lld"
+#: ../vector/v.kernel/main.c:192
+msgid "Equal split (Okabe 2009) applied at nodes"
 msgstr ""
-#: ../raster3d/r3.in.bin/main.c:448 ../raster/r.in.bin/main.c:577
-msgid "Bytes do not match file size"
+#: ../vector/v.kernel/main.c:200
+msgid "Kernel function"
 msgstr ""
-#: ../raster3d/r3.in.bin/main.c:463 ../raster3d/r3.in.v5d/main.c:201
-#: ../raster3d/r3.in.ascii/main.c:387
-msgid "Unable to open 3D raster map"
+#: ../vector/v.kernel/main.c:208
+msgid ""
+"Try to calculate an optimal radius with given 'radius' taken as maximum "
+"(experimental)"
 msgstr ""
-#: ../raster3d/r3.out.bin/main.c:113 ../raster/r.out.bin/main.c:53
-#: ../raster/r.out.bin/main.c:62 ../raster/r.out.bin/main.c:470
-#: ../raster/r.mapcalc/map3.c:128 ../raster/r.mapcalc/map3.c:142
-#: ../raster/r.mapcalc/map3.c:156
-msgid "Error writing data"
+#: ../vector/v.kernel/main.c:213
+msgid "Only calculate optimal radius and exit (no map is written)"
 msgstr ""
-#: ../raster3d/r3.out.bin/main.c:208
-msgid "Exports a GRASS 3D raster map to a binary array."
+#: ../vector/v.kernel/main.c:218
+msgid ""
+"In network mode, normalize values by sum of density multiplied by length of "
+"each segment. Integral over the output map then gives 1.0 * mult"
 msgstr ""
-#: ../raster3d/r3.out.bin/main.c:221 ../raster/r.out.bin/main.c:304
-msgid "Value to write out for null"
+#: ../vector/v.kernel/main.c:224
+msgid "In network mode, multiply the result by number of input points"
 msgstr ""
-#: ../raster3d/r3.out.bin/main.c:235 ../raster/r.in.bin/main.c:330
-#: ../raster/r.out.bin/main.c:318
-msgid "Output byte order"
+#: ../vector/v.kernel/main.c:237
+msgid ""
+"Use option net_output if you compute network density. Name provided in "
+"option output will be used for net_output."
 msgstr ""
-#: ../raster3d/r3.out.bin/main.c:250
-msgid "Write data as integer"
+#: ../vector/v.kernel/main.c:256
+msgid "Unknown node method"
 msgstr ""
-#: ../raster3d/r3.out.bin/main.c:256 ../raster/r.out.bin/main.c:347
-msgid "Invalid value for null (integers only)"
+#: ../vector/v.kernel/main.c:274
+msgid "Unknown kernel function"
 msgstr ""
-#: ../raster3d/r3.out.bin/main.c:269
-msgid "Floating-point output requires bytes=4 or bytes=8"
+#: ../vector/v.kernel/main.c:280
+msgid ""
+"Optimal standard deviation calculation is supported only for node method "
+"'none' and kernel function 'gaussian'."
 msgstr ""
-#: ../raster3d/r3.out.bin/main.c:273
-msgid "Integer output doesn't support bytes=8 in this build"
+#: ../vector/v.kernel/main.c:284
+msgid ""
+"Optimal standard deviation calculation is supported only for kernel function "
+"'gaussian'."
 msgstr ""
-#: ../raster3d/r3.out.bin/main.c:321 ../raster/r.out.bin/main.c:144
-#: ../raster/r.out.bin/main.c:228 ../raster/r.out.bin/main.c:414
-#: ../display/d.mon/start.c:181 ../display/d.mon/start.c:224
+#: ../vector/v.kernel/main.c:301
 #, c-format
-msgid "Unable to create file <%s>"
+msgid "Standard deviation: %f"
 msgstr ""
-#: ../raster3d/r3.out.bin/main.c:323 ../raster/r.out.bin/main.c:454
-msgid "Using the current region settings..."
+#: ../vector/v.kernel/main.c:306
+#, c-format
+msgid "Output raster map: resolution: %f\t%s\t%s"
 msgstr ""
-#: ../raster3d/r3.out.bin/main.c:324 ../raster/r.out.bin/main.c:455
+#: ../vector/v.kernel/main.c:309
 #, c-format
-msgid "north=%f"
+msgid "Output raster map resolution: %f"
 msgstr ""
-#: ../raster3d/r3.out.bin/main.c:325 ../raster/r.out.bin/main.c:456
+#: ../vector/v.kernel/main.c:357
 #, c-format
-msgid "south=%f"
-msgstr ""
+msgid "%d point outside threshold"
+msgid_plural "%d points outside threshold"
+msgstr[0] ""
+msgstr[1] ""
+msgstr[2] ""
-#: ../raster3d/r3.out.bin/main.c:326 ../raster/r.out.bin/main.c:457
+#: ../vector/v.kernel/main.c:380
 #, c-format
-msgid "east=%f"
+msgid ""
+"Automatic choice of smoothing parameter (radius), maximum possible value of "
+"radius is set to %f"
 msgstr ""
-#: ../raster3d/r3.out.bin/main.c:327 ../raster/r.out.bin/main.c:458
+#: ../vector/v.kernel/main.c:387
 #, c-format
-msgid "west=%f"
+msgid "Using maximum distance between points: %f"
 msgstr ""
-#: ../raster3d/r3.out.bin/main.c:328
+#: ../vector/v.kernel/main.c:401
 #, c-format
-msgid "top=%f"
+msgid "Number of input points: %d."
 msgstr ""
-#: ../raster3d/r3.out.bin/main.c:329
+#: ../vector/v.kernel/main.c:402
 #, c-format
-msgid "bottom=%f"
-msgstr ""
+msgid "%d distance read from the map."
+msgid_plural "%d distances read from the map."
+msgstr[0] ""
+msgstr[1] ""
+msgstr[2] ""
-#: ../raster3d/r3.out.bin/main.c:330 ../raster/r.in.mat/main.c:398
-#: ../raster/r.out.mat/main.c:180
+#: ../vector/v.kernel/main.c:407
 #, c-format
-msgid "rows=%d"
+msgid ""
+"Distances between all points are beyond %e (4 * standard deviation), unable "
+"to calculate optimal value."
 msgstr ""
-#: ../raster3d/r3.out.bin/main.c:331 ../raster/r.in.mat/main.c:399
-#: ../raster/r.out.mat/main.c:181
+#: ../vector/v.kernel/main.c:418
 #, c-format
-msgid "cols=%d"
+msgid "Optimal smoothing parameter (standard deviation): %f."
 msgstr ""
-#: ../raster3d/r3.out.bin/main.c:332
+#: ../vector/v.kernel/main.c:449
 #, c-format
-msgid "depths=%d"
+msgid "Writing output vector map using smooth parameter %f"
 msgstr ""
-#: ../raster3d/r3.neighbors/main.c:94 ../raster/r.neighbors/main.c:102
-#: ../raster/r.series/main.c:104 ../raster/r.resamp.stats/main.c:301
+#: ../vector/v.kernel/main.c:451 ../vector/v.kernel/main.c:561
 #, c-format
-msgid "Unknown method <%s>"
-msgstr "Nezināma metode <%s>"
-#: ../raster3d/r3.neighbors/main.c:119 ../raster/r.series/main.c:161
-msgid "Aggregate operation"
+msgid "Normalising factor %f"
 msgstr ""
-#: ../raster3d/r3.neighbors/main.c:127 ../raster/r.neighbors/main.c:239
-#: ../raster/r.series/main.c:168 ../raster/r.resamp.stats/main.c:282
-msgid "Quantile to calculate for method=quantile"
+#: ../vector/v.kernel/main.c:559
+#, c-format
+msgid "Writing output raster map using smooth parameter %f"
 msgstr ""
-#: ../raster3d/r3.neighbors/main.c:137
-msgid "The size of the window in x, y and z direction, values must be odd integer numbers, eg: 3,3,3"
+#: ../vector/v.kernel/main.c:611
+#, c-format
+msgid "Maximum value in output: %e."
 msgstr ""
-#: ../raster3d/r3.neighbors/main.c:213 ../raster/r.neighbors/main.c:171
-msgid "neighbor"
+#: ../vector/v.outlier/main.c:73 ../raster/r.resamp.filter/main.c:392
+#: ../raster/r.neighbors/main.c:173 ../raster/r.mfilter/main.c:59
+#: ../raster3d/r3.neighbors/main.c:215
+msgid "filter"
 msgstr ""
-#: ../raster3d/r3.neighbors/main.c:214 ../raster/r.neighbors/main.c:172
-msgid "focal statistics"
+#: ../vector/v.outlier/main.c:75
+msgid "Removes outliers from vector point data."
 msgstr ""
-#: ../raster3d/r3.neighbors/main.c:215 ../raster/r.neighbors/main.c:173
-#: ../raster/r.resamp.filter/main.c:392 ../raster/r.mfilter/main.c:59
-#: ../vector/v.outlier/main.c:73
-msgid "filter"
+#: ../vector/v.outlier/main.c:79 ../vector/v.surf.bspline/main.c:105
+msgid "Estimate point density and distance"
 msgstr ""
-#: ../raster3d/r3.neighbors/main.c:218
-msgid "Makes each voxel value a function of the values assigned to the voxels around it, and stores new voxel values in an output 3D raster map"
+#: ../vector/v.outlier/main.c:81
+msgid ""
+"Estimate point density and distance for the input vector points within the "
+"current region extends and quit"
 msgstr ""
-#: ../raster3d/r3.neighbors/main.c:287
-msgid "Unable to allocate buffer"
+#: ../vector/v.outlier/main.c:90
+msgid "Name for output outlier vector map"
 msgstr ""
-#: ../raster3d/r3.out.ascii/main.c:82
-msgid "3D raster map to be converted to ASCII"
+#: ../vector/v.outlier/main.c:95
+msgid "Name for vector map for visualization in QGIS"
 msgstr ""
-#: ../raster3d/r3.out.ascii/main.c:86
-msgid "Name for ASCII output file"
-msgstr "Izvades ACII faila nosaukums"
+#: ../vector/v.outlier/main.c:103
+#, fuzzy
+msgid "Default: 10 * east-west resolution"
+msgstr "Vēlamā austrumi-rietumi izšķirtspēja"
-#: ../raster3d/r3.out.ascii/main.c:95
-msgid "Number of decimal places for floats"
-msgstr ""
+#: ../vector/v.outlier/main.c:112
+#, fuzzy
+msgid "Default: 10 * north-south resolution"
+msgstr "Vēlamā ziemeļi-dienvidi izšķirtspēja"
-#: ../raster3d/r3.out.ascii/main.c:102 ../raster/r.out.ascii/main.c:95
-msgid "Suppress printing of header information"
+#: ../vector/v.outlier/main.c:119
+msgid "Tykhonov regularization weight"
 msgstr ""
-#: ../raster3d/r3.out.ascii/main.c:114
-msgid "Print grass6 compatible format. Flags -d and -r are ignored."
+#: ../vector/v.outlier/main.c:127
+msgid "Threshold for the outliers"
 msgstr ""
-#: ../raster3d/r3.out.ascii/main.c:118 ../raster3d/r3.cross.rast/main.c:109
-#: ../raster3d/r3.out.netcdf/main.c:116 ../raster3d/r3.to.rast/main.c:128
-#: ../raster/r.to.rast3elev/main.c:194
-msgid "Use 3D raster mask (if exists) with input map"
+#: ../vector/v.outlier/main.c:134
+msgid "Filtering option"
 msgstr ""
-#: ../raster3d/r3.out.ascii/main.c:308
-msgid "Converts a 3D raster map layer into a ASCII text file."
+#: ../vector/v.outlier/main.c:205 ../vector/v.surf.bspline/main.c:267
+#: ../vector/v.surf.bspline/main.c:336
+#, c-format
+msgid "Unable to open vector map <%s> at the topological level"
 msgstr ""
-#: ../raster3d/r3.out.ascii/main.c:371
-msgid "Unable to close new ASCII file"
+#: ../vector/v.outlier/main.c:268
+#, c-format
+msgid "It was impossible to create <%s> table."
 msgstr ""
-#: ../raster3d/r3.info/main.c:80
-msgid "Outputs basic information about a user-specified 3D raster map layer."
+#: ../vector/v.outlier/main.c:300 ../vector/v.surf.bspline/main.c:554
+#: ../vector/v.lidar.edgedetection/main.c:304
+#, c-format
+msgid "Adjusted EW splines %d"
 msgstr ""
-#: ../raster3d/r3.info/main.c:86
-msgid "Print raster3d information in shell style"
+#: ../vector/v.outlier/main.c:301 ../vector/v.surf.bspline/main.c:555
+#: ../vector/v.lidar.edgedetection/main.c:305
+#, c-format
+msgid "Adjusted NS splines %d"
 msgstr ""
-#: ../raster3d/r3.info/main.c:90
-msgid "Print range in shell style only"
+#: ../vector/v.outlier/main.c:357 ../vector/v.surf.bspline/main.c:626
+#, c-format
+msgid "Processing subregion %d of %d..."
 msgstr ""
-#: ../raster3d/r3.info/main.c:94 ../raster/r.info/main.c:93
-msgid "Print raster history instead of info"
+#: ../vector/v.outlier/main.c:430
+msgid "Outlier detection"
 msgstr ""
-#: ../raster3d/r3.info/main.c:103
-#, c-format
-msgid "3D Raster map <%s> not found"
+#: ../vector/v.outlier/main.c:450 ../vector/v.surf.bspline/main.c:893
+msgid "No data within this subregion. Consider increasing spline step values."
 msgstr ""
-#: ../raster3d/r3.info/main.c:138 ../raster3d/r3.info/main.c:145
-#: ../raster3d/r3.info/main.c:151 ../raster3d/r3.info/main.c:156
-#: ../raster3d/r3.info/main.c:162 ../raster3d/r3.info/main.c:167
-#: ../raster3d/r3.info/main.c:172 ../raster3d/r3.info/main.c:183
-#: ../raster3d/r3.info/main.c:189 ../raster3d/r3.info/main.c:204
-#: ../raster3d/r3.info/main.c:211 ../raster3d/r3.info/main.c:218
-#: ../raster3d/r3.info/main.c:223 ../raster3d/r3.info/main.c:228
-#: ../raster3d/r3.info/main.c:235 ../raster3d/r3.info/main.c:245
-#: ../raster3d/r3.info/main.c:251 ../raster3d/r3.info/main.c:257
-#: ../raster3d/r3.info/main.c:273 ../raster3d/r3.info/main.c:280
-#: ../raster3d/r3.info/main.c:287 ../raster3d/r3.info/main.c:296
-#: ../raster3d/r3.info/main.c:306 ../raster3d/r3.info/main.c:316
-#: ../raster3d/r3.info/main.c:326 ../raster3d/r3.info/main.c:346
-#: ../raster3d/r3.info/main.c:356 ../raster3d/r3.info/main.c:361
-#: ../raster3d/r3.info/main.c:369 ../raster3d/r3.info/main.c:382
-#: ../raster/r.info/main.c:303 ../raster/r.info/main.c:445
-msgid "Cannot allocate memory for string"
+#: ../vector/v.hull/chull.c:212
+msgid "Reading 3D vertices..."
 msgstr ""
-#: ../raster3d/r3.info/main.c:492
-msgid "Error while reading history file"
+#: ../vector/v.hull/chull.c:396
+msgid "Constructing 3D hull..."
 msgstr ""
-#: ../raster3d/r3.info/main.c:499 ../raster3d/r3.null/main.c:169
-#: ../raster3d/r3.cross.rast/main.c:343
-#: ../raster3d/r3.out.vtk/errorHandling.c:65
-#, c-format
-msgid "Unable to close 3D raster map <%s>"
+#: ../vector/v.hull/main.c:56
+msgid "Produces a 2D/3D convex hull for a given vector map."
 msgstr ""
-#: ../raster3d/r3.null/main.c:55
-msgid "3D raster map for which to modify null values"
+#: ../vector/v.hull/main.c:70
+msgid "Limit to current region"
 msgstr ""
-#: ../raster3d/r3.null/main.c:63 ../raster/r.null/main.c:73
-msgid "List of cell values to be set to NULL"
+#: ../vector/v.hull/main.c:75
+msgid "Create a 'flat' 2D hull even if the input is 3D points"
 msgstr ""
-#: ../raster3d/r3.null/main.c:70 ../raster/r.null/main.c:81
-msgid "The value to replace the null value by"
+#: ../vector/v.hull/main.c:100
+#, c-format
+msgid "Error loading vector points from <%s>"
 msgstr ""
-#: ../raster3d/r3.null/main.c:85
-msgid "Illegal value for null"
+#: ../vector/v.hull/main.c:103
+#, c-format
+msgid "Convex hull calculation requires at least three points (%d found)"
 msgstr ""
-#: ../raster3d/r3.null/main.c:122
-msgid "modifyNull: error opening tmp file"
+#: ../vector/v.hull/main.c:105
+#, c-format
+msgid "%d points read from vector map <%s>"
 msgstr ""
-#: ../raster3d/r3.null/main.c:156
-msgid "modifyNull: error flushing tiles in cube"
+#: ../vector/v.hull/hull.c:107
+msgid "Simple planar hulls not implemented yet"
 msgstr ""
-#: ../raster3d/r3.null/main.c:161
-msgid "modifyNull: error flushing all tiles"
+#: ../vector/v.what/main.c:63 ../vector/v.what.rast/main.c:75
+#: ../vector/v.what.rast3/main.c:68 ../raster/r.what/main.c:101
+#: ../raster/r.what.color/main.c:89
+#: ../locale/scriptstrings/v.what.vect_to_translate.c:6
+#: ../locale/scriptstrings/i.spectral_to_translate.c:3
+#: ../locale/scriptstrings/v.what.strds_to_translate.c:6
+#: ../locale/scriptstrings/v.rast.stats_to_translate.c:8
+#: ../display/d.where/main.c:46
+msgid "querying"
 msgstr ""
-#: ../raster3d/r3.null/main.c:171
-msgid "modifyNull: Unable to close tmp file"
+#: ../vector/v.what/main.c:64 ../vector/v.what.rast/main.c:74
+#: ../vector/v.what.rast3/main.c:67 ../raster/r.what/main.c:102
+#: ../locale/scriptstrings/v.what.vect_to_translate.c:5
+#: ../locale/scriptstrings/v.what.strds_to_translate.c:5
+#: ../display/d.where/main.c:45
+msgid "position"
 msgstr ""
-#: ../raster3d/r3.null/main.c:187 ../raster/r.null/main.c:61
-msgid "null data"
+#: ../vector/v.what/main.c:65
+msgid "Queries a vector map at given locations."
 msgstr ""
-#: ../raster3d/r3.null/main.c:190
-msgid "Explicitly create the 3D NULL-value bitmap file."
+#: ../vector/v.what/main.c:77 ../raster/r.what/main.c:111
+msgid "Coordinates for query"
+msgstr "Vaicājuma koordinātes"
+#: ../vector/v.what/main.c:85
+msgid "Query threshold distance"
 msgstr ""
-#: ../raster3d/r3.cross.rast/main.c:90
-msgid "Input 3D raster map for cross section"
+#: ../vector/v.what/main.c:86
+msgid "Threshold"
 msgstr ""
-#: ../raster3d/r3.cross.rast/main.c:97
-msgid "2D elevation map used to create the cross section map"
+#: ../vector/v.what/main.c:90
+msgid "Print topological information (debugging)"
 msgstr ""
-#: ../raster3d/r3.cross.rast/main.c:104
-msgid "Resulting cross section 2D raster map"
+#: ../vector/v.what/main.c:95
+msgid "Print attribute information"
 msgstr ""
-#: ../raster3d/r3.cross.rast/main.c:229 ../raster/r.profile/main.c:54
-#: ../display/d.profile/main.c:192 ../vector/v.profile/main.c:99
-msgid "profile"
-msgstr "profils"
-#: ../raster3d/r3.cross.rast/main.c:233
-msgid "Creates cross section 2D raster map from 3D raster map based on 2D elevation map"
+#: ../vector/v.what/main.c:105
+msgid "Print the stats in JSON"
 msgstr ""
-#: ../raster3d/r3.cross.rast/main.c:259
-msgid "The 2D and 3D region settings are different. Using the 3D raster map settings to adjust the 2D region."
+#: ../vector/v.what/main.c:110
+msgid "Print multiple features if overlapping features are found"
 msgstr ""
-#: ../raster3d/r3.cross.rast/main.c:302
-msgid "Output map already exists. Will be overwritten!"
+#: ../vector/v.what/main.c:127
+msgid "No input vector maps!"
 msgstr ""
-#: ../raster3d/r3.cross.rast/main.c:338
-msgid "Wrong 3D raster datatype! Cannot create raster map"
+#: ../vector/v.what/main.c:175
+#, c-format
+msgid "Number of given vector maps (%d) differs from number of layers (%d)"
 msgstr ""
-#: ../raster3d/r3.in.v5d/main.c:66
-msgid "Name of V5D raster file to be imported"
+#: ../vector/v.what/main.c:184
+#, c-format
+msgid "You must build topology on vector map <%s>"
 msgstr ""
-#: ../raster3d/r3.in.v5d/main.c:182
-msgid "Import 3-dimensional Vis5D files."
+#: ../vector/v.what/main.c:202
+#, c-format
+msgid "Unknown input format, skipping: '%s'"
 msgstr ""
-#: ../raster3d/r3.stats/main.c:51
-msgid "Generates volume statistics for 3D raster maps."
+#: ../vector/v.what/what.c:45
+msgid "Cannot open driver"
 msgstr ""
-#: ../raster3d/r3.stats/main.c:62
-msgid "Number of subranges to collect stats from"
+#: ../vector/v.what/what.c:53
+msgid "Cannot open database"
 msgstr ""
-#: ../raster3d/r3.stats/main.c:67
-msgid "Calculate statistics based on equal value groups"
+#: ../vector/v.what/what.c:66
+msgid "Cannot open select cursor"
 msgstr ""
-#: ../raster3d/r3.stats/main.c:71
-msgid "Only print cell counts"
-msgstr "Tikai izdrukāt šūnu skaitu"
-#: ../raster3d/r3.stats/main.c:91
-msgid "The number of subranges has to be equal or greater than 1"
+#: ../vector/v.what/what.c:73
+msgid "Cannot fetch next record"
 msgstr ""
-#: ../raster3d/r3.stats/main.c:150
-msgid "Sort non-null values"
+#: ../vector/v.what/what.c:76
+msgid "No database record"
 msgstr ""
-#: ../raster3d/r3.out.netcdf/main.c:81
+#: ../vector/v.what/what.c:177
 #, c-format
-msgid "Unable to close 3D raster map while catching error: %s"
+msgid ""
+"Layer: %d\n"
+"Category: %d\n"
 msgstr ""
-#: ../raster3d/r3.out.netcdf/main.c:97
-msgid "Name for netCDF output file"
+#: ../vector/v.what/what.c:201
+#, c-format
+msgid ""
+"\n"
+"Driver: %s\n"
+"Database: %s\n"
+"Table: %s\n"
+"Key column: %s\n"
 msgstr ""
-#: ../raster3d/r3.out.netcdf/main.c:106
-msgid "The value to be used for null values, default is the netCDF standard"
+#: ../vector/v.what/what.c:380
+#, c-format
+msgid "Nothing found.\n"
 msgstr ""
-#: ../raster3d/r3.out.netcdf/main.c:111
-msgid "Export projection information as wkt and proj4 parameter"
+#: ../vector/v.what/what.c:475
+#, c-format
+msgid ""
+"Id: %d\n"
+"Type: %s\n"
+"Left: %d\n"
+"Right: %d\n"
 msgstr ""
-#: ../raster3d/r3.out.netcdf/main.c:588
-msgid "netCDF"
-msgstr ""
+#: ../vector/v.what/what.c:481 ../vector/v.what/what.c:557
+#, c-format
+msgid "Length: %f\n"
+msgstr "Garums: %f\n"
-#: ../raster3d/r3.out.netcdf/main.c:590
-msgid "Export a 3D raster map as netCDF file."
+#: ../vector/v.what/what.c:501
+#, c-format
+msgid ""
+"Node[%d]=%d\n"
+"Number_lines=%d\n"
+"Coordinates=%.6f,%.6f,%.6f\n"
 msgstr ""
-#: ../raster3d/r3.flow/test_main.c:44
-msgid "unit test"
+#: ../vector/v.what/what.c:506
+#, c-format
+msgid ""
+",\n"
+"\"Node[%d]\": %d,\n"
+"\"Number_lines\": %d,\n"
+"\"Coordinates\": %.6f,%.6f,%.6f"
 msgstr ""
-#: ../raster3d/r3.flow/test_main.c:45
-msgid "Testing flow lines."
+#: ../vector/v.what/what.c:511
+#, c-format
+msgid ""
+"Node[%d]: %d\n"
+"Number of lines: %d\n"
+"Coordinates: %.6f, %.6f, %.6f\n"
 msgstr ""
-#: ../raster3d/r3.flow/flowline.c:60 ../raster/r.contour/main.c:216
-#: ../vector/v.overlay/line_area.c:443 ../vector/v.overlay/area_area.c:345
-#: ../vector/v.to.points/write.c:57
+#: ../vector/v.what/what.c:531
 #, c-format
-msgid "Unable to insert new record: '%s'"
+msgid ""
+"Id: %5d\n"
+"Angle: %.8f\n"
 msgstr ""
-#: ../raster3d/r3.flow/main.c:64 ../raster/r.to.vect/main.c:229
-#: ../raster/r.volume/main.c:260 ../vector/v.random/main.c:252
-#: ../vector/v.lrs/v.lrs.create/main.c:338 ../vector/v.in.dxf/write_vect.c:233
-#: ../vector/v.in.ascii/main.c:413 ../vector/v.mkgrid/main.c:342
-#: ../vector/v.mkgrid/main.c:400
+#: ../vector/v.what/what.c:554
 #, c-format
-msgid "Unable to create table: %s"
+msgid "Type: %s\n"
 msgstr ""
-#: ../raster3d/r3.flow/main.c:67 ../raster/r.contour/main.c:188
-#: ../vector/v.in.dxf/write_vect.c:241 ../vector/v.in.ascii/main.c:521
-#: ../vector/v.in.ogr/main.c:1683 ../vector/v.to.points/main.c:197
-#: ../vector/v.in.dwg/main.c:244 ../vector/v.reclass/main.c:322
-#: ../vector/v.in.lidar/attributes.c:139
+#: ../vector/v.what/what.c:555
 #, c-format
-msgid "Unable to create index for table <%s>, key <%s>"
+msgid "Id: %d\n"
 msgstr ""
-#: ../raster3d/r3.flow/main.c:72 ../raster/r.to.vect/main.c:238
-#: ../raster/r.random/random.c:257 ../raster/r.stream.extract/close.c:196
-#: ../raster/r.contour/main.c:193 ../vector/v.extract/copy_tab.c:129
-#: ../vector/v.random/main.c:264 ../vector/v.in.dxf/write_vect.c:238
-#: ../vector/v.sample/main.c:197 ../vector/v.in.ascii/main.c:421
-#: ../vector/v.mkgrid/main.c:350 ../vector/v.mkgrid/main.c:408
-#: ../vector/v.overlay/main.c:597 ../vector/v.in.ogr/main.c:1157
-#: ../vector/v.select/copy_tabs.c:90 ../vector/v.to.points/main.c:202
-#: ../vector/v.patch/main.c:331 ../vector/v.in.dwg/main.c:249
-#: ../vector/v.reclass/main.c:327 ../vector/v.in.lidar/attributes.c:144
-#: ../vector/v.distance/main.c:1424
+#: ../vector/v.what/what.c:576
 #, c-format
-msgid "Unable to grant privileges on table <%s>"
-msgstr ""
+msgid "Point height: %f\n"
+msgstr "Punkta augstums: %f\n"
-#: ../raster3d/r3.flow/main.c:91
-msgid "Please provide three 3D raster maps"
-msgstr ""
+#: ../vector/v.what/what.c:600
+#, c-format
+msgid "Line height: %f\n"
+msgstr "Līnijas augstums: %f\n"
-#: ../raster3d/r3.flow/main.c:98
+#: ../vector/v.what/what.c:618
 #, c-format
-msgid "Vector seed map <%s> not found"
+msgid ""
+"Line height min: %f\n"
+"Line height max: %f\n"
 msgstr ""
-#: ../raster3d/r3.flow/main.c:147
-msgid "init_flowaccum: error in Rast3d_put_float"
+#: ../vector/v.what/what.c:662
+#, c-format
+msgid ""
+"Type: Area\n"
+"Area height: %f\n"
 msgstr ""
-#: ../raster3d/r3.flow/main.c:183
-msgid "Computes 3D flow lines and 3D flow accumulation."
+#: ../vector/v.what/what.c:676
+#, c-format
+msgid "Type: Area\n"
 msgstr ""
-#: ../raster3d/r3.flow/main.c:193
-msgid "Names of three 3D raster maps describing x, y, z components of vector field"
+#: ../vector/v.what/what.c:704
+#, c-format
+msgid ""
+"Area: %d\n"
+"Number of isles: %d\n"
 msgstr ""
-#: ../raster3d/r3.flow/main.c:200
-msgid "If no map is provided, flow lines are generated from each cell of the input 3D raster"
-msgstr ""
+#: ../vector/v.what/what.c:719
+#, c-format
+msgid "Isle[%d]: %d\n"
+msgstr "Sala[%d]: %d\n"
-#: ../raster3d/r3.flow/main.c:203
-msgid "Name of vector map with points from which flow lines are generated"
+#: ../vector/v.what/what.c:738
+#, c-format
+msgid "Island: %d In area: %d\n"
+msgstr "Sala: %d Poligonā: %d\n"
+#: ../vector/v.what/what.c:759
+#, c-format
+msgid ""
+"Sq Meters: %.3f\n"
+"Hectares: %.3f\n"
 msgstr ""
-#: ../raster3d/r3.flow/main.c:210
-msgid "Name for vector map of flow lines"
+#: ../vector/v.what/what.c:761
+#, c-format
+msgid ""
+"Acres: %.3f\n"
+"Sq Miles: %.4f\n"
 msgstr ""
-#: ../raster3d/r3.flow/main.c:217
-msgid "Name for output flowaccumulation 3D raster"
+#: ../vector/v.generalize/main.c:77 ../vector/v.decimate/main.c:125
+msgid "generalization"
 msgstr ""
-#: ../raster3d/r3.flow/main.c:224
-msgid "Name for 3D raster sampled by flowlines"
+#: ../vector/v.generalize/main.c:78
+msgid "simplification"
 msgstr ""
-#: ../raster3d/r3.flow/main.c:226
-msgid "Values of this 3D raster will be stored as attributes of flowlines segments"
+#: ../vector/v.generalize/main.c:79
+msgid "smoothing"
 msgstr ""
-#: ../raster3d/r3.flow/main.c:240
-msgid "elapsed time"
+#: ../vector/v.generalize/main.c:80
+msgid "displacement"
 msgstr ""
-#: ../raster3d/r3.flow/main.c:241
-msgid "length in map units"
+#: ../vector/v.generalize/main.c:81
+msgid "network generalization"
 msgstr ""
-msgid "length in cells (voxels)"
+#: ../vector/v.generalize/main.c:82
+msgid "Performs vector based generalization."
 msgstr ""
-#: ../raster3d/r3.flow/main.c:243
-msgid "Unit of integration step"
+#: ../vector/v.generalize/main.c:100
+msgid "Error map with failed generalizations"
 msgstr ""
-#: ../raster3d/r3.flow/main.c:244
-msgid "Default unit is cell"
+#: ../vector/v.generalize/main.c:102
+msgid ""
+"Lines and boundaries causing errors (collapsed to a point or topology errors)"
 msgstr ""
-#: ../raster3d/r3.flow/main.c:245 ../raster3d/r3.flow/main.c:254
-#: ../raster3d/r3.flow/main.c:262 ../raster3d/r3.flow/main.c:272
-msgid "Integration"
+#: ../vector/v.generalize/main.c:126
+msgid "Douglas-Peucker Algorithm"
 msgstr ""
-#: ../raster3d/r3.flow/main.c:252
-msgid "Integration step in selected unit"
+#: ../vector/v.generalize/main.c:127
+msgid "Douglas-Peucker Algorithm with reduction parameter"
 msgstr ""
-#: ../raster3d/r3.flow/main.c:253
-msgid "Default step is 0.25 cell"
+#: ../vector/v.generalize/main.c:128
+msgid "Lang Simplification Algorithm"
 msgstr ""
-#: ../raster3d/r3.flow/main.c:261
-msgid "Maximum number of steps"
+#: ../vector/v.generalize/main.c:129
+msgid "Vertex Reduction Algorithm eliminates points close to each other"
 msgstr ""
-#: ../raster3d/r3.flow/main.c:269
-msgid "Maximum error of integration"
+#: ../vector/v.generalize/main.c:130
+msgid "Reumann-Witkam Algorithm"
 msgstr ""
-#: ../raster3d/r3.flow/main.c:270
-msgid "Influences step, increase maximum error to allow bigger steps"
+#: ../vector/v.generalize/main.c:131
+msgid "Boyle's Forward-Looking Algorithm"
 msgstr ""
-#: ../raster3d/r3.flow/main.c:280
-msgid "Number of cells between flow lines in x, y and z direction"
+#: ../vector/v.generalize/main.c:132
+msgid "McMaster's Sliding Averaging Algorithm"
 msgstr ""
-#: ../raster3d/r3.flow/main.c:289
-msgid "Compute flowlines upstream, downstream or in both direction."
+#: ../vector/v.generalize/main.c:133
+msgid "McMaster's Distance-Weighting Algorithm"
 msgstr ""
-#: ../raster3d/r3.flow/main.c:294
-msgid "Create and fill attribute table"
+#: ../vector/v.generalize/main.c:134
+msgid "Chaiken's Algorithm"
 msgstr ""
-#: ../raster3d/r3.flow/main.c:349
-msgid "Please provide 3 integer values for skip option."
+#: ../vector/v.generalize/main.c:135
+msgid "Interpolation by Cubic Hermite Splines"
 msgstr ""
-#: ../raster3d/r3.flow/main.c:396 ../raster/r.flow/io.c:178
-#: ../raster/r.to.vect/main.c:157 ../raster/r.resamp.bspline/main.c:485
-#: ../raster/r.random/random.c:63 ../raster/r.volume/main.c:155
-#: ../raster/r.drain/main.c:197 ../raster/r.sim/simlib/output.c:38
-#: ../raster/r.sim/simlib/output.c:44 ../raster/r.stream.extract/close.c:37
-#: ../raster/r.contour/main.c:156 ../raster/r.carve/vect.c:32
-#: ../display/d.extract/main.c:106 ../vector/v.net.spanningtree/main.c:107
-#: ../vector/v.surf.rst/main.c:600 ../vector/v.surf.rst/main.c:603
-#: ../vector/v.surf.rst/main.c:769 ../vector/v.extrude/main.c:196
-#: ../vector/v.extract/main.c:346 ../vector/v.lidar.correction/main.c:210
-#: ../vector/v.lidar.correction/main.c:216
-#: ../vector/v.net.components/main.c:154 ../vector/v.net.distance/main.c:198
-#: ../vector/v.segment/main.c:114 ../vector/v.net.flow/main.c:149
-#: ../vector/v.net.flow/main.c:155 ../vector/v.split/main.c:177
-#: ../vector/v.edit/main.c:105 ../vector/v.edit/main.c:120
-#: ../vector/v.random/main.c:227 ../vector/v.profile/main.c:426
-#: ../vector/v.voronoi/main.c:215 ../vector/v.lrs/v.lrs.segment/main.c:148
-#: ../vector/v.lrs/v.lrs.label/main.c:276
-#: ../vector/v.lrs/v.lrs.create/main.c:267
-#: ../vector/v.lrs/v.lrs.create/main.c:273 ../vector/v.in.region/main.c:75
-#: ../vector/v.kernel/main.c:338 ../vector/v.net.timetable/main.c:359
-#: ../vector/v.in.db/main.c:151 ../vector/v.in.dxf/main.c:144
-#: ../vector/v.sample/main.c:162 ../vector/v.build.polylines/main.c:156
-#: ../vector/v.net.alloc/main.c:273 ../vector/v.external/main.c:157
-#: ../vector/v.in.ascii/main.c:249 ../vector/v.to.3d/main.c:87
-#: ../vector/v.qcount/main.c:127 ../vector/v.mkgrid/main.c:264
-#: ../vector/v.overlay/main.c:220 ../vector/v.in.ogr/main.c:920
-#: ../vector/v.net.allpairs/main.c:136 ../vector/v.decimate/main.c:389
-#: ../vector/v.parallel/main.c:153 ../vector/v.rectify/main.c:214
-#: ../vector/v.build/main.c:154 ../vector/v.net.connectivity/main.c:136
-#: ../vector/v.vol.rst/main.c:580 ../vector/v.vol.rst/main.c:583
-#: ../vector/v.select/main.c:125 ../vector/v.to.points/main.c:138
-#: ../vector/v.clean/main.c:288 ../vector/v.clean/main.c:295
-#: ../vector/v.lidar.edgedetection/main.c:245
-#: ../vector/v.surf.bspline/main.c:347 ../vector/v.outlier/main.c:224
-#: ../vector/v.outlier/main.c:229 ../vector/v.outlier/main.c:235
-#: ../vector/v.net.bridge/main.c:124 ../vector/v.net.path/main.c:167
-#: ../vector/v.drape/main.c:158 ../vector/v.perturb/main.c:153
-#: ../vector/v.patch/main.c:281 ../vector/v.patch/main.c:286
-#: ../vector/v.proj/main.c:380 ../vector/v.net.steiner/main.c:607
-#: ../vector/v.in.dwg/main.c:200 ../vector/v.cluster/main.c:207
-#: ../vector/v.delaunay/main.c:126 ../vector/v.reclass/main.c:117
-#: ../vector/v.in.lidar/main.c:553 ../vector/v.net.centrality/main.c:215
-#: ../vector/v.net.visibility/main.c:77 ../vector/v.generalize/main.c:336
-#: ../vector/v.net.iso/main.c:374 ../vector/v.net.salesman/main.c:551
-#: ../vector/v.transform/main.c:265 ../vector/v.distance/main.c:410
-#: ../vector/v.hull/main.c:121 ../vector/v.buffer/main.c:391
-#: ../doc/vector/v.example/main.c:98
-#: ../scripts/v.what.strds/v.what.strds.py:217
-#, c-format, python-format
-msgid "Unable to create vector map <%s>"
+#: ../vector/v.generalize/main.c:136
+msgid "Snakes method for line smoothing"
 msgstr ""
-#: ../raster3d/r3.flow/main.c:414 ../vector/v.to.rast/vect2rast.c:48
-#: ../vector/v.colors/main.c:266
-#, c-format
-msgid "Vector map <%s> is not 3D"
+#: ../vector/v.generalize/main.c:137
+msgid "Network generalization"
 msgstr ""
-#: ../raster3d/r3.flow/main.c:441
-msgid "Error during reading seed vector map"
+#: ../vector/v.generalize/main.c:138
+msgid "Displacement of lines close to each other"
 msgstr ""
-#: ../raster3d/r3.in.ascii/main.c:86 ../raster/r.in.ascii/main.c:78
-#: ../vector/v.in.ascii/main.c:78
-msgid "Name of input file to be imported"
+#: ../vector/v.generalize/main.c:141
+msgid "Generalization algorithm"
 msgstr ""
-#: ../raster3d/r3.in.ascii/main.c:94
-msgid "String representing NULL value data cell (use 'none' if no such value)"
+#: ../vector/v.generalize/main.c:148
+msgid "Maximal tolerance value"
 msgstr ""
-#: ../raster3d/r3.in.ascii/main.c:130 ../raster/r.in.ascii/main.c:275
-msgid "Unable to write to file"
+#: ../vector/v.generalize/main.c:155
+msgid "Look-ahead parameter"
 msgstr ""
-#: ../raster3d/r3.in.ascii/main.c:172 ../raster/r.in.ascii/main.c:153
-msgid "Unable to read input from stdin"
+#: ../vector/v.generalize/main.c:164
+msgid "Percentage of the points in the output of 'douglas_reduction' algorithm"
 msgstr ""
-#: ../raster3d/r3.in.ascii/main.c:221
-#, c-format
-msgid "Unsupported GRASS version %s"
+#: ../vector/v.generalize/main.c:173
+msgid "Slide of computed point toward the original point"
 msgstr ""
-#: ../raster3d/r3.in.ascii/main.c:265
-#, c-format
-msgid "Loading data ...  (%dx%dx%d)"
+#: ../vector/v.generalize/main.c:182
+msgid "Minimum angle between two consecutive segments in Hermite method"
 msgstr ""
-#: ../raster3d/r3.in.ascii/main.c:298
-msgid "End of file reached while still loading data."
+#: ../vector/v.generalize/main.c:190
+msgid "Degree threshold in network generalization"
 msgstr ""
-#: ../raster3d/r3.in.ascii/main.c:310
-#, c-format
-msgid "Invalid value detected (at col=%d row=%d depth=%d): %s"
+#: ../vector/v.generalize/main.c:199
+msgid "Closeness threshold in network generalization"
 msgstr ""
-#: ../raster3d/r3.in.ascii/main.c:322
-#, c-format
-msgid "Data exists in input file after fully importing expected data.  [%.4f ...]"
+#: ../vector/v.generalize/main.c:207
+msgid "Betweeness threshold in network generalization"
 msgstr ""
-#: ../raster3d/r3.in.ascii/main.c:360
-msgid "Converts a 3D ASCII raster text file into a (binary) 3D raster map."
+#: ../vector/v.generalize/main.c:214
+msgid "Snakes alpha parameter"
 msgstr ""
-#: ../raster3d/r3.in.ascii/main.c:403
-msgid "Unable to close ASCII file"
+#: ../vector/v.generalize/main.c:221
+msgid "Snakes beta parameter"
 msgstr ""
-#: ../raster3d/r3.support/check.c:20
-#, c-format
-msgid "Updating statistics for <%s>"
+#: ../vector/v.generalize/main.c:228
+msgid "Number of iterations"
 msgstr ""
-#: ../raster3d/r3.support/check.c:36
-#, c-format
-msgid "Updating the number of categories for <%s>"
+#: ../vector/v.generalize/main.c:238
+msgid "Disable loop support"
 msgstr ""
-#: ../raster3d/r3.support/main.c:52
-msgid "Allows creation and/or modification of 3D raster map layer support files."
+#: ../vector/v.generalize/main.c:239
+msgid "Do not modify end points of lines forming a closed loop"
 msgstr ""
-#: ../raster3d/r3.support/main.c:62
-msgid "Text to use for map title"
+#: ../vector/v.generalize/main.c:242
+msgid "Do not copy attributes"
 msgstr ""
-#: ../raster3d/r3.support/main.c:70 ../raster/r.support/main.c:74
-msgid "Text to append to the next line of the map's metadata file"
+#: ../vector/v.generalize/main.c:296
+msgid "Unknown method"
 msgstr ""
-#: ../raster3d/r3.support/main.c:76
-msgid "The map data unit"
+#: ../vector/v.generalize/main.c:328
+#, c-format
+msgid "No lines found in input map <%s>"
 msgstr ""
-#: ../raster3d/r3.support/main.c:82
-msgid "The vertical unit of the map"
+#: ../vector/v.generalize/main.c:342
+#, c-format
+msgid "Unable to create error vector map <%s>"
 msgstr ""
-#: ../raster3d/r3.support/main.c:89 ../raster/r.support/main.c:93
-msgid "Text to use for data source, line 1"
+#: ../vector/v.generalize/main.c:362
+msgid "Displacement..."
 msgstr ""
-#: ../raster3d/r3.support/main.c:96 ../raster/r.support/main.c:100
-msgid "Text to use for data source, line 2"
+#: ../vector/v.generalize/main.c:371
+msgid "Network generalization..."
 msgstr ""
-#: ../raster3d/r3.support/main.c:104 ../raster/r.support/main.c:108
-msgid "Text to use for data description or keyword(s)"
+#: ../vector/v.generalize/main.c:386
+msgid "Attributes are needed for 'where' option, copying table"
 msgstr ""
-#: ../raster3d/r3.support/main.c:111 ../raster/r.category/main.c:80
-#: ../raster/r.support/main.c:115
-msgid "Raster map from which to copy category table"
+#: ../vector/v.generalize/main.c:402
+#, c-format
+msgid "Generalization (%s)..."
 msgstr ""
-#: ../raster3d/r3.support/main.c:116 ../raster/r.support/main.c:120
-msgid "Text file from which to load history"
+#: ../vector/v.generalize/main.c:403
+#, c-format
+msgid "Using threshold: %g %s"
 msgstr ""
-#: ../raster3d/r3.support/main.c:121 ../raster/r.support/main.c:125
-msgid "Text file in which to save history"
+#: ../vector/v.generalize/main.c:523
+#, c-format
+msgid "Method '%s' did not preserve first point"
 msgstr ""
-#: ../raster3d/r3.support/main.c:125
-msgid "Update range"
-msgstr "Atjaunināt diapazonu"
-#: ../raster3d/r3.support/main.c:248 ../raster/r.statistics/main.c:110
-#: ../raster/r.support/main.c:245 ../display/d.title/main.c:110
+#: ../vector/v.generalize/main.c:528
 #, c-format
-msgid "Unable to read category file of raster map <%s>"
+msgid "Method '%s' did not preserve last point"
 msgstr ""
-#: ../raster3d/r3.support/main.c:252 ../raster/r.support/main.c:249
+#: ../vector/v.generalize/main.c:535
 #, c-format
-msgid "cats table for [%s] set to %s"
+msgid "Method '%s' did not preserve loop"
 msgstr ""
-#: ../raster3d/r3.mask/main.c:75
-msgid "Unable to open 3D raster mask file"
+#: ../vector/v.generalize/main.c:567
+#, c-format
+msgid ""
+"%d boundaries were not modified because modification would damage topology"
 msgstr ""
-#: ../raster3d/r3.mask/main.c:104
-msgid "makeMask: error flushing tiles in cube"
+#: ../vector/v.generalize/main.c:570
+#, c-format
+msgid "%d lines/boundaries were not modified due to over-simplification"
 msgstr ""
-#: ../raster3d/r3.mask/main.c:109
-msgid "makeMask: error flushing all tiles"
+#: ../vector/v.generalize/main.c:591
+#, c-format
+msgid ""
+"Number of vertices for selected features %s from %d to %d (%d%% remaining)"
 msgstr ""
-#: ../raster3d/r3.mask/main.c:117
-msgid "Unable to close 3D raster mask file"
+#: ../vector/v.generalize/main.c:592
+msgid "reduced"
 msgstr ""
-#: ../raster3d/r3.mask/main.c:119
-#, c-format
-msgid "Unable to close raster map <%s>"
+msgid "changed"
 msgstr ""
-#: ../raster3d/r3.mask/main.c:137
-msgid "Establishes the current working 3D raster mask."
+#: ../vector/v.generalize/displacement.c:78 ../raster/r.in.lidar/main.c:608
+#: ../raster/r.contour/main.c:237
+msgid "Reading data..."
 msgstr ""
-#: ../raster3d/r3.mask/main.c:145
-msgid "3D raster map with reference values"
+#: ../vector/v.generalize/displacement.c:199
+msgid "Inverting matrix..."
 msgstr ""
-#: ../raster3d/r3.mask/main.c:153
-msgid "List of cell values to be masked out"
+#: ../vector/v.generalize/displacement.c:201
+msgid "Unable to calculate the inverse matrix"
 msgstr ""
-#: ../raster3d/r3.mask/main.c:159
-msgid "Cannot create mask file: RASTER3D_MASK already exists"
+#: ../vector/v.generalize/displacement.c:204
+msgid "Resolving conflicts..."
 msgstr ""
-#: ../raster3d/r3.to.rast/main.c:100
-msgid "3D raster map(s) to be converted to 2D raster slices"
+#: ../vector/v.generalize/misc.c:166
+#, c-format
+msgid "Layer %d"
 msgstr ""
-#: ../raster3d/r3.to.rast/main.c:106
-msgid "Basename for resultant raster slice maps"
+#: ../vector/v.generalize/smoothing.c:135
+#: ../vector/v.generalize/smoothing.c:225
+msgid "Look ahead parameter must be odd"
 msgstr ""
-#: ../raster3d/r3.to.rast/main.c:116
-#, fuzzy
-msgid "Value to multiply the raster values with"
-msgstr "Summē visas rastra šūnu vērtības."
-#: ../raster3d/r3.to.rast/main.c:117
-msgid "Coefficient a in the equation y = ax + b"
+#: ../vector/v.generalize/smoothing.c:664
+msgid "Unable to find the inverse matrix"
 msgstr ""
-#: ../raster3d/r3.to.rast/main.c:123
-#, fuzzy
-msgid "Value to add to the raster values"
-#: ../raster3d/r3.to.rast/main.c:124
-msgid "Coefficient b in the equation y = ax + b"
+#: ../vector/v.generalize/smoothing.c:671
+msgid "Unable to calculate the output vectors"
 msgstr ""
-#: ../raster3d/r3.to.rast/main.c:133
-msgid "Use the same resolution as the input 3D raster map for the 2D output maps, independent of the current region settings"
+#: ../vector/v.generalize/network.c:89 ../vector/v.net.components/main.c:163
+#: ../vector/v.net.bridge/main.c:134 ../vector/v.net.flow/main.c:226
+#: ../vector/v.net.connectivity/main.c:178 ../vector/v.net.timetable/main.c:405
+#: ../vector/v.net.distance/main.c:264 ../vector/v.net.spanningtree/main.c:124
+#: ../vector/v.net.centrality/main.c:284
+#, c-format
+msgid "Unable to build graph for vector map <%s>"
 msgstr ""
-#: ../raster3d/r3.to.rast/main.c:174
-#, fuzzy, c-format
-msgid "Unknown raster type <%d>"
-msgstr "Nenosakāms tips: %c"
-#: ../raster3d/r3.to.rast/main.c:263
-msgid "Converts 3D raster maps to 2D raster maps"
+#: ../vector/v.generalize/network.c:166
+msgid "Calculating centrality measures..."
 msgstr ""
-#: ../raster3d/r3.to.rast/main.c:332 ../raster3d/r3.out.vtk/main.c:451
-msgid "The 2D and 3D region settings are different. Using the 2D window settings to adjust the 2D part of the 3D region."
+#: ../vector/v.out.lidar/main.c:77
+#, c-format
+msgid "Database connection not defined for layer <%d>"
 msgstr ""
-#: ../raster3d/r3.to.rast/main.c:360 ../raster/r.li/r.li.daemon/list.c:49
-#: ../raster/r.stream.extract/bseg.c:50 ../raster/r.stream.extract/seg.c:55
-#: ../raster/r.stream.extract/cseg.c:51 ../raster/r.stream.extract/dseg.c:51
-#: ../raster/r.to.rast3/main.c:244 ../vector/v.surf.rst/main.c:843
-#: ../vector/v.net.components/main.c:170 ../vector/v.net.distance/main.c:228
-#: ../vector/v.net.flow/main.c:232 ../vector/v.profile/main.c:653
-#: ../vector/v.net.timetable/main.c:389 ../vector/v.net.timetable/main.c:399
-#: ../vector/v.mkgrid/write_grid.c:28 ../vector/v.net.allpairs/main.c:201
-#: ../vector/v.kcv/main.c:208 ../vector/v.net.connectivity/main.c:186
-#: ../vector/v.net.connectivity/main.c:202 ../vector/v.vol.rst/user1.c:423
-#: ../vector/v.net.centrality/main.c:293 ../vector/v.net.centrality/main.c:298
-#: ../vector/v.net.centrality/main.c:304 ../vector/v.net.centrality/main.c:310
-#: ../vector/v.net.centrality/main.c:316 ../vector/v.generalize/matrix.c:144
-#: ../vector/v.generalize/simplification.c:33
-#: ../vector/v.generalize/simplification.c:40
-#: ../vector/v.generalize/simplification.c:306
-#: ../vector/v.generalize/simplification.c:314
-#: ../vector/v.generalize/simplification.c:338
-#: ../vector/v.generalize/smoothing.c:144
-#: ../vector/v.generalize/smoothing.c:231
-#: ../vector/v.generalize/smoothing.c:374
-#: ../vector/v.generalize/smoothing.c:528
-#: ../vector/v.generalize/smoothing.c:574
-#: ../vector/v.generalize/smoothing.c:578
-#: ../vector/v.generalize/smoothing.c:582
-#: ../vector/v.generalize/smoothing.c:586
-#: ../vector/v.generalize/smoothing.c:590
-#: ../vector/v.generalize/smoothing.c:594
-#: ../vector/v.generalize/smoothing.c:598 ../vector/v.generalize/network.c:96
-#: ../vector/v.generalize/network.c:131 ../imagery/i.smap/multialloc.c:115
-#: ../db/drivers/postgres/listtab.c:92 ../db/drivers/postgres/listdb.c:88
-#: ../db/drivers/sqlite/listdb.c:134
-msgid "Out of memory"
+#: ../vector/v.out.lidar/main.c:123
+msgid "Double values will be converted to integers"
 msgstr ""
-#: ../raster3d/r3.to.rast/main.c:362
+#: ../vector/v.out.lidar/main.c:184
 #, c-format
-msgid "Creating %i raster maps"
+msgid "No record for cat = %d"
 msgstr ""
-#: ../raster3d/r3.to.rast/main.c:368
+#: ../vector/v.out.lidar/main.c:187
 #, c-format
-msgid "Raster map %i Filename: %s"
+msgid "NULL value for cat = %d"
 msgstr ""
-#: ../raster3d/r3.to.rast/main.c:373
+#: ../vector/v.out.lidar/main.c:196
 #, c-format
-msgid "Raster map %d Filename: %s already exists. Use the flag --o to overwrite."
+msgid "Column type is not numeric (type = %d, cat = %d"
 msgstr ""
-#: ../raster3d/r3.timestamp/main.c:45 ../raster/r.timestamp/main.c:37
-#: ../vector/v.timestamp/main.c:37
-msgid "timestamp"
+#: ../vector/v.out.lidar/main.c:475
+msgid "Exports vector points as LAS point cloud"
 msgstr ""
-#: ../raster3d/r3.timestamp/main.c:48
-msgid "Modifies a timestamp for a 3D raster map."
+#: ../vector/v.out.lidar/main.c:476
+msgid "Converts LAS LiDAR point clouds to a GRASS vector map with libLAS"
 msgstr ""
-#: ../raster3d/r3.timestamp/main.c:49
-msgid "Print/add/remove a timestamp for a 3D raster map."
+#: ../vector/v.out.lidar/main.c:503
+msgid "Layer number to store return number as category"
 msgstr ""
-#: ../raster3d/r3.timestamp/main.c:58
-msgid "Datetime, datetime1/datetime2, or none"
+#: ../vector/v.out.lidar/main.c:517
+msgid "Layer number where RGB color is stored as category"
 msgstr ""
-#: ../raster3d/r3.timestamp/main.c:91
-msgid "Timestamp format is invalid"
+#: ../vector/v.out.lidar/main.c:525 ../vector/v.out.lidar/main.c:531
+#: ../vector/v.out.lidar/main.c:537
+msgid "Column with return number"
 msgstr ""
-#: ../raster3d/r3.retile/main.c:49
-msgid "Unable to close the 3D raster map"
+#: ../vector/v.out.lidar/main.c:527 ../vector/v.out.lidar/main.c:533
+#: ../vector/v.out.lidar/main.c:539 ../vector/v.out.lidar/main.c:546
+#: ../vector/v.out.lidar/main.c:552 ../vector/v.out.lidar/main.c:558
+#: ../vector/v.out.lidar/main.c:564 ../vector/v.net.centrality/main.c:149
+#: ../vector/v.net.centrality/main.c:155 ../vector/v.net.centrality/main.c:161
+#: ../vector/v.net.centrality/main.c:167
+msgid "Columns"
+msgstr "Kolonas"
+#: ../vector/v.out.lidar/main.c:543
+msgid "RGB color definition column"
 msgstr ""
-#: ../raster3d/r3.retile/main.c:71
-msgid "Name of the retiled 3D raster map"
+#: ../vector/v.out.lidar/main.c:544 ../display/d.vect/main.c:133
+msgid "Color definition in R:G:B form"
 msgstr ""
-#: ../raster3d/r3.retile/main.c:99
-msgid "Retiles an existing 3D raster map with user defined x, y and z tile size."
+#: ../vector/v.out.lidar/main.c:550
+msgid "Column with red color"
 msgstr ""
-#: ../raster3d/r3.retile/main.c:135
-msgid "Rast3d_get_standard3d_params: tile dimension value invalid"
+#: ../vector/v.out.lidar/main.c:556
+msgid "Column with green color"
 msgstr ""
-#: ../raster3d/r3.retile/main.c:148
-msgid "Error closing 3D raster map"
+#: ../vector/v.out.lidar/main.c:562
+msgid "Column with blue color"
 msgstr ""
-#: ../raster3d/r3.in.lidar/main.c:170
-#, fuzzy
-msgid "Creates a 3D raster map from LAS LiDAR points using univariate statistics."
-msgstr "Eksistējošas rastra kartes nosaukums"
+#: ../vector/v.out.lidar/main.c:571
+msgid "Internal scale to apply to X and Y values"
+msgstr ""
-#: ../raster3d/r3.in.lidar/main.c:174 ../raster/r.in.lidar/main.c:120
-#: ../vector/v.in.lidar/main.c:142
-msgid "LAS input file"
+#: ../vector/v.out.lidar/main.c:572 ../vector/v.out.lidar/main.c:582
+msgid ""
+"This scale does not change the values itself but only how precisely they are "
+"stored, for example 0.01 will preserve two decimal places"
 msgstr ""
-#: ../raster3d/r3.in.lidar/main.c:176
-msgid "LiDAR input file in LAS format (*.las or *.laz)"
+#: ../vector/v.out.lidar/main.c:581
+msgid "Internal scale to apply to z values"
 msgstr ""
-#: ../raster3d/r3.in.lidar/main.c:181 ../raster/r.in.lidar/main.c:130
-msgid "File containing names of LAS input files"
+#: ../vector/v.out.lidar/main.c:589
+msgid "Limit export to the current region"
 msgstr ""
-#: ../raster3d/r3.in.lidar/main.c:182 ../raster/r.in.lidar/main.c:121
-#: ../raster/r.in.lidar/main.c:131 ../vector/v.in.lidar/main.c:143
-msgid "LiDAR input files in LAS format (*.las or *.laz)"
+#: ../vector/v.out.lidar/main.c:593
+msgid "Ignore color table"
 msgstr ""
-#: ../raster3d/r3.in.lidar/main.c:189
-msgid "Count of points per cell"
+#: ../vector/v.out.lidar/main.c:595
+msgid "Ignore color table even when set and not other options are present"
 msgstr ""
-#: ../raster3d/r3.in.lidar/main.c:195
-msgid "Sum of values of point intensities per cell"
+#: ../vector/v.out.svg/main.c:76
+msgid "Exports a vector map to SVG file."
 msgstr ""
-#: ../raster3d/r3.in.lidar/main.c:201
-msgid "Mean of point intensities per cell"
+#: ../vector/v.out.svg/main.c:85
+msgid "Name for SVG output file"
 msgstr ""
-#: ../raster3d/r3.in.lidar/main.c:209
-msgid "3D raster map of proportional point count"
+#: ../vector/v.out.svg/main.c:94
+msgid "Output type"
 msgstr ""
-#: ../raster3d/r3.in.lidar/main.c:211
-msgid "Point count per 3D cell divided by point count per vertical column"
+#: ../vector/v.out.svg/main.c:95
+msgid "Defines which feature-type will be extracted"
 msgstr ""
-#: ../raster3d/r3.in.lidar/main.c:213 ../raster3d/r3.in.lidar/main.c:223
-msgid "Proportional output"
+#: ../vector/v.out.svg/main.c:103
+msgid "Coordinate precision"
 msgstr ""
-#: ../raster3d/r3.in.lidar/main.c:219
-msgid "3D raster map of proportional sum of values"
+#: ../vector/v.out.svg/main.c:109
+msgid "Attribute(s) to include in output SVG"
 msgstr ""
-#: ../raster3d/r3.in.lidar/main.c:221
-msgid "Sum of values per 3D cell divided by sum of values per vertical column"
+#: ../vector/v.out.svg/main.c:130
+msgid "Precision must not be negative"
 msgstr ""
-#: ../raster3d/r3.in.lidar/main.c:229 ../raster/r.in.lidar/main.c:258
-#: ../vector/v.in.lidar/main.c:201
-msgid "Only import points of selected return type"
+#: ../vector/v.out.svg/main.c:133
+msgid "Precision must not be higher than 15"
 msgstr ""
-#: ../raster3d/r3.in.lidar/main.c:230 ../raster/r.in.lidar/main.c:259
-#: ../vector/v.in.lidar/main.c:202
-msgid "If not specified, all points are imported"
+#: ../vector/v.out.svg/main.c:201
+#, c-format
+msgid "Unable to create SVG file <%s>"
 msgstr ""
-#: ../raster3d/r3.in.lidar/main.c:239 ../raster/r.in.lidar/main.c:268
-#: ../vector/v.in.lidar/main.c:211
-msgid "Only import points of selected class(es)"
+#: ../vector/v.out.svg/main.c:218
+#, c-format
+msgid "No areas found, skipping %s"
 msgstr ""
-#: ../raster3d/r3.in.lidar/main.c:240 ../raster/r.in.lidar/main.c:269
-#: ../vector/v.in.lidar/main.c:212
-msgid "Input is comma separated integers. If not specified, all points are imported."
+#: ../vector/v.out.svg/main.c:233 ../vector/v.extrude/main.c:275
+#, c-format
+msgid "Skipping area %d without centroid"
 msgstr ""
-#: ../raster3d/r3.in.lidar/main.c:248
-msgid "Subtract raster values from the z coordinates"
+#: ../vector/v.out.svg/main.c:259
+#, c-format
+msgid "%d areas extracted"
 msgstr ""
-#: ../raster3d/r3.in.lidar/main.c:250
-msgid "The scale for z is applied beforehand, the filter afterwards"
+#: ../vector/v.out.svg/main.c:266
+#, c-format
+msgid "No points found, skipping %s"
 msgstr ""
-#: ../raster3d/r3.in.lidar/main.c:251 ../raster3d/r3.in.lidar/main.c:264
-#: ../raster3d/r3.in.lidar/main.c:280 ../raster/r.in.lidar/main.c:184
-#: ../raster/r.in.lidar/main.c:200 ../raster/r.in.lidar/main.c:216
-msgid "Transform"
+#: ../vector/v.out.svg/main.c:295
+#, c-format
+msgid "%d points extracted"
 msgstr ""
-#: ../raster3d/r3.in.lidar/main.c:256
-msgid "Use base raster actual resolution instead of computational region"
+#: ../vector/v.out.svg/main.c:302
+#, c-format
+msgid "No lines found, skipping %s"
 msgstr ""
-#: ../raster3d/r3.in.lidar/main.c:263 ../raster/r.in.lidar/main.c:199
-msgid "Scale to apply to Z data"
+#: ../vector/v.out.svg/main.c:329
+#, c-format
+msgid "%d lines extracted"
 msgstr ""
-#: ../raster3d/r3.in.lidar/main.c:271 ../raster/r.in.lidar/main.c:207
-msgid "Filter range for intensity values (min,max)"
+#: ../vector/v.out.svg/main.c:396
+#, c-format
+msgid "Cannot select attributes for cat=%d"
 msgstr ""
-#: ../raster3d/r3.in.lidar/main.c:279 ../raster/r.in.lidar/main.c:215
-msgid "Scale to apply to intensity values"
+#: ../vector/v.neighbors/main.c:51 ../raster/r.quantile/main.c:266
+#: ../raster/r.neighbors/main.c:168 ../raster/r.mapcalc/main.c:71
+#: ../raster/r.mode/main.c:57 ../raster/r.texture/main.c:103
+#: ../raster/r.mfilter/main.c:57
+#: ../locale/scriptstrings/t.rast3d.mapcalc_to_translate.c:3
+#: ../locale/scriptstrings/t.rast.mapcalc_to_translate.c:3
+#: ../locale/scriptstrings/t.rast.algebra_to_translate.c:3
+#: ../locale/scriptstrings/t.rast3d.algebra_to_translate.c:3
+#: ../locale/scriptstrings/t.vect.algebra_to_translate.c:3
+#: ../raster3d/r3.neighbors/main.c:209
+msgid "algebra"
 msgstr ""
-#: ../raster3d/r3.in.lidar/main.c:284 ../raster/r.in.lidar/main.c:335
-#: ../vector/v.in.lidar/main.c:291
-msgid "Use only valid points"
+#: ../vector/v.neighbors/main.c:54 ../raster/r.patch/main.c:63
+#: ../raster/r.neighbors/main.c:170 ../raster/r.in.lidar/main.c:113
+#: ../raster/r.in.xyz/main.c:162 ../raster/r.series/main.c:138
+#: ../locale/scriptstrings/t.rast.aggregate_to_translate.c:3
+#: ../locale/scriptstrings/r.reclass.area_to_translate.c:4
+#: ../locale/scriptstrings/t.rast.series_to_translate.c:3
+#: ../locale/scriptstrings/t.rast.aggregate.ds_to_translate.c:3
+#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:8
+#: ../locale/scriptstrings/t.rast.neighbors_to_translate.c:3
+#: ../raster3d/r3.in.lidar/main.c:167 ../raster3d/r3.neighbors/main.c:212
+msgid "aggregation"
 msgstr ""
-#: ../raster3d/r3.in.lidar/main.c:286 ../raster/r.in.lidar/main.c:337
-#: ../vector/v.in.lidar/main.c:293
-msgid "Points invalid according to APSRS LAS specification will be filtered out"
+#: ../vector/v.neighbors/main.c:55
+msgid "Neighborhood analysis tool for vector point maps."
 msgstr ""
-#: ../raster3d/r3.in.lidar/main.c:299 ../raster/r.in.lidar/main.c:276
-#: ../vector/v.in.lidar/main.c:276
-msgid "Print LAS file info and exit"
+#: ../vector/v.neighbors/main.c:56
+msgid ""
+"Makes each cell value a function of the attribute values assigned to the "
+"vector points or centroids around it, and stores new cell values in an "
+"output raster map."
 msgstr ""
-#: ../raster3d/r3.in.lidar/main.c:329
-#, c-format
-msgid "%s will not be taken into account during scan"
+#: ../vector/v.neighbors/main.c:72 ../raster/r.neighbors/main.c:204
+msgid "Neighborhood operation"
+msgstr "Operācijas ar blakusšūnām"
+#: ../vector/v.neighbors/main.c:78
+msgid "Neighborhood diameter in map units"
 msgstr ""
-#: ../raster3d/r3.in.lidar/main.c:340 ../raster/r.in.lidar/main.c:367
-#, c-format
-msgid "File <%s> does not exist"
+#: ../vector/v.neighbors/main.c:98
+msgid "Input vector and computational region do not overlap"
 msgstr ""
-#: ../raster3d/r3.in.lidar/main.c:374 ../raster/r.in.lidar/main.c:397
-#: ../vector/v.in.lidar/main.c:347
+#: ../vector/v.neighbors/main.c:103
 #, c-format
-msgid "Input file <%s> does not exist"
+msgid ""
+"The search diameter %g is smaller than cell diagonal %g: some points could "
+"not be detected"
 msgstr ""
-#: ../raster3d/r3.in.lidar/main.c:378 ../raster/r.in.lidar/main.c:401
-#, c-format
-msgid "Unable to open file <%s> as a LiDAR point cloud"
+#: ../vector/v.in.db/main.c:57
+msgid ""
+"Creates new vector (points) map from database table containing coordinates."
 msgstr ""
-#: ../raster3d/r3.in.lidar/main.c:382 ../raster/r.in.lidar/main.c:405
-#: ../vector/v.in.lidar/main.c:356
-#, c-format
-msgid "Unable to read LAS header of <%s>"
+#: ../vector/v.in.db/main.c:61
+msgid "Input table name"
 msgstr ""
-#: ../raster3d/r3.in.lidar/main.c:398 ../raster/r.in.lidar/main.c:421
-msgid "First file's projection checked, checking projection of the other files..."
+#: ../vector/v.in.db/main.c:66 ../vector/v.in.db/main.c:70
+msgid "Input DB"
 msgstr ""
-#: ../raster3d/r3.in.lidar/main.c:540
-#, fuzzy
-msgid "Preparing the maps..."
-msgstr "Lasam dig_att failu...\n"
+#: ../vector/v.in.db/main.c:75
+msgid "Name of column containing x coordinate"
+msgstr ""
-#: ../raster3d/r3.in.lidar/main.c:574 ../vector/v.sample/main.c:200
-msgid "Reading points..."
+#: ../vector/v.in.db/main.c:80
+msgid "Name of column containing y coordinate"
 msgstr ""
-#: ../raster3d/r3.in.lidar/main.c:656
-#, fuzzy
-msgid "Computing proportional count map..."
-msgstr "Elementa nosaukums"
+#: ../vector/v.in.db/main.c:84
+msgid "Name of column containing z coordinate"
+msgstr ""
-#: ../raster3d/r3.in.lidar/main.c:661
-#, fuzzy
-msgid "Computing proportional sum map..."
-msgstr "Tabulu kopēšana"
+#: ../vector/v.in.db/main.c:85 ../vector/v.random/main.c:137
+#: ../vector/v.random/main.c:146 ../vector/v.random/main.c:159
+#: ../vector/v.random/main.c:169 ../vector/v.random/main.c:174
+msgid "3D output"
+msgstr "3D izvade"
-#: ../raster3d/r3.in.lidar/main.c:666
-#, fuzzy
-msgid "Computing mean map..."
+#: ../vector/v.in.db/main.c:90
+msgid "Name of column containing category number"
+msgstr ""
-#: ../raster3d/r3.in.lidar/main.c:671
-#, fuzzy
-msgid "Closing the maps..."
-msgstr "baāzes rastra karte"
+#: ../vector/v.in.db/main.c:91
+msgid "Must refer to an integer column"
+msgstr ""
-#: ../raster3d/r3.in.lidar/main.c:707 ../vector/v.in.lidar/main.c:783
-#, c-format
-msgid "%lu input points were not valid and filtered out"
+#: ../vector/v.in.db/main.c:101
+msgid "Use imported table as attribute table for new map"
 msgstr ""
-#: ../raster3d/r3.in.lidar/main.c:710 ../vector/v.in.lidar/main.c:789
+#: ../vector/v.in.db/main.c:141
 #, c-format
-msgid "%lu input points were filtered out by return number"
+msgid ""
+"Vector map <%s> cannot be overwritten because input table <%s> is linked to "
+"this map."
 msgstr ""
-#: ../raster3d/r3.in.lidar/main.c:712 ../vector/v.in.lidar/main.c:791
+#: ../vector/v.in.db/main.c:177
 #, c-format
-msgid "%lu input points were filtered out by class number"
+msgid ""
+"Output vector map, table <%s> (driver: <%s>, database: <%s>) already exists"
 msgstr ""
-#: ../raster3d/r3.in.lidar/main.c:714
-#, fuzzy, c-format
-msgid "%lu input points had intensity out of range"
-msgstr "%d punkti ielādēti\n"
-#: ../raster3d/r3.in.lidar/main.c:716 ../vector/v.in.lidar/main.c:811
+#: ../vector/v.in.db/main.c:194
 #, c-format
-msgid "%lu input points were not valid, use -%c flag to filter them out"
+msgid "Option <%s> must be specified when -%c flag is given"
 msgstr ""
-#: ../raster3d/r3.in.lidar/rast_segment.c:53
-#: ../raster/r.in.lidar/rast_segment.c:40
-msgid "Cannot create temporary file with segments of a raster map"
-msgstr ""
-#: ../raster3d/r3.in.lidar/string_list.c:47
-#: ../raster/r.in.lidar/string_list.c:34
+#: ../vector/v.in.db/main.c:199
 #, c-format
-msgid "Cannot open file %s for reading"
+msgid ""
+"Unable to define key column. This operation is not supported by <%s> driver. "
+"You need to define <%s> option."
 msgstr ""
-#: ../raster3d/r3.in.lidar/filters.c:27
-#, fuzzy, c-format
-msgid "Invalid range <%s> for option %s"
-msgstr "nederīgs reģions: %s"
-#: ../raster3d/r3.in.lidar/filters.c:54 ../vector/v.in.pdal/filters.c:95
-#: ../vector/v.in.lidar/filters.c:36
+#: ../vector/v.in.db/main.c:225 ../display/d.vect.chart/plot.c:86
+#: ../display/d.vect/attr.c:110
 #, c-format
-msgid "Unknown return filter value <%s>"
+msgid "Unable to open select cursor: '%s'"
 msgstr ""
-#: ../raster3d/r3.in.lidar/info.c:109 ../raster/r.in.xyz/main.c:1203
-#: ../raster/r.in.lidar/info.c:108
-msgid "Scanning data ..."
+#: ../vector/v.in.db/main.c:243
+msgid "Key column must be integer"
 msgstr ""
-#: ../raster3d/r3.in.lidar/info.c:149 ../raster/r.in.xyz/main.c:1309
-#: ../raster/r.in.lidar/info.c:148
-#, c-format
-msgid "Range:     min         max\n"
+#: ../vector/v.in.db/main.c:256
+msgid "x/y/z column must be integer or double"
 msgstr ""
-#: ../raster3d/r3.in.lidar/projection.c:36 ../raster/r.external/proj.c:42
-#: ../raster/r.in.gdal/main.c:493 ../raster/r.in.lidar/projection.c:34
-#: ../vector/v.in.pdal/projection.c:31 ../vector/v.external/proj.c:51
-#: ../vector/v.in.ogr/main.c:627 ../vector/v.in.lidar/projection.c:32
-msgid ""
-"Projection of dataset does not appear to match current location.\n"
-"\n"
+#: ../vector/v.in.db/main.c:288
+msgid "Unable to copy table"
 msgstr ""
-#: ../raster3d/r3.in.lidar/projection.c:42 ../raster/r.in.lidar/projection.c:40
-#: ../vector/v.in.pdal/projection.c:37 ../vector/v.external/proj.c:57
-#: ../vector/v.in.ogr/main.c:633 ../vector/v.in.lidar/projection.c:38
-msgid "GRASS LOCATION PROJ_INFO is:\n"
+#: ../vector/v.in.db/main.c:313
+#, c-format
+msgid "Unable to add key column <%s>: SERIAL type is not supported by <%s>"
 msgstr ""
-#: ../raster3d/r3.in.lidar/projection.c:51
-#: ../raster3d/r3.in.lidar/projection.c:57 ../raster/r.external/proj.c:85
-#: ../raster/r.in.gdal/main.c:545 ../raster/r.in.lidar/projection.c:49
-#: ../raster/r.in.lidar/projection.c:55 ../vector/v.in.pdal/projection.c:46
-#: ../vector/v.in.pdal/projection.c:52 ../vector/v.external/proj.c:67
-#: ../vector/v.external/proj.c:74 ../vector/v.in.ogr/main.c:643
-#: ../vector/v.in.ogr/main.c:650 ../vector/v.in.lidar/projection.c:47
-#: ../vector/v.in.lidar/projection.c:53
-msgid "Import dataset PROJ_INFO is:\n"
+#: ../vector/v.in.db/main.c:324
+#, c-format
+msgid "Failed to update key column <%s>"
 msgstr ""
-#: ../raster3d/r3.in.lidar/projection.c:93 ../raster/r.external/proj.c:107
-#: ../raster/r.in.gdal/main.c:563 ../raster/r.in.lidar/projection.c:91
-#: ../vector/v.in.pdal/projection.c:88 ../vector/v.external/proj.c:113
-#: ../vector/v.in.ogr/main.c:689 ../vector/v.in.lidar/projection.c:89
+#: ../vector/v.in.db/main.c:340
 #, c-format
-msgid ""
-"\n"
-"In case of no significant differences in the projection definitions, use the -o flag to ignore them and use current location definition.\n"
-msgstr ""
+msgid "%d point written to vector map."
+msgid_plural "%d points written to vector map."
+msgstr[0] ""
+msgstr[1] ""
+msgstr[2] ""
-#: ../raster3d/r3.in.lidar/projection.c:97 ../raster/r.in.lidar/projection.c:95
-#: ../vector/v.in.pdal/projection.c:92 ../vector/v.external/proj.c:117
-#: ../vector/v.in.ogr/main.c:693 ../vector/v.in.lidar/projection.c:93
-msgid "Consider generating a new location with 'location' parameter from input data set.\n"
+#: ../vector/v.net.alloc/main.c:66 ../vector/v.net.iso/main.c:78
+#: ../raster/r.walk/main.c:181 ../raster/r.cost/main.c:143
+msgid "cost allocation"
 msgstr ""
-#: ../raster3d/r3.in.lidar/projection.c:115
-#: ../raster/r.in.lidar/projection.c:113 ../vector/v.in.pdal/projection.c:110
-#: ../vector/v.in.pdal/projection.c:156 ../vector/v.in.pdal/projection.c:189
-#: ../vector/v.external/proj.c:41 ../vector/v.in.ogr/main.c:603
-#: ../vector/v.in.lidar/projection.c:111
-msgid "Unable to convert input map projection information to GRASS format for checking"
+#: ../vector/v.net.alloc/main.c:67
+msgid "Allocates subnets for nearest centers."
 msgstr ""
-#: ../raster3d/r3.in.lidar/projection.c:130 ../raster/r.external/proj.c:34
-#: ../raster/r.in.gdal/main.c:483 ../raster/r.in.lidar/projection.c:128
-#: ../vector/v.in.ogr/main.c:618 ../vector/v.in.lidar/projection.c:126
-msgid "Over-riding projection check"
+#: ../vector/v.net.alloc/main.c:69
+msgid ""
+"Center node must be opened (costs >= 0). Costs of center node are used in "
+"calculation."
 msgstr ""
-#: ../raster3d/r3.in.lidar/projection.c:141 ../raster/r.external/proj.c:116
-#: ../raster/r.in.gdal/main.c:583 ../raster/r.in.lidar/projection.c:139
-#: ../vector/v.in.pdal/projection.c:137 ../vector/v.external/proj.c:122
-#: ../vector/v.in.ogr/main.c:708 ../vector/v.in.lidar/projection.c:137
-msgid "Projection of input dataset and current location appear to match"
+#: ../vector/v.net.alloc/main.c:81 ../vector/v.net.iso/main.c:95
+msgid "Use costs from centers or costs to centers"
 msgstr ""
-#: ../raster3d/r3.out.vtk/parameters.c:30
-msgid "3D raster map(s) to be converted to VTK-ASCII data format"
+#: ../vector/v.net.alloc/main.c:88 ../vector/v.net.iso/main.c:102
+msgid ""
+"Categories of centers (points on nodes) to which net will be allocated, "
+"layer for this categories is given by nlayer option"
 msgstr ""
-#: ../raster3d/r3.out.vtk/parameters.c:34 ../raster/r.out.vtk/parameters.c:36
-msgid "Name for VTK-ASCII output file"
+#: ../vector/v.net.alloc/main.c:129 ../vector/v.net.iso/main.c:150
+#: ../vector/v.net.path/main.c:110 ../vector/v.net.salesman/main.c:181
+msgid "Use turntable"
 msgstr ""
-#: ../raster3d/r3.out.vtk/parameters.c:41
-msgid "Float value to represent no data cell/points"
+#: ../vector/v.net.alloc/main.c:135 ../vector/v.net.iso/main.c:156
+#: ../vector/v.net.path/main.c:116 ../vector/v.net.salesman/main.c:187
+msgid "Layer with turntable"
 msgstr ""
-#: ../raster3d/r3.out.vtk/parameters.c:47
-msgid "Create VTK pointdata instead of VTK celldata (celldata is default)"
+#: ../vector/v.net.alloc/main.c:137 ../vector/v.net.alloc/main.c:145
+#: ../vector/v.net.iso/main.c:158 ../vector/v.net.iso/main.c:166
+#: ../vector/v.net.path/main.c:118 ../vector/v.net.path/main.c:126
+#: ../vector/v.net.salesman/main.c:188 ../vector/v.net.salesman/main.c:195
+msgid "Relevant only with -t flag"
 msgstr ""
-#: ../raster3d/r3.out.vtk/parameters.c:56
-msgid "Top surface 2D raster map"
-msgstr ""
+#: ../vector/v.net.alloc/main.c:156 ../vector/v.net.iso/main.c:177
+#, fuzzy
+msgid "Create unique categories and attribute table"
+msgstr "Izejas rastra kartes nosaukums"
-#: ../raster3d/r3.out.vtk/parameters.c:65
-msgid "Bottom surface 2D raster map"
+#: ../vector/v.net.alloc/main.c:158
+msgid "Default: same category like nearest center"
 msgstr ""
-#: ../raster3d/r3.out.vtk/parameters.c:71
-msgid "Create 3D elevation output with a top and a bottom surface, both raster maps are required."
+#: ../vector/v.net.alloc/main.c:224 ../vector/v.net.iso/main.c:282
+#: ../vector/v.net.salesman/main.c:277
+msgid "Point is not connected to the network"
 msgstr ""
-#: ../raster3d/r3.out.vtk/parameters.c:80
-msgid "Three (R,G,B) 3D raster maps to create RGB values [redmap,greenmap,bluemap]"
+#: ../vector/v.net.alloc/main.c:232 ../vector/v.net.iso/main.c:290
+msgid "Center at closed node (costs = -1) ignored"
 msgstr ""
-#: ../raster3d/r3.out.vtk/parameters.c:88
-msgid "Three (x,y,z) 3D raster maps to create vector values [xmap,ymap,zmap]"
-msgstr ""
+#: ../vector/v.net.alloc/main.c:250 ../vector/v.net.iso/main.c:308
+#, fuzzy, c-format
+msgid "Number of centers: %d (nlayer %d)"
+msgstr "Punktu skaits: %d"
-#: ../raster3d/r3.out.vtk/parameters.c:94 ../raster/r.out.vtk/parameters.c:85
-#: ../vector/v.out.vtk/main.c:76
-msgid "Scale factor for elevation"
+#: ../vector/v.net.alloc/main.c:253 ../vector/v.net.iso/main.c:311
+msgid "Not enough centers for selected nlayer. Nothing will be allocated."
 msgstr ""
-#: ../raster3d/r3.out.vtk/parameters.c:107 ../raster/r.out.ascii/main.c:79
-#: ../raster/r.out.vtk/parameters.c:98 ../display/d.rast.num/main.c:104
-#: ../vector/v.out.vtk/main.c:70 ../vector/v.out.ascii/args.c:75
-msgid "Number of significant digits (floating point only)"
+#: ../vector/v.net.alloc/main.c:275 ../vector/v.net.alloc/main.c:287
+#: ../vector/v.net.iso/main.c:333 ../vector/v.net.iso/main.c:345
+msgid "Calculating costs from centers ..."
 msgstr ""
-#: ../raster3d/r3.out.vtk/parameters.c:112
-msgid "Use 3D raster mask (if exists) with input maps"
+#: ../vector/v.net.alloc/main.c:280 ../vector/v.net.alloc/main.c:291
+#: ../vector/v.net.iso/main.c:338 ../vector/v.net.iso/main.c:349
+msgid "Calculating costs to centers ..."
 msgstr ""
-#: ../raster3d/r3.out.vtk/parameters.c:117
-msgid "Scale factor affects the origin"
+#: ../vector/v.net.alloc/main.c:342
+#, fuzzy
+msgid "Allocating subnets..."
+msgstr "Aprēķina %s..."
+#: ../vector/v.net.alloc/main.c:592 ../vector/v.net.alloc/main.c:627
+#: ../vector/v.net.iso/main.c:704
+msgid "Cannot get line segment, segment out of line"
 msgstr ""
-#: ../raster3d/r3.out.vtk/parameters.c:123 ../raster/r.out.vtk/parameters.c:128
-msgid "Correct the coordinates to match the VTK-OpenGL precision"
+#: ../vector/v.out.pov/main.c:49
+msgid "Converts GRASS x,y,z points to POV-Ray x,z,y format."
 msgstr ""
-#: ../raster3d/r3.out.vtk/parameters.c:129
-msgid "Do not convert the top-bottom resolution in case of lat long projection to meters"
+#: ../vector/v.out.pov/main.c:60
+msgid "Name for output POV file"
 msgstr ""
-#: ../raster3d/r3.out.vtk/writeVTKData.c:122
-msgid "write_vtk_points: Writing point coordinates"
+#: ../vector/v.out.pov/main.c:67
+msgid "Radius of sphere for points and tube for lines"
 msgstr ""
-#: ../raster3d/r3.out.vtk/writeVTKData.c:256
-msgid "write_vtk_unstructured_grid_cells: Writing the cells"
+#: ../vector/v.out.pov/main.c:68
+msgid "May be also variable, e.g. grass_r."
 msgstr ""
-#: ../raster3d/r3.out.vtk/writeVTKData.c:335
-#, c-format
-msgid "write_vtk_data: Writing Celldata %s with rows %i cols %i depths %i to vtk-ascii file"
+#: ../vector/v.out.pov/main.c:74
+msgid "Modifier for z coordinates"
 msgstr ""
-#: ../raster3d/r3.out.vtk/writeVTKData.c:441
-msgid "Wrong 3D raster map values! Values should in between 0 and 255!"
+#: ../vector/v.out.pov/main.c:75
+msgid ""
+"This string is appended to each z coordinate. Examples: '*10', '+1000', "
+"'*10+100', '*exaggeration'"
 msgstr ""
-#: ../raster3d/r3.out.vtk/main.c:117
-msgid "Specify top and bottom map"
+#: ../vector/v.out.pov/main.c:82
+msgid "Object modifier (OBJECT_MODIFIER in POV-Ray documentation)"
 msgstr ""
-#: ../raster3d/r3.out.vtk/main.c:124
-#, c-format
-msgid "Top cell map <%s> not found"
+#: ../vector/v.out.pov/main.c:83
+msgid "Example: \"pigment { color red 0 green 1 blue 0 }\""
 msgstr ""
-#: ../raster3d/r3.out.vtk/main.c:133
+#: ../vector/v.out.pov/main.c:104 ../raster/r.topmodel/topmodel.c:77
+#: ../raster/r.topmodel/file_io.c:209
 #, c-format
-msgid "Bottom cell map <%s> not found"
+msgid "Unable to create output file <%s>"
 msgstr ""
-#: ../raster3d/r3.out.vtk/main.c:152
+#: ../vector/v.out.pov/main.c:218
 #, c-format
-msgid "3D raster map RGB map <%s> not found"
-msgstr ""
+msgid "%d feature written."
+msgid_plural "%d features written."
+msgstr[0] ""
+msgstr[1] ""
+msgstr[2] ""
-#: ../raster3d/r3.out.vtk/main.c:155
-msgid "Please provide three RGB 3D raster maps"
+#: ../vector/v.net.components/main.c:74
+msgid "components"
 msgstr ""
-#: ../raster3d/r3.out.vtk/main.c:165
-#, c-format
-msgid "3D vector map <%s> not found"
+#: ../vector/v.net.components/main.c:76
+msgid "Computes strongly and weakly connected components in the network."
 msgstr ""
-#: ../raster3d/r3.out.vtk/main.c:168
-msgid "Please provide three 3D raster maps for the xyz-vector maps [x,y,z]"
+#: ../vector/v.net.components/main.c:124
+msgid "Weakly connected components"
 msgstr ""
-#: ../raster3d/r3.out.vtk/main.c:175
-msgid "No 3D raster data, RGB or xyz-vector maps are provided! Will only write the geometry."
+#: ../vector/v.net.components/main.c:125
+msgid "Strongly connected components"
 msgstr ""
-#: ../raster3d/r3.out.vtk/main.c:209
-msgid "No RGB Data will be created."
+#: ../vector/v.net.components/main.c:127
+msgid "Type of components"
 msgstr ""
-#: ../raster3d/r3.out.vtk/main.c:294
-msgid "No vector data will be created."
+#: ../vector/v.net.components/main.c:131 ../vector/v.net.centrality/main.c:192
+msgid "Add points on nodes"
 msgstr ""
-#: ../raster3d/r3.out.vtk/main.c:381
-msgid "Converts 3D raster maps into the VTK-ASCII format."
+#: ../vector/v.net.components/main.c:203
+msgid "Computing weakly connected components..."
 msgstr ""
-#: ../raster3d/r3.out.vtk/main.c:392
-msgid "failed to interpret dp as an integer"
+#: ../vector/v.net.components/main.c:207
+msgid "Computing strongly connected components..."
 msgstr ""
-#: ../raster3d/r3.out.vtk/main.c:394 ../raster/r.out.ascii/main.c:116
-msgid "dp has to be from 0 to 20"
+#: ../vector/v.net.components/main.c:213 ../vector/v.out.postgis/main.c:174
+#: ../vector/v.surf.bspline/main.c:899 ../raster/r.resamp.bspline/main.c:746
+msgid "Writing output..."
 msgstr ""
-#: ../raster3d/r3.out.vtk/main.c:542
-msgid "Unable to close 3D raster map, the VTK file may be incomplete"
+#: ../vector/v.net.components/main.c:279
+#, c-format
+msgid "Found %d components."
 msgstr ""
-#: ../raster3d/r3.out.vtk/main.c:557
-msgid "Unable to close VTK-ASCII file"
-msgstr ""
+#: ../vector/v.net.iso/main.c:79
+msgid "isolines"
+msgstr "izolīnijas"
-#: ../raster3d/r3.out.vtk/errorHandling.c:105
-msgid "Unable to close input raster maps"
+#: ../vector/v.net.iso/main.c:80
+msgid "Splits subnets for nearest centers by cost isolines."
 msgstr ""
-#: ../raster/r.mode/main.c:59
-msgid "Finds the mode of values in a cover map within areas assigned the same category value in a user-specified base map."
+#: ../vector/v.net.iso/main.c:82
+msgid ""
+"Splits net to bands between cost isolines (direction from center). Center "
+"node must be opened (costs >= 0). Costs of center node are used in "
+"calculation."
 msgstr ""
-#: ../raster/r.mode/main.c:65
-msgid "Base map to be reclassified"
+#: ../vector/v.net.iso/main.c:111
+msgid "Costs for isolines"
 msgstr ""
-#: ../raster/r.mode/main.c:72
-msgid "Coverage map"
+#: ../vector/v.net.iso/main.c:179
+msgid "Default: one category for each iso-band"
 msgstr ""
-#: ../raster/r.mode/main.c:79
-msgid "Output map"
+#: ../vector/v.net.iso/main.c:215
+#, c-format
+msgid "Wrong iso cost: %f"
 msgstr ""
-#: ../raster/r.mode/main.c:92
+#: ../vector/v.net.iso/main.c:218
 #, c-format
-msgid "%s: Unable to read category labels"
+msgid "Iso cost: %f less than previous"
 msgstr ""
-#: ../raster/r.mode/main.c:143 ../raster/r.resamp.interp/main.c:370
-#: ../raster/r.tile/main.c:200 ../raster/r.resamp.filter/main.c:579
-#: ../raster/r.resamp.stats/main.c:395
+#: ../vector/v.net.iso/main.c:223
 #, c-format
-msgid "Unable to read color table for %s"
+msgid "Iso cost %d: %f"
 msgstr ""
-#: ../raster/r.mode/read_stats.c:14
-msgid "reading r.stats output"
+#: ../vector/v.net.iso/main.c:231
+msgid "Not enough costs, everything reachable falls to first band"
 msgstr ""
-#: ../raster/r.thin/thin_lines.c:67
-msgid "Unable to find bounding box for lines"
-msgstr ""
+#: ../vector/v.net.iso/main.c:403
+#, fuzzy
+msgid "Generating isolines..."
+msgstr "Rakstu jaunu failu... \n"
-#: ../raster/r.thin/thin_lines.c:69
+#: ../vector/v.out.postgis/table.c:27
 #, c-format
-msgid "Bounding box:  l = %d, r = %d, t = %d, b = %d"
+msgid "No database connection for layer <%s>"
 msgstr ""
-#: ../raster/r.thin/thin_lines.c:116
+#: ../vector/v.out.postgis/table.c:50
 #, c-format
-msgid "Pass number %d"
+msgid ""
+"Invalid FID column (%s). FID column must be integer. Please specify "
+"different FID column by 'options=\"FID=<name>\"'."
 msgstr ""
-#: ../raster/r.thin/thin_lines.c:167
+#: ../vector/v.out.postgis/table.c:57
 #, c-format
-msgid "Deleted %d pixel"
-msgid_plural "Deleted %d pixels"
-msgstr[0] ""
-msgstr[1] ""
-msgstr[2] ""
-#: ../raster/r.thin/thin_lines.c:171
-msgid "Thinning completed successfully."
+msgid ""
+"Column (%s) already exists in the table. Please specify different geometry "
+"column by 'options=\"GEOMETRY_NAME=<name>\"'."
 msgstr ""
-#: ../raster/r.thin/thin_lines.c:173
-msgid "Thinning not completed, consider to increase 'iterations' parameter."
+#: ../vector/v.out.postgis/main.c:46
+msgid "PostGIS"
 msgstr ""
-#: ../raster/r.thin/main.c:60
-msgid "Thins non-null cells that denote linear features in a raster map layer."
+#: ../vector/v.out.postgis/main.c:47
+msgid "simple features"
 msgstr ""
-#: ../raster/r.thin/main.c:72
-msgid "Maximal number of iterations"
+#: ../vector/v.out.postgis/main.c:52
+msgid "Exports a vector map layer to PostGIS feature table."
 msgstr ""
-#: ../raster/r.thin/io.c:98
-msgid "Input raster must be of type CELL."
-msgstr ""
-#. GTC Count of raster rows
-#. GTC Count of window rows
-#: ../raster/r.thin/io.c:105 ../raster/r.thin/io.c:172
-#: ../raster/r.thin/io.c:181 ../display/d.rast.num/main.c:199
-#: ../vector/v.surf.idw/main.c:259 ../vector/v.kernel/main.c:303
+#: ../vector/v.out.postgis/main.c:103
 #, c-format
-msgid "%d row"
-msgid_plural "%d rows"
-msgstr[0] ""
-msgstr[1] ""
-msgstr[2] ""
-#. GTC Count of raster columns
-#. GTC Count of window columns
-#: ../raster/r.thin/io.c:107 ../raster/r.thin/io.c:174
-#: ../raster/r.thin/io.c:183 ../vector/v.surf.idw/main.c:261
-#: ../vector/v.kernel/main.c:304
-#, c-format
-msgid "%d column"
-msgid_plural "%d columns"
-msgstr[0] ""
-msgstr[1] ""
-msgstr[2] ""
-#. GTC First argument is the raster map name, second and third - a string representing number of rows and cols
-#: ../raster/r.thin/io.c:109
-#, c-format
-msgid "Raster map <%s> - %s X %s"
+msgid "Vector map <%s> is not in native format. Export cancelled."
 msgstr ""
-#: ../raster/r.thin/io.c:122
+#: ../vector/v.out.postgis/main.c:110
 #, c-format
-msgid "Unable to create temporary file <%s> -- errno = %d"
+msgid "Unable to open vector map <%s> on topological level"
 msgstr ""
-#: ../raster/r.thin/io.c:131 ../raster/r.thin/io.c:138
-#: ../raster/r.thin/io.c:147 ../raster/r.resamp.rst/main.c:547
-#: ../vector/v.surf.rst/main.c:869
+#: ../vector/v.out.postgis/main.c:134
 #, c-format
-msgid "Error writing temporary file <%s>"
+msgid "Unable to create PostGIS layer <%s>"
 msgstr ""
-#. GTC %s will be replaced with number of rows and columns
-#: ../raster/r.thin/io.c:176
+#: ../vector/v.out.postgis/main.c:156
 #, c-format
-msgid "Output map %s X %s"
+msgid "Feature type '%s' not supported"
 msgstr ""
-#: ../raster/r.thin/io.c:185
+#: ../vector/v.out.postgis/main.c:161
 #, c-format
-msgid "Window %s X %s"
+msgid "Feature type %d is not supported"
 msgstr ""
-#: ../raster/r.reclass/reclass.c:51 ../raster/r.reclass/reclass.c:111
-msgid "Too many categories"
+#: ../vector/v.out.postgis/main.c:168
+msgid "Copying features failed"
 msgstr ""
-#: ../raster/r.reclass/reclass.c:216
+#: ../vector/v.out.postgis/main.c:181
 #, c-format
-msgid "Cannot read header file of <%s@%s>"
+msgid "Building %s topology failed"
 msgstr ""
-#: ../raster/r.reclass/reclass.c:234
+#: ../vector/v.out.postgis/main.c:186
 #, c-format
-msgid "Cannot overwrite existing raster map <%s>"
+msgid "No features exported. PostGIS layer <%s> not created."
 msgstr ""
-#: ../raster/r.reclass/reclass.c:239
+#: ../vector/v.out.postgis/main.c:190
 #, c-format
-msgid "Cannot create reclass file of <%s>"
-msgstr ""
+msgid "%d feature (%s type) written to <%s>."
+msgid_plural "%d features (%s type) written to <%s>."
+msgstr[0] ""
+msgstr[1] ""
+msgstr[2] ""
-#: ../raster/r.reclass/reclass.c:247
+#: ../vector/v.out.postgis/main.c:196
 #, c-format
-msgid "Cannot create raster map <%s>"
+msgid "%d primitive written to <%s>."
+msgid_plural "%d primitives written to <%s>."
+msgstr[0] ""
+msgstr[1] ""
+msgstr[2] ""
+#: ../vector/v.out.postgis/main.c:247
+#, c-format
+msgid "Unable to drop topology schema <%s>"
 msgstr ""
-#: ../raster/r.reclass/main.c:51 ../raster/r.recode/main.c:50
-#: ../vector/v.reclass/main.c:68
-msgid "reclassification"
+#: ../vector/v.out.postgis/args.c:25
+msgid "Name for output PostGIS datasource"
 msgstr ""
-#: ../raster/r.reclass/main.c:52
-msgid "Reclassify raster map based on category values."
+#: ../vector/v.out.postgis/args.c:27
+msgid "Starts with 'PG' prefix, eg. 'PG:dbname=grass'"
 msgstr ""
-#: ../raster/r.reclass/main.c:54
-msgid "Creates a new raster map whose category values are based upon a reclassification of the categories in an existing raster map."
+#: ../vector/v.out.postgis/args.c:35
+msgid "Name for output PostGIS layer"
 msgstr ""
-#: ../raster/r.reclass/main.c:59
-msgid "Name of raster map to be reclassified"
+#: ../vector/v.out.postgis/args.c:37
+msgid "If not specified, input name is used"
 msgstr ""
-#: ../raster/r.reclass/main.c:65
-msgid "File containing reclass rules"
+#: ../vector/v.out.postgis/args.c:44
+msgid ""
+"Name for output vector map defined as a link to the PostGIS feature table"
 msgstr ""
-#: ../raster/r.reclass/main.c:72 ../raster/r.clump/main.c:75
-#: ../raster/r.neighbors/main.c:221 ../raster/r.recode/main.c:67
-msgid "Title for output raster map"
+#: ../vector/v.out.postgis/args.c:46
+msgid ""
+"If not specified, the vector link is not created. The link can be also "
+"manually created by 'v.external' module."
 msgstr ""
-#: ../raster/r.reclass/main.c:83
-msgid "Input map can NOT be the same as output map"
+#: ../vector/v.out.postgis/args.c:53
+msgid ""
+"Examples:\n"
+"\t\t'FID=cat': define feature id column 'cat'\n"
+"\t\t'GEOMETRY_NAME=wkb_geometry': define geometry column 'wkb_geometry'\n"
+"\t\t'SPATIAL_INDEX=NO': do not create spatial index on geometry column"
 msgstr ""
-#: ../raster/r.reclass/main.c:89
-#, c-format
-msgid "Cannot open rules file <%s>"
+#: ../vector/v.out.postgis/args.c:66
+msgid "Do not export attribute table"
 msgstr ""
-#: ../raster/r.reclass/main.c:103
-#, c-format
-msgid "Enter rule(s), \"end\" when done, \"help\" if you need it\n"
+#: ../vector/v.out.postgis/args.c:72
+msgid "Export PostGIS topology instead of simple features"
 msgstr ""
-#: ../raster/r.reclass/main.c:105
-#, c-format
-msgid "FCELL: Data range is %.7g to %.7g\n"
+#: ../vector/v.out.postgis/args.c:77
+msgid "Force 2D output even if input is 3D "
 msgstr ""
-#: ../raster/r.reclass/main.c:108
+#: ../vector/v.out.postgis/create.c:28
 #, c-format
-msgid "DCELL: Data range is %.15g to %.15g\n"
+msgid "Unable to create <%s> file"
 msgstr ""
-#: ../raster/r.reclass/main.c:111
+#: ../vector/v.out.postgis/create.c:66
 #, c-format
-msgid "CELL: Data range is %ld to %ld\n"
+msgid "Invalid option skipped: %s"
 msgstr ""
-#: ../raster/r.reclass/main.c:119
+#: ../vector/v.out.postgis/create.c:77
 #, c-format
-msgid "Illegal reclass rule -"
+msgid "EPSG code defined for current location (%s) is overridden by %s"
 msgstr ""
-#: ../raster/r.reclass/main.c:120
+#: ../vector/v.out.postgis/create.c:105
 #, c-format
-msgid " ignored\n"
+msgid "Error writing <%s> file"
 msgstr ""
-#: ../raster/r.reclass/main.c:123
-msgid " - invalid reclass rule"
-msgstr ""
+#: ../vector/v.distance/main.c:122 ../raster/r.distance/main.c:40
+#: ../raster/r.grow.distance/main.c:151
+#: ../locale/scriptstrings/r.grow_to_translate.c:3 ../misc/m.measure/main.c:48
+#: ../misc/m.cogo/main.c:226 ../display/d.geodesic/main.c:47
+#: ../display/d.rhumbline/main.c:45
+msgid "distance"
+msgstr "attālums"
-#: ../raster/r.reclass/main.c:139
-#, c-format
-msgid "No rules specified. Raster map <%s> not created"
+#: ../vector/v.distance/main.c:126
+msgid ""
+"Finds the nearest element in vector map 'to' for elements in vector map "
+"'from'."
 msgstr ""
-#: ../raster/r.reclass/main.c:142 ../raster/r.recode/main.c:99
-#: ../raster/r.quant/main.c:183
-msgid "No rules specified"
+#: ../vector/v.distance/main.c:130
+msgid "Name of existing vector map (from)"
 msgstr ""
-#: ../raster/r.reclass/parse.c:41 ../raster/r.colors/rules.c:104
-#, c-format
-msgid "Enter a rule in one of these formats:\n"
+#: ../vector/v.distance/main.c:131 ../vector/v.distance/main.c:136
+#: ../vector/v.distance/main.c:143 ../vector/v.distance/main.c:187
+#: ../vector/v.distance/main.c:224 ../vector/v.net.distance/main.c:101
+#: ../vector/v.net.distance/main.c:106 ../vector/v.net.distance/main.c:112
+msgid "From"
 msgstr ""
-#: ../raster/r.reclass/parse.c:42
-msgid "poor quality"
+#: ../vector/v.distance/main.c:135
+msgid "Layer number or name (from)"
+msgstr "Slāņa numurs vai nosaukums (no)"
+#: ../vector/v.distance/main.c:142
+msgid "Feature type (from)"
 msgstr ""
-#: ../raster/r.reclass/parse.c:44
-msgid "medium quality"
+#: ../vector/v.distance/main.c:147
+msgid "Name of existing vector map (to)"
 msgstr ""
-#: ../raster/r.reclass/parse.c:59
-msgid "Can't have null on the left-hand side of the rule"
+#: ../vector/v.distance/main.c:148 ../vector/v.distance/main.c:153
+#: ../vector/v.distance/main.c:160 ../vector/v.distance/main.c:230
+#: ../vector/v.net.distance/main.c:117 ../vector/v.net.distance/main.c:124
+#: ../vector/v.net.distance/main.c:129 ../vector/v.net.distance/main.c:135
+msgid "To"
+msgstr "Uz"
+#: ../vector/v.distance/main.c:152
+msgid "Layer number or name (to)"
+msgstr "Slāņa numurs vai nosaukums (uz)"
+#: ../vector/v.distance/main.c:159
+msgid "Feature type (to)"
 msgstr ""
-#: ../raster/r.reclass/parse.c:88 ../raster/r.reclass/parse.c:100
-msgid "Can't have null on the right-hand side of the rule"
+#: ../vector/v.distance/main.c:165
+msgid "Name for output vector map containing lines connecting nearest elements"
 msgstr ""
-#: ../raster/r.reclass/parse.c:196
-#, c-format
-msgid "%f rounded up to %d\n"
+#: ../vector/v.distance/main.c:173
+msgid "Maximum distance or -1 for no limit"
 msgstr ""
-#: ../raster/r.in.bin/main.c:61 ../raster/r.in.bin/main.c:70
-#: ../raster/r.in.bin/main.c:614
-msgid "Error reading data"
+#: ../vector/v.distance/main.c:180
+msgid "Minimum distance or -1 for no limit"
 msgstr ""
-#: ../raster/r.in.bin/main.c:260
-msgid "Import a binary raster file into a GRASS raster map layer."
+#: ../vector/v.distance/main.c:190
+msgid "Values describing the relation between two nearest features"
 msgstr ""
-#: ../raster/r.in.bin/main.c:265
-msgid "Import as floating-point data (default: integer)"
+#: ../vector/v.distance/main.c:200
+msgid "category of the nearest feature"
 msgstr ""
-#: ../raster/r.in.bin/main.c:270
-msgid "Import as double-precision floating-point data (default: integer)"
+#: ../vector/v.distance/main.c:201
+msgid "minimum distance to nearest feature"
 msgstr ""
-#: ../raster/r.in.bin/main.c:279
-msgid "Byte swap the data during import"
+#: ../vector/v.distance/main.c:202
+msgid "x coordinate of the nearest point on the 'to' feature"
 msgstr ""
-#: ../raster/r.in.bin/main.c:284
-msgid "Get region info from GMT style header"
+#: ../vector/v.distance/main.c:203
+msgid "y coordinate of the nearest point on the 'to' feature"
 msgstr ""
-#: ../raster/r.in.bin/main.c:288
-msgid "Name of binary raster file to be imported"
+#: ../vector/v.distance/main.c:204
+msgid ""
+"distance to the nearest point on the 'to' feature along that linear feature"
 msgstr ""
-#: ../raster/r.in.bin/main.c:291
-msgid "Output name or prefix if several bands are imported"
+#: ../vector/v.distance/main.c:206
+msgid ""
+"angle along the nearest linear feature in the 'to' map, measured CCW from "
+"the +x axis, in radians, between -Pi and Pi inclusive"
 msgstr ""
-#: ../raster/r.in.bin/main.c:305 ../raster/r.out.bin/main.c:311
-msgid "Number of bytes per cell"
+#: ../vector/v.distance/main.c:209
+msgid "attribute of nearest feature given by to_column option"
 msgstr ""
-#: ../raster/r.in.bin/main.c:313
-msgid "Header size in bytes"
+#: ../vector/v.distance/main.c:223
+msgid ""
+"Column name(s) where values specified by 'upload' option will be uploaded"
 msgstr ""
-#: ../raster/r.in.bin/main.c:321
-msgid "Number of bands in input file"
+#: ../vector/v.distance/main.c:229
+msgid "Column name of nearest feature (used with upload=to_attr)"
 msgstr ""
-#: ../raster/r.in.bin/main.c:322
-msgid "Bands must be in band-sequential order"
+#: ../vector/v.distance/main.c:234
+#, fuzzy
+msgid "Name for new attribute table"
+#: ../vector/v.distance/main.c:237
+msgid "Field separator for printing output to stdout"
 msgstr ""
-#: ../raster/r.in.bin/main.c:392
-msgid "Flip input horizontal and/or vertical"
+#: ../vector/v.distance/main.c:242
+msgid "Print output to stdout, don't update attribute table"
 msgstr ""
-#: ../raster/r.in.bin/main.c:395
-msgid "Flip input horizontal (East - West)"
+#: ../vector/v.distance/main.c:244
+msgid "First column is always category of 'from' feature called from_cat"
 msgstr ""
-#: ../raster/r.in.bin/main.c:396
-msgid "Flip input vertical (North - South)"
+#: ../vector/v.distance/main.c:249
+msgid "Calculate distances to all features within the threshold"
 msgstr ""
-#: ../raster/r.in.bin/main.c:410
-#, c-format
-msgid "Option %s must be > 0"
+#: ../vector/v.distance/main.c:251
+msgid ""
+"Output may be written to stdout using the '-p' flag or uploaded to a new "
+"table created by the 'table' option; multiple 'upload' options may be used."
 msgstr ""
-#: ../raster/r.in.bin/main.c:413
-#, c-format
-msgid "Option %s must be >= 0"
+#: ../vector/v.distance/main.c:291
+msgid "Updating the from= table is not supported with -a"
 msgstr ""
-#: ../raster/r.in.bin/main.c:426 ../raster/r.in.bin/main.c:432
-#: ../raster/r.neighbors/main.c:262 ../raster/r.stats.quantile/main.c:590
-#: ../raster/r.out.bin/main.c:369
-#, c-format
-msgid "-%c and %s= are mutually exclusive"
+#: ../vector/v.distance/main.c:307
+msgid "Printing distance matrix is not supported with dmin= or dmax="
 msgstr ""
-#: ../raster/r.in.bin/main.c:435 ../raster/r.in.bin/main.c:438
-#, c-format
-msgid "Option %s= is ignored if -%c is set"
+#: ../vector/v.distance/main.c:334
+msgid "to_column option missing"
 msgstr ""
-#: ../raster/r.in.bin/main.c:462 ../raster/r.out.bin/main.c:379
-#: ../vector/v.colors/main.c:225
-#, c-format
-msgid "-%c and -%c are mutually exclusive"
+#: ../vector/v.distance/main.c:350
+msgid "Too many column names"
 msgstr ""
-#: ../raster/r.in.bin/main.c:467
-#, c-format
-msgid "-%c incompatible with %s=%d; must be 4 or 8"
+#: ../vector/v.distance/main.c:357
+msgid "Not enough column names"
 msgstr ""
-#: ../raster/r.in.bin/main.c:476
+#: ../vector/v.distance/main.c:369 ../vector/v.distance/main.c:389
 #, c-format
-msgid "-%c incompatible with %s=%d; must be 8"
+msgid "Input vector map <%s> is 3D"
 msgstr ""
-#: ../raster/r.in.bin/main.c:484
+#: ../vector/v.distance/main.c:380 ../vector/v.distance/main.c:401
 #, c-format
-msgid "%s= required for integer data"
+msgid "No features of selected type found in <%s>"
 msgstr ""
-#: ../raster/r.in.bin/main.c:488
-#, c-format
-msgid "Integer input doesn't support %s=8 in this build"
+#: ../vector/v.distance/main.c:474
+msgid "dmin can not be larger than dmax"
 msgstr ""
-#: ../raster/r.in.bin/main.c:493
-#, c-format
-msgid "%s= must be 1, 2, 4 or 8"
+#: ../vector/v.distance/main.c:617
+msgid "Incompatible column types"
 msgstr ""
-#: ../raster/r.in.bin/main.c:506
-#, c-format
-msgid "Either -%c or %s= and %s= must be given"
+#: ../vector/v.distance/main.c:667
+msgid "No categories for 'from' for slected type and layer"
 msgstr ""
-#: ../raster/r.in.bin/main.c:512
-#, c-format
-msgid "Either all or none of %s=, %s=, %s= and %s= must be given"
+#: ../vector/v.distance/main.c:695
+msgid "Finding nearest features..."
 msgstr ""
-#: ../raster/r.in.bin/main.c:554
+#: ../vector/v.distance/main.c:796 ../vector/v.distance/main.c:1083
 #, c-format
-msgid "East-West (ewres: %f) and North-South (nwres: %f) resolution differ significantly. Did you assign %s= and %s= correctly?"
+msgid "More cats found in to_layer (line=%d)"
 msgstr ""
-#: ../raster/r.in.bin/main.c:575
-msgid "File Size %"
-msgstr "Faila izmērs %"
+#: ../vector/v.distance/main.c:810 ../vector/v.distance/main.c:887
+#: ../vector/v.distance/main.c:1097 ../imagery/i.segment/flag.c:21
+#: ../imagery/i.segment/flag.c:28
+msgid "Out of memory!"
+msgstr "Pietrūkst atmiņas!"
-#: ../raster/r.in.bin/main.c:595
+#: ../vector/v.distance/main.c:873 ../vector/v.distance/main.c:1230
 #, c-format
-msgid "Importing band %d..."
+msgid "More cats found in to_layer (area=%d)"
 msgstr ""
-#: ../raster/r.out.png/main.c:116
-msgid "Export a GRASS raster map as a non-georeferenced PNG image."
+#: ../vector/v.distance/main.c:983
+msgid "Finding nearest features for areas..."
 msgstr ""
-#: ../raster/r.out.png/main.c:122
-msgid "Name for new PNG file (use '-' for stdout)"
+#: ../vector/v.distance/main.c:1349
+msgid "DATETIME type not yet supported, no attributes will be uploaded"
 msgstr ""
-#: ../raster/r.out.png/main.c:130
-msgid "Compression level of PNG file"
+#: ../vector/v.distance/main.c:1365
+msgid "Unable to open default database"
 msgstr ""
-#: ../raster/r.out.png/main.c:131
-msgid "(0 = none, 1 = fastest, 9 = best)"
+#: ../vector/v.distance/main.c:1707
+#, c-format
+msgid "%d categories with more than 1 feature in vector map <%s>"
 msgstr ""
-#: ../raster/r.out.png/main.c:138
-msgid "Make NULL cells transparent"
-msgstr "Padarīt NULL šūnas caurspīdīgas"
-#: ../raster/r.out.png/main.c:142
-msgid "Output world file"
+#: ../vector/v.distance/main.c:1710
+#, c-format
+msgid "%d categories - no nearest feature found"
 msgstr ""
-#: ../raster/r.out.png/main.c:175 ../display/d.labels/color.c:68
-#: ../display/d.rast/display.c:27 ../display/d.graph/main.c:104
-#: ../display/d.graph/do_graph.c:105 ../display/d.graph/do_graph.c:355
-#: ../display/d.graph/do_graph.c:370 ../display/d.legend.vect/draw.c:198
-#: ../display/d.legend.vect/draw.c:209
+#: ../vector/v.distance/main.c:1719
 #, c-format
-msgid "[%s]: No such color"
+msgid "%d distances calculated"
 msgstr ""
-#: ../raster/r.out.png/main.c:257
+#: ../vector/v.distance/main.c:1720
 #, c-format
-msgid "Converting <%s>..."
-msgstr "Konvertē <%s>..."
+msgid "%d records inserted"
+msgstr ""
-#: ../raster/r.out.png/main.c:272 ../raster/r.univar/r.univar_main.c:201
+#: ../vector/v.distance/main.c:1722
 #, c-format
-msgid "Raster <%s> type mismatch"
+msgid "%d insert errors"
 msgstr ""
-#: ../raster/r.out.png/main.c:422
-msgid "Writing world file"
+#: ../vector/v.distance/main.c:1726
+#, c-format
+msgid "%d categories read from the map"
 msgstr ""
-#: ../raster/r.out.png/main.c:425
-msgid "Got null file name"
+#: ../vector/v.distance/main.c:1728
+#, c-format
+msgid "%d categories exist in the table"
 msgstr ""
-#: ../raster/r.out.png/main.c:427
-msgid "Got null region struct"
+#: ../vector/v.distance/main.c:1730
+#, c-format
+msgid "%d categories read from the map exist in the table"
 msgstr ""
-#: ../raster/r.out.png/main.c:429
-msgid "Unable to open world file for writing"
+#: ../vector/v.distance/main.c:1733
+#, c-format
+msgid "%d categories read from the map don't exist in the table"
 msgstr ""
-#: ../raster/r.in.xyz/main.c:167
-msgid "Creates a raster map from an assemblage of many coordinates using univariate statistics."
+#: ../vector/v.distance/main.c:1738 ../vector/v.what.rast/main.c:690
+#, c-format
+msgid "%d records updated."
 msgstr ""
-#: ../raster/r.in.xyz/main.c:171
-msgid "ASCII file containing input data (or \"-\" to read from stdin)"
+#: ../vector/v.distance/distance.c:49
+#, c-format
+msgid "Invalid segment number %d for %d points"
 msgstr ""
-#: ../raster/r.in.xyz/main.c:198 ../raster/r.in.lidar/main.c:158
-msgid "Number of points in cell"
+#: ../vector/v.distance/distance.c:426
+msgid "At least one point is really inside the area!"
 msgstr ""
-#: ../raster/r.in.xyz/main.c:199 ../raster/r.in.lidar/main.c:159
-msgid "Minimum value of point values in cell"
+#: ../vector/v.net.bridge/main.c:49
+msgid "articulation points"
 msgstr ""
-#: ../raster/r.in.xyz/main.c:200 ../raster/r.in.lidar/main.c:160
-msgid "Maximum value of point values in cell"
+#: ../vector/v.net.bridge/main.c:51
+msgid "Computes bridges and articulation points in the network."
 msgstr ""
-#: ../raster/r.in.xyz/main.c:201 ../raster/r.in.lidar/main.c:161
-msgid "Range of point values in cell"
+#: ../vector/v.net.bridge/main.c:98
+msgid "Finds bridges"
 msgstr ""
-#: ../raster/r.in.xyz/main.c:202 ../raster/r.in.lidar/main.c:162
-msgid "Sum of point values in cell"
+#: ../vector/v.net.bridge/main.c:99
+msgid "Finds articulation points"
 msgstr ""
-#: ../raster/r.in.xyz/main.c:203 ../raster/r.in.lidar/main.c:163
-msgid "Mean (average) value of point values in cell"
+#: ../vector/v.edit/snap.c:111 ../vector/v.edit/close.c:56
+#, c-format
+msgid "Unable to rewrite line %d"
 msgstr ""
-#: ../raster/r.in.xyz/main.c:204 ../raster/r.in.lidar/main.c:164
-msgid "Standard deviation of point values in cell"
+#: ../vector/v.edit/main.c:56 ../vector/v.type/main.c:40
+#: ../locale/scriptstrings/d.rast.edit_to_translate.c:3
+msgid "editing"
 msgstr ""
-#: ../raster/r.in.xyz/main.c:205 ../raster/r.in.lidar/main.c:165
-msgid "Variance of point values in cell"
+#: ../vector/v.edit/main.c:63
+msgid ""
+"Edits a vector map, allows adding, deleting and modifying selected vector "
+"features."
 msgstr ""
-#: ../raster/r.in.xyz/main.c:206 ../raster/r.in.lidar/main.c:166
-msgid "Coefficient of variance of point values in cell"
+#: ../vector/v.edit/main.c:72
+#, c-format
+msgid "Unable to get category list <%s>"
 msgstr ""
-#: ../raster/r.in.xyz/main.c:207 ../raster/r.in.lidar/main.c:167
-msgid "Median value of point values in cell"
+#: ../vector/v.edit/main.c:119
+msgid "Supported feature types for non-native formats:"
 msgstr ""
-#: ../raster/r.in.xyz/main.c:208
-msgid "Pth (nth) percentile of point values in cell"
+#: ../vector/v.edit/main.c:140
+#, c-format
+msgid ""
+"Unable to open vector map <%s> on topological level. Try to rebuild vector "
+"topology by v.build."
 msgstr ""
-#: ../raster/r.in.xyz/main.c:209 ../raster/r.in.lidar/main.c:169
-msgid "Skewness of point values in cell"
+#: ../vector/v.edit/main.c:160
+#, c-format
+msgid ""
+"Unable to open vector map <%s> as the background map. It is given as vector "
+"map to be edited."
 msgstr ""
-#: ../raster/r.in.xyz/main.c:210 ../raster/r.in.lidar/main.c:170
-msgid "Trimmed mean of point values in cell"
+#: ../vector/v.edit/main.c:171
+#, c-format
+msgid "Background vector map <%s> registered"
 msgstr ""
-#: ../raster/r.in.xyz/main.c:239
-msgid "If a separate value column is given, this option refers to the z-coordinate column to be filtered by the zrange option"
+#: ../vector/v.edit/main.c:208
+msgid "Threshold for snapping must be > 0. No snapping applied."
 msgstr ""
-#: ../raster/r.in.xyz/main.c:250
-msgid "Number of header lines to skip at top of input file"
+#: ../vector/v.edit/main.c:215
+msgid "Selecting features..."
 msgstr ""
-#: ../raster/r.in.xyz/main.c:258 ../vector/v.decimate/main.c:146
-#: ../vector/v.in.lidar/main.c:194
-msgid "Filter range for z data (min,max)"
+#: ../vector/v.edit/main.c:227
+msgid "No features selected, nothing to edit"
 msgstr ""
-#: ../raster/r.in.xyz/main.c:259 ../raster/r.in.xyz/main.c:267
-#: ../raster/r.in.xyz/main.c:276 ../raster/r.in.xyz/main.c:284
-#: ../raster/r.in.xyz/main.c:292
-msgid "Advanced Input"
+#: ../vector/v.edit/main.c:235
+#, c-format
+msgid ""
+"Vector map <%s> is not 3D. Tool '%s' requires 3D vector map. Please convert "
+"the vector map to 3D using e.g. %s."
 msgstr ""
-#: ../raster/r.in.xyz/main.c:266
-msgid "Scale to apply to z data"
-msgstr ""
+#: ../vector/v.edit/main.c:277
+#, c-format
+msgid "%d feature added"
+msgid_plural "%d features added"
+msgstr[0] ""
+msgstr[1] ""
+msgstr[2] ""
-#: ../raster/r.in.xyz/main.c:274
-msgid "Alternate column number of data values in input file"
+#: ../vector/v.edit/main.c:285 ../vector/v.edit/main.c:314
+#: ../vector/v.edit/main.c:325 ../vector/v.edit/main.c:357
+#: ../vector/v.edit/main.c:365 ../vector/v.edit/main.c:374
+#: ../vector/v.edit/main.c:383 ../vector/v.edit/main.c:430
+#, c-format
+msgid "Threshold value for snapping is %.2f"
 msgstr ""
-#: ../raster/r.in.xyz/main.c:275
-msgid "If not given (or set to 0) the z-column data is used"
-msgstr ""
+#: ../vector/v.edit/main.c:297
+#, c-format
+msgid "%d boundary closed"
+msgid_plural "%d boundaries closed"
+msgstr[0] ""
+msgstr[1] ""
+msgstr[2] ""
-#: ../raster/r.in.xyz/main.c:283
-msgid "Filter range for alternate value column data (min,max)"
-msgstr ""
+#: ../vector/v.edit/main.c:306
+#, c-format
+msgid "%d feature deleted"
+msgid_plural "%d features deleted"
+msgstr[0] ""
+msgstr[1] ""
+msgstr[2] ""
-#: ../raster/r.in.xyz/main.c:291
-msgid "Scale to apply to alternate value column data"
-msgstr ""
+#: ../vector/v.edit/main.c:317
+#, c-format
+msgid "%d feature moved"
+msgid_plural "%d features moved"
+msgstr[0] ""
+msgstr[1] ""
+msgstr[2] ""
-#: ../raster/r.in.xyz/main.c:314
-msgid "Pth percentile of the values"
-msgstr ""
+#: ../vector/v.edit/main.c:328
+#, c-format
+msgid "%d vertex moved"
+msgid_plural "%d vertices moved"
+msgstr[0] ""
+msgstr[1] ""
+msgstr[2] ""
-#: ../raster/r.in.xyz/main.c:329 ../raster/r.in.xyz/main.c:336
-msgid "Scan"
-msgstr ""
+#: ../vector/v.edit/main.c:334
+#, c-format
+msgid "%d vertex added"
+msgid_plural "%d vertices added"
+msgstr[0] ""
+msgstr[1] ""
+msgstr[2] ""
-#: ../raster/r.in.xyz/main.c:366
-msgid "Please specify a reasonable column number."
-msgstr ""
+#: ../vector/v.edit/main.c:340
+#, c-format
+msgid "%d vertex removed"
+msgid_plural "%d vertices removed"
+msgstr[0] ""
+msgstr[1] ""
+msgstr[2] ""
-#: ../raster/r.in.xyz/main.c:378 ../vector/v.in.ascii/main.c:218
-msgid "Please specify reasonable number of lines to skip"
-msgstr ""
+#: ../vector/v.edit/main.c:352
+#, c-format
+msgid "%d line broken"
+msgid_plural "%d lines broken"
+msgstr[0] "%d līnija ir bojāta"
+msgstr[1] "%d līnijas ir bojātas"
+msgstr[2] "%d līniju ir bojātas"
-#: ../raster/r.in.xyz/main.c:383 ../raster/r.in.lidar/main.c:477
-msgid "Invalid zrange"
-msgstr ""
+#: ../vector/v.edit/main.c:360
+#, c-format
+msgid "%d line connected"
+msgid_plural "%d lines connected"
+msgstr[0] ""
+msgstr[1] ""
+msgstr[2] ""
-#: ../raster/r.in.xyz/main.c:397
-msgid "Invalid vrange"
-msgstr ""
+#: ../vector/v.edit/main.c:369 ../vector/v.edit/main.c:378
+#: ../vector/v.edit/main.c:387
+#, fuzzy, c-format
+msgid "%d line extended"
+msgid_plural "%d lines extended"
+msgstr[0] "%d punkti ierakstīti izejas kartē\n"
+msgstr[1] "%d punkti ierakstīti izejas kartē\n"
+msgstr[2] "%d punkti ierakstīti izejas kartē\n"
-#: ../raster/r.in.xyz/main.c:483 ../raster/r.in.lidar/point_binning.c:205
-msgid "Unable to calculate percentile without the pth option specified!"
-msgstr ""
+#: ../vector/v.edit/main.c:393
+#, c-format
+msgid "%d line merged"
+msgid_plural "%d lines merged"
+msgstr[0] ""
+msgstr[1] ""
+msgstr[2] ""
-#: ../raster/r.in.xyz/main.c:495 ../raster/r.in.lidar/point_binning.c:217
-msgid "Unable to calculate trimmed mean without the trim option specified!"
-msgstr ""
+#: ../vector/v.edit/main.c:402 ../vector/v.edit/main.c:408
+#, c-format
+msgid "%d feature modified"
+msgid_plural "%d features modified"
+msgstr[0] ""
+msgstr[1] ""
+msgstr[2] ""
-#: ../raster/r.in.xyz/main.c:536
+#: ../vector/v.edit/main.c:415
 #, c-format
-msgid "Unable to process the hole map at once. Please set the %s option to some value lower than 100."
+msgid ""
+"Multiple background maps were given. Selected features will be copied only "
+"from vector map <%s>."
 msgstr ""
-#: ../raster/r.in.xyz/main.c:589
-msgid "If input is not from a file it is only possible to perform a single pass."
-msgstr ""
+#: ../vector/v.edit/main.c:425
+#, c-format
+msgid "%d feature copied"
+msgid_plural "%d features copied"
+msgstr[0] ""
+msgstr[1] ""
+msgstr[2] ""
-#: ../raster/r.in.xyz/main.c:601
-msgid "Range filters will not be taken into account during scan"
-msgstr ""
+#: ../vector/v.edit/main.c:436
+#, c-format
+msgid "%d line flipped"
+msgid_plural "%d lines flipped"
+msgstr[0] ""
+msgstr[1] ""
+msgstr[2] ""
-#: ../raster/r.in.xyz/main.c:638
-msgid "Reading input data..."
-msgstr ""
-#: ../raster/r.in.xyz/main.c:645 ../raster/r.in.poly/poly2rast.c:56
+#: ../vector/v.edit/main.c:457
 #, c-format
-msgid "Pass #%d (of %d) ..."
-msgstr ""
+msgid "%d line labeled"
+msgid_plural "%d lines labeled"
+msgstr[0] ""
+msgstr[1] ""
+msgstr[2] ""
-#: ../raster/r.in.xyz/main.c:721 ../raster/r.in.xyz/main.c:729
-#: ../raster/r.in.xyz/main.c:1218 ../raster/r.in.xyz/main.c:1226
+#: ../vector/v.edit/main.c:466
 #, c-format
-msgid ""
-"Not enough data columns. Incorrect delimiter or column number? Found the following character(s) in row %lu:\n"
-"[%s]"
-msgstr ""
+msgid "%d feature converted"
+msgid_plural "%d features converted"
+msgstr[0] ""
+msgstr[1] ""
+msgstr[2] ""
-#: ../raster/r.in.xyz/main.c:725 ../raster/r.in.xyz/main.c:1222
-msgid "Line ignored as requested"
+#: ../vector/v.edit/main.c:471
+msgid "No feature modified"
 msgstr ""
-#: ../raster/r.in.xyz/main.c:744 ../raster/r.in.xyz/main.c:1256
+#: ../vector/v.edit/main.c:478
 #, c-format
-msgid "Bad y-coordinate line %lu column %d. <%s>"
+msgid "Select feature %d is not centroid, ignoring..."
 msgstr ""
-#: ../raster/r.in.xyz/main.c:751 ../raster/r.in.xyz/main.c:1241
+#: ../vector/v.edit/main.c:485
 #, c-format
-msgid "Bad x-coordinate line %lu column %d. <%s>"
+msgid "%d area removed"
+msgid_plural "%d areas removed"
+msgstr[0] ""
+msgstr[1] ""
+msgstr[2] ""
+#: ../vector/v.edit/main.c:491
+msgid "Operation not implemented"
 msgstr ""
-#: ../raster/r.in.xyz/main.c:769 ../raster/r.in.xyz/main.c:1271
-#, c-format
-msgid "Bad z-coordinate line %lu column %d. <%s>"
+#: ../vector/v.edit/args.c:20
+msgid "Name of vector map to edit"
 msgstr ""
-#: ../raster/r.in.xyz/main.c:782 ../raster/r.in.xyz/main.c:1289
-#, c-format
-msgid "Bad data value line %lu column %d. <%s>"
+#: ../vector/v.edit/args.c:36
+msgid "Tool"
 msgstr ""
-#: ../raster/r.in.xyz/main.c:835
-#, c-format
-msgid "%lu points found in input file"
+#: ../vector/v.edit/args.c:61
+msgid "Create new (empty) vector map"
 msgstr ""
-#: ../raster/r.in.xyz/main.c:838
-msgid "Writing to output raster map..."
+#: ../vector/v.edit/args.c:62
+msgid "Add new features to existing vector map"
 msgstr ""
-#: ../raster/r.in.xyz/main.c:1177
-#, c-format
-msgid "%lu points found in region."
+#: ../vector/v.edit/args.c:63
+msgid "Delete selected features from vector map"
 msgstr ""
-#: ../raster/r.univar/r3.univar_main.c:37
-msgid "3D Raster map used for zoning, must be of type CELL"
+#: ../vector/v.edit/args.c:64
+msgid "Move selected features in vector map"
 msgstr ""
-#: ../raster/r.univar/r3.univar_main.c:59 ../raster/r.univar/r.univar_main.c:61
-#: ../vector/v.univar/main.c:126 ../vector/v.what/main.c:100
-msgid "Print the stats in shell script style"
-msgstr "Drukāt statistiku komandrindas skripta stilā"
-#: ../raster/r.univar/r3.univar_main.c:67 ../raster/r.univar/r.univar_main.c:71
-msgid "Table output format instead of standard output format"
+#: ../vector/v.edit/args.c:65
+msgid "Move vertex of selected vector lines"
 msgstr ""
-#: ../raster/r.univar/r3.univar_main.c:103
-msgid "Calculates univariate statistics from the non-null cells of a 3D raster map."
+#: ../vector/v.edit/args.c:66
+msgid "Remove vertex from selected vector lines"
 msgstr ""
-#: ../raster/r.univar/r3.univar_main.c:105
-#: ../raster/r.univar/r.univar_main.c:112
-msgid "Statistics include number of cells counted, minimum and maximum cell values, range, arithmetic mean, population variance, standard deviation, coefficient of variation, and sum."
+#: ../vector/v.edit/args.c:67
+msgid "Add new vertex to selected vector lines"
 msgstr ""
-#: ../raster/r.univar/r3.univar_main.c:128
-#: ../raster/r.univar/r.univar_main.c:129 ../raster/r.quantile/main.c:310
-#: ../raster/r.stats.quantile/main.c:319 ../raster/r.regression.line/main.c:77
-#: ../raster/r.what/main.c:170 ../raster/r.stats/main.c:227
-#: ../raster/r.regression.multi/main.c:169 ../vector/v.db.select/main.c:126
-#: ../db/db.select/main.c:142
-#, c-format
-msgid "Unable to open file <%s> for writing"
+#: ../vector/v.edit/args.c:68
+msgid "Merge selected vector lines"
 msgstr ""
-#: ../raster/r.univar/r.univar_main.c:36
-msgid "Raster map used for zoning, must be of type CELL"
+#: ../vector/v.edit/args.c:69
+msgid "Break/split vector lines"
 msgstr ""
-#: ../raster/r.univar/r.univar_main.c:53 ../raster/r.univar/r.univar_main.c:67
-msgid "Extended"
+#: ../vector/v.edit/args.c:70
+msgid "Select lines and print their ID's"
 msgstr ""
-#: ../raster/r.univar/r.univar_main.c:76
-msgid "Use the native resolution and extent of the raster map, instead of the current region"
+#: ../vector/v.edit/args.c:71
+msgid "Set new categories to selected vector features for defined layer"
 msgstr ""
-#: ../raster/r.univar/r.univar_main.c:110
-msgid "Calculates univariate statistics from the non-null cells of a raster map."
+#: ../vector/v.edit/args.c:73
+msgid "Delete categories from selected vector features for defined layer"
 msgstr ""
-#: ../raster/r.univar/r.univar_main.c:123
-msgid "zones option and region flag -r are mutually exclusive"
+#: ../vector/v.edit/args.c:75
+msgid "Copy selected features"
 msgstr ""
-#: ../raster/r.surf.area/main.c:77 ../raster/r.resamp.bspline/main.c:81
-#: ../raster/r.surf.contour/main.c:61 ../raster/r.surf.fractal/main.c:39
-#: ../raster/r.surf.random/main.c:37 ../raster/r.surf.idw/main.c:105
-#: ../raster/r.surf.gauss/main.c:39 ../raster/r.contour/main.c:88
-#: ../raster/r.random.surface/main.c:58 ../vector/v.surf.rst/main.c:148
-#: ../vector/v.surf.idw/main.c:88 ../vector/v.vol.rst/main.c:237
-#: ../vector/v.surf.bspline/main.c:92
-msgid "surface"
+#: ../vector/v.edit/args.c:76
+msgid "Snap vector features in given threshold"
 msgstr ""
-#: ../raster/r.surf.area/main.c:79
-msgid "area estimation"
+#: ../vector/v.edit/args.c:77
+msgid "Flip direction of selected vector lines"
 msgstr ""
-#: ../raster/r.surf.area/main.c:80
-msgid "Prints estimation of surface area for raster map."
+#: ../vector/v.edit/args.c:78
+msgid "Connect two lines"
 msgstr ""
-#: ../raster/r.surf.area/main.c:89
-msgid "Vertical scale"
-msgstr "Vertikālais mērogs"
+#: ../vector/v.edit/args.c:79
+#, fuzzy
+msgid "Extend lines"
-#: ../raster/r.surf.area/main.c:93
-msgid "Output units"
-msgstr "Izvades vienības"
-#: ../raster/r.surf.area/main.c:94
-msgid "Default: square map units"
+#: ../vector/v.edit/args.c:80
+msgid "Extend start nodes"
 msgstr ""
-#: ../raster/r.surf.area/main.c:102
-#, c-format
-msgid "Output in '%s'"
+#: ../vector/v.edit/args.c:81
+msgid "Extend end nodes"
 msgstr ""
-#: ../raster/r.surf.area/main.c:106
-msgid "Output in 'square map units'"
+#: ../vector/v.edit/args.c:82
+msgid "Z bulk-labeling (automated assignment of z coordinate to vector lines)"
 msgstr ""
-#: ../raster/r.surf.area/main.c:153
-msgid "Null value area ignored in calculation:"
+#: ../vector/v.edit/args.c:84
+msgid "Change feature type (point<->centroid, line<->boundary)"
 msgstr ""
-#: ../raster/r.surf.area/main.c:155
-msgid "Plan area used in calculation:"
+#: ../vector/v.edit/args.c:85
+msgid "Delete selected areas from vector map (based on selected centroids)"
 msgstr ""
-#: ../raster/r.surf.area/main.c:158
-msgid "Surface area calculation(low, high, avg):"
+#: ../vector/v.edit/args.c:93
+msgid "Name of file containing data in GRASS ASCII vector format"
 msgstr ""
-#: ../raster/r.surf.area/main.c:163
-msgid "Current region plan area:"
+#: ../vector/v.edit/args.c:105
+msgid "Difference in x,y,z direction for moving feature or vertex"
 msgstr ""
-#: ../raster/r.surf.area/main.c:165
-msgid "Estimated region Surface Area:"
+#: ../vector/v.edit/args.c:112
+msgid "Threshold distance (coords,snap,query)"
 msgstr ""
-#: ../raster/r.in.png/main.c:297
-#, c-format
-msgid "Unable to open PNG file '%s'"
+#: ../vector/v.edit/args.c:114
+msgid "'-1' for threshold based on the current resolution settings"
 msgstr ""
-#: ../raster/r.in.png/main.c:300
-msgid "Input file empty or too short"
+#: ../vector/v.edit/args.c:130
+msgid "List of point coordinates"
 msgstr ""
-#: ../raster/r.in.png/main.c:303
-msgid "Input file not a PNG file"
+#: ../vector/v.edit/args.c:139
+msgid "Bounding box for selecting features"
 msgstr ""
-#: ../raster/r.in.png/main.c:314
-msgid "PNG error"
+#: ../vector/v.edit/args.c:148
+msgid "Polygon for selecting features"
 msgstr ""
-#: ../raster/r.in.png/main.c:485 ../raster/r.cross/main.c:169
-#: ../raster/r.resample/main.c:125 ../raster/r.basins.fill/main.c:146
-#, c-format
-msgid "Creating support files for <%s>..."
+#: ../vector/v.edit/args.c:158
+msgid "Query tool"
 msgstr ""
-#: ../raster/r.in.png/main.c:522
-msgid "Imports non-georeferenced PNG format image."
+#: ../vector/v.edit/args.c:160
+msgid "For 'shorter' use negative threshold value, positive value for 'longer'"
 msgstr ""
-#: ../raster/r.in.png/main.c:532
-msgid "Title for created raster map"
+#: ../vector/v.edit/args.c:166
+msgid "Select only lines or boundaries shorter/longer than threshold distance"
 msgstr ""
-#: ../raster/r.in.png/main.c:538
-msgid "Display gamma"
+#: ../vector/v.edit/args.c:168
+msgid "Select dangles shorter/longer than threshold distance"
 msgstr ""
-#: ../raster/r.in.png/main.c:544
-msgid "Alpha threshold"
+#: ../vector/v.edit/args.c:175
+msgid "Name of background vector map(s)"
 msgstr ""
-#: ../raster/r.in.png/main.c:548
-msgid "Create floating-point map (0.0 - 1.0)"
+#: ../vector/v.edit/args.c:182
+msgid ""
+"Snap added or modified features in the given threshold to the nearest "
+"existing feature"
 msgstr ""
-#: ../raster/r.in.png/main.c:552
-msgid "Output image file header only and exit"
+#: ../vector/v.edit/args.c:188
+msgid "Not apply snapping"
 msgstr ""
-#: ../raster/r.in.poly/get_item.c:97
-#, c-format
-msgid "Illegal coordinate <%s, %s>, skipping."
+#: ../vector/v.edit/args.c:189
+msgid "Snap only to node"
 msgstr ""
-#: ../raster/r.in.poly/get_item.c:102
-#, c-format
-msgid "Illegal north coordinate <%s>, skipping."
+#: ../vector/v.edit/args.c:190
+msgid "Allow snapping also to vertex"
 msgstr ""
-#: ../raster/r.in.poly/get_item.c:107
-#, c-format
-msgid "Illegal east coordinate <%s>, skipping."
+#: ../vector/v.edit/args.c:198
+msgid "Starting value and step for z bulk-labeling"
 msgstr ""
-#: ../raster/r.in.poly/main.c:37
-msgid "Creates raster maps from ASCII polygon/line/point data files."
+#: ../vector/v.edit/args.c:199
+msgid "Pair: value,step (e.g. 1100,10)"
 msgstr ""
-#: ../raster/r.in.poly/main.c:41
-msgid "Name of input file; or \"-\" to read from stdin"
+#: ../vector/v.edit/args.c:210
+msgid "Close added boundaries (using threshold distance)"
 msgstr ""
-#: ../raster/r.in.poly/main.c:60
-msgid "Integer representing NULL value data cell"
+#: ../vector/v.edit/args.c:214
+msgid "Do not expect header of input data"
 msgstr ""
-#: ../raster/r.in.poly/main.c:66
-msgid "Number of rows to hold in memory"
+#: ../vector/v.edit/args.c:222
+msgid "Modify only first found feature in bounding box"
 msgstr ""
-#: ../raster/r.in.poly/main.c:74
-msgid "Minimum number of rows to hold in memory is 1"
+#: ../vector/v.edit/args.c:227
+msgid "Connect parallel lines (using extend tools and threshold distance)"
 msgstr ""
-#: ../raster/r.in.poly/main.c:83
-msgid "Type doesn't exist"
+#: ../vector/v.edit/args.c:239
+msgid "Polygon must have at least 3 coordinate pairs"
 msgstr ""
-#: ../raster/r.in.poly/poly2rast.c:81 ../raster/r.carve/raster.c:33
-#: ../vector/v.to.rast/vect2rast.c:179
-msgid "Writing raster map..."
+#: ../vector/v.edit/args.c:312
+#, c-format
+msgid "Operation '%s' not implemented"
 msgstr ""
-#: ../raster/r.texture/main.c:68
+#: ../vector/v.edit/args.c:321
 #, c-format
-msgid "Unknown measure <%s>"
+msgid "At least one option from %s must be specified"
 msgstr ""
-#: ../raster/r.texture/main.c:105
-msgid "texture"
+#: ../vector/v.edit/args.c:327 ../vector/v.edit/args.c:336
+#: ../vector/v.edit/args.c:343 ../vector/v.edit/args.c:350
+#: ../vector/v.edit/args.c:354
+#, c-format
+msgid "Tool %s requires option %s"
 msgstr ""
-#: ../raster/r.texture/main.c:107
-msgid "Generate images with textural features from a raster map."
+#: ../vector/v.edit/select.c:73
+#, c-format
+msgid "Threshold value for coordinates is %.2f"
 msgstr ""
-#: ../raster/r.texture/main.c:121
-msgid "The size of moving window (odd and >= 3)"
+#: ../vector/v.edit/select.c:160
+#, c-format
+msgid "Threshold value for querying is %.2f"
 msgstr ""
-#: ../raster/r.texture/main.c:131
-msgid "The distance between two samples (>= 1)"
-msgstr ""
+#: ../vector/v.edit/select.c:176
+#, c-format
+msgid "%d of %d feature selected from vector map <%s>"
+msgid_plural "%d of %d features selected from vector map <%s>"
+msgstr[0] ""
+msgstr[1] ""
+msgstr[2] ""
-#: ../raster/r.texture/main.c:132
-msgid "The distance must be smaller than the size of the moving window"
+#: ../vector/v.edit/select.c:496
+msgid "Layer must be > 0 for 'where'"
 msgstr ""
-#: ../raster/r.texture/main.c:148
-msgid "Textural measurement method"
+#: ../vector/v.parallel/main.c:53
+msgid "Creates parallel line to input vector lines."
 msgstr ""
-#: ../raster/r.texture/main.c:152
-msgid "Separate output for each angle (0, 45, 90, 135)"
+#: ../vector/v.parallel/main.c:68
+msgid "Offset along major axis in map units"
 msgstr ""
-#: ../raster/r.texture/main.c:153
-msgid "Angles are counterclockwise from east: 0 is East to West, 45 is North-East to South-West"
+#: ../vector/v.parallel/main.c:76
+msgid "Offset along minor axis in map units"
 msgstr ""
-#: ../raster/r.texture/main.c:158
-msgid "Calculate all textural measurements"
+#: ../vector/v.parallel/main.c:93
+msgid "Side"
 msgstr ""
-#: ../raster/r.texture/main.c:162
-msgid "Allow NULL cells in a moving window"
+#: ../vector/v.parallel/main.c:97
+msgid "Parallel line is on the left"
 msgstr ""
-#: ../raster/r.texture/main.c:163
-#, fuzzy
-msgid "This will also avoid cropping along edges of the current region"
-msgstr "Sākuma punkts ir ārpus pašreizējā reģiona."
-#: ../raster/r.texture/main.c:172
-msgid "Size of the moving window must be > 0"
+#: ../vector/v.parallel/main.c:98
+msgid "Parallel line is on the right"
 msgstr ""
-#: ../raster/r.texture/main.c:174
-msgid "Size of the moving window must be odd"
+#: ../vector/v.parallel/main.c:99
+msgid "Parallel lines on both sides"
 msgstr ""
-#: ../raster/r.texture/main.c:177
-msgid "The distance between two samples must be > 0"
+#: ../vector/v.parallel/main.c:108
+msgid "Tolerance of arc polylines in map units"
 msgstr ""
-#: ../raster/r.texture/main.c:179
-msgid "The distance between two samples must be smaller than the size of the moving window"
+#: ../vector/v.parallel/main.c:112
+msgid "Make outside corners round"
 msgstr ""
-#: ../raster/r.texture/main.c:200
-msgid "Nothing to compute. Use at least one textural measure."
+#: ../vector/v.parallel/main.c:116
+msgid "Create buffer-like parallel lines"
 msgstr ""
-#: ../raster/r.texture/main.c:292 ../raster/r.carve/raster.c:13
-#: ../imagery/i.zc/main.c:156
-msgid "Reading raster map..."
+#: ../vector/v.timestamp/main.c:36 ../vector/v.support/main.c:40
+#: ../vector/v.info/main.c:38 ../raster/r.region/main.c:52
+#: ../raster/r.timestamp/main.c:36 ../raster/r.info/main.c:71
+#: ../raster/r.describe/main.c:55 ../raster/r.support/main.c:55
+#: ../locale/scriptstrings/t.support_to_translate.c:3
+#: ../locale/scriptstrings/t.info_to_translate.c:3
+#: ../locale/scriptstrings/t.select_to_translate.c:3
+#: ../temporal/t.connect/main.c:36 ../raster3d/r3.info/main.c:76
+#: ../raster3d/r3.timestamp/main.c:44 ../raster3d/r3.support/main.c:50
+msgid "metadata"
 msgstr ""
-#: ../raster/r.texture/main.c:342
-#, c-format
-msgid "Calculating %d texture measure"
-msgid_plural "Calculating %d texture measures"
-msgstr[0] ""
-msgstr[1] ""
-msgstr[2] ""
-#: ../raster/r.texture/main.c:345 ../imagery/i.vi/main.c:225
-#, c-format
-msgid "Calculating %s..."
+#: ../vector/v.timestamp/main.c:37 ../raster/r.timestamp/main.c:37
+#: ../raster3d/r3.timestamp/main.c:45
+msgid "timestamp"
 msgstr ""
-#: ../raster/r.texture/h_measure.c:156
-#, c-format
-msgid "Too many categories (found: %i, max: %i). Try to rescale or reclassify the map"
+#: ../vector/v.timestamp/main.c:38 ../raster/r.timestamp/main.c:38
+#: ../locale/scriptstrings/t.vect.list_to_translate.c:6
+#: ../locale/scriptstrings/t.rast3d.univar_to_translate.c:6
+#: ../locale/scriptstrings/t.rast.to.rast3_to_translate.c:7
+#: ../locale/scriptstrings/t.rast.export_to_translate.c:5
+#: ../locale/scriptstrings/t.unregister_to_translate.c:5
+#: ../locale/scriptstrings/t.rast3d.mapcalc_to_translate.c:6
+#: ../locale/scriptstrings/t.rast.accdetect_to_translate.c:5
+#: ../locale/scriptstrings/t.vect.extract_to_translate.c:5
+#: ../locale/scriptstrings/t.rename_to_translate.c:5
+#: ../locale/scriptstrings/t.rast.aggregate_to_translate.c:5
+#: ../locale/scriptstrings/t.rast.to.vect_to_translate.c:6
+#: ../locale/scriptstrings/t.rast3d.list_to_translate.c:7
+#: ../locale/scriptstrings/t.rast.series_to_translate.c:6
+#: ../locale/scriptstrings/t.support_to_translate.c:4
+#: ../locale/scriptstrings/t.create_to_translate.c:5
+#: ../locale/scriptstrings/t.snap_to_translate.c:5
+#: ../locale/scriptstrings/t.sample_to_translate.c:4
+#: ../locale/scriptstrings/t.rast.aggregate.ds_to_translate.c:5
+#: ../locale/scriptstrings/t.vect.observe.strds_to_translate.c:5
+#: ../locale/scriptstrings/t.rast.univar_to_translate.c:5
+#: ../locale/scriptstrings/t.rast.gapfill_to_translate.c:5
+#: ../locale/scriptstrings/t.rast.mapcalc_to_translate.c:5
+#: ../locale/scriptstrings/t.vect.export_to_translate.c:5
+#: ../locale/scriptstrings/t.info_to_translate.c:5
+#: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:5
+#: ../locale/scriptstrings/t.rast3d.extract_to_translate.c:6
+#: ../locale/scriptstrings/t.register_to_translate.c:5
+#: ../locale/scriptstrings/t.vect.what.strds_to_translate.c:5
+#: ../locale/scriptstrings/t.rast.list_to_translate.c:6
+#: ../locale/scriptstrings/t.rast.contour_to_translate.c:6
+#: ../locale/scriptstrings/t.rast.colors_to_translate.c:5
+#: ../locale/scriptstrings/t.rast.algebra_to_translate.c:5
+#: ../locale/scriptstrings/t.merge_to_translate.c:5
+#: ../locale/scriptstrings/v.what.strds_to_translate.c:8
+#: ../locale/scriptstrings/t.shift_to_translate.c:5
+#: ../locale/scriptstrings/t.remove_to_translate.c:5
+#: ../locale/scriptstrings/t.topology_to_translate.c:4
+#: ../locale/scriptstrings/t.select_to_translate.c:4
+#: ../locale/scriptstrings/t.rast.what_to_translate.c:5
+#: ../locale/scriptstrings/t.list_to_translate.c:5
+#: ../locale/scriptstrings/t.rast.extract_to_translate.c:5
+#: ../locale/scriptstrings/t.rast.import_to_translate.c:5
+#: ../locale/scriptstrings/t.vect.import_to_translate.c:5
+#: ../locale/scriptstrings/t.rast3d.algebra_to_translate.c:6
+#: ../locale/scriptstrings/t.vect.db.select_to_translate.c:7
+#: ../locale/scriptstrings/t.vect.univar_to_translate.c:5
+#: ../locale/scriptstrings/t.vect.algebra_to_translate.c:5
+#: ../locale/scriptstrings/t.rast.out.vtk_to_translate.c:6
+#: ../locale/scriptstrings/t.rast.neighbors_to_translate.c:5
+#: ../raster3d/r3.timestamp/main.c:46
+msgid "time"
 msgstr ""
-#: ../raster/r.texture/h_measure.c:738 ../raster/r.walk/main.c:808
-#: ../raster/r.cost/main.c:673 ../raster/r.stream.extract/load.c:44
-#: ../raster/r.stream.extract/load.c:53 ../imagery/i.smap/interp.c:68
-msgid "Unable to allocate memory"
+#: ../vector/v.timestamp/main.c:39
+msgid "Modifies a timestamp for a vector map."
 msgstr ""
-#: ../raster/r.external.out/main.c:38
-#, c-format
-msgid "Supported Formats:\n"
+#: ../vector/v.timestamp/main.c:40
+msgid "Print/add/remove a timestamp for a vector map."
 msgstr ""
-#: ../raster/r.external.out/main.c:132
-msgid "Unable to open GDAL file"
+#: ../vector/v.timestamp/main.c:50 ../raster/r.timestamp/main.c:49
+msgid "Datetime, datetime1/datetime2, or 'none' to remove"
 msgstr ""
-#: ../raster/r.external.out/main.c:156 ../vector/v.external.out/format.c:49
-#, c-format
-msgid "Format <%s> not supported"
+#: ../vector/v.timestamp/main.c:51 ../raster/r.timestamp/main.c:50
+msgid "Format: '15 jan 1994' (absolute) or '2 years' (relative)"
 msgstr ""
-#: ../raster/r.external.out/main.c:162
+#: ../vector/v.timestamp/main.c:66
 #, c-format
-msgid "Format <%s> does not support direct write"
+msgid "Vector map <%s> not found %s"
 msgstr ""
-#: ../raster/r.external.out/main.c:166 ../vector/v.external.out/format.c:52
-#, c-format
-msgid "Format <%s> does not support writing"
+#: ../vector/v.perturb/main.c:70
+msgid "Random location perturbations of vector points."
 msgstr ""
-#: ../raster/r.external.out/main.c:214
-msgid "Unable to create GDAL file"
+#: ../vector/v.perturb/main.c:84
+msgid "Distribution of perturbation"
 msgstr ""
-#: ../raster/r.external.out/main.c:217
-msgid "Error writing GDAL file"
+#: ../vector/v.perturb/main.c:91
+msgid "Parameter(s) of distribution"
 msgstr ""
-#: ../raster/r.external.out/main.c:237 ../vector/v.external.out/main.c:45
-msgid "output"
-msgstr "izvade"
-#: ../raster/r.external.out/main.c:238 ../raster/r.external/main.c:59
-#: ../vector/v.external/main.c:52 ../vector/v.external.out/main.c:46
-msgid "external"
+#: ../vector/v.perturb/main.c:92
+msgid ""
+"If the distribution is uniform, only one parameter, the maximum, is needed. "
+"For a normal distribution, two parameters, the mean and standard deviation, "
+"are required."
 msgstr ""
-#: ../raster/r.external.out/main.c:240
-msgid "Redirects raster output to file utilizing GDAL library rather than storing in GRASS raster format."
+#: ../vector/v.perturb/main.c:102
+msgid "Minimum deviation in map units"
 msgstr ""
-#: ../raster/r.external.out/main.c:244
-msgid "Name of output directory"
+#: ../vector/v.perturb/main.c:109
+msgid "Seed for random number generation"
 msgstr ""
-#: ../raster/r.external.out/main.c:251
-msgid "Extension for output files"
+#: ../vector/v.perturb/main.c:130 ../vector/v.perturb/main.c:137
+msgid "Error scanning arguments"
 msgstr ""
-#: ../raster/r.external.out/main.c:257
-msgid "Format of output files"
+#: ../vector/v.perturb/main.c:133
+msgid "Maximum of uniform distribution must be >= zero"
 msgstr ""
-#: ../raster/r.external.out/main.c:264 ../vector/v.out.postgis/args.c:52
-#: ../vector/v.external.out/args.c:39
-msgid "Creation options"
+#: ../vector/v.perturb/main.c:140
+msgid "Standard deviation of normal distribution must be >= zero"
 msgstr ""
-#: ../raster/r.external.out/main.c:271 ../raster/r.external/main.c:95
-#: ../raster/r.in.gdal/main.c:202 ../vector/v.external/args.c:51
-#: ../vector/v.external.out/args.c:62
-msgid "List supported formats and exit"
+#: ../vector/v.perturb/main.c:245
+msgid "Cannot get db link info"
 msgstr ""
-#: ../raster/r.external.out/main.c:277
-msgid "Cease using GDAL and revert to native output"
+#: ../vector/v.perturb/normalsv.c:29
+msgid "normalsv: save of uninitialized block"
 msgstr ""
-#: ../raster/r.external.out/main.c:282 ../vector/v.external.out/args.c:74
-msgid "Print current status"
+#: ../vector/v.perturb/normalrs.c:31
+msgid "normalsv: restoration of uninitialized block"
 msgstr ""
-#: ../raster/r.uslek/main.c:55 ../raster/r.sim/r.sim.sediment/main.c:115
-#: ../raster/r.sim/r.sim.water/main.c:115 ../raster/r.usler/main.c:55
-msgid "soil"
+#: ../vector/v.out.ascii/main.c:51
+msgid "Exports a vector map to a GRASS ASCII vector representation."
 msgstr ""
-#: ../raster/r.uslek/main.c:56 ../raster/r.sim/r.sim.sediment/main.c:117
-#: ../raster/r.usler/main.c:56
-msgid "erosion"
+#: ../vector/v.out.ascii/main.c:52
+msgid ""
+"By default only features with category are exported. To export all features "
+"use 'layer=-1'."
 msgstr ""
-#: ../raster/r.uslek/main.c:57
-msgid "Computes USLE Soil Erodibility Factor (K)."
+#: ../vector/v.out.ascii/main.c:60
+#, c-format
+msgid "Parameter '%s' ignored in standard mode"
 msgstr ""
-#: ../raster/r.uslek/main.c:62
-msgid "Name of soil sand fraction raster map [0.0-1.0]"
+#: ../vector/v.out.ascii/main.c:69
+#, c-format
+msgid "Format '%s' is not supported for old version"
 msgstr ""
-#: ../raster/r.uslek/main.c:66
-msgid "Name of soil clay fraction raster map [0.0-1.0]"
+#: ../vector/v.out.ascii/main.c:73
+#, c-format
+msgid "Parameter '%s' must be given for old version"
 msgstr ""
-#: ../raster/r.uslek/main.c:70
-msgid "Name of soil silt fraction raster map [0.0-1.0]"
+#: ../vector/v.out.ascii/main.c:80
+#, c-format
+msgid ""
+"Unable to open vector map <%s> at topology level. Areas will not be "
+"processed."
 msgstr ""
-#: ../raster/r.uslek/main.c:74
-msgid "Name of soil organic matter raster map [0.0-1.0]"
-msgstr ""
+#: ../vector/v.out.ascii/main.c:107
+#, c-format
+msgid "%d error in <%s> option"
+msgid_plural "%d errors in <%s> option"
+msgstr[0] ""
+msgstr[1] ""
+msgstr[2] ""
-#: ../raster/r.uslek/main.c:77
-msgid "Name for output USLE K factor raster map [t.ha.hr/ha.MJ.mm]"
+#: ../vector/v.out.ascii/main.c:141
+msgid "dig_att file already exist"
 msgstr ""
-#: ../raster/r.flow/mem.c:40
+#: ../vector/v.out.ascii/main.c:144
 #, c-format
-msgid "Unable to write segment file for %s"
+msgid "Unable to open dig_att file <%s>"
 msgstr ""
-#: ../raster/r.flow/main.c:314 ../raster/r.topidx/topidx.c:41
-#: ../imagery/i.landsat.toar/main.c:535
-msgid "Calculating..."
-msgstr "Aprēķina..."
-#: ../raster/r.flow/main.c:423
-msgid "Constructs flowlines."
+#: ../vector/v.out.ascii/main.c:149
+msgid "Fetching data..."
 msgstr ""
-#: ../raster/r.flow/main.c:425
-msgid "Computes flowlines, flowpath lengths, and flowaccumulation (contributing areas) from a elevation raster map."
+#: ../vector/v.out.ascii/main.c:156
+msgid "No points found, nothing to be exported"
 msgstr ""
-#: ../raster/r.flow/main.c:435 ../raster/r.flow/main.c:441
-#: ../raster/r.stream.extract/main.c:89 ../raster/r.stream.extract/main.c:97
-msgid "Input maps"
+#: ../vector/v.out.ascii/main.c:159
+msgid "No features found, nothing to be exported"
 msgstr ""
-#: ../raster/r.flow/main.c:440
-msgid "Name of input barrier raster map"
+#: ../vector/v.out.ascii/main.c:163
+msgid "An error occurred, nothing to be exported"
 msgstr ""
-#: ../raster/r.flow/main.c:447
-msgid "Number of cells between flowlines"
+#: ../vector/v.out.ascii/args.c:31
+msgid "Name for output ASCII file or ASCII vector name if '-o' is defined"
 msgstr ""
-#: ../raster/r.flow/main.c:453
-msgid "Maximum number of segments per flowline"
+#: ../vector/v.out.ascii/args.c:33 ../general/g.list/main.c:115
+msgid "If not given or '-' then standard output"
 msgstr ""
-#: ../raster/r.flow/main.c:458
-msgid "Name for output flow line vector map"
+#: ../vector/v.out.ascii/args.c:38
+msgid "Name of attribute column(s) to be exported (point mode)"
 msgstr ""
-#: ../raster/r.flow/main.c:459 ../raster/r.flow/main.c:465
-#: ../raster/r.flow/main.c:471 ../raster/r.stream.extract/main.c:149
-#: ../raster/r.stream.extract/main.c:156 ../raster/r.stream.extract/main.c:163
-msgid "Output maps"
-msgstr "Izvades kartes"
-#: ../raster/r.flow/main.c:464
-msgid "Name for output flow path length raster map"
+#: ../vector/v.out.ascii/args.c:39
+msgid "\"*\" for all columns"
 msgstr ""
-#: ../raster/r.flow/main.c:470
-msgid "Name for output flow accumulation raster map"
+#: ../vector/v.out.ascii/args.c:55 ../misc/m.transform/main.c:352
+#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:417
+msgid "Output format"
 msgstr ""
-#: ../raster/r.flow/main.c:476
-msgid "Compute upslope flowlines instead of default downhill flowlines"
+#: ../vector/v.out.ascii/args.c:59
+msgid "Simple point format (point per row)"
 msgstr ""
-#: ../raster/r.flow/main.c:480
-msgid "3D lengths instead of 2D"
+#: ../vector/v.out.ascii/args.c:60
+msgid "GRASS ASCII vector format"
 msgstr ""
-#: ../raster/r.flow/main.c:484
-msgid "Use less memory, at a performance penalty"
+#: ../vector/v.out.ascii/args.c:61
+msgid "OGC well-known text"
 msgstr ""
-#: ../raster/r.flow/main.c:539
-msgid "You must select one or more output maps (flout, lgout, dsout)"
+#: ../vector/v.out.ascii/args.c:65
+msgid "Field separator (points mode)"
 msgstr ""
-#: ../raster/r.flow/main.c:555
-msgid "lat/long projection not supported by r.flow. Please use 'r.watershed' for calculating flow accumulation."
+#: ../vector/v.out.ascii/args.c:80
+msgid "Create old (version 4) ASCII file"
 msgstr ""
-#: ../raster/r.flow/io.c:87
-msgid "Elevation raster map resolution differs from current region resolution"
+#: ../vector/v.out.ascii/args.c:85
+msgid "Include column names in output (points mode)"
 msgstr ""
-#: ../raster/r.flow/io.c:89 ../raster/r.flow/io.c:107
-#: ../raster/r.buffer/read_map.c:52
-#, c-format
-msgid "Reading input raster map <%s>..."
+#: ../vector/v.out.ascii/args.c:91
+msgid "Only export points falling within current 3D region (points mode)"
 msgstr ""
-#: ../raster/r.flow/io.c:104
-msgid "Resolution of aspect file differs from current region resolution"
+#: ../vector/v.type/main.c:44
+msgid "Changes type of vector features."
 msgstr ""
-#: ../raster/r.flow/io.c:121
-msgid "Reading input files: barrier"
+#: ../vector/v.type/main.c:57
+msgid "Feature type to convert from"
 msgstr ""
-#: ../raster/r.flow/io.c:149
-#, c-format
-msgid "Cannot create segment file %s"
+#: ../vector/v.type/main.c:65
+msgid "Feature type to convert to"
 msgstr ""
-#: ../raster/r.flow/io.c:154
-#, c-format
-msgid "Cannot format segment file %s"
+#: ../vector/v.type/main.c:120
+msgid "Incompatible types"
 msgstr ""
-#: ../raster/r.flow/io.c:160
-#, c-format
-msgid "Cannot open segment file %s"
+#: ../vector/v.net.flow/main.c:60 ../raster/r.sim/r.sim.water/main.c:116
+msgid "flow"
+msgstr "plūsma"
+#: ../vector/v.net.flow/main.c:62
+msgid "Computes the maximum flow between two sets of nodes in the network."
 msgstr ""
-#: ../raster/r.flow/io.c:207 ../raster/r.buffer/write_map.c:45
-#: ../raster/r.cost/main.c:1034
-#, c-format
-msgid "Writing output raster map <%s>..."
+#: ../vector/v.net.flow/main.c:84
+msgid "Name for output vector map containing a minimum cut"
 msgstr ""
-#: ../raster/r.flow/precomp.c:48
-msgid "Precomputing e/w distances..."
+#: ../vector/v.net.flow/main.c:107
+msgid "Source category values"
 msgstr ""
-#: ../raster/r.flow/precomp.c:50
-msgid "Precomputing quantization tolerances..."
+#: ../vector/v.net.flow/main.c:108 ../vector/v.net.flow/main.c:114
+#: ../vector/v.proj/main.c:79 ../vector/v.proj/main.c:84
+#: ../vector/v.proj/main.c:90 ../raster/r.proj/main.c:154
+#: ../raster/r.proj/main.c:159 ../raster/r.proj/main.c:164
+msgid "Source"
 msgstr ""
-#: ../raster/r.flow/precomp.c:53
-msgid "Precomputing inverted elevations..."
+#: ../vector/v.net.flow/main.c:113
+msgid "Source WHERE conditions of SQL statement without 'where' keyword"
 msgstr ""
-#: ../raster/r.flow/precomp.c:57
-msgid "Precomputing interpolated border elevations..."
+#: ../vector/v.net.flow/main.c:118
+msgid "Sink category values"
 msgstr ""
-#: ../raster/r.flow/precomp.c:63
-msgid "Precomputing re-oriented aspects..."
+#: ../vector/v.net.flow/main.c:119 ../vector/v.net.flow/main.c:125
+msgid "Sink"
 msgstr ""
-#: ../raster/r.flow/precomp.c:67
-msgid "Precomputing aspects..."
+#: ../vector/v.net.flow/main.c:124
+msgid "Sink WHERE conditions of SQL statement without 'where' keyword"
 msgstr ""
-#: ../raster/r.flow/precomp.c:111
+#: ../vector/v.net.flow/main.c:199
 #, c-format
-msgid ""
-"Resolution too unbalanced:\n"
-"atan2(%f deg, %f deg) =%f < %f tolerance\n"
-"please resample input map"
+msgid "No source features selected. Please check options '%s', '%s'."
 msgstr ""
-#: ../raster/r.flow/precomp.c:116
+#: ../vector/v.net.flow/main.c:206
 #, c-format
-msgid "Resolution too unbalanced (%f x %f); please resample input map"
+msgid "No sink features selected. Please check options '%s', '%s'."
 msgstr ""
-#: ../raster/r.buffer/execute.c:34
-msgid "Finding buffer zones..."
+#: ../vector/v.net.flow/main.c:215
+msgid "No sources"
 msgstr ""
-#: ../raster/r.buffer/parse_dist.c:54
-#, c-format
-msgid "%s: %s - illegal distance specification"
+#: ../vector/v.net.flow/main.c:218
+msgid "No sinks"
 msgstr ""
-#: ../raster/r.buffer/main.c:131
-msgid "Parse distances error"
+#: ../vector/v.net.flow/main.c:242
+msgid "Writing the output..."
 msgstr ""
-#: ../raster/r.buffer/main.c:150
-#, c-format
-msgid "Pass %d (of %d)"
+#: ../vector/v.overlay/line_area.c:256 ../vector/v.overlay/area_area.c:109
+msgid "Breaking lines..."
 msgstr ""
-#: ../raster/r.resamp.interp/main.c:77 ../raster/r.resamp.bspline/main.c:82
-#: ../raster/r.resamp.rst/main.c:149 ../raster/r.resamp.filter/main.c:390
-#: ../raster/r.resample/main.c:55 ../raster/r.resamp.stats/main.c:262
-msgid "resample"
+#: ../vector/v.overlay/line_area.c:273
+msgid "Selecting lines..."
 msgstr ""
-#: ../raster/r.resamp.interp/main.c:80
-msgid "Resamples raster map to a finer grid using interpolation."
+#: ../vector/v.overlay/line_area.c:345
+#, c-format
+msgid "Ambiguous line %d: not all vertices are really outside any area"
 msgstr ""
-#: ../raster/r.resamp.interp/main.c:88
-msgid "Method"
-msgstr "Metode"
+#: ../vector/v.overlay/line_area.c:387 ../vector/v.overlay/line_area.c:415
+#: ../vector/v.overlay/area_area.c:208 ../vector/v.overlay/area_area.c:290
+#: ../vector/v.overlay/area_area.c:318
+msgid "Attribute not found"
+msgstr ""
-#: ../raster/r.resamp.interp/main.c:102 ../imagery/i.topo.corr/main.c:158
-#, c-format
-msgid "Invalid method: %s"
+#: ../vector/v.overlay/main.c:66
+#: ../locale/scriptstrings/v.clip_to_translate.c:3
+msgid "clip"
 msgstr ""
-#: ../raster/r.clump/clump.c:51 ../vector/v.cluster/main.c:404
-#: ../vector/v.cluster/main.c:613 ../vector/v.cluster/main.c:970
-#: ../imagery/i.segment/cluster.c:386
-msgid "Generating renumbering scheme..."
+#: ../vector/v.overlay/main.c:67
+msgid "difference"
 msgstr ""
-#: ../raster/r.clump/clump.c:81
-msgid "Pass 2 of 2..."
+#: ../vector/v.overlay/main.c:68
+msgid "intersection"
 msgstr ""
-#: ../raster/r.clump/clump.c:97 ../raster/r.clump/clump.c:149
-#: ../raster/r.clump/minsize.c:152 ../raster/r.clump/minsize.c:253
-#: ../raster/r.clump/minsize.c:287 ../raster/r.clump/minsize.c:293
-#: ../raster/r.clump/minsize.c:424 ../raster/r.clump/minsize.c:447
-#: ../raster/r.clump/minsize.c:518 ../imagery/i.segment/cluster.c:431
-msgid "Unable to read from temp file"
+#: ../vector/v.overlay/main.c:69
+msgid "union"
 msgstr ""
-#: ../raster/r.clump/clump.c:113 ../raster/r.clump/clump.c:345
-#: ../raster/r.clump/clump.c:359 ../raster/r.clump/clump.c:646
-#: ../raster/r.clump/clump.c:660 ../raster/r.clump/minsize.c:163
-#: ../raster/r.clump/minsize.c:390 ../imagery/i.segment/cluster.c:363
-#: ../imagery/i.segment/cluster.c:377
-msgid "Unable to write to temp file"
+#: ../vector/v.overlay/main.c:70
+msgid ""
+"Overlays two vector maps offering clip, intersection, difference, "
+"symmetrical difference, union operators."
 msgstr ""
-#: ../raster/r.clump/clump.c:122
-#, fuzzy, c-format
-msgid "%d initial clumps"
-msgstr "Tabulu kopēšana"
+#: ../vector/v.overlay/main.c:73
+msgid "Name of input vector map (A)"
+msgstr ""
-#: ../raster/r.clump/clump.c:211 ../raster/r.clump/clump.c:475
-#: ../raster/r.clump/minsize.c:373 ../imagery/i.segment/cluster.c:121
-msgid "Unable to open temp file"
+#: ../vector/v.overlay/main.c:77
+msgid "Layer number or name (vector map A)"
 msgstr ""
-#: ../raster/r.clump/clump.c:233 ../raster/r.clump/clump.c:490
-msgid "Pass 1 of 2..."
+#: ../vector/v.overlay/main.c:87
+msgid "Name of input vector map (B)"
 msgstr ""
-#: ../raster/r.clump/clump.c:425
-#, fuzzy, c-format
-msgid "%d-band clumping with threshold %g"
-msgstr "%d punkti ielādēti\n"
+#: ../vector/v.overlay/main.c:91
+msgid "Layer number or name (vector map B)"
+msgstr ""
-#: ../raster/r.clump/clump.c:449 ../imagery/i.segment/open_files.c:71
-#: ../imagery/i.segment/open_files.c:238 ../imagery/i.segment/open_files.c:246
-#: ../imagery/i.segment/write_output.c:112
-#, c-format
-msgid "No min/max found in raster map <%s>"
+#: ../vector/v.overlay/main.c:106
+msgid "Operator defines features written to output vector map"
 msgstr ""
-#: ../raster/r.clump/main.c:60
-msgid "reclass"
+#: ../vector/v.overlay/main.c:109
+msgid ""
+"Feature is written to output if the result of operation 'ainput operator "
+"binput' is true. Input feature is considered to be true, if category of "
+"given layer is defined."
 msgstr ""
-#: ../raster/r.clump/main.c:61 ../raster/r.volume/main.c:78
-msgid "clumps"
+#: ../vector/v.overlay/main.c:116
+msgid "also known as 'intersection' in GIS"
 msgstr ""
-#: ../raster/r.clump/main.c:63
-msgid "Recategorizes data in a raster map by grouping cells that form physically discrete areas into unique categories."
+#: ../vector/v.overlay/main.c:117
+msgid "also known as 'union' in GIS (only for atype=area)"
 msgstr ""
-#: ../raster/r.clump/main.c:82
-msgid "Threshold to identify similar cells"
+#: ../vector/v.overlay/main.c:118
+msgid ""
+"also known as 'difference' (features from ainput not overlayed by features "
+"from binput)"
 msgstr ""
-#: ../raster/r.clump/main.c:83
-msgid "Valid range: 0 = identical to < 1 = maximal difference"
+#: ../vector/v.overlay/main.c:120
+msgid ""
+"also known as 'symmetrical difference' (features from either ainput or "
+"binput but not those from ainput overlayed by binput (only for atype=area)"
 msgstr ""
-#: ../raster/r.clump/main.c:90
-#, fuzzy
-msgid "Minimum clump size in cells"
-msgstr "Līniju skaits"
+#: ../vector/v.overlay/main.c:131
+msgid "Output layer for new category, ainput and binput"
+msgstr ""
-#: ../raster/r.clump/main.c:91
-msgid "Clumps smaller than minsize will be merged to form larger clumps"
+#: ../vector/v.overlay/main.c:132
+msgid "If 0 or not given, the category is not written"
 msgstr ""
-#: ../raster/r.clump/main.c:95
-msgid "Clump also diagonal cells"
+#: ../vector/v.overlay/main.c:139
+msgid "Snapping threshold for boundaries"
 msgstr ""
-#: ../raster/r.clump/main.c:96
-msgid "Clumps are also traced along diagonal neighboring cells"
+#: ../vector/v.overlay/main.c:140
+msgid "Disable snapping with snap <= 0"
 msgstr ""
-#: ../raster/r.clump/main.c:100
-msgid "Print only the number of clumps in shell script style"
+#: ../vector/v.overlay/main.c:195
+#, c-format
+msgid "Unable to determine feature type for <%s>"
 msgstr ""
-#: ../raster/r.clump/main.c:122
+#: ../vector/v.overlay/main.c:201
 #, c-format
-msgid "Valid range for option <%s> is 0 <= value < 1"
+msgid "Invalid feature type (%d) for <%s>. Only '%s' or '%s' supported."
 msgstr ""
-#: ../raster/r.clump/main.c:180
+#: ../vector/v.overlay/main.c:209
 #, c-format
-msgid "%d clump."
-msgid_plural "%d clumps."
-msgstr[0] ""
-msgstr[1] ""
-msgstr[2] ""
+msgid "Operator '%s' is not supported for type line"
+msgstr ""
-#: ../raster/r.clump/minsize.c:357
-#, fuzzy
-msgid "Minimum size must be larger than 1"
-msgstr "2 līmeņiem jābūt norādītiem"
+#: ../vector/v.overlay/main.c:264
+#, c-format
+msgid "Copying vector features from <%s>..."
+msgstr ""
-#: ../raster/r.clump/minsize.c:368
-#, fuzzy
-msgid "Loading input ..."
-msgstr "Lasa %s ..."
-#: ../raster/r.clump/minsize.c:418
+#: ../vector/v.overlay/main.c:345
 #, c-format
-msgid "Merging clumps smaller than %d cells..."
+msgid "No %s features found in vector map <%s>. Verify '%s' parameter."
 msgstr ""
-#: ../raster/r.clump/minsize.c:509
-#, fuzzy, c-format
-msgid "Renumbering remaining %d clumps..."
-msgstr "Neveiksme atverot ieejas dig_att failu"
-#: ../raster/r.clump/rclist.c:17 ../imagery/i.segment/rclist.c:17
-msgid "rclist out of memory"
+#: ../vector/v.overlay/main.c:394
+msgid "Collecting input attributes..."
 msgstr ""
-#: ../raster/r.to.vect/points.c:36
-msgid "Extracting points..."
+#: ../vector/v.overlay/main.c:474
+#, c-format
+msgid "Unknown column type '%s' of column '%s'"
 msgstr ""
-#: ../raster/r.to.vect/areas_io.c:154
+#: ../vector/v.overlay/main.c:539
 #, c-format
-msgid ""
-"write_bnd:  line terminated unexpectedly\n"
-"previous (%d) point %p (%d,%d,%d) %p %p"
+msgid "Unknown column type '%s' of column '%s', values lost"
 msgstr ""
-#: ../raster/r.to.vect/areas_io.c:287
-msgid "Writing areas..."
+#: ../vector/v.overlay/area_area.c:51
+#, c-format
+msgid "Snapping boundaries with %g ..."
 msgstr ""
-#: ../raster/r.to.vect/areas_io.c:359 ../raster/r.to.vect/util.c:157
-#: ../raster/r.volume/main.c:296 ../vector/v.random/main.c:469
-#: ../vector/v.random/main.c:589 ../vector/v.in.ogr/main.c:1292
-#: ../vector/v.vol.rst/vector.c:80 ../vector/v.in.lidar/attributes.c:240
+#: ../vector/v.overlay/area_area.c:99
 #, c-format
-msgid "Cannot insert new row: %s"
-msgstr "Nevar izveidot jaunu rindu: %s"
+msgid "%d boundary snapped"
+msgid_plural "%d boundaries snapped"
+msgstr[0] ""
+msgstr[1] ""
+msgstr[2] ""
-#: ../raster/r.to.vect/areas.c:122
-msgid "Extracting areas..."
+#: ../vector/v.overlay/area_area.c:154
+msgid "Merging lines..."
 msgstr ""
-#: ../raster/r.to.vect/main.c:79
-msgid "vectorization"
+#: ../vector/v.overlay/area_area.c:181
+#, c-format
+msgid "Querying vector map <%s>..."
 msgstr ""
-#: ../raster/r.to.vect/main.c:80
-msgid "Converts a raster map into a vector map."
+#: ../vector/v.db.select/main.c:57 ../db/db.select/main.c:267
+#: ../db/db.createdb/main.c:73 ../db/db.copy/main.c:37
+#: ../db/db.dropdb/main.c:73 ../db/db.databases/main.c:97
+#: ../db/db.execute/main.c:127 ../db/db.execute/main.c:134
+#: ../db/db.execute/main.c:140
+msgid "SQL"
 msgstr ""
-#: ../raster/r.to.vect/main.c:106 ../raster/r.to.vect/main.c:113
-#: ../vector/v.extract/main.c:93 ../vector/v.extract/main.c:145
-#: ../vector/v.overlay/main.c:135 ../vector/v.overlay/main.c:145
-#: ../vector/v.in.ogr/main.c:226 ../vector/v.in.ogr/main.c:236
-#: ../vector/v.in.ogr/main.c:246 ../vector/v.in.ogr/main.c:279
-#: ../vector/v.in.ogr/main.c:311 ../vector/v.generalize/main.c:243
-#: ../vector/v.to.rast/main.c:88 ../vector/v.to.rast/main.c:94
-#: ../vector/v.to.rast/main.c:100 ../vector/v.buffer/main.c:307
-msgid "Attributes"
+#: ../vector/v.db.select/main.c:58
+msgid "Prints vector map attributes."
 msgstr ""
-#: ../raster/r.to.vect/main.c:118
-msgid "Recommended for massive point conversion"
+#: ../vector/v.db.select/main.c:61 ../vector/v.db.select/main.c:79
+#: ../vector/v.db.select/main.c:93
+msgid "Main"
 msgstr ""
-#: ../raster/r.to.vect/main.c:131
-msgid "z flag is supported only for points"
+#: ../vector/v.db.select/main.c:75
+msgid "GROUP BY conditions of SQL statement without 'group by' keyword"
 msgstr ""
-#: ../raster/r.to.vect/main.c:142
-msgid "Raster is not CELL, '-v' flag ignored, raster values will be written to the table."
+#: ../vector/v.db.select/main.c:83
+msgid "Output vertical record separator"
 msgstr ""
-#: ../raster/r.to.vect/main.c:144
-msgid "Raster is not CELL, '-v' flag ignored, raster values will be z coordinate."
+#: ../vector/v.db.select/main.c:95 ../raster/r.stats.quantile/main.c:555
+#: ../raster/r.univar/r.univar_main.c:41 ../raster/r.univar/r3.univar_main.c:42
+#: ../raster/r.what/main.c:127 ../raster/r.quantile/main.c:299
+#: ../raster/r.stats/main.c:119 ../locale/scriptstrings/i.oif_to_translate.c:5
+#: ../locale/scriptstrings/r.out.xyz_to_translate.c:6
+#: ../db/db.select/main.c:241
+msgid "Name for output file (if omitted or \"-\" output to stdout)"
 msgstr ""
-#: ../raster/r.to.vect/main.c:146
-msgid "Raster is not CELL, '-v' flag ignored, raster values will be lost."
+#: ../vector/v.db.select/main.c:100
+msgid ""
+"Print minimal region extent of selected vector features instead of attributes"
 msgstr ""
-#: ../raster/r.to.vect/main.c:151
-msgid "Categories will be unique sequence, raster values will be lost."
+#: ../vector/v.db.select/main.c:101 ../raster/r.in.gdal/main.c:203
+#: ../raster/r.in.gdal/main.c:236
+#: ../locale/scriptstrings/v.clip_to_translate.c:9
+msgid "Region"
+msgstr "Reģions"
+#: ../vector/v.db.select/main.c:105 ../db/db.select/main.c:245
+msgid "Do not include column names in output"
 msgstr ""
-#: ../raster/r.to.vect/main.c:233 ../raster/r.random/random.c:253
-#: ../vector/v.extract/copy_tab.c:124 ../vector/v.random/main.c:258
-#: ../vector/v.mkgrid/main.c:346 ../vector/v.mkgrid/main.c:404
-#: ../vector/v.overlay/main.c:592 ../vector/v.select/copy_tabs.c:87
-#: ../vector/v.patch/main.c:326 ../db/drivers/postgres/index.c:59
-msgid "Unable to create index"
+#: ../vector/v.db.select/main.c:110 ../db/db.select/main.c:255
+msgid "Vertical output (instead of horizontal)"
 msgstr ""
-#: ../raster/r.to.vect/main.c:289 ../raster/r.drain/main.c:283
-#: ../raster/r.walk/main.c:688 ../raster/r.walk/main.c:754
-#: ../raster/r.cost/main.c:548 ../raster/r.cost/main.c:618
-#: ../display/d.vect/zcoor.c:38 ../display/d.vect/topo.c:52
-#: ../display/d.vect/dir.c:30 ../display/d.vect/lines.c:143
-#: ../display/d.vect/vert.c:27 ../display/d.vect/label.c:44
-#: ../display/d.vect/attr.c:51 ../display/d.vect.thematic/display.c:75
-#: ../vector/v.label.sa/labels.c:141 ../vector/v.to.3d/trans3.c:85
-#: ../vector/v.to.3d/trans2.c:84 ../vector/v.out.lidar/main.c:732
-#: ../vector/v.decimate/main.c:404 ../vector/v.vol.rst/user1.c:140
-#: ../vector/v.kriging/getval.c:244 ../vector/v.perturb/main.c:181
-#: ../vector/v.info/level1.c:38 ../vector/v.what.rast/main.c:213
-#: ../vector/v.label/main.c:293 ../vector/v.colors/scan_z.c:36
-#: ../vector/v.colors/scan_cats.c:24 ../vector/v.colors.out/scan_cats.c:32
-msgid "Unable to read vector map"
+#: ../vector/v.db.select/main.c:115
+msgid "Exclude attributes not linked to features"
 msgstr ""
-#: ../raster/r.to.vect/main.c:312
-msgid "Updating attributes..."
+#: ../vector/v.db.select/main.c:126 ../raster/r.stats.quantile/main.c:319
+#: ../raster/r.univar/r.univar_main.c:129
+#: ../raster/r.univar/r3.univar_main.c:128 ../raster/r.what/main.c:177
+#: ../raster/r.quantile/main.c:313 ../raster/r.regression.line/main.c:77
+#: ../raster/r.stats/main.c:227 ../raster/r.regression.multi/main.c:170
+#: ../db/db.select/main.c:142
+#, c-format
+msgid "Unable to open file <%s> for writing"
 msgstr ""
-#: ../raster/r.to.vect/main.c:335
+#: ../vector/v.db.select/main.c:157
 #, c-format
-msgid "Unable to insert into table: %s"
+msgid ""
+"Unable to open vector map <%s> at topology level. Flag '%c' requires "
+"topology level."
 msgstr ""
-#: ../raster/r.to.vect/lines.c:71
-msgid "Extracting lines..."
+#: ../vector/v.db.select/main.c:208
+msgid "Unable to open select cursor"
 msgstr ""
-#: ../raster/r.to.vect/lines.c:504
+#: ../vector/v.db.select/main.c:286
 #, c-format
-msgid "Crowded cell at (%f, %f): row %d, col %d, count %d"
+msgid "Unable to get bounding box of area %d"
 msgstr ""
-#: ../raster/r.to.vect/lines.c:508
-msgid ""
-"Raster map is not thinned properly.\n"
-"Please run r.thin."
+#: ../vector/v.db.select/main.c:292
+#, c-format
+msgid "Unable to get bounding box of line %d"
 msgstr ""
-#: ../raster/r.to.vect/lines.c:582
-msgid "join_lines: p front pointer not NULL!"
+#: ../vector/v.surf.bspline/main.c:96
+msgid ""
+"Performs bicubic or bilinear spline interpolation with Tykhonov "
+"regularization."
 msgstr ""
-#: ../raster/r.to.vect/lines.c:588
-msgid "join_lines: q front pointer not NULL!"
+#: ../vector/v.surf.bspline/main.c:101 ../raster/r.resamp.bspline/main.c:143
+msgid ""
+"Find the best Tykhonov regularizing parameter using a \"leave-one-out\" "
+"cross validation method"
 msgstr ""
-#: ../raster/r.to.vect/lines.c:606
-msgid "extend line:  p is NULL"
+#: ../vector/v.surf.bspline/main.c:119
+msgid "If not given and input is 3D vector map then z-coordinates are used."
 msgstr ""
-#: ../raster/r.to.vect/lines.c:632
-msgid "extend_lines: p front pointer not NULL!"
+#: ../vector/v.surf.bspline/main.c:126
+msgid "Name of input vector map with sparse points"
 msgstr ""
-#: ../raster/r.to.vect/lines.c:639
-msgid "extend_lines: q back pointer not NULL!"
+#: ../vector/v.surf.bspline/main.c:139
+msgid "Raster map to use for masking (applies to raster output only)"
 msgstr ""
-#: ../raster/r.to.vect/lines_io.c:76
-msgid "write_line:  found half a loop!"
+#: ../vector/v.surf.bspline/main.c:140 ../raster/r.resamp.bspline/main.c:98
+msgid "Only cells that are not NULL and not zero are interpolated"
 msgstr ""
-#: ../raster/r.to.vect/lines_io.c:177
-#, c-format
-msgid ""
-"write_line: line terminated unexpectedly\n"
-"  previous (%d) point %p (%d,%d,%d) %p %p"
+#: ../vector/v.surf.bspline/main.c:149
+#: ../vector/v.lidar.edgedetection/main.c:98
+#, fuzzy
+msgid "Default: 4 * east-west resolution"
+msgstr "Vēlamā austrumi-rietumi izšķirtspēja"
+#: ../vector/v.surf.bspline/main.c:158
+#: ../vector/v.lidar.edgedetection/main.c:107
+#, fuzzy
+msgid "Default: 4 * north-south resolution"
+msgstr "Vēlamā ziemeļi-dienvidi izšķirtspēja"
+#: ../vector/v.surf.bspline/main.c:163 ../raster/r.resamp.bspline/main.c:118
+msgid "Spline interpolation algorithm"
 msgstr ""
-#: ../raster/r.resamp.bspline/main.c:85
-msgid "Performs bilinear or bicubic spline interpolation with Tykhonov regularization."
+#: ../vector/v.surf.bspline/main.c:171 ../raster/r.resamp.bspline/main.c:125
+msgid "Bicubic interpolation"
 msgstr ""
-#: ../raster/r.resamp.bspline/main.c:93
-msgid "Name for output vector map with interpolation grid"
+#: ../vector/v.surf.bspline/main.c:177 ../raster/r.resamp.bspline/main.c:131
+#: ../locale/scriptstrings/r.fillnulls_to_translate.c:16
+msgid "Tykhonov regularization parameter (affects smoothing)"
 msgstr ""
-#: ../raster/r.resamp.bspline/main.c:98
-msgid "Name of raster map to use for masking"
+#: ../vector/v.surf.bspline/main.c:194 ../vector/v.to.rast/main.c:116
+#: ../raster/r.stream.extract/main.c:140 ../raster/r.resamp.bspline/main.c:150
+#: ../raster/r.proj/main.c:191 ../raster/r.in.gdal/main.c:122
+#: ../locale/scriptstrings/r.import_to_translate.c:9
+#: ../locale/scriptstrings/t.rast.import_to_translate.c:14
+msgid "Maximum memory to be used (in MB)"
 msgstr ""
-#: ../raster/r.resamp.bspline/main.c:99 ../vector/v.surf.bspline/main.c:140
-msgid "Only cells that are not NULL and not zero are interpolated"
+#: ../vector/v.surf.bspline/main.c:195 ../vector/v.to.rast/main.c:117
+#: ../raster/r.stream.extract/main.c:141 ../raster/r.resamp.bspline/main.c:151
+#: ../raster/r.proj/main.c:192 ../raster/r.in.gdal/main.c:123
+#: ../locale/scriptstrings/r.import_to_translate.c:10
+#: ../locale/scriptstrings/t.rast.import_to_translate.c:13
+msgid "Cache size for raster rows"
 msgstr ""
-#: ../raster/r.resamp.bspline/main.c:107
-msgid "Length of each spline step in the east-west direction. Default: 1.5 * ewres."
+#: ../vector/v.surf.bspline/main.c:207
+msgid "Choose either vector or raster output, not both"
 msgstr ""
-#: ../raster/r.resamp.bspline/main.c:115
-msgid "Length of each spline step in the north-south direction. Default: 1.5 * nsres."
+#: ../vector/v.surf.bspline/main.c:210
+msgid "No raster or vector or cross-validation output"
 msgstr ""
-#: ../raster/r.resamp.bspline/main.c:119 ../vector/v.surf.bspline/main.c:163
-msgid "Spline interpolation algorithm"
+#: ../vector/v.surf.bspline/main.c:231
+msgid "Unable to set default DB connection"
 msgstr ""
-#: ../raster/r.resamp.bspline/main.c:125
-#: ../vector/v.lidar.correction/main.c:403 ../vector/v.surf.bspline/main.c:170
-#: ../vector/v.outlier/main.c:416
-msgid "Bilinear interpolation"
+#: ../vector/v.surf.bspline/main.c:236
+msgid "No default DB defined"
 msgstr ""
-#: ../raster/r.resamp.bspline/main.c:126 ../vector/v.surf.bspline/main.c:171
-msgid "Bicubic interpolation"
+#: ../vector/v.surf.bspline/main.c:283
+#, c-format
+msgid "Input vector map is 2D. Parameter <%s> required."
 msgstr ""
-#: ../raster/r.resamp.bspline/main.c:138
-msgid "Only interpolate null cells in input raster map"
+#: ../vector/v.surf.bspline/main.c:295
+#, c-format
+msgid "Estimated point density: %.4g"
 msgstr ""
-#: ../raster/r.resamp.bspline/main.c:144 ../vector/v.surf.bspline/main.c:101
-msgid "Find the best Tykhonov regularizing parameter using a \"leave-one-out\" cross validation method"
+#: ../vector/v.surf.bspline/main.c:296
+#, c-format
+msgid "Estimated mean distance between points: %.4g"
 msgstr ""
-#: ../raster/r.resamp.bspline/main.c:187
-msgid "ew_step must be positive"
+#: ../vector/v.surf.bspline/main.c:299
+#, c-format
+msgid "No points in current region"
 msgstr ""
-#: ../raster/r.resamp.bspline/main.c:195
-msgid "ns_step must be positive"
+#: ../vector/v.surf.bspline/main.c:313 ../raster/r.resamp.bspline/main.c:370
+msgid "Cross validation didn't finish correctly"
 msgstr ""
-#: ../raster/r.resamp.bspline/main.c:222
+#: ../vector/v.surf.bspline/main.c:319 ../raster/r.resamp.bspline/main.c:374
 #, c-format
-msgid "spline step in ew direction %g"
+msgid "Cross validation finished for ew_step = %f and ns_step = %f"
 msgstr ""
-#: ../raster/r.resamp.bspline/main.c:223
+#: ../vector/v.surf.bspline/main.c:328
 #, c-format
-msgid "spline step in ns direction %g"
+msgid "Vector map <%s> of sparse points will be interpolated"
 msgstr ""
-#: ../raster/r.resamp.bspline/main.c:224
+#: ../vector/v.surf.bspline/main.c:344
 #, c-format
-msgid "adjusted EW splines %d"
+msgid ""
+"Sorry, the <%s> driver is not compatible with the vector output of this "
+"module. Try with raster output or another driver."
 msgstr ""
-#: ../raster/r.resamp.bspline/main.c:225
+#: ../vector/v.surf.bspline/main.c:367
 #, c-format
-msgid "adjusted NS splines %d"
+msgid "Points in input vector map <%s> will be interpolated"
 msgstr ""
-#: ../raster/r.resamp.bspline/main.c:292 ../vector/v.surf.bspline/main.c:456
-msgid "Memory in MB must be >= 3"
+#: ../vector/v.surf.bspline/main.c:374
+msgid "Reading values from attribute table..."
 msgstr ""
-#: ../raster/r.resamp.bspline/main.c:308 ../raster/r.resamp.bspline/main.c:394
-#: ../raster/r.resamp.bspline/main.c:465 ../raster/r.walk/main.c:549
-#: ../raster/r.walk/main.c:554 ../raster/r.cost/main.c:435
-#: ../raster/r.cost/main.c:440 ../vector/v.surf.bspline/main.c:470
-#: ../vector/v.surf.bspline/main.c:498
-msgid "Can not create temporary file"
+#: ../vector/v.surf.bspline/main.c:378
+msgid "Cannot read layer info"
 msgstr ""
-#: ../raster/r.resamp.bspline/main.c:313 ../raster/r.resamp.bspline/main.c:399
-#: ../raster/r.resamp.bspline/main.c:470 ../vector/v.surf.bspline/main.c:475
-#: ../vector/v.surf.bspline/main.c:503
-msgid "Can not initialize temporary file"
+#: ../vector/v.surf.bspline/main.c:420
+#, c-format
+msgid "Interpolation: Creating table: It was impossible to create table <%s>."
 msgstr ""
-#: ../raster/r.resamp.bspline/main.c:319
+#: ../vector/v.surf.bspline/main.c:437
 #, c-format
-msgid "Loading input raster <%s>"
+msgid "Cells for raster map <%s> will be interpolated"
 msgstr ""
-#: ../raster/r.resamp.bspline/main.c:339
-msgid "Only NULL cells in input raster"
+#: ../vector/v.surf.bspline/main.c:461 ../raster/r.resamp.bspline/main.c:300
+msgid "Memory in MB must be >= 3"
 msgstr ""
-#: ../raster/r.resamp.bspline/main.c:363 ../vector/v.surf.bspline/main.c:307
-msgid "Cross validation didn't finish correctly"
+#: ../vector/v.surf.bspline/main.c:475 ../vector/v.surf.bspline/main.c:503
+#: ../raster/r.walk/main.c:549 ../raster/r.walk/main.c:554
+#: ../raster/r.resamp.bspline/main.c:316 ../raster/r.resamp.bspline/main.c:401
+#: ../raster/r.resamp.bspline/main.c:473 ../raster/r.cost/main.c:435
+#: ../raster/r.cost/main.c:440
+msgid "Can not create temporary file"
 msgstr ""
-#: ../raster/r.resamp.bspline/main.c:367 ../vector/v.surf.bspline/main.c:313
-#, c-format
-msgid "Cross validation finished for ew_step = %f and ns_step = %f"
+#: ../vector/v.surf.bspline/main.c:480 ../vector/v.surf.bspline/main.c:508
+#: ../raster/r.resamp.bspline/main.c:321 ../raster/r.resamp.bspline/main.c:406
+#: ../raster/r.resamp.bspline/main.c:478
+msgid "Can not initialize temporary file"
 msgstr ""
-#: ../raster/r.resamp.bspline/main.c:387
-msgid "Mark cells for interpolation"
+#: ../vector/v.surf.bspline/main.c:483 ../raster/r.resamp.bspline/main.c:481
+msgid "Initializing output..."
 msgstr ""
-#: ../raster/r.resamp.bspline/main.c:458
-msgid "No NULL cells found in input raster."
+#: ../vector/v.surf.bspline/main.c:498
+msgid "Load masking map"
 msgstr ""
-#: ../raster/r.resamp.bspline/main.c:473 ../vector/v.surf.bspline/main.c:478
-msgid "Initializing output..."
+#: ../vector/v.surf.bspline/main.c:710
+#, c-format
+msgid "%d points found in this subregion"
 msgstr ""
-#: ../raster/r.resamp.bspline/main.c:546 ../vector/v.lidar.growing/main.c:246
+#: ../vector/v.surf.bspline/main.c:757
 #, c-format
-msgid "subregion %d of %d"
+msgid "Interpolation: (%d,%d): No record for point (cat = %d)"
 msgstr ""
-#: ../raster/r.resamp.bspline/main.c:720
-msgid "No data within this subregion. Consider increasing the spline step."
+#: ../vector/v.surf.bspline/crosscorr.c:75
+#, c-format
+msgid "%d are too many points. The cross validation would take too much time."
 msgstr ""
-#: ../raster/r.resamp.bspline/main.c:736 ../vector/v.net.components/main.c:213
-#: ../vector/v.surf.bspline/main.c:895
-msgid "Writing output..."
+#: ../vector/v.surf.bspline/crosscorr.c:84
+#, c-format
+msgid "%d points read in region"
 msgstr ""
-#: ../raster/r.resamp.bspline/crosscorr.c:160
+#: ../vector/v.surf.bspline/crosscorr.c:88
+msgid ""
+"Maybe it takes too long. It will depend on how many points you are "
+"considering."
+msgstr ""
+#: ../vector/v.surf.bspline/crosscorr.c:119
 #, c-format
-msgid "%d are too many cells, recommended are < 100 cells. The cross validation would take too much time."
+msgid "CrossCorrelation: driver=%s db=%s"
 msgstr ""
-#: ../raster/r.resamp.bspline/crosscorr.c:169
+#: ../vector/v.surf.bspline/crosscorr.c:136
 #, c-format
-msgid "%d point read in region"
-msgid_plural "%d points read in region"
-msgstr[0] ""
-msgstr[1] ""
-msgstr[2] ""
-#: ../raster/r.resamp.bspline/crosscorr.c:174
-msgid "Maybe it takes too long. Consider reducing the region extents."
+msgid "No records selected from table <%s> "
 msgstr ""
+#: ../vector/v.surf.bspline/crosscorr.c:151
 #: ../raster/r.resamp.bspline/crosscorr.c:197
-#: ../vector/v.surf.bspline/crosscorr.c:151
 #, c-format
-msgid "Too many splines (%d x %d). Consider changing spline steps \"ew_step=\" \"ns_step=\"."
+msgid ""
+"Too many splines (%d x %d). Consider changing spline steps \"ew_step=\" "
+"\"ns_step=\"."
 msgstr ""
+#: ../vector/v.surf.bspline/crosscorr.c:169
 #: ../raster/r.resamp.bspline/crosscorr.c:215
-#: ../vector/v.surf.bspline/crosscorr.c:169
 #, c-format
 msgid "Beginning cross validation with lambda_i=%.4f ... (%d of %d)"
 msgstr ""
+#: ../vector/v.surf.bspline/crosscorr.c:295
 #: ../raster/r.resamp.bspline/crosscorr.c:306
-#: ../vector/v.surf.bspline/crosscorr.c:295
 #, c-format
 msgid "Mean = %.5lf"
 msgstr ""
+#: ../vector/v.surf.bspline/crosscorr.c:296
 #: ../raster/r.resamp.bspline/crosscorr.c:307
-#: ../vector/v.surf.bspline/crosscorr.c:296
 #, c-format
 msgid "Root Mean Square (RMS) = %.5lf"
 msgstr ""
+#: ../vector/v.surf.bspline/crosscorr.c:313
 #: ../raster/r.resamp.bspline/crosscorr.c:324
-#: ../vector/v.surf.bspline/crosscorr.c:313
-msgid "Different number of splines and lambda_i values have been taken for the cross correlation"
+msgid ""
+"Different number of splines and lambda_i values have been taken for the "
+"cross correlation"
 msgstr ""
+#: ../vector/v.surf.bspline/crosscorr.c:315
 #: ../raster/r.resamp.bspline/crosscorr.c:326
-#: ../vector/v.surf.bspline/crosscorr.c:315
 #, c-format
-msgid "The minimum value for the test (rms=%lf) was obtained with: lambda_i = %.3f"
+msgid ""
+"The minimum value for the test (rms=%lf) was obtained with: lambda_i = %.3f"
 msgstr ""
+#: ../vector/v.surf.bspline/crosscorr.c:323
 #: ../raster/r.resamp.bspline/crosscorr.c:334
-#: ../vector/v.surf.bspline/crosscorr.c:323
 msgid "Table of results:"
 msgstr ""
+#: ../vector/v.surf.bspline/crosscorr.c:324
 #: ../raster/r.resamp.bspline/crosscorr.c:335
-#: ../vector/v.surf.bspline/crosscorr.c:324
 #, c-format
 msgid "    lambda |       mean |        rms |\n"
 msgstr ""
+#: ../vector/v.surf.bspline/crosscorr.c:334
 #: ../raster/r.resamp.bspline/crosscorr.c:345
-#: ../vector/v.surf.bspline/crosscorr.c:334
 msgid "No point lies into the current region"
 msgstr ""
-#: ../raster/r.relief/main.c:110 ../raster/r.slope.aspect/main.c:152
-#: ../raster/r.param.scale/interface.c:56 ../imagery/i.topo.corr/main.c:48
-msgid "terrain"
+#: ../vector/v.lidar.edgedetection/main.c:77 ../imagery/i.zc/main.c:54
+msgid "edges"
 msgstr ""
-#: ../raster/r.relief/main.c:112
-msgid "Creates shaded relief map from an elevation map (DEM)."
+#: ../vector/v.lidar.edgedetection/main.c:79
+msgid "Detects the object's edges from a LIDAR data set."
+msgstr "Detektē objektu robežas no LiDAR datu kopas."
+#: ../vector/v.lidar.edgedetection/main.c:115
+msgid "Regularization weight in gradient evaluation"
 msgstr ""
-#: ../raster/r.relief/main.c:117
-msgid "Name for output shaded relief map"
+#: ../vector/v.lidar.edgedetection/main.c:124
+msgid "High gradient threshold for edge classification"
 msgstr ""
-#: ../raster/r.relief/main.c:125
-msgid "Altitude of the sun in degrees above the horizon"
+#: ../vector/v.lidar.edgedetection/main.c:133
+msgid "Low gradient threshold for edge classification"
 msgstr ""
-#: ../raster/r.relief/main.c:126 ../raster/r.relief/main.c:136
-msgid "Sun position"
+#: ../vector/v.lidar.edgedetection/main.c:141
+msgid "Angle range for same direction detection"
 msgstr ""
-#: ../raster/r.relief/main.c:135
-msgid "Azimuth of the sun in degrees to the east of north"
+#: ../vector/v.lidar.edgedetection/main.c:150
+msgid "Regularization weight in residual evaluation"
 msgstr ""
-#: ../raster/r.relief/main.c:143
-msgid "Factor for exaggerating relief"
+#: ../vector/v.lidar.edgedetection/main.c:267
+#, c-format
+msgid "It was impossible to create <%s>."
 msgstr ""
-#: ../raster/r.relief/main.c:151
-msgid "Scale factor for converting meters to elevation units"
+#: ../vector/v.lidar.edgedetection/main.c:270
+#, c-format
+msgid "It was impossible to create <%s> interpolation table in database."
 msgstr ""
-#: ../raster/r.relief/main.c:158
-msgid "Elevation units (overrides scale factor)"
+#: ../vector/v.lidar.edgedetection/main.c:423
+msgid "Performing bilinear interpolation..."
 msgstr ""
-#: ../raster/r.relief/main.c:163
-msgid "international feet"
+#: ../vector/v.lidar.edgedetection/main.c:440
+msgid "Performing bicubic interpolation..."
 msgstr ""
-#: ../raster/r.relief/main.c:164
-msgid "survey feet"
+#: ../vector/v.lidar.edgedetection/main.c:452
+msgid "Point classification..."
 msgstr ""
-#: ../raster/r.relief/main.c:194 ../raster/r.in.gdal/main.c:358
-#: ../raster/r.in.gdal/main.c:712 ../vector/v.kernel/main.c:236
-#: ../imagery/i.landsat.toar/main.c:549
-#, c-format
-msgid "Raster map <%s> already exists and will be overwritten"
+#: ../vector/v.lidar.edgedetection/edgedetection.c:228
+#: ../vector/v.lidar.edgedetection/edgedetection.c:274
+#: ../vector/v.lidar.edgedetection/edgedetection.c:304
+#: ../vector/v.lidar.edgedetection/edgedetection.c:322
+#: ../vector/v.lidar.edgedetection/edgedetection.c:352
+msgid "Impossible to read from aux table"
 msgstr ""
-#: ../raster/r.relief/main.c:197 ../raster/r.in.gdal/main.c:361
-#: ../raster/r.in.gdal/main.c:715 ../vector/v.kernel/main.c:239
-#, c-format
-msgid "Raster map <%s> already exists"
+#: ../vector/v.lidar.edgedetection/edgedetection.c:233
+#: ../vector/v.lidar.edgedetection/edgedetection.c:309
+msgid "Impossible to update aux table"
 msgstr ""
-#: ../raster/r.relief/main.c:201 ../raster/r.relief/main.c:207
-#: ../raster/r.slope.aspect/main.c:321
-#, c-format
-msgid "%s=%s - must be a non-negative number"
+#: ../vector/v.lidar.edgedetection/edgedetection.c:246
+#: ../vector/v.lidar.edgedetection/edgedetection.c:258
+#: ../vector/v.lidar.edgedetection/edgedetection.c:379
+msgid "Impossible to write to aux table"
 msgstr ""
-#: ../raster/r.relief/main.c:215
-#, c-format
-msgid "%s=%s - must not be zero"
+#: ../vector/v.what.rast/main.c:77 ../vector/v.what.rast3/main.c:70
+#: ../vector/v.drape/main.c:60
+msgid "surface information"
 msgstr ""
-#: ../raster/r.relief/main.c:220 ../raster/r.slope.aspect/main.c:315
-#, c-format
-msgid "%s=%s - must be a positive number"
+#: ../vector/v.what.rast/main.c:79
+msgid "Uploads raster values at positions of vector points to the table."
 msgstr ""
-#: ../raster/r.relief/main.c:316 ../raster/r.series.interp/main.c:339
-#: ../raster/r.series.accumulate/main.c:318 ../raster/r.series/main.c:386
-#: ../raster/r.slope.aspect/main.c:544 ../raster/r.patch/main.c:138
-msgid "Percent complete..."
+#: ../vector/v.what.rast/main.c:83 ../vector/v.what.rast3/main.c:76
+#: ../locale/scriptstrings/v.what.vect_to_translate.c:8
+msgid "Name of vector points map for which to edit attributes"
 msgstr ""
-#: ../raster/r.relief/main.c:474
+#: ../vector/v.what.rast/main.c:93
+msgid "Name of existing raster map to be queried"
+msgstr ""
+#: ../vector/v.what.rast/main.c:98 ../vector/v.what.rast3/main.c:87
+#: ../locale/scriptstrings/v.what.vect_to_translate.c:11
+msgid "Name of attribute column to be updated with the query result"
+msgstr ""
+#: ../vector/v.what.rast/main.c:105
+msgid "Interpolate values from the nearest four cells"
+msgstr ""
+#: ../vector/v.what.rast/main.c:110
+msgid "Print categories and values instead of updating the database"
+msgstr ""
+#: ../vector/v.what.rast/main.c:170
 #, c-format
-msgid "Shaded relief raster map <%s> complete"
+msgid "Column <%s> not found in the table <%s>. Creating..."
 msgstr ""
-#: ../raster/r.series.interp/main.c:69
-msgid "Interpolates raster maps located (temporal or spatial) in between input raster maps at specific sampling positions."
+#: ../vector/v.what.rast/main.c:177 ../vector/v.colors/write_rgb.c:37
+#, c-format
+msgid "Unable to add column <%s> to table <%s>"
 msgstr ""
-#: ../raster/r.series.interp/main.c:79
-msgid "Data point position for each input map"
+#: ../vector/v.what.rast/main.c:186
+msgid "Raster type is integer and column type is float"
 msgstr ""
-#: ../raster/r.series.interp/main.c:84
-msgid "Input file with one input raster map name and data point position per line, field separator between name and sample point is |"
+#: ../vector/v.what.rast/main.c:189
+msgid "Raster type is float and column type is integer, some data lost!!"
 msgstr ""
-#: ../raster/r.series.interp/main.c:97
-msgid "Sampling point position for each output map"
+#: ../vector/v.what.rast/main.c:206 ../vector/v.what.rast3/main.c:158
+msgid "Reading features from vector map..."
 msgstr ""
-#: ../raster/r.series.interp/main.c:101
-msgid "Input file with one output raster map name and sample point position per line, field separator between name and sample point is |"
+#: ../vector/v.what.rast/main.c:271
+#, c-format
+msgid "No features of type (%s) found in vector map <%s>"
 msgstr ""
-#: ../raster/r.series.interp/main.c:111
-msgid "Interpolation method, currently only linear interpolation is supported"
+#: ../vector/v.what.rast/main.c:295
+#, c-format
+msgid "%d points outside current region were skipped"
 msgstr ""
-#: ../raster/r.series.interp/main.c:118 ../raster/r.series.interp/main.c:122
-#: ../raster/r.series.interp/main.c:134 ../raster/r.series.interp/main.c:138
-#: ../raster/r.series.accumulate/main.c:206 ../raster/r.neighbors/main.c:266
-#: ../raster/r.series/main.c:204 ../raster/r.external/main.c:164
-#: ../raster/r.mapcalc/main.c:117 ../vector/v.colors/main.c:206
+#: ../vector/v.what.rast/main.c:299
 #, c-format
-msgid "%s= and %s= are mutually exclusive"
+msgid "%d points without category were skipped"
 msgstr ""
-#: ../raster/r.series.interp/main.c:126 ../raster/r.series.interp/main.c:142
-#: ../raster/r.series.accumulate/main.c:210 ../raster/r.series/main.c:208
+#: ../vector/v.what.rast/main.c:570 ../vector/v.what.rast/main.c:610
 #, c-format
-msgid "Please specify %s= or %s="
+msgid "Multiple points (%d) of category %d, value set to 'NULL'"
 msgstr ""
-#: ../raster/r.series.interp/main.c:130 ../raster/r.series.interp/main.c:146
+#: ../vector/v.what.rast/main.c:678
 #, c-format
-msgid "Please specify %s= and %s="
+msgid "%d categories loaded from vector"
 msgstr ""
-#: ../raster/r.series.interp/main.c:180 ../raster/r.colors/edit_colors.c:186
+#: ../vector/v.what.rast/main.c:680
 #, c-format
-msgid "Unable to open %s file <%s>"
+msgid "%d duplicate categories in vector map <%s>"
 msgstr ""
-#: ../raster/r.series.interp/main.c:213
+#: ../vector/v.what.rast/main.c:684
 #, c-format
-msgid "Missing point position for %s map <%s> in file <%s> near line %i"
+msgid "%d categories loaded from table"
 msgstr ""
-#: ../raster/r.series.interp/main.c:228 ../raster/r.series.interp/main.c:262
+#: ../vector/v.what.rast/main.c:685
 #, c-format
-msgid "Preparing %s map <%s> at position %g"
+msgid "%d categories from vector missing in table"
 msgstr ""
-#: ../raster/r.series.interp/main.c:232
+#: ../vector/v.net.path/path.c:82
 #, c-format
-msgid "No raster map name found in %s file <%s>"
+msgid "[%d] points without category (nfield: [%d])"
 msgstr ""
-#: ../raster/r.series.interp/main.c:243
+#: ../vector/v.net.path/path.c:146 ../vector/v.net.path/path.c:211
 #, c-format
-msgid "No %s raster map not found"
+msgid "From and to are identical (id %d)"
 msgstr ""
-#: ../raster/r.series.interp/main.c:250
+#: ../vector/v.net.path/path.c:153 ../vector/v.net.timetable/main.c:482
 #, c-format
-msgid "The number of %s maps and %s point positions must be equal"
+msgid "Wrong input format: %s"
 msgstr ""
-#: ../raster/r.series.interp/main.c:279
+#: ../vector/v.net.path/path.c:164 ../vector/v.net.path/path.c:188
 #, c-format
-msgid "Start interpolation run with %i input maps and %i output maps"
+msgid "No point with category [%d]"
 msgstr ""
-#: ../raster/r.series.interp/main.c:299
+#: ../vector/v.net.path/path.c:234
 #, c-format
-msgid "map <%s> at position %g was not interpolated. Check the interpolation interval."
+msgid "Point with category [%d] is not reachable from point with category [%d]"
 msgstr ""
-#: ../raster/r.series.interp/main.c:319
-msgid "At least 2 input maps are required for linear interpolation"
+#: ../vector/v.net.path/path.c:303
+#, c-format
+msgid "Point %f,%f is not reachable from point %f,%f"
 msgstr ""
-#: ../raster/r.series.interp/main.c:337
+#: ../vector/v.net.path/path.c:368
 #, c-format
-msgid "Interpolate map <%s> at position %g in interval (%g;%g)"
+msgid "[%d] input format errors"
 msgstr ""
-#: ../raster/r.quantile/main.c:67
-msgid "Computing histogram"
+#: ../vector/v.net.path/path.c:370
+#, c-format
+msgid "[%d] points of given category missing"
 msgstr ""
-#: ../raster/r.quantile/main.c:101 ../raster/r.stats.quantile/main.c:174
-msgid "Computing bins"
+#: ../vector/v.net.path/path.c:372
+#, c-format
+msgid "%d destination(s) unreachable (including points out of threshold)"
 msgstr ""
-#: ../raster/r.quantile/main.c:139 ../raster/r.stats.quantile/main.c:231
-msgid "Binning data"
+#: ../vector/v.net.path/main.c:45
+msgid "Finds shortest path on vector network."
 msgstr ""
-#: ../raster/r.quantile/main.c:184 ../raster/r.stats.quantile/main.c:287
-msgid "Sorting bins"
+#: ../vector/v.net.path/main.c:72
+msgid ""
+"Name of file containing start and end points. If not given, read from stdin"
 msgstr ""
-#: ../raster/r.quantile/main.c:194 ../raster/r.stats.quantile/main.c:360
-msgid "Computing quantiles"
+#: ../vector/v.net.path/main.c:101
+msgid "Maximum distance to the network"
 msgstr ""
-#: ../raster/r.quantile/main.c:265 ../raster/r.stats.quantile/main.c:518
-msgid "percentile"
+#: ../vector/v.net.path/main.c:102
+msgid ""
+"If start/end are given as coordinates. If start/end point is outside this "
+"threshold, the path is not found and error message is printed. To speed up "
+"the process, keep this value as low as possible."
 msgstr ""
-#: ../raster/r.quantile/main.c:266 ../raster/r.stats.quantile/main.c:519
-msgid "quantile"
+#: ../vector/v.net.path/main.c:136 ../vector/v.net.distance/main.c:165
+msgid "Write output as original input segments, not each path as one line."
 msgstr ""
-#: ../raster/r.quantile/main.c:267
-msgid "Compute quantiles using two passes."
+#: ../vector/v.net.visibility/main.c:48
+msgid "visibility"
 msgstr ""
-#: ../raster/r.quantile/main.c:275 ../raster/r.stats.quantile/main.c:530
-msgid "Number of quantiles"
+#: ../vector/v.net.visibility/main.c:49
+msgid "Performs visibility graph construction."
 msgstr ""
-#: ../raster/r.quantile/main.c:283 ../raster/r.stats.quantile/main.c:536
-msgid "List of percentiles"
+#: ../vector/v.net.visibility/main.c:60
+msgid "Name of input vector map containing visible points"
 msgstr ""
-#: ../raster/r.quantile/main.c:289 ../raster/r.stats.quantile/main.c:543
-msgid "Number of bins to use"
+#: ../vector/v.net.visibility/main.c:61
+msgid "Add points after computing the visibility graph"
 msgstr ""
-#: ../raster/r.quantile/main.c:300
-msgid "Generate recode rules based on quantile-defined intervals"
+#: ../vector/v.net.visibility/main.c:85
+#, c-format
+msgid "Unable to copy elements from vector map <%s>"
 msgstr ""
-#: ../raster/r.quantile/main.c:334
-msgid "Too many quantiles"
+#: ../vector/v.net.visibility/main.c:90
+msgid "Lat-long projection"
 msgstr ""
-#: ../raster/r.series.accumulate/main.c:84
-msgid "Makes each output cell value a accumulationfunction of the values assigned to the corresponding cells in the input raster map layers."
+#: ../vector/v.mkgrid/main.c:72 ../display/d.grid/main.c:56
+msgid "grid"
 msgstr ""
-#: ../raster/r.series.accumulate/main.c:90
-msgid "Existing map to be added to output"
+#: ../vector/v.mkgrid/main.c:74
+msgid "hexagon"
 msgstr ""
-#: ../raster/r.series.accumulate/main.c:98
-msgid "Input file with raster map names, one per line"
+#: ../vector/v.mkgrid/main.c:75
+msgid "Creates a vector map of a user-defined grid."
 msgstr ""
-#: ../raster/r.series.accumulate/main.c:109
-msgid "Scale factor for input"
+#: ../vector/v.mkgrid/main.c:82
+msgid "rows,columns"
 msgstr ""
-#: ../raster/r.series.accumulate/main.c:116
-msgid "Shift factor for input"
+#: ../vector/v.mkgrid/main.c:86
+msgid "Number of rows and columns in grid"
 msgstr ""
-#: ../raster/r.series.accumulate/main.c:121
-msgid "The raster map specifying the lower accumulation limit, also called baseline"
+#: ../vector/v.mkgrid/main.c:95
+msgid "Where to place the grid"
 msgstr ""
-#: ../raster/r.series.accumulate/main.c:126
-msgid "The raster map specifying the upper accumulation limit, also called cutoff. Only applied to BEDD computation."
+#: ../vector/v.mkgrid/main.c:99
+msgid "current region"
 msgstr ""
-#: ../raster/r.series.accumulate/main.c:132 ../raster/r.series/main.c:183
-msgid "Ignore values outside this range"
+#: ../vector/v.mkgrid/main.c:100
+msgid "use 'coor' and 'box' options"
 msgstr ""
-#: ../raster/r.series.accumulate/main.c:139
-msgid "Use these limits in case lower and/or upper input maps are not defined"
+#: ../vector/v.mkgrid/main.c:105
+msgid "Lower left easting and northing coordinates of map"
 msgstr ""
-#: ../raster/r.series.accumulate/main.c:151
-msgid "Growing Degree Days or Winkler indices"
+#: ../vector/v.mkgrid/main.c:109
+msgid "width,height"
 msgstr ""
-#: ../raster/r.series.accumulate/main.c:152
-msgid "Mean: sum(input maps)/(number of input maps)"
+#: ../vector/v.mkgrid/main.c:113
+msgid "Width and height of boxes in grid"
 msgstr ""
-#: ../raster/r.series.accumulate/main.c:153
-msgid "Biologically Effective Degree Days"
+#: ../vector/v.mkgrid/main.c:120
+msgid "Angle of rotation (in degrees counter-clockwise)"
 msgstr ""
-#: ../raster/r.series.accumulate/main.c:154
-msgid "Huglin Heliothermal index"
+#: ../vector/v.mkgrid/main.c:128
+msgid "Number of vertex points per grid cell"
 msgstr ""
-#: ../raster/r.series.accumulate/main.c:163 ../raster/r.series/main.c:191
-msgid "Do not keep files open"
+#: ../vector/v.mkgrid/main.c:136 ../raster/r.to.vect/main.c:87
+#: ../locale/scriptstrings/t.rast.to.vect_to_translate.c:7
+msgid "Output feature type"
+msgstr "Izvades objektu tips"
+#: ../vector/v.mkgrid/main.c:141
+msgid "Create hexagons (default: rectangles)"
 msgstr ""
-#: ../raster/r.series.accumulate/main.c:167
-msgid "Create a FCELL map (floating point single precision) as output"
+#: ../vector/v.mkgrid/main.c:146
+msgid "Allow asymmetric hexagons"
 msgstr ""
-#: ../raster/r.series.accumulate/main.c:248
-#: ../raster/r.series.accumulate/main.c:273
-#: ../raster/r.series.accumulate/main.c:284
-#: ../raster/r.series.accumulate/main.c:292
-#: ../raster/r.series.accumulate/main.c:300 ../raster/r.out.mpeg/main.c:286
-#: ../raster/r.grow.distance/main.c:276 ../raster/r.surf.idw/main.c:713
-#: ../ps/ps.map/ps_raster.c:102
-#, c-format
-msgid "Reading raster map <%s>..."
+#: ../vector/v.mkgrid/main.c:186
+msgid "'coor' and 'position=region' are exclusive options"
 msgstr ""
-#: ../raster/r.series.accumulate/main.c:255 ../raster/r.series/main.c:275
-msgid "No raster map name found in input file"
+#: ../vector/v.mkgrid/main.c:189
+msgid "'box' and 'grid' are exclusive options for 'position=region'"
 msgstr ""
-#: ../raster/r.series.accumulate/main.c:265 ../raster/r.series/main.c:287
-#: ../raster/r.stats/main.c:285
-msgid "Raster map not found"
+#: ../vector/v.mkgrid/main.c:212 ../vector/v.mkgrid/main.c:248
+msgid "Invalid width"
 msgstr ""
-#: ../raster/r.series.accumulate/main.c:354
-#, c-format
-msgid "'%s'=%f must be > '%s'=%f"
+#: ../vector/v.mkgrid/main.c:215 ../vector/v.mkgrid/main.c:251
+msgid "Invalid height"
 msgstr ""
-#: ../raster/r.topidx/file_io.c:35
-#, c-format
-msgid "The current region resolution [%s x %s] is finer than the input map's resolution [%s x %s]. The current region resolution must be identical to, or coarser than, the input map's resolution."
+#: ../vector/v.mkgrid/main.c:231
+msgid "'grid' option missing"
 msgstr ""
-#: ../raster/r.topidx/file_io.c:42
-msgid "Reading elevation map..."
+#: ../vector/v.mkgrid/main.c:234
+msgid "'coor' option missing"
 msgstr ""
-#: ../raster/r.topidx/file_io.c:87
-msgid "Writing topographic index map..."
+#: ../vector/v.mkgrid/main.c:237
+msgid "'box' option missing"
 msgstr ""
-#: ../raster/r.topidx/main.c:41
-msgid "wetness"
+#: ../vector/v.mkgrid/main.c:241
+msgid "Invalid easting"
 msgstr ""
-#: ../raster/r.topidx/main.c:43
-msgid "Creates a topographic index (wetness index) raster map from an elevation raster map."
+#: ../vector/v.mkgrid/main.c:244
+msgid "Invalid northing"
 msgstr ""
-#: ../raster/r.topidx/main.c:49
-msgid "Name for output topographic index raster map"
+#: ../vector/v.mkgrid/main.c:309
+msgid "The hexagons will be asymmetrical."
 msgstr ""
-#: ../raster/r.topidx/main.c:56 ../raster/r.solute.transport/main.c:244
-#: ../raster/r.carve/main.c:213 ../raster/r.gwflow/main.c:222
-#, c-format
-msgid "Lat/Long location is not supported by %s. Please reproject map first."
+#: ../vector/v.mkgrid/main.c:322 ../vector/v.mkgrid/main.c:325
+msgid "Please use a higher resolution or a larger region"
 msgstr ""
-#: ../raster/r.topidx/topidx.c:272
+#: ../vector/v.mkgrid/main.c:329
 #, c-format
-msgid "Number of sinks or boundaries: %d"
+msgid "The number of rows has been adjusted from %d to %d"
 msgstr ""
-#: ../raster/r.neighbors/readweights.c:18
+#: ../vector/v.mkgrid/main.c:332
 #, c-format
-msgid "Unable to open weights file %s"
+msgid "The number of columns has been adjusted from %d to %d"
 msgstr ""
-#: ../raster/r.neighbors/readweights.c:23
-#, c-format
-msgid "Error reading weights file %s"
+#: ../vector/v.mkgrid/main.c:361 ../vector/v.mkgrid/main.c:446
+#: ../vector/v.mkgrid/main.c:458
+msgid "Unable to fill attribute table"
 msgstr ""
-#: ../raster/r.neighbors/main.c:121
-#, c-format
-msgid "Invalid out_type enumeration: %d"
+#: ../vector/v.mkgrid/main.c:372
+msgid "The rectangles will be asymmetrical."
 msgstr ""
-#: ../raster/r.neighbors/main.c:175
-msgid "Makes each cell category value a function of the category values assigned to the cells around it, and stores new cell values in an output raster map layer."
-msgstr "Šūnas jaunā vērtība būs kā funkcija no tai apkārt esošo šūnu vērtībām. Jaunā vērtība tiks saglabāta izvades rastra kartē."
+#: ../vector/v.mkgrid/main.c:417
+msgid "Creating centroids..."
+msgstr ""
-#: ../raster/r.neighbors/main.c:185
-msgid "Name of an input raster map to select the cells which should be processed"
+#: ../vector/v.mkgrid/write_grid.c:68
+msgid "Writing out vector rows..."
 msgstr ""
-#: ../raster/r.neighbors/main.c:204 ../vector/v.neighbors/main.c:72
-msgid "Neighborhood operation"
-msgstr "Operācijas ar blakusšūnām"
+#: ../vector/v.mkgrid/write_grid.c:107
+msgid "Writing out vector columns..."
+msgstr ""
-#: ../raster/r.neighbors/main.c:206 ../raster/r.neighbors/main.c:214
-#: ../raster/r.neighbors/main.c:249
-msgid "Neighborhood"
+#: ../vector/v.mkgrid/hexgrid.c:86
+msgid "Writing out hexagon grid..."
 msgstr ""
-#: ../raster/r.neighbors/main.c:226
-msgid "Text file containing weights"
+#: ../vector/v.net.connectivity/main.c:54
+msgid "connectivity"
 msgstr ""
-#: ../raster/r.neighbors/main.c:232
-msgid "Sigma (in cells) for Gaussian filter"
+#: ../vector/v.net.connectivity/main.c:56
+msgid "Computes vertex connectivity between two sets of nodes in the network."
 msgstr ""
-#: ../raster/r.neighbors/main.c:244
-msgid "Do not align output with the input"
+#: ../vector/v.net.connectivity/main.c:96
+msgid "Set1 category values"
 msgstr ""
-#: ../raster/r.neighbors/main.c:248
-msgid "Use circular neighborhood"
+#: ../vector/v.net.connectivity/main.c:97
+#: ../vector/v.net.connectivity/main.c:103
+msgid "Set1"
 msgstr ""
-#: ../raster/r.neighbors/main.c:256
-msgid "Neighborhood size must be positive"
+#: ../vector/v.net.connectivity/main.c:102
+msgid "Set1 WHERE conditions of SQL statement without 'where' keyword"
 msgstr ""
-#: ../raster/r.neighbors/main.c:258
-msgid "Neighborhood size must be odd"
+#: ../vector/v.net.connectivity/main.c:107
+msgid "Set2 category values"
 msgstr ""
-#: ../raster/r.neighbors/main.c:293
-#, c-format
-msgid "%s= and %s= must have the same number of values"
+#: ../vector/v.net.connectivity/main.c:108
+#: ../vector/v.net.connectivity/main.c:114
+msgid "Set2"
 msgstr ""
-#: ../raster/r.neighbors/main.c:329
-#, c-format
-msgid "Method %s not compatible with weighing window, using weight mask instead"
+#: ../vector/v.net.connectivity/main.c:113
+msgid "Set2 WHERE conditions of SQL statement without 'where' keyword"
 msgstr ""
-#: ../raster/r.neighbors/main.c:337
+#: ../vector/v.net.connectivity/main.c:146
+#: ../vector/v.net.connectivity/main.c:153
 #, c-format
-msgid "Method %s not compatible with Gaussian filter, using unweighed version instead"
+msgid "No features for %s selected. Please check options '%s', '%s'."
 msgstr ""
-#: ../raster/r.neighbors/main.c:386
+#: ../vector/v.net.connectivity/main.c:167
+#: ../vector/v.net.connectivity/main.c:170
 #, c-format
-msgid "Opening selection map <%s>"
+msgid "%s is empty"
+msgstr "%s ir tukšs"
+#: ../vector/v.lrs/v.lrs.label/main.c:103 ../vector/v.lrs/v.lrs.where/main.c:58
+#: ../vector/v.lrs/v.lrs.create/main.c:122
+#: ../vector/v.lrs/v.lrs.segment/main.c:72
+msgid "linear reference system"
 msgstr ""
-#: ../raster/r.stats.zonal/main.c:105
-msgid "Calculates category or object oriented statistics (accumulator-based statistics)."
+#: ../vector/v.lrs/v.lrs.label/main.c:105
+msgid "Creates stationing from input lines, and linear reference system."
 msgstr ""
-#: ../raster/r.stats.zonal/main.c:115 ../raster/r.statistics/main.c:69
-msgid "Method of object-based statistic"
+#: ../vector/v.lrs/v.lrs.label/main.c:109 ../vector/v.lrs/v.lrs.where/main.c:66
+#: ../vector/v.lrs/v.lrs.create/main.c:128
+#: ../vector/v.lrs/v.lrs.segment/main.c:79
+msgid "Input vector map containing lines"
 msgstr ""
-#: ../raster/r.stats.zonal/main.c:138 ../raster/r.statistics/main.c:92
-msgid "Resultant raster map"
+#: ../vector/v.lrs/v.lrs.label/main.c:113
+msgid "Output vector map where stationing will be written"
 msgstr ""
-#: ../raster/r.stats.zonal/main.c:144 ../raster/r.statistics/main.c:98
-msgid "Cover values extracted from the category labels of the cover map"
+#: ../vector/v.lrs/v.lrs.label/main.c:118 ../vector/v.lrs/v.lrs.where/main.c:75
+#: ../vector/v.lrs/v.lrs.create/main.c:147
+#: ../vector/v.lrs/v.lrs.segment/main.c:88
+msgid "Line layer"
 msgstr ""
-#: ../raster/r.stats.zonal/main.c:149 ../raster/r.stats.quantile/main.c:564
-msgid "Create reclass map with statistics as category labels"
+#: ../vector/v.lrs/v.lrs.label/main.c:124 ../vector/v.lrs/v.lrs.where/main.c:86
+#: ../vector/v.lrs/v.lrs.create/main.c:207
+#: ../vector/v.lrs/v.lrs.segment/main.c:94
+msgid "Driver name for reference system table"
 msgstr ""
-#: ../raster/r.stats.zonal/main.c:165 ../raster/r.statistics/main.c:118
-#: ../raster/r.proj/main.c:237 ../vector/v.vect.stats/main.c:263
-#: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:152
-#: ../imagery/i.rectify/main.c:172
-#, c-format
-msgid "<%s=%s> unknown %s"
+#: ../vector/v.lrs/v.lrs.label/main.c:132 ../vector/v.lrs/v.lrs.where/main.c:94
+#: ../vector/v.lrs/v.lrs.create/main.c:215
+#: ../vector/v.lrs/v.lrs.segment/main.c:102
+msgid "Database name for reference system table"
 msgstr ""
-#: ../raster/r.stats.zonal/main.c:178
-#, c-format
-msgid "Unable to read category file of cover map <%s>"
+#: ../vector/v.lrs/v.lrs.label/main.c:139
+#: ../vector/v.lrs/v.lrs.where/main.c:101
+#: ../vector/v.lrs/v.lrs.segment/main.c:109
+msgid "Name of the reference system table"
 msgstr ""
-#: ../raster/r.stats.zonal/main.c:181 ../raster/r.stats.quantile/main.c:624
-msgid "The base map must be an integer (CELL) map"
+#: ../vector/v.lrs/v.lrs.label/main.c:147
+msgid "Label file"
 msgstr ""
-#: ../raster/r.stats.zonal/main.c:184 ../raster/r.stats.quantile/main.c:627
-#, c-format
-msgid "Unable to read range of base map <%s>"
+#: ../vector/v.lrs/v.lrs.label/main.c:156
+msgid "PM left, MP right, stationing left, stationing right offset"
 msgstr ""
-#: ../raster/r.stats.zonal/main.c:248
-msgid "First pass"
+#: ../vector/v.lrs/v.lrs.label/main.c:161
+msgid "Offset label in label x-direction in map units"
 msgstr ""
-#: ../raster/r.stats.zonal/main.c:327
-msgid "Second pass"
+#: ../vector/v.lrs/v.lrs.label/main.c:168
+msgid "Offset label in label y-direction in map units"
 msgstr ""
-#: ../raster/r.stats.zonal/main.c:474
-msgid "Generating reclass map"
+#: ../vector/v.lrs/v.lrs.label/main.c:197
+msgid "Line width of text"
 msgstr ""
-#: ../raster/r.stats.zonal/main.c:482 ../raster/r.stats.quantile/main.c:427
-#: ../raster/r.proj/readcell.c:59 ../raster/r.proj/readcell.c:129
-#: ../imagery/i.ortho.photo/i.ortho.rectify/readcell.c:64
-#: ../imagery/i.rectify/readcell.c:58
-msgid "Unable to open temporary file"
+#: ../vector/v.lrs/v.lrs.label/main.c:198
+#: ../vector/v.lrs/v.lrs.label/main.c:211
+msgid "Only for d.label output"
 msgstr ""
-#: ../raster/r.stats.zonal/main.c:496
-msgid "Writing output map"
+#: ../vector/v.lrs/v.lrs.label/main.c:210
+msgid "Line width of highlight color"
 msgstr ""
-#: ../raster/r.series/main.c:141
-msgid "Makes each output cell value a function of the values assigned to the corresponding cells in the input raster map layers."
+#: ../vector/v.lrs/v.lrs.label/main.c:228
+msgid "Opaque to vector"
 msgstr ""
-#: ../raster/r.series/main.c:150
-msgid "Input file with one raster map name and optional one weight per line, field separator between name and weight is |"
+#: ../vector/v.lrs/v.lrs.label/main.c:229
+msgid "Only relevant if background color is selected"
 msgstr ""
-#: ../raster/r.series/main.c:176
-msgid "Weighting factor for each input map, default value is 1.0 for each input map"
+#: ../vector/v.lrs/v.lrs.label/main.c:283 ../display/d.labels/main.c:114
+#, c-format
+msgid "Unable to open label file <%s>"
 msgstr ""
-#: ../raster/r.series/main.c:250 ../raster/r.series/main.c:312
-msgid "Weights must be positive"
+#: ../vector/v.lrs/v.lrs.label/main.c:292
+#: ../vector/v.lrs/v.lrs.where/main.c:147
+#: ../vector/v.lrs/v.lrs.create/main.c:315
+#: ../vector/v.lrs/v.lrs.segment/main.c:155
+msgid "Unable to open database for reference table"
 msgstr ""
-#: ../raster/r.series/main.c:268 ../raster/r.series/main.c:318
+#: ../vector/v.lrs/v.lrs.label/main.c:322
 #, c-format
-msgid "Reading raster map <%s> using weight %f..."
+msgid "Unable to select records from LRS table: %s"
 msgstr ""
-#: ../raster/r.series/main.c:298
-msgid "input= and weights= must have the same number of values"
+#: ../vector/v.lrs/v.lrs.label/main.c:412
+msgid "No record in LR table"
 msgstr ""
-#: ../raster/r.series/main.c:333
-msgid "output= and method= must have the same number of values"
+#: ../vector/v.lrs/v.lrs.label/main.c:416
+msgid "More than one record in LR table"
 msgstr ""
-#: ../raster/r.series/main.c:351
-#, c-format
-msgid "Method %s not compatible with weights, using unweighed version instead"
+#: ../vector/v.lrs/v.lrs.where/main.c:61
+msgid ""
+"Finds line id and real km+offset for given points in vector map using linear "
+"reference system."
 msgstr ""
-#: ../raster/r.slope.aspect/main.c:153
-msgid "aspect"
+#: ../vector/v.lrs/v.lrs.where/main.c:70
+msgid "Input vector map containing points"
 msgstr ""
-#: ../raster/r.slope.aspect/main.c:154
-msgid "slope"
+#: ../vector/v.lrs/v.lrs.where/main.c:80
+#: ../vector/v.lrs/v.lrs.create/main.c:151
+msgid "Point layer"
 msgstr ""
-#: ../raster/r.slope.aspect/main.c:155
-msgid "curvature"
+#: ../vector/v.lrs/v.lrs.where/main.c:108
+msgid "Maximum distance to nearest line"
 msgstr ""
-#: ../raster/r.slope.aspect/main.c:156
-msgid "Generates raster maps of slope, aspect, curvatures and partial derivatives from an elevation raster map."
-msgstr ""
+#: ../vector/v.lrs/v.lrs.where/main.c:222
+#: ../vector/v.lrs/v.lrs.segment/main.c:357
+#, c-format
+msgid "[%d] point read from input"
+msgid_plural "[%d] points read from input"
+msgstr[0] ""
+msgstr[1] ""
+msgstr[2] ""
-#: ../raster/r.slope.aspect/main.c:158
-msgid "Aspect is calculated counterclockwise from east."
+#: ../vector/v.lrs/v.lrs.where/main.c:225
+#, c-format
+msgid "[%d] position found"
+msgid_plural "[%d] positions found"
+msgstr[0] ""
+msgstr[1] ""
+msgstr[2] ""
+#: ../vector/v.lrs/v.lrs.where/main.c:229
+#, c-format
+msgid "[%d] point outside threshold"
+msgid_plural "[%d] points outside threshold"
+msgstr[0] ""
+msgstr[1] ""
+msgstr[2] ""
+#: ../vector/v.lrs/v.lrs.where/main.c:233
+#, c-format
+msgid "[%d] point - no record found"
+msgid_plural "[%d] points - no record found"
+msgstr[0] ""
+msgstr[1] ""
+msgstr[2] ""
+#: ../vector/v.lrs/v.lrs.where/main.c:237
+#, c-format
+msgid "[%d] point - too many records found"
+msgid_plural "[%d] points - too many records found"
+msgstr[0] ""
+msgstr[1] ""
+msgstr[2] ""
+#: ../vector/v.lrs/v.lrs.create/main.c:124
+msgid "Creates a linear reference system."
 msgstr ""
-#: ../raster/r.slope.aspect/main.c:165 ../vector/v.surf.rst/main.c:201
-msgid "Name for output slope raster map"
+#: ../vector/v.lrs/v.lrs.create/main.c:133
+msgid "Output vector map where oriented lines are written"
 msgstr ""
-#: ../raster/r.slope.aspect/main.c:166 ../raster/r.slope.aspect/main.c:172
-#: ../raster/r.slope.aspect/main.c:196 ../raster/r.slope.aspect/main.c:203
-#: ../raster/r.slope.aspect/main.c:210 ../raster/r.slope.aspect/main.c:217
-#: ../raster/r.slope.aspect/main.c:224 ../raster/r.slope.aspect/main.c:231
-#: ../raster/r.slope.aspect/main.c:238 ../raster/r.watershed/front/main.c:134
-#: ../raster/r.watershed/front/main.c:141
-#: ../raster/r.watershed/front/main.c:148
-#: ../raster/r.watershed/front/main.c:154
-#: ../raster/r.watershed/front/main.c:160
-#: ../raster/r.watershed/front/main.c:166
-#: ../raster/r.watershed/front/main.c:174
-#: ../raster/r.watershed/front/main.c:182
-#: ../raster/r.watershed/front/main.c:189 ../vector/v.surf.rst/main.c:172
-#: ../vector/v.surf.rst/main.c:196 ../vector/v.surf.rst/main.c:202
-#: ../vector/v.surf.rst/main.c:208 ../vector/v.surf.rst/main.c:214
-#: ../vector/v.surf.rst/main.c:220 ../vector/v.surf.rst/main.c:226
-#: ../vector/v.surf.rst/main.c:232 ../vector/v.surf.rst/main.c:239
-#: ../vector/v.surf.rst/main.c:246 ../vector/v.surf.rst/main.c:253
-#: ../vector/v.vol.rst/main.c:291 ../vector/v.vol.rst/main.c:297
-#: ../vector/v.vol.rst/main.c:360 ../vector/v.vol.rst/main.c:366
-#: ../vector/v.vol.rst/main.c:372 ../vector/v.vol.rst/main.c:379
-#: ../vector/v.vol.rst/main.c:385 ../vector/v.vol.rst/main.c:391
-#: ../vector/v.vol.rst/main.c:397 ../vector/v.vol.rst/main.c:403
-#: ../vector/v.surf.bspline/main.c:130 ../vector/v.surf.bspline/main.c:135
-msgid "Outputs"
-msgstr "Izvades"
-#: ../raster/r.slope.aspect/main.c:171 ../vector/v.surf.rst/main.c:207
-msgid "Name for output aspect raster map"
+#: ../vector/v.lrs/v.lrs.create/main.c:138
+msgid "Output vector map of errors"
 msgstr ""
-#: ../raster/r.slope.aspect/main.c:180
-msgid "Format for reporting the slope"
+#: ../vector/v.lrs/v.lrs.create/main.c:143
+msgid "Input vector map containing reference points"
 msgstr ""
-#: ../raster/r.slope.aspect/main.c:187
-msgid "Type of output aspect and slope maps"
+#: ../vector/v.lrs/v.lrs.create/main.c:158
+msgid "Column containing line identifiers for lines"
 msgstr ""
-#: ../raster/r.slope.aspect/main.c:195 ../vector/v.surf.rst/main.c:213
-msgid "Name for output profile curvature raster map"
+#: ../vector/v.lrs/v.lrs.create/main.c:165
+msgid "Column containing line identifiers for points"
 msgstr ""
-#: ../raster/r.slope.aspect/main.c:202 ../vector/v.surf.rst/main.c:219
-msgid "Name for output tangential curvature raster map"
+#: ../vector/v.lrs/v.lrs.create/main.c:173
+msgid "Column containing milepost position for the beginning of next segment"
 msgstr ""
-#: ../raster/r.slope.aspect/main.c:209
-msgid "Name for output first order partial derivative dx (E-W slope) raster map"
+#: ../vector/v.lrs/v.lrs.create/main.c:182
+msgid ""
+"Column containing offset from milepost for the beginning of next segment"
 msgstr ""
-#: ../raster/r.slope.aspect/main.c:216
-msgid "Name for output first order partial derivative dy (N-S slope) raster map"
+#: ../vector/v.lrs/v.lrs.create/main.c:191
+msgid "Column containing milepost position for the end of previous segment"
 msgstr ""
-#: ../raster/r.slope.aspect/main.c:223
-msgid "Name for output second order partial derivative dxx raster map"
+#: ../vector/v.lrs/v.lrs.create/main.c:200
+msgid "Column containing offset from milepost for the end of previous segment"
 msgstr ""
-#: ../raster/r.slope.aspect/main.c:230
-msgid "Name for output second order partial derivative dyy raster map"
+#: ../vector/v.lrs/v.lrs.create/main.c:223
+msgid "Name of table where the reference system will be written"
 msgstr ""
-#: ../raster/r.slope.aspect/main.c:237
-msgid "Name for output second order partial derivative dxy raster map"
+#: ../vector/v.lrs/v.lrs.create/main.c:224
+msgid "New table is created by this module"
 msgstr ""
-#: ../raster/r.slope.aspect/main.c:243
-msgid "Multiplicative factor to convert elevation units to horizontal units"
+#: ../vector/v.lrs/v.lrs.create/main.c:231
+msgid "Maximum distance of point to line allowed"
 msgstr ""
-#: ../raster/r.slope.aspect/main.c:252
-msgid "Minimum slope value (in percent) for which aspect is computed"
+#: ../vector/v.lrs/v.lrs.create/main.c:286
+msgid "Cannot get layer info for lines"
 msgstr ""
-#: ../raster/r.slope.aspect/main.c:261
-msgid "Do not align the current region to the raster elevation map"
+#: ../vector/v.lrs/v.lrs.create/main.c:289
+msgid "Cannot get layer info for points"
 msgstr ""
-#: ../raster/r.slope.aspect/main.c:336
+#: ../vector/v.lrs/v.lrs.create/main.c:327
 #, c-format
-msgid "You must specify at least one of the parameters: <%s>, <%s>, <%s>, <%s>, <%s>, <%s>, <%s>, <%s> or <%s>"
+msgid "Unable to drop table: %s"
 msgstr ""
-#: ../raster/r.slope.aspect/main.c:358
+#: ../vector/v.lrs/v.lrs.create/main.c:346
 #, c-format
-msgid "Wrong raster type: %s"
+msgid "Unable to select line id values from %s.%s."
 msgstr ""
-#: ../raster/r.slope.aspect/main.c:387
-msgid "r.slope.aspect does not convert horizontal units to meters in this version, see manual page."
+#: ../vector/v.lrs/v.lrs.create/main.c:356
+msgid "Line id column must be integer"
 msgstr ""
-#: ../raster/r.slope.aspect/main.c:968
-#, c-format
-msgid "Elevation products for mapset <%s> in <%s>"
+#: ../vector/v.lrs/v.lrs.create/main.c:367
+#: ../vector/v.lrs/v.lrs.create/main.c:469
+msgid "Unable to fetch line id from line table"
 msgstr ""
-#: ../raster/r.slope.aspect/main.c:987
+#: ../vector/v.lrs/v.lrs.create/main.c:419
 #, c-format
-msgid "Min computed aspect %.4f, max computed aspect %.4f"
+msgid "Line [%d] without category (layer [%d])"
 msgstr ""
-#: ../raster/r.slope.aspect/main.c:1051
+#: ../vector/v.lrs/v.lrs.create/main.c:439
 #, c-format
-msgid "Aspect raster map <%s> complete"
+msgid "No lines selected for line id [%d]"
 msgstr ""
-#: ../raster/r.slope.aspect/main.c:1108
+#: ../vector/v.lrs/v.lrs.create/main.c:459
 #, c-format
-msgid "Min computed slope %.4f, max computed slope %.4f"
+msgid "Unable to select point attributes from <%s>"
 msgstr ""
-#: ../raster/r.slope.aspect/main.c:1161
+#: ../vector/v.lrs/v.lrs.create/main.c:490
 #, c-format
-msgid "Slope raster map <%s> complete"
+msgid "Milepost (start) %f+%f used as %f+%f (change MP to integer)"
 msgstr ""
-#: ../raster/r.slope.aspect/main.c:1233
+#: ../vector/v.lrs/v.lrs.create/main.c:512
 #, c-format
-msgid "Profile curve raster map <%s> complete"
+msgid "Milepost (end) %f+%f used as %f+%f (change MP to integer)"
 msgstr ""
-#: ../raster/r.slope.aspect/main.c:1260
+#: ../vector/v.lrs/v.lrs.create/main.c:538
 #, c-format
-msgid "Tangential curve raster map <%s> complete"
+msgid "Point [%d] without category (layer [%d])"
 msgstr ""
-#: ../raster/r.slope.aspect/main.c:1285
+#: ../vector/v.lrs/v.lrs.create/main.c:585
 #, c-format
-msgid "E-W slope raster map <%s> complete"
+msgid "Point [%d] cat [%d] is out of threshold (distance = %f)"
 msgstr ""
-#: ../raster/r.slope.aspect/main.c:1310
+#: ../vector/v.lrs/v.lrs.create/main.c:717
 #, c-format
-msgid "N-S slope raster map <%s> complete"
+msgid "End > start for point cat [%d]"
 msgstr ""
-#: ../raster/r.slope.aspect/main.c:1335
-#, c-format
-msgid "Dxx raster map <%s> complete"
+#: ../vector/v.lrs/v.lrs.create/main.c:734
+msgid "Start of 1. MP >= end of 2. MP for points' cats %[d], [%d]"
 msgstr ""
-#: ../raster/r.slope.aspect/main.c:1360
+#: ../vector/v.lrs/v.lrs.create/main.c:751
 #, c-format
-msgid "Dyy raster map <%s> complete"
+msgid "Start of 1. MP >= start of 2. MP for points' cats [%d], [%d]"
 msgstr ""
-#: ../raster/r.slope.aspect/main.c:1385
+#: ../vector/v.lrs/v.lrs.create/main.c:761
 #, c-format
-msgid "Dxy raster map <%s> complete"
+msgid "Distance along line identical for points' cats [%d], [%d]"
 msgstr ""
-#: ../raster/r.report/stats.c:93
+#: ../vector/v.lrs/v.lrs.create/main.c:775
 #, c-format
-msgid "Unable to open result file <%s>"
+msgid "Not enough points (%d) attached to the line (cat %d), line skip."
 msgstr ""
-#: ../raster/r.report/stats.c:128 ../raster/r.kappa/stats.c:14
-msgid "Problem reading r.stats output"
+#: ../vector/v.lrs/v.lrs.create/main.c:780
+#, c-format
+msgid "Unable to guess direction for the line (cat %d), line skip."
 msgstr ""
-#: ../raster/r.report/main.c:69
-msgid "Reports statistics for raster maps."
+#: ../vector/v.lrs/v.lrs.create/main.c:784
+#, c-format
+msgid "Incorrect order of points along line cat [%d]"
 msgstr ""
-#: ../raster/r.report/label.c:13
-msgid "Page width is too small"
+#: ../vector/v.lrs/v.lrs.create/main.c:834
+#, c-format
+msgid "Unable to insert reference records: %s"
 msgstr ""
-#: ../raster/r.report/parse.c:38 ../raster/r.stats/main.c:114
-msgid "Name of raster map(s) to report on"
+#: ../vector/v.lrs/v.lrs.create/main.c:875
+msgid "Building topology for output (out_lines) map..."
 msgstr ""
-#: ../raster/r.report/parse.c:45
-msgid "Units to report"
+#: ../vector/v.lrs/v.lrs.create/main.c:886
+msgid "Building topology for error (err) map..."
 msgstr ""
-#: ../raster/r.report/parse.c:49
-msgid "area in square miles"
+#: ../vector/v.lrs/v.lrs.segment/main.c:75
+msgid ""
+"Creates points/segments from input lines, linear reference system and "
+"positions read from stdin or a file."
 msgstr ""
-#: ../raster/r.report/parse.c:50
-msgid "area in square meters"
+#: ../vector/v.lrs/v.lrs.segment/main.c:83
+msgid "Output vector map where segments will be written"
 msgstr ""
-#: ../raster/r.report/parse.c:51
-msgid "area in square kilometers"
+#: ../vector/v.lrs/v.lrs.segment/main.c:114
+msgid "Name of file containing segment rules. If not given, read from stdin."
 msgstr ""
-#: ../raster/r.report/parse.c:52
-msgid "area in acres"
+#: ../vector/v.lrs/v.lrs.segment/main.c:184
+#: ../vector/v.lrs/v.lrs.segment/main.c:238
+#, c-format
+msgid "Cannot read input: %s"
 msgstr ""
-#: ../raster/r.report/parse.c:53
-msgid "area in hectares"
+#: ../vector/v.lrs/v.lrs.segment/main.c:196
+#, c-format
+msgid "No record in LR table for: %s"
 msgstr ""
-#: ../raster/r.report/parse.c:54
-msgid "number of cells"
+#: ../vector/v.lrs/v.lrs.segment/main.c:200
+#, c-format
+msgid "More than one record in LR table for: %s"
 msgstr ""
-#: ../raster/r.report/parse.c:55
-msgid "percent cover"
+#: ../vector/v.lrs/v.lrs.segment/main.c:207
+#: ../vector/v.lrs/v.lrs.segment/main.c:294
+#, c-format
+msgid "Unable to find line of cat [%d]"
 msgstr ""
-#: ../raster/r.report/parse.c:58 ../raster/r.stats/main.c:158
-#: ../raster/r.stats/main.c:163 ../raster/r.stats/main.c:169
-msgid "Statistics"
+#: ../vector/v.lrs/v.lrs.segment/main.c:217
+#, c-format
+msgid ""
+"Cannot get point on line: cat = [%d] distance = [%f] (line length = %f)\n"
+"%s"
 msgstr ""
-#: ../raster/r.report/parse.c:63 ../raster/r.volume/main.c:104
-msgid "Name for output file to hold the report"
+#: ../vector/v.lrs/v.lrs.segment/main.c:253
+#, c-format
+msgid ""
+"No record in LRS table for 1. point of:\n"
+"  %s"
 msgstr ""
-#: ../raster/r.report/parse.c:65 ../raster/r.volume/main.c:106
-msgid "If no output file given report is printed to standard output"
+#: ../vector/v.lrs/v.lrs.segment/main.c:258
+#, c-format
+msgid ""
+"Using last from more offsets found for 1. point of:\n"
+"  %s"
 msgstr ""
-#: ../raster/r.report/parse.c:75
-msgid "Page length"
+#: ../vector/v.lrs/v.lrs.segment/main.c:262
+#, c-format
+msgid ""
+"Requested offset for the 1. point not found, using nearest found:\n"
+"  %s"
 msgstr ""
-#: ../raster/r.report/parse.c:83
-msgid "Page width"
+#: ../vector/v.lrs/v.lrs.segment/main.c:273
+#, c-format
+msgid ""
+"No record in LRS table for 2. point of:\n"
+"  %s"
 msgstr ""
-#: ../raster/r.report/parse.c:94 ../raster/r.stats/main.c:136
-msgid "Number of floating-point subranges to collect stats from"
+#: ../vector/v.lrs/v.lrs.segment/main.c:278
+#, c-format
+msgid ""
+"Requested offset for the 2. point not found, using nearest found:\n"
+"  %s"
 msgstr ""
-#: ../raster/r.report/parse.c:95 ../raster/r.report/parse.c:139
-#: ../raster/r.report/parse.c:145 ../raster/r.stats/main.c:137
-#: ../raster/r.stats/main.c:192 ../raster/r.stats/main.c:197
-#: ../raster/r.stats/main.c:212 ../raster/r.stats/main.c:217
-msgid "Floating point"
+#: ../vector/v.lrs/v.lrs.segment/main.c:282
+#, c-format
+msgid ""
+"Using first from more offsets found for 2. point of:\n"
+"  %s"
 msgstr ""
-#: ../raster/r.report/parse.c:102 ../raster/r.stats/main.c:144
-msgid "Sort output statistics by cell counts"
+#: ../vector/v.lrs/v.lrs.segment/main.c:287
+msgid "Segment over 2 (or more) segments, not yet supported"
 msgstr ""
-#: ../raster/r.report/parse.c:103 ../raster/r.stats/main.c:145
-msgid "Default: sorted by categories or intervals"
+#: ../vector/v.lrs/v.lrs.segment/main.c:304
+#, c-format
+msgid "End of segment > line length (%e) -> cut"
 msgstr ""
-#: ../raster/r.report/parse.c:107 ../raster/r.stats/main.c:149
-msgid "Sort by cell counts in ascending order"
+#: ../vector/v.lrs/v.lrs.segment/main.c:313
+#, c-format
+msgid ""
+"Cannot make line segment: cat = %d : %f - %f (line length = %f)\n"
+"%s"
 msgstr ""
-#: ../raster/r.report/parse.c:108 ../raster/r.stats/main.c:150
-msgid "Sort by cell counts in descending order"
+#. GTC %s will be replaced with a message about lost points.
+#: ../vector/v.lrs/v.lrs.segment/main.c:364
+#, c-format
+msgid "[%d] point written to output map (%s)"
+msgid_plural "[%d] points written to output map (%s)"
+msgstr[0] ""
+msgstr[1] ""
+msgstr[2] ""
+#: ../vector/v.lrs/v.lrs.segment/main.c:369
+#, c-format
+msgid "[%d] line read from input"
+msgid_plural "[%d] lines read from input"
+msgstr[0] ""
+msgstr[1] ""
+msgstr[2] ""
+#. GTC %s will be replaced with a message about lost lines.
+#: ../vector/v.lrs/v.lrs.segment/main.c:376
+#, c-format
+msgid "[%d] line written to output map (%s)"
+msgid_plural "[%d] lines written to output map (%s)"
+msgstr[0] ""
+msgstr[1] ""
+msgstr[2] ""
+#: ../vector/v.net.timetable/main.c:218
+#, c-format
+msgid "Could not find a path between stops %d and %d"
 msgstr ""
-#: ../raster/r.report/parse.c:113
-msgid "Suppress page headers"
+#: ../vector/v.net.timetable/main.c:263
+msgid "Finds shortest path using timetables."
 msgstr ""
-#: ../raster/r.report/parse.c:118
-msgid "Use formfeeds between pages"
+#: ../vector/v.net.timetable/main.c:309
+msgid "Layer number or name with walking connections or -1"
 msgstr ""
-#: ../raster/r.report/parse.c:123
-msgid "Scientific format"
-msgstr "Zinātniskais formāts"
-#: ../raster/r.report/parse.c:128 ../raster/r.stats/main.c:201
-msgid "Do not report no data value"
+#: ../vector/v.net.timetable/main.c:315
+msgid "Name of column with route ids"
 msgstr ""
-#: ../raster/r.report/parse.c:129 ../raster/r.report/parse.c:134
-#: ../raster/r.stats/main.c:202 ../raster/r.stats/main.c:207
-msgid "No data"
+#: ../vector/v.net.timetable/main.c:322
+msgid "Name of column with stop timestamps"
 msgstr ""
-#: ../raster/r.report/parse.c:133 ../raster/r.stats/main.c:206
-msgid "Do not report cells where all maps have no data"
+#: ../vector/v.net.timetable/main.c:328
+msgid "Name of column with stop ids"
 msgstr ""
-#: ../raster/r.report/parse.c:138 ../raster/r.stats/main.c:211
-msgid "Report for cats floating-point ranges (floating-point maps only)"
+#: ../vector/v.net.timetable/main.c:334
+msgid "Name of column with walk lengths"
 msgstr ""
-#: ../raster/r.report/parse.c:144 ../raster/r.stats/main.c:216
-msgid "Read floating-point map as integer (use map's quant rules)"
+#: ../vector/v.net.timetable/main.c:381
+msgid "Could not initialize the timetables"
 msgstr ""
-#: ../raster/r.report/parse.c:187
-msgid "nsteps has to be > 0; using nsteps=255"
+#: ../vector/v.net.timetable/main.c:459 ../vector/v.net.timetable/main.c:490
+#: ../vector/v.net.timetable/main.c:498
+#, c-format
+msgid "No stop with category: %d"
 msgstr ""
-#: ../raster/r.report/parse.c:193
-msgid "Illegal page length"
+#: ../vector/v.net.timetable/main.c:505
+msgid "'From' and 'To' stops are the same"
 msgstr ""
-#: ../raster/r.report/parse.c:198
-msgid "Illegal page width"
+#: ../vector/v.net.timetable/main.c:514
+msgid "No path between the stops"
 msgstr ""
-#: ../raster/r.report/parse.c:253
+#: ../vector/v.rectify/target.c:18
+#: ../imagery/i.ortho.photo/i.ortho.rectify/target.c:13
+#: ../imagery/i.rectify/target.c:13
 #, c-format
-msgid "Only %d unit%s allowed"
+msgid "Target information for group <%s> missing"
 msgstr ""
-#: ../raster/r.report/parse.c:286
+#: ../vector/v.rectify/target.c:29
+#: ../imagery/i.ortho.photo/i.ortho.rectify/target.c:19
+#: ../imagery/i.rectify/target.c:19
 #, c-format
-msgid "Unable to read fp range for raster map <%s>"
+msgid "Target location <%s> not found"
 msgstr ""
-#: ../raster/r.report/parse.c:294 ../raster/r.category/main.c:148
-#: ../raster/r.category/main.c:230 ../raster/r.mapcalc/map3.c:190
-#: ../raster/r.mapcalc/map.c:233
+#: ../vector/v.rectify/target.c:40 ../raster/r.in.gdal/main.c:936
+#: ../imagery/i.ortho.photo/i.ortho.rectify/target.c:31
+#: ../imagery/i.rectify/target.c:31
 #, c-format
-msgid "Unable to read category file of raster map <%s@%s>"
+msgid "Mapset <%s> in target location <%s> - "
 msgstr ""
-#: ../raster/r.his/main.c:68 ../display/d.his/main.c:64
-#: ../imagery/i.his.rgb/main.c:47 ../imagery/i.rgb.his/main.c:47
-msgid "color transformation"
+#: ../vector/v.rectify/target.c:41 ../raster/r.proj/main.c:281
+#: ../raster/r.in.gdal/main.c:938
+#: ../imagery/i.ortho.photo/i.ortho.rectify/target.c:32
+#: ../imagery/i.rectify/target.c:32
+msgid "permission denied"
 msgstr ""
-#: ../raster/r.his/main.c:73
-msgid "Generates red, green and blue (RGB) raster map layers combining hue, intensity and saturation (HIS) values from user-specified input raster map layers."
+#: ../vector/v.rectify/target.c:41 ../raster/r.proj/main.c:282
+#: ../raster/r.in.gdal/main.c:939
+msgid "not found"
 msgstr ""
-#: ../raster/r.his/main.c:82 ../display/d.his/main.c:78
-msgid "Name of layer to be used for hue"
+#: ../vector/v.rectify/target.c:43
+msgid "Please run i.target for group."
 msgstr ""
-#: ../raster/r.his/main.c:89 ../display/d.his/main.c:85
-msgid "Name of layer to be used for intensity"
+#: ../vector/v.rectify/main.c:71 ../imagery/i.rectify/main.c:84
+msgid "rectify"
 msgstr ""
-#: ../raster/r.his/main.c:96 ../display/d.his/main.c:92
-msgid "Name of layer to be used for saturation"
+#: ../vector/v.rectify/main.c:75
+msgid ""
+"Rectifies a vector by computing a coordinate transformation for each object "
+"in the vector based on the control points."
 msgstr ""
-#: ../raster/r.his/main.c:103
-msgid "Name of output layer to be used for red"
+#: ../vector/v.rectify/main.c:90
+msgid "Name of input file with control points"
 msgstr ""
-#: ../raster/r.his/main.c:110
-msgid "Name of output layer to be used for green"
+#: ../vector/v.rectify/main.c:95
+msgid "Name of output file with RMS errors (if omitted or '-' output to stdout"
 msgstr ""
-#: ../raster/r.his/main.c:117
-msgid "Name of output layer to be used for blue"
+#: ../vector/v.rectify/main.c:104 ../imagery/i.rectify/main.c:108
+msgid "Rectification polynomial order (1-3)"
 msgstr ""
-#: ../raster/r.his/main.c:145
-#, c-format
-msgid "No such color <%s>"
+#: ../vector/v.rectify/main.c:107
+msgid "Field separator for RMS report"
 msgstr ""
-#: ../raster/r.his/main.c:167 ../raster/r.his/main.c:183
-#: ../raster/r.his/main.c:201 ../raster/r.out.ppm3/main.c:115
-#: ../display/d.his/main.c:139 ../display/d.his/main.c:156
-#: ../display/d.his/main.c:174 ../display/d.colortable/main.c:135
-#: ../display/d.rast/display.c:23 ../display/d.rast.num/main.c:253
-#: ../display/d.legend/main.c:409 ../display/d.legend/main.c:417
-#: ../display/d.histogram/main.c:171 ../display/d.rgb/main.c:99
-#, c-format
-msgid "Color file for <%s> not available"
+#: ../vector/v.rectify/main.c:111
+msgid "Perform 3D transformation"
 msgstr ""
-#: ../raster/r.category/main.c:53 ../vector/v.category/main.c:76
-msgid "category"
+#: ../vector/v.rectify/main.c:115
+msgid "Perform orthogonal 3D transformation"
 msgstr ""
-#: ../raster/r.category/main.c:55
-msgid "Manages category values and labels associated with user-specified raster map layers."
+#: ../vector/v.rectify/main.c:119
+msgid "Print RMS errors"
 msgstr ""
-#: ../raster/r.category/main.c:69
-msgid "Comma separated value list"
+#: ../vector/v.rectify/main.c:120
+msgid "Print RMS errors and exit without rectifying the input map"
 msgstr ""
-#: ../raster/r.category/main.c:70
-msgid "Example: 1.4,3.8,13"
+#: ../vector/v.rectify/main.c:138
+msgid "Please select a group or give an input file."
 msgstr ""
-#: ../raster/r.category/main.c:87
-msgid "File containing category label rules (or \"-\" to read from stdin)"
+#: ../vector/v.rectify/main.c:140
+msgid "Points in group will be ignored, GCPs in input file are used."
 msgstr ""
-#: ../raster/r.category/main.c:95
-msgid "Default label or format string for dynamic labeling"
+#: ../vector/v.rectify/main.c:145 ../imagery/i.rectify/main.c:180
+#, c-format
+msgid "Invalid order (%d); please enter 1 to %d"
 msgstr ""
-#: ../raster/r.category/main.c:97
-msgid "Used when no explicit label exists for the category"
+#: ../vector/v.rectify/main.c:156
+msgid "3D transformation requires a 3D vector"
 msgstr ""
-#: ../raster/r.category/main.c:105
-msgid "Dynamic label coefficients"
+#: ../vector/v.rectify/main.c:159
+msgid "A file with 3D control points is needed for 3D transformation"
 msgstr ""
-#: ../raster/r.category/main.c:107
-msgid "Two pairs of category multiplier and offsets, for $1 and $2"
-msgstr ""
-#: ../raster/r.category/main.c:130 ../raster/r.support/main.c:147
+#: ../vector/v.rectify/main.c:172 ../vector/v.net.salesman/main.c:580
 #, c-format
-msgid "Raster map <%s> not found in current mapset"
+msgid "Unable to open file '%s' for writing"
 msgstr ""
-#: ../raster/r.category/main.c:152
+#: ../vector/v.rectify/main.c:203
 #, c-format
-msgid "Category table for <%s> set from <%s>"
+msgid "The vector map <%s> already exists in"
 msgstr ""
-#: ../raster/r.category/main.c:211
+#: ../vector/v.rectify/main.c:204
+#: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:289
+#: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:298
+#: ../imagery/i.rectify/main.c:278
 #, c-format
-msgid ""
-"Incorrect format of input rules. Check separators. Invalid line is:\n"
-"%s"
+msgid "target LOCATION %s, MAPSET %s:"
 msgstr ""
-#: ../raster/r.category/main.c:267
-#, c-format
-msgid "Unable to read category file of raster map <%s> in <%s>"
+#: ../vector/v.rectify/main.c:206
+msgid "Rectification cancelled."
 msgstr ""
-#: ../raster/r.category/main.c:283
-msgid "The map is floating point! Ignoring cats list, using vals list"
+#: ../vector/v.rectify/main.c:235 ../vector/v.proj/main.c:291
+#: ../vector/v.proj/main.c:417
+msgid "Reading input vector map"
 msgstr ""
-#: ../raster/r.category/main.c:300
-msgid "vals argument is required for floating point map!"
+#: ../vector/v.rectify/cp.c:307 ../vector/v.rectify/cp.c:331
+#, c-format
+msgid "Can not open file <%s>"
 msgstr ""
-#: ../raster/r.category/cats.c:47
+#: ../vector/v.rectify/cp.c:314 ../vector/v.rectify/cp.c:338
 #, c-format
-msgid "Reading <%s> in <%s>"
+msgid "Bad format in control point file <%s>"
 msgstr ""
-#: ../raster/r.composite/main.c:76
-msgid "Combines red, green and blue raster maps into a single composite raster map."
+#: ../vector/v.rectify/cp.c:350 ../imagery/i.rectify/cp.c:12
+#, c-format
+msgid "Control Point file for group <%s@%s> - "
 msgstr ""
-#: ../raster/r.composite/main.c:90 ../raster/r.out.ppm3/main.c:64
-#: ../display/d.rgb/main.c:69
+#: ../vector/v.rectify/cp.c:359 ../imagery/i.rectify/cp.c:47
 #, c-format
-msgid "Name of raster map to be used for <%s>"
-msgstr "Izmantojamās rastra kartes nosaukums priekš <%s>"
+msgid "Not enough active control points for current order, %d are required."
+msgstr ""
-#: ../raster/r.composite/main.c:102
-msgid "Number of levels to be used for each component"
+#: ../vector/v.rectify/cp.c:363
+#: ../imagery/i.ortho.photo/i.ortho.rectify/cp.c:21
+#: ../imagery/i.rectify/cp.c:27 ../imagery/i.rectify/cp.c:51
+msgid "Poorly placed control points."
 msgstr ""
-#: ../raster/r.composite/main.c:103 ../raster/r.composite/main.c:121
-msgid "Levels"
+#: ../vector/v.rectify/cp.c:364
+#: ../imagery/i.ortho.photo/i.ortho.rectify/cp.c:22
+#: ../imagery/i.ortho.photo/i.ortho.rectify/cp.c:27
+#: ../imagery/i.ortho.photo/i.ortho.rectify/cp.c:52
+#: ../imagery/i.ortho.photo/i.ortho.rectify/cp.c:58
+#: ../imagery/i.rectify/cp.c:28 ../imagery/i.rectify/cp.c:52
+msgid " Can not generate the transformation equation."
 msgstr ""
-#: ../raster/r.composite/main.c:118
-#, c-format
-msgid "Number of levels to be used for <%s>"
-msgstr "Izmantojamo līmeņu skaits priekš <%s>"
-#: ../raster/r.composite/main.c:128
-msgid "Dither"
+#: ../vector/v.rectify/cp.c:367
+msgid "Not enough memory to solve for transformation equation"
 msgstr ""
-#: ../raster/r.composite/main.c:132
-msgid "Use closest color"
+#: ../vector/v.rectify/cp.c:370 ../imagery/i.rectify/cp.c:58
+msgid "Invalid order"
 msgstr ""
-#: ../raster/r.composite/main.c:164
-#, c-format
-msgid "Unable to read color file of raster map <%s>"
+#: ../vector/v.proj/main.c:69 ../raster/r.proj/main.c:145
+#: ../raster/r.latlong/main.c:59
+#: ../locale/scriptstrings/m.proj_to_translate.c:3
+#: ../locale/scriptstrings/v.import_to_translate.c:4
+#: ../locale/scriptstrings/r.import_to_translate.c:4
+#: ../general/g.setproj/main.c:79 ../general/g.proj/main.c:65
+msgid "projection"
 msgstr ""
-#: ../raster/r.composite/main.c:191 ../raster/r.random.cells/indep.c:139
-#: ../raster/r.drain/main.c:519 ../raster/r.random.surface/save.c:98
-#: ../imagery/i.ifft/main.c:207
-#, c-format
-msgid "Writing raster map <%s>..."
+#: ../vector/v.proj/main.c:70 ../vector/v.transform/main.c:71
+#: ../raster/r.proj/main.c:146
+#: ../locale/scriptstrings/i.tasscap_to_translate.c:3
+#: ../locale/scriptstrings/m.proj_to_translate.c:4
+#: ../misc/m.transform/main.c:317
+#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:390
+#: ../imagery/i.fft/main.c:79 ../imagery/i.ifft/main.c:78
+#: ../imagery/i.pca/main.c:73
+msgid "transformation"
 msgstr ""
-#: ../raster/r.composite/main.c:262 ../raster/r.li/r.li.daemon/daemon.c:174
-#: ../raster/r.surf.fractal/main.c:85 ../raster/r.surf.random/main.c:66
-#: ../raster/r.circle/main.c:153
-#, c-format
-msgid "Raster map <%s> created."
+#: ../vector/v.proj/main.c:72
+msgid "Re-projects a vector map from one location to the current location."
 msgstr ""
-#: ../raster/r.composite/main.c:286
-msgid "Creating color table for output raster map..."
+#: ../vector/v.proj/main.c:78
+msgid "Location containing input vector map"
 msgstr ""
-#: ../raster/r.spreadpath/main.c:89 ../raster/r.spread/main.c:106
-#: ../raster/r.ros/main.c:213
-msgid "fire"
-msgstr "uguns"
-#: ../raster/r.spreadpath/main.c:90 ../raster/r.walk/main.c:180
-#: ../raster/r.cost/main.c:142
-msgid "cumulative costs"
+#: ../vector/v.proj/main.c:82
+msgid "Mapset containing input vector map"
 msgstr ""
-#: ../raster/r.spreadpath/main.c:92
-msgid "Recursively traces the least cost path backwards to cells from which the cumulative cost was determined."
+#: ../vector/v.proj/main.c:83 ../raster/r.proj/main.c:158
+msgid "Default: name of current mapset"
 msgstr ""
-#: ../raster/r.spreadpath/main.c:98
-msgid "Name of raster map containing back-path easting information"
+#: ../vector/v.proj/main.c:88
+msgid "Name of input vector map to re-project"
 msgstr ""
-#: ../raster/r.spreadpath/main.c:103
-msgid "Name of raster map containing back-path northing information"
+#: ../vector/v.proj/main.c:93 ../raster/r.proj/main.c:167
+msgid "Path to GRASS database of input location"
 msgstr ""
-#: ../raster/r.spreadpath/main.c:108
-msgid "The map E and N grid coordinates of starting points"
+#: ../vector/v.proj/main.c:100
+msgid "Maximum segment length in meters in output vector map"
 msgstr ""
-#: ../raster/r.spreadpath/main.c:161
-#, c-format
-msgid "eading the input map -%s- and -%s- and creating some temporary files..."
+#: ../vector/v.proj/main.c:101
+msgid "Increases accuracy of reprojected shapes, disable with smax=0"
 msgstr ""
-#: ../raster/r.spreadpath/main.c:281
-msgid "Finding the least cost paths ..."
+#: ../vector/v.proj/main.c:102 ../vector/v.proj/main.c:107
+#: ../vector/v.proj/main.c:119 ../vector/v.proj/main.c:126
+#: ../raster/r.proj/main.c:172 ../raster/r.proj/main.c:183
+#: ../raster/r.proj/main.c:199
+msgid "Target"
 msgstr ""
-#: ../raster/r.spreadpath/main.c:296
-#, c-format
-msgid "Writing the output map  -%s-..."
+#: ../vector/v.proj/main.c:106
+#: ../locale/scriptstrings/v.import_to_translate.c:9
+msgid "Name for output vector map (default: input)"
 msgstr ""
-#: ../raster/r.describe/main.c:57
-msgid "Prints terse list of category values found in a raster map layer."
+#: ../vector/v.proj/main.c:111
+msgid "List vector maps in input mapset and exit"
 msgstr ""
-#: ../raster/r.describe/main.c:71
-msgid "Number of quantization steps"
+#: ../vector/v.proj/main.c:115
+msgid "3D vector maps only"
 msgstr ""
-#: ../raster/r.describe/main.c:77
-msgid "Print the output one value per line"
+#: ../vector/v.proj/main.c:117
+msgid "Assume z coordinate is ellipsoidal height and transform if possible"
 msgstr ""
-#: ../raster/r.describe/main.c:81
-msgid "Only print the range of the data"
+#: ../vector/v.proj/main.c:123
+msgid "Latlon output only, default is -180,180"
 msgstr ""
-#: ../raster/r.describe/main.c:85
-msgid "Suppress reporting of any NULLs"
+#: ../vector/v.proj/main.c:125
+msgid "Disable wrapping to -180,180 for latlon output"
 msgstr ""
-#: ../raster/r.describe/main.c:89
-msgid "Use the current region"
+#: ../vector/v.proj/main.c:130 ../raster/r.to.vect/main.c:117
+#: ../locale/scriptstrings/t.rast.to.vect_to_translate.c:18
+msgid "Do not build vector topology"
 msgstr ""
-#: ../raster/r.describe/main.c:93
-msgid "Read floating-point map as integer"
+#: ../vector/v.proj/main.c:131
+msgid "Recommended for massive point projection"
 msgstr ""
-#: ../raster/r.describe/main.c:105
-#, c-format
-msgid "%s = %s -- must be greater than zero"
+#: ../vector/v.proj/main.c:165 ../raster/r.proj/main.c:252
+msgid "Input and output locations can not be the same"
 msgstr ""
-#: ../raster/r.describe/describe.c:94
+#: ../vector/v.proj/main.c:189 ../raster/r.proj/main.c:288
 #, c-format
-msgid "Reading <%s> ..."
+msgid "Checking location <%s> mapset <%s>"
 msgstr ""
-#: ../raster/r.surf.contour/main.c:64
-msgid "Generates surface raster map from rasterized contours."
+#: ../vector/v.proj/main.c:200
+msgid "No vector maps found"
 msgstr ""
-#: ../raster/r.surf.contour/main.c:67
-msgid "Name of input raster map containing contours"
+#: ../vector/v.proj/main.c:213
+#, c-format
+msgid "Vector map <%s> in location <%s> mapset <%s> not found"
 msgstr ""
-#: ../raster/r.in.mat/main.c:94
-msgid "Imports a binary MAT-File(v4) to a GRASS raster."
+#: ../vector/v.proj/main.c:243
+#, c-format
+msgid "Mapset <%s> in input location <%s> - permission denied"
 msgstr ""
-#: ../raster/r.in.mat/main.c:101
-msgid "Name of input MAT-File(v4)"
+#: ../vector/v.proj/main.c:246
+#, c-format
+msgid "Mapset <%s> in input location <%s> not found"
 msgstr ""
-#: ../raster/r.in.mat/main.c:105
-msgid "Name for output raster map (override)"
+#: ../vector/v.proj/main.c:314
+#, c-format
+msgid "Input vector map <%s> is empty"
 msgstr ""
-#: ../raster/r.in.mat/main.c:149
-msgid "Reading MAT-File..."
+#: ../vector/v.proj/main.c:322 ../vector/v.proj/main.c:333
+#: ../vector/v.proj/main.c:348 ../vector/v.proj/main.c:363
+msgid "Error in pj_do_transform"
 msgstr ""
-#: ../raster/r.in.mat/main.c:175
-msgid "Array contains no data"
+#: ../vector/v.proj/main.c:408
+msgid "Reprojecting primitives ..."
 msgstr ""
-#: ../raster/r.in.mat/main.c:180
-msgid "Array contains imaginary data"
+#: ../vector/v.proj/main.c:445 ../vector/v.proj/main.c:452
+#: ../vector/v.proj/main.c:478 ../vector/v.proj/main.c:492
+#, c-format
+msgid "Unable to re-project vector map <%s> from <%s>"
 msgstr ""
-#: ../raster/r.in.mat/main.c:186
-msgid "Invalid array name"
+#: ../vector/v.proj/main.c:512
+msgid "Try to disable wrapping to -180,180 if topological errors occurred"
 msgstr ""
-#: ../raster/r.in.mat/main.c:206
-msgid "Invalid 'map_name' array"
+#: ../vector/v.split/main.c:56
+msgid "densification"
 msgstr ""
-#: ../raster/r.in.mat/main.c:216
-msgid "Error reading 'map_name' array"
+#: ../vector/v.split/main.c:60
+msgid "Splits vector lines to shorter segments."
 msgstr ""
-#: ../raster/r.in.mat/main.c:227
-msgid "Invalid 'map_northern_edge' array"
+#: ../vector/v.split/main.c:73
+msgid "Maximum segment length"
 msgstr ""
-#: ../raster/r.in.mat/main.c:236
-msgid "Invalid 'map_southern_edge' array"
+#: ../vector/v.split/main.c:82
+msgid "Length units"
 msgstr ""
-#: ../raster/r.in.mat/main.c:245
-msgid "Invalid 'map_eastern_edge' array"
+#: ../vector/v.split/main.c:89
+msgid "Maximum number of vertices in segment"
 msgstr ""
-#: ../raster/r.in.mat/main.c:254
-msgid "Invalid 'map_western_edge' array"
+#: ../vector/v.split/main.c:93
+msgid "Add new vertices, but do not split"
 msgstr ""
-#: ../raster/r.in.mat/main.c:262
-msgid "Invalid 'map_title' array"
+#: ../vector/v.split/main.c:94 ../vector/v.split/main.c:99
+msgid "Applies only to 'length' option"
 msgstr ""
-#: ../raster/r.in.mat/main.c:272
-msgid "Error reading 'map_title' array"
+#: ../vector/v.split/main.c:98
+msgid "Force segments to be exactly of given length, except for last one"
 msgstr ""
-#: ../raster/r.in.mat/main.c:285
-msgid "Invalid 'map_data' array"
+#: ../vector/v.split/main.c:108
+msgid "Use either length or vertices"
 msgstr ""
-#: ../raster/r.in.mat/main.c:311 ../raster/r.in.mat/main.c:443
-#: ../raster/r.in.mat/main.c:522
-msgid "Please contact the GRASS development team"
+#: ../vector/v.split/main.c:115
+#, c-format
+msgid "Length must be positive but is %g"
 msgstr ""
-#: ../raster/r.in.mat/main.c:316
+#: ../vector/v.split/main.c:131
 #, c-format
-msgid "Skipping unknown array '%s'"
+msgid "Unknown unit %s"
 msgstr ""
-#: ../raster/r.in.mat/main.c:344
-#, c-format
-msgid "No 'map_data' array found in <%s>"
+#: ../vector/v.split/main.c:149
+msgid "Can not get projection units"
 msgstr ""
-#: ../raster/r.in.mat/main.c:351
+#: ../vector/v.split/main.c:156
 #, c-format
-msgid "Setting map name to <%s> which overrides <%s>"
+msgid "Length in map units: %g"
 msgstr ""
-#: ../raster/r.in.mat/main.c:358
+#: ../vector/v.split/main.c:158
 #, c-format
-msgid "Setting map name to <%s>"
+msgid "Length in meters: %g"
 msgstr ""
-#: ../raster/r.in.mat/main.c:362
-msgid "No 'map_name' array found; using <MatFile>"
+#: ../vector/v.split/main.c:164
+msgid "Number of vertices must be at least 2"
 msgstr ""
-#: ../raster/r.in.mat/main.c:373
-msgid "Missing bound"
-msgstr ""
-#: ../raster/r.in.mat/main.c:377
-msgid "Using default bounds"
-msgstr ""
-#: ../raster/r.in.mat/main.c:391
+#: ../vector/v.split/main.c:250
 #, c-format
-msgid "Map <%s> bounds set to:"
+msgid "Unable to make line segment: %f - %f (line length = %f)"
 msgstr ""
-#: ../raster/r.in.mat/main.c:392 ../raster/r.out.mat/main.c:174
-#, c-format
-msgid "northern edge=%f"
+#: ../vector/v.to.rast/vect2rast.c:36
+msgid "Loading data..."
 msgstr ""
-#: ../raster/r.in.mat/main.c:393 ../raster/r.out.mat/main.c:175
+#: ../vector/v.to.rast/vect2rast.c:48 ../vector/v.colors/main.c:266
+#: ../raster3d/r3.flow/main.c:414
 #, c-format
-msgid "southern edge=%f"
+msgid "Vector map <%s> is not 3D"
 msgstr ""
-#: ../raster/r.in.mat/main.c:394 ../raster/r.out.mat/main.c:176
-#, c-format
-msgid "eastern edge=%f"
+#: ../vector/v.to.rast/vect2rast.c:69 ../vector/v.to.rast/support.c:308
+#: ../vector/v.to.rast/support.c:547 ../vector/v.what.rast3/main.c:141
+#: ../scripts/v.db.update/v.db.update.py:98
+#: ../scripts/v.dissolve/v.dissolve.py:85
+#, c-format, python-format
+msgid "Column <%s> not found"
 msgstr ""
-#: ../raster/r.in.mat/main.c:395 ../raster/r.out.mat/main.c:177
+#: ../vector/v.to.rast/vect2rast.c:74
 #, c-format
-msgid "western edge=%f"
+msgid "Column type (%s) not supported (did you mean 'labelcolumn'?)"
 msgstr ""
-#: ../raster/r.in.mat/main.c:396 ../raster/r.out.mat/main.c:178
+#: ../vector/v.to.rast/vect2rast.c:104
 #, c-format
-msgid "nsres=%f"
+msgid "Unable to use column <%s>"
 msgstr ""
-#: ../raster/r.in.mat/main.c:397 ../raster/r.out.mat/main.c:179
+#: ../vector/v.to.rast/vect2rast.c:122 ../vector/v.to.rast/support.c:652
 #, c-format
-msgid "ewres=%f"
+msgid "Unknown use type: %d"
 msgstr ""
-#: ../raster/r.in.mat/main.c:408
-msgid "Writing new raster map..."
-msgstr ""
-#: ../raster/r.sunhours/solpos00.c:994 ../raster/r.sunmask/solpos00.c:950
+#: ../vector/v.to.rast/vect2rast.c:131
 #, c-format
-msgid "S_decode ==> Please fix the year: %d [1950-2050]"
+msgid "No areas selected from vector map <%s>"
 msgstr ""
-#: ../raster/r.sunhours/solpos00.c:997 ../raster/r.sunmask/solpos00.c:953
-#, c-format
-msgid "S_decode ==> Please fix the month: %d"
+#: ../vector/v.to.rast/vect2rast.c:137
+msgid ""
+"Area conversion and line densification are mutually exclusive, disabling "
+"line densification."
 msgstr ""
-#: ../raster/r.sunhours/solpos00.c:999 ../raster/r.sunmask/solpos00.c:955
+#: ../vector/v.to.rast/vect2rast.c:152
 #, c-format
-msgid "S_decode ==> Please fix the day-of-month: %d"
+msgid "Pass %d of %d:"
 msgstr ""
-#: ../raster/r.sunhours/solpos00.c:1002 ../raster/r.sunmask/solpos00.c:958
+#: ../vector/v.to.rast/vect2rast.c:160
 #, c-format
-msgid "S_decode ==> Please fix the day-of-year: %d"
+msgid "Problem processing areas from vector map <%s>, continuing..."
 msgstr ""
-#: ../raster/r.sunhours/solpos00.c:1005 ../raster/r.sunmask/solpos00.c:961
+#: ../vector/v.to.rast/vect2rast.c:172
 #, c-format
-msgid "S_decode ==> Please fix the hour: %d"
+msgid "Problem processing lines from vector map <%s>, continuing..."
 msgstr ""
-#: ../raster/r.sunhours/solpos00.c:1007 ../raster/r.sunmask/solpos00.c:963
-#, c-format
-msgid "S_decode ==> Please fix the minute: %d"
+#: ../vector/v.to.rast/vect2rast.c:179 ../raster/r.in.poly/poly2rast.c:81
+#: ../raster/r.carve/raster.c:33
+msgid "Writing raster map..."
 msgstr ""
-#: ../raster/r.sunhours/solpos00.c:1009 ../raster/r.sunmask/solpos00.c:965
-#, c-format
-msgid "S_decode ==> Please fix the second: %d"
+#: ../vector/v.to.rast/vect2rast.c:197
+msgid "Creating support files for raster map..."
 msgstr ""
-#: ../raster/r.sunhours/solpos00.c:1011 ../raster/r.sunmask/solpos00.c:967
-#, c-format
-msgid "S_decode ==> Please fix the time zone: %f"
+#: ../vector/v.to.rast/vect2rast.c:204
+msgid "Color can be updated from database only if use=attr"
 msgstr ""
-#: ../raster/r.sunhours/solpos00.c:1014 ../raster/r.sunmask/solpos00.c:970
+#: ../vector/v.to.rast/vect2rast.c:224
 #, c-format
-msgid "S_decode ==> Please fix the interval: %d"
+msgid "Converted areas: %d of %d"
 msgstr ""
-#: ../raster/r.sunhours/solpos00.c:1017 ../raster/r.sunmask/solpos00.c:973
+#: ../vector/v.to.rast/vect2rast.c:231
 #, c-format
-msgid "S_decode ==> Please fix the latitude: %f"
+msgid "Converted points/lines: %d of %d"
 msgstr ""
-#: ../raster/r.sunhours/solpos00.c:1020 ../raster/r.sunmask/solpos00.c:976
+#: ../vector/v.to.rast/support.c:119 ../vector/v.to.rast/support.c:291
+#: ../vector/v.to.rast/support.c:530
 #, c-format
-msgid "S_decode ==> Please fix the longitude: %f"
+msgid "Unknown column <%s> in table <%s>"
 msgstr ""
-#: ../raster/r.sunhours/solpos00.c:1023 ../raster/r.sunmask/solpos00.c:979
-#, c-format
-msgid "S_decode ==> Please fix the temperature: %f"
+#: ../vector/v.to.rast/support.c:140 ../vector/v.to.rast/support.c:320
+msgid "No records selected"
 msgstr ""
-#: ../raster/r.sunhours/solpos00.c:1026 ../raster/r.sunmask/solpos00.c:982
+#: ../vector/v.to.rast/support.c:153
 #, c-format
-msgid "S_decode ==> Please fix the pressure: %f"
+msgid "Error in color definition column (%s) with cat %d: colorstring [%s]"
 msgstr ""
-#: ../raster/r.sunhours/solpos00.c:1028 ../raster/r.sunmask/solpos00.c:984
-#, c-format
-msgid "S_decode ==> Please fix the tilt: %f"
+#: ../vector/v.to.rast/support.c:156
+msgid "Color set to [200:200:200]"
 msgstr ""
-#: ../raster/r.sunhours/solpos00.c:1030 ../raster/r.sunmask/solpos00.c:986
+#: ../vector/v.to.rast/support.c:161
 #, c-format
-msgid "S_decode ==> Please fix the aspect: %f"
+msgid "Error in color definition column (%s), with cat %d"
 msgstr ""
-#: ../raster/r.sunhours/solpos00.c:1032 ../raster/r.sunmask/solpos00.c:988
-#, c-format
-msgid "S_decode ==> Please fix the shadowband width: %f"
+#: ../vector/v.to.rast/support.c:263
+msgid "Label column was not specified, no labels will be written"
 msgstr ""
-#: ../raster/r.sunhours/solpos00.c:1035 ../raster/r.sunmask/solpos00.c:991
+#: ../vector/v.to.rast/support.c:343 ../vector/v.to.rast/support.c:576
 #, c-format
-msgid "S_decode ==> Please fix the shadowband radius: %f"
+msgid "Column type (%s) not supported"
 msgstr ""
-#: ../raster/r.sunhours/solpos00.c:1038 ../raster/r.sunmask/solpos00.c:994
-#, c-format
-msgid "S_decode ==> Please fix the shadowband sky factor: %f"
+#: ../vector/v.to.rast/support.c:392 ../vector/v.to.rast/support.c:433
+msgid "Different labels for the same value are not supported"
 msgstr ""
-#: ../raster/r.sunhours/main.c:73 ../raster/r.sun/main.c:240
-#: ../raster/r.horizon/main.c:181 ../raster/r.sunmask/main.c:117
-msgid "solar"
+#: ../vector/v.to.rast/main.c:45 ../vector/v.to.rast3/main.c:49
+#: ../raster/r.to.vect/main.c:77 ../raster/r.to.rast3elev/main.c:362
+#: ../raster/r.in.lidar/main.c:112 ../raster/r.to.rast3/main.c:198
+#: ../raster/r.in.xyz/main.c:161 ../raster/r.in.ascii/main.c:71
+#: ../locale/scriptstrings/t.rast.to.rast3_to_translate.c:3
+#: ../locale/scriptstrings/t.rast.to.vect_to_translate.c:3
+#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:7
+#: ../locale/scriptstrings/r.out.xyz_to_translate.c:5
+#: ../raster3d/r3.in.lidar/main.c:166 ../raster3d/r3.in.ascii/main.c:357
+#: ../raster3d/r3.to.rast/main.c:260 ../raster3d/r3.out.ascii/main.c:305
+msgid "conversion"
 msgstr ""
-#: ../raster/r.sunhours/main.c:74 ../raster/r.sun/main.c:241
-msgid "sun energy"
+#: ../vector/v.to.rast/main.c:47
+msgid "rasterization"
 msgstr ""
-#: ../raster/r.sunhours/main.c:75 ../raster/r.horizon/main.c:182
-#: ../raster/r.sunmask/main.c:118
-msgid "sun position"
+#: ../vector/v.to.rast/main.c:48
+msgid "Converts (rasterize) a vector map into a raster map."
 msgstr ""
-#: ../raster/r.sunhours/main.c:76
-msgid "Calculates solar elevation, solar azimuth, and sun hours."
+#: ../vector/v.to.rast/main.c:73
+msgid "Source of raster values"
 msgstr ""
-#: ../raster/r.sunhours/main.c:77
-msgid "Solar elevation: the angle between the direction of the geometric center of the sun's apparent disk and the (idealized) horizon. Solar azimuth: the angle from due north in clockwise direction."
+#: ../vector/v.to.rast/main.c:77
+msgid "read values from attribute table"
 msgstr ""
-#: ../raster/r.sunhours/main.c:83
-msgid "Output raster map with solar elevation angle"
+#: ../vector/v.to.rast/main.c:78 ../vector/v.colors/main.c:74
+msgid "use category values"
 msgstr ""
-#: ../raster/r.sunhours/main.c:88
-msgid "Output raster map with solar azimuth angle"
+#: ../vector/v.to.rast/main.c:79
+msgid "use value specified by value option"
 msgstr ""
-#: ../raster/r.sunhours/main.c:93
-msgid "Output raster map with sunshine hours"
+#: ../vector/v.to.rast/main.c:80
+msgid "use z coordinate (points or contours only)"
 msgstr ""
-#: ../raster/r.sunhours/main.c:94
-msgid "Sunshine hours require SOLPOS use and Greenwich standard time"
+#: ../vector/v.to.rast/main.c:81
+msgid "line direction in degrees CCW from east (lines only)"
 msgstr ""
-#: ../raster/r.sunhours/main.c:101
-msgid "Year"
-msgstr "Gads"
-#: ../raster/r.sunhours/main.c:103 ../raster/r.sunhours/main.c:112
-#: ../raster/r.sunhours/main.c:120 ../raster/r.sunhours/main.c:129
-#: ../raster/r.sunhours/main.c:138 ../raster/r.sunhours/main.c:147
-#: ../raster/r.sun/main.c:444 ../raster/r.sun/main.c:453
-#: ../raster/r.sun/main.c:470 ../raster/r.sun/main.c:508
-#: ../raster/r.sunmask/main.c:153 ../raster/r.sunmask/main.c:161
-#: ../raster/r.sunmask/main.c:169 ../raster/r.sunmask/main.c:177
-#: ../raster/r.sunmask/main.c:185 ../raster/r.sunmask/main.c:194
-#: ../raster/r.sunmask/main.c:203 ../imagery/i.landsat.toar/main.c:207
-msgid "Time"
+#: ../vector/v.to.rast/main.c:87
+msgid "Name of column for 'attr' parameter (data type must be numeric)"
 msgstr ""
-#: ../raster/r.sunhours/main.c:109
-msgid "Month"
-msgstr "Mēnesis"
-#: ../raster/r.sunhours/main.c:110
-msgid "If not given, day is interpreted as day of the year"
+#: ../vector/v.to.rast/main.c:93
+msgid "Name of color definition column (with RRR:GGG:BBB entries)"
 msgstr ""
-#: ../raster/r.sunhours/main.c:118
-msgid "Day"
-msgstr "Diena"
-#: ../raster/r.sunhours/main.c:126
-msgid "Hour"
+#: ../vector/v.to.rast/main.c:99
+msgid "Name of column used as raster category labels"
 msgstr ""
-#: ../raster/r.sunhours/main.c:135
-msgid "Minutes"
+#: ../vector/v.to.rast/main.c:108
+msgid "Raster value (for use=val)"
 msgstr ""
-#: ../raster/r.sunhours/main.c:144
-msgid "Seconds"
+#: ../vector/v.to.rast/main.c:121
+#: ../locale/scriptstrings/v.rast.stats_to_translate.c:10
+msgid "Create densified lines (default: thin lines)"
 msgstr ""
-#: ../raster/r.sunhours/main.c:151
-msgid "Time is local sidereal time, not Greenwich standard time"
+#: ../vector/v.to.rast/main.c:122
+#: ../locale/scriptstrings/v.rast.stats_to_translate.c:11
+msgid ""
+"All cells touched by the line will be set, not only those on the render path"
 msgstr ""
-#: ../raster/r.sunhours/main.c:155
-msgid "Do not use SOLPOS algorithm of NREL"
+#: ../vector/v.to.rast/main.c:132
+#, c-format
+msgid "Cache size must be at least 1 MiB, changing %d to 1"
 msgstr ""
-#: ../raster/r.sunhours/main.c:167
-msgid "No output requested, exiting."
+#: ../vector/v.to.rast/main.c:141
+msgid "Column parameter missing (or use value parameter)"
 msgstr ""
-#: ../raster/r.sunhours/main.c:193
-msgid "NREL SOLPOS algorithm uses Greenwich standard time."
+#: ../vector/v.to.rast/main.c:146
+msgid "Column parameter cannot be combined with use of category values option"
 msgstr ""
-#: ../raster/r.sunhours/main.c:194 ../raster/r.sunhours/main.c:202
-msgid "Time will be interpreted as Greenwich standard time."
+#: ../vector/v.to.rast/main.c:151
+msgid "Column parameter cannot be combined with use of value option"
 msgstr ""
-#: ../raster/r.sunhours/main.c:200
-msgid "Time will be interpreted as local sidereal time."
+#: ../vector/v.to.rast/main.c:156
+msgid "Column parameter cannot be combined with use of z coordinate"
 msgstr ""
-#: ../raster/r.sunhours/main.c:205
-msgid "Sunshine hours require NREL SOLPOS."
+#: ../vector/v.to.rast/main.c:162
+#, c-format
+msgid "Unknown option '%s'"
 msgstr ""
-#: ../raster/r.sunhours/main.c:210
-msgid "Current projection is x,y (undefined)."
-msgstr ""
+#: ../vector/v.to.rast/do_lines.c:59 ../vector/v.to.rast/do_lines.c:67
+#: ../vector/v.to.rast3/main.c:145
+#, c-format
+msgid "No record for line (cat = %d)"
+msgstr "Nav ieraksta priekš līnijas (cat= %d)"
-#: ../raster/r.sunhours/main.c:216
-msgid "Cannot get projection info of current location"
+#: ../vector/v.to.rast/do_lines.c:73 ../vector/v.to.rast/do_areas.c:64
+msgid "Unable to use column specified"
 msgstr ""
-#: ../raster/r.sunhours/main.c:219
-msgid "Cannot get projection units of current location"
+#: ../vector/v.to.rast/do_lines.c:133
+#, c-format
+msgid "%d lines with varying height were not written to raster"
 msgstr ""
-#: ../raster/r.sunhours/main.c:222
-msgid "Cannot get projection key values of current location"
+#: ../vector/v.to.rast/do_areas.c:50 ../vector/v.to.rast/do_areas.c:58
+#, c-format
+msgid "No record for area (cat = %d)"
 msgstr ""
-#: ../raster/r.sunhours/main.c:324 ../raster/r.sunhours/main.c:335
-#: ../raster/r.sunhours/main.c:346 ../raster/r.mapcalc/map3.c:606
-#: ../imagery/i.landsat.toar/main.c:567
-#: ../imagery/i.landsat.acca/algorithm.c:234
-#: ../imagery/i.landsat.acca/algorithm.c:388
-#: ../imagery/i.landsat.acca/tools.c:136
+#: ../vector/v.to.rast/do_areas.c:79
 #, c-format
-msgid "Unable to create raster map <%s>"
+msgid "Get area %d failed"
 msgstr ""
-#: ../raster/r.sunhours/main.c:356
-msgid "Calculating solar elevation and azimuth..."
+#: ../vector/v.to.rast/do_areas.c:84
+msgid "Failed to plot polygon"
 msgstr ""
-#: ../raster/r.sunhours/main.c:359
-msgid "Calculating solar elevation..."
+#: ../vector/v.to.rast/do_areas.c:118
+msgid "Area without centroid (OK for island)"
 msgstr ""
-#: ../raster/r.sunhours/main.c:362
-msgid "Calculating solar azimuth..."
+#: ../vector/v.to.rast/do_areas.c:128
+msgid "Area centroid without category"
 msgstr ""
-#: ../raster/r.what.color/main.c:91
-msgid "Queries colors for a raster map layer."
+#: ../vector/v.net.distance/main.c:69
+msgid ""
+"Computes shortest distance via the network between the given sets of "
+"features."
 msgstr ""
-#: ../raster/r.what.color/main.c:99
-msgid "Name of existing raster map to query colors"
+#: ../vector/v.net.distance/main.c:72
+msgid ""
+"Finds the shortest paths from each 'from' point to the nearest 'to' feature "
+"and various information about this relation are uploaded to the attribute "
+"table."
 msgstr ""
-#: ../raster/r.what.color/main.c:106
-msgid "Values to query colors for"
+#: ../vector/v.net.distance/main.c:100
+msgid "From layer number or name"
 msgstr ""
-#: ../raster/r.what.color/main.c:113
-msgid "Output format (printf-style)"
+#: ../vector/v.net.distance/main.c:105
+msgid "From category values"
 msgstr ""
-#: ../raster/r.what.color/main.c:117
-msgid "Read values from stdin"
+#: ../vector/v.net.distance/main.c:111
+msgid "From WHERE conditions of SQL statement without 'where' keyword"
 msgstr ""
-#: ../raster/r.what.color/main.c:123
-msgid "Either \"-i\" or \"value=\" must be given"
+#: ../vector/v.net.distance/main.c:116
+msgid "To layer number or name"
 msgstr ""
-#: ../raster/r.resamp.rst/main.c:151
-msgid "Reinterpolates and optionally computes topographic analysis from input raster map to a new raster map (possibly with different resolution) using regularized spline with tension and smoothing."
+#: ../vector/v.net.distance/main.c:123
+msgid "To feature type"
 msgstr ""
-#: ../raster/r.resamp.rst/main.c:162
-msgid "Desired east-west resolution"
-msgstr "Vēlamā austrumi-rietumi izšķirtspēja"
-#: ../raster/r.resamp.rst/main.c:168
-msgid "Desired north-south resolution"
-msgstr "Vēlamā ziemeļi-dienvidi izšķirtspēja"
-#: ../raster/r.resamp.rst/main.c:173
-msgid "Name for output elevation raster map"
+#: ../vector/v.net.distance/main.c:128
+msgid "To category values"
 msgstr ""
-#: ../raster/r.resamp.rst/main.c:179
-msgid "Name for output slope map (or fx)"
+#: ../vector/v.net.distance/main.c:134
+msgid "To WHERE conditions of SQL statement without 'where' keyword"
 msgstr ""
-#: ../raster/r.resamp.rst/main.c:185
-msgid "Name for output aspect map (or fy)"
+#: ../vector/v.net.distance/main.c:169
+msgid "Write each output path as one line, not as original input segments."
 msgstr ""
-#: ../raster/r.resamp.rst/main.c:191
-msgid "Name for output profile curvature map (or fxx)"
+#: ../vector/v.net.distance/main.c:244
+#, c-format
+msgid "No 'from' features selected. Please check options '%s', '%s', '%s'."
 msgstr ""
-#: ../raster/r.resamp.rst/main.c:197
-msgid "Name for output tangential curvature map (or fyy)"
+#: ../vector/v.net.distance/main.c:251
+#, c-format
+msgid "No 'to' features selected. Please check options '%s', '%s', '%s'."
 msgstr ""
-#: ../raster/r.resamp.rst/main.c:203
-msgid "Name for output mean curvature map (or fxy)"
+#: ../vector/v.net.distance/main.c:260
+msgid "No 'to' features"
 msgstr ""
-#: ../raster/r.resamp.rst/main.c:209
-msgid "Name of input raster map containing smoothing"
+#: ../vector/v.net.distance/main.c:268
+msgid "Distances to 'to' features ..."
 msgstr ""
-#: ../raster/r.resamp.rst/main.c:215
-msgid "Name of input raster map to be used as mask"
+#: ../vector/v.net.distance/main.c:307
+msgid "Tracing paths from 'from' features ..."
 msgstr ""
-#: ../raster/r.resamp.rst/main.c:223
-msgid "Rows/columns overlap for segmentation"
-msgstr ""
+#: ../vector/v.net.distance/main.c:423
+#, c-format
+msgid "%d 'from' feature was not reachable"
+msgid_plural "%d 'from' features were not reachable"
+msgstr[0] ""
+msgstr[1] ""
+msgstr[2] ""
-#: ../raster/r.resamp.rst/main.c:231
-msgid "Multiplier for z-values"
+#: ../vector/v.net.spanningtree/main.c:48
+msgid "spanning tree"
 msgstr ""
-#: ../raster/r.resamp.rst/main.c:239
-msgid "Spline tension value"
+#: ../vector/v.net.spanningtree/main.c:50
+msgid "Computes minimum spanning tree for the network."
 msgstr ""
-#: ../raster/r.resamp.rst/main.c:246 ../vector/v.surf.rst/main.c:340
-msgid "Anisotropy angle (in degrees counterclockwise from East)"
+#: ../vector/v.transform/main.c:75
+msgid ""
+"Performs an affine transformation (shift, scale and rotate) on vector map."
 msgstr ""
-#: ../raster/r.resamp.rst/main.c:247 ../raster/r.resamp.rst/main.c:254
-msgid "Anisotropy"
+#: ../vector/v.transform/main.c:80
+msgid "Shift all z values to bottom=0"
 msgstr ""
-#: ../raster/r.resamp.rst/main.c:253 ../vector/v.surf.rst/main.c:347
-msgid "Anisotropy scaling factor"
+#: ../vector/v.transform/main.c:85
+msgid "Swap coordinates x, y and then apply other parameters"
 msgstr ""
-#: ../raster/r.resamp.rst/main.c:258
-msgid "Use dnorm independent tension"
+#: ../vector/v.transform/main.c:90
+msgid "Swap coordinates x, z and then apply other parameters"
 msgstr ""
-#: ../raster/r.resamp.rst/main.c:263 ../vector/v.surf.rst/main.c:171
-msgid "Output partial derivatives instead of topographic parameters"
+#: ../vector/v.transform/main.c:95
+msgid "Swap coordinates y, z and then apply other parameters"
 msgstr ""
-#: ../raster/r.resamp.rst/main.c:297
-msgid "Unable to read ew_res value"
-msgstr ""
+#: ../vector/v.transform/main.c:100
+#, fuzzy
+msgid "Swap coordinates after the other transformations"
+msgstr "Vienu koordinātu pāri uz līniju, lūdzu"
-#: ../raster/r.resamp.rst/main.c:300
-msgid "Unable to read ns_res value"
+#: ../vector/v.transform/main.c:104
+msgid "Do not build topology"
 msgstr ""
-#: ../raster/r.resamp.rst/main.c:303
-msgid "Invalid value for tension"
+#: ../vector/v.transform/main.c:109 ../vector/v.transform/main.c:120
+#: ../vector/v.transform/main.c:129 ../vector/v.transform/main.c:138
+#: ../vector/v.transform/main.c:147 ../vector/v.transform/main.c:156
+#: ../vector/v.transform/main.c:165 ../vector/v.transform/main.c:175
+#: ../vector/v.transform/main.c:182
+msgid "Custom"
 msgstr ""
-#: ../raster/r.resamp.rst/main.c:306
-msgid "Invalid value for zmult"
+#: ../vector/v.transform/main.c:118
+msgid "Shifting value for x coordinates"
 msgstr ""
-#: ../raster/r.resamp.rst/main.c:309
-msgid "Invalid value for overlap"
+#: ../vector/v.transform/main.c:127
+msgid "Shifting value for y coordinates"
 msgstr ""
-#: ../raster/r.resamp.rst/main.c:313
-msgid "Invalid value for theta"
+#: ../vector/v.transform/main.c:136 ../vector/v.extrude/main.c:101
+msgid "Shifting value for z coordinates"
 msgstr ""
-#: ../raster/r.resamp.rst/main.c:317
-msgid "Invalid value for scalex"
+#: ../vector/v.transform/main.c:145
+msgid "Scaling factor for x coordinates"
 msgstr ""
-#: ../raster/r.resamp.rst/main.c:319
-msgid "When using anisotropy both theta and scalex must be specified"
+#: ../vector/v.transform/main.c:154
+msgid "Scaling factor for y coordinates"
 msgstr ""
-#: ../raster/r.resamp.rst/main.c:357
-#, c-format
-msgid "Map <%s> is the wrong resolution"
+#: ../vector/v.transform/main.c:163
+msgid "Scaling factor for z coordinates"
 msgstr ""
-#: ../raster/r.resamp.rst/main.c:365
-msgid "Smoothing values can not be negative or NULL"
+#: ../vector/v.transform/main.c:173
+msgid "Rotation around z axis in degrees (counter-clockwise)"
 msgstr ""
-#: ../raster/r.resamp.rst/main.c:371
-msgid "Input map resolution differs from current region resolution!"
+#: ../vector/v.transform/main.c:179
+msgid "Name of attribute column(s) used as transformation parameters"
 msgstr ""
-#: ../raster/r.resamp.rst/main.c:387
-msgid "Processing all selected output files will require"
+#: ../vector/v.transform/main.c:181
+msgid "Format: parameter:column, e.g. xshift:xs,yshift:ys,zrot:zr"
 msgstr ""
-#: ../raster/r.resamp.rst/main.c:391
+#: ../vector/v.transform/main.c:201
 #, c-format
-msgid "%.2f GB of disk space for temp files."
+msgid "Columns require a valid layer. Please use '%s' parameter."
 msgstr ""
-#: ../raster/r.resamp.rst/main.c:394
+#: ../vector/v.transform/main.c:231
 #, c-format
-msgid "%.2f MB of disk space for temp files."
+msgid "Unknown column parameter '%s'"
 msgstr ""
-#: ../raster/r.resamp.rst/main.c:397
+#: ../vector/v.transform/main.c:242
 #, c-format
-msgid "%.2f KB of disk space for temp files."
+msgid "Unable to tokenize column string: [%s]"
 msgstr ""
-#: ../raster/r.resamp.rst/main.c:400
+#: ../vector/v.transform/main.c:310
 #, c-format
-msgid "%d byte of disk space for temp files."
-msgid_plural "%d bytes of disk space for temp files."
-msgstr[0] ""
-msgstr[1] ""
-msgstr[2] ""
-#: ../raster/r.resamp.rst/main.c:436
-msgid "Maximum value of a raster map is NULL."
+msgid "New vector map <%s> boundary coordinates:"
 msgstr ""
-#: ../raster/r.resamp.rst/main.c:464
-msgid "Temporarily changing the region to desired resolution ..."
+#: ../vector/v.transform/main.c:312
+#, c-format
+msgid " N: %-10.3f    S: %-10.3f"
 msgstr ""
-#: ../raster/r.resamp.rst/main.c:469
-msgid "Changing back to the original region ..."
+#: ../vector/v.transform/main.c:313
+#, c-format
+msgid " E: %-10.3f    W: %-10.3f"
 msgstr ""
-#: ../raster/r.resamp.rst/main.c:478 ../raster/r.resample/main.c:112
-msgid "Percent complete: "
-msgstr "Pabeigts: "
-#: ../raster/r.resamp.rst/main.c:490
+#: ../vector/v.transform/main.c:314
 #, c-format
-msgid "dnorm in mainc after grid before out1= %f"
+msgid " B: %6.3f    T: %6.3f"
 msgstr ""
-#: ../raster/r.resamp.rst/main.c:494
-msgid "split_and_interpolate() failed"
+#: ../vector/v.transform/trans_digit.c:119
+#, c-format
+msgid "Unsupported column type of <%s>"
 msgstr ""
-#: ../raster/r.resamp.rst/main.c:509
+#: ../vector/v.transform/trans_digit.c:127
 #, c-format
-msgid "dnorm in mainc after grid before out2= %f"
+msgid ""
+"Unable to select value for category %d from table <%s>, column <%s>. For "
+"category %d using default transformation parameter %.3f."
 msgstr ""
-#: ../raster/r.resamp.rst/main.c:515
-msgid "Unable to write raster maps -- try increasing cell size"
+#: ../vector/v.transform/trans_digit.c:138
+msgid "No category number defined. Using default transformation parameters."
 msgstr ""
-#: ../raster/r.out.ascii/main.c:63
-msgid "Converts a raster map layer into a GRASS ASCII text file."
+#: ../vector/v.support/main.c:41
+msgid "Updates vector map metadata."
 msgstr ""
-#: ../raster/r.out.ascii/main.c:72
-msgid "Name for output ASCII grid map (use out=- for stdout)"
+#: ../vector/v.support/main.c:52
+msgid "Organization where vector map was created"
 msgstr ""
-#: ../raster/r.out.ascii/main.c:86
-msgid "Number of values printed before wrapping a line (only SURFER or MODFLOW format)"
+#: ../vector/v.support/main.c:61
+msgid "Date of vector map digitization (e.g., \"15 Mar 2007\")"
 msgstr ""
-#: ../raster/r.out.ascii/main.c:91
-msgid "String to represent null cell (GRASS grid only)"
+#: ../vector/v.support/main.c:68
+msgid "Person who created vector map"
 msgstr ""
-#: ../raster/r.out.ascii/main.c:99
-msgid "Write SURFER (Golden Software) ASCII grid"
+#: ../vector/v.support/main.c:75
+msgid "Vector map title"
 msgstr ""
-#: ../raster/r.out.ascii/main.c:103
-msgid "Write MODFLOW (USGS) ASCII array"
+#: ../vector/v.support/main.c:83
+msgid "Date when the source map was originally produced"
 msgstr ""
-#: ../raster/r.out.ascii/main.c:107
-msgid "Force output of integer values"
+#: ../vector/v.support/main.c:89
+msgid "Vector map scale number (e.g., 24000)"
 msgstr ""
-#: ../raster/r.out.ascii/main.c:114
-msgid "Failed to interpret dp as an integer"
+#: ../vector/v.support/main.c:95
+msgid "Vector map projection zone"
 msgstr ""
-#: ../raster/r.out.ascii/main.c:122
-msgid "Failed to interpret width as an integer"
+#: ../vector/v.support/main.c:102
+msgid "Vector map digitizing threshold number (e.g., 0.5)"
 msgstr ""
-#: ../raster/r.out.ascii/main.c:128
-msgid "Both -s and -h doesn't make sense"
+#: ../vector/v.support/main.c:110
+msgid "Text to append to the comment line of the map's metadata file"
 msgstr ""
-#: ../raster/r.out.ascii/main.c:131
-msgid "Use -M or -s, not both"
+#: ../vector/v.support/main.c:118
+msgid ""
+"Command line to store into vector map history file (used for vector scripts)"
 msgstr ""
-#: ../raster/r.out.ascii/main.c:166
-#, c-format
-msgid "Unable to read fp range for <%s>"
+#: ../vector/v.support/main.c:122
+msgid "Replace comment instead of appending it"
 msgstr ""
-#: ../raster/r.out.ascii/main.c:182
-#, c-format
-msgid "Read failed at row %d"
+#: ../vector/v.support/main.c:126
+msgid "Replace command line instead of appending it"
 msgstr ""
-#: ../raster/r.distance/distance.c:102
+#: ../vector/v.support/main.c:190
 #, c-format
-msgid "Reading maps  <%s,%s> while finding 0 distance ..."
+msgid "Unable to open history file for vector map <%s>"
 msgstr ""
-#: ../raster/r.distance/report.c:61
-#: ../scripts/i.colors.enhance/i.colors.enhance.py:153
-#: ../scripts/i.colors.enhance/i.colors.enhance.py:176
-#: ../scripts/i.colors.enhance/i.colors.enhance.py:186
-#: ../scripts/i.colors.enhance/i.colors.enhance.py:210
-msgid "Processing..."
+#: ../vector/v.random/main.c:102
+msgid "stratified random sampling"
 msgstr ""
-#: ../raster/r.distance/main.c:42
-msgid "Locates the closest points between objects in two raster maps."
+#: ../vector/v.random/main.c:105
+msgid "Generates random 2D/3D vector points."
 msgstr ""
-#: ../raster/r.distance/edges.c:47
-#, c-format
-msgid "Reading map %s ..."
+#: ../vector/v.random/main.c:113
+msgid "Number of points to be created"
+msgstr "Izveidojamo punktu skaits"
+#: ../vector/v.random/main.c:118
+msgid "Restrict points to areas in input vector"
 msgstr ""
-#: ../raster/r.distance/parse.c:35
-msgid "Name of two input raster maps for computing inter-class distances"
+#: ../vector/v.random/main.c:135
+msgid "Minimum z height (needs -z flag or column name)"
 msgstr ""
-#: ../raster/r.distance/parse.c:45
-msgid "Sort output by distance"
+#: ../vector/v.random/main.c:144
+msgid "Maximum z height (needs -z flag or column name)"
 msgstr ""
-#: ../raster/r.distance/parse.c:46
-msgid "Default: sorted by categories"
+#: ../vector/v.random/main.c:153
+msgid ""
+"The seed to initialize the random generator. If not set the process ID is "
+"used"
 msgstr ""
-#: ../raster/r.distance/parse.c:50
-msgid "Sort by distance in ascending order"
+#: ../vector/v.random/main.c:156
+msgid "Name of column for z values"
 msgstr ""
-#: ../raster/r.distance/parse.c:51
-msgid "Sort by distance in descending order"
+#: ../vector/v.random/main.c:158
+msgid "Writes z values to column"
 msgstr ""
-#: ../raster/r.distance/parse.c:55
-msgid "Include category labels in the output"
+#: ../vector/v.random/main.c:166
+msgid "Type of column for z values"
 msgstr ""
-#: ../raster/r.distance/parse.c:60
-msgid "Report zero distance if rasters are overlapping"
+#: ../vector/v.random/main.c:173
+msgid "Create 3D output"
 msgstr ""
-#: ../raster/r.distance/parse.c:64
-msgid "Report null objects as *"
+#: ../vector/v.random/main.c:178
+msgid "Generate n points for each individual area"
 msgstr ""
-#: ../raster/r.distance/parse.c:74 ../raster/r.distance/parse.c:83
+#: ../vector/v.random/main.c:192
 #, c-format
-msgid "Raster map <%s> is not CELL"
-msgstr ""
+msgid "Number of points must be > 0 (%d given)"
+msgstr "Punktu skaitam jābūt lielākam par 0 (%d doti)"
-#: ../raster/r.random/main.c:54 ../raster/r.random.cells/main.c:49
-#: ../raster/r.surf.random/main.c:38 ../raster/r.surf.gauss/main.c:40
-#: ../raster/r.random.surface/main.c:59 ../vector/v.extract/main.c:81
-#: ../vector/v.random/main.c:100 ../vector/v.perturb/main.c:65
-msgid "random"
+#: ../vector/v.random/main.c:218
+#, c-format
+msgid "No areas in vector map <%s>"
 msgstr ""
-#: ../raster/r.random/main.c:56
-msgid "Creates a raster map layer and vector point map containing randomly located points."
+#: ../vector/v.random/main.c:223
+#, c-format
+msgid "The <-%c> flag requires an input vector with areas"
 msgstr ""
-#: ../raster/r.random/main.c:60 ../raster/r.out.bin/main.c:290
-#: ../imagery/i.zc/main.c:65
-msgid "Name of input raster map"
+#: ../vector/v.random/main.c:277
+msgid "Table should contain only two columns"
 msgstr ""
-#: ../raster/r.random/main.c:65
-msgid "Name of cover raster map"
+#: ../vector/v.random/main.c:286
+msgid ""
+"You have created unsupported column type. This module supports only INTEGER "
+"and DOUBLE PRECISION column types."
 msgstr ""
-#: ../raster/r.random/main.c:72
-msgid "The number of points to allocate"
+#: ../vector/v.random/main.c:349
+#, c-format
+msgid ""
+"Selected areas in input vector <%s> do not overlap with the current region"
 msgstr ""
-#: ../raster/r.random/main.c:84
-msgid "Generate points also for NULL category"
+#: ../vector/v.random/main.c:361
+#, c-format
+msgid "Input vector <%s> does not overlap with the current region"
 msgstr ""
-#: ../raster/r.random/main.c:89
-msgid "Report information about input raster and exit"
+#: ../vector/v.random/main.c:386
+msgid "Generating points..."
 msgstr ""
-#: ../raster/r.random/main.c:93
-msgid "Generate vector points as 3D points"
+#: ../vector/v.what.rast3/main.c:72
+msgid "Uploads 3D raster values at positions of vector points to the table."
 msgstr ""
-#: ../raster/r.random/main.c:96 ../vector/v.in.ascii/main.c:193
-msgid "Do not build topology in points mode"
+#: ../vector/v.what.rast3/main.c:82
+msgid "Name of existing 3D raster map to be queried"
 msgstr ""
-#: ../raster/r.random/main.c:97 ../display/d.linegraph/main.c:353
-#: ../display/d.linegraph/main.c:362 ../display/d.linegraph/main.c:371
-#: ../display/d.linegraph/main.c:386 ../vector/v.in.ascii/main.c:117
-#: ../vector/v.in.ascii/main.c:124 ../vector/v.in.ascii/main.c:136
-#: ../vector/v.in.ascii/main.c:146 ../vector/v.in.ascii/main.c:156
-#: ../vector/v.in.ascii/main.c:166 ../vector/v.in.ascii/main.c:190
-#: ../vector/v.in.ascii/main.c:194 ../vector/v.in.ascii/main.c:200
-#: ../vector/v.in.ascii/main.c:205 ../vector/v.out.ascii/args.c:40
-#: ../vector/v.out.ascii/args.c:66 ../vector/v.out.ascii/args.c:76
-#: ../vector/v.out.ascii/args.c:86 ../vector/v.out.ascii/args.c:92
-msgid "Points"
-msgstr "Punkti"
-#: ../raster/r.random/main.c:133
+#: ../vector/v.what.rast3/main.c:135
 #, c-format
-msgid "Note: one (or both) of %s and %s must be specified"
+msgid "Error opening 3D raster map <%s>"
 msgstr ""
-#: ../raster/r.random/main.c:141
-#, c-format
-msgid "<%s=%s> invalid percentage"
+#: ../vector/v.what.rast3/main.c:144
+msgid "Column type not supported, please use a column with double type"
 msgstr ""
-#: ../raster/r.random/main.c:148
+#: ../vector/v.what.rast3/main.c:215
 #, c-format
-msgid "<%s=%s> invalid number of points"
-msgstr ""
+msgid "%d point outside current region was skipped"
+msgid_plural "%d points outside current region were skipped"
+msgstr[0] ""
+msgstr[1] ""
+msgstr[2] ""
-#: ../raster/r.random/main.c:161
+#: ../vector/v.what.rast3/main.c:220
 #, c-format
-msgid "There aren't [%ld] cells in the current region"
-msgstr ""
+msgid "%d point without category was skipped"
+msgid_plural "%d points without category were skipped"
+msgstr[0] ""
+msgstr[1] ""
+msgstr[2] ""
-#: ../raster/r.random/main.c:164
+#: ../vector/v.what.rast3/main.c:259
 #, c-format
-msgid "There aren't [%ld] non-NULL cells in the current region"
+msgid "More points (%d) of category %d, value set to 'NULL'"
 msgstr ""
-#: ../raster/r.random/main.c:169
-msgid "There are no valid locations in the current region"
-msgstr ""
+#: ../vector/v.what.rast3/main.c:329
+#, c-format
+msgid "%d category loaded from table"
+msgid_plural "%d categories loaded from table"
+msgstr[0] ""
+msgstr[1] ""
+msgstr[2] ""
-#: ../raster/r.random/random.c:43 ../raster/r.random/random.c:47
-#: ../raster/r.mapcalc/map3.c:517 ../imagery/i.landsat.toar/main.c:407
-#: ../imagery/i.landsat.toar/main.c:545 ../imagery/i.landsat.acca/main.c:57
-#: ../imagery/i.landsat.acca/algorithm.c:380
-#: ../imagery/i.landsat.acca/tools.c:126
+#: ../vector/v.what.rast3/main.c:332
 #, c-format
-msgid "Unable to open raster map <%s>"
-msgstr ""
+msgid "%d category loaded from vector"
+msgid_plural "%d categories loaded from vector"
+msgstr[0] ""
+msgstr[1] ""
+msgstr[2] ""
-#: ../raster/r.random/random.c:100
-msgid "Cannot create new table"
-msgstr ""
+#: ../vector/v.what.rast3/main.c:335
+#, c-format
+msgid "%d category from vector missing in table"
+msgid_plural "%d categories from vector missing in table"
+msgstr[0] ""
+msgstr[1] ""
+msgstr[2] ""
-#: ../raster/r.random/random.c:110
+#: ../vector/v.what.rast3/main.c:339
 #, c-format
-msgid "Writing raster map <%s> and vector map <%s> ..."
-msgstr ""
+msgid "%d duplicate category in vector"
+msgid_plural "%d duplicate categories in vector"
+msgstr[0] ""
+msgstr[1] ""
+msgstr[2] ""
-#: ../raster/r.random/random.c:113
+#: ../vector/v.what.rast3/main.c:343
 #, c-format
-msgid "Writing raster map <%s> ..."
-msgstr ""
+msgid "%d update error"
+msgid_plural "%d update errors"
+msgstr[0] ""
+msgstr[1] ""
+msgstr[2] ""
-#: ../raster/r.random/random.c:115
+#: ../vector/v.what.rast3/main.c:347
 #, c-format
-msgid "Writing vector map <%s> ..."
-msgstr ""
+msgid "%d record updated."
+msgid_plural "%d records updated."
+msgstr[0] ""
+msgstr[1] ""
+msgstr[2] ""
-#: ../raster/r.random/random.c:190 ../vector/v.net.components/main.c:39
-#: ../vector/v.net.distance/main.c:363 ../vector/v.net.flow/main.c:262
-#: ../vector/v.net.timetable/main.c:134 ../vector/v.net.timetable/main.c:156
-#: ../vector/v.net.allpairs/main.c:271 ../vector/v.net.path/path.c:350
-#: ../vector/v.net.centrality/main.c:69
+#: ../vector/v.colors/make_colors.c:14
 #, c-format
-msgid "Cannot insert new record: %s"
+msgid "Color table '%s' is not supported for floating point attributes"
 msgstr ""
-#: ../raster/r.random/random.c:243
+#: ../vector/v.colors/make_colors.c:18 ../vector/v.colors/make_colors.c:25
 #, c-format
-msgid "Only [%ld] random points created"
+msgid "Color table <%s> not supported"
 msgstr ""
-#: ../raster/r.random/count.c:68
-msgid "Collecting Stats..."
+#: ../vector/v.colors/make_colors.c:51 ../raster/r.colors/edit_colors.c:386
+#, c-format
+msgid "Unable to load rules file <%s>"
 msgstr ""
-#: ../raster/r.random/count.c:123
-msgid "Programmer error in get_stats/switch"
+#: ../vector/v.colors/main.c:56 ../vector/v.colors.out/main.c:50
+#: ../raster/r.what.color/main.c:90 ../raster/r.colors.out/raster_main.c:46
+#: ../raster/r.colors.out/raster3d_main.c:47
+#: ../raster/r.colors/edit_colors.c:67
+#: ../locale/scriptstrings/t.rast.colors_to_translate.c:3
+#: ../locale/scriptstrings/r.colors.stddev_to_translate.c:3
+#: ../display/d.colortable/main.c:62
+msgid "color table"
 msgstr ""
-#: ../raster/r.volume/main.c:77
-msgid "volume"
+#: ../vector/v.colors/main.c:58
+msgid "Creates/modifies the color table associated with a vector map."
 msgstr ""
-#: ../raster/r.volume/main.c:80
-msgid "Calculates the volume of data \"clumps\"."
+#: ../vector/v.colors/main.c:70
+msgid "Source values"
 msgstr ""
-#: ../raster/r.volume/main.c:81
-msgid "Optionally produces a GRASS vector points map containing the calculated centroids of these clumps."
+#: ../vector/v.colors/main.c:73
+msgid "read values from attribute table (requires <column> option)"
 msgstr ""
-#: ../raster/r.volume/main.c:86
-msgid "Name of input raster map representing data that will be summed within clumps"
+#: ../vector/v.colors/main.c:75
+msgid "use z coordinate (3D points or centroids only)"
 msgstr ""
-#: ../raster/r.volume/main.c:92
-msgid "Name of input clump raster map"
+#: ../vector/v.colors/main.c:79
+msgid "Name of column containing numeric data"
 msgstr ""
-#: ../raster/r.volume/main.c:93
-msgid "Preferably the output of r.clump. If no clump map is given than MASK is used."
+#: ../vector/v.colors/main.c:80
+msgid "Required for use=attr"
 msgstr ""
-#: ../raster/r.volume/main.c:99
-msgid "Name for output vector points map to contain clump centroids"
-msgstr ""
+#: ../vector/v.colors/main.c:81 ../vector/v.colors/main.c:92
+#: ../vector/v.colors/main.c:99 ../vector/v.colors/main.c:106
+#: ../vector/v.colors/main.c:112 ../vector/v.colors/main.c:138
+#: ../vector/v.colors/main.c:143 ../vector/v.colors/main.c:148
+#: ../raster/r.colors/edit_colors.c:90 ../raster/r.colors/edit_colors.c:97
+#: ../raster/r.colors/edit_colors.c:104 ../raster/r.colors/edit_colors.c:111
+#: ../raster/r.colors/edit_colors.c:122 ../raster/r.colors/edit_colors.c:133
+#: ../raster/r.colors/edit_colors.c:138 ../raster/r.colors/edit_colors.c:143
+#: ../raster/r.colors/edit_colors.c:148 ../raster/r.category/main.c:81
+#: ../raster/r.category/main.c:88
+#: ../locale/scriptstrings/t.rast.colors_to_translate.c:7
+#: ../locale/scriptstrings/t.rast.colors_to_translate.c:9
+#: ../locale/scriptstrings/t.rast.colors_to_translate.c:11
+#: ../locale/scriptstrings/t.rast.colors_to_translate.c:13
+#: ../locale/scriptstrings/t.rast.colors_to_translate.c:20
+#: ../locale/scriptstrings/t.rast.colors_to_translate.c:22
+#: ../locale/scriptstrings/t.rast.colors_to_translate.c:24
+#: ../locale/scriptstrings/t.rast.colors_to_translate.c:26
+#: ../display/d.linegraph/main.c:270
+msgid "Define"
+msgstr "Definēt"
-#: ../raster/r.volume/main.c:110
-msgid "Generate unformatted report (items separated by colon)"
+#: ../vector/v.colors/main.c:87
+msgid "Manually set range (refers to 'column' option)"
 msgstr ""
-#: ../raster/r.volume/main.c:143
-msgid "No MASK found. If no clump map is given than the MASK is required. You need to define a clump raster map or create a MASK by r.mask command."
+#: ../vector/v.colors/main.c:88
+msgid "Ignored when 'rules' given"
 msgstr ""
-#: ../raster/r.volume/main.c:145
-msgid "No clump map given, using MASK"
+#: ../vector/v.colors/main.c:98 ../raster/r.colors/edit_colors.c:96
+#: ../locale/scriptstrings/t.rast.colors_to_translate.c:8
+msgid "Raster map from which to copy color table"
 msgstr ""
-#: ../raster/r.volume/main.c:198
-#, c-format
-msgid "Invalid category value %d (max=%d): row=%d col=%d"
+#: ../vector/v.colors/main.c:105 ../raster/r.colors/edit_colors.c:103
+#: ../locale/scriptstrings/t.rast.colors_to_translate.c:10
+msgid "3D raster map from which to copy color table"
 msgstr ""
-#: ../raster/r.volume/main.c:231
-#, c-format
-msgid "Creating vector point map <%s>..."
+#: ../vector/v.colors/main.c:111 ../raster/r.colors/edit_colors.c:109
+#: ../locale/scriptstrings/t.rast.colors_to_translate.c:12
+msgid "Path to rules file"
 msgstr ""
-#: ../raster/r.volume/main.c:233
-#, c-format
-msgid "From '%s' on raster map <%s> using clumps from <%s>"
+#: ../vector/v.colors/main.c:116
+msgid "Name of color column to populate RGB values"
 msgstr ""
-#: ../raster/r.volume/main.c:266
-#, c-format
-msgid ""
-"\n"
-"Volume report on data from <%s> using clumps on <%s> raster map"
+#: ../vector/v.colors/main.c:117
+msgid "If not given writes color table"
 msgstr ""
-#: ../raster/r.volume/main.c:270
-#, c-format
-msgid "Category   Average   Data   # Cells        Centroid             Total\n"
+#: ../vector/v.colors/main.c:121 ../raster/r.colors/edit_colors.c:115
+#: ../locale/scriptstrings/t.rast.colors_to_translate.c:14
+msgid "Remove existing color table"
 msgstr ""
-#: ../raster/r.volume/main.c:272
-#, c-format
-msgid "Number     in clump  Total  in clump   Easting     Northing     Volume"
+#: ../vector/v.colors/main.c:122 ../raster/r.null/main.c:108
+#: ../raster/r.colors/edit_colors.c:116
+#: ../locale/scriptstrings/r.mask_to_translate.c:20
+#: ../locale/scriptstrings/t.rast.colors_to_translate.c:15
+#: ../locale/scriptstrings/g.extension_to_translate.c:30
+msgid "Remove"
 msgstr ""
-#: ../raster/r.volume/main.c:318
-msgid "Total Volume"
+#: ../vector/v.colors/main.c:127 ../raster/r.colors/edit_colors.c:121
+#: ../locale/scriptstrings/t.rast.colors_to_translate.c:16
+msgid "Only write new color table if it does not already exist"
 msgstr ""
-#: ../raster/r.random.cells/main.c:50
-msgid "autocorrelation"
+#: ../vector/v.colors/main.c:131 ../raster/r.colors/edit_colors.c:126
+#: ../locale/scriptstrings/t.rast.colors_to_translate.c:17
+msgid "List available rules then exit"
 msgstr ""
-#: ../raster/r.random.cells/main.c:52
-msgid "Generates random cell values with spatial dependence."
-msgstr "Ģenerē gadījuma rastra šūnas ar telpiski atkarīgām vērtībām."
+#: ../vector/v.colors/main.c:137 ../raster/r.colors/edit_colors.c:132
+#: ../locale/scriptstrings/t.rast.colors_to_translate.c:19
+msgid "Invert colors"
+msgstr "Pretējas krāsas"
-#: ../raster/r.random.cells/main.c:62 ../raster/r.random.surface/main.c:77
-msgid "Maximum distance of spatial correlation (value >= 0.0)"
+#: ../vector/v.colors/main.c:142 ../raster/r.colors/edit_colors.c:137
+#: ../locale/scriptstrings/t.rast.colors_to_translate.c:21
+msgid "Logarithmic scaling"
 msgstr ""
-#: ../raster/r.random.cells/main.c:70
-msgid "Maximum number of cells to be created"
+#: ../vector/v.colors/main.c:147 ../raster/r.colors/edit_colors.c:142
+#: ../locale/scriptstrings/t.rast.colors_to_translate.c:23
+msgid "Logarithmic-absolute scaling"
 msgstr ""
-#: ../raster/r.random.cells/main.c:77
-msgid "Random seed (SEED_MIN >= value >= SEED_MAX) (default [random])"
+#: ../vector/v.colors/main.c:152
+msgid "Convert color rules from RGB values to color table"
 msgstr ""
-#: ../raster/r.random.cells/random.c:50
-#, c-format
-msgid "RAN1: j == %d shouldn't happen"
+#: ../vector/v.colors/main.c:153
+msgid "Option 'rgb_column' with valid RGB values required"
 msgstr ""
-#: ../raster/r.random.cells/init.c:77
-msgid "Distance must be >= 0.0"
+#: ../vector/v.colors/main.c:196
+msgid "No vector map specified"
 msgstr ""
-#: ../raster/r.random.cells/init.c:96 ../raster/r.random.surface/main.c:128
+#: ../vector/v.colors/main.c:199 ../raster/r.sunmask/main.c:444
 #, c-format
-msgid "Generating raster map <%s>..."
+msgid "Option <%s> required"
 msgstr ""
-#: ../raster/r.cross/renumber.c:33
+#: ../vector/v.colors/main.c:201
 #, c-format
-msgid "%s: STEP 3 ... "
+msgid "Option <%s> given, assuming <use=attr>..."
 msgstr ""
-#: ../raster/r.cross/cross.c:65
+#: ../vector/v.colors/main.c:206 ../raster/r.series.interp/main.c:118
+#: ../raster/r.series.interp/main.c:122 ../raster/r.series.interp/main.c:134
+#: ../raster/r.series.interp/main.c:138 ../raster/r.external/main.c:170
+#: ../raster/r.neighbors/main.c:266 ../raster/r.mapcalc/main.c:131
+#: ../raster/r.series/main.c:204 ../raster/r.series.accumulate/main.c:206
 #, c-format
-msgid "%s: STEP 1 ... "
+msgid "%s= and %s= are mutually exclusive"
 msgstr ""
-#: ../raster/r.cross/main.c:72
-msgid "Creates a cross product of the category values from multiple raster map layers."
+#: ../vector/v.colors/main.c:216
+#, c-format
+msgid "One of -%c, -%c or %s=, %s= or %s= must be specified"
 msgstr ""
-#: ../raster/r.cross/main.c:81
+#: ../vector/v.colors/main.c:221
 #, c-format
-msgid "Names of 2-%d input raster maps"
+msgid "%s=, %s= and %s= are mutually exclusive"
 msgstr ""
-#: ../raster/r.cross/main.c:90
-msgid "Non-zero data only"
+#: ../vector/v.colors/main.c:225 ../raster/r.out.bin/main.c:379
+#: ../raster/r.in.bin/main.c:462
+#, c-format
+msgid "-%c and -%c are mutually exclusive"
 msgstr ""
-#: ../raster/r.cross/main.c:103
+#: ../vector/v.colors/main.c:229
 #, c-format
-msgid "More than %d files not allowed"
+msgid "%s= required for -%c"
 msgstr ""
-#: ../raster/r.cross/main.c:119
-msgid "Must specify 2 or more input maps"
+#: ../vector/v.colors/main.c:234
+msgid ""
+"Reading rules from standard input is not implemented yet, please provide "
+"path to rules file instead."
 msgstr ""
-#: ../raster/r.cross/main.c:136
+#: ../vector/v.colors/main.c:244
 #, c-format
-msgid "%s: STEP 2 ..."
+msgid "Unable to remove color table of vector map <%s>"
 msgstr ""
-#: ../raster/r.cross/main.c:179
+#: ../vector/v.colors/main.c:246
 #, c-format
-msgid "%ld categories"
+msgid "Color table of vector map <%s> not found"
 msgstr ""
-#: ../raster/r.li/r.li.cwed/cwed.c:53
-msgid "Calculates contrast weighted edge density index on a raster map"
+#: ../vector/v.colors/main.c:254
+msgid "Color table exists. Exiting."
 msgstr ""
-#: ../raster/r.li/r.li.cwed/cwed.c:55
-#: ../raster/r.li/r.li.padrange/padrange.c:54
-#: ../raster/r.li/r.li.renyi/renyi.c:48
-#: ../raster/r.li/r.li.dominance/dominance.c:47
-#: ../raster/r.li/r.li.shannon/shannon.c:47
-#: ../raster/r.li/r.li.padcv/padcv.c:54 ../raster/r.li/r.li.mps/mps.c:53
-#: ../raster/r.li/r.li.patchdensity/main.c:52
-#: ../raster/r.li/r.li.shape/main.c:50 ../raster/r.li/r.li.mpa/mpa.c:45
-#: ../raster/r.li/r.li.padsd/padsd.c:54
-#: ../raster/r.li/r.li.simpson/simpson.c:47
-#: ../raster/r.li/r.li.richness/richness.c:44
-#: ../raster/r.li/r.li.edgedensity/edgedensity.c:49
-#: ../raster/r.li/r.li.patchnum/main.c:51
-#: ../raster/r.li/r.li.pielou/pielou.c:47
-msgid "landscape structure analysis"
+#: ../vector/v.colors/main.c:276
+#, c-format
+msgid "Option <%s>: min must be greater or equal to max"
 msgstr ""
-#: ../raster/r.li/r.li.cwed/cwed.c:56
-#: ../raster/r.li/r.li.padrange/padrange.c:55
-#: ../raster/r.li/r.li.padcv/padcv.c:55 ../raster/r.li/r.li.mps/mps.c:54
-#: ../raster/r.li/r.li.patchdensity/main.c:53
-#: ../raster/r.li/r.li.shape/main.c:51 ../raster/r.li/r.li.mpa/mpa.c:46
-#: ../raster/r.li/r.li.padsd/padsd.c:55
-#: ../raster/r.li/r.li.edgedensity/edgedensity.c:50
-#: ../raster/r.li/r.li.patchnum/main.c:52
-msgid "patch index"
+#: ../vector/v.colors/main.c:282
+msgid "Reading color rules from standard input is currently not supported"
 msgstr ""
-#: ../raster/r.li/r.li.cwed/cwed.c:64
-#: ../raster/r.li/r.li.padrange/padrange.c:62
-#: ../raster/r.li/r.li.renyi/renyi.c:57
-#: ../raster/r.li/r.li.dominance/dominance.c:56
-#: ../raster/r.li/r.li.shannon/shannon.c:56
-#: ../raster/r.li/r.li.padcv/padcv.c:62 ../raster/r.li/r.li.mps/mps.c:62
-#: ../raster/r.li/r.li.patchdensity/main.c:61
-#: ../raster/r.li/r.li.shape/main.c:59 ../raster/r.li/r.li.mpa/mpa.c:53
-#: ../raster/r.li/r.li.padsd/padsd.c:62
-#: ../raster/r.li/r.li.simpson/simpson.c:56
-#: ../raster/r.li/r.li.richness/richness.c:53
-#: ../raster/r.li/r.li.edgedensity/edgedensity.c:58
-#: ../raster/r.li/r.li.patchnum/main.c:59
-#: ../raster/r.li/r.li.pielou/pielou.c:56
-msgid "Configuration file"
+#: ../vector/v.colors/main.c:289
+#, c-format
+msgid "Color table <%s> not found"
 msgstr ""
-#: ../raster/r.li/r.li.cwed/cwed.c:70
-msgid "Name of file that contains the weight to calculate the index"
+#: ../vector/v.colors/main.c:315 ../raster/r.grow.distance/main.c:382
+#: ../raster/r.colors.out/raster_main.c:69 ../raster/r.fill.dir/main.c:153
+#: ../raster/r.colors/edit_colors.c:396
+#, c-format
+msgid "Unable to read color table for raster map <%s>"
 msgstr ""
-#: ../raster/r.li/r.li.cwed/cwed.c:306 ../raster/r.li/r.li.cwed/cwed.c:453
-#: ../raster/r.li/r.li.cwed/cwed.c:599
-msgid "Row cache is too small"
+#: ../vector/v.colors/main.c:319 ../raster/r.univar/r3.univar_main.c:144
+#: ../raster/r.univar/r3.univar_main.c:182 ../raster/r.colors/edit_colors.c:400
+#: ../general/g.region/main.c:455 ../raster3d/r3.out.bin/main.c:299
+#: ../raster3d/r3.out.v5d/main.c:307 ../raster3d/r3.out.netcdf/main.c:600
+#: ../raster3d/r3.retile/main.c:113 ../raster3d/r3.stats/main.c:97
+#: ../raster3d/r3.cross.rast/main.c:245 ../raster3d/r3.neighbors/main.c:229
+#: ../raster3d/r3.to.rast/main.c:275 ../raster3d/r3.null/main.c:103
+#: ../raster3d/r3.timestamp/main.c:73 ../raster3d/r3.mask/main.c:58
+#: ../raster3d/r3.out.ascii/main.c:326 ../raster3d/r3.out.vtk/main.c:142
+#: ../raster3d/r3.flow/main.c:87 ../raster3d/r3.support/main.c:135
+#, c-format
+msgid "3D raster map <%s> not found"
 msgstr ""
-#: ../raster/r.li/r.li.padrange/padrange.c:52
-msgid "Calculates range of patch area size on a raster map"
+#: ../vector/v.colors/main.c:322 ../raster/r.colors/edit_colors.c:403
+#, c-format
+msgid "Unable to read color table for 3D raster map <%s>"
 msgstr ""
-#: ../raster/r.li/r.li.renyi/renyi.c:46
-msgid "Calculates Renyi's diversity index on a raster map"
+#: ../vector/v.colors/main.c:347
+msgid "Writing color rules..."
 msgstr ""
-#: ../raster/r.li/r.li.renyi/renyi.c:49
-#: ../raster/r.li/r.li.dominance/dominance.c:48
-#: ../raster/r.li/r.li.shannon/shannon.c:48
-#: ../raster/r.li/r.li.simpson/simpson.c:48
-#: ../raster/r.li/r.li.richness/richness.c:45
-#: ../raster/r.li/r.li.pielou/pielou.c:48
-msgid "diversity index"
+#: ../vector/v.colors/main.c:363
+#, c-format
+msgid "Color table for vector map <%s> set to '%s'"
 msgstr ""
-#: ../raster/r.li/r.li.renyi/renyi.c:63
-msgid "Alpha value is the order of the generalized entropy"
+#: ../vector/v.colors/write_rgb.c:60
+#, c-format
+msgid "Column <%s> added to table <%s>"
 msgstr ""
-#: ../raster/r.li/r.li.dominance/dominance.c:45
-msgid "Calculates dominance's diversity index on a raster map"
+#: ../vector/v.colors/write_rgb.c:64
+#, c-format
+msgid "Data type of column <%s> must be char"
 msgstr ""
-#: ../raster/r.li/r.li.shannon/shannon.c:45
-msgid "Calculates Shannon's diversity index on a raster map"
+#: ../vector/v.colors/write_rgb.c:68
+msgid "No categories found"
 msgstr ""
-#: ../raster/r.li/r.li.padcv/padcv.c:52
-msgid "Calculates coefficient of variation of patch area on a raster map"
+#: ../vector/v.colors/write_rgb.c:78
+#, c-format
+msgid "No color value defined for category %d"
 msgstr ""
-#: ../raster/r.li/r.li.mps/mps.c:51
-msgid "Calculates mean patch size index on a raster map, using a 4 neighbour algorithm"
+#: ../vector/v.colors/write_rgb.c:86
+msgid "Unable to update RGB values"
 msgstr ""
-#: ../raster/r.li/r.li.patchdensity/main.c:50
-msgid "Calculates patch density index on a raster map, using a 4 neighbour algorithm"
+#: ../vector/v.colors/scan_attr.c:38 ../vector/v.colors.out/make_colors.c:45
+#: ../scripts/db.univar/db.univar.py:118
+msgid "Column <%s> is not numeric"
 msgstr ""
-#: ../raster/r.li/r.li.shape/main.c:48
-msgid "Calculates shape index on a raster map"
+#: ../vector/v.colors/scan_attr.c:45 ../vector/v.colors.out/make_colors.c:52
+msgid "No data selected"
 msgstr ""
-#: ../raster/r.li/r.li.daemon/daemon.c:97
-msgid "Cannot create random access file"
+#: ../vector/v.colors/scan_attr.c:59 ../vector/v.colors/scan_z.c:68
+#, c-format
+msgid "Min value (%f) is out of range %f,%f"
 msgstr ""
-#: ../raster/r.li/r.li.daemon/daemon.c:105
-#: ../raster/r.li/r.li.daemon/daemon.c:111
-#: ../raster/r.li/r.li.daemon/daemon.c:117
+#: ../vector/v.colors/scan_attr.c:65 ../vector/v.colors/scan_z.c:74
 #, c-format
-msgid "Cannot create %s directory"
+msgid "Max value (%f) is out of range %f,%f"
 msgstr ""
-#: ../raster/r.li/r.li.daemon/daemon.c:201
+#: ../vector/v.colors/scan_attr.c:77 ../vector/v.colors/scan_cats.c:43
 #, c-format
-msgid "Cannot find configuration file <%s>"
+msgid "Min value (%d) is out of range %d,%d"
 msgstr ""
-#: ../raster/r.li/r.li.daemon/daemon.c:208
-#: ../raster/r.li/r.li.daemon/daemon.c:212
-msgid "Cannot read setup file"
+#: ../vector/v.colors/scan_attr.c:83 ../vector/v.colors/scan_cats.c:49
+#, c-format
+msgid "Max value (%d) is out of range %d,%d"
 msgstr ""
-#: ../raster/r.li/r.li.daemon/daemon.c:216
-msgid "Unable to parse configuration file (sampling frame)"
+#: ../vector/v.colors/scan_attr.c:108
+msgid "Converting color rules into categories..."
 msgstr ""
-#: ../raster/r.li/r.li.daemon/daemon.c:475
-msgid "Irregular MASKEDOVERLAY areas definition"
+#: ../vector/v.colors/read_rgb.c:32
+#, c-format
+msgid "Data type of RGB column <%s> must be char"
 msgstr ""
-#: ../raster/r.li/r.li.daemon/daemon.c:479
-#, c-format
-msgid "The configuration file can only be used with the <%s> raster map"
+#: ../vector/v.colors/read_rgb.c:37
+msgid "No RGB values found"
 msgstr ""
-#: ../raster/r.li/r.li.daemon/daemon.c:485
-msgid "Unable to parse configuration file (sample area)"
+#: ../vector/v.colors/read_rgb.c:65
+#, c-format
+msgid "%d invalid RGB color values skipped"
 msgstr ""
-#: ../raster/r.li/r.li.daemon/daemon.c:520
-msgid "Too many units to place"
+#: ../vector/v.out.dxf/main.c:58
+msgid "DXF"
+msgstr "DXF"
+#: ../vector/v.out.dxf/main.c:60
+msgid "Exports vector map to DXF file format."
 msgstr ""
-#: ../raster/r.li/r.li.daemon/daemon.c:589
-msgid "Too many stratified random sample for raster map"
+#: ../vector/v.out.dxf/main.c:68
+msgid "Name for DXF output file"
 msgstr ""
-#: ../raster/r.li/r.li.daemon/daemon.c:623
-msgid "Illegal areas disposition"
+#: ../vector/v.out.dxf/main.c:93
+#, c-format
+msgid "%d features written to '%s'."
 msgstr ""
-#: ../raster/r.li/r.li.daemon/daemon.c:695
-msgid "Cannot make lseek"
+#: ../vector/v.out.dxf/write_dxf.c:21
+#, c-format
+msgid "The file '%s' already exists."
+msgstr "Fails '%s' jau eksistē."
+#: ../vector/v.out.dxf/write_dxf.c:23
+#, c-format
+msgid "The file '%s' already exists and will be overwritten."
 msgstr ""
-#: ../raster/r.li/r.li.daemon/worker.c:135
+#: ../vector/v.out.dxf/write_dxf.c:27
 #, c-format
-msgid "unable to open <%s> mask ... continuing without!"
+msgid "%s: Cannot write dxf file."
 msgstr ""
-#: ../raster/r.li/r.li.mpa/mpa.c:43
-msgid "Calculates mean pixel attribute index on a raster map"
+#: ../vector/v.net.salesman/main.c:129
+msgid "salesman"
 msgstr ""
-#: ../raster/r.li/r.li.padsd/padsd.c:52
-msgid "Calculates standard deviation of patch area a raster map"
+#: ../vector/v.net.salesman/main.c:131
+msgid "Creates a cycle connecting given nodes (Traveling salesman problem)."
 msgstr ""
-#: ../raster/r.li/r.li.simpson/simpson.c:45
-msgid "Calculates Simpson's diversity index on a raster map"
+#: ../vector/v.net.salesman/main.c:133
+msgid ""
+"Note that TSP is NP-hard, heuristic algorithm is used by this module and "
+"created cycle may be sub optimal"
 msgstr ""
-#: ../raster/r.li/r.li.richness/richness.c:42
-msgid "Calculates richness index on a raster map"
+#: ../vector/v.net.salesman/main.c:142
+msgid "Categories of points ('cities') on nodes (layer is specified by nlayer)"
 msgstr ""
-#: ../raster/r.li/r.li.edgedensity/edgedensity.c:47
-msgid "Calculates edge density index on a raster map, using a 4 neighbour algorithm"
+#: ../vector/v.net.salesman/main.c:162
+msgid "Node layer (used for cities)"
 msgstr ""
-#: ../raster/r.li/r.li.edgedensity/edgedensity.c:68
-msgid "The value of the patch type"
+#: ../vector/v.net.salesman/main.c:176
+msgid "EXPERIMENTAL: Arc backward direction cost column (number)"
 msgstr ""
-#: ../raster/r.li/r.li.edgedensity/edgedensity.c:69
-msgid "It can be integer, double or float; it will be changed in function of map type"
+#: ../vector/v.net.salesman/main.c:203
+msgid "Name for output file holding node sequence (\"-\" for stdout)"
 msgstr ""
-#: ../raster/r.li/r.li.edgedensity/edgedensity.c:74
-msgid "Exclude border edges"
+#: ../vector/v.net.salesman/main.c:286
+#, c-format
+msgid "Number of cities: %d"
 msgstr ""
-#: ../raster/r.li/r.li.patchnum/main.c:49
-msgid "Calculates patch number index on a raster map, using a 4 neighbour algorithm."
+#: ../vector/v.net.salesman/main.c:288
+msgid "Not enough cities (< 2)"
 msgstr ""
-#: ../raster/r.li/r.li.pielou/pielou.c:45
-msgid "Calculates Pielou's diversity index on a raster map"
+#: ../vector/v.net.salesman/main.c:328
+msgid "Creating cost cache..."
 msgstr ""
-#: ../raster/r.drain/main.c:111 ../raster/r.walk/main.c:179
-#: ../raster/r.cost/main.c:141
-msgid "cost surface"
+#: ../vector/v.net.salesman/main.c:357 ../vector/v.net.salesman/main.c:371
+#, c-format
+msgid "No point at node %d"
 msgstr ""
-#: ../raster/r.drain/main.c:113
-msgid "Traces a flow through an elevation model or cost surface on a raster map."
+#: ../vector/v.net.salesman/main.c:361 ../vector/v.net.salesman/main.c:375
+#, c-format
+msgid "No category for point at node %d"
 msgstr ""
-#: ../raster/r.drain/main.c:116
-msgid "Name of input elevation or cost surface raster map"
+#: ../vector/v.net.salesman/main.c:378
+#, c-format
+msgid "Destination node [cat %d] is unreachable from node [cat %d]"
 msgstr ""
-#: ../raster/r.drain/main.c:121
-msgid "Name of input movement direction map associated with the cost surface"
+#: ../vector/v.net.salesman/main.c:421
+msgid "Searching for the shortest cycle..."
 msgstr ""
-#: ../raster/r.drain/main.c:123 ../raster/r.drain/main.c:164
-msgid "Cost surface"
-msgstr "Izmaksu virsma"
-#: ../raster/r.drain/main.c:131
-msgid "Name for output drain vector map"
+#: ../vector/v.net.salesman/main.c:555
+#, c-format
+msgid "Cycle with total cost %.3f"
 msgstr ""
-#: ../raster/r.drain/main.c:132
-msgid "Recommended for cost surface made using knight's move"
+#: ../vector/v.in.dxf/read_dxf.c:57
+msgid "end of file while looking for HEADER"
 msgstr ""
-#: ../raster/r.drain/main.c:136 ../raster/r.walk/main.c:227
-#: ../raster/r.cost/main.c:192
-msgid "Coordinates of starting point(s) (E,N)"
+#: ../vector/v.in.dxf/main.c:70
+msgid "Converts file in DXF format to GRASS vector map."
 msgstr ""
-#: ../raster/r.drain/main.c:137 ../raster/r.drain/main.c:144
-#: ../raster/r.walk/main.c:209 ../raster/r.walk/main.c:221
-#: ../raster/r.walk/main.c:228 ../raster/r.walk/main.c:309
-#: ../raster/r.cost/main.c:174 ../raster/r.cost/main.c:186
-#: ../raster/r.cost/main.c:193 ../raster/r.cost/main.c:243
-msgid "Start"
+#: ../vector/v.in.dxf/main.c:74
+msgid "Ignore the map extent of DXF file"
 msgstr ""
-#: ../raster/r.drain/main.c:142
-msgid "Name of starting vector points map(s)"
+#: ../vector/v.in.dxf/main.c:82
+msgid "Import polyface meshes as 3D wire frame"
 msgstr ""
-#: ../raster/r.drain/main.c:148
-msgid "Copy input cell values on output"
+#: ../vector/v.in.dxf/main.c:86
+msgid "List available DXF layers and exit"
 msgstr ""
-#: ../raster/r.drain/main.c:152
-msgid "Accumulate input values along the path"
+#: ../vector/v.in.dxf/main.c:87 ../vector/v.in.dxf/main.c:94
+#: ../vector/v.in.dxf/main.c:99 ../vector/v.in.dxf/main.c:112
+msgid "DXF layers"
 msgstr ""
-#: ../raster/r.drain/main.c:153 ../raster/r.drain/main.c:158
-msgid "Path settings"
+#: ../vector/v.in.dxf/main.c:93
+msgid "Invert selection by DXF layers (don't import layers in list)"
 msgstr ""
-#: ../raster/r.drain/main.c:157
-msgid "Count cell numbers along the path"
+#: ../vector/v.in.dxf/main.c:98
+msgid "Import all objects into one layer"
 msgstr ""
-#: ../raster/r.drain/main.c:163
-msgid "The input raster map is a cost surface (direction surface must also be specified)"
+#: ../vector/v.in.dxf/main.c:102
+msgid "Path to input DXF file"
 msgstr ""
-#: ../raster/r.drain/main.c:175
-msgid "Directional drain selected... checking for direction raster map"
+#: ../vector/v.in.dxf/main.c:111
+msgid "List of DXF layers to import (default: all)"
 msgstr ""
-#: ../raster/r.drain/main.c:178
-msgid "Surface/Hydrology drain selected"
+#: ../vector/v.in.dxf/main.c:126
+msgid "Please specify list of DXF layers to exclude"
 msgstr ""
-#: ../raster/r.drain/main.c:183
+#: ../vector/v.in.dxf/main.c:130
 #, c-format
-msgid "Direction raster map <%s> not specified, if direction flag is on, a direction raster must be given"
+msgid "Unable to open DXF file <%s>"
 msgstr ""
-#: ../raster/r.drain/main.c:190
-#, c-format
-msgid "Direction raster map <%s> should not be specified for Surface/Hydrology drains"
+#: ../vector/v.in.dxf/main.c:133
+msgid "Layer number: layer name / GRASS compliant name"
 msgstr ""
-#: ../raster/r.drain/main.c:209
-msgid "Specify just one of the -c, -a and -n flags"
+#: ../vector/v.in.dxf/main.c:167
+msgid "Building topology failed"
 msgstr ""
-#: ../raster/r.drain/main.c:240
-#, c-format
-msgid "Starting point %d is outside the current region"
+#: ../vector/v.in.dxf/main.c:173
+msgid "Failed to import DXF file!"
 msgstr ""
-#: ../raster/r.drain/main.c:270 ../raster/r.walk/main.c:675
-#: ../raster/r.cost/main.c:535
+#: ../vector/v.in.dxf/layer_list.c:16
 #, c-format
-msgid "Reading vector map <%s> with start points..."
+msgid "Layer %d: %s\n"
 msgstr ""
-#: ../raster/r.drain/main.c:315
-#, c-format
-msgid "Starting vector map <%s> contains no points in the current region"
+#: ../vector/v.in.dxf/write_vect.c:52
+msgid "Entity handle truncated to 16 characters."
 msgstr ""
-#: ../raster/r.drain/main.c:323
-msgid "No start/stop point(s) specified"
+#: ../vector/v.in.dxf/write_vect.c:91
+msgid "No DXF layers found!"
 msgstr ""
-#: ../raster/r.drain/main.c:398
-msgid "Calculating flow directions..."
+#: ../vector/v.in.dxf/write_vect.c:100
+msgid "Following DXF layers found:"
 msgstr ""
-#: ../raster/r.drain/main.c:467 ../raster/r.in.lidar/main.c:753
-msgid "Writing output raster map..."
+#: ../vector/v.in.dxf/write_vect.c:104
+#, c-format
+msgid "Layer %d: %s"
 msgstr ""
-#: ../raster/r.drain/main.c:689
+#: ../vector/v.in.dxf/write_vect.c:246
 #, c-format
-msgid "direction read: %lf, neighbour found: %i"
+msgid "Unable to add database link for vector map <%s>"
 msgstr ""
-#: ../raster/r.tile/main.c:46
-msgid "Splits a raster map into tiles."
+#: ../vector/v.in.dxf/add_polyline.c:47
+msgid "vertices following flag missing"
 msgstr ""
-#: ../raster/r.tile/main.c:55
-msgid "Output base name"
+#: ../vector/v.info/parse.c:24
+msgid "Print history instead of info and exit"
 msgstr ""
-#: ../raster/r.tile/main.c:62
-msgid "Width of tiles (columns)"
+#: ../vector/v.info/parse.c:30
+msgid ""
+"Print types/names of table columns for specified layer instead of info and "
+"exit"
 msgstr ""
-#: ../raster/r.tile/main.c:69
-msgid "Height of tiles (rows)"
+#: ../vector/v.info/parse.c:35
+msgid "Print region info in shell script style"
 msgstr ""
-#: ../raster/r.tile/main.c:76
-msgid "Overlap of tiles"
+#: ../vector/v.info/parse.c:40
+msgid "Print extended metadata info in shell script style"
 msgstr ""
-#: ../raster/r.tile/main.c:129
-#, c-format
-msgid "Generating %d x %d = %d tiles..."
+#: ../vector/v.info/parse.c:45
+msgid "Print topology info in shell script style"
 msgstr ""
-#: ../raster/r.tile/main.c:184
+#: ../vector/v.info/level1.c:29
 #, c-format
-msgid "Unable to read cats for %s"
+msgid "Topology not available for vector map <%s>. Registering primitives..."
 msgstr ""
-#: ../raster/r.sun/main.c:242 ../raster/r.sunmask/main.c:119
-msgid "shadow"
-msgstr "ēna"
-#: ../raster/r.sun/main.c:243
-msgid "Solar irradiance and irradiation model."
+#: ../vector/v.info/main.c:40 ../raster/r.info/main.c:72
+#: ../locale/scriptstrings/t.info_to_translate.c:4
+#: ../general/g.region/main.c:67 ../raster3d/r3.info/main.c:78
+msgid "extent"
 msgstr ""
-#: ../raster/r.sun/main.c:245
-msgid "Computes direct (beam), diffuse and reflected solar irradiation raster maps for given day, latitude, surface and atmospheric conditions. Solar parameters (e.g. sunrise, sunset times, declination, extraterrestrial irradiance, daylight length) are saved in the map history file. Alternatively, a local time can be specified to compute solar incidence angle and/or irradiance raster maps. The shadowing effect of the topography is optionally incorporated."
-msgstr ""
+#: ../vector/v.info/main.c:41 ../raster/r.info/main.c:73
+msgid "history"
+msgstr "vēsture"
-#: ../raster/r.sun/main.c:259
-msgid "Name of the input elevation raster map [meters]"
+#: ../vector/v.info/main.c:42
+msgid "attribute columns"
 msgstr ""
-#: ../raster/r.sun/main.c:268
-msgid "Name of the input aspect map (terrain aspect or azimuth of the solar panel) [decimal degrees]"
+#: ../vector/v.info/main.c:46
+msgid "Outputs basic information about a vector map."
 msgstr ""
-#: ../raster/r.sun/main.c:277
-msgid "A single value of the orientation (aspect), 270 is south"
+#: ../vector/v.info/print.c:130
+#, c-format
+msgid "Database connection for map <%s> is not defined in DB file"
 msgstr ""
-#: ../raster/r.sun/main.c:286
-msgid "Name of the input slope raster map (terrain slope or solar panel inclination) [decimal degrees]"
+#: ../vector/v.info/print.c:134
+#, c-format
+msgid "Displaying column types/names for database connection of layer <%s>:"
 msgstr ""
-#: ../raster/r.sun/main.c:294
-msgid "A single value of inclination (slope)"
+#: ../vector/v.info/print.c:142
+#, c-format
+msgid "Unable to open driver <%s>"
 msgstr ""
-#: ../raster/r.sun/main.c:303
-msgid "Name of the Linke atmospheric turbidity coefficient input raster map [-]"
+#: ../vector/v.info/print.c:317
+msgid "Name:"
 msgstr ""
-#: ../raster/r.sun/main.c:312
-msgid "A single value of the Linke atmospheric turbidity coefficient [-]"
+#: ../vector/v.info/print.c:320
+msgid "Mapset:"
 msgstr ""
-#: ../raster/r.sun/main.c:321
-msgid "Name of the ground albedo coefficient input raster map [-]"
+#: ../vector/v.info/print.c:324
+msgid "Location:"
 msgstr ""
-#: ../raster/r.sun/main.c:330
-msgid "A single value of the ground albedo coefficient [-]"
+#: ../vector/v.info/print.c:327
+msgid "Database:"
 msgstr ""
-#: ../raster/r.sun/main.c:339
-msgid "Name of input raster map containing latitudes [decimal degrees]"
-msgstr ""
+#: ../vector/v.info/print.c:331
+msgid "Title:"
+msgstr "Virsraksts:"
-#: ../raster/r.sun/main.c:348
-msgid "Name of input raster map containing longitudes [decimal degrees]"
+#: ../vector/v.info/print.c:334
+msgid "Map scale:"
 msgstr ""
-#: ../raster/r.sun/main.c:357
-msgid "Name of real-sky beam radiation coefficient (thick cloud) input raster map [0-1]"
+#: ../vector/v.info/print.c:338
+msgid "Name of creator:"
 msgstr ""
-#: ../raster/r.sun/main.c:366
-msgid "Name of real-sky diffuse radiation coefficient (haze) input raster map [0-1]"
+#: ../vector/v.info/print.c:341
+msgid "Organization:"
 msgstr ""
-#: ../raster/r.sun/main.c:373
-msgid "The horizon information input map basename"
+#: ../vector/v.info/print.c:344
+msgid "Source date:"
 msgstr ""
-#: ../raster/r.sun/main.c:381 ../raster/r.horizon/main.c:211
-msgid "Angle step size for multidirectional horizon [degrees]"
+#: ../vector/v.info/print.c:351
+msgid "Timestamp (first layer): "
 msgstr ""
-#: ../raster/r.sun/main.c:390
-msgid "Output incidence angle raster map (mode 1 only)"
+#: ../vector/v.info/print.c:355
+msgid "Timestamp (first layer): none"
 msgstr ""
-#: ../raster/r.sun/main.c:399
-msgid "Output beam irradiance [W.m-2] (mode 1) or irradiation raster map [Wh.m-2.day-1] (mode 2)"
-msgstr ""
+#: ../vector/v.info/print.c:363 ../vector/v.info/print.c:387
+#: ../vector/v.info/print.c:427
+msgid "Map format:"
+msgstr "Kartes formāts:"
-#: ../raster/r.sun/main.c:408
-msgid "Output diffuse irradiance [W.m-2] (mode 1) or irradiation raster map [Wh.m-2.day-1] (mode 2)"
+#: ../vector/v.info/print.c:368
+msgid "OGR layer:"
 msgstr ""
-#: ../raster/r.sun/main.c:417
-msgid "Output ground reflected irradiance [W.m-2] (mode 1) or irradiation raster map [Wh.m-2.day-1] (mode 2)"
+#: ../vector/v.info/print.c:371
+msgid "OGR datasource:"
 msgstr ""
-#: ../raster/r.sun/main.c:426
-msgid "Output global (total) irradiance/irradiation [W.m-2] (mode 1) or irradiance/irradiation raster map [Wh.m-2.day-1] (mode 2)"
+#: ../vector/v.info/print.c:374 ../vector/v.info/print.c:403
+msgid "Feature type:"
+msgstr "Objektu tips:"
+#: ../vector/v.info/print.c:392
+msgid "DB table:"
+msgstr "DB tabula:"
+#: ../vector/v.info/print.c:395
+msgid "DB name:"
+msgstr "DB nosaukums:"
+#: ../vector/v.info/print.c:399
+msgid "Geometry column:"
 msgstr ""
-#: ../raster/r.sun/main.c:435
-msgid "Output insolation time raster map [h] (mode 2 only)"
+#: ../vector/v.info/print.c:413 ../vector/v.info/print.c:422
+msgid "Topology:"
 msgstr ""
-#: ../raster/r.sun/main.c:442
-msgid "No. of day of the year (1-365)"
+#: ../vector/v.info/print.c:414
+msgid "schema:"
 msgstr ""
-#: ../raster/r.sun/main.c:452
-msgid "Time step when computing all-day radiation sums [decimal hours]"
+#: ../vector/v.info/print.c:418
+msgid "Topology column:"
 msgstr ""
-#: ../raster/r.sun/main.c:460
-msgid "Declination value (overriding the internally computed value) [radians]"
+#: ../vector/v.info/print.c:436
+msgid "Type of map"
 msgstr ""
-#: ../raster/r.sun/main.c:468
-msgid "Local (solar) time (to be set for mode 1 only) [decimal hours]"
+msgid "level"
 msgstr ""
-#: ../raster/r.sun/main.c:492 ../raster/r.horizon/main.c:296
-msgid "Sampling distance step coefficient (0.5-1.5)"
+#: ../vector/v.info/print.c:443
+msgid "Number of points:"
+msgstr "Punktu skaits:"
+#: ../vector/v.info/print.c:445
+msgid "Number of centroids:"
 msgstr ""
-#: ../raster/r.sun/main.c:500
-msgid "Read the input files in this number of chunks"
+#: ../vector/v.info/print.c:450
+msgid "Number of lines:"
+msgstr "Līniju skaits:"
+#: ../vector/v.info/print.c:452
+msgid "Number of boundaries:"
 msgstr ""
-#: ../raster/r.sun/main.c:507
-msgid "Civil time zone value, if none, the time will be local solar time"
+#: ../vector/v.info/print.c:457
+msgid "Number of areas:"
 msgstr ""
-#: ../raster/r.sun/main.c:513
-msgid "Do not incorporate the shadowing effect of terrain"
+#: ../vector/v.info/print.c:459
+msgid "Number of islands:"
 msgstr ""
-#: ../raster/r.sun/main.c:518
-msgid "Use the low-memory version of the program"
+#: ../vector/v.info/print.c:465
+msgid "Number of faces:"
 msgstr ""
-#: ../raster/r.sun/main.c:559
-msgid "You must give the longitude raster if you use civil time"
+#: ../vector/v.info/print.c:467
+msgid "Number of kernels:"
 msgstr ""
-#: ../raster/r.sun/main.c:562
-msgid "Error reading civil time zone value"
+#: ../vector/v.info/print.c:472
+msgid "Number of volumes:"
 msgstr ""
-#: ../raster/r.sun/main.c:565
-msgid "Invalid civil time zone value"
+#: ../vector/v.info/print.c:474
+msgid "Number of holes:"
 msgstr ""
-#: ../raster/r.sun/main.c:590
-msgid "insol_time and incidout are incompatible options"
+#: ../vector/v.info/print.c:481
+msgid "Map is 3D:"
 msgstr ""
-#: ../raster/r.sun/main.c:595
-msgid "Error reading time step size"
+#: ../vector/v.info/print.c:482
+msgid "Yes"
+msgstr "Jā"
+msgid "No"
 msgstr ""
-#: ../raster/r.sun/main.c:597
-msgid "Invalid time step size"
+#: ../vector/v.info/print.c:485
+msgid "Number of dblinks:"
 msgstr ""
-#: ../raster/r.sun/main.c:601
-msgid "Error reading horizon step size"
+#: ../vector/v.info/print.c:498
+msgid "invalid"
 msgstr ""
-#: ../raster/r.sun/main.c:606
-msgid "The horizon step size must be greater than 0."
+#: ../vector/v.info/print.c:500
+msgid "unspecified"
 msgstr ""
-#: ../raster/r.sun/main.c:609
-msgid "If you use the horizon option you must also set the 'horizonstep' parameter."
+#: ../vector/v.info/print.c:505 ../vector/v.info/print.c:510
+#: ../raster/r.in.gdal/main.c:133 ../raster/r.in.gdal/main.c:188
+#: ../raster/r.in.gdal/main.c:195
+msgid "Projection"
 msgstr ""
-#: ../raster/r.sun/main.c:615
-msgid "Time and insol_time are incompatible options"
+#: ../vector/v.info/print.c:506
+msgid "zone"
 msgstr ""
-#: ../raster/r.sun/main.c:617
-msgid "Mode 1: instantaneous solar incidence angle & irradiance using a set local time"
+#: ../vector/v.info/print.c:539
+msgid "Digitization threshold"
 msgstr ""
-#: ../raster/r.sun/main.c:622
-msgid "incidout requires time parameter to be set"
+#: ../vector/v.info/print.c:541
+msgid "Comment"
+msgstr "Komentārs"
+#: ../vector/v.label.sa/main.c:41
+msgid "Create optimally placed labels for vector map(s)"
 msgstr ""
-#: ../raster/r.sun/main.c:624
-msgid "Mode 2: integrated daily irradiation for a given day of the year"
+#: ../vector/v.label.sa/main.c:71
+#, fuzzy
+msgid "Name of TrueType font (as listed in the fontcap)"
+msgstr "Ceļš līdz TrueType fontam (ieskaitot faila nosaukumu)"
+#: ../vector/v.label.sa/main.c:84
+msgid "Icon size of point features (in map-units)"
 msgstr ""
-#: ../raster/r.sun/main.c:647
-#, c-format
-msgid "Using Linke constant: %lf"
+#: ../vector/v.label.sa/main.c:154
+msgid "Border width (only for ps.map output)"
 msgstr ""
-#: ../raster/r.sun/main.c:649
+#: ../vector/v.label.sa/font.c:54
 #, c-format
-msgid "Using Linke map <%s>"
+msgid "%s: Unable to read font definition file; use the default"
 msgstr ""
-#: ../raster/r.sun/main.c:654
+#: ../vector/v.label.sa/font.c:60
 #, c-format
-msgid "Using albedo constant: %lf"
+msgid "%s: No font definition file"
 msgstr ""
-#: ../raster/r.sun/main.c:656
-#, c-format
-msgid "Using albedo map <%s>"
+#: ../vector/v.label.sa/labels.c:68
+#, fuzzy, c-format
+msgid "Cannot allocate %lu bytes of memory"
+msgstr "Nevar atvērt izvēlēto marķieri/kursoru"
+#: ../vector/v.label.sa/labels.c:87
+msgid "Unable to initialise FreeType"
 msgstr ""
-#: ../raster/r.sun/main.c:661
+#: ../vector/v.label.sa/labels.c:90
+#, fuzzy, c-format
+msgid "Unable to find font '%s'\n"
+msgstr "Nevaratvērt datubāzi %s"
+#: ../vector/v.label.sa/labels.c:92
 #, c-format
-msgid "Using slope constant: %lf"
+msgid "Font '%s' is not a FreeType font\n"
 msgstr ""
-#: ../raster/r.sun/main.c:664
-#, c-format
-msgid "Using slope map <%s>"
+#: ../vector/v.label.sa/labels.c:96
+msgid "Font file format is not supported by FreeType"
 msgstr ""
-#: ../raster/r.sun/main.c:669
-#, c-format
-msgid "Using aspect constant: %lf"
+#: ../vector/v.label.sa/labels.c:98
+#, fuzzy
+msgid "Font file can not be loaded"
+msgstr "vektora karte <%s> nav atrasta"
+#: ../vector/v.label.sa/labels.c:107
+#, fuzzy
+msgid "Unable to set font size"
+msgstr "neiespējami atvērt <%s>"
+#: ../vector/v.label.sa/labels.c:128
+#, fuzzy
+msgid "Cannot allocate more memory"
+#: ../vector/v.label.sa/labels.c:244
+#, fuzzy, c-format
+msgid "Cannot load glyph for '%c'"
+msgstr "Nevar nolasīt faila informāciju"
+#: ../vector/v.in.region/main.c:43
+msgid "Creates a vector polygon from the current region extent."
 msgstr ""
-#: ../raster/r.sun/main.c:672
-#, c-format
-msgid "Using aspect map <%s>"
+#: ../vector/v.in.region/main.c:51
+msgid "Select type: line or area"
+msgstr "Izvēlēties tipu: līnija vai poligons"
+#: ../vector/v.in.region/main.c:58
+msgid "Densify lines using region resolution"
 msgstr ""
-#: ../raster/r.sun/main.c:687
-msgid "If you use -s and no horizon rasters, numpartitions must be =1"
+#: ../vector/v.to.rast3/main.c:51
+msgid "Converts a vector map (only points) into a 3D raster map."
 msgstr ""
-#: ../raster/r.sun/main.c:700
-msgid "If you want to save memory and to use shadows, you must use pre-calculated horizons."
+#: ../vector/v.to.rast3/main.c:62
+msgid "Name of attribute column (data type must be numeric)"
 msgstr ""
-#: ../raster/r.sun/main.c:763 ../raster/r.horizon/main.c:548
-#: ../raster/r.latlong/main.c:114 ../display/d.grid/plot.c:561
-#: ../display/d.grid/plot.c:588 ../display/d.where/main.c:120
-#: ../display/d.where/main.c:146 ../ps/ps.map/do_geogrid.c:278
-msgid "Unable to set up lat/long projection parameters"
+#: ../vector/v.to.rast3/main.c:107
+msgid "Unable to create output map"
 msgstr ""
-#: ../raster/r.sun/main.c:767
-msgid "latin and longin raster maps have no effect when in a Lat/Lon location"
+#: ../vector/v.to.rast3/main.c:157
+msgid "Unable to close new 3d raster map"
 msgstr ""
-#: ../raster/r.sun/main.c:772
-msgid "Both latin and longin raster maps must be given, or neither"
+#: ../vector/v.colors.out/main.c:53
+msgid "Exports the color table associated with a vector map."
 msgstr ""
-#: ../raster/r.out.pov/main.c:124
-msgid "Converts a raster map layer into a height-field file for POV-Ray."
+#: ../vector/v.colors.out/main.c:61 ../raster/r.colors.out/raster_main.c:55
+#: ../raster/r.colors.out/raster3d_main.c:56
+msgid "Path to output rules file"
 msgstr ""
-#: ../raster/r.out.pov/main.c:131
-msgid "Name of output povray file (TGA height field file)"
+#: ../vector/v.colors.out/main.c:62 ../raster/r.kappa/main.c:89
+#: ../raster/r.colors.out/raster_main.c:56
+#: ../raster/r.colors.out/raster3d_main.c:57
+msgid "If not given write to standard output"
 msgstr ""
-#: ../raster/r.out.pov/main.c:138
-msgid "Height-field type (0=actual heights 1=normalized)"
+#: ../vector/v.colors.out/main.c:66
+msgid "Name of attribute (numeric) column to which refer color rules"
 msgstr ""
-#: ../raster/r.out.pov/main.c:144
-msgid "Elevation bias"
+#: ../vector/v.colors.out/main.c:67
+msgid "If not given, color rules refer to categories"
 msgstr ""
-#: ../raster/r.out.pov/main.c:150 ../raster/r.param.scale/interface.c:118
-msgid "Vertical scaling factor"
+#: ../vector/v.colors.out/main.c:72 ../raster/r.colors.out/raster_main.c:61
+#: ../raster/r.colors.out/raster3d_main.c:62
+msgid "Output values as percentages"
 msgstr ""
-#: ../raster/r.out.pov/main.c:170
+#: ../vector/v.colors.out/main.c:85
 #, c-format
-msgid "Invalid output filename <%s>"
+msgid "Unable to read color table for vector map <%s>"
 msgstr ""
-#: ../raster/r.out.pov/main.c:180
+#: ../vector/v.colors.out/main.c:88
 #, c-format
-msgid "Raster map is too big! Exceeds %d columns or %d rows"
+msgid "No color table defined for vector map <%s>"
 msgstr ""
-#: ../raster/r.out.pov/main.c:201
-msgid "Negative elevation values in input"
-msgstr ""
-#: ../raster/r.resamp.filter/main.c:142
+#: ../vector/v.colors.out/main.c:103 ../raster/r.out.vrml/main.c:131
+#: ../raster/r.out.pov/main.c:173 ../raster/r.out.mat/main.c:91
+#: ../raster/r.support/main.c:162 ../raster/r.colors.out/raster_main.c:79
+#: ../raster/r.colors.out/raster3d_main.c:80 ../raster/r.out.png/main.c:205
+#: ../general/g.cairocomp/main.c:66 ../raster3d/r3.support/main.c:153
 #, c-format
-msgid "Filter <%s> not found"
+msgid "Unable to open output file <%s>"
 msgstr ""
-#: ../raster/r.resamp.filter/main.c:391
-msgid "kernel filter"
+#: ../vector/v.delaunay/main.c:88
+msgid ""
+"Creates a Delaunay triangulation from an input vector map containing points "
+"or centroids."
 msgstr ""
-#: ../raster/r.resamp.filter/main.c:394
-msgid "Resamples raster map layers using an analytic kernel."
+#: ../vector/v.delaunay/main.c:103
+msgid "Output triangulation as a graph (lines), not areas"
 msgstr ""
-#: ../raster/r.resamp.filter/main.c:405
-msgid "Filter kernel(s)"
+#: ../vector/v.delaunay/main.c:147
+msgid "no points to triangulate"
 msgstr ""
-#: ../raster/r.resamp.filter/main.c:413
-msgid "Filter radius"
+#: ../vector/v.delaunay/main.c:150
+msgid "Delaunay triangulation..."
 msgstr ""
-#: ../raster/r.resamp.filter/main.c:420
-msgid "Filter radius (horizontal)"
+#: ../vector/v.delaunay/main.c:162
+msgid "Calculating area centroids..."
 msgstr ""
-#: ../raster/r.resamp.filter/main.c:427
-msgid "Filter radius (vertical)"
+#: ../vector/v.delaunay/main.c:178
+msgid "Unable to calculate area centroid z coordinate"
 msgstr ""
-#: ../raster/r.resamp.filter/main.c:438 ../vector/v.external.out/args.c:90
-#, c-format
-msgid "%s= and %s=/%s= are mutually exclusive"
+#: ../vector/v.delaunay/in_out.c:214
+msgid "Reading point features..."
 msgstr ""
-#: ../raster/r.resamp.filter/main.c:443
-#, c-format
-msgid "Either %s= or %s=/%s= required"
+#: ../vector/v.delaunay/memory.c:64 ../vector/v.delaunay/memory.c:70
+#: ../vector/v.delaunay/memory.c:74 ../vector/v.delaunay/memory.c:84
+#: ../vector/v.delaunay/memory.c:92 ../vector/v.delaunay/memory.c:104
+#: ../vector/v.delaunay/memory.c:108
+msgid "Not enough memory."
 msgstr ""
-#: ../raster/r.resamp.filter/main.c:446
-#, c-format
-msgid "Both %s= and %s= required"
+#: ../vector/v.delaunay/memory.c:124
+msgid "All allocated edges have been used."
 msgstr ""
-#: ../raster/r.resamp.filter/main.c:469
-msgid "Differing number of values for filter= and [xy_]radius="
+#: ../vector/v.net.centrality/main.c:98
+msgid "centrality measures"
 msgstr ""
-#: ../raster/r.resamp.filter/main.c:472
-#, c-format
-msgid "Too many filters (max: %d)"
+#: ../vector/v.net.centrality/main.c:100
+msgid ""
+"Computes degree, centrality, betweeness, closeness and eigenvector "
+"centrality measures in the network."
 msgstr ""
-#: ../raster/r.resamp.filter/main.c:490
-msgid "At least one filter must be finite"
+#: ../vector/v.net.centrality/main.c:148
+msgid "Name of degree centrality column"
 msgstr ""
-#: ../raster/r.surf.fractal/spec_syn.c:60
-msgid "Preliminary surface calculations..."
+#: ../vector/v.net.centrality/main.c:154
+msgid "Name of closeness centrality column"
 msgstr ""
-#: ../raster/r.surf.fractal/spec_syn.c:119
-#, c-format
-msgid "Calculating surface %d (of %d)..."
+#: ../vector/v.net.centrality/main.c:160
+msgid "Name of betweenness centrality column"
 msgstr ""
-#: ../raster/r.surf.fractal/process.c:54
-msgid "Unable to allocate data buffer. Check current region with g.region."
+#: ../vector/v.net.centrality/main.c:166
+msgid "Name of eigenvector centrality column"
 msgstr ""
-#: ../raster/r.surf.fractal/main.c:40
-msgid "fractal"
+#: ../vector/v.net.centrality/main.c:175
+msgid "Maximum number of iterations to compute eigenvector centrality"
 msgstr ""
-#: ../raster/r.surf.fractal/main.c:42
-msgid "Creates a fractal surface of a given fractal dimension."
+#: ../vector/v.net.centrality/main.c:183
+msgid "Cumulative error tolerance for eigenvector centrality"
 msgstr ""
-#: ../raster/r.surf.fractal/main.c:48
-msgid "Fractal dimension of surface (2 < D < 3)"
+#: ../vector/v.net.centrality/main.c:321
+msgid "Computing degree centrality measure"
 msgstr ""
-#: ../raster/r.surf.fractal/main.c:55
-msgid "Number of intermediate images to produce"
+#: ../vector/v.net.centrality/main.c:325
+msgid "Computing betweenness and/or closeness centrality measure"
 msgstr ""
-#: ../raster/r.surf.fractal/main.c:79
-#, c-format
-msgid "Fractal dimension of %.2lf must be between 2 and 3."
+#: ../vector/v.net.centrality/main.c:332
+msgid "Computing eigenvector centrality measure"
 msgstr ""
-#: ../raster/r.spread/main.c:107 ../raster/r.ros/main.c:214
-msgid "spread"
+#: ../vector/v.net.centrality/main.c:339
+msgid "Writing data into the table..."
 msgstr ""
-#: ../raster/r.spread/main.c:108 ../raster/r.lake/main.c:152
-#: ../raster/r.ros/main.c:216
-msgid "hazard"
+#: ../vector/v.drape/main.c:62
+msgid "Converts 2D vector features to 3D by sampling of elevation raster map."
 msgstr ""
-#: ../raster/r.spread/main.c:109 ../raster/r.sim/r.sim.sediment/main.c:119
-#: ../raster/r.sim/r.sim.water/main.c:118 ../raster/r.ros/main.c:217
-#: ../raster/r.topmodel/main.c:53
-msgid "model"
+#: ../vector/v.drape/main.c:83 ../vector/v.extrude/main.c:124
+msgid "Elevation raster map for height extraction"
 msgstr ""
-#: ../raster/r.spread/main.c:111
-msgid "Simulates elliptically anisotropic spread."
+#: ../vector/v.drape/main.c:87 ../vector/v.drape/main.c:94
+#: ../vector/v.drape/main.c:101 ../vector/v.extrude/main.c:79
+#: ../vector/v.extrude/main.c:125 ../vector/v.extrude/main.c:129
+#: ../vector/v.extrude/main.c:136 ../vector/v.extrude/main.c:143
+msgid "Elevation"
 msgstr ""
-#: ../raster/r.spread/main.c:113
-msgid "Generates a raster map of the cumulative time of spread, given raster maps containing the rates of spread (ROS), the ROS directions and the spread origins. It optionally produces raster maps to contain backlink UTM coordinates for tracing spread paths. Usable for fire spread simulations."
+#: ../vector/v.drape/main.c:92 ../vector/v.extrude/main.c:134
+msgid "Scale factor sampled raster values"
 msgstr ""
-#: ../raster/r.spread/main.c:127
-msgid "Raster map containing base ROS (cm/min)"
+#: ../vector/v.drape/main.c:100 ../vector/v.extrude/main.c:142
+msgid "Height for sampled raster NULL values"
 msgstr ""
-#: ../raster/r.spread/main.c:129
-msgid "Name of an existing raster map layer in the user's current mapset search path containing the ROS values in the directions perpendicular to maximum ROSes' (cm/minute). These ROSes are also the ones without the effect of directional factors."
+#: ../vector/v.drape/main.c:199
+#, c-format
+msgid "Undefined height for feature %d. Skipping."
 msgstr ""
-#: ../raster/r.spread/main.c:141
-msgid "Raster map containing maximal ROS (cm/min)"
+#: ../vector/v.drape/main.c:204
+msgid "Copying attribute tables..."
 msgstr ""
-#: ../raster/r.spread/main.c:143
-msgid "Name of an existing raster map layer in the user's current mapset search path containing the maximum ROS values (cm/minute)."
+#: ../vector/v.decimate/main.c:126
+msgid "decimation"
 msgstr ""
-#: ../raster/r.spread/main.c:153
-msgid "Raster map containing directions of maximal ROS (degree)"
+#: ../vector/v.decimate/main.c:132
+msgid "Decimates a point cloud"
 msgstr ""
-#: ../raster/r.spread/main.c:155
-msgid "Name of an existing raster map layer in the user's current mapset search path containing directions of the maximum ROSes, clockwise from north (degree)."
+#: ../vector/v.decimate/main.c:133
+msgid ""
+"Copies points from one vector to another while applying different decimations"
 msgstr ""
-#: ../raster/r.spread/main.c:166
-msgid "Raster map containing starting sources"
+#: ../vector/v.decimate/main.c:161
+msgid "Throw away every n-th point"
 msgstr ""
-#: ../raster/r.spread/main.c:168
-msgid "Name of an existing raster map layer in the user's current mapset search path containing starting locations of the spread phenomenon. Any positive integers in this map are recognized as starting sources (seeds)."
+#: ../vector/v.decimate/main.c:163
+msgid ""
+"For example, 5 will import 80 percent of points. If not specified, all "
+"points are copied"
 msgstr ""
-#: ../raster/r.spread/main.c:179
-msgid "Raster map containing maximal spotting distance (m, required with -s)"
-msgstr ""
+#: ../vector/v.decimate/main.c:165 ../vector/v.decimate/main.c:176
+#: ../vector/v.decimate/main.c:186 ../vector/v.decimate/main.c:195
+msgid "Count"
+msgstr "Skaits"
-#: ../raster/r.spread/main.c:181
-msgid "Name of an existing raster map layer in the user's current mapset search path containing the maximum potential spotting distances (meters)."
+#: ../vector/v.decimate/main.c:172
+msgid "Preserve only every n-th point"
 msgstr ""
-#: ../raster/r.spread/main.c:191
-msgid "Raster map containing midflame wind speed (ft/min, required with -s)"
+#: ../vector/v.decimate/main.c:174
+msgid ""
+"For example, 4 will import 25 percent of points. If not specified, all "
 msgstr ""
-#: ../raster/r.spread/main.c:193 ../raster/r.ros/main.c:279
-msgid "Name of an existing raster map layer in the user's current mapset search path containing wind velocities at half of the average flame height (feet/minute)."
+#: ../vector/v.decimate/main.c:193
+msgid "Copy only n points"
 msgstr ""
-#: ../raster/r.spread/main.c:203
-msgid "Raster map containing fine fuel moisture of the cell receiving a spotting firebrand (%, required with -s)"
+#: ../vector/v.decimate/main.c:194
+msgid "Copies only the given number of points"
 msgstr ""
-#: ../raster/r.spread/main.c:205 ../raster/r.ros/main.c:240
-msgid "Name of an existing raster map layer in the user's current mapset search path containing the 1-hour (<.25\") fuel moisture (percentage content multiplied by 100)."
+#: ../vector/v.decimate/main.c:201
+msgid "Minimal difference of z values"
 msgstr ""
-#: ../raster/r.spread/main.c:215
-msgid "Basic sampling window size needed to meet certain accuracy (3)"
+#: ../vector/v.decimate/main.c:203
+msgid "Minimal difference between z values in grid-based decimation"
 msgstr ""
-#: ../raster/r.spread/main.c:217
-msgid "An odd integer ranging 3 - 15 indicating the basic sampling window size within which all cells will be considered to see whether they will be reached by the current spread cell. The default number is 3 which means a 3x3 window."
+#: ../vector/v.decimate/main.c:204 ../vector/v.decimate/main.c:214
+#: ../vector/v.decimate/main.c:219 ../vector/v.decimate/main.c:225
+#: ../vector/v.decimate/main.c:230 ../vector/v.decimate/main.c:235
+msgid "Grid"
 msgstr ""
-#: ../raster/r.spread/main.c:227
-msgid "Sampling density for additional computing (range: 0.0 - 1.0 (0.5))"
+#: ../vector/v.decimate/main.c:211
+msgid "Preserve only n points per grid cell"
 msgstr ""
-#: ../raster/r.spread/main.c:229
-msgid "A decimal number ranging 0.0 - 1.0 indicating additional sampling cells will be considered to see whether they will be reached by the current spread cell. The closer to 1.0 the decimal number is, the longer the program will run and the higher the simulation accuracy will be. The default number is 0.5."
+#: ../vector/v.decimate/main.c:213
+msgid ""
+"Preserves only the given number of points per grid cell in grid-based "
+"decimation"
 msgstr ""
-#: ../raster/r.spread/main.c:241
-msgid "Initial time for current simulation (0) (min)"
+#: ../vector/v.decimate/main.c:218
+msgid "Apply grid-based decimation"
 msgstr ""
-#: ../raster/r.spread/main.c:243
-msgid "A non-negative number specifying the initial time for the current spread simulation (minutes). This is useful when multiple phase simulation is conducted. The default time is 0."
+#: ../vector/v.decimate/main.c:224
+msgid "Use only first point in grid cell during grid-based decimation"
 msgstr ""
-#: ../raster/r.spread/main.c:252
-msgid "Simulating time duration LAG (fill the region) (min)"
+#: ../vector/v.decimate/main.c:229
+msgid "Only one point per cat in grid cell"
 msgstr ""
-#: ../raster/r.spread/main.c:254
-msgid "A non-negative integer specifying the simulating duration time lag (minutes). The default is infinite, but the program will terminate when the current geographic region/mask has been filled. It also controls the computational time, the shorter the time lag, the faster the program will run."
+#: ../vector/v.decimate/main.c:234
+msgid "Use z in grid decimation"
 msgstr ""
-#: ../raster/r.spread/main.c:266
-msgid "Name of raster map as a display backdrop"
+#: ../vector/v.decimate/main.c:240
+msgid "Store only the coordinates, throw away categories"
 msgstr ""
-#: ../raster/r.spread/main.c:268
-msgid "Name of an existing raster map layer in the user's current mapset search path to be used as the background on which the \"live\" movement will be shown."
+#: ../vector/v.decimate/main.c:242
+msgid "Do not story any categories even if they are present in input data"
 msgstr ""
-#: ../raster/r.spread/main.c:279
-msgid "Raster map to contain output spread time (min)"
+#: ../vector/v.decimate/main.c:276
+#, c-format
+msgid ""
+"Input layer must be set to a particular layer, not <%s>, when using <%s> "
+"option or <-%c> flag"
 msgstr ""
-#: ../raster/r.spread/main.c:281
-msgid "Name of the new raster map layer to contain the results of the cumulative spread time needed for a phenomenon to reach each cell from the starting sources (minutes)."
+#: ../vector/v.decimate/main.c:318
+msgid "Cannot use z for decimation, input is not 3D"
 msgstr ""
-#: ../raster/r.spread/main.c:291
-msgid "Name of raster map to contain X back coordinates"
+#: ../vector/v.decimate/main.c:320
+msgid "Cannot select by z range, input is not 3D"
 msgstr ""
-#: ../raster/r.spread/main.c:293
-msgid "Name of the new raster map layer to contain the results of backlink information in UTM easting coordinates for each cell."
+#: ../vector/v.decimate/main.c:350
+msgid ""
+"Settings for count-based decimation would cause it to do nothing and no "
+"other options has been set."
 msgstr ""
-#: ../raster/r.spread/main.c:303
-msgid "Name of raster map to contain Y back coordinates"
+#: ../vector/v.extrude/db.c:27
+#, c-format
+msgid "Unable to select attributes category %d"
 msgstr ""
-#: ../raster/r.spread/main.c:305
-msgid "Name of the new raster map layer to contain the results of backlink information in UTM northing coordinates for each cell."
+#: ../vector/v.extrude/main.c:72
+msgid ""
+"Extrudes flat vector features to 3D vector features with defined height."
 msgstr ""
-#: ../raster/r.spread/main.c:312
-msgid "DISPLAY 'live' spread process on screen"
+#: ../vector/v.extrude/main.c:74
+msgid ""
+"Optionally the height can be derived from sampling of elevation raster map."
 msgstr ""
-#: ../raster/r.spread/main.c:314
-msgid "Display the 'live' simulation on screen. A graphics window must be opened and selected before using this option."
+#: ../vector/v.extrude/main.c:78
+msgid "Trace elevation"
 msgstr ""
-#: ../raster/r.spread/main.c:320
-msgid "Consider spotting effect (for wildfires)"
+#: ../vector/v.extrude/main.c:118
+msgid "Name of attribute column with feature height"
 msgstr ""
-#: ../raster/r.spread/main.c:324
-msgid "Use start raster map values in output spread time raster map"
+#: ../vector/v.extrude/main.c:151
+#, c-format
+msgid "One of '%s' or '%s' parameters must be set"
 msgstr ""
-#: ../raster/r.spread/main.c:326
-msgid "Designed to be used with output of previous run of r.spread when computing spread iteratively. The values in start raster map are considered as time. Allowed values in raster map are from zero to the value of init_time option. If not enabled, init_time is used in the area of start raster map"
+#: ../vector/v.extrude/main.c:202
+#, c-format
+msgid ""
+"Invalid layer number (%d). Parameter '%s', '%s' or '%s' specified, assuming "
+"layer '1'."
 msgstr ""
-#: ../raster/r.spread/main.c:502
-msgid "Reading inputs..."
+#: ../vector/v.extrude/main.c:234
+#, c-format
+msgid "Column <%s> does not exist"
 msgstr ""
-#: ../raster/r.spread/main.c:543
+#: ../vector/v.extrude/main.c:243
 #, c-format
-msgid "Maximum of start raster map is grater than init_time (%d > %d)"
+msgid "Column <%s>: invalid data type"
 msgstr ""
-#: ../raster/r.spread/main.c:547
+#: ../vector/v.extrude/main.c:265
+msgid "Extruding areas..."
+msgstr ""
+#: ../vector/v.extrude/main.c:287
 #, c-format
-msgid "Minimum of start raster map is less than zero (%d < 0)"
+msgid "No category defined for area %d. Using default fixed height %f."
 msgstr ""
-#: ../raster/r.spread/main.c:555
+#: ../vector/v.extrude/main.c:293
 #, c-format
-msgid "Reading %s..."
+msgid ""
+"Unable to fetch height from DB for area %d. Using default fixed height %f."
 msgstr ""
-#: ../raster/r.walk/main.c:181 ../raster/r.cost/main.c:143
-#: ../vector/v.net.alloc/main.c:59
-msgid "cost allocation"
+#: ../vector/v.extrude/main.c:319
+msgid "Extruding features..."
 msgstr ""
-#: ../raster/r.walk/main.c:183
-msgid "Creates a raster map showing the anisotropic cumulative cost of moving between different geographic locations on an input raster map whose cell category values represent cost."
+#: ../vector/v.extrude/main.c:340
+#, c-format
+msgid "No category defined for feature %d. Using default fixed height %f."
 msgstr ""
-#: ../raster/r.walk/main.c:193
-msgid "Name of input raster map containing friction costs"
+#: ../vector/v.extrude/main.c:346
+#, c-format
+msgid ""
+"Unable to fetch height from DB for line %d. Using default fixed height %f."
 msgstr ""
-#: ../raster/r.walk/main.c:196
-msgid "Name for output raster map to contain walking costs"
+#: ../vector/v.extrude/main.c:364
+msgid "Copying attribute table..."
 msgstr ""
-#: ../raster/r.walk/main.c:202 ../raster/r.cost/main.c:167
-msgid "Name for output raster map to contain movement directions"
+#: ../raster/r.geomorphon/main.c:103
+msgid ""
+"Calculates geomorphons (terrain forms) and associated geometry using machine "
+"vision approach."
 msgstr ""
-#: ../raster/r.walk/main.c:203 ../raster/r.cost/main.c:161
-#: ../raster/r.cost/main.c:168
-msgid "Optional outputs"
+#: ../raster/r.geomorphon/main.c:105
+msgid "geomorphons"
 msgstr ""
-#: ../raster/r.walk/main.c:208 ../raster/r.cost/main.c:173
-msgid "Name of starting vector points map"
+#: ../raster/r.geomorphon/main.c:106
+msgid "terrain patterns"
 msgstr ""
-#: ../raster/r.walk/main.c:214 ../raster/r.cost/main.c:179
-msgid "Name of stopping vector points map"
+#: ../raster/r.geomorphon/main.c:107
+msgid "machine vision geomorphometry"
 msgstr ""
-#: ../raster/r.walk/main.c:215 ../raster/r.walk/main.c:235
-#: ../raster/r.cost/main.c:180 ../raster/r.cost/main.c:200
-msgid "Stop"
+#: ../raster/r.geomorphon/main.c:127
+msgid "Outer search radius"
 msgstr ""
-#: ../raster/r.walk/main.c:220 ../raster/r.cost/main.c:185
-msgid "Name of starting raster points map"
+#: ../raster/r.geomorphon/main.c:134
+msgid "Inner search radius"
 msgstr ""
-#: ../raster/r.walk/main.c:234 ../raster/r.cost/main.c:199
-msgid "Coordinates of stopping point(s) (E,N)"
+#: ../raster/r.geomorphon/main.c:141
+msgid "Flatenss threshold (degrees)"
 msgstr ""
-#: ../raster/r.walk/main.c:244 ../raster/r.cost/main.c:209
-msgid "Maximum cumulative cost"
+#: ../raster/r.geomorphon/main.c:149
+msgid "Flatenss distance, zero for none"
 msgstr ""
-#: ../raster/r.walk/main.c:253 ../raster/r.cost/main.c:218
-msgid "Cost assigned to null cells. By default, null cells are excluded"
-msgstr "NULL šūnām piešķiramās izmaksas. Parasti NULL šūnas netiek ietvertas"
-#: ../raster/r.walk/main.c:254 ../raster/r.walk/main.c:304
-#: ../raster/r.cost/main.c:219 ../raster/r.cost/main.c:238
-msgid "NULL cells"
-msgstr "NULL šūnas"
-#: ../raster/r.walk/main.c:263 ../raster/r.cost/main.c:228
-msgid "Maximum memory to be used in MB"
+#: ../raster/r.geomorphon/main.c:155
+msgid "Prefix for maps resulting from multiresolution approach"
 msgstr ""
-#: ../raster/r.walk/main.c:273
-msgid "Coefficients for walking energy formula parameters a,b,c,d"
+#: ../raster/r.geomorphon/main.c:156 ../raster/r.geomorphon/main.c:164
+#: ../raster/r.geomorphon/main.c:172
+msgid "Multires"
 msgstr ""
-#: ../raster/r.walk/main.c:283
-msgid "Lambda coefficients for combining walking energy and friction cost"
+#: ../raster/r.geomorphon/main.c:163
+msgid "Distance step for every iteration (zero to omit)"
 msgstr ""
-#: ../raster/r.walk/main.c:293
-msgid "Slope factor determines travel energy cost per height step"
+#: ../raster/r.geomorphon/main.c:171
+msgid "Distance where serch will start in multiple mode (zero to omit)"
 msgstr ""
-#: ../raster/r.walk/main.c:299 ../raster/r.cost/main.c:233
-msgid "Use the 'Knight's move'; slower, but more accurate"
+#: ../raster/r.geomorphon/main.c:177
+msgid "Use meters to define search units (default is cells)"
 msgstr ""
-#: ../raster/r.walk/main.c:303 ../raster/r.cost/main.c:237
-msgid "Keep null values in output raster map"
+#: ../raster/r.geomorphon/main.c:181
+#, fuzzy
+msgid "Use extended form correction"
+msgstr "Nevar izveidot projekcijas failus: %s"
+#: ../raster/r.geomorphon/main.c:196 ../raster/r.watershed/shed/com_line.c:231
+#: ../raster/r.watershed/shed/com_line.c:266 ../general/g.copy/main.c:80
+#: ../general/g.rename/main.c:85 ../imagery/i.landsat.acca/main.c:188
+#: ../imagery/i.ortho.photo/i.ortho.camera/main.c:114
+#: ../imagery/i.landsat.toar/main.c:563
+#, c-format
+msgid "<%s> is an illegal file name"
 msgstr ""
-#: ../raster/r.walk/main.c:308 ../raster/r.cost/main.c:242
-msgid "Start with values in raster map"
+#: ../raster/r.geomorphon/main.c:201
+#, fuzzy, c-format
+msgid "At least one output is required, e.g. %s"
+msgstr "Vaicājuma koordinātes"
+#: ../raster/r.geomorphon/main.c:227
+msgid "Search radius size must cover at least 1 cell"
 msgstr ""
-#: ../raster/r.walk/main.c:313 ../raster/r.cost/main.c:247
-msgid "Print info about disk space and memory requirements and exit"
+#: ../raster/r.geomorphon/main.c:239
+msgid "Skip radius size must be at least 1 cell lower than radius"
 msgstr ""
-#: ../raster/r.walk/main.c:357 ../raster/r.cost/main.c:297
-msgid "Must specify exactly one of start_points, start_rast or coordinate"
+#: ../raster/r.geomorphon/main.c:245
+#, fuzzy
+msgid "Flatenss threshold must be grater than 0"
+msgstr "2 līmeņiem jābūt norādītiem"
+#: ../raster/r.geomorphon/main.c:254
+msgid ""
+"Flatenss distance should be between skip and search radius. Otherwise ignored"
 msgstr ""
-#: ../raster/r.walk/main.c:362 ../raster/r.walk/main.c:845
-#: ../raster/r.cost/main.c:302 ../raster/r.cost/main.c:712
-msgid "No start points"
+#: ../raster/r.geomorphon/main.c:272
+msgid ""
+"For multiresolution mode step must be greater than or equal to resolution of "
+"one cell"
 msgstr ""
-#: ../raster/r.walk/main.c:369 ../raster/r.cost/main.c:309
+#: ../raster/r.geomorphon/main.c:276
 #, c-format
-msgid "Inappropriate maximum cost: %d"
+msgid "<%s> is an incorrect prefix"
 msgstr ""
-#: ../raster/r.walk/main.c:372 ../raster/r.cost/main.c:312
+#: ../raster/r.geomorphon/main.c:368
+#, fuzzy
+msgid "Unknown output data type"
+msgstr "Drukāt tikai rastra kartes tipu"
+#: ../raster/r.geomorphon/memory.c:21
 #, c-format
-msgid "Inappropriate amount of memory: %d"
+msgid ""
+"Region resolution shoudn't be lesser than map %s resolution. Run g.region "
+"raster=%s to set proper resolution"
 msgstr ""
-#: ../raster/r.walk/main.c:377
-#, c-format
-msgid "Missing required value: got %d instead of 4"
+#: ../raster/r.covar/main.c:54
+msgid ""
+"Outputs a covariance/correlation matrix for user-specified raster map "
+"layer(s)."
 msgstr ""
-#: ../raster/r.walk/main.c:380
-#, c-format
-msgid "Walking costs are a=%g b=%g c=%g d=%g"
+#: ../raster/r.covar/main.c:61
+msgid "Print correlation matrix"
 msgstr ""
-#: ../raster/r.walk/main.c:385 ../raster/r.walk/main.c:393
+#: ../raster/r.covar/main.c:86
 #, c-format
-msgid "Missing required value: %d"
+msgid "%s: complete ... "
 msgstr ""
-#: ../raster/r.walk/main.c:388
+#: ../raster/r.covar/main.c:110 ../imagery/i.pca/main.c:197
+msgid "No non-null values"
+msgstr ""
+#: ../raster/r.stream.extract/streams.c:72
+#: ../raster/r.stream.extract/streams.c:668
 #, c-format
-msgid "Lambda is %g"
+msgid "Stream_no %d and n_stream_nodes %lld out of sync"
 msgstr ""
-#: ../raster/r.walk/main.c:396
+#: ../raster/r.stream.extract/streams.c:128
 #, c-format
-msgid "Slope_factor is %g"
+msgid "BUG: stream node %d has only 1 tributary: %d"
 msgstr ""
-#: ../raster/r.walk/main.c:415 ../raster/r.cost/main.c:330
-msgid "Assigning negative cost to null cell. Null cells excluded."
+#: ../raster/r.stream.extract/streams.c:160
+msgid "Calculating flow accumulation..."
 msgstr ""
-#: ../raster/r.walk/main.c:525 ../raster/r.walk/main.c:538
-#: ../raster/r.cost/main.c:412 ../raster/r.cost/main.c:424
+#: ../raster/r.stream.extract/streams.c:336
+#: ../raster/r.watershed/seg/do_cum.c:487
+#: ../raster/r.watershed/ram/do_cum.c:443
 #, c-format
-msgid "Will need at least %.2f MB of disk space"
+msgid "MFD: cumulative proportion of flow distribution not 1.0 but %f"
 msgstr ""
-#: ../raster/r.walk/main.c:527 ../raster/r.walk/main.c:539
-#: ../raster/r.cost/main.c:414 ../raster/r.cost/main.c:425
-#, c-format
-msgid "Will need at least %.2f MB of memory"
+#: ../raster/r.stream.extract/streams.c:392
+msgid "Extracting streams..."
 msgstr ""
-#: ../raster/r.walk/main.c:529 ../raster/r.walk/main.c:540
-#: ../raster/r.cost/main.c:416 ../raster/r.cost/main.c:426
-#, c-format
-msgid "%d of %d segments are kept in memory"
+#: ../raster/r.stream.extract/streams.c:469
+msgid "Bug in stream extraction"
 msgstr ""
-#: ../raster/r.walk/main.c:545 ../raster/r.cost/main.c:431
-msgid "Creating some temporary files..."
+#: ../raster/r.stream.extract/streams.c:631
+msgid "Can't use Montgomery's method, no stream direction found"
 msgstr ""
-#: ../raster/r.walk/main.c:558
+#: ../raster/r.stream.extract/streams.c:700
 #, c-format
-msgid "Reading raster maps <%s> and <%s>, initializing output..."
+msgid ""
+"MFD: A * path already processed when setting drainage direction: %lld of "
+"%lld cells"
 msgstr ""
-#: ../raster/r.walk/main.c:643 ../raster/r.cost/main.c:504
-msgid "Initializing directional output..."
+#: ../raster/r.stream.extract/load.c:33
+msgid "Loading elevation raster map..."
 msgstr ""
-#: ../raster/r.walk/main.c:722
-#, c-format
-msgid "No start points found in vector <%s>"
+#: ../raster/r.stream.extract/load.c:35
+msgid "Loading input raster maps..."
 msgstr ""
-#: ../raster/r.walk/main.c:734 ../raster/r.cost/main.c:598
-#, c-format
-msgid "Reading vector map <%s> with stop points..."
+#: ../raster/r.stream.extract/load.c:44 ../raster/r.stream.extract/load.c:53
+#: ../raster/r.walk/main.c:808 ../raster/r.cost/main.c:673
+#: ../raster/r.texture/h_measure.c:738 ../imagery/i.smap/interp.c:68
+msgid "Unable to allocate memory"
 msgstr ""
-#: ../raster/r.walk/main.c:788 ../raster/r.cost/main.c:652
-#, c-format
-msgid "No stop points found in vector <%s>"
+#: ../raster/r.stream.extract/load.c:95
+msgid "Elevation raster map is NULL but accumulation map is not NULL"
 msgstr ""
-#: ../raster/r.walk/main.c:810 ../raster/r.cost/main.c:675
-#, c-format
-msgid "Reading raster map <%s> with start points..."
+#: ../raster/r.stream.extract/init_search.c:24
+msgid "Initializing A* search..."
 msgstr ""
-#: ../raster/r.walk/main.c:859 ../raster/r.cost/main.c:726
-msgid "Specified starting location outside database window"
+#: ../raster/r.stream.extract/seg.c:20 ../raster/r.stream.extract/cseg.c:19
+#: ../raster/r.stream.extract/bseg.c:19
+msgid "Unable to create segment file"
 msgstr ""
-#: ../raster/r.walk/main.c:879 ../raster/r.cost/main.c:748
-msgid "Finding cost path..."
+#: ../raster/r.stream.extract/seg.c:34 ../raster/r.stream.extract/seg.c:76
+#: ../raster/r.stream.extract/dseg.c:29 ../raster/r.stream.extract/dseg.c:79
+#: ../raster/r.stream.extract/dseg.c:88 ../raster/r.stream.extract/cseg.c:29
+#: ../raster/r.stream.extract/cseg.c:79 ../raster/r.stream.extract/cseg.c:88
+#: ../raster/r.stream.extract/bseg.c:28 ../raster/r.stream.extract/bseg.c:78
+#: ../raster/r.stream.extract/bseg.c:87
+msgid "Unable to write segment file"
 msgstr ""
-#: ../raster/r.walk/main.c:1356 ../raster/r.cost/main.c:1011
-msgid "Error, ct == pres_cell"
+#: ../raster/r.stream.extract/seg.c:38 ../raster/r.stream.extract/cseg.c:33
+#: ../raster/r.stream.extract/bseg.c:32
+msgid "Illegal configuration parameter(s)"
 msgstr ""
-#: ../raster/r.walk/main.c:1368
+#: ../raster/r.stream.extract/seg.c:45
 #, c-format
-msgid "Writing output raster map <%s>... "
+msgid "Unable to re-open file '%s'"
 msgstr ""
-#: ../raster/r.walk/main.c:1432 ../raster/r.cost/main.c:1131
-#, c-format
-msgid "Writing output movement direction raster map <%s>..."
+#: ../raster/r.stream.extract/seg.c:52 ../raster/r.stream.extract/seg.c:94
+#: ../raster/r.stream.extract/seg.c:103 ../raster/r.stream.extract/dseg.c:47
+#: ../raster/r.stream.extract/dseg.c:97 ../raster/r.stream.extract/cseg.c:47
+#: ../raster/r.stream.extract/bseg.c:46 ../raster/r.stream.extract/bseg.c:96
+msgid "Unable to read segment file"
 msgstr ""
-#: ../raster/r.walk/main.c:1477 ../raster/r.cost/main.c:1197
-#, c-format
-msgid "Peak cost value: %g"
+#: ../raster/r.stream.extract/seg.c:85
+msgid "seg_put_row(): could not write segment file"
 msgstr ""
-#: ../raster/r.walk/main.c:1498 ../raster/r.cost/main.c:1219
+#: ../raster/r.stream.extract/close.c:35
 #, c-format
-msgid "Illegal x coordinate <%s>"
-msgstr "Nederīga x koordināta <%s>"
+msgid "Writing vector map <%s>..."
+msgstr ""
-#: ../raster/r.walk/main.c:1500 ../raster/r.cost/main.c:1221
+#: ../raster/r.stream.extract/close.c:123
 #, c-format
-msgid "Illegal y coordinate <%s>"
-msgstr "Nederīga y koordināta <%s>"
-#: ../raster/r.walk/main.c:1504 ../raster/r.cost/main.c:1225
-#, c-format
-msgid "Warning, ignoring point outside window: %g, %g"
+msgid "Stream id %d not set, top is %d, parent is %d"
 msgstr ""
-#: ../raster/r.cost/main.c:145
-msgid "Creates a raster map showing the cumulative cost of moving between different geographic locations on an input raster map whose cell category values represent cost."
+#: ../raster/r.stream.extract/close.c:144
+msgid "Stream id not set while tracing"
 msgstr ""
-#: ../raster/r.cost/main.c:152
-msgid "Name of input raster map containing grid cell cost information"
+#: ../raster/r.stream.extract/close.c:163
+msgid "Writing attribute data..."
 msgstr ""
-#: ../raster/r.cost/main.c:160
-msgid "Name for output raster map with nearest start point"
+#: ../raster/r.stream.extract/close.c:198
+#, c-format
+msgid "Unable to create index on table <%s>"
 msgstr ""
-#: ../raster/r.cost/main.c:444
+#: ../raster/r.stream.extract/close.c:219
 #, c-format
-msgid "Reading raster map <%s>, initializing output..."
+msgid "Unable to insert new row: '%s'"
 msgstr ""
-#: ../raster/r.cost/main.c:489
-#, c-format
-msgid "Negative cell value found at row %d, col %d. Setting negative value to null_cost value"
+#: ../raster/r.stream.extract/close.c:255 ../raster/r.grow.distance/main.c:325
+#: ../raster/r.fill.dir/main.c:253
+msgid "Writing output raster maps..."
 msgstr ""
-#: ../raster/r.cost/main.c:582
+#: ../raster/r.stream.extract/close.c:320
 #, c-format
-msgid "No start points found in vector map <%s>"
+msgid "Unable to write vector map <%s>"
 msgstr ""
-#: ../raster/r.cost/main.c:584
-#, c-format
-msgid "%d point found"
-msgid_plural "%d points found"
-msgstr[0] ""
-msgstr[1] ""
-msgstr[2] ""
+#: ../raster/r.stream.extract/main.c:77 ../raster/r.gwflow/main.c:210
+#: ../raster/r.uslek/main.c:54 ../raster/r.drain/main.c:110
+#: ../raster/r.water.outlet/main.c:58 ../raster/r.solute.transport/main.c:230
+#: ../raster/r.topidx/main.c:40 ../raster/r.topmodel/main.c:52
+#: ../raster/r.usler/main.c:53 ../raster/r.watershed/front/main.c:74
+#: ../raster/r.fill.dir/main.c:87 ../raster/r.basins.fill/main.c:55
+#: ../raster/r.flow/main.c:422 ../raster/r.sim/r.sim.sediment/main.c:115
+#: ../raster/r.sim/r.sim.water/main.c:114 ../raster/r.carve/main.c:75
+#: ../raster/r.lake/main.c:151 ../raster3d/r3.gwflow/main.c:162
+#: ../raster3d/r3.flow/main.c:180
+msgid "hydrology"
+msgstr "hidroloģija"
-#: ../raster/r.cost/main.c:1036
-#, c-format
-msgid "Writing raster map with nearest start point <%s>..."
+#: ../raster/r.stream.extract/main.c:78 ../raster/r.watershed/front/main.c:78
+msgid "stream network"
 msgstr ""
-#: ../raster/r.lake/main.c:153
-msgid "flood"
-msgstr "plūdi"
+#: ../raster/r.stream.extract/main.c:79
+msgid "Performs stream network extraction."
+msgstr ""
-#: ../raster/r.lake/main.c:154
-msgid "Fills lake at given point to given level."
+#: ../raster/r.stream.extract/main.c:85
+msgid "Name of input accumulation raster map"
 msgstr ""
-#: ../raster/r.lake/main.c:160
-msgid "Water level"
-msgstr "Ūdens līmenis"
+#: ../raster/r.stream.extract/main.c:88
+msgid ""
+"Stream extraction will use provided accumulation instead of calculating it "
+"anew"
+msgstr ""
-#: ../raster/r.lake/main.c:170
-msgid "Seed point coordinates"
-msgstr "Sākuma punkta koordinātes"
+#: ../raster/r.stream.extract/main.c:89 ../raster/r.stream.extract/main.c:97
+#: ../raster/r.flow/main.c:435 ../raster/r.flow/main.c:441
+msgid "Input maps"
+msgstr ""
-#: ../raster/r.lake/main.c:171
-msgid "Either this coordinates pair or a seed map have to be specified"
+#: ../raster/r.stream.extract/main.c:93
+msgid "Name of input raster map with real depressions"
 msgstr ""
-#: ../raster/r.lake/main.c:175 ../raster/r.lake/main.c:184
-msgid "Seed"
+#: ../raster/r.stream.extract/main.c:96
+msgid "Streams will not be routed out of real depressions"
 msgstr ""
-#: ../raster/r.lake/main.c:180
-msgid "Input raster map with given starting point(s) (at least 1 cell > 0)"
+#: ../raster/r.stream.extract/main.c:101
+msgid "Minimum flow accumulation for streams"
 msgstr ""
-#: ../raster/r.lake/main.c:182
-msgid "Either this parameter or a coordinates pair have to be specified"
+#: ../raster/r.stream.extract/main.c:102
+msgid "Must be > 0"
 msgstr ""
-#: ../raster/r.lake/main.c:189
-msgid "Use negative depth values for lake raster map"
-msgstr "Izmantot negatīvas vērtības ezera rastra kartei"
+#: ../raster/r.stream.extract/main.c:108
+msgid "Use SFD above this threshold"
+msgstr ""
-#: ../raster/r.lake/main.c:194
-msgid "Overwrite seed map with result (lake) map"
-msgstr "Pārrakstīt sākuma punkta karti ar rezultāta (ezera) karti"
+#: ../raster/r.stream.extract/main.c:110
+msgid ""
+"If accumulation is larger than d8cut, SFD is used instead of MFD. Applies "
+"only if no accumulation map is given."
+msgstr ""
-#: ../raster/r.lake/main.c:201
-msgid "Both seed map and coordinates cannot be specified"
+#: ../raster/r.stream.extract/main.c:121
+msgid "Montgomery exponent for slope, disabled with 0"
 msgstr ""
-#: ../raster/r.lake/main.c:204
-msgid "Seed map or seed coordinates must be set!"
-msgstr "Sākuma punkta kartei vai koordinātām jābūt uzstādītām!"
+#: ../raster/r.stream.extract/main.c:123
+msgid ""
+"Montgomery: accumulation is multiplied with pow(slope,mexp) and then "
+"compared with threshold"
+msgstr ""
-#: ../raster/r.lake/main.c:207
-msgid "Seed coordinates and output map lake= must be set!"
-msgstr "Sākuma punkta koordinātēm un izvades kartei lake= jābūt uz uzstādītiem!"
+#: ../raster/r.stream.extract/main.c:131
+msgid "Delete stream segments shorter than stream_length cells"
+msgstr ""
-#: ../raster/r.lake/main.c:210
-msgid "Both lake and overwrite cannot be specified"
+#: ../raster/r.stream.extract/main.c:133
+msgid "Applies only to first-order stream segments (springs/stream heads)"
 msgstr ""
-#: ../raster/r.lake/main.c:213
-msgid "Output lake map or overwrite flag must be set!"
-msgstr "Izvades kartei lake ir jābūt uzstādītai vai jābūt uzstādītam pārrakstīšanas karogam!"
+#: ../raster/r.stream.extract/main.c:146
+msgid "Name for output raster map with unique stream ids"
+msgstr ""
-#: ../raster/r.lake/main.c:240
-msgid "Seed point outside the current region"
+#: ../raster/r.stream.extract/main.c:148 ../raster/r.stream.extract/main.c:155
+#: ../raster/r.stream.extract/main.c:162 ../raster/r.flow/main.c:459
+#: ../raster/r.flow/main.c:465 ../raster/r.flow/main.c:471
+msgid "Output maps"
+msgstr "Izvades kartes"
+#: ../raster/r.stream.extract/main.c:153
+msgid "Name for output vector map with unique stream ids"
 msgstr ""
-#: ../raster/r.lake/main.c:254
-msgid "G_malloc: out of memory"
-msgstr "G_malloc: pietrūkst atmiņas"
+#: ../raster/r.stream.extract/main.c:160
+msgid "Name for output raster map with flow direction"
+msgstr ""
-#: ../raster/r.lake/main.c:276
-msgid "Given water level at seed point is below earth surface. Increase water level or move seed point."
+#: ../raster/r.stream.extract/main.c:191
+#, c-format
+msgid "Threshold must be > 0 but is %f"
 msgstr ""
-#: ../raster/r.lake/main.c:355
+#: ../raster/r.stream.extract/main.c:200
 #, c-format
-msgid "Lake depth from %f to %f (specified water level is taken as zero)"
+msgid "d8cut must be positive or zero but is %f"
 msgstr ""
-#: ../raster/r.lake/main.c:356
+#: ../raster/r.stream.extract/main.c:208
 #, c-format
-msgid "Lake area %f square meters"
-msgstr "Ezera laukums %f kvadrātmetri"
+msgid "Montgomery exponent must be positive or zero but is %f"
+msgstr ""
-#: ../raster/r.lake/main.c:357
+#: ../raster/r.stream.extract/main.c:211
 #, c-format
-msgid "Lake volume %f cubic meters"
-msgstr "Ezera tilpums ir %f kubikmetri"
+msgid "Montgomery exponent is %f, recommended range is 0.0 - 3.0"
+msgstr ""
-#: ../raster/r.lake/main.c:358
-msgid "Volume is correct only if lake depth (terrain raster map) is in meters"
-msgstr "Uzmanību. Tilpums ir korekts tikai tad, ja dziļums (reljefa karte) ir metros"
-#: ../raster/r.sim/simlib/hydro.c:203
+#: ../raster/r.stream.extract/main.c:221
 #, c-format
-msgid "nwalk (%d) > maxw (%d)!"
+msgid "Minimum stream length must be positive or zero but is %d"
 msgstr ""
-#: ../raster/r.sim/simlib/hydro.c:398
-msgid "Unable to write raster maps"
+#: ../raster/r.stream.extract/main.c:230
+#, c-format
+msgid "Memory must be positive but is %d"
 msgstr ""
-#: ../raster/r.sim/simlib/hydro.c:465 ../raster/r.sim/r.sim.sediment/main.c:411
-msgid "Cannot write raster maps"
+#: ../raster/r.stream.extract/main.c:240
+msgid "At least one output raster maps must be specified"
 msgstr ""
-#: ../raster/r.sim/simlib/observation_points.c:64
+#: ../raster/r.stream.extract/main.c:314
 #, c-format
-msgid "Unable to read points from map %s"
+msgid "%.2f%% of data are kept in memory"
 msgstr ""
-#: ../raster/r.sim/simlib/observation_points.c:85
+#: ../raster/r.stream.extract/main.c:318
+#: ../raster/r.watershed/seg/init_vars.c:252
 #, c-format
-msgid "Unable to open observation logfile %s for writing"
+msgid "Will need up to %.2f MB of disk space"
 msgstr ""
-#: ../raster/r.sim/simlib/output.c:321 ../raster/r.sim/simlib/output.c:329
+#: ../raster/r.stream.extract/main.c:320
+#: ../raster/r.watershed/seg/init_vars.c:254
 #, c-format
-msgid "FP raster map <%s> not found"
+msgid "Will need up to %.2f GB (%.0f MB) of disk space"
 msgstr ""
-#: ../raster/r.sim/simlib/input.c:307
-#, c-format
-msgid "Raster map <%s> not found, and manin_val undefined, choose one to be allowed to process"
+#: ../raster/r.stream.extract/main.c:324
+msgid "Creating temporary files..."
 msgstr ""
-#: ../raster/r.sim/simlib/input.c:420
-msgid "Zero value in Mannings n"
+#: ../raster/r.stream.extract/main.c:344
+msgid "Unable to load input raster map(s)"
 msgstr ""
-#: ../raster/r.sim/simlib/input.c:471
-msgid "Infiltration exceeds the rainfall rate everywhere! No overland flow."
+#: ../raster/r.stream.extract/main.c:346
+msgid "No non-NULL cells in input raster map(s)"
 msgstr ""
-#: ../raster/r.sim/simlib/input.c:495
-#, c-format
-msgid ""
-"Min elevation \t= %.2f m\n"
-"Max elevation \t= %.2f m\n"
+#: ../raster/r.stream.extract/main.c:397
+msgid "Unable to initialize search"
 msgstr ""
-#: ../raster/r.sim/simlib/input.c:497
-#, c-format
-msgid "Mean Source Rate (rainf. excess or sediment) \t= %f m/s or kg/m2s \n"
+#: ../raster/r.stream.extract/main.c:401
+msgid "Unable to sort elevation raster map values"
 msgstr ""
-#: ../raster/r.sim/simlib/input.c:499
-#, c-format
-msgid "Mean flow velocity \t= %f m/s\n"
+#: ../raster/r.stream.extract/main.c:407
+msgid "Unable to calculate flow accumulation"
 msgstr ""
-#: ../raster/r.sim/simlib/input.c:500
+#: ../raster/r.stream.extract/main.c:412
+msgid "Unable to extract streams"
+msgstr ""
+#: ../raster/r.stream.extract/main.c:419
+msgid "Unable to thin streams"
+msgstr ""
+#: ../raster/r.stream.extract/main.c:424
+msgid "Unable to delete short stream segments"
+msgstr ""
+#: ../raster/r.stream.extract/main.c:430
+msgid "Unable to write output raster maps"
+msgstr ""
+#: ../raster/r.stream.extract/dseg.c:19
+msgid "dseg_open(): unable to create segment file"
+msgstr ""
+#: ../raster/r.stream.extract/dseg.c:33
+msgid "Iillegal configuration parameter(s)"
+msgstr ""
+#: ../raster/r.stream.extract/dseg.c:40 ../raster/r.stream.extract/cseg.c:40
+#: ../raster/r.stream.extract/bseg.c:39
+msgid "Unable to re-open segment file"
+msgstr ""
+#: ../raster/r.stream.extract/dseg.c:120
 #, c-format
-msgid "Mean Mannings \t= %f\n"
+msgid "Inable to segment put row %d for raster <%s>"
 msgstr ""
-#: ../raster/r.sim/simlib/input.c:504
+#: ../raster/r.stream.extract/del_streams.c:130
 #, c-format
-msgid "Number of iterations \t= %d cell\n"
-msgid_plural "Number of iterations \t= %d cells\n"
+msgid "Deleting stream segments shorter than %d cell..."
+msgid_plural "Deleting stream segments shorter than %d cells..."
 msgstr[0] ""
 msgstr[1] ""
 msgstr[2] ""
-#: ../raster/r.sim/simlib/input.c:506
+#: ../raster/r.stream.extract/del_streams.c:193
 #, c-format
-msgid "Time step \t= %.2f s\n"
-msgstr ""
+msgid "%d stream segment deleted"
+msgid_plural "%d stream segments deleted"
+msgstr[0] ""
+msgstr[1] ""
+msgstr[2] ""
-#: ../raster/r.sim/simlib/input.c:508
+#: ../raster/r.stream.extract/do_astar.c:40
+msgid "A* Search..."
+msgstr "A* meklēšana..."
+#: ../raster/r.stream.extract/do_astar.c:62
 #, c-format
-msgid ""
-"Sigmax \t= %f\n"
-"Max velocity \t= %f m/s\n"
+msgid "%lld surplus points"
 msgstr ""
-#: ../raster/r.sim/simlib/input.c:510
+#: ../raster/r.stream.extract/do_astar.c:67
 #, c-format
-msgid "Time step used \t= %.2f s\n"
+msgid "Too many points in heap %lld, should be %lld"
 msgstr ""
-#: ../raster/r.sim/simlib/input.c:562
-msgid "Unable to write et file"
+#: ../raster/r.stream.extract/cseg.c:97
+msgid "Unabel to read segment file"
 msgstr ""
-#: ../raster/r.sim/r.sim.sediment/main.c:116
-msgid "sediment flow"
+#: ../raster/r.stream.extract/cseg.c:120
+#, c-format
+msgid "Unable to segment put row %d for raster map <%s>"
 msgstr ""
-#: ../raster/r.sim/r.sim.sediment/main.c:118
-msgid "deposition"
+#: ../raster/r.stream.extract/thin.c:83
+msgid "Thinning stream segments..."
 msgstr ""
-#: ../raster/r.sim/r.sim.sediment/main.c:121
-msgid "Sediment transport and erosion/deposition simulation using path sampling method (SIMWE)."
+#: ../raster/r.stream.extract/thin.c:169
+#, c-format
+msgid "%d of %lld stream segments were thinned"
 msgstr ""
-#: ../raster/r.sim/r.sim.sediment/main.c:128
-msgid "Name of water depth raster map [m]"
+#: ../raster/r.gwflow/main.c:57
+msgid "Name of input raster map with initial piezometric head in [m]"
 msgstr ""
-#: ../raster/r.sim/r.sim.sediment/main.c:132
-#: ../raster/r.sim/r.sim.water/main.c:127
-msgid "Name of x-derivatives raster map [m/m]"
+#: ../raster/r.gwflow/main.c:62
+msgid ""
+"Name of input raster map providing boundary condition status: 0-inactive, 1-"
+"active, 2-dirichlet"
 msgstr ""
-#: ../raster/r.sim/r.sim.sediment/main.c:136
-#: ../raster/r.sim/r.sim.water/main.c:131
-msgid "Name of y-derivatives raster map [m/m]"
+#: ../raster/r.gwflow/main.c:67
+msgid ""
+"Name of input raster map with x-part of the hydraulic conductivity tensor in "
+"[m/s]"
 msgstr ""
-#: ../raster/r.sim/r.sim.sediment/main.c:141
-msgid "Name of detachment capacity coefficient raster map [s/m]"
+#: ../raster/r.gwflow/main.c:72
+msgid ""
+"Name of input raster map with y-part of the hydraulic conductivity tensor in "
+"[m/s]"
 msgstr ""
-#: ../raster/r.sim/r.sim.sediment/main.c:146
-msgid "Name of transport capacity coefficient raster map [s]"
+#: ../raster/r.gwflow/main.c:77
+msgid "Name of input raster map with water sources and sinks in [m^3/s]"
 msgstr ""
-#: ../raster/r.sim/r.sim.sediment/main.c:151
-msgid "Name of critical shear stress raster map [Pa]"
+#: ../raster/r.gwflow/main.c:81
+msgid ""
+"Name of input raster map with storativity for confined or effective porosity "
+"for unconfined groundwater flow booth in [-] "
 msgstr ""
-#: ../raster/r.sim/r.sim.sediment/main.c:156
-#: ../raster/r.sim/r.sim.water/main.c:168
-msgid "Name of Manning's n raster map"
+#: ../raster/r.gwflow/main.c:86
+msgid "Recharge"
 msgstr ""
-#: ../raster/r.sim/r.sim.sediment/main.c:164
-#: ../raster/r.sim/r.sim.water/main.c:176
-msgid "Manning's n unique value"
+#: ../raster/r.gwflow/main.c:88
+msgid "Recharge input raster map e.g: 6*10^-9 per cell in [m^3/s*m^2]"
 msgstr ""
-#: ../raster/r.sim/r.sim.sediment/main.c:171
-#: ../raster/r.sim/r.sim.water/main.c:190
-msgid "Name of sampling locations vector points map"
+#: ../raster/r.gwflow/main.c:92
+msgid ""
+"Name of input raster map describing the top surface of the aquifer in [m]"
 msgstr ""
-#: ../raster/r.sim/r.sim.sediment/main.c:177
-msgid "Name for output transport capacity raster map [kg/ms]"
+#: ../raster/r.gwflow/main.c:96
+msgid ""
+"Name of input raster map describing the bottom surface of the aquifer in [m]"
 msgstr ""
-#: ../raster/r.sim/r.sim.sediment/main.c:184
-msgid "Name for output transport limited erosion-deposition raster map [kg/m2s]"
+#: ../raster/r.gwflow/main.c:100
+msgid "Output raster map storing the numerical result [m]"
 msgstr ""
-#: ../raster/r.sim/r.sim.sediment/main.c:191
-msgid "Name for output sediment concentration raster map [particle/m3]"
+#: ../raster/r.gwflow/main.c:106
+msgid ""
+"Output raster map to store the groundwater filter velocity vector part in x "
+"direction [m/s]"
 msgstr ""
-#: ../raster/r.sim/r.sim.sediment/main.c:197
-msgid "Name for output sediment flux raster map [kg/ms]"
+#: ../raster/r.gwflow/main.c:112
+msgid ""
+"Output raster map to store the groundwater filter velocity vector part in y "
+"direction [m/s]"
 msgstr ""
-#: ../raster/r.sim/r.sim.sediment/main.c:204
-msgid "Name for output erosion-deposition raster map [kg/m2s]"
+#: ../raster/r.gwflow/main.c:118
+msgid "Output raster map to store the groundwater budget for each cell [m^3/s]"
 msgstr ""
-#: ../raster/r.sim/r.sim.sediment/main.c:211
-#: ../raster/r.sim/r.sim.water/main.c:222
-msgid "Name for sampling points output text file. For each observation vector point the time series of sediment transport is stored."
+#: ../raster/r.gwflow/main.c:126
+msgid "The type of groundwater flow"
 msgstr ""
-#: ../raster/r.sim/r.sim.sediment/main.c:218
-#: ../raster/r.sim/r.sim.water/main.c:215
-msgid "Base name of the output walkers vector points map"
+#: ../raster/r.gwflow/main.c:132
+msgid "Name of input raster map providing the height of the river bed in [m]"
 msgstr ""
-#: ../raster/r.sim/r.sim.sediment/main.c:225
-msgid "Number of walkers"
+#: ../raster/r.gwflow/main.c:140
+msgid ""
+"Name of input raster map providing the water level (head) of the river with "
+"leakage connection in [m]"
 msgstr ""
-#: ../raster/r.sim/r.sim.sediment/main.c:226
-#: ../raster/r.sim/r.sim.sediment/main.c:234
-#: ../raster/r.sim/r.sim.sediment/main.c:243
-#: ../raster/r.sim/r.sim.sediment/main.c:261
-#: ../raster/r.sim/r.sim.water/main.c:231
-#: ../raster/r.sim/r.sim.water/main.c:239
-#: ../raster/r.sim/r.sim.water/main.c:248
-#: ../raster/r.sim/r.sim.water/main.c:266
-#: ../raster/r.sim/r.sim.water/main.c:276
-#: ../raster/r.sim/r.sim.water/main.c:284
-#: ../raster/r.sim/r.sim.water/main.c:293 ../vector/v.surf.rst/main.c:161
-#: ../vector/v.surf.rst/main.c:166 ../vector/v.surf.rst/main.c:187
-#: ../vector/v.surf.rst/main.c:262 ../vector/v.surf.rst/main.c:268
-#: ../vector/v.surf.rst/main.c:276 ../vector/v.surf.rst/main.c:283
-#: ../vector/v.surf.rst/main.c:291 ../vector/v.surf.rst/main.c:299
-#: ../vector/v.surf.rst/main.c:308 ../vector/v.surf.rst/main.c:316
-#: ../vector/v.surf.rst/main.c:324 ../vector/v.surf.rst/main.c:333
-#: ../vector/v.surf.rst/main.c:341 ../vector/v.surf.rst/main.c:348
-#: ../imagery/i.eb.hsebal01/main.c:141 ../imagery/i.eb.hsebal01/main.c:150
-#: ../imagery/i.eb.hsebal01/main.c:157 ../imagery/i.eb.hsebal01/main.c:164
-#: ../imagery/i.eb.hsebal01/main.c:171 ../imagery/i.eb.hsebal01/main.c:178
-msgid "Parameters"
+#: ../raster/r.gwflow/main.c:147
+msgid ""
+"Name of input raster map providing the leakage coefficient of the river bed "
+"in [1/s]."
 msgstr ""
-#: ../raster/r.sim/r.sim.sediment/main.c:233
-#: ../raster/r.sim/r.sim.water/main.c:238
-msgid "Time used for iterations [minutes]"
+#: ../raster/r.gwflow/main.c:155
+msgid ""
+"Name of input raster map providing the height of the drainage bed in [m]"
 msgstr ""
-#: ../raster/r.sim/r.sim.sediment/main.c:242
-#: ../raster/r.sim/r.sim.water/main.c:247
-msgid "Time interval for creating output maps [minutes]"
+#: ../raster/r.gwflow/main.c:162
+msgid ""
+"Name of input raster map providing the leakage coefficient of the drainage "
+"bed in [1/s]"
 msgstr ""
-#: ../raster/r.sim/r.sim.sediment/main.c:260
-#: ../raster/r.sim/r.sim.water/main.c:265
-msgid "Water diffusion constant"
+#: ../raster/r.gwflow/main.c:167
+msgid "The maximum number of iterations in the linearization approach"
 msgstr ""
-#: ../raster/r.sim/r.sim.sediment/main.c:268
-#: ../raster/r.sim/r.sim.water/main.c:304
-msgid "Seed for random number generator"
+#: ../raster/r.gwflow/main.c:176
+msgid ""
+"Allocate a full quadratic linear equation system, default is a sparse linear "
+"equation system."
 msgstr ""
-#: ../raster/r.sim/r.sim.sediment/main.c:270
-#: ../raster/r.sim/r.sim.water/main.c:306
-msgid "The same seed can be used to obtain same results or random seed can be generated by other means."
+#: ../raster/r.gwflow/main.c:209 ../raster3d/r3.gwflow/main.c:160
+msgid "groundwater flow"
 msgstr ""
-#: ../raster/r.sim/r.sim.sediment/main.c:276
-#: ../raster/r.sim/r.sim.water/main.c:312
-msgid "Generate random seed"
+#: ../raster/r.gwflow/main.c:212
+msgid ""
+"Numerical calculation program for transient, confined and unconfined "
+"groundwater flow in two dimensions."
 msgstr ""
-#: ../raster/r.sim/r.sim.sediment/main.c:278
-#: ../raster/r.sim/r.sim.water/main.c:314
-msgid "Automatically generates random seed for random number generator (use when you don't want to provide the seed option)"
+#: ../raster/r.gwflow/main.c:222 ../raster/r.solute.transport/main.c:244
+#: ../raster/r.topidx/main.c:57 ../raster/r.carve/main.c:213
+#, c-format
+msgid "Lat/Long location is not supported by %s. Please reproject map first."
 msgstr ""
-#: ../raster/r.sim/r.sim.sediment/main.c:286
-#: ../raster/r.sim/r.sim.water/main.c:322
-#, c-format
-msgid "Generated random seed (-s): %ld"
+#: ../raster/r.gwflow/main.c:237
+msgid "Please provide river_head, river_leak and river_bed maps"
 msgstr ""
-#: ../raster/r.sim/r.sim.sediment/main.c:291
-#: ../raster/r.sim/r.sim.water/main.c:327
-#, c-format
-msgid "Read random seed from %s option: %ld"
+#: ../raster/r.gwflow/main.c:249
+msgid "Please provide drain_head and drain_leak maps"
 msgstr ""
-#: ../raster/r.sim/r.sim.sediment/main.c:373
-#: ../raster/r.sim/r.sim.water/main.c:482
-msgid "More than 100 files are going to be created !!!!!"
+#: ../raster/r.gwflow/main.c:263
+msgid ""
+"The cholesky solver dos not work with sparse matrices. You may choose a full "
+"filled quadratic matrix, flag -f."
 msgstr ""
-#: ../raster/r.sim/r.sim.sediment/main.c:379
-#: ../raster/r.sim/r.sim.water/main.c:488
+#: ../raster/r.gwflow/main.c:293
 #, c-format
-msgid "default nwalk=%d, rwalk=%f"
+msgid "Calculation time: %g"
 msgstr ""
-#: ../raster/r.sim/r.sim.sediment/main.c:388
-#: ../raster/r.sim/r.sim.water/main.c:498
+#: ../raster/r.gwflow/main.c:380
 #, c-format
-msgid "Using metric conversion factor %f, step=%f"
+msgid "Calculation of unconfined groundwater flow loop %i"
 msgstr ""
-#: ../raster/r.sim/r.sim.sediment/main.c:395
-msgid "You are not outputting any raster or site files"
+#: ../raster/r.gwflow/main.c:403
+#, c-format
+msgid "Maximum difference between this and last increment: %g"
 msgstr ""
-#: ../raster/r.sim/r.sim.sediment/main.c:398
-#: ../raster/r.sim/r.sim.water/main.c:507 ../vector/v.surf.rst/main.c:656
-#: ../vector/v.surf.rst/main.c:711 ../vector/v.vol.rst/main.c:914
-msgid "Input failed"
+#: ../raster/r.gwflow/main.c:546 ../raster3d/r3.gwflow/main.c:279
+msgid "Unable to create and solve the linear equation system"
 msgstr ""
-#: ../raster/r.sim/r.sim.water/main.c:116 ../vector/v.net.flow/main.c:60
-msgid "flow"
-msgstr "plūsma"
-#: ../raster/r.sim/r.sim.water/main.c:117
-msgid "overland flow"
+#: ../raster/r.in.mat/main.c:94
+msgid "Imports a binary MAT-File(v4) to a GRASS raster."
 msgstr ""
-#: ../raster/r.sim/r.sim.water/main.c:120
-msgid "Overland flow hydrologic simulation using path sampling method (SIMWE)."
+#: ../raster/r.in.mat/main.c:101
+msgid "Name of input MAT-File(v4)"
 msgstr ""
-#: ../raster/r.sim/r.sim.water/main.c:137
-msgid "Name of rainfall excess rate (rain-infilt) raster map [mm/hr]"
+#: ../raster/r.in.mat/main.c:105
+msgid "Name for output raster map (override)"
 msgstr ""
-#: ../raster/r.sim/r.sim.water/main.c:146
-msgid "Rainfall excess rate unique value [mm/hr]"
+#: ../raster/r.in.mat/main.c:149
+msgid "Reading MAT-File..."
 msgstr ""
-#: ../raster/r.sim/r.sim.water/main.c:153
-msgid "Name of runoff infiltration rate raster map [mm/hr]"
+#: ../raster/r.in.mat/main.c:175
+msgid "Array contains no data"
 msgstr ""
-#: ../raster/r.sim/r.sim.water/main.c:162
-msgid "Runoff infiltration rate unique value [mm/hr]"
+#: ../raster/r.in.mat/main.c:180
+msgid "Array contains imaginary data"
 msgstr ""
-#: ../raster/r.sim/r.sim.water/main.c:183
-msgid "Name of flow controls raster map (permeability ratio 0-1)"
+#: ../raster/r.in.mat/main.c:186
+msgid "Invalid array name"
 msgstr ""
-#: ../raster/r.sim/r.sim.water/main.c:196
-msgid "Name for output water depth raster map [m]"
+#: ../raster/r.in.mat/main.c:206
+msgid "Invalid 'map_name' array"
 msgstr ""
-#: ../raster/r.sim/r.sim.water/main.c:202
-msgid "Name for output water discharge raster map [m3/s]"
+#: ../raster/r.in.mat/main.c:216
+msgid "Error reading 'map_name' array"
 msgstr ""
-#: ../raster/r.sim/r.sim.water/main.c:208
-msgid "Name for output simulation error raster map [m]"
+#: ../raster/r.in.mat/main.c:227
+msgid "Invalid 'map_northern_edge' array"
 msgstr ""
-#: ../raster/r.sim/r.sim.water/main.c:230
-msgid "Number of walkers, default is twice the number of cells"
+#: ../raster/r.in.mat/main.c:236
+msgid "Invalid 'map_southern_edge' array"
 msgstr ""
-#: ../raster/r.sim/r.sim.water/main.c:274
-msgid "Threshold water depth [m]"
+#: ../raster/r.in.mat/main.c:245
+msgid "Invalid 'map_eastern_edge' array"
 msgstr ""
-#: ../raster/r.sim/r.sim.water/main.c:275
-msgid "Diffusion increases after this water depth is reached"
+#: ../raster/r.in.mat/main.c:254
+msgid "Invalid 'map_western_edge' array"
 msgstr ""
-#: ../raster/r.sim/r.sim.water/main.c:283
-msgid "Diffusion increase constant"
+#: ../raster/r.in.mat/main.c:262
+msgid "Invalid 'map_title' array"
 msgstr ""
-#: ../raster/r.sim/r.sim.water/main.c:292
-msgid "Weighting factor for water flow velocity vector"
+#: ../raster/r.in.mat/main.c:272
+msgid "Error reading 'map_title' array"
 msgstr ""
-#: ../raster/r.sim/r.sim.water/main.c:297
-msgid "Time-series output"
+#: ../raster/r.in.mat/main.c:285
+msgid "Invalid 'map_data' array"
 msgstr ""
-#: ../raster/r.sim/r.sim.water/main.c:504
-msgid "You are not outputting any raster maps"
+#: ../raster/r.in.mat/main.c:311 ../raster/r.in.mat/main.c:443
+#: ../raster/r.in.mat/main.c:522
+msgid "Please contact the GRASS development team"
 msgstr ""
-#: ../raster/r.out.mpeg/main.c:104
-msgid "animation"
+#: ../raster/r.in.mat/main.c:316
+#, c-format
+msgid "Skipping unknown array '%s'"
 msgstr ""
-#: ../raster/r.out.mpeg/main.c:107
-msgid "Converts raster map series to MPEG movie."
+#: ../raster/r.in.mat/main.c:344
+#, c-format
+msgid "No 'map_data' array found in <%s>"
 msgstr ""
-#: ../raster/r.out.mpeg/main.c:115
+#: ../raster/r.in.mat/main.c:351
 #, c-format
-msgid "Name of input raster map(s) for view no.%d"
+msgid "Setting map name to <%s> which overrides <%s>"
 msgstr ""
-#: ../raster/r.out.mpeg/main.c:117
-msgid "Views"
-msgstr "Skati"
-#: ../raster/r.out.mpeg/main.c:131
-msgid "Quality factor (1 = highest quality, lowest compression)"
+#: ../raster/r.in.mat/main.c:358
+#, c-format
+msgid "Setting map name to <%s>"
 msgstr ""
-#: ../raster/r.out.mpeg/main.c:136
-msgid "Convert on the fly, uses less disk space"
+#: ../raster/r.in.mat/main.c:362
+msgid "No 'map_name' array found; using <MatFile>"
 msgstr ""
-#: ../raster/r.out.mpeg/main.c:137
-msgid "Requires r.out.ppm with stdout option"
+#: ../raster/r.in.mat/main.c:373
+msgid "Missing bound"
 msgstr ""
-#: ../raster/r.out.mpeg/main.c:160
-msgid "Either mpeg_encode or ppmtompeg must be installed"
+#: ../raster/r.in.mat/main.c:377
+msgid "Using default bounds"
 msgstr ""
-#: ../raster/r.out.mpeg/main.c:291
+#: ../raster/r.in.mat/main.c:391
 #, c-format
-msgid "Unable to read color table for <%s>"
+msgid "Map <%s> bounds set to:"
 msgstr ""
-#: ../raster/r.out.mpeg/main.c:341 ../raster/r.out.mpeg/main.c:374
-msgid "mpeg_encode ERROR"
+#: ../raster/r.in.mat/main.c:392 ../raster/r.out.mat/main.c:174
+#, c-format
+msgid "northern edge=%f"
 msgstr ""
-#: ../raster/r.out.mpeg/main.c:417
-msgid "Error reading wildcard"
+#: ../raster/r.in.mat/main.c:393 ../raster/r.out.mat/main.c:175
+#, c-format
+msgid "southern edge=%f"
 msgstr ""
-#: ../raster/r.out.mpeg/write.c:81 ../raster/r.out.mpeg/write.c:178
-msgid "Size mismatch error!"
+#: ../raster/r.in.mat/main.c:394 ../raster/r.out.mat/main.c:176
+#, c-format
+msgid "eastern edge=%f"
 msgstr ""
-#: ../raster/r.out.mpeg/write.c:139 ../raster/r.out.mpeg/write.c:181
-msgid "Unable to open output file"
+#: ../raster/r.in.mat/main.c:395 ../raster/r.out.mat/main.c:177
+#, c-format
+msgid "western edge=%f"
 msgstr ""
-#: ../raster/r.out.mpeg/write.c:215
-msgid "Unable to create temporary files."
+#: ../raster/r.in.mat/main.c:396 ../raster/r.out.mat/main.c:178
+#, c-format
+msgid "nsres=%f"
 msgstr ""
-#: ../raster/r.support.stats/check.c:43
+#: ../raster/r.in.mat/main.c:397 ../raster/r.out.mat/main.c:179
 #, c-format
-msgid "Updating statistics for [%s]..."
+msgid "ewres=%f"
 msgstr ""
-#: ../raster/r.support.stats/check.c:56
-msgid "Updating histogram range..."
+#: ../raster/r.in.mat/main.c:398 ../raster/r.out.mat/main.c:180
+#: ../raster3d/r3.out.bin/main.c:330
+#, c-format
+msgid "rows=%d"
 msgstr ""
-#: ../raster/r.support.stats/check.c:88
+#: ../raster/r.in.mat/main.c:399 ../raster/r.out.mat/main.c:181
+#: ../raster3d/r3.out.bin/main.c:331
 #, c-format
-msgid "Updating the number of categories for [%s]..."
+msgid "cols=%d"
 msgstr ""
-#: ../raster/r.support.stats/main.c:37
-msgid "Update raster map statistics"
+#: ../raster/r.in.mat/main.c:408
+msgid "Writing new raster map..."
 msgstr ""
-#: ../raster/r.support.stats/main.c:49
-#, c-format
-msgid "Statistics for <%s> updated"
+#: ../raster/r.param.scale/main.c:42
+msgid "Lat/Long locations are not supported by this module"
 msgstr ""
-#: ../raster/r.grow.distance/main.c:154
-msgid "Generates a raster map containing distances to nearest raster features."
+#: ../raster/r.param.scale/interface.c:55
+msgid "geomorphology"
 msgstr ""
-#: ../raster/r.grow.distance/main.c:161
-msgid "Name for distance output raster map"
+#: ../raster/r.param.scale/interface.c:56 ../raster/r.relief/main.c:110
+#: ../raster/r.slope.aspect/main.c:152 ../imagery/i.topo.corr/main.c:48
+msgid "terrain"
 msgstr ""
-#: ../raster/r.grow.distance/main.c:167
-msgid "Name for value output raster map"
+#: ../raster/r.param.scale/interface.c:57 ../raster/r.relief/main.c:108
+#: ../locale/scriptstrings/r.fillnulls_to_translate.c:3
+#: ../locale/scriptstrings/r.shade_to_translate.c:3
+#: ../locale/scriptstrings/d.shade_to_translate.c:3
+#: ../locale/scriptstrings/r.plane_to_translate.c:3
+#: ../locale/scriptstrings/r.in.aster_to_translate.c:6
+msgid "elevation"
 msgstr ""
-#: ../raster/r.grow.distance/main.c:180
-msgid "Output distances in meters instead of map units"
+#: ../raster/r.param.scale/interface.c:58
+msgid "landform"
 msgstr ""
-#: ../raster/r.grow.distance/main.c:184
-msgid "Calculate distance to nearest NULL cell"
+#: ../raster/r.param.scale/interface.c:59
+msgid "Extracts terrain parameters from a DEM."
 msgstr ""
-#: ../raster/r.grow.distance/main.c:195
-msgid "Distance output is required for distance to NULL cells"
+#: ../raster/r.param.scale/interface.c:60
+msgid ""
+"Uses a multi-scale approach by taking fitting quadratic parameters to any "
+"size window (via least squares)."
 msgstr ""
-#: ../raster/r.grow.distance/main.c:197
-msgid "Value output is meaningless for distance to NULL cells"
+#: ../raster/r.param.scale/interface.c:78
+msgid "Name for output raster map containing morphometric parameter"
 msgstr ""
-#: ../raster/r.grow.distance/main.c:203
-msgid "At least one of distance= and value= must be given"
+#: ../raster/r.param.scale/interface.c:82
+msgid "Slope tolerance that defines a 'flat' surface (degrees)"
 msgstr ""
-#: ../raster/r.grow.distance/main.c:218
-msgid "metric=geodesic is only valid for lat/lon"
+#: ../raster/r.param.scale/interface.c:89
+msgid "Curvature tolerance that defines 'planar' surface"
 msgstr ""
-#: ../raster/r.grow.distance/main.c:224
-#, c-format
-msgid "Unknown metric: '%s'"
+#: ../raster/r.param.scale/interface.c:96
+msgid "Size of processing window (odd number only)"
 msgstr ""
-#: ../raster/r.grow.distance/main.c:229
-#, c-format
-msgid "Output distance in meters for lat/lon is only possible with '%s=%s'"
+#: ../raster/r.param.scale/interface.c:104
+msgid "Morphometric parameter in 'size' window to calculate"
 msgstr ""
-#: ../raster/r.grow.distance/main.c:249
-#, c-format
-msgid "Unable to create temporary file <%s>"
+#: ../raster/r.param.scale/interface.c:112
+msgid "Exponent for distance weighting (0.0-4.0)"
 msgstr ""
-#: ../raster/r.grow.distance/main.c:325 ../raster/r.fill.dir/main.c:253
-#: ../raster/r.stream.extract/close.c:248
-msgid "Writing output raster maps..."
+#: ../raster/r.param.scale/interface.c:118 ../raster/r.out.pov/main.c:150
+msgid "Vertical scaling factor"
 msgstr ""
-#: ../raster/r.grow.distance/main.c:382 ../raster/r.fill.dir/main.c:153
-#: ../raster/r.colors/edit_colors.c:396 ../raster/r.colors.out/raster_main.c:69
-#: ../vector/v.colors/main.c:315
-#, c-format
-msgid "Unable to read color table for raster map <%s>"
+#: ../raster/r.param.scale/interface.c:124
+msgid "Constrain model through central window cell"
 msgstr ""
-#: ../raster/r.transect/main.c:84
-#, c-format
-msgid "End coordinate: %.15g, %.15g"
+#: ../raster/r.param.scale/interface.c:167
+msgid "Morphometric parameter not recognised. Assuming 'Elevation'"
 msgstr ""
-#: ../raster/r.transect/main.c:104 ../vector/v.profile/main.c:100
-msgid "transect"
+#: ../raster/r.param.scale/interface.c:175
+msgid "Inappropriate window size (too big or even)"
 msgstr ""
-#: ../raster/r.transect/main.c:106
-msgid "Outputs raster map layer values lying along user defined transect line(s)."
+#: ../raster/r.param.scale/process.c:75
+msgid "E-W and N-S grid resolutions are different. Taking average."
 msgstr ""
-#: ../raster/r.transect/main.c:110
-msgid "Raster map to be queried"
+#: ../raster/r.resamp.filter/main.c:142
+#, c-format
+msgid "Filter <%s> not found"
 msgstr ""
-#: ../raster/r.transect/main.c:116
-msgid "Transect definition"
+#: ../raster/r.resamp.filter/main.c:390 ../raster/r.resamp.bspline/main.c:81
+#: ../raster/r.resamp.stats/main.c:262 ../raster/r.resamp.rst/main.c:149
+#: ../raster/r.resample/main.c:55 ../raster/r.resamp.interp/main.c:77
+msgid "resample"
 msgstr ""
-#: ../raster/r.transect/main.c:126 ../raster/r.profile/main.c:93
-msgid "Output easting and northing in first two columns of four column output"
+#: ../raster/r.resamp.filter/main.c:391
+msgid "kernel filter"
 msgstr ""
-#: ../raster/r.fill.dir/dopolys.c:84
-#, c-format
-msgid "Found %d unresolved area"
-msgid_plural "Found %d unresolved areas"
-msgstr[0] ""
-msgstr[1] ""
-msgstr[2] ""
-#: ../raster/r.fill.dir/main.c:88
-msgid "sink"
+#: ../raster/r.resamp.filter/main.c:394
+msgid "Resamples raster map layers using an analytic kernel."
 msgstr ""
-#: ../raster/r.fill.dir/main.c:89
-msgid "fill sinks"
+#: ../raster/r.resamp.filter/main.c:405
+msgid "Filter kernel(s)"
 msgstr ""
-#: ../raster/r.fill.dir/main.c:90
-msgid "depressions"
+#: ../raster/r.resamp.filter/main.c:413
+msgid "Filter radius"
 msgstr ""
-#: ../raster/r.fill.dir/main.c:92
-msgid "Filters and generates a depressionless elevation map and a flow direction map from a given elevation raster map."
+#: ../raster/r.resamp.filter/main.c:420
+msgid "Filter radius (horizontal)"
 msgstr ""
-#: ../raster/r.fill.dir/main.c:99
-msgid "Name for output depressionless elevation raster map"
+#: ../raster/r.resamp.filter/main.c:427
+msgid "Filter radius (vertical)"
 msgstr ""
-#: ../raster/r.fill.dir/main.c:103
-msgid "Name for output flow direction map for depressionless elevation raster map"
+#: ../raster/r.resamp.filter/main.c:431 ../raster/r.resamp.stats/main.c:288
+#: ../raster/r.series/main.c:187 ../raster/r.series.accumulate/main.c:159
+#: ../locale/scriptstrings/t.rast.series_to_translate.c:11
+msgid "Propagate NULLs"
 msgstr ""
-#: ../raster/r.fill.dir/main.c:108
-msgid "Name for output raster map of problem areas"
+#: ../raster/r.resamp.filter/main.c:443
+#, c-format
+msgid "Either %s= or %s=/%s= required"
 msgstr ""
-#: ../raster/r.fill.dir/main.c:115
-msgid "Aspect direction format"
+#: ../raster/r.resamp.filter/main.c:446
+#, c-format
+msgid "Both %s= and %s= required"
 msgstr ""
-#: ../raster/r.fill.dir/main.c:121
-msgid "Find unresolved areas only"
+#: ../raster/r.resamp.filter/main.c:469
+msgid "Differing number of values for filter= and [xy_]radius="
 msgstr ""
-#: ../raster/r.fill.dir/main.c:127
+#: ../raster/r.resamp.filter/main.c:472
 #, c-format
-msgid "The '%c' flag requires '%s'to be specified"
+msgid "Too many filters (max: %d)"
 msgstr ""
-#: ../raster/r.fill.dir/main.c:148
-msgid "Direction map is D8 resolution, i.e. 45 degrees"
+#: ../raster/r.resamp.filter/main.c:490
+msgid "At least one filter must be finite"
 msgstr ""
-#: ../raster/r.fill.dir/main.c:190
-msgid "Reading input elevation raster map..."
+#: ../raster/r.resamp.filter/main.c:579 ../raster/r.tile/main.c:200
+#: ../raster/r.resamp.stats/main.c:395 ../raster/r.mode/main.c:143
+#: ../raster/r.resamp.interp/main.c:370
+#, c-format
+msgid "Unable to read color table for %s"
 msgstr ""
-#: ../raster/r.fill.dir/main.c:200
-msgid "Filling sinks..."
+#: ../raster/r.out.vtk/main.c:62
+msgid "Converts raster maps into the VTK-ASCII format."
 msgstr ""
-#: ../raster/r.fill.dir/main.c:204
-msgid "Determining flow directions for ambiguous cases..."
+#: ../raster/r.out.vtk/main.c:73
+msgid ""
+"No input maps specified. You need to specify at least one input map or three "
+"vector maps or three rgb maps."
 msgstr ""
-#: ../raster/r.fill.dir/main.c:217
-msgid "Repeat to get the final directions..."
+#: ../raster/r.out.vtk/main.c:131 ../raster/r.out.vtk/main.c:191
+#: ../raster/r.out.vtk/main.c:212 ../raster/r.out.vtk/main.c:251
+#, c-format
+msgid "Open Raster file %s"
 msgstr ""
-#: ../raster/r.fill.dir/wtrshed.c:95
-#, c-format
-msgid "Watershed pass %d"
+#: ../raster/r.out.vtk/main.c:222
+msgid "Writing VTK ImageData\n"
 msgstr ""
-#: ../raster/r.fill.dir/resolve.c:136
-#, c-format
-msgid "Downward pass %d"
+#: ../raster/r.out.vtk/main.c:232
+msgid "Wrong RGB maps. Maps should have the same type! RGB output not added!"
 msgstr ""
-#: ../raster/r.fill.dir/resolve.c:173
-#, c-format
-msgid "Upward pass %d"
+#: ../raster/r.out.vtk/main.c:261
+msgid "Writing VTK Vector Data\n"
 msgstr ""
-#: ../raster/r.stream.extract/bseg.c:19 ../raster/r.stream.extract/seg.c:19
-#: ../raster/r.stream.extract/cseg.c:19
-msgid "Unable to create segment file"
+#: ../raster/r.out.vtk/main.c:271
+msgid ""
+"Wrong vector maps. Maps should have the same type! Vector output not added!"
 msgstr ""
-#: ../raster/r.stream.extract/bseg.c:28 ../raster/r.stream.extract/bseg.c:78
-#: ../raster/r.stream.extract/bseg.c:87 ../raster/r.stream.extract/seg.c:33
-#: ../raster/r.stream.extract/seg.c:75 ../raster/r.stream.extract/cseg.c:29
-#: ../raster/r.stream.extract/cseg.c:79 ../raster/r.stream.extract/cseg.c:88
-#: ../raster/r.stream.extract/dseg.c:29 ../raster/r.stream.extract/dseg.c:79
-#: ../raster/r.stream.extract/dseg.c:88
-msgid "Unable to write segment file"
+#: ../raster/r.out.vtk/main.c:283
+msgid "Error closing VTK-ASCII file"
 msgstr ""
-#: ../raster/r.stream.extract/bseg.c:32 ../raster/r.stream.extract/seg.c:37
-#: ../raster/r.stream.extract/cseg.c:33
-msgid "Illegal configuration parameter(s)"
+#: ../raster/r.out.vtk/writeascii.c:75
+msgid "write_vtk_normal_header: Writing VTK-Header"
 msgstr ""
-#: ../raster/r.stream.extract/bseg.c:39 ../raster/r.stream.extract/cseg.c:40
-#: ../raster/r.stream.extract/dseg.c:40
-msgid "Unable to re-open segment file"
+#: ../raster/r.out.vtk/writeascii.c:108
+msgid "write_vtk_structured_elevation_header: Writing VTK-Header"
 msgstr ""
-#: ../raster/r.stream.extract/bseg.c:46 ../raster/r.stream.extract/bseg.c:96
-#: ../raster/r.stream.extract/seg.c:51 ../raster/r.stream.extract/seg.c:93
-#: ../raster/r.stream.extract/seg.c:102 ../raster/r.stream.extract/cseg.c:47
-#: ../raster/r.stream.extract/dseg.c:47 ../raster/r.stream.extract/dseg.c:97
-msgid "Unable to read segment file"
+#: ../raster/r.out.vtk/writeascii.c:124
+msgid "write_vtk_polygonal_elevation_header: Writing VTK-Header"
 msgstr ""
-#: ../raster/r.stream.extract/del_streams.c:130
-#, c-format
-msgid "Deleting stream segments shorter than %d cell..."
-msgid_plural "Deleting stream segments shorter than %d cells..."
-msgstr[0] ""
-msgstr[1] ""
-msgstr[2] ""
-#: ../raster/r.stream.extract/del_streams.c:193
-#, c-format
-msgid "%d stream segment deleted"
-msgid_plural "%d stream segments deleted"
-msgstr[0] ""
-msgstr[1] ""
-msgstr[2] ""
-#: ../raster/r.stream.extract/close.c:34
-#, c-format
-msgid "Writing vector map <%s>..."
+#: ../raster/r.out.vtk/writeascii.c:139
+msgid "write_vtk_celldata_header: Writing VTK-DataHeader"
 msgstr ""
-#: ../raster/r.stream.extract/close.c:117
-#, c-format
-msgid "Stream id %d not set, top is %d, parent is %d"
+#: ../raster/r.out.vtk/writeascii.c:148
+msgid "writeVTKPointHeader: Writing VTK-DataHeader"
 msgstr ""
-#: ../raster/r.stream.extract/close.c:138
-msgid "Stream id not set while tracing"
+#: ../raster/r.out.vtk/writeascii.c:169
+msgid "write_vtk_structured_coordinates: Writing Coordinates"
 msgstr ""
-#: ../raster/r.stream.extract/close.c:157
-msgid "Writing attribute data..."
+#: ../raster/r.out.vtk/writeascii.c:225
+msgid "write_vtk_polygonal_coordinates: Writing VTK Polygonal data"
 msgstr ""
-#: ../raster/r.stream.extract/close.c:172 ../display/d.vect/opt.c:147
-#: ../display/d.vect.thematic/main.c:294 ../vector/v.out.vtk/writeVTK.c:644
-#: ../vector/v.edit/select.c:509 ../vector/v.profile/main.c:349
-#: ../vector/v.profile/main.c:457 ../vector/v.out.svg/main.c:152
-#: ../vector/v.db.connect/main.c:217 ../vector/v.db.connect/main.c:283
-#: ../doc/vector/v.example/main.c:126 ../db/db.createdb/main.c:42
-#: ../db/db.describe/main.c:56 ../db/db.databases/main.c:48
-#: ../db/db.execute/main.c:70 ../db/db.dropdb/main.c:42
-#: ../db/db.tables/main.c:45 ../db/db.select/main.c:75
-#: ../db/db.columns/main.c:51
-#, c-format
-msgid "Unable to start driver <%s>"
+#: ../raster/r.out.vtk/writeascii.c:334
+msgid "write_vtk_data: Writing VTK-Data"
 msgstr ""
-#: ../raster/r.stream.extract/close.c:188 ../raster/r.contour/main.c:183
-#: ../vector/v.net.components/main.c:190 ../vector/v.net.distance/main.c:291
-#: ../vector/v.net.flow/main.c:181 ../vector/v.net.timetable/main.c:103
-#: ../vector/v.overlay/main.c:587 ../vector/v.in.ogr/main.c:1150
-#: ../vector/v.net.allpairs/main.c:179 ../vector/v.to.points/main.c:192
-#: ../vector/v.net.path/path.c:109 ../vector/v.in.dwg/main.c:240
-#: ../vector/v.in.lidar/attributes.c:135 ../vector/v.net.centrality/main.c:266
-#: ../vector/v.distance/main.c:1419
-#, c-format
-msgid "Unable to create table: '%s'"
+#: ../raster/r.out.vtk/writeascii.c:384
+msgid "write_vtk_rgb_image_data: Writing VTK-ImageData"
 msgstr ""
-#: ../raster/r.stream.extract/close.c:192
-#, c-format
-msgid "Unable to create index on table <%s>"
+#: ../raster/r.out.vtk/writeascii.c:412
+msgid "Wrong map values! Values should in between 0 and 255!\n"
 msgstr ""
-#: ../raster/r.stream.extract/close.c:213
-#, c-format
-msgid "Unable to insert new row: '%s'"
+#: ../raster/r.out.vtk/writeascii.c:442
+msgid "write_vtk_vector_data: Writing VTK-vector data"
 msgstr ""
-#: ../raster/r.stream.extract/close.c:313
-#, c-format
-msgid "Unable to write vector map <%s>"
+#: ../raster/r.out.vtk/parameters.c:32
+msgid "Raster map(s) to be converted to VTK-ASCII data format"
 msgstr ""
-#: ../raster/r.stream.extract/init_search.c:24
-msgid "Initializing A* search..."
+#: ../raster/r.out.vtk/parameters.c:36 ../raster3d/r3.out.vtk/parameters.c:34
+msgid "Name for VTK-ASCII output file"
 msgstr ""
-#: ../raster/r.stream.extract/load.c:33
-msgid "Loading elevation raster map..."
+#: ../raster/r.out.vtk/parameters.c:45
+#: ../locale/scriptstrings/t.rast.out.vtk_to_translate.c:8
+msgid "Value to represent no data cell"
 msgstr ""
-#: ../raster/r.stream.extract/load.c:35
-msgid "Loading input raster maps..."
+#: ../raster/r.out.vtk/parameters.c:53
+msgid "Constant elevation (if no elevation map is specified)"
 msgstr ""
-#: ../raster/r.stream.extract/load.c:95
-msgid "Elevation raster map is NULL but accumulation map is not NULL"
+#: ../raster/r.out.vtk/parameters.c:59
+#: ../locale/scriptstrings/t.rast.out.vtk_to_translate.c:9
+msgid ""
+"Create VTK point data instead of VTK cell data (if no elevation map is given)"
 msgstr ""
-#: ../raster/r.stream.extract/load.c:120
-msgid "Accumulation raster map is NULL but elevation map is not NULL"
+#: ../raster/r.out.vtk/parameters.c:69
+msgid ""
+"Three (r,g,b) raster maps to create RGB values [redmap,greenmap,bluemap]"
 msgstr ""
-#: ../raster/r.stream.extract/main.c:78
-msgid "stream network"
+#: ../raster/r.out.vtk/parameters.c:79
+msgid "Three (x,y,z) raster maps to create vector values [xmap,ymap,zmap]"
 msgstr ""
-#: ../raster/r.stream.extract/main.c:79
-msgid "Performs stream network extraction."
+#: ../raster/r.out.vtk/parameters.c:104
+msgid "Use structured grid for elevation (not recommended)"
 msgstr ""
-#: ../raster/r.stream.extract/main.c:85
-msgid "Name of input accumulation raster map"
+#: ../raster/r.out.vtk/parameters.c:110
+msgid "Use polydata-trianglestrips for elevation grid creation"
 msgstr ""
-#: ../raster/r.stream.extract/main.c:88
-msgid "Stream extraction will use provided accumulation instead of calculating it anew"
+#: ../raster/r.out.vtk/parameters.c:116
+msgid ""
+"Use polydata-vertices for elevation grid creation (to use with vtkDelauny2D)"
 msgstr ""
-#: ../raster/r.stream.extract/main.c:93
-msgid "Name of input raster map with real depressions"
+#: ../raster/r.out.vtk/parameters.c:122
+msgid "Scale factor affects the origin (if no elevation map is given)"
 msgstr ""
-#: ../raster/r.stream.extract/main.c:96
-msgid "Streams will not be routed out of real depressions"
+#: ../raster/r.out.vtk/parameters.c:128 ../raster3d/r3.out.vtk/parameters.c:123
+msgid "Correct the coordinates to match the VTK-OpenGL precision"
 msgstr ""
-#: ../raster/r.stream.extract/main.c:101
-msgid "Minimum flow accumulation for streams"
+#: ../raster/r.series.interp/main.c:65 ../raster/r.patch/main.c:64
+#: ../raster/r.series/main.c:139 ../raster/r.series.accumulate/main.c:81
+#: ../locale/scriptstrings/t.rast.series_to_translate.c:4
+msgid "series"
 msgstr ""
-#: ../raster/r.stream.extract/main.c:102
-msgid "Must be > 0"
+#: ../raster/r.series.interp/main.c:69
+msgid ""
+"Interpolates raster maps located (temporal or spatial) in between input "
+"raster maps at specific sampling positions."
 msgstr ""
-#: ../raster/r.stream.extract/main.c:108
-msgid "Use SFD above this threshold"
+#: ../raster/r.series.interp/main.c:79
+msgid "Data point position for each input map"
 msgstr ""
-#: ../raster/r.stream.extract/main.c:110
-msgid "If accumulation is larger than d8cut, SFD is used instead of MFD. Applies only if no accumulation map is given."
+#: ../raster/r.series.interp/main.c:84
+msgid ""
+"Input file with one input raster map name and data point position per line, "
+"field separator between name and sample point is |"
 msgstr ""
-#: ../raster/r.stream.extract/main.c:122
-msgid "Montgomery exponent for slope, disabled with 0"
+#: ../raster/r.series.interp/main.c:97
+msgid "Sampling point position for each output map"
 msgstr ""
-#: ../raster/r.stream.extract/main.c:124
-msgid "Montgomery: accumulation is multiplied with pow(slope,mexp) and then compared with threshold"
+#: ../raster/r.series.interp/main.c:101
+msgid ""
+"Input file with one output raster map name and sample point position per "
+"line, field separator between name and sample point is |"
 msgstr ""
-#: ../raster/r.stream.extract/main.c:132
-msgid "Delete stream segments shorter than stream_length cells"
+#: ../raster/r.series.interp/main.c:111
+msgid "Interpolation method, currently only linear interpolation is supported"
 msgstr ""
-#: ../raster/r.stream.extract/main.c:134
-msgid "Applies only to first-order stream segments (springs/stream heads)"
+#: ../raster/r.series.interp/main.c:126 ../raster/r.series.interp/main.c:142
+#: ../raster/r.series/main.c:208 ../raster/r.series.accumulate/main.c:210
+#, c-format
+msgid "Please specify %s= or %s="
 msgstr ""
-#: ../raster/r.stream.extract/main.c:147
-msgid "Name for output raster map with unique stream ids"
+#: ../raster/r.series.interp/main.c:130 ../raster/r.series.interp/main.c:146
+#, c-format
+msgid "Please specify %s= and %s="
 msgstr ""
-#: ../raster/r.stream.extract/main.c:154
-msgid "Name for output vector map with unique stream ids"
+#: ../raster/r.series.interp/main.c:180 ../raster/r.colors/edit_colors.c:186
+#, c-format
+msgid "Unable to open %s file <%s>"
 msgstr ""
-#: ../raster/r.stream.extract/main.c:161
-msgid "Name for output raster map with flow direction"
+#: ../raster/r.series.interp/main.c:213
+#, c-format
+msgid "Missing point position for %s map <%s> in file <%s> near line %i"
 msgstr ""
-#: ../raster/r.stream.extract/main.c:192
+#: ../raster/r.series.interp/main.c:228 ../raster/r.series.interp/main.c:262
 #, c-format
-msgid "Threshold must be > 0 but is %f"
+msgid "Preparing %s map <%s> at position %g"
 msgstr ""
-#: ../raster/r.stream.extract/main.c:201
+#: ../raster/r.series.interp/main.c:232
 #, c-format
-msgid "d8cut must be positive or zero but is %f"
+msgid "No raster map name found in %s file <%s>"
 msgstr ""
-#: ../raster/r.stream.extract/main.c:209
+#: ../raster/r.series.interp/main.c:243
 #, c-format
-msgid "Montgomery exponent must be positive or zero but is %f"
+msgid "No %s raster map not found"
 msgstr ""
-#: ../raster/r.stream.extract/main.c:212
+#: ../raster/r.series.interp/main.c:250
 #, c-format
-msgid "Montgomery exponent is %f, recommended range is 0.0 - 3.0"
+msgid "The number of %s maps and %s point positions must be equal"
 msgstr ""
-#: ../raster/r.stream.extract/main.c:222
+#: ../raster/r.series.interp/main.c:279
 #, c-format
-msgid "Minimum stream length must be positive or zero but is %d"
+msgid "Start interpolation run with %i input maps and %i output maps"
 msgstr ""
-#: ../raster/r.stream.extract/main.c:231
+#: ../raster/r.series.interp/main.c:299
 #, c-format
-msgid "Memory must be positive but is %d"
+msgid ""
+"map <%s> at position %g was not interpolated. Check the interpolation "
+"interval."
 msgstr ""
-#: ../raster/r.stream.extract/main.c:241
-msgid "At least one output raster maps must be specified"
+#: ../raster/r.series.interp/main.c:319
+msgid "At least 2 input maps are required for linear interpolation"
 msgstr ""
-#: ../raster/r.stream.extract/main.c:315
+#: ../raster/r.series.interp/main.c:337
 #, c-format
-msgid "%.2f%% of data are kept in memory"
+msgid "Interpolate map <%s> at position %g in interval (%g;%g)"
 msgstr ""
-#: ../raster/r.stream.extract/main.c:319
-#: ../raster/r.watershed/seg/init_vars.c:252
-#, c-format
-msgid "Will need up to %.2f MB of disk space"
+#: ../raster/r.series.interp/main.c:339 ../raster/r.relief/main.c:316
+#: ../raster/r.patch/main.c:140 ../raster/r.slope.aspect/main.c:544
+#: ../raster/r.series/main.c:386 ../raster/r.series.accumulate/main.c:318
+msgid "Percent complete..."
 msgstr ""
-#: ../raster/r.stream.extract/main.c:321
-#: ../raster/r.watershed/seg/init_vars.c:254
-#, c-format
-msgid "Will need up to %.2f GB (%.0f MB) of disk space"
+#: ../raster/r.relief/main.c:109
+#: ../locale/scriptstrings/r.shade_to_translate.c:4
+#: ../locale/scriptstrings/d.shade_to_translate.c:4
+msgid "relief"
 msgstr ""
-#: ../raster/r.stream.extract/main.c:325
-msgid "Creating temporary files..."
+#: ../raster/r.relief/main.c:111
+#: ../locale/scriptstrings/r.shade_to_translate.c:5
+#: ../locale/scriptstrings/d.shade_to_translate.c:5
+msgid "hillshade"
 msgstr ""
-#: ../raster/r.stream.extract/main.c:345
-msgid "Unable to load input raster map(s)"
+#: ../raster/r.relief/main.c:112
+msgid "Creates shaded relief map from an elevation map (DEM)."
 msgstr ""
-#: ../raster/r.stream.extract/main.c:347
-msgid "No non-NULL cells in input raster map(s)"
+#: ../raster/r.relief/main.c:117
+msgid "Name for output shaded relief map"
 msgstr ""
-#: ../raster/r.stream.extract/main.c:398
-msgid "Unable to initialize search"
+#: ../raster/r.relief/main.c:125
+msgid "Altitude of the sun in degrees above the horizon"
 msgstr ""
-#: ../raster/r.stream.extract/main.c:402
-msgid "Unable to sort elevation raster map values"
+#: ../raster/r.relief/main.c:126 ../raster/r.relief/main.c:136
+msgid "Sun position"
 msgstr ""
-#: ../raster/r.stream.extract/main.c:408
-msgid "Unable to calculate flow accumulation"
+#: ../raster/r.relief/main.c:135
+msgid "Azimuth of the sun in degrees to the east of north"
 msgstr ""
-#: ../raster/r.stream.extract/main.c:413
-msgid "Unable to extract streams"
+#: ../raster/r.relief/main.c:143
+msgid "Factor for exaggerating relief"
 msgstr ""
-#: ../raster/r.stream.extract/main.c:420
-msgid "Unable to thin streams"
+#: ../raster/r.relief/main.c:151
+msgid "Scale factor for converting meters to elevation units"
 msgstr ""
-#: ../raster/r.stream.extract/main.c:425
-msgid "Unable to delete short stream segments"
+#: ../raster/r.relief/main.c:158
+msgid "Elevation units (overrides scale factor)"
 msgstr ""
-#: ../raster/r.stream.extract/main.c:431
-msgid "Unable to write output raster maps"
+#: ../raster/r.relief/main.c:163
+msgid "international feet"
 msgstr ""
-#: ../raster/r.stream.extract/do_astar.c:40
-msgid "A* Search..."
-msgstr "A* meklēšana..."
+#: ../raster/r.relief/main.c:164
+msgid "survey feet"
+msgstr ""
-#: ../raster/r.stream.extract/do_astar.c:62
+#: ../raster/r.relief/main.c:194 ../raster/r.in.gdal/main.c:400
+#: ../raster/r.in.gdal/main.c:682 ../imagery/i.landsat.toar/main.c:548
 #, c-format
-msgid "%lld surplus points"
+msgid "Raster map <%s> already exists and will be overwritten"
 msgstr ""
-#: ../raster/r.stream.extract/do_astar.c:67
+#: ../raster/r.relief/main.c:197 ../raster/r.in.gdal/main.c:403
+#: ../raster/r.in.gdal/main.c:685
 #, c-format
-msgid "Too many points in heap %lld, should be %lld"
+msgid "Raster map <%s> already exists"
 msgstr ""
-#: ../raster/r.stream.extract/seg.c:44
+#: ../raster/r.relief/main.c:201 ../raster/r.relief/main.c:207
+#: ../raster/r.slope.aspect/main.c:321
 #, c-format
-msgid "Unable to re-open file '%s'"
+msgid "%s=%s - must be a non-negative number"
 msgstr ""
-#: ../raster/r.stream.extract/seg.c:84
-msgid "seg_put_row(): could not write segment file"
+#: ../raster/r.relief/main.c:215
+#, c-format
+msgid "%s=%s - must not be zero"
 msgstr ""
-#: ../raster/r.stream.extract/streams.c:72
-#: ../raster/r.stream.extract/streams.c:668
+#: ../raster/r.relief/main.c:220 ../raster/r.slope.aspect/main.c:315
 #, c-format
-msgid "Stream_no %d and n_stream_nodes %lld out of sync"
+msgid "%s=%s - must be a positive number"
 msgstr ""
-#: ../raster/r.stream.extract/streams.c:128
+#: ../raster/r.relief/main.c:474
 #, c-format
-msgid "BUG: stream node %d has only 1 tributary: %d"
+msgid "Shaded relief raster map <%s> complete"
 msgstr ""
-#: ../raster/r.stream.extract/streams.c:160
-msgid "Calculating flow accumulation..."
+#: ../raster/r.stats.quantile/main.c:86
+msgid "Computing histograms"
 msgstr ""
-#: ../raster/r.stream.extract/streams.c:336
-#: ../raster/r.watershed/ram/do_cum.c:443
-#: ../raster/r.watershed/seg/do_cum.c:487
-#, c-format
-msgid "MFD: cumulative proportion of flow distribution not 1.0 but %f"
+#: ../raster/r.stats.quantile/main.c:123
+msgid "No cells found where both base and cover are not NULL"
 msgstr ""
-#: ../raster/r.stream.extract/streams.c:392
-msgid "Extracting streams..."
+#: ../raster/r.stats.quantile/main.c:174 ../raster/r.quantile/main.c:103
+msgid "Computing bins"
 msgstr ""
-#: ../raster/r.stream.extract/streams.c:469
-msgid "Bug in stream extraction"
+#: ../raster/r.stats.quantile/main.c:231 ../raster/r.quantile/main.c:144
+msgid "Binning data"
 msgstr ""
-#: ../raster/r.stream.extract/streams.c:631
-msgid "Can't use Montgomery's method, no stream direction found"
+#: ../raster/r.stats.quantile/main.c:287 ../raster/r.quantile/main.c:189
+msgid "Sorting bins"
 msgstr ""
-#: ../raster/r.stream.extract/streams.c:700
-#, c-format
-msgid "MFD: A * path already processed when setting drainage direction: %lld of %lld cells"
+#: ../raster/r.stats.quantile/main.c:315
+msgid "Printing quantiles"
 msgstr ""
-#: ../raster/r.stream.extract/cseg.c:97
-msgid "Unabel to read segment file"
+#: ../raster/r.stats.quantile/main.c:360 ../raster/r.quantile/main.c:204
+msgid "Computing quantiles"
 msgstr ""
-#: ../raster/r.stream.extract/cseg.c:120
-#, c-format
-msgid "Unable to segment put row %d for raster map <%s>"
+#: ../raster/r.stats.quantile/main.c:412
+msgid "Generating reclass maps"
 msgstr ""
-#: ../raster/r.stream.extract/thin.c:83
-msgid "Thinning stream segments..."
+#: ../raster/r.stats.quantile/main.c:427 ../raster/r.stats.zonal/main.c:482
+#: ../raster/r.proj/readcell.c:59 ../raster/r.proj/readcell.c:129
+#: ../imagery/i.ortho.photo/i.ortho.rectify/readcell.c:66
+#: ../imagery/i.rectify/readcell.c:55
+msgid "Unable to open temporary file"
 msgstr ""
-#: ../raster/r.stream.extract/thin.c:169
-#, c-format
-msgid "%d of %lld stream segments were thinned"
+#: ../raster/r.stats.quantile/main.c:454
+msgid "Writing output maps"
 msgstr ""
-#: ../raster/r.stream.extract/dseg.c:19
-msgid "dseg_open(): unable to create segment file"
+#: ../raster/r.stats.quantile/main.c:518 ../raster/r.quantile/main.c:268
+msgid "percentile"
 msgstr ""
-#: ../raster/r.stream.extract/dseg.c:33
-msgid "Iillegal configuration parameter(s)"
+#: ../raster/r.stats.quantile/main.c:519 ../raster/r.quantile/main.c:269
+msgid "quantile"
 msgstr ""
-#: ../raster/r.stream.extract/dseg.c:120
-#, c-format
-msgid "Inable to segment put row %d for raster <%s>"
+#: ../raster/r.stats.quantile/main.c:520
+msgid "Compute category quantiles using two passes."
 msgstr ""
-#: ../raster/r.stats.quantile/main.c:86
-msgid "Computing histograms"
+#: ../raster/r.stats.quantile/main.c:530 ../raster/r.quantile/main.c:278
+msgid "Number of quantiles"
 msgstr ""
-#: ../raster/r.stats.quantile/main.c:123
-msgid "No cells found where both base and cover are not NULL"
+#: ../raster/r.stats.quantile/main.c:536 ../raster/r.quantile/main.c:286
+msgid "List of percentiles"
 msgstr ""
-#: ../raster/r.stats.quantile/main.c:315
-msgid "Printing quantiles"
+#: ../raster/r.stats.quantile/main.c:543 ../raster/r.quantile/main.c:292
+msgid "Number of bins to use"
 msgstr ""
-#: ../raster/r.stats.quantile/main.c:412
-msgid "Generating reclass maps"
+#: ../raster/r.stats.quantile/main.c:547
+msgid "Resultant raster map(s)"
 msgstr ""
-#: ../raster/r.stats.quantile/main.c:454
-msgid "Writing output maps"
+#: ../raster/r.stats.quantile/main.c:559 ../raster/r.kappa/main.c:104
+#: ../raster/r.kappa/main.c:109 ../raster/r.univar/r.univar_main.c:56
+#: ../raster/r.univar/r.univar_main.c:62 ../raster/r.univar/r.univar_main.c:72
+#: ../raster/r.report/parse.c:69 ../raster/r.report/parse.c:77
+#: ../raster/r.report/parse.c:85 ../raster/r.report/parse.c:109
+#: ../raster/r.report/parse.c:114 ../raster/r.report/parse.c:119
+#: ../raster/r.report/parse.c:124 ../raster/r.stats/main.c:123
+#: ../raster/r.stats/main.c:127 ../raster/r.stats/main.c:151
+#: ../locale/scriptstrings/t.vect.list_to_translate.c:8
+#: ../locale/scriptstrings/t.vect.list_to_translate.c:14
+#: ../locale/scriptstrings/t.vect.list_to_translate.c:16
+#: ../locale/scriptstrings/t.rast3d.univar_to_translate.c:9
+#: ../locale/scriptstrings/t.rast3d.univar_to_translate.c:12
+#: ../locale/scriptstrings/t.rast3d.list_to_translate.c:14
+#: ../locale/scriptstrings/t.rast3d.list_to_translate.c:16
+#: ../locale/scriptstrings/t.rast.univar_to_translate.c:8
+#: ../locale/scriptstrings/t.rast.univar_to_translate.c:12
+#: ../locale/scriptstrings/t.rast.list_to_translate.c:8
+#: ../locale/scriptstrings/t.rast.list_to_translate.c:15
+#: ../locale/scriptstrings/t.rast.list_to_translate.c:17
+#: ../locale/scriptstrings/t.list_to_translate.c:11
+#: ../locale/scriptstrings/t.list_to_translate.c:17
+#: ../locale/scriptstrings/t.list_to_translate.c:19
+#: ../locale/scriptstrings/t.vect.univar_to_translate.c:9
+#: ../locale/scriptstrings/t.vect.univar_to_translate.c:12
+msgid "Formatting"
 msgstr ""
-#: ../raster/r.stats.quantile/main.c:520
-msgid "Compute category quantiles using two passes."
+#: ../raster/r.stats.quantile/main.c:564 ../raster/r.stats.zonal/main.c:149
+msgid "Create reclass map with statistics as category labels"
 msgstr ""
-#: ../raster/r.stats.quantile/main.c:547
-msgid "Resultant raster map(s)"
-msgstr ""
 #: ../raster/r.stats.quantile/main.c:569
 msgid "Do not create output maps; just print statistics"
 msgstr ""
@@ -15517,34 +16556,42 @@
 msgid "Either -%c or %s= must be given"
 msgstr ""
-#: ../raster/r.stats.quantile/main.c:615
+#: ../raster/r.stats.quantile/main.c:590 ../raster/r.out.bin/main.c:369
+#: ../raster/r.neighbors/main.c:262 ../raster/r.in.bin/main.c:426
+#: ../raster/r.in.bin/main.c:432
 #, c-format
-msgid "Number of quantiles (%d) does not match number of output maps (%d)"
+msgid "-%c and %s= are mutually exclusive"
 msgstr ""
-#: ../raster/r.stats.quantile/main.c:632
+#: ../raster/r.stats.quantile/main.c:615
 #, c-format
-msgid "Base map <%s> has many categories (%d), computation might be slow and might need a lot of memory"
+msgid "Number of quantiles (%d) does not match number of output maps (%d)"
 msgstr ""
-#: ../raster/r.resample/main.c:57
-msgid "GRASS raster map layer data resampling capability."
+#: ../raster/r.stats.quantile/main.c:624 ../raster/r.stats.zonal/main.c:181
+msgid "The base map must be an integer (CELL) map"
 msgstr ""
-#: ../raster/r.resample/main.c:66
-msgid "Name of an input layer"
+#: ../raster/r.stats.quantile/main.c:627 ../raster/r.stats.zonal/main.c:184
+#, c-format
+msgid "Unable to read range of base map <%s>"
 msgstr ""
-#: ../raster/r.resample/main.c:73
-msgid "Name of an output layer"
+#: ../raster/r.stats.quantile/main.c:632
+#, c-format
+msgid ""
+"Base map <%s> has many categories (%d), computation might be slow and might "
+"need a lot of memory"
 msgstr ""
-#: ../raster/r.resample/main.c:138
-msgid "Creating new cats file..."
+#: ../raster/r.horizon/main.c:181 ../raster/r.sunmask/main.c:117
+#: ../raster/r.sunhours/main.c:73 ../raster/r.sun/main.c:252
+msgid "solar"
 msgstr ""
-#: ../raster/r.out.gridatb/main.c:70
-msgid "Exports GRASS raster map to GRIDATB.FOR map file (TOPMODEL)."
+#: ../raster/r.horizon/main.c:182 ../raster/r.sunmask/main.c:118
+#: ../raster/r.sunhours/main.c:75
+msgid "sun position"
 msgstr ""
 #: ../raster/r.horizon/main.c:184
@@ -15552,13 +16599,23 @@
 msgstr ""
 #: ../raster/r.horizon/main.c:186
-msgid "The module has two different modes of operation: 1. Computes the entire horizon around a single point whose coordinates are given with the 'coord' option. The horizon height (in radians). 2. Computes one or more raster maps of the horizon height in a single direction. The input for this is the angle (in degrees), which is measured counterclockwise with east=0, north=90 etc. The output is the horizon height in radians."
+msgid ""
+"The module has two different modes of operation: 1. Computes the entire "
+"horizon around a single point whose coordinates are given with the 'coord' "
+"option. The horizon height (in radians). 2. Computes one or more raster maps "
+"of the horizon height in a single direction. The input for this is the angle "
+"(in degrees), which is measured counterclockwise with east=0, north=90 etc. "
+"The output is the horizon height in radians."
 msgstr ""
 #: ../raster/r.horizon/main.c:203
 msgid "Direction in which you want to know the horizon height"
 msgstr ""
+#: ../raster/r.horizon/main.c:211 ../raster/r.sun/main.c:393
+msgid "Angle step size for multidirectional horizon [degrees]"
+msgstr ""
 #: ../raster/r.horizon/main.c:220
 msgid "Start angle for multidirectional horizon [degrees]"
 msgstr ""
@@ -15575,29 +16632,45 @@
 msgstr ""
 #: ../raster/r.horizon/main.c:237
-msgid "For horizon rasters, read from the DEM an extra buffer around the present region"
+msgid ""
+"For horizon rasters, read from the DEM an extra buffer around the present "
+"region"
 msgstr ""
 #: ../raster/r.horizon/main.c:245
-msgid "For horizon rasters, read from the DEM an extra buffer eastward the present region"
+msgid ""
+"For horizon rasters, read from the DEM an extra buffer eastward the present "
+"region"
 msgstr ""
 #: ../raster/r.horizon/main.c:253
-msgid "For horizon rasters, read from the DEM an extra buffer westward the present region"
+msgid ""
+"For horizon rasters, read from the DEM an extra buffer westward the present "
+"region"
 msgstr ""
 #: ../raster/r.horizon/main.c:261
-msgid "For horizon rasters, read from the DEM an extra buffer northward the present region"
+msgid ""
+"For horizon rasters, read from the DEM an extra buffer northward the present "
+"region"
 msgstr ""
 #: ../raster/r.horizon/main.c:269
-msgid "For horizon rasters, read from the DEM an extra buffer southward the present region"
+msgid ""
+"For horizon rasters, read from the DEM an extra buffer southward the present "
+"region"
 msgstr ""
 #: ../raster/r.horizon/main.c:277
 msgid "The maximum distance to consider when finding the horizon height"
 msgstr ""
+#: ../raster/r.horizon/main.c:278 ../raster/r.horizon/main.c:297
+#: ../locale/scriptstrings/r.import_to_translate.c:27
+#: ../locale/scriptstrings/r.import_to_translate.c:29
+msgid "Optional"
+msgstr ""
 #: ../raster/r.horizon/main.c:288
 msgid "Coordinate for which you want to calculate the horizon"
 msgstr ""
@@ -15606,7 +16679,11 @@
 msgid "Point mode"
 msgstr ""
-#: ../raster/r.horizon/main.c:304 ../raster/r.profile/main.c:64
+#: ../raster/r.horizon/main.c:296 ../raster/r.sun/main.c:513
+msgid "Sampling distance step coefficient (0.5-1.5)"
+msgstr ""
+#: ../raster/r.horizon/main.c:304 ../raster/r.profile/main.c:65
 msgid "Name of file for output (use output=- for stdout)"
 msgstr ""
@@ -15619,7 +16696,8 @@
 msgstr ""
 #: ../raster/r.horizon/main.c:355
-msgid "Note: In latitude-longitude coordinate system specify buffers in degree unit"
+msgid ""
+"Note: In latitude-longitude coordinate system specify buffers in degree unit"
 msgstr ""
 #: ../raster/r.horizon/main.c:368
@@ -15684,6 +16762,32 @@
 msgid "The distance value must be 0.5-1.5. Aborting."
 msgstr ""
+#: ../raster/r.horizon/main.c:531 ../raster/r.sun/main.c:780
+#: ../general/g.region/printwindow.c:251 ../general/g.region/printwindow.c:475
+#: ../general/g.region/printwindow.c:542 ../display/d.where/main.c:107
+msgid "Can't get projection info of current location"
+msgstr ""
+#: ../raster/r.horizon/main.c:534 ../raster/r.sun/main.c:784
+#: ../general/g.region/printwindow.c:254 ../general/g.region/printwindow.c:478
+#: ../general/g.region/printwindow.c:547 ../display/d.where/main.c:110
+msgid "Can't get projection units of current location"
+msgstr ""
+#: ../raster/r.horizon/main.c:538 ../raster/r.sun/main.c:788
+#: ../general/g.region/printwindow.c:257 ../general/g.region/printwindow.c:481
+#: ../general/g.region/printwindow.c:550 ../ps/ps.map/do_geogrid.c:272
+#: ../display/d.where/main.c:113 ../display/d.grid/plot.c:554
+msgid "Can't get projection key values of current location"
+msgstr ""
+#: ../raster/r.horizon/main.c:548 ../raster/r.sun/main.c:798
+#: ../raster/r.latlong/main.c:114 ../ps/ps.map/do_geogrid.c:278
+#: ../display/d.where/main.c:120 ../display/d.where/main.c:146
+#: ../display/d.grid/plot.c:561 ../display/d.grid/plot.c:588
+msgid "Unable to set up lat/long projection parameters"
+msgstr ""
 #: ../raster/r.horizon/main.c:654 ../raster/r.in.ascii/main.c:187
 #, c-format
 msgid "OOPS: rows changed from %d to %d"
@@ -15695,13 +16799,7 @@
 msgstr ""
 #: ../raster/r.horizon/main.c:846 ../raster/r.horizon/main.c:864
-#: ../raster/r.latlong/main.c:133 ../display/d.grid/plot.c:287
-#: ../display/d.grid/plot.c:293 ../display/d.grid/plot.c:334
-#: ../display/d.grid/plot.c:340 ../display/d.grid/plot.c:427
-#: ../display/d.grid/plot.c:433 ../display/d.grid/plot.c:485
-#: ../display/d.grid/plot.c:491 ../display/d.grid/plot.c:635
-#: ../display/d.grid/plot.c:651 ../display/d.grid/plot.c:668
-#: ../display/d.grid/plot.c:685 ../ps/ps.map/do_geogrid.c:86
+#: ../raster/r.latlong/main.c:133 ../ps/ps.map/do_geogrid.c:86
 #: ../ps/ps.map/do_geogrid.c:91 ../ps/ps.map/do_geogrid.c:115
 #: ../ps/ps.map/do_geogrid.c:120 ../ps/ps.map/do_geogrid.c:189
 #: ../ps/ps.map/do_geogrid.c:230 ../ps/ps.map/do_geogrid.c:306
@@ -15709,6 +16807,12 @@
 #: ../ps/ps.map/do_geogrid.c:356 ../ps/ps.map/do_geogrid.c:412
 #: ../ps/ps.map/do_geogrid.c:418 ../ps/ps.map/do_geogrid.c:422
 #: ../ps/ps.map/do_geogrid.c:430 ../ps/ps.map/do_geogrid.c:434
+#: ../display/d.grid/plot.c:287 ../display/d.grid/plot.c:293
+#: ../display/d.grid/plot.c:334 ../display/d.grid/plot.c:340
+#: ../display/d.grid/plot.c:427 ../display/d.grid/plot.c:433
+#: ../display/d.grid/plot.c:485 ../display/d.grid/plot.c:491
+#: ../display/d.grid/plot.c:635 ../display/d.grid/plot.c:651
+#: ../display/d.grid/plot.c:668 ../display/d.grid/plot.c:685
 msgid "Error in pj_do_proj"
 msgstr "Kļūda iekš pj_do_proj"
@@ -15717,309 +16821,368 @@
 msgid "Calculating map %01d of %01d (angle %.2f, raster map <%s>)"
 msgstr ""
-#: ../raster/r.sunmask/main.c:120
-msgid "Calculates cast shadow areas from sun position and elevation raster map."
+#: ../raster/r.region/main.c:54
+msgid "Sets the boundary definitions for a raster map."
 msgstr ""
-#: ../raster/r.sunmask/main.c:121
-msgid "Either exact sun position (A) is specified, or date/time to calculate the sun position (B) by r.sunmask itself."
+#: ../raster/r.region/main.c:60
+msgid "Set from current region"
 msgstr ""
-#: ../raster/r.sunmask/main.c:135
-msgid "Altitude of the sun in degrees above the horizon (A)"
+#: ../raster/r.region/main.c:61 ../raster/r.region/main.c:66
+#: ../raster/r.region/main.c:72 ../raster/r.region/main.c:87
+#: ../raster/r.region/main.c:94 ../raster/r.region/main.c:101
+#: ../raster/r.region/main.c:144 ../general/g.region/main.c:78
+#: ../general/g.region/main.c:84 ../general/g.region/main.c:171
+#: ../general/g.region/main.c:178 ../general/g.region/main.c:187
+#: ../general/g.region/main.c:195
+msgid "Existing"
+msgstr "Eksistējošs"
+#: ../raster/r.region/main.c:65 ../general/g.region/main.c:77
+msgid "Set from default region"
 msgstr ""
-#: ../raster/r.sunmask/main.c:136 ../raster/r.sunmask/main.c:145
-#: ../raster/r.sunmask/main.c:213 ../raster/r.sunmask/main.c:223
-#: ../display/d.text/main.c:198 ../display/d.text/main.c:207
-#: ../display/d.text/main.c:216 ../display/d.text/main.c:253
-#: ../display/d.text/main.c:258
-msgid "Position"
+#: ../raster/r.region/main.c:70 ../raster/r.external/main.c:119
+#: ../raster/r.in.gdal/main.c:218
+msgid "Auto-adjustment for lat/lon"
 msgstr ""
-#: ../raster/r.sunmask/main.c:144
-msgid "Azimuth of the sun in degrees from north (A)"
+#: ../raster/r.region/main.c:71 ../raster/r.external/main.c:120
+#: ../raster/r.in.gdal/main.c:219
+msgid "Attempt to fix small precision errors in resolution and extents"
 msgstr ""
-#: ../raster/r.sunmask/main.c:151
-msgid "Year (B)"
+#: ../raster/r.region/main.c:77
+msgid "Name of raster map to change"
 msgstr ""
-#: ../raster/r.sunmask/main.c:159
-msgid "Month (B)"
+#: ../raster/r.region/main.c:85
+msgid "Set region from named region"
 msgstr ""
-#: ../raster/r.sunmask/main.c:167
-msgid "Day (B)"
+#: ../raster/r.region/main.c:93
+msgid "Set region to match this raster map"
 msgstr ""
-#: ../raster/r.sunmask/main.c:175
-msgid "Hour (B)"
+#: ../raster/r.region/main.c:100
+msgid "Set region to match this vector map"
 msgstr ""
-#: ../raster/r.sunmask/main.c:183
-msgid "Minutes (B)"
+#: ../raster/r.region/main.c:109 ../general/g.region/main.c:203
+msgid "Value for the northern edge"
+msgstr "Ziemeļu šķautnes vērtība"
+#: ../raster/r.region/main.c:110 ../raster/r.region/main.c:119
+#: ../raster/r.region/main.c:128 ../raster/r.region/main.c:137
+#: ../raster/r.in.bin/main.c:285 ../raster/r.in.bin/main.c:339
+#: ../raster/r.in.bin/main.c:347 ../raster/r.in.bin/main.c:355
+#: ../raster/r.in.bin/main.c:363 ../raster/r.in.bin/main.c:370
+#: ../raster/r.in.bin/main.c:377 ../general/g.region/main.c:160
+#: ../general/g.region/main.c:204 ../general/g.region/main.c:213
+#: ../general/g.region/main.c:222 ../general/g.region/main.c:231
+#: ../general/g.region/main.c:240 ../general/g.region/main.c:249
+#: ../general/g.region/main.c:325 ../general/g.region/main.c:336
+#: ../raster3d/r3.in.bin/main.c:284 ../raster3d/r3.in.bin/main.c:292
+#: ../raster3d/r3.in.bin/main.c:300 ../raster3d/r3.in.bin/main.c:308
+#: ../raster3d/r3.in.bin/main.c:316 ../raster3d/r3.in.bin/main.c:323
+#: ../raster3d/r3.in.bin/main.c:330 ../raster3d/r3.in.bin/main.c:337
+#: ../raster3d/r3.in.bin/main.c:344
+msgid "Bounds"
+msgstr "Robežas"
+#: ../raster/r.region/main.c:118 ../general/g.region/main.c:212
+msgid "Value for the southern edge"
+msgstr "Dienvidu šķautnes vērtība"
+#: ../raster/r.region/main.c:127 ../general/g.region/main.c:221
+msgid "Value for the eastern edge"
+msgstr "Austrumu šķautnes vērtība"
+#: ../raster/r.region/main.c:136 ../general/g.region/main.c:230
+msgid "Value for the western edge"
+msgstr "Rietumu šķautnes vērtība"
+#: ../raster/r.region/main.c:143
+msgid "Raster map to align to"
 msgstr ""
-#: ../raster/r.sunmask/main.c:191
-msgid "Seconds (B)"
+#: ../raster/r.buffer/main.c:69
+#: ../locale/scriptstrings/r.buffer.lowmem_to_translate.c:1
+msgid ""
+"Creates a raster map showing buffer zones surrounding cells that contain non-"
+"NULL category values."
 msgstr ""
-#: ../raster/r.sunmask/main.c:201
-msgid "Timezone"
+#: ../raster/r.buffer/main.c:81
+#: ../locale/scriptstrings/r.buffer.lowmem_to_translate.c:6
+msgid "Distance zone(s)"
 msgstr ""
-#: ../raster/r.sunmask/main.c:202
-msgid "East positive, offset from GMT, also use to adjust daylight savings"
+#: ../raster/r.buffer/main.c:88
+#: ../locale/scriptstrings/r.buffer.lowmem_to_translate.c:7
+msgid "Units of distance"
+msgstr "Attāluma vienības"
+#: ../raster/r.buffer/main.c:94
+#: ../locale/scriptstrings/r.buffer.lowmem_to_translate.c:5
+msgid "Ignore zero (0) data cells instead of NULL cells"
 msgstr ""
-#: ../raster/r.sunmask/main.c:211
-msgid "Easting coordinate (point of interest)"
+#: ../raster/r.buffer/main.c:131
+msgid "Parse distances error"
 msgstr ""
-#: ../raster/r.sunmask/main.c:212 ../raster/r.sunmask/main.c:222
-msgid "Default: map center"
+#: ../raster/r.buffer/main.c:150
+#, c-format
+msgid "Pass %d (of %d)"
 msgstr ""
-#: ../raster/r.sunmask/main.c:221
-msgid "Northing coordinate (point of interest)"
+#: ../raster/r.buffer/write_map.c:45 ../raster/r.cost/main.c:1034
+#: ../raster/r.flow/io.c:207
+#, c-format
+msgid "Writing output raster map <%s>..."
 msgstr ""
-#: ../raster/r.sunmask/main.c:227
-msgid "Do not ignore zero elevation"
+#: ../raster/r.buffer/execute.c:34
+msgid "Finding buffer zones..."
 msgstr ""
-#: ../raster/r.sunmask/main.c:231
-msgid "Calculate sun position only and exit"
+#: ../raster/r.buffer/parse_dist.c:54
+#, c-format
+msgid "%s: %s - illegal distance specification"
 msgstr ""
-#: ../raster/r.sunmask/main.c:237
-msgid "Print the sun position output in shell script style"
-msgstr "Drukāt saules pozīcijas aprakstu komandrindas skripta stilā"
-#: ../raster/r.sunmask/main.c:251
+#: ../raster/r.buffer/read_map.c:52 ../raster/r.flow/io.c:89
+#: ../raster/r.flow/io.c:107
 #, c-format
-msgid "Using map center coordinates: %f %f"
+msgid "Reading input raster map <%s>..."
 msgstr ""
-#: ../raster/r.sunmask/main.c:258
-msgid "Empty east coordinate specified"
+#: ../raster/r.quant/main.c:49
+msgid "quantization"
 msgstr ""
-#: ../raster/r.sunmask/main.c:260
-msgid "Empty north coordinate specified"
+#: ../raster/r.quant/main.c:51
+msgid "Produces the quantization file for a floating-point map."
 msgstr ""
-#: ../raster/r.sunmask/main.c:279
-msgid "Either define sun position or location/date/time parameters"
+#: ../raster/r.quant/main.c:59
+msgid "Raster map(s) to be quantized"
 msgstr ""
-#: ../raster/r.sunmask/main.c:282
-msgid "Neither sun position nor east/north, date/time/timezone definition are complete"
+#: ../raster/r.quant/main.c:64
+msgid "Path to rules file (\"-\" to read from stdin)"
 msgstr ""
-#: ../raster/r.sunmask/main.c:286
-#, c-format
-msgid "Calculating sun position... (using solpos (V. %s) from NREL)"
+#: ../raster/r.quant/main.c:70
+msgid "Base map to take quant rules from"
 msgstr ""
-#: ../raster/r.sunmask/main.c:291
-msgid "Using user defined sun azimuth, altitude settings (ignoring eventual other values)"
+#: ../raster/r.quant/main.c:75
+msgid "Floating point range: dmin,dmax"
 msgstr ""
-#: ../raster/r.sunmask/main.c:399
-msgid "Please correct settings"
+#: ../raster/r.quant/main.c:81
+msgid "Integer range: min,max"
 msgstr ""
-#: ../raster/r.sunmask/main.c:413
-#, c-format
-msgid "Time (%02i:%02i:%02i) is before sunrise (%02d:%02d:%02d)"
+#: ../raster/r.quant/main.c:86
+msgid "Truncate floating point data"
 msgstr ""
-#: ../raster/r.sunmask/main.c:417
+#: ../raster/r.quant/main.c:90
+msgid "Round floating point data"
+msgstr ""
+#: ../raster/r.quant/main.c:111
 #, c-format
-msgid "Time (%02i:%02i:%02i) is before sunrise"
+msgid "-%c, -%c, %s=, %s= and %s= are mutually exclusive"
 msgstr ""
-#: ../raster/r.sunmask/main.c:420 ../raster/r.sunmask/main.c:430
-msgid "Nothing to calculate. Please verify settings."
-msgstr "Nav nekā ko rēķināt. Lūdzu pārbaudi iestatījumus."
-#: ../raster/r.sunmask/main.c:424
+#: ../raster/r.quant/main.c:120
 #, c-format
-msgid "Time (%02i:%02i:%02i) is after sunset (%02d:%02d:%02d)"
+msgid "%s= and %s= must be used together"
 msgstr ""
-#: ../raster/r.sunmask/main.c:428
+#: ../raster/r.quant/main.c:131
 #, c-format
-msgid "Time (%02i:%02i:%02i) is after sunset"
+msgid "%s is integer map, it can't be quantized"
 msgstr ""
-#: ../raster/r.sunmask/main.c:439
-msgid "You already know the sun position"
+#: ../raster/r.quant/main.c:139
+msgid "Truncating..."
 msgstr ""
-#: ../raster/r.sunmask/main.c:444 ../vector/v.colors/main.c:199
-#, c-format
-msgid "Option <%s> required"
+#: ../raster/r.quant/main.c:144
+msgid "Rounding..."
 msgstr ""
-#: ../raster/r.sunmask/main.c:456
+#: ../raster/r.quant/main.c:152
 #, c-format
-msgid "Unable to open range file for raster map <%s>"
+msgid "%s is integer map, it can't be used as basemap"
 msgstr ""
-#: ../raster/r.sunmask/main.c:472
-msgid "Calculating shadows from DEM..."
-msgstr "Rēķina ēnas no DEM..."
-#: ../raster/r.sunmask/g_solposition.c:66
-msgid "Unable to calculate sun position in un-projected locations. Specify sunposition directly."
+#: ../raster/r.quant/main.c:156
+#, c-format
+msgid "unable to read quant rules for basemap <%s>"
 msgstr ""
-#: ../raster/r.sunmask/g_solposition.c:88
+#: ../raster/r.quant/main.c:163 ../raster/r.quant/main.c:166
 #, c-format
-msgid "Specified point %f, %f outside of current region, is that intended? Anyway, it will be used."
+msgid "invalid value for %s= <%s>"
 msgstr ""
-#: ../raster/r.sunmask/g_solposition.c:98 ../raster/r.latlong/main.c:101
-msgid "Unable to get projection info of current location"
+#: ../raster/r.quant/main.c:168
+#, c-format
+msgid "Setting quant rules for input map(s) to (%f,%f) -> (%d,%d)"
 msgstr ""
-#: ../raster/r.sunmask/g_solposition.c:101 ../raster/r.latlong/main.c:103
-msgid "Unable to get projection units of current location"
+#: ../raster/r.quant/main.c:181
+msgid "No rules specified. Quant table(s) not changed."
 msgstr ""
-#: ../raster/r.sunmask/g_solposition.c:104 ../raster/r.latlong/main.c:105
-msgid "Unable to get projection key values of current location"
+#: ../raster/r.quant/main.c:183 ../raster/r.recode/main.c:99
+#: ../raster/r.reclass/main.c:142
+msgid "No rules specified"
 msgstr ""
-#: ../raster/r.info/main.c:73 ../vector/v.info/main.c:41
-msgid "history"
-msgstr "vēsture"
-#: ../raster/r.info/main.c:75
-msgid "Outputs basic information about a raster map."
+#: ../raster/r.quant/main.c:189
+#, c-format
+msgid "New quant table created for %s"
 msgstr ""
-#: ../raster/r.info/main.c:81
-msgid "Print raster array information in shell script style"
+#: ../raster/r.quant/read_rules.c:50
+msgid "Old data range is empty"
 msgstr ""
-#: ../raster/r.info/main.c:85
-msgid "Print range in shell script style"
+#: ../raster/r.quant/read_rules.c:56
+#, c-format
+msgid "Old data range is %s to %s"
 msgstr ""
-#: ../raster/r.info/main.c:89
-msgid "Print extended metadata information in shell script style"
+#: ../raster/r.quant/read_rules.c:59
+msgid "Old integer data range is empty"
 msgstr ""
-#: ../raster/r.info/main.c:99
+#: ../raster/r.quant/read_rules.c:61
 #, c-format
-msgid "Flags -%c and -%c/%c/%c are mutually exclusive"
+msgid "Old integer data range is %d to %d"
 msgstr ""
-#: ../raster/r.info/main.c:127
-msgid "Unable to read range file"
+#: ../raster/r.quant/read_rules.c:83
+#, c-format
+msgid "unable to open input file <%s>"
 msgstr ""
-#: ../raster/r.recode/read_rules.c:20
+#: ../raster/r.quant/read_rules.c:89
 #, c-format
-msgid "Unable to read f_range for map %s"
+msgid ""
+"\n"
+"Enter the rule or 'help' for the format description or 'end' to exit:\n"
 msgstr ""
-#: ../raster/r.recode/read_rules.c:24 ../display/d.colortable/main.c:146
-msgid "Data range is empty"
+#: ../raster/r.quant/read_rules.c:112
+msgid "quant rules do not cover the whole range map"
 msgstr ""
-#: ../raster/r.recode/read_rules.c:30
+#: ../raster/r.quant/read_rules.c:158 ../raster/r.recode/read_rules.c:126
 #, c-format
-msgid "Data range of %s is %s to %s (entire map)"
+msgid "%s is not a valid rule"
 msgstr ""
-#: ../raster/r.recode/read_rules.c:35 ../raster/r.stats/main.c:358
+#: ../raster/r.kappa/calc_kappa.c:32
 #, c-format
-msgid "Unable to read range for map <%s>"
+msgid "Cannot open file <%s> to write kappa and relevant parameters"
 msgstr ""
-#: ../raster/r.recode/read_rules.c:39
-#, c-format
-msgid "Integer data range of %s is empty"
+#: ../raster/r.kappa/main.c:72
+msgid ""
+"Calculates error matrix and kappa parameter for accuracy assessment of "
+"classification result."
 msgstr ""
-#: ../raster/r.recode/read_rules.c:41
-#, c-format
-msgid "Integer data range of %s is %d to %d"
+#: ../raster/r.kappa/main.c:78
+msgid "Name of raster map containing classification result"
 msgstr ""
-#: ../raster/r.recode/read_rules.c:61
-msgid "Enter the rule or 'help' for the format description"
+#: ../raster/r.kappa/main.c:83
+msgid "Name of raster map containing reference classes"
 msgstr ""
-#: ../raster/r.recode/read_rules.c:85
-msgid "Enter a rule in one of these formats:"
+#: ../raster/r.kappa/main.c:88
+msgid "Name for output file containing error matrix and kappa"
 msgstr ""
-#: ../raster/r.recode/read_rules.c:87
-msgid "old_low:old_high:new_low:new_high"
-msgstr ""
+#: ../raster/r.kappa/main.c:90 ../raster/r.kappa/main.c:98
+#: ../raster/r.univar/r.univar_main.c:42
+#: ../locale/scriptstrings/v.unpack_to_translate.c:8
+#: ../locale/scriptstrings/v.unpack_to_translate.c:11
+#: ../locale/scriptstrings/r.unpack_to_translate.c:7
+#: ../locale/scriptstrings/r.unpack_to_translate.c:10 ../ps/ps.map/main.c:100
+#: ../ps/ps.map/main.c:113 ../ps/ps.map/main.c:135
+msgid "Output settings"
+msgstr "Izvades iestatījumi"
-#: ../raster/r.recode/read_rules.c:88
-msgid "old_low:old_high:new_val      (i.e. new_high == new_low)"
+#: ../raster/r.kappa/main.c:96
+msgid "Title for error matrix and kappa"
 msgstr ""
-#: ../raster/r.recode/read_rules.c:89
-msgid "*:old_val:new_val             (interval [inf, old_val])"
+#: ../raster/r.kappa/main.c:102
+msgid "Wide report"
 msgstr ""
-#: ../raster/r.recode/read_rules.c:90
-msgid "old_val:*:new_val             (interval [old_val, inf])"
+#: ../raster/r.kappa/main.c:103
+msgid "132 columns (default: 80)"
 msgstr ""
-#: ../raster/r.recode/read_rules.c:92
-msgid "When finished type \"end\"."
+#: ../raster/r.kappa/main.c:108
+msgid "No header in the report"
 msgstr ""
-#: ../raster/r.recode/read_rules.c:126 ../raster/r.quant/read_rules.c:158
+#: ../raster/r.kappa/prt_mat.c:39
 #, c-format
-msgid "%s is not a valid rule"
+msgid "Cannot open file <%s> to write cats and counts (error matrix)"
 msgstr ""
-#: ../raster/r.recode/main.c:49
-msgid "recode categories"
+#: ../raster/r.kappa/prt_hdr.c:18
+#, c-format
+msgid "Cannot open file <%s> to write header"
 msgstr ""
-#: ../raster/r.recode/main.c:51
-msgid "Recodes categorical raster maps."
+#: ../raster/r.kappa/stats.c:14 ../raster/r.report/stats.c:128
+msgid "Problem reading r.stats output"
 msgstr ""
-#: ../raster/r.recode/main.c:54
-msgid "Name of raster map to be recoded"
+#: ../raster/r.kappa/prt_label.c:17
+#, c-format
+msgid "Can't open file <%s> to write label"
 msgstr ""
-#: ../raster/r.recode/main.c:60
-msgid "File containing recode rules"
+#: ../raster/r.null/main.c:61 ../raster/r.fill.stats/main.c:779
+#: ../raster3d/r3.null/main.c:181
+msgid "null data"
 msgstr ""
-#: ../raster/r.recode/main.c:71
-msgid "Align the current region to the input raster map"
+#: ../raster/r.null/main.c:62
+msgid "Manages NULL-values of given raster map."
 msgstr ""
-#: ../raster/r.recode/main.c:75
-msgid "Force output to 'double' raster map type (DCELL)"
+#: ../raster/r.null/main.c:65
+msgid "Name of raster map for which to edit null values"
 msgstr ""
-#: ../raster/r.recode/main.c:96
-#, c-format
-msgid "No rules specified. Raster map <%s> not created."
+#: ../raster/r.null/main.c:73 ../raster3d/r3.null/main.c:63
+msgid "List of cell values to be set to NULL"
 msgstr ""
-#: ../raster/r.null/main.c:62
-msgid "Manages NULL-values of given raster map."
+#: ../raster/r.null/main.c:74 ../raster/r.null/main.c:82
+#: ../general/g.proj/main.c:193
+msgid "Modify"
 msgstr ""
-#: ../raster/r.null/main.c:65
-msgid "Name of raster map for which to edit null values"
+#: ../raster/r.null/main.c:81 ../raster3d/r3.null/main.c:70
+msgid "The value to replace the null value by"
 msgstr ""
 #: ../raster/r.null/main.c:86
@@ -16053,7 +17216,9 @@
 #: ../raster/r.null/main.c:132
 #, c-format
-msgid "Raster map <%s> is a reclass of map <%s@%s>. Consider to generate a copy with r.mapcalc. Exiting."
+msgid ""
+"Raster map <%s> is a reclass of map <%s@%s>. Consider to generate a copy "
+"with r.mapcalc. Exiting."
 msgstr ""
 #: ../raster/r.null/main.c:138
@@ -16125,1171 +17290,891 @@
 msgid "Writing new data for raster map <%s>..."
 msgstr ""
-#: ../raster/r.param.scale/process.c:75
-msgid "E-W and N-S grid resolutions are different. Taking average."
+#: ../raster/r.patch/main.c:60
+#: ../locale/scriptstrings/i.image.mosaic_to_translate.c:4
+msgid "mosaicking"
 msgstr ""
-#: ../raster/r.param.scale/interface.c:55
-msgid "geomorphology"
+#: ../raster/r.patch/main.c:61 ../locale/scriptstrings/t.merge_to_translate.c:4
+msgid "merge"
 msgstr ""
-#: ../raster/r.param.scale/interface.c:58
-msgid "landform"
+#: ../raster/r.patch/main.c:62
+msgid "patching"
 msgstr ""
-#: ../raster/r.param.scale/interface.c:59
-msgid "Extracts terrain parameters from a DEM."
+#: ../raster/r.patch/main.c:66
+msgid ""
+"Creates a composite raster map layer by using known category values from one "
+"(or more) map layer(s) to fill in areas of \"no data\" in another map layer."
 msgstr ""
-#: ../raster/r.param.scale/interface.c:60
-msgid "Uses a multi-scale approach by taking fitting quadratic parameters to any size window (via least squares)."
+#: ../raster/r.patch/main.c:73
+msgid "Name of raster maps to be patched together"
 msgstr ""
-#: ../raster/r.param.scale/interface.c:78
-msgid "Name for output raster map containing morphometric parameter"
+#: ../raster/r.patch/main.c:76
+msgid "Name for resultant raster map"
 msgstr ""
-#: ../raster/r.param.scale/interface.c:82
-msgid "Slope tolerance that defines a 'flat' surface (degrees)"
+#: ../raster/r.patch/main.c:83
+msgid "Use zero (0) for transparency instead of NULL"
 msgstr ""
-#: ../raster/r.param.scale/interface.c:89
-msgid "Curvature tolerance that defines 'planar' surface"
+#: ../raster/r.patch/main.c:88
+msgid "Do not create color and category files"
 msgstr ""
-#: ../raster/r.param.scale/interface.c:96
-msgid "Size of processing window (odd number only)"
+#: ../raster/r.patch/main.c:103
+msgid "The minimum number of input raster maps is two"
 msgstr ""
-#: ../raster/r.param.scale/interface.c:104
-msgid "Morphometric parameter in 'size' window to calculate"
+#: ../raster/r.patch/main.c:180
+#, c-format
+msgid "Creating support files for raster map <%s>..."
 msgstr ""
-#: ../raster/r.param.scale/interface.c:112
-msgid "Exponent for distance weighting (0.0-4.0)"
+#: ../raster/r.walk/main.c:179 ../raster/r.drain/main.c:111
+#: ../raster/r.cost/main.c:141
+msgid "cost surface"
 msgstr ""
-#: ../raster/r.param.scale/interface.c:124
-msgid "Constrain model through central window cell"
+#: ../raster/r.walk/main.c:180 ../raster/r.spreadpath/main.c:90
+#: ../raster/r.cost/main.c:142
+msgid "cumulative costs"
 msgstr ""
-#: ../raster/r.param.scale/interface.c:167
-msgid "Morphometric parameter not recognised. Assuming 'Elevation'"
+#: ../raster/r.walk/main.c:183
+msgid ""
+"Creates a raster map showing the anisotropic cumulative cost of moving "
+"between different geographic locations on an input raster map whose cell "
+"category values represent cost."
 msgstr ""
-#: ../raster/r.param.scale/interface.c:175
-msgid "Inappropriate window size (too big or even)"
+#: ../raster/r.walk/main.c:193
+msgid "Name of input raster map containing friction costs"
 msgstr ""
-#: ../raster/r.param.scale/main.c:42
-msgid "Lat/Long locations are not supported by this module"
+#: ../raster/r.walk/main.c:196
+msgid "Name for output raster map to contain walking costs"
 msgstr ""
-#: ../raster/r.surf.random/main.c:40
-msgid "Produces a raster surface map of uniform random deviates with defined range."
+#: ../raster/r.walk/main.c:202 ../raster/r.cost/main.c:167
+msgid "Name for output raster map to contain movement directions"
 msgstr ""
-#: ../raster/r.surf.random/main.c:46
-msgid "Minimum random value"
+#: ../raster/r.walk/main.c:203 ../raster/r.cost/main.c:161
+#: ../raster/r.cost/main.c:168
+msgid "Optional outputs"
 msgstr ""
-#: ../raster/r.surf.random/main.c:52
-msgid "Maximum random value"
+#: ../raster/r.walk/main.c:208 ../raster/r.cost/main.c:173
+msgid "Name of starting vector points map"
 msgstr ""
-#: ../raster/r.surf.random/main.c:58
-msgid "Create an integer raster map"
+#: ../raster/r.walk/main.c:209 ../raster/r.walk/main.c:221
+#: ../raster/r.walk/main.c:228 ../raster/r.walk/main.c:309
+#: ../raster/r.drain/main.c:139 ../raster/r.drain/main.c:146
+#: ../raster/r.cost/main.c:174 ../raster/r.cost/main.c:186
+#: ../raster/r.cost/main.c:193 ../raster/r.cost/main.c:243
+msgid "Start"
 msgstr ""
-#: ../raster/r.out.ppm3/main.c:59
-msgid "Converts 3 GRASS raster layers (R,G,B) to a PPM image file."
+#: ../raster/r.walk/main.c:214 ../raster/r.cost/main.c:179
+msgid "Name of stopping vector points map"
 msgstr ""
-#: ../raster/r.out.ppm3/main.c:84
-msgid "Name for new PPM file. (use '-' for stdout)"
+#: ../raster/r.walk/main.c:215 ../raster/r.walk/main.c:235
+#: ../raster/r.cost/main.c:180 ../raster/r.cost/main.c:200
+msgid "Stop"
 msgstr ""
-#: ../raster/r.out.ppm3/main.c:88
-msgid "Add comments to describe the region"
+#: ../raster/r.walk/main.c:220 ../raster/r.cost/main.c:185
+msgid "Name of starting raster points map"
 msgstr ""
-#: ../raster/r.out.ppm3/main.c:95 ../raster/r.out.ppm/main.c:101
-#, c-format
-msgid "row = %d"
-msgid_plural "rows = %d"
-msgstr[0] ""
-msgstr[1] ""
-msgstr[2] ""
-#. GTC Raster columns
-#: ../raster/r.out.ppm3/main.c:97 ../raster/r.out.ppm/main.c:102
-#, c-format
-msgid "column = %d"
-msgid_plural "columns = %d"
-msgstr[0] ""
-msgstr[1] ""
-msgstr[2] ""
-#: ../raster/r.out.ppm3/main.c:160
-msgid "Converting... "
+#: ../raster/r.walk/main.c:227 ../raster/r.drain/main.c:138
+#: ../raster/r.cost/main.c:192
+msgid "Coordinates of starting point(s) (E,N)"
 msgstr ""
-#: ../raster/r.surf.idw/main.c:107 ../vector/v.surf.idw/main.c:90
-msgid "IDW"
+#: ../raster/r.walk/main.c:234 ../raster/r.cost/main.c:199
+msgid "Coordinates of stopping point(s) (E,N)"
 msgstr ""
-#: ../raster/r.surf.idw/main.c:109
-msgid "Provides surface interpolation from raster point data by Inverse Distance Squared Weighting."
+#: ../raster/r.walk/main.c:244 ../raster/r.cost/main.c:209
+msgid "Maximum cumulative cost"
 msgstr ""
-#: ../raster/r.surf.idw/main.c:119 ../vector/v.surf.idw/main.c:113
-msgid "Number of interpolation points"
-msgstr ""
+#: ../raster/r.walk/main.c:253 ../raster/r.cost/main.c:218
+msgid "Cost assigned to null cells. By default, null cells are excluded"
+msgstr "NULL šūnām piešķiramās izmaksas. Parasti NULL šūnas netiek ietvertas"
-#: ../raster/r.surf.idw/main.c:124
-msgid "Output is the interpolation error"
-msgstr ""
+#: ../raster/r.walk/main.c:254 ../raster/r.walk/main.c:304
+#: ../raster/r.cost/main.c:219 ../raster/r.cost/main.c:238
+msgid "NULL cells"
+msgstr "NULL šūnas"
-#: ../raster/r.surf.idw/main.c:130
-#, c-format
-msgid "Illegal value for '%s' (%s)"
+#: ../raster/r.walk/main.c:263 ../raster/r.cost/main.c:228
+msgid "Maximum memory to be used in MB"
 msgstr ""
-#: ../raster/r.surf.idw/main.c:164 ../raster/r.statistics/main.c:104
-#: ../raster/r.statistics/main.c:107
-msgid "This module currently only works for integer (CELL) maps"
+#: ../raster/r.walk/main.c:273
+msgid "Coefficients for walking energy formula parameters a,b,c,d"
 msgstr ""
-#: ../raster/r.surf.idw/main.c:260
-#, c-format
-msgid "Interpolating raster map <%s> (%d row)..."
-msgid_plural "Interpolating raster map <%s> (%d rows)..."
-msgstr[0] ""
-msgstr[1] ""
-msgstr[2] ""
-#: ../raster/r.surf.gauss/main.c:42
-msgid "Generates a raster map using gaussian random number generator."
+#: ../raster/r.walk/main.c:283
+msgid "Lambda coefficients for combining walking energy and friction cost"
 msgstr ""
-#: ../raster/r.surf.gauss/main.c:44
-msgid "Mean and standard deviation of gaussian deviates can be expressed by the user."
+#: ../raster/r.walk/main.c:293
+msgid "Slope factor determines travel energy cost per height step"
 msgstr ""
-#: ../raster/r.surf.gauss/main.c:51
-msgid "Distribution mean"
+#: ../raster/r.walk/main.c:299 ../raster/r.cost/main.c:233
+msgid "Use the 'Knight's move'; slower, but more accurate"
 msgstr ""
-#: ../raster/r.surf.gauss/main.c:57
-msgid "Standard deviation"
+#: ../raster/r.walk/main.c:303 ../raster/r.cost/main.c:237
+msgid "Keep null values in output raster map"
 msgstr ""
-#: ../raster/r.contour/cont.c:82
-#, c-format
-msgid "Writing vector contour (one level)..."
-msgid_plural "Writing vector contours (total levels %d)..."
-msgstr[0] ""
-msgstr[1] ""
-msgstr[2] ""
-#: ../raster/r.contour/cont.c:213
-#, c-format
-msgid "%d crossing found"
-msgid_plural "%d crossings found"
-msgstr[0] ""
-msgstr[1] ""
-msgstr[2] ""
-#: ../raster/r.contour/cont.c:266
-msgid "Illegal edge number"
+#: ../raster/r.walk/main.c:308 ../raster/r.cost/main.c:242
+msgid "Start with values in raster map"
 msgstr ""
-#: ../raster/r.contour/cont.c:374
-msgid "Edge number out of range"
+#: ../raster/r.walk/main.c:313 ../raster/r.cost/main.c:247
+msgid "Print info about disk space and memory requirements and exit"
 msgstr ""
-#: ../raster/r.contour/main.c:89
-msgid "contours"
+#: ../raster/r.walk/main.c:357 ../raster/r.cost/main.c:297
+msgid "Must specify exactly one of start_points, start_rast or coordinate"
 msgstr ""
-#: ../raster/r.contour/main.c:91
-msgid "Produces a vector map of specified contours from a raster map."
+#: ../raster/r.walk/main.c:362 ../raster/r.walk/main.c:845
+#: ../raster/r.cost/main.c:302 ../raster/r.cost/main.c:712
+msgid "No start points"
 msgstr ""
-#: ../raster/r.contour/main.c:102 ../raster/r.contour/main.c:110
-#: ../raster/r.contour/main.c:117 ../raster/r.contour/main.c:124
-msgid "Contour levels"
+#: ../raster/r.walk/main.c:369 ../raster/r.cost/main.c:309
+#, c-format
+msgid "Inappropriate maximum cost: %d"
 msgstr ""
-#: ../raster/r.contour/main.c:140
+#: ../raster/r.walk/main.c:372 ../raster/r.cost/main.c:312
 #, c-format
-msgid "Neither <%s> nor <%s> option must be specified"
+msgid "Inappropriate amount of memory: %d"
 msgstr ""
-#: ../raster/r.contour/main.c:149 ../raster/r.stats/main.c:331
+#: ../raster/r.walk/main.c:377
 #, c-format
-msgid "Unable to read fp range of raster map <%s>"
+msgid "Missing required value: got %d instead of 4"
 msgstr ""
-#: ../raster/r.contour/main.c:203 ../vector/v.extract/copy_tab.c:57
-#: ../vector/v.voronoi/main.c:384 ../vector/v.select/copy_tabs.c:17
-#: ../vector/v.generalize/misc.c:134
-msgid "Writing attributes..."
+#: ../raster/r.walk/main.c:380
+#, c-format
+msgid "Walking costs are a=%g b=%g c=%g d=%g"
 msgstr ""
-#: ../raster/r.contour/main.c:237 ../raster/r.in.lidar/main.c:606
-#: ../vector/v.generalize/displacement.c:78
-msgid "Reading data..."
+#: ../raster/r.walk/main.c:385 ../raster/r.walk/main.c:393
+#, c-format
+msgid "Missing required value: %d"
 msgstr ""
-#: ../raster/r.contour/main.c:263
+#: ../raster/r.walk/main.c:388
 #, c-format
-msgid "Range of data: min=%f, max=%f"
+msgid "Lambda is %g"
 msgstr ""
-#: ../raster/r.contour/main.c:265
-msgid "Range of data: empty"
+#: ../raster/r.walk/main.c:396
+#, c-format
+msgid "Slope_factor is %g"
 msgstr ""
-#: ../raster/r.contour/main.c:293 ../raster/r.contour/main.c:296
-msgid "This step value is not allowed"
+#: ../raster/r.walk/main.c:415 ../raster/r.cost/main.c:330
+msgid "Assigning negative cost to null cell. Null cells excluded."
 msgstr ""
-#: ../raster/r.contour/main.c:321
+#: ../raster/r.walk/main.c:525 ../raster/r.walk/main.c:538
+#: ../raster/r.cost/main.c:412 ../raster/r.cost/main.c:424
 #, c-format
-msgid "Range of levels: min = %f, max = %f"
+msgid "Will need at least %.2f MB of disk space"
 msgstr ""
-#: ../raster/r.contour/main.c:350
-msgid "Displacing data..."
-msgstr ""
-#: ../raster/r.out.mat/main.c:64
-msgid "Exports a GRASS raster to a binary MAT-File."
-msgstr "Eksportē GRASS rastru uz bināro MAT-Failu"
-#: ../raster/r.out.mat/main.c:73
-msgid "Name for output binary MAT file"
-msgstr ""
-#: ../raster/r.out.mat/main.c:113
+#: ../raster/r.walk/main.c:527 ../raster/r.walk/main.c:539
+#: ../raster/r.cost/main.c:414 ../raster/r.cost/main.c:425
 #, c-format
-msgid "Exporting <%s>"
+msgid "Will need at least %.2f MB of memory"
 msgstr ""
-#: ../raster/r.out.mat/main.c:173
-msgid "Using the Current Region settings:"
-msgstr ""
-#: ../raster/r.out.mat/main.c:248
-msgid "Exporting raster as integer values"
-msgstr ""
-#: ../raster/r.out.mat/main.c:253
-msgid "Exporting raster as floating point values"
-msgstr ""
-#: ../raster/r.out.mat/main.c:258
-msgid "Exporting raster as double FP values"
-msgstr ""
-#: ../raster/r.out.mat/main.c:301
-msgid "Reading in map ... "
-msgstr ""
-#: ../raster/r.out.mat/main.c:314
-msgid "Writing out map..."
-msgstr ""
-#: ../raster/r.out.mat/main.c:374
+#: ../raster/r.walk/main.c:529 ../raster/r.walk/main.c:540
+#: ../raster/r.cost/main.c:416 ../raster/r.cost/main.c:426
 #, c-format
-msgid "%ld bytes written to '%s'"
+msgid "%d of %d segments are kept in memory"
 msgstr ""
-#: ../raster/r.profile/main.c:56
-msgid "Outputs the raster map layer values lying on user-defined line(s)."
-msgstr "Izvada rastra kartes vērtības, kas atrodas uz lietotāja norādītās līnijas."
-#: ../raster/r.profile/main.c:69 ../display/d.profile/main.c:203
-msgid "Profile coordinate pairs"
+#: ../raster/r.walk/main.c:545 ../raster/r.cost/main.c:431
+msgid "Creating some temporary files..."
 msgstr ""
-#: ../raster/r.profile/main.c:75
-msgid "Name of input file containing coordinate pairs"
-msgstr ""
-#: ../raster/r.profile/main.c:77
-msgid "Use instead of the 'coordinates' option. \"-\" reads from stdin."
-msgstr ""
-#: ../raster/r.profile/main.c:85
-msgid "Resolution along profile (default = current region resolution)"
-msgstr ""
-#: ../raster/r.profile/main.c:98
-msgid "Output RRR:GGG:BBB color values for each profile point"
-msgstr ""
-#: ../raster/r.profile/main.c:103
-msgid "If units are not specified, current location units are used. Meters are used by default in geographic (latlon) locations."
-msgstr ""
-#: ../raster/r.profile/main.c:117
-msgid "Either use profile option or coordinate_file  option, but not both"
-msgstr ""
-#: ../raster/r.profile/main.c:144
+#: ../raster/r.walk/main.c:558
 #, c-format
-msgid "Illegal resolution %g [%s]"
+msgid "Reading raster maps <%s> and <%s>, initializing output..."
 msgstr ""
-#: ../raster/r.profile/main.c:151
-#, c-format
-msgid "Using resolution: %g [%s]"
+#: ../raster/r.walk/main.c:643 ../raster/r.cost/main.c:504
+msgid "Initializing directional output..."
 msgstr ""
-#: ../raster/r.profile/main.c:182
-msgid "Output columns:"
-msgstr ""
-#: ../raster/r.profile/main.c:185
+#: ../raster/r.walk/main.c:675 ../raster/r.drain/main.c:273
+#: ../raster/r.cost/main.c:535
 #, c-format
-msgid "Easting, Northing, Along track dist. [%s], Elevation"
+msgid "Reading vector map <%s> with start points..."
 msgstr ""
-#: ../raster/r.profile/main.c:187
+#: ../raster/r.walk/main.c:722
 #, c-format
-msgid "Along track dist. [%s], Elevation"
+msgid "No start points found in vector <%s>"
 msgstr ""
-#: ../raster/r.profile/main.c:189
-msgid " RGB color"
-msgstr "RGB krāsa"
-#: ../raster/r.profile/main.c:200
+#: ../raster/r.walk/main.c:734 ../raster/r.cost/main.c:598
 #, c-format
-msgid "Could not open <%s>"
+msgid "Reading vector map <%s> with stop points..."
 msgstr ""
-#: ../raster/r.profile/main.c:207
+#: ../raster/r.walk/main.c:788 ../raster/r.cost/main.c:652
 #, c-format
-msgid "Invalid coordinates %s %s"
+msgid "No stop points found in vector <%s>"
 msgstr ""
-#: ../raster/r.profile/main.c:278
+#: ../raster/r.walk/main.c:810 ../raster/r.cost/main.c:675
 #, c-format
-msgid "Approx. transect length: %f [%s]"
+msgid "Reading raster map <%s> with start points..."
 msgstr ""
-#: ../raster/r.profile/main.c:281
-msgid "Endpoint coordinates are outside of current region settings"
+#: ../raster/r.walk/main.c:859 ../raster/r.cost/main.c:726
+msgid "Specified starting location outside database window"
 msgstr ""
-#: ../raster/r.profile/input.c:30 ../raster/r.profile/input.c:47
-#: ../raster/r.profile/input.c:60
-msgid "One coordinate pair per line, please"
+#: ../raster/r.walk/main.c:879 ../raster/r.cost/main.c:748
+msgid "Finding cost path..."
 msgstr ""
-#: ../raster/r.in.gridatb/file_io.c:35
-msgid "Setting window header failed"
+#: ../raster/r.walk/main.c:1356 ../raster/r.cost/main.c:1011
+msgid "Error, ct == pres_cell"
 msgstr ""
-#: ../raster/r.in.gridatb/file_io.c:38
-msgid "Rows changed"
+#: ../raster/r.walk/main.c:1368
+#, c-format
+msgid "Writing output raster map <%s>... "
 msgstr ""
-#: ../raster/r.in.gridatb/file_io.c:41
-msgid "Cols changed"
-msgstr ""
-#: ../raster/r.in.gridatb/main.c:48
-msgid "Imports GRIDATB.FOR map file (TOPMODEL) into a GRASS raster map."
-msgstr ""
-#: ../raster/r.in.gridatb/main.c:51
-msgid "GRIDATB i/o map file"
-msgstr ""
-#: ../raster/r.in.gridatb/main.c:68
+#: ../raster/r.walk/main.c:1432 ../raster/r.cost/main.c:1131
 #, c-format
-msgid "File not found: %s"
+msgid "Writing output movement direction raster map <%s>..."
 msgstr ""
-#: ../raster/r.regression.line/main.c:48
-#: ../raster/r.regression.multi/main.c:130
-msgid "regression"
-msgstr ""
-#: ../raster/r.regression.line/main.c:50
-msgid "Calculates linear regression from two raster maps: y = a + b*x."
-msgstr ""
-#: ../raster/r.regression.line/main.c:55
-#: ../raster/r.regression.multi/main.c:137
-msgid "Map for x coefficient"
-msgstr ""
-#: ../raster/r.regression.line/main.c:59
-#: ../raster/r.regression.multi/main.c:141
-msgid "Map for y coefficient"
-msgstr ""
-#: ../raster/r.regression.line/main.c:65
-#: ../raster/r.regression.multi/main.c:157
-msgid "ASCII file for storing regression coefficients (output to screen if file not specified)."
-msgstr ""
-#: ../raster/r.quant/read_rules.c:50
-msgid "Old data range is empty"
-msgstr ""
-#: ../raster/r.quant/read_rules.c:56
+#: ../raster/r.walk/main.c:1477 ../raster/r.cost/main.c:1197
 #, c-format
-msgid "Old data range is %s to %s"
+msgid "Peak cost value: %g"
 msgstr ""
-#: ../raster/r.quant/read_rules.c:59
-msgid "Old integer data range is empty"
-msgstr ""
-#: ../raster/r.quant/read_rules.c:61
+#: ../raster/r.walk/main.c:1498 ../raster/r.cost/main.c:1219
 #, c-format
-msgid "Old integer data range is %d to %d"
-msgstr ""
+msgid "Illegal x coordinate <%s>"
+msgstr "Nederīga x koordināta <%s>"
-#: ../raster/r.quant/read_rules.c:83
+#: ../raster/r.walk/main.c:1500 ../raster/r.cost/main.c:1221
 #, c-format
-msgid "unable to open input file <%s>"
-msgstr ""
+msgid "Illegal y coordinate <%s>"
+msgstr "Nederīga y koordināta <%s>"
-#: ../raster/r.quant/read_rules.c:89
+#: ../raster/r.walk/main.c:1504 ../raster/r.cost/main.c:1225
 #, c-format
-msgid ""
-"\n"
-"Enter the rule or 'help' for the format description or 'end' to exit:\n"
+msgid "Warning, ignoring point outside window: %g, %g"
 msgstr ""
-#: ../raster/r.quant/read_rules.c:112
-msgid "quant rules do not cover the whole range map"
+#: ../raster/r.out.ppm/main.c:56
+msgid "Converts a GRASS raster map to a PPM image file."
 msgstr ""
-#: ../raster/r.quant/main.c:49
-msgid "quantization"
+#: ../raster/r.out.ppm/main.c:64
+msgid "Name for new PPM file (use '-' for stdout)"
 msgstr ""
-#: ../raster/r.quant/main.c:51
-msgid "Produces the quantization file for a floating-point map."
+#: ../raster/r.out.ppm/main.c:68
+msgid "Output greyscale instead of color"
 msgstr ""
-#: ../raster/r.quant/main.c:59
-msgid "Raster map(s) to be quantized"
+#: ../raster/r.out.ppm/main.c:72
+msgid "Suppress printing of PPM header"
 msgstr ""
-#: ../raster/r.quant/main.c:64
-msgid "Path to rules file (\"-\" to read from stdin)"
-msgstr ""
+#: ../raster/r.out.ppm/main.c:101 ../raster/r.out.ppm3/main.c:95
+#, c-format
+msgid "row = %d"
+msgid_plural "rows = %d"
+msgstr[0] ""
+msgstr[1] ""
+msgstr[2] ""
-#: ../raster/r.quant/main.c:70
-msgid "Base map to take quant rules from"
-msgstr ""
+#. GTC Raster columns
+#: ../raster/r.out.ppm/main.c:102 ../raster/r.out.ppm3/main.c:97
+#, c-format
+msgid "column = %d"
+msgid_plural "columns = %d"
+msgstr[0] ""
+msgstr[1] ""
+msgstr[2] ""
-#: ../raster/r.quant/main.c:75
-msgid "Floating point range: dmin,dmax"
+#: ../raster/r.out.ppm/main.c:124
+#, c-format
+msgid "Unable to open file <%s> for write"
 msgstr ""
-#: ../raster/r.quant/main.c:81
-msgid "Integer range: min,max"
-msgstr ""
+#: ../raster/r.out.ppm/main.c:154
+msgid "Converting..."
+msgstr "Konvertē..."
-#: ../raster/r.quant/main.c:86
-msgid "Truncate floating point data"
-msgstr ""
-#: ../raster/r.quant/main.c:90
-msgid "Round floating point data"
-msgstr ""
-#: ../raster/r.quant/main.c:111
+#: ../raster/r.out.ppm/main.c:234
 #, c-format
-msgid "-%c, -%c, %s=, %s= and %s= are mutually exclusive"
+msgid "File <%s> created"
 msgstr ""
-#: ../raster/r.quant/main.c:120
-#, c-format
-msgid "%s= and %s= must be used together"
+#: ../raster/r.out.vrml/main.c:49
+msgid "VRML"
 msgstr ""
-#: ../raster/r.quant/main.c:131
-#, c-format
-msgid "%s is integer map, it can't be quantized"
+#: ../raster/r.out.vrml/main.c:51
+msgid "Exports a raster map to the Virtual Reality Modeling Language (VRML)."
 msgstr ""
-#: ../raster/r.quant/main.c:139
-msgid "Truncating..."
+#: ../raster/r.out.vrml/main.c:58
+msgid "Name of input color map"
 msgstr ""
-#: ../raster/r.quant/main.c:144
-msgid "Rounding..."
+#: ../raster/r.out.vrml/main.c:65 ../misc/m.nviz.image/args.c:575
+msgid "Vertical exaggeration"
 msgstr ""
-#: ../raster/r.quant/main.c:152
-#, c-format
-msgid "%s is integer map, it can't be used as basemap"
+#: ../raster/r.out.vrml/main.c:69
+msgid "Name for output VRML file"
 msgstr ""
-#: ../raster/r.quant/main.c:156
+#: ../raster/r.out.vrml/main.c:88
 #, c-format
-msgid "unable to read quant rules for basemap <%s>"
+msgid "Range info for [%s] not available (run r.support)"
 msgstr ""
-#: ../raster/r.quant/main.c:163 ../raster/r.quant/main.c:166
+#: ../raster/r.out.vrml/main.c:97
 #, c-format
-msgid "invalid value for %s= <%s>"
+msgid "Range info for <%s> not available (run r.support)"
 msgstr ""
-#: ../raster/r.quant/main.c:168
+#: ../raster/r.out.vrml/main.c:129
 #, c-format
-msgid "Setting quant rules for input map(s) to (%f,%f) -> (%d,%d)"
+msgid "Opening %s for writing... "
 msgstr ""
-#: ../raster/r.quant/main.c:181
-msgid "No rules specified. Quant table(s) not changed."
+#: ../raster/r.out.vrml/put_grid.c:38
+msgid "Writing vertices..."
 msgstr ""
-#: ../raster/r.quant/main.c:189
-#, c-format
-msgid "New quant table created for %s"
+#: ../raster/r.out.vrml/put_grid.c:83
+msgid "Writing color file..."
 msgstr ""
-#: ../raster/r.timestamp/main.c:39
-msgid "Modifies a timestamp for a raster map."
+#: ../raster/r.out.pov/main.c:124
+msgid "Converts a raster map layer into a height-field file for POV-Ray."
 msgstr ""
-#: ../raster/r.timestamp/main.c:40
-msgid "Print/add/remove a timestamp for a raster map."
+#: ../raster/r.out.pov/main.c:131
+msgid "Name of output povray file (TGA height field file)"
 msgstr ""
-#: ../raster/r.timestamp/main.c:49 ../vector/v.timestamp/main.c:50
-msgid "Datetime, datetime1/datetime2, or 'none' to remove"
+#: ../raster/r.out.pov/main.c:138
+msgid "Height-field type (0=actual heights 1=normalized)"
 msgstr ""
-#: ../raster/r.timestamp/main.c:50 ../vector/v.timestamp/main.c:51
-msgid "Format: '15 jan 1994' (absolute) or '2 years' (relative)"
+#: ../raster/r.out.pov/main.c:144
+msgid "Elevation bias"
 msgstr ""
-#: ../raster/r.timestamp/main.c:65
+#: ../raster/r.out.pov/main.c:170
 #, c-format
-msgid "Raster map <%s> not found %s"
+msgid "Invalid output filename <%s>"
 msgstr ""
-#: ../raster/r.statistics/o_skew.c:91
-msgid "o_skew: No data in array"
+#: ../raster/r.out.pov/main.c:180
+#, c-format
+msgid "Raster map is too big! Exceeds %d columns or %d rows"
 msgstr ""
-#: ../raster/r.statistics/main.c:59
-msgid "Calculates category or object oriented statistics."
+#: ../raster/r.out.pov/main.c:201
+msgid "Negative elevation values in input"
 msgstr ""
-#: ../raster/r.statistics/read_stats.c:20
-msgid "Reading r.stats output"
-msgstr ""
+#: ../raster/r.sunmask/main.c:119 ../raster/r.sun/main.c:254
+msgid "shadow"
+msgstr "ēna"
-#: ../raster/r.statistics/o_sdev.c:94 ../raster/r.statistics/o_var.c:95
-msgid "o_var: No data in array"
+#: ../raster/r.sunmask/main.c:120
+msgid ""
+"Calculates cast shadow areas from sun position and elevation raster map."
 msgstr ""
-#: ../raster/r.statistics/o_adev.c:93
-msgid "o_adev: No data in array"
+#: ../raster/r.sunmask/main.c:121
+msgid ""
+"Either exact sun position (A) is specified, or date/time to calculate the "
+"sun position (B) by r.sunmask itself."
 msgstr ""
-#: ../raster/r.statistics/o_kurt.c:91
-msgid "o_kurto: No data in array"
+#: ../raster/r.sunmask/main.c:135
+msgid "Altitude of the sun in degrees above the horizon (A)"
 msgstr ""
-#: ../raster/r.proj/bordwalk.c:216
-msgid "Input raster map is outside current region"
+#: ../raster/r.sunmask/main.c:136 ../raster/r.sunmask/main.c:145
+#: ../raster/r.sunmask/main.c:213 ../raster/r.sunmask/main.c:223
+#: ../display/d.text/main.c:199 ../display/d.text/main.c:208
+#: ../display/d.text/main.c:217 ../display/d.text/main.c:254
+#: ../display/d.text/main.c:259
+msgid "Position"
 msgstr ""
-#: ../raster/r.proj/bordwalk.c:242
-msgid "Unable to reproject map center"
+#: ../raster/r.sunmask/main.c:144
+msgid "Azimuth of the sun in degrees from north (A)"
 msgstr ""
-#: ../raster/r.proj/main.c:149
-msgid "Re-projects a raster map from given location to the current location."
+#: ../raster/r.sunmask/main.c:151
+msgid "Year (B)"
 msgstr ""
-#: ../raster/r.proj/main.c:153
-msgid "Location containing input raster map"
+#: ../raster/r.sunmask/main.c:153 ../raster/r.sunmask/main.c:161
+#: ../raster/r.sunmask/main.c:169 ../raster/r.sunmask/main.c:177
+#: ../raster/r.sunmask/main.c:185 ../raster/r.sunmask/main.c:194
+#: ../raster/r.sunmask/main.c:203 ../raster/r.sunhours/main.c:103
+#: ../raster/r.sunhours/main.c:112 ../raster/r.sunhours/main.c:120
+#: ../raster/r.sunhours/main.c:129 ../raster/r.sunhours/main.c:138
+#: ../raster/r.sunhours/main.c:147 ../raster/r.sun/main.c:456
+#: ../raster/r.sun/main.c:465 ../raster/r.sun/main.c:482
+#: ../raster/r.sun/main.c:529 ../imagery/i.landsat.toar/main.c:206
+msgid "Time"
 msgstr ""
-#: ../raster/r.proj/main.c:154 ../raster/r.proj/main.c:159
-#: ../raster/r.proj/main.c:164 ../vector/v.net.flow/main.c:108
-#: ../vector/v.net.flow/main.c:114 ../vector/v.proj/main.c:79
-#: ../vector/v.proj/main.c:84 ../vector/v.proj/main.c:90
-msgid "Source"
+#: ../raster/r.sunmask/main.c:159
+msgid "Month (B)"
 msgstr ""
-#: ../raster/r.proj/main.c:157
-msgid "Mapset containing input raster map"
+#: ../raster/r.sunmask/main.c:167
+msgid "Day (B)"
 msgstr ""
-#: ../raster/r.proj/main.c:158 ../vector/v.proj/main.c:83
-msgid "Default: name of current mapset"
+#: ../raster/r.sunmask/main.c:175
+msgid "Hour (B)"
 msgstr ""
-#: ../raster/r.proj/main.c:162
-msgid "Name of input raster map to re-project"
+#: ../raster/r.sunmask/main.c:183
+msgid "Minutes (B)"
 msgstr ""
-#: ../raster/r.proj/main.c:167 ../vector/v.proj/main.c:93
-msgid "Path to GRASS database of input location"
+#: ../raster/r.sunmask/main.c:191
+msgid "Seconds (B)"
 msgstr ""
-#: ../raster/r.proj/main.c:171
-msgid "Name for output raster map (default: same as 'input')"
+#: ../raster/r.sunmask/main.c:201
+msgid "Timezone"
 msgstr ""
-#: ../raster/r.proj/main.c:172 ../raster/r.proj/main.c:183
-#: ../raster/r.proj/main.c:199 ../vector/v.proj/main.c:102
-#: ../vector/v.proj/main.c:107 ../vector/v.proj/main.c:119
-#: ../vector/v.proj/main.c:126
-msgid "Target"
+#: ../raster/r.sunmask/main.c:202
+msgid "East positive, offset from GMT, also use to adjust daylight savings"
 msgstr ""
-#: ../raster/r.proj/main.c:198
-msgid "Resolution of output raster map"
+#: ../raster/r.sunmask/main.c:211
+msgid "Easting coordinate (point of interest)"
 msgstr ""
-#: ../raster/r.proj/main.c:203
-msgid "List raster maps in input mapset and exit"
+#: ../raster/r.sunmask/main.c:212 ../raster/r.sunmask/main.c:222
+msgid "Default: map center"
 msgstr ""
-#: ../raster/r.proj/main.c:213
-msgid "Print input map's bounds in the current projection and exit"
+#: ../raster/r.sunmask/main.c:221
+msgid "Northing coordinate (point of interest)"
 msgstr ""
-#: ../raster/r.proj/main.c:219
-msgid "Print input map's bounds in the current projection and exit (shell style)"
+#: ../raster/r.sunmask/main.c:227
+msgid "Do not ignore zero elevation"
 msgstr ""
-#: ../raster/r.proj/main.c:245 ../display/d.mon/start.c:52
-#: ../vector/v.external/main.c:133 ../vector/v.proj/main.c:150
-#: ../imagery/i.gensigset/parse.c:57 ../imagery/i.gensig/parse.c:50
-#: ../imagery/i.cluster/main.c:179
-#, c-format
-msgid "option <%s>: <%s> exists. To overwrite, use the --overwrite flag"
+#: ../raster/r.sunmask/main.c:231
+msgid "Calculate sun position only and exit"
 msgstr ""
-#: ../raster/r.proj/main.c:252 ../vector/v.proj/main.c:165
-msgid "Input and output locations can not be the same"
-msgstr ""
+#: ../raster/r.sunmask/main.c:237
+msgid "Print the sun position output in shell script style"
+msgstr "Drukāt saules pozīcijas aprakstu komandrindas skripta stilā"
-#: ../raster/r.proj/main.c:254
-msgid "Input and output locations are the same"
-msgstr ""
-#: ../raster/r.proj/main.c:264
-msgid "Unable to get projection info of output raster map"
-msgstr ""
-#: ../raster/r.proj/main.c:267
-msgid "Unable to get projection units of output raster map"
-msgstr ""
-#: ../raster/r.proj/main.c:270
-msgid "Unable to get projection key values of output raster map"
-msgstr ""
-#: ../raster/r.proj/main.c:279
+#: ../raster/r.sunmask/main.c:251
 #, c-format
-msgid "Mapset <%s> in input location <%s> - %s"
+msgid "Using map center coordinates: %f %f"
 msgstr ""
-#: ../raster/r.proj/main.c:281 ../raster/r.in.gdal/main.c:968
-#: ../vector/v.rectify/target.c:41
-#: ../imagery/i.ortho.photo/i.ortho.rectify/target.c:32
-#: ../imagery/i.rectify/target.c:33
-msgid "permission denied"
+#: ../raster/r.sunmask/main.c:258
+msgid "Empty east coordinate specified"
 msgstr ""
-#: ../raster/r.proj/main.c:282 ../raster/r.in.gdal/main.c:969
-msgid "not found"
+#: ../raster/r.sunmask/main.c:260
+msgid "Empty north coordinate specified"
 msgstr ""
-#: ../raster/r.proj/main.c:288 ../vector/v.proj/main.c:189
-#, c-format
-msgid "Checking location <%s> mapset <%s>"
+#: ../raster/r.sunmask/main.c:279
+msgid "Either define sun position or location/date/time parameters"
 msgstr ""
-#: ../raster/r.proj/main.c:300 ../vector/v.edit/main.c:87
-#: ../vector/v.external/main.c:106 ../vector/v.in.ogr/main.c:353
-#: ../vector/v.select/main.c:89 ../vector/v.proj/main.c:206
-#: ../vector/v.net/args.c:152 ../vector/v.net/args.c:159
-#: ../vector/v.net/args.c:165 ../vector/v.net/args.c:169
-#: ../vector/v.net/args.c:179 ../vector/v.what.rast/main.c:121
-#: ../scripts/d.frame/d.frame.py:288
-#, c-format, python-format
-msgid "Required parameter <%s> not set"
+#: ../raster/r.sunmask/main.c:282
+msgid ""
+"Neither sun position nor east/north, date/time/timezone definition are "
+"complete"
 msgstr ""
-#: ../raster/r.proj/main.c:303
+#: ../raster/r.sunmask/main.c:286
 #, c-format
-msgid "Raster map <%s> in location <%s> in mapset <%s> not found"
+msgid "Calculating sun position... (using solpos (V. %s) from NREL)"
 msgstr ""
-#: ../raster/r.proj/main.c:311
-msgid "Unable to get projection info of input map"
+#: ../raster/r.sunmask/main.c:291
+msgid ""
+"Using user defined sun azimuth, altitude settings (ignoring eventual other "
+"values)"
 msgstr ""
-#: ../raster/r.proj/main.c:314
-msgid "Unable to get projection units of input map"
+#: ../raster/r.sunmask/main.c:399
+msgid "Please correct settings"
 msgstr ""
-#: ../raster/r.proj/main.c:317
-msgid "Unable to get projection key values of input map"
+#: ../raster/r.sunmask/main.c:413
+#, c-format
+msgid "Time (%02i:%02i:%02i) is before sunrise (%02d:%02d:%02d)"
 msgstr ""
-#: ../raster/r.proj/main.c:332
-msgid "Unable to work with unprojected data (xy location)"
-msgstr ""
-#: ../raster/r.proj/main.c:351
+#: ../raster/r.sunmask/main.c:417
 #, c-format
-msgid "Input map <%s@%s> in location <%s>:"
+msgid "Time (%02i:%02i:%02i) is before sunrise"
 msgstr ""
-#: ../raster/r.proj/main.c:443
-msgid "Input:"
-msgstr ""
+#: ../raster/r.sunmask/main.c:420 ../raster/r.sunmask/main.c:430
+msgid "Nothing to calculate. Please verify settings."
+msgstr "Nav nekā ko rēķināt. Lūdzu pārbaudi iestatījumus."
-#: ../raster/r.proj/main.c:444 ../raster/r.proj/main.c:455
+#: ../raster/r.sunmask/main.c:424
 #, c-format
-msgid "Cols: %d (%d)"
+msgid "Time (%02i:%02i:%02i) is after sunset (%02d:%02d:%02d)"
 msgstr ""
-#: ../raster/r.proj/main.c:445 ../raster/r.proj/main.c:456
+#: ../raster/r.sunmask/main.c:428
 #, c-format
-msgid "Rows: %d (%d)"
+msgid "Time (%02i:%02i:%02i) is after sunset"
 msgstr ""
-#: ../raster/r.proj/main.c:446 ../raster/r.proj/main.c:457
-#, c-format
-msgid "North: %f (%f)"
+#: ../raster/r.sunmask/main.c:439
+msgid "You already know the sun position"
 msgstr ""
-#: ../raster/r.proj/main.c:447 ../raster/r.proj/main.c:458
+#: ../raster/r.sunmask/main.c:456
 #, c-format
-msgid "South: %f (%f)"
+msgid "Unable to open range file for raster map <%s>"
 msgstr ""
-#: ../raster/r.proj/main.c:448 ../raster/r.proj/main.c:459
-#, c-format
-msgid "West: %f (%f)"
-msgstr ""
+#: ../raster/r.sunmask/main.c:472
+msgid "Calculating shadows from DEM..."
+msgstr "Rēķina ēnas no DEM..."
-#: ../raster/r.proj/main.c:449 ../raster/r.proj/main.c:460
-#, c-format
-msgid "East: %f (%f)"
+#: ../raster/r.sunmask/g_solposition.c:66
+msgid ""
+"Unable to calculate sun position in un-projected locations. Specify "
+"sunposition directly."
 msgstr ""
-#: ../raster/r.proj/main.c:450 ../raster/r.proj/main.c:461
+#: ../raster/r.sunmask/g_solposition.c:88
 #, c-format
-msgid "EW-res: %f"
+msgid ""
+"Specified point %f, %f outside of current region, is that intended? Anyway, "
+"it will be used."
 msgstr ""
-#: ../raster/r.proj/main.c:451 ../raster/r.proj/main.c:462
-#, c-format
-msgid "NS-res: %f"
+#: ../raster/r.sunmask/g_solposition.c:98 ../raster/r.latlong/main.c:101
+msgid "Unable to get projection info of current location"
 msgstr ""
-#: ../raster/r.proj/main.c:454
-msgid "Output:"
+#: ../raster/r.sunmask/g_solposition.c:101 ../raster/r.latlong/main.c:103
+msgid "Unable to get projection units of current location"
 msgstr ""
-#: ../raster/r.proj/main.c:491
-msgid "Projecting..."
+#: ../raster/r.sunmask/g_solposition.c:104 ../raster/r.latlong/main.c:105
+msgid "Unable to get projection key values of current location"
 msgstr ""
-#: ../raster/r.proj/readcell.c:67
-msgid "Allocating memory and reading input raster map..."
+#: ../raster/r.sunmask/g_solposition.c:127 ../raster/r.sunhours/main.c:296
+#: ../raster/r.sunhours/main.c:391 ../general/g.region/printwindow.c:285
+#: ../general/g.region/printwindow.c:293 ../general/g.region/printwindow.c:301
+#: ../general/g.region/printwindow.c:309 ../general/g.region/printwindow.c:319
+#: ../general/g.region/printwindow.c:503 ../general/g.region/printwindow.c:596
+#: ../general/g.region/printwindow.c:608 ../general/g.region/printwindow.c:625
+#: ../general/g.region/printwindow.c:643 ../general/g.region/printwindow.c:658
+msgid "Error in pj_do_proj (projection of input coordinate pair)"
 msgstr ""
-#: ../raster/r.proj/readcell.c:92
-#: ../imagery/i.ortho.photo/i.ortho.rectify/readcell.c:100
-#: ../imagery/i.rectify/readcell.c:90 ../imagery/i.rectify/readcell.c:129
-msgid "Error writing segment file"
+#: ../raster/r.sunmask/solpos00.c:950 ../raster/r.sunhours/solpos00.c:994
+#, c-format
+msgid "S_decode ==> Please fix the year: %d [1950-2050]"
 msgstr ""
-#: ../raster/r.proj/readcell.c:125
-#: ../imagery/i.ortho.photo/i.ortho.rectify/readcell.c:130
-#: ../imagery/i.rectify/readcell.c:117
-msgid "Internal error: cache miss on fully-cached map"
+#: ../raster/r.sunmask/solpos00.c:953 ../raster/r.sunhours/solpos00.c:997
+#, c-format
+msgid "S_decode ==> Please fix the month: %d"
 msgstr ""
-#: ../raster/r.proj/readcell.c:138
-#: ../imagery/i.ortho.photo/i.ortho.rectify/readcell.c:139
-#: ../imagery/i.rectify/readcell.c:126
-msgid "Error seeking on segment file"
+#: ../raster/r.sunmask/solpos00.c:955 ../raster/r.sunhours/solpos00.c:999
+#, c-format
+msgid "S_decode ==> Please fix the day-of-month: %d"
 msgstr ""
-#: ../raster/r.proj/readcell.c:141
-#: ../imagery/i.ortho.photo/i.ortho.rectify/readcell.c:142
-msgid "Error reading segment file"
+#: ../raster/r.sunmask/solpos00.c:958 ../raster/r.sunhours/solpos00.c:1002
+#, c-format
+msgid "S_decode ==> Please fix the day-of-year: %d"
 msgstr ""
-#: ../raster/r.kappa/prt_hdr.c:18
+#: ../raster/r.sunmask/solpos00.c:961 ../raster/r.sunhours/solpos00.c:1005
 #, c-format
-msgid "Cannot open file <%s> to write header"
+msgid "S_decode ==> Please fix the hour: %d"
 msgstr ""
-#: ../raster/r.kappa/main.c:70 ../vector/v.class/main.c:46
-#: ../imagery/i.segment/main.c:38 ../imagery/i.maxlik/main.c:62
-#: ../imagery/i.smap/main.c:39 ../imagery/i.gensigset/main.c:41
-#: ../imagery/i.gensig/main.c:40 ../imagery/i.cluster/main.c:76
-msgid "classification"
-msgstr ""
-#: ../raster/r.kappa/main.c:72
-msgid "Calculates error matrix and kappa parameter for accuracy assessment of classification result."
-msgstr ""
-#: ../raster/r.kappa/main.c:78
-msgid "Name of raster map containing classification result"
-msgstr ""
-#: ../raster/r.kappa/main.c:83
-msgid "Name of raster map containing reference classes"
-msgstr ""
-#: ../raster/r.kappa/main.c:88
-msgid "Name for output file containing error matrix and kappa"
-msgstr ""
-#: ../raster/r.kappa/main.c:89 ../raster/r.colors.out/raster3d_main.c:57
-#: ../raster/r.colors.out/raster_main.c:56 ../vector/v.colors.out/main.c:62
-msgid "If not given write to standard output"
-msgstr ""
-#: ../raster/r.kappa/main.c:96
-msgid "Title for error matrix and kappa"
-msgstr ""
-#: ../raster/r.kappa/main.c:102
-msgid "Wide report"
-msgstr ""
-#: ../raster/r.kappa/main.c:103
-msgid "132 columns (default: 80)"
-msgstr ""
-#: ../raster/r.kappa/main.c:108
-msgid "No header in the report"
-msgstr ""
-#: ../raster/r.kappa/prt_mat.c:39
+#: ../raster/r.sunmask/solpos00.c:963 ../raster/r.sunhours/solpos00.c:1007
 #, c-format
-msgid "Cannot open file <%s> to write cats and counts (error matrix)"
+msgid "S_decode ==> Please fix the minute: %d"
 msgstr ""
-#: ../raster/r.kappa/prt_label.c:17
+#: ../raster/r.sunmask/solpos00.c:965 ../raster/r.sunhours/solpos00.c:1009
 #, c-format
-msgid "Can't open file <%s> to write label"
+msgid "S_decode ==> Please fix the second: %d"
 msgstr ""
-#: ../raster/r.kappa/calc_kappa.c:32
+#: ../raster/r.sunmask/solpos00.c:967 ../raster/r.sunhours/solpos00.c:1011
 #, c-format
-msgid "Cannot open file <%s> to write kappa and relevant parameters"
+msgid "S_decode ==> Please fix the time zone: %f"
 msgstr ""
-#: ../raster/r.out.bin/main.c:139
+#: ../raster/r.sunmask/solpos00.c:970 ../raster/r.sunhours/solpos00.c:1014
 #, c-format
-msgid "Header File = %s"
+msgid "S_decode ==> Please fix the interval: %d"
 msgstr ""
-#: ../raster/r.out.bin/main.c:223
+#: ../raster/r.sunmask/solpos00.c:973 ../raster/r.sunhours/solpos00.c:1017
 #, c-format
-msgid "World File = %s"
+msgid "S_decode ==> Please fix the latitude: %f"
 msgstr ""
-#: ../raster/r.out.bin/main.c:281
-msgid "Exports a GRASS raster to a binary array."
-msgstr "Eksportēt GRASS rastru uz bināro masīvu."
-#: ../raster/r.out.bin/main.c:297
-msgid "Name for output binary map (use output=- for stdout)"
-msgstr ""
-#: ../raster/r.out.bin/main.c:323
-msgid "Generate integer output"
-msgstr ""
-#: ../raster/r.out.bin/main.c:327
-msgid "Generate floating-point output"
-msgstr ""
-#: ../raster/r.out.bin/main.c:331
-msgid "Export array with GMT compatible header"
-msgstr ""
-#: ../raster/r.out.bin/main.c:335
-msgid "Generate BIL world and header files"
-msgstr ""
-#: ../raster/r.out.bin/main.c:339
-msgid "Byte swap output"
-msgstr ""
-#: ../raster/r.out.bin/main.c:399
+#: ../raster/r.sunmask/solpos00.c:976 ../raster/r.sunhours/solpos00.c:1020
 #, c-format
-msgid "Floating-point output requires %s=4 or %s=8"
+msgid "S_decode ==> Please fix the longitude: %f"
 msgstr ""
-#: ../raster/r.out.bin/main.c:404
+#: ../raster/r.sunmask/solpos00.c:979 ../raster/r.sunhours/solpos00.c:1023
 #, c-format
-msgid "Integer output doesn't support %s=8 in this build"
+msgid "S_decode ==> Please fix the temperature: %f"
 msgstr ""
-#: ../raster/r.out.bin/main.c:419
-msgid "GMT grid doesn't support 64-bit integers"
-msgstr ""
-#: ../raster/r.out.bin/main.c:425
-msgid "Creating BIL support files..."
-msgstr ""
-#: ../raster/r.out.bin/main.c:442
+#: ../raster/r.sunmask/solpos00.c:982 ../raster/r.sunhours/solpos00.c:1026
 #, c-format
-msgid "Exporting raster as floating values (%s=%d)"
+msgid "S_decode ==> Please fix the pressure: %f"
 msgstr ""
-#: ../raster/r.out.bin/main.c:445
-msgid "Writing GMT float format ID=1"
-msgstr ""
-#: ../raster/r.out.bin/main.c:448
+#: ../raster/r.sunmask/solpos00.c:984 ../raster/r.sunhours/solpos00.c:1028
 #, c-format
-msgid "Exporting raster as integer values (%s=%d)"
+msgid "S_decode ==> Please fix the tilt: %f"
 msgstr ""
-#: ../raster/r.out.bin/main.c:451
-msgid "Writing GMT integer format ID=2"
-msgstr ""
-#: ../raster/r.out.bin/main.c:459
+#: ../raster/r.sunmask/solpos00.c:986 ../raster/r.sunhours/solpos00.c:1030
 #, c-format
-msgid "r=%d"
+msgid "S_decode ==> Please fix the aspect: %f"
 msgstr ""
-#: ../raster/r.out.bin/main.c:460
+#: ../raster/r.sunmask/solpos00.c:988 ../raster/r.sunhours/solpos00.c:1032
 #, c-format
-msgid "c=%d"
+msgid "S_decode ==> Please fix the shadowband width: %f"
 msgstr ""
-#: ../raster/r.rescale.eq/get_stats.c:19 ../raster/r.rescale/get_range.c:24
+#: ../raster/r.sunmask/solpos00.c:991 ../raster/r.sunhours/solpos00.c:1035
 #, c-format
-msgid "Reading %s ..."
-msgstr "Lasa %s ..."
-#: ../raster/r.rescale.eq/main.c:53 ../raster/r.rescale/main.c:49
-msgid "rescale"
+msgid "S_decode ==> Please fix the shadowband radius: %f"
 msgstr ""
-#: ../raster/r.rescale.eq/main.c:55
-msgid "Rescales histogram equalized the range of category values in a raster map layer."
-msgstr ""
-#: ../raster/r.rescale.eq/main.c:61 ../raster/r.rescale/main.c:56
-msgid "The name of the raster map to be rescaled"
-msgstr ""
-#: ../raster/r.rescale.eq/main.c:69 ../raster/r.rescale/main.c:64
-msgid "The input data range to be rescaled (default: full range of input map)"
-msgstr ""
-#: ../raster/r.rescale.eq/main.c:72 ../raster/r.rescale/main.c:67
-msgid "The resulting raster map name"
-msgstr ""
-#: ../raster/r.rescale.eq/main.c:79 ../raster/r.rescale/main.c:74
-msgid "The output data range"
-msgstr ""
-#: ../raster/r.rescale.eq/main.c:86 ../raster/r.rescale/main.c:81
-msgid "Title for new raster map"
-msgstr ""
-#: ../raster/r.rescale.eq/main.c:115
+#: ../raster/r.sunmask/solpos00.c:994 ../raster/r.sunhours/solpos00.c:1038
 #, c-format
-msgid "Rescale %s[%d,%d] to %s[%d,%d]"
+msgid "S_decode ==> Please fix the shadowband sky factor: %f"
 msgstr ""
-#: ../raster/r.ros/main.c:215
-msgid "rate of spread"
+#: ../raster/r.distance/parse.c:35
+msgid "Name of two input raster maps for computing inter-class distances"
 msgstr ""
-#: ../raster/r.ros/main.c:218
-msgid "Generates rate of spread raster maps."
+#: ../raster/r.distance/parse.c:45
+msgid "Sort output by distance"
 msgstr ""
-#: ../raster/r.ros/main.c:220
-msgid "Generates three, or four raster map layers showing the base (perpendicular) rate of spread (ROS), the maximum (forward) ROS, the direction of the maximum ROS, and optionally the maximum potential spotting distance for fire spread simulation."
+#: ../raster/r.distance/parse.c:46
+msgid "Default: sorted by categories"
 msgstr ""
-#: ../raster/r.ros/main.c:227
-msgid "Raster map containing fuel models"
+#: ../raster/r.distance/parse.c:50
+msgid "Sort by distance in ascending order"
 msgstr ""
-#: ../raster/r.ros/main.c:229
-msgid "Name of an existing raster map layer in the user's current mapset search path containing the standard fuel models defined by the USDA Forest Service. Valid values are 1-13; other numbers are recognized as barriers by r.ros."
+#: ../raster/r.distance/parse.c:51
+msgid "Sort by distance in descending order"
 msgstr ""
-#: ../raster/r.ros/main.c:238
-msgid "Raster map containing the 1-hour fuel moisture (%)"
+#: ../raster/r.distance/parse.c:55
+msgid "Include category labels in the output"
 msgstr ""
-#: ../raster/r.ros/main.c:248
-msgid "Raster map containing the 10-hour fuel moisture (%)"
+#: ../raster/r.distance/parse.c:60
+msgid "Report zero distance if rasters are overlapping"
 msgstr ""
-#: ../raster/r.ros/main.c:250
-msgid "Name of an existing raster map layer in the user's current mapset search path containing the 10-hour (.25-1\") fuel moisture (percentage content multiplied by 100)."
+#: ../raster/r.distance/parse.c:64
+msgid "Report null objects as *"
 msgstr ""
-#: ../raster/r.ros/main.c:258
-msgid "Raster map containing the 100-hour fuel moisture (%)"
+#: ../raster/r.distance/parse.c:74 ../raster/r.distance/parse.c:83
+#, c-format
+msgid "Raster map <%s> is not CELL"
 msgstr ""
-#: ../raster/r.ros/main.c:260
-msgid "Name of an existing raster map layer in the user's current mapset search path containing the 100-hour (1-3\") fuel moisture (percentage content multiplied by 100)."
+#: ../raster/r.distance/edges.c:47
+#, c-format
+msgid "Reading map %s ..."
 msgstr ""
-#: ../raster/r.ros/main.c:267
-msgid "Raster map containing live fuel moisture (%)"
+#: ../raster/r.distance/main.c:42
+msgid "Locates the closest points between objects in two raster maps."
 msgstr ""
-#: ../raster/r.ros/main.c:269
-msgid "Name of an existing raster map layer in the user's current mapset search path containing live (herbaceous) fuel moisture (percentage content multiplied by 100)."
+#: ../raster/r.distance/report.c:61
+#: ../scripts/i.colors.enhance/i.colors.enhance.py:153
+#: ../scripts/i.colors.enhance/i.colors.enhance.py:176
+#: ../scripts/i.colors.enhance/i.colors.enhance.py:186
+#: ../scripts/i.colors.enhance/i.colors.enhance.py:210
+msgid "Processing..."
 msgstr ""
-#: ../raster/r.ros/main.c:277
-msgid "Raster map containing midflame wind velocities (ft/min)"
+#: ../raster/r.distance/distance.c:102
+#, c-format
+msgid "Reading maps  <%s,%s> while finding 0 distance ..."
 msgstr ""
-#: ../raster/r.ros/main.c:287
-msgid "Name of raster map containing wind directions (degree)"
+#: ../raster/r.volume/main.c:77 ../raster3d/r3.stats/main.c:51
+msgid "volume"
 msgstr ""
-#: ../raster/r.ros/main.c:289
-msgid "Name of an existing raster map layer in the user's current mapset search path containing wind direction, clockwise from north (degree)."
+#: ../raster/r.volume/main.c:78 ../raster/r.clump/main.c:61
+msgid "clumps"
 msgstr ""
-#: ../raster/r.ros/main.c:297
-msgid "Name of raster map containing slope (degree)"
+#: ../raster/r.volume/main.c:80
+msgid "Calculates the volume of data \"clumps\"."
 msgstr ""
-#: ../raster/r.ros/main.c:299
-msgid "Name of an existing raster map layer in the user's current mapset search path containing topographic slope (degree)."
+#: ../raster/r.volume/main.c:81
+msgid ""
+"Optionally produces a GRASS vector points map containing the calculated "
+"centroids of these clumps."
 msgstr ""
-#: ../raster/r.ros/main.c:307
-msgid "Raster map containing aspect (degree, CCW from E)"
+#: ../raster/r.volume/main.c:86
+msgid ""
+"Name of input raster map representing data that will be summed within clumps"
 msgstr ""
-#: ../raster/r.ros/main.c:309
-msgid "Name of an existing raster map layer in the user's current mapset search path containing topographic aspect, counterclockwise from east (GRASS convention) in degrees."
+#: ../raster/r.volume/main.c:92
+msgid "Name of input clump raster map"
 msgstr ""
-#: ../raster/r.ros/main.c:317
-msgid "Raster map containing elevation (m, required for spotting)"
+#: ../raster/r.volume/main.c:93
+msgid ""
+"Preferably the output of r.clump. If no clump map is given than MASK is used."
 msgstr ""
-#: ../raster/r.ros/main.c:319
-msgid "Name of an existing raster map layer in the user's current mapset search path containing elevation (meters). Option is required from spotting distance computation (when spotting_distance option is provided)"
+#: ../raster/r.volume/main.c:99
+msgid "Name for output vector points map to contain clump centroids"
 msgstr ""
-#: ../raster/r.ros/main.c:328
-msgid "Output raster map containing base ROS (cm/min)"
+#: ../raster/r.volume/main.c:104 ../raster/r.report/parse.c:63
+msgid "Name for output file to hold the report"
 msgstr ""
-#: ../raster/r.ros/main.c:330
-msgid "Base (perpendicular) rate of spread (ROS)"
+#: ../raster/r.volume/main.c:106 ../raster/r.report/parse.c:65
+msgid "If no output file given report is printed to standard output"
 msgstr ""
-#: ../raster/r.ros/main.c:336
-msgid "Output raster map containing maximal ROS (cm/min)"
+#: ../raster/r.volume/main.c:110
+msgid "Generate unformatted report (items separated by colon)"
 msgstr ""
-#: ../raster/r.ros/main.c:338
-msgid "The maximum (forward) rate of spread (ROS)"
+#: ../raster/r.volume/main.c:143
+msgid ""
+"No MASK found. If no clump map is given than the MASK is required. You need "
+"to define a clump raster map or create a MASK by r.mask command."
 msgstr ""
-#: ../raster/r.ros/main.c:344
-msgid "Output raster map containing directions of maximal ROS (degree)"
+#: ../raster/r.volume/main.c:145
+msgid "No clump map given, using MASK"
 msgstr ""
-#: ../raster/r.ros/main.c:346
-msgid "The direction of the maximal (forward) rate of spread (ROS)"
+#: ../raster/r.volume/main.c:198
+#, c-format
+msgid "Invalid category value %d (max=%d): row=%d col=%d"
 msgstr ""
-#: ../raster/r.ros/main.c:352
-msgid "Output raster map containing maximal spotting distance (m)"
-msgstr ""
-#: ../raster/r.ros/main.c:354
-msgid "The maximal potential spotting distance (requires elevation raster map to be provided)."
-msgstr ""
-#: ../raster/r.ros/main.c:373
-msgid "No dead fuel moisture is given. At least one of the 1-h, 10-h, 100-h moisture layers is required."
-msgstr ""
-#: ../raster/r.ros/main.c:397
+#: ../raster/r.volume/main.c:231
 #, c-format
-msgid "A wind direction layer should be given if the wind velocity layer <%s> has been given"
+msgid "Creating vector point map <%s>..."
 msgstr ""
-#: ../raster/r.ros/main.c:402
+#: ../raster/r.volume/main.c:233
 #, c-format
-msgid "A wind velocity layer should be given if the wind direction layer <%s> has been given"
+msgid "From '%s' on raster map <%s> using clumps from <%s>"
 msgstr ""
-#: ../raster/r.ros/main.c:416
+#: ../raster/r.volume/main.c:266
 #, c-format
-msgid "An aspect layer should be given if the slope layer <%s> has been given"
+msgid ""
+"\n"
+"Volume report on data from <%s> using clumps on <%s> raster map"
 msgstr ""
-#: ../raster/r.ros/main.c:421
+#: ../raster/r.volume/main.c:270
 #, c-format
-msgid "A slope layer should be given if the aspect layer <%s> has been given"
+msgid "Category   Average   Data   # Cells        Centroid             Total\n"
 msgstr ""
-#: ../raster/r.ros/main.c:437
-msgid "An elevation layer should be given if considering spotting"
-msgstr ""
-#: ../raster/r.ros/main.c:873
+#: ../raster/r.volume/main.c:272
 #, c-format
-msgid "Raster maps <%s>, <%s> and <%s> created."
+msgid "Number     in clump  Total  in clump   Easting     Northing     Volume"
 msgstr ""
-#: ../raster/r.covar/main.c:54
-msgid "Outputs a covariance/correlation matrix for user-specified raster map layer(s)."
+#: ../raster/r.volume/main.c:319
+msgid "Total Volume"
 msgstr ""
-#: ../raster/r.covar/main.c:61
-msgid "Print correlation matrix"
-msgstr ""
-#: ../raster/r.covar/main.c:86
+#: ../raster/r.external/proj.c:41 ../raster/r.in.gdal/proj.c:41
 #, c-format
-msgid "%s: complete ... "
+msgid ""
+"Input contains an invalid SRS. WKT definition:\n"
+"%s"
 msgstr ""
-#: ../raster/r.covar/main.c:110 ../imagery/i.pca/main.c:197
-msgid "No non-null values"
+#: ../raster/r.external/proj.c:50 ../raster/r.in.gdal/proj.c:50
+msgid "No projection information available"
 msgstr ""
 #: ../raster/r.external/main.c:61
@@ -17308,97 +18193,72 @@
 msgid "Band to select (default is all bands)"
 msgstr ""
-#: ../raster/r.external/main.c:108 ../raster/r.in.gdal/main.c:195
-#: ../vector/v.in.ogr/main.c:303 ../vector/v.in.lidar/main.c:300
-msgid "Extend region extents based on new dataset"
+#: ../raster/r.external/main.c:90 ../raster/r.in.poly/main.c:50
+#: ../raster/r.support/main.c:66 ../raster/r.in.bin/main.c:298
+#: ../raster/r.in.ascii/main.c:92 ../raster/r.in.gdal/main.c:140
+#: ../locale/scriptstrings/r.import_to_translate.c:24
+msgid "Title for resultant raster map"
 msgstr ""
-#: ../raster/r.external/main.c:109 ../raster/r.in.gdal/main.c:197
-#: ../vector/v.in.ogr/main.c:305
-msgid "Also updates the default region if in the PERMANENT mapset"
+#: ../raster/r.external/main.c:91 ../raster/r.in.gdal/main.c:141
+#: ../raster/r.in.gdal/main.c:150 ../raster/r.in.gdal/main.c:159
+#: ../raster/r.in.gdal/main.c:165
+#: ../locale/scriptstrings/r.import_to_translate.c:25
+#: ../imagery/i.landsat.toar/main.c:94 ../imagery/i.landsat.toar/main.c:116
+#: ../imagery/i.landsat.toar/main.c:125 ../imagery/i.landsat.toar/main.c:134
+#: ../imagery/i.landsat.toar/main.c:142 ../imagery/i.landsat.toar/main.c:151
+msgid "Metadata"
 msgstr ""
-#: ../raster/r.external/main.c:113 ../raster/r.in.gdal/main.c:213
-#: ../raster/r.region/main.c:70
-msgid "Auto-adjustment for lat/lon"
-msgstr ""
-#: ../raster/r.external/main.c:114 ../raster/r.in.gdal/main.c:214
-#: ../raster/r.region/main.c:71
-msgid "Attempt to fix small precision errors in resolution and extents"
-msgstr ""
-#: ../raster/r.external/main.c:118
+#: ../raster/r.external/main.c:124
 msgid "Flip horizontally"
 msgstr ""
-#: ../raster/r.external/main.c:122
+#: ../raster/r.external/main.c:128
 msgid "Flip vertically"
 msgstr ""
-#: ../raster/r.external/main.c:127
+#: ../raster/r.external/main.c:133
 msgid "List available bands including band type in dataset and exit"
 msgstr ""
-#: ../raster/r.external/main.c:128
+#: ../raster/r.external/main.c:134
 msgid "Format: band number,type,projection check"
 msgstr ""
-#: ../raster/r.external/main.c:160
+#: ../raster/r.external/main.c:166
 #, c-format
 msgid "%s= or %s= must be given"
 msgstr ""
-#: ../raster/r.external/main.c:171 ../display/d.mon/start.c:86
+#: ../raster/r.external/main.c:177 ../display/d.mon/start.c:86
 msgid "Unable to get current working directory"
 msgstr ""
-#: ../raster/r.external/main.c:208
+#: ../raster/r.external/main.c:214
 msgid "Proceeding with import..."
 msgstr ""
-#: ../raster/r.external/main.c:212
+#: ../raster/r.external/main.c:218
 #, c-format
 msgid "Imagery group <%s> already exists and will be overwritten."
 msgstr ""
-#: ../raster/r.external/main.c:219
+#: ../raster/r.external/main.c:225
 #, c-format
 msgid "Reading band %d of %d..."
 msgstr ""
-#: ../raster/r.external/main.c:224 ../raster/r.in.gdal/main.c:628
+#: ../raster/r.external/main.c:230 ../raster/r.in.gdal/main.c:598
 #, c-format
 msgid "Selected band (%d) does not exist"
 msgstr ""
-#: ../raster/r.external/main.c:256
+#: ../raster/r.external/main.c:262
 #, c-format
 msgid "Imagery group <%s> created"
 msgstr ""
-#: ../raster/r.external/window.c:23
-msgid "Input raster map is rotated - cannot import. You may use 'gdalwarp' to transform the map to North-up."
-msgstr ""
-#: ../raster/r.external/window.c:26
-msgid "Applying horizontal flip"
-msgstr ""
-#: ../raster/r.external/window.c:30
-msgid "Applying vertical flip"
-msgstr ""
-#: ../raster/r.external/window.c:93 ../raster/r.in.gdal/main.c:911
-#: ../vector/v.in.ogr/main.c:1725
-msgid "Default region for this location updated"
-msgstr ""
-#: ../raster/r.external/window.c:96 ../raster/r.in.gdal/main.c:914
-#: ../vector/v.in.ogr/main.c:1728
-msgid "Region for the current mapset updated"
-msgstr ""
 #: ../raster/r.external/link.c:48
 msgid "Complex types not supported"
 msgstr ""
@@ -17458,2019 +18318,2089 @@
 msgid "Link to raster map <%s> created."
 msgstr ""
-#: ../raster/r.external/list.c:23 ../raster/r.in.gdal/main.c:300
-#: ../vector/v.external/list.c:94 ../vector/v.in.ogr/main.c:334
-#: ../vector/v.external.out/list.c:102
-msgid "Supported formats:"
+#: ../raster/r.external/window.c:23
+msgid ""
+"Input raster map is rotated - cannot import. You may use 'gdalwarp' to "
+"transform the map to North-up."
 msgstr ""
-#: ../raster/r.external/proj.c:18 ../raster/r.in.gdal/main.c:465
-msgid "Unable to convert input raster map projection information to GRASS format for checking"
+#: ../raster/r.external/window.c:26
+msgid "Applying horizontal flip"
 msgstr ""
-#: ../raster/r.external/proj.c:47 ../raster/r.in.gdal/main.c:498
-msgid "Location PROJ_INFO is:\n"
+#: ../raster/r.external/window.c:30
+msgid "Applying vertical flip"
 msgstr ""
-#: ../raster/r.external/proj.c:58 ../raster/r.in.gdal/main.c:509
-msgid "Dataset PROJ_INFO is:\n"
+#: ../raster/r.surf.area/main.c:79
+msgid "area estimation"
 msgstr ""
-#: ../raster/r.external/proj.c:111 ../raster/r.in.gdal/main.c:567
-msgid "Consider generating a new location from the input dataset using the 'location' parameter.\n"
+#: ../raster/r.surf.area/main.c:80
+msgid "Prints estimation of surface area for raster map."
 msgstr ""
-#: ../raster/r.out.vrml/main.c:49
-msgid "VRML"
+#: ../raster/r.surf.area/main.c:89
+msgid "Vertical scale"
+msgstr "Vertikālais mērogs"
+#: ../raster/r.surf.area/main.c:93
+msgid "Output units"
+msgstr "Izvades vienības"
+#: ../raster/r.surf.area/main.c:94
+msgid "Default: square map units"
 msgstr ""
-#: ../raster/r.out.vrml/main.c:51
-msgid "Exports a raster map to the Virtual Reality Modeling Language (VRML)."
+#: ../raster/r.surf.area/main.c:102
+#, c-format
+msgid "Output in '%s'"
 msgstr ""
-#: ../raster/r.out.vrml/main.c:58
-msgid "Name of input color map"
+#: ../raster/r.surf.area/main.c:106
+msgid "Output in 'square map units'"
 msgstr ""
-#: ../raster/r.out.vrml/main.c:69
-msgid "Name for output VRML file"
+#: ../raster/r.surf.area/main.c:153
+msgid "Null value area ignored in calculation:"
 msgstr ""
-#: ../raster/r.out.vrml/main.c:88
-#, c-format
-msgid "Range info for [%s] not available (run r.support)"
+#: ../raster/r.surf.area/main.c:155
+msgid "Plan area used in calculation:"
 msgstr ""
-#: ../raster/r.out.vrml/main.c:97
-#, c-format
-msgid "Range info for <%s> not available (run r.support)"
+#: ../raster/r.surf.area/main.c:158
+msgid "Surface area calculation(low, high, avg):"
 msgstr ""
-#: ../raster/r.out.vrml/main.c:129
-#, c-format
-msgid "Opening %s for writing... "
+#: ../raster/r.surf.area/main.c:163
+msgid "Current region plan area:"
 msgstr ""
-#: ../raster/r.out.vrml/put_grid.c:38
-msgid "Writing vertices..."
+#: ../raster/r.surf.area/main.c:165
+msgid "Estimated region Surface Area:"
 msgstr ""
-#: ../raster/r.out.vrml/put_grid.c:83
-msgid "Writing color file..."
+#: ../raster/r.compress/main.c:69
+#: ../locale/scriptstrings/t.vect.list_to_translate.c:3
+#: ../locale/scriptstrings/t.unregister_to_translate.c:3
+#: ../locale/scriptstrings/t.rename_to_translate.c:3
+#: ../locale/scriptstrings/t.rast3d.list_to_translate.c:3
+#: ../locale/scriptstrings/t.create_to_translate.c:3
+#: ../locale/scriptstrings/t.register_to_translate.c:3
+#: ../locale/scriptstrings/t.rast.list_to_translate.c:3
+#: ../locale/scriptstrings/t.remove_to_translate.c:3
+#: ../locale/scriptstrings/t.list_to_translate.c:3
+#: ../general/g.access/main.c:38 ../general/g.findetc/main.c:29
+#: ../general/g.findfile/main.c:39 ../general/g.list/main.c:66
+#: ../general/g.dirseps/main.c:35 ../general/g.filename/main.c:40
+#: ../general/g.remove/main.c:70 ../general/g.copy/main.c:42
+#: ../general/g.rename/main.c:46 ../imagery/i.target/main.c:46
+#: ../imagery/i.group/main.c:53
+msgid "map management"
 msgstr ""
-#: ../raster/r.what/main.c:102
-msgid "Queries raster maps on their category values and category labels."
+#: ../raster/r.compress/main.c:70
+msgid "compression"
 msgstr ""
-#: ../raster/r.what/main.c:106
-msgid "Name of existing raster map(s) to query"
+#: ../raster/r.compress/main.c:71
+msgid "Compresses and decompresses raster maps."
+msgstr "Arhivēt un atarhivēt rastra failus."
+#: ../raster/r.compress/main.c:74
+msgid "Name of existing raster map(s)"
+msgstr "Esksistējošu rastra failu nosaukumi"
+#: ../raster/r.compress/main.c:78
+msgid "Uncompress the map"
+msgstr "Atarhivēt kartes"
+#: ../raster/r.compress/main.c:82
+msgid "Print compression information and data type of input map(s)"
 msgstr ""
-#: ../raster/r.what/main.c:109 ../vector/v.what/main.c:77
-msgid "Coordinates for query"
-msgstr "Vaicājuma koordinātes"
+#: ../raster/r.compress/main.c:86
+msgid "Print compression information in shell script style"
+msgstr ""
-#: ../raster/r.what/main.c:110 ../raster/r.what/main.c:116
-#: ../vector/v.to.db/parse.c:106 ../vector/v.to.db/parse.c:114
-#: ../db/db.select/main.c:203 ../db/db.select/main.c:209
-#: ../db/db.select/main.c:213 ../db/db.select/main.c:251
-#: ../db/db.select/main.c:261
-msgid "Query"
+#: ../raster/r.compress/main.c:128 ../raster/r.compress/main.c:308
+#, c-format
+msgid "Raster map <%s> is not in the current mapset"
 msgstr ""
-#: ../raster/r.what/main.c:114
-msgid "Name of vector points map for query"
+#: ../raster/r.compress/main.c:134
+#, c-format
+msgid "<%s> is a reclass file of map <%s> in mapset <%s> - can't uncompress"
 msgstr ""
-#: ../raster/r.what/main.c:135
-msgid "Size of point cache"
+#: ../raster/r.compress/main.c:136
+#, c-format
+msgid "<%s> is a reclass file of map <%s> in mapset <%s> - can't compress"
 msgstr ""
-#: ../raster/r.what/main.c:137 ../raster/r.what/main.c:162
-#: ../display/d.legend/main.c:118 ../display/d.legend/main.c:128
-#: ../display/d.legend/main.c:136 ../display/d.legend/main.c:168
-#: ../display/d.legend/main.c:253 ../display/d.legend/main.c:258
-#: ../display/d.legend/main.c:268 ../display/d.legend/main.c:278
-#: ../display/d.legend/main.c:293
-msgid "Advanced"
+#: ../raster/r.compress/main.c:141
+#, c-format
+msgid "<%s> is a GDAL-linked map - can't (un)compress"
 msgstr ""
-#: ../raster/r.what/main.c:146
-msgid "Show the category labels of the grid cell(s)"
+#: ../raster/r.compress/main.c:215
+msgid "DONE: uncompressed file is %lu %s (%.2f%) smaller"
 msgstr ""
-#: ../raster/r.what/main.c:151
-msgid "Output color values as RRR:GGG:BBB"
+#: ../raster/r.compress/main.c:216
+msgid "DONE: compressed file is %lu %s (%.2f%) smaller"
 msgstr ""
-#: ../raster/r.what/main.c:156
-msgid "Output integer category values, not cell values"
+#: ../raster/r.compress/main.c:220
+msgid "DONE: uncompressed file is %lu %s (%.2f%) larger"
 msgstr ""
-#: ../raster/r.what/main.c:161
-msgid "Turn on cache reporting"
+#: ../raster/r.compress/main.c:221
+msgid "DONE: compressed file is %lu %s (%.2f%) larger"
 msgstr ""
-#: ../raster/r.what/main.c:201
-#, c-format
-msgid "Can only do up to %d raster maps (more than %d given)"
+#: ../raster/r.compress/main.c:224
+msgid "same size"
 msgstr ""
-#: ../raster/r.what/main.c:218
+#: ../raster/r.compress/main.c:240
 #, c-format
-msgid "Unable to read category file for <%s>"
+msgid "<%s> already uncompressed"
 msgstr ""
-#: ../raster/r.what/main.c:297
+#: ../raster/r.compress/main.c:243
 #, c-format
-msgid "Unable to read vector map <%s>"
+msgid "Uncompressing <%s>"
 msgstr ""
-#: ../raster/r.what/main.c:301
+#: ../raster/r.compress/main.c:251
 #, c-format
-msgid "Line %d is not point or centroid, skipped"
+msgid "Re-compressing <%s>"
 msgstr ""
-#: ../raster/r.what/main.c:385
+#: ../raster/r.compress/main.c:254
 #, c-format
-msgid "%s %s is outside your current region"
+msgid "Compressing <%s>"
 msgstr ""
-#: ../raster/r.out.gdal/export_band.c:52 ../raster/r.out.gdal/export_band.c:344
-msgid "Unable to allocate buffer for reading raster map"
+#: ../raster/r.compress/main.c:312
+#, c-format
+msgid "<%s> is a GDAL-linked map"
 msgstr ""
-#: ../raster/r.out.gdal/export_band.c:156
+#: ../raster/r.compress/main.c:316
 #, c-format
-msgid "Using GDAL data type <%s>"
+msgid "<%s> is a reclass file of map <%s> in mapset <%s>"
 msgstr ""
-#: ../raster/r.out.gdal/export_band.c:161
+#: ../raster/r.compress/main.c:336
 #, c-format
-msgid "Input raster map contains cells with NULL-value (no-data). The value %d will be used to represent no-data values in the input map. You can specify a nodata value with the %s option."
+msgid "<%s> is uncompressed (method %i: %s). Data type: %s"
 msgstr ""
-#: ../raster/r.out.gdal/export_band.c:166
+#: ../raster/r.compress/main.c:343
 #, c-format
-msgid "Input raster map contains cells with NULL-value (no-data). The value %g will be used to represent no-data values in the input map. You can specify a nodata value with the %s option."
+msgid "<%s> is compressed (method %i: %s). Data type: %s"
 msgstr ""
-#: ../raster/r.out.gdal/export_band.c:176
+#: ../raster/r.compress/main.c:351
 #, c-format
-msgid "The default nodata value is present in rasterband <%s> and would lead to data loss. Please specify a custom nodata value with the %s parameter."
+msgid "<%s> has a compressed NULL file"
 msgstr ""
-#: ../raster/r.out.gdal/export_band.c:183
+#: ../raster/r.compress/main.c:353
 #, c-format
-msgid "The user given nodata value %g is present in rasterband <%s> and would lead to data loss. Please specify a different nodata value with the %s parameter."
+msgid "<%s> has an uncompressed NULL file"
 msgstr ""
-#: ../raster/r.out.gdal/export_band.c:228
-msgid "Unable to get raster band"
+#: ../raster/r.stats.zonal/main.c:105
+msgid ""
+"Calculates category or object oriented statistics (accumulator-based "
+"statistics)."
 msgstr ""
-#: ../raster/r.out.gdal/export_band.c:381
-#: ../raster/r.out.gdal/export_band.c:410
-#: ../raster/r.out.gdal/export_band.c:439
-msgid "Unable to write GDAL raster file"
+#: ../raster/r.stats.zonal/main.c:115 ../raster/r.statistics/main.c:69
+msgid "Method of object-based statistic"
 msgstr ""
-#: ../raster/r.out.gdal/export_band.c:462
-#: ../raster/r.out.gdal/export_band.c:474
-#: ../raster/r.out.gdal/export_band.c:487
-#: ../raster/r.out.gdal/export_band.c:500
-#: ../raster/r.out.gdal/export_band.c:512
-#: ../raster/r.out.gdal/export_band.c:525
-#: ../raster/r.out.gdal/export_band.c:539 ../raster/r.out.gdal/main.c:673
-#: ../raster/r.out.gdal/main.c:685 ../raster/r.out.gdal/main.c:698
-#: ../raster/r.out.gdal/main.c:711 ../raster/r.out.gdal/main.c:723
-#: ../raster/r.out.gdal/main.c:736
-msgid "Selected GDAL datatype does not cover data range."
+#: ../raster/r.stats.zonal/main.c:138 ../raster/r.statistics/main.c:92
+msgid "Resultant raster map"
 msgstr ""
-#: ../raster/r.out.gdal/export_band.c:463
-#: ../raster/r.out.gdal/export_band.c:475
-#: ../raster/r.out.gdal/export_band.c:488
-#: ../raster/r.out.gdal/export_band.c:501 ../raster/r.out.gdal/main.c:674
-#: ../raster/r.out.gdal/main.c:686 ../raster/r.out.gdal/main.c:699
-#: ../raster/r.out.gdal/main.c:712
-#, c-format
-msgid "GDAL datatype: %s, range: %d - %d"
+#: ../raster/r.stats.zonal/main.c:144 ../raster/r.statistics/main.c:98
+msgid "Cover values extracted from the category labels of the cover map"
 msgstr ""
-#: ../raster/r.out.gdal/export_band.c:466
-#: ../raster/r.out.gdal/export_band.c:478
-#: ../raster/r.out.gdal/export_band.c:491
-#: ../raster/r.out.gdal/export_band.c:504
-#: ../raster/r.out.gdal/export_band.c:516
-#: ../raster/r.out.gdal/export_band.c:529
-#: ../raster/r.out.gdal/export_band.c:543
+#: ../raster/r.stats.zonal/main.c:178
 #, c-format
-msgid "Raster map <%s> range: %g - %g"
+msgid "Unable to read category file of cover map <%s>"
 msgstr ""
-#: ../raster/r.out.gdal/export_band.c:513 ../raster/r.out.gdal/main.c:724
-#, c-format
-msgid "GDAL datatype: %s, range: %u - %u"
+#: ../raster/r.stats.zonal/main.c:248
+msgid "First pass"
 msgstr ""
-#: ../raster/r.out.gdal/export_band.c:526
-#: ../raster/r.out.gdal/export_band.c:540 ../raster/r.out.gdal/main.c:737
-#, c-format
-msgid "GDAL datatype: %s, range: %g - %g"
+#: ../raster/r.stats.zonal/main.c:327
+msgid "Second pass"
 msgstr ""
-#: ../raster/r.out.gdal/main.c:50
-#, c-format
-msgid "Supported formats:\n"
+#: ../raster/r.stats.zonal/main.c:474
+msgid "Generating reclass map"
 msgstr ""
-#: ../raster/r.out.gdal/main.c:135
-msgid "Exports GRASS raster maps into GDAL supported formats."
+#: ../raster/r.stats.zonal/main.c:496
+msgid "Writing output map"
 msgstr ""
-#: ../raster/r.out.gdal/main.c:141
-msgid "List supported output formats"
+#: ../raster/r.in.poly/get_item.c:97
+#, c-format
+msgid "Illegal coordinate <%s, %s>, skipping."
 msgstr ""
-#: ../raster/r.out.gdal/main.c:147
-msgid "Do not write GDAL standard colortable"
+#: ../raster/r.in.poly/get_item.c:102
+#, c-format
+msgid "Illegal north coordinate <%s>, skipping."
 msgstr ""
-#: ../raster/r.out.gdal/main.c:148
-msgid "Only applicable to Byte or UInt16 data types"
+#: ../raster/r.in.poly/get_item.c:107
+#, c-format
+msgid "Illegal east coordinate <%s>, skipping."
 msgstr ""
-#: ../raster/r.out.gdal/main.c:149 ../raster/r.out.gdal/main.c:155
-#: ../raster/r.out.gdal/main.c:202 ../raster/r.out.gdal/main.c:213
-#: ../raster/r.out.gdal/main.c:224 ../raster/r.out.gdal/main.c:237
-#: ../vector/v.out.ogr/args.c:48 ../vector/v.out.ogr/args.c:59
-#: ../vector/v.out.ogr/args.c:69 ../vector/v.out.ogr/args.c:79
-#: ../vector/v.out.ogr/args.c:95 ../vector/v.out.ogr/args.c:108
-#: ../vector/v.out.ogr/args.c:115 ../vector/v.out.ogr/args.c:121
-#: ../vector/v.out.ogr/args.c:128 ../vector/v.out.postgis/args.c:38
-#: ../vector/v.out.postgis/args.c:48 ../vector/v.out.postgis/args.c:61
-#: ../vector/v.out.postgis/args.c:67 ../vector/v.out.postgis/args.c:73
-#: ../vector/v.out.postgis/args.c:79
-msgid "Creation"
+#: ../raster/r.in.poly/main.c:37
+msgid "Creates raster maps from ASCII polygon/line/point data files."
 msgstr ""
-#: ../raster/r.out.gdal/main.c:153
-msgid "Do not write non-standard metadata"
+#: ../raster/r.in.poly/main.c:41
+msgid "Name of input file; or \"-\" to read from stdin"
 msgstr ""
-#: ../raster/r.out.gdal/main.c:154
-msgid "Enhances compatibility with other GIS software"
+#: ../raster/r.in.poly/main.c:60
+msgid "Integer representing NULL value data cell"
 msgstr ""
-#: ../raster/r.out.gdal/main.c:159
-msgid "Write raster attribute table"
+#: ../raster/r.in.poly/main.c:66
+msgid "Number of rows to hold in memory"
 msgstr ""
-#: ../raster/r.out.gdal/main.c:160
-msgid "Some export formats may not be supported"
+#: ../raster/r.in.poly/main.c:74
+msgid "Minimum number of rows to hold in memory is 1"
 msgstr ""
-#: ../raster/r.out.gdal/main.c:164
-msgid "Force raster export despite any warnings of data loss"
+#: ../raster/r.in.poly/main.c:83
+msgid "Type doesn't exist"
 msgstr ""
-#: ../raster/r.out.gdal/main.c:165
-msgid "Overrides nodata safety check"
+#: ../raster/r.in.poly/poly2rast.c:56 ../raster/r.in.xyz/main.c:645
+#, c-format
+msgid "Pass #%d (of %d) ..."
 msgstr ""
-#: ../raster/r.out.gdal/main.c:168
-msgid "Name of raster map (or group) to export"
+#: ../raster/r.ros/main.c:213 ../raster/r.spreadpath/main.c:89
+#: ../raster/r.spread/main.c:106
+msgid "fire"
+msgstr "uguns"
+#: ../raster/r.ros/main.c:214 ../raster/r.spread/main.c:107
+msgid "spread"
 msgstr ""
-#: ../raster/r.out.gdal/main.c:171
-msgid "Name for output raster file"
+#: ../raster/r.ros/main.c:215
+msgid "rate of spread"
 msgstr ""
-#: ../raster/r.out.gdal/main.c:177
-msgid "Raster data format to write (case sensitive, see also -l flag)"
+#: ../raster/r.ros/main.c:216 ../raster/r.spread/main.c:108
+#: ../raster/r.lake/main.c:152
+msgid "hazard"
 msgstr ""
-#: ../raster/r.out.gdal/main.c:208
-msgid "Creation option(s) to pass to the output format driver"
+#: ../raster/r.ros/main.c:217 ../raster/r.topmodel/main.c:53
+#: ../raster/r.spread/main.c:109 ../raster/r.sim/r.sim.sediment/main.c:120
+#: ../raster/r.sim/r.sim.water/main.c:118
+msgid "model"
 msgstr ""
-#: ../raster/r.out.gdal/main.c:210
-msgid "In the form of \"NAME=VALUE\", separate multiple entries with a comma"
+#: ../raster/r.ros/main.c:218
+msgid "Generates rate of spread raster maps."
 msgstr ""
-#: ../raster/r.out.gdal/main.c:218
-msgid "Metadata key(s) and value(s) to include"
+#: ../raster/r.ros/main.c:220
+msgid ""
+"Generates three, or four raster map layers showing the base (perpendicular) "
+"rate of spread (ROS), the maximum (forward) ROS, the direction of the "
+"maximum ROS, and optionally the maximum potential spotting distance for fire "
+"spread simulation."
 msgstr ""
-#: ../raster/r.out.gdal/main.c:220
-msgid "In the form of \"META-TAG=VALUE\", separate multiple entries with a comma. Not supported by all output format drivers."
+#: ../raster/r.ros/main.c:227
+msgid "Raster map containing fuel models"
 msgstr ""
-#: ../raster/r.out.gdal/main.c:230
-msgid "Assign a specified nodata value to output bands"
+#: ../raster/r.ros/main.c:229
+msgid ""
+"Name of an existing raster map layer in the user's current mapset search "
+"path containing the standard fuel models defined by the USDA Forest Service. "
+"Valid values are 1-13; other numbers are recognized as barriers by r.ros."
 msgstr ""
-#: ../raster/r.out.gdal/main.c:232
-msgid "If given, the nodata value is always written to metadata even if there are no NULL cells in the input band (enhances output compatibility)."
+#: ../raster/r.ros/main.c:238
+msgid "Raster map containing the 1-hour fuel moisture (%)"
 msgstr ""
-#: ../raster/r.out.gdal/main.c:264
-#, c-format
-msgid "Raster map or group <%s> not found"
+#: ../raster/r.ros/main.c:240 ../raster/r.spread/main.c:205
+msgid ""
+"path containing the 1-hour (<.25\") fuel moisture (percentage content "
+"multiplied by 100)."
 msgstr ""
-#: ../raster/r.out.gdal/main.c:268
-#, c-format
-msgid "No raster maps in group <%s>"
+#: ../raster/r.ros/main.c:248
+msgid "Raster map containing the 10-hour fuel moisture (%)"
 msgstr ""
-#: ../raster/r.out.gdal/main.c:282
-#, c-format
-msgid "Unable to get <%s> driver"
+#: ../raster/r.ros/main.c:250
+msgid ""
+"path containing the 10-hour (.25-1\") fuel moisture (percentage content "
 msgstr ""
-#: ../raster/r.out.gdal/main.c:288
-#, c-format
-msgid "Driver <%s> does not support direct writing. Using MEM driver for intermediate dataset."
+#: ../raster/r.ros/main.c:258
+msgid "Raster map containing the 100-hour fuel moisture (%)"
 msgstr ""
-#: ../raster/r.out.gdal/main.c:293
-msgid "Unable to get in-memory raster driver"
+#: ../raster/r.ros/main.c:260
+msgid ""
+"path containing the 100-hour (1-3\") fuel moisture (percentage content "
 msgstr ""
-#: ../raster/r.out.gdal/main.c:297
-#, c-format
-msgid "Driver <%s> does not support creating rasters"
+#: ../raster/r.ros/main.c:267
+msgid "Raster map containing live fuel moisture (%)"
 msgstr ""
-#: ../raster/r.out.gdal/main.c:372
-#, c-format
-msgid "Could not read data range of raster <%s>"
+#: ../raster/r.ros/main.c:269
+msgid ""
+"path containing live (herbaceous) fuel moisture (percentage content "
 msgstr ""
-#: ../raster/r.out.gdal/main.c:429
-#, c-format
-msgid "Exporting to GDAL data type: %s"
+#: ../raster/r.ros/main.c:277
+msgid "Raster map containing midflame wind velocities (ft/min)"
 msgstr ""
-#: ../raster/r.out.gdal/main.c:444
-msgid "Raster export would result in complete data loss, aborting."
+#: ../raster/r.ros/main.c:279 ../raster/r.spread/main.c:193
+msgid ""
+"path containing wind velocities at half of the average flame height (feet/"
+"minute)."
 msgstr ""
-#: ../raster/r.out.gdal/main.c:455
-#, c-format
-msgid "Precision loss: Raster map <%s> of type %s to be exported as %s. This can be avoided by using %s."
+#: ../raster/r.ros/main.c:287
+msgid "Name of raster map containing wind directions (degree)"
 msgstr ""
-#: ../raster/r.out.gdal/main.c:466
-#, c-format
-msgid "Precision loss: The range of <%s> can not be accurately preserved with GDAL datatype Float32. This can be avoided by exporting to Int32 or Float64."
+#: ../raster/r.ros/main.c:289
+msgid ""
+"path containing wind direction, clockwise from north (degree)."
 msgstr ""
-#: ../raster/r.out.gdal/main.c:474
-#, c-format
-msgid "Precision loss: Float32 can not preserve the DCELL precision of raster <%s>. This can be avoided by using Float64"
+#: ../raster/r.ros/main.c:297
+msgid "Name of raster map containing slope (degree)"
 msgstr ""
-#: ../raster/r.out.gdal/main.c:483
-msgid "Forcing raster export"
+#: ../raster/r.ros/main.c:299
+msgid ""
+"path containing topographic slope (degree)."
 msgstr ""
-#: ../raster/r.out.gdal/main.c:485
-#, c-format
-msgid "Raster export aborted. To override data loss check, use the -%c flag"
+#: ../raster/r.ros/main.c:307
+msgid "Raster map containing aspect (degree, CCW from E)"
 msgstr ""
-#: ../raster/r.out.gdal/main.c:500 ../raster/r.out.gdal/main.c:529
-#: ../raster/r.out.gdal/main.c:533
-msgid "Raster export aborted."
+#: ../raster/r.ros/main.c:309
+msgid ""
+"path containing topographic aspect, counterclockwise from east (GRASS "
+"convention) in degrees."
 msgstr ""
-#: ../raster/r.out.gdal/main.c:510
-msgid "Checking GDAL data type and nodata value..."
+#: ../raster/r.ros/main.c:317
+msgid "Raster map containing elevation (m, required for spotting)"
 msgstr ""
-#: ../raster/r.out.gdal/main.c:513
-#, c-format
-msgid "Checking options for raster map <%s> (band %d)..."
+#: ../raster/r.ros/main.c:319
+msgid ""
+"path containing elevation (meters). Option is required from spotting "
+"distance computation (when spotting_distance option is provided)"
 msgstr ""
-#: ../raster/r.out.gdal/main.c:527
-msgid "Forcing raster export."
+#: ../raster/r.ros/main.c:328
+msgid "Output raster map containing base ROS (cm/min)"
 msgstr ""
-#: ../raster/r.out.gdal/main.c:558
-msgid "Unable to create dataset using memory raster driver"
+#: ../raster/r.ros/main.c:330
+msgid "Base (perpendicular) rate of spread (ROS)"
 msgstr ""
-#: ../raster/r.out.gdal/main.c:567
-#, c-format
-msgid "Unable to create <%s> dataset using <%s> driver"
+#: ../raster/r.ros/main.c:336
+msgid "Output raster map containing maximal ROS (cm/min)"
 msgstr ""
-#: ../raster/r.out.gdal/main.c:582
-msgid "Unable to set geo transform"
+#: ../raster/r.ros/main.c:338
+msgid "The maximum (forward) rate of spread (ROS)"
 msgstr ""
-#: ../raster/r.out.gdal/main.c:590
-msgid "Unable to set projection"
+#: ../raster/r.ros/main.c:344
+msgid "Output raster map containing directions of maximal ROS (degree)"
 msgstr ""
-#: ../raster/r.out.gdal/main.c:618
-#, c-format
-msgid "Exporting raster data to %s format..."
+#: ../raster/r.ros/main.c:346
+msgid "The direction of the maximal (forward) rate of spread (ROS)"
 msgstr ""
-#: ../raster/r.out.gdal/main.c:621
-#, c-format
-msgid "Exporting raster map <%s> (band %d)..."
+#: ../raster/r.ros/main.c:352
+msgid "Output raster map containing maximal spotting distance (m)"
 msgstr ""
-#: ../raster/r.out.gdal/main.c:634
-#, c-format
-msgid "Unable to export raster map <%s>"
+#: ../raster/r.ros/main.c:354
+msgid ""
+"The maximal potential spotting distance (requires elevation raster map to be "
+"provided)."
 msgstr ""
-#: ../raster/r.out.gdal/main.c:650
-#, c-format
-msgid "Unable to create raster map <%s> using driver <%s>"
+#: ../raster/r.ros/main.c:373
+msgid ""
+"No dead fuel moisture is given. At least one of the 1-h, 10-h, 100-h "
+"moisture layers is required."
 msgstr ""
-#: ../raster/r.out.gdal/main.c:677 ../raster/r.out.gdal/main.c:689
-#: ../raster/r.out.gdal/main.c:702 ../raster/r.out.gdal/main.c:715
-#: ../raster/r.out.gdal/main.c:727 ../raster/r.out.gdal/main.c:740
+#: ../raster/r.ros/main.c:397
 #, c-format
-msgid "Range to be exported: %g - %g"
+msgid ""
+"A wind direction layer should be given if the wind velocity layer <%s> has "
+"been given"
 msgstr ""
-#: ../raster/r.out.gdal/main.c:764 ../raster/r.out.gdal/main.c:777
-#: ../raster/r.out.gdal/main.c:791 ../raster/r.out.gdal/main.c:804
-#: ../raster/r.out.gdal/main.c:819
+#: ../raster/r.ros/main.c:402
 #, c-format
-msgid "Mismatch between metadata nodata value and actual nodata value in exported raster: specified nodata value %g gets converted to %d by selected GDAL datatype."
+msgid ""
+"A wind velocity layer should be given if the wind direction layer <%s> has "
+"been given"
 msgstr ""
-#: ../raster/r.out.gdal/main.c:767 ../raster/r.out.gdal/main.c:794
-#: ../raster/r.out.gdal/main.c:822
+#: ../raster/r.ros/main.c:416
 #, c-format
-msgid "GDAL datatype: %s, valid range: %d - %d"
+msgid "An aspect layer should be given if the slope layer <%s> has been given"
 msgstr ""
-#: ../raster/r.out.gdal/main.c:780 ../raster/r.out.gdal/main.c:807
+#: ../raster/r.ros/main.c:421
 #, c-format
-msgid "GDAL datatype: %s, valid range: %u - %u"
+msgid "A slope layer should be given if the aspect layer <%s> has been given"
 msgstr ""
-#: ../raster/r.out.gdal/main.c:833
-#, c-format
-msgid "Mismatch between metadata nodata value and actual nodata value in exported raster: specified nodata value %g gets converted to %g by selected GDAL datatype."
+#: ../raster/r.ros/main.c:437
+msgid "An elevation layer should be given if considering spotting"
 msgstr ""
-#: ../raster/r.out.gdal/main.c:836
+#: ../raster/r.ros/main.c:873
 #, c-format
-msgid "GDAL datatype: %s, valid range: %g - %g"
+msgid "Raster maps <%s>, <%s> and <%s> created."
 msgstr ""
-#: ../raster/r.out.gdal/attr.c:140 ../raster/r.out.gdal/attr.c:178
-msgid "Failed to set raster attribute table"
+#: ../raster/r.li/r.li.mps/mps.c:51
+msgid ""
+"Calculates mean patch size index on a raster map, using a 4 neighbour "
+"algorithm"
 msgstr ""
-#: ../raster/r.in.gdal/main.c:93
-msgid "Imports raster data into a GRASS raster map using GDAL library."
+#: ../raster/r.li/r.li.mps/mps.c:53 ../raster/r.li/r.li.renyi/renyi.c:48
+#: ../raster/r.li/r.li.simpson/simpson.c:47
+#: ../raster/r.li/r.li.shannon/shannon.c:47
+#: ../raster/r.li/r.li.patchnum/main.c:51 ../raster/r.li/r.li.padsd/padsd.c:54
+#: ../raster/r.li/r.li.pielou/pielou.c:47 ../raster/r.li/r.li.shape/main.c:50
+#: ../raster/r.li/r.li.richness/richness.c:44
+#: ../raster/r.li/r.li.patchdensity/main.c:52
+#: ../raster/r.li/r.li.edgedensity/edgedensity.c:49
+#: ../raster/r.li/r.li.dominance/dominance.c:47
+#: ../raster/r.li/r.li.mpa/mpa.c:45 ../raster/r.li/r.li.cwed/cwed.c:55
+#: ../raster/r.li/r.li.padcv/padcv.c:54
+#: ../raster/r.li/r.li.padrange/padrange.c:54
+msgid "landscape structure analysis"
 msgstr ""
-#: ../raster/r.in.gdal/main.c:99
-msgid "Name of raster file to be imported"
+#: ../raster/r.li/r.li.mps/mps.c:54 ../raster/r.li/r.li.patchnum/main.c:52
+#: ../raster/r.li/r.li.padsd/padsd.c:55 ../raster/r.li/r.li.shape/main.c:51
+#: ../raster/r.li/r.li.patchdensity/main.c:53
+#: ../raster/r.li/r.li.edgedensity/edgedensity.c:50
+#: ../raster/r.li/r.li.mpa/mpa.c:46 ../raster/r.li/r.li.cwed/cwed.c:56
+#: ../raster/r.li/r.li.padcv/padcv.c:55
+#: ../raster/r.li/r.li.padrange/padrange.c:55
+msgid "patch index"
 msgstr ""
-#: ../raster/r.in.gdal/main.c:108
-msgid "Band(s) to select (default is all bands)"
+#: ../raster/r.li/r.li.mps/mps.c:62 ../raster/r.li/r.li.renyi/renyi.c:57
+#: ../raster/r.li/r.li.simpson/simpson.c:56
+#: ../raster/r.li/r.li.shannon/shannon.c:56
+#: ../raster/r.li/r.li.patchnum/main.c:59 ../raster/r.li/r.li.padsd/padsd.c:62
+#: ../raster/r.li/r.li.pielou/pielou.c:56 ../raster/r.li/r.li.shape/main.c:59
+#: ../raster/r.li/r.li.richness/richness.c:53
+#: ../raster/r.li/r.li.patchdensity/main.c:61
+#: ../raster/r.li/r.li.edgedensity/edgedensity.c:58
+#: ../raster/r.li/r.li.dominance/dominance.c:56
+#: ../raster/r.li/r.li.mpa/mpa.c:53 ../raster/r.li/r.li.cwed/cwed.c:64
+#: ../raster/r.li/r.li.padcv/padcv.c:62
+#: ../raster/r.li/r.li.padrange/padrange.c:62
+msgid "Configuration file"
 msgstr ""
-#: ../raster/r.in.gdal/main.c:109 ../raster/r.in.gdal/main.c:220
-msgid "Bands"
+#: ../raster/r.li/r.li.renyi/renyi.c:46
+msgid "Calculates Renyi's diversity index on a raster map"
 msgstr ""
-#: ../raster/r.in.gdal/main.c:124
-msgid "Name of GCPs target location"
+#: ../raster/r.li/r.li.renyi/renyi.c:49
+#: ../raster/r.li/r.li.simpson/simpson.c:48
+#: ../raster/r.li/r.li.shannon/shannon.c:48
+#: ../raster/r.li/r.li.pielou/pielou.c:48
+#: ../raster/r.li/r.li.richness/richness.c:45
+#: ../raster/r.li/r.li.dominance/dominance.c:48
+msgid "diversity index"
 msgstr ""
-#: ../raster/r.in.gdal/main.c:126
-msgid "Name of location to create or to read projection from for GCPs transformation"
+#: ../raster/r.li/r.li.renyi/renyi.c:63
+msgid "Alpha value is the order of the generalized entropy"
 msgstr ""
-#: ../raster/r.in.gdal/main.c:128 ../raster/r.in.gdal/main.c:183
-#: ../raster/r.in.gdal/main.c:190 ../vector/v.info/print.c:505
-#: ../vector/v.info/print.c:510
-msgid "Projection"
+#: ../raster/r.li/r.li.simpson/simpson.c:45
+msgid "Calculates Simpson's diversity index on a raster map"
 msgstr ""
-#: ../raster/r.in.gdal/main.c:143
-msgid "Offset to be added to band numbers"
+#: ../raster/r.li/r.li.shannon/shannon.c:45
+msgid "Calculates Shannon's diversity index on a raster map"
 msgstr ""
-#: ../raster/r.in.gdal/main.c:144
-msgid "If 0, no offset is added and the first band is 1"
+#: ../raster/r.li/r.li.patchnum/main.c:49
+msgid ""
+"Calculates patch number index on a raster map, using a 4 neighbour algorithm."
 msgstr ""
-#: ../raster/r.in.gdal/main.c:152
-msgid "Zero-padding of band number by filling with leading zeros up to given number"
+#: ../raster/r.li/r.li.padsd/padsd.c:52
+msgid "Calculates standard deviation of patch area a raster map"
 msgstr ""
-#: ../raster/r.in.gdal/main.c:153
-msgid "If 0, length will be adjusted to 'offset' number without leading zeros"
+#: ../raster/r.li/r.li.pielou/pielou.c:45
+msgid "Calculates Pielou's diversity index on a raster map"
 msgstr ""
-#: ../raster/r.in.gdal/main.c:159
-msgid "Name of the output file that contains the imported map names"
+#: ../raster/r.li/r.li.shape/main.c:48
+msgid "Calculates shape index on a raster map"
 msgstr ""
-#: ../raster/r.in.gdal/main.c:166 ../vector/v.in.ogr/main.c:218
-#: ../vector/v.in.lidar/main.c:270
-msgid "Name for new location to create"
-msgstr "Janveidojamā novietojuma nosaukums"
+#: ../raster/r.li/r.li.richness/richness.c:42
+msgid "Calculates richness index on a raster map"
+msgstr ""
-#: ../raster/r.in.gdal/main.c:173
-msgid "File prefix for raster attribute tables"
+#: ../raster/r.li/r.li.patchdensity/main.c:50
+msgid ""
+"Calculates patch density index on a raster map, using a 4 neighbour algorithm"
 msgstr ""
-#: ../raster/r.in.gdal/main.c:174
-msgid "The band number and \".csv\" will be appended to the file prefix"
+#: ../raster/r.li/r.li.edgedensity/edgedensity.c:47
+msgid ""
+"Calculates edge density index on a raster map, using a 4 neighbour algorithm"
 msgstr ""
-#: ../raster/r.in.gdal/main.c:188 ../vector/v.in.ogr/main.c:291
-msgid "Perform projection check only and exit"
+#: ../raster/r.li/r.li.edgedensity/edgedensity.c:68
+msgid "The value of the patch type"
 msgstr ""
-#: ../raster/r.in.gdal/main.c:198 ../vector/v.db.select/main.c:101
-msgid "Region"
-msgstr "Reģions"
-#: ../raster/r.in.gdal/main.c:219
-msgid "Keep band numbers instead of using band color names"
+#: ../raster/r.li/r.li.edgedensity/edgedensity.c:69
+msgid ""
+"It can be integer, double or float; it will be changed in function of map "
+"type"
 msgstr ""
-#: ../raster/r.in.gdal/main.c:225
-msgid "Create the location specified by the \"location\" parameter and exit. Do not import the raster file."
+#: ../raster/r.li/r.li.edgedensity/edgedensity.c:74
+msgid "Exclude border edges"
 msgstr ""
-#: ../raster/r.in.gdal/main.c:230
-msgid "Print number of bands and exit"
+#: ../raster/r.li/r.li.dominance/dominance.c:45
+msgid "Calculates dominance's diversity index on a raster map"
 msgstr ""
-#: ../raster/r.in.gdal/main.c:259
-msgid "You have to specify a target location different from output location"
+#: ../raster/r.li/r.li.mpa/mpa.c:43
+msgid "Calculates mean pixel attribute index on a raster map"
 msgstr ""
-#: ../raster/r.in.gdal/main.c:263
-msgid "You need to specify valid location name."
+#: ../raster/r.li/r.li.cwed/cwed.c:53
+msgid "Calculates contrast weighted edge density index on a raster map"
 msgstr ""
-#: ../raster/r.in.gdal/main.c:267
-msgid "The '-l' flag only works in Lat/Lon locations"
+#: ../raster/r.li/r.li.cwed/cwed.c:70
+msgid "Name of file that contains the weight to calculate the index"
 msgstr ""
-#: ../raster/r.in.gdal/main.c:270
-msgid "The number of digits for band numbering must be equal or greater than 0"
+#: ../raster/r.li/r.li.cwed/cwed.c:306 ../raster/r.li/r.li.cwed/cwed.c:453
+#: ../raster/r.li/r.li.cwed/cwed.c:599
+msgid "Row cache is too small"
 msgstr ""
-#: ../raster/r.in.gdal/main.c:289
-#, c-format
-msgid "Using memory cache size: %.1f MiB"
+#: ../raster/r.li/r.li.padcv/padcv.c:52
+msgid "Calculates coefficient of variation of patch area on a raster map"
 msgstr ""
-#: ../raster/r.in.gdal/main.c:331
-#, c-format
-msgid "Unable to open datasource <%s>"
+#: ../raster/r.li/r.li.padrange/padrange.c:52
+msgid "Calculates range of patch area size on a raster map"
 msgstr ""
-#: ../raster/r.in.gdal/main.c:342
+#: ../raster/r.li/r.li.daemon/worker.c:135
 #, c-format
-msgid "Input seems to be NOAA/AVHRR data which needs to be georeferenced with thin plate spline transformation (%s or %s)."
+msgid "unable to open <%s> mask ... continuing without!"
 msgstr ""
-#: ../raster/r.in.gdal/main.c:381
-msgid "Input raster map is flipped or rotated - cannot import. You may use 'gdalwarp' to transform the map to North-up."
+#: ../raster/r.li/r.li.daemon/daemon.c:97
+msgid "Cannot create random access file"
 msgstr ""
-#: ../raster/r.in.gdal/main.c:424
-msgid "Map bounds have been constrained to geographic coordinates. You will almost certainly want to check map bounds and resolution with r.info and reset them with r.region before going any further."
+#: ../raster/r.li/r.li.daemon/daemon.c:105
+#: ../raster/r.li/r.li.daemon/daemon.c:111
+#: ../raster/r.li/r.li.daemon/daemon.c:117
+#, c-format
+msgid "Cannot create %s directory"
 msgstr ""
-#: ../raster/r.in.gdal/main.c:444 ../raster/r.in.gdal/main.c:838
-#: ../vector/v.in.ogr/main.c:575 ../vector/v.in.lidar/main.c:505
-msgid "Unable to convert input map projection to GRASS format; cannot create new location."
+#: ../raster/r.li/r.li.daemon/daemon.c:174 ../raster/r.surf.fractal/main.c:85
+#: ../raster/r.surf.random/main.c:66 ../raster/r.composite/main.c:262
+#: ../raster/r.circle/main.c:153
+#, c-format
+msgid "Raster map <%s> created."
 msgstr ""
-#: ../raster/r.in.gdal/main.c:450 ../raster/r.in.gdal/main.c:862
-#: ../vector/v.in.ogr/main.c:581 ../vector/v.in.lidar/main.c:511
+#: ../raster/r.li/r.li.daemon/daemon.c:201
 #, c-format
-msgid "Unable to create new location <%s>"
+msgid "Cannot find configuration file <%s>"
 msgstr ""
-#: ../raster/r.in.gdal/main.c:592
-#, fuzzy, c-format
-msgid "Importing %d raster bands..."
-msgstr "Eksistējošas rastra kartes nosaukums"
+#: ../raster/r.li/r.li.daemon/daemon.c:208
+#: ../raster/r.li/r.li.daemon/daemon.c:212
+msgid "Cannot read setup file"
+msgstr ""
-#: ../raster/r.in.gdal/main.c:653
-msgid "Unable to open the map names output text file"
+#: ../raster/r.li/r.li.daemon/daemon.c:216
+msgid "Unable to parse configuration file (sampling frame)"
 msgstr ""
-#: ../raster/r.in.gdal/main.c:684
-#, c-format
-msgid "Unable to get raster band number %d"
+#: ../raster/r.li/r.li.daemon/daemon.c:475
+msgid "Irregular MASKEDOVERLAY areas definition"
 msgstr ""
-#: ../raster/r.in.gdal/main.c:761
+#: ../raster/r.li/r.li.daemon/daemon.c:479
 #, c-format
-msgid "Copying %d GCPS in points file for <%s>"
+msgid "The configuration file can only be used with the <%s> raster map"
 msgstr ""
-#: ../raster/r.in.gdal/main.c:769
-msgid "GCPs have the following OpenGIS WKT Coordinate System:"
+#: ../raster/r.li/r.li.daemon/daemon.c:485
+msgid "Unable to parse configuration file (sample area)"
 msgstr ""
-#: ../raster/r.in.gdal/main.c:792
-msgid "Re-projecting GCPs table:"
+#: ../raster/r.li/r.li.daemon/daemon.c:520
+msgid "Too many units to place"
 msgstr ""
-#: ../raster/r.in.gdal/main.c:793
-#, c-format
-msgid "* Input projection for GCP table: %s"
+#: ../raster/r.li/r.li.daemon/daemon.c:589
+msgid "Too many stratified random sample for raster map"
 msgstr ""
-#: ../raster/r.in.gdal/main.c:795
-#, c-format
-msgid "* Output projection for GCP table: %s"
+#: ../raster/r.li/r.li.daemon/daemon.c:623
+msgid "Illegal areas disposition"
 msgstr ""
-#: ../raster/r.in.gdal/main.c:816
-#, c-format
-msgid "Error in pj_do_proj (can't re-projection GCP %i)"
+#: ../raster/r.li/r.li.daemon/daemon.c:695
+msgid "Cannot make lseek"
 msgstr ""
-#: ../raster/r.in.gdal/main.c:871
-#, c-format
-msgid "The target for the output group <%s> has been set to location <%s>, mapset <PERMANENT>."
+#: ../raster/r.surf.fractal/spec_syn.c:60
+msgid "Preliminary surface calculations..."
 msgstr ""
-#: ../raster/r.in.gdal/main.c:942
-msgid "Unable to translate projection key values of input GCPs"
+#: ../raster/r.surf.fractal/spec_syn.c:119
+#, c-format
+msgid "Calculating surface %d (of %d)..."
 msgstr ""
-#: ../raster/r.in.gdal/main.c:958
-msgid "Unable to get projection info of target location"
+#: ../raster/r.surf.fractal/main.c:40
+msgid "fractal"
 msgstr ""
-#: ../raster/r.in.gdal/main.c:960
-msgid "Unable to get projection units of target location"
+#: ../raster/r.surf.fractal/main.c:42
+msgid "Creates a fractal surface of a given fractal dimension."
 msgstr ""
-#: ../raster/r.in.gdal/main.c:962
-msgid "Unable to get projection key values of target location"
+#: ../raster/r.surf.fractal/main.c:48
+msgid "Fractal dimension of surface (2 < D < 3)"
 msgstr ""
-#: ../raster/r.in.gdal/main.c:966 ../vector/v.rectify/target.c:40
-#: ../imagery/i.ortho.photo/i.ortho.rectify/target.c:31
-#: ../imagery/i.rectify/target.c:32
-#, c-format
-msgid "Mapset <%s> in target location <%s> - "
+#: ../raster/r.surf.fractal/main.c:55
+msgid "Number of intermediate images to produce"
 msgstr ""
-#: ../raster/r.in.gdal/main.c:1001
+#: ../raster/r.surf.fractal/main.c:79
 #, c-format
-msgid "Importing raster map <%s>..."
+msgid "Fractal dimension of %.2lf must be between 2 and 3."
 msgstr ""
-#: ../raster/r.in.gdal/main.c:1396 ../raster/r.in.gdal/main.c:1453
-msgid "Inconsistent color rules in RAT"
+#: ../raster/r.surf.fractal/process.c:54
+msgid "Unable to allocate data buffer. Check current region with g.region."
 msgstr ""
-#: ../raster/r.in.gdal/main.c:1510
-#, c-format
-msgid "Setting grey color table for <%s> (8bit, full range)"
+#: ../raster/r.random.cells/init.c:77
+msgid "Distance must be >= 0.0"
 msgstr ""
-#: ../raster/r.in.gdal/main.c:1524
+#: ../raster/r.random.cells/init.c:96 ../raster/r.random.surface/main.c:128
 #, c-format
-msgid "Setting grey color table for <%s> (16bit, image range)"
+msgid "Generating raster map <%s>..."
 msgstr ""
-#: ../raster/r.in.gdal/main.c:1626
-#, c-format
-msgid "Unable to open file <%s>: %s."
+#: ../raster/r.random.cells/main.c:50
+msgid "autocorrelation"
 msgstr ""
-#: ../raster/r.colors/stats.c:39
-#, c-format
-msgid "(%i/%i) Reading raster map <%s>..."
-msgstr ""
+#: ../raster/r.random.cells/main.c:52
+msgid "Generates random cell values with spatial dependence."
+msgstr "Ģenerē gadījuma rastra šūnas ar telpiski atkarīgām vērtībām."
-#: ../raster/r.colors/stats.c:73
-msgid "Unable to use logarithmic scaling if range includes zero"
+#: ../raster/r.random.cells/main.c:62 ../raster/r.random.surface/main.c:77
+msgid "Maximum distance of spatial correlation (value >= 0.0)"
 msgstr ""
-#: ../raster/r.colors/stats.c:118
-msgid "Error opening 3d raster map"
+#: ../raster/r.random.cells/main.c:70
+msgid "Maximum number of cells to be created"
 msgstr ""
-#: ../raster/r.colors/stats.c:125
-#, c-format
-msgid "(%i/%i) Reading map <%s>..."
+#: ../raster/r.random.cells/main.c:77
+msgid "Random seed (SEED_MIN >= value >= SEED_MAX) (default [random])"
 msgstr ""
-#: ../raster/r.colors/rules.c:40
+#: ../raster/r.random.cells/indep.c:139 ../raster/r.drain/main.c:522
+#: ../raster/r.composite/main.c:191 ../raster/r.random.surface/save.c:98
+#: ../imagery/i.ifft/main.c:207
 #, c-format
-msgid "Enter rules, \"end\" when done, \"help\" if you need it.\n"
+msgid "Writing raster map <%s>..."
 msgstr ""
-#: ../raster/r.colors/rules.c:49
+#: ../raster/r.random.cells/random.c:50
 #, c-format
-msgid "fp: Data range is %s to %s\n"
+msgid "RAN1: j == %d shouldn't happen"
 msgstr ""
-#: ../raster/r.colors/rules.c:53
-#, c-format
-msgid "Data range is %ld to %ld\n"
+#: ../raster/r.to.vect/main.c:79
+msgid "vectorization"
 msgstr ""
-#: ../raster/r.colors/rules.c:64
-#, c-format
-msgid ""
-"Your color rules do not cover the whole range of data!\n"
-" (rules %f to %f but data %f to %f)"
+#: ../raster/r.to.vect/main.c:80
+msgid "Converts a raster map into a vector map."
 msgstr ""
-#: ../raster/r.colors/rules.c:105
-#, c-format
-msgid " val color\n"
+#: ../raster/r.to.vect/main.c:94
+#: ../locale/scriptstrings/t.rast.to.vect_to_translate.c:11
+msgid "Name of attribute column to store value"
 msgstr ""
-#: ../raster/r.colors/rules.c:106
-#, c-format
-msgid " n%% color\n"
+#: ../raster/r.to.vect/main.c:95
+#: ../locale/scriptstrings/t.rast.to.vect_to_translate.c:19
+msgid "Name must be SQL compliant"
 msgstr ""
-#: ../raster/r.colors/rules.c:107
-#, c-format
-msgid " nv color\n"
+#: ../raster/r.to.vect/main.c:100
+#: ../locale/scriptstrings/t.rast.to.vect_to_translate.c:15
+msgid "Smooth corners of area features"
 msgstr ""
-#: ../raster/r.colors/rules.c:108
-#, c-format
-msgid " default color\n"
-msgstr "noklusējuma krāsa\n"
-#: ../raster/r.colors/rules.c:109
-#, c-format
-msgid "color can be one of:\n"
-msgstr "krāsa var būt viena no:\n"
-#: ../raster/r.colors/rules.c:111
-#, c-format
-msgid "or an R:G:B triplet, e.g.: 0:127:255\n"
-msgstr "vai R:G:B triplets, piem. 0:126:255\n"
-#: ../raster/r.colors/rules.c:132
-#, c-format
-msgid "bad rule (%s); rule not added"
+#: ../raster/r.to.vect/main.c:105
+#: ../locale/scriptstrings/t.rast.to.vect_to_translate.c:20
+msgid "Use raster values as categories instead of unique sequence (CELL only)"
 msgstr ""
-#: ../raster/r.colors/rules.c:134
-#, c-format
-msgid "bad rule (%s): [%s]"
+#: ../raster/r.to.vect/main.c:110
+#: ../locale/scriptstrings/t.rast.to.vect_to_translate.c:16
+msgid "Write raster values as z coordinate"
 msgstr ""
-#: ../raster/r.colors/edit_colors.c:61
-msgid "Creates/modifies the color table associated with a 3D raster map."
+#: ../raster/r.to.vect/main.c:111
+#: ../locale/scriptstrings/t.rast.to.vect_to_translate.c:17
+msgid "Table is not created. Currently supported only for points."
 msgstr ""
-#: ../raster/r.colors/edit_colors.c:65
-msgid "Creates/modifies the color table associated with a raster map."
+#: ../raster/r.to.vect/main.c:118
+msgid "Recommended for massive point conversion"
 msgstr ""
-#: ../raster/r.colors/edit_colors.c:75 ../raster/r.colors/edit_colors.c:87
-msgid "Map"
+#: ../raster/r.to.vect/main.c:131
+msgid "z flag is supported only for points"
 msgstr ""
-#: ../raster/r.colors/edit_colors.c:81
-msgid "Input file with one map name per line"
+#: ../raster/r.to.vect/main.c:142
+msgid ""
+"Raster is not CELL, '-v' flag ignored, raster values will be written to the "
+"table."
 msgstr ""
-#: ../raster/r.colors/edit_colors.c:83
-msgid "Input map names can be defined in an input file in case a large amount of maps must be specified. This option is mutual exclusive to the map option."
+#: ../raster/r.to.vect/main.c:144
+msgid ""
+"Raster is not CELL, '-v' flag ignored, raster values will be z coordinate."
 msgstr ""
-#: ../raster/r.colors/edit_colors.c:110
-msgid "\"-\" to read rules from stdin"
+#: ../raster/r.to.vect/main.c:146
+msgid "Raster is not CELL, '-v' flag ignored, raster values will be lost."
 msgstr ""
-#: ../raster/r.colors/edit_colors.c:229 ../raster/r.colors/edit_colors.c:262
-#, c-format
-msgid "%s map <%s> not found"
+#: ../raster/r.to.vect/main.c:151
+msgid "Categories will be unique sequence, raster values will be lost."
 msgstr ""
-#: ../raster/r.colors/edit_colors.c:235
-#, c-format
-msgid "No %s map name found in input file <%s>"
+#: ../raster/r.to.vect/main.c:312
+msgid "Updating attributes..."
 msgstr ""
-#: ../raster/r.colors/edit_colors.c:278
+#: ../raster/r.to.vect/main.c:335
 #, c-format
-msgid "Unable to remove color table of %s map <%s>"
+msgid "Unable to insert into table: %s"
 msgstr ""
-#: ../raster/r.colors/edit_colors.c:280
-#, c-format
-msgid "Color table of %s map <%s> not found"
+#: ../raster/r.to.vect/lines.c:71
+msgid "Extracting lines..."
 msgstr ""
-#: ../raster/r.colors/edit_colors.c:302
+#: ../raster/r.to.vect/lines.c:504
 #, c-format
-msgid "Color table exists for %s map <%s>. Exiting."
+msgid "Crowded cell at (%f, %f): row %d, col %d, count %d"
 msgstr ""
-#: ../raster/r.colors/edit_colors.c:358
-#, c-format
-msgid "Color table 'random' is not supported for floating point %s map"
+#: ../raster/r.to.vect/lines.c:508
+msgid ""
+"Raster map is not thinned properly.\n"
+"Please run r.thin."
 msgstr ""
-#: ../raster/r.colors/edit_colors.c:362
-#, c-format
-msgid "Color table 'grey.eq' is not supported for floating point %s map"
+#: ../raster/r.to.vect/lines.c:582
+msgid "join_lines: p front pointer not NULL!"
 msgstr ""
-#: ../raster/r.colors/edit_colors.c:368
-#, c-format
-msgid "Color table 'grey.log' is not supported for floating point %s map"
+#: ../raster/r.to.vect/lines.c:588
+msgid "join_lines: q front pointer not NULL!"
 msgstr ""
-#: ../raster/r.colors/edit_colors.c:376 ../imagery/i.vi/main.c:545
-#, c-format
-msgid "Unknown color request '%s'"
+#: ../raster/r.to.vect/lines.c:606
+msgid "extend line:  p is NULL"
 msgstr ""
-#: ../raster/r.colors/edit_colors.c:386 ../vector/v.colors/make_colors.c:51
-#, c-format
-msgid "Unable to load rules file <%s>"
+#: ../raster/r.to.vect/lines.c:632
+msgid "extend_lines: p front pointer not NULL!"
 msgstr ""
-#: ../raster/r.colors/edit_colors.c:403 ../vector/v.colors/main.c:322
-#, c-format
-msgid "Unable to read color table for 3D raster map <%s>"
+#: ../raster/r.to.vect/lines.c:639
+msgid "extend_lines: q back pointer not NULL!"
 msgstr ""
-#: ../raster/r.colors/edit_colors.c:447
+#: ../raster/r.to.vect/areas_io.c:154
 #, c-format
-msgid "Color table for %s map <%s> set to '%s'"
+msgid ""
+"write_bnd:  line terminated unexpectedly\n"
+"previous (%d) point %p (%d,%d,%d) %p %p"
 msgstr ""
-#: ../raster/r.to.rast3/main.c:59 ../raster/r.to.rast3elev/main.c:136
-msgid "Could not close the map"
+#: ../raster/r.to.vect/areas_io.c:287
+msgid "Writing areas..."
 msgstr ""
-#: ../raster/r.to.rast3/main.c:79
-msgid "2D raster maps which represent the slices"
+#: ../raster/r.to.vect/areas.c:122
+msgid "Extracting areas..."
 msgstr ""
-#: ../raster/r.to.rast3/main.c:84 ../raster/r.to.rast3elev/main.c:175
-msgid "The maximum tile size in kilo bytes. Default is 32KB."
+#: ../raster/r.to.vect/points.c:36
+msgid "Extracting points..."
 msgstr ""
-#: ../raster/r.to.rast3/main.c:93
-msgid "Use 3D raster mask (if exists) with output map"
+#: ../raster/r.to.vect/lines_io.c:76
+msgid "write_line:  found half a loop!"
 msgstr ""
-#: ../raster/r.to.rast3/main.c:201
-msgid "Converts 2D raster map slices to one 3D raster volume map."
+#: ../raster/r.to.vect/lines_io.c:177
+#, c-format
+msgid ""
+"write_line: line terminated unexpectedly\n"
+"  previous (%d) point %p (%d,%d,%d) %p %p"
 msgstr ""
-#: ../raster/r.to.rast3/main.c:213
-msgid "No output map"
+#: ../raster/r.out.bin/main.c:53 ../raster/r.out.bin/main.c:62
+#: ../raster/r.out.bin/main.c:470 ../raster/r.mapcalc/map3.c:129
+#: ../raster/r.mapcalc/map3.c:143 ../raster/r.mapcalc/map3.c:157
+#: ../raster3d/r3.out.bin/main.c:113
+msgid "Error writing data"
 msgstr ""
-#: ../raster/r.to.rast3/main.c:230
-msgid "The 2D and 3D region settings are different. Using the 3D region settings to adjust the 2D region."
+#: ../raster/r.out.bin/main.c:139
+#, c-format
+msgid "Header File = %s"
 msgstr ""
-#: ../raster/r.to.rast3/main.c:262
+#: ../raster/r.out.bin/main.c:144 ../raster/r.out.bin/main.c:228
+#: ../raster/r.out.bin/main.c:414 ../raster3d/r3.out.bin/main.c:321
+#: ../display/d.mon/start.c:181 ../display/d.mon/start.c:224
 #, c-format
-msgid "Open raster map %s - one time for each depth (%d/%d)"
+msgid "Unable to create file <%s>"
 msgstr ""
-#: ../raster/r.to.rast3/main.c:275
-msgid "Input maps have to be from the same type. CELL, FCELL or DCELL!"
+#: ../raster/r.out.bin/main.c:223
+#, c-format
+msgid "World File = %s"
 msgstr ""
-#: ../raster/r.to.rast3/main.c:279 ../raster/r.to.rast3elev/main.c:457
-msgid "Creating 3D raster map"
-msgstr ""
+#: ../raster/r.out.bin/main.c:281
+msgid "Exports a GRASS raster to a binary array."
+msgstr "Eksportēt GRASS rastru uz bināro masīvu."
-#: ../raster/r.to.rast3/main.c:291 ../raster/r.to.rast3elev/main.c:443
-msgid "Error opening 3D raster map"
+#: ../raster/r.out.bin/main.c:290 ../raster/r.random/main.c:62
+#: ../imagery/i.zc/main.c:66
+msgid "Name of input raster map"
 msgstr ""
-#: ../raster/r.to.rast3/main.c:326 ../raster/r.to.rast3elev/main.c:501
-msgid "Error closing 3d raster map"
+#: ../raster/r.out.bin/main.c:297
+msgid "Name for output binary map (use output=- for stdout)"
 msgstr ""
-#: ../raster/r.mfilter/getrow.c:23
-msgid "Error reading temporary file"
+#: ../raster/r.out.bin/main.c:304 ../raster3d/r3.out.bin/main.c:221
+msgid "Value to write out for null"
 msgstr ""
-#: ../raster/r.mfilter/main.c:60
-msgid "Performs raster map matrix filter."
+#: ../raster/r.out.bin/main.c:311 ../raster/r.in.bin/main.c:305
+msgid "Number of bytes per cell"
 msgstr ""
-#: ../raster/r.mfilter/main.c:71
-msgid "Path to filter file"
+#: ../raster/r.out.bin/main.c:318 ../raster/r.in.bin/main.c:330
+#: ../raster3d/r3.out.bin/main.c:235
+msgid "Output byte order"
 msgstr ""
-#: ../raster/r.mfilter/main.c:79
-msgid "Number of times to repeat the filter"
+#: ../raster/r.out.bin/main.c:323
+msgid "Generate integer output"
 msgstr ""
-#: ../raster/r.mfilter/main.c:80 ../raster/r.mfilter/main.c:99
-#: ../imagery/i.pca/main.c:109 ../imagery/i.pca/main.c:120
-msgid "Filter"
-msgstr "Filtrs"
-#: ../raster/r.mfilter/main.c:86
-msgid "Output raster map title"
+#: ../raster/r.out.bin/main.c:327
+msgid "Generate floating-point output"
 msgstr ""
-#: ../raster/r.mfilter/main.c:98
-msgid "Apply filter only to null data values"
+#: ../raster/r.out.bin/main.c:331
+msgid "Export array with GMT compatible header"
 msgstr ""
-#: ../raster/r.mfilter/main.c:125
-msgid "Raster map too small for the size of the filter"
+#: ../raster/r.out.bin/main.c:335
+msgid "Generate BIL world and header files"
 msgstr ""
-#: ../raster/r.mfilter/getfilt.c:27
-#, c-format
-msgid "Cannot open filter file '%s'"
+#: ../raster/r.out.bin/main.c:339
+msgid "Byte swap output"
 msgstr ""
-#: ../raster/r.mfilter/getfilt.c:47
-msgid "Illegal filter matrix size specified"
+#: ../raster/r.out.bin/main.c:347 ../raster3d/r3.out.bin/main.c:256
+msgid "Invalid value for null (integers only)"
 msgstr ""
-#: ../raster/r.mfilter/getfilt.c:50
-msgid "Even filter matrix size specified"
+#: ../raster/r.out.bin/main.c:399
+#, c-format
+msgid "Floating-point output requires %s=4 or %s=8"
 msgstr ""
-#: ../raster/r.mfilter/getfilt.c:72
-msgid "Illegal filter matrix"
+#: ../raster/r.out.bin/main.c:404
+#, c-format
+msgid "Integer output doesn't support %s=8 in this build"
 msgstr ""
-#: ../raster/r.mfilter/getfilt.c:80 ../raster/r.mfilter/getfilt.c:107
-#: ../raster/r.mfilter/getfilt.c:124
-msgid "Filter file format error"
+#: ../raster/r.out.bin/main.c:419
+msgid "GMT grid doesn't support 64-bit integers"
 msgstr ""
-#: ../raster/r.mfilter/getfilt.c:83
-msgid "Duplicate filter divisor specified"
+#: ../raster/r.out.bin/main.c:425
+msgid "Creating BIL support files..."
 msgstr ""
-#: ../raster/r.mfilter/getfilt.c:101
-msgid "Illegal divisor matrix"
+#: ../raster/r.out.bin/main.c:442
+#, c-format
+msgid "Exporting raster as floating values (%s=%d)"
 msgstr ""
-#: ../raster/r.mfilter/getfilt.c:110
-msgid "Duplicate filter type specified"
+#: ../raster/r.out.bin/main.c:445
+msgid "Writing GMT float format ID=1"
 msgstr ""
-#: ../raster/r.mfilter/getfilt.c:117
-msgid "Illegal filter type specified"
-msgstr ""
-#: ../raster/r.mfilter/getfilt.c:127
-msgid "Duplicate filter start specified"
-msgstr ""
-#: ../raster/r.mfilter/getfilt.c:135
+#: ../raster/r.out.bin/main.c:448
 #, c-format
-msgid "Filter start %s ignored, using UL"
+msgid "Exporting raster as integer values (%s=%d)"
 msgstr ""
-#: ../raster/r.mfilter/getfilt.c:157
-msgid "Illegal filter file format"
+#: ../raster/r.out.bin/main.c:451
+msgid "Writing GMT integer format ID=2"
 msgstr ""
-#: ../raster/r.mfilter/perform.c:40 ../raster/r.mfilter/perform.c:51
-msgid "Unable to create temporary file"
+#: ../raster/r.out.bin/main.c:454 ../raster3d/r3.out.bin/main.c:323
+msgid "Using the current region settings..."
 msgstr ""
-#: ../raster/r.mfilter/perform.c:81
+#: ../raster/r.out.bin/main.c:455 ../raster3d/r3.out.bin/main.c:324
 #, c-format
-msgid "Writing raster map <%s>"
+msgid "north=%f"
 msgstr ""
-#: ../raster/r.in.ascii/main.c:74
-msgid "Converts a GRASS ASCII raster file to binary raster map."
+#: ../raster/r.out.bin/main.c:456 ../raster3d/r3.out.bin/main.c:325
+#, c-format
+msgid "south=%f"
 msgstr ""
-#: ../raster/r.in.ascii/main.c:85
-msgid "Default: CELL for integer values, DCELL for floating-point values"
+#: ../raster/r.out.bin/main.c:457 ../raster3d/r3.out.bin/main.c:326
+#, c-format
+msgid "east=%f"
 msgstr ""
-#: ../raster/r.in.ascii/main.c:97 ../raster/r.in.ascii/main.c:102
-msgid "Default: read from header"
+#: ../raster/r.out.bin/main.c:458 ../raster3d/r3.out.bin/main.c:327
+#, c-format
+msgid "west=%f"
 msgstr ""
-#: ../raster/r.in.ascii/main.c:99
-msgid "Multiplier for ASCII data"
+#: ../raster/r.out.bin/main.c:459
+#, c-format
+msgid "r=%d"
 msgstr ""
-#: ../raster/r.in.ascii/main.c:103
-msgid "String representing NULL value data cell"
+#: ../raster/r.out.bin/main.c:460
+#, c-format
+msgid "c=%d"
 msgstr ""
-#: ../raster/r.in.ascii/main.c:104
-msgid "NULL data"
+#: ../raster/r.timestamp/main.c:39
+msgid "Modifies a timestamp for a raster map."
 msgstr ""
-#: ../raster/r.in.ascii/main.c:109
-msgid "SURFER (Golden Software) ASCII file will be imported"
+#: ../raster/r.timestamp/main.c:40
+msgid "Print/add/remove a timestamp for a raster map."
 msgstr ""
-#: ../raster/r.in.ascii/main.c:128
+#: ../raster/r.timestamp/main.c:65
 #, c-format
-msgid "Wrong entry for multiplier: %s"
+msgid "Raster map <%s> not found %s"
 msgstr ""
-#: ../raster/r.in.ascii/main.c:160
-#, c-format
-msgid "Unable to read input from <%s>"
+#: ../raster/r.slope.aspect/main.c:153
+msgid "aspect"
 msgstr ""
-#: ../raster/r.in.ascii/main.c:180
-msgid "Can't get cell header"
+#: ../raster/r.slope.aspect/main.c:154
+msgid "slope"
 msgstr ""
-#: ../raster/r.in.ascii/main.c:202
-#, c-format
-msgid "Data conversion failed at row %d, col %d"
+#: ../raster/r.slope.aspect/main.c:155
+msgid "curvature"
 msgstr ""
-#: ../raster/r.in.ascii/gethead.c:35
-msgid "input file is not a Surfer ascii grid file"
+#: ../raster/r.slope.aspect/main.c:156
+msgid ""
+"Generates raster maps of slope, aspect, curvatures and partial derivatives "
+"from an elevation raster map."
 msgstr ""
-#: ../raster/r.in.ascii/gethead.c:41
-msgid "error reading the column and row dimension from the Surfer grid file"
+#: ../raster/r.slope.aspect/main.c:158
+msgid "Aspect is calculated counterclockwise from east."
 msgstr ""
-#: ../raster/r.in.ascii/gethead.c:47
-msgid "error reading the X range from the Surfer grid file"
+#: ../raster/r.slope.aspect/main.c:180
+msgid "Format for reporting the slope"
 msgstr ""
-#: ../raster/r.in.ascii/gethead.c:53
-msgid "error reading the Y range from the Surfer grid file"
+#: ../raster/r.slope.aspect/main.c:187
+msgid "Type of output aspect and slope maps"
 msgstr ""
-#: ../raster/r.in.ascii/gethead.c:59
-msgid "error reading the Z range from the Surfer grid file"
+#: ../raster/r.slope.aspect/main.c:209
+msgid ""
+"Name for output first order partial derivative dx (E-W slope) raster map"
 msgstr ""
-#: ../raster/r.in.ascii/gethead.c:105
-msgid "error getting file position"
+#: ../raster/r.slope.aspect/main.c:216
+msgid ""
+"Name for output first order partial derivative dy (N-S slope) raster map"
 msgstr ""
-#: ../raster/r.in.ascii/gethead.c:164
-msgid "illegal type field: using type int"
+#: ../raster/r.slope.aspect/main.c:223
+msgid "Name for output second order partial derivative dxx raster map"
 msgstr ""
-#: ../raster/r.in.ascii/gethead.c:169
-msgid "ignoring type filed in header, type is set on command line"
+#: ../raster/r.slope.aspect/main.c:230
+msgid "Name for output second order partial derivative dyy raster map"
 msgstr ""
-#: ../raster/r.in.ascii/gethead.c:176
-msgid "illegal multiplier field: using 1.0"
+#: ../raster/r.slope.aspect/main.c:237
+msgid "Name for output second order partial derivative dxy raster map"
 msgstr ""
-#: ../raster/r.in.ascii/gethead.c:181
-msgid "ignoring multiplier filed in header, multiplier is set on command line"
+#: ../raster/r.slope.aspect/main.c:243
+msgid "Multiplicative factor to convert elevation units to horizontal units"
 msgstr ""
-#: ../raster/r.in.ascii/gethead.c:189
-msgid "ignoring null filed in header, null string is set on command line"
+#: ../raster/r.slope.aspect/main.c:252
+msgid "Minimum slope value (in percent) for which aspect is computed"
 msgstr ""
-#: ../raster/r.in.ascii/gethead.c:218
-msgid "error in ascii data format"
+#: ../raster/r.slope.aspect/main.c:261
+msgid "Do not align the current region to the raster elevation map"
 msgstr ""
-#: ../raster/r.in.ascii/gethead.c:248
+#: ../raster/r.slope.aspect/main.c:336
 #, c-format
-msgid "Duplicate \"%s\" field in header"
+msgid ""
+"You must specify at least one of the parameters: <%s>, <%s>, <%s>, <%s>, <"
+"%s>, <%s>, <%s>, <%s> or <%s>"
 msgstr ""
-#: ../raster/r.in.ascii/gethead.c:253
+#: ../raster/r.slope.aspect/main.c:358
 #, c-format
-msgid "Illegal \"%s\" value in header: %s"
+msgid "Wrong raster type: %s"
 msgstr ""
-#: ../raster/r.in.ascii/gethead.c:261
-#, c-format
-msgid "\"%s\" field missing from header"
+#: ../raster/r.slope.aspect/main.c:387
+msgid ""
+"r.slope.aspect does not convert horizontal units to meters in this version, "
+"see manual page."
 msgstr ""
-#: ../raster/r.mapcalc/map3.c:181 ../raster/r.mapcalc/map.c:224
+#: ../raster/r.slope.aspect/main.c:968
 #, c-format
-msgid "Unable to read color file for raster map <%s@%s>"
+msgid "Elevation products for mapset <%s> in <%s>"
 msgstr ""
-#: ../raster/r.mapcalc/map3.c:194 ../raster/r.mapcalc/map.c:237
+#: ../raster/r.slope.aspect/main.c:987
 #, c-format
-msgid "Unable to create btree for raster map <%s@%s>"
+msgid "Min computed aspect %.4f, max computed aspect %.4f"
 msgstr ""
-#: ../raster/r.mapcalc/map3.c:239 ../raster/r.mapcalc/map3.c:423
-#: ../raster/r.mapcalc/map3.c:468 ../raster/r.mapcalc/map3.c:565
-#: ../raster/r.mapcalc/map.c:286 ../raster/r.mapcalc/map.c:493
-#: ../raster/r.mapcalc/map.c:534 ../raster/r.mapcalc/map.c:632
-#: ../raster/r.mapcalc/expression.c:357
+#: ../raster/r.slope.aspect/main.c:1051
 #, c-format
-msgid "Invalid map modifier: '%c'"
+msgid "Aspect raster map <%s> complete"
 msgstr ""
-#: ../raster/r.mapcalc/map3.c:353 ../raster/r.mapcalc/map.c:424
-#: ../raster/r.mapcalc/evaluate.c:94 ../raster/r.mapcalc/evaluate.c:234
+#: ../raster/r.slope.aspect/main.c:1108
 #, c-format
-msgid "Unknown type: %d"
+msgid "Min computed slope %.4f, max computed slope %.4f"
 msgstr ""
-#: ../raster/r.mapcalc/map3.c:372
+#: ../raster/r.slope.aspect/main.c:1161
 #, c-format
-msgid "Unable to close raster map <%s@%s>"
+msgid "Slope raster map <%s> complete"
 msgstr ""
-#: ../raster/r.mapcalc/map3.c:631
-msgid "Unable to close output raster map"
-msgstr ""
-#: ../raster/r.mapcalc/main.c:71
-msgid "Raster map calculator."
-msgstr ""
-#: ../raster/r.mapcalc/main.c:78
-msgid "Expression to evaluate"
-msgstr ""
-#: ../raster/r.mapcalc/main.c:79 ../raster/r.mapcalc/main.c:85
-msgid "Expression"
-msgstr "Izteiksme"
-#: ../raster/r.mapcalc/main.c:84
-msgid "File containing expression(s) to evaluate"
-msgstr ""
-#: ../raster/r.mapcalc/main.c:91
-msgid "Seed for rand() function"
-msgstr ""
-#: ../raster/r.mapcalc/main.c:95
-msgid "Generate random seed (result is non-deterministic)"
-msgstr ""
-#: ../raster/r.mapcalc/main.c:99
-msgid "List input and output maps"
-msgstr ""
-#: ../raster/r.mapcalc/main.c:121
+#: ../raster/r.slope.aspect/main.c:1233
 #, c-format
-msgid "%s= and -%c are mutually exclusive"
+msgid "Profile curve raster map <%s> complete"
 msgstr ""
-#: ../raster/r.mapcalc/main.c:132
-msgid "parse error"
-msgstr ""
-#: ../raster/r.mapcalc/main.c:159
-msgid "Floating point error(s) occurred in the calculation"
-msgstr ""
-#: ../raster/r.mapcalc/function.c:35
+#: ../raster/r.slope.aspect/main.c:1260
 #, c-format
-msgid "Known functions:"
+msgid "Tangential curve raster map <%s> complete"
 msgstr ""
-#: ../raster/r.mapcalc/evaluate.c:140
+#: ../raster/r.slope.aspect/main.c:1285
 #, c-format
-msgid "Invalid type: %d"
+msgid "E-W slope raster map <%s> complete"
 msgstr ""
-#: ../raster/r.mapcalc/evaluate.c:179
+#: ../raster/r.slope.aspect/main.c:1310
 #, c-format
-msgid "Too few arguments for function '%s'"
+msgid "N-S slope raster map <%s> complete"
 msgstr ""
-#: ../raster/r.mapcalc/evaluate.c:183
+#: ../raster/r.slope.aspect/main.c:1335
 #, c-format
-msgid "Too many arguments for function '%s'"
+msgid "Dxx raster map <%s> complete"
 msgstr ""
-#: ../raster/r.mapcalc/evaluate.c:187
+#: ../raster/r.slope.aspect/main.c:1360
 #, c-format
-msgid "Invalid argument type for function '%s'"
+msgid "Dyy raster map <%s> complete"
 msgstr ""
-#: ../raster/r.mapcalc/evaluate.c:191
+#: ../raster/r.slope.aspect/main.c:1385
 #, c-format
-msgid "Invalid return type for function '%s'"
+msgid "Dxy raster map <%s> complete"
 msgstr ""
-#: ../raster/r.mapcalc/evaluate.c:195
-#, c-format
-msgid "Unknown type for function '%s'"
+#: ../raster/r.out.ppm3/main.c:59
+msgid "Converts 3 GRASS raster layers (R,G,B) to a PPM image file."
 msgstr ""
-#: ../raster/r.mapcalc/evaluate.c:198
+#: ../raster/r.out.ppm3/main.c:64 ../raster/r.composite/main.c:90
+#: ../display/d.rgb/main.c:69
 #, c-format
-msgid "Number of arguments for function '%s'"
-msgstr ""
+msgid "Name of raster map to be used for <%s>"
+msgstr "Izmantojamās rastra kartes nosaukums priekš <%s>"
-#: ../raster/r.mapcalc/evaluate.c:202
-#, c-format
-msgid "Unknown error for function '%s'"
+#: ../raster/r.out.ppm3/main.c:84
+msgid "Name for new PPM file. (use '-' for stdout)"
 msgstr ""
-#: ../raster/r.mapcalc/evaluate.c:282
-#, c-format
-msgid "output map <%s> exists. To overwrite, use the --overwrite flag"
+#: ../raster/r.out.ppm3/main.c:88
+msgid "Add comments to describe the region"
 msgstr ""
-#: ../raster/r.mapcalc/expression.c:206
+#: ../raster/r.out.ppm3/main.c:115 ../raster/r.his/main.c:167
+#: ../raster/r.his/main.c:183 ../raster/r.his/main.c:201
+#: ../display/d.legend/main.c:409 ../display/d.legend/main.c:417
+#: ../display/d.his/main.c:139 ../display/d.his/main.c:156
+#: ../display/d.his/main.c:174 ../display/d.rgb/main.c:99
+#: ../display/d.colortable/main.c:135 ../display/d.rast.num/main.c:253
+#: ../display/d.histogram/main.c:171 ../display/d.rast/display.c:23
 #, c-format
-msgid "Undefined variable '%s'"
+msgid "Color file for <%s> not available"
 msgstr ""
-#: ../raster/r.mapcalc/expression.c:221
-#, c-format
-msgid "Invalid map <%s>"
+#: ../raster/r.out.ppm3/main.c:160
+msgid "Converting... "
 msgstr ""
-#: ../raster/r.mapcalc/expression.c:262
-#, c-format
-msgid "Undefined function '%s'"
+#: ../raster/r.support.stats/main.c:37
+msgid "Update raster map statistics"
 msgstr ""
-#: ../raster/r.mapcalc/expression.c:267
+#: ../raster/r.support.stats/main.c:49
 #, c-format
-msgid "Too few arguments (%d) to function %s()"
+msgid "Statistics for <%s> updated"
 msgstr ""
-#: ../raster/r.mapcalc/expression.c:271
+#: ../raster/r.support.stats/check.c:43
 #, c-format
-msgid "Too many arguments (%d) to function %s()"
+msgid "Updating statistics for [%s]..."
 msgstr ""
-#: ../raster/r.mapcalc/expression.c:275
-#, c-format
-msgid "Incorrect argument types to function %s()"
+#: ../raster/r.support.stats/check.c:56
+msgid "Updating histogram range..."
 msgstr ""
-#: ../raster/r.mapcalc/expression.c:278
+#: ../raster/r.support.stats/check.c:88
 #, c-format
-msgid "Internal error for function %s()"
+msgid "Updating the number of categories for [%s]..."
 msgstr ""
-#: ../raster/r.mapcalc/expression.c:453
-#, c-format
-msgid "Illegal number of arguments (%d) for operator '%s'"
+#: ../raster/r.out.ascii/main.c:63
+msgid "Converts a raster map layer into a GRASS ASCII text file."
 msgstr ""
-#: ../raster/r.mapcalc/expression.c:493
-#, c-format
-msgid "Format_expression_prec: unknown type: %d"
+#: ../raster/r.out.ascii/main.c:72
+msgid "Name for output ASCII grid map (use out=- for stdout)"
 msgstr ""
-#: ../raster/r.basins.fill/read_map.c:39
-#, c-format
-msgid "Reading <%s> ... "
+#: ../raster/r.out.ascii/main.c:86
+msgid ""
+"Number of values printed before wrapping a line (only SURFER or MODFLOW "
+"format)"
 msgstr ""
-#: ../raster/r.basins.fill/main.c:56 ../raster/r.water.outlet/main.c:59
-#: ../raster/r.watershed/front/main.c:75
-msgid "watershed"
+#: ../raster/r.out.ascii/main.c:91
+msgid "String to represent null cell (GRASS grid only)"
 msgstr ""
-#: ../raster/r.basins.fill/main.c:58
-msgid "Generates watershed subbasins raster map."
+#: ../raster/r.out.ascii/main.c:95 ../raster3d/r3.out.ascii/main.c:102
+msgid "Suppress printing of header information"
 msgstr ""
-#: ../raster/r.basins.fill/main.c:62
-msgid "Name of input coded stream network raster map"
+#: ../raster/r.out.ascii/main.c:99
+msgid "Write SURFER (Golden Software) ASCII grid"
 msgstr ""
-#: ../raster/r.basins.fill/main.c:66
-msgid "Name of input thinned ridge network raster map"
+#: ../raster/r.out.ascii/main.c:103
+msgid "Write MODFLOW (USGS) ASCII array"
 msgstr ""
-#: ../raster/r.basins.fill/main.c:74
-msgid "Number of passes through the dataset"
+#: ../raster/r.out.ascii/main.c:107
+msgid "Force output of integer values"
 msgstr ""
-#: ../raster/r.basins.fill/main.c:122
-msgid "Forward sweep complete"
+#: ../raster/r.out.ascii/main.c:114
+msgid "Failed to interpret dp as an integer"
 msgstr ""
-#: ../raster/r.basins.fill/main.c:139
-msgid "Reverse sweep complete"
+#: ../raster/r.out.ascii/main.c:116 ../raster3d/r3.out.vtk/main.c:394
+msgid "dp has to be from 0 to 20"
 msgstr ""
-#: ../raster/r.in.lidar/main.c:116
-msgid "Creates a raster map from LAS LiDAR points using univariate statistics."
+#: ../raster/r.out.ascii/main.c:122
+msgid "Failed to interpret width as an integer"
 msgstr ""
-#: ../raster/r.in.lidar/main.c:168
-msgid "pth (nth) percentile of point values in cell"
+#: ../raster/r.out.ascii/main.c:128
+msgid "Both -s and -h doesn't make sense"
 msgstr ""
-#: ../raster/r.in.lidar/main.c:180
-msgid "Subtract raster values from the Z coordinates"
+#: ../raster/r.out.ascii/main.c:131
+msgid "Use -M or -s, not both"
 msgstr ""
-#: ../raster/r.in.lidar/main.c:182
-msgid "The scale for Z is applied beforehand, the range filter for Z afterwards"
+#: ../raster/r.out.ascii/main.c:166
+#, c-format
+msgid "Unable to read fp range for <%s>"
 msgstr ""
-#: ../raster/r.in.lidar/main.c:191
-msgid "Filter range for Z data (min,max)"
+#: ../raster/r.out.ascii/main.c:182
+#, c-format
+msgid "Read failed at row %d"
 msgstr ""
-#: ../raster/r.in.lidar/main.c:241
-msgid "Discard given percentage of the smallest and largest values"
+#: ../raster/r.external.out/main.c:38
+#, c-format
+msgid "Supported Formats:\n"
 msgstr ""
-#: ../raster/r.in.lidar/main.c:251
-msgid "Output raster resolution"
+#: ../raster/r.external.out/main.c:132
+msgid "Unable to open GDAL file"
 msgstr ""
-#: ../raster/r.in.lidar/main.c:281
-msgid "Use the extent of the input for the raster extent"
+#: ../raster/r.external.out/main.c:162
+#, c-format
+msgid "Format <%s> does not support direct write"
 msgstr ""
-#: ../raster/r.in.lidar/main.c:283
-msgid "Set internally computational region extents based on the point cloud"
+#: ../raster/r.external.out/main.c:214
+msgid "Unable to create GDAL file"
 msgstr ""
-#: ../raster/r.in.lidar/main.c:290
-msgid "Set computation region to match the new raster map"
+#: ../raster/r.external.out/main.c:217
+msgid "Error writing GDAL file"
 msgstr ""
-#: ../raster/r.in.lidar/main.c:292
-msgid "Set computation region to match the 2D extent and resolution of the newly created new raster map"
+#: ../raster/r.external.out/main.c:240
+msgid ""
+"Redirects raster output to file utilizing GDAL library rather than storing "
+"in GRASS raster format."
 msgstr ""
-#: ../raster/r.in.lidar/main.c:315
-msgid "Use intensity values rather than Z values"
+#: ../raster/r.external.out/main.c:244
+msgid "Name of output directory"
 msgstr ""
-#: ../raster/r.in.lidar/main.c:317
-msgid "Uses intensity values everywhere as if they would be Z coordinates"
+#: ../raster/r.external.out/main.c:251
+msgid "Extension for output files"
 msgstr ""
-#: ../raster/r.in.lidar/main.c:323
-msgid "Use Z values for filtering, but intensity values for statistics"
+#: ../raster/r.external.out/main.c:257
+msgid "Format of output files"
 msgstr ""
-#: ../raster/r.in.lidar/main.c:328
-msgid "Use base raster resolution instead of computational region"
+#: ../raster/r.external.out/main.c:277
+msgid "Cease using GDAL and revert to native output"
 msgstr ""
-#: ../raster/r.in.lidar/main.c:330
-msgid "For getting values from base raster, use its actual resolution instead of computational region resolution"
+#: ../raster/r.univar/r.univar_main.c:36
+msgid "Raster map used for zoning, must be of type CELL"
 msgstr ""
-#: ../raster/r.in.lidar/main.c:357
-#, c-format
-msgid "Flag %c makes sense only with %s option or -%c flag"
+#: ../raster/r.univar/r.univar_main.c:53 ../raster/r.univar/r.univar_main.c:67
+msgid "Extended"
 msgstr ""
-#: ../raster/r.in.lidar/main.c:384
-msgid "zrange will not be taken into account during scan"
+#: ../raster/r.univar/r.univar_main.c:71 ../raster/r.univar/r3.univar_main.c:67
+msgid "Table output format instead of standard output format"
 msgstr ""
-#: ../raster/r.in.lidar/main.c:459
-#, c-format
-msgid "Unknown filter option <%s>"
+#: ../raster/r.univar/r.univar_main.c:76
+msgid ""
+"Use the native resolution and extent of the raster map, instead of the "
+"current region"
 msgstr ""
-#: ../raster/r.in.lidar/main.c:491
-#, c-format
-msgid "Invalid %s"
+#: ../raster/r.univar/r.univar_main.c:110
+msgid ""
+"Calculates univariate statistics from the non-null cells of a raster map."
 msgstr ""
-#: ../raster/r.in.lidar/main.c:526
-#, c-format
-msgid "Option '%s' must be > 0.0"
+#: ../raster/r.univar/r.univar_main.c:112
+#: ../raster/r.univar/r3.univar_main.c:105
+msgid ""
+"Statistics include number of cells counted, minimum and maximum cell values, "
+"range, arithmetic mean, population variance, standard deviation, coefficient "
+"of variation, and sum."
 msgstr ""
-#: ../raster/r.in.lidar/main.c:594
-#, c-format
-msgid "Unable to process the hole map at once. Please set the '%s' option to some value lower than 100."
+#: ../raster/r.univar/r.univar_main.c:123
+msgid "zones option and region flag -r are mutually exclusive"
 msgstr ""
-#: ../raster/r.in.lidar/main.c:614
+#: ../raster/r.univar/r.univar_main.c:201 ../raster/r.out.png/main.c:272
 #, c-format
-msgid "Pass #%d (of %d)..."
+msgid "Raster <%s> type mismatch"
 msgstr ""
-#: ../raster/r.in.lidar/main.c:776
-#, c-format
-msgid "%lu points found in input file(s)"
+#: ../raster/r.univar/r3.univar_main.c:37
+msgid "3D Raster map used for zoning, must be of type CELL"
 msgstr ""
-#: ../raster/r.in.lidar/main.c:796
-#, c-format
-msgid "%lu input points were invalid and filtered out"
+#: ../raster/r.univar/r3.univar_main.c:98 ../raster/r.to.rast3elev/main.c:363
+#: ../raster/r.colors.out/raster3d_main.c:46
+#: ../raster/r.colors/edit_colors.c:59
+#: ../locale/scriptstrings/t.rast3d.univar_to_translate.c:4
+#: ../locale/scriptstrings/t.rast.to.rast3_to_translate.c:5
+#: ../locale/scriptstrings/t.rast3d.mapcalc_to_translate.c:4
+#: ../locale/scriptstrings/t.rast3d.list_to_translate.c:5
+#: ../locale/scriptstrings/t.rast3d.extract_to_translate.c:4
+#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:2
+#: ../locale/scriptstrings/t.rast3d.algebra_to_translate.c:4
+#: ../misc/m.nviz.script/main.c:72 ../misc/m.nviz.image/main.c:55
+#: ../raster3d/r3.out.bin/main.c:205 ../raster3d/r3.out.v5d/main.c:284
+#: ../raster3d/r3.in.lidar/main.c:162 ../raster3d/r3.mkdspf/main.c:79
+#: ../raster3d/r3.in.v5d/main.c:178 ../raster3d/r3.in.bin/main.c:252
+#: ../raster3d/r3.out.netcdf/main.c:586 ../raster3d/r3.in.ascii/main.c:354
+#: ../raster3d/r3.gwflow/main.c:159 ../raster3d/r3.retile/main.c:96
+#: ../raster3d/r3.stats/main.c:48 ../raster3d/r3.gradient/main.c:43
+#: ../raster3d/r3.cross.rast/main.c:228 ../raster3d/r3.neighbors/main.c:208
+#: ../raster3d/r3.to.rast/main.c:259 ../raster3d/r3.info/main.c:75
+#: ../raster3d/r3.null/main.c:180 ../raster3d/r3.timestamp/main.c:43
+#: ../raster3d/r3.mask/main.c:133 ../raster3d/r3.out.ascii/main.c:302
+#: ../raster3d/r3.out.vtk/main.c:376 ../raster3d/r3.flow/main.c:179
+#: ../raster3d/r3.flow/test_main.c:43 ../raster3d/r3.support/main.c:49
+msgid "raster3d"
+msgstr "rastrs_3d"
+#: ../raster/r.univar/r3.univar_main.c:103
+msgid ""
+"Calculates univariate statistics from the non-null cells of a 3D raster map."
 msgstr ""
-#: ../raster/r.in.lidar/main.c:799
+#: ../raster/r.univar/r3.univar_main.c:151
+#: ../raster/r.univar/r3.univar_main.c:189 ../raster3d/r3.out.bin/main.c:314
+#: ../raster3d/r3.out.v5d/main.c:312 ../raster3d/r3.mkdspf/main.c:168
+#: ../raster3d/r3.out.netcdf/main.c:617 ../raster3d/r3.retile/main.c:127
+#: ../raster3d/r3.stats/main.c:104 ../raster3d/r3.gradient/main.c:113
+#: ../raster3d/r3.gradient/main.c:122 ../raster3d/r3.cross.rast/main.c:279
+#: ../raster3d/r3.neighbors/main.c:266 ../raster3d/r3.neighbors/main.c:275
+#: ../raster3d/r3.to.rast/main.c:298 ../raster3d/r3.to.rast/main.c:322
+#: ../raster3d/r3.info/main.c:110 ../raster3d/r3.null/main.c:110
+#: ../raster3d/r3.mask/main.c:64 ../raster3d/r3.out.ascii/main.c:339
+#: ../raster3d/r3.out.vtk/main.c:207 ../raster3d/r3.out.vtk/main.c:292
+#: ../raster3d/r3.out.vtk/main.c:513 ../raster3d/r3.flow/main.c:118
+#: ../raster3d/r3.flow/main.c:132 ../raster3d/r3.flow/main.c:373
+#: ../raster3d/r3.flow/main.c:385 ../raster3d/r3.flow/test_main.c:82
 #, c-format
-msgid "%lu input points were invalid, use -%c flag to filter them out"
+msgid "Unable to open 3D raster map <%s>"
 msgstr ""
-#: ../raster/r.in.lidar/main.c:802
-#, c-format
-msgid "Raster map <%s> created. %lu points from %d files found in region."
+#: ../raster/r.out.gridatb/main.c:70
+msgid "Exports GRASS raster map to GRIDATB.FOR map file (TOPMODEL)."
 msgstr ""
-#: ../raster/r.in.lidar/main.c:807
-#, c-format
-msgid "Raster map <%s> created. %lu points found in region."
+#: ../raster/r.uslek/main.c:55 ../raster/r.usler/main.c:55
+#: ../raster/r.sim/r.sim.sediment/main.c:116
+#: ../raster/r.sim/r.sim.water/main.c:115
+msgid "soil"
 msgstr ""
-#: ../raster/r.to.rast3elev/main.c:99
-msgid "The number of input and elevation maps is not equal"
+#: ../raster/r.uslek/main.c:56 ../raster/r.usler/main.c:56
+#: ../raster/r.sim/r.sim.sediment/main.c:118
+msgid "erosion"
 msgstr ""
-#: ../raster/r.to.rast3elev/main.c:165
-msgid "The value to fill the upper cells, default is null"
+#: ../raster/r.uslek/main.c:57
+msgid "Computes USLE Soil Erodibility Factor (K)."
 msgstr ""
-#: ../raster/r.to.rast3elev/main.c:172
-msgid "The value to fill the lower cells, default is null"
+#: ../raster/r.uslek/main.c:62
+msgid "Name of soil sand fraction raster map [0.0-1.0]"
 msgstr ""
-#: ../raster/r.to.rast3elev/main.c:185
-msgid "Use the input map values to fill the upper cells"
+#: ../raster/r.uslek/main.c:66
+msgid "Name of soil clay fraction raster map [0.0-1.0]"
 msgstr ""
-#: ../raster/r.to.rast3elev/main.c:190
-msgid "Use the input map values to fill the lower cells"
+#: ../raster/r.uslek/main.c:70
+msgid "Name of soil silt fraction raster map [0.0-1.0]"
 msgstr ""
-#: ../raster/r.to.rast3elev/main.c:287 ../raster/r.to.rast3elev/main.c:320
-msgid "Error writing 3D raster double data"
+#: ../raster/r.uslek/main.c:74
+msgid "Name of soil organic matter raster map [0.0-1.0]"
 msgstr ""
-#: ../raster/r.to.rast3elev/main.c:366
-msgid "Creates a 3D volume map based on 2D elevation and value raster maps."
+#: ../raster/r.uslek/main.c:77
+msgid "Name for output USLE K factor raster map [t.ha.hr/ha.MJ.mm]"
 msgstr ""
-#: ../raster/r.to.rast3elev/main.c:400
-msgid "The upper value is not valid"
+#: ../raster/r.grow.distance/main.c:152
+#: ../locale/scriptstrings/r.grow_to_translate.c:4
+msgid "proximity"
 msgstr ""
-#: ../raster/r.to.rast3elev/main.c:410
-msgid "The lower value is not valid"
+#: ../raster/r.grow.distance/main.c:154
+msgid "Generates a raster map containing distances to nearest raster features."
 msgstr ""
-#: ../raster/r.to.rast3elev/main.c:427
-msgid "The 2D and 3D region settings are different. I will use the 3D region settings to adjust the 2D region."
+#: ../raster/r.grow.distance/main.c:161
+msgid "Name for distance output raster map"
 msgstr ""
-#: ../raster/r.circle/main.c:54 ../vector/v.buffer/main.c:224
-msgid "circle"
+#: ../raster/r.grow.distance/main.c:167
+msgid "Name for value output raster map"
 msgstr ""
-#: ../raster/r.circle/main.c:56
-msgid "Creates a raster map containing concentric rings around a given point."
+#: ../raster/r.grow.distance/main.c:174
+#: ../locale/scriptstrings/r.grow_to_translate.c:7
+msgid "Metric"
+msgstr "Metriskā"
+#: ../raster/r.grow.distance/main.c:180
+msgid "Output distances in meters instead of map units"
 msgstr ""
-#: ../raster/r.circle/main.c:63
-msgid "The coordinate of the center (east,north)"
+#: ../raster/r.grow.distance/main.c:184
+msgid "Calculate distance to nearest NULL cell"
 msgstr ""
-#: ../raster/r.circle/main.c:69
-msgid "Minimum radius for ring/circle map (in meters)"
+#: ../raster/r.grow.distance/main.c:195
+msgid "Distance output is required for distance to NULL cells"
 msgstr ""
-#: ../raster/r.circle/main.c:75
-msgid "Maximum radius for ring/circle map (in meters)"
+#: ../raster/r.grow.distance/main.c:197
+msgid "Value output is meaningless for distance to NULL cells"
 msgstr ""
-#: ../raster/r.circle/main.c:81
-msgid "Data value multiplier"
+#: ../raster/r.grow.distance/main.c:203
+msgid "At least one of distance= and value= must be given"
 msgstr ""
-#: ../raster/r.circle/main.c:85
-msgid "Generate binary raster map"
+#: ../raster/r.grow.distance/main.c:218
+msgid "metric=geodesic is only valid for lat/lon"
 msgstr ""
-#: ../raster/r.circle/main.c:108
-msgid "Please specify a radius in which min < max"
+#: ../raster/r.grow.distance/main.c:224
+#, c-format
+msgid "Unknown metric: '%s'"
 msgstr ""
-#: ../raster/r.circle/main.c:116
-msgid "Please specify min and/or max radius when using the binary flag"
+#: ../raster/r.grow.distance/main.c:229
+#, c-format
+msgid "Output distance in meters for lat/lon is only possible with '%s=%s'"
 msgstr ""
-#: ../raster/r.solute.transport/main.c:59
-msgid "The initial concentration in [kg/m^3]"
+#: ../raster/r.grow.distance/main.c:249
+#, c-format
+msgid "Unable to create temporary file <%s>"
 msgstr ""
-#: ../raster/r.solute.transport/main.c:63
-msgid "The piezometric head in [m]"
+#: ../raster/r.grow.distance/main.c:276 ../raster/r.surf.idw/main.c:713
+#: ../raster/r.out.mpeg/main.c:286 ../raster/r.series.accumulate/main.c:248
+#: ../raster/r.series.accumulate/main.c:273
+#: ../raster/r.series.accumulate/main.c:284
+#: ../raster/r.series.accumulate/main.c:292
+#: ../raster/r.series.accumulate/main.c:300 ../ps/ps.map/ps_raster.c:102
+#, c-format
+msgid "Reading raster map <%s>..."
 msgstr ""
-#: ../raster/r.solute.transport/main.c:68
-msgid "The x-part of the hydraulic conductivity tensor in [m/s]"
+#: ../raster/r.what/main.c:104
+msgid "Queries raster maps on their category values and category labels."
 msgstr ""
-#: ../raster/r.solute.transport/main.c:73
-msgid "The y-part of the hydraulic conductivity tensor in [m/s]"
+#: ../raster/r.what/main.c:108
+msgid "Name of existing raster map(s) to query"
 msgstr ""
-#: ../raster/r.solute.transport/main.c:79
-msgid "The status for each cell, = 0 - inactive cell, 1 - active cell, 2 - dirichlet- and 3 - transfer boundary condition"
+#: ../raster/r.what/main.c:116
+msgid "Name of vector points map for query"
 msgstr ""
-#: ../raster/r.solute.transport/main.c:85
-msgid "The x-part of the diffusion tensor in [m^2/s]"
+#: ../raster/r.what/main.c:137
+msgid "Size of point cache"
 msgstr ""
-#: ../raster/r.solute.transport/main.c:90
-msgid "The y-part of the diffusion tensor in [m^2/s]"
+#: ../raster/r.what/main.c:139 ../raster/r.what/main.c:164
+#: ../display/d.legend/main.c:118 ../display/d.legend/main.c:128
+#: ../display/d.legend/main.c:136 ../display/d.legend/main.c:168
+#: ../display/d.legend/main.c:253 ../display/d.legend/main.c:258
+#: ../display/d.legend/main.c:268 ../display/d.legend/main.c:278
+#: ../display/d.legend/main.c:293
+msgid "Advanced"
 msgstr ""
-#: ../raster/r.solute.transport/main.c:94
-#: ../raster/r.solute.transport/main.c:102
-#: ../raster/r.solute.transport/main.c:138
-#: ../raster/r.solute.transport/main.c:145
-msgid "Water flow"
+#: ../raster/r.what/main.c:143
+#: ../locale/scriptstrings/t.rast.what_to_translate.c:11
+msgid "Output header row"
 msgstr ""
-#: ../raster/r.solute.transport/main.c:96
-msgid "Groundwater sources and sinks in [m^3/s]"
+#: ../raster/r.what/main.c:148
+msgid "Show the category labels of the grid cell(s)"
 msgstr ""
-#: ../raster/r.solute.transport/main.c:103
-msgid "Concentration sources and sinks bounded to a water source or sink in [kg/s]"
+#: ../raster/r.what/main.c:153
+msgid "Output color values as RRR:GGG:BBB"
 msgstr ""
-#: ../raster/r.solute.transport/main.c:112
-msgid "Concentration of inner sources and inner sinks in [kg/s] (i.e. a chemical reaction)"
+#: ../raster/r.what/main.c:158
+msgid "Output integer category values, not cell values"
 msgstr ""
-#: ../raster/r.solute.transport/main.c:117
-msgid "Retardation factor [-]"
+#: ../raster/r.what/main.c:163
+msgid "Turn on cache reporting"
 msgstr ""
-#: ../raster/r.solute.transport/main.c:121
-msgid "Effective porosity [-]"
+#: ../raster/r.what/main.c:168
+#: ../locale/scriptstrings/t.rast.what_to_translate.c:13
+#, fuzzy
+msgid "Show the category for vector points map"
+msgstr "Vektorkartes nosaukums"
+#: ../raster/r.what/main.c:199
+msgid "Flag 'v' required option 'points'"
 msgstr ""
-#: ../raster/r.solute.transport/main.c:125
-msgid "Top surface of the aquifer in [m]"
+#: ../raster/r.what/main.c:214
+#, c-format
+msgid "Can only do up to %d raster maps (more than %d given)"
 msgstr ""
-#: ../raster/r.solute.transport/main.c:129
-msgid "Bottom surface of the aquifer in [m]"
+#: ../raster/r.what/main.c:231
+#, c-format
+msgid "Unable to read category file for <%s>"
 msgstr ""
-#: ../raster/r.solute.transport/main.c:132
-msgid "The resulting concentration of the numerical solute transport calculation will be written to this map. [kg/m^3]"
+#: ../raster/r.what/main.c:314
+#, c-format
+msgid "Unable to read vector map <%s>"
 msgstr ""
-#: ../raster/r.solute.transport/main.c:140
-msgid "Calculate and store the groundwater filter velocity vector part in x direction [m/s]\n"
+#: ../raster/r.what/main.c:318
+#, c-format
+msgid "Line %d is not point or centroid, skipped"
 msgstr ""
-#: ../raster/r.solute.transport/main.c:147
-msgid "Calculate and store the groundwater filter velocity vector part in y direction [m/s]\n"
+#: ../raster/r.what/main.c:404
+#, c-format
+msgid "%s %s is outside your current region"
 msgstr ""
-#: ../raster/r.solute.transport/main.c:161
-msgid "The longditudinal dispersivity length. [m]"
+#: ../raster/r.report/parse.c:38 ../raster/r.stats/main.c:114
+msgid "Name of raster map(s) to report on"
 msgstr ""
-#: ../raster/r.solute.transport/main.c:169
-msgid "The transversal dispersivity length. [m]"
+#: ../raster/r.report/parse.c:45
+msgid "Units to report"
 msgstr ""
-#: ../raster/r.solute.transport/main.c:177
-msgid "Use this number of time loops if the CFL flag is off. The timestep will become dt/loops."
+#: ../raster/r.report/parse.c:49
+msgid "area in square miles"
 msgstr ""
-#: ../raster/r.solute.transport/main.c:187
-msgid "Set the flow stabilizing scheme (full or exponential upwinding)."
+#: ../raster/r.report/parse.c:50
+msgid "area in square meters"
 msgstr ""
-#: ../raster/r.solute.transport/main.c:199
-msgid "Use the Courant-Friedrichs-Lewy criteria for time step calculation"
+#: ../raster/r.report/parse.c:51
+msgid "area in square kilometers"
 msgstr ""
-#: ../raster/r.solute.transport/main.c:231
-msgid "solute transport"
+#: ../raster/r.report/parse.c:52
+msgid "area in acres"
 msgstr ""
-#: ../raster/r.solute.transport/main.c:233
-msgid "Numerical calculation program for transient, confined and unconfined solute transport in two dimensions"
+#: ../raster/r.report/parse.c:53
+msgid "area in hectares"
 msgstr ""
-#: ../raster/r.solute.transport/main.c:258
-msgid "The direct LU solver do not work with sparse matrices"
+#: ../raster/r.report/parse.c:54
+msgid "number of cells"
 msgstr ""
-#: ../raster/r.solute.transport/main.c:260
-msgid "The direct Gauss solver do not work with sparse matrices"
+#: ../raster/r.report/parse.c:55
+msgid "percent cover"
 msgstr ""
-#: ../raster/r.solute.transport/main.c:370
-#, c-format
-msgid "The Courant-Friedrichs-Lewy criteria is %g it should be within [0:1]"
+#: ../raster/r.report/parse.c:58 ../raster/r.stats/main.c:158
+#: ../raster/r.stats/main.c:163 ../raster/r.stats/main.c:169
+msgid "Statistics"
 msgstr ""
-#: ../raster/r.solute.transport/main.c:371
-#, c-format
-msgid "The largest stable time step is %g"
+#: ../raster/r.report/parse.c:75
+msgid "Page length"
 msgstr ""
-#: ../raster/r.solute.transport/main.c:380
-#, c-format
-msgid "Number of inner loops is %g"
+#: ../raster/r.report/parse.c:83
+msgid "Page width"
 msgstr ""
-#: ../raster/r.solute.transport/main.c:381
-#, c-format
-msgid "Time step for each loop %g"
+#: ../raster/r.report/parse.c:94 ../raster/r.stats/main.c:136
+msgid "Number of floating-point subranges to collect stats from"
 msgstr ""
-#: ../raster/r.solute.transport/main.c:385
-#, c-format
-msgid "The time step is to large: %gs. The largest time step should be of size %gs."
+#: ../raster/r.report/parse.c:95 ../raster/r.report/parse.c:139
+#: ../raster/r.report/parse.c:145 ../raster/r.stats/main.c:137
+#: ../raster/r.stats/main.c:192 ../raster/r.stats/main.c:197
+#: ../raster/r.stats/main.c:212 ../raster/r.stats/main.c:217
+msgid "Floating point"
 msgstr ""
-#: ../raster/r.solute.transport/main.c:397
-#, c-format
-msgid "Time step %i with time sum %g"
+#: ../raster/r.report/parse.c:102 ../raster/r.stats/main.c:144
+msgid "Sort output statistics by cell counts"
 msgstr ""
-#: ../raster/r.solute.transport/main.c:543
-msgid "Could not create and solve the linear equation system"
+#: ../raster/r.report/parse.c:103 ../raster/r.stats/main.c:145
+msgid "Default: sorted by categories or intervals"
 msgstr ""
-#: ../raster/r.stats/main.c:109
-msgid "Generates area statistics for raster map."
+#: ../raster/r.report/parse.c:107 ../raster/r.stats/main.c:149
+msgid "Sort by cell counts in ascending order"
 msgstr ""
-#: ../raster/r.stats/main.c:157
-msgid "Print area totals in square meters"
+#: ../raster/r.report/parse.c:108 ../raster/r.stats/main.c:150
+msgid "Sort by cell counts in descending order"
 msgstr ""
-#: ../raster/r.stats/main.c:162
-msgid "Print cell counts (sortable)"
+#: ../raster/r.report/parse.c:113
+msgid "Suppress page headers"
 msgstr ""
-#: ../raster/r.stats/main.c:168
-msgid "Print approximate (total percent may not be 100%) percents"
+#: ../raster/r.report/parse.c:118
+msgid "Use formfeeds between pages"
 msgstr ""
-#: ../raster/r.stats/main.c:173
-msgid "Print category labels"
+#: ../raster/r.report/parse.c:123
+msgid "Scientific format"
+msgstr "Zinātniskais formāts"
+#: ../raster/r.report/parse.c:128 ../raster/r.stats/main.c:201
+msgid "Do not report no data value"
 msgstr ""
-#: ../raster/r.stats/main.c:177
-msgid "One cell (range) per line"
+#: ../raster/r.report/parse.c:129 ../raster/r.report/parse.c:134
+#: ../raster/r.stats/main.c:202 ../raster/r.stats/main.c:207
+msgid "No data"
 msgstr ""
-#: ../raster/r.stats/main.c:181
-msgid "Print grid coordinates (east and north)"
+#: ../raster/r.report/parse.c:133 ../raster/r.stats/main.c:206
+msgid "Do not report cells where all maps have no data"
 msgstr ""
-#: ../raster/r.stats/main.c:182 ../raster/r.stats/main.c:187
-msgid "Coordinates"
+#: ../raster/r.report/parse.c:138 ../raster/r.stats/main.c:211
+msgid "Report for cats floating-point ranges (floating-point maps only)"
 msgstr ""
-#: ../raster/r.stats/main.c:186
-msgid "Print x and y (column and row)"
+#: ../raster/r.report/parse.c:144 ../raster/r.stats/main.c:216
+msgid "Read floating-point map as integer (use map's quant rules)"
 msgstr ""
-#: ../raster/r.stats/main.c:191
-msgid "Print averaged values instead of intervals (floating-point maps only)"
+#: ../raster/r.report/parse.c:187
+msgid "nsteps has to be > 0; using nsteps=255"
 msgstr ""
-#: ../raster/r.stats/main.c:196
-msgid "Print raw indexes of floating-point ranges (floating-point maps only)"
+#: ../raster/r.report/parse.c:193
+msgid "Illegal page length"
 msgstr ""
-#: ../raster/r.stats/main.c:233
-#, c-format
-msgid "'%s' must be greater than zero; using %s=255"
+#: ../raster/r.report/parse.c:198
+msgid "Illegal page width"
 msgstr ""
-#: ../raster/r.stats/main.c:303
+#: ../raster/r.report/parse.c:253
 #, c-format
-msgid "Raster map <%s> is reading as integer map! Flag '-%c' and/or '%s' option will be ignored."
+msgid "Only %d unit%s allowed"
 msgstr ""
-#: ../raster/r.stats/main.c:319
+#: ../raster/r.report/parse.c:286
 #, c-format
-msgid "Cats for raster map <%s> are either missing or have no explicit labels. Using %s=%d."
+msgid "Unable to read fp range for raster map <%s>"
 msgstr ""
-#: ../raster/r.stats/main.c:325
+#: ../raster/r.report/parse.c:294 ../raster/r.mapcalc/map3.c:191
+#: ../raster/r.mapcalc/map.c:235 ../raster/r.category/main.c:148
+#: ../raster/r.category/main.c:230
 #, c-format
-msgid "Flag '-%c' was given, using cats fp ranges of raster map <%s>, ignoring '%s' option"
+msgid "Unable to read category file of raster map <%s@%s>"
 msgstr ""
-#: ../raster/r.stats/raw_stats.c:118
-msgid "Invalid map type"
+#: ../raster/r.report/main.c:69
+msgid "Reports statistics for raster maps."
 msgstr ""
-#: ../raster/r.compress/main.c:70
-msgid "compression"
+#: ../raster/r.report/label.c:13
+msgid "Page width is too small"
 msgstr ""
-#: ../raster/r.compress/main.c:71
-msgid "Compresses and decompresses raster maps."
-msgstr "Arhivēt un atarhivēt rastra failus."
-#: ../raster/r.compress/main.c:74
-msgid "Name of existing raster map(s)"
-msgstr "Esksistējošu rastra failu nosaukumi"
-#: ../raster/r.compress/main.c:78
-msgid "Uncompress the map"
-msgstr "Atarhivēt kartes"
-#: ../raster/r.compress/main.c:82
-msgid "Print compression information and data type of input map(s)"
+#: ../raster/r.report/stats.c:93
+#, c-format
+msgid "Unable to open result file <%s>"
 msgstr ""
-#: ../raster/r.compress/main.c:86
-msgid "Print compression information in shell script style"
+#: ../raster/r.drain/main.c:113
+msgid ""
+"Traces a flow through an elevation model or cost surface on a raster map."
 msgstr ""
-#: ../raster/r.compress/main.c:128 ../raster/r.compress/main.c:308
-#, c-format
-msgid "Raster map <%s> is not in the current mapset"
+#: ../raster/r.drain/main.c:116
+msgid "Name of input elevation or cost surface raster map"
 msgstr ""
-#: ../raster/r.compress/main.c:134
-#, c-format
-msgid "<%s> is a reclass file of map <%s> in mapset <%s> - can't uncompress"
+#: ../raster/r.drain/main.c:121
+msgid "Name of input movement direction map associated with the cost surface"
 msgstr ""
-#: ../raster/r.compress/main.c:136
-#, c-format
-msgid "<%s> is a reclass file of map <%s> in mapset <%s> - can't compress"
+#: ../raster/r.drain/main.c:123
+msgid "Direction in degrees CCW from east"
 msgstr ""
-#: ../raster/r.compress/main.c:141
-#, c-format
-msgid "<%s> is a GDAL-linked map - can't (un)compress"
-msgstr ""
+#: ../raster/r.drain/main.c:125 ../raster/r.drain/main.c:167
+msgid "Cost surface"
+msgstr "Izmaksu virsma"
-#: ../raster/r.compress/main.c:215
-msgid "DONE: uncompressed file is %lu %s (%.2f%) smaller"
+#: ../raster/r.drain/main.c:133
+msgid "Name for output drain vector map"
 msgstr ""
-#: ../raster/r.compress/main.c:216
-msgid "DONE: compressed file is %lu %s (%.2f%) smaller"
+#: ../raster/r.drain/main.c:134
+msgid "Recommended for cost surface made using knight's move"
 msgstr ""
-#: ../raster/r.compress/main.c:220
-msgid "DONE: uncompressed file is %lu %s (%.2f%) larger"
+#: ../raster/r.drain/main.c:144
+msgid "Name of starting vector points map(s)"
 msgstr ""
-#: ../raster/r.compress/main.c:221
-msgid "DONE: compressed file is %lu %s (%.2f%) larger"
+#: ../raster/r.drain/main.c:150
+msgid "Copy input cell values on output"
 msgstr ""
-#: ../raster/r.compress/main.c:224
-msgid "same size"
+#: ../raster/r.drain/main.c:151 ../raster/r.drain/main.c:156
+#: ../raster/r.drain/main.c:161
+msgid "Path settings"
 msgstr ""
-#: ../raster/r.compress/main.c:240
-#, c-format
-msgid "<%s> already uncompressed"
+#: ../raster/r.drain/main.c:155
+msgid "Accumulate input values along the path"
 msgstr ""
-#: ../raster/r.compress/main.c:243
-#, c-format
-msgid "Uncompressing <%s>"
+#: ../raster/r.drain/main.c:160
+msgid "Count cell numbers along the path"
 msgstr ""
-#: ../raster/r.compress/main.c:251
-#, c-format
-msgid "Re-compressing <%s>"
+#: ../raster/r.drain/main.c:166
+msgid ""
+"The input raster map is a cost surface (direction surface must also be "
+"specified)"
 msgstr ""
-#: ../raster/r.compress/main.c:254
-#, c-format
-msgid "Compressing <%s>"
+#: ../raster/r.drain/main.c:178
+msgid "Directional drain selected... checking for direction raster map"
 msgstr ""
-#: ../raster/r.compress/main.c:312
-#, c-format
-msgid "<%s> is a GDAL-linked map"
+#: ../raster/r.drain/main.c:181
+msgid "Surface/Hydrology drain selected"
 msgstr ""
-#: ../raster/r.compress/main.c:316
+#: ../raster/r.drain/main.c:186
 #, c-format
-msgid "<%s> is a reclass file of map <%s> in mapset <%s>"
+msgid ""
+"Direction raster map <%s> not specified, if direction flag is on, a "
+"direction raster must be given"
 msgstr ""
-#: ../raster/r.compress/main.c:336
+#: ../raster/r.drain/main.c:193
 #, c-format
-msgid "<%s> is uncompressed (method %i: %s). Data type: %s"
+msgid ""
+"Direction raster map <%s> should not be specified for Surface/Hydrology "
+"drains"
 msgstr ""
-#: ../raster/r.compress/main.c:343
-#, c-format
-msgid "<%s> is compressed (method %i: %s). Data type: %s"
+#: ../raster/r.drain/main.c:212
+msgid "Specify just one of the -c, -a and -n flags"
 msgstr ""
-#: ../raster/r.compress/main.c:351
+#: ../raster/r.drain/main.c:243
 #, c-format
-msgid "<%s> has a compressed NULL file"
+msgid "Starting point %d is outside the current region"
 msgstr ""
-#: ../raster/r.compress/main.c:353
+#: ../raster/r.drain/main.c:318
 #, c-format
-msgid "<%s> has an uncompressed NULL file"
+msgid "Starting vector map <%s> contains no points in the current region"
 msgstr ""
-#: ../raster/r.colors.out/raster3d_main.c:50
-msgid "Exports the color table associated with a 3D raster map."
+#: ../raster/r.drain/main.c:326
+msgid "No start/stop point(s) specified"
 msgstr ""
-#: ../raster/r.colors.out/raster3d_main.c:56
-#: ../raster/r.colors.out/raster_main.c:55 ../vector/v.colors.out/main.c:61
-msgid "Path to output rules file"
+#: ../raster/r.drain/main.c:401
+msgid "Calculating flow directions..."
 msgstr ""
-#: ../raster/r.colors.out/raster3d_main.c:62
-#: ../raster/r.colors.out/raster_main.c:61 ../vector/v.colors.out/main.c:72
-msgid "Output values as percentages"
+#: ../raster/r.drain/main.c:470 ../raster/r.in.lidar/main.c:755
+msgid "Writing output raster map..."
 msgstr ""
-#: ../raster/r.colors.out/raster3d_main.c:70
+#: ../raster/r.drain/main.c:692
 #, c-format
-msgid "Unable to read color table for raster3d map <%s>"
+msgid "direction read: %lf, neighbour found: %i"
 msgstr ""
-#: ../raster/r.colors.out/raster_main.c:49
-msgid "Exports the color table associated with a raster map."
+#: ../raster/r.info/main.c:75
+msgid "Outputs basic information about a raster map."
 msgstr ""
-#: ../raster/r.regression.multi/main.c:61
-msgid "Matrix is unsolvable"
+#: ../raster/r.info/main.c:81
+msgid "Print raster array information in shell script style"
 msgstr ""
-#: ../raster/r.regression.multi/main.c:132
-msgid "Calculates multiple linear regression from raster maps."
+#: ../raster/r.info/main.c:85
+msgid "Print range in shell script style"
 msgstr ""
-#: ../raster/r.regression.multi/main.c:146
-msgid "Map to store residuals"
+#: ../raster/r.info/main.c:89
+msgid "Print extended metadata information in shell script style"
 msgstr ""
-#: ../raster/r.regression.multi/main.c:151
-msgid "Map to store estimates"
+#: ../raster/r.info/main.c:93 ../raster3d/r3.info/main.c:94
+msgid "Print raster history instead of info"
 msgstr ""
-#: ../raster/r.regression.multi/main.c:249
-msgid "First pass..."
+#: ../raster/r.info/main.c:99
+#, c-format
+msgid "Flags -%c and -%c/%c/%c are mutually exclusive"
 msgstr ""
-#: ../raster/r.regression.multi/main.c:322
-msgid "Not enough valid cells available"
+#: ../raster/r.info/main.c:127
+msgid "Unable to read range file"
 msgstr ""
-#: ../raster/r.regression.multi/main.c:336
-msgid "Multiple regression failed"
+#: ../raster/r.info/main.c:303 ../raster/r.info/main.c:445
+#: ../raster3d/r3.info/main.c:138 ../raster3d/r3.info/main.c:145
+#: ../raster3d/r3.info/main.c:151 ../raster3d/r3.info/main.c:156
+#: ../raster3d/r3.info/main.c:162 ../raster3d/r3.info/main.c:167
+#: ../raster3d/r3.info/main.c:172 ../raster3d/r3.info/main.c:183
+#: ../raster3d/r3.info/main.c:189 ../raster3d/r3.info/main.c:204
+#: ../raster3d/r3.info/main.c:211 ../raster3d/r3.info/main.c:218
+#: ../raster3d/r3.info/main.c:223 ../raster3d/r3.info/main.c:228
+#: ../raster3d/r3.info/main.c:235 ../raster3d/r3.info/main.c:245
+#: ../raster3d/r3.info/main.c:251 ../raster3d/r3.info/main.c:257
+#: ../raster3d/r3.info/main.c:273 ../raster3d/r3.info/main.c:280
+#: ../raster3d/r3.info/main.c:287 ../raster3d/r3.info/main.c:296
+#: ../raster3d/r3.info/main.c:306 ../raster3d/r3.info/main.c:316
+#: ../raster3d/r3.info/main.c:326 ../raster3d/r3.info/main.c:346
+#: ../raster3d/r3.info/main.c:356 ../raster3d/r3.info/main.c:361
+#: ../raster3d/r3.info/main.c:369 ../raster3d/r3.info/main.c:382
+msgid "Cannot allocate memory for string"
 msgstr ""
-#: ../raster/r.regression.multi/main.c:341
-msgid "Second pass..."
+#: ../raster/r.resamp.bspline/main.c:84
+msgid ""
+"Performs bilinear or bicubic spline interpolation with Tykhonov "
+"regularization."
 msgstr ""
-#: ../raster/r.random.surface/main.c:61
-msgid "Generates random surface(s) with spatial dependence."
-msgstr "Ģenerēt nejaušu virsmu(as) ar telpiskajām atkarībām."
-#: ../raster/r.random.surface/main.c:68
-msgid "Name for output raster map(s)"
+#: ../raster/r.resamp.bspline/main.c:92
+msgid "Name for output vector map with interpolation grid"
 msgstr ""
-#: ../raster/r.random.surface/main.c:85
-msgid "Distance decay exponent (value > 0.0)"
+#: ../raster/r.resamp.bspline/main.c:97
+msgid "Name of raster map to use for masking"
 msgstr ""
-#: ../raster/r.random.surface/main.c:94
-msgid "Distance filter remains flat before beginning exponent"
+#: ../raster/r.resamp.bspline/main.c:106
+msgid ""
+"Length of each spline step in the east-west direction. Default: 1.5 * ewres."
 msgstr ""
-#: ../raster/r.random.surface/main.c:102
-msgid "Random seed (SEED_MIN >= value >= SEED_MAX), default [random]"
+#: ../raster/r.resamp.bspline/main.c:114
+msgid ""
+"Length of each spline step in the north-south direction. Default: 1.5 * "
+"nsres."
 msgstr ""
-#: ../raster/r.random.surface/main.c:108
-msgid "Maximum cell value of distribution"
+#: ../raster/r.resamp.bspline/main.c:137
+msgid "Only interpolate null cells in input raster map"
 msgstr ""
-#: ../raster/r.random.surface/main.c:113
-msgid "Uniformly distributed cell values"
+#: ../raster/r.resamp.bspline/main.c:183
+msgid "ew_step must be positive"
 msgstr ""
-#: ../raster/r.random.surface/init.c:73
-#, c-format
-msgid "High (%d) must be greater than 1"
+#: ../raster/r.resamp.bspline/main.c:191
+msgid "ns_step must be positive"
 msgstr ""
-#: ../raster/r.random.surface/init.c:82
+#: ../raster/r.resamp.bspline/main.c:218
 #, c-format
-msgid "Rastar map <%s> repeated, maps must be unique"
+msgid "spline step in ew direction %g"
 msgstr ""
-#: ../raster/r.random.surface/init.c:92
-msgid "Output raster map required"
-msgstr ""
-#: ../raster/r.random.surface/init.c:108
+#: ../raster/r.resamp.bspline/main.c:219
 #, c-format
-msgid "Seed (%d) larger than maximum (%d)"
+msgid "spline step in ns direction %g"
 msgstr ""
-#: ../raster/r.random.surface/init.c:111 ../raster/r.random.surface/init.c:120
+#: ../raster/r.resamp.bspline/main.c:220
 #, c-format
-msgid " seed is set to %d"
+msgid "adjusted EW splines %d"
 msgstr ""
-#: ../raster/r.random.surface/init.c:116
+#: ../raster/r.resamp.bspline/main.c:221
 #, c-format
-msgid "Seed (%d) smaller than minimum (%d)"
+msgid "adjusted NS splines %d"
 msgstr ""
-#: ../raster/r.random.surface/init.c:159
+#: ../raster/r.resamp.bspline/main.c:327
 #, c-format
-msgid "Distance value (%d): %lf must be >= 0.0"
+msgid "Loading input raster <%s>"
 msgstr ""
-#: ../raster/r.random.surface/init.c:187
-#, c-format
-msgid "Exponent value (%lf) must be > 0.0"
-msgstr ""
+#: ../raster/r.resamp.bspline/main.c:341 ../raster/r.resamp.bspline/main.c:452
+#: ../raster/r.resamp.bspline/main.c:488
+#, fuzzy
+msgid "Can not write to temp file"
+msgstr "Nav iespēju atvērt šūnu failu priekš[%s]"
-#: ../raster/r.random.surface/init.c:211
-#, c-format
-msgid "Flat value (%lf) must be less than distance value (%lf)"
+#: ../raster/r.resamp.bspline/main.c:346
+msgid "Only NULL cells in input raster"
 msgstr ""
-#: ../raster/r.random.surface/init.c:232
-msgid "Must have a distance value for each filter"
+#: ../raster/r.resamp.bspline/main.c:394
+msgid "Mark cells for interpolation"
 msgstr ""
-#: ../raster/r.random.surface/init.c:264
-msgid "Must have a exponent value for each filter"
+#: ../raster/r.resamp.bspline/main.c:466
+msgid "No NULL cells found in input raster."
 msgstr ""
-#: ../raster/r.random.surface/init.c:281
-msgid "Must have a weight value for each filter"
+#: ../raster/r.resamp.bspline/main.c:730
+msgid "No data within this subregion. Consider increasing the spline step."
 msgstr ""
-#: ../raster/r.latlong/main.c:57
-msgid "latitude"
+#: ../raster/r.resamp.bspline/crosscorr.c:160
+#, c-format
+msgid ""
+"%d are too many cells, recommended are < 100 cells. The cross validation "
+"would take too much time."
 msgstr ""
-#: ../raster/r.latlong/main.c:58
-msgid "longitude"
-msgstr ""
+#: ../raster/r.resamp.bspline/crosscorr.c:169
+#, c-format
+msgid "%d point read in region"
+msgid_plural "%d points read in region"
+msgstr[0] ""
+msgstr[1] ""
+msgstr[2] ""
-#: ../raster/r.latlong/main.c:60
-msgid "Creates a latitude/longitude raster map."
+#: ../raster/r.resamp.bspline/crosscorr.c:174
+msgid "Maybe it takes too long. Consider reducing the region extents."
 msgstr ""
-#: ../raster/r.latlong/main.c:66
-msgid "Name for output latitude or longitude raster map"
-msgstr ""
-#: ../raster/r.latlong/main.c:70
-msgid "Longitude output"
-msgstr ""
 #: ../raster/r.coin/main.c:69
-msgid "Tabulates the mutual occurrence (coincidence) of categories for two raster map layers."
+msgid ""
+"Tabulates the mutual occurrence (coincidence) of categories for two raster "
+"map layers."
 msgstr ""
 #: ../raster/r.coin/main.c:74
@@ -19486,7 +20416,9 @@
 msgstr ""
 #: ../raster/r.coin/main.c:86
-msgid "c(ells), p(ercent), x(percent of category [column]), y(percent of category [row]), a(cres), h(ectares), k(square kilometers), m(square miles)"
+msgid ""
+"c(ells), p(ercent), x(percent of category [column]), y(percent of category "
+"[row]), a(cres), h(ectares), k(square kilometers), m(square miles)"
 msgstr ""
 #: ../raster/r.coin/main.c:93
@@ -19519,18322 +20451,18275 @@
 msgid "Preparing report ..."
 msgstr ""
-#: ../raster/r.out.ppm/main.c:56
-msgid "Converts a GRASS raster map to a PPM image file."
+#: ../raster/r.to.rast3elev/main.c:99
+msgid "The number of input and elevation maps is not equal"
 msgstr ""
-#: ../raster/r.out.ppm/main.c:64
-msgid "Name for new PPM file (use '-' for stdout)"
+#: ../raster/r.to.rast3elev/main.c:136 ../raster/r.to.rast3/main.c:59
+msgid "Could not close the map"
 msgstr ""
-#: ../raster/r.out.ppm/main.c:68
-msgid "Output greyscale instead of color"
+#: ../raster/r.to.rast3elev/main.c:165
+msgid "The value to fill the upper cells, default is null"
 msgstr ""
-#: ../raster/r.out.ppm/main.c:72
-msgid "Suppress printing of PPM header"
+#: ../raster/r.to.rast3elev/main.c:172
+msgid "The value to fill the lower cells, default is null"
 msgstr ""
-#: ../raster/r.out.ppm/main.c:124
-#, c-format
-msgid "Unable to open file <%s> for write"
+#: ../raster/r.to.rast3elev/main.c:175 ../raster/r.to.rast3/main.c:84
+msgid "The maximum tile size in kilo bytes. Default is 32KB."
 msgstr ""
-#: ../raster/r.out.ppm/main.c:154
-msgid "Converting..."
-msgstr "Konvertē..."
+#: ../raster/r.to.rast3elev/main.c:185
+msgid "Use the input map values to fill the upper cells"
+msgstr ""
-#: ../raster/r.out.ppm/main.c:234
-#, c-format
-msgid "File <%s> created"
+#: ../raster/r.to.rast3elev/main.c:190
+msgid "Use the input map values to fill the lower cells"
 msgstr ""
-#: ../raster/r.support/check.c:26
-#, c-format
-msgid ""
-"\n"
-"  Updating statistics for [%s]"
+#: ../raster/r.to.rast3elev/main.c:194 ../raster3d/r3.out.netcdf/main.c:116
+#: ../raster3d/r3.cross.rast/main.c:109 ../raster3d/r3.to.rast/main.c:128
+#: ../raster3d/r3.out.ascii/main.c:118
+msgid "Use 3D raster mask (if exists) with input map"
 msgstr ""
-#: ../raster/r.support/check.c:69
-#, c-format
-msgid ""
-"   Updating the number of categories for [%s]\n"
-"\n"
+#: ../raster/r.to.rast3elev/main.c:287 ../raster/r.to.rast3elev/main.c:320
+msgid "Error writing 3D raster double data"
 msgstr ""
-#: ../raster/r.support/main.c:56
-msgid "Allows creation and/or modification of raster map layer support files."
+#: ../raster/r.to.rast3elev/main.c:366
+msgid "Creates a 3D volume map based on 2D elevation and value raster maps."
 msgstr ""
-#: ../raster/r.support/main.c:80
-msgid "Text to use for map data units"
+#: ../raster/r.to.rast3elev/main.c:400
+msgid "The upper value is not valid"
 msgstr ""
-#: ../raster/r.support/main.c:86
-msgid "Text to use for map vertical datum"
+#: ../raster/r.to.rast3elev/main.c:410
+msgid "The lower value is not valid"
 msgstr ""
-#: ../raster/r.support/main.c:129
-msgid "Update statistics (histogram, range)"
+#: ../raster/r.to.rast3elev/main.c:427
+msgid ""
+"The 2D and 3D region settings are different. I will use the 3D region "
+"settings to adjust the 2D region."
 msgstr ""
-#: ../raster/r.support/main.c:133
-msgid "Create/reset the null file"
+#: ../raster/r.to.rast3elev/main.c:443 ../raster/r.to.rast3/main.c:291
+msgid "Error opening 3D raster map"
 msgstr ""
-#: ../raster/r.support/main.c:137
-msgid "Delete the null file"
+#: ../raster/r.to.rast3elev/main.c:457 ../raster/r.to.rast3/main.c:279
+msgid "Creating 3D raster map"
 msgstr ""
-#: ../raster/r.support/main.c:273 ../raster/r.support/main.c:301
-#, c-format
-msgid "[%s] is a reclass of another map. Exiting."
+#: ../raster/r.to.rast3elev/main.c:501 ../raster/r.to.rast3/main.c:326
+msgid "Error closing 3d raster map"
 msgstr ""
-#: ../raster/r.support/main.c:285
-#, c-format
-msgid "Writing new null file for [%s]... "
+#: ../raster/r.out.gdal/attr.c:140 ../raster/r.out.gdal/attr.c:178
+msgid "Failed to set raster attribute table"
 msgstr ""
-#: ../raster/r.support/main.c:305
+#: ../raster/r.out.gdal/main.c:52
 #, c-format
-msgid "Removing null file for [%s]...\n"
+msgid "Supported formats:\n"
 msgstr ""
-#: ../raster/r.support/main.c:312 ../scripts/v.in.e00/v.in.e00.py:165
-#: ../scripts/r.in.aster/r.in.aster.py:144
-#: ../scripts/r.fillnulls/r.fillnulls.py:490 ../scripts/d.polar/d.polar.py:407
-#: ../scripts/r.plane/r.plane.py:121
-#: ../scripts/i.in.spotvgt/i.in.spotvgt.py:280
-msgid "Done."
-msgstr "Padarīts."
+#: ../raster/r.out.gdal/main.c:138
+msgid "Exports GRASS raster maps into GDAL supported formats."
+msgstr ""
-#: ../raster/r.region/main.c:54
-msgid "Sets the boundary definitions for a raster map."
+#: ../raster/r.out.gdal/main.c:144
+msgid "List supported output formats"
 msgstr ""
-#: ../raster/r.region/main.c:60
-msgid "Set from current region"
+#: ../raster/r.out.gdal/main.c:150
+msgid "Do not write GDAL standard colortable"
 msgstr ""
-#: ../raster/r.region/main.c:77
-msgid "Name of raster map to change"
+#: ../raster/r.out.gdal/main.c:151
+msgid "Only applicable to Byte or UInt16 data types"
 msgstr ""
-#: ../raster/r.region/main.c:85
-msgid "Set region from named region"
+#: ../raster/r.out.gdal/main.c:156
+msgid "Do not write non-standard metadata"
 msgstr ""
-#: ../raster/r.region/main.c:93
-msgid "Set region to match this raster map"
+#: ../raster/r.out.gdal/main.c:157
+msgid "Enhances compatibility with other GIS software"
 msgstr ""
-#: ../raster/r.region/main.c:100
-msgid "Set region to match this vector map"
+#: ../raster/r.out.gdal/main.c:162
+msgid "Write raster attribute table"
 msgstr ""
-#: ../raster/r.region/main.c:143
-msgid "Raster map to align to"
+#: ../raster/r.out.gdal/main.c:163
+msgid "Some export formats may not be supported"
 msgstr ""
-#: ../raster/r.carve/main.c:76
-msgid "Generates stream channels."
+#: ../raster/r.out.gdal/main.c:167
+msgid "Force raster export despite any warnings of data loss"
 msgstr ""
-#: ../raster/r.carve/main.c:77
-msgid "Takes vector stream data, transforms it to raster and subtracts depth from the output DEM."
+#: ../raster/r.out.gdal/main.c:168
+msgid "Overrides nodata safety check"
 msgstr ""
-#: ../raster/r.carve/main.c:82
-msgid "Name of input raster elevation map"
+#: ../raster/r.out.gdal/main.c:171
+msgid "Name of raster map (or group) to export"
 msgstr ""
-#: ../raster/r.carve/main.c:87
-msgid "Name of input vector map containing stream(s)"
+#: ../raster/r.out.gdal/main.c:174
+msgid "Name for output raster file"
 msgstr ""
-#: ../raster/r.carve/main.c:95
-msgid "Name for output vector map for adjusted stream points"
+#: ../raster/r.out.gdal/main.c:180
+msgid "Raster data format to write (case sensitive, see also -l flag)"
 msgstr ""
-#: ../raster/r.carve/main.c:100
-msgid "Stream width (in meters)"
+#: ../raster/r.out.gdal/main.c:201
+#: ../locale/scriptstrings/t.rast.export_to_translate.c:11
+msgid "Data type"
+msgstr "Datu tips"
+#: ../raster/r.out.gdal/main.c:211
+#: ../locale/scriptstrings/t.rast.export_to_translate.c:13
+msgid "Creation option(s) to pass to the output format driver"
 msgstr ""
-#: ../raster/r.carve/main.c:101
-msgid "Default is raster cell width"
+#: ../raster/r.out.gdal/main.c:213
+#: ../locale/scriptstrings/t.rast.export_to_translate.c:14
+msgid "In the form of \"NAME=VALUE\", separate multiple entries with a comma"
 msgstr ""
-#: ../raster/r.carve/main.c:106
-msgid "Additional stream depth (in meters)"
+#: ../raster/r.out.gdal/main.c:221
+#: ../locale/scriptstrings/t.rast.export_to_translate.c:15
+msgid "Metadata key(s) and value(s) to include"
 msgstr ""
-#: ../raster/r.carve/main.c:110
-msgid "No flat areas allowed in flow direction"
+#: ../raster/r.out.gdal/main.c:223
+#: ../locale/scriptstrings/t.rast.export_to_translate.c:16
+msgid ""
+"In the form of \"META-TAG=VALUE\", separate multiple entries with a comma. "
+"Not supported by all output format drivers."
 msgstr ""
-#: ../raster/r.carve/main.c:134
-#, c-format
-msgid "Invalid width value '%s' - using default."
+#: ../raster/r.out.gdal/main.c:233
+#: ../locale/scriptstrings/t.rast.export_to_translate.c:17
+msgid "Assign a specified nodata value to output bands"
 msgstr ""
-#: ../raster/r.carve/main.c:148
-#, c-format
-msgid "Invalid depth value '%s' - using default."
+#: ../raster/r.out.gdal/main.c:235
+#: ../locale/scriptstrings/t.rast.export_to_translate.c:18
+msgid ""
+"If given, the nodata value is always written to metadata even if there are "
+"no NULL cells in the input band (enhances output compatibility)."
 msgstr ""
-#: ../raster/r.carve/lobf.c:74
-msgid "trying to divide by zero...no unique solution for system...skipping..."
+#: ../raster/r.out.gdal/main.c:248
+msgid "Number of overviews to create for the output dataset"
 msgstr ""
-#: ../raster/r.carve/enforce_ds.c:83
-msgid "Processing lines... "
+#: ../raster/r.out.gdal/main.c:278
+#, c-format
+msgid "Raster map or group <%s> not found"
 msgstr ""
-#: ../raster/r.carve/enforce_ds.c:175
-msgid "Vect runs out of region and re-enters - this case is not yet implemented."
+#: ../raster/r.out.gdal/main.c:282
+#, c-format
+msgid "No raster maps in group <%s>"
 msgstr ""
-#: ../raster/r.rescale/main.c:51
-msgid "Rescales the range of category values in a raster map layer."
+#: ../raster/r.out.gdal/main.c:296
+#, c-format
+msgid "Unable to get <%s> driver"
 msgstr ""
-#: ../raster/r.rescale/main.c:110
+#: ../raster/r.out.gdal/main.c:302
 #, c-format
-msgid "Rescale %s[%ld,%ld] to %s[%ld,%ld]"
+msgid ""
+"Driver <%s> does not support direct writing. Using MEM driver for "
+"intermediate dataset."
 msgstr ""
-#: ../raster/r.gwflow/main.c:57
-msgid "Name of input raster map with initial piezometric head in [m]"
+#: ../raster/r.out.gdal/main.c:307
+msgid "Unable to get in-memory raster driver"
 msgstr ""
-#: ../raster/r.gwflow/main.c:62
-msgid "Name of input raster map providing boundary condition status: 0-inactive, 1-active, 2-dirichlet"
+#: ../raster/r.out.gdal/main.c:311
+#, c-format
+msgid "Driver <%s> does not support creating rasters"
 msgstr ""
-#: ../raster/r.gwflow/main.c:67
-msgid "Name of input raster map with x-part of the hydraulic conductivity tensor in [m/s]"
+#: ../raster/r.out.gdal/main.c:386
+#, c-format
+msgid "Could not read data range of raster <%s>"
 msgstr ""
-#: ../raster/r.gwflow/main.c:72
-msgid "Name of input raster map with y-part of the hydraulic conductivity tensor in [m/s]"
+#: ../raster/r.out.gdal/main.c:443
+#, c-format
+msgid "Exporting to GDAL data type: %s"
 msgstr ""
-#: ../raster/r.gwflow/main.c:77
-msgid "Name of input raster map with water sources and sinks in [m^3/s]"
+#: ../raster/r.out.gdal/main.c:458
+msgid "Raster export would result in complete data loss, aborting."
 msgstr ""
-#: ../raster/r.gwflow/main.c:81
-msgid "Name of input raster map with storativity for confined or effective porosity for unconfined groundwater flow booth in [-] "
+#: ../raster/r.out.gdal/main.c:469
+#, c-format
+msgid ""
+"Precision loss: Raster map <%s> of type %s to be exported as %s. This can be "
+"avoided by using %s."
 msgstr ""
-#: ../raster/r.gwflow/main.c:86
-msgid "Recharge"
+#: ../raster/r.out.gdal/main.c:480
+#, c-format
+msgid ""
+"Precision loss: The range of <%s> can not be accurately preserved with GDAL "
+"datatype Float32. This can be avoided by exporting to Int32 or Float64."
 msgstr ""
-#: ../raster/r.gwflow/main.c:88
-msgid "Recharge input raster map e.g: 6*10^-9 per cell in [m^3/s*m^2]"
+#: ../raster/r.out.gdal/main.c:488
+#, c-format
+msgid ""
+"Precision loss: Float32 can not preserve the DCELL precision of raster <%s>. "
+"This can be avoided by using Float64"
 msgstr ""
-#: ../raster/r.gwflow/main.c:92
-msgid "Name of input raster map describing the top surface of the aquifer in [m]"
+#: ../raster/r.out.gdal/main.c:497
+msgid "Forcing raster export"
 msgstr ""
-#: ../raster/r.gwflow/main.c:96
-msgid "Name of input raster map describing the bottom surface of the aquifer in [m]"
+#: ../raster/r.out.gdal/main.c:499
+#, c-format
+msgid "Raster export aborted. To override data loss check, use the -%c flag"
 msgstr ""
-#: ../raster/r.gwflow/main.c:100
-msgid "Output raster map storing the numerical result [m]"
+#: ../raster/r.out.gdal/main.c:514 ../raster/r.out.gdal/main.c:543
+#: ../raster/r.out.gdal/main.c:547
+msgid "Raster export aborted."
 msgstr ""
-#: ../raster/r.gwflow/main.c:106
-msgid "Output raster map to store the groundwater filter velocity vector part in x direction [m/s]"
+#: ../raster/r.out.gdal/main.c:524
+msgid "Checking GDAL data type and nodata value..."
 msgstr ""
-#: ../raster/r.gwflow/main.c:112
-msgid "Output raster map to store the groundwater filter velocity vector part in y direction [m/s]"
+#: ../raster/r.out.gdal/main.c:527
+#, c-format
+msgid "Checking options for raster map <%s> (band %d)..."
 msgstr ""
-#: ../raster/r.gwflow/main.c:118
-msgid "Output raster map to store the groundwater budget for each cell [m^3/s]"
+#: ../raster/r.out.gdal/main.c:541
+msgid "Forcing raster export."
 msgstr ""
-#: ../raster/r.gwflow/main.c:126
-msgid "The type of groundwater flow"
+#: ../raster/r.out.gdal/main.c:572
+msgid "Unable to create dataset using memory raster driver"
 msgstr ""
-#: ../raster/r.gwflow/main.c:132
-msgid "Name of input raster map providing the height of the river bed in [m]"
+#: ../raster/r.out.gdal/main.c:581
+#, c-format
+msgid "Unable to create <%s> dataset using <%s> driver"
 msgstr ""
-#: ../raster/r.gwflow/main.c:140
-msgid "Name of input raster map providing the water level (head) of the river with leakage connection in [m]"
+#: ../raster/r.out.gdal/main.c:596
+msgid "Unable to set geo transform"
 msgstr ""
-#: ../raster/r.gwflow/main.c:147
-msgid "Name of input raster map providing the leakage coefficient of the river bed in [1/s]."
+#: ../raster/r.out.gdal/main.c:604
+msgid "Unable to set projection"
 msgstr ""
-#: ../raster/r.gwflow/main.c:155
-msgid "Name of input raster map providing the height of the drainage bed in [m]"
+#: ../raster/r.out.gdal/main.c:632
+#, c-format
+msgid "Exporting raster data to %s format..."
 msgstr ""
-#: ../raster/r.gwflow/main.c:162
-msgid "Name of input raster map providing the leakage coefficient of the drainage bed in [1/s]"
+#: ../raster/r.out.gdal/main.c:635
+#, c-format
+msgid "Exporting raster map <%s> (band %d)..."
 msgstr ""
-#: ../raster/r.gwflow/main.c:167
-msgid "The maximum number of iterations in the linearization approach"
+#: ../raster/r.out.gdal/main.c:648
+#, c-format
+msgid "Unable to export raster map <%s>"
 msgstr ""
-#: ../raster/r.gwflow/main.c:176
-msgid "Allocate a full quadratic linear equation system, default is a sparse linear equation system."
+#: ../raster/r.out.gdal/main.c:661
+#, fuzzy
+msgid "Number of overviews must be between 0 and 5"
+msgstr "Punktu skaitam jābūt lielākam par 0 (%d doti)"
+#: ../raster/r.out.gdal/main.c:668
+msgid "Building overviews ..."
 msgstr ""
-#: ../raster/r.gwflow/main.c:212
-msgid "Numerical calculation program for transient, confined and unconfined groundwater flow in two dimensions."
+#: ../raster/r.out.gdal/main.c:678
+#, fuzzy
+msgid "Unable to build overviews"
+msgstr "neiespējami atvērt <%s>"
+#: ../raster/r.out.gdal/main.c:689
+#, c-format
+msgid "Unable to create raster map <%s> using driver <%s>"
 msgstr ""
-#: ../raster/r.gwflow/main.c:237
-msgid "Please provide river_head, river_leak and river_bed maps"
+#: ../raster/r.out.gdal/main.c:712 ../raster/r.out.gdal/main.c:724
+#: ../raster/r.out.gdal/main.c:737 ../raster/r.out.gdal/main.c:750
+#: ../raster/r.out.gdal/main.c:762 ../raster/r.out.gdal/main.c:776
+#: ../raster/r.out.gdal/export_band.c:477
+#: ../raster/r.out.gdal/export_band.c:489
+#: ../raster/r.out.gdal/export_band.c:502
+#: ../raster/r.out.gdal/export_band.c:515
+#: ../raster/r.out.gdal/export_band.c:527
+#: ../raster/r.out.gdal/export_band.c:540
+#: ../raster/r.out.gdal/export_band.c:554
+msgid "Selected GDAL datatype does not cover data range."
 msgstr ""
-#: ../raster/r.gwflow/main.c:249
-msgid "Please provide drain_head and drain_leak maps"
+#: ../raster/r.out.gdal/main.c:713 ../raster/r.out.gdal/main.c:725
+#: ../raster/r.out.gdal/main.c:738 ../raster/r.out.gdal/main.c:751
+#: ../raster/r.out.gdal/export_band.c:478
+#: ../raster/r.out.gdal/export_band.c:490
+#: ../raster/r.out.gdal/export_band.c:503
+#: ../raster/r.out.gdal/export_band.c:516
+#, c-format
+msgid "GDAL datatype: %s, range: %d - %d"
 msgstr ""
-#: ../raster/r.gwflow/main.c:263
-msgid "The cholesky solver dos not work with sparse matrices. You may choose a full filled quadratic matrix, flag -f."
+#: ../raster/r.out.gdal/main.c:716 ../raster/r.out.gdal/main.c:728
+#: ../raster/r.out.gdal/main.c:741 ../raster/r.out.gdal/main.c:754
+#: ../raster/r.out.gdal/main.c:766 ../raster/r.out.gdal/main.c:780
+#, c-format
+msgid "Range to be exported: %g - %g"
 msgstr ""
-#: ../raster/r.gwflow/main.c:293
+#: ../raster/r.out.gdal/main.c:763 ../raster/r.out.gdal/export_band.c:528
 #, c-format
-msgid "Calculation time: %g"
+msgid "GDAL datatype: %s, range: %u - %u"
 msgstr ""
-#: ../raster/r.gwflow/main.c:380
+#: ../raster/r.out.gdal/main.c:777 ../raster/r.out.gdal/export_band.c:541
+#: ../raster/r.out.gdal/export_band.c:555
 #, c-format
-msgid "Calculation of unconfined groundwater flow loop %i"
+msgid "GDAL datatype: %s, range: %g - %g"
 msgstr ""
-#: ../raster/r.gwflow/main.c:403
+#: ../raster/r.out.gdal/main.c:804 ../raster/r.out.gdal/main.c:817
+#: ../raster/r.out.gdal/main.c:831 ../raster/r.out.gdal/main.c:844
+#: ../raster/r.out.gdal/main.c:859
 #, c-format
-msgid "Maximum difference between this and last increment: %g"
+msgid ""
+"Mismatch between metadata nodata value and actual nodata value in exported "
+"raster: specified nodata value %g gets converted to %d by selected GDAL "
+"datatype."
 msgstr ""
-#: ../raster/r.topmodel/file_io.c:56
+#: ../raster/r.out.gdal/main.c:807 ../raster/r.out.gdal/main.c:834
+#: ../raster/r.out.gdal/main.c:862
 #, c-format
-msgid "%s cannot be 0"
-msgstr "%s nevar būt 0"
+msgid "GDAL datatype: %s, valid range: %d - %d"
+msgstr ""
-#: ../raster/r.topmodel/file_io.c:209 ../raster/r.topmodel/topmodel.c:77
-#: ../vector/v.out.pov/main.c:104
+#: ../raster/r.out.gdal/main.c:820 ../raster/r.out.gdal/main.c:847
 #, c-format
-msgid "Unable to create output file <%s>"
+msgid "GDAL datatype: %s, valid range: %u - %u"
 msgstr ""
-#: ../raster/r.topmodel/main.c:55
-msgid "Simulates TOPMODEL which is a physically based hydrologic model."
+#: ../raster/r.out.gdal/main.c:873
+#, c-format
+msgid ""
+"raster: specified nodata value %g gets converted to %g by selected GDAL "
+"datatype."
 msgstr ""
-#: ../raster/r.topmodel/main.c:60
-msgid "Name of input TOPMODEL parameters file"
+#: ../raster/r.out.gdal/main.c:876
+#, c-format
+msgid "GDAL datatype: %s, valid range: %g - %g"
 msgstr ""
-#: ../raster/r.topmodel/main.c:65
-msgid "Name of input topographic index statistics file"
+#: ../raster/r.out.gdal/export_band.c:53 ../raster/r.out.gdal/export_band.c:359
+msgid "Unable to allocate buffer for reading raster map"
 msgstr ""
-#: ../raster/r.topmodel/main.c:69
-msgid "Name of input rainfall and potential evapotranspiration data file"
+#: ../raster/r.out.gdal/export_band.c:168
+#, c-format
+msgid "Using GDAL data type <%s>"
 msgstr ""
-#: ../raster/r.topmodel/main.c:76
-msgid "Time step"
+#: ../raster/r.out.gdal/export_band.c:173
+#, c-format
+msgid ""
+"Input raster map contains cells with NULL-value (no-data). The value %d will "
+"be used to represent no-data values in the input map. You can specify a "
+"nodata value with the %s option."
 msgstr ""
-#: ../raster/r.topmodel/main.c:77
-msgid "Generate output for this time step"
+#: ../raster/r.out.gdal/export_band.c:178
+#, c-format
+msgid ""
+"Input raster map contains cells with NULL-value (no-data). The value %g will "
 msgstr ""
-#: ../raster/r.topmodel/main.c:83
-msgid "Topographic index class"
+#: ../raster/r.out.gdal/export_band.c:188
+#, c-format
+msgid ""
+"The default nodata value is present in rasterband <%s> and would lead to "
+"data loss. Please specify a custom nodata value with the %s parameter."
 msgstr ""
-#: ../raster/r.topmodel/main.c:85
-msgid "Generate output for this topographic index class"
+#: ../raster/r.out.gdal/export_band.c:195
+#, c-format
+msgid ""
+"The user given nodata value %g is present in rasterband <%s> and would lead "
+"to data loss. Please specify a different nodata value with the %s parameter."
 msgstr ""
-#: ../raster/r.topmodel/main.c:92
-msgid "Name of input topographic index raster map"
+#: ../raster/r.out.gdal/export_band.c:240
+msgid "Unable to get raster band"
 msgstr ""
-#: ../raster/r.topmodel/main.c:94
-msgid "Must be clipped to the catchment boundary. Used for generating outtopidxstats"
+#: ../raster/r.out.gdal/export_band.c:396
+#: ../raster/r.out.gdal/export_band.c:425
+#: ../raster/r.out.gdal/export_band.c:454
+msgid "Unable to write GDAL raster file"
 msgstr ""
-#: ../raster/r.topmodel/main.c:96 ../raster/r.topmodel/main.c:106
-#: ../raster/r.topmodel/main.c:115
-msgid "Preprocess"
+#: ../raster/r.out.gdal/export_band.c:481
+#: ../raster/r.out.gdal/export_band.c:493
+#: ../raster/r.out.gdal/export_band.c:506
+#: ../raster/r.out.gdal/export_band.c:519
+#: ../raster/r.out.gdal/export_band.c:531
+#: ../raster/r.out.gdal/export_band.c:544
+#: ../raster/r.out.gdal/export_band.c:558
+#, c-format
+msgid "Raster map <%s> range: %g - %g"
 msgstr ""
-#: ../raster/r.topmodel/main.c:100
-msgid "Number of topographic index classes"
+#: ../raster/r.describe/main.c:57
+msgid "Prints terse list of category values found in a raster map layer."
 msgstr ""
-#: ../raster/r.topmodel/main.c:102
-msgid "Used for generating outtopidxstats"
+#: ../raster/r.describe/main.c:71
+msgid "Number of quantization steps"
 msgstr ""
-#: ../raster/r.topmodel/main.c:111
-msgid "Name for output topographic index statistics file"
+#: ../raster/r.describe/main.c:77
+msgid "Print the output one value per line"
 msgstr ""
-#: ../raster/r.topmodel/main.c:113
-msgid "Requires topidx and ntopidxclasses"
+#: ../raster/r.describe/main.c:81
+msgid "Only print the range of the data"
 msgstr ""
-#: ../raster/r.topmodel/main.c:120
-msgid "Preprocess only and stop after generating outtopidxstats"
+#: ../raster/r.describe/main.c:85
+msgid "Suppress reporting of any NULLs"
 msgstr ""
-#: ../raster/r.topmodel/main.c:150
-#, c-format
-msgid "%s must be greater than 1"
+#: ../raster/r.describe/main.c:89
+msgid "Use the current region"
 msgstr ""
-#: ../raster/r.topmodel/main.c:154 ../raster/r.topmodel/main.c:157
-#, c-format
-msgid "Ignoring %s because %s is not specified"
+#: ../raster/r.describe/main.c:93
+msgid "Read floating-point map as integer"
 msgstr ""
-#: ../raster/r.topmodel/topmodel.c:32
+#: ../raster/r.describe/main.c:105
 #, c-format
-msgid "Unable to run %s"
+msgid "%s = %s -- must be greater than zero"
 msgstr ""
-#: ../raster/r.topmodel/topmodel.c:74
+#: ../raster/r.describe/describe.c:94
 #, c-format
-msgid "Invalid %s output"
+msgid "Reading <%s> ..."
 msgstr ""
-#: ../raster/r.topmodel/infiltration.c:148
-#: ../raster/r.topmodel/infiltration.c:217
-#, fuzzy, c-format
-msgid "Maximum number of iterations exceeded at time step %d"
+#: ../raster/r.quantile/main.c:69
+msgid "Computing histogram"
 msgstr ""
-"\n"
-"\n"
-"  Punktu skaits: %d\n"
-#: ../raster/r.out.vtk/parameters.c:32
-msgid "Raster map(s) to be converted to VTK-ASCII data format"
+#: ../raster/r.quantile/main.c:270
+msgid "Compute quantiles using two passes."
 msgstr ""
-#: ../raster/r.out.vtk/parameters.c:53
-msgid "Constant elevation (if no elevation map is specified)"
+#: ../raster/r.quantile/main.c:303
+msgid "Generate recode rules based on quantile-defined intervals"
 msgstr ""
-#: ../raster/r.out.vtk/parameters.c:69
-msgid "Three (r,g,b) raster maps to create RGB values [redmap,greenmap,bluemap]"
+#: ../raster/r.quantile/main.c:337
+msgid "Too many quantiles"
 msgstr ""
-#: ../raster/r.out.vtk/parameters.c:79
-msgid "Three (x,y,z) raster maps to create vector values [xmap,ymap,zmap]"
+#: ../raster/r.neighbors/readweights.c:18
+#, c-format
+msgid "Unable to open weights file %s"
 msgstr ""
-#: ../raster/r.out.vtk/parameters.c:104
-msgid "Use structured grid for elevation (not recommended)"
+#: ../raster/r.neighbors/readweights.c:23
+#, c-format
+msgid "Error reading weights file %s"
 msgstr ""
-#: ../raster/r.out.vtk/parameters.c:110
-msgid "Use polydata-trianglestrips for elevation grid creation"
-msgstr ""
+#: ../raster/r.neighbors/main.c:102 ../raster/r.resamp.stats/main.c:301
+#: ../raster/r.series/main.c:104 ../raster3d/r3.neighbors/main.c:94
+#, c-format
+msgid "Unknown method <%s>"
+msgstr "Nezināma metode <%s>"
-#: ../raster/r.out.vtk/parameters.c:116
-msgid "Use polydata-vertices for elevation grid creation (to use with vtkDelauny2D)"
+#: ../raster/r.neighbors/main.c:121
+#, c-format
+msgid "Invalid out_type enumeration: %d"
 msgstr ""
-#: ../raster/r.out.vtk/parameters.c:122
-msgid "Scale factor affects the origin (if no elevation map is given)"
+#: ../raster/r.neighbors/main.c:171 ../raster3d/r3.neighbors/main.c:213
+msgid "neighbor"
 msgstr ""
-#: ../raster/r.out.vtk/writeascii.c:75
-msgid "write_vtk_normal_header: Writing VTK-Header"
+#: ../raster/r.neighbors/main.c:172 ../raster3d/r3.neighbors/main.c:214
+msgid "focal statistics"
 msgstr ""
-#: ../raster/r.out.vtk/writeascii.c:108
-msgid "write_vtk_structured_elevation_header: Writing VTK-Header"
+#: ../raster/r.neighbors/main.c:175
+msgid ""
+"Makes each cell category value a function of the category values assigned to "
+"the cells around it, and stores new cell values in an output raster map "
+"layer."
 msgstr ""
+"Šūnas jaunā vērtība būs kā funkcija no tai apkārt esošo šūnu vērtībām. Jaunā "
+"vērtība tiks saglabāta izvades rastra kartē."
-#: ../raster/r.out.vtk/writeascii.c:124
-msgid "write_vtk_polygonal_elevation_header: Writing VTK-Header"
+#: ../raster/r.neighbors/main.c:185
+msgid ""
+"Name of an input raster map to select the cells which should be processed"
 msgstr ""
-#: ../raster/r.out.vtk/writeascii.c:139
-msgid "write_vtk_celldata_header: Writing VTK-DataHeader"
+#: ../raster/r.neighbors/main.c:206 ../raster/r.neighbors/main.c:214
+#: ../raster/r.neighbors/main.c:249
+msgid "Neighborhood"
 msgstr ""
-#: ../raster/r.out.vtk/writeascii.c:148
-msgid "writeVTKPointHeader: Writing VTK-DataHeader"
+#: ../raster/r.neighbors/main.c:212
+#: ../locale/scriptstrings/t.rast.neighbors_to_translate.c:6
+msgid "Neighborhood size"
+msgstr "Apkārtnes izmērs šūnās"
+#: ../raster/r.neighbors/main.c:221 ../raster/r.clump/main.c:75
+#: ../raster/r.recode/main.c:67 ../raster/r.reclass/main.c:72
+msgid "Title for output raster map"
 msgstr ""
-#: ../raster/r.out.vtk/writeascii.c:169
-msgid "write_vtk_structured_coordinates: Writing Coordinates"
+#: ../raster/r.neighbors/main.c:226
+msgid "Text file containing weights"
 msgstr ""
-#: ../raster/r.out.vtk/writeascii.c:225
-msgid "write_vtk_polygonal_coordinates: Writing VTK Polygonal data"
+#: ../raster/r.neighbors/main.c:232
+msgid "Sigma (in cells) for Gaussian filter"
 msgstr ""
-#: ../raster/r.out.vtk/writeascii.c:334
-msgid "write_vtk_data: Writing VTK-Data"
+#: ../raster/r.neighbors/main.c:239 ../raster/r.resamp.stats/main.c:282
+#: ../raster/r.series/main.c:168
+#: ../locale/scriptstrings/t.rast.series_to_translate.c:8
+#: ../raster3d/r3.neighbors/main.c:127
+msgid "Quantile to calculate for method=quantile"
 msgstr ""
-#: ../raster/r.out.vtk/writeascii.c:384
-msgid "write_vtk_rgb_image_data: Writing VTK-ImageData"
+#: ../raster/r.neighbors/main.c:244
+msgid "Do not align output with the input"
 msgstr ""
-#: ../raster/r.out.vtk/writeascii.c:412
-msgid "Wrong map values! Values should in between 0 and 255!\n"
+#: ../raster/r.neighbors/main.c:248
+msgid "Use circular neighborhood"
 msgstr ""
-#: ../raster/r.out.vtk/writeascii.c:442
-msgid "write_vtk_vector_data: Writing VTK-vector data"
+#: ../raster/r.neighbors/main.c:256
+msgid "Neighborhood size must be positive"
 msgstr ""
-#: ../raster/r.out.vtk/main.c:62
-msgid "Converts raster maps into the VTK-ASCII format."
+#: ../raster/r.neighbors/main.c:258
+msgid "Neighborhood size must be odd"
 msgstr ""
-#: ../raster/r.out.vtk/main.c:73
-msgid "No input maps specified. You need to specify at least one input map or three vector maps or three rgb maps."
+#: ../raster/r.neighbors/main.c:293
+#, c-format
+msgid "%s= and %s= must have the same number of values"
 msgstr ""
-#: ../raster/r.out.vtk/main.c:131 ../raster/r.out.vtk/main.c:191
-#: ../raster/r.out.vtk/main.c:212 ../raster/r.out.vtk/main.c:251
+#: ../raster/r.neighbors/main.c:329
 #, c-format
-msgid "Open Raster file %s"
+msgid ""
+"Method %s not compatible with weighing window, using weight mask instead"
 msgstr ""
-#: ../raster/r.out.vtk/main.c:222
-msgid "Writing VTK ImageData\n"
+#: ../raster/r.neighbors/main.c:337
+#, c-format
+msgid ""
+"Method %s not compatible with Gaussian filter, using unweighed version "
+"instead"
 msgstr ""
-#: ../raster/r.out.vtk/main.c:232
-msgid "Wrong RGB maps. Maps should have the same type! RGB output not added!"
+#: ../raster/r.neighbors/main.c:386
+#, c-format
+msgid "Opening selection map <%s>"
 msgstr ""
-#: ../raster/r.out.vtk/main.c:261
-msgid "Writing VTK Vector Data\n"
+#: ../raster/r.mapcalc/expression.c:206
+#, c-format
+msgid "Undefined variable '%s'"
 msgstr ""
-#: ../raster/r.out.vtk/main.c:271
-msgid "Wrong vector maps. Maps should have the same type! Vector output not added!"
+#: ../raster/r.mapcalc/expression.c:221
+#, c-format
+msgid "Invalid map <%s>"
 msgstr ""
-#: ../raster/r.out.vtk/main.c:283
-msgid "Error closing VTK-ASCII file"
+#: ../raster/r.mapcalc/expression.c:262
+#, c-format
+msgid "Undefined function '%s'"
 msgstr ""
-#: ../raster/r.water.outlet/main.c:56
-msgid "Creates watershed basins from a drainage direction map."
+#: ../raster/r.mapcalc/expression.c:267
+#, c-format
+msgid "Too few arguments (%d) to function %s()"
 msgstr ""
-#: ../raster/r.water.outlet/main.c:62
-msgid "Name of input drainage direction map"
+#: ../raster/r.mapcalc/expression.c:271
+#, c-format
+msgid "Too many arguments (%d) to function %s()"
 msgstr ""
-#: ../raster/r.water.outlet/main.c:65
-msgid "Name for output watershed basin map"
+#: ../raster/r.mapcalc/expression.c:275
+#, c-format
+msgid "Incorrect argument types to function %s()"
 msgstr ""
-#: ../raster/r.water.outlet/main.c:68
-msgid "Coordinates of outlet point"
+#: ../raster/r.mapcalc/expression.c:278
+#, c-format
+msgid "Internal error for function %s()"
 msgstr ""
-#: ../raster/r.water.outlet/main.c:81
+#: ../raster/r.mapcalc/expression.c:357 ../raster/r.mapcalc/map3.c:240
+#: ../raster/r.mapcalc/map3.c:424 ../raster/r.mapcalc/map3.c:469
+#: ../raster/r.mapcalc/map3.c:566 ../raster/r.mapcalc/map.c:288
+#: ../raster/r.mapcalc/map.c:495 ../raster/r.mapcalc/map.c:536
+#: ../raster/r.mapcalc/map.c:634
 #, c-format
-msgid "Illegal east coordinate '%s'"
+msgid "Invalid map modifier: '%c'"
 msgstr ""
-#: ../raster/r.water.outlet/main.c:83
+#: ../raster/r.mapcalc/expression.c:453
 #, c-format
-msgid "Illegal north coordinate '%s'"
+msgid "Illegal number of arguments (%d) for operator '%s'"
 msgstr ""
-#: ../raster/r.water.outlet/main.c:88
+#: ../raster/r.mapcalc/expression.c:493
 #, c-format
-msgid "Ignoring point outside computation region: %.4f,%.4f"
+msgid "Format_expression_prec: unknown type: %d"
 msgstr ""
-#: ../raster/r.resamp.stats/main.c:264
-msgid "Resamples raster map layers to a coarser grid using aggregation."
+#: ../raster/r.mapcalc/main.c:72
+msgid "Raster map calculator."
 msgstr ""
-#: ../raster/r.resamp.stats/main.c:274
-msgid "Aggregation method"
+#: ../raster/r.mapcalc/main.c:79
+msgid "Expression to evaluate"
 msgstr ""
-#: ../raster/r.resamp.stats/main.c:292
-msgid "Weight according to area (slower)"
+#: ../raster/r.mapcalc/main.c:80 ../raster/r.mapcalc/main.c:99
+msgid "Expression"
+msgstr "Izteiksme"
+#: ../raster/r.mapcalc/main.c:88
+msgid ""
+"The computational region that should be used.\n"
+"               - current uses the current region of the mapset.\n"
+"               - intersect computes the intersection region between\n"
+"                 all input maps and uses the smallest resolution\n"
+"               - union computes the union extent of all map regions\n"
+"                 and uses the smallest resolution"
 msgstr ""
-#: ../raster/r.patch/main.c:62
-msgid "patching"
+#: ../raster/r.mapcalc/main.c:98
+msgid "File containing expression(s) to evaluate"
 msgstr ""
-#: ../raster/r.patch/main.c:64
-msgid "Creates a composite raster map layer by using known category values from one (or more) map layer(s) to fill in areas of \"no data\" in another map layer."
+#: ../raster/r.mapcalc/main.c:105
+msgid "Seed for rand() function"
 msgstr ""
-#: ../raster/r.patch/main.c:71
-msgid "Name of raster maps to be patched together"
+#: ../raster/r.mapcalc/main.c:109
+msgid "Generate random seed (result is non-deterministic)"
 msgstr ""
-#: ../raster/r.patch/main.c:74
-msgid "Name for resultant raster map"
+#: ../raster/r.mapcalc/main.c:113
+msgid "List input and output maps"
 msgstr ""
-#: ../raster/r.patch/main.c:81
-msgid "Use zero (0) for transparency instead of NULL"
+#: ../raster/r.mapcalc/main.c:135
+#, c-format
+msgid "%s= and -%c are mutually exclusive"
 msgstr ""
-#: ../raster/r.patch/main.c:86
-msgid "Do not create color and category files"
+#: ../raster/r.mapcalc/main.c:146
+msgid "parse error"
 msgstr ""
-#: ../raster/r.patch/main.c:101
-msgid "The minimum number of input raster maps is two"
+#: ../raster/r.mapcalc/main.c:185
+msgid "Floating point error(s) occurred in the calculation"
 msgstr ""
-#: ../raster/r.patch/main.c:178
+#: ../raster/r.mapcalc/function.c:35
 #, c-format
-msgid "Creating support files for raster map <%s>..."
+msgid "Known functions:"
 msgstr ""
-#: ../raster/r.watershed/shed/read.c:23
-msgid "unable to open basin/half basin map"
+#: ../raster/r.mapcalc/map3.c:182 ../raster/r.mapcalc/map.c:226
+#, c-format
+msgid "Unable to read color file for raster map <%s@%s>"
 msgstr ""
-#: ../raster/r.watershed/shed/main.c:41
-msgid "Slow version of water analysis program starting now"
+#: ../raster/r.mapcalc/map3.c:195 ../raster/r.mapcalc/map.c:239
+#, c-format
+msgid "Unable to create btree for raster map <%s@%s>"
 msgstr ""
-#: ../raster/r.watershed/shed/main.c:46 ../raster/r.watershed/shed/main.c:55
+#: ../raster/r.mapcalc/map3.c:354 ../raster/r.mapcalc/map.c:426
+#: ../raster/r.mapcalc/evaluate.c:143 ../raster/r.mapcalc/evaluate.c:283
 #, c-format
-msgid "<<%s>> command line failed"
+msgid "Unknown type: %d"
 msgstr ""
-#: ../raster/r.watershed/shed/main.c:72
-msgid "unable to open output file"
+#: ../raster/r.mapcalc/map3.c:373
+#, c-format
+msgid "Unable to close raster map <%s@%s>"
 msgstr ""
-#: ../raster/r.watershed/shed/valid.c:24
-msgid "accum file missing in valid_basins()"
+#: ../raster/r.mapcalc/map3.c:518 ../raster/r.random/random.c:43
+#: ../raster/r.random/random.c:47 ../imagery/i.landsat.acca/main.c:57
+#: ../imagery/i.landsat.acca/tools.c:126
+#: ../imagery/i.landsat.acca/algorithm.c:380
+#: ../imagery/i.landsat.toar/main.c:406 ../imagery/i.landsat.toar/main.c:544
+#, c-format
+msgid "Unable to open raster map <%s>"
 msgstr ""
-#: ../raster/r.watershed/shed/intro.c:8
+#: ../raster/r.mapcalc/map3.c:607 ../raster/r.sunhours/main.c:324
+#: ../raster/r.sunhours/main.c:335 ../raster/r.sunhours/main.c:346
+#: ../imagery/i.landsat.acca/tools.c:136
+#: ../imagery/i.landsat.acca/algorithm.c:234
+#: ../imagery/i.landsat.acca/algorithm.c:388
+#: ../imagery/i.landsat.toar/main.c:566
 #, c-format
-msgid "%s provides a text-based user-interface to the %s program."
+msgid "Unable to create raster map <%s>"
 msgstr ""
-#: ../raster/r.watershed/shed/intro.c:10
-#, c-format
-msgid "%s also allows the user to prepare a report of map layers for each"
+#: ../raster/r.mapcalc/map3.c:632
+msgid "Unable to close output raster map"
 msgstr ""
-#: ../raster/r.watershed/shed/intro.c:12
+#: ../raster/r.mapcalc/evaluate.c:189
 #, c-format
-msgid "watershed basin determined in %s.\n"
+msgid "Invalid type: %d"
 msgstr ""
-#: ../raster/r.watershed/shed/intro.c:14
+#: ../raster/r.mapcalc/evaluate.c:228
 #, c-format
-msgid "%s will help the user determine which options to use for the"
+msgid "Too few arguments for function '%s'"
 msgstr ""
-#: ../raster/r.watershed/shed/intro.c:16
+#: ../raster/r.mapcalc/evaluate.c:232
 #, c-format
-msgid "%s program.  %s will then ask for map layers that will be"
+msgid "Too many arguments for function '%s'"
 msgstr ""
-#: ../raster/r.watershed/shed/intro.c:18
+#: ../raster/r.mapcalc/evaluate.c:236
 #, c-format
-msgid "divided by basin. %s will then run %s and create the report."
+msgid "Invalid argument type for function '%s'"
 msgstr ""
-#: ../raster/r.watershed/shed/basin_maps.c:12
-msgid ""
-"\n"
-"\n"
-"Please indicate which map layers you wish to use in the lumped"
+#: ../raster/r.mapcalc/evaluate.c:240
+#, c-format
+msgid "Invalid return type for function '%s'"
 msgstr ""
-#: ../raster/r.watershed/shed/basin_maps.c:13
-msgid "parameter hydrologic/soil erosion model.  Continue inputing cell map"
+#: ../raster/r.mapcalc/evaluate.c:244
+#, c-format
+msgid "Unknown type for function '%s'"
 msgstr ""
-#: ../raster/r.watershed/shed/basin_maps.c:14
-msgid "layers, one at a time, until all desired map layers are in."
+#: ../raster/r.mapcalc/evaluate.c:247
+#, c-format
+msgid "Number of arguments for function '%s'"
 msgstr ""
-#: ../raster/r.watershed/shed/basin_maps.c:15
+#: ../raster/r.mapcalc/evaluate.c:251
 #, c-format
-msgid "You can have %s include a list of categories in each."
+msgid "Unknown error for function '%s'"
 msgstr ""
-#: ../raster/r.watershed/shed/basin_maps.c:17
+#: ../raster/r.mapcalc/evaluate.c:329
 #, c-format
-msgid ""
-"\n"
-"Hit <return> at the map prompt to continue with %s"
+msgid "output map <%s> exists. To overwrite, use the --overwrite flag"
 msgstr ""
-#: ../raster/r.watershed/shed/basin_maps.c:36
-#, c-format
-msgid ""
-"\n"
-"The output from %s will be divided into watershed"
+#: ../raster/r.in.lidar/point_binning.c:205 ../raster/r.in.xyz/main.c:483
+msgid "Unable to calculate percentile without the pth option specified!"
 msgstr ""
-#: ../raster/r.watershed/shed/basin_maps.c:38
-msgid "basins.  There are two possible methods of tabulating the information:"
+#: ../raster/r.in.lidar/point_binning.c:217 ../raster/r.in.xyz/main.c:495
+msgid "Unable to calculate trimmed mean without the trim option specified!"
 msgstr ""
-#: ../raster/r.watershed/shed/basin_maps.c:39
-msgid "1) by only including data pertaining to the basin itself, or 2) using"
+#: ../raster/r.in.lidar/rast_segment.c:40
+#: ../raster3d/r3.in.lidar/rast_segment.c:53
+msgid "Cannot create temporary file with segments of a raster map"
 msgstr ""
-#: ../raster/r.watershed/shed/basin_maps.c:40
-msgid "data from the basin, and all basins upstream of it."
+#: ../raster/r.in.lidar/main.c:114 ../raster/r.in.xyz/main.c:163
+#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:9
+#: ../raster3d/r3.in.lidar/main.c:168
+msgid "binning"
 msgstr ""
-#: ../raster/r.watershed/shed/basin_maps.c:43
-msgid ""
-"\n"
-"Would you like the data organized:"
+#: ../raster/r.in.lidar/main.c:116
+msgid "Creates a raster map from LAS LiDAR points using univariate statistics."
 msgstr ""
-#: ../raster/r.watershed/shed/basin_maps.c:44
-msgid ""
-"1) Basin only\n"
-"2) Upstream only\n"
-"3) Both\n"
-"OR 0) to cancel program"
+#: ../raster/r.in.lidar/main.c:130 ../raster3d/r3.in.lidar/main.c:181
+msgid "File containing names of LAS input files"
 msgstr ""
-#: ../raster/r.watershed/shed/basin_maps.c:45
-#, c-format
-msgid ""
-"\n"
-"Your choice: "
+#: ../raster/r.in.lidar/main.c:139 ../raster/r.in.xyz/main.c:179
+#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:15
+msgid "Statistic to use for raster values"
 msgstr ""
-#: ../raster/r.watershed/shed/basin_maps.c:69
-#: ../raster/r.watershed/shed/basin_maps.c:73
-#, c-format
-msgid ""
-"\n"
-"OK, %s should start running now using the following form:\n"
-"%s"
+#: ../raster/r.in.lidar/main.c:143 ../raster/r.in.lidar/main.c:235
+#: ../raster/r.in.lidar/main.c:245 ../raster/r.in.xyz/main.c:183
+#: ../raster/r.in.xyz/main.c:315 ../raster/r.in.xyz/main.c:324
+#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:16
+#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:32
+#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:34
+msgid "Statistic"
 msgstr ""
-#: ../raster/r.watershed/shed/file_in.c:15
-msgid "unable to open ARMSED file"
+#: ../raster/r.in.lidar/main.c:158 ../raster/r.in.xyz/main.c:198
+msgid "Number of points in cell"
 msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:23
-msgid ""
-"\n"
-"This set of questions will organize the command line for the"
+#: ../raster/r.in.lidar/main.c:159 ../raster/r.in.xyz/main.c:199
+msgid "Minimum value of point values in cell"
 msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:24
-#, c-format
-msgid "%s program to run properly for your application."
+#: ../raster/r.in.lidar/main.c:160 ../raster/r.in.xyz/main.c:200
+msgid "Maximum value of point values in cell"
 msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:26
-#, c-format
-msgid "The first question is whether you want %s to run"
+#: ../raster/r.in.lidar/main.c:161 ../raster/r.in.xyz/main.c:201
+msgid "Range of point values in cell"
 msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:28
-#, c-format
-msgid "in its fast mode or its slow mode.  If you run %s"
+#: ../raster/r.in.lidar/main.c:162 ../raster/r.in.xyz/main.c:202
+msgid "Sum of point values in cell"
 msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:30
-msgid "in the fast mode, the computer will finish about 10 times faster"
+#: ../raster/r.in.lidar/main.c:163 ../raster/r.in.xyz/main.c:203
+msgid "Mean (average) value of point values in cell"
 msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:31
-msgid "than in the slow mode, but will not allow other programs to run"
+#: ../raster/r.in.lidar/main.c:164 ../raster/r.in.xyz/main.c:204
+msgid "Standard deviation of point values in cell"
 msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:32
-msgid "at the same time.  The fast mode also places all of the data into"
+#: ../raster/r.in.lidar/main.c:165 ../raster/r.in.xyz/main.c:205
+msgid "Variance of point values in cell"
 msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:33
-msgid "RAM, which limits the size of window that can be run.  The slow"
+#: ../raster/r.in.lidar/main.c:166 ../raster/r.in.xyz/main.c:206
+msgid "Coefficient of variance of point values in cell"
 msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:34
-msgid "mode uses disk space in the same hard disk partition as where GRASS is"
+#: ../raster/r.in.lidar/main.c:167 ../raster/r.in.xyz/main.c:207
+msgid "Median value of point values in cell"
 msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:35
-msgid "stored.  Thus, if the program does not work in the slow mode, you will"
+#: ../raster/r.in.lidar/main.c:168
+msgid "pth (nth) percentile of point values in cell"
 msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:36
-msgid "need to remove unnecessary files from that partition.  The slow mode"
+#: ../raster/r.in.lidar/main.c:169 ../raster/r.in.xyz/main.c:209
+msgid "Skewness of point values in cell"
 msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:37
-#, c-format
-msgid "will allow other processes to run concurrently with %s.\n"
+#: ../raster/r.in.lidar/main.c:170 ../raster/r.in.xyz/main.c:210
+msgid "Trimmed mean of point values in cell"
 msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:69
-#: ../raster/r.watershed/shed/com_line.c:182
+#: ../raster/r.in.lidar/main.c:180
+msgid "Subtract raster values from the Z coordinates"
+msgstr ""
+#: ../raster/r.in.lidar/main.c:182
 msgid ""
-"\n"
-"If you hit <return> by itself for the next question, this"
+"The scale for Z is applied beforehand, the range filter for Z afterwards"
 msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:70
-#: ../raster/r.watershed/shed/com_line.c:183
-msgid "program will terminate."
+#: ../raster/r.in.lidar/main.c:184 ../raster/r.in.lidar/main.c:201
+#: ../raster/r.in.lidar/main.c:217 ../raster/r.in.lidar/main.c:333
+#: ../raster3d/r3.in.lidar/main.c:251 ../raster3d/r3.in.lidar/main.c:264
+#: ../raster3d/r3.in.lidar/main.c:280
+msgid "Transform"
 msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:81
-#, c-format
-msgid ""
-"\n"
-"One of the options for %s is a `depression map'.  A"
+#: ../raster/r.in.lidar/main.c:191
+msgid "Filter range for Z data (min,max)"
 msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:83
-msgid "depression map indicates all the locations in the current map window where"
+#: ../raster/r.in.lidar/main.c:192
+#, fuzzy
+msgid "Applied after base_raster transformation step"
+msgstr "Vienu koordinātu pāri uz līniju, lūdzu"
+#: ../raster/r.in.lidar/main.c:200 ../raster3d/r3.in.lidar/main.c:263
+msgid "Scale to apply to Z data"
 msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:84
-msgid "water accumulates and does not leave by the edge of the map. Lakes without"
+#: ../raster/r.in.lidar/main.c:208 ../raster3d/r3.in.lidar/main.c:271
+msgid "Filter range for intensity values (min,max)"
 msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:85
-msgid "outlet streams and sinkholes are examples of `depressions'.  If you wish to"
+#: ../raster/r.in.lidar/main.c:216 ../raster3d/r3.in.lidar/main.c:279
+msgid "Scale to apply to intensity values"
 msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:86
-msgid "have a depression map, prepare a map where non-zero values indicate the"
+#: ../raster/r.in.lidar/main.c:225 ../raster/r.in.xyz/main.c:305
+#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:30
+msgid "Percent of map to keep in memory"
 msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:87
-msgid "locations where depressions occur.\n"
+#: ../raster/r.in.lidar/main.c:234
+#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:31
+msgid "pth percentile of the values"
 msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:88
-msgid "Hit <return> by itself for the next question if there is no depression map."
+#: ../raster/r.in.lidar/main.c:242
+msgid "Discard given percentage of the smallest and largest values"
 msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:99
-#, c-format
+#: ../raster/r.in.lidar/main.c:244 ../raster/r.in.xyz/main.c:323
+#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:33
 msgid ""
-"\n"
-"The %s program will divide the elevation map into a number of"
+"Discard <trim> percent of the smallest and <trim> percent of the largest "
+"observations"
 msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:101
-msgid "watershed basins.  The number of watershed basins is indirectly determined"
+#: ../raster/r.in.lidar/main.c:252
+msgid "Output raster resolution"
 msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:102
-msgid "by the `basin threshold' value.  The basin threshold is the area necessary for"
+#: ../raster/r.in.lidar/main.c:282
+msgid "Use the extent of the input for the raster extent"
 msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:103
-#, c-format
-msgid "%s to define a unique watershed basin.  This area only applies to"
+#: ../raster/r.in.lidar/main.c:284
+msgid "Set internally computational region extents based on the point cloud"
 msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:105
-msgid "`exterior drainage basins'.  An exterior drainage basin does not have any"
+#: ../raster/r.in.lidar/main.c:291
+msgid "Set computation region to match the new raster map"
 msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:106
-msgid "drainage basins flowing into it.  Interior drainage basin size is determined"
+#: ../raster/r.in.lidar/main.c:293
+msgid ""
+"Set computation region to match the 2D extent and resolution of the newly "
+"created new raster map"
 msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:107
-msgid "by the surface flow going into stream segments between stream interceptions."
+#: ../raster/r.in.lidar/main.c:306 ../raster/r.in.xyz/main.c:328
+#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:10
+#: ../raster3d/r3.in.lidar/main.c:303
+msgid "Scan data file for extent then exit"
 msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:108
-#, c-format
-msgid "Thus interior drainage basins can be of any size.  The %s program"
+#: ../raster/r.in.lidar/main.c:311 ../raster/r.in.xyz/main.c:335
+#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:11
+#: ../raster3d/r3.in.lidar/main.c:307
+msgid "In scan mode, print using shell script style"
 msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:110
-msgid "also allows the user to relate basin size to potential overland flow"
+#: ../raster/r.in.lidar/main.c:316
+msgid "Use intensity values rather than Z values"
 msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:111
-msgid "(i.e., areas with low infiltration capacities will need smaller areas to"
+#: ../raster/r.in.lidar/main.c:318
+msgid "Uses intensity values everywhere as if they would be Z coordinates"
 msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:112
-msgid "develop stream channels than neighboring areas with high infiltration rates)."
+#: ../raster/r.in.lidar/main.c:324
+msgid "Use Z values for filtering, but intensity values for statistics"
 msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:113
-msgid "The user can create a map layer with potential overland flow values, and"
+#: ../raster/r.in.lidar/main.c:329
+msgid "Use base raster resolution instead of computational region"
 msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:114
-#, c-format
-msgid "%s will accumulate those values instead of area.\n"
+#: ../raster/r.in.lidar/main.c:331
+msgid ""
+"For getting values from base raster, use its actual resolution instead of "
+"computational region resolution"
 msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:116
-msgid "What unit of measure will you use for the basin threshold:"
+#: ../raster/r.in.lidar/main.c:359
+#, c-format
+msgid "Flag %c makes sense only with %s option or -%c flag"
 msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:119
-msgid " 1) acres,          2) meters sq., 3) miles sq., 4) hectares,"
+#: ../raster/r.in.lidar/main.c:369 ../raster3d/r3.in.lidar/main.c:340
+#, c-format
+msgid "File <%s> does not exist"
 msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:120
-msgid " 5) kilometers sq., 6) map cells,  7) overland flow units"
+#: ../raster/r.in.lidar/main.c:386
+msgid "zrange will not be taken into account during scan"
 msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:121
+#: ../raster/r.in.lidar/main.c:403 ../raster3d/r3.in.lidar/main.c:378
 #, c-format
-msgid "Choose 1-7 or 0 to exit this program: "
+msgid "Unable to open file <%s> as a LiDAR point cloud"
 msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:131
+#: ../raster/r.in.lidar/main.c:423 ../raster3d/r3.in.lidar/main.c:398
 msgid ""
-"\n"
-"How large an area (or how many overland flow units) must a drainage basin"
+"First file's projection checked, checking projection of the other files..."
 msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:132
+#: ../raster/r.in.lidar/main.c:461
 #, c-format
-msgid "be for it to be an exterior drainage basin: "
+msgid "Unknown filter option <%s>"
 msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:201
-#, c-format
-msgid ""
-"\n"
-"%s must create a map layer of watershed basins"
+#: ../raster/r.in.lidar/main.c:479 ../raster/r.in.xyz/main.c:383
+msgid "Invalid zrange"
 msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:203
-#: ../raster/r.watershed/shed/com_line.c:224
+#: ../raster/r.in.lidar/main.c:493
 #, c-format
-msgid "before %s can run properly."
+msgid "Invalid %s"
 msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:222
+#: ../raster/r.in.lidar/main.c:525 ../general/g.region/main.c:815
 #, c-format
-msgid ""
-"\n"
-"%s must create a file of watershed basin relationships"
+msgid "Invalid input <%s=%s>"
 msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:228
-#: ../raster/r.watershed/shed/com_line.c:263
+#: ../raster/r.in.lidar/main.c:528
 #, c-format
-msgid ""
-"\n"
-"Please name this file:"
+msgid "Option '%s' must be > 0.0"
 msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:257
+#: ../raster/r.in.lidar/main.c:596
 #, c-format
 msgid ""
-"\n"
-"%s will generate a lot of output.  Indicate a file"
+"Unable to process the hole map at once. Please set the '%s' option to some "
+"value lower than 100."
 msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:259
+#: ../raster/r.in.lidar/main.c:616
 #, c-format
-msgid "name for %s to send the output to."
+msgid "Pass #%d (of %d)..."
 msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:277
+#: ../raster/r.in.lidar/main.c:778
 #, c-format
-msgid ""
-"\n"
-"The accumulation map from %s must be present for"
+msgid "%lu points found in input file(s)"
 msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:279
+#: ../raster/r.in.lidar/main.c:798
 #, c-format
-msgid "%s to work properly."
+msgid "%lu input points were invalid and filtered out"
 msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:290
+#: ../raster/r.in.lidar/main.c:801
 #, c-format
-msgid ""
-"\n"
-"%s can produce several maps not necessary for"
+msgid "%lu input points were invalid, use -%c flag to filter them out"
 msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:292
+#: ../raster/r.in.lidar/main.c:804
 #, c-format
-msgid "%s to function (stream channels, overland flow aspect, and"
+msgid "Raster map <%s> created. %lu points from %d files found in region."
 msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:294
+#: ../raster/r.in.lidar/main.c:809
 #, c-format
-msgid "a display version of the accumulation map).  %s also has the"
+msgid "Raster map <%s> created. %lu points found in region."
 msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:296
-msgid "ability to generate several variables in the Revised Universal Soil Loss"
+#: ../raster/r.in.lidar/info.c:108 ../raster/r.in.xyz/main.c:1203
+#: ../raster3d/r3.in.lidar/info.c:109
+msgid "Scanning data ..."
 msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:297
-msgid "Equation (Rusle): Slope Length (LS), and Slope Steepness (S).\n"
+#: ../raster/r.in.lidar/info.c:148 ../raster/r.in.xyz/main.c:1309
+#: ../raster3d/r3.in.lidar/info.c:149
+#, c-format
+msgid "Range:     min         max\n"
 msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:348
-msgid ""
-"\n"
-"The Slope Length factor (LS) and Slope Steepness (S) are influenced by"
+#: ../raster/r.in.lidar/string_list.c:34
+#: ../raster3d/r3.in.lidar/string_list.c:47
+#, c-format
+msgid "Cannot open file %s for reading"
 msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:349
-#, c-format
-msgid "disturbed land.  %s reflects this with an optional map layer or value"
+#: ../raster/r.rescale/main.c:49 ../raster/r.rescale.eq/main.c:53
+msgid "rescale"
 msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:351
-msgid "where the value indicates the percent of disturbed (barren) land in that cell."
+#: ../raster/r.rescale/main.c:51
+msgid "Rescales the range of category values in a raster map layer."
 msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:352
-msgid "Type <return> if you do not have a disturbed land map layer."
+#: ../raster/r.rescale/main.c:56 ../raster/r.rescale.eq/main.c:61
+msgid "The name of the raster map to be rescaled"
 msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:364
-msgid ""
-"\n"
-"Type the value indicating the percent of disturbed land.  This value will"
+#: ../raster/r.rescale/main.c:64 ../raster/r.rescale.eq/main.c:69
+msgid "The input data range to be rescaled (default: full range of input map)"
 msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:365
-msgid "be used for every cell in the current region."
+#: ../raster/r.rescale/main.c:67 ../raster/r.rescale.eq/main.c:72
+msgid "The resulting raster map name"
 msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:368
-#, c-format
-msgid ""
-"\n"
-"Input value here [0-100]: "
+#: ../raster/r.rescale/main.c:74 ../raster/r.rescale.eq/main.c:79
+msgid "The output data range"
 msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:379
-msgid ""
-"\n"
-"Overland surface flow only occurs for a set distance before swales form."
+#: ../raster/r.rescale/main.c:81 ../raster/r.rescale.eq/main.c:86
+msgid "Title for new raster map"
 msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:380
+#: ../raster/r.rescale/main.c:110
 #, c-format
-msgid "Because of digital terrain model limitations, %s cannot pick up"
+msgid "Rescale %s[%ld,%ld] to %s[%ld,%ld]"
 msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:382
+#: ../raster/r.rescale/get_range.c:24 ../raster/r.rescale.eq/get_stats.c:19
 #, c-format
-msgid "these swales.  %s allows for an input (warning: kludge factor)"
+msgid "Reading %s ..."
+msgstr "Lasa %s ..."
+#: ../raster/r.surf.random/main.c:40
+msgid ""
+"Produces a raster surface map of uniform random deviates with defined range."
 msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:384
-msgid "that prevents the surface flow distance from getting too long.  Normally,"
+#: ../raster/r.surf.random/main.c:46
+msgid "Minimum random value"
 msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:385
-msgid "maximum slope length is around 600 feet (about 183 meters)."
+#: ../raster/r.surf.random/main.c:52
+msgid "Maximum random value"
 msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:400
-msgid ""
-"\n"
-"Roads, ditches, changes in ground cover, and other factors will stop"
+#: ../raster/r.surf.random/main.c:58
+msgid "Create an integer raster map"
 msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:401
-msgid "slope length.  You may input a raster map indicating the locations of these"
+#: ../raster/r.to.rast3/main.c:79
+msgid "2D raster maps which represent the slices"
 msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:402
-msgid "blocking factors.\n"
+#: ../raster/r.to.rast3/main.c:93
+msgid "Use 3D raster mask (if exists) with output map"
 msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:403
-msgid "Hit <return> by itself for the next question if there is no blocking map."
+#: ../raster/r.to.rast3/main.c:201
+msgid "Converts 2D raster map slices to one 3D raster volume map."
 msgstr ""
-#: ../raster/r.watershed/ram/sg_factor.c:14
-msgid "SECTION 4: RUSLE LS and/or S factor determination."
+#: ../raster/r.to.rast3/main.c:213
+msgid "No output map"
 msgstr ""
-#: ../raster/r.watershed/ram/usage.c:9 ../raster/r.watershed/seg/usage.c:9
-#, c-format
+#: ../raster/r.to.rast3/main.c:230
 msgid ""
-"USAGE for basin delineation:\n"
-"%s -4 elevation=elevation_map threshold=swale_threshold [flow=overland_flow_map] [drainage=drain_direction_map] [depression=depression_map] [accumulation=accumulation_map] [basin=watershed_basin_map] [stream=stream_segment_map]\n"
-"\n"
-"USAGE for slope length determination:\n"
-"%s [-4] elevation=elevation_map threshold=swale_threshold [drainage=drain_direction_map] [depression=depression_map] [accumulation=accumulation_map] [max_slope_length=max_slope_length] [blocking=overland_blocking_map] [slope_steepness=slope_steepness_map] length_slope=length_slope_map [disturbed_land=rill_erosion_map] [slope_deposition=slope_deposition value or map]USAGE for ARMSED FILE creation:\n"
-"%s [-4] elevation=elevation_map threshold=swale_threshold [flow=overland_flow_map] [drainage=drain_direction_map] [depression=depression_map] [accumulation=accumulation_map] [basin=watershed_basin_map] [stream=stream_segment_map] [half_basin=half_basin_map] ar=ARMSED_file_name\n"
-"\n"
+"The 2D and 3D region settings are different. Using the 3D region settings to "
+"adjust the 2D region."
 msgstr ""
-#: ../raster/r.watershed/ram/do_cum.c:114
-#: ../raster/r.watershed/seg/do_cum.c:119
-msgid "SECTION 3: Accumulating Surface Flow with SFD."
+#: ../raster/r.to.rast3/main.c:262
+#, c-format
+msgid "Open raster map %s - one time for each depth (%d/%d)"
 msgstr ""
-#: ../raster/r.watershed/ram/do_cum.c:276
-#: ../raster/r.watershed/seg/do_cum.c:293
-msgid "SECTION 3a: Accumulating Surface Flow with MFD."
+#: ../raster/r.to.rast3/main.c:275
+msgid "Input maps have to be from the same type. CELL, FCELL or DCELL!"
 msgstr ""
-#: ../raster/r.watershed/ram/do_cum.c:480
+#: ../raster/r.contour/cont.c:82
 #, c-format
-msgid "MFD: A * path already processed when distributing flow: %d of %d cell"
-msgid_plural "MFD: A * path already processed when distributing flow: %d of %d cells"
+msgid "Writing vector contour (one level)..."
+msgid_plural "Writing vector contours (total levels %d)..."
 msgstr[0] ""
 msgstr[1] ""
 msgstr[2] ""
-#: ../raster/r.watershed/ram/do_cum.c:486
-#: ../raster/r.watershed/seg/do_cum.c:533
-msgid "SECTION 3b: Adjusting drainage directions."
-msgstr ""
-#: ../raster/r.watershed/ram/close_maps2.c:34
-#: ../raster/r.watershed/seg/close_maps2.c:38
-msgid "No basins were created. Verify threshold and region settings."
-msgstr ""
-#: ../raster/r.watershed/ram/main.c:82 ../raster/r.watershed/ram/main.c:98
-#: ../raster/r.watershed/seg/main.c:92 ../raster/r.watershed/seg/main.c:107
+#: ../raster/r.contour/cont.c:213
 #, c-format
-msgid "SECTION %d: Closing Maps."
-msgstr ""
+msgid "%d crossing found"
+msgid_plural "%d crossings found"
+msgstr[0] ""
+msgstr[1] ""
+msgstr[2] ""
-#: ../raster/r.watershed/ram/main.c:96 ../raster/r.watershed/seg/main.c:105
-#, c-format
-msgid "SECTION %d: Watershed determination."
+#: ../raster/r.contour/cont.c:266
+msgid "Illegal edge number"
 msgstr ""
-#: ../raster/r.watershed/ram/init_vars.c:121
-#, c-format
-msgid "SECTION 1a (of %1d): Initiating Memory."
+#: ../raster/r.contour/cont.c:374
+msgid "Edge number out of range"
 msgstr ""
-#: ../raster/r.watershed/ram/init_vars.c:311
-#, c-format
-msgid "SECTION 1b (of %1d): Determining Offmap Flow."
+#: ../raster/r.contour/main.c:89
+msgid "contours"
 msgstr ""
-#: ../raster/r.watershed/ram/do_astar.c:27
-#: ../raster/r.watershed/seg/do_astar.c:30
-msgid "SECTION 2: A* Search."
+#: ../raster/r.contour/main.c:91
+msgid "Produces a vector map of specified contours from a raster map."
 msgstr ""
-#: ../raster/r.watershed/ram/do_astar.c:256
-msgid "heapsize too large"
+#: ../raster/r.contour/main.c:101
+#: ../locale/scriptstrings/t.rast.contour_to_translate.c:10
+msgid "Increment between contour levels"
 msgstr ""
-#: ../raster/r.watershed/ram/do_flatarea.c:56
-msgid "Beautify flat areas: priority queue error"
+#: ../raster/r.contour/main.c:102 ../raster/r.contour/main.c:110
+#: ../raster/r.contour/main.c:117 ../raster/r.contour/main.c:124
+msgid "Contour levels"
 msgstr ""
-#: ../raster/r.watershed/ram/do_flatarea.c:229
-msgid "flat cell escaped for uphill correction"
+#: ../raster/r.contour/main.c:109
+#: ../locale/scriptstrings/t.rast.contour_to_translate.c:11
+msgid "List of contour levels"
 msgstr ""
-#: ../raster/r.watershed/ram/do_flatarea.c:235
-#, c-format
-msgid "queue error: last uphill order %d > current uphill order %d"
+#: ../raster/r.contour/main.c:116
+#: ../locale/scriptstrings/t.rast.contour_to_translate.c:12
+msgid "Minimum contour level"
 msgstr ""
-#: ../raster/r.watershed/ram/do_flatarea.c:240
-msgid "uphill order not set"
+#: ../raster/r.contour/main.c:123
+#: ../locale/scriptstrings/t.rast.contour_to_translate.c:13
+msgid "Maximum contour level"
 msgstr ""
-#: ../raster/r.watershed/ram/do_flatarea.c:266
-msgid "flat cell escaped in uphill correction"
+#: ../raster/r.contour/main.c:132
+#: ../locale/scriptstrings/t.rast.contour_to_translate.c:14
+msgid "Minimum number of points for a contour line (0 -> no limit)"
 msgstr ""
-#: ../raster/r.watershed/ram/do_flatarea.c:302
-msgid "downhill order: no more points in down queue"
+#: ../raster/r.contour/main.c:140
+#, c-format
+msgid "Neither <%s> nor <%s> option must be specified"
 msgstr ""
-#: ../raster/r.watershed/ram/do_flatarea.c:310
-msgid "flat cell escaped for downhill correction"
+#: ../raster/r.contour/main.c:149 ../raster/r.stats/main.c:331
+#, c-format
+msgid "Unable to read fp range of raster map <%s>"
 msgstr ""
-#: ../raster/r.watershed/ram/do_flatarea.c:316
+#: ../raster/r.contour/main.c:263
 #, c-format
-msgid "queue error: last downhill order %d > current downhill order %d"
+msgid "Range of data: min=%f, max=%f"
 msgstr ""
-#: ../raster/r.watershed/ram/do_flatarea.c:321
-msgid "downhill order: downhill order not set"
+#: ../raster/r.contour/main.c:265
+msgid "Range of data: empty"
 msgstr ""
-#: ../raster/r.watershed/ram/do_flatarea.c:344
-msgid "flat cell escaped in downhill correction"
+#: ../raster/r.contour/main.c:293 ../raster/r.contour/main.c:296
+msgid "This step value is not allowed"
 msgstr ""
-#: ../raster/r.watershed/ram/do_flatarea.c:382
-msgid "flat cell escaped for adjustment"
+#: ../raster/r.contour/main.c:321
+#, c-format
+msgid "Range of levels: min = %f, max = %f"
 msgstr ""
-#: ../raster/r.watershed/ram/do_flatarea.c:389
-msgid "adjustment: uphill order not set"
+#: ../raster/r.contour/main.c:350
+msgid "Displacing data..."
 msgstr ""
-#: ../raster/r.watershed/ram/do_flatarea.c:391
-msgid "adjustment: downhill order not set"
+#: ../raster/r.tile/main.c:44
+#: ../locale/scriptstrings/r.tileset_to_translate.c:3
+#: ../raster3d/r3.retile/main.c:97
+msgid "tiling"
 msgstr ""
-#: ../raster/r.watershed/ram/do_flatarea.c:417
-msgid "flat cell escaped in adjustment"
+#: ../raster/r.tile/main.c:46
+msgid "Splits a raster map into tiles."
 msgstr ""
-#: ../raster/r.watershed/seg/sg_factor.c:14
-msgid "SECTION 5: RUSLE LS and/or S factor determination."
+#: ../raster/r.tile/main.c:55
+msgid "Output base name"
 msgstr ""
-#: ../raster/r.watershed/seg/do_cum.c:529
-msgid "MFD: A * path already processed when distributing flow: %d of %"
+#: ../raster/r.tile/main.c:62
+msgid "Width of tiles (columns)"
 msgstr ""
-#: ../raster/r.watershed/seg/close_maps2.c:86
-msgid "Closing stream segments map"
+#: ../raster/r.tile/main.c:69
+msgid "Height of tiles (rows)"
 msgstr ""
-#: ../raster/r.watershed/seg/close_maps2.c:109
-msgid "Closing basins map"
+#: ../raster/r.tile/main.c:76
+msgid "Overlap of tiles"
 msgstr ""
-#: ../raster/r.watershed/seg/close_maps2.c:116
-msgid "Closing half basins map"
+#: ../raster/r.tile/main.c:129
+#, c-format
+msgid "Generating %d x %d = %d tiles..."
 msgstr ""
-#: ../raster/r.watershed/seg/init_vars.c:139
+#: ../raster/r.tile/main.c:184
 #, c-format
-msgid "SECTION 1 beginning: Initiating Variables. %d section total."
-msgid_plural "SECTION 1 beginning: Initiating Variables. %d sections total."
-msgstr[0] ""
-msgstr[1] ""
-msgstr[2] ""
-#: ../raster/r.watershed/seg/init_vars.c:175
-msgid "Maximum memory to be used was smaller than 3 MB, set to 3 MB."
+msgid "Unable to read cats for %s"
 msgstr ""
-#: ../raster/r.watershed/seg/init_vars.c:470
-msgid "SECTION 1b: Determining Offmap Flow."
+#: ../raster/r.surf.gauss/main.c:42
+msgid "Generates a raster map using gaussian random number generator."
 msgstr ""
-#: ../raster/r.watershed/seg/do_astar.c:48
-msgid "No seeds for A* Search"
+#: ../raster/r.surf.gauss/main.c:44
+msgid ""
+"Mean and standard deviation of gaussian deviates can be expressed by the "
+"user."
 msgstr ""
-#: ../raster/r.watershed/seg/do_astar.c:146
-msgid "bug in A* Search: doer %"
+#: ../raster/r.surf.gauss/main.c:51
+msgid "Distribution mean"
 msgstr ""
-#: ../raster/r.watershed/seg/close_maps.c:20
-msgid "Closing accumulation map"
+#: ../raster/r.surf.gauss/main.c:57
+msgid "Standard deviation"
 msgstr ""
-#: ../raster/r.watershed/seg/close_maps.c:136
-msgid "Closing TCI and SPI maps"
+#: ../raster/r.spreadpath/main.c:92
+msgid ""
+"Recursively traces the least cost path backwards to cells from which the "
+"cumulative cost was determined."
 msgstr ""
-#: ../raster/r.watershed/seg/close_maps.c:138
-msgid "Closing TCI map"
+#: ../raster/r.spreadpath/main.c:98
+msgid "Name of raster map containing back-path easting information"
 msgstr ""
-#: ../raster/r.watershed/seg/close_maps.c:140
-msgid "Closing SPI map"
+#: ../raster/r.spreadpath/main.c:103
+msgid "Name of raster map containing back-path northing information"
 msgstr ""
-#: ../raster/r.watershed/seg/close_maps.c:300
-msgid "Closing flow direction map"
+#: ../raster/r.spreadpath/main.c:108
+msgid "The map E and N grid coordinates of starting points"
 msgstr ""
-#: ../raster/r.watershed/seg/close_maps.c:327
-msgid "Closing LS map"
+#: ../raster/r.spreadpath/main.c:161
+#, c-format
+msgid "eading the input map -%s- and -%s- and creating some temporary files..."
 msgstr ""
-#: ../raster/r.watershed/seg/close_maps.c:332
-msgid "Closing SL map"
+#: ../raster/r.spreadpath/main.c:281
+msgid "Finding the least cost paths ..."
 msgstr ""
-#: ../raster/r.watershed/front/main.c:76
-msgid "Calculates hydrological parameters and RUSLE factors."
+#: ../raster/r.spreadpath/main.c:296
+#, c-format
+msgid "Writing the output map  -%s-..."
 msgstr ""
-#: ../raster/r.watershed/front/main.c:79 ../raster/r.watershed/front/main.c:86
-#: ../raster/r.watershed/front/main.c:92 ../raster/r.watershed/front/main.c:99
-#: ../raster/r.watershed/front/main.c:108
-#: ../raster/r.watershed/front/main.c:116
-#: ../raster/r.watershed/front/main.c:125
-msgid "Inputs"
-msgstr ""
+#: ../raster/r.out.mat/main.c:64
+msgid "Exports a GRASS raster to a binary MAT-File."
+msgstr "Eksportē GRASS rastru uz bināro MAT-Failu"
-#: ../raster/r.watershed/front/main.c:83
-msgid "Name of input depressions raster map"
+#: ../raster/r.out.mat/main.c:73
+msgid "Name for output binary MAT file"
 msgstr ""
-#: ../raster/r.watershed/front/main.c:84
-msgid "All non-NULL and non-zero cells are considered as real depressions"
+#: ../raster/r.out.mat/main.c:113
+#, c-format
+msgid "Exporting <%s>"
 msgstr ""
-#: ../raster/r.watershed/front/main.c:90
-msgid "Name of input raster representing amount of overland flow per cell"
+#: ../raster/r.out.mat/main.c:173
+msgid "Using the Current Region settings:"
 msgstr ""
-#: ../raster/r.watershed/front/main.c:96
-msgid "Name of input raster map percent of disturbed land"
+#: ../raster/r.out.mat/main.c:248
+msgid "Exporting raster as integer values"
 msgstr ""
-#: ../raster/r.watershed/front/main.c:97 ../raster/r.watershed/front/main.c:122
-msgid "For USLE"
+#: ../raster/r.out.mat/main.c:253
+msgid "Exporting raster as floating point values"
 msgstr ""
-#: ../raster/r.watershed/front/main.c:104
-msgid "Name of input raster map blocking overland surface flow"
+#: ../raster/r.out.mat/main.c:258
+msgid "Exporting raster as double FP values"
 msgstr ""
-#: ../raster/r.watershed/front/main.c:106
-msgid "For USLE. All non-NULL and non-zero cells are considered as blocking terrain."
+#: ../raster/r.out.mat/main.c:301
+msgid "Reading in map ... "
 msgstr ""
-#: ../raster/r.watershed/front/main.c:113
-msgid "Minimum size of exterior watershed basin"
+#: ../raster/r.out.mat/main.c:314
+msgid "Writing out map..."
 msgstr ""
-#: ../raster/r.watershed/front/main.c:121
-msgid "Maximum length of surface flow in map units"
+#: ../raster/r.out.mat/main.c:374
+#, c-format
+msgid "%ld bytes written to '%s'"
 msgstr ""
-#: ../raster/r.watershed/front/main.c:130
-msgid "Name for output accumulation raster map"
+#: ../raster/r.what.color/main.c:91
+msgid "Queries colors for a raster map layer."
 msgstr ""
-#: ../raster/r.watershed/front/main.c:132
-msgid "Number of cells that drain through each cell"
+#: ../raster/r.what.color/main.c:99
+msgid "Name of existing raster map to query colors"
 msgstr ""
-#: ../raster/r.watershed/front/main.c:139
-msgid "Name for output topographic index ln(a / tan(b)) map"
+#: ../raster/r.what.color/main.c:106
+msgid "Values to query colors for"
 msgstr ""
-#: ../raster/r.watershed/front/main.c:146
-msgid "Stream power index a * tan(b)"
+#: ../raster/r.what.color/main.c:113
+msgid "Output format (printf-style)"
 msgstr ""
-#: ../raster/r.watershed/front/main.c:152
-msgid "Name for output drainage direction raster map"
+#: ../raster/r.what.color/main.c:117
+msgid "Read values from stdin"
 msgstr ""
-#: ../raster/r.watershed/front/main.c:158
-msgid "Name for output basins raster map"
+#: ../raster/r.what.color/main.c:123
+msgid "Either \"-i\" or \"value=\" must be given"
 msgstr ""
-#: ../raster/r.watershed/front/main.c:164
-msgid "Name for output stream segments raster map"
+#: ../raster/r.in.gridatb/main.c:48
+msgid "Imports GRIDATB.FOR map file (TOPMODEL) into a GRASS raster map."
 msgstr ""
-#: ../raster/r.watershed/front/main.c:170
-msgid "Name for output half basins raster map"
+#: ../raster/r.in.gridatb/main.c:51
+msgid "GRIDATB i/o map file"
 msgstr ""
-#: ../raster/r.watershed/front/main.c:172
-msgid "Each half-basin is given a unique value"
+#: ../raster/r.in.gridatb/main.c:68
+#, c-format
+msgid "File not found: %s"
 msgstr ""
-#: ../raster/r.watershed/front/main.c:178
-msgid "Name for output slope length raster map"
+#: ../raster/r.in.gridatb/file_io.c:35
+msgid "Setting window header failed"
 msgstr ""
-#: ../raster/r.watershed/front/main.c:180
-msgid "Slope length and steepness (LS) factor for USLE"
+#: ../raster/r.in.gridatb/file_io.c:38
+msgid "Rows changed"
 msgstr ""
-#: ../raster/r.watershed/front/main.c:186
-msgid "Name for output slope steepness raster map"
+#: ../raster/r.in.gridatb/file_io.c:41
+msgid "Cols changed"
 msgstr ""
-#: ../raster/r.watershed/front/main.c:187
-msgid "Slope steepness (S) factor for USLE"
+#: ../raster/r.resamp.stats/main.c:264
+msgid "Resamples raster map layers to a coarser grid using aggregation."
 msgstr ""
-#: ../raster/r.watershed/front/main.c:196
-msgid "Convergence factor for MFD (1-10)"
+#: ../raster/r.resamp.stats/main.c:274
+msgid "Aggregation method"
 msgstr ""
-#: ../raster/r.watershed/front/main.c:198
-msgid "1 = most diverging flow, 10 = most converging flow. Recommended: 5"
+#: ../raster/r.resamp.stats/main.c:292
+msgid "Weight according to area (slower)"
 msgstr ""
-#: ../raster/r.watershed/front/main.c:205
-msgid "Maximum memory to be used with -m flag (in MB)"
+#: ../raster/r.water.outlet/main.c:56
+msgid "Creates watershed basins from a drainage direction map."
 msgstr ""
-#: ../raster/r.watershed/front/main.c:209
-msgid "SFD (D8) flow (default is MFD)"
+#: ../raster/r.water.outlet/main.c:59 ../raster/r.watershed/front/main.c:75
+#: ../raster/r.basins.fill/main.c:56
+msgid "watershed"
 msgstr ""
-#: ../raster/r.watershed/front/main.c:211
-msgid "SFD: single flow direction, MFD: multiple flow direction"
+#: ../raster/r.water.outlet/main.c:62
+msgid "Name of input drainage direction map"
 msgstr ""
-#: ../raster/r.watershed/front/main.c:216
-msgid "Allow only horizontal and vertical flow of water"
-msgstr "Atļaut tikai horizontālu un vertikālu ūdens plūsmu"
-#: ../raster/r.watershed/front/main.c:221
-msgid "Enable disk swap memory option: Operation is slow"
+#: ../raster/r.water.outlet/main.c:65
+msgid "Name for output watershed basin map"
 msgstr ""
-#: ../raster/r.watershed/front/main.c:223
-msgid "Only needed if memory requirements exceed available RAM; see manual on how to calculate memory requirements"
+#: ../raster/r.water.outlet/main.c:68
+msgid "Coordinates of outlet point"
 msgstr ""
-#: ../raster/r.watershed/front/main.c:228
-msgid "Use positive flow accumulation even for likely underestimates"
+#: ../raster/r.water.outlet/main.c:81
+#, c-format
+msgid "Illegal east coordinate '%s'"
 msgstr ""
-#: ../raster/r.watershed/front/main.c:230
-msgid "See manual for a detailed description of flow accumulation output"
+#: ../raster/r.water.outlet/main.c:83
+#, c-format
+msgid "Illegal north coordinate '%s'"
 msgstr ""
-#: ../raster/r.watershed/front/main.c:235
-msgid "Beautify flat areas"
+#: ../raster/r.water.outlet/main.c:88
+#, c-format
+msgid "Ignoring point outside computation region: %.4f,%.4f"
 msgstr ""
-#: ../raster/r.watershed/front/main.c:237
-msgid "Flow direction in flat areas is modified to look prettier"
+#: ../raster/r.surf.contour/main.c:64
+msgid "Generates surface raster map from rasterized contours."
 msgstr ""
-#: ../raster/r.watershed/front/main.c:253
-msgid "Sorry, you must choose an output map."
-msgstr "Piedodiet, jums ir jāizvēlas izvades karte."
-#: ../raster/r.watershed/front/main.c:259
-msgid "The basin threshold must be a positive number."
+#: ../raster/r.surf.contour/main.c:67
+msgid "Name of input raster map containing contours"
 msgstr ""
-#: ../raster/r.watershed/front/main.c:275
+#: ../raster/r.resamp.rst/main.c:151
 msgid ""
-"Sorry, if any of the following options are set:\n"
-"    basin, stream, half_basin, length_slope, or slope_steepness\n"
-"    you MUST provide a value for the basin threshold parameter."
+"Reinterpolates and optionally computes topographic analysis from input "
+"raster map to a new raster map (possibly with different resolution) using "
+"regularized spline with tension and smoothing."
 msgstr ""
-#: ../raster/r.watershed/front/main.c:302
-msgid "Beautify flat areas is not yet supported for disk swap mode"
-msgstr ""
+#: ../raster/r.resamp.rst/main.c:162
+msgid "Desired east-west resolution"
+msgstr "Vēlamā austrumi-rietumi izšķirtspēja"
-#: ../raster/r.watershed/front/main.c:332
-#, c-format
-msgid "Subprocess failed with exit code %d"
-msgstr ""
+#: ../raster/r.resamp.rst/main.c:168
+msgid "Desired north-south resolution"
+msgstr "Vēlamā ziemeļi-dienvidi izšķirtspēja"
-#: ../raster/r.usler/main.c:54
-msgid "rainfall"
-msgstr "lietus"
-#: ../raster/r.usler/main.c:57
-msgid "Computes USLE R factor, Rainfall erosivity index."
+#: ../raster/r.resamp.rst/main.c:173
+msgid "Name for output elevation raster map"
 msgstr ""
-#: ../raster/r.usler/main.c:60
-msgid "Name of annual precipitation raster map [mm/year]"
+#: ../raster/r.resamp.rst/main.c:179
+msgid "Name for output slope map (or fx)"
 msgstr ""
-#: ../raster/r.usler/main.c:63
-msgid "Name for output USLE R raster map [MJ.mm/ha.hr.year]"
+#: ../raster/r.resamp.rst/main.c:185
+msgid "Name for output aspect map (or fy)"
 msgstr ""
-#: ../raster/r.usler/main.c:70
-msgid "Name of USLE R equation"
+#: ../raster/r.resamp.rst/main.c:191
+msgid "Name for output profile curvature map (or fxx)"
 msgstr ""
-#: ../raster/r.usler/main.c:75
-msgid "Roosle (1975)"
+#: ../raster/r.resamp.rst/main.c:197
+msgid "Name for output tangential curvature map (or fyy)"
 msgstr ""
-#: ../raster/r.usler/main.c:76
-msgid "Morgan (1974)"
+#: ../raster/r.resamp.rst/main.c:203
+msgid "Name for output mean curvature map (or fxy)"
 msgstr ""
-#: ../raster/r.usler/main.c:77
-msgid "Foster (1981)"
+#: ../raster/r.resamp.rst/main.c:209
+msgid "Name of input raster map containing smoothing"
 msgstr ""
-#: ../raster/r.usler/main.c:78
-msgid "El-Swaify (1985)"
+#: ../raster/r.resamp.rst/main.c:215
+msgid "Name of input raster map to be used as mask"
 msgstr ""
-#: ../display/d.his/main.c:69
-msgid "Displays the result obtained by combining hue, intensity, and saturation (HIS) values from user-specified input raster map layers."
+#: ../raster/r.resamp.rst/main.c:223
+msgid "Rows/columns overlap for segmentation"
 msgstr ""
-#: ../display/d.his/main.c:97
-msgid "Percent to brighten intensity channel"
+#: ../raster/r.resamp.rst/main.c:231
+msgid "Multiplier for z-values"
 msgstr ""
-#: ../display/d.his/main.c:103
-msgid "Respect NULL values while drawing"
-msgstr "Ņemt vērā NULL vērtības zīmēšanas laikā"
-#: ../display/d.colortable/main.c:64
-msgid "Displays the color table associated with a raster map layer."
+#: ../raster/r.resamp.rst/main.c:239
+msgid "Spline tension value"
 msgstr ""
-#: ../display/d.colortable/main.c:68
-msgid "Name of raster map whose color table is to be displayed"
+#: ../raster/r.resamp.rst/main.c:247 ../raster/r.resamp.rst/main.c:254
+msgid "Anisotropy"
 msgstr ""
-#: ../display/d.colortable/main.c:73
-msgid "Color of lines separating the colors of the color table"
+#: ../raster/r.resamp.rst/main.c:258
+msgid "Use dnorm independent tension"
 msgstr ""
-#: ../display/d.colortable/main.c:79
-msgid "Number of lines to appear in the color table"
+#: ../raster/r.resamp.rst/main.c:297
+msgid "Unable to read ew_res value"
 msgstr ""
-#: ../display/d.colortable/main.c:85
-msgid "Number of columns to appear in the color table"
+#: ../raster/r.resamp.rst/main.c:300
+msgid "Unable to read ns_res value"
 msgstr ""
-#: ../display/d.colortable/main.c:90
-msgid "Do not draw a collar showing the NULL color in FP maps"
+#: ../raster/r.resamp.rst/main.c:303
+msgid "Invalid value for tension"
 msgstr ""
-#: ../display/d.colortable/main.c:112
-#, c-format
-msgid "<%s> is floating-point; ignoring [lines] and drawing continuous color ramp"
+#: ../raster/r.resamp.rst/main.c:306
+msgid "Invalid value for zmult"
 msgstr ""
-#: ../display/d.colortable/main.c:126
-#, c-format
-msgid "<%s> is floating-point; ignoring [cols] and drawing continuous color ramp"
+#: ../raster/r.resamp.rst/main.c:309
+msgid "Invalid value for overlap"
 msgstr ""
-#: ../display/d.colortable/main.c:137
-#, c-format
-msgid "Range file for <%s> not available"
+#: ../raster/r.resamp.rst/main.c:313
+msgid "Invalid value for theta"
 msgstr ""
-#: ../display/d.labels/do_labels.c:142
-#, c-format
-msgid "Error: %s\n"
-msgstr "Kļūda: %s\n"
-#: ../display/d.labels/main.c:44 ../vector/v.label.sa/main.c:39
-#: ../vector/v.label/main.c:60
-msgid "paint labels"
+#: ../raster/r.resamp.rst/main.c:317
+msgid "Invalid value for scalex"
 msgstr ""
-#: ../display/d.labels/main.c:46
-msgid "Displays text labels (created with v.label) to the active frame on the graphics monitor."
+#: ../raster/r.resamp.rst/main.c:319
+msgid "When using anisotropy both theta and scalex must be specified"
 msgstr ""
-#: ../display/d.labels/main.c:52
-msgid "Ignore rotation setting and draw horizontally"
+#: ../raster/r.resamp.rst/main.c:357
+#, c-format
+msgid "Map <%s> is the wrong resolution"
 msgstr ""
-#: ../display/d.labels/main.c:59
-msgid "Name of label file"
+#: ../raster/r.resamp.rst/main.c:365
+msgid "Smoothing values can not be negative or NULL"
 msgstr ""
-#: ../display/d.labels/main.c:66
-msgid "Minimum region size (diagonal) when labels are displayed"
+#: ../raster/r.resamp.rst/main.c:371
+msgid "Input map resolution differs from current region resolution!"
 msgstr ""
-#: ../display/d.labels/main.c:73
-msgid "Maximum region size (diagonal) when labels are displayed"
+#: ../raster/r.resamp.rst/main.c:387
+msgid "Processing all selected output files will require"
 msgstr ""
-#: ../display/d.labels/main.c:85
+#: ../raster/r.resamp.rst/main.c:391
 #, c-format
-msgid "Label file <%s> not found"
+msgid "%.2f GB of disk space for temp files."
 msgstr ""
-#: ../display/d.labels/main.c:97
-msgid "Region size is lower than minreg, nothing displayed."
+#: ../raster/r.resamp.rst/main.c:394
+#, c-format
+msgid "%.2f MB of disk space for temp files."
 msgstr ""
-#: ../display/d.labels/main.c:105
-msgid "Region size is greater than maxreg, nothing displayed."
+#: ../raster/r.resamp.rst/main.c:397
+#, c-format
+msgid "%.2f KB of disk space for temp files."
 msgstr ""
-#: ../display/d.labels/main.c:114 ../vector/v.lrs/v.lrs.label/main.c:283
+#: ../raster/r.resamp.rst/main.c:400
 #, c-format
-msgid "Unable to open label file <%s>"
-msgstr ""
+msgid "%d byte of disk space for temp files."
+msgid_plural "%d bytes of disk space for temp files."
+msgstr[0] ""
+msgstr[1] ""
+msgstr[2] ""
-#: ../display/d.rast.arrow/main.c:98 ../display/d.rast.num/main.c:78
-msgid "map annotations"
+#: ../raster/r.resamp.rst/main.c:436
+msgid "Maximum value of a raster map is NULL."
 msgstr ""
-#: ../display/d.rast.arrow/main.c:101
-msgid "Draws arrows representing cell aspect direction for a raster map containing aspect data."
+#: ../raster/r.resamp.rst/main.c:464
+msgid "Temporarily changing the region to desired resolution ..."
 msgstr ""
-#: ../display/d.rast.arrow/main.c:105
-msgid "Name of raster aspect map to be displayed"
+#: ../raster/r.resamp.rst/main.c:469
+msgid "Changing back to the original region ..."
 msgstr ""
-#: ../display/d.rast.arrow/main.c:113
-msgid "Type of existing raster aspect map"
-msgstr ""
+#: ../raster/r.resamp.rst/main.c:478 ../raster/r.resample/main.c:112
+msgid "Percent complete: "
+msgstr "Pabeigts: "
-#: ../display/d.rast.arrow/main.c:118
-msgid "Color for drawing arrows"
+#: ../raster/r.resamp.rst/main.c:490
+#, c-format
+msgid "dnorm in mainc after grid before out1= %f"
 msgstr ""
-#: ../display/d.rast.arrow/main.c:124
-msgid "Color for drawing drawing grid"
+#: ../raster/r.resamp.rst/main.c:494
+msgid "split_and_interpolate() failed"
 msgstr ""
-#: ../display/d.rast.arrow/main.c:130
-msgid "Color for drawing null values (X symbol)"
+#: ../raster/r.resamp.rst/main.c:509
+#, c-format
+msgid "dnorm in mainc after grid before out2= %f"
 msgstr ""
-#: ../display/d.rast.arrow/main.c:136
-msgid "Color for showing unknown information (? symbol)"
+#: ../raster/r.resamp.rst/main.c:515
+msgid "Unable to write raster maps -- try increasing cell size"
 msgstr ""
-#: ../display/d.rast.arrow/main.c:144
-msgid "Draw arrow every Nth grid cell"
+#: ../raster/r.composite/main.c:73
+#: ../locale/scriptstrings/r.blend_to_translate.c:3
+msgid "composite"
 msgstr ""
-#: ../display/d.rast.arrow/main.c:153
-msgid "Raster map containing values used for arrow length"
+#: ../raster/r.composite/main.c:76
+msgid ""
+"Combines red, green and blue raster maps into a single composite raster map."
 msgstr ""
-#: ../display/d.rast.arrow/main.c:160
-msgid "Scale factor for arrows (magnitude map)"
+#: ../raster/r.composite/main.c:102
+msgid "Number of levels to be used for each component"
 msgstr ""
-#: ../display/d.rast.arrow/main.c:164 ../display/d.rast.num/main.c:108
-msgid "Align grids with raster cells"
+#: ../raster/r.composite/main.c:103 ../raster/r.composite/main.c:121
+msgid "Levels"
 msgstr ""
-#: ../display/d.rast.arrow/main.c:210
-msgid "Illegal value for scale factor"
-msgstr ""
+#: ../raster/r.composite/main.c:118
+#, c-format
+msgid "Number of levels to be used for <%s>"
+msgstr "Izmantojamo līmeņu skaits priekš <%s>"
-#: ../display/d.rast.arrow/main.c:214
-msgid "Illegal value for skip factor"
+#: ../raster/r.composite/main.c:128
+msgid "Dither"
 msgstr ""
-#: ../display/d.rast.arrow/main.c:219
-msgid "Magnitude is only supported for GRASS and compass aspect maps."
+#: ../raster/r.composite/main.c:132
+msgid "Use closest color"
 msgstr ""
-#: ../display/d.rast.arrow/main.c:224
-msgid "Scale option requires magnitude_map"
+#: ../raster/r.composite/main.c:164
+#, c-format
+msgid "Unable to read color file of raster map <%s>"
 msgstr ""
-#: ../display/d.rast.arrow/main.c:275
-msgid "Problem reading range file"
+#: ../raster/r.composite/main.c:286
+msgid "Creating color table for output raster map..."
 msgstr ""
-#: ../display/d.geodesic/main.c:48
-msgid "great circle"
+#: ../raster/r.in.xyz/main.c:167
+msgid ""
+"Creates a raster map from an assemblage of many coordinates using univariate "
+"statistics."
 msgstr ""
-#: ../display/d.geodesic/main.c:49 ../display/d.path/main.c:50
-#: ../vector/v.net.distance/main.c:68 ../vector/v.net.timetable/main.c:262
-#: ../vector/v.net.allpairs/main.c:63 ../vector/v.net.path/main.c:44
-#: ../vector/v.net.visibility/main.c:47
-msgid "shortest path"
-msgstr "īsākais ceļš"
-#: ../display/d.geodesic/main.c:51
-msgid "Displays a geodesic line, tracing the shortest distance between two geographic points along a great circle, in a longitude/latitude data set."
+#: ../raster/r.in.xyz/main.c:171
+msgid "ASCII file containing input data (or \"-\" to read from stdin)"
 msgstr ""
-#: ../display/d.geodesic/main.c:58 ../display/d.rhumbline/main.c:53
-#: ../display/d.path/main.c:65
-msgid "Starting and ending coordinates"
+#: ../raster/r.in.xyz/main.c:208
+msgid "Pth (nth) percentile of point values in cell"
 msgstr ""
-#: ../display/d.geodesic/main.c:62 ../display/d.rhumbline/main.c:57
-#: ../display/d.northarrow/main.c:103
-msgid "Line color"
-msgstr "Līnijas krāsa"
-#: ../display/d.geodesic/main.c:66 ../display/d.rast.num/main.c:88
-#: ../display/d.legend/main.c:203 ../display/d.rhumbline/main.c:62
-#: ../display/d.grid/main.c:107 ../display/d.northarrow/main.c:113
-#: ../vector/v.lrs/v.lrs.label/main.c:193 ../vector/v.label.sa/main.c:98
-#: ../vector/v.label/main.c:151
-msgid "Text color"
-msgstr "Teksta krāsa"
-#: ../display/d.geodesic/main.c:78 ../display/d.rhumbline/main.c:75
-#, c-format
-msgid "Location is not %s"
+#: ../raster/r.in.xyz/main.c:221
+#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:19
+msgid "Column number of x coordinates in input file (first column is 1)"
 msgstr ""
-#: ../display/d.geodesic/main.c:87 ../display/d.rhumbline/main.c:86
-#: ../display/d.path/main.c:140
-msgid "No coordinates given"
+#: ../raster/r.in.xyz/main.c:229
+#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:21
+msgid "Column number of y coordinates in input file"
 msgstr ""
-#: ../display/d.geodesic/main.c:90 ../display/d.geodesic/main.c:93
-#: ../display/d.geodesic/main.c:96 ../display/d.geodesic/main.c:99
-#: ../display/d.rhumbline/main.c:89 ../display/d.rhumbline/main.c:92
-#: ../display/d.rhumbline/main.c:95 ../display/d.rhumbline/main.c:98
-#, c-format
-msgid "%s - illegal longitude"
+#: ../raster/r.in.xyz/main.c:237
+#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:25
+msgid "Column number of data values in input file"
 msgstr ""
-#: ../display/d.mon/select.c:14
-#, c-format
-msgid "Monitor <%s> is already selected"
+#: ../raster/r.in.xyz/main.c:239
+msgid ""
+"If a separate value column is given, this option refers to the z-coordinate "
+"column to be filtered by the zrange option"
 msgstr ""
-#: ../display/d.mon/select.c:30 ../display/d.mon/stop.c:18
-#, c-format
-msgid "Monitor <%s> is not running"
+#: ../raster/r.in.xyz/main.c:250
+msgid "Number of header lines to skip at top of input file"
 msgstr ""
-#: ../display/d.mon/main.c:41
-msgid "Controls graphics display monitors from the command line."
+#: ../raster/r.in.xyz/main.c:259 ../raster/r.in.xyz/main.c:267
+#: ../raster/r.in.xyz/main.c:276 ../raster/r.in.xyz/main.c:284
+#: ../raster/r.in.xyz/main.c:292
+msgid "Advanced Input"
 msgstr ""
-#: ../display/d.mon/main.c:46
-msgid "Name of monitor to start"
+#: ../raster/r.in.xyz/main.c:266
+msgid "Scale to apply to z data"
 msgstr ""
-#: ../display/d.mon/main.c:48 ../display/d.mon/main.c:55
-#: ../display/d.mon/main.c:62 ../display/d.mon/main.c:123
-#: ../display/d.mon/main.c:128
-msgid "Manage"
+#: ../raster/r.in.xyz/main.c:274
+msgid "Alternate column number of data values in input file"
 msgstr ""
-#: ../display/d.mon/main.c:53
-msgid "Name of monitor to stop"
+#: ../raster/r.in.xyz/main.c:275
+msgid "If not given (or set to 0) the z-column data is used"
 msgstr ""
-#: ../display/d.mon/main.c:60
-msgid "Name of monitor to select"
+#: ../raster/r.in.xyz/main.c:283
+msgid "Filter range for alternate value column data (min,max)"
 msgstr ""
-#: ../display/d.mon/main.c:66
-msgid "Width for display monitor if not set by GRASS_RENDER_WIDTH"
+#: ../raster/r.in.xyz/main.c:291
+msgid "Scale to apply to alternate value column data"
 msgstr ""
-#: ../display/d.mon/main.c:67
-msgid "Default value: 720"
+#: ../raster/r.in.xyz/main.c:314
+msgid "Pth percentile of the values"
 msgstr ""
-#: ../display/d.mon/main.c:74
-msgid "Height for display monitor if not set by GRASS_RENDER_HEIGHT"
+#: ../raster/r.in.xyz/main.c:329 ../raster/r.in.xyz/main.c:336
+msgid "Scan"
 msgstr ""
-#: ../display/d.mon/main.c:75
-msgid "Default value: 480"
+#: ../raster/r.in.xyz/main.c:341
+#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:12
+msgid "Ignore broken lines"
 msgstr ""
-#: ../display/d.mon/main.c:82
-msgid "Dimensions of display monitor versus current size"
+#: ../raster/r.in.xyz/main.c:366
+msgid "Please specify a reasonable column number."
 msgstr ""
-#: ../display/d.mon/main.c:83
-msgid "Example: resolution=2 enlarge display monitor twice to 1280x960"
+#: ../raster/r.in.xyz/main.c:397
+msgid "Invalid vrange"
 msgstr ""
-#: ../display/d.mon/main.c:96
-msgid "Name for output file (when starting new monitor)"
+#: ../raster/r.in.xyz/main.c:536
+#, c-format
+msgid ""
+"Unable to process the hole map at once. Please set the %s option to some "
 msgstr ""
-#: ../display/d.mon/main.c:97
-msgid "Ignored for 'wx' monitors"
+#: ../raster/r.in.xyz/main.c:589
+msgid ""
+"If input is not from a file it is only possible to perform a single pass."
 msgstr ""
-#: ../display/d.mon/main.c:102
-msgid "List running monitors and exit"
+#: ../raster/r.in.xyz/main.c:601
+msgid "Range filters will not be taken into account during scan"
 msgstr ""
-#: ../display/d.mon/main.c:107
-msgid "Print name of currently selected monitor and exit"
+#: ../raster/r.in.xyz/main.c:638
+msgid "Reading input data..."
 msgstr ""
-#: ../display/d.mon/main.c:112
-msgid "Print commands for currently selected monitor and exit"
+#: ../raster/r.in.xyz/main.c:721 ../raster/r.in.xyz/main.c:729
+#: ../raster/r.in.xyz/main.c:1218 ../raster/r.in.xyz/main.c:1226
+#, c-format
+msgid ""
+"Not enough data columns. Incorrect delimiter or column number? Found the "
+"following character(s) in row %lu:\n"
+"[%s]"
 msgstr ""
-#: ../display/d.mon/main.c:118
-msgid "Print path to support files of currently selected monitor and exit"
+#: ../raster/r.in.xyz/main.c:725 ../raster/r.in.xyz/main.c:1222
+msgid "Line ignored as requested"
 msgstr ""
-#: ../display/d.mon/main.c:122
-msgid "Do not automatically select when starting"
+#: ../raster/r.in.xyz/main.c:744 ../raster/r.in.xyz/main.c:1256
+#, c-format
+msgid "Bad y-coordinate line %lu column %d. <%s>"
 msgstr ""
-#: ../display/d.mon/main.c:127
-msgid "Release and stop currently selected monitor and exit"
+#: ../raster/r.in.xyz/main.c:751 ../raster/r.in.xyz/main.c:1241
+#, c-format
+msgid "Bad x-coordinate line %lu column %d. <%s>"
 msgstr ""
-#: ../display/d.mon/main.c:132
-msgid "Disable true colors"
+#: ../raster/r.in.xyz/main.c:769 ../raster/r.in.xyz/main.c:1271
+#, c-format
+msgid "Bad z-coordinate line %lu column %d. <%s>"
 msgstr ""
-#: ../display/d.mon/main.c:137
-msgid "Open output file in update mode"
+#: ../raster/r.in.xyz/main.c:782 ../raster/r.in.xyz/main.c:1289
+#, c-format
+msgid "Bad data value line %lu column %d. <%s>"
 msgstr ""
-#: ../display/d.mon/main.c:138
-msgid "Requires --overwrite flag"
+#: ../raster/r.in.xyz/main.c:835
+#, c-format
+msgid "%lu points found in input file"
 msgstr ""
-#: ../display/d.mon/main.c:143
-msgid "Launch light-weight wx monitor without toolbars and statusbar"
+#: ../raster/r.in.xyz/main.c:838
+msgid "Writing to output raster map..."
 msgstr ""
-#: ../display/d.mon/main.c:144
-msgid "Requires 'start=wx0-7'"
+#: ../raster/r.in.xyz/main.c:1177
+#, c-format
+msgid "%lu points found in region."
 msgstr ""
-#: ../display/d.mon/main.c:151
+#: ../raster/r.cross/cross.c:65
 #, c-format
-msgid "Flag -%c has effect only for wx monitors (%s=wx0-7)"
+msgid "%s: STEP 1 ... "
 msgstr ""
-#: ../display/d.mon/main.c:161
-msgid "Currently selected monitor:"
+#: ../raster/r.cross/main.c:72
+msgid ""
+"Creates a cross product of the category values from multiple raster map "
+"layers."
 msgstr ""
-#: ../display/d.mon/main.c:165
+#: ../raster/r.cross/main.c:81
 #, c-format
-msgid "List of commands for monitor <%s>:"
+msgid "Names of 2-%d input raster maps"
 msgstr ""
-#: ../display/d.mon/main.c:173
-#, c-format
-msgid "Monitor <%s> released"
+#: ../raster/r.cross/main.c:90
+msgid "Non-zero data only"
 msgstr ""
-#: ../display/d.mon/main.c:178
-msgid "No monitor selected"
+#: ../raster/r.cross/main.c:103
+#, c-format
+msgid "More than %d files not allowed"
 msgstr ""
-#: ../display/d.mon/main.c:197
-#, c-format
-msgid "Either <%s>, <%s> or <%s> must be given"
+#: ../raster/r.cross/main.c:119
+msgid "Must specify 2 or more input maps"
 msgstr ""
-#: ../display/d.mon/stop.c:41
+#: ../raster/r.cross/main.c:136
 #, c-format
-msgid "Unable to delete file <%s>"
+msgid "%s: STEP 2 ..."
 msgstr ""
-#: ../display/d.mon/stop.c:46
+#: ../raster/r.cross/main.c:169 ../raster/r.resample/main.c:125
+#: ../raster/r.basins.fill/main.c:146 ../raster/r.in.png/main.c:485
 #, c-format
-msgid "Unable to delete directory <%s>"
+msgid "Creating support files for <%s>..."
 msgstr ""
-#: ../display/d.mon/stop.c:75
+#: ../raster/r.cross/main.c:179
 #, c-format
-msgid "Unable to read file <%s>"
+msgid "%ld categories"
 msgstr ""
-#: ../display/d.mon/start.c:46 ../display/d.mon/start.c:74
+#: ../raster/r.cross/renumber.c:33
 #, c-format
-msgid "File <%s> already exists and will be overwritten"
+msgid "%s: STEP 3 ... "
 msgstr ""
-#: ../display/d.mon/start.c:67
-#, c-format
-msgid "Unable to start monitor, don't have write permission for <%s>"
+#: ../raster/r.support/main.c:56
+msgid "Allows creation and/or modification of raster map layer support files."
 msgstr ""
-#: ../display/d.mon/start.c:76
-#, c-format
-msgid "Unable to delete <%s>"
+#: ../raster/r.support/main.c:74 ../raster3d/r3.support/main.c:70
+msgid "Text to append to the next line of the map's metadata file"
 msgstr ""
-#: ../display/d.mon/start.c:93
-#, c-format
-msgid "Output file: %s"
+#: ../raster/r.support/main.c:80
+msgid "Text to use for map data units"
 msgstr ""
-#: ../display/d.mon/start.c:148
-#, c-format
-msgid "Monitor <%s> already running"
+#: ../raster/r.support/main.c:86
+msgid "Text to use for map vertical datum"
 msgstr ""
-#: ../display/d.mon/start.c:151
-#, c-format
-msgid "Starting monitor <%s>..."
+#: ../raster/r.support/main.c:93 ../raster3d/r3.support/main.c:89
+msgid "Text to use for data source, line 1"
 msgstr ""
-#: ../display/d.mon/start.c:169
-msgid "Unable to copy render command file"
+#: ../raster/r.support/main.c:100 ../raster3d/r3.support/main.c:96
+msgid "Text to use for data source, line 2"
 msgstr ""
-#: ../display/d.mon/list.c:80
-msgid "List of running monitors:"
+#: ../raster/r.support/main.c:108 ../raster3d/r3.support/main.c:104
+msgid "Text to use for data description or keyword(s)"
 msgstr ""
-#: ../display/d.mon/list.c:82
-msgid "No monitors running"
+#: ../raster/r.support/main.c:115 ../raster/r.category/main.c:80
+#: ../raster3d/r3.support/main.c:111
+msgid "Raster map from which to copy category table"
 msgstr ""
-#: ../display/d.mon/list.c:116 ../scripts/d.redraw/d.redraw.py:41
-#: ../scripts/d.what.vect/d.what.vect.py:40
-#: ../scripts/d.what.rast/d.what.rast.py:40
-#, c-format, python-format
-msgid "Unable to open file '%s'"
+#: ../raster/r.support/main.c:120 ../raster3d/r3.support/main.c:116
+msgid "Text file from which to load history"
 msgstr ""
-#: ../display/d.mon/list.c:145
-#, c-format
-msgid "No support files found for monitor <%s>"
+#: ../raster/r.support/main.c:125 ../raster3d/r3.support/main.c:121
+msgid "Text file in which to save history"
 msgstr ""
-#: ../display/d.rast/main.c:56
-msgid "Displays user-specified raster map in the active graphics frame."
+#: ../raster/r.support/main.c:129
+msgid "Update statistics (histogram, range)"
 msgstr ""
-#: ../display/d.rast/main.c:61
-msgid "Name of raster map to be displayed"
-msgstr "Attēlojamā rastra karte"
-#: ../display/d.rast/main.c:69
-msgid "List of categories or values to be displayed"
+#: ../raster/r.support/main.c:133
+msgid "Create/reset the null file"
 msgstr ""
-#: ../display/d.rast/main.c:76
-msgid "Background color (for null)"
-msgstr "Fona krāsa (priekš NULL)"
-#: ../display/d.rast/main.c:77 ../display/d.rast/main.c:82
-#: ../display/d.rgb/main.c:64
-msgid "Null cells"
-msgstr "NULL šūnas"
-#: ../display/d.rast/main.c:81 ../display/d.rgb/main.c:63
-msgid "Make null cells opaque"
-msgstr "Padarīt NULL šūnas necaurspīdīgas"
-#: ../display/d.rast/main.c:86
-msgid "Invert value list"
+#: ../raster/r.support/main.c:137
+msgid "Delete the null file"
 msgstr ""
-#: ../display/d.rast/main.c:204
+#: ../raster/r.support/main.c:147 ../raster/r.category/main.c:130
 #, c-format
-msgid "[%s]: illegal category specified"
+msgid "Raster map <%s> not found in current mapset"
 msgstr ""
-#: ../display/d.rast/main.c:235
+#: ../raster/r.support/main.c:245 ../raster/r.statistics/main.c:110
+#: ../raster3d/r3.support/main.c:248 ../display/d.title/main.c:110
 #, c-format
-msgid "[%s]: illegal value specified"
+msgid "Unable to read category file of raster map <%s>"
 msgstr ""
-#: ../display/d.font/main.c:48
-msgid "Selects the font in which text will be displayed on the user's graphics monitor."
-msgstr "Izvēlies fontu kurš tiks parādīts lietotāja grafiskajā vidē."
-#: ../display/d.font/main.c:56
-msgid "Choose new current font"
+#: ../raster/r.support/main.c:249 ../raster3d/r3.support/main.c:252
+#, c-format
+msgid "cats table for [%s] set to %s"
 msgstr ""
-#: ../display/d.font/main.c:62
-msgid "Path to Freetype-compatible font including file name"
+#: ../raster/r.support/main.c:273 ../raster/r.support/main.c:301
+#, c-format
+msgid "[%s] is a reclass of another map. Exiting."
 msgstr ""
-#: ../display/d.font/main.c:70
-msgid "Character encoding"
-msgstr "Rakstzīmju kodējums"
-#: ../display/d.font/main.c:74
-msgid "List fonts"
+#: ../raster/r.support/main.c:285
+#, c-format
+msgid "Writing new null file for [%s]... "
 msgstr ""
-#: ../display/d.font/main.c:78 ../display/d.fontlist/main.c:55
-msgid "List fonts verbosely"
+#: ../raster/r.support/main.c:305
+#, c-format
+msgid "Removing null file for [%s]...\n"
 msgstr ""
-#: ../display/d.font/main.c:103
+#: ../raster/r.support/main.c:312 ../scripts/r.fillnulls/r.fillnulls.py:490
+#: ../scripts/r.plane/r.plane.py:122
+#: ../scripts/i.in.spotvgt/i.in.spotvgt.py:280
+#: ../scripts/d.polar/d.polar.py:407 ../scripts/v.in.e00/v.in.e00.py:165
+#: ../scripts/r.in.aster/r.in.aster.py:144
+msgid "Done."
+msgstr "Padarīts."
+#: ../raster/r.support/check.c:26
 #, c-format
-msgid "Unable to access font path %s: %s"
+msgid ""
+"\n"
+"  Updating statistics for [%s]"
 msgstr ""
-#: ../display/d.font/main.c:107
+#: ../raster/r.support/check.c:69
 #, c-format
-msgid "Font path %s is not a file"
+msgid ""
+"   Updating the number of categories for [%s]\n"
+"\n"
 msgstr ""
-#: ../display/d.font/main.c:124
-#, c-format
-msgid "Font name <%s> is invalid. Check font name or consider running 'g.mkfontcap'"
+#: ../raster/r.sunhours/main.c:74 ../raster/r.sun/main.c:253
+msgid "sun energy"
 msgstr ""
-#: ../display/d.vect/zcoor.c:19
-msgid "Vector map is not 3D. Unable to display z-coordinates."
+#: ../raster/r.sunhours/main.c:76
+msgid "Calculates solar elevation, solar azimuth, and sun hours."
 msgstr ""
-#: ../display/d.vect/topo.c:18
-msgid "Unable to display topology, not available.Please try to rebuild topology using v.build or v.build.all."
+#: ../raster/r.sunhours/main.c:77
+msgid ""
+"Solar elevation: the angle between the direction of the geometric center of "
+"the sun's apparent disk and the (idealized) horizon. Solar azimuth: the "
+"angle from due north in clockwise direction."
 msgstr ""
-#: ../display/d.vect/main.c:76
-msgid "Displays user-specified vector map in the active graphics frame."
+#: ../raster/r.sunhours/main.c:83
+msgid "Output raster map with solar elevation angle"
 msgstr ""
-#: ../display/d.vect/main.c:92
-msgid "Display"
-msgstr "Attēlot"
-#: ../display/d.vect/main.c:96
-msgid "Display geometry of features"
-msgstr "Objektu ģeometrija"
-#: ../display/d.vect/main.c:97
-msgid "Display category numbers of features"
-msgstr "Objektu kategoriju numuri"
-#: ../display/d.vect/main.c:98
-msgid "Display topology information (nodes, edges)"
-msgstr "Topoloģijas informācija (mezgli, robežas)"
-#: ../display/d.vect/main.c:99
-msgid "Display vertices of features"
-msgstr "Objektu virsotnes"
-#: ../display/d.vect/main.c:100
-msgid "Display direction of linear features"
-msgstr "Līnījveida objektu orientācija"
-#: ../display/d.vect/main.c:101
-msgid "Display z-coordinate of features (only for 3D vector maps)"
-msgstr "Objektu Z koordinātas informācija (tikai 3D vektoriem)"
-#: ../display/d.vect/main.c:119
-msgid "Feature color"
-msgstr "Objekta krāsa"
-#: ../display/d.vect/main.c:125
-msgid "Area fill color"
-msgstr "Laukuma aizpildījuma krāsa"
-#: ../display/d.vect/main.c:131
-msgid "Colorize features according color definition column"
+#: ../raster/r.sunhours/main.c:88
+msgid "Output raster map with solar azimuth angle"
 msgstr ""
-#: ../display/d.vect/main.c:132 ../vector/v.out.lidar/main.c:544
-msgid "Color definition in R:G:B form"
+#: ../raster/r.sunhours/main.c:93
+msgid "Output raster map with sunshine hours"
 msgstr ""
-#: ../display/d.vect/main.c:136
-msgid "Colorize point or area features according to z-coordinate"
+#: ../raster/r.sunhours/main.c:94
+msgid "Sunshine hours require SOLPOS use and Greenwich standard time"
 msgstr ""
-#: ../display/d.vect/main.c:144 ../display/d.vect/main.c:149
-#: ../display/d.vect/main.c:157
-msgid "Lines"
-msgstr "Līnijas"
+#: ../raster/r.sunhours/main.c:101
+msgid "Year"
+msgstr "Gads"
-#: ../display/d.vect/main.c:145 ../display/d.northarrow/main.c:121
-msgid "Line width"
-msgstr "Līnijas platums"
+#: ../raster/r.sunhours/main.c:109
+msgid "Month"
+msgstr "Mēnesis"
-#: ../display/d.vect/main.c:150
-msgid "Name of numeric column containing line width"
+#: ../raster/r.sunhours/main.c:110
+msgid "If not given, day is interpreted as day of the year"
 msgstr ""
-#: ../display/d.vect/main.c:151
-msgid "These values will be scaled by width_scale"
-msgstr ""
+#: ../raster/r.sunhours/main.c:118
+msgid "Day"
+msgstr "Diena"
-#: ../display/d.vect/main.c:158
-msgid "Scale factor for width_column"
+#: ../raster/r.sunhours/main.c:126
+msgid "Hour"
 msgstr ""
-#: ../display/d.vect/main.c:166 ../display/d.vect/main.c:176
-#: ../display/d.vect/main.c:183 ../display/d.vect/main.c:189
-#: ../display/d.vect/main.c:325 ../display/d.vect.thematic/main.c:168
-#: ../display/d.vect.thematic/main.c:178
-msgid "Symbols"
-msgstr "Simboli"
-#: ../display/d.vect/main.c:170 ../display/d.vect.thematic/main.c:172
-msgid "Point and centroid symbol"
-msgstr "Punktu un centroīdu simbols"
-#: ../display/d.vect/main.c:177 ../display/d.vect.thematic/main.c:179
-#: ../display/d.legend.vect/main.c:88
-msgid "Symbol size"
-msgstr "Simbola izmērs"
-#: ../display/d.vect/main.c:179
-msgid "When used with the size_column option this becomes the scale factor"
+#: ../raster/r.sunhours/main.c:135
+msgid "Minutes"
 msgstr ""
-#: ../display/d.vect/main.c:185
-msgid "Name of numeric column containing symbol size"
+#: ../raster/r.sunhours/main.c:144
+msgid "Seconds"
 msgstr ""
-#: ../display/d.vect/main.c:191
-msgid "Name of numeric column containing symbol rotation angle"
+#: ../raster/r.sunhours/main.c:151
+msgid "Time is local sidereal time, not Greenwich standard time"
 msgstr ""
-#: ../display/d.vect/main.c:193
-msgid "Measured in degrees CCW from east"
+#: ../raster/r.sunhours/main.c:155
+msgid "Do not use SOLPOS algorithm of NREL"
 msgstr ""
-#: ../display/d.vect/main.c:200 ../display/d.vect/main.c:210
-#: ../display/d.vect/main.c:218 ../display/d.vect/main.c:330
-#: ../display/d.vect.thematic/main.c:186 ../display/d.vect.thematic/main.c:197
-#: ../display/d.vect.thematic/main.c:206 ../display/d.vect.thematic/main.c:218
-#: ../display/d.vect.thematic/main.c:224 ../display/d.vect.thematic/main.c:229
-#: ../display/d.vect.thematic/main.c:239 ../display/d.vect.thematic/main.c:244
-msgid "Legend"
+#: ../raster/r.sunhours/main.c:167
+msgid "No output requested, exiting."
 msgstr ""
-#: ../display/d.vect/main.c:203
-msgid "Area/boundary symbol for legend"
+#: ../raster/r.sunhours/main.c:193
+msgid "NREL SOLPOS algorithm uses Greenwich standard time."
 msgstr ""
-#: ../display/d.vect/main.c:213
-msgid "Line symbol for legend"
+#: ../raster/r.sunhours/main.c:194 ../raster/r.sunhours/main.c:202
+msgid "Time will be interpreted as Greenwich standard time."
 msgstr ""
-#: ../display/d.vect/main.c:219
-msgid "Label to display after symbol in vector legend"
+#: ../raster/r.sunhours/main.c:200
+msgid "Time will be interpreted as local sidereal time."
 msgstr ""
-#: ../display/d.vect/main.c:225 ../display/d.vect/main.c:232
-#: ../display/d.vect/main.c:239 ../display/d.vect/main.c:244
-#: ../display/d.vect/main.c:251 ../display/d.vect/main.c:258
-#: ../display/d.vect/main.c:264 ../display/d.vect/main.c:270
-#: ../display/d.vect/main.c:276 ../display/d.vect/main.c:284
-msgid "Labels"
-msgstr "Uzraksti"
-#: ../display/d.vect/main.c:227
-msgid "Layer number for labels (default: the given layer number)"
+#: ../raster/r.sunhours/main.c:205
+msgid "Sunshine hours require NREL SOLPOS."
 msgstr ""
-#: ../display/d.vect/main.c:233
-msgid "Name of column to be displayed as a label"
+#: ../raster/r.sunhours/main.c:210
+msgid "Current projection is x,y (undefined)."
 msgstr ""
-#: ../display/d.vect/main.c:238
-msgid "Label color"
-msgstr "Uzraksta krāsa"
-#: ../display/d.vect/main.c:245
-msgid "Label background color"
-msgstr "Uzraksta fona krāsa"
-#: ../display/d.vect/main.c:252
-msgid "Label border color"
+#: ../raster/r.sunhours/main.c:216
+msgid "Cannot get projection info of current location"
 msgstr ""
-#: ../display/d.vect/main.c:259
-msgid "Label size (pixels)"
+#: ../raster/r.sunhours/main.c:219
+msgid "Cannot get projection units of current location"
 msgstr ""
-#: ../display/d.vect/main.c:265 ../display/d.rast.num/main.c:119
-#: ../display/d.legend/main.c:210 ../display/d.legend.vect/main.c:115
-#: ../display/d.text/main.c:222 ../vector/v.label/main.c:122
-msgid "Font name"
-msgstr "Fonta nosaukums"
-#: ../display/d.vect/main.c:271
-msgid "Text encoding"
-#: ../display/d.vect/main.c:279
-msgid "Label horizontal justification"
+#: ../raster/r.sunhours/main.c:222
+msgid "Cannot get projection key values of current location"
 msgstr ""
-#: ../display/d.vect/main.c:287
-msgid "Label vertical justification"
+#: ../raster/r.sunhours/main.c:232 ../general/g.region/printwindow.c:267
+#: ../general/g.region/printwindow.c:488 ../general/g.region/printwindow.c:569
+msgid "Unable to update lat/long projection parameters"
 msgstr ""
-#: ../display/d.vect/main.c:294
-msgid "Minimum region size (average from height and width) when map is displayed"
+#: ../raster/r.sunhours/main.c:356
+msgid "Calculating solar elevation and azimuth..."
 msgstr ""
-#: ../display/d.vect/main.c:302
-msgid "Maximum region size (average from height and width) when map is displayed"
+#: ../raster/r.sunhours/main.c:359
+msgid "Calculating solar elevation..."
 msgstr ""
-#: ../display/d.vect/main.c:310
-msgid "Random colors according to category number (or layer number if 'layer=-1' is given)"
+#: ../raster/r.sunhours/main.c:362
+msgid "Calculating solar azimuth..."
 msgstr ""
-#: ../display/d.vect/main.c:317
-msgid "Use values from 'cats' option as feature id"
+#: ../raster/r.clump/clump.c:83
+msgid "Pass 2 of 2..."
 msgstr ""
-#: ../display/d.vect/main.c:321
-msgid "Use square root of the value of size_column"
+#: ../raster/r.clump/clump.c:99 ../raster/r.clump/clump.c:151
+#: ../raster/r.clump/minsize.c:152 ../raster/r.clump/minsize.c:253
+#: ../raster/r.clump/minsize.c:287 ../raster/r.clump/minsize.c:293
+#: ../raster/r.clump/minsize.c:424 ../raster/r.clump/minsize.c:447
+#: ../raster/r.clump/minsize.c:518 ../imagery/i.segment/cluster.c:431
+msgid "Unable to read from temp file"
 msgstr ""
-#: ../display/d.vect/main.c:323
-msgid "This makes circle areas proportionate to the size_column values instead of circle radius"
+#: ../raster/r.clump/clump.c:115 ../raster/r.clump/clump.c:347
+#: ../raster/r.clump/clump.c:361 ../raster/r.clump/clump.c:648
+#: ../raster/r.clump/clump.c:662 ../raster/r.clump/minsize.c:163
+#: ../raster/r.clump/minsize.c:390 ../imagery/i.segment/cluster.c:363
+#: ../imagery/i.segment/cluster.c:377
+msgid "Unable to write to temp file"
 msgstr ""
-#: ../display/d.vect/main.c:329 ../display/d.vect.thematic/main.c:243
-msgid "Do not show this layer in vector legend"
-msgstr ""
+#: ../raster/r.clump/clump.c:124
+#, fuzzy, c-format
+msgid "%d initial clumps"
+msgstr "Tabulu kopēšana"
-#: ../display/d.vect/main.c:348
-msgid "Region size is lower than minreg, nothing displayed"
+#: ../raster/r.clump/clump.c:213 ../raster/r.clump/clump.c:477
+#: ../raster/r.clump/minsize.c:373 ../imagery/i.segment/cluster.c:121
+msgid "Unable to open temp file"
 msgstr ""
-#: ../display/d.vect/main.c:356
-msgid "Region size is greater than maxreg, nothing displayed"
+#: ../raster/r.clump/clump.c:235 ../raster/r.clump/clump.c:492
+msgid "Pass 1 of 2..."
 msgstr ""
-#: ../display/d.vect/main.c:369
+#: ../raster/r.clump/clump.c:427
+#, fuzzy, c-format
+msgid "%d-band clumping with threshold %g"
+msgstr "%d punkti ielādēti\n"
+#: ../raster/r.clump/clump.c:451 ../imagery/i.segment/write_output.c:112
+#: ../imagery/i.segment/open_files.c:71 ../imagery/i.segment/open_files.c:238
+#: ../imagery/i.segment/open_files.c:246
 #, c-format
-msgid "The -%c flag and <%s> option cannot be used together, the -%c flag will be ignored!"
+msgid "No min/max found in raster map <%s>"
 msgstr ""
-#: ../display/d.vect/main.c:393 ../display/d.vect/main.c:399
-#, c-format
-msgid "Option <%s> must be > 0"
+#: ../raster/r.clump/main.c:60
+msgid "reclass"
 msgstr ""
-#: ../display/d.vect/main.c:403
-#, c-format
-msgid "%d error in cat option"
-msgid_plural "%d errors in cat option"
-msgstr[0] ""
-msgstr[1] ""
-msgstr[2] ""
+#: ../raster/r.clump/main.c:63
+msgid ""
+"Recategorizes data in a raster map by grouping cells that form physically "
+"discrete areas into unique categories."
+msgstr ""
-#: ../display/d.vect/main.c:419
-msgid "Plotting..."
-msgstr "Zīmē..."
-#: ../display/d.vect/main.c:430
-msgid "The bounding box of the map is outside the current region, nothing drawn"
+#: ../raster/r.clump/main.c:82
+msgid "Threshold to identify similar cells"
 msgstr ""
-#: ../display/d.vect/main.c:501
-msgid "Rendering failed"
+#: ../raster/r.clump/main.c:83
+msgid "Valid range: 0 = identical to < 1 = maximal difference"
 msgstr ""
-#: ../display/d.vect/area.c:37
-msgid "Unable to display areas, topology not available. Please try to rebuild topology using v.build or v.build.all."
+#: ../raster/r.clump/main.c:90
+#, fuzzy
+msgid "Minimum clump size in cells"
+msgstr "Līniju skaits"
+#: ../raster/r.clump/main.c:91
+msgid "Clumps smaller than minsize will be merged to form larger clumps"
 msgstr ""
-#: ../display/d.vect/area.c:135
-#, c-format
-msgid "Invalid area %d skipped (not enough points)"
+#: ../raster/r.clump/main.c:95
+msgid "Clump also diagonal cells"
 msgstr ""
-#: ../display/d.vect/area.c:234
-#, c-format
-msgid "%d invalid color rule for areas skipped"
-msgid_plural "%d invalid color rules for areas skipped"
-msgstr[0] ""
-msgstr[1] ""
-msgstr[2] ""
-#: ../display/d.vect/lines.c:107 ../display/d.vect/lines.c:335
-#: ../display/d.vect.thematic/display.c:51
-#, c-format
-msgid "Unable to read symbol <%s>, unable to display points"
+#: ../raster/r.clump/main.c:96
+msgid "Clumps are also traced along diagonal neighboring cells"
 msgstr ""
-#: ../display/d.vect/lines.c:121
-msgid "Unable to display features by id, topology not available. Please try to rebuild topology using v.build or v.build.all."
+#: ../raster/r.clump/main.c:100
+msgid "Print only the number of clumps in shell script style"
 msgstr ""
-#: ../display/d.vect/lines.c:169
+#: ../raster/r.clump/main.c:122
 #, c-format
-msgid "%d invalid color rule for lines skipped"
-msgid_plural "%d invalid color rules for lines skipped"
-msgstr[0] ""
-msgstr[1] ""
-msgstr[2] ""
+msgid "Valid range for option <%s> is 0 <= value < 1"
+msgstr ""
-#: ../display/d.vect/lines.c:175 ../display/d.vect.thematic/display.c:118
+#: ../raster/r.clump/main.c:180
 #, c-format
-msgid "%d point plotted"
-msgid_plural "%d points plotted"
+msgid "%d clump."
+msgid_plural "%d clumps."
 msgstr[0] ""
 msgstr[1] ""
 msgstr[2] ""
-#: ../display/d.vect/lines.c:177 ../display/d.vect.thematic/display.c:121
-#, c-format
-msgid "%d line plotted"
-msgid_plural "%d lines plotted"
-msgstr[0] ""
-msgstr[1] ""
-msgstr[2] ""
+#: ../raster/r.clump/rclist.c:17 ../imagery/i.segment/rclist.c:17
+msgid "rclist out of memory"
+msgstr ""
-#: ../display/d.vect/lines.c:179 ../display/d.vect.thematic/display.c:125
-#, c-format
-msgid "%d centroid plotted"
-msgid_plural "%d centroids plotted"
-msgstr[0] ""
-msgstr[1] ""
-msgstr[2] ""
+#: ../raster/r.clump/minsize.c:357
+#, fuzzy
+msgid "Minimum size must be larger than 1"
+msgstr "2 līmeņiem jābūt norādītiem"
-#: ../display/d.vect/lines.c:181 ../display/d.vect.thematic/display.c:129
-#, c-format
-msgid "%d boundary plotted"
-msgid_plural "%d boundaries plotted"
-msgstr[0] ""
-msgstr[1] ""
-msgstr[2] ""
+#: ../raster/r.clump/minsize.c:368
+#, fuzzy
+msgid "Loading input ..."
-#: ../display/d.vect/lines.c:183 ../display/d.vect.thematic/display.c:132
+#: ../raster/r.clump/minsize.c:418
 #, c-format
-msgid "%d face plotted"
-msgid_plural "%d faces plotted"
-msgstr[0] ""
-msgstr[1] ""
-msgstr[2] ""
-#: ../display/d.vect/shape.c:38 ../display/d.vect.thematic/plot1.c:105
-#: ../display/d.vect.chart/plot.c:38 ../vector/v.what.rast3/main.c:120
-#: ../vector/v.extrude/main.c:224 ../vector/v.edit/select.c:502
-#: ../vector/v.univar/main.c:229 ../vector/v.overlay/main.c:398
-#: ../vector/v.kriging/getval.c:43 ../vector/v.surf.bspline/crosscorr.c:114
-#: ../vector/v.generalize/misc.c:170 ../vector/v.to.rast/support.c:104
-#: ../vector/v.to.rast/support.c:276 ../vector/v.to.rast/support.c:515
-#: ../vector/v.what.rast/main.c:138 ../vector/v.vect.stats/main.c:291
-#: ../vector/v.vect.stats/main.c:365 ../vector/v.distance/main.c:549
-#: ../vector/v.colors/scan_attr.c:24 ../vector/v.colors/read_rgb.c:23
-#: ../vector/v.colors/write_rgb.c:20 ../vector/v.buffer/main.c:412
-#: ../doc/vector/v.example/main.c:105
-#, c-format
-msgid "Database connection not defined for layer %d"
+msgid "Merging clumps smaller than %d cells..."
 msgstr ""
-#: ../display/d.vect/shape.c:53
-#, c-format
-msgid "Both color table and <%s> option detected. Color table will ignored."
+#: ../raster/r.clump/minsize.c:509
+#, fuzzy, c-format
+msgid "Renumbering remaining %d clumps..."
+msgstr "Neveiksme atverot ieejas dig_att failu"
+#: ../raster/r.mode/main.c:59
+msgid ""
+"Finds the mode of values in a cover map within areas assigned the same "
+"category value in a user-specified base map."
 msgstr ""
-#: ../display/d.vect/shape.c:68
-#, c-format
-msgid "Color definition column ('%s') not a string. Column must be of form 'RRR:GGG:BBB' where RGB values range 0-255. You can use '%s' module to define color rules. Unable to colorize features."
+#: ../raster/r.mode/main.c:65
+msgid "Base map to be reclassified"
 msgstr ""
-#: ../display/d.vect/shape.c:77 ../display/d.vect/shape.c:100
-#: ../display/d.vect/shape.c:131 ../display/d.vect/shape.c:162
-#, c-format
-msgid "Unable to select data ('%s') from table"
+#: ../raster/r.mode/main.c:72
+msgid "Coverage map"
 msgstr ""
-#: ../display/d.vect/shape.c:85
-msgid "Line width column not specified"
+#: ../raster/r.mode/main.c:79
+msgid "Output map"
 msgstr ""
-#: ../display/d.vect/shape.c:96
+#: ../raster/r.mode/main.c:92
 #, c-format
-msgid "Line width column ('%s') not a number"
+msgid "%s: Unable to read category labels"
 msgstr ""
-#: ../display/d.vect/shape.c:116
-msgid "Symbol size column not specified"
+#: ../raster/r.mode/read_stats.c:14
+msgid "reading r.stats output"
 msgstr ""
-#: ../display/d.vect/shape.c:127
-#, c-format
-msgid "Symbol size column ('%s') is not numeric"
+#: ../raster/r.recode/main.c:49
+msgid "recode categories"
 msgstr ""
-#: ../display/d.vect/shape.c:147
-msgid "Symbol rotation column not specified"
+#: ../raster/r.recode/main.c:51
+msgid "Recodes categorical raster maps."
 msgstr ""
-#: ../display/d.vect/shape.c:158
-#, c-format
-msgid "Symbol rotation column ('%s') is not numeric"
+#: ../raster/r.recode/main.c:54
+msgid "Name of raster map to be recoded"
 msgstr ""
-#: ../display/d.vect/shape.c:182
-msgid "Vector map is not 3D. Unable to colorize features based on z-coordinates."
+#: ../raster/r.recode/main.c:60
+msgid "File containing recode rules"
 msgstr ""
-#: ../display/d.vect/shape.c:201
-msgid "Unable to colorize features, unknown map bounding box"
+#: ../raster/r.recode/main.c:71
+msgid "Align the current region to the input raster map"
 msgstr ""
-#: ../display/d.vect/shape.c:338
-#, c-format
-msgid "Invalid negative value - feature %d with category %d"
+#: ../raster/r.recode/main.c:75
+msgid "Force output to 'double' raster map type (DCELL)"
 msgstr ""
-#: ../display/d.vect/opt.c:126
+#: ../raster/r.recode/main.c:96
 #, c-format
-msgid "Unknown color: '%s'"
+msgid "No rules specified. Raster map <%s> not created."
 msgstr ""
-#: ../display/d.vect/opt.c:143 ../display/d.vect.thematic/main.c:290
-#: ../vector/v.db.connect/main.c:180
-msgid "Database connection not defined"
-msgstr "Nav definēts datubāzes savienojums"
-#: ../display/d.vect/opt.c:152 ../display/d.vect.thematic/main.c:299
-#: ../db/db.describe/main.c:61 ../db/db.execute/main.c:76
-#: ../db/db.tables/main.c:50 ../db/db.select/main.c:81
-#: ../db/db.columns/main.c:56
+#: ../raster/r.recode/read_rules.c:20
 #, c-format
-msgid "Unable to open database <%s>"
+msgid "Unable to read f_range for map %s"
 msgstr ""
-#: ../display/d.vect/label.c:33
-msgid "Topology level required for drawing centroids for OGR layers"
+#: ../raster/r.recode/read_rules.c:24 ../display/d.colortable/main.c:146
+msgid "Data range is empty"
 msgstr ""
-#: ../display/d.vect/attr.c:28
-msgid "attrcol not specified, cannot display attributes"
+#: ../raster/r.recode/read_rules.c:30
+#, c-format
+msgid "Data range of %s is %s to %s (entire map)"
 msgstr ""
-#: ../display/d.vect/attr.c:110 ../display/d.vect.chart/plot.c:86
-#: ../vector/v.in.db/main.c:225
+#: ../raster/r.recode/read_rules.c:35 ../raster/r.stats/main.c:358
 #, c-format
-msgid "Unable to open select cursor: '%s'"
+msgid "Unable to read range for map <%s>"
 msgstr ""
-#: ../display/d.vect/attr.c:129
+#: ../raster/r.recode/read_rules.c:39
 #, c-format
-msgid "No attribute found for cat %d: %s"
+msgid "Integer data range of %s is empty"
 msgstr ""
-#: ../display/d.graph/graphics.c:60 ../display/d.graph/do_graph.c:129
-#: ../display/d.graph/do_graph.c:195 ../display/d.graph/do_graph.c:216
-#: ../display/d.graph/do_graph.c:267 ../display/d.graph/do_graph.c:334
+#: ../raster/r.recode/read_rules.c:41
 #, c-format
-msgid "Problem parsing command [%s]"
+msgid "Integer data range of %s is %d to %d"
 msgstr ""
-#: ../display/d.graph/main.c:61
-msgid "Program for generating and displaying simple graphics on the display monitor."
+#: ../raster/r.recode/read_rules.c:61
+msgid "Enter the rule or 'help' for the format description"
 msgstr ""
-#: ../display/d.graph/main.c:66
-msgid "Name of file containing graphics commands, if not given reads from standard input"
+#: ../raster/r.recode/read_rules.c:85
+msgid "Enter a rule in one of these formats:"
 msgstr ""
-#: ../display/d.graph/main.c:73
-msgid "Color to draw with, either a standard GRASS color or R:G:B triplet"
+#: ../raster/r.recode/read_rules.c:87
+msgid "old_low:old_high:new_low:new_high"
 msgstr ""
-#: ../display/d.graph/main.c:80
-msgid "Coordinates are given in map units"
+#: ../raster/r.recode/read_rules.c:88
+msgid "old_low:old_high:new_val      (i.e. new_high == new_low)"
 msgstr ""
-#: ../display/d.graph/main.c:91
-#, c-format
-msgid "Graph file <%s> not found"
+#: ../raster/r.recode/read_rules.c:89
+msgid "*:old_val:new_val             (interval [inf, old_val])"
 msgstr ""
-#: ../display/d.graph/do_graph.c:65 ../display/d.graph/do_graph.c:81
-#, c-format
-msgid "Problem parsing coordinates [%s]"
+#: ../raster/r.recode/read_rules.c:90
+msgid "old_val:*:new_val             (interval [old_val, inf])"
 msgstr ""
-#: ../display/d.graph/do_graph.c:98
-msgid "Unable to read color"
+#: ../raster/r.recode/read_rules.c:92
+msgid "When finished type \"end\"."
 msgstr ""
-#: ../display/d.graph/do_graph.c:377
-msgid "Cannot read symbol, cannot display points"
+#: ../raster/r.circle/main.c:56
+msgid "Creates a raster map containing concentric rings around a given point."
 msgstr ""
-#: ../display/d.extract/main.c:52
-msgid "Selects and extracts vectors with mouse into new vector map."
+#: ../raster/r.circle/main.c:63
+msgid "The coordinate of the center (east,north)"
 msgstr ""
-#: ../display/d.extract/main.c:65 ../display/d.path/main.c:99
-msgid "Original line color"
-msgstr "Oriģinālā līnijas krāsa"
-#: ../display/d.extract/main.c:71 ../display/d.path/main.c:107
-msgid "Highlight color"
+#: ../raster/r.circle/main.c:69
+msgid "Minimum radius for ring/circle map (in meters)"
 msgstr ""
-#: ../display/d.extract/main.c:79 ../vector/v.label/main.c:233
-msgid "No graphics device selected"
-msgstr "Nav izvēlēta grafiskā iekārta"
-#: ../display/d.extract/main.c:122
-msgid "Copying tables..."
-msgstr "Kopē tabulas..."
-#: ../display/d.extract/main.c:130
-msgid "Cannot get db link info -> cannot copy table."
-msgstr "Nevar iegūt datubāzes saites informāciju -> nevar nokopēt tabulu."
-#: ../display/d.extract/extract.c:43
-msgid "Select vector(s) with mouse"
+#: ../raster/r.circle/main.c:75
+msgid "Maximum radius for ring/circle map (in meters)"
 msgstr ""
-#: ../display/d.extract/extract.c:44
-msgid " - L: draw box with left mouse button to select"
+#: ../raster/r.circle/main.c:81
+msgid "Data value multiplier"
 msgstr ""
-#: ../display/d.extract/extract.c:45
-msgid " - M: draw box with middle mouse button to remove from display"
+#: ../raster/r.circle/main.c:85
+msgid "Generate binary raster map"
 msgstr ""
-#: ../display/d.extract/extract.c:46
-msgid " - R: quit and save selected vectors to new map\n"
+#: ../raster/r.circle/main.c:108
+msgid "Please specify a radius in which min < max"
 msgstr ""
-#: ../display/d.extract/extract.c:48
-msgid "L: add  M: remove  R: quit and save\n"
-msgstr "L: un  M: atņemt R: iziet un saglabāt\n"
-#: ../display/d.rast.num/main.c:81
-msgid "Overlays cell category values on a raster map displayed in the active graphics frame."
+#: ../raster/r.circle/main.c:116
+msgid "Please specify min and/or max radius when using the binary flag"
 msgstr ""
-#: ../display/d.rast.num/main.c:94 ../display/d.grid/main.c:96
-msgid "Grid color"
-msgstr "Tīkla krāsa"
-#: ../display/d.rast.num/main.c:112
-msgid "Get text color from cell color value"
+#: ../raster/r.regression.line/main.c:48
+#: ../raster/r.regression.multi/main.c:131
+msgid "regression"
 msgstr ""
-#: ../display/d.rast.num/main.c:120 ../display/d.rast.num/main.c:127
-#: ../display/d.rast.num/main.c:135 ../display/d.legend/main.c:204
-#: ../display/d.legend/main.c:211 ../display/d.legend/main.c:220
-#: ../display/d.legend/main.c:227 ../display/d.legend/main.c:235
-#: ../display/d.legend.vect/main.c:116 ../display/d.legend.vect/main.c:125
-#: ../display/d.legend.vect/main.c:132 ../display/d.legend.vect/main.c:148
-#: ../display/d.legend.vect/main.c:157 ../display/d.legend.vect/main.c:163
-#: ../display/d.text/main.c:223 ../display/d.text/main.c:233
-#: ../display/d.text/main.c:240 ../display/d.text/main.c:248
-#: ../display/d.text/main.c:273
-msgid "Font settings"
+#: ../raster/r.regression.line/main.c:50
+msgid "Calculates linear regression from two raster maps: y = a + b*x."
 msgstr ""
-#: ../display/d.rast.num/main.c:125 ../display/d.legend/main.c:225
-#: ../display/d.text/main.c:238
-msgid "Path to font file"
+#: ../raster/r.regression.line/main.c:55
+#: ../raster/r.regression.multi/main.c:138
+msgid "Map for x coefficient"
 msgstr ""
-#: ../display/d.rast.num/main.c:134 ../display/d.legend/main.c:234
-#: ../display/d.text/main.c:247
-msgid "Text encoding (only applicable to TrueType fonts)"
+#: ../raster/r.regression.line/main.c:59
+#: ../raster/r.regression.multi/main.c:142
+msgid "Map for y coefficient"
 msgstr ""
-#: ../display/d.rast.num/main.c:200
-#, c-format
-msgid "%d col"
-msgid_plural "%d cols"
-msgstr[0] ""
-msgstr[1] ""
-msgstr[2] ""
-#. GTC %s will be replaced by strings "X rows" and "Y cols"
-#: ../display/d.rast.num/main.c:202
-#, c-format
+#: ../raster/r.regression.line/main.c:65
+#: ../raster/r.regression.multi/main.c:158
 msgid ""
-"Current region size: %s X %s\n"
-"Your current region setting may be too large. Cells displayed on your graphics window may be too small for cell category number to be visible."
+"ASCII file for storing regression coefficients (output to screen if file not "
+"specified)."
 msgstr ""
-#: ../display/d.rast.num/main.c:212
-msgid "Aborting (region larger then 200 rows X 200 cols is not allowed)"
+#: ../raster/r.regression.line/main.c:69
+#: ../raster/r.regression.multi/main.c:162
+#: ../locale/scriptstrings/t.info_to_translate.c:9
+#: ../locale/scriptstrings/i.oif_to_translate.c:6
+#: ../general/g.region/main.c:147 ../imagery/i.group/main.c:88
+msgid "Print in shell script style"
 msgstr ""
-#: ../display/d.legend/histogram.c:115
-msgid "Histogram constrained by range not yet implemented for categorical rasters"
+#: ../raster/r.statistics/o_sdev.c:94 ../raster/r.statistics/o_var.c:95
+msgid "o_var: No data in array"
 msgstr ""
-#: ../display/d.legend/main.c:82
-msgid "Displays a legend for a 2D or 3D raster map in the active frame of the graphics monitor."
+#: ../raster/r.statistics/main.c:59
+msgid "Calculates category or object oriented statistics."
 msgstr ""
-#: ../display/d.legend/main.c:99 ../display/d.legend.vect/main.c:81
-msgid "Legend title"
+#: ../raster/r.statistics/main.c:104 ../raster/r.statistics/main.c:107
+#: ../raster/r.surf.idw/main.c:164
+msgid "This module currently only works for integer (CELL) maps"
 msgstr ""
-#: ../display/d.legend/main.c:100 ../display/d.legend/main.c:109
-#: ../display/d.legend.vect/main.c:82 ../display/d.legend.vect/main.c:141
-msgid "Title"
+#: ../raster/r.statistics/o_adev.c:93
+msgid "o_adev: No data in array"
 msgstr ""
-#: ../display/d.legend/main.c:107 ../display/d.legend.vect/main.c:139
-msgid "Title font size"
+#: ../raster/r.statistics/o_kurt.c:91
+msgid "o_kurto: No data in array"
 msgstr ""
-#: ../display/d.legend/main.c:108
-msgid "Default: Same as fontsize"
+#: ../raster/r.statistics/read_stats.c:20
+msgid "Reading r.stats output"
 msgstr ""
-#: ../display/d.legend/main.c:117
-msgid "Number of text lines (useful for truncating long legends)"
+#: ../raster/r.statistics/o_skew.c:91
+msgid "o_skew: No data in array"
 msgstr ""
-#: ../display/d.legend/main.c:127
-msgid "Thinning factor (thin=10 gives cats 0,10,20...)"
+#: ../raster/r.solute.transport/main.c:59
+msgid "The initial concentration in [kg/m^3]"
 msgstr ""
-#: ../display/d.legend/main.c:135
-msgid "Units to display after labels (e.g. meters)"
+#: ../raster/r.solute.transport/main.c:63
+msgid "The piezometric head in [m]"
 msgstr ""
-#: ../display/d.legend/main.c:144
-msgid "Number of text labels for smooth gradient legend"
+#: ../raster/r.solute.transport/main.c:68
+msgid "The x-part of the hydraulic conductivity tensor in [m/s]"
 msgstr ""
-#: ../display/d.legend/main.c:145 ../display/d.legend/main.c:154
-#: ../display/d.legend/main.c:161 ../display/d.legend/main.c:263
-#: ../display/d.legend/main.c:273 ../display/d.legend/main.c:283
-msgid "Gradient"
+#: ../raster/r.solute.transport/main.c:73
+msgid "The y-part of the hydraulic conductivity tensor in [m/s]"
 msgstr ""
-#: ../display/d.legend/main.c:151
-msgid "Specific values to draw ticks"
+#: ../raster/r.solute.transport/main.c:79
+msgid ""
+"The status for each cell, = 0 - inactive cell, 1 - active cell, 2 - "
+"dirichlet- and 3 - transfer boundary condition"
 msgstr ""
-#: ../display/d.legend/main.c:160
-msgid "Display label every step"
+#: ../raster/r.solute.transport/main.c:85
+msgid "The x-part of the diffusion tensor in [m^2/s]"
 msgstr ""
-#: ../display/d.legend/main.c:167
-msgid "Number of digits after decimal point"
+#: ../raster/r.solute.transport/main.c:90
+msgid "The y-part of the diffusion tensor in [m^2/s]"
 msgstr ""
-#: ../display/d.legend/main.c:179
-msgid "Size and placement as percentage of screen coordinates (0,0 is lower left)"
+#: ../raster/r.solute.transport/main.c:94
+#: ../raster/r.solute.transport/main.c:102
+#: ../raster/r.solute.transport/main.c:138
+#: ../raster/r.solute.transport/main.c:145
+msgid "Water flow"
 msgstr ""
-#: ../display/d.legend/main.c:189
-msgid "List of discrete category numbers/values for legend"
+#: ../raster/r.solute.transport/main.c:96
+msgid "Groundwater sources and sinks in [m^3/s]"
 msgstr ""
-#: ../display/d.legend/main.c:191 ../display/d.legend/main.c:200
-msgid "Subset"
+#: ../raster/r.solute.transport/main.c:103
+msgid ""
+"Concentration sources and sinks bounded to a water source or sink in [kg/s]"
 msgstr ""
-#: ../display/d.legend/main.c:199
-msgid "Use a subset of the map range for the legend (min,max)"
+#: ../raster/r.solute.transport/main.c:112
+msgid ""
+"Concentration of inner sources and inner sinks in [kg/s] (i.e. a chemical "
+"reaction)"
 msgstr ""
-#: ../display/d.legend/main.c:218 ../display/d.barscale/main.c:182
-#: ../display/d.legend.vect/main.c:123 ../display/d.northarrow/main.c:129
-msgid "Font size"
+#: ../raster/r.solute.transport/main.c:117
+msgid "Retardation factor [-]"
 msgstr ""
-#: ../display/d.legend/main.c:219
-msgid "Default: Auto-scaled"
+#: ../raster/r.solute.transport/main.c:121
+msgid "Effective porosity [-]"
 msgstr ""
-#: ../display/d.legend/main.c:240 ../display/d.grid/main.c:101
-#: ../display/d.legend.vect/main.c:95 ../vector/v.lrs/v.lrs.label/main.c:223
-#: ../vector/v.label.sa/main.c:144 ../vector/v.label/main.c:193
-msgid "Border color"
-msgstr "Malu krāsa"
+#: ../raster/r.solute.transport/main.c:125
+msgid "Top surface of the aquifer in [m]"
+msgstr ""
-#: ../display/d.legend/main.c:241 ../display/d.legend/main.c:247
-#: ../display/d.legend/main.c:288 ../display/d.legend.vect/main.c:96
-#: ../display/d.legend.vect/main.c:102 ../display/d.legend.vect/main.c:109
-#: ../display/d.legend.vect/main.c:168
-msgid "Background"
+#: ../raster/r.solute.transport/main.c:129
+msgid "Bottom surface of the aquifer in [m]"
 msgstr ""
-#: ../display/d.legend/main.c:252
-msgid "Do not show category labels"
-msgstr "Nerādīt kategoriju uzrakstus"
-#: ../display/d.legend/main.c:257
-msgid "Do not show category numbers"
-msgstr "Nerādīt kategoriju numurus"
-#: ../display/d.legend/main.c:262
-msgid "Draw legend ticks for labels"
+#: ../raster/r.solute.transport/main.c:132
+msgid ""
+"The resulting concentration of the numerical solute transport calculation "
+"will be written to this map. [kg/m^3]"
 msgstr ""
-#: ../display/d.legend/main.c:267
-msgid "Skip categories with no label"
-msgstr "Izlaist kategorijas bez uzrakstiem"
-#: ../display/d.legend/main.c:282
-msgid "Add histogram to smoothed legend"
+#: ../raster/r.solute.transport/main.c:140
+msgid ""
+"Calculate and store the groundwater filter velocity vector part in x "
+"direction [m/s]\n"
 msgstr ""
-#: ../display/d.legend/main.c:287
-msgid "Show background"
+#: ../raster/r.solute.transport/main.c:147
+msgid ""
+"Calculate and store the groundwater filter velocity vector part in y "
 msgstr ""
-#: ../display/d.legend/main.c:292
-msgid "Use logarithmic scale"
+#: ../raster/r.solute.transport/main.c:161
+msgid "The longditudinal dispersivity length. [m]"
 msgstr ""
-#: ../display/d.legend/draw.c:109
-msgid "Legend box lies outside of frame. Text may not display properly."
+#: ../raster/r.solute.transport/main.c:169
+msgid "The transversal dispersivity length. [m]"
 msgstr ""
-#: ../display/d.legend/draw.c:114
-msgid "Drawing horizontal legend as box width exceeds height"
+#: ../raster/r.solute.transport/main.c:177
+msgid ""
+"Use this number of time loops if the CFL flag is off. The timestep will "
+"become dt/loops."
 msgstr ""
-#: ../display/d.legend/draw.c:126
-#, c-format
-msgid "Range information for <%s> not available (run r.support)"
+#: ../raster/r.solute.transport/main.c:187
+msgid "Set the flow stabilizing scheme (full or exponential upwinding)."
 msgstr ""
-#: ../display/d.legend/draw.c:131
-msgid "Input map contains no data"
+#: ../raster/r.solute.transport/main.c:192 ../raster3d/r3.gwflow/main.c:131
+msgid ""
+"Use a full filled quadratic linear equation system, default is a sparse "
+"linear equation system."
 msgstr ""
-#: ../display/d.legend/draw.c:145
-msgid "Requested range exceeds lower limit of actual data"
+#: ../raster/r.solute.transport/main.c:199
+msgid "Use the Courant-Friedrichs-Lewy criteria for time step calculation"
 msgstr ""
-#: ../display/d.legend/draw.c:152
-msgid "Requested range exceeds upper limit of actual data"
+#: ../raster/r.solute.transport/main.c:231
+msgid "solute transport"
 msgstr ""
-#: ../display/d.legend/draw.c:214
-#, c-format
-msgid "use=%s out of range [%d,%d] (extend with range= ?)"
+#: ../raster/r.solute.transport/main.c:233
+msgid ""
+"Numerical calculation program for transient, confined and unconfined solute "
+"transport in two dimensions"
 msgstr ""
-#: ../display/d.legend/draw.c:239
-msgid "Nothing to draw! (no categories with labels? out of range?)"
+#: ../raster/r.solute.transport/main.c:258
+msgid "The direct LU solver do not work with sparse matrices"
 msgstr ""
-#: ../display/d.legend/draw.c:250
-msgid "Forcing a smooth legend: too many categories for current window height"
+#: ../raster/r.solute.transport/main.c:260
+msgid "The direct Gauss solver do not work with sparse matrices"
 msgstr ""
-#: ../display/d.legend/draw.c:282 ../display/d.legend/draw.c:287
-#: ../display/d.histogram/main.c:177
+#: ../raster/r.solute.transport/main.c:370
 #, c-format
-msgid "Range information for <%s> not available"
+msgid "The Courant-Friedrichs-Lewy criteria is %g it should be within [0:1]"
 msgstr ""
-#: ../display/d.legend/draw.c:301
-msgid "Color range exceeds lower limit of actual data"
+#: ../raster/r.solute.transport/main.c:371
+#, c-format
+msgid "The largest stable time step is %g"
 msgstr ""
-#: ../display/d.legend/draw.c:305
-msgid "Color range exceeds upper limit of actual data"
+#: ../raster/r.solute.transport/main.c:380
+#, c-format
+msgid "Number of inner loops is %g"
 msgstr ""
-#: ../display/d.legend/draw.c:312
+#: ../raster/r.solute.transport/main.c:381
 #, c-format
-msgid "Range [%.3f, %.3f] out of the logarithm domain."
+msgid "Time step for each loop %g"
 msgstr ""
-#: ../display/d.legend/draw.c:319
+#: ../raster/r.solute.transport/main.c:385
 #, c-format
-msgid "use=%s out of range [%.3f, %.3f] (extend with range= ?)"
+msgid ""
+"The time step is to large: %gs. The largest time step should be of size %gs."
 msgstr ""
-#: ../display/d.legend/draw.c:613
+#: ../raster/r.solute.transport/main.c:397
 #, c-format
-msgid "tick_value=%.3f out of range [%.3f, %.3f]"
+msgid "Time step %i with time sum %g"
 msgstr ""
-#: ../display/d.legend/draw.c:1029
-msgid "Histogram plotting not implemented for categorical legends. Use the '-s' flag"
+#: ../raster/r.solute.transport/main.c:543
+msgid "Could not create and solve the linear equation system"
 msgstr ""
-#: ../display/d.legend/draw.c:1286
-msgid "Nothing to draw! (no categories with labels?)"
-msgstr "Nav ko zīmēt! (nav kategorijas ar uzrakstiem?)"
-#: ../display/d.barscale/draw_scale.c:220 ../display/d.barscale/main.c:237
-#: ../display/d.barscale/main.c:254
-msgid "Programmer error"
+#: ../raster/r.series/main.c:141
+msgid ""
+"Makes each output cell value a function of the values assigned to the "
+"corresponding cells in the input raster map layers."
 msgstr ""
-#: ../display/d.barscale/draw_scale.c:611
-#: ../display/d.northarrow/draw_n_arrow.c:200
-#, c-format
-msgid "Could not read symbol \"%s\""
+#: ../raster/r.series/main.c:150
+msgid ""
+"Input file with one raster map name and optional one weight per line, field "
+"separator between name and weight is |"
 msgstr ""
-#: ../display/d.barscale/main.c:65
-msgid "Displays a barscale on the graphics monitor."
+#: ../raster/r.series/main.c:161 ../raster3d/r3.neighbors/main.c:119
+msgid "Aggregate operation"
 msgstr ""
-#: ../display/d.barscale/main.c:69
-msgid "Use feet/miles instead of meters"
+#: ../raster/r.series/main.c:176
+msgid ""
+"Weighting factor for each input map, default value is 1.0 for each input map"
 msgstr ""
-#: ../display/d.barscale/main.c:73
-msgid "Draw the scale bar without text"
+#: ../raster/r.series/main.c:183 ../raster/r.series.accumulate/main.c:132
+msgid "Ignore values outside this range"
 msgstr ""
-#: ../display/d.barscale/main.c:74 ../display/d.barscale/main.c:141
-#: ../display/d.barscale/main.c:166 ../display/d.barscale/main.c:183
-#: ../display/d.text/main.c:163 ../display/d.text/main.c:172
-#: ../display/d.text/main.c:181 ../display/d.text/main.c:189
-#: ../display/d.text/main.c:263 ../display/d.text/main.c:268
-#: ../display/d.northarrow/main.c:100 ../display/d.northarrow/main.c:130
-#: ../display/d.northarrow/main.c:135 ../display/d.northarrow/main.c:140
-msgid "Text"
+#: ../raster/r.series/main.c:191 ../raster/r.series.accumulate/main.c:163
+msgid "Do not keep files open"
 msgstr ""
-#: ../display/d.barscale/main.c:78
-msgid "Display north-arrow symbol."
+#: ../raster/r.series/main.c:250 ../raster/r.series/main.c:312
+msgid "Weights must be positive"
 msgstr ""
-#: ../display/d.barscale/main.c:79 ../display/d.barscale/main.c:88
-#: ../display/d.barscale/main.c:149 ../display/d.northarrow/main.c:73
-msgid "Style"
-msgstr "Stils"
-#: ../display/d.barscale/main.c:83
-msgid "Type of barscale to draw"
+#: ../raster/r.series/main.c:268 ../raster/r.series/main.c:318
+#, c-format
+msgid "Reading raster map <%s> using weight %f..."
 msgstr ""
-#: ../display/d.barscale/main.c:102
-msgid "Classic style"
+#: ../raster/r.series/main.c:275 ../raster/r.series.accumulate/main.c:255
+msgid "No raster map name found in input file"
 msgstr ""
-#: ../display/d.barscale/main.c:103
-msgid "Line style"
+#: ../raster/r.series/main.c:287 ../raster/r.stats/main.c:285
+#: ../raster/r.series.accumulate/main.c:265
+msgid "Raster map not found"
 msgstr ""
-#: ../display/d.barscale/main.c:104
-msgid "Solid style"
+#: ../raster/r.series/main.c:298
+msgid "input= and weights= must have the same number of values"
 msgstr ""
-#: ../display/d.barscale/main.c:105
-msgid "Hollow style"
+#: ../raster/r.series/main.c:333
+msgid "output= and method= must have the same number of values"
 msgstr ""
-#: ../display/d.barscale/main.c:106
-msgid "Full checker style"
+#: ../raster/r.series/main.c:351
+#, c-format
+msgid "Method %s not compatible with weights, using unweighed version instead"
 msgstr ""
-#: ../display/d.barscale/main.c:107
-msgid "Part checker style"
+#: ../raster/r.random/main.c:58
+msgid ""
+"Creates a raster map layer and vector point map containing randomly located "
+"points."
 msgstr ""
-#: ../display/d.barscale/main.c:108
-msgid "Mixed checker style"
+#: ../raster/r.random/main.c:67
+msgid "Name of cover raster map"
 msgstr ""
-#: ../display/d.barscale/main.c:109
-msgid "Tail checker style"
+#: ../raster/r.random/main.c:74
+msgid "The number of points to allocate"
 msgstr ""
-#: ../display/d.barscale/main.c:110
-msgid "Up ticks style"
+#: ../raster/r.random/main.c:86
+msgid "Generate points also for NULL category"
 msgstr ""
-#: ../display/d.barscale/main.c:111
-msgid "Down ticks style"
+#: ../raster/r.random/main.c:91
+msgid "Report information about input raster and exit"
 msgstr ""
-#: ../display/d.barscale/main.c:112
-msgid "Both ticks style"
+#: ../raster/r.random/main.c:95
+msgid "Generate vector points as 3D points"
 msgstr ""
-msgid "Arrow ends style"
+#: ../raster/r.random/main.c:143
+#, c-format
+msgid "Note: one (or both) of %s and %s must be specified"
 msgstr ""
-#: ../display/d.barscale/main.c:121 ../display/d.northarrow/main.c:83
-msgid "Screen coordinates of the rectangle's top-left corner"
+#: ../raster/r.random/main.c:151
+#, c-format
+msgid "<%s=%s> invalid percentage"
 msgstr ""
-#: ../display/d.barscale/main.c:122 ../display/d.northarrow/main.c:84
-msgid "(0,0) is lower-left of the display frame"
+#: ../raster/r.random/main.c:162
+#, c-format
+msgid "<%s=%s> invalid number of points"
 msgstr ""
-#: ../display/d.barscale/main.c:130
-msgid "Length of barscale in map units"
-msgstr ""
+#: ../raster/r.random/main.c:176
+#, fuzzy, c-format
+msgid "There aren't [%llu] cells in the current region"
+msgstr "Drukāt tekošo reģionu pēc platuma/garuma"
-#: ../display/d.barscale/main.c:134
-msgid "Barscale units to display"
-msgstr ""
+#: ../raster/r.random/main.c:179
+#, fuzzy, c-format
+msgid "There aren't [%llu] non-NULL cells in the current region"
-#: ../display/d.barscale/main.c:139
-msgid "Custom label of unit"
+#: ../raster/r.random/main.c:183
+#, fuzzy, c-format
+msgid "There aren't [%lu] cells in the current region"
+#: ../raster/r.random/main.c:186
+#, fuzzy, c-format
+msgid "There aren't [%lu] non-NULL cells in the current region"
+#: ../raster/r.random/main.c:192
+msgid "There are no valid locations in the current region"
 msgstr ""
-#: ../display/d.barscale/main.c:148
-msgid "Number of segments"
+#: ../raster/r.random/random.c:100
+msgid "Cannot create new table"
 msgstr ""
-#: ../display/d.barscale/main.c:152
-msgid "Bar scale and text color"
+#: ../raster/r.random/random.c:110
+#, c-format
+msgid "Writing raster map <%s> and vector map <%s> ..."
 msgstr ""
-#: ../display/d.barscale/main.c:158
-msgid "Background color (drawn behind the bar)"
+#: ../raster/r.random/random.c:113
+#, c-format
+msgid "Writing raster map <%s> ..."
 msgstr ""
-#: ../display/d.barscale/main.c:163
-msgid "Text position"
+#: ../raster/r.random/random.c:115
+#, c-format
+msgid "Writing vector map <%s> ..."
 msgstr ""
-#: ../display/d.barscale/main.c:174
-msgid "Scale factor to change bar width"
+#: ../raster/r.random/random.c:244
+#, c-format
+msgid "Only [%llu] random points created"
 msgstr ""
-#: ../display/d.barscale/main.c:193
+#: ../raster/r.random/random.c:247
 #, c-format
-msgid "%s does not work with a latitude-longitude location"
+msgid "Only [%lu] random points created"
 msgstr ""
-#: ../display/d.colorlist/main.c:39
-msgid "Outputs a list of all available display colors."
+#: ../raster/r.random/count.c:68
+msgid "Collecting Stats..."
 msgstr ""
-#: ../display/d.vect.thematic/main.c:87
-msgid "choropleth map"
+#: ../raster/r.random/count.c:123
+msgid "Programmer error in get_stats/switch"
 msgstr ""
-#: ../display/d.vect.thematic/main.c:90
-msgid "Displays a thematic vector map in the active graphics frame."
+#: ../raster/r.random.surface/init.c:73
+#, c-format
+msgid "High (%d) must be greater than 1"
 msgstr ""
-#: ../display/d.vect.thematic/main.c:97
-msgid "Layer number. If -1, all layers are displayed."
+#: ../raster/r.random.surface/init.c:82
+#, c-format
+msgid "Rastar map <%s> repeated, maps must be unique"
 msgstr ""
-#: ../display/d.vect.thematic/main.c:103
-msgid "Name of attribute column to be classified"
+#: ../raster/r.random.surface/init.c:92
+msgid "Output raster map required"
 msgstr ""
-#: ../display/d.vect.thematic/main.c:110
-msgid "Class breaks, without minimum and maximum"
+#: ../raster/r.random.surface/init.c:108
+#, c-format
+msgid "Seed (%d) larger than maximum (%d)"
 msgstr ""
-#: ../display/d.vect.thematic/main.c:111 ../display/d.vect.thematic/main.c:129
-#: ../display/d.vect.thematic/main.c:137
-msgid "Classes"
-msgstr "Klases"
+#: ../raster/r.random.surface/init.c:111 ../raster/r.random.surface/init.c:120
+#, c-format
+msgid " seed is set to %d"
+msgstr ""
-#: ../display/d.vect.thematic/main.c:119 ../vector/v.class/main.c:68
-msgid "Algorithm to use for classification"
+#: ../raster/r.random.surface/init.c:116
+#, c-format
+msgid "Seed (%d) smaller than minimum (%d)"
 msgstr ""
-#: ../display/d.vect.thematic/main.c:123 ../vector/v.class/main.c:76
-msgid "simple intervals"
+#: ../raster/r.random.surface/init.c:159
+#, c-format
+msgid "Distance value (%d): %lf must be >= 0.0"
 msgstr ""
-#: ../display/d.vect.thematic/main.c:124 ../vector/v.class/main.c:77
-msgid "standard deviations"
+#: ../raster/r.random.surface/init.c:187
+#, c-format
+msgid "Exponent value (%lf) must be > 0.0"
 msgstr ""
-#: ../display/d.vect.thematic/main.c:125 ../vector/v.class/main.c:78
-msgid "quantiles"
+#: ../raster/r.random.surface/init.c:211
+#, c-format
+msgid "Flat value (%lf) must be less than distance value (%lf)"
 msgstr ""
-#: ../display/d.vect.thematic/main.c:126 ../vector/v.class/main.c:79
-msgid "equiprobable (normal distribution)"
+#: ../raster/r.random.surface/init.c:232
+msgid "Must have a distance value for each filter"
 msgstr ""
-#: ../display/d.vect.thematic/main.c:136 ../vector/v.class/main.c:88
-msgid "Number of classes to define"
+#: ../raster/r.random.surface/init.c:264
+msgid "Must have a exponent value for each filter"
 msgstr ""
-#: ../display/d.vect.thematic/main.c:144
-msgid "Colors (one per class)"
+#: ../raster/r.random.surface/init.c:281
+msgid "Must have a weight value for each filter"
 msgstr ""
-#: ../display/d.vect.thematic/main.c:154 ../display/d.vect.thematic/main.c:160
-msgid "Boundaries"
-msgstr "Robežas"
+#: ../raster/r.random.surface/main.c:61
+msgid "Generates random surface(s) with spatial dependence."
+msgstr "Ģenerēt nejaušu virsmu(as) ar telpiskajām atkarībām."
-#: ../display/d.vect.thematic/main.c:155
-msgid "Boundary width"
-msgstr "Robežas platums"
+#: ../raster/r.random.surface/main.c:68
+msgid "Name for output raster map(s)"
+msgstr ""
-#: ../display/d.vect.thematic/main.c:159
-msgid "Boundary color"
-msgstr "Robežas krāsa"
+#: ../raster/r.random.surface/main.c:85
+msgid "Distance decay exponent (value > 0.0)"
+msgstr ""
-#: ../display/d.vect.thematic/main.c:190
-msgid "Legend symbol for lines"
+#: ../raster/r.random.surface/main.c:94
+msgid "Distance filter remains flat before beginning exponent"
 msgstr ""
-#: ../display/d.vect.thematic/main.c:201
-msgid "Legend symbol for areas"
+#: ../raster/r.random.surface/main.c:102
+msgid "Random seed (SEED_MIN >= value >= SEED_MAX), default [random]"
 msgstr ""
-#: ../display/d.vect.thematic/main.c:207
-msgid "Thematic map title"
+#: ../raster/r.random.surface/main.c:108
+msgid "Maximum cell value of distribution"
 msgstr ""
-#: ../display/d.vect.thematic/main.c:214 ../display/d.vect.thematic/main.c:236
-msgid "DEPRECATED"
+#: ../raster/r.random.surface/main.c:113
+msgid "Uniformly distributed cell values"
 msgstr ""
-#: ../display/d.vect.thematic/main.c:215
-msgid "Output legend file"
+#: ../raster/r.colors.out/raster_main.c:49
+msgid "Exports the color table associated with a raster map."
 msgstr ""
-#: ../display/d.vect.thematic/main.c:223 ../display/d.vect.chart/main.c:142
-msgid "Create legend information and send to stdout"
+#: ../raster/r.colors.out/raster3d_main.c:50
+msgid "Exports the color table associated with a 3D raster map."
 msgstr ""
-#: ../display/d.vect.thematic/main.c:228
-msgid "Do not draw map, only output the legend information"
+#: ../raster/r.colors.out/raster3d_main.c:70
+#, c-format
+msgid "Unable to read color table for raster3d map <%s>"
 msgstr ""
-#: ../display/d.vect.thematic/main.c:237
-msgid "When printing legend info, include extended statistical info from classification algorithm"
+#: ../raster/r.cost/main.c:145
+msgid ""
+"Creates a raster map showing the cumulative cost of moving between different "
+"geographic locations on an input raster map whose cell category values "
+"represent cost."
 msgstr ""
-#: ../display/d.vect.thematic/main.c:255
-msgid "Flag -e is deprecated, set verbose mode with --v to get the extended statistical info."
+#: ../raster/r.cost/main.c:152
+msgid "Name of input raster map containing grid cell cost information"
 msgstr ""
-#: ../display/d.vect.thematic/main.c:258
-msgid "Option legendfile is deprecated, either use flag -l to print legend to standard output, or set GRASS_LEGEND_FILE environment variable (see d.legend.vect for details)."
+#: ../raster/r.cost/main.c:160
+msgid "Name for output raster map with nearest start point"
 msgstr ""
-#: ../display/d.vect.thematic/main.c:277
+#: ../raster/r.cost/main.c:444
 #, c-format
-msgid "%s: You must build topology on vector map. Run v.build."
+msgid "Reading raster map <%s>, initializing output..."
 msgstr ""
-#: ../display/d.vect.thematic/main.c:288
-msgid "'layer' must be > 0"
+#: ../raster/r.cost/main.c:489
+#, c-format
+msgid ""
+"Negative cell value found at row %d, col %d. Setting negative value to "
+"null_cost value"
 msgstr ""
-#: ../display/d.vect.thematic/main.c:312
+#: ../raster/r.cost/main.c:582
 #, c-format
-msgid "Data (%s) not numeric. Column must be numeric."
+msgid "No start points found in vector map <%s>"
 msgstr ""
-#: ../display/d.vect.thematic/main.c:316 ../display/d.vect.thematic/plot1.c:135
-#: ../display/d.vect.thematic/plot1.c:163
+#: ../raster/r.cost/main.c:584
 #, c-format
-msgid "Cannot select data (%s) from table"
-msgstr ""
+msgid "%d point found"
+msgid_plural "%d points found"
+msgstr[0] ""
+msgstr[1] ""
+msgstr[2] ""
-#: ../display/d.vect.thematic/main.c:379
+#: ../raster/r.cost/main.c:1036
 #, c-format
-msgid "Unknown color: [%s]"
+msgid "Writing raster map with nearest start point <%s>..."
 msgstr ""
-#: ../display/d.vect.thematic/main.c:390
-msgid "You gave both manual breaks and a classification algorithm or a number of classes. The manual breaks have precedence and will thus be used."
+#: ../raster/r.topidx/main.c:41
+msgid "wetness"
 msgstr ""
-#: ../display/d.vect.thematic/main.c:427
-msgid "You must either give classbreaks or a classification algorithm"
-msgstr ""
+#: ../raster/r.topidx/main.c:42 ../raster/r.watershed/front/main.c:80
+#, fuzzy
+msgid "topographic index"
+msgstr "Izejas rastra kartes nosaukums"
-#: ../display/d.vect.thematic/main.c:440
-#, c-format
+#: ../raster/r.topidx/main.c:44
 msgid ""
-"Not enough colors or error in color specifications.\n"
-"Need %i entries for 'colors' parameter"
+"Creates a topographic index (wetness index) raster map from an elevation "
+"raster map."
 msgstr ""
-#: ../display/d.vect.thematic/main.c:445
-#, c-format
-msgid "Error interpreting color %s"
+#: ../raster/r.topidx/main.c:50
+msgid "Name for output topographic index raster map"
 msgstr ""
-#: ../display/d.vect.thematic/main.c:462
-msgid "Plotting ..."
-msgstr "Zīmē..."
+#: ../raster/r.topidx/topidx.c:41 ../raster/r.flow/main.c:314
+#: ../imagery/i.landsat.toar/main.c:534
+msgid "Calculating..."
+msgstr "Aprēķina..."
-#: ../display/d.vect.thematic/main.c:474
-msgid "The bounding box of the map is outside the current region, nothing drawn."
+#: ../raster/r.topidx/topidx.c:272
+#, c-format
+msgid "Number of sinks or boundaries: %d"
 msgstr ""
-#: ../display/d.vect.thematic/main.c:523
+#: ../raster/r.topidx/file_io.c:35
 #, c-format
 msgid ""
-"\n"
-"Total number of records: %.0f\n"
+"The current region resolution [%s x %s] is finer than the input map's "
+"resolution [%s x %s]. The current region resolution must be identical to, or "
+"coarser than, the input map's resolution."
 msgstr ""
-#: ../display/d.vect.thematic/main.c:525
-#, c-format
-msgid "Classification of %s into %i classes\n"
+#: ../raster/r.topidx/file_io.c:42
+msgid "Reading elevation map..."
 msgstr ""
-#: ../display/d.vect.thematic/main.c:527 ../vector/v.class/main.c:203
-#, c-format
-msgid "Using algorithm: *** %s ***\n"
+#: ../raster/r.topidx/file_io.c:87
+msgid "Writing topographic index map..."
 msgstr ""
-#: ../display/d.vect.thematic/main.c:529 ../vector/v.class/main.c:204
-#, c-format
-msgid "Mean: %f\tStandard deviation = %f\n"
+#: ../raster/r.resample/main.c:57
+msgid "GRASS raster map layer data resampling capability."
 msgstr ""
-#: ../display/d.vect.thematic/main.c:533
-#, c-format
-msgid "Last chi2 = %f\n"
+#: ../raster/r.resample/main.c:66
+msgid "Name of an input layer"
 msgstr ""
-#: ../display/d.vect.thematic/main.c:535 ../vector/v.class/main.c:211
-#, c-format
-msgid "Stdev multiplied by %.4f to define step\n"
+#: ../raster/r.resample/main.c:73
+msgid "Name of an output layer"
 msgstr ""
-#: ../display/d.vect.thematic/plot1.c:120
-msgid "Color definition column not specified"
+#: ../raster/r.resample/main.c:138
+msgid "Creating new cats file..."
 msgstr ""
-#: ../display/d.vect.thematic/plot1.c:130
-#, c-format
-msgid "Color definition column (%s) not a string. Column must be of form RRR:GGG:BBB where RGB values range 0-255."
+#: ../raster/r.proj/main.c:149
+msgid "Re-projects a raster map from given location to the current location."
 msgstr ""
-#: ../display/d.vect.thematic/plot1.c:148
-msgid "Line width column not specified."
+#: ../raster/r.proj/main.c:153
+msgid "Location containing input raster map"
 msgstr ""
-#: ../display/d.vect.thematic/plot1.c:159
-#, c-format
-msgid "Line width column (%s) not a number."
+#: ../raster/r.proj/main.c:157
+msgid "Mapset containing input raster map"
 msgstr ""
-#: ../display/d.vect.thematic/plot1.c:204
-#, c-format
-msgid ""
-"\n"
-"ERROR: vector map - can't read\n"
+#: ../raster/r.proj/main.c:162
+msgid "Name of input raster map to re-project"
 msgstr ""
-"\n"
-"KĻŪDA: vektora failu - nevar nolasīt\n"
-#: ../display/d.vect.thematic/plot1.c:279
-#, c-format
-msgid "Error in color definition column (%s), element %d with cat %d: colorstring [%s]"
+#: ../raster/r.proj/main.c:171
+msgid "Name for output raster map (default: same as 'input')"
 msgstr ""
-#: ../display/d.vect.thematic/plot1.c:286
-#, c-format
-msgid "Error in color definition column (%s), element %d with cat %d"
+#: ../raster/r.proj/main.c:182
+#: ../locale/scriptstrings/r.fillnulls_to_translate.c:5
+#: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:126
+#: ../imagery/i.rectify/main.c:132
+msgid "Interpolation method to use"
 msgstr ""
-#: ../display/d.vect.thematic/plot1.c:354
-#, c-format
-msgid "Error in line width column (%s), element %d with cat %d: line width [%d]"
+#: ../raster/r.proj/main.c:198
+msgid "Resolution of output raster map"
 msgstr ""
-#: ../display/d.rhumbline/main.c:46
-msgid "rhumbline"
+#: ../raster/r.proj/main.c:203
+msgid "List raster maps in input mapset and exit"
 msgstr ""
-#: ../display/d.rhumbline/main.c:48
-msgid "Displays the rhumbline joining two longitude/latitude coordinates."
+#: ../raster/r.proj/main.c:208
+#: ../locale/scriptstrings/r.import_to_translate.c:28
+msgid "Do not perform region cropping optimization"
 msgstr ""
-#: ../display/d.grid/plot.c:373
-msgid "Geo-grid option only available for LL projection, use without -g/-w"
+#: ../raster/r.proj/main.c:213
+msgid "Print input map's bounds in the current projection and exit"
 msgstr ""
-#: ../display/d.grid/plot.c:575
+#: ../raster/r.proj/main.c:219
 msgid ""
-"WGS84 grid output not possible as this location does not contain\n"
-"datum transformation parameters. Try running g.setproj."
+"Print input map's bounds in the current projection and exit (shell style)"
 msgstr ""
-#: ../display/d.grid/plot.c:743
-msgid "Error in pj_do_proj1"
+#: ../raster/r.proj/main.c:254
+msgid "Input and output locations are the same"
 msgstr ""
-#: ../display/d.grid/plot.c:749
-msgid "Error in pj_do_proj2"
+#: ../raster/r.proj/main.c:264
+msgid "Unable to get projection info of output raster map"
 msgstr ""
-#: ../display/d.grid/plot.c:753
-msgid "Error in pj_do_proj3"
+#: ../raster/r.proj/main.c:267
+msgid "Unable to get projection units of output raster map"
 msgstr ""
-#: ../display/d.grid/plot.c:761
-msgid "Error in pj_do_proj5"
+#: ../raster/r.proj/main.c:270
+msgid "Unable to get projection key values of output raster map"
 msgstr ""
-#: ../display/d.grid/plot.c:765
-msgid "Error in pj_do_proj6"
+#: ../raster/r.proj/main.c:279
+#, c-format
+msgid "Mapset <%s> in input location <%s> - %s"
 msgstr ""
-#: ../display/d.grid/main.c:55
-msgid "graticule"
+#: ../raster/r.proj/main.c:303
+#, c-format
+msgid "Raster map <%s> in location <%s> in mapset <%s> not found"
 msgstr ""
-#: ../display/d.grid/main.c:56 ../vector/v.mkgrid/main.c:72
-msgid "grid"
+#: ../raster/r.proj/main.c:311
+msgid "Unable to get projection info of input map"
 msgstr ""
-#: ../display/d.grid/main.c:58
-msgid "Overlays a user-specified grid in the active display frame on the graphics monitor."
+#: ../raster/r.proj/main.c:314
+msgid "Unable to get projection units of input map"
 msgstr ""
-#: ../display/d.grid/main.c:66
-msgid "Size of grid to be drawn (in map units)"
+#: ../raster/r.proj/main.c:317
+msgid "Unable to get projection key values of input map"
 msgstr ""
-#: ../display/d.grid/main.c:68
-msgid "0 for north-south resolution of the current region. In map units or DDD:MM:SS format. Example: \"1000\" or \"0:10\""
+#: ../raster/r.proj/main.c:332
+msgid "Unable to work with unprojected data (xy location)"
 msgstr ""
-#: ../display/d.grid/main.c:76
-msgid "Lines of the grid pass through this coordinate"
+#: ../raster/r.proj/main.c:351
+#, c-format
+msgid "Input map <%s@%s> in location <%s>:"
 msgstr ""
-#: ../display/d.grid/main.c:85
-msgid "Draw only east-west lines, north-south lines, or both "
+#: ../raster/r.proj/main.c:443
+msgid "Input:"
 msgstr ""
-#: ../display/d.grid/main.c:86 ../display/d.grid/main.c:159
-#: ../display/d.grid/main.c:164 ../display/d.grid/main.c:169
-msgid "Disable"
-msgstr "Atslēgt"
-#: ../display/d.grid/main.c:92
-msgid "Grid line width"
+#: ../raster/r.proj/main.c:444 ../raster/r.proj/main.c:455
+#, c-format
+msgid "Cols: %d (%d)"
 msgstr ""
-#: ../display/d.grid/main.c:97 ../display/d.grid/main.c:102
-#: ../display/d.grid/main.c:108 ../display/d.grid/main.c:114
-msgid "Color"
-msgstr "Krāsa"
-#: ../display/d.grid/main.c:122
-msgid "Font size for gridline coordinate labels"
+#: ../raster/r.proj/main.c:445 ../raster/r.proj/main.c:456
+#, c-format
+msgid "Rows: %d (%d)"
 msgstr ""
-#: ../display/d.grid/main.c:127
-msgid "Align the origin to the east-north corner of the current region"
+#: ../raster/r.proj/main.c:446 ../raster/r.proj/main.c:457
+#, c-format
+msgid "North: %f (%f)"
 msgstr ""
-#: ../display/d.grid/main.c:132
-msgid "Draw geographic grid (referenced to current ellipsoid)"
+#: ../raster/r.proj/main.c:447 ../raster/r.proj/main.c:458
+#, c-format
+msgid "South: %f (%f)"
 msgstr ""
-#: ../display/d.grid/main.c:138
-msgid "Draw geographic grid (referenced to WGS84 ellipsoid)"
+#: ../raster/r.proj/main.c:448 ../raster/r.proj/main.c:459
+#, c-format
+msgid "West: %f (%f)"
 msgstr ""
-#: ../display/d.grid/main.c:143
-msgid "Draw '+' marks instead of grid lines"
+#: ../raster/r.proj/main.c:449 ../raster/r.proj/main.c:460
+#, c-format
+msgid "East: %f (%f)"
 msgstr ""
-#: ../display/d.grid/main.c:148
-msgid "Draw '.' marks instead of grid lines"
+#: ../raster/r.proj/main.c:450 ../raster/r.proj/main.c:461
+#, c-format
+msgid "EW-res: %f"
 msgstr ""
-#: ../display/d.grid/main.c:153
-msgid "Draw fiducial marks instead of grid lines"
+#: ../raster/r.proj/main.c:451 ../raster/r.proj/main.c:462
+#, c-format
+msgid "NS-res: %f"
 msgstr ""
-#: ../display/d.grid/main.c:158
-msgid "Disable grid drawing"
+#: ../raster/r.proj/main.c:454
+msgid "Output:"
 msgstr ""
-#: ../display/d.grid/main.c:163
-msgid "Disable border drawing"
+#: ../raster/r.proj/main.c:491
+msgid "Projecting..."
 msgstr ""
-#: ../display/d.grid/main.c:168
-msgid "Disable text drawing"
+#: ../raster/r.proj/bordwalk.c:216
+msgid "Input raster map is outside current region"
 msgstr ""
-#: ../display/d.grid/main.c:178
-msgid "Both grid and border drawing are disabled"
+#: ../raster/r.proj/bordwalk.c:242
+msgid "Unable to reproject map center"
 msgstr ""
-#: ../display/d.grid/main.c:182
-msgid "Geo-grid option not available for LL projection, use without -g/-w"
+#: ../raster/r.proj/readcell.c:67
+msgid "Allocating memory and reading input raster map..."
 msgstr ""
-#: ../display/d.grid/main.c:184
-msgid "Geo-grid option not available for XY projection, use without -g/-w"
+#: ../raster/r.proj/readcell.c:92
+#: ../imagery/i.ortho.photo/i.ortho.rectify/readcell.c:102
+#: ../imagery/i.rectify/readcell.c:89
+msgid "Error writing segment file"
 msgstr ""
-#: ../display/d.grid/main.c:203
-msgid "Choose a single mark style"
+#: ../raster/r.proj/readcell.c:125
+#: ../imagery/i.ortho.photo/i.ortho.rectify/readcell.c:132
+#: ../imagery/i.rectify/readcell.c:116
+msgid "Internal error: cache miss on fully-cached map"
 msgstr ""
-#: ../display/d.grid/main.c:234
-#, c-format
-msgid "Invalid geo-grid size <%s>"
+#: ../raster/r.proj/readcell.c:138
+#: ../imagery/i.ortho.photo/i.ortho.rectify/readcell.c:141
+#: ../imagery/i.rectify/readcell.c:125
+msgid "Error seeking on segment file"
 msgstr ""
-#: ../display/d.grid/main.c:239
-#, c-format
-msgid "Invalid grid size <%s>"
+#: ../raster/r.proj/readcell.c:141
+#: ../imagery/i.ortho.photo/i.ortho.rectify/readcell.c:144
+#: ../imagery/i.rectify/readcell.c:128
+msgid "Error reading segment file"
 msgstr ""
-#: ../display/d.grid/fiducial.c:61
-msgid "Reading symbol"
+#: ../raster/r.profile/main.c:57
+msgid "Outputs the raster map layer values lying on user-defined line(s)."
 msgstr ""
+"Izvada rastra kartes vērtības, kas atrodas uz lietotāja norādītās līnijas."
-#: ../display/d.legend.vect/main.c:55
-msgid "Displays a vector legend in the active graphics frame."
+#: ../raster/r.profile/main.c:70 ../display/d.profile/main.c:203
+msgid "Profile coordinate pairs"
 msgstr ""
-#: ../display/d.legend.vect/main.c:66
-msgid "Screen position of legend to be drawn (percentage, [0,0] is lower left)"
+#: ../raster/r.profile/main.c:76
+msgid "Name of input file containing coordinate pairs"
 msgstr ""
-#: ../display/d.legend.vect/main.c:74
-msgid "Number of legend columns"
+#: ../raster/r.profile/main.c:78
+msgid "Use instead of the 'coordinates' option. \"-\" reads from stdin."
 msgstr ""
-#: ../display/d.legend.vect/main.c:75 ../display/d.legend.vect/main.c:90
-msgid "Layout"
+#: ../raster/r.profile/main.c:86
+msgid "Resolution along profile (default = current region resolution)"
 msgstr ""
-#: ../display/d.legend.vect/main.c:108
-msgid "Background border width"
+#: ../raster/r.profile/main.c:94 ../raster/r.transect/main.c:127
+msgid "Output easting and northing in first two columns of four column output"
 msgstr ""
-#: ../display/d.legend.vect/main.c:124
-msgid "Default: 12"
+#: ../raster/r.profile/main.c:99
+msgid "Output RRR:GGG:BBB color values for each profile point"
 msgstr ""
-#: ../display/d.legend.vect/main.c:131
-msgid "Title font name"
+#: ../raster/r.profile/main.c:104
+msgid ""
+"If units are not specified, current location units are used. Meters are used "
+"by default in geographic (latlon) locations."
 msgstr ""
-#: ../display/d.legend.vect/main.c:140
-msgid "Default: 18"
+#: ../raster/r.profile/main.c:118
+msgid "Either use profile option or coordinate_file  option, but not both"
 msgstr ""
-#: ../display/d.legend.vect/main.c:147
-msgid "Subtitle font name"
+#: ../raster/r.profile/main.c:145
+#, c-format
+msgid "Illegal resolution %g [%s]"
 msgstr ""
-#: ../display/d.legend.vect/main.c:155
-msgid "Subtitle font size"
+#: ../raster/r.profile/main.c:152
+#, c-format
+msgid "Using resolution: %g [%s]"
 msgstr ""
-#: ../display/d.legend.vect/main.c:156
-msgid "Default: 14"
+#: ../raster/r.profile/main.c:183
+msgid "Output columns:"
 msgstr ""
-#: ../display/d.legend.vect/main.c:162
-msgid "Font color"
+#: ../raster/r.profile/main.c:186
+#, c-format
+msgid "Easting, Northing, Along track dist. [%s], Elevation"
 msgstr ""
-#: ../display/d.legend.vect/main.c:167
-msgid "Display legend background"
+#: ../raster/r.profile/main.c:188
+#, c-format
+msgid "Along track dist. [%s], Elevation"
 msgstr ""
-#: ../display/d.legend.vect/main.c:171 ../display/d.legend.vect/main.c:178
-#: ../display/d.legend.vect/main.c:185
-msgid "In/Out"
-msgstr ""
+#: ../raster/r.profile/main.c:190
+msgid " RGB color"
+msgstr "RGB krāsa"
-#: ../display/d.legend.vect/main.c:172
-msgid "Field separator for input file"
+#: ../raster/r.profile/main.c:201
+#, c-format
+msgid "Could not open <%s>"
 msgstr ""
-#: ../display/d.legend.vect/main.c:175
-msgid "Input legend file"
+#: ../raster/r.profile/main.c:208
+#, c-format
+msgid "Invalid coordinates %s %s"
 msgstr ""
-#: ../display/d.legend.vect/main.c:176
-msgid "Path to legend file "
+#: ../raster/r.profile/main.c:279
+#, c-format
+msgid "Approx. transect length: %f [%s]"
 msgstr ""
-#: ../display/d.legend.vect/main.c:181
-msgid "Output csv file"
+#: ../raster/r.profile/main.c:282
+msgid "Endpoint coordinates are outside of current region settings"
 msgstr ""
-#: ../display/d.legend.vect/main.c:182
-msgid "Path to output file or '-' for standard output"
+#: ../raster/r.profile/input.c:30 ../raster/r.profile/input.c:47
+#: ../raster/r.profile/input.c:60
+msgid "One coordinate pair per line, please"
 msgstr ""
-#: ../display/d.legend.vect/draw.c:95 ../display/d.legend.vect/draw.c:183
-msgid "Cannot read symbol"
+#: ../raster/r.surf.idw/main.c:109
+msgid ""
+"Provides surface interpolation from raster point data by Inverse Distance "
+"Squared Weighting."
 msgstr ""
-#: ../display/d.legend.vect/draw.c:244
-msgid "Invalid value for color type in legend file. Use one of 'lf' or 'ps'."
+#: ../raster/r.surf.idw/main.c:124
+msgid "Output is the interpolation error"
 msgstr ""
-#: ../display/d.profile/main.c:68
+#: ../raster/r.surf.idw/main.c:130
 #, c-format
-msgid "Unable to read range for %s"
+msgid "Illegal value for '%s' (%s)"
 msgstr ""
-#: ../display/d.profile/main.c:79
+#: ../raster/r.surf.idw/main.c:260
 #, c-format
-msgid "Unable to read FP range for %s"
+msgid "Interpolating raster map <%s> (%d row)..."
+msgid_plural "Interpolating raster map <%s> (%d rows)..."
+msgstr[0] ""
+msgstr[1] ""
+msgstr[2] ""
+#: ../raster/r.in.bin/main.c:61 ../raster/r.in.bin/main.c:70
+#: ../raster/r.in.bin/main.c:614
+msgid "Error reading data"
 msgstr ""
-#: ../display/d.profile/main.c:194
-msgid "Plots profile of a transect."
+#: ../raster/r.in.bin/main.c:260
+msgid "Import a binary raster file into a GRASS raster map layer."
 msgstr ""
-#: ../display/d.profile/main.c:198
-msgid "Raster map to be profiled"
-msgstr "Profilējamā rastra karte"
+#: ../raster/r.in.bin/main.c:265
+msgid "Import as floating-point data (default: integer)"
+msgstr ""
-#: ../display/d.profile/main.c:207
-msgid "Use map's range recorded range"
+#: ../raster/r.in.bin/main.c:270
+msgid "Import as double-precision floating-point data (default: integer)"
 msgstr ""
-#: ../display/d.profile/main.c:256
-msgid "At least two points are required"
+#: ../raster/r.in.bin/main.c:274 ../raster3d/r3.in.bin/main.c:369
+msgid "Signed data (two's complement)"
 msgstr ""
-#: ../display/d.path/select.c:84 ../display/d.path/select.c:101
-#, c-format
-msgid "Node %d: %f %f\n"
-msgstr "Mezgls %d: %f %f\n"
+#: ../raster/r.in.bin/main.c:279
+msgid "Byte swap the data during import"
+msgstr ""
-#: ../display/d.path/select.c:122
-#, c-format
-msgid "Destination unreachable\n"
-msgstr "Galapunkts nesasniedzams\n"
+#: ../raster/r.in.bin/main.c:284
+msgid "Get region info from GMT style header"
+msgstr ""
-#: ../display/d.path/select.c:125
-#, c-format
-msgid "Costs on the network = %f\n"
-msgstr "Pašizmaksa tīklā = %f\n"
+#: ../raster/r.in.bin/main.c:288
+msgid "Name of binary raster file to be imported"
+msgstr ""
-#: ../display/d.path/select.c:126
-#, c-format
-msgid ""
-"  Distance to the network = %f, distance from the network = %f\n"
-"\n"
+#: ../raster/r.in.bin/main.c:291
+msgid "Output name or prefix if several bands are imported"
 msgstr ""
-#: ../display/d.path/main.c:49 ../vector/v.net.spanningtree/main.c:47
-#: ../vector/v.net.components/main.c:73 ../vector/v.net.distance/main.c:67
-#: ../vector/v.net.flow/main.c:59 ../vector/v.lrs/v.lrs.segment/main.c:73
-#: ../vector/v.lrs/v.lrs.label/main.c:104
-#: ../vector/v.lrs/v.lrs.create/main.c:123
-#: ../vector/v.lrs/v.lrs.where/main.c:59 ../vector/v.net.timetable/main.c:261
-#: ../vector/v.net.alloc/main.c:58 ../vector/v.net.allpairs/main.c:62
-#: ../vector/v.net.connectivity/main.c:53 ../vector/v.net.bridge/main.c:48
-#: ../vector/v.net.path/main.c:43 ../vector/v.net.steiner/main.c:347
-#: ../vector/v.net.centrality/main.c:97 ../vector/v.net.visibility/main.c:46
-#: ../vector/v.net.iso/main.c:73 ../vector/v.net/main.c:48
-#: ../vector/v.net.salesman/main.c:128
-msgid "network"
-msgstr "tīkls"
+#: ../raster/r.in.bin/main.c:313
+msgid "Header size in bytes"
+msgstr ""
-#: ../display/d.path/main.c:52
-msgid "Finds shortest path for selected starting and ending node."
+#: ../raster/r.in.bin/main.c:321
+msgid "Number of bands in input file"
 msgstr ""
-#: ../display/d.path/main.c:60 ../vector/v.net.distance/main.c:89
-#: ../vector/v.net.alloc/main.c:98 ../vector/v.net.path/main.c:61
-#: ../vector/v.net.steiner/main.c:363 ../vector/v.net.iso/main.c:111
-#: ../vector/v.net/args.c:63 ../vector/v.net.salesman/main.c:156
-msgid "Arc type"
+#: ../raster/r.in.bin/main.c:322
+msgid "Bands must be in band-sequential order"
 msgstr ""
-#: ../display/d.path/main.c:70 ../vector/v.net.spanningtree/main.c:59
-#: ../vector/v.net.components/main.c:84 ../vector/v.net.distance/main.c:82
-#: ../vector/v.net.flow/main.c:70 ../vector/v.net.timetable/main.c:274
-#: ../vector/v.net.alloc/main.c:91 ../vector/v.net.allpairs/main.c:74
-#: ../vector/v.net.connectivity/main.c:64 ../vector/v.net.bridge/main.c:60
-#: ../vector/v.net.path/main.c:54 ../vector/v.net.steiner/main.c:368
-#: ../vector/v.net.centrality/main.c:109 ../vector/v.net.iso/main.c:104
-#: ../vector/v.net/args.c:56 ../vector/v.net.salesman/main.c:149
-msgid "Arc layer"
+#: ../raster/r.in.bin/main.c:338 ../raster3d/r3.in.bin/main.c:283
+msgid "Northern limit of geographic region (outer edge)"
 msgstr ""
-#: ../display/d.path/main.c:75 ../vector/v.net.spanningtree/main.c:65
-#: ../vector/v.net.components/main.c:90 ../vector/v.net.distance/main.c:95
-#: ../vector/v.net.flow/main.c:76 ../vector/v.net.timetable/main.c:280
-#: ../vector/v.net.alloc/main.c:104 ../vector/v.net.allpairs/main.c:80
-#: ../vector/v.net.connectivity/main.c:70 ../vector/v.net.bridge/main.c:66
-#: ../vector/v.net.path/main.c:67 ../vector/v.net.centrality/main.c:115
-#: ../vector/v.net.iso/main.c:117 ../vector/v.net/args.c:70
-msgid "Node layer"
+#: ../raster/r.in.bin/main.c:346 ../raster3d/r3.in.bin/main.c:291
+msgid "Southern limit of geographic region (outer edge)"
 msgstr ""
-#: ../display/d.path/main.c:81 ../vector/v.net.spanningtree/main.c:72
-#: ../vector/v.net.components/main.c:97 ../vector/v.net.distance/main.c:141
-#: ../vector/v.net.flow/main.c:90 ../vector/v.net.timetable/main.c:288
-#: ../vector/v.net.alloc/main.c:110 ../vector/v.net.allpairs/main.c:93
-#: ../vector/v.net.connectivity/main.c:77 ../vector/v.net.bridge/main.c:73
-#: ../vector/v.net.path/main.c:79 ../vector/v.net.centrality/main.c:129
-#: ../vector/v.net.iso/main.c:122 ../vector/v.net.salesman/main.c:168
-msgid "Arc forward/both direction(s) cost column (number)"
+#: ../raster/r.in.bin/main.c:354 ../raster3d/r3.in.bin/main.c:299
+msgid "Eastern limit of geographic region (outer edge)"
 msgstr ""
-#: ../display/d.path/main.c:87 ../vector/v.net.components/main.c:103
-#: ../vector/v.net.distance/main.c:147 ../vector/v.net.flow/main.c:96
-#: ../vector/v.net.timetable/main.c:295 ../vector/v.net.alloc/main.c:117
-#: ../vector/v.net.allpairs/main.c:99 ../vector/v.net.connectivity/main.c:83
-#: ../vector/v.net.bridge/main.c:79 ../vector/v.net.path/main.c:86
-#: ../vector/v.net.centrality/main.c:135 ../vector/v.net.iso/main.c:127
-msgid "Arc backward direction cost column (number)"
+#: ../raster/r.in.bin/main.c:362 ../raster3d/r3.in.bin/main.c:307
+msgid "Western limit of geographic region (outer edge)"
 msgstr ""
-#: ../display/d.path/main.c:93
-msgid "Node cost column"
+#: ../raster/r.in.bin/main.c:369 ../raster3d/r3.in.bin/main.c:329
+msgid "Number of rows"
+msgstr "Rindu skaits"
+#: ../raster/r.in.bin/main.c:376 ../raster3d/r3.in.bin/main.c:336
+msgid "Number of columns"
+msgstr "Kolonu skaits"
+#: ../raster/r.in.bin/main.c:383 ../raster3d/r3.in.bin/main.c:350
+msgid "Set Value to NULL"
 msgstr ""
-#: ../display/d.path/main.c:101 ../display/d.path/main.c:109
-#: ../display/d.path/main.c:117 ../display/d.path/main.c:127
-msgid "Rendering"
+#: ../raster/r.in.bin/main.c:392
+msgid "Flip input horizontal and/or vertical"
 msgstr ""
-#: ../display/d.path/main.c:122 ../vector/v.net.spanningtree/main.c:84
-#: ../vector/v.net.distance/main.c:159 ../vector/v.net.alloc/main.c:151
-#: ../vector/v.net.allpairs/main.c:112 ../vector/v.net.path/main.c:132
-#: ../vector/v.net.steiner/main.c:398 ../vector/v.net.centrality/main.c:188
-#: ../vector/v.net.iso/main.c:159 ../vector/v.net.salesman/main.c:208
-msgid "Use geodesic calculation for longitude-latitude locations"
+#: ../raster/r.in.bin/main.c:395
+msgid "Flip input horizontal (East - West)"
 msgstr ""
-#: ../display/d.path/main.c:126
-msgid "Render bold lines"
+#: ../raster/r.in.bin/main.c:396
+msgid "Flip input vertical (North - South)"
 msgstr ""
-#: ../display/d.path/main.c:143 ../display/d.path/main.c:147
+#: ../raster/r.in.bin/main.c:410
 #, c-format
-msgid "%s - illegal x value"
+msgid "Option %s must be > 0"
 msgstr ""
-#: ../display/d.path/main.c:145 ../display/d.path/main.c:149
+#: ../raster/r.in.bin/main.c:413
 #, c-format
-msgid "%s - illegal y value"
+msgid "Option %s must be >= 0"
 msgstr ""
-#: ../display/d.path/main.c:178 ../vector/v.net.spanningtree/main.c:113
-#: ../vector/v.net.distance/main.c:205 ../vector/v.net.allpairs/main.c:142
-#: ../vector/v.net.path/main.c:148 ../vector/v.net.centrality/main.c:222
-msgid "The current projection is not longitude-latitude"
+#: ../raster/r.in.bin/main.c:435 ../raster/r.in.bin/main.c:438
+#, c-format
+msgid "Option %s= is ignored if -%c is set"
 msgstr ""
-#: ../display/d.vect.chart/main.c:65
-msgid "chart maps"
+#: ../raster/r.in.bin/main.c:467
+#, c-format
+msgid "-%c incompatible with %s=%d; must be 4 or 8"
 msgstr ""
-#: ../display/d.vect.chart/main.c:67
-msgid "Displays charts of vector data in the active frame on the graphics monitor."
+#: ../raster/r.in.bin/main.c:476
+#, c-format
+msgid "-%c incompatible with %s=%d; must be 8"
 msgstr ""
-#: ../display/d.vect.chart/main.c:86
-msgid "Chart type"
+#: ../raster/r.in.bin/main.c:484
+#, c-format
+msgid "%s= required for integer data"
 msgstr ""
-#: ../display/d.vect.chart/main.c:87 ../display/d.vect.chart/main.c:97
-#: ../display/d.vect.chart/main.c:105 ../display/d.vect.chart/main.c:112
-#: ../display/d.vect.chart/main.c:117 ../display/d.vect.chart/main.c:123
-#: ../display/d.vect.chart/main.c:129 ../display/d.vect.chart/main.c:148
-msgid "Chart properties"
+#: ../raster/r.in.bin/main.c:488
+#, c-format
+msgid "Integer input doesn't support %s=8 in this build"
 msgstr ""
-#: ../display/d.vect.chart/main.c:91
-msgid "Attribute columns containing data"
+#: ../raster/r.in.bin/main.c:493
+#, c-format
+msgid "%s= must be 1, 2, 4 or 8"
 msgstr ""
-#: ../display/d.vect.chart/main.c:96
-msgid "Column used for pie chart size"
+#: ../raster/r.in.bin/main.c:506
+#, c-format
+msgid "Either -%c or %s= and %s= must be given"
 msgstr ""
-#: ../display/d.vect.chart/main.c:104
-msgid "Size of chart (diameter for pie, total width for bar)"
+#: ../raster/r.in.bin/main.c:512
+#, c-format
+msgid "Either all or none of %s=, %s=, %s= and %s= must be given"
 msgstr ""
-#: ../display/d.vect.chart/main.c:111
-msgid "Scale for size (to get size in pixels)"
+#: ../raster/r.in.bin/main.c:521 ../raster3d/r3.in.bin/main.c:424
+#: ../display/d.grid/main.c:266
+#, c-format
+msgid "Illegal north coordinate <%s>"
 msgstr ""
-#: ../display/d.vect.chart/main.c:116
-msgid "Outline color"
+#: ../raster/r.in.bin/main.c:523 ../raster3d/r3.in.bin/main.c:426
+#, c-format
+msgid "Illegal south coordinate <%s>"
 msgstr ""
-#: ../display/d.vect.chart/main.c:122
-msgid "Colors used to fill charts"
+#: ../raster/r.in.bin/main.c:525 ../raster3d/r3.in.bin/main.c:428
+#: ../display/d.grid/main.c:259
+#, c-format
+msgid "Illegal east coordinate <%s>"
 msgstr ""
-#: ../display/d.vect.chart/main.c:128
-msgid "Center the bar chart around a data point"
+#: ../raster/r.in.bin/main.c:527 ../raster3d/r3.in.bin/main.c:430
+#, c-format
+msgid "Illegal west coordinate <%s>"
 msgstr ""
-#: ../display/d.vect.chart/main.c:137
-msgid "Maximum value used for bar plot reference"
+#: ../raster/r.in.bin/main.c:533 ../raster3d/r3.in.bin/main.c:438
+#, c-format
+msgid "Unable to open <%s>"
 msgstr ""
-#: ../display/d.vect.chart/main.c:147
-msgid "Create 3D charts"
+#: ../raster/r.in.bin/main.c:554
+#, c-format
+msgid ""
+"East-West (ewres: %f) and North-South (nwres: %f) resolution differ "
+"significantly. Did you assign %s= and %s= correctly?"
 msgstr ""
-#: ../display/d.info/main.c:38
-msgid "Displays information about the active display monitor."
+#: ../raster/r.in.bin/main.c:575
+msgid "File Size %"
+msgstr "Faila izmērs %"
+#: ../raster/r.in.bin/main.c:577 ../raster3d/r3.in.bin/main.c:448
+msgid "Bytes do not match file size"
 msgstr ""
-#: ../display/d.info/main.c:40
-msgid "Display monitors are maintained by d.mon."
+#: ../raster/r.in.bin/main.c:595
+#, c-format
+msgid "Importing band %d..."
 msgstr ""
-#: ../display/d.info/main.c:45
-msgid "Display screen rectangle (left, right, top, bottom)"
+#: ../raster/r.stats/main.c:109
+msgid "Generates area statistics for raster map."
 msgstr ""
-#: ../display/d.info/main.c:49
-msgid "Display screen dimensions (width, height)"
+#: ../raster/r.stats/main.c:157
+msgid "Print area totals in square meters"
 msgstr ""
-#: ../display/d.info/main.c:53
-msgid "Display active frame rectangle"
+#: ../raster/r.stats/main.c:162
+msgid "Print cell counts (sortable)"
 msgstr ""
-#: ../display/d.info/main.c:57
-msgid "Display frame dimensions (width, height)"
+#: ../raster/r.stats/main.c:168
+msgid "Print approximate (total percent may not be 100%) percents"
 msgstr ""
-#: ../display/d.info/main.c:61
-msgid "Display screen rectangle of current region"
+#: ../raster/r.stats/main.c:173
+msgid "Print category labels"
 msgstr ""
-#: ../display/d.info/main.c:66
-msgid "Display geographic coordinates and resolution of entire frame"
+#: ../raster/r.stats/main.c:177
+msgid "One cell (range) per line"
 msgstr ""
-#: ../display/d.histogram/main.c:84
-msgid "histogram"
+#: ../raster/r.stats/main.c:181
+msgid "Print grid coordinates (east and north)"
 msgstr ""
-#: ../display/d.histogram/main.c:87
-msgid "Displays a histogram in the form of a pie or bar chart for a user-specified raster map."
+#: ../raster/r.stats/main.c:182 ../raster/r.stats/main.c:187
+msgid "Coordinates"
 msgstr ""
-#: ../display/d.histogram/main.c:91
-msgid "Raster map for which histogram will be displayed"
-msgstr "Rastra karte, kurai tiks parādīta histogramma"
+#: ../raster/r.stats/main.c:186
+msgid "Print x and y (column and row)"
+msgstr ""
-#: ../display/d.histogram/main.c:95
-msgid "Indicate if a pie or bar chart is desired"
+#: ../raster/r.stats/main.c:191
+msgid "Print averaged values instead of intervals (floating-point maps only)"
 msgstr ""
-#: ../display/d.histogram/main.c:104
-msgid "Color for text and axes"
+#: ../raster/r.stats/main.c:196
+msgid "Print raw indexes of floating-point ranges (floating-point maps only)"
 msgstr ""
-#: ../display/d.histogram/main.c:115
-msgid "Indicate if cell counts or map areas should be displayed"
+#: ../raster/r.stats/main.c:233
+#, c-format
+msgid "'%s' must be greater than zero; using %s=255"
 msgstr ""
-#: ../display/d.histogram/main.c:125
-msgid "Number of steps to divide the data range into (fp maps only)"
+#: ../raster/r.stats/main.c:303
+#, c-format
+msgid ""
+"Raster map <%s> is reading as integer map! Flag '-%c' and/or '%s' option "
+"will be ignored."
 msgstr ""
-#: ../display/d.histogram/main.c:132
-msgid "Display information for null cells"
-msgstr "Parādīt NULL šūnu informāciju"
-#: ../display/d.histogram/main.c:137
-msgid "Report for ranges defined in cats file (fp maps only)"
+#: ../raster/r.stats/main.c:319
+#, c-format
+msgid ""
+"Cats for raster map <%s> are either missing or have no explicit labels. "
+"Using %s=%d."
 msgstr ""
-#: ../display/d.histogram/main.c:161
+#: ../raster/r.stats/main.c:325
 #, c-format
-msgid "Invalid number of steps: %s"
-msgstr "Nederīgs soļu skaits: %s"
+msgid ""
+"Flag '-%c' was given, using cats fp ranges of raster map <%s>, ignoring '%s' "
+"option"
+msgstr ""
-#: ../display/d.histogram/main.c:166
-msgid "When -C flag is set, the nsteps argument is ignored"
+#: ../raster/r.stats/raw_stats.c:118
+msgid "Invalid map type"
 msgstr ""
-#: ../display/d.histogram/main.c:174 ../ps/ps.map/ps_clrtbl.c:39
+#: ../raster/r.topmodel/topmodel.c:32
 #, c-format
-msgid "Category file for <%s> not available"
+msgid "Unable to run %s"
 msgstr ""
-#: ../display/d.text/main.c:141
-msgid "Draws text in the active display frame on the graphics monitor using the current font."
+#: ../raster/r.topmodel/topmodel.c:74
+#, c-format
+msgid "Invalid %s output"
 msgstr ""
-#: ../display/d.text/main.c:147
-msgid "Text to display"
+#: ../raster/r.topmodel/main.c:55
+msgid "Simulates TOPMODEL which is a physically based hydrologic model."
 msgstr ""
-#: ../display/d.text/main.c:152
-msgid "Input file"
-msgstr "Ieejas fails"
+#: ../raster/r.topmodel/main.c:60
+msgid "Name of input TOPMODEL parameters file"
+msgstr ""
-#: ../display/d.text/main.c:161
-msgid "Text color, either a standard GRASS color or R:G:B triplet"
+#: ../raster/r.topmodel/main.c:65
+msgid "Name of input topographic index statistics file"
 msgstr ""
-#: ../display/d.text/main.c:170
-msgid "Text background color, either a standard GRASS color or R:G:B triplet"
+#: ../raster/r.topmodel/main.c:69
+msgid "Name of input rainfall and potential evapotranspiration data file"
 msgstr ""
-#: ../display/d.text/main.c:180 ../display/d.northarrow/main.c:92
-#: ../vector/v.label/main.c:156
-msgid "Rotation angle in degrees (counter-clockwise)"
+#: ../raster/r.topmodel/main.c:72
+#: ../locale/scriptstrings/d.out.file_to_translate.c:4
+#: ../general/g.list/main.c:114
+msgid "Name for output file"
 msgstr ""
-#: ../display/d.text/main.c:188
-msgid "Line spacing"
+#: ../raster/r.topmodel/main.c:76
+msgid "Time step"
 msgstr ""
-#: ../display/d.text/main.c:197
-msgid "Screen position at which text will begin to be drawn (percentage, [0,0] is lower left)"
+#: ../raster/r.topmodel/main.c:77
+msgid "Generate output for this time step"
 msgstr ""
-#: ../display/d.text/main.c:206
-msgid "The screen line number on which text will begin to be drawn"
+#: ../raster/r.topmodel/main.c:83
+msgid "Topographic index class"
 msgstr ""
-#: ../display/d.text/main.c:215
-msgid "Text alignment"
+#: ../raster/r.topmodel/main.c:85
+msgid "Generate output for this topographic index class"
 msgstr ""
-#: ../display/d.text/main.c:232
-msgid "Height of letters in percentage of available frame height"
+#: ../raster/r.topmodel/main.c:92
+msgid "Name of input topographic index raster map"
 msgstr ""
-#: ../display/d.text/main.c:252
-msgid "Screen position in pixels ([0,0] is top left)"
+#: ../raster/r.topmodel/main.c:94
+msgid ""
+"Must be clipped to the catchment boundary. Used for generating outtopidxstats"
 msgstr ""
-#: ../display/d.text/main.c:257
-msgid "Screen position in geographic coordinates"
+#: ../raster/r.topmodel/main.c:96 ../raster/r.topmodel/main.c:106
+#: ../raster/r.topmodel/main.c:115
+msgid "Preprocess"
 msgstr ""
-#: ../display/d.text/main.c:262
-msgid "Use bold text"
-msgstr "Lietot treknrakstu"
+#: ../raster/r.topmodel/main.c:100
+msgid "Number of topographic index classes"
+msgstr ""
-#: ../display/d.text/main.c:267 ../display/d.northarrow/main.c:144
-msgid "Use radians instead of degrees for rotation"
+#: ../raster/r.topmodel/main.c:102
+msgid "Used for generating outtopidxstats"
 msgstr ""
-#: ../display/d.text/main.c:272
-msgid "Font size is height in pixels"
+#: ../raster/r.topmodel/main.c:111
+msgid "Name for output topographic index statistics file"
 msgstr ""
-#: ../display/d.text/main.c:284
-msgid "Please choose only one placement method"
+#: ../raster/r.topmodel/main.c:113
+msgid "Requires topidx and ntopidxclasses"
 msgstr ""
-#: ../display/d.text/main.c:343
-msgid "Invalid coordinates"
+#: ../raster/r.topmodel/main.c:120
+msgid "Preprocess only and stop after generating outtopidxstats"
 msgstr ""
-#: ../display/d.text/main.c:387
+#: ../raster/r.topmodel/main.c:150
 #, c-format
-msgid ""
-"\n"
-"Please enter text instructions.  Enter EOF (ctrl-d) on last line to quit\n"
+msgid "%s must be greater than 1"
 msgstr ""
-#: ../display/d.text/main.c:578
+#: ../raster/r.topmodel/main.c:154 ../raster/r.topmodel/main.c:157
 #, c-format
-msgid "[%s]: No such color. Use '%s'"
+msgid "Ignoring %s because %s is not specified"
 msgstr ""
-#: ../display/d.fontlist/main.c:47
-msgid "Lists the available fonts."
+#: ../raster/r.topmodel/file_io.c:56
+#, c-format
+msgid "%s cannot be 0"
+msgstr "%s nevar būt 0"
+#: ../raster/r.topmodel/infiltration.c:148
+#: ../raster/r.topmodel/infiltration.c:217
+#, fuzzy, c-format
+msgid "Maximum number of iterations exceeded at time step %d"
 msgstr ""
+"\n"
+"\n"
+"  Punktu skaits: %d\n"
-#: ../display/d.fontlist/main.c:51
-msgid "List fonts (default; provided for compatibility with d.font)"
+#: ../raster/r.resamp.interp/main.c:80
+msgid "Resamples raster map to a finer grid using interpolation."
 msgstr ""
-#: ../display/d.erase/main.c:33
-msgid "Erases the contents of the active graphics display frame with user defined color."
+#: ../raster/r.resamp.interp/main.c:88
+msgid "Method"
+msgstr "Metode"
+#: ../raster/r.resamp.interp/main.c:102 ../imagery/i.topo.corr/main.c:158
+#, c-format
+msgid "Invalid method: %s"
 msgstr ""
-#: ../display/d.erase/main.c:42
-msgid "Remove all frames and erase the screen"
+#: ../raster/r.rescale.eq/main.c:55
+msgid ""
+"Rescales histogram equalized the range of category values in a raster map "
+"layer."
 msgstr ""
-#: ../display/d.where/main.c:48
-msgid "Identifies the geographic coordinates associated with point locations given in display coordinates."
+#: ../raster/r.rescale.eq/main.c:115
+#, c-format
+msgid "Rescale %s[%d,%d] to %s[%d,%d]"
 msgstr ""
-#: ../display/d.where/main.c:58
-msgid "Display coordinates to convert"
+#: ../raster/r.his/main.c:68 ../display/d.his/main.c:64
+#: ../imagery/i.his.rgb/main.c:47 ../imagery/i.rgb.his/main.c:47
+msgid "color transformation"
 msgstr ""
-#: ../display/d.where/main.c:63
-msgid "File from which to read coordinates (\"-\" to read from stdin)"
+#: ../raster/r.his/main.c:73
+msgid ""
+"Generates red, green and blue (RGB) raster map layers combining hue, "
+"intensity and saturation (HIS) values from user-specified input raster map "
+"layers."
 msgstr ""
-#: ../display/d.where/main.c:67
-msgid "Output lat/long in decimal degree"
+#: ../raster/r.his/main.c:82 ../display/d.his/main.c:78
+msgid "Name of layer to be used for hue"
 msgstr ""
-#: ../display/d.where/main.c:72
-msgid "Output lat/long referenced to current ellipsoid"
+#: ../raster/r.his/main.c:89 ../display/d.his/main.c:85
+msgid "Name of layer to be used for intensity"
 msgstr ""
-#: ../display/d.where/main.c:77
-msgid "Output lat/long referenced to WGS84 ellipsoid using datum transformation parameters defined in current location (if available)"
+#: ../raster/r.his/main.c:96 ../display/d.his/main.c:92
+msgid "Name of layer to be used for saturation"
 msgstr ""
-#: ../display/d.where/main.c:83
-msgid "Output frame coordinates of current display monitor (percentage)"
+#: ../raster/r.his/main.c:103
+msgid "Name of output layer to be used for red"
 msgstr ""
-#: ../display/d.where/main.c:91
-msgid "Ambiguous request for lat/long ellipsoids"
+#: ../raster/r.his/main.c:110
+msgid "Name of output layer to be used for green"
 msgstr ""
-#: ../display/d.where/main.c:94
-msgid "Please specify a lat/long ellipsoid with -l or -w"
+#: ../raster/r.his/main.c:117
+msgid "Name of output layer to be used for blue"
 msgstr ""
-#: ../display/d.where/main.c:136
-msgid ""
-"WGS84 output not possible as this location does not contain\n"
+#: ../raster/r.his/main.c:121 ../locale/scriptstrings/r.shade_to_translate.c:12
+msgid "Color to use instead of NULL values"
 msgstr ""
-#: ../display/d.where/where.c:29
+#: ../raster/r.his/main.c:126 ../locale/scriptstrings/r.shade_to_translate.c:14
+msgid "Use colors from color tables for NULL values"
+msgstr ""
+#: ../raster/r.his/main.c:145
 #, c-format
-msgid "Invalid coordinates <%s,%s>"
+msgid "No such color <%s>"
 msgstr ""
-#: ../display/d.title/main.c:52
-msgid "Create a TITLE for a raster map in a form suitable for display with d.text."
+#: ../raster/r.usler/main.c:54
+msgid "rainfall"
+msgstr "lietus"
+#: ../raster/r.usler/main.c:57
+msgid "Computes USLE R factor, Rainfall erosivity index."
 msgstr ""
-#: ../display/d.title/main.c:63
-msgid "Sets the text color"
+#: ../raster/r.usler/main.c:60
+msgid "Name of annual precipitation raster map [mm/year]"
 msgstr ""
-#: ../display/d.title/main.c:71
-msgid "Sets the text size as percentage of the frame's height"
+#: ../raster/r.usler/main.c:63
+msgid "Name for output USLE R raster map [MJ.mm/ha.hr.year]"
 msgstr ""
-#: ../display/d.title/main.c:75
-msgid "Draw title on current display"
+#: ../raster/r.usler/main.c:70
+msgid "Name of USLE R equation"
 msgstr ""
-#: ../display/d.title/main.c:79
-msgid "Do a fancier title"
+#: ../raster/r.usler/main.c:75
+msgid "Roosle (1975)"
 msgstr ""
-#: ../display/d.title/main.c:84
-msgid "Do a simple title"
+#: ../raster/r.usler/main.c:76
+msgid "Morgan (1974)"
 msgstr ""
-#: ../display/d.title/main.c:102
-msgid "Title can be fancy or simple, not both"
+#: ../raster/r.usler/main.c:77
+msgid "Foster (1981)"
 msgstr ""
-#: ../display/d.title/main.c:105
-msgid "No map name given"
+#: ../raster/r.usler/main.c:78
+msgid "El-Swaify (1985)"
 msgstr ""
-#: ../display/d.northarrow/draw_n_arrow.c:108
-#: ../display/d.northarrow/draw_n_arrow.c:174
-msgid "Could not parse symbol"
+#: ../raster/r.watershed/front/main.c:76
+#: ../raster/r.series.accumulate/main.c:82
+#: ../locale/scriptstrings/t.rast.accdetect_to_translate.c:3
+#: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:3
+msgid "accumulation"
 msgstr ""
-#: ../display/d.northarrow/main.c:49
-msgid "Displays a north arrow on the graphics monitor."
+#: ../raster/r.watershed/front/main.c:77
+#, fuzzy
+msgid "drainage"
+msgstr "lietus"
+#: ../raster/r.watershed/front/main.c:79
+msgid "stream power index"
 msgstr ""
-#: ../display/d.northarrow/main.c:53
-msgid "North arrow style"
+#: ../raster/r.watershed/front/main.c:81
+msgid "Calculates hydrological parameters and RUSLE factors."
 msgstr ""
-#: ../display/d.northarrow/main.c:61
-msgid "Two color arrowhead"
+#: ../raster/r.watershed/front/main.c:84 ../raster/r.watershed/front/main.c:91
+#: ../raster/r.watershed/front/main.c:97 ../raster/r.watershed/front/main.c:104
+#: ../raster/r.watershed/front/main.c:113
+#: ../raster/r.watershed/front/main.c:121
+#: ../raster/r.watershed/front/main.c:130
+msgid "Inputs"
 msgstr ""
-#: ../display/d.northarrow/main.c:62
-msgid "Two color arrowhead with circle"
+#: ../raster/r.watershed/front/main.c:88
+msgid "Name of input depressions raster map"
 msgstr ""
-#: ../display/d.northarrow/main.c:63
-msgid "Narrow with blending N"
+#: ../raster/r.watershed/front/main.c:89
+msgid "All non-NULL and non-zero cells are considered as real depressions"
 msgstr ""
-msgid "Long with small arrowhead"
+#: ../raster/r.watershed/front/main.c:95
+msgid "Name of input raster representing amount of overland flow per cell"
 msgstr ""
-#: ../display/d.northarrow/main.c:64
-msgid "Inverted narrow inside a circle"
+#: ../raster/r.watershed/front/main.c:101
+msgid "Name of input raster map percent of disturbed land"
 msgstr ""
-#: ../display/d.northarrow/main.c:65
-msgid "Triangle and N inside a circle"
+#: ../raster/r.watershed/front/main.c:102
+#: ../raster/r.watershed/front/main.c:127
+msgid "For USLE"
 msgstr ""
-#: ../display/d.northarrow/main.c:66
-msgid "Arrowhead and N inside a circle"
+#: ../raster/r.watershed/front/main.c:109
+msgid "Name of input raster map blocking overland surface flow"
 msgstr ""
-#: ../display/d.northarrow/main.c:67
-msgid "Tall half convex arrowhead"
+#: ../raster/r.watershed/front/main.c:111
+msgid ""
+"For USLE. All non-NULL and non-zero cells are considered as blocking terrain."
 msgstr ""
-#: ../display/d.northarrow/main.c:68
-msgid "Tall half concave arrowhead"
+#: ../raster/r.watershed/front/main.c:118
+msgid "Minimum size of exterior watershed basin"
 msgstr ""
-msgid "Thin arrow in a circle"
+#: ../raster/r.watershed/front/main.c:126
+msgid "Maximum length of surface flow in map units"
 msgstr ""
-#: ../display/d.northarrow/main.c:69
-msgid "Fat arrow in a circle"
+#: ../raster/r.watershed/front/main.c:135
+msgid "Name for output accumulation raster map"
 msgstr ""
-msgid "One color arrowhead"
+#: ../raster/r.watershed/front/main.c:137
+msgid "Number of cells that drain through each cell"
 msgstr ""
-#: ../display/d.northarrow/main.c:70
-msgid "Fancy compass"
+#: ../raster/r.watershed/front/main.c:144
+msgid "Name for output topographic index ln(a / tan(b)) map"
 msgstr ""
-msgid "Basic compass"
+#: ../raster/r.watershed/front/main.c:151
+msgid "Stream power index a * tan(b)"
 msgstr ""
-msgid "Simple arrow"
+#: ../raster/r.watershed/front/main.c:157
+msgid "Name for output drainage direction raster map"
 msgstr ""
-#: ../display/d.northarrow/main.c:71
-msgid "Thin arrow"
+#: ../raster/r.watershed/front/main.c:158
+msgid "Directions numbered from 1 to 8"
 msgstr ""
-msgid "Fat arrow"
+#: ../raster/r.watershed/front/main.c:164
+msgid "Name for output basins raster map"
 msgstr ""
-msgid "4-point star"
+#: ../raster/r.watershed/front/main.c:170
+msgid "Name for output stream segments raster map"
 msgstr ""
-#: ../display/d.northarrow/main.c:99
-msgid "Displayed letter on the top of arrow"
+#: ../raster/r.watershed/front/main.c:176
+msgid "Name for output half basins raster map"
 msgstr ""
-#: ../display/d.northarrow/main.c:108
-msgid "Fill color"
-msgstr "Azipildījuma krāsa"
+#: ../raster/r.watershed/front/main.c:178
+msgid "Each half-basin is given a unique value"
+msgstr ""
-#: ../display/d.northarrow/main.c:134
-msgid "Draw the symbol without text"
+#: ../raster/r.watershed/front/main.c:184
+msgid "Name for output slope length raster map"
 msgstr ""
-#: ../display/d.northarrow/main.c:139
-msgid "Do not rotate text with symbol"
+#: ../raster/r.watershed/front/main.c:186
+msgid "Slope length and steepness (LS) factor for USLE"
 msgstr ""
-#: ../display/d.linegraph/main.c:234
-msgid "Generates and displays simple line graphs in the active graphics monitor display frame."
+#: ../raster/r.watershed/front/main.c:192
+msgid "Name for output slope steepness raster map"
 msgstr ""
-#: ../display/d.linegraph/main.c:238
-msgid "Name of data file for X axis of graph"
+#: ../raster/r.watershed/front/main.c:193
+msgid "Slope steepness (S) factor for USLE"
 msgstr ""
-#: ../display/d.linegraph/main.c:244
-msgid "Name of data file(s) for Y axis of graph"
+#: ../raster/r.watershed/front/main.c:202
+msgid "Convergence factor for MFD (1-10)"
 msgstr ""
-#: ../display/d.linegraph/main.c:251
-#, fuzzy
-msgid "Path to files"
-msgstr "Esošā rastra faila nosaukums"
+#: ../raster/r.watershed/front/main.c:204
+msgid "1 = most diverging flow, 10 = most converging flow. Recommended: 5"
+msgstr ""
-#: ../display/d.linegraph/main.c:253
-msgid "Path to the directory where the input files are located"
+#: ../raster/r.watershed/front/main.c:211
+msgid "Maximum memory to be used with -m flag (in MB)"
 msgstr ""
-#: ../display/d.linegraph/main.c:261
-msgid "Color for Y data"
+#: ../raster/r.watershed/front/main.c:215
+msgid "SFD (D8) flow (default is MFD)"
 msgstr ""
-#: ../display/d.linegraph/main.c:274
-#, fuzzy
-msgid "Width of the lines"
-msgstr "Sākuma punkta koordinātes"
+#: ../raster/r.watershed/front/main.c:217
+msgid "SFD: single flow direction, MFD: multiple flow direction"
+msgstr ""
-#: ../display/d.linegraph/main.c:281
-msgid "Color for axis, tics, numbers, and title"
+#: ../raster/r.watershed/front/main.c:222
+msgid "Allow only horizontal and vertical flow of water"
+msgstr "Atļaut tikai horizontālu un vertikālu ūdens plūsmu"
+#: ../raster/r.watershed/front/main.c:227
+msgid "Enable disk swap memory option: Operation is slow"
 msgstr ""
-#: ../display/d.linegraph/main.c:289
-msgid "Title for X data"
+#: ../raster/r.watershed/front/main.c:229
+msgid ""
+"Only needed if memory requirements exceed available RAM; see manual on how "
+"to calculate memory requirements"
 msgstr ""
-#: ../display/d.linegraph/main.c:296
-msgid "Title for Y data"
+#: ../raster/r.watershed/front/main.c:234
+msgid "Use positive flow accumulation even for likely underestimates"
 msgstr ""
-#: ../display/d.linegraph/main.c:303
-msgid "Title for Graph"
+#: ../raster/r.watershed/front/main.c:236
+msgid "See manual for a detailed description of flow accumulation output"
 msgstr ""
-#: ../display/d.linegraph/main.c:311
-msgid "Minimum and maximun value for Y axis (min,max)"
+#: ../raster/r.watershed/front/main.c:241
+msgid "Beautify flat areas"
 msgstr ""
-#: ../display/d.linegraph/main.c:318
-msgid "Tic values for the Y axis"
+#: ../raster/r.watershed/front/main.c:243
+msgid "Flow direction in flat areas is modified to look prettier"
 msgstr ""
-#: ../display/d.linegraph/main.c:325
-#, fuzzy
-msgid "Scale for X values"
-msgstr "Rastra izejas fails"
+#: ../raster/r.watershed/front/main.c:259
+msgid "Sorry, you must choose an output map."
+msgstr "Piedodiet, jums ir jāizvēlas izvades karte."
-#: ../display/d.linegraph/main.c:331
-#, fuzzy
-msgid "Scale for Y values"
+#: ../raster/r.watershed/front/main.c:265
+msgid "The basin threshold must be a positive number."
+msgstr ""
-#: ../display/d.linegraph/main.c:352
-#, fuzzy
-msgid "Symbol for point"
-msgstr "Punktu skaits:"
+#: ../raster/r.watershed/front/main.c:281
+msgid ""
+"Sorry, if any of the following options are set:\n"
+"    basin, stream, half_basin, length_slope, or slope_steepness\n"
+"    you MUST provide a value for the basin threshold parameter."
+msgstr ""
-#: ../display/d.linegraph/main.c:361
-#, fuzzy
-msgid "Point size"
-msgstr "Fonta nosaukums"
+#: ../raster/r.watershed/front/main.c:308
+msgid "Beautify flat areas is not yet supported for disk swap mode"
+msgstr ""
-#: ../display/d.linegraph/main.c:370
-msgid "Color for point symbol edge color"
+#: ../raster/r.watershed/front/main.c:338
+#, c-format
+msgid "Subprocess failed with exit code %d"
 msgstr ""
-#: ../display/d.linegraph/main.c:376
-#, fuzzy
-msgid "Width of point symbol lines"
-#: ../display/d.linegraph/main.c:437
-msgid "Maximum of 10 Y data files exceeded"
+#: ../raster/r.watershed/shed/main.c:41
+msgid "Slow version of water analysis program starting now"
 msgstr ""
-#: ../display/d.linegraph/main.c:494
-#, fuzzy, c-format
-msgid "Cannot find/open symbol: '%s'"
-msgstr "Nevar izveidot jaunu rindu: %s"
-#: ../display/d.linegraph/main.c:511
-#, fuzzy, c-format
-msgid "Color <%s> cannot for option %s be parsed"
-msgstr "reģions <%s> nav atrasts"
-#: ../display/d.linegraph/main.c:549
+#: ../raster/r.watershed/shed/main.c:46 ../raster/r.watershed/shed/main.c:55
 #, c-format
-msgid "Only <%d> colors given for <%d> lines"
+msgid "<<%s>> command line failed"
 msgstr ""
-#: ../display/d.linegraph/main.c:593
-#, fuzzy, c-format
-msgid "Number of widths (%d) is higher then the number of files (%d)"
-msgstr "Augstuma karšu skaits neatbilst krāsu kašu skaitam"
+#: ../raster/r.watershed/shed/main.c:72
+msgid "unable to open output file"
+msgstr ""
-#: ../display/d.linegraph/main.c:606
-#, fuzzy, c-format
-msgid "Number of widths (%d) is lower then the number of files (%d)"
-#: ../display/d.linegraph/main.c:659
+#: ../raster/r.watershed/shed/intro.c:8
 #, c-format
-msgid "Y input file <%s> contains fewer data points than the X input file"
+msgid "%s provides a text-based user-interface to the %s program."
 msgstr ""
-#: ../display/d.linegraph/main.c:663
+#: ../raster/r.watershed/shed/intro.c:10
 #, c-format
-msgid "Y input file <%s> contains more data points than the X input file"
+msgid "%s also allows the user to prepare a report of map layers for each"
 msgstr ""
-#: ../display/d.linegraph/main.c:668
+#: ../raster/r.watershed/shed/intro.c:12
 #, c-format
-msgid "The last point will be ignored"
-msgid_plural "The last %d points will be ignored"
-msgstr[0] ""
-msgstr[1] ""
-msgstr[2] ""
+msgid "watershed basin determined in %s.\n"
+msgstr ""
-#: ../display/d.linegraph/main.c:722
+#: ../raster/r.watershed/shed/intro.c:14
 #, c-format
-msgid "Scale X labels cannot be used with this range of data (%f, %f)"
+msgid "%s will help the user determine which options to use for the"
 msgstr ""
-#: ../display/d.linegraph/main.c:752
+#: ../raster/r.watershed/shed/intro.c:16
 #, c-format
-msgid "Problem reading X data file at line %d"
+msgid "%s program.  %s will then ask for map layers that will be"
 msgstr ""
-#: ../display/d.linegraph/main.c:764
+#: ../raster/r.watershed/shed/intro.c:18
 #, c-format
-msgid "Problem reading <%s> data file at line %d"
+msgid "divided by basin. %s will then run %s and create the report."
 msgstr ""
-#: ../display/d.linegraph/main.c:971
-#, c-format
-msgid "Scale Y labels cannot be used with thisrange of data (%f, %f)"
+#: ../raster/r.watershed/shed/file_in.c:15
+msgid "unable to open ARMSED file"
 msgstr ""
-#: ../display/d.rgb/main.c:58
-msgid "Displays three user-specified raster maps as red, green, and blue overlays in the active graphics frame."
+#: ../raster/r.watershed/shed/read.c:23
+msgid "unable to open basin/half basin map"
 msgstr ""
-#: ../vector/v.net.spanningtree/main.c:48
-msgid "spanning tree"
+#: ../raster/r.watershed/shed/basin_maps.c:12
+msgid ""
+"\n"
+"\n"
+"Please indicate which map layers you wish to use in the lumped"
 msgstr ""
-#: ../vector/v.net.spanningtree/main.c:50
-msgid "Computes minimum spanning tree for the network."
+#: ../raster/r.watershed/shed/basin_maps.c:13
+msgid "parameter hydrologic/soil erosion model.  Continue inputing cell map"
 msgstr ""
-#: ../vector/v.net.spanningtree/main.c:60
-#: ../vector/v.net.spanningtree/main.c:66
-#: ../vector/v.net.spanningtree/main.c:73
-#: ../vector/v.net.spanningtree/main.c:79 ../vector/v.net.components/main.c:85
-#: ../vector/v.net.components/main.c:91 ../vector/v.net.components/main.c:98
-#: ../vector/v.net.components/main.c:104 ../vector/v.net.components/main.c:111
-#: ../vector/v.net.distance/main.c:83 ../vector/v.net.distance/main.c:90
-#: ../vector/v.net.distance/main.c:96 ../vector/v.net.distance/main.c:142
-#: ../vector/v.net.distance/main.c:148 ../vector/v.net.distance/main.c:154
-#: ../vector/v.net.flow/main.c:71 ../vector/v.net.flow/main.c:77
-#: ../vector/v.net.flow/main.c:91 ../vector/v.net.flow/main.c:97
-#: ../vector/v.net.flow/main.c:103 ../vector/v.net.timetable/main.c:275
-#: ../vector/v.net.timetable/main.c:281 ../vector/v.net.timetable/main.c:289
-#: ../vector/v.net.timetable/main.c:296 ../vector/v.net.timetable/main.c:303
-#: ../vector/v.net.alloc/main.c:77 ../vector/v.net.alloc/main.c:111
-#: ../vector/v.net.alloc/main.c:118 ../vector/v.net.alloc/main.c:125
-#: ../vector/v.net.allpairs/main.c:94 ../vector/v.net.allpairs/main.c:100
-#: ../vector/v.net.allpairs/main.c:107 ../vector/v.net.connectivity/main.c:65
-#: ../vector/v.net.connectivity/main.c:71
-#: ../vector/v.net.connectivity/main.c:78
-#: ../vector/v.net.connectivity/main.c:84
-#: ../vector/v.net.connectivity/main.c:92 ../vector/v.net.bridge/main.c:61
-#: ../vector/v.net.bridge/main.c:67 ../vector/v.net.bridge/main.c:74
-#: ../vector/v.net.bridge/main.c:80 ../vector/v.net.bridge/main.c:87
-#: ../vector/v.net.path/main.c:80 ../vector/v.net.path/main.c:87
-#: ../vector/v.net.path/main.c:94 ../vector/v.net.centrality/main.c:110
-#: ../vector/v.net.centrality/main.c:116 ../vector/v.net.centrality/main.c:130
-#: ../vector/v.net.centrality/main.c:136 ../vector/v.net.centrality/main.c:143
-#: ../vector/v.net.iso/main.c:123 ../vector/v.net.iso/main.c:128
-#: ../vector/v.net.iso/main.c:133 ../vector/v.net.salesman/main.c:169
-#: ../vector/v.net.salesman/main.c:177
-msgid "Cost"
-msgstr "Izmaksas"
+#: ../raster/r.watershed/shed/basin_maps.c:14
+msgid "layers, one at a time, until all desired map layers are in."
+msgstr ""
-#: ../vector/v.net.spanningtree/main.c:78 ../vector/v.net.components/main.c:110
-#: ../vector/v.net.distance/main.c:153 ../vector/v.net.flow/main.c:102
-#: ../vector/v.net.timetable/main.c:302 ../vector/v.net.alloc/main.c:124
-#: ../vector/v.net.allpairs/main.c:106 ../vector/v.net.connectivity/main.c:91
-#: ../vector/v.net.bridge/main.c:86 ../vector/v.net.path/main.c:93
-#: ../vector/v.net.centrality/main.c:142 ../vector/v.net.iso/main.c:132
-msgid "Node cost column (number)"
+#: ../raster/r.watershed/shed/basin_maps.c:15
+#, c-format
+msgid "You can have %s include a list of categories in each."
 msgstr ""
-#: ../vector/v.net.spanningtree/main.c:124
-#: ../vector/v.net.components/main.c:163 ../vector/v.net.distance/main.c:264
-#: ../vector/v.net.flow/main.c:226 ../vector/v.net.timetable/main.c:405
-#: ../vector/v.net.connectivity/main.c:178 ../vector/v.net.bridge/main.c:134
-#: ../vector/v.net.centrality/main.c:284 ../vector/v.generalize/network.c:89
+#: ../raster/r.watershed/shed/basin_maps.c:17
 #, c-format
-msgid "Unable to build graph for vector map <%s>"
+msgid ""
+"\n"
+"Hit <return> at the map prompt to continue with %s"
 msgstr ""
-#: ../vector/v.surf.rst/main.c:150 ../vector/v.extrude/main.c:70
-#: ../vector/v.to.3d/main.c:38 ../vector/v.out.postgis/main.c:49
-#: ../vector/v.kriging/main.c:69 ../vector/v.kriging/main.c:163
-#: ../vector/v.drape/main.c:59 ../vector/v.hull/main.c:54
-msgid "3D"
-msgstr "3D"
-#: ../vector/v.surf.rst/main.c:151
-msgid "Performs surface interpolation from vector points map by splines."
+#: ../raster/r.watershed/shed/basin_maps.c:36
+#, c-format
+msgid ""
+"\n"
+"The output from %s will be divided into watershed"
 msgstr ""
-#: ../vector/v.surf.rst/main.c:153
-msgid "Spatial approximation and topographic analysis from given point or isoline data in vector format to floating point raster format using regularized spline with tension."
+#: ../raster/r.watershed/shed/basin_maps.c:38
+msgid "basins.  There are two possible methods of tabulating the information:"
 msgstr ""
-#: ../vector/v.surf.rst/main.c:160
-msgid "Perform cross-validation procedure without raster approximation"
+#: ../raster/r.watershed/shed/basin_maps.c:39
+msgid "1) by only including data pertaining to the basin itself, or 2) using"
 msgstr ""
-#: ../vector/v.surf.rst/main.c:165
-msgid "Use scale dependent tension"
+#: ../raster/r.watershed/shed/basin_maps.c:40
+msgid "data from the basin, and all basins upstream of it."
 msgstr ""
-#: ../vector/v.surf.rst/main.c:184 ../vector/v.surf.bspline/main.c:118
-msgid "Name of the attribute column with values to be used for approximation"
+#: ../raster/r.watershed/shed/basin_maps.c:43
+msgid ""
+"\n"
+"Would you like the data organized:"
 msgstr ""
-#: ../vector/v.surf.rst/main.c:185 ../vector/v.surf.idw/main.c:102
-msgid "If not given and input is 2D vector map then category values are used. If input is 3D vector map then z-coordinates are used."
+#: ../raster/r.watershed/shed/basin_maps.c:44
+msgid ""
+"1) Basin only\n"
+"2) Upstream only\n"
+"3) Both\n"
+"OR 0) to cancel program"
 msgstr ""
-#: ../vector/v.surf.rst/main.c:195
-msgid "Name for output surface elevation raster map"
+#: ../raster/r.watershed/shed/basin_maps.c:45
+#, c-format
+msgid ""
+"\n"
+"Your choice: "
 msgstr ""
-#: ../vector/v.surf.rst/main.c:225
-msgid "Name for output mean curvature raster map"
+#: ../raster/r.watershed/shed/basin_maps.c:69
+#: ../raster/r.watershed/shed/basin_maps.c:73
+#, c-format
+msgid ""
+"\n"
+"OK, %s should start running now using the following form:\n"
+"%s"
 msgstr ""
-#: ../vector/v.surf.rst/main.c:231 ../vector/v.vol.rst/main.c:290
-msgid "Name for output deviations vector point map"
+#: ../raster/r.watershed/shed/com_line.c:23
+msgid ""
+"\n"
+"This set of questions will organize the command line for the"
 msgstr ""
-#: ../vector/v.surf.rst/main.c:238 ../vector/v.vol.rst/main.c:296
-msgid "Name for output cross-validation errors vector point map"
+#: ../raster/r.watershed/shed/com_line.c:24
+#, c-format
+msgid "%s program to run properly for your application."
 msgstr ""
-#: ../vector/v.surf.rst/main.c:245
-msgid "Name for output vector map showing quadtree segmentation"
+#: ../raster/r.watershed/shed/com_line.c:26
+#, c-format
+msgid "The first question is whether you want %s to run"
 msgstr ""
-#: ../vector/v.surf.rst/main.c:252
-msgid "Name for output vector map showing overlapping windows"
+#: ../raster/r.watershed/shed/com_line.c:28
+#, c-format
+msgid "in its fast mode or its slow mode.  If you run %s"
 msgstr ""
-#: ../vector/v.surf.rst/main.c:261
-#, fuzzy
-msgid "Number of threads for parallel computing"
-msgstr "Drukājamo kopiju sakits"
-#: ../vector/v.surf.rst/main.c:267
-msgid "Name of raster map used as mask"
+#: ../raster/r.watershed/shed/com_line.c:30
+msgid "in the fast mode, the computer will finish about 10 times faster"
 msgstr ""
-#: ../vector/v.surf.rst/main.c:275 ../vector/v.vol.rst/main.c:267
-msgid "Tension parameter"
+#: ../raster/r.watershed/shed/com_line.c:31
+msgid "than in the slow mode, but will not allow other programs to run"
 msgstr ""
-#: ../vector/v.surf.rst/main.c:282 ../vector/v.vol.rst/main.c:275
-msgid "Smoothing parameter"
+#: ../raster/r.watershed/shed/com_line.c:32
+msgid "at the same time.  The fast mode also places all of the data into"
 msgstr ""
-#: ../vector/v.surf.rst/main.c:290
-msgid "Name of the attribute column with smoothing parameters"
+#: ../raster/r.watershed/shed/com_line.c:33
+msgid "RAM, which limits the size of window that can be run.  The slow"
 msgstr ""
-#: ../vector/v.surf.rst/main.c:315 ../vector/v.vol.rst/main.c:336
-msgid "Minimum distance between points (to remove almost identical points)"
+#: ../raster/r.watershed/shed/com_line.c:34
+msgid "mode uses disk space in the same hard disk partition as where GRASS is"
 msgstr ""
-#: ../vector/v.surf.rst/main.c:323
-msgid "Maximum distance between points on isoline (to insert additional points)"
+#: ../raster/r.watershed/shed/com_line.c:35
+msgid "stored.  Thus, if the program does not work in the slow mode, you will"
 msgstr ""
-#: ../vector/v.surf.rst/main.c:332
-msgid "Conversion factor for values used for approximation"
+#: ../raster/r.watershed/shed/com_line.c:36
+msgid "need to remove unnecessary files from that partition.  The slow mode"
 msgstr ""
-#: ../vector/v.surf.rst/main.c:404
+#: ../raster/r.watershed/shed/com_line.c:37
 #, c-format
-msgid "<%d> is not valid number of threads. Number of threads will be set on <%d>"
+msgid "will allow other processes to run concurrently with %s.\n"
 msgstr ""
-#: ../vector/v.surf.rst/main.c:409
-msgid "Parallel computation disabled when deviation output is required"
+#: ../raster/r.watershed/shed/com_line.c:69
+#: ../raster/r.watershed/shed/com_line.c:182
+msgid ""
+"\n"
+"If you hit <return> by itself for the next question, this"
 msgstr ""
-#: ../vector/v.surf.rst/main.c:416
-msgid "GRASS GIS is not compiled with OpenMP support, parallel computation is disabled."
+#: ../raster/r.watershed/shed/com_line.c:70
+#: ../raster/r.watershed/shed/com_line.c:183
+msgid "program will terminate."
 msgstr ""
-#: ../vector/v.surf.rst/main.c:421 ../vector/v.surf.rst/main.c:426
-#: ../vector/v.surf.rst/main.c:431 ../vector/v.surf.rst/main.c:436
+#: ../raster/r.watershed/shed/com_line.c:81
 #, c-format
-msgid "Output vector map name <%s> is not valid map name"
+msgid ""
+"\n"
+"One of the options for %s is a `depression map'.  A"
 msgstr ""
-#: ../vector/v.surf.rst/main.c:449
-msgid "You are not outputting any raster or vector maps"
+#: ../raster/r.watershed/shed/com_line.c:83
+msgid ""
+"depression map indicates all the locations in the current map window where"
 msgstr ""
-#: ../vector/v.surf.rst/main.c:458
-msgid "Both cross-validation options (-c flag and cvdev vector output) must be specified"
+#: ../raster/r.watershed/shed/com_line.c:84
+msgid ""
+"water accumulates and does not leave by the edge of the map. Lakes without"
 msgstr ""
-#: ../vector/v.surf.rst/main.c:461
-msgid "The cross-validation cannot be computed simultaneously with output raster or devi file"
+#: ../raster/r.watershed/shed/com_line.c:85
+msgid ""
+"outlet streams and sinkholes are examples of `depressions'.  If you wish to"
 msgstr ""
-#: ../vector/v.surf.rst/main.c:479
-msgid "Using anisotropy - both theta and scalex have to be specified"
+#: ../raster/r.watershed/shed/com_line.c:86
+msgid "have a depression map, prepare a map where non-zero values indicate the"
 msgstr ""
-#: ../vector/v.surf.rst/main.c:487
-msgid "Both smatt and smooth options specified - using constant"
+#: ../raster/r.watershed/shed/com_line.c:87
+msgid "locations where depressions occur.\n"
 msgstr ""
-#: ../vector/v.surf.rst/main.c:497
-msgid "The computation will last too long - lower npmin is suggested"
+#: ../raster/r.watershed/shed/com_line.c:88
+msgid ""
+"Hit <return> by itself for the next question if there is no depression map."
 msgstr ""
-#: ../vector/v.surf.rst/main.c:515 ../vector/v.surf.rst/main.c:520
-#: ../vector/v.surf.rst/main.c:524 ../vector/v.surf.rst/main.c:529
-#: ../vector/v.surf.rst/main.c:533 ../vector/v.surf.rst/main.c:537
-#: ../vector/v.vol.rst/main.c:507 ../vector/v.vol.rst/main.c:510
-#: ../vector/v.vol.rst/main.c:513 ../vector/v.vol.rst/main.c:516
-#: ../vector/v.vol.rst/main.c:519 ../vector/v.vol.rst/main.c:522
-#: ../vector/v.vol.rst/main.c:525 ../vector/v.vol.rst/main.c:528
-#: ../vector/v.vol.rst/main.c:531 ../vector/v.vol.rst/main.c:534
-#: ../vector/v.vol.rst/main.c:621 ../vector/v.vol.rst/main.c:652
-#: ../vector/v.vol.rst/main.c:674 ../vector/v.vol.rst/main.c:696
-#: ../vector/v.vol.rst/main.c:718 ../vector/v.vol.rst/main.c:740
-#: ../vector/v.vol.rst/main.c:762 ../vector/v.vol.rst/main.c:784
-#: ../vector/v.vol.rst/user3.c:273 ../vector/v.vol.rst/user3.c:279
-#: ../vector/v.vol.rst/user3.c:285 ../vector/v.vol.rst/user2.c:122
-#: ../vector/v.vol.rst/user2.c:232
+#: ../raster/r.watershed/shed/com_line.c:99
 #, c-format
-msgid "Not enough memory for %s"
+msgid ""
+"\n"
+"The %s program will divide the elevation map into a number of"
 msgstr ""
-#: ../vector/v.surf.rst/main.c:544 ../vector/v.surf.rst/main.c:550
-#: ../vector/v.surf.rst/main.c:553 ../vector/v.surf.rst/main.c:557
-#: ../vector/v.vol.rst/main.c:539 ../vector/v.vol.rst/main.c:544
-#: ../vector/v.vol.rst/main.c:546
-#, c-format
-msgid "Unable to create %s"
+#: ../raster/r.watershed/shed/com_line.c:101
+msgid ""
+"watershed basins.  The number of watershed basins is indirectly determined"
 msgstr ""
-#: ../vector/v.surf.rst/main.c:570 ../vector/v.out.ascii/main.c:104
-#: ../vector/v.colors/main.c:270 ../vector/v.colors.out/make_colors.c:27
-#: ../vector/v.colors.out/scan_cats.c:24
-#, c-format
-msgid "Layer <%s> not found"
+#: ../raster/r.watershed/shed/com_line.c:102
+msgid ""
+"by the `basin threshold' value.  The basin threshold is the area necessary "
+"for"
 msgstr ""
-#: ../vector/v.surf.rst/main.c:574 ../vector/v.surf.bspline/main.c:272
-msgid "Input is 3D: using attribute values instead of z-coordinates for approximation"
+#: ../raster/r.watershed/shed/com_line.c:103
+#, c-format
+msgid "%s to define a unique watershed basin.  This area only applies to"
 msgstr ""
-#: ../vector/v.surf.rst/main.c:576 ../vector/v.surf.bspline/main.c:274
-msgid "Input is 3D: using z-coordinates for approximation"
+#: ../raster/r.watershed/shed/com_line.c:105
+msgid ""
+"`exterior drainage basins'.  An exterior drainage basin does not have any"
 msgstr ""
-#: ../vector/v.surf.rst/main.c:580
-msgid "Input is 2D: using attribute values for approximation"
+#: ../raster/r.watershed/shed/com_line.c:106
+msgid ""
+"drainage basins flowing into it.  Interior drainage basin size is determined"
 msgstr ""
-#: ../vector/v.surf.rst/main.c:582
-msgid "Input is 2D: using category values for approximation"
+#: ../raster/r.watershed/shed/com_line.c:107
+msgid ""
+"by the surface flow going into stream segments between stream interceptions."
 msgstr ""
-#: ../vector/v.surf.rst/main.c:625 ../vector/v.vol.rst/main.c:605
+#: ../raster/r.watershed/shed/com_line.c:108
 #, c-format
-msgid "Unable to create table '%s'"
+msgid "Thus interior drainage basins can be of any size.  The %s program"
 msgstr ""
-#: ../vector/v.surf.rst/main.c:695
-#, c-format
-msgid "Processing all selected output files will require %d bytes of disk space for temp files"
+#: ../raster/r.watershed/shed/com_line.c:110
+msgid "also allows the user to relate basin size to potential overland flow"
 msgstr ""
-#: ../vector/v.surf.rst/main.c:716
-#, fuzzy
-msgid "Processing segments in parallel..."
-msgstr "Izveidot punktus visā garumā ilīniju garumā"
+#: ../raster/r.watershed/shed/com_line.c:111
+msgid ""
+"(i.e., areas with low infiltration capacities will need smaller areas to"
+msgstr ""
-#: ../vector/v.surf.rst/main.c:722 ../vector/v.surf.rst/main.c:731
-msgid "Interp_segmets failed"
+#: ../raster/r.watershed/shed/com_line.c:112
+msgid ""
+"develop stream channels than neighboring areas with high infiltration rates)."
 msgstr ""
-#: ../vector/v.surf.rst/main.c:725
-msgid "Processing segments..."
+#: ../raster/r.watershed/shed/com_line.c:113
+msgid ""
+"The user can create a map layer with potential overland flow values, and"
 msgstr ""
-#: ../vector/v.surf.rst/main.c:749
-msgid "Unable to write raster maps - try to increase resolution"
+#: ../raster/r.watershed/shed/com_line.c:114
+#, c-format
+msgid "%s will accumulate those values instead of area.\n"
 msgstr ""
-#: ../vector/v.what.rast3/main.c:70 ../vector/v.drape/main.c:60
-#: ../vector/v.what.rast/main.c:77
-msgid "surface information"
+#: ../raster/r.watershed/shed/com_line.c:116
+msgid "What unit of measure will you use for the basin threshold:"
 msgstr ""
-#: ../vector/v.what.rast3/main.c:72
-msgid "Uploads 3D raster values at positions of vector points to the table."
+#: ../raster/r.watershed/shed/com_line.c:119
+msgid " 1) acres,          2) meters sq., 3) miles sq., 4) hectares,"
 msgstr ""
-#: ../vector/v.what.rast3/main.c:82
-msgid "Name of existing 3D raster map to be queried"
+#: ../raster/r.watershed/shed/com_line.c:120
+msgid " 5) kilometers sq., 6) map cells,  7) overland flow units"
 msgstr ""
-#: ../vector/v.what.rast3/main.c:135
+#: ../raster/r.watershed/shed/com_line.c:121
 #, c-format
-msgid "Error opening 3D raster map <%s>"
+msgid "Choose 1-7 or 0 to exit this program: "
 msgstr ""
-#: ../vector/v.what.rast3/main.c:141 ../vector/v.to.rast/support.c:308
-#: ../vector/v.to.rast/support.c:547 ../vector/v.to.rast/vect2rast.c:69
-#: ../scripts/v.dissolve/v.dissolve.py:85
-#: ../scripts/v.db.update/v.db.update.py:98
-#, c-format, python-format
-msgid "Column <%s> not found"
+#: ../raster/r.watershed/shed/com_line.c:131
+msgid ""
+"\n"
+"How large an area (or how many overland flow units) must a drainage basin"
 msgstr ""
-#: ../vector/v.what.rast3/main.c:144
-msgid "Column type not supported, please use a column with double type"
+#: ../raster/r.watershed/shed/com_line.c:132
+#, c-format
+msgid "be for it to be an exterior drainage basin: "
 msgstr ""
-#: ../vector/v.what.rast3/main.c:158 ../vector/v.what.rast/main.c:206
-msgid "Reading features from vector map..."
+#: ../raster/r.watershed/shed/com_line.c:201
+#, c-format
+msgid ""
+"\n"
+"%s must create a map layer of watershed basins"
 msgstr ""
-#: ../vector/v.what.rast3/main.c:215
+#: ../raster/r.watershed/shed/com_line.c:203
+#: ../raster/r.watershed/shed/com_line.c:224
 #, c-format
-msgid "%d point outside current region was skipped"
-msgid_plural "%d points outside current region were skipped"
-msgstr[0] ""
-msgstr[1] ""
-msgstr[2] ""
+msgid "before %s can run properly."
+msgstr ""
-#: ../vector/v.what.rast3/main.c:220
+#: ../raster/r.watershed/shed/com_line.c:222
 #, c-format
-msgid "%d point without category was skipped"
-msgid_plural "%d points without category were skipped"
-msgstr[0] ""
-msgstr[1] ""
-msgstr[2] ""
+msgid ""
+"\n"
+"%s must create a file of watershed basin relationships"
+msgstr ""
-#: ../vector/v.what.rast3/main.c:259
+#: ../raster/r.watershed/shed/com_line.c:228
+#: ../raster/r.watershed/shed/com_line.c:263
 #, c-format
-msgid "More points (%d) of category %d, value set to 'NULL'"
+msgid ""
+"\n"
+"Please name this file:"
 msgstr ""
-#: ../vector/v.what.rast3/main.c:272 ../vector/v.label.sa/labels.c:166
-#: ../vector/v.sample/main.c:226 ../vector/v.sample/main.c:234
-#: ../vector/v.vol.rst/user1.c:172 ../vector/v.what.rast/main.c:623
-#: ../vector/v.label/main.c:325 ../vector/v.buffer/main.c:526
-#: ../vector/v.buffer/main.c:628
+#: ../raster/r.watershed/shed/com_line.c:257
 #, c-format
-msgid "No record for category %d in table <%s>"
+msgid ""
+"\n"
+"%s will generate a lot of output.  Indicate a file"
 msgstr ""
-#: ../vector/v.what.rast3/main.c:329
+#: ../raster/r.watershed/shed/com_line.c:259
 #, c-format
-msgid "%d category loaded from table"
-msgid_plural "%d categories loaded from table"
-msgstr[0] ""
-msgstr[1] ""
-msgstr[2] ""
+msgid "name for %s to send the output to."
+msgstr ""
-#: ../vector/v.what.rast3/main.c:332
+#: ../raster/r.watershed/shed/com_line.c:277
 #, c-format
-msgid "%d category loaded from vector"
-msgid_plural "%d categories loaded from vector"
-msgstr[0] ""
-msgstr[1] ""
-msgstr[2] ""
+msgid ""
+"\n"
+"The accumulation map from %s must be present for"
+msgstr ""
-#: ../vector/v.what.rast3/main.c:335
+#: ../raster/r.watershed/shed/com_line.c:279
 #, c-format
-msgid "%d category from vector missing in table"
-msgid_plural "%d categories from vector missing in table"
-msgstr[0] ""
-msgstr[1] ""
-msgstr[2] ""
+msgid "%s to work properly."
+msgstr ""
-#: ../vector/v.what.rast3/main.c:339
+#: ../raster/r.watershed/shed/com_line.c:290
 #, c-format
-msgid "%d duplicate category in vector"
-msgid_plural "%d duplicate categories in vector"
-msgstr[0] ""
-msgstr[1] ""
-msgstr[2] ""
+msgid ""
+"\n"
+"%s can produce several maps not necessary for"
+msgstr ""
-#: ../vector/v.what.rast3/main.c:343
+#: ../raster/r.watershed/shed/com_line.c:292
 #, c-format
-msgid "%d update error"
-msgid_plural "%d update errors"
-msgstr[0] ""
-msgstr[1] ""
-msgstr[2] ""
+msgid "%s to function (stream channels, overland flow aspect, and"
+msgstr ""
-#: ../vector/v.what.rast3/main.c:347
+#: ../raster/r.watershed/shed/com_line.c:294
 #, c-format
-msgid "%d record updated."
-msgid_plural "%d records updated."
-msgstr[0] ""
-msgstr[1] ""
-msgstr[2] ""
-#: ../vector/v.category/main.c:77 ../vector/v.db.connect/main.c:55
-msgid "layer"
-msgstr "slānis"
-#: ../vector/v.category/main.c:79
-msgid "Attaches, deletes or reports vector categories to map geometry."
+msgid "a display version of the accumulation map).  %s also has the"
 msgstr ""
-#: ../vector/v.category/main.c:92
-msgid "Feature ids (by default all features are processed)"
+#: ../raster/r.watershed/shed/com_line.c:296
+msgid ""
+"ability to generate several variables in the Revised Universal Soil Loss"
 msgstr ""
-#: ../vector/v.category/main.c:104
-msgid "Action to be done"
+#: ../raster/r.watershed/shed/com_line.c:297
+msgid "Equation (Rusle): Slope Length (LS), and Slope Steepness (S).\n"
 msgstr ""
-#: ../vector/v.category/main.c:115
-msgid "add a category to features without category in the given layer"
+#: ../raster/r.watershed/shed/com_line.c:348
+msgid ""
+"\n"
+"The Slope Length factor (LS) and Slope Steepness (S) are influenced by"
 msgstr ""
-#: ../vector/v.category/main.c:116
-msgid "delete category (cat=-1 to delete all categories of given layer)"
+#: ../raster/r.watershed/shed/com_line.c:349
+#, c-format
+msgid "disturbed land.  %s reflects this with an optional map layer or value"
 msgstr ""
-#: ../vector/v.category/main.c:117
-msgid "change layer number (e.g. layer=3,1 changes layer 3 to layer 1)"
+#: ../raster/r.watershed/shed/com_line.c:351
+msgid ""
+"where the value indicates the percent of disturbed (barren) land in that "
+"cell."
 msgstr ""
-#: ../vector/v.category/main.c:118
-msgid "add the value specified by cat option to the current category value"
+#: ../raster/r.watershed/shed/com_line.c:352
+msgid "Type <return> if you do not have a disturbed land map layer."
 msgstr ""
-#: ../vector/v.category/main.c:119
-msgid "copy values from one layer to another (e.g. layer=1,2,3 copies values from layer 1 to layer 2 and 3)"
+#: ../raster/r.watershed/shed/com_line.c:364
+msgid ""
+"\n"
+"Type the value indicating the percent of disturbed land.  This value will"
 msgstr ""
-#: ../vector/v.category/main.c:120
-msgid "print report (statistics), in shell style: layer type count min max"
+#: ../raster/r.watershed/shed/com_line.c:365
+msgid "be used for every cell in the current region."
 msgstr ""
-#: ../vector/v.category/main.c:121
-msgid "print category values, layers are separated by '|', more cats in the same layer are separated by '/'"
+#: ../raster/r.watershed/shed/com_line.c:368
+#, c-format
+msgid ""
+"\n"
+"Input value here [0-100]: "
 msgstr ""
-#: ../vector/v.category/main.c:122
-msgid "print only layer numbers"
+#: ../raster/r.watershed/shed/com_line.c:379
+msgid ""
+"\n"
+"Overland surface flow only occurs for a set distance before swales form."
 msgstr ""
-#: ../vector/v.category/main.c:138
-msgid "Shell script style, currently only for report"
+#: ../raster/r.watershed/shed/com_line.c:380
+#, c-format
+msgid "Because of digital terrain model limitations, %s cannot pick up"
 msgstr ""
-#: ../vector/v.category/main.c:139
-msgid "Format: layer type count min max"
+#: ../raster/r.watershed/shed/com_line.c:382
+#, c-format
+msgid "these swales.  %s allows for an input (warning: kludge factor)"
 msgstr ""
-#: ../vector/v.category/main.c:142
-msgid "Do not copy attribute table(s)"
+#: ../raster/r.watershed/shed/com_line.c:384
+msgid ""
+"that prevents the surface flow distance from getting too long.  Normally,"
 msgstr ""
-#: ../vector/v.category/main.c:160
-msgid "Database connection and attribute tables for concerned layers are not changed"
+#: ../raster/r.watershed/shed/com_line.c:385
+msgid "maximum slope length is around 600 feet (about 183 meters)."
 msgstr ""
-#: ../vector/v.category/main.c:186 ../vector/v.category/main.c:250
-#: ../vector/v.category/main.c:258 ../vector/v.kcv/main.c:96
-#: ../vector/v.kcv/main.c:186
-#, c-format
-msgid "Unable to open vector map <%s> at topological level %d"
+#: ../raster/r.watershed/shed/com_line.c:400
+msgid ""
+"\n"
+"Roads, ditches, changes in ground cover, and other factors will stop"
 msgstr ""
-#: ../vector/v.category/main.c:208
-msgid "Invalid category number (must be equal to or greater than 0). Normally category number starts at 1."
+#: ../raster/r.watershed/shed/com_line.c:401
+msgid ""
+"slope length.  You may input a raster map indicating the locations of these"
 msgstr ""
-#: ../vector/v.category/main.c:217
-#, c-format
-msgid "%d error in id option"
-msgid_plural "%d errors in id option"
-msgstr[0] ""
-msgstr[1] ""
-msgstr[2] ""
-#: ../vector/v.category/main.c:228
-msgid "Output vector wasn't entered"
+#: ../raster/r.watershed/shed/com_line.c:402
+msgid "blocking factors.\n"
 msgstr ""
-#: ../vector/v.category/main.c:275
-msgid "Too many layers for this operation"
-msgstr "Pārāk daudz līmeņu šai operācijai"
-#: ../vector/v.category/main.c:278 ../vector/v.category/main.c:281
-msgid "2 layers must be specified"
-msgstr "Jābūt norādītiem 2 līmeņiem"
-#: ../vector/v.category/main.c:289
-#, c-format
-msgid "Categories already exist in layer %d"
+#: ../raster/r.watershed/shed/com_line.c:403
+msgid ""
+"Hit <return> by itself for the next question if there is no blocking map."
 msgstr ""
-#: ../vector/v.category/main.c:332 ../vector/v.select/select.c:41
-#: ../vector/v.drape/main.c:177
-msgid "Processing features..."
+#: ../raster/r.watershed/shed/valid.c:24
+msgid "accum file missing in valid_basins()"
 msgstr ""
-#: ../vector/v.category/main.c:364 ../vector/v.in.ogr/main.c:1428
-#: ../vector/v.delaunay/main.c:172
-msgid "Unable to calculate area centroid"
+#: ../raster/r.watershed/seg/close_maps2.c:38
+#: ../raster/r.watershed/ram/close_maps2.c:34
+msgid "No basins were created. Verify threshold and region settings."
 msgstr ""
-#: ../vector/v.category/main.c:378
-#, c-format
-msgid "%d new centroid placed in output map"
-msgid_plural "%d new centroids placed in output map"
-msgstr[0] ""
-msgstr[1] ""
-msgstr[2] ""
-#: ../vector/v.category/main.c:672
-msgid "Layer/table"
+#: ../raster/r.watershed/seg/close_maps2.c:86
+msgid "Closing stream segments map"
 msgstr ""
-#: ../vector/v.category/main.c:676
-msgid "Layer"
+#: ../raster/r.watershed/seg/close_maps2.c:109
+msgid "Closing basins map"
 msgstr ""
-#: ../vector/v.category/main.c:678
-#, c-format
-msgid "type       count        min        max\n"
+#: ../raster/r.watershed/seg/close_maps2.c:116
+msgid "Closing half basins map"
 msgstr ""
-#: ../vector/v.category/main.c:687
-msgid "boundary"
+#: ../raster/r.watershed/seg/do_cum.c:119
+#: ../raster/r.watershed/ram/do_cum.c:114
+msgid "SECTION 3: Accumulating Surface Flow with SFD."
 msgstr ""
-#: ../vector/v.category/main.c:699
-msgid "face"
+#: ../raster/r.watershed/seg/do_cum.c:293
+#: ../raster/r.watershed/ram/do_cum.c:276
+msgid "SECTION 3a: Accumulating Surface Flow with MFD."
 msgstr ""
-#: ../vector/v.category/main.c:703
-msgid "kernel"
+#: ../raster/r.watershed/seg/do_cum.c:529
+msgid "MFD: A * path already processed when distributing flow: %d of %"
 msgstr ""
-#: ../vector/v.category/main.c:707
-msgid "all"
+#: ../raster/r.watershed/seg/do_cum.c:533
+#: ../raster/r.watershed/ram/do_cum.c:486
+msgid "SECTION 3b: Adjusting drainage directions."
 msgstr ""
-#: ../vector/v.category/main.c:761 ../vector/v.rectify/main.c:274
-msgid "Copying attribute table(s)..."
+#: ../raster/r.watershed/seg/main.c:92 ../raster/r.watershed/seg/main.c:107
+#: ../raster/r.watershed/ram/main.c:82 ../raster/r.watershed/ram/main.c:98
+#, c-format
+msgid "SECTION %d: Closing Maps."
 msgstr ""
-#: ../vector/v.category/main.c:763 ../vector/v.type/main.c:155
-#: ../vector/v.build.polylines/main.c:241 ../vector/v.rectify/main.c:276
-#: ../vector/v.proj/main.c:503 ../vector/v.net/main.c:158
-#: ../vector/v.transform/main.c:304
-msgid "Failed to copy attribute table to output map"
-msgstr ""
-#: ../vector/v.category/main.c:771
+#: ../raster/r.watershed/seg/main.c:105 ../raster/r.watershed/ram/main.c:96
 #, c-format
-msgid "Categories copied from layer %d to layer %d"
+msgid "SECTION %d: Watershed determination."
 msgstr ""
-#: ../vector/v.category/main.c:775
+#: ../raster/r.watershed/seg/init_vars.c:139
 #, c-format
-msgid "%d feature modified."
-msgid_plural "%d features modified."
+msgid "SECTION 1 beginning: Initiating Variables. %d section total."
+msgid_plural "SECTION 1 beginning: Initiating Variables. %d sections total."
 msgstr[0] ""
 msgstr[1] ""
 msgstr[2] ""
-#: ../vector/v.extrude/db.c:27
+#: ../raster/r.watershed/seg/init_vars.c:175
+msgid "Maximum memory to be used was smaller than 3 MB, set to 3 MB."
+msgstr ""
+#: ../raster/r.watershed/seg/init_vars.c:470
+msgid "SECTION 1b: Determining Offmap Flow."
+msgstr ""
+#: ../raster/r.watershed/seg/usage.c:9 ../raster/r.watershed/ram/usage.c:9
 #, c-format
-msgid "Unable to select attributes category %d"
+msgid ""
+"USAGE for basin delineation:\n"
+"%s -4 elevation=elevation_map threshold=swale_threshold "
+"[flow=overland_flow_map] [drainage=drain_direction_map] "
+"[depression=depression_map] [accumulation=accumulation_map] "
+"[basin=watershed_basin_map] [stream=stream_segment_map]\n"
+"\n"
+"USAGE for slope length determination:\n"
+"%s [-4] elevation=elevation_map threshold=swale_threshold "
+"[drainage=drain_direction_map] [depression=depression_map] "
+"[accumulation=accumulation_map] [max_slope_length=max_slope_length] "
+"[blocking=overland_blocking_map] [slope_steepness=slope_steepness_map] "
+"length_slope=length_slope_map [disturbed_land=rill_erosion_map] "
+"[slope_deposition=slope_deposition value or map]USAGE for ARMSED FILE "
+"creation:\n"
+"[basin=watershed_basin_map] [stream=stream_segment_map] "
+"[half_basin=half_basin_map] ar=ARMSED_file_name\n"
+"\n"
 msgstr ""
-#: ../vector/v.extrude/main.c:72
-msgid "Extrudes flat vector features to 3D vector features with defined height."
+#: ../raster/r.watershed/seg/close_maps.c:20
+msgid "Closing accumulation map"
 msgstr ""
-#: ../vector/v.extrude/main.c:74
-msgid "Optionally the height can be derived from sampling of elevation raster map."
+#: ../raster/r.watershed/seg/close_maps.c:136
+msgid "Closing TCI and SPI maps"
 msgstr ""
-#: ../vector/v.extrude/main.c:78
-msgid "Trace elevation"
+#: ../raster/r.watershed/seg/close_maps.c:138
+msgid "Closing TCI map"
 msgstr ""
-#: ../vector/v.extrude/main.c:79 ../vector/v.extrude/main.c:125
-#: ../vector/v.extrude/main.c:129 ../vector/v.extrude/main.c:136
-#: ../vector/v.extrude/main.c:143 ../vector/v.drape/main.c:87
-#: ../vector/v.drape/main.c:94 ../vector/v.drape/main.c:101
-msgid "Elevation"
+#: ../raster/r.watershed/seg/close_maps.c:140
+msgid "Closing SPI map"
 msgstr ""
-#: ../vector/v.extrude/main.c:101 ../vector/v.transform/main.c:136
-msgid "Shifting value for z coordinates"
+#: ../raster/r.watershed/seg/close_maps.c:300
+msgid "Closing flow direction map"
 msgstr ""
-#: ../vector/v.extrude/main.c:105 ../vector/v.extrude/main.c:113
-#: ../vector/v.extrude/main.c:119 ../vector/v.to.3d/args.c:33
-#: ../vector/v.to.3d/args.c:41
-msgid "Height"
+#: ../raster/r.watershed/seg/close_maps.c:327
+msgid "Closing LS map"
 msgstr ""
-#: ../vector/v.extrude/main.c:112 ../vector/v.to.3d/args.c:40
-msgid "Fixed height for 3D vector features"
+#: ../raster/r.watershed/seg/close_maps.c:332
+msgid "Closing SL map"
 msgstr ""
-#: ../vector/v.extrude/main.c:118
-msgid "Name of attribute column with feature height"
+#: ../raster/r.watershed/seg/do_astar.c:30
+#: ../raster/r.watershed/ram/do_astar.c:27
+msgid "SECTION 2: A* Search."
 msgstr ""
-#: ../vector/v.extrude/main.c:124 ../vector/v.drape/main.c:83
-msgid "Elevation raster map for height extraction"
+#: ../raster/r.watershed/seg/do_astar.c:48
+msgid "No seeds for A* Search"
 msgstr ""
-#: ../vector/v.extrude/main.c:134 ../vector/v.drape/main.c:92
-msgid "Scale factor sampled raster values"
+#: ../raster/r.watershed/seg/do_astar.c:146
+msgid "bug in A* Search: doer %"
 msgstr ""
-#: ../vector/v.extrude/main.c:142 ../vector/v.drape/main.c:100
-msgid "Height for sampled raster NULL values"
+#: ../raster/r.watershed/seg/sg_factor.c:14
+msgid "SECTION 5: RUSLE LS and/or S factor determination."
 msgstr ""
-#: ../vector/v.extrude/main.c:151
+#: ../raster/r.watershed/ram/do_cum.c:480
 #, c-format
-msgid "One of '%s' or '%s' parameters must be set"
-msgstr ""
+msgid "MFD: A * path already processed when distributing flow: %d of %d cell"
+msgid_plural ""
+"MFD: A * path already processed when distributing flow: %d of %d cells"
+msgstr[0] ""
+msgstr[1] ""
+msgstr[2] ""
-#: ../vector/v.extrude/main.c:202
+#: ../raster/r.watershed/ram/init_vars.c:121
 #, c-format
-msgid "Invalid layer number (%d). Parameter '%s', '%s' or '%s' specified, assuming layer '1'."
+msgid "SECTION 1a (of %1d): Initiating Memory."
 msgstr ""
-#: ../vector/v.extrude/main.c:234
+#: ../raster/r.watershed/ram/init_vars.c:311
 #, c-format
-msgid "Column <%s> does not exist"
+msgid "SECTION 1b (of %1d): Determining Offmap Flow."
 msgstr ""
-#: ../vector/v.extrude/main.c:243
-#, c-format
-msgid "Column <%s>: invalid data type"
+#: ../raster/r.watershed/ram/do_flatarea.c:56
+msgid "Beautify flat areas: priority queue error"
 msgstr ""
-#: ../vector/v.extrude/main.c:265
-msgid "Extruding areas..."
+#: ../raster/r.watershed/ram/do_flatarea.c:229
+msgid "flat cell escaped for uphill correction"
 msgstr ""
-#: ../vector/v.extrude/main.c:275 ../vector/v.out.svg/main.c:233
+#: ../raster/r.watershed/ram/do_flatarea.c:235
 #, c-format
-msgid "Skipping area %d without centroid"
+msgid "queue error: last uphill order %d > current uphill order %d"
 msgstr ""
-#: ../vector/v.extrude/main.c:287
-#, c-format
-msgid "No category defined for area %d. Using default fixed height %f."
+#: ../raster/r.watershed/ram/do_flatarea.c:240
+msgid "uphill order not set"
 msgstr ""
-#: ../vector/v.extrude/main.c:293
-#, c-format
-msgid "Unable to fetch height from DB for area %d. Using default fixed height %f."
+#: ../raster/r.watershed/ram/do_flatarea.c:266
+msgid "flat cell escaped in uphill correction"
 msgstr ""
-#: ../vector/v.extrude/main.c:319
-msgid "Extruding features..."
+#: ../raster/r.watershed/ram/do_flatarea.c:302
+msgid "downhill order: no more points in down queue"
 msgstr ""
-#: ../vector/v.extrude/main.c:340
-#, c-format
-msgid "No category defined for feature %d. Using default fixed height %f."
+#: ../raster/r.watershed/ram/do_flatarea.c:310
+msgid "flat cell escaped for downhill correction"
 msgstr ""
-#: ../vector/v.extrude/main.c:346
+#: ../raster/r.watershed/ram/do_flatarea.c:316
 #, c-format
-msgid "Unable to fetch height from DB for line %d. Using default fixed height %f."
+msgid "queue error: last downhill order %d > current downhill order %d"
 msgstr ""
-#: ../vector/v.extrude/main.c:364
-msgid "Copying attribute table..."
+#: ../raster/r.watershed/ram/do_flatarea.c:321
+msgid "downhill order: downhill order not set"
 msgstr ""
-#: ../vector/v.extract/main.c:83
-msgid "Selects vector features from an existing vector map and creates a new vector map containing only the selected features."
+#: ../raster/r.watershed/ram/do_flatarea.c:344
+msgid "flat cell escaped in downhill correction"
 msgstr ""
-#: ../vector/v.extract/main.c:88
-msgid "Dissolve common boundaries (default is no)"
+#: ../raster/r.watershed/ram/do_flatarea.c:382
+msgid "flat cell escaped for adjustment"
 msgstr ""
-#: ../vector/v.extract/main.c:92
-msgid "Do not copy attributes (see also 'new' parameter)"
+#: ../raster/r.watershed/ram/do_flatarea.c:389
+msgid "adjustment: uphill order not set"
 msgstr ""
-#: ../vector/v.extract/main.c:97 ../vector/v.edit/args.c:204
-#: ../vector/v.select/args.c:105
-msgid "Reverse selection"
+#: ../raster/r.watershed/ram/do_flatarea.c:391
+msgid "adjustment: downhill order not set"
 msgstr ""
-#: ../vector/v.extract/main.c:108
-msgid "Types to be extracted"
+#: ../raster/r.watershed/ram/do_flatarea.c:417
+msgid "flat cell escaped in adjustment"
 msgstr ""
-#: ../vector/v.extract/main.c:123
-msgid "Input text file with category numbers/number ranges to be extracted"
+#: ../raster/r.watershed/ram/do_astar.c:256
+msgid "heapsize too large"
 msgstr ""
-#: ../vector/v.extract/main.c:124
-msgid "If '-' given reads from standard input"
+#: ../raster/r.watershed/ram/sg_factor.c:14
+msgid "SECTION 4: RUSLE LS and/or S factor determination."
 msgstr ""
-#: ../vector/v.extract/main.c:132
-msgid "Number of random categories matching vector objects to extract"
+#: ../raster/r.out.png/main.c:116
+msgid "Export a GRASS raster map as a non-georeferenced PNG image."
 msgstr ""
-#: ../vector/v.extract/main.c:134
-msgid "Number must be smaller than unique cat count in layer"
+#: ../raster/r.out.png/main.c:122
+msgid "Name for new PNG file (use '-' for stdout)"
 msgstr ""
-#: ../vector/v.extract/main.c:142
-msgid "Desired new category value (enter -1 to keep original categories)"
+#: ../raster/r.out.png/main.c:130
+msgid "Compression level of PNG file"
 msgstr ""
-#: ../vector/v.extract/main.c:144
-msgid "If new >= 0, attributes is not copied"
+#: ../raster/r.out.png/main.c:131
+msgid "(0 = none, 1 = fastest, 9 = best)"
 msgstr ""
-#: ../vector/v.extract/main.c:161
-#, c-format
-msgid "Options <%s>, <%s>, <%s> and <%s> options are exclusive. Please specify only one of them."
+#: ../raster/r.out.png/main.c:138
+msgid "Make NULL cells transparent"
+msgstr "Padarīt NULL šūnas caurspīdīgas"
+#: ../raster/r.out.png/main.c:142
+msgid "Output world file"
 msgstr ""
-#: ../vector/v.extract/main.c:208
+#: ../raster/r.out.png/main.c:175 ../display/d.labels/color.c:68
+#: ../display/d.legend.vect/draw.c:193 ../display/d.legend.vect/draw.c:204
+#: ../display/d.rast/display.c:27 ../display/d.graph/main.c:104
+#: ../display/d.graph/do_graph.c:105 ../display/d.graph/do_graph.c:355
+#: ../display/d.graph/do_graph.c:370
 #, c-format
-msgid "Category value in '%s' not valid"
+msgid "[%s]: No such color"
 msgstr ""
-#: ../vector/v.extract/main.c:224
+#: ../raster/r.out.png/main.c:257
 #, c-format
-msgid "Process file <%s> for category numbers..."
+msgid "Converting <%s>..."
+msgstr "Konvertē <%s>..."
+#: ../raster/r.out.png/main.c:422
+msgid "Writing world file"
 msgstr ""
-#: ../vector/v.extract/main.c:229
-#, c-format
-msgid "Unable to open specified file <%s>"
+#: ../raster/r.out.png/main.c:425
+msgid "Got null file name"
 msgstr ""
-#: ../vector/v.extract/main.c:240
-#, c-format
-msgid "Ignored text entry: %s"
+#: ../raster/r.out.png/main.c:427
+msgid "Got null region struct"
 msgstr ""
-#: ../vector/v.extract/main.c:255 ../vector/v.to.rast3/main.c:80
-#: ../vector/v.to.3d/trans3.c:51 ../vector/v.to.3d/trans2.c:49
-#: ../vector/v.db.select/main.c:171 ../vector/v.info/print.c:138
-#: ../vector/v.to.rast/vect2rast.c:55 ../vector/v.distance/main.c:515
-#: ../vector/v.distance/main.c:596 ../vector/v.db.connect/main.c:213
-#: ../vector/v.colors.out/make_colors.c:31
-#, c-format
-msgid "Database connection not defined for layer <%s>"
+#: ../raster/r.out.png/main.c:429
+msgid "Unable to open world file for writing"
 msgstr ""
-#: ../vector/v.extract/main.c:259
-#, c-format
-msgid "Loading categories from table <%s>..."
+#: ../raster/r.out.mpeg/main.c:104
+msgid "animation"
 msgstr ""
-#: ../vector/v.extract/main.c:269
-#, c-format
-msgid "Unable select records from table <%s>"
+#: ../raster/r.out.mpeg/main.c:107
+msgid "Converts raster map series to MPEG movie."
 msgstr ""
-#: ../vector/v.extract/main.c:271
+#: ../raster/r.out.mpeg/main.c:115
 #, c-format
-msgid "%d category loaded"
-msgid_plural "%d categories loaded"
-msgstr[0] ""
-msgstr[1] ""
-msgstr[2] ""
-#: ../vector/v.extract/main.c:286
-msgid "This map has no categories attached. Use v.category to attach categories to this vector map."
+msgid "Name of input raster map(s) for view no.%d"
 msgstr ""
-#: ../vector/v.extract/main.c:293
-msgid "Please specify random number larger than 0"
-msgstr ""
+#: ../raster/r.out.mpeg/main.c:117
+msgid "Views"
+msgstr "Skati"
-#: ../vector/v.extract/main.c:297
-#, c-format
-msgid "Random category count must be smaller than feature count. There are only %d features of type(s): %s"
+#: ../raster/r.out.mpeg/main.c:131
+msgid "Quality factor (1 = highest quality, lowest compression)"
 msgstr ""
-#: ../vector/v.extract/main.c:320
-#, c-format
-msgid "Random category count is larger or equal to uniq <%s> feature category count %d"
+#: ../raster/r.out.mpeg/main.c:136
+msgid "Convert on the fly, uses less disk space"
 msgstr ""
-#: ../vector/v.extract/main.c:354
-msgid "Extracting features..."
+#: ../raster/r.out.mpeg/main.c:137
+msgid "Requires r.out.ppm with stdout option"
 msgstr ""
-#: ../vector/v.extract/main.c:378
-msgid "Removing duplicate centroids..."
+#: ../raster/r.out.mpeg/main.c:160
+msgid "Either mpeg_encode or ppmtompeg must be installed"
 msgstr ""
-#: ../vector/v.extract/extract.c:171
+#: ../raster/r.out.mpeg/main.c:291
 #, c-format
-msgid "No category found for area %d. Skipping."
+msgid "Unable to read color table for <%s>"
 msgstr ""
-#: ../vector/v.extract/extract.c:175
-#, c-format
-msgid "More categories (%d) found for area %d. Using first found category %d"
+#: ../raster/r.out.mpeg/main.c:341 ../raster/r.out.mpeg/main.c:374
+msgid "mpeg_encode ERROR"
 msgstr ""
-#: ../vector/v.extract/extract.c:228
-msgid "Topology level required for extracting areas for OGR layers. Areas will be not processed."
+#: ../raster/r.out.mpeg/main.c:417
+msgid "Error reading wildcard"
 msgstr ""
-#: ../vector/v.extract/copy_tab.c:90
-#, c-format
-msgid "Writing attributes for layer %d"
+#: ../raster/r.out.mpeg/write.c:81 ../raster/r.out.mpeg/write.c:178
+msgid "Size mismatch error!"
 msgstr ""
-#: ../vector/v.extract/copy_tab.c:95
-#, c-format
-msgid "No attribute table for layer %d"
+#: ../raster/r.out.mpeg/write.c:139 ../raster/r.out.mpeg/write.c:181
+msgid "Unable to open output file"
 msgstr ""
-#: ../vector/v.extract/copy_tab.c:108 ../vector/v.to.points/main.c:165
-#: ../vector/v.generalize/misc.c:184
-#: ../scripts/v.db.reconnect.all/v.db.reconnect.all.py:128
-msgid "Unable to copy table <%s>"
+#: ../raster/r.out.mpeg/write.c:215
+msgid "Unable to create temporary files."
 msgstr ""
-#: ../vector/v.extract/copy_tab.c:117 ../vector/v.vect.stats/main.c:296
-#: ../vector/v.vect.stats/main.c:378
+#: ../raster/r.reclass/parse.c:41 ../raster/r.colors/rules.c:104
 #, c-format
-msgid "Unable to open database <%s> with driver <%s>"
+msgid "Enter a rule in one of these formats:\n"
 msgstr ""
-#: ../vector/v.lidar.correction/main.c:74
-msgid "Corrects the v.lidar.growing output. It is the last of the three algorithms for LIDAR filtering."
+#: ../raster/r.reclass/parse.c:42
+msgid "poor quality"
 msgstr ""
-#: ../vector/v.lidar.correction/main.c:78
-#: ../vector/v.lidar.edgedetection/main.c:83
-msgid "Estimate point density and distance and quit"
+#: ../raster/r.reclass/parse.c:44
+msgid "medium quality"
 msgstr ""
-#: ../vector/v.lidar.correction/main.c:80
-#: ../vector/v.lidar.edgedetection/main.c:85
-#: ../vector/v.surf.bspline/main.c:107 ../vector/v.outlier/main.c:81
-msgid "Estimate point density and distance for the input vector points within the current region extends and quit"
+#: ../raster/r.reclass/parse.c:59
+msgid "Can't have null on the left-hand side of the rule"
 msgstr ""
-#: ../vector/v.lidar.correction/main.c:85
-msgid "Input observation vector map name (v.lidar.growing output)"
+#: ../raster/r.reclass/parse.c:88 ../raster/r.reclass/parse.c:100
+msgid "Can't have null on the right-hand side of the rule"
 msgstr ""
-#: ../vector/v.lidar.correction/main.c:88
-msgid "Output classified vector map name"
+#: ../raster/r.reclass/parse.c:196
+#, c-format
+msgid "%f rounded up to %d\n"
 msgstr ""
-#: ../vector/v.lidar.correction/main.c:93
-msgid "Name for output only 'terrain' points vector map"
+#: ../raster/r.reclass/main.c:52
+msgid "Reclassify raster map based on category values."
 msgstr ""
-#: ../vector/v.lidar.correction/main.c:101
-#: ../vector/v.lidar.edgedetection/main.c:98
-#: ../vector/v.surf.bspline/main.c:149 ../vector/v.outlier/main.c:103
-msgid "Length of each spline step in the east-west direction"
+#: ../raster/r.reclass/main.c:54
+msgid ""
+"Creates a new raster map whose category values are based upon a "
+"reclassification of the categories in an existing raster map."
 msgstr ""
-#: ../vector/v.lidar.correction/main.c:110
-#: ../vector/v.lidar.edgedetection/main.c:107
-#: ../vector/v.surf.bspline/main.c:158 ../vector/v.outlier/main.c:112
-msgid "Length of each spline step in the north-south direction"
+#: ../raster/r.reclass/main.c:59
+msgid "Name of raster map to be reclassified"
 msgstr ""
-#: ../vector/v.lidar.correction/main.c:118
-msgid "Regularization weight in reclassification evaluation"
+#: ../raster/r.reclass/main.c:65
+msgid "File containing reclass rules"
 msgstr ""
-#: ../vector/v.lidar.correction/main.c:126
-msgid "High threshold for object to terrain reclassification"
+#: ../raster/r.reclass/main.c:83
+msgid "Input map can NOT be the same as output map"
 msgstr ""
-#: ../vector/v.lidar.correction/main.c:134
-msgid "Low threshold for terrain to object reclassification"
+#: ../raster/r.reclass/main.c:89
+#, c-format
+msgid "Cannot open rules file <%s>"
 msgstr ""
-#: ../vector/v.lidar.correction/main.c:160
-#: ../vector/v.lidar.edgedetection/main.c:184 ../vector/v.outlier/main.c:205
+#: ../raster/r.reclass/main.c:103
 #, c-format
-msgid "Input vector map <%s> is not 3D!"
+msgid "Enter rule(s), \"end\" when done, \"help\" if you need it\n"
 msgstr ""
-#: ../vector/v.lidar.correction/main.c:166
-#: ../vector/v.lidar.edgedetection/main.c:190
+#: ../raster/r.reclass/main.c:105
 #, c-format
-msgid "Estimated point density: %.4g\n"
+msgid "FCELL: Data range is %.7g to %.7g\n"
 msgstr ""
-#: ../vector/v.lidar.correction/main.c:167
-#: ../vector/v.lidar.edgedetection/main.c:191
+#: ../raster/r.reclass/main.c:108
 #, c-format
-msgid "Estimated mean distance between points: %.4g\n"
+msgid "DCELL: Data range is %.15g to %.15g\n"
 msgstr ""
-#: ../vector/v.lidar.correction/main.c:170
-#: ../vector/v.lidar.edgedetection/main.c:194 ../vector/v.outlier/main.c:215
-msgid "No points in current region!"
+#: ../raster/r.reclass/main.c:111
+#, c-format
+msgid "CELL: Data range is %ld to %ld\n"
 msgstr ""
-#: ../vector/v.lidar.correction/main.c:177
-#: ../vector/v.lidar.edgedetection/main.c:201 ../vector/v.outlier/main.c:146
-msgid "Unable to read name of database"
+#: ../raster/r.reclass/main.c:119
+#, c-format
+msgid "Illegal reclass rule -"
 msgstr ""
-#: ../vector/v.lidar.correction/main.c:180
-#: ../vector/v.lidar.edgedetection/main.c:204 ../vector/v.outlier/main.c:149
-msgid "Unable to read name of driver"
-msgstr ""
-#: ../vector/v.lidar.correction/main.c:194
-#: ../vector/v.lidar.correction/main.c:230 ../vector/v.lidar.growing/main.c:163
-#: ../vector/v.lidar.edgedetection/main.c:221
-#: ../vector/v.lidar.edgedetection/main.c:233
-#: ../vector/v.lidar.edgedetection/main.c:255
-#: ../vector/v.surf.bspline/main.c:247 ../vector/v.surf.bspline/main.c:406
-#: ../vector/v.outlier/main.c:188 ../vector/v.outlier/main.c:256
+#: ../raster/r.reclass/main.c:120
 #, c-format
-msgid "No database connection for driver <%s> is defined. Run db.connect."
+msgid " ignored\n"
 msgstr ""
-#: ../vector/v.lidar.correction/main.c:199
-#: ../vector/v.lidar.edgedetection/main.c:224
-#: ../vector/v.lidar.edgedetection/main.c:236
-#: ../vector/v.surf.bspline/main.c:252 ../vector/v.outlier/main.c:193
-msgid "Old auxiliary table could not be dropped"
+#: ../raster/r.reclass/main.c:123
+msgid " - invalid reclass rule"
 msgstr ""
-#: ../vector/v.lidar.correction/main.c:274
+#: ../raster/r.reclass/main.c:139
 #, c-format
-msgid "Adjusted EW spline %d"
-msgid_plural "Adjusted EW splines %d"
-msgstr[0] ""
-msgstr[1] ""
-msgstr[2] ""
-#: ../vector/v.lidar.correction/main.c:277
-#, c-format
-msgid "Adjusted NS spline %d"
-msgid_plural "Adjusted NS splines %d"
-msgstr[0] ""
-msgstr[1] ""
-msgstr[2] ""
-#: ../vector/v.lidar.correction/main.c:334
-#: ../vector/v.lidar.edgedetection/main.c:355
-#, c-format
-msgid "Subregion %d of %d"
+msgid "No rules specified. Raster map <%s> not created"
 msgstr ""
-#: ../vector/v.lidar.correction/main.c:372
-msgid "Performing mean calculation..."
+#: ../raster/r.reclass/reclass.c:51 ../raster/r.reclass/reclass.c:111
+msgid "Too many categories"
 msgstr ""
-#: ../vector/v.lidar.correction/main.c:416
-msgid "Correction and creation of terrain vector..."
+#: ../raster/r.reclass/reclass.c:216
+#, c-format
+msgid "Cannot read header file of <%s@%s>"
 msgstr ""
-#: ../vector/v.lidar.correction/main.c:429
-#: ../vector/v.lidar.edgedetection/main.c:461
-msgid "No data within this subregion. Consider changing the spline step."
+#: ../raster/r.reclass/reclass.c:234
+#, c-format
+msgid "Cannot overwrite existing raster map <%s>"
 msgstr ""
-#: ../vector/v.lidar.correction/main.c:440
-#: ../vector/v.lidar.edgedetection/main.c:471
-#: ../vector/v.surf.bspline/main.c:942 ../vector/v.outlier/main.c:458
-msgid "Auxiliary table could not be dropped"
+#: ../raster/r.reclass/reclass.c:239
+#, c-format
+msgid "Cannot create reclass file of <%s>"
 msgstr ""
-#: ../vector/v.lidar.correction/correction.c:93
-#: ../vector/v.lidar.correction/correction.c:127
-#: ../vector/v.lidar.correction/correction.c:151
-#: ../vector/v.lidar.correction/correction.c:163
-#: ../vector/v.lidar.correction/correction.c:187
-#: ../vector/v.outlier/outlier.c:86 ../vector/v.outlier/outlier.c:123
-#: ../vector/v.outlier/outlier.c:148 ../vector/v.outlier/outlier.c:161
-#: ../vector/v.outlier/outlier.c:185
-msgid "Impossible to read the database"
+#: ../raster/r.reclass/reclass.c:247
+#, c-format
+msgid "Cannot create raster map <%s>"
 msgstr ""
-#: ../vector/v.lidar.correction/correction.c:97
-#: ../vector/v.lidar.correction/correction.c:155
-#: ../vector/v.outlier/outlier.c:90 ../vector/v.outlier/outlier.c:152
-msgid "Impossible to update the database"
+#: ../raster/r.regression.multi/main.c:61
+msgid "Matrix is unsolvable"
 msgstr ""
-#: ../vector/v.lidar.correction/correction.c:107
-#: ../vector/v.lidar.correction/correction.c:115
-#: ../vector/v.lidar.correction/correction.c:210
-#: ../vector/v.outlier/outlier.c:101 ../vector/v.outlier/outlier.c:110
-#: ../vector/v.outlier/outlier.c:207
-msgid "Impossible to write in the database"
+#: ../raster/r.regression.multi/main.c:133
+msgid "Calculates multiple linear regression from raster maps."
 msgstr ""
-#: ../vector/v.net.components/main.c:74
-msgid "components"
+#: ../raster/r.regression.multi/main.c:147
+msgid "Map to store residuals"
 msgstr ""
-#: ../vector/v.net.components/main.c:76
-msgid "Computes strongly and weakly connected components in the network."
+#: ../raster/r.regression.multi/main.c:152
+msgid "Map to store estimates"
 msgstr ""
-#: ../vector/v.net.components/main.c:124
-msgid "Weakly connected components"
+#: ../raster/r.regression.multi/main.c:250
+msgid "First pass..."
 msgstr ""
-#: ../vector/v.net.components/main.c:125
-msgid "Strongly connected components"
+#: ../raster/r.regression.multi/main.c:323
+msgid "Not enough valid cells available"
 msgstr ""
-#: ../vector/v.net.components/main.c:127
-msgid "Type of components"
+#: ../raster/r.regression.multi/main.c:337
+msgid "Multiple regression failed"
 msgstr ""
-#: ../vector/v.net.components/main.c:131 ../vector/v.net.centrality/main.c:192
-msgid "Add points on nodes"
+#: ../raster/r.regression.multi/main.c:342
+msgid "Second pass..."
 msgstr ""
-#: ../vector/v.net.components/main.c:194 ../vector/v.net.distance/main.c:295
-#: ../vector/v.net.flow/main.c:185 ../vector/v.net.timetable/main.c:107
-#: ../vector/v.sample/main.c:193 ../vector/v.net.allpairs/main.c:183
-#: ../vector/v.kcv/main.c:175 ../vector/v.net.path/path.c:113
-#: ../vector/v.net.centrality/main.c:270 ../vector/v.db.connect/main.c:336
-msgid "Cannot create index"
-msgstr "Nevar izveidot indeksu"
-#: ../vector/v.net.components/main.c:198 ../vector/v.net.distance/main.c:299
-#: ../vector/v.net.flow/main.c:189 ../vector/v.net.timetable/main.c:112
-#: ../vector/v.net.allpairs/main.c:187 ../vector/v.net.path/path.c:117
-#: ../vector/v.net.centrality/main.c:274
-#, c-format
-msgid "Cannot grant privileges on table <%s>"
+#: ../raster/r.spread/main.c:111
+msgid "Simulates elliptically anisotropic spread."
 msgstr ""
-#: ../vector/v.net.components/main.c:203
-msgid "Computing weakly connected components..."
+#: ../raster/r.spread/main.c:113
+msgid ""
+"Generates a raster map of the cumulative time of spread, given raster maps "
+"containing the rates of spread (ROS), the ROS directions and the spread "
+"origins. It optionally produces raster maps to contain backlink UTM "
+"coordinates for tracing spread paths. Usable for fire spread simulations."
 msgstr ""
-#: ../vector/v.net.components/main.c:207
-msgid "Computing strongly connected components..."
+#: ../raster/r.spread/main.c:127
+msgid "Raster map containing base ROS (cm/min)"
 msgstr ""
-#: ../vector/v.net.components/main.c:279
-#, c-format
-msgid "Found %d components."
+#: ../raster/r.spread/main.c:129
+msgid ""
+"Name of an existing raster map layer in the user's current mapset search "
+"path containing the ROS values in the directions perpendicular to maximum "
+"ROSes' (cm/minute). These ROSes are also the ones without the effect of "
+"directional factors."
 msgstr ""
-#: ../vector/v.net.distance/main.c:69
-msgid "Computes shortest distance via the network between the given sets of features."
+#: ../raster/r.spread/main.c:141
+msgid "Raster map containing maximal ROS (cm/min)"
 msgstr ""
-#: ../vector/v.net.distance/main.c:72
-msgid "Finds the shortest paths from each 'from' point to the nearest 'to' feature and various information about this relation are uploaded to the attribute table."
+#: ../raster/r.spread/main.c:143
+msgid ""
+"path containing the maximum ROS values (cm/minute)."
 msgstr ""
-#: ../vector/v.net.distance/main.c:100
-msgid "From layer number or name"
+#: ../raster/r.spread/main.c:153
+msgid "Raster map containing directions of maximal ROS (degree)"
 msgstr ""
-#: ../vector/v.net.distance/main.c:101 ../vector/v.net.distance/main.c:106
-#: ../vector/v.net.distance/main.c:112 ../vector/v.distance/main.c:131
-#: ../vector/v.distance/main.c:136 ../vector/v.distance/main.c:143
-#: ../vector/v.distance/main.c:187 ../vector/v.distance/main.c:224
-msgid "From"
+#: ../raster/r.spread/main.c:155
+msgid ""
+"path containing directions of the maximum ROSes, clockwise from north "
+"(degree)."
 msgstr ""
-#: ../vector/v.net.distance/main.c:105
-msgid "From category values"
+#: ../raster/r.spread/main.c:166
+msgid "Raster map containing starting sources"
 msgstr ""
-#: ../vector/v.net.distance/main.c:111
-msgid "From WHERE conditions of SQL statement without 'where' keyword"
+#: ../raster/r.spread/main.c:168
+msgid ""
+"path containing starting locations of the spread phenomenon. Any positive "
+"integers in this map are recognized as starting sources (seeds)."
 msgstr ""
-#: ../vector/v.net.distance/main.c:116
-msgid "To layer number or name"
+#: ../raster/r.spread/main.c:179
+msgid "Raster map containing maximal spotting distance (m, required with -s)"
 msgstr ""
-#: ../vector/v.net.distance/main.c:117 ../vector/v.net.distance/main.c:124
-#: ../vector/v.net.distance/main.c:129 ../vector/v.net.distance/main.c:135
-#: ../vector/v.distance/main.c:148 ../vector/v.distance/main.c:153
-#: ../vector/v.distance/main.c:160 ../vector/v.distance/main.c:230
-msgid "To"
-msgstr "Uz"
-#: ../vector/v.net.distance/main.c:123
-msgid "To feature type"
+#: ../raster/r.spread/main.c:181
+msgid ""
+"path containing the maximum potential spotting distances (meters)."
 msgstr ""
-#: ../vector/v.net.distance/main.c:128
-msgid "To category values"
+#: ../raster/r.spread/main.c:191
+msgid "Raster map containing midflame wind speed (ft/min, required with -s)"
 msgstr ""
-#: ../vector/v.net.distance/main.c:134
-msgid "To WHERE conditions of SQL statement without 'where' keyword"
+#: ../raster/r.spread/main.c:203
+msgid ""
+"Raster map containing fine fuel moisture of the cell receiving a spotting "
+"firebrand (%, required with -s)"
 msgstr ""
-#: ../vector/v.net.distance/main.c:165 ../vector/v.net.path/main.c:136
-msgid "Write output as original input segments, not each path as one line."
+#: ../raster/r.spread/main.c:215
+msgid "Basic sampling window size needed to meet certain accuracy (3)"
 msgstr ""
-#: ../vector/v.net.distance/main.c:169
-msgid "Write each output path as one line, not as original input segments."
+#: ../raster/r.spread/main.c:217
+msgid ""
+"An odd integer ranging 3 - 15 indicating the basic sampling window size "
+"within which all cells will be considered to see whether they will be "
+"reached by the current spread cell. The default number is 3 which means a "
+"3x3 window."
 msgstr ""
-#: ../vector/v.net.distance/main.c:244
-#, c-format
-msgid "No 'from' features selected. Please check options '%s', '%s', '%s'."
+#: ../raster/r.spread/main.c:227
+msgid "Sampling density for additional computing (range: 0.0 - 1.0 (0.5))"
 msgstr ""
-#: ../vector/v.net.distance/main.c:251
-#, c-format
-msgid "No 'to' features selected. Please check options '%s', '%s', '%s'."
+#: ../raster/r.spread/main.c:229
+msgid ""
+"A decimal number ranging 0.0 - 1.0 indicating additional sampling cells will "
+"be considered to see whether they will be reached by the current spread "
+"cell. The closer to 1.0 the decimal number is, the longer the program will "
+"run and the higher the simulation accuracy will be. The default number is "
+"0.5."
 msgstr ""
-#: ../vector/v.net.distance/main.c:260
-msgid "No 'to' features"
+#: ../raster/r.spread/main.c:241
+msgid "Initial time for current simulation (0) (min)"
 msgstr ""
-#: ../vector/v.net.distance/main.c:268
-msgid "Distances to 'to' features ..."
+#: ../raster/r.spread/main.c:243
+msgid ""
+"A non-negative number specifying the initial time for the current spread "
+"simulation (minutes). This is useful when multiple phase simulation is "
+"conducted. The default time is 0."
 msgstr ""
-#: ../vector/v.net.distance/main.c:307
-msgid "Tracing paths from 'from' features ..."
+#: ../raster/r.spread/main.c:252
+msgid "Simulating time duration LAG (fill the region) (min)"
 msgstr ""
-#: ../vector/v.net.distance/main.c:423
-#, c-format
-msgid "%d 'from' feature was not reachable"
-msgid_plural "%d 'from' features were not reachable"
-msgstr[0] ""
-msgstr[1] ""
-msgstr[2] ""
-#: ../vector/v.out.pov/main.c:49
-msgid "Converts GRASS x,y,z points to POV-Ray x,z,y format."
+#: ../raster/r.spread/main.c:254
+msgid ""
+"A non-negative integer specifying the simulating duration time lag "
+"(minutes). The default is infinite, but the program will terminate when the "
+"current geographic region/mask has been filled. It also controls the "
+"computational time, the shorter the time lag, the faster the program will "
+"run."
 msgstr ""
-#: ../vector/v.out.pov/main.c:60
-msgid "Name for output POV file"
+#: ../raster/r.spread/main.c:266
+msgid "Name of raster map as a display backdrop"
 msgstr ""
-#: ../vector/v.out.pov/main.c:67
-msgid "Radius of sphere for points and tube for lines"
+#: ../raster/r.spread/main.c:268
+msgid ""
+"path to be used as the background on which the \"live\" movement will be "
+"shown."
 msgstr ""
-#: ../vector/v.out.pov/main.c:68
-msgid "May be also variable, e.g. grass_r."
+#: ../raster/r.spread/main.c:279
+msgid "Raster map to contain output spread time (min)"
 msgstr ""
-#: ../vector/v.out.pov/main.c:74
-msgid "Modifier for z coordinates"
+#: ../raster/r.spread/main.c:281
+msgid ""
+"Name of the new raster map layer to contain the results of the cumulative "
+"spread time needed for a phenomenon to reach each cell from the starting "
+"sources (minutes)."
 msgstr ""
-#: ../vector/v.out.pov/main.c:75
-msgid "This string is appended to each z coordinate. Examples: '*10', '+1000', '*10+100', '*exaggeration'"
+#: ../raster/r.spread/main.c:291
+msgid "Name of raster map to contain X back coordinates"
 msgstr ""
-#: ../vector/v.out.pov/main.c:82
-msgid "Object modifier (OBJECT_MODIFIER in POV-Ray documentation)"
+#: ../raster/r.spread/main.c:293
+msgid ""
+"Name of the new raster map layer to contain the results of backlink "
+"information in UTM easting coordinates for each cell."
 msgstr ""
-#: ../vector/v.out.pov/main.c:83
-msgid "Example: \"pigment { color red 0 green 1 blue 0 }\""
+#: ../raster/r.spread/main.c:303
+msgid "Name of raster map to contain Y back coordinates"
 msgstr ""
-#: ../vector/v.out.pov/main.c:175 ../vector/v.select/select.c:171
-msgid "Processing areas..."
+#: ../raster/r.spread/main.c:305
+msgid ""
+"information in UTM northing coordinates for each cell."
 msgstr ""
-#: ../vector/v.out.pov/main.c:218
-#, c-format
-msgid "%d feature written."
-msgid_plural "%d features written."
-msgstr[0] ""
-msgstr[1] ""
-msgstr[2] ""
-#: ../vector/v.surf.idw/main.c:92
-msgid "Provides surface interpolation from vector point data by Inverse Distance Squared Weighting."
+#: ../raster/r.spread/main.c:312
+msgid "DISPLAY 'live' spread process on screen"
 msgstr ""
-#: ../vector/v.surf.idw/main.c:101
-msgid "Name of attribute column with values to interpolate"
+#: ../raster/r.spread/main.c:314
+msgid ""
+"Display the 'live' simulation on screen. A graphics window must be opened "
+"and selected before using this option."
 msgstr ""
-#: ../vector/v.surf.idw/main.c:104
-msgid "Values"
+#: ../raster/r.spread/main.c:320
+msgid "Consider spotting effect (for wildfires)"
 msgstr ""
-#: ../vector/v.surf.idw/main.c:121
-msgid "Power parameter"
+#: ../raster/r.spread/main.c:324
+msgid "Use start raster map values in output spread time raster map"
 msgstr ""
-#: ../vector/v.surf.idw/main.c:123
-msgid "Greater values assign greater influence to closer points"
+#: ../raster/r.spread/main.c:326
+msgid ""
+"Designed to be used with output of previous run of r.spread when computing "
+"spread iteratively. The values in start raster map are considered as time. "
+"Allowed values in raster map are from zero to the value of init_time option. "
+"If not enabled, init_time is used in the area of start raster map"
 msgstr ""
-#: ../vector/v.surf.idw/main.c:128
-msgid "Don't index points by raster cell"
+#: ../raster/r.spread/main.c:502
+msgid "Reading inputs..."
 msgstr ""
-#: ../vector/v.surf.idw/main.c:129
-msgid "Slower but uses less memory and includes points from outside region in the interpolation"
-msgstr ""
-#: ../vector/v.surf.idw/main.c:139
+#: ../raster/r.spread/main.c:543
 #, c-format
-msgid "Illegal number (%s) of interpolation points"
+msgid "Maximum of start raster map is grater than init_time (%d > %d)"
 msgstr ""
-#: ../vector/v.surf.idw/main.c:176 ../vector/v.neighbors/main.c:175
-#: ../vector/v.normal/main.c:195
-msgid "No points found"
-msgstr ""
-#. GTC First argument is map name, second - message about number of rows, third - columns.
-#: ../vector/v.surf.idw/main.c:263
+#: ../raster/r.spread/main.c:547
 #, c-format
-msgid "Interpolating raster map <%s> (%s, %s)..."
+msgid "Minimum of start raster map is less than zero (%d < 0)"
 msgstr ""
-#: ../vector/v.surf.idw/read_sites.c:37
+#: ../raster/r.spread/main.c:555
 #, c-format
-msgid "Input vector map <%s> is 2D - using categories to interpolate"
+msgid "Reading %s..."
 msgstr ""
-#: ../vector/v.surf.idw/read_sites.c:40
+#: ../raster/r.fill.dir/wtrshed.c:95
 #, c-format
-msgid "Input vector map <%s> is 3D - using z-coordinates to interpolate"
+msgid "Watershed pass %d"
 msgstr ""
-#: ../vector/v.surf.idw/read_sites.c:50 ../vector/v.sample/main.c:133
-#: ../vector/v.reclass/main.c:128
-#, c-format
-msgid "Database connection not defined for layer %s"
+#: ../raster/r.fill.dir/main.c:88
+msgid "sink"
 msgstr ""
-#: ../vector/v.surf.idw/read_sites.c:65 ../vector/v.to.rast3/main.c:99
-#: ../vector/v.sample/main.c:240 ../vector/v.class/main.c:129
-#: ../vector/v.surf.bspline/main.c:389 ../vector/v.surf.bspline/crosscorr.c:133
-#: ../vector/v.what.rast/main.c:183 ../vector/v.buffer/main.c:434
-msgid "Column type not supported"
-msgstr "Kolonas tips nav atbalstīts"
-#: ../vector/v.surf.idw/read_sites.c:68 ../vector/v.to.rast3/main.c:95
-#: ../vector/v.sample/main.c:152 ../vector/v.class/main.c:132
-#: ../vector/v.univar/main.c:366 ../vector/v.out.lidar/main.c:132
-#: ../vector/v.out.lidar/main.c:167 ../vector/v.vol.rst/user1.c:112
-#: ../vector/v.surf.bspline/main.c:392 ../vector/v.normal/main.c:134
-#: ../ps/ps.map/catval.c:66 ../ps/ps.map/catval.c:131 ../ps/ps.map/catval.c:198
-msgid "Unable to select data from table"
+#: ../raster/r.fill.dir/main.c:89
+msgid "fill sinks"
 msgstr ""
-#: ../vector/v.surf.idw/read_sites.c:70
-#, c-format
-msgid "One record selected from table"
-msgid_plural "%d records selected from table"
-msgstr[0] ""
-msgstr[1] ""
-msgstr[2] ""
-#: ../vector/v.surf.idw/read_sites.c:107
-#: ../vector/v.surf.bspline/crosscorr.c:220
-#, c-format
-msgid "No record for point (cat = %d)"
+#: ../raster/r.fill.dir/main.c:90
+msgid "depressions"
 msgstr ""
-#: ../vector/v.surf.idw/read_sites.c:123
-#, c-format
-msgid "%ld point loaded"
-msgid_plural "%ld points loaded"
-msgstr[0] ""
-msgstr[1] ""
-msgstr[2] ""
-#: ../vector/v.timestamp/main.c:39
-msgid "Modifies a timestamp for a vector map."
+#: ../raster/r.fill.dir/main.c:92
+msgid ""
+"Filters and generates a depressionless elevation map and a flow direction "
+"map from a given elevation raster map."
 msgstr ""
-#: ../vector/v.timestamp/main.c:40
-msgid "Print/add/remove a timestamp for a vector map."
+#: ../raster/r.fill.dir/main.c:99
+msgid "Name for output depressionless elevation raster map"
 msgstr ""
-#: ../vector/v.timestamp/main.c:66
-#, c-format
-msgid "Vector map <%s> not found %s"
+#: ../raster/r.fill.dir/main.c:103
+msgid ""
+"Name for output flow direction map for depressionless elevation raster map"
 msgstr ""
-#: ../vector/v.segment/main.c:62 ../vector/v.split/main.c:57
-#: ../vector/v.edit/main.c:58 ../vector/v.build.polylines/main.c:114
-#: ../vector/v.to.points/main.c:57
-msgid "node"
-msgstr "mezgls"
-#: ../vector/v.segment/main.c:64 ../vector/v.split/main.c:58
-msgid "segment"
+#: ../raster/r.fill.dir/main.c:108
+msgid "Name for output raster map of problem areas"
 msgstr ""
-#: ../vector/v.segment/main.c:65 ../vector/v.split/main.c:59
-#: ../vector/v.edit/main.c:60 ../vector/v.build.polylines/main.c:115
-#: ../vector/v.to.points/main.c:58
-msgid "vertex"
+#: ../raster/r.fill.dir/main.c:115
+msgid "Aspect direction format"
 msgstr ""
-#: ../vector/v.segment/main.c:67
-msgid "Creates points/segments from input vector lines and positions."
+#: ../raster/r.fill.dir/main.c:121
+msgid "Find unresolved areas only"
 msgstr ""
-#: ../vector/v.segment/main.c:70
-msgid "Name of input vector lines map"
-msgstr ""
-#: ../vector/v.segment/main.c:79
-msgid "Name of file containing segment rules"
-msgstr ""
-#: ../vector/v.segment/main.c:146 ../vector/v.segment/main.c:190
+#: ../raster/r.fill.dir/main.c:127
 #, c-format
-msgid "Unable to read input: %s"
+msgid "The '%c' flag requires '%s'to be specified"
 msgstr ""
-#: ../vector/v.segment/main.c:157 ../vector/v.segment/main.c:201
-#, c-format
-msgid "Unable to find line of cat %d"
+#: ../raster/r.fill.dir/main.c:148
+msgid "Direction map is D8 resolution, i.e. 45 degrees"
 msgstr ""
-#: ../vector/v.segment/main.c:172
-#, c-format
-msgid ""
-"Unable to get point on line: cat = %d offset = %f (line length = %.15g)\n"
-"%s"
+#: ../raster/r.fill.dir/main.c:190
+msgid "Reading input elevation raster map..."
 msgstr ""
-#: ../vector/v.segment/main.c:226
-msgid "End of segment > line length -> cut"
+#: ../raster/r.fill.dir/main.c:200
+msgid "Filling sinks..."
 msgstr ""
-#: ../vector/v.segment/main.c:232
-#, c-format
-msgid ""
-"Unable to make line segment: cat = %d : %f - %f (line length = %.15g)\n"
-"%s"
+#: ../raster/r.fill.dir/main.c:204
+msgid "Determining flow directions for ambiguous cases..."
 msgstr ""
-#: ../vector/v.segment/main.c:254 ../vector/v.lrs/v.lrs.segment/main.c:336
-#, c-format
-msgid "Incorrect segment type: %s"
+#: ../raster/r.fill.dir/main.c:217
+msgid "Repeat to get the final directions..."
 msgstr ""
-#: ../vector/v.segment/main.c:261
+#: ../raster/r.fill.dir/dopolys.c:84
 #, c-format
-msgid "%d point read from input"
-msgid_plural "%d points read from input"
+msgid "Found %d unresolved area"
+msgid_plural "Found %d unresolved areas"
 msgstr[0] ""
 msgstr[1] ""
 msgstr[2] ""
-#. GTC Number of lost points
-#. GTC Number of lost lines
-#: ../vector/v.segment/main.c:265 ../vector/v.segment/main.c:276
-#: ../vector/v.lrs/v.lrs.segment/main.c:359
-#: ../vector/v.lrs/v.lrs.segment/main.c:371
+#: ../raster/r.fill.dir/resolve.c:136
 #, c-format
-msgid "%d lost"
-msgid_plural "%d lost"
-msgstr[0] ""
-msgstr[1] ""
-msgstr[2] ""
+msgid "Downward pass %d"
+msgstr ""
-#. GTC %s is replaced with message indicating number of lost points.
-#: ../vector/v.segment/main.c:267
+#: ../raster/r.fill.dir/resolve.c:173
 #, c-format
-msgid "%d point written to output map (%s)"
-msgid_plural "%d points written to output map (%s)"
-msgstr[0] ""
-msgstr[1] ""
-msgstr[2] ""
-#: ../vector/v.segment/main.c:272
-#, c-format
-msgid "%d line read from input"
-msgid_plural "%d lines read from input"
-msgstr[0] ""
-msgstr[1] ""
-msgstr[2] ""
-#. GTC %s is replaced with message indicating number of lost lines.
-#: ../vector/v.segment/main.c:278
-#, c-format
-msgid "%d line written to output map (%s)"
-msgid_plural "%d lines written to output map (%s)"
-msgstr[0] ""
-msgstr[1] ""
-msgstr[2] ""
-#: ../vector/v.in.pdal/filters.c:46
-#, c-format
-msgid "4 values required for '%s' option"
+msgid "Upward pass %d"
 msgstr ""
-#: ../vector/v.in.pdal/filters.c:68 ../vector/v.decimate/main.c:292
-#: ../vector/v.in.lidar/main.c:433
-#, c-format
-msgid "Invalid zrange <%s>"
+#: ../raster/r.in.ascii/main.c:74
+msgid "Converts a GRASS ASCII raster file to binary raster map."
 msgstr ""
-#: ../vector/v.in.pdal/projection.c:125
-msgid "Overriding projection check"
+#: ../raster/r.in.ascii/main.c:85
+msgid "Default: CELL for integer values, DCELL for floating-point values"
 msgstr ""
-#: ../vector/v.out.vtk/head.c:27
-msgid "writeVTKHeader: Writing VTK-Header"
+#: ../raster/r.in.ascii/main.c:97 ../raster/r.in.ascii/main.c:102
+msgid "Default: read from header"
 msgstr ""
-#: ../vector/v.out.vtk/main.c:51
-msgid "Converts a vector map to VTK ASCII output."
+#: ../raster/r.in.ascii/main.c:99
+msgid "Multiplier for ASCII data"
 msgstr ""
-#: ../vector/v.out.vtk/main.c:59
-msgid "Name for output VTK file"
+#: ../raster/r.in.ascii/main.c:103
+msgid "String representing NULL value data cell"
 msgstr ""
-#: ../vector/v.out.vtk/main.c:89
-msgid "Export numeric attribute table fields as VTK scalar variables"
+#: ../raster/r.in.ascii/main.c:104
+msgid "NULL data"
 msgstr ""
-#: ../vector/v.out.vtk/main.c:153 ../vector/v.out.ascii/args.c:109
-msgid "Failed to interpret 'dp' parameter as an integer"
+#: ../raster/r.in.ascii/main.c:109
+msgid "SURFER (Golden Software) ASCII file will be imported"
 msgstr ""
-#: ../vector/v.out.vtk/main.c:155
-msgid "dp has to be from 0 to 8"
+#: ../raster/r.in.ascii/main.c:128
+#, c-format
+msgid "Wrong entry for multiplier: %s"
 msgstr ""
-#: ../vector/v.out.vtk/main.c:164
-msgid "Failed to interpret 'layer' parameter as an integer"
+#: ../raster/r.in.ascii/main.c:153 ../raster3d/r3.in.ascii/main.c:172
+msgid "Unable to read input from stdin"
 msgstr ""
-#: ../vector/v.out.vtk/main.c:183
+#: ../raster/r.in.ascii/main.c:160
 #, c-format
-msgid "Export of areas requires topology. Please adjust '%s' option or rebuild topology."
+msgid "Unable to read input from <%s>"
 msgstr ""
-#: ../vector/v.out.vtk/writeVTK.c:196
-msgid "No coordinates to generate the output! Maybe an empty vector type chosen?"
+#: ../raster/r.in.ascii/main.c:180
+msgid "Can't get cell header"
 msgstr ""
-#: ../vector/v.out.vtk/writeVTK.c:585 ../vector/v.out.ogr/attrb.c:48
+#: ../raster/r.in.ascii/main.c:202
 #, c-format
-msgid "Cannot select attributes for cat = %d"
+msgid "Data conversion failed at row %d, col %d"
 msgstr ""
-#: ../vector/v.out.vtk/writeVTK.c:589 ../vector/v.lrs/v.lrs.label/main.c:331
-#: ../vector/v.out.ogr/attrb.c:53 ../vector/v.overlay/main.c:487
-#: ../vector/v.out.svg/main.c:400
-msgid "Unable to fetch data from table"
+#: ../raster/r.in.ascii/main.c:275 ../raster3d/r3.in.ascii/main.c:130
+msgid "Unable to write to file"
 msgstr ""
-#: ../vector/v.out.vtk/writeVTK.c:632
-msgid "Cannot export attribute table fields for layer < 1. Skipping export"
+#: ../raster/r.in.ascii/gethead.c:35
+msgid "input file is not a Surfer ascii grid file"
 msgstr ""
-#: ../vector/v.out.vtk/writeVTK.c:640
-msgid "No attribute table found"
+#: ../raster/r.in.ascii/gethead.c:41
+msgid "error reading the column and row dimension from the Surfer grid file"
 msgstr ""
-#: ../vector/v.out.vtk/writeVTK.c:655 ../vector/v.random/main.c:271
-#: ../vector/v.profile/main.c:362 ../vector/v.profile/main.c:468
-#: ../vector/v.out.ogr/main.c:636 ../vector/v.in.ascii/main.c:433
-#: ../vector/v.out.postgis/table.c:41 ../vector/v.info/print.c:152
-#: ../vector/v.patch/main.c:162 ../vector/v.patch/main.c:202
-#: ../vector/v.reclass/main.c:193 ../vector/v.out.svg/main.c:165
-#: ../vector/v.db.connect/main.c:228 ../doc/vector/v.example/main.c:137
-#: ../db/db.describe/main.c:67 ../db/db.columns/main.c:62
-#: ../scripts/db.univar/db.univar.py:112
-msgid "Unable to describe table <%s>"
+#: ../raster/r.in.ascii/gethead.c:47
+msgid "error reading the X range from the Surfer grid file"
 msgstr ""
-#: ../vector/v.out.vtk/writeVTK.c:673
-msgid "No numerical attributes found. Skipping export"
+#: ../raster/r.in.ascii/gethead.c:53
+msgid "error reading the Y range from the Surfer grid file"
 msgstr ""
-#: ../vector/v.out.vtk/writeVTK.c:732 ../vector/v.out.vtk/writeVTK.c:763
-#: ../vector/v.out.vtk/writeVTK.c:794 ../vector/v.out.vtk/writeVTK.c:823
-#, c-format
-msgid "Error reading value of attribute '%s'"
+#: ../raster/r.in.ascii/gethead.c:59
+msgid "error reading the Z range from the Surfer grid file"
 msgstr ""
-#: ../vector/v.net.flow/main.c:62
-msgid "Computes the maximum flow between two sets of nodes in the network."
+#: ../raster/r.in.ascii/gethead.c:105
+msgid "error getting file position"
 msgstr ""
-#: ../vector/v.net.flow/main.c:84
-msgid "Name for output vector map containing a minimum cut"
+#: ../raster/r.in.ascii/gethead.c:164
+msgid "illegal type field: using type int"
 msgstr ""
-#: ../vector/v.net.flow/main.c:107
-msgid "Source category values"
+#: ../raster/r.in.ascii/gethead.c:169
+msgid "ignoring type filed in header, type is set on command line"
 msgstr ""
-#: ../vector/v.net.flow/main.c:113
-msgid "Source WHERE conditions of SQL statement without 'where' keyword"
+#: ../raster/r.in.ascii/gethead.c:176
+msgid "illegal multiplier field: using 1.0"
 msgstr ""
-#: ../vector/v.net.flow/main.c:118
-msgid "Sink category values"
+#: ../raster/r.in.ascii/gethead.c:181
+msgid "ignoring multiplier filed in header, multiplier is set on command line"
 msgstr ""
-#: ../vector/v.net.flow/main.c:119 ../vector/v.net.flow/main.c:125
-msgid "Sink"
+#: ../raster/r.in.ascii/gethead.c:189
+msgid "ignoring null filed in header, null string is set on command line"
 msgstr ""
-#: ../vector/v.net.flow/main.c:124
-msgid "Sink WHERE conditions of SQL statement without 'where' keyword"
+#: ../raster/r.in.ascii/gethead.c:218
+msgid "error in ascii data format"
 msgstr ""
-#: ../vector/v.net.flow/main.c:199
+#: ../raster/r.in.ascii/gethead.c:248
 #, c-format
-msgid "No source features selected. Please check options '%s', '%s'."
+msgid "Duplicate \"%s\" field in header"
 msgstr ""
-#: ../vector/v.net.flow/main.c:206
+#: ../raster/r.in.ascii/gethead.c:253
 #, c-format
-msgid "No sink features selected. Please check options '%s', '%s'."
+msgid "Illegal \"%s\" value in header: %s"
 msgstr ""
-#: ../vector/v.net.flow/main.c:215
-msgid "No sources"
+#: ../raster/r.in.ascii/gethead.c:261
+#, c-format
+msgid "\"%s\" field missing from header"
 msgstr ""
-#: ../vector/v.net.flow/main.c:218
-msgid "No sinks"
+#: ../raster/r.basins.fill/main.c:58
+msgid "Generates watershed subbasins raster map."
 msgstr ""
-#: ../vector/v.net.flow/main.c:242
-msgid "Writing the output..."
+#: ../raster/r.basins.fill/main.c:62
+msgid "Name of input coded stream network raster map"
 msgstr ""
-#: ../vector/v.split/main.c:56
-msgid "densification"
+#: ../raster/r.basins.fill/main.c:66
+msgid "Name of input thinned ridge network raster map"
 msgstr ""
-#: ../vector/v.split/main.c:60
-msgid "Splits vector lines to shorter segments."
+#: ../raster/r.basins.fill/main.c:74
+msgid "Number of passes through the dataset"
 msgstr ""
-#: ../vector/v.split/main.c:73
-msgid "Maximum segment length"
+#: ../raster/r.basins.fill/main.c:122
+msgid "Forward sweep complete"
 msgstr ""
-#: ../vector/v.split/main.c:82
-msgid "Length units"
+#: ../raster/r.basins.fill/main.c:139
+msgid "Reverse sweep complete"
 msgstr ""
-#: ../vector/v.split/main.c:89
-msgid "Maximum number of vertices in segment"
+#: ../raster/r.basins.fill/read_map.c:39
+#, c-format
+msgid "Reading <%s> ... "
 msgstr ""
-#: ../vector/v.split/main.c:93
-msgid "Add new vertices, but do not split"
+#: ../raster/r.transect/main.c:84
+#, c-format
+msgid "End coordinate: %.15g, %.15g"
 msgstr ""
-#: ../vector/v.split/main.c:94 ../vector/v.split/main.c:99
-msgid "Applies only to 'length' option"
+#: ../raster/r.transect/main.c:107
+msgid ""
+"Outputs raster map layer values lying along user defined transect line(s)."
 msgstr ""
-#: ../vector/v.split/main.c:98
-msgid "Force segments to be exactly of given length, except for last one"
+#: ../raster/r.transect/main.c:111
+msgid "Raster map to be queried"
 msgstr ""
-#: ../vector/v.split/main.c:108
-msgid "Use either length or vertices"
+#: ../raster/r.transect/main.c:117
+msgid "Transect definition"
 msgstr ""
-#: ../vector/v.split/main.c:115
+#: ../raster/r.flow/mem.c:40
 #, c-format
-msgid "Length must be positive but is %g"
+msgid "Unable to write segment file for %s"
 msgstr ""
-#: ../vector/v.split/main.c:131
-#, c-format
-msgid "Unknown unit %s"
+#: ../raster/r.flow/main.c:423
+msgid "Constructs flowlines."
 msgstr ""
-#: ../vector/v.split/main.c:149
-msgid "Can not get projection units"
+#: ../raster/r.flow/main.c:425
+msgid ""
+"Computes flowlines, flowpath lengths, and flowaccumulation (contributing "
+"areas) from a elevation raster map."
 msgstr ""
-#: ../vector/v.split/main.c:156
-#, c-format
-msgid "Length in map units: %g"
+#: ../raster/r.flow/main.c:434
+#: ../locale/scriptstrings/d.rast.edit_to_translate.c:5
+msgid "Name of input aspect raster map"
 msgstr ""
-#: ../vector/v.split/main.c:158
-#, c-format
-msgid "Length in meters: %g"
+#: ../raster/r.flow/main.c:440
+msgid "Name of input barrier raster map"
 msgstr ""
-#: ../vector/v.split/main.c:164
-msgid "Number of vertices must be at least 2"
+#: ../raster/r.flow/main.c:447
+msgid "Number of cells between flowlines"
 msgstr ""
-#: ../vector/v.split/main.c:250
-#, c-format
-msgid "Unable to make line segment: %f - %f (line length = %f)"
+#: ../raster/r.flow/main.c:453
+msgid "Maximum number of segments per flowline"
 msgstr ""
-#: ../vector/v.edit/close.c:56 ../vector/v.edit/snap.c:111
-#, c-format
-msgid "Unable to rewrite line %d"
+#: ../raster/r.flow/main.c:458
+msgid "Name for output flow line vector map"
 msgstr ""
-#: ../vector/v.edit/args.c:20
-msgid "Name of vector map to edit"
+#: ../raster/r.flow/main.c:464
+msgid "Name for output flow path length raster map"
 msgstr ""
-#: ../vector/v.edit/args.c:36
-msgid "Tool"
+#: ../raster/r.flow/main.c:470
+msgid "Name for output flow accumulation raster map"
 msgstr ""
-#: ../vector/v.edit/args.c:61
-msgid "Create new (empty) vector map"
+#: ../raster/r.flow/main.c:476
+msgid "Compute upslope flowlines instead of default downhill flowlines"
 msgstr ""
-#: ../vector/v.edit/args.c:62
-msgid "Add new features to existing vector map"
+#: ../raster/r.flow/main.c:480
+msgid "3D lengths instead of 2D"
 msgstr ""
-#: ../vector/v.edit/args.c:63
-msgid "Delete selected features from vector map"
+#: ../raster/r.flow/main.c:484
+msgid "Use less memory, at a performance penalty"
 msgstr ""
-#: ../vector/v.edit/args.c:64
-msgid "Move selected features in vector map"
+#: ../raster/r.flow/main.c:539
+msgid "You must select one or more output maps (flout, lgout, dsout)"
 msgstr ""
-#: ../vector/v.edit/args.c:65
-msgid "Move vertex of selected vector lines"
+#: ../raster/r.flow/main.c:555
+msgid ""
+"lat/long projection not supported by r.flow. Please use 'r.watershed' for "
+"calculating flow accumulation."
 msgstr ""
-#: ../vector/v.edit/args.c:66
-msgid "Remove vertex from selected vector lines"
+#: ../raster/r.flow/io.c:87
+msgid "Elevation raster map resolution differs from current region resolution"
 msgstr ""
-#: ../vector/v.edit/args.c:67
-msgid "Add new vertex to selected vector lines"
+#: ../raster/r.flow/io.c:104
+msgid "Resolution of aspect file differs from current region resolution"
 msgstr ""
-#: ../vector/v.edit/args.c:68
-msgid "Merge selected vector lines"
+#: ../raster/r.flow/io.c:121
+msgid "Reading input files: barrier"
 msgstr ""
-#: ../vector/v.edit/args.c:69
-msgid "Break/split vector lines"
+#: ../raster/r.flow/io.c:149
+#, c-format
+msgid "Cannot create segment file %s"
 msgstr ""
-#: ../vector/v.edit/args.c:70
-msgid "Select lines and print their ID's"
+#: ../raster/r.flow/io.c:154
+#, c-format
+msgid "Cannot format segment file %s"
 msgstr ""
-#: ../vector/v.edit/args.c:71
-msgid "Set new categories to selected vector features for defined layer"
+#: ../raster/r.flow/io.c:160
+#, c-format
+msgid "Cannot open segment file %s"
 msgstr ""
-#: ../vector/v.edit/args.c:73
-msgid "Delete categories from selected vector features for defined layer"
+#: ../raster/r.flow/precomp.c:48
+msgid "Precomputing e/w distances..."
 msgstr ""
-#: ../vector/v.edit/args.c:75
-msgid "Copy selected features"
+#: ../raster/r.flow/precomp.c:50
+msgid "Precomputing quantization tolerances..."
 msgstr ""
-#: ../vector/v.edit/args.c:76
-msgid "Snap vector features in given threshold"
+#: ../raster/r.flow/precomp.c:53
+msgid "Precomputing inverted elevations..."
 msgstr ""
-#: ../vector/v.edit/args.c:77
-msgid "Flip direction of selected vector lines"
+#: ../raster/r.flow/precomp.c:57
+msgid "Precomputing interpolated border elevations..."
 msgstr ""
-#: ../vector/v.edit/args.c:78
-msgid "Connect two lines"
+#: ../raster/r.flow/precomp.c:63
+msgid "Precomputing re-oriented aspects..."
 msgstr ""
-#: ../vector/v.edit/args.c:79
-#, fuzzy
-msgid "Extend lines"
-msgstr "Rakstu jaunu failu... \n"
-#: ../vector/v.edit/args.c:80
-msgid "Extend start nodes"
+#: ../raster/r.flow/precomp.c:67
+msgid "Precomputing aspects..."
 msgstr ""
-#: ../vector/v.edit/args.c:81
-msgid "Extend end nodes"
+#: ../raster/r.flow/precomp.c:111
+#, c-format
+msgid ""
+"Resolution too unbalanced:\n"
+"atan2(%f deg, %f deg) =%f < %f tolerance\n"
+"please resample input map"
 msgstr ""
-#: ../vector/v.edit/args.c:82
-msgid "Z bulk-labeling (automated assignment of z coordinate to vector lines)"
+#: ../raster/r.flow/precomp.c:116
+#, c-format
+msgid "Resolution too unbalanced (%f x %f); please resample input map"
 msgstr ""
-#: ../vector/v.edit/args.c:84
-msgid "Change feature type (point<->centroid, line<->boundary)"
+#: ../raster/r.texture/h_measure.c:156
+#, c-format
+msgid ""
+"Too many categories (found: %i, max: %i). Try to rescale or reclassify the "
+"map"
 msgstr ""
-#: ../vector/v.edit/args.c:85
-msgid "Delete selected areas from vector map (based on selected centroids)"
+#: ../raster/r.texture/main.c:68
+#, c-format
+msgid "Unknown measure <%s>"
 msgstr ""
-#: ../vector/v.edit/args.c:93
-msgid "Name of file containing data in GRASS ASCII vector format"
+#: ../raster/r.texture/main.c:105
+msgid "texture"
 msgstr ""
-#: ../vector/v.edit/args.c:105
-msgid "Difference in x,y,z direction for moving feature or vertex"
+#: ../raster/r.texture/main.c:107
+msgid "Generate images with textural features from a raster map."
 msgstr ""
-#: ../vector/v.edit/args.c:112
-msgid "Threshold distance (coords,snap,query)"
+#: ../raster/r.texture/main.c:121
+msgid "The size of moving window (odd and >= 3)"
 msgstr ""
-#: ../vector/v.edit/args.c:114
-msgid "'-1' for threshold based on the current resolution settings"
+#: ../raster/r.texture/main.c:131
+msgid "The distance between two samples (>= 1)"
 msgstr ""
-#: ../vector/v.edit/args.c:130
-msgid "List of point coordinates"
+#: ../raster/r.texture/main.c:132
+msgid "The distance must be smaller than the size of the moving window"
 msgstr ""
-#: ../vector/v.edit/args.c:139
-msgid "Bounding box for selecting features"
+#: ../raster/r.texture/main.c:148
+msgid "Textural measurement method"
 msgstr ""
-#: ../vector/v.edit/args.c:148
-msgid "Polygon for selecting features"
+#: ../raster/r.texture/main.c:152
+msgid "Separate output for each angle (0, 45, 90, 135)"
 msgstr ""
-#: ../vector/v.edit/args.c:158
-msgid "Query tool"
+#: ../raster/r.texture/main.c:153
+msgid ""
+"Angles are counterclockwise from east: 0 is East to West, 45 is North-East "
+"to South-West"
 msgstr ""
-#: ../vector/v.edit/args.c:160
-msgid "For 'shorter' use negative threshold value, positive value for 'longer'"
+#: ../raster/r.texture/main.c:158
+msgid "Calculate all textural measurements"
 msgstr ""
-#: ../vector/v.edit/args.c:166
-msgid "Select only lines or boundaries shorter/longer than threshold distance"
+#: ../raster/r.texture/main.c:162
+msgid "Allow NULL cells in a moving window"
 msgstr ""
-#: ../vector/v.edit/args.c:168
-msgid "Select dangles shorter/longer than threshold distance"
+#: ../raster/r.texture/main.c:163
+#, fuzzy
+msgid "This will also avoid cropping along edges of the current region"
+msgstr "Sākuma punkts ir ārpus pašreizējā reģiona."
+#: ../raster/r.texture/main.c:172
+msgid "Size of the moving window must be > 0"
 msgstr ""
-#: ../vector/v.edit/args.c:175
-msgid "Name of background vector map(s)"
+#: ../raster/r.texture/main.c:174
+msgid "Size of the moving window must be odd"
 msgstr ""
-#: ../vector/v.edit/args.c:182
-msgid "Snap added or modified features in the given threshold to the nearest existing feature"
+#: ../raster/r.texture/main.c:177
+msgid "The distance between two samples must be > 0"
 msgstr ""
-#: ../vector/v.edit/args.c:188
-msgid "Not apply snapping"
+#: ../raster/r.texture/main.c:179
+msgid ""
+"The distance between two samples must be smaller than the size of the moving "
+"window"
 msgstr ""
-#: ../vector/v.edit/args.c:189
-msgid "Snap only to node"
+#: ../raster/r.texture/main.c:200
+msgid "Nothing to compute. Use at least one textural measure."
 msgstr ""
-#: ../vector/v.edit/args.c:190
-msgid "Allow snapping also to vertex"
+#: ../raster/r.texture/main.c:292 ../raster/r.carve/raster.c:13
+#: ../imagery/i.zc/main.c:157
+msgid "Reading raster map..."
 msgstr ""
-#: ../vector/v.edit/args.c:198
-msgid "Starting value and step for z bulk-labeling"
+#: ../raster/r.texture/main.c:342
+#, c-format
+msgid "Calculating %d texture measure"
+msgid_plural "Calculating %d texture measures"
+msgstr[0] ""
+msgstr[1] ""
+msgstr[2] ""
+#: ../raster/r.texture/main.c:345 ../imagery/i.vi/main.c:225
+#, c-format
+msgid "Calculating %s..."
 msgstr ""
-#: ../vector/v.edit/args.c:199
-msgid "Pair: value,step (e.g. 1100,10)"
+#: ../raster/r.in.gdal/main.c:96
+msgid "Imports raster data into a GRASS raster map using GDAL library."
 msgstr ""
-#: ../vector/v.edit/args.c:210
-msgid "Close added boundaries (using threshold distance)"
+#: ../raster/r.in.gdal/main.c:102
+msgid "Name of raster file to be imported"
 msgstr ""
-#: ../vector/v.edit/args.c:214
-msgid "Do not expect header of input data"
+#: ../raster/r.in.gdal/main.c:111
+msgid "Band(s) to select (default is all bands)"
 msgstr ""
-#: ../vector/v.edit/args.c:222
-msgid "Modify only first found feature in bounding box"
+#: ../raster/r.in.gdal/main.c:112 ../raster/r.in.gdal/main.c:225
+msgid "Bands"
 msgstr ""
-#: ../vector/v.edit/args.c:227
-msgid "Connect parallel lines (using extend tools and threshold distance)"
+#: ../raster/r.in.gdal/main.c:129
+msgid "Name of GCPs target location"
 msgstr ""
-#: ../vector/v.edit/args.c:239
-msgid "Polygon must have at least 3 coordinate pairs"
+#: ../raster/r.in.gdal/main.c:131
+msgid ""
+"Name of location to create or to read projection from for GCPs transformation"
 msgstr ""
-#: ../vector/v.edit/args.c:312
-#, c-format
-msgid "Operation '%s' not implemented"
+#: ../raster/r.in.gdal/main.c:148
+msgid "Offset to be added to band numbers"
 msgstr ""
-#: ../vector/v.edit/args.c:321
-#, c-format
-msgid "At least one option from %s must be specified"
+#: ../raster/r.in.gdal/main.c:149
+msgid "If 0, no offset is added and the first band is 1"
 msgstr ""
-#: ../vector/v.edit/args.c:327 ../vector/v.edit/args.c:336
-#: ../vector/v.edit/args.c:343 ../vector/v.edit/args.c:350
-#: ../vector/v.edit/args.c:354
-#, c-format
-msgid "Tool %s requires option %s"
+#: ../raster/r.in.gdal/main.c:157
+msgid ""
+"Zero-padding of band number by filling with leading zeros up to given number"
 msgstr ""
-#: ../vector/v.edit/select.c:73
-#, c-format
-msgid "Threshold value for coordinates is %.2f"
+#: ../raster/r.in.gdal/main.c:158
+msgid "If 0, length will be adjusted to 'offset' number without leading zeros"
 msgstr ""
-#: ../vector/v.edit/select.c:160
-#, c-format
-msgid "Threshold value for querying is %.2f"
+#: ../raster/r.in.gdal/main.c:164
+msgid "Name of the output file that contains the imported map names"
 msgstr ""
-#: ../vector/v.edit/select.c:176
-#, c-format
-msgid "%d of %d feature selected from vector map <%s>"
-msgid_plural "%d of %d features selected from vector map <%s>"
-msgstr[0] ""
-msgstr[1] ""
-msgstr[2] ""
-#: ../vector/v.edit/select.c:496
-msgid "Layer must be > 0 for 'where'"
+#: ../raster/r.in.gdal/main.c:178
+msgid "File prefix for raster attribute tables"
 msgstr ""
-#: ../vector/v.edit/main.c:61
-msgid "Edits a vector map, allows adding, deleting and modifying selected vector features."
+#: ../raster/r.in.gdal/main.c:179
+msgid "The band number and \".csv\" will be appended to the file prefix"
 msgstr ""
-#: ../vector/v.edit/main.c:70
-#, c-format
-msgid "Unable to get category list <%s>"
+#: ../raster/r.in.gdal/main.c:214
+#: ../locale/scriptstrings/r.import_to_translate.c:30
+msgid "Force Lat/Lon maps to fit into geographic coordinates (90N,S; 180E,W)"
 msgstr ""
-#: ../vector/v.edit/main.c:97 ../vector/v.kernel/main.c:230
-#: ../vector/v.in.ogr/main.c:503 ../vector/v.in.lidar/main.c:543
-#: ../scripts/v.unpack/v.unpack.py:99
-#, c-format, python-format
-msgid "Vector map <%s> already exists"
+#: ../raster/r.in.gdal/main.c:224
+msgid "Keep band numbers instead of using band color names"
 msgstr ""
-#: ../vector/v.edit/main.c:117
-msgid "Supported feature types for non-native formats:"
+#: ../raster/r.in.gdal/main.c:230
+msgid ""
+"Create the location specified by the \"location\" parameter and exit. Do not "
+"import the raster file."
 msgstr ""
-#: ../vector/v.edit/main.c:138
-#, c-format
-msgid "Unable to open vector map <%s> on topological level. Try to rebuild vector topology by v.build."
+#: ../raster/r.in.gdal/main.c:240
+msgid "Print number of bands and exit"
 msgstr ""
-#: ../vector/v.edit/main.c:158
-#, c-format
-msgid "Unable to open vector map <%s> as the background map. It is given as vector map to be edited."
+#: ../raster/r.in.gdal/main.c:315
+msgid "You have to specify a target location different from output location"
 msgstr ""
-#: ../vector/v.edit/main.c:169
-#, c-format
-msgid "Background vector map <%s> registered"
+#: ../raster/r.in.gdal/main.c:319
+msgid "You need to specify valid location name."
 msgstr ""
-#: ../vector/v.edit/main.c:206
-msgid "Threshold for snapping must be > 0. No snapping applied."
+#: ../raster/r.in.gdal/main.c:323
+msgid "The '-l' flag only works in Lat/Lon locations"
 msgstr ""
-#: ../vector/v.edit/main.c:213
-msgid "Selecting features..."
+#: ../raster/r.in.gdal/main.c:326
+msgid "The number of digits for band numbering must be equal or greater than 0"
 msgstr ""
-#: ../vector/v.edit/main.c:225
-msgid "No features selected, nothing to edit"
+#: ../raster/r.in.gdal/main.c:339
+msgid "Disabling '-r' flag for new location"
 msgstr ""
-#: ../vector/v.edit/main.c:233
+#: ../raster/r.in.gdal/main.c:347 ../raster/r.in.gdal/main.c:350
 #, c-format
-msgid "Vector map <%s> is not 3D. Tool '%s' requires 3D vector map. Please convert the vector map to 3D using e.g. %s."
+msgid "Using memory cache size: %.1f MiB"
 msgstr ""
-#: ../vector/v.edit/main.c:275
+#: ../raster/r.in.gdal/main.c:359
 #, c-format
-msgid "%d feature added"
-msgid_plural "%d features added"
-msgstr[0] ""
-msgstr[1] ""
-msgstr[2] ""
+msgid "Unable to open datasource <%s>"
+msgstr ""
-#: ../vector/v.edit/main.c:283 ../vector/v.edit/main.c:312
-#: ../vector/v.edit/main.c:323 ../vector/v.edit/main.c:355
-#: ../vector/v.edit/main.c:363 ../vector/v.edit/main.c:372
-#: ../vector/v.edit/main.c:381 ../vector/v.edit/main.c:428
+#: ../raster/r.in.gdal/main.c:370
 #, c-format
-msgid "Threshold value for snapping is %.2f"
+msgid ""
+"Input seems to be NOAA/AVHRR data which needs to be georeferenced with thin "
+"plate spline transformation (%s or %s)."
 msgstr ""
-#: ../vector/v.edit/main.c:295
-#, c-format
-msgid "%d boundary closed"
-msgid_plural "%d boundaries closed"
-msgstr[0] ""
-msgstr[1] ""
-msgstr[2] ""
+#: ../raster/r.in.gdal/main.c:383
+msgid "Input contains subdatasets which may need to be imported separately"
+msgstr ""
-#: ../vector/v.edit/main.c:304
-#, c-format
-msgid "%d feature deleted"
-msgid_plural "%d features deleted"
-msgstr[0] ""
-msgstr[1] ""
-msgstr[2] ""
+#: ../raster/r.in.gdal/main.c:423
+msgid ""
+"Input raster map is flipped or rotated - cannot import. You may use "
+"'gdalwarp' to transform the map to North-up."
+msgstr ""
-#: ../vector/v.edit/main.c:315
+#: ../raster/r.in.gdal/main.c:442
 #, c-format
-msgid "%d feature moved"
-msgid_plural "%d features moved"
-msgstr[0] ""
-msgstr[1] ""
-msgstr[2] ""
+msgid ""
+"Unable to fetch the affine transformation coefficients. Flag -%c cannot be "
+"used in this case."
+msgstr ""
-#: ../vector/v.edit/main.c:326
-#, c-format
-msgid "%d vertex moved"
-msgid_plural "%d vertices moved"
-msgstr[0] ""
-msgstr[1] ""
-msgstr[2] ""
+#: ../raster/r.in.gdal/main.c:470
+msgid ""
+"Map bounds have been constrained to geographic coordinates. You will almost "
+"certainly want to check map bounds and resolution with r.info and reset them "
+"with r.region before going any further."
+msgstr ""
-#: ../vector/v.edit/main.c:332
-#, c-format
-msgid "%d vertex added"
-msgid_plural "%d vertices added"
-msgstr[0] ""
-msgstr[1] ""
-msgstr[2] ""
-#: ../vector/v.edit/main.c:338
-#, c-format
-msgid "%d vertex removed"
-msgid_plural "%d vertices removed"
-msgstr[0] ""
-msgstr[1] ""
-msgstr[2] ""
-#: ../vector/v.edit/main.c:350
-#, c-format
-msgid "%d line broken"
-msgid_plural "%d lines broken"
-msgstr[0] "%d līnija ir bojāta"
-msgstr[1] "%d līnijas ir bojātas"
-msgstr[2] "%d līniju ir bojātas"
-#: ../vector/v.edit/main.c:358
-#, c-format
-msgid "%d line connected"
-msgid_plural "%d lines connected"
-msgstr[0] ""
-msgstr[1] ""
-msgstr[2] ""
-#: ../vector/v.edit/main.c:367 ../vector/v.edit/main.c:376
-#: ../vector/v.edit/main.c:385
+#: ../raster/r.in.gdal/main.c:480
 #, fuzzy, c-format
-msgid "%d line extended"
-msgid_plural "%d lines extended"
-msgstr[0] "%d punkti ierakstīti izejas kartē\n"
-msgstr[1] "%d punkti ierakstīti izejas kartē\n"
-msgstr[2] "%d punkti ierakstīti izejas kartē\n"
+msgid "Importing %d raster bands..."
+msgstr "Eksistējošas rastra kartes nosaukums"
-#: ../vector/v.edit/main.c:391
-#, c-format
-msgid "%d line merged"
-msgid_plural "%d lines merged"
-msgstr[0] ""
-msgstr[1] ""
-msgstr[2] ""
-#: ../vector/v.edit/main.c:400 ../vector/v.edit/main.c:406
-#, c-format
-msgid "%d feature modified"
-msgid_plural "%d features modified"
-msgstr[0] ""
-msgstr[1] ""
-msgstr[2] ""
-#: ../vector/v.edit/main.c:413
-#, c-format
-msgid "Multiple background maps were given. Selected features will be copied only from vector map <%s>."
+#: ../raster/r.in.gdal/main.c:520 ../raster/r.in.gdal/main.c:547
+msgid ""
+"Input raster does not overlap current computational region. Nothing to "
+"import."
 msgstr ""
-#: ../vector/v.edit/main.c:423
-#, c-format
-msgid "%d feature copied"
-msgid_plural "%d features copied"
-msgstr[0] ""
-msgstr[1] ""
-msgstr[2] ""
-#: ../vector/v.edit/main.c:434
-#, c-format
-msgid "%d line flipped"
-msgid_plural "%d lines flipped"
-msgstr[0] ""
-msgstr[1] ""
-msgstr[2] ""
-#: ../vector/v.edit/main.c:455
-#, c-format
-msgid "%d line labeled"
-msgid_plural "%d lines labeled"
-msgstr[0] ""
-msgstr[1] ""
-msgstr[2] ""
-#: ../vector/v.edit/main.c:464
-#, c-format
-msgid "%d feature converted"
-msgid_plural "%d features converted"
-msgstr[0] ""
-msgstr[1] ""
-msgstr[2] ""
-#: ../vector/v.edit/main.c:469
-msgid "No feature modified"
+#: ../raster/r.in.gdal/main.c:623
+msgid "Unable to open the map names output text file"
 msgstr ""
-#: ../vector/v.edit/main.c:476
+#: ../raster/r.in.gdal/main.c:654
 #, c-format
-msgid "Select feature %d is not centroid, ignoring..."
+msgid "Unable to get raster band number %d"
 msgstr ""
-#: ../vector/v.edit/main.c:483
+#: ../raster/r.in.gdal/main.c:731
 #, c-format
-msgid "%d area removed"
-msgid_plural "%d areas removed"
-msgstr[0] ""
-msgstr[1] ""
-msgstr[2] ""
-#: ../vector/v.edit/main.c:489
-msgid "Operation not implemented"
+msgid "Copying %d GCPS in points file for <%s>"
 msgstr ""
-#: ../vector/v.random/main.c:101 ../vector/v.qcount/main.c:62
-#: ../vector/v.mkgrid/main.c:73 ../vector/v.kcv/main.c:58
-#: ../vector/v.perturb/main.c:66 ../vector/v.normal/main.c:75
-msgid "point pattern"
+#: ../raster/r.in.gdal/main.c:739
+msgid "GCPs have the following OpenGIS WKT Coordinate System:"
 msgstr ""
-#: ../vector/v.random/main.c:102
-msgid "stratified random sampling"
+#: ../raster/r.in.gdal/main.c:762
+msgid "Re-projecting GCPs table:"
 msgstr ""
-#: ../vector/v.random/main.c:103
-msgid "Generates random 2D/3D vector points."
+#: ../raster/r.in.gdal/main.c:763
+#, c-format
+msgid "* Input projection for GCP table: %s"
 msgstr ""
-#: ../vector/v.random/main.c:111
-msgid "Number of points to be created"
-msgstr "Izveidojamo punktu skaits"
-#: ../vector/v.random/main.c:116
-msgid "Restrict points to areas in input vector"
+#: ../raster/r.in.gdal/main.c:765
+#, c-format
+msgid "* Output projection for GCP table: %s"
 msgstr ""
-#: ../vector/v.random/main.c:133
-msgid "Minimum z height (needs -z flag or column name)"
+#: ../raster/r.in.gdal/main.c:786
+#, c-format
+msgid "Error in pj_do_proj (can't re-projection GCP %i)"
 msgstr ""
-#: ../vector/v.random/main.c:135 ../vector/v.random/main.c:144
-#: ../vector/v.random/main.c:157 ../vector/v.random/main.c:167
-#: ../vector/v.random/main.c:172 ../vector/v.in.db/main.c:85
-msgid "3D output"
-msgstr "3D izvade"
-#: ../vector/v.random/main.c:142
-msgid "Maximum z height (needs -z flag or column name)"
+#: ../raster/r.in.gdal/main.c:841
+#, c-format
+msgid ""
+"The target for the output group <%s> has been set to location <%s>, mapset "
+"<PERMANENT>."
 msgstr ""
-#: ../vector/v.random/main.c:151
-msgid "The seed to initialize the random generator. If not set the process ID is used"
+#: ../raster/r.in.gdal/main.c:912
+msgid "Unable to translate projection key values of input GCPs"
 msgstr ""
-#: ../vector/v.random/main.c:154
-msgid "Name of column for z values"
+#: ../raster/r.in.gdal/main.c:928
+msgid "Unable to get projection info of target location"
 msgstr ""
-#: ../vector/v.random/main.c:156
-msgid "Writes z values to column"
+#: ../raster/r.in.gdal/main.c:930
+msgid "Unable to get projection units of target location"
 msgstr ""
-#: ../vector/v.random/main.c:164
-msgid "Type of column for z values"
+#: ../raster/r.in.gdal/main.c:932
+msgid "Unable to get projection key values of target location"
 msgstr ""
-#: ../vector/v.random/main.c:171
-msgid "Create 3D output"
+#: ../raster/r.in.gdal/main.c:974
+#, c-format
+msgid "Importing raster map <%s>..."
 msgstr ""
-#: ../vector/v.random/main.c:176
-msgid "Generate n points for each individual area"
+#: ../raster/r.in.gdal/main.c:1089 ../raster/r.in.gdal/main.c:1144
+#: ../raster/r.in.gdal/main.c:1218
+msgid "Invalid row"
 msgstr ""
-#: ../vector/v.random/main.c:190
-#, c-format
-msgid "Number of points must be > 0 (%d given)"
-msgstr "Punktu skaitam jābūt lielākam par 0 (%d doti)"
-#: ../vector/v.random/main.c:206 ../vector/v.drape/main.c:150
-#: ../vector/v.buffer/main.c:348
-#, c-format
-msgid "Invalid layer number (%d). Parameter '%s' or '%s' specified, assuming layer '1'."
+#: ../raster/r.in.gdal/main.c:1486 ../raster/r.in.gdal/main.c:1543
+msgid "Inconsistent color rules in RAT"
 msgstr ""
-#: ../vector/v.random/main.c:216
+#: ../raster/r.in.gdal/main.c:1600
 #, c-format
-msgid "No areas in vector map <%s>"
+msgid "Setting grey color table for <%s> (8bit, full range)"
 msgstr ""
-#: ../vector/v.random/main.c:221
+#: ../raster/r.in.gdal/main.c:1614
 #, c-format
-msgid "The <-%c> flag requires an input vector with areas"
+msgid "Setting grey color table for <%s> (16bit, image range)"
 msgstr ""
-#: ../vector/v.random/main.c:275
-msgid "Table should contain only two columns"
-msgstr ""
-#: ../vector/v.random/main.c:284
-msgid "You have created unsupported column type. This module supports only INTEGER and DOUBLE PRECISION column types."
-msgstr ""
-#: ../vector/v.random/main.c:347
+#: ../raster/r.in.gdal/main.c:1716
 #, c-format
-msgid "Selected areas in input vector <%s> do not overlap with the current region"
+msgid "Unable to open file <%s>: %s."
 msgstr ""
-#: ../vector/v.random/main.c:359
-#, c-format
-msgid "Input vector <%s> does not overlap with the current region"
-msgstr ""
+#: ../raster/r.fill.stats/main.c:155
+#, fuzzy
+msgid "Spatial weights neighborhood (cells):"
+msgstr "Līniju skaits"
-#: ../vector/v.random/main.c:384
-msgid "Generating points..."
+#: ../raster/r.fill.stats/main.c:781
+msgid ""
+"Rapidly fills 'no data' cells (NULLs) of a raster map with interpolated "
+"values (IDW)."
 msgstr ""
-#: ../vector/v.profile/main.c:101
+#: ../raster/r.fill.stats/main.c:789
 #, fuzzy
-msgid "Vector map profiling tool"
-msgstr "vektora karte <%s> nav atrasta"
+msgid "Raster map with data gaps to fill"
+msgstr "Profilējamā rastra karte"
-#: ../vector/v.profile/main.c:109 ../vector/v.profile/main.c:143
-#: ../vector/v.profile/main.c:148
+#: ../raster/r.fill.stats/main.c:794
 #, fuzzy
-msgid "Input filter"
-msgstr "Ieejas fails"
+msgid "Name of result output map"
+msgstr "Izvades skripta nosaukums"
-#: ../vector/v.profile/main.c:113
+#: ../raster/r.fill.stats/main.c:799
 #, fuzzy
-msgid "Coordinates for profiling line nodes"
-msgstr "Vienu koordinātu pāri uz līniju, lūdzu"
+msgid "Name of uncertainty output map"
+msgstr "Izejas rastra kartes nosaukums"
-#: ../vector/v.profile/main.c:114 ../vector/v.profile/main.c:183
-#: ../vector/v.profile/main.c:194 ../vector/v.profile/main.c:202
-#, fuzzy
-msgid "Profiling line"
-msgstr "Izveidot punktus visā garumā ilīniju garumā"
+#: ../raster/r.fill.stats/main.c:808
+msgid "Distance threshold (default: in cells) for interpolation"
+msgstr ""
-#: ../vector/v.profile/main.c:121
-#, fuzzy
-msgid "Buffer (tolerance) for points in map units"
-msgstr "Bufera izmērs kartes vienībās"
+#: ../raster/r.fill.stats/main.c:817
+msgid "Statistic for interpolated cell values"
+msgstr ""
-#: ../vector/v.profile/main.c:122
-msgid "How far points can be from sampling line"
+#: ../raster/r.fill.stats/main.c:828
+msgid "Minimum input data value to include in interpolation"
 msgstr ""
-#: ../vector/v.profile/main.c:128 ../vector/v.profile/main.c:131
-#: ../vector/v.profile/main.c:140 ../vector/v.profile/main.c:160
-#: ../vector/v.profile/main.c:165 ../vector/v.profile/main.c:171
-#, fuzzy
-msgid "Output formating"
-msgstr "Izejas rastra kartes nosaukums"
-#: ../vector/v.profile/main.c:139
-#, fuzzy
-msgid "Number of significant digits"
+#: ../raster/r.fill.stats/main.c:837
+msgid "Maximum input data value to include in interpolation"
 msgstr ""
-"\n"
-"\n"
-"  Punktu skaits: %d\n"
-#: ../vector/v.profile/main.c:147
+#: ../raster/r.fill.stats/main.c:846
 #, fuzzy
-msgid "Use features only from specified layer"
-msgstr "Drukāt saules pozīcijas apraskstu komandrindas skripta stilā"
+msgid "Power coefficient for IDW interpolation"
+msgstr "Sākuma punkta koordinātes"
-#: ../vector/v.profile/main.c:157
-#, fuzzy
-msgid "Name for profile line and buffer output map"
+#: ../raster/r.fill.stats/main.c:856
+msgid "Minimum number of data cells within search radius"
+msgstr ""
-#: ../vector/v.profile/main.c:159
+#: ../raster/r.fill.stats/main.c:861
 #, fuzzy
-msgid "Profile line and buffer around it will be written"
-msgstr "Izejas karte kurā tiks ierakstīti punkti"
+msgid "Interpret distance as map units, not number of cells"
-#: ../vector/v.profile/main.c:164
-#, fuzzy
-msgid "Do not print column names"
-msgstr "Atslēga (id) kolonas nosaukums"
-#: ../vector/v.profile/main.c:169
-#, fuzzy
-msgid "Do not print 3D vector data (z values)"
-msgstr "Nevajag taisīt atribūtu tabulu"
-#: ../vector/v.profile/main.c:170
-msgid "Only affects 3D vectors"
+#: ../raster/r.fill.stats/main.c:865
+msgid "Keep (preserve) original cell values"
 msgstr ""
-#: ../vector/v.profile/main.c:181
-#, fuzzy
-msgid "Profiling line map"
-#: ../vector/v.profile/main.c:182
-#, fuzzy
-msgid "Vector map containing profiling line"
-msgstr "Ieejošā karte satur līnijas"
-#: ../vector/v.profile/main.c:191
-msgid "WHERE conditions for input profile line map"
+#: ../raster/r.fill.stats/main.c:867
+msgid "By default original values are smoothed"
 msgstr ""
-#: ../vector/v.profile/main.c:193
-msgid "Use to select only one line from profiling line map"
+#: ../raster/r.fill.stats/main.c:871
+msgid "Just print the spatial weights matrix"
 msgstr ""
-#: ../vector/v.profile/main.c:201
-#, fuzzy
-msgid "Profiling line map layer"
-#: ../vector/v.profile/main.c:212
-#, fuzzy
-msgid "Layer 0 not supported"
-#: ../vector/v.profile/main.c:217
-msgid "Failed to interpreter 'dp' parameter as an integer"
+#: ../raster/r.fill.stats/main.c:875
+msgid "Just print estimated memory usage"
 msgstr ""
-#: ../vector/v.profile/main.c:223
-msgid "Tolerance value can not be less than 0"
+#: ../raster/r.fill.stats/main.c:880
+msgid "Single precision floating point output"
 msgstr ""
-#: ../vector/v.profile/main.c:228
-#, fuzzy, c-format
-msgid "<%s> is not a valid vector map name"
-msgstr "izejas līmeņa nosaukums"
-#: ../vector/v.profile/main.c:233
-msgid "No input profile map name provided, but WHERE conditions for it have been set"
+#: ../raster/r.fill.stats/main.c:893
+msgid "You are working with lat/lon data."
 msgstr ""
-#: ../vector/v.profile/main.c:237
-msgid "Profile input coordinates and vector map are provided. Please provide only one of them"
+#: ../raster/r.fill.stats/main.c:894
+msgid "This module uses a straight-line distance metric."
 msgstr ""
-#: ../vector/v.profile/main.c:241
-msgid "No profile input coordinates nor vector map are provided. Please provide one of them"
+#: ../raster/r.fill.stats/main.c:895
+msgid "Expect inaccuracies."
 msgstr ""
-#: ../vector/v.profile/main.c:278
-#, fuzzy
-msgid "At least profile start and end coordinates are required!"
-msgstr "Vaicājuma koordinātes"
-#: ../vector/v.profile/main.c:290 ../vector/v.cluster/main.c:144
-#: ../doc/vector/v.example/main.c:81
-msgid "Unable to set predetermined vector open level"
+#: ../raster/r.fill.stats/main.c:910
+msgid "Result map name cannot be identical with uncertainty map name."
 msgstr ""
-#: ../vector/v.profile/main.c:315 ../vector/v.profile/main.c:330
-#, fuzzy, c-format
-msgid "No database connection defined for map <%s> layer %d, but WHERE condition is provided"
-msgstr "Datubāzes konekcija nav definēta"
-#: ../vector/v.profile/main.c:373 ../vector/v.profile/main.c:478
+#: ../raster/r.fill.stats/main.c:919
 #, fuzzy
-msgid "No features match Your query"
-msgstr "Vektorkartes nosaukums"
+msgid "Maximum distance must be larger than zero."
+msgstr "2 līmeņiem jābūt norādītiem"
-#: ../vector/v.profile/main.c:378 ../vector/v.profile/main.c:391
-msgid "Your query matches more than one record in input profiling map. Currently it's not supported. Enhance WHERE conditions to get only one line."
+#: ../raster/r.fill.stats/main.c:923
+#, c-format
+msgid "Maximum distance must be at least '%.6f' (W-E resolution)."
 msgstr ""
-#: ../vector/v.profile/main.c:384
-msgid "Error while initialising line list"
+#: ../raster/r.fill.stats/main.c:928
+#, c-format
+msgid "Maximum distance must be at least '%.6f' (S-N resolution)."
 msgstr ""
-#: ../vector/v.profile/main.c:396
-msgid "Error while reading vector feature from profile line map"
+#: ../raster/r.fill.stats/main.c:933
+#, c-format
+msgid "Maximum distance must be at least '%.6f' (W-E and S-N resolution)."
 msgstr ""
-#: ../vector/v.profile/main.c:410
-msgid "Your input profile map contains more than one line. Currently it's not supported. Provide WHERE conditions to get only one line."
-msgstr ""
-#: ../vector/v.profile/main.c:557
-#, fuzzy, c-format
-msgid "Unabale to get attribute data for cat %d"
-msgstr "Nevar iatlasīt datus no tabulas"
-#: ../vector/v.profile/main.c:566
+#: ../raster/r.fill.stats/main.c:938
 #, c-format
-msgid "Error while retreiving database record for cat %d"
+msgid ""
+"Maximum distance too large. Adjusted to '%.6f' (diagonal of current region)."
 msgstr ""
-#: ../vector/v.profile/main.c:604
-msgid "Can not write data portion to provided output"
-msgstr ""
+#: ../raster/r.fill.stats/main.c:948
+#, fuzzy
+msgid "Maximum distance must be at least one cell."
+msgstr "Jums ir jāizvēlas vismaz viens rīks"
-#: ../vector/v.voronoi/sw_main.c:188
+#: ../raster/r.fill.stats/main.c:954
 #, c-format
-msgid "Found %d point/centroid in <%s>, but at least 2 are needed"
-msgid_plural "Found %d points/centroids in <%s>, but at least 2 are needed"
-msgstr[0] ""
-msgstr[1] ""
-msgstr[2] ""
-#: ../vector/v.voronoi/sw_main.c:410 ../vector/v.voronoi/sw_main.c:436
-msgid "All boundaries in the list should be valid"
+msgid ""
+"Maximum distance too large. Adjusted to '%lu' cells (diagonal of current "
+"region)."
 msgstr ""
-#: ../vector/v.voronoi/sw_main.c:416 ../vector/v.voronoi/sw_main.c:442
-msgid "Boundary is degenerate"
+#: ../raster/r.fill.stats/main.c:961
+#, fuzzy
+msgid "Minimum number of cells must be at least '1'."
 msgstr ""
+"\n"
+"\n"
+"  Punktu skaits: %d\n"
-#: ../vector/v.voronoi/sw_main.c:468
-#, c-format
-msgid "Found %d vertex in <%s>, but at least 2 are needed"
-msgid_plural "Found %d vertices in <%s>, but at least 2 are needed"
-msgstr[0] ""
-msgstr[1] ""
-msgstr[2] ""
-#: ../vector/v.voronoi/main.c:125 ../vector/v.delaunay/main.c:87
-msgid "triangulation"
+#: ../raster/r.fill.stats/main.c:964
+msgid "Specified minimum number of cells unreachable with current settings."
 msgstr ""
-#: ../vector/v.voronoi/main.c:126
-msgid "skeleton"
+#: ../raster/r.fill.stats/main.c:969
+msgid "Value for 'minimum' must be smaller than value for 'maximum'."
 msgstr ""
-#: ../vector/v.voronoi/main.c:127
-msgid "Creates a Voronoi diagram in current region from an input vector map containing points or centroids."
+#: ../raster/r.fill.stats/main.c:973
+msgid "The 'power' option has no effect in any mode other than 'wmean'."
 msgstr ""
-#: ../vector/v.voronoi/main.c:131 ../vector/v.sample/main.c:82
-#: ../vector/v.surf.bspline/main.c:110
-msgid "Name of input vector point map"
+#: ../raster/r.fill.stats/main.c:984
+msgid ""
+"The specified maximum distance cannot be resolved to whole cells\n"
+" at the current resolution settings."
 msgstr ""
-#: ../vector/v.voronoi/main.c:141
-msgid "Factor for output smoothness"
+#: ../raster/r.fill.stats/main.c:995
+#, c-format
+msgid "W-E size of neighborhood is %lu cells."
 msgstr ""
-#: ../vector/v.voronoi/main.c:142
-msgid "Applies to input areas only. Smaller values produce smoother output but can cause numerical instability."
+#: ../raster/r.fill.stats/main.c:996
+#, c-format
+msgid "S-N size of neighborhood is %lu cells."
 msgstr ""
-#: ../vector/v.voronoi/main.c:149
-msgid "Maximum dangle length of skeletons"
+#: ../raster/r.fill.stats/main.c:999
+msgid "Neighborhood cannot be smaller than 3 cells in X or Y direction."
 msgstr ""
-#: ../vector/v.voronoi/main.c:150
-msgid "Applies only to skeleton extraction. Default = -1 will extract the center line."
+#: ../raster/r.fill.stats/main.c:1052
+#, c-format
+msgid "Input data range is %f to %f.\n"
 msgstr ""
-#: ../vector/v.voronoi/main.c:156
-msgid "Create Voronoi diagram for input areas"
+#: ../raster/r.fill.stats/main.c:1068
+#, c-format
+msgid "Input data type is integer but interpolation mode is '%s'."
 msgstr ""
-#: ../vector/v.voronoi/main.c:161
-msgid "Extract skeletons for input areas"
+#: ../raster/r.fill.stats/main.c:1072
+msgid "Output type changed to floating point (single)."
 msgstr ""
-#: ../vector/v.voronoi/main.c:166
-msgid "Output tessellation as a graph (lines), not areas"
+#: ../raster/r.fill.stats/main.c:1076
+msgid "Output type changed to floating point (double)."
 msgstr ""
-#: ../vector/v.voronoi/main.c:182
+#: ../raster/r.fill.stats/main.c:1081
 #, c-format
-msgid "Option '%s' is too small, set to %g"
+msgid "Ignoring '%c' flag. Output data type will be integer."
 msgstr ""
-#: ../vector/v.voronoi/main.c:208 ../vector/v.to.db/lines.c:75
-#: ../vector/v.to.db/query.c:23 ../vector/v.to.rast/do_lines.c:36
-#: ../vector/v.colors/scan_z.c:31 ../vector/v.colors/scan_cats.c:19
-#: ../vector/v.colors.out/scan_cats.c:28
-msgid "Reading features..."
+#: ../raster/r.fill.stats/main.c:1111
+#, c-format
+msgid ""
+"Input data type is '%s' (%i bytes) and output data type is '%s' (%i bytes)."
 msgstr ""
-#: ../vector/v.voronoi/main.c:226
-#, c-format
-msgid "Voronoi triangulation for %d point..."
-msgid_plural "Voronoi triangulation for %d points..."
-msgstr[0] ""
-msgstr[1] ""
-msgstr[2] ""
+#: ../raster/r.fill.stats/main.c:1252
+#, fuzzy
+msgid "Interpolating:"
+msgstr "Rakstu jaunu failu... \n"
-#: ../vector/v.voronoi/main.c:230 ../vector/v.delaunay/in_out.c:93
-msgid "Writing edges..."
-msgstr ""
+#: ../raster/r.fill.stats/main.c:1386
+#, fuzzy, c-format
+msgid "Processing time was %ih%im%is."
+msgstr "Izveidot punktus visā garumā ilīniju garumā"
-#: ../vector/v.voronoi/main.c:239
-msgid "Thin skeletons ..."
+#: ../raster/r.colors/edit_colors.c:61
+msgid "Creates/modifies the color table associated with a 3D raster map."
 msgstr ""
-#: ../vector/v.voronoi/main.c:322 ../vector/v.in.db/main.c:235
-msgid "Writing features..."
+#: ../raster/r.colors/edit_colors.c:65
+msgid "Creates/modifies the color table associated with a raster map."
 msgstr ""
-#: ../vector/v.voronoi/main.c:396
-msgid "No table"
+#: ../raster/r.colors/edit_colors.c:75 ../raster/r.colors/edit_colors.c:87
+msgid "Map"
 msgstr ""
-#: ../vector/v.voronoi/main.c:411
-msgid "Cannot copy table"
-msgstr "Nevar nokopēt tabulu"
-#: ../vector/v.voronoi/skeleton.c:293 ../vector/v.voronoi/skeleton.c:400
-#, c-format
-msgid "Pass %d"
+#: ../raster/r.colors/edit_colors.c:81
+msgid "Input file with one map name per line"
 msgstr ""
-#: ../vector/v.voronoi/skeleton.c:509
-msgid "Node is outside any input area"
+#: ../raster/r.colors/edit_colors.c:83
+msgid ""
+"Input map names can be defined in an input file in case a large amount of "
+"maps must be specified. This option is mutual exclusive to the map option."
 msgstr ""
-#: ../vector/v.voronoi/clean_topo.c:20
-msgid "Searching for topology errors..."
+#: ../raster/r.colors/edit_colors.c:110
+msgid "\"-\" to read rules from stdin"
 msgstr ""
-#: ../vector/v.voronoi/clean_topo.c:78
-msgid "Cleaning output topology"
+#: ../raster/r.colors/edit_colors.c:147
+#: ../locale/scriptstrings/t.rast.colors_to_translate.c:25
+msgid "Histogram equalization"
 msgstr ""
-#: ../vector/v.voronoi/clean_topo.c:87 ../vector/v.in.ogr/main.c:1391
-#: ../vector/v.buffer/main.c:759
-msgid "Removing dangles..."
+#: ../raster/r.colors/edit_colors.c:229 ../raster/r.colors/edit_colors.c:262
+#, c-format
+msgid "%s map <%s> not found"
 msgstr ""
-#: ../vector/v.voronoi/clean_topo.c:89 ../vector/v.in.ogr/main.c:1406
-#: ../vector/v.buffer/main.c:762
-msgid "Removing bridges..."
+#: ../raster/r.colors/edit_colors.c:235
+#, c-format
+msgid "No %s map name found in input file <%s>"
 msgstr ""
-#: ../vector/v.voronoi/clean_topo.c:115
-msgid "Removing incorrect boundaries from output"
+#: ../raster/r.colors/edit_colors.c:278
+#, c-format
+msgid "Unable to remove color table of %s map <%s>"
 msgstr ""
-#: ../vector/v.lrs/v.lrs.segment/main.c:72
-#: ../vector/v.lrs/v.lrs.label/main.c:103
-#: ../vector/v.lrs/v.lrs.create/main.c:122
-#: ../vector/v.lrs/v.lrs.where/main.c:58
-msgid "linear reference system"
+#: ../raster/r.colors/edit_colors.c:280
+#, c-format
+msgid "Color table of %s map <%s> not found"
 msgstr ""
-#: ../vector/v.lrs/v.lrs.segment/main.c:75
-msgid "Creates points/segments from input lines, linear reference system and positions read from stdin or a file."
+#: ../raster/r.colors/edit_colors.c:302
+#, c-format
+msgid "Color table exists for %s map <%s>. Exiting."
 msgstr ""
-#: ../vector/v.lrs/v.lrs.segment/main.c:79
-#: ../vector/v.lrs/v.lrs.label/main.c:109
-#: ../vector/v.lrs/v.lrs.create/main.c:128
-#: ../vector/v.lrs/v.lrs.where/main.c:66
-msgid "Input vector map containing lines"
+#: ../raster/r.colors/edit_colors.c:358
+#, c-format
+msgid "Color table 'random' is not supported for floating point %s map"
 msgstr ""
-#: ../vector/v.lrs/v.lrs.segment/main.c:83
-msgid "Output vector map where segments will be written"
+#: ../raster/r.colors/edit_colors.c:362
+#, c-format
+msgid "Color table 'grey.eq' is not supported for floating point %s map"
 msgstr ""
-#: ../vector/v.lrs/v.lrs.segment/main.c:88
-#: ../vector/v.lrs/v.lrs.label/main.c:118
-#: ../vector/v.lrs/v.lrs.create/main.c:147
-#: ../vector/v.lrs/v.lrs.where/main.c:75
-msgid "Line layer"
+#: ../raster/r.colors/edit_colors.c:368
+#, c-format
+msgid "Color table 'grey.log' is not supported for floating point %s map"
 msgstr ""
-#: ../vector/v.lrs/v.lrs.segment/main.c:94
-#: ../vector/v.lrs/v.lrs.label/main.c:124
-#: ../vector/v.lrs/v.lrs.create/main.c:207
-#: ../vector/v.lrs/v.lrs.where/main.c:86
-msgid "Driver name for reference system table"
+#: ../raster/r.colors/edit_colors.c:376 ../imagery/i.vi/main.c:545
+#, c-format
+msgid "Unknown color request '%s'"
 msgstr ""
-#: ../vector/v.lrs/v.lrs.segment/main.c:102
-#: ../vector/v.lrs/v.lrs.label/main.c:132
-#: ../vector/v.lrs/v.lrs.create/main.c:215
-#: ../vector/v.lrs/v.lrs.where/main.c:94
-msgid "Database name for reference system table"
+#: ../raster/r.colors/edit_colors.c:447
+#, c-format
+msgid "Color table for %s map <%s> set to '%s'"
 msgstr ""
-#: ../vector/v.lrs/v.lrs.segment/main.c:109
-#: ../vector/v.lrs/v.lrs.label/main.c:139
-#: ../vector/v.lrs/v.lrs.where/main.c:101
-msgid "Name of the reference system table"
+#: ../raster/r.colors/rules.c:40
+#, c-format
+msgid "Enter rules, \"end\" when done, \"help\" if you need it.\n"
 msgstr ""
-#: ../vector/v.lrs/v.lrs.segment/main.c:114
-msgid "Name of file containing segment rules. If not given, read from stdin."
+#: ../raster/r.colors/rules.c:49
+#, c-format
+msgid "fp: Data range is %s to %s\n"
 msgstr ""
-#: ../vector/v.lrs/v.lrs.segment/main.c:155
-#: ../vector/v.lrs/v.lrs.label/main.c:292
-#: ../vector/v.lrs/v.lrs.create/main.c:315
-#: ../vector/v.lrs/v.lrs.where/main.c:147
-msgid "Unable to open database for reference table"
+#: ../raster/r.colors/rules.c:53
+#, c-format
+msgid "Data range is %ld to %ld\n"
 msgstr ""
-#: ../vector/v.lrs/v.lrs.segment/main.c:184
-#: ../vector/v.lrs/v.lrs.segment/main.c:238
+#: ../raster/r.colors/rules.c:64
 #, c-format
-msgid "Cannot read input: %s"
+msgid ""
+"Your color rules do not cover the whole range of data!\n"
+" (rules %f to %f but data %f to %f)"
 msgstr ""
-#: ../vector/v.lrs/v.lrs.segment/main.c:196
+#: ../raster/r.colors/rules.c:105
 #, c-format
-msgid "No record in LR table for: %s"
+msgid " val color\n"
 msgstr ""
-#: ../vector/v.lrs/v.lrs.segment/main.c:200
+#: ../raster/r.colors/rules.c:106
 #, c-format
-msgid "More than one record in LR table for: %s"
+msgid " n%% color\n"
 msgstr ""
-#: ../vector/v.lrs/v.lrs.segment/main.c:207
-#: ../vector/v.lrs/v.lrs.segment/main.c:294
+#: ../raster/r.colors/rules.c:107
 #, c-format
-msgid "Unable to find line of cat [%d]"
+msgid " nv color\n"
 msgstr ""
-#: ../vector/v.lrs/v.lrs.segment/main.c:217
+#: ../raster/r.colors/rules.c:108
 #, c-format
-msgid ""
-"Cannot get point on line: cat = [%d] distance = [%f] (line length = %f)\n"
-"%s"
-msgstr ""
+msgid " default color\n"
+msgstr "noklusējuma krāsa\n"
-#: ../vector/v.lrs/v.lrs.segment/main.c:253
+#: ../raster/r.colors/rules.c:109
 #, c-format
-msgid ""
-"No record in LRS table for 1. point of:\n"
-"  %s"
-msgstr ""
+msgid "color can be one of:\n"
+msgstr "krāsa var būt viena no:\n"
-#: ../vector/v.lrs/v.lrs.segment/main.c:258
+#: ../raster/r.colors/rules.c:111
 #, c-format
-msgid ""
-"Using last from more offsets found for 1. point of:\n"
-"  %s"
-msgstr ""
+msgid "or an R:G:B triplet, e.g.: 0:127:255\n"
+msgstr "vai R:G:B triplets, piem. 0:126:255\n"
-#: ../vector/v.lrs/v.lrs.segment/main.c:262
+#: ../raster/r.colors/rules.c:132
 #, c-format
-msgid ""
-"Requested offset for the 1. point not found, using nearest found:\n"
-"  %s"
+msgid "bad rule (%s); rule not added"
 msgstr ""
-#: ../vector/v.lrs/v.lrs.segment/main.c:273
+#: ../raster/r.colors/rules.c:134
 #, c-format
-msgid ""
-"No record in LRS table for 2. point of:\n"
-"  %s"
+msgid "bad rule (%s): [%s]"
 msgstr ""
-#: ../vector/v.lrs/v.lrs.segment/main.c:278
+#: ../raster/r.colors/stats.c:39
 #, c-format
-msgid ""
-"Requested offset for the 2. point not found, using nearest found:\n"
-"  %s"
+msgid "(%i/%i) Reading raster map <%s>..."
 msgstr ""
-#: ../vector/v.lrs/v.lrs.segment/main.c:282
-#, c-format
-msgid ""
-"Using first from more offsets found for 2. point of:\n"
-"  %s"
+#: ../raster/r.colors/stats.c:73
+msgid "Unable to use logarithmic scaling if range includes zero"
 msgstr ""
-#: ../vector/v.lrs/v.lrs.segment/main.c:287
-msgid "Segment over 2 (or more) segments, not yet supported"
+#: ../raster/r.colors/stats.c:118
+msgid "Error opening 3d raster map"
 msgstr ""
-#: ../vector/v.lrs/v.lrs.segment/main.c:304
+#: ../raster/r.colors/stats.c:125
 #, c-format
-msgid "End of segment > line length (%e) -> cut"
+msgid "(%i/%i) Reading map <%s>..."
 msgstr ""
-#: ../vector/v.lrs/v.lrs.segment/main.c:313
-#, c-format
-msgid ""
-"Cannot make line segment: cat = %d : %f - %f (line length = %f)\n"
-"%s"
+#: ../raster/r.sim/r.sim.sediment/main.c:117
+msgid "sediment flow"
 msgstr ""
-#: ../vector/v.lrs/v.lrs.segment/main.c:356
-#: ../vector/v.lrs/v.lrs.where/main.c:222
-#, c-format
-msgid "[%d] point read from input"
-msgid_plural "[%d] points read from input"
-msgstr[0] ""
-msgstr[1] ""
-msgstr[2] ""
+#: ../raster/r.sim/r.sim.sediment/main.c:119
+msgid "deposition"
+msgstr ""
-#. GTC %s will be replaced with a message about lost points.
-#: ../vector/v.lrs/v.lrs.segment/main.c:363
-#, c-format
-msgid "[%d] point written to output map (%s)"
-msgid_plural "[%d] points written to output map (%s)"
-msgstr[0] ""
-msgstr[1] ""
-msgstr[2] ""
+#: ../raster/r.sim/r.sim.sediment/main.c:122
+msgid ""
+"Sediment transport and erosion/deposition simulation using path sampling "
+"method (SIMWE)."
+msgstr ""
-#: ../vector/v.lrs/v.lrs.segment/main.c:368
-#, c-format
-msgid "[%d] line read from input"
-msgid_plural "[%d] lines read from input"
-msgstr[0] ""
-msgstr[1] ""
-msgstr[2] ""
+#: ../raster/r.sim/r.sim.sediment/main.c:129
+msgid "Name of water depth raster map [m]"
+msgstr ""
-#. GTC %s will be replaced with a message about lost lines.
-#: ../vector/v.lrs/v.lrs.segment/main.c:375
-#, c-format
-msgid "[%d] line written to output map (%s)"
-msgid_plural "[%d] lines written to output map (%s)"
-msgstr[0] ""
-msgstr[1] ""
-msgstr[2] ""
-#: ../vector/v.lrs/v.lrs.label/main.c:105
-msgid "Creates stationing from input lines, and linear reference system."
+#: ../raster/r.sim/r.sim.sediment/main.c:133
+#: ../raster/r.sim/r.sim.water/main.c:127
+msgid "Name of x-derivatives raster map [m/m]"
 msgstr ""
-#: ../vector/v.lrs/v.lrs.label/main.c:113
-msgid "Output vector map where stationing will be written"
+#: ../raster/r.sim/r.sim.sediment/main.c:137
+#: ../raster/r.sim/r.sim.water/main.c:131
+msgid "Name of y-derivatives raster map [m/m]"
 msgstr ""
-#: ../vector/v.lrs/v.lrs.label/main.c:147
-msgid "Label file"
+#: ../raster/r.sim/r.sim.sediment/main.c:142
+msgid "Name of detachment capacity coefficient raster map [s/m]"
 msgstr ""
-#: ../vector/v.lrs/v.lrs.label/main.c:156
-msgid "PM left, MP right, stationing left, stationing right offset"
+#: ../raster/r.sim/r.sim.sediment/main.c:147
+msgid "Name of transport capacity coefficient raster map [s]"
 msgstr ""
-#: ../vector/v.lrs/v.lrs.label/main.c:161
-msgid "Offset label in label x-direction in map units"
+#: ../raster/r.sim/r.sim.sediment/main.c:152
+msgid "Name of critical shear stress raster map [Pa]"
 msgstr ""
-#: ../vector/v.lrs/v.lrs.label/main.c:168
-msgid "Offset label in label y-direction in map units"
+#: ../raster/r.sim/r.sim.sediment/main.c:157
+#: ../raster/r.sim/r.sim.water/main.c:168
+msgid "Name of Manning's n raster map"
 msgstr ""
-#: ../vector/v.lrs/v.lrs.label/main.c:174 ../vector/v.label/main.c:113
-msgid "Reference position"
+#: ../raster/r.sim/r.sim.sediment/main.c:165
+#: ../raster/r.sim/r.sim.water/main.c:176
+msgid "Manning's n unique value"
 msgstr ""
-#: ../vector/v.lrs/v.lrs.label/main.c:181 ../vector/v.label.sa/main.c:72
-#: ../vector/v.label.sa/main.c:80 ../vector/v.label/main.c:125
-#: ../vector/v.label/main.c:132 ../vector/v.label/main.c:140
-#: ../vector/v.label/main.c:148
-msgid "Font"
+#: ../raster/r.sim/r.sim.sediment/main.c:172
+#: ../raster/r.sim/r.sim.water/main.c:190
+msgid "Name of sampling locations vector points map"
 msgstr ""
-#: ../vector/v.lrs/v.lrs.label/main.c:187 ../vector/v.label.sa/main.c:77
-#: ../vector/v.label/main.c:129
-msgid "Label size (in map-units)"
+#: ../raster/r.sim/r.sim.sediment/main.c:178
+msgid "Name for output transport capacity raster map [kg/ms]"
 msgstr ""
-#: ../vector/v.lrs/v.lrs.label/main.c:197
-msgid "Line width of text"
+#: ../raster/r.sim/r.sim.sediment/main.c:185
+msgid ""
+"Name for output transport limited erosion-deposition raster map [kg/m2s]"
 msgstr ""
-#: ../vector/v.lrs/v.lrs.label/main.c:198
-#: ../vector/v.lrs/v.lrs.label/main.c:211
-msgid "Only for d.label output"
+#: ../raster/r.sim/r.sim.sediment/main.c:192
+msgid "Name for output sediment concentration raster map [particle/m3]"
 msgstr ""
-#: ../vector/v.lrs/v.lrs.label/main.c:205 ../vector/v.label.sa/main.c:107
-#: ../vector/v.label/main.c:174
-msgid "Highlight color for text"
+#: ../raster/r.sim/r.sim.sediment/main.c:198
+msgid "Name for output sediment flux raster map [kg/ms]"
 msgstr ""
-#: ../vector/v.lrs/v.lrs.label/main.c:210
-msgid "Line width of highlight color"
+#: ../raster/r.sim/r.sim.sediment/main.c:205
+msgid "Name for output erosion-deposition raster map [kg/m2s]"
 msgstr ""
-#: ../vector/v.lrs/v.lrs.label/main.c:228
-msgid "Opaque to vector"
+#: ../raster/r.sim/r.sim.sediment/main.c:212
+#: ../raster/r.sim/r.sim.water/main.c:222
+msgid ""
+"Name for sampling points output text file. For each observation vector point "
+"the time series of sediment transport is stored."
 msgstr ""
-#: ../vector/v.lrs/v.lrs.label/main.c:229
-msgid "Only relevant if background color is selected"
+#: ../raster/r.sim/r.sim.sediment/main.c:219
+#: ../raster/r.sim/r.sim.water/main.c:215
+msgid "Base name of the output walkers vector points map"
 msgstr ""
-#: ../vector/v.lrs/v.lrs.label/main.c:322
-#, c-format
-msgid "Unable to select records from LRS table: %s"
+#: ../raster/r.sim/r.sim.sediment/main.c:226
+msgid "Number of walkers"
 msgstr ""
-#: ../vector/v.lrs/v.lrs.label/main.c:412
-msgid "No record in LR table"
+#: ../raster/r.sim/r.sim.sediment/main.c:234
+#: ../raster/r.sim/r.sim.water/main.c:238
+msgid "Time used for iterations [minutes]"
 msgstr ""
-#: ../vector/v.lrs/v.lrs.label/main.c:416
-msgid "More than one record in LR table"
+#: ../raster/r.sim/r.sim.sediment/main.c:243
+#: ../raster/r.sim/r.sim.water/main.c:247
+msgid "Time interval for creating output maps [minutes]"
 msgstr ""
-#: ../vector/v.lrs/v.lrs.create/main.c:124
-msgid "Creates a linear reference system."
+#: ../raster/r.sim/r.sim.sediment/main.c:261
+#: ../raster/r.sim/r.sim.water/main.c:265
+msgid "Water diffusion constant"
 msgstr ""
-#: ../vector/v.lrs/v.lrs.create/main.c:133
-msgid "Output vector map where oriented lines are written"
+#: ../raster/r.sim/r.sim.sediment/main.c:269
+#: ../raster/r.sim/r.sim.water/main.c:304
+msgid "Seed for random number generator"
 msgstr ""
-#: ../vector/v.lrs/v.lrs.create/main.c:138
-msgid "Output vector map of errors"
+#: ../raster/r.sim/r.sim.sediment/main.c:271
+#: ../raster/r.sim/r.sim.water/main.c:306
+msgid ""
+"The same seed can be used to obtain same results or random seed can be "
+"generated by other means."
 msgstr ""
-#: ../vector/v.lrs/v.lrs.create/main.c:143
-msgid "Input vector map containing reference points"
+#: ../raster/r.sim/r.sim.sediment/main.c:277
+#: ../raster/r.sim/r.sim.water/main.c:312
+msgid "Generate random seed"
 msgstr ""
-#: ../vector/v.lrs/v.lrs.create/main.c:151
-#: ../vector/v.lrs/v.lrs.where/main.c:80
-msgid "Point layer"
+#: ../raster/r.sim/r.sim.sediment/main.c:279
+#: ../raster/r.sim/r.sim.water/main.c:314
+msgid ""
+"Automatically generates random seed for random number generator (use when "
+"you don't want to provide the seed option)"
 msgstr ""
-#: ../vector/v.lrs/v.lrs.create/main.c:158
-msgid "Column containing line identifiers for lines"
+#: ../raster/r.sim/r.sim.sediment/main.c:288
+#: ../raster/r.sim/r.sim.water/main.c:323
+#, fuzzy
+msgid "Number of threads which will be used for parallel compute"
+msgstr "Drukājamo kopiju sakits"
+#: ../raster/r.sim/r.sim.sediment/main.c:296
+#: ../raster/r.sim/r.sim.water/main.c:331
+#, c-format
+msgid "Generated random seed (-s): %ld"
 msgstr ""
-#: ../vector/v.lrs/v.lrs.create/main.c:165
-msgid "Column containing line identifiers for points"
+#: ../raster/r.sim/r.sim.sediment/main.c:301
+#: ../raster/r.sim/r.sim.water/main.c:336
+#, c-format
+msgid "Read random seed from %s option: %ld"
 msgstr ""
-#: ../vector/v.lrs/v.lrs.create/main.c:173
-msgid "Column containing milepost position for the beginning of next segment"
+#: ../raster/r.sim/r.sim.sediment/main.c:383
+#: ../raster/r.sim/r.sim.water/main.c:411
+#, fuzzy, c-format
+msgid "Number of threads: %d"
+msgstr "Punktu skaits: %d"
+#: ../raster/r.sim/r.sim.sediment/main.c:397
+#: ../raster/r.sim/r.sim.water/main.c:505
+msgid "More than 100 files are going to be created !!!!!"
 msgstr ""
-#: ../vector/v.lrs/v.lrs.create/main.c:182
-msgid "Column containing offset from milepost for the beginning of next segment"
+#: ../raster/r.sim/r.sim.sediment/main.c:403
+#: ../raster/r.sim/r.sim.water/main.c:511
+#, c-format
+msgid "default nwalk=%d, rwalk=%f"
 msgstr ""
-#: ../vector/v.lrs/v.lrs.create/main.c:191
-msgid "Column containing milepost position for the end of previous segment"
+#: ../raster/r.sim/r.sim.sediment/main.c:412
+#: ../raster/r.sim/r.sim.water/main.c:521
+#, c-format
+msgid "Using metric conversion factor %f, step=%f"
 msgstr ""
-#: ../vector/v.lrs/v.lrs.create/main.c:200
-msgid "Column containing offset from milepost for the end of previous segment"
+#: ../raster/r.sim/r.sim.sediment/main.c:419
+msgid "You are not outputting any raster or site files"
 msgstr ""
-#: ../vector/v.lrs/v.lrs.create/main.c:223
-msgid "Name of table where the reference system will be written"
+#: ../raster/r.sim/r.sim.sediment/main.c:435 ../raster/r.sim/simlib/hydro.c:478
+msgid "Cannot write raster maps"
 msgstr ""
-#: ../vector/v.lrs/v.lrs.create/main.c:224
-msgid "New table is created by this module"
+#: ../raster/r.sim/r.sim.water/main.c:117
+msgid "overland flow"
 msgstr ""
-#: ../vector/v.lrs/v.lrs.create/main.c:231
-msgid "Maximum distance of point to line allowed"
+#: ../raster/r.sim/r.sim.water/main.c:120
+msgid "Overland flow hydrologic simulation using path sampling method (SIMWE)."
 msgstr ""
-#: ../vector/v.lrs/v.lrs.create/main.c:286
-msgid "Cannot get layer info for lines"
+#: ../raster/r.sim/r.sim.water/main.c:137
+msgid "Name of rainfall excess rate (rain-infilt) raster map [mm/hr]"
 msgstr ""
-#: ../vector/v.lrs/v.lrs.create/main.c:289
-msgid "Cannot get layer info for points"
+#: ../raster/r.sim/r.sim.water/main.c:146
+msgid "Rainfall excess rate unique value [mm/hr]"
 msgstr ""
-#: ../vector/v.lrs/v.lrs.create/main.c:327
-#, c-format
-msgid "Unable to drop table: %s"
+#: ../raster/r.sim/r.sim.water/main.c:153
+msgid "Name of runoff infiltration rate raster map [mm/hr]"
 msgstr ""
-#: ../vector/v.lrs/v.lrs.create/main.c:346
-#, c-format
-msgid "Unable to select line id values from %s.%s."
+#: ../raster/r.sim/r.sim.water/main.c:162
+msgid "Runoff infiltration rate unique value [mm/hr]"
 msgstr ""
-#: ../vector/v.lrs/v.lrs.create/main.c:356
-msgid "Line id column must be integer"
+#: ../raster/r.sim/r.sim.water/main.c:183
+msgid "Name of flow controls raster map (permeability ratio 0-1)"
 msgstr ""
-#: ../vector/v.lrs/v.lrs.create/main.c:367
-#: ../vector/v.lrs/v.lrs.create/main.c:469
-msgid "Unable to fetch line id from line table"
+#: ../raster/r.sim/r.sim.water/main.c:196
+msgid "Name for output water depth raster map [m]"
 msgstr ""
-#: ../vector/v.lrs/v.lrs.create/main.c:419
-#, c-format
-msgid "Line [%d] without category (layer [%d])"
+#: ../raster/r.sim/r.sim.water/main.c:202
+msgid "Name for output water discharge raster map [m3/s]"
 msgstr ""
-#: ../vector/v.lrs/v.lrs.create/main.c:439
-#, c-format
-msgid "No lines selected for line id [%d]"
+#: ../raster/r.sim/r.sim.water/main.c:208
+msgid "Name for output simulation error raster map [m]"
 msgstr ""
-#: ../vector/v.lrs/v.lrs.create/main.c:459
-#, c-format
-msgid "Unable to select point attributes from <%s>"
+#: ../raster/r.sim/r.sim.water/main.c:230
+msgid "Number of walkers, default is twice the number of cells"
 msgstr ""
-#: ../vector/v.lrs/v.lrs.create/main.c:490
-#, c-format
-msgid "Milepost (start) %f+%f used as %f+%f (change MP to integer)"
+#: ../raster/r.sim/r.sim.water/main.c:274
+msgid "Threshold water depth [m]"
 msgstr ""
-#: ../vector/v.lrs/v.lrs.create/main.c:512
-#, c-format
-msgid "Milepost (end) %f+%f used as %f+%f (change MP to integer)"
+#: ../raster/r.sim/r.sim.water/main.c:275
+msgid "Diffusion increases after this water depth is reached"
 msgstr ""
-#: ../vector/v.lrs/v.lrs.create/main.c:538
-#, c-format
-msgid "Point [%d] without category (layer [%d])"
+#: ../raster/r.sim/r.sim.water/main.c:283
+msgid "Diffusion increase constant"
 msgstr ""
-#: ../vector/v.lrs/v.lrs.create/main.c:585
-#, c-format
-msgid "Point [%d] cat [%d] is out of threshold (distance = %f)"
+#: ../raster/r.sim/r.sim.water/main.c:292
+msgid "Weighting factor for water flow velocity vector"
 msgstr ""
-#: ../vector/v.lrs/v.lrs.create/main.c:717
-#, c-format
-msgid "End > start for point cat [%d]"
+#: ../raster/r.sim/r.sim.water/main.c:297
+msgid "Time-series output"
 msgstr ""
-#: ../vector/v.lrs/v.lrs.create/main.c:734
-msgid "Start of 1. MP >= end of 2. MP for points' cats %[d], [%d]"
+#: ../raster/r.sim/r.sim.water/main.c:527
+msgid "You are not outputting any raster maps"
 msgstr ""
-#: ../vector/v.lrs/v.lrs.create/main.c:751
+#: ../raster/r.sim/simlib/hydro.c:202
 #, c-format
-msgid "Start of 1. MP >= start of 2. MP for points' cats [%d], [%d]"
+msgid "nwalk (%d) > maxw (%d)!"
 msgstr ""
-#: ../vector/v.lrs/v.lrs.create/main.c:761
-#, c-format
-msgid "Distance along line identical for points' cats [%d], [%d]"
+#: ../raster/r.sim/simlib/hydro.c:411
+msgid "Unable to write raster maps"
 msgstr ""
-#: ../vector/v.lrs/v.lrs.create/main.c:775
+#: ../raster/r.sim/simlib/observation_points.c:64
 #, c-format
-msgid "Not enough points (%d) attached to the line (cat %d), line skip."
+msgid "Unable to read points from map %s"
 msgstr ""
-#: ../vector/v.lrs/v.lrs.create/main.c:780
+#: ../raster/r.sim/simlib/observation_points.c:85
 #, c-format
-msgid "Unable to guess direction for the line (cat %d), line skip."
+msgid "Unable to open observation logfile %s for writing"
 msgstr ""
-#: ../vector/v.lrs/v.lrs.create/main.c:784
+#: ../raster/r.sim/simlib/input.c:307
 #, c-format
-msgid "Incorrect order of points along line cat [%d]"
+msgid ""
+"Raster map <%s> not found, and manin_val undefined, choose one to be allowed "
+"to process"
 msgstr ""
-#: ../vector/v.lrs/v.lrs.create/main.c:834
-#, c-format
-msgid "Unable to insert reference records: %s"
+#: ../raster/r.sim/simlib/input.c:420
+msgid "Zero value in Mannings n"
 msgstr ""
-#: ../vector/v.lrs/v.lrs.create/main.c:875
-msgid "Building topology for output (out_lines) map..."
+#: ../raster/r.sim/simlib/input.c:471
+msgid "Infiltration exceeds the rainfall rate everywhere! No overland flow."
 msgstr ""
-#: ../vector/v.lrs/v.lrs.create/main.c:886
-msgid "Building topology for error (err) map..."
+#: ../raster/r.sim/simlib/input.c:495
+#, c-format
+msgid ""
+"Min elevation \t= %.2f m\n"
+"Max elevation \t= %.2f m\n"
 msgstr ""
-#: ../vector/v.lrs/v.lrs.where/main.c:61
-msgid "Finds line id and real km+offset for given points in vector map using linear reference system."
+#: ../raster/r.sim/simlib/input.c:497
+#, c-format
+msgid "Mean Source Rate (rainf. excess or sediment) \t= %f m/s or kg/m2s \n"
 msgstr ""
-#: ../vector/v.lrs/v.lrs.where/main.c:70
-msgid "Input vector map containing points"
+#: ../raster/r.sim/simlib/input.c:499
+#, c-format
+msgid "Mean flow velocity \t= %f m/s\n"
 msgstr ""
-#: ../vector/v.lrs/v.lrs.where/main.c:108
-msgid "Maximum distance to nearest line"
+#: ../raster/r.sim/simlib/input.c:500
+#, c-format
+msgid "Mean Mannings \t= %f\n"
 msgstr ""
-#: ../vector/v.lrs/v.lrs.where/main.c:225
+#: ../raster/r.sim/simlib/input.c:504
 #, c-format
-msgid "[%d] position found"
-msgid_plural "[%d] positions found"
+msgid "Number of iterations \t= %d cell\n"
+msgid_plural "Number of iterations \t= %d cells\n"
 msgstr[0] ""
 msgstr[1] ""
 msgstr[2] ""
-#: ../vector/v.lrs/v.lrs.where/main.c:229
+#: ../raster/r.sim/simlib/input.c:506
 #, c-format
-msgid "[%d] point outside threshold"
-msgid_plural "[%d] points outside threshold"
-msgstr[0] ""
-msgstr[1] ""
-msgstr[2] ""
+msgid "Time step \t= %.2f s\n"
+msgstr ""
-#: ../vector/v.lrs/v.lrs.where/main.c:233
+#: ../raster/r.sim/simlib/input.c:508
 #, c-format
-msgid "[%d] point - no record found"
-msgid_plural "[%d] points - no record found"
-msgstr[0] ""
-msgstr[1] ""
-msgstr[2] ""
+msgid ""
+"Sigmax \t= %f\n"
+"Max velocity \t= %f m/s\n"
+msgstr ""
-#: ../vector/v.lrs/v.lrs.where/main.c:237
+#: ../raster/r.sim/simlib/input.c:510
 #, c-format
-msgid "[%d] point - too many records found"
-msgid_plural "[%d] points - too many records found"
-msgstr[0] ""
-msgstr[1] ""
-msgstr[2] ""
-#: ../vector/v.in.region/main.c:43
-msgid "Creates a vector polygon from the current region extent."
+msgid "Time step used \t= %.2f s\n"
 msgstr ""
-#: ../vector/v.in.region/main.c:51
-msgid "Select type: line or area"
-msgstr "Izvēlēties tipu: līnija vai poligons"
-#: ../vector/v.in.region/main.c:58
-msgid "Densify lines using region resolution"
+#: ../raster/r.sim/simlib/input.c:562
+msgid "Unable to write et file"
 msgstr ""
-#: ../vector/v.kernel/main.c:68
+#: ../raster/r.sim/simlib/output.c:321 ../raster/r.sim/simlib/output.c:329
 #, c-format
-msgid "\tScore Value=%f\tsmoothing parameter (standard deviation)=%f"
+msgid "FP raster map <%s> not found"
 msgstr ""
-#: ../vector/v.kernel/main.c:110
-msgid "kernel density"
+#: ../raster/r.carve/main.c:76
+msgid "Generates stream channels."
 msgstr ""
-#: ../vector/v.kernel/main.c:111
-msgid "point density"
+#: ../raster/r.carve/main.c:77
+msgid ""
+"Takes vector stream data, transforms it to raster and subtracts depth from "
+"the output DEM."
 msgstr ""
-#: ../vector/v.kernel/main.c:112
-msgid "heatmap"
+#: ../raster/r.carve/main.c:82
+msgid "Name of input raster elevation map"
 msgstr ""
-#: ../vector/v.kernel/main.c:113
-msgid "hotspot"
+#: ../raster/r.carve/main.c:87
+msgid "Name of input vector map containing stream(s)"
 msgstr ""
-#: ../vector/v.kernel/main.c:115
-msgid "Generates a raster density map from vector points map."
+#: ../raster/r.carve/main.c:95
+msgid "Name for output vector map for adjusted stream points"
 msgstr ""
-#: ../vector/v.kernel/main.c:116
-msgid "Density is computed using a moving kernel. Optionally generates a vector density map on a vector network."
+#: ../raster/r.carve/main.c:100
+msgid "Stream width (in meters)"
 msgstr ""
-#: ../vector/v.kernel/main.c:120
-msgid "Name of input vector map with training points"
+#: ../raster/r.carve/main.c:101
+msgid "Default is raster cell width"
 msgstr ""
-#: ../vector/v.kernel/main.c:125
-msgid "Name of input network vector map"
+#: ../raster/r.carve/main.c:106
+msgid "Additional stream depth (in meters)"
 msgstr ""
-#: ../vector/v.kernel/main.c:128 ../vector/v.kernel/main.c:157
-#: ../vector/v.kernel/main.c:165 ../vector/v.kernel/main.c:187
-#: ../vector/v.kernel/main.c:212 ../vector/v.kernel/main.c:218
-msgid "Network"
-msgstr "Tīkls"
+#: ../raster/r.carve/main.c:110
+msgid "No flat areas allowed in flow direction"
+msgstr ""
-#: ../vector/v.kernel/main.c:135
-#, fuzzy
-msgid "Name for output raster/vector map"
+#: ../raster/r.carve/main.c:134
+#, c-format
+msgid "Invalid width value '%s' - using default."
+msgstr ""
-#: ../vector/v.kernel/main.c:136
-#, fuzzy
-msgid "Outputs vector map if network map is given, otherwise raster map"
-msgstr "2 līmeņiem jābūt norādītiem"
+#: ../raster/r.carve/main.c:148
+#, c-format
+msgid "Invalid depth value '%s' - using default."
+msgstr ""
-#: ../vector/v.kernel/main.c:142
-msgid "Kernel radius in map units"
+#: ../raster/r.carve/lobf.c:74
+msgid "trying to divide by zero...no unique solution for system...skipping..."
 msgstr ""
-#: ../vector/v.kernel/main.c:148
-msgid "Discretization error in map units"
+#: ../raster/r.carve/enforce_ds.c:83
+msgid "Processing lines... "
 msgstr ""
-#: ../vector/v.kernel/main.c:155
-msgid "Maximum length of segment on network"
+#: ../raster/r.carve/enforce_ds.c:175
+msgid ""
+"Vect runs out of region and re-enters - this case is not yet implemented."
 msgstr ""
-#: ../vector/v.kernel/main.c:163
-msgid "Maximum distance from point to network"
+#: ../raster/r.in.png/main.c:297
+#, c-format
+msgid "Unable to open PNG file '%s'"
 msgstr ""
-#: ../vector/v.kernel/main.c:171
-msgid "Multiply the density result by this number"
+#: ../raster/r.in.png/main.c:300
+msgid "Input file empty or too short"
 msgstr ""
-#: ../vector/v.kernel/main.c:178
-msgid "Node method"
+#: ../raster/r.in.png/main.c:303
+msgid "Input file not a PNG file"
 msgstr ""
-#: ../vector/v.kernel/main.c:184
-msgid "No method applied at nodes with more than 2 arcs"
+#: ../raster/r.in.png/main.c:307 ../raster/r.in.png/main.c:311
+#: ../general/g.ppmtopng/main.c:70 ../general/g.ppmtopng/main.c:74
+msgid "Unable to allocate PNG structure"
 msgstr ""
-#: ../vector/v.kernel/main.c:185
-msgid "Equal split (Okabe 2009) applied at nodes"
+#: ../raster/r.in.png/main.c:314
+msgid "PNG error"
 msgstr ""
-#: ../vector/v.kernel/main.c:193
-msgid "Kernel function"
+#: ../raster/r.in.png/main.c:522
+msgid "Imports non-georeferenced PNG format image."
 msgstr ""
-#: ../vector/v.kernel/main.c:201
-msgid "Try to calculate an optimal radius with given 'radius' taken as maximum (experimental)"
+#: ../raster/r.in.png/main.c:532
+msgid "Title for created raster map"
 msgstr ""
-#: ../vector/v.kernel/main.c:206
-msgid "Only calculate optimal radius and exit (no map is written)"
+#: ../raster/r.in.png/main.c:538
+msgid "Display gamma"
 msgstr ""
-#: ../vector/v.kernel/main.c:211
-msgid "In network mode, normalize values by sum of density multiplied by length of each segment. Integral over the output map then gives 1.0 * mult"
+#: ../raster/r.in.png/main.c:544
+msgid "Alpha threshold"
 msgstr ""
-#: ../vector/v.kernel/main.c:217
-msgid "In network mode, multiply the result by number of input points"
+#: ../raster/r.in.png/main.c:548
+msgid "Create floating-point map (0.0 - 1.0)"
 msgstr ""
-#: ../vector/v.kernel/main.c:227 ../vector/v.in.lidar/main.c:540
-#: ../scripts/v.unpack/v.unpack.py:101
-msgid "Vector map <%s> already exists and will be overwritten"
+#: ../raster/r.in.png/main.c:552
+msgid "Output image file header only and exit"
 msgstr ""
-#: ../vector/v.kernel/main.c:257
-msgid "Unknown node method"
+#: ../raster/r.category/main.c:55
+msgid ""
+"Manages category values and labels associated with user-specified raster map "
+"layers."
 msgstr ""
-#: ../vector/v.kernel/main.c:275
-msgid "Unknown kernel function"
+#: ../raster/r.category/main.c:69
+msgid "Comma separated value list"
 msgstr ""
-#: ../vector/v.kernel/main.c:281
-msgid "Optimal standard deviation calculation is supported only for node method 'none' and kernel function 'gaussian'."
+#: ../raster/r.category/main.c:70
+msgid "Example: 1.4,3.8,13"
 msgstr ""
-#: ../vector/v.kernel/main.c:285
-msgid "Optimal standard deviation calculation is supported only for kernel function 'gaussian'."
+#: ../raster/r.category/main.c:87
+msgid "File containing category label rules (or \"-\" to read from stdin)"
 msgstr ""
-#: ../vector/v.kernel/main.c:302
-#, c-format
-msgid "Standard deviation: %f"
+#: ../raster/r.category/main.c:95
+msgid "Default label or format string for dynamic labeling"
 msgstr ""
-#: ../vector/v.kernel/main.c:307
-#, c-format
-msgid "Output raster map: resolution: %f\t%s\t%s"
+#: ../raster/r.category/main.c:97
+msgid "Used when no explicit label exists for the category"
 msgstr ""
-#: ../vector/v.kernel/main.c:310
-#, c-format
-msgid "Output raster map resolution: %f"
+#: ../raster/r.category/main.c:105
+msgid "Dynamic label coefficients"
 msgstr ""
-#: ../vector/v.kernel/main.c:358
-#, c-format
-msgid "%d point outside threshold"
-msgid_plural "%d points outside threshold"
-msgstr[0] ""
-msgstr[1] ""
-msgstr[2] ""
+#: ../raster/r.category/main.c:107
+msgid "Two pairs of category multiplier and offsets, for $1 and $2"
+msgstr ""
-#: ../vector/v.kernel/main.c:381
+#: ../raster/r.category/main.c:152
 #, c-format
-msgid "Automatic choice of smoothing parameter (radius), maximum possible value of radius is set to %f"
+msgid "Category table for <%s> set from <%s>"
 msgstr ""
-#: ../vector/v.kernel/main.c:388
+#: ../raster/r.category/main.c:211
 #, c-format
-msgid "Using maximum distance between points: %f"
+msgid ""
+"Incorrect format of input rules. Check separators. Invalid line is:\n"
+"%s"
 msgstr ""
-#: ../vector/v.kernel/main.c:402
+#: ../raster/r.category/main.c:267
 #, c-format
-msgid "Number of input points: %d."
+msgid "Unable to read category file of raster map <%s> in <%s>"
 msgstr ""
-#: ../vector/v.kernel/main.c:403
-#, c-format
-msgid "%d distance read from the map."
-msgid_plural "%d distances read from the map."
-msgstr[0] ""
-msgstr[1] ""
-msgstr[2] ""
+#: ../raster/r.category/main.c:283
+msgid "The map is floating point! Ignoring cats list, using vals list"
+msgstr ""
-#: ../vector/v.kernel/main.c:408
-#, c-format
-msgid "Distances between all points are beyond %e (4 * standard deviation), unable to calculate optimal value."
+#: ../raster/r.category/main.c:300
+msgid "vals argument is required for floating point map!"
 msgstr ""
-#: ../vector/v.kernel/main.c:419
+#: ../raster/r.category/cats.c:47
 #, c-format
-msgid "Optimal smoothing parameter (standard deviation): %f."
+msgid "Reading <%s> in <%s>"
 msgstr ""
-#: ../vector/v.kernel/main.c:450
-#, c-format
-msgid "Writing output vector map using smooth parameter %f"
+#: ../raster/r.mfilter/getrow.c:23
+msgid "Error reading temporary file"
 msgstr ""
-#: ../vector/v.kernel/main.c:452 ../vector/v.kernel/main.c:562
-#, c-format
-msgid "Normalising factor %f"
+#: ../raster/r.mfilter/main.c:60
+msgid "Performs raster map matrix filter."
 msgstr ""
-#: ../vector/v.kernel/main.c:560
-#, c-format
-msgid "Writing output raster map using smooth parameter %f"
+#: ../raster/r.mfilter/main.c:71
+msgid "Path to filter file"
 msgstr ""
-#: ../vector/v.kernel/main.c:612
-#, c-format
-msgid "Maximum value in output: %e."
+#: ../raster/r.mfilter/main.c:79
+msgid "Number of times to repeat the filter"
 msgstr ""
-#: ../vector/v.to.rast3/main.c:51
-msgid "Converts a vector map (only points) into a 3D raster map."
+#: ../raster/r.mfilter/main.c:80 ../raster/r.mfilter/main.c:99
+#: ../imagery/i.pca/main.c:109 ../imagery/i.pca/main.c:120
+msgid "Filter"
+msgstr "Filtrs"
+#: ../raster/r.mfilter/main.c:86
+msgid "Output raster map title"
 msgstr ""
-#: ../vector/v.to.rast3/main.c:62
-msgid "Name of attribute column (data type must be numeric)"
+#: ../raster/r.mfilter/main.c:98
+msgid "Apply filter only to null data values"
 msgstr ""
-#: ../vector/v.to.rast3/main.c:107
-msgid "Unable to create output map"
+#: ../raster/r.mfilter/main.c:125
+msgid "Raster map too small for the size of the filter"
 msgstr ""
-#: ../vector/v.to.rast3/main.c:145 ../vector/v.to.rast/do_lines.c:59
-#: ../vector/v.to.rast/do_lines.c:67
+#: ../raster/r.mfilter/getfilt.c:27
 #, c-format
-msgid "No record for line (cat = %d)"
-msgstr "Nav ieraksta priekš līnijas (cat= %d)"
+msgid "Cannot open filter file '%s'"
+msgstr ""
-#: ../vector/v.to.rast3/main.c:157
-msgid "Unable to close new 3d raster map"
+#: ../raster/r.mfilter/getfilt.c:47
+msgid "Illegal filter matrix size specified"
 msgstr ""
-#: ../vector/v.out.ogr/attrb.c:65
-#, c-format
-msgid "No database record for cat = %d and export of 'cat' disabled"
+#: ../raster/r.mfilter/getfilt.c:50
+msgid "Even filter matrix size specified"
 msgstr ""
-#: ../vector/v.out.ogr/args.c:9
-msgid "Name of input vector map to export"
+#: ../raster/r.mfilter/getfilt.c:72
+msgid "Illegal filter matrix"
 msgstr ""
-#: ../vector/v.out.ogr/args.c:18
-msgid "Feature type(s)"
+#: ../raster/r.mfilter/getfilt.c:80 ../raster/r.mfilter/getfilt.c:107
+#: ../raster/r.mfilter/getfilt.c:124
+msgid "Filter file format error"
 msgstr ""
-#: ../vector/v.out.ogr/args.c:20
-msgid "Combination of types is not supported by all output formats. Default is to use first type found in input vector map."
+#: ../raster/r.mfilter/getfilt.c:83
+msgid "Duplicate filter divisor specified"
 msgstr ""
-#: ../vector/v.out.ogr/args.c:25
-msgid "Name of output OGR datasource"
+#: ../raster/r.mfilter/getfilt.c:101
+msgid "Illegal divisor matrix"
 msgstr ""
-#: ../vector/v.out.ogr/args.c:27
-msgid ""
-"For example: ESRI Shapefile: filename or directory for storage\n"
-"\t\t\tPostGIS database: connection string"
+#: ../raster/r.mfilter/getfilt.c:110
+msgid "Duplicate filter type specified"
 msgstr ""
-#: ../vector/v.out.ogr/args.c:37
-msgid "Data format to write"
+#: ../raster/r.mfilter/getfilt.c:117
+msgid "Illegal filter type specified"
 msgstr ""
-#: ../vector/v.out.ogr/args.c:44
-msgid "Name for output OGR layer. If not specified, input name is used"
+#: ../raster/r.mfilter/getfilt.c:127
+msgid "Duplicate filter start specified"
 msgstr ""
-#: ../vector/v.out.ogr/args.c:46
-msgid ""
-"For example: ESRI Shapefile: shapefile name\n"
-"\t\t\tPostGIS database: table name"
+#: ../raster/r.mfilter/getfilt.c:135
+#, c-format
+msgid "Filter start %s ignored, using UL"
 msgstr ""
-#: ../vector/v.out.ogr/args.c:54
-msgid "Optionally change default output type"
+#: ../raster/r.mfilter/getfilt.c:157
+msgid "Illegal filter file format"
 msgstr ""
-#: ../vector/v.out.ogr/args.c:57
-msgid "export area boundaries as linestrings"
+#: ../raster/r.mfilter/perform.c:40 ../raster/r.mfilter/perform.c:51
+msgid "Unable to create temporary file"
 msgstr ""
-#: ../vector/v.out.ogr/args.c:58
-msgid "export lines as polygons"
+#: ../raster/r.mfilter/perform.c:81
+#, c-format
+msgid "Writing raster map <%s>"
 msgstr ""
-#: ../vector/v.out.ogr/args.c:68
-msgid "OGR dataset creation option (format specific, NAME=VALUE)"
+#: ../raster/r.sun/main.c:255
+msgid "Solar irradiance and irradiation model."
 msgstr ""
-#: ../vector/v.out.ogr/args.c:78
-msgid "OGR layer creation option (format specific, NAME=VALUE)"
+#: ../raster/r.sun/main.c:257
+msgid ""
+"Computes direct (beam), diffuse and reflected solar irradiation raster maps "
+"for given day, latitude, surface and atmospheric conditions. Solar "
+"parameters (e.g. sunrise, sunset times, declination, extraterrestrial "
+"irradiance, daylight length) are saved in the map history file. "
+"Alternatively, a local time can be specified to compute solar incidence "
+"angle and/or irradiance raster maps. The shadowing effect of the topography "
+"is optionally incorporated."
 msgstr ""
-#: ../vector/v.out.ogr/args.c:83
-msgid "Open an existing OGR datasource for update"
+#: ../raster/r.sun/main.c:271
+msgid "Name of the input elevation raster map [meters]"
 msgstr ""
-#: ../vector/v.out.ogr/args.c:87
-msgid "Append to existing layer"
+#: ../raster/r.sun/main.c:280
+msgid ""
+"Name of the input aspect map (terrain aspect or azimuth of the solar panel) "
+"[decimal degrees]"
 msgstr ""
-#: ../vector/v.out.ogr/args.c:88
-msgid "A new OGR layer is created if it does not exist"
+#: ../raster/r.sun/main.c:289
+msgid "A single value of the orientation (aspect), 270 is south"
 msgstr ""
-#: ../vector/v.out.ogr/args.c:94
-msgid "Skip export of GRASS category ID ('cat') attribute"
+#: ../raster/r.sun/main.c:298
+msgid ""
+"Name of the input slope raster map (terrain slope or solar panel "
+"inclination) [decimal degrees]"
 msgstr ""
-#: ../vector/v.out.ogr/args.c:100
-msgid "Also export features without category (not labeled). Otherwise only features with category are exported."
+#: ../raster/r.sun/main.c:306
+msgid "A single value of inclination (slope)"
 msgstr ""
-#: ../vector/v.out.ogr/args.c:106
-msgid "Use ESRI-style .prj file format (applies to Shapefile output only)"
+#: ../raster/r.sun/main.c:315
+msgid ""
+"Name of the Linke atmospheric turbidity coefficient input raster map [-]"
 msgstr ""
-#: ../vector/v.out.ogr/args.c:112
-msgid "Force 2D output even if input is 3D (applies to Shapefile output only)"
+#: ../raster/r.sun/main.c:324
+msgid "A single value of the Linke atmospheric turbidity coefficient [-]"
 msgstr ""
-#: ../vector/v.out.ogr/args.c:114 ../vector/v.out.postgis/args.c:78
-#: ../vector/v.in.ogr/main.c:275
-msgid "Useful if input is 3D but all z coordinates are identical"
+#: ../raster/r.sun/main.c:333
+msgid "Name of the ground albedo coefficient input raster map [-]"
 msgstr ""
-#: ../vector/v.out.ogr/args.c:120
-msgid "Export vector data as multi-features"
+#: ../raster/r.sun/main.c:342
+msgid "A single value of the ground albedo coefficient [-]"
 msgstr ""
-#: ../vector/v.out.ogr/args.c:126
-msgid "Create a new empty layer in defined OGR datasource and exit. Nothing is read from input."
+#: ../raster/r.sun/main.c:351
+msgid "Name of input raster map containing latitudes [decimal degrees]"
 msgstr ""
-#: ../vector/v.out.ogr/main.c:86
-msgid "Exports a vector map layer to any of the supported OGR vector formats."
+#: ../raster/r.sun/main.c:360
+msgid "Name of input raster map containing longitudes [decimal degrees]"
 msgstr ""
-#: ../vector/v.out.ogr/main.c:87
-msgid "By default a vector map layer is exported to Esri Shapefile format."
+#: ../raster/r.sun/main.c:369
+msgid ""
+"Name of real-sky beam radiation coefficient (thick cloud) input raster map "
+"[0-1]"
 msgstr ""
-#: ../vector/v.out.ogr/main.c:96 ../vector/v.external.out/link.c:26
-#, c-format
-msgid "Data source starts with \"PG:\" prefix, expecting \"PostgreSQL\" format (\"%s\" given)"
+#: ../raster/r.sun/main.c:378
+msgid ""
+"Name of real-sky diffuse radiation coefficient (haze) input raster map [0-1]"
 msgstr ""
-#: ../vector/v.out.ogr/main.c:164
-msgid "Volumes will be exported as sets of faces"
+#: ../raster/r.sun/main.c:385
+msgid "The horizon information input map basename"
 msgstr ""
-#: ../vector/v.out.ogr/main.c:182
-msgid "Unable to determine input map's vector feature type(s)."
+#: ../raster/r.sun/main.c:402
+msgid "Output incidence angle raster map (mode 1 only)"
 msgstr ""
-#: ../vector/v.out.ogr/main.c:248
-msgid "The combination of types is not supported by all formats."
+#: ../raster/r.sun/main.c:411
+msgid ""
+"Output beam irradiance [W.m-2] (mode 1) or irradiation raster map [Wh.m-2."
+"day-1] (mode 2)"
 msgstr ""
-#: ../vector/v.out.ogr/main.c:272
-#, c-format
-msgid "Unknown EPSG code %s"
+#: ../raster/r.sun/main.c:420
+msgid ""
+"Output diffuse irradiance [W.m-2] (mode 1) or irradiation raster map [Wh.m-2."
+"day-1] (mode 2)"
 msgstr ""
-#: ../vector/v.out.ogr/main.c:290
-#, c-format
-msgid "OGR layer <%s> created in datasource <%s> (format '%s')"
+#: ../raster/r.sun/main.c:429
+msgid ""
+"Output ground reflected irradiance [W.m-2] (mode 1) or irradiation raster "
+"map [Wh.m-2.day-1] (mode 2)"
 msgstr ""
-#: ../vector/v.out.ogr/main.c:302
-msgid "The map contains islands. With the -c flag, islands will appear as filled areas, not holes in the output map."
+#: ../raster/r.sun/main.c:438
+msgid ""
+"Output global (total) irradiance/irradiation [W.m-2] (mode 1) or irradiance/"
+"irradiation raster map [Wh.m-2.day-1] (mode 2)"
 msgstr ""
-#: ../vector/v.out.ogr/main.c:308
-#, c-format
-msgid "%d point found, but not requested to be exported. Verify 'type' parameter."
-msgid_plural "%d points found, but not requested to be exported. Verify 'type' parameter."
-msgstr[0] ""
-msgstr[1] ""
-msgstr[2] ""
+#: ../raster/r.sun/main.c:447
+msgid "Output insolation time raster map [h] (mode 2 only)"
+msgstr ""
-#: ../vector/v.out.ogr/main.c:316
-#, c-format
-msgid "%d line found, but not requested to be exported. Verify 'type' parameter."
-msgid_plural "%d line(s) found, but not requested to be exported. Verify 'type' parameter."
-msgstr[0] ""
-msgstr[1] ""
-msgstr[2] ""
-#: ../vector/v.out.ogr/main.c:325
-#, c-format
-msgid "%d boundary found, but not requested to be exported. Verify 'type' parameter."
-msgid_plural "%d boundaries found, but not requested to be exported. Verify 'type' parameter."
-msgstr[0] ""
-msgstr[1] ""
-msgstr[2] ""
-#: ../vector/v.out.ogr/main.c:334
-#, c-format
-msgid "%d centroid found, but not requested to be exported. Verify 'type' parameter."
-msgid_plural "%d centroids found, but not requested to be exported. Verify 'type' parameter."
-msgstr[0] ""
-msgstr[1] ""
-msgstr[2] ""
-#: ../vector/v.out.ogr/main.c:342
-#, c-format
-msgid "%d area found, but not requested to be exported. Verify 'type' parameter."
-msgid_plural "%d areas found, but not requested to be exported. Verify 'type' parameter."
-msgstr[0] ""
-msgstr[1] ""
-msgstr[2] ""
-#: ../vector/v.out.ogr/main.c:350
-#, c-format
-msgid "%d face found, but not requested to be exported. Verify 'type' parameter."
-msgid_plural "%d faces found, but not requested to be exported. Verify 'type' parameter."
-msgstr[0] ""
-msgstr[1] ""
-msgstr[2] ""
-#: ../vector/v.out.ogr/main.c:358
-#, c-format
-msgid "%d volume found, but not requested to be exported. Verify 'type' parameter."
-msgid_plural "%d volumes found, but not requested to be exported. Verify 'type' parameter."
-msgstr[0] ""
-msgstr[1] ""
-msgstr[2] ""
-#: ../vector/v.out.ogr/main.c:368
-msgid "No points found, but requested to be exported. Will skip this feature type."
+#: ../raster/r.sun/main.c:454
+msgid "No. of day of the year (1-365)"
 msgstr ""
-#: ../vector/v.out.ogr/main.c:377
-msgid "No lines found, but requested to be exported. Will skip this feature type."
+#: ../raster/r.sun/main.c:464
+msgid "Time step when computing all-day radiation sums [decimal hours]"
 msgstr ""
-#: ../vector/v.out.ogr/main.c:387
-msgid "No boundaries found, but requested to be exported. Will skip this feature type."
+#: ../raster/r.sun/main.c:472
+msgid "Declination value (overriding the internally computed value) [radians]"
 msgstr ""
-#: ../vector/v.out.ogr/main.c:396
-msgid "No areas found, but requested to be exported. Will skip this feature type."
+#: ../raster/r.sun/main.c:480
+msgid "Local (solar) time (to be set for mode 1 only) [decimal hours]"
 msgstr ""
-#: ../vector/v.out.ogr/main.c:406
-msgid "No centroids found, but requested to be exported. Will skip this feature type."
+#: ../raster/r.sun/main.c:491
+#, fuzzy
+msgid "Number of threads which will be used for parallel computing"
+#: ../raster/r.sun/main.c:521
+msgid "Read the input files in this number of chunks"
 msgstr ""
-#: ../vector/v.out.ogr/main.c:415
-msgid "No faces found, but requested to be exported. Will skip this feature type."
+#: ../raster/r.sun/main.c:528
+msgid "Civil time zone value, if none, the time will be local solar time"
 msgstr ""
-#: ../vector/v.out.ogr/main.c:424
-msgid "No kernels found, but requested to be exported. Will skip this feature type."
+#: ../raster/r.sun/main.c:534
+msgid "Do not incorporate the shadowing effect of terrain"
 msgstr ""
-#: ../vector/v.out.ogr/main.c:433
-msgid "No volumes found, but requested to be exported. Will skip this feature type."
+#: ../raster/r.sun/main.c:539
+msgid "Use the low-memory version of the program"
 msgstr ""
-#: ../vector/v.out.ogr/main.c:458
+#: ../raster/r.sun/main.c:578
 #, c-format
-msgid "OGR driver <%s> not found"
+msgid ""
+"<%d> is not valid number of threads. Number of threads will be set to <%d>"
 msgstr ""
-#: ../vector/v.out.ogr/main.c:485
-#, c-format
-msgid "Unable to open OGR data source '%s'"
+#: ../raster/r.sun/main.c:587
+#, fuzzy, c-format
+msgid "Number of threads <%d>"
+#: ../raster/r.sun/main.c:594
+msgid "You must give the longitude raster if you use civil time"
 msgstr ""
-#: ../vector/v.out.ogr/main.c:499
-#, c-format
-msgid "Layer <%s> already exists in OGR data source '%s'"
+#: ../raster/r.sun/main.c:597
+msgid "Error reading civil time zone value"
 msgstr ""
-#: ../vector/v.out.ogr/main.c:503
-#, c-format
-msgid "OGR layer <%s> already exists and will be overwritten"
+#: ../raster/r.sun/main.c:600
+msgid "Invalid civil time zone value"
 msgstr ""
-#: ../vector/v.out.ogr/main.c:510
-#, c-format
-msgid "OGR layer <%s> doesn't exists, creating new OGR layer instead"
+#: ../raster/r.sun/main.c:625
+msgid "insol_time and incidout are incompatible options"
 msgstr ""
-#: ../vector/v.out.ogr/main.c:538
-msgid "Overriding existing user-defined 'SHPT=' LCO."
+#: ../raster/r.sun/main.c:630
+msgid "Error reading time step size"
 msgstr ""
-#: ../vector/v.out.ogr/main.c:553
-#, c-format
-msgid "Vector map <%s> is 3D. Use format specific layer creation options SHPT (parameter 'lco') or '-z' flag to export in 3D rather than 2D (default)"
+#: ../raster/r.sun/main.c:632
+msgid "Invalid time step size"
 msgstr ""
-#: ../vector/v.out.ogr/main.c:565
-#, c-format
-msgid "Vector map <%s> is 3D. Use format specific layer creation options DIM (parameter 'lco') to export in 3D rather than 2D (default)."
+#: ../raster/r.sun/main.c:636
+msgid "Error reading horizon step size"
 msgstr ""
-#: ../vector/v.out.ogr/main.c:572
-#, c-format
-msgid "Vector map <%s> is 3D. Use format specific layer creation options (parameter 'lco') to export <in 3D rather than 2D (default)."
+#: ../raster/r.sun/main.c:641
+msgid "The horizon step size must be greater than 0."
 msgstr ""
-#: ../vector/v.out.ogr/main.c:589 ../db/drivers/ogr/execute.c:56
-#, c-format
-msgid "OGR layer <%s> not found"
+#: ../raster/r.sun/main.c:644
+msgid ""
+"If you use the horizon option you must also set the 'horizonstep' parameter."
 msgstr ""
-#: ../vector/v.out.ogr/main.c:591
-msgid "Unable to create OGR layer"
+#: ../raster/r.sun/main.c:650
+msgid "Time and insol_time are incompatible options"
 msgstr ""
-#: ../vector/v.out.ogr/main.c:603
-msgid "No attribute table found -> using only category numbers as attributes"
-msgstr "Atribūtu tabula nav atrasta -> tiek izmantoti kategoriju numuri kā atribūti"
+#: ../raster/r.sun/main.c:652
+msgid ""
+"Mode 1: instantaneous solar incidence angle & irradiance using a set local "
+"time"
+msgstr ""
-#: ../vector/v.out.ogr/main.c:607
-msgid "Exporting 'cat' anyway, as it is the only attribute table field"
+#: ../raster/r.sun/main.c:657
+msgid "incidout requires time parameter to be set"
 msgstr ""
-#: ../vector/v.out.ogr/main.c:616 ../vector/v.out.ogr/main.c:688
-#, c-format
-msgid "New attribute column <%s> added to the table"
+#: ../raster/r.sun/main.c:659
+msgid "Mode 2: integrated daily irradiation for a given day of the year"
 msgstr ""
-#: ../vector/v.out.ogr/main.c:700
+#: ../raster/r.sun/main.c:682
 #, c-format
-msgid "Key column <%s> not found"
+msgid "Using Linke constant: %lf"
 msgstr ""
-#: ../vector/v.out.ogr/main.c:713
+#: ../raster/r.sun/main.c:684
 #, c-format
-msgid "Exporting %d feature..."
-msgid_plural "Exporting %d features..."
-msgstr[0] ""
-msgstr[1] ""
-msgstr[2] ""
-#: ../vector/v.out.ogr/main.c:728
-#, c-format
-msgid "Exporting %d area (may take some time)..."
-msgid_plural "Exporting %d areas (may take some time)..."
-msgstr[0] ""
-msgstr[1] ""
-msgstr[2] ""
-#: ../vector/v.out.ogr/main.c:747
-#, c-format
-msgid "Exporting %d volume..."
-msgid_plural "Exporting %d volumes..."
-msgstr[0] ""
-msgstr[1] ""
-msgstr[2] ""
-#: ../vector/v.out.ogr/main.c:751
-msgid "Export of volumes not implemented yet. Skipping."
+msgid "Using Linke map <%s>"
 msgstr ""
-#: ../vector/v.out.ogr/main.c:768
+#: ../raster/r.sun/main.c:689
 #, c-format
-msgid "%d feature without attributes was written"
-msgid_plural "%d features without attributes were written"
-msgstr[0] ""
-msgstr[1] ""
-msgstr[2] ""
-#: ../vector/v.out.ogr/main.c:774
-#, c-format
-msgid "%d feature without category was written"
-msgid_plural "%d features without category were written"
-msgstr[0] ""
-msgstr[1] ""
-msgstr[2] ""
-#: ../vector/v.out.ogr/main.c:778
-#, c-format
-msgid "%d feature without category was skipped. Features without category are written only when -%c flag is given."
-msgid_plural "%d features without category were skipped. Features without category are written only when -%c flag is given."
-msgstr[0] ""
-msgstr[1] ""
-msgstr[2] ""
-#: ../vector/v.out.ogr/main.c:794
-msgid "Output layer is empty, no features written"
+msgid "Using albedo constant: %lf"
 msgstr ""
-#: ../vector/v.out.ogr/main.c:795
+#: ../raster/r.sun/main.c:691
 #, c-format
-msgid "%d feature (%s type) written to <%s> (%s format)."
-msgid_plural "%d features (%s type) written to <%s> (%s format)."
-msgstr[0] ""
-msgstr[1] ""
-msgstr[2] ""
-#: ../vector/v.out.ogr/export_areas.c:143
-#: ../vector/v.out.ogr/export_lines.c:178
-#, c-format
-msgid "Unable to export multi-features. No category index for layer %d."
+msgid "Using albedo map <%s>"
 msgstr ""
-#: ../vector/v.out.ogr/export_areas.c:154
-msgid "Exporting features with category..."
-msgstr ""
-#: ../vector/v.out.ogr/export_areas.c:176
-#: ../vector/v.out.ogr/export_lines.c:212
+#: ../raster/r.sun/main.c:696
 #, c-format
-msgid "Unable to create multi-feature. Category %d not found in line %d, field %d"
+msgid "Using slope constant: %lf"
 msgstr ""
-#: ../vector/v.out.ogr/export_areas.c:214
-msgid "Exporting features without category..."
-msgstr ""
-#: ../vector/v.out.ogr/create.c:20
+#: ../raster/r.sun/main.c:699
 #, c-format
-msgid "OGR driver <%s> not available"
+msgid "Using slope map <%s>"
 msgstr ""
-#: ../vector/v.out.ogr/create.c:26
+#: ../raster/r.sun/main.c:704
 #, c-format
-msgid "Creation of output OGR datasource <%s> failed"
+msgid "Using aspect constant: %lf"
 msgstr ""
-#: ../vector/v.out.ogr/create.c:36
+#: ../raster/r.sun/main.c:707
 #, c-format
-msgid "Creation of OGR layer <%s> failed"
+msgid "Using aspect map <%s>"
 msgstr ""
-#: ../vector/v.type/main.c:44
-msgid "Changes type of vector features."
+#: ../raster/r.sun/main.c:722
+msgid "If you use -s and no horizon rasters, numpartitions must be =1"
 msgstr ""
-#: ../vector/v.type/main.c:57
-msgid "Feature type to convert from"
+#: ../raster/r.sun/main.c:735
+msgid ""
+"If you want to save memory and to use shadows, you must use pre-calculated "
+"horizons."
 msgstr ""
-#: ../vector/v.type/main.c:65
-msgid "Feature type to convert to"
+#: ../raster/r.sun/main.c:802
+msgid "latin and longin raster maps have no effect when in a Lat/Lon location"
 msgstr ""
-#: ../vector/v.type/main.c:120
-msgid "Incompatible types"
+#: ../raster/r.sun/main.c:807
+msgid "Both latin and longin raster maps must be given, or neither"
 msgstr ""
-#: ../vector/v.net.timetable/main.c:218
-#, c-format
-msgid "Could not find a path between stops %d and %d"
+#: ../raster/r.latlong/main.c:57
+msgid "latitude"
 msgstr ""
-#: ../vector/v.net.timetable/main.c:263
-msgid "Finds shortest path using timetables."
+#: ../raster/r.latlong/main.c:58
+msgid "longitude"
 msgstr ""
-#: ../vector/v.net.timetable/main.c:309
-msgid "Layer number or name with walking connections or -1"
+#: ../raster/r.latlong/main.c:60
+msgid "Creates a latitude/longitude raster map."
 msgstr ""
-#: ../vector/v.net.timetable/main.c:315
-msgid "Name of column with route ids"
+#: ../raster/r.latlong/main.c:66
+msgid "Name for output latitude or longitude raster map"
 msgstr ""
-#: ../vector/v.net.timetable/main.c:322
-msgid "Name of column with stop timestamps"
+#: ../raster/r.latlong/main.c:70
+msgid "Longitude output"
 msgstr ""
-#: ../vector/v.net.timetable/main.c:328
-msgid "Name of column with stop ids"
+#: ../raster/r.series.accumulate/main.c:84
+msgid ""
+"Makes each output cell value a accumulationfunction of the values assigned "
+"to the corresponding cells in the input raster map layers."
 msgstr ""
-#: ../vector/v.net.timetable/main.c:334
-msgid "Name of column with walk lengths"
+#: ../raster/r.series.accumulate/main.c:90
+msgid "Existing map to be added to output"
 msgstr ""
-#: ../vector/v.net.timetable/main.c:381
-msgid "Could not initialize the timetables"
+#: ../raster/r.series.accumulate/main.c:98
+msgid "Input file with raster map names, one per line"
 msgstr ""
-#: ../vector/v.net.timetable/main.c:459 ../vector/v.net.timetable/main.c:490
-#: ../vector/v.net.timetable/main.c:498
-#, c-format
-msgid "No stop with category: %d"
+#: ../raster/r.series.accumulate/main.c:109
+msgid "Scale factor for input"
 msgstr ""
-#: ../vector/v.net.timetable/main.c:482 ../vector/v.net.path/path.c:153
-#, c-format
-msgid "Wrong input format: %s"
+#: ../raster/r.series.accumulate/main.c:116
+msgid "Shift factor for input"
 msgstr ""
-#: ../vector/v.net.timetable/main.c:505
-msgid "'From' and 'To' stops are the same"
+#: ../raster/r.series.accumulate/main.c:121
+msgid ""
+"The raster map specifying the lower accumulation limit, also called baseline"
 msgstr ""
-#: ../vector/v.net.timetable/main.c:514
-msgid "No path between the stops"
+#: ../raster/r.series.accumulate/main.c:126
+msgid ""
+"The raster map specifying the upper accumulation limit, also called cutoff. "
+"Only applied to BEDD computation."
 msgstr ""
-#: ../vector/v.label.sa/main.c:41
-msgid "Create optimally placed labels for vector map(s)"
+#: ../raster/r.series.accumulate/main.c:139
+msgid "Use these limits in case lower and/or upper input maps are not defined"
 msgstr ""
-#: ../vector/v.label.sa/main.c:57 ../vector/v.label/main.c:78
-msgid "Name of attribute column to be used for labels"
+#: ../raster/r.series.accumulate/main.c:151
+msgid "Growing Degree Days or Winkler indices"
 msgstr ""
-#: ../vector/v.label.sa/main.c:61 ../vector/v.label/main.c:67
-msgid "Name for new paint-label file"
+#: ../raster/r.series.accumulate/main.c:152
+msgid "Mean: sum(input maps)/(number of input maps)"
 msgstr ""
-#: ../vector/v.label.sa/main.c:71
-#, fuzzy
-msgid "Name of TrueType font (as listed in the fontcap)"
-msgstr "Ceļš līdz TrueType fontam (ieskaitot faila nosaukumu)"
-#: ../vector/v.label.sa/main.c:84
-msgid "Icon size of point features (in map-units)"
+#: ../raster/r.series.accumulate/main.c:153
+msgid "Biologically Effective Degree Days"
 msgstr ""
-#: ../vector/v.label.sa/main.c:117 ../vector/v.label/main.c:180
-msgid "Width of highlight coloring"
+#: ../raster/r.series.accumulate/main.c:154
+msgid "Huglin Heliothermal index"
 msgstr ""
-#: ../vector/v.label.sa/main.c:135 ../vector/v.label/main.c:200
-msgid "Opaque to vector (only relevant if background color is selected)"
+#: ../raster/r.series.accumulate/main.c:167
+msgid "Create a FCELL map (floating point single precision) as output"
 msgstr ""
-#: ../vector/v.label.sa/main.c:154
-msgid "Border width (only for ps.map output)"
+#: ../raster/r.series.accumulate/main.c:354
+#, c-format
+msgid "'%s'=%f must be > '%s'=%f"
 msgstr ""
-#: ../vector/v.label.sa/labels.c:68
-#, fuzzy, c-format
-msgid "Cannot allocate %lu bytes of memory"
-msgstr "Nevar atvērt izvēlēto marķieri/kursoru"
+#: ../raster/r.lake/main.c:153
+msgid "flood"
+msgstr "plūdi"
-#: ../vector/v.label.sa/labels.c:75 ../vector/v.class/main.c:111
-#: ../vector/v.vol.rst/user1.c:95 ../vector/v.label/main.c:274
-#: ../ps/ps.map/catval.c:48 ../ps/ps.map/catval.c:110 ../ps/ps.map/catval.c:176
-msgid "Unable to get layer info for vector map"
+#: ../raster/r.lake/main.c:154
+msgid "Fills lake at given point to given level."
 msgstr ""
-#: ../vector/v.label.sa/labels.c:87
-msgid "Unable to initialise FreeType"
-msgstr ""
+#: ../raster/r.lake/main.c:160
+msgid "Water level"
+msgstr "Ūdens līmenis"
-#: ../vector/v.label.sa/labels.c:90
-#, fuzzy, c-format
-msgid "Unable to find font '%s'\n"
-msgstr "Nevaratvērt datubāzi %s"
+#: ../raster/r.lake/main.c:170
+msgid "Seed point coordinates"
+msgstr "Sākuma punkta koordinātes"
-#: ../vector/v.label.sa/labels.c:92
-#, c-format
-msgid "Font '%s' is not a FreeType font\n"
+#: ../raster/r.lake/main.c:171
+msgid "Either this coordinates pair or a seed map have to be specified"
 msgstr ""
-#: ../vector/v.label.sa/labels.c:96
-msgid "Font file format is not supported by FreeType"
+#: ../raster/r.lake/main.c:175 ../raster/r.lake/main.c:184
+msgid "Seed"
 msgstr ""
-#: ../vector/v.label.sa/labels.c:98
-#, fuzzy
-msgid "Font file can not be loaded"
-msgstr "vektora karte <%s> nav atrasta"
-#: ../vector/v.label.sa/labels.c:107
-#, fuzzy
-msgid "Unable to set font size"
-msgstr "neiespējami atvērt <%s>"
-#: ../vector/v.label.sa/labels.c:128
-#, fuzzy
-msgid "Cannot allocate more memory"
-#: ../vector/v.label.sa/labels.c:162 ../vector/v.overlay/main.c:423
-#: ../vector/v.label/main.c:319
-msgid "Unable to select attributes"
+#: ../raster/r.lake/main.c:180
+msgid "Input raster map with given starting point(s) (at least 1 cell > 0)"
 msgstr ""
-#: ../vector/v.label.sa/labels.c:244
-#, fuzzy, c-format
-msgid "Cannot load glyph for '%c'"
-msgstr "Nevar nolasīt faila informāciju"
-#: ../vector/v.in.db/main.c:55 ../vector/v.out.lidar/main.c:474
-#: ../vector/v.decimate/main.c:129 ../vector/v.kcv/main.c:57
-#: ../vector/v.normal/main.c:74
-msgid "points"
+#: ../raster/r.lake/main.c:182
+msgid "Either this parameter or a coordinates pair have to be specified"
 msgstr ""
-#: ../vector/v.in.db/main.c:57
-msgid "Creates new vector (points) map from database table containing coordinates."
-msgstr ""
+#: ../raster/r.lake/main.c:189
+msgid "Use negative depth values for lake raster map"
+msgstr "Izmantot negatīvas vērtības ezera rastra kartei"
-#: ../vector/v.in.db/main.c:61
-msgid "Input table name"
-msgstr ""
+#: ../raster/r.lake/main.c:194
+msgid "Overwrite seed map with result (lake) map"
+msgstr "Pārrakstīt sākuma punkta karti ar rezultāta (ezera) karti"
-#: ../vector/v.in.db/main.c:66 ../vector/v.in.db/main.c:70
-msgid "Input DB"
+#: ../raster/r.lake/main.c:201
+msgid "Both seed map and coordinates cannot be specified"
 msgstr ""
-#: ../vector/v.in.db/main.c:75
-msgid "Name of column containing x coordinate"
-msgstr ""
+#: ../raster/r.lake/main.c:204
+msgid "Seed map or seed coordinates must be set!"
+msgstr "Sākuma punkta kartei vai koordinātām jābūt uzstādītām!"
-#: ../vector/v.in.db/main.c:80
-msgid "Name of column containing y coordinate"
+#: ../raster/r.lake/main.c:207
+msgid "Seed coordinates and output map lake= must be set!"
 msgstr ""
+"Sākuma punkta koordinātēm un izvades kartei lake= jābūt uz uzstādītiem!"
-#: ../vector/v.in.db/main.c:84
-msgid "Name of column containing z coordinate"
+#: ../raster/r.lake/main.c:210
+msgid "Both lake and overwrite cannot be specified"
 msgstr ""
-#: ../vector/v.in.db/main.c:90
-msgid "Name of column containing category number"
+#: ../raster/r.lake/main.c:213
+msgid "Output lake map or overwrite flag must be set!"
 msgstr ""
+"Izvades kartei lake ir jābūt uzstādītai vai jābūt uzstādītam pārrakstīšanas "
+"karogam!"
-#: ../vector/v.in.db/main.c:91
-msgid "Must refer to an integer column"
+#: ../raster/r.lake/main.c:240
+msgid "Seed point outside the current region"
 msgstr ""
-#: ../vector/v.in.db/main.c:101
-msgid "Use imported table as attribute table for new map"
-msgstr ""
+#: ../raster/r.lake/main.c:254
+msgid "G_malloc: out of memory"
+msgstr "G_malloc: pietrūkst atmiņas"
-#: ../vector/v.in.db/main.c:141
-#, c-format
-msgid "Vector map <%s> cannot be overwritten because input table <%s> is linked to this map."
+#: ../raster/r.lake/main.c:276
+msgid ""
+"Given water level at seed point is below earth surface. Increase water level "
+"or move seed point."
 msgstr ""
-#: ../vector/v.in.db/main.c:177
+#: ../raster/r.lake/main.c:355
 #, c-format
-msgid "Output vector map, table <%s> (driver: <%s>, database: <%s>) already exists"
+msgid "Lake depth from %f to %f (specified water level is taken as zero)"
 msgstr ""
-#: ../vector/v.in.db/main.c:187 ../vector/v.to.3d/trans3.c:65
-#: ../vector/v.to.3d/trans2.c:63 ../vector/v.univar/main.c:355
-#: ../vector/v.out.lidar/main.c:118 ../vector/v.out.lidar/main.c:155
-#: ../vector/v.reclass/main.c:145 ../vector/v.vect.stats/main.c:389
-#: ../vector/v.transform/trans_digit.c:116 ../vector/v.distance/main.c:533
-#: ../vector/v.distance/main.c:574 ../vector/v.db.connect/main.c:289
-#: ../vector/v.colors/scan_attr.c:35 ../vector/v.colors.out/make_colors.c:42
-#: ../db/drivers/ogr/execute.c:69 ../scripts/db.univar/db.univar.py:120
-#: ../scripts/v.db.renamecolumn/v.db.renamecolumn.py:96
-#: ../scripts/v.db.join/v.db.join.py:98 ../scripts/v.db.join/v.db.join.py:106
-#: ../scripts/v.db.join/v.db.join.py:123
-#, c-format, python-format
-msgid "Column <%s> not found in table <%s>"
-msgstr ""
-#: ../vector/v.in.db/main.c:190 ../vector/v.db.connect/main.c:295
-msgid "Data type of key column must be integer"
-msgstr ""
-#: ../vector/v.in.db/main.c:194
+#: ../raster/r.lake/main.c:356
 #, c-format
-msgid "Option <%s> must be specified when -%c flag is given"
-msgstr ""
+msgid "Lake area %f square meters"
+msgstr "Ezera laukums %f kvadrātmetri"
-#: ../vector/v.in.db/main.c:199
+#: ../raster/r.lake/main.c:357
 #, c-format
-msgid "Unable to define key column. This operation is not supported by <%s> driver. You need to define <%s> option."
-msgstr ""
+msgid "Lake volume %f cubic meters"
+msgstr "Ezera tilpums ir %f kubikmetri"
-#: ../vector/v.in.db/main.c:243
-msgid "Key column must be integer"
+#: ../raster/r.lake/main.c:358
+msgid "Volume is correct only if lake depth (terrain raster map) is in meters"
 msgstr ""
+"Uzmanību. Tilpums ir korekts tikai tad, ja dziļums (reljefa karte) ir metros"
-#: ../vector/v.in.db/main.c:256
-msgid "x/y/z column must be integer or double"
+#: ../raster/r.thin/main.c:60
+msgid "Thins non-null cells that denote linear features in a raster map layer."
 msgstr ""
-#: ../vector/v.in.db/main.c:282 ../vector/v.to.3d/main.c:96
-#: ../vector/v.to.3d/main.c:117 ../vector/v.net/main.c:156
-#: ../vector/v.transform/main.c:302
-msgid "Copying attributes..."
+#: ../raster/r.thin/main.c:72
+msgid "Maximal number of iterations"
 msgstr ""
-#: ../vector/v.in.db/main.c:288
-msgid "Unable to copy table"
+#: ../raster/r.thin/thin_lines.c:67
+msgid "Unable to find bounding box for lines"
 msgstr ""
-#: ../vector/v.in.db/main.c:313
+#: ../raster/r.thin/thin_lines.c:69
 #, c-format
-msgid "Unable to add key column <%s>: SERIAL type is not supported by <%s>"
+msgid "Bounding box:  l = %d, r = %d, t = %d, b = %d"
 msgstr ""
-#: ../vector/v.in.db/main.c:324
+#: ../raster/r.thin/thin_lines.c:116
 #, c-format
-msgid "Failed to update key column <%s>"
+msgid "Pass number %d"
 msgstr ""
-#: ../vector/v.in.db/main.c:340
+#: ../raster/r.thin/thin_lines.c:167
 #, c-format
-msgid "%d point written to vector map."
-msgid_plural "%d points written to vector map."
+msgid "Deleted %d pixel"
+msgid_plural "Deleted %d pixels"
 msgstr[0] ""
 msgstr[1] ""
 msgstr[2] ""
-#: ../vector/v.in.dxf/layer_list.c:16
-#, c-format
-msgid "Layer %d: %s\n"
+#: ../raster/r.thin/thin_lines.c:171
+msgid "Thinning completed successfully."
 msgstr ""
-#: ../vector/v.in.dxf/write_vect.c:52
-msgid "Entity handle truncated to 16 characters."
+#: ../raster/r.thin/thin_lines.c:173
+msgid "Thinning not completed, consider to increase 'iterations' parameter."
 msgstr ""
-#: ../vector/v.in.dxf/write_vect.c:70 ../vector/v.in.ascii/points.c:452
-#: ../vector/v.mkgrid/main.c:365 ../vector/v.mkgrid/main.c:463
-#, c-format
-msgid "Unable to insert new record: %s"
+#: ../raster/r.thin/io.c:98
+msgid "Input raster must be of type CELL."
 msgstr ""
-#: ../vector/v.in.dxf/write_vect.c:91
-msgid "No DXF layers found!"
+#. GTC First argument is the raster map name, second and third - a string representing number of rows and cols
+#: ../raster/r.thin/io.c:109
+#, c-format
+msgid "Raster map <%s> - %s X %s"
 msgstr ""
-#: ../vector/v.in.dxf/write_vect.c:100
-msgid "Following DXF layers found:"
+#: ../raster/r.thin/io.c:122
+#, c-format
+msgid "Unable to create temporary file <%s> -- errno = %d"
 msgstr ""
-#: ../vector/v.in.dxf/write_vect.c:104
+#. GTC %s will be replaced with number of rows and columns
+#: ../raster/r.thin/io.c:176
 #, c-format
-msgid "Layer %d: %s"
+msgid "Output map %s X %s"
 msgstr ""
-#: ../vector/v.in.dxf/write_vect.c:246
+#: ../raster/r.thin/io.c:185
 #, c-format
-msgid "Unable to add database link for vector map <%s>"
+msgid "Window %s X %s"
 msgstr ""
-#: ../vector/v.in.dxf/main.c:68
-msgid "Converts file in DXF format to GRASS vector map."
+#: ../locale/scriptstrings/t.vect.list_to_translate.c:1
+msgid "Lists registered maps of a space time vector dataset."
 msgstr ""
-#: ../vector/v.in.dxf/main.c:72
-msgid "Ignore the map extent of DXF file"
+#: ../locale/scriptstrings/t.vect.list_to_translate.c:2
+#: ../locale/scriptstrings/t.rast3d.univar_to_translate.c:2
+#: ../locale/scriptstrings/t.rast.to.rast3_to_translate.c:2
+#: ../locale/scriptstrings/t.rast.export_to_translate.c:2
+#: ../locale/scriptstrings/t.unregister_to_translate.c:2
+#: ../locale/scriptstrings/t.rast3d.mapcalc_to_translate.c:2
+#: ../locale/scriptstrings/t.rast.accdetect_to_translate.c:2
+#: ../locale/scriptstrings/t.vect.extract_to_translate.c:2
+#: ../locale/scriptstrings/t.rename_to_translate.c:2
+#: ../locale/scriptstrings/t.rast.aggregate_to_translate.c:2
+#: ../locale/scriptstrings/t.rast.to.vect_to_translate.c:2
+#: ../locale/scriptstrings/t.rast3d.list_to_translate.c:2
+#: ../locale/scriptstrings/t.rast.series_to_translate.c:2
+#: ../locale/scriptstrings/t.support_to_translate.c:2
+#: ../locale/scriptstrings/t.create_to_translate.c:2
+#: ../locale/scriptstrings/t.snap_to_translate.c:2
+#: ../locale/scriptstrings/t.sample_to_translate.c:2
+#: ../locale/scriptstrings/t.rast.aggregate.ds_to_translate.c:2
+#: ../locale/scriptstrings/t.vect.observe.strds_to_translate.c:2
+#: ../locale/scriptstrings/t.rast.univar_to_translate.c:2
+#: ../locale/scriptstrings/t.rast.gapfill_to_translate.c:2
+#: ../locale/scriptstrings/t.rast.mapcalc_to_translate.c:2
+#: ../locale/scriptstrings/t.vect.export_to_translate.c:2
+#: ../locale/scriptstrings/t.info_to_translate.c:2
+#: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:2
+#: ../locale/scriptstrings/t.rast3d.extract_to_translate.c:2
+#: ../locale/scriptstrings/t.register_to_translate.c:2
+#: ../locale/scriptstrings/t.vect.what.strds_to_translate.c:2
+#: ../locale/scriptstrings/t.rast.list_to_translate.c:2
+#: ../locale/scriptstrings/t.rast.contour_to_translate.c:2
+#: ../locale/scriptstrings/t.rast.colors_to_translate.c:2
+#: ../locale/scriptstrings/t.rast.algebra_to_translate.c:2
+#: ../locale/scriptstrings/t.merge_to_translate.c:2
+#: ../locale/scriptstrings/v.what.strds_to_translate.c:3
+#: ../locale/scriptstrings/t.shift_to_translate.c:2
+#: ../locale/scriptstrings/t.remove_to_translate.c:2
+#: ../locale/scriptstrings/t.topology_to_translate.c:2
+#: ../locale/scriptstrings/t.select_to_translate.c:2
+#: ../locale/scriptstrings/t.rast.what_to_translate.c:2
+#: ../locale/scriptstrings/t.list_to_translate.c:2
+#: ../locale/scriptstrings/t.rast.extract_to_translate.c:2
+#: ../locale/scriptstrings/t.rast.import_to_translate.c:2
+#: ../locale/scriptstrings/t.vect.import_to_translate.c:2
+#: ../locale/scriptstrings/t.rast3d.algebra_to_translate.c:2
+#: ../locale/scriptstrings/t.vect.db.select_to_translate.c:2
+#: ../locale/scriptstrings/t.vect.univar_to_translate.c:2
+#: ../locale/scriptstrings/t.vect.algebra_to_translate.c:2
+#: ../locale/scriptstrings/t.rast.out.vtk_to_translate.c:2
+#: ../locale/scriptstrings/t.rast.neighbors_to_translate.c:2
+#: ../temporal/t.connect/main.c:34
+msgid "temporal"
 msgstr ""
-#: ../vector/v.in.dxf/main.c:80
-msgid "Import polyface meshes as 3D wire frame"
+#: ../locale/scriptstrings/t.vect.list_to_translate.c:5
+#: ../locale/scriptstrings/t.rast3d.list_to_translate.c:4
+#: ../locale/scriptstrings/t.rast.list_to_translate.c:5
+#: ../locale/scriptstrings/t.list_to_translate.c:4 ../general/g.list/main.c:67
+msgid "list"
+msgstr "saraksts"
+#: ../locale/scriptstrings/t.vect.list_to_translate.c:7
+#: ../locale/scriptstrings/t.rast.list_to_translate.c:7
+#: ../locale/scriptstrings/t.list_to_translate.c:10
+msgid "Sort the space time dataset by category"
 msgstr ""
-#: ../vector/v.in.dxf/main.c:84
-msgid "List available DXF layers and exit"
+#: ../locale/scriptstrings/t.vect.list_to_translate.c:9
+#: ../locale/scriptstrings/t.rast3d.list_to_translate.c:9
+#: ../locale/scriptstrings/t.rast.list_to_translate.c:9
+#: ../locale/scriptstrings/t.list_to_translate.c:13
+msgid "Columns to be printed to stdout"
 msgstr ""
-#: ../vector/v.in.dxf/main.c:85 ../vector/v.in.dxf/main.c:92
-#: ../vector/v.in.dxf/main.c:97 ../vector/v.in.dxf/main.c:110
-msgid "DXF layers"
+#: ../locale/scriptstrings/t.vect.list_to_translate.c:12
+#: ../locale/scriptstrings/t.rast3d.list_to_translate.c:12
+#: ../locale/scriptstrings/t.rast.list_to_translate.c:12
+msgid "Method used for data listing"
 msgstr ""
-#: ../vector/v.in.dxf/main.c:91
-msgid "Invert selection by DXF layers (don't import layers in list)"
+#: ../locale/scriptstrings/t.vect.list_to_translate.c:13
+#: ../locale/scriptstrings/t.rast3d.univar_to_translate.c:8
+#: ../locale/scriptstrings/t.rast3d.list_to_translate.c:13
+#: ../locale/scriptstrings/t.rast.univar_to_translate.c:7
+#: ../locale/scriptstrings/t.rast.list_to_translate.c:14
+#: ../locale/scriptstrings/t.list_to_translate.c:16
+#: ../locale/scriptstrings/t.vect.db.select_to_translate.c:8
+#: ../locale/scriptstrings/t.vect.univar_to_translate.c:8
+msgid "Field separator character between the output columns"
 msgstr ""
-#: ../vector/v.in.dxf/main.c:96
-msgid "Import all objects into one layer"
+#: ../locale/scriptstrings/t.vect.list_to_translate.c:15
+#: ../locale/scriptstrings/t.rast3d.univar_to_translate.c:11
+#: ../locale/scriptstrings/t.rast3d.list_to_translate.c:15
+#: ../locale/scriptstrings/t.rast.univar_to_translate.c:11
+#: ../locale/scriptstrings/t.rast.list_to_translate.c:16
+#: ../locale/scriptstrings/t.vect.univar_to_translate.c:11
+msgid "Suppress printing of column names"
 msgstr ""
-#: ../vector/v.in.dxf/main.c:100
-msgid "Path to input DXF file"
+#: ../locale/scriptstrings/r.buffer.lowmem_to_translate.c:2
+msgid "This is the low-memory alternative to the classic r.buffer module."
 msgstr ""
-#: ../vector/v.in.dxf/main.c:109
-msgid "List of DXF layers to import (default: all)"
+msgid ""
+"Calculates univariate statistics from the non-null cells for each registered "
+"3D raster map of a space time 3D raster dataset."
 msgstr ""
-#: ../vector/v.in.dxf/main.c:124
-msgid "Please specify list of DXF layers to exclude"
+#: ../locale/scriptstrings/t.rast.to.rast3_to_translate.c:1
+msgid "Converts a space time raster dataset into a 3D raster map."
 msgstr ""
-#: ../vector/v.in.dxf/main.c:128
-#, c-format
-msgid "Unable to open DXF file <%s>"
+#: ../locale/scriptstrings/d.what.vect_to_translate.c:1
+msgid ""
+"Allows the user to interactively query vector map layers at user-selected "
+"locations."
 msgstr ""
-#: ../vector/v.in.dxf/main.c:131
-msgid "Layer number: layer name / GRASS compliant name"
+#: ../locale/scriptstrings/d.what.vect_to_translate.c:2
+#: ../locale/scriptstrings/d.correlate_to_translate.c:2
+#: ../locale/scriptstrings/d.out.file_to_translate.c:2
+#: ../locale/scriptstrings/d.shade_to_translate.c:2
+#: ../locale/scriptstrings/d.frame_to_translate.c:2
+#: ../locale/scriptstrings/d.rast.edit_to_translate.c:2
+#: ../locale/scriptstrings/d.redraw_to_translate.c:2
+#: ../locale/scriptstrings/wxpyimgview_to_translate.c:2
+#: ../locale/scriptstrings/d.rast.leg_to_translate.c:2
+#: ../locale/scriptstrings/d.to.rast_to_translate.c:2
+#: ../locale/scriptstrings/d.polar_to_translate.c:2
+#: ../locale/scriptstrings/d.what.rast_to_translate.c:2
+#: ../general/g.cairocomp/main.c:197 ../general/g.ppmtopng/main.c:118
+#: ../general/g.pnmcomp/main.c:283 ../raster3d/r3.mkdspf/main.c:80
+#: ../visualization/ximgview/main.c:290 ../display/d.where/main.c:43
+#: ../display/d.erase/main.c:29 ../display/d.geodesic/main.c:46
+#: ../display/d.legend/main.c:78 ../display/d.linegraph/main.c:231
+#: ../display/d.his/main.c:62 ../display/d.vect.chart/main.c:63
+#: ../display/d.rgb/main.c:53 ../display/d.rhumbline/main.c:44
+#: ../display/d.title/main.c:49 ../display/d.profile/main.c:191
+#: ../display/d.mon/main.c:50 ../display/d.vect.thematic/main.c:85
+#: ../display/d.extract/main.c:49 ../display/d.info/main.c:34
+#: ../display/d.colortable/main.c:60 ../display/d.rast.num/main.c:77
+#: ../display/d.barscale/main.c:63 ../display/d.fontlist/main.c:45
+#: ../display/d.northarrow/main.c:46 ../display/d.labels/main.c:43
+#: ../display/d.histogram/main.c:83 ../display/d.vect/main.c:73
+#: ../display/d.legend.vect/main.c:50 ../display/d.text/main.c:139
+#: ../display/d.path/main.c:48 ../display/d.rast.arrow/main.c:97
+#: ../display/d.colorlist/main.c:35 ../display/d.grid/main.c:53
+#: ../display/d.rast/main.c:53 ../display/d.font/main.c:45
+#: ../display/d.graph/main.c:58
+msgid "display"
 msgstr ""
-#: ../vector/v.in.dxf/main.c:165
-msgid "Building topology failed"
+#: ../locale/scriptstrings/t.rast.export_to_translate.c:1
+msgid "Exports space time raster dataset."
 msgstr ""
-#: ../vector/v.in.dxf/main.c:171
-msgid "Failed to import DXF file!"
+#: ../locale/scriptstrings/t.rast.export_to_translate.c:6
+msgid "Name of a space time raster dataset archive"
 msgstr ""
-#: ../vector/v.in.dxf/add_polyline.c:47
-msgid "vertices following flag missing"
+#: ../locale/scriptstrings/t.rast.export_to_translate.c:7
+#: ../locale/scriptstrings/t.vect.export_to_translate.c:7
+msgid "Path to the work directory, default is /tmp"
 msgstr ""
-#: ../vector/v.in.dxf/read_dxf.c:57
-msgid "end of file while looking for HEADER"
+#: ../locale/scriptstrings/t.rast.export_to_translate.c:8
+#: ../locale/scriptstrings/t.vect.export_to_translate.c:8
+msgid "Compression method of the tar archive"
 msgstr ""
-#: ../vector/v.sample/main.c:79
-msgid "Samples a raster map at vector point locations."
+#: ../locale/scriptstrings/t.rast.export_to_translate.c:9
+msgid "The export format of a single raster map"
 msgstr ""
-#: ../vector/v.sample/main.c:89
-msgid "Name of attribute column to use for comparison"
+#: ../locale/scriptstrings/t.rast.export_to_translate.c:10
+msgid ""
+"Supported are GTiff, AAIGrid via r.out.gdal and the GRASS package format of "
+"r.pack"
 msgstr ""
-#: ../vector/v.sample/main.c:92
-msgid "Name for output vector map to store differences"
+#: ../locale/scriptstrings/t.rast.export_to_translate.c:12
+msgid "Supported only for GTiff"
 msgstr ""
-#: ../vector/v.sample/main.c:96
-msgid "Name of raster map to be sampled"
+#: ../locale/scriptstrings/t.unregister_to_translate.c:1
+msgid ""
+"Unregisters raster, vector and raster3d maps from the temporal database or a "
+"specific space time dataset."
 msgstr ""
-#: ../vector/v.sample/main.c:107
-msgid "Scaling factor for values read from raster map"
+#: ../locale/scriptstrings/t.unregister_to_translate.c:4
+msgid "unregister"
 msgstr ""
-#: ../vector/v.sample/main.c:109
-msgid "Sampled values will be multiplied by this factor"
+#: ../locale/scriptstrings/t.unregister_to_translate.c:6
+#: ../locale/scriptstrings/t.register_to_translate.c:10
+msgid "Input file with map names, one per line"
 msgstr ""
-#: ../vector/v.sample/main.c:148
-#, c-format
-msgid "Column type <%s> not supported (must be integer or double precision)"
+#: ../locale/scriptstrings/t.unregister_to_translate.c:7
+#: ../locale/scriptstrings/t.register_to_translate.c:8
+msgid "input,maps"
 msgstr ""
-#: ../vector/v.sample/main.c:154
-#, c-format
-msgid "%d record selected from table"
-msgid_plural "%d records selected from table"
-msgstr[0] ""
-msgstr[1] ""
-msgstr[2] ""
-#: ../vector/v.sample/main.c:190 ../vector/v.patch/main.c:320
-#: ../scripts/v.db.addtable/v.db.addtable.py:137
-msgid "Unable to create table <%s>"
+#: ../locale/scriptstrings/t.unregister_to_translate.c:8
+msgid "Name(s) of existing raster, vector or raster3d map(s) to unregister"
 msgstr ""
-#: ../vector/v.sample/main.c:263 ../vector/v.kcv/main.c:284
-#, c-format
-msgid "Unable to insert row: %s"
+#: ../locale/scriptstrings/t.rast3d.mapcalc_to_translate.c:1
+msgid ""
+"Performs r3.mapcalc expressions on maps of sampled space time 3D raster "
+"datasets."
 msgstr ""
-#: ../vector/v.build.polylines/main.c:116
-msgid "Builds polylines from lines or boundaries."
+#: ../locale/scriptstrings/t.rast3d.mapcalc_to_translate.c:7
+msgid "r3.mapcalc expression applied to each time step of the sampled data"
 msgstr ""
-#: ../vector/v.build.polylines/main.c:126
-msgid "Category number mode"
+#: ../locale/scriptstrings/t.rast3d.mapcalc_to_translate.c:8
+#: ../locale/scriptstrings/t.rast.accdetect_to_translate.c:14
+#: ../locale/scriptstrings/t.vect.extract_to_translate.c:6
+#: ../locale/scriptstrings/t.rast.aggregate_to_translate.c:6
+#: ../locale/scriptstrings/t.rast.to.vect_to_translate.c:8
+#: ../locale/scriptstrings/t.rast.aggregate.ds_to_translate.c:8
+#: ../locale/scriptstrings/t.rast.gapfill_to_translate.c:6
+#: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:13
+#: ../locale/scriptstrings/t.rast.contour_to_translate.c:7
+#: ../locale/scriptstrings/t.rast.algebra_to_translate.c:7
+#: ../locale/scriptstrings/t.rast.extract_to_translate.c:7
+#: ../locale/scriptstrings/t.rast.import_to_translate.c:7
+#: ../locale/scriptstrings/t.vect.import_to_translate.c:7
+#: ../locale/scriptstrings/t.rast3d.algebra_to_translate.c:8
+#: ../locale/scriptstrings/t.vect.algebra_to_translate.c:7
+#: ../locale/scriptstrings/t.rast.neighbors_to_translate.c:8
+msgid "Basename of the new generated output maps"
 msgstr ""
-#: ../vector/v.build.polylines/main.c:131
-msgid "Do not assign any category number to polyline"
+#: ../locale/scriptstrings/t.rast3d.mapcalc_to_translate.c:9
+#: ../locale/scriptstrings/t.rast.accdetect_to_translate.c:15
+#: ../locale/scriptstrings/t.vect.extract_to_translate.c:7
+#: ../locale/scriptstrings/t.rast.to.vect_to_translate.c:9
+#: ../locale/scriptstrings/t.rast.aggregate.ds_to_translate.c:9
+#: ../locale/scriptstrings/t.rast.gapfill_to_translate.c:7
+#: ../locale/scriptstrings/t.rast.mapcalc_to_translate.c:8
+#: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:14
+#: ../locale/scriptstrings/t.rast.contour_to_translate.c:8
+#: ../locale/scriptstrings/t.rast.algebra_to_translate.c:8
+#: ../locale/scriptstrings/t.rast.extract_to_translate.c:8
+#: ../locale/scriptstrings/t.rast.import_to_translate.c:8
+#: ../locale/scriptstrings/t.vect.import_to_translate.c:8
+#: ../locale/scriptstrings/t.rast3d.algebra_to_translate.c:9
+#: ../locale/scriptstrings/t.vect.algebra_to_translate.c:8
+#: ../locale/scriptstrings/t.rast.neighbors_to_translate.c:9
+msgid ""
+"A numerical suffix separated by an underscore will be attached to create a "
+"unique identifier"
 msgstr ""
-#: ../vector/v.build.polylines/main.c:132
-msgid "Assign category number of first line to polyline"
+#: ../locale/scriptstrings/t.rast3d.mapcalc_to_translate.c:10
+#: ../locale/scriptstrings/t.rast3d.extract_to_translate.c:10
+#: ../locale/scriptstrings/t.rast3d.algebra_to_translate.c:10
+msgid "Number of r3.mapcalc processes to run in parallel"
 msgstr ""
-#: ../vector/v.build.polylines/main.c:133
-msgid "Assign multiple category numbers to polyline"
+#: ../locale/scriptstrings/t.rast3d.mapcalc_to_translate.c:11
+#: ../locale/scriptstrings/t.rast.aggregate_to_translate.c:14
+#: ../locale/scriptstrings/t.rast.aggregate.ds_to_translate.c:14
+#: ../locale/scriptstrings/t.rast.mapcalc_to_translate.c:10
+#: ../locale/scriptstrings/t.rast3d.extract_to_translate.c:11
+#: ../locale/scriptstrings/t.rast.algebra_to_translate.c:11
+#: ../locale/scriptstrings/t.rast.extract_to_translate.c:11
+#: ../locale/scriptstrings/t.rast3d.algebra_to_translate.c:12
+#: ../locale/scriptstrings/t.rast.neighbors_to_translate.c:12
+msgid "Register Null maps"
 msgstr ""
-#: ../vector/v.build.polylines/main.c:134
-msgid "Create polyline from lines with same categories"
+#: ../locale/scriptstrings/t.rast3d.mapcalc_to_translate.c:12
+#: ../locale/scriptstrings/t.rast.mapcalc_to_translate.c:11
+#: ../locale/scriptstrings/t.rast.algebra_to_translate.c:10
+#: ../locale/scriptstrings/t.rast3d.algebra_to_translate.c:11
+#: ../locale/scriptstrings/t.vect.algebra_to_translate.c:9
+msgid ""
+"Check the spatial topology of temporally related maps and process only "
+"spatially related maps"
 msgstr ""
-#: ../vector/v.build.polylines/main.c:231
-#, c-format
-msgid "%d line or boundaries found in input vector map"
-msgid_plural "%d lines or boundaries found in input vector map"
-msgstr[0] ""
-msgstr[1] ""
-msgstr[2] ""
-#: ../vector/v.build.polylines/main.c:234
-#, c-format
-msgid "%d polyline stored in output vector map"
-msgid_plural "%d polylines stored in output vector map"
-msgstr[0] ""
-msgstr[1] ""
-msgstr[2] ""
-#: ../vector/v.class/main.c:50
-msgid "Classifies attribute data, e.g. for thematic mapping"
+#: ../locale/scriptstrings/db.out.ogr_to_translate.c:1
+msgid "Exports attribute tables into various formats."
 msgstr ""
-#: ../vector/v.class/main.c:58
-msgid "Column name or expression"
+#: ../locale/scriptstrings/db.out.ogr_to_translate.c:5
+msgid "GRASS table name"
 msgstr ""
-#: ../vector/v.class/main.c:93
-msgid "Print only class breaks (without min and max)"
+#: ../locale/scriptstrings/db.out.ogr_to_translate.c:6
+msgid "Output table file name or DB connection string"
 msgstr ""
-#: ../vector/v.class/main.c:138
-msgid "Unable to sort array of values"
+#: ../locale/scriptstrings/db.out.ogr_to_translate.c:7
+msgid "Table format"
 msgstr ""
-#: ../vector/v.class/main.c:173
-msgid "The discontinuities algorithm indicates that some class breaks are not statistically significant at alpha=0.05. You are advised to reduce the number of classes."
+#: ../locale/scriptstrings/db.out.ogr_to_translate.c:8
+msgid "Name for output table (default: input name)"
 msgstr ""
-#: ../vector/v.class/main.c:201
-#, c-format
 msgid ""
-"\n"
-"Classification of %s into %i classes\n"
+"Detects accumulation patterns in temporally accumulated space time raster "
+"datasets created by t.rast.accumulate."
 msgstr ""
-#: ../vector/v.class/main.c:208
-#, c-format
-msgid "Lowest chi2 = %f\n"
+#: ../locale/scriptstrings/t.rast.accdetect_to_translate.c:6
+msgid ""
+"Input space time raster dataset that specifies the minimum values to detect "
+"the accumulation pattern"
 msgstr ""
-#: ../vector/v.class/main.c:214
-#, c-format
+#: ../locale/scriptstrings/t.rast.accdetect_to_translate.c:7
 msgid ""
-"%15s%15s%15s\n"
-"\n"
+"Input space time raster dataset that specifies the maximum values to detect "
 msgstr ""
-#: ../vector/v.class/main.c:226
-#, c-format
+#: ../locale/scriptstrings/t.rast.accdetect_to_translate.c:8
 msgid ""
-"\n"
-"Note: Minimum of first class is including\n"
-"\n"
+"The output space time raster dataset that stores the occurrence of the the "
+"accumulation pattern using the provided data range"
 msgstr ""
-#: ../vector/v.net.alloc/main.c:61
-msgid "Allocates subnets for nearest centers (direction from center)."
+#: ../locale/scriptstrings/t.rast.accdetect_to_translate.c:9
+msgid ""
+"The output space time raster dataset that stores the indication of the "
+"start, intermediate and end of the specified data range"
 msgstr ""
-#: ../vector/v.net.alloc/main.c:63
-msgid "center node must be opened (costs >= 0). Costs of center node are used in calculation"
+#: ../locale/scriptstrings/t.rast.accdetect_to_translate.c:10
+#: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:8
+msgid "The temporal starting point to begin the accumulation, eg '2001-01-01'"
 msgstr ""
-#: ../vector/v.net.alloc/main.c:76
-msgid "Use costs from centers or costs to centers"
+#: ../locale/scriptstrings/t.rast.accdetect_to_translate.c:11
+#: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:9
+msgid "The temporal date to stop the accumulation, eg '2009-01-01'"
 msgstr ""
-#: ../vector/v.net.alloc/main.c:83 ../vector/v.net.iso/main.c:89
-msgid "Categories of centers (points on nodes) to which net will be allocated, layer for this categories is given by nlayer option"
+#: ../locale/scriptstrings/t.rast.accdetect_to_translate.c:12
+#: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:10
+msgid "The temporal cycle to restart the accumulation, eg '12 months'"
 msgstr ""
-#: ../vector/v.net.alloc/main.c:129 ../vector/v.net.path/main.c:110
-#: ../vector/v.net.iso/main.c:137 ../vector/v.net.salesman/main.c:181
-msgid "Use turntable"
+#: ../locale/scriptstrings/t.rast.accdetect_to_translate.c:13
+msgid "The temporal offset to the begin of the next cycle, eg '6 months'"
 msgstr ""
-#: ../vector/v.net.alloc/main.c:130 ../vector/v.net.alloc/main.c:138
-#: ../vector/v.net.alloc/main.c:146 ../vector/v.net.path/main.c:111
-#: ../vector/v.net.path/main.c:119 ../vector/v.net.path/main.c:127
-#: ../vector/v.net.iso/main.c:138 ../vector/v.net.iso/main.c:146
-#: ../vector/v.net.iso/main.c:154 ../vector/v.net/args.c:64
-#: ../vector/v.net/args.c:111 ../vector/v.net/args.c:123
-#: ../vector/v.net.salesman/main.c:182 ../vector/v.net.salesman/main.c:189
-#: ../vector/v.net.salesman/main.c:196
-msgid "Turntable"
+#: ../locale/scriptstrings/t.rast.accdetect_to_translate.c:16
+msgid ""
+"Suffix to add at basename: set 'gran' for granularity, 'time' for the full "
+"time format, 'count' for numerical suffix with a specific number of digits "
+"(default %05)"
 msgstr ""
-#: ../vector/v.net.alloc/main.c:135 ../vector/v.net.path/main.c:116
-#: ../vector/v.net.iso/main.c:143 ../vector/v.net.salesman/main.c:187
-msgid "Layer with turntable"
+#: ../locale/scriptstrings/t.rast.accdetect_to_translate.c:17
+msgid ""
+"The minimum and maximum value of the occurrence of accumulated values, these "
+"values will be used if the min/max space time raster datasets are not "
+"specified"
 msgstr ""
-#: ../vector/v.net.alloc/main.c:137 ../vector/v.net.alloc/main.c:145
-#: ../vector/v.net.path/main.c:118 ../vector/v.net.path/main.c:126
-#: ../vector/v.net.iso/main.c:145 ../vector/v.net.iso/main.c:153
-#: ../vector/v.net.salesman/main.c:188 ../vector/v.net.salesman/main.c:195
-msgid "Relevant only with -t flag"
+#: ../locale/scriptstrings/t.rast.accdetect_to_translate.c:18
+msgid ""
+"The user defined values that indicate start, intermediate and end status in "
+"the indicator output space time raster dataset"
 msgstr ""
-#: ../vector/v.net.alloc/main.c:143 ../vector/v.net.path/main.c:124
-#: ../vector/v.net.iso/main.c:151 ../vector/v.net/args.c:114
-#: ../vector/v.net.salesman/main.c:194
-msgid "Layer with unique categories used in turntable"
+#: ../locale/scriptstrings/t.rast.accdetect_to_translate.c:19
+#: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:21
+msgid ""
+"Register empty maps in the output space time raster dataset, otherwise they "
+"will be deleted"
 msgstr ""
-#: ../vector/v.net.alloc/main.c:212 ../vector/v.net.iso/main.c:241
-#: ../vector/v.net.salesman/main.c:277
-msgid "Point is not connected to the network"
+#: ../locale/scriptstrings/t.rast.accdetect_to_translate.c:20
+#: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:22
+msgid "Reverse time direction in cyclic accumulation"
 msgstr ""
-#: ../vector/v.net.alloc/main.c:238
-#, c-format
-msgid "Number of centers: [%d] (nlayer: [%d])"
+#: ../locale/scriptstrings/v.db.univar_to_translate.c:1
+msgid ""
+"Calculates univariate statistics on selected table column for a GRASS vector "
+"map."
 msgstr ""
-#: ../vector/v.net.alloc/main.c:241
-msgid "Not enough centers for selected nlayer. Nothing will be allocated."
+#: ../locale/scriptstrings/v.db.univar_to_translate.c:5
+#: ../locale/scriptstrings/db.univar_to_translate.c:5
+msgid ""
+"Name of attribute column on which to calculate statistics (must be numeric)"
 msgstr ""
-#: ../vector/v.net.alloc/main.c:256 ../vector/v.net.alloc/main.c:262
-msgid "Calculating costs from centers ..."
+#: ../locale/scriptstrings/v.db.univar_to_translate.c:7
+#: ../locale/scriptstrings/db.univar_to_translate.c:7
+msgid "Extended statistics (quartiles and 90th percentile)"
 msgstr ""
-#: ../vector/v.net.alloc/main.c:266
-msgid "Calculating costs to centers ..."
+#: ../locale/scriptstrings/v.db.univar_to_translate.c:8
+#: ../locale/scriptstrings/db.univar_to_translate.c:8
+msgid "Print stats in shell script style"
 msgstr ""
-#: ../vector/v.net.alloc/main.c:394 ../vector/v.net.alloc/main.c:406
-#: ../vector/v.net.iso/main.c:618
-msgid "Cannot get line segment, segment out of line"
+#: ../locale/scriptstrings/r.fillnulls_to_translate.c:1
+msgid "Fills no-data areas in raster maps using spline interpolation."
 msgstr ""
-#: ../vector/v.external/args.c:14
-msgid "Name of input OGR or PostGIS data source"
+#: ../locale/scriptstrings/r.fillnulls_to_translate.c:6
+msgid "Spline tension parameter"
 msgstr ""
-#: ../vector/v.external/args.c:15 ../vector/v.external.out/args.c:15
-msgid ""
-"Examples:\n"
-"\t\tESRI Shapefile: directory containing a shapefile\n"
-"\t\tMapInfo File: directory containing a mapinfo file\n"
-"\t\tPostGIS database: connection string, eg. 'PG:dbname=db user=grass'"
+#: ../locale/scriptstrings/r.fillnulls_to_translate.c:7
+#: ../locale/scriptstrings/r.fillnulls_to_translate.c:9
+#: ../locale/scriptstrings/r.fillnulls_to_translate.c:11
+#: ../locale/scriptstrings/r.fillnulls_to_translate.c:13
+#: ../locale/scriptstrings/r.fillnulls_to_translate.c:15
+msgid "RST options"
 msgstr ""
-#: ../vector/v.external/args.c:27
-msgid "Name of OGR layer or PostGIS feature table to be linked"
+#: ../locale/scriptstrings/r.fillnulls_to_translate.c:8
+msgid "Spline smoothing parameter"
 msgstr ""
-#: ../vector/v.external/args.c:28
-msgid ""
-"Examples:\n"
-"\t\tESRI Shapefile: shapefile name\n"
-"\t\tMapInfo File: mapinfo file name\n"
-"\t\tPostGIS database: table name"
+#: ../locale/scriptstrings/r.fillnulls_to_translate.c:10
+msgid "Width of hole edge used for interpolation (in cells)"
 msgstr ""
-#: ../vector/v.external/args.c:40
-msgid "Name for output GRASS vector map (default: input layer)"
+#: ../locale/scriptstrings/r.fillnulls_to_translate.c:17
+msgid "Used in bilinear and bicubic spline interpolation"
 msgstr ""
-#: ../vector/v.external/args.c:57
-msgid "List available layers in data source and exit"
+#: ../locale/scriptstrings/r.fillnulls_to_translate.c:18
+msgid "Spline options"
 msgstr ""
-#: ../vector/v.external/args.c:63
-msgid "List available layers including feature type in data source and exit"
+#: ../locale/scriptstrings/v.in.mapgen_to_translate.c:1
+msgid "Imports Mapgen or Matlab-ASCII vector maps into GRASS."
 msgstr ""
-#: ../vector/v.external/args.c:65
-msgid "Format: layer name,type,projection check,geometry"
+#: ../locale/scriptstrings/v.in.mapgen_to_translate.c:4
+msgid "Input map is in Matlab format"
 msgstr ""
-#: ../vector/v.external/dsn.c:21 ../vector/v.in.ogr/dsn.c:21
-msgid "Invalid connection string (dbname missing)"
+#: ../locale/scriptstrings/v.in.mapgen_to_translate.c:5
+msgid "Create a 3D vector points map from 3 column Matlab data"
 msgstr ""
-#: ../vector/v.external/main.c:55
-msgid "Creates a new pseudo-vector map as a link to an OGR-supported layer or a PostGIS feature table."
+#: ../locale/scriptstrings/v.in.mapgen_to_translate.c:6
+msgid "Name of input file in Mapgen/Matlab format"
 msgstr ""
-#: ../vector/v.external/main.c:74 ../vector/v.external.out/format.c:22
-msgid "Environment variable GRASS_VECTOR_OGR defined, but GRASS is compiled with OGR support. Using GRASS-PostGIS data driver instead."
+#: ../locale/scriptstrings/v.in.mapgen_to_translate.c:7
+msgid "Name for output vector map (omit for display to stdout)"
 msgstr ""
-#: ../vector/v.external/main.c:79 ../vector/v.external.out/format.c:27
-msgid "GRASS is not compiled with PostgreSQL support. Using OGR-PostgreSQL driver instead of native GRASS-PostGIS data driver."
+#: ../locale/scriptstrings/d.correlate_to_translate.c:1
+msgid "Prints a graph of the correlation between raster maps (in pairs)."
 msgstr ""
-#: ../vector/v.external/main.c:120 ../vector/v.in.ogr/main.c:479
-#, c-format
-msgid "Layer <%s> not available"
+#: ../locale/scriptstrings/d.correlate_to_translate.c:5
+#: ../locale/scriptstrings/d.polar_to_translate.c:3
+msgid "diagram"
 msgstr ""
-#: ../vector/v.external/main.c:122
-msgid "No layer defined"
+#: ../locale/scriptstrings/d.correlate_to_translate.c:6
+msgid "correlation"
 msgstr ""
-#: ../vector/v.external/main.c:169
-#, c-format
-msgid "Unable to delete '%s'"
+#: ../locale/scriptstrings/r.shade_to_translate.c:1
+#: ../locale/scriptstrings/d.shade_to_translate.c:1
+msgid "Drapes a color raster over an shaded relief or aspect map."
 msgstr ""
-#: ../vector/v.external/main.c:176
-#, c-format
-msgid "Unable to create file '%s/%s'"
-msgstr ""
+#: ../locale/scriptstrings/r.shade_to_translate.c:6
+#: ../locale/scriptstrings/d.shade_to_translate.c:6
+#: ../misc/m.nviz.script/main.c:74 ../misc/m.nviz.image/main.c:51
+#: ../visualization/ximgview/main.c:294
+msgid "visualization"
+msgstr "vizualizācija"
-#: ../vector/v.external/main.c:210
-#, c-format
-msgid "Link to vector map <%s> created."
+#: ../locale/scriptstrings/r.shade_to_translate.c:7
+#: ../lo
